[U-Boot] [PATCH v3 00/14] Add rockchip SARADC support
The SARADC is used for adc keys and charging detect at uboot loader. Except for the rk3036 and rk3228 Socs, the others support the SARADC IP.
Changes in v3: - Add commit message - Add commit message - Add commit message - Add commit message - Add commit message - Add commit message
Changes in v2: - Order the the include file - Use structures for I/O access - Use dev_read_add - Add the ROCKCHIP_SARADC config at other rockchip defconfigs like evb-px5... - Use bitfield_extract - Use GENMASK - Use bitfield_extract - Use GENMASK - Use bitfield_extract - Use GENMASK - Use GENMASK - Use GENMASK
David Wu (14): dm: adc: Add driver for Rockchip SARADC rockchip: configs: Enable the ROCKCHIP_SARADC config rockchip: clk: Add rv1108 SARADC clock support rockchip: clk: Add SARADC clock support for rk3288 rockchip: clk: Add rk3328 SARADC clock support rockchip: clk: Add rk3368 SARADC clock support rockchip: clk: Add rk3399 SARADC clock support rockchip: dts: rv1108: Add SARADC node at dtsi level rockchip: dts: Enable SARADC for rv1108-evb rockchip: dts: Enable SARADC for rk3288-popmetal rockchip: dts: Enable SARADC for rk3328-evb rockchip: dts: Enable SARADC for rk3368-px5-evb rockchip: dts: Enable SARADC for rk3368-sheep rockchip: dts: Enable SARADC for rk3399-evb
arch/arm/dts/rk3288-popmetal.dtsi | 4 + arch/arm/dts/rk3328-evb.dts | 4 + arch/arm/dts/rk3368-px5-evb.dts | 4 + arch/arm/dts/rk3368-sheep.dts | 4 + arch/arm/dts/rk3399-evb.dts | 4 + arch/arm/dts/rv1108-evb.dts | 4 + arch/arm/dts/rv1108.dtsi | 11 ++ arch/arm/include/asm/arch-rockchip/cru_rk3368.h | 5 + arch/arm/include/asm/arch-rockchip/cru_rv1108.h | 5 + configs/chromebit_mickey_defconfig | 2 + configs/chromebook_jerry_defconfig | 2 + configs/chromebook_minnie_defconfig | 2 + configs/evb-px5_defconfig | 2 + configs/evb-rk3288_defconfig | 2 + configs/evb-rk3328_defconfig | 2 + configs/evb-rk3399_defconfig | 2 + configs/evb-rv1108_defconfig | 2 + configs/fennec-rk3288_defconfig | 2 + configs/firefly-rk3288_defconfig | 2 + configs/firefly-rk3399_defconfig | 2 + configs/geekbox_defconfig | 2 + configs/lion-rk3368_defconfig | 2 + configs/miqi-rk3288_defconfig | 2 + configs/phycore-rk3288_defconfig | 2 + configs/popmetal-rk3288_defconfig | 2 + configs/puma-rk3399_defconfig | 2 + configs/rock2_defconfig | 2 + configs/rock_defconfig | 2 + configs/sheep-rk3368_defconfig | 2 + configs/tinker-rk3288_defconfig | 2 + drivers/adc/Kconfig | 9 ++ drivers/adc/Makefile | 1 + drivers/adc/rockchip-saradc.c | 183 ++++++++++++++++++++++++ drivers/clk/rockchip/clk_rk3288.c | 41 ++++++ drivers/clk/rockchip/clk_rk3328.c | 35 ++++- drivers/clk/rockchip/clk_rk3368.c | 32 +++++ drivers/clk/rockchip/clk_rk3399.c | 36 ++++- drivers/clk/rockchip/clk_rv1108.c | 33 ++++- include/dt-bindings/clock/rv1108-cru.h | 2 + 39 files changed, 456 insertions(+), 3 deletions(-) create mode 100644 drivers/adc/rockchip-saradc.c
The ADC can support some channels signal-ended some bits Successive Approximation Register (SAR) A/D Converter, like 6-channel and 10-bit. It converts the analog input signal into some bits binary digital codes.
Signed-off-by: David Wu david.wu@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Changes in v3: None Changes in v2: - Order the the include file - Use structures for I/O access - Use dev_read_add
drivers/adc/Kconfig | 9 +++ drivers/adc/Makefile | 1 + drivers/adc/rockchip-saradc.c | 183 ++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 193 insertions(+) create mode 100644 drivers/adc/rockchip-saradc.c
diff --git a/drivers/adc/Kconfig b/drivers/adc/Kconfig index e5335f7..8094420 100644 --- a/drivers/adc/Kconfig +++ b/drivers/adc/Kconfig @@ -28,3 +28,12 @@ config ADC_SANDBOX - 4 analog input channels - 16-bit resolution - single and multi-channel conversion mode + +config SARADC_ROCKCHIP + bool "Enable Rockchip SARADC driver" + help + This enables driver for Rockchip SARADC. + It provides: + - 2~6 analog input channels + - 1O or 12 bits resolution + - Up to 1MSPS of sample rate diff --git a/drivers/adc/Makefile b/drivers/adc/Makefile index cebf26d..4b5aa69 100644 --- a/drivers/adc/Makefile +++ b/drivers/adc/Makefile @@ -8,3 +8,4 @@ obj-$(CONFIG_ADC) += adc-uclass.o obj-$(CONFIG_ADC_EXYNOS) += exynos-adc.o obj-$(CONFIG_ADC_SANDBOX) += sandbox.o +obj-$(CONFIG_SARADC_ROCKCHIP) += rockchip-saradc.o diff --git a/drivers/adc/rockchip-saradc.c b/drivers/adc/rockchip-saradc.c new file mode 100644 index 0000000..0e6271d --- /dev/null +++ b/drivers/adc/rockchip-saradc.c @@ -0,0 +1,183 @@ +/* + * (C) Copyright 2017, Fuzhou Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Rockchip SARADC driver for U-Boot + */ + +#include <common.h> +#include <adc.h> +#include <clk.h> +#include <dm.h> +#include <errno.h> +#include <asm/io.h> + +#define SARADC_CTRL_CHN_MASK GENMASK(2, 0) +#define SARADC_CTRL_POWER_CTRL BIT(3) +#define SARADC_CTRL_IRQ_ENABLE BIT(5) +#define SARADC_CTRL_IRQ_STATUS BIT(6) + +#define SARADC_TIMEOUT (100 * 1000) + +struct rockchip_saradc_regs { + unsigned int data; + unsigned int stas; + unsigned int ctrl; + unsigned int dly_pu_soc; +}; + +struct rockchip_saradc_data { + int num_bits; + int num_channels; + unsigned long clk_rate; +}; + +struct rockchip_saradc_priv { + struct rockchip_saradc_regs *regs; + int active_channel; + const struct rockchip_saradc_data *data; +}; + +int rockchip_saradc_channel_data(struct udevice *dev, int channel, + unsigned int *data) +{ + struct rockchip_saradc_priv *priv = dev_get_priv(dev); + struct adc_uclass_platdata *uc_pdata = dev_get_uclass_platdata(dev); + + if (channel != priv->active_channel) { + error("Requested channel is not active!"); + return -EINVAL; + } + + if ((readl(&priv->regs->ctrl) & SARADC_CTRL_IRQ_STATUS) != + SARADC_CTRL_IRQ_STATUS) + return -EBUSY; + + /* Read value */ + *data = readl(&priv->regs->data); + *data &= uc_pdata->data_mask; + + /* Power down adc */ + writel(0, &priv->regs->ctrl); + + return 0; +} + +int rockchip_saradc_start_channel(struct udevice *dev, int channel) +{ + struct rockchip_saradc_priv *priv = dev_get_priv(dev); + + if (channel < 0 || channel >= priv->data->num_channels) { + error("Requested channel is invalid!"); + return -EINVAL; + } + + /* 8 clock periods as delay between power up and start cmd */ + writel(8, &priv->regs->dly_pu_soc); + + /* Select the channel to be used and trigger conversion */ + writel(SARADC_CTRL_POWER_CTRL | (channel & SARADC_CTRL_CHN_MASK) | + SARADC_CTRL_IRQ_ENABLE, &priv->regs->ctrl); + + priv->active_channel = channel; + + return 0; +} + +int rockchip_saradc_stop(struct udevice *dev) +{ + struct rockchip_saradc_priv *priv = dev_get_priv(dev); + + /* Power down adc */ + writel(0, &priv->regs->ctrl); + + priv->active_channel = -1; + + return 0; +} + +int rockchip_saradc_probe(struct udevice *dev) +{ + struct rockchip_saradc_priv *priv = dev_get_priv(dev); + struct clk clk; + int ret; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret) + return ret; + + ret = clk_set_rate(&clk, priv->data->clk_rate); + if (IS_ERR_VALUE(ret)) + return ret; + + priv->active_channel = -1; + + return 0; +} + +int rockchip_saradc_ofdata_to_platdata(struct udevice *dev) +{ + struct adc_uclass_platdata *uc_pdata = dev_get_uclass_platdata(dev); + struct rockchip_saradc_priv *priv = dev_get_priv(dev); + struct rockchip_saradc_data *data; + + data = (struct rockchip_saradc_data *)dev_get_driver_data(dev); + priv->regs = (struct rockchip_saradc_regs *)dev_read_addr(dev); + if (priv->regs == (struct rockchip_saradc_regs *)FDT_ADDR_T_NONE) { + error("Dev: %s - can't get address!", dev->name); + return -ENODATA; + } + + priv->data = data; + uc_pdata->data_mask = (1 << priv->data->num_bits) - 1;; + uc_pdata->data_format = ADC_DATA_FORMAT_BIN; + uc_pdata->data_timeout_us = SARADC_TIMEOUT / 5; + uc_pdata->channel_mask = (1 << priv->data->num_channels) - 1; + + return 0; +} + +static const struct adc_ops rockchip_saradc_ops = { + .start_channel = rockchip_saradc_start_channel, + .channel_data = rockchip_saradc_channel_data, + .stop = rockchip_saradc_stop, +}; + +static const struct rockchip_saradc_data saradc_data = { + .num_bits = 10, + .num_channels = 3, + .clk_rate = 1000000, +}; + +static const struct rockchip_saradc_data rk3066_tsadc_data = { + .num_bits = 12, + .num_channels = 2, + .clk_rate = 50000, +}; + +static const struct rockchip_saradc_data rk3399_saradc_data = { + .num_bits = 10, + .num_channels = 6, + .clk_rate = 1000000, +}; + +static const struct udevice_id rockchip_saradc_ids[] = { + { .compatible = "rockchip,saradc", + .data = (ulong)&saradc_data }, + { .compatible = "rockchip,rk3066-tsadc", + .data = (ulong)&rk3066_tsadc_data }, + { .compatible = "rockchip,rk3399-saradc", + .data = (ulong)&rk3399_saradc_data }, + { } +}; + +U_BOOT_DRIVER(rockchip_saradc) = { + .name = "rockchip_saradc", + .id = UCLASS_ADC, + .of_match = rockchip_saradc_ids, + .ops = &rockchip_saradc_ops, + .probe = rockchip_saradc_probe, + .ofdata_to_platdata = rockchip_saradc_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct rockchip_saradc_priv), +};
- Use dev_read_add
Applied to u-boot-rockchip, thanks!
The clk_saradc is dividing from the 24M, clk_saradc=24MHz/(saradc_div_con+1). SARADC integer divider control register is 10-bits width.
Changes in v3: None Changes in v2: - Use bitfield_extract - Use GENMASK
arch/arm/include/asm/arch-rockchip/cru_rv1108.h | 5 ++++ drivers/clk/rockchip/clk_rv1108.c | 33 ++++++++++++++++++++++++- include/dt-bindings/clock/rv1108-cru.h | 2 ++ 3 files changed, 39 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rv1108.h b/arch/arm/include/asm/arch-rockchip/cru_rv1108.h index 2a1ae69..ad2dc96 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rv1108.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rv1108.h @@ -90,6 +90,11 @@ enum { CORE_CLK_DIV_SHIFT = 0, CORE_CLK_DIV_MASK = 0x1f << CORE_CLK_DIV_SHIFT,
+ /* CLKSEL_CON22 */ + CLK_SARADC_DIV_CON_SHIFT= 0, + CLK_SARADC_DIV_CON_MASK = GENMASK(9, 0), + CLK_SARADC_DIV_CON_WIDTH= 10, + /* CLKSEL24_CON */ MAC_PLL_SEL_SHIFT = 12, MAC_PLL_SEL_MASK = 1 << MAC_PLL_SEL_SHIFT, diff --git a/drivers/clk/rockchip/clk_rv1108.c b/drivers/clk/rockchip/clk_rv1108.c index cf966bb..86e73e4 100644 --- a/drivers/clk/rockchip/clk_rv1108.c +++ b/drivers/clk/rockchip/clk_rv1108.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <bitfield.h> #include <clk-uclass.h> #include <dm.h> #include <errno.h> @@ -36,7 +37,7 @@ enum { #hz "Hz cannot be hit with PLL "\ "divisors on line " __stringify(__LINE__));
-/* use interge mode*/ +/* use integer mode */ static inline int rv1108_pll_id(enum rk_clk_id clk_id) { int id = 0; @@ -130,6 +131,31 @@ static int rv1108_sfc_set_clk(struct rv1108_cru *cru, uint rate) return DIV_TO_RATE(pll_rate, div); }
+static ulong rv1108_saradc_get_clk(struct rv1108_cru *cru) +{ + u32 div, val; + + val = readl(&cru->clksel_con[22]); + div = bitfield_extract(val, CLK_SARADC_DIV_CON_SHIFT, + CLK_SARADC_DIV_CON_WIDTH); + + return DIV_TO_RATE(OSC_HZ, div); +} + +static ulong rv1108_saradc_set_clk(struct rv1108_cru *cru, uint hz) +{ + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(OSC_HZ, hz) - 1; + assert(src_clk_div < 128); + + rk_clrsetreg(&cru->clksel_con[22], + CLK_SARADC_DIV_CON_MASK, + src_clk_div << CLK_SARADC_DIV_CON_SHIFT); + + return rv1108_saradc_get_clk(cru); +} + static ulong rv1108_clk_get_rate(struct clk *clk) { struct rv1108_clk_priv *priv = dev_get_priv(clk->dev); @@ -137,6 +163,8 @@ static ulong rv1108_clk_get_rate(struct clk *clk) switch (clk->id) { case 0 ... 63: return rkclk_pll_get_rate(priv->cru, clk->id); + case SCLK_SARADC: + return rv1108_saradc_get_clk(priv->cru); default: return -ENOENT; } @@ -154,6 +182,9 @@ static ulong rv1108_clk_set_rate(struct clk *clk, ulong rate) case SCLK_SFC: new_rate = rv1108_sfc_set_clk(priv->cru, rate); break; + case SCLK_SARADC: + new_rate = rv1108_saradc_set_clk(priv->cru, rate); + break; default: return -ENOENT; } diff --git a/include/dt-bindings/clock/rv1108-cru.h b/include/dt-bindings/clock/rv1108-cru.h index d2ad3bb..7defc6b 100644 --- a/include/dt-bindings/clock/rv1108-cru.h +++ b/include/dt-bindings/clock/rv1108-cru.h @@ -39,6 +39,7 @@ #define SCLK_MAC_TX 88 #define SCLK_MACREF 89 #define SCLK_MACREF_OUT 90 +#define SCLK_SARADC 91
/* aclk gates */ @@ -67,6 +68,7 @@ #define PCLK_TIMER 270 #define PCLK_PERI 271 #define PCLK_GMAC 272 +#define PCLK_SARADC 273
/* hclk gates */ #define HCLK_I2S0_8CH 320
- Use GENMASK
The clk_saradc is dividing from the 24M, clk_saradc=24MHz/(saradc_div_con+1). SARADC integer divider control register is 8-bits width.
Signed-off-by: David Wu david.wu@rock-chips.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
drivers/clk/rockchip/clk_rk3288.c | 41 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 41 insertions(+)
diff --git a/drivers/clk/rockchip/clk_rk3288.c b/drivers/clk/rockchip/clk_rk3288.c index 478195b..a133810 100644 --- a/drivers/clk/rockchip/clk_rk3288.c +++ b/drivers/clk/rockchip/clk_rk3288.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <bitfield.h> #include <clk-uclass.h> #include <dm.h> #include <dt-structs.h> @@ -111,6 +112,15 @@ enum { PERI_ACLK_DIV_SHIFT = 0, PERI_ACLK_DIV_MASK = 0x1f << PERI_ACLK_DIV_SHIFT,
+ /* + * CLKSEL24 + * saradc_div_con: + * clk_saradc=24MHz/(saradc_div_con+1) + */ + CLK_SARADC_DIV_CON_SHIFT = 8, + CLK_SARADC_DIV_CON_MASK = GENMASK(15, 8), + CLK_SARADC_DIV_CON_WIDTH = 8, + SOCSTS_DPLL_LOCK = 1 << 5, SOCSTS_APLL_LOCK = 1 << 6, SOCSTS_CPLL_LOCK = 1 << 7, @@ -634,6 +644,31 @@ static ulong rockchip_spi_set_clk(struct rk3288_cru *cru, uint gclk_rate, return rockchip_spi_get_clk(cru, gclk_rate, periph); }
+static ulong rockchip_saradc_get_clk(struct rk3288_cru *cru) +{ + u32 div, val; + + val = readl(&cru->cru_clksel_con[24]); + div = bitfield_extract(val, CLK_SARADC_DIV_CON_SHIFT, + CLK_SARADC_DIV_CON_WIDTH); + + return DIV_TO_RATE(OSC_HZ, div); +} + +static ulong rockchip_saradc_set_clk(struct rk3288_cru *cru, uint hz) +{ + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(OSC_HZ, hz) - 1; + assert(src_clk_div < 128); + + rk_clrsetreg(&cru->cru_clksel_con[24], + CLK_SARADC_DIV_CON_MASK, + src_clk_div << CLK_SARADC_DIV_CON_SHIFT); + + return rockchip_saradc_get_clk(cru); +} + static ulong rk3288_clk_get_rate(struct clk *clk) { struct rk3288_clk_priv *priv = dev_get_priv(clk->dev); @@ -666,6 +701,9 @@ static ulong rk3288_clk_get_rate(struct clk *clk) return gclk_rate; case PCLK_PWM: return PD_BUS_PCLK_HZ; + case SCLK_SARADC: + new_rate = rockchip_saradc_get_clk(priv->cru); + break; default: return -ENOENT; } @@ -756,6 +794,9 @@ static ulong rk3288_clk_set_rate(struct clk *clk, ulong rate) new_rate = rate; break; #endif + case SCLK_SARADC: + new_rate = rockchip_saradc_set_clk(priv->cru, rate); + break; default: return -ENOENT; }
- Use GENMASK
Signed-off-by: David Wu david.wu@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
drivers/clk/rockchip/clk_rk3328.c | 35 ++++++++++++++++++++++++++++++++++- 1 file changed, 34 insertions(+), 1 deletion(-)
diff --git a/drivers/clk/rockchip/clk_rk3328.c b/drivers/clk/rockchip/clk_rk3328.c index c3a6650..540d910 100644 --- a/drivers/clk/rockchip/clk_rk3328.c +++ b/drivers/clk/rockchip/clk_rk3328.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <bitfield.h> #include <clk-uclass.h> #include <dm.h> #include <errno.h> @@ -114,7 +115,8 @@ enum {
/* CLKSEL_CON23 */ CLK_SARADC_DIV_CON_SHIFT = 0, - CLK_SARADC_DIV_CON_MASK = 0x3ff << CLK_SARADC_DIV_CON_SHIFT, + CLK_SARADC_DIV_CON_MASK = GENMASK(9, 0), + CLK_SARADC_DIV_CON_WIDTH = 10,
/* CLKSEL_CON24 */ CLK_PWM_PLL_SEL_CPLL = 0, @@ -478,6 +480,31 @@ static ulong rk3328_pwm_set_clk(struct rk3328_cru *cru, uint hz) return DIV_TO_RATE(GPLL_HZ, div); }
+static ulong rk3328_saradc_get_clk(struct rk3328_cru *cru) +{ + u32 div, val; + + val = readl(&cru->clksel_con[23]); + div = bitfield_extract(val, CLK_SARADC_DIV_CON_SHIFT, + CLK_SARADC_DIV_CON_WIDTH); + + return DIV_TO_RATE(OSC_HZ, div); +} + +static ulong rk3328_saradc_set_clk(struct rk3328_cru *cru, uint hz) +{ + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(OSC_HZ, hz) - 1; + assert(src_clk_div < 128); + + rk_clrsetreg(&cru->clksel_con[23], + CLK_SARADC_DIV_CON_MASK, + src_clk_div << CLK_SARADC_DIV_CON_SHIFT); + + return rk3328_saradc_get_clk(cru); +} + static ulong rk3328_clk_get_rate(struct clk *clk) { struct rk3328_clk_priv *priv = dev_get_priv(clk->dev); @@ -501,6 +528,9 @@ static ulong rk3328_clk_get_rate(struct clk *clk) case SCLK_PWM: rate = rk3328_pwm_get_clk(priv->cru); break; + case SCLK_SARADC: + rate = rk3328_saradc_get_clk(priv->cru); + break; default: return -ENOENT; } @@ -531,6 +561,9 @@ static ulong rk3328_clk_set_rate(struct clk *clk, ulong rate) case SCLK_PWM: ret = rk3328_pwm_set_clk(priv->cru, rate); break; + case SCLK_SARADC: + ret = rk3328_saradc_set_clk(priv->cru, rate); + break; default: return -ENOENT; }
- Use GENMASK
Changes in v3: None Changes in v2: - Use GENMASK
arch/arm/include/asm/arch-rockchip/cru_rk3368.h | 5 ++++ drivers/clk/rockchip/clk_rk3368.c | 32 +++++++++++++++++++++++++ 2 files changed, 37 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3368.h b/arch/arm/include/asm/arch-rockchip/cru_rk3368.h index 2b1197f..5f6a5fb 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rk3368.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3368.h @@ -89,6 +89,11 @@ enum { MCU_CLK_DIV_SHIFT = 0, MCU_CLK_DIV_MASK = GENMASK(4, 0),
+ /* CLKSEL_CON25 */ + CLK_SARADC_DIV_CON_SHIFT = 8, + CLK_SARADC_DIV_CON_MASK = GENMASK(15, 8), + CLK_SARADC_DIV_CON_WIDTH = 8, + /* CLKSEL43_CON */ GMAC_MUX_SEL_EXTCLK = BIT(8),
diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index 2be1f57..2eedf77 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -12,6 +12,7 @@ #include <errno.h> #include <mapmem.h> #include <syscon.h> +#include <bitfield.h> #include <asm/arch/clock.h> #include <asm/arch/cru_rk3368.h> #include <asm/arch/hardware.h> @@ -397,6 +398,31 @@ static ulong rk3368_spi_set_clk(struct rk3368_cru *cru, ulong clk_id, uint hz) return rk3368_spi_get_clk(cru, clk_id); }
+static ulong rk3368_saradc_get_clk(struct rk3368_cru *cru) +{ + u32 div, val; + + val = readl(&cru->clksel_con[25]); + div = bitfield_extract(val, CLK_SARADC_DIV_CON_SHIFT, + CLK_SARADC_DIV_CON_WIDTH); + + return DIV_TO_RATE(OSC_HZ, div); +} + +static ulong rk3368_saradc_set_clk(struct rk3368_cru *cru, uint hz) +{ + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(OSC_HZ, hz) - 1; + assert(src_clk_div < 128); + + rk_clrsetreg(&cru->clksel_con[25], + CLK_SARADC_DIV_CON_MASK, + src_clk_div << CLK_SARADC_DIV_CON_SHIFT); + + return rk3368_saradc_get_clk(cru); +} + static ulong rk3368_clk_get_rate(struct clk *clk) { struct rk3368_clk_priv *priv = dev_get_priv(clk->dev); @@ -419,6 +445,9 @@ static ulong rk3368_clk_get_rate(struct clk *clk) rate = rk3368_mmc_get_clk(priv->cru, clk->id); break; #endif + case SCLK_SARADC: + rate = rk3368_saradc_get_clk(priv->cru); + break; default: return -ENOENT; } @@ -453,6 +482,9 @@ static ulong rk3368_clk_set_rate(struct clk *clk, ulong rate) ret = rk3368_gmac_set_clk(priv->cru, clk->id, rate); break; #endif + case SCLK_SARADC: + ret = rk3368_saradc_set_clk(priv->cru, rate); + break; default: return -ENOENT; }
- Use GENMASK
drivers/clk/rockchip/clk_rk3399.c | 36 +++++++++++++++++++++++++++++++++++- 1 file changed, 35 insertions(+), 1 deletion(-)
diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 3edafea..105c499 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -12,6 +12,7 @@ #include <errno.h> #include <mapmem.h> #include <syscon.h> +#include <bitfield.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/cru_rk3399.h> @@ -181,7 +182,8 @@ enum {
/* CLKSEL_CON26 */ CLK_SARADC_DIV_CON_SHIFT = 8, - CLK_SARADC_DIV_CON_MASK = 0xff << CLK_SARADC_DIV_CON_SHIFT, + CLK_SARADC_DIV_CON_MASK = GENMASK(15, 8), + CLK_SARADC_DIV_CON_WIDTH = 8,
/* CLKSEL_CON27 */ CLK_TSADC_SEL_X24M = 0x0, @@ -860,6 +862,32 @@ static ulong rk3399_ddr_set_clk(struct rk3399_cru *cru,
return set_rate; } + +static ulong rk3399_saradc_get_clk(struct rk3399_cru *cru) +{ + u32 div, val; + + val = readl(&cru->clksel_con[26]); + div = bitfield_extract(val, CLK_SARADC_DIV_CON_SHIFT, + CLK_SARADC_DIV_CON_WIDTH); + + return DIV_TO_RATE(OSC_HZ, div); +} + +static ulong rk3399_saradc_set_clk(struct rk3399_cru *cru, uint hz) +{ + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(OSC_HZ, hz) - 1; + assert(src_clk_div < 128); + + rk_clrsetreg(&cru->clksel_con[26], + CLK_SARADC_DIV_CON_MASK, + src_clk_div << CLK_SARADC_DIV_CON_SHIFT); + + return rk3399_saradc_get_clk(cru); +} + static ulong rk3399_clk_get_rate(struct clk *clk) { struct rk3399_clk_priv *priv = dev_get_priv(clk->dev); @@ -895,6 +923,9 @@ static ulong rk3399_clk_get_rate(struct clk *clk) break; case PCLK_EFUSE1024NS: break; + case SCLK_SARADC: + rate = rk3399_saradc_get_clk(priv->cru); + break; default: return -ENOENT; } @@ -943,6 +974,9 @@ static ulong rk3399_clk_set_rate(struct clk *clk, ulong rate) break; case PCLK_EFUSE1024NS: break; + case SCLK_SARADC: + ret = rk3399_saradc_set_clk(priv->cru, rate); + break; default: return -ENOENT; }
- Use GENMASK
arch/arm/dts/rv1108.dtsi | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/arch/arm/dts/rv1108.dtsi b/arch/arm/dts/rv1108.dtsi index 77ca24e..d6927ee 100644 --- a/arch/arm/dts/rv1108.dtsi +++ b/arch/arm/dts/rv1108.dtsi @@ -126,6 +126,17 @@ reg = <0x10300000 0x1000>; };
+ saradc: saradc@1038c000 { + compatible = "rockchip,rv1108-saradc", "rockchip,rk3399-saradc"; + reg = <0x1038c000 0x100>; + interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + #io-channel-cells = <1>; + clock-frequency = <1000000>; + clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>; + clock-names = "saradc", "apb_pclk"; + status = "disabled"; + }; + pmugrf: syscon@20060000 { compatible = "rockchip,rv1108-pmugrf", "syscon"; reg = <0x20060000 0x1000>;
Enable the SARADC for download key pressed detect.
Signed-off-by: David Wu david.wu@rock-chips.com ---
Changes in v2: None
arch/arm/dts/rv1108-evb.dts | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/rv1108-evb.dts b/arch/arm/dts/rv1108-evb.dts index 0128dd8..e21b57f 100644 --- a/arch/arm/dts/rv1108-evb.dts +++ b/arch/arm/dts/rv1108-evb.dts @@ -30,6 +30,10 @@ snps,reset-gpio = <&gpio1 RK_PC1 GPIO_ACTIVE_LOW>; };
+&saradc { + status = "okay"; +}; + &sfc { status = "okay"; flash@0 {
Changes in v3:
Changes in v2: None
Changes in v3:
Changes in v2: None
Changes in v3:
Changes in v2: None
Changes in v2: None
arch/arm/dts/rk3328-evb.dts | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/rk3328-evb.dts b/arch/arm/dts/rk3328-evb.dts index 8a14c65..df44ccb 100644 --- a/arch/arm/dts/rk3328-evb.dts +++ b/arch/arm/dts/rk3328-evb.dts @@ -42,6 +42,10 @@ }; };
+&saradc { + status = "okay"; +}; + &uart2 { status = "okay"; };
Changes in v3:
Changes in v2: None
Changes in v3:
Changes in v2: None
Changes in v3:
Changes in v2: None
Changes in v2: None
arch/arm/dts/rk3368-px5-evb.dts | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/rk3368-px5-evb.dts b/arch/arm/dts/rk3368-px5-evb.dts index c7478f7..e9c5eba 100644 --- a/arch/arm/dts/rk3368-px5-evb.dts +++ b/arch/arm/dts/rk3368-px5-evb.dts @@ -296,6 +296,10 @@ }; };
+&saradc { + status = "okay"; +}; + &tsadc { status = "okay"; rockchip,hw-tshut-mode = <0>; /* CRU */
Changes in v3:
Changes in v2: None
Changes in v3:
Changes in v2: None
Changes in v3:
Changes in v2: None
Changes in v2: None
arch/arm/dts/rk3399-evb.dts | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts index be0c6d9..0e5d8d7 100644 --- a/arch/arm/dts/rk3399-evb.dts +++ b/arch/arm/dts/rk3399-evb.dts @@ -149,6 +149,10 @@ status = "okay"; };
+&saradc { + status = "okay"; +}; + &sdmmc { bus-width = <4>; status = "okay";
Changes in v3:
Changes in v2: None
Changes in v3:
Changes in v2: None
Changes in v3:
Changes in v2: None
David Wu
Philipp Tomsich
