[U-Boot] [RFC] ARM timing code refactoring
Hi All,
I am starting this thread to revive and, hopefully, come to a general agreement on how timers should be implemented and used in the ARM architecture, and get rid of current quick fixes. Let us start with Reinhard's proposal:
There were several suggestions about that in the past (including from me) that involve rework everywhere HZ related timeouts are used. I still prefer a method as follows (because it does not need repeated mul/div calculations nor necessarily 64 bit arithmetic):
Agreed for unnecessary mult-div, but 64-bit we would not avoid, and should not IMO, when the HW has it.
u32 timeout = timeout_init(100); /* 100ms timeout */
do {...} while (!timed_out(timeout));
Internally it would be like:
timeout_init(x): return fast_tick + (x * fast_tick_rate) / CONFIG_SYS_HZ; /* this might need 64 bit precision in some implementations */
time_out(x): return ((i32)(x - fast_tick)) < 0;
If the tick were really high speed (and then 64 bits), fast_tick could be derived by shifting the tick some bits to the right.
The only thing I slightly dislike about the overall idea is the signed rather than unsigned comparison in the timeout function (I prefer using the full 32-bit range, even if only as an academic point) and the fact that the value of the timeout is encoded in advance in the loop control variable 'timeout'.
I'd rather have a single 'time(x)' (or 'ticks_elapsed(x)', names are negotiable) macro which subtract its argument from the current ticks, e.g. 'then = time(0)' would set 'then' to the number of ticks elapsed from boot, while 'now = time(then)' would set 'now' the ticks elapsed from 'then'; and a 'ms_to_ticks(x)' (again, or 'milliseconds(x)') :
#define time(x) (ticks - x) #define ms_to_ticks(m) ( (m * fast_tick_rate) / CONFIG_SYS_HZ)
Note that time(x) assumes unsigned arguments and amounts to an unsigned compare, because we're always computing an difference time, i.e. even with x = 2 and ticks = 1, the result is correct -- that's assuming ticks is monotonous 32-bits (or 64-bits for the platforms that can support it as an atomic value)
Your example would then become
then = time(0); do {...} while ( time(then) < ms_to_ticks(100) );
... moving the actual timeout value impact from the time sample before the 'while' to the 'while' condition at then end.
For expressiveness, added macros such as:
#define now() time(0) #define ms_elapsed(then,ms) ( time(then) < ms_to_ticks(ms) )
... would allow writing the same example as:
then = now(); do {...} while ( !ms_elapsed(then,100) );
But, as long as we cannot agree on something, there will be no time spent to make patches...
Makes sense, hence this specific thread. :)
Best Regards, Reinhard
Amicalement,
Dear Albert ARIBAUD,
Hi All,
time_out(x): return ((i32)(x - fast_tick))< 0;
1. you always need signed compares there, unless you never anticipate a rollover of your timer value to zero. 2. whats the problem with initializing the timeout value at the beginning?
We have exactly an equivalent of this in use at AT91. It works only as long as the ticks value does not roll back to zero - which in the current 64 bit implementation I did is after the end of the universe...
Note also that "fast_tick_rate" would not be a constant in AT91, it is dynamically calculated from main xtal frequency measured against the 32kHz xtal and PLL settings.
Assume: Monotonous AND never wrapping back to zero!
then = time(0); do {...} while ( time(then)< ms_to_ticks(100) );
That looks ugly to me. We don't want to see the high speed(64 bit) values in the drivers - I think.
Which does a multiply and a divide in 64 bit each loop iteration... (fast_tick_rate being a variable)
#define now() time(0) #define ms_elapsed(then,ms) ( time(then)< ms_to_ticks(ms) )
Why make everything so complicated???
The how-many-th thread about timers is this ? :)
Hi All,
- you always need signed compares there, unless you never anticipate a
I don't think rollover to zero is an issue if the tick counter is free-running on 32 (or 64 bits); and if it is free-running on some other number of bits, the time() macro just needs anding to work.
- whats the problem with initializing the timeout value at the beginning?
There isn't a problem as such; simply, as the timeout is not conceptually needed at the beginning of the timing loop, I would favor implementations which do not need it at the beginning either.
Let us take a case where the tick value rolls over 0. Say, ticks is equal to 2^32 - 100, and we should delay for 200 ticks. At the beginning of the loop, 'then' becomes equal to 2^32 - 100. While the loop runs, time(then) equals 'ticks - then', or, '2^32 - 100 + n - (2^32 - 100)', or '2^32 - 100 - 2^32 + 100 +n', or (since we're computing modulo 2^32) '-100 + 100 +n', or 'n', where n is the number of ticks elapsed since 'now' was caculated. When n is 200 or more, the loop end condition is met. Crossing the 0 value did not affect the computation -- or did it?
That's another issue entirely, with two consequences, but they don't really differ with respect to which proposal, yours or mine, is considered.
1. This makes the compiler unable to optimize ms to tick conversions at compile time. Not a really big deal, and unavoidable as soon as the decision is taken to calibrate the fast tick at run time.
2. If calibration is done continuously, then ticks *may* not be monotonous. If it is done once at startup, a la bogomips calculation, then we should be safe.
I think zero wraparound is not an issue if the ticks are on N (ideally, 32 or 64) bits, which is most probably the case for a free-running counter. We need to assume monotonous at least during delay loops; since we have little or no parallel execution, we should be able to avoid recalibration while a delay loop is running, right?
We don't see them, actually; but why would HW tick values would be unwelcome in drivers that already handle, and actually are designed to handle, lots of other HW related values? And besides, how does this differ from your proposal in this respect?
Not if the compiler is half decent; it will optimize out the constant expression. And if you don't trust the compiler, you can pre-compute the value of the delay.
I am surprised by this question. The last point I make is to simplify things, not complicate them, and besides, it is only for expressiveness and clarity of the code.
The last one, trust me. :)
Amicalement,
this is not an ARM local issue.
The timeouts are used in generic drivers all around u-boot.
Have a grep for get_timer, reset_timer...
The most ugly use is with reset_timer involved, where the internal pseudo-tick is reset to zero, so all calls to get_timer are relative to that moment.
We are looking at replacing all those occurrences of reset_timer and get_timer with "better" methods.
Hi Reinhard,
Well, there *is* an ARM specific side of it (use of gd variables during relocation), and that is what prompted me to start the RFC, but generalization to U-boot is welcome if it leads to a satisfactory solution. If not, at least I'll adopt a solution for ARM.
Seems to me this replacement is quite straightforward, as most uses of reset_timer() and subsequent get_timer are actually loops, functionally the same as our proposals, only instead of using a local to store the start or end time, they reset ticks to zero -- which, I concur, is a Bad Thing.
But 'reset_timer()' calls just need to be replaced with your 'timeout = timeout_init(N)' or my 'then = now()' and 'get_timer() > N' or 'get_timer_masked() > N' by your 'time_out(timeout)' or my 'ms_elapsed(N)'. Seems to me like a tedious effort, possibly involving occasional time-out value conversions, but not a difficulty.
What do I miss?
Amicalement,
When attempting to come up with true generic code, we should probably _always_ use a (virtual) unsigned 64 bit counter.
Please don't. Use an unsigned counter and allow it to roll over. Anything else causes additional (and unnecessary) restrictions and makes the code more complicated.
I'm not sure what you have in mind with "substract". I strongly recommend to avoid problems with wrap-around etc. right from the beginning, and let unsigned arithmentcs handle this for us.
Do we really need such a function? As far as I can tell we don't really have any time (in the sense of wallclock time) related requirements, we only need delta times, and nobody really cares about the starting point.
We should _always_ be able to use the standard approach of
start = get_timer()
while ((get_timer() - start) < timeout) { ... wait ... }
We should NOT do this. It is bound to break as soon as the code in the loop (the "..." part) needs to implement a timeout, too.
This is not a good isea for the same reason.
Hi Wolfgang,
That's fine with me. We'll just have to keep in mind that with a 32-bit HW counter, the upper 32 bits of the 64-bit virtual counter must be managed by SW -- which should not prove to be too much of a problem, but will force us to handle HW-to-SW rollovers in get_timer() on each virtual timer reads.
Hmm... don't we actually agree here? I was also expressing my preference for unsigned.
That's what I meant with my comment about subtracting: the difference of two unsigned integers is always correct.
Hmm... My idea with providing time() with an argument was that precisely since we are interested only in elapsed time, not absolute time, our basic time function should be able to tell us relative times.
start = get_timer()
while ((get_timer() - start)< timeout) { suall ... wait ... }
Functionally this is the same as what I suggested, minus the absolute get_timer() vs relative time(x) call. Either way works, I'm not going to try and make a point that we use "my" time(x).
We still need ms-to-tick and us-to-tick conversions, though, because usually timing constraints will be expressed in us or ms, not in ticks.
Just one thing, however:
I'm not sure to understand why. Can you develop how you think this would break with an inner timeout?
Those two were just syntactic sugaring anyway; if you don't like them, no worries.
Amicalement,
Yes.
I'm happy if we agree. I just wan't sure.
Good.
The disadvantage of this approach is that such calls cannot be nested, i. e. you must always make sure that the code run within the timeout loop does not attempt to set up a timeout on it's own. From my point of view, this is a killing point.
See above for the fundamental difference - not in the implementation for a single timeout, but from a system-wide point of view.
Sure:
/* implement something which needs a 100 ms timeout */ then = time(0);
do { int then_nested; ... do something... ... do more... /* now do something which needs a 5 ms timeout */ then_nested = time(0); do { ... } while (time(then_nested) < ms_to_ticks(5));
} while (time(then) < ms_to_ticks(100));
You see the problem?
Dear Wolfgang Denk,
With all this half quoting and deleting of important parts, my original proposal was lost again.
If you really care to look at it, it
1. does not have issues with rollover 2. does not have problems with nested timeouts 3. does 64 bit mul/div calculations only once at the begin of a timeout 4. is easy and straightforward to use 5. needs very few lines of code to implement
Calculating the end time at the begin of a loop is not a problem, I am not aware of any timeout loops where the timeout value needs to be changed inside the loop.
Reinhard
Dear Reinhard Meyer,
This is a prettyu long running thread, and I am not exactly sure what your original proposal actually was. Could you please post a reference?
Dear Wolfgang Denk,
I just repost here:
I dislike this approach. I immediately fear the same problem I just saw (incorrectly) in Albert's proposal - timeout_init() seems to store the timeouut information in some internal varoable, which is then checked by timed_out() - this is bound to fail as soon as somebody atttempts to nest timeouts.
Your implementation may be different, but you can bet sooner or later comes up with such a bugy implementation.
And it is not needed.
PLease see my proposal: we do not needs several timer or timeout related functions, all we need is a plain "get timer" function, without any arguments. And the resulting code makes it obvious to the reader that such loops can be nested as you like.
I have no idea what "fast_tick" versus "tick" means here, nor why we would need more than one tick.
Dear Wolfgang Denk,
Excuse me: the timeout info is stored in the user's variable "timeout", that should be quite obvious!
Nested timeouts pose no problem as long as the user uses different (local) vars to store the return value of timeout_init().
There is nothing buggy.
If you demand that this get_timer returns in HZ units, that will not be possible on most hardware without complicated code. We have discussed that long ago...
Well, you could try to understand: tick=the "at hardware speed running" timer, if that's incrementing too fast for 32 bit "timeout" vars for reasonable timeouts (up to a minute?), it could be divided by a power of two before use, or we plainly use u64 for the "timeout" variables; probably simpler than shifting...
Reinhard
Is it? Why? It could be as well that timeout_init(100) keeps some internal information about an initialized timeout - the name suggests it.
Yes, but you need to see the implementation of timeout_init() and timed_out() to make sure.
Not in your proposal - but the interface allows (or even invites) to come up with incorrect implementations, and history has shown that we don't catch all of these. So let's chose an interface which has no such problems.
If we agree on get_timer(), then indeed the resolution shall ne milliseconds, as this is how this function is defined.
On the other hand, milliseconds are too long for some types of timeouts, so for short timeouts we would use get_ticks().
For reference, please see the PPC implementation (in arch/powerpc/lib/ticks.S, arch/powerpc/lib/time.c, arch/powerpc/lib/interrupts.c).
At the moment I would suggest to change the existing interface like that:
* Drop the set_timer() function.
* Change get_timer() to take no argument, i. e.:
unsigned long get_timer(void);
get_timer() returns a monotonous upward counting time stamp with a resolution of milliseconds. After reaching ULONG_MAX the timer wraps around to 0.
The get_timer() implementation may be interrupt based and is only available after relocation.
* Provide a fast, low-level, system dependent timer function
unsigned long long get_ticks(void);
get_ticks() returns a monotonous upward counting time stamp with a system-specific resolution. No assumptions should be made about the resolution. After reaching ULLONG_MAX the timer wraps around to 0.
It is mandatory that get_ticks() is available before relocation.
* Provide a set of utility functions:
-> void wait_ticks(unsigned long ticks);
Delay execution for "ticks" ticks.
-> unsigned long usec2ticks(unsigned long usec);
Convert microseconds into ticks; intended for SHORT delays only (maximum depending on system clock, usually below 1 second).
-> void __udelay(unsigned long usec);
Delay execution for "usec" microseconds; intended for SHORT delays only (maximum depending on system clock, usually below 1 second). If all architectures followed the above suggestion, we could move the PPC implementation to common code:
void __udelay(unsigned long usec) { ulong ticks = usec2ticks(usec); wait_ticks(ticks); }
__udelay() can reliably be used before relocation.
-> void udelay(unsigned long usec)
Similar to __udelay() with the additional functionality to trigger the watchdog timer for long delays.
I am aware of this.
See above. For short, high resolution timeouts you can use get_ticks() and friends. For long delays you can use get_timer().
Note that "reasonable timeouts (up to a minute?)" are only very infrequently needed, and don't need the high resolution of get_ticks(), so these would naturally be implemented on the base of get_timer().
We have been using this implementation for more than a decade on PowerPC. The only thing you need is a monotonous upward counting 64 bit "time base" counter where you can read the system ticks from.
I am aware of this.
This proposal covers what I was thinking of (oubviously I had not looked into PPC implementations) and the few differences with my proposal are not worth fighting over, so overall I am fine with the above.
Let us hear from others now, and if we reach an agreement, then we'll start discussing implementation.
Amicalement,
Exactly that wrap makes the situation so complicated, since the simple code u32 get_timer(void) { return (ticks * 1000ULL) / tickspersec; } won't do that wrap.
Currently it is used before relocation in some places, I think I have seen it in NAND drivers... That would have to be changed then.
- Provide a fast, low-level, system dependent timer function
- Provide a set of utility functions:
I am aware of this.
Amicalement,
This is already implemented functionally very closely (apart from factoring and the get_timer(void) change) to this in AT91, the only (academic) hitch is that it will burp a few billion years after each reset :)
Check arch/arm/cpu/arm926ejs/at91/timer.c
What bothers me is the need for 64 bit mul/div in each loop iteration, for CPUs without hardware for that this might slow down data transfer loops of the style
u32 start_time = get_timer(); do { if ("data_ready") /* transfer a byte */ if (get_timer() - start_time > timeout) /* fail and exit loop */ } while (--"bytestodo" > 0);
since get_timer() will be somewhat like:
return (tick * 1000ULL) / tickspersec;
As I stated before, tickspersec is a variable in, for example, AT91. So the expression cannot be optimized by the compiler.
Reinhard
I am aware of this.
Amicalement,
look at u-boot-atmel.git, rework101229 branch, this reworked version already is minus the reset_timer() function that is not needed anymore
u32 start_time = get_timer(); do { if ("data_ready") /* transfer a byte */ if (get_timer() - start_time> timeout) /* fail and exit loop */ } while (--"bytestodo"> 0);
Reinhard _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Do you have a better suggestion?
Indeed. It is unreliable or even broken now.
I don't think this is the only way to implement this. How does Linux derive time info from jiffies?
This is already implemented functionally very closely (apart from factoring and the get_timer(void) change) to this in AT91, the only (academic) hitch is that it will burp a few billion years after each reset :) What bothers me is the need for 64 bit mul/div in each loop iteration, for CPUs without hardware for that this might slow down data transfer loops of the style
Hi All, In order to avoid doing 64 bit math, we can define a "jiffie" or a "bogo_ms" that is the 64 bit timebase shifted right such that the lsb of the bottom 32 bits has a resolution of between 0.5 ms and 1 ms. It is then possible to convert the difference between two jiffie/bogo_ms values to a number of ms using a 32 bit multiply and a right shift of 16 bits, with essentially negligible error. get_bogo_ms() would return a 32 bit number in bogo_ms, thus the timing loop would be written.
u32 start_time = get_bogo_ms(); do { if ("data_ready") /* transfer a byte */ if (bogo_ms_to_ms(get_timer() - start_time)> TIMEOUT_IN_MS) /* fail and exit loop */ } while (--"bytestodo"> 0);
u32 get_bogo_ms() { u64 tick; read(tick);
return (tick>> gd->timer_shift); } u32 bogo_ms_to_ms(u32 x) { /* this code assumes the resulting ms will be between 0 and 65535, or 65 seconds */ return ((x * gd->cvt_bogo_ms_to_ms)>> 16); /* cvt_bogo_ms_to_ms is a 16 bit binary fraction */ }
All the above code assumes timeouts are 65 seconds or less, which I think is probably fair. Conversion of ms values up to 65 seconds to bogo_ms is also easy, and a 32 bit multiplied result is all that is required. What is not so easy is converting a 32 bit timer value to ms. It can be done if the CPU can do a 32 by 32 multiply to produce a 64 bit result, use the msb, and possibly correct the result by an add if bit 32,of the timer is set. You need a 33 bit counter in bogo_ms to get a monotonic, accurate 32 bit counter in ms. The powerpc can use a mulhw operation to do this, and any CPU that will produce a 64 bit product can do this. However, many CPUs do not produce 64 bit products easily. Using division to do these operations are even less appealing, as many CPUs do not provide hardware division at all. Since it is not necessary to do this conversion to easily use timeouts with 1 ms resolution and accuracy, I think the idea of not using a timer in ms but rather bogo_ms/jiffies is possibly better?
Best Regards, Bill Campbell
That is assuming a 64-bit timebase, isn't it? for CPUs / SoCs that don't have such a timebase but only a 32-bit timer, the bogo_ms/jiffy would not go through the full 32-bit range, which would cause issues with the timing loops on rollover -- and while a timeout of more than 65 sec may not be too likely, a timeout starting near the wraparound value of bogo_ms still could happen.
Besides, the 'tick' unit of time makes physical sense but the bogo_ms would not, while still not being a common timing value -- reminds me of my ms_to_ticks conversion macro that Wolfgang did not like.
In a more general perspective, I'd like to see where where exactly we need 64-bit multiply/divide operations in Wolfgang's proposal before we try to get rid of it. In my understanding:
- get_timer() works in pure ticks, not ms, and thus does not need multiply/divide; it may at most need to implement a carry over from 32 bit to 64 bits *if* the HW counter is 32 bits *and if* we want a 64-bit virtual counter.
- get_time() works in ms, and thus needs scale conversion, so possibly a multiply/divide but possibly some other method, to convert a tick value to an ms value.
That's where I come back to one point of my proposal: if we can get a general framework for get_timer() to return a 64-bit free-running tick value, then we might not need a ms-based get_time() at all, because we could use get_timer() as well for ms timings, provided we can convert our timeout from ms to ticks, i.e.
/* let's wait 200 milliseconds */ /* Timing loop uses ticks: convert 200 ms to 'timeout' ticks */ timeout = ms_to_ticks(200); u32 start = get_timer(); /* start time, in ticks */ do { ... } while ( (get_timer() -start) < timeout);
This way, a timing loop would not involve anything more complex than a 64-bit subtraction and comparison; the only division/multiplication involved would be in the timeout computation, out of the loop.
Amicalement,
Dear all,
its quite funny to see how we go around in circles here, this proposal of Albert now is quite close to my original proposal. Only that I factored the ms_to_ticks AND the comparison into the timer calls:
u64 timer_setup(u32 timeout_in_ms) { return get_ticks() + ms_to_ticks(timeout_in_ms); }
int timer_expired(u64 endtime) { /* * convert the unsigned difference to signed, to easyly * check for "carry". In assembly we could just do a BCC * after the subtraction to see whether get_ticks() * has passed ahead of endtime. */ return (signed)(endtime - get_ticks()) < 0; }
What can be more pragmatic and trivial than those two functions??
Usage then:
/* let's wait 200 milliseconds */ u64 endtime = timer_setup(200); do { ... } while (!timer_expired(endtime));
We have that already at least on PowerPC and AT91. Its called u64 get_ticks(void) and returns a free running 64 bit value. An associated function, u64 get_tbclk(void) returns the frequency of that tick.
I don't think that this part of the framework needs to be discussed - except *maybe* for function names.
Mandatory u64 for start AND timeout, please. It is the same functionality as my proposal, just bears more places where "users" might make mistakes.
But I am sure that Wolfgang will not like either of our proposals, because the variables used in "userspace" are not in ms.
Reinhard
In message 4D3D2F34.6020903@emk-elektronik.de you wrote:
Dear all,
No. I said this severaltimes before, and I repeat it here one other time: I do not want to see such a function. There nothing to be done to "set up a timer".
Are you sure this is really working? Why do you insist on this approach instead of using the proven to be correct way to write this?
No. I do not see any reason to change existing interfaces.
If ticks are wanted, then use get_ticks(). And deal with the overhead or 64 bit arithmetics.
But in general code I prefer get_timer() - milliseconds, u32.
Am 24.01.2011 um 08:24 schrieb Albert ARIBAUD:
I agree with the possibility of wrap around near the end of u32 'bogo_ms' counter. Therefore we do need to define some constraints for such a '64 bit free running tick counter'. It could be implemented to overflow in some seconds as the u32 bogo_ms would do.
I also dislike to have another virtual physical dimension defined here.
You may think about the following change to this proposal:
/* lets wait 200 ms */ /* get the end point of our timeout in ticks */ u64 timeout_end = get_timer() + ms_to_ticks(200); do { ... } while ( get_timer() < timeout_end);
If I got Reinhard's proposal correct this is exactly what he meant. He call it 'timer_init(timeout_val)' and 'is_timeout()' but I feel this is exactly what he described.
First we calculate the timeout in ticks, then just compare the 'now()' value with the end point of the timeout loop. I claim this approach is a bit better than yours on systems that can not do 64 bit instructions natively.
You forgot to mention the 'ms_to_ticks()' could be pre-calculated by preprocessor in most cases. This may be a huge performance gain in most cases.
regards
Andreas Bießmann
Hi Andreas,
/* let's wait 200 milliseconds */ /* Timing loop uses ticks: convert 200 ms to 'timeout' ticks */ timeout = ms_to_ticks(200); u32 start = get_timer(); /* start time, in ticks */ do { ... } while ( (get_timer() -start)< timeout);
/* lets wait 200 ms */ /* get the end point of our timeout in ticks */ u64 timeout_end = get_timer() + ms_to_ticks(200); do { ... } while ( get_timer()< timeout_end);
The problem here is that in the loop exit condition you replace a difference between two unsigned times (which always yields the correct duration) with a comparison of two dates (which does not).
For instance, if at loop entry get_timer() was, say, 10 ticks to rollover and the loop timing was 12 ticks, you end up with an end date of 2. If your loop body runs long enough, get_timer() may already have gone past this and will this stay greater than timeout_end for a very long time.
OTOH, using get_timer() on entry of loop and subtracting it from get_timer() at each loop iteration always yields the time elapsed, unaffected by rollover. You can then safely compare this elapsed time with the time-out value.
Amicalement,
I should always wait for the coffee to produce its effect before posting. The right example is having timeout_end *not* have rolled over (thus being a very high number) and the loop body being long enough that get_timer() is called at the first loop condition test *after* rollover, thus being very small.
Amicalement,
Amicalement,
Hi Albert,
Am 24.01.2011 12:58, schrieb Albert ARIBAUD:
Hi Andreas,
Ok, I got your point.
regards
Andreas Bießmann
No. There is get_ticks(), which operates on ticks, and there is get_timer(), which returns milliseconds.
Then you will always have to use 64 bit variables for all related operations. Note that get_timer() returns "unsigned long"", which allows for smaller code in the majority of use cases.
That is assuming a 64-bit timebase, isn't it? for CPUs / SoCs that don't > have such a timebase but only a 32-bit timer, the bogo_ms/jiffy would > not go through the full 32-bit range, which would cause issues with the > timing loops on rollover -- and while a timeout of more than 65 sec may > not be too likely, a timeout starting near the wraparound value of > bogo_ms still could happen.
Sorry, but I don't get it. What exactly is the problem with a 32 bit counter, and why would it not go through the full 32-bit range?
In message4D3D2942.4060600@free.fr you wrote:
That is assuming a 64-bit timebase, isn't it? for CPUs / SoCs that don't> have such a timebase but only a 32-bit timer, the bogo_ms/jiffy would> not go through the full 32-bit range, which would cause issues with the> timing loops on rollover -- and while a timeout of more than 65 sec may> not be too likely, a timeout starting near the wraparound value of> bogo_ms still could happen.
Hi All, If you use my approach of shifting right by n bits (in order to get a counter that has "about" 1 ms resolution), zeros are shifted into the top. The counter would never reach more than (32-n) bits in magnitude. This is easily fixed by creating a "virtual" n msbs for the counter, as must be done if a 64 bit counter is to be simulated. Actually, I only need "n" bits, but in any case it requires detecting that the counter has "backed up" mod 32 bits and if so, increase the virtual counter by 1.
If you really, really, really want a timer that "ticks" at a 1 ms rate, instead of bogo_ms/jiffies, I propose the following:
u32 get_time() { u32 delta_t_bogo_ms; u32 t_save; #if defined(TIMER_IS_64_BITS) u64 tick; read(&tick);
t_save = tick >> gd->timer_shift; delta_t_bogo_ms = t_bogo_ms - gd->prev_timer; #else read(t_save); delta_t_bogo_ms = (t_save - gd->prev_timer) >> gd->timer_shift; #endif gd->prev_timer = t_save; /* save previous counter */ if (delta_t_bogo_ms < gd->bogo_ms_per_65_sec) { gd->fract_timer += delta_t_bogo_ms * gd->cvt_bogo_ms_to_ms; /* accumulate fraction of ms */ gd->timer_in_ms += gd->fract_timer >> 16; gd->fract_timer &= 0X0000FFFF; } else gd->fract_timer = 0; /* start accumulating from 0 fraction */ return(gd->timer_in_ms) }
This routine will create a timer in ms, that will be accurate as long as this routine is called either once about ever 65 seconds or once per time base rollover, whichever is less. Nested timer use is ok. If the timer is not called frequently enough, it will return the same value twice, but after that it will start timing normally. This shouldn't matter, as the second returned value will be the start of a timing loop. Timeout values can be the full 32 bits, as long as you keep calling the routine frequently enough. No initialization is required. Note that you can (and probably should) use the bottom 32 bits of the hardware timebase as a 32 bit timebase unless the clock would overflow in 65 seconds (running faster than about 66 MHz), or if you want to relax the 65 seconds. If you want to save a word in the gd data, use 0X10000 instead of bogo_ms_per_65_sec (or a more precise value if you know it). Note that gd->timer_shift and gd->cvt_bogo_ms_to_ms can also be replaced by constants if the clock speed is fixed.
This is more expensive than using the bogo_ms timer, but does have the advantage that everything is in ms. FWIW, I think converting from ms to some other unit for loop control is fine, as long as we have a standard routine to do that that is "cheap". However, others may not agree. For sure, passing around 64 bit tick values to do this process is, IMHO, vast overkill and not a good general solution, as many processors really don't like to do 64 bit operations.
Best Regards. Bill Campbell
Sure:
do { int then_nested; ... do something... ... do more... /* now do something which needs a 5 ms timeout */ then_nested = time(0); do { ... } while (time(then_nested)< ms_to_ticks(5));
} while (time(then)< ms_to_ticks(100));
Actually no, I don't. As a reminder, I am considering the following definitions:
#define time(n) (ticks-n) #define ms_to_ticks(ms) (ms * fast_tick_rate) / CONFIG_SYS_HZ
Neither of these has any side effect, so I am at loss as to why that would break when used in nested loops; each loop has its own reference start time by assigning time(0) to its own variable (then and then_nested), and each has its own elapsed time computation by passing its own variable to time() and comparing with its own constant timeout value. Can you point the exact instruction that would break in the code above, and why it would?
Amicalement,
Ah, I see. Well, I have to admit that I did not see this part; but then, it is still similar to what the current get_timer(t) call is doing (at least in it's reference implementation on PowerPC, cf. arch/powerpc/lib/interrupts.c), except that no set_timer(t) is provided.
In acy case - I vote to get rid of this funktion to set some "time base value", and provide a plain void call interface to get_timer() [or whatever the corresponding function would be called].
Also, I vote to always explicitly write the timeout loop as I gave in the example, because this makes the meachnism clear to the reader of the code - hiding it in macros or functions may only lead to conusions or different (and broken) implementations across architectures.
My reading was that "time(0)" would perform some reset of a variable to give a wrap-around free starting point. Sorry for not reading all of the previous context.
I don't see any use of the extra argument to the time() function / macro, nor any need / use for such a function / macro at all.
participants (5)
Albert ARIBAUD
Andreas Bießmann
J. William Campbell
Reinhard Meyer
