[U-Boot] Some puzzles about u-boot.lds
Dear lists,
I met some problems about integrate our bootloader to u-boot, my working CPU is ARM1136EJ-S. Our boot routine likes below:
1. Rom code, and copy the first 4KB u-boot to ITCM (0x70000000), switch to u-boot. ( cpu/arm1136/start.S)
2. u-boot running at ITCM, and config PLL, and memory, and switch to romcode. (board/xxx/lowlevel_init.S)
3. If it is cold boot, copy the whole u-boot to Ram (the address ram address is 0xc1000000)
4. Back from the rom code, and running first part of u-boot at ITCM. (board/xxx/lowlevel_init.S, and cpu/arm1136/start.S)
5. After finishing setup stack and clear bss, jump to the start_armboot (cpu/arm1136/start.S), the VMA of start_armboot is ram address (0xc1000xxx)
I would like the first part is at 0x70000000( both VMA and LMA), and the second part is at 0xc1000000 + sizeof(first boot), so I design the u-boot.lds like below:
OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") OUTPUT_ARCH(arm) ENTRY(_start) SECTIONS {
. = ALIGN(4); . = 0x70000000;
.textboot : { cpu/arm1136/start.o (.text) board/atlas5cb/lowlevel_init.o (.text) }
. = ALIGN(4); _textram_start = 0xC1000000 + SIZEOF(.textboot);
.textram 0xC1000000 + SIZEOF(.textboot): AT ( _textram_start ) { *(.text) }
. = ALIGN(4); .rodata : { *(.rodata) } .ARM.extab : { *(.ARM.extab* .gnu.linkonce.armextab.*) } __exidx_start = .; .ARM.exidx : { *(.ARM.exidx* .gnu.linkonce.armexidx.*) } __exidx_end = .; . = .; __u_boot_cmd_start = .; .u_boot_cmd : { *(.u_boot_cmd) } __u_boot_cmd_end = .;
. = ALIGN(4); __bss_start = .; .bss : { *(.bss) } _end = .;
But it can't finish the link, it stops at: arm-none-linux-gnueabi-objcopy --gap-fill=0xff -O srec /home/nchen/work/L27EVB/Dev/bootloader/uboot/u-boot /home/nchen/work/L27EVB/Dev/out/bootloader/uboot/u-boot.srec
Why I can't set two LMA for two different text sections?
It can work after I change the second text section's LMA just near to the first one
... . = 0x70000000;
.textboot : { cpu/arm1136/start.o (.text) board/xxx/lowlevel_init.o (.text) }
. = ALIGN(4); .textram 0xC1000000 + SIZEOF(.textboot):
AT ( ADDR(.textboot) + SIZEOF(.textboot) ) { *(.text) }
After that my output layout like to be:
Idx Name Size VMA LMA File off Algn 0 .textboot 00000950 70000000 70000000 00008000 2**5 CONTENTS, ALLOC, LOAD, READONLY, CODE 1 .textram 000130e0 c1000950 70000950 00008950 2**5 CONTENTS, ALLOC, LOAD, READONLY, CODE 2 .rodata 00001858 c1013a30 70013a30 0001ba30 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 3 .rodata.str1.1 00003442 c1015288 70015288 0001d288 2**0 CONTENTS, ALLOC, LOAD, READONLY, DATA 4 .data 000407a4 c10186cc 700186cc 000206cc 2**2 CONTENTS, ALLOC, LOAD, DATA 5 .u_boot_cmd 00000348 c1058e70 70058e70 00060e70 2**2 CONTENTS, ALLOC, LOAD, DATA 6 .bss 00004cb4 c10591b8 700591b8 000611b8 2**2 ALLOC
It should be ok If I set pc to VMA of start_armboot, as all parts of u-boot is at correct ram regions now, although I did not do relocate. After executing: ldr pc, [r0] /* r0 stores VMA of start_armboot) The pc goes to the undefined address, but I can set pc to start_armboot using realview debugger. Do you have any clues for such problems, Is it possible that my u-boot.lds is not correct?
Although I can set pc to start_armboot, and let it run, but the system's behavior is incorrect, and can't output anything.
By the way, the old structure ( our bootloader + u-boot + Linux ) is work well, so the second part of u-boot should be ok.
Thank you
Best Regards, Peter Chen
Peter Chen
