[PATCH] Fix BMP display when the image stretches beyond border
When an image stretches beyond the display border, one still needs to seek to the next pixel line to display the visible part of that image correctly.
Signed-off-by: Vitaly Wool vitaly.wool@konsulko.com --- drivers/video/video_bmp.c | 15 +++++++-------- 1 file changed, 7 insertions(+), 8 deletions(-)
diff --git a/drivers/video/video_bmp.c b/drivers/video/video_bmp.c index 4d2d961696..d0177daf58 100644 --- a/drivers/video/video_bmp.c +++ b/drivers/video/video_bmp.c @@ -238,7 +238,7 @@ int video_bmp_display(struct udevice *dev, ulong bmp_image, int x, int y, struct bmp_image *bmp = map_sysmem(bmp_image, 0); uchar *bmap; ushort padded_width; - unsigned long width, height, byte_width; + unsigned long width, vis_width, height, byte_width; unsigned long pwidth = priv->xsize; unsigned colours, bpix, bmp_bpix; enum video_format eformat; @@ -297,8 +297,7 @@ int video_bmp_display(struct udevice *dev, ulong bmp_image, int x, int y, video_splash_align_axis(&y, priv->ysize, height); }
- if ((x + width) > pwidth) - width = pwidth - x; + vis_width = min(pwidth - x, width); if ((y + height) > priv->ysize) height = priv->ysize - y;
@@ -318,7 +317,7 @@ int video_bmp_display(struct udevice *dev, ulong bmp_image, int x, int y, debug("compressed %d %d\n", compression, BMP_BI_RLE8); if (compression == BMP_BI_RLE8) { video_display_rle8_bitmap(dev, bmp, bpix, palette, fb, - x, y, width, height); + x, y, vis_width, height); break; } } @@ -330,7 +329,7 @@ int video_bmp_display(struct udevice *dev, ulong bmp_image, int x, int y,
for (i = 0; i < height; ++i) { WATCHDOG_RESET(); - for (j = 0; j < width; j++) { + for (j = 0; j < vis_width; j++) { write_pix8(fb, bpix, eformat, palette, bmap); bmap++; fb += bpix / 8; @@ -343,7 +342,7 @@ int video_bmp_display(struct udevice *dev, ulong bmp_image, int x, int y, if (IS_ENABLED(CONFIG_BMP_16BPP)) { for (i = 0; i < height; ++i) { WATCHDOG_RESET(); - for (j = 0; j < width; j++) { + for (j = 0; j < vis_width; j++) { *fb++ = *bmap++; *fb++ = *bmap++; } @@ -355,7 +354,7 @@ int video_bmp_display(struct udevice *dev, ulong bmp_image, int x, int y, case 24: if (IS_ENABLED(CONFIG_BMP_24BPP)) { for (i = 0; i < height; ++i) { - for (j = 0; j < width; j++) { + for (j = 0; j < vis_width; j++) { if (bpix == 16) { /* 16bit 565RGB format */ *(u16 *)fb = ((bmap[2] >> 3) @@ -389,7 +388,7 @@ int video_bmp_display(struct udevice *dev, ulong bmp_image, int x, int y, case 32: if (IS_ENABLED(CONFIG_BMP_32BPP)) { for (i = 0; i < height; ++i) { - for (j = 0; j < width; j++) { + for (j = 0; j < vis_width; j++) { if (eformat == VIDEO_X2R10G10B10) { u32 pix;
- unsigned long width, vis_width, height, byte_width; unsigned long pwidth = priv->xsize; unsigned colours, bpix, bmp_bpix; enum video_format eformat;
width = pwidth - x;
- vis_width = min(pwidth - x, width);
Where do we treat x > pwidth?
Or y > priv->ysize?
Best regards
Heinrich
}x, y, vis_width, height); break; }
Vitaly Wool
