Hi Tom,
please pull from u-boot-imx, thanks !
The following changes since commit 08cca188c120b8337600091c94dc0e211cd03e10:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-usb (2021-02-26 15:11:08 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-20210303
for you to fetch changes up to 03bf8436a3a5b19ff4ae23868dd479acc050ff08:
board: gateworks: imx8mm: Add Gateworks Venice board support (2021-03-03 14:15:02 +0100)
---------------------------------------------------------------- i.MX for 2021.04 ----------------
- new boards: - i.MX8MN Beacon EmbeddedWorks (2GB) - Gateworks Venice imx8mm - convert to DM: - imx53-qsb, mx53loco, mx51evk, mx23-evk - Fixes : - Network : FEC ethernet quirks - DH dh-imx6
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/6597
---------------------------------------------------------------- Adam Ford (1): imx: Add 2GB lpddr support for i.MX8MN Beacon EmbeddedWorks devkit.
Fabio Estevam (13): imx53-qsb: Import devicetree files from Linux mx53loco: Convert to driver model ARM: dts: imx53-qsb: Describe the esdhc1 card detect pin mx53loco: Add myself as maintainer mmc: fsl_esdhc_imx: Add a compatible for i.MX51 imx51-babbage: Import devicetree files from Linux mx51evk: Convert to driver model mx51evk: Add myself as maintainer mx23-evk: Import devicetree file from Linux mx23evk: Convert to driver model mx23evk: Add myself as maintainer tools: imx8mimage: Restore the original __ALIGN_MASK() macro ARM: dts: imx8mq-evk: Remove u-boot,off-on-delay-us property
Frieder Schrempf (1): Respect that some compression algos can be enabled separately for SPL
Haibo Chen (1): mmc: fsl_esdhc_imx: fix the DTOCV to 0xE
Marek Vasut (8): ARM: imx: Revert "dh_imx6: Switch to full DM-aware" ARM: imx6: dh-imx6: Enable support for applying DTO ARM: imx6: dh-imx6: Drop the SF hunk in config ARM: imx6: mx6sabre-common: Replace fatload with FS_GENERIC load ARM: imx6: mx6sabre-common: Search for boot components in /boot too ARM: imx: Add missing FEC ethernet quirk for MX8M ARM: imx: Do not hard-code MX8M MMU table DRAM entry offset ARM: imx: Include u-boot.img in u-boot-with-spl.imx if OF_SEPARATE=y
Oleksandr Suvorov (2): ARM: imx8: Add missing FEC ENET quirk for i.MX8/i.MX8X board: toradex: move RGMII delays to PHY side
Peter Bergin (1): doc: board: freescale: imx8mp_evk: update to newer versions and change ATF_LOAD_ADDR
Sean Anderson (1): ARM: mx6: Add function to set serial#
Tim Harvey (3): thermal: imx_tmu: enable monitoring and default alert/critical arm: dts: imx8mm: add Gateworks i.MX8 Mini Dev kits board: gateworks: imx8mm: Add Gateworks Venice board support
Ye Li (2): mx6sabre: Fix boot failure arm: dts: imx8mp-evk: Add FEC PHY reset timing
Makefile | 5 +- arch/arm/dts/Makefile | 11 + arch/arm/dts/fsl-imx8qm-apalis.dts | 2 +- arch/arm/dts/fsl-imx8qxp-apalis.dts | 2 +- arch/arm/dts/imx23-evk-u-boot.dtsi | 4 + arch/arm/dts/imx23-evk.dts | 145 +++++++++++ arch/arm/dts/imx23-pinfunc.h | 333 +++++++++++++++++++++++++ arch/arm/dts/imx23-u-boot.dtsi | 14 ++ arch/arm/dts/imx23.dtsi | 636 +++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx51-babbage.dts | 726 ++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx51-pinfunc.h | 768 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx51.dtsi | 654 +++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx53-qsb-common.dtsi | 387 +++++++++++++++++++++++++++++ arch/arm/dts/imx53-qsb.dts | 111 +++++++++ arch/arm/dts/imx8mm-venice-gw700x-u-boot.dtsi | 105 ++++++++ arch/arm/dts/imx8mm-venice-gw700x.dtsi | 495 +++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx8mm-venice-gw71xx-0x-u-boot.dtsi | 5 + arch/arm/dts/imx8mm-venice-gw71xx-0x.dts | 19 ++ arch/arm/dts/imx8mm-venice-gw71xx.dtsi | 186 ++++++++++++++ arch/arm/dts/imx8mm-venice-gw72xx-0x-u-boot.dtsi | 5 + arch/arm/dts/imx8mm-venice-gw72xx-0x.dts | 19 ++ arch/arm/dts/imx8mm-venice-gw72xx.dtsi | 311 +++++++++++++++++++++++ arch/arm/dts/imx8mm-venice-gw73xx-0x-u-boot.dtsi | 5 + arch/arm/dts/imx8mm-venice-gw73xx-0x.dts | 19 ++ arch/arm/dts/imx8mm-venice-gw73xx.dtsi | 362 +++++++++++++++++++++++++++ arch/arm/dts/imx8mm-venice-u-boot.dtsi | 103 ++++++++ arch/arm/dts/imx8mm-venice.dts | 152 ++++++++++++ arch/arm/dts/imx8mp-evk-u-boot.dtsi | 2 + arch/arm/dts/imx8mq-evk-u-boot.dtsi | 4 - arch/arm/include/asm/arch-imx8/imx-regs.h | 2 + arch/arm/include/asm/arch-imx8m/imx-regs.h | 1 + arch/arm/mach-imx/Makefile | 4 +- arch/arm/mach-imx/imx8m/Kconfig | 7 + arch/arm/mach-imx/imx8m/soc.c | 19 +- arch/arm/mach-imx/mx6/soc.c | 37 +++ board/beacon/imx8mn/Kconfig | 4 + board/beacon/imx8mn/MAINTAINERS | 1 + board/beacon/imx8mn/Makefile | 7 +- board/beacon/imx8mn/lpddr4_2g_timing.c | 1440 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/freescale/mx23evk/MAINTAINERS | 2 + board/freescale/mx23evk/mx23evk.c | 23 -- board/freescale/mx51evk/MAINTAINERS | 1 + board/freescale/mx51evk/mx51evk.c | 186 +------------- board/freescale/mx53loco/MAINTAINERS | 1 + board/freescale/mx53loco/mx53loco.c | 124 ---------- board/gateworks/venice/Kconfig | 12 + board/gateworks/venice/MAINTAINERS | 7 + board/gateworks/venice/Makefile | 12 + board/gateworks/venice/README | 34 +++ board/gateworks/venice/gsc.c | 687 +++++++++++++++++++++++++++++++++++++++++++++++++++ board/gateworks/venice/gsc.h | 39 +++ board/gateworks/venice/imx8mm_venice.c | 133 ++++++++++ board/gateworks/venice/lpddr4_timing.c | 2505 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/gateworks/venice/lpddr4_timing.h | 12 + board/gateworks/venice/spl.c | 205 ++++++++++++++++ common/image.c | 24 +- configs/dh_imx6_defconfig | 7 +- configs/imx8mm_venice_defconfig | 113 +++++++++ configs/imx8mn_beacon_2g_defconfig | 133 ++++++++++ configs/mx23evk_defconfig | 14 +- configs/mx51evk_defconfig | 19 +- configs/mx53loco_defconfig | 22 +- configs/mx6sabreauto_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + doc/board/freescale/imx8mp_evk.rst | 27 +- drivers/mmc/fsl_esdhc_imx.c | 7 + drivers/thermal/imx_tmu.c | 6 + include/configs/apalis-imx8.h | 3 - include/configs/apalis-imx8x.h | 4 - include/configs/capricorn-common.h | 1 - include/configs/colibri-imx8x.h | 2 - include/configs/imx8mm_venice.h | 125 ++++++++++ include/configs/imx8mn_beacon.h | 4 + include/configs/imx8qm_mek.h | 1 - include/configs/imx8qm_rom7720.h | 1 - include/configs/imx8qxp_mek.h | 1 - include/configs/mx51evk.h | 8 - include/configs/mx53loco.h | 6 - include/configs/mx6sabre_common.h | 9 +- tools/imx8mimage.c | 8 +- 80 files changed, 11232 insertions(+), 410 deletions(-) create mode 100644 arch/arm/dts/imx23-evk-u-boot.dtsi create mode 100644 arch/arm/dts/imx23-evk.dts create mode 100644 arch/arm/dts/imx23-pinfunc.h create mode 100644 arch/arm/dts/imx23-u-boot.dtsi create mode 100644 arch/arm/dts/imx23.dtsi create mode 100644 arch/arm/dts/imx51-babbage.dts create mode 100644 arch/arm/dts/imx51-pinfunc.h create mode 100644 arch/arm/dts/imx51.dtsi create mode 100644 arch/arm/dts/imx53-qsb-common.dtsi create mode 100644 arch/arm/dts/imx53-qsb.dts create mode 100644 arch/arm/dts/imx8mm-venice-gw700x-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-venice-gw700x.dtsi create mode 100644 arch/arm/dts/imx8mm-venice-gw71xx-0x-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-venice-gw71xx-0x.dts create mode 100644 arch/arm/dts/imx8mm-venice-gw71xx.dtsi create mode 100644 arch/arm/dts/imx8mm-venice-gw72xx-0x-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-venice-gw72xx-0x.dts create mode 100644 arch/arm/dts/imx8mm-venice-gw72xx.dtsi create mode 100644 arch/arm/dts/imx8mm-venice-gw73xx-0x-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-venice-gw73xx-0x.dts create mode 100644 arch/arm/dts/imx8mm-venice-gw73xx.dtsi create mode 100644 arch/arm/dts/imx8mm-venice-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-venice.dts create mode 100644 board/beacon/imx8mn/lpddr4_2g_timing.c create mode 100644 board/gateworks/venice/Kconfig create mode 100644 board/gateworks/venice/MAINTAINERS create mode 100644 board/gateworks/venice/Makefile create mode 100644 board/gateworks/venice/README create mode 100644 board/gateworks/venice/gsc.c create mode 100644 board/gateworks/venice/gsc.h create mode 100644 board/gateworks/venice/imx8mm_venice.c create mode 100644 board/gateworks/venice/lpddr4_timing.c create mode 100644 board/gateworks/venice/lpddr4_timing.h create mode 100644 board/gateworks/venice/spl.c create mode 100644 configs/imx8mm_venice_defconfig create mode 100644 configs/imx8mn_beacon_2g_defconfig create mode 100644 include/configs/imx8mm_venice.h
Best regards, Stefano
On Wed, Mar 03, 2021 at 03:20:43PM +0100, Stefano Babic wrote:
Hi Tom,
Stefano Babic
