[PATCH V2] spi: imx: Implement set_speed
The set_speed() callback should configure the bus speed, make it so.
Signed-off-by: Marek Vasut marex@denx.de Cc: Jagan Teki jagan@amarulasolutions.com Cc: Stefano Babic sbabic@denx.de --- V2: Rename dev_get_platdata() to dev_get_plat() --- drivers/spi/mxc_spi.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index 553a0315df5..7449d9c72cc 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -661,7 +661,10 @@ static int mxc_spi_release_bus(struct udevice *dev)
static int mxc_spi_set_speed(struct udevice *bus, uint speed) { - /* Nothing to do */ + struct mxc_spi_slave *mxcs = dev_get_plat(bus); + + mxcs->max_hz = speed; + return 0; }
Jagan, any news on this patch ?
Applied to u-boot-spi/master
Bin Meng
Jagan Teki
