[U-Boot] [PATCH] cmd: add clear screen 'cls' command
Add common clear screen command for configurations CONFIG_DM_VIDEO, CONFIG_LCD and CONFIG_CFB_CONSOLE.
Remove the existing cls command implementation from lcd.c code and activate the command for all boards enabling CONFIG_LCD for compatibility reasons.
Signed-off-by: Anatolij Gustschin agust@denx.de --- cmd/Kconfig | 7 ++++ cmd/Makefile | 1 + cmd/cls.c | 35 +++++++++++++++++++ common/lcd.c | 8 ----- configs/at91sam9261ek_dataflash_cs0_defconfig | 1 + configs/at91sam9261ek_dataflash_cs3_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_dataflash_cs0_defconfig | 1 + configs/at91sam9263ek_dataflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9263ek_norflash_boot_defconfig | 1 + configs/at91sam9263ek_norflash_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 1 + configs/at91sam9g10ek_nandflash_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9rlek_dataflash_defconfig | 1 + configs/at91sam9rlek_mmc_defconfig | 1 + configs/at91sam9rlek_nandflash_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/cm_t3517_defconfig | 1 + configs/cm_t35_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/picosam9g45_defconfig | 1 + configs/pm9261_defconfig | 1 + configs/pm9263_defconfig | 1 + configs/snow_defconfig | 1 + configs/spring_defconfig | 1 + configs/zipitz2_defconfig | 1 + 34 files changed, 73 insertions(+), 8 deletions(-) create mode 100644 cmd/cls.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index d609f9d1c9..6023867007 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1372,6 +1372,13 @@ config CMD_CONITRACE Enable the 'conitrace' command which displays the codes received from the console input as hexadecimal numbers.
+config CMD_CLS + bool "Enable clear screen command 'cls'" + depends on CFB_CONSOLE || DM_VIDEO || LCD || VIDEO + help + Enable the 'cls' command which clears the screen contents + on video frame buffer. + config CMD_DISPLAY bool "Enable the 'display' command, for character displays" help diff --git a/cmd/Makefile b/cmd/Makefile index 12a1330b06..2cb07df3c8 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -32,6 +32,7 @@ obj-$(CONFIG_CMD_BTRFS) += btrfs.o obj-$(CONFIG_CMD_CACHE) += cache.o obj-$(CONFIG_CMD_CBFS) += cbfs.o obj-$(CONFIG_CMD_CLK) += clk.o +obj-$(CONFIG_CMD_CLS) += cls.o obj-$(CONFIG_CMD_CONFIG) += config.o obj-$(CONFIG_CMD_CONITRACE) += conitrace.o obj-$(CONFIG_CMD_CONSOLE) += console.o diff --git a/cmd/cls.c b/cmd/cls.c new file mode 100644 index 0000000000..f1ce6e8df1 --- /dev/null +++ b/cmd/cls.c @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2018 + * DENX Software Engineering, Anatolij Gustschin agust@denx.de + * + * cls - clear screen command + */ +#include <common.h> +#include <command.h> +#include <dm.h> +#include <lcd.h> +#include <video.h> + +static int do_video_clear(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ +#if defined(CONFIG_DM_VIDEO) + struct udevice *dev; + + if (uclass_first_device_err(UCLASS_VIDEO, &dev)) + return CMD_RET_FAILURE; + + if (video_clear(dev)) + return CMD_RET_FAILURE; +#elif defined(CONFIG_CFB_CONSOLE) + video_clear(); +#elif defined(CONFIG_LCD) + lcd_clear(); +#else + return CMD_RET_FAILURE; +#endif + return CMD_RET_SUCCESS; +} + +U_BOOT_CMD(cls, 1, 1, do_video_clear, "clear screen", ""); diff --git a/common/lcd.c b/common/lcd.c index 2e2bef3848..74407a17e9 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -242,14 +242,6 @@ void lcd_clear(void) lcd_sync(); }
-static int do_lcd_clear(cmd_tbl_t *cmdtp, int flag, int argc, - char *const argv[]) -{ - lcd_clear(); - return 0; -} -U_BOOT_CMD(cls, 1, 1, do_lcd_clear, "clear screen", ""); - static int lcd_init(void *lcdbase) { debug("[LCD] Initializing LCD frambuffer at %p\n", lcdbase); diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 431cf280eb..3c73df88fd 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index e5efad80de..4360fa8158 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index f6f3288951..d557c933ab 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index a19f309c4a..898959a644 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -19,6 +19,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index a19f309c4a..898959a644 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -19,6 +19,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index 3ecb1b3726..1bd2570d84 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -19,6 +19,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index 556fc15418..f843739c5a 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -17,6 +17,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index 892f6af1b8..3109bcb737 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -17,6 +17,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index 7bf0b79e34..370a1cb1b5 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index b4e8892cca..0951a463c4 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index c88e55404e..e942eeaf6b 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index 7ef4843c72..cba9db2ff3 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -19,6 +19,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index f8101f5fd4..623d707a2d 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -19,6 +19,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index 6b2cfe9c42..02806f1ce7 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index 354c24ff16..8f7c295cdc 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index 63889355bf..7dfa1ccb8d 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index 800a92cf81..9c8e0be1c4 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -19,6 +19,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index dd5158a034..7f831f9ace 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -19,6 +19,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index 6b863d46da..fae77334d1 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -19,6 +19,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index c56a633292..6dd61a6ea0 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -27,6 +27,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_BOOTM is not set CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y # CONFIG_CMD_GO is not set # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/cm_t3517_defconfig b/configs/cm_t3517_defconfig index 0901fea638..3e4092536f 100644 --- a/configs/cm_t3517_defconfig +++ b/configs/cm_t3517_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T3517 # " CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y CONFIG_CMD_EEPROM=y CONFIG_CMD_EEPROM_LAYOUT=y CONFIG_EEPROM_LAYOUT_HELP_STRING="v1, v2, v3" diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index f1fe2d058d..c5c64a5631 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T3x # " CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y CONFIG_CMD_EEPROM=y CONFIG_CMD_EEPROM_LAYOUT=y CONFIG_EEPROM_LAYOUT_HELP_STRING="v1, v2, v3" diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 338eae20b4..b01635e89e 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -12,6 +12,7 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SYS_PROMPT="Peach-Pi # " +CONFIG_CMD_CLS=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index 933c823ea8..0951e90197 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -11,6 +11,7 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SYS_PROMPT="Peach-Pit # " +CONFIG_CMD_CLS=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index 0b6234fbd9..6255323e3f 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -24,6 +24,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index d2c4c25672..d5904428be 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -15,6 +15,7 @@ CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PROMPT="pm9261> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index ceb7efe503..4375b4ce7b 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -14,6 +14,7 @@ CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PROMPT="u-boot-pm9263> " # CONFIG_CMD_BDI is not set +CONFIG_CMD_CLS=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 21080091a7..9c055e9306 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SYS_PROMPT="snow # " +CONFIG_CMD_CLS=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index ca1799895e..ae49f67444 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SYS_PROMPT="spring # " +CONFIG_CMD_CLS=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y diff --git a/configs/zipitz2_defconfig b/configs/zipitz2_defconfig index 509adcffd9..142a61a8ab 100644 --- a/configs/zipitz2_defconfig +++ b/configs/zipitz2_defconfig @@ -10,6 +10,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PROMPT="$ " +CONFIG_CMD_CLS=y CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y
Hi Anatolij
From: Anatolij Gustschin agust@denx.de Sent: samedi 17 novembre 2018 15:30
+config CMD_CLS
- bool "Enable clear screen command 'cls'"
- depends on CFB_CONSOLE || DM_VIDEO || LCD || VIDEO
Just a minor remark, you can also add :
default y if !DM_VIDEO
To avoid the defconfig modifications in the patch. (lcd.o if compiled ifndef CONFIG_DM_VIDEO) / command previously always define in this case) But you prefer perhaps to have clear CONFIG_CMD configuration in each defconfig.
- help
But Ok for the rest. Tested on my board (stm32mp157_ev1 with DM_VIDEO activated)
Regards, Patrick.
Tested-by: Patrick.Delaunay patrick.delaunay@free.fr
Hi Patrick,
On Mon, 19 Nov 2018 18:09:12 +0000 Patrick DELAUNAY patrick.delaunay@st.com wrote: ...
+config CMD_CLS
There are also a few boards with DM_VIDEO and LCD both enabled:
$ git grep CONFIG_LCD `git grep DM_VIDEO=y configs/ | awk -F : '{print $1}'` configs/peach-pi_defconfig:CONFIG_LCD=y configs/peach-pit_defconfig:CONFIG_LCD=y configs/snow_defconfig:CONFIG_LCD=y configs/spring_defconfig:CONFIG_LCD=y
so using y if !DM_VIDEO would disable the command for them.
I'd like to reduce the defconfig size, so v2 patch uses "default y if LCD" to auto-select the command (compatibility for existing CONFIG_LCD users). For other configurations the command should be enabled in defconfig by users, when needed.
Regards, Patrick.
Thanks for testing it!
-- Anatolij
Anatolij Gustschin
Patrick DELAUNAY
