[U-Boot] [RESEND PATCH V2 1/3] imx: mx7: psci: improve cpu hotplug flow
This patch improves cpu hotplug, previous cpu_off implementation is NOT safe, a CPU can NOT power down itself in runtime, it will cause system bus hang due to pending transaction. So need to use other online CPU to kill it when it is ready for killed.
Here use SRC parameter register and a magic number of ~0 as handshake for killing a offline CPU, when the online CPU checks the psci_affinity_info, it will help kill the offline CPU according to the magic number stored in SRC parameter register.
Signed-off-by: Anson Huang Anson.Huang@nxp.com --- arch/arm/mach-imx/mx7/psci-mx7.c | 23 +++++++++++++++++++++-- 1 file changed, 21 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-imx/mx7/psci-mx7.c b/arch/arm/mach-imx/mx7/psci-mx7.c index aae96c5..d6c4263 100644 --- a/arch/arm/mach-imx/mx7/psci-mx7.c +++ b/arch/arm/mach-imx/mx7/psci-mx7.c @@ -44,6 +44,14 @@ #error "invalid value for CONFIG_ARMV7_PSCI_NR_CPUS" #endif
+#define imx_cpu_gpr_entry_offset(cpu) \ + (SRC_BASE_ADDR + SRC_GPR1_MX7D + cpu * 8) +#define imx_cpu_gpr_para_offset(cpu) \ + (imx_cpu_gpr_entry_offset(cpu) + 4) + +#define IMX_CPU_SYNC_OFF ~0 +#define IMX_CPU_SYNC_ON 0 + u8 psci_state[IMX7D_PSCI_NR_CPUS] __secure_data = { PSCI_AFFINITY_LEVEL_ON, PSCI_AFFINITY_LEVEL_OFF}; @@ -116,7 +124,7 @@ __secure s32 psci_cpu_on(u32 __always_unused function_id, u32 mpidr, u32 ep,
psci_save(cpu, ep, context_id);
- writel((u32)psci_cpu_entry, SRC_BASE_ADDR + cpu * 8 + SRC_GPR1_MX7D); + writel((u32)psci_cpu_entry, imx_cpu_gpr_entry_offset(cpu));
psci_set_state(cpu, PSCI_AFFINITY_LEVEL_ON_PENDING);
@@ -137,7 +145,11 @@ __secure s32 psci_cpu_off(void)
imx_enable_cpu_ca7(cpu, false); imx_gpcv2_set_core_power(cpu, false); - writel(0, SRC_BASE_ADDR + cpu * 8 + SRC_GPR1_MX7D + 4); + /* + * We use the cpu jumping argument register to sync with + * psci_affinity_info() which is running on cpu0 to kill the cpu. + */ + writel(IMX_CPU_SYNC_OFF, imx_cpu_gpr_para_offset(cpu));
while (1) wfi(); @@ -198,6 +210,13 @@ __secure s32 psci_affinity_info(u32 __always_unused function_id, if (cpu >= IMX7D_PSCI_NR_CPUS) return ARM_PSCI_RET_INVAL;
+ /* CPU is waiting for killed */ + if (readl(imx_cpu_gpr_para_offset(cpu)) == IMX_CPU_SYNC_OFF) { + imx_enable_cpu_ca7(cpu, false); + imx_gpcv2_set_core_power(cpu, false); + writel(IMX_CPU_SYNC_ON, imx_cpu_gpr_para_offset(cpu)); + } + return psci_state[cpu]; }
Add i.MX7D GPC initialization for low power mode support like system suspend/resume from linux kernel:
- Pending IOMUXC IRQ to workaround GPC state machine issue; - Mask all GPC interrupts for M4/C0/C1; - Configure SCU timing; - Configure time slot ack; - Configure C0/C1 power up/down timing; - Configure wakeup source mechanism; - Disable DSM/RBC related settings.
Signed-off-by: Anson Huang Anson.Huang@nxp.com --- arch/arm/mach-imx/mx7/soc.c | 103 ++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 103 insertions(+)
diff --git a/arch/arm/mach-imx/mx7/soc.c b/arch/arm/mach-imx/mx7/soc.c index 7334ca9..502f033 100644 --- a/arch/arm/mach-imx/mx7/soc.c +++ b/arch/arm/mach-imx/mx7/soc.c @@ -18,6 +18,37 @@ #include <fsl_sec.h> #include <asm/setup.h>
+#define IOMUXC_GPR1 0x4 +#define BM_IOMUXC_GPR1_IRQ 0x1000 + +#define GPC_LPCR_A7_BSC 0x0 +#define GPC_LPCR_M4 0x8 +#define GPC_SLPCR 0x14 +#define GPC_PGC_ACK_SEL_A7 0x24 +#define GPC_IMR1_CORE0 0x30 +#define GPC_IMR1_CORE1 0x40 +#define GPC_IMR1_M4 0x50 +#define GPC_PGC_CPU_MAPPING 0xec +#define GPC_PGC_C0_PUPSCR 0x804 +#define GPC_PGC_SCU_TIMING 0x890 +#define GPC_PGC_C1_PUPSCR 0x844 + +#define BM_LPCR_A7_BSC_IRQ_SRC_A7_WAKEUP 0x70000000 +#define BM_LPCR_A7_BSC_CPU_CLK_ON_LPM 0x4000 +#define BM_LPCR_M4_MASK_DSM_TRIGGER 0x80000000 +#define BM_SLPCR_EN_DSM 0x80000000 +#define BM_SLPCR_RBC_EN 0x40000000 +#define BM_SLPCR_REG_BYPASS_COUNT 0x3f000000 +#define BM_SLPCR_VSTBY 0x4 +#define BM_SLPCR_SBYOS 0x2 +#define BM_SLPCR_BYPASS_PMIC_READY 0x1 +#define BM_SLPCR_EN_A7_FASTWUP_WAIT_MODE 0x10000 + +#define BM_GPC_PGC_ACK_SEL_A7_DUMMY_PUP_ACK 0x80000000 +#define BM_GPC_PGC_ACK_SEL_A7_DUMMY_PDN_ACK 0x8000 + +#define BM_GPC_PGC_CORE_PUPSCR 0x7fff80 + #if defined(CONFIG_IMX_THERMAL) static const struct imx_thermal_plat imx7_thermal_plat = { .regs = (void *)ANATOP_BASE_ADDR, @@ -159,6 +190,76 @@ static void imx_enet_mdio_fixup(void) } }
+static void imx_gpcv2_init(void) +{ + u32 val, i; + + /* + * Force IOMUXC irq pending, so that the interrupt to GPC can be + * used to deassert dsm_request signal when the signal gets + * asserted unexpectedly. + */ + val = readl(IOMUXC_GPR_BASE_ADDR + IOMUXC_GPR1); + val |= BM_IOMUXC_GPR1_IRQ; + writel(val, IOMUXC_GPR_BASE_ADDR + IOMUXC_GPR1); + + /* Initially mask all interrupts */ + for (i = 0; i < 4; i++) { + writel(~0, GPC_IPS_BASE_ADDR + GPC_IMR1_CORE0 + i * 4); + writel(~0, GPC_IPS_BASE_ADDR + GPC_IMR1_CORE1 + i * 4); + writel(~0, GPC_IPS_BASE_ADDR + GPC_IMR1_M4 + i * 4); + } + + /* set SCU timing */ + writel((0x59 << 10) | 0x5B | (0x2 << 20), + GPC_IPS_BASE_ADDR + GPC_PGC_SCU_TIMING); + + /* only external IRQs to wake up LPM and core 0/1 */ + val = readl(GPC_IPS_BASE_ADDR + GPC_LPCR_A7_BSC); + val |= BM_LPCR_A7_BSC_IRQ_SRC_A7_WAKEUP; + writel(val, GPC_IPS_BASE_ADDR + GPC_LPCR_A7_BSC); + + /* set C0 power up timming per design requirement */ + val = readl(GPC_IPS_BASE_ADDR + GPC_PGC_C0_PUPSCR); + val &= ~BM_GPC_PGC_CORE_PUPSCR; + val |= (0x1A << 7); + writel(val, GPC_IPS_BASE_ADDR + GPC_PGC_C0_PUPSCR); + + /* set C1 power up timming per design requirement */ + val = readl(GPC_IPS_BASE_ADDR + GPC_PGC_C1_PUPSCR); + val &= ~BM_GPC_PGC_CORE_PUPSCR; + val |= (0x1A << 7); + writel(val, GPC_IPS_BASE_ADDR + GPC_PGC_C1_PUPSCR); + + /* dummy ack for time slot by default */ + writel(BM_GPC_PGC_ACK_SEL_A7_DUMMY_PUP_ACK | + BM_GPC_PGC_ACK_SEL_A7_DUMMY_PDN_ACK, + GPC_IPS_BASE_ADDR + GPC_PGC_ACK_SEL_A7); + + /* mask M4 DSM trigger */ + writel(readl(GPC_IPS_BASE_ADDR + GPC_LPCR_M4) | + BM_LPCR_M4_MASK_DSM_TRIGGER, + GPC_IPS_BASE_ADDR + GPC_LPCR_M4); + + /* set mega/fast mix in A7 domain */ + writel(0x1, GPC_IPS_BASE_ADDR + GPC_PGC_CPU_MAPPING); + + /* DSM related settings */ + val = readl(GPC_IPS_BASE_ADDR + GPC_SLPCR); + val &= ~(BM_SLPCR_EN_DSM | BM_SLPCR_VSTBY | BM_SLPCR_RBC_EN | + BM_SLPCR_SBYOS | BM_SLPCR_BYPASS_PMIC_READY | + BM_SLPCR_REG_BYPASS_COUNT); + val |= BM_SLPCR_EN_A7_FASTWUP_WAIT_MODE; + writel(val, GPC_IPS_BASE_ADDR + GPC_SLPCR); + + /* + * disabling RBC need to delay at least 2 cycles of CKIL(32K) + * due to hardware design requirement, which is + * ~61us, here we use 65us for safe + */ + udelay(65); +} + int arch_cpu_init(void) { init_aips(); @@ -180,6 +281,8 @@ int arch_cpu_init(void)
init_snvs();
+ imx_gpcv2_init(); + return 0; }
This patch adds system suspend/resume support, when linux kernel enters deep sleep mode, SoC will go into below mode:
- CA7 platform goes into STOP mode; - SoC goes into DSM mode; - DDR goes into self-refresh mode; - CPU0/SCU will be powered down.
When wake up event arrives:
- SoC DSM mdoe exits; - CA7 platform exit STOP mode, SCU/CPU0 power up; - Invalidate L1 cache; - DDR exit self-refresh mode; - Do secure monitor mode related initialization; - Jump to linux kernel resume entry.
Belwo is the log of 1 iteration of system suspend/resume:
[ 338.824862] PM: suspend entry (deep) [ 338.828853] PM: Syncing filesystems ... done. [ 338.834433] Freezing user space processes ... (elapsed 0.001 seconds) done. [ 338.842939] OOM killer disabled. [ 338.846182] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done. [ 338.869717] PM: suspend devices took 0.010 seconds [ 338.877846] Disabling non-boot CPUs ... [ 338.960301] Retrying again to check for CPU kill [ 338.964953] CPU1 killed. [ 338.968104] Enabling non-boot CPUs ... [ 338.973598] CPU1 is up [ 339.267155] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [ 339.275833] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [ 339.284158] mmc1: queuing unknown CIS tuple 0x80 (6 bytes) [ 339.385065] PM: resume devices took 0.400 seconds [ 339.389836] OOM killer enabled. [ 339.392986] Restarting tasks ... done. [ 339.398990] PM: suspend exit
The resume entry function has to initialize stack pointer before calling C code, otherwise there will be an external abort occur, in additional, invalidate L1 cache must be done in secure section as well, so this patch also adds assembly code back and keep it as simple as possible.
Signed-off-by: Anson Huang Anson.Huang@nxp.com --- arch/arm/mach-imx/mx7/Makefile | 2 +- arch/arm/mach-imx/mx7/psci-mx7.c | 449 ++++++++++++++++++++++++++++++++++- arch/arm/mach-imx/mx7/psci-suspend.S | 67 ++++++ 3 files changed, 515 insertions(+), 3 deletions(-) create mode 100644 arch/arm/mach-imx/mx7/psci-suspend.S
diff --git a/arch/arm/mach-imx/mx7/Makefile b/arch/arm/mach-imx/mx7/Makefile index 94a0e64..f1436e2 100644 --- a/arch/arm/mach-imx/mx7/Makefile +++ b/arch/arm/mach-imx/mx7/Makefile @@ -4,4 +4,4 @@ #
obj-y := soc.o clock.o clock_slice.o ddr.o snvs.o -obj-$(CONFIG_ARMV7_PSCI) += psci-mx7.o +obj-$(CONFIG_ARMV7_PSCI) += psci-mx7.o psci-suspend.o diff --git a/arch/arm/mach-imx/mx7/psci-mx7.c b/arch/arm/mach-imx/mx7/psci-mx7.c index d6c4263..34ba0a9 100644 --- a/arch/arm/mach-imx/mx7/psci-mx7.c +++ b/arch/arm/mach-imx/mx7/psci-mx7.c @@ -8,20 +8,77 @@ #include <asm/psci.h> #include <asm/secure.h> #include <asm/arch/imx-regs.h> +#include <asm/armv7.h> +#include <asm/gic.h> #include <linux/bitops.h> #include <common.h> #include <fsl_wdog.h>
-#define GPC_CPU_PGC_SW_PDN_REQ 0xfc +#define GPC_LPCR_A7_BSC 0x0 +#define GPC_LPCR_A7_AD 0x4 +#define GPC_SLPCR 0x14 +#define GPC_PGC_ACK_SEL_A7 0x24 +#define GPC_IMR1_CORE0 0x30 +#define GPC_SLOT0_CFG 0xb0 #define GPC_CPU_PGC_SW_PUP_REQ 0xf0 +#define GPC_CPU_PGC_SW_PDN_REQ 0xfc +#define GPC_PGC_C0 0x800 #define GPC_PGC_C0 0x800 #define GPC_PGC_C1 0x840 +#define GPC_PGC_SCU 0x880 + +#define BM_LPCR_A7_BSC_CPU_CLK_ON_LPM 0x4000 +#define BM_LPCR_A7_BSC_LPM1 0xc +#define BM_LPCR_A7_BSC_LPM0 0x3 +#define BP_LPCR_A7_BSC_LPM0 0 +#define BM_SLPCR_EN_DSM 0x80000000 +#define BM_SLPCR_RBC_EN 0x40000000 +#define BM_SLPCR_REG_BYPASS_COUNT 0x3f000000 +#define BM_SLPCR_VSTBY 0x4 +#define BM_SLPCR_SBYOS 0x2 +#define BM_SLPCR_BYPASS_PMIC_READY 0x1 +#define BM_LPCR_A7_AD_L2PGE 0x10000 +#define BM_LPCR_A7_AD_EN_C1_PUP 0x800 +#define BM_LPCR_A7_AD_EN_C0_PUP 0x200 +#define BM_LPCR_A7_AD_EN_PLAT_PDN 0x10 +#define BM_LPCR_A7_AD_EN_C1_PDN 0x8 +#define BM_LPCR_A7_AD_EN_C0_PDN 0x2
#define BM_CPU_PGC_SW_PDN_PUP_REQ_CORE0_A7 0x1 #define BM_CPU_PGC_SW_PDN_PUP_REQ_CORE1_A7 0x2
-/* below is for i.MX7D */ +#define BM_GPC_PGC_ACK_SEL_A7_PD_DUMMY_ACK 0x8000 +#define BM_GPC_PGC_ACK_SEL_A7_PU_DUMMY_ACK 0x80000000 + +#define MAX_SLOT_NUMBER 10 +#define A7_LPM_WAIT 0x5 +#define A7_LPM_STOP 0xa + +#define BM_SYS_COUNTER_CNTCR_FCR1 0x200 +#define BM_SYS_COUNTER_CNTCR_FCR0 0x100 + +#define REG_SET 0x4 +#define REG_CLR 0x8 + +#define ANADIG_ARM_PLL 0x60 +#define ANADIG_DDR_PLL 0x70 +#define ANADIG_SYS_PLL 0xb0 +#define ANADIG_ENET_PLL 0xe0 +#define ANADIG_AUDIO_PLL 0xf0 +#define ANADIG_VIDEO_PLL 0x130 +#define BM_ANATOP_ARM_PLL_OVERRIDE BIT(20) +#define BM_ANATOP_DDR_PLL_OVERRIDE BIT(19) +#define BM_ANATOP_SYS_PLL_OVERRIDE (0x1ff << 17) +#define BM_ANATOP_ENET_PLL_OVERRIDE BIT(13) +#define BM_ANATOP_AUDIO_PLL_OVERRIDE BIT(24) +#define BM_ANATOP_VIDEO_PLL_OVERRIDE BIT(24) + +#define DDRC_STAT 0x4 +#define DDRC_PWRCTL 0x30 +#define DDRC_PSTAT 0x3fc + #define SRC_GPR1_MX7D 0x074 +#define SRC_GPR2_MX7D 0x078 #define SRC_A7RCR0 0x004 #define SRC_A7RCR1 0x008
@@ -56,6 +113,27 @@ u8 psci_state[IMX7D_PSCI_NR_CPUS] __secure_data = { PSCI_AFFINITY_LEVEL_ON, PSCI_AFFINITY_LEVEL_OFF};
+enum imx_gpc_slot { + CORE0_A7, + CORE1_A7, + SCU_A7, + FAST_MEGA_MIX, + MIPI_PHY, + PCIE_PHY, + USB_OTG1_PHY, + USB_OTG2_PHY, + USB_HSIC_PHY, + CORE0_M4, +}; + +enum mxc_cpu_pwr_mode { + RUN, + WAIT, + STOP, +}; + +extern void psci_system_resume(void); + static inline void psci_set_state(int cpu, u8 state) { psci_state[cpu] = state; @@ -237,7 +315,374 @@ __secure s32 psci_features(u32 __always_unused function_id, u32 psci_fid) case ARM_PSCI_0_2_FN_SYSTEM_OFF: case ARM_PSCI_0_2_FN_SYSTEM_RESET: case ARM_PSCI_1_0_FN_PSCI_FEATURES: + case ARM_PSCI_1_0_FN_SYSTEM_SUSPEND: return 0x0; } return ARM_PSCI_RET_NI; } + +static __secure void imx_gpcv2_set_lpm_mode(enum mxc_cpu_pwr_mode mode) +{ + u32 val1, val2, val3; + + val1 = readl(GPC_IPS_BASE_ADDR + GPC_LPCR_A7_BSC); + val2 = readl(GPC_IPS_BASE_ADDR + GPC_SLPCR); + + /* all cores' LPM settings must be same */ + val1 &= ~(BM_LPCR_A7_BSC_LPM0 | BM_LPCR_A7_BSC_LPM1); + val1 |= BM_LPCR_A7_BSC_CPU_CLK_ON_LPM; + + val2 &= ~(BM_SLPCR_EN_DSM | BM_SLPCR_VSTBY | BM_SLPCR_RBC_EN | + BM_SLPCR_SBYOS | BM_SLPCR_BYPASS_PMIC_READY); + /* + * GPC: When improper low-power sequence is used, + * the SoC enters low power mode before the ARM core executes WFI. + * + * Software workaround: + * 1) Software should trigger IRQ #32 (IOMUX) to be always pending + * by setting IOMUX_GPR1_IRQ. + * 2) Software should then unmask IRQ #32 in GPC before setting GPC + * Low-Power mode. + * 3) Software should mask IRQ #32 right after GPC Low-Power mode + * is set. + */ + switch (mode) { + case RUN: + val3 = readl(GPC_IPS_BASE_ADDR + GPC_IMR1_CORE0); + val3 &= ~0x1; + writel(val3, GPC_IPS_BASE_ADDR + GPC_IMR1_CORE0); + break; + case WAIT: + val1 |= A7_LPM_WAIT << BP_LPCR_A7_BSC_LPM0; + val1 &= ~BM_LPCR_A7_BSC_CPU_CLK_ON_LPM; + val3 = readl(GPC_IPS_BASE_ADDR + GPC_IMR1_CORE0); + val3 &= ~0x1; + writel(val3, GPC_IPS_BASE_ADDR + GPC_IMR1_CORE0); + break; + case STOP: + val1 |= A7_LPM_STOP << BP_LPCR_A7_BSC_LPM0; + val1 &= ~BM_LPCR_A7_BSC_CPU_CLK_ON_LPM; + val2 |= BM_SLPCR_EN_DSM; + val2 |= BM_SLPCR_SBYOS; + val2 |= BM_SLPCR_VSTBY; + val2 |= BM_SLPCR_BYPASS_PMIC_READY; + val3 = readl(GPC_IPS_BASE_ADDR + GPC_IMR1_CORE0); + val3 |= 0x1; + writel(val3, GPC_IPS_BASE_ADDR + GPC_IMR1_CORE0); + break; + default: + return; + } + writel(val1, GPC_IPS_BASE_ADDR + GPC_LPCR_A7_BSC); + writel(val2, GPC_IPS_BASE_ADDR + GPC_SLPCR); +} + +static __secure void imx_gpcv2_set_plat_power_gate_by_lpm(bool pdn) +{ + u32 val = readl(GPC_IPS_BASE_ADDR + GPC_LPCR_A7_AD); + + val &= ~(BM_LPCR_A7_AD_EN_PLAT_PDN | BM_LPCR_A7_AD_L2PGE); + if (pdn) + val |= BM_LPCR_A7_AD_EN_PLAT_PDN | BM_LPCR_A7_AD_L2PGE; + + writel(val, GPC_IPS_BASE_ADDR + GPC_LPCR_A7_AD); +} + +static __secure void imx_gpcv2_set_cpu_power_gate_by_lpm(u32 cpu, bool pdn) +{ + u32 val; + + val = readl(GPC_IPS_BASE_ADDR + GPC_LPCR_A7_AD); + if (cpu == 0) { + if (pdn) + val |= BM_LPCR_A7_AD_EN_C0_PDN | + BM_LPCR_A7_AD_EN_C0_PUP; + else + val &= ~(BM_LPCR_A7_AD_EN_C0_PDN | + BM_LPCR_A7_AD_EN_C0_PUP); + } + if (cpu == 1) { + if (pdn) + val |= BM_LPCR_A7_AD_EN_C1_PDN | + BM_LPCR_A7_AD_EN_C1_PUP; + else + val &= ~(BM_LPCR_A7_AD_EN_C1_PDN | + BM_LPCR_A7_AD_EN_C1_PUP); + } + writel(val, GPC_IPS_BASE_ADDR + GPC_LPCR_A7_AD); +} + +static __secure void imx_gpcv2_set_slot_ack(u32 index, enum imx_gpc_slot m_core, + bool mode, bool ack) +{ + u32 val; + + if (index >= MAX_SLOT_NUMBER) + return; + + /* set slot */ + writel(readl(GPC_IPS_BASE_ADDR + GPC_SLOT0_CFG + index * 4) | + ((mode + 1) << (m_core * 2)), + GPC_IPS_BASE_ADDR + GPC_SLOT0_CFG + index * 4); + + if (ack) { + /* set ack */ + val = readl(GPC_IPS_BASE_ADDR + GPC_PGC_ACK_SEL_A7); + /* clear dummy ack */ + val &= ~(mode ? BM_GPC_PGC_ACK_SEL_A7_PU_DUMMY_ACK : + BM_GPC_PGC_ACK_SEL_A7_PD_DUMMY_ACK); + val |= 1 << (m_core + (mode ? 16 : 0)); + writel(val, GPC_IPS_BASE_ADDR + GPC_PGC_ACK_SEL_A7); + } +} + +static __secure void imx_system_counter_resume(void) +{ + u32 val; + + val = readl(SYSCNT_CTRL_IPS_BASE_ADDR); + val &= ~BM_SYS_COUNTER_CNTCR_FCR1; + val |= BM_SYS_COUNTER_CNTCR_FCR0; + writel(val, SYSCNT_CTRL_IPS_BASE_ADDR); +} + +static __secure void imx_system_counter_suspend(void) +{ + u32 val; + + val = readl(SYSCNT_CTRL_IPS_BASE_ADDR); + val &= ~BM_SYS_COUNTER_CNTCR_FCR0; + val |= BM_SYS_COUNTER_CNTCR_FCR1; + writel(val, SYSCNT_CTRL_IPS_BASE_ADDR); +} + +static __secure void gic_resume(void) +{ + u32 itlinesnr, i; + u32 gic_dist_addr = GIC400_ARB_BASE_ADDR + GIC_DIST_OFFSET; + + /* enable the GIC distributor */ + writel(readl(gic_dist_addr + GICD_CTLR) | 0x03, + gic_dist_addr + GICD_CTLR); + + /* TYPER[4:0] contains an encoded number of available interrupts */ + itlinesnr = readl(gic_dist_addr + GICD_TYPER) & 0x1f; + + /* set all bits in the GIC group registers to one to allow access + * from non-secure state. The first 32 interrupts are private per + * CPU and will be set later when enabling the GIC for each core + */ + for (i = 1; i <= itlinesnr; i++) + writel((u32)-1, gic_dist_addr + GICD_IGROUPRn + 4 * i); +} + +static inline void imx_pll_suspend(void) +{ + writel(BM_ANATOP_ARM_PLL_OVERRIDE, + ANATOP_BASE_ADDR + ANADIG_ARM_PLL + REG_SET); + writel(BM_ANATOP_DDR_PLL_OVERRIDE, + ANATOP_BASE_ADDR + ANADIG_DDR_PLL + REG_SET); + writel(BM_ANATOP_SYS_PLL_OVERRIDE, + ANATOP_BASE_ADDR + ANADIG_SYS_PLL + REG_SET); + writel(BM_ANATOP_ENET_PLL_OVERRIDE, + ANATOP_BASE_ADDR + ANADIG_ENET_PLL + REG_SET); + writel(BM_ANATOP_AUDIO_PLL_OVERRIDE, + ANATOP_BASE_ADDR + ANADIG_AUDIO_PLL + REG_SET); + writel(BM_ANATOP_VIDEO_PLL_OVERRIDE, + ANATOP_BASE_ADDR + ANADIG_VIDEO_PLL + REG_SET); +} + +static inline void imx_pll_resume(void) +{ + writel(BM_ANATOP_ARM_PLL_OVERRIDE, + ANATOP_BASE_ADDR + ANADIG_ARM_PLL + REG_CLR); + writel(BM_ANATOP_DDR_PLL_OVERRIDE, + ANATOP_BASE_ADDR + ANADIG_DDR_PLL + REG_CLR); + writel(BM_ANATOP_SYS_PLL_OVERRIDE, + ANATOP_BASE_ADDR + ANADIG_SYS_PLL + REG_CLR); + writel(BM_ANATOP_ENET_PLL_OVERRIDE, + ANATOP_BASE_ADDR + ANADIG_ENET_PLL + REG_CLR); + writel(BM_ANATOP_AUDIO_PLL_OVERRIDE, + ANATOP_BASE_ADDR + ANADIG_AUDIO_PLL + REG_CLR); + writel(BM_ANATOP_VIDEO_PLL_OVERRIDE, + ANATOP_BASE_ADDR + ANADIG_VIDEO_PLL + REG_CLR); +} + +static inline void imx_udelay(u32 usec) +{ + u32 freq; + u64 start, end; + + asm volatile("mrc p15, 0, %0, c14, c0, 0" : "=r" (freq)); + asm volatile("mrrc p15, 0, %Q0, %R0, c14" : "=r" (start)); + do { + asm volatile("mrrc p15, 0, %Q0, %R0, c14" : "=r" (end)); + if ((end - start) > usec * (freq / 1000000)) + break; + } while (1); +} + +static inline void imx_ddrc_enter_self_refresh(void) +{ + writel(0, DDRC_IPS_BASE_ADDR + DDRC_PWRCTL); + while (readl(DDRC_IPS_BASE_ADDR + DDRC_PSTAT) & 0x10001) + ; + + writel(0x20, DDRC_IPS_BASE_ADDR + DDRC_PWRCTL); + while ((readl(DDRC_IPS_BASE_ADDR + DDRC_STAT) & 0x23) != 0x23) + ; + writel(readl(DDRC_IPS_BASE_ADDR + DDRC_PWRCTL) | 0x8, + DDRC_IPS_BASE_ADDR + DDRC_PWRCTL); +} + +static inline void imx_ddrc_exit_self_refresh(void) +{ + writel(0, DDRC_IPS_BASE_ADDR + DDRC_PWRCTL); + while ((readl(DDRC_IPS_BASE_ADDR + DDRC_STAT) & 0x3) == 0x3) + ; + writel(readl(DDRC_IPS_BASE_ADDR + DDRC_PWRCTL) | 0x1, + DDRC_IPS_BASE_ADDR + DDRC_PWRCTL); +} + +__secure void imx_system_resume(void) +{ + unsigned int i, val, imr[4], entry; + + entry = psci_get_target_pc(0); + imx_ddrc_exit_self_refresh(); + imx_system_counter_resume(); + imx_gpcv2_set_lpm_mode(RUN); + imx_gpcv2_set_cpu_power_gate_by_lpm(0, false); + imx_gpcv2_set_plat_power_gate_by_lpm(false); + imx_gpcv2_set_m_core_pgc(false, GPC_PGC_C0); + imx_gpcv2_set_m_core_pgc(false, GPC_PGC_SCU); + + /* + * need to mask all interrupts in GPC before + * operating RBC configurations + */ + for (i = 0; i < 4; i++) { + imr[i] = readl(GPC_IPS_BASE_ADDR + GPC_IMR1_CORE0 + i * 4); + writel(~0, GPC_IPS_BASE_ADDR + GPC_IMR1_CORE0 + i * 4); + } + + /* configure RBC enable bit */ + val = readl(GPC_IPS_BASE_ADDR + GPC_SLPCR); + val &= ~BM_SLPCR_RBC_EN; + writel(val, GPC_IPS_BASE_ADDR + GPC_SLPCR); + + /* configure RBC count */ + val = readl(GPC_IPS_BASE_ADDR + GPC_SLPCR); + val &= ~BM_SLPCR_REG_BYPASS_COUNT; + writel(val, GPC_IPS_BASE_ADDR + GPC_SLPCR); + + /* + * need to delay at least 2 cycles of CKIL(32K) + * due to hardware design requirement, which is + * ~61us, here we use 65us for safe + */ + imx_udelay(65); + + /* restore GPC interrupt mask settings */ + for (i = 0; i < 4; i++) + writel(imr[i], GPC_IPS_BASE_ADDR + GPC_IMR1_CORE0 + i * 4); + + /* initialize gic distributor */ + gic_resume(); + _nonsec_init(); + + /* save cpu0 entry */ + psci_save(0, entry, 0); + psci_cpu_entry(); +} + +__secure void psci_system_suspend(u32 __always_unused function_id, + u32 ep, u32 context_id) +{ + u32 gpc_mask[4]; + u32 i, val; + + psci_save(0, ep, context_id); + /* overwrite PLL to be controlled by low power mode */ + imx_pll_suspend(); + imx_system_counter_suspend(); + /* set CA7 platform to enter STOP mode */ + imx_gpcv2_set_lpm_mode(STOP); + /* enable core0/scu power down/up with low power mode */ + imx_gpcv2_set_cpu_power_gate_by_lpm(0, true); + imx_gpcv2_set_plat_power_gate_by_lpm(true); + /* time slot settings for core0 and scu */ + imx_gpcv2_set_slot_ack(0, CORE0_A7, false, false); + imx_gpcv2_set_slot_ack(1, SCU_A7, false, true); + imx_gpcv2_set_slot_ack(5, SCU_A7, true, false); + imx_gpcv2_set_slot_ack(6, CORE0_A7, true, true); + imx_gpcv2_set_m_core_pgc(true, GPC_PGC_C0); + imx_gpcv2_set_m_core_pgc(true, GPC_PGC_SCU); + psci_v7_flush_dcache_all(); + + imx_ddrc_enter_self_refresh(); + + /* + * e10133: ARM: Boot failure after A7 enters into + * low-power idle mode + * + * Workaround: + * If both CPU0/CPU1 are IDLE, the last IDLE CPU should + * disable GIC first, then REG_BYPASS_COUNTER is used + * to mask wakeup INT, and then execute “wfi” is used to + * bring the system into power down processing safely. + * The counter must be enabled as close to the “wfi” state + * as possible. The following equation can be used to + * determine the RBC counter value: + * RBC_COUNT * (1/32K RTC frequency) >= + * (46 + PDNSCR_SW + PDNSCR_SW2ISO ) ( 1/IPG_CLK frequency ). + */ + + /* disable GIC distributor */ + writel(0, GIC400_ARB_BASE_ADDR + GIC_DIST_OFFSET); + + for (i = 0; i < 4; i++) + gpc_mask[i] = readl(GPC_IPS_BASE_ADDR + GPC_IMR1_CORE0 + i * 4); + + /* + * enable the RBC bypass counter here + * to hold off the interrupts. RBC counter + * = 8 (240us). With this setting, the latency + * from wakeup interrupt to ARM power up + * is ~250uS. + */ + val = readl(GPC_IPS_BASE_ADDR + GPC_SLPCR); + val &= ~(0x3f << 24); + val |= (0x8 << 24); + writel(val, GPC_IPS_BASE_ADDR + GPC_SLPCR); + + /* enable the counter. */ + val = readl(GPC_IPS_BASE_ADDR + GPC_SLPCR); + val |= (1 << 30); + writel(val, GPC_IPS_BASE_ADDR + GPC_SLPCR); + + /* unmask all the GPC interrupts. */ + for (i = 0; i < 4; i++) + writel(gpc_mask[i], GPC_IPS_BASE_ADDR + GPC_IMR1_CORE0 + i * 4); + + /* + * now delay for a short while (3usec) + * ARM is at 1GHz at this point + * so a short loop should be enough. + * this delay is required to ensure that + * the RBC counter can start counting in + * case an interrupt is already pending + * or in case an interrupt arrives just + * as ARM is about to assert DSM_request. + */ + imx_udelay(3); + + /* save resume entry and sp in CPU0 GPR registers */ + asm volatile("mov %0, sp" : "=r" (val)); + writel((u32)psci_system_resume, SRC_BASE_ADDR + SRC_GPR1_MX7D); + writel(val, SRC_BASE_ADDR + SRC_GPR2_MX7D); + + /* sleep */ + while (1) + wfi(); +} diff --git a/arch/arm/mach-imx/mx7/psci-suspend.S b/arch/arm/mach-imx/mx7/psci-suspend.S new file mode 100644 index 0000000..a21403f --- /dev/null +++ b/arch/arm/mach-imx/mx7/psci-suspend.S @@ -0,0 +1,67 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 NXP + */ + +#include <config.h> +#include <linux/linkage.h> + +#include <asm/armv7.h> +#include <asm/psci.h> + + .pushsection ._secure.text, "ax" + + .arch_extension sec + +.globl v7_invalidate_l1 +v7_invalidate_l1: + mov r0, #0 + mcr p15, 2, r0, c0, c0, 0 + mrc p15, 1, r0, c0, c0, 0 + + movw r1, #0x7fff + and r2, r1, r0, lsr #13 + + movw r1, #0x3ff + + and r3, r1, r0, lsr #3 @ NumWays - 1 + add r2, r2, #1 @ NumSets + + and r0, r0, #0x7 + add r0, r0, #4 @ SetShift + + clz r1, r3 @ WayShift + add r4, r3, #1 @ NumWays +1: + sub r2, r2, #1 @ NumSets-- + mov r3, r4 @ Temp = NumWays +2: + subs r3, r3, #1 @ Temp-- + mov r5, r3, lsl r1 + mov r6, r2, lsl r0 + orr r5, r5, r6 @ Reg = (Temp<<WayShift)|(NumSets<<SetShift) + mcr p15, 0, r5, c7, c6, 2 + bgt 2b + cmp r2, #0 + bgt 1b + dsb st + isb + mov pc, lr + +.globl psci_system_resume +psci_system_resume: + mov sp, r0 + + /* invalidate L1 I-cache first */ + mov r6, #0x0 + mcr p15, 0, r6, c7, c5, 0 + mcr p15, 0, r6, c7, c5, 6 + /* enable the Icache and branch prediction */ + mov r6, #0x1800 + mcr p15, 0, r6, c1, c0, 0 + isb + + bl v7_invalidate_l1 + b imx_system_resume + + .popsection
Hi Anson,
Gave this a try with a 3.18-rc6 kernel today on our Colibri iMX7, I could successfully suspend and resume using RTC wakealarm.
What is a bit weird is that sometimes the SoC seems to consume more power than other times (sometimes 135mW, sometimes 60mW). Any idea where that could come from?
In any case, the system seems to wakeup just fine.
-- Stefan
- CORE0_A7,
- CORE1_A7,
- SCU_A7,
- FAST_MEGA_MIX,
- MIPI_PHY,
- PCIE_PHY,
- USB_OTG1_PHY,
- USB_OTG2_PHY,
- USB_HSIC_PHY,
- CORE0_M4,
- RUN,
- WAIT,
- STOP,
- case ARM_PSCI_1_0_FN_SYSTEM_SUSPEND: return 0x0; } return ARM_PSCI_RET_NI;
- u32 val1, val2, val3;
- val1 = readl(GPC_IPS_BASE_ADDR + GPC_LPCR_A7_BSC);
- val2 = readl(GPC_IPS_BASE_ADDR + GPC_SLPCR);
- /* all cores' LPM settings must be same */
- val1 &= ~(BM_LPCR_A7_BSC_LPM0 | BM_LPCR_A7_BSC_LPM1);
- val1 |= BM_LPCR_A7_BSC_CPU_CLK_ON_LPM;
- val2 &= ~(BM_SLPCR_EN_DSM | BM_SLPCR_VSTBY | BM_SLPCR_RBC_EN |
* Low-Power mode.
* is set.
- switch (mode) {
- case RUN:
val3 &= ~0x1;
break;
- case WAIT:
val3 &= ~0x1;
break;
- case STOP:
val3 |= 0x1;
break;
- default:
return;
- writel(val1, GPC_IPS_BASE_ADDR + GPC_LPCR_A7_BSC);
- writel(val2, GPC_IPS_BASE_ADDR + GPC_SLPCR);
- u32 val = readl(GPC_IPS_BASE_ADDR + GPC_LPCR_A7_AD);
- val &= ~(BM_LPCR_A7_AD_EN_PLAT_PDN | BM_LPCR_A7_AD_L2PGE);
- if (pdn)
- writel(val, GPC_IPS_BASE_ADDR + GPC_LPCR_A7_AD);
- u32 val;
- val = readl(GPC_IPS_BASE_ADDR + GPC_LPCR_A7_AD);
- if (cpu == 0) {
if (pdn)
else
- if (cpu == 1) {
if (pdn)
else
- u32 val;
- if (index >= MAX_SLOT_NUMBER)
return;
- /* set slot */
- writel(readl(GPC_IPS_BASE_ADDR + GPC_SLOT0_CFG + index * 4) |
- if (ack) {
/* set ack */
- u32 val;
- val = readl(SYSCNT_CTRL_IPS_BASE_ADDR);
- val &= ~BM_SYS_COUNTER_CNTCR_FCR1;
- val |= BM_SYS_COUNTER_CNTCR_FCR0;
- writel(val, SYSCNT_CTRL_IPS_BASE_ADDR);
- u32 val;
- val &= ~BM_SYS_COUNTER_CNTCR_FCR0;
- val |= BM_SYS_COUNTER_CNTCR_FCR1;
- u32 itlinesnr, i;
- u32 gic_dist_addr = GIC400_ARB_BASE_ADDR + GIC_DIST_OFFSET;
- /* enable the GIC distributor */
- writel(readl(gic_dist_addr + GICD_CTLR) | 0x03,
- /* TYPER[4:0] contains an encoded number of available interrupts */
- itlinesnr = readl(gic_dist_addr + GICD_TYPER) & 0x1f;
- /* set all bits in the GIC group registers to one to allow access
- for (i = 1; i <= itlinesnr; i++)
- writel(BM_ANATOP_ARM_PLL_OVERRIDE,
- writel(BM_ANATOP_DDR_PLL_OVERRIDE,
- writel(BM_ANATOP_SYS_PLL_OVERRIDE,
- writel(BM_ANATOP_ENET_PLL_OVERRIDE,
- writel(BM_ANATOP_AUDIO_PLL_OVERRIDE,
- writel(BM_ANATOP_VIDEO_PLL_OVERRIDE,
- u32 freq;
- u64 start, end;
- asm volatile("mrc p15, 0, %0, c14, c0, 0" : "=r" (freq));
- asm volatile("mrrc p15, 0, %Q0, %R0, c14" : "=r" (start));
- do {
break;
- } while (1);
- writel(0, DDRC_IPS_BASE_ADDR + DDRC_PWRCTL);
- while (readl(DDRC_IPS_BASE_ADDR + DDRC_PSTAT) & 0x10001)
- writel(0x20, DDRC_IPS_BASE_ADDR + DDRC_PWRCTL);
- while ((readl(DDRC_IPS_BASE_ADDR + DDRC_STAT) & 0x23) != 0x23)
- writel(readl(DDRC_IPS_BASE_ADDR + DDRC_PWRCTL) | 0x8,
- while ((readl(DDRC_IPS_BASE_ADDR + DDRC_STAT) & 0x3) == 0x3)
- writel(readl(DDRC_IPS_BASE_ADDR + DDRC_PWRCTL) | 0x1,
- unsigned int i, val, imr[4], entry;
- entry = psci_get_target_pc(0);
- imx_ddrc_exit_self_refresh();
- imx_system_counter_resume();
- imx_gpcv2_set_lpm_mode(RUN);
- imx_gpcv2_set_cpu_power_gate_by_lpm(0, false);
- imx_gpcv2_set_plat_power_gate_by_lpm(false);
- imx_gpcv2_set_m_core_pgc(false, GPC_PGC_C0);
- imx_gpcv2_set_m_core_pgc(false, GPC_PGC_SCU);
- for (i = 0; i < 4; i++) {
- /* configure RBC enable bit */
- val = readl(GPC_IPS_BASE_ADDR + GPC_SLPCR);
- val &= ~BM_SLPCR_RBC_EN;
- writel(val, GPC_IPS_BASE_ADDR + GPC_SLPCR);
- /* configure RBC count */
- val &= ~BM_SLPCR_REG_BYPASS_COUNT;
- imx_udelay(65);
- /* restore GPC interrupt mask settings */
- /* initialize gic distributor */
- gic_resume();
- _nonsec_init();
- /* save cpu0 entry */
- psci_save(0, entry, 0);
- psci_cpu_entry();
- u32 gpc_mask[4];
- u32 i, val;
- psci_save(0, ep, context_id);
- /* overwrite PLL to be controlled by low power mode */
- imx_pll_suspend();
- imx_system_counter_suspend();
- /* set CA7 platform to enter STOP mode */
- imx_gpcv2_set_lpm_mode(STOP);
- /* enable core0/scu power down/up with low power mode */
- imx_gpcv2_set_cpu_power_gate_by_lpm(0, true);
- imx_gpcv2_set_plat_power_gate_by_lpm(true);
- /* time slot settings for core0 and scu */
- imx_gpcv2_set_slot_ack(0, CORE0_A7, false, false);
- imx_gpcv2_set_slot_ack(1, SCU_A7, false, true);
- imx_gpcv2_set_slot_ack(5, SCU_A7, true, false);
- imx_gpcv2_set_slot_ack(6, CORE0_A7, true, true);
- imx_gpcv2_set_m_core_pgc(true, GPC_PGC_C0);
- imx_gpcv2_set_m_core_pgc(true, GPC_PGC_SCU);
- psci_v7_flush_dcache_all();
- imx_ddrc_enter_self_refresh();
* Workaround:
- /* disable GIC distributor */
- writel(0, GIC400_ARB_BASE_ADDR + GIC_DIST_OFFSET);
* is ~250uS.
- val &= ~(0x3f << 24);
- val |= (0x8 << 24);
- /* enable the counter. */
- val |= (1 << 30);
- /* unmask all the GPC interrupts. */
- imx_udelay(3);
- /* save resume entry and sp in CPU0 GPR registers */
- asm volatile("mov %0, sp" : "=r" (val));
- writel((u32)psci_system_resume, SRC_BASE_ADDR + SRC_GPR1_MX7D);
- writel(val, SRC_BASE_ADDR + SRC_GPR2_MX7D);
- /* sleep */
- while (1)
wfi();
- Copyright 2018 NXP
- .pushsection ._secure.text, "ax"
- .arch_extension sec
- mov r0, #0
- mcr p15, 2, r0, c0, c0, 0
- mrc p15, 1, r0, c0, c0, 0
- movw r1, #0x7fff
- and r2, r1, r0, lsr #13
- movw r1, #0x3ff
- and r3, r1, r0, lsr #3 @ NumWays - 1
- add r2, r2, #1 @ NumSets
- and r0, r0, #0x7
- add r0, r0, #4 @ SetShift
- clz r1, r3 @ WayShift
- add r4, r3, #1 @ NumWays
+1:
- sub r2, r2, #1 @ NumSets--
- mov r3, r4 @ Temp = NumWays
+2:
- subs r3, r3, #1 @ Temp--
- mov r5, r3, lsl r1
- mov r6, r2, lsl r0
- orr r5, r5, r6 @ Reg = (Temp<<WayShift)|(NumSets<<SetShift)
- mcr p15, 0, r5, c7, c6, 2
- bgt 2b
- cmp r2, #0
- bgt 1b
- dsb st
- isb
- mov pc, lr
- mov sp, r0
- /* invalidate L1 I-cache first */
- mov r6, #0x0
- mcr p15, 0, r6, c7, c5, 0
- mcr p15, 0, r6, c7, c5, 6
- /* enable the Icache and branch prediction */
- mov r6, #0x1800
- mcr p15, 0, r6, c1, c0, 0
- isb
- bl v7_invalidate_l1
- b imx_system_resume
- .popsection
Hi, Stefan
Anson Huang Best Regards!
-----Original Message----- From: Stefan Agner [mailto:stefan@agner.ch] Sent: Wednesday, August 8, 2018 5:03 PM To: Anson Huang anson.huang@nxp.com Cc: sbabic@denx.de; Fabio Estevam fabio.estevam@nxp.com; albert.u.boot@aribaud.net; bryan.odonoghue@linaro.org; uri.mashiach@compulab.co.il; Stefan Agner stefan.agner@toradex.com; Peng Fan peng.fan@nxp.com; Ye Li ye.li@nxp.com; sjg@chromium.org; u-boot@lists.denx.de; dl-linux-imx linux-imx@nxp.com Subject: Re: [U-Boot] [RESEND PATCH V2 3/3] imx: mx7: add system suspend/resume support
Hi Anson,
done.
I ONLY tried the function with latest 4.18 kernel and did NOT measure the power, if the power you saw is a board level total power, then I have no idea, maybe you can disable all peripheral devices in dtb to have another try, could be some peripherals' different state consuming different power, if you can break down the power rails to VDD_ARM, VDD_SOC and VDDA_1P8, then I think you should be able to see the benefit, and from each power rails' number, maybe we can figure out why, but I think this patch set is mainly for function level, for power number optimization, we can have patch later, I think.
Noted that latest kernel's PCIe driver has resume issue, you have to disable PCIe if using 4.18 kernel. I suggest you to break down power rails first.
Anson.
-- Stefan
possible.
+#define BM_SYS_COUNTER_CNTCR_FCR1 0x200 #define +BM_SYS_COUNTER_CNTCR_FCR0 0x100
__secure_data = {
- CORE0_A7,
- CORE1_A7,
- SCU_A7,
- FAST_MEGA_MIX,
- MIPI_PHY,
- PCIE_PHY,
- USB_OTG1_PHY,
- USB_OTG2_PHY,
- USB_HSIC_PHY,
- CORE0_M4,
- RUN,
- WAIT,
- STOP,
+static __secure void imx_gpcv2_set_lpm_mode(enum mxc_cpu_pwr_mode +mode) {
* Low-Power mode.
* is set.
- switch (mode) {
- case RUN:
val3 &= ~0x1;
break;
- case WAIT:
val3 &= ~0x1;
break;
- case STOP:
val3 |= 0x1;
break;
- default:
return;
- writel(val2, GPC_IPS_BASE_ADDR + GPC_SLPCR); }
+static __secure void imx_gpcv2_set_plat_power_gate_by_lpm(bool pdn) {
- if (pdn)
- writel(val, GPC_IPS_BASE_ADDR + GPC_LPCR_A7_AD); }
+static __secure void imx_gpcv2_set_cpu_power_gate_by_lpm(u32 cpu, +bool pdn) {
- u32 val;
- if (cpu == 0) {
if (pdn)
else
- if (cpu == 1) {
if (pdn)
else
- u32 val;
return;
- /* set slot */
- if (ack) {
/* set ack */
+static __secure void imx_system_counter_resume(void) {
- u32 val;
- writel(val, SYSCNT_CTRL_IPS_BASE_ADDR); }
+static __secure void imx_system_counter_suspend(void) {
- u32 val;
+static __secure void gic_resume(void) {
- u32 itlinesnr, i;
writel((u32)-1, gic_dist_addr + GICD_IGROUPRn + 4 * i); }
+static inline void imx_pll_suspend(void) {
ANATOP_BASE_ADDR + ANADIG_VIDEO_PLL + REG_SET); }
+static inline void imx_pll_resume(void) {
ANATOP_BASE_ADDR + ANADIG_VIDEO_PLL + REG_CLR); }
+static inline void imx_udelay(u32 usec) {
- u32 freq;
- u64 start, end;
- do {
break;
- } while (1);
+static inline void imx_ddrc_enter_self_refresh(void) {
DDRC_IPS_BASE_ADDR + DDRC_PWRCTL); }
+static inline void imx_ddrc_exit_self_refresh(void) {
+__secure void imx_system_resume(void) {
- imx_udelay(65);
- gic_resume();
- _nonsec_init();
- psci_cpu_entry();
- u32 gpc_mask[4];
- u32 i, val;
* Workaround:
4);
* is ~250uS.
- val |= (1 << 30);
4);
- imx_udelay(3);
- /* sleep */
- while (1)
wfi();
- mov r0, #0
- movw r1, #0x7fff
- movw r1, #0x3ff
- and r0, r0, #0x7
+1:
+2:
- bgt 2b
- cmp r2, #0
- bgt 1b
- dsb st
- isb
- mov pc, lr
- mov sp, r0
- mov r6, #0x0
- mov r6, #0x1800
- isb
- .popsection
On 08.08.2018 11:09, Anson Huang wrote:
Hi, Stefan
Hi Anson,
done.
I checked VDD_ARM, it gets turned off properly. But yeah, could definitely be related to some peripheral. Just wanted to ask you since you just worked with it.
I agree, this finding should not hold back the merge of this patch set.
We do not use PCIe by default, so I think it should not have any influence.
Yeah will have a closer look to all the individual rails. However, due to other priorities I probably will do this at a later time.
Since suspend/resume does work stable:
Acked-by: Stefan Agner stefan@agner.ch Tested-by: Stefan Agner stefan@agner.ch
-- Stefan
Anson.
-- Stefan
possible.
__secure_data = {
- CORE0_A7,
- CORE1_A7,
- SCU_A7,
- FAST_MEGA_MIX,
- MIPI_PHY,
- PCIE_PHY,
- USB_OTG1_PHY,
- USB_OTG2_PHY,
- USB_HSIC_PHY,
- CORE0_M4,
- RUN,
- WAIT,
- STOP,
* Low-Power mode.
* is set.
- switch (mode) {
- case RUN:
val3 &= ~0x1;
break;
- case WAIT:
val3 &= ~0x1;
break;
- case STOP:
val3 |= 0x1;
break;
- default:
return;
- if (pdn)
- u32 val;
- if (cpu == 0) {
if (pdn)
else
- if (cpu == 1) {
if (pdn)
else
- u32 val;
return;
- /* set slot */
- if (ack) {
/* set ack */
- u32 val;
- u32 val;
- u32 itlinesnr, i;
- u32 freq;
- u64 start, end;
- do {
break;
- } while (1);
- imx_udelay(65);
- gic_resume();
- _nonsec_init();
- psci_cpu_entry();
- u32 gpc_mask[4];
- u32 i, val;
* Workaround:
4);
* is ~250uS.
- val |= (1 << 30);
4);
- imx_udelay(3);
- /* sleep */
- while (1)
wfi();
- mov r0, #0
- movw r1, #0x7fff
- movw r1, #0x3ff
- and r0, r0, #0x7
+1:
+2:
- bgt 2b
- cmp r2, #0
- bgt 1b
- dsb st
- isb
- mov pc, lr
- mov sp, r0
- mov r6, #0x0
- mov r6, #0x1800
- isb
- .popsection
Hi, all Can anyone pick up this patch set, it has been tested and suspend/resume is an important feature many people want, thanks!
-----Original Message----- From: Stefan Agner stefan@agner.ch Sent: Wednesday, August 8, 2018 8:09 PM To: Anson Huang anson.huang@nxp.com Cc: sbabic@denx.de; Fabio Estevam fabio.estevam@nxp.com; albert.u.boot@aribaud.net; bryan.odonoghue@linaro.org; uri.mashiach@compulab.co.il; Stefan Agner stefan.agner@toradex.com; Peng Fan peng.fan@nxp.com; Ye Li ye.li@nxp.com; sjg@chromium.org; u-boot@lists.denx.de; dl-linux-imx linux-imx@nxp.com Subject: Re: [U-Boot] [RESEND PATCH V2 3/3] imx: mx7: add system suspend/resume support
Hi, Stefan
sjg@chromium.org;
Hi Anson,
done.
-- Stefan
Anson.
-- Stefan
possible.
__secure_data = {
- CORE0_A7,
- CORE1_A7,
- SCU_A7,
- FAST_MEGA_MIX,
- MIPI_PHY,
- PCIE_PHY,
- USB_OTG1_PHY,
- USB_OTG2_PHY,
- USB_HSIC_PHY,
- CORE0_M4,
- RUN,
- WAIT,
- STOP,
mxc_cpu_pwr_mode
+mode) {
BM_SLPCR_RBC_EN
WFI.
GPC
* Low-Power mode.
* is set.
- switch (mode) {
- case RUN:
val3 &= ~0x1;
break;
- case WAIT:
val3 &= ~0x1;
break;
- case STOP:
val3 |= 0x1;
break;
- default:
return;
- if (pdn)
- u32 val;
- if (cpu == 0) {
if (pdn)
else
- if (cpu == 1) {
if (pdn)
else
- u32 val;
return;
- /* set slot */
- if (ack) {
/* set ack */
val &= ~(mode ?
- u32 val;
- u32 val;
- u32 itlinesnr, i;
- u32 freq;
- u64 start, end;
- do {
break;
- } while (1);
4);
- imx_udelay(65);
- gic_resume();
- _nonsec_init();
- psci_cpu_entry();
- u32 gpc_mask[4];
- u32 i, val;
* Workaround:
- i *
4);
* is ~250uS.
- val |= (1 << 30);
- i *
4);
- imx_udelay(3);
SRC_GPR1_MX7D);
- /* sleep */
- while (1)
wfi();
- mov r0, #0
- movw r1, #0x7fff
- movw r1, #0x3ff
- and r0, r0, #0x7
+1:
+2:
- bgt 2b
- cmp r2, #0
- bgt 1b
- dsb st
- isb
- mov pc, lr
- mov sp, r0
- mov r6, #0x0
- mov r6, #0x1800
- isb
- .popsection
Hi Anson,
Thanks for your work on this.
This series looks good.
Hi Stefano,
Are you happy with this series?
Thanks
On 29/08/2018 15:31, Fabio Estevam wrote:
Hi Anson,
Hi Stefano,
I'll pick it up
Regards, Stefano
Hi Anson,
Hi Stefano,
I'll pick it up
Looking forward to see this upstream to!
If you anyway do a pull request, any chance to get this in still?
https://patchwork.ozlabs.org/patch/953756/ https://patchwork.ozlabs.org/patch/953755/
-- Stefan
Regards, Stefano
participants (5)
Anson Huang
Anson Huang
Fabio Estevam
Stefan Agner
Stefano Babic
