[U-Boot] [RESEND PATCH 1/7 v5] armv8: ls2080a: remove obsolete stream ID partitioning support
Remove stream ID partitioning support that has been made obsolete by upstream device tree bindings that specify how representing how PCI requester IDs are mapped to MSI specifiers and SMMU stream IDs.
Signed-off-by: Stuart Yoder stuart.yoder@nxp.com --- -v5: no change
arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 113 ------------------------------- drivers/pci/pcie_layerscape.c | 70 ------------------- 2 files changed, 183 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index 4e4861d..7a64f41 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -70,115 +70,6 @@ void ft_fixup_cpu(void *blob) } #endif
-/* - * the burden is on the the caller to not request a count - * exceeding the bounds of the stream_ids[] array - */ -void alloc_stream_ids(int start_id, int count, u32 *stream_ids, int max_cnt) -{ - int i; - - if (count > max_cnt) { - printf("\n%s: ERROR: max per-device stream ID count exceed\n", - __func__); - return; - } - - for (i = 0; i < count; i++) - stream_ids[i] = start_id++; -} - -/* - * This function updates the mmu-masters property on the SMMU - * node as per the SMMU binding-- phandle and list of stream IDs - * for each MMU master. - */ -void append_mmu_masters(void *blob, const char *smmu_path, - const char *master_name, u32 *stream_ids, int count) -{ - u32 phandle; - int smmu_nodeoffset; - int master_nodeoffset; - int i; - - /* get phandle of mmu master device */ - master_nodeoffset = fdt_path_offset(blob, master_name); - if (master_nodeoffset < 0) { - printf("\n%s: ERROR: master not found\n", __func__); - return; - } - phandle = fdt_get_phandle(blob, master_nodeoffset); - if (!phandle) { /* if master has no phandle, create one */ - phandle = fdt_create_phandle(blob, master_nodeoffset); - if (!phandle) { - printf("\n%s: ERROR: unable to create phandle\n", - __func__); - return; - } - } - - /* append it to mmu-masters */ - smmu_nodeoffset = fdt_path_offset(blob, smmu_path); - if (fdt_appendprop_u32(blob, smmu_nodeoffset, "mmu-masters", - phandle) < 0) { - printf("\n%s: ERROR: unable to update SMMU node\n", __func__); - return; - } - - /* for each stream ID, append to mmu-masters */ - for (i = 0; i < count; i++) { - fdt_appendprop_u32(blob, smmu_nodeoffset, "mmu-masters", - stream_ids[i]); - } - - /* fix up #stream-id-cells with stream ID count */ - if (fdt_setprop_u32(blob, master_nodeoffset, "#stream-id-cells", - count) < 0) - printf("\n%s: ERROR: unable to update #stream-id-cells\n", - __func__); -} - - -/* - * The info below summarizes how streamID partitioning works - * for ls2080a and how it is conveyed to the OS via the device tree. - * - * -non-PCI legacy, platform devices (USB, SD/MMC, SATA, DMA) - * -all legacy devices get a unique ICID assigned and programmed in - * their AMQR registers by u-boot - * -u-boot updates the hardware device tree with streamID properties - * for each platform/legacy device (smmu-masters property) - * - * -PCIe - * -for each PCI controller that is active (as per RCW settings), - * u-boot will allocate a range of ICID and convey that to Linux via - * the device tree (smmu-masters property) - * - * -DPAA2 - * -u-boot will allocate a range of ICIDs to be used by the Management - * Complex for containers and will set these values in the MC DPC image. - * -the MC is responsible for allocating and setting up ICIDs - * for all DPAA2 devices. - * - */ -#ifdef CONFIG_FSL_LSCH3 -static void fdt_fixup_smmu(void *blob) -{ - int nodeoffset; - - nodeoffset = fdt_path_offset(blob, "/iommu@5000000"); - if (nodeoffset < 0) { - printf("\n%s: WARNING: no SMMU node found\n", __func__); - return; - } - - /* fixup for all PCI controllers */ -#ifdef CONFIG_PCI - fdt_fixup_smmu_pcie(blob); -#endif -} -#endif - void ft_cpu_setup(void *blob, bd_t *bd) { #ifdef CONFIG_MP @@ -200,8 +91,4 @@ void ft_cpu_setup(void *blob, bd_t *bd) #ifdef CONFIG_FSL_ESDHC fdt_fixup_esdhc(blob, bd); #endif - -#ifdef CONFIG_FSL_LSCH3 - fdt_fixup_smmu(blob); -#endif } diff --git a/drivers/pci/pcie_layerscape.c b/drivers/pci/pcie_layerscape.c index 99f9c83..bb29222 100644 --- a/drivers/pci/pcie_layerscape.c +++ b/drivers/pci/pcie_layerscape.c @@ -664,73 +664,3 @@ void ft_pci_setup(void *blob, bd_t *bd) { } #endif - -#if defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) - -void pcie_set_available_streamids(void *blob, const char *pcie_path, - u32 *stream_ids, int count) -{ - int nodeoffset; - int i; - - nodeoffset = fdt_path_offset(blob, pcie_path); - if (nodeoffset < 0) { - printf("\n%s: ERROR: unable to update PCIe node\n", __func__); - return; - } - - /* for each stream ID, append to mmu-masters */ - for (i = 0; i < count; i++) { - fdt_appendprop_u32(blob, nodeoffset, "available-stream-ids", - stream_ids[i]); - } -} - -#define MAX_STREAM_IDS 4 -void fdt_fixup_smmu_pcie(void *blob) -{ - int count; - u32 stream_ids[MAX_STREAM_IDS]; - u32 ctlr_streamid = 0x300; - - #ifdef CONFIG_PCIE1 - /* PEX1 stream ID fixup */ - count = FSL_PEX1_STREAM_ID_END - FSL_PEX1_STREAM_ID_START + 1; - alloc_stream_ids(FSL_PEX1_STREAM_ID_START, count, stream_ids, - MAX_STREAM_IDS); - pcie_set_available_streamids(blob, "/pcie@3400000", stream_ids, count); - append_mmu_masters(blob, "/iommu@5000000", "/pcie@3400000", - &ctlr_streamid, 1); - #endif - - #ifdef CONFIG_PCIE2 - /* PEX2 stream ID fixup */ - count = FSL_PEX2_STREAM_ID_END - FSL_PEX2_STREAM_ID_START + 1; - alloc_stream_ids(FSL_PEX2_STREAM_ID_START, count, stream_ids, - MAX_STREAM_IDS); - pcie_set_available_streamids(blob, "/pcie@3500000", stream_ids, count); - append_mmu_masters(blob, "/iommu@5000000", "/pcie@3500000", - &ctlr_streamid, 1); - #endif - - #ifdef CONFIG_PCIE3 - /* PEX3 stream ID fixup */ - count = FSL_PEX3_STREAM_ID_END - FSL_PEX3_STREAM_ID_START + 1; - alloc_stream_ids(FSL_PEX3_STREAM_ID_START, count, stream_ids, - MAX_STREAM_IDS); - pcie_set_available_streamids(blob, "/pcie@3600000", stream_ids, count); - append_mmu_masters(blob, "/iommu@5000000", "/pcie@3600000", - &ctlr_streamid, 1); - #endif - - #ifdef CONFIG_PCIE4 - /* PEX4 stream ID fixup */ - count = FSL_PEX4_STREAM_ID_END - FSL_PEX4_STREAM_ID_START + 1; - alloc_stream_ids(FSL_PEX4_STREAM_ID_START, count, stream_ids, - MAX_STREAM_IDS); - pcie_set_available_streamids(blob, "/pcie@3700000", stream_ids, count); - append_mmu_masters(blob, "/iommu@5000000", "/pcie@3700000", - &ctlr_streamid, 1); - #endif -} -#endif
Stuart Yoder
