[U-Boot] [PATCH v2] bootm: Reinstate special case for standalone images
For standalone images, bootm had a special case where the OS boot function was NULL but did actually exist. It was just called manually.
This was removed by commit 35fc84fa which checks for the non-existence of this function before the special case is examined.
There is no obvious reason why standalone is handled with a special case. Adjust the code so that standalone has a normal OS boot function. We still need a special case for when the function returns, but at least we can avoid the main problem.
This is intended to fix the reported:
ERROR: booting os 'U-Boot' (17) is not supported
but needs testing.
Changes in v2: - Change IH_TYPE_STANDALONE to IH_OS_U_BOOT
common/cmd_bootm.c | 21 ++++++++++++--------- 1 file changed, 12 insertions(+), 9 deletions(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 3f57659..a59ee95 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -82,6 +82,9 @@ static int do_imls(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); static void fixup_silent_linux(void); #endif
+static int do_bootm_standalone(int flag, int argc, char * const argv[], + bootm_headers_t *images); + static const void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], bootm_headers_t *images, ulong *os_data, ulong *os_len); @@ -139,6 +142,7 @@ static boot_os_fn do_bootm_integrity; #endif
static boot_os_fn *boot_os[] = { + [IH_OS_U_BOOT] = do_bootm_standalone, #ifdef CONFIG_BOOTM_LINUX [IH_OS_LINUX] = do_bootm_linux, #endif @@ -499,17 +503,18 @@ static int bootm_load_os(bootm_headers_t *images, unsigned long *load_end, return 0; }
-static int bootm_start_standalone(int argc, char * const argv[]) +static int do_bootm_standalone(int flag, int argc, char * const argv[], + bootm_headers_t *images) { char *s; int (*appl)(int, char * const []);
/* Don't start if "autostart" is set to "no" */ if (((s = getenv("autostart")) != NULL) && (strcmp(s, "no") == 0)) { - setenv_hex("filesize", images.os.image_len); + setenv_hex("filesize", images->os.image_len); return 0; } - appl = (int (*)(int, char * const []))(ulong)ntohl(images.ep); + appl = (int (*)(int, char * const []))(ulong)ntohl(images->ep); (*appl)(argc, argv); return 0; } @@ -535,14 +540,12 @@ static cmd_tbl_t cmd_bootm_sub[] = { static int boot_selected_os(int argc, char * const argv[], int state, bootm_headers_t *images, boot_os_fn *boot_fn) { - if (images->os.type == IH_TYPE_STANDALONE) { - /* This may return when 'autostart' is 'no' */ - bootm_start_standalone(argc, argv); - return 0; - } arch_preboot_os(); boot_fn(state, argc, argv, images); - if (state == BOOTM_STATE_OS_FAKE_GO) /* We expect to return */ + + /* Stand-alone may return when 'autostart' is 'no' */ + if (images->os.type == IH_TYPE_STANDALONE || + state == BOOTM_STATE_OS_FAKE_GO) /* We expect to return */ return 0; bootstage_error(BOOTSTAGE_ID_BOOT_OS_RETURNED); #ifdef DEBUG
but needs testing.
