[U-Boot] Please pull u-boot-sh
Dear Wolfgang Denk,
The following changes since commit 0e7790d450000c1a2cda40458adb28707eaa5041:
LAN91C*: Change chip names to fit the eth_device struct size (2011-01-10 22:38:36 +0100)
are available in the git repository at: git://git.denx.de/u-boot-sh.git master
Nobuhiro Iwamatsu (14): sh: serial: Update serial driver for SH sh: Add support SH7706 sh: Add support shmin board sh: Add support showing KByte of flash memory size sh: Remove SCIF/SCI register infomation sh: sh7722: Fix multiple definition of PSDR in serial_sh sh: serial_sh: Fix build in serial_sh sh: Delete the function that was not necessary sh: Divided macro for zImage and add asm/zimage.h sh: Add support zimageboot command for Renesas SH sh: sh7785lcr: Add support zimageboot sh: r2dplus: Add support zimageboot sh: Fix build of shmin board sh: Add support T-SH7706LSR board
MAINTAINERS | 1 + arch/sh/include/asm/cpu_sh3.h | 6 +- arch/sh/include/asm/cpu_sh7706.h | 53 +++ arch/sh/include/asm/cpu_sh7722.h | 38 -- arch/sh/include/asm/cpu_sh7750.h | 16 - arch/sh/include/asm/cpu_sh7780.h | 21 +-- arch/sh/include/asm/zimage.h | 41 +++ arch/sh/lib/Makefile | 3 + arch/sh/lib/board.c | 8 +- arch/sh/lib/bootm.c | 21 +- arch/sh/lib/zimageboot.c | 80 +++++ board/shmin/Makefile | 49 +++ board/shmin/config.mk | 27 ++ board/shmin/lowlevel_init.S | 36 ++ board/shmin/shmin.c | 108 ++++++ boards.cfg | 1 + drivers/serial/serial_sh.c | 200 ++++------- drivers/serial/serial_sh.h | 690 ++++++++++++++++++++++++++++++++++++++ include/configs/r2dplus.h | 1 + include/configs/sh7785lcr.h | 1 + include/configs/shmin.h | 128 +++++++ 21 files changed, 1307 insertions(+), 222 deletions(-) create mode 100644 arch/sh/include/asm/cpu_sh7706.h create mode 100644 arch/sh/include/asm/zimage.h create mode 100644 arch/sh/lib/zimageboot.c create mode 100644 board/shmin/Makefile create mode 100644 board/shmin/config.mk create mode 100644 board/shmin/lowlevel_init.S create mode 100644 board/shmin/shmin.c create mode 100644 drivers/serial/serial_sh.h create mode 100644 include/configs/shmin.h
Dear Nobuhiro Iwamatsu,
In message AANLkTin+mBakREXD7pmUwJWa9NpeKm2G6f3VgjzkGM7y@mail.gmail.com you wrote:
Dear Wolfgang Denk,
Applied, thanks.
Nobuhiro Iwamatsu
