[U-Boot] [RFC][PATCH] Update malloc to dlmalloc version 2.8.4
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- This is an attempt at using dlmalloc v2.8.4. Its a work in progress, but wanted to post to see what peoples feelings are on updating. This version resolves all the various warnings we see w/gcc4.4 and the older version of dlmalloc however the trade of is the code size has increased.
I still need to see if we need to hand relocate the global structs or not.
This diff is just of malloc.h to see how things are cfg, and of dmalloc.src vs dmalloc.c to see the changes to it.
- k
diff --git a/include/malloc.h b/include/malloc.h index 47154b0..2af6c8a 100644 --- a/include/malloc.h +++ b/include/malloc.h @@ -1,942 +1,784 @@ -/* - A version of malloc/free/realloc written by Doug Lea and released to the - public domain. Send questions/comments/complaints/performance data - to dl@cs.oswego.edu - -* VERSION 2.6.6 Sun Mar 5 19:10:03 2000 Doug Lea (dl at gee) - - Note: There may be an updated version of this malloc obtainable at - ftp://g.oswego.edu/pub/misc/malloc.c - Check before installing! - -* Why use this malloc? - - This is not the fastest, most space-conserving, most portable, or - most tunable malloc ever written. However it is among the fastest - while also being among the most space-conserving, portable and tunable. - Consistent balance across these factors results in a good general-purpose - allocator. For a high-level description, see - http://g.oswego.edu/dl/html/malloc.html - -* Synopsis of public routines - - (Much fuller descriptions are contained in the program documentation below.) - - malloc(size_t n); - Return a pointer to a newly allocated chunk of at least n bytes, or null - if no space is available. - free(Void_t* p); - Release the chunk of memory pointed to by p, or no effect if p is null. - realloc(Void_t* p, size_t n); - Return a pointer to a chunk of size n that contains the same data - as does chunk p up to the minimum of (n, p's size) bytes, or null - if no space is available. The returned pointer may or may not be - the same as p. If p is null, equivalent to malloc. Unless the - #define REALLOC_ZERO_BYTES_FREES below is set, realloc with a - size argument of zero (re)allocates a minimum-sized chunk. - memalign(size_t alignment, size_t n); - Return a pointer to a newly allocated chunk of n bytes, aligned - in accord with the alignment argument, which must be a power of - two. - valloc(size_t n); - Equivalent to memalign(pagesize, n), where pagesize is the page - size of the system (or as near to this as can be figured out from - all the includes/defines below.) - pvalloc(size_t n); - Equivalent to valloc(minimum-page-that-holds(n)), that is, - round up n to nearest pagesize. - calloc(size_t unit, size_t quantity); - Returns a pointer to quantity * unit bytes, with all locations - set to zero. - cfree(Void_t* p); - Equivalent to free(p). - malloc_trim(size_t pad); - Release all but pad bytes of freed top-most memory back - to the system. Return 1 if successful, else 0. - malloc_usable_size(Void_t* p); - Report the number usable allocated bytes associated with allocated - chunk p. This may or may not report more bytes than were requested, - due to alignment and minimum size constraints. - malloc_stats(); - Prints brief summary statistics on stderr. - mallinfo() - Returns (by copy) a struct containing various summary statistics. - mallopt(int parameter_number, int parameter_value) - Changes one of the tunable parameters described below. Returns - 1 if successful in changing the parameter, else 0. - -* Vital statistics: - - Alignment: 8-byte - 8 byte alignment is currently hardwired into the design. This - seems to suffice for all current machines and C compilers. - - Assumed pointer representation: 4 or 8 bytes - Code for 8-byte pointers is untested by me but has worked - reliably by Wolfram Gloger, who contributed most of the - changes supporting this. - - Assumed size_t representation: 4 or 8 bytes - Note that size_t is allowed to be 4 bytes even if pointers are 8. - - Minimum overhead per allocated chunk: 4 or 8 bytes - Each malloced chunk has a hidden overhead of 4 bytes holding size - and status information. - - Minimum allocated size: 4-byte ptrs: 16 bytes (including 4 overhead) - 8-byte ptrs: 24/32 bytes (including, 4/8 overhead) - - When a chunk is freed, 12 (for 4byte ptrs) or 20 (for 8 byte - ptrs but 4 byte size) or 24 (for 8/8) additional bytes are - needed; 4 (8) for a trailing size field - and 8 (16) bytes for free list pointers. Thus, the minimum - allocatable size is 16/24/32 bytes. - - Even a request for zero bytes (i.e., malloc(0)) returns a - pointer to something of the minimum allocatable size. - - Maximum allocated size: 4-byte size_t: 2^31 - 8 bytes - 8-byte size_t: 2^63 - 16 bytes - - It is assumed that (possibly signed) size_t bit values suffice to - represent chunk sizes. `Possibly signed' is due to the fact - that `size_t' may be defined on a system as either a signed or - an unsigned type. To be conservative, values that would appear - as negative numbers are avoided. - Requests for sizes with a negative sign bit when the request - size is treaded as a long will return null. - - Maximum overhead wastage per allocated chunk: normally 15 bytes - - Alignnment demands, plus the minimum allocatable size restriction - make the normal worst-case wastage 15 bytes (i.e., up to 15 - more bytes will be allocated than were requested in malloc), with - two exceptions: - 1. Because requests for zero bytes allocate non-zero space, - the worst case wastage for a request of zero bytes is 24 bytes. - 2. For requests >= mmap_threshold that are serviced via - mmap(), the worst case wastage is 8 bytes plus the remainder - from a system page (the minimal mmap unit); typically 4096 bytes. - -* Limitations - - Here are some features that are NOT currently supported - - * No user-definable hooks for callbacks and the like. - * No automated mechanism for fully checking that all accesses - to malloced memory stay within their bounds. - * No support for compaction. - -* Synopsis of compile-time options: - - People have reported using previous versions of this malloc on all - versions of Unix, sometimes by tweaking some of the defines - below. It has been tested most extensively on Solaris and - Linux. It is also reported to work on WIN32 platforms. - People have also reported adapting this malloc for use in - stand-alone embedded systems. - - The implementation is in straight, hand-tuned ANSI C. Among other - consequences, it uses a lot of macros. Because of this, to be at - all usable, this code should be compiled using an optimizing compiler - (for example gcc -O2) that can simplify expressions and control - paths. - - __STD_C (default: derived from C compiler defines) - Nonzero if using ANSI-standard C compiler, a C++ compiler, or - a C compiler sufficiently close to ANSI to get away with it. - DEBUG (default: NOT defined) - Define to enable debugging. Adds fairly extensive assertion-based - checking to help track down memory errors, but noticeably slows down - execution. - REALLOC_ZERO_BYTES_FREES (default: NOT defined) - Define this if you think that realloc(p, 0) should be equivalent - to free(p). Otherwise, since malloc returns a unique pointer for - malloc(0), so does realloc(p, 0). - HAVE_MEMCPY (default: defined) - Define if you are not otherwise using ANSI STD C, but still - have memcpy and memset in your C library and want to use them. - Otherwise, simple internal versions are supplied. - USE_MEMCPY (default: 1 if HAVE_MEMCPY is defined, 0 otherwise) - Define as 1 if you want the C library versions of memset and - memcpy called in realloc and calloc (otherwise macro versions are used). - At least on some platforms, the simple macro versions usually - outperform libc versions. - HAVE_MMAP (default: defined as 1) - Define to non-zero to optionally make malloc() use mmap() to - allocate very large blocks. - HAVE_MREMAP (default: defined as 0 unless Linux libc set) - Define to non-zero to optionally make realloc() use mremap() to - reallocate very large blocks. - malloc_getpagesize (default: derived from system #includes) - Either a constant or routine call returning the system page size. - HAVE_USR_INCLUDE_MALLOC_H (default: NOT defined) - Optionally define if you are on a system with a /usr/include/malloc.h - that declares struct mallinfo. It is not at all necessary to - define this even if you do, but will ensure consistency. - INTERNAL_SIZE_T (default: size_t) - Define to a 32-bit type (probably `unsigned int') if you are on a - 64-bit machine, yet do not want or need to allow malloc requests of - greater than 2^31 to be handled. This saves space, especially for - very small chunks. - INTERNAL_LINUX_C_LIB (default: NOT defined) - Defined only when compiled as part of Linux libc. - Also note that there is some odd internal name-mangling via defines - (for example, internally, `malloc' is named `mALLOc') needed - when compiling in this case. These look funny but don't otherwise - affect anything. - WIN32 (default: undefined) - Define this on MS win (95, nt) platforms to compile in sbrk emulation. - LACKS_UNISTD_H (default: undefined if not WIN32) - Define this if your system does not have a <unistd.h>. - LACKS_SYS_PARAM_H (default: undefined if not WIN32) - Define this if your system does not have a <sys/param.h>. - MORECORE (default: sbrk) - The name of the routine to call to obtain more memory from the system. - MORECORE_FAILURE (default: -1) - The value returned upon failure of MORECORE. - MORECORE_CLEARS (default 1) - True (1) if the routine mapped to MORECORE zeroes out memory (which - holds for sbrk). - DEFAULT_TRIM_THRESHOLD - DEFAULT_TOP_PAD - DEFAULT_MMAP_THRESHOLD - DEFAULT_MMAP_MAX - Default values of tunable parameters (described in detail below) - controlling interaction with host system routines (sbrk, mmap, etc). - These values may also be changed dynamically via mallopt(). The - preset defaults are those that give best performance for typical - programs/systems. - USE_DL_PREFIX (default: undefined) - Prefix all public routines with the string 'dl'. Useful to - quickly avoid procedure declaration conflicts and linker symbol - conflicts with existing memory allocation routines. - - -*/ - - - - -/* Preliminaries */ - -#ifndef __STD_C -#ifdef __STDC__ -#define __STD_C 1 -#else -#if __cplusplus -#define __STD_C 1 -#else -#define __STD_C 0 -#endif /*__cplusplus*/ -#endif /*__STDC__*/ -#endif /*__STD_C*/ - -#ifndef Void_t -#if (__STD_C || defined(WIN32)) -#define Void_t void -#else -#define Void_t char -#endif -#endif /*Void_t*/ - -#if __STD_C -#include <linux/stddef.h> /* for size_t */ -#else -#include <sys/types.h> -#endif /* __STD_C */ - -#ifdef __cplusplus -extern "C" { -#endif - -#if 0 /* not for U-Boot */ -#include <stdio.h> /* needed for malloc_stats */ -#endif - - -/* - Compile-time options -*/ - - -/* - Debugging: - - Because freed chunks may be overwritten with link fields, this - malloc will often die when freed memory is overwritten by user - programs. This can be very effective (albeit in an annoying way) - in helping track down dangling pointers. - - If you compile with -DDEBUG, a number of assertion checks are - enabled that will catch more memory errors. You probably won't be - able to make much sense of the actual assertion errors, but they - should help you locate incorrectly overwritten memory. The - checking is fairly extensive, and will slow down execution - noticeably. Calling malloc_stats or mallinfo with DEBUG set will - attempt to check every non-mmapped allocated and free chunk in the - course of computing the summmaries. (By nature, mmapped regions - cannot be checked very much automatically.) - - Setting DEBUG may also be helpful if you are trying to modify - this code. The assertions in the check routines spell out in more - detail the assumptions and invariants underlying the algorithms. - -*/ - -#ifdef DEBUG -/* #include <assert.h> */ -#define assert(x) ((void)0) -#else -#define assert(x) ((void)0) -#endif - - -/* - INTERNAL_SIZE_T is the word-size used for internal bookkeeping - of chunk sizes. On a 64-bit machine, you can reduce malloc - overhead by defining INTERNAL_SIZE_T to be a 32 bit `unsigned int' - at the expense of not being able to handle requests greater than - 2^31. This limitation is hardly ever a concern; you are encouraged - to set this. However, the default version is the same as size_t. -*/ - -#ifndef INTERNAL_SIZE_T -#define INTERNAL_SIZE_T size_t -#endif - -/* - REALLOC_ZERO_BYTES_FREES should be set if a call to - realloc with zero bytes should be the same as a call to free. - Some people think it should. Otherwise, since this malloc - returns a unique pointer for malloc(0), so does realloc(p, 0). -*/ - - -/* #define REALLOC_ZERO_BYTES_FREES */ - - -/* - WIN32 causes an emulation of sbrk to be compiled in - mmap-based options are not currently supported in WIN32. -*/ - -/* #define WIN32 */ -#ifdef WIN32 -#define MORECORE wsbrk -#define HAVE_MMAP 0 - -#define LACKS_UNISTD_H -#define LACKS_SYS_PARAM_H - -/* - Include 'windows.h' to get the necessary declarations for the - Microsoft Visual C++ data structures and routines used in the 'sbrk' - emulation. - - Define WIN32_LEAN_AND_MEAN so that only the essential Microsoft - Visual C++ header files are included. -*/ -#define WIN32_LEAN_AND_MEAN -#include <windows.h> +#define HAVE_MMAP 0 +#define HAVE_MREMAP 0 +#define HAVE_MORECORE 1 +#define LACKS_SYS_TYPES_H 1 +#define LACKS_ERRNO_H 1 +#define LACKS_STDLIB_H 1 +#define LACKS_STRING_H 1 +#define LACKS_STRINGS_H 1 +#define LACKS_UNISTD_H 1 +#define LACKS_SYS_PARAM_H 1 +#define EXEC_PAGESIZE 4096 +#define MALLOC_FAILURE_ACTION 0 +#define ABORT_ON_ASSERT_FAILURE 0 +#define ABORT +#define INSECURE 1 +#define NO_MALLINFO 1 + +#include <linux/types.h> + + + +/* Version identifier to allow people to support multiple versions */ +#ifndef DLMALLOC_VERSION +#define DLMALLOC_VERSION 20804 +#endif /* DLMALLOC_VERSION */ + +#if defined(DARWIN) || defined(_DARWIN) +/* Mac OSX docs advise not to use sbrk; it seems better to use mmap */ +#ifndef HAVE_MORECORE +#define HAVE_MORECORE 0 +#define HAVE_MMAP 1 +/* OSX allocators provide 16 byte alignment */ +#ifndef MALLOC_ALIGNMENT +#define MALLOC_ALIGNMENT ((size_t)16U) #endif +#endif /* HAVE_MORECORE */ +#endif /* DARWIN */
+#ifndef LACKS_SYS_TYPES_H +#include <sys/types.h> /* For size_t */ +#endif /* LACKS_SYS_TYPES_H */
-/* - HAVE_MEMCPY should be defined if you are not otherwise using - ANSI STD C, but still have memcpy and memset in your C library - and want to use them in calloc and realloc. Otherwise simple - macro versions are defined here. - - USE_MEMCPY should be defined as 1 if you actually want to - have memset and memcpy called. People report that the macro - versions are often enough faster than libc versions on many - systems that it is better to use them. - -*/ - -#define HAVE_MEMCPY - -#ifndef USE_MEMCPY -#ifdef HAVE_MEMCPY -#define USE_MEMCPY 1 +#if (defined(__GNUC__) && ((defined(__i386__) || defined(__x86_64__)))) || (defined(_MSC_VER) && _MSC_VER>=1310) +#define SPIN_LOCKS_AVAILABLE 1 #else -#define USE_MEMCPY 0 -#endif +#define SPIN_LOCKS_AVAILABLE 0 #endif
-#if (__STD_C || defined(HAVE_MEMCPY)) +/* The maximum possible size_t value has all bits set */ +#define MAX_SIZE_T (~(size_t)0)
-#if __STD_C -void* memset(void*, int, size_t); -void* memcpy(void*, const void*, size_t); +#ifndef ONLY_MSPACES +#define ONLY_MSPACES 0 /* define to a value */ #else -#ifdef WIN32 -/* On Win32 platforms, 'memset()' and 'memcpy()' are already declared in */ -/* 'windows.h' */ +#define ONLY_MSPACES 1 +#endif /* ONLY_MSPACES */ +#ifndef MSPACES +#if ONLY_MSPACES +#define MSPACES 1 +#else /* ONLY_MSPACES */ +#define MSPACES 0 +#endif /* ONLY_MSPACES */ +#endif /* MSPACES */ +#ifndef MALLOC_ALIGNMENT +#define MALLOC_ALIGNMENT ((size_t)8U) +#endif /* MALLOC_ALIGNMENT */ +#ifndef FOOTERS +#define FOOTERS 0 +#endif /* FOOTERS */ +#ifndef ABORT +#define ABORT abort() +#endif /* ABORT */ +#ifndef ABORT_ON_ASSERT_FAILURE +#define ABORT_ON_ASSERT_FAILURE 1 +#endif /* ABORT_ON_ASSERT_FAILURE */ +#ifndef PROCEED_ON_ERROR +#define PROCEED_ON_ERROR 0 +#endif /* PROCEED_ON_ERROR */ +#ifndef USE_LOCKS +#define USE_LOCKS 0 +#endif /* USE_LOCKS */ +#ifndef USE_SPIN_LOCKS +#if USE_LOCKS && SPIN_LOCKS_AVAILABLE +#define USE_SPIN_LOCKS 1 #else -Void_t* memset(); -Void_t* memcpy(); -#endif -#endif -#endif - -#if USE_MEMCPY - -/* The following macros are only invoked with (2n+1)-multiples of - INTERNAL_SIZE_T units, with a positive integer n. This is exploited - for fast inline execution when n is small. */ - -#define MALLOC_ZERO(charp, nbytes) \ -do { \ - INTERNAL_SIZE_T mzsz = (nbytes); \ - if(mzsz <= 9*sizeof(mzsz)) { \ - INTERNAL_SIZE_T* mz = (INTERNAL_SIZE_T*) (charp); \ - if(mzsz >= 5*sizeof(mzsz)) { *mz++ = 0; \ - *mz++ = 0; \ - if(mzsz >= 7*sizeof(mzsz)) { *mz++ = 0; \ - *mz++ = 0; \ - if(mzsz >= 9*sizeof(mzsz)) { *mz++ = 0; \ - *mz++ = 0; }}} \ - *mz++ = 0; \ - *mz++ = 0; \ - *mz = 0; \ - } else memset((charp), 0, mzsz); \ -} while(0) - -#define MALLOC_COPY(dest,src,nbytes) \ -do { \ - INTERNAL_SIZE_T mcsz = (nbytes); \ - if(mcsz <= 9*sizeof(mcsz)) { \ - INTERNAL_SIZE_T* mcsrc = (INTERNAL_SIZE_T*) (src); \ - INTERNAL_SIZE_T* mcdst = (INTERNAL_SIZE_T*) (dest); \ - if(mcsz >= 5*sizeof(mcsz)) { *mcdst++ = *mcsrc++; \ - *mcdst++ = *mcsrc++; \ - if(mcsz >= 7*sizeof(mcsz)) { *mcdst++ = *mcsrc++; \ - *mcdst++ = *mcsrc++; \ - if(mcsz >= 9*sizeof(mcsz)) { *mcdst++ = *mcsrc++; \ - *mcdst++ = *mcsrc++; }}} \ - *mcdst++ = *mcsrc++; \ - *mcdst++ = *mcsrc++; \ - *mcdst = *mcsrc ; \ - } else memcpy(dest, src, mcsz); \ -} while(0) - -#else /* !USE_MEMCPY */ - -/* Use Duff's device for good zeroing/copying performance. */ - -#define MALLOC_ZERO(charp, nbytes) \ -do { \ - INTERNAL_SIZE_T* mzp = (INTERNAL_SIZE_T*)(charp); \ - long mctmp = (nbytes)/sizeof(INTERNAL_SIZE_T), mcn; \ - if (mctmp < 8) mcn = 0; else { mcn = (mctmp-1)/8; mctmp %= 8; } \ - switch (mctmp) { \ - case 0: for(;;) { *mzp++ = 0; \ - case 7: *mzp++ = 0; \ - case 6: *mzp++ = 0; \ - case 5: *mzp++ = 0; \ - case 4: *mzp++ = 0; \ - case 3: *mzp++ = 0; \ - case 2: *mzp++ = 0; \ - case 1: *mzp++ = 0; if(mcn <= 0) break; mcn--; } \ - } \ -} while(0) - -#define MALLOC_COPY(dest,src,nbytes) \ -do { \ - INTERNAL_SIZE_T* mcsrc = (INTERNAL_SIZE_T*) src; \ - INTERNAL_SIZE_T* mcdst = (INTERNAL_SIZE_T*) dest; \ - long mctmp = (nbytes)/sizeof(INTERNAL_SIZE_T), mcn; \ - if (mctmp < 8) mcn = 0; else { mcn = (mctmp-1)/8; mctmp %= 8; } \ - switch (mctmp) { \ - case 0: for(;;) { *mcdst++ = *mcsrc++; \ - case 7: *mcdst++ = *mcsrc++; \ - case 6: *mcdst++ = *mcsrc++; \ - case 5: *mcdst++ = *mcsrc++; \ - case 4: *mcdst++ = *mcsrc++; \ - case 3: *mcdst++ = *mcsrc++; \ - case 2: *mcdst++ = *mcsrc++; \ - case 1: *mcdst++ = *mcsrc++; if(mcn <= 0) break; mcn--; } \ - } \ -} while(0) - -#endif - - -/* - Define HAVE_MMAP to optionally make malloc() use mmap() to - allocate very large blocks. These will be returned to the - operating system immediately after a free(). -*/ - -/*** +#define USE_SPIN_LOCKS 0 +#endif /* USE_LOCKS && SPIN_LOCKS_AVAILABLE. */ +#endif /* USE_SPIN_LOCKS */ +#ifndef INSECURE +#define INSECURE 0 +#endif /* INSECURE */ #ifndef HAVE_MMAP #define HAVE_MMAP 1 -#endif -***/ -#undef HAVE_MMAP /* Not available for U-Boot */ - -/* - Define HAVE_MREMAP to make realloc() use mremap() to re-allocate - large blocks. This is currently only possible on Linux with - kernel versions newer than 1.3.77. -*/ - -/*** +#endif /* HAVE_MMAP */ +#ifndef MMAP_CLEARS +#define MMAP_CLEARS 1 +#endif /* MMAP_CLEARS */ #ifndef HAVE_MREMAP -#ifdef INTERNAL_LINUX_C_LIB +#ifdef linux #define HAVE_MREMAP 1 -#else +#else /* linux */ #define HAVE_MREMAP 0 -#endif -#endif -***/ -#undef HAVE_MREMAP /* Not available for U-Boot */ - +#endif /* linux */ +#endif /* HAVE_MREMAP */ +#ifndef MALLOC_FAILURE_ACTION +#define MALLOC_FAILURE_ACTION errno = ENOMEM; +#endif /* MALLOC_FAILURE_ACTION */ +#ifndef HAVE_MORECORE +#if ONLY_MSPACES +#define HAVE_MORECORE 0 +#else /* ONLY_MSPACES */ +#define HAVE_MORECORE 1 +#endif /* ONLY_MSPACES */ +#endif /* HAVE_MORECORE */ +#if !HAVE_MORECORE +#define MORECORE_CONTIGUOUS 0 +#else /* !HAVE_MORECORE */ +#define MORECORE_DEFAULT sbrk +#ifndef MORECORE_CONTIGUOUS +#define MORECORE_CONTIGUOUS 1 +#endif /* MORECORE_CONTIGUOUS */ +#endif /* HAVE_MORECORE */ +#ifndef DEFAULT_GRANULARITY +#if (MORECORE_CONTIGUOUS || defined(WIN32)) +#define DEFAULT_GRANULARITY (0) /* 0 means to compute in init_mparams */ +#else /* MORECORE_CONTIGUOUS */ +#define DEFAULT_GRANULARITY ((size_t)64U * (size_t)1024U) +#endif /* MORECORE_CONTIGUOUS */ +#endif /* DEFAULT_GRANULARITY */ +#ifndef DEFAULT_TRIM_THRESHOLD +#ifndef MORECORE_CANNOT_TRIM +#define DEFAULT_TRIM_THRESHOLD ((size_t)2U * (size_t)1024U * (size_t)1024U) +#else /* MORECORE_CANNOT_TRIM */ +#define DEFAULT_TRIM_THRESHOLD MAX_SIZE_T +#endif /* MORECORE_CANNOT_TRIM */ +#endif /* DEFAULT_TRIM_THRESHOLD */ +#ifndef DEFAULT_MMAP_THRESHOLD #if HAVE_MMAP - -#include <unistd.h> -#include <fcntl.h> -#include <sys/mman.h> - -#if !defined(MAP_ANONYMOUS) && defined(MAP_ANON) -#define MAP_ANONYMOUS MAP_ANON -#endif - +#define DEFAULT_MMAP_THRESHOLD ((size_t)256U * (size_t)1024U) +#else /* HAVE_MMAP */ +#define DEFAULT_MMAP_THRESHOLD MAX_SIZE_T +#endif /* HAVE_MMAP */ +#endif /* DEFAULT_MMAP_THRESHOLD */ +#ifndef MAX_RELEASE_CHECK_RATE +#if HAVE_MMAP +#define MAX_RELEASE_CHECK_RATE 4095 +#else +#define MAX_RELEASE_CHECK_RATE MAX_SIZE_T #endif /* HAVE_MMAP */ +#endif /* MAX_RELEASE_CHECK_RATE */ +#ifndef USE_BUILTIN_FFS +#define USE_BUILTIN_FFS 0 +#endif /* USE_BUILTIN_FFS */ +#ifndef USE_DEV_RANDOM +#define USE_DEV_RANDOM 0 +#endif /* USE_DEV_RANDOM */ +#ifndef NO_MALLINFO +#define NO_MALLINFO 0 +#endif /* NO_MALLINFO */ +#ifndef MALLINFO_FIELD_TYPE +#define MALLINFO_FIELD_TYPE size_t +#endif /* MALLINFO_FIELD_TYPE */ +#ifndef NO_SEGMENT_TRAVERSAL +#define NO_SEGMENT_TRAVERSAL 0 +#endif /* NO_SEGMENT_TRAVERSAL */
/* - Access to system page size. To the extent possible, this malloc - manages memory from the system in page-size units. - - The following mechanics for getpagesize were adapted from - bsd/gnu getpagesize.h + mallopt tuning options. SVID/XPG defines four standard parameter + numbers for mallopt, normally defined in malloc.h. None of these + are used in this malloc, so setting them has no effect. But this + malloc does support the following options. */
-#define LACKS_UNISTD_H /* Shortcut for U-Boot */ -#define malloc_getpagesize 4096 - -#ifndef LACKS_UNISTD_H -# include <unistd.h> -#endif - -#ifndef malloc_getpagesize -# ifdef _SC_PAGESIZE /* some SVR4 systems omit an underscore */ -# ifndef _SC_PAGE_SIZE -# define _SC_PAGE_SIZE _SC_PAGESIZE -# endif -# endif -# ifdef _SC_PAGE_SIZE -# define malloc_getpagesize sysconf(_SC_PAGE_SIZE) -# else -# if defined(BSD) || defined(DGUX) || defined(HAVE_GETPAGESIZE) - extern size_t getpagesize(); -# define malloc_getpagesize getpagesize() -# else -# ifdef WIN32 -# define malloc_getpagesize (4096) /* TBD: Use 'GetSystemInfo' instead */ -# else -# ifndef LACKS_SYS_PARAM_H -# include <sys/param.h> -# endif -# ifdef EXEC_PAGESIZE -# define malloc_getpagesize EXEC_PAGESIZE -# else -# ifdef NBPG -# ifndef CLSIZE -# define malloc_getpagesize NBPG -# else -# define malloc_getpagesize (NBPG * CLSIZE) -# endif -# else -# ifdef NBPC -# define malloc_getpagesize NBPC -# else -# ifdef PAGESIZE -# define malloc_getpagesize PAGESIZE -# else -# define malloc_getpagesize (4096) /* just guess */ -# endif -# endif -# endif -# endif -# endif -# endif -# endif -#endif +#define M_TRIM_THRESHOLD (-1) +#define M_GRANULARITY (-2) +#define M_MMAP_THRESHOLD (-3)
+/* ------------------------ Mallinfo declarations ------------------------ */
+#if !NO_MALLINFO /* - This version of malloc supports the standard SVID/XPG mallinfo - routine that returns a struct containing the same kind of - information you can get from malloc_stats. It should work on - any SVID/XPG compliant system that has a /usr/include/malloc.h - defining struct mallinfo. (If you'd like to install such a thing - yourself, cut out the preliminary declarations as described above - and below and save them in a malloc.h file. But there's no - compelling reason to bother to do this.) - - The main declaration needed is the mallinfo struct that is returned - (by-copy) by mallinfo(). The SVID/XPG malloinfo struct contains a - bunch of fields, most of which are not even meaningful in this - version of malloc. Some of these fields are are instead filled by - mallinfo() with other numbers that might possibly be of interest. + routine that returns a struct containing usage properties and + statistics. It should work on any system that has a + /usr/include/malloc.h defining struct mallinfo. The main + declaration needed is the mallinfo struct that is returned (by-copy) + by mallinfo(). The malloinfo struct contains a bunch of fields that + are not even meaningful in this version of malloc. These fields are + are instead filled by mallinfo() with other numbers that might be of + interest.
HAVE_USR_INCLUDE_MALLOC_H should be set if you have a /usr/include/malloc.h file that includes a declaration of struct - mallinfo. If so, it is included; else an SVID2/XPG2 compliant - version is declared below. These must be precisely the same for - mallinfo() to work. - + mallinfo. If so, it is included; else a compliant version is + declared below. These must be precisely the same for mallinfo() to + work. The original SVID version of this struct, defined on most + systems with mallinfo, declares all fields as ints. But some others + define as unsigned long. If your system defines the fields using a + type of different width than listed here, you MUST #include your + system version and #define HAVE_USR_INCLUDE_MALLOC_H. */
/* #define HAVE_USR_INCLUDE_MALLOC_H */
-#if HAVE_USR_INCLUDE_MALLOC_H +#ifdef HAVE_USR_INCLUDE_MALLOC_H #include "/usr/include/malloc.h" -#else - -/* SVID2/XPG mallinfo structure */ - +#else /* HAVE_USR_INCLUDE_MALLOC_H */ +#ifndef STRUCT_MALLINFO_DECLARED +#define STRUCT_MALLINFO_DECLARED 1 struct mallinfo { - int arena; /* total space allocated from system */ - int ordblks; /* number of non-inuse chunks */ - int smblks; /* unused -- always zero */ - int hblks; /* number of mmapped regions */ - int hblkhd; /* total space in mmapped regions */ - int usmblks; /* unused -- always zero */ - int fsmblks; /* unused -- always zero */ - int uordblks; /* total allocated space */ - int fordblks; /* total non-inuse space */ - int keepcost; /* top-most, releasable (via malloc_trim) space */ + MALLINFO_FIELD_TYPE arena; /* non-mmapped space allocated from system */ + MALLINFO_FIELD_TYPE ordblks; /* number of free chunks */ + MALLINFO_FIELD_TYPE smblks; /* always 0 */ + MALLINFO_FIELD_TYPE hblks; /* always 0 */ + MALLINFO_FIELD_TYPE hblkhd; /* space in mmapped regions */ + MALLINFO_FIELD_TYPE usmblks; /* maximum total allocated space */ + MALLINFO_FIELD_TYPE fsmblks; /* always 0 */ + MALLINFO_FIELD_TYPE uordblks; /* total allocated space */ + MALLINFO_FIELD_TYPE fordblks; /* total free space */ + MALLINFO_FIELD_TYPE keepcost; /* releasable (via malloc_trim) space */ }; +#endif /* STRUCT_MALLINFO_DECLARED */ +#endif /* HAVE_USR_INCLUDE_MALLOC_H */ +#endif /* NO_MALLINFO */
-/* SVID2/XPG mallopt options */ - -#define M_MXFAST 1 /* UNUSED in this malloc */ -#define M_NLBLKS 2 /* UNUSED in this malloc */ -#define M_GRAIN 3 /* UNUSED in this malloc */ -#define M_KEEP 4 /* UNUSED in this malloc */ +/* + Try to persuade compilers to inline. The most critical functions for + inlining are defined as macros, so these aren't used for them. +*/
+#ifndef FORCEINLINE + #if defined(__GNUC__) +#define FORCEINLINE __inline __attribute__ ((always_inline)) + #elif defined(_MSC_VER) + #define FORCEINLINE __forceinline + #endif +#endif +#ifndef NOINLINE + #if defined(__GNUC__) + #define NOINLINE __attribute__ ((noinline)) + #elif defined(_MSC_VER) + #define NOINLINE __declspec(noinline) + #else + #define NOINLINE + #endif #endif
-/* mallopt options that actually do something */ - -#define M_TRIM_THRESHOLD -1 -#define M_TOP_PAD -2 -#define M_MMAP_THRESHOLD -3 -#define M_MMAP_MAX -4 +#ifdef __cplusplus +extern "C" { +#ifndef FORCEINLINE + #define FORCEINLINE inline +#endif +#endif /* __cplusplus */ +#ifndef FORCEINLINE + #define FORCEINLINE +#endif + +#if !ONLY_MSPACES + +/* ------------------- Declarations of public routines ------------------- */ + +#ifndef USE_DL_PREFIX +#define dlcalloc calloc +#define dlfree free +#define dlmalloc malloc +#define dlmemalign memalign +#define dlrealloc realloc +#define dlvalloc valloc +#define dlpvalloc pvalloc +#define dlmallinfo mallinfo +#define dlmallopt mallopt +#define dlmalloc_trim malloc_trim +#define dlmalloc_stats malloc_stats +#define dlmalloc_usable_size malloc_usable_size +#define dlmalloc_footprint malloc_footprint +#define dlmalloc_max_footprint malloc_max_footprint +#define dlindependent_calloc independent_calloc +#define dlindependent_comalloc independent_comalloc +#endif /* USE_DL_PREFIX */
-#ifndef DEFAULT_TRIM_THRESHOLD -#define DEFAULT_TRIM_THRESHOLD (128 * 1024) -#endif +/* + malloc(size_t n) + Returns a pointer to a newly allocated chunk of at least n bytes, or + null if no space is available, in which case errno is set to ENOMEM + on ANSI C systems. + + If n is zero, malloc returns a minimum-sized chunk. (The minimum + size is 16 bytes on most 32bit systems, and 32 bytes on 64bit + systems.) Note that size_t is an unsigned type, so calls with + arguments that would be negative if signed are interpreted as + requests for huge amounts of space, which will often fail. The + maximum supported value of n differs across systems, but is in all + cases less than the maximum representable value of a size_t. +*/ +void* dlmalloc(size_t);
/* - M_TRIM_THRESHOLD is the maximum amount of unused top-most memory - to keep before releasing via malloc_trim in free(). - - Automatic trimming is mainly useful in long-lived programs. - Because trimming via sbrk can be slow on some systems, and can - sometimes be wasteful (in cases where programs immediately - afterward allocate more large chunks) the value should be high - enough so that your overall system performance would improve by - releasing. - - The trim threshold and the mmap control parameters (see below) - can be traded off with one another. Trimming and mmapping are - two different ways of releasing unused memory back to the - system. Between these two, it is often possible to keep - system-level demands of a long-lived program down to a bare - minimum. For example, in one test suite of sessions measuring - the XF86 X server on Linux, using a trim threshold of 128K and a - mmap threshold of 192K led to near-minimal long term resource - consumption. - - If you are using this malloc in a long-lived program, it should - pay to experiment with these values. As a rough guide, you - might set to a value close to the average size of a process - (program) running on your system. Releasing this much memory - would allow such a process to run in memory. Generally, it's - worth it to tune for trimming rather tham memory mapping when a - program undergoes phases where several large chunks are - allocated and released in ways that can reuse each other's - storage, perhaps mixed with phases where there are no such - chunks at all. And in well-behaved long-lived programs, - controlling release of large blocks via trimming versus mapping - is usually faster. - - However, in most programs, these parameters serve mainly as - protection against the system-level effects of carrying around - massive amounts of unneeded memory. Since frequent calls to - sbrk, mmap, and munmap otherwise degrade performance, the default - parameters are set to relatively high values that serve only as - safeguards. - - The default trim value is high enough to cause trimming only in - fairly extreme (by current memory consumption standards) cases. - It must be greater than page size to have any useful effect. To - disable trimming completely, you can set to (unsigned long)(-1); - - -*/ - - -#ifndef DEFAULT_TOP_PAD -#define DEFAULT_TOP_PAD (0) -#endif + free(void* p) + Releases the chunk of memory pointed to by p, that had been previously + allocated using malloc or a related routine such as realloc. + It has no effect if p is null. If p was not malloced or already + freed, free(p) will by default cause the current program to abort. +*/ +void dlfree(void*);
/* - M_TOP_PAD is the amount of extra `padding' space to allocate or - retain whenever sbrk is called. It is used in two ways internally: + calloc(size_t n_elements, size_t element_size); + Returns a pointer to n_elements * element_size bytes, with all locations + set to zero. +*/ +void* dlcalloc(size_t, size_t);
- * When sbrk is called to extend the top of the arena to satisfy - a new malloc request, this much padding is added to the sbrk - request. +/* + realloc(void* p, size_t n) + Returns a pointer to a chunk of size n that contains the same data + as does chunk p up to the minimum of (n, p's size) bytes, or null + if no space is available.
- * When malloc_trim is called automatically from free(), - it is used as the `pad' argument. + The returned pointer may or may not be the same as p. The algorithm + prefers extending p in most cases when possible, otherwise it + employs the equivalent of a malloc-copy-free sequence.
- In both cases, the actual amount of padding is rounded - so that the end of the arena is always a system page boundary. + If p is null, realloc is equivalent to malloc.
- The main reason for using padding is to avoid calling sbrk so - often. Having even a small pad greatly reduces the likelihood - that nearly every malloc request during program start-up (or - after trimming) will invoke sbrk, which needlessly wastes - time. + If space is not available, realloc returns null, errno is set (if on + ANSI) and p is NOT freed.
- Automatic rounding-up to page-size units is normally sufficient - to avoid measurable overhead, so the default is 0. However, in - systems where sbrk is relatively slow, it can pay to increase - this value, at the expense of carrying around more memory than - the program needs. + if n is for fewer bytes than already held by p, the newly unused + space is lopped off and freed if possible. realloc with a size + argument of zero (re)allocates a minimum-sized chunk.
+ The old unix realloc convention of allowing the last-free'd chunk + to be used as an argument to realloc is not supported. */
- -#ifndef DEFAULT_MMAP_THRESHOLD -#define DEFAULT_MMAP_THRESHOLD (128 * 1024) -#endif +void* dlrealloc(void*, size_t);
/* + memalign(size_t alignment, size_t n); + Returns a pointer to a newly allocated chunk of n bytes, aligned + in accord with the alignment argument.
- M_MMAP_THRESHOLD is the request size threshold for using mmap() - to service a request. Requests of at least this size that cannot - be allocated using already-existing space will be serviced via mmap. - (If enough normal freed space already exists it is used instead.) + The alignment argument should be a power of two. If the argument is + not a power of two, the nearest greater power is used. + 8-byte alignment is guaranteed by normal malloc calls, so don't + bother calling memalign with an argument of 8 or less.
- Using mmap segregates relatively large chunks of memory so that - they can be individually obtained and released from the host - system. A request serviced through mmap is never reused by any - other request (at least not directly; the system may just so - happen to remap successive requests to the same locations). + Overreliance on memalign is a sure way to fragment space. +*/ +void* dlmemalign(size_t, size_t);
- Segregating space in this way has the benefit that mmapped space - can ALWAYS be individually released back to the system, which - helps keep the system level memory demands of a long-lived - program low. Mapped memory can never become `locked' between - other chunks, as can happen with normally allocated chunks, which - menas that even trimming via malloc_trim would not release them. +/* + valloc(size_t n); + Equivalent to memalign(pagesize, n), where pagesize is the page + size of the system. If the pagesize is unknown, 4096 is used. +*/ +void* dlvalloc(size_t);
- However, it has the disadvantages that: +/* + mallopt(int parameter_number, int parameter_value) + Sets tunable parameters The format is to provide a + (parameter-number, parameter-value) pair. mallopt then sets the + corresponding parameter to the argument value if it can (i.e., so + long as the value is meaningful), and returns 1 if successful else + 0. To workaround the fact that mallopt is specified to use int, + not size_t parameters, the value -1 is specially treated as the + maximum unsigned size_t value. + + SVID/XPG/ANSI defines four standard param numbers for mallopt, + normally defined in malloc.h. None of these are use in this malloc, + so setting them has no effect. But this malloc also supports other + options in mallopt. See below for details. Briefly, supported + parameters are as follows (listed defaults are for "typical" + configurations). + + Symbol param # default allowed param values + M_TRIM_THRESHOLD -1 2*1024*1024 any (-1 disables) + M_GRANULARITY -2 page size any power of 2 >= page size + M_MMAP_THRESHOLD -3 256*1024 any (or 0 if no MMAP support) +*/ +int dlmallopt(int, int);
- 1. The space cannot be reclaimed, consolidated, and then - used to service later requests, as happens with normal chunks. - 2. It can lead to more wastage because of mmap page alignment - requirements - 3. It causes malloc performance to be more dependent on host - system memory management support routines which may vary in - implementation quality and may impose arbitrary - limitations. Generally, servicing a request via normal - malloc steps is faster than going through a system's mmap. +/* + malloc_footprint(); + Returns the number of bytes obtained from the system. The total + number of bytes allocated by malloc, realloc etc., is less than this + value. Unlike mallinfo, this function returns only a precomputed + result, so can be called frequently to monitor memory consumption. + Even if locks are otherwise defined, this function does not use them, + so results might not be up to date. +*/ +size_t dlmalloc_footprint(void);
- All together, these considerations should lead you to use mmap - only for relatively large requests. +/* + malloc_max_footprint(); + Returns the maximum number of bytes obtained from the system. This + value will be greater than current footprint if deallocated space + has been reclaimed by the system. The peak number of bytes allocated + by malloc, realloc etc., is less than this value. Unlike mallinfo, + this function returns only a precomputed result, so can be called + frequently to monitor memory consumption. Even if locks are + otherwise defined, this function does not use them, so results might + not be up to date. +*/ +size_t dlmalloc_max_footprint(void);
+#if !NO_MALLINFO +/* + mallinfo() + Returns (by copy) a struct containing various summary statistics: + + arena: current total non-mmapped bytes allocated from system + ordblks: the number of free chunks + smblks: always zero. + hblks: current number of mmapped regions + hblkhd: total bytes held in mmapped regions + usmblks: the maximum total allocated space. This will be greater + than current total if trimming has occurred. + fsmblks: always zero + uordblks: current total allocated space (normal or mmapped) + fordblks: total free space + keepcost: the maximum number of bytes that could ideally be released + back to system via malloc_trim. ("ideally" means that + it ignores page restrictions etc.) + + Because these fields are ints, but internal bookkeeping may + be kept as longs, the reported values may wrap around zero and + thus be inaccurate. +*/ +struct mallinfo dlmallinfo(void); +#endif /* NO_MALLINFO */
+/* + independent_calloc(size_t n_elements, size_t element_size, void* chunks[]); + + independent_calloc is similar to calloc, but instead of returning a + single cleared space, it returns an array of pointers to n_elements + independent elements that can hold contents of size elem_size, each + of which starts out cleared, and can be independently freed, + realloc'ed etc. The elements are guaranteed to be adjacently + allocated (this is not guaranteed to occur with multiple callocs or + mallocs), which may also improve cache locality in some + applications. + + The "chunks" argument is optional (i.e., may be null, which is + probably the most typical usage). If it is null, the returned array + is itself dynamically allocated and should also be freed when it is + no longer needed. Otherwise, the chunks array must be of at least + n_elements in length. It is filled in with the pointers to the + chunks. + + In either case, independent_calloc returns this pointer array, or + null if the allocation failed. If n_elements is zero and "chunks" + is null, it returns a chunk representing an array with zero elements + (which should be freed if not wanted). + + Each element must be individually freed when it is no longer + needed. If you'd like to instead be able to free all at once, you + should instead use regular calloc and assign pointers into this + space to represent elements. (In this case though, you cannot + independently free elements.) + + independent_calloc simplifies and speeds up implementations of many + kinds of pools. It may also be useful when constructing large data + structures that initially have a fixed number of fixed-sized nodes, + but the number is not known at compile time, and some of the nodes + may later need to be freed. For example: + + struct Node { int item; struct Node* next; }; + + struct Node* build_list() { + struct Node** pool; + int n = read_number_of_nodes_needed(); + if (n <= 0) return 0; + pool = (struct Node**)(independent_calloc(n, sizeof(struct Node), 0); + if (pool == 0) die(); + // organize into a linked list... + struct Node* first = pool[0]; + for (i = 0; i < n-1; ++i) + pool[i]->next = pool[i+1]; + free(pool); // Can now free the array (or not, if it is needed later) + return first; + } */ +void** dlindependent_calloc(size_t, size_t, void**);
+/* + independent_comalloc(size_t n_elements, size_t sizes[], void* chunks[]); + + independent_comalloc allocates, all at once, a set of n_elements + chunks with sizes indicated in the "sizes" array. It returns + an array of pointers to these elements, each of which can be + independently freed, realloc'ed etc. The elements are guaranteed to + be adjacently allocated (this is not guaranteed to occur with + multiple callocs or mallocs), which may also improve cache locality + in some applications. + + The "chunks" argument is optional (i.e., may be null). If it is null + the returned array is itself dynamically allocated and should also + be freed when it is no longer needed. Otherwise, the chunks array + must be of at least n_elements in length. It is filled in with the + pointers to the chunks. + + In either case, independent_comalloc returns this pointer array, or + null if the allocation failed. If n_elements is zero and chunks is + null, it returns a chunk representing an array with zero elements + (which should be freed if not wanted). + + Each element must be individually freed when it is no longer + needed. If you'd like to instead be able to free all at once, you + should instead use a single regular malloc, and assign pointers at + particular offsets in the aggregate space. (In this case though, you + cannot independently free elements.) + + independent_comallac differs from independent_calloc in that each + element may have a different size, and also that it does not + automatically clear elements. + + independent_comalloc can be used to speed up allocation in cases + where several structs or objects must always be allocated at the + same time. For example: + + struct Head { ... } + struct Foot { ... } + + void send_message(char* msg) { + int msglen = strlen(msg); + size_t sizes[3] = { sizeof(struct Head), msglen, sizeof(struct Foot) }; + void* chunks[3]; + if (independent_comalloc(3, sizes, chunks) == 0) + die(); + struct Head* head = (struct Head*)(chunks[0]); + char* body = (char*)(chunks[1]); + struct Foot* foot = (struct Foot*)(chunks[2]); + // ... + } + + In general though, independent_comalloc is worth using only for + larger values of n_elements. For small values, you probably won't + detect enough difference from series of malloc calls to bother. + + Overuse of independent_comalloc can increase overall memory usage, + since it cannot reuse existing noncontiguous small chunks that + might be available for some of the elements. +*/ +void** dlindependent_comalloc(size_t, size_t*, void**);
-#ifndef DEFAULT_MMAP_MAX -#if HAVE_MMAP -#define DEFAULT_MMAP_MAX (64) -#else -#define DEFAULT_MMAP_MAX (0) -#endif -#endif
/* - M_MMAP_MAX is the maximum number of requests to simultaneously - service using mmap. This parameter exists because: + pvalloc(size_t n); + Equivalent to valloc(minimum-page-that-holds(n)), that is, + round up n to nearest pagesize. + */ +void* dlpvalloc(size_t);
- 1. Some systems have a limited number of internal tables for - use by mmap. - 2. In most systems, overreliance on mmap can degrade overall - performance. - 3. If a program allocates many large regions, it is probably - better off using normal sbrk-based allocation routines that - can reclaim and reallocate normal heap memory. Using a - small value allows transition into this mode after the - first few allocations. +/* + malloc_trim(size_t pad);
- Setting to 0 disables all use of mmap. If HAVE_MMAP is not set, - the default value is 0, and attempts to set it to non-zero values - in mallopt will fail. + If possible, gives memory back to the system (via negative arguments + to sbrk) if there is unused memory at the `high' end of the malloc + pool or in unused MMAP segments. You can call this after freeing + large blocks of memory to potentially reduce the system-level memory + requirements of a program. However, it cannot guarantee to reduce + memory. Under some allocation patterns, some large free blocks of + memory will be locked between two used chunks, so they cannot be + given back to the system. + + The `pad' argument to malloc_trim represents the amount of free + trailing space to leave untrimmed. If this argument is zero, only + the minimum amount of memory to maintain internal data structures + will be left. Non-zero arguments can be supplied to maintain enough + trailing space to service future expected allocations without having + to re-obtain memory from the system. + + Malloc_trim returns 1 if it actually released any memory, else 0. */ - +int dlmalloc_trim(size_t);
/* - USE_DL_PREFIX will prefix all public routines with the string 'dl'. - Useful to quickly avoid procedure declaration conflicts and linker - symbol conflicts with existing memory allocation routines. + malloc_stats(); + Prints on stderr the amount of space obtained from the system (both + via sbrk and mmap), the maximum amount (which may be more than + current if malloc_trim and/or munmap got called), and the current + number of bytes allocated via malloc (or realloc, etc) but not yet + freed. Note that this is the number of bytes allocated, not the + number requested. It will be larger than the number requested + because of alignment and bookkeeping overhead. Because it includes + alignment wastage as being in use, this figure may be greater than + zero even when no user-level chunks are allocated. + + The reported current and maximum system memory can be inaccurate if + a program makes other calls to system memory allocation functions + (normally sbrk) outside of malloc. + + malloc_stats prints only the most commonly interesting statistics. + More information can be obtained by calling mallinfo. +*/ +void dlmalloc_stats(void); + +#endif /* ONLY_MSPACES */
+/* + malloc_usable_size(void* p); + + Returns the number of bytes you can actually use in + an allocated chunk, which may be more than you requested (although + often not) due to alignment and minimum size constraints. + You can use this many bytes without worrying about + overwriting other allocated objects. This is not a particularly great + programming practice. malloc_usable_size can be more useful in + debugging and assertions, for example: + + p = malloc(n); + assert(malloc_usable_size(p) >= 256); */ +size_t dlmalloc_usable_size(void*);
-/* #define USE_DL_PREFIX */
+#if MSPACES + +/* + mspace is an opaque type representing an independent + region of space that supports mspace_malloc, etc. +*/ +typedef void* mspace;
/* + create_mspace creates and returns a new independent space with the + given initial capacity, or, if 0, the default granularity size. It + returns null if there is no system memory available to create the + space. If argument locked is non-zero, the space uses a separate + lock to control access. The capacity of the space will grow + dynamically as needed to service mspace_malloc requests. You can + control the sizes of incremental increases of this space by + compiling with a different DEFAULT_GRANULARITY or dynamically + setting with mallopt(M_GRANULARITY, value). +*/ +mspace create_mspace(size_t capacity, int locked);
- Special defines for linux libc +/* + destroy_mspace destroys the given space, and attempts to return all + of its memory back to the system, returning the total number of + bytes freed. After destruction, the results of access to all memory + used by the space become undefined. +*/ +size_t destroy_mspace(mspace msp);
- Except when compiled using these special defines for Linux libc - using weak aliases, this malloc is NOT designed to work in - multithreaded applications. No semaphores or other concurrency - control are provided to ensure that multiple malloc or free calls - don't run at the same time, which could be disasterous. A single - semaphore could be used across malloc, realloc, and free (which is - essentially the effect of the linux weak alias approach). It would - be hard to obtain finer granularity. +/* + create_mspace_with_base uses the memory supplied as the initial base + of a new mspace. Part (less than 128*sizeof(size_t) bytes) of this + space is used for bookkeeping, so the capacity must be at least this + large. (Otherwise 0 is returned.) When this initial space is + exhausted, additional memory will be obtained from the system. + Destroying this space will deallocate all additionally allocated + space (if possible) but not the initial base. +*/ +mspace create_mspace_with_base(void* base, size_t capacity, int locked);
+/* + mspace_track_large_chunks controls whether requests for large chunks + are allocated in their own untracked mmapped regions, separate from + others in this mspace. By default large chunks are not tracked, + which reduces fragmentation. However, such chunks are not + necessarily released to the system upon destroy_mspace. Enabling + tracking by setting to true may increase fragmentation, but avoids + leakage when relying on destroy_mspace to release all memory + allocated using this space. The function returns the previous + setting. */ +int mspace_track_large_chunks(mspace msp, int enable);
-#ifdef INTERNAL_LINUX_C_LIB +/* + mspace_malloc behaves as malloc, but operates within + the given space. +*/ +void* mspace_malloc(mspace msp, size_t bytes);
-#if __STD_C +/* + mspace_free behaves as free, but operates within + the given space.
-Void_t * __default_morecore_init (ptrdiff_t); -Void_t *(*__morecore)(ptrdiff_t) = __default_morecore_init; + If compiled with FOOTERS==1, mspace_free is not actually needed. + free may be called instead of mspace_free because freed chunks from + any space are handled by their originating spaces. +*/ +void mspace_free(mspace msp, void* mem);
-#else +/* + mspace_realloc behaves as realloc, but operates within + the given space.
-Void_t * __default_morecore_init (); -Void_t *(*__morecore)() = __default_morecore_init; + If compiled with FOOTERS==1, mspace_realloc is not actually + needed. realloc may be called instead of mspace_realloc because + realloced chunks from any space are handled by their originating + spaces. +*/ +void* mspace_realloc(mspace msp, void* mem, size_t newsize);
-#endif +/* + mspace_calloc behaves as calloc, but operates within + the given space. +*/ +void* mspace_calloc(mspace msp, size_t n_elements, size_t elem_size);
-#define MORECORE (*__morecore) -#define MORECORE_FAILURE 0 -#define MORECORE_CLEARS 1 +/* + mspace_memalign behaves as memalign, but operates within + the given space. +*/ +void* mspace_memalign(mspace msp, size_t alignment, size_t bytes);
-#else /* INTERNAL_LINUX_C_LIB */ +/* + mspace_independent_calloc behaves as independent_calloc, but + operates within the given space. +*/ +void** mspace_independent_calloc(mspace msp, size_t n_elements, + size_t elem_size, void* chunks[]);
-#if __STD_C -extern Void_t* sbrk(ptrdiff_t); -#else -extern Void_t* sbrk(); -#endif +/* + mspace_independent_comalloc behaves as independent_comalloc, but + operates within the given space. +*/ +void** mspace_independent_comalloc(mspace msp, size_t n_elements, + size_t sizes[], void* chunks[]);
-#ifndef MORECORE -#define MORECORE sbrk -#endif +/* + mspace_footprint() returns the number of bytes obtained from the + system for this space. +*/ +size_t mspace_footprint(mspace msp);
-#ifndef MORECORE_FAILURE -#define MORECORE_FAILURE -1 -#endif +/* + mspace_max_footprint() returns the peak number of bytes obtained from the + system for this space. +*/ +size_t mspace_max_footprint(mspace msp);
-#ifndef MORECORE_CLEARS -#define MORECORE_CLEARS 1 -#endif
-#endif /* INTERNAL_LINUX_C_LIB */ - -#if defined(INTERNAL_LINUX_C_LIB) && defined(__ELF__) - -#define cALLOc __libc_calloc -#define fREe __libc_free -#define mALLOc __libc_malloc -#define mEMALIGn __libc_memalign -#define rEALLOc __libc_realloc -#define vALLOc __libc_valloc -#define pvALLOc __libc_pvalloc -#define mALLINFo __libc_mallinfo -#define mALLOPt __libc_mallopt - -#pragma weak calloc = __libc_calloc -#pragma weak free = __libc_free -#pragma weak cfree = __libc_free -#pragma weak malloc = __libc_malloc -#pragma weak memalign = __libc_memalign -#pragma weak realloc = __libc_realloc -#pragma weak valloc = __libc_valloc -#pragma weak pvalloc = __libc_pvalloc -#pragma weak mallinfo = __libc_mallinfo -#pragma weak mallopt = __libc_mallopt +#if !NO_MALLINFO +/* + mspace_mallinfo behaves as mallinfo, but reports properties of + the given space. +*/ +struct mallinfo mspace_mallinfo(mspace msp); +#endif /* NO_MALLINFO */
-#else +/* + malloc_usable_size(void* p) behaves the same as malloc_usable_size; +*/ + size_t mspace_usable_size(void* mem);
-#ifdef USE_DL_PREFIX -#define cALLOc dlcalloc -#define fREe dlfree -#define mALLOc dlmalloc -#define mEMALIGn dlmemalign -#define rEALLOc dlrealloc -#define vALLOc dlvalloc -#define pvALLOc dlpvalloc -#define mALLINFo dlmallinfo -#define mALLOPt dlmallopt -#else /* USE_DL_PREFIX */ -#define cALLOc calloc -#define fREe free -#define mALLOc malloc -#define mEMALIGn memalign -#define rEALLOc realloc -#define vALLOc valloc -#define pvALLOc pvalloc -#define mALLINFo mallinfo -#define mALLOPt mallopt -#endif /* USE_DL_PREFIX */ +/* + mspace_malloc_stats behaves as malloc_stats, but reports + properties of the given space. +*/ +void mspace_malloc_stats(mspace msp);
-#endif +/* + mspace_trim behaves as malloc_trim, but + operates within the given space. +*/ +int mspace_trim(mspace msp, size_t pad);
-/* Public routines */ - -#if __STD_C - -Void_t* mALLOc(size_t); -void fREe(Void_t*); -Void_t* rEALLOc(Void_t*, size_t); -Void_t* mEMALIGn(size_t, size_t); -Void_t* vALLOc(size_t); -Void_t* pvALLOc(size_t); -Void_t* cALLOc(size_t, size_t); -void cfree(Void_t*); -int malloc_trim(size_t); -size_t malloc_usable_size(Void_t*); -void malloc_stats(void); -int mALLOPt(int, int); -struct mallinfo mALLINFo(void); -#else -Void_t* mALLOc(); -void fREe(); -Void_t* rEALLOc(); -Void_t* mEMALIGn(); -Void_t* vALLOc(); -Void_t* pvALLOc(); -Void_t* cALLOc(); -void cfree(); -int malloc_trim(); -size_t malloc_usable_size(); -void malloc_stats(); -int mALLOPt(); -struct mallinfo mALLINFo(); -#endif +/* + An alias for mallopt. +*/ +int mspace_mallopt(int, int);
#ifdef __cplusplus }; /* end of extern "C" */ -#endif +#endif /* __cplusplus */ + +/* + ======================================================================== + To make a fully customizable malloc.h header file, cut everything + above this line, put into file malloc.h, edit to suit, and #include it + on the next line, as well as in programs that use this malloc. + ======================================================================== +*/ + +/* #include "malloc.h" */ diff --git a/lib_ppc/board.c b/lib_ppc/board.c index 155171d..d03ad95 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -662,7 +662,6 @@ void board_init_r (gd_t *id, ulong dest_addr) cmd_tbl_t *cmdtp; char *s; bd_t *bd; - extern void malloc_bin_reloc (void); #ifndef CONFIG_ENV_IS_NOWHERE extern char * env_name_spec; #endif @@ -777,7 +776,6 @@ void board_init_r (gd_t *id, ulong dest_addr)
/* initialize malloc() area */ mem_malloc_init (); - malloc_bin_reloc ();
#if !defined(CONFIG_SYS_NO_FLASH) puts ("FLASH: ");
- k
Here are some size #'s
[galak@blarg u-boot-85xx]$ size u-boot text data bss dec hex filename 392040 50536 41957 484533 764b5 u-boot 397660 49500 42397 489557 77855 u-boot (new dlmalloc)
[galak@blarg u-boot-85xx]$ size common/dlmalloc.o text data bss dec hex filename 4768 1056 56 5880 16f8 common/dlmalloc.o 10390 16 492 10898 2a92 common/dlmalloc.o (new dlmalloc)
old dlmalloc: [galak@blarg u-boot-85xx]$ nm --size-sort common/dlmalloc.o
00000004 b max_sbrked_mem 00000004 b max_total_mem 00000004 d mmap_threshold 00000004 b n_mmaps_max 00000004 d sbrk_base 00000004 b top_pad 00000004 d trim_threshold 00000028 b current_mallinfo 00000038 T cfree 00000040 T malloc_usable_size 00000040 T valloc 00000044 T pvalloc 00000064 T malloc_bin_reloc 000000a0 T mallopt 000000f0 T malloc_trim 0000010c T calloc 00000148 T memalign 00000274 T free 00000408 d av_ 000004a8 T realloc 00000640 T malloc
new dlmalloc:
[galak@blarg u-boot-85xx]$ nm --size-sort common/dlmalloc.o 00000018 b mparams 0000003c T malloc_footprint 0000003c T malloc_max_footprint 0000003c T malloc_usable_size 00000050 T independent_comalloc 00000058 T independent_calloc 00000088 T malloc_trim 0000008c T calloc 00000090 T valloc 000000a0 T pvalloc 000000e8 T mallopt 0000015c T malloc_stats 000001b0 T realloc 000001d4 b _gm_ 000001f4 T memalign 000001fc t sys_trim 00000208 t ialloc 000005ec T free 000014cc T malloc
to say it has increased is an understatement. i cant imagine the upstream code increasing that much. perhaps we had trimmed/customized the implementation so as to shrink it ?
use the bloatcheck script to do a human readable compare between the two objects. you can find it in the linux kernel. -mike
And/or, 'pahole' (Poke-a-hole) or some of the other "7 Dwarves" tools might help shed light on the differences.
LWN article http://lwn.net/Articles/335942/ (how I heard about them) GIT http://git.kernel.org/?p=linux/kernel/git/acme/pahole.git OLS '07 paper http://oops.ghostprotocols.net:81/acme/7dwarves.pdf or http://ols.fedoraproject.org/OLS/Reprints-2007/melo-Reprint.pdf
Tom
Those would help if the data structs had gotten bigger. In this case the code itself is just larger.
- k
Perhaps we should look into using/writing a malloc implementation that takes a space/speed tradeoff more in line with U-boot's requirements (using a simple first-fit linear scan of free blocks, for example) -- and hopefully more readable than dlmalloc?
I nominate those with the tightest space requirements to do this. :-)
-Scott
I agree it's sound a better plan but I'll take a lot's of time
Best Regards, J.
Right, for now we can use the existing malloc with -fno-strict-aliasing.
-Scott
Do we think there is some other project that we can acquire one from?
Right, for now we can use the existing malloc with -fno-strict- aliasing.
I'm all for doing this.
- k
there was another public domain malloc implementation Robin pointed me to recently, but i cant seem to remember/find it. -mike
On Wed 8 Jul 2009 01:58, Mike Frysinger pondered:
It was bget
Kumar Gala wrote: > Those would help if the data structs had gotten bigger. In this > case the code itself is just larger. Perhaps we should look into using/writing a malloc implementation that takes a space/speed tradeoff more in line with U-boot's requirements (using a simple first-fit linear scan of free blocks, for example) -- and hopefully more readable than dlmalloc?
It was bget
The CFE bootloader has a pretty simple malloc implementation. It looks relatively readable and is much smaller than dlmalloc:
ptyser@petert cfe$ size cfe30/lib_malloc.o text data bss dec hex filename 1128 4 0 1132 46c cfe30/lib_malloc.o
http://www.broadcom.com/support/communications_processors/downloads.php
Some other liberally licensed bootloaders such as PMON2000 might have some basic implementations too.
Best, Peter
On 15:02 Tue 07 Jul , Scott Wood wrote: > Kumar Gala wrote: >> Those would help if the data structs had gotten bigger. In this >> case the code itself is just larger. > > Perhaps we should look into using/writing a malloc implementation > that takes a space/speed tradeoff more in line with U-boot's > requirements (using a simple first-fit linear scan of free blocks, > for example) -- and hopefully more readable than dlmalloc? > > I nominate those with the tightest space requirements to do > this. :-)
It was bget
it's trivial to find smaller implementations. i guess the problem we have is that we dont have any guidelines for what we want out of a malloc implementation. i would bet that dlmalloc fairs better than these simple implementations wrt fragmentation, re-use, and freeing. but if our typical u- boot usage does little malloc/free, then this better behavior doesnt really matter to us.
does dlmalloc have any compile time knobs to help direct the functionality actually desired ? -mike
Right; a more specific suggestion would be "codiff" in that package. Though maybe you've already extracted the same information in another way.
Tom
On Tue, 7 Jul 2009 14:50:31 -0500 Kumar Gala galak@kernel.crashing.org wrote:
fyi, gcc4.4.0 apparently doesn't like to emit ld/st multiple insns as much as prior versions did.
NAND bootstraps don't fit, e.g., because of the code density savings ld/st multiples make: e.g., mpc8313erdb.o is 322 bytes text with gcc 4.2.1 and is now 476 bytes text with gcc4.4...
btw, fixes for upstream gcc should be under way in the next couple of days.
Kim
Signed-off-by: Kumar Gala galak@kernel.crashing.org
This is an attempt at using dlmalloc v2.8.4. Its a work in progress, but wanted to post to see what peoples feelings are on updating. This version resolves all the various warnings we see w/gcc4.4 and the older version of dlmalloc however the trade of is the code size has increased.
I still need to see if we need to hand relocate the global structs or not.
This diff is just of malloc.h to see how things are cfg, and of dmalloc.src vs dmalloc.c to see the changes to it.
Nope, the older version is just smaller:
6632 1080 68 7780 1e64 malloc-2.6.6.o 7530 24 888 8442 20fa malloc-2.7.2.o 14386 20 492 14898 3a32 malloc-2.8.4.o
Where, do you mean bloat-o-meter?
- k
participants (8)
Kim Phillips
Kumar Gala
Mike Frysinger
Peter Tyser
Robin Getz
Scott Wood
T Ziomek
