[RFC PATCH v1 0/5] Amlogic A1 SoC Family Support
This patch series adds basic support for Amlogic AD401 development board based on Amlogic A1 SoC family
Igor Prusov (5): ARM: dts: Add Amlogic Meson A1 DT from Linux 6.3-rc7 ARM: dts: sync meson-a1-ad401 from Linux 6.3-rc7 ARM: meson: add A1 support pinctrl: meson: add pinctrl driver for Amlogic A1 board: amlogic: add support for AD401 board
MAINTAINERS | 1 + arch/arm/dts/Makefile | 1 + arch/arm/dts/meson-a1-ad401.dts | 30 + arch/arm/dts/meson-a1.dtsi | 161 +++++ arch/arm/include/asm/arch-meson/a1.h | 20 + arch/arm/mach-meson/Kconfig | 7 + arch/arm/mach-meson/Makefile | 1 + arch/arm/mach-meson/board-a1.c | 59 ++ board/amlogic/ad401/Makefile | 4 + board/amlogic/ad401/ad401.c | 15 + configs/ad401_defconfig | 54 ++ drivers/pinctrl/meson/Kconfig | 4 + drivers/pinctrl/meson/Makefile | 1 + drivers/pinctrl/meson/pinctrl-meson-a1.c | 867 +++++++++++++++++++++++ include/configs/meson64.h | 3 + include/dt-bindings/gpio/meson-a1-gpio.h | 73 ++ 16 files changed, 1301 insertions(+) create mode 100644 arch/arm/dts/meson-a1-ad401.dts create mode 100644 arch/arm/dts/meson-a1.dtsi create mode 100644 arch/arm/include/asm/arch-meson/a1.h create mode 100644 arch/arm/mach-meson/board-a1.c create mode 100644 board/amlogic/ad401/Makefile create mode 100644 board/amlogic/ad401/ad401.c create mode 100644 configs/ad401_defconfig create mode 100644 drivers/pinctrl/meson/pinctrl-meson-a1.c create mode 100644 include/dt-bindings/gpio/meson-a1-gpio.h
Import Linux 6.3-rc7 Device tree and necessary bindings for Amlogic A1 board from 6a8f57ae2eb0 ("Linux 6.3-rc7").
Signed-off-by: Igor Prusov ivprusov@sberdevices.ru --- arch/arm/dts/meson-a1.dtsi | 161 +++++++++++++++++++++++ include/dt-bindings/gpio/meson-a1-gpio.h | 73 ++++++++++ 2 files changed, 234 insertions(+) create mode 100644 arch/arm/dts/meson-a1.dtsi create mode 100644 include/dt-bindings/gpio/meson-a1-gpio.h
diff --git a/arch/arm/dts/meson-a1.dtsi b/arch/arm/dts/meson-a1.dtsi new file mode 100644 index 0000000000..6509329b85 --- /dev/null +++ b/arch/arm/dts/meson-a1.dtsi @@ -0,0 +1,161 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 Amlogic, Inc. All rights reserved. + */ + +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/gpio/meson-a1-gpio.h> + +/ { + compatible = "amlogic,a1"; + + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + cpus { + #address-cells = <2>; + #size-cells = <0>; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a35"; + reg = <0x0 0x0>; + enable-method = "psci"; + next-level-cache = <&l2>; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a35"; + reg = <0x0 0x1>; + enable-method = "psci"; + next-level-cache = <&l2>; + }; + + l2: l2-cache0 { + compatible = "cache"; + cache-level = <2>; + }; + }; + + psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + linux,cma { + compatible = "shared-dma-pool"; + reusable; + size = <0x0 0x800000>; + alignment = <0x0 0x400000>; + linux,cma-default; + }; + }; + + sm: secure-monitor { + compatible = "amlogic,meson-gxbb-sm"; + + pwrc: power-controller { + compatible = "amlogic,meson-a1-pwrc"; + #power-domain-cells = <1>; + status = "okay"; + }; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + apb: bus@fe000000 { + compatible = "simple-bus"; + reg = <0x0 0xfe000000 0x0 0x1000000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0xfe000000 0x0 0x1000000>; + + reset: reset-controller@0 { + compatible = "amlogic,meson-a1-reset"; + reg = <0x0 0x0 0x0 0x8c>; + #reset-cells = <1>; + }; + + periphs_pinctrl: pinctrl@400 { + compatible = "amlogic,meson-a1-periphs-pinctrl"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + gpio: bank@400 { + reg = <0x0 0x0400 0x0 0x003c>, + <0x0 0x0480 0x0 0x0118>; + reg-names = "mux", "gpio"; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&periphs_pinctrl 0 0 62>; + }; + + }; + + uart_AO: serial@1c00 { + compatible = "amlogic,meson-gx-uart", + "amlogic,meson-ao-uart"; + reg = <0x0 0x1c00 0x0 0x18>; + interrupts = <GIC_SPI 25 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, <&xtal>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; + status = "disabled"; + }; + + uart_AO_B: serial@2000 { + compatible = "amlogic,meson-gx-uart", + "amlogic,meson-ao-uart"; + reg = <0x0 0x2000 0x0 0x18>; + interrupts = <GIC_SPI 26 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, <&xtal>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; + status = "disabled"; + }; + }; + + gic: interrupt-controller@ff901000 { + compatible = "arm,gic-400"; + reg = <0x0 0xff901000 0x0 0x1000>, + <0x0 0xff902000 0x0 0x2000>, + <0x0 0xff904000 0x0 0x2000>, + <0x0 0xff906000 0x0 0x2000>; + interrupt-controller; + interrupts = <GIC_PPI 9 + (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>; + #interrupt-cells = <3>; + #address-cells = <0>; + }; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>; + }; + + xtal: xtal-clk { + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "xtal"; + #clock-cells = <0>; + }; +}; diff --git a/include/dt-bindings/gpio/meson-a1-gpio.h b/include/dt-bindings/gpio/meson-a1-gpio.h new file mode 100644 index 0000000000..40e57a5ff1 --- /dev/null +++ b/include/dt-bindings/gpio/meson-a1-gpio.h @@ -0,0 +1,73 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2019 Amlogic, Inc. All rights reserved. + * Author: Qianggui Song qianggui.song@amlogic.com + */ + +#ifndef _DT_BINDINGS_MESON_A1_GPIO_H +#define _DT_BINDINGS_MESON_A1_GPIO_H + +#define GPIOP_0 0 +#define GPIOP_1 1 +#define GPIOP_2 2 +#define GPIOP_3 3 +#define GPIOP_4 4 +#define GPIOP_5 5 +#define GPIOP_6 6 +#define GPIOP_7 7 +#define GPIOP_8 8 +#define GPIOP_9 9 +#define GPIOP_10 10 +#define GPIOP_11 11 +#define GPIOP_12 12 +#define GPIOB_0 13 +#define GPIOB_1 14 +#define GPIOB_2 15 +#define GPIOB_3 16 +#define GPIOB_4 17 +#define GPIOB_5 18 +#define GPIOB_6 19 +#define GPIOX_0 20 +#define GPIOX_1 21 +#define GPIOX_2 22 +#define GPIOX_3 23 +#define GPIOX_4 24 +#define GPIOX_5 25 +#define GPIOX_6 26 +#define GPIOX_7 27 +#define GPIOX_8 28 +#define GPIOX_9 29 +#define GPIOX_10 30 +#define GPIOX_11 31 +#define GPIOX_12 32 +#define GPIOX_13 33 +#define GPIOX_14 34 +#define GPIOX_15 35 +#define GPIOX_16 36 +#define GPIOF_0 37 +#define GPIOF_1 38 +#define GPIOF_2 39 +#define GPIOF_3 40 +#define GPIOF_4 41 +#define GPIOF_5 42 +#define GPIOF_6 43 +#define GPIOF_7 44 +#define GPIOF_8 45 +#define GPIOF_9 46 +#define GPIOF_10 47 +#define GPIOF_11 48 +#define GPIOF_12 49 +#define GPIOA_0 50 +#define GPIOA_1 51 +#define GPIOA_2 52 +#define GPIOA_3 53 +#define GPIOA_4 54 +#define GPIOA_5 55 +#define GPIOA_6 56 +#define GPIOA_7 57 +#define GPIOA_8 58 +#define GPIOA_9 59 +#define GPIOA_10 60 +#define GPIOA_11 61 + +#endif /* _DT_BINDINGS_MESON_A1_GPIO_H */
- Copyright (c) 2019 Amlogic, Inc. All rights reserved.
- compatible = "amlogic,a1";
- interrupt-parent = <&gic>;
- #address-cells = <2>;
- #size-cells = <2>;
- cpus {
#size-cells = <0>;
cpu0: cpu@0 {
reg = <0x0 0x0>;
cpu1: cpu@1 {
reg = <0x0 0x1>;
l2: l2-cache0 {
cache-level = <2>;
- psci {
method = "smc";
- reserved-memory {
#size-cells = <2>;
ranges;
linux,cma {
reusable;
linux,cma-default;
- sm: secure-monitor {
status = "okay";
- soc {
#size-cells = <2>;
ranges;
apb: bus@fe000000 {
#size-cells = <2>;
#reset-cells = <1>;
#size-cells = <2>;
ranges;
gpio: bank@400 {
gpio-controller;
#gpio-cells = <2>;
- timer {
<GIC_PPI 14
<GIC_PPI 11
<GIC_PPI 10
- xtal: xtal-clk {
#clock-cells = <0>;
- Author: Qianggui Song qianggui.song@amlogic.com
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
Add meson-a1-ad401.dts file from Linux 6.3-rc7
Signed-off-by: Igor Prusov ivprusov@sberdevices.ru --- arch/arm/dts/Makefile | 1 + arch/arm/dts/meson-a1-ad401.dts | 30 ++++++++++++++++++++++++++++++ 2 files changed, 31 insertions(+) create mode 100644 arch/arm/dts/meson-a1-ad401.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 3385948d22..8de35c5454 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -185,6 +185,7 @@ dtb-$(CONFIG_ARCH_S5P4418) += \ s5p4418-nanopi2.dtb
dtb-$(CONFIG_ARCH_MESON) += \ + meson-a1-ad401.dtb \ meson-axg-s400.dtb \ meson-axg-jethome-jethub-j100.dtb \ meson-gxbb-nanopi-k2.dtb \ diff --git a/arch/arm/dts/meson-a1-ad401.dts b/arch/arm/dts/meson-a1-ad401.dts new file mode 100644 index 0000000000..69c25c68c3 --- /dev/null +++ b/arch/arm/dts/meson-a1-ad401.dts @@ -0,0 +1,30 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 Amlogic, Inc. All rights reserved. + */ + +/dts-v1/; + +#include "meson-a1.dtsi" + +/ { + compatible = "amlogic,ad401", "amlogic,a1"; + model = "Amlogic Meson A1 AD401 Development Board"; + + aliases { + serial0 = &uart_AO_B; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x8000000>; + }; +}; + +&uart_AO_B { + status = "okay"; +};
- meson-a1-ad401.dtb \ meson-axg-s400.dtb \ meson-axg-jethome-jethub-j100.dtb \ meson-gxbb-nanopi-k2.dtb \
+/dts-v1/;
- compatible = "amlogic,ad401", "amlogic,a1";
- model = "Amlogic Meson A1 AD401 Development Board";
- aliases {
- chosen {
- memory@0 {
+&uart_AO_B {
- status = "okay";
Add support for Amlogic A1 SoC family.
Signed-off-by: Igor Prusov ivprusov@sberdevices.ru Signed-off-by: Evgeny Bachinin eabachinin@sberdevices.ru --- arch/arm/include/asm/arch-meson/a1.h | 20 ++++++++++ arch/arm/mach-meson/Kconfig | 6 +++ arch/arm/mach-meson/Makefile | 1 + arch/arm/mach-meson/board-a1.c | 59 ++++++++++++++++++++++++++++ include/configs/meson64.h | 3 ++ 5 files changed, 89 insertions(+) create mode 100644 arch/arm/include/asm/arch-meson/a1.h create mode 100644 arch/arm/mach-meson/board-a1.c
diff --git a/arch/arm/include/asm/arch-meson/a1.h b/arch/arm/include/asm/arch-meson/a1.h new file mode 100644 index 0000000000..86d1a68de8 --- /dev/null +++ b/arch/arm/include/asm/arch-meson/a1.h @@ -0,0 +1,20 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2023 SberDevices, Inc. + * Author: Igor Prusov ivprusov@sberdevices.ru + */ + +#ifndef __MESON_A1_H__ +#define __MESON_A1_H__ + +#define A1_SYSCTRL_BASE 0xfe005800 + +/* SYSCTRL registers */ +#define A1_SYSCTRL_ADDR(off) (A1_SYSCTRL_BASE + ((off) << 2)) + +#define A1_SYSCTRL_SEC_STATUS_REG4 A1_SYSCTRL_ADDR(0xc4) + +#define A1_SYSCTRL_MEM_SIZE_MASK 0xFFFF0000 +#define A1_SYSCTRL_MEM_SIZE_SHIFT 16 + +#endif /* __MESON_A1_H__ */ diff --git a/arch/arm/mach-meson/Kconfig b/arch/arm/mach-meson/Kconfig index 6cba2c40dd..519ed563c0 100644 --- a/arch/arm/mach-meson/Kconfig +++ b/arch/arm/mach-meson/Kconfig @@ -51,6 +51,12 @@ config MESON_G12A help Select this if your SoC is an S905X/D2
+config MESON_A1 + bool "A1" + select MESON64_COMMON + help + Select this if your SoC is an A113L + endchoice
config SYS_SOC diff --git a/arch/arm/mach-meson/Makefile b/arch/arm/mach-meson/Makefile index a9e4046f80..535b0878b9 100644 --- a/arch/arm/mach-meson/Makefile +++ b/arch/arm/mach-meson/Makefile @@ -6,3 +6,4 @@ obj-y += board-common.o sm.o board-info.o obj-$(CONFIG_MESON_GX) += board-gx.o obj-$(CONFIG_MESON_AXG) += board-axg.o obj-$(CONFIG_MESON_G12A) += board-g12a.o +obj-$(CONFIG_MESON_A1) += board-a1.o diff --git a/arch/arm/mach-meson/board-a1.c b/arch/arm/mach-meson/board-a1.c new file mode 100644 index 0000000000..967bb67182 --- /dev/null +++ b/arch/arm/mach-meson/board-a1.c @@ -0,0 +1,59 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2023 SberDevices, Inc. + */ + +#include <common.h> +#include <asm/arch/a1.h> +#include <asm/arch/boot.h> +#include <asm/armv8/mmu.h> +#include <asm/io.h> +#include <linux/compiler.h> +#include <linux/sizes.h> + +phys_size_t get_effective_memsize(void) +{ + return ((readl(A1_SYSCTRL_SEC_STATUS_REG4) & A1_SYSCTRL_MEM_SIZE_MASK) + >> A1_SYSCTRL_MEM_SIZE_SHIFT) * SZ_1M; +} + +void meson_init_reserved_memory(__maybe_unused void *fdt) +{ +} + +int meson_get_boot_device(void) +{ + return -ENOSYS; +} + +static struct mm_region a1_mem_map[] = { + { + .virt = 0x00000000UL, + .phys = 0x00000000UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0x80000000UL, + .phys = 0x80000000UL, + .size = 0x7FE00000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* + * This mem region contains in/out shared memory with bl31, + * hence it's marked as NORMAL memory type + */ + .virt = 0xFFE00000UL, + .phys = 0xFFE00000UL, + .size = 0x00200000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + /* List terminator */ + 0, + } +}; + +struct mm_region *mem_map = a1_mem_map; diff --git a/include/configs/meson64.h b/include/configs/meson64.h index 9244601284..801cdae470 100644 --- a/include/configs/meson64.h +++ b/include/configs/meson64.h @@ -11,6 +11,9 @@ #if (defined(CONFIG_MESON_AXG) || defined(CONFIG_MESON_G12A)) #define GICD_BASE 0xffc01000 #define GICC_BASE 0xffc02000 +#elif defined(CONFIG_MESON_A1) +#define GICD_BASE 0xff901000 +#define GICC_BASE 0xff902000 #else /* MESON GXL and GXBB */ #define GICD_BASE 0xc4301000 #define GICC_BASE 0xc4302000
- (C) Copyright 2023 SberDevices, Inc.
- Author: Igor Prusov ivprusov@sberdevices.ru
+config MESON_A1
bool "A1"
help
endchoice
config SYS_SOC
- return ((readl(A1_SYSCTRL_SEC_STATUS_REG4) & A1_SYSCTRL_MEM_SIZE_MASK)
- return -ENOSYS;
0,
Based on Linux kernel commit: dabad1ff85611 (pinctrl: meson: add pinctrl driver support for Meson-A1 SoC)
Signed-off-by: Igor Prusov ivprusov@sberdevices.ru --- drivers/pinctrl/meson/Kconfig | 4 + drivers/pinctrl/meson/Makefile | 1 + drivers/pinctrl/meson/pinctrl-meson-a1.c | 867 +++++++++++++++++++++++ 3 files changed, 872 insertions(+) create mode 100644 drivers/pinctrl/meson/pinctrl-meson-a1.c
diff --git a/drivers/pinctrl/meson/Kconfig b/drivers/pinctrl/meson/Kconfig index ef02087ed2..97e574330f 100644 --- a/drivers/pinctrl/meson/Kconfig +++ b/drivers/pinctrl/meson/Kconfig @@ -29,4 +29,8 @@ config PINCTRL_MESON_G12A bool "Amlogic Meson G12a SoC pinctrl driver" select PINCTRL_MESON_AXG_PMX
+config PINCTRL_MESON_A1 + bool "Amlogic Meson A1 SoC pinctrl driver" + select PINCTRL_MESON_AXG_PMX + endif diff --git a/drivers/pinctrl/meson/Makefile b/drivers/pinctrl/meson/Makefile index 80dba65e1b..8d10d027ac 100644 --- a/drivers/pinctrl/meson/Makefile +++ b/drivers/pinctrl/meson/Makefile @@ -7,3 +7,4 @@ obj-$(CONFIG_PINCTRL_MESON_GXBB) += pinctrl-meson-gxbb.o obj-$(CONFIG_PINCTRL_MESON_GXL) += pinctrl-meson-gxl.o obj-$(CONFIG_PINCTRL_MESON_AXG) += pinctrl-meson-axg.o obj-$(CONFIG_PINCTRL_MESON_G12A) += pinctrl-meson-g12a.o +obj-$(CONFIG_PINCTRL_MESON_A1) += pinctrl-meson-a1.o diff --git a/drivers/pinctrl/meson/pinctrl-meson-a1.c b/drivers/pinctrl/meson/pinctrl-meson-a1.c new file mode 100644 index 0000000000..30cf3bc0be --- /dev/null +++ b/drivers/pinctrl/meson/pinctrl-meson-a1.c @@ -0,0 +1,867 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 Amlogic, Inc. All rights reserved. + * Author: Qianggui Song qianggui.song@amlogic.com + * Copyright (C) 2023 SberDevices, Inc. + * Author: Igor Prusov ivprusov@sberdevices.ru + */ + +#include <common.h> +#include <dm.h> +#include <dm/pinctrl.h> +#include <dt-bindings/gpio/meson-a1-gpio.h> + +#include "pinctrl-meson.h" +#include "pinctrl-meson-axg.h" + +/* psram */ +static const unsigned int psram_clkn_pins[] = { GPIOP_0 }; +static const unsigned int psram_clkp_pins[] = { GPIOP_1 }; +static const unsigned int psram_ce_n_pins[] = { GPIOP_2 }; +static const unsigned int psram_rst_n_pins[] = { GPIOP_3 }; +static const unsigned int psram_adq0_pins[] = { GPIOP_4 }; +static const unsigned int psram_adq1_pins[] = { GPIOP_5 }; +static const unsigned int psram_adq2_pins[] = { GPIOP_6 }; +static const unsigned int psram_adq3_pins[] = { GPIOP_7 }; +static const unsigned int psram_adq4_pins[] = { GPIOP_8 }; +static const unsigned int psram_adq5_pins[] = { GPIOP_9 }; +static const unsigned int psram_adq6_pins[] = { GPIOP_10 }; +static const unsigned int psram_adq7_pins[] = { GPIOP_11 }; +static const unsigned int psram_dqs_dm_pins[] = { GPIOP_12 }; + +/* sdcard */ +static const unsigned int sdcard_d0_b_pins[] = { GPIOB_0 }; +static const unsigned int sdcard_d1_b_pins[] = { GPIOB_1 }; +static const unsigned int sdcard_d2_b_pins[] = { GPIOB_2 }; +static const unsigned int sdcard_d3_b_pins[] = { GPIOB_3 }; +static const unsigned int sdcard_clk_b_pins[] = { GPIOB_4 }; +static const unsigned int sdcard_cmd_b_pins[] = { GPIOB_5 }; + +static const unsigned int sdcard_d0_x_pins[] = { GPIOX_0 }; +static const unsigned int sdcard_d1_x_pins[] = { GPIOX_1 }; +static const unsigned int sdcard_d2_x_pins[] = { GPIOX_2 }; +static const unsigned int sdcard_d3_x_pins[] = { GPIOX_3 }; +static const unsigned int sdcard_clk_x_pins[] = { GPIOX_4 }; +static const unsigned int sdcard_cmd_x_pins[] = { GPIOX_5 }; + +/* spif */ +static const unsigned int spif_mo_pins[] = { GPIOB_0 }; +static const unsigned int spif_mi_pins[] = { GPIOB_1 }; +static const unsigned int spif_wp_n_pins[] = { GPIOB_2 }; +static const unsigned int spif_hold_n_pins[] = { GPIOB_3 }; +static const unsigned int spif_clk_pins[] = { GPIOB_4 }; +static const unsigned int spif_cs_pins[] = { GPIOB_5 }; + +/* i2c0 */ +static const unsigned int i2c0_sck_f9_pins[] = { GPIOF_9 }; +static const unsigned int i2c0_sda_f10_pins[] = { GPIOF_10 }; +static const unsigned int i2c0_sck_f11_pins[] = { GPIOF_11 }; +static const unsigned int i2c0_sda_f12_pins[] = { GPIOF_12 }; + +/* i2c1 */ +static const unsigned int i2c1_sda_x_pins[] = { GPIOX_9 }; +static const unsigned int i2c1_sck_x_pins[] = { GPIOX_10 }; +static const unsigned int i2c1_sda_a_pins[] = { GPIOA_10 }; +static const unsigned int i2c1_sck_a_pins[] = { GPIOA_11 }; + +/* i2c2 */ +static const unsigned int i2c2_sck_x0_pins[] = { GPIOX_0 }; +static const unsigned int i2c2_sda_x1_pins[] = { GPIOX_1 }; +static const unsigned int i2c2_sck_x15_pins[] = { GPIOX_15 }; +static const unsigned int i2c2_sda_x16_pins[] = { GPIOX_16 }; +static const unsigned int i2c2_sck_a4_pins[] = { GPIOA_4 }; +static const unsigned int i2c2_sda_a5_pins[] = { GPIOA_5 }; +static const unsigned int i2c2_sck_a8_pins[] = { GPIOA_8 }; +static const unsigned int i2c2_sda_a9_pins[] = { GPIOA_9 }; + +/* i2c3 */ +static const unsigned int i2c3_sck_f_pins[] = { GPIOF_4 }; +static const unsigned int i2c3_sda_f_pins[] = { GPIOF_5 }; +static const unsigned int i2c3_sck_x_pins[] = { GPIOX_11 }; +static const unsigned int i2c3_sda_x_pins[] = { GPIOX_12 }; + +/* i2c slave */ +static const unsigned int i2c_slave_sck_a_pins[] = { GPIOA_10 }; +static const unsigned int i2c_slave_sda_a_pins[] = { GPIOA_11 }; +static const unsigned int i2c_slave_sck_f_pins[] = { GPIOF_11 }; +static const unsigned int i2c_slave_sda_f_pins[] = { GPIOF_12 }; + +/* uart_a */ +static const unsigned int uart_a_tx_pins[] = { GPIOX_11 }; +static const unsigned int uart_a_rx_pins[] = { GPIOX_12 }; +static const unsigned int uart_a_cts_pins[] = { GPIOX_13 }; +static const unsigned int uart_a_rts_pins[] = { GPIOX_14 }; + +/* uart_b */ +static const unsigned int uart_b_tx_x_pins[] = { GPIOX_7 }; +static const unsigned int uart_b_rx_x_pins[] = { GPIOX_8 }; +static const unsigned int uart_b_tx_f_pins[] = { GPIOF_0 }; +static const unsigned int uart_b_rx_f_pins[] = { GPIOF_1 }; + +/* uart_c */ +static const unsigned int uart_c_tx_x0_pins[] = { GPIOX_0 }; +static const unsigned int uart_c_rx_x1_pins[] = { GPIOX_1 }; +static const unsigned int uart_c_cts_pins[] = { GPIOX_2 }; +static const unsigned int uart_c_rts_pins[] = { GPIOX_3 }; +static const unsigned int uart_c_tx_x15_pins[] = { GPIOX_15 }; +static const unsigned int uart_c_rx_x16_pins[] = { GPIOX_16 }; + +/* pmw_a */ +static const unsigned int pwm_a_x6_pins[] = { GPIOX_6 }; +static const unsigned int pwm_a_x7_pins[] = { GPIOX_7 }; +static const unsigned int pwm_a_f6_pins[] = { GPIOF_6 }; +static const unsigned int pwm_a_f10_pins[] = { GPIOF_10 }; +static const unsigned int pwm_a_a_pins[] = { GPIOA_5 }; + +/* pmw_b */ +static const unsigned int pwm_b_x_pins[] = { GPIOX_8 }; +static const unsigned int pwm_b_f_pins[] = { GPIOF_7 }; +static const unsigned int pwm_b_a_pins[] = { GPIOA_11 }; + +/* pmw_c */ +static const unsigned int pwm_c_x_pins[] = { GPIOX_9 }; +static const unsigned int pwm_c_f3_pins[] = { GPIOF_3 }; +static const unsigned int pwm_c_f8_pins[] = { GPIOF_8 }; +static const unsigned int pwm_c_a_pins[] = { GPIOA_10 }; + +/* pwm_d */ +static const unsigned int pwm_d_x10_pins[] = { GPIOX_10 }; +static const unsigned int pwm_d_x13_pins[] = { GPIOX_13 }; +static const unsigned int pwm_d_x15_pins[] = { GPIOX_15 }; +static const unsigned int pwm_d_f_pins[] = { GPIOF_11 }; + +/* pwm_e */ +static const unsigned int pwm_e_p_pins[] = { GPIOP_3 }; +static const unsigned int pwm_e_x2_pins[] = { GPIOX_2 }; +static const unsigned int pwm_e_x14_pins[] = { GPIOX_14 }; +static const unsigned int pwm_e_x16_pins[] = { GPIOX_16 }; +static const unsigned int pwm_e_f_pins[] = { GPIOF_3 }; +static const unsigned int pwm_e_a_pins[] = { GPIOA_0 }; + +/* pwm_f */ +static const unsigned int pwm_f_b_pins[] = { GPIOB_6 }; +static const unsigned int pwm_f_x_pins[] = { GPIOX_3 }; +static const unsigned int pwm_f_f4_pins[] = { GPIOF_4 }; +static const unsigned int pwm_f_f12_pins[] = { GPIOF_12 }; + +/* pwm_a_hiz */ +static const unsigned int pwm_a_hiz_f8_pins[] = { GPIOF_8 }; +static const unsigned int pwm_a_hiz_f10_pins[] = { GPIOF_10 }; +static const unsigned int pmw_a_hiz_f6_pins[] = { GPIOF_6 }; + +/* pwm_b_hiz */ +static const unsigned int pwm_b_hiz_pins[] = { GPIOF_7 }; + +/* pmw_c_hiz */ +static const unsigned int pwm_c_hiz_pins[] = { GPIOF_8 }; + +/* tdm_a */ +static const unsigned int tdm_a_dout1_pins[] = { GPIOX_7 }; +static const unsigned int tdm_a_dout0_pins[] = { GPIOX_8 }; +static const unsigned int tdm_a_fs_pins[] = { GPIOX_9 }; +static const unsigned int tdm_a_sclk_pins[] = { GPIOX_10 }; +static const unsigned int tdm_a_din1_pins[] = { GPIOX_7 }; +static const unsigned int tdm_a_din0_pins[] = { GPIOX_8 }; +static const unsigned int tdm_a_slv_fs_pins[] = { GPIOX_9 }; +static const unsigned int tdm_a_slv_sclk_pins[] = { GPIOX_10 }; + +/* spi_a */ +static const unsigned int spi_a_mosi_x2_pins[] = { GPIOX_2 }; +static const unsigned int spi_a_ss0_x3_pins[] = { GPIOX_3 }; +static const unsigned int spi_a_sclk_x4_pins[] = { GPIOX_4 }; +static const unsigned int spi_a_miso_x5_pins[] = { GPIOX_5 }; +static const unsigned int spi_a_mosi_x7_pins[] = { GPIOX_7 }; +static const unsigned int spi_a_miso_x8_pins[] = { GPIOX_8 }; +static const unsigned int spi_a_ss0_x9_pins[] = { GPIOX_9 }; +static const unsigned int spi_a_sclk_x10_pins[] = { GPIOX_10 }; + +static const unsigned int spi_a_mosi_a_pins[] = { GPIOA_6 }; +static const unsigned int spi_a_miso_a_pins[] = { GPIOA_7 }; +static const unsigned int spi_a_ss0_a_pins[] = { GPIOA_8 }; +static const unsigned int spi_a_sclk_a_pins[] = { GPIOA_9 }; + +/* pdm */ +static const unsigned int pdm_din0_x_pins[] = { GPIOX_7 }; +static const unsigned int pdm_din1_x_pins[] = { GPIOX_8 }; +static const unsigned int pdm_din2_x_pins[] = { GPIOX_9 }; +static const unsigned int pdm_dclk_x_pins[] = { GPIOX_10 }; + +static const unsigned int pdm_din2_a_pins[] = { GPIOA_6 }; +static const unsigned int pdm_din1_a_pins[] = { GPIOA_7 }; +static const unsigned int pdm_din0_a_pins[] = { GPIOA_8 }; +static const unsigned int pdm_dclk_pins[] = { GPIOA_9 }; + +/* gen_clk */ +static const unsigned int gen_clk_x_pins[] = { GPIOX_7 }; +static const unsigned int gen_clk_f8_pins[] = { GPIOF_8 }; +static const unsigned int gen_clk_f10_pins[] = { GPIOF_10 }; +static const unsigned int gen_clk_a_pins[] = { GPIOA_11 }; + +/* jtag_a */ +static const unsigned int jtag_a_clk_pins[] = { GPIOF_4 }; +static const unsigned int jtag_a_tms_pins[] = { GPIOF_5 }; +static const unsigned int jtag_a_tdi_pins[] = { GPIOF_6 }; +static const unsigned int jtag_a_tdo_pins[] = { GPIOF_7 }; + +/* clk_32_in */ +static const unsigned int clk_32k_in_pins[] = { GPIOF_2 }; + +/* ir in */ +static const unsigned int remote_input_f_pins[] = { GPIOF_3 }; +static const unsigned int remote_input_a_pins[] = { GPIOA_11 }; + +/* ir out */ +static const unsigned int remote_out_pins[] = { GPIOF_5 }; + +/* spdif */ +static const unsigned int spdif_in_f6_pins[] = { GPIOF_6 }; +static const unsigned int spdif_in_f7_pins[] = { GPIOF_7 }; + +/* sw */ +static const unsigned int swclk_pins[] = { GPIOF_4 }; +static const unsigned int swdio_pins[] = { GPIOF_5 }; + +/* clk_25 */ +static const unsigned int clk25_pins[] = { GPIOF_10 }; + +/* cec_a */ +static const unsigned int cec_a_pins[] = { GPIOF_2 }; + +/* cec_b */ +static const unsigned int cec_b_pins[] = { GPIOF_2 }; + +/* clk12_24 */ +static const unsigned int clk12_24_pins[] = { GPIOF_10 }; + +/* mclk_0 */ +static const unsigned int mclk_0_pins[] = { GPIOA_0 }; + +/* tdm_b */ +static const unsigned int tdm_b_sclk_pins[] = { GPIOA_1 }; +static const unsigned int tdm_b_fs_pins[] = { GPIOA_2 }; +static const unsigned int tdm_b_dout0_pins[] = { GPIOA_3 }; +static const unsigned int tdm_b_dout1_pins[] = { GPIOA_4 }; +static const unsigned int tdm_b_dout2_pins[] = { GPIOA_5 }; +static const unsigned int tdm_b_dout3_pins[] = { GPIOA_6 }; +static const unsigned int tdm_b_dout4_pins[] = { GPIOA_7 }; +static const unsigned int tdm_b_dout5_pins[] = { GPIOA_8 }; +static const unsigned int tdm_b_slv_sclk_pins[] = { GPIOA_5 }; +static const unsigned int tdm_b_slv_fs_pins[] = { GPIOA_6 }; +static const unsigned int tdm_b_din0_pins[] = { GPIOA_7 }; +static const unsigned int tdm_b_din1_pins[] = { GPIOA_8 }; +static const unsigned int tdm_b_din2_pins[] = { GPIOA_9 }; + +/* mclk_vad */ +static const unsigned int mclk_vad_pins[] = { GPIOA_0 }; + +/* tdm_vad */ +static const unsigned int tdm_vad_sclk_a1_pins[] = { GPIOA_1 }; +static const unsigned int tdm_vad_fs_a2_pins[] = { GPIOA_2 }; +static const unsigned int tdm_vad_sclk_a5_pins[] = { GPIOA_5 }; +static const unsigned int tdm_vad_fs_a6_pins[] = { GPIOA_6 }; + +/* tst_out */ +static const unsigned int tst_out0_pins[] = { GPIOA_0 }; +static const unsigned int tst_out1_pins[] = { GPIOA_1 }; +static const unsigned int tst_out2_pins[] = { GPIOA_2 }; +static const unsigned int tst_out3_pins[] = { GPIOA_3 }; +static const unsigned int tst_out4_pins[] = { GPIOA_4 }; +static const unsigned int tst_out5_pins[] = { GPIOA_5 }; +static const unsigned int tst_out6_pins[] = { GPIOA_6 }; +static const unsigned int tst_out7_pins[] = { GPIOA_7 }; +static const unsigned int tst_out8_pins[] = { GPIOA_8 }; +static const unsigned int tst_out9_pins[] = { GPIOA_9 }; +static const unsigned int tst_out10_pins[] = { GPIOA_10 }; +static const unsigned int tst_out11_pins[] = { GPIOA_11 }; + +/* mute */ +static const unsigned int mute_key_pins[] = { GPIOA_4 }; +static const unsigned int mute_en_pins[] = { GPIOA_5 }; + +static struct meson_pmx_group meson_a1_periphs_groups[] = { + GPIO_GROUP(GPIOP_0, 0), + GPIO_GROUP(GPIOP_1, 0), + GPIO_GROUP(GPIOP_2, 0), + GPIO_GROUP(GPIOP_3, 0), + GPIO_GROUP(GPIOP_4, 0), + GPIO_GROUP(GPIOP_5, 0), + GPIO_GROUP(GPIOP_6, 0), + GPIO_GROUP(GPIOP_7, 0), + GPIO_GROUP(GPIOP_8, 0), + GPIO_GROUP(GPIOP_9, 0), + GPIO_GROUP(GPIOP_10, 0), + GPIO_GROUP(GPIOP_11, 0), + GPIO_GROUP(GPIOP_12, 0), + GPIO_GROUP(GPIOB_0, 0), + GPIO_GROUP(GPIOB_1, 0), + GPIO_GROUP(GPIOB_2, 0), + GPIO_GROUP(GPIOB_3, 0), + GPIO_GROUP(GPIOB_4, 0), + GPIO_GROUP(GPIOB_5, 0), + GPIO_GROUP(GPIOB_6, 0), + GPIO_GROUP(GPIOX_0, 0), + GPIO_GROUP(GPIOX_1, 0), + GPIO_GROUP(GPIOX_2, 0), + GPIO_GROUP(GPIOX_3, 0), + GPIO_GROUP(GPIOX_4, 0), + GPIO_GROUP(GPIOX_5, 0), + GPIO_GROUP(GPIOX_6, 0), + GPIO_GROUP(GPIOX_7, 0), + GPIO_GROUP(GPIOX_8, 0), + GPIO_GROUP(GPIOX_9, 0), + GPIO_GROUP(GPIOX_10, 0), + GPIO_GROUP(GPIOX_11, 0), + GPIO_GROUP(GPIOX_12, 0), + GPIO_GROUP(GPIOX_13, 0), + GPIO_GROUP(GPIOX_14, 0), + GPIO_GROUP(GPIOX_15, 0), + GPIO_GROUP(GPIOX_16, 0), + GPIO_GROUP(GPIOF_0, 0), + GPIO_GROUP(GPIOF_1, 0), + GPIO_GROUP(GPIOF_2, 0), + GPIO_GROUP(GPIOF_3, 0), + GPIO_GROUP(GPIOF_4, 0), + GPIO_GROUP(GPIOF_5, 0), + GPIO_GROUP(GPIOF_6, 0), + GPIO_GROUP(GPIOF_7, 0), + GPIO_GROUP(GPIOF_8, 0), + GPIO_GROUP(GPIOF_9, 0), + GPIO_GROUP(GPIOF_10, 0), + GPIO_GROUP(GPIOF_11, 0), + GPIO_GROUP(GPIOF_12, 0), + GPIO_GROUP(GPIOA_0, 0), + GPIO_GROUP(GPIOA_1, 0), + GPIO_GROUP(GPIOA_2, 0), + GPIO_GROUP(GPIOA_3, 0), + GPIO_GROUP(GPIOA_4, 0), + GPIO_GROUP(GPIOA_5, 0), + GPIO_GROUP(GPIOA_6, 0), + GPIO_GROUP(GPIOA_7, 0), + GPIO_GROUP(GPIOA_8, 0), + GPIO_GROUP(GPIOA_9, 0), + GPIO_GROUP(GPIOA_10, 0), + GPIO_GROUP(GPIOA_11, 0), + + /* bank P func1 */ + GROUP(psram_clkn, 1), + GROUP(psram_clkp, 1), + GROUP(psram_ce_n, 1), + GROUP(psram_rst_n, 1), + GROUP(psram_adq0, 1), + GROUP(psram_adq1, 1), + GROUP(psram_adq2, 1), + GROUP(psram_adq3, 1), + GROUP(psram_adq4, 1), + GROUP(psram_adq5, 1), + GROUP(psram_adq6, 1), + GROUP(psram_adq7, 1), + GROUP(psram_dqs_dm, 1), + + /* bank P func2 */ + GROUP(pwm_e_p, 2), + + /* bank B func1 */ + GROUP(spif_mo, 1), + GROUP(spif_mi, 1), + GROUP(spif_wp_n, 1), + GROUP(spif_hold_n, 1), + GROUP(spif_clk, 1), + GROUP(spif_cs, 1), + GROUP(pwm_f_b, 1), + + /* bank B func2 */ + GROUP(sdcard_d0_b, 2), + GROUP(sdcard_d1_b, 2), + GROUP(sdcard_d2_b, 2), + GROUP(sdcard_d3_b, 2), + GROUP(sdcard_clk_b, 2), + GROUP(sdcard_cmd_b, 2), + + /* bank X func1 */ + GROUP(sdcard_d0_x, 1), + GROUP(sdcard_d1_x, 1), + GROUP(sdcard_d2_x, 1), + GROUP(sdcard_d3_x, 1), + GROUP(sdcard_clk_x, 1), + GROUP(sdcard_cmd_x, 1), + GROUP(pwm_a_x6, 1), + GROUP(tdm_a_dout1, 1), + GROUP(tdm_a_dout0, 1), + GROUP(tdm_a_fs, 1), + GROUP(tdm_a_sclk, 1), + GROUP(uart_a_tx, 1), + GROUP(uart_a_rx, 1), + GROUP(uart_a_cts, 1), + GROUP(uart_a_rts, 1), + GROUP(pwm_d_x15, 1), + GROUP(pwm_e_x16, 1), + + /* bank X func2 */ + GROUP(i2c2_sck_x0, 2), + GROUP(i2c2_sda_x1, 2), + GROUP(spi_a_mosi_x2, 2), + GROUP(spi_a_ss0_x3, 2), + GROUP(spi_a_sclk_x4, 2), + GROUP(spi_a_miso_x5, 2), + GROUP(tdm_a_din1, 2), + GROUP(tdm_a_din0, 2), + GROUP(tdm_a_slv_fs, 2), + GROUP(tdm_a_slv_sclk, 2), + GROUP(i2c3_sck_x, 2), + GROUP(i2c3_sda_x, 2), + GROUP(pwm_d_x13, 2), + GROUP(pwm_e_x14, 2), + GROUP(i2c2_sck_x15, 2), + GROUP(i2c2_sda_x16, 2), + + /* bank X func3 */ + GROUP(uart_c_tx_x0, 3), + GROUP(uart_c_rx_x1, 3), + GROUP(uart_c_cts, 3), + GROUP(uart_c_rts, 3), + GROUP(pdm_din0_x, 3), + GROUP(pdm_din1_x, 3), + GROUP(pdm_din2_x, 3), + GROUP(pdm_dclk_x, 3), + GROUP(uart_c_tx_x15, 3), + GROUP(uart_c_rx_x16, 3), + + /* bank X func4 */ + GROUP(pwm_e_x2, 4), + GROUP(pwm_f_x, 4), + GROUP(spi_a_mosi_x7, 4), + GROUP(spi_a_miso_x8, 4), + GROUP(spi_a_ss0_x9, 4), + GROUP(spi_a_sclk_x10, 4), + + /* bank X func5 */ + GROUP(uart_b_tx_x, 5), + GROUP(uart_b_rx_x, 5), + GROUP(i2c1_sda_x, 5), + GROUP(i2c1_sck_x, 5), + + /* bank X func6 */ + GROUP(pwm_a_x7, 6), + GROUP(pwm_b_x, 6), + GROUP(pwm_c_x, 6), + GROUP(pwm_d_x10, 6), + + /* bank X func7 */ + GROUP(gen_clk_x, 7), + + /* bank F func1 */ + GROUP(uart_b_tx_f, 1), + GROUP(uart_b_rx_f, 1), + GROUP(remote_input_f, 1), + GROUP(jtag_a_clk, 1), + GROUP(jtag_a_tms, 1), + GROUP(jtag_a_tdi, 1), + GROUP(jtag_a_tdo, 1), + GROUP(gen_clk_f8, 1), + GROUP(pwm_a_f10, 1), + GROUP(i2c0_sck_f11, 1), + GROUP(i2c0_sda_f12, 1), + + /* bank F func2 */ + GROUP(clk_32k_in, 2), + GROUP(pwm_e_f, 2), + GROUP(pwm_f_f4, 2), + GROUP(remote_out, 2), + GROUP(spdif_in_f6, 2), + GROUP(spdif_in_f7, 2), + GROUP(pwm_a_hiz_f8, 2), + GROUP(pwm_a_hiz_f10, 2), + GROUP(pwm_d_f, 2), + GROUP(pwm_f_f12, 2), + + /* bank F func3 */ + GROUP(pwm_c_f3, 3), + GROUP(swclk, 3), + GROUP(swdio, 3), + GROUP(pwm_a_f6, 3), + GROUP(pwm_b_f, 3), + GROUP(pwm_c_f8, 3), + GROUP(clk25, 3), + GROUP(i2c_slave_sck_f, 3), + GROUP(i2c_slave_sda_f, 3), + + /* bank F func4 */ + GROUP(cec_a, 4), + GROUP(i2c3_sck_f, 4), + GROUP(i2c3_sda_f, 4), + GROUP(pmw_a_hiz_f6, 4), + GROUP(pwm_b_hiz, 4), + GROUP(pwm_c_hiz, 4), + GROUP(i2c0_sck_f9, 4), + GROUP(i2c0_sda_f10, 4), + + /* bank F func5 */ + GROUP(cec_b, 5), + GROUP(clk12_24, 5), + + /* bank F func7 */ + GROUP(gen_clk_f10, 7), + + /* bank A func1 */ + GROUP(mclk_0, 1), + GROUP(tdm_b_sclk, 1), + GROUP(tdm_b_fs, 1), + GROUP(tdm_b_dout0, 1), + GROUP(tdm_b_dout1, 1), + GROUP(tdm_b_dout2, 1), + GROUP(tdm_b_dout3, 1), + GROUP(tdm_b_dout4, 1), + GROUP(tdm_b_dout5, 1), + GROUP(remote_input_a, 1), + + /* bank A func2 */ + GROUP(pwm_e_a, 2), + GROUP(tdm_b_slv_sclk, 2), + GROUP(tdm_b_slv_fs, 2), + GROUP(tdm_b_din0, 2), + GROUP(tdm_b_din1, 2), + GROUP(tdm_b_din2, 2), + GROUP(i2c1_sda_a, 2), + GROUP(i2c1_sck_a, 2), + + /* bank A func3 */ + GROUP(i2c2_sck_a4, 3), + GROUP(i2c2_sda_a5, 3), + GROUP(pdm_din2_a, 3), + GROUP(pdm_din1_a, 3), + GROUP(pdm_din0_a, 3), + GROUP(pdm_dclk, 3), + GROUP(pwm_c_a, 3), + GROUP(pwm_b_a, 3), + + /* bank A func4 */ + GROUP(pwm_a_a, 4), + GROUP(spi_a_mosi_a, 4), + GROUP(spi_a_miso_a, 4), + GROUP(spi_a_ss0_a, 4), + GROUP(spi_a_sclk_a, 4), + GROUP(i2c_slave_sck_a, 4), + GROUP(i2c_slave_sda_a, 4), + + /* bank A func5 */ + GROUP(mclk_vad, 5), + GROUP(tdm_vad_sclk_a1, 5), + GROUP(tdm_vad_fs_a2, 5), + GROUP(tdm_vad_sclk_a5, 5), + GROUP(tdm_vad_fs_a6, 5), + GROUP(i2c2_sck_a8, 5), + GROUP(i2c2_sda_a9, 5), + + /* bank A func6 */ + GROUP(tst_out0, 6), + GROUP(tst_out1, 6), + GROUP(tst_out2, 6), + GROUP(tst_out3, 6), + GROUP(tst_out4, 6), + GROUP(tst_out5, 6), + GROUP(tst_out6, 6), + GROUP(tst_out7, 6), + GROUP(tst_out8, 6), + GROUP(tst_out9, 6), + GROUP(tst_out10, 6), + GROUP(tst_out11, 6), + + /* bank A func7 */ + GROUP(mute_key, 7), + GROUP(mute_en, 7), + GROUP(gen_clk_a, 7), +}; + +static const char * const gpio_periphs_groups[] = { + "GPIOP_0", "GPIOP_1", "GPIOP_2", "GPIOP_3", "GPIOP_4", + "GPIOP_5", "GPIOP_6", "GPIOP_7", "GPIOP_8", "GPIOP_9", + "GPIOP_10", "GPIOP_11", "GPIOP_12", + + "GPIOB_0", "GPIOB_1", "GPIOB_2", "GPIOB_3", "GPIOB_4", + "GPIOB_5", "GPIOB_6", + + "GPIOX_0", "GPIOX_1", "GPIOX_2", "GPIOX_3", "GPIOX_4", + "GPIOX_5", "GPIOX_6", "GPIOX_7", "GPIOX_8", "GPIOX_9", + "GPIOX_10", "GPIOX_11", "GPIOX_12", "GPIOX_13", "GPIOX_14", + "GPIOX_15", "GPIOX_16", + + "GPIOF_0", "GPIOF_1", "GPIOF_2", "GPIOF_3", "GPIOF_4", + "GPIOF_5", "GPIOF_6", "GPIOF_7", "GPIOF_8", "GPIOF_9", + "GPIOF_10", "GPIOF_11", "GPIOF_12", + + "GPIOA_0", "GPIOA_1", "GPIOA_2", "GPIOA_3", "GPIOA_4", + "GPIOA_5", "GPIOA_6", "GPIOA_7", "GPIOA_8", "GPIOA_9", + "GPIOA_10", "GPIOA_11", +}; + +static const char * const psram_groups[] = { + "psram_clkn", "psram_clkp", "psram_ce_n", "psram_rst_n", "psram_adq0", + "psram_adq1", "psram_adq2", "psram_adq3", "psram_adq4", "psram_adq5", + "psram_adq6", "psram_adq7", "psram_dqs_dm", +}; + +static const char * const pwm_a_groups[] = { + "pwm_a_x6", "pwm_a_x7", "pwm_a_f10", "pwm_a_f6", "pwm_a_a", +}; + +static const char * const pwm_b_groups[] = { + "pwm_b_x", "pwm_b_f", "pwm_b_a", +}; + +static const char * const pwm_c_groups[] = { + "pwm_c_x", "pwm_c_f3", "pwm_c_f8", "pwm_c_a", +}; + +static const char * const pwm_d_groups[] = { + "pwm_d_x15", "pwm_d_x13", "pwm_d_x10", "pwm_d_f", +}; + +static const char * const pwm_e_groups[] = { + "pwm_e_p", "pwm_e_x16", "pwm_e_x14", "pwm_e_x2", "pwm_e_f", + "pwm_e_a", +}; + +static const char * const pwm_f_groups[] = { + "pwm_f_b", "pwm_f_x", "pwm_f_f4", "pwm_f_f12", +}; + +static const char * const pwm_a_hiz_groups[] = { + "pwm_a_hiz_f8", "pwm_a_hiz_f10", "pwm_a_hiz_f6", +}; + +static const char * const pwm_b_hiz_groups[] = { + "pwm_b_hiz", +}; + +static const char * const pwm_c_hiz_groups[] = { + "pwm_c_hiz", +}; + +static const char * const spif_groups[] = { + "spif_mo", "spif_mi", "spif_wp_n", "spif_hold_n", "spif_clk", + "spif_cs", +}; + +static const char * const sdcard_groups[] = { + "sdcard_d0_b", "sdcard_d1_b", "sdcard_d2_b", "sdcard_d3_b", + "sdcard_clk_b", "sdcard_cmd_b", + + "sdcard_d0_x", "sdcard_d1_x", "sdcard_d2_x", "sdcard_d3_x", + "sdcard_clk_x", "sdcard_cmd_x", +}; + +static const char * const tdm_a_groups[] = { + "tdm_a_din0", "tdm_a_din1", "tdm_a_fs", "tdm_a_sclk", + "tdm_a_slv_fs", "tdm_a_slv_sclk", "tdm_a_dout0", "tdm_a_dout1", +}; + +static const char * const uart_a_groups[] = { + "uart_a_tx", "uart_a_rx", "uart_a_cts", "uart_a_rts", +}; + +static const char * const uart_b_groups[] = { + "uart_b_tx_x", "uart_b_rx_x", "uart_b_tx_f", "uart_b_rx_f", +}; + +static const char * const uart_c_groups[] = { + "uart_c_tx_x0", "uart_c_rx_x1", "uart_c_cts", "uart_c_rts", + "uart_c_tx_x15", "uart_c_rx_x16", +}; + +static const char * const i2c0_groups[] = { + "i2c0_sck_f11", "i2c0_sda_f12", "i2c0_sck_f9", "i2c0_sda_f10", +}; + +static const char * const i2c1_groups[] = { + "i2c1_sda_x", "i2c1_sck_x", "i2c1_sda_a", "i2c1_sck_a", +}; + +static const char * const i2c2_groups[] = { + "i2c2_sck_x0", "i2c2_sda_x1", "i2c2_sck_x15", "i2c2_sda_x16", + "i2c2_sck_a4", "i2c2_sda_a5", "i2c2_sck_a8", "i2c2_sda_a9", +}; + +static const char * const i2c3_groups[] = { + "i2c3_sck_x", "i2c3_sda_x", "i2c3_sck_f", "i2c3_sda_f", +}; + +static const char * const spi_a_groups[] = { + "spi_a_mosi_x2", "spi_a_ss0_x3", "spi_a_sclk_x4", "spi_a_miso_x5", + "spi_a_mosi_x7", "spi_a_miso_x8", "spi_a_ss0_x9", "spi_a_sclk_x10", + + "spi_a_mosi_a", "spi_a_miso_a", "spi_a_ss0_a", "spi_a_sclk_a", +}; + +static const char * const pdm_groups[] = { + "pdm_din0_x", "pdm_din1_x", "pdm_din2_x", "pdm_dclk_x", "pdm_din2_a", + "pdm_din1_a", "pdm_din0_a", "pdm_dclk", +}; + +static const char * const gen_clk_groups[] = { + "gen_clk_x", "gen_clk_f8", "gen_clk_f10", "gen_clk_a", +}; + +static const char * const remote_input_groups[] = { + "remote_input_f", + "remote_input_a", +}; + +static const char * const jtag_a_groups[] = { + "jtag_a_clk", "jtag_a_tms", "jtag_a_tdi", "jtag_a_tdo", +}; + +static const char * const clk_32k_in_groups[] = { + "clk_32k_in", +}; + +static const char * const remote_out_groups[] = { + "remote_out", +}; + +static const char * const spdif_in_groups[] = { + "spdif_in_f6", "spdif_in_f7", +}; + +static const char * const sw_groups[] = { + "swclk", "swdio", +}; + +static const char * const clk25_groups[] = { + "clk_25", +}; + +static const char * const cec_a_groups[] = { + "cec_a", +}; + +static const char * const cec_b_groups[] = { + "cec_b", +}; + +static const char * const clk12_24_groups[] = { + "clk12_24", +}; + +static const char * const mclk_0_groups[] = { + "mclk_0", +}; + +static const char * const tdm_b_groups[] = { + "tdm_b_din0", "tdm_b_din1", "tdm_b_din2", + "tdm_b_sclk", "tdm_b_fs", "tdm_b_dout0", "tdm_b_dout1", + "tdm_b_dout2", "tdm_b_dout3", "tdm_b_dout4", "tdm_b_dout5", + "tdm_b_slv_sclk", "tdm_b_slv_fs", +}; + +static const char * const mclk_vad_groups[] = { + "mclk_vad", +}; + +static const char * const tdm_vad_groups[] = { + "tdm_vad_sclk_a1", "tdm_vad_fs_a2", "tdm_vad_sclk_a5", "tdm_vad_fs_a6", +}; + +static const char * const tst_out_groups[] = { + "tst_out0", "tst_out1", "tst_out2", "tst_out3", + "tst_out4", "tst_out5", "tst_out6", "tst_out7", + "tst_out8", "tst_out9", "tst_out10", "tst_out11", +}; + +static const char * const mute_groups[] = { + "mute_key", "mute_en", +}; + +static struct meson_pmx_func meson_a1_periphs_functions[] = { + FUNCTION(gpio_periphs), + FUNCTION(psram), + FUNCTION(pwm_a), + FUNCTION(pwm_b), + FUNCTION(pwm_c), + FUNCTION(pwm_d), + FUNCTION(pwm_e), + FUNCTION(pwm_f), + FUNCTION(pwm_a_hiz), + FUNCTION(pwm_b_hiz), + FUNCTION(pwm_c_hiz), + FUNCTION(spif), + FUNCTION(sdcard), + FUNCTION(tdm_a), + FUNCTION(uart_a), + FUNCTION(uart_b), + FUNCTION(uart_c), + FUNCTION(i2c0), + FUNCTION(i2c1), + FUNCTION(i2c2), + FUNCTION(i2c3), + FUNCTION(spi_a), + FUNCTION(pdm), + FUNCTION(gen_clk), + FUNCTION(remote_input), + FUNCTION(jtag_a), + FUNCTION(clk_32k_in), + FUNCTION(remote_out), + FUNCTION(spdif_in), + FUNCTION(sw), + FUNCTION(clk25), + FUNCTION(cec_a), + FUNCTION(cec_b), + FUNCTION(clk12_24), + FUNCTION(mclk_0), + FUNCTION(tdm_b), + FUNCTION(mclk_vad), + FUNCTION(tdm_vad), + FUNCTION(tst_out), + FUNCTION(mute), +}; + +static struct meson_bank meson_a1_periphs_banks[] = { + /* name first last pullen pull dir out in ds */ + BANK_DS("P", GPIOP_0, GPIOP_12, 0x3, 0, 0x4, 0, 0x2, 0, 0x1, 0, 0x0, 0, 0x5, 0), + BANK_DS("B", GPIOB_0, GPIOB_6, 0x13, 0, 0x14, 0, 0x12, 0, 0x11, 0, 0x10, 0, 0x15, 0), + BANK_DS("X", GPIOX_0, GPIOX_16, 0x23, 0, 0x24, 0, 0x22, 0, 0x21, 0, 0x20, 0, 0x25, 0), + BANK_DS("F", GPIOF_0, GPIOF_12, 0x33, 0, 0x34, 0, 0x32, 0, 0x31, 0, 0x30, 0, 0x35, 0), + BANK_DS("A", GPIOA_0, GPIOA_11, 0x43, 0, 0x44, 0, 0x42, 0, 0x41, 0, 0x40, 0, 0x45, 0), +}; + +static struct meson_pmx_bank meson_a1_periphs_pmx_banks[] = { + /* name first last reg offset */ + BANK_PMX("P", GPIOP_0, GPIOP_12, 0x0, 0), + BANK_PMX("B", GPIOB_0, GPIOB_6, 0x2, 0), + BANK_PMX("X", GPIOX_0, GPIOX_16, 0x3, 0), + BANK_PMX("F", GPIOF_0, GPIOF_12, 0x6, 0), + BANK_PMX("A", GPIOA_0, GPIOA_11, 0x8, 0), +}; + +static struct meson_axg_pmx_data meson_a1_periphs_pmx_banks_data = { + .pmx_banks = meson_a1_periphs_pmx_banks, + .num_pmx_banks = ARRAY_SIZE(meson_a1_periphs_pmx_banks), +}; + +static struct meson_pinctrl_data meson_a1_periphs_pinctrl_data = { + .name = "periphs-banks", + .groups = meson_a1_periphs_groups, + .funcs = meson_a1_periphs_functions, + .banks = meson_a1_periphs_banks, + .num_pins = 62, + .num_groups = ARRAY_SIZE(meson_a1_periphs_groups), + .num_funcs = ARRAY_SIZE(meson_a1_periphs_functions), + .num_banks = ARRAY_SIZE(meson_a1_periphs_banks), + .pmx_data = &meson_a1_periphs_pmx_banks_data, +}; + +static const struct udevice_id meson_a1_pinctrl_match[] = { + { + .compatible = "amlogic,meson-a1-periphs-pinctrl", + .data = (ulong)&meson_a1_periphs_pinctrl_data, + }, + { }, +}; + +U_BOOT_DRIVER(meson_a1_pinctrl) = { + .name = "meson-a1-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = of_match_ptr(meson_a1_pinctrl_match), + .probe = meson_pinctrl_probe, + .priv_auto = sizeof(struct meson_pinctrl), + .ops = &meson_axg_pinctrl_ops, +};
- bool "Amlogic Meson A1 SoC pinctrl driver"
- select PINCTRL_MESON_AXG_PMX
- endif
- Copyright (C) 2023 SberDevices, Inc.
- GPIO_GROUP(GPIOP_0, 0),
- GPIO_GROUP(GPIOP_1, 0),
- GPIO_GROUP(GPIOP_2, 0),
- GPIO_GROUP(GPIOP_3, 0),
- GPIO_GROUP(GPIOP_4, 0),
- GPIO_GROUP(GPIOP_5, 0),
- GPIO_GROUP(GPIOP_6, 0),
- GPIO_GROUP(GPIOP_7, 0),
- GPIO_GROUP(GPIOP_8, 0),
- GPIO_GROUP(GPIOP_9, 0),
- GPIO_GROUP(GPIOP_10, 0),
- GPIO_GROUP(GPIOP_11, 0),
- GPIO_GROUP(GPIOP_12, 0),
- GPIO_GROUP(GPIOB_0, 0),
- GPIO_GROUP(GPIOB_1, 0),
- GPIO_GROUP(GPIOB_2, 0),
- GPIO_GROUP(GPIOB_3, 0),
- GPIO_GROUP(GPIOB_4, 0),
- GPIO_GROUP(GPIOB_5, 0),
- GPIO_GROUP(GPIOB_6, 0),
- GPIO_GROUP(GPIOX_0, 0),
- GPIO_GROUP(GPIOX_1, 0),
- GPIO_GROUP(GPIOX_2, 0),
- GPIO_GROUP(GPIOX_3, 0),
- GPIO_GROUP(GPIOX_4, 0),
- GPIO_GROUP(GPIOX_5, 0),
- GPIO_GROUP(GPIOX_6, 0),
- GPIO_GROUP(GPIOX_7, 0),
- GPIO_GROUP(GPIOX_8, 0),
- GPIO_GROUP(GPIOX_9, 0),
- GPIO_GROUP(GPIOX_10, 0),
- GPIO_GROUP(GPIOX_11, 0),
- GPIO_GROUP(GPIOX_12, 0),
- GPIO_GROUP(GPIOX_13, 0),
- GPIO_GROUP(GPIOX_14, 0),
- GPIO_GROUP(GPIOX_15, 0),
- GPIO_GROUP(GPIOX_16, 0),
- GPIO_GROUP(GPIOF_0, 0),
- GPIO_GROUP(GPIOF_1, 0),
- GPIO_GROUP(GPIOF_2, 0),
- GPIO_GROUP(GPIOF_3, 0),
- GPIO_GROUP(GPIOF_4, 0),
- GPIO_GROUP(GPIOF_5, 0),
- GPIO_GROUP(GPIOF_6, 0),
- GPIO_GROUP(GPIOF_7, 0),
- GPIO_GROUP(GPIOF_8, 0),
- GPIO_GROUP(GPIOF_9, 0),
- GPIO_GROUP(GPIOF_10, 0),
- GPIO_GROUP(GPIOF_11, 0),
- GPIO_GROUP(GPIOF_12, 0),
- GPIO_GROUP(GPIOA_0, 0),
- GPIO_GROUP(GPIOA_1, 0),
- GPIO_GROUP(GPIOA_2, 0),
- GPIO_GROUP(GPIOA_3, 0),
- GPIO_GROUP(GPIOA_4, 0),
- GPIO_GROUP(GPIOA_5, 0),
- GPIO_GROUP(GPIOA_6, 0),
- GPIO_GROUP(GPIOA_7, 0),
- GPIO_GROUP(GPIOA_8, 0),
- GPIO_GROUP(GPIOA_9, 0),
- GPIO_GROUP(GPIOA_10, 0),
- GPIO_GROUP(GPIOA_11, 0),
- /* bank P func1 */
- GROUP(psram_clkn, 1),
- GROUP(psram_clkp, 1),
- GROUP(psram_ce_n, 1),
- GROUP(psram_rst_n, 1),
- GROUP(psram_adq0, 1),
- GROUP(psram_adq1, 1),
- GROUP(psram_adq2, 1),
- GROUP(psram_adq3, 1),
- GROUP(psram_adq4, 1),
- GROUP(psram_adq5, 1),
- GROUP(psram_adq6, 1),
- GROUP(psram_adq7, 1),
- GROUP(psram_dqs_dm, 1),
- /* bank P func2 */
- GROUP(pwm_e_p, 2),
- /* bank B func1 */
- GROUP(spif_mo, 1),
- GROUP(spif_mi, 1),
- GROUP(spif_wp_n, 1),
- GROUP(spif_hold_n, 1),
- GROUP(spif_clk, 1),
- GROUP(spif_cs, 1),
- GROUP(pwm_f_b, 1),
- /* bank B func2 */
- GROUP(sdcard_d0_b, 2),
- GROUP(sdcard_d1_b, 2),
- GROUP(sdcard_d2_b, 2),
- GROUP(sdcard_d3_b, 2),
- GROUP(sdcard_clk_b, 2),
- GROUP(sdcard_cmd_b, 2),
- /* bank X func1 */
- GROUP(sdcard_d0_x, 1),
- GROUP(sdcard_d1_x, 1),
- GROUP(sdcard_d2_x, 1),
- GROUP(sdcard_d3_x, 1),
- GROUP(sdcard_clk_x, 1),
- GROUP(sdcard_cmd_x, 1),
- GROUP(pwm_a_x6, 1),
- GROUP(tdm_a_dout1, 1),
- GROUP(tdm_a_dout0, 1),
- GROUP(tdm_a_fs, 1),
- GROUP(tdm_a_sclk, 1),
- GROUP(uart_a_tx, 1),
- GROUP(uart_a_rx, 1),
- GROUP(uart_a_cts, 1),
- GROUP(uart_a_rts, 1),
- GROUP(pwm_d_x15, 1),
- GROUP(pwm_e_x16, 1),
- /* bank X func2 */
- GROUP(i2c2_sck_x0, 2),
- GROUP(i2c2_sda_x1, 2),
- GROUP(spi_a_mosi_x2, 2),
- GROUP(spi_a_ss0_x3, 2),
- GROUP(spi_a_sclk_x4, 2),
- GROUP(spi_a_miso_x5, 2),
- GROUP(tdm_a_din1, 2),
- GROUP(tdm_a_din0, 2),
- GROUP(tdm_a_slv_fs, 2),
- GROUP(tdm_a_slv_sclk, 2),
- GROUP(i2c3_sck_x, 2),
- GROUP(i2c3_sda_x, 2),
- GROUP(pwm_d_x13, 2),
- GROUP(pwm_e_x14, 2),
- GROUP(i2c2_sck_x15, 2),
- GROUP(i2c2_sda_x16, 2),
- /* bank X func3 */
- GROUP(uart_c_tx_x0, 3),
- GROUP(uart_c_rx_x1, 3),
- GROUP(uart_c_cts, 3),
- GROUP(uart_c_rts, 3),
- GROUP(pdm_din0_x, 3),
- GROUP(pdm_din1_x, 3),
- GROUP(pdm_din2_x, 3),
- GROUP(pdm_dclk_x, 3),
- GROUP(uart_c_tx_x15, 3),
- GROUP(uart_c_rx_x16, 3),
- /* bank X func4 */
- GROUP(pwm_e_x2, 4),
- GROUP(pwm_f_x, 4),
- GROUP(spi_a_mosi_x7, 4),
- GROUP(spi_a_miso_x8, 4),
- GROUP(spi_a_ss0_x9, 4),
- GROUP(spi_a_sclk_x10, 4),
- /* bank X func5 */
- GROUP(uart_b_tx_x, 5),
- GROUP(uart_b_rx_x, 5),
- GROUP(i2c1_sda_x, 5),
- GROUP(i2c1_sck_x, 5),
- /* bank X func6 */
- GROUP(pwm_a_x7, 6),
- GROUP(pwm_b_x, 6),
- GROUP(pwm_c_x, 6),
- GROUP(pwm_d_x10, 6),
- /* bank X func7 */
- GROUP(gen_clk_x, 7),
- /* bank F func1 */
- GROUP(uart_b_tx_f, 1),
- GROUP(uart_b_rx_f, 1),
- GROUP(remote_input_f, 1),
- GROUP(jtag_a_clk, 1),
- GROUP(jtag_a_tms, 1),
- GROUP(jtag_a_tdi, 1),
- GROUP(jtag_a_tdo, 1),
- GROUP(gen_clk_f8, 1),
- GROUP(pwm_a_f10, 1),
- GROUP(i2c0_sck_f11, 1),
- GROUP(i2c0_sda_f12, 1),
- /* bank F func2 */
- GROUP(clk_32k_in, 2),
- GROUP(pwm_e_f, 2),
- GROUP(pwm_f_f4, 2),
- GROUP(remote_out, 2),
- GROUP(spdif_in_f6, 2),
- GROUP(spdif_in_f7, 2),
- GROUP(pwm_a_hiz_f8, 2),
- GROUP(pwm_a_hiz_f10, 2),
- GROUP(pwm_d_f, 2),
- GROUP(pwm_f_f12, 2),
- /* bank F func3 */
- GROUP(pwm_c_f3, 3),
- GROUP(swclk, 3),
- GROUP(swdio, 3),
- GROUP(pwm_a_f6, 3),
- GROUP(pwm_b_f, 3),
- GROUP(pwm_c_f8, 3),
- GROUP(clk25, 3),
- GROUP(i2c_slave_sck_f, 3),
- GROUP(i2c_slave_sda_f, 3),
- /* bank F func4 */
- GROUP(cec_a, 4),
- GROUP(i2c3_sck_f, 4),
- GROUP(i2c3_sda_f, 4),
- GROUP(pmw_a_hiz_f6, 4),
- GROUP(pwm_b_hiz, 4),
- GROUP(pwm_c_hiz, 4),
- GROUP(i2c0_sck_f9, 4),
- GROUP(i2c0_sda_f10, 4),
- /* bank F func5 */
- GROUP(cec_b, 5),
- GROUP(clk12_24, 5),
- /* bank F func7 */
- GROUP(gen_clk_f10, 7),
- /* bank A func1 */
- GROUP(mclk_0, 1),
- GROUP(tdm_b_sclk, 1),
- GROUP(tdm_b_fs, 1),
- GROUP(tdm_b_dout0, 1),
- GROUP(tdm_b_dout1, 1),
- GROUP(tdm_b_dout2, 1),
- GROUP(tdm_b_dout3, 1),
- GROUP(tdm_b_dout4, 1),
- GROUP(tdm_b_dout5, 1),
- GROUP(remote_input_a, 1),
- /* bank A func2 */
- GROUP(pwm_e_a, 2),
- GROUP(tdm_b_slv_sclk, 2),
- GROUP(tdm_b_slv_fs, 2),
- GROUP(tdm_b_din0, 2),
- GROUP(tdm_b_din1, 2),
- GROUP(tdm_b_din2, 2),
- GROUP(i2c1_sda_a, 2),
- GROUP(i2c1_sck_a, 2),
- /* bank A func3 */
- GROUP(i2c2_sck_a4, 3),
- GROUP(i2c2_sda_a5, 3),
- GROUP(pdm_din2_a, 3),
- GROUP(pdm_din1_a, 3),
- GROUP(pdm_din0_a, 3),
- GROUP(pdm_dclk, 3),
- GROUP(pwm_c_a, 3),
- GROUP(pwm_b_a, 3),
- /* bank A func4 */
- GROUP(pwm_a_a, 4),
- GROUP(spi_a_mosi_a, 4),
- GROUP(spi_a_miso_a, 4),
- GROUP(spi_a_ss0_a, 4),
- GROUP(spi_a_sclk_a, 4),
- GROUP(i2c_slave_sck_a, 4),
- GROUP(i2c_slave_sda_a, 4),
- /* bank A func5 */
- GROUP(mclk_vad, 5),
- GROUP(tdm_vad_sclk_a1, 5),
- GROUP(tdm_vad_fs_a2, 5),
- GROUP(tdm_vad_sclk_a5, 5),
- GROUP(tdm_vad_fs_a6, 5),
- GROUP(i2c2_sck_a8, 5),
- GROUP(i2c2_sda_a9, 5),
- /* bank A func6 */
- GROUP(tst_out0, 6),
- GROUP(tst_out1, 6),
- GROUP(tst_out2, 6),
- GROUP(tst_out3, 6),
- GROUP(tst_out4, 6),
- GROUP(tst_out5, 6),
- GROUP(tst_out6, 6),
- GROUP(tst_out7, 6),
- GROUP(tst_out8, 6),
- GROUP(tst_out9, 6),
- GROUP(tst_out10, 6),
- GROUP(tst_out11, 6),
- /* bank A func7 */
- GROUP(mute_key, 7),
- GROUP(mute_en, 7),
- GROUP(gen_clk_a, 7),
- "GPIOP_0", "GPIOP_1", "GPIOP_2", "GPIOP_3", "GPIOP_4",
- "GPIOP_5", "GPIOP_6", "GPIOP_7", "GPIOP_8", "GPIOP_9",
- "GPIOP_10", "GPIOP_11", "GPIOP_12",
- "GPIOB_0", "GPIOB_1", "GPIOB_2", "GPIOB_3", "GPIOB_4",
- "GPIOB_5", "GPIOB_6",
- "GPIOX_0", "GPIOX_1", "GPIOX_2", "GPIOX_3", "GPIOX_4",
- "GPIOX_5", "GPIOX_6", "GPIOX_7", "GPIOX_8", "GPIOX_9",
- "GPIOX_10", "GPIOX_11", "GPIOX_12", "GPIOX_13", "GPIOX_14",
- "GPIOX_15", "GPIOX_16",
- "GPIOF_0", "GPIOF_1", "GPIOF_2", "GPIOF_3", "GPIOF_4",
- "GPIOF_5", "GPIOF_6", "GPIOF_7", "GPIOF_8", "GPIOF_9",
- "GPIOF_10", "GPIOF_11", "GPIOF_12",
- "GPIOA_0", "GPIOA_1", "GPIOA_2", "GPIOA_3", "GPIOA_4",
- "GPIOA_5", "GPIOA_6", "GPIOA_7", "GPIOA_8", "GPIOA_9",
- "GPIOA_10", "GPIOA_11",
- "psram_clkn", "psram_clkp", "psram_ce_n", "psram_rst_n", "psram_adq0",
- "psram_adq1", "psram_adq2", "psram_adq3", "psram_adq4", "psram_adq5",
- "psram_adq6", "psram_adq7", "psram_dqs_dm",
- "pwm_a_x6", "pwm_a_x7", "pwm_a_f10", "pwm_a_f6", "pwm_a_a",
- "pwm_b_x", "pwm_b_f", "pwm_b_a",
- "pwm_c_x", "pwm_c_f3", "pwm_c_f8", "pwm_c_a",
- "pwm_d_x15", "pwm_d_x13", "pwm_d_x10", "pwm_d_f",
- "pwm_e_p", "pwm_e_x16", "pwm_e_x14", "pwm_e_x2", "pwm_e_f",
- "pwm_e_a",
- "pwm_f_b", "pwm_f_x", "pwm_f_f4", "pwm_f_f12",
- "pwm_a_hiz_f8", "pwm_a_hiz_f10", "pwm_a_hiz_f6",
- "pwm_b_hiz",
- "pwm_c_hiz",
- "spif_mo", "spif_mi", "spif_wp_n", "spif_hold_n", "spif_clk",
- "spif_cs",
- "sdcard_d0_b", "sdcard_d1_b", "sdcard_d2_b", "sdcard_d3_b",
- "sdcard_clk_b", "sdcard_cmd_b",
- "sdcard_d0_x", "sdcard_d1_x", "sdcard_d2_x", "sdcard_d3_x",
- "sdcard_clk_x", "sdcard_cmd_x",
- "tdm_a_din0", "tdm_a_din1", "tdm_a_fs", "tdm_a_sclk",
- "tdm_a_slv_fs", "tdm_a_slv_sclk", "tdm_a_dout0", "tdm_a_dout1",
- "uart_a_tx", "uart_a_rx", "uart_a_cts", "uart_a_rts",
- "uart_b_tx_x", "uart_b_rx_x", "uart_b_tx_f", "uart_b_rx_f",
- "uart_c_tx_x0", "uart_c_rx_x1", "uart_c_cts", "uart_c_rts",
- "uart_c_tx_x15", "uart_c_rx_x16",
- "i2c0_sck_f11", "i2c0_sda_f12", "i2c0_sck_f9", "i2c0_sda_f10",
- "i2c1_sda_x", "i2c1_sck_x", "i2c1_sda_a", "i2c1_sck_a",
- "i2c2_sck_x0", "i2c2_sda_x1", "i2c2_sck_x15", "i2c2_sda_x16",
- "i2c2_sck_a4", "i2c2_sda_a5", "i2c2_sck_a8", "i2c2_sda_a9",
- "i2c3_sck_x", "i2c3_sda_x", "i2c3_sck_f", "i2c3_sda_f",
- "spi_a_mosi_x2", "spi_a_ss0_x3", "spi_a_sclk_x4", "spi_a_miso_x5",
- "spi_a_mosi_x7", "spi_a_miso_x8", "spi_a_ss0_x9", "spi_a_sclk_x10",
- "spi_a_mosi_a", "spi_a_miso_a", "spi_a_ss0_a", "spi_a_sclk_a",
- "pdm_din0_x", "pdm_din1_x", "pdm_din2_x", "pdm_dclk_x", "pdm_din2_a",
- "pdm_din1_a", "pdm_din0_a", "pdm_dclk",
- "gen_clk_x", "gen_clk_f8", "gen_clk_f10", "gen_clk_a",
- "remote_input_f",
- "remote_input_a",
- "jtag_a_clk", "jtag_a_tms", "jtag_a_tdi", "jtag_a_tdo",
- "clk_32k_in",
- "remote_out",
- "spdif_in_f6", "spdif_in_f7",
- "swclk", "swdio",
- "clk_25",
- "cec_a",
- "cec_b",
- "clk12_24",
- "mclk_0",
- "tdm_b_din0", "tdm_b_din1", "tdm_b_din2",
- "tdm_b_sclk", "tdm_b_fs", "tdm_b_dout0", "tdm_b_dout1",
- "tdm_b_dout2", "tdm_b_dout3", "tdm_b_dout4", "tdm_b_dout5",
- "tdm_b_slv_sclk", "tdm_b_slv_fs",
- "mclk_vad",
- "tdm_vad_sclk_a1", "tdm_vad_fs_a2", "tdm_vad_sclk_a5", "tdm_vad_fs_a6",
- "tst_out0", "tst_out1", "tst_out2", "tst_out3",
- "tst_out4", "tst_out5", "tst_out6", "tst_out7",
- "tst_out8", "tst_out9", "tst_out10", "tst_out11",
- "mute_key", "mute_en",
- FUNCTION(gpio_periphs),
- FUNCTION(psram),
- FUNCTION(pwm_a),
- FUNCTION(pwm_b),
- FUNCTION(pwm_c),
- FUNCTION(pwm_d),
- FUNCTION(pwm_e),
- FUNCTION(pwm_f),
- FUNCTION(pwm_a_hiz),
- FUNCTION(pwm_b_hiz),
- FUNCTION(pwm_c_hiz),
- FUNCTION(spif),
- FUNCTION(sdcard),
- FUNCTION(tdm_a),
- FUNCTION(uart_a),
- FUNCTION(uart_b),
- FUNCTION(uart_c),
- FUNCTION(i2c0),
- FUNCTION(i2c1),
- FUNCTION(i2c2),
- FUNCTION(i2c3),
- FUNCTION(spi_a),
- FUNCTION(pdm),
- FUNCTION(gen_clk),
- FUNCTION(remote_input),
- FUNCTION(jtag_a),
- FUNCTION(clk_32k_in),
- FUNCTION(remote_out),
- FUNCTION(spdif_in),
- FUNCTION(sw),
- FUNCTION(clk25),
- FUNCTION(cec_a),
- FUNCTION(cec_b),
- FUNCTION(clk12_24),
- FUNCTION(mclk_0),
- FUNCTION(tdm_b),
- FUNCTION(mclk_vad),
- FUNCTION(tdm_vad),
- FUNCTION(tst_out),
- FUNCTION(mute),
- /* name first last pullen pull dir out in ds */
- BANK_DS("P", GPIOP_0, GPIOP_12, 0x3, 0, 0x4, 0, 0x2, 0, 0x1, 0, 0x0, 0, 0x5, 0),
- BANK_DS("B", GPIOB_0, GPIOB_6, 0x13, 0, 0x14, 0, 0x12, 0, 0x11, 0, 0x10, 0, 0x15, 0),
- BANK_DS("X", GPIOX_0, GPIOX_16, 0x23, 0, 0x24, 0, 0x22, 0, 0x21, 0, 0x20, 0, 0x25, 0),
- BANK_DS("F", GPIOF_0, GPIOF_12, 0x33, 0, 0x34, 0, 0x32, 0, 0x31, 0, 0x30, 0, 0x35, 0),
- BANK_DS("A", GPIOA_0, GPIOA_11, 0x43, 0, 0x44, 0, 0x42, 0, 0x41, 0, 0x40, 0, 0x45, 0),
- /* name first last reg offset */
- BANK_PMX("P", GPIOP_0, GPIOP_12, 0x0, 0),
- BANK_PMX("B", GPIOB_0, GPIOB_6, 0x2, 0),
- BANK_PMX("X", GPIOX_0, GPIOX_16, 0x3, 0),
- BANK_PMX("F", GPIOF_0, GPIOF_12, 0x6, 0),
- BANK_PMX("A", GPIOA_0, GPIOA_11, 0x8, 0),
- .pmx_banks = meson_a1_periphs_pmx_banks,
- .num_pmx_banks = ARRAY_SIZE(meson_a1_periphs_pmx_banks),
- .name = "periphs-banks",
- .groups = meson_a1_periphs_groups,
- .funcs = meson_a1_periphs_functions,
- .banks = meson_a1_periphs_banks,
- .num_pins = 62,
- .num_groups = ARRAY_SIZE(meson_a1_periphs_groups),
- .num_funcs = ARRAY_SIZE(meson_a1_periphs_functions),
- .num_banks = ARRAY_SIZE(meson_a1_periphs_banks),
- .pmx_data = &meson_a1_periphs_pmx_banks_data,
- .name = "meson-a1-pinctrl",
- .id = UCLASS_PINCTRL,
- .of_match = of_match_ptr(meson_a1_pinctrl_match),
- .probe = meson_pinctrl_probe,
- .priv_auto = sizeof(struct meson_pinctrl),
- .ops = &meson_axg_pinctrl_ops,
The AD401 board is the Amlogic A1 SoC reference board
Signed-off-by: Igor Prusov ivprusov@sberdevices.ru --- MAINTAINERS | 1 + arch/arm/mach-meson/Kconfig | 1 + board/amlogic/ad401/Makefile | 4 +++ board/amlogic/ad401/ad401.c | 15 ++++++++++ configs/ad401_defconfig | 54 ++++++++++++++++++++++++++++++++++++ 5 files changed, 75 insertions(+) create mode 100644 board/amlogic/ad401/Makefile create mode 100644 board/amlogic/ad401/ad401.c create mode 100644 configs/ad401_defconfig
diff --git a/MAINTAINERS b/MAINTAINERS index 02a5a8682f..6860309896 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -150,6 +150,7 @@ L: u-boot-amlogic@groups.io T: git https://source.denx.de/u-boot/custodians/u-boot-amlogic.git F: arch/arm/mach-meson/ F: arch/arm/include/asm/arch-meson/ +F: board/amlogic/ F: cmd/meson/ F: drivers/clk/meson/ F: drivers/serial/serial_meson.c diff --git a/arch/arm/mach-meson/Kconfig b/arch/arm/mach-meson/Kconfig index 519ed563c0..669ca09a00 100644 --- a/arch/arm/mach-meson/Kconfig +++ b/arch/arm/mach-meson/Kconfig @@ -75,6 +75,7 @@ config SYS_VENDOR
config SYS_BOARD string "Board name" + default "ad401" if MESON_A1 default "p200" if MESON_GXBB default "p212" if MESON_GXL default "q200" if MESON_GXM diff --git a/board/amlogic/ad401/Makefile b/board/amlogic/ad401/Makefile new file mode 100644 index 0000000000..e65c1215f6 --- /dev/null +++ b/board/amlogic/ad401/Makefile @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0+ +# (C) Copyright 2023 SberDevices, Inc. + +obj-y := ad401.o diff --git a/board/amlogic/ad401/ad401.c b/board/amlogic/ad401/ad401.c new file mode 100644 index 0000000000..356b2880bd --- /dev/null +++ b/board/amlogic/ad401/ad401.c @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2023 SberDevices, Inc. + * Author: Igor Prusov ivprusov@sberdevices.ru + */ + +#include <init.h> +#include <asm/arch/eth.h> + +int misc_init_r(void) +{ + meson_generate_serial_ethaddr(); + + return 0; +} diff --git a/configs/ad401_defconfig b/configs/ad401_defconfig new file mode 100644 index 0000000000..529e553bac --- /dev/null +++ b/configs/ad401_defconfig @@ -0,0 +1,54 @@ +CONFIG_ARM=y +CONFIG_ARCH_MESON=y +CONFIG_TEXT_BASE=0x00000000 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x00200000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="meson-a1-ad401" +CONFIG_SYS_PROMPT="ad401 # " +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_MESON_A1=y +CONFIG_DEBUG_UART_BASE=0xfe001c00 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0x0 +CONFIG_DEBUG_UART=y +CONFIG_ANDROID_BOOT_IMAGE=y +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_BOOTCOMMAND="run storeboot" +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_UBI=y +CONFIG_OF_CONTROL=y +CONFIG_ADC=y +CONFIG_SARADC_MESON=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MESON=y +CONFIG_LED=y +CONFIG_MISC=y +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_A1=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_PWM=y +CONFIG_PWM_MESON=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_WDT=y
Boards MAINTAINERS are separate, so please add a separate MAINTAINERS file in board/amlogic/ad401/, you can add me ad maintainer like other boards.
- default "ad401" if MESON_A1 default "p200" if MESON_GXBB default "p212" if MESON_GXL default "q200" if MESON_GXM
- meson_generate_serial_ethaddr();
With MAINTAINERS file in board dir:
Igor Prusov
Neil Armstrong
