[PATCH 0/2] rockchip: Fix ethernet on Radxa ROCK Pi E v1.21
Ethernet on a Radxa ROCK Pi E v1.21 with a RTL8211F ethernet PHY currently fails with the following message:
Could not get PHY for ethernet@ff540000: addr -1
This happens because the ethernet PHY is never reset before a phy-id is read back from the MDIO bus.
This series fixes this issue by calling eth_phy_set_mdio_bus() from the designware ethernet driver to issue a PHY reset before the phy_connect() call.
With the driver change and DM_ETH_PHY and PHY_REALTEK enabled the PHY can be identified and etherent works:
=> mdio list ethernet@ff540000: 1 - RealTek RTL8211F <--> ethernet@ff540000
This was tested with and without the DM_MDIO option enabled. Decided to leave it disabled in this series.
Jonas Karlman (2): net: designware: Reset eth phy before phy connect rockchip: rk3328-rock-pi-e: Enable DM_ETH_PHY and PHY_REALTEK
configs/rock-pi-e-rk3328_defconfig | 2 ++ drivers/net/designware.c | 7 +++++++ 2 files changed, 9 insertions(+)
Some ethernet PHY require being reset before a phy-id can be read back on the MDIO bus. This can result in the following message being show on e.g. a Radxa ROCK Pi E v1.21 with a RTL8211F ethernet PHY.
Add support to designware ethernet driver to reset eth phy by calling the eth phy uclass function eth_phy_set_mdio_bus(). The call use NULL as bus parameter to not set a shared mdio bus reference that would be freed when probe fails. Also add a eth_phy_get_addr() call to try and get the phy addr from DT when DM_MDIO is disabled.
This help fix ethernet on Radxa ROCK Pi E v1.21:
Reported-by: Trevor Woerner twoerner@gmail.com Signed-off-by: Jonas Karlman jonas@kwiboo.se --- drivers/net/designware.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index a174344b3ef5..9aa5d8a1409e 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -13,6 +13,7 @@ #include <cpu_func.h> #include <dm.h> #include <errno.h> +#include <eth_phy.h> #include <log.h> #include <miiphy.h> #include <malloc.h> @@ -576,6 +577,9 @@ static int dw_phy_init(struct dw_eth_dev *priv, void *dev) struct phy_device *phydev; int ret;
+ if (IS_ENABLED(CONFIG_DM_ETH_PHY)) + eth_phy_set_mdio_bus(dev, NULL); + #if IS_ENABLED(CONFIG_DM_MDIO) phydev = dm_eth_phy_connect(dev); if (!phydev) @@ -583,6 +587,9 @@ static int dw_phy_init(struct dw_eth_dev *priv, void *dev) #else int phy_addr = -1;
+ if (IS_ENABLED(CONFIG_DM_ETH_PHY)) + phy_addr = eth_phy_get_addr(dev); + #ifdef CONFIG_PHY_ADDR phy_addr = CONFIG_PHY_ADDR; #endif
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- if (IS_ENABLED(CONFIG_DM_ETH_PHY))
- #if IS_ENABLED(CONFIG_DM_MDIO) phydev = dm_eth_phy_connect(dev); if (!phydev)
- #ifdef CONFIG_PHY_ADDR phy_addr = CONFIG_PHY_ADDR; #endif
Enable the DM_ETH_PHY and PHY_REALTEK now that the designware ethernet driver call eth_phy_set_mdio_bus() to assist with resetting the eth PHY during probe.
Fixes ethernet on the v1.21 hw revision of Radxa ROCK Pi E:
=> mdio list ethernet@ff540000: 1 - RealTek RTL8211F <--> ethernet@ff540000 => net list eth0 : ethernet@ff540000 86:e0:c0:ea:fa:a9 active eth1 : ethernet@ff550000 86:e0:c0:ea:fa:a8 => dhcp Speed: 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 DHCP client bound to address 192.168.1.114 (1004 ms)
Reported-by: Trevor Woerner twoerner@gmail.com Signed-off-by: Jonas Karlman jonas@kwiboo.se --- configs/rock-pi-e-rk3328_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/rock-pi-e-rk3328_defconfig b/configs/rock-pi-e-rk3328_defconfig index c0375beffec3..6dda900a9b42 100644 --- a/configs/rock-pi-e-rk3328_defconfig +++ b/configs/rock-pi-e-rk3328_defconfig @@ -76,6 +76,8 @@ CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH_PHY=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y
Thanks, - Kever
Hi Jonas,
This works great, thank you! As you suspected, both boards/PHYs work fine now work under Linux (in addition to U-Boot).
Tested-By: Trevor Woerner twoerner@gmail.com
-- 2.43.0
Jonas Karlman
Kever Yang
Trevor Woerner
