[U-Boot] Please pull u-boot-rockchip
Hi Tom,
Here is a second installment for rockchip - more rk3399 support and some other fairly minor changes.
The following changes since commit 45b047e557bdcf68dc08e61cf207dd35b9ba8bbc:
Merge branch 'master' of git://git.denx.de/u-boot-nds32 (2016-09-30 21:59:11 -0400)
git://git.denx.de/u-boot-rockchip.git
for you to fetch changes up to 67171e13a3e0665b18c657a6704a22ca7900f4c3:
rockchip: add boot-mode support for rk3288, rk3036 (2016-10-01 18:36:55 -0600)
---------------------------------------------------------------- Jacob Chen (4): rockchip: move partitons define from 3036-kylin to 3036-common rockchip: rename board.c to rk3288-board.c rockchip: move common function from board-file to rk3036-board.c rockchip: add boot-mode support for rk3288, rk3036
Kever Yang (7): rockchip: rk3399: update PPLL and pmu_pclk frequency rockchip: rkpwm: fix the register sequence power: regulator: add pwm regulator rockchip: evb_rk3399: init vdd_center regulator Kconfig: rockchip: enable DM_PWM and DM_REGULATOR dts: evb-rk3399: add init voltage node for vdd-center config: evb-rk3399: enable pwm regulator
Sandy Patterson (3): rockchip: Fix SPL console output when ROCKCHIP_SPL_BACK_TO_BROM is enabled Disable SPL_MMC_SUPPORT if ROCKCHIP_SPL_BACK_TO_BROM is enabled. Enable ROCKCHIP_SPL_BACK_TO_BROM for rock2 board
Xu Ziyuan (2): rockchip: rk3288: sdram: fix DDR address range rockchip: miniarm: remove eMMC support
jacob2.chen (1): rockchip: add usb mass storage feature support for rk3036
arch/arm/Kconfig | 2 + arch/arm/dts/rk3288-miniarm.dtsi | 12 ---- arch/arm/dts/rk3399-evb.dts | 1 + arch/arm/include/asm/arch-rockchip/boot_mode.h | 19 +++++ arch/arm/include/asm/arch-rockchip/cru_rk3399.h | 4 +- arch/arm/include/asm/arch-rockchip/pwm.h | 2 +- arch/arm/mach-rockchip/Kconfig | 3 + arch/arm/mach-rockchip/Makefile | 3 +- arch/arm/mach-rockchip/rk3036-board.c | 122 +++++++++++++++++++++++++++++++ arch/arm/mach-rockchip/rk3288-board-spl.c | 5 +- arch/arm/mach-rockchip/{board.c => rk3288-board.c} | 50 +++++++++++-- arch/arm/mach-rockchip/rk3288/sdram_rk3288.c | 7 +- board/rockchip/evb_rk3036/evb_rk3036.c | 66 ----------------- board/rockchip/evb_rk3399/evb-rk3399.c | 6 ++ board/rockchip/kylin_rk3036/kylin_rk3036.c | 80 +-------------------- board/rockchip/miniarm_rk3288/miniarm-rk3288.c | 8 --- configs/evb-rk3399_defconfig | 1 + configs/rock2_defconfig | 2 + drivers/power/regulator/Kconfig | 10 +++ drivers/power/regulator/Makefile | 1 + drivers/power/regulator/pwm_regulator.c | 159 +++++++++++++++++++++++++++++++++++++++++ include/configs/kylin_rk3036.h | 27 ------- include/configs/miniarm_rk3288.h | 7 +- include/configs/rk3036_common.h | 17 +++++ include/configs/rk3288_common.h | 3 + include/configs/rock2.h | 9 +++ 26 files changed, 421 insertions(+), 205 deletions(-) create mode 100644 arch/arm/include/asm/arch-rockchip/boot_mode.h create mode 100644 arch/arm/mach-rockchip/rk3036-board.c rename arch/arm/mach-rockchip/{board.c => rk3288-board.c} (80%) create mode 100644 drivers/power/regulator/pwm_regulator.c
On Sun, Oct 02, 2016 at 03:31:40PM -0600, Simon Glass wrote:
Hi Tom,
