[U-Boot] [PATCH 1/2 u-boot-next] Move libgcc inclusion from common Makefile to platform configs files
This patch moves the libgcc Makefile inclusion from the toplevel Makefile to the arch_config.mk files. This is in preparation for the ARM architecture to move away from including libgcc function and only using self-contained U-Boot functions as done in Linux.
Currently in the next branch all the ARM boards that use the nand are broken due to the adding of the 64 Bit device size support. In the past we have seen problems with different toolchains due to EABI, FPU as example. With this patch and the following one we move away from all these problems and we will be able to have full control to have a functions embedded into u-boot.
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com Cc: Stefan Roese sr@denx.de --- Makefile | 2 +- api_examples/Makefile | 4 +--- arm_config.mk | 2 ++ avr32_config.mk | 2 ++ blackfin_config.mk | 2 ++ board/netstar/Makefile | 4 +--- board/sl8245/config.mk | 1 - board/trab/Makefile | 2 -- board/voiceblue/Makefile | 4 +--- examples/Makefile | 2 +- i386_config.mk | 2 ++ m68k_config.mk | 2 ++ microblaze_config.mk | 2 ++ mips_config.mk | 2 ++ nios2_config.mk | 2 ++ nios_config.mk | 2 ++ ppc_config.mk | 2 ++ sh_config.mk | 2 ++ sparc_config.mk | 2 ++ 19 files changed, 29 insertions(+), 14 deletions(-)
diff --git a/Makefile b/Makefile index 37356af..be12164 100644 --- a/Makefile +++ b/Makefile @@ -280,7 +280,7 @@ LIBBOARD = board/$(BOARDDIR)/lib$(BOARD).a LIBBOARD := $(addprefix $(obj),$(LIBBOARD))
# Add GCC lib -PLATFORM_LIBS += -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc +PLATFORM_LIBS += $(PLATFORM_LIBGCC)
# The "tools" are needed early, so put this first # Don't include stuff already done in $(LIBS) diff --git a/api_examples/Makefile b/api_examples/Makefile index 4c01437..4bfa7e6 100644 --- a/api_examples/Makefile +++ b/api_examples/Makefile @@ -56,8 +56,6 @@ OBJS := $(addprefix $(obj),$(COBJS)) ELF := $(addprefix $(obj),$(ELF)) BIN := $(addprefix $(obj),$(BIN))
-gcclibdir := $(shell dirname `$(CC) -print-libgcc-file-name`) - CPPFLAGS += -I..
all: $(obj).depend $(OBJS) $(LIB) $(ELF) $(BIN) @@ -70,7 +68,7 @@ $(ELF): $(obj)%: $(obj)%.o $(LIB) $(LD) $(obj)crt0.o -Ttext $(LOAD_ADDR) \ -o $@ $< $(LIB) \ - -L$(gcclibdir) -lgcc + $(PLATFORM_LIBGCC)
$(BIN): $(obj)%.bin: $(obj)% diff --git a/arm_config.mk b/arm_config.mk index c4cf99d..b88a3f2 100644 --- a/arm_config.mk +++ b/arm_config.mk @@ -24,3 +24,5 @@ PLATFORM_CPPFLAGS += -DCONFIG_ARM -D__ARM__
LDSCRIPT := $(SRCTREE)/cpu/$(CPU)/u-boot.lds + +PLATFORM_LIBGCC += -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc diff --git a/avr32_config.mk b/avr32_config.mk index 441caa4..8569d5f 100644 --- a/avr32_config.mk +++ b/avr32_config.mk @@ -23,3 +23,5 @@
PLATFORM_RELFLAGS += -ffixed-r5 -fPIC -mno-init-got -mrelax PLATFORM_LDFLAGS += --relax + +PLATFORM_LIBGCC += -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc diff --git a/blackfin_config.mk b/blackfin_config.mk index 05077c8..9a3c8b2 100644 --- a/blackfin_config.mk +++ b/blackfin_config.mk @@ -49,3 +49,5 @@ LDR_FLAGS += --quiet endif
LDR_FLAGS += $(LDR_FLAGS-y) + +PLATFORM_LIBGCC += -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc diff --git a/board/netstar/Makefile b/board/netstar/Makefile index 91bac38..1cc2722 100644 --- a/board/netstar/Makefile +++ b/board/netstar/Makefile @@ -36,8 +36,6 @@ SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) eeprom.c \ OBJS := $(addprefix $(obj),$(COBJS)) SOBJS := $(addprefix $(obj),$(SOBJS))
-gcclibdir := $(shell dirname `$(CC) -print-libgcc-file-name`) - LOAD_ADDR = 0x10400000 LDSCRIPT = $(TOPDIR)/board/$(BOARDDIR)/eeprom.lds lnk = $(if $(obj),$(obj),.) @@ -55,7 +53,7 @@ $(obj)eeprom.srec: $(obj)eeprom.o $(obj)eeprom_start.o -o $(<:.o=) -e eeprom eeprom.o eeprom_start.o \ -L$(obj)../../examples -lstubs \ -L$(obj)../../lib_generic -lgeneric \ - -L$(gcclibdir) -lgcc + $(PLATFROM_LIBGCC) $(OBJCOPY) -O srec $(<:.o=) $@
$(obj)eeprom.bin: $(obj)eeprom.srec diff --git a/board/sl8245/config.mk b/board/sl8245/config.mk index 022512b..299fc6c 100644 --- a/board/sl8245/config.mk +++ b/board/sl8245/config.mk @@ -28,4 +28,3 @@ TEXT_BASE = 0xFFF00000
PLATFORM_CPPFLAGS += -DTEXT_BASE=$(TEXT_BASE) -PLATFORM_LIBS += $(shell $(CC) -print-libgcc-file-name) diff --git a/board/trab/Makefile b/board/trab/Makefile index 30e5fbb..a3661c4 100644 --- a/board/trab/Makefile +++ b/board/trab/Makefile @@ -36,8 +36,6 @@ SOBJS := $(addprefix $(obj),$(SOBJS))
OBJS_FKT := $(addprefix $(obj),$(COBJS_FKT))
-gcclibdir := $(shell dirname `$(CC) -print-libgcc-file-name`) - LOAD_ADDR = 0xc100000
######################################################################### diff --git a/board/voiceblue/Makefile b/board/voiceblue/Makefile index e7c1cbb..0d1e079 100644 --- a/board/voiceblue/Makefile +++ b/board/voiceblue/Makefile @@ -33,8 +33,6 @@ SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) eeprom.c eeprom_start.S OBJS := $(addprefix $(obj),$(COBJS)) SOBJS := $(addprefix $(obj),$(SOBJS))
-gcclibdir := $(shell dirname `$(CC) -print-libgcc-file-name`) - LOAD_ADDR = 0x10400000 LDSCRIPT = $(TOPDIR)/board/$(BOARDDIR)/eeprom.lds lnk = $(if $(obj),$(obj),.) @@ -49,7 +47,7 @@ $(obj)eeprom.srec: $(obj)eeprom.o $(obj)eeprom_start.o -o $(<:.o=) -e eeprom eeprom.o eeprom_start.o \ -L$(obj)../../examples -lstubs \ -L$(obj)../../lib_generic -lgeneric \ - -L$(gcclibdir) -lgcc + $(PLATFROM_LIBGCC) $(OBJCOPY) -O srec $(<:.o=) $@
$(obj)eeprom.bin: $(obj)eeprom.srec diff --git a/examples/Makefile b/examples/Makefile index dbcfa92..5bd13f1 100644 --- a/examples/Makefile +++ b/examples/Makefile @@ -178,7 +178,7 @@ $(ELF): $(obj)%: $(obj)%.o $(LIB) $(LD) -g $(EX_LDFLAGS) -Ttext $(LOAD_ADDR) \ -o $@ -e $(SYM_PREFIX)$(notdir $(<:.o=)) $< $(LIB) \ - -L$(gcclibdir) -lgcc + $(PLATFORM_LIBGCC)
$(SREC): $(obj)%.srec: $(obj)% diff --git a/i386_config.mk b/i386_config.mk index 9e6d37d..03b2538 100644 --- a/i386_config.mk +++ b/i386_config.mk @@ -22,3 +22,5 @@ #
PLATFORM_CPPFLAGS += -DCONFIG_I386 -D__I386__ + +PLATFORM_LIBGCC += -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc diff --git a/m68k_config.mk b/m68k_config.mk index 12bd27c..f0c963b 100644 --- a/m68k_config.mk +++ b/m68k_config.mk @@ -23,3 +23,5 @@
PLATFORM_CPPFLAGS += -DCONFIG_M68K -D__M68K__ PLATFORM_LDFLAGS += -n + +PLATFORM_LIBGCC += -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc diff --git a/microblaze_config.mk b/microblaze_config.mk index e44c79e..5f78c5c 100644 --- a/microblaze_config.mk +++ b/microblaze_config.mk @@ -25,3 +25,5 @@ #
PLATFORM_CPPFLAGS += -ffixed-r31 -D__microblaze__ + +PLATFORM_LIBGCC += -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc diff --git a/mips_config.mk b/mips_config.mk index 05eb05d..3ae6c19 100644 --- a/mips_config.mk +++ b/mips_config.mk @@ -23,6 +23,8 @@
PLATFORM_CPPFLAGS += -DCONFIG_MIPS -D__MIPS__
+PLATFORM_LIBGCC += -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc + # # From Linux arch/mips/Makefile # diff --git a/nios2_config.mk b/nios2_config.mk index 3f23b56..1bf4992 100644 --- a/nios2_config.mk +++ b/nios2_config.mk @@ -24,3 +24,5 @@
PLATFORM_CPPFLAGS += -DCONFIG_NIOS2 -D__NIOS2__ PLATFORM_CPPFLAGS += -ffixed-r15 -G0 + +PLATFORM_LIBGCC += -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc diff --git a/nios_config.mk b/nios_config.mk index 1cf0f32..d72db7d 100644 --- a/nios_config.mk +++ b/nios_config.mk @@ -23,3 +23,5 @@ #
PLATFORM_CPPFLAGS += -m32 -DCONFIG_NIOS -D__NIOS__ -ffixed-g7 -gstabs + +PLATFORM_LIBGCC += -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc diff --git a/ppc_config.mk b/ppc_config.mk index c95b3b1..74a4f11 100644 --- a/ppc_config.mk +++ b/ppc_config.mk @@ -24,6 +24,8 @@ PLATFORM_CPPFLAGS += -DCONFIG_PPC -D__powerpc__ PLATFORM_LDFLAGS += -n
+PLATFORM_LIBGCC += -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc + # # When cross-compiling on NetBSD, we have to define __PPC__ or else we # will pick up a va_list declaration that is incompatible with the diff --git a/sh_config.mk b/sh_config.mk index 49d50f7..311699a 100644 --- a/sh_config.mk +++ b/sh_config.mk @@ -22,3 +22,5 @@ #
PLATFORM_CPPFLAGS += -DCONFIG_SH -D__SH__ + +PLATFORM_LIBGCC += -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc diff --git a/sparc_config.mk b/sparc_config.mk index 87f745f..15d2f5b 100644 --- a/sparc_config.mk +++ b/sparc_config.mk @@ -22,3 +22,5 @@ #
PLATFORM_CPPFLAGS += -DCONFIG_SPARC -D__sparc__ + +PLATFORM_LIBGCC += -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc
This patch removes the inclusion of libgcc functions into U-Boot on the ARM architecture. Only the really needed functions are provided in the lib_arm directory. Those implementations are copied from Linux where they are well proven related to reliably, performance.
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com Cc: Stefan Roese sr@denx.de --- Makefile | 11 +- arm_config.mk | 2 +- board/trab/u-boot.lds | 2 +- include/asm-arm/assembler.h | 116 ++++++++++++ include/asm-arm/linkage.h | 11 ++ include/linux/linkage.h | 95 ++++++++++ lib_arm/Makefile | 10 +- lib_arm/_divsi3.S | 140 --------------- lib_arm/_modsi3.S | 99 ----------- lib_arm/_udivsi3.S | 77 -------- lib_arm/_umodsi3.S | 88 ---------- lib_arm/{_ashldi3.S => ashldi3.S} | 9 +- lib_arm/{_ashrdi3.S => ashrdi3.S} | 9 +- lib_arm/lib1funcs.S | 348 +++++++++++++++++++++++++++++++++++++ lib_arm/{_ashrdi3.S => lshrdi3.S} | 13 +- 15 files changed, 607 insertions(+), 423 deletions(-) create mode 100644 include/asm-arm/assembler.h create mode 100644 include/asm-arm/linkage.h create mode 100644 include/linux/linkage.h delete mode 100644 lib_arm/_divsi3.S delete mode 100644 lib_arm/_modsi3.S delete mode 100644 lib_arm/_udivsi3.S delete mode 100644 lib_arm/_umodsi3.S rename lib_arm/{_ashldi3.S => ashldi3.S} (93%) copy lib_arm/{_ashrdi3.S => ashrdi3.S} (93%) create mode 100644 lib_arm/lib1funcs.S rename lib_arm/{_ashrdi3.S => lshrdi3.S} (90%)
diff --git a/Makefile b/Makefile index be12164..977ed5a 100644 --- a/Makefile +++ b/Makefile @@ -220,7 +220,6 @@ endif ifeq ($(CPU),ixp) LIBS += cpu/ixp/npe/libnpe.a endif -LIBS += lib_$(ARCH)/lib$(ARCH).a LIBS += fs/cramfs/libcramfs.a fs/fat/libfat.a fs/fdos/libfdos.a fs/jffs2/libjffs2.a \ fs/reiserfs/libreiserfs.a fs/ext2/libext2fs.a fs/yaffs2/libyaffs2.a \ fs/ubifs/libubifs.a @@ -279,6 +278,9 @@ LIBS := $(addprefix $(obj),$(LIBS)) LIBBOARD = board/$(BOARDDIR)/lib$(BOARD).a LIBBOARD := $(addprefix $(obj),$(LIBBOARD))
+LIBARCH = lib_$(ARCH)/lib$(ARCH).a +LIBARCH := $(addprefix $(obj),$(LIBARCH)) + # Add GCC lib PLATFORM_LIBS += $(PLATFORM_LIBGCC)
@@ -301,7 +303,7 @@ U_BOOT_ONENAND = $(obj)u-boot-onenand.bin endif
__OBJS := $(subst $(obj),,$(OBJS)) -__LIBS := $(subst $(obj),,$(LIBS)) $(subst $(obj),,$(LIBBOARD)) +__LIBS := $(subst $(obj),,$(LIBS)) $(subst $(obj),,$(LIBBOARD)) $(subst $(obj),,$(LIBARCH))
######################################################################### ######################################################################### @@ -354,13 +356,16 @@ $(obj)u-boot: depend $(SUBDIRS) $(OBJS) $(LIBBOARD) $(LIBS) $(LDSCRIPT) $(OBJS): depend $(MAKE) -C cpu/$(CPU) $(if $(REMOTE_BUILD),$@,$(notdir $@))
+$(LIBARCH): depend + $(MAKE) -C $(dir $(subst $(obj),,$@)) + $(LIBS): depend $(SUBDIRS) $(MAKE) -C $(dir $(subst $(obj),,$@))
$(LIBBOARD): depend $(LIBS) $(MAKE) -C $(dir $(subst $(obj),,$@))
-$(SUBDIRS): depend +$(SUBDIRS): depend $(LIBARCH) $(MAKE) -C $@ all
$(LDSCRIPT): depend diff --git a/arm_config.mk b/arm_config.mk index b88a3f2..0d6cd24 100644 --- a/arm_config.mk +++ b/arm_config.mk @@ -25,4 +25,4 @@ PLATFORM_CPPFLAGS += -DCONFIG_ARM -D__ARM__
-PLATFORM_LIBGCC += -L $(shell dirname `$(CC) $(CFLAGS) -print-libgcc-file-name`) -lgcc +PLATFORM_LIBGCC += -L$(OBJTREE)/lib_arm -larm diff --git a/board/trab/u-boot.lds b/board/trab/u-boot.lds index d8bcfa4..a83853e 100644 --- a/board/trab/u-boot.lds +++ b/board/trab/u-boot.lds @@ -33,7 +33,7 @@ SECTIONS .text : { cpu/arm920t/start.o (.text) - lib_arm/_umodsi3.o (.text) + lib_arm/lib1funcs.o (.text) lib_generic/zlib.o (.text) lib_generic/crc32.o (.text) lib_generic/string.o (.text) diff --git a/include/asm-arm/assembler.h b/include/asm-arm/assembler.h new file mode 100644 index 0000000..6116e48 --- /dev/null +++ b/include/asm-arm/assembler.h @@ -0,0 +1,116 @@ +/* + * arch/arm/include/asm/assembler.h + * + * Copyright (C) 1996-2000 Russell King + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This file contains arm architecture specific defines + * for the different processors. + * + * Do not include any C declarations in this file - it is included by + * assembler source. + */ +#ifndef __ASSEMBLY__ +#error "Only include this from assembly code" +#endif + +#include <asm/ptrace.h> + +/* + * Endian independent macros for shifting bytes within registers. + */ +#ifndef __ARMEB__ +#define pull lsr +#define push lsl +#define get_byte_0 lsl #0 +#define get_byte_1 lsr #8 +#define get_byte_2 lsr #16 +#define get_byte_3 lsr #24 +#define put_byte_0 lsl #0 +#define put_byte_1 lsl #8 +#define put_byte_2 lsl #16 +#define put_byte_3 lsl #24 +#else +#define pull lsl +#define push lsr +#define get_byte_0 lsr #24 +#define get_byte_1 lsr #16 +#define get_byte_2 lsr #8 +#define get_byte_3 lsl #0 +#define put_byte_0 lsl #24 +#define put_byte_1 lsl #16 +#define put_byte_2 lsl #8 +#define put_byte_3 lsl #0 +#endif + +/* + * Data preload for architectures that support it + */ +#if __LINUX_ARM_ARCH__ >= 5 +#define PLD(code...) code +#else +#define PLD(code...) +#endif + +/* + * This can be used to enable code to cacheline align the destination + * pointer when bulk writing to memory. Experiments on StrongARM and + * XScale didn't show this a worthwhile thing to do when the cache is not + * set to write-allocate (this would need further testing on XScale when WA + * is used). + * + * On Feroceon there is much to gain however, regardless of cache mode. + */ +#ifdef CONFIG_CPU_FEROCEON +#define CALGN(code...) code +#else +#define CALGN(code...) +#endif + +/* + * Enable and disable interrupts + */ +#if __LINUX_ARM_ARCH__ >= 6 + .macro disable_irq + cpsid i + .endm + + .macro enable_irq + cpsie i + .endm +#else + .macro disable_irq + msr cpsr_c, #PSR_I_BIT | SVC_MODE + .endm + + .macro enable_irq + msr cpsr_c, #SVC_MODE + .endm +#endif + +/* + * Save the current IRQ state and disable IRQs. Note that this macro + * assumes FIQs are enabled, and that the processor is in SVC mode. + */ + .macro save_and_disable_irqs, oldcpsr + mrs \oldcpsr, cpsr + disable_irq + .endm + +/* + * Restore interrupt state previously stored in a register. We don't + * guarantee that this will preserve the flags. + */ + .macro restore_irqs, oldcpsr + msr cpsr_c, \oldcpsr + .endm + +#define USER(x...) \ +9999: x; \ + .section __ex_table,"a"; \ + .align 3; \ + .long 9999b,9001f; \ + .previous diff --git a/include/asm-arm/linkage.h b/include/asm-arm/linkage.h new file mode 100644 index 0000000..5a25632 --- /dev/null +++ b/include/asm-arm/linkage.h @@ -0,0 +1,11 @@ +#ifndef __ASM_LINKAGE_H +#define __ASM_LINKAGE_H + +#define __ALIGN .align 0 +#define __ALIGN_STR ".align 0" + +#define ENDPROC(name) \ + .type name, %function; \ + END(name) + +#endif diff --git a/include/linux/linkage.h b/include/linux/linkage.h new file mode 100644 index 0000000..b25624e --- /dev/null +++ b/include/linux/linkage.h @@ -0,0 +1,95 @@ +#ifndef _LINUX_LINKAGE_H +#define _LINUX_LINKAGE_H + +#include <asm/linkage.h> + +#ifdef __cplusplus +#define CPP_ASMLINKAGE extern "C" +#else +#define CPP_ASMLINKAGE +#endif + +#ifndef asmlinkage +#define asmlinkage CPP_ASMLINKAGE +#endif + +#ifndef asmregparm +# define asmregparm +#endif + +#define __page_aligned_data __section(.data.page_aligned) __aligned(PAGE_SIZE) +#define __page_aligned_bss __section(.bss.page_aligned) __aligned(PAGE_SIZE) + +/* + * This is used by architectures to keep arguments on the stack + * untouched by the compiler by keeping them live until the end. + * The argument stack may be owned by the assembly-language + * caller, not the callee, and gcc doesn't always understand + * that. + * + * We have the return value, and a maximum of six arguments. + * + * This should always be followed by a "return ret" for the + * protection to work (ie no more work that the compiler might + * end up needing stack temporaries for). + */ +/* Assembly files may be compiled with -traditional .. */ +#ifndef __ASSEMBLY__ +#ifndef asmlinkage_protect +# define asmlinkage_protect(n, ret, args...) do { } while (0) +#endif +#endif + +#ifndef __ALIGN +#define __ALIGN .align 4,0x90 +#define __ALIGN_STR ".align 4,0x90" +#endif + +#ifdef __ASSEMBLY__ + +#define ALIGN __ALIGN +#define ALIGN_STR __ALIGN_STR + +#ifndef ENTRY +#define ENTRY(name) \ + .globl name; \ + ALIGN; \ + name: +#endif + +#ifndef WEAK +#define WEAK(name) \ + .weak name; \ + name: +#endif + +#define KPROBE_ENTRY(name) \ + .pushsection .kprobes.text, "ax"; \ + ENTRY(name) + +#define KPROBE_END(name) \ + END(name); \ + .popsection + +#ifndef END +#define END(name) \ + .size name, .-name +#endif + +/* If symbol 'name' is treated as a subroutine (gets called, and returns) + * then please use ENDPROC to mark 'name' as STT_FUNC for the benefit of + * static analysis tools such as stack depth analyzer. + */ +#ifndef ENDPROC +#define ENDPROC(name) \ + .type name, @function; \ + END(name) +#endif + +#endif + +#define NORET_TYPE /**/ +#define ATTRIB_NORET __attribute__((noreturn)) +#define NORET_AND noreturn, + +#endif diff --git a/lib_arm/Makefile b/lib_arm/Makefile index 4469361..756643f 100644 --- a/lib_arm/Makefile +++ b/lib_arm/Makefile @@ -25,12 +25,10 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(ARCH).a
-SOBJS-y += _ashldi3.o -SOBJS-y += _ashrdi3.o -SOBJS-y += _divsi3.o -SOBJS-y += _modsi3.o -SOBJS-y += _udivsi3.o -SOBJS-y += _umodsi3.o +SOBJS-y += lib1funcs.o +SOBJS-y += ashldi3.o +SOBJS-y += ashrdi3.o +SOBJS-y += lshrdi3.o
COBJS-y += board.o COBJS-y += bootm.o diff --git a/lib_arm/_divsi3.S b/lib_arm/_divsi3.S deleted file mode 100644 index 9dc15f6..0000000 --- a/lib_arm/_divsi3.S +++ /dev/null @@ -1,140 +0,0 @@ - -.macro ARM_DIV_BODY dividend, divisor, result, curbit - -#if __LINUX_ARM_ARCH__ >= 5 - - clz \curbit, \divisor - clz \result, \dividend - sub \result, \curbit, \result - mov \curbit, #1 - mov \divisor, \divisor, lsl \result - mov \curbit, \curbit, lsl \result - mov \result, #0 - -#else - - @ Initially shift the divisor left 3 bits if possible, - @ set curbit accordingly. This allows for curbit to be located - @ at the left end of each 4 bit nibbles in the division loop - @ to save one loop in most cases. - tst \divisor, #0xe0000000 - moveq \divisor, \divisor, lsl #3 - moveq \curbit, #8 - movne \curbit, #1 - - @ Unless the divisor is very big, shift it up in multiples of - @ four bits, since this is the amount of unwinding in the main - @ division loop. Continue shifting until the divisor is - @ larger than the dividend. -1: cmp \divisor, #0x10000000 - cmplo \divisor, \dividend - movlo \divisor, \divisor, lsl #4 - movlo \curbit, \curbit, lsl #4 - blo 1b - - @ For very big divisors, we must shift it a bit at a time, or - @ we will be in danger of overflowing. -1: cmp \divisor, #0x80000000 - cmplo \divisor, \dividend - movlo \divisor, \divisor, lsl #1 - movlo \curbit, \curbit, lsl #1 - blo 1b - - mov \result, #0 - -#endif - - @ Division loop -1: cmp \dividend, \divisor - subhs \dividend, \dividend, \divisor - orrhs \result, \result, \curbit - cmp \dividend, \divisor, lsr #1 - subhs \dividend, \dividend, \divisor, lsr #1 - orrhs \result, \result, \curbit, lsr #1 - cmp \dividend, \divisor, lsr #2 - subhs \dividend, \dividend, \divisor, lsr #2 - orrhs \result, \result, \curbit, lsr #2 - cmp \dividend, \divisor, lsr #3 - subhs \dividend, \dividend, \divisor, lsr #3 - orrhs \result, \result, \curbit, lsr #3 - cmp \dividend, #0 @ Early termination? - movnes \curbit, \curbit, lsr #4 @ No, any more bits to do? - movne \divisor, \divisor, lsr #4 - bne 1b - -.endm - -.macro ARM_DIV2_ORDER divisor, order - -#if __LINUX_ARM_ARCH__ >= 5 - - clz \order, \divisor - rsb \order, \order, #31 - -#else - - cmp \divisor, #(1 << 16) - movhs \divisor, \divisor, lsr #16 - movhs \order, #16 - movlo \order, #0 - - cmp \divisor, #(1 << 8) - movhs \divisor, \divisor, lsr #8 - addhs \order, \order, #8 - - cmp \divisor, #(1 << 4) - movhs \divisor, \divisor, lsr #4 - addhs \order, \order, #4 - - cmp \divisor, #(1 << 2) - addhi \order, \order, #3 - addls \order, \order, \divisor, lsr #1 - -#endif - -.endm - - .align 5 -.globl __divsi3 -__divsi3: - cmp r1, #0 - eor ip, r0, r1 @ save the sign of the result. - beq Ldiv0 - rsbmi r1, r1, #0 @ loops below use unsigned. - subs r2, r1, #1 @ division by 1 or -1 ? - beq 10f - movs r3, r0 - rsbmi r3, r0, #0 @ positive dividend value - cmp r3, r1 - bls 11f - tst r1, r2 @ divisor is power of 2 ? - beq 12f - - ARM_DIV_BODY r3, r1, r0, r2 - - cmp ip, #0 - rsbmi r0, r0, #0 - mov pc, lr - -10: teq ip, r0 @ same sign ? - rsbmi r0, r0, #0 - mov pc, lr - -11: movlo r0, #0 - moveq r0, ip, asr #31 - orreq r0, r0, #1 - mov pc, lr - -12: ARM_DIV2_ORDER r1, r2 - - cmp ip, #0 - mov r0, r3, lsr r2 - rsbmi r0, r0, #0 - mov pc, lr - -Ldiv0: - - str lr, [sp, #-4]! - bl __div0 - mov r0, #0 @ About as wrong as it could be. - ldr pc, [sp], #4 diff --git a/lib_arm/_modsi3.S b/lib_arm/_modsi3.S deleted file mode 100644 index 539c584..0000000 --- a/lib_arm/_modsi3.S +++ /dev/null @@ -1,99 +0,0 @@ - -.macro ARM_MOD_BODY dividend, divisor, order, spare - -#if __LINUX_ARM_ARCH__ >= 5 - - clz \order, \divisor - clz \spare, \dividend - sub \order, \order, \spare - mov \divisor, \divisor, lsl \order - -#else - - mov \order, #0 - - @ Unless the divisor is very big, shift it up in multiples of - @ four bits, since this is the amount of unwinding in the main - @ division loop. Continue shifting until the divisor is - @ larger than the dividend. -1: cmp \divisor, #0x10000000 - cmplo \divisor, \dividend - movlo \divisor, \divisor, lsl #4 - addlo \order, \order, #4 - blo 1b - - @ For very big divisors, we must shift it a bit at a time, or - @ we will be in danger of overflowing. -1: cmp \divisor, #0x80000000 - cmplo \divisor, \dividend - movlo \divisor, \divisor, lsl #1 - addlo \order, \order, #1 - blo 1b - -#endif - - @ Perform all needed substractions to keep only the reminder. - @ Do comparisons in batch of 4 first. - subs \order, \order, #3 @ yes, 3 is intended here - blt 2f - -1: cmp \dividend, \divisor - subhs \dividend, \dividend, \divisor - cmp \dividend, \divisor, lsr #1 - subhs \dividend, \dividend, \divisor, lsr #1 - cmp \dividend, \divisor, lsr #2 - subhs \dividend, \dividend, \divisor, lsr #2 - cmp \dividend, \divisor, lsr #3 - subhs \dividend, \dividend, \divisor, lsr #3 - cmp \dividend, #1 - mov \divisor, \divisor, lsr #4 - subges \order, \order, #4 - bge 1b - - tst \order, #3 - teqne \dividend, #0 - beq 5f - - @ Either 1, 2 or 3 comparison/substractions are left. -2: cmn \order, #2 - blt 4f - beq 3f - cmp \dividend, \divisor - subhs \dividend, \dividend, \divisor - mov \divisor, \divisor, lsr #1 -3: cmp \dividend, \divisor - subhs \dividend, \dividend, \divisor - mov \divisor, \divisor, lsr #1 -4: cmp \dividend, \divisor - subhs \dividend, \dividend, \divisor -5: -.endm - - .align 5 -.globl __modsi3 -__modsi3: - cmp r1, #0 - beq Ldiv0 - rsbmi r1, r1, #0 @ loops below use unsigned. - movs ip, r0 @ preserve sign of dividend - rsbmi r0, r0, #0 @ if negative make positive - subs r2, r1, #1 @ compare divisor with 1 - cmpne r0, r1 @ compare dividend with divisor - moveq r0, #0 - tsthi r1, r2 @ see if divisor is power of 2 - andeq r0, r0, r2 - bls 10f - - ARM_MOD_BODY r0, r1, r2, r3 - -10: cmp ip, #0 - rsbmi r0, r0, #0 - mov pc, lr - - -Ldiv0: - - str lr, [sp, #-4]! - bl __div0 - mov r0, #0 @ About as wrong as it could be. - ldr pc, [sp], #4 diff --git a/lib_arm/_udivsi3.S b/lib_arm/_udivsi3.S deleted file mode 100644 index a3f9b59..0000000 --- a/lib_arm/_udivsi3.S +++ /dev/null @@ -1,77 +0,0 @@ -/* # 1 "libgcc1.S" */ -@ libgcc1 routines for ARM cpu. -@ Division routines, written by Richard Earnshaw, (rearnsha@armltd.co.uk) -dividend .req r0 -divisor .req r1 -result .req r2 -curbit .req r3 -/* ip .req r12 */ -/* sp .req r13 */ -/* lr .req r14 */ -/* pc .req r15 */ - .text - .globl __udivsi3 - .type __udivsi3 ,function - .align 0 - __udivsi3 : - cmp divisor, #0 - beq Ldiv0 - mov curbit, #1 - mov result, #0 - cmp dividend, divisor - bcc Lgot_result -Loop1: - @ Unless the divisor is very big, shift it up in multiples of - @ four bits, since this is the amount of unwinding in the main - @ division loop. Continue shifting until the divisor is - @ larger than the dividend. - cmp divisor, #0x10000000 - cmpcc divisor, dividend - movcc divisor, divisor, lsl #4 - movcc curbit, curbit, lsl #4 - bcc Loop1 -Lbignum: - @ For very big divisors, we must shift it a bit at a time, or - @ we will be in danger of overflowing. - cmp divisor, #0x80000000 - cmpcc divisor, dividend - movcc divisor, divisor, lsl #1 - movcc curbit, curbit, lsl #1 - bcc Lbignum -Loop3: - @ Test for possible subtractions, and note which bits - @ are done in the result. On the final pass, this may subtract - @ too much from the dividend, but the result will be ok, since the - @ "bit" will have been shifted out at the bottom. - cmp dividend, divisor - subcs dividend, dividend, divisor - orrcs result, result, curbit - cmp dividend, divisor, lsr #1 - subcs dividend, dividend, divisor, lsr #1 - orrcs result, result, curbit, lsr #1 - cmp dividend, divisor, lsr #2 - subcs dividend, dividend, divisor, lsr #2 - orrcs result, result, curbit, lsr #2 - cmp dividend, divisor, lsr #3 - subcs dividend, dividend, divisor, lsr #3 - orrcs result, result, curbit, lsr #3 - cmp dividend, #0 @ Early termination? - movnes curbit, curbit, lsr #4 @ No, any more bits to do? - movne divisor, divisor, lsr #4 - bne Loop3 -Lgot_result: - mov r0, result - mov pc, lr -Ldiv0: - str lr, [sp, #-4]! - bl __div0 (PLT) - mov r0, #0 @ about as wrong as it could be - ldmia sp!, {pc} - .size __udivsi3 , . - __udivsi3 -/* # 235 "libgcc1.S" */ -/* # 320 "libgcc1.S" */ -/* # 421 "libgcc1.S" */ -/* # 433 "libgcc1.S" */ -/* # 456 "libgcc1.S" */ -/* # 500 "libgcc1.S" */ -/* # 580 "libgcc1.S" */ diff --git a/lib_arm/_umodsi3.S b/lib_arm/_umodsi3.S deleted file mode 100644 index 8465ef0..0000000 --- a/lib_arm/_umodsi3.S +++ /dev/null @@ -1,88 +0,0 @@ -/* # 1 "libgcc1.S" */ -@ libgcc1 routines for ARM cpu. -@ Division routines, written by Richard Earnshaw, (rearnsha@armltd.co.uk) -/* # 145 "libgcc1.S" */ -dividend .req r0 -divisor .req r1 -overdone .req r2 -curbit .req r3 -/* ip .req r12 */ -/* sp .req r13 */ -/* lr .req r14 */ -/* pc .req r15 */ - .text - .globl __umodsi3 - .type __umodsi3 ,function - .align 0 - __umodsi3 : - cmp divisor, #0 - beq Ldiv0 - mov curbit, #1 - cmp dividend, divisor - movcc pc, lr -Loop1: - @ Unless the divisor is very big, shift it up in multiples of - @ four bits, since this is the amount of unwinding in the main - @ division loop. Continue shifting until the divisor is - @ larger than the dividend. - cmp divisor, #0x10000000 - cmpcc divisor, dividend - movcc divisor, divisor, lsl #4 - movcc curbit, curbit, lsl #4 - bcc Loop1 -Lbignum: - @ For very big divisors, we must shift it a bit at a time, or - @ we will be in danger of overflowing. - cmp divisor, #0x80000000 - cmpcc divisor, dividend - movcc divisor, divisor, lsl #1 - movcc curbit, curbit, lsl #1 - bcc Lbignum -Loop3: - @ Test for possible subtractions. On the final pass, this may - @ subtract too much from the dividend, so keep track of which - @ subtractions are done, we can fix them up afterwards... - mov overdone, #0 - cmp dividend, divisor - subcs dividend, dividend, divisor - cmp dividend, divisor, lsr #1 - subcs dividend, dividend, divisor, lsr #1 - orrcs overdone, overdone, curbit, ror #1 - cmp dividend, divisor, lsr #2 - subcs dividend, dividend, divisor, lsr #2 - orrcs overdone, overdone, curbit, ror #2 - cmp dividend, divisor, lsr #3 - subcs dividend, dividend, divisor, lsr #3 - orrcs overdone, overdone, curbit, ror #3 - mov ip, curbit - cmp dividend, #0 @ Early termination? - movnes curbit, curbit, lsr #4 @ No, any more bits to do? - movne divisor, divisor, lsr #4 - bne Loop3 - @ Any subtractions that we should not have done will be recorded in - @ the top three bits of "overdone". Exactly which were not needed - @ are governed by the position of the bit, stored in ip. - @ If we terminated early, because dividend became zero, - @ then none of the below will match, since the bit in ip will not be - @ in the bottom nibble. - ands overdone, overdone, #0xe0000000 - moveq pc, lr @ No fixups needed - tst overdone, ip, ror #3 - addne dividend, dividend, divisor, lsr #3 - tst overdone, ip, ror #2 - addne dividend, dividend, divisor, lsr #2 - tst overdone, ip, ror #1 - addne dividend, dividend, divisor, lsr #1 - mov pc, lr -Ldiv0: - str lr, [sp, #-4]! - bl __div0 (PLT) - mov r0, #0 @ about as wrong as it could be - ldmia sp!, {pc} - .size __umodsi3 , . - __umodsi3 -/* # 320 "libgcc1.S" */ -/* # 421 "libgcc1.S" */ -/* # 433 "libgcc1.S" */ -/* # 456 "libgcc1.S" */ -/* # 500 "libgcc1.S" */ -/* # 580 "libgcc1.S" */ diff --git a/lib_arm/_ashldi3.S b/lib_arm/ashldi3.S similarity index 93% rename from lib_arm/_ashldi3.S rename to lib_arm/ashldi3.S index de4403d..1154d92 100644 --- a/lib_arm/_ashldi3.S +++ b/lib_arm/ashldi3.S @@ -26,6 +26,8 @@ the Free Software Foundation, 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA. */
+#include <linux/linkage.h> + #ifdef __ARMEB__ #define al r1 #define ah r0 @@ -34,8 +36,8 @@ Boston, MA 02110-1301, USA. */ #define ah r1 #endif
-.globl __ashldi3 -__ashldi3: +ENTRY(__ashldi3) +ENTRY(__aeabi_llsl)
subs r3, r2, #32 rsb ip, r2, #32 @@ -44,3 +46,6 @@ __ashldi3: orrmi ah, ah, al, lsr ip mov al, al, lsl r2 mov pc, lr + +ENDPROC(__ashldi3) +ENDPROC(__aeabi_llsl) diff --git a/lib_arm/_ashrdi3.S b/lib_arm/ashrdi3.S similarity index 93% copy from lib_arm/_ashrdi3.S copy to lib_arm/ashrdi3.S index 5edbcb3..9f8b355 100644 --- a/lib_arm/_ashrdi3.S +++ b/lib_arm/ashrdi3.S @@ -26,6 +26,8 @@ the Free Software Foundation, 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA. */
-.globl __ashrdi3 -__ashrdi3: +ENTRY(__ashrdi3) +ENTRY(__aeabi_lasr)
subs r3, r2, #32 rsb ip, r2, #32 @@ -44,3 +46,6 @@ __ashrdi3: orrmi al, al, ah, lsl ip mov ah, ah, asr r2 mov pc, lr + +ENDPROC(__ashrdi3) +ENDPROC(__aeabi_lasr) diff --git a/lib_arm/lib1funcs.S b/lib_arm/lib1funcs.S new file mode 100644 index 0000000..67964bc --- /dev/null +++ b/lib_arm/lib1funcs.S @@ -0,0 +1,348 @@ +/* + * linux/arch/arm/lib/lib1funcs.S: Optimized ARM division routines + * + * Author: Nicolas Pitre nico@cam.org + * - contributed to gcc-3.4 on Sep 30, 2003 + * - adapted for the Linux kernel on Oct 2, 2003 + */ + +/* Copyright 1995, 1996, 1998, 1999, 2000, 2003 Free Software Foundation, Inc. + +This file is free software; you can redistribute it and/or modify it +under the terms of the GNU General Public License as published by the +Free Software Foundation; either version 2, or (at your option) any +later version. + +In addition to the permissions in the GNU General Public License, the +Free Software Foundation gives you unlimited permission to link the +compiled version of this file into combinations with other programs, +and to distribute those combinations without any restriction coming +from the use of this file. (The General Public License restrictions +do apply in other respects; for example, they cover modification of +the file, and distribution when not linked into a combine +executable.) + +This file is distributed in the hope that it will be useful, but +WITHOUT ANY WARRANTY; without even the implied warranty of +MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU +General Public License for more details. + +You should have received a copy of the GNU General Public License +along with this program; see the file COPYING. If not, write to +the Free Software Foundation, 59 Temple Place - Suite 330, +Boston, MA 02111-1307, USA. */ + + +#include <linux/linkage.h> +#include <asm/assembler.h> + + +.macro ARM_DIV_BODY dividend, divisor, result, curbit + +#if __LINUX_ARM_ARCH__ >= 5 + + clz \curbit, \divisor + clz \result, \dividend + sub \result, \curbit, \result + mov \curbit, #1 + mov \divisor, \divisor, lsl \result + mov \curbit, \curbit, lsl \result + mov \result, #0 + +#else + + @ Initially shift the divisor left 3 bits if possible, + @ set curbit accordingly. This allows for curbit to be located + @ at the left end of each 4 bit nibbles in the division loop + @ to save one loop in most cases. + tst \divisor, #0xe0000000 + moveq \divisor, \divisor, lsl #3 + moveq \curbit, #8 + movne \curbit, #1 + + @ Unless the divisor is very big, shift it up in multiples of + @ four bits, since this is the amount of unwinding in the main + @ division loop. Continue shifting until the divisor is + @ larger than the dividend. +1: cmp \divisor, #0x10000000 + cmplo \divisor, \dividend + movlo \divisor, \divisor, lsl #4 + movlo \curbit, \curbit, lsl #4 + blo 1b + + @ For very big divisors, we must shift it a bit at a time, or + @ we will be in danger of overflowing. +1: cmp \divisor, #0x80000000 + cmplo \divisor, \dividend + movlo \divisor, \divisor, lsl #1 + movlo \curbit, \curbit, lsl #1 + blo 1b + + mov \result, #0 + +#endif + + @ Division loop +1: cmp \dividend, \divisor + subhs \dividend, \dividend, \divisor + orrhs \result, \result, \curbit + cmp \dividend, \divisor, lsr #1 + subhs \dividend, \dividend, \divisor, lsr #1 + orrhs \result, \result, \curbit, lsr #1 + cmp \dividend, \divisor, lsr #2 + subhs \dividend, \dividend, \divisor, lsr #2 + orrhs \result, \result, \curbit, lsr #2 + cmp \dividend, \divisor, lsr #3 + subhs \dividend, \dividend, \divisor, lsr #3 + orrhs \result, \result, \curbit, lsr #3 + cmp \dividend, #0 @ Early termination? + movnes \curbit, \curbit, lsr #4 @ No, any more bits to do? + movne \divisor, \divisor, lsr #4 + bne 1b + +.endm + + +.macro ARM_DIV2_ORDER divisor, order + +#if __LINUX_ARM_ARCH__ >= 5 + + clz \order, \divisor + rsb \order, \order, #31 + +#else + + cmp \divisor, #(1 << 16) + movhs \divisor, \divisor, lsr #16 + movhs \order, #16 + movlo \order, #0 + + cmp \divisor, #(1 << 8) + movhs \divisor, \divisor, lsr #8 + addhs \order, \order, #8 + + cmp \divisor, #(1 << 4) + movhs \divisor, \divisor, lsr #4 + addhs \order, \order, #4 + + cmp \divisor, #(1 << 2) + addhi \order, \order, #3 + addls \order, \order, \divisor, lsr #1 + +#endif + +.endm + + +.macro ARM_MOD_BODY dividend, divisor, order, spare + +#if __LINUX_ARM_ARCH__ >= 5 + + clz \order, \divisor + clz \spare, \dividend + sub \order, \order, \spare + mov \divisor, \divisor, lsl \order + +#else + + mov \order, #0 + + @ Unless the divisor is very big, shift it up in multiples of + @ four bits, since this is the amount of unwinding in the main + @ division loop. Continue shifting until the divisor is + @ larger than the dividend. +1: cmp \divisor, #0x10000000 + cmplo \divisor, \dividend + movlo \divisor, \divisor, lsl #4 + addlo \order, \order, #4 + blo 1b + + @ For very big divisors, we must shift it a bit at a time, or + @ we will be in danger of overflowing. +1: cmp \divisor, #0x80000000 + cmplo \divisor, \dividend + movlo \divisor, \divisor, lsl #1 + addlo \order, \order, #1 + blo 1b + +#endif + + @ Perform all needed substractions to keep only the reminder. + @ Do comparisons in batch of 4 first. + subs \order, \order, #3 @ yes, 3 is intended here + blt 2f + +1: cmp \dividend, \divisor + subhs \dividend, \dividend, \divisor + cmp \dividend, \divisor, lsr #1 + subhs \dividend, \dividend, \divisor, lsr #1 + cmp \dividend, \divisor, lsr #2 + subhs \dividend, \dividend, \divisor, lsr #2 + cmp \dividend, \divisor, lsr #3 + subhs \dividend, \dividend, \divisor, lsr #3 + cmp \dividend, #1 + mov \divisor, \divisor, lsr #4 + subges \order, \order, #4 + bge 1b + + tst \order, #3 + teqne \dividend, #0 + beq 5f + + @ Either 1, 2 or 3 comparison/substractions are left. +2: cmn \order, #2 + blt 4f + beq 3f + cmp \dividend, \divisor + subhs \dividend, \dividend, \divisor + mov \divisor, \divisor, lsr #1 +3: cmp \dividend, \divisor + subhs \dividend, \dividend, \divisor + mov \divisor, \divisor, lsr #1 +4: cmp \dividend, \divisor + subhs \dividend, \dividend, \divisor +5: +.endm + + +ENTRY(__udivsi3) +ENTRY(__aeabi_uidiv) + + subs r2, r1, #1 + moveq pc, lr + bcc Ldiv0 + cmp r0, r1 + bls 11f + tst r1, r2 + beq 12f + + ARM_DIV_BODY r0, r1, r2, r3 + + mov r0, r2 + mov pc, lr + +11: moveq r0, #1 + movne r0, #0 + mov pc, lr + +12: ARM_DIV2_ORDER r1, r2 + + mov r0, r0, lsr r2 + mov pc, lr + +ENDPROC(__udivsi3) +ENDPROC(__aeabi_uidiv) + +ENTRY(__umodsi3) + + subs r2, r1, #1 @ compare divisor with 1 + bcc Ldiv0 + cmpne r0, r1 @ compare dividend with divisor + moveq r0, #0 + tsthi r1, r2 @ see if divisor is power of 2 + andeq r0, r0, r2 + movls pc, lr + + ARM_MOD_BODY r0, r1, r2, r3 + + mov pc, lr + +ENDPROC(__umodsi3) + +ENTRY(__divsi3) +ENTRY(__aeabi_idiv) + + cmp r1, #0 + eor ip, r0, r1 @ save the sign of the result. + beq Ldiv0 + rsbmi r1, r1, #0 @ loops below use unsigned. + subs r2, r1, #1 @ division by 1 or -1 ? + beq 10f + movs r3, r0 + rsbmi r3, r0, #0 @ positive dividend value + cmp r3, r1 + bls 11f + tst r1, r2 @ divisor is power of 2 ? + beq 12f + + ARM_DIV_BODY r3, r1, r0, r2 + + cmp ip, #0 + rsbmi r0, r0, #0 + mov pc, lr + +10: teq ip, r0 @ same sign ? + rsbmi r0, r0, #0 + mov pc, lr + +11: movlo r0, #0 + moveq r0, ip, asr #31 + orreq r0, r0, #1 + mov pc, lr + +12: ARM_DIV2_ORDER r1, r2 + + cmp ip, #0 + mov r0, r3, lsr r2 + rsbmi r0, r0, #0 + mov pc, lr + +ENDPROC(__divsi3) +ENDPROC(__aeabi_idiv) + +ENTRY(__modsi3) + + cmp r1, #0 + beq Ldiv0 + rsbmi r1, r1, #0 @ loops below use unsigned. + movs ip, r0 @ preserve sign of dividend + rsbmi r0, r0, #0 @ if negative make positive + subs r2, r1, #1 @ compare divisor with 1 + cmpne r0, r1 @ compare dividend with divisor + moveq r0, #0 + tsthi r1, r2 @ see if divisor is power of 2 + andeq r0, r0, r2 + bls 10f + + ARM_MOD_BODY r0, r1, r2, r3 + +10: cmp ip, #0 + rsbmi r0, r0, #0 + mov pc, lr + +ENDPROC(__modsi3) + +#ifdef CONFIG_AEABI + +ENTRY(__aeabi_uidivmod) + + stmfd sp!, {r0, r1, ip, lr} + bl __aeabi_uidiv + ldmfd sp!, {r1, r2, ip, lr} + mul r3, r0, r2 + sub r1, r1, r3 + mov pc, lr + +ENDPROC(__aeabi_uidivmod) + +ENTRY(__aeabi_idivmod) + + stmfd sp!, {r0, r1, ip, lr} + bl __aeabi_idiv + ldmfd sp!, {r1, r2, ip, lr} + mul r3, r0, r2 + sub r1, r1, r3 + mov pc, lr + +ENDPROC(__aeabi_idivmod) + +#endif + +Ldiv0: + + str lr, [sp, #-8]! + bl __div0 + mov r0, #0 @ About as wrong as it could be. + ldr pc, [sp], #8 + + diff --git a/lib_arm/_ashrdi3.S b/lib_arm/lshrdi3.S similarity index 90% rename from lib_arm/_ashrdi3.S rename to lib_arm/lshrdi3.S index 5edbcb3..99ea338 100644 --- a/lib_arm/_ashrdi3.S +++ b/lib_arm/lshrdi3.S @@ -26,6 +26,8 @@ the Free Software Foundation, 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA. */
+#include <linux/linkage.h> + #ifdef __ARMEB__ #define al r1 #define ah r0 @@ -34,13 +36,16 @@ Boston, MA 02110-1301, USA. */ #define ah r1 #endif
-.globl __ashrdi3 -__ashrdi3: +ENTRY(__lshrdi3) +ENTRY(__aeabi_llsr)
subs r3, r2, #32 rsb ip, r2, #32 movmi al, al, lsr r2 - movpl al, ah, asr r3 + movpl al, ah, lsr r3 orrmi al, al, ah, lsl ip - mov ah, ah, asr r2 + mov ah, ah, lsr r2 mov pc, lr + +ENDPROC(__lshrdi3) +ENDPROC(__aeabi_llsr)
Acked-by: Stefan Roese sr@denx.de
Thanks.
Best regards, Stefan
Thanks.
Stefan Roese
