[U-Boot] [PATCH v2] efi_loader: initialise partition_signature memory
Zero partition_signature in the efi_device_path_hard_drive_path structure when signature_type is 0 (no signature) as required by the UEFI specification.
This is required so that efi_dp_match() will work as expected when doing memcmp() comparisons. Previously uninitialised memory would cause it not match nodes when it should have when the signature type was not GUID.
Corrects a problem where the loaded image protocol would not return a device path with MEDIA_DEVICE causing the OpenBSD bootloader to fail on rpi_3 and other targets.
v2: Also handle signature_type 1 (MBR) as described in the specification
Signed-off-by: Jonathan Gray jsg@jsg.id.au --- lib/efi_loader/efi_device_path.c | 21 +++++++++++++++++++-- 1 file changed, 19 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index f6e368e029..12a81d311c 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -427,10 +427,27 @@ static void *dp_part_fill(void *buf, struct blk_desc *desc, int part) hddp->partmap_type = 2; else hddp->partmap_type = 1; - hddp->signature_type = desc->sig_type; - if (hddp->signature_type != 0) + + switch (desc->sig_type) { + case SIG_TYPE_NONE: + default: + hddp->signature_type = 0; + memset(hddp->partition_signature, 0, + sizeof(hddp->partition_signature)); + break; + case SIG_TYPE_MBR: + hddp->signature_type = 1; + memset(hddp->partition_signature, 0, + sizeof(hddp->partition_signature)); + memcpy(hddp->partition_signature, &desc->mbr_sig, + sizeof(desc->mbr_sig)); + break; + case SIG_TYPE_GUID: + hddp->signature_type = 2; memcpy(hddp->partition_signature, &desc->guid_sig, sizeof(hddp->partition_signature)); + break; + }
buf = &hddp[1]; }
Tested-by: Artturi Alm artturi.alm@gmail.com
Tested with Marsboard_A10_defconfig. Thanks, -Artturi
case SIG_TYPE_NONE:
default:
break;
case SIG_TYPE_MBR:
break;
case SIG_TYPE_GUID:
break;
buf = &hddp[1]; }
-- 2.15.0
Signed-off-by: Jonathan Gray jsg@jsg.id.au Tested-by: Artturi Alm artturi.alm@gmail.com
Thanks, applied to efi-next
Alex
Alexander Graf
Artturi Alm
Jonathan Gray
