[U-Boot] [PATCH] ARM: omap3: Implement dpll5 (HSUSB clk) workaround for OMAP36xx/AM/DM37xx according to errata sprz318e.
In chapter 'Advisory 2.1 USB Host Clock Drift Causes USB Spec Non-compliance in Certain Configurations' of the TI Errata it is recommended to use certain div/mult values for the DPLL5 clock setup. So far u-boot used the old 34xx values, so I added the errata recommended values specificly for 36xx init only. Also, the FSEL registers exist no longer, so removed them from init.
Tested this on a AM3703 board with 19.2MHz oscillator, which previously couldnt lock the dpll5 (kernel complained). As a consequence the EHCI USB port wasnt usable in U-Boot and kernel. With this patch, kernel panics disappear and USB working fine in u-boot and kernel.
Signed-off-by: Andreas Naumann anaumann@ultratronik.de --- arch/arm/cpu/armv7/omap3/clock.c | 20 +++++++++++++++++++- arch/arm/cpu/armv7/omap3/lowlevel_init.S | 18 ++++++++++++++++++ arch/arm/include/asm/arch-omap3/clocks_omap3.h | 22 ++++++++++++++++++++++ 3 files changed, 59 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/omap3/clock.c b/arch/arm/cpu/armv7/omap3/clock.c index 81cc859..68833ba 100644 --- a/arch/arm/cpu/armv7/omap3/clock.c +++ b/arch/arm/cpu/armv7/omap3/clock.c @@ -491,6 +491,24 @@ static void dpll4_init_36xx(u32 sil_index, u32 clk_index) wait_on_value(ST_PERIPH_CLK, 2, &prcm_base->idlest_ckgen, LDELAY); }
+static void dpll5_init_36xx(u32 sil_index, u32 clk_index) +{ + struct prcm *prcm_base = (struct prcm *)PRCM_BASE; + dpll_param *ptr = (dpll_param *) get_36x_per2_dpll_param(); + + /* Moving it to the right sysclk base */ + ptr = ptr + clk_index; + + /* PER2 DPLL (DPLL5) */ + sr32(&prcm_base->clken2_pll, 0, 3, PLL_STOP); + wait_on_value(1, 0, &prcm_base->idlest2_ckgen, LDELAY); + sr32(&prcm_base->clksel5_pll, 0, 5, ptr->m2); /* set M2 (usbtll_fck) */ + sr32(&prcm_base->clksel4_pll, 8, 11, ptr->m); /* set m (11-bit multiplier) */ + sr32(&prcm_base->clksel4_pll, 0, 7, ptr->n); /* set n (7-bit divider)*/ + sr32(&prcm_base->clken2_pll, 0, 3, PLL_LOCK); /* lock mode */ + wait_on_value(1, 1, &prcm_base->idlest2_ckgen, LDELAY); +} + static void mpu_init_36xx(u32 sil_index, u32 clk_index) { struct prcm *prcm_base = (struct prcm *)PRCM_BASE; @@ -595,7 +613,7 @@ void prcm_init(void)
dpll3_init_36xx(0, clk_index); dpll4_init_36xx(0, clk_index); - dpll5_init_34xx(0, clk_index); + dpll5_init_36xx(0, clk_index); iva_init_36xx(0, clk_index); mpu_init_36xx(0, clk_index);
diff --git a/arch/arm/cpu/armv7/omap3/lowlevel_init.S b/arch/arm/cpu/armv7/omap3/lowlevel_init.S index eacfef8..66a1b48 100644 --- a/arch/arm/cpu/armv7/omap3/lowlevel_init.S +++ b/arch/arm/cpu/armv7/omap3/lowlevel_init.S @@ -480,6 +480,19 @@ per_36x_dpll_param: .word 26000, 432, 12, 9, 16, 9, 4, 3, 1 .word 38400, 360, 15, 9, 16, 5, 4, 3, 1
+per2_36x_dpll_param: +/* 12MHz */ +.word PER2_36XX_M_12, PER2_36XX_N_12, 0, PER2_36XX_M2_12 +/* 13MHz */ +.word PER2_36XX_M_13, PER2_36XX_N_13, 0, PER2_36XX_M2_13 +/* 19.2MHz */ +.word PER2_36XX_M_19P2, PER2_36XX_N_19P2, 0, PER2_36XX_M2_19P2 +/* 26MHz */ +.word PER2_36XX_M_26, PER2_36XX_N_26, 0, PER2_36XX_M2_26 +/* 38.4MHz */ +.word PER2_36XX_M_38P4, PER2_36XX_N_38P4, 0, PER2_36XX_M2_38P4 + + ENTRY(get_36x_mpu_dpll_param) adr r0, mpu_36x_dpll_param mov pc, lr @@ -499,3 +512,8 @@ ENTRY(get_36x_per_dpll_param) adr r0, per_36x_dpll_param mov pc, lr ENDPROC(get_36x_per_dpll_param) + +ENTRY(get_36x_per2_dpll_param) + adr r0, per2_36x_dpll_param + mov pc, lr +ENDPROC(get_36x_per2_dpll_param) diff --git a/arch/arm/include/asm/arch-omap3/clocks_omap3.h b/arch/arm/include/asm/arch-omap3/clocks_omap3.h index 5925ac4..59e61e8 100644 --- a/arch/arm/include/asm/arch-omap3/clocks_omap3.h +++ b/arch/arm/include/asm/arch-omap3/clocks_omap3.h @@ -336,4 +336,26 @@ #define PER_36XX_FSEL_38P4 0x07 #define PER_36XX_M2_38P4 0x09
+/* 36XX PER2 DPLL */ + +#define PER2_36XX_M_12 0x50 +#define PER2_36XX_N_12 0x00 +#define PER2_36XX_M2_12 0x08 + +#define PER2_36XX_M_13 0x1BB +#define PER2_36XX_N_13 0x05 +#define PER2_36XX_M2_13 0x08 + +#define PER2_36XX_M_19P2 0x32 +#define PER2_36XX_N_19P2 0x00 +#define PER2_36XX_M2_19P2 0x08 + +#define PER2_36XX_M_26 0x1BB +#define PER2_36XX_N_26 0x0B +#define PER2_36XX_M2_26 0x08 + +#define PER2_36XX_M_38P4 0x19 +#define PER2_36XX_N_38P4 0x00 +#define PER2_36XX_M2_38P4 0x08 + #endif /* endif _CLOCKS_OMAP3_H_ */
While this patch works with Linux that has been patched for this erratum, it will cause problems with some unpatched versions of Linux.
In particular, this patch sets CM_CLKSEL4_PLL to generate (nearly) 960MHz, and CM_CLKSEL5_PLL to divide by 8 to produce the required 120MHz, as recommended by sprz318e advisory 2.1.
Version 3.5 of Linux, and possibly others, configure CM_CLKSEL4_PLL (named "dpll5_ck") to generate 120MHz and leaves CM_CLKSEL5_PLL unmodified since its clock (named "dpll5_m2_ck") does not support set rate. If u-boot has configured a divisor of 8, the result is that the actual clock speed is 15MHz and USB does not work.
Not sure how this ought to be resolved; in my case I'm going to skip the u-boot patch and just use the Linux patch.
Peter
- struct prcm *prcm_base = (struct prcm *)PRCM_BASE;
- dpll_param *ptr = (dpll_param *) get_36x_per2_dpll_param();
- /* Moving it to the right sysclk base */
- ptr = ptr + clk_index;
- /* PER2 DPLL (DPLL5) */
- sr32(&prcm_base->clken2_pll, 0, 3, PLL_STOP);
- wait_on_value(1, 0, &prcm_base->idlest2_ckgen, LDELAY);
- sr32(&prcm_base->clksel5_pll, 0, 5, ptr->m2); /* set M2 (usbtll_fck) */
- sr32(&prcm_base->clksel4_pll, 8, 11, ptr->m); /* set m (11-bit multiplier) */
- sr32(&prcm_base->clksel4_pll, 0, 7, ptr->n); /* set n (7-bit divider)*/
- sr32(&prcm_base->clken2_pll, 0, 3, PLL_LOCK); /* lock mode */
- wait_on_value(1, 1, &prcm_base->idlest2_ckgen, LDELAY);
- static void mpu_init_36xx(u32 sil_index, u32 clk_index) { struct prcm *prcm_base = (struct prcm *)PRCM_BASE;
iva_init_36xx(0, clk_index); mpu_init_36xx(0, clk_index);dpll5_init_36xx(0, clk_index);
- ENTRY(get_36x_mpu_dpll_param) adr r0, mpu_36x_dpll_param mov pc, lr
- adr r0, per2_36x_dpll_param
- mov pc, lr
- #endif /* endif _CLOCKS_OMAP3_H_ */
Right. So Linux also needs to be patched for the erratum.
Yes. My point was that if you update u-boot alone, then try to use it to boot an unpatched Linux that assumes CM_CLKSEL5_PLL has its power-on value, USB will not work.
I think it's dangerous to assume that the mixture of an unpatched Linux with a patched u-boot will never occur, and the cause of the failure that results is pretty subtle. So whatever gets merged would be safer if it restored the default setting of CM_CLKSEL5_PLL prior to handing off control to Linux.
Peter
Agree, we should not apply this, till we also have an 'approved' patch for mainline linux posted. Right now we have a set of kernel hacks, but no agreed on method as the kernel maintainer did not have a board that suffered from the errata..
Regards,
On Fri, Aug 16, 2013 at 10:07 AM, Robert Nelson robertcnelson@gmail.com wrote:
btw: here's a version that seems to work on v3.11-rc5:
https://raw.github.com/RobertCNelson/armv7-multiplatform/v3.11.x/patches/oma...
Regards,
Am 16.08.2013 17:30, schrieb Robert Nelson:
Oh, I was not aware of that. But indeed i use a patched 3.1 kernel, see below. Some info on the history: In our design (19.2MHz crystal) we could clearly see the errata problem of high jitter on the 60MHz USB clock when (re-)booting a board that was already warmed up. Back then I applied a slightly extended kernel patch (see below) that I found on some kernel list. This reproducably did solve the problem with the jitter. We verified this with a high quality oscilloscope and numerous powercycles at different temperatures. The U-Boot in use was 2010.09 and some old X-Loader, both of which dont touch the PLL4/5 stuff.
Introducing the current U-Boot (to make use of SPL) brought up above described problems with the clock, probably due to setting the lock mode active. Hence this patch for DM37xx.
Unfortunately I dont find the origin of the kernel patch anymore, can somebody point me in the right direction? Otherwise I could open a new post on the linux-omap list. What do you think?
Here my applied kernel patch. I had it working both on kernel 3.1 as well as 3.4:
diff --git a/arch/arm/mach-omap2/clkt_clksel.c b/arch/arm/mach-omap2/clkt_clksel.c index e25364d..e378fe7 100644 --- a/arch/arm/mach-omap2/clkt_clksel.c +++ b/arch/arm/mach-omap2/clkt_clksel.c @@ -460,6 +460,21 @@ int omap2_clksel_set_rate(struct clk *clk, unsigned long rate) return 0; }
+int omap2_clksel_force_divisor(struct clk *clk, int new_div) +{ + u32 field_val; + + field_val = _divisor_to_clksel(clk, new_div); + if (field_val == ~0) + return -EINVAL; + + _write_clksel_reg(clk, field_val); + + clk->rate = clk->parent->rate / new_div; + + return 0; +} + /* * Clksel parent setting function - not passed in struct clk function * pointer - instead, the OMAP clock code currently assumes that any diff --git a/arch/arm/mach-omap2/clock.h b/arch/arm/mach-omap2/clock.h index 48ac568..3d2c899 100644 --- a/arch/arm/mach-omap2/clock.h +++ b/arch/arm/mach-omap2/clock.h @@ -61,6 +61,12 @@ void omap3_dpll_allow_idle(struct clk *clk); void omap3_dpll_deny_idle(struct clk *clk); u32 omap3_dpll_autoidle_read(struct clk *clk); int omap3_noncore_dpll_set_rate(struct clk *clk, unsigned long rate); +#if CONFIG_ARCH_OMAP3 +int omap3_noncore_dpll_program(struct clk *clk, u16 m, u8 n, u16 freqsel); +/* If you are using this function and not on OMAP3, you are + * Doing It Wrong(tm), so there is no stub. + */ +#endif int omap3_noncore_dpll_enable(struct clk *clk); void omap3_noncore_dpll_disable(struct clk *clk); int omap4_dpllmx_gatectrl_read(struct clk *clk); @@ -84,6 +90,7 @@ unsigned long omap2_clksel_recalc(struct clk *clk); long omap2_clksel_round_rate(struct clk *clk, unsigned long target_rate); int omap2_clksel_set_rate(struct clk *clk, unsigned long rate); int omap2_clksel_set_parent(struct clk *clk, struct clk *new_parent); +int omap2_clksel_force_divisor(struct clk *clk, int new_div);
/* clkt_iclk.c public functions */ extern void omap2_clkt_iclk_allow_idle(struct clk *clk); diff --git a/arch/arm/mach-omap2/clock3xxx.c b/arch/arm/mach-omap2/clock3xxx.c index 952c3e0..97d4192 100644 --- a/arch/arm/mach-omap2/clock3xxx.c +++ b/arch/arm/mach-omap2/clock3xxx.c @@ -40,6 +40,63 @@ /* needed by omap3_core_dpll_m2_set_rate() */ struct clk *sdrc_ick_p, *arm_fck_p;
+struct dpll_settings { + int rate, m, n, f; +}; + + +static int omap3_dpll5_apply_erratum21(struct clk *clk, struct clk *dpll5_m2) +{ + struct clk *sys_clk; + int i, rv; + static const struct dpll_settings precomputed[] = { + /* From DM3730 errata (sprz319e), table 36 + * +1 is because the values in the table are register values; + * dpll_program() will subtract one from what we give it, + * so ... + */ + { 13000000, 443+1, 5+1, 8 }, + { 12000000, 80, 0+1, 8 }, + { 19200000, 50, 0+1, 8 }, + { 26000000, 443+1, 11+1, 8 }, + { 38400000, 25, 0+1, 8 }, + }; + + sys_clk = clk_get(NULL, "sys_ck"); + + for (i = 0 ; i < (sizeof(precomputed)/sizeof(struct dpll_settings)) ; + ++i) { + const struct dpll_settings *d = &precomputed[i]; + if (sys_clk->rate == d->rate) { + rv = omap3_noncore_dpll_program(clk, d->m , d->n, 0); + if (rv) + return 1; + rv = omap2_clksel_force_divisor(dpll5_m2 , d->f); + return 1; + } + } + return 0; +} + +int omap3_dpll5_set_rate(struct clk *clk, unsigned long rate) +{ + struct clk *dpll5_m2; + int rv; + dpll5_m2 = clk_get(NULL, "dpll5_m2_ck"); + + if (cpu_is_omap3630() && rate == DPLL5_FREQ_FOR_USBHOST && + omap3_dpll5_apply_erratum21(clk, dpll5_m2)) { + return 1; + } + rv = omap3_noncore_dpll_set_rate(clk, rate); + if (rv) + goto out; + rv = clk_set_rate(dpll5_m2, rate); + +out: + return rv; +} + int omap3_dpll4_set_rate(struct clk *clk, unsigned long rate) { /* @@ -59,19 +116,14 @@ int omap3_dpll4_set_rate(struct clk *clk, unsigned long rate) void __init omap3_clk_lock_dpll5(void) { struct clk *dpll5_clk; - struct clk *dpll5_m2_clk;
dpll5_clk = clk_get(NULL, "dpll5_ck"); clk_set_rate(dpll5_clk, DPLL5_FREQ_FOR_USBHOST); - clk_enable(dpll5_clk);
- /* Program dpll5_m2_clk divider for no division */ - dpll5_m2_clk = clk_get(NULL, "dpll5_m2_ck"); - clk_enable(dpll5_m2_clk); - clk_set_rate(dpll5_m2_clk, DPLL5_FREQ_FOR_USBHOST); + /* dpll5_m2_ck is now (grottily!) handled by dpll5_clk's set routine, + * to cope with an erratum on DM3730 + */
- clk_disable(dpll5_m2_clk); - clk_disable(dpll5_clk); return; }
diff --git a/arch/arm/mach-omap2/clock3xxx.h b/arch/arm/mach-omap2/clock3xxx.h index 8bbeeaf..0ede513 100644 --- a/arch/arm/mach-omap2/clock3xxx.h +++ b/arch/arm/mach-omap2/clock3xxx.h @@ -10,6 +10,7 @@
int omap3xxx_clk_init(void); int omap3_dpll4_set_rate(struct clk *clk, unsigned long rate); +int omap3_dpll5_set_rate(struct clk *clk, unsigned long rate); int omap3_core_dpll_m2_set_rate(struct clk *clk, unsigned long rate); void omap3_clk_lock_dpll5(void);
diff --git a/arch/arm/mach-omap2/clock3xxx_data.c b/arch/arm/mach-omap2/clock3xxx_data.c index b9b8446..33f9853 100644 --- a/arch/arm/mach-omap2/clock3xxx_data.c +++ b/arch/arm/mach-omap2/clock3xxx_data.c @@ -942,7 +942,7 @@ static struct clk dpll5_ck = { .parent = &sys_ck, .dpll_data = &dpll5_dd, .round_rate = &omap2_dpll_round_rate, - .set_rate = &omap3_noncore_dpll_set_rate, + .set_rate = &omap3_dpll5_set_rate, .clkdm_name = "dpll5_clkdm", .recalc = &omap3_dpll_recalc, }; diff --git a/arch/arm/mach-omap2/dpll3xxx.c b/arch/arm/mach-omap2/dpll3xxx.c index f77022b..1909cd0 100644 --- a/arch/arm/mach-omap2/dpll3xxx.c +++ b/arch/arm/mach-omap2/dpll3xxx.c @@ -291,7 +291,7 @@ static void _lookup_sddiv(struct clk *clk, u8 *sd_div, u16 m, u8 n) * Program the DPLL with the supplied M, N values, and wait for the DPLL to * lock.. Returns -EINVAL upon error, or 0 upon success. */ -static int omap3_noncore_dpll_program(struct clk *clk, u16 m, u8 n, u16 freqsel) +int omap3_noncore_dpll_program(struct clk *clk, u16 m, u8 n, u16 freqsel) { struct dpll_data *dd = clk->dpll_data; u8 dco, sd_div;
On 07/09/2013 02:43 AM, Naumann Andreas wrote: > > In chapter 'Advisory 2.1 USB Host Clock Drift Causes USB Spec > Non-compliance in Certain Configurations' of the TI Errata it is recommended > to use certain div/mult values for the DPLL5 clock setup. > So far u-boot used the old 34xx values, so I added the errata > recommended values specificly for 36xx init only. > Also, the FSEL registers exist no longer, so removed them from init. > > Tested this on a AM3703 board with 19.2MHz oscillator, which previously > couldnt lock the dpll5 (kernel complained). As a consequence the EHCI USB > port wasnt usable in U-Boot and kernel. With this patch, kernel panics > disappear and USB working fine in u-boot and kernel. > > Signed-off-by: Andreas Naumann anaumann@ultratronik.de
What are the symptoms you see when this issue triggers?
What is the test case to trigger the error? Is it just running any USB I/O for long enough time?
I have a beagle-xm (DM3730 ES1.2) with me and would like to reproduce the error.
cheers, -roger
Hi Roger,
The symptoms are erroneous USB transaction, seen with a USB port analyzer. These only sometimes (not always) stall the USB communication, e.g. a USB mass storage device cant be read any longer.
Our scenario to reproduce was rebooting a warmed up board (either let it run for >5min or heat up in climate chamber).
However, the beagle probably uses a 26 MHz crystal oscillator (our board uses 19.2MHz), so the PLL5 dividers may be set in a way that the problem never occurs.
cheers, -roger
regards, Andreas
On Tue, Aug 20, 2013 at 5:15 AM, Andreas Naumann dev@andin.de wrote:
Hi Roger,
The xM uses a 26Mhz, but the errata still applies, as a number of customer boards do show the issue..
http://www.ti.com/lit/er/sprz319e/sprz319e.pdf page 113
Roger, this only seems to effect a small number of xM's, as it seems to vary on pll drift. So if your xM is fine, i do have a spare xM C, that pretty reliably shows the issue after transferring a large amount of data over the usb port... I had traded a good xM with a customer such that i could keep re-basing our out of tree dpll5 tweak..
Regards,
Applied to u-boot-ti/master with a prototype added to <asm/arch-omap3/clock.h> to avoid a warning.
participants (6)
Andreas Naumann
Andreas Naumann
Peter A. Bigot
Robert Nelson
Roger Quadros
