[PATCH 0/3] Add Clock and Pincontrol driver support for RZ/G2H SoC
Add Clock and Pincontrol driver support for RZ/G2H SoC.
This patches are based on u-boot-sh next.
This patch depends on [1] [1]https://patchwork.ozlabs.org/project/uboot/list/?series=204203
Biju Das (3): arm: renesas: Add config option for R8A774E1 SoC clk: renesas: Add R8A774E1 clock tables pinctrl: renesas: r8a77951: Add R8A774E1 PFC support
arch/arm/mach-rmobile/Kconfig.64 | 5 + drivers/clk/renesas/Kconfig | 6 + drivers/clk/renesas/Makefile | 1 + drivers/clk/renesas/r8a774e1-cpg-mssr.c | 358 ++++++++++ drivers/pinctrl/renesas/Kconfig | 10 + drivers/pinctrl/renesas/Makefile | 1 + drivers/pinctrl/renesas/pfc-r8a7795.c | 905 +++++++++++++----------- drivers/pinctrl/renesas/pfc.c | 11 + drivers/pinctrl/renesas/sh_pfc.h | 1 + 9 files changed, 889 insertions(+), 409 deletions(-) create mode 100644 drivers/clk/renesas/r8a774e1-cpg-mssr.c
Add config support for RZ/G2H(a.k.a R8A774E1) SoC.
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- This patch depends on [1] [1]https://patchwork.ozlabs.org/project/uboot/list/?series=204203 --- arch/arm/mach-rmobile/Kconfig.64 | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index b3f7b90978..ac897b9295 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -12,6 +12,9 @@ config R8A774B1 imply CLK_R8A774B1 imply PINCTRL_PFC_R8A774B1
+config R8A774E1 + bool "Renesas SoC R8A774E1" + config R8A7795 bool "Renesas SoC R8A7795" imply CLK_R8A7795
This sync's the RZ/G2H clock tables with mainline linux 5.9-rc4 commit f4d51dffc6c0 ("Linux 5.9-rc4")
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- This patch depends on [1] [1]https://patchwork.ozlabs.org/project/uboot/list/?series=204203 --- arch/arm/mach-rmobile/Kconfig.64 | 1 + drivers/clk/renesas/Kconfig | 6 + drivers/clk/renesas/Makefile | 1 + drivers/clk/renesas/r8a774e1-cpg-mssr.c | 358 ++++++++++++++++++++++++ 4 files changed, 366 insertions(+) create mode 100644 drivers/clk/renesas/r8a774e1-cpg-mssr.c
diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index ac897b9295..422f14f70f 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -14,6 +14,7 @@ config R8A774B1
config R8A774E1 bool "Renesas SoC R8A774E1" + imply CLK_R8A774E1
config R8A7795 bool "Renesas SoC R8A7795" diff --git a/drivers/clk/renesas/Kconfig b/drivers/clk/renesas/Kconfig index 00a173b8c8..44afcecbfa 100644 --- a/drivers/clk/renesas/Kconfig +++ b/drivers/clk/renesas/Kconfig @@ -61,6 +61,12 @@ config CLK_R8A774B1 help Enable this to support the clocks on Renesas R8A774B1 SoC.
+config CLK_R8A774E1 + bool "Renesas R8A774E1 clock driver" + depends on CLK_RCAR_GEN3 + help + Enable this to support the clocks on Renesas R8A774E1 SoC. + config CLK_R8A7795 bool "Renesas R8A7795 clock driver" depends on CLK_RCAR_GEN3 diff --git a/drivers/clk/renesas/Makefile b/drivers/clk/renesas/Makefile index 2e8d796f89..da353e811d 100644 --- a/drivers/clk/renesas/Makefile +++ b/drivers/clk/renesas/Makefile @@ -2,6 +2,7 @@ obj-$(CONFIG_CLK_RENESAS) += renesas-cpg-mssr.o obj-$(CONFIG_CLK_RCAR_GEN2) += clk-rcar-gen2.o obj-$(CONFIG_CLK_R8A774A1) += r8a774a1-cpg-mssr.o obj-$(CONFIG_CLK_R8A774B1) += r8a774b1-cpg-mssr.o +obj-$(CONFIG_CLK_R8A774E1) += r8a774e1-cpg-mssr.o obj-$(CONFIG_CLK_R8A7790) += r8a7790-cpg-mssr.o obj-$(CONFIG_CLK_R8A7791) += r8a7791-cpg-mssr.o obj-$(CONFIG_CLK_R8A7792) += r8a7792-cpg-mssr.o diff --git a/drivers/clk/renesas/r8a774e1-cpg-mssr.c b/drivers/clk/renesas/r8a774e1-cpg-mssr.c new file mode 100644 index 0000000000..6cce007aa1 --- /dev/null +++ b/drivers/clk/renesas/r8a774e1-cpg-mssr.c @@ -0,0 +1,358 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * r8a774e1 Clock Pulse Generator / Module Standby and Software Reset + * + * Copyright (C) 2020 Renesas Electronics Corp. + * + * Based on r8a7795-cpg-mssr.c + * + * Copyright (C) 2015 Glider bvba + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <linux/bitops.h> + +#include <dt-bindings/clock/r8a774e1-cpg-mssr.h> + +#include "renesas-cpg-mssr.h" +#include "rcar-gen3-cpg.h" + +enum clk_ids { + /* Core Clock Outputs exported to DT */ + LAST_DT_CORE_CLK = R8A774E1_CLK_CANFD, + + /* External Input Clocks */ + CLK_EXTAL, + CLK_EXTALR, + + /* Internal Core Clocks */ + CLK_MAIN, + CLK_PLL0, + CLK_PLL1, + CLK_PLL2, + CLK_PLL3, + CLK_PLL4, + CLK_PLL1_DIV2, + CLK_PLL1_DIV4, + CLK_S0, + CLK_S1, + CLK_S2, + CLK_S3, + CLK_SDSRC, + CLK_RPCSRC, + CLK_RINT, + + /* Module Clocks */ + MOD_CLK_BASE +}; + +static const struct cpg_core_clk r8a774e1_core_clks[] = { + /* External Clock Inputs */ + DEF_INPUT("extal", CLK_EXTAL), + DEF_INPUT("extalr", CLK_EXTALR), + + /* Internal Core Clocks */ + DEF_BASE(".main", CLK_MAIN, CLK_TYPE_GEN3_MAIN, CLK_EXTAL), + DEF_BASE(".pll0", CLK_PLL0, CLK_TYPE_GEN3_PLL0, CLK_MAIN), + DEF_BASE(".pll1", CLK_PLL1, CLK_TYPE_GEN3_PLL1, CLK_MAIN), + DEF_BASE(".pll2", CLK_PLL2, CLK_TYPE_GEN3_PLL2, CLK_MAIN), + DEF_BASE(".pll3", CLK_PLL3, CLK_TYPE_GEN3_PLL3, CLK_MAIN), + DEF_BASE(".pll4", CLK_PLL4, CLK_TYPE_GEN3_PLL4, CLK_MAIN), + + DEF_FIXED(".pll1_div2", CLK_PLL1_DIV2, CLK_PLL1, 2, 1), + DEF_FIXED(".pll1_div4", CLK_PLL1_DIV4, CLK_PLL1_DIV2, 2, 1), + DEF_FIXED(".s0", CLK_S0, CLK_PLL1_DIV2, 2, 1), + DEF_FIXED(".s1", CLK_S1, CLK_PLL1_DIV2, 3, 1), + DEF_FIXED(".s2", CLK_S2, CLK_PLL1_DIV2, 4, 1), + DEF_FIXED(".s3", CLK_S3, CLK_PLL1_DIV2, 6, 1), + DEF_FIXED(".sdsrc", CLK_SDSRC, CLK_PLL1_DIV2, 2, 1), + DEF_BASE(".rpcsrc", CLK_RPCSRC, CLK_TYPE_GEN3_RPCSRC, CLK_PLL1), + + DEF_BASE("rpc", R8A774E1_CLK_RPC, CLK_TYPE_GEN3_RPC, + CLK_RPCSRC), + DEF_BASE("rpcd2", R8A774E1_CLK_RPCD2, CLK_TYPE_GEN3_RPCD2, + R8A774E1_CLK_RPC), + + DEF_GEN3_OSC(".r", CLK_RINT, CLK_EXTAL, 32), + + /* Core Clock Outputs */ + DEF_GEN3_Z("z", R8A774E1_CLK_Z, CLK_TYPE_GEN3_Z, CLK_PLL0, 2, 8), + DEF_GEN3_Z("z2", R8A774E1_CLK_Z2, CLK_TYPE_GEN3_Z, CLK_PLL2, 2, 0), + DEF_FIXED("ztr", R8A774E1_CLK_ZTR, CLK_PLL1_DIV2, 6, 1), + DEF_FIXED("ztrd2", R8A774E1_CLK_ZTRD2, CLK_PLL1_DIV2, 12, 1), + DEF_FIXED("zt", R8A774E1_CLK_ZT, CLK_PLL1_DIV2, 4, 1), + DEF_FIXED("zx", R8A774E1_CLK_ZX, CLK_PLL1_DIV2, 2, 1), + DEF_FIXED("s0d1", R8A774E1_CLK_S0D1, CLK_S0, 1, 1), + DEF_FIXED("s0d2", R8A774E1_CLK_S0D2, CLK_S0, 2, 1), + DEF_FIXED("s0d3", R8A774E1_CLK_S0D3, CLK_S0, 3, 1), + DEF_FIXED("s0d4", R8A774E1_CLK_S0D4, CLK_S0, 4, 1), + DEF_FIXED("s0d6", R8A774E1_CLK_S0D6, CLK_S0, 6, 1), + DEF_FIXED("s0d8", R8A774E1_CLK_S0D8, CLK_S0, 8, 1), + DEF_FIXED("s0d12", R8A774E1_CLK_S0D12, CLK_S0, 12, 1), + DEF_FIXED("s1d2", R8A774E1_CLK_S1D2, CLK_S1, 2, 1), + DEF_FIXED("s1d4", R8A774E1_CLK_S1D4, CLK_S1, 4, 1), + DEF_FIXED("s2d1", R8A774E1_CLK_S2D1, CLK_S2, 1, 1), + DEF_FIXED("s2d2", R8A774E1_CLK_S2D2, CLK_S2, 2, 1), + DEF_FIXED("s2d4", R8A774E1_CLK_S2D4, CLK_S2, 4, 1), + DEF_FIXED("s3d1", R8A774E1_CLK_S3D1, CLK_S3, 1, 1), + DEF_FIXED("s3d2", R8A774E1_CLK_S3D2, CLK_S3, 2, 1), + DEF_FIXED("s3d4", R8A774E1_CLK_S3D4, CLK_S3, 4, 1), + + DEF_GEN3_SD("sd0", R8A774E1_CLK_SD0, CLK_SDSRC, 0x074), + DEF_GEN3_SD("sd1", R8A774E1_CLK_SD1, CLK_SDSRC, 0x078), + DEF_GEN3_SD("sd2", R8A774E1_CLK_SD2, CLK_SDSRC, 0x268), + DEF_GEN3_SD("sd3", R8A774E1_CLK_SD3, CLK_SDSRC, 0x26c), + + DEF_FIXED("cl", R8A774E1_CLK_CL, CLK_PLL1_DIV2, 48, 1), + DEF_FIXED("cr", R8A774E1_CLK_CR, CLK_PLL1_DIV4, 2, 1), + DEF_FIXED("cp", R8A774E1_CLK_CP, CLK_EXTAL, 2, 1), + DEF_FIXED("cpex", R8A774E1_CLK_CPEX, CLK_EXTAL, 2, 1), + + DEF_DIV6P1("canfd", R8A774E1_CLK_CANFD, CLK_PLL1_DIV4, 0x244), + DEF_DIV6P1("csi0", R8A774E1_CLK_CSI0, CLK_PLL1_DIV4, 0x00c), + DEF_DIV6P1("mso", R8A774E1_CLK_MSO, CLK_PLL1_DIV4, 0x014), + DEF_DIV6P1("hdmi", R8A774E1_CLK_HDMI, CLK_PLL1_DIV4, 0x250), + + DEF_GEN3_OSC("osc", R8A774E1_CLK_OSC, CLK_EXTAL, 8), + + DEF_BASE("r", R8A774E1_CLK_R, CLK_TYPE_GEN3_R, CLK_RINT), +}; + +static const struct mssr_mod_clk r8a774e1_mod_clks[] = { + DEF_MOD("fdp1-1", 118, R8A774E1_CLK_S0D1), + DEF_MOD("fdp1-0", 119, R8A774E1_CLK_S0D1), + DEF_MOD("tmu4", 121, R8A774E1_CLK_S0D6), + DEF_MOD("tmu3", 122, R8A774E1_CLK_S3D2), + DEF_MOD("tmu2", 123, R8A774E1_CLK_S3D2), + DEF_MOD("tmu1", 124, R8A774E1_CLK_S3D2), + DEF_MOD("tmu0", 125, R8A774E1_CLK_CP), + DEF_MOD("vcplf", 130, R8A774E1_CLK_S2D1), + DEF_MOD("vdpb", 131, R8A774E1_CLK_S2D1), + DEF_MOD("scif5", 202, R8A774E1_CLK_S3D4), + DEF_MOD("scif4", 203, R8A774E1_CLK_S3D4), + DEF_MOD("scif3", 204, R8A774E1_CLK_S3D4), + DEF_MOD("scif1", 206, R8A774E1_CLK_S3D4), + DEF_MOD("scif0", 207, R8A774E1_CLK_S3D4), + DEF_MOD("msiof3", 208, R8A774E1_CLK_MSO), + DEF_MOD("msiof2", 209, R8A774E1_CLK_MSO), + DEF_MOD("msiof1", 210, R8A774E1_CLK_MSO), + DEF_MOD("msiof0", 211, R8A774E1_CLK_MSO), + DEF_MOD("sys-dmac2", 217, R8A774E1_CLK_S3D1), + DEF_MOD("sys-dmac1", 218, R8A774E1_CLK_S3D1), + DEF_MOD("sys-dmac0", 219, R8A774E1_CLK_S0D3), + DEF_MOD("cmt3", 300, R8A774E1_CLK_R), + DEF_MOD("cmt2", 301, R8A774E1_CLK_R), + DEF_MOD("cmt1", 302, R8A774E1_CLK_R), + DEF_MOD("cmt0", 303, R8A774E1_CLK_R), + DEF_MOD("tpu0", 304, R8A774E1_CLK_S3D4), + DEF_MOD("scif2", 310, R8A774E1_CLK_S3D4), + DEF_MOD("sdif3", 311, R8A774E1_CLK_SD3), + DEF_MOD("sdif2", 312, R8A774E1_CLK_SD2), + DEF_MOD("sdif1", 313, R8A774E1_CLK_SD1), + DEF_MOD("sdif0", 314, R8A774E1_CLK_SD0), + DEF_MOD("pcie1", 318, R8A774E1_CLK_S3D1), + DEF_MOD("pcie0", 319, R8A774E1_CLK_S3D1), + DEF_MOD("usb3-if0", 328, R8A774E1_CLK_S3D1), + DEF_MOD("usb-dmac0", 330, R8A774E1_CLK_S3D1), + DEF_MOD("usb-dmac1", 331, R8A774E1_CLK_S3D1), + DEF_MOD("rwdt", 402, R8A774E1_CLK_R), + DEF_MOD("intc-ex", 407, R8A774E1_CLK_CP), + DEF_MOD("intc-ap", 408, R8A774E1_CLK_S0D3), + DEF_MOD("audmac1", 501, R8A774E1_CLK_S1D2), + DEF_MOD("audmac0", 502, R8A774E1_CLK_S1D2), + DEF_MOD("hscif4", 516, R8A774E1_CLK_S3D1), + DEF_MOD("hscif3", 517, R8A774E1_CLK_S3D1), + DEF_MOD("hscif2", 518, R8A774E1_CLK_S3D1), + DEF_MOD("hscif1", 519, R8A774E1_CLK_S3D1), + DEF_MOD("hscif0", 520, R8A774E1_CLK_S3D1), + DEF_MOD("thermal", 522, R8A774E1_CLK_CP), + DEF_MOD("pwm", 523, R8A774E1_CLK_S0D12), + DEF_MOD("fcpvd1", 602, R8A774E1_CLK_S0D2), + DEF_MOD("fcpvd0", 603, R8A774E1_CLK_S0D2), + DEF_MOD("fcpvb1", 606, R8A774E1_CLK_S0D1), + DEF_MOD("fcpvb0", 607, R8A774E1_CLK_S0D1), + DEF_MOD("fcpvi1", 610, R8A774E1_CLK_S0D1), + DEF_MOD("fcpvi0", 611, R8A774E1_CLK_S0D1), + DEF_MOD("fcpf1", 614, R8A774E1_CLK_S0D1), + DEF_MOD("fcpf0", 615, R8A774E1_CLK_S0D1), + DEF_MOD("fcpcs", 619, R8A774E1_CLK_S0D1), + DEF_MOD("vspd1", 622, R8A774E1_CLK_S0D2), + DEF_MOD("vspd0", 623, R8A774E1_CLK_S0D2), + DEF_MOD("vspbc", 624, R8A774E1_CLK_S0D1), + DEF_MOD("vspbd", 626, R8A774E1_CLK_S0D1), + DEF_MOD("vspi1", 630, R8A774E1_CLK_S0D1), + DEF_MOD("vspi0", 631, R8A774E1_CLK_S0D1), + DEF_MOD("ehci1", 702, R8A774E1_CLK_S3D2), + DEF_MOD("ehci0", 703, R8A774E1_CLK_S3D2), + DEF_MOD("hsusb", 704, R8A774E1_CLK_S3D2), + DEF_MOD("csi20", 714, R8A774E1_CLK_CSI0), + DEF_MOD("csi40", 716, R8A774E1_CLK_CSI0), + DEF_MOD("du3", 721, R8A774E1_CLK_S2D1), + DEF_MOD("du1", 723, R8A774E1_CLK_S2D1), + DEF_MOD("du0", 724, R8A774E1_CLK_S2D1), + DEF_MOD("lvds", 727, R8A774E1_CLK_S0D4), + DEF_MOD("hdmi0", 729, R8A774E1_CLK_HDMI), + DEF_MOD("vin7", 804, R8A774E1_CLK_S0D2), + DEF_MOD("vin6", 805, R8A774E1_CLK_S0D2), + DEF_MOD("vin5", 806, R8A774E1_CLK_S0D2), + DEF_MOD("vin4", 807, R8A774E1_CLK_S0D2), + DEF_MOD("vin3", 808, R8A774E1_CLK_S0D2), + DEF_MOD("vin2", 809, R8A774E1_CLK_S0D2), + DEF_MOD("vin1", 810, R8A774E1_CLK_S0D2), + DEF_MOD("vin0", 811, R8A774E1_CLK_S0D2), + DEF_MOD("etheravb", 812, R8A774E1_CLK_S0D6), + DEF_MOD("sata0", 815, R8A774E1_CLK_S3D2), + DEF_MOD("gpio7", 905, R8A774E1_CLK_S3D4), + DEF_MOD("gpio6", 906, R8A774E1_CLK_S3D4), + DEF_MOD("gpio5", 907, R8A774E1_CLK_S3D4), + DEF_MOD("gpio4", 908, R8A774E1_CLK_S3D4), + DEF_MOD("gpio3", 909, R8A774E1_CLK_S3D4), + DEF_MOD("gpio2", 910, R8A774E1_CLK_S3D4), + DEF_MOD("gpio1", 911, R8A774E1_CLK_S3D4), + DEF_MOD("gpio0", 912, R8A774E1_CLK_S3D4), + DEF_MOD("can-fd", 914, R8A774E1_CLK_S3D2), + DEF_MOD("can-if1", 915, R8A774E1_CLK_S3D4), + DEF_MOD("can-if0", 916, R8A774E1_CLK_S3D4), + DEF_MOD("rpc-if", 917, R8A774E1_CLK_RPCD2), + DEF_MOD("i2c6", 918, R8A774E1_CLK_S0D6), + DEF_MOD("i2c5", 919, R8A774E1_CLK_S0D6), + DEF_MOD("adg", 922, R8A774E1_CLK_S0D1), + DEF_MOD("i2c-dvfs", 926, R8A774E1_CLK_CP), + DEF_MOD("i2c4", 927, R8A774E1_CLK_S0D6), + DEF_MOD("i2c3", 928, R8A774E1_CLK_S0D6), + DEF_MOD("i2c2", 929, R8A774E1_CLK_S3D2), + DEF_MOD("i2c1", 930, R8A774E1_CLK_S3D2), + DEF_MOD("i2c0", 931, R8A774E1_CLK_S3D2), + DEF_MOD("ssi-all", 1005, R8A774E1_CLK_S3D4), + DEF_MOD("ssi9", 1006, MOD_CLK_ID(1005)), + DEF_MOD("ssi8", 1007, MOD_CLK_ID(1005)), + DEF_MOD("ssi7", 1008, MOD_CLK_ID(1005)), + DEF_MOD("ssi6", 1009, MOD_CLK_ID(1005)), + DEF_MOD("ssi5", 1010, MOD_CLK_ID(1005)), + DEF_MOD("ssi4", 1011, MOD_CLK_ID(1005)), + DEF_MOD("ssi3", 1012, MOD_CLK_ID(1005)), + DEF_MOD("ssi2", 1013, MOD_CLK_ID(1005)), + DEF_MOD("ssi1", 1014, MOD_CLK_ID(1005)), + DEF_MOD("ssi0", 1015, MOD_CLK_ID(1005)), + DEF_MOD("scu-all", 1017, R8A774E1_CLK_S3D4), + DEF_MOD("scu-dvc1", 1018, MOD_CLK_ID(1017)), + DEF_MOD("scu-dvc0", 1019, MOD_CLK_ID(1017)), + DEF_MOD("scu-ctu1-mix1", 1020, MOD_CLK_ID(1017)), + DEF_MOD("scu-ctu0-mix0", 1021, MOD_CLK_ID(1017)), + DEF_MOD("scu-src9", 1022, MOD_CLK_ID(1017)), + DEF_MOD("scu-src8", 1023, MOD_CLK_ID(1017)), + DEF_MOD("scu-src7", 1024, MOD_CLK_ID(1017)), + DEF_MOD("scu-src6", 1025, MOD_CLK_ID(1017)), + DEF_MOD("scu-src5", 1026, MOD_CLK_ID(1017)), + DEF_MOD("scu-src4", 1027, MOD_CLK_ID(1017)), + DEF_MOD("scu-src3", 1028, MOD_CLK_ID(1017)), + DEF_MOD("scu-src2", 1029, MOD_CLK_ID(1017)), + DEF_MOD("scu-src1", 1030, MOD_CLK_ID(1017)), + DEF_MOD("scu-src0", 1031, MOD_CLK_ID(1017)), +}; + +/* + * CPG Clock Data + */ + +/* + * MD EXTAL PLL0 PLL1 PLL2 PLL3 PLL4 OSC + * 14 13 19 17 (MHz) + *------------------------------------------------------------------------- + * 0 0 0 0 16.66 x 1 x180 x192 x144 x192 x144 /16 + * 0 0 0 1 16.66 x 1 x180 x192 x144 x128 x144 /16 + * 0 0 1 0 Prohibited setting + * 0 0 1 1 16.66 x 1 x180 x192 x144 x192 x144 /16 + * 0 1 0 0 20 x 1 x150 x160 x120 x160 x120 /19 + * 0 1 0 1 20 x 1 x150 x160 x120 x106 x120 /19 + * 0 1 1 0 Prohibited setting + * 0 1 1 1 20 x 1 x150 x160 x120 x160 x120 /19 + * 1 0 0 0 25 x 1 x120 x128 x96 x128 x96 /24 + * 1 0 0 1 25 x 1 x120 x128 x96 x84 x96 /24 + * 1 0 1 0 Prohibited setting + * 1 0 1 1 25 x 1 x120 x128 x96 x128 x96 /24 + * 1 1 0 0 33.33 / 2 x180 x192 x144 x192 x144 /32 + * 1 1 0 1 33.33 / 2 x180 x192 x144 x128 x144 /32 + * 1 1 1 0 Prohibited setting + * 1 1 1 1 33.33 / 2 x180 x192 x144 x192 x144 /32 + */ +#define CPG_PLL_CONFIG_INDEX(md) ((((md) & BIT(14)) >> 11) | \ + (((md) & BIT(13)) >> 11) | \ + (((md) & BIT(19)) >> 18) | \ + (((md) & BIT(17)) >> 17)) + +static const struct rcar_gen3_cpg_pll_config cpg_pll_configs[16] = { + /* EXTAL div PLL1 mult/div PLL3 mult/div OSC prediv */ + { 1, 192, 1, 192, 1, 16, }, + { 1, 192, 1, 128, 1, 16, }, + { 0, /* Prohibited setting */ }, + { 1, 192, 1, 192, 1, 16, }, + { 1, 160, 1, 160, 1, 19, }, + { 1, 160, 1, 106, 1, 19, }, + { 0, /* Prohibited setting */ }, + { 1, 160, 1, 160, 1, 19, }, + { 1, 128, 1, 128, 1, 24, }, + { 1, 128, 1, 84, 1, 24, }, + { 0, /* Prohibited setting */ }, + { 1, 128, 1, 128, 1, 24, }, + { 2, 192, 1, 192, 1, 32, }, + { 2, 192, 1, 128, 1, 32, }, + { 0, /* Prohibited setting */ }, + { 2, 192, 1, 192, 1, 32, }, +}; + +/* RMSTPCR[0-11] is not present on RZ/G2H */ +static const struct mstp_stop_table r8a774e1_mstp_table[] = { + { 0x00640800, 0x0, 0x0, 0 }, + { 0xF3EE9390, 0x0, 0x0, 0 }, + { 0x340FAFDC, 0x2040, 0x0, 0 }, + { 0xD80C7CDF, 0x400, 0x0, 0 }, + { 0x80000184, 0x180, 0x0, 0 }, + { 0x40BFFF46, 0x0, 0x0, 0 }, + { 0xE5FBEECF, 0x0, 0x0, 0 }, + { 0x39FFFF0E, 0x0, 0x0, 0 }, + { 0x01F19FF4, 0x0, 0x0, 0 }, + { 0xFFDFFFFF, 0x0, 0x0, 0 }, + { 0xFFFEFFE0, 0x0, 0x0, 0 }, + { 0x00000000, 0x0, 0x0, 0 }, +}; + +static const void *r8a774e1_get_pll_config(const u32 cpg_mode) +{ + return &cpg_pll_configs[CPG_PLL_CONFIG_INDEX(cpg_mode)]; +} + +static const struct cpg_mssr_info r8a774e1_cpg_mssr_info = { + .core_clk = r8a774e1_core_clks, + .core_clk_size = ARRAY_SIZE(r8a774e1_core_clks), + .mod_clk = r8a774e1_mod_clks, + .mod_clk_size = ARRAY_SIZE(r8a774e1_mod_clks), + .mstp_table = r8a774e1_mstp_table, + .mstp_table_size = ARRAY_SIZE(r8a774e1_mstp_table), + .reset_node = "renesas,r8a774e1-rst", + .extalr_node = "extalr", + .mod_clk_base = MOD_CLK_BASE, + .clk_extal_id = CLK_EXTAL, + .clk_extalr_id = CLK_EXTALR, + .get_pll_config = r8a774e1_get_pll_config, +}; + +static const struct udevice_id r8a774e1_clk_ids[] = { + { + .compatible = "renesas,r8a774e1-cpg-mssr", + .data = (ulong)&r8a774e1_cpg_mssr_info + }, + { } +}; + +U_BOOT_DRIVER(clk_r8a774e1) = { + .name = "clk_r8a774e1", + .id = UCLASS_CLK, + .of_match = r8a774e1_clk_ids, + .priv_auto_alloc_size = sizeof(struct gen3_clk_priv), + .ops = &gen3_clk_ops, + .probe = gen3_clk_probe, + .remove = gen3_clk_remove, +};
Renesas RZ/G2H (r8a774e1) is pin compatible with R-Car H3 (r8a77951), however it doesn't have several automotive specific peripherals. Add a r8a77951 specific pin groups/functions along with common pin groups/functions for supporting both r8a77951 and r8a774e1 SoC.
This patch is ported from mainline linux-5.9-rc4.
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- This patch depends on [1] [1]https://patchwork.ozlabs.org/project/uboot/list/?series=204203 --- arch/arm/mach-rmobile/Kconfig.64 | 1 + drivers/pinctrl/renesas/Kconfig | 10 + drivers/pinctrl/renesas/Makefile | 1 + drivers/pinctrl/renesas/pfc-r8a7795.c | 905 ++++++++++++++------------ drivers/pinctrl/renesas/pfc.c | 11 + drivers/pinctrl/renesas/sh_pfc.h | 1 + 6 files changed, 520 insertions(+), 409 deletions(-)
diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 422f14f70f..3a0529e7a4 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -15,6 +15,7 @@ config R8A774B1 config R8A774E1 bool "Renesas SoC R8A774E1" imply CLK_R8A774E1 + imply PINCTRL_PFC_R8A774E1
config R8A7795 bool "Renesas SoC R8A7795" diff --git a/drivers/pinctrl/renesas/Kconfig b/drivers/pinctrl/renesas/Kconfig index 0d839eecad..d2be4c84ba 100644 --- a/drivers/pinctrl/renesas/Kconfig +++ b/drivers/pinctrl/renesas/Kconfig @@ -77,6 +77,16 @@ config PINCTRL_PFC_R8A774B1 the GPIO definitions and pin control functions for each available multiplex function.
+config PINCTRL_PFC_R8A774E1 + bool "Renesas RZ/G2 R8A774E1 pin control driver" + depends on PINCTRL_PFC + help + Support pin multiplexing control on Renesas RZ/G2H R8A774E1 SoCs. + + The driver is controlled by a device tree node which contains both + the GPIO definitions and pin control functions for each available + multiplex function. + config PINCTRL_PFC_R8A7795 bool "Renesas RCar Gen3 R8A7795 pin control driver" depends on PINCTRL_PFC diff --git a/drivers/pinctrl/renesas/Makefile b/drivers/pinctrl/renesas/Makefile index 59dfd05b2c..1d00752051 100644 --- a/drivers/pinctrl/renesas/Makefile +++ b/drivers/pinctrl/renesas/Makefile @@ -1,6 +1,7 @@ obj-$(CONFIG_PINCTRL_PFC) += pfc.o obj-$(CONFIG_PINCTRL_PFC_R8A774A1) += pfc-r8a7796.o obj-$(CONFIG_PINCTRL_PFC_R8A774B1) += pfc-r8a77965.o +obj-$(CONFIG_PINCTRL_PFC_R8A774E1) += pfc-r8a7795.o obj-$(CONFIG_PINCTRL_PFC_R8A7790) += pfc-r8a7790.o obj-$(CONFIG_PINCTRL_PFC_R8A7791) += pfc-r8a7791.o obj-$(CONFIG_PINCTRL_PFC_R8A7792) += pfc-r8a7792.o diff --git a/drivers/pinctrl/renesas/pfc-r8a7795.c b/drivers/pinctrl/renesas/pfc-r8a7795.c index ba17a55775..b787c4883a 100644 --- a/drivers/pinctrl/renesas/pfc-r8a7795.c +++ b/drivers/pinctrl/renesas/pfc-r8a7795.c @@ -683,7 +683,7 @@ static const u16 pinmux_data[] = { PINMUX_IPSR_PHYS_MSEL(IP1_23_20, HRX3_D, I2C_SEL_3_0, SEL_HSCIF3_3), PINMUX_IPSR_PHYS_MSEL(IP1_23_20, VI4_DATA7_B, I2C_SEL_3_0, SEL_VIN4_1), PINMUX_IPSR_PHYS_MSEL(IP1_23_20, IERX_B, I2C_SEL_3_0, SEL_IEBUS_1), - PINMUX_IPSR_PHYS(IP0_23_20, SCL3, I2C_SEL_3_1), + PINMUX_IPSR_PHYS(IP1_23_20, SCL3, I2C_SEL_3_1),
PINMUX_IPSR_PHYS_MSEL(IP1_27_24, PWM2_A, I2C_SEL_3_0, SEL_PWM2_0), PINMUX_IPSR_PHYS_MSEL(IP1_27_24, HTX3_D, I2C_SEL_3_0, SEL_HSCIF3_3), @@ -3902,6 +3902,36 @@ static const unsigned int tmu_tclk2_b_mux[] = { TCLK2_B_MARK, };
+/* - TPU ------------------------------------------------------------------- */ +static const unsigned int tpu_to0_pins[] = { + /* TPU0TO0 */ + RCAR_GP_PIN(6, 28), +}; +static const unsigned int tpu_to0_mux[] = { + TPU0TO0_MARK, +}; +static const unsigned int tpu_to1_pins[] = { + /* TPU0TO1 */ + RCAR_GP_PIN(6, 29), +}; +static const unsigned int tpu_to1_mux[] = { + TPU0TO1_MARK, +}; +static const unsigned int tpu_to2_pins[] = { + /* TPU0TO2 */ + RCAR_GP_PIN(6, 30), +}; +static const unsigned int tpu_to2_mux[] = { + TPU0TO2_MARK, +}; +static const unsigned int tpu_to3_pins[] = { + /* TPU0TO3 */ + RCAR_GP_PIN(6, 31), +}; +static const unsigned int tpu_to3_mux[] = { + TPU0TO3_MARK, +}; + /* - USB0 ------------------------------------------------------------------- */ static const unsigned int usb0_pins[] = { /* PWEN, OVC */ @@ -4136,353 +4166,365 @@ static const unsigned int vin5_clk_mux[] = { VI5_CLK_MARK, };
-static const struct sh_pfc_pin_group pinmux_groups[] = { - SH_PFC_PIN_GROUP(audio_clk_a_a), - SH_PFC_PIN_GROUP(audio_clk_a_b), - SH_PFC_PIN_GROUP(audio_clk_a_c), - SH_PFC_PIN_GROUP(audio_clk_b_a), - SH_PFC_PIN_GROUP(audio_clk_b_b), - SH_PFC_PIN_GROUP(audio_clk_c_a), - SH_PFC_PIN_GROUP(audio_clk_c_b), - SH_PFC_PIN_GROUP(audio_clkout_a), - SH_PFC_PIN_GROUP(audio_clkout_b), - SH_PFC_PIN_GROUP(audio_clkout_c), - SH_PFC_PIN_GROUP(audio_clkout_d), - SH_PFC_PIN_GROUP(audio_clkout1_a), - SH_PFC_PIN_GROUP(audio_clkout1_b), - SH_PFC_PIN_GROUP(audio_clkout2_a), - SH_PFC_PIN_GROUP(audio_clkout2_b), - SH_PFC_PIN_GROUP(audio_clkout3_a), - SH_PFC_PIN_GROUP(audio_clkout3_b), - SH_PFC_PIN_GROUP(avb_link), - SH_PFC_PIN_GROUP(avb_magic), - SH_PFC_PIN_GROUP(avb_phy_int), - SH_PFC_PIN_GROUP_ALIAS(avb_mdc, avb_mdio), /* Deprecated */ - SH_PFC_PIN_GROUP(avb_mdio), - SH_PFC_PIN_GROUP(avb_mii), - SH_PFC_PIN_GROUP(avb_avtp_pps), - SH_PFC_PIN_GROUP(avb_avtp_match_a), - SH_PFC_PIN_GROUP(avb_avtp_capture_a), - SH_PFC_PIN_GROUP(avb_avtp_match_b), - SH_PFC_PIN_GROUP(avb_avtp_capture_b), - SH_PFC_PIN_GROUP(can0_data_a), - SH_PFC_PIN_GROUP(can0_data_b), - SH_PFC_PIN_GROUP(can1_data), - SH_PFC_PIN_GROUP(can_clk), - SH_PFC_PIN_GROUP(canfd0_data_a), - SH_PFC_PIN_GROUP(canfd0_data_b), - SH_PFC_PIN_GROUP(canfd1_data), - SH_PFC_PIN_GROUP(drif0_ctrl_a), - SH_PFC_PIN_GROUP(drif0_data0_a), - SH_PFC_PIN_GROUP(drif0_data1_a), - SH_PFC_PIN_GROUP(drif0_ctrl_b), - SH_PFC_PIN_GROUP(drif0_data0_b), - SH_PFC_PIN_GROUP(drif0_data1_b), - SH_PFC_PIN_GROUP(drif0_ctrl_c), - SH_PFC_PIN_GROUP(drif0_data0_c), - SH_PFC_PIN_GROUP(drif0_data1_c), - SH_PFC_PIN_GROUP(drif1_ctrl_a), - SH_PFC_PIN_GROUP(drif1_data0_a), - SH_PFC_PIN_GROUP(drif1_data1_a), - SH_PFC_PIN_GROUP(drif1_ctrl_b), - SH_PFC_PIN_GROUP(drif1_data0_b), - SH_PFC_PIN_GROUP(drif1_data1_b), - SH_PFC_PIN_GROUP(drif1_ctrl_c), - SH_PFC_PIN_GROUP(drif1_data0_c), - SH_PFC_PIN_GROUP(drif1_data1_c), - SH_PFC_PIN_GROUP(drif2_ctrl_a), - SH_PFC_PIN_GROUP(drif2_data0_a), - SH_PFC_PIN_GROUP(drif2_data1_a), - SH_PFC_PIN_GROUP(drif2_ctrl_b), - SH_PFC_PIN_GROUP(drif2_data0_b), - SH_PFC_PIN_GROUP(drif2_data1_b), - SH_PFC_PIN_GROUP(drif3_ctrl_a), - SH_PFC_PIN_GROUP(drif3_data0_a), - SH_PFC_PIN_GROUP(drif3_data1_a), - SH_PFC_PIN_GROUP(drif3_ctrl_b), - SH_PFC_PIN_GROUP(drif3_data0_b), - SH_PFC_PIN_GROUP(drif3_data1_b), - SH_PFC_PIN_GROUP(du_rgb666), - SH_PFC_PIN_GROUP(du_rgb888), - SH_PFC_PIN_GROUP(du_clk_out_0), - SH_PFC_PIN_GROUP(du_clk_out_1), - SH_PFC_PIN_GROUP(du_sync), - SH_PFC_PIN_GROUP(du_oddf), - SH_PFC_PIN_GROUP(du_cde), - SH_PFC_PIN_GROUP(du_disp), - SH_PFC_PIN_GROUP(hscif0_data), - SH_PFC_PIN_GROUP(hscif0_clk), - SH_PFC_PIN_GROUP(hscif0_ctrl), - SH_PFC_PIN_GROUP(hscif1_data_a), - SH_PFC_PIN_GROUP(hscif1_clk_a), - SH_PFC_PIN_GROUP(hscif1_ctrl_a), - SH_PFC_PIN_GROUP(hscif1_data_b), - SH_PFC_PIN_GROUP(hscif1_clk_b), - SH_PFC_PIN_GROUP(hscif1_ctrl_b), - SH_PFC_PIN_GROUP(hscif2_data_a), - SH_PFC_PIN_GROUP(hscif2_clk_a), - SH_PFC_PIN_GROUP(hscif2_ctrl_a), - SH_PFC_PIN_GROUP(hscif2_data_b), - SH_PFC_PIN_GROUP(hscif2_clk_b), - SH_PFC_PIN_GROUP(hscif2_ctrl_b), - SH_PFC_PIN_GROUP(hscif2_data_c), - SH_PFC_PIN_GROUP(hscif2_clk_c), - SH_PFC_PIN_GROUP(hscif2_ctrl_c), - SH_PFC_PIN_GROUP(hscif3_data_a), - SH_PFC_PIN_GROUP(hscif3_clk), - SH_PFC_PIN_GROUP(hscif3_ctrl), - SH_PFC_PIN_GROUP(hscif3_data_b), - SH_PFC_PIN_GROUP(hscif3_data_c), - SH_PFC_PIN_GROUP(hscif3_data_d), - SH_PFC_PIN_GROUP(hscif4_data_a), - SH_PFC_PIN_GROUP(hscif4_clk), - SH_PFC_PIN_GROUP(hscif4_ctrl), - SH_PFC_PIN_GROUP(hscif4_data_b), - SH_PFC_PIN_GROUP(i2c0), - SH_PFC_PIN_GROUP(i2c1_a), - SH_PFC_PIN_GROUP(i2c1_b), - SH_PFC_PIN_GROUP(i2c2_a), - SH_PFC_PIN_GROUP(i2c2_b), - SH_PFC_PIN_GROUP(i2c3), - SH_PFC_PIN_GROUP(i2c5), - SH_PFC_PIN_GROUP(i2c6_a), - SH_PFC_PIN_GROUP(i2c6_b), - SH_PFC_PIN_GROUP(i2c6_c), - SH_PFC_PIN_GROUP(intc_ex_irq0), - SH_PFC_PIN_GROUP(intc_ex_irq1), - SH_PFC_PIN_GROUP(intc_ex_irq2), - SH_PFC_PIN_GROUP(intc_ex_irq3), - SH_PFC_PIN_GROUP(intc_ex_irq4), - SH_PFC_PIN_GROUP(intc_ex_irq5), - SH_PFC_PIN_GROUP(msiof0_clk), - SH_PFC_PIN_GROUP(msiof0_sync), - SH_PFC_PIN_GROUP(msiof0_ss1), - SH_PFC_PIN_GROUP(msiof0_ss2), - SH_PFC_PIN_GROUP(msiof0_txd), - SH_PFC_PIN_GROUP(msiof0_rxd), - SH_PFC_PIN_GROUP(msiof1_clk_a), - SH_PFC_PIN_GROUP(msiof1_sync_a), - SH_PFC_PIN_GROUP(msiof1_ss1_a), - SH_PFC_PIN_GROUP(msiof1_ss2_a), - SH_PFC_PIN_GROUP(msiof1_txd_a), - SH_PFC_PIN_GROUP(msiof1_rxd_a), - SH_PFC_PIN_GROUP(msiof1_clk_b), - SH_PFC_PIN_GROUP(msiof1_sync_b), - SH_PFC_PIN_GROUP(msiof1_ss1_b), - SH_PFC_PIN_GROUP(msiof1_ss2_b), - SH_PFC_PIN_GROUP(msiof1_txd_b), - SH_PFC_PIN_GROUP(msiof1_rxd_b), - SH_PFC_PIN_GROUP(msiof1_clk_c), - SH_PFC_PIN_GROUP(msiof1_sync_c), - SH_PFC_PIN_GROUP(msiof1_ss1_c), - SH_PFC_PIN_GROUP(msiof1_ss2_c), - SH_PFC_PIN_GROUP(msiof1_txd_c), - SH_PFC_PIN_GROUP(msiof1_rxd_c), - SH_PFC_PIN_GROUP(msiof1_clk_d), - SH_PFC_PIN_GROUP(msiof1_sync_d), - SH_PFC_PIN_GROUP(msiof1_ss1_d), - SH_PFC_PIN_GROUP(msiof1_ss2_d), - SH_PFC_PIN_GROUP(msiof1_txd_d), - SH_PFC_PIN_GROUP(msiof1_rxd_d), - SH_PFC_PIN_GROUP(msiof1_clk_e), - SH_PFC_PIN_GROUP(msiof1_sync_e), - SH_PFC_PIN_GROUP(msiof1_ss1_e), - SH_PFC_PIN_GROUP(msiof1_ss2_e), - SH_PFC_PIN_GROUP(msiof1_txd_e), - SH_PFC_PIN_GROUP(msiof1_rxd_e), - SH_PFC_PIN_GROUP(msiof1_clk_f), - SH_PFC_PIN_GROUP(msiof1_sync_f), - SH_PFC_PIN_GROUP(msiof1_ss1_f), - SH_PFC_PIN_GROUP(msiof1_ss2_f), - SH_PFC_PIN_GROUP(msiof1_txd_f), - SH_PFC_PIN_GROUP(msiof1_rxd_f), - SH_PFC_PIN_GROUP(msiof1_clk_g), - SH_PFC_PIN_GROUP(msiof1_sync_g), - SH_PFC_PIN_GROUP(msiof1_ss1_g), - SH_PFC_PIN_GROUP(msiof1_ss2_g), - SH_PFC_PIN_GROUP(msiof1_txd_g), - SH_PFC_PIN_GROUP(msiof1_rxd_g), - SH_PFC_PIN_GROUP(msiof2_clk_a), - SH_PFC_PIN_GROUP(msiof2_sync_a), - SH_PFC_PIN_GROUP(msiof2_ss1_a), - SH_PFC_PIN_GROUP(msiof2_ss2_a), - SH_PFC_PIN_GROUP(msiof2_txd_a), - SH_PFC_PIN_GROUP(msiof2_rxd_a), - SH_PFC_PIN_GROUP(msiof2_clk_b), - SH_PFC_PIN_GROUP(msiof2_sync_b), - SH_PFC_PIN_GROUP(msiof2_ss1_b), - SH_PFC_PIN_GROUP(msiof2_ss2_b), - SH_PFC_PIN_GROUP(msiof2_txd_b), - SH_PFC_PIN_GROUP(msiof2_rxd_b), - SH_PFC_PIN_GROUP(msiof2_clk_c), - SH_PFC_PIN_GROUP(msiof2_sync_c), - SH_PFC_PIN_GROUP(msiof2_ss1_c), - SH_PFC_PIN_GROUP(msiof2_ss2_c), - SH_PFC_PIN_GROUP(msiof2_txd_c), - SH_PFC_PIN_GROUP(msiof2_rxd_c), - SH_PFC_PIN_GROUP(msiof2_clk_d), - SH_PFC_PIN_GROUP(msiof2_sync_d), - SH_PFC_PIN_GROUP(msiof2_ss1_d), - SH_PFC_PIN_GROUP(msiof2_ss2_d), - SH_PFC_PIN_GROUP(msiof2_txd_d), - SH_PFC_PIN_GROUP(msiof2_rxd_d), - SH_PFC_PIN_GROUP(msiof3_clk_a), - SH_PFC_PIN_GROUP(msiof3_sync_a), - SH_PFC_PIN_GROUP(msiof3_ss1_a), - SH_PFC_PIN_GROUP(msiof3_ss2_a), - SH_PFC_PIN_GROUP(msiof3_txd_a), - SH_PFC_PIN_GROUP(msiof3_rxd_a), - SH_PFC_PIN_GROUP(msiof3_clk_b), - SH_PFC_PIN_GROUP(msiof3_sync_b), - SH_PFC_PIN_GROUP(msiof3_ss1_b), - SH_PFC_PIN_GROUP(msiof3_ss2_b), - SH_PFC_PIN_GROUP(msiof3_txd_b), - SH_PFC_PIN_GROUP(msiof3_rxd_b), - SH_PFC_PIN_GROUP(msiof3_clk_c), - SH_PFC_PIN_GROUP(msiof3_sync_c), - SH_PFC_PIN_GROUP(msiof3_txd_c), - SH_PFC_PIN_GROUP(msiof3_rxd_c), - SH_PFC_PIN_GROUP(msiof3_clk_d), - SH_PFC_PIN_GROUP(msiof3_sync_d), - SH_PFC_PIN_GROUP(msiof3_ss1_d), - SH_PFC_PIN_GROUP(msiof3_txd_d), - SH_PFC_PIN_GROUP(msiof3_rxd_d), - SH_PFC_PIN_GROUP(msiof3_clk_e), - SH_PFC_PIN_GROUP(msiof3_sync_e), - SH_PFC_PIN_GROUP(msiof3_ss1_e), - SH_PFC_PIN_GROUP(msiof3_ss2_e), - SH_PFC_PIN_GROUP(msiof3_txd_e), - SH_PFC_PIN_GROUP(msiof3_rxd_e), - SH_PFC_PIN_GROUP(pwm0), - SH_PFC_PIN_GROUP(pwm1_a), - SH_PFC_PIN_GROUP(pwm1_b), - SH_PFC_PIN_GROUP(pwm2_a), - SH_PFC_PIN_GROUP(pwm2_b), - SH_PFC_PIN_GROUP(pwm3_a), - SH_PFC_PIN_GROUP(pwm3_b), - SH_PFC_PIN_GROUP(pwm4_a), - SH_PFC_PIN_GROUP(pwm4_b), - SH_PFC_PIN_GROUP(pwm5_a), - SH_PFC_PIN_GROUP(pwm5_b), - SH_PFC_PIN_GROUP(pwm6_a), - SH_PFC_PIN_GROUP(pwm6_b), - SH_PFC_PIN_GROUP(sata0_devslp_a), - SH_PFC_PIN_GROUP(sata0_devslp_b), - SH_PFC_PIN_GROUP(scif0_data), - SH_PFC_PIN_GROUP(scif0_clk), - SH_PFC_PIN_GROUP(scif0_ctrl), - SH_PFC_PIN_GROUP(scif1_data_a), - SH_PFC_PIN_GROUP(scif1_clk), - SH_PFC_PIN_GROUP(scif1_ctrl), - SH_PFC_PIN_GROUP(scif1_data_b), - SH_PFC_PIN_GROUP(scif2_data_a), - SH_PFC_PIN_GROUP(scif2_clk), - SH_PFC_PIN_GROUP(scif2_data_b), - SH_PFC_PIN_GROUP(scif3_data_a), - SH_PFC_PIN_GROUP(scif3_clk), - SH_PFC_PIN_GROUP(scif3_ctrl), - SH_PFC_PIN_GROUP(scif3_data_b), - SH_PFC_PIN_GROUP(scif4_data_a), - SH_PFC_PIN_GROUP(scif4_clk_a), - SH_PFC_PIN_GROUP(scif4_ctrl_a), - SH_PFC_PIN_GROUP(scif4_data_b), - SH_PFC_PIN_GROUP(scif4_clk_b), - SH_PFC_PIN_GROUP(scif4_ctrl_b), - SH_PFC_PIN_GROUP(scif4_data_c), - SH_PFC_PIN_GROUP(scif4_clk_c), - SH_PFC_PIN_GROUP(scif4_ctrl_c), - SH_PFC_PIN_GROUP(scif5_data_a), - SH_PFC_PIN_GROUP(scif5_clk_a), - SH_PFC_PIN_GROUP(scif5_data_b), - SH_PFC_PIN_GROUP(scif5_clk_b), - SH_PFC_PIN_GROUP(scif_clk_a), - SH_PFC_PIN_GROUP(scif_clk_b), - SH_PFC_PIN_GROUP(sdhi0_data1), - SH_PFC_PIN_GROUP(sdhi0_data4), - SH_PFC_PIN_GROUP(sdhi0_ctrl), - SH_PFC_PIN_GROUP(sdhi0_cd), - SH_PFC_PIN_GROUP(sdhi0_wp), - SH_PFC_PIN_GROUP(sdhi1_data1), - SH_PFC_PIN_GROUP(sdhi1_data4), - SH_PFC_PIN_GROUP(sdhi1_ctrl), - SH_PFC_PIN_GROUP(sdhi1_cd), - SH_PFC_PIN_GROUP(sdhi1_wp), - SH_PFC_PIN_GROUP(sdhi2_data1), - SH_PFC_PIN_GROUP(sdhi2_data4), - SH_PFC_PIN_GROUP(sdhi2_data8), - SH_PFC_PIN_GROUP(sdhi2_ctrl), - SH_PFC_PIN_GROUP(sdhi2_cd_a), - SH_PFC_PIN_GROUP(sdhi2_wp_a), - SH_PFC_PIN_GROUP(sdhi2_cd_b), - SH_PFC_PIN_GROUP(sdhi2_wp_b), - SH_PFC_PIN_GROUP(sdhi2_ds), - SH_PFC_PIN_GROUP(sdhi3_data1), - SH_PFC_PIN_GROUP(sdhi3_data4), - SH_PFC_PIN_GROUP(sdhi3_data8), - SH_PFC_PIN_GROUP(sdhi3_ctrl), - SH_PFC_PIN_GROUP(sdhi3_cd), - SH_PFC_PIN_GROUP(sdhi3_wp), - SH_PFC_PIN_GROUP(sdhi3_ds), - SH_PFC_PIN_GROUP(ssi0_data), - SH_PFC_PIN_GROUP(ssi01239_ctrl), - SH_PFC_PIN_GROUP(ssi1_data_a), - SH_PFC_PIN_GROUP(ssi1_data_b), - SH_PFC_PIN_GROUP(ssi1_ctrl_a), - SH_PFC_PIN_GROUP(ssi1_ctrl_b), - SH_PFC_PIN_GROUP(ssi2_data_a), - SH_PFC_PIN_GROUP(ssi2_data_b), - SH_PFC_PIN_GROUP(ssi2_ctrl_a), - SH_PFC_PIN_GROUP(ssi2_ctrl_b), - SH_PFC_PIN_GROUP(ssi3_data), - SH_PFC_PIN_GROUP(ssi349_ctrl), - SH_PFC_PIN_GROUP(ssi4_data), - SH_PFC_PIN_GROUP(ssi4_ctrl), - SH_PFC_PIN_GROUP(ssi5_data), - SH_PFC_PIN_GROUP(ssi5_ctrl), - SH_PFC_PIN_GROUP(ssi6_data), - SH_PFC_PIN_GROUP(ssi6_ctrl), - SH_PFC_PIN_GROUP(ssi7_data), - SH_PFC_PIN_GROUP(ssi78_ctrl), - SH_PFC_PIN_GROUP(ssi8_data), - SH_PFC_PIN_GROUP(ssi9_data_a), - SH_PFC_PIN_GROUP(ssi9_data_b), - SH_PFC_PIN_GROUP(ssi9_ctrl_a), - SH_PFC_PIN_GROUP(ssi9_ctrl_b), - SH_PFC_PIN_GROUP(tmu_tclk1_a), - SH_PFC_PIN_GROUP(tmu_tclk1_b), - SH_PFC_PIN_GROUP(tmu_tclk2_a), - SH_PFC_PIN_GROUP(tmu_tclk2_b), - SH_PFC_PIN_GROUP(usb0), - SH_PFC_PIN_GROUP(usb1), - SH_PFC_PIN_GROUP(usb2), - SH_PFC_PIN_GROUP(usb2_ch3), - SH_PFC_PIN_GROUP(usb30), - VIN_DATA_PIN_GROUP(vin4_data, 8, _a), - VIN_DATA_PIN_GROUP(vin4_data, 10, _a), - VIN_DATA_PIN_GROUP(vin4_data, 12, _a), - VIN_DATA_PIN_GROUP(vin4_data, 16, _a), - SH_PFC_PIN_GROUP(vin4_data18_a), - VIN_DATA_PIN_GROUP(vin4_data, 20, _a), - VIN_DATA_PIN_GROUP(vin4_data, 24, _a), - VIN_DATA_PIN_GROUP(vin4_data, 8, _b), - VIN_DATA_PIN_GROUP(vin4_data, 10, _b), - VIN_DATA_PIN_GROUP(vin4_data, 12, _b), - VIN_DATA_PIN_GROUP(vin4_data, 16, _b), - SH_PFC_PIN_GROUP(vin4_data18_b), - VIN_DATA_PIN_GROUP(vin4_data, 20, _b), - VIN_DATA_PIN_GROUP(vin4_data, 24, _b), - SH_PFC_PIN_GROUP(vin4_sync), - SH_PFC_PIN_GROUP(vin4_field), - SH_PFC_PIN_GROUP(vin4_clkenb), - SH_PFC_PIN_GROUP(vin4_clk), - VIN_DATA_PIN_GROUP(vin5_data, 8), - VIN_DATA_PIN_GROUP(vin5_data, 10), - VIN_DATA_PIN_GROUP(vin5_data, 12), - VIN_DATA_PIN_GROUP(vin5_data, 16), - SH_PFC_PIN_GROUP(vin5_sync), - SH_PFC_PIN_GROUP(vin5_field), - SH_PFC_PIN_GROUP(vin5_clkenb), - SH_PFC_PIN_GROUP(vin5_clk), +static const struct { + struct sh_pfc_pin_group common[320]; + struct sh_pfc_pin_group automotive[30]; +} pinmux_groups = { + .common = { + SH_PFC_PIN_GROUP(audio_clk_a_a), + SH_PFC_PIN_GROUP(audio_clk_a_b), + SH_PFC_PIN_GROUP(audio_clk_a_c), + SH_PFC_PIN_GROUP(audio_clk_b_a), + SH_PFC_PIN_GROUP(audio_clk_b_b), + SH_PFC_PIN_GROUP(audio_clk_c_a), + SH_PFC_PIN_GROUP(audio_clk_c_b), + SH_PFC_PIN_GROUP(audio_clkout_a), + SH_PFC_PIN_GROUP(audio_clkout_b), + SH_PFC_PIN_GROUP(audio_clkout_c), + SH_PFC_PIN_GROUP(audio_clkout_d), + SH_PFC_PIN_GROUP(audio_clkout1_a), + SH_PFC_PIN_GROUP(audio_clkout1_b), + SH_PFC_PIN_GROUP(audio_clkout2_a), + SH_PFC_PIN_GROUP(audio_clkout2_b), + SH_PFC_PIN_GROUP(audio_clkout3_a), + SH_PFC_PIN_GROUP(audio_clkout3_b), + SH_PFC_PIN_GROUP(avb_link), + SH_PFC_PIN_GROUP(avb_magic), + SH_PFC_PIN_GROUP(avb_phy_int), + SH_PFC_PIN_GROUP_ALIAS(avb_mdc, avb_mdio), /* Deprecated */ + SH_PFC_PIN_GROUP(avb_mdio), + SH_PFC_PIN_GROUP(avb_mii), + SH_PFC_PIN_GROUP(avb_avtp_pps), + SH_PFC_PIN_GROUP(avb_avtp_match_a), + SH_PFC_PIN_GROUP(avb_avtp_capture_a), + SH_PFC_PIN_GROUP(avb_avtp_match_b), + SH_PFC_PIN_GROUP(avb_avtp_capture_b), + SH_PFC_PIN_GROUP(can0_data_a), + SH_PFC_PIN_GROUP(can0_data_b), + SH_PFC_PIN_GROUP(can1_data), + SH_PFC_PIN_GROUP(can_clk), + SH_PFC_PIN_GROUP(canfd0_data_a), + SH_PFC_PIN_GROUP(canfd0_data_b), + SH_PFC_PIN_GROUP(canfd1_data), + SH_PFC_PIN_GROUP(du_rgb666), + SH_PFC_PIN_GROUP(du_rgb888), + SH_PFC_PIN_GROUP(du_clk_out_0), + SH_PFC_PIN_GROUP(du_clk_out_1), + SH_PFC_PIN_GROUP(du_sync), + SH_PFC_PIN_GROUP(du_oddf), + SH_PFC_PIN_GROUP(du_cde), + SH_PFC_PIN_GROUP(du_disp), + SH_PFC_PIN_GROUP(hscif0_data), + SH_PFC_PIN_GROUP(hscif0_clk), + SH_PFC_PIN_GROUP(hscif0_ctrl), + SH_PFC_PIN_GROUP(hscif1_data_a), + SH_PFC_PIN_GROUP(hscif1_clk_a), + SH_PFC_PIN_GROUP(hscif1_ctrl_a), + SH_PFC_PIN_GROUP(hscif1_data_b), + SH_PFC_PIN_GROUP(hscif1_clk_b), + SH_PFC_PIN_GROUP(hscif1_ctrl_b), + SH_PFC_PIN_GROUP(hscif2_data_a), + SH_PFC_PIN_GROUP(hscif2_clk_a), + SH_PFC_PIN_GROUP(hscif2_ctrl_a), + SH_PFC_PIN_GROUP(hscif2_data_b), + SH_PFC_PIN_GROUP(hscif2_clk_b), + SH_PFC_PIN_GROUP(hscif2_ctrl_b), + SH_PFC_PIN_GROUP(hscif2_data_c), + SH_PFC_PIN_GROUP(hscif2_clk_c), + SH_PFC_PIN_GROUP(hscif2_ctrl_c), + SH_PFC_PIN_GROUP(hscif3_data_a), + SH_PFC_PIN_GROUP(hscif3_clk), + SH_PFC_PIN_GROUP(hscif3_ctrl), + SH_PFC_PIN_GROUP(hscif3_data_b), + SH_PFC_PIN_GROUP(hscif3_data_c), + SH_PFC_PIN_GROUP(hscif3_data_d), + SH_PFC_PIN_GROUP(hscif4_data_a), + SH_PFC_PIN_GROUP(hscif4_clk), + SH_PFC_PIN_GROUP(hscif4_ctrl), + SH_PFC_PIN_GROUP(hscif4_data_b), + SH_PFC_PIN_GROUP(i2c0), + SH_PFC_PIN_GROUP(i2c1_a), + SH_PFC_PIN_GROUP(i2c1_b), + SH_PFC_PIN_GROUP(i2c2_a), + SH_PFC_PIN_GROUP(i2c2_b), + SH_PFC_PIN_GROUP(i2c3), + SH_PFC_PIN_GROUP(i2c5), + SH_PFC_PIN_GROUP(i2c6_a), + SH_PFC_PIN_GROUP(i2c6_b), + SH_PFC_PIN_GROUP(i2c6_c), + SH_PFC_PIN_GROUP(intc_ex_irq0), + SH_PFC_PIN_GROUP(intc_ex_irq1), + SH_PFC_PIN_GROUP(intc_ex_irq2), + SH_PFC_PIN_GROUP(intc_ex_irq3), + SH_PFC_PIN_GROUP(intc_ex_irq4), + SH_PFC_PIN_GROUP(intc_ex_irq5), + SH_PFC_PIN_GROUP(msiof0_clk), + SH_PFC_PIN_GROUP(msiof0_sync), + SH_PFC_PIN_GROUP(msiof0_ss1), + SH_PFC_PIN_GROUP(msiof0_ss2), + SH_PFC_PIN_GROUP(msiof0_txd), + SH_PFC_PIN_GROUP(msiof0_rxd), + SH_PFC_PIN_GROUP(msiof1_clk_a), + SH_PFC_PIN_GROUP(msiof1_sync_a), + SH_PFC_PIN_GROUP(msiof1_ss1_a), + SH_PFC_PIN_GROUP(msiof1_ss2_a), + SH_PFC_PIN_GROUP(msiof1_txd_a), + SH_PFC_PIN_GROUP(msiof1_rxd_a), + SH_PFC_PIN_GROUP(msiof1_clk_b), + SH_PFC_PIN_GROUP(msiof1_sync_b), + SH_PFC_PIN_GROUP(msiof1_ss1_b), + SH_PFC_PIN_GROUP(msiof1_ss2_b), + SH_PFC_PIN_GROUP(msiof1_txd_b), + SH_PFC_PIN_GROUP(msiof1_rxd_b), + SH_PFC_PIN_GROUP(msiof1_clk_c), + SH_PFC_PIN_GROUP(msiof1_sync_c), + SH_PFC_PIN_GROUP(msiof1_ss1_c), + SH_PFC_PIN_GROUP(msiof1_ss2_c), + SH_PFC_PIN_GROUP(msiof1_txd_c), + SH_PFC_PIN_GROUP(msiof1_rxd_c), + SH_PFC_PIN_GROUP(msiof1_clk_d), + SH_PFC_PIN_GROUP(msiof1_sync_d), + SH_PFC_PIN_GROUP(msiof1_ss1_d), + SH_PFC_PIN_GROUP(msiof1_ss2_d), + SH_PFC_PIN_GROUP(msiof1_txd_d), + SH_PFC_PIN_GROUP(msiof1_rxd_d), + SH_PFC_PIN_GROUP(msiof1_clk_e), + SH_PFC_PIN_GROUP(msiof1_sync_e), + SH_PFC_PIN_GROUP(msiof1_ss1_e), + SH_PFC_PIN_GROUP(msiof1_ss2_e), + SH_PFC_PIN_GROUP(msiof1_txd_e), + SH_PFC_PIN_GROUP(msiof1_rxd_e), + SH_PFC_PIN_GROUP(msiof1_clk_f), + SH_PFC_PIN_GROUP(msiof1_sync_f), + SH_PFC_PIN_GROUP(msiof1_ss1_f), + SH_PFC_PIN_GROUP(msiof1_ss2_f), + SH_PFC_PIN_GROUP(msiof1_txd_f), + SH_PFC_PIN_GROUP(msiof1_rxd_f), + SH_PFC_PIN_GROUP(msiof1_clk_g), + SH_PFC_PIN_GROUP(msiof1_sync_g), + SH_PFC_PIN_GROUP(msiof1_ss1_g), + SH_PFC_PIN_GROUP(msiof1_ss2_g), + SH_PFC_PIN_GROUP(msiof1_txd_g), + SH_PFC_PIN_GROUP(msiof1_rxd_g), + SH_PFC_PIN_GROUP(msiof2_clk_a), + SH_PFC_PIN_GROUP(msiof2_sync_a), + SH_PFC_PIN_GROUP(msiof2_ss1_a), + SH_PFC_PIN_GROUP(msiof2_ss2_a), + SH_PFC_PIN_GROUP(msiof2_txd_a), + SH_PFC_PIN_GROUP(msiof2_rxd_a), + SH_PFC_PIN_GROUP(msiof2_clk_b), + SH_PFC_PIN_GROUP(msiof2_sync_b), + SH_PFC_PIN_GROUP(msiof2_ss1_b), + SH_PFC_PIN_GROUP(msiof2_ss2_b), + SH_PFC_PIN_GROUP(msiof2_txd_b), + SH_PFC_PIN_GROUP(msiof2_rxd_b), + SH_PFC_PIN_GROUP(msiof2_clk_c), + SH_PFC_PIN_GROUP(msiof2_sync_c), + SH_PFC_PIN_GROUP(msiof2_ss1_c), + SH_PFC_PIN_GROUP(msiof2_ss2_c), + SH_PFC_PIN_GROUP(msiof2_txd_c), + SH_PFC_PIN_GROUP(msiof2_rxd_c), + SH_PFC_PIN_GROUP(msiof2_clk_d), + SH_PFC_PIN_GROUP(msiof2_sync_d), + SH_PFC_PIN_GROUP(msiof2_ss1_d), + SH_PFC_PIN_GROUP(msiof2_ss2_d), + SH_PFC_PIN_GROUP(msiof2_txd_d), + SH_PFC_PIN_GROUP(msiof2_rxd_d), + SH_PFC_PIN_GROUP(msiof3_clk_a), + SH_PFC_PIN_GROUP(msiof3_sync_a), + SH_PFC_PIN_GROUP(msiof3_ss1_a), + SH_PFC_PIN_GROUP(msiof3_ss2_a), + SH_PFC_PIN_GROUP(msiof3_txd_a), + SH_PFC_PIN_GROUP(msiof3_rxd_a), + SH_PFC_PIN_GROUP(msiof3_clk_b), + SH_PFC_PIN_GROUP(msiof3_sync_b), + SH_PFC_PIN_GROUP(msiof3_ss1_b), + SH_PFC_PIN_GROUP(msiof3_ss2_b), + SH_PFC_PIN_GROUP(msiof3_txd_b), + SH_PFC_PIN_GROUP(msiof3_rxd_b), + SH_PFC_PIN_GROUP(msiof3_clk_c), + SH_PFC_PIN_GROUP(msiof3_sync_c), + SH_PFC_PIN_GROUP(msiof3_txd_c), + SH_PFC_PIN_GROUP(msiof3_rxd_c), + SH_PFC_PIN_GROUP(msiof3_clk_d), + SH_PFC_PIN_GROUP(msiof3_sync_d), + SH_PFC_PIN_GROUP(msiof3_ss1_d), + SH_PFC_PIN_GROUP(msiof3_txd_d), + SH_PFC_PIN_GROUP(msiof3_rxd_d), + SH_PFC_PIN_GROUP(msiof3_clk_e), + SH_PFC_PIN_GROUP(msiof3_sync_e), + SH_PFC_PIN_GROUP(msiof3_ss1_e), + SH_PFC_PIN_GROUP(msiof3_ss2_e), + SH_PFC_PIN_GROUP(msiof3_txd_e), + SH_PFC_PIN_GROUP(msiof3_rxd_e), + SH_PFC_PIN_GROUP(pwm0), + SH_PFC_PIN_GROUP(pwm1_a), + SH_PFC_PIN_GROUP(pwm1_b), + SH_PFC_PIN_GROUP(pwm2_a), + SH_PFC_PIN_GROUP(pwm2_b), + SH_PFC_PIN_GROUP(pwm3_a), + SH_PFC_PIN_GROUP(pwm3_b), + SH_PFC_PIN_GROUP(pwm4_a), + SH_PFC_PIN_GROUP(pwm4_b), + SH_PFC_PIN_GROUP(pwm5_a), + SH_PFC_PIN_GROUP(pwm5_b), + SH_PFC_PIN_GROUP(pwm6_a), + SH_PFC_PIN_GROUP(pwm6_b), + SH_PFC_PIN_GROUP(sata0_devslp_a), + SH_PFC_PIN_GROUP(sata0_devslp_b), + SH_PFC_PIN_GROUP(scif0_data), + SH_PFC_PIN_GROUP(scif0_clk), + SH_PFC_PIN_GROUP(scif0_ctrl), + SH_PFC_PIN_GROUP(scif1_data_a), + SH_PFC_PIN_GROUP(scif1_clk), + SH_PFC_PIN_GROUP(scif1_ctrl), + SH_PFC_PIN_GROUP(scif1_data_b), + SH_PFC_PIN_GROUP(scif2_data_a), + SH_PFC_PIN_GROUP(scif2_clk), + SH_PFC_PIN_GROUP(scif2_data_b), + SH_PFC_PIN_GROUP(scif3_data_a), + SH_PFC_PIN_GROUP(scif3_clk), + SH_PFC_PIN_GROUP(scif3_ctrl), + SH_PFC_PIN_GROUP(scif3_data_b), + SH_PFC_PIN_GROUP(scif4_data_a), + SH_PFC_PIN_GROUP(scif4_clk_a), + SH_PFC_PIN_GROUP(scif4_ctrl_a), + SH_PFC_PIN_GROUP(scif4_data_b), + SH_PFC_PIN_GROUP(scif4_clk_b), + SH_PFC_PIN_GROUP(scif4_ctrl_b), + SH_PFC_PIN_GROUP(scif4_data_c), + SH_PFC_PIN_GROUP(scif4_clk_c), + SH_PFC_PIN_GROUP(scif4_ctrl_c), + SH_PFC_PIN_GROUP(scif5_data_a), + SH_PFC_PIN_GROUP(scif5_clk_a), + SH_PFC_PIN_GROUP(scif5_data_b), + SH_PFC_PIN_GROUP(scif5_clk_b), + SH_PFC_PIN_GROUP(scif_clk_a), + SH_PFC_PIN_GROUP(scif_clk_b), + SH_PFC_PIN_GROUP(sdhi0_data1), + SH_PFC_PIN_GROUP(sdhi0_data4), + SH_PFC_PIN_GROUP(sdhi0_ctrl), + SH_PFC_PIN_GROUP(sdhi0_cd), + SH_PFC_PIN_GROUP(sdhi0_wp), + SH_PFC_PIN_GROUP(sdhi1_data1), + SH_PFC_PIN_GROUP(sdhi1_data4), + SH_PFC_PIN_GROUP(sdhi1_ctrl), + SH_PFC_PIN_GROUP(sdhi1_cd), + SH_PFC_PIN_GROUP(sdhi1_wp), + SH_PFC_PIN_GROUP(sdhi2_data1), + SH_PFC_PIN_GROUP(sdhi2_data4), + SH_PFC_PIN_GROUP(sdhi2_data8), + SH_PFC_PIN_GROUP(sdhi2_ctrl), + SH_PFC_PIN_GROUP(sdhi2_cd_a), + SH_PFC_PIN_GROUP(sdhi2_wp_a), + SH_PFC_PIN_GROUP(sdhi2_cd_b), + SH_PFC_PIN_GROUP(sdhi2_wp_b), + SH_PFC_PIN_GROUP(sdhi2_ds), + SH_PFC_PIN_GROUP(sdhi3_data1), + SH_PFC_PIN_GROUP(sdhi3_data4), + SH_PFC_PIN_GROUP(sdhi3_data8), + SH_PFC_PIN_GROUP(sdhi3_ctrl), + SH_PFC_PIN_GROUP(sdhi3_cd), + SH_PFC_PIN_GROUP(sdhi3_wp), + SH_PFC_PIN_GROUP(sdhi3_ds), + SH_PFC_PIN_GROUP(ssi0_data), + SH_PFC_PIN_GROUP(ssi01239_ctrl), + SH_PFC_PIN_GROUP(ssi1_data_a), + SH_PFC_PIN_GROUP(ssi1_data_b), + SH_PFC_PIN_GROUP(ssi1_ctrl_a), + SH_PFC_PIN_GROUP(ssi1_ctrl_b), + SH_PFC_PIN_GROUP(ssi2_data_a), + SH_PFC_PIN_GROUP(ssi2_data_b), + SH_PFC_PIN_GROUP(ssi2_ctrl_a), + SH_PFC_PIN_GROUP(ssi2_ctrl_b), + SH_PFC_PIN_GROUP(ssi3_data), + SH_PFC_PIN_GROUP(ssi349_ctrl), + SH_PFC_PIN_GROUP(ssi4_data), + SH_PFC_PIN_GROUP(ssi4_ctrl), + SH_PFC_PIN_GROUP(ssi5_data), + SH_PFC_PIN_GROUP(ssi5_ctrl), + SH_PFC_PIN_GROUP(ssi6_data), + SH_PFC_PIN_GROUP(ssi6_ctrl), + SH_PFC_PIN_GROUP(ssi7_data), + SH_PFC_PIN_GROUP(ssi78_ctrl), + SH_PFC_PIN_GROUP(ssi8_data), + SH_PFC_PIN_GROUP(ssi9_data_a), + SH_PFC_PIN_GROUP(ssi9_data_b), + SH_PFC_PIN_GROUP(ssi9_ctrl_a), + SH_PFC_PIN_GROUP(ssi9_ctrl_b), + SH_PFC_PIN_GROUP(tmu_tclk1_a), + SH_PFC_PIN_GROUP(tmu_tclk1_b), + SH_PFC_PIN_GROUP(tmu_tclk2_a), + SH_PFC_PIN_GROUP(tmu_tclk2_b), + SH_PFC_PIN_GROUP(tpu_to0), + SH_PFC_PIN_GROUP(tpu_to1), + SH_PFC_PIN_GROUP(tpu_to2), + SH_PFC_PIN_GROUP(tpu_to3), + SH_PFC_PIN_GROUP(usb0), + SH_PFC_PIN_GROUP(usb1), + SH_PFC_PIN_GROUP(usb2), + SH_PFC_PIN_GROUP(usb2_ch3), + SH_PFC_PIN_GROUP(usb30), + VIN_DATA_PIN_GROUP(vin4_data, 8, _a), + VIN_DATA_PIN_GROUP(vin4_data, 10, _a), + VIN_DATA_PIN_GROUP(vin4_data, 12, _a), + VIN_DATA_PIN_GROUP(vin4_data, 16, _a), + SH_PFC_PIN_GROUP(vin4_data18_a), + VIN_DATA_PIN_GROUP(vin4_data, 20, _a), + VIN_DATA_PIN_GROUP(vin4_data, 24, _a), + VIN_DATA_PIN_GROUP(vin4_data, 8, _b), + VIN_DATA_PIN_GROUP(vin4_data, 10, _b), + VIN_DATA_PIN_GROUP(vin4_data, 12, _b), + VIN_DATA_PIN_GROUP(vin4_data, 16, _b), + SH_PFC_PIN_GROUP(vin4_data18_b), + VIN_DATA_PIN_GROUP(vin4_data, 20, _b), + VIN_DATA_PIN_GROUP(vin4_data, 24, _b), + SH_PFC_PIN_GROUP(vin4_sync), + SH_PFC_PIN_GROUP(vin4_field), + SH_PFC_PIN_GROUP(vin4_clkenb), + SH_PFC_PIN_GROUP(vin4_clk), + VIN_DATA_PIN_GROUP(vin5_data, 8), + VIN_DATA_PIN_GROUP(vin5_data, 10), + VIN_DATA_PIN_GROUP(vin5_data, 12), + VIN_DATA_PIN_GROUP(vin5_data, 16), + SH_PFC_PIN_GROUP(vin5_sync), + SH_PFC_PIN_GROUP(vin5_field), + SH_PFC_PIN_GROUP(vin5_clkenb), + SH_PFC_PIN_GROUP(vin5_clk), + }, + .automotive = { + SH_PFC_PIN_GROUP(drif0_ctrl_a), + SH_PFC_PIN_GROUP(drif0_data0_a), + SH_PFC_PIN_GROUP(drif0_data1_a), + SH_PFC_PIN_GROUP(drif0_ctrl_b), + SH_PFC_PIN_GROUP(drif0_data0_b), + SH_PFC_PIN_GROUP(drif0_data1_b), + SH_PFC_PIN_GROUP(drif0_ctrl_c), + SH_PFC_PIN_GROUP(drif0_data0_c), + SH_PFC_PIN_GROUP(drif0_data1_c), + SH_PFC_PIN_GROUP(drif1_ctrl_a), + SH_PFC_PIN_GROUP(drif1_data0_a), + SH_PFC_PIN_GROUP(drif1_data1_a), + SH_PFC_PIN_GROUP(drif1_ctrl_b), + SH_PFC_PIN_GROUP(drif1_data0_b), + SH_PFC_PIN_GROUP(drif1_data1_b), + SH_PFC_PIN_GROUP(drif1_ctrl_c), + SH_PFC_PIN_GROUP(drif1_data0_c), + SH_PFC_PIN_GROUP(drif1_data1_c), + SH_PFC_PIN_GROUP(drif2_ctrl_a), + SH_PFC_PIN_GROUP(drif2_data0_a), + SH_PFC_PIN_GROUP(drif2_data1_a), + SH_PFC_PIN_GROUP(drif2_ctrl_b), + SH_PFC_PIN_GROUP(drif2_data0_b), + SH_PFC_PIN_GROUP(drif2_data1_b), + SH_PFC_PIN_GROUP(drif3_ctrl_a), + SH_PFC_PIN_GROUP(drif3_data0_a), + SH_PFC_PIN_GROUP(drif3_data1_a), + SH_PFC_PIN_GROUP(drif3_ctrl_b), + SH_PFC_PIN_GROUP(drif3_data0_b), + SH_PFC_PIN_GROUP(drif3_data1_b), + } + };
static const char * const audio_clk_groups[] = { @@ -4947,6 +4989,13 @@ static const char * const tmu_groups[] = { "tmu_tclk2_b", };
+static const char * const tpu_groups[] = { + "tpu_to0", + "tpu_to1", + "tpu_to2", + "tpu_to3", +}; + static const char * const usb0_groups[] = { "usb0", }; @@ -4999,63 +5048,72 @@ static const char * const vin5_groups[] = { "vin5_clk", };
-static const struct sh_pfc_function pinmux_functions[] = { - SH_PFC_FUNCTION(audio_clk), - SH_PFC_FUNCTION(avb), - SH_PFC_FUNCTION(can0), - SH_PFC_FUNCTION(can1), - SH_PFC_FUNCTION(can_clk), - SH_PFC_FUNCTION(canfd0), - SH_PFC_FUNCTION(canfd1), - SH_PFC_FUNCTION(drif0), - SH_PFC_FUNCTION(drif1), - SH_PFC_FUNCTION(drif2), - SH_PFC_FUNCTION(drif3), - SH_PFC_FUNCTION(du), - SH_PFC_FUNCTION(hscif0), - SH_PFC_FUNCTION(hscif1), - SH_PFC_FUNCTION(hscif2), - SH_PFC_FUNCTION(hscif3), - SH_PFC_FUNCTION(hscif4), - SH_PFC_FUNCTION(i2c0), - SH_PFC_FUNCTION(i2c1), - SH_PFC_FUNCTION(i2c2), - SH_PFC_FUNCTION(i2c3), - SH_PFC_FUNCTION(i2c5), - SH_PFC_FUNCTION(i2c6), - SH_PFC_FUNCTION(intc_ex), - SH_PFC_FUNCTION(msiof0), - SH_PFC_FUNCTION(msiof1), - SH_PFC_FUNCTION(msiof2), - SH_PFC_FUNCTION(msiof3), - SH_PFC_FUNCTION(pwm0), - SH_PFC_FUNCTION(pwm1), - SH_PFC_FUNCTION(pwm2), - SH_PFC_FUNCTION(pwm3), - SH_PFC_FUNCTION(pwm4), - SH_PFC_FUNCTION(pwm5), - SH_PFC_FUNCTION(pwm6), - SH_PFC_FUNCTION(sata0), - SH_PFC_FUNCTION(scif0), - SH_PFC_FUNCTION(scif1), - SH_PFC_FUNCTION(scif2), - SH_PFC_FUNCTION(scif3), - SH_PFC_FUNCTION(scif4), - SH_PFC_FUNCTION(scif5), - SH_PFC_FUNCTION(scif_clk), - SH_PFC_FUNCTION(sdhi0), - SH_PFC_FUNCTION(sdhi1), - SH_PFC_FUNCTION(sdhi2), - SH_PFC_FUNCTION(sdhi3), - SH_PFC_FUNCTION(ssi), - SH_PFC_FUNCTION(tmu), - SH_PFC_FUNCTION(usb0), - SH_PFC_FUNCTION(usb1), - SH_PFC_FUNCTION(usb2), - SH_PFC_FUNCTION(usb2_ch3), - SH_PFC_FUNCTION(usb30), - SH_PFC_FUNCTION(vin4), - SH_PFC_FUNCTION(vin5), +static const struct { + struct sh_pfc_function common[53]; + struct sh_pfc_function automotive[4]; +} pinmux_functions = { + .common = { + SH_PFC_FUNCTION(audio_clk), + SH_PFC_FUNCTION(avb), + SH_PFC_FUNCTION(can0), + SH_PFC_FUNCTION(can1), + SH_PFC_FUNCTION(can_clk), + SH_PFC_FUNCTION(canfd0), + SH_PFC_FUNCTION(canfd1), + SH_PFC_FUNCTION(du), + SH_PFC_FUNCTION(hscif0), + SH_PFC_FUNCTION(hscif1), + SH_PFC_FUNCTION(hscif2), + SH_PFC_FUNCTION(hscif3), + SH_PFC_FUNCTION(hscif4), + SH_PFC_FUNCTION(i2c0), + SH_PFC_FUNCTION(i2c1), + SH_PFC_FUNCTION(i2c2), + SH_PFC_FUNCTION(i2c3), + SH_PFC_FUNCTION(i2c5), + SH_PFC_FUNCTION(i2c6), + SH_PFC_FUNCTION(intc_ex), + SH_PFC_FUNCTION(msiof0), + SH_PFC_FUNCTION(msiof1), + SH_PFC_FUNCTION(msiof2), + SH_PFC_FUNCTION(msiof3), + SH_PFC_FUNCTION(pwm0), + SH_PFC_FUNCTION(pwm1), + SH_PFC_FUNCTION(pwm2), + SH_PFC_FUNCTION(pwm3), + SH_PFC_FUNCTION(pwm4), + SH_PFC_FUNCTION(pwm5), + SH_PFC_FUNCTION(pwm6), + SH_PFC_FUNCTION(sata0), + SH_PFC_FUNCTION(scif0), + SH_PFC_FUNCTION(scif1), + SH_PFC_FUNCTION(scif2), + SH_PFC_FUNCTION(scif3), + SH_PFC_FUNCTION(scif4), + SH_PFC_FUNCTION(scif5), + SH_PFC_FUNCTION(scif_clk), + SH_PFC_FUNCTION(sdhi0), + SH_PFC_FUNCTION(sdhi1), + SH_PFC_FUNCTION(sdhi2), + SH_PFC_FUNCTION(sdhi3), + SH_PFC_FUNCTION(ssi), + SH_PFC_FUNCTION(tmu), + SH_PFC_FUNCTION(tpu), + SH_PFC_FUNCTION(usb0), + SH_PFC_FUNCTION(usb1), + SH_PFC_FUNCTION(usb2), + SH_PFC_FUNCTION(usb2_ch3), + SH_PFC_FUNCTION(usb30), + SH_PFC_FUNCTION(vin4), + SH_PFC_FUNCTION(vin5), + }, + .automotive = { + SH_PFC_FUNCTION(drif0), + SH_PFC_FUNCTION(drif1), + SH_PFC_FUNCTION(drif2), + SH_PFC_FUNCTION(drif3), + } + };
static const struct pinmux_cfg_reg pinmux_config_regs[] = { @@ -6186,6 +6244,32 @@ static const struct sh_pfc_soc_operations r8a7795_pinmux_ops = { .set_bias = r8a7795_pinmux_set_bias, };
+#ifdef CONFIG_PINCTRL_PFC_R8A774E1 +const struct sh_pfc_soc_info r8a774e1_pinmux_info = { + .name = "r8a774e1_pfc", + .ops = &r8a7795_pinmux_ops, + .unlock_reg = 0xe6060000, /* PMMR */ + + .function = { PINMUX_FUNCTION_BEGIN, PINMUX_FUNCTION_END }, + + .pins = pinmux_pins, + .nr_pins = ARRAY_SIZE(pinmux_pins), + .groups = pinmux_groups.common, + .nr_groups = ARRAY_SIZE(pinmux_groups.common), + .functions = pinmux_functions.common, + .nr_functions = ARRAY_SIZE(pinmux_functions.common), + + .cfg_regs = pinmux_config_regs, + .drive_regs = pinmux_drive_regs, + .bias_regs = pinmux_bias_regs, + .ioctrl_regs = pinmux_ioctrl_regs, + + .pinmux_data = pinmux_data, + .pinmux_data_size = ARRAY_SIZE(pinmux_data), +}; +#endif + +#ifdef CONFIG_PINCTRL_PFC_R8A7795 const struct sh_pfc_soc_info r8a7795_pinmux_info = { .name = "r8a77951_pfc", .ops = &r8a7795_pinmux_ops, @@ -6195,10 +6279,12 @@ const struct sh_pfc_soc_info r8a7795_pinmux_info = {
.pins = pinmux_pins, .nr_pins = ARRAY_SIZE(pinmux_pins), - .groups = pinmux_groups, - .nr_groups = ARRAY_SIZE(pinmux_groups), - .functions = pinmux_functions, - .nr_functions = ARRAY_SIZE(pinmux_functions), + .groups = pinmux_groups.common, + .nr_groups = ARRAY_SIZE(pinmux_groups.common) + + ARRAY_SIZE(pinmux_groups.automotive), + .functions = pinmux_functions.common, + .nr_functions = ARRAY_SIZE(pinmux_functions.common) + + ARRAY_SIZE(pinmux_functions.automotive),
.cfg_regs = pinmux_config_regs, .drive_regs = pinmux_drive_regs, @@ -6208,3 +6294,4 @@ const struct sh_pfc_soc_info r8a7795_pinmux_info = { .pinmux_data = pinmux_data, .pinmux_data_size = ARRAY_SIZE(pinmux_data), }; +#endif diff --git a/drivers/pinctrl/renesas/pfc.c b/drivers/pinctrl/renesas/pfc.c index 568ed3e7df..db0fa9b728 100644 --- a/drivers/pinctrl/renesas/pfc.c +++ b/drivers/pinctrl/renesas/pfc.c @@ -34,6 +34,7 @@ enum sh_pfc_model { SH_PFC_R8A7796, SH_PFC_R8A774A1, SH_PFC_R8A774B1, + SH_PFC_R8A774E1, SH_PFC_R8A77965, SH_PFC_R8A77970, SH_PFC_R8A77980, @@ -863,6 +864,10 @@ static int sh_pfc_pinctrl_probe(struct udevice *dev) if (model == SH_PFC_R8A774B1) priv->pfc.info = &r8a774b1_pinmux_info; #endif +#ifdef CONFIG_PINCTRL_PFC_R8A774E1 + if (model == SH_PFC_R8A774E1) + priv->pfc.info = &r8a774e1_pinmux_info; +#endif #ifdef CONFIG_PINCTRL_PFC_R8A77965 if (model == SH_PFC_R8A77965) priv->pfc.info = &r8a77965_pinmux_info; @@ -946,6 +951,12 @@ static const struct udevice_id sh_pfc_pinctrl_ids[] = { .data = SH_PFC_R8A774B1, }, #endif +#ifdef CONFIG_PINCTRL_PFC_R8A774E1 + { + .compatible = "renesas,pfc-r8a774e1", + .data = SH_PFC_R8A774E1, + }, +#endif #ifdef CONFIG_PINCTRL_PFC_R8A77965 { .compatible = "renesas,pfc-r8a77965", diff --git a/drivers/pinctrl/renesas/sh_pfc.h b/drivers/pinctrl/renesas/sh_pfc.h index f5cf31d26f..22cc860f29 100644 --- a/drivers/pinctrl/renesas/sh_pfc.h +++ b/drivers/pinctrl/renesas/sh_pfc.h @@ -295,6 +295,7 @@ sh_pfc_pin_to_bias_reg(const struct sh_pfc *pfc, unsigned int pin,
extern const struct sh_pfc_soc_info r8a774a1_pinmux_info; extern const struct sh_pfc_soc_info r8a774b1_pinmux_info; +extern const struct sh_pfc_soc_info r8a774e1_pinmux_info; extern const struct sh_pfc_soc_info r8a7790_pinmux_info; extern const struct sh_pfc_soc_info r8a7791_pinmux_info; extern const struct sh_pfc_soc_info r8a7792_pinmux_info;
Biju Das
