[PATCH 1/1] x86: rename CONFIG_STACK_SIZE
Configuration variables should have the same meaning independent of the architecture. x86 and ARM both use CONFIG_STACK_SIZE:
* x86: U-Boot's runtime stack size during reboot * ARM: max stack size that can be used by U-Boot
Rename the x86 configuration variable to CONFIG_STACK_SIZE_REBOOT
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- arch/x86/Kconfig | 2 +- arch/x86/lib/fsp/fsp_dram.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index ff4f06ed79..f677472501 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -802,7 +802,7 @@ config S3_VGA_ROM_RUN graphics console won't work without VGA options ROMs. Set it to N if your kernel is only on a serial console.
-config STACK_SIZE +config STACK_SIZE_RESUME hex depends on HAVE_ACPI_RESUME default 0x1000 diff --git a/arch/x86/lib/fsp/fsp_dram.c b/arch/x86/lib/fsp/fsp_dram.c index 01d498c21e..faa819fab4 100644 --- a/arch/x86/lib/fsp/fsp_dram.c +++ b/arch/x86/lib/fsp/fsp_dram.c @@ -121,7 +121,7 @@ unsigned int install_e820_map(unsigned int max_entries, ulong stack_size;
stack_size = CONFIG_IS_ENABLED(HAVE_ACPI_RESUME, - (CONFIG_STACK_SIZE), (0)); + (CONFIG_STACK_SIZE_RESUME), (0)); /* * Everything between U-Boot's stack and ram top needs to be * reserved in order for ACPI S3 resume to work. -- 2.27.0
