[U-Boot] [PATCH 2/3] powerpc/p1010rdb: SECURE BOOT- enable workaround for IFC errata A003399
The workaround for IFC errata A003399 was not enabled in case of secure boot. So, secure boot from NOR was not working.
Signed-off-by: Aneesh Bansal aneesh.bansal@freescale.com --- include/configs/P1010RDB.h | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index c21cf07..b0e51fb 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -455,8 +455,7 @@ extern unsigned long get_sdram_size(void); #endif
#ifdef CONFIG_SYS_FSL_ERRATUM_IFC_A003399 -#if !defined(CONFIG_SPL) && !defined(CONFIG_SYS_RAMBOOT)\ - && !defined(CONFIG_SECURE_BOOT) +#if !defined(CONFIG_SPL) && !defined(CONFIG_SYS_RAMBOOT) #define CONFIG_A003399_NOR_WORKAROUND #endif #endif
Why do you need the workaround? Doesn't secure boot involve the bootrom loading U-Boot into SRAM, rather than execute-in-place from NOR?
-Scott
-Scott
The Boot ROM code does not copy the U-boot from NOR into SRAM. In case of secure boot from NOR, it is executed as an execute-in-place memory and so this workaround is required.
Regards, Aneesh Bansal
Applied to u-boot-mpc85xx/master, thanks.
York
Aneesh Bansal
Scott Wood
York Sun
