[PATCH 1/4] mmc: fsl_esdhc_imx: Add a compatible for i.MX51
Add a compatible for i.MX51 so that i.MX51 can use this driver via driver model.
Signed-off-by: Fabio Estevam festevam@gmail.com --- drivers/mmc/fsl_esdhc_imx.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 8ac859797f04..827a6f113f3b 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -1705,6 +1705,7 @@ static struct esdhc_soc_data usdhc_imx8qm_data = { };
static const struct udevice_id fsl_esdhc_ids[] = { + { .compatible = "fsl,imx51-esdhc", }, { .compatible = "fsl,imx53-esdhc", }, { .compatible = "fsl,imx6ul-usdhc", }, { .compatible = "fsl,imx6sx-usdhc", },
Import the imx51-babbage devicetree files from Linux kernel version 5.11-rc7.
This is in preparation for converting the mx51evk_defconfig target to driver model.
Signed-off-by: Fabio Estevam festevam@gmail.com --- arch/arm/dts/imx51-babbage.dts | 726 +++++++++++++++++++++++++++++++ arch/arm/dts/imx51-pinfunc.h | 768 +++++++++++++++++++++++++++++++++ arch/arm/dts/imx51.dtsi | 654 ++++++++++++++++++++++++++++ 3 files changed, 2148 insertions(+) create mode 100644 arch/arm/dts/imx51-babbage.dts create mode 100644 arch/arm/dts/imx51-pinfunc.h create mode 100644 arch/arm/dts/imx51.dtsi
diff --git a/arch/arm/dts/imx51-babbage.dts b/arch/arm/dts/imx51-babbage.dts new file mode 100644 index 000000000000..552196d8a60a --- /dev/null +++ b/arch/arm/dts/imx51-babbage.dts @@ -0,0 +1,726 @@ +// SPDX-License-Identifier: GPL-2.0+ +// +// Copyright 2011 Freescale Semiconductor, Inc. +// Copyright 2011 Linaro Ltd. + +/dts-v1/; +#include "imx51.dtsi" + +/ { + model = "Freescale i.MX51 Babbage Board"; + compatible = "fsl,imx51-babbage", "fsl,imx51"; + + chosen { + stdout-path = &uart1; + }; + + memory@90000000 { + device_type = "memory"; + reg = <0x90000000 0x20000000>; + }; + + ckih1 { + clock-frequency = <22579200>; + }; + + clk_osc: clk-osc { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <26000000>; + }; + + clk_osc_gate: clk-osc-gate { + compatible = "gpio-gate-clock"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_clk26mhz_osc>; + clocks = <&clk_osc>; + #clock-cells = <0>; + enable-gpios = <&gpio3 1 GPIO_ACTIVE_HIGH>; + }; + + clk_audio: clk-audio { + compatible = "gpio-gate-clock"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_clk26mhz_audio>; + clocks = <&clk_osc_gate>; + #clock-cells = <0>; + enable-gpios = <&gpio4 26 GPIO_ACTIVE_LOW>; + }; + + clk_usb: clk-usb { + compatible = "gpio-gate-clock"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_clk26mhz_usb>; + clocks = <&clk_osc_gate>; + #clock-cells = <0>; + enable-gpios = <&gpio2 1 GPIO_ACTIVE_LOW>; + }; + + display1: disp1 { + compatible = "fsl,imx-parallel-display"; + #address-cells = <1>; + #size-cells = <0>; + interface-pix-fmt = "rgb24"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ipu_disp1>; + + port@0 { + reg = <0>; + + display0_in: endpoint { + remote-endpoint = <&ipu_di0_disp1>; + }; + }; + + port@1 { + reg = <1>; + + parallel_display_out: endpoint { + remote-endpoint = <&tfp410_in>; + }; + }; + }; + + display2: disp2 { + compatible = "fsl,imx-parallel-display"; + interface-pix-fmt = "rgb565"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ipu_disp2>; + status = "disabled"; + display-timings { + native-mode = <&timing1>; + timing1: claawvga { + clock-frequency = <27000000>; + hactive = <800>; + vactive = <480>; + hback-porch = <40>; + hfront-porch = <60>; + vback-porch = <10>; + vfront-porch = <10>; + hsync-len = <20>; + vsync-len = <10>; + hsync-active = <0>; + vsync-active = <0>; + de-active = <1>; + pixelclk-active = <0>; + }; + }; + + port { + display1_in: endpoint { + remote-endpoint = <&ipu_di1_disp2>; + }; + }; + }; + + dvi-connector { + compatible = "dvi-connector"; + digital; + + port { + dvi_connector_in: endpoint { + remote-endpoint = <&tfp410_out>; + }; + }; + }; + + dvi-encoder { + compatible = "ti,tfp410"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + tfp410_in: endpoint { + remote-endpoint = <¶llel_display_out>; + }; + }; + + port@1 { + reg = <1>; + + tfp410_out: endpoint { + remote-endpoint = <&dvi_connector_in>; + }; + }; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_keys>; + + power { + label = "Power Button"; + gpios = <&gpio2 21 GPIO_ACTIVE_HIGH>; + linux,code = <KEY_POWER>; + wakeup-source; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_leds>; + + led-diagnostic { + label = "diagnostic"; + gpios = <&gpio2 6 GPIO_ACTIVE_HIGH>; + }; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + reg_hub_reset: regulator@0 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotgreg>; + reg = <0>; + regulator-name = "hub_reset"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio1 7 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + }; + + sound { + compatible = "fsl,imx51-babbage-sgtl5000", + "fsl,imx-audio-sgtl5000"; + model = "imx51-babbage-sgtl5000"; + ssi-controller = <&ssi2>; + audio-codec = <&sgtl5000>; + audio-routing = + "MIC_IN", "Mic Jack", + "Mic Jack", "Mic Bias", + "Headphone Jack", "HP_OUT"; + mux-int-port = <2>; + mux-ext-port = <3>; + }; + + usbphy1: usbphy1 { + compatible = "usb-nop-xceiv"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbh1reg>; + clocks = <&clk_usb>; + clock-names = "main_clk"; + reset-gpios = <&gpio2 5 GPIO_ACTIVE_LOW>; + vcc-supply = <&vusb_reg>; + #phy-cells = <0>; + }; +}; + +&audmux { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_audmux>; + status = "okay"; +}; + +&ecspi1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi1>; + cs-gpios = <&gpio4 24 GPIO_ACTIVE_HIGH>, + <&gpio4 25 GPIO_ACTIVE_LOW>; + status = "okay"; + + pmic: mc13892@0 { + compatible = "fsl,mc13892"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pmic>; + spi-max-frequency = <6000000>; + spi-cs-high; + reg = <0>; + interrupt-parent = <&gpio1>; + interrupts = <8 IRQ_TYPE_LEVEL_HIGH>; + fsl,mc13xxx-uses-adc; + fsl,mc13xxx-uses-rtc; + + regulators { + sw1_reg: sw1 { + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <1375000>; + regulator-boot-on; + regulator-always-on; + }; + + sw2_reg: sw2 { + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1850000>; + regulator-boot-on; + regulator-always-on; + }; + + sw3_reg: sw3 { + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1850000>; + regulator-boot-on; + regulator-always-on; + }; + + sw4_reg: sw4 { + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1850000>; + regulator-boot-on; + regulator-always-on; + }; + + vpll_reg: vpll { + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + vdig_reg: vdig { + regulator-min-microvolt = <1650000>; + regulator-max-microvolt = <1650000>; + regulator-boot-on; + }; + + vsd_reg: vsd { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3150000>; + }; + + vusb_reg: vusb { + regulator-boot-on; + }; + + vusb2_reg: vusb2 { + regulator-min-microvolt = <2400000>; + regulator-max-microvolt = <2775000>; + regulator-boot-on; + regulator-always-on; + }; + + vvideo_reg: vvideo { + regulator-min-microvolt = <2775000>; + regulator-max-microvolt = <2775000>; + }; + + vaudio_reg: vaudio { + regulator-min-microvolt = <2300000>; + regulator-max-microvolt = <3000000>; + }; + + vcam_reg: vcam { + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <3000000>; + }; + + vgen1_reg: vgen1 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + }; + + vgen2_reg: vgen2 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <3150000>; + regulator-always-on; + }; + + vgen3_reg: vgen3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <2900000>; + regulator-always-on; + }; + }; + }; + + flash: at45db321d@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "atmel,at45db321d", "atmel,at45", "atmel,dataflash"; + spi-max-frequency = <25000000>; + reg = <1>; + + partition@0 { + label = "U-Boot"; + reg = <0x0 0x40000>; + read-only; + }; + + partition@40000 { + label = "Kernel"; + reg = <0x40000 0x3c0000>; + }; + }; +}; + +&esdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_esdhc1>; + cd-gpios = <&gpio1 0 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio1 1 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&esdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_esdhc2>; + cd-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio1 5 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec>; + phy-mode = "mii"; + phy-reset-gpios = <&gpio2 14 GPIO_ACTIVE_LOW>; + phy-reset-duration = <1>; + status = "okay"; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; +}; + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + sgtl5000: codec@a { + compatible = "fsl,sgtl5000"; + reg = <0x0a>; + #sound-dai-cells = <0>; + clocks = <&clk_audio>; + VDDA-supply = <&vdig_reg>; + VDDIO-supply = <&vvideo_reg>; + }; +}; + +&ipu_di0_disp1 { + remote-endpoint = <&display0_in>; +}; + +&ipu_di1_disp2 { + remote-endpoint = <&display1_in>; +}; + +&kpp { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_kpp>; + linux,keymap = < + MATRIX_KEY(0, 0, KEY_UP) + MATRIX_KEY(0, 1, KEY_DOWN) + MATRIX_KEY(0, 2, KEY_VOLUMEDOWN) + MATRIX_KEY(0, 3, KEY_HOME) + MATRIX_KEY(1, 0, KEY_RIGHT) + MATRIX_KEY(1, 1, KEY_LEFT) + MATRIX_KEY(1, 2, KEY_ENTER) + MATRIX_KEY(1, 3, KEY_VOLUMEUP) + MATRIX_KEY(2, 0, KEY_F6) + MATRIX_KEY(2, 1, KEY_F8) + MATRIX_KEY(2, 2, KEY_F9) + MATRIX_KEY(2, 3, KEY_F10) + MATRIX_KEY(3, 0, KEY_F1) + MATRIX_KEY(3, 1, KEY_F2) + MATRIX_KEY(3, 2, KEY_F3) + MATRIX_KEY(3, 3, KEY_POWER) + >; + status = "okay"; +}; + +&pmu { + secure-reg-access; +}; + +&ssi2 { + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + uart-has-rtscts; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + uart-has-rtscts; + status = "okay"; +}; + +&usbh1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbh1>; + vbus-supply = <®_hub_reset>; + fsl,usbphy = <&usbphy1>; + phy_type = "ulpi"; + status = "okay"; +}; + +&usbphy0 { + vcc-supply = <&vusb_reg>; +}; + +&usbotg { + dr_mode = "otg"; + disable-over-current; + phy_type = "utmi_wide"; + status = "okay"; +}; + +&iomuxc { + imx51-babbage { + pinctrl_audmux: audmuxgrp { + fsl,pins = < + MX51_PAD_AUD3_BB_TXD__AUD3_TXD 0x80000000 + MX51_PAD_AUD3_BB_RXD__AUD3_RXD 0x80000000 + MX51_PAD_AUD3_BB_CK__AUD3_TXC 0x80000000 + MX51_PAD_AUD3_BB_FS__AUD3_TXFS 0x80000000 + >; + }; + + pinctrl_clk26mhz_audio: clk26mhzaudiocgrp { + fsl,pins = < + MX51_PAD_CSPI1_RDY__GPIO4_26 0x85 + >; + }; + + pinctrl_clk26mhz_osc: clk26mhzoscgrp { + fsl,pins = < + MX51_PAD_DI1_PIN12__GPIO3_1 0x85 + >; + }; + + pinctrl_clk26mhz_usb: clk26mhzusbgrp { + fsl,pins = < + MX51_PAD_EIM_D17__GPIO2_1 0x85 + >; + }; + + pinctrl_ecspi1: ecspi1grp { + fsl,pins = < + MX51_PAD_CSPI1_MISO__ECSPI1_MISO 0x185 + MX51_PAD_CSPI1_MOSI__ECSPI1_MOSI 0x185 + MX51_PAD_CSPI1_SCLK__ECSPI1_SCLK 0x185 + MX51_PAD_CSPI1_SS0__GPIO4_24 0x85 /* CS0 */ + MX51_PAD_CSPI1_SS1__GPIO4_25 0x85 /* CS1 */ + >; + }; + + pinctrl_esdhc1: esdhc1grp { + fsl,pins = < + MX51_PAD_SD1_CMD__SD1_CMD 0x400020d5 + MX51_PAD_SD1_CLK__SD1_CLK 0x20d5 + MX51_PAD_SD1_DATA0__SD1_DATA0 0x20d5 + MX51_PAD_SD1_DATA1__SD1_DATA1 0x20d5 + MX51_PAD_SD1_DATA2__SD1_DATA2 0x20d5 + MX51_PAD_SD1_DATA3__SD1_DATA3 0x20d5 + MX51_PAD_GPIO1_0__GPIO1_0 0x100 + MX51_PAD_GPIO1_1__GPIO1_1 0x100 + >; + }; + + pinctrl_esdhc2: esdhc2grp { + fsl,pins = < + MX51_PAD_SD2_CMD__SD2_CMD 0x400020d5 + MX51_PAD_SD2_CLK__SD2_CLK 0x20d5 + MX51_PAD_SD2_DATA0__SD2_DATA0 0x20d5 + MX51_PAD_SD2_DATA1__SD2_DATA1 0x20d5 + MX51_PAD_SD2_DATA2__SD2_DATA2 0x20d5 + MX51_PAD_SD2_DATA3__SD2_DATA3 0x20d5 + MX51_PAD_GPIO1_5__GPIO1_5 0x100 /* WP */ + MX51_PAD_GPIO1_6__GPIO1_6 0x100 /* CD */ + >; + }; + + pinctrl_fec: fecgrp { + fsl,pins = < + MX51_PAD_EIM_EB2__FEC_MDIO 0x000001f5 + MX51_PAD_EIM_EB3__FEC_RDATA1 0x00000085 + MX51_PAD_EIM_CS2__FEC_RDATA2 0x00000085 + MX51_PAD_EIM_CS3__FEC_RDATA3 0x00000085 + MX51_PAD_EIM_CS4__FEC_RX_ER 0x00000180 + MX51_PAD_EIM_CS5__FEC_CRS 0x00000180 + MX51_PAD_NANDF_RB2__FEC_COL 0x00000180 + MX51_PAD_NANDF_RB3__FEC_RX_CLK 0x00000180 + MX51_PAD_NANDF_D9__FEC_RDATA0 0x00002180 + MX51_PAD_NANDF_D8__FEC_TDATA0 0x00002004 + MX51_PAD_NANDF_CS2__FEC_TX_ER 0x00002004 + MX51_PAD_NANDF_CS3__FEC_MDC 0x00002004 + MX51_PAD_NANDF_CS4__FEC_TDATA1 0x00002004 + MX51_PAD_NANDF_CS5__FEC_TDATA2 0x00002004 + MX51_PAD_NANDF_CS6__FEC_TDATA3 0x00002004 + MX51_PAD_NANDF_CS7__FEC_TX_EN 0x00002004 + MX51_PAD_NANDF_RDY_INT__FEC_TX_CLK 0x00002180 + MX51_PAD_NANDF_D11__FEC_RX_DV 0x000020a4 + MX51_PAD_EIM_A20__GPIO2_14 0x00000085 /* Phy Reset */ + >; + }; + + pinctrl_gpio_keys: gpiokeysgrp { + fsl,pins = < + MX51_PAD_EIM_A27__GPIO2_21 0x5 + >; + }; + + pinctrl_gpio_leds: gpioledsgrp { + fsl,pins = < + MX51_PAD_EIM_D22__GPIO2_6 0x80000000 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX51_PAD_EIM_D19__I2C1_SCL 0x400001ed + MX51_PAD_EIM_D16__I2C1_SDA 0x400001ed + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX51_PAD_KEY_COL4__I2C2_SCL 0x400001ed + MX51_PAD_KEY_COL5__I2C2_SDA 0x400001ed + >; + }; + + pinctrl_ipu_disp1: ipudisp1grp { + fsl,pins = < + MX51_PAD_DISP1_DAT0__DISP1_DAT0 0x5 + MX51_PAD_DISP1_DAT1__DISP1_DAT1 0x5 + MX51_PAD_DISP1_DAT2__DISP1_DAT2 0x5 + MX51_PAD_DISP1_DAT3__DISP1_DAT3 0x5 + MX51_PAD_DISP1_DAT4__DISP1_DAT4 0x5 + MX51_PAD_DISP1_DAT5__DISP1_DAT5 0x5 + MX51_PAD_DISP1_DAT6__DISP1_DAT6 0x5 + MX51_PAD_DISP1_DAT7__DISP1_DAT7 0x5 + MX51_PAD_DISP1_DAT8__DISP1_DAT8 0x5 + MX51_PAD_DISP1_DAT9__DISP1_DAT9 0x5 + MX51_PAD_DISP1_DAT10__DISP1_DAT10 0x5 + MX51_PAD_DISP1_DAT11__DISP1_DAT11 0x5 + MX51_PAD_DISP1_DAT12__DISP1_DAT12 0x5 + MX51_PAD_DISP1_DAT13__DISP1_DAT13 0x5 + MX51_PAD_DISP1_DAT14__DISP1_DAT14 0x5 + MX51_PAD_DISP1_DAT15__DISP1_DAT15 0x5 + MX51_PAD_DISP1_DAT16__DISP1_DAT16 0x5 + MX51_PAD_DISP1_DAT17__DISP1_DAT17 0x5 + MX51_PAD_DISP1_DAT18__DISP1_DAT18 0x5 + MX51_PAD_DISP1_DAT19__DISP1_DAT19 0x5 + MX51_PAD_DISP1_DAT20__DISP1_DAT20 0x5 + MX51_PAD_DISP1_DAT21__DISP1_DAT21 0x5 + MX51_PAD_DISP1_DAT22__DISP1_DAT22 0x5 + MX51_PAD_DISP1_DAT23__DISP1_DAT23 0x5 + MX51_PAD_DI1_PIN2__DI1_PIN2 0x5 + MX51_PAD_DI1_PIN3__DI1_PIN3 0x5 + >; + }; + + pinctrl_ipu_disp2: ipudisp2grp { + fsl,pins = < + MX51_PAD_DISP2_DAT0__DISP2_DAT0 0x5 + MX51_PAD_DISP2_DAT1__DISP2_DAT1 0x5 + MX51_PAD_DISP2_DAT2__DISP2_DAT2 0x5 + MX51_PAD_DISP2_DAT3__DISP2_DAT3 0x5 + MX51_PAD_DISP2_DAT4__DISP2_DAT4 0x5 + MX51_PAD_DISP2_DAT5__DISP2_DAT5 0x5 + MX51_PAD_DISP2_DAT6__DISP2_DAT6 0x5 + MX51_PAD_DISP2_DAT7__DISP2_DAT7 0x5 + MX51_PAD_DISP2_DAT8__DISP2_DAT8 0x5 + MX51_PAD_DISP2_DAT9__DISP2_DAT9 0x5 + MX51_PAD_DISP2_DAT10__DISP2_DAT10 0x5 + MX51_PAD_DISP2_DAT11__DISP2_DAT11 0x5 + MX51_PAD_DISP2_DAT12__DISP2_DAT12 0x5 + MX51_PAD_DISP2_DAT13__DISP2_DAT13 0x5 + MX51_PAD_DISP2_DAT14__DISP2_DAT14 0x5 + MX51_PAD_DISP2_DAT15__DISP2_DAT15 0x5 + MX51_PAD_DI2_PIN2__DI2_PIN2 0x5 + MX51_PAD_DI2_PIN3__DI2_PIN3 0x5 + MX51_PAD_DI2_DISP_CLK__DI2_DISP_CLK 0x5 + MX51_PAD_DI_GP4__DI2_PIN15 0x5 + >; + }; + + pinctrl_kpp: kppgrp { + fsl,pins = < + MX51_PAD_KEY_ROW0__KEY_ROW0 0xe0 + MX51_PAD_KEY_ROW1__KEY_ROW1 0xe0 + MX51_PAD_KEY_ROW2__KEY_ROW2 0xe0 + MX51_PAD_KEY_ROW3__KEY_ROW3 0xe0 + MX51_PAD_KEY_COL0__KEY_COL0 0xe8 + MX51_PAD_KEY_COL1__KEY_COL1 0xe8 + MX51_PAD_KEY_COL2__KEY_COL2 0xe8 + MX51_PAD_KEY_COL3__KEY_COL3 0xe8 + >; + }; + + pinctrl_pmic: pmicgrp { + fsl,pins = < + MX51_PAD_GPIO1_8__GPIO1_8 0xe5 /* IRQ */ + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX51_PAD_UART1_RXD__UART1_RXD 0x1c5 + MX51_PAD_UART1_TXD__UART1_TXD 0x1c5 + MX51_PAD_UART1_RTS__UART1_RTS 0x1c5 + MX51_PAD_UART1_CTS__UART1_CTS 0x1c5 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX51_PAD_UART2_RXD__UART2_RXD 0x1c5 + MX51_PAD_UART2_TXD__UART2_TXD 0x1c5 + >; + }; + + pinctrl_uart3: uart3grp { + fsl,pins = < + MX51_PAD_EIM_D25__UART3_RXD 0x1c5 + MX51_PAD_EIM_D26__UART3_TXD 0x1c5 + MX51_PAD_EIM_D27__UART3_RTS 0x1c5 + MX51_PAD_EIM_D24__UART3_CTS 0x1c5 + >; + }; + + pinctrl_usbh1: usbh1grp { + fsl,pins = < + MX51_PAD_USBH1_CLK__USBH1_CLK 0x80000000 + MX51_PAD_USBH1_DIR__USBH1_DIR 0x80000000 + MX51_PAD_USBH1_NXT__USBH1_NXT 0x80000000 + MX51_PAD_USBH1_DATA0__USBH1_DATA0 0x80000000 + MX51_PAD_USBH1_DATA1__USBH1_DATA1 0x80000000 + MX51_PAD_USBH1_DATA2__USBH1_DATA2 0x80000000 + MX51_PAD_USBH1_DATA3__USBH1_DATA3 0x80000000 + MX51_PAD_USBH1_DATA4__USBH1_DATA4 0x80000000 + MX51_PAD_USBH1_DATA5__USBH1_DATA5 0x80000000 + MX51_PAD_USBH1_DATA6__USBH1_DATA6 0x80000000 + MX51_PAD_USBH1_DATA7__USBH1_DATA7 0x80000000 + >; + }; + + pinctrl_usbh1reg: usbh1reggrp { + fsl,pins = < + MX51_PAD_EIM_D21__GPIO2_5 0x85 + >; + }; + + pinctrl_usbotgreg: usbotgreggrp { + fsl,pins = < + MX51_PAD_GPIO1_7__GPIO1_7 0x85 + >; + }; + }; +}; diff --git a/arch/arm/dts/imx51-pinfunc.h b/arch/arm/dts/imx51-pinfunc.h new file mode 100644 index 000000000000..910e0ec50ef3 --- /dev/null +++ b/arch/arm/dts/imx51-pinfunc.h @@ -0,0 +1,768 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + */ + +#ifndef __DTS_IMX51_PINFUNC_H +#define __DTS_IMX51_PINFUNC_H + +/* + * The pin function ID is a tuple of + * <mux_reg conf_reg input_reg mux_mode input_val> + */ +#define MX51_PAD_EIM_D16__AUD4_RXFS 0x05c 0x3f0 0x000 0x5 0x0 +#define MX51_PAD_EIM_D16__AUD5_TXD 0x05c 0x3f0 0x8d8 0x7 0x0 +#define MX51_PAD_EIM_D16__EIM_D16 0x05c 0x3f0 0x000 0x0 0x0 +#define MX51_PAD_EIM_D16__GPIO2_0 0x05c 0x3f0 0x000 0x1 0x0 +#define MX51_PAD_EIM_D16__I2C1_SDA 0x05c 0x3f0 0x9b4 0x4 0x0 +#define MX51_PAD_EIM_D16__UART2_CTS 0x05c 0x3f0 0x000 0x3 0x0 +#define MX51_PAD_EIM_D16__USBH2_DATA0 0x05c 0x3f0 0x000 0x2 0x0 +#define MX51_PAD_EIM_D17__AUD5_RXD 0x060 0x3f4 0x8d4 0x7 0x0 +#define MX51_PAD_EIM_D17__EIM_D17 0x060 0x3f4 0x000 0x0 0x0 +#define MX51_PAD_EIM_D17__GPIO2_1 0x060 0x3f4 0x000 0x1 0x0 +#define MX51_PAD_EIM_D17__UART2_RXD 0x060 0x3f4 0x9ec 0x3 0x0 +#define MX51_PAD_EIM_D17__UART3_CTS 0x060 0x3f4 0x000 0x4 0x0 +#define MX51_PAD_EIM_D17__USBH2_DATA1 0x060 0x3f4 0x000 0x2 0x0 +#define MX51_PAD_EIM_D18__AUD5_TXC 0x064 0x3f8 0x8e4 0x7 0x0 +#define MX51_PAD_EIM_D18__EIM_D18 0x064 0x3f8 0x000 0x0 0x0 +#define MX51_PAD_EIM_D18__GPIO2_2 0x064 0x3f8 0x000 0x1 0x0 +#define MX51_PAD_EIM_D18__UART2_TXD 0x064 0x3f8 0x000 0x3 0x0 +#define MX51_PAD_EIM_D18__UART3_RTS 0x064 0x3f8 0x9f0 0x4 0x1 +#define MX51_PAD_EIM_D18__USBH2_DATA2 0x064 0x3f8 0x000 0x2 0x0 +#define MX51_PAD_EIM_D19__AUD4_RXC 0x068 0x3fc 0x000 0x5 0x0 +#define MX51_PAD_EIM_D19__AUD5_TXFS 0x068 0x3fc 0x8e8 0x7 0x0 +#define MX51_PAD_EIM_D19__EIM_D19 0x068 0x3fc 0x000 0x0 0x0 +#define MX51_PAD_EIM_D19__GPIO2_3 0x068 0x3fc 0x000 0x1 0x0 +#define MX51_PAD_EIM_D19__I2C1_SCL 0x068 0x3fc 0x9b0 0x4 0x0 +#define MX51_PAD_EIM_D19__UART2_RTS 0x068 0x3fc 0x9e8 0x3 0x1 +#define MX51_PAD_EIM_D19__USBH2_DATA3 0x068 0x3fc 0x000 0x2 0x0 +#define MX51_PAD_EIM_D20__AUD4_TXD 0x06c 0x400 0x8c8 0x5 0x0 +#define MX51_PAD_EIM_D20__EIM_D20 0x06c 0x400 0x000 0x0 0x0 +#define MX51_PAD_EIM_D20__GPIO2_4 0x06c 0x400 0x000 0x1 0x0 +#define MX51_PAD_EIM_D20__SRTC_ALARM_DEB 0x06c 0x400 0x000 0x4 0x0 +#define MX51_PAD_EIM_D20__USBH2_DATA4 0x06c 0x400 0x000 0x2 0x0 +#define MX51_PAD_EIM_D21__AUD4_RXD 0x070 0x404 0x8c4 0x5 0x0 +#define MX51_PAD_EIM_D21__EIM_D21 0x070 0x404 0x000 0x0 0x0 +#define MX51_PAD_EIM_D21__GPIO2_5 0x070 0x404 0x000 0x1 0x0 +#define MX51_PAD_EIM_D21__SRTC_ALARM_DEB 0x070 0x404 0x000 0x3 0x0 +#define MX51_PAD_EIM_D21__USBH2_DATA5 0x070 0x404 0x000 0x2 0x0 +#define MX51_PAD_EIM_D22__AUD4_TXC 0x074 0x408 0x8cc 0x5 0x0 +#define MX51_PAD_EIM_D22__EIM_D22 0x074 0x408 0x000 0x0 0x0 +#define MX51_PAD_EIM_D22__GPIO2_6 0x074 0x408 0x000 0x1 0x0 +#define MX51_PAD_EIM_D22__USBH2_DATA6 0x074 0x408 0x000 0x2 0x0 +#define MX51_PAD_EIM_D23__AUD4_TXFS 0x078 0x40c 0x8d0 0x5 0x0 +#define MX51_PAD_EIM_D23__EIM_D23 0x078 0x40c 0x000 0x0 0x0 +#define MX51_PAD_EIM_D23__GPIO2_7 0x078 0x40c 0x000 0x1 0x0 +#define MX51_PAD_EIM_D23__SPDIF_OUT1 0x078 0x40c 0x000 0x4 0x0 +#define MX51_PAD_EIM_D23__USBH2_DATA7 0x078 0x40c 0x000 0x2 0x0 +#define MX51_PAD_EIM_D24__AUD6_RXFS 0x07c 0x410 0x8f8 0x5 0x0 +#define MX51_PAD_EIM_D24__EIM_D24 0x07c 0x410 0x000 0x0 0x0 +#define MX51_PAD_EIM_D24__GPIO2_8 0x07c 0x410 0x000 0x1 0x0 +#define MX51_PAD_EIM_D24__I2C2_SDA 0x07c 0x410 0x9bc 0x4 0x0 +#define MX51_PAD_EIM_D24__UART3_CTS 0x07c 0x410 0x000 0x3 0x0 +#define MX51_PAD_EIM_D24__USBOTG_DATA0 0x07c 0x410 0x000 0x2 0x0 +#define MX51_PAD_EIM_D25__EIM_D25 0x080 0x414 0x000 0x0 0x0 +#define MX51_PAD_EIM_D25__KEY_COL6 0x080 0x414 0x9c8 0x1 0x0 +#define MX51_PAD_EIM_D25__UART2_CTS 0x080 0x414 0x000 0x4 0x0 +#define MX51_PAD_EIM_D25__UART3_RXD 0x080 0x414 0x9f4 0x3 0x0 +#define MX51_PAD_EIM_D25__USBOTG_DATA1 0x080 0x414 0x000 0x2 0x0 +#define MX51_PAD_EIM_D26__EIM_D26 0x084 0x418 0x000 0x0 0x0 +#define MX51_PAD_EIM_D26__KEY_COL7 0x084 0x418 0x9cc 0x1 0x0 +#define MX51_PAD_EIM_D26__UART2_RTS 0x084 0x418 0x9e8 0x4 0x3 +#define MX51_PAD_EIM_D26__UART3_TXD 0x084 0x418 0x000 0x3 0x0 +#define MX51_PAD_EIM_D26__USBOTG_DATA2 0x084 0x418 0x000 0x2 0x0 +#define MX51_PAD_EIM_D27__AUD6_RXC 0x088 0x41c 0x8f4 0x5 0x0 +#define MX51_PAD_EIM_D27__EIM_D27 0x088 0x41c 0x000 0x0 0x0 +#define MX51_PAD_EIM_D27__GPIO2_9 0x088 0x41c 0x000 0x1 0x0 +#define MX51_PAD_EIM_D27__I2C2_SCL 0x088 0x41c 0x9b8 0x4 0x0 +#define MX51_PAD_EIM_D27__UART3_RTS 0x088 0x41c 0x9f0 0x3 0x3 +#define MX51_PAD_EIM_D27__USBOTG_DATA3 0x088 0x41c 0x000 0x2 0x0 +#define MX51_PAD_EIM_D28__AUD6_TXD 0x08c 0x420 0x8f0 0x5 0x0 +#define MX51_PAD_EIM_D28__EIM_D28 0x08c 0x420 0x000 0x0 0x0 +#define MX51_PAD_EIM_D28__KEY_ROW4 0x08c 0x420 0x9d0 0x1 0x0 +#define MX51_PAD_EIM_D28__USBOTG_DATA4 0x08c 0x420 0x000 0x2 0x0 +#define MX51_PAD_EIM_D29__AUD6_RXD 0x090 0x424 0x8ec 0x5 0x0 +#define MX51_PAD_EIM_D29__EIM_D29 0x090 0x424 0x000 0x0 0x0 +#define MX51_PAD_EIM_D29__KEY_ROW5 0x090 0x424 0x9d4 0x1 0x0 +#define MX51_PAD_EIM_D29__USBOTG_DATA5 0x090 0x424 0x000 0x2 0x0 +#define MX51_PAD_EIM_D30__AUD6_TXC 0x094 0x428 0x8fc 0x5 0x0 +#define MX51_PAD_EIM_D30__EIM_D30 0x094 0x428 0x000 0x0 0x0 +#define MX51_PAD_EIM_D30__KEY_ROW6 0x094 0x428 0x9d8 0x1 0x0 +#define MX51_PAD_EIM_D30__USBOTG_DATA6 0x094 0x428 0x000 0x2 0x0 +#define MX51_PAD_EIM_D31__AUD6_TXFS 0x098 0x42c 0x900 0x5 0x0 +#define MX51_PAD_EIM_D31__EIM_D31 0x098 0x42c 0x000 0x0 0x0 +#define MX51_PAD_EIM_D31__KEY_ROW7 0x098 0x42c 0x9dc 0x1 0x0 +#define MX51_PAD_EIM_D31__USBOTG_DATA7 0x098 0x42c 0x000 0x2 0x0 +#define MX51_PAD_EIM_A16__EIM_A16 0x09c 0x430 0x000 0x0 0x0 +#define MX51_PAD_EIM_A16__GPIO2_10 0x09c 0x430 0x000 0x1 0x0 +#define MX51_PAD_EIM_A16__OSC_FREQ_SEL0 0x09c 0x430 0x000 0x7 0x0 +#define MX51_PAD_EIM_A17__EIM_A17 0x0a0 0x434 0x000 0x0 0x0 +#define MX51_PAD_EIM_A17__GPIO2_11 0x0a0 0x434 0x000 0x1 0x0 +#define MX51_PAD_EIM_A17__OSC_FREQ_SEL1 0x0a0 0x434 0x000 0x7 0x0 +#define MX51_PAD_EIM_A18__BOOT_LPB0 0x0a4 0x438 0x000 0x7 0x0 +#define MX51_PAD_EIM_A18__EIM_A18 0x0a4 0x438 0x000 0x0 0x0 +#define MX51_PAD_EIM_A18__GPIO2_12 0x0a4 0x438 0x000 0x1 0x0 +#define MX51_PAD_EIM_A19__BOOT_LPB1 0x0a8 0x43c 0x000 0x7 0x0 +#define MX51_PAD_EIM_A19__EIM_A19 0x0a8 0x43c 0x000 0x0 0x0 +#define MX51_PAD_EIM_A19__GPIO2_13 0x0a8 0x43c 0x000 0x1 0x0 +#define MX51_PAD_EIM_A20__BOOT_UART_SRC0 0x0ac 0x440 0x000 0x7 0x0 +#define MX51_PAD_EIM_A20__EIM_A20 0x0ac 0x440 0x000 0x0 0x0 +#define MX51_PAD_EIM_A20__GPIO2_14 0x0ac 0x440 0x000 0x1 0x0 +#define MX51_PAD_EIM_A21__BOOT_UART_SRC1 0x0b0 0x444 0x000 0x7 0x0 +#define MX51_PAD_EIM_A21__EIM_A21 0x0b0 0x444 0x000 0x0 0x0 +#define MX51_PAD_EIM_A21__GPIO2_15 0x0b0 0x444 0x000 0x1 0x0 +#define MX51_PAD_EIM_A22__EIM_A22 0x0b4 0x448 0x000 0x0 0x0 +#define MX51_PAD_EIM_A22__GPIO2_16 0x0b4 0x448 0x000 0x1 0x0 +#define MX51_PAD_EIM_A23__BOOT_HPN_EN 0x0b8 0x44c 0x000 0x7 0x0 +#define MX51_PAD_EIM_A23__EIM_A23 0x0b8 0x44c 0x000 0x0 0x0 +#define MX51_PAD_EIM_A23__GPIO2_17 0x0b8 0x44c 0x000 0x1 0x0 +#define MX51_PAD_EIM_A24__EIM_A24 0x0bc 0x450 0x000 0x0 0x0 +#define MX51_PAD_EIM_A24__GPIO2_18 0x0bc 0x450 0x000 0x1 0x0 +#define MX51_PAD_EIM_A24__USBH2_CLK 0x0bc 0x450 0x000 0x2 0x0 +#define MX51_PAD_EIM_A25__DISP1_PIN4 0x0c0 0x454 0x000 0x6 0x0 +#define MX51_PAD_EIM_A25__EIM_A25 0x0c0 0x454 0x000 0x0 0x0 +#define MX51_PAD_EIM_A25__GPIO2_19 0x0c0 0x454 0x000 0x1 0x0 +#define MX51_PAD_EIM_A25__USBH2_DIR 0x0c0 0x454 0x000 0x2 0x0 +#define MX51_PAD_EIM_A26__CSI1_DATA_EN 0x0c4 0x458 0x9a0 0x5 0x0 +#define MX51_PAD_EIM_A26__DISP2_EXT_CLK 0x0c4 0x458 0x908 0x6 0x0 +#define MX51_PAD_EIM_A26__EIM_A26 0x0c4 0x458 0x000 0x0 0x0 +#define MX51_PAD_EIM_A26__GPIO2_20 0x0c4 0x458 0x000 0x1 0x0 +#define MX51_PAD_EIM_A26__USBH2_STP 0x0c4 0x458 0x000 0x2 0x0 +#define MX51_PAD_EIM_A27__CSI2_DATA_EN 0x0c8 0x45c 0x99c 0x5 0x0 +#define MX51_PAD_EIM_A27__DISP1_PIN1 0x0c8 0x45c 0x9a4 0x6 0x0 +#define MX51_PAD_EIM_A27__EIM_A27 0x0c8 0x45c 0x000 0x0 0x0 +#define MX51_PAD_EIM_A27__GPIO2_21 0x0c8 0x45c 0x000 0x1 0x0 +#define MX51_PAD_EIM_A27__USBH2_NXT 0x0c8 0x45c 0x000 0x2 0x0 +#define MX51_PAD_EIM_EB0__EIM_EB0 0x0cc 0x460 0x000 0x0 0x0 +#define MX51_PAD_EIM_EB1__EIM_EB1 0x0d0 0x464 0x000 0x0 0x0 +#define MX51_PAD_EIM_EB2__AUD5_RXFS 0x0d4 0x468 0x8e0 0x6 0x0 +#define MX51_PAD_EIM_EB2__CSI1_D2 0x0d4 0x468 0x000 0x5 0x0 +#define MX51_PAD_EIM_EB2__EIM_EB2 0x0d4 0x468 0x000 0x0 0x0 +#define MX51_PAD_EIM_EB2__FEC_MDIO 0x0d4 0x468 0x954 0x3 0x0 +#define MX51_PAD_EIM_EB2__GPIO2_22 0x0d4 0x468 0x000 0x1 0x0 +#define MX51_PAD_EIM_EB2__GPT_CMPOUT1 0x0d4 0x468 0x000 0x7 0x0 +#define MX51_PAD_EIM_EB3__AUD5_RXC 0x0d8 0x46c 0x8dc 0x6 0x0 +#define MX51_PAD_EIM_EB3__CSI1_D3 0x0d8 0x46c 0x000 0x5 0x0 +#define MX51_PAD_EIM_EB3__EIM_EB3 0x0d8 0x46c 0x000 0x0 0x0 +#define MX51_PAD_EIM_EB3__FEC_RDATA1 0x0d8 0x46c 0x95c 0x3 0x0 +#define MX51_PAD_EIM_EB3__GPIO2_23 0x0d8 0x46c 0x000 0x1 0x0 +#define MX51_PAD_EIM_EB3__GPT_CMPOUT2 0x0d8 0x46c 0x000 0x7 0x0 +#define MX51_PAD_EIM_OE__EIM_OE 0x0dc 0x470 0x000 0x0 0x0 +#define MX51_PAD_EIM_OE__GPIO2_24 0x0dc 0x470 0x000 0x1 0x0 +#define MX51_PAD_EIM_CS0__EIM_CS0 0x0e0 0x474 0x000 0x0 0x0 +#define MX51_PAD_EIM_CS0__GPIO2_25 0x0e0 0x474 0x000 0x1 0x0 +#define MX51_PAD_EIM_CS1__EIM_CS1 0x0e4 0x478 0x000 0x0 0x0 +#define MX51_PAD_EIM_CS1__GPIO2_26 0x0e4 0x478 0x000 0x1 0x0 +#define MX51_PAD_EIM_CS2__AUD5_TXD 0x0e8 0x47c 0x8d8 0x6 0x1 +#define MX51_PAD_EIM_CS2__CSI1_D4 0x0e8 0x47c 0x000 0x5 0x0 +#define MX51_PAD_EIM_CS2__EIM_CS2 0x0e8 0x47c 0x000 0x0 0x0 +#define MX51_PAD_EIM_CS2__FEC_RDATA2 0x0e8 0x47c 0x960 0x3 0x0 +#define MX51_PAD_EIM_CS2__GPIO2_27 0x0e8 0x47c 0x000 0x1 0x0 +#define MX51_PAD_EIM_CS2__USBOTG_STP 0x0e8 0x47c 0x000 0x2 0x0 +#define MX51_PAD_EIM_CS3__AUD5_RXD 0x0ec 0x480 0x8d4 0x6 0x1 +#define MX51_PAD_EIM_CS3__CSI1_D5 0x0ec 0x480 0x000 0x5 0x0 +#define MX51_PAD_EIM_CS3__EIM_CS3 0x0ec 0x480 0x000 0x0 0x0 +#define MX51_PAD_EIM_CS3__FEC_RDATA3 0x0ec 0x480 0x964 0x3 0x0 +#define MX51_PAD_EIM_CS3__GPIO2_28 0x0ec 0x480 0x000 0x1 0x0 +#define MX51_PAD_EIM_CS3__USBOTG_NXT 0x0ec 0x480 0x000 0x2 0x0 +#define MX51_PAD_EIM_CS4__AUD5_TXC 0x0f0 0x484 0x8e4 0x6 0x1 +#define MX51_PAD_EIM_CS4__CSI1_D6 0x0f0 0x484 0x000 0x5 0x0 +#define MX51_PAD_EIM_CS4__EIM_CS4 0x0f0 0x484 0x000 0x0 0x0 +#define MX51_PAD_EIM_CS4__FEC_RX_ER 0x0f0 0x484 0x970 0x3 0x0 +#define MX51_PAD_EIM_CS4__GPIO2_29 0x0f0 0x484 0x000 0x1 0x0 +#define MX51_PAD_EIM_CS4__USBOTG_CLK 0x0f0 0x484 0x000 0x2 0x0 +#define MX51_PAD_EIM_CS5__AUD5_TXFS 0x0f4 0x488 0x8e8 0x6 0x1 +#define MX51_PAD_EIM_CS5__CSI1_D7 0x0f4 0x488 0x000 0x5 0x0 +#define MX51_PAD_EIM_CS5__DISP1_EXT_CLK 0x0f4 0x488 0x904 0x4 0x0 +#define MX51_PAD_EIM_CS5__EIM_CS5 0x0f4 0x488 0x000 0x0 0x0 +#define MX51_PAD_EIM_CS5__FEC_CRS 0x0f4 0x488 0x950 0x3 0x0 +#define MX51_PAD_EIM_CS5__GPIO2_30 0x0f4 0x488 0x000 0x1 0x0 +#define MX51_PAD_EIM_CS5__USBOTG_DIR 0x0f4 0x488 0x000 0x2 0x0 +#define MX51_PAD_EIM_DTACK__EIM_DTACK 0x0f8 0x48c 0x000 0x0 0x0 +#define MX51_PAD_EIM_DTACK__GPIO2_31 0x0f8 0x48c 0x000 0x1 0x0 +#define MX51_PAD_EIM_LBA__EIM_LBA 0x0fc 0x494 0x000 0x0 0x0 +#define MX51_PAD_EIM_LBA__GPIO3_1 0x0fc 0x494 0x978 0x1 0x0 +#define MX51_PAD_EIM_CRE__EIM_CRE 0x100 0x4a0 0x000 0x0 0x0 +#define MX51_PAD_EIM_CRE__GPIO3_2 0x100 0x4a0 0x97c 0x1 0x0 +#define MX51_PAD_DRAM_CS1__DRAM_CS1 0x104 0x4d0 0x000 0x0 0x0 +#define MX51_PAD_NANDF_WE_B__GPIO3_3 0x108 0x4e4 0x980 0x3 0x0 +#define MX51_PAD_NANDF_WE_B__NANDF_WE_B 0x108 0x4e4 0x000 0x0 0x0 +#define MX51_PAD_NANDF_WE_B__PATA_DIOW 0x108 0x4e4 0x000 0x1 0x0 +#define MX51_PAD_NANDF_WE_B__SD3_DATA0 0x108 0x4e4 0x93c 0x2 0x0 +#define MX51_PAD_NANDF_RE_B__GPIO3_4 0x10c 0x4e8 0x984 0x3 0x0 +#define MX51_PAD_NANDF_RE_B__NANDF_RE_B 0x10c 0x4e8 0x000 0x0 0x0 +#define MX51_PAD_NANDF_RE_B__PATA_DIOR 0x10c 0x4e8 0x000 0x1 0x0 +#define MX51_PAD_NANDF_RE_B__SD3_DATA1 0x10c 0x4e8 0x940 0x2 0x0 +#define MX51_PAD_NANDF_ALE__GPIO3_5 0x110 0x4ec 0x988 0x3 0x0 +#define MX51_PAD_NANDF_ALE__NANDF_ALE 0x110 0x4ec 0x000 0x0 0x0 +#define MX51_PAD_NANDF_ALE__PATA_BUFFER_EN 0x110 0x4ec 0x000 0x1 0x0 +#define MX51_PAD_NANDF_CLE__GPIO3_6 0x114 0x4f0 0x98c 0x3 0x0 +#define MX51_PAD_NANDF_CLE__NANDF_CLE 0x114 0x4f0 0x000 0x0 0x0 +#define MX51_PAD_NANDF_CLE__PATA_RESET_B 0x114 0x4f0 0x000 0x1 0x0 +#define MX51_PAD_NANDF_WP_B__GPIO3_7 0x118 0x4f4 0x990 0x3 0x0 +#define MX51_PAD_NANDF_WP_B__NANDF_WP_B 0x118 0x4f4 0x000 0x0 0x0 +#define MX51_PAD_NANDF_WP_B__PATA_DMACK 0x118 0x4f4 0x000 0x1 0x0 +#define MX51_PAD_NANDF_WP_B__SD3_DATA2 0x118 0x4f4 0x944 0x2 0x0 +#define MX51_PAD_NANDF_RB0__ECSPI2_SS1 0x11c 0x4f8 0x930 0x5 0x0 +#define MX51_PAD_NANDF_RB0__GPIO3_8 0x11c 0x4f8 0x994 0x3 0x0 +#define MX51_PAD_NANDF_RB0__NANDF_RB0 0x11c 0x4f8 0x000 0x0 0x0 +#define MX51_PAD_NANDF_RB0__PATA_DMARQ 0x11c 0x4f8 0x000 0x1 0x0 +#define MX51_PAD_NANDF_RB0__SD3_DATA3 0x11c 0x4f8 0x948 0x2 0x0 +#define MX51_PAD_NANDF_RB1__CSPI_MOSI 0x120 0x4fc 0x91c 0x6 0x0 +#define MX51_PAD_NANDF_RB1__ECSPI2_RDY 0x120 0x4fc 0x000 0x2 0x0 +#define MX51_PAD_NANDF_RB1__GPIO3_9 0x120 0x4fc 0x000 0x3 0x0 +#define MX51_PAD_NANDF_RB1__NANDF_RB1 0x120 0x4fc 0x000 0x0 0x0 +#define MX51_PAD_NANDF_RB1__PATA_IORDY 0x120 0x4fc 0x000 0x1 0x0 +#define MX51_PAD_NANDF_RB1__SD4_CMD 0x120 0x4fc 0x000 0x5 0x0 +#define MX51_PAD_NANDF_RB2__DISP2_WAIT 0x124 0x500 0x9a8 0x5 0x0 +#define MX51_PAD_NANDF_RB2__ECSPI2_SCLK 0x124 0x500 0x000 0x2 0x0 +#define MX51_PAD_NANDF_RB2__FEC_COL 0x124 0x500 0x94c 0x1 0x0 +#define MX51_PAD_NANDF_RB2__GPIO3_10 0x124 0x500 0x000 0x3 0x0 +#define MX51_PAD_NANDF_RB2__NANDF_RB2 0x124 0x500 0x000 0x0 0x0 +#define MX51_PAD_NANDF_RB2__USBH3_H3_DP 0x124 0x500 0x000 0x7 0x0 +#define MX51_PAD_NANDF_RB2__USBH3_NXT 0x124 0x500 0xa20 0x6 0x0 +#define MX51_PAD_NANDF_RB3__DISP1_WAIT 0x128 0x504 0x000 0x5 0x0 +#define MX51_PAD_NANDF_RB3__ECSPI2_MISO 0x128 0x504 0x000 0x2 0x0 +#define MX51_PAD_NANDF_RB3__FEC_RX_CLK 0x128 0x504 0x968 0x1 0x0 +#define MX51_PAD_NANDF_RB3__GPIO3_11 0x128 0x504 0x000 0x3 0x0 +#define MX51_PAD_NANDF_RB3__NANDF_RB3 0x128 0x504 0x000 0x0 0x0 +#define MX51_PAD_NANDF_RB3__USBH3_CLK 0x128 0x504 0x9f8 0x6 0x0 +#define MX51_PAD_NANDF_RB3__USBH3_H3_DM 0x128 0x504 0x000 0x7 0x0 +#define MX51_PAD_GPIO_NAND__GPIO_NAND 0x12c 0x514 0x998 0x0 0x0 +#define MX51_PAD_GPIO_NAND__PATA_INTRQ 0x12c 0x514 0x000 0x1 0x0 +#define MX51_PAD_NANDF_CS0__GPIO3_16 0x130 0x518 0x000 0x3 0x0 +#define MX51_PAD_NANDF_CS0__NANDF_CS0 0x130 0x518 0x000 0x0 0x0 +#define MX51_PAD_NANDF_CS1__GPIO3_17 0x134 0x51c 0x000 0x3 0x0 +#define MX51_PAD_NANDF_CS1__NANDF_CS1 0x134 0x51c 0x000 0x0 0x0 +#define MX51_PAD_NANDF_CS2__CSPI_SCLK 0x138 0x520 0x914 0x6 0x0 +#define MX51_PAD_NANDF_CS2__FEC_TX_ER 0x138 0x520 0x000 0x2 0x0 +#define MX51_PAD_NANDF_CS2__GPIO3_18 0x138 0x520 0x000 0x3 0x0 +#define MX51_PAD_NANDF_CS2__NANDF_CS2 0x138 0x520 0x000 0x0 0x0 +#define MX51_PAD_NANDF_CS2__PATA_CS_0 0x138 0x520 0x000 0x1 0x0 +#define MX51_PAD_NANDF_CS2__SD4_CLK 0x138 0x520 0x000 0x5 0x0 +#define MX51_PAD_NANDF_CS2__USBH3_H1_DP 0x138 0x520 0x000 0x7 0x0 +#define MX51_PAD_NANDF_CS3__FEC_MDC 0x13c 0x524 0x000 0x2 0x0 +#define MX51_PAD_NANDF_CS3__GPIO3_19 0x13c 0x524 0x000 0x3 0x0 +#define MX51_PAD_NANDF_CS3__NANDF_CS3 0x13c 0x524 0x000 0x0 0x0 +#define MX51_PAD_NANDF_CS3__PATA_CS_1 0x13c 0x524 0x000 0x1 0x0 +#define MX51_PAD_NANDF_CS3__SD4_DAT0 0x13c 0x524 0x000 0x5 0x0 +#define MX51_PAD_NANDF_CS3__USBH3_H1_DM 0x13c 0x524 0x000 0x7 0x0 +#define MX51_PAD_NANDF_CS4__FEC_TDATA1 0x140 0x528 0x000 0x2 0x0 +#define MX51_PAD_NANDF_CS4__GPIO3_20 0x140 0x528 0x000 0x3 0x0 +#define MX51_PAD_NANDF_CS4__NANDF_CS4 0x140 0x528 0x000 0x0 0x0 +#define MX51_PAD_NANDF_CS4__PATA_DA_0 0x140 0x528 0x000 0x1 0x0 +#define MX51_PAD_NANDF_CS4__SD4_DAT1 0x140 0x528 0x000 0x5 0x0 +#define MX51_PAD_NANDF_CS4__USBH3_STP 0x140 0x528 0xa24 0x7 0x0 +#define MX51_PAD_NANDF_CS5__FEC_TDATA2 0x144 0x52c 0x000 0x2 0x0 +#define MX51_PAD_NANDF_CS5__GPIO3_21 0x144 0x52c 0x000 0x3 0x0 +#define MX51_PAD_NANDF_CS5__NANDF_CS5 0x144 0x52c 0x000 0x0 0x0 +#define MX51_PAD_NANDF_CS5__PATA_DA_1 0x144 0x52c 0x000 0x1 0x0 +#define MX51_PAD_NANDF_CS5__SD4_DAT2 0x144 0x52c 0x000 0x5 0x0 +#define MX51_PAD_NANDF_CS5__USBH3_DIR 0x144 0x52c 0xa1c 0x7 0x0 +#define MX51_PAD_NANDF_CS6__CSPI_SS3 0x148 0x530 0x928 0x7 0x0 +#define MX51_PAD_NANDF_CS6__FEC_TDATA3 0x148 0x530 0x000 0x2 0x0 +#define MX51_PAD_NANDF_CS6__GPIO3_22 0x148 0x530 0x000 0x3 0x0 +#define MX51_PAD_NANDF_CS6__NANDF_CS6 0x148 0x530 0x000 0x0 0x0 +#define MX51_PAD_NANDF_CS6__PATA_DA_2 0x148 0x530 0x000 0x1 0x0 +#define MX51_PAD_NANDF_CS6__SD4_DAT3 0x148 0x530 0x000 0x5 0x0 +#define MX51_PAD_NANDF_CS7__FEC_TX_EN 0x14c 0x534 0x000 0x1 0x0 +#define MX51_PAD_NANDF_CS7__GPIO3_23 0x14c 0x534 0x000 0x3 0x0 +#define MX51_PAD_NANDF_CS7__NANDF_CS7 0x14c 0x534 0x000 0x0 0x0 +#define MX51_PAD_NANDF_CS7__SD3_CLK 0x14c 0x534 0x000 0x5 0x0 +#define MX51_PAD_NANDF_RDY_INT__ECSPI2_SS0 0x150 0x538 0x000 0x2 0x0 +#define MX51_PAD_NANDF_RDY_INT__FEC_TX_CLK 0x150 0x538 0x974 0x1 0x0 +#define MX51_PAD_NANDF_RDY_INT__GPIO3_24 0x150 0x538 0x000 0x3 0x0 +#define MX51_PAD_NANDF_RDY_INT__NANDF_RDY_INT 0x150 0x538 0x938 0x0 0x0 +#define MX51_PAD_NANDF_RDY_INT__SD3_CMD 0x150 0x538 0x000 0x5 0x0 +#define MX51_PAD_NANDF_D15__ECSPI2_MOSI 0x154 0x53c 0x000 0x2 0x0 +#define MX51_PAD_NANDF_D15__GPIO3_25 0x154 0x53c 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D15__NANDF_D15 0x154 0x53c 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D15__PATA_DATA15 0x154 0x53c 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D15__SD3_DAT7 0x154 0x53c 0x000 0x5 0x0 +#define MX51_PAD_NANDF_D14__ECSPI2_SS3 0x158 0x540 0x934 0x2 0x0 +#define MX51_PAD_NANDF_D14__GPIO3_26 0x158 0x540 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D14__NANDF_D14 0x158 0x540 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D14__PATA_DATA14 0x158 0x540 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D14__SD3_DAT6 0x158 0x540 0x000 0x5 0x0 +#define MX51_PAD_NANDF_D13__ECSPI2_SS2 0x15c 0x544 0x000 0x2 0x0 +#define MX51_PAD_NANDF_D13__GPIO3_27 0x15c 0x544 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D13__NANDF_D13 0x15c 0x544 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D13__PATA_DATA13 0x15c 0x544 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D13__SD3_DAT5 0x15c 0x544 0x000 0x5 0x0 +#define MX51_PAD_NANDF_D12__ECSPI2_SS1 0x160 0x548 0x930 0x2 0x1 +#define MX51_PAD_NANDF_D12__GPIO3_28 0x160 0x548 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D12__NANDF_D12 0x160 0x548 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D12__PATA_DATA12 0x160 0x548 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D12__SD3_DAT4 0x160 0x548 0x000 0x5 0x0 +#define MX51_PAD_NANDF_D11__FEC_RX_DV 0x164 0x54c 0x96c 0x2 0x0 +#define MX51_PAD_NANDF_D11__GPIO3_29 0x164 0x54c 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D11__NANDF_D11 0x164 0x54c 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D11__PATA_DATA11 0x164 0x54c 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D11__SD3_DATA3 0x164 0x54c 0x948 0x5 0x1 +#define MX51_PAD_NANDF_D10__GPIO3_30 0x168 0x550 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D10__NANDF_D10 0x168 0x550 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D10__PATA_DATA10 0x168 0x550 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D10__SD3_DATA2 0x168 0x550 0x944 0x5 0x1 +#define MX51_PAD_NANDF_D9__FEC_RDATA0 0x16c 0x554 0x958 0x2 0x0 +#define MX51_PAD_NANDF_D9__GPIO3_31 0x16c 0x554 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D9__NANDF_D9 0x16c 0x554 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D9__PATA_DATA9 0x16c 0x554 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D9__SD3_DATA1 0x16c 0x554 0x940 0x5 0x1 +#define MX51_PAD_NANDF_D8__FEC_TDATA0 0x170 0x558 0x000 0x2 0x0 +#define MX51_PAD_NANDF_D8__GPIO4_0 0x170 0x558 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D8__NANDF_D8 0x170 0x558 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D8__PATA_DATA8 0x170 0x558 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D8__SD3_DATA0 0x170 0x558 0x93c 0x5 0x1 +#define MX51_PAD_NANDF_D7__GPIO4_1 0x174 0x55c 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D7__NANDF_D7 0x174 0x55c 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D7__PATA_DATA7 0x174 0x55c 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D7__USBH3_DATA0 0x174 0x55c 0x9fc 0x5 0x0 +#define MX51_PAD_NANDF_D6__GPIO4_2 0x178 0x560 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D6__NANDF_D6 0x178 0x560 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D6__PATA_DATA6 0x178 0x560 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D6__SD4_LCTL 0x178 0x560 0x000 0x2 0x0 +#define MX51_PAD_NANDF_D6__USBH3_DATA1 0x178 0x560 0xa00 0x5 0x0 +#define MX51_PAD_NANDF_D5__GPIO4_3 0x17c 0x564 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D5__NANDF_D5 0x17c 0x564 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D5__PATA_DATA5 0x17c 0x564 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D5__SD4_WP 0x17c 0x564 0x000 0x2 0x0 +#define MX51_PAD_NANDF_D5__USBH3_DATA2 0x17c 0x564 0xa04 0x5 0x0 +#define MX51_PAD_NANDF_D4__GPIO4_4 0x180 0x568 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D4__NANDF_D4 0x180 0x568 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D4__PATA_DATA4 0x180 0x568 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D4__SD4_CD 0x180 0x568 0x000 0x2 0x0 +#define MX51_PAD_NANDF_D4__USBH3_DATA3 0x180 0x568 0xa08 0x5 0x0 +#define MX51_PAD_NANDF_D3__GPIO4_5 0x184 0x56c 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D3__NANDF_D3 0x184 0x56c 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D3__PATA_DATA3 0x184 0x56c 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D3__SD4_DAT4 0x184 0x56c 0x000 0x2 0x0 +#define MX51_PAD_NANDF_D3__USBH3_DATA4 0x184 0x56c 0xa0c 0x5 0x0 +#define MX51_PAD_NANDF_D2__GPIO4_6 0x188 0x570 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D2__NANDF_D2 0x188 0x570 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D2__PATA_DATA2 0x188 0x570 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D2__SD4_DAT5 0x188 0x570 0x000 0x2 0x0 +#define MX51_PAD_NANDF_D2__USBH3_DATA5 0x188 0x570 0xa10 0x5 0x0 +#define MX51_PAD_NANDF_D1__GPIO4_7 0x18c 0x574 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D1__NANDF_D1 0x18c 0x574 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D1__PATA_DATA1 0x18c 0x574 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D1__SD4_DAT6 0x18c 0x574 0x000 0x2 0x0 +#define MX51_PAD_NANDF_D1__USBH3_DATA6 0x18c 0x574 0xa14 0x5 0x0 +#define MX51_PAD_NANDF_D0__GPIO4_8 0x190 0x578 0x000 0x3 0x0 +#define MX51_PAD_NANDF_D0__NANDF_D0 0x190 0x578 0x000 0x0 0x0 +#define MX51_PAD_NANDF_D0__PATA_DATA0 0x190 0x578 0x000 0x1 0x0 +#define MX51_PAD_NANDF_D0__SD4_DAT7 0x190 0x578 0x000 0x2 0x0 +#define MX51_PAD_NANDF_D0__USBH3_DATA7 0x190 0x578 0xa18 0x5 0x0 +#define MX51_PAD_CSI1_D8__CSI1_D8 0x194 0x57c 0x000 0x0 0x0 +#define MX51_PAD_CSI1_D8__GPIO3_12 0x194 0x57c 0x998 0x3 0x1 +#define MX51_PAD_CSI1_D9__CSI1_D9 0x198 0x580 0x000 0x0 0x0 +#define MX51_PAD_CSI1_D9__GPIO3_13 0x198 0x580 0x000 0x3 0x0 +#define MX51_PAD_CSI1_D10__CSI1_D10 0x19c 0x584 0x000 0x0 0x0 +#define MX51_PAD_CSI1_D11__CSI1_D11 0x1a0 0x588 0x000 0x0 0x0 +#define MX51_PAD_CSI1_D12__CSI1_D12 0x1a4 0x58c 0x000 0x0 0x0 +#define MX51_PAD_CSI1_D13__CSI1_D13 0x1a8 0x590 0x000 0x0 0x0 +#define MX51_PAD_CSI1_D14__CSI1_D14 0x1ac 0x594 0x000 0x0 0x0 +#define MX51_PAD_CSI1_D15__CSI1_D15 0x1b0 0x598 0x000 0x0 0x0 +#define MX51_PAD_CSI1_D16__CSI1_D16 0x1b4 0x59c 0x000 0x0 0x0 +#define MX51_PAD_CSI1_D17__CSI1_D17 0x1b8 0x5a0 0x000 0x0 0x0 +#define MX51_PAD_CSI1_D18__CSI1_D18 0x1bc 0x5a4 0x000 0x0 0x0 +#define MX51_PAD_CSI1_D19__CSI1_D19 0x1c0 0x5a8 0x000 0x0 0x0 +#define MX51_PAD_CSI1_VSYNC__CSI1_VSYNC 0x1c4 0x5ac 0x000 0x0 0x0 +#define MX51_PAD_CSI1_VSYNC__GPIO3_14 0x1c4 0x5ac 0x000 0x3 0x0 +#define MX51_PAD_CSI1_HSYNC__CSI1_HSYNC 0x1c8 0x5b0 0x000 0x0 0x0 +#define MX51_PAD_CSI1_HSYNC__GPIO3_15 0x1c8 0x5b0 0x000 0x3 0x0 +#define MX51_PAD_CSI1_PIXCLK__CSI1_PIXCLK 0x000 0x5b4 0x000 0x0 0x0 +#define MX51_PAD_CSI1_MCLK__CSI1_MCLK 0x000 0x5b8 0x000 0x0 0x0 +#define MX51_PAD_CSI2_D12__CSI2_D12 0x1cc 0x5bc 0x000 0x0 0x0 +#define MX51_PAD_CSI2_D12__GPIO4_9 0x1cc 0x5bc 0x000 0x3 0x0 +#define MX51_PAD_CSI2_D13__CSI2_D13 0x1d0 0x5c0 0x000 0x0 0x0 +#define MX51_PAD_CSI2_D13__GPIO4_10 0x1d0 0x5c0 0x000 0x3 0x0 +#define MX51_PAD_CSI2_D14__CSI2_D14 0x1d4 0x5c4 0x000 0x0 0x0 +#define MX51_PAD_CSI2_D15__CSI2_D15 0x1d8 0x5c8 0x000 0x0 0x0 +#define MX51_PAD_CSI2_D16__CSI2_D16 0x1dc 0x5cc 0x000 0x0 0x0 +#define MX51_PAD_CSI2_D17__CSI2_D17 0x1e0 0x5d0 0x000 0x0 0x0 +#define MX51_PAD_CSI2_D18__CSI2_D18 0x1e4 0x5d4 0x000 0x0 0x0 +#define MX51_PAD_CSI2_D18__GPIO4_11 0x1e4 0x5d4 0x000 0x3 0x0 +#define MX51_PAD_CSI2_D19__CSI2_D19 0x1e8 0x5d8 0x000 0x0 0x0 +#define MX51_PAD_CSI2_D19__GPIO4_12 0x1e8 0x5d8 0x000 0x3 0x0 +#define MX51_PAD_CSI2_VSYNC__CSI2_VSYNC 0x1ec 0x5dc 0x000 0x0 0x0 +#define MX51_PAD_CSI2_VSYNC__GPIO4_13 0x1ec 0x5dc 0x000 0x3 0x0 +#define MX51_PAD_CSI2_HSYNC__CSI2_HSYNC 0x1f0 0x5e0 0x000 0x0 0x0 +#define MX51_PAD_CSI2_HSYNC__GPIO4_14 0x1f0 0x5e0 0x000 0x3 0x0 +#define MX51_PAD_CSI2_PIXCLK__CSI2_PIXCLK 0x1f4 0x5e4 0x000 0x0 0x0 +#define MX51_PAD_CSI2_PIXCLK__GPIO4_15 0x1f4 0x5e4 0x000 0x3 0x0 +#define MX51_PAD_I2C1_CLK__GPIO4_16 0x1f8 0x5e8 0x000 0x3 0x0 +#define MX51_PAD_I2C1_CLK__I2C1_CLK 0x1f8 0x5e8 0x000 0x0 0x0 +#define MX51_PAD_I2C1_DAT__GPIO4_17 0x1fc 0x5ec 0x000 0x3 0x0 +#define MX51_PAD_I2C1_DAT__I2C1_DAT 0x1fc 0x5ec 0x000 0x0 0x0 +#define MX51_PAD_AUD3_BB_TXD__AUD3_TXD 0x200 0x5f0 0x000 0x0 0x0 +#define MX51_PAD_AUD3_BB_TXD__GPIO4_18 0x200 0x5f0 0x000 0x3 0x0 +#define MX51_PAD_AUD3_BB_RXD__AUD3_RXD 0x204 0x5f4 0x000 0x0 0x0 +#define MX51_PAD_AUD3_BB_RXD__GPIO4_19 0x204 0x5f4 0x000 0x3 0x0 +#define MX51_PAD_AUD3_BB_RXD__UART3_RXD 0x204 0x5f4 0x9f4 0x1 0x2 +#define MX51_PAD_AUD3_BB_CK__AUD3_TXC 0x208 0x5f8 0x000 0x0 0x0 +#define MX51_PAD_AUD3_BB_CK__GPIO4_20 0x208 0x5f8 0x000 0x3 0x0 +#define MX51_PAD_AUD3_BB_FS__AUD3_TXFS 0x20c 0x5fc 0x000 0x0 0x0 +#define MX51_PAD_AUD3_BB_FS__GPIO4_21 0x20c 0x5fc 0x000 0x3 0x0 +#define MX51_PAD_AUD3_BB_FS__UART3_TXD 0x20c 0x5fc 0x000 0x1 0x0 +#define MX51_PAD_CSPI1_MOSI__ECSPI1_MOSI 0x210 0x600 0x000 0x0 0x0 +#define MX51_PAD_CSPI1_MOSI__GPIO4_22 0x210 0x600 0x000 0x3 0x0 +#define MX51_PAD_CSPI1_MOSI__I2C1_SDA 0x210 0x600 0x9b4 0x1 0x1 +#define MX51_PAD_CSPI1_MISO__AUD4_RXD 0x214 0x604 0x8c4 0x1 0x1 +#define MX51_PAD_CSPI1_MISO__ECSPI1_MISO 0x214 0x604 0x000 0x0 0x0 +#define MX51_PAD_CSPI1_MISO__GPIO4_23 0x214 0x604 0x000 0x3 0x0 +#define MX51_PAD_CSPI1_SS0__AUD4_TXC 0x218 0x608 0x8cc 0x1 0x1 +#define MX51_PAD_CSPI1_SS0__ECSPI1_SS0 0x218 0x608 0x000 0x0 0x0 +#define MX51_PAD_CSPI1_SS0__GPIO4_24 0x218 0x608 0x000 0x3 0x0 +#define MX51_PAD_CSPI1_SS1__AUD4_TXD 0x21c 0x60c 0x8c8 0x1 0x1 +#define MX51_PAD_CSPI1_SS1__ECSPI1_SS1 0x21c 0x60c 0x000 0x0 0x0 +#define MX51_PAD_CSPI1_SS1__GPIO4_25 0x21c 0x60c 0x000 0x3 0x0 +#define MX51_PAD_CSPI1_RDY__AUD4_TXFS 0x220 0x610 0x8d0 0x1 0x1 +#define MX51_PAD_CSPI1_RDY__ECSPI1_RDY 0x220 0x610 0x000 0x0 0x0 +#define MX51_PAD_CSPI1_RDY__GPIO4_26 0x220 0x610 0x000 0x3 0x0 +#define MX51_PAD_CSPI1_SCLK__ECSPI1_SCLK 0x224 0x614 0x000 0x0 0x0 +#define MX51_PAD_CSPI1_SCLK__GPIO4_27 0x224 0x614 0x000 0x3 0x0 +#define MX51_PAD_CSPI1_SCLK__I2C1_SCL 0x224 0x614 0x9b0 0x1 0x1 +#define MX51_PAD_UART1_RXD__GPIO4_28 0x228 0x618 0x000 0x3 0x0 +#define MX51_PAD_UART1_RXD__UART1_RXD 0x228 0x618 0x9e4 0x0 0x0 +#define MX51_PAD_UART1_TXD__GPIO4_29 0x22c 0x61c 0x000 0x3 0x0 +#define MX51_PAD_UART1_TXD__PWM2_PWMO 0x22c 0x61c 0x000 0x1 0x0 +#define MX51_PAD_UART1_TXD__UART1_TXD 0x22c 0x61c 0x000 0x0 0x0 +#define MX51_PAD_UART1_RTS__GPIO4_30 0x230 0x620 0x000 0x3 0x0 +#define MX51_PAD_UART1_RTS__UART1_RTS 0x230 0x620 0x9e0 0x0 0x0 +#define MX51_PAD_UART1_CTS__GPIO4_31 0x234 0x624 0x000 0x3 0x0 +#define MX51_PAD_UART1_CTS__UART1_CTS 0x234 0x624 0x000 0x0 0x0 +#define MX51_PAD_UART2_RXD__FIRI_TXD 0x238 0x628 0x000 0x1 0x0 +#define MX51_PAD_UART2_RXD__GPIO1_20 0x238 0x628 0x000 0x3 0x0 +#define MX51_PAD_UART2_RXD__UART2_RXD 0x238 0x628 0x9ec 0x0 0x2 +#define MX51_PAD_UART2_TXD__FIRI_RXD 0x23c 0x62c 0x000 0x1 0x0 +#define MX51_PAD_UART2_TXD__GPIO1_21 0x23c 0x62c 0x000 0x3 0x0 +#define MX51_PAD_UART2_TXD__UART2_TXD 0x23c 0x62c 0x000 0x0 0x0 +#define MX51_PAD_UART3_RXD__CSI1_D0 0x240 0x630 0x000 0x2 0x0 +#define MX51_PAD_UART3_RXD__GPIO1_22 0x240 0x630 0x000 0x3 0x0 +#define MX51_PAD_UART3_RXD__UART1_DTR 0x240 0x630 0x000 0x0 0x0 +#define MX51_PAD_UART3_RXD__UART3_RXD 0x240 0x630 0x9f4 0x1 0x4 +#define MX51_PAD_UART3_TXD__CSI1_D1 0x244 0x634 0x000 0x2 0x0 +#define MX51_PAD_UART3_TXD__GPIO1_23 0x244 0x634 0x000 0x3 0x0 +#define MX51_PAD_UART3_TXD__UART1_DSR 0x244 0x634 0x000 0x0 0x0 +#define MX51_PAD_UART3_TXD__UART3_TXD 0x244 0x634 0x000 0x1 0x0 +#define MX51_PAD_OWIRE_LINE__GPIO1_24 0x248 0x638 0x000 0x3 0x0 +#define MX51_PAD_OWIRE_LINE__OWIRE_LINE 0x248 0x638 0x000 0x0 0x0 +#define MX51_PAD_OWIRE_LINE__SPDIF_OUT 0x248 0x638 0x000 0x6 0x0 +#define MX51_PAD_KEY_ROW0__KEY_ROW0 0x24c 0x63c 0x000 0x0 0x0 +#define MX51_PAD_KEY_ROW1__KEY_ROW1 0x250 0x640 0x000 0x0 0x0 +#define MX51_PAD_KEY_ROW2__KEY_ROW2 0x254 0x644 0x000 0x0 0x0 +#define MX51_PAD_KEY_ROW3__KEY_ROW3 0x258 0x648 0x000 0x0 0x0 +#define MX51_PAD_KEY_COL0__KEY_COL0 0x25c 0x64c 0x000 0x0 0x0 +#define MX51_PAD_KEY_COL0__PLL1_BYP 0x25c 0x64c 0x90c 0x7 0x0 +#define MX51_PAD_KEY_COL1__KEY_COL1 0x260 0x650 0x000 0x0 0x0 +#define MX51_PAD_KEY_COL1__PLL2_BYP 0x260 0x650 0x910 0x7 0x0 +#define MX51_PAD_KEY_COL2__KEY_COL2 0x264 0x654 0x000 0x0 0x0 +#define MX51_PAD_KEY_COL2__PLL3_BYP 0x264 0x654 0x000 0x7 0x0 +#define MX51_PAD_KEY_COL3__KEY_COL3 0x268 0x658 0x000 0x0 0x0 +#define MX51_PAD_KEY_COL4__I2C2_SCL 0x26c 0x65c 0x9b8 0x3 0x1 +#define MX51_PAD_KEY_COL4__KEY_COL4 0x26c 0x65c 0x000 0x0 0x0 +#define MX51_PAD_KEY_COL4__SPDIF_OUT1 0x26c 0x65c 0x000 0x6 0x0 +#define MX51_PAD_KEY_COL4__UART1_RI 0x26c 0x65c 0x000 0x1 0x0 +#define MX51_PAD_KEY_COL4__UART3_RTS 0x26c 0x65c 0x9f0 0x2 0x4 +#define MX51_PAD_KEY_COL5__I2C2_SDA 0x270 0x660 0x9bc 0x3 0x1 +#define MX51_PAD_KEY_COL5__KEY_COL5 0x270 0x660 0x000 0x0 0x0 +#define MX51_PAD_KEY_COL5__UART1_DCD 0x270 0x660 0x000 0x1 0x0 +#define MX51_PAD_KEY_COL5__UART3_CTS 0x270 0x660 0x000 0x2 0x0 +#define MX51_PAD_USBH1_CLK__CSPI_SCLK 0x278 0x678 0x914 0x1 0x1 +#define MX51_PAD_USBH1_CLK__GPIO1_25 0x278 0x678 0x000 0x2 0x0 +#define MX51_PAD_USBH1_CLK__I2C2_SCL 0x278 0x678 0x9b8 0x5 0x2 +#define MX51_PAD_USBH1_CLK__USBH1_CLK 0x278 0x678 0x000 0x0 0x0 +#define MX51_PAD_USBH1_DIR__CSPI_MOSI 0x27c 0x67c 0x91c 0x1 0x1 +#define MX51_PAD_USBH1_DIR__GPIO1_26 0x27c 0x67c 0x000 0x2 0x0 +#define MX51_PAD_USBH1_DIR__I2C2_SDA 0x27c 0x67c 0x9bc 0x5 0x2 +#define MX51_PAD_USBH1_DIR__USBH1_DIR 0x27c 0x67c 0x000 0x0 0x0 +#define MX51_PAD_USBH1_STP__CSPI_RDY 0x280 0x680 0x000 0x1 0x0 +#define MX51_PAD_USBH1_STP__GPIO1_27 0x280 0x680 0x000 0x2 0x0 +#define MX51_PAD_USBH1_STP__UART3_RXD 0x280 0x680 0x9f4 0x5 0x6 +#define MX51_PAD_USBH1_STP__USBH1_STP 0x280 0x680 0x000 0x0 0x0 +#define MX51_PAD_USBH1_NXT__CSPI_MISO 0x284 0x684 0x918 0x1 0x0 +#define MX51_PAD_USBH1_NXT__GPIO1_28 0x284 0x684 0x000 0x2 0x0 +#define MX51_PAD_USBH1_NXT__UART3_TXD 0x284 0x684 0x000 0x5 0x0 +#define MX51_PAD_USBH1_NXT__USBH1_NXT 0x284 0x684 0x000 0x0 0x0 +#define MX51_PAD_USBH1_DATA0__GPIO1_11 0x288 0x688 0x000 0x2 0x0 +#define MX51_PAD_USBH1_DATA0__UART2_CTS 0x288 0x688 0x000 0x1 0x0 +#define MX51_PAD_USBH1_DATA0__USBH1_DATA0 0x288 0x688 0x000 0x0 0x0 +#define MX51_PAD_USBH1_DATA1__GPIO1_12 0x28c 0x68c 0x000 0x2 0x0 +#define MX51_PAD_USBH1_DATA1__UART2_RXD 0x28c 0x68c 0x9ec 0x1 0x4 +#define MX51_PAD_USBH1_DATA1__USBH1_DATA1 0x28c 0x68c 0x000 0x0 0x0 +#define MX51_PAD_USBH1_DATA2__GPIO1_13 0x290 0x690 0x000 0x2 0x0 +#define MX51_PAD_USBH1_DATA2__UART2_TXD 0x290 0x690 0x000 0x1 0x0 +#define MX51_PAD_USBH1_DATA2__USBH1_DATA2 0x290 0x690 0x000 0x0 0x0 +#define MX51_PAD_USBH1_DATA3__GPIO1_14 0x294 0x694 0x000 0x2 0x0 +#define MX51_PAD_USBH1_DATA3__UART2_RTS 0x294 0x694 0x9e8 0x1 0x5 +#define MX51_PAD_USBH1_DATA3__USBH1_DATA3 0x294 0x694 0x000 0x0 0x0 +#define MX51_PAD_USBH1_DATA4__CSPI_SS0 0x298 0x698 0x000 0x1 0x0 +#define MX51_PAD_USBH1_DATA4__GPIO1_15 0x298 0x698 0x000 0x2 0x0 +#define MX51_PAD_USBH1_DATA4__USBH1_DATA4 0x298 0x698 0x000 0x0 0x0 +#define MX51_PAD_USBH1_DATA5__CSPI_SS1 0x29c 0x69c 0x920 0x1 0x0 +#define MX51_PAD_USBH1_DATA5__GPIO1_16 0x29c 0x69c 0x000 0x2 0x0 +#define MX51_PAD_USBH1_DATA5__USBH1_DATA5 0x29c 0x69c 0x000 0x0 0x0 +#define MX51_PAD_USBH1_DATA6__CSPI_SS3 0x2a0 0x6a0 0x928 0x1 0x1 +#define MX51_PAD_USBH1_DATA6__GPIO1_17 0x2a0 0x6a0 0x000 0x2 0x0 +#define MX51_PAD_USBH1_DATA6__USBH1_DATA6 0x2a0 0x6a0 0x000 0x0 0x0 +#define MX51_PAD_USBH1_DATA7__ECSPI1_SS3 0x2a4 0x6a4 0x000 0x1 0x0 +#define MX51_PAD_USBH1_DATA7__ECSPI2_SS3 0x2a4 0x6a4 0x934 0x5 0x1 +#define MX51_PAD_USBH1_DATA7__GPIO1_18 0x2a4 0x6a4 0x000 0x2 0x0 +#define MX51_PAD_USBH1_DATA7__USBH1_DATA7 0x2a4 0x6a4 0x000 0x0 0x0 +#define MX51_PAD_DI1_PIN11__DI1_PIN11 0x2a8 0x6a8 0x000 0x0 0x0 +#define MX51_PAD_DI1_PIN11__ECSPI1_SS2 0x2a8 0x6a8 0x000 0x7 0x0 +#define MX51_PAD_DI1_PIN11__GPIO3_0 0x2a8 0x6a8 0x000 0x4 0x0 +#define MX51_PAD_DI1_PIN12__DI1_PIN12 0x2ac 0x6ac 0x000 0x0 0x0 +#define MX51_PAD_DI1_PIN12__GPIO3_1 0x2ac 0x6ac 0x978 0x4 0x1 +#define MX51_PAD_DI1_PIN13__DI1_PIN13 0x2b0 0x6b0 0x000 0x0 0x0 +#define MX51_PAD_DI1_PIN13__GPIO3_2 0x2b0 0x6b0 0x97c 0x4 0x1 +#define MX51_PAD_DI1_D0_CS__DI1_D0_CS 0x2b4 0x6b4 0x000 0x0 0x0 +#define MX51_PAD_DI1_D0_CS__GPIO3_3 0x2b4 0x6b4 0x980 0x4 0x1 +#define MX51_PAD_DI1_D1_CS__DI1_D1_CS 0x2b8 0x6b8 0x000 0x0 0x0 +#define MX51_PAD_DI1_D1_CS__DISP1_PIN14 0x2b8 0x6b8 0x000 0x2 0x0 +#define MX51_PAD_DI1_D1_CS__DISP1_PIN5 0x2b8 0x6b8 0x000 0x3 0x0 +#define MX51_PAD_DI1_D1_CS__GPIO3_4 0x2b8 0x6b8 0x984 0x4 0x1 +#define MX51_PAD_DISPB2_SER_DIN__DISP1_PIN1 0x2bc 0x6bc 0x9a4 0x2 0x1 +#define MX51_PAD_DISPB2_SER_DIN__DISPB2_SER_DIN 0x2bc 0x6bc 0x9c4 0x0 0x0 +#define MX51_PAD_DISPB2_SER_DIN__GPIO3_5 0x2bc 0x6bc 0x988 0x4 0x1 +#define MX51_PAD_DISPB2_SER_DIO__DISP1_PIN6 0x2c0 0x6c0 0x000 0x3 0x0 +#define MX51_PAD_DISPB2_SER_DIO__DISPB2_SER_DIO 0x2c0 0x6c0 0x9c4 0x0 0x1 +#define MX51_PAD_DISPB2_SER_DIO__GPIO3_6 0x2c0 0x6c0 0x98c 0x4 0x1 +#define MX51_PAD_DISPB2_SER_CLK__DISP1_PIN17 0x2c4 0x6c4 0x000 0x2 0x0 +#define MX51_PAD_DISPB2_SER_CLK__DISP1_PIN7 0x2c4 0x6c4 0x000 0x3 0x0 +#define MX51_PAD_DISPB2_SER_CLK__DISPB2_SER_CLK 0x2c4 0x6c4 0x000 0x0 0x0 +#define MX51_PAD_DISPB2_SER_CLK__GPIO3_7 0x2c4 0x6c4 0x990 0x4 0x1 +#define MX51_PAD_DISPB2_SER_RS__DISP1_PIN16 0x2c8 0x6c8 0x000 0x2 0x0 +#define MX51_PAD_DISPB2_SER_RS__DISP1_PIN8 0x2c8 0x6c8 0x000 0x3 0x0 +#define MX51_PAD_DISPB2_SER_RS__DISPB2_SER_RS 0x2c8 0x6c8 0x000 0x0 0x0 +#define MX51_PAD_DISPB2_SER_RS__GPIO3_8 0x2c8 0x6c8 0x994 0x4 0x1 +#define MX51_PAD_DISP1_DAT0__DISP1_DAT0 0x2cc 0x6cc 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT1__DISP1_DAT1 0x2d0 0x6d0 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT2__DISP1_DAT2 0x2d4 0x6d4 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT3__DISP1_DAT3 0x2d8 0x6d8 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT4__DISP1_DAT4 0x2dc 0x6dc 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT5__DISP1_DAT5 0x2e0 0x6e0 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT6__BOOT_USB_SRC 0x2e4 0x6e4 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT6__DISP1_DAT6 0x2e4 0x6e4 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT7__BOOT_EEPROM_CFG 0x2e8 0x6e8 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT7__DISP1_DAT7 0x2e8 0x6e8 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT8__BOOT_SRC0 0x2ec 0x6ec 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT8__DISP1_DAT8 0x2ec 0x6ec 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT9__BOOT_SRC1 0x2f0 0x6f0 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT9__DISP1_DAT9 0x2f0 0x6f0 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT10__BOOT_SPARE_SIZE 0x2f4 0x6f4 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT10__DISP1_DAT10 0x2f4 0x6f4 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT11__BOOT_LPB_FREQ2 0x2f8 0x6f8 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT11__DISP1_DAT11 0x2f8 0x6f8 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT12__BOOT_MLC_SEL 0x2fc 0x6fc 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT12__DISP1_DAT12 0x2fc 0x6fc 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT13__BOOT_MEM_CTL0 0x300 0x700 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT13__DISP1_DAT13 0x300 0x700 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT14__BOOT_MEM_CTL1 0x304 0x704 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT14__DISP1_DAT14 0x304 0x704 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT15__BOOT_BUS_WIDTH 0x308 0x708 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT15__DISP1_DAT15 0x308 0x708 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT16__BOOT_PAGE_SIZE0 0x30c 0x70c 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT16__DISP1_DAT16 0x30c 0x70c 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT17__BOOT_PAGE_SIZE1 0x310 0x710 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT17__DISP1_DAT17 0x310 0x710 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT18__BOOT_WEIM_MUXED0 0x314 0x714 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT18__DISP1_DAT18 0x314 0x714 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT18__DISP2_PIN11 0x314 0x714 0x000 0x5 0x0 +#define MX51_PAD_DISP1_DAT18__DISP2_PIN5 0x314 0x714 0x000 0x4 0x0 +#define MX51_PAD_DISP1_DAT19__BOOT_WEIM_MUXED1 0x318 0x718 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT19__DISP1_DAT19 0x318 0x718 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT19__DISP2_PIN12 0x318 0x718 0x000 0x5 0x0 +#define MX51_PAD_DISP1_DAT19__DISP2_PIN6 0x318 0x718 0x000 0x4 0x0 +#define MX51_PAD_DISP1_DAT20__BOOT_MEM_TYPE0 0x31c 0x71c 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT20__DISP1_DAT20 0x31c 0x71c 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT20__DISP2_PIN13 0x31c 0x71c 0x000 0x5 0x0 +#define MX51_PAD_DISP1_DAT20__DISP2_PIN7 0x31c 0x71c 0x000 0x4 0x0 +#define MX51_PAD_DISP1_DAT21__BOOT_MEM_TYPE1 0x320 0x720 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT21__DISP1_DAT21 0x320 0x720 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT21__DISP2_PIN14 0x320 0x720 0x000 0x5 0x0 +#define MX51_PAD_DISP1_DAT21__DISP2_PIN8 0x320 0x720 0x000 0x4 0x0 +#define MX51_PAD_DISP1_DAT22__BOOT_LPB_FREQ0 0x324 0x724 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT22__DISP1_DAT22 0x324 0x724 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT22__DISP2_D0_CS 0x324 0x724 0x000 0x6 0x0 +#define MX51_PAD_DISP1_DAT22__DISP2_DAT16 0x324 0x724 0x000 0x5 0x0 +#define MX51_PAD_DISP1_DAT23__BOOT_LPB_FREQ1 0x328 0x728 0x000 0x7 0x0 +#define MX51_PAD_DISP1_DAT23__DISP1_DAT23 0x328 0x728 0x000 0x0 0x0 +#define MX51_PAD_DISP1_DAT23__DISP2_D1_CS 0x328 0x728 0x000 0x6 0x0 +#define MX51_PAD_DISP1_DAT23__DISP2_DAT17 0x328 0x728 0x000 0x5 0x0 +#define MX51_PAD_DISP1_DAT23__DISP2_SER_CS 0x328 0x728 0x000 0x4 0x0 +#define MX51_PAD_DI1_PIN3__DI1_PIN3 0x32c 0x72c 0x000 0x0 0x0 +#define MX51_PAD_DI1_PIN2__DI1_PIN2 0x330 0x734 0x000 0x0 0x0 +#define MX51_PAD_DI_GP2__DISP1_SER_CLK 0x338 0x740 0x000 0x0 0x0 +#define MX51_PAD_DI_GP2__DISP2_WAIT 0x338 0x740 0x9a8 0x2 0x1 +#define MX51_PAD_DI_GP3__CSI1_DATA_EN 0x33c 0x744 0x9a0 0x3 0x1 +#define MX51_PAD_DI_GP3__DISP1_SER_DIO 0x33c 0x744 0x9c0 0x0 0x0 +#define MX51_PAD_DI_GP3__FEC_TX_ER 0x33c 0x744 0x000 0x2 0x0 +#define MX51_PAD_DI2_PIN4__CSI2_DATA_EN 0x340 0x748 0x99c 0x3 0x1 +#define MX51_PAD_DI2_PIN4__DI2_PIN4 0x340 0x748 0x000 0x0 0x0 +#define MX51_PAD_DI2_PIN4__FEC_CRS 0x340 0x748 0x950 0x2 0x1 +#define MX51_PAD_DI2_PIN2__DI2_PIN2 0x344 0x74c 0x000 0x0 0x0 +#define MX51_PAD_DI2_PIN2__FEC_MDC 0x344 0x74c 0x000 0x2 0x0 +#define MX51_PAD_DI2_PIN3__DI2_PIN3 0x348 0x750 0x000 0x0 0x0 +#define MX51_PAD_DI2_PIN3__FEC_MDIO 0x348 0x750 0x954 0x2 0x1 +#define MX51_PAD_DI2_DISP_CLK__DI2_DISP_CLK 0x34c 0x754 0x000 0x0 0x0 +#define MX51_PAD_DI2_DISP_CLK__FEC_RDATA1 0x34c 0x754 0x95c 0x2 0x1 +#define MX51_PAD_DI_GP4__DI2_PIN15 0x350 0x758 0x000 0x4 0x0 +#define MX51_PAD_DI_GP4__DISP1_SER_DIN 0x350 0x758 0x9c0 0x0 0x1 +#define MX51_PAD_DI_GP4__DISP2_PIN1 0x350 0x758 0x000 0x3 0x0 +#define MX51_PAD_DI_GP4__FEC_RDATA2 0x350 0x758 0x960 0x2 0x1 +#define MX51_PAD_DISP2_DAT0__DISP2_DAT0 0x354 0x75c 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT0__FEC_RDATA3 0x354 0x75c 0x964 0x2 0x1 +#define MX51_PAD_DISP2_DAT0__KEY_COL6 0x354 0x75c 0x9c8 0x4 0x1 +#define MX51_PAD_DISP2_DAT0__UART3_RXD 0x354 0x75c 0x9f4 0x5 0x8 +#define MX51_PAD_DISP2_DAT0__USBH3_CLK 0x354 0x75c 0x9f8 0x3 0x1 +#define MX51_PAD_DISP2_DAT1__DISP2_DAT1 0x358 0x760 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT1__FEC_RX_ER 0x358 0x760 0x970 0x2 0x1 +#define MX51_PAD_DISP2_DAT1__KEY_COL7 0x358 0x760 0x9cc 0x4 0x1 +#define MX51_PAD_DISP2_DAT1__UART3_TXD 0x358 0x760 0x000 0x5 0x0 +#define MX51_PAD_DISP2_DAT1__USBH3_DIR 0x358 0x760 0xa1c 0x3 0x1 +#define MX51_PAD_DISP2_DAT2__DISP2_DAT2 0x35c 0x764 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT3__DISP2_DAT3 0x360 0x768 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT4__DISP2_DAT4 0x364 0x76c 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT5__DISP2_DAT5 0x368 0x770 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT6__DISP2_DAT6 0x36c 0x774 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT6__FEC_TDATA1 0x36c 0x774 0x000 0x2 0x0 +#define MX51_PAD_DISP2_DAT6__GPIO1_19 0x36c 0x774 0x000 0x5 0x0 +#define MX51_PAD_DISP2_DAT6__KEY_ROW4 0x36c 0x774 0x9d0 0x4 0x1 +#define MX51_PAD_DISP2_DAT6__USBH3_STP 0x36c 0x774 0xa24 0x3 0x1 +#define MX51_PAD_DISP2_DAT7__DISP2_DAT7 0x370 0x778 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT7__FEC_TDATA2 0x370 0x778 0x000 0x2 0x0 +#define MX51_PAD_DISP2_DAT7__GPIO1_29 0x370 0x778 0x000 0x5 0x0 +#define MX51_PAD_DISP2_DAT7__KEY_ROW5 0x370 0x778 0x9d4 0x4 0x1 +#define MX51_PAD_DISP2_DAT7__USBH3_NXT 0x370 0x778 0xa20 0x3 0x1 +#define MX51_PAD_DISP2_DAT8__DISP2_DAT8 0x374 0x77c 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT8__FEC_TDATA3 0x374 0x77c 0x000 0x2 0x0 +#define MX51_PAD_DISP2_DAT8__GPIO1_30 0x374 0x77c 0x000 0x5 0x0 +#define MX51_PAD_DISP2_DAT8__KEY_ROW6 0x374 0x77c 0x9d8 0x4 0x1 +#define MX51_PAD_DISP2_DAT8__USBH3_DATA0 0x374 0x77c 0x9fc 0x3 0x1 +#define MX51_PAD_DISP2_DAT9__AUD6_RXC 0x378 0x780 0x8f4 0x4 0x1 +#define MX51_PAD_DISP2_DAT9__DISP2_DAT9 0x378 0x780 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT9__FEC_TX_EN 0x378 0x780 0x000 0x2 0x0 +#define MX51_PAD_DISP2_DAT9__GPIO1_31 0x378 0x780 0x000 0x5 0x0 +#define MX51_PAD_DISP2_DAT9__USBH3_DATA1 0x378 0x780 0xa00 0x3 0x1 +#define MX51_PAD_DISP2_DAT10__DISP2_DAT10 0x37c 0x784 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT10__DISP2_SER_CS 0x37c 0x784 0x000 0x5 0x0 +#define MX51_PAD_DISP2_DAT10__FEC_COL 0x37c 0x784 0x94c 0x2 0x1 +#define MX51_PAD_DISP2_DAT10__KEY_ROW7 0x37c 0x784 0x9dc 0x4 0x1 +#define MX51_PAD_DISP2_DAT10__USBH3_DATA2 0x37c 0x784 0xa04 0x3 0x1 +#define MX51_PAD_DISP2_DAT11__AUD6_TXD 0x380 0x788 0x8f0 0x4 0x1 +#define MX51_PAD_DISP2_DAT11__DISP2_DAT11 0x380 0x788 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT11__FEC_RX_CLK 0x380 0x788 0x968 0x2 0x1 +#define MX51_PAD_DISP2_DAT11__GPIO1_10 0x380 0x788 0x000 0x7 0x0 +#define MX51_PAD_DISP2_DAT11__USBH3_DATA3 0x380 0x788 0xa08 0x3 0x1 +#define MX51_PAD_DISP2_DAT12__AUD6_RXD 0x384 0x78c 0x8ec 0x4 0x1 +#define MX51_PAD_DISP2_DAT12__DISP2_DAT12 0x384 0x78c 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT12__FEC_RX_DV 0x384 0x78c 0x96c 0x2 0x1 +#define MX51_PAD_DISP2_DAT12__USBH3_DATA4 0x384 0x78c 0xa0c 0x3 0x1 +#define MX51_PAD_DISP2_DAT13__AUD6_TXC 0x388 0x790 0x8fc 0x4 0x1 +#define MX51_PAD_DISP2_DAT13__DISP2_DAT13 0x388 0x790 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT13__FEC_TX_CLK 0x388 0x790 0x974 0x2 0x1 +#define MX51_PAD_DISP2_DAT13__USBH3_DATA5 0x388 0x790 0xa10 0x3 0x1 +#define MX51_PAD_DISP2_DAT14__AUD6_TXFS 0x38c 0x794 0x900 0x4 0x1 +#define MX51_PAD_DISP2_DAT14__DISP2_DAT14 0x38c 0x794 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT14__FEC_RDATA0 0x38c 0x794 0x958 0x2 0x1 +#define MX51_PAD_DISP2_DAT14__USBH3_DATA6 0x38c 0x794 0xa14 0x3 0x1 +#define MX51_PAD_DISP2_DAT15__AUD6_RXFS 0x390 0x798 0x8f8 0x4 0x1 +#define MX51_PAD_DISP2_DAT15__DISP1_SER_CS 0x390 0x798 0x000 0x5 0x0 +#define MX51_PAD_DISP2_DAT15__DISP2_DAT15 0x390 0x798 0x000 0x0 0x0 +#define MX51_PAD_DISP2_DAT15__FEC_TDATA0 0x390 0x798 0x000 0x2 0x0 +#define MX51_PAD_DISP2_DAT15__USBH3_DATA7 0x390 0x798 0xa18 0x3 0x1 +#define MX51_PAD_SD1_CMD__AUD5_RXFS 0x394 0x79c 0x8e0 0x1 0x1 +#define MX51_PAD_SD1_CMD__CSPI_MOSI 0x394 0x79c 0x91c 0x2 0x2 +#define MX51_PAD_SD1_CMD__SD1_CMD 0x394 0x79c 0x000 0x0 0x0 +#define MX51_PAD_SD1_CLK__AUD5_RXC 0x398 0x7a0 0x8dc 0x1 0x1 +#define MX51_PAD_SD1_CLK__CSPI_SCLK 0x398 0x7a0 0x914 0x2 0x2 +#define MX51_PAD_SD1_CLK__SD1_CLK 0x398 0x7a0 0x000 0x0 0x0 +#define MX51_PAD_SD1_DATA0__AUD5_TXD 0x39c 0x7a4 0x8d8 0x1 0x2 +#define MX51_PAD_SD1_DATA0__CSPI_MISO 0x39c 0x7a4 0x918 0x2 0x1 +#define MX51_PAD_SD1_DATA0__SD1_DATA0 0x39c 0x7a4 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA0__EIM_DA0 0x01c 0x000 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA1__EIM_DA1 0x020 0x000 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA2__EIM_DA2 0x024 0x000 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA3__EIM_DA3 0x028 0x000 0x000 0x0 0x0 +#define MX51_PAD_SD1_DATA1__AUD5_RXD 0x3a0 0x7a8 0x8d4 0x1 0x2 +#define MX51_PAD_SD1_DATA1__SD1_DATA1 0x3a0 0x7a8 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA4__EIM_DA4 0x02c 0x000 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA5__EIM_DA5 0x030 0x000 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA6__EIM_DA6 0x034 0x000 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA7__EIM_DA7 0x038 0x000 0x000 0x0 0x0 +#define MX51_PAD_SD1_DATA2__AUD5_TXC 0x3a4 0x7ac 0x8e4 0x1 0x2 +#define MX51_PAD_SD1_DATA2__SD1_DATA2 0x3a4 0x7ac 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA10__EIM_DA10 0x044 0x000 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA11__EIM_DA11 0x048 0x000 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA8__EIM_DA8 0x03c 0x000 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA9__EIM_DA9 0x040 0x000 0x000 0x0 0x0 +#define MX51_PAD_SD1_DATA3__AUD5_TXFS 0x3a8 0x7b0 0x8e8 0x1 0x2 +#define MX51_PAD_SD1_DATA3__CSPI_SS1 0x3a8 0x7b0 0x920 0x2 0x1 +#define MX51_PAD_SD1_DATA3__SD1_DATA3 0x3a8 0x7b0 0x000 0x0 0x0 +#define MX51_PAD_GPIO1_0__CSPI_SS2 0x3ac 0x7b4 0x924 0x2 0x0 +#define MX51_PAD_GPIO1_0__GPIO1_0 0x3ac 0x7b4 0x000 0x1 0x0 +#define MX51_PAD_GPIO1_0__SD1_CD 0x3ac 0x7b4 0x000 0x0 0x0 +#define MX51_PAD_GPIO1_1__CSPI_MISO 0x3b0 0x7b8 0x918 0x2 0x2 +#define MX51_PAD_GPIO1_1__GPIO1_1 0x3b0 0x7b8 0x000 0x1 0x0 +#define MX51_PAD_GPIO1_1__SD1_WP 0x3b0 0x7b8 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA12__EIM_DA12 0x04c 0x000 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA13__EIM_DA13 0x050 0x000 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA14__EIM_DA14 0x054 0x000 0x000 0x0 0x0 +#define MX51_PAD_EIM_DA15__EIM_DA15 0x058 0x000 0x000 0x0 0x0 +#define MX51_PAD_SD2_CMD__CSPI_MOSI 0x3b4 0x7bc 0x91c 0x2 0x3 +#define MX51_PAD_SD2_CMD__I2C1_SCL 0x3b4 0x7bc 0x9b0 0x1 0x2 +#define MX51_PAD_SD2_CMD__SD2_CMD 0x3b4 0x7bc 0x000 0x0 0x0 +#define MX51_PAD_SD2_CLK__CSPI_SCLK 0x3b8 0x7c0 0x914 0x2 0x3 +#define MX51_PAD_SD2_CLK__I2C1_SDA 0x3b8 0x7c0 0x9b4 0x1 0x2 +#define MX51_PAD_SD2_CLK__SD2_CLK 0x3b8 0x7c0 0x000 0x0 0x0 +#define MX51_PAD_SD2_DATA0__CSPI_MISO 0x3bc 0x7c4 0x918 0x2 0x3 +#define MX51_PAD_SD2_DATA0__SD1_DAT4 0x3bc 0x7c4 0x000 0x1 0x0 +#define MX51_PAD_SD2_DATA0__SD2_DATA0 0x3bc 0x7c4 0x000 0x0 0x0 +#define MX51_PAD_SD2_DATA1__SD1_DAT5 0x3c0 0x7c8 0x000 0x1 0x0 +#define MX51_PAD_SD2_DATA1__SD2_DATA1 0x3c0 0x7c8 0x000 0x0 0x0 +#define MX51_PAD_SD2_DATA1__USBH3_H2_DP 0x3c0 0x7c8 0x000 0x2 0x0 +#define MX51_PAD_SD2_DATA2__SD1_DAT6 0x3c4 0x7cc 0x000 0x1 0x0 +#define MX51_PAD_SD2_DATA2__SD2_DATA2 0x3c4 0x7cc 0x000 0x0 0x0 +#define MX51_PAD_SD2_DATA2__USBH3_H2_DM 0x3c4 0x7cc 0x000 0x2 0x0 +#define MX51_PAD_SD2_DATA3__CSPI_SS2 0x3c8 0x7d0 0x924 0x2 0x1 +#define MX51_PAD_SD2_DATA3__SD1_DAT7 0x3c8 0x7d0 0x000 0x1 0x0 +#define MX51_PAD_SD2_DATA3__SD2_DATA3 0x3c8 0x7d0 0x000 0x0 0x0 +#define MX51_PAD_GPIO1_2__CCM_OUT_2 0x3cc 0x7d4 0x000 0x5 0x0 +#define MX51_PAD_GPIO1_2__GPIO1_2 0x3cc 0x7d4 0x000 0x0 0x0 +#define MX51_PAD_GPIO1_2__I2C2_SCL 0x3cc 0x7d4 0x9b8 0x2 0x3 +#define MX51_PAD_GPIO1_2__PLL1_BYP 0x3cc 0x7d4 0x90c 0x7 0x1 +#define MX51_PAD_GPIO1_2__PWM1_PWMO 0x3cc 0x7d4 0x000 0x1 0x0 +#define MX51_PAD_GPIO1_3__GPIO1_3 0x3d0 0x7d8 0x000 0x0 0x0 +#define MX51_PAD_GPIO1_3__I2C2_SDA 0x3d0 0x7d8 0x9bc 0x2 0x3 +#define MX51_PAD_GPIO1_3__PLL2_BYP 0x3d0 0x7d8 0x910 0x7 0x1 +#define MX51_PAD_GPIO1_3__PWM2_PWMO 0x3d0 0x7d8 0x000 0x1 0x0 +#define MX51_PAD_PMIC_INT_REQ__PMIC_INT_REQ 0x3d4 0x7fc 0x000 0x0 0x0 +#define MX51_PAD_PMIC_INT_REQ__PMIC_PMU_IRQ_B 0x3d4 0x7fc 0x000 0x1 0x0 +#define MX51_PAD_GPIO1_4__DISP2_EXT_CLK 0x3d8 0x804 0x908 0x4 0x1 +#define MX51_PAD_GPIO1_4__EIM_RDY 0x3d8 0x804 0x938 0x3 0x1 +#define MX51_PAD_GPIO1_4__GPIO1_4 0x3d8 0x804 0x000 0x0 0x0 +#define MX51_PAD_GPIO1_4__WDOG1_WDOG_B 0x3d8 0x804 0x000 0x2 0x0 +#define MX51_PAD_GPIO1_5__CSI2_MCLK 0x3dc 0x808 0x000 0x6 0x0 +#define MX51_PAD_GPIO1_5__DISP2_PIN16 0x3dc 0x808 0x000 0x3 0x0 +#define MX51_PAD_GPIO1_5__GPIO1_5 0x3dc 0x808 0x000 0x0 0x0 +#define MX51_PAD_GPIO1_5__WDOG2_WDOG_B 0x3dc 0x808 0x000 0x2 0x0 +#define MX51_PAD_GPIO1_6__DISP2_PIN17 0x3e0 0x80c 0x000 0x4 0x0 +#define MX51_PAD_GPIO1_6__GPIO1_6 0x3e0 0x80c 0x000 0x0 0x0 +#define MX51_PAD_GPIO1_6__REF_EN_B 0x3e0 0x80c 0x000 0x3 0x0 +#define MX51_PAD_GPIO1_7__CCM_OUT_0 0x3e4 0x810 0x000 0x3 0x0 +#define MX51_PAD_GPIO1_7__GPIO1_7 0x3e4 0x810 0x000 0x0 0x0 +#define MX51_PAD_GPIO1_7__SD2_WP 0x3e4 0x810 0x000 0x6 0x0 +#define MX51_PAD_GPIO1_7__SPDIF_OUT1 0x3e4 0x810 0x000 0x2 0x0 +#define MX51_PAD_GPIO1_8__CSI2_DATA_EN 0x3e8 0x814 0x99c 0x2 0x2 +#define MX51_PAD_GPIO1_8__GPIO1_8 0x3e8 0x814 0x000 0x0 0x0 +#define MX51_PAD_GPIO1_8__SD2_CD 0x3e8 0x814 0x000 0x6 0x0 +#define MX51_PAD_GPIO1_8__USBH3_PWR 0x3e8 0x814 0x000 0x1 0x0 +#define MX51_PAD_GPIO1_9__CCM_OUT_1 0x3ec 0x818 0x000 0x3 0x0 +#define MX51_PAD_GPIO1_9__DISP2_D1_CS 0x3ec 0x818 0x000 0x2 0x0 +#define MX51_PAD_GPIO1_9__DISP2_SER_CS 0x3ec 0x818 0x000 0x7 0x0 +#define MX51_PAD_GPIO1_9__GPIO1_9 0x3ec 0x818 0x000 0x0 0x0 +#define MX51_PAD_GPIO1_9__SD2_LCTL 0x3ec 0x818 0x000 0x6 0x0 +#define MX51_PAD_GPIO1_9__USBH3_OC 0x3ec 0x818 0x000 0x1 0x0 + +#endif /* __DTS_IMX51_PINFUNC_H */ diff --git a/arch/arm/dts/imx51.dtsi b/arch/arm/dts/imx51.dtsi new file mode 100644 index 000000000000..7ebb46ce9e36 --- /dev/null +++ b/arch/arm/dts/imx51.dtsi @@ -0,0 +1,654 @@ +// SPDX-License-Identifier: GPL-2.0+ +// +// Copyright 2011 Freescale Semiconductor, Inc. +// Copyright 2011 Linaro Ltd. + +#include "imx51-pinfunc.h" +#include <dt-bindings/clock/imx5-clock.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + /* + * The decompressor and also some bootloaders rely on a + * pre-existing /chosen node to be available to insert the + * command line and merge other ATAGS info. + */ + chosen {}; + + aliases { + ethernet0 = &fec; + gpio0 = &gpio1; + gpio1 = &gpio2; + gpio2 = &gpio3; + gpio3 = &gpio4; + i2c0 = &i2c1; + i2c1 = &i2c2; + mmc0 = &esdhc1; + mmc1 = &esdhc2; + mmc2 = &esdhc3; + mmc3 = &esdhc4; + serial0 = &uart1; + serial1 = &uart2; + serial2 = &uart3; + spi0 = &ecspi1; + spi1 = &ecspi2; + spi2 = &cspi; + }; + + tzic: tz-interrupt-controller@e0000000 { + compatible = "fsl,imx51-tzic", "fsl,tzic"; + interrupt-controller; + #interrupt-cells = <1>; + reg = <0xe0000000 0x4000>; + }; + + clocks { + ckil { + compatible = "fsl,imx-ckil", "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + }; + + ckih1 { + compatible = "fsl,imx-ckih1", "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + ckih2 { + compatible = "fsl,imx-ckih2", "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + osc { + compatible = "fsl,imx-osc", "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + }; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + cpu: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a8"; + reg = <0>; + clock-latency = <62500>; + clocks = <&clks IMX5_CLK_CPU_PODF>; + clock-names = "cpu"; + operating-points = < + 166000 1000000 + 600000 1050000 + 800000 1100000 + >; + voltage-tolerance = <5>; + }; + }; + + pmu: pmu { + compatible = "arm,cortex-a8-pmu"; + interrupt-parent = <&tzic>; + interrupts = <77>; + }; + + usbphy0: usbphy0 { + compatible = "usb-nop-xceiv"; + clocks = <&clks IMX5_CLK_USB_PHY_GATE>; + clock-names = "main_clk"; + #phy-cells = <0>; + }; + + capture-subsystem { + compatible = "fsl,imx-capture-subsystem"; + ports = <&ipu_csi0>, <&ipu_csi1>; + }; + + display-subsystem { + compatible = "fsl,imx-display-subsystem"; + ports = <&ipu_di0>, <&ipu_di1>; + }; + + soc { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + interrupt-parent = <&tzic>; + ranges; + + iram: sram@1ffe0000 { + compatible = "mmio-sram"; + reg = <0x1ffe0000 0x20000>; + }; + + gpu: gpu@30000000 { + compatible = "amd,imageon-200.1", "amd,imageon"; + reg = <0x30000000 0x20000>; + reg-names = "kgsl_3d0_reg_memory"; + interrupts = <12>; + interrupt-names = "kgsl_3d0_irq"; + clocks = <&clks IMX5_CLK_GPU3D_GATE>, <&clks IMX5_CLK_GARB_GATE>; + clock-names = "core_clk", "mem_iface_clk"; + }; + + ipu: ipu@40000000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx51-ipu"; + reg = <0x40000000 0x20000000>; + interrupts = <11 10>; + clocks = <&clks IMX5_CLK_IPU_GATE>, + <&clks IMX5_CLK_IPU_DI0_GATE>, + <&clks IMX5_CLK_IPU_DI1_GATE>; + clock-names = "bus", "di0", "di1"; + resets = <&src 2>; + + ipu_csi0: port@0 { + reg = <0>; + }; + + ipu_csi1: port@1 { + reg = <1>; + }; + + ipu_di0: port@2 { + reg = <2>; + + ipu_di0_disp1: endpoint { + }; + }; + + ipu_di1: port@3 { + reg = <3>; + + ipu_di1_disp2: endpoint { + }; + }; + }; + + bus@70000000 { /* AIPS1 */ + compatible = "fsl,aips-bus", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x70000000 0x10000000>; + ranges; + + spba@70000000 { + compatible = "fsl,spba-bus", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x70000000 0x40000>; + ranges; + + esdhc1: mmc@70004000 { + compatible = "fsl,imx51-esdhc"; + reg = <0x70004000 0x4000>; + interrupts = <1>; + clocks = <&clks IMX5_CLK_ESDHC1_IPG_GATE>, + <&clks IMX5_CLK_DUMMY>, + <&clks IMX5_CLK_ESDHC1_PER_GATE>; + clock-names = "ipg", "ahb", "per"; + status = "disabled"; + }; + + esdhc2: mmc@70008000 { + compatible = "fsl,imx51-esdhc"; + reg = <0x70008000 0x4000>; + interrupts = <2>; + clocks = <&clks IMX5_CLK_ESDHC2_IPG_GATE>, + <&clks IMX5_CLK_DUMMY>, + <&clks IMX5_CLK_ESDHC2_PER_GATE>; + clock-names = "ipg", "ahb", "per"; + bus-width = <4>; + status = "disabled"; + }; + + uart3: serial@7000c000 { + compatible = "fsl,imx51-uart", "fsl,imx21-uart"; + reg = <0x7000c000 0x4000>; + interrupts = <33>; + clocks = <&clks IMX5_CLK_UART3_IPG_GATE>, + <&clks IMX5_CLK_UART3_PER_GATE>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + ecspi1: spi@70010000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx51-ecspi"; + reg = <0x70010000 0x4000>; + interrupts = <36>; + clocks = <&clks IMX5_CLK_ECSPI1_IPG_GATE>, + <&clks IMX5_CLK_ECSPI1_PER_GATE>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + ssi2: ssi@70014000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx51-ssi", "fsl,imx21-ssi"; + reg = <0x70014000 0x4000>; + interrupts = <30>; + clocks = <&clks IMX5_CLK_SSI2_IPG_GATE>, + <&clks IMX5_CLK_SSI2_ROOT_GATE>; + clock-names = "ipg", "baud"; + dmas = <&sdma 24 1 0>, + <&sdma 25 1 0>; + dma-names = "rx", "tx"; + fsl,fifo-depth = <15>; + status = "disabled"; + }; + + esdhc3: mmc@70020000 { + compatible = "fsl,imx51-esdhc"; + reg = <0x70020000 0x4000>; + interrupts = <3>; + clocks = <&clks IMX5_CLK_ESDHC3_IPG_GATE>, + <&clks IMX5_CLK_DUMMY>, + <&clks IMX5_CLK_ESDHC3_PER_GATE>; + clock-names = "ipg", "ahb", "per"; + bus-width = <4>; + status = "disabled"; + }; + + esdhc4: mmc@70024000 { + compatible = "fsl,imx51-esdhc"; + reg = <0x70024000 0x4000>; + interrupts = <4>; + clocks = <&clks IMX5_CLK_ESDHC4_IPG_GATE>, + <&clks IMX5_CLK_DUMMY>, + <&clks IMX5_CLK_ESDHC4_PER_GATE>; + clock-names = "ipg", "ahb", "per"; + bus-width = <4>; + status = "disabled"; + }; + }; + + aipstz1: bridge@73f00000 { + compatible = "fsl,imx51-aipstz"; + reg = <0x73f00000 0x60>; + }; + + usbotg: usb@73f80000 { + compatible = "fsl,imx51-usb", "fsl,imx27-usb"; + reg = <0x73f80000 0x0200>; + interrupts = <18>; + clocks = <&clks IMX5_CLK_USBOH3_GATE>; + fsl,usbmisc = <&usbmisc 0>; + fsl,usbphy = <&usbphy0>; + status = "disabled"; + }; + + usbh1: usb@73f80200 { + compatible = "fsl,imx51-usb", "fsl,imx27-usb"; + reg = <0x73f80200 0x0200>; + interrupts = <14>; + clocks = <&clks IMX5_CLK_USBOH3_GATE>; + fsl,usbmisc = <&usbmisc 1>; + dr_mode = "host"; + status = "disabled"; + }; + + usbh2: usb@73f80400 { + compatible = "fsl,imx51-usb", "fsl,imx27-usb"; + reg = <0x73f80400 0x0200>; + interrupts = <16>; + clocks = <&clks IMX5_CLK_USBOH3_GATE>; + fsl,usbmisc = <&usbmisc 2>; + dr_mode = "host"; + status = "disabled"; + }; + + usbh3: usb@73f80600 { + compatible = "fsl,imx51-usb", "fsl,imx27-usb"; + reg = <0x73f80600 0x0200>; + interrupts = <17>; + clocks = <&clks IMX5_CLK_USBOH3_GATE>; + fsl,usbmisc = <&usbmisc 3>; + dr_mode = "host"; + status = "disabled"; + }; + + usbmisc: usbmisc@73f80800 { + #index-cells = <1>; + compatible = "fsl,imx51-usbmisc"; + reg = <0x73f80800 0x200>; + clocks = <&clks IMX5_CLK_USBOH3_GATE>; + }; + + gpio1: gpio@73f84000 { + compatible = "fsl,imx51-gpio", "fsl,imx35-gpio"; + reg = <0x73f84000 0x4000>; + interrupts = <50 51>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio@73f88000 { + compatible = "fsl,imx51-gpio", "fsl,imx35-gpio"; + reg = <0x73f88000 0x4000>; + interrupts = <52 53>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio@73f8c000 { + compatible = "fsl,imx51-gpio", "fsl,imx35-gpio"; + reg = <0x73f8c000 0x4000>; + interrupts = <54 55>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio4: gpio@73f90000 { + compatible = "fsl,imx51-gpio", "fsl,imx35-gpio"; + reg = <0x73f90000 0x4000>; + interrupts = <56 57>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + kpp: kpp@73f94000 { + compatible = "fsl,imx51-kpp", "fsl,imx21-kpp"; + reg = <0x73f94000 0x4000>; + interrupts = <60>; + clocks = <&clks IMX5_CLK_DUMMY>; + status = "disabled"; + }; + + wdog1: watchdog@73f98000 { + compatible = "fsl,imx51-wdt", "fsl,imx21-wdt"; + reg = <0x73f98000 0x4000>; + interrupts = <58>; + clocks = <&clks IMX5_CLK_DUMMY>; + }; + + wdog2: watchdog@73f9c000 { + compatible = "fsl,imx51-wdt", "fsl,imx21-wdt"; + reg = <0x73f9c000 0x4000>; + interrupts = <59>; + clocks = <&clks IMX5_CLK_DUMMY>; + status = "disabled"; + }; + + gpt: timer@73fa0000 { + compatible = "fsl,imx51-gpt", "fsl,imx31-gpt"; + reg = <0x73fa0000 0x4000>; + interrupts = <39>; + clocks = <&clks IMX5_CLK_GPT_IPG_GATE>, + <&clks IMX5_CLK_GPT_HF_GATE>; + clock-names = "ipg", "per"; + }; + + iomuxc: iomuxc@73fa8000 { + compatible = "fsl,imx51-iomuxc"; + reg = <0x73fa8000 0x4000>; + }; + + pwm1: pwm@73fb4000 { + #pwm-cells = <3>; + compatible = "fsl,imx51-pwm", "fsl,imx27-pwm"; + reg = <0x73fb4000 0x4000>; + clocks = <&clks IMX5_CLK_PWM1_IPG_GATE>, + <&clks IMX5_CLK_PWM1_HF_GATE>; + clock-names = "ipg", "per"; + interrupts = <61>; + }; + + pwm2: pwm@73fb8000 { + #pwm-cells = <3>; + compatible = "fsl,imx51-pwm", "fsl,imx27-pwm"; + reg = <0x73fb8000 0x4000>; + clocks = <&clks IMX5_CLK_PWM2_IPG_GATE>, + <&clks IMX5_CLK_PWM2_HF_GATE>; + clock-names = "ipg", "per"; + interrupts = <94>; + }; + + uart1: serial@73fbc000 { + compatible = "fsl,imx51-uart", "fsl,imx21-uart"; + reg = <0x73fbc000 0x4000>; + interrupts = <31>; + clocks = <&clks IMX5_CLK_UART1_IPG_GATE>, + <&clks IMX5_CLK_UART1_PER_GATE>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + uart2: serial@73fc0000 { + compatible = "fsl,imx51-uart", "fsl,imx21-uart"; + reg = <0x73fc0000 0x4000>; + interrupts = <32>; + clocks = <&clks IMX5_CLK_UART2_IPG_GATE>, + <&clks IMX5_CLK_UART2_PER_GATE>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + src: reset-controller@73fd0000 { + compatible = "fsl,imx51-src"; + reg = <0x73fd0000 0x4000>; + interrupts = <75>; + #reset-cells = <1>; + }; + + clks: ccm@73fd4000{ + compatible = "fsl,imx51-ccm"; + reg = <0x73fd4000 0x4000>; + interrupts = <0 71 0x04 0 72 0x04>; + #clock-cells = <1>; + }; + }; + + bus@80000000 { /* AIPS2 */ + compatible = "fsl,aips-bus", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x80000000 0x10000000>; + ranges; + + aipstz2: bridge@83f00000 { + compatible = "fsl,imx51-aipstz"; + reg = <0x83f00000 0x60>; + }; + + iim: efuse@83f98000 { + compatible = "fsl,imx51-iim", "fsl,imx27-iim"; + reg = <0x83f98000 0x4000>; + interrupts = <69>; + clocks = <&clks IMX5_CLK_IIM_GATE>; + }; + + tigerp: tigerp@83fa0000 { + compatible = "fsl,imx51-tigerp"; + reg = <0x83fa0000 0x28>; + }; + + owire: owire@83fa4000 { + compatible = "fsl,imx51-owire", "fsl,imx21-owire"; + reg = <0x83fa4000 0x4000>; + interrupts = <88>; + clocks = <&clks IMX5_CLK_OWIRE_GATE>; + status = "disabled"; + }; + + ecspi2: spi@83fac000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx51-ecspi"; + reg = <0x83fac000 0x4000>; + interrupts = <37>; + clocks = <&clks IMX5_CLK_ECSPI2_IPG_GATE>, + <&clks IMX5_CLK_ECSPI2_PER_GATE>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + sdma: sdma@83fb0000 { + compatible = "fsl,imx51-sdma", "fsl,imx35-sdma"; + reg = <0x83fb0000 0x4000>; + interrupts = <6>; + clocks = <&clks IMX5_CLK_SDMA_GATE>, + <&clks IMX5_CLK_AHB>; + clock-names = "ipg", "ahb"; + #dma-cells = <3>; + fsl,sdma-ram-script-name = "imx/sdma/sdma-imx51.bin"; + }; + + cspi: spi@83fc0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx51-cspi", "fsl,imx35-cspi"; + reg = <0x83fc0000 0x4000>; + interrupts = <38>; + clocks = <&clks IMX5_CLK_CSPI_IPG_GATE>, + <&clks IMX5_CLK_CSPI_IPG_GATE>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + i2c2: i2c@83fc4000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx51-i2c", "fsl,imx21-i2c"; + reg = <0x83fc4000 0x4000>; + interrupts = <63>; + clocks = <&clks IMX5_CLK_I2C2_GATE>; + status = "disabled"; + }; + + i2c1: i2c@83fc8000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx51-i2c", "fsl,imx21-i2c"; + reg = <0x83fc8000 0x4000>; + interrupts = <62>; + clocks = <&clks IMX5_CLK_I2C1_GATE>; + status = "disabled"; + }; + + ssi1: ssi@83fcc000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx51-ssi", "fsl,imx21-ssi"; + reg = <0x83fcc000 0x4000>; + interrupts = <29>; + clocks = <&clks IMX5_CLK_SSI1_IPG_GATE>, + <&clks IMX5_CLK_SSI1_ROOT_GATE>; + clock-names = "ipg", "baud"; + dmas = <&sdma 28 0 0>, + <&sdma 29 0 0>; + dma-names = "rx", "tx"; + fsl,fifo-depth = <15>; + status = "disabled"; + }; + + audmux: audmux@83fd0000 { + compatible = "fsl,imx51-audmux", "fsl,imx31-audmux"; + reg = <0x83fd0000 0x4000>; + clocks = <&clks IMX5_CLK_DUMMY>; + clock-names = "audmux"; + status = "disabled"; + }; + + m4if: m4if@83fd8000 { + compatible = "fsl,imx51-m4if"; + reg = <0x83fd8000 0x1000>; + }; + + weim: weim@83fda000 { + #address-cells = <2>; + #size-cells = <1>; + compatible = "fsl,imx51-weim"; + reg = <0x83fda000 0x1000>; + clocks = <&clks IMX5_CLK_EMI_SLOW_GATE>; + ranges = < + 0 0 0xb0000000 0x08000000 + 1 0 0xb8000000 0x08000000 + 2 0 0xc0000000 0x08000000 + 3 0 0xc8000000 0x04000000 + 4 0 0xcc000000 0x02000000 + 5 0 0xce000000 0x02000000 + >; + status = "disabled"; + }; + + nfc: nand@83fdb000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "fsl,imx51-nand"; + reg = <0x83fdb000 0x1000 0xcfff0000 0x10000>; + interrupts = <8>; + clocks = <&clks IMX5_CLK_NFC_GATE>; + status = "disabled"; + }; + + pata: pata@83fe0000 { + compatible = "fsl,imx51-pata", "fsl,imx27-pata"; + reg = <0x83fe0000 0x4000>; + interrupts = <70>; + clocks = <&clks IMX5_CLK_PATA_GATE>; + status = "disabled"; + }; + + ssi3: ssi@83fe8000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx51-ssi", "fsl,imx21-ssi"; + reg = <0x83fe8000 0x4000>; + interrupts = <96>; + clocks = <&clks IMX5_CLK_SSI3_IPG_GATE>, + <&clks IMX5_CLK_SSI3_ROOT_GATE>; + clock-names = "ipg", "baud"; + dmas = <&sdma 46 0 0>, + <&sdma 47 0 0>; + dma-names = "rx", "tx"; + fsl,fifo-depth = <15>; + status = "disabled"; + }; + + fec: ethernet@83fec000 { + compatible = "fsl,imx51-fec", "fsl,imx27-fec"; + reg = <0x83fec000 0x4000>; + interrupts = <87>; + clocks = <&clks IMX5_CLK_FEC_GATE>, + <&clks IMX5_CLK_FEC_GATE>, + <&clks IMX5_CLK_FEC_GATE>; + clock-names = "ipg", "ahb", "ptp"; + status = "disabled"; + }; + + vpu: vpu@83ff4000 { + compatible = "fsl,imx51-vpu", "cnm,codahx4"; + reg = <0x83ff4000 0x1000>; + interrupts = <9>; + clocks = <&clks IMX5_CLK_VPU_REFERENCE_GATE>, + <&clks IMX5_CLK_VPU_GATE>; + clock-names = "per", "ahb"; + resets = <&src 1>; + iram = <&iram>; + }; + + sahara: crypto@83ff8000 { + compatible = "fsl,imx53-sahara", "fsl,imx51-sahara"; + reg = <0x83ff8000 0x4000>; + interrupts = <19 20>; + clocks = <&clks IMX5_CLK_SAHARA_IPG_GATE>, + <&clks IMX5_CLK_SAHARA_IPG_GATE>; + clock-names = "ipg", "ahb"; + }; + }; + }; +};
Import the imx51-babbage devicetree files from Linux kernel version 5.11-rc7. This is in preparation for converting the mx51evk_defconfig target to driver model. Signed-off-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Make the conversion to driver model as it is mandatory.
Tested booting the Linux kernel from the SD card.
Signed-off-by: Fabio Estevam festevam@gmail.com --- arch/arm/dts/Makefile | 3 + board/freescale/mx51evk/mx51evk.c | 186 +----------------------------- configs/mx51evk_defconfig | 19 ++- include/configs/mx51evk.h | 8 -- 4 files changed, 22 insertions(+), 194 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 4fd3eabd6e8f..88f23e4ef41e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -653,6 +653,9 @@ dtb-$(CONFIG_VF610) += vf500-colibri.dtb \ dtb-$(CONFIG_MX28) += \ imx28-xea.dtb
+dtb-$(CONFIG_MX51) += \ + imx51-babbage.dtb + dtb-$(CONFIG_MX53) += imx53-cx9020.dtb \ imx53-qsb.dtb \ imx53-kp.dtb \ diff --git a/board/freescale/mx51evk/mx51evk.c b/board/freescale/mx51evk/mx51evk.c index 4250efddde77..b1a5c6b5f8bd 100644 --- a/board/freescale/mx51evk/mx51evk.c +++ b/board/freescale/mx51evk/mx51evk.c @@ -26,13 +26,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#ifdef CONFIG_FSL_ESDHC_IMX -struct fsl_esdhc_cfg esdhc_cfg[2] = { - {MMC_SDHC1_BASE_ADDR}, - {MMC_SDHC2_BASE_ADDR}, -}; -#endif - int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ @@ -63,34 +56,6 @@ static void setup_iomux_uart(void) imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); }
-static void setup_iomux_fec(void) -{ - static const iomux_v3_cfg_t fec_pads[] = { - NEW_PAD_CTRL(MX51_PAD_EIM_EB2__FEC_MDIO, PAD_CTL_HYS | - PAD_CTL_PUS_22K_UP | PAD_CTL_ODE | - PAD_CTL_DSE_HIGH | PAD_CTL_SRE_FAST), - MX51_PAD_NANDF_CS3__FEC_MDC, - NEW_PAD_CTRL(MX51_PAD_EIM_CS3__FEC_RDATA3, MX51_PAD_CTRL_2), - NEW_PAD_CTRL(MX51_PAD_EIM_CS2__FEC_RDATA2, MX51_PAD_CTRL_2), - NEW_PAD_CTRL(MX51_PAD_EIM_EB3__FEC_RDATA1, MX51_PAD_CTRL_2), - MX51_PAD_NANDF_D9__FEC_RDATA0, - MX51_PAD_NANDF_CS6__FEC_TDATA3, - MX51_PAD_NANDF_CS5__FEC_TDATA2, - MX51_PAD_NANDF_CS4__FEC_TDATA1, - MX51_PAD_NANDF_D8__FEC_TDATA0, - MX51_PAD_NANDF_CS7__FEC_TX_EN, - MX51_PAD_NANDF_CS2__FEC_TX_ER, - MX51_PAD_NANDF_RDY_INT__FEC_TX_CLK, - NEW_PAD_CTRL(MX51_PAD_NANDF_RB2__FEC_COL, MX51_PAD_CTRL_4), - NEW_PAD_CTRL(MX51_PAD_NANDF_RB3__FEC_RX_CLK, MX51_PAD_CTRL_4), - MX51_PAD_EIM_CS5__FEC_CRS, - MX51_PAD_EIM_CS4__FEC_RX_ER, - NEW_PAD_CTRL(MX51_PAD_NANDF_D11__FEC_RX_DV, MX51_PAD_CTRL_4), - }; - - imx_iomux_v3_setup_multiple_pads(fec_pads, ARRAY_SIZE(fec_pads)); -} - #ifdef CONFIG_MXC_SPI static void setup_iomux_spi(void) { @@ -111,64 +76,6 @@ static void setup_iomux_spi(void) } #endif
-#ifdef CONFIG_USB_EHCI_MX5 -#define MX51EVK_USBH1_HUB_RST IMX_GPIO_NR(1, 7) -#define MX51EVK_USBH1_STP IMX_GPIO_NR(1, 27) -#define MX51EVK_USB_CLK_EN_B IMX_GPIO_NR(2, 1) -#define MX51EVK_USB_PHY_RESET IMX_GPIO_NR(2, 5) - -static void setup_usb_h1(void) -{ - static const iomux_v3_cfg_t usb_h1_pads[] = { - MX51_PAD_USBH1_CLK__USBH1_CLK, - MX51_PAD_USBH1_DIR__USBH1_DIR, - MX51_PAD_USBH1_STP__USBH1_STP, - MX51_PAD_USBH1_NXT__USBH1_NXT, - MX51_PAD_USBH1_DATA0__USBH1_DATA0, - MX51_PAD_USBH1_DATA1__USBH1_DATA1, - MX51_PAD_USBH1_DATA2__USBH1_DATA2, - MX51_PAD_USBH1_DATA3__USBH1_DATA3, - MX51_PAD_USBH1_DATA4__USBH1_DATA4, - MX51_PAD_USBH1_DATA5__USBH1_DATA5, - MX51_PAD_USBH1_DATA6__USBH1_DATA6, - MX51_PAD_USBH1_DATA7__USBH1_DATA7, - - NEW_PAD_CTRL(MX51_PAD_GPIO1_7__GPIO1_7, 0), /* H1 hub reset */ - MX51_PAD_EIM_D17__GPIO2_1, - MX51_PAD_EIM_D21__GPIO2_5, /* PHY reset */ - }; - - imx_iomux_v3_setup_multiple_pads(usb_h1_pads, ARRAY_SIZE(usb_h1_pads)); -} - -int board_ehci_hcd_init(int port) -{ - /* Set USBH1_STP to GPIO and toggle it */ - imx_iomux_v3_setup_pad(NEW_PAD_CTRL(MX51_PAD_USBH1_STP__GPIO1_27, - MX51_USBH_PAD_CTRL)); - - gpio_direction_output(MX51EVK_USBH1_STP, 0); - gpio_direction_output(MX51EVK_USB_PHY_RESET, 0); - mdelay(10); - gpio_set_value(MX51EVK_USBH1_STP, 1); - - /* Set back USBH1_STP to be function */ - imx_iomux_v3_setup_pad(MX51_PAD_USBH1_STP__USBH1_STP); - - /* De-assert USB PHY RESETB */ - gpio_set_value(MX51EVK_USB_PHY_RESET, 1); - - /* Drive USB_CLK_EN_B line low */ - gpio_direction_output(MX51EVK_USB_CLK_EN_B, 0); - - /* Reset USB hub */ - gpio_direction_output(MX51EVK_USBH1_HUB_RST, 0); - mdelay(2); - gpio_set_value(MX51EVK_USBH1_HUB_RST, 1); - return 0; -} -#endif - static void power_init(void) { unsigned int val; @@ -257,6 +164,7 @@ static void power_init(void)
imx_iomux_v3_setup_pad(NEW_PAD_CTRL(MX51_PAD_EIM_A20__GPIO2_14, NO_PAD_CTRL)); + gpio_request(IMX_GPIO_NR(2, 14), "gpio2_14"); gpio_direction_output(IMX_GPIO_NR(2, 14), 0);
udelay(500); @@ -264,101 +172,9 @@ static void power_init(void) gpio_set_value(IMX_GPIO_NR(2, 14), 1); }
-#ifdef CONFIG_FSL_ESDHC_IMX -int board_mmc_getcd(struct mmc *mmc) -{ - struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; - int ret; - - imx_iomux_v3_setup_pad(NEW_PAD_CTRL(MX51_PAD_GPIO1_0__GPIO1_0, - NO_PAD_CTRL)); - gpio_direction_input(IMX_GPIO_NR(1, 0)); - imx_iomux_v3_setup_pad(NEW_PAD_CTRL(MX51_PAD_GPIO1_6__GPIO1_6, - NO_PAD_CTRL)); - gpio_direction_input(IMX_GPIO_NR(1, 6)); - - if (cfg->esdhc_base == MMC_SDHC1_BASE_ADDR) - ret = !gpio_get_value(IMX_GPIO_NR(1, 0)); - else - ret = !gpio_get_value(IMX_GPIO_NR(1, 6)); - - return ret; -} - -int board_mmc_init(struct bd_info *bis) -{ - static const iomux_v3_cfg_t sd1_pads[] = { - NEW_PAD_CTRL(MX51_PAD_SD1_CMD__SD1_CMD, PAD_CTL_DSE_MAX | - PAD_CTL_HYS | PAD_CTL_PUS_47K_UP | PAD_CTL_SRE_FAST), - NEW_PAD_CTRL(MX51_PAD_SD1_CLK__SD1_CLK, PAD_CTL_DSE_MAX | - PAD_CTL_PUS_47K_UP | PAD_CTL_SRE_FAST), - NEW_PAD_CTRL(MX51_PAD_SD1_DATA0__SD1_DATA0, PAD_CTL_DSE_MAX | - PAD_CTL_HYS | PAD_CTL_PUS_47K_UP | PAD_CTL_SRE_FAST), - NEW_PAD_CTRL(MX51_PAD_SD1_DATA1__SD1_DATA1, PAD_CTL_DSE_MAX | - PAD_CTL_HYS | PAD_CTL_PUS_47K_UP | PAD_CTL_SRE_FAST), - NEW_PAD_CTRL(MX51_PAD_SD1_DATA2__SD1_DATA2, PAD_CTL_DSE_MAX | - PAD_CTL_HYS | PAD_CTL_PUS_47K_UP | PAD_CTL_SRE_FAST), - NEW_PAD_CTRL(MX51_PAD_SD1_DATA3__SD1_DATA3, PAD_CTL_DSE_MAX | - PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN | PAD_CTL_SRE_FAST), - NEW_PAD_CTRL(MX51_PAD_GPIO1_0__SD1_CD, PAD_CTL_HYS), - NEW_PAD_CTRL(MX51_PAD_GPIO1_1__SD1_WP, PAD_CTL_HYS), - }; - - static const iomux_v3_cfg_t sd2_pads[] = { - NEW_PAD_CTRL(MX51_PAD_SD2_CMD__SD2_CMD, - PAD_CTL_DSE_MAX | PAD_CTL_SRE_FAST), - NEW_PAD_CTRL(MX51_PAD_SD2_CLK__SD2_CLK, - PAD_CTL_DSE_MAX | PAD_CTL_SRE_FAST), - NEW_PAD_CTRL(MX51_PAD_SD2_DATA0__SD2_DATA0, - PAD_CTL_DSE_MAX | PAD_CTL_SRE_FAST), - NEW_PAD_CTRL(MX51_PAD_SD2_DATA1__SD2_DATA1, - PAD_CTL_DSE_MAX | PAD_CTL_SRE_FAST), - NEW_PAD_CTRL(MX51_PAD_SD2_DATA2__SD2_DATA2, - PAD_CTL_DSE_MAX | PAD_CTL_SRE_FAST), - NEW_PAD_CTRL(MX51_PAD_SD2_DATA3__SD2_DATA3, - PAD_CTL_DSE_MAX | PAD_CTL_SRE_FAST), - NEW_PAD_CTRL(MX51_PAD_GPIO1_6__GPIO1_6, PAD_CTL_HYS), - NEW_PAD_CTRL(MX51_PAD_GPIO1_5__GPIO1_5, PAD_CTL_HYS), - }; - - u32 index; - int ret; - - esdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); - esdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); - - for (index = 0; index < CONFIG_SYS_FSL_ESDHC_NUM; - index++) { - switch (index) { - case 0: - imx_iomux_v3_setup_multiple_pads(sd1_pads, - ARRAY_SIZE(sd1_pads)); - break; - case 1: - imx_iomux_v3_setup_multiple_pads(sd2_pads, - ARRAY_SIZE(sd2_pads)); - break; - default: - printf("Warning: you configured more ESDHC controller" - "(%d) as supported by the board(2)\n", - CONFIG_SYS_FSL_ESDHC_NUM); - return -EINVAL; - } - ret = fsl_esdhc_initialize(bis, &esdhc_cfg[index]); - if (ret) - return ret; - } - return 0; -} -#endif - int board_early_init_f(void) { setup_iomux_uart(); - setup_iomux_fec(); -#ifdef CONFIG_USB_EHCI_MX5 - setup_usb_h1(); -#endif setup_iomux_lcd();
return 0; diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index 343816f89f31..557a1b57bb2e 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -5,15 +5,19 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xC0000 CONFIG_TARGET_MX51EVK=y +CONFIG_DM_GPIO=y # CONFIG_CMD_BMODE is not set +CONFIG_DEFAULT_DEVICE_TREE="imx51-babbage" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx51evk/imximage.cfg" CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DM=y CONFIG_CMD_FUSE=y CONFIG_CMD_MMC=y +# CONFIG_CMD_PINMUX is not set CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set @@ -22,16 +26,30 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_DM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y +CONFIG_PHYLIB=y +CONFIG_PHY_SMSC=y +CONFIG_PHY_FIXED=y +CONFIG_DM_ETH=y +CONFIG_FEC_MXC=y CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX5=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_MX5=y CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y @@ -39,4 +57,3 @@ CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_SPLASH_SCREEN=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 49f88c27dcd2..3574d6545164 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -51,14 +51,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR MMC_SDHC1_BASE_ADDR #define CONFIG_SYS_FSL_ESDHC_NUM 2
-/* - * Eth Configs - */ - -#define CONFIG_FEC_MXC -#define IMX_FEC_BASE FEC_BASE_ADDR -#define CONFIG_FEC_MXC_PHYADDR 0x1F - /* USB Configs */ #define CONFIG_MXC_USB_PORT 1 #define CONFIG_MXC_USB_PORTSC PORT_PTS_ULPI
Make the conversion to driver model as it is mandatory. Tested booting the Linux kernel from the SD card. Signed-off-by: Fabio Estevam festevam@gmail.com
I would like to help supporting this board, so add myself as a maintainer.
Signed-off-by: Fabio Estevam festevam@gmail.com --- board/freescale/mx51evk/MAINTAINERS | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/freescale/mx51evk/MAINTAINERS b/board/freescale/mx51evk/MAINTAINERS index 0e5f22c26b4b..1ca55f7d14ec 100644 --- a/board/freescale/mx51evk/MAINTAINERS +++ b/board/freescale/mx51evk/MAINTAINERS @@ -1,4 +1,5 @@ MX51EVK BOARD +M: Fabio Estevam festevam@gmail.com M: Stefano Babic sbabic@denx.de S: Maintained F: board/freescale/mx51evk/
Please add either here or the patch that adds the new dts files, those files to the MAINTAINERS entry as well. Thanks!
I would like to help supporting this board, so add myself as a maintainer. Signed-off-by: Fabio Estevam festevam@gmail.com
On 2/15/21 8:58 PM, Fabio Estevam wrote:
Add a compatible for i.MX51 so that i.MX51 can use this driver via driver model.
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
drivers/mmc/fsl_esdhc_imx.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 8ac859797f04..827a6f113f3b 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -1705,6 +1705,7 @@ static struct esdhc_soc_data usdhc_imx8qm_data = { };
static const struct udevice_id fsl_esdhc_ids[] = {
- { .compatible = "fsl,imx51-esdhc", }, { .compatible = "fsl,imx53-esdhc", }, { .compatible = "fsl,imx6ul-usdhc", }, { .compatible = "fsl,imx6sx-usdhc", },
Add a compatible for i.MX51 so that i.MX51 can use this driver via driver model. Signed-off-by: Fabio Estevam festevam@gmail.com Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Fabio Estevam
Jaehoon Chung
sbabic@denx.de
