[U-Boot] [PATCH] powerpc/t1040qds: Remove Video - HDMI support
We should remove this support. First, there is not any documents to say we need to support this feature, and kernel also not support this feature. Second, Kerneal not support this on T1040QDS, so if we open it in u-boot, FPGA will be changed and that will affect deep sleep feature.
Signed-off-by: Wang Dongsheng dongsheng.wang@freescale.com
diff --git a/board/freescale/t1040qds/Makefile b/board/freescale/t1040qds/Makefile index 19ed21b..c7470d7 100644 --- a/board/freescale/t1040qds/Makefile +++ b/board/freescale/t1040qds/Makefile @@ -10,4 +10,3 @@ obj-$(CONFIG_PCI) += pci.o obj-y += law.o obj-y += tlb.o obj-y += eth.o -obj-y += diu.o diff --git a/board/freescale/t1040qds/diu.c b/board/freescale/t1040qds/diu.c deleted file mode 100644 index 0214224..0000000 --- a/board/freescale/t1040qds/diu.c +++ /dev/null @@ -1,97 +0,0 @@ -/* - * Copyright 2014 Freescale Semiconductor, Inc. - * Author: Priyanka Jain Priyanka.Jain@freescale.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <command.h> -#include <linux/ctype.h> -#include <asm/io.h> -#include <stdio_dev.h> -#include <video_fb.h> -#include <fsl_diu_fb.h> -#include "../common/qixis.h" -#include "../common/diu_ch7301.h" -#include "t1040qds.h" -#include "t1040qds_qixis.h" - -/* - * DIU Area Descriptor - * - * Note that we need to byte-swap the value before it's written to the AD - * register. So even though the registers don't look like they're in the same - * bit positions as they are on the MPC8610, the same value is written to the - * AD register on the MPC8610 and on the P1022. - */ -#define AD_BYTE_F 0x10000000 -#define AD_ALPHA_C_SHIFT 25 -#define AD_BLUE_C_SHIFT 23 -#define AD_GREEN_C_SHIFT 21 -#define AD_RED_C_SHIFT 19 -#define AD_PIXEL_S_SHIFT 16 -#define AD_COMP_3_SHIFT 12 -#define AD_COMP_2_SHIFT 8 -#define AD_COMP_1_SHIFT 4 -#define AD_COMP_0_SHIFT 0 - -void diu_set_pixel_clock(unsigned int pixclock) -{ - unsigned long speed_ccb, temp; - u32 pixval; - int ret = 0; - speed_ccb = get_bus_freq(0); - temp = 1000000000 / pixclock; - temp *= 1000; - pixval = speed_ccb / temp; - - /* Program HDMI encoder */ - /* Switch channel to DIU */ - select_i2c_ch_pca9547(I2C_MUX_CH_DIU); - - /* Set dispaly encoder */ - ret = diu_set_dvi_encoder(temp); - if (ret) { - puts("Failed to set DVI encoder\n"); - return; - } - - /* Switch channel to default */ - select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); - - /* Program pixel clock */ - out_be32((unsigned *)CONFIG_SYS_FSL_SCFG_PIXCLK_ADDR, - ((pixval << PXCK_BITS_START) & PXCK_MASK)); - /* enable clock*/ - out_be32((unsigned *)CONFIG_SYS_FSL_SCFG_PIXCLK_ADDR, PXCKEN_MASK | - ((pixval << PXCK_BITS_START) & PXCK_MASK)); -} - -int platform_diu_init(unsigned int xres, unsigned int yres, const char *port) -{ - u32 pixel_format; - u8 sw; - - /*Route I2C4 to DIU system as HSYNC/VSYNC*/ - sw = QIXIS_READ(brdcfg[5]); - QIXIS_WRITE(brdcfg[5], - ((sw & ~(BRDCFG5_IMX_MASK)) | (BRDCFG5_IMX_DIU))); - - /*Configure Display ouput port as HDMI*/ - sw = QIXIS_READ(brdcfg[15]); - QIXIS_WRITE(brdcfg[15], - ((sw & ~(BRDCFG15_LCDPD_MASK | BRDCFG15_DIUSEL_MASK)) - | (BRDCFG15_LCDPD_ENABLED | BRDCFG15_DIUSEL_HDMI))); - - pixel_format = cpu_to_le32(AD_BYTE_F | (3 << AD_ALPHA_C_SHIFT) | - (0 << AD_BLUE_C_SHIFT) | (1 << AD_GREEN_C_SHIFT) | - (2 << AD_RED_C_SHIFT) | (8 << AD_COMP_3_SHIFT) | - (8 << AD_COMP_2_SHIFT) | (8 << AD_COMP_1_SHIFT) | - (8 << AD_COMP_0_SHIFT) | (3 << AD_PIXEL_S_SHIFT)); - - printf("DIU: Switching to monitor @ %ux%u\n", xres, yres); - - - return fsl_diu_init(xres, yres, pixel_format, 0); -} diff --git a/board/freescale/t1040qds/t1040qds.h b/board/freescale/t1040qds/t1040qds.h index 5041f37..79bdeda 100644 --- a/board/freescale/t1040qds/t1040qds.h +++ b/board/freescale/t1040qds/t1040qds.h @@ -9,6 +9,5 @@
void fdt_fixup_board_enet(void *blob); void pci_of_setup(void *blob, bd_t *bd); -int select_i2c_ch_pca9547(u8 ch);
#endif diff --git a/board/freescale/t1040qds/t1040qds_qixis.h b/board/freescale/t1040qds/t1040qds_qixis.h index 98d2d39..2ce8795 100644 --- a/board/freescale/t1040qds/t1040qds_qixis.h +++ b/board/freescale/t1040qds/t1040qds_qixis.h @@ -13,18 +13,6 @@ #define BRDCFG4_EMISEL_MASK 0xE0 #define BRDCFG4_EMISEL_SHIFT 5
-/* BRDCFG5[0:1] controls routing and use of I2C3 & I2C4 ports*/ -#define BRDCFG5_IMX_MASK 0xC0 -#define BRDCFG5_IMX_DIU 0x80 - -/* BRDCFG15[3] controls LCD Panel Powerdown*/ -#define BRDCFG15_LCDPD_MASK 0x10 -#define BRDCFG15_LCDPD_ENABLED 0x00 - -/* BRDCFG15[6:7] controls DIU MUX selction*/ -#define BRDCFG15_DIUSEL_MASK 0x03 -#define BRDCFG15_DIUSEL_HDMI 0x00 - /* SYSCLK */ #define QIXIS_SYSCLK_66 0x0 #define QIXIS_SYSCLK_83 0x1 diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index f4c8547..61bffce 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -375,7 +375,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) -#define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024) +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024)
/* Serial Port - controlled on board with jumper J8 * open - index 2 @@ -401,26 +401,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
-/* Video */ -#define CONFIG_FSL_DIU_FB -#ifdef CONFIG_FSL_DIU_FB -#define CONFIG_FSL_DIU_CH7301 -#define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) -#define CONFIG_VIDEO -#define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE -#define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_VIDEO_LOGO -#define CONFIG_VIDEO_BMP_LOGO -#define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS -/* - * With CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS, flash I/O is really slow, so - * disable empty flash sector detection, which is I/O-intensive. - */ -#undef CONFIG_SYS_FLASH_EMPTY_INFO -#endif - /* pass open firmware flat tree */ #define CONFIG_OF_LIBFDT #define CONFIG_OF_BOARD_SETUP @@ -446,11 +426,6 @@ unsigned long get_board_ddr_clk(void);
/* I2C bus multiplexer */ #define I2C_MUX_CH_DEFAULT 0x8 -#define I2C_MUX_CH_DIU 0xC - -/* LDI/DVI Encoder for display */ -#define CONFIG_SYS_I2C_LDI_ADDR 0x38 -#define CONFIG_SYS_I2C_DVI_ADDR 0x75
/* * RTC configuration @@ -728,7 +703,6 @@ unsigned long get_board_ddr_clk(void); "bank_intlv=cs0_cs1;" \ "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ "netdev=eth0\0" \ - "video-mode=fslfb:1024x768-32@60,monitor=dvi\0" \ "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \ "tftpflash=tftpboot $loadaddr $uboot && " \
Hello Dongsheng,
We do have requirement to support this that's why code development was done. Also , what is the dependency of deep-sleep on this. Please elaborate And if something is broken, we should fix it. Instead of removing the feature.
Regards Priyanka
-----Original Message----- From: Dongsheng Wang [mailto:dongsheng.wang@freescale.com] Sent: Friday, April 18, 2014 1:09 PM To: Sun York-R58495 Cc: Jain Priyanka-B32167; Wood Scott-B07421; u-boot@lists.denx.de; Wang Dongsheng-B40534 Subject: [PATCH] powerpc/t1040qds: Remove Video - HDMI support
- Copyright 2014 Freescale Semiconductor, Inc.
- Author: Priyanka Jain Priyanka.Jain@freescale.com
- DIU Area Descriptor
- Note that we need to byte-swap the value before it's written to the
AD
- register. So even though the registers don't look like they're in
the same
- bit positions as they are on the MPC8610, the same value is written
to the
- AD register on the MPC8610 and on the P1022.
- u32 pixval;
- int ret = 0;
- temp *= 1000;
- if (ret) {
return;
- /* enable clock*/
- u32 pixel_format;
- u8 sw;
- open - index 2
- With CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS, flash I/O is really slow,
so
- disable empty flash sector detection, which is I/O-intensive.
- RTC configuration
-- 1.8.5
-----Original Message----- From: Jain Priyanka-B32167 Sent: Friday, April 18, 2014 4:26 PM To: Wang Dongsheng-B40534; Sun York-R58495 Cc: Wood Scott-B07421; u-boot@lists.denx.de; Wang Dongsheng-B40534 Subject: RE: [PATCH] powerpc/t1040qds: Remove Video - HDMI support
Hello Dongsheng,
If we have, why kernel doesn't support DIU on T1040QDS? That I must remove it reason.
Regards, -Dongsheng
Regards Priyanka
AD
the same
to the
- u32 pixval;
- int ret = 0;
- temp *= 1000;
- if (ret) {
return;
- /* enable clock*/
- u32 pixel_format;
- u8 sw;
- open - index 2
so
- RTC configuration
-- 1.8.5
Hello Dongsheng,
Guys,
Do we have an agreement if this feature should be kept or removed?
York
Hi York,
Sorry for late response. We don't need to remove this patch. Please keep this patch.
Regards, Dongsheng
-----Original Message----- From: Sun York-R58495 Sent: Thursday, August 07, 2014 1:17 AM To: Wang Dongsheng-B40534; Jain Priyanka-B32167 Cc: Wood Scott-B07421; u-boot@lists.denx.de Subject: Re: [PATCH] powerpc/t1040qds: Remove Video - HDMI support
Hello Dongsheng,
reason.
Guys,
York
Hi York,
Sorry, I'm wrong. Please drop the "powerpc/t1040qds: Remove Video - HDMI support" patch.
Cause of we need to keep u-boot support to QDS-DIU feature.
Regards, Dongsheng
-----Original Message----- From: Wang Dongsheng-B40534 Sent: Thursday, August 07, 2014 10:22 AM To: Sun York-R58495; Jain Priyanka-B32167 Cc: Wood Scott-B07421; u-boot@lists.denx.de Subject: RE: [PATCH] powerpc/t1040qds: Remove Video - HDMI support
Hi York,
Regards, Dongsheng
Hello Dongsheng,
the feature.
reason.
Guys,
York
On Fri, Apr 18, 2014 at 4:32 AM, Dongsheng.Wang@freescale.com Dongsheng.Wang@freescale.com wrote:
Because no one added that support yet. You should finish the job by fixing the kernel.
Hold on this. Let's sort it out before removing this feature. It was developed for a reason.
York
participants (5)
Dongsheng Wang
Priyanka Jain
Timur Tabi
York Sun
