[U-Boot] [PATCH v1 0/5] board: toradex: add Colibri iMX6ULL support
This patchset adds Toradex Colibri iMX6ULL support. It makes use of the device tree support for the MXS NAND driver and hence depends on: https://patchwork.ozlabs.org/cover/897263/ https://patchwork.ozlabs.org/cover/901995/
-- Stefan
Stefan Agner (5): mtd: nand: mxs_nand: add device tree support for i.MX 6 imx: add macro to detect whether USB has been initialized ARM: dts: imx6ull: use same compatible string as Linux is using board: toradex: add new and upcoming SKUs board: toradex: add Colibri iMX6ULL support
arch/arm/dts/imx6ull-colibri.dts | 550 ++++++++++++++++++ arch/arm/dts/imx6ull.dtsi | 2 +- arch/arm/include/asm/arch-mx6/imx-regs.h | 7 + arch/arm/mach-imx/mx6/Kconfig | 8 + board/toradex/colibri-imx6ull/Kconfig | 29 + board/toradex/colibri-imx6ull/MAINTAINERS | 10 + board/toradex/colibri-imx6ull/Makefile | 4 + .../toradex/colibri-imx6ull/colibri-imx6ull.c | 408 +++++++++++++ board/toradex/colibri-imx6ull/imximage.cfg | 106 ++++ board/toradex/common/tdx-cfg-block.c | 7 + board/toradex/common/tdx-cfg-block.h | 7 + configs/colibri-imx6ull_defconfig | 76 +++ drivers/mtd/nand/mxs_nand_dt.c | 8 + include/configs/colibri-imx6ull.h | 199 +++++++ 14 files changed, 1420 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx6ull-colibri.dts create mode 100644 board/toradex/colibri-imx6ull/Kconfig create mode 100644 board/toradex/colibri-imx6ull/MAINTAINERS create mode 100644 board/toradex/colibri-imx6ull/Makefile create mode 100644 board/toradex/colibri-imx6ull/colibri-imx6ull.c create mode 100644 board/toradex/colibri-imx6ull/imximage.cfg create mode 100644 configs/colibri-imx6ull_defconfig create mode 100644 include/configs/colibri-imx6ull.h
Support i.MX 6 NAND GPMI driver data from device tree.
Signed-off-by: Stefan Agner stefan.agner@toradex.com ---
drivers/mtd/nand/mxs_nand_dt.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/mtd/nand/mxs_nand_dt.c b/drivers/mtd/nand/mxs_nand_dt.c index c7355371ac..f2663d1023 100644 --- a/drivers/mtd/nand/mxs_nand_dt.c +++ b/drivers/mtd/nand/mxs_nand_dt.c @@ -21,11 +21,19 @@ struct mxs_nand_dt_data { unsigned int max_ecc_strength_supported; };
+static const struct mxs_nand_dt_data mxs_nand_imx6q_data = { + .max_ecc_strength_supported = 40, +}; + static const struct mxs_nand_dt_data mxs_nand_imx7d_data = { .max_ecc_strength_supported = 62, };
static const struct udevice_id mxs_nand_dt_ids[] = { + { + .compatible = "fsl,imx6q-gpmi-nand", + .data = (unsigned long)&mxs_nand_imx6q_data, + }, { .compatible = "fsl,imx7d-gpmi-nand", .data = (unsigned long)&mxs_nand_imx7d_data,
This macro allows to detect whether the boot ROM initialized USB already (serial downloader). This is helpful to reliably detect if the system has been recovered via USB serial downloader.
Signed-off-by: Stefan Agner stefan.agner@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
arch/arm/include/asm/arch-mx6/imx-regs.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 431439218d..4f01b20aed 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -996,5 +996,12 @@ struct pwm_regs { u32 pr; u32 cnr; }; + +/* + * If ROM fail back to USB recover mode, USBPH0_PWD will be clear to use USB + * If boot from the other mode, USB0_PWD will keep reset value + */ +#define is_boot_from_usb(void) (!(readl(USB_PHY0_BASE_ADDR) & (1<<20))) + #endif /* __ASSEMBLER__*/ #endif /* __ASM_ARCH_MX6_IMX_REGS_H__ */
The GPMI NAND IP seems to be the same as used in i.MX 6Quad. Use the fsl,imx6q-gpmi-nand compatible string like Linux devices trees are.
arch/arm/dts/imx6ull.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/imx6ull.dtsi b/arch/arm/dts/imx6ull.dtsi index f8ec649460..97236d86ea 100644 --- a/arch/arm/dts/imx6ull.dtsi +++ b/arch/arm/dts/imx6ull.dtsi @@ -190,7 +190,7 @@ };
gpmi: gpmi-nand@01806000{ - compatible = "fsl,imx6ull-gpmi-nand", "fsl, imx6ul-gpmi-nand"; + compatible = "fsl,imx6q-gpmi-nand"; #address-cells = <1>; #size-cells = <1>; reg = <0x01806000 0x2000>, <0x01808000 0x4000>;
board/toradex/common/tdx-cfg-block.c | 7 +++++++ board/toradex/common/tdx-cfg-block.h | 7 +++++++ 2 files changed, 14 insertions(+)
diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index f6231ff2f9..57edb6c5c9 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -91,6 +91,13 @@ const char * const toradex_modules[] = { [33] = "Colibri iMX7 Dual 512MB", [34] = "Apalis TK1 2GB", [35] = "Apalis iMX6 Dual 1GB IT", + [36] = "Colibri iMX6ULL 256MB", + [37] = "Apalis iMX8 QuadMax 4GB Wi-Fi / Bluetooth", + [38] = "Colibri iMX8X", + [39] = "Colibri iMX7 Dual 1GB (eMMC)", + [40] = "Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT", + [41] = "Colibri iMX7 Dual 512MB EPDC", + [42] = "Apalis TK1 4GB", };
#ifdef CONFIG_TDX_CFG_BLOCK_IS_IN_MMC diff --git a/board/toradex/common/tdx-cfg-block.h b/board/toradex/common/tdx-cfg-block.h index 29b933c307..da60e789a7 100644 --- a/board/toradex/common/tdx-cfg-block.h +++ b/board/toradex/common/tdx-cfg-block.h @@ -54,6 +54,13 @@ enum { COLIBRI_IMX7D, APALIS_TK1_2GB, APALIS_IMX6D_IT, + COLIBRI_IMX6ULL, + APALIS_IMX8QM, /* 37 */ + COLIBRI_IMX8X, + COLIBRI_IMX7D_EMMC, + COLIBRI_IMX6ULL_WIFI_BT_IT, /* 40 */ + COLIBRI_IMX7D_EPDC, + APALIS_TK1_4GB, };
extern const char * const toradex_modules[];
Add support for the Colibri iMX6ULL module which comes with on-board raw NAND.
arch/arm/dts/imx6ull-colibri.dts | 550 ++++++++++++++++++ arch/arm/mach-imx/mx6/Kconfig | 8 + board/toradex/colibri-imx6ull/Kconfig | 29 + board/toradex/colibri-imx6ull/MAINTAINERS | 10 + board/toradex/colibri-imx6ull/Makefile | 4 + .../toradex/colibri-imx6ull/colibri-imx6ull.c | 408 +++++++++++++ board/toradex/colibri-imx6ull/imximage.cfg | 106 ++++ configs/colibri-imx6ull_defconfig | 76 +++ include/configs/colibri-imx6ull.h | 199 +++++++ 9 files changed, 1390 insertions(+) create mode 100644 arch/arm/dts/imx6ull-colibri.dts create mode 100644 board/toradex/colibri-imx6ull/Kconfig create mode 100644 board/toradex/colibri-imx6ull/MAINTAINERS create mode 100644 board/toradex/colibri-imx6ull/Makefile create mode 100644 board/toradex/colibri-imx6ull/colibri-imx6ull.c create mode 100644 board/toradex/colibri-imx6ull/imximage.cfg create mode 100644 configs/colibri-imx6ull_defconfig create mode 100644 include/configs/colibri-imx6ull.h
diff --git a/arch/arm/dts/imx6ull-colibri.dts b/arch/arm/dts/imx6ull-colibri.dts new file mode 100644 index 0000000000..95c67be438 --- /dev/null +++ b/arch/arm/dts/imx6ull-colibri.dts @@ -0,0 +1,550 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2018 Toradex AG + */ + +/dts-v1/; +#include <dt-bindings/gpio/gpio.h> +#include "imx6ull.dtsi" + +/ { + model = "Toradex Colibri iMX6ULL"; + compatible = "toradex,imx6ull-colibri", "fsl,imx6ull"; + + chosen { + stdout-path = &uart1; + }; + + reg_module_3v3: regulator-module-3v3 { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-name = "+V3.3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + reg_module_3v3_avdd: regulator-module-3v3-avdd { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-name = "+V3.3_AVDD_AUDIO"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + reg_sd1_vmmc: regulator-sd1-vmmc { + compatible = "regulator-gpio"; + gpio = <&gpio5 9 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_snvs_reg_sd>; + regulator-always-on; + regulator-name = "+V3.3_1.8_SD"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + states = <1800000 0x1 3300000 0x0>; + vin-supply = <®_module_3v3>; + }; +}; + +&adc1 { + num-channels = <10>; + vref-supply = <®_module_3v3_avdd>; +}; + +/* Colibri SPI */ +&ecspi1 { + cs-gpios = <&gpio3 26 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi1 &pinctrl_ecspi1_cs>; +}; + +&fec2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet2>; + phy-mode = "rmii"; + phy-handle = <ðphy1>; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy1: ethernet-phy@2 { + compatible = "ethernet-phy-ieee802.3-c22"; + max-speed = <100>; + reg = <2>; + }; + }; +}; + +&gpmi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpmi_nand>; + nand-on-flash-bbt; + nand-ecc-mode = "hw"; + nand-ecc-strength = <8>; + nand-ecc-step-size = <512>; + status = "okay"; +}; + +&i2c1 { + pinctrl-names = "default", "gpio"; + pinctrl-0 = <&pinctrl_i2c1>; + pinctrl-1 = <&pinctrl_i2c1_gpio>; + sda-gpios = <&gpio1 29 GPIO_ACTIVE_LOW>; + scl-gpios = <&gpio1 28 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&i2c2 { + pinctrl-names = "default", "gpio"; + pinctrl-0 = <&pinctrl_i2c2>; + pinctrl-1 = <&pinctrl_i2c2_gpio>; + sda-gpios = <&gpio1 31 GPIO_ACTIVE_LOW>; + scl-gpios = <&gpio1 30 GPIO_ACTIVE_LOW>; + status = "okay"; + + ad7879@2c { + compatible = "adi,ad7879-1"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_snvs_ad7879_int>; + reg = <0x2c>; + interrupt-parent = <&gpio5>; + interrupts = <7 IRQ_TYPE_EDGE_FALLING>; + touchscreen-max-pressure = <4096>; + adi,resistance-plate-x = <120>; + adi,first-conversion-delay = /bits/ 8 <3>; + adi,acquisition-time = /bits/ 8 <1>; + adi,median-filter-size = /bits/ 8 <2>; + adi,averaging = /bits/ 8 <1>; + adi,conversion-interval = /bits/ 8 <255>; + }; +}; + +&lcdif { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lcdif_dat + &pinctrl_lcdif_ctrl>; +}; + +&pwm4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm4>; + #pwm-cells = <3>; +}; + +&pwm5 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm5>; + #pwm-cells = <3>; +}; + +&pwm6 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm6>; + #pwm-cells = <3>; +}; + +&pwm7 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm7>; + #pwm-cells = <3>; +}; + +&sdma { + status = "okay"; +}; + +&snvs_pwrkey { + status = "disabled"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1 &pinctrl_uart1_ctrl1>; + fsl,uart-has-rtscts; + fsl,dte-mode; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + fsl,uart-has-rtscts; + fsl,dte-mode; +}; + +&uart5 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart5>; + fsl,dte-mode; +}; + +&usbotg1 { + dr_mode = "otg"; + srp-disable; + hnp-disable; + adp-disable; +}; + +&usbotg2 { + dr_mode = "host"; +}; + +&usdhc1 { + assigned-clocks = <&clks IMX6UL_CLK_USDHC1_SEL>, <&clks IMX6UL_CLK_USDHC1>; + assigned-clock-parents = <&clks IMX6UL_CLK_PLL2_PFD2>; + assigned-clock-rates = <0>, <198000000>; +}; + +&iomuxc { + pinctrl_gpio1: gpio1-grp { + fsl,pins = < + MX6UL_PAD_ENET1_RX_DATA0__GPIO2_IO00 0x74 /* SODIMM 55 */ + MX6UL_PAD_ENET1_RX_DATA1__GPIO2_IO01 0x74 /* SODIMM 63 */ + MX6UL_PAD_UART3_RX_DATA__GPIO1_IO25 0X14 /* SODIMM 77 */ + MX6UL_PAD_JTAG_TCK__GPIO1_IO14 0x14 /* SODIMM 99 */ + MX6UL_PAD_NAND_CE1_B__GPIO4_IO14 0x14 /* SODIMM 133 */ + MX6UL_PAD_UART3_TX_DATA__GPIO1_IO24 0x14 /* SODIMM 135 */ + MX6UL_PAD_UART3_CTS_B__GPIO1_IO26 0x14 /* SODIMM 100 */ + MX6UL_PAD_JTAG_TRST_B__GPIO1_IO15 0x14 /* SODIMM 102 */ + MX6UL_PAD_ENET1_RX_ER__GPIO2_IO07 0x14 /* SODIMM 104 */ + MX6UL_PAD_UART3_RTS_B__GPIO1_IO27 0x14 /* SODIMM 186 */ + >; + }; + + pinctrl_gpio2: gpio2-grp { /* Camera */ + fsl,pins = < + MX6UL_PAD_CSI_DATA04__GPIO4_IO25 0x74 /* SODIMM 69 */ + MX6UL_PAD_CSI_MCLK__GPIO4_IO17 0x14 /* SODIMM 75 */ + MX6UL_PAD_CSI_DATA06__GPIO4_IO27 0x14 /* SODIMM 85 */ + MX6UL_PAD_CSI_PIXCLK__GPIO4_IO18 0x14 /* SODIMM 96 */ + MX6UL_PAD_CSI_DATA05__GPIO4_IO26 0x14 /* SODIMM 98 */ + >; + }; + + pinctrl_gpio3: gpio3-grp { /* CAN2 */ + fsl,pins = < + MX6UL_PAD_ENET1_RX_EN__GPIO2_IO02 0x14 /* SODIMM 178 */ + MX6UL_PAD_ENET1_TX_DATA0__GPIO2_IO03 0x14 /* SODIMM 188 */ + >; + }; + + pinctrl_gpio4: gpio4-grp { + fsl,pins = < + MX6UL_PAD_CSI_DATA07__GPIO4_IO28 0x74 /* SODIMM 65 */ + >; + }; + + pinctrl_gpio5: gpio5-grp { /* ATMEL MXT TOUCH */ + fsl,pins = < + MX6UL_PAD_JTAG_MOD__GPIO1_IO10 0x74 /* SODIMM 106 */ + >; + }; + + pinctrl_gpio6: gpio6-grp { /* Wifi pins */ + fsl,pins = < + MX6UL_PAD_GPIO1_IO03__GPIO1_IO03 0x14 /* SODIMM 89 */ + MX6UL_PAD_CSI_DATA02__GPIO4_IO23 0x14 /* SODIMM 79 */ + MX6UL_PAD_CSI_VSYNC__GPIO4_IO19 0x14 /* SODIMM 81 */ + MX6UL_PAD_CSI_DATA03__GPIO4_IO24 0x14 /* SODIMM 97 */ + MX6UL_PAD_CSI_DATA00__GPIO4_IO21 0x14 /* SODIMM 101 */ + MX6UL_PAD_CSI_DATA01__GPIO4_IO22 0x14 /* SODIMM 103 */ + MX6UL_PAD_CSI_HSYNC__GPIO4_IO20 0x14 /* SODIMM 94 */ + >; + }; + + pinctrl_can_int: canint-grp { + fsl,pins = < + MX6UL_PAD_ENET1_TX_DATA1__GPIO2_IO04 0X14 /* SODIMM 73 */ + >; + }; + + pinctrl_enet2: enet2-grp { + fsl,pins = < + MX6UL_PAD_GPIO1_IO06__ENET2_MDIO 0x1b0b0 + MX6UL_PAD_GPIO1_IO07__ENET2_MDC 0x1b0b0 + MX6UL_PAD_ENET2_RX_DATA0__ENET2_RDATA00 0x1b0b0 + MX6UL_PAD_ENET2_RX_DATA1__ENET2_RDATA01 0x1b0b0 + MX6UL_PAD_ENET2_RX_EN__ENET2_RX_EN 0x1b0b0 + MX6UL_PAD_ENET2_RX_ER__ENET2_RX_ER 0x1b0b0 + MX6UL_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 0x4001b031 + MX6UL_PAD_ENET2_TX_DATA0__ENET2_TDATA00 0x1b0b0 + MX6UL_PAD_ENET2_TX_DATA1__ENET2_TDATA01 0x1b0b0 + MX6UL_PAD_ENET2_TX_EN__ENET2_TX_EN 0x1b0b0 + >; + }; + + pinctrl_ecspi1_cs: ecspi1-cs-grp { + fsl,pins = < + MX6UL_PAD_LCD_DATA21__GPIO3_IO26 0x000a0 + >; + }; + + pinctrl_ecspi1: ecspi1-grp { + fsl,pins = < + MX6UL_PAD_LCD_DATA20__ECSPI1_SCLK 0x000a0 + MX6UL_PAD_LCD_DATA22__ECSPI1_MOSI 0x000a0 + MX6UL_PAD_LCD_DATA23__ECSPI1_MISO 0x100a0 + >; + }; + + pinctrl_flexcan2: flexcan2-grp { + fsl,pins = < + MX6UL_PAD_ENET1_TX_DATA0__FLEXCAN2_RX 0x1b020 + MX6UL_PAD_ENET1_RX_EN__FLEXCAN2_TX 0x1b020 + >; + }; + + pinctrl_gpio_bl_on: gpio-bl-on-grp { + fsl,pins = < + MX6UL_PAD_JTAG_TMS__GPIO1_IO11 0x000a0 + >; + }; + + pinctrl_gpmi_nand: gpmi-nand-grp { + fsl,pins = < + MX6UL_PAD_NAND_DATA00__RAWNAND_DATA00 0x100a9 + MX6UL_PAD_NAND_DATA01__RAWNAND_DATA01 0x100a9 + MX6UL_PAD_NAND_DATA02__RAWNAND_DATA02 0x100a9 + MX6UL_PAD_NAND_DATA03__RAWNAND_DATA03 0x100a9 + MX6UL_PAD_NAND_DATA04__RAWNAND_DATA04 0x100a9 + MX6UL_PAD_NAND_DATA05__RAWNAND_DATA05 0x100a9 + MX6UL_PAD_NAND_DATA06__RAWNAND_DATA06 0x100a9 + MX6UL_PAD_NAND_DATA07__RAWNAND_DATA07 0x100a9 + MX6UL_PAD_NAND_CLE__RAWNAND_CLE 0x100a9 + MX6UL_PAD_NAND_ALE__RAWNAND_ALE 0x100a9 + MX6UL_PAD_NAND_RE_B__RAWNAND_RE_B 0x100a9 + MX6UL_PAD_NAND_WE_B__RAWNAND_WE_B 0x100a9 + MX6UL_PAD_NAND_CE0_B__RAWNAND_CE0_B 0x100a9 + MX6UL_PAD_NAND_READY_B__RAWNAND_READY_B 0x100a9 + >; + }; + + pinctrl_i2c1: i2c1-grp { + fsl,pins = < + MX6UL_PAD_UART4_TX_DATA__I2C1_SCL 0x4001b8b0 + MX6UL_PAD_UART4_RX_DATA__I2C1_SDA 0x4001b8b0 + >; + }; + + pinctrl_i2c1_gpio: i2c1-gpio-grp { + fsl,pins = < + MX6UL_PAD_UART4_TX_DATA__GPIO1_IO28 0x4001b8b0 + MX6UL_PAD_UART4_RX_DATA__GPIO1_IO29 0x4001b8b0 + >; + }; + + pinctrl_i2c2: i2c2-grp { + fsl,pins = < + MX6UL_PAD_UART5_TX_DATA__I2C2_SCL 0x4001b8b0 + MX6UL_PAD_UART5_RX_DATA__I2C2_SDA 0x4001b8b0 + >; + }; + + pinctrl_i2c2_gpio: i2c2-gpio-grp { + fsl,pins = < + MX6UL_PAD_UART5_TX_DATA__GPIO1_IO30 0x4001b8b0 + MX6UL_PAD_UART5_RX_DATA__GPIO1_IO31 0x4001b8b0 + >; + }; + + pinctrl_lcdif_dat: lcdif-dat-grp { + fsl,pins = < + MX6UL_PAD_LCD_DATA00__LCDIF_DATA00 0x00079 + MX6UL_PAD_LCD_DATA01__LCDIF_DATA01 0x00079 + MX6UL_PAD_LCD_DATA02__LCDIF_DATA02 0x00079 + MX6UL_PAD_LCD_DATA03__LCDIF_DATA03 0x00079 + MX6UL_PAD_LCD_DATA04__LCDIF_DATA04 0x00079 + MX6UL_PAD_LCD_DATA05__LCDIF_DATA05 0x00079 + MX6UL_PAD_LCD_DATA06__LCDIF_DATA06 0x00079 + MX6UL_PAD_LCD_DATA07__LCDIF_DATA07 0x00079 + MX6UL_PAD_LCD_DATA08__LCDIF_DATA08 0x00079 + MX6UL_PAD_LCD_DATA09__LCDIF_DATA09 0x00079 + MX6UL_PAD_LCD_DATA10__LCDIF_DATA10 0x00079 + MX6UL_PAD_LCD_DATA11__LCDIF_DATA11 0x00079 + MX6UL_PAD_LCD_DATA12__LCDIF_DATA12 0x00079 + MX6UL_PAD_LCD_DATA13__LCDIF_DATA13 0x00079 + MX6UL_PAD_LCD_DATA14__LCDIF_DATA14 0x00079 + MX6UL_PAD_LCD_DATA15__LCDIF_DATA15 0x00079 + MX6UL_PAD_LCD_DATA16__LCDIF_DATA16 0x00079 + MX6UL_PAD_LCD_DATA17__LCDIF_DATA17 0x00079 + >; + }; + + pinctrl_lcdif_ctrl: lcdif-ctrl-grp { + fsl,pins = < + MX6UL_PAD_LCD_CLK__LCDIF_CLK 0x00079 + MX6UL_PAD_LCD_ENABLE__LCDIF_ENABLE 0x00079 + MX6UL_PAD_LCD_HSYNC__LCDIF_HSYNC 0x00079 + MX6UL_PAD_LCD_VSYNC__LCDIF_VSYNC 0x00079 + >; + }; + + pinctrl_pwm4: pwm4-grp { + fsl,pins = < + MX6UL_PAD_NAND_WP_B__PWM4_OUT 0x00079 + >; + }; + + pinctrl_pwm5: pwm5-grp { + fsl,pins = < + MX6UL_PAD_NAND_DQS__PWM5_OUT 0x00079 + >; + }; + + pinctrl_pwm6: pwm6-grp { + fsl,pins = < + MX6UL_PAD_ENET1_TX_EN__PWM6_OUT 0x00079 + >; + }; + + pinctrl_pwm7: pwm7-grp { + fsl,pins = < + MX6UL_PAD_ENET1_TX_CLK__PWM7_OUT 0x00079 + >; + }; + + pinctrl_uart1: uart1-grp { + fsl,pins = < + MX6UL_PAD_UART1_TX_DATA__UART1_DTE_RX 0x1b0b1 + MX6UL_PAD_UART1_RX_DATA__UART1_DTE_TX 0x1b0b1 + MX6UL_PAD_UART1_RTS_B__UART1_DTE_CTS 0x1b0b1 + MX6UL_PAD_UART1_CTS_B__UART1_DTE_RTS 0x1b0b1 + >; + }; + + pinctrl_uart1_ctrl1: uart1-ctrl1-grp { /* Additional DTR, DCD */ + fsl,pins = < + MX6UL_PAD_JTAG_TDI__GPIO1_IO13 0x1b0b1 /* DCD */ + MX6UL_PAD_LCD_DATA18__GPIO3_IO23 0x1b0b1 /* DSR */ + MX6UL_PAD_JTAG_TDO__GPIO1_IO12 0x1b0b1 /* DTR */ + MX6UL_PAD_LCD_DATA19__GPIO3_IO24 0x1b0b1 /* RI */ + >; + }; + + pinctrl_uart2: uart2-grp { + fsl,pins = < + MX6UL_PAD_UART2_TX_DATA__UART2_DTE_RX 0x1b0b1 + MX6UL_PAD_UART2_RX_DATA__UART2_DTE_TX 0x1b0b1 + MX6UL_PAD_UART2_CTS_B__UART2_DTE_RTS 0x1b0b1 + MX6UL_PAD_UART2_RTS_B__UART2_DTE_CTS 0x1b0b1 + >; + }; + pinctrl_uart5: uart5-grp { + fsl,pins = < + MX6UL_PAD_GPIO1_IO04__UART5_DTE_RX 0x1b0b1 + MX6UL_PAD_GPIO1_IO05__UART5_DTE_TX 0x1b0b1 + >; + }; + + pinctrl_usbh_reg: gpio-usbh-reg { + fsl,pins = < + MX6UL_PAD_GPIO1_IO02__GPIO1_IO02 0x1b0b1 /* SODIMM 129 USBH PEN */ + >; + }; + + pinctrl_usdhc1: usdhc1-grp { + fsl,pins = < + MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x17059 + MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x10059 + MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x17059 + MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x17059 + MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x17059 + MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x17059 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1-100mhz-grp { + fsl,pins = < + MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x170b9 + MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x100b9 + MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x170b9 + MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x170b9 + MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x170b9 + MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x170b9 + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1-200mhz-grp { + fsl,pins = < + MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x170f9 + MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x100f9 + MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x170b9 + MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x170b9 + MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x170b9 + MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x170b9 + >; + }; + + pinctrl_usdhc2: usdhc2-grp { + fsl,pins = < + MX6UL_PAD_CSI_DATA00__USDHC2_DATA0 0x17059 + MX6UL_PAD_CSI_DATA01__USDHC2_DATA1 0x17059 + MX6UL_PAD_CSI_DATA02__USDHC2_DATA2 0x17059 + MX6UL_PAD_CSI_DATA03__USDHC2_DATA3 0x17059 + MX6UL_PAD_CSI_HSYNC__USDHC2_CMD 0x17059 + MX6UL_PAD_CSI_VSYNC__USDHC2_CLK 0x17059 + >; + }; +}; + +&iomuxc_snvs { + pinctrl_snvs_gpio1: snvs-gpio1-grp { + fsl,pins = < + MX6ULL_PAD_SNVS_TAMPER6__GPIO5_IO06 0x14 /* SODIMM 93 */ + MX6ULL_PAD_SNVS_TAMPER3__GPIO5_IO03 0x14 /* SODIMM 95 */ + MX6ULL_PAD_BOOT_MODE0__GPIO5_IO10 0x74 /* SODIMM 105 */ + MX6ULL_PAD_SNVS_TAMPER5__GPIO5_IO05 0x14 /* SODIMM 131 USBH OC */ + MX6ULL_PAD_SNVS_TAMPER8__GPIO5_IO08 0x74 /* SODIMM 138 */ + >; + }; + + pinctrl_snvs_gpio2: snvs-gpio2-grp { /* ATMEL MXT TOUCH */ + fsl,pins = < + MX6ULL_PAD_SNVS_TAMPER4__GPIO5_IO04 0x74 /* SODIMM 107 */ + >; + }; + + pinctrl_snvs_gpio3: snvs-gpio3-grp { /* Wifi pins */ + fsl,pins = < + MX6ULL_PAD_BOOT_MODE1__GPIO5_IO11 0x14 /* SODIMM 127 */ + >; + }; + + pinctrl_snvs_ad7879_int: snvs-ad7879-int { /* TOUCH Interrupt */ + fsl,pins = < + MX6ULL_PAD_SNVS_TAMPER7__GPIO5_IO07 0x1b0b0 + >; + }; + + pinctrl_snvs_reg_sd: snvs-reg-sd-grp { + fsl,pins = < + MX6ULL_PAD_SNVS_TAMPER9__GPIO5_IO09 0x4001b8b0 + >; + }; + + pinctrl_snvs_usbc_det: snvs-usbc-det-grp { + fsl,pins = < + MX6ULL_PAD_SNVS_TAMPER2__GPIO5_IO02 0x1b0b0 + >; + }; + + pinctrl_snvs_gpiokeys: snvs-gpiokeys-grp { + fsl,pins = < + MX6ULL_PAD_SNVS_TAMPER1__GPIO5_IO01 0x130b0 + >; + }; + + pinctrl_snvs_usdhc1_cd: snvs-usdhc1-cd-grp { + fsl,pins = < + MX6ULL_PAD_SNVS_TAMPER0__GPIO5_IO00 0x1b0b0 /* CD */ + >; + }; + + pinctrl_snvs_wifi_pdn: snvs-wifi-pdn-grp { + fsl,pins = < + MX6ULL_PAD_BOOT_MODE1__GPIO5_IO11 0x14 + >; + }; +}; + diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 98ea1f566c..4237887db1 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -147,6 +147,13 @@ config TARGET_COLIBRI_IMX6 select DM_SERIAL select DM_THERMAL
+config TARGET_COLIBRI_IMX6ULL + bool "Toradex Colibri iMX6ULL" + select BOARD_LATE_INIT + select DM + select DM_THERMAL + select MX6ULL + config TARGET_DHCOMIMX6 bool "dh_imx6" select MX6QDL @@ -507,6 +514,7 @@ source "board/tbs/tbs2910/Kconfig" source "board/tqc/tqma6/Kconfig" source "board/toradex/apalis_imx6/Kconfig" source "board/toradex/colibri_imx6/Kconfig" +source "board/toradex/colibri-imx6ull/Kconfig" source "board/k+p/kp_imx6q_tpc/Kconfig" source "board/udoo/Kconfig" source "board/udoo/neo/Kconfig" diff --git a/board/toradex/colibri-imx6ull/Kconfig b/board/toradex/colibri-imx6ull/Kconfig new file mode 100644 index 0000000000..3ce9885c12 --- /dev/null +++ b/board/toradex/colibri-imx6ull/Kconfig @@ -0,0 +1,29 @@ +if TARGET_COLIBRI_IMX6ULL + +config SYS_BOARD + default "colibri-imx6ull" + +config SYS_VENDOR + default "toradex" + +config SYS_CONFIG_NAME + default "colibri-imx6ull" + +config TDX_CFG_BLOCK + default y + +config TDX_HAVE_NAND + default y + +config TDX_CFG_BLOCK_OFFSET + default "2048" + +config TDX_CFG_BLOCK_OFFSET2 + default "133120" + +config TDX_CFG_BLOCK_2ND_ETHADDR + default y + +source "board/toradex/common/Kconfig" + +endif diff --git a/board/toradex/colibri-imx6ull/MAINTAINERS b/board/toradex/colibri-imx6ull/MAINTAINERS new file mode 100644 index 0000000000..7cda555984 --- /dev/null +++ b/board/toradex/colibri-imx6ull/MAINTAINERS @@ -0,0 +1,10 @@ +Colibri iMX6ULL +M: Stefan Agner stefan.agner@toradex.com +M: Toradex ARM Support support.arm@toradex.com +W: http://developer.toradex.com/software/linux/linux-software +W: https://www.toradex.com/community +S: Maintained +F: arch/arm/dts/imx6ull-colibri.dts +F: board/toradex/colibri-imx6ull/ +F: configs/colibri-imx6ull_defconfig +F: include/configs/colibri-imx6ull.h diff --git a/board/toradex/colibri-imx6ull/Makefile b/board/toradex/colibri-imx6ull/Makefile new file mode 100644 index 0000000000..f478e68049 --- /dev/null +++ b/board/toradex/colibri-imx6ull/Makefile @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2018 Toradex AG + +obj-y := colibri-imx6ull.o diff --git a/board/toradex/colibri-imx6ull/colibri-imx6ull.c b/board/toradex/colibri-imx6ull/colibri-imx6ull.c new file mode 100644 index 0000000000..fcb49a0718 --- /dev/null +++ b/board/toradex/colibri-imx6ull/colibri-imx6ull.c @@ -0,0 +1,408 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Toradex AG + */ +#include <common.h> +#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch-mx6/clock.h> +#include <asm/arch-mx6/imx-regs.h> +#include <asm/arch-mx6/mx6ull_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/io.h> +#include <common.h> +#include <dm.h> +#include <dm/platform_data/serial_mxc.h> +#include <fdt_support.h> +#include <fsl_esdhc.h> +#include <imx_thermal.h> +#include <jffs2/load_kernel.h> +#include <linux/sizes.h> +#include <mmc.h> +#include <miiphy.h> +#include <mtd_node.h> +#include <netdev.h> +#include <usb.h> +#include <usb/ehci-ci.h> +#include "../common/tdx-common.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) +#define ENET_PAD_CTRL_MII (PAD_CTL_DSE_40ohm) + +#define ENET_RX_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_DSE_48ohm) + +#define LCD_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_PUS_100K_UP | \ + PAD_CTL_DSE_48ohm) + +#define NAND_PAD_CTRL (PAD_CTL_DSE_48ohm | PAD_CTL_SRE_SLOW | PAD_CTL_HYS) + +#define NAND_PAD_READY0_CTRL (PAD_CTL_DSE_48ohm | PAD_CTL_PUS_22K_UP) + +#define USB_CDET_GPIO IMX_GPIO_NR(7, 14) + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + + return 0; +} + +static iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_UART1_TX_DATA__UART1_DTE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART1_RX_DATA__UART1_DTE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART1_RTS_B__UART1_DTE_CTS | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART1_CTS_B__UART1_DTE_RTS | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +#ifdef CONFIG_FSL_ESDHC +static iomux_v3_cfg_t const usdhc1_pads[] = { + MX6_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA0__USDHC1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA1__USDHC1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA2__USDHC1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DATA3__USDHC1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + + MX6_PAD_SNVS_TAMPER0__GPIO5_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; +#endif + +static iomux_v3_cfg_t const usb_cdet_pads[] = { + MX6_PAD_SNVS_TAMPER2__GPIO5_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +#ifdef CONFIG_NAND_MXS +static iomux_v3_cfg_t const gpmi_pads[] = { + MX6_PAD_NAND_DATA00__RAWNAND_DATA00 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_DATA01__RAWNAND_DATA01 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_DATA02__RAWNAND_DATA02 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_DATA03__RAWNAND_DATA03 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_DATA04__RAWNAND_DATA04 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_DATA05__RAWNAND_DATA05 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_DATA06__RAWNAND_DATA06 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_DATA07__RAWNAND_DATA07 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_CLE__RAWNAND_CLE | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_ALE__RAWNAND_ALE | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_RE_B__RAWNAND_RE_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_WE_B__RAWNAND_WE_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_CE0_B__RAWNAND_CE0_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX6_PAD_NAND_READY_B__RAWNAND_READY_B | MUX_PAD_CTRL(NAND_PAD_READY0_CTRL), +}; + +static void setup_gpmi_nand(void) +{ + imx_iomux_v3_setup_multiple_pads(gpmi_pads, ARRAY_SIZE(gpmi_pads)); + + setup_gpmi_io_clk((3 << MXC_CCM_CSCDR1_BCH_PODF_OFFSET) | + (3 << MXC_CCM_CSCDR1_GPMI_PODF_OFFSET)); +} +#endif + +#ifdef CONFIG_VIDEO_MXS +static iomux_v3_cfg_t const lcd_pads[] = { + MX6_PAD_LCD_CLK__LCDIF_CLK | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_ENABLE__LCDIF_ENABLE | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_HSYNC__LCDIF_HSYNC | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_CLK__LCDIF_CLK | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA00__LCDIF_DATA00 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA01__LCDIF_DATA01 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA02__LCDIF_DATA02 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA03__LCDIF_DATA03 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA04__LCDIF_DATA04 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA05__LCDIF_DATA05 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA06__LCDIF_DATA06 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA07__LCDIF_DATA07 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA08__LCDIF_DATA08 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA09__LCDIF_DATA09 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA10__LCDIF_DATA10 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA11__LCDIF_DATA11 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA12__LCDIF_DATA12 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA13__LCDIF_DATA13 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA14__LCDIF_DATA14 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA15__LCDIF_DATA15 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA16__LCDIF_DATA16 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD_DATA17__LCDIF_DATA17 | MUX_PAD_CTRL(LCD_PAD_CTRL), +}; + +static iomux_v3_cfg_t const backlight_pads[] = { + /* Backlight On */ + MX6_PAD_JTAG_TMS__GPIO1_IO11 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* Backlight PWM<A> (multiplexed pin) */ + MX6_PAD_NAND_WP_B__GPIO4_IO11 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +#define GPIO_BL_ON IMX_GPIO_NR(1, 11) +#define GPIO_PWM_A IMX_GPIO_NR(4, 11) + +static int setup_lcd(void) +{ + imx_iomux_v3_setup_multiple_pads(lcd_pads, ARRAY_SIZE(lcd_pads)); + + imx_iomux_v3_setup_multiple_pads(backlight_pads, ARRAY_SIZE(backlight_pads)); + + /* Set BL_ON */ + gpio_request(GPIO_BL_ON, "BL_ON"); + gpio_direction_output(GPIO_BL_ON, 1); + + /* Set PWM<A> to full brightness (assuming inversed polarity) */ + gpio_request(GPIO_PWM_A, "PWM<A>"); + gpio_direction_output(GPIO_PWM_A, 0); + + return 0; +} +#endif + +#ifdef CONFIG_FEC_MXC +static iomux_v3_cfg_t const fec2_pads[] = { + MX6_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 | MUX_PAD_CTRL(ENET_PAD_CTRL) | MUX_MODE_SION, + MX6_PAD_GPIO1_IO06__ENET2_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL_MII), + MX6_PAD_GPIO1_IO07__ENET2_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL_MII), + MX6_PAD_ENET2_RX_DATA0__ENET2_RDATA00 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX6_PAD_ENET2_RX_DATA1__ENET2_RDATA01 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX6_PAD_ENET2_RX_ER__ENET2_RX_ER | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX6_PAD_ENET2_RX_EN__ENET2_RX_EN | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX6_PAD_ENET2_TX_DATA0__ENET2_TDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET2_TX_DATA1__ENET2_TDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET2_TX_EN__ENET2_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), +}; + +static void setup_iomux_fec(void) +{ + imx_iomux_v3_setup_multiple_pads(fec2_pads, ARRAY_SIZE(fec2_pads)); +} +#endif + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} + +#ifdef CONFIG_FSL_ESDHC + +#define USDHC1_CD_GPIO IMX_GPIO_NR(5, 0) + +static struct fsl_esdhc_cfg usdhc_cfg[] = { + {USDHC1_BASE_ADDR, 0, 4}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = !gpio_get_value(USDHC1_CD_GPIO); + break; + } + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + int i, ret; + + /* USDHC1 is mmc0 */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + imx_iomux_v3_setup_multiple_pads(usdhc1_pads, + ARRAY_SIZE(usdhc1_pads)); + gpio_request(USDHC1_CD_GPIO, "usdhc1_cd"); + gpio_direction_input(USDHC1_CD_GPIO); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) than supported by the board\n", i + 1); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) + return ret; + } + + return 0; +} +#endif + +#ifdef CONFIG_FEC_MXC + +static int setup_fec(void) +{ + struct iomuxc *iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; + int ret; + + setup_iomux_fec(); + + /* provide the PHY clock from the i.MX 6 */ + ret = enable_fec_anatop_clock(1, ENET_50MHZ); + if (ret) + return ret; + + /* Use 50M anatop REF_CLK and output it on the ENET2_TX_CLK */ + clrsetbits_le32(&iomuxc_regs->gpr[1], + IOMUX_GPR1_FEC2_CLOCK_MUX2_SEL_MASK, + IOMUX_GPR1_FEC2_CLOCK_MUX1_SEL_MASK); + + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ + if (phydev->drv->config) + phydev->drv->config(phydev); + return 0; +} +#endif + +int board_early_init_f(void) +{ + setup_iomux_uart(); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + +#ifdef CONFIG_FEC_MXC + setup_fec(); +#endif + +#ifdef CONFIG_NAND_MXS + setup_gpmi_nand(); +#endif + +#ifdef CONFIG_VIDEO_MXS + setup_lcd(); +#endif + +#ifdef CONFIG_USB_EHCI_MX6 + imx_iomux_v3_setup_multiple_pads(usb_cdet_pads, ARRAY_SIZE(usb_cdet_pads)); + gpio_request(USB_CDET_GPIO, "usb-cdet-gpio"); +#endif + + return 0; +} + +#ifdef CONFIG_CMD_BMODE +/* TODO */ +static const struct boot_mode board_boot_modes[] = { + /* 4 bit bus width */ + {"nand", MAKE_CFGVAL(0x40, 0x34, 0x00, 0x00)}, + {"sd1", MAKE_CFGVAL(0x10, 0x10, 0x00, 0x00)}, + {NULL, 0}, +}; +#endif + +int board_late_init(void) +{ + int minc, maxc; + + if (get_cpu_temp_grade(&minc, &maxc) != TEMP_COMMERCIAL) + env_set("variant", "-wifi"); + +#ifdef CONFIG_CMD_BMODE + add_board_boot_modes(board_boot_modes); +#endif + +#ifdef CONFIG_CMD_USB_SDP + if (is_boot_from_usb()) { + printf("Serial Downloader recovery mode, using sdp command\n"); + env_set("bootdelay", "0"); + env_set("bootcmd", "sdp 0"); + } +#endif /* CONFIG_CMD_USB_SDP */ + + return 0; +} + +int checkboard(void) +{ + printf("Model: Toradex Colibri iMX6ULL\n"); + + return 0; +} + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, bd_t *bd) +{ +#if defined(CONFIG_FDT_FIXUP_PARTITIONS) + static struct node_info nodes[] = { + { "fsl,imx6ull-gpmi-nand", MTD_DEV_TYPE_NAND, }, + { "fsl,imx6q-gpmi-nand", MTD_DEV_TYPE_NAND, }, + }; + + /* Update partition nodes using info from mtdparts env var */ + puts(" Updating MTD partitions...\n"); + fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes)); +#endif + + return ft_common_board_setup(blob, bd); +} +#endif + +#ifdef CONFIG_USB_EHCI_MX6 +static iomux_v3_cfg_t const usb_otg2_pads[] = { + MX6_PAD_GPIO1_IO02__GPIO1_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +int board_ehci_hcd_init(int port) +{ + switch (port) { + case 0: + break; + case 1: + imx_iomux_v3_setup_multiple_pads(usb_otg2_pads, + ARRAY_SIZE(usb_otg2_pads)); + break; + default: + return -EINVAL; + } + return 0; +} + +int board_usb_phy_mode(int port) +{ + switch (port) { + case 0: + if (gpio_get_value(USB_CDET_GPIO)) + return USB_INIT_DEVICE; + else + return USB_INIT_HOST; + case 1: + default: + return USB_INIT_HOST; + } +} +#endif + +static struct mxc_serial_platdata mxc_serial_plat = { + .reg = (struct mxc_uart *)UART1_BASE, + .use_dte = 1, +}; + +U_BOOT_DEVICE(mxc_serial) = { + .name = "serial_mxc", + .platdata = &mxc_serial_plat, +}; diff --git a/board/toradex/colibri-imx6ull/imximage.cfg b/board/toradex/colibri-imx6ull/imximage.cfg new file mode 100644 index 0000000000..2ce55a610a --- /dev/null +++ b/board/toradex/colibri-imx6ull/imximage.cfg @@ -0,0 +1,106 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + * Copyright (C) 2018 Toradex AG + * + * Refer doc/README.imximage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +#define __ASSEMBLY__ +#include <config.h> + +/* image version */ + +IMAGE_VERSION 2 + +/* + * Boot Device : nand + */ + +BOOT_FROM nand + +/* + * Secure boot support + */ +#ifdef CONFIG_SECURE_BOOT +CSF CONFIG_CSF_SIZE +#endif + +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* Enable all clocks */ +DATA 4 0x020c4068 0xffffffff +DATA 4 0x020c406c 0xffffffff +DATA 4 0x020c4070 0xffffffff +DATA 4 0x020c4074 0xffffffff +DATA 4 0x020c4078 0xffffffff +DATA 4 0x020c407c 0xffffffff +DATA 4 0x020c4080 0xffffffff + +DATA 4 0x020E04B4 0x000C0000 +DATA 4 0x020E04AC 0x00000000 +DATA 4 0x020E027C 0x00000030 +DATA 4 0x020E0250 0x00000030 +DATA 4 0x020E024C 0x00000030 +DATA 4 0x020E0490 0x00000030 +DATA 4 0x020E0288 0x000C0030 +DATA 4 0x020E0270 0x00000000 +DATA 4 0x020E0260 0x00000030 +DATA 4 0x020E0264 0x00000030 +DATA 4 0x020E04A0 0x00000030 +DATA 4 0x020E0494 0x00020000 +DATA 4 0x020E0280 0x00000030 +DATA 4 0x020E0284 0x00000030 +DATA 4 0x020E04B0 0x00020000 +DATA 4 0x020E0498 0x00000030 +DATA 4 0x020E04A4 0x00000030 +DATA 4 0x020E0244 0x00000030 +DATA 4 0x020E0248 0x00000030 +DATA 4 0x021B001C 0x00008000 +DATA 4 0x021B0800 0xA1390003 +DATA 4 0x021B080C 0x00000004 +DATA 4 0x021B083C 0x41640158 +DATA 4 0x021B0848 0x40403237 +DATA 4 0x021B0850 0x40403C33 +DATA 4 0x021B081C 0x33333333 +DATA 4 0x021B0820 0x33333333 +DATA 4 0x021B082C 0xf3333333 +DATA 4 0x021B0830 0xf3333333 +DATA 4 0x021B08C0 0x00944009 +DATA 4 0x021B08b8 0x00000800 +DATA 4 0x021B0004 0x0002002D +DATA 4 0x021B0008 0x1B333030 +DATA 4 0x021B000C 0x676B52F3 +DATA 4 0x021B0010 0xB66D0B63 +DATA 4 0x021B0014 0x01FF00DB +DATA 4 0x021B0018 0x00201740 +DATA 4 0x021B001C 0x00008000 +DATA 4 0x021B002C 0x000026D2 +DATA 4 0x021B0030 0x006B1023 +DATA 4 0x021B0040 0x0000004F +DATA 4 0x021B0000 0x84180000 +DATA 4 0x021B0890 0x00400000 +DATA 4 0x021B001C 0x02008032 +DATA 4 0x021B001C 0x00008033 +DATA 4 0x021B001C 0x00048031 +DATA 4 0x021B001C 0x15208030 +DATA 4 0x021B001C 0x04008040 +DATA 4 0x021B0020 0x00000800 +DATA 4 0x021B0818 0x00000227 +DATA 4 0x021B0004 0x0002552D +DATA 4 0x021B0404 0x00011006 +DATA 4 0x021B001C 0x00000000 + diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig new file mode 100644 index 0000000000..a6db0b8c6a --- /dev/null +++ b/configs/colibri-imx6ull_defconfig @@ -0,0 +1,76 @@ +CONFIG_ARM=y +CONFIG_SYS_THUMB_BUILD=y +# CONFIG_SPL_SYS_THUMB_BUILD is not set +CONFIG_ARCH_MX6=y +CONFIG_SYS_TEXT_BASE=0x87800000 +CONFIG_TARGET_COLIBRI_IMX6ULL=y +CONFIG_DEFAULT_DEVICE_TREE="imx6ull-colibri" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri-imx6ull/imximage.cfg,MX6ULL,IMX_NAND" +CONFIG_BOOTDELAY=1 +# CONFIG_USE_BOOTCOMMAND is not set +# CONFIG_CONSOLE_MUX is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_VERSION_VARIABLE=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SYS_PROMPT="Colibri iMX6ULL # " +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_NAND_TRIMFFS=y +CONFIG_CMD_NAND_TORTURE=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_BMP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_UBI=y +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DFU_MMC=y +CONFIG_DFU_NAND=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_FSL_ESDHC=y +CONFIG_MTD=y +CONFIG_NAND=y +CONFIG_NAND_MXS=y +CONFIG_NAND_MXS_DT=y +CONFIG_MTD_UBI_FASTMAP=y +CONFIG_PHYLIB=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_NETDEVICES=y +CONFIG_FEC_MXC=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_REGULATOR=y +# CONFIG_SPL_SERIAL_PRESENT is not set +CONFIG_DM_SERIAL=y +CONFIG_MXC_UART=y +CONFIG_USB=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Toradex" +CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 +CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_FUNCTION_SDP=y +CONFIG_VIDEO=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_FDT_FIXUP_PARTITIONS=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/colibri-imx6ull.h b/include/configs/colibri-imx6ull.h new file mode 100644 index 0000000000..7661000b45 --- /dev/null +++ b/include/configs/colibri-imx6ull.h @@ -0,0 +1,199 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 Toradex AG + * + * Configuration settings for the Colibri iMX6ULL module. + * + * based on colibri_imx7.h + */ + +#ifndef __COLIBRI_IMX6ULL_CONFIG_H +#define __COLIBRI_IMX6ULL_CONFIG_H + +#include "mx6_common.h" +#define CONFIG_IOMUX_LPSR + +/* #define CONFIG_DBG_MONITOR*/ +#define PHYS_SDRAM_SIZE SZ_512M + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (32 * SZ_1M) + +/* Network */ +#define CONFIG_MII +#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 0 + +#define CONFIG_IP_DEFRAG +#define CONFIG_TFTP_BLOCKSIZE 16352 +#define CONFIG_TFTP_TSIZE + +/* ENET1 */ +#define IMX_FEC_BASE ENET2_BASE_ADDR + +/* MMC Config*/ +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_USDHC_NUM 1 + +#undef CONFIG_BOOTM_PLAN9 +#undef CONFIG_BOOTM_RTEMS + +/* I2C configs */ +#define CONFIG_SYS_I2C_SPEED 100000 + +#define CONFIG_IPADDR 192.168.10.2 +#define CONFIG_NETMASK 255.255.255.0 +#define CONFIG_SERVERIP 192.168.10.1 + +#define FDT_FILE "imx6ull-colibri${variant}-${fdt_board}.dtb" + +#define MEM_LAYOUT_ENV_SETTINGS \ + "bootm_size=0x10000000\0" \ + "fdt_addr_r=0x82000000\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "kernel_addr_r=0x81000000\0" \ + "pxefile_addr_r=0x87100000\0" \ + "ramdisk_addr_r=0x82100000\0" \ + "scriptaddr=0x87000000\0" + +#define NFS_BOOTCMD \ + "nfsargs=ip=:::::eth0: root=/dev/nfs\0" \ + "nfsboot=run setup; " \ + "setenv bootargs ${defargs} ${nfsargs} " \ + "${setupargs} ${vidargs}; echo Booting from NFS...;" \ + "dhcp ${kernel_addr_r} && " \ + "tftp ${fdt_addr_r} " FDT_FILE " && " \ + "run fdt_fixup && bootz ${kernel_addr_r} - ${fdt_addr_r}\0" \ + +#define SD_BOOTCMD \ + "sdargs=root=/dev/mmcblk0p2 ro rootwait\0" \ + "sdboot=run setup; setenv bootargs ${defargs} ${sdargs} " \ + "${setupargs} ${vidargs}; echo Booting from MMC/SD card...; " \ + "load mmc 0:1 ${kernel_addr_r} ${kernel_file} && " \ + "load mmc 0:1 ${fdt_addr_r} " FDT_FILE " && " \ + "run fdt_fixup && bootz ${kernel_addr_r} - ${fdt_addr_r}\0" \ + +#define UBI_BOOTCMD \ + "ubiargs=ubi.mtd=ubi root=ubi0:rootfs rw rootfstype=ubifs " \ + "ubi.fm_autoconvert=1\0" \ + "ubiboot=run setup; " \ + "setenv bootargs ${defargs} ${ubiargs} " \ + "${setupargs} ${vidargs}; echo Booting from NAND...; " \ + "ubi part ubi &&" \ + "ubi read ${kernel_addr_r} kernel && " \ + "ubi read ${fdt_addr_r} dtb && " \ + "run fdt_fixup && bootz ${kernel_addr_r} - ${fdt_addr_r}\0" \ + +#define CONFIG_BOOTCOMMAND "run ubiboot; " \ + "setenv fdtfile " FDT_FILE " && run distro_bootcmd;" + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(USB, usb, 0) \ + func(DHCP, dhcp, na) +#include <config_distro_bootcmd.h> + +#define DFU_ALT_NAND_INFO "imx6ull-bcb part 0,1;u-boot1 part 0,2;u-boot2 part 0,3;u-boot-env part 0,4;ubi partubi 0,5" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + BOOTENV \ + MEM_LAYOUT_ENV_SETTINGS \ + NFS_BOOTCMD \ + SD_BOOTCMD \ + UBI_BOOTCMD \ + "console=ttymxc0\0" \ + "defargs=user_debug=30\0" \ + "dfu_alt_info=" DFU_ALT_NAND_INFO "\0" \ + "fdt_board=eval-v3\0" \ + "fdt_fixup=;\0" \ + "ip_dyn=yes\0" \ + "kernel_file=zImage\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "setethupdate=if env exists ethaddr; then; else setenv ethaddr " \ + "00:14:2d:00:00:00; fi; tftpboot ${loadaddr} " \ + "${board}/flash_eth.img && source ${loadaddr}\0" \ + "setsdupdate=mmc rescan && setenv interface mmc && " \ + "fatload ${interface} 0:1 ${loadaddr} " \ + "${board}/flash_blk.img && source ${loadaddr}\0" \ + "setup=setenv setupargs " \ + "console=tty1 console=${console}" \ + ",${baudrate}n8 ${memargs} consoleblank=0\0" \ + "setupdate=run setsdupdate || run setusbupdate || run setethupdate\0" \ + "setusbupdate=usb start && setenv interface usb && " \ + "fatload ${interface} 0:1 ${loadaddr} " \ + "${board}/flash_blk.img && source ${loadaddr}\0" \ + "splashpos=m,m\0" \ + "videomode=video=ctfb:x:640,y:480,depth:18,pclk:39722,le:48,ri:16,up:33,lo:10,hs:96,vs:2,sync:0,vmode:0\0" \ + "vidargs=video=mxsfb:640x480-16@60" + +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x08000000) + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#if defined(CONFIG_ENV_IS_IN_NAND) +#define CONFIG_ENV_SECT_SIZE (128 * 1024) +#define CONFIG_ENV_OFFSET (28 * CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#endif + +/* NAND stuff */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +/* used to initialize CONFIG_SYS_NAND_BASE_LIST which is unused */ +#define CONFIG_SYS_NAND_BASE -1 +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_SYS_NAND_USE_FLASH_BBT + +/* Dynamic MTD partition support */ +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define MTDIDS_DEFAULT "nand0=gpmi-nand" +#define MTDPARTS_DEFAULT "mtdparts=gpmi-nand:" \ + "512k(mx6ull-bcb)," \ + "1536k(u-boot1)ro," \ + "1536k(u-boot2)ro," \ + "512k(u-boot-env)," \ + "-(ubi)" + +/* USB Configs */ +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET + +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 + +#define CONFIG_IMX_THERMAL + +#define CONFIG_USBD_HS + +/* USB Device Firmware Update support */ +#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_16M +#define DFU_DEFAULT_POLL_TIMEOUT 300 + +#ifdef CONFIG_VIDEO +#define CONFIG_VIDEO_MXS +#define MXS_LCDIF_BASE MX6UL_LCDIF1_BASE_ADDR +#define CONFIG_VIDEO_LOGO +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_VIDEO_BMP_LOGO +#endif + +#endif
FWIW, the above dependencies are now part of v2018.07. This still applies cleanly on v2018.07 so I guess I don't have to resend.
-- Stefan
-- Stefan
Stefan Agner
