[U-Boot] [PATCH 06/10] arm: socfpga: arria10: Added drivers for Arria10 Reset Manager
Drivers for reset manager is restructured such that common functions, gen5 drivers and Arria10 drivers are moved to reset_manager.c, reset_manager_gen5.c and reset_manager_arria10.c respectively.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@kernel.org Cc: Chin Liang See chin.liang.see@intel.com Cc: Tien Fong skywindctf@gmail.com --- arch/arm/mach-socfpga/Makefile | 16 +- arch/arm/mach-socfpga/include/mach/reset_manager.h | 164 ++++-- arch/arm/mach-socfpga/reset_manager.c | 114 +--- arch/arm/mach-socfpga/reset_manager_arria10.c | 766 ++++++++++++++++++++ arch/arm/mach-socfpga/reset_manager_gen5.c | 116 +++ 5 files changed, 1017 insertions(+), 159 deletions(-) create mode 100644 arch/arm/mach-socfpga/reset_manager_arria10.c create mode 100644 arch/arm/mach-socfpga/reset_manager_gen5.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 809cd47..b8fcf6e 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -2,21 +2,27 @@ # (C) Copyright 2000-2003 # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # -# Copyright (C) 2012 Altera Corporation <www.altera.com> +# Copyright (C) 2012-2016 Altera Corporation <www.altera.com> # # SPDX-License-Identifier: GPL-2.0+ #
obj-y += misc.o timer.o reset_manager.o system_manager.o clock_manager.o \ fpga_manager.o board.o +obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += reset_manager_arria10.o +obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o \ + reset_manager_gen5.o
-obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += freeze_controller.o wrap_iocsr_config.o \ + wrap_pinmux_config.o wrap_sdram_config.o +endif
+ifdef CONFIG_TARGET_SOCFPGA_GEN5 # QTS-generated config file wrappers -obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o -obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ - wrap_sdram_config.o CFLAGS_wrap_iocsr_config.o += -I$(srctree)/board/$(BOARDDIR) CFLAGS_wrap_pinmux_config.o += -I$(srctree)/board/$(BOARDDIR) CFLAGS_wrap_pll_config.o += -I$(srctree)/board/$(BOARDDIR) CFLAGS_wrap_sdram_config.o += -I$(srctree)/board/$(BOARDDIR) +endif diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager.h b/arch/arm/mach-socfpga/include/mach/reset_manager.h index 6225118..077391a 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager.h @@ -1,19 +1,32 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2016 Altera Corporation <www.altera.com> * - * SPDX-License-Identifier: GPL-2.0+ + * SPDX-License-Identifier: GPL-2.0 */
#ifndef _RESET_MANAGER_H_ #define _RESET_MANAGER_H_
-void reset_cpu(ulong addr); -void reset_deassert_peripherals_handoff(void); +/* Common function prototypes */ +extern void reset_cpu(ulong addr); +extern void socfpga_bridges_reset(int enable); +extern void socfpga_per_reset(u32 reset, int set); +extern void socfpga_per_reset_all(void);
-void socfpga_bridges_reset(int enable); - -void socfpga_per_reset(u32 reset, int set); -void socfpga_per_reset_all(void); +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +extern void reset_deassert_peripherals_handoff(void); +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +extern void watchdog_disable(void); +extern void reset_deassert_noc_ddr_scheduler(void); +extern int is_wdt_in_reset(void); +extern void emac_manage_reset(ulong emacbase, uint state); +extern int reset_deassert_bridges_handoff(void); +extern void reset_deassert_dedicated_peripherals(void); +extern void reset_assert_fpga_connected_peripherals(void); +extern void reset_deassert_fpga_connected_peripherals(void); +extern void reset_deassert_shared_connected_peripherals(void); +extern void reset_deassert_osc1wd0(void); +#endif
#if defined(CONFIG_TARGET_SOCFPGA_GEN5) struct socfpga_reset_manager { @@ -29,40 +42,40 @@ struct socfpga_reset_manager { u32 padding2[12]; u32 tstscratch; }; -#else +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) struct socfpga_reset_manager { - u32 stat; - u32 ramstat; - u32 miscstat; - u32 ctrl; - u32 hdsken; - u32 hdskreq; - u32 hdskack; - u32 counts; - u32 mpu_mod_reset; - u32 per_mod_reset; /* stated as per0_mod_reset in A10 datasheet */ - u32 per2_mod_reset; /* stated as per1_mod_reset in A10 datasheet */ - u32 brg_mod_reset; - u32 misc_mod_reset; /* stated as sys_mod_reset in A10 datasheet */ - u32 coldmodrst; - u32 nrstmodrst; - u32 dbgmodrst; - u32 mpuwarmmask; - u32 per0warmmask; - u32 per1warmmask; - u32 brgwarmmask; - u32 syswarmmask; - u32 nrstwarmmask; - u32 l3warmmask; - u32 tststa; - u32 tstscratch; - u32 hdsktimeout; - u32 hmcintr; - u32 hmcintren; - u32 hmcintrens; - u32 hmcintrenr; - u32 hmcgpout; - u32 hmcgpin; + volatile uint32_t stat; + volatile uint32_t ramstat; + volatile uint32_t miscstat; + volatile uint32_t ctrl; + volatile uint32_t hdsken; + volatile uint32_t hdskreq; + volatile uint32_t hdskack; + volatile uint32_t counts; + volatile uint32_t mpumodrst; + volatile uint32_t per0modrst; + volatile uint32_t per1modrst; + volatile uint32_t brgmodrst; + volatile uint32_t sysmodrst; + volatile uint32_t coldmodrst; + volatile uint32_t nrstmodrst; + volatile uint32_t dbgmodrst; + volatile uint32_t mpuwarmmask; + volatile uint32_t per0warmmask; + volatile uint32_t per1warmmask; + volatile uint32_t brgwarmmask; + volatile uint32_t syswarmmask; + volatile uint32_t nrstwarmmask; + volatile uint32_t l3warmmask; + volatile uint32_t tststa; + volatile uint32_t tstscratch; + volatile uint32_t hdsktimeout; + volatile uint32_t hmcintr; + volatile uint32_t hmcintren; + volatile uint32_t hmcintrens; + volatile uint32_t hmcintrenr; + volatile uint32_t hmcgpout; + volatile uint32_t hmcgpin; }; #endif
@@ -113,7 +126,7 @@ struct socfpga_reset_manager { #define RSTMGR_SDMMC RSTMGR_DEFINE(1, 22) #define RSTMGR_DMA RSTMGR_DEFINE(1, 28) #define RSTMGR_SDR RSTMGR_DEFINE(1, 29) -#else +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) /* * SocFPGA Arria10 reset IDs, bank mapping is as follows: * 0 ... mpumodrst @@ -144,4 +157,71 @@ struct socfpga_reset_manager { /* Create a human-readable reference to SoCFPGA reset. */ #define SOCFPGA_RESET(_name) RSTMGR_##_name
+/* Create a human-readable reference to SoCFPGA reset. */ +#define SOCFPGA_RESET(_name) RSTMGR_##_name + +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define ALT_RSTMGR_CTL_SWWARMRSTREQ_SET_MSK 0x00000002 +#define ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK 0x00000001 +#define ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK 0x00000002 +#define ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK 0x00000004 +#define ALT_RSTMGR_PER0MODRST_USB0_SET_MSK 0x00000008 +#define ALT_RSTMGR_PER0MODRST_USB1_SET_MSK 0x00000010 +#define ALT_RSTMGR_PER0MODRST_NAND_SET_MSK 0x00000020 +#define ALT_RSTMGR_PER0MODRST_QSPI_SET_MSK 0x00000040 +#define ALT_RSTMGR_PER0MODRST_SDMMC_SET_MSK 0x00000080 +#define ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK 0x00000100 +#define ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK 0x00000200 +#define ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK 0x00000400 +#define ALT_RSTMGR_PER0MODRST_USBECC0_SET_MSK 0x00000800 +#define ALT_RSTMGR_PER0MODRST_USBECC1_SET_MSK 0x00001000 +#define ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK 0x00002000 +#define ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK 0x00004000 +#define ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK 0x00008000 +#define ALT_RSTMGR_PER0MODRST_DMA_SET_MSK 0x00010000 +#define ALT_RSTMGR_PER0MODRST_SPIM0_SET_MSK 0x00020000 +#define ALT_RSTMGR_PER0MODRST_SPIM1_SET_MSK 0x00040000 +#define ALT_RSTMGR_PER0MODRST_SPIS0_SET_MSK 0x00080000 +#define ALT_RSTMGR_PER0MODRST_SPIS1_SET_MSK 0x00100000 +#define ALT_RSTMGR_PER0MODRST_DMAECC_SET_MSK 0x00200000 +#define ALT_RSTMGR_PER0MODRST_EMACPTP_SET_MSK 0x00400000 +#define ALT_RSTMGR_PER0MODRST_DMAIF0_SET_MSK 0x01000000 +#define ALT_RSTMGR_PER0MODRST_DMAIF1_SET_MSK 0x02000000 +#define ALT_RSTMGR_PER0MODRST_DMAIF2_SET_MSK 0x04000000 +#define ALT_RSTMGR_PER0MODRST_DMAIF3_SET_MSK 0x08000000 +#define ALT_RSTMGR_PER0MODRST_DMAIF4_SET_MSK 0x10000000 +#define ALT_RSTMGR_PER0MODRST_DMAIF5_SET_MSK 0x20000000 +#define ALT_RSTMGR_PER0MODRST_DMAIF6_SET_MSK 0x40000000 +#define ALT_RSTMGR_PER0MODRST_DMAIF7_SET_MSK 0x80000000 + +#define ALT_RSTMGR_PER1MODRST_WD0_SET_MSK 0x00000001 +#define ALT_RSTMGR_PER1MODRST_WD1_SET_MSK 0x00000002 +#define ALT_RSTMGR_PER1MODRST_L4SYSTMR0_SET_MSK 0x00000004 +#define ALT_RSTMGR_PER1MODRST_L4SYSTMR1_SET_MSK 0x00000008 +#define ALT_RSTMGR_PER1MODRST_SPTMR0_SET_MSK 0x00000010 +#define ALT_RSTMGR_PER1MODRST_SPTMR1_SET_MSK 0x00000020 +#define ALT_RSTMGR_PER1MODRST_I2C0_SET_MSK 0x00000100 +#define ALT_RSTMGR_PER1MODRST_I2C1_SET_MSK 0x00000200 +#define ALT_RSTMGR_PER1MODRST_I2C2_SET_MSK 0x00000400 +#define ALT_RSTMGR_PER1MODRST_I2C3_SET_MSK 0x00000800 +#define ALT_RSTMGR_PER1MODRST_I2C4_SET_MSK 0x00001000 +#define ALT_RSTMGR_PER1MODRST_UART0_SET_MSK 0x00010000 +#define ALT_RSTMGR_PER1MODRST_UART1_SET_MSK 0x00020000 +#define ALT_RSTMGR_PER1MODRST_GPIO0_SET_MSK 0x01000000 +#define ALT_RSTMGR_PER1MODRST_GPIO1_SET_MSK 0x02000000 +#define ALT_RSTMGR_PER1MODRST_GPIO2_SET_MSK 0x04000000 + +#define ALT_RSTMGR_BRGMODRST_H2F_SET_MSK 0x00000001 +#define ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK 0x00000002 +#define ALT_RSTMGR_BRGMODRST_F2H_SET_MSK 0x00000004 +#define ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK 0x00000008 +#define ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK 0x00000010 +#define ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK 0x00000020 +#define ALT_RSTMGR_BRGMODRST_DDRSCH_SET_MSK 0x00000040 + +#define ALT_RSTMGR_HDSKEN_SDRSELFREFEN_SET_MSK 0x00000001 +#define ALT_RSTMGR_HDSKEN_FPGAMGRHSEN_SET_MSK 0x00000002 +#define ALT_RSTMGR_HDSKEN_FPGAHSEN_SET_MSK 0x00000004 +#define ALT_RSTMGR_HDSKEN_ETRSTALLEN_SET_MSK 0x00000008 +#endif #endif /* _RESET_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/reset_manager.c b/arch/arm/mach-socfpga/reset_manager.c index d0ff6c4..0fd4221 100644 --- a/arch/arm/mach-socfpga/reset_manager.c +++ b/arch/arm/mach-socfpga/reset_manager.c @@ -1,77 +1,18 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2016 Altera Corporation <www.altera.com> * - * SPDX-License-Identifier: GPL-2.0+ + * SPDX-License-Identifier: GPL-2.0 */
#include <common.h> #include <asm/io.h> -#include <asm/arch/fpga_manager.h> #include <asm/arch/reset_manager.h> -#include <asm/arch/system_manager.h>
DECLARE_GLOBAL_DATA_PTR;
static const struct socfpga_reset_manager *reset_manager_base = (void *)SOCFPGA_RSTMGR_ADDRESS; -static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - -/* - * Assert or de-assert SoCFPGA reset manager reset. - */ -void socfpga_per_reset(u32 reset, int set) -{ - const void *reg; - - if (RSTMGR_BANK(reset) == 0) - reg = &reset_manager_base->mpu_mod_reset; - else if (RSTMGR_BANK(reset) == 1) - reg = &reset_manager_base->per_mod_reset; - else if (RSTMGR_BANK(reset) == 2) - reg = &reset_manager_base->per2_mod_reset; - else if (RSTMGR_BANK(reset) == 3) - reg = &reset_manager_base->brg_mod_reset; - else if (RSTMGR_BANK(reset) == 4) - reg = &reset_manager_base->misc_mod_reset; - else /* Invalid reset register, do nothing */ - return; - - if (set) - setbits_le32(reg, 1 << RSTMGR_RESET(reset)); - else - clrbits_le32(reg, 1 << RSTMGR_RESET(reset)); -} - -/* - * Assert reset on every peripheral but L4WD0. - * Watchdog must be kept intact to prevent glitches - * and/or hangs. - * For the Arria10, we disable all the peripherals except L4 watchdog0, - * L4 Timer 0, and ECC. - */ -void socfpga_per_reset_all(void) -{ -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) - const u32 l4wd0 = 1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)); - - writel(~l4wd0, &reset_manager_base->per_mod_reset); - writel(0xffffffff, &reset_manager_base->per2_mod_reset); -#else - const u32 l4wd0 = (1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)) | - (1 << RSTMGR_RESET(SOCFPGA_RESET(L4SYSTIMER0)))); - - unsigned mask_ecc_ocp = 0x0000FF00; - - /* disable all components except ECC_OCP, L4 Timer0 and L4 WD0 */ - writel(~l4wd0, &reset_manager_base->per1_mod_reset); - setbits_le32(&reset_manager_base->per0_mod_reset, ~mask_ecc_ocp); - - /* Finally disable the ECC_OCP */ - setbits_le32(&reset_manager_base->per0_mod_reset, mask_ecc_ocp); -#endif -}
/* * Write the reset manager register to cause reset @@ -89,54 +30,3 @@ void reset_cpu(ulong addr) ; }
-#if defined(CONFIG_TARGET_SOCFPGA_GEN5) -/* - * Release peripherals from reset based on handoff - */ -void reset_deassert_peripherals_handoff(void) -{ - writel(0, &reset_manager_base->per_mod_reset); -} -#endif - -#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) -void socfpga_bridges_reset(int enable) -{ - /* For SoCFPGA-VT, this is NOP. */ -} -#else - -#define L3REGS_REMAP_LWHPS2FPGA_MASK 0x10 -#define L3REGS_REMAP_HPS2FPGA_MASK 0x08 -#define L3REGS_REMAP_OCRAM_MASK 0x01 - -void socfpga_bridges_reset(int enable) -{ -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) - const uint32_t l3mask = L3REGS_REMAP_LWHPS2FPGA_MASK | - L3REGS_REMAP_HPS2FPGA_MASK | - L3REGS_REMAP_OCRAM_MASK; - - if (enable) { - /* brdmodrst */ - writel(0xffffffff, &reset_manager_base->brg_mod_reset); - } else { - writel(0, &sysmgr_regs->iswgrp_handoff[0]); - writel(l3mask, &sysmgr_regs->iswgrp_handoff[1]); - - /* Check signal from FPGA. */ - if (!fpgamgr_test_fpga_ready()) { - /* FPGA not ready, do nothing. */ - printf("%s: FPGA not ready, aborting.\n", __func__); - return; - } - - /* brdmodrst */ - writel(0, &reset_manager_base->brg_mod_reset); - - /* Remap the bridges into memory map */ - writel(l3mask, SOCFPGA_L3REGS_ADDRESS); - } -#endif -} -#endif diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c new file mode 100644 index 0000000..36f83f8 --- /dev/null +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c @@ -0,0 +1,766 @@ +/* + * Copyright (C) 2016, Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/fpga_manager.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h> +#include <fdtdec.h> +#include <errno.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_reset_manager *reset_manager_base = + (void *)SOCFPGA_RSTMGR_ADDRESS; +static const struct socfpga_system_manager *sysmgr_regs = + (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; + +static int get_bridge_init_val(const void *blob, int compat_id); +static void reset_deassert_shared_connected_peripherals_q1(uint32_t *mask0, + uint32_t *mask1, uint32_t *pinmux_addr); +static void reset_deassert_shared_connected_peripherals_q2(uint32_t *mask0, + uint32_t *mask1, uint32_t *pinmux_addr); +static void reset_deassert_shared_connected_peripherals_q3(uint32_t *mask0, + uint32_t *mask1, uint32_t *pinmux_addr); +static void reset_deassert_shared_connected_peripherals_q4(uint32_t *mask0, + uint32_t *mask1, uint32_t *pinmux_addr); + +#define ECC_MASK (ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK|\ + ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK|\ + ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK|\ + ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK|\ + ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK|\ + ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK) + +static const uint32_t per0fpgamasks[] = { + ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK, + ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK, + ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK, + 0, /* i2c0 per1mod */ + 0, /* i2c1 per1mod */ + 0, /* i2c0_emac */ + 0, /* i2c1_emac */ + 0, /* i2c2_emac */ + ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_NAND_SET_MSK, + ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_QSPI_SET_MSK, + ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_SDMMC_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIM0_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIM1_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIS0_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIS1_SET_MSK, + 0, /* uart0 per1mod */ + 0, /* uart1 per1mod */ +}; + +static const uint32_t per1fpgamasks[] = { + 0, /* emac0 per0mod */ + 0, /* emac1 per0mod */ + 0, /* emac2 per0mod */ + ALT_RSTMGR_PER1MODRST_I2C0_SET_MSK, + ALT_RSTMGR_PER1MODRST_I2C1_SET_MSK, + ALT_RSTMGR_PER1MODRST_I2C2_SET_MSK, /* i2c0_emac */ + ALT_RSTMGR_PER1MODRST_I2C3_SET_MSK, /* i2c1_emac */ + ALT_RSTMGR_PER1MODRST_I2C4_SET_MSK, /* i2c2_emac */ + 0, /* nand per0mod */ + 0, /* qspi per0mod */ + 0, /* sdmmc per0mod */ + 0, /* spim0 per0mod */ + 0, /* spim1 per0mod */ + 0, /* spis0 per0mod */ + 0, /* spis1 per0mod */ + ALT_RSTMGR_PER1MODRST_UART0_SET_MSK, + ALT_RSTMGR_PER1MODRST_UART1_SET_MSK, +}; + +struct bridge_cfg { + int compat_id; + u32 mask_noc; + u32 mask_rstmgr; +}; + +static const struct bridge_cfg bridge_cfg_tbl[] = { + { + COMPAT_ALTERA_SOCFPGA_H2F_BRG, + ALT_SYSMGR_NOC_H2F_SET_MSK, + ALT_RSTMGR_BRGMODRST_H2F_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_LWH2F_BRG, + ALT_SYSMGR_NOC_LWH2F_SET_MSK, + ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2H_BRG, + ALT_SYSMGR_NOC_F2H_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2H_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2SDR0, + ALT_SYSMGR_NOC_F2SDR0_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2SDR1, + ALT_SYSMGR_NOC_F2SDR1_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2SDR2, + ALT_SYSMGR_NOC_F2SDR2_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK, + }, +}; + +/* Disable the watchdog (toggle reset to watchdog) */ +void watchdog_disable(void) +{ + /* assert reset for watchdog */ + setbits_le32(&reset_manager_base->per1modrst, + ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); + +} + +/* Release NOC ddr scheduler from reset */ +void reset_deassert_noc_ddr_scheduler(void) +{ + clrbits_le32(&reset_manager_base->brgmodrst, + ALT_RSTMGR_BRGMODRST_DDRSCH_SET_MSK); +} + +/* Check whether Watchdog in reset state? */ +int is_wdt_in_reset(void) +{ + unsigned long val; + + val = readl(&reset_manager_base->per1modrst); + val &= ALT_RSTMGR_PER1MODRST_WD0_SET_MSK; + + /* return 0x1 if watchdog in reset */ + return val; +} + +/* emacbase: base address of emac to enable/disable reset + * state: 0 - disable reset, !0 - enable reset + */ +void emac_manage_reset(ulong emacbase, uint state) +{ + ulong eccmask; + ulong emacmask; + switch (emacbase) { + case SOCFPGA_EMAC0_ADDRESS: + eccmask = ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK; + emacmask = ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK; + break; + case SOCFPGA_EMAC1_ADDRESS: + eccmask = ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK; + emacmask = ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK; + break; + case SOCFPGA_EMAC2_ADDRESS: + eccmask = ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK; + emacmask = ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK; + break; + default: + error("emac base address unexpected! %lx", emacbase); + hang(); + break; + } + + if (state) { + /* Enable ECC OCP first */ + setbits_le32(&reset_manager_base->per0modrst, eccmask); + setbits_le32(&reset_manager_base->per0modrst, emacmask); + } else { + /* Disable ECC OCP first */ + clrbits_le32(&reset_manager_base->per0modrst, emacmask); + clrbits_le32(&reset_manager_base->per0modrst, eccmask); + } +} + +static int get_bridge_init_val(const void *blob, int compat_id) +{ + int rval = 0; + int node; + u32 val; + + node = fdtdec_next_compatible(blob, 0, compat_id); + if (node >= 0) { + if (!fdtdec_get_int_array(blob, node, "init-val", &val, 1)) { + if (val == 1) + rval = val; + } + } + return rval; +} + +/* Enable bridges (hps2fpga, lwhps2fpga, fpga2hps, fpga2sdram) per handoff */ +int reset_deassert_bridges_handoff(void) +{ + u32 mask_noc = 0, mask_rstmgr = 0; + int i; + unsigned start = get_timer(0); + + for (i = 0; i < ARRAY_SIZE(bridge_cfg_tbl); i++) { + if (get_bridge_init_val(gd->fdt_blob, + bridge_cfg_tbl[i].compat_id)) { + mask_noc |= bridge_cfg_tbl[i].mask_noc; + mask_rstmgr |= bridge_cfg_tbl[i].mask_rstmgr; + } + } + + /* clear idle request to all bridges */ + setbits_le32(&sysmgr_regs->noc_idlereq_clr, mask_noc); + + /* Release bridges from reset state per handoff value */ + clrbits_le32(&reset_manager_base->brgmodrst, mask_rstmgr); + + /* Poll until all idleack to 0, timeout at 1000ms */ + while (readl(&sysmgr_regs->noc_idleack) & mask_noc) { + if (get_timer(start) > 1000) { + printf("Fail: noc_idleack = 0x%08x mask_noc = 0x%08x\n", + readl(&sysmgr_regs->noc_idleack), + mask_noc); + return -ETIMEDOUT; + } + } + return 0; +} + +void reset_deassert_dedicated_peripherals(void) +{ + int i; + u32 mask0 = 0; + u32 mask1 = 0; + u32 pinmux_addr = SOCFPGA_PINMUX_DEDICATED_IO_ADDRESS; + u32 mask = 0; +#if defined(CONFIG_MMC) + mask |= ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK; +#elif defined(CONFIG_CADENCE_QSPI) + mask |= ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK; +#elif defined(CONFIG_NAND_DENALI) + mask |= ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK; +#else +#error "unsupported dedicated peripherals" +#endif + mask |= ALT_RSTMGR_PER0MODRST_DMAECC_SET_MSK; + + /* enable ECC OCP first */ + clrbits_le32(&reset_manager_base->per0modrst, mask); + + mask = 0; +#if defined(CONFIG_MMC) + mask |= ALT_RSTMGR_PER0MODRST_SDMMC_SET_MSK; +#elif defined(CONFIG_CADENCE_QSPI) + mask |= ALT_RSTMGR_PER0MODRST_QSPI_SET_MSK; +#elif defined(CONFIG_NAND_DENALI) + mask |= ALT_RSTMGR_PER0MODRST_NAND_SET_MSK; +#else +#error "unsupported dedicated peripherals" +#endif + mask |= ALT_RSTMGR_PER0MODRST_DMA_SET_MSK; + + clrbits_le32(&reset_manager_base->per0modrst, mask); + + mask = ALT_RSTMGR_PER1MODRST_L4SYSTMR0_SET_MSK; + + clrbits_le32(&reset_manager_base->per1modrst, mask); + + /* start with 4 as first 3 registers are reserved */ + for (i = 4, pinmux_addr += (sizeof(u32) * (i - 1)); i <= 17; + i++, pinmux_addr += sizeof(u32)) { + switch (readl(pinmux_addr)) { + case 0: + if ((i == 12) || (i == 13)) + mask1 |= ALT_RSTMGR_PER1MODRST_I2C3_SET_MSK; + else if ((i == 14) || (i == 15)) + mask1 |= ALT_RSTMGR_PER1MODRST_I2C4_SET_MSK; + else if ((i == 16) || (i == 17)) + mask1 |= ALT_RSTMGR_PER1MODRST_I2C2_SET_MSK; + break; + case 1: + if ((i == 12) || (i == 13)) + mask0 |= + ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK; + else if ((i == 14) || (i == 15)) + mask0 |= + ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK; + else if ((i == 16) || (i == 17)) + mask0 |= + ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK; + break; + case 2: + if ((i == 10) || ((i >= 15) && (i <= 17))) + mask0 |= ALT_RSTMGR_PER0MODRST_SPIS0_SET_MSK; + break; + case 3: + if ((i >= 10) && (i <= 14)) + mask0 |= ALT_RSTMGR_PER0MODRST_SPIM0_SET_MSK; + break; + case 13: + if (i >= 12) + mask1 |= ALT_RSTMGR_PER1MODRST_UART1_SET_MSK; + break; + case 15: + mask1 |= ALT_RSTMGR_PER1MODRST_GPIO2_SET_MSK; + break; + } + } + clrbits_le32(&reset_manager_base->per0modrst, mask0 & ECC_MASK); + clrbits_le32(&reset_manager_base->per1modrst, mask1); + clrbits_le32(&reset_manager_base->per0modrst, mask0); + +} + +void reset_assert_fpga_connected_peripherals(void) +{ + uint32_t mask0 = 0; + uint32_t mask1 = 0; + uint32_t fpga_pinux_addr = SOCFPGA_PINMUX_FPGA_INTERFACE_ADDRESS; + int i; + + for (i = 0; i < ARRAY_SIZE(per1fpgamasks); i++) { + if (readl(fpga_pinux_addr)) { + mask0 |= per0fpgamasks[i]; + mask1 |= per1fpgamasks[i]; + } + fpga_pinux_addr += sizeof(uint32_t); + } + + setbits_le32(&reset_manager_base->per0modrst, mask0 & ECC_MASK); + setbits_le32(&reset_manager_base->per1modrst, mask1); + setbits_le32(&reset_manager_base->per0modrst, mask0); +} + +void reset_deassert_fpga_connected_peripherals(void) +{ + uint32_t mask0 = 0; + uint32_t mask1 = 0; + uint32_t fpga_pinux_addr = SOCFPGA_PINMUX_FPGA_INTERFACE_ADDRESS; + int i; + + for (i = 0; i < ARRAY_SIZE(per1fpgamasks); i++) { + if (readl(fpga_pinux_addr)) { + mask0 |= per0fpgamasks[i]; + mask1 |= per1fpgamasks[i]; + } + fpga_pinux_addr += sizeof(uint32_t); + } + + clrbits_le32(&reset_manager_base->per0modrst, mask0 & ECC_MASK); + clrbits_le32(&reset_manager_base->per1modrst, mask1); + clrbits_le32(&reset_manager_base->per0modrst, mask0); +} + +static void reset_deassert_shared_connected_peripherals_q1(uint32_t *mask0, + uint32_t *mask1, uint32_t *pinmux_addr) +{ + int i; + + for (i = 1; i <= 12; i++, *pinmux_addr += sizeof(uint32_t)) { + switch (readl(*pinmux_addr)) { + case 15: + *mask1 |= ALT_RSTMGR_PER1MODRST_GPIO0_SET_MSK; + break; + case 14: + *mask0 |= ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK| + ALT_RSTMGR_PER0MODRST_NAND_SET_MSK; + break; + case 13: + if ((i >= 1) && (i <= 4)) + *mask1 |= ALT_RSTMGR_PER1MODRST_UART0_SET_MSK; + else if ((i >= 5) && (i <= 8)) + *mask1 |= ALT_RSTMGR_PER1MODRST_UART1_SET_MSK; + break; + case 12: + if ((i >= 5) && (i <= 6)) + *mask0 |= + ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_QSPI_SET_MSK; + break; + case 8: + *mask0 |= ALT_RSTMGR_PER0MODRST_USBECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_USB0_SET_MSK; + break; + case 4: + if ((i >= 1) && (i <= 10)) + *mask0 |= + ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_SDMMC_SET_MSK; + break; + case 3: + if ((i == 1) || ((i >= 5) && (i <= 8))) + *mask0 |= ALT_RSTMGR_PER0MODRST_SPIM0_SET_MSK; + else if ((i == 2) || ((i >= 9) && (i <= 12))) + *mask0 |= ALT_RSTMGR_PER0MODRST_SPIM1_SET_MSK; + break; + case 2: + if ((i >= 1) && (i <= 4)) + *mask0 |= ALT_RSTMGR_PER0MODRST_SPIS0_SET_MSK; + else if ((i >= 9) && (i <= 12)) + *mask0 |= ALT_RSTMGR_PER0MODRST_SPIS1_SET_MSK; + break; + case 1: + if ((i == 7) || (i == 8)) + *mask0 |= + ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK; + else if ((i == 9) || (i == 10)) + *mask0 |= + ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK; + else if ((i == 11) || (1 == 12)) + *mask0 |= + ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK; + break; + case 0: + if ((i == 3) || (i == 4)) + *mask1 |= ALT_RSTMGR_PER1MODRST_I2C1_SET_MSK; + else if ((i == 5) || (i == 6)) + *mask1 |= ALT_RSTMGR_PER1MODRST_I2C0_SET_MSK; + else if ((i == 7) || (i == 8)) + *mask1 |= ALT_RSTMGR_PER1MODRST_I2C4_SET_MSK; + else if ((i == 9) || (i == 10)) + *mask1 |= ALT_RSTMGR_PER1MODRST_I2C3_SET_MSK; + else if ((i == 11) || (i == 12)) + *mask1 |= ALT_RSTMGR_PER1MODRST_I2C2_SET_MSK; + break; + } + } +} + +static void reset_deassert_shared_connected_peripherals_q2(uint32_t *mask0, + uint32_t *mask1, uint32_t *pinmux_addr) +{ + int i; + + for (i = 1; i <= 12; i++, *pinmux_addr += sizeof(uint32_t)) { + switch (readl(*pinmux_addr)) { + case 15: + *mask1 |= ALT_RSTMGR_PER1MODRST_GPIO0_SET_MSK; + break; + case 14: + if ((i != 4) && (i != 5)) + *mask0 |= + ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_NAND_SET_MSK; + break; + case 13: + if ((i >= 9) && (i <= 12)) + *mask1 |= ALT_RSTMGR_PER1MODRST_UART0_SET_MSK; + break; + case 8: + *mask0 |= ALT_RSTMGR_PER0MODRST_USBECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_USB1_SET_MSK; + break; + case 4: + *mask0 |= ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK; + break; + case 3: + if ((i >= 8) && (i <= 12)) + *mask0 |= ALT_RSTMGR_PER0MODRST_SPIM1_SET_MSK; + break; + case 2: + if ((i >= 9) && (i <= 12)) + *mask0 |= ALT_RSTMGR_PER0MODRST_SPIS0_SET_MSK; + break; + case 0: + if ((i == 9) || (i == 10)) + *mask1 |= ALT_RSTMGR_PER1MODRST_I2C1_SET_MSK; + else if ((i == 11) || (i == 12)) + *mask1 |= ALT_RSTMGR_PER1MODRST_I2C0_SET_MSK; + break; + } + } +} + +static void reset_deassert_shared_connected_peripherals_q3(uint32_t *mask0, + uint32_t *mask1, uint32_t *pinmux_addr) +{ + int i; + + for (i = 1; i <= 12; i++, *pinmux_addr += sizeof(uint32_t)) { + switch (readl(*pinmux_addr)) { + case 15: + *mask1 |= ALT_RSTMGR_PER1MODRST_GPIO1_SET_MSK; + break; + case 14: + *mask0 |= ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_NAND_SET_MSK; + break; + case 13: + if ((i >= 1) && (i <= 4)) + *mask1 |= ALT_RSTMGR_PER1MODRST_UART0_SET_MSK; + else if ((i >= 5) && (i <= 8)) + *mask1 |= ALT_RSTMGR_PER1MODRST_UART1_SET_MSK; + break; + case 8: + *mask0 |= ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK; + break; + case 3: + if ((i >= 1) && (i <= 5)) + *mask0 |= ALT_RSTMGR_PER0MODRST_SPIM1_SET_MSK; + break; + case 2: + if ((i >= 5) && (i <= 8)) + *mask0 |= ALT_RSTMGR_PER0MODRST_SPIS1_SET_MSK; + else if ((i >= 9) && (i <= 12)) + *mask0 |= ALT_RSTMGR_PER0MODRST_SPIS0_SET_MSK; + break; + case 1: + if ((i == 9) || (i == 10)) + *mask0 |= + ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK; + else if ((i == 11) || (i == 12)) + *mask0 |= + ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK; + break; + case 0: + if ((i == 7) || (i == 8)) + *mask1 |= ALT_RSTMGR_PER1MODRST_I2C1_SET_MSK; + else if ((i == 3) || (i == 4)) + *mask1 |= ALT_RSTMGR_PER1MODRST_I2C0_SET_MSK; + else if ((i == 9) || (i == 10)) + *mask1 |= ALT_RSTMGR_PER1MODRST_I2C4_SET_MSK; + else if ((i == 11) || (i == 12)) + *mask1 |= ALT_RSTMGR_PER1MODRST_I2C2_SET_MSK; + break; + } + } +} + +static void reset_deassert_shared_connected_peripherals_q4(uint32_t *mask0, + uint32_t *mask1, uint32_t *pinmux_addr) +{ + int i; + + for (i = 1; i <= 12; i++, *pinmux_addr += sizeof(uint32_t)) { + switch (readl(*pinmux_addr)) { + case 15: + *mask1 |= ALT_RSTMGR_PER1MODRST_GPIO1_SET_MSK; + break; + case 14: + if (i != 4) + *mask0 |= + ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_NAND_SET_MSK; + break; + case 13: + if ((i >= 3) && (i <= 6)) + *mask1 |= ALT_RSTMGR_PER1MODRST_UART1_SET_MSK; + break; + case 12: + if ((i == 5) || (i == 6)) + *mask0 |= + ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_QSPI_SET_MSK; + break; + case 8: + *mask0 |= ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK; + break; + case 4: + if ((i >= 1) && (i <= 6)) + *mask0 |= + ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_SDMMC_SET_MSK; + break; + case 3: + if ((i >= 6) && (i <= 12)) + *mask0 |= ALT_RSTMGR_PER0MODRST_SPIM0_SET_MSK; + break; + case 2: + if ((i >= 9) && (i <= 12)) + *mask0 |= ALT_RSTMGR_PER0MODRST_SPIS1_SET_MSK; + break; + case 1: + if ((i == 7) || (i == 8)) + *mask0 |= + ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK; + else if ((i == 11) || (i == 12)) + *mask0 |= + ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK; + break; + case 0: + if ((i == 1) || (i == 2)) + *mask1 |= ALT_RSTMGR_PER1MODRST_I2C1_SET_MSK; + else if ((i == 7) || (i == 8)) + *mask1 |= ALT_RSTMGR_PER1MODRST_I2C3_SET_MSK; + else if ((i == 9) || (i == 10)) + *mask1 |= ALT_RSTMGR_PER1MODRST_I2C4_SET_MSK; + else if ((i == 11) || (i == 12)) + *mask1 |= ALT_RSTMGR_PER1MODRST_I2C2_SET_MSK; + break; + } + } +} + +void reset_deassert_shared_connected_peripherals(void) +{ + uint32_t mask0 = 0; + uint32_t mask1 = 0; + uint32_t pinmux_addr = SOCFPGA_PINMUX_SHARED_3V_IO_ADDRESS; + + reset_deassert_shared_connected_peripherals_q1(&mask0, &mask1, + &pinmux_addr); + reset_deassert_shared_connected_peripherals_q2(&mask0, &mask1, + &pinmux_addr); + reset_deassert_shared_connected_peripherals_q3(&mask0, &mask1, + &pinmux_addr); + reset_deassert_shared_connected_peripherals_q4(&mask0, &mask1, + &pinmux_addr); + mask1 |= ALT_RSTMGR_PER1MODRST_WD1_SET_MSK | + ALT_RSTMGR_PER1MODRST_L4SYSTMR1_SET_MSK | + ALT_RSTMGR_PER1MODRST_SPTMR0_SET_MSK | + ALT_RSTMGR_PER1MODRST_SPTMR1_SET_MSK; + + clrbits_le32(&reset_manager_base->per0modrst, mask0 & ECC_MASK); + clrbits_le32(&reset_manager_base->per1modrst, mask1); + clrbits_le32(&reset_manager_base->per0modrst, mask0); +} + +/* Release L4 OSC1 Watchdog Timer 0 from reset through reset manager */ +void reset_deassert_osc1wd0(void) +{ + clrbits_le32(&reset_manager_base->per1modrst, + ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); +} + +/* + * Assert or de-assert SoCFPGA reset manager reset. + */ +void socfpga_per_reset(u32 reset, int set) +{ + const volatile uint32_t *reg; + uint32_t rstmgr_bank = RSTMGR_BANK(reset); + + switch (rstmgr_bank) { + case 0: + reg = &reset_manager_base->mpumodrst; + break; + case 1: + reg = &reset_manager_base->per0modrst; + break; + case 2: + reg = &reset_manager_base->per1modrst; + break; + case 3: + reg = &reset_manager_base->brgmodrst; + break; + case 4: + reg = &reset_manager_base->sysmodrst; + break; + + default: + return; + } + + if (set) + setbits_le32(reg, 1 << RSTMGR_RESET(reset)); + else + clrbits_le32(reg, 1 << RSTMGR_RESET(reset)); +} + +/* + * Assert reset on every peripheral but L4WD0. + * Watchdog must be kept intact to prevent glitches + * and/or hangs. + * For the Arria10, we disable all the peripherals except L4 watchdog0, + * L4 Timer 0, and ECC. + */ +void socfpga_per_reset_all(void) +{ + const u32 l4wd0 = (1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)) | + (1 << RSTMGR_RESET(SOCFPGA_RESET(L4SYSTIMER0)))); + + unsigned mask_ecc_ocp = + ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK | + ALT_RSTMGR_PER0MODRST_USBECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_USBECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK; + + /* disable all components except ECC_OCP, L4 Timer0 and L4 WD0 */ + writel(~l4wd0, &reset_manager_base->per1modrst); + setbits_le32(&reset_manager_base->per0modrst, ~mask_ecc_ocp); + + /* Finally disable the ECC_OCP */ + setbits_le32(&reset_manager_base->per0modrst, mask_ecc_ocp); +} + +#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) +void socfpga_bridges_reset(int enable) +{ + /* For SoCFPGA-VT, this is NOP. */ +} +#else +void socfpga_bridges_reset(int enable) +{ +/* Disable all the bridges (hps2fpga, lwhps2fpga, fpga2hps, fpga2sdram) */ + /* set idle request to all bridges */ + writel(ALT_SYSMGR_NOC_H2F_SET_MSK | + ALT_SYSMGR_NOC_LWH2F_SET_MSK | + ALT_SYSMGR_NOC_F2H_SET_MSK | + ALT_SYSMGR_NOC_F2SDR0_SET_MSK | + ALT_SYSMGR_NOC_F2SDR1_SET_MSK | + ALT_SYSMGR_NOC_F2SDR2_SET_MSK, + &sysmgr_regs->noc_idlereq_set); + + /* Enable the NOC timeout */ + writel(ALT_SYSMGR_NOC_TMO_EN_SET_MSK, + &sysmgr_regs->noc_timeout); + + /* Poll until all idleack to 1 */ + while ((readl(&sysmgr_regs->noc_idleack) ^ + (ALT_SYSMGR_NOC_H2F_SET_MSK | + ALT_SYSMGR_NOC_LWH2F_SET_MSK | + ALT_SYSMGR_NOC_F2H_SET_MSK | + ALT_SYSMGR_NOC_F2SDR0_SET_MSK | + ALT_SYSMGR_NOC_F2SDR1_SET_MSK | + ALT_SYSMGR_NOC_F2SDR2_SET_MSK))) + ; + + /* Poll until all idlestatus to 1 */ + while ((readl(&sysmgr_regs->noc_idlestatus) ^ + (ALT_SYSMGR_NOC_H2F_SET_MSK | + ALT_SYSMGR_NOC_LWH2F_SET_MSK | + ALT_SYSMGR_NOC_F2H_SET_MSK | + ALT_SYSMGR_NOC_F2SDR0_SET_MSK | + ALT_SYSMGR_NOC_F2SDR1_SET_MSK | + ALT_SYSMGR_NOC_F2SDR2_SET_MSK))) + ; + + /* Put all bridges (except NOR DDR scheduler) into reset state */ + setbits_le32(&reset_manager_base->brgmodrst, + (ALT_RSTMGR_BRGMODRST_H2F_SET_MSK | + ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2H_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK)); + + /* Disable NOC timeout */ + writel(0, &sysmgr_regs->noc_timeout); +} +#endif diff --git a/arch/arm/mach-socfpga/reset_manager_gen5.c b/arch/arm/mach-socfpga/reset_manager_gen5.c new file mode 100644 index 0000000..8c1f96e --- /dev/null +++ b/arch/arm/mach-socfpga/reset_manager_gen5.c @@ -0,0 +1,116 @@ +/* + * Copyright (C) 2016, Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/fpga_manager.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_reset_manager *reset_manager_base = + (void *)SOCFPGA_RSTMGR_ADDRESS; +static const struct socfpga_system_manager *sysmgr_regs = + (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; + +/* + * Release peripherals from reset based on handoff + */ +void reset_deassert_peripherals_handoff(void) +{ + writel(0, &reset_manager_base->per_mod_reset); +} + +/* + * Assert or de-assert SoCFPGA reset manager reset. + */ +void socfpga_per_reset(u32 reset, int set) +{ + const volatile uint32_t *reg; + uint32_t rstmgr_bank = RSTMGR_BANK(reset); + + switch (rstmgr_bank) { + case 0: + reg = &reset_manager_base->mpu_mod_reset; + break; + case 1: + reg = &reset_manager_base->per_mod_reset; + break; + case 2: + reg = &reset_manager_base->per2_mod_reset; + break; + case 3: + reg = &reset_manager_base->brg_mod_reset; + break; + case 4: + reg = &reset_manager_base->misc_mod_reset; + break; + + default: + return; + } + + if (set) + setbits_le32(reg, 1 << RSTMGR_RESET(reset)); + else + clrbits_le32(reg, 1 << RSTMGR_RESET(reset)); +} + +/* + * Assert reset on every peripheral but L4WD0. + * Watchdog must be kept intact to prevent glitches + * and/or hangs. + * For the Arria10, we disable all the peripherals except L4 watchdog0, + * L4 Timer 0, and ECC. + */ +void socfpga_per_reset_all(void) +{ + const u32 l4wd0 = 1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)); + + writel(~l4wd0, &reset_manager_base->per_mod_reset); + writel(0xffffffff, &reset_manager_base->per2_mod_reset); +} + +#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) +void socfpga_bridges_reset(int enable) +{ + /* For SoCFPGA-VT, this is NOP. */ +} +#else + +#define L3REGS_REMAP_LWHPS2FPGA_MASK 0x10 +#define L3REGS_REMAP_HPS2FPGA_MASK 0x08 +#define L3REGS_REMAP_OCRAM_MASK 0x01 + +void socfpga_bridges_reset(int enable) +{ + const uint32_t l3mask = L3REGS_REMAP_LWHPS2FPGA_MASK | + L3REGS_REMAP_HPS2FPGA_MASK | + L3REGS_REMAP_OCRAM_MASK; + + if (enable) { + /* brdmodrst */ + writel(0xffffffff, &reset_manager_base->brg_mod_reset); + } else { + writel(0, &sysmgr_regs->iswgrp_handoff[0]); + writel(l3mask, &sysmgr_regs->iswgrp_handoff[1]); + + /* Check signal from FPGA. */ + if (!fpgamgr_test_fpga_ready()) { + /* FPGA not ready, do nothing. */ + printf("%s: FPGA not ready, aborting.\n", __func__); + return; + } + + /* brdmodrst */ + writel(0, &reset_manager_base->brg_mod_reset); + + /* Remap the bridges into memory map */ + writel(l3mask, SOCFPGA_L3REGS_ADDRESS); + } +} +#endif
+endif
wrap_sdram_config.o
- Copyright (C) 2012 Altera Corporation <www.altera.com>
- Copyright (C) 2012-2016 Altera Corporation <www.altera.com>
License change ?
Drop the extern ...
- u32 stat;
- u32 ramstat;
- u32 miscstat;
- u32 ctrl;
- u32 hdsken;
- u32 hdskreq;
- u32 hdskack;
- u32 counts;
- u32 coldmodrst;
- u32 nrstmodrst;
- u32 dbgmodrst;
- u32 mpuwarmmask;
- u32 per0warmmask;
- u32 per1warmmask;
- u32 brgwarmmask;
- u32 syswarmmask;
- u32 nrstwarmmask;
- u32 l3warmmask;
- u32 tststa;
- u32 tstscratch;
- u32 hdsktimeout;
- u32 hmcintr;
- u32 hmcintren;
- u32 hmcintrens;
- u32 hmcintrenr;
- u32 hmcgpout;
- u32 hmcgpin;
- volatile uint32_t stat;
Drop the volatile, it's useless here as it describes register layout. If it has any meaning in the code, the code is broken.
- volatile uint32_t ramstat;
- volatile uint32_t miscstat;
- volatile uint32_t ctrl;
- volatile uint32_t hdsken;
- volatile uint32_t hdskreq;
- volatile uint32_t hdskack;
- volatile uint32_t counts;
- volatile uint32_t mpumodrst;
- volatile uint32_t per0modrst;
- volatile uint32_t per1modrst;
- volatile uint32_t brgmodrst;
- volatile uint32_t sysmodrst;
- volatile uint32_t coldmodrst;
- volatile uint32_t nrstmodrst;
- volatile uint32_t dbgmodrst;
- volatile uint32_t mpuwarmmask;
- volatile uint32_t per0warmmask;
- volatile uint32_t per1warmmask;
- volatile uint32_t brgwarmmask;
- volatile uint32_t syswarmmask;
- volatile uint32_t nrstwarmmask;
- volatile uint32_t l3warmmask;
- volatile uint32_t tststa;
- volatile uint32_t tstscratch;
- volatile uint32_t hdsktimeout;
- volatile uint32_t hmcintr;
- volatile uint32_t hmcintren;
- volatile uint32_t hmcintrens;
- volatile uint32_t hmcintrenr;
- volatile uint32_t hmcgpout;
- volatile uint32_t hmcgpin;
}; #endif
- SocFPGA Arria10 reset IDs, bank mapping is as follows:
- 0 ... mpumodrst
- Copyright (C) 2013 Altera Corporation <www.altera.com>
- Copyright (C) 2013-2016 Altera Corporation <www.altera.com>
You're changing licenses without consulting all contributors, this cannot be done IMO.
- int i;
- u32 mask0 = 0;
- u32 mask1 = 0;
- u32 pinmux_addr = SOCFPGA_PINMUX_DEDICATED_IO_ADDRESS;
- u32 mask = 0;
- mask |= ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK;
- mask |= ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK;
- mask |= ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK;
+#else
Shouldn't this come from OF instead of being ifdef'd ?
- mask |= ALT_RSTMGR_PER0MODRST_DMAECC_SET_MSK;
- /* enable ECC OCP first */
- clrbits_le32(&reset_manager_base->per0modrst, mask);
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach- socfpga/Makefile index 809cd47..b8fcf6e 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -2,21 +2,27 @@ # (C) Copyright 2000-2003 # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # -# Copyright (C) 2012 Altera Corporation <www.altera.com> +# Copyright (C) 2012-2016 Altera Corporation <www.altera.com> # # SPDX-License-Identifier: GPL-2.0+ # obj-y += misc.o timer.o reset_manager.o system_manager.o clock_manager.o \ fpga_manager.o board.o +obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += reset_manager_arria10.o +obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o \
wrap_sdram_config.o +endif +ifdef CONFIG_TARGET_SOCFPGA_GEN5 # QTS-generated config file wrappers -obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o -obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \
wrap_sdram_config.o
- * Copyright (C) 2012-2016 Altera Corporation <www.altera.com>
License change ?
i will revert it.
*/ #ifndef _RESET_MANAGER_H_ #define _RESET_MANAGER_H_ -void reset_cpu(ulong addr); -void reset_deassert_peripherals_handoff(void); +/* Common function prototypes */ +extern void reset_cpu(ulong addr); +extern void socfpga_bridges_reset(int enable); +extern void socfpga_per_reset(u32 reset, int set); +extern void socfpga_per_reset_all(void);
Drop the extern ...
okay.
-void socfpga_per_reset(u32 reset, int set); -void socfpga_per_reset_all(void); +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +extern void reset_deassert_peripherals_handoff(void); +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +extern void watchdog_disable(void); +extern void reset_deassert_noc_ddr_scheduler(void); +extern int is_wdt_in_reset(void); +extern void emac_manage_reset(ulong emacbase, uint state); +extern int reset_deassert_bridges_handoff(void); +extern void reset_deassert_dedicated_peripherals(void); +extern void reset_assert_fpga_connected_peripherals(void); +extern void reset_deassert_fpga_connected_peripherals(void); +extern void reset_deassert_shared_connected_peripherals(void); +extern void reset_deassert_osc1wd0(void); +#endif #if defined(CONFIG_TARGET_SOCFPGA_GEN5) struct socfpga_reset_manager { @@ -29,40 +42,40 @@ struct socfpga_reset_manager { u32 padding2[12]; u32 tstscratch; }; -#else +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) struct socfpga_reset_manager {
- u32 stat;
- u32 ramstat;
- u32 miscstat;
- u32 ctrl;
- u32 hdsken;
- u32 hdskreq;
- u32 hdskack;
- u32 counts;
- u32 coldmodrst;
- u32 nrstmodrst;
- u32 dbgmodrst;
- u32 mpuwarmmask;
- u32 per0warmmask;
- u32 per1warmmask;
- u32 brgwarmmask;
- u32 syswarmmask;
- u32 nrstwarmmask;
- u32 l3warmmask;
- u32 tststa;
- u32 tstscratch;
- u32 hdsktimeout;
- u32 hmcintr;
- u32 hmcintren;
- u32 hmcintrens;
- u32 hmcintrenr;
- u32 hmcgpout;
- u32 hmcgpin;
okay. I found that readl and writel in arm lib having volatile cast, so volatile declaration is no longer needed.
}; #endif @@ -113,7 +126,7 @@ struct socfpga_reset_manager { #define RSTMGR_SDMMC RSTMGR_DEFINE(1, 22) #define RSTMGR_DMA RSTMGR_DEFINE(1, 28) #define RSTMGR_SDR RSTMGR_DEFINE(1, 29) -#else +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) /* * SocFPGA Arria10 reset IDs, bank mapping is as follows: * 0 ... mpumodrst @@ -144,4 +157,71 @@ struct socfpga_reset_manager { /* Create a human-readable reference to SoCFPGA reset. */ #define SOCFPGA_RESET(_name) RSTMGR_##_name +/* Create a human-readable reference to SoCFPGA reset. */ +#define SOCFPGA_RESET(_name) RSTMGR_##_name
+#define ALT_RSTMGR_HDSKEN_SDRSELFREFEN_SET_MSK 0x00000001 +#define ALT_RSTMGR_HDSKEN_FPGAMGRHSEN_SET_MSK 0x00000002 +#define ALT_RSTMGR_HDSKEN_FPGAHSEN_SET_MSK 0x00000004 +#define ALT_RSTMGR_HDSKEN_ETRSTALLEN_SET_MSK 0x00000008 +#endif #endif /* _RESET_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/reset_manager.c b/arch/arm/mach- socfpga/reset_manager.c index d0ff6c4..0fd4221 100644 --- a/arch/arm/mach-socfpga/reset_manager.c +++ b/arch/arm/mach-socfpga/reset_manager.c @@ -1,77 +1,18 @@ /*
- * Copyright (C) 2013-2016 Altera Corporation <www.altera.com>
okay, i will revert it.
- int i;
- u32 mask0 = 0;
- u32 mask1 = 0;
- u32 mask = 0;
+#else
What is OF? what is your suggestion to make this function generic for all type of flash?
- int i;
- u32 mask0 = 0;
- u32 mask1 = 0;
- u32 mask = 0;
+#else
What is OF?
Device Tree (Open Firmware).
Pull it from OF ?
- int i;
- u32 mask0 = 0;
- u32 mask1 = 0;
- u32 mask = 0;
+#else
What is OF?
Pull it from OF ?
Why you prefer device tree implementation over #define in defconfig, because there is performance penalty.
- int i;
- u32 mask0 = 0;
- u32 mask1 = 0;
- u32 mask = 0;
+#else
What is OF?
Pull it from OF ?
Because we are moving away from excessive random #defines and toward having one single binary where you could exchange just the DT and run it on multiple boards, just like Linux, that is the ultimate goal.
Also, this is not performance critical code, is it.
- int i;
- u32 mask0 = 0;
- u32 mask1 = 0;
- u32 pinmux_addr =
- u32 mask = 0;
+#else
What is OF?
Pull it from OF ?
This code just to release peripherals from reset, not performance critical codes. However, our defconfigs based on flash type booting, so this is why i din't use the DT, since we have flash type determined from defconfig. Since DT is ultimate goal, i can change to DT implementation.
On 12/06/2016 09:08 AM, Chee Tien Fong wrote: > > > > From: Tien Fong Chee tien.fong.chee@intel.com > > Drivers for reset manager is restructured such that common > functions, > gen5 drivers and Arria10 drivers are moved to > reset_manager.c, > reset_manager_gen5.c and reset_manager_arria10.c > respectively. > > Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com > Cc: Marek Vasut marex@denx.de > Cc: Dinh Nguyen dinguyen@kernel.org > Cc: Chin Liang See chin.liang.see@intel.com > Cc: Tien Fong skywindctf@gmail.com
> > > +void reset_deassert_dedicated_peripherals(void) > +{ > + int i; > + u32 mask0 = 0; > + u32 mask1 = 0; > + u32 pinmux_addr = > SOCFPGA_PINMUX_DEDICATED_IO_ADDRESS; > + u32 mask = 0; > +#if defined(CONFIG_MMC) > + mask |= ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK; > +#elif defined(CONFIG_CADENCE_QSPI) > + mask |= ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK; > +#elif defined(CONFIG_NAND_DENALI) > + mask |= ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK; > +#else Shouldn't this come from OF instead of being ifdef'd ?
What is OF?
Pull it from OF ?
You should really only unreset the peripherals which you need and, ideally, only when you need them. So it should be the driver which handles the peripheral reset, not the common code (unless there is a reason for the common code to do it).
On Sel, 2016-12-06 at 13:55 +0100, Marek Vasut wrote: > > > > On 12/06/2016 09:08 AM, Chee Tien Fong wrote: > > > > > > > > > > From: Tien Fong Chee tien.fong.chee@intel.com > > > > Drivers for reset manager is restructured such that > > common > > functions, > > gen5 drivers and Arria10 drivers are moved to > > reset_manager.c, > > reset_manager_gen5.c and reset_manager_arria10.c > > respectively. > > > > Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com > > > > > Cc: Marek Vasut marex@denx.de > > Cc: Dinh Nguyen dinguyen@kernel.org > > Cc: Chin Liang See chin.liang.see@intel.com > > Cc: Tien Fong skywindctf@gmail.com
> > > > > > > > > > > +void reset_deassert_dedicated_peripherals(void) > > +{ > > + int i; > > + u32 mask0 = 0; > > + u32 mask1 = 0; > > + u32 pinmux_addr = > > SOCFPGA_PINMUX_DEDICATED_IO_ADDRESS; > > + u32 mask = 0; > > +#if defined(CONFIG_MMC) > > + mask |= > > ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK; > > +#elif defined(CONFIG_CADENCE_QSPI) > > + mask |= ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK; > > +#elif defined(CONFIG_NAND_DENALI) > > + mask |= ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK; > > +#else > Shouldn't this come from OF instead of being ifdef'd ? > What is OF?
Pull it from OF ?
Yeah, i agree with you too. Did our cyclone5 implement this also? Does DM has framework to support user define reset mechanism?
On 12/07/2016 12:58 PM, Chee, Tien Fong wrote: > > > > On Sel, 2016-12-06 at 13:55 +0100, Marek Vasut wrote: >> >> >> >> On 12/06/2016 09:08 AM, Chee Tien Fong wrote: >>> >>> >>> >>> >>> From: Tien Fong Chee tien.fong.chee@intel.com >>> >>> Drivers for reset manager is restructured such that >>> common >>> functions, >>> gen5 drivers and Arria10 drivers are moved to >>> reset_manager.c, >>> reset_manager_gen5.c and reset_manager_arria10.c >>> respectively. >>> >>> Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com >>>> >>> Cc: Marek Vasut marex@denx.de >>> Cc: Dinh Nguyen dinguyen@kernel.org >>> Cc: Chin Liang See chin.liang.see@intel.com >>> Cc: Tien Fong skywindctf@gmail.com [...]
> > > >> >> >> >>> >>> >>> >>> +void reset_deassert_dedicated_peripherals(void) >>> +{ >>> + int i; >>> + u32 mask0 = 0; >>> + u32 mask1 = 0; >>> + u32 pinmux_addr = >>> SOCFPGA_PINMUX_DEDICATED_IO_ADDRESS; >>> + u32 mask = 0; >>> +#if defined(CONFIG_MMC) >>> + mask |= >>> ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK; >>> +#elif defined(CONFIG_CADENCE_QSPI) >>> + mask |= ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK; >>> +#elif defined(CONFIG_NAND_DENALI) >>> + mask |= ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK; >>> +#else >> Shouldn't this come from OF instead of being ifdef'd ? >> > What is OF? Device Tree (Open Firmware).
> > > > what is your suggestion to make this function generic for > all type of flash? Pull it from OF ?
The CV does it at least for ethernet . I don't think there is a dedicated mechanism yet.
Chee Tien Fong
Chee, Tien Fong
