[PATCH] arm: dts: k3-am654-base-board: Enable I2C nodes
Add DT nodes for main domain I2Cs and its slave devices
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- arch/arm/dts/k3-am654-base-board.dts | 48 ++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+)
diff --git a/arch/arm/dts/k3-am654-base-board.dts b/arch/arm/dts/k3-am654-base-board.dts index 375f1d089c7d..5058b6c88e96 100644 --- a/arch/arm/dts/k3-am654-base-board.dts +++ b/arch/arm/dts/k3-am654-base-board.dts @@ -64,6 +64,29 @@ AM65X_IOPAD(0x02c0, PIN_OUTPUT, 0) /* (AC8) USB1_DRVVBUS */ >; }; + + main_i2c2_pins_default: main-i2c2-pins-default { + pinctrl-single,pins = < + AM65X_IOPAD(0x0074, PIN_INPUT, 5) /* (T27) GPMC0_CSn3.I2C2_SCL */ + AM65X_IOPAD(0x0070, PIN_INPUT, 5) /* (R25) GPMC0_CSn2.I2C2_SDA */ + >; + }; +}; + +&main_pmx1 { + main_i2c0_pins_default: main-i2c0-pins-default { + pinctrl-single,pins = < + AM65X_IOPAD(0x0000, PIN_INPUT, 0) /* (D20) I2C0_SCL */ + AM65X_IOPAD(0x0004, PIN_INPUT, 0) /* (C21) I2C0_SDA */ + >; + }; + + main_i2c1_pins_default: main-i2c1-pins-default { + pinctrl-single,pins = < + AM65X_IOPAD(0x0008, PIN_INPUT, 0) /* (B21) I2C1_SCL */ + AM65X_IOPAD(0x000c, PIN_INPUT, 0) /* (E21) I2C1_SDA */ + >; + }; };
&wkup_pmx0 { @@ -112,6 +135,31 @@ }; };
+&main_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c0_pins_default>; + clock-frequency = <400000>; + + pca9555: gpio@21 { + compatible = "nxp,pca9555"; + reg = <0x21>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + +&main_i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c1_pins_default>; + clock-frequency = <400000>; +}; + +&main_i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c2_pins_default>; + clock-frequency = <400000>; +}; + &dwc3_1 { status = "okay"; };
Applied to u-boot-ti next branch.
Thanks and regards, Lokesh
Lokesh Vutla
Vignesh Raghavendra
