[PATCH v1] serdes: ls1046afwry: Disable sgmi support
LS1046A SoC serdes protocol 0x3040 supports both sgmi and qsgmii, however frwy-ls1046a supports only QSGMI on board. Disable unsupported sgmii on bord.
Signed-off-by: Pramod Kumar pramod.kumar_1@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/ls1046a_serdes.c | 56 +++++++++++++++++++--- 1 file changed, 50 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1046a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1046a_serdes.c index 9347e51..e5b2269 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls1046a_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1046a_serdes.c @@ -38,6 +38,31 @@ static struct serdes_config serdes1_cfg_tbl[] = { {} };
+static struct serdes_config serdes1_cfg_tbl_frwy_ls1046a[] = { + /* SerDes 1 */ + {0x3333, {SGMII_FM1_DTSEC9, SGMII_FM1_DTSEC10, SGMII_FM1_DTSEC5, + SGMII_FM1_DTSEC6} }, + {0x1133, {XFI_FM1_MAC9, XFI_FM1_MAC10, SGMII_FM1_DTSEC5, + SGMII_FM1_DTSEC6} }, + {0x1333, {XFI_FM1_MAC9, SGMII_FM1_DTSEC10, SGMII_FM1_DTSEC5, + SGMII_FM1_DTSEC6} }, + {0x2333, {SGMII_2500_FM1_DTSEC9, SGMII_FM1_DTSEC10, SGMII_FM1_DTSEC5, + SGMII_FM1_DTSEC6} }, + {0x2233, {SGMII_2500_FM1_DTSEC9, SGMII_2500_FM1_DTSEC10, + SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, + {0x1040, {XFI_FM1_MAC9, NONE, QSGMII_FM1_A, NONE} }, + {0x2040, {SGMII_2500_FM1_DTSEC9, NONE, QSGMII_FM1_A, NONE} }, + {0x1163, {XFI_FM1_MAC9, XFI_FM1_MAC10, PCIE1, SGMII_FM1_DTSEC6} }, + {0x2263, {SGMII_2500_FM1_DTSEC9, SGMII_2500_FM1_DTSEC10, PCIE1, + SGMII_FM1_DTSEC6} }, + {0x3363, {SGMII_FM1_DTSEC9, SGMII_FM1_DTSEC10, PCIE1, + SGMII_FM1_DTSEC6} }, + {0x2223, {SGMII_2500_FM1_DTSEC9, SGMII_2500_FM1_DTSEC10, + SGMII_2500_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, + {0x3040, {NONE, NONE, QSGMII_FM1_A, NONE} }, + {} +}; + static struct serdes_config serdes2_cfg_tbl[] = { /* SerDes 2 */ {0x8888, {PCIE1, PCIE1, PCIE1, PCIE1} }, @@ -56,14 +81,26 @@ static struct serdes_config *serdes_cfg_tbl[] = { serdes2_cfg_tbl, };
+static struct serdes_config *serdes_cfg_tbl_frwy_ls1046a[] = { + serdes1_cfg_tbl_frwy_ls1046a, + serdes2_cfg_tbl, +}; + enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane) { struct serdes_config *ptr; + char *board_type = CONFIG_SYS_BOARD;
- if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) - return 0; + if (!strncmp(board_type, "ls1046afrwy", strlen("ls1046afrwy"))) { + if (serdes >= ARRAY_SIZE(serdes_cfg_tbl_frwy_ls1046a)) + return 0; + ptr = serdes_cfg_tbl_frwy_ls1046a[serdes]; + } else { + if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + ptr = serdes_cfg_tbl[serdes]; + }
- ptr = serdes_cfg_tbl[serdes]; while (ptr->protocol) { if (ptr->protocol == cfg) return ptr->lanes[lane]; @@ -77,11 +114,18 @@ int is_serdes_prtcl_valid(int serdes, u32 prtcl) { int i; struct serdes_config *ptr; + char *board_type = CONFIG_SYS_BOARD;
- if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) - return 0; + if (!strncmp(board_type, "ls1046afrwy", strlen("ls1046afrwy"))) { + if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + ptr = serdes_cfg_tbl_frwy_ls1046a[serdes]; + } else { + if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + ptr = serdes_cfg_tbl[serdes]; + }
- ptr = serdes_cfg_tbl[serdes]; while (ptr->protocol) { if (ptr->protocol == prtcl) break;
Pramod Kumar
