[PATCH v6 0/6] enable menu-driven boot device selection
Most of the patches are merged into u-boot/master, this series contains the remaining patches to support menu-driven UEFI boot variable maintenance and removable media support.
[Major Changes] - rebased to v2022.07-rc2 - there is detailed changelog in each commit
Masahisa Kojima (6): efi_loader: menu-driven addition of UEFI boot option efi_loader: menu-driven deletion of UEFI boot variable efi_loader: menu-driven update of UEFI bootorder variable bootmenu: add removable media entries doc:bootmenu: add description for UEFI boot support lib/charset: fix compile warnings
cmd/bootmenu.c | 167 ++- doc/usage/cmd/bootmenu.rst | 55 + include/charset.h | 2 +- include/efi_loader.h | 60 + lib/efi_loader/Makefile | 3 + lib/efi_loader/efi_bootmenu_maintenance.c | 1282 +++++++++++++++++++++ lib/efi_loader/efi_bootmgr.c | 4 + lib/efi_loader/efi_boottime.c | 52 +- lib/efi_loader/efi_console.c | 81 ++ lib/efi_loader/efi_disk.c | 11 + lib/efi_loader/efi_file.c | 75 +- 11 files changed, 1737 insertions(+), 55 deletions(-) create mode 100644 lib/efi_loader/efi_bootmenu_maintenance.c
This commit supports the menu-driven UEFI boot option addition. User can select the block device volume having efi_simple_file_system_protocol and select the file corresponding to the Boot#### variable. Then user enter the label of the BOOT#### variable in utf8.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- Changes in v6: - fix typos - modify volume name to match U-Boot syntax - compile in CONFIG_EFI_LOADER=n and CONFIG_CMD_BOOTEFI_BOOTMGR=n - simplify u16_strncmp() usage - support "a\b.efi" file path, use link list to handle filepath - modify length check condition - UEFI related menu items only appears with CONFIG_AUTOBOOT_MENU_SHOW=y
Changes in v5: - remove forward declarations - add const qualifier for menu items - fix the possible unaligned access for directory info access - split into three commit 1)add boot option 2) delete boot option 3)change boot order This commit is 1)add boot option. - fix file name buffer allocation size, it should be EFI_BOOTMENU_FILE_PATH_MAX * sizeof(u16) - fix wrong size checking for file selection
Chanes in v4: - UEFI boot option maintenance menu is integrated into bootmenu - display the simplified volume name(e.g. usb0:1, nvme1:2) for the volume selection - instead of extending lib/efi_loader/efi_bootmgr.c, newly create lib/efi_loader/efi_bootmenu_maintenance.c and implement boot variable maintenance into it.
Changes in RFC v3: not included in v3 series
Changes in RFC v2: - enable utf8 user input for boot option name - create lib/efi_loader/efi_console.c::efi_console_get_u16_string() for utf8 user input handling - use u16_strlcat instead of u16_strcat - remove the EFI_CALLs, and newly create or expose the following xxx_int() functions. efi_locate_handle_buffer_int(), efi_open_volume_int(), efi_file_open_int(), efi_file_close_int(), efi_file_read_int() and efi_file_setpos_int(). Note that EFI_CALLs still exist for EFI_DEVICE_PATH_TO_TEXT_PROTOCOL and EFI_SIMPLE_TEXT_INPUT/OUTPUT_PROTOCOL - use efi_search_protocol() instead of calling locate_protocol() to get the device_path_to_text_protocol interface. - remove unnecessary puts(ANSI_CLEAR_LINE), this patch is still depends on puts(ANSI_CLEAR_CONSOLE) - skip SetVariable() if the bootorder is not changed
cmd/bootmenu.c | 73 +- include/efi_loader.h | 37 + lib/efi_loader/Makefile | 3 + lib/efi_loader/efi_bootmenu_maintenance.c | 906 ++++++++++++++++++++++ lib/efi_loader/efi_boottime.c | 52 +- lib/efi_loader/efi_console.c | 81 ++ lib/efi_loader/efi_disk.c | 11 + lib/efi_loader/efi_file.c | 75 +- 8 files changed, 1184 insertions(+), 54 deletions(-) create mode 100644 lib/efi_loader/efi_bootmenu_maintenance.c
diff --git a/cmd/bootmenu.c b/cmd/bootmenu.c index 8859eebea5..4b846332b0 100644 --- a/cmd/bootmenu.c +++ b/cmd/bootmenu.c @@ -19,6 +19,12 @@
/* maximum bootmenu entries */ #define MAX_COUNT 99 +#if defined(CONFIG_CMD_BOOTEFI_BOOTMGR) && defined(CONFIG_AUTOBOOT_MENU_SHOW) +#define STATIC_ENTRY 2 +#else +#define STATIC_ENTRY 1 +#endif +#define MAX_DYNAMIC_ENTRY (MAX_COUNT - STATIC_ENTRY)
/* maximal size of bootmenu env * 9 = strlen("bootmenu_") @@ -38,10 +44,11 @@ enum boot_type { BOOTMENU_TYPE_NONE = 0, BOOTMENU_TYPE_BOOTMENU, BOOTMENU_TYPE_UEFI_BOOT_OPTION, + BOOTMENU_TYPE_UEFI_MAINTENANCE, };
struct bootmenu_entry { - unsigned short int num; /* unique number 0 .. MAX_COUNT */ + unsigned short int num; /* unique number 0 .. (MAX_COUNT - 1) */ char key[3]; /* key identifier of number */ u16 *title; /* title of entry */ char *command; /* hush command of entry */ @@ -55,7 +62,7 @@ static char *bootmenu_getoption(unsigned short int n) { char name[MAX_ENV_SIZE];
- if (n > MAX_COUNT) + if (n > MAX_DYNAMIC_ENTRY) return NULL;
sprintf(name, "bootmenu_%d", n); @@ -217,7 +224,7 @@ static int prepare_bootmenu_entry(struct bootmenu_data *menu, iter = entry; ++i;
- if (i == MAX_COUNT - 1) + if (i == MAX_DYNAMIC_ENTRY) break; }
@@ -305,7 +312,7 @@ static int prepare_uefi_bootorder_entry(struct bootmenu_data *menu,
free(load_option);
@@ -341,14 +348,51 @@ static struct bootmenu_data *bootmenu_create(int delay) if (ret < 0) goto cleanup;
- if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR)) { - if (i < MAX_COUNT - 1) { + if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR) && IS_ENABLED(CONFIG_AUTOBOOT_MENU_SHOW)) { + if (i < MAX_DYNAMIC_ENTRY) { ret = prepare_uefi_bootorder_entry(menu, &iter, &i); if (ret < 0 && ret != -ENOENT) goto cleanup; } }
+ if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR) && IS_ENABLED(CONFIG_AUTOBOOT_MENU_SHOW)) { + /* Add UEFI Boot Manager Maintenance entry */ + if (i <= MAX_DYNAMIC_ENTRY) { + entry = malloc(sizeof(struct bootmenu_entry)); + if (!entry) + goto cleanup; + + entry->title = u16_strdup(u"UEFI Boot Manager Maintenance"); + if (!entry->title) { + free(entry); + goto cleanup; + } + + entry->command = strdup(""); + if (!entry->command) { + free(entry->title); + free(entry); + goto cleanup; + } + + sprintf(entry->key, "%d", i); + + entry->num = i; + entry->menu = menu; + entry->type = BOOTMENU_TYPE_UEFI_MAINTENANCE; + entry->next = NULL; + + if (!iter) + menu->first = entry; + else + iter->next = entry; + + iter = entry; + i++; + } + } + /* Add U-Boot console entry at the end */ if (i <= MAX_COUNT - 1) { entry = malloc(sizeof(struct bootmenu_entry)); @@ -520,6 +564,14 @@ static enum bootmenu_ret bootmenu_show(int delay) title = u16_strdup(iter->title); command = strdup(iter->command);
+ if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR)) { + if (iter->type == BOOTMENU_TYPE_UEFI_MAINTENANCE) { + efi_bootmenu_show_maintenance_menu(); + ret = BOOTMENU_RET_UPDATED; + goto cleanup; + } + } + /* last entry is U-Boot console or Quit */ if (iter->num == iter->menu->count - 1) { ret = BOOTMENU_RET_QUIT; @@ -610,6 +662,7 @@ int do_bootmenu(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { char *delay_str = NULL; int delay = 10; + int ret;
#if defined(CONFIG_BOOTDELAY) && (CONFIG_BOOTDELAY >= 0) delay = CONFIG_BOOTDELAY; @@ -624,7 +677,13 @@ int do_bootmenu(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) if (delay_str) delay = (int)simple_strtol(delay_str, NULL, 10);
- bootmenu_show(delay); + while (1) { + ret = bootmenu_show(delay); + delay = -1; + if (ret != BOOTMENU_RET_UPDATED) + break; + } + return 0; }
diff --git a/include/efi_loader.h b/include/efi_loader.h index 733ee03cd7..49f326e585 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -226,6 +226,9 @@ const char *__efi_nesting_dec(void); #define EFI_CACHELINE_SIZE 128 #endif
+/* max bootmenu title size for volume selection */ +#define BOOTMENU_DEVICE_NAME_MAX 16 + /* Key identifying current memory map */ extern efi_uintn_t efi_memory_map_key;
@@ -314,6 +317,9 @@ extern const efi_guid_t efi_guid_firmware_management_protocol; extern const efi_guid_t efi_esrt_guid; /* GUID of the SMBIOS table */ extern const efi_guid_t smbios_guid; +/*GUID of console */ +extern const efi_guid_t efi_guid_text_input_protocol; +extern const efi_guid_t efi_guid_text_output_protocol;
extern char __efi_runtime_start[], __efi_runtime_stop[]; extern char __efi_runtime_rel_start[], __efi_runtime_rel_stop[]; @@ -877,6 +883,8 @@ efi_status_t efi_set_load_options(efi_handle_t handle, void *load_options); efi_status_t efi_bootmgr_load(efi_handle_t *handle, void **load_options);
+efi_status_t efi_bootmenu_show_maintenance_menu(void); + /** * struct efi_image_regions - A list of memory regions * @@ -1048,4 +1056,33 @@ efi_status_t efi_esrt_populate(void); efi_status_t efi_load_capsule_drivers(void);
efi_status_t platform_get_eventlog(struct udevice *dev, u64 *addr, u32 *sz); + +efi_status_t efi_locate_handle_buffer_int(enum efi_locate_search_type search_type, + const efi_guid_t *protocol, void *search_key, + efi_uintn_t *no_handles, efi_handle_t **buffer); + +efi_status_t efi_open_volume_int(struct efi_simple_file_system_protocol *this, + struct efi_file_handle **root); +efi_status_t efi_file_open_int(struct efi_file_handle *this, + struct efi_file_handle **new_handle, + u16 *file_name, u64 open_mode, + u64 attributes); +efi_status_t efi_file_close_int(struct efi_file_handle *file); +efi_status_t efi_file_read_int(struct efi_file_handle *this, + efi_uintn_t *buffer_size, void *buffer); +efi_status_t efi_file_setpos_int(struct efi_file_handle *file, u64 pos); + +typedef efi_status_t (*efi_console_filter_func)(struct efi_input_key *key); +efi_status_t efi_console_get_u16_string + (struct efi_simple_text_input_protocol *cin, + struct efi_simple_text_output_protocol *cout, + u16 *buf, efi_uintn_t count, efi_console_filter_func filer_func, + int row, int col); + +efi_status_t efi_bootmenu_get_unused_bootoption(u16 *buf, + efi_uintn_t buf_size, u32 *index); +efi_status_t efi_bootmenu_append_bootorder(u16 index); + +efi_status_t efi_disk_get_device_name(struct efi_block_io *this, char *buf, int size); + #endif /* _EFI_LOADER_H */ diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index aaaa25cefe..807e9a4319 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -77,6 +77,9 @@ obj-$(CONFIG_EFI_TCG2_PROTOCOL) += efi_tcg2.o obj-$(CONFIG_EFI_RISCV_BOOT_PROTOCOL) += efi_riscv.o obj-$(CONFIG_EFI_LOAD_FILE2_INITRD) += efi_load_initrd.o obj-$(CONFIG_EFI_SIGNATURE_SUPPORT) += efi_signature.o +ifeq ($(CONFIG_CMD_BOOTEFI_BOOTMGR),y) +obj-$(CONFIG_CMD_BOOTMENU) += efi_bootmenu_maintenance.o +endif
EFI_VAR_SEED_FILE := $(subst $",,$(CONFIG_EFI_VAR_SEED_FILE)) $(obj)/efi_var_seed.o: $(srctree)/$(EFI_VAR_SEED_FILE) diff --git a/lib/efi_loader/efi_bootmenu_maintenance.c b/lib/efi_loader/efi_bootmenu_maintenance.c new file mode 100644 index 0000000000..e5124a8a21 --- /dev/null +++ b/lib/efi_loader/efi_bootmenu_maintenance.c @@ -0,0 +1,906 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Menu-driven UEFI Boot Variable maintenance + * + * Copyright (c) 2022 Masahisa Kojima, Linaro Limited + */ + +#define LOG_CATEGORY LOGC_EFI + +#include <ansi.h> +#include <common.h> +#include <charset.h> +#include <log.h> +#include <malloc.h> +#include <menu.h> +#include <efi_loader.h> +#include <efi_variable.h> +#include <asm/unaligned.h> + +static struct efi_simple_text_input_protocol *cin; +static struct efi_simple_text_output_protocol *cout; + +#define EFI_BOOTMENU_ENTRY_NUM_MAX 99 +#define EFI_BOOTMENU_FILE_PATH_MAX 512 +#define EFI_BOOTMENU_FILE_PATH_BUF_SIZE (EFI_BOOTMENU_FILE_PATH_MAX * sizeof(u16)) +#define EFI_BOOTMENU_BOOT_NAME_MAX 32 +#define EFI_BOOT_ORDER_MAX_SIZE_IN_DECIMAL 6 + +typedef efi_status_t (*efi_bootmenu_entry_func)(void *data, bool *exit); + +/** + * struct efi_bootmenu_entry - menu entry structure + * + * @num: menu entry index + * @title: title of entry + * @key: unique key + * @bootmgr_menu: pointer to the menu structure + * @next: pointer to the next entry + * @func: callback function to be called when this entry is selected + * @data: data to be passed to the callback function + */ +struct efi_bootmenu_entry { + u32 num; + u16 *title; + char key[6]; + struct efi_bootmenu *bootmgr_menu; + struct efi_bootmenu_entry *next; + efi_bootmenu_entry_func func; + void *data; +}; + +/** + * struct efi_bootmenu - bootmgr menu structure + * + * @delay: delay for autoboot + * @active: active menu entry index + * @count: total count of menu entry + * @first: pointer to the first menu entry + */ +struct efi_bootmenu { + int delay; + int active; + int count; + struct efi_bootmenu_entry *first; +}; + +struct efi_bootmenu_item { + u16 *title; + efi_bootmenu_entry_func func; + void *data; +}; + +struct efi_bootmenu_boot_selection_data { + u16 bootorder_index; + void *load_option; + int *selected; +}; + +struct efi_bootmenu_filepath_info { + u16 *name; + struct list_head list; +}; + +struct efi_bootmenu_boot_option { + struct efi_simple_file_system_protocol *current_volume; + struct efi_device_path *dp_volume; + u16 *current_path; + struct list_head filepath_list; + u16 *boot_name; + bool file_selected; +}; + +static const struct efi_device_path END = { + .type = DEVICE_PATH_TYPE_END, + .sub_type = DEVICE_PATH_SUB_TYPE_END, + .length = sizeof(END), +}; + +struct efi_bootmenu_volume_entry_data { + struct efi_bootmenu_boot_option *bo; + struct efi_simple_file_system_protocol *v; + struct efi_device_path *dp; +}; + +struct efi_bootmenu_file_entry_data { + struct efi_bootmenu_boot_option *bo; + bool is_directory; + u16 *file_name; +}; + +static void efi_bootmenu_print_entry(void *data) +{ + struct efi_bootmenu_entry *entry = data; + int reverse = (entry->bootmgr_menu->active == entry->num); + + /* TODO: support scroll or page for many entries */ + + /* + * Move cursor to line where the entry will be drawn (entry->count) + * First 3 lines contain bootmgr menu header + one empty line + * For the last "Quit" entry, add one empty line + */ + if (entry->num == (entry->bootmgr_menu->count - 1)) + printf(ANSI_CURSOR_POSITION, entry->num + 5, 1); + else + printf(ANSI_CURSOR_POSITION, entry->num + 4, 1); + + puts(" "); + + if (reverse) + puts(ANSI_COLOR_REVERSE); + + printf("%ls", entry->title); + + if (reverse) + puts(ANSI_COLOR_RESET); +} + +static void efi_bootmenu_display_statusline(struct menu *m) +{ + struct efi_bootmenu_entry *entry; + struct efi_bootmenu *bootmgr_menu; + + if (menu_default_choice(m, (void *)&entry) < 0) + return; + + bootmgr_menu = entry->bootmgr_menu; + + printf(ANSI_CURSOR_POSITION, 1, 1); + puts(ANSI_CLEAR_LINE); + printf(ANSI_CURSOR_POSITION, 2, 1); + puts(" *** U-Boot EFI Boot Manager ***"); + puts(ANSI_CLEAR_LINE_TO_END); + printf(ANSI_CURSOR_POSITION, 3, 1); + puts(ANSI_CLEAR_LINE); + + /* First 3 lines are bootmgr_menu header + 2 empty lines between entries */ + printf(ANSI_CURSOR_POSITION, bootmgr_menu->count + 5, 1); + puts(ANSI_CLEAR_LINE); + printf(ANSI_CURSOR_POSITION, bootmgr_menu->count + 6, 1); + puts(" Press UP/DOWN to move, ENTER to select, ESC/CTRL+C to quit"); + puts(ANSI_CLEAR_LINE_TO_END); + printf(ANSI_CURSOR_POSITION, bootmgr_menu->count + 7, 1); + puts(ANSI_CLEAR_LINE); +} + +static char *efi_bootmenu_choice_entry(void *data) +{ + int i; + int esc = 0; + struct efi_bootmenu_entry *iter; + enum bootmenu_key key = KEY_NONE; + struct efi_bootmenu *bootmgr_menu = data; + + while (1) { + if (bootmgr_menu->delay >= 0) { + /* Autoboot was not stopped */ + bootmenu_autoboot_loop((struct bootmenu_data *)bootmgr_menu, &key, &esc); + } else { + /* Some key was pressed, so autoboot was stopped */ + bootmenu_loop((struct bootmenu_data *)bootmgr_menu, &key, &esc); + } + + if (bootmgr_menu->delay == 0) + key = KEY_QUIT; + + switch (key) { + case KEY_UP: + if (bootmgr_menu->active > 0) + --bootmgr_menu->active; + /* no menu key selected, regenerate menu */ + return NULL; + case KEY_DOWN: + if (bootmgr_menu->active < bootmgr_menu->count - 1) + ++bootmgr_menu->active; + /* no menu key selected, regenerate menu */ + return NULL; + case KEY_SELECT: + iter = bootmgr_menu->first; + for (i = 0; i < bootmgr_menu->active; ++i) + iter = iter->next; + return iter->key; + case KEY_QUIT: + /* Quit by choosing the last entry */ + iter = bootmgr_menu->first; + while (iter->next) + iter = iter->next; + return iter->key; + default: + break; + } + } + + /* never happens */ + debug("bootmgr menu: this should not happen"); + return NULL; +} + +static void efi_bootmenu_destroy(struct efi_bootmenu *bootmgr_menu) +{ + struct efi_bootmenu_entry *next; + struct efi_bootmenu_entry *iter = bootmgr_menu->first; + + while (iter) { + next = iter->next; + free(iter); + iter = next; + } + free(bootmgr_menu); +} + +/** + * efi_bootmenu_process_common() - main handler for uefi bootmgr menu + * + * Construct the structures required to show the menu, then handle + * the user input intracting with u-boot menu functions. + * + * @items: pointer to the structure of each menu entry + * @count: the number of menu entry + * @delay: delay for autoboot/autoselect + * Return: status code + */ +static efi_status_t efi_bootmenu_process_common(const struct efi_bootmenu_item *items, + int count, int delay) +{ + u32 i; + bool exit = false; + efi_status_t ret; + struct menu *menu; + void *choice = NULL; + struct efi_bootmenu_entry *entry; + struct efi_bootmenu *bootmgr_menu; + struct efi_bootmenu_entry *iter = NULL; + + if (count > EFI_BOOTMENU_ENTRY_NUM_MAX) + return EFI_OUT_OF_RESOURCES; + + bootmgr_menu = calloc(1, sizeof(struct efi_bootmenu)); + if (!bootmgr_menu) + return EFI_OUT_OF_RESOURCES; + + bootmgr_menu->delay = delay; + bootmgr_menu->active = 0; + bootmgr_menu->first = NULL; + + for (i = 0; i < count; i++) { + entry = calloc(1, sizeof(struct efi_bootmenu_entry)); + if (!entry) { + ret = EFI_LOAD_ERROR; + goto out; + } + + entry->num = i; + entry->title = items->title; + snprintf(entry->key, sizeof(entry->key), "%04X", i); + entry->bootmgr_menu = bootmgr_menu; + entry->func = items->func; + entry->data = items->data; + entry->next = NULL; + + if (!iter) + bootmgr_menu->first = entry; + else + iter->next = entry; + + iter = entry; + items++; + } + bootmgr_menu->count = count; + + menu = menu_create(NULL, 0, 1, efi_bootmenu_display_statusline, + efi_bootmenu_print_entry, efi_bootmenu_choice_entry, + bootmgr_menu); + if (!menu) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + + for (entry = bootmgr_menu->first; entry; entry = entry->next) { + if (!menu_item_add(menu, entry->key, entry)) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + } + + menu_default_set(menu, bootmgr_menu->first->key); + + while (!exit) { + puts(ANSI_CURSOR_HIDE); + puts(ANSI_CLEAR_CONSOLE); + printf(ANSI_CURSOR_POSITION, 1, 1); + + if (menu_get_choice(menu, &choice)) { + entry = choice; + if (entry->func) + ret = entry->func(entry->data, &exit); + + /* last entry "Quit" is selected, exit this menu */ + if (entry->num == (entry->bootmgr_menu->count - 1)) { + ret = EFI_ABORTED; + break; + } + } + } + +out: + menu_destroy(menu); + efi_bootmenu_destroy(bootmgr_menu); + + puts(ANSI_CLEAR_CONSOLE); + printf(ANSI_CURSOR_POSITION, 1, 1); + puts(ANSI_CURSOR_SHOW); + + return ret; +} + +static efi_status_t efi_bootmenu_volume_selected(void *data, bool *exit) +{ + struct efi_bootmenu_volume_entry_data *info = data; + + *exit = true; + + if (info) { + info->bo->current_volume = info->v; + info->bo->dp_volume = info->dp; + } + + return EFI_SUCCESS; +} + +static efi_status_t efi_bootmenu_file_selected(void *data, bool *exit) +{ + struct efi_bootmenu_file_entry_data *info = data; + + *exit = true; + + if (!info) + return EFI_INVALID_PARAMETER; + + if (u16_strcmp(info->file_name, u".") == 0 && + u16_strlen(info->file_name) == 1) { + /* stay current path */ + } else if (u16_strcmp(info->file_name, u"..") == 0 && + u16_strlen(info->file_name) == 2) { + struct efi_bootmenu_filepath_info *iter; + struct list_head *pos, *n; + int is_last; + + memset(info->bo->current_path, 0, EFI_BOOTMENU_FILE_PATH_BUF_SIZE); + list_for_each_safe(pos, n, &info->bo->filepath_list) { + iter = list_entry(pos, struct efi_bootmenu_filepath_info, list); + + is_last = list_is_last(&iter->list, &info->bo->filepath_list); + if (is_last) { + list_del(&iter->list); + free(iter->name); + free(iter); + break; + } + u16_strlcat(info->bo->current_path, iter->name, + EFI_BOOTMENU_FILE_PATH_MAX); + u16_strlcat(info->bo->current_path, u"\", + EFI_BOOTMENU_FILE_PATH_MAX); + } + } else { + size_t new_len; + struct efi_bootmenu_filepath_info *filepath; + + new_len = u16_strlen(info->bo->current_path) + + u16_strlen(info->file_name); + if (new_len >= EFI_BOOTMENU_FILE_PATH_MAX) { + /* TODO: show error notification to user */ + log_err("file path is too long\n"); + return EFI_INVALID_PARAMETER; + } + u16_strlcat(info->bo->current_path, info->file_name, + EFI_BOOTMENU_FILE_PATH_MAX); + + filepath = calloc(1, sizeof(struct efi_bootmenu_filepath_info)); + if (!filepath) + return EFI_OUT_OF_RESOURCES; + + filepath->name = u16_strdup(info->file_name); + if (!filepath->name) { + free(filepath); + return EFI_OUT_OF_RESOURCES; + } + list_add_tail(&filepath->list, &info->bo->filepath_list); + + if (info->is_directory) { + /* + * Remainig buffer should have enough space to contain u"\" and + * at least one character for file name + */ + if (new_len + 2 >= EFI_BOOTMENU_FILE_PATH_MAX) { + log_err("directory path is too long\n"); + return EFI_INVALID_PARAMETER; + } + u16_strlcat(info->bo->current_path, u"\", + EFI_BOOTMENU_FILE_PATH_MAX); + } else { + info->bo->file_selected = true; + } + } + return EFI_SUCCESS; +} + +static efi_status_t efi_bootmenu_select_volume(struct efi_bootmenu_boot_option *bo) +{ + u32 i; + efi_status_t ret; + efi_uintn_t count; + struct efi_handler *handler; + struct efi_device_path *device_path; + efi_handle_t *volume_handles = NULL; + struct efi_simple_file_system_protocol *v; + struct efi_bootmenu_item *menu_item, *iter; + + ret = efi_locate_handle_buffer_int(BY_PROTOCOL, &efi_simple_file_system_protocol_guid, + NULL, &count, (efi_handle_t **)&volume_handles); + if (ret != EFI_SUCCESS) + return ret; + + menu_item = calloc(count + 1, sizeof(struct efi_bootmenu_item)); + if (!menu_item) { + ret = EFI_OUT_OF_RESOURCES; + goto out1; + } + + iter = menu_item; + for (i = 0; i < count; i++) { + u16 *dev_name, *p; + struct efi_block_io *block_io; + char buf[BOOTMENU_DEVICE_NAME_MAX]; + struct efi_bootmenu_volume_entry_data *info; + + ret = efi_search_protocol(volume_handles[i], + &efi_simple_file_system_protocol_guid, &handler); + if (ret != EFI_SUCCESS) + continue; + ret = efi_protocol_open(handler, (void **)&v, efi_root, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + continue; + + ret = efi_search_protocol(volume_handles[i], &efi_guid_device_path, &handler); + if (ret != EFI_SUCCESS) + continue; + ret = efi_protocol_open(handler, (void **)&device_path, + efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + continue; + + ret = efi_search_protocol(volume_handles[i], &efi_block_io_guid, &handler); + if (ret != EFI_SUCCESS) + continue; + ret = efi_protocol_open(handler, (void **)&block_io, + efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + continue; + + info = calloc(1, sizeof(struct efi_bootmenu_volume_entry_data)); + if (!info) { + ret = EFI_OUT_OF_RESOURCES; + goto out2; + } + + efi_disk_get_device_name(block_io, buf, BOOTMENU_DEVICE_NAME_MAX); + dev_name = calloc(1, (strlen(buf) + 1) * sizeof(u16)); + if (!dev_name) { + free(info); + ret = EFI_OUT_OF_RESOURCES; + goto out2; + } + p = dev_name; + utf8_utf16_strncpy(&p, buf, strlen(buf)); + + info->v = v; + info->dp = device_path; + info->bo = bo; + iter->title = dev_name; + iter->func = efi_bootmenu_volume_selected; + iter->data = info; + iter++; + } + + iter->title = u16_strdup(u"Quit"); + iter->func = NULL; + iter->data = NULL; + count += 1; + + ret = efi_bootmenu_process_common(menu_item, count, -1); + +out2: + iter = menu_item; + for (i = 0; i < count; i++) { + struct efi_bootmenu_volume_entry_data *p; + + p = (struct efi_bootmenu_volume_entry_data *)(iter->data); + free(iter->title); + free(p); + iter++; + } + + free(menu_item); + +out1: + efi_free_pool(volume_handles); + + return ret; +} + +static efi_status_t efi_bootmenu_select_file(struct efi_bootmenu_boot_option *bo, + struct efi_file_handle *root) +{ + u32 i; + struct efi_file_info *buf; + u32 count = 0; + efi_uintn_t len; + efi_status_t ret; + struct efi_file_handle *f; + struct efi_bootmenu_item *menu_item, *iter; + + buf = calloc(1, sizeof(struct efi_file_info) + EFI_BOOTMENU_FILE_PATH_BUF_SIZE); + if (!buf) + return EFI_OUT_OF_RESOURCES; + + while (!bo->file_selected) { + count = 0; + + ret = efi_file_open_int(root, &f, bo->current_path, EFI_FILE_MODE_READ, 0); + if (ret != EFI_SUCCESS) + return ret; + + /* calculate directory information total count */ + for (;;) { + len = sizeof(struct efi_file_info) + EFI_BOOTMENU_FILE_PATH_BUF_SIZE; + ret = efi_file_read_int(f, &len, buf); + if (ret != EFI_SUCCESS || len == 0) + break; + + count++; + } + + menu_item = calloc(count + 1, sizeof(struct efi_bootmenu_item)); + if (!menu_item) { + efi_file_close_int(f); + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + + /* read directory and construct menu structure */ + efi_file_setpos_int(f, 0); + iter = menu_item; + for (i = 0; i < count; i++) { + u16 *name; + int name_len; + struct efi_bootmenu_file_entry_data *info; + + len = sizeof(struct efi_file_info) + EFI_BOOTMENU_FILE_PATH_BUF_SIZE; + ret = efi_file_read_int(f, &len, buf); + if (ret != EFI_SUCCESS || len == 0) + goto err; + + info = calloc(1, sizeof(struct efi_bootmenu_file_entry_data)); + if (!info) { + ret = EFI_OUT_OF_RESOURCES; + goto err; + } + + if (buf->attribute & EFI_FILE_DIRECTORY) { + /* append u'/' at the end of directory name */ + name_len = u16_strsize(buf->file_name) + sizeof(u16); + name = calloc(1, name_len); + if (!name) { + ret = EFI_OUT_OF_RESOURCES; + goto err; + } + u16_strcpy(name, buf->file_name); + name[u16_strlen(buf->file_name)] = u'/'; + + info->is_directory = true; + } else { + name_len = u16_strsize(buf->file_name); + name = calloc(1, name_len); + if (!name) { + ret = EFI_OUT_OF_RESOURCES; + goto err; + } + u16_strcpy(name, buf->file_name); + } + + info->file_name = u16_strdup(buf->file_name); + info->bo = bo; + iter->title = name; + iter->func = efi_bootmenu_file_selected; + iter->data = info; + iter++; + } + + /* add "Quit" entry */ + iter->title = u"Quit"; + iter->func = NULL; + iter->data = NULL; + count += 1; + + ret = efi_bootmenu_process_common(menu_item, count, -1); +err: + efi_file_close_int(f); + iter = menu_item; + for (i = 0; i < count - 1; i++, iter++) { + free(((struct efi_bootmenu_file_entry_data *)(iter->data))->file_name); + free(iter->title); + free(iter->data); + } + + free(menu_item); + + if (ret != EFI_SUCCESS) + break; + } + +out: + free(buf); + return ret; +} + +static efi_status_t efi_bootmenu_boot_add_enter_name(struct efi_bootmenu_boot_option *bo) +{ + efi_status_t ret; + + printf(ANSI_CURSOR_POSITION, 2, 1); + puts(" *** U-Boot EFI Boot Manager Menu ***"); + printf(ANSI_CURSOR_POSITION, 4, 1); + puts(" enter name:"); + + printf(ANSI_CURSOR_POSITION, 8, 1); + puts(" ENTER to complete, ESC/CTRL+C to quit"); + + ret = efi_console_get_u16_string(cin, cout, bo->boot_name, + EFI_BOOTMENU_BOOT_NAME_MAX, NULL, 4, 15); + + return ret; +} + +static efi_status_t efi_bootmenu_select_file_handler(struct efi_bootmenu_boot_option *bo) +{ + efi_status_t ret; + struct efi_file_handle *root; + + bo->file_selected = false; + + while (!bo->file_selected) { + bo->current_volume = NULL; + memset(bo->current_path, 0, EFI_BOOTMENU_FILE_PATH_BUF_SIZE); + + ret = efi_bootmenu_select_volume(bo); + if (ret != EFI_SUCCESS) + return ret; + + if (!bo->current_volume) + return EFI_INVALID_PARAMETER; + + ret = efi_open_volume_int(bo->current_volume, &root); + if (ret != EFI_SUCCESS) + return ret; + + ret = efi_bootmenu_select_file(bo, root); + if (ret != EFI_SUCCESS) + return ret; + } + + ret = efi_bootmenu_boot_add_enter_name(bo); + + return ret; +} + +efi_status_t efi_bootmenu_get_unused_bootoption(u16 *buf, + efi_uintn_t buf_size, u32 *index) +{ + u32 i; + efi_status_t ret; + efi_uintn_t size; + + if (buf_size < u16_strsize(u"Boot####")) + return EFI_BUFFER_TOO_SMALL; + + for (i = 0; i <= 0xFFFF; i++) { + size = 0; + efi_create_indexed_name(buf, buf_size, "Boot", i); + ret = efi_get_variable_int(buf, &efi_global_variable_guid, + NULL, &size, NULL, NULL); + if (ret == EFI_BUFFER_TOO_SMALL) + continue; + else + break; + } + + if (i > 0xFFFF) + return EFI_OUT_OF_RESOURCES; + + *index = i; + + return EFI_SUCCESS; +} + +static efi_status_t efi_bootmenu_set_boot_option(u16 *var_name, struct efi_device_path *dp, + u16 *label, char *optional_data) +{ + void *p = NULL; + efi_status_t ret; + efi_uintn_t size; + struct efi_load_option lo; + + lo.file_path = dp; + lo.file_path_length = efi_dp_size(dp) + sizeof(END); + lo.attributes = LOAD_OPTION_ACTIVE; + lo.optional_data = optional_data; + lo.label = label; + + size = efi_serialize_load_option(&lo, (u8 **)&p); + if (!size) + return EFI_INVALID_PARAMETER; + + ret = efi_set_variable_int(var_name, &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + size, p, false); + free(p); + + return ret; +} + +efi_status_t efi_bootmenu_append_bootorder(u16 index) +{ + u16 *bootorder; + efi_status_t ret; + u16 *new_bootorder = NULL; + efi_uintn_t last, size, new_size; + + /* append new boot option */ + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + last = size / sizeof(u16); + new_size = size + sizeof(u16); + new_bootorder = calloc(1, new_size); + if (!new_bootorder) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + memcpy(new_bootorder, bootorder, size); + new_bootorder[last] = index; + + ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + new_size, new_bootorder, false); + if (ret != EFI_SUCCESS) + goto out; + +out: + free(bootorder); + free(new_bootorder); + + return ret; +} + +static efi_status_t efi_bootmenu_process_add_boot_option(void *data, bool *exit) +{ + u32 index; + u16 var_name[9]; + char *buf = NULL; + efi_status_t ret; + char *iter = NULL; + struct list_head *pos, *n; + efi_uintn_t dp_size, fp_size; + struct efi_bootmenu_boot_option bo; + struct efi_device_path_file_path *fp; + struct efi_bootmenu_filepath_info *item; + + ret = efi_bootmenu_get_unused_bootoption(var_name, sizeof(var_name), + &index); + if (ret != EFI_SUCCESS) + return ret; + + bo.current_path = calloc(1, EFI_BOOTMENU_FILE_PATH_BUF_SIZE); + if (!bo.current_path) + goto out; + + bo.boot_name = calloc(1, EFI_BOOTMENU_BOOT_NAME_MAX * sizeof(u16)); + if (!bo.boot_name) + goto out; + + INIT_LIST_HEAD(&bo.filepath_list); + + ret = efi_bootmenu_select_file_handler(&bo); + if (ret != EFI_SUCCESS) + goto out; + + dp_size = efi_dp_size(bo.dp_volume); + fp_size = sizeof(struct efi_device_path) + + ((u16_strlen(bo.current_path) + 1) * sizeof(u16)); + buf = calloc(1, dp_size + fp_size + sizeof(END)); + if (!buf) + goto out; + + iter = buf; + memcpy(iter, bo.dp_volume, dp_size); + iter += dp_size; + + fp = (struct efi_device_path_file_path *)iter; + fp->dp.type = DEVICE_PATH_TYPE_MEDIA_DEVICE; + fp->dp.sub_type = DEVICE_PATH_SUB_TYPE_FILE_PATH; + fp->dp.length = (u16)fp_size; + u16_strcpy(fp->str, bo.current_path); + iter += fp_size; + *((struct efi_device_path *)iter) = END; + + ret = efi_bootmenu_set_boot_option(var_name, (struct efi_device_path *)buf, + bo.boot_name, NULL); + if (ret != EFI_SUCCESS) + goto out; + + efi_bootmenu_append_bootorder((u16)index); + if (ret != EFI_SUCCESS) + goto out; + +out: + free(buf); + free(bo.boot_name); + free(bo.current_path); + + list_for_each_safe(pos, n, &bo.filepath_list) { + item = list_entry(pos, struct efi_bootmenu_filepath_info, list); + list_del(&item->list); + free(item->name); + free(item); + } + + return ret; +} + +static efi_status_t efi_bootmenu_init(void) +{ + efi_status_t ret; + struct efi_handler *handler; + + ret = efi_search_protocol(efi_root, &efi_guid_text_input_protocol, &handler); + if (ret != EFI_SUCCESS) + return ret; + + ret = efi_protocol_open(handler, (void **)&cin, efi_root, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + return ret; + + ret = efi_search_protocol(efi_root, &efi_guid_text_output_protocol, &handler); + if (ret != EFI_SUCCESS) + return ret; + + ret = efi_protocol_open(handler, (void **)&cout, efi_root, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + return ret; + + return ret; +} + +static const struct efi_bootmenu_item maintenance_menu_items[] = { + {u"Add Boot Option", efi_bootmenu_process_add_boot_option}, + {u"Quit", NULL}, +}; + +efi_status_t efi_bootmenu_show_maintenance_menu(void) +{ + efi_status_t ret; + + ret = efi_bootmenu_init(); + if (ret != EFI_SUCCESS) + return ret; + + return efi_bootmenu_process_common(maintenance_menu_items, + ARRAY_SIZE(maintenance_menu_items), + -1); +} diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 4da64b5d29..1233418e77 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2453,6 +2453,35 @@ static efi_status_t EFIAPI efi_protocols_per_handle( return EFI_EXIT(EFI_SUCCESS); }
+efi_status_t efi_locate_handle_buffer_int(enum efi_locate_search_type search_type, + const efi_guid_t *protocol, void *search_key, + efi_uintn_t *no_handles, efi_handle_t **buffer) +{ + efi_status_t r; + efi_uintn_t buffer_size = 0; + + if (!no_handles || !buffer) { + r = EFI_INVALID_PARAMETER; + goto out; + } + *no_handles = 0; + *buffer = NULL; + r = efi_locate_handle(search_type, protocol, search_key, &buffer_size, + *buffer); + if (r != EFI_BUFFER_TOO_SMALL) + goto out; + r = efi_allocate_pool(EFI_BOOT_SERVICES_DATA, buffer_size, + (void **)buffer); + if (r != EFI_SUCCESS) + goto out; + r = efi_locate_handle(search_type, protocol, search_key, &buffer_size, + *buffer); + if (r == EFI_SUCCESS) + *no_handles = buffer_size / sizeof(efi_handle_t); +out: + return r; +} + /** * efi_locate_handle_buffer() - locate handles implementing a protocol * @search_type: selection criterion @@ -2474,30 +2503,13 @@ efi_status_t EFIAPI efi_locate_handle_buffer( efi_uintn_t *no_handles, efi_handle_t **buffer) { efi_status_t r; - efi_uintn_t buffer_size = 0;
EFI_ENTRY("%d, %pUs, %p, %p, %p", search_type, protocol, search_key, no_handles, buffer);
- if (!no_handles || !buffer) { - r = EFI_INVALID_PARAMETER; - goto out; - } - *no_handles = 0; - *buffer = NULL; - r = efi_locate_handle(search_type, protocol, search_key, &buffer_size, - *buffer); - if (r != EFI_BUFFER_TOO_SMALL) - goto out; - r = efi_allocate_pool(EFI_BOOT_SERVICES_DATA, buffer_size, - (void **)buffer); - if (r != EFI_SUCCESS) - goto out; - r = efi_locate_handle(search_type, protocol, search_key, &buffer_size, - *buffer); - if (r == EFI_SUCCESS) - *no_handles = buffer_size / sizeof(efi_handle_t); -out: + r = efi_locate_handle_buffer_int(search_type, protocol, search_key, + no_handles, buffer); + return EFI_EXIT(r); }
diff --git a/lib/efi_loader/efi_console.c b/lib/efi_loader/efi_console.c index 60a3fc85ac..cf9622ed1a 100644 --- a/lib/efi_loader/efi_console.c +++ b/lib/efi_loader/efi_console.c @@ -5,6 +5,7 @@ * Copyright (c) 2016 Alexander Graf */
+#include <ansi.h> #include <common.h> #include <charset.h> #include <malloc.h> @@ -1312,3 +1313,83 @@ out_of_memory: printf("ERROR: Out of memory\n"); return r; } + +/** + * efi_console_get_u16_string() - get user input string + * + * @cin: protocol interface to EFI_SIMPLE_TEXT_INPUT_PROTOCOL + * @cout: protocol interface to EFI_SIMPLE_TEXT_OUTPUT_PROTOCOL + * @buf: buffer to store user input string in UTF16 + * @size: buffer size including NULL terminator + * @filter_func: callback to filter user input + * @row: row number to locate user input form + * @col: column number to locate user input form + * Return: status code + */ +efi_status_t efi_console_get_u16_string(struct efi_simple_text_input_protocol *cin, + struct efi_simple_text_output_protocol *cout, + u16 *buf, efi_uintn_t size, + efi_console_filter_func filter_func, + int row, int col) +{ + efi_status_t ret; + efi_uintn_t len = 0; + struct efi_input_key key; + + printf(ANSI_CURSOR_POSITION, row, col); + puts(ANSI_CLEAR_LINE_TO_END); + puts(ANSI_CURSOR_SHOW); + + ret = EFI_CALL(cin->reset(cin, false)); + if (ret != EFI_SUCCESS) + return ret; + + for (;;) { + do { + ret = EFI_CALL(cin->read_key_stroke(cin, &key)); + mdelay(10); + } while (ret == EFI_NOT_READY); + + if (key.unicode_char == u'\b') { + if (len > 0) + buf[--len] = u'\0'; + + printf(ANSI_CURSOR_POSITION, row, col); + ret = EFI_CALL(cout->output_string(cout, buf)); + if (ret != EFI_SUCCESS) + return ret; + + puts(ANSI_CLEAR_LINE_TO_END); + continue; + } else if (key.unicode_char == u'\r') { + if (len == 0) /* no user input */ + continue; + + buf[len] = u'\0'; + return EFI_SUCCESS; + } else if (key.unicode_char == 0x3 || key.scan_code == 23) { + return EFI_ABORTED; + } else if (key.unicode_char < 0x20) { + /* ignore control codes other than Ctrl+C, '\r' and '\b' */ + continue; + } else if (key.scan_code != 0) { + /* only accept single ESC press for cancel */ + continue; + } + + if (filter_func) { + if (filter_func(&key) != EFI_SUCCESS) + continue; + } + + if (len >= (size - 1)) + continue; + + buf[len] = key.unicode_char; + len++; + printf(ANSI_CURSOR_POSITION, row, col); + ret = EFI_CALL(cout->output_string(cout, buf)); + if (ret != EFI_SUCCESS) + return ret; + } +} diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index f5b462fb16..01576c8ed2 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -751,3 +751,14 @@ efi_status_t efi_disk_init(void)
return EFI_SUCCESS; } + +efi_status_t efi_disk_get_device_name(struct efi_block_io *this, char *buf, int size) +{ + struct efi_disk_obj *diskobj; + + diskobj = container_of(this, struct efi_disk_obj, ops); + + snprintf(buf, size, "%s %d:%d", diskobj->ifname, diskobj->dev_index, diskobj->part); + + return EFI_SUCCESS; +} diff --git a/lib/efi_loader/efi_file.c b/lib/efi_loader/efi_file.c index 7a7077e6d0..c96a7f7ca3 100644 --- a/lib/efi_loader/efi_file.c +++ b/lib/efi_loader/efi_file.c @@ -246,10 +246,10 @@ error: return NULL; }
-static efi_status_t efi_file_open_int(struct efi_file_handle *this, - struct efi_file_handle **new_handle, - u16 *file_name, u64 open_mode, - u64 attributes) +efi_status_t efi_file_open_int(struct efi_file_handle *this, + struct efi_file_handle **new_handle, + u16 *file_name, u64 open_mode, + u64 attributes) { struct file_handle *fh = to_fh(this); efi_status_t ret; @@ -369,11 +369,17 @@ static efi_status_t file_close(struct file_handle *fh) return EFI_SUCCESS; }
-static efi_status_t EFIAPI efi_file_close(struct efi_file_handle *file) +efi_status_t efi_file_close_int(struct efi_file_handle *file) { struct file_handle *fh = to_fh(file); + + return file_close(fh); +} + +static efi_status_t EFIAPI efi_file_close(struct efi_file_handle *file) +{ EFI_ENTRY("%p", file); - return EFI_EXIT(file_close(fh)); + return EFI_EXIT(efi_file_close_int(file)); }
static efi_status_t EFIAPI efi_file_delete(struct efi_file_handle *file) @@ -562,8 +568,8 @@ static efi_status_t dir_read(struct file_handle *fh, u64 *buffer_size, return EFI_SUCCESS; }
-static efi_status_t efi_file_read_int(struct efi_file_handle *this, - efi_uintn_t *buffer_size, void *buffer) +efi_status_t efi_file_read_int(struct efi_file_handle *this, + efi_uintn_t *buffer_size, void *buffer) { struct file_handle *fh = to_fh(this); efi_status_t ret = EFI_SUCCESS; @@ -773,24 +779,11 @@ out: return EFI_EXIT(ret); }
-/** - * efi_file_setpos() - set current position in file - * - * This function implements the SetPosition service of the EFI file protocol. - * See the UEFI spec for details. - * - * @file: file handle - * @pos: new file position - * Return: status code - */ -static efi_status_t EFIAPI efi_file_setpos(struct efi_file_handle *file, - u64 pos) +efi_status_t efi_file_setpos_int(struct efi_file_handle *file, u64 pos) { struct file_handle *fh = to_fh(file); efi_status_t ret = EFI_SUCCESS;
- EFI_ENTRY("%p, %llu", file, pos); - if (fh->isdir) { if (pos != 0) { ret = EFI_UNSUPPORTED; @@ -812,6 +805,28 @@ static efi_status_t EFIAPI efi_file_setpos(struct efi_file_handle *file, fh->offset = pos;
error: + return ret; +} + +/** + * efi_file_setpos() - set current position in file + * + * This function implements the SetPosition service of the EFI file protocol. + * See the UEFI spec for details. + * + * @file: file handle + * @pos: new file position + * Return: status code + */ +static efi_status_t EFIAPI efi_file_setpos(struct efi_file_handle *file, + u64 pos) +{ + efi_status_t ret = EFI_SUCCESS; + + EFI_ENTRY("%p, %llu", file, pos); + + ret = efi_file_setpos_int(file, pos); + return EFI_EXIT(ret); }
@@ -1138,17 +1153,23 @@ struct efi_file_handle *efi_file_from_path(struct efi_device_path *fp) return f; }
+efi_status_t efi_open_volume_int(struct efi_simple_file_system_protocol *this, + struct efi_file_handle **root) +{ + struct file_system *fs = to_fs(this); + + *root = file_open(fs, NULL, NULL, 0, 0); + + return EFI_SUCCESS; +} + static efi_status_t EFIAPI efi_open_volume(struct efi_simple_file_system_protocol *this, struct efi_file_handle **root) { - struct file_system *fs = to_fs(this); - EFI_ENTRY("%p, %p", this, root);
- *root = file_open(fs, NULL, NULL, 0, 0); - - return EFI_EXIT(EFI_SUCCESS); + return EFI_EXIT(efi_open_volume_int(this, root)); }
Changes in v6:
- fix typos
Is this correct?
Why? I think that the feature is useful even without AUTOBOOT. As you know, efidebug is seen as a debugging tool and is not expected to be enabled in production systems.
So the feature you're adding is the only available UI for boot manager. What I recommend is - to create a boot manager maintenance as a standalone U-Boot command, - to add an bootmenu entry for invoking the command
Changes in v5:
Chanes in v4:
Changes in RFC v2:
I would say that this file should be moved under /cmd as the code does not implement any UEFI specification semantics, but simply provides helper functions for bootmenu command.
Or I recommend that the boot manager be implemented as a standalone command (as I insisted serveral times before) and the related maintenance feature be invoked as follows: => efibootmanager -i (i for interactive)
- 9 = strlen("bootmenu_")
- BOOTMENU_TYPE_UEFI_MAINTENANCE,
- unsigned short int num; /* unique number 0 .. (MAX_COUNT - 1) */ char key[3]; /* key identifier of number */ u16 *title; /* title of entry */ char *command; /* hush command of entry */
}if (i == MAX_DYNAMIC_ENTRY) break;
free(load_option);
if (!entry)
goto cleanup;
If 'u16' is a matter, why not define the type of 'title' as u8 and you can always use utf16_to_utf8() for the setting the value to this field.
free(entry);
goto cleanup;
free(entry->title);
free(entry);
goto cleanup;
entry->num = i;
entry->menu = menu;
entry->next = NULL;
if (!iter)
else
iter->next = entry;
iter = entry;
i++;
- /* Add U-Boot console entry at the end */ if (i <= MAX_COUNT - 1) { entry = malloc(sizeof(struct bootmenu_entry));
goto cleanup;
- /* last entry is U-Boot console or Quit */ if (iter->num == iter->menu->count - 1) { ret = BOOTMENU_RET_QUIT;
- int ret;
- while (1) {
delay = -1;
break;
- struct efi_image_regions - A list of memory regions
u64 attributes);
int row, int col);
- Menu-driven UEFI Boot Variable maintenance
- Copyright (c) 2022 Masahisa Kojima, Linaro Limited
- struct efi_bootmenu_entry - menu entry structure
- @num: menu entry index
- @title: title of entry
- @key: unique key
- @bootmgr_menu: pointer to the menu structure
- @next: pointer to the next entry
- @func: callback function to be called when this entry is selected
- @data: data to be passed to the callback function
- u32 num;
- u16 *title;
- char key[6];
- struct efi_bootmenu *bootmgr_menu;
- struct efi_bootmenu_entry *next;
- efi_bootmenu_entry_func func;
- void *data;
- struct efi_bootmenu - bootmgr menu structure
- @delay: delay for autoboot
- @active: active menu entry index
- @count: total count of menu entry
- @first: pointer to the first menu entry
- int delay;
- int active;
- int count;
- struct efi_bootmenu_entry *first;
- u16 *title;
- void *data;
- u16 bootorder_index;
- void *load_option;
- int *selected;
- u16 *name;
- struct list_head list;
- struct efi_simple_file_system_protocol *current_volume;
- struct efi_device_path *dp_volume;
- u16 *current_path;
- struct list_head filepath_list;
- u16 *boot_name;
- bool file_selected;
- .type = DEVICE_PATH_TYPE_END,
- .sub_type = DEVICE_PATH_SUB_TYPE_END,
- .length = sizeof(END),
FYI, 'END' is also defined as a static variable in efi_device_path.c
- struct efi_bootmenu_boot_option *bo;
- struct efi_simple_file_system_protocol *v;
- struct efi_device_path *dp;
- bool is_directory;
- u16 *file_name;
- struct efi_bootmenu_entry *entry = data;
- int reverse = (entry->bootmgr_menu->active == entry->num);
- /* TODO: support scroll or page for many entries */
- if (entry->num == (entry->bootmgr_menu->count - 1))
- else
- puts(" ");
- if (reverse)
- printf("%ls", entry->title);
- if (reverse)
- struct efi_bootmenu_entry *entry;
- if (menu_default_choice(m, (void *)&entry) < 0)
return;
- bootmgr_menu = entry->bootmgr_menu;
- printf(ANSI_CURSOR_POSITION, 1, 1);
- puts(ANSI_CLEAR_LINE);
- printf(ANSI_CURSOR_POSITION, 2, 1);
- puts(" *** U-Boot EFI Boot Manager ***");
- puts(ANSI_CLEAR_LINE_TO_END);
- printf(ANSI_CURSOR_POSITION, 3, 1);
- /* First 3 lines are bootmgr_menu header + 2 empty lines between entries */
- printf(ANSI_CURSOR_POSITION, bootmgr_menu->count + 5, 1);
- printf(ANSI_CURSOR_POSITION, bootmgr_menu->count + 6, 1);
- puts(" Press UP/DOWN to move, ENTER to select, ESC/CTRL+C to quit");
- printf(ANSI_CURSOR_POSITION, bootmgr_menu->count + 7, 1);
- int i;
- int esc = 0;
- struct efi_bootmenu_entry *iter;
- enum bootmenu_key key = KEY_NONE;
- struct efi_bootmenu *bootmgr_menu = data;
- while (1) {
} else {
key = KEY_QUIT;
switch (key) {
case KEY_UP:
return NULL;
case KEY_DOWN:
return NULL;
case KEY_SELECT:
iter = iter->next;
return iter->key;
case KEY_QUIT:
while (iter->next)
iter = iter->next;
return iter->key;
default:
break;
I don't fully understand how bootmenu works with key strokes, but I think that this kind of key handling is quite generic and put it as a common helper function.
- /* never happens */
- debug("bootmgr menu: this should not happen");
- return NULL;
- struct efi_bootmenu_entry *iter = bootmgr_menu->first;
- while (iter) {
next = iter->next;
free(iter);
iter = next;
- free(bootmgr_menu);
- efi_bootmenu_process_common() - main handler for uefi bootmgr menu
- Construct the structures required to show the menu, then handle
- the user input intracting with u-boot menu functions.
- @items: pointer to the structure of each menu entry
- @count: the number of menu entry
- @delay: delay for autoboot/autoselect
- Return: status code
- u32 i;
- bool exit = false;
- efi_status_t ret;
- struct menu *menu;
- void *choice = NULL;
- struct efi_bootmenu_entry *iter = NULL;
- if (count > EFI_BOOTMENU_ENTRY_NUM_MAX)
- bootmgr_menu = calloc(1, sizeof(struct efi_bootmenu));
- if (!bootmgr_menu)
- bootmgr_menu->delay = delay;
- bootmgr_menu->active = 0;
- bootmgr_menu->first = NULL;
- for (i = 0; i < count; i++) {
if (!entry) {
goto out;
entry->num = i;
entry->next = NULL;
if (!iter)
else
iter->next = entry;
iter = entry;
items++;
- bootmgr_menu->count = count;
- menu = menu_create(NULL, 0, 1, efi_bootmenu_display_statusline,
bootmgr_menu);
- if (!menu) {
goto out;
- for (entry = bootmgr_menu->first; entry; entry = entry->next) {
goto out;
- menu_default_set(menu, bootmgr_menu->first->key);
- while (!exit) {
entry = choice;
if (entry->func)
ret = EFI_ABORTED;
break;
+out:
- menu_destroy(menu);
- efi_bootmenu_destroy(bootmgr_menu);
- puts(ANSI_CLEAR_CONSOLE);
- puts(ANSI_CURSOR_SHOW);
- return ret;
- struct efi_bootmenu_volume_entry_data *info = data;
- *exit = true;
- if (info) {
- return EFI_SUCCESS;
- struct efi_bootmenu_file_entry_data *info = data;
- *exit = true;
- if (!info)
- if (u16_strcmp(info->file_name, u".") == 0 &&
- } else if (u16_strcmp(info->file_name, u"..") == 0 &&
int is_last;
if (is_last) {
free(iter->name);
free(iter);
break;
u16_strlcat(info->bo->current_path, u"\\",
- } else {
size_t new_len;
if (!filepath)
free(filepath);
* Remainig buffer should have enough space to contain u"\\" and
} else {
- u32 i;
- efi_status_t ret;
- efi_uintn_t count;
- struct efi_handler *handler;
- struct efi_device_path *device_path;
- efi_handle_t *volume_handles = NULL;
- struct efi_bootmenu_item *menu_item, *iter;
- ret = efi_locate_handle_buffer_int(BY_PROTOCOL, &efi_simple_file_system_protocol_guid,
- if (ret != EFI_SUCCESS)
return ret;
- menu_item = calloc(count + 1, sizeof(struct efi_bootmenu_item));
- if (!menu_item) {
goto out1;
- iter = menu_item;
u16 *dev_name, *p;
continue;
continue;
continue;
continue;
continue;
continue;
if (!info) {
goto out2;
if (!dev_name) {
free(info);
goto out2;
p = dev_name;
info->v = v;
info->bo = bo;
iter->data = info;
iter++;
- iter->title = u16_strdup(u"Quit");
- iter->func = NULL;
- iter->data = NULL;
- count += 1;
- ret = efi_bootmenu_process_common(menu_item, count, -1);
+out2:
- iter = menu_item;
free(iter->title);
free(p);
iter++;
- free(menu_item);
+out1:
- efi_free_pool(volume_handles);
- return ret;
- u32 i;
- struct efi_file_info *buf;
- u32 count = 0;
- efi_uintn_t len;
- efi_status_t ret;
- struct efi_file_handle *f;
- buf = calloc(1, sizeof(struct efi_file_info) + EFI_BOOTMENU_FILE_PATH_BUF_SIZE);
- if (!buf)
- while (!bo->file_selected) {
count = 0;
return ret;
for (;;) {
break;
count++;
if (!menu_item) {
goto out;
iter = menu_item;
u16 *name;
int name_len;
goto err;
if (!info) {
goto err;
if (!name) {
goto err;
} else {
if (!name) {
goto err;
info->bo = bo;
iter->title = name;
iter->data = info;
iter++;
iter->func = NULL;
iter->data = NULL;
count += 1;
+err:
iter = menu_item;
free(iter->title);
free(iter->data);
free(menu_item);
break;
+out:
- free(buf);
- return ret;
- efi_status_t ret;
- puts(" *** U-Boot EFI Boot Manager Menu ***");
- printf(ANSI_CURSOR_POSITION, 4, 1);
- puts(" enter name:");
- printf(ANSI_CURSOR_POSITION, 8, 1);
- puts(" ENTER to complete, ESC/CTRL+C to quit");
- ret = efi_console_get_u16_string(cin, cout, bo->boot_name,
- return ret;
I prefer to see a menu like: BOOTxxxx title: file: option(arguments): set: cancel: rather than being prompted one by one.
Then users can select any of items in arbitrary order to define them or to quit the menu.
This way, the same menu can be re-used to *modify* an existing entry.
- efi_status_t ret;
- struct efi_file_handle *root;
- bo->file_selected = false;
return ret;
return ret;
return ret;
- ret = efi_bootmenu_boot_add_enter_name(bo);
- return ret;
- u32 i;
- efi_status_t ret;
- efi_uintn_t size;
- if (buf_size < u16_strsize(u"Boot####"))
- for (i = 0; i <= 0xFFFF; i++) {
size = 0;
continue;
else
break;
- if (i > 0xFFFF)
- *index = i;
- void *p = NULL;
- efi_status_t ret;
- efi_uintn_t size;
- struct efi_load_option lo;
- lo.file_path = dp;
- lo.file_path_length = efi_dp_size(dp) + sizeof(END);
- lo.attributes = LOAD_OPTION_ACTIVE;
- lo.optional_data = optional_data;
- lo.label = label;
- size = efi_serialize_load_option(&lo, (u8 **)&p);
- if (!size)
- ret = efi_set_variable_int(var_name, &efi_global_variable_guid,
size, p, false);
- free(p);
- return ret;
- u16 *bootorder;
- efi_status_t ret;
- u16 *new_bootorder = NULL;
- efi_uintn_t last, size, new_size;
- /* append new boot option */
- bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size);
- last = size / sizeof(u16);
- new_size = size + sizeof(u16);
- new_bootorder = calloc(1, new_size);
- if (!new_bootorder) {
goto out;
- memcpy(new_bootorder, bootorder, size);
- new_bootorder[last] = index;
- ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid,
goto out;
+out:
- free(bootorder);
- free(new_bootorder);
- return ret;
- u32 index;
- u16 var_name[9];
- char *buf = NULL;
- efi_status_t ret;
- char *iter = NULL;
- struct list_head *pos, *n;
- efi_uintn_t dp_size, fp_size;
- struct efi_bootmenu_boot_option bo;
- struct efi_device_path_file_path *fp;
- struct efi_bootmenu_filepath_info *item;
- ret = efi_bootmenu_get_unused_bootoption(var_name, sizeof(var_name),
&index);
return ret;
- bo.current_path = calloc(1, EFI_BOOTMENU_FILE_PATH_BUF_SIZE);
- if (!bo.current_path)
goto out;
- bo.boot_name = calloc(1, EFI_BOOTMENU_BOOT_NAME_MAX * sizeof(u16));
- if (!bo.boot_name)
goto out;
- INIT_LIST_HEAD(&bo.filepath_list);
- ret = efi_bootmenu_select_file_handler(&bo);
goto out;
- dp_size = efi_dp_size(bo.dp_volume);
- fp_size = sizeof(struct efi_device_path) +
- buf = calloc(1, dp_size + fp_size + sizeof(END));
- if (!buf)
goto out;
- iter = buf;
- memcpy(iter, bo.dp_volume, dp_size);
- iter += dp_size;
- fp = (struct efi_device_path_file_path *)iter;
- fp->dp.type = DEVICE_PATH_TYPE_MEDIA_DEVICE;
- fp->dp.sub_type = DEVICE_PATH_SUB_TYPE_FILE_PATH;
- fp->dp.length = (u16)fp_size;
- u16_strcpy(fp->str, bo.current_path);
- iter += fp_size;
- *((struct efi_device_path *)iter) = END;
- ret = efi_bootmenu_set_boot_option(var_name, (struct efi_device_path *)buf,
goto out;
- efi_bootmenu_append_bootorder((u16)index);
goto out;
This if statement doesn't make sense.
+out:
- free(buf);
- free(bo.boot_name);
- free(bo.current_path);
- list_for_each_safe(pos, n, &bo.filepath_list) {
free(item->name);
free(item);
- return ret;
- efi_status_t ret;
- ret = efi_search_protocol(efi_root, &efi_guid_text_input_protocol, &handler);
return ret;
- ret = efi_protocol_open(handler, (void **)&cin, efi_root, NULL,
return ret;
- ret = efi_search_protocol(efi_root, &efi_guid_text_output_protocol, &handler);
return ret;
- ret = efi_protocol_open(handler, (void **)&cout, efi_root, NULL,
return ret;
- return ret;
- {u"Add Boot Option", efi_bootmenu_process_add_boot_option},
- {u"Quit", NULL},
- efi_status_t ret;
- ret = efi_bootmenu_init();
return ret;
- return efi_bootmenu_process_common(maintenance_menu_items,
-1);
- efi_status_t r;
goto out;
- *no_handles = 0;
- *buffer = NULL;
*buffer);
goto out;
(void **)buffer);
goto out;
*buffer);
+out:
- return r;
- efi_locate_handle_buffer() - locate handles implementing a protocol
- @search_type: selection criterion
goto out;
*no_handles = 0;
*buffer = NULL;
*buffer);
goto out;
(void **)buffer);
goto out;
*buffer);
-out:
- r = efi_locate_handle_buffer_int(search_type, protocol, search_key,
- return EFI_EXIT(r);
- Copyright (c) 2016 Alexander Graf
- efi_console_get_u16_string() - get user input string
- @cin: protocol interface to EFI_SIMPLE_TEXT_INPUT_PROTOCOL
- @cout: protocol interface to EFI_SIMPLE_TEXT_OUTPUT_PROTOCOL
- @buf: buffer to store user input string in UTF16
- @size: buffer size including NULL terminator
- @filter_func: callback to filter user input
- @row: row number to locate user input form
- @col: column number to locate user input form
int row, int col)
- efi_status_t ret;
- efi_uintn_t len = 0;
- struct efi_input_key key;
- printf(ANSI_CURSOR_POSITION, row, col);
- ret = EFI_CALL(cin->reset(cin, false));
return ret;
- for (;;) {
do {
mdelay(10);
if (len > 0)
buf[--len] = u'\0';
return ret;
continue;
continue;
buf[len] = u'\0';
return EFI_SUCCESS;
return EFI_ABORTED;
continue;
continue;
if (filter_func) {
continue;
continue;
len++;
return ret;
- struct efi_disk_obj *diskobj;
- diskobj = container_of(this, struct efi_disk_obj, ops);
- snprintf(buf, size, "%s %d:%d", diskobj->ifname, diskobj->dev_index, diskobj->part);
Please note that not all the BLOCK_IO interfaces have corresponding diskobj's, in particular, efi_driver/efi_block_device.c.
-Takahiro Akashi
u64 attributes)
u64 attributes)
- return file_close(fh);
- return EFI_EXIT(efi_file_close_int(file));
- efi_file_setpos() - set current position in file
- This function implements the SetPosition service of the EFI file protocol.
- See the UEFI spec for details.
- @file: file handle
- @pos: new file position
u64 pos)
error:
- return ret;
u64 pos)
- efi_status_t ret = EFI_SUCCESS;
- ret = efi_file_setpos_int(file, pos);
- return EFI_EXIT(ret);
- return EFI_EXIT(efi_open_volume_int(this, root));
2.17.1
Changes in v6:
- fix typos
Is this correct?
Changes in v5:
Chanes in v4:
Changes in RFC v2:
free(load_option);
if (!entry)
goto cleanup;
free(entry);
goto cleanup;
free(entry->title);
free(entry);
goto cleanup;
entry->num = i;
entry->menu = menu;
entry->next = NULL;
if (!iter)
else
iter->next = entry;
iter = entry;
i++;
goto cleanup;
int ret;
- while (1) {
delay = -1;
break;
- return 0; }
- /* Key identifying current memory map */ extern efi_uintn_t efi_memory_map_key;
u64 attributes);
int row, int col);
- #endif /* _EFI_LOADER_H */
- @key: unique key
- u32 num;
- u16 *title;
- char key[6];
- void *data;
- int delay;
- int active;
- int count;
- u16 *title;
- void *data;
- int *selected;
- u16 *name;
- u16 *boot_name;
- u16 *file_name;
- else
- puts(" ");
Code size of U-Boot is critical on many board. Please, minimize the number of function calls. You can set the column number in the printf statement above.
- if (reverse)
- if (reverse)
The if is not strictly needed. Just add ANSI_COLOR_RESET to the printf statement above.
return;
Please, minimize the number of function calls. This can be a single printf() call instread of 14 function invocations.
Best regards
Heinrich
- int i;
- int esc = 0;
- while (1) {
} else {
key = KEY_QUIT;
switch (key) {
case KEY_UP:
return NULL;
case KEY_DOWN:
return NULL;
case KEY_SELECT:
iter = iter->next;
return iter->key;
case KEY_QUIT:
while (iter->next)
iter = iter->next;
return iter->key;
default:
break;
- return NULL;
- while (iter) {
next = iter->next;
free(iter);
iter = next;
- u32 i;
- efi_status_t ret;
if (!entry) {
goto out;
entry->num = i;
entry->next = NULL;
if (!iter)
else
iter->next = entry;
iter = entry;
items++;
bootmgr_menu);
- if (!menu) {
goto out;
goto out;
- while (!exit) {
entry = choice;
if (entry->func)
ret = EFI_ABORTED;
break;
+out:
- return ret;
- *exit = true;
- if (info) {
- *exit = true;
- if (!info)
int is_last;
if (is_last) {
free(iter->name);
free(iter);
break;
- } else {
size_t new_len;
if (!filepath)
free(filepath);
} else {
- u32 i;
- efi_status_t ret;
return ret;
- if (!menu_item) {
goto out1;
- iter = menu_item;
u16 *dev_name, *p;
continue;
continue;
continue;
continue;
continue;
continue;
if (!info) {
goto out2;
if (!dev_name) {
free(info);
goto out2;
p = dev_name;
info->v = v;
info->bo = bo;
iter->data = info;
iter++;
- count += 1;
+out2:
- iter = menu_item;
free(iter->title);
free(p);
iter++;
- free(menu_item);
+out1:
- return ret;
- u32 i;
- u32 count = 0;
- efi_uintn_t len;
- efi_status_t ret;
- if (!buf)
count = 0;
return ret;
for (;;) {
break;
count++;
if (!menu_item) {
goto out;
iter = menu_item;
u16 *name;
int name_len;
goto err;
if (!info) {
goto err;
if (!name) {
goto err;
} else {
if (!name) {
goto err;
info->bo = bo;
iter->title = name;
iter->data = info;
iter++;
iter->func = NULL;
iter->data = NULL;
count += 1;
+err:
iter = menu_item;
free(iter->title);
free(iter->data);
free(menu_item);
break;
+out:
- free(buf);
- return ret;
- efi_status_t ret;
- return ret;
- efi_status_t ret;
return ret;
return ret;
return ret;
- return ret;
- u32 i;
- efi_status_t ret;
- efi_uintn_t size;
size = 0;
continue;
else
break;
- if (i > 0xFFFF)
- *index = i;
- void *p = NULL;
- efi_status_t ret;
- efi_uintn_t size;
- lo.label = label;
- if (!size)
size, p, false);
- free(p);
- return ret;
- u16 *bootorder;
- efi_status_t ret;
goto out;
goto out;
+out:
- free(bootorder);
- return ret;
- u32 index;
- u16 var_name[9];
- char *buf = NULL;
- efi_status_t ret;
&index);
return ret;
goto out;
goto out;
goto out;
- if (!buf)
goto out;
- iter = buf;
- iter += dp_size;
- iter += fp_size;
goto out;
goto out;
+out:
- free(buf);
free(item->name);
free(item);
- return ret;
- efi_status_t ret;
return ret;
return ret;
return ret;
return ret;
- return ret;
- {u"Quit", NULL},
- efi_status_t ret;
return ret;
-1);
- efi_status_t r;
goto out;
- *no_handles = 0;
- *buffer = NULL;
*buffer);
goto out;
(void **)buffer);
goto out;
*buffer);
+out:
- return r;
goto out;
*no_handles = 0;
*buffer = NULL;
*buffer);
goto out;
(void **)buffer);
goto out;
*buffer);
-out:
- return EFI_EXIT(r); }
int row, int col)
- efi_status_t ret;
return ret;
- for (;;) {
do {
mdelay(10);
if (len > 0)
buf[--len] = u'\0';
return ret;
continue;
continue;
buf[len] = u'\0';
return EFI_SUCCESS;
return EFI_ABORTED;
continue;
continue;
if (filter_func) {
continue;
continue;
len++;
return ret;
-Takahiro Akashi
u64 attributes)
{ struct file_handle *fh = to_fh(this); efi_status_t ret;u64 attributes)
{ struct file_handle *fh = to_fh(this); efi_status_t ret = EFI_SUCCESS;efi_uintn_t *buffer_size, void *buffer)
u64 pos)
error:
- return ret;
u64 pos)
- return EFI_EXIT(ret); }
- static efi_status_t EFIAPI efi_open_volume(struct efi_simple_file_system_protocol *this, struct efi_file_handle **root) {
-- 2.17.1
This commit supports the menu-driven UEFI boot option addition. User can select the block device volume having efi_simple_file_system_protocol and select the file corresponding to the Boot#### variable. Then user enter the label of the BOOT#### variable in utf8.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org
Changes in v6:
- fix typos
- modify volume name to match U-Boot syntax
- compile in CONFIG_EFI_LOADER=n and CONFIG_CMD_BOOTEFI_BOOTMGR=n
Is this correct?
- simplify u16_strncmp() usage
- support "a\b.efi" file path, use link list to handle filepath
- modify length check condition
- UEFI related menu items only appears with CONFIG_AUTOBOOT_MENU_SHOW=y
Changes in v5:
- remove forward declarations
- add const qualifier for menu items
- fix the possible unaligned access for directory info access
- split into three commit 1)add boot option 2) delete boot option 3)change boot order This commit is 1)add boot option.
- fix file name buffer allocation size, it should be EFI_BOOTMENU_FILE_PATH_MAX * sizeof(u16)
- fix wrong size checking for file selection
Chanes in v4:
- UEFI boot option maintenance menu is integrated into bootmenu
- display the simplified volume name(e.g. usb0:1, nvme1:2) for the volume selection
- instead of extending lib/efi_loader/efi_bootmgr.c, newly create lib/efi_loader/efi_bootmenu_maintenance.c and implement boot variable maintenance into it.
Changes in RFC v3: not included in v3 series
Changes in RFC v2:
enable utf8 user input for boot option name
create lib/efi_loader/efi_console.c::efi_console_get_u16_string() for utf8 user input handling
use u16_strlcat instead of u16_strcat
remove the EFI_CALLs, and newly create or expose the following xxx_int() functions. efi_locate_handle_buffer_int(), efi_open_volume_int(), efi_file_open_int(), efi_file_close_int(), efi_file_read_int() and efi_file_setpos_int(). Note that EFI_CALLs still exist for EFI_DEVICE_PATH_TO_TEXT_PROTOCOL and EFI_SIMPLE_TEXT_INPUT/OUTPUT_PROTOCOL
use efi_search_protocol() instead of calling locate_protocol() to get the device_path_to_text_protocol interface.
remove unnecessary puts(ANSI_CLEAR_LINE), this patch is still depends on puts(ANSI_CLEAR_CONSOLE)
skip SetVariable() if the bootorder is not changed
cmd/bootmenu.c | 73 +- include/efi_loader.h | 37 + lib/efi_loader/Makefile | 3 + lib/efi_loader/efi_bootmenu_maintenance.c | 906 ++++++++++++++++++++++
lib/efi_loader/efi_boottime.c | 52 +- lib/efi_loader/efi_console.c | 81 ++ lib/efi_loader/efi_disk.c | 11 + lib/efi_loader/efi_file.c | 75 +- 8 files changed, 1184 insertions(+), 54 deletions(-) create mode 100644 lib/efi_loader/efi_bootmenu_maintenance.c
diff --git a/cmd/bootmenu.c b/cmd/bootmenu.c index 8859eebea5..4b846332b0 100644 --- a/cmd/bootmenu.c +++ b/cmd/bootmenu.c @@ -19,6 +19,12 @@
/* maximum bootmenu entries */ #define MAX_COUNT 99 +#if defined(CONFIG_CMD_BOOTEFI_BOOTMGR) && defined(CONFIG_AUTOBOOT_MENU_SHOW) +#define STATIC_ENTRY 2 +#else +#define STATIC_ENTRY 1 +#endif +#define MAX_DYNAMIC_ENTRY (MAX_COUNT - STATIC_ENTRY)
/* maximal size of bootmenu env
@@ -38,10 +44,11 @@ enum boot_type { BOOTMENU_TYPE_NONE = 0, BOOTMENU_TYPE_BOOTMENU, BOOTMENU_TYPE_UEFI_BOOT_OPTION,
BOOTMENU_TYPE_UEFI_MAINTENANCE, };
struct bootmenu_entry {
- unsigned short int num; /* unique number 0 .. MAX_COUNT */
@@ -55,7 +62,7 @@ static char *bootmenu_getoption(unsigned short int n) { char name[MAX_ENV_SIZE];
- if (n > MAX_COUNT)
if (n > MAX_DYNAMIC_ENTRY) return NULL;
sprintf(name, "bootmenu_%d", n);
@@ -217,7 +224,7 @@ static int prepare_bootmenu_entry(struct bootmenu_data *menu, iter = entry; ++i;
if (i == MAX_COUNT - 1)
free(load_option);
if (!entry)
goto cleanup;
free(entry);
goto cleanup;
free(entry->title);
free(entry);
goto cleanup;
entry->num = i;
entry->menu = menu;
entry->next = NULL;
if (!iter)
else
iter->next = entry;
iter = entry;
i++;
goto cleanup;
int ret;
- while (1) {
delay = -1;
break;
- return 0; }
u64 attributes);
int row, int col);
- @key: unique key
- u32 num;
- u16 *title;
- char key[6];
- void *data;
- int delay;
- int active;
- int count;
- u16 *title;
- void *data;
- int *selected;
- u16 *name;
- u16 *boot_name;
- u16 *file_name;
- else
- puts(" ");
OK.
- if (reverse)
- if (reverse)
Without this 'if' statement, ANSI_COLOR_RESET is sent every time the line is drawn. I prefer to keep this 'if' statement.
return;
OK.
Thanks, Masahisa Kojima
Best regards
Heinrich
- int i;
- int esc = 0;
- while (1) {
} else {
key = KEY_QUIT;
switch (key) {
case KEY_UP:
return NULL;
case KEY_DOWN:
return NULL;
case KEY_SELECT:
iter = iter->next;
return iter->key;
case KEY_QUIT:
while (iter->next)
iter = iter->next;
return iter->key;
default:
break;
- return NULL;
- while (iter) {
next = iter->next;
free(iter);
iter = next;
- u32 i;
- efi_status_t ret;
if (!entry) {
goto out;
entry->num = i;
entry->next = NULL;
if (!iter)
else
iter->next = entry;
iter = entry;
items++;
bootmgr_menu);
- if (!menu) {
goto out;
goto out;
- while (!exit) {
entry = choice;
if (entry->func)
ret = EFI_ABORTED;
break;
+out:
- return ret;
- *exit = true;
- if (info) {
- *exit = true;
- if (!info)
int is_last;
if (is_last) {
free(iter->name);
free(iter);
break;
- } else {
size_t new_len;
if (!filepath)
free(filepath);
} else {
- u32 i;
- efi_status_t ret;
return ret;
- if (!menu_item) {
goto out1;
- iter = menu_item;
u16 *dev_name, *p;
continue;
continue;
continue;
continue;
continue;
continue;
if (!info) {
goto out2;
if (!dev_name) {
free(info);
goto out2;
p = dev_name;
info->v = v;
info->bo = bo;
iter->data = info;
iter++;
- count += 1;
+out2:
- iter = menu_item;
free(iter->title);
free(p);
iter++;
- free(menu_item);
+out1:
- return ret;
- u32 i;
- u32 count = 0;
- efi_uintn_t len;
- efi_status_t ret;
- if (!buf)
count = 0;
return ret;
for (;;) {
break;
count++;
if (!menu_item) {
goto out;
iter = menu_item;
u16 *name;
int name_len;
goto err;
if (!info) {
goto err;
if (!name) {
goto err;
} else {
if (!name) {
goto err;
info->bo = bo;
iter->title = name;
iter->data = info;
iter++;
iter->func = NULL;
iter->data = NULL;
count += 1;
+err:
iter = menu_item;
free(iter->title);
free(iter->data);
free(menu_item);
break;
+out:
- free(buf);
- return ret;
- efi_status_t ret;
- return ret;
- efi_status_t ret;
return ret;
return ret;
return ret;
- return ret;
- u32 i;
- efi_status_t ret;
- efi_uintn_t size;
size = 0;
continue;
else
break;
- if (i > 0xFFFF)
- *index = i;
- void *p = NULL;
- efi_status_t ret;
- efi_uintn_t size;
- lo.label = label;
- if (!size)
size, p, false);
- free(p);
- return ret;
- u16 *bootorder;
- efi_status_t ret;
goto out;
goto out;
+out:
- free(bootorder);
- return ret;
- u32 index;
- u16 var_name[9];
- char *buf = NULL;
- efi_status_t ret;
&index);
return ret;
goto out;
goto out;
goto out;
- if (!buf)
goto out;
- iter = buf;
- iter += dp_size;
- iter += fp_size;
goto out;
goto out;
+out:
- free(buf);
free(item->name);
free(item);
- return ret;
- efi_status_t ret;
return ret;
return ret;
return ret;
return ret;
- return ret;
- {u"Quit", NULL},
- efi_status_t ret;
return ret;
-1);
- efi_status_t r;
goto out;
- *no_handles = 0;
- *buffer = NULL;
*buffer);
goto out;
(void **)buffer);
goto out;
*buffer);
+out:
- return r;
goto out;
*no_handles = 0;
*buffer = NULL;
*buffer);
goto out;
(void **)buffer);
goto out;
*buffer);
-out:
int row, int col)
- efi_status_t ret;
return ret;
- for (;;) {
do {
mdelay(10);
if (len > 0)
buf[--len] = u'\0';
return ret;
continue;
continue;
buf[len] = u'\0';
return EFI_SUCCESS;
return EFI_ABORTED;
continue;
continue;
if (filter_func) {
continue;
continue;
len++;
return ret;
return EFI_SUCCESS;
-Takahiro Akashi
u64 attributes)
u64 pos)
error:
- return ret;
u64 pos)
-- 2.17.1
On Wed, 25 May 2022 at 10:39, Takahiro Akashi takahiro.akashi@linaro.org wrote:
Changes in v6:
- fix typos
Is this correct?
Sorry for the lack of information. I would like to say that build test in the following configurations. - CONFIG_EFI_LOADER=n, CONFIG_CMD_BOOTEFI_BOOTMGR=n - CONFIG_EFI_LOADER=y, CONFIG_CMD_BOOTEFI_BOOTMGR=n
I agree.
Changes in v5:
Chanes in v4:
Changes in RFC v2:
- enable utf8 user input for boot option name
- create lib/efi_loader/efi_console.c::efi_console_get_u16_string() for utf8 user input handling
- use u16_strlcat instead of u16_strcat
- remove the EFI_CALLs, and newly create or expose the following xxx_int() functions. efi_locate_handle_buffer_int(), efi_open_volume_int(), efi_file_open_int(), efi_file_close_int(), efi_file_read_int() and efi_file_setpos_int(). Note that EFI_CALLs still exist for EFI_DEVICE_PATH_TO_TEXT_PROTOCOL and EFI_SIMPLE_TEXT_INPUT/OUTPUT_PROTOCOL
- use efi_search_protocol() instead of calling locate_protocol() to get the device_path_to_text_protocol interface.
- remove unnecessary puts(ANSI_CLEAR_LINE), this patch is still depends on puts(ANSI_CLEAR_CONSOLE)
- skip SetVariable() if the bootorder is not changed
OK, I will create a new command for UEFI variable maintenance.
if (n > MAX_COUNT)
if (n > MAX_DYNAMIC_ENTRY) return NULL; sprintf(name, "bootmenu_%d", n);
if (i == MAX_DYNAMIC_ENTRY) break; }
@@ -305,7 +312,7 @@ static int prepare_uefi_bootorder_entry(struct bootmenu_data *menu,
free(load_option);
@@ -341,14 +348,51 @@ static struct bootmenu_data *bootmenu_create(int delay) if (ret < 0) goto cleanup;
if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR)) {
if (i < MAX_COUNT - 1) {
if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR) && IS_ENABLED(CONFIG_AUTOBOOT_MENU_SHOW)) {
if (i < MAX_DYNAMIC_ENTRY) { ret = prepare_uefi_bootorder_entry(menu, &iter, &i); if (ret < 0 && ret != -ENOENT) goto cleanup; } }
/* Add UEFI Boot Manager Maintenance entry */
if (i <= MAX_DYNAMIC_ENTRY) {
if (!entry)
goto cleanup;
entry->title = u16_strdup(u"UEFI Boot Manager Maintenance");
OK.
if (!entry->title) {
free(entry);
goto cleanup;
entry->command = strdup("");
if (!entry->command) {
free(entry->title);
free(entry);
goto cleanup;
sprintf(entry->key, "%d", i);
entry->num = i;
entry->menu = menu;
entry->type = BOOTMENU_TYPE_UEFI_MAINTENANCE;
entry->next = NULL;
if (!iter)
else
iter->next = entry;
iter = entry;
i++;
@@ -520,6 +564,14 @@ static enum bootmenu_ret bootmenu_show(int delay) title = u16_strdup(iter->title); command = strdup(iter->command);
if (iter->type == BOOTMENU_TYPE_UEFI_MAINTENANCE) {
efi_bootmenu_show_maintenance_menu();
ret = BOOTMENU_RET_UPDATED;
goto cleanup;
@@ -610,6 +662,7 @@ int do_bootmenu(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { char *delay_str = NULL; int delay = 10;
int ret;
#if defined(CONFIG_BOOTDELAY) && (CONFIG_BOOTDELAY >= 0) delay = CONFIG_BOOTDELAY; @@ -624,7 +677,13 @@ int do_bootmenu(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) if (delay_str) delay = (int)simple_strtol(delay_str, NULL, 10);
bootmenu_show(delay);
while (1) {
ret = bootmenu_show(delay);
delay = -1;
if (ret != BOOTMENU_RET_UPDATED)
break;
diff --git a/include/efi_loader.h b/include/efi_loader.h index 733ee03cd7..49f326e585 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -226,6 +226,9 @@ const char *__efi_nesting_dec(void); #define EFI_CACHELINE_SIZE 128 #endif
+/* max bootmenu title size for volume selection */ +#define BOOTMENU_DEVICE_NAME_MAX 16
@@ -314,6 +317,9 @@ extern const efi_guid_t efi_guid_firmware_management_protocol; extern const efi_guid_t efi_esrt_guid; /* GUID of the SMBIOS table */ extern const efi_guid_t smbios_guid; +/*GUID of console */ +extern const efi_guid_t efi_guid_text_input_protocol; +extern const efi_guid_t efi_guid_text_output_protocol;
extern char __efi_runtime_start[], __efi_runtime_stop[]; extern char __efi_runtime_rel_start[], __efi_runtime_rel_stop[]; @@ -877,6 +883,8 @@ efi_status_t efi_set_load_options(efi_handle_t handle, void *load_options); efi_status_t efi_bootmgr_load(efi_handle_t *handle, void **load_options);
+efi_status_t efi_bootmenu_show_maintenance_menu(void);
@@ -1048,4 +1056,33 @@ efi_status_t efi_esrt_populate(void); efi_status_t efi_load_capsule_drivers(void);
efi_status_t platform_get_eventlog(struct udevice *dev, u64 *addr, u32 *sz);
efi_uintn_t *no_handles, efi_handle_t **buffer);
struct efi_file_handle **root);
u64 attributes);
+efi_status_t efi_file_close_int(struct efi_file_handle *file); +efi_status_t efi_file_read_int(struct efi_file_handle *this,
efi_uintn_t *buffer_size, void *buffer);
+efi_status_t efi_file_setpos_int(struct efi_file_handle *file, u64 pos);
+typedef efi_status_t (*efi_console_filter_func)(struct efi_input_key *key); +efi_status_t efi_console_get_u16_string
u16 *buf, efi_uintn_t count, efi_console_filter_func filer_func,
int row, int col);
efi_uintn_t buf_size, u32 *index);
+efi_status_t efi_bootmenu_append_bootorder(u16 index);
+efi_status_t efi_disk_get_device_name(struct efi_block_io *this, char *buf, int size);
#endif /* _EFI_LOADER_H */ diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index aaaa25cefe..807e9a4319 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -77,6 +77,9 @@ obj-$(CONFIG_EFI_TCG2_PROTOCOL) += efi_tcg2.o obj-$(CONFIG_EFI_RISCV_BOOT_PROTOCOL) += efi_riscv.o obj-$(CONFIG_EFI_LOAD_FILE2_INITRD) += efi_load_initrd.o obj-$(CONFIG_EFI_SIGNATURE_SUPPORT) += efi_signature.o +ifeq ($(CONFIG_CMD_BOOTEFI_BOOTMGR),y) +obj-$(CONFIG_CMD_BOOTMENU) += efi_bootmenu_maintenance.o +endif
EFI_VAR_SEED_FILE := $(subst $",,$(CONFIG_EFI_VAR_SEED_FILE)) $(obj)/efi_var_seed.o: $(srctree)/$(EFI_VAR_SEED_FILE) diff --git a/lib/efi_loader/efi_bootmenu_maintenance.c b/lib/efi_loader/efi_bootmenu_maintenance.c new file mode 100644 index 0000000000..e5124a8a21 --- /dev/null +++ b/lib/efi_loader/efi_bootmenu_maintenance.c @@ -0,0 +1,906 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#define LOG_CATEGORY LOGC_EFI
+#include <ansi.h> +#include <common.h> +#include <charset.h> +#include <log.h> +#include <malloc.h> +#include <menu.h> +#include <efi_loader.h> +#include <efi_variable.h> +#include <asm/unaligned.h>
+static struct efi_simple_text_input_protocol *cin; +static struct efi_simple_text_output_protocol *cout;
+#define EFI_BOOTMENU_ENTRY_NUM_MAX 99 +#define EFI_BOOTMENU_FILE_PATH_MAX 512 +#define EFI_BOOTMENU_FILE_PATH_BUF_SIZE (EFI_BOOTMENU_FILE_PATH_MAX * sizeof(u16)) +#define EFI_BOOTMENU_BOOT_NAME_MAX 32 +#define EFI_BOOT_ORDER_MAX_SIZE_IN_DECIMAL 6
+typedef efi_status_t (*efi_bootmenu_entry_func)(void *data, bool *exit);
- @key: unique key
+struct efi_bootmenu_entry {
u32 num;
u16 *title;
char key[6];
void *data;
+struct efi_bootmenu {
int delay;
int active;
int count;
+struct efi_bootmenu_item {
u16 *title;
void *data;
+struct efi_bootmenu_boot_selection_data {
void *load_option;
int *selected;
+struct efi_bootmenu_filepath_info {
u16 *name;
+struct efi_bootmenu_boot_option {
u16 *current_path;
u16 *boot_name;
bool file_selected;
+static const struct efi_device_path END = {
OK, I will move 'END' to the common include file.
+struct efi_bootmenu_volume_entry_data {
+struct efi_bootmenu_file_entry_data {
bool is_directory;
u16 *file_name;
+static void efi_bootmenu_print_entry(void *data) +{
* Move cursor to line where the entry will be drawn (entry->count)
* First 3 lines contain bootmgr menu header + one empty line
* For the last "Quit" entry, add one empty line
printf(ANSI_CURSOR_POSITION, entry->num + 5, 1);
else
printf(ANSI_CURSOR_POSITION, entry->num + 4, 1);
puts(" ");
if (reverse)
puts(ANSI_COLOR_REVERSE);
if (reverse)
puts(ANSI_COLOR_RESET);
+static void efi_bootmenu_display_statusline(struct menu *m) +{
return;
+static char *efi_bootmenu_choice_entry(void *data) +{
int i;
int esc = 0;
while (1) {
if (bootmgr_menu->delay >= 0) {
/* Autoboot was not stopped */
bootmenu_autoboot_loop((struct bootmenu_data *)bootmgr_menu, &key, &esc);
} else {
/* Some key was pressed, so autoboot was stopped */
bootmenu_loop((struct bootmenu_data *)bootmgr_menu, &key, &esc);
if (bootmgr_menu->delay == 0)
key = KEY_QUIT;
switch (key) {
case KEY_UP:
if (bootmgr_menu->active > 0)
--bootmgr_menu->active;
/* no menu key selected, regenerate menu */
return NULL;
case KEY_DOWN:
if (bootmgr_menu->active < bootmgr_menu->count - 1)
++bootmgr_menu->active;
return NULL;
case KEY_SELECT:
for (i = 0; i < bootmgr_menu->active; ++i)
iter = iter->next;
return iter->key;
case KEY_QUIT:
/* Quit by choosing the last entry */
while (iter->next)
iter = iter->next;
return iter->key;
default:
break;
I will consider moving this function to common.
/* never happens */
return NULL;
+static void efi_bootmenu_destroy(struct efi_bootmenu *bootmgr_menu) +{
while (iter) {
next = iter->next;
free(iter);
iter = next;
free(bootmgr_menu);
+static efi_status_t efi_bootmenu_process_common(const struct efi_bootmenu_item *items,
int count, int delay)
u32 i;
bool exit = false;
efi_status_t ret;
struct menu *menu;
if (!bootmgr_menu)
entry = calloc(1, sizeof(struct efi_bootmenu_entry));
if (!entry) {
ret = EFI_LOAD_ERROR;
goto out;
entry->num = i;
entry->title = items->title;
snprintf(entry->key, sizeof(entry->key), "%04X", i);
entry->bootmgr_menu = bootmgr_menu;
entry->func = items->func;
entry->data = items->data;
entry->next = NULL;
if (!iter)
bootmgr_menu->first = entry;
else
iter->next = entry;
iter = entry;
items++;
efi_bootmenu_print_entry, efi_bootmenu_choice_entry,
bootmgr_menu);
if (!menu) {
ret = EFI_INVALID_PARAMETER;
goto out;
if (!menu_item_add(menu, entry->key, entry)) {
goto out;
while (!exit) {
puts(ANSI_CURSOR_HIDE);
if (menu_get_choice(menu, &choice)) {
entry = choice;
if (entry->func)
ret = entry->func(entry->data, &exit);
/* last entry "Quit" is selected, exit this menu */
if (entry->num == (entry->bootmgr_menu->count - 1)) {
ret = EFI_ABORTED;
break;
+out:
menu_destroy(menu);
return ret;
*exit = true;
if (info) {
return EFI_SUCCESS;
*exit = true;
if (!info)
int is_last;
if (is_last) {
free(iter->name);
free(iter);
break;
} else {
size_t new_len;
if (!filepath)
free(filepath);
} else {
return EFI_SUCCESS;
u32 i;
efi_status_t ret;
efi_uintn_t count;
return ret;
if (!menu_item) {
goto out1;
iter = menu_item;
u16 *dev_name, *p;
continue;
continue;
continue;
continue;
continue;
continue;
if (!info) {
goto out2;
if (!dev_name) {
free(info);
goto out2;
p = dev_name;
info->v = v;
info->bo = bo;
iter->data = info;
iter++;
iter->func = NULL;
iter->data = NULL;
count += 1;
+out2:
iter = menu_item;
free(iter->title);
free(p);
iter++;
free(menu_item);
+out1:
return ret;
u32 i;
u32 count = 0;
efi_uintn_t len;
efi_status_t ret;
if (!buf)
count = 0;
return ret;
for (;;) {
break;
count++;
if (!menu_item) {
goto out;
iter = menu_item;
u16 *name;
int name_len;
goto err;
if (!info) {
goto err;
if (!name) {
goto err;
} else {
if (!name) {
goto err;
info->bo = bo;
iter->title = name;
iter->data = info;
iter++;
iter->func = NULL;
iter->data = NULL;
count += 1;
+err:
iter = menu_item;
free(iter->title);
free(iter->data);
free(menu_item);
break;
+out:
free(buf);
return ret;
efi_status_t ret;
return ret;
I agree, I will implement like you suggested.
efi_status_t ret;
return ret;
return ret;
return ret;
return ret;
u32 i;
efi_status_t ret;
efi_uintn_t size;
size = 0;
continue;
else
break;
if (i > 0xFFFF)
*index = i;
return EFI_SUCCESS;
void *p = NULL;
efi_status_t ret;
efi_uintn_t size;
lo.file_path = dp;
lo.label = label;
if (!size)
size, p, false);
free(p);
return ret;
u16 *bootorder;
efi_status_t ret;
goto out;
goto out;
+out:
free(bootorder);
return ret;
u32 index;
u16 var_name[9];
char *buf = NULL;
efi_status_t ret;
char *iter = NULL;
&index);
return ret;
goto out;
if (!bo.boot_name)
goto out;
goto out;
if (!buf)
goto out;
iter = buf;
iter += dp_size;
iter += fp_size;
goto out;
goto out;
OK.
+out:
free(buf);
free(bo.boot_name);
free(item->name);
free(item);
return ret;
efi_status_t ret;
return ret;
return ret;
return ret;
return ret;
return ret;
{u"Quit", NULL},
efi_status_t ret;
return ret;
-1);
efi_status_t r;
goto out;
*no_handles = 0;
*buffer = NULL;
*buffer);
goto out;
(void **)buffer);
goto out;
*buffer);
+out:
return r;
efi_uintn_t buffer_size = 0; EFI_ENTRY("%d, %pUs, %p, %p, %p", search_type, protocol, search_key, no_handles, buffer);
goto out;
*no_handles = 0;
*buffer = NULL;
*buffer);
goto out;
(void **)buffer);
goto out;
*buffer);
-out:
return EFI_EXIT(r);
int row, int col)
efi_status_t ret;
return ret;
for (;;) {
do {
mdelay(10);
if (len > 0)
buf[--len] = u'\0';
return ret;
continue;
continue;
buf[len] = u'\0';
return EFI_SUCCESS;
return EFI_ABORTED;
continue;
continue;
if (filter_func) {
continue;
continue;
len++;
return ret;
return EFI_SUCCESS;
return EFI_SUCCESS;
I will check the case that bootmenu starts EFI application using efi_driver/efi_block_device.c, then returns to bootmenu.
-Takahiro Akashi
u64 attributes)
u64 attributes)
u64 pos)
error:
return ret;
u64 pos)
return EFI_SUCCESS;
2.17.1
Hi Akashi-san,
On Mon, 6 Jun 2022 at 09:39, Masahisa Kojima masahisa.kojima@linaro.org wrote:
Changes in v6:
- fix typos
Is this correct?
I agree.
Changes in v5:
Chanes in v4:
Changes in RFC v2:
if (n > MAX_COUNT)
free(load_option);
if (!entry)
goto cleanup;
OK.
free(entry);
goto cleanup;
free(entry->title);
free(entry);
goto cleanup;
entry->num = i;
entry->menu = menu;
entry->next = NULL;
if (!iter)
else
iter->next = entry;
iter = entry;
i++;
goto cleanup;
int ret;
while (1) {
delay = -1;
break;
u64 attributes);
int row, int col);
- @key: unique key
u32 num;
u16 *title;
char key[6];
void *data;
int delay;
int active;
int count;
u16 *title;
void *data;
void *load_option;
int *selected;
u16 *name;
u16 *current_path;
u16 *boot_name;
bool file_selected;
bool is_directory;
u16 *file_name;
else
puts(" ");
if (reverse)
if (reverse)
return;
int i;
int esc = 0;
while (1) {
} else {
key = KEY_QUIT;
switch (key) {
case KEY_UP:
return NULL;
case KEY_DOWN:
return NULL;
case KEY_SELECT:
iter = iter->next;
return iter->key;
case KEY_QUIT:
while (iter->next)
iter = iter->next;
return iter->key;
default:
break;
/* never happens */
return NULL;
while (iter) {
next = iter->next;
free(iter);
iter = next;
free(bootmgr_menu);
u32 i;
bool exit = false;
efi_status_t ret;
struct menu *menu;
if (!bootmgr_menu)
if (!entry) {
goto out;
entry->num = i;
entry->next = NULL;
if (!iter)
else
iter->next = entry;
iter = entry;
items++;
bootmgr_menu);
if (!menu) {
goto out;
goto out;
while (!exit) {
entry = choice;
if (entry->func)
ret = EFI_ABORTED;
break;
+out:
menu_destroy(menu);
return ret;
+static efi_status_t efi_bootmenu_volume_selected(void *data, bool *exit) +{
*exit = true;
if (info) {
info->bo->current_volume = info->v;
info->bo->dp_volume = info->dp;
return EFI_SUCCESS;
+static efi_status_t efi_bootmenu_file_selected(void *data, bool *exit) +{
*exit = true;
if (!info)
u16_strlen(info->file_name) == 1) {
/* stay current path */
u16_strlen(info->file_name) == 2) {
struct efi_bootmenu_filepath_info *iter;
int is_last;
memset(info->bo->current_path, 0, EFI_BOOTMENU_FILE_PATH_BUF_SIZE);
list_for_each_safe(pos, n, &info->bo->filepath_list) {
iter = list_entry(pos, struct efi_bootmenu_filepath_info, list);
is_last = list_is_last(&iter->list, &info->bo->filepath_list);
if (is_last) {
list_del(&iter->list);
free(iter->name);
free(iter);
break;
u16_strlcat(info->bo->current_path, iter->name,
EFI_BOOTMENU_FILE_PATH_MAX);
} else {
size_t new_len;
struct efi_bootmenu_filepath_info *filepath;
new_len = u16_strlen(info->bo->current_path) +
u16_strlen(info->file_name);
if (new_len >= EFI_BOOTMENU_FILE_PATH_MAX) {
/* TODO: show error notification to user */
log_err("file path is too long\n");
u16_strlcat(info->bo->current_path, info->file_name,
filepath = calloc(1, sizeof(struct efi_bootmenu_filepath_info));
if (!filepath)
filepath->name = u16_strdup(info->file_name);
if (!filepath->name) {
free(filepath);
list_add_tail(&filepath->list, &info->bo->filepath_list);
if (info->is_directory) {
* at least one character for file name
if (new_len + 2 >= EFI_BOOTMENU_FILE_PATH_MAX) {
log_err("directory path is too long\n");
} else {
info->bo->file_selected = true;
return EFI_SUCCESS;
+static efi_status_t efi_bootmenu_select_volume(struct efi_bootmenu_boot_option *bo) +{
u32 i;
efi_status_t ret;
efi_uintn_t count;
NULL, &count, (efi_handle_t **)&volume_handles);
return ret;
if (!menu_item) {
goto out1;
iter = menu_item;
u16 *dev_name, *p;
struct efi_block_io *block_io;
char buf[BOOTMENU_DEVICE_NAME_MAX];
struct efi_bootmenu_volume_entry_data *info;
ret = efi_search_protocol(volume_handles[i],
&efi_simple_file_system_protocol_guid, &handler);
continue;
ret = efi_protocol_open(handler, (void **)&v, efi_root, NULL,
continue;
ret = efi_search_protocol(volume_handles[i], &efi_guid_device_path, &handler);
continue;
ret = efi_protocol_open(handler, (void **)&device_path,
efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL);
continue;
ret = efi_search_protocol(volume_handles[i], &efi_block_io_guid, &handler);
continue;
ret = efi_protocol_open(handler, (void **)&block_io,
continue;
info = calloc(1, sizeof(struct efi_bootmenu_volume_entry_data));
if (!info) {
goto out2;
efi_disk_get_device_name(block_io, buf, BOOTMENU_DEVICE_NAME_MAX);
dev_name = calloc(1, (strlen(buf) + 1) * sizeof(u16));
if (!dev_name) {
free(info);
goto out2;
p = dev_name;
utf8_utf16_strncpy(&p, buf, strlen(buf));
info->v = v;
info->dp = device_path;
info->bo = bo;
iter->title = dev_name;
iter->func = efi_bootmenu_volume_selected;
iter->data = info;
iter++;
iter->func = NULL;
iter->data = NULL;
count += 1;
+out2:
iter = menu_item;
struct efi_bootmenu_volume_entry_data *p;
p = (struct efi_bootmenu_volume_entry_data *)(iter->data);
free(iter->title);
free(p);
iter++;
free(menu_item);
+out1:
return ret;
+static efi_status_t efi_bootmenu_select_file(struct efi_bootmenu_boot_option *bo,
struct efi_file_handle *root)
u32 i;
u32 count = 0;
efi_uintn_t len;
efi_status_t ret;
if (!buf)
count = 0;
ret = efi_file_open_int(root, &f, bo->current_path, EFI_FILE_MODE_READ, 0);
return ret;
/* calculate directory information total count */
for (;;) {
len = sizeof(struct efi_file_info) + EFI_BOOTMENU_FILE_PATH_BUF_SIZE;
ret = efi_file_read_int(f, &len, buf);
if (ret != EFI_SUCCESS || len == 0)
break;
count++;
if (!menu_item) {
efi_file_close_int(f);
goto out;
/* read directory and construct menu structure */
efi_file_setpos_int(f, 0);
iter = menu_item;
u16 *name;
int name_len;
struct efi_bootmenu_file_entry_data *info;
goto err;
info = calloc(1, sizeof(struct efi_bootmenu_file_entry_data));
if (!info) {
goto err;
if (buf->attribute & EFI_FILE_DIRECTORY) {
/* append u'/' at the end of directory name */
name_len = u16_strsize(buf->file_name) + sizeof(u16);
name = calloc(1, name_len);
if (!name) {
goto err;
u16_strcpy(name, buf->file_name);
name[u16_strlen(buf->file_name)] = u'/';
info->is_directory = true;
} else {
name_len = u16_strsize(buf->file_name);
if (!name) {
goto err;
info->file_name = u16_strdup(buf->file_name);
info->bo = bo;
iter->title = name;
iter->func = efi_bootmenu_file_selected;
iter->data = info;
iter++;
/* add "Quit" entry */
iter->title = u"Quit";
iter->func = NULL;
iter->data = NULL;
count += 1;
+err:
iter = menu_item;
for (i = 0; i < count - 1; i++, iter++) {
free(((struct efi_bootmenu_file_entry_data *)(iter->data))->file_name);
free(iter->title);
free(iter->data);
free(menu_item);
break;
+out:
free(buf);
return ret;
+static efi_status_t efi_bootmenu_boot_add_enter_name(struct efi_bootmenu_boot_option *bo) +{
efi_status_t ret;
EFI_BOOTMENU_BOOT_NAME_MAX, NULL, 4, 15);
return ret;
+static efi_status_t efi_bootmenu_select_file_handler(struct efi_bootmenu_boot_option *bo) +{
efi_status_t ret;
bo->current_volume = NULL;
memset(bo->current_path, 0, EFI_BOOTMENU_FILE_PATH_BUF_SIZE);
ret = efi_bootmenu_select_volume(bo);
return ret;
if (!bo->current_volume)
ret = efi_open_volume_int(bo->current_volume, &root);
return ret;
ret = efi_bootmenu_select_file(bo, root);
return ret;
return ret;
+efi_status_t efi_bootmenu_get_unused_bootoption(u16 *buf,
u32 i;
efi_status_t ret;
efi_uintn_t size;
return EFI_BUFFER_TOO_SMALL;
size = 0;
efi_create_indexed_name(buf, buf_size, "Boot", i);
ret = efi_get_variable_int(buf, &efi_global_variable_guid,
NULL, &size, NULL, NULL);
if (ret == EFI_BUFFER_TOO_SMALL)
continue;
else
break;
if (i > 0xFFFF)
return EFI_OUT_OF_RESOURCES;
*index = i;
return EFI_SUCCESS;
+static efi_status_t efi_bootmenu_set_boot_option(u16 *var_name, struct efi_device_path *dp,
u16 *label, char *optional_data)
void *p = NULL;
efi_status_t ret;
efi_uintn_t size;
lo.file_path = dp;
lo.label = label;
if (!size)
return EFI_INVALID_PARAMETER;
size, p, false);
free(p);
return ret;
+efi_status_t efi_bootmenu_append_bootorder(u16 index) +{
u16 *bootorder;
efi_status_t ret;
ret = EFI_OUT_OF_RESOURCES;
goto out;
EFI_VARIABLE_NON_VOLATILE |
EFI_VARIABLE_BOOTSERVICE_ACCESS |
EFI_VARIABLE_RUNTIME_ACCESS,
new_size, new_bootorder, false);
goto out;
+out:
free(bootorder);
return ret;
u32 index;
u16 var_name[9];
char *buf = NULL;
efi_status_t ret;
char *iter = NULL;
&index);
return ret;
goto out;
if (!bo.boot_name)
goto out;
goto out;
if (!buf)
goto out;
iter = buf;
iter += dp_size;
iter += fp_size;
goto out;
goto out;
OK.
+out:
free(buf);
free(bo.boot_name);
free(item->name);
free(item);
return ret;
efi_status_t ret;
return ret;
return ret;
return ret;
return ret;
return ret;
{u"Quit", NULL},
efi_status_t ret;
return ret;
-1);
efi_status_t r;
goto out;
*no_handles = 0;
*buffer = NULL;
*buffer);
goto out;
(void **)buffer);
goto out;
*buffer);
+out:
return r;
goto out;
*no_handles = 0;
*buffer = NULL;
*buffer);
goto out;
(void **)buffer);
goto out;
*buffer);
-out:
return EFI_EXIT(r);
int row, int col)
efi_status_t ret;
return ret;
for (;;) {
do {
mdelay(10);
if (len > 0)
buf[--len] = u'\0';
return ret;
continue;
continue;
buf[len] = u'\0';
return EFI_SUCCESS;
return EFI_ABORTED;
continue;
continue;
if (filter_func) {
continue;
continue;
len++;
return ret;
return EFI_SUCCESS;
return EFI_SUCCESS;
When I test with efi_driver/efi_block_device.c, I could get "efiloader 0:1". So it seems no problem.
-Takahiro Akashi
u64 attributes)
u64 attributes)
u64 pos)
error:
return ret;
u64 pos)
return EFI_SUCCESS;
2.17.1
This commit adds the menu-driven deletion of UEFI boot variable.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- (no update sinch v5)
changes in v5: - split into the separate patch
lib/efi_loader/efi_bootmenu_maintenance.c | 136 ++++++++++++++++++++++ 1 file changed, 136 insertions(+)
diff --git a/lib/efi_loader/efi_bootmenu_maintenance.c b/lib/efi_loader/efi_bootmenu_maintenance.c index e5124a8a21..96306cd2cc 100644 --- a/lib/efi_loader/efi_bootmenu_maintenance.c +++ b/lib/efi_loader/efi_bootmenu_maintenance.c @@ -334,6 +334,89 @@ out: return ret; }
+static efi_status_t efi_bootmenu_process_boot_selected(void *data, bool *exit) +{ + struct efi_bootmenu_boot_selection_data *info = data; + + *exit = true; + + if (info) + *info->selected = info->bootorder_index; + + return EFI_SUCCESS; +} + +static efi_status_t efi_bootmenu_show_boot_selection(u16 *bootorder, efi_uintn_t count, + int *selected) +{ + u32 i; + efi_status_t ret; + efi_uintn_t size; + void *load_option; + struct efi_load_option lo; + u16 varname[] = u"Boot####"; + struct efi_bootmenu_item *menu_item, *iter; + + menu_item = calloc(count + 1, sizeof(struct efi_bootmenu_item)); + if (!menu_item) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + + iter = menu_item; + for (i = 0; i < count; i++) { + efi_create_indexed_name(varname, sizeof(varname), + "Boot", bootorder[i]); + load_option = efi_get_var(varname, &efi_global_variable_guid, &size); + if (!load_option) + continue; + + ret = efi_deserialize_load_option(&lo, load_option, &size); + if (ret != EFI_SUCCESS) { + log_warning("Invalid load option for %ls\n", varname); + free(load_option); + continue; + } + + if (lo.attributes & LOAD_OPTION_ACTIVE) { + struct efi_bootmenu_boot_selection_data *info; + + info = calloc(1, sizeof(struct efi_bootmenu_boot_selection_data)); + if (!info) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + + info->bootorder_index = i; + info->load_option = load_option; + info->selected = selected; + iter->title = lo.label; + iter->func = efi_bootmenu_process_boot_selected; + iter->data = info; + iter++; + } + } + + /* add "Quit" entry */ + iter->title = u"Quit"; + iter->func = NULL; + iter->data = NULL; + count += 1; + + ret = efi_bootmenu_process_common(menu_item, count, -1); + +out: + iter = menu_item; + for (i = 0; i < count - 1; i++, iter++) { + free(((struct efi_bootmenu_boot_selection_data *)iter->data)->load_option); + free(iter->data); + } + + free(menu_item); + + return ret; +} + static efi_status_t efi_bootmenu_volume_selected(void *data, bool *exit) { struct efi_bootmenu_volume_entry_data *info = data; @@ -861,6 +944,58 @@ out: return ret; }
+static efi_status_t delete_boot_option(u16 *bootorder, u16 index, efi_uintn_t size) +{ + u16 var_name[9]; + efi_status_t ret; + efi_uintn_t num; + + efi_create_indexed_name(var_name, sizeof(var_name), + "Boot", bootorder[index]); + ret = efi_set_variable_int(var_name, &efi_global_variable_guid, + 0, 0, NULL, false); + if (ret != EFI_SUCCESS) { + log_err("delete boot option(%ls) failed\n", var_name); + return ret; + } + + /* update BootOrder */ + num = size / sizeof(u16); + memmove(&bootorder[index], &bootorder[index + 1], + (num - index - 1) * sizeof(u16)); + size -= sizeof(u16); + ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + size, bootorder, false); + + return ret; +} + +static efi_status_t efi_bootmenu_process_delete_boot_option(void *data, bool *exit) +{ + int selected; + u16 *bootorder; + efi_status_t ret; + efi_uintn_t num, size; + + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + if (!bootorder) { + ret = EFI_NOT_FOUND; + return ret; + } + + num = size / sizeof(u16); + ret = efi_bootmenu_show_boot_selection(bootorder, num, &selected); + if (ret == EFI_SUCCESS) + ret = delete_boot_option(bootorder, selected, size); + + free(bootorder); + + return ret; +} + static efi_status_t efi_bootmenu_init(void) { efi_status_t ret; @@ -889,6 +1024,7 @@ static efi_status_t efi_bootmenu_init(void)
static const struct efi_bootmenu_item maintenance_menu_items[] = { {u"Add Boot Option", efi_bootmenu_process_add_boot_option}, + {u"Delete Boot Option", efi_bootmenu_process_delete_boot_option}, {u"Quit", NULL}, };
This commit adds the menu-driven update of UEFI bootorder variable.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- (no update since v5)
Changes in v5: - split into the separate patch
lib/efi_loader/efi_bootmenu_maintenance.c | 102 ++++++++++++++++++++++ 1 file changed, 102 insertions(+)
diff --git a/lib/efi_loader/efi_bootmenu_maintenance.c b/lib/efi_loader/efi_bootmenu_maintenance.c index 96306cd2cc..be67fca95f 100644 --- a/lib/efi_loader/efi_bootmenu_maintenance.c +++ b/lib/efi_loader/efi_bootmenu_maintenance.c @@ -746,6 +746,56 @@ static efi_status_t efi_bootmenu_boot_add_enter_name(struct efi_bootmenu_boot_op return ret; }
+static efi_status_t allow_decimal(struct efi_input_key *key) +{ + if (u'0' <= key->unicode_char && key->unicode_char <= u'9') + return EFI_SUCCESS; + + return EFI_INVALID_PARAMETER; +} + +static efi_status_t efi_bootmenu_change_boot_order(int selected, int max, int *new) +{ + efi_status_t ret; + u16 new_order[EFI_BOOT_ORDER_MAX_SIZE_IN_DECIMAL] = {0}; + + printf(ANSI_CURSOR_POSITION, 2, 1); + puts(" *** U-Boot EFI Boot Manager Menu ***"); + printf(ANSI_CURSOR_POSITION, 4, 1); + printf(" current boot order : %d", selected); + + printf(ANSI_CURSOR_POSITION, 6, 1); + printf(" new boot order(0 - %4d): ", max); + + printf(ANSI_CURSOR_POSITION, 8, 1); + puts(" ENTER to complete, ESC/CTRL+C to quit"); + + printf(ANSI_CURSOR_POSITION, 6, 29); + puts(ANSI_CURSOR_SHOW); + + for (;;) { + memset(new_order, 0, sizeof(new_order)); + ret = efi_console_get_u16_string(cin, cout, new_order, 6, allow_decimal, 6, 29); + if (ret == EFI_SUCCESS) { + int i; + int val = 0; + + for (i = 0; + i < u16_strnlen(new_order, EFI_BOOT_ORDER_MAX_SIZE_IN_DECIMAL - 1); + i++) + val = (val * 10) + (new_order[i] - u'0'); + + if (val > max) + continue; + + *new = val; + return EFI_SUCCESS; + } else { + return ret; + } + } +} + static efi_status_t efi_bootmenu_select_file_handler(struct efi_bootmenu_boot_option *bo) { efi_status_t ret; @@ -996,6 +1046,57 @@ static efi_status_t efi_bootmenu_process_delete_boot_option(void *data, bool *ex return ret; }
+static efi_status_t efi_bootmenu_process_change_boot_order(void *data, bool *exit) +{ + int selected; + int new_order; + efi_status_t ret; + efi_uintn_t num, size; + u16 *bootorder = NULL; + u16 *new_bootorder = NULL; + + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + if (!bootorder) + return EFI_NOT_FOUND; + + num = size / sizeof(u16); + ret = efi_bootmenu_show_boot_selection(bootorder, num, &selected); + if (ret != EFI_SUCCESS) + goto out; + + ret = efi_bootmenu_change_boot_order(selected, num - 1, &new_order); + if (ret != EFI_SUCCESS) + goto out; + + new_bootorder = calloc(1, size); + if (!new_bootorder) + goto out; + + memcpy(new_bootorder, bootorder, size); + if (selected > new_order) { + new_bootorder[new_order] = bootorder[selected]; + memcpy(&new_bootorder[new_order + 1], &bootorder[new_order], + (selected - new_order) * sizeof(u16)); + } else if (selected < new_order) { + new_bootorder[new_order] = bootorder[selected]; + memcpy(&new_bootorder[selected], &bootorder[selected + 1], + (new_order - selected) * sizeof(u16)); + } else { + /* nothing to change */ + goto out; + } + ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + size, new_bootorder, false); +out: + free(new_bootorder); + free(bootorder); + + return ret; +} + static efi_status_t efi_bootmenu_init(void) { efi_status_t ret; @@ -1025,6 +1126,7 @@ static efi_status_t efi_bootmenu_init(void) static const struct efi_bootmenu_item maintenance_menu_items[] = { {u"Add Boot Option", efi_bootmenu_process_add_boot_option}, {u"Delete Boot Option", efi_bootmenu_process_delete_boot_option}, + {u"Change Boot Order", efi_bootmenu_process_change_boot_order}, {u"Quit", NULL}, };
Changes in v5:
- if (u'0' <= key->unicode_char && key->unicode_char <= u'9')
return EFI_SUCCESS;
- return EFI_INVALID_PARAMETER;
- efi_status_t ret;
- u16 new_order[EFI_BOOT_ORDER_MAX_SIZE_IN_DECIMAL] = {0};
After selecting an item why can we simply use the up and down key to move the selected item?
- printf(" current boot order : %d", selected);
- printf(ANSI_CURSOR_POSITION, 6, 1);
- printf(" new boot order(0 - %4d): ", max);
- printf(ANSI_CURSOR_POSITION, 6, 29);
- for (;;) {
int i;
int val = 0;
for (i = 0;
i++)
if (val > max)
continue;
*new = val;
return EFI_SUCCESS;
} else {
return ret;
- static efi_status_t efi_bootmenu_select_file_handler(struct efi_bootmenu_boot_option *bo) { efi_status_t ret;
- int selected;
- int new_order;
- efi_status_t ret;
- efi_uintn_t num, size;
- u16 *bootorder = NULL;
- if (!bootorder)
- num = size / sizeof(u16);
- ret = efi_bootmenu_show_boot_selection(bootorder, num, &selected);
goto out;
- ret = efi_bootmenu_change_boot_order(selected, num - 1, &new_order);
goto out;
- new_bootorder = calloc(1, size);
goto out;
- if (selected > new_order) {
- } else if (selected < new_order) {
After updating an item we should be in the efi_bootmenu_show_boot_selection() screen again.
Best regards
Heinrich
- } else {
goto out;
+out:
- free(bootorder);
- return ret;
- static efi_status_t efi_bootmenu_init(void) { efi_status_t ret;
- {u"Change Boot Order", efi_bootmenu_process_change_boot_order}, {u"Quit", NULL}, };
Changes in v5:
return EFI_SUCCESS;
efi_status_t ret;
OK, I will use the up and down key, as Takahiro also requested this before.
for (;;) {
int i;
int val = 0;
for (i = 0;
i++)
if (val > max)
continue;
*new = val;
return EFI_SUCCESS;
} else {
return ret;
int selected;
int new_order;
efi_status_t ret;
if (!bootorder)
goto out;
goto out;
if (!new_bootorder)
goto out;
OK.
Best regards
Heinrich
} else {
goto out;
+out:
free(bootorder);
return ret;
};{u"Change Boot Order", efi_bootmenu_process_change_boot_order}, {u"Quit", NULL},
UEFI specification requires booting from removal media using a architecture-specific default image name such as BOOTAA64.EFI. This commit adds the removable media entries into bootmenu, so that user can select the removable media and boot with default image.
The bootmenu automatically enumerates the possible bootable media devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL, add it as new UEFI boot option(BOOT####) and update BootOrder variable. This automatically generated UEFI boot option has the dedicated guid in the optional_data to distinguish it from the UEFI boot option user adds manually. This optional_data is removed when the efi bootmgr loads the selected UEFI boot option.
This commit also provides the BOOT#### variable maintenance feature. Depending on the system hardware setup, some devices may not exist at a later system boot, so bootmenu checks the available device in each bootmenu invocation and automatically removes the BOOT#### variable corrensponding to the non-existent media device.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- Changes in v6: - optional_data size is changed to 16bytes - check the load option size before comparison - remove guid included in optional_data of auto generated entry when loading
Changes in v5: - Return EFI_SUCCESS if there is no BootOrder defined - correctly handle the case if no removable device found - use guid to identify the automatically generated entry by bootmenu
Newly created in v4
cmd/bootmenu.c | 94 +++++++++++++++ include/efi_loader.h | 23 ++++ lib/efi_loader/efi_bootmenu_maintenance.c | 138 ++++++++++++++++++++++ lib/efi_loader/efi_bootmgr.c | 4 + 4 files changed, 259 insertions(+)
diff --git a/cmd/bootmenu.c b/cmd/bootmenu.c index 4b846332b0..911086c97e 100644 --- a/cmd/bootmenu.c +++ b/cmd/bootmenu.c @@ -234,6 +234,89 @@ static int prepare_bootmenu_entry(struct bootmenu_data *menu, return 1; }
+/** + * prepare_media_device_entry() - generate the media device entries + * + * This function enumerates all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL + * and generate the bootmenu entries. + * This function also provide the BOOT#### variable maintenance for + * the media device entries. + * - Automatically create the BOOT#### variable for the newly detected device, + * this BOOT#### variable is distinguished by the special GUID + * stored in the EFI_LOAD_OPTION.optional_data + * - If the device is not attached to the system, the associated BOOT#### variable + * is automatically deleted. + * + * Return: status code + */ +static efi_status_t prepare_media_device_entry(void) +{ + u32 i; + efi_status_t ret; + efi_uintn_t count; + efi_handle_t *volume_handles = NULL; + struct efi_bootmenu_media_boot_option *opt = NULL; + + ret = efi_locate_handle_buffer_int(BY_PROTOCOL, &efi_simple_file_system_protocol_guid, + NULL, &count, (efi_handle_t **)&volume_handles); + if (ret != EFI_SUCCESS) + return ret; + + opt = calloc(count, sizeof(struct efi_bootmenu_media_boot_option)); + if (!opt) + goto out; + + /* enumerate all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL */ + ret = efi_bootmenu_enumerate_boot_option(opt, volume_handles, count); + if (ret != EFI_SUCCESS) + goto out; + + /* + * System hardware configuration may vary depending on the user setup. + * The boot option is automatically added by the bootmenu. + * If the device is not attached to the system, the boot option needs + * to be deleted. + */ + ret = efi_bootmenu_delete_invalid_boot_option(opt, count); + if (ret != EFI_SUCCESS) + goto out; + + /* add non-existent boot option */ + for (i = 0; i < count; i++) { + u32 boot_index; + u16 var_name[9]; + + if (!opt[i].exist) { + ret = efi_bootmenu_get_unused_bootoption(var_name, sizeof(var_name), + &boot_index); + if (ret != EFI_SUCCESS) + goto out; + + ret = efi_set_variable_int(var_name, &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + opt[i].size, opt[i].lo, false); + if (ret != EFI_SUCCESS) + goto out; + + ret = efi_bootmenu_append_bootorder(boot_index); + if (ret != EFI_SUCCESS) + goto out; + } + } + +out: + if (opt) { + for (i = 0; i < count; i++) + free(opt[i].lo); + } + free(opt); + efi_free_pool(volume_handles); + + return ret; +} + /** * prepare_uefi_bootorder_entry() - generate the uefi bootmenu entries * @@ -326,6 +409,7 @@ static int prepare_uefi_bootorder_entry(struct bootmenu_data *menu, static struct bootmenu_data *bootmenu_create(int delay) { int ret; + efi_status_t efi_ret; unsigned short int i = 0; struct bootmenu_data *menu; struct bootmenu_entry *iter = NULL; @@ -349,6 +433,16 @@ static struct bootmenu_data *bootmenu_create(int delay) goto cleanup;
if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR) && IS_ENABLED(CONFIG_AUTOBOOT_MENU_SHOW)) { + if (i < MAX_DYNAMIC_ENTRY) { + /* + * UEFI specification requires booting from removal media using + * a architecture-specific default image name such as BOOTAA64.EFI. + */ + efi_ret = prepare_media_device_entry(); + if (efi_ret != EFI_SUCCESS && efi_ret != EFI_NOT_FOUND) + goto cleanup; + } + if (i < MAX_DYNAMIC_ENTRY) { ret = prepare_uefi_bootorder_entry(menu, &iter, &i); if (ret < 0 && ret != -ENOENT) diff --git a/include/efi_loader.h b/include/efi_loader.h index 49f326e585..48485e8da9 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -252,6 +252,9 @@ extern const struct efi_hii_string_protocol efi_hii_string;
uint16_t *efi_dp_str(struct efi_device_path *dp);
+/* GUID for the auto generated boot menu entry */ +extern const efi_guid_t efi_guid_bootmenu_auto_generated; + /* GUID of the U-Boot root node */ extern const efi_guid_t efi_u_boot_guid; #ifdef CONFIG_SANDBOX @@ -934,6 +937,22 @@ struct efi_signature_store { struct x509_certificate; struct pkcs7_message;
+/** + * struct efi_bootmenu_media_boot_option - boot option for (removable) media device + * + * This structure is used to enumerate possible boot option + * + * @lo: Serialized load option data + * @size: Size of serialized load option data + * @exist: Flag to indicate the load option already exists + * in Non-volatile load option + */ +struct efi_bootmenu_media_boot_option { + void *lo; + efi_uintn_t size; + bool exist; +}; + bool efi_signature_lookup_digest(struct efi_image_regions *regs, struct efi_signature_store *db, bool dbx); @@ -1082,6 +1101,10 @@ efi_status_t efi_console_get_u16_string efi_status_t efi_bootmenu_get_unused_bootoption(u16 *buf, efi_uintn_t buf_size, u32 *index); efi_status_t efi_bootmenu_append_bootorder(u16 index); +efi_status_t efi_bootmenu_enumerate_boot_option(struct efi_bootmenu_media_boot_option *opt, + efi_handle_t *volume_handles, efi_status_t count); +efi_status_t efi_bootmenu_delete_invalid_boot_option(struct efi_bootmenu_media_boot_option *opt, + efi_status_t count);
diff --git a/lib/efi_loader/efi_bootmenu_maintenance.c b/lib/efi_loader/efi_bootmenu_maintenance.c index be67fca95f..58f2999c61 100644 --- a/lib/efi_loader/efi_bootmenu_maintenance.c +++ b/lib/efi_loader/efi_bootmenu_maintenance.c @@ -26,6 +26,13 @@ static struct efi_simple_text_output_protocol *cout; #define EFI_BOOTMENU_BOOT_NAME_MAX 32 #define EFI_BOOT_ORDER_MAX_SIZE_IN_DECIMAL 6
+#define EFI_BOOTMENU_AUTO_GENERATED_ENTRY_GUID \ + EFI_GUID(0x38c1acc1, 0x9fc0, 0x41f0, \ + 0xb9, 0x01, 0xfa, 0x74, 0xd6, 0xd6, 0xe4, 0xde) + +const efi_guid_t efi_guid_bootmenu_auto_generated = + EFI_BOOTMENU_AUTO_GENERATED_ENTRY_GUID; + typedef efi_status_t (*efi_bootmenu_entry_func)(void *data, bool *exit);
/** @@ -1142,3 +1149,134 @@ efi_status_t efi_bootmenu_show_maintenance_menu(void) ARRAY_SIZE(maintenance_menu_items), -1); } + +efi_status_t efi_bootmenu_enumerate_boot_option(struct efi_bootmenu_media_boot_option *opt, + efi_handle_t *volume_handles, efi_status_t count) +{ + u32 i; + struct efi_handler *handler; + efi_status_t ret = EFI_SUCCESS; + + for (i = 0; i < count; i++) { + char *optional_data; + u16 *dev_name, *p; + struct efi_load_option lo; + struct efi_block_io *block_io; + char buf[BOOTMENU_DEVICE_NAME_MAX]; + struct efi_device_path *device_path; + + ret = efi_search_protocol(volume_handles[i], &efi_guid_device_path, &handler); + if (ret != EFI_SUCCESS) + continue; + ret = efi_protocol_open(handler, (void **)&device_path, + efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + continue; + + ret = efi_search_protocol(volume_handles[i], &efi_block_io_guid, &handler); + if (ret != EFI_SUCCESS) + continue; + ret = efi_protocol_open(handler, (void **)&block_io, + efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + continue; + + efi_disk_get_device_name(block_io, buf, BOOTMENU_DEVICE_NAME_MAX); + dev_name = calloc(1, (strlen(buf) + 1) * sizeof(u16)); + if (!dev_name) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + p = dev_name; + utf8_utf16_strncpy(&p, buf, strlen(buf)); + + lo.label = dev_name; + lo.attributes = LOAD_OPTION_ACTIVE; + lo.file_path = device_path; + lo.file_path_length = efi_dp_size(device_path) + sizeof(END); + /* + * Set the dedicated guid to optional_data, it is used to identify + * the boot option that automatically generated by the bootmenu. + * efi_serialize_load_option() expects optional_data is null-terminated + * utf8 string, so set the "1234567" string to allocate enough space + * to store guid, instead of realloc the load_option. + */ + lo.optional_data = "1234567"; + opt[i].size = efi_serialize_load_option(&lo, (u8 **)&opt[i].lo); + if (!opt[i].size) { + ret = EFI_OUT_OF_RESOURCES; + free(dev_name); + goto out; + } + /* set the guid */ + optional_data = (char *)opt[i].lo + (opt[i].size - u16_strsize(u"1234567")); + memcpy(optional_data, &efi_guid_bootmenu_auto_generated, sizeof(efi_guid_t)); + free(dev_name); + } + +out: + return ret; +} + +efi_status_t efi_bootmenu_delete_invalid_boot_option(struct efi_bootmenu_media_boot_option *opt, + efi_status_t count) +{ + u16 *bootorder; + u32 i, j; + efi_status_t ret; + efi_uintn_t num, size, bootorder_size; + void *load_option; + struct efi_load_option lo; + u16 varname[] = u"Boot####"; + + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &bootorder_size); + if (!bootorder) + return EFI_SUCCESS; /* BootOrder is not defined, nothing to do */ + + num = bootorder_size / sizeof(u16); + for (i = 0; i < num;) { + efi_uintn_t tmp; + + efi_create_indexed_name(varname, sizeof(varname), + "Boot", bootorder[i]); + load_option = efi_get_var(varname, &efi_global_variable_guid, &size); + if (!load_option) + goto next; + + tmp = size; + ret = efi_deserialize_load_option(&lo, load_option, &size); + if (ret != EFI_SUCCESS) + goto next; + + if (size >= sizeof(efi_guid_bootmenu_auto_generated)) { + if (guidcmp(lo.optional_data, &efi_guid_bootmenu_auto_generated) == 0) { + for (j = 0; j < count; j++) { + if (opt[j].size == tmp && + memcmp(opt[j].lo, load_option, tmp) == 0) { + opt[j].exist = true; + break; + } + } + + if (j == count) { + ret = delete_boot_option(bootorder, i, bootorder_size); + if (ret != EFI_SUCCESS) { + free(load_option); + goto out; + } + + num--; + bootorder_size -= sizeof(u16); + free(load_option); + continue; + } + } + } +next: + free(load_option); + i++; + } + +out: + return ret; +} diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 631a25d76e..ca2fbd26ce 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -146,6 +146,10 @@ static efi_status_t try_load_entry(u16 n, efi_handle_t *handle, }
/* Set load options */ + if (size >= sizeof(efi_guid_t) && + !guidcmp(lo.optional_data, &efi_guid_bootmenu_auto_generated)) + size = 0; + if (size) { *load_options = malloc(size); if (!*load_options) {
The bootmenu enumerates the UEFI boot options for boot device selection.
This commit adds the description how the UEFI boot work in bootmenu. This commit also adds "Synopsis", "Description" and "Configuration" sections to follow the U-Boot command documentation format.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- Changes in v6: - remove distro boot related contents because the distro boot support in bootmenu is dropped - update uefi entry example - add [delay] argument of bootmenu command - add description to enable uefi boot entry
Changes in v5: - follow the cmd documentation format same as other command, add "Synopsis", "Description" add "Configuration" sections
Newly created in v4
doc/usage/cmd/bootmenu.rst | 55 ++++++++++++++++++++++++++++++++++++++ 1 file changed, 55 insertions(+)
diff --git a/doc/usage/cmd/bootmenu.rst b/doc/usage/cmd/bootmenu.rst index 9430f8c9aa..6b154d9655 100644 --- a/doc/usage/cmd/bootmenu.rst +++ b/doc/usage/cmd/bootmenu.rst @@ -4,6 +4,16 @@ bootmenu command ================
+Synopsis +-------- + +:: + + bootmenu [delay] + +Description +----------- + The "bootmenu" command uses U-Boot menu interfaces and provides a simple mechanism for creating menus with different boot items. The cursor keys "Up" and "Down" are used for navigation through @@ -79,6 +89,35 @@ The above example will be rendered as below:: The selected menu entry will be highlighted - it will have inverted background and text colors.
+UEFI boot variable enumeration +'''''''''''''''''''''''''''''' + +The bootmenu automatically generates the UEFI boot variable("BOOT####") +in order of "BootOrder". When the user selects the UEFI boot +variable entry, bootmenu sets the selected boot variable index +to "BootNext", then call the uefi boot manager with the command +"bootefi bootmgr". + +The bootmenu automatically enumerates the possible bootable +media devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL. +This auto generated entry is named as "<interface> <devnum>:<part>" format. +(e.g. "usb 0:1") + +Example bootmenu is as below:: + + *** U-Boot Boot Menu *** + + mmc 0:1 + mmc 0:2 + debian + nvme 0:1 + ubuntu + nvme 0:2 + usb 0:2 + +Configuration +------------- + The "bootmenu" command is enabled by::
CONFIG_CMD_BOOTMENU=y @@ -88,3 +127,19 @@ To run the bootmenu at startup add these additional settings:: CONFIG_AUTOBOOT_KEYED=y CONFIG_BOOTDELAY=30 CONFIG_AUTOBOOT_MENU_SHOW=y + +UEFI boot variable enumeration is enabled by:: + + CONFIG_AUTOBOOT_MENU_SHOW=y + +To improve the product security, entering U-Boot console from bootmenu +can be disabled by:: + + CONFIG_CMD_BOOTMENU_ENTER_UBOOT_CONSOLE=n + +To scan the discoverable devices connected to the buses such as +USB and PCIe prior to bootmenu showing up, CONFIG_PREBOOT can be +used to run the command before showing the bootmenu, i.e.:: + + CONFIG_USE_PREBOOT=y + CONFIG_PREBOOT="pci enum; usb start; scsi scan; nvme scan; virtio scan"
Kojima-san,
Changes in v6:
? I rejected it in my comment. I don't think we have enough consensus yet.
Changes in v5:
Newly created in v4
+Synopsis +--------
- bootmenu [delay]
To be strict, the bootmenu command *does not* create UEFI boot variables (except ones for removable media). So, I would suggest you to modify the text like:
If enabled, the bootmenu command will automatically generate and add UEFI-related boot menu entries for * possible bootable media with default file names * user-defined UEFI boot options
Then,
- *** U-Boot Boot Menu ***
mmc 0:1
mmc 0:2
debian
nvme 0:1
ubuntu
nvme 0:2
usb 0:2
If I understand your patch correctly, menus are initially sorted out in the order of * user-defined bootmenu_xxx variables * removable bootable media * user-defined UEFI boot options
The example above looks odd.
That said, it would be worth mentioning that users can changes the order among UEFI-related menus. (Right?)
In addition, please describe the default action if users do not select anything.
-Takahiro Akashi
- CONFIG_AUTOBOOT_MENU_SHOW=y
- CONFIG_CMD_BOOTMENU_ENTER_UBOOT_CONSOLE=n
- CONFIG_USE_PREBOOT=y
- CONFIG_PREBOOT="pci enum; usb start; scsi scan; nvme scan; virtio scan"
-- 2.17.1
Hi Akashi-san,
On Wed, 18 May 2022 at 10:31, Takahiro Akashi takahiro.akashi@linaro.org wrote:
Kojima-san,
Changes in v6:
I am aware of your comment and discussion in U-Boot ML.
In my opinion, I doubt that the distro boot users use "bootmenu" to select the device to invoke "run bootcmd_xxx". I guess no. And my primary goal is disabling the U-Boot console for UEFI based system. Distro boot users can still live without the U-Boot console without bootmenu support.
Distro boot support in bootmenu is not planned initially at my side, but it was added during code review process, then it is (temporary) dropped in the end. I don't have a strong opinion about it.
Anyway, distro boot support in bootmenu is an individual patch, I am happy to re-send if needed.
Changes in v5:
Newly created in v4
+Synopsis +--------
- bootmenu [delay]
- possible bootable media with default file names
- user-defined UEFI boot options
Then,
Thank you, I agree.
mmc 0:1
mmc 0:2
debian
nvme 0:1
ubuntu
nvme 0:2
usb 0:2
- user-defined bootmenu_xxx variables
- removable bootable media
The example is intended and same as actual behavior.
Sorry for confusing you, the function name and description of prepare_media_device_entry() is wrong. This function just checks the removable bootable media, then updates UEFI boot variables(BOOTXXXX and BootOrder).
prepare_uefi_bootorder_entry() enumerates the UEFI related entries in the order of BootOrder. So removable bootable media entries and user-defined UEFI boot option entries are mixed in the bootmenu.
OK.
Yes, It should be noted.
-Takahiro Akashi
-- 2.17.1
This commit fixes the following compile warnings for the documentation.
./include/charset.h:276: warning: Function parameter or member 'size' not described in 'u16_strlcat' ./include/charset.h:276: warning: Excess function parameter 'count' description in 'u16_strlcat'
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- Newly created in v6
include/charset.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/charset.h b/include/charset.h index 20abfbe752..e900fd789a 100644 --- a/include/charset.h +++ b/include/charset.h @@ -273,7 +273,7 @@ u16 *u16_strdup(const void *src); * Return: required size including trailing 0x0000 in u16 words * If return value >= count, truncation occurred. */ -size_t u16_strlcat(u16 *dest, const u16 *src, size_t size); +size_t u16_strlcat(u16 *dest, const u16 *src, size_t count);
/** * utf16_to_utf8() - Convert an utf16 string to utf8
Most of the patches are merged into u-boot/master, this series contains the remaining patches to support menu-driven UEFI boot variable maintenance and removable media support.
This series needs to be rebased as we have switched to from utf-16 titles to utf-8 ones.
Best regards
Heinrich
[Major Changes]
- rebased to v2022.07-rc2
- there is detailed changelog in each commit
Masahisa Kojima (6): efi_loader: menu-driven addition of UEFI boot option efi_loader: menu-driven deletion of UEFI boot variable efi_loader: menu-driven update of UEFI bootorder variable bootmenu: add removable media entries doc:bootmenu: add description for UEFI boot support lib/charset: fix compile warnings
cmd/bootmenu.c | 167 ++- doc/usage/cmd/bootmenu.rst | 55 + include/charset.h | 2 +- include/efi_loader.h | 60 + lib/efi_loader/Makefile | 3 + lib/efi_loader/efi_bootmenu_maintenance.c | 1282 +++++++++++++++++++++ lib/efi_loader/efi_bootmgr.c | 4 + lib/efi_loader/efi_boottime.c | 52 +- lib/efi_loader/efi_console.c | 81 ++ lib/efi_loader/efi_disk.c | 11 + lib/efi_loader/efi_file.c | 75 +- 11 files changed, 1737 insertions(+), 55 deletions(-) create mode 100644 lib/efi_loader/efi_bootmenu_maintenance.c
Hi Heinrich,
Yes. Anyway, as Takahiro suggested, I will implement a new U-Boot command to invoke the UEFI variable maintenance menu. This new command runs from bootmenu_x.
Best regards
Heinrich
[Major Changes]
Masahisa Kojima
Takahiro Akashi
