[PATCH v2 00/14] Introduce the lwIP network stack
This is a rework of a patch series by Maxim Uvarov: "net/lwip: add lwip library for the network stack" [1]. The goal is to introduce the lwIP TCP/IP stack [2] [3] as an alternative to the current implementation in net/, selectable with Kconfig, and ultimately keep only lwIP if possible. Some reasons for doing so are: - Make the support of HTTPS in the wget command easier. Javier T. (CC'd) has some additional lwIP and Mbed TLS patches to do so. With that it becomes possible to fetch and launch a distro installer such as Debian etc. directly from the U-Boot shell. - Possibly benefit from additional features implemented in lwIP - Less code to maintain in U-Boot
The first patch introduces a new Kconfig symbol: NET_LWIP, which selects the lwIP implementation instead of the current one (NET). Contrary to the approach chosen by Maxim in [1], NET_LWIP and NET cannot be enabled simultaneously. The rationale is we want to start from a clean state and not pull potentially duplicated functionality from both stacks. Note however that a few files are still built in net/, they are the ones related to ethernet device management and the ethernet bootflow.
The second patch imports the lwIP code as a Git subtree under lib/lwip/lwip. Some glue code is added under lib/lwip/u-boot.
The third patch introduces the Makefile to build lwIP when CONFIG_NET_LWIP=y.
The subsequent patches implement various network-oriented commands and features: dhcp, dns, ping, tftpboot, wget.
NET_LWIP is not enabled by default because it lacks functionality compared to NET and many CI tests would fail to run or even build.
Some tests (dm dsa/eth) are disabled when NET_LWIP is selected because they make strong assumptions on how the network stack is implemented and how the packet flow occurs. For example, an ARP exchange is expected when an ICMP packet goes out, but with lwIP no exchange will occur if the host IP is already in the the ARP cache.
Due to the above and in order to provide some level of testing, a new QEMU configuration is introduced (qemu_arm64_lwip_defconfig) which is the same as qemu_arm64_lwip_defconfig but with NET_LWIP and CMD_*_LWIP enabled. Tests are added to test/py/tests/test_net.py for that configuration.
Changes in v2:
** Address comments from Ilias A.
- "net-lwip: add wget command" Implement the wget_with_dns() function to do most of the wget work and call it from do_wget(). This allows to simplify patch "net-lwip: add support for EFI_HTTP_BOOT".
- "net-lwip: import net command from cmd/net.c" Move a few functions from cmd/net.c to a new file cmd/net-common.c rather than duplicating then in cmd/net-lwip.c.
- "net-lwip: add support for EFI_HTTP_BOOT" Since wget_with_dns() is now implemented in "net-lwip: add wget command", just enable the wget command when the lwIP stack is enabled and EFI_HTTP_BOOT is requested.
** Address comments from Tom R.
- "net-lwip: add DHCP support and dhcp commmand", "net-lwip: add TFTP support and tftpboot command", "net-lwip: add ping command", "net-lwip: add dns command", "net-lwip: add wget command" Do not introduce new CMD_XXX_LWIP symbols and use existing CMD_XXX instead.
- "configs: add qemu_arm64_lwip_defconfig" Use #include <configs/qemu_arm64_defconfig>.
- "net-lwip: import lwIP library under lib/lwip" Patch removed and replaced by the introduction of a Git subtree: "Squashed 'lib/lwip/lwip/' content from commit 0a0452b2c3".
Note that I have not yet addressed your comments on "test: dm: dsa, eth: disable tests when CONFIG_NET_LWIP=y"). I need some more time for that and I think running CI on this v2 will help better understand what is needed for v3.
** Miscellaneous improvements
- "net: introduce alternative implementation as net-lwip/":
* Make DFU_OVER_TFTP not DFU_TFTP incompatible with NET_LWIP. It seems quite natural to supplement "depends on NET" with "&& !NET_LWIP". * Make PROT_*_LWIP not visible by removing the Kconfig prompt.
[1] https://lore.kernel.org/all/20231127125726.3735-1-maxim.uvarov@linaro.org/ [2] https://www.nongnu.org/lwip/ [3] https://en.wikipedia.org/wiki/LwIP
CC: Javier Tia javier.tia@linaro.org
Jerome Forissier (14): net: introduce alternative implementation as net-lwip/ Squashed 'lib/lwip/lwip/' content from commit 0a0452b2c39 net-lwip: build lwIP net-lwip: add DHCP support and dhcp commmand net-lwip: add TFTP support and tftpboot command net-lwip: add ping command net-lwip: add dns command net-lwip: add wget command test: dm: dsa, eth: disable tests when CONFIG_NET_LWIP=y cmd: bdinfo: enable -e when CONFIG_CMD_NET_LWIP=y configs: add qemu_arm64_lwip_defconfig test/py: net: add _lwip variants of dhcp, ping and tftpboot tests MAINTAINERS: net-lwip: add myself as a maintainer CI: add qemu_arm64_lwip to the test matrix
Prepare the introduction of the lwIP (lightweight IP) TCP/IP stack by adding a new net-lwip/ directory and the NET_LWIP symbol. At this point, enabling NET_LWIP simply disables NET. Subsequent commits will introduce the lwIP code, re-work the NETDEVICE integration and port some of the NET commands and features to lwIP.
SPL_NET cannot be enabled when NET_LWIP=y. SPL_NET pulls some symbols that are part of NET (such as arp_init(), arp_timeout_check(), arp_receive(), net_arp_wait_packet_ip()). lwIP support in SPL may be added later.
Similarly, DFU_TFTP is not compatible with NET_LWIP because it depends on net_loop(), tftp_timeout_ms, tftp_timeout_count_max. Let's add a dependency on !NET_LWIP for now.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org --- Kconfig | 2 ++ Makefile | 2 +- common/Kconfig | 2 +- common/spl/Kconfig | 1 + drivers/dfu/Kconfig | 2 +- drivers/fastboot/Kconfig | 4 ++-- drivers/net/phy/Kconfig | 2 +- drivers/usb/gadget/Kconfig | 2 +- net-lwip/Kconfig | 15 +++++++++++++++ net/Kconfig | 1 + 10 files changed, 26 insertions(+), 7 deletions(-) create mode 100644 net-lwip/Kconfig
diff --git a/Kconfig b/Kconfig index 82df59f176e..758256ab121 100644 --- a/Kconfig +++ b/Kconfig @@ -747,6 +747,8 @@ source "env/Kconfig"
source "net/Kconfig"
+source "net-lwip/Kconfig" + source "drivers/Kconfig"
source "fs/Kconfig" diff --git a/Makefile b/Makefile index 79b28c2d81f..3df9c45a17c 100644 --- a/Makefile +++ b/Makefile @@ -859,7 +859,7 @@ libs-$(CONFIG_OF_EMBED) += dts/ libs-y += env/ libs-y += lib/ libs-y += fs/ -libs-y += net/ +libs-$(CONFIG_NET) += net/ libs-y += disk/ libs-y += drivers/ libs-$(CONFIG_SYS_FSL_DDR) += drivers/ddr/fsl/ diff --git a/common/Kconfig b/common/Kconfig index 5e3070e9253..807b726384d 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -424,7 +424,7 @@ config LOGF_FUNC_PAD
config LOG_SYSLOG bool "Log output to syslog server" - depends on NET + depends on NET || NET_LWIP help Enables a log driver which broadcasts log records via UDP port 514 to syslog servers. diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 6405374bcc1..f67f0a859db 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -1055,6 +1055,7 @@ config SPL_DM_SPI_FLASH
config SPL_NET bool "Support networking" + depends on !NET_LWIP help Enable support for network devices (such as Ethernet) in SPL. This permits SPL to load U-Boot over a network link rather than diff --git a/drivers/dfu/Kconfig b/drivers/dfu/Kconfig index 0360d9da142..c6bce82eb10 100644 --- a/drivers/dfu/Kconfig +++ b/drivers/dfu/Kconfig @@ -11,7 +11,7 @@ config DFU_OVER_USB
config DFU_OVER_TFTP bool - depends on NET + depends on NET && !NET_LWIP
if DFU config DFU_WRITE_ALT diff --git a/drivers/fastboot/Kconfig b/drivers/fastboot/Kconfig index 70207573de2..05e988166fb 100644 --- a/drivers/fastboot/Kconfig +++ b/drivers/fastboot/Kconfig @@ -27,7 +27,7 @@ config USB_FUNCTION_FASTBOOT This enables the USB part of the fastboot gadget.
config UDP_FUNCTION_FASTBOOT - depends on NET + depends on NET || NET_LWIP select FASTBOOT bool "Enable fastboot protocol over UDP" help @@ -41,7 +41,7 @@ config UDP_FUNCTION_FASTBOOT_PORT The fastboot protocol requires a UDP port number.
config TCP_FUNCTION_FASTBOOT - depends on NET + depends on NET || NET_LWIP select FASTBOOT bool "Enable fastboot protocol over TCP" help diff --git a/drivers/net/phy/Kconfig b/drivers/net/phy/Kconfig index 3d96938eaba..738752d29c2 100644 --- a/drivers/net/phy/Kconfig +++ b/drivers/net/phy/Kconfig @@ -11,7 +11,7 @@ config MV88E6352_SWITCH
menuconfig PHYLIB bool "Ethernet PHY (physical media interface) support" - depends on NET + depends on NET || NET_LWIP help Enable Ethernet PHY (physical media interface) support.
diff --git a/drivers/usb/gadget/Kconfig b/drivers/usb/gadget/Kconfig index 4621a6fd5e6..03fe3bca197 100644 --- a/drivers/usb/gadget/Kconfig +++ b/drivers/usb/gadget/Kconfig @@ -224,7 +224,7 @@ endif # USB_GADGET_DOWNLOAD
config USB_ETHER bool "USB Ethernet Gadget" - depends on NET + depends on NET || NET_LWIP default y if ARCH_SUNXI && USB_MUSB_GADGET help Creates an Ethernet network device through a USB peripheral diff --git a/net-lwip/Kconfig b/net-lwip/Kconfig new file mode 100644 index 00000000000..f8e0481964f --- /dev/null +++ b/net-lwip/Kconfig @@ -0,0 +1,15 @@ +# +# Network configuration (with lwIP stack) +# + +menuconfig NET_LWIP + bool "Networking support (lwIP stack) -- EXPERIMENTAL" + help + Include networking support based on the lwIP (lightweight IP) + TCP/IP stack (https://nongnu.org/lwip). This is a replacement for + the default U-Boot network stack and applications located in net/ + and enabled via CONFIG_NET as well as other pieces of code that + depend on CONFIG_NET (such as cmd/net.c enabled via CONFIG_CMD_NET). + Therefore the two symbols CONFIG_NET and CONFIG_NET_LWIP are mutually + exclusive. + NOTE: This is currently a placeholder. diff --git a/net/Kconfig b/net/Kconfig index 5dff6336293..04b81dd4976 100644 --- a/net/Kconfig +++ b/net/Kconfig @@ -6,6 +6,7 @@ menuconfig NET bool "Networking support" default y imply NETDEVICES + depends on !NET_LWIP
if NET
[snip]
source "fs/Kconfig"
I think we need to instead rework this to a choice statement instead so that in the end we have something like: choice "Networking stack" config NO_NET bool "No networking support" config NET bool "Legacy U-Boot networking stack" config NET_LWIP bool "Use lwIP for networking stack"
if NET_LEGACY source "net/Kconfig" endif
if NET_LWIP source "net-lwip/Kconfig" endif
And then SPL_NET still depends on !NET_LWIP for now and we sort out the problems with different networking stacks in SPL vs full U-Boot later on.
[snip]
source "fs/Kconfig"
+ 1
That's an excellent idea tbh. We can now decouple SPL and u-boot proper using different stacks and fix the more difficult to debug SPL issues in time. Once we feel happy we can switch over to LWIP completely
Thanks /Ilias
-- Tom
[snip]
source "fs/Kconfig"
Done in v3. Thanks.
git-subtree-dir: lib/lwip/lwip git-subtree-split: 0a0452b2c39bdd91e252aef045c115f88f6ca773 Signed-off-by: Jerome Forissier jerome.forissier@linaro.org --- .gitattributes | 10 + .github/workflows/ci-linux.yml | 43 + .gitignore | 60 + .vscode/c_cpp_properties.json | 28 + .vscode/launch.json | 62 + .vscode/settings.json | 10 + .vscode/tasks.json | 54 + BUILDING | 119 + CHANGELOG | 4635 +++++++++++++++ CMakeLists.txt | 35 + COPYING | 25 + FEATURES | 11 + FILES | 6 + README | 109 + UPGRADING | 288 + codespell_changed_files.sh | 26 + codespell_check.sh | 57 + contrib/Coverity/coverity.c | 106 + contrib/Filelists.cmake | 61 + contrib/Filelists.mk | 57 + contrib/addons/dhcp_extra_opts/README | 5 + .../addons/dhcp_extra_opts/dhcp_extra_opts.c | 91 + .../addons/dhcp_extra_opts/dhcp_extra_opts.h | 61 + contrib/addons/ipv6_static_routing/README | 43 + .../ipv6_static_routing/ip6_route_table.c | 248 + .../ipv6_static_routing/ip6_route_table.h | 94 + .../addons/netconn/external_resolve/dnssd.c | 164 + .../addons/netconn/external_resolve/dnssd.h | 50 + contrib/addons/tcp_isn/tcp_isn.c | 182 + contrib/addons/tcp_isn/tcp_isn.h | 48 + contrib/addons/tcp_md5/README | 27 + contrib/addons/tcp_md5/tcp_md5.c | 534 ++ contrib/addons/tcp_md5/tcp_md5.h | 84 + .../CCodeGeneration/CCodeGeneration.csproj | 67 + .../LwipMibCompiler/CCodeGeneration/CFile.cs | 54 + .../CCodeGeneration/CGenerator.cs | 119 + .../LwipMibCompiler/CCodeGeneration/Code.cs | 56 + .../CCodeGeneration/CodeContainerBase.cs | 139 + .../CCodeGeneration/CodeElement.cs | 41 + .../CCodeGeneration/Comment.cs | 75 + .../CCodeGeneration/EmptyLine.cs | 64 + .../CCodeGeneration/Function.cs | 129 + .../CCodeGeneration/FunctionDeclaration.cs | 114 + .../CCodeGeneration/IfThenElse.cs | 137 + .../LwipMibCompiler/CCodeGeneration/PP_If.cs | 67 + .../CCodeGeneration/PP_Ifdef.cs | 76 + .../CCodeGeneration/PP_Include.cs | 71 + .../CCodeGeneration/PP_Macro.cs | 59 + .../CCodeGeneration/PlainText.cs | 49 + .../Properties/AssemblyInfo.cs | 36 + .../LwipMibCompiler/CCodeGeneration/Switch.cs | 146 + .../CCodeGeneration/VariableDeclaration.cs | 82 + .../CCodeGeneration/VariablePrototype.cs | 73 + .../CCodeGeneration/VariableType.cs | 130 + .../apps/LwipMibCompiler/LwipMibCompiler.sln | 47 + .../LwipMibCompiler/LwipMibCompiler.csproj | 73 + .../LwipMibCompiler/Program.cs | 480 ++ .../Properties/AssemblyInfo.cs | 36 + .../LwipMibCompiler/app.config | 3 + .../LwipSnmpCodeGeneration/IRestriction.cs | 120 + .../LwipSnmpCodeGeneration/LwipSnmp.cs | 199 + .../LwipSnmpCodeGeneration.csproj | 72 + .../LwipSnmpCodeGeneration/MibCFile.cs | 196 + .../LwipSnmpCodeGeneration/MibHeaderFile.cs | 129 + .../Properties/AssemblyInfo.cs | 36 + .../LwipSnmpCodeGeneration/SnmpMib.cs | 97 + .../LwipSnmpCodeGeneration/SnmpNode.cs | 119 + .../SnmpScalarAggregationNode.cs | 293 + .../SnmpScalarArrayNode.cs | 105 + .../LwipSnmpCodeGeneration/SnmpScalarNode.cs | 395 ++ .../SnmpScalarNodeBits.cs | 121 + .../SnmpScalarNodeCounter64.cs | 72 + .../SnmpScalarNodeInt.cs | 86 + .../SnmpScalarNodeObjectIdentifier.cs | 90 + .../SnmpScalarNodeOctetString.cs | 118 + .../SnmpScalarNodeTruthValue.cs | 66 + .../SnmpScalarNodeUint.cs | 91 + .../LwipSnmpCodeGeneration/SnmpTableNode.cs | 332 ++ .../LwipSnmpCodeGeneration/SnmpTreeNode.cs | 242 + .../MibViewer/FormMain.Designer.cs | 166 + .../LwipMibCompiler/MibViewer/FormMain.cs | 217 + .../LwipMibCompiler/MibViewer/FormMain.resx | 298 + .../MibViewer/MibViewer.csproj | 94 + .../apps/LwipMibCompiler/MibViewer/Program.cs | 51 + .../MibViewer/Properties/AssemblyInfo.cs | 36 + .../Properties/Resources.Designer.cs | 63 + .../MibViewer/Properties/Resources.resx | 117 + .../MibViewer/Properties/Settings.Designer.cs | 26 + .../MibViewer/Properties/Settings.settings | 7 + .../apps/LwipMibCompiler/MibViewer/app.config | 3 + .../Mibs/IANA-ADDRESS-FAMILY-NUMBERS-MIB | 131 + .../LwipMibCompiler/Mibs/IANA-CHARSET-MIB | 345 ++ .../Mibs/IANA/IANA-ITU-ALARM-TC-MIB | 333 ++ .../Mibs/IANA/IANA-LANGUAGE-MIB | 127 + .../LwipMibCompiler/Mibs/IANA/IANA-MALLOC-MIB | 67 + .../LwipMibCompiler/Mibs/IANA/IANA-MAU-MIB | 770 +++ .../Mibs/IANA/IANA-PRINTER-MIB | 1319 +++++ .../Mibs/IANA/IANA-RTPROTO-MIB | 92 + .../Mibs/IANA/IANATn3270eTC-MIB | 306 + .../LwipMibCompiler/Mibs/IANA/IANAifType-MIB | 572 ++ contrib/apps/LwipMibCompiler/Mibs/IF-MIB | 1899 ++++++ .../LwipMibCompiler/Mibs/INET-ADDRESS-MIB | 421 ++ contrib/apps/LwipMibCompiler/Mibs/IP-MIB | 5254 +++++++++++++++++ contrib/apps/LwipMibCompiler/Mibs/RFC-1212 | 75 + contrib/apps/LwipMibCompiler/Mibs/RFC-1215 | 34 + contrib/apps/LwipMibCompiler/Mibs/RFC1065-SMI | 132 + contrib/apps/LwipMibCompiler/Mibs/RFC1155-SMI | 129 + contrib/apps/LwipMibCompiler/Mibs/RFC1158-MIB | 1493 +++++ contrib/apps/LwipMibCompiler/Mibs/RFC1213-MIB | 2621 ++++++++ contrib/apps/LwipMibCompiler/Mibs/SNMPv2-CONF | 318 + contrib/apps/LwipMibCompiler/Mibs/SNMPv2-MIB | 903 +++ contrib/apps/LwipMibCompiler/Mibs/SNMPv2-SMI | 352 ++ contrib/apps/LwipMibCompiler/Mibs/SNMPv2-TC | 786 +++ contrib/apps/LwipMibCompiler/Mibs/SNMPv2-TM | 194 + contrib/apps/LwipMibCompiler/Mibs/TCP-MIB | 829 +++ contrib/apps/LwipMibCompiler/Mibs/UDP-MIB | 579 ++ .../SharpSnmpLib/Mib/DisplayHint.cs | 84 + .../Elements/Entities/AgentCapabilities.cs | 29 + .../Mib/Elements/Entities/EntityBase.cs | 46 + .../Mib/Elements/Entities/IEntity.cs | 62 + .../Mib/Elements/Entities/ModuleCompliance.cs | 23 + .../Mib/Elements/Entities/ModuleIdentity.cs | 10 + .../Elements/Entities/NotificationGroup.cs | 22 + .../Mib/Elements/Entities/NotificationType.cs | 11 + .../Mib/Elements/Entities/ObjectGroup.cs | 22 + .../Mib/Elements/Entities/ObjectIdentity.cs | 21 + .../Mib/Elements/Entities/ObjectType.cs | 336 ++ .../Elements/Entities/OidValueAssignment.cs | 30 + .../SharpSnmpLib/Mib/Elements/Exports.cs | 56 + .../SharpSnmpLib/Mib/Elements/IDeclaration.cs | 18 + .../SharpSnmpLib/Mib/Elements/IElement.cs | 35 + .../Mib/Elements/ITypeReferrer.cs | 10 + .../SharpSnmpLib/Mib/Elements/Imports.cs | 81 + .../SharpSnmpLib/Mib/Elements/ImportsFrom.cs | 60 + .../SharpSnmpLib/Mib/Elements/TrapType.cs | 48 + .../Mib/Elements/Types/BaseType.cs | 54 + .../Mib/Elements/Types/BitsType.cs | 26 + .../SharpSnmpLib/Mib/Elements/Types/Choice.cs | 35 + .../Mib/Elements/Types/ITypeAssignment.cs | 6 + .../Mib/Elements/Types/IntegerType.cs | 117 + .../Mib/Elements/Types/IpAddressType.cs | 21 + .../SharpSnmpLib/Mib/Elements/Types/Macro.cs | 34 + .../Elements/Types/ObjectIdentifierType.cs | 11 + .../Mib/Elements/Types/OctetStringType.cs | 31 + .../Mib/Elements/Types/OpaqueType.cs | 11 + .../Mib/Elements/Types/Sequence.cs | 46 + .../Mib/Elements/Types/SequenceOf.cs | 23 + .../Mib/Elements/Types/TextualConvention.cs | 238 + .../Mib/Elements/Types/TypeAssignment.cs | 147 + .../Mib/Elements/Types/UnsignedType.cs | 103 + .../SharpSnmpLib/Mib/IModule.cs | 81 + .../SharpSnmpLib/Mib/ISymbolEnumerator.cs | 9 + .../LwipMibCompiler/SharpSnmpLib/Mib/Lexer.cs | 581 ++ .../SharpSnmpLib/Mib/MaxAccess.cs | 17 + .../SharpSnmpLib/Mib/MibDocument.cs | 57 + .../SharpSnmpLib/Mib/MibException.cs | 113 + .../SharpSnmpLib/Mib/MibModule.cs | 294 + .../SharpSnmpLib/Mib/MibResolver.cs | 97 + .../SharpSnmpLib/Mib/MibTree.cs | 130 + .../SharpSnmpLib/Mib/MibTreeNode.cs | 112 + .../SharpSnmpLib/Mib/MibTypesResolver.cs | 216 + .../SharpSnmpLib/Mib/ObjectIdentifier.cs | 54 + .../SharpSnmpLib/Mib/Status.cs | 17 + .../SharpSnmpLib/Mib/Symbol.cs | 357 ++ .../SharpSnmpLib/Mib/SymbolList.cs | 146 + .../SharpSnmpLib/Mib/ValueMap.cs | 103 + .../SharpSnmpLib/Mib/ValueRange.cs | 76 + .../SharpSnmpLib/Properties/AssemblyInfo.cs | 61 + .../Properties/Resources.Designer.cs | 63 + .../SharpSnmpLib/Properties/Resources.resx | 120 + .../SharpSnmpLib/SharpSnmpLib.Mib.csproj | 140 + .../LwipMibCompiler/SharpSnmpLib/license.txt | 458 ++ .../LwipMibCompiler/SharpSnmpLib/readme.txt | 1 + .../SharpSnmpLib/sharpsnmplib.snk | Bin 0 -> 596 bytes .../example/compile_udp_mib.cmd | 1 + .../example/compile_udp_mib.sh | 1 + contrib/apps/chargen/README | 52 + contrib/apps/chargen/chargen.c | 274 + contrib/apps/chargen/chargen.h | 12 + contrib/apps/httpserver/README | 12 + contrib/apps/httpserver/httpserver-netconn.c | 103 + contrib/apps/httpserver/httpserver-netconn.h | 6 + contrib/apps/netio/netio.c | 55 + contrib/apps/netio/netio.h | 6 + contrib/apps/ping/ping.c | 396 ++ contrib/apps/ping/ping.h | 19 + contrib/apps/rtp/rtp.c | 308 + contrib/apps/rtp/rtp.h | 8 + contrib/apps/rtp/rtpdata.h | 2040 +++++++ contrib/apps/shell/shell.c | 1277 ++++ contrib/apps/shell/shell.h | 37 + .../apps/socket_examples/socket_examples.c | 680 +++ .../apps/socket_examples/socket_examples.h | 6 + contrib/apps/tcpecho/tcpecho.c | 101 + contrib/apps/tcpecho/tcpecho.h | 38 + contrib/apps/tcpecho_raw/tcpecho_raw.c | 301 + contrib/apps/tcpecho_raw/tcpecho_raw.h | 35 + contrib/apps/udpecho/udpecho.c | 88 + contrib/apps/udpecho/udpecho.h | 37 + contrib/apps/udpecho_raw/udpecho_raw.c | 88 + contrib/apps/udpecho_raw/udpecho_raw.h | 39 + contrib/examples/ethernetif/ethernetif.c | 337 ++ contrib/examples/example_app/default_netif.h | 47 + contrib/examples/example_app/lwipcfg.h.ci | 73 + .../examples/example_app/lwipcfg.h.example | 77 + contrib/examples/example_app/lwipopts.h | 326 + contrib/examples/example_app/lwippools.h | 20 + contrib/examples/example_app/ppp_settings.h | 6 + contrib/examples/example_app/test.c | 773 +++ .../example_app/test_configs/opt_default.h | 295 + .../example_app/test_configs/opt_dualstack.h | 295 + .../example_app/test_configs/opt_ipv4only.h | 295 + .../example_app/test_configs/opt_ipv6only.h | 295 + .../test_configs/opt_no_tcp_dualstack.h | 4 + .../test_configs/opt_no_tcp_ipv4only.h | 4 + .../test_configs/opt_no_tcp_ipv6only.h | 4 + .../test_configs/opt_no_udp_dualstack.h | 4 + .../test_configs/opt_no_udp_ipv4only.h | 4 + .../test_configs/opt_no_udp_ipv6only.h | 4 + .../example_app/test_configs/opt_none.h | 2 + .../example_app/test_configs/opt_nosys_dual.h | 295 + .../example_app/test_configs/opt_nosys_ipv4.h | 295 + .../example_app/test_configs/opt_nosys_ipv6.h | 295 + .../examples/httpd/cgi_example/cgi_example.c | 107 + .../examples/httpd/cgi_example/cgi_example.h | 38 + contrib/examples/httpd/examples_fs/404.html | 21 + .../examples/httpd/examples_fs/img/sics.gif | Bin 0 -> 724 bytes contrib/examples/httpd/examples_fs/index.html | 47 + contrib/examples/httpd/examples_fs/login.html | 28 + .../examples/httpd/examples_fs/loginfail.html | 25 + .../examples/httpd/examples_fs/session.html | 25 + contrib/examples/httpd/examples_fs/ssi.shtml | 315 + contrib/examples/httpd/examples_fsdata.c | 1543 +++++ .../examples/httpd/fs_example/fs_example.c | 324 + .../examples/httpd/fs_example/fs_example.h | 38 + .../httpd/genfiles_example/genfiles_example.c | 186 + .../httpd/genfiles_example/genfiles_example.h | 38 + .../httpd/https_example/https_example.c | 144 + .../httpd/https_example/https_example.h | 38 + .../httpd/post_example/post_example.c | 167 + .../examples/httpd/ssi_example/ssi_example.c | 264 + .../examples/httpd/ssi_example/ssi_example.h | 38 + contrib/examples/lwiperf/lwiperf_example.c | 50 + contrib/examples/lwiperf/lwiperf_example.h | 43 + contrib/examples/mdns/mdns_example.c | 63 + contrib/examples/mdns/mdns_example.h | 43 + contrib/examples/mqtt/mqtt_example.c | 128 + contrib/examples/mqtt/mqtt_example.h | 43 + contrib/examples/ppp/pppos_example.c | 221 + contrib/examples/ppp/pppos_example.h | 43 + contrib/examples/snmp/snmp_example.c | 80 + contrib/examples/snmp/snmp_example.h | 43 + .../snmp/snmp_private_mib/lwip_prvmib.c | 401 ++ .../snmp/snmp_private_mib/private_mib.h | 26 + contrib/examples/snmp/snmp_v3/snmpv3_dummy.c | 395 ++ contrib/examples/snmp/snmp_v3/snmpv3_dummy.h | 53 + contrib/examples/sntp/sntp_example.c | 66 + contrib/examples/sntp/sntp_example.h | 45 + contrib/examples/tftp/tftp_example.c | 155 + contrib/examples/tftp/tftp_example.h | 29 + contrib/ports/CMakeCommon.cmake | 128 + contrib/ports/Common.allports.mk | 91 + .../ports/freertos/include/arch/sys_arch.h | 95 + contrib/ports/freertos/sys_arch.c | 607 ++ contrib/ports/unix/Common.mk | 51 + contrib/ports/unix/Filelists.cmake | 44 + contrib/ports/unix/README | 25 + contrib/ports/unix/check/CMakeLists.txt | 61 + contrib/ports/unix/check/Makefile | 94 + contrib/ports/unix/check/README | 8 + contrib/ports/unix/check/config.h | 2 + contrib/ports/unix/example_app/CMakeLists.txt | 27 + contrib/ports/unix/example_app/Makefile | 60 + .../ports/unix/example_app/default_netif.c | 68 + contrib/ports/unix/example_app/iteropts.sh | 34 + contrib/ports/unix/lib/CMakeLists.txt | 33 + contrib/ports/unix/lib/README | 28 + contrib/ports/unix/lib/lwipopts.h | 436 ++ contrib/ports/unix/port/include/arch/cc.h | 89 + contrib/ports/unix/port/include/arch/perf.h | 63 + .../ports/unix/port/include/arch/sys_arch.h | 90 + contrib/ports/unix/port/include/netif/fifo.h | 54 + contrib/ports/unix/port/include/netif/list.h | 26 + .../ports/unix/port/include/netif/pcapif.h | 39 + contrib/ports/unix/port/include/netif/sio.h | 60 + contrib/ports/unix/port/include/netif/tapif.h | 43 + contrib/ports/unix/port/include/netif/vdeif.h | 43 + contrib/ports/unix/port/netif/fifo.c | 139 + contrib/ports/unix/port/netif/list.c | 152 + contrib/ports/unix/port/netif/pcapif.c | 207 + contrib/ports/unix/port/netif/sio.c | 485 ++ contrib/ports/unix/port/netif/tapif.c | 432 ++ contrib/ports/unix/port/netif/vdeif.c | 344 ++ contrib/ports/unix/port/perf.c | 65 + contrib/ports/unix/port/sys_arch.c | 840 +++ contrib/ports/unix/posixlib/CMakeLists.txt | 94 + contrib/ports/unix/posixlib/Uninstall.cmake | 22 + .../ports/unix/posixlib/include/posix/inet.h | 76 + .../unix/posixlib/include/posix/sockets.h | 150 + contrib/ports/unix/posixlib/lwipopts.h | 180 + contrib/ports/unix/setup-tapif | 22 + contrib/ports/win32/Common.mk | 51 + contrib/ports/win32/Filelists.cmake | 46 + contrib/ports/win32/check/check_stdint.h | 1 + contrib/ports/win32/check/config.h | 29 + contrib/ports/win32/check/stdbool.h | 9 + contrib/ports/win32/check/sys/time.h | 12 + contrib/ports/win32/check/time.c | 66 + contrib/ports/win32/check/unistd.h | 7 + .../ports/win32/example_app/CMakeLists.txt | 27 + contrib/ports/win32/example_app/Makefile | 55 + .../ports/win32/example_app/default_netif.c | 80 + contrib/ports/win32/include/arch/bpstruct.h | 1 + contrib/ports/win32/include/arch/cc.h | 115 + contrib/ports/win32/include/arch/epstruct.h | 1 + contrib/ports/win32/include/arch/perf.h | 40 + contrib/ports/win32/include/arch/sys_arch.h | 91 + contrib/ports/win32/msvc/build_coverity.cmd | 26 + contrib/ports/win32/msvc/libcheck.vcxproj | 102 + .../ports/win32/msvc/libcheck.vcxproj.filters | 96 + contrib/ports/win32/msvc/lwIP.vcxproj | 593 ++ contrib/ports/win32/msvc/lwIP.vcxproj.filters | 1075 ++++ contrib/ports/win32/msvc/lwIP_Test.sln | 37 + contrib/ports/win32/msvc/lwIP_Test.vcxproj | 209 + .../win32/msvc/lwIP_Test.vcxproj.filters | 252 + contrib/ports/win32/msvc/lwIP_pcapif.vcxproj | 113 + .../win32/msvc/lwIP_pcapif.vcxproj.filters | 28 + contrib/ports/win32/msvc/lwIP_unittests.sln | 31 + .../ports/win32/msvc/lwip_unittests.vcxproj | 145 + .../win32/msvc/lwip_unittests.vcxproj.filters | 168 + contrib/ports/win32/msvc/makefsdata.vcxproj | 101 + .../win32/msvc/makefsdata.vcxproj.filters | 14 + contrib/ports/win32/pcapif.c | 1124 ++++ contrib/ports/win32/pcapif.h | 32 + contrib/ports/win32/pcapif_helper.c | 172 + contrib/ports/win32/pcapif_helper.h | 31 + contrib/ports/win32/readme.txt | 26 + contrib/ports/win32/sio.c | 304 + contrib/ports/win32/sys_arch.c | 782 +++ doc/FILES | 6 + doc/NO_SYS_SampleCode.c | 121 + doc/ZeroCopyRx.c | 45 + doc/contrib.txt | 58 + doc/doxygen/generate.bat | 1 + doc/doxygen/generate.sh | 3 + doc/doxygen/lwip.Doxyfile | 2516 ++++++++ doc/doxygen/lwip.Doxyfile.cmake.in | 2516 ++++++++ doc/doxygen/main_page.h | 417 ++ doc/doxygen/output/index.html | 10 + doc/mdns.txt | 111 + doc/mqtt_client.txt | 164 + doc/ppp.txt | 529 ++ doc/savannah.txt | 122 + src/FILES | 15 + src/Filelists.cmake | 293 + src/Filelists.mk | 208 + src/api/api_lib.c | 1367 +++++ src/api/api_msg.c | 2177 +++++++ src/api/err.c | 115 + src/api/if_api.c | 102 + src/api/netbuf.c | 250 + src/api/netdb.c | 422 ++ src/api/netifapi.c | 380 ++ src/api/sockets.c | 4205 +++++++++++++ src/api/tcpip.c | 706 +++ src/apps/altcp_tls/altcp_tls_mbedtls.c | 1367 +++++ src/apps/altcp_tls/altcp_tls_mbedtls_mem.c | 210 + src/apps/altcp_tls/altcp_tls_mbedtls_mem.h | 72 + .../altcp_tls/altcp_tls_mbedtls_structs.h | 83 + src/apps/http/altcp_proxyconnect.c | 584 ++ src/apps/http/fs.c | 161 + src/apps/http/fs/404.html | 21 + src/apps/http/fs/img/sics.gif | Bin 0 -> 724 bytes src/apps/http/fs/index.html | 47 + src/apps/http/fsdata.c | 336 ++ src/apps/http/fsdata.h | 41 + src/apps/http/http_client.c | 911 +++ src/apps/http/httpd.c | 2770 +++++++++ src/apps/http/httpd_structs.h | 123 + src/apps/http/makefsdata/makefsdata | 97 + src/apps/http/makefsdata/makefsdata.c | 1307 ++++ src/apps/http/makefsdata/readme.txt | 23 + src/apps/http/makefsdata/tinydir.h | 831 +++ src/apps/lwiperf/lwiperf.c | 847 +++ src/apps/mdns/mdns.c | 2855 +++++++++ src/apps/mdns/mdns_domain.c | 635 ++ src/apps/mdns/mdns_out.c | 1163 ++++ src/apps/mqtt/mqtt.c | 1480 +++++ src/apps/netbiosns/netbiosns.c | 533 ++ src/apps/smtp/smtp.c | 1554 +++++ src/apps/snmp/snmp_asn1.c | 704 +++ src/apps/snmp/snmp_asn1.h | 113 + src/apps/snmp/snmp_core.c | 1356 +++++ src/apps/snmp/snmp_core_priv.h | 91 + src/apps/snmp/snmp_mib2.c | 116 + src/apps/snmp/snmp_mib2_icmp.c | 182 + src/apps/snmp/snmp_mib2_interfaces.c | 368 ++ src/apps/snmp/snmp_mib2_ip.c | 731 +++ src/apps/snmp/snmp_mib2_snmp.c | 227 + src/apps/snmp/snmp_mib2_system.c | 376 ++ src/apps/snmp/snmp_mib2_tcp.c | 607 ++ src/apps/snmp/snmp_mib2_udp.c | 372 ++ src/apps/snmp/snmp_msg.c | 1981 +++++++ src/apps/snmp/snmp_msg.h | 185 + src/apps/snmp/snmp_netconn.c | 122 + src/apps/snmp/snmp_pbuf_stream.c | 156 + src/apps/snmp/snmp_pbuf_stream.h | 72 + src/apps/snmp/snmp_raw.c | 103 + src/apps/snmp/snmp_scalar.c | 232 + src/apps/snmp/snmp_snmpv2_framework.c | 90 + src/apps/snmp/snmp_snmpv2_usm.c | 410 ++ src/apps/snmp/snmp_table.c | 342 ++ src/apps/snmp/snmp_threadsync.c | 231 + src/apps/snmp/snmp_traps.c | 900 +++ src/apps/snmp/snmpv3.c | 136 + src/apps/snmp/snmpv3_mbedtls.c | 342 ++ src/apps/snmp/snmpv3_priv.h | 69 + src/apps/sntp/sntp.c | 948 +++ src/apps/tftp/tftp.c | 548 ++ src/core/altcp.c | 717 +++ src/core/altcp_alloc.c | 87 + src/core/altcp_tcp.c | 578 ++ src/core/def.c | 263 + src/core/dns.c | 1657 ++++++ src/core/inet_chksum.c | 608 ++ src/core/init.c | 387 ++ src/core/ip.c | 167 + src/core/ipv4/acd.c | 557 ++ src/core/ipv4/autoip.c | 379 ++ src/core/ipv4/dhcp.c | 1999 +++++++ src/core/ipv4/etharp.c | 1251 ++++ src/core/ipv4/icmp.c | 407 ++ src/core/ipv4/igmp.c | 801 +++ src/core/ipv4/ip4.c | 1166 ++++ src/core/ipv4/ip4_addr.c | 323 + src/core/ipv4/ip4_frag.c | 894 +++ src/core/ipv6/dhcp6.c | 821 +++ src/core/ipv6/ethip6.c | 123 + src/core/ipv6/icmp6.c | 425 ++ src/core/ipv6/inet6.c | 53 + src/core/ipv6/ip6.c | 1494 +++++ src/core/ipv6/ip6_addr.c | 355 ++ src/core/ipv6/ip6_frag.c | 862 +++ src/core/ipv6/mld6.c | 626 ++ src/core/ipv6/nd6.c | 2474 ++++++++ src/core/mem.c | 1017 ++++ src/core/memp.c | 447 ++ src/core/netif.c | 1855 ++++++ src/core/pbuf.c | 1545 +++++ src/core/raw.c | 673 +++ src/core/stats.c | 168 + src/core/sys.c | 148 + src/core/tcp.c | 2696 +++++++++ src/core/tcp_in.c | 2184 +++++++ src/core/tcp_out.c | 2257 +++++++ src/core/timeouts.c | 451 ++ src/core/udp.c | 1321 +++++ src/include/compat/posix/arpa/inet.h | 33 + src/include/compat/posix/net/if.h | 36 + src/include/compat/posix/netdb.h | 33 + src/include/compat/posix/sys/socket.h | 33 + src/include/compat/stdc/errno.h | 33 + src/include/lwip/acd.h | 109 + src/include/lwip/altcp.h | 207 + src/include/lwip/altcp_tcp.h | 72 + src/include/lwip/altcp_tls.h | 196 + src/include/lwip/api.h | 434 ++ src/include/lwip/apps/FILES | 2 + src/include/lwip/apps/altcp_proxyconnect.h | 79 + .../lwip/apps/altcp_tls_mbedtls_opts.h | 111 + src/include/lwip/apps/fs.h | 139 + src/include/lwip/apps/http_client.h | 160 + src/include/lwip/apps/httpd.h | 256 + src/include/lwip/apps/httpd_opts.h | 416 ++ src/include/lwip/apps/lwiperf.h | 109 + src/include/lwip/apps/mdns.h | 154 + src/include/lwip/apps/mdns_domain.h | 80 + src/include/lwip/apps/mdns_opts.h | 121 + src/include/lwip/apps/mdns_out.h | 138 + src/include/lwip/apps/mdns_priv.h | 237 + src/include/lwip/apps/mqtt.h | 205 + src/include/lwip/apps/mqtt_opts.h | 103 + src/include/lwip/apps/mqtt_priv.h | 104 + src/include/lwip/apps/netbiosns.h | 51 + src/include/lwip/apps/netbiosns_opts.h | 66 + src/include/lwip/apps/smtp.h | 128 + src/include/lwip/apps/smtp_opts.h | 80 + src/include/lwip/apps/snmp.h | 145 + src/include/lwip/apps/snmp_core.h | 377 ++ src/include/lwip/apps/snmp_mib2.h | 78 + src/include/lwip/apps/snmp_opts.h | 297 + src/include/lwip/apps/snmp_scalar.h | 113 + src/include/lwip/apps/snmp_snmpv2_framework.h | 32 + src/include/lwip/apps/snmp_snmpv2_usm.h | 24 + src/include/lwip/apps/snmp_table.h | 134 + src/include/lwip/apps/snmp_threadsync.h | 114 + src/include/lwip/apps/snmpv3.h | 114 + src/include/lwip/apps/sntp.h | 81 + src/include/lwip/apps/sntp_opts.h | 215 + src/include/lwip/apps/tftp_client.h | 50 + src/include/lwip/apps/tftp_common.h | 108 + src/include/lwip/apps/tftp_opts.h | 106 + src/include/lwip/apps/tftp_server.h | 42 + src/include/lwip/arch.h | 402 ++ src/include/lwip/autoip.h | 90 + src/include/lwip/debug.h | 161 + src/include/lwip/def.h | 156 + src/include/lwip/dhcp.h | 155 + src/include/lwip/dhcp6.h | 104 + src/include/lwip/dns.h | 131 + src/include/lwip/err.h | 117 + src/include/lwip/errno.h | 198 + src/include/lwip/etharp.h | 110 + src/include/lwip/ethip6.h | 68 + src/include/lwip/icmp.h | 110 + src/include/lwip/icmp6.h | 72 + src/include/lwip/if_api.h | 70 + src/include/lwip/igmp.h | 115 + src/include/lwip/inet.h | 188 + src/include/lwip/inet_chksum.h | 104 + src/include/lwip/init.h | 100 + src/include/lwip/init.h.cmake.in | 100 + src/include/lwip/ip.h | 339 ++ src/include/lwip/ip4.h | 109 + src/include/lwip/ip4_addr.h | 225 + src/include/lwip/ip4_frag.h | 100 + src/include/lwip/ip6.h | 93 + src/include/lwip/ip6_addr.h | 372 ++ src/include/lwip/ip6_frag.h | 144 + src/include/lwip/ip6_zone.h | 306 + src/include/lwip/ip_addr.h | 468 ++ src/include/lwip/mem.h | 82 + src/include/lwip/memp.h | 155 + src/include/lwip/mld6.h | 99 + src/include/lwip/nd6.h | 90 + src/include/lwip/netbuf.h | 116 + src/include/lwip/netdb.h | 150 + src/include/lwip/netif.h | 698 +++ src/include/lwip/netifapi.h | 161 + src/include/lwip/opt.h | 3595 +++++++++++ src/include/lwip/pbuf.h | 326 + src/include/lwip/priv/altcp_priv.h | 159 + src/include/lwip/priv/api_msg.h | 272 + src/include/lwip/priv/mem_priv.h | 84 + src/include/lwip/priv/memp_priv.h | 161 + src/include/lwip/priv/memp_std.h | 153 + src/include/lwip/priv/nd6_priv.h | 143 + src/include/lwip/priv/raw_priv.h | 69 + src/include/lwip/priv/sockets_priv.h | 175 + src/include/lwip/priv/tcp_priv.h | 523 ++ src/include/lwip/priv/tcpip_priv.h | 176 + src/include/lwip/prot/acd.h | 91 + src/include/lwip/prot/autoip.h | 65 + src/include/lwip/prot/dhcp.h | 178 + src/include/lwip/prot/dhcp6.h | 138 + src/include/lwip/prot/dns.h | 140 + src/include/lwip/prot/etharp.h | 114 + src/include/lwip/prot/ethernet.h | 127 + src/include/lwip/prot/iana.h | 97 + src/include/lwip/prot/icmp.h | 105 + src/include/lwip/prot/icmp6.h | 172 + src/include/lwip/prot/ieee.h | 91 + src/include/lwip/prot/igmp.h | 90 + src/include/lwip/prot/ip.h | 59 + src/include/lwip/prot/ip4.h | 131 + src/include/lwip/prot/ip6.h | 235 + src/include/lwip/prot/mld6.h | 71 + src/include/lwip/prot/nd6.h | 274 + src/include/lwip/prot/tcp.h | 100 + src/include/lwip/prot/udp.h | 68 + src/include/lwip/raw.h | 143 + src/include/lwip/sio.h | 142 + src/include/lwip/snmp.h | 213 + src/include/lwip/sockets.h | 707 +++ src/include/lwip/stats.h | 491 ++ src/include/lwip/sys.h | 575 ++ src/include/lwip/tcp.h | 500 ++ src/include/lwip/tcpbase.h | 88 + src/include/lwip/tcpip.h | 114 + src/include/lwip/timeouts.h | 128 + src/include/lwip/udp.h | 195 + src/include/netif/bridgeif.h | 127 + src/include/netif/bridgeif_opts.h | 90 + src/include/netif/etharp.h | 3 + src/include/netif/ethernet.h | 77 + src/include/netif/ieee802154.h | 112 + src/include/netif/lowpan6.h | 89 + src/include/netif/lowpan6_ble.h | 78 + src/include/netif/lowpan6_common.h | 82 + src/include/netif/lowpan6_opts.h | 122 + src/include/netif/ppp/ccp.h | 164 + src/include/netif/ppp/chap-md5.h | 36 + src/include/netif/ppp/chap-new.h | 200 + src/include/netif/ppp/chap_ms.h | 44 + src/include/netif/ppp/eap.h | 169 + src/include/netif/ppp/ecp.h | 62 + src/include/netif/ppp/eui64.h | 102 + src/include/netif/ppp/fsm.h | 182 + src/include/netif/ppp/ipcp.h | 134 + src/include/netif/ppp/ipv6cp.h | 191 + src/include/netif/ppp/lcp.h | 179 + src/include/netif/ppp/magic.h | 130 + src/include/netif/ppp/mppe.h | 181 + src/include/netif/ppp/polarssl/arc4.h | 81 + src/include/netif/ppp/polarssl/des.h | 92 + src/include/netif/ppp/polarssl/md4.h | 97 + src/include/netif/ppp/polarssl/md5.h | 96 + src/include/netif/ppp/polarssl/sha1.h | 96 + src/include/netif/ppp/ppp.h | 698 +++ src/include/netif/ppp/ppp_impl.h | 736 +++ src/include/netif/ppp/ppp_opts.h | 610 ++ src/include/netif/ppp/pppapi.h | 137 + src/include/netif/ppp/pppcrypt.h | 144 + src/include/netif/ppp/pppdebug.h | 88 + src/include/netif/ppp/pppoe.h | 187 + src/include/netif/ppp/pppol2tp.h | 209 + src/include/netif/ppp/pppos.h | 125 + src/include/netif/ppp/upap.h | 131 + src/include/netif/ppp/vj.h | 169 + src/include/netif/slipif.h | 86 + src/include/netif/zepif.h | 81 + src/netif/FILES | 23 + src/netif/bridgeif.c | 563 ++ src/netif/bridgeif_fdb.c | 212 + src/netif/ethernet.c | 329 ++ src/netif/lowpan6.c | 921 +++ src/netif/lowpan6_ble.c | 447 ++ src/netif/lowpan6_common.c | 841 +++ src/netif/ppp/PPPD_FOLLOWUP | 473 ++ src/netif/ppp/auth.c | 2513 ++++++++ src/netif/ppp/ccp.c | 1740 ++++++ src/netif/ppp/chap-md5.c | 126 + src/netif/ppp/chap-new.c | 677 +++ src/netif/ppp/chap_ms.c | 962 +++ src/netif/ppp/demand.c | 465 ++ src/netif/ppp/eap.c | 2441 ++++++++ src/netif/ppp/ecp.c | 191 + src/netif/ppp/eui64.c | 56 + src/netif/ppp/fsm.c | 799 +++ src/netif/ppp/ipcp.c | 2418 ++++++++ src/netif/ppp/ipv6cp.c | 1533 +++++ src/netif/ppp/lcp.c | 2794 +++++++++ src/netif/ppp/magic.c | 286 + src/netif/ppp/mppe.c | 412 ++ src/netif/ppp/multilink.c | 609 ++ src/netif/ppp/polarssl/README | 22 + src/netif/ppp/polarssl/arc4.c | 101 + src/netif/ppp/polarssl/des.c | 422 ++ src/netif/ppp/polarssl/md4.c | 281 + src/netif/ppp/polarssl/md5.c | 300 + src/netif/ppp/polarssl/sha1.c | 335 ++ src/netif/ppp/ppp.c | 1645 ++++++ src/netif/ppp/pppapi.c | 427 ++ src/netif/ppp/pppcrypt.c | 66 + src/netif/ppp/pppoe.c | 1217 ++++ src/netif/ppp/pppol2tp.c | 1171 ++++ src/netif/ppp/pppos.c | 940 +++ src/netif/ppp/upap.c | 679 +++ src/netif/ppp/utils.c | 957 +++ src/netif/ppp/vj.c | 685 +++ src/netif/slipif.c | 558 ++ src/netif/zepif.c | 300 + test/fuzz/Makefile | 73 + test/fuzz/README | 34 + test/fuzz/config.h | 0 test/fuzz/fuzz.c | 39 + test/fuzz/fuzz2.c | 39 + test/fuzz/fuzz3.c | 40 + test/fuzz/fuzz_common.c | 702 +++ test/fuzz/fuzz_common.h | 62 + test/fuzz/inputs/arp/arp_req.bin | Bin 0 -> 42 bytes test/fuzz/inputs/icmp/icmp_ping.bin | Bin 0 -> 98 bytes .../inputs/ipv6/neighbor_solicitation.bin | Bin 0 -> 86 bytes test/fuzz/inputs/ipv6/router_adv.bin | Bin 0 -> 118 bytes test/fuzz/inputs/tcp/tcp_syn.bin | Bin 0 -> 74 bytes test/fuzz/inputs/udp/udp_port_5000.bin | Bin 0 -> 50 bytes test/fuzz/lwipopts.h | 84 + test/fuzz/output_to_pcap.sh | 31 + test/sockets/sockets_stresstest.c | 726 +++ test/sockets/sockets_stresstest.h | 40 + test/unit/Filelists.cmake | 38 + test/unit/Filelists.mk | 54 + test/unit/Makefile | 11 + test/unit/api/test_sockets.c | 852 +++ test/unit/api/test_sockets.h | 8 + test/unit/arch/sys_arch.c | 387 ++ test/unit/arch/sys_arch.h | 79 + test/unit/core/test_def.c | 84 + test/unit/core/test_def.h | 8 + test/unit/core/test_dns.c | 52 + test/unit/core/test_dns.h | 8 + test/unit/core/test_mem.c | 221 + test/unit/core/test_mem.h | 8 + test/unit/core/test_netif.c | 285 + test/unit/core/test_netif.h | 8 + test/unit/core/test_pbuf.c | 359 ++ test/unit/core/test_pbuf.h | 8 + test/unit/core/test_timers.c | 233 + test/unit/core/test_timers.h | 8 + test/unit/dhcp/test_dhcp.c | 1103 ++++ test/unit/dhcp/test_dhcp.h | 8 + test/unit/etharp/test_etharp.c | 273 + test/unit/etharp/test_etharp.h | 8 + test/unit/ip4/test_ip4.c | 342 ++ test/unit/ip4/test_ip4.h | 8 + test/unit/ip6/test_ip6.c | 469 ++ test/unit/ip6/test_ip6.h | 8 + test/unit/lwip_check.h | 52 + test/unit/lwip_unittests.c | 125 + test/unit/lwipopts.h | 94 + test/unit/mdns/test_mdns.c | 916 +++ test/unit/mdns/test_mdns.h | 8 + test/unit/mqtt/test_mqtt.c | 115 + test/unit/mqtt/test_mqtt.h | 8 + test/unit/ppp/test_pppos.c | 67 + test/unit/ppp/test_pppos.h | 13 + test/unit/tcp/tcp_helper.c | 325 + test/unit/tcp/tcp_helper.h | 58 + test/unit/tcp/test_tcp.c | 1700 ++++++ test/unit/tcp/test_tcp.h | 8 + test/unit/tcp/test_tcp_oos.c | 1018 ++++ test/unit/tcp/test_tcp_oos.h | 8 + test/unit/tcp/test_tcp_state.c | 665 +++ test/unit/tcp/test_tcp_state.h | 8 + test/unit/udp/test_udp.c | 472 ++ test/unit/udp/test_udp.h | 8 + 726 files changed, 221755 insertions(+) create mode 100644 .gitattributes create mode 100644 .github/workflows/ci-linux.yml create mode 100644 .gitignore create mode 100644 .vscode/c_cpp_properties.json create mode 100644 .vscode/launch.json create mode 100644 .vscode/settings.json create mode 100644 .vscode/tasks.json create mode 100644 BUILDING create mode 100644 CHANGELOG create mode 100644 CMakeLists.txt create mode 100644 COPYING create mode 100644 FEATURES create mode 100644 FILES create mode 100644 README create mode 100644 UPGRADING create mode 100644 codespell_changed_files.sh create mode 100755 codespell_check.sh create mode 100644 contrib/Coverity/coverity.c create mode 100644 contrib/Filelists.cmake create mode 100644 contrib/Filelists.mk create mode 100644 contrib/addons/dhcp_extra_opts/README create mode 100644 contrib/addons/dhcp_extra_opts/dhcp_extra_opts.c create mode 100644 contrib/addons/dhcp_extra_opts/dhcp_extra_opts.h create mode 100644 contrib/addons/ipv6_static_routing/README create mode 100644 contrib/addons/ipv6_static_routing/ip6_route_table.c create mode 100644 contrib/addons/ipv6_static_routing/ip6_route_table.h create mode 100644 contrib/addons/netconn/external_resolve/dnssd.c create mode 100644 contrib/addons/netconn/external_resolve/dnssd.h create mode 100644 contrib/addons/tcp_isn/tcp_isn.c create mode 100644 contrib/addons/tcp_isn/tcp_isn.h create mode 100644 contrib/addons/tcp_md5/README create mode 100644 contrib/addons/tcp_md5/tcp_md5.c create mode 100644 contrib/addons/tcp_md5/tcp_md5.h create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/CCodeGeneration.csproj create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/CFile.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/CGenerator.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/Code.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/CodeContainerBase.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/CodeElement.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/Comment.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/EmptyLine.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/Function.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/FunctionDeclaration.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/IfThenElse.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/PP_If.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/PP_Ifdef.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/PP_Include.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/PP_Macro.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/PlainText.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/Properties/AssemblyInfo.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/Switch.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/VariableDeclaration.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/VariablePrototype.cs create mode 100644 contrib/apps/LwipMibCompiler/CCodeGeneration/VariableType.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipMibCompiler.sln create mode 100644 contrib/apps/LwipMibCompiler/LwipMibCompiler/LwipMibCompiler.csproj create mode 100644 contrib/apps/LwipMibCompiler/LwipMibCompiler/Program.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipMibCompiler/Properties/AssemblyInfo.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipMibCompiler/app.config create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/IRestriction.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/LwipSnmp.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/LwipSnmpCodeGeneration.csproj create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/MibCFile.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/MibHeaderFile.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/Properties/AssemblyInfo.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpMib.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpNode.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarAggregationNode.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarArrayNode.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNode.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeBits.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeCounter64.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeInt.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeObjectIdentifier.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeOctetString.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeTruthValue.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeUint.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpTableNode.cs create mode 100644 contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpTreeNode.cs create mode 100644 contrib/apps/LwipMibCompiler/MibViewer/FormMain.Designer.cs create mode 100644 contrib/apps/LwipMibCompiler/MibViewer/FormMain.cs create mode 100644 contrib/apps/LwipMibCompiler/MibViewer/FormMain.resx create mode 100644 contrib/apps/LwipMibCompiler/MibViewer/MibViewer.csproj create mode 100644 contrib/apps/LwipMibCompiler/MibViewer/Program.cs create mode 100644 contrib/apps/LwipMibCompiler/MibViewer/Properties/AssemblyInfo.cs create mode 100644 contrib/apps/LwipMibCompiler/MibViewer/Properties/Resources.Designer.cs create mode 100644 contrib/apps/LwipMibCompiler/MibViewer/Properties/Resources.resx create mode 100644 contrib/apps/LwipMibCompiler/MibViewer/Properties/Settings.Designer.cs create mode 100644 contrib/apps/LwipMibCompiler/MibViewer/Properties/Settings.settings create mode 100644 contrib/apps/LwipMibCompiler/MibViewer/app.config create mode 100644 contrib/apps/LwipMibCompiler/Mibs/IANA-ADDRESS-FAMILY-NUMBERS-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/IANA-CHARSET-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-ITU-ALARM-TC-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-LANGUAGE-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-MALLOC-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-MAU-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-PRINTER-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-RTPROTO-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/IANA/IANATn3270eTC-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/IANA/IANAifType-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/IF-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/INET-ADDRESS-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/IP-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/RFC-1212 create mode 100644 contrib/apps/LwipMibCompiler/Mibs/RFC-1215 create mode 100644 contrib/apps/LwipMibCompiler/Mibs/RFC1065-SMI create mode 100644 contrib/apps/LwipMibCompiler/Mibs/RFC1155-SMI create mode 100644 contrib/apps/LwipMibCompiler/Mibs/RFC1158-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/RFC1213-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/SNMPv2-CONF create mode 100644 contrib/apps/LwipMibCompiler/Mibs/SNMPv2-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/SNMPv2-SMI create mode 100644 contrib/apps/LwipMibCompiler/Mibs/SNMPv2-TC create mode 100644 contrib/apps/LwipMibCompiler/Mibs/SNMPv2-TM create mode 100644 contrib/apps/LwipMibCompiler/Mibs/TCP-MIB create mode 100644 contrib/apps/LwipMibCompiler/Mibs/UDP-MIB create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/DisplayHint.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/AgentCapabilities.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/EntityBase.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/IEntity.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ModuleCompliance.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ModuleIdentity.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/NotificationGroup.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/NotificationType.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ObjectGroup.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ObjectIdentity.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ObjectType.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/OidValueAssignment.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Exports.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/IDeclaration.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/IElement.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/ITypeReferrer.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Imports.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/ImportsFrom.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/TrapType.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/BaseType.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/BitsType.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/Choice.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/ITypeAssignment.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/IntegerType.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/IpAddressType.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/Macro.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/ObjectIdentifierType.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/OctetStringType.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/OpaqueType.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/Sequence.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/SequenceOf.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/TextualConvention.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/TypeAssignment.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/UnsignedType.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/IModule.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ISymbolEnumerator.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Lexer.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MaxAccess.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibDocument.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibException.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibModule.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibResolver.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibTree.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibTreeNode.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibTypesResolver.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ObjectIdentifier.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Status.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Symbol.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/SymbolList.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ValueMap.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ValueRange.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Properties/AssemblyInfo.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Properties/Resources.Designer.cs create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/Properties/Resources.resx create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/SharpSnmpLib.Mib.csproj create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/license.txt create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/readme.txt create mode 100644 contrib/apps/LwipMibCompiler/SharpSnmpLib/sharpsnmplib.snk create mode 100644 contrib/apps/LwipMibCompiler/example/compile_udp_mib.cmd create mode 100644 contrib/apps/LwipMibCompiler/example/compile_udp_mib.sh create mode 100644 contrib/apps/chargen/README create mode 100644 contrib/apps/chargen/chargen.c create mode 100644 contrib/apps/chargen/chargen.h create mode 100644 contrib/apps/httpserver/README create mode 100644 contrib/apps/httpserver/httpserver-netconn.c create mode 100644 contrib/apps/httpserver/httpserver-netconn.h create mode 100644 contrib/apps/netio/netio.c create mode 100644 contrib/apps/netio/netio.h create mode 100644 contrib/apps/ping/ping.c create mode 100644 contrib/apps/ping/ping.h create mode 100644 contrib/apps/rtp/rtp.c create mode 100644 contrib/apps/rtp/rtp.h create mode 100644 contrib/apps/rtp/rtpdata.h create mode 100644 contrib/apps/shell/shell.c create mode 100644 contrib/apps/shell/shell.h create mode 100644 contrib/apps/socket_examples/socket_examples.c create mode 100644 contrib/apps/socket_examples/socket_examples.h create mode 100644 contrib/apps/tcpecho/tcpecho.c create mode 100644 contrib/apps/tcpecho/tcpecho.h create mode 100644 contrib/apps/tcpecho_raw/tcpecho_raw.c create mode 100644 contrib/apps/tcpecho_raw/tcpecho_raw.h create mode 100644 contrib/apps/udpecho/udpecho.c create mode 100644 contrib/apps/udpecho/udpecho.h create mode 100644 contrib/apps/udpecho_raw/udpecho_raw.c create mode 100644 contrib/apps/udpecho_raw/udpecho_raw.h create mode 100644 contrib/examples/ethernetif/ethernetif.c create mode 100644 contrib/examples/example_app/default_netif.h create mode 100644 contrib/examples/example_app/lwipcfg.h.ci create mode 100644 contrib/examples/example_app/lwipcfg.h.example create mode 100644 contrib/examples/example_app/lwipopts.h create mode 100644 contrib/examples/example_app/lwippools.h create mode 100644 contrib/examples/example_app/ppp_settings.h create mode 100644 contrib/examples/example_app/test.c create mode 100644 contrib/examples/example_app/test_configs/opt_default.h create mode 100644 contrib/examples/example_app/test_configs/opt_dualstack.h create mode 100644 contrib/examples/example_app/test_configs/opt_ipv4only.h create mode 100644 contrib/examples/example_app/test_configs/opt_ipv6only.h create mode 100644 contrib/examples/example_app/test_configs/opt_no_tcp_dualstack.h create mode 100644 contrib/examples/example_app/test_configs/opt_no_tcp_ipv4only.h create mode 100644 contrib/examples/example_app/test_configs/opt_no_tcp_ipv6only.h create mode 100644 contrib/examples/example_app/test_configs/opt_no_udp_dualstack.h create mode 100644 contrib/examples/example_app/test_configs/opt_no_udp_ipv4only.h create mode 100644 contrib/examples/example_app/test_configs/opt_no_udp_ipv6only.h create mode 100644 contrib/examples/example_app/test_configs/opt_none.h create mode 100644 contrib/examples/example_app/test_configs/opt_nosys_dual.h create mode 100644 contrib/examples/example_app/test_configs/opt_nosys_ipv4.h create mode 100644 contrib/examples/example_app/test_configs/opt_nosys_ipv6.h create mode 100644 contrib/examples/httpd/cgi_example/cgi_example.c create mode 100644 contrib/examples/httpd/cgi_example/cgi_example.h create mode 100644 contrib/examples/httpd/examples_fs/404.html create mode 100644 contrib/examples/httpd/examples_fs/img/sics.gif create mode 100644 contrib/examples/httpd/examples_fs/index.html create mode 100644 contrib/examples/httpd/examples_fs/login.html create mode 100644 contrib/examples/httpd/examples_fs/loginfail.html create mode 100644 contrib/examples/httpd/examples_fs/session.html create mode 100644 contrib/examples/httpd/examples_fs/ssi.shtml create mode 100644 contrib/examples/httpd/examples_fsdata.c create mode 100644 contrib/examples/httpd/fs_example/fs_example.c create mode 100644 contrib/examples/httpd/fs_example/fs_example.h create mode 100644 contrib/examples/httpd/genfiles_example/genfiles_example.c create mode 100644 contrib/examples/httpd/genfiles_example/genfiles_example.h create mode 100644 contrib/examples/httpd/https_example/https_example.c create mode 100644 contrib/examples/httpd/https_example/https_example.h create mode 100644 contrib/examples/httpd/post_example/post_example.c create mode 100644 contrib/examples/httpd/ssi_example/ssi_example.c create mode 100644 contrib/examples/httpd/ssi_example/ssi_example.h create mode 100644 contrib/examples/lwiperf/lwiperf_example.c create mode 100644 contrib/examples/lwiperf/lwiperf_example.h create mode 100644 contrib/examples/mdns/mdns_example.c create mode 100644 contrib/examples/mdns/mdns_example.h create mode 100644 contrib/examples/mqtt/mqtt_example.c create mode 100644 contrib/examples/mqtt/mqtt_example.h create mode 100644 contrib/examples/ppp/pppos_example.c create mode 100644 contrib/examples/ppp/pppos_example.h create mode 100644 contrib/examples/snmp/snmp_example.c create mode 100644 contrib/examples/snmp/snmp_example.h create mode 100644 contrib/examples/snmp/snmp_private_mib/lwip_prvmib.c create mode 100644 contrib/examples/snmp/snmp_private_mib/private_mib.h create mode 100644 contrib/examples/snmp/snmp_v3/snmpv3_dummy.c create mode 100644 contrib/examples/snmp/snmp_v3/snmpv3_dummy.h create mode 100644 contrib/examples/sntp/sntp_example.c create mode 100644 contrib/examples/sntp/sntp_example.h create mode 100644 contrib/examples/tftp/tftp_example.c create mode 100644 contrib/examples/tftp/tftp_example.h create mode 100644 contrib/ports/CMakeCommon.cmake create mode 100644 contrib/ports/Common.allports.mk create mode 100644 contrib/ports/freertos/include/arch/sys_arch.h create mode 100644 contrib/ports/freertos/sys_arch.c create mode 100644 contrib/ports/unix/Common.mk create mode 100644 contrib/ports/unix/Filelists.cmake create mode 100644 contrib/ports/unix/README create mode 100644 contrib/ports/unix/check/CMakeLists.txt create mode 100644 contrib/ports/unix/check/Makefile create mode 100644 contrib/ports/unix/check/README create mode 100644 contrib/ports/unix/check/config.h create mode 100644 contrib/ports/unix/example_app/CMakeLists.txt create mode 100644 contrib/ports/unix/example_app/Makefile create mode 100644 contrib/ports/unix/example_app/default_netif.c create mode 100755 contrib/ports/unix/example_app/iteropts.sh create mode 100644 contrib/ports/unix/lib/CMakeLists.txt create mode 100644 contrib/ports/unix/lib/README create mode 100644 contrib/ports/unix/lib/lwipopts.h create mode 100644 contrib/ports/unix/port/include/arch/cc.h create mode 100644 contrib/ports/unix/port/include/arch/perf.h create mode 100644 contrib/ports/unix/port/include/arch/sys_arch.h create mode 100644 contrib/ports/unix/port/include/netif/fifo.h create mode 100644 contrib/ports/unix/port/include/netif/list.h create mode 100644 contrib/ports/unix/port/include/netif/pcapif.h create mode 100644 contrib/ports/unix/port/include/netif/sio.h create mode 100644 contrib/ports/unix/port/include/netif/tapif.h create mode 100644 contrib/ports/unix/port/include/netif/vdeif.h create mode 100644 contrib/ports/unix/port/netif/fifo.c create mode 100644 contrib/ports/unix/port/netif/list.c create mode 100644 contrib/ports/unix/port/netif/pcapif.c create mode 100644 contrib/ports/unix/port/netif/sio.c create mode 100644 contrib/ports/unix/port/netif/tapif.c create mode 100644 contrib/ports/unix/port/netif/vdeif.c create mode 100644 contrib/ports/unix/port/perf.c create mode 100644 contrib/ports/unix/port/sys_arch.c create mode 100644 contrib/ports/unix/posixlib/CMakeLists.txt create mode 100644 contrib/ports/unix/posixlib/Uninstall.cmake create mode 100644 contrib/ports/unix/posixlib/include/posix/inet.h create mode 100644 contrib/ports/unix/posixlib/include/posix/sockets.h create mode 100644 contrib/ports/unix/posixlib/lwipopts.h create mode 100755 contrib/ports/unix/setup-tapif create mode 100644 contrib/ports/win32/Common.mk create mode 100644 contrib/ports/win32/Filelists.cmake create mode 100644 contrib/ports/win32/check/check_stdint.h create mode 100644 contrib/ports/win32/check/config.h create mode 100644 contrib/ports/win32/check/stdbool.h create mode 100644 contrib/ports/win32/check/sys/time.h create mode 100644 contrib/ports/win32/check/time.c create mode 100644 contrib/ports/win32/check/unistd.h create mode 100644 contrib/ports/win32/example_app/CMakeLists.txt create mode 100644 contrib/ports/win32/example_app/Makefile create mode 100644 contrib/ports/win32/example_app/default_netif.c create mode 100644 contrib/ports/win32/include/arch/bpstruct.h create mode 100644 contrib/ports/win32/include/arch/cc.h create mode 100644 contrib/ports/win32/include/arch/epstruct.h create mode 100644 contrib/ports/win32/include/arch/perf.h create mode 100644 contrib/ports/win32/include/arch/sys_arch.h create mode 100644 contrib/ports/win32/msvc/build_coverity.cmd create mode 100644 contrib/ports/win32/msvc/libcheck.vcxproj create mode 100644 contrib/ports/win32/msvc/libcheck.vcxproj.filters create mode 100644 contrib/ports/win32/msvc/lwIP.vcxproj create mode 100644 contrib/ports/win32/msvc/lwIP.vcxproj.filters create mode 100644 contrib/ports/win32/msvc/lwIP_Test.sln create mode 100644 contrib/ports/win32/msvc/lwIP_Test.vcxproj create mode 100644 contrib/ports/win32/msvc/lwIP_Test.vcxproj.filters create mode 100644 contrib/ports/win32/msvc/lwIP_pcapif.vcxproj create mode 100644 contrib/ports/win32/msvc/lwIP_pcapif.vcxproj.filters create mode 100644 contrib/ports/win32/msvc/lwIP_unittests.sln create mode 100644 contrib/ports/win32/msvc/lwip_unittests.vcxproj create mode 100644 contrib/ports/win32/msvc/lwip_unittests.vcxproj.filters create mode 100644 contrib/ports/win32/msvc/makefsdata.vcxproj create mode 100644 contrib/ports/win32/msvc/makefsdata.vcxproj.filters create mode 100644 contrib/ports/win32/pcapif.c create mode 100644 contrib/ports/win32/pcapif.h create mode 100644 contrib/ports/win32/pcapif_helper.c create mode 100644 contrib/ports/win32/pcapif_helper.h create mode 100644 contrib/ports/win32/readme.txt create mode 100644 contrib/ports/win32/sio.c create mode 100644 contrib/ports/win32/sys_arch.c create mode 100644 doc/FILES create mode 100644 doc/NO_SYS_SampleCode.c create mode 100644 doc/ZeroCopyRx.c create mode 100644 doc/contrib.txt create mode 100644 doc/doxygen/generate.bat create mode 100755 doc/doxygen/generate.sh create mode 100644 doc/doxygen/lwip.Doxyfile create mode 100644 doc/doxygen/lwip.Doxyfile.cmake.in create mode 100644 doc/doxygen/main_page.h create mode 100644 doc/doxygen/output/index.html create mode 100644 doc/mdns.txt create mode 100644 doc/mqtt_client.txt create mode 100644 doc/ppp.txt create mode 100644 doc/savannah.txt create mode 100644 src/FILES create mode 100644 src/Filelists.cmake create mode 100644 src/Filelists.mk create mode 100644 src/api/api_lib.c create mode 100644 src/api/api_msg.c create mode 100644 src/api/err.c create mode 100644 src/api/if_api.c create mode 100644 src/api/netbuf.c create mode 100644 src/api/netdb.c create mode 100644 src/api/netifapi.c create mode 100644 src/api/sockets.c create mode 100644 src/api/tcpip.c create mode 100644 src/apps/altcp_tls/altcp_tls_mbedtls.c create mode 100644 src/apps/altcp_tls/altcp_tls_mbedtls_mem.c create mode 100644 src/apps/altcp_tls/altcp_tls_mbedtls_mem.h create mode 100644 src/apps/altcp_tls/altcp_tls_mbedtls_structs.h create mode 100644 src/apps/http/altcp_proxyconnect.c create mode 100644 src/apps/http/fs.c create mode 100644 src/apps/http/fs/404.html create mode 100644 src/apps/http/fs/img/sics.gif create mode 100644 src/apps/http/fs/index.html create mode 100644 src/apps/http/fsdata.c create mode 100644 src/apps/http/fsdata.h create mode 100644 src/apps/http/http_client.c create mode 100644 src/apps/http/httpd.c create mode 100644 src/apps/http/httpd_structs.h create mode 100644 src/apps/http/makefsdata/makefsdata create mode 100644 src/apps/http/makefsdata/makefsdata.c create mode 100644 src/apps/http/makefsdata/readme.txt create mode 100644 src/apps/http/makefsdata/tinydir.h create mode 100644 src/apps/lwiperf/lwiperf.c create mode 100644 src/apps/mdns/mdns.c create mode 100644 src/apps/mdns/mdns_domain.c create mode 100644 src/apps/mdns/mdns_out.c create mode 100644 src/apps/mqtt/mqtt.c create mode 100644 src/apps/netbiosns/netbiosns.c create mode 100644 src/apps/smtp/smtp.c create mode 100644 src/apps/snmp/snmp_asn1.c create mode 100644 src/apps/snmp/snmp_asn1.h create mode 100644 src/apps/snmp/snmp_core.c create mode 100644 src/apps/snmp/snmp_core_priv.h create mode 100644 src/apps/snmp/snmp_mib2.c create mode 100644 src/apps/snmp/snmp_mib2_icmp.c create mode 100644 src/apps/snmp/snmp_mib2_interfaces.c create mode 100644 src/apps/snmp/snmp_mib2_ip.c create mode 100644 src/apps/snmp/snmp_mib2_snmp.c create mode 100644 src/apps/snmp/snmp_mib2_system.c create mode 100644 src/apps/snmp/snmp_mib2_tcp.c create mode 100644 src/apps/snmp/snmp_mib2_udp.c create mode 100644 src/apps/snmp/snmp_msg.c create mode 100644 src/apps/snmp/snmp_msg.h create mode 100644 src/apps/snmp/snmp_netconn.c create mode 100644 src/apps/snmp/snmp_pbuf_stream.c create mode 100644 src/apps/snmp/snmp_pbuf_stream.h create mode 100644 src/apps/snmp/snmp_raw.c create mode 100644 src/apps/snmp/snmp_scalar.c create mode 100644 src/apps/snmp/snmp_snmpv2_framework.c create mode 100644 src/apps/snmp/snmp_snmpv2_usm.c create mode 100644 src/apps/snmp/snmp_table.c create mode 100644 src/apps/snmp/snmp_threadsync.c create mode 100644 src/apps/snmp/snmp_traps.c create mode 100644 src/apps/snmp/snmpv3.c create mode 100644 src/apps/snmp/snmpv3_mbedtls.c create mode 100644 src/apps/snmp/snmpv3_priv.h create mode 100644 src/apps/sntp/sntp.c create mode 100644 src/apps/tftp/tftp.c create mode 100644 src/core/altcp.c create mode 100644 src/core/altcp_alloc.c create mode 100644 src/core/altcp_tcp.c create mode 100644 src/core/def.c create mode 100644 src/core/dns.c create mode 100644 src/core/inet_chksum.c create mode 100644 src/core/init.c create mode 100644 src/core/ip.c create mode 100644 src/core/ipv4/acd.c create mode 100644 src/core/ipv4/autoip.c create mode 100644 src/core/ipv4/dhcp.c create mode 100644 src/core/ipv4/etharp.c create mode 100644 src/core/ipv4/icmp.c create mode 100644 src/core/ipv4/igmp.c create mode 100644 src/core/ipv4/ip4.c create mode 100644 src/core/ipv4/ip4_addr.c create mode 100644 src/core/ipv4/ip4_frag.c create mode 100644 src/core/ipv6/dhcp6.c create mode 100644 src/core/ipv6/ethip6.c create mode 100644 src/core/ipv6/icmp6.c create mode 100644 src/core/ipv6/inet6.c create mode 100644 src/core/ipv6/ip6.c create mode 100644 src/core/ipv6/ip6_addr.c create mode 100644 src/core/ipv6/ip6_frag.c create mode 100644 src/core/ipv6/mld6.c create mode 100644 src/core/ipv6/nd6.c create mode 100644 src/core/mem.c create mode 100644 src/core/memp.c create mode 100644 src/core/netif.c create mode 100644 src/core/pbuf.c create mode 100644 src/core/raw.c create mode 100644 src/core/stats.c create mode 100644 src/core/sys.c create mode 100644 src/core/tcp.c create mode 100644 src/core/tcp_in.c create mode 100644 src/core/tcp_out.c create mode 100644 src/core/timeouts.c create mode 100644 src/core/udp.c create mode 100644 src/include/compat/posix/arpa/inet.h create mode 100644 src/include/compat/posix/net/if.h create mode 100644 src/include/compat/posix/netdb.h create mode 100644 src/include/compat/posix/sys/socket.h create mode 100644 src/include/compat/stdc/errno.h create mode 100644 src/include/lwip/acd.h create mode 100644 src/include/lwip/altcp.h create mode 100644 src/include/lwip/altcp_tcp.h create mode 100644 src/include/lwip/altcp_tls.h create mode 100644 src/include/lwip/api.h create mode 100644 src/include/lwip/apps/FILES create mode 100644 src/include/lwip/apps/altcp_proxyconnect.h create mode 100644 src/include/lwip/apps/altcp_tls_mbedtls_opts.h create mode 100644 src/include/lwip/apps/fs.h create mode 100644 src/include/lwip/apps/http_client.h create mode 100644 src/include/lwip/apps/httpd.h create mode 100644 src/include/lwip/apps/httpd_opts.h create mode 100644 src/include/lwip/apps/lwiperf.h create mode 100644 src/include/lwip/apps/mdns.h create mode 100644 src/include/lwip/apps/mdns_domain.h create mode 100644 src/include/lwip/apps/mdns_opts.h create mode 100644 src/include/lwip/apps/mdns_out.h create mode 100644 src/include/lwip/apps/mdns_priv.h create mode 100644 src/include/lwip/apps/mqtt.h create mode 100644 src/include/lwip/apps/mqtt_opts.h create mode 100644 src/include/lwip/apps/mqtt_priv.h create mode 100644 src/include/lwip/apps/netbiosns.h create mode 100644 src/include/lwip/apps/netbiosns_opts.h create mode 100644 src/include/lwip/apps/smtp.h create mode 100644 src/include/lwip/apps/smtp_opts.h create mode 100644 src/include/lwip/apps/snmp.h create mode 100644 src/include/lwip/apps/snmp_core.h create mode 100644 src/include/lwip/apps/snmp_mib2.h create mode 100644 src/include/lwip/apps/snmp_opts.h create mode 100644 src/include/lwip/apps/snmp_scalar.h create mode 100644 src/include/lwip/apps/snmp_snmpv2_framework.h create mode 100644 src/include/lwip/apps/snmp_snmpv2_usm.h create mode 100644 src/include/lwip/apps/snmp_table.h create mode 100644 src/include/lwip/apps/snmp_threadsync.h create mode 100644 src/include/lwip/apps/snmpv3.h create mode 100644 src/include/lwip/apps/sntp.h create mode 100644 src/include/lwip/apps/sntp_opts.h create mode 100644 src/include/lwip/apps/tftp_client.h create mode 100644 src/include/lwip/apps/tftp_common.h create mode 100644 src/include/lwip/apps/tftp_opts.h create mode 100644 src/include/lwip/apps/tftp_server.h create mode 100644 src/include/lwip/arch.h create mode 100644 src/include/lwip/autoip.h create mode 100644 src/include/lwip/debug.h create mode 100644 src/include/lwip/def.h create mode 100644 src/include/lwip/dhcp.h create mode 100644 src/include/lwip/dhcp6.h create mode 100644 src/include/lwip/dns.h create mode 100644 src/include/lwip/err.h create mode 100644 src/include/lwip/errno.h create mode 100644 src/include/lwip/etharp.h create mode 100644 src/include/lwip/ethip6.h create mode 100644 src/include/lwip/icmp.h create mode 100644 src/include/lwip/icmp6.h create mode 100644 src/include/lwip/if_api.h create mode 100644 src/include/lwip/igmp.h create mode 100644 src/include/lwip/inet.h create mode 100644 src/include/lwip/inet_chksum.h create mode 100644 src/include/lwip/init.h create mode 100644 src/include/lwip/init.h.cmake.in create mode 100644 src/include/lwip/ip.h create mode 100644 src/include/lwip/ip4.h create mode 100644 src/include/lwip/ip4_addr.h create mode 100644 src/include/lwip/ip4_frag.h create mode 100644 src/include/lwip/ip6.h create mode 100644 src/include/lwip/ip6_addr.h create mode 100644 src/include/lwip/ip6_frag.h create mode 100644 src/include/lwip/ip6_zone.h create mode 100644 src/include/lwip/ip_addr.h create mode 100644 src/include/lwip/mem.h create mode 100644 src/include/lwip/memp.h create mode 100644 src/include/lwip/mld6.h create mode 100644 src/include/lwip/nd6.h create mode 100644 src/include/lwip/netbuf.h create mode 100644 src/include/lwip/netdb.h create mode 100644 src/include/lwip/netif.h create mode 100644 src/include/lwip/netifapi.h create mode 100644 src/include/lwip/opt.h create mode 100644 src/include/lwip/pbuf.h create mode 100644 src/include/lwip/priv/altcp_priv.h create mode 100644 src/include/lwip/priv/api_msg.h create mode 100644 src/include/lwip/priv/mem_priv.h create mode 100644 src/include/lwip/priv/memp_priv.h create mode 100644 src/include/lwip/priv/memp_std.h create mode 100644 src/include/lwip/priv/nd6_priv.h create mode 100644 src/include/lwip/priv/raw_priv.h create mode 100644 src/include/lwip/priv/sockets_priv.h create mode 100644 src/include/lwip/priv/tcp_priv.h create mode 100644 src/include/lwip/priv/tcpip_priv.h create mode 100644 src/include/lwip/prot/acd.h create mode 100644 src/include/lwip/prot/autoip.h create mode 100644 src/include/lwip/prot/dhcp.h create mode 100644 src/include/lwip/prot/dhcp6.h create mode 100644 src/include/lwip/prot/dns.h create mode 100644 src/include/lwip/prot/etharp.h create mode 100644 src/include/lwip/prot/ethernet.h create mode 100644 src/include/lwip/prot/iana.h create mode 100644 src/include/lwip/prot/icmp.h create mode 100644 src/include/lwip/prot/icmp6.h create mode 100644 src/include/lwip/prot/ieee.h create mode 100644 src/include/lwip/prot/igmp.h create mode 100644 src/include/lwip/prot/ip.h create mode 100644 src/include/lwip/prot/ip4.h create mode 100644 src/include/lwip/prot/ip6.h create mode 100644 src/include/lwip/prot/mld6.h create mode 100644 src/include/lwip/prot/nd6.h create mode 100644 src/include/lwip/prot/tcp.h create mode 100644 src/include/lwip/prot/udp.h create mode 100644 src/include/lwip/raw.h create mode 100644 src/include/lwip/sio.h create mode 100644 src/include/lwip/snmp.h create mode 100644 src/include/lwip/sockets.h create mode 100644 src/include/lwip/stats.h create mode 100644 src/include/lwip/sys.h create mode 100644 src/include/lwip/tcp.h create mode 100644 src/include/lwip/tcpbase.h create mode 100644 src/include/lwip/tcpip.h create mode 100644 src/include/lwip/timeouts.h create mode 100644 src/include/lwip/udp.h create mode 100644 src/include/netif/bridgeif.h create mode 100644 src/include/netif/bridgeif_opts.h create mode 100644 src/include/netif/etharp.h create mode 100644 src/include/netif/ethernet.h create mode 100644 src/include/netif/ieee802154.h create mode 100644 src/include/netif/lowpan6.h create mode 100644 src/include/netif/lowpan6_ble.h create mode 100644 src/include/netif/lowpan6_common.h create mode 100644 src/include/netif/lowpan6_opts.h create mode 100644 src/include/netif/ppp/ccp.h create mode 100644 src/include/netif/ppp/chap-md5.h create mode 100644 src/include/netif/ppp/chap-new.h create mode 100644 src/include/netif/ppp/chap_ms.h create mode 100644 src/include/netif/ppp/eap.h create mode 100644 src/include/netif/ppp/ecp.h create mode 100644 src/include/netif/ppp/eui64.h create mode 100644 src/include/netif/ppp/fsm.h create mode 100644 src/include/netif/ppp/ipcp.h create mode 100644 src/include/netif/ppp/ipv6cp.h create mode 100644 src/include/netif/ppp/lcp.h create mode 100644 src/include/netif/ppp/magic.h create mode 100644 src/include/netif/ppp/mppe.h create mode 100644 src/include/netif/ppp/polarssl/arc4.h create mode 100644 src/include/netif/ppp/polarssl/des.h create mode 100644 src/include/netif/ppp/polarssl/md4.h create mode 100644 src/include/netif/ppp/polarssl/md5.h create mode 100644 src/include/netif/ppp/polarssl/sha1.h create mode 100644 src/include/netif/ppp/ppp.h create mode 100644 src/include/netif/ppp/ppp_impl.h create mode 100644 src/include/netif/ppp/ppp_opts.h create mode 100644 src/include/netif/ppp/pppapi.h create mode 100644 src/include/netif/ppp/pppcrypt.h create mode 100644 src/include/netif/ppp/pppdebug.h create mode 100644 src/include/netif/ppp/pppoe.h create mode 100644 src/include/netif/ppp/pppol2tp.h create mode 100644 src/include/netif/ppp/pppos.h create mode 100644 src/include/netif/ppp/upap.h create mode 100644 src/include/netif/ppp/vj.h create mode 100644 src/include/netif/slipif.h create mode 100644 src/include/netif/zepif.h create mode 100644 src/netif/FILES create mode 100644 src/netif/bridgeif.c create mode 100644 src/netif/bridgeif_fdb.c create mode 100644 src/netif/ethernet.c create mode 100644 src/netif/lowpan6.c create mode 100644 src/netif/lowpan6_ble.c create mode 100644 src/netif/lowpan6_common.c create mode 100644 src/netif/ppp/PPPD_FOLLOWUP create mode 100644 src/netif/ppp/auth.c create mode 100644 src/netif/ppp/ccp.c create mode 100644 src/netif/ppp/chap-md5.c create mode 100644 src/netif/ppp/chap-new.c create mode 100644 src/netif/ppp/chap_ms.c create mode 100644 src/netif/ppp/demand.c create mode 100644 src/netif/ppp/eap.c create mode 100644 src/netif/ppp/ecp.c create mode 100644 src/netif/ppp/eui64.c create mode 100644 src/netif/ppp/fsm.c create mode 100644 src/netif/ppp/ipcp.c create mode 100644 src/netif/ppp/ipv6cp.c create mode 100644 src/netif/ppp/lcp.c create mode 100644 src/netif/ppp/magic.c create mode 100644 src/netif/ppp/mppe.c create mode 100644 src/netif/ppp/multilink.c create mode 100644 src/netif/ppp/polarssl/README create mode 100644 src/netif/ppp/polarssl/arc4.c create mode 100644 src/netif/ppp/polarssl/des.c create mode 100644 src/netif/ppp/polarssl/md4.c create mode 100644 src/netif/ppp/polarssl/md5.c create mode 100644 src/netif/ppp/polarssl/sha1.c create mode 100644 src/netif/ppp/ppp.c create mode 100644 src/netif/ppp/pppapi.c create mode 100644 src/netif/ppp/pppcrypt.c create mode 100644 src/netif/ppp/pppoe.c create mode 100644 src/netif/ppp/pppol2tp.c create mode 100644 src/netif/ppp/pppos.c create mode 100644 src/netif/ppp/upap.c create mode 100644 src/netif/ppp/utils.c create mode 100644 src/netif/ppp/vj.c create mode 100644 src/netif/slipif.c create mode 100644 src/netif/zepif.c create mode 100644 test/fuzz/Makefile create mode 100644 test/fuzz/README create mode 100644 test/fuzz/config.h create mode 100644 test/fuzz/fuzz.c create mode 100644 test/fuzz/fuzz2.c create mode 100644 test/fuzz/fuzz3.c create mode 100644 test/fuzz/fuzz_common.c create mode 100644 test/fuzz/fuzz_common.h create mode 100644 test/fuzz/inputs/arp/arp_req.bin create mode 100644 test/fuzz/inputs/icmp/icmp_ping.bin create mode 100644 test/fuzz/inputs/ipv6/neighbor_solicitation.bin create mode 100644 test/fuzz/inputs/ipv6/router_adv.bin create mode 100644 test/fuzz/inputs/tcp/tcp_syn.bin create mode 100644 test/fuzz/inputs/udp/udp_port_5000.bin create mode 100644 test/fuzz/lwipopts.h create mode 100644 test/fuzz/output_to_pcap.sh create mode 100644 test/sockets/sockets_stresstest.c create mode 100644 test/sockets/sockets_stresstest.h create mode 100644 test/unit/Filelists.cmake create mode 100644 test/unit/Filelists.mk create mode 100644 test/unit/Makefile create mode 100644 test/unit/api/test_sockets.c create mode 100644 test/unit/api/test_sockets.h create mode 100644 test/unit/arch/sys_arch.c create mode 100644 test/unit/arch/sys_arch.h create mode 100644 test/unit/core/test_def.c create mode 100644 test/unit/core/test_def.h create mode 100644 test/unit/core/test_dns.c create mode 100644 test/unit/core/test_dns.h create mode 100644 test/unit/core/test_mem.c create mode 100644 test/unit/core/test_mem.h create mode 100644 test/unit/core/test_netif.c create mode 100644 test/unit/core/test_netif.h create mode 100644 test/unit/core/test_pbuf.c create mode 100644 test/unit/core/test_pbuf.h create mode 100644 test/unit/core/test_timers.c create mode 100644 test/unit/core/test_timers.h create mode 100644 test/unit/dhcp/test_dhcp.c create mode 100644 test/unit/dhcp/test_dhcp.h create mode 100644 test/unit/etharp/test_etharp.c create mode 100644 test/unit/etharp/test_etharp.h create mode 100644 test/unit/ip4/test_ip4.c create mode 100644 test/unit/ip4/test_ip4.h create mode 100644 test/unit/ip6/test_ip6.c create mode 100644 test/unit/ip6/test_ip6.h create mode 100644 test/unit/lwip_check.h create mode 100644 test/unit/lwip_unittests.c create mode 100644 test/unit/lwipopts.h create mode 100644 test/unit/mdns/test_mdns.c create mode 100644 test/unit/mdns/test_mdns.h create mode 100644 test/unit/mqtt/test_mqtt.c create mode 100644 test/unit/mqtt/test_mqtt.h create mode 100644 test/unit/ppp/test_pppos.c create mode 100644 test/unit/ppp/test_pppos.h create mode 100644 test/unit/tcp/tcp_helper.c create mode 100644 test/unit/tcp/tcp_helper.h create mode 100644 test/unit/tcp/test_tcp.c create mode 100644 test/unit/tcp/test_tcp.h create mode 100644 test/unit/tcp/test_tcp_oos.c create mode 100644 test/unit/tcp/test_tcp_oos.h create mode 100644 test/unit/tcp/test_tcp_state.c create mode 100644 test/unit/tcp/test_tcp_state.h create mode 100644 test/unit/udp/test_udp.c create mode 100644 test/unit/udp/test_udp.h
diff --git a/.gitattributes b/.gitattributes new file mode 100644 index 00000000000..dd82723fe67 --- /dev/null +++ b/.gitattributes @@ -0,0 +1,10 @@ +# These files are text and should be normalized +*.txt text +*.c text +*.h text + +# For git archive +.gitignore export-ignore +.gitattributes export-ignore +.github export-ignore +.vscode export-ignore diff --git a/.github/workflows/ci-linux.yml b/.github/workflows/ci-linux.yml new file mode 100644 index 00000000000..f97d23c919b --- /dev/null +++ b/.github/workflows/ci-linux.yml @@ -0,0 +1,43 @@ +name: CI + +on: + push: + branches: [master] + +jobs: + build: + strategy: + matrix: + compiler: [gcc, clang] + env: + CC: ${{ matrix.compiler }} + LSAN_OPTIONS: verbosity=1:log_threads=1 + runs-on: ubuntu-latest + + steps: + - uses: actions/checkout@v2 + - name: Install deps + run: sudo apt-get install check ninja-build doxygen + + - name: Copy lwipcfg.h for example app + run: cp contrib/examples/example_app/lwipcfg.h.ci contrib/examples/example_app/lwipcfg.h + + - name: Build unit tests with make + run: make -C contrib/ports/unix/check + - name: Run unit tests + run: make -C contrib/ports/unix/check check + + - name: Run cmake + run: mkdir build && cd build && cmake .. -G Ninja + - name: Build with cmake + run: cd build && cmake --build . + - name: Build docs with cmake + run: cd build && cmake --build . --target lwipdocs + + - name: Validate combinations of options + run: cd contrib/ports/unix/example_app && ./iteropts.sh + + - name: Build the default example app + run: | + cp contrib/examples/example_app/lwipcfg.h.example contrib/examples/example_app/lwipcfg.h + make -C contrib/ports/unix/example_app TESTFLAGS="-Wno-documentation" -j 4 diff --git a/.gitignore b/.gitignore new file mode 100644 index 00000000000..2fbaca4f5b2 --- /dev/null +++ b/.gitignore @@ -0,0 +1,60 @@ +*.o +*.so +*.a +*.exe +*lwip_unittests.xml +*.suo +*.log +.depend* + +/.vscode/ipch + +/doc/doxygen/output/html + +/test/fuzz/output +/test/fuzz/lwip_fuzz +/test/fuzz/lwip_fuzz2 +/test/fuzz/lwip_fuzz3 +/test/fuzz/.depend + +/build + +/contrib/examples/example_app/lwipcfg.h +/contrib/examples/example_app/lwipopts_test.h + +/contrib/ports/unix/example_app/build +/contrib/ports/unix/example_app/example_app +/contrib/ports/unix/example_app/makefsdata + +/contrib/ports/unix/check/build +/contrib/ports/unix/lib/build +/contrib/ports/unix/check/lwip_unittests + +/contrib/ports/win32/example_app/build +/contrib/ports/win32/lwipcfg_msvc.h + +/contrib/ports/win32/msvc/Debug +/contrib/ports/win32/msvc/Debug unittests +/contrib/ports/win32/msvc/Release +/contrib/ports/win32/msvc/Release unittests +/contrib/ports/win32/msvc/*.user +/contrib/ports/win32/msvc/*.ncb +/contrib/ports/win32/msvc/*.cache +/contrib/ports/win32/msvc/*.suo +/contrib/ports/win32/msvc/ipch +/contrib/ports/win32/msvc/*.opensdf +/contrib/ports/win32/msvc/*.sdf +/contrib/ports/win32/mingw/*.map +/contrib/ports/win32/mingw/cov-int +/contrib/ports/win32/msvc/.vs +/contrib/apps/LwipMibCompiler/.vs +/contrib/apps/LwipMibCompiler/CCodeGeneration/bin +/contrib/apps/LwipMibCompiler/CCodeGeneration/obj +/contrib/apps/LwipMibCompiler/LwipMibCompiler/bin +/contrib/apps/LwipMibCompiler/LwipMibCompiler/obj +/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/bin +/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/obj +/contrib/apps/LwipMibCompiler/MibViewer/bin +/contrib/apps/LwipMibCompiler/MibViewer/obj +/contrib/apps/LwipMibCompiler/SharpSnmpLib/bin +/contrib/apps/LwipMibCompiler/SharpSnmpLib/obj diff --git a/.vscode/c_cpp_properties.json b/.vscode/c_cpp_properties.json new file mode 100644 index 00000000000..e7eb6a69d63 --- /dev/null +++ b/.vscode/c_cpp_properties.json @@ -0,0 +1,28 @@ +{ + "configurations": [ + { + "name": "Linux", + "includePath": [ + "${workspaceFolder}/src/include", + "${workspaceFolder}/contrib", + "${workspaceFolder}/contrib/examples/example_app", + "${workspaceFolder}/contrib/ports/unix/port/include", + "${workspaceFolder}/contrib/ports/unix/example_app" + ], + "defines": [], + "intelliSenseMode": "gcc-x64", + "browse": { + "path": [ + "${workspaceFolder}/**" + ], + "limitSymbolsToIncludedHeaders": true, + "databaseFilename": "" + }, + "compilerPath": "/usr/bin/gcc", + "cStandard": "c11", + "cppStandard": "c++17", + "configurationProvider": "vector-of-bool.cmake-tools" + } + ], + "version": 4 +} \ No newline at end of file diff --git a/.vscode/launch.json b/.vscode/launch.json new file mode 100644 index 00000000000..69b9bcf9eb1 --- /dev/null +++ b/.vscode/launch.json @@ -0,0 +1,62 @@ +{ + // Use IntelliSense to learn about possible attributes. + // Hover to view descriptions of existing attributes. + // For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387 + "version": "0.2.0", + "configurations": [ + { + "name": "(gdb) Launch example_app", + "type": "cppdbg", + "request": "launch", + "args": [], + "stopAtEntry": true, + "environment": [], + "externalConsole": true, + "MIMode": "gdb", + "preLaunchTask": "Build example_app", + "setupCommands": [ + { + "description": "Enable pretty-printing for gdb", + "text": "-enable-pretty-printing", + "ignoreFailures": true + } + ], + "linux": { + "cwd": "${workspaceFolder}/build/contrib/ports/unix/example_app", + "program": "${workspaceFolder}/build/contrib/ports/unix/example_app/example_app", + }, + "windows": { + "cwd": "${workspaceFolder}/build/contrib/ports/win32/example_app", + "program": "${workspaceFolder}/build/contrib/ports/win32/example_app/example_app", + "miDebuggerPath": "gdb.exe", + } + }, + { + "name": "(gdb) Launch unit tests", + "type": "cppdbg", + "request": "launch", + "args": [], + "stopAtEntry": true, + "environment": [], + "externalConsole": false, + "MIMode": "gdb", + "preLaunchTask": "Build unit tests", + "setupCommands": [ + { + "description": "Enable pretty-printing for gdb", + "text": "-enable-pretty-printing", + "ignoreFailures": true + } + ], + "linux": { + "cwd": "${workspaceFolder}/contrib/ports/unix/check/build", + "program": "${workspaceFolder}/contrib/ports/unix/check/build/lwip_unittests", + }, + "windows": { + "cwd": "${workspaceFolder}/contrib/ports/win32/check/build", + "program": "${workspaceFolder}/contrib/ports/win32/check/build/lwip_unittests", + "miDebuggerPath": "gdb.exe", + } + } + ] +} diff --git a/.vscode/settings.json b/.vscode/settings.json new file mode 100644 index 00000000000..5940f404d6e --- /dev/null +++ b/.vscode/settings.json @@ -0,0 +1,10 @@ +{ + "editor.tabSize": 2, + "editor.insertSpaces": true, + "files.insertFinalNewline": true, + "files.trimFinalNewlines": true, + "files.trimTrailingWhitespace": true, + "files.associations": { + "*.h": "c" + } +} diff --git a/.vscode/tasks.json b/.vscode/tasks.json new file mode 100644 index 00000000000..ccc3c7e335e --- /dev/null +++ b/.vscode/tasks.json @@ -0,0 +1,54 @@ +{ + // See https://go.microsoft.com/fwlink/?LinkId=733558 + // for the documentation about the tasks.json format + "version": "2.0.0", + "tasks": [ + { + "label": "Build example_app", + "type": "shell", + "options": { + "cwd": "${workspaceFolder}/build" + }, + "problemMatcher": "$gcc", + "group": { + "kind": "build", + "isDefault": true + }, + "command": "cmake --build ." + }, + { + "label": "Build unit tests", + "type": "shell", + "problemMatcher": "$gcc", + "group": "build", + "linux": { + "options": { + "cwd": "${workspaceFolder}/contrib/ports/unix/check/build" + }, + }, + "windows": { + "options": { + "cwd": "${workspaceFolder}/contrib/ports/win32/check/build" + }, + }, + "command": "cmake --build ." + }, + { + "label": "Configure example_app", + "type": "shell", + "problemMatcher": "$gcc", + "group": "build", + "command": "cd ${workspaceFolder}; mkdir build; cd build; cmake .." + }, + { + "label": "Generate documentation", + "type": "shell", + "problemMatcher": [], + "group": "none", + "options": { + "cwd": "${workspaceFolder}/build" + }, + "command": "cmake --build . --target lwipdocs" + } + ] +} diff --git a/BUILDING b/BUILDING new file mode 100644 index 00000000000..a2adc626b61 --- /dev/null +++ b/BUILDING @@ -0,0 +1,119 @@ +Building lwIP +============= + +lwIP uses a CMake based build system. + +The CMake files in this project are designed to +be included into your own CMake files. They are +mainly variable definitions containing a list of +source files and predefined static libraries to +be linked against application code. + +1) lwIP sources: + src/Filelists.cmake provides file lists containing + the lwIP core library. + The file also contains two static libraries, lwipcore + and lwipallapps, where you can link your app against. + This is the file that is useful to all lwIP users. + +2) Example applications: + contrib/Filelists.cmake provides several file lists + containing the example applications. + The file also contains several static libraries + for these example apps. + This file is only useful for you, if you can use one + of the examples in your application, which is normally + not the case. + +3) OS/platform port: + Usually the OS port needs to be provided by the user. + If a port to Linux, Windows or MacOS is useful for + you, you can use + contrib/ports/{win32, unix}/Filelists.cmake + that contains file lists and libraries for + these operating systems. + +VARIABLES +========= +In all cases, you need to provide two variables. + +"LWIP_DIR" pointing to the lwIP directory +Example: +set(LWIP_DIR ${CMAKE_CURRENT_SOURCE_DIR}/externals/lwip) + +"LWIP_INCLUDE_DIRS" that contains the include base paths +- for lwIP itself (${LWIP_DIR}/src/include) +- for lwIP contrib if you use it (${LWIP_DIR}/contrib) +- to a directory containing an OS port +- to a directory containing lwipopts.h + +Example: +set (LWIP_INCLUDE_DIRS + "${LWIP_DIR}/src/include" + "${LWIP_DIR}/contrib" + "${LWIP_DIR}/contrib/ports/unix/port/include" + "${LWIP_DIR}/contrib/examples/example_app" +) + +Putting it all together +======================= +To get a working application, your CMake system +needs to provide the variables described above, e.g. +set (LWIP_DIR <path to lwip sources>) +set (LWIP_INCLUDE_DIRS + "${LWIP_DIR}/src/include" + "${LWIP_DIR}/contrib" + "<path to my port>/include" + "<path to lwipopts.h>" +) + +You may add some defines: +set (LWIP_DEFINITIONS LWIP_DEBUG=1) + +Then include the filelists you need: +include(${LWIP_DIR}/src/Filelists.cmake) +include(${LWIP_DIR}/contrib/Filelists.cmake) + +Then, declare you executable: +add_executable(my_app <my source files> <my lwip port files>) + +Add lwIP include dirs to your app: +target_include_directories(my_app PRIVATE ${LWIP_INCLUDE_DIRS}) + +Link your app against the lwIP libs from the filelists you need: +target_link_libraries(my_app lwipcontribapps lwipallapps lwipcore) + +Working example +=============== +Working build examples can be found in the +contrib/ports/{win32, unix}/example_app +subdirectory. +To use them, create a build directory and call cmake with +the lwIP root dir: + +- mkdir build +- cd build +- cmake .. +- cmake --build . + +The CMakeLists.txt will autoselect the correct port +for your system (supported: Linux, Windows, Darwin). + +To configure the example app to your needs, you need to copy the file + contrib/examples/example_app/lwipcfg.h.example +to + contrib/examples/example_app/lwipcfg.h +and edit to your needs. + +Makefile based build system +=========================== +lwIP also maintains file lists for Makefile-based +build systems. Look for Filelists.mk files +in the source tree. We try to maintain them, +but lwIP's mainly focused build system is CMake. + +MS Visual Studio +================ +lwIP also provides basic support for MSVS in the win32 port +folder under 'msvc'. We try to maintain these files, +but lwIP's mainly focused build system is CMake. diff --git a/CHANGELOG b/CHANGELOG new file mode 100644 index 00000000000..5d5f81ad31c --- /dev/null +++ b/CHANGELOG @@ -0,0 +1,4635 @@ +HISTORY + * These are only the most important changes. For a full list, use git log: + http://git.savannah.nongnu.org/cgit/lwip.git + +(git master) + + * [Enter new changes just after this line - do not remove this line] + +(STABLE-2.2.0): + + 2018-10-02: Dirk Ziegelmeier + * Integrate contrib repository into main lwIP repository + + ++ New features: + + 2022-04-05: David Cermak + * contrib/addons: Add example of using DHCP extra options hooks + + 2023-05-11: David Cermak + * dhcp: Add macro for appending extra client's request options + + 2023-05-11: xueyunfei + * dhcp: Enable custom config for timeouts, thresholds, backoff time + + 2021-04-26 + * test/unit: added more unit tests + + 2020-03-27: Simon Goldschmidt + * test/fuzz: improve fuzz test + + 2019-12-11: Simon Goldschmidt + * ip6addr_aton: support scoped address strings (via '%') + + 2019-08-28: Joan Lledó + * Contrib: Add kFreeBSD to the Unix port + + 2019-07-14: Joan Lledó + * Unix port: improve support for the Hurd + + ++ Bugfixes: + + 2019-12-11: David Girault + * altcp_tls: support for saving/restoring session information + + 2018-11-16: Craig McQUeen + * dns: allow a DNS look-up with a trailing dot in the name + + 2018-10-19: Timmy Brolin + * Add outgoing VLAN PCP support for Ethernet level QoS + + 2018-10-08: Ben Wijen + * apps/tftp: added TFTP client + + 2018-10-04: Jasper Verschueren + * Implement IPv4 ACD (Address Conflict Detection) + + 2023-05-10 + * altcp_tls_mbedtls: note which version of mbedtls we are compatible to + * altcp_tls_mbedtls: multiple compatibility fixes + + 2023-04-26: Jan Breuer, Harrold Spier, Ognjen Bjelica, Dirk Ziegelmeier, Simon Goldschmidt + * apps/snmp: multiple fixes and improvements to snmp + + 2022-01-12: Simon Goldschmidt + * httpd: clean up custom file handling + + 2021-11-25: quanjia + * ping: fix sockaddr len in ping_send() for PING_USE_SOCKETS==1 + + 2021-11-12: Bas Prins + * http_client: reset timeout when receiving data + + 2020-07-07: Erik Ekman + * Rename IP and Ethernet equality checkers from _cmp to _eq + + 2020-03-05: Simon Goldschmidt + * tcp: tighten up checks for received SYN + + 2020-01-30: Simon Goldschmidt, David Girault, David J. Fiddes, Tom Ferrin + * apps/sntp: multiple fixes and improvements for sntp + + 2020-01-30: Simon Goldschmidt + * ip_forward: fix IPv4 forwarding with multiple netifs/offloading + + 2019-06-11: David Girault, Giuseppe Modugno + * apps/mqtt: multiple fixes for mqtt + + 2019-05-19: Joan Lledó + * New function tcpip_callback_wait() + Call a function inside the tcpip thread and block the calling thread until + the callback finishes + + 2018-08-15: Jasper Verschueren, David Girault, Our Air Quality + * apps/mdns: greatly improved the mdns client + +(STABLE-2.1.2): + + ++ Bugfixes: + + 2018-11-21: Jens Nielsen + * netbiosns.c: fix expecting too large packet (bug #55069) + + 2018-11-19: Dirk Ziegelmeier + * smtp.c: fix compiling with strict C compatibility because of strnlen (bug #55034) + + 2018-11-12: Simon Goldschmidt + * tcp.c: fix overflow check in tcp_recved triggering invalid assertion (bug #55015) + + 2018-11-12: Simon Goldschmidt + * tcp.c: fix a bug in sending RST segments (sent from port 0) + +(STABLE-2.1.1): + + ++ Bugfixes: + + 2018-11-01: Joan Lledó + * sockets.c: fix bad assertion in lwip_poll_dec_sockets_used() (bug #54933) + + 2018-11-01: Dirk Ziegelmeier + * ip4.c: don't send 127.* to default netif (bug #54670) + + 2018-10-23: David Girault + * altcp_tls_mbedtls.c: fix use-after free (bug #54774) + + 2018-10-23: Ognjen Bjelica, Dirk Ziegelmeier + * snmp_scalar.c: Avoid NULL pointer dereference (bug #54886) + + 2018-10-23: Simon Goldschmidt + * Fix missing standard includes in multiple files + + 2018-10-17: Ivan Warren + * def.h: fix casting htonX and ntohX to u16_t (bug #54850) + + 2018-10-12: Simon Goldschmidt + * Revert "tcp_abandon: no need to buffer pcb->local_port" (fix that source port was 0 for RST + called when aborting a connection) + + 2018-10-11: Jonas Rabenstein + * tcp.c: tcp_recved: check for overflow and warn about too big values (patch #9699) + + 2018-10-06: Joan Lledó + * sockets.c: alloc_socket(): Check for LWIP_SOCKET_POLL when setting select- + related variables (patch #9696) + + 2018-10-04: Spencer + * tcp.c: Update prev pointer when skipping entries in tcp_slowtmr (patch #9694) + + 2018-09-27: Martine Lenders + * lowpan6.c: Fix IEEE 802.15.4 address setting (bug #54749) + +(STABLE-2.1.0): + + ++ New features: + + 2018-06-17: Simon Goldschmidt + * lwiperf: implemented iPerf client mode + + 2018-04-23: Dirk Ziegelmeier + * added cmake build files + + 2018-03-04: Ray Abram + * netbios responder: respond to '*' queries + + 2018-02-23: Benjamin Aigner + * 6lowpan: add 6lowpan-over-BLE netif (based on existing 6lowpan netif) + + 2018-02-22: Simon Goldschmidt + * ipv6: add support for stateless DHCPv6 (to get DNS servers in SLAAC nets) + + 2018-02-16: Simon Goldschmidt + * add raw API http(s) client (with proxy support) + + 2018-02-01: Simon Goldschmidt + * tcp: add hooks to implement additional socket options + + 2018-02-01: Simon Goldschmidt + * tcp: add hooks to implement tcp md5 signatures or similar (see contrib/addons for an example) + + 2018-01-05: Simon Goldschmidt + * Added sys_mbox_trypost_fromisr() and tcpip_callbackmsg_trycallback_fromisr() + These can be used to post preallocated messages from an ISR to the tcpip thread + (e.g. when using FreeRTOS) + + 2018-01-02: Dirk Ziegelmeier + * task #14780: Add debug helper asserts to ensure threading/locking requirements are met + + 2017-11-21: Simon Goldschmidt + * task #14600: tcp_alloc(): kill TF_CLOSEPEND connections before other ESTABLISHED + + 2017-11-21: Simon Goldschmidt + * makefsdata: added option "-ssi:<filename>" to control SSI tag checking/insertion + through a list of filenames, not by checking the file extension at runtime + + 2017-11-20: Joel Cunningham + * netconn: add LWIP_HOOK_NETCONN_EXTERNAL_RESOLVE to use external DNS resolver (patch #9427) + + 2017-11-14: Joel Cunningham + * netifapi: Add thread safe ARP cache APIs (task #14724) + + 2017-11-06: Axel Lin + * TCP: kill existing connections with a LOWER priority than the one currently being opened. + Previous implementations also kill existing connections of the SAME priority. + + 2017-09-21: Kalle Olavi Niemitalo + * sockets: add poll() implementation (patch #9450) + + 2017-09-10: Joel Cunningham + * sockets: add readv() implementation (task #14610) + + 2017-08-04: Simon Goldschmidt + * Clean up DHCP a bit: no need keep msg_out and msg_in as members in struct + dhcp - they are used in a call stack only (p_out and options_out_len as well) + + 2017-08-04: Simon Goldschmidt + * pbuf: split pbuf_header(s16_t) into pbuf_add_header(size_t) and + pbuf_remove_header(size_t) + + 2017-07-20: Douglas + * sys: deprecate sys_arch_sem_wait and sys_arch_mbox_fetch returning the + time waited rather they are now defined to return != SYS_ARCH_TIMEOUT + on success. + + 2017-07-03: Jakub Schmidtke + * tcp: added support for sending TCP SACKs + + 2017-06-20: Joel Cunningham + * netconn/netdb: added core locking support to netconn_gethostbyname (task #14523) + + 2017-04-25: Simon Goldschmidt + * dhcp: added two hooks for adding and parsing user defined DHCP options + + 2017-04-25: Joel Cunningham + * sockets: added recvmsg for UDP (together with CMSG and IP_PKTINFO) (task #14247) + + 2017-04-20: Joel Cunningham + * tcp: added Appropriate Byte Counting support (task #14128) + + 2017-04-11: Simon Goldschmidt + * netconn/sockets: remove fatal error handling, fix asynchronous error handling, + ensure data before RST can be received + + 2017-03-30: Simon Goldschmidt + * added "application layered TCP" connection API (altcp) for seamless integration + of TLS or proxy connections + + 2017-03-09: Simon Goldschmidt + * sockets: add recvmsg for TCP + + 2017-03-02: Joel Cunningham + * netconn/sockets: vectorize netconn_write for TCP, treating a vectored I/O write + atomically in regards to TCP segmentation (patch #8882) + + 2017-03-02: Simon Goldschmidt + * netconn: added nonblocking accept/recv to netconn API (task #14396) + + 2017-02-28: Simon Goldschmidt + * Added LWIP_SINGLE_NETIF for small targets with only one netif + + 2017-02-10: David van Moolenbroek + * Implement UDP and RAW multicast support for IPv6 (core API, not netconn/sockets) + + 2017-02-04: David van Moolenbroek + * IPv6 scopes support + + 2017-01-20: Joel Cunningham + * sockets: add interface name/index APIs (task #14314) + + 2017-01-08: David van Moolenbroek + * Extensions to RAW API (patch #9208) + - Connected RAW PCBs + - Add raw_sendto_if_src() + - Support IP_HDRINCL socket option + + ++ Bugfixes: + + 2018-06-19: Simon Goldschmidt + * tcp: fix RTO timer not working if link is down + + 2018-06-15: Sylvain Rochet + * ppp: multiple smaller bugfixes + + 2018-05-17: Simon Goldschmidt + * etharp: arp table can now be bigger than 127 entries + + 2018-04-25: Jens Nielsen + * tftp server: correctly handle retransmissions + + 2018-04-18: Simon Goldschmidt + sockets: fix race conditions when closing full-duplex sockets + + 2018-03-09: Simon Goldschmidt + * 6lowpan: fix to work against contiki; added ZigBee encapsulation netif for tests + + 2018-02-04: Simon Goldschmidt + * sockets: fix inconsistencies on close (inconsistent error codes, double FIN) + + 2018-01-05: Dirk Ziegelmeier + * Fix bug #52748: the bug in timeouts.c by reimplementing timer logic to use + absolute instead of relative timeout values + + 2017-12-31: Dirk Ziegelmeier + * Fix bug #52704: DHCP and bad OFFER: Stop timeout only if offer is accepted + + 2017-11-08: Joel Cunningham + * netif: ensure link and admin states are up in issue reports (bug #52353) + + 2017-09-12: David Lockyer + * select: allocate select_cb from memp for LWIP_MPU_COMPATIBLE = 1 (bug #51990) + + 2017-09-11: Simon Goldschmidt + * tcp_in.c: fix bug #51937 (leaking tcp_pcbs on passive close with unacked data) + + 2017-08-11: Joel Cunningham + * lwip_itoa: fix converting the number 0 (previously converted to '\0') (bug #51729) + + 2017-08-08: Dirk Ziegelmeier + * ip4_route_src: parameter order is reversed: ip4_route_src(dest, src) -> ip4_route_src(src, dest) + to make parameter order consistent with other ip*_route*() functions + Same also applies to LWIP_HOOK_IP4_ROUTE_SRC() parameter order. + + 2017-08-04: Joel Cunningham + * tcp: re-work persist timer to fully close window (details in bug #50837) + + 2017-07-26: Simon Goldschmidt + * snmp_msg.c: fix bug #51578 (SNMP failed to decode some values on non 32bit platforms) + + 2017-07-20: Simon Goldschmidt + * compatibility headers: moved from 'src/include/posix' to 'src/include/compat/posix', + 'src/include/compat/stdc' etc. + + 2017-05-09: Joel Cunningham + * tcp: add zero-window probe timeout (bug #50837) + + 2017-04-11: Simon Goldschmidt + * sockets.c: task #14420 (Remove sys_sem_signal from inside SYS_ARCH_PROTECT + crit section) done for LWIP_TCPIP_CORE_LOCKING==1 + + 2017-02-24: Simon Goldschmidt + * sockets.c: fixed close race conditions in lwip_select (for LWIP_NETCONN_FULLDUPLEX) + + 2017-02-24: Simon Goldschmidt + * sockets.c: fixed that select ignored invalid/not open sockets in the fd_sets (bug #50392) + + 2017-01-11: David van Moolenbroek + * Lots of IPv6 related fixes and improvements + +(STABLE-2.0.3) + + ++ Bugfixes: + + 2017-09-11: Simon Goldschmidt + * tcp_in.c: fix bug #51937 (leaking tcp_pcbs on passive close with unacked data) + + 2017-08-02: Abroz Bizjak/Simon Goldschmidt + * multiple fixes in IPv4 reassembly (leading to corrupted datagrams received) + + 2017-03-30: Simon Goldschmidt + * dhcp.c: return ERR_VAL instead of asserting on offset-out-of-pbuf + + 2017-03-23: Dirk Ziegelmeier + * dhcp.h: fix bug #50618 (dhcp_remove_struct() macro does not work) + +(STABLE-2.0.2) + + ++ New features: + + 2017-02-10: Dirk Ziegelmeier + * Implement task #14367: Hooks need a better place to be defined: + We now have a #define for a header file name that is #included in every .c + file that provides hooks. + + 2017-02-10: Simon Goldschmidt + * tcp_close does not fail on memory error (instead, FIN is sent from tcp_tmr) + + ++ Bugfixes: + + 2017-03-08 + * tcp: do not keep sending SYNs when getting ACKs + + 2017-03-08: Joel Cunningham + * tcp: Initialize ssthresh to TCP_SND_BUF (bug #50476) + + 2017-03-01: Simon Goldschmidt + * httpd: LWIP_HTTPD_POST_MANUAL_WND: fixed double-free when httpd_post_data_recved + is called nested from httpd_post_receive_data() (bug #50424) + + 2017-02-28: David van Moolenbroek/Simon Goldschmidt + * tcp: fixed bug #50418: LWIP_EVENT_API: fix invalid calbacks for SYN_RCVD pcb + + 2017-02-17: Simon Goldschmidt + * dns: Improved DNS_LOCAL_HOSTLIST interface (bug #50325) + + 2017-02-16: Simon Goldschmidt + * LWIP_NETCONN_FULLDUPLEX: fixed shutdown during write (bug #50274) + + 2017-02-13: Simon Goldschmidt/Dirk Ziegelmeier + * For tiny targtes, LWIP_RAND is optional (fix compile time checks) + + 2017-02-10: Simon Goldschmidt + * tcp: Fixed bug #47485 (tcp_close() should not fail on memory error) by retrying + to send FIN from tcp_fasttmr + + 2017-02-09: Simon Goldschmidt + * sockets: Fixed bug #44032 (LWIP_NETCONN_FULLDUPLEX: select might work on + invalid/reused socket) by not allowing to reallocate a socket that has + "select_waiting != 0" + + 2017-02-09: Simon Goldschmidt + * httpd: Fixed bug #50059 (httpd LWIP_HTTPD_SUPPORT_11_KEEPALIVE vs. + LWIP_HTTPD_KILL_OLD_ON_CONNECTIONS_EXCEEDED) + + 2017-02-08: Dirk Ziegelmeier + * Rename "IPv6 mapped IPv4 addresses" to their correct name from RFC4191: + "IPv4-mapped IPv6 address" + + 2017-02-08: Luc Revardel + * mld6.c: Fix bug #50220 (mld6_leavegroup does not send ICMP6_TYPE_MLD, even + if last reporter) + + 2017-02-08: David van Moolenbroek + * ip6.c: Patch #9250: fix source substitution in ip6_output_if() + + 2017-02-08: Simon Goldschmidt + * tcp_out.c: Fixed bug #50090 (last_unsent->oversize_left can become wrong value + in tcp_write error path) + + 2017-02-02: Dirk Ziegelmeier + * Fix bug #50206: UDP Netconn bind to IP6_ADDR_ANY fails + + 2017-01-18: Dirk Ziegelmeier + * Fix zero-copy RX, see bug bug #50064. PBUF_REFs were not supported as ARP requests. + + 2017-01-15: Axel Lin, Dirk Ziegelmeier + * minor bug fixes in mqtt + + 2017-01-11: Knut Andre Tidemann + * sockets/netconn: fix broken default ICMPv6 handling of checksums + +(STABLE-2.0.1) + + ++ New features: + + 2016-12-31: Simon Goldschmidt + * tcp.h/.c: added function tcp_listen_with_backlog_and_err() to get the error + reason when listening fails (bug #49861) + + 2016-12-20: Erik Andersen + * Add MQTT client + + 2016-12-14: Jan Breuer: + * opt.h, ndc.h/.c: add support for RDNSS option (as per RFC 6106) + + 2016-12-14: David van Moolenbroek + * opt.h, nd6.c: Added LWIP_HOOK_ND6_GET_GW() + + 2016-12-09: Dirk Ziegelmeier + * ip6_frag.c: Implemented support for LWIP_NETIF_TX_SINGLE_PBUF + + 2016-12-09: Simon Goldschmidt + * dns.c: added one-shot multicast DNS queries + + 2016-11-24: Ambroz Bizjak, David van Moolenbroek + * tcp_out.c: Optimize passing contiguous nocopy buffers to tcp_write (bug #46290) + + 2016-11-16: Dirk Ziegelmeier + * sockets.c: added support for IPv6 mapped IPv4 addresses + + ++ Bugfixes: + + 2016-12-16: Thomas Mueller + * api_lib.c: fixed race condition in return value of netconn_gethostbyname() + (and thus also lwip_gethostbyname/_r() and lwip_getaddrinfo()) + + 2016-12-15: David van Moolenbroek + * opt.h, tcp: added LWIP_HOOK_TCP_ISN() to implement less predictable initial + sequence numbers (see contrib/addons/tcp_isn for an example implementation) + + 2016-12-05: Dirk Ziegelmeier + * fixed compiling with IPv4 disabled (IPv6 only case) + + 2016-11-28: Simon Goldschmidt + * api_lib.c: fixed bug #49725 (send-timeout: netconn_write() can return + ERR_OK without all bytes being written) + + 2016-11-28: Ambroz Bizjak + * tcpi_in.c: fixed bug #49717 (window size in received SYN and SYN-ACK + assumed scaled) + + 2016-11-25: Simon Goldschmidt + * dhcp.c: fixed bug #49676 (Possible endless loop when parsing dhcp options) + + 2016-11-23: Dirk Ziegelmeier + * udp.c: fixed bug #49662: multicast traffic is now only received on a UDP PCB + (and therefore on a UDP socket/netconn) when the PCB is bound to IP_ADDR_ANY + + 2016-11-16: Dirk Ziegelmeier + * *: Fixed dual-stack behaviour, IPv6 mapped IPv4 support in socket API + + 2016-11-14: Joel Cunningham + * tcp_out.c: fixed bug #49533 (start persist timer when unsent seg can't fit + in window) + + 2016-11-16: Roberto Barbieri Carrera + * autoip.c: fixed bug #49610 (sometimes AutoIP fails to reuse the same address) + + 2016-11-11: Dirk Ziegelmeier + * sockets.c: fixed bug #49578 (dropping multicast membership does not work + with LWIP_SOCKET_OFFSET) + +(STABLE-2.0.0) + + ++ New features: + + 2016-07-27: Simon Goldschmidt + * opt.h, timeouts.h/.c: added LWIP_TIMERS_CUSTOM to override the default + implementation of timeouts + + 2016-07-xx: Dirk Ziegelmeier + * Large overhaul of doxygen documentation + + 2016-04-05: Simon Goldschmidt + * timers.h/.c: prepare for overriding current timeout implementation: all + stack-internal caclic timers are avaliable in the lwip_cyclic_timers array + + 2016-03-23: Simon Goldschmidt + * tcp: call accept-callback with ERR_MEM when allocating a pcb fails on + passive open to inform the application about this error + ATTENTION: applications have to handle NULL pcb in accept callback! + + 2016-02-22: Ivan Delamer + * Initial 6LoWPAN support + + 2016-02-XX to 2016-03-XX: Dirk Ziegelmeier + * Cleanup TCPIP thread sync methods in a way that it is possibe to use them + in arbitrary code that needs things to be done in TCPIP thread. Used to + decouple netconn, netif, ppp and 6LoWPAN from LWIP core. + + 2016-02-XX: Dirk Ziegelmeier + * Implement dual-stack support in RAW, UDP and TCP. Add new IP address + type IPADDR_ANY_TYPE for this. Netconn/Socket API: Dual-stack is + automatically supported when an IPv6 netconn/socket is created. + + 2015-12-26: Martin Hentschel and Dirk Ziegelmeier + * Rewrite SNMP agent. SNMPv2c + MIB compiler. + + 2015-11-12: Dirk Ziegelmeier + * Decouple SNMP stack from lwIP core and move stack to apps/ directory. + Breaking change: Users have to call snmp_init() now! + + 2015-11-12: Dirk Ziegelmeier + * Implement possibility to declare private memory pools. This is useful to + decouple some apps from the core (SNMP stack) or make contrib app usage + simpler (httpserver_raw) + + 2015-10-09: Simon Goldschmidt + * started to move "private" header files containing implementation details to + "lwip/priv/" include directory to seperate the API from the implementation. + + 2015-10-07: Simon Goldschmidt + * added sntp client as first "supported" application layer protocol implementation + added 'apps' folder + + 2015-09-30: Dirk Ziegelmeier + * snmp_structs.h, mib_structs.c, mib2.c: snmp: fixed ugly inheritance + implementation by aggregating the "base class" (struct mib_node) in all + derived node classes to get more type-safe code + + 2015-09-23: Simon Goldschmidt + * netif.h/.c, nd6.c: task #13729: Convert netif addresses (IPv4 & IPv6) to + ip_addr_t (so they can be used without conversion/temporary storage) + + 2015-09-08: Dirk Ziegelmeier + * snmp: Separate mib2 counter/table callbacks from snmp agent. This both cleans + up the code and should allow integration of a 3rd party agent/mib2. Simple + counters are kept in MIB2_STATS, tree/table change function prototypes moved to + snmp_mib2.h. + + 2015-09-03: Simon Goldschmidt + * opt.h, dns.h/.c: DNS/IPv6: added support for AAAA records + + 2015-09-01: Simon Goldschmidt + * task #12178: hardware checksum capabilities can be configured per netif + (use NETIF_SET_CHECKSUM_CTRL() in your netif's init function) + + 2015-08-30: Simon Goldschmidt + * PBUF_REF with "custom" pbufs is now supported for RX pbufs (see pcapif in + contrib for an example, LWIP_SUPPORT_CUSTOM_PBUF is required) + + 2015-08-30: Simon Goldschmidt + * support IPv4 source based routing: define LWIP_HOOK_IP4_ROUTE_SRC to point + to a routing function + + 2015-08-05: Simon Goldschmidt + * many files: allow multicast socket options IP_MULTICAST_TTL, IP_MULTICAST_IF + and IP_MULTICAST_LOOP to be used without IGMP + + 2015-04-24: Simon Goldschmidt + * dhcp.h/c, autoip.h/.c: added functions dhcp/autoip_supplied_address() to + check for the source of address assignment (replacement for NETIF_FLAG_DHCP) + + 2015-04-10: Simon Goldschmidt + * many files: task #13480: added LWIP_IPV4 define - IPv4 can be disabled, + leaving an IPv6-only stack + + 2015-04-09: Simon Goldschmidt + * nearly all files: task #12722 (improve IPv4/v6 address handling): renamed + ip_addr_t to ip4_addr_t, renamed ipX_addr_t to ip_addr_t and added IP + version; ip_addr_t is used for all generic IP addresses for the API, + ip(4/6)_addr_t are only used internally or when initializing netifs or when + calling version-related functions + + 2015-03-24: Simon Goldschmidt + * opt.h, ip4_addr.h, ip4.c, ip6.c: loopif is not required for loopback traffic + any more but passed through any netif (ENABLE_LOOPBACK has to be enabled) + + 2015-03-23: Simon Goldschmidt + * opt.h, etharp.c: with ETHARP_TABLE_MATCH_NETIF== 1, duplicate (Auto)-IP + addresses on multiple netifs should now be working correctly (if correctly + addressed by routing, that is) + + 2015-03-23: Simon Goldschmidt + * etharp.c: Stable etharp entries that are about to expire are now refreshed + using unicast to prevent unnecessary broadcast. Only if no answer is received + after 15 seconds, broadcast is used. + + 2015-03-06: Philip Gladstone + * netif.h/.c: patch #8359 (Provide utility function to add an IPv6 address to + an interface) + + 2015-03-05: Simon Goldschmidt + * netif.c, ip4.c, dhcp.c, autoip.c: fixed bug #37068 (netif up/down handling + is unclear): correclty separated administrative status of a netif (up/down) + from 'valid address' status + ATTENTION: netif_set_up() now always has to be called, even when dhcp/autoip + is used! + + 2015-02-26: patch by TabascoEye + * netif.c, udp.h/.c: fixed bug #40753 (re-bind UDP pcbs on change of IP address) + + 2015-02-22: chrysn, Simon Goldschmidt + * *.*: Changed nearly all functions taking 'ip(X)_addr_t' pointer to take + const pointers (changed user callbacks: raw_recv_fn, udp_recv_fn; changed + port callbacks: netif_output_fn, netif_igmp_mac_filter_fn) + + 2015-02-19: Ivan Delamer + * netif.h, dhcp.c: Removed unused netif flag for DHCP. The preferred way to evaluate + if DHCP is active is through netif->dhcp field. + + 2015-02-19: Ivan Delamer + * netif.h, slipif.c, ppp.c: Removed unused netif flag for point to point connections + + 2015-02-18: Simon Goldschmidt + * api_lib.c: fixed bug #37958 "netconn API doesn't handle correctly + connections half-closed by peer" + + 2015-02-18: Simon Goldschmidt + * tcp.c: tcp_alloc() prefers killing CLOSING/LAST_ACK over active connections + (see bug #39565) + + 2015-02-16: Claudius Zingerli, Sergio Caprile + * opt.h, dhcp.h/.c: patch #8361 "Add support for NTP option in DHCP" + + 2015-02-14: Simon Goldschmidt + * opt.h, snmp*: added support for write-access community and dedicated + community for sending traps + + 2015-02-13: Simon Goldschmidt + * opt.h, memp.c: added hook LWIP_HOOK_MEMP_AVAILABLE() to get informed when + a memp pool was empty and an item is now available + + 2015-02-13: Simon Goldschmidt + * opt.h, pbuf.h/.c, etharp.c: Added the option PBUF_LINK_ENCAPSULATION_HLEN to + allocate additional header space for TX on netifs requiring additional headers + + 2015-02-12: chrysn + * timers.h/.c: introduce sys_timeouts_sleeptime (returns the time left before + the next timeout is due, for NO_SYS==1) + + 2015-02-11: Nick van Ijzendoorn + * opt.h, sockets.h/c: patch #7702 "Include ability to increase the socket number + with defined offset" + + 2015-02-11: Frederick Baksik + * opt.h, def.h, others: patch #8423 "arch/perf.h" should be made an optional item + + 2015-02-11: Simon Goldschmidt + * api_msg.c, opt.h: started to implement fullduplex sockets/netconns + (note that this is highly unstable yet!) + + 2015-01-17: Simon Goldschmidt + * api: allow enabling socket API without (public) netconn API - netconn API is + still used by sockets, but keeping it private (static) should allow better + compiler optimizations + + 2015-01-16: Simon Goldschmidt + * tcp_in.c: fixed bug #20506 "Initial congestion window is very small" again + by implementing the calculation formula from RFC3390 + + 2014-12-10: Simon Goldschmidt + * api: added option LWIP_NETCONN_SEM_PER_THREAD to use a semaphore per thread + instead of using one per netconn and per select call + + 2014-12-08: Simon Goldschmidt + * ip6.h: fixed bug #43778: IPv6 header version not set on 16-bit platform + (macro IP6H_VTCFL_SET()) + + 2014-12-08: Simon Goldschmidt + * icmp.c, ip4.c, pbuf.c, udp.c, pbuf.h: task #11472 Support PBUF_REF for RX + (IPv6 and IPv4/v6 reassembly might not work yet) + + 2014-11-06: Simon Goldschmidt + * sockets.c/.h, init.c: lwip_socket_init() is not needed any more + -> compatibility define + + 2014-09-16: Simon Goldschmidt + * dns.c, opt.h: reduced ram usage by parsing DNS responses in place + + 2014-09-16: Simon Goldschmidt + * pbuf.h/.c: added pbuf_take_at() and pbuf_put_at() + + 2014-09-15: Simon Goldschmidt + * dns.c: added source port randomization to make the DNS client more robust + (see bug #43144) + + 2013-09-02: Simon Goldschmidt + * arch.h and many other files: added optional macros PACK_STRUCT_FLD_8() and + PACK_STRUCT_FLD_S() to prevent gcc 4 from warning about struct members that + do not need packing + + 2013-08-19: Simon Goldschmidt + * netif.h: bug #42998: made NETIF_MAX_HWADDR_LEN overridable for some special + networks + + 2013-03-17: Simon Goldschmidt (patch by Ghobad Emadi) + * opt.h, etharp.c: Added LWIP_HOOK_ETHARP_GET_GW to implement IPv4 routing with + multiple gateways + + 2013-04-20: Fatih Asici + * opt.h, etharp.h/.c: patch #7993: Added support for transmitting packets + with VLAN headers via hook function LWIP_HOOK_VLAN_SET and to check them + via hook function LWIP_HOOK_VLAN_CHECK + + 2014-02-20: Simon Goldschmidt (based on patch by Artem Pisarenko) + * patch #7885: modification of api modules to support FreeRTOS-MPU + (don't pass stack-pointers to other threads) + + 2014-02-05: Simon Goldschmidt (patch by "xtian" and "alex_ab") + * patch #6537/#7858: TCP window scaling support + + 2014-01-17: Jiri Engelthaler + * icmp, icmp6, opt.h: patch #8027: Completed HW checksuming for IPv4 and + IPv6 ICMP's + + 2012-08-22: Sylvain Rochet + * New PPP stack for lwIP, developed in ppp-new branch. + Based from pppd 2.4.5, released 2009-11-17, with huge changes to match + code size and memory requirements for embedded devices, including: + - Gluing together the previous low-level PPP code in lwIP to pppd 2.4.5, which + is more or less what pppd sys-* files are, so that we get something working + using the unix port. + - Merged some patchs from lwIP Git repository which add interesting features + or fix bugs. + - Merged some patchs from Debian pppd package which add interesting features + or fix bugs. + - Ported PPP timeout handling to the lwIP timers system + - Disabled all the PPP code using filesystem access, replaced in necessary cases + to configuration variables. + - Disabled all the PPP code forking processes. + - Removed IPX support, lwIP does not support IPX. + - Ported and improved random module from the previous PPP port. + - Removed samba TDB (file-driven database) usage, because it needs a filesystem. + - MS-CHAP required a DES implementation, we added the latest PolarSSL DES + implementation which is under a BSD-ish license. + - Also switched to PolarSSL MD4,MD5,SHA1 implementations, which are meant to be + used in embedded devices with reduced memory footprint. + - Removed PPP configuration file parsing support. + - Added macro definition EAP_SUPPORT to make EAP support optional. + - Added macro definition CHAP_SUPPORT to make CHAP support optional. + - Added macro definition MSCHAP_SUPPORT to make MSCHAP support optional. + - Added macro definition PAP_SUPPORT to make PAP support optional. + - Cleared all Linux syscall calls. + - Disabled demand support using a macro, so that it can be ported later. + - Disabled ECP support using a macro, so that it can be ported later. + - Disabled CCP support using a macro, so that it can be ported later. + - Disabled CBCP support using a macro, so that it can be ported later. + - Disabled LQR support using a macro, so that it can be ported later. + - Print packet debug feature optional, through PRINTPKT_SUPPORT + - Removed POSIX signal usage. + - Fully ported PPPoS code from the previous port. + - Fully ported PPPoE code from the previous port. + - Fully ported VJ compression protocol code from the previous port. + - Removed all malloc()/free() use from PPP, replaced by stack usage or PBUF. + - Disabled PPP server support using a macro, so that it can be ported later. + - Switched all PPP debug to lwIP debug system. + - Created PPP Control Block (PPP PCB), removed PPP unit integer everywhere, + removed all global variables everywhere, did everything necessary for + the PPP stack to support more than one PPP session (pppd only support + one session per process). + - Removed the statically allocated output buffer, now using PBUF. + - Improved structure size of all PPP modules, deep analyze of code to reduce + variables size to the bare minimum. Switched all boolean type (char type in + most architecture) to compiler generated bitfields. + - Added PPP IPv6 support, glued lwIP IPv6 support to PPP. + - Now using a persistent netif interface which can then be used in lwIP + functions requiring a netif. + - Now initializing PPP in lwip_init() function. + - Reworked completely the PPP state machine, so that we don't end up in + anymore in inconsistent state, especially with PPPoE. + - Improved the way we handle PPP reconnection after disconnect, cleaning + everything required so that we start the PPP connection again from a + clean state. + - Added PPP holdoff support, allow the lwIP user to wait a little bit before + reconnecting, prevents connection flood, especially when using PPPoL2TP. + - Added PPPoL2TP LAC support (a.k.a. UDP tunnels), adding a VPN client + feature to lwIP, L2TP being a widely used tunnel protocol. + - Switched all used PPP types to lwIP types (u8t, u16t, u32t, ...) + - Added PPP API "sequential" thread-safe API, based from NETIFAPI. + + 2011-07-21: Simon Goldschmidt + * sockets.c, opt.h: (bug #30185): added LWIP_FIONREAD_LINUXMODE that makes + ioctl/FIONREAD return the size of the next pending datagram. + + 2011-05-25: Simon Goldschmidt + * again nearly the whole stack, renamed ip.c to ip4.c, ip_addr.c to ip4_addr.c, + combined ipv4/ipv6 inet_chksum.c, added ip.h, ip_addr.h: Combined IPv4 + and IPv6 code where possible, added defines to access IPv4/IPv6 in non-IP + code so that the code is more readable. + + 2011-05-17: Patch by Ivan Delamer (only checked in by Simon Goldschmidt) + * nearly the whole stack: Finally, we got decent IPv6 support, big thanks to + Ivan! (this is work in progress: we're just post release anyway :-) + + + ++ Bugfixes: + + 2016-08-23: Simon Goldschmidt + * etharp: removed ETHARP_TRUST_IP_MAC since it is insecure and we don't need + it any more after implementing unicast ARP renewal towards arp entry timeout + + 2016-07-20: Simon Goldschmidt + * memp.h/.c: fixed bug #48442 (memp stats don't work for MEMP_MEM_MALLOC) + + 2016-07-21: Simon Goldschmidt (patch by Ambroz Bizjak) + * tcp_in.c, tcp_out.c: fixed bug #48543 (TCP sent callback may prematurely + report sent data when only part of a segment is acked) and don't include + SYN/FIN in snd_buf counter + + 2016-07-19: Simon Goldschmidt + * etharp.c: fixed bug #48477 (ARP input packet might update static entry) + + 2016-07-11: Simon Goldschmidt + * tcp_in.c: fixed bug #48476 (TCP sent callback called wrongly due to picking + up old pcb->acked + + 2016-06-30: Simon Goldschmidt (original patch by Fabian Koch) + * tcp_in.c: fixed bug #48170 (Vulnerable to TCP RST spoofing) + + 2016-05-20: Dirk Ziegelmeier + * sntp.h/.c: Fix return value of sntp_getserver() call to return a pointer + + 2016-04-05: Simon Goldschmidt (patch by Philip Gladstone) + * udp.c: patch #8358: allow more combinations of listening PCB for IPv6 + + 2016-04-05: Simon Goldschmidt + * netconn/socket API: fixed bug# 43739 (Accept not reporting errors about + aborted connections): netconn_accept() returns ERR_ABRT (sockets: ECONNABORTED) + for aborted connections, ERR_CLSD (sockets: EINVAL) if the listening netconn + is closed, which better seems to follow the standard. + + 2016-03-23: Florent Matignon + * dhcp.c: fixed bug #38203: DHCP options are not recorded in all DHCP ack messages + + 2016-03-22: Simon Goldschmidt + * tcp: changed accept handling to be done internally: the application does not + have to call tcp_accepted() any more. Instead, when delaying accept (e.g. sockets + do), call tcp_backlog_delayed()/tcp_backlog_accepted() (fixes bug #46696) + + 2016-03-22: Simon Goldschmidt + * dns.c: ignore dns response parsing errors, only abort resolving for correct + responses or error responses from correct server (bug #47459) + + 2016-03-17: Simon Goldschmidt + * api_msg.c: fixed bug #47448 (netconn/socket leak if RST is received during close) + + 2016-03-17: Joel Cunningham + * api_msg.c: don't fail closing a socket/netconn when failing to allocate the + FIN segment; blocking the calling thread for a while is better than risking + leaking a netconn/socket (see bug #46701) + + 2016-03-16: Joel Cunningham + * tcp_out.c: reset rto timer on fast retransmission + + 2016-03-16: Deomid Ryabkov + * tcp_out.c: fixed bug #46384 Segment size calculation bug with MSS != TCP_MSS + + 2016-03-05: Simon Goldschmidt + * err.h/.c, sockets.c: ERR_IF is not necessarily a fatal error + + 2015-11-19: fix by Kerem Hadimli + * sockets.c: fixed bug #46471: lwip_accept() leaks socket descriptors if new + netconn was already closed because of peer behavior + + 2015-11-12: fix by Valery Ushakov + * tcp_in.c: fixed bug #46365 tcp_accept_null() should call tcp_abort() + + 2015-10-02: Dirk Ziegelmeier/Simon Goldschmidt + * snmp: cleaned up snmp structs API (fixed race conditions from bug #46089, + reduce ram/rom usage of tables): incompatible change for private MIBs + + 2015-09-30: Simon Goldschmidt + * ip4_addr.c: fixed bug #46072: ip4addr_aton() does not check the number range + of all address parts + + 2015-08-28: Simon Goldschmidt + * tcp.c, tcp_in.c: fixed bug #44023: TCP ssthresh value is unclear: ssthresh + is set to the full send window for active open, too, and is updated once + after SYN to ensure the correct send window is used + + 2015-08-28: Simon Goldschmidt + * tcp: fixed bug #45559: Window scaling casts u32_t to u16_t without checks + + 2015-08-26: Simon Goldschmidt + * ip6_frag.h/.c: fixed bug bug #41009: IPv6 reassembly broken on 64-bit platforms: + define IPV6_FRAG_COPYHEADER==1 on these platforms to copy the IPv6 header + instead of referencing it, which gives more room for struct ip6_reass_helper + + 2015-08-25: Simon Goldschmidt + * sockets.c: fixed bug #45827: recvfrom: TCP window is updated with MSG_PEEK + + 2015-08-20: Manoj Kumar + * snmp_msg.h, msg_in.c: fixed bug #43790: Sending octet string of Length >255 + from SNMP agent + + 2015-08-19: Jens Nielsen + * icmp.c, ip4.c, tcp_in.c, udp.c, raw.c: fixed bug #45120: Broadcast & multiple + interfaces handling + + 2015-08-19: Simon Goldschmidt (patch by "Sandra") + * dns.c: fixed bug #45004: dns response without answer might be discarded + + 2015-08-18: Chrysn + * timers.c: patch #8704 fix sys_timeouts_sleeptime function + + 2015-07-01: Erik Ekman + * puf.c: fixed bug #45454 (pbuf_take_at() skips write and returns OK if offset + is at start of pbuf in chain) + + 2015-05-19: Simon Goldschmidt + * dhcp.h/.c: fixed bugs #45140 and #45141 (dhcp was not stopped correctly after + fixing bug #38204) + + 2015-03-21: Simon Goldschmidt (patch by Homyak) + * tcp_in.c: fixed bug #44766 (LWIP_WND_SCALE: tcphdr->wnd was not scaled in + two places) + + 2015-03-21: Simon Goldschmidt + * tcp_impl.h, tcp.c, tcp_in.c: fixed bug #41318 (Bad memory ref in tcp_input() + after tcp_close()) + + 2015-03-21: Simon Goldschmidt + * tcp_in.c: fixed bug #38468 (tcp_sent() not called on half-open connection for + data ACKed with the same ack as FIN) + + 2015-03-21: Simon Goldschmidt (patch by Christoffer Lind) + * dhcp.h/.c: fixed bug #38204 (DHCP lease time not handled correctly) + + 2015-03-20: Simon Goldschmidt + * dhcp.c: fixed bug #38714 (Missing option and client address in DHCPRELEASE message) + + 2015-03-19: Simon Goldschmidt + * api.h, tcpip.h, api_lib.c, api_msg.c: fixed race conditions in assigning + netconn->last_err (fixed bugs #38121 and #37676) + + 2015-03-09: Simon Goldschmidt + * ip4.c: fixed the IPv4 part of bug #43904 (ip_route() must detect linkup status) + + 2015-03-04: Simon Goldschmidt + * nd6.c: fixed bug #43784 (a host should send at least one Router Solicitation) + + 2015-03-04: Valery Ushakov + * ip6.c: fixed bug #41094 (Byte-order bug in IPv6 fragmentation header test) + + 2015-03-04: Zach Smith + * nd6.c: fixed bug #38153 (nd6_input() byte order issues) + + 2015-02-26: Simon Goldschmidt + * netif.c, tcp.h/.c: fixed bug #44378 (TCP connections are not aborted on netif + remove) + + 2015-02-25: Simon Goldschmidt + * ip4.c, etharp.c: fixed bug #40177 (System hangs when dealing with corrupted + packets), implemented task #12357 (Ensure that malicious packets don't + assert-fail): improved some pbuf_header calls to not assert-fail. + + 2015-02-25: patch by Joel Cunningham + * udp.h/.c, sockets.c: fixed bug #43028 (IP_MULTICAST_TTL affects unicast + datagrams) + + 2015-02-25: patch by Greg Renda + * ip4_frag.c: fixed bug #38210 (ip reassembly while remove oldest datagram) + + 2015-02-25: Simon Goldschmidt + * sockets.c: fixed bug #38165 (socket with mulicast): ensure igmp membership + are dropped when socket (not netconn!) is closed. + + 2015-02-25: Simon Goldschmidt + * ip4.h/.c, udp.c: fixed bug #38061 (wrong multicast routing in IPv4) by + adding an optional default netif for multicast routing + + 2015-02-25: Simon Goldschmidt + * netconn API: fixed that netconn_connect still used message passing for + LWIP_TCPIP_CORE_LOCKING==1 + + 2015-02-22: patch by Jens Nielsen + * icmp.c: fixed bug #38803 (Source address in broadcast ping reply) + + 2015-02-22: Simon Goldschmidt + * udp.h, sockets.c: added proper accessor functions for pcb->multicast_ip + (previously used by get/setsockopt only) + + 2015-02-18: Simon Goldschmidt + * sockets.c: Fixed select not reporting received FIN as 'readable' in certain + rare cases (bug #43779: select(), close(), and TCP retransmission error) + + 2015-02-17: Simon Goldschmidt + * err.h, sockets.c, api_msg.c: fixed bug #38853 "connect() use a wrong errno": + return ERR_ALREADY/EALRADY during connect, ERR_ISCONN/EISCONN when already + connected + + 2015-02-17: Simon Goldschmidt + * tcp_impl.h, tcp_out.c, tcp.c, api_msg.c: fixed bug #37614 "Errors from + ipX_output are not processed". Now tcp_output(_segment) checks for the return + value of ipX_output and does not try to send more on error. A netif driver + can call tcp_txnow() (from tcpip_thread!) to try to send again if TX buffers + are available again. + + 2015-02-14: patches by Freddie Chopin + * snmp*: made community writable, fixed some const pointers + + 2015-02-13: Simon Goldschmidt + * msg_in.c: fixed bug #22070 "MIB_OBJECT_WRITE_ONLY not implemented in SNMP" + + 2015-02-12: Simon Goldschmidt + * ip.h, ip4.c, ip6.c: fixed bug #36403 "ip4_input() and ip6_input() always pass + inp to higher layers": now the accepting netif is passed up, but the input + netif is available through ip_current_input_netif() if required. + + 2015-02-11: patch by hichard + * tcpip.c: fixed bug #43094 "The function tcpip_input() forget to handle IPv6" + + 2015-02-10: Simon Goldschmidt + * netconn API: fixed that netconn_close/netconn_delete still used message passing + for LWIP_TCPIP_CORE_LOCKING==1 + + 2015-02-10: Simon Goldschmidt + * netconn/socket api: fixed bug #44225 "closing TCP socket should time out + eventually", implemented task #6930 "Implement SO_LINGER": closing TCP sockets + times out after 20 seconds or after the configured SND_TIMEOUT or depending + on the linger settings. + + 2015-01-27: Simon Goldschmidt + * api_msg.c: fixed that SHUT_RD followed by SHUT_WR was different to SHUT_RDWR, + fixed return value of lwip_netconn_do_close on unconnected netconns + + 2015-01-17: Simon Goldschmidt + * sockets.c: fixed bug #43361 select() crashes with stale FDs + + 2015-01-17: Simon Goldschmidt + * sockets.c/.h, memp_std.h: fixed bug #40788 "lwip_setsockopt_internal() crashes" + by rewriting set/getsockopt functions to combine checks with the actual code + and add more NULL checks; this also fixes that CORE_LOCKING used message + passing for set/getsockopt. + + 2014-12-19: Simon Goldschmidt + * opt.h, dhcp.h/.c: prevent dhcp from starting when netif link is down (only + when LWIP_DHCP_CHECK_LINK_UP==1, which is disabled by default for + compatibility reasons) + + 2014-12-17: Simon Goldschmidt + * tcp_out.c: fixed bug #43840 Checksum error for TCP_CHECKSUM_ON_COPY==1 for + no-copy data with odd length + + 2014-12-10: Simon Goldschmidt + * sockets.c, tcp.c, others: fixed bug #43797 set/getsockopt: SO_SNDTIMEO/SO_RCVTIMEO + take int as option but should take timeval (LWIP_SO_SNDRCVTIMEO_STANDARD==0 can + be used to revert to the old 'winsock' style behaviour) + Fixed implementation of SO_ACCEPTCONN to just look at the pcb state + + 2014-12-09: Simon Goldschmidt + * ip4.c: fixed bug #43596 IGMP queries from 0.0.0.0 are discarded + + 2014-10-21: Simon Goldschmidt (patch by Joel Cunningham and Albert Huitsing) + * sockts.c: fixed bugs #41495 Possible threading issue in select() and #43278 + event_callback() handle context switch when calling sys_sem_signal() + + 2014-10-21: Simon Goldschmidt + * api_msg.c: fixed bug #38219 Assert on TCP netconn_write with sndtimeout set + + 2014-09-16: Kevin Cernekee + * dns.c: patch #8480 Fix handling of dns_seqno wraparound + + 2014-09-16: Simon Goldschmidt + * tcp_out.c: fixed bug #43192 tcp_enqueue_flags() should not check TCP_SND_QUEUELEN + when sending FIN + + 2014-09-03: Simon Goldschmidt + * msg_in.c: fixed bug #39355 SNMP Memory Leak in case of error + + 2014-09-02: Simon Goldschmidt + * err.h/.c, sockets.c, api_msg.c: fixed bug #43110 call getpeername() before + listen() will cause a error + + 2014-09-02: Simon Goldschmidt + * sockets.c: fixed bug #42117 lwip_fcntl does not set errno + + 2014-09-02: Simon Goldschmidt + * tcp.c: fixed bug #42299 tcp_abort() leaves freed pcb on tcp_bound_pcbs list + + 2014-08-20: Simon Goldschmidt + * dns.c: fixed bug #42987 lwIP is vulnerable to DNS cache poisoning due to + non-randomized TXIDs + + 2014-06-03: Simon Goldschmidt + * tcp_impl.h, tcp_in.c: fixed bug #37969 SYN packet dropped as short packet in + tcp_input function + + 2014-05-20: Simon Goldschmidt + * tcp_out.c: fixed bug #37184 tcp_write problem for pcbs in the SYN_SENT state + + 2014-05-19: Simon Goldschmidt + * *.h: Fixed bug #35874 reserved identifier violation (removed leading underscores + from header include guards) + + 2014-04-08: Simon Goldschmidt + * tcp.c: Fixed bug #36167 tcp server crash when client closes (maximum window) + + 2014-04-06: Simon Goldschmidt + * tcp_in.c: Fixed bug #36210 lwIP does not elicit an empty ACK when received + unacceptable ACK + + 2014-04-06: Simon Goldschmidt + * dhcp.c, ip4.c/.h, ip6.c/.h, udp.c/.h, ip.h: Fixed bug #41787 DHCP Discovery + is invalid when an IP is set to thet netif. + + 2014-03-14: Simon Goldschmidt + * tcp_out.c: Fixed bug #36153 TCP Cheksum error if LWIP_CHECKSUM_ON_COPY=1 + + 2014-03-11: Simon Goldschmidt (patch by Mason) + * opt.h, sockets.c: fixed bug #35928 BSD sockets functions must set errno for + POSIX-compliance + + 2014-02-27: Simon Goldschmidt + * dhcp.c: fixed bug #40303 DHCP xid renewed when sending a DHCPREQUEST + + 2014-02-27: Simon Goldschmidt + * raw.c: fixed bug #41680 raw socket can not receive IPv6 packet when + IP_SOF_BROADCAST_RECV==1 + + 2014-02-27: Simon Goldschmidt + * api_msg.c, sockets.c: fixed bug #38404 getpeeraddr returns success on + unconnected/listening TCP sockets + + 2014-02-27: Simon Goldschmidt + * sockets.c: fixed bug #41729 Some socket functions return Exyz instead of -1 + + 2014-02-25: Simon Goldschmidt + * ip4.c: fixed bug #39514 ip_route() may return an IPv6-only interface + + 2014-02-25: Simon Goldschmidt, patch by Fatih Asici + * pbuf.c: fixed bug #39356 Wrong increment in pbuf_memfind() + + 2014-02-25: Simon Goldschmidt + * netif.c/.h, udp.c: fixed bug #39225 udp.c uses netif_matches_ip6_addr() incorrectly; + renamed function netif_matches_ip6_addr() to netif_get_ip6_addr_match() + + 2014-02-25: Simon Goldschmidt + * igmp.c: fixed bug #39145 IGMP membership report for 224.0.0.1 + + 2014-02-22: Simon Goldschmidt (patch by Amir Shalem) + * etharp.c, opt.h: fixed bug #34681 Limit ARP queue length by ARP_QUEUE_LEN (=3) + + 2014-02-22: Simon Goldschmidt (patch by Amir Shalem) + * etharp.h/.c: fixed bug #34682 Limit ARP request flood for unresolved entry + + 2014-02-20: Simon Goldschmidt + * tcp_out.c: fixed bug #39683 Assertion "seg->tcphdr not aligned" failed with + MEM_ALIGNMENT = 8 + + 2014-02-20: Simon Goldschmidt + * sockets.c: fixed bug #39882 No function shall set errno to 0 + + 2014-02-20: Simon Goldschmidt + * mib_structs.c: fixed bug #40050 SNMP problem with MIB arrays > 255 + + 2014-02-20: Simon Goldschmidt + * api.h, sockets.c: fixed bug #41499 netconn::recv_avail can overflow + + 2014-01-08: Stathis Voukelatos + * memp_std.h: patch #7928 Fixed size calculation in MALLOC memory pool + creation macro + + 2014-01-18: Brian Fahs + * tcp_out.c: patch #8237: tcp_rexmit_rto fails to update pcb->unsent_oversize + when necessary + + 2014-01-17: Grant Erickson, Jay Logue, Simon Goldschmidt + * ipv6.c, netif.c: patch #7913 Enable Support for IPv6 Loopback + + 2014-01-16: Stathis Voukelatos + * netif.c: patch #7902 Fixed netif_poll() operation when LWIP_LOOPBACK_MAX_PBUFS > 0 + + 2014-01-14: "Freddie Chopin" + * snmp.h, mib2.c: fixed constness and spelling of sysdescr + + 2014-01-14: Simon Goldschmidt (patch by Thomas Faber) + * tcpip.c: patch #8241: Fix implicit declaration of ip_input with + LWIP_TCPIP_CORE_LOCKING_INPUT disabled + + 2014-01-14: chrysn + * timers.c: patch #8244 make timeouts usable reliably from outside of the + timeout routine + + 2014-01-10: Simon Goldschmidt + * ip_frag.c, ip6_frag.c: fixed bug #41041 Potential use-after-free in IPv6 reassembly + + 2014-01-10: Simon Goldschmidt + * memp.c: fixed bug #41188 Alignment error in memp_init() when MEMP_SEPARATE_POOLS==1 + + 2014-01-10: Simon Goldschmidt + * tcp.c: fixed bug #39898 tcp_fasttmr() possible lock due to infinte queue process loop + + 2013-06-29: Simon Goldschmidt + * inet.h, sockets.h: partially fixed bug #37585: IPv6 compatibility (in socket structs) + + 2013-06-29: Simon Goldschmidt + * inet6.h: bug #37585/task #12600: fixed struct in6_addr.s6_addr to conform to spec + + 2013-04-24: patch by Liam <morepork> + * api_msg.c: patch #8008 Fix a potential null pointer dereference in assert + + 2013-04-24: Simon Goldschmidt + * igmp.c: fixed possible division by zero + + 2013-04-24: Simon Goldschmidt + * ip6.h, some ipv6 C files: fixed bug #38526 Coverity: Recursive Header Inclusion in ip6.h + + 2013-04-24: Simon Goldschmidt (patch by Emil Ljungdahl): + * netif.c: fixed bug #38586 netif_loop_output() "deadlocks" + + 2013-01-15: Simon Goldschmidt + * ip4.c: fixed bug #37665 ip_canforward operates on address in wrong byte order + + 2013-01-15: Simon Goldschmidt + * pbuf.h: fixed bug #38097 pbuf_free_ooseq() warning + + 2013-01-14: Simon Goldschmidt + * dns.c: fixed bug #37705 Possible memory corruption in DNS query + + 2013-01-11: Simon Goldschmidt + * raw.c: fixed bug #38066 Raw pcbs can alter packet without eating it + + 2012-08-22: Simon Goldschmidt + * memp.c: fixed bug #37166: memp_sanity check loops itself + + 2012-08-13: Simon Goldschmidt + * dhcp.c: fixed bug #36645: Calling dhcp_release before dhcp_start + dereferences NULL + + 2012-08-13: Simon Goldschmidt + * msg_out.c: fixed bug #36840 snmp_send_trap() NULL de-reference if traps + configured but no interfaces available + + 2012-08-13: Simon Goldschmidt + * dns.c: fixed bug #36899 DNS TTL 0 is cached for a long time + + 2012-05-11: Simon Goldschmidt (patch by Marty) + * memp.c: fixed bug #36412: memp.c does not compile when + MEMP_OVERFLOW_CHECK > zero and MEMP_SEPARATE_POOLS == 1 + + 2012-05-03: Simon Goldschmidt (patch by Sylvain Rochet) + * ppp.c: fixed bug #36283 (PPP struct used on header size computation and + not packed) + + 2012-05-03: Simon Goldschmidt (patch by David Empson) + * ppp.c: fixed bug #36388 (PPP: checksum-only in last pbuf leads to pbuf with + zero length) + + 2012-03-25: Simon Goldschmidt + * api_msg.c: Fixed bug #35817: do_connect() invalidly signals op_completed + for UDP/RAW with LWIP_TCPIP_CORE_LOCKING==1 + + 2012-03-25: Simon Goldschmidt + * api_msg.h, api_lib.c, api_msg.c, netifapi.c: fixed bug #35931: Name space + pollution in api_msg.c and netifapi.c + + 2011-08-24: Simon Goldschmidt + * inet6.h: fixed bug #34124 struct in6_addr does not conform to the standard + + + +(STABLE-1.4.1) + + ++ New features: + + 2012-03-25: Simon Goldschmidt (idea by Mason) + * posix/*: added posix-compatibility include files posix/netdb.h and posix/sys/socket.h + which are a simple wrapper to the correct lwIP include files. + + 2012-01-16: Simon Goldschmidt + * opt.h, icmp.c: Added option CHECKSUM_GEN_ICMP + + 2011-12-17: Simon Goldschmidt + * ip.h: implemented API functions to access so_options of IP pcbs (UDP, TCP, RAW) + (fixes bug #35061) + + 2011-09-27: Simon Goldschmidt + * opt.h, tcp.c, tcp_in.c: Implemented limiting data on ooseq queue (task #9989) + (define TCP_OOSEQ_MAX_BYTES / TCP_OOSEQ_MAX_PBUFS in lwipopts.h) + + 2011-09-21: Simon Goldschmidt + * opt.h, api.h, api_lib.c, api_msg.h/.c, sockets.c: Implemented timeout on + send (TCP only, bug #33820) + + 2011-09-21: Simon Goldschmidt + * init.c: Converted runtime-sanity-checks into compile-time checks that can + be disabled (since runtime checks can often not be seen on embedded targets) + + 2011-09-11: Simon Goldschmidt + * ppp.h, ppp_impl.h: splitted ppp.h to an internal and external header file + to get a clear separation of which functions an application or port may use + (task #11281) + + 2011-09-11: Simon Goldschmidt + * opt.h, tcp_impl.h, tcp.c, udp.h/.c: Added a config option to randomize + initial local TCP/UDP ports (so that different port ranges are used after + a reboot; bug #33818; this one added tcp_init/udp_init functions again) + + 2011-09-03: Simon Goldschmidt + * dhcp.c: DHCP uses LWIP_RAND() for xid's (bug #30302) + + 2011-08-24: Simon Goldschmidt + * opt.h, netif.h/.c: added netif remove callback (bug #32397) + + 2011-07-26: Simon Goldschmidt + * etharp.c: ETHARP_SUPPORT_VLAN: add support for an external VLAN filter + function instead of only checking for one VLAN (define ETHARP_VLAN_CHECK_FN) + + 2011-07-21: Simon Goldschmidt (patch by hanhui) + * ip4.c, etharp.c, pbuf.h: bug #33634 ip_forward() have a faulty behaviour: + Added pbuf flags to mark incoming packets as link-layer broadcast/multicast. + Also added code to allow ip_forward() to forward non-broadcast packets to + the input netif (set IP_FORWARD_ALLOW_TX_ON_RX_NETIF==1). + + 2011-06-26: Simon Goldschmidt (patch by Cameron Gutman) + * tcp.c, tcp_out.c: bug #33604: added some more asserts to check that + pcb->state != LISTEN + + 2011-05-14: Simon Goldschmidt (patch by Stéphane Lesage) + * tcpip.c/.h: patch #7449 allow tcpip callback from interrupt with static + memory message + + + ++ Bugfixes: + + 2012-09-26: Simon Goldschmidt + * api_msg.c: fixed bug #37405 'err_tcp()' uses already freed 'netconn' object + + 2012-09-26: patch by Henrik Persson + * dhcp.c: patch #7843 Fix corner case with dhcp timeouts + + 2012-09-26: patch by Henrik Persson + * dhcp.c: patch #7840 Segfault in dhcp_parse_reply if no end marker in dhcp packet + + 2012-08-22: Simon Goldschmidt + * memp.c: fixed bug #37166: memp_sanity check loops itself + + 2012-05-08: Simon Goldschmidt + * tcp_out.c: fixed bug: #36380 unsent_oversize mismatch in 1.4.1RC1 (this was + a debug-check issue only) + + 2012-03-27: Simon Goldschmidt + * vj.c: fixed bug #35756 header length calculation problem in ppp/vj.c + + 2012-03-27: Simon Goldschmidt (patch by Mason) + * tcp_out.c: fixed bug #35945: SYN packet should provide the recv MSS not the + send MSS + + 2012-03-22: Simon Goldschmidt + * ip4.c: fixed bug #35927: missing refragmentaion in ip_forward + + 2012-03-20: Simon Goldschmidt (patch by Mason) + * netdb.c: fixed bug #35907: lwip_gethostbyname_r returns an invalid h_addr_list + + 2012-03-12: Simon Goldschmidt (patch by Bostjan Meglic) + * ppp.c: fixed bug #35809: PPP GetMask(): Compiler warning on big endian, + possible bug on little endian system + + 2012-02-23: Simon Goldschmidt + * etharp.c: fixed bug #35595: Impossible to send broadcast without a gateway + (introduced when fixing bug# 33551) + + 2012-02-16: Simon Goldschmidt + * ppp.c: fixed pbuf leak when PPP session is aborted through pppSigHUP() + (bug #35541: PPP Memory Leak) + + 2012-02-16: Simon Goldschmidt + * etharp.c: fixed bug #35531: Impossible to send multicast without a gateway + (introduced when fixing bug# 33551) + + 2012-02-16: Simon Goldschmidt (patch by Stéphane Lesage) + * msg_in.c, msg_out.c: fixed bug #35536 SNMP: error too big response is malformed + + 2012-02-15: Simon Goldschmidt + * init.c: fixed bug #35537: MEMP_NUM_* sanity checks should be disabled with + MEMP_MEM_MALLOC==1 + + 2012-02-12: Simon Goldschmidt + * tcp.h, tcp_in.c, tcp_out.c: partly fixed bug #25882: TCP hangs on + MSS > pcb->snd_wnd (by not creating segments bigger than half the window) + + 2012-02-11: Simon Goldschmidt + * tcp.c: fixed bug #35435: No pcb state check before adding it to time-wait + queue while closing + + 2012-01-22: Simon Goldschmidt + * tcp.c, tcp_in.c: fixed bug #35305: pcb may be freed too early on shutdown(WR) + + 2012-01-21: Simon Goldschmidt + * tcp.c: fixed bug #34636: FIN_WAIT_2 - Incorrect shutdown of TCP pcb + + 2012-01-20: Simon Goldschmidt + * dhcp.c: fixed bug #35151: DHCP asserts on incoming option lengths + + 2012-01-20: Simon Goldschmidt + * pbuf.c: fixed bug #35291: NULL pointer in pbuf_copy + + 2011-11-25: Simon Goldschmidt + * tcp.h/.c, tcp_impl.h, tcp_in.c: fixed bug #31177: tcp timers can corrupt + tcp_active_pcbs in some cases + + 2011-11-23: Simon Goldschmidt + * sys.c: fixed bug #34884: sys_msleep() body needs to be surrounded with + '#ifndef sys_msleep' + + 2011-11-22: Simon Goldschmidt + * netif.c, etharp.h/.c: fixed bug #34684: Clear the arp table cache when + netif is brought down + + 2011-10-28: Simon Goldschmidt + * tcp_in.c: fixed bug #34638: Dead code in tcp_receive - pcb->dupacks + + 2011-10-23: Simon Goldschmidt + * mem.c: fixed bug #34429: possible memory corruption with + LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT set to 1 + + 2011-10-18: Simon Goldschmidt + * arch.h, netdb.c: fixed bug #34592: lwip_gethostbyname_r uses nonstandard + error value + + 2011-10-18: Simon Goldschmidt + * opt.h: fixed default values of TCP_SNDLOWAT and TCP_SNDQUEUELOWAT for small + windows (bug #34176 select after non-blocking send times out) + + 2011-10-18: Simon Goldschmidt + * tcp_impl.h, tcp_out.c: fixed bug #34587: TCP_BUILD_MSS_OPTION doesn't + consider netif->mtu, causes slow network + + 2011-10-18: Simon Goldschmidt + * sockets.c: fixed bug #34581 missing parentheses in udplite sockets code + + 2011-10-18: Simon Goldschmidt + * sockets.h: fixed bug #34580 fcntl() is missing in LWIP_COMPAT_SOCKETS + + 2011-10-17: Simon Goldschmidt + * api_msg.c: fixed bug #34569: shutdown(SHUT_WR) crashes netconn/socket api + + 2011-10-13: Simon Goldschmidt + * tcp_in.c, tcp_out.c: fixed bug #34517 (persist timer is started although no + zero window is received) by starting the persist timer when a zero window is + received, not when we have more data queued for sending than fits into the + window + + 2011-10-13: Simon Goldschmidt + * def.h, timers.c: fixed bug #34541: LWIP_U32_DIFF is unnecessarily complex + + 2011-10-13: Simon Goldschmidt + * sockets.c, api_lib.c: fixed bug #34540: compiler error when CORE_LOCKING is + used and not all protocols are enabled + + 2011-10-12: Simon Goldschmidt + * pbuf.c: fixed bug #34534: Error in sending fragmented IP if MEM_ALIGNMENT > 4 + + 2011-10-09: Simon Goldschmidt + * tcp_out.c: fixed bug #34426: tcp_zero_window_probe() transmits incorrect + byte value when pcb->unacked != NULL + + 2011-10-09: Simon Goldschmidt + * ip4.c: fixed bug #34447 LWIP_IP_ACCEPT_UDP_PORT(dst_port) wrong + + 2011-09-27: Simon Goldschmidt + * tcp_in.c, tcp_out.c: Reset pcb->unsent_oversize in 2 more places... + + 2011-09-27: Simon Goldschmidt + * tcp_in.c: fixed bug #28288: Data after FIN in oos queue + + 2011-09-27: Simon Goldschmidt + * dhcp.c: fixed bug #34406 dhcp_option_hostname() can overflow the pbuf + + 2011-09-24: Simon Goldschmidt + * mem.h: fixed bug #34377 MEM_SIZE_F is not defined if MEM_LIBC_MALLOC==1 + + 2011-09-23: Simon Goldschmidt + * pbuf.h, tcp.c, tcp_in.c: fixed bug #33871: rejecting TCP_EVENT_RECV() for + the last packet including FIN can lose data + + 2011-09-22: Simon Goldschmidt + * tcp_impl.h: fixed bug #34355: nagle does not take snd_buf/snd_queuelen into + account + + 2011-09-21: Simon Goldschmidt + * opt.h: fixed default value of TCP_SND_BUF to not violate the sanity checks + in init.c + + 2011-09-20: Simon Goldschmidt + * timers.c: fixed bug #34337 (possible NULL pointer in sys_check_timeouts) + + 2011-09-11: Simon Goldschmidt + * tcp_out.c: use pcb->mss instead of TCP_MSS for preallocate mss-sized pbufs + (bug #34019) + + 2011-09-09: Simon Goldschmidt + * udp.c: fixed bug #34072: UDP broadcast is received from wrong UDP pcb if + udp port matches + + 2011-09-03: Simon Goldschmidt + * tcp_in.c: fixed bug #33952 PUSH flag in incoming packet is lost when packet + is aggregated and sent to application + + 2011-09-01: Simon Goldschmidt + * opt.h: fixed bug #31809 LWIP_EVENT_API in opts.h is inconsistent compared + to other options + + 2011-09-01: Simon Goldschmidt + * tcp_in.c: fixed bug #34111 RST for ACK to listening pcb has wrong seqno + + 2011-08-24: Simon Goldschmidt + * api_msg.c, sockets.c: fixed bug #33956 Wrong error returned when calling + accept() on UDP connections + + 2011-08-24: Simon Goldschmidt + * sockets.h: fixed bug #34057 socklen_t should be a typedef + + 2011-08-24: Simon Goldschmidt + * pbuf.c: fixed bug #34112 Odd check in pbuf_alloced_custom (typo) + + 2011-08-24: Simon Goldschmidt + * dhcp.c: fixed bug #34122 dhcp: hostname can overflow + + 2011-08-24: Simon Goldschmidt + * netif.c: fixed bug #34121 netif_add/netif_set_ipaddr fail on NULL ipaddr + + 2011-08-22: Simon Goldschmidt + * tcp_out.c: fixed bug #33962 TF_FIN not always set after FIN is sent. (This + merely prevents nagle from not transmitting fast after closing.) + + 2011-07-22: Simon Goldschmidt + * api_lib.c, api_msg.c, sockets.c, api.h: fixed bug #31084 (socket API returns + always EMSGSIZE on non-blocking sockets if data size > send buffers) -> now + lwip_send() sends as much as possible for non-blocking sockets + + 2011-07-22: Simon Goldschmidt + * pbuf.c/.h, timers.c: freeing ooseq pbufs when the pbuf pool is empty implemented + for NO_SYS==1: when not using sys_check_timeouts(), call PBUF_CHECK_FREE_OOSEQ() + at regular intervals from main level. + + 2011-07-21: Simon Goldschmidt + * etharp.c: fixed bug #33551 (ARP entries may time out although in use) by + sending an ARP request when an ARP entry is used in the last minute before + it would time out. + + 2011-07-04: Simon Goldschmidt + * sys_arch.txt: Fixed documentation after changing sys arch prototypes for 1.4.0. + + 2011-06-26: Simon Goldschmidt + * tcp.c: fixed bug #31723 (tcp_kill_prio() kills pcbs with the same prio) by + updating its documentation only. + + 2011-06-26: Simon Goldschmidt + * mem.c: fixed bug #33545: With MEM_USE_POOLS==1, mem_malloc can return an + unaligned pointer. + + 2011-06-26: Simon Goldschmidt + * mem.c: fixed bug #33544 "warning in mem.c in lwip 1.4.0 with NO_SYS=1" + + 2011-05-25: Simon Goldschmidt + * tcp.c: fixed bug #33398 (pointless conversion when checking TCP port range) + + + +(STABLE-1.4.0) + + ++ New features: + + 2011-03-27: Simon Goldschmidt + * tcp_impl.h, tcp_in.c, tcp_out.c: Removed 'dataptr' from 'struct tcp_seg' and + calculate it in tcp_zero_window_probe (the only place where it was used). + + 2010-11-21: Simon Goldschmidt + * dhcp.c/.h: Added a function to deallocate the struct dhcp from a netif + (fixes bug #31525). + + 2010-07-12: Simon Goldschmidt (patch by Stephane Lesage) + * ip.c, udp.c/.h, pbuf.h, sockets.c: task #10495: Added support for + IP_MULTICAST_LOOP at socket- and raw-API level. + + 2010-06-16: Simon Goldschmidt + * ip.c: Added an optional define (LWIP_IP_ACCEPT_UDP_PORT) that can allow + link-layer-addressed UDP traffic to be received while a netif is down (just + like DHCP during configuration) + + 2010-05-22: Simon Goldschmidt + * many many files: bug #27352: removed packing from ip_addr_t, the packed + version is now only used in protocol headers. Added global storage for + current src/dest IP address while in input functions. + + 2010-05-16: Simon Goldschmidt + * def.h: task #10391: Add preprocessor-macros for compile-time htonl + calculation (and use them throughout the stack where applicable) + + 2010-05-16: Simon Goldschmidt + * opt.h, memp_std.h, memp.c, ppp_oe.h/.c: PPPoE now uses its own MEMP pool + instead of the heap (moved struct pppoe_softc from ppp_oe.c to ppp_oe.h) + + 2010-05-16: Simon Goldschmidt + * opt.h, memp_std.h, dns.h/.c: DNS_LOCAL_HOSTLIST_IS_DYNAMIC uses its own + MEMP pool instead of the heap + + 2010-05-13: Simon Goldschmidt + * tcp.c, udp.c: task #6995: Implement SO_REUSEADDR (correctly), added + new option SO_REUSE_RXTOALL to pass received UDP broadcast/multicast + packets to more than one pcb. + + 2010-05-02: Simon Goldschmidt + * netbuf.h/.c, sockets.c, api_msg.c: use checksum-on-copy for sending + UDP data for LWIP_NETIF_TX_SINGLE_PBUF==1 + + 2010-04-30: Simon Goldschmidt + * udp.h/.c, pbuf.h/.c: task #6849: added udp_send(_to/_if) functions that + take a precalculated checksum, added pbuf_fill_chksum() to copy data + into a pbuf and at the same time calculating the checksum for that data + + 2010-04-29: Simon Goldschmidt + * ip_addr.h, etharp.h/.c, autoip.c: Create overridable macros for copying + 2-byte-aligned IP addresses and MAC addresses + + 2010-04-28: Patch by Bill Auerbach + * ip.c: Inline generating IP checksum to save a function call + + 2010-04-14: Simon Goldschmidt + * tcpip.h/.c, timers.c: Added an overridable define to get informed when the + tcpip_thread processes messages or timeouts to implement a watchdog. + + 2010-03-28: Simon Goldschmidt + * ip_frag.c: create a new (contiguous) PBUF_RAM for every outgoing + fragment if LWIP_NETIF_TX_SINGLE_PBUF==1 + + 2010-03-27: Simon Goldschmidt + * etharp.c: Speedup TX by moving code from find_entry to etharp_output/ + etharp_query to prevent unnecessary function calls (inspired by + patch #7135). + + 2010-03-20: Simon Goldschmidt + * opt.h, tcpip.c/.h: Added an option to disable tcpip_(un)timeout code + since the linker cannot do this automatically to save space. + + 2010-03-20: Simon Goldschmidt + * opt.h, etharp.c/.h: Added support for static ARP table entries + + 2010-03-14: Simon Goldschmidt + * tcp_impl.h, tcp_out.c, inet_chksum.h/.c: task #6849: Calculate checksum + when creating TCP segments, not when (re-)transmitting them. + + 2010-03-07: Simon Goldschmidt + * sockets.c: bug #28775 (select/event_callback: only check select_cb_list + on change) plus use SYS_LIGHTWEIGHT_PROT to protect the select code. + This should speed up receiving data on sockets as the select code in + event_callback is only executed when select is waiting. + + 2010-03-06: Simon Goldschmidt + * tcp_out.c: task #7013 (Create option to have all packets delivered to + netif->output in one piece): Always copy to try to create single pbufs + in tcp_write. + + 2010-03-06: Simon Goldschmidt + * api.h, api_lib.c, sockets.c: task #10167 (sockets: speed up TCP recv + by not allocating a netbuf): added function netconn_recv_tcp_pbuf() + for tcp netconns to receive pbufs, not netbufs; use that function + for tcp sockets. + + 2010-03-05: Jakob Ole Stoklundsen / Simon Goldschmidt + * opt.h, tcp.h, tcp_impl.h, tcp.c, tcp_in.c, tcp_out.c: task #7040: + Work on tcp_enqueue: Don't waste memory when chaining segments, + added option TCP_OVERSIZE to prevent creating many small pbufs when + calling tcp_write with many small blocks of data. Instead, pbufs are + allocated larger than needed and the space is used for later calls to + tcp_write. + + 2010-02-21: Simon Goldschmidt + * stats.c/.h: Added const char* name to mem- and memp-stats for easier + debugging. + + 2010-02-21: Simon Goldschmidt + * tcp.h (and usages), added tcp_impl.h: Splitted API and internal + implementation of tcp to make API usage cleare to application programmers + + 2010-02-14: Simon Goldschmidt/Stephane Lesage + * ip_addr.h: Improved some defines working on ip addresses, added faster + macro to copy addresses that cannot be NULL + + 2010-02-13: Simon Goldschmidt + * api.h, api_lib.c, api_msg.c, sockets.c: task #7865 (implement non- + blocking send operation) + + 2010-02-12: Simon Goldschmidt + * sockets.c/.h: Added a minimal version of posix fctl() to have a + standardised way to set O_NONBLOCK for nonblocking sockets. + + 2010-02-12: Simon Goldschmidt + * dhcp.c/.h, autoip.c/.h: task #10139 (Prefer statically allocated + memory): added autoip_set_struct() and dhcp_set_struct() to let autoip + and dhcp work with user-allocated structs instead of callin mem_malloc + + 2010-02-12: Simon Goldschmidt/Jeff Barber + * tcp.c/h: patch #6865 (SO_REUSEADDR for TCP): if pcb.so_options has + SOF_REUSEADDR set, allow binding to endpoint in TIME_WAIT + + 2010-02-12: Simon Goldschmidt + * sys layer: task #10139 (Prefer statically allocated memory): converted + mbox and semaphore functions to take pointers to sys_mbox_t/sys_sem_t; + converted sys_mbox_new/sys_sem_new to take pointers and return err_t; + task #7212: Add Mutex concept in sys_arch (define LWIP_COMPAT_MUTEX + to let sys.h use binary semaphores instead of mutexes - as before) + + 2010-02-09: Simon Goldschmidt (Simon Kallweit) + * timers.c/.h: Added function sys_restart_timeouts() from patch #7085 + (Restart system timeout handling) + + 2010-02-09: Simon Goldschmidt + * netif.c/.h, removed loopif.c/.h: task #10153 (Integrate loopif into + netif.c) - loopif does not have to be created by the port any more, + just define LWIP_HAVE_LOOPIF to 1. + + 2010-02-08: Simon Goldschmidt + * inet.h, ip_addr.c/.h: Added reentrant versions of inet_ntoa/ipaddr_ntoa + inet_ntoa_r/ipaddr_ntoa_r + + 2010-02-08: Simon Goldschmidt + * netif.h: Added netif_s/get_igmp_mac_filter() macros + + 2010-02-05: Simon Goldschmidt + * netif.h: Added function-like macros to get/set the hostname on a netif + + 2010-02-04: Simon Goldschmidt + * nearly every file: Replaced struct ip_addr by typedef ip_addr_t to + make changing the actual implementation behind the typedef easier. + + 2010-02-01: Simon Goldschmidt + * opt.h, memp_std.h, dns.h, netdb.c, memp.c: Let netdb use a memp pool + for allocating memory when getaddrinfo() is called. + + 2010-01-31: Simon Goldschmidt + * dhcp.h, dhcp.c: Reworked the code that parses DHCP options: parse + them once instead of parsing for every option. This also removes + the need for mem_malloc from dhcp_recv and makes it possible to + correctly retrieve the BOOTP file. + + 2010-01-30: simon Goldschmidt + * sockets.c: Use SYS_LIGHTWEIGHT_PROT instead of a semaphore to protect + the sockets array. + + 2010-01-29: Simon Goldschmidt (patch by Laura Garrett) + * api.h, api_msg.c, sockets.c: Added except set support in select + (patch #6860) + + 2010-01-29: Simon Goldschmidt (patch by Laura Garrett) + * api.h, sockets.h, err.h, api_lib.c, api_msg.c, sockets.c, err.c: + Add non-blocking support for connect (partly from patch #6860), + plus many cleanups in socket & netconn API. + + 2010-01-27: Simon Goldschmidt + * opt.h, tcp.h, init.c, api_msg.c: Added TCP_SNDQUEUELOWAT corresponding + to TCP_SNDLOWAT and added tcp_sndqueuelen() - this fixes bug #28605 + + 2010-01-26: Simon Goldschmidt + * snmp: Use memp pools for snmp instead of the heap; added 4 new pools. + + 2010-01-14: Simon Goldschmidt + * ppp.c/.h: Fixed bug #27856: PPP: Set netif link- and status-callback + by adding ppp_set_netif_statuscallback()/ppp_set_netif_linkcallback() + + 2010-01-13: Simon Goldschmidt + * mem.c: The heap now may be moved to user-defined memory by defining + LWIP_RAM_HEAP_POINTER as a void pointer to that memory's address + (patch #6966 and bug #26133) + + 2010-01-10: Simon Goldschmidt (Bill Auerbach) + * opt.h, memp.c: patch #6822 (Add option to place memory pools in + separate arrays) + + 2010-01-10: Simon Goldschmidt + * init.c, igmp.c: patch #6463 (IGMP - Adding Random Delay): added define + LWIP_RAND() for lwip-wide randomization (to be defined in cc.h) + + 2009-12-31: Simon Goldschmidt + * tcpip.c, init.c, memp.c, sys.c, memp_std.h, sys.h, tcpip.h + added timers.c/.h: Separated timer implementation from semaphore/mbox + implementation, moved timer implementation to timers.c/.h, timers are + now only called from tcpip_thread or by explicitly checking them. + (TASK#7235) + + 2009-12-27: Simon Goldschmidt + * opt.h, etharp.h/.c, init.c, tcpip.c: Added an additional option + LWIP_ETHERNET to support ethernet without ARP (necessary for pure PPPoE) + + + ++ Bugfixes: + + 2011-04-20: Simon Goldschmidt + * sys_arch.txt: sys_arch_timeouts() is not needed any more. + + 2011-04-13: Simon Goldschmidt + * tcp.c, udp.c: Fixed bug #33048 (Bad range for IP source port numbers) by + using ports in the IANA private/dynamic range (49152 through 65535). + + 2011-03-29: Simon Goldschmidt, patch by Emil Lhungdahl: + * etharp.h/.c: Fixed broken VLAN support. + + 2011-03-27: Simon Goldschmidt + * tcp.c: Fixed bug #32926 (TCP_RMV(&tcp_bound_pcbs) is called on unbound tcp + pcbs) by checking if the pcb was bound (local_port != 0). + + 2011-03-27: Simon Goldschmidt + * ppp.c: Fixed bug #32280 (ppp: a pbuf is freed twice) + + 2011-03-27: Simon Goldschmidt + * sockets.c: Fixed bug #32906: lwip_connect+lwip_send did not work for udp and + raw pcbs with LWIP_TCPIP_CORE_LOCKING==1. + + 2011-03-27: Simon Goldschmidt + * tcp_out.c: Fixed bug #32820 (Outgoing TCP connections created before route + is present never times out) by starting retransmission timer before checking + route. + + 2011-03-22: Simon Goldschmidt + * ppp.c: Fixed bug #32648 (PPP code crashes when terminating a link) by only + calling sio_read_abort() if the file descriptor is valid. + + 2011-03-14: Simon Goldschmidt + * err.h/.c, sockets.c, api_msg.c: fixed bug #31748 (Calling non-blocking connect + more than once can render a socket useless) since it mainly involves changing + "FATAL" classification of error codes: ERR_USE and ERR_ISCONN just aren't fatal. + + 2011-03-13: Simon Goldschmidt + * sockets.c: fixed bug #32769 (ESHUTDOWN is linux-specific) by fixing + err_to_errno_table (ERR_CLSD: ENOTCONN instead of ESHUTDOWN), ERR_ISCONN: + use EALRADY instead of -1 + + 2011-03-13: Simon Goldschmidt + * api_lib.c: netconn_accept: return ERR_ABRT instead of ERR_CLSD if the + connection has been aborted by err_tcp (since this is not a normal closing + procedure). + + 2011-03-13: Simon Goldschmidt + * tcp.c: tcp_bind: return ERR_VAL instead of ERR_ISCONN when trying to bind + with pcb->state != CLOSED + + 2011-02-17: Simon Goldschmidt + * rawapi.txt: Fixed bug #32561 tcp_poll argument definition out-of-order in + documentation + + 2011-02-17: Simon Goldschmidt + * many files: Added missing U/UL modifiers to fix 16-bit-arch portability. + + 2011-01-24: Simon Goldschmidt + * sockets.c: Fixed bug #31741: lwip_select seems to have threading problems + + 2010-12-02: Simon Goldschmidt + * err.h: Fixed ERR_IS_FATAL so that ERR_WOULDBLOCK is not fatal. + + 2010-11-23: Simon Goldschmidt + * api.h, api_lib.c, api_msg.c, sockets.c: netconn.recv_avail is only used for + LWIP_SO_RCVBUF and ioctl/FIONREAD. + + 2010-11-23: Simon Goldschmidt + * etharp.c: Fixed bug #31720: ARP-queueing: RFC 1122 recommends to queue at + least 1 packet -> ARP_QUEUEING==0 now queues the most recent packet. + + 2010-11-23: Simon Goldschmidt + * tcp_in.c: Fixed bug #30577: tcp_input: don't discard ACK-only packets after + refusing 'refused_data' again. + + 2010-11-22: Simon Goldschmidt + * sockets.c: Fixed bug #31590: getsockopt(... SO_ERROR ...) gives EINPROGRESS + after a successful nonblocking connection. + + 2010-11-22: Simon Goldschmidt + * etharp.c: Fixed bug #31722: IP packets sent with an AutoIP source addr + must be sent link-local + + 2010-11-22: Simon Goldschmidt + * timers.c: patch #7329: tcp_timer_needed prototype was ifdef'ed out for + LWIP_TIMERS==0 + + 2010-11-20: Simon Goldschmidt + * sockets.c: Fixed bug #31170: lwip_setsockopt() does not set socket number + + 2010-11-20: Simon Goldschmidt + * sockets.h: Fixed bug #31304: Changed SHUT_RD, SHUT_WR and SHUT_RDWR to + resemble other stacks. + + 2010-11-20: Simon Goldschmidt + * dns.c: Fixed bug #31535: TCP_SND_QUEUELEN must be at least 2 or else + no-copy TCP writes will never succeed. + + 2010-11-20: Simon Goldschmidt + * dns.c: Fixed bug #31701: Error return value from dns_gethostbyname() does + not match documentation: return ERR_ARG instead of ERR_VAL if not + initialized or wrong argument. + + 2010-10-20: Simon Goldschmidt + * sockets.h: Fixed bug #31385: sizeof(struct sockaddr) is 30 but should be 16 + + 2010-10-05: Simon Goldschmidt + * dhcp.c: Once again fixed #30038: DHCP/AutoIP cooperation failed when + replugging the network cable after an AutoIP address was assigned. + + 2010-08-10: Simon Goldschmidt + * tcp.c: Fixed bug #30728: tcp_new_port() did not check listen pcbs + + 2010-08-03: Simon Goldschmidt + * udp.c, raw.c: Don't chain empty pbufs when sending them (fixes bug #30625) + + 2010-08-01: Simon Goldschmidt (patch by Greg Renda) + * ppp.c: Applied patch #7264 (PPP protocols are rejected incorrectly on big + endian architectures) + + 2010-07-28: Simon Goldschmidt + * api_lib.c, api_msg.c, sockets.c, mib2.c: Fixed compilation with TCP or UDP + disabled. + + 2010-07-27: Simon Goldschmidt + * tcp.c: Fixed bug #30565 (tcp_connect() check bound list): that check did no + harm but never did anything + + 2010-07-21: Simon Goldschmidt + * ip.c: Fixed invalid fix for bug #30402 (CHECKSUM_GEN_IP_INLINE does not + add IP options) + + 2010-07-16: Kieran Mansley + * msg_in.c: Fixed SNMP ASN constant defines to not use ! operator + + 2010-07-10: Simon Goldschmidt + * ip.c: Fixed bug #30402: CHECKSUM_GEN_IP_INLINE does not add IP options + + 2010-06-30: Simon Goldschmidt + * api_msg.c: fixed bug #30300 (shutdown parameter was not initialized in + netconn_delete) + + 2010-06-28: Kieran Mansley + * timers.c remove unportable printing of C function pointers + + 2010-06-24: Simon Goldschmidt + * init.c, timers.c/.h, opt.h, memp_std.h: From patch #7221: added flag + NO_SYS_NO_TIMERS to drop timer support for NO_SYS==1 for easier upgrading + + 2010-06-24: Simon Goldschmidt + * api(_lib).c/.h, api_msg.c/.h, sockets.c/.h: Fixed bug #10088: Correctly + implemented shutdown at socket level. + + 2010-06-21: Simon Goldschmidt + * pbuf.c/.h, ip_frag.c/.h, opt.h, memp_std.h: Fixed bug #29361 (ip_frag has + problems with zero-copy DMA MACs) by adding custom pbufs and implementing + custom pbufs that reference other (original) pbufs. Additionally set + IP_FRAG_USES_STATIC_BUF=0 as default to be on the safe side. + + 2010-06-15: Simon Goldschmidt + * dhcp.c: Fixed bug #29970: DHCP endian issue parsing option responses + + 2010-06-14: Simon Goldschmidt + * autoip.c: Fixed bug #30039: AutoIP does not reuse previous addresses + + 2010-06-12: Simon Goldschmidt + * dhcp.c: Fixed bug #30038: dhcp_network_changed doesn't reset AUTOIP coop + state + + 2010-05-17: Simon Goldschmidt + * netdb.c: Correctly NULL-terminate h_addr_list + + 2010-05-16: Simon Goldschmidt + * def.h/.c: changed the semantics of LWIP_PREFIX_BYTEORDER_FUNCS to prevent + "symbol already defined" i.e. when linking to winsock + + 2010-05-05: Simon Goldschmidt + * def.h, timers.c: Fixed bug #29769 (sys_check_timeouts: sys_now() may + overflow) + + 2010-04-21: Simon Goldschmidt + * api_msg.c: Fixed bug #29617 (sometime cause stall on delete listening + connection) + + 2010-03-28: Luca Ceresoli + * ip_addr.c/.h: patch #7143: Add a few missing const qualifiers + + 2010-03-27: Luca Ceresoli + * mib2.c: patch #7130: remove meaningless const qualifiers + + 2010-03-26: Simon Goldschmidt + * tcp_out.c: Make LWIP_NETIF_TX_SINGLE_PBUF work for TCP, too + + 2010-03-26: Simon Goldschmidt + * various files: Fixed compiling with different options disabled (TCP/UDP), + triggered by bug #29345; don't allocate acceptmbox if LWIP_TCP is disabled + + 2010-03-25: Simon Goldschmidt + * sockets.c: Fixed bug #29332: lwip_select() processes readset incorrectly + + 2010-03-25: Simon Goldschmidt + * tcp_in.c, test_tcp_oos.c: Fixed bug #29080: Correctly handle remote side + overrunning our rcv_wnd in ooseq case. + + 2010-03-22: Simon Goldschmidt + * tcp.c: tcp_listen() did not copy the pcb's prio. + + 2010-03-19: Simon Goldschmidt + * snmp_msg.c: Fixed bug #29256: SNMP Trap address was not correctly set + + 2010-03-14: Simon Goldschmidt + * opt.h, etharp.h: Fixed bug #29148 (Incorrect PBUF_POOL_BUFSIZE for ports + where ETH_PAD_SIZE > 0) by moving definition of ETH_PAD_SIZE to opt.h + and basing PBUF_LINK_HLEN on it. + + 2010-03-08: Simon Goldschmidt + * netif.c, ipv4/ip.c: task #10241 (AutoIP: don't break existing connections + when assiging routable address): when checking incoming packets and + aborting existing connection on address change, filter out link-local + addresses. + + 2010-03-06: Simon Goldschmidt + * sockets.c: Fixed LWIP_NETIF_TX_SINGLE_PBUF for LWIP_TCPIP_CORE_LOCKING + + 2010-03-06: Simon Goldschmidt + * ipv4/ip.c: Don't try to forward link-local addresses + + 2010-03-06: Simon Goldschmidt + * etharp.c: Fixed bug #29087: etharp: don't send packets for LinkLocal- + addresses to gw + + 2010-03-05: Simon Goldschmidt + * dhcp.c: Fixed bug #29072: Correctly set ciaddr based on message-type + and state. + + 2010-03-05: Simon Goldschmidt + * api_msg.c: Correctly set TCP_WRITE_FLAG_MORE when netconn_write is split + into multiple calls to tcp_write. + + 2010-02-21: Simon Goldschmidt + * opt.h, mem.h, dns.c: task #10140: Remove DNS_USES_STATIC_BUF (keep + the implementation of DNS_USES_STATIC_BUF==1) + + 2010-02-20: Simon Goldschmidt + * tcp.h, tcp.c, tcp_in.c, tcp_out.c: Task #10088: Correctly implement + close() vs. shutdown(). Now the application does not get any more + recv callbacks after calling tcp_close(). Added tcp_shutdown(). + + 2010-02-19: Simon Goldschmidt + * mem.c/.h, pbuf.c: Renamed mem_realloc() to mem_trim() to prevent + confusion with realloc() + + 2010-02-15: Simon Goldschmidt/Stephane Lesage + * netif.c/.h: Link status does not depend on LWIP_NETIF_LINK_CALLBACK + (fixes bug #28899) + + 2010-02-14: Simon Goldschmidt + * netif.c: Fixed bug #28877 (Duplicate ARP gratuitous packet with + LWIP_NETIF_LINK_CALLBACK set on) by only sending if both link- and + admin-status of a netif are up + + 2010-02-14: Simon Goldschmidt + * opt.h: Disable ETHARP_TRUST_IP_MAC by default since it slows down packet + reception and is not really necessary + + 2010-02-14: Simon Goldschmidt + * etharp.c/.h: Fixed ARP input processing: only add a new entry if a + request was directed as us (RFC 826, Packet Reception), otherwise + only update existing entries; internalized some functions + + 2010-02-14: Simon Goldschmidt + * netif.h, etharp.c, tcpip.c: Fixed bug #28183 (ARP and TCP/IP cannot be + disabled on netif used for PPPoE) by adding a new netif flag + (NETIF_FLAG_ETHERNET) that tells the stack the device is an ethernet + device but prevents usage of ARP (so that ethernet_input can be used + for PPPoE). + + 2010-02-12: Simon Goldschmidt + * netif.c: netif_set_link_up/down: only do something if the link state + actually changes + + 2010-02-12: Simon Goldschmidt/Stephane Lesage + * api_msg.c: Fixed bug #28865 (Cannot close socket/netconn in non-blocking + connect) + + 2010-02-12: Simon Goldschmidt + * mem.h: Fixed bug #28866 (mem_realloc function defined in mem.h) + + 2010-02-09: Simon Goldschmidt + * api_lib.c, api_msg.c, sockets.c, api.h, api_msg.h: Fixed bug #22110 + (recv() makes receive window update for data that wasn't received by + application) + + 2010-02-09: Simon Goldschmidt/Stephane Lesage + * sockets.c: Fixed bug #28853 (lwip_recvfrom() returns 0 on receive time-out + or any netconn_recv() error) + + 2010-02-09: Simon Goldschmidt + * ppp.c: task #10154 (PPP: Update snmp in/out counters for tx/rx packets) + + 2010-02-09: Simon Goldschmidt + * netif.c: For loopback packets, adjust the stats- and snmp-counters + for the loopback netif. + + 2010-02-08: Simon Goldschmidt + * igmp.c/.h, ip.h: Moved most defines from igmp.h to igmp.c for clarity + since they are not used anywhere else. + + 2010-02-08: Simon Goldschmidt (Stéphane Lesage) + * igmp.c, igmp.h, stats.c, stats.h: Improved IGMP stats + (patch from bug #28798) + + 2010-02-08: Simon Goldschmidt (Stéphane Lesage) + * igmp.c: Fixed bug #28798 (Error in "Max Response Time" processing) and + another bug when LWIP_RAND() returns zero. + + 2010-02-04: Simon Goldschmidt + * nearly every file: Use macros defined in ip_addr.h (some of them new) + to work with IP addresses (preparation for bug #27352 - Change ip_addr + from struct to typedef (u32_t) - and better code). + + 2010-01-31: Simon Goldschmidt + * netif.c: Don't call the link-callback from netif_set_up/down() since + this invalidly retriggers DHCP. + + 2010-01-29: Simon Goldschmidt + * ip_addr.h, inet.h, def.h, inet.c, def.c, more: Cleanly separate the + portability file inet.h and its contents from the stack: moved htonX- + functions to def.h (and the new def.c - they are not ipv4 dependent), + let inet.h depend on ip_addr.h and not the other way round. + This fixes bug #28732. + + 2010-01-28: Kieran Mansley + * tcp.c: Ensure ssthresh >= 2*MSS + + 2010-01-27: Simon Goldschmidt + * tcp.h, tcp.c, tcp_in.c: Fixed bug #27871: Calling tcp_abort() in recv + callback can lead to accessing unallocated memory. As a consequence, + ERR_ABRT means the application has called tcp_abort()! + + 2010-01-25: Simon Goldschmidt + * snmp_structs.h, msg_in.c: Partly fixed bug #22070 (MIB_OBJECT_WRITE_ONLY + not implemented in SNMP): write-only or not-accessible are still + returned by getnext (though not by get) + + 2010-01-24: Simon Goldschmidt + * snmp: Renamed the private mib node from 'private' to 'mib_private' to + not use reserved C/C++ keywords + + 2010-01-23: Simon Goldschmidt + * sockets.c: Fixed bug #28716: select() returns 0 after waiting for less + than 1 ms + + 2010-01-21: Simon Goldschmidt + * tcp.c, api_msg.c: Fixed bug #28651 (tcp_connect: no callbacks called + if tcp_enqueue fails) both in raw- and netconn-API + + 2010-01-19: Simon Goldschmidt + * api_msg.c: Fixed bug #27316: netconn: Possible deadlock in err_tcp + + 2010-01-18: Iordan Neshev/Simon Goldschmidt + * src/netif/ppp: reorganised PPP sourcecode to 2.3.11 including some + bugfix backports from 2.4.x. + + 2010-01-18: Simon Goldschmidt + * mem.c: Fixed bug #28679: mem_realloc calculates mem_stats wrong + + 2010-01-17: Simon Goldschmidt + * api_lib.c, api_msg.c, (api_msg.h, api.h, sockets.c, tcpip.c): + task #10102: "netconn: clean up conn->err threading issues" by adding + error return value to struct api_msg_msg + + 2010-01-17: Simon Goldschmidt + * api.h, api_lib.c, sockets.c: Changed netconn_recv() and netconn_accept() + to return err_t (bugs #27709 and #28087) + + 2010-01-14: Simon Goldschmidt + * ...: Use typedef for function prototypes throughout the stack. + + 2010-01-13: Simon Goldschmidt + * api_msg.h/.c, api_lib.c: Fixed bug #26672 (close connection when receive + window = 0) by correctly draining recvmbox/acceptmbox + + 2010-01-11: Simon Goldschmidt + * pap.c: Fixed bug #13315 (PPP PAP authentication can result in + erroneous callbacks) by copying the code from recent pppd + + 2010-01-10: Simon Goldschmidt + * raw.c: Fixed bug #28506 (raw_bind should filter received packets) + + 2010-01-10: Simon Goldschmidt + * tcp.h/.c: bug #28127 (remove call to tcp_output() from tcp_ack(_now)()) + + 2010-01-08: Simon Goldschmidt + * sockets.c: Fixed bug #28519 (lwip_recvfrom bug with len > 65535) + + 2010-01-08: Simon Goldschmidt + * dns.c: Copy hostname for DNS_LOCAL_HOSTLIST_IS_DYNAMIC==1 since string + passed to dns_local_addhost() might be volatile + + 2010-01-07: Simon Goldschmidt + * timers.c, tcp.h: Call tcp_timer_needed() with NO_SYS==1, too + + 2010-01-06: Simon Goldschmidt + * netdb.h: Fixed bug #28496: missing include guards in netdb.h + + 2009-12-31: Simon Goldschmidt + * many ppp files: Reorganised PPP source code from ucip structure to pppd + structure to easily compare our code against the pppd code (around v2.3.1) + + 2009-12-27: Simon Goldschmidt + * tcp_in.c: Another fix for bug #28241 (ooseq processing) and adapted + unit test + + +(STABLE-1.3.2) + + ++ New features: + + 2009-10-27 Simon Goldschmidt/Stephan Lesage + * netifapi.c/.h: Added netifapi_netif_set_addr() + + 2009-10-07 Simon Goldschmidt/Fabian Koch + * api_msg.c, netbuf.c/.h, opt.h: patch #6888: Patch for UDP Netbufs to + support dest-addr and dest-port (optional: LWIP_NETBUF_RECVINFO) + + 2009-08-26 Simon Goldschmidt/Simon Kallweit + * slipif.c/.h: bug #26397: SLIP polling support + + 2009-08-25 Simon Goldschmidt + * opt.h, etharp.h/.c: task #9033: Support IEEE 802.1q tagged frame (VLAN), + New configuration options ETHARP_SUPPORT_VLAN and ETHARP_VLAN_CHECK. + + 2009-08-25 Simon Goldschmidt + * ip_addr.h, netdb.c: patch #6900: added define ip_ntoa(struct ip_addr*) + + 2009-08-24 Jakob Stoklund Olesen + * autoip.c, dhcp.c, netif.c: patch #6725: Teach AutoIP and DHCP to respond + to netif_set_link_up(). + + 2009-08-23 Simon Goldschmidt + * tcp.h/.c: Added function tcp_debug_state_str() to convert a tcp state + to a human-readable string. + + ++ Bugfixes: + + 2009-12-24: Kieran Mansley + * tcp_in.c Apply patches from Oleg Tyshev to improve OOS processing + (BUG#28241) + + 2009-12-06: Simon Goldschmidt + * ppp.h/.c: Fixed bug #27079 (Yet another leak in PPP): outpacket_buf can + be statically allocated (like in ucip) + + 2009-12-04: Simon Goldschmidt (patch by Ioardan Neshev) + * pap.c: patch #6969: PPP: missing PAP authentication UNTIMEOUT + + 2009-12-03: Simon Goldschmidt + * tcp.h, tcp_in.c, tcp_out.c: Fixed bug #28106: dup ack for fast retransmit + could have non-zero length + + 2009-12-02: Simon Goldschmidt + * tcp_in.c: Fixed bug #27904: TCP sends too many ACKs: delay resetting + tcp_input_pcb until after calling the pcb's callbacks + + 2009-11-29: Simon Goldschmidt + * tcp_in.c: Fixed bug #28054: Two segments with FIN flag on the out-of- + sequence queue, also fixed PBUF_POOL leak in the out-of-sequence code + + 2009-11-29: Simon Goldschmidt + * pbuf.c: Fixed bug #28064: pbuf_alloc(PBUF_POOL) is not thread-safe by + queueing a call into tcpip_thread to free ooseq-bufs if the pool is empty + + 2009-11-26: Simon Goldschmidt + * tcp.h: Fixed bug #28098: Nagle can prevent fast retransmit from sending + segment + + 2009-11-26: Simon Goldschmidt + * tcp.h, sockets.c: Fixed bug #28099: API required to disable Nagle + algorithm at PCB level + + 2009-11-22: Simon Goldschmidt + * tcp_out.c: Fixed bug #27905: FIN isn't combined with data on unsent + + 2009-11-22: Simon Goldschmidt (suggested by Bill Auerbach) + * tcp.c: tcp_alloc: prevent increasing stats.err for MEMP_TCP_PCB when + reusing time-wait pcb + + 2009-11-20: Simon Goldschmidt (patch by Albert Bartel) + * sockets.c: Fixed bug #28062: Data received directly after accepting + does not wake up select + + 2009-11-11: Simon Goldschmidt + * netdb.h: Fixed bug #27994: incorrect define for freeaddrinfo(addrinfo) + + 2009-10-30: Simon Goldschmidt + * opt.h: Increased default value for TCP_MSS to 536, updated default + value for TCP_WND to 4*TCP_MSS to keep delayed ACK working. + + 2009-10-28: Kieran Mansley + * tcp_in.c, tcp_out.c, tcp.h: re-work the fast retransmission code + to follow algorithm from TCP/IP Illustrated + + 2009-10-27: Kieran Mansley + * tcp_in.c: fix BUG#27445: grow cwnd with every duplicate ACK + + 2009-10-25: Simon Goldschmidt + * tcp.h: bug-fix in the TCP_EVENT_RECV macro (has to call tcp_recved if + pcb->recv is NULL to keep rcv_wnd correct) + + 2009-10-25: Simon Goldschmidt + * tcp_in.c: Fixed bug #26251: RST process in TIME_WAIT TCP state + + 2009-10-23: Simon Goldschmidt (David Empson) + * tcp.c: Fixed bug #27783: Silly window avoidance for small window sizes + + 2009-10-21: Simon Goldschmidt + * tcp_in.c: Fixed bug #27215: TCP sent() callback gives leading and + trailing 1 byte len (SYN/FIN) + + 2009-10-21: Simon Goldschmidt + * tcp_out.c: Fixed bug #27315: zero window probe and FIN + + 2009-10-19: Simon Goldschmidt + * dhcp.c/.h: Minor code simplification (don't store received pbuf, change + conditional code to assert where applicable), check pbuf length before + testing for valid reply + + 2009-10-19: Simon Goldschmidt + * dhcp.c: Removed most calls to udp_connect since they aren't necessary + when using udp_sendto_if() - always stay connected to IP_ADDR_ANY. + + 2009-10-16: Simon Goldschmidt + * ip.c: Fixed bug #27390: Source IP check in ip_input() causes it to drop + valid DHCP packets -> allow 0.0.0.0 as source address when LWIP_DHCP is + enabled + + 2009-10-15: Simon Goldschmidt (Oleg Tyshev) + * tcp_in.c: Fixed bug #27329: dupacks by unidirectional data transmit + + 2009-10-15: Simon Goldschmidt + * api_lib.c: Fixed bug #27709: conn->err race condition on netconn_recv() + timeout + + 2009-10-15: Simon Goldschmidt + * autoip.c: Fixed bug #27704: autoip starts with wrong address + LWIP_AUTOIP_CREATE_SEED_ADDR() returned address in host byte order instead + of network byte order + + 2009-10-11 Simon Goldschmidt (Jörg Kesten) + * tcp_out.c: Fixed bug #27504: tcp_enqueue wrongly concatenates segments + which are not consecutive when retransmitting unacked segments + + 2009-10-09 Simon Goldschmidt + * opt.h: Fixed default values of some stats to only be enabled if used + Fixes bug #27338: sys_stats is defined when NO_SYS = 1 + + 2009-08-30 Simon Goldschmidt + * ip.c: Fixed bug bug #27345: "ip_frag() does not use the LWIP_NETIF_LOOPBACK + function" by checking for loopback before calling ip_frag + + 2009-08-25 Simon Goldschmidt + * dhcp.c: fixed invalid dependency to etharp_query if DHCP_DOES_ARP_CHECK==0 + + 2009-08-23 Simon Goldschmidt + * ppp.c: bug #27078: Possible memory leak in pppInit() + + 2009-08-23 Simon Goldschmidt + * netdb.c, dns.c: bug #26657: DNS, if host name is "localhost", result + is error. + + 2009-08-23 Simon Goldschmidt + * opt.h, init.c: bug #26649: TCP fails when TCP_MSS > TCP_SND_BUF + Fixed wrong parenthesis, added check in init.c + + 2009-08-23 Simon Goldschmidt + * ppp.c: bug #27266: wait-state debug message in pppMain occurs every ms + + 2009-08-23 Simon Goldschmidt + * many ppp files: bug #27267: Added include to string.h where needed + + 2009-08-23 Simon Goldschmidt + * tcp.h: patch #6843: tcp.h macro optimization patch (for little endian) + + +(STABLE-1.3.1) + + ++ New features: + + 2009-05-10 Simon Goldschmidt + * opt.h, sockets.c, pbuf.c, netbuf.h, pbuf.h: task #7013: Added option + LWIP_NETIF_TX_SINGLE_PBUF to try to create transmit packets from only + one pbuf to help MACs that don't support scatter-gather DMA. + + 2009-05-09 Simon Goldschmidt + * icmp.h, icmp.c: Shrinked ICMP code, added option to NOT check icoming + ECHO pbuf for size (just use it): LWIP_ICMP_ECHO_CHECK_INPUT_PBUF_LEN + + 2009-05-05 Simon Goldschmidt, Jakob Stoklund Olesen + * ip.h, ip.c: Added ip_current_netif() & ip_current_header() to receive + extended info about the currently received packet. + + 2009-04-27 Simon Goldschmidt + * sys.h: Made SYS_LIGHTWEIGHT_PROT and sys_now() work with NO_SYS=1 + + 2009-04-25 Simon Goldschmidt + * mem.c, opt.h: Added option MEM_USE_POOLS_TRY_BIGGER_POOL to try the next + bigger malloc pool if one is empty (only usable with MEM_USE_POOLS). + + 2009-04-21 Simon Goldschmidt + * dns.c, init.c, dns.h, opt.h: task #7507, patch #6786: DNS supports static + hosts table. New configuration options DNS_LOCAL_HOSTLIST and + DNS_LOCAL_HOSTLIST_IS_DYNAMIC. Also, DNS_LOOKUP_LOCAL_EXTERN() can be defined + as an external function for lookup. + + 2009-04-15 Simon Goldschmidt + * dhcp.c: patch #6763: Global DHCP XID can be redefined to something more unique + + 2009-03-31 Kieran Mansley + * tcp.c, tcp_out.c, tcp_in.c, sys.h, tcp.h, opts.h: add support for + TCP timestamp options, off by default. Rework tcp_enqueue() to + take option flags rather than specified option data + + 2009-02-18 Simon Goldschmidt + * cc.h: Added printf formatter for size_t: SZT_F + + 2009-02-16 Simon Goldschmidt (patch by Rishi Khan) + * icmp.c, opt.h: patch #6539: (configurable) response to broadcast- and multicast + pings + + 2009-02-12 Simon Goldschmidt + * init.h: Added LWIP_VERSION to get the current version of the stack + + 2009-02-11 Simon Goldschmidt (suggested by Gottfried Spitaler) + * opt.h, memp.h/.c: added MEMP_MEM_MALLOC to use mem_malloc/mem_free instead + of the pool allocator (can save code size with MEM_LIBC_MALLOC if libc-malloc + is otherwise used) + + 2009-01-28 Jonathan Larmour (suggested by Bill Bauerbach) + * ipv4/inet_chksum.c, ipv4/lwip/inet_chksum.h: inet_chksum_pseudo_partial() + is only used by UDPLITE at present, so conditionalise it. + + 2008-12-03 Simon Goldschmidt (base on patch from Luca Ceresoli) + * autoip.c: checked in (slightly modified) patch #6683: Customizable AUTOIP + "seed" address. This should reduce AUTOIP conflicts if + LWIP_AUTOIP_CREATE_SEED_ADDR is overridden. + + 2008-10-02 Jonathan Larmour and Rishi Khan + * sockets.c (lwip_accept): Return EWOULDBLOCK if would block on non-blocking + socket. + + 2008-06-30 Simon Goldschmidt + * mem.c, opt.h, stats.h: fixed bug #21433: Calling mem_free/pbuf_free from + interrupt context isn't safe: LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT allows + mem_free to run between mem_malloc iterations. Added illegal counter for + mem stats. + + 2008-06-27 Simon Goldschmidt + * stats.h/.c, some other files: patch #6483: stats module improvement: + Added defines to display each module's statistic individually, added stats + defines for MEM, MEMP and SYS modules, removed (unused) rexmit counter. + + 2008-06-17 Simon Goldschmidt + * err.h: patch #6459: Made err_t overridable to use a more efficient type + (define LWIP_ERR_T in cc.h) + + 2008-06-17 Simon Goldschmidt + * slipif.c: patch #6480: Added a configuration option for slipif for symmetry + to loopif + + 2008-06-17 Simon Goldschmidt (patch by Luca Ceresoli) + * netif.c, loopif.c, ip.c, netif.h, loopif.h, opt.h: Checked in slightly + modified version of patch # 6370: Moved loopif code to netif.c so that + loopback traffic is supported on all netifs (all local IPs). + Added option to limit loopback packets for each netifs. + + + ++ Bugfixes: + 2009-08-12 Kieran Mansley + * tcp_in.c, tcp.c: Fix bug #27209: handle trimming of segments when + out of window or out of order properly + + 2009-08-12 Kieran Mansley + * tcp_in.c: Fix bug #27199: use snd_wl2 instead of snd_wl1 + + 2009-07-28 Simon Goldschmidt + * mem.h: Fixed bug #27105: "realloc() cannot replace mem_realloc()"s + + 2009-07-27 Kieran Mansley + * api.h api_msg.h netdb.h sockets.h: add missing #include directives + + 2009-07-09 Kieran Mansley + * api_msg.c, sockets.c, api.h: BUG23240 use signed counters for + recv_avail and don't increment counters until message successfully + sent to mbox + + 2009-06-25 Kieran Mansley + * api_msg.c api.h: BUG26722: initialise netconn write variables + in netconn_alloc + + 2009-06-25 Kieran Mansley + * tcp.h: BUG26879: set ret value in TCP_EVENT macros when function is not set + + 2009-06-25 Kieran Mansley + * tcp.c, tcp_in.c, tcp_out.c, tcp.h: BUG26301 and BUG26267: correct + simultaneous close behaviour, and make snd_nxt have the same meaning + as in the RFCs. + + 2009-05-12 Simon Goldschmidt + * etharp.h, etharp.c, netif.c: fixed bug #26507: "Gratuitous ARP depends on + arp_table / uses etharp_query" by adding etharp_gratuitous() + + 2009-05-12 Simon Goldschmidt + * ip.h, ip.c, igmp.c: bug #26487: Added ip_output_if_opt that can add IP options + to the IP header (used by igmp_ip_output_if) + + 2009-05-06 Simon Goldschmidt + * inet_chksum.c: On little endian architectures, use LWIP_PLATFORM_HTONS (if + defined) for SWAP_BYTES_IN_WORD to speed up checksumming. + + 2009-05-05 Simon Goldschmidt + * sockets.c: bug #26405: Prematurely released semaphore causes lwip_select() + to crash + + 2009-05-04 Simon Goldschmidt + * init.c: snmp was not initialized in lwip_init() + + 2009-05-04 Frédéric Bernon + * dhcp.c, netbios.c: Changes if IP_SOF_BROADCAST is enabled. + + 2009-05-03 Simon Goldschmidt + * tcp.h: bug #26349: Nagle algorithm doesn't send although segment is full + (and unsent->next == NULL) + + 2009-05-02 Simon Goldschmidt + * tcpip.h, tcpip.c: fixed tcpip_untimeout (does not need the time, broken after + 1.3.0 in CVS only) - fixes compilation of ppp_oe.c + + 2009-05-02 Simon Goldschmidt + * msg_in.c: fixed bug #25636: SNMPSET value is ignored for integer fields + + 2009-05-01 Simon Goldschmidt + * pap.c: bug #21680: PPP upap_rauthnak() drops legal NAK packets + + 2009-05-01 Simon Goldschmidt + * ppp.c: bug #24228: Memory corruption with PPP and DHCP + + 2009-04-29 Frédéric Bernon + * raw.c, udp.c, init.c, opt.h, ip.h, sockets.h: bug #26309: Implement the + SO(F)_BROADCAST filter for all API layers. Avoid the unindented reception + of broadcast packets even when this option wasn't set. Port maintainers + which want to enable this filter have to set IP_SOF_BROADCAST=1 in opt.h. + If you want this option also filter broadcast on recv operations, you also + have to set IP_SOF_BROADCAST_RECV=1 in opt.h. + + 2009-04-28 Simon Goldschmidt, Jakob Stoklund Olesen + * dhcp.c: patch #6721, bugs #25575, #25576: Some small fixes to DHCP and + DHCP/AUTOIP cooperation + + 2009-04-25 Simon Goldschmidt, Oleg Tyshev + * tcp_out.c: bug #24212: Deadlocked tcp_retransmit due to exceeded pcb->cwnd + Fixed by sorting the unsent and unacked queues (segments are inserted at the + right place in tcp_output and tcp_rexmit). + + 2009-04-25 Simon Goldschmidt + * memp.c, mem.c, memp.h, mem_std.h: bug #26213 "Problem with memory allocation + when debugging": memp_sizes contained the wrong sizes (including sanity + regions); memp pools for MEM_USE_POOLS were too small + + 2009-04-24 Simon Goldschmidt, Frédéric Bernon + * inet.c: patch #6765: Fix a small problem with the last changes (incorrect + behavior, with with ip address string not ended by a '\0', a space or a + end of line) + + 2009-04-19 Simon Goldschmidt + * rawapi.txt: Fixed bug #26069: Corrected documentation: if tcp_connect fails, + pcb->err is called, not pcb->connected (with an error code). + + 2009-04-19 Simon Goldschmidt + * tcp_out.c: Fixed bug #26236: "TCP options (timestamp) don't work with + no-copy-tcpwrite": deallocate option data, only concat segments with same flags + + 2009-04-19 Simon Goldschmidt + * tcp_out.c: Fixed bug #25094: "Zero-length pbuf" (options are now allocated + in the header pbuf, not the data pbuf) + + 2009-04-18 Simon Goldschmidt + * api_msg.c: fixed bug #25695: Segmentation fault in do_writemore() + + 2009-04-15 Simon Goldschmidt + * sockets.c: tried to fix bug #23559: lwip_recvfrom problem with tcp + + 2009-04-15 Simon Goldschmidt + * dhcp.c: task #9192: mem_free of dhcp->options_in and dhcp->msg_in + + 2009-04-15 Simon Goldschmidt + * ip.c, ip6.c, tcp_out.c, ip.h: patch #6808: Add a utility function + ip_hinted_output() (for smaller code mainly) + + 2009-04-15 Simon Goldschmidt + * inet.c: patch #6765: Supporting new line characters in inet_aton() + + 2009-04-15 Simon Goldschmidt + * dhcp.c: patch #6764: DHCP rebind and renew did not send hostnam option; + Converted constant OPTION_MAX_MSG_SIZE to netif->mtu, check if netif->mtu + is big enough in dhcp_start + + 2009-04-15 Simon Goldschmidt + * netbuf.c: bug #26027: netbuf_chain resulted in pbuf memory leak + + 2009-04-15 Simon Goldschmidt + * sockets.c, ppp.c: bug #25763: corrected 4 occurrences of SMEMCPY to MEMCPY + + 2009-04-15 Simon Goldschmidt + * sockets.c: bug #26121: set_errno can be overridden + + 2009-04-09 Kieran Mansley (patch from Luca Ceresoli <lucaceresoli>) + * init.c, opt.h: Patch#6774 TCP_QUEUE_OOSEQ breaks compilation when + LWIP_TCP==0 + + 2009-04-09 Kieran Mansley (patch from Roy Lee <roylee17>) + * tcp.h: Patch#6802 Add do-while-clauses to those function like + macros in tcp.h + + 2009-03-31 Kieran Mansley + * tcp.c, tcp_in.c, tcp_out.c, tcp.h, opt.h: Rework the way window + updates are calculated and sent (BUG20515) + + * tcp_in.c: cope with SYN packets received during established states, + and retransmission of initial SYN. + + * tcp_out.c: set push bit correctly when tcp segments are merged + + 2009-03-27 Kieran Mansley + * tcp_out.c set window correctly on probes (correcting change made + yesterday) + + 2009-03-26 Kieran Mansley + * tcp.c, tcp_in.c, tcp.h: add tcp_abandon() to cope with dropping + connections where no reset required (bug #25622) + + * tcp_out.c: set TCP_ACK flag on keepalive and zero window probes + (bug #20779) + + 2009-02-18 Simon Goldschmidt (Jonathan Larmour and Bill Auerbach) + * ip_frag.c: patch #6528: the buffer used for IP_FRAG_USES_STATIC_BUF could be + too small depending on MEM_ALIGNMENT + + 2009-02-16 Simon Goldschmidt + * sockets.h/.c, api_*.h/.c: fixed arguments of socket functions to match the standard; + converted size argument of netconn_write to 'size_t' + + 2009-02-16 Simon Goldschmidt + * tcp.h, tcp.c: fixed bug #24440: TCP connection close problem on 64-bit host + by moving accept callback function pointer to TCP_PCB_COMMON + + 2009-02-12 Simon Goldschmidt + * dhcp.c: fixed bug #25345 (DHCPDECLINE is sent with "Maximum message size" + option) + + 2009-02-11 Simon Goldschmidt + * dhcp.c: fixed bug #24480 (releasing old udp_pdb and pbuf in dhcp_start) + + 2009-02-11 Simon Goldschmidt + * opt.h, api_msg.c: added configurable default valud for netconn->recv_bufsize: + RECV_BUFSIZE_DEFAULT (fixes bug #23726: pbuf pool exhaustion on slow recv()) + + 2009-02-10 Simon Goldschmidt + * tcp.c: fixed bug #25467: Listen backlog is not reset on timeout in SYN_RCVD: + Accepts_pending is decrease on a corresponding listen pcb when a connection + in state SYN_RCVD is close. + + 2009-01-28 Jonathan Larmour + * pbuf.c: reclaim pbufs from TCP out-of-sequence segments if we run + out of pool pbufs. + + 2008-12-19 Simon Goldschmidt + * many files: patch #6699: fixed some warnings on platform where sizeof(int) == 2 + + 2008-12-10 Tamas Somogyi, Frédéric Bernon + * sockets.c: fixed bug #25051: lwip_recvfrom problem with udp: fromaddr and + port uses deleted netbuf. + + 2008-10-18 Simon Goldschmidt + * tcp_in.c: fixed bug ##24596: Vulnerability on faulty TCP options length + in tcp_parseopt + + 2008-10-15 Simon Goldschmidt + * ip_frag.c: fixed bug #24517: IP reassembly crashes on unaligned IP headers + by packing the struct ip_reass_helper. + + 2008-10-03 David Woodhouse, Jonathan Larmour + * etharp.c (etharp_arp_input): Fix type aliasing problem copying ip address. + + 2008-10-02 Jonathan Larmour + * dns.c: Hard-code structure sizes, to avoid issues on some compilers where + padding is included. + + 2008-09-30 Jonathan Larmour + * sockets.c (lwip_accept): check addr isn't NULL. If it's valid, do an + assertion check that addrlen isn't NULL. + + 2008-09-30 Jonathan Larmour + * tcp.c: Fix bug #24227, wrong error message in tcp_bind. + + 2008-08-26 Simon Goldschmidt + * inet.h, ip_addr.h: fixed bug #24132: Cross-dependency between ip_addr.h and + inet.h -> moved declaration of struct in_addr from ip_addr.h to inet.h + + 2008-08-14 Simon Goldschmidt + * api_msg.c: fixed bug #23847: do_close_internal references freed memory (when + tcp_close returns != ERR_OK) + + 2008-07-08 Frédéric Bernon + * stats.h: Fix some build bugs introduced with patch #6483 (missing some parameters + in macros, mainly if MEM_STATS=0 and MEMP_STATS=0). + + 2008-06-24 Jonathan Larmour + * tcp_in.c: Fix for bug #23693 as suggested by Art R. Ensure cseg is unused + if tcp_seg_copy fails. + + 2008-06-17 Simon Goldschmidt + * inet_chksum.c: Checked in some ideas of patch #6460 (loop optimizations) + and created defines for swapping bytes and folding u32 to u16. + + 2008-05-30 Kieran Mansley + * tcp_in.c Remove redundant "if" statement, and use real rcv_wnd + rather than rcv_ann_wnd when deciding if packets are in-window. + Contributed by arasmussen@consultant.datasys.swri.edu + + 2008-05-30 Kieran Mansley + * mem.h: Fix BUG#23254. Change macro definition of mem_* to allow + passing as function pointers when MEM_LIBC_MALLOC is defined. + + 2008-05-09 Jonathan Larmour + * err.h, err.c, sockets.c: Fix bug #23119: Reorder timeout error code to + stop it being treated as a fatal error. + + 2008-04-15 Simon Goldschmidt + * dhcp.c: fixed bug #22804: dhcp_stop doesn't clear NETIF_FLAG_DHCP + (flag now cleared) + + 2008-03-27 Simon Goldschmidt + * mem.c, tcpip.c, tcpip.h, opt.h: fixed bug #21433 (Calling mem_free/pbuf_free + from interrupt context isn't safe): set LWIP_USE_HEAP_FROM_INTERRUPT to 1 + in lwipopts.h or use pbuf_free_callback(p)/mem_free_callback(m) to free pbufs + or heap memory from interrupt context + + 2008-03-26 Simon Goldschmidt + * tcp_in.c, tcp.c: fixed bug #22249: division by zero could occur if a remote + host sent a zero mss as TCP option. + + +(STABLE-1.3.0) + + ++ New features: + + 2008-03-10 Jonathan Larmour + * inet_chksum.c: Allow choice of one of the sample algorithms to be + made from lwipopts.h. Fix comment on how to override LWIP_CHKSUM. + + 2008-01-22 Frédéric Bernon + * tcp.c, tcp_in.c, tcp.h, opt.h: Rename LWIP_CALCULATE_EFF_SEND_MSS in + TCP_CALCULATE_EFF_SEND_MSS to have coherent TCP options names. + + 2008-01-14 Frédéric Bernon + * rawapi.txt, api_msg.c, tcp.c, tcp_in.c, tcp.h: changes for task #7675 "Enable + to refuse data on a TCP_EVENT_RECV call". Important, behavior changes for the + tcp_recv callback (see rawapi.txt). + + 2008-01-14 Frédéric Bernon, Marc Chaland + * ip.c: Integrate patch #6369" ip_input : checking before realloc". + + 2008-01-12 Frédéric Bernon + * tcpip.h, tcpip.c, api.h, api_lib.c, api_msg.c, sockets.c: replace the field + netconn::sem per netconn::op_completed like suggested for the task #7490 + "Add return value to sys_mbox_post". + + 2008-01-12 Frédéric Bernon + * api_msg.c, opt.h: replace DEFAULT_RECVMBOX_SIZE per DEFAULT_TCP_RECVMBOX_SIZE, + DEFAULT_UDP_RECVMBOX_SIZE and DEFAULT_RAW_RECVMBOX_SIZE (to optimize queues + sizes), like suggested for the task #7490 "Add return value to sys_mbox_post". + + 2008-01-10 Frédéric Bernon + * tcpip.h, tcpip.c: add tcpip_callback_with_block function for the task #7490 + "Add return value to sys_mbox_post". tcpip_callback is always defined as + "blocking" ("block" parameter = 1). + + 2008-01-10 Frédéric Bernon + * tcpip.h, tcpip.c, api.h, api_lib.c, api_msg.c, sockets.c: replace the field + netconn::mbox (sys_mbox_t) per netconn::sem (sys_sem_t) for the task #7490 + "Add return value to sys_mbox_post". + + 2008-01-05 Frédéric Bernon + * sys_arch.txt, api.h, api_lib.c, api_msg.h, api_msg.c, tcpip.c, sys.h, opt.h: + Introduce changes for task #7490 "Add return value to sys_mbox_post" with some + modifications in the sys_mbox api: sys_mbox_new take a "size" parameters which + indicate the number of pointers query by the mailbox. There is three defines + in opt.h to indicate sizes for tcpip::mbox, netconn::recvmbox, and for the + netconn::acceptmbox. Port maintainers, you can decide to just add this new + parameter in your implementation, but to ignore it to keep the previous behavior. + The new sys_mbox_trypost function return a value to know if the mailbox is + full or if the message is posted. Take a look to sys_arch.txt for more details. + This new function is used in tcpip_input (so, can be called in an interrupt + context since the function is not blocking), and in recv_udp and recv_raw. + + 2008-01-04 Frédéric Bernon, Simon Goldschmidt, Jonathan Larmour + * rawapi.txt, api.h, api_lib.c, api_msg.h, api_msg.c, sockets.c, tcp.h, tcp.c, + tcp_in.c, init.c, opt.h: rename backlog options with TCP_ prefix, limit the + "backlog" parameter in an u8_t, 0 is interpreted as "smallest queue", add + documentation in the rawapi.txt file. + + 2007-12-31 Kieran Mansley (based on patch from Per-Henrik Lundbolm) + * tcp.c, tcp_in.c, tcp_out.c, tcp.h: Add TCP persist timer + + 2007-12-31 Frédéric Bernon, Luca Ceresoli + * autoip.c, etharp.c: ip_addr.h: Integrate patch #6348: "Broadcast ARP packets + in autoip". The change in etharp_raw could be removed, since all calls to + etharp_raw use ethbroadcast for the "ethdst_addr" parameter. But it could be + wrong in the future. + + 2007-12-30 Frédéric Bernon, Tom Evans + * ip.c: Fix bug #21846 "LwIP doesn't appear to perform any IP Source Address + Filtering" reported by Tom Evans. + + 2007-12-21 Frédéric Bernon, Simon Goldschmidt, Jonathan Larmour + * tcp.h, opt.h, api.h, api_msg.h, tcp.c, tcp_in.c, api_lib.c, api_msg.c, + sockets.c, init.c: task #7252: Implement TCP listen backlog: Warning: raw API + applications have to call 'tcp_accepted(pcb)' in their accept callback to + keep accepting new connections. + + 2007-12-13 Frédéric Bernon + * api_msg.c, err.h, err.c, sockets.c, dns.c, dns.h: replace "enum dns_result" + by err_t type. Add a new err_t code "ERR_INPROGRESS". + + 2007-12-12 Frédéric Bernon + * dns.h, dns.c, opt.h: move DNS options to the "right" place. Most visibles + are the one which have ram usage. + + 2007-12-05 Frédéric Bernon + * netdb.c: add a LWIP_DNS_API_HOSTENT_STORAGE option to decide to use a static + set of variables (=0) or a local one (=1). In this last case, your port should + provide a function "struct hostent* sys_thread_hostent( struct hostent* h)" + which have to do a copy of "h" and return a pointer ont the "per-thread" copy. + + 2007-12-03 Simon Goldschmidt + * ip.c: ip_input: check if a packet is for inp first before checking all other + netifs on netif_list (speeds up packet receiving in most cases) + + 2007-11-30 Simon Goldschmidt + * udp.c, raw.c: task #7497: Sort lists (pcb, netif, ...) for faster access + UDP: move a (connected) pcb selected for input to the front of the list of + pcbs so that it is found faster next time. Same for RAW pcbs that have eaten + a packet. + + 2007-11-28 Simon Goldschmidt + * etharp.c, stats.c, stats.h, opt.h: Introduced ETHARP_STATS + + 2007-11-25 Simon Goldschmidt + * dhcp.c: dhcp_unfold_reply() uses pbuf_copy_partial instead of its own copy + algorithm. + + 2007-11-24 Simon Goldschmidt + * netdb.h, netdb.c, sockets.h/.c: Moved lwip_gethostbyname from sockets.c + to the new file netdb.c; included lwip_getaddrinfo. + + 2007-11-21 Simon Goldschmidt + * tcp.h, opt.h, tcp.c, tcp_in.c: implemented calculating the effective send-mss + based on the MTU of the netif used to send. Enabled by default. Disable by + setting LWIP_CALCULATE_EFF_SEND_MSS to 0. This fixes bug #21492. + + 2007-11-19 Frédéric Bernon + * api_msg.c, dns.h, dns.c: Implement DNS_DOES_NAME_CHECK option (check if name + received match the name query), implement DNS_USES_STATIC_BUF (the place where + copy dns payload to parse the response), return an error if there is no place + for a new query, and fix some minor problems. + + 2007-11-16 Simon Goldschmidt + * new files: ipv4/inet.c, ipv4/inet_chksum.c, ipv6/inet6.c + removed files: core/inet.c, core/inet6.c + Moved inet files into ipv4/ipv6 directory; splitted inet.c/inet.h into + inet and chksum part; changed includes in all lwIP files as appropriate + + 2007-11-16 Simon Goldschmidt + * api.h, api_msg.h, api_lib.c, api_msg.c, socket.h, socket.c: Added sequential + dns resolver function for netconn api (netconn_gethostbyname) and socket api + (gethostbyname/gethostbyname_r). + + 2007-11-15 Jim Pettinato, Frédéric Bernon + * opt.h, init.c, tcpip.c, dhcp.c, dns.h, dns.c: add DNS client for simple name + requests with RAW api interface. Initialization is done in lwip_init() with + build time options. DNS timer is added in tcpip_thread context. DHCP can set + DNS server ip addresses when options are received. You need to set LWIP_DNS=1 + in your lwipopts.h file (LWIP_DNS=0 in opt.h). DNS_DEBUG can be set to get + some traces with LWIP_DEBUGF. Sanity check have been added. There is a "todo" + list with points to improve. + + 2007-11-06 Simon Goldschmidt + * opt.h, mib2.c: Patch #6215: added ifAdminStatus write support (if explicitly + enabled by defining SNMP_SAFE_REQUESTS to 0); added code to check link status + for ifOperStatus if LWIP_NETIF_LINK_CALLBACK is defined. + + 2007-11-06 Simon Goldschmidt + * api.h, api_msg.h and dependent files: Task #7410: Removed the need to include + core header files in api.h (ip/tcp/udp/raw.h) to hide the internal + implementation from netconn api applications. + + 2007-11-03 Frédéric Bernon + * api.h, api_lib.c, api_msg.c, sockets.c, opt.h: add SO_RCVBUF option for UDP & + RAW netconn. You need to set LWIP_SO_RCVBUF=1 in your lwipopts.h (it's disabled + by default). Netconn API users can use the netconn_recv_bufsize macro to access + it. This is a first release which have to be improve for TCP. Note it used the + netconn::recv_avail which need to be more "thread-safe" (note there is already + the problem for FIONREAD with lwip_ioctl/ioctlsocket). + + 2007-11-01 Frédéric Bernon, Marc Chaland + * sockets.h, sockets.c, api.h, api_lib.c, api_msg.h, api_msg.c, tcp.h, tcp_out.c: + Integrate "patch #6250 : MSG_MORE flag for send". MSG_MORE is used at socket api + layer, NETCONN_MORE at netconn api layer, and TCP_WRITE_FLAG_MORE at raw api + layer. This option enable to delayed TCP PUSH flag on multiple "write" calls. + Note that previous "copy" parameter for "write" APIs is now called "apiflags". + + 2007-10-24 Frédéric Bernon + * api.h, api_lib.c, api_msg.c: Add macro API_EVENT in the same spirit than + TCP_EVENT_xxx macros to get a code more readable. It could also help to remove + some code (like we have talk in "patch #5919 : Create compile switch to remove + select code"), but it could be done later. + + 2007-10-08 Simon Goldschmidt + * many files: Changed initialization: many init functions are not needed any + more since we now rely on the compiler initializing global and static + variables to zero! + + 2007-10-06 Simon Goldschmidt + * ip_frag.c, memp.c, mib2.c, ip_frag.h, memp_std.h, opt.h: Changed IP_REASSEMBLY + to enqueue the received pbufs so that multiple packets can be reassembled + simultaneously and no static reassembly buffer is needed. + + 2007-10-05 Simon Goldschmidt + * tcpip.c, etharp.h, etharp.c: moved ethernet_input from tcpip.c to etharp.c so + all netifs (or ports) can use it. + + 2007-10-05 Frédéric Bernon + * netifapi.h, netifapi.c: add function netifapi_netif_set_default. Change the + common function to reduce a little bit the footprint (for all functions using + only the "netif" parameter). + + 2007-10-03 Frédéric Bernon + * netifapi.h, netifapi.c: add functions netifapi_netif_set_up, netifapi_netif_set_down, + netifapi_autoip_start and netifapi_autoip_stop. Use a common function to reduce + a little bit the footprint (for all functions using only the "netif" parameter). + + 2007-09-15 Frédéric Bernon + * udp.h, udp.c, sockets.c: Changes for "#20503 IGMP Improvement". Add IP_MULTICAST_IF + option in socket API, and a new field "multicast_ip" in "struct udp_pcb" (for + netconn and raw API users), only if LWIP_IGMP=1. Add getsockopt processing for + IP_MULTICAST_TTL and IP_MULTICAST_IF. + + 2007-09-10 Frédéric Bernon + * snmp.h, mib2.c: enable to remove SNMP timer (which consumne several cycles + even when it's not necessary). snmp_agent.txt tell to call snmp_inc_sysuptime() + each 10ms (but, it's intrusive if you use sys_timeout feature). Now, you can + decide to call snmp_add_sysuptime(100) each 1000ms (which is bigger "step", but + call to a lower frequency). Or, you can decide to not call snmp_inc_sysuptime() + or snmp_add_sysuptime(), and to define the SNMP_GET_SYSUPTIME(sysuptime) macro. + This one is undefined by default in mib2.c. SNMP_GET_SYSUPTIME is called inside + snmp_get_sysuptime(u32_t *value), and enable to change "sysuptime" value only + when it's queried (any direct call to "sysuptime" is changed by a call to + snmp_get_sysuptime). + + 2007-09-09 Frédéric Bernon, Bill Florac + * igmp.h, igmp.c, netif.h, netif.c, ip.c: To enable to have interfaces with IGMP, + and others without it, there is a new NETIF_FLAG_IGMP flag to set in netif->flags + if you want IGMP on an interface. igmp_stop() is now called inside netif_remove(). + igmp_report_groups() is now called inside netif_set_link_up() (need to have + LWIP_NETIF_LINK_CALLBACK=1) to resend reports once the link is up (avoid to wait + the next query message to receive the matching multicast streams). + + 2007-09-08 Frédéric Bernon + * sockets.c, ip.h, api.h, tcp.h: declare a "struct ip_pcb" which only contains + IP_PCB. Add in the netconn's "pcb" union a "struct ip_pcb *ip;" (no size change). + Use this new field to access to common pcb fields (ttl, tos, so_options, etc...). + Enable to access to these fields with LWIP_TCP=0. + + 2007-09-05 Frédéric Bernon + * udp.c, ipv4/icmp.c, ipv4/ip.c, ipv6/icmp.c, ipv6/ip6.c, ipv4/icmp.h, + ipv6/icmp.h, opt.h: Integrate "task #7272 : LWIP_ICMP option". The new option + LWIP_ICMP enable/disable ICMP module inside the IP stack (enable per default). + Be careful, disabling ICMP make your product non-compliant to RFC1122, but + help to reduce footprint, and to reduce "visibility" on the Internet. + + 2007-09-05 Frédéric Bernon, Bill Florac + * opt.h, sys.h, tcpip.c, slipif.c, ppp.c, sys_arch.txt: Change parameters list + for sys_thread_new (see "task #7252 : Create sys_thread_new_ex()"). Two new + parameters have to be provided: a task name, and a task stack size. For this + one, since it's platform dependant, you could define the best one for you in + your lwipopts.h. For port maintainers, you can just add these new parameters + in your sys_arch.c file, and but it's not mandatory, use them in your OS + specific functions. + + 2007-09-05 Frédéric Bernon + * inet.c, autoip.c, msg_in.c, msg_out.c, init.c: Move some build time checkings + inside init.c for task #7142 "Sanity check user-configurable values". + + 2007-09-04 Frédéric Bernon, Bill Florac + * igmp.h, igmp.c, memp_std.h, memp.c, init.c, opt.h: Replace mem_malloc call by + memp_malloc, and use a new MEMP_NUM_IGMP_GROUP option (see opt.h to define the + value). It will avoid potential fragmentation problems, use a counter to know + how many times a group is used on an netif, and free it when all applications + leave it. MEMP_NUM_IGMP_GROUP got 8 as default value (and init.c got a sanity + check if LWIP_IGMP!=0). + + 2007-09-03 Frédéric Bernon + * igmp.h, igmp.c, sockets.c, api_msg.c: Changes for "#20503 IGMP Improvement". + Initialize igmp_mac_filter to NULL in netif_add (this field should be set in + the netif's "init" function). Use the "imr_interface" field (for socket layer) + and/or the "interface" field (for netconn layer), for join/leave operations. + The igmp_join/leavegroup first parameter change from a netif to an ipaddr. + This field could be a netif's ipaddr, or "any" (same meaning than ip_addr_isany). + + 2007-08-30 Frédéric Bernon + * Add netbuf.h, netbuf.c, Change api.h, api_lib.c: #7249 "Split netbuf functions + from api/api_lib". Now netbuf API is independant of netconn, and can be used + with other API (application based on raw API, or future "socket2" API). Ports + maintainers just have to add src/api/netbuf.c in their makefile/projects. + + 2007-08-30 Frédéric Bernon, Jonathan Larmour + * init.c: Add first version of lwip_sanity_check for task #7142 "Sanity check + user-configurable values". + + 2007-08-29 Frédéric Bernon + * igmp.h, igmp.c, tcpip.c, init.c, netif.c: change igmp_init and add igmp_start. + igmp_start is call inside netif_add. Now, igmp initialization is in the same + spirit than the others modules. Modify some IGMP debug traces. + + 2007-08-29 Frédéric Bernon + * Add init.h, init.c, Change opt.h, tcpip.c: Task #7213 "Add a lwip_init function" + Add lwip_init function to regroup all modules initializations, and to provide + a place to add code for task #7142 "Sanity check user-configurable values". + Ports maintainers should remove direct initializations calls from their code, + and add init.c in their makefiles. Note that lwip_init() function is called + inside tcpip_init, but can also be used by raw api users since all calls are + disabled when matching options are disabled. Also note that their is new options + in opt.h, you should configure in your lwipopts.h (they are enabled per default). + + 2007-08-26 Marc Boucher + * api_msg.c: do_close_internal(): Reset the callbacks and arg (conn) to NULL + since they can under certain circumstances be called with an invalid conn + pointer after the connection has been closed (and conn has been freed). + + 2007-08-25 Frédéric Bernon (Artem Migaev's Patch) + * netif.h, netif.c: Integrate "patch #6163 : Function to check if link layer is up". + Add a netif_is_link_up() function if LWIP_NETIF_LINK_CALLBACK option is set. + + 2007-08-22 Frédéric Bernon + * netif.h, netif.c, opt.h: Rename LWIP_NETIF_CALLBACK in LWIP_NETIF_STATUS_CALLBACK + to be coherent with new LWIP_NETIF_LINK_CALLBACK option before next release. + + 2007-08-22 Frédéric Bernon + * tcpip.h, tcpip.c, ethernetif.c, opt.h: remove options ETHARP_TCPIP_INPUT & + ETHARP_TCPIP_ETHINPUT, now, only "ethinput" code is supported, even if the + name is tcpip_input (we keep the name of 1.2.0 function). + + 2007-08-17 Jared Grubb + * memp_std.h, memp.h, memp.c, mem.c, stats.c: (Task #7136) Centralize mempool + settings into new memp_std.h and optional user file lwippools.h. This adds + more dynamic mempools, and allows the user to create an arbitrary number of + mempools for mem_malloc. + + 2007-08-16 Marc Boucher + * api_msg.c: Initialize newconn->state to NETCONN_NONE in accept_function; + otherwise it was left to NETCONN_CLOSE and sent_tcp() could prematurely + close the connection. + + 2007-08-16 Marc Boucher + * sockets.c: lwip_accept(): check netconn_peer() error return. + + 2007-08-16 Marc Boucher + * mem.c, mem.h: Added mem_calloc(). + + 2007-08-16 Marc Boucher + * tcpip.c, tcpip.h memp.c, memp.h: Added distinct memp (MEMP_TCPIP_MSG_INPKT) + for input packets to prevent floods from consuming all of MEMP_TCPIP_MSG + and starving other message types. + Renamed MEMP_TCPIP_MSG to MEMP_TCPIP_MSG_API + + 2007-08-16 Marc Boucher + * pbuf.c, pbuf.h, etharp.c, tcp_in.c, sockets.c: Split pbuf flags in pbuf + type and flgs (later renamed to flags). + Use enum pbuf_flag as pbuf_type. Renumber PBUF_FLAG_*. + Improved lwip_recvfrom(). TCP push now propagated. + + 2007-08-16 Marc Boucher + * ethernetif.c, contrib/ports/various: ethbroadcast now a shared global + provided by etharp. + + 2007-08-16 Marc Boucher + * ppp_oe.c ppp_oe.h, auth.c chap.c fsm.c lcp.c ppp.c ppp.h, + etharp.c ethernetif.c, etharp.h, opt.h tcpip.h, tcpip.c: + Added PPPoE support and various PPP improvements. + + 2007-07-25 Simon Goldschmidt + * api_lib.c, ip_frag.c, pbuf.c, api.h, pbuf.h: Introduced pbuf_copy_partial, + making netbuf_copy_partial use this function. + + 2007-07-25 Simon Goldschmidt + * tcp_in.c: Fix bug #20506: Slow start / initial congestion window starts with + 2 * mss (instead of 1 * mss previously) to comply with some newer RFCs and + other stacks. + + 2007-07-13 Jared Grubb (integrated by Frédéric Bernon) + * opt.h, netif.h, netif.c, ethernetif.c: Add new configuration option to add + a link callback in the netif struct, and functions to handle it. Be carefull + for port maintainers to add the NETIF_FLAG_LINK_UP flag (like in ethernetif.c) + if you want to be sure to be compatible with future changes... + + 2007-06-30 Frédéric Bernon + * sockets.h, sockets.c: Implement MSG_PEEK flag for recv/recvfrom functions. + + 2007-06-21 Simon Goldschmidt + * etharp.h, etharp.c: Combined etharp_request with etharp_raw for both + LWIP_AUTOIP =0 and =1 to remove redundant code. + + 2007-06-21 Simon Goldschmidt + * mem.c, memp.c, mem.h, memp.h, opt.h: task #6863: Introduced the option + MEM_USE_POOLS to use 4 pools with different sized elements instead of a + heap. This both prevents memory fragmentation and gives a higher speed + at the cost of more memory consumption. Turned off by default. + + 2007-06-21 Simon Goldschmidt + * api_lib.c, api_msg.c, api.h, api_msg.h: Converted the length argument of + netconn_write (and therefore also api_msg_msg.msg.w.len) from u16_t into + int to be able to send a bigger buffer than 64K with one time (mainly + used from lwip_send). + + 2007-06-21 Simon Goldschmidt + * tcp.h, api_msg.c: Moved the nagle algorithm from netconn_write/do_write + into a define (tcp_output_nagle) in tcp.h to provide it to raw api users, too. + + 2007-06-21 Simon Goldschmidt + * api.h, api_lib.c, api_msg.c: Fixed bug #20021: Moved sendbuf-processing in + netconn_write from api_lib.c to api_msg.c to also prevent multiple context- + changes on low memory or empty send-buffer. + + 2007-06-18 Simon Goldschmidt + * etharp.c, etharp.h: Changed etharp to use a defined hardware address length + of 6 to avoid loading netif->hwaddr_len every time (since this file is only + used for ethernet and struct eth_addr already had a defined length of 6). + + 2007-06-17 Simon Goldschmidt + * sockets.c, sockets.h: Implemented socket options SO_NO_CHECK for UDP sockets + to disable UDP checksum generation on transmit. + + 2007-06-13 Frédéric Bernon, Simon Goldschmidt + * debug.h, api_msg.c: change LWIP_ERROR to use it to check errors like invalid + pointers or parameters, and let the possibility to redefined it in cc.h. Use + this macro to check "conn" parameter in api_msg.c functions. + + 2007-06-11 Simon Goldschmidt + * sockets.c, sockets.h: Added UDP lite support for sockets + + 2007-06-10 Simon Goldschmidt + * udp.h, opt.h, api_msg.c, ip.c, udp.c: Included switch LWIP_UDPLITE (enabled + by default) to switch off UDP-Lite support if not needed (reduces udp.c code + size) + + 2007-06-09 Dominik Spies (integrated by Frédéric Bernon) + * autoip.h, autoip.c, dhcp.h, dhcp.c, netif.h, netif.c, etharp.h, etharp.c, opt.h: + AutoIP implementation available for IPv4, with new options LWIP_AUTOIP and + LWIP_DHCP_AUTOIP_COOP if you want to cooperate with DHCP. Some tips to adapt + (see TODO mark in the source code). + + 2007-06-09 Simon Goldschmidt + * etharp.h, etharp.c, ethernetif.c: Modified order of parameters for + etharp_output() to match netif->output so etharp_output() can be used + directly as netif->output to save one function call. + + 2007-06-08 Simon Goldschmidt + * netif.h, ethernetif.c, slipif.c, loopif.c: Added define + NETIF_INIT_SNMP(netif, type, speed) to initialize per-netif snmp variables, + added initialization of those to ethernetif, slipif and loopif. + + 2007-05-18 Simon Goldschmidt + * opt.h, ip_frag.c, ip_frag.h, ip.c: Added option IP_FRAG_USES_STATIC_BUF + (defaulting to off for now) that can be set to 0 to send fragmented + packets by passing PBUF_REFs down the stack. + + 2007-05-23 Frédéric Bernon + * api_lib.c: Implement SO_RCVTIMEO for accept and recv on TCP + connections, such present in patch #5959. + + 2007-05-23 Frédéric Bernon + * api.h, api_lib.c, api_msg.c, sockets.c: group the different NETCONN_UDPxxx + code in only one part... + + 2007-05-18 Simon Goldschmidt + * opt.h, memp.h, memp.c: Added option MEMP_OVERFLOW_CHECK to check for memp + elements to overflow. This is achieved by adding some bytes before and after + each pool element (increasing their size, of course), filling them with a + prominent value and checking them on freeing the element. + Set it to 2 to also check every element in every pool each time memp_malloc() + or memp_free() is called (slower but more helpful). + + 2007-05-10 Simon Goldschmidt + * opt.h, memp.h, memp.c, pbuf.c (see task #6831): use a new memp pool for + PBUF_POOL pbufs instead of the old pool implementation in pbuf.c to reduce + code size. + + 2007-05-11 Frédéric Bernon + * sockets.c, api_lib.c, api_msg.h, api_msg.c, netifapi.h, netifapi.c, tcpip.c: + Include a function pointer instead of a table index in the message to reduce + footprint. Disable some part of lwip_send and lwip_sendto if some options are + not set (LWIP_TCP, LWIP_UDP, LWIP_RAW). + + 2007-05-10 Simon Goldschmidt + * *.h (except netif/ppp/*.h): Included patch #5448: include '#ifdef __cplusplus + \ extern "C" {' in all header files. Now you can write your application using + the lwIP stack in C++ and simply #include the core files. Note I have left + out the netif/ppp/*h header files for now, since I don't know which files are + included by applications and which are for internal use only. + + 2007-05-09 Simon Goldschmidt + * opt.h, *.c/*.h: Included patch #5920: Create define to override C-library + memcpy. 2 Defines are created: MEMCPY() for normal memcpy, SMEMCPY() for + situations where some compilers might inline the copy and save a function + call. Also replaced all calls to memcpy() with calls to (S)MEMCPY(). + + 2007-05-08 Simon Goldschmidt + * mem.h: If MEM_LIBC_MALLOC==1, allow the defines (e.g. mem_malloc() -> malloc()) + to be overriden in case the C-library malloc implementation is not protected + against concurrent access. + + 2007-05-04 Simon Goldschmidt (Atte Kojo) + * etharp.c: Introduced fast one-entry-cache to speed up ARP lookup when sending + multiple packets to the same host. + + 2007-05-04 Frédéric Bernon, Jonathan Larmour + * sockets.c, api.h, api_lib.c, api_msg.h, api_msg.c: Fix bug #19162 "lwip_sento: a possible + to corrupt remote addr/port connection state". Reduce problems "not enought memory" with + netbuf (if we receive lot of datagrams). Improve lwip_sendto (only one exchange between + sockets api and api_msg which run in tcpip_thread context). Add netconn_sento function. + Warning, if you directly access to "fromaddr" & "fromport" field from netbuf struct, + these fields are now renamed "addr" & "port". + + 2007-04-11 Jonathan Larmour + * sys.h, api_lib.c: Provide new sys_mbox_tryfetch function. Require ports to provide new + sys_arch_mbox_tryfetch function to get a message if one is there, otherwise return + with SYS_MBOX_EMPTY. sys_arch_mbox_tryfetch can be implemented as a function-like macro + by the port in sys_arch.h if desired. + + 2007-04-06 Frédéric Bernon, Simon Goldschmidt + * opt.h, tcpip.h, tcpip.c, netifapi.h, netifapi.c: New configuration option LWIP_NETIF_API + allow to use thread-safe functions to add/remove netif in list, and to start/stop dhcp + clients, using new functions from netifapi.h. Disable as default (no port change to do). + + 2007-04-05 Frédéric Bernon + * sockets.c: remplace ENOBUFS errors on alloc_socket by ENFILE to be more BSD compliant. + + 2007-04-04 Simon Goldschmidt + * arch.h, api_msg.c, dhcp.c, msg_in.c, sockets.c: Introduced #define LWIP_UNUSED_ARG(x) + use this for and architecture-independent form to tell the compiler you intentionally + are not using this variable. Can be overriden in cc.h. + + 2007-03-28 Frédéric Bernon + * opt.h, netif.h, dhcp.h, dhcp.c: New configuration option LWIP_NETIF_HOSTNAME allow to + define a hostname in netif struct (this is just a pointer, so, you can use a hardcoded + string, point on one of your's ethernetif field, or alloc a string you will free yourself). + It will be used by DHCP to register a client hostname, but can also be use when you call + snmp_set_sysname. + + 2007-03-28 Frédéric Bernon + * netif.h, netif.c: A new NETIF_FLAG_ETHARP flag is defined in netif.h, to allow to + initialize a network interface's flag with. It tell this interface is an ethernet + device, and we can use ARP with it to do a "gratuitous ARP" (RFC 3220 "IP Mobility + Support for IPv4" section 4.6) when interface is "up" with netif_set_up(). + + 2007-03-26 Frédéric Bernon, Jonathan Larmour + * opt.h, tcpip.c: New configuration option LWIP_ARP allow to disable ARP init at build + time if you only use PPP or SLIP. The default is enable. Note we don't have to call + etharp_init in your port's initilization sequence if you use tcpip.c, because this call + is done in tcpip_init function. + + 2007-03-22 Frédéric Bernon + * stats.h, stats.c, msg_in.c: Stats counters can be change to u32_t if necessary with the + new option LWIP_STATS_LARGE. If you need this option, define LWIP_STATS_LARGE to 1 in + your lwipopts.h. More, unused counters are not defined in the stats structs, and not + display by stats_display(). Note that some options (SYS_STATS and RAW_STATS) are defined + but never used. Fix msg_in.c with the correct #if test for a stat display. + + 2007-03-21 Kieran Mansley + * netif.c, netif.h: Apply patch#4197 with some changes (originator: rireland@hmgsl.com). + Provides callback on netif up/down state change. + + 2007-03-11 Frédéric Bernon, Mace Gael, Steve Reynolds + * sockets.h, sockets.c, api.h, api_lib.c, api_msg.h, api_msg.c, igmp.h, igmp.c, + ip.c, netif.h, tcpip.c, opt.h: + New configuration option LWIP_IGMP to enable IGMP processing. Based on only one + filter per all network interfaces. Declare a new function in netif to enable to + control the MAC filter (to reduce lwIP traffic processing). + + 2007-03-11 Frédéric Bernon + * tcp.h, tcp.c, sockets.c, tcp_out.c, tcp_in.c, opt.h: Keepalive values can + be configured at run time with LWIP_TCP_KEEPALIVE, but don't change this + unless you know what you're doing (default are RFC1122 compliant). Note + that TCP_KEEPIDLE and TCP_KEEPINTVL have to be set in seconds. + + 2007-03-08 Frédéric Bernon + * tcp.h: Keepalive values can be configured at compile time, but don't change + this unless you know what you're doing (default are RFC1122 compliant). + + 2007-03-08 Frédéric Bernon + * sockets.c, api.h, api_lib.c, tcpip.c, sys.h, sys.c, err.c, opt.h: + Implement LWIP_SO_RCVTIMEO configuration option to enable/disable SO_RCVTIMEO + on UDP sockets/netconn. + + 2007-03-08 Simon Goldschmidt + * snmp_msg.h, msg_in.c: SNMP UDP ports can be configured at compile time. + + 2007-03-06 Frédéric Bernon + * api.h, api_lib.c, sockets.h, sockets.c, tcpip.c, sys.h, sys.c, err.h: + Implement SO_RCVTIMEO on UDP sockets/netconn. + + 2007-02-28 Kieran Mansley (based on patch from Simon Goldschmidt) + * api_lib.c, tcpip.c, memp.c, memp.h: make API msg structs allocated + on the stack and remove the API msg type from memp + + 2007-02-26 Jonathan Larmour (based on patch from Simon Goldschmidt) + * sockets.h, sockets.c: Move socket initialization to new + lwip_socket_init() function. + NOTE: this changes the API with ports. Ports will have to be + updated to call lwip_socket_init() now. + + 2007-02-26 Jonathan Larmour (based on patch from Simon Goldschmidt) + * api_lib.c: Use memcpy in netbuf_copy_partial. + + + ++ Bug fixes: + + 2008-03-17 Frédéric Bernon, Ed Kerekes + * igmp.h, igmp.c: Fix bug #22613 "IGMP iphdr problem" (could have + some problems to fill the IP header on some targets, use now the + ip.h macros to do it). + + 2008-03-13 Frédéric Bernon + * sockets.c: Fix bug #22435 "lwip_recvfrom with TCP break;". Using + (lwip_)recvfrom with valid "from" and "fromlen" parameters, on a + TCP connection caused a crash. Note that using (lwip_)recvfrom + like this is a bit slow and that using (lwip)getpeername is the + good lwip way to do it (so, using recv is faster on tcp sockets). + + 2008-03-12 Frédéric Bernon, Jonathan Larmour + * api_msg.c, contrib/apps/ping.c: Fix bug #22530 "api_msg.c's + recv_raw() does not consume data", and the ping sample (with + LWIP_SOCKET=1, the code did the wrong supposition that lwip_recvfrom + returned the IP payload, without the IP header). + + 2008-03-04 Jonathan Larmour + * mem.c, stats.c, mem.h: apply patch #6414 to avoid compiler errors + and/or warnings on some systems where mem_size_t and size_t differ. + * pbuf.c, ppp.c: Fix warnings on some systems with mem_malloc. + + 2008-03-04 Kieran Mansley (contributions by others) + * Numerous small compiler error/warning fixes from contributions to + mailing list after 1.3.0 release candidate made. + + 2008-01-25 Cui hengbin (integrated by Frédéric Bernon) + * dns.c: Fix bug #22108 "DNS problem" caused by unaligned structures. + + 2008-01-15 Kieran Mansley + * tcp_out.c: BUG20511. Modify persist timer to start when we are + prevented from sending by a small send window, not just a zero + send window. + + 2008-01-09 Jonathan Larmour + * opt.h, ip.c: Rename IP_OPTIONS define to IP_OPTIONS_ALLOWED to avoid + conflict with Linux system headers. + + 2008-01-06 Jonathan Larmour + * dhcp.c: fix bug #19927: "DHCP NACK problem" by clearing any existing set IP + address entirely on receiving a DHCPNAK, and restarting discovery. + + 2007-12-21 Simon Goldschmidt + * sys.h, api_lib.c, api_msg.c, sockets.c: fix bug #21698: "netconn->recv_avail + is not protected" by using new macros for interlocked access to modify/test + netconn->recv_avail. + + 2007-12-20 Kieran Mansley (based on patch from Oleg Tyshev) + * tcp_in.c: fix bug# 21535 (nrtx not reset correctly in SYN_SENT state) + + 2007-12-20 Kieran Mansley (based on patch from Per-Henrik Lundbolm) + * tcp.c, tcp_in.c, tcp_out.c, tcp.h: fix bug #20199 (better handling + of silly window avoidance and prevent lwIP from shrinking the window) + + 2007-12-04 Simon Goldschmidt + * tcp.c, tcp_in.c: fix bug #21699 (segment leak in ooseq processing when last + data packet was lost): add assert that all segment lists are empty in + tcp_pcb_remove before setting pcb to CLOSED state; don't directly set CLOSED + state from LAST_ACK in tcp_process + + 2007-12-02 Simon Goldschmidt + * sockets.h: fix bug #21654: exclude definition of struct timeval from #ifndef FD_SET + If including <sys/time.h> for system-struct timeval, LWIP_TIMEVAL_PRIVATE now + has to be set to 0 in lwipopts.h + + 2007-12-02 Simon Goldschmidt + * api_msg.c, api_lib.c: fix bug #21656 (recvmbox problem in netconn API): always + allocate a recvmbox in netconn_new_with_proto_and_callback. For a tcp-listen + netconn, this recvmbox is later freed and a new mbox is allocated for acceptmbox. + This is a fix for thread-safety and allocates all items needed for a netconn + when the netconn is created. + + 2007-11-30 Simon Goldschmidt + * udp.c: first attempt to fix bug #21655 (DHCP doesn't work reliably with multiple + netifs): if LWIP_DHCP is enabled, UDP packets to DHCP_CLIENT_PORT are passed + to netif->dhcp->pcb only (if that exists) and not to any other pcb for the same + port (only solution to let UDP pcbs 'bind' to a netif instead of an IP address) + + 2007-11-27 Simon Goldschmidt + * ip.c: fixed bug #21643 (udp_send/raw_send don't fail if netif is down) by + letting ip_route only use netifs that are up. + + 2007-11-27 Simon Goldschmidt + * err.h, api_lib.c, api_msg.c, sockets.c: Changed error handling: ERR_MEM, ERR_BUF + and ERR_RTE are seen as non-fatal, all other errors are fatal. netconns and + sockets block most operations once they have seen a fatal error. + + 2007-11-27 Simon Goldschmidt + * udp.h, udp.c, dhcp.c: Implemented new function udp_sendto_if which takes the + netif to send as an argument (to be able to send on netifs that are down). + + 2007-11-26 Simon Goldschmidt + * tcp_in.c: Fixed bug #21582: pcb->acked accounting can be wrong when ACKs + arrive out-of-order + + 2007-11-21 Simon Goldschmidt + * tcp.h, tcp_out.c, api_msg.c: Fixed bug #20287: tcp_output_nagle sends too early + Fixed the nagle algorithm; nagle now also works for all raw API applications + and has to be explicitly disabled with 'tcp_pcb->flags |= TF_NODELAY' + + 2007-11-12 Frédéric Bernon + * sockets.c, api.h, api_lib.c, api_msg.h, api_msg.c: Fixed bug #20900. Now, most + of the netconn_peer and netconn_addr processing is done inside tcpip_thread + context in do_getaddr. + + 2007-11-10 Simon Goldschmidt + * etharp.c: Fixed bug: assert fired when MEMP_ARP_QUEUE was empty (which can + happen any time). Now the packet simply isn't enqueued when out of memory. + + 2007-11-01 Simon Goldschmidt + * tcp.c, tcp_in.c: Fixed bug #21494: The send mss (pcb->mss) is set to 536 (or + TCP_MSS if that is smaller) as long as no MSS option is received from the + remote host. + + 2007-11-01 Simon Goldschmidt + * tcp.h, tcp.c, tcp_in.c: Fixed bug #21491: The MSS option sent (with SYN) + is now based on TCP_MSS instead of pcb->mss (on passive open now effectively + sending our configured TCP_MSS instead of the one received). + + 2007-11-01 Simon Goldschmidt + * tcp_in.c: Fixed bug #21181: On active open, the initial congestion window was + calculated based on the configured TCP_MSS, not on the MSS option received + with SYN+ACK. + + 2007-10-09 Simon Goldschmidt + * udp.c, inet.c, inet.h: Fixed UDPLite: send: Checksum was always generated too + short and also was generated wrong if checksum coverage != tot_len; + receive: checksum was calculated wrong if checksum coverage != tot_len + + 2007-10-08 Simon Goldschmidt + * mem.c: lfree was not updated in mem_realloc! + + 2007-10-07 Frédéric Bernon + * sockets.c, api.h, api_lib.c: First step to fix "bug #20900 : Potential + crash error problem with netconn_peer & netconn_addr". VERY IMPORTANT: + this change cause an API breakage for netconn_addr, since a parameter + type change. Any compiler should cause an error without any changes in + yours netconn_peer calls (so, it can't be a "silent change"). It also + reduce a little bit the footprint for socket layer (lwip_getpeername & + lwip_getsockname use now a common lwip_getaddrname function since + netconn_peer & netconn_addr have the same parameters). + + 2007-09-20 Simon Goldschmidt + * tcp.c: Fixed bug #21080 (tcp_bind without check pcbs in TIME_WAIT state) + by checking tcp_tw_pcbs also + + 2007-09-19 Simon Goldschmidt + * icmp.c: Fixed bug #21107 (didn't reset IP TTL in ICMP echo replies) + + 2007-09-15 Mike Kleshov + * mem.c: Fixed bug #21077 (inaccuracy in calculation of lwip_stat.mem.used) + + 2007-09-06 Frédéric Bernon + * several-files: replace some #include "arch/cc.h" by "lwip/arch.h", or simply remove + it as long as "lwip/opt.h" is included before (this one include "lwip/debug.h" which + already include "lwip/arch.h"). Like that, default defines are provided by "lwip/arch.h" + if they are not defined in cc.h, in the same spirit than "lwip/opt.h" for lwipopts.h. + + 2007-08-30 Frédéric Bernon + * igmp.h, igmp.c: Some changes to remove some redundant code, add some traces, + and fix some coding style. + + 2007-08-28 Frédéric Bernon + * tcpip.c: Fix TCPIP_MSG_INPKT processing: now, tcpip_input can be used for any + kind of packets. These packets are considered like Ethernet packets (payload + pointing to ethhdr) if the netif got the NETIF_FLAG_ETHARP flag. Else, packets + are considered like IP packets (payload pointing to iphdr). + + 2007-08-27 Frédéric Bernon + * api.h, api_lib.c, api_msg.c: First fix for "bug #20900 : Potential crash error + problem with netconn_peer & netconn_addr". Introduce NETCONN_LISTEN netconn_state + and remove obsolete ones (NETCONN_RECV & NETCONN_ACCEPT). + + 2007-08-24 Kieran Mansley + * inet.c Modify (acc >> 16) test to ((acc >> 16) != 0) to help buggy + compiler (Paradigm C++) + + 2007-08-09 Frédéric Bernon, Bill Florac + * stats.h, stats.c, igmp.h, igmp.c, opt.h: Fix for bug #20503 : IGMP Improvement. + Introduce IGMP_STATS to centralize statistics management. + + 2007-08-09 Frédéric Bernon, Bill Florac + * udp.c: Fix for bug #20503 : IGMP Improvement. Enable to receive a multicast + packet on a udp pcb binded on an netif's IP address, and not on "any". + + 2007-08-09 Frédéric Bernon, Bill Florac + * igmp.h, igmp.c, ip.c: Fix minor changes from bug #20503 : IGMP Improvement. + This is mainly on using lookup/lookfor, and some coding styles... + + 2007-07-26 Frédéric Bernon (and "thedoctor") + * igmp.c: Fix bug #20595 to accept IGMPv3 "Query" messages. + + 2007-07-25 Simon Goldschmidt + * api_msg.c, tcp.c: Another fix for bug #20021: by not returning an error if + tcp_output fails in tcp_close, the code in do_close_internal gets simpler + (tcp_output is called again later from tcp timers). + + 2007-07-25 Simon Goldschmidt + * ip_frag.c: Fixed bug #20429: use the new pbuf_copy_partial instead of the old + copy_from_pbuf, which illegally modified the given pbuf. + + 2007-07-25 Simon Goldschmidt + * tcp_out.c: tcp_enqueue: pcb->snd_queuelen didn't work for chaine PBUF_RAMs: + changed snd_queuelen++ to snd_queuelen += pbuf_clen(p). + + 2007-07-24 Simon Goldschmidt + * api_msg.c, tcp.c: Fix bug #20480: Check the pcb passed to tcp_listen() for the + correct state (must be CLOSED). + + 2007-07-13 Thomas Taranowski (commited by Jared Grubb) + * memp.c: Fix bug #20478: memp_malloc returned NULL+MEMP_SIZE on failed + allocation. It now returns NULL. + + 2007-07-13 Frédéric Bernon + * api_msg.c: Fix bug #20318: api_msg "recv" callbacks don't call pbuf_free in + all error cases. + + 2007-07-13 Frédéric Bernon + * api_msg.c: Fix bug #20315: possible memory leak problem if tcp_listen failed, + because current code doesn't follow rawapi.txt documentation. + + 2007-07-13 Kieran Mansley + * src/core/tcp_in.c Apply patch#5741 from Oleg Tyshev to fix bug in + out of sequence processing of received packets + + 2007-07-03 Simon Goldschmidt + * nearly-all-files: Added assertions where PBUF_RAM pbufs are used and an + assumption is made that this pbuf is in one piece (i.e. not chained). These + assumptions clash with the possibility of converting to fully pool-based + pbuf implementations, where PBUF_RAM pbufs might be chained. + + 2007-07-03 Simon Goldschmidt + * api.h, api_lib.c, api_msg.c: Final fix for bug #20021 and some other problems + when closing tcp netconns: removed conn->sem, less context switches when + closing, both netconn_close and netconn_delete should safely close tcp + connections. + + 2007-07-02 Simon Goldschmidt + * ipv4/ip.h, ipv6/ip.h, opt.h, netif.h, etharp.h, ipv4/ip.c, netif.c, raw.c, + tcp_out.c, udp.c, etharp.c: Added option LWIP_NETIF_HWADDRHINT (default=off) + to cache ARP table indices with each pcb instead of single-entry cache for + the complete stack. + + 2007-07-02 Simon Goldschmidt + * tcp.h, tcp.c, tcp_in.c, tcp_out.c: Added some ASSERTS and casts to prevent + warnings when assigning to smaller types. + + 2007-06-28 Simon Goldschmidt + * tcp_out.c: Added check to prevent tcp_pcb->snd_queuelen from overflowing. + + 2007-06-28 Simon Goldschmidt + * tcp.h: Fixed bug #20287: Fixed nagle algorithm (sending was done too early if + a segment contained chained pbufs) + + 2007-06-28 Frédéric Bernon + * autoip.c: replace most of rand() calls by a macro LWIP_AUTOIP_RAND which compute + a "pseudo-random" value based on netif's MAC and some autoip fields. It's always + possible to define this macro in your own lwipopts.h to always use C library's + rand(). Note that autoip_create_rand_addr doesn't use this macro. + + 2007-06-28 Frédéric Bernon + * netifapi.h, netifapi.c, tcpip.h, tcpip.c: Update code to handle the option + LWIP_TCPIP_CORE_LOCKING, and do some changes to be coherent with last modifications + in api_lib/api_msg (use pointers and not type with table, etc...) + + 2007-06-26 Simon Goldschmidt + * udp.h: Fixed bug #20259: struct udp_hdr was lacking the packin defines. + + 2007-06-25 Simon Goldschmidt + * udp.c: Fixed bug #20253: icmp_dest_unreach was called with a wrong p->payload + for udp packets with no matching pcb. + + 2007-06-25 Simon Goldschmidt + * udp.c: Fixed bug #20220: UDP PCB search in udp_input(): a non-local match + could get udp input packets if the remote side matched. + + 2007-06-13 Simon Goldschmidt + * netif.c: Fixed bug #20180 (TCP pcbs listening on IP_ADDR_ANY could get + changed in netif_set_ipaddr if previous netif->ip_addr.addr was 0. + + 2007-06-13 Simon Goldschmidt + * api_msg.c: pcb_new sets conn->err if protocol is not implemented + -> netconn_new_..() does not allocate a new connection for unsupported + protocols. + + 2007-06-13 Frédéric Bernon, Simon Goldschmidt + * api_lib.c: change return expression in netconn_addr and netconn_peer, because + conn->err was reset to ERR_OK without any reasons (and error was lost)... + + 2007-06-13 Frédéric Bernon, Matthias Weisser + * opt.h, mem.h, mem.c, memp.c, pbuf.c, ip_frag.c, vj.c: Fix bug #20162. Rename + MEM_ALIGN in LWIP_MEM_ALIGN and MEM_ALIGN_SIZE in LWIP_MEM_ALIGN_SIZE to avoid + some macro names collision with some OS macros. + + 2007-06-11 Simon Goldschmidt + * udp.c: UDP Lite: corrected the use of chksum_len (based on RFC3828: if it's 0, + create checksum over the complete packet. On RX, if it's < 8 (and not 0), + discard the packet. Also removed the duplicate 'udphdr->chksum = 0' for both + UDP & UDP Lite. + + 2007-06-11 Srinivas Gollakota & Oleg Tyshev + * tcp_out.c: Fix for bug #20075 : "A problem with keep-alive timer and TCP flags" + where TCP flags wasn't initialized in tcp_keepalive. + + 2007-06-03 Simon Goldschmidt + * udp.c: udp_input(): Input pbuf was not freed if pcb had no recv function + registered, p->payload was modified without modifying p->len if sending + icmp_dest_unreach() (had no negative effect but was definitively wrong). + + 2007-06-03 Simon Goldschmidt + * icmp.c: Corrected bug #19937: For responding to an icmp echo request, icmp + re-used the input pbuf even if that didn't have enough space to include the + link headers. Now the space is tested and a new pbuf is allocated for the + echo response packet if the echo request pbuf isn't big enough. + + 2007-06-01 Simon Goldschmidt + * sockets.c: Checked in patch #5914: Moved sockopt processing into tcpip_thread. + + 2007-05-23 Frédéric Bernon + * api_lib.c, sockets.c: Fixed bug #5958 for netconn_listen (acceptmbox only + allocated by do_listen if success) and netconn_accept errors handling. In + most of api_lib functions, we replace some errors checkings like "if (conn==NULL)" + by ASSERT, except for netconn_delete. + + 2007-05-23 Frédéric Bernon + * api_lib.c: Fixed bug #5957 "Safe-thread problem inside netconn_recv" to return + an error code if it's impossible to fetch a pbuf on a TCP connection (and not + directly close the recvmbox). + + 2007-05-22 Simon Goldschmidt + * tcp.c: Fixed bug #1895 (tcp_bind not correct) by introducing a list of + bound but unconnected (and non-listening) tcp_pcbs. + + 2007-05-22 Frédéric Bernon + * sys.h, sys.c, api_lib.c, tcpip.c: remove sys_mbox_fetch_timeout() (was only + used for LWIP_SO_RCVTIMEO option) and use sys_arch_mbox_fetch() instead of + sys_mbox_fetch() in api files. Now, users SHOULD NOT use internal lwIP features + like "sys_timeout" in their application threads. + + 2007-05-22 Frédéric Bernon + * api.h, api_lib.c, api_msg.h, api_msg.c: change the struct api_msg_msg to see + which parameters are used by which do_xxx function, and to avoid "misusing" + parameters (patch #5938). + + 2007-05-22 Simon Goldschmidt + * api_lib.c, api_msg.c, raw.c, api.h, api_msg.h, raw.h: Included patch #5938: + changed raw_pcb.protocol from u16_t to u8_t since for IPv4 and IPv6, proto + is only 8 bits wide. This affects the api, as there, the protocol was + u16_t, too. + + 2007-05-18 Simon Goldschmidt + * memp.c: addition to patch #5913: smaller pointer was returned but + memp_memory was the same size -> did not save memory. + + 2007-05-16 Simon Goldschmidt + * loopif.c, slipif.c: Fix bug #19729: free pbuf if netif->input() returns + != ERR_OK. + + 2007-05-16 Simon Goldschmidt + * api_msg.c, udp.c: If a udp_pcb has a local_ip set, check if it is the same + as the one of the netif used for sending to prevent sending from old + addresses after a netif address gets changed (partly fixes bug #3168). + + 2007-05-16 Frédéric Bernon + * tcpip.c, igmp.h, igmp.c: Fixed bug "#19800 : IGMP: igmp_tick() will not work + with NO_SYS=1". Note that igmp_init is always in tcpip_thread (and not in + tcpip_init) because we have to be sure that network interfaces are already + added (mac filter is updated only in igmp_init for the moment). + + 2007-05-16 Simon Goldschmidt + * mem.c, memp.c: Removed semaphores from memp, changed sys_sem_wait calls + into sys_arch_sem_wait calls to prevent timers from running while waiting + for the heap. This fixes bug #19167. + + 2007-05-13 Simon Goldschmidt + * tcp.h, sockets.h, sockets.c: Fixed bug from patch #5865 by moving the defines + for socket options (lwip_set/-getsockopt) used with level IPPROTO_TCP from + tcp.h to sockets.h. + + 2007-05-07 Simon Goldschmidt + * mem.c: Another attempt to fix bug #17922. + + 2007-05-04 Simon Goldschmidt + * pbuf.c, pbuf.h, etharp.c: Further update to ARP queueing: Changed pbuf_copy() + implementation so that it can be reused (don't allocate the target + pbuf inside pbuf_copy()). + + 2007-05-04 Simon Goldschmidt + * memp.c: checked in patch #5913: in memp_malloc() we can return memp as mem + to save a little RAM (next pointer of memp is not used while not in pool). + + 2007-05-03 "maq" + * sockets.c: Fix ioctl FIONREAD when some data remains from last recv. + (patch #3574). + + 2007-04-23 Simon Goldschmidt + * loopif.c, loopif.h, opt.h, src/netif/FILES: fix bug #2595: "loopif results + in NULL reference for incoming TCP packets". Loopif has to be configured + (using LWIP_LOOPIF_MULTITHREADING) to directly call netif->input() + (multithreading environments, e.g. netif->input() = tcpip_input()) or + putting packets on a list that is fed to the stack by calling loopif_poll() + (single-thread / NO_SYS / polling environment where e.g. + netif->input() = ip_input). + + 2007-04-17 Jonathan Larmour + * pbuf.c: Use s32_t in pbuf_realloc(), as an s16_t can't reliably hold + the difference between two u16_t's. + * sockets.h: FD_SETSIZE needs to match number of sockets, which is + MEMP_NUM_NETCONN in sockets.c right now. + + 2007-04-12 Jonathan Larmour + * icmp.c: Reset IP header TTL in ICMP ECHO responses (bug #19580). + + 2007-04-12 Kieran Mansley + * tcp.c, tcp_in.c, tcp_out.c, tcp.h: Modify way the retransmission + timer is reset to fix bug#19434, with help from Oleg Tyshev. + + 2007-04-11 Simon Goldschmidt + * etharp.c, pbuf.c, pbuf.h: 3rd fix for bug #11400 (arp-queuing): More pbufs than + previously thought need to be copied (everything but PBUF_ROM!). Cleaned up + pbuf.c: removed functions no needed any more (by etharp). + + 2007-04-11 Kieran Mansley + * inet.c, ip_addr.h, sockets.h, sys.h, tcp.h: Apply patch #5745: Fix + "Constant is long" warnings with 16bit compilers. Contributed by + avatar@mmlab.cse.yzu.edu.tw + + 2007-04-05 Frédéric Bernon, Jonathan Larmour + * api_msg.c: Fix bug #16830: "err_tcp() posts to connection mailbox when no pend on + the mailbox is active". Now, the post is only done during a connect, and do_send, + do_write and do_join_leave_group don't do anything if a previous error was signaled. + + 2007-04-03 Frédéric Bernon + * ip.c: Don't set the IP_DF ("Don't fragment") flag in the IP header in IP output + packets. See patch #5834. + + 2007-03-30 Frédéric Bernon + * api_msg.c: add a "pcb_new" helper function to avoid redundant code, and to add + missing pcb allocations checking (in do_bind, and for each raw_new). Fix style. + + 2007-03-30 Frédéric Bernon + * most of files: prefix all debug.h define with "LWIP_" to avoid any conflict with + others environment defines (these were too "generic"). + + 2007-03-28 Frédéric Bernon + * api.h, api_lib.c, sockets.c: netbuf_ref doesn't check its internal pbuf_alloc call + result and can cause a crash. lwip_send now check netbuf_ref result. + + 2007-03-28 Simon Goldschmidt + * sockets.c Remove "#include <errno.h>" from sockets.c to avoid multiple + definition of macros (in errno.h and lwip/arch.h) if LWIP_PROVIDE_ERRNO is + defined. This is the way it should have been already (looking at + doc/sys_arch.txt) + + 2007-03-28 Kieran Mansley + * opt.h Change default PBUF_POOL_BUFSIZE (again) to accomodate default MSS + + IP and TCP headers *and* physical link headers + + 2007-03-26 Frédéric Bernon (based on patch from Dmitry Potapov) + * api_lib.c: patch for netconn_write(), fixes a possible race condition which cause + to send some garbage. It is not a definitive solution, but the patch does solve + the problem for most cases. + + 2007-03-22 Frédéric Bernon + * api_msg.h, api_msg.c: Remove obsolete API_MSG_ACCEPT and do_accept (never used). + + 2007-03-22 Frédéric Bernon + * api_lib.c: somes resources couldn't be freed if there was errors during + netconn_new_with_proto_and_callback. + + 2007-03-22 Frédéric Bernon + * ethernetif.c: update netif->input calls to check return value. In older ports, + it's a good idea to upgrade them, even if before, there could be another problem + (access to an uninitialized mailbox). + + 2007-03-21 Simon Goldschmidt + * sockets.c: fixed bug #5067 (essentialy a signed/unsigned warning fixed + by casting to unsigned). + + 2007-03-21 Frédéric Bernon + * api_lib.c, api_msg.c, tcpip.c: integrate sys_mbox_fetch(conn->mbox, NULL) calls from + api_lib.c to tcpip.c's tcpip_apimsg(). Now, use a local variable and not a + dynamic one from memp to send tcpip_msg to tcpip_thread in a synchrone call. + Free tcpip_msg from tcpip_apimsg is not done in tcpip_thread. This give a + faster and more reliable communication between api_lib and tcpip. + + 2007-03-21 Frédéric Bernon + * opt.h: Add LWIP_NETIF_CALLBACK (to avoid compiler warning) and set it to 0. + + 2007-03-21 Frédéric Bernon + * api_msg.c, igmp.c, igmp.h: Fix C++ style comments + + 2007-03-21 Kieran Mansley + * opt.h Change default PBUF_POOL_BUFSIZE to accomodate default MSS + + IP and TCP headers + + 2007-03-21 Kieran Mansley + * Fix all uses of pbuf_header to check the return value. In some + cases just assert if it fails as I'm not sure how to fix them, but + this is no worse than before when they would carry on regardless + of the failure. + + 2007-03-21 Kieran Mansley + * sockets.c, igmp.c, igmp.h, memp.h: Fix C++ style comments and + comment out missing header include in icmp.c + + 2007-03-20 Frédéric Bernon + * memp.h, stats.c: Fix stats_display function where memp_names table wasn't + synchronized with memp.h. + + 2007-03-20 Frédéric Bernon + * tcpip.c: Initialize tcpip's mbox, and verify if initialized in tcpip_input, + tcpip_ethinput, tcpip_callback, tcpip_apimsg, to fix a init problem with + network interfaces. Also fix a compiler warning. + + 2007-03-20 Kieran Mansley + * udp.c: Only try and use pbuf_header() to make space for headers if + not a ROM or REF pbuf. + + 2007-03-19 Frédéric Bernon + * api_msg.h, api_msg.c, tcpip.h, tcpip.c: Add return types to tcpip_apimsg() + and api_msg_post(). + + 2007-03-19 Frédéric Bernon + * Remove unimplemented "memp_realloc" function from memp.h. + + 2007-03-11 Simon Goldschmidt + * pbuf.c: checked in patch #5796: pbuf_alloc: len field claculation caused + memory corruption. + + 2007-03-11 Simon Goldschmidt (based on patch from Dmitry Potapov) + * api_lib.c, sockets.c, api.h, api_msg.h, sockets.h: Fixed bug #19251 + (missing `const' qualifier in socket functions), to get more compatible to + standard POSIX sockets. + + 2007-03-11 Frédéric Bernon (based on patch from Dmitry Potapov) + * sockets.c: Add asserts inside bind, connect and sendto to check input + parameters. Remove excessive set_errno() calls after get_socket(), because + errno is set inside of get_socket(). Move last sock_set_errno() inside + lwip_close. + + 2007-03-09 Simon Goldschmidt + * memp.c: Fixed bug #11400: New etharp queueing introduced bug: memp_memory + was allocated too small. + + 2007-03-06 Simon Goldschmidt + * tcpip.c: Initialize dhcp timers in tcpip_thread (if LWIP_DHCP) to protect + the stack from concurrent access. + + 2007-03-06 Frédéric Bernon, Dmitry Potapov + * tcpip.c, ip_frag.c, ethernetif.c: Fix some build problems, and a redundancy + call to "lwip_stats.link.recv++;" in low_level_input() & ethernetif_input(). + + 2007-03-06 Simon Goldschmidt + * ip_frag.c, ip_frag.h: Reduce code size: don't include code in those files + if IP_FRAG == 0 and IP_REASSEMBLY == 0 + + 2007-03-06 Frédéric Bernon, Simon Goldschmidt + * opt.h, ip_frag.h, tcpip.h, tcpip.c, ethernetif.c: add new configuration + option named ETHARP_TCPIP_ETHINPUT, which enable the new tcpip_ethinput. + Allow to do ARP processing for incoming packets inside tcpip_thread + (protecting ARP layer against concurrent access). You can also disable + old code using tcp_input with new define ETHARP_TCPIP_INPUT set to 0. + Older ports have to use tcpip_ethinput. + + 2007-03-06 Simon Goldschmidt (based on patch from Dmitry Potapov) + * err.h, err.c: fixed compiler warning "initialization dircards qualifiers + from pointer target type" + + 2007-03-05 Frédéric Bernon + * opt.h, sockets.h: add new configuration options (LWIP_POSIX_SOCKETS_IO_NAMES, + ETHARP_TRUST_IP_MAC, review SO_REUSE) + + 2007-03-04 Frédéric Bernon + * api_msg.c: Remove some compiler warnings : parameter "pcb" was never + referenced. + + 2007-03-04 Frédéric Bernon + * api_lib.c: Fix "[patch #5764] api_lib.c cleanup: after patch #5687" (from + Dmitry Potapov). + The api_msg struct stay on the stack (not moved to netconn struct). + + 2007-03-04 Simon Goldschmidt (based on patch from Dmitry Potapov) + * pbuf.c: Fix BUG#19168 - pbuf_free can cause deadlock (if + SYS_LIGHTWEIGHT_PROT=1 & freeing PBUF_RAM when mem_sem is not available) + Also fixed cast warning in pbuf_alloc() + + 2007-03-04 Simon Goldschmidt + * etharp.c, etharp.h, memp.c, memp.h, opt.h: Fix BUG#11400 - don't corrupt + existing pbuf chain when enqueuing multiple pbufs to a pending ARP request + + 2007-03-03 Frédéric Bernon + * udp.c: remove obsolete line "static struct udp_pcb *pcb_cache = NULL;" + It is static, and never used in udp.c except udp_init(). + + 2007-03-02 Simon Goldschmidt + * tcpip.c: Moved call to ip_init(), udp_init() and tcp_init() from + tcpip_thread() to tcpip_init(). This way, raw API connections can be + initialized before tcpip_thread is running (e.g. before OS is started) + + 2007-03-02 Frédéric Bernon + * rawapi.txt: Fix documentation mismatch with etharp.h about etharp_tmr's call + interval. + + 2007-02-28 Kieran Mansley + * pbuf.c: Fix BUG#17645 - ensure pbuf payload pointer is not moved + outside the region of the pbuf by pbuf_header() + + 2007-02-28 Kieran Mansley + * sockets.c: Fix BUG#19161 - ensure milliseconds timeout is non-zero + when supplied timeout is also non-zero + +(STABLE-1.2.0) + + 2006-12-05 Leon Woestenberg + * CHANGELOG: Mention STABLE-1.2.0 release. + + ++ New features: + + 2006-12-01 Christiaan Simons + * mem.h, opt.h: Added MEM_LIBC_MALLOC option. + Note this is a workaround. Currently I have no other options left. + + 2006-10-26 Christiaan Simons (accepted patch by Jonathan Larmour) + * ipv4/ip_frag.c: rename MAX_MTU to IP_FRAG_MAX_MTU and move define + to include/lwip/opt.h. + * ipv4/lwip/ip_frag.h: Remove unused IP_REASS_INTERVAL. + Move IP_REASS_MAXAGE and IP_REASS_BUFSIZE to include/lwip/opt.h. + * opt.h: Add above new options. + + 2006-08-18 Christiaan Simons + * tcp_{in,out}.c: added SNMP counters. + * ipv4/ip.c: added SNMP counters. + * ipv4/ip_frag.c: added SNMP counters. + + 2006-08-08 Christiaan Simons + * etharp.{c,h}: added etharp_find_addr() to read + (stable) ethernet/IP address pair from ARP table + + 2006-07-14 Christiaan Simons + * mib_structs.c: added + * include/lwip/snmp_structs.h: added + * netif.{c,h}, netif/ethernetif.c: added SNMP statistics to netif struct + + 2006-07-06 Christiaan Simons + * snmp/asn1_{enc,dec}.c added + * snmp/mib2.c added + * snmp/msg_{in,out}.c added + * include/lwip/snmp_asn1.h added + * include/lwip/snmp_msg.h added + * doc/snmp_agent.txt added + + 2006-03-29 Christiaan Simons + * inet.c, inet.h: Added platform byteswap support. + Added LWIP_PLATFORM_BYTESWAP define (defaults to 0) and + optional LWIP_PLATFORM_HTONS(), LWIP_PLATFORM_HTONL() macros. + + ++ Bug fixes: + + 2006-11-30 Christiaan Simons + * dhcp.c: Fixed false triggers of request_timeout. + + 2006-11-28 Christiaan Simons + * netif.c: In netif_add() fixed missing clear of ip_addr, netmask, gw and flags. + + 2006-10-11 Christiaan Simons + * api_lib.c etharp.c, ip.c, memp.c, stats.c, sys.{c,h} tcp.h: + Partially accepted patch #5449 for ANSI C compatibility / build fixes. + * ipv4/lwip/ip.h ipv6/lwip/ip.h: Corrected UDP-Lite protocol + identifier from 170 to 136 (bug #17574). + + 2006-10-10 Christiaan Simons + * api_msg.c: Fixed Nagle algorithm as reported by Bob Grice. + + 2006-08-17 Christiaan Simons + * udp.c: Fixed bug #17200, added check for broadcast + destinations for PCBs bound to a unicast address. + + 2006-08-07 Christiaan Simons + * api_msg.c: Flushing TCP output in do_close() (bug #15926). + + 2006-06-27 Christiaan Simons + * api_msg.c: Applied patch for cold case (bug #11135). + In accept_function() ensure newconn->callback is always initialized. + + 2006-06-15 Christiaan Simons + * mem.h: added MEM_SIZE_F alias to fix an ancient cold case (bug #1748), + facilitate printing of mem_size_t and u16_t statistics. + + 2006-06-14 Christiaan Simons + * api_msg.c: Applied patch #5146 to handle allocation failures + in accept() by Kevin Lawson. + + 2006-05-26 Christiaan Simons + * api_lib.c: Removed conn->sem creation and destruction + from netconn_write() and added sys_sem_new to netconn_new_*. + +(STABLE-1_1_1) + + 2006-03-03 Christiaan Simons + * ipv4/ip_frag.c: Added bound-checking assertions on ip_reassbitmap + access and added pbuf_alloc() return value checks. + + 2006-01-01 Leon Woestenberg leon.woestenberg@gmx.net + * tcp_{in,out}.c, tcp_out.c: Removed 'even sndbuf' fix in TCP, which is + now handled by the checksum routine properly. + + 2006-02-27 Leon Woestenberg leon.woestenberg@gmx.net + * pbuf.c: Fix alignment; pbuf_init() would not work unless + pbuf_pool_memory[] was properly aligned. (Patch by Curt McDowell.) + + 2005-12-20 Leon Woestenberg leon.woestenberg@gmx.net + * tcp.c: Remove PCBs which stay in LAST_ACK state too long. Patch + submitted by Mitrani Hiroshi. + + 2005-12-15 Christiaan Simons + * inet.c: Disabled the added summing routine to preserve code space. + + 2005-12-14 Leon Woestenberg leon.woestenberg@gmx.net + * tcp_in.c: Duplicate FIN ACK race condition fix by Kelvin Lawson. + Added Curt McDowell's optimized checksumming routine for future + inclusion. Need to create test case for unaliged, aligned, odd, + even length combination of cases on various endianess machines. + + 2005-12-09 Christiaan Simons + * inet.c: Rewrote standard checksum routine in proper portable C. + + 2005-11-25 Christiaan Simons + * udp.c tcp.c: Removed SO_REUSE hack. Should reside in socket code only. + * *.c: introduced cc.h LWIP_DEBUG formatters matching the u16_t, s16_t, + u32_t, s32_t typedefs. This solves most debug word-length assumes. + + 2005-07-17 Leon Woestenberg leon.woestenberg@gmx.net + * inet.c: Fixed unaligned 16-bit access in the standard checksum + routine by Peter Jolasson. + * slipif.c: Fixed implementation assumption of single-pbuf datagrams. + + 2005-02-04 Leon Woestenberg leon.woestenberg@gmx.net + * tcp_out.c: Fixed uninitialized 'queue' referenced in memerr branch. + * tcp_{out|in}.c: Applied patch fixing unaligned access. + + 2005-01-04 Leon Woestenberg leon.woestenberg@gmx.net + * pbuf.c: Fixed missing semicolon after LWIP_DEBUG statement. + + 2005-01-03 Leon Woestenberg leon.woestenberg@gmx.net + * udp.c: UDP pcb->recv() was called even when it was NULL. + +(STABLE-1_1_0) + + 2004-12-28 Leon Woestenberg leon.woestenberg@gmx.net + * etharp.*: Disabled multiple packets on the ARP queue. + This clashes with TCP queueing. + + 2004-11-28 Leon Woestenberg leon.woestenberg@gmx.net + * etharp.*: Fixed race condition from ARP request to ARP timeout. + Halved the ARP period, doubled the period counts. + ETHARP_MAX_PENDING now should be at least 2. This prevents + the counter from reaching 0 right away (which would allow + too little time for ARP responses to be received). + + 2004-11-25 Leon Woestenberg leon.woestenberg@gmx.net + * dhcp.c: Decline messages were not multicast but unicast. + * etharp.c: ETHARP_CREATE is renamed to ETHARP_TRY_HARD. + Do not try hard to insert arbitrary packet's source address, + etharp_ip_input() now calls etharp_update() without ETHARP_TRY_HARD. + etharp_query() now always DOES call ETHARP_TRY_HARD so that users + querying an address will see it appear in the cache (DHCP could + suffer from this when a server invalidly gave an in-use address.) + * ipv4/ip_addr.h: Renamed ip_addr_maskcmp() to _netcmp() as we are + comparing network addresses (identifiers), not the network masks + themselves. + * ipv4/ip_addr.c: ip_addr_isbroadcast() now checks that the given + IP address actually belongs to the network of the given interface. + + 2004-11-24 Kieran Mansley kjm25@cam.ac.uk + * tcp.c: Increment pcb->snd_buf when ACK is received in SYN_SENT state. + +(STABLE-1_1_0-RC1) + + 2004-10-16 Kieran Mansley kjm25@cam.ac.uk + * tcp.c: Add code to tcp_recved() to send an ACK (window update) immediately, + even if one is already pending, if the rcv_wnd is above a threshold + (currently TCP_WND/2). This avoids waiting for a timer to expire to send a + delayed ACK in order to open the window if the stack is only receiving data. + + 2004-09-12 Kieran Mansley kjm25@cam.ac.uk + * tcp*.*: Retransmit time-out handling improvement by Sam Jansen. + + 2004-08-20 Tony Mountifield tony@softins.co.uk + * etharp.c: Make sure the first pbuf queued on an ARP entry + is properly ref counted. + + 2004-07-27 Tony Mountifield tony@softins.co.uk + * debug.h: Added (int) cast in LWIP_DEBUGF() to avoid compiler + warnings about comparison. + * pbuf.c: Stopped compiler complaining of empty if statement + when LWIP_DEBUGF() empty. Closed an unclosed comment. + * tcp.c: Stopped compiler complaining of empty if statement + when LWIP_DEBUGF() empty. + * ip.h Corrected IPH_TOS() macro: returns a byte, so doesn't need htons(). + * inet.c: Added a couple of casts to quiet the compiler. + No need to test isascii(c) before isdigit(c) or isxdigit(c). + + 2004-07-22 Tony Mountifield tony@softins.co.uk + * inet.c: Made data types consistent in inet_ntoa(). + Added casts for return values of checksum routines, to pacify compiler. + * ip_frag.c, tcp_out.c, sockets.c, pbuf.c + Small corrections to some debugging statements, to pacify compiler. + + 2004-07-21 Tony Mountifield tony@softins.co.uk + * etharp.c: Removed spurious semicolon and added missing end-of-comment. + * ethernetif.c Updated low_level_output() to match prototype for + netif->linkoutput and changed low_level_input() similarly for consistency. + * api_msg.c: Changed recv_raw() from int to u8_t, to match prototype + of raw_recv() in raw.h and so avoid compiler error. + * sockets.c: Added trivial (int) cast to keep compiler happier. + * ip.c, netif.c Changed debug statements to use the tidier ip4_addrN() macros. + +(STABLE-1_0_0) + + ++ Changes: + + 2004-07-05 Leon Woestenberg leon.woestenberg@gmx.net + * sockets.*: Restructured LWIP_PRIVATE_TIMEVAL. Make sure + your cc.h file defines this either 1 or 0. If non-defined, + defaults to 1. + * .c: Added <string.h> and <errno.h> includes where used. + * etharp.c: Made some array indices unsigned. + + 2004-06-27 Leon Woestenberg leon.woestenberg@gmx.net + * netif.*: Added netif_set_up()/down(). + * dhcp.c: Changes to restart program flow. + + 2004-05-07 Leon Woestenberg leon.woestenberg@gmx.net + * etharp.c: In find_entry(), instead of a list traversal per candidate, do a + single-pass lookup for different candidates. Should exploit locality. + + 2004-04-29 Leon Woestenberg leon.woestenberg@gmx.net + * tcp*.c: Cleaned up source comment documentation for Doxygen processing. + * opt.h: ETHARP_ALWAYS_INSERT option removed to comply with ARP RFC. + * etharp.c: update_arp_entry() only adds new ARP entries when adviced to by + the caller. This deprecates the ETHARP_ALWAYS_INSERT overrule option. + + ++ Bug fixes: + + 2004-04-27 Leon Woestenberg leon.woestenberg@gmx.net + * etharp.c: Applied patch of bug #8708 by Toni Mountifield with a solution + suggested by Timmy Brolin. Fix for 32-bit processors that cannot access + non-aligned 32-bit words, such as soms 32-bit TCP/IP header fields. Fix + is to prefix the 14-bit Ethernet headers with two padding bytes. + + 2004-04-23 Leon Woestenberg leon.woestenberg@gmx.net + * ip_addr.c: Fix in the ip_addr_isbroadcast() check. + * etharp.c: Fixed the case where the packet that initiates the ARP request + is not queued, and gets lost. Fixed the case where the packets destination + address is already known; we now always queue the packet and perform an ARP + request. + +(STABLE-0_7_0) + + ++ Bug fixes: + + * Fixed TCP bug for SYN_SENT to ESTABLISHED state transition. + * Fixed TCP bug in dequeueing of FIN from out of order segment queue. + * Fixed two possible NULL references in rare cases. + +(STABLE-0_6_6) + + ++ Bug fixes: + + * Fixed DHCP which did not include the IP address in DECLINE messages. + + ++ Changes: + + * etharp.c has been hauled over a bit. + +(STABLE-0_6_5) + + ++ Bug fixes: + + * Fixed TCP bug induced by bad window resizing with unidirectional TCP traffic. + * Packets sent from ARP queue had invalid source hardware address. + + ++ Changes: + + * Pass-by ARP requests do now update the cache. + + ++ New features: + + * No longer dependent on ctype.h. + * New socket options. + * Raw IP pcb support. + +(STABLE-0_6_4) + + ++ Bug fixes: + + * Some debug formatters and casts fixed. + * Numereous fixes in PPP. + + ++ Changes: + + * DEBUGF now is LWIP_DEBUGF + * pbuf_dechain() has been re-enabled. + * Mentioned the changed use of CVS branches in README. + +(STABLE-0_6_3) + + ++ Bug fixes: + + * Fixed pool pbuf memory leak in pbuf_alloc(). + Occured if not enough PBUF_POOL pbufs for a packet pbuf chain. + Reported by Savin Zlobec. + + * PBUF_POOL chains had their tot_len field not set for non-first + pbufs. Fixed in pbuf_alloc(). + + ++ New features: + + * Added PPP stack contributed by Marc Boucher + + ++ Changes: + + * Now drops short packets for ICMP/UDP/TCP protocols. More robust. + + * ARP queueuing now queues the latest packet instead of the first. + This is the RFC recommended behaviour, but can be overridden in + lwipopts.h. + +(0.6.2) + + ++ Bugfixes: + + * TCP has been fixed to deal with the new use of the pbuf->ref + counter. + + * DHCP dhcp_inform() crash bug fixed. + + ++ Changes: + + * Removed pbuf_pool_free_cache and pbuf_pool_alloc_cache. Also removed + pbuf_refresh(). This has sped up pbuf pool operations considerably. + Implemented by David Haas. + +(0.6.1) + + ++ New features: + + * The packet buffer implementation has been enhanced to support + zero-copy and copy-on-demand for packet buffers which have their + payloads in application-managed memory. + Implemented by David Haas. + + Use PBUF_REF to make a pbuf refer to RAM. lwIP will use zero-copy + if an outgoing packet can be directly sent on the link, or perform + a copy-on-demand when necessary. + + The application can safely assume the packet is sent, and the RAM + is available to the application directly after calling udp_send() + or similar function. + + ++ Bugfixes: + + * ARP_QUEUEING should now correctly work for all cases, including + PBUF_REF. + Implemented by Leon Woestenberg. + + ++ Changes: + + * IP_ADDR_ANY is no longer a NULL pointer. Instead, it is a pointer + to a '0.0.0.0' IP address. + + * The packet buffer implementation is changed. The pbuf->ref counter + meaning has changed, and several pbuf functions have been + adapted accordingly. + + * netif drivers have to be changed to set the hardware address length field + that must be initialized correctly by the driver (hint: 6 for Ethernet MAC). + See the contrib/ports/c16x cs8900 driver as a driver example. + + * netif's have a dhcp field that must be initialized to NULL by the driver. + See the contrib/ports/c16x cs8900 driver as a driver example. + +(0.5.x) This file has been unmaintained up to 0.6.1. All changes are + logged in CVS but have not been explained here. + +(0.5.3) Changes since version 0.5.2 + + ++ Bugfixes: + + * memp_malloc(MEMP_API_MSG) could fail with multiple application + threads because it wasn't protected by semaphores. + + ++ Other changes: + + * struct ip_addr now packed. + + * The name of the time variable in arp.c has been changed to ctime + to avoid conflicts with the time() function. + +(0.5.2) Changes since version 0.5.1 + + ++ New features: + + * A new TCP function, tcp_tmr(), now handles both TCP timers. + + ++ Bugfixes: + + * A bug in tcp_parseopt() could cause the stack to hang because of a + malformed TCP option. + + * The address of new connections in the accept() function in the BSD + socket library was not handled correctly. + + * pbuf_dechain() did not update the ->tot_len field of the tail. + + * Aborted TCP connections were not handled correctly in all + situations. + + ++ Other changes: + + * All protocol header structs are now packed. + + * The ->len field in the tcp_seg structure now counts the actual + amount of data, and does not add one for SYN and FIN segments. + +(0.5.1) Changes since version 0.5.0 + + ++ New features: + + * Possible to run as a user process under Linux. + + * Preliminary support for cross platform packed structs. + + * ARP timer now implemented. + + ++ Bugfixes: + + * TCP output queue length was badly initialized when opening + connections. + + * TCP delayed ACKs were not sent correctly. + + * Explicit initialization of BSS segment variables. + + * read() in BSD socket library could drop data. + + * Problems with memory alignment. + + * Situations when all TCP buffers were used could lead to + starvation. + + * TCP MSS option wasn't parsed correctly. + + * Problems with UDP checksum calculation. + + * IP multicast address tests had endianess problems. + + * ARP requests had wrong destination hardware address. + + ++ Other changes: + + * struct eth_addr changed from u16_t[3] array to u8_t[6]. + + * A ->linkoutput() member was added to struct netif. + + * TCP and UDP ->dest_* struct members where changed to ->remote_*. + + * ntoh* macros are now null definitions for big endian CPUs. + +(0.5.0) Changes since version 0.4.2 + + ++ New features: + + * Redesigned operating system emulation layer to make porting easier. + + * Better control over TCP output buffers. + + * Documenation added. + + ++ Bugfixes: + + * Locking issues in buffer management. + + * Bugfixes in the sequential API. + + * IP forwarding could cause memory leakage. This has been fixed. + + ++ Other changes: + + * Directory structure somewhat changed; the core/ tree has been + collapsed. + +(0.4.2) Changes since version 0.4.1 + + ++ New features: + + * Experimental ARP implementation added. + + * Skeleton Ethernet driver added. + + * Experimental BSD socket API library added. + + ++ Bugfixes: + + * In very intense situations, memory leakage could occur. This has + been fixed. + + ++ Other changes: + + * Variables named "data" and "code" have been renamed in order to + avoid name conflicts in certain compilers. + + * Variable++ have in appliciable cases been translated to ++variable + since some compilers generate better code in the latter case. + +(0.4.1) Changes since version 0.4 + + ++ New features: + + * TCP: Connection attempts time out earlier than data + transmissions. Nagle algorithm implemented. Push flag set on the + last segment in a burst. + + * UDP: experimental support for UDP-Lite extensions. + + ++ Bugfixes: + + * TCP: out of order segments were in some cases handled incorrectly, + and this has now been fixed. Delayed acknowledgements was broken + in 0.4, has now been fixed. Binding to an address that is in use + now results in an error. Reset connections sometimes hung an + application; this has been fixed. + + * Checksum calculation sometimes failed for chained pbufs with odd + lengths. This has been fixed. + + * API: a lot of bug fixes in the API. The UDP API has been improved + and tested. Error reporting and handling has been + improved. Logical flaws and race conditions for incoming TCP + connections has been found and removed. + + * Memory manager: alignment issues. Reallocating memory sometimes + failed, this has been fixed. + + * Generic library: bcopy was flawed and has been fixed. + + ++ Other changes: + + * API: all datatypes has been changed from generic ones such as + ints, to specified ones such as u16_t. Functions that return + errors now have the correct type (err_t). + + * General: A lot of code cleaned up and debugging code removed. Many + portability issues have been fixed. + + * The license was changed; the advertising clause was removed. + + * C64 port added. + + * Thanks: Huge thanks go to Dagan Galarneau, Horst Garnetzke, Petri + Kosunen, Mikael Caleres, and Frits Wilmink for reporting and + fixing bugs! + +(0.4) Changes since version 0.3.1 + + * Memory management has been radically changed; instead of + allocating memory from a shared heap, memory for objects that are + rapidly allocated and deallocated is now kept in pools. Allocation + and deallocation from those memory pools is very fast. The shared + heap is still present but is used less frequently. + + * The memory, memory pool, and packet buffer subsystems now support + 4-, 2-, or 1-byte alignment. + + * "Out of memory" situations are handled in a more robust way. + + * Stack usage has been reduced. + + * Easier configuration of lwIP parameters such as memory usage, + TTLs, statistics gathering, etc. All configuration parameters are + now kept in a single header file "lwipopts.h". + + * The directory structure has been changed slightly so that all + architecture specific files are kept under the src/arch + hierarchy. + + * Error propagation has been improved, both in the protocol modules + and in the API. + + * The code for the RTXC architecture has been implemented, tested + and put to use. + + * Bugs have been found and corrected in the TCP, UDP, IP, API, and + the Internet checksum modules. + + * Bugs related to porting between a 32-bit and a 16-bit architecture + have been found and corrected. + + * The license has been changed slightly to conform more with the + original BSD license, including the advertisement clause. + +(0.3.1) Changes since version 0.3 + + * Fix of a fatal bug in the buffer management. Pbufs with allocated + RAM never returned the RAM when the pbuf was deallocated. + + * TCP congestion control, window updates and retransmissions did not + work correctly. This has now been fixed. + + * Bugfixes in the API. + +(0.3) Changes since version 0.2 + + * New and improved directory structure. All include files are now + kept in a dedicated include/ directory. + + * The API now has proper error handling. A new function, + netconn_err(), now returns an error code for the connection in + case of errors. + + * Improvements in the memory management subsystem. The system now + keeps a pointer to the lowest free memory block. A new function, + mem_malloc2() tries to allocate memory once, and if it fails tries + to free some memory and retry the allocation. + + * Much testing has been done with limited memory + configurations. lwIP now does a better job when overloaded. + + * Some bugfixes and improvements to the buffer (pbuf) subsystem. + + * Many bugfixes in the TCP code: + + - Fixed a bug in tcp_close(). + + - The TCP receive window was incorrectly closed when out of + sequence segments was received. This has been fixed. + + - Connections are now timed-out of the FIN-WAIT-2 state. + + - The initial congestion window could in some cases be too + large. This has been fixed. + + - The retransmission queue could in some cases be screwed up. This + has been fixed. + + - TCP RST flag now handled correctly. + + - Out of sequence data was in some cases never delivered to the + application. This has been fixed. + + - Retransmitted segments now contain the correct acknowledgment + number and advertised window. + + - TCP retransmission timeout backoffs are not correctly computed + (ala BSD). After a number of retransmissions, TCP now gives up + the connection. + + * TCP connections now are kept on three lists, one for active + connections, one for listening connections, and one for + connections that are in TIME-WAIT. This greatly speeds up the fast + timeout processing for sending delayed ACKs. + + * TCP now provides proper feedback to the application when a + connection has been successfully set up. + + * More comments have been added to the code. The code has also been + somewhat cleaned up. + +(0.2) Initial public release. diff --git a/CMakeLists.txt b/CMakeLists.txt new file mode 100644 index 00000000000..55fc44a1349 --- /dev/null +++ b/CMakeLists.txt @@ -0,0 +1,35 @@ +cmake_minimum_required(VERSION 3.10) + +set (CMAKE_CONFIGURATION_TYPES "Debug;Release") + +project(lwIP) + +# Example lwIP application +set(LWIP_DIR ${CMAKE_CURRENT_SOURCE_DIR}) + +set (LWIP_DEFINITIONS LWIP_DEBUG=1) + +if (${CMAKE_SYSTEM_NAME} STREQUAL "Windows") + add_subdirectory(${LWIP_DIR}/contrib/ports/win32/example_app) +elseif(${CMAKE_SYSTEM_NAME} STREQUAL "Linux" OR ${CMAKE_SYSTEM_NAME} STREQUAL "Darwin") + add_subdirectory(${LWIP_DIR}/contrib/ports/unix/example_app) +else() + message(WARNING "Host ${CMAKE_SYSTEM_NAME} is not supported to build example_app") +endif() + +# Source package generation +set(CPACK_SOURCE_GENERATOR "ZIP") +set(CPACK_SOURCE_PACKAGE_DESCRIPTION_SUMMARY "lwIP lightweight IP stack") +set(CPACK_PACKAGE_VERSION_MAJOR "${LWIP_VERSION_MAJOR}") +set(CPACK_PACKAGE_VERSION_MINOR "${LWIP_VERSION_MINOR}") +set(CPACK_PACKAGE_VERSION_PATCH "${LWIP_VERSION_REVISION}") +set(CPACK_SOURCE_IGNORE_FILES "/build/;${CPACK_SOURCE_IGNORE_FILES};.git") +set(CPACK_SOURCE_PACKAGE_FILE_NAME "lwip-${LWIP_VERSION_MAJOR}.${LWIP_VERSION_MINOR}.${LWIP_VERSION_REVISION}") +include(CPack) + +# Generate docs before creating source package +include(src/Filelists.cmake) +add_custom_target(dist COMMAND ${CMAKE_MAKE_PROGRAM} package_source) +if (TARGET lwipdocs) + add_dependencies(dist lwipdocs) +endif() diff --git a/COPYING b/COPYING new file mode 100644 index 00000000000..90465f592ce --- /dev/null +++ b/COPYING @@ -0,0 +1,25 @@ +Copyright (c) 2001, 2002 Swedish Institute of Computer Science. +All rights reserved. + +Redistribution and use in source and binary forms, with or without modification, +are permitted provided that the following conditions are met: + +1. Redistributions of source code must retain the above copyright notice, + this list of conditions and the following disclaimer. +2. Redistributions in binary form must reproduce the above copyright notice, + this list of conditions and the following disclaimer in the documentation + and/or other materials provided with the distribution. +3. The name of the author may not be used to endorse or promote products + derived from this software without specific prior written permission. + +THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED +WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF +MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT +SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, +EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT +OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS +INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN +CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING +IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY +OF SUCH DAMAGE. + diff --git a/FEATURES b/FEATURES new file mode 100644 index 00000000000..87802d13f7d --- /dev/null +++ b/FEATURES @@ -0,0 +1,11 @@ +lwIP is a small independent implementation of the TCP/IP protocol suite targeted at embedded systems. + +The focus of the lwIP TCP/IP implementation is to reduce resource usage while still having a full scale TCP. This makes lwIP suitable for use in embedded systems with tens of kilobytes of free RAM and room for around 40 kilobytes of code ROM. + +Main features include: +- Protocols: IP, IPv6, ICMP, ND, MLD, UDP, TCP, IGMP, ARP, PPPoS, PPPoE, 6LowPAN (via IEEE 802.15.4, BLE or ZEP; since v2.1.0) +- DHCP client, stateless DHCPv6 (since v2.1.0), DNS client (incl. mDNS hostname resolver), AutoIP/APIPA (Zeroconf), ACD (Address Conflict Detection), SNMP agent (v1, v2c, v3 (since v2.1.0), private MIB support & MIB compiler) +- APIs: specialized APIs for enhanced performance & zero copy, optional Berkeley-alike socket API +- Extended features: IP forwarding over multiple network interfaces +- Extended TCP features: congestion control, RTT estimation and fast recovery/fast retransmit, sending SACKs (since v2.1.0), "altcp": nearly transparent TLS for any tcp pcb (since v2.1.0) +- Addon applications: HTTP server (HTTPS via altcp), HTTP(S) client (since v2.1.0), SNTP client, SMTP client (SMTPS via altcp), ping, NetBIOS nameserver, mDNS responder, MQTT client (TLS support since v2.1.0), TFTP server, iPerf2 counterpart diff --git a/FILES b/FILES new file mode 100644 index 00000000000..2a7086c1022 --- /dev/null +++ b/FILES @@ -0,0 +1,6 @@ +contrib/ - lwIP examples, ports, and small apps (formerly http://git.savannah.gnu.org/cgit/lwip/lwip-contrib.git/) +src/ - The source code for the lwIP TCP/IP stack. +doc/ - The documentation for lwIP. +test/ - Some code to test whether the sources do what they should. + +See also the FILES file in each subdirectory. diff --git a/README b/README new file mode 100644 index 00000000000..f831051b13a --- /dev/null +++ b/README @@ -0,0 +1,109 @@ +INTRODUCTION + +lwIP is a small independent implementation of the TCP/IP protocol suite. + +The focus of the lwIP TCP/IP implementation is to reduce the RAM usage +while still having a full scale TCP. This making lwIP suitable for use +in embedded systems with tens of kilobytes of free RAM and room for +around 40 kilobytes of code ROM. + +lwIP was originally developed by Adam Dunkels at the Computer and Networks +Architectures (CNA) lab at the Swedish Institute of Computer Science (SICS) +and is now developed and maintained by a worldwide network of developers. + +FEATURES + + * IP (Internet Protocol, IPv4 and IPv6) including packet forwarding over + multiple network interfaces + * ICMP (Internet Control Message Protocol) for network maintenance and debugging + * IGMP (Internet Group Management Protocol) for multicast traffic management + * MLD (Multicast listener discovery for IPv6). Aims to be compliant with + RFC 2710. No support for MLDv2 + * ND (Neighbor discovery and stateless address autoconfiguration for IPv6). + Aims to be compliant with RFC 4861 (Neighbor discovery) and RFC 4862 + (Address autoconfiguration) + * DHCP, AutoIP/APIPA (Zeroconf), ACD (Address Conflict Detection) + and (stateless) DHCPv6 + * UDP (User Datagram Protocol) including experimental UDP-lite extensions + * TCP (Transmission Control Protocol) with congestion control, RTT estimation + fast recovery/fast retransmit and sending SACKs + * raw/native API for enhanced performance + * Optional Berkeley-like socket API + * TLS: optional layered TCP ("altcp") for nearly transparent TLS for any + TCP-based protocol (ported to mbedTLS) (see changelog for more info) + * PPPoS and PPPoE (Point-to-point protocol over Serial/Ethernet) + * DNS (Domain name resolver incl. mDNS) + * 6LoWPAN (via IEEE 802.15.4, BLE or ZEP) + + +APPLICATIONS + + * HTTP server with SSI and CGI (HTTPS via altcp) + * SNMPv2c agent with MIB compiler (Simple Network Management Protocol), v3 via altcp + * SNTP (Simple network time protocol) + * NetBIOS name service responder + * MDNS (Multicast DNS) responder + * iPerf server implementation + * MQTT client (TLS support via altcp) + + +LICENSE + +lwIP is freely available under a BSD license. + + +DEVELOPMENT + +lwIP has grown into an excellent TCP/IP stack for embedded devices, +and developers using the stack often submit bug fixes, improvements, +and additions to the stack to further increase its usefulness. + +Development of lwIP is hosted on Savannah, a central point for +software development, maintenance and distribution. Everyone can +help improve lwIP by use of Savannah's interface, Git and the +mailing list. A core team of developers will commit changes to the +Git source tree. + +The lwIP TCP/IP stack is maintained in the 'src' directory and +contributions (such as platform ports and applications) are in +the 'contrib' directory. + +See doc/savannah.txt for details on Git server access for users and +developers. + +The current Git tree is web-browsable: + https://git.savannah.gnu.org/cgit/lwip.git + +Submit patches and bugs via the lwIP project page: + https://savannah.nongnu.org/projects/lwip/ + +Continuous integration builds (GCC, clang): + https://github.com/lwip-tcpip/lwip/actions + + +DOCUMENTATION + +Self documentation of the source code is regularly extracted from the current +Git sources and is available from this web page: + https://www.nongnu.org/lwip/ + +Also, there are mailing lists you can subscribe at + https://savannah.nongnu.org/mail/?group=lwip +plus searchable archives: + https://lists.nongnu.org/archive/html/lwip-users/ + https://lists.nongnu.org/archive/html/lwip-devel/ + +There is a wiki about lwIP at + https://lwip.wikia.com/wiki/LwIP_Wiki +You might get questions answered there, but unfortunately, it is not as +well maintained as it should be. + +lwIP was originally written by Adam Dunkels: + http://dunkels.com/adam/ + +Reading Adam's papers, the files in docs/, browsing the source code +documentation and browsing the mailing list archives is a good way to +become familiar with the design of lwIP. + +Adam Dunkels adam@sics.se +Leon Woestenberg leon.woestenberg@gmx.net diff --git a/UPGRADING b/UPGRADING new file mode 100644 index 00000000000..0d357906c02 --- /dev/null +++ b/UPGRADING @@ -0,0 +1,288 @@ +This file lists major changes between release versions that require +ports or applications to be changed. Use it to update a port or an +application written for an older version of lwIP to correctly work +with newer versions. + + +(git master) + + * [Enter new changes just after this line - do not remove this line] + * The eth_addr_cmp and ip_addr_cmp set of functions have been renamed to eth_addr_eq, ip_addr_eq + and so on, since they return non-zero on equality. Macros for the old names exist. + * The sio_write function used by PPP now takes the data argument as const. + +(2.2.0) + + ++ Repository changes: + + * The contrib repository has been added into the main repository in the subdirectory 'contrib' + (the old contrib repository remains online for reference but is not used any more) + +(2.1.0) + + ++ Application changes: + + * Use the new altcp API for seamless TLS integration into existing TCP applications (see changelog) + * TCP only kills existing connections with a LOWER priority than the one currently being opened. + Previous implementations also kill existing connections of the SAME priority. + * ip4_route_src: parameter order is reversed: ip4_route_src(dest, src) -> ip4_route_src(src, dest) + to make parameter order consistent with other ip*_route*() functions. + Same also applies to LWIP_HOOK_IP4_ROUTE_SRC() parameter order. + * pbuf API: pbuf->type (an u8_t holding the enum 'pbuf_type') has changed to only hold a + description of the pbuf (e.g. data following pbuf struct, data volatile, allocation + source heap/pool/etc.). As a consequence, applications can't test pbuf->type any more. + Use pbuf_match_type(pbuf, type) instead. + * socket API: according to the standard, SO_ERROR now only returns asynchronous errors. + All other/normal/synchronous errors are (and always were) available via 'errno'. + LWIP_SOCKET_SET_ERRNO has been removed - 'errno' is always set - and required! + * httpd LWIP_HTTPD_CGI_SSI: httpd_cgi_handler() has an additional parameter "struct fs_file *" + + ++ Port changes: + + * tcpip_trycallback() was renamed to tcpip_callbackmsg_trycallback() to avoid confusion + with tcpip_try_callback() + * compatibility headers: moved from 'src/include/posix' to 'src/include/compat/posix', + 'src/include/compat/stdc' etc. + * The IPv6 implementation now supports address scopes. (See LWIP_IPV6_SCOPES documentation + and ip6_zone.h for more documentation) + * LWIP_HOOK_DHCP_APPEND_OPTIONS() has changed, see description in opt.h (options_out_len is not + available in struct dhcp any more) + * Added debug helper asserts to ensure threading/locking requirements are met (define + LWIP_MARK_TCPIP_THREAD() and LWIP_ASSERT_CORE_LOCKED()). + * Added sys_mbox_trypost_fromisr() and tcpip_callbackmsg_trycallback_fromisr() + These can be used to post preallocated messages from an ISR to the tcpip thread + (e.g. when using FreeRTOS) + +(2.0.2) + + ++ Application changes: + + * slipif: The way to pass serial port number has changed. netif->num is not + supported any more, netif->state is interpreted as an u8_t port number now + (it's not a POINTER to an u8_t any more!) + +(2.0.1) + + ++ Application changes: + + * UDP does NOT receive multicast traffic from ALL netifs on an UDP PCB bound to a specific + netif any more. Users need to bind to IP_ADDR_ANY to receive multicast traffic and compare + ip_current_netif() to the desired netif for every packet. + See bug #49662 for an explanation. + +(2.0.0) + + ++ Application changes: + + * Changed netif "up" flag handling to be an administrative flag (as opposed to the previous meaning of + "ip4-address-valid", a netif will now not be used for transmission if not up) -> even a DHCP netif + has to be set "up" before starting the DHCP client + * Added IPv6 support (dual-stack or IPv4/IPv6 only) + * Changed ip_addr_t to be a union in dual-stack mode (use ip4_addr_t where referring to IPv4 only). + * Major rewrite of SNMP (added MIB parser that creates code stubs for custom MIBs); + supports SNMPv2c (experimental v3 support) + * Moved some core applications from contrib repository to src/apps (and include/lwip/apps) + + +++ Raw API: + * Changed TCP listen backlog: removed tcp_accepted(), added the function pair tcp_backlog_delayed()/ + tcp_backlog_accepted() to explicitly delay backlog handling on a connection pcb + + +++ Socket API: + * Added an implementation for posix sendmsg() + * Added LWIP_FIONREAD_LINUXMODE that makes ioctl/FIONREAD return the size of the next pending datagram + + ++ Port changes + + +++ new files: + * MANY new and moved files! + * Added src/Filelists.mk for use in Makefile projects + * Continued moving stack-internal parts from abc.h to abc_priv.h in sub-folder "priv" + to let abc.h only contain the actual application programmer's API + + +++ sys layer: + * Made LWIP_TCPIP_CORE_LOCKING==1 the default as it usually performs better than + the traditional message passing (although with LWIP_COMPAT_MUTEX you are still + open to priority inversion, so this is not recommended any more) + * Added LWIP_NETCONN_SEM_PER_THREAD to use one "op_completed" semaphore per thread + instead of using one per netconn (these semaphores are used even with core locking + enabled as some longer lasting functions like big writes still need to delay) + * Added generalized abstraction for itoa(), strnicmp(), stricmp() and strnstr() + in def.h (to be overridden in cc.h) instead of config + options for netbiosns, httpd, dns, etc. ... + * New abstraction for hton* and ntoh* functions in def.h. + To override them, use the following in cc.h: + #define lwip_htons(x) <your_htons> + #define lwip_htonl(x) <your_htonl> + + +++ new options: + * TODO + + +++ new pools: + * Added LWIP_MEMPOOL_* (declare/init/alloc/free) to declare private memp pools + that share memp.c code but do not have to be made global via lwippools.h + * Added pools for IPv6, MPU_COMPATIBLE, dns-api, netif-api, etc. + * added hook LWIP_HOOK_MEMP_AVAILABLE() to get informed when a memp pool was empty and an item + is now available + + * Signature of LWIP_HOOK_VLAN_SET macro was changed + + * LWIP_DECLARE_MEMORY_ALIGNED() may be used to declare aligned memory buffers (mem/memp) + or to move buffers to dedicated memory using compiler attributes + + * Standard C headers are used to define sized types and printf formatters + (disable by setting LWIP_NO_STDINT_H=1 or LWIP_NO_INTTYPES_H=1 if your compiler + does not support these) + + + ++ Major bugfixes/improvements + + * Added IPv6 support (dual-stack or IPv4/IPv6 only) + * Major rewrite of PPP (incl. keep-up with apache pppd) + see doc/ppp.txt for an upgrading how-to + * Major rewrite of SNMP (incl. MIB parser) + * Fixed timing issues that might have lead to losing a DHCP lease + * Made rx processing path more robust against crafted errors + * TCP window scaling support + * modification of api modules to support FreeRTOS-MPU (don't pass stack-pointers to other threads) + * made DNS client more robust + * support PBUF_REF for RX packets + * LWIP_NETCONN_FULLDUPLEX allows netconn/sockets to be used for reading/writing from separate + threads each (needs LWIP_NETCONN_SEM_PER_THREAD) + * Moved and reordered stats (mainly memp/mib2) + +(1.4.0) + + ++ Application changes: + + * Replaced struct ip_addr by typedef ip_addr_t (struct ip_addr is kept for + compatibility to old applications, but will be removed in the future). + + * Renamed mem_realloc() to mem_trim() to prevent confusion with realloc() + + +++ Raw API: + * Changed the semantics of tcp_close() (since it was rather a + shutdown before): Now the application does *NOT* get any calls to the recv + callback (aside from NULL/closed) after calling tcp_close() + + * When calling tcp_abort() from a raw API TCP callback function, + make sure you return ERR_ABRT to prevent accessing unallocated memory. + (ERR_ABRT now means the applicaiton has called tcp_abort!) + + +++ Netconn API: + * Changed netconn_receive() and netconn_accept() to return + err_t, not a pointer to new data/netconn. + + +++ Socket API: + * LWIP_SO_RCVTIMEO: when accept() or recv() time out, they + now set errno to EWOULDBLOCK/EAGAIN, not ETIMEDOUT. + + * Added a minimal version of posix fctl() to have a + standardised way to set O_NONBLOCK for nonblocking sockets. + + +++ all APIs: + * correctly implemented SO(F)_REUSEADDR + + ++ Port changes + + +++ new files: + + * Added 4 new files: def.c, timers.c, timers.h, tcp_impl.h: + + * Moved stack-internal parts of tcp.h to tcp_impl.h, tcp.h now only contains + the actual application programmer's API + + * Separated timer implementation from sys.h/.c, moved to timers.h/.c; + Added timer implementation for NO_SYS==1, set NO_SYS_NO_TIMERS==1 if you + still want to use your own timer implementation for NO_SYS==0 (as before). + + +++ sys layer: + + * Converted mbox- and semaphore-functions to take pointers to sys_mbox_t/ + sys_sem_t; + + * Converted sys_mbox_new/sys_sem_new to take pointers and return err_t; + + * Added Mutex concept in sys_arch (define LWIP_COMPAT_MUTEX to let sys.h use + binary semaphores instead of mutexes - as before) + + +++ new options: + + * Don't waste memory when chaining segments, added option TCP_OVERSIZE to + prevent creating many small pbufs when calling tcp_write with many small + blocks of data. Instead, pbufs are allocated larger than needed and the + space is used for later calls to tcp_write. + + * Added LWIP_NETIF_TX_SINGLE_PBUF to always copy to try to create single pbufs + in tcp_write/udp_send. + + * Added an additional option LWIP_ETHERNET to support ethernet without ARP + (necessary for pure PPPoE) + + * Add MEMP_SEPARATE_POOLS to place memory pools in separate arrays. This may + be used to place these pools into user-defined memory by using external + declaration. + + * Added TCP_SNDQUEUELOWAT corresponding to TCP_SNDLOWAT + + +++ new pools: + + * Netdb uses a memp pool for allocating memory when getaddrinfo() is called, + so MEMP_NUM_NETDB has to be set accordingly. + + * DNS_LOCAL_HOSTLIST_IS_DYNAMIC uses a memp pool instead of the heap, so + MEMP_NUM_LOCALHOSTLIST has to be set accordingly. + + * Snmp-agent uses a memp pools instead of the heap, so MEMP_NUM_SNMP_* have + to be set accordingly. + + * PPPoE uses a MEMP pool instead of the heap, so MEMP_NUM_PPPOE_INTERFACES + has to be set accordingly + + * Integrated loopif into netif.c - loopif does not have to be created by the + port any more, just define LWIP_HAVE_LOOPIF to 1. + + * Added define LWIP_RAND() for lwip-wide randomization (needs to be defined + in cc.h, e.g. used by igmp) + + * Added printf-formatter X8_F to printf u8_t as hex + + * The heap now may be moved to user-defined memory by defining + LWIP_RAM_HEAP_POINTER as a void pointer to that memory's address + + * added autoip_set_struct() and dhcp_set_struct() to let autoip and dhcp work + with user-allocated structs instead of calling mem_malloc + + * Added const char* name to mem- and memp-stats for easier debugging. + + * Calculate the TCP/UDP checksum while copying to only fetch data once: + Define LWIP_CHKSUM_COPY to a memcpy-like function that returns the checksum + + * Added SO_REUSE_RXTOALL to pass received UDP broadcast/multicast packets to + more than one pcb. + + * Changed the semantics of ARP_QUEUEING==0: ARP_QUEUEING now cannot be turned + off any more, if this is set to 0, only one packet (the most recent one) is + queued (like demanded by RFC 1122). + + + ++ Major bugfixes/improvements + + * Implemented tcp_shutdown() to only shut down one end of a connection + * Implemented shutdown() at socket- and netconn-level + * Added errorset support to select() + improved select speed overhead + * Merged pppd to v2.3.11 (including some backported bugfixes from 2.4.x) + * Added timer implementation for NO_SYS==1 (may be disabled with NO_SYS_NO_TIMERS==1 + * Use macros defined in ip_addr.h to work with IP addresses + * Implemented many nonblocking socket/netconn functions + * Fixed ARP input processing: only add a new entry if a request was directed as us + * mem_realloc() to mem_trim() to prevent confusion with realloc() + * Some improvements for AutoIP (don't route/forward link-local addresses, don't break + existing connections when assigning a routable address) + * Correctly handle remote side overrunning our rcv_wnd in ooseq case + * Removed packing from ip_addr_t, the packed version is now only used in protocol headers + * Corrected PBUF_POOL_BUFSIZE for ports where ETH_PAD_SIZE > 0 + * Added support for static ARP table entries + +(STABLE-1.3.2) + + * initial version of this file diff --git a/codespell_changed_files.sh b/codespell_changed_files.sh new file mode 100644 index 00000000000..638a18e2019 --- /dev/null +++ b/codespell_changed_files.sh @@ -0,0 +1,26 @@ +# Copyright 2017 Kaspar Schleiser kaspar@schleiser.de +# Copyright 2014 Ludwig Knüpfer ludwig.knuepfer@fu-berlin.de +# Copyright 2014 Hinnerk van Bruinehsen h.v.bruinehsen@fu-berlin.de +# Copyright 2020 Jonathan Demeyer jona.dem@gmail.com +# +# This file is subject to the terms and conditions of the GNU Lesser +# General Public License v2.1. See the file LICENSE in the top level +# directory for more details. + +changed_files() { + : ${FILEREGEX:='.([CcHh])$'} + : ${EXCLUDE:=''} + : ${DIFFFILTER:='ACMR'} + + DIFFFILTER="--diff-filter=${DIFFFILTER}" + + # select either all or only touched-in-branch files, filter through FILEREGEX + if [ -z "${BASE_BRANCH}" ]; then + FILES="$(git ls-tree -r --full-tree --name-only HEAD | grep -E ${FILEREGEX})" + else + FILES="$(git diff ${DIFFFILTER} --name-only ${BASE_BRANCH} | grep -E ${FILEREGEX})" + fi + + # filter out negatives + echo "${FILES}" | grep -v -E ${EXCLUDE} +} diff --git a/codespell_check.sh b/codespell_check.sh new file mode 100755 index 00000000000..7d8d0dfb75a --- /dev/null +++ b/codespell_check.sh @@ -0,0 +1,57 @@ +#!/usr/bin/env bash + +# Copyright 2019 Alexandre Abadie alexandre.abadie@inria.fr +# +# This file is subject to the terms and conditions of the GNU Lesser +# General Public License v2.1. See the file LICENSE in the top level +# directory for more details. + +CODESPELL_CMD="codespell" + +if tput colors &> /dev/null && [ "$(tput colors)" -ge 8 ]; then + CERROR=$'\033[1;31m' + CRESET=$'\033[0m' +else + CERROR= + CRESET= +fi + +: "${LWIPBASE:=$(cd $(dirname $0)/; pwd)}" +cd $LWIPBASE + +: "${LWIPTOOLS:=${LWIPBASE}}" +. "${LWIPTOOLS}"/codespell_changed_files.sh + +FILEREGEX='.([CcHh]|sh|py|md|txt)$' +EXCLUDE='^(./contrib/apps/LwipMibCompiler/Mibs)' +FILES=$(FILEREGEX=${FILEREGEX} EXCLUDE=${EXCLUDE} changed_files) + +if [ -z "${FILES}" ]; then + exit 0 +fi + +${CODESPELL_CMD} --version &> /dev/null || { + printf "%s%s: cannot execute "%s"!%s\n" "${CERROR}" "$0" "${CODESPELL_CMD}" "${CRESET}" + exit 1 +} + +CODESPELL_OPTS="-q 2" # Disable "WARNING: Binary file" +CODESPELL_OPTS+=" --check-hidden" +# Disable false positives "nd => and, 2nd", "ans => and", "tolen => token", +# "ofo => of", "WAN => WANT", "mut => must, mutt, moot" +CODESPELL_OPTS+=" --ignore-words-list=nd,ans,tolen,ofo,wan,mut " +# propagate all options to codespell -> pass "-w" to this script to write changes +CODESPELL_OPTS+="$@" + +# Filter-out all false positive raising "disabled due to" messages. +ERRORS=$(${CODESPELL_CMD} ${CODESPELL_OPTS} ${FILES} | grep -ve "disabled due to") + +if [ -n "${ERRORS}" ] +then + printf "%sThere are typos in the following files:%s\n\n" "${CERROR}" "${CRESET}" + printf "%s\n" "${ERRORS}" + # TODO: return 1 when all typos are fixed + exit 0 +else + exit 0 +fi diff --git a/contrib/Coverity/coverity.c b/contrib/Coverity/coverity.c new file mode 100644 index 00000000000..99bebae934d --- /dev/null +++ b/contrib/Coverity/coverity.c @@ -0,0 +1,106 @@ +typedef unsigned char err_t; +typedef unsigned int u32_t; +typedef unsigned short u16_t; +typedef unsigned char u8_t; +typedef void sys_sem_t; +typedef void sys_mutex_t; +typedef size_t mem_size_t; +typedef size_t memp_t; +struct pbuf; +struct netif; + +void* mem_malloc(mem_size_t size) +{ + __coverity_alloc__(size); +} +void mem_free(void* mem) +{ + __coverity_free__(mem); +} + +void* memp_malloc(memp_t type) +{ + __coverity_alloc_nosize__(); +} +void memp_free(memp_t type, void* mem) +{ + __coverity_free__(mem); +} + +void sys_mutex_lock(sys_mutex_t* mutex) +{ + __coverity_exclusive_lock_acquire__(mutex); +} +void sys_mutex_unlock(sys_mutex_t* mutex) +{ + __coverity_exclusive_lock_release__(mutex); +} + +u32_t sys_arch_sem_wait(sys_sem_t *sem, u32_t timeout) +{ + __coverity_recursive_lock_acquire__(sem); +} +void sys_sem_signal(sys_sem_t *sem) +{ + __coverity_recursive_lock_release__(sem); +} + +err_t ethernet_input(struct pbuf *p, struct netif *inp) +{ + __coverity_tainted_string_sink_content__(p); +} +err_t tcpip_input(struct pbuf *p, struct netif *inp) +{ + __coverity_tainted_string_sink_content__(p); +} +err_t ip_input(struct pbuf *p, struct netif *inp) +{ + __coverity_tainted_string_sink_content__(p); +} +err_t ip4_input(struct pbuf *p, struct netif *inp) +{ + __coverity_tainted_string_sink_content__(p); +} +err_t ip6_input(struct pbuf *p, struct netif *inp) +{ + __coverity_tainted_string_sink_content__(p); +} + +err_t pbuf_take(struct pbuf *buf, const void *dataptr, u16_t len) +{ + __coverity_tainted_string_argument__(buf); + __coverity_tainted_data_argument__(buf); +} +err_t pbuf_take_at(struct pbuf *buf, const void *dataptr, u16_t len, u16_t offset) +{ + __coverity_tainted_string_argument__(buf); + __coverity_tainted_data_argument__(buf); +} +err_t pbuf_copy(struct pbuf *p_to, struct pbuf *p_from) +{ + __coverity_tainted_data_transitive__(p_to, p_from); +} +u16_t pbuf_copy_partial(struct pbuf *p, void *dataptr, u16_t len, u16_t offset) +{ + __coverity_tainted_string_argument__(dataptr); + __coverity_tainted_data_argument__(dataptr); +} +u8_t pbuf_get_at(struct pbuf* p, u16_t offset) +{ + __coverity_tainted_data_return__(); +} + +void abort(void) +{ + __coverity_panic__(); +} + +int check_path(char* path, size_t size) +{ + if (size) { + __coverity_tainted_data_sanitize__(path); + return 1; + } else { + return 0; + } +} diff --git a/contrib/Filelists.cmake b/contrib/Filelists.cmake new file mode 100644 index 00000000000..a375dd26b19 --- /dev/null +++ b/contrib/Filelists.cmake @@ -0,0 +1,61 @@ +# This file is indended to be included in end-user CMakeLists.txt +# include(/path/to/Filelists.cmake) +# It assumes the variable LWIP_CONTRIB_DIR is defined pointing to the +# root path of lwIP/contrib sources. +# +# This file is NOT designed (on purpose) to be used as cmake +# subdir via add_subdirectory() +# The intention is to provide greater flexibility to users to +# create their own targets using the *_SRCS variables. + +if(NOT ${CMAKE_VERSION} VERSION_LESS "3.10.0") + include_guard(GLOBAL) +endif() + +set(lwipcontribexamples_SRCS + ${LWIP_CONTRIB_DIR}/examples/httpd/fs_example/fs_example.c + ${LWIP_CONTRIB_DIR}/examples/httpd/https_example/https_example.c + ${LWIP_CONTRIB_DIR}/examples/httpd/ssi_example/ssi_example.c + ${LWIP_CONTRIB_DIR}/examples/lwiperf/lwiperf_example.c + ${LWIP_CONTRIB_DIR}/examples/mdns/mdns_example.c + ${LWIP_CONTRIB_DIR}/examples/mqtt/mqtt_example.c + ${LWIP_CONTRIB_DIR}/examples/ppp/pppos_example.c + ${LWIP_CONTRIB_DIR}/examples/snmp/snmp_private_mib/lwip_prvmib.c + ${LWIP_CONTRIB_DIR}/examples/snmp/snmp_v3/snmpv3_dummy.c + ${LWIP_CONTRIB_DIR}/examples/snmp/snmp_example.c + ${LWIP_CONTRIB_DIR}/examples/sntp/sntp_example.c + ${LWIP_CONTRIB_DIR}/examples/tftp/tftp_example.c +) +add_library(lwipcontribexamples EXCLUDE_FROM_ALL ${lwipcontribexamples_SRCS}) +target_compile_options(lwipcontribexamples PRIVATE ${LWIP_COMPILER_FLAGS}) +target_compile_definitions(lwipcontribexamples PRIVATE ${LWIP_DEFINITIONS} ${LWIP_MBEDTLS_DEFINITIONS}) +target_include_directories(lwipcontribexamples PRIVATE ${LWIP_INCLUDE_DIRS} ${LWIP_MBEDTLS_INCLUDE_DIRS}) + +set(lwipcontribapps_SRCS + ${LWIP_CONTRIB_DIR}/apps/httpserver/httpserver-netconn.c + ${LWIP_CONTRIB_DIR}/apps/chargen/chargen.c + ${LWIP_CONTRIB_DIR}/apps/udpecho/udpecho.c + ${LWIP_CONTRIB_DIR}/apps/tcpecho/tcpecho.c + ${LWIP_CONTRIB_DIR}/apps/shell/shell.c + ${LWIP_CONTRIB_DIR}/apps/udpecho_raw/udpecho_raw.c + ${LWIP_CONTRIB_DIR}/apps/tcpecho_raw/tcpecho_raw.c + ${LWIP_CONTRIB_DIR}/apps/netio/netio.c + ${LWIP_CONTRIB_DIR}/apps/ping/ping.c + ${LWIP_CONTRIB_DIR}/apps/socket_examples/socket_examples.c + ${LWIP_CONTRIB_DIR}/apps/rtp/rtp.c +) +add_library(lwipcontribapps EXCLUDE_FROM_ALL ${lwipcontribapps_SRCS}) +target_compile_options(lwipcontribapps PRIVATE ${LWIP_COMPILER_FLAGS}) +target_compile_definitions(lwipcontribapps PRIVATE ${LWIP_DEFINITIONS} ${LWIP_MBEDTLS_DEFINITIONS}) +target_include_directories(lwipcontribapps PRIVATE ${LWIP_INCLUDE_DIRS} ${LWIP_MBEDTLS_INCLUDE_DIRS}) + +set(lwipcontribaddons_SRCS + ${LWIP_CONTRIB_DIR}/addons/tcp_isn/tcp_isn.c + ${LWIP_CONTRIB_DIR}/addons/ipv6_static_routing/ip6_route_table.c +# ${LWIP_CONTRIB_DIR}/addons/netconn/external_resolve/dnssd.c +# ${LWIP_CONTRIB_DIR}/addons/tcp_md5/tcp_md5.c +) +add_library(lwipcontribaddons EXCLUDE_FROM_ALL ${lwipcontribaddons_SRCS}) +target_compile_options(lwipcontribaddons PRIVATE ${LWIP_COMPILER_FLAGS}) +target_compile_definitions(lwipcontribaddons PRIVATE ${LWIP_DEFINITIONS} ${LWIP_MBEDTLS_DEFINITIONS}) +target_include_directories(lwipcontribaddons PRIVATE ${LWIP_INCLUDE_DIRS} ${LWIP_MBEDTLS_INCLUDE_DIRS}) diff --git a/contrib/Filelists.mk b/contrib/Filelists.mk new file mode 100644 index 00000000000..f0fb48b285c --- /dev/null +++ b/contrib/Filelists.mk @@ -0,0 +1,57 @@ +# +# Copyright (c) 2001, 2002 Swedish Institute of Computer Science. +# All rights reserved. +# +# Redistribution and use in source and binary forms, with or without modification, +# are permitted provided that the following conditions are met: +# +# 1. Redistributions of source code must retain the above copyright notice, +# this list of conditions and the following disclaimer. +# 2. Redistributions in binary form must reproduce the above copyright notice, +# this list of conditions and the following disclaimer in the documentation +# and/or other materials provided with the distribution. +# 3. The name of the author may not be used to endorse or promote products +# derived from this software without specific prior written permission. +# +# THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED +# WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF +# MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT +# SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, +# EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT +# OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING +# IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY +# OF SUCH DAMAGE. +# +# This file is part of the lwIP TCP/IP stack. +# +# Author: Adam Dunkels adam@sics.se +# + +# CONTRIBAPPFILES: Contrib Applications. +CONTRIBAPPFILES=$(CONTRIBDIR)/apps/httpserver/httpserver-netconn.c \ + $(CONTRIBDIR)/apps/chargen/chargen.c \ + $(CONTRIBDIR)/apps/udpecho/udpecho.c \ + $(CONTRIBDIR)/apps/tcpecho/tcpecho.c \ + $(CONTRIBDIR)/apps/shell/shell.c \ + $(CONTRIBDIR)/apps/udpecho_raw/udpecho_raw.c \ + $(CONTRIBDIR)/apps/tcpecho_raw/tcpecho_raw.c \ + $(CONTRIBDIR)/apps/netio/netio.c \ + $(CONTRIBDIR)/apps/ping/ping.c \ + $(CONTRIBDIR)/apps/socket_examples/socket_examples.c \ + $(CONTRIBDIR)/apps/rtp/rtp.c \ + $(CONTRIBDIR)/examples/httpd/fs_example/fs_example.c \ + $(CONTRIBDIR)/examples/httpd/https_example/https_example.c \ + $(CONTRIBDIR)/examples/httpd/ssi_example/ssi_example.c \ + $(CONTRIBDIR)/examples/lwiperf/lwiperf_example.c \ + $(CONTRIBDIR)/examples/mdns/mdns_example.c \ + $(CONTRIBDIR)/examples/mqtt/mqtt_example.c \ + $(CONTRIBDIR)/examples/ppp/pppos_example.c \ + $(CONTRIBDIR)/examples/snmp/snmp_private_mib/lwip_prvmib.c \ + $(CONTRIBDIR)/examples/snmp/snmp_v3/snmpv3_dummy.c \ + $(CONTRIBDIR)/examples/snmp/snmp_example.c \ + $(CONTRIBDIR)/examples/sntp/sntp_example.c \ + $(CONTRIBDIR)/examples/tftp/tftp_example.c \ + $(CONTRIBDIR)/addons/tcp_isn/tcp_isn.c \ + $(CONTRIBDIR)/addons/ipv6_static_routing/ip6_route_table.c diff --git a/contrib/addons/dhcp_extra_opts/README b/contrib/addons/dhcp_extra_opts/README new file mode 100644 index 00000000000..81a7ced5629 --- /dev/null +++ b/contrib/addons/dhcp_extra_opts/README @@ -0,0 +1,5 @@ +A simple example of using LWIP_HOOK_DHCP_PARSE/APPEND_OPTION hooks to implement: +* DHCP_OPTION_MTU (option 26) to update the netif's MTU +* DHCP_OPTION_CLIENT_ID (option 61) to advertize client's HW id of LWIP_IANA_HWTYPE_ETHERNET type + +Please follow the instructions in dhcp_extra_opts.h to add the hooks, definitions in lwipopts.h and enabling the extra options. diff --git a/contrib/addons/dhcp_extra_opts/dhcp_extra_opts.c b/contrib/addons/dhcp_extra_opts/dhcp_extra_opts.c new file mode 100644 index 00000000000..3e287bfe37c --- /dev/null +++ b/contrib/addons/dhcp_extra_opts/dhcp_extra_opts.c @@ -0,0 +1,91 @@ +/* + * Copyright (c) Espressif Systems (Shanghai) CO LTD + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. Neither the name of the copyright holder nor the names of its contributors + * may be used to endorse or promote products derived from this software + * without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE + * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR + * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER + * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, + * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE + * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + */ +#include <string.h> + +#include "lwip/prot/dhcp.h" +#include "lwip/dhcp.h" +#include "lwip/netif.h" +#include "lwip/prot/iana.h" + + +void dhcp_parse_extra_opts(struct dhcp *dhcp, uint8_t state, uint8_t option, uint8_t len, struct pbuf* p, uint16_t offset) +{ + LWIP_UNUSED_ARG(dhcp); + LWIP_UNUSED_ARG(state); + LWIP_UNUSED_ARG(option); + LWIP_UNUSED_ARG(len); + LWIP_UNUSED_ARG(p); + LWIP_UNUSED_ARG(offset); +#if LWIP_DHCP_ENABLE_MTU_UPDATE + if ((option == DHCP_OPTION_MTU) && + (state == DHCP_STATE_REBOOTING || state == DHCP_STATE_REBINDING || + state == DHCP_STATE_RENEWING || state == DHCP_STATE_REQUESTING)) { + u32_t mtu = 0; + struct netif *netif; + LWIP_ERROR("dhcp_parse_extra_opts(): MTU option's len != 2", len == 2, return;); + LWIP_ERROR("dhcp_parse_extra_opts(): extracting MTU option failed", + pbuf_copy_partial(p, &mtu, 2, offset) == 2, return;); + mtu = lwip_htons((u16_t)mtu); + NETIF_FOREACH(netif) { + /* find the netif related to this dhcp */ + if (dhcp == netif_dhcp_data(netif)) { + if (mtu < netif->mtu) { + netif->mtu = mtu; + LWIP_DEBUGF(DHCP_DEBUG | LWIP_DBG_TRACE, ("dhcp_parse_extra_opts(): Negotiated netif MTU is %d\n", netif->mtu)); + } + return; + } + } + } /* DHCP_OPTION_MTU */ +#endif /* LWIP_DHCP_ENABLE_MTU_UPDATE */ +} + +void dhcp_append_extra_opts(struct netif *netif, uint8_t state, struct dhcp_msg *msg_out, uint16_t *options_out_len) +{ + LWIP_UNUSED_ARG(netif); + LWIP_UNUSED_ARG(state); + LWIP_UNUSED_ARG(msg_out); + LWIP_UNUSED_ARG(options_out_len); +#if LWIP_DHCP_ENABLE_CLIENT_ID + if (state == DHCP_STATE_RENEWING || state == DHCP_STATE_REBINDING || + state == DHCP_STATE_REBOOTING || state == DHCP_STATE_OFF || + state == DHCP_STATE_REQUESTING || state == DHCP_STATE_BACKING_OFF || state == DHCP_STATE_SELECTING) { + size_t i; + u8_t *options = msg_out->options + *options_out_len; + LWIP_ERROR("dhcp_append(client_id): options_out_len + 3 + netif->hwaddr_len <= DHCP_OPTIONS_LEN", + *options_out_len + 3U + netif->hwaddr_len <= DHCP_OPTIONS_LEN, return;); + *options_out_len = *options_out_len + netif->hwaddr_len + 3; + *options++ = DHCP_OPTION_CLIENT_ID; + *options++ = netif->hwaddr_len + 1; /* option size */ + *options++ = LWIP_IANA_HWTYPE_ETHERNET; + for (i = 0; i < netif->hwaddr_len; i++) { + *options++ = netif->hwaddr[i]; + } + } +#endif /* LWIP_DHCP_ENABLE_CLIENT_ID */ +} diff --git a/contrib/addons/dhcp_extra_opts/dhcp_extra_opts.h b/contrib/addons/dhcp_extra_opts/dhcp_extra_opts.h new file mode 100644 index 00000000000..959404d0d18 --- /dev/null +++ b/contrib/addons/dhcp_extra_opts/dhcp_extra_opts.h @@ -0,0 +1,61 @@ +/* + * Copyright (c) Espressif Systems (Shanghai) CO LTD + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. Neither the name of the copyright holder nor the names of its contributors + * may be used to endorse or promote products derived from this software + * without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE + * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR + * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER + * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, + * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE + * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + * + * To use these additional DHCP options, make sure this file is included in LWIP_HOOK_FILENAME + * and define these hooks: + * + * #define LWIP_HOOK_DHCP_PARSE_OPTION(netif, dhcp, state, msg, msg_type, option, len, pbuf, offset) \ + * do { LWIP_UNUSED_ARG(msg); \ + * dhcp_parse_extra_opts(dhcp, state, option, len, pbuf, offset); \ + * } while(0) + * + * #define LWIP_HOOK_DHCP_APPEND_OPTIONS(netif, dhcp, state, msg, msg_type, options_len_ptr) \ + * dhcp_append_extra_opts(netif, state, msg, options_len_ptr); + * + * To enable (disable) these option, please set one or both of the below macros to 1 (0) + * #define LWIP_DHCP_ENABLE_MTU_UPDATE 1 + * #define LWIP_DHCP_ENABLE_CLIENT_ID 1 + */ + +#ifndef LWIP_HDR_CONTRIB_ADDONS_DHCP_OPTS_H +#define LWIP_HDR_CONTRIB_ADDONS_DHCP_OPTS_H + +/* Add standard integers so the header could be included before lwip */ +#include <stdint.h> + +/* Forward declare lwip structs */ +struct dhcp; +struct pbuf; +struct dhcp; +struct netif; +struct dhcp_msg; + +/* Internal hook functions */ +void dhcp_parse_extra_opts(struct dhcp *dhcp, uint8_t state, uint8_t option, uint8_t len, struct pbuf* p, uint16_t offset); +void dhcp_append_extra_opts(struct netif *netif, uint8_t state, struct dhcp_msg *msg_out, uint16_t *options_out_len); + +#endif /* LWIP_HDR_CONTRIB_ADDONS_DHCP_OPTS_H */ diff --git a/contrib/addons/ipv6_static_routing/README b/contrib/addons/ipv6_static_routing/README new file mode 100644 index 00000000000..0c3b06cc08f --- /dev/null +++ b/contrib/addons/ipv6_static_routing/README @@ -0,0 +1,43 @@ +A simple routing table implementation for addition, deletion and lookup of IPv6 routes. + +APIs are: +1) s8_t ip6_add_route_entry(struct ip6_prefix *ip6_prefix, + struct netif *netif, + ip6_addr_t *gateway, + s8_t *index); + +2) err_t ip6_remove_route_entry(struct ip6_prefix *ip6_prefix); + +3) s8_t ip6_find_route_entry(ip6_addr_t *ip6_dest_addr); + +4) struct netif *ip6_static_route(ip6_addr_t *src, ip6_addr_t *dest); + +5) ip6_addr_t *ip6_get_gateway(struct netif *netif, ip6_addr_t *dest); + +6) struct ip6_route_entry *ip6_get_route_table(void); + +For route lookup from the table, The LWIP_HOOK_IP6_ROUTE hook in ip6_route(..) of ip6.c +could be assigned to the ip6_static_route() API of this implementation to return the +appropriate netif. + +-- The application can add routes using the API ip6_add_route_entry(..). + This API adds the ip6 prefix route into the static route table while + keeping all entries sorted in decreasing order of prefix length. + Subsequently, a linear search down the list can be performed to retrieve a + matching route entry for a Longest Prefix Match. + The prefix length is expected to be at an 8-bit boundary. While this is + a limitation, it would serve most practical purposes. + +-- The application can remove routes using the API ip6_remove_route_entry(..). + +-- The application can find a route entry for a specific address using the + ip6_find_route_entry() function which returns the index of the found entry. + This is used internally by the route lookup function ip6_static_route() API. + +-- To fetch the gateway IPv6 address for a specific destination IPv6 + address and target netif, the application can call ip6_get_gateway(..). + This API could be assigned to the LWIP_HOOK_ND6_GET_GW() if a gateway has + been added as part of the ip6_add_route_entry(). + +-- To fetch a pointer to the head of the table, the application can call + ip6_get_route_table(). diff --git a/contrib/addons/ipv6_static_routing/ip6_route_table.c b/contrib/addons/ipv6_static_routing/ip6_route_table.c new file mode 100644 index 00000000000..a92dd33706d --- /dev/null +++ b/contrib/addons/ipv6_static_routing/ip6_route_table.c @@ -0,0 +1,248 @@ +/** + * @file + * IPv6 static route table. + */ + +/* + * Copyright (c) 2015 Nest Labs, Inc. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * Author: Pradip De pradipd@google.com + * + * + * Please coordinate changes and requests with Pradip De + * pradipd@google.com + */ + +#include "lwip/opt.h" + +#if LWIP_IPV6 /* don't build if not configured for use in lwipopts.h */ + +#include "ip6_route_table.h" +#include "lwip/def.h" +#include "lwip/mem.h" +#include "lwip/netif.h" +#include "lwip/ip6.h" +#include "lwip/ip6_addr.h" +#include "lwip/nd6.h" +#include "lwip/debug.h" +#include "lwip/stats.h" + +#include "string.h" + +static struct ip6_route_entry static_route_table[LWIP_IPV6_NUM_ROUTE_ENTRIES]; + +/** + * Add the ip6 prefix route and target netif into the static route table while + * keeping all entries sorted in decreasing order of prefix length. + * 1. Search from the last entry up to find the correct slot to insert while + * moving entries one position down to create room. + * 2. Insert into empty slot created. + * + * Subsequently, a linear search down the list can be performed to retrieve a + * matching route entry for a Longest Prefix Match. + * + * @param ip6_prefix the route prefix entry to add. + * @param netif pointer to target netif. + * @param gateway the gateway address to use to send through. Has to be link local. + * @param idx return value argument of index where route entry was added in table. + * @return ERR_OK if addition was successful. + * ERR_MEM if table is already full. + * ERR_ARG if passed argument is bad or route already exists in table. + */ +err_t +ip6_add_route_entry(const struct ip6_prefix *ip6_prefix, struct netif *netif, const ip6_addr_t *gateway, s8_t *idx) +{ + s8_t i = -1; + err_t retval = ERR_OK; + + if (!ip6_prefix_valid(ip6_prefix->prefix_len) || (netif == NULL)) { + retval = ERR_ARG; + goto exit; + } + + /* Check if an entry already exists with matching prefix; If so, replace it. */ + for (i = 0; i < LWIP_IPV6_NUM_ROUTE_ENTRIES; i++) { + if ((ip6_prefix->prefix_len == static_route_table[i].prefix.prefix_len) && + memcmp(&ip6_prefix->addr, &static_route_table[i].prefix.addr, + ip6_prefix->prefix_len / 8) == 0) { + /* Prefix matches; replace the netif with the one being added. */ + goto insert; + } + } + + /* Check if the table is full */ + if (static_route_table[LWIP_IPV6_NUM_ROUTE_ENTRIES - 1].netif != NULL) { + retval = ERR_MEM; + goto exit; + } + + /* Shift all entries down the table until slot is found */ + for (i = LWIP_IPV6_NUM_ROUTE_ENTRIES - 1; + i > 0 && (ip6_prefix->prefix_len > static_route_table[i - 1].prefix.prefix_len); i--) { + SMEMCPY(&static_route_table[i], &static_route_table[i - 1], sizeof(struct ip6_route_entry)); + } + +insert: + /* Insert into the slot selected */ + SMEMCPY(&static_route_table[i].prefix, ip6_prefix, sizeof(struct ip6_prefix)); + static_route_table[i].netif = netif; + + /* Add gateway to route table */ + static_route_table[i].gateway = gateway; + + if (idx != NULL) { + *idx = i; + } + +exit: + return retval; +} + +/** + * Removes the route entry from the static route table. + * + * @param ip6_prefix the route prefix entry to delete. + */ +void +ip6_remove_route_entry(const struct ip6_prefix *ip6_prefix) +{ + int i, pos = -1; + + for (i = 0; i < LWIP_IPV6_NUM_ROUTE_ENTRIES; i++) { + /* compare prefix to find position to delete */ + if (ip6_prefix->prefix_len == static_route_table[i].prefix.prefix_len && + memcmp(&ip6_prefix->addr, &static_route_table[i].prefix.addr, + ip6_prefix->prefix_len / 8) == 0) { + pos = i; + break; + } + } + + if (pos >= 0) { + /* Shift everything beyond pos one slot up */ + for (i = pos; i < LWIP_IPV6_NUM_ROUTE_ENTRIES - 1; i++) { + SMEMCPY(&static_route_table[i], &static_route_table[i+1], sizeof(struct ip6_route_entry)); + if (static_route_table[i].netif == NULL) { + break; + } + } + /* Zero the remaining entries */ + for (; i < LWIP_IPV6_NUM_ROUTE_ENTRIES; i++) { + ip6_addr_set_zero((&static_route_table[i].prefix.addr)); + static_route_table[i].netif = NULL; + } + } +} + +/** + * Finds the appropriate route entry in the static route table corresponding to the given + * destination IPv6 address. Since the entries in the route table are kept sorted in decreasing + * order of prefix length, a linear search down the list is performed to retrieve a matching + * index. + * + * @param ip6_dest_addr the destination address to match + * @return the idx of the found route entry; -1 if not found. + */ +s8_t +ip6_find_route_entry(const ip6_addr_t *ip6_dest_addr) +{ + s8_t i, idx = -1; + + /* Search prefix in the sorted(decreasing order of prefix length) list */ + for(i = 0; i < LWIP_IPV6_NUM_ROUTE_ENTRIES; i++) { + if (memcmp(ip6_dest_addr, &static_route_table[i].prefix.addr, + static_route_table[i].prefix.prefix_len / 8) == 0) { + idx = i; + break; + } + } + + return idx; +} + +/** + * Finds the appropriate network interface for a given IPv6 address from a routing table with + * static IPv6 routes. + * + * @param src the source IPv6 address, if known + * @param dest the destination IPv6 address for which to find the route + * @return the netif on which to send to reach dest + */ +struct netif * +ip6_static_route(const ip6_addr_t *src, const ip6_addr_t *dest) +{ + int i; + + LWIP_UNUSED_ARG(src); + + /* Perform table lookup */ + i = ip6_find_route_entry(dest); + + if (i >= 0) { + return static_route_table[i].netif; + } else { + return NULL; + } +} + +/** + * Finds the gateway IP6 address for a given destination IPv6 address and target netif + * from a routing table with static IPv6 routes. + * + * @param netif the netif used for sending + * @param dest the destination IPv6 address + * @return the ip6 address of the gateway to forward packet to + */ +const ip6_addr_t * +ip6_get_gateway(struct netif *netif, const ip6_addr_t *dest) +{ + const ip6_addr_t *ret_gw = NULL; + const int i = ip6_find_route_entry(dest); + + LWIP_UNUSED_ARG(netif); + + if (i >= 0) { + if (static_route_table[i].gateway != NULL) { + ret_gw = static_route_table[i].gateway; + } + } + + return ret_gw; +} + +/** + * Returns the top of the route table. + * This should be used for debug printing only. + * + * @return the top of the route table. + */ +const struct ip6_route_entry * +ip6_get_route_table(void) +{ + return static_route_table; +} + +#endif /* LWIP_IPV6 */ diff --git a/contrib/addons/ipv6_static_routing/ip6_route_table.h b/contrib/addons/ipv6_static_routing/ip6_route_table.h new file mode 100644 index 00000000000..478328e47d7 --- /dev/null +++ b/contrib/addons/ipv6_static_routing/ip6_route_table.h @@ -0,0 +1,94 @@ +/** + * @file + * + * IPv6 static route table. + */ + +/* + * Copyright (c) 2015 Nest Labs, Inc. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * Author: Pradip De pradipd@google.com + * + * + * Please coordinate changes and requests with Pradip De + * pradipd@google.com + */ + +#ifndef __LWIP_IP6_ROUTE_TABLE_H__ +#define __LWIP_IP6_ROUTE_TABLE_H__ + +#include "lwip/opt.h" + +#if LWIP_IPV6 /* don't build if not configured for use in lwipopts.h */ + +#include "lwip/ip6_addr.h" +#include "lwip/err.h" + +#ifdef __cplusplus +extern "C" { +#endif + +struct netif; + +/** + * LWIP_IPV6_NUM_ROUTES: Number of IPV6 routes that can be kept in the static route table. + */ +#ifndef LWIP_IPV6_NUM_ROUTE_ENTRIES +#define LWIP_IPV6_NUM_ROUTE_ENTRIES (8) +#endif + +#define IP6_MAX_PREFIX_LEN (128) +#define IP6_PREFIX_ALLOWED_GRANULARITY (8) +/* Prefix length cannot be greater than 128 bits and needs to be at a byte boundary */ +#define ip6_prefix_valid(prefix_len) (((prefix_len) <= IP6_MAX_PREFIX_LEN) && \ + (((prefix_len) % IP6_PREFIX_ALLOWED_GRANULARITY) == 0)) + +struct ip6_prefix { + ip6_addr_t addr; + u8_t prefix_len; /* prefix length in bits at byte boundaries */ +}; + +struct ip6_route_entry { + struct ip6_prefix prefix; + struct netif *netif; + const ip6_addr_t *gateway; +}; + +err_t ip6_add_route_entry(const struct ip6_prefix *ip6_prefix, struct netif *netif, + const ip6_addr_t *gateway, s8_t *idx); +void ip6_remove_route_entry(const struct ip6_prefix *ip6_prefix); +s8_t ip6_find_route_entry(const ip6_addr_t *ip6_dest_addr); +struct netif *ip6_static_route(const ip6_addr_t *src, const ip6_addr_t *dest); +const ip6_addr_t *ip6_get_gateway(struct netif *netif, const ip6_addr_t *dest); +const struct ip6_route_entry *ip6_get_route_table(void); + +#ifdef __cplusplus +} +#endif + +#endif /* LWIP_IPV6 */ + +#endif /* __LWIP_IP6_ROUTE_TABLE_H__ */ diff --git a/contrib/addons/netconn/external_resolve/dnssd.c b/contrib/addons/netconn/external_resolve/dnssd.c new file mode 100644 index 00000000000..d26743bc65c --- /dev/null +++ b/contrib/addons/netconn/external_resolve/dnssd.c @@ -0,0 +1,164 @@ +/** + * @file + * DNS-SD APIs used by LWIP_HOOK_NETCONN_EXTERNAL_RESOLVE + * + * This implementation assumes the DNS-SD API implementation (most likely provided by + * mDNSResponder) is implemented in the same process space as LwIP and can directly + * invoke the callback for DNSServiceGetAddrInfo. This is the typical deployment in + * an embedded environment where as a traditional OS requires pumping the callback results + * through an IPC mechanism (see DNSServiceRefSockFD/DNSServiceProcessResult) + * + * @defgroup dnssd DNS-SD + * @ingroup dns + */ + +/* + * Copyright (c) 2017 Joel Cunningham, Garmin International, Inc. joel.cunningham@garmin.com + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Joel Cunningham joel.cunningham@me.com + * + */ +#include "lwip/opt.h" + +#include "lwip/err.h" +#include "lwip/inet.h" +#include "lwip/sockets.h" +#include "lwip/sys.h" + +#include "dnssd.h" + +/* External headers */ +#include <string.h> +#include <dns_sd.h> + +/* This timeout should allow for multiple queries. +mDNSResponder has the following query timeline: + Query 1: time = 0s + Query 2: time = 1s + Query 3: time = 4s +*/ +#define GETADDR_TIMEOUT_MS 5000 +#define LOCAL_DOMAIN ".local" + +/* Only consume .local hosts */ +#ifndef CONSUME_LOCAL_ONLY +#define CONSUME_LOCAL_ONLY 1 +#endif + +struct addr_clbk_msg { + sys_sem_t sem; + struct sockaddr_storage addr; + err_t err; +}; + +static void addr_info_callback(DNSServiceRef ref, DNSServiceFlags flags, u32_t interface_index, + DNSServiceErrorType error_code, char const* hostname, + const struct sockaddr* address, u32_t ttl, void* context); + +int +lwip_dnssd_gethostbyname(const char *name, ip_addr_t *addr, u8_t addrtype, err_t *err) +{ + DNSServiceErrorType result; + DNSServiceRef ref; + struct addr_clbk_msg msg; + char *p; + + /* @todo: use with IPv6 */ + LWIP_UNUSED_ARG(addrtype); + +#if CONSUME_LOCAL_ONLY + /* check if this is a .local host. If it is, then we consume the query */ + p = strstr(name, LOCAL_DOMAIN); + if (p == NULL) { + return 0; /* not consumed */ + } + p += (sizeof(LOCAL_DOMAIN) - 1); + /* check to make sure .local isn't a substring (only allow .local\0 or .local.\0) */ + if ((*p != '.' && *p != '\0') || + (*p == '.' && *(p + 1) != '\0')) { + return 0; /* not consumed */ + } +#endif /* CONSUME_LOCAL_ONLY */ + + msg.err = sys_sem_new(&msg.sem, 0); + if (msg.err != ERR_OK) { + goto query_done; + } + + msg.err = ERR_TIMEOUT; + result = DNSServiceGetAddrInfo(&ref, 0, 0, kDNSServiceProtocol_IPv4, name, addr_info_callback, &msg); + if (result == kDNSServiceErr_NoError) { + sys_arch_sem_wait(&msg.sem, GETADDR_TIMEOUT_MS); + DNSServiceRefDeallocate(ref); + + /* We got a response */ + if (msg.err == ERR_OK) { + struct sockaddr_in* addr_in = (struct sockaddr_in *)&msg.addr; + if (addr_in->sin_family == AF_INET) { + inet_addr_to_ip4addr(ip_2_ip4(addr), &addr_in->sin_addr); + } else { + /* @todo add IPv6 support */ + msg.err = ERR_VAL; + } + } + } + sys_sem_free(&msg.sem); + +/* Query has been consumed and is finished */ +query_done: +*err = msg.err; +return 1; +} + +static void +addr_info_callback(DNSServiceRef ref, DNSServiceFlags flags, u32_t interface_index, + DNSServiceErrorType error_code, char const* hostname, + const struct sockaddr* address, u32_t ttl, void* context) +{ + struct addr_clbk_msg* msg = (struct addr_clbk_msg*)context; + struct sockaddr_in* addr_in = (struct sockaddr_in *)address; + + LWIP_UNUSED_ARG(ref); + LWIP_UNUSED_ARG(flags); + LWIP_UNUSED_ARG(interface_index); + LWIP_UNUSED_ARG(hostname); + LWIP_UNUSED_ARG(ttl); + LWIP_UNUSED_ARG(context); + + if ((error_code == kDNSServiceErr_NoError) && + (addr_in->sin_family == AF_INET)) { + MEMCPY(&msg->addr, addr_in, sizeof(*addr_in)); + msg->err = ERR_OK; + } + else { + /* @todo add IPv6 support */ + msg->err = ERR_VAL; + } + + sys_sem_signal(&msg->sem); +} /* addr_info_callback() */ diff --git a/contrib/addons/netconn/external_resolve/dnssd.h b/contrib/addons/netconn/external_resolve/dnssd.h new file mode 100644 index 00000000000..e2d71d93083 --- /dev/null +++ b/contrib/addons/netconn/external_resolve/dnssd.h @@ -0,0 +1,50 @@ +/** + * @file + * DNS-SD APIs used by LWIP_HOOK_NETCONN_EXTERNAL_RESOLVE + * + * @defgroup dnssd DNS-SD + * @ingroup dns + */ + +/* + * Copyright (c) 2017 Joel Cunningham, Garmin International, Inc. joel.cunningham@garmin.com + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Joel Cunningham joel.cunningham@me.com + * + */ +#include "lwip/opt.h" + +#ifndef LWIP_HDR_DNSSD_H +#define LWIP_HDR_DNSSD_H + +#include "lwip/err.h" +#include "lwip/ip_addr.h" + +int lwip_dnssd_gethostbyname(const char *name, ip_addr_t *addr, u8_t addrtype, err_t *err); + +#endif /* LWIP_HDR_DNSSD_H */ diff --git a/contrib/addons/tcp_isn/tcp_isn.c b/contrib/addons/tcp_isn/tcp_isn.c new file mode 100644 index 00000000000..c1614996381 --- /dev/null +++ b/contrib/addons/tcp_isn/tcp_isn.c @@ -0,0 +1,182 @@ +/** + * @file + * + * Reference implementation of the TCP ISN algorithm standardized in RFC 6528. + * Produce TCP Initial Sequence Numbers by combining an MD5-generated hash + * based on the new TCP connection's identity and a stable secret, with the + * current time at 4-microsecond granularity. + * + * Specifically, the implementation uses MD5 to compute a hash of the input + * buffer, which contains both the four-tuple of the new TCP connection (local + * and remote IP address and port), as well as a 16-byte secret to make the + * results unpredictable to external parties. The secret must be given at + * initialization time and should ideally remain the same across system + * reboots. To be sure: the spoofing-resistance of the resulting ISN depends + * mainly on the strength of the supplied secret! + * + * The implementation takes 32 bits from the computed hash, and adds to it the + * current time, in 4-microsecond units. The current time is computed from a + * boot time given at initialization, and the current uptime as provided by + * sys_now(). Thus, it assumes that sys_now() returns a time value that is + * relative to the boot time, i.e., that it starts at 0 at system boot, and + * only ever increases monotonically. + * + * For efficiency reasons, a single MD5 input buffer is used, and partially + * filled in at initialization time. Specifically, of this 64-byte buffer, the + * first 36 bytes are used for the four-way TCP tuple data, followed by the + * 16-byte secret, followed by 12-byte zero padding. The 64-byte size of the + * buffer should achieve the best performance for the actual MD5 computation. + * + * Basic usage: + * + * 1. in your lwipopts.h, add the following lines: + * + * #include <lwip/arch.h> + * struct ip_addr; + * u32_t lwip_hook_tcp_isn(const struct ip_addr *local_ip, u16_t local_port, + * const struct ip_addr *remote_ip, u16_t remote_port); + * "#define LWIP_HOOK_TCP_ISN lwip_hook_tcp_isn"; + * + * 2. from your own code, call lwip_init_tcp_isn() at initialization time, with + * appropriate parameters. + */ + +/* + * Copyright (c) 2016 The MINIX 3 Project. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * Author: David van Moolenbroek david@minix3.org + */ + +#include "tcp_isn.h" +#include "lwip/ip_addr.h" +#include "lwip/sys.h" +#include <string.h> + +#ifdef LWIP_HOOK_TCP_ISN + +/* pull in md5 of ppp? */ +#include "netif/ppp/ppp_opts.h" +#if !PPP_SUPPORT || (!LWIP_USE_EXTERNAL_POLARSSL && !LWIP_USE_EXTERNAL_MBEDTLS) +#undef LWIP_INCLUDED_POLARSSL_MD5 +#define LWIP_INCLUDED_POLARSSL_MD5 1 +#include "netif/ppp/polarssl/md5.h" +#endif + +static u8_t input[64]; +static u32_t base_time; + +/** + * Initialize the TCP ISN module, with the boot time and a secret. + * + * @param boot_time Wall clock boot time of the system, in seconds. + * @param secret_16_bytes A 16-byte secret used to randomize the TCP ISNs. + */ +void +lwip_init_tcp_isn(u32_t boot_time, const u8_t *secret_16_bytes) +{ + /* Initialize the input buffer with the secret and trailing zeroes. */ + memset(input, 0, sizeof(input)); + + MEMCPY(&input[36], secret_16_bytes, 16); + + /* Save the boot time in 4-us units. Overflow is no problem here. */ + base_time = boot_time * 250000; +} + +/** + * Hook to generate an Initial Sequence Number (ISN) for a new TCP connection. + * + * @param local_ip The local IP address. + * @param local_port The local port number, in host-byte order. + * @param remote_ip The remote IP address. + * @param remote_port The remote port number, in host-byte order. + * @return The ISN to use for the new TCP connection. + */ +u32_t +lwip_hook_tcp_isn(const ip_addr_t *local_ip, u16_t local_port, + const ip_addr_t *remote_ip, u16_t remote_port) +{ + md5_context ctx; + u8_t output[16]; + u32_t isn; + +#if LWIP_IPV4 && LWIP_IPV6 + if (IP_IS_V6(local_ip)) +#endif /* LWIP_IPV4 && LWIP_IPV6 */ +#if LWIP_IPV6 + { + const ip6_addr_t *local_ip6, *remote_ip6; + + local_ip6 = ip_2_ip6(local_ip); + remote_ip6 = ip_2_ip6(remote_ip); + + SMEMCPY(&input[0], &local_ip6->addr, 16); + SMEMCPY(&input[16], &remote_ip6->addr, 16); + } +#endif /* LWIP_IPV6 */ +#if LWIP_IPV4 && LWIP_IPV6 + else +#endif /* LWIP_IPV4 && LWIP_IPV6 */ +#if LWIP_IPV4 + { + const ip4_addr_t *local_ip4, *remote_ip4; + + local_ip4 = ip_2_ip4(local_ip); + remote_ip4 = ip_2_ip4(remote_ip); + + /* Represent IPv4 addresses as IPv4-mapped IPv6 addresses, to ensure that + * the IPv4 and IPv6 address spaces are completely disjoint. */ + memset(&input[0], 0, 10); + input[10] = 0xff; + input[11] = 0xff; + SMEMCPY(&input[12], &local_ip4->addr, 4); + memset(&input[16], 0, 10); + input[26] = 0xff; + input[27] = 0xff; + SMEMCPY(&input[28], &remote_ip4->addr, 4); + } +#endif /* LWIP_IPV4 */ + + input[32] = (u8_t)(local_port >> 8); + input[33] = (u8_t)(local_port & 0xff); + input[34] = (u8_t)(remote_port >> 8); + input[35] = (u8_t)(remote_port & 0xff); + + /* The secret and padding are already filled in. */ + + /* Generate the hash, using MD5. */ + md5_starts(&ctx); + md5_update(&ctx, input, sizeof(input)); + md5_finish(&ctx, output); + + /* Arbitrarily take the first 32 bits from the generated hash. */ + MEMCPY(&isn, output, sizeof(isn)); + + /* Add the current time in 4-microsecond units. */ + return isn + base_time + sys_now() * 250; +} + +#endif /* LWIP_HOOK_TCP_ISN */ diff --git a/contrib/addons/tcp_isn/tcp_isn.h b/contrib/addons/tcp_isn/tcp_isn.h new file mode 100644 index 00000000000..ebaeca24729 --- /dev/null +++ b/contrib/addons/tcp_isn/tcp_isn.h @@ -0,0 +1,48 @@ +/* + * Copyright (c) 2016 The MINIX 3 Project. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * Author: David van Moolenbroek david@minix3.org + */ + +#ifndef LWIP_HDR_CONTRIB_ADDONS_TCP_ISN_H +#define LWIP_HDR_CONTRIB_ADDONS_TCP_ISN_H + +#include "lwip/opt.h" +#include "lwip/ip_addr.h" + +#ifdef __cplusplus +extern "C" { +#endif + +void lwip_init_tcp_isn(u32_t boot_time, const u8_t *secret_16_bytes); +u32_t lwip_hook_tcp_isn(const ip_addr_t *local_ip, u16_t local_port, + const ip_addr_t *remote_ip, u16_t remote_port); + +#ifdef __cplusplus +} +#endif + +#endif /* LWIP_HDR_CONTRIB_ADDONS_TCP_ISN_H */ diff --git a/contrib/addons/tcp_md5/README b/contrib/addons/tcp_md5/README new file mode 100644 index 00000000000..a6408ca2c20 --- /dev/null +++ b/contrib/addons/tcp_md5/README @@ -0,0 +1,27 @@ +This folder provides an example implementation of how to add custom tcp header +options and custom socket options. + +It does this by implementing the (seldom used) tcp md5 signature. + +To enable it, add an LWIP_HOOK_FILENAME hook file, include tcp_md5.h in it and +define these hooks: + + #define LWIP_HOOK_TCP_INPACKET_PCB(pcb, hdr, optlen, opt1len, opt2, p) tcp_md5_check_inpacket(pcb, hdr, optlen, opt1len, opt2, p) + #define LWIP_HOOK_TCP_OPT_LENGTH_SEGMENT(pcb, internal_len) tcp_md5_get_additional_option_length(pcb, internal_len) + #define LWIP_HOOK_TCP_ADD_TX_OPTIONS(p, hdr, pcb, opts) tcp_md5_add_tx_options(p, hdr, pcb, opts) + #define LWIP_HOOK_SOCKETS_SETSOCKOPT(s, sock, level, optname, optval, optlen, err) tcp_md5_setsockopt_hook(sock, level, optname, optval, optlen, err) + +Then, in your sockets application, enable md5 signature on a socket like this: + + struct tcp_md5sig md5; + struct sockaddr_storage addr_remote; /* Initialize this to remote address and port */ + memcpy(&md5.tcpm_addr, &addr_remote, sizeof(addr_remote)); + strcpy(md5.tcpm_key, key); /* this is the md5 key per connection */ + md5.tcpm_keylen = strlen(key); + if ((ret = setsockopt(sockfd, IPPROTO_TCP, TCP_MD5SIG, &md5, sizeof(md5))) < 0) { + perror("setsockopt TCP_MD5SIG"); + return; + } + +After that, your connection (client) or all incoming connections (server) require +tcp md5 signatures. diff --git a/contrib/addons/tcp_md5/tcp_md5.c b/contrib/addons/tcp_md5/tcp_md5.c new file mode 100644 index 00000000000..e7815d8f19c --- /dev/null +++ b/contrib/addons/tcp_md5/tcp_md5.c @@ -0,0 +1,534 @@ +/** + * @file: An implementation of TCP MD5 signatures by using various hooks in + * lwIP to implement custom tcp options and custom socket options. + */ + +/* + * Copyright (c) 2018 Simon Goldschmidt + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * Author: Simon Goldschmidt goldsimon@gmx.de + */ + +#include "tcp_md5.h" +#include "lwip/ip_addr.h" +#include "lwip/sys.h" +#include "lwip/prot/tcp.h" +#include "lwip/priv/tcp_priv.h" +#include "lwip/sockets.h" +#include "lwip/priv/sockets_priv.h" +#include "lwip/api.h" +#include <string.h> + +/* pull in md5 of ppp? */ +#include "netif/ppp/ppp_opts.h" +#if !PPP_SUPPORT || (!LWIP_USE_EXTERNAL_POLARSSL && !LWIP_USE_EXTERNAL_MBEDTLS) +#undef LWIP_INCLUDED_POLARSSL_MD5 +#define LWIP_INCLUDED_POLARSSL_MD5 1 +#include "netif/ppp/polarssl/md5.h" +#endif + +#if !LWIP_TCP_PCB_NUM_EXT_ARGS +#error tcp_md5 needs LWIP_TCP_PCB_NUM_EXT_ARGS +#endif + +#define LWIP_TCP_OPT_MD5 19 /* number of the md5 option */ +#define LWIP_TCP_OPT_LEN_MD5 18 /* length of the md5 option */ +#define LWIP_TCP_OPT_LEN_MD5_OUT 20 /* 18 + alignment */ + +#define LWIP_TCP_MD5_DIGEST_LEN 16 + +/* This keeps the md5 state internally */ +struct tcp_md5_conn_info { + struct tcp_md5_conn_info *next; + ip_addr_t remote_addr; + u16_t remote_port; + u8_t key[TCP_MD5SIG_MAXKEYLEN]; + u16_t key_len; +}; + +/* Callback function prototypes: */ +static void tcp_md5_extarg_destroy(u8_t id, void *data); +static err_t tcp_md5_extarg_passive_open(u8_t id, struct tcp_pcb_listen *lpcb, struct tcp_pcb *cpcb); +/* Define our tcp ext arg callback structure: */ +const struct tcp_ext_arg_callbacks tcp_md5_ext_arg_callbacks = { + tcp_md5_extarg_destroy, + tcp_md5_extarg_passive_open +}; + +static u8_t tcp_md5_extarg_id = LWIP_TCP_PCB_NUM_EXT_ARG_ID_INVALID; +static u8_t tcp_md5_opts_buf[40]; + +/** Initialize this module (allocates a tcp ext arg id) */ +void +tcp_md5_init(void) +{ + tcp_md5_extarg_id = tcp_ext_arg_alloc_id(); +} + +/* Create a conn-info structure that holds the md5 state per connection */ +static struct tcp_md5_conn_info * +tcp_md5_conn_info_alloc(void) +{ + return (struct tcp_md5_conn_info *)mem_malloc(sizeof(struct tcp_md5_conn_info)); +} + +/* Frees a conn-info structure that holds the md5 state per connection */ +static void +tcp_md5_conn_info_free(struct tcp_md5_conn_info *info) +{ + mem_free(info); +} + +/* A pcb is about to be destroyed. Free its extdata */ +static void +tcp_md5_extarg_destroy(u8_t id, void *data) +{ + struct tcp_md5_conn_info *iter; + + LWIP_ASSERT("tcp_md5_extarg_id != LWIP_TCP_PCB_NUM_EXT_ARG_ID_INVALID", + tcp_md5_extarg_id != LWIP_TCP_PCB_NUM_EXT_ARG_ID_INVALID); + LWIP_ASSERT("id == tcp_md5_extarg_id", id == tcp_md5_extarg_id); + LWIP_UNUSED_ARG(id); + + iter = (struct tcp_md5_conn_info *)data; + while (iter != NULL) { + struct tcp_md5_conn_info *info = iter; + iter = iter->next; + tcp_md5_conn_info_free(info); + } +} + +/* Try to find an md5 connection info for the specified remote connection */ +static struct tcp_md5_conn_info * +tcp_md5_get_info(const struct tcp_pcb *pcb, const ip_addr_t *remote_ip, u16_t remote_port) +{ + if (pcb != NULL) { + struct tcp_md5_conn_info *info = (struct tcp_md5_conn_info *)tcp_ext_arg_get(pcb, tcp_md5_extarg_id); + while (info != NULL) { + if (ip_addr_eq(&info->remote_addr, remote_ip)) { + if (info->remote_port == remote_port) { + return info; + } + } + info = info->next; + } + } + return NULL; +} + +/* Passive open: copy md5 connection info from listen pcb to connection pcb + * or return error (connection will be closed) + */ +static err_t +tcp_md5_extarg_passive_open(u8_t id, struct tcp_pcb_listen *lpcb, struct tcp_pcb *cpcb) +{ + struct tcp_md5_conn_info *iter; + + LWIP_ASSERT("lpcb != NULL", lpcb != NULL); + LWIP_ASSERT("cpcb != NULL", cpcb != NULL); + LWIP_ASSERT("tcp_md5_extarg_id != LWIP_TCP_PCB_NUM_EXT_ARG_ID_INVALID", + tcp_md5_extarg_id != LWIP_TCP_PCB_NUM_EXT_ARG_ID_INVALID); + LWIP_ASSERT("id == tcp_md5_extarg_id", id == tcp_md5_extarg_id); + LWIP_UNUSED_ARG(id); + + iter = (struct tcp_md5_conn_info *)tcp_ext_arg_get((struct tcp_pcb *)lpcb, id); + while (iter != NULL) { + if (iter->remote_port == cpcb->remote_port) { + if (ip_addr_eq(&iter->remote_addr, &cpcb->remote_ip)) { + struct tcp_md5_conn_info *info = tcp_md5_conn_info_alloc(); + if (info != NULL) { + memcpy(info, iter, sizeof(struct tcp_md5_conn_info)); + tcp_ext_arg_set(cpcb, id, info); + tcp_ext_arg_set_callbacks(cpcb, id, &tcp_md5_ext_arg_callbacks); + return ERR_OK; + } else { + return ERR_MEM; + } + } + } + iter = iter->next; + } + /* remote connection not found */ + return ERR_VAL; +} + +/* Parse tcp header options and return 1 if an md5 signature option was found */ +static int +tcp_md5_parseopt(const u8_t *opts, u16_t optlen, u8_t *md5_digest_out) +{ + u8_t data; + u16_t optidx; + + /* Parse the TCP MSS option, if present. */ + if (optlen != 0) { + for (optidx = 0; optidx < optlen; ) { + u8_t opt = opts[optidx++]; + switch (opt) { + case LWIP_TCP_OPT_EOL: + /* End of options. */ + LWIP_DEBUGF(TCP_INPUT_DEBUG, ("tcp_parseopt: EOL\n")); + return 0; + case LWIP_TCP_OPT_NOP: + /* NOP option. */ + LWIP_DEBUGF(TCP_INPUT_DEBUG, ("tcp_parseopt: NOP\n")); + break; + case LWIP_TCP_OPT_MD5: + LWIP_DEBUGF(TCP_INPUT_DEBUG, ("tcp_parseopt: MD5\n")); + if (opts[optidx++] != LWIP_TCP_OPT_LEN_MD5 || (optidx - 2 + LWIP_TCP_OPT_LEN_MD5) > optlen) { + /* Bad length */ + LWIP_DEBUGF(TCP_INPUT_DEBUG, ("tcp_parseopt: bad length\n")); + return 0; + } + /* An MD5 option with the right option length. */ + memcpy(md5_digest_out, &opts[optidx], LWIP_TCP_MD5_DIGEST_LEN); + /* no need to process the options further */ + return 1; + break; + default: + LWIP_DEBUGF(TCP_INPUT_DEBUG, ("tcp_parseopt: other\n")); + data = opts[optidx++]; + if (data < 2) { + LWIP_DEBUGF(TCP_INPUT_DEBUG, ("tcp_parseopt: bad length\n")); + /* If the length field is zero, the options are malformed + and we don't process them further. */ + return 0; + } + /* All other options have a length field, so that we easily + can skip past them. */ + optidx += data - 2; + } + } + } + return 0; +} + +/* Get tcp options into contiguous memory. May be required if input pbufs + * are chained. + */ +static const u8_t* +tcp_md5_options_singlebuf(struct tcp_hdr *hdr, u16_t optlen, u16_t opt1len, u8_t *opt2) +{ + const u8_t *opts; + LWIP_ASSERT("hdr != NULL", hdr != NULL); + LWIP_ASSERT("optlen >= opt1len", optlen >= opt1len); + opts = (const u8_t *)hdr + TCP_HLEN; + if (optlen == opt1len) { + /* arleady in one piece */ + return opts; + } + if (optlen > sizeof(tcp_md5_opts_buf)) { + /* options too long */ + return NULL; + } + LWIP_ASSERT("opt2 != NULL", opt2 != NULL); + /* copy first part */ + memcpy(tcp_md5_opts_buf, opts, opt1len); + /* copy second part */ + memcpy(&tcp_md5_opts_buf[opt1len], opt2, optlen - opt1len); + return tcp_md5_opts_buf; +} + +/* Create the md5 digest for a given segment */ +static int +tcp_md5_create_digest(const ip_addr_t *ip_src, const ip_addr_t *ip_dst, const struct tcp_hdr *hdr, + const u8_t *key, size_t key_len, u8_t *digest_out, struct pbuf *p) +{ + md5_context ctx; + u8_t tmp8; + u16_t tmp16; + const size_t addr_len = IP_ADDR_RAW_SIZE(*ip_src); + + if (p != NULL) { + LWIP_ASSERT("pbuf must not point to tcp header here!", (const void *)hdr != p->payload); + } + + /* Generate the hash, using MD5. */ + md5_starts(&ctx); + /* 1. the TCP pseudo-header (in the order: source IP address, + destination IP address, zero-padded protocol number, and + segment length) */ + md5_update(&ctx, (const unsigned char*)ip_src, addr_len); + md5_update(&ctx, (const unsigned char*)ip_dst, addr_len); + tmp8 = 0; /* zero-padded */ + md5_update(&ctx, &tmp8, 1); + tmp8 = IP_PROTO_TCP; + md5_update(&ctx, &tmp8, 1); + tmp16 = lwip_htons(TCPH_HDRLEN_BYTES(hdr) + (p ? p->tot_len : 0)); + md5_update(&ctx, (const unsigned char*)&tmp16, 2); + /* 2. the TCP header, excluding options, and assuming a checksum of + zero */ + md5_update(&ctx, (const unsigned char*)hdr, sizeof(struct tcp_hdr)); + /* 3. the TCP segment data (if any) */ + if ((p != NULL) && (p->tot_len != 0)) { + struct pbuf *q; + for (q = p; q != NULL; q = q->next) { + md5_update(&ctx, (const unsigned char*)q->payload, q->len); + } + } + /* 4. an independently-specified key or password, known to both TCPs + and presumably connection-specific */ + md5_update(&ctx, key, key_len); + + md5_finish(&ctx, digest_out); + return 1; +} + +/* Duplicate a tcp header and make sure the fields are in network byte order */ +static void +tcp_md5_dup_tcphdr(struct tcp_hdr *tcphdr_copy, const struct tcp_hdr *tcphdr_in, int tcphdr_in_is_host_order) +{ + memcpy(tcphdr_copy, tcphdr_in, sizeof(struct tcp_hdr)); + tcphdr_copy->chksum = 0; /* checksum is zero for the pseudo header */ + if (tcphdr_in_is_host_order) { + /* lwIP writes the TCP header values back to the buffer, we need to invert that here: */ + tcphdr_copy->src = lwip_htons(tcphdr_copy->src); + tcphdr_copy->dest = lwip_htons(tcphdr_copy->dest); + tcphdr_copy->seqno = lwip_htonl(tcphdr_copy->seqno); + tcphdr_copy->ackno = lwip_htonl(tcphdr_copy->ackno); + tcphdr_copy->wnd = lwip_htons(tcphdr_copy->wnd); + tcphdr_copy->urgp = lwip_htons(tcphdr_copy->urgp); + } +} + +/* Check if md5 is enabled on a given pcb */ +static int +tcp_md5_is_enabled_on_pcb(const struct tcp_pcb *pcb) +{ + if (tcp_md5_extarg_id != LWIP_TCP_PCB_NUM_EXT_ARG_ID_INVALID) { + struct tcp_md5_conn_info *info = (struct tcp_md5_conn_info *)tcp_ext_arg_get(pcb, tcp_md5_extarg_id); + if (info != NULL) { + return 1; + } + } + return 0; +} + +/* Check if md5 is enabled on a given listen pcb */ +static int +tcp_md5_is_enabled_on_lpcb(const struct tcp_pcb_listen *lpcb) +{ + /* same as for connection pcbs */ + return tcp_md5_is_enabled_on_pcb((const struct tcp_pcb *)lpcb); +} + +/* Hook implementation for LWIP_HOOK_TCP_OPT_LENGTH_SEGMENT */ +u8_t +tcp_md5_get_additional_option_length(const struct tcp_pcb *pcb, u8_t internal_option_length) +{ + if ((pcb != NULL) && tcp_md5_is_enabled_on_pcb(pcb)) { + u8_t new_option_length = internal_option_length + LWIP_TCP_OPT_LEN_MD5_OUT; + LWIP_ASSERT("overflow", new_option_length > internal_option_length); + LWIP_ASSERT("options too long", new_option_length <= TCP_MAX_OPTION_BYTES); + return new_option_length; + } + return internal_option_length; +} + +/* Hook implementation for LWIP_HOOK_TCP_INPACKET_PCB when called for listen pcbs */ +static err_t +tcp_md5_check_listen(struct tcp_pcb_listen* lpcb, struct tcp_hdr *hdr, u16_t optlen, u16_t opt1len, u8_t *opt2) +{ + LWIP_ASSERT("lpcb != NULL", lpcb != NULL); + + if (tcp_md5_is_enabled_on_lpcb(lpcb)) { + const u8_t *opts; + u8_t digest_received[LWIP_TCP_MD5_DIGEST_LEN]; + u8_t digest_calculated[LWIP_TCP_MD5_DIGEST_LEN]; + const struct tcp_md5_conn_info *info = tcp_md5_get_info((struct tcp_pcb *)lpcb, ip_current_src_addr(), hdr->src); + if (info != NULL) { + opts = tcp_md5_options_singlebuf(hdr, optlen, opt1len, opt2); + if (opts != NULL) { + if (tcp_md5_parseopt(opts, optlen, digest_received)) { + struct tcp_hdr tcphdr_copy; + tcp_md5_dup_tcphdr(&tcphdr_copy, hdr, 1); + if (tcp_md5_create_digest(ip_current_src_addr(), ip_current_dest_addr(), &tcphdr_copy, info->key, info->key_len, digest_calculated, NULL)) { + /* everything set up, compare the digests */ + if (!memcmp(digest_received, digest_calculated, LWIP_TCP_MD5_DIGEST_LEN)) { + /* equal */ + return ERR_OK; + } + /* not equal */ + } + } + } + } + /* md5 enabled on this pcb but no match or other error -> fail */ + return ERR_VAL; + } + return ERR_OK; +} + +/* Hook implementation for LWIP_HOOK_TCP_INPACKET_PCB */ +err_t +tcp_md5_check_inpacket(struct tcp_pcb* pcb, struct tcp_hdr *hdr, u16_t optlen, u16_t opt1len, u8_t *opt2, struct pbuf *p) +{ + LWIP_ASSERT("pcb != NULL", pcb != NULL); + + if (pcb->state == LISTEN) { + return tcp_md5_check_listen((struct tcp_pcb_listen *)pcb, hdr, optlen, opt1len, opt2); + } + + if (tcp_md5_is_enabled_on_pcb(pcb)) { + const struct tcp_md5_conn_info *info = tcp_md5_get_info(pcb, ip_current_src_addr(), hdr->src); + if (info != NULL) { + const u8_t *opts; + u8_t digest_received[LWIP_TCP_MD5_DIGEST_LEN]; + u8_t digest_calculated[LWIP_TCP_MD5_DIGEST_LEN]; + opts = tcp_md5_options_singlebuf(hdr, optlen, opt1len, opt2); + if (opts != NULL) { + if (tcp_md5_parseopt(opts, optlen, digest_received)) { + struct tcp_hdr hdr_copy; + tcp_md5_dup_tcphdr(&hdr_copy, hdr, 1); + if (tcp_md5_create_digest(&pcb->remote_ip, &pcb->local_ip, &hdr_copy, info->key, info->key_len, digest_calculated, p)) { + /* everything set up, compare the digests */ + if (!memcmp(digest_received, digest_calculated, LWIP_TCP_MD5_DIGEST_LEN)) { + /* equal */ + return ERR_OK; + } + /* not equal */ + } + } + } + } + /* md5 enabled on this pcb but no match or other error -> fail */ + return ERR_VAL; + } + return ERR_OK; +} + +/* Hook implementation for LWIP_HOOK_TCP_ADD_TX_OPTIONS */ +u32_t * +tcp_md5_add_tx_options(struct pbuf *p, struct tcp_hdr *hdr, const struct tcp_pcb *pcb, u32_t *opts) +{ + LWIP_ASSERT("p != NULL", p != NULL); + LWIP_ASSERT("hdr != NULL", hdr != NULL); + LWIP_ASSERT("pcb != NULL", pcb != NULL); + LWIP_ASSERT("opts != NULL", opts != NULL); + + if (tcp_md5_is_enabled_on_pcb(pcb)) { + u8_t digest_calculated[LWIP_TCP_MD5_DIGEST_LEN]; + u32_t *opts_ret = opts + 5; /* we use 20 bytes: 2 bytes padding + 18 bytes for this option */ + u8_t *ptr = (u8_t*)opts; + + const struct tcp_md5_conn_info *info = tcp_md5_get_info(pcb, &pcb->remote_ip, pcb->remote_port); + if (info != NULL) { + struct tcp_hdr hdr_copy; + size_t hdrsize = TCPH_HDRLEN_BYTES(hdr); + tcp_md5_dup_tcphdr(&hdr_copy, hdr, 0); + /* p->payload points to the tcp header */ + LWIP_ASSERT("p->payload == hdr", p->payload == hdr); + if (!pbuf_remove_header(p, hdrsize)) { + u8_t ret; + if (!tcp_md5_create_digest(&pcb->local_ip, &pcb->remote_ip, &hdr_copy, info->key, info->key_len, digest_calculated, p)) { + info = NULL; + } + ret = pbuf_add_header_force(p, hdrsize); + LWIP_ASSERT("tcp_md5_add_tx_options: pbuf_add_header_force failed", !ret); + LWIP_UNUSED_ARG(ret); + } else { + LWIP_ASSERT("error", 0); + } + } + if (info == NULL) { + /* create an invalid signature by zeroing the digest */ + memset(&digest_calculated, 0, sizeof(digest_calculated)); + } + + *ptr++ = LWIP_TCP_OPT_NOP; + *ptr++ = LWIP_TCP_OPT_NOP; + *ptr++ = LWIP_TCP_OPT_MD5; + *ptr++ = LWIP_TCP_OPT_LEN_MD5; + memcpy(ptr, digest_calculated, LWIP_TCP_MD5_DIGEST_LEN); + ptr += LWIP_TCP_MD5_DIGEST_LEN; + LWIP_ASSERT("ptr == opts_ret", ptr == (u8_t *)opts_ret); + return opts_ret; + } + return opts; +} + +/* Hook implementation for LWIP_HOOK_SOCKETS_SETSOCKOPT */ +int +tcp_md5_setsockopt_hook(struct lwip_sock *sock, int level, int optname, const void *optval, socklen_t optlen, int *err) +{ + LWIP_ASSERT("sock != NULL", sock != NULL); + LWIP_ASSERT("err != NULL", err != NULL); + + if ((level == IPPROTO_TCP) && (optname == TCP_MD5SIG)) { + const struct tcp_md5sig *md5 = (const struct tcp_md5sig*)optval; + if ((optval == NULL) || (optlen < sizeof(struct tcp_md5sig))) { + *err = EINVAL; + } else { + if (sock->conn && (NETCONNTYPE_GROUP(netconn_type(sock->conn)) == NETCONN_TCP) && (sock->conn->pcb.tcp != NULL)) { + if (tcp_md5_extarg_id == LWIP_TCP_PCB_NUM_EXT_ARG_ID_INVALID) { + /* not initialized */ + *err = EINVAL; + } else { + struct tcp_md5_conn_info *info = tcp_md5_conn_info_alloc(); + if (info == NULL) { + *err = ENOMEM; + } else { + int addr_valid = 0; + /* OK, fill and link this request */ + memcpy(info->key, md5->tcpm_key, TCP_MD5SIG_MAXKEYLEN); + info->key_len = md5->tcpm_keylen; + memset(&info->remote_addr, 0, sizeof(info->remote_addr)); + if (md5->tcpm_addr.ss_family == AF_INET) { +#if LWIP_IPV4 + const struct sockaddr_in *sin = (const struct sockaddr_in *)&md5->tcpm_addr; + memcpy(&info->remote_addr, &sin->sin_addr, sizeof(sin->sin_addr)); + IP_SET_TYPE_VAL(info->remote_addr, IPADDR_TYPE_V4); + info->remote_port = lwip_htons(sin->sin_port); + addr_valid = 1; +#endif /* LWIP_IPV4 */ + } else if (md5->tcpm_addr.ss_family == AF_INET6) { +#if LWIP_IPV6 + const struct sockaddr_in6 *sin6 = (const struct sockaddr_in6 *)&md5->tcpm_addr; + memcpy(&info->remote_addr, &sin6->sin6_addr, sizeof(sin6->sin6_addr)); + IP_SET_TYPE_VAL(info->remote_addr, IPADDR_TYPE_V6); + info->remote_port = lwip_htons(sin6->sin6_port); + addr_valid = 1; +#endif /* LWIP_IPV6 */ + } + if (addr_valid) { + /* store it */ + tcp_ext_arg_set_callbacks(sock->conn->pcb.tcp, tcp_md5_extarg_id, &tcp_md5_ext_arg_callbacks); + info->next = (struct tcp_md5_conn_info *)tcp_ext_arg_get(sock->conn->pcb.tcp, tcp_md5_extarg_id); + tcp_ext_arg_set(sock->conn->pcb.tcp, tcp_md5_extarg_id, info); + } else { + *err = EINVAL; + tcp_md5_conn_info_free(info); + } + } + } + } else { + /* not a tcp netconn */ + *err = EINVAL; + } + } + return 1; + } + return 0; +} diff --git a/contrib/addons/tcp_md5/tcp_md5.h b/contrib/addons/tcp_md5/tcp_md5.h new file mode 100644 index 00000000000..e55740a414b --- /dev/null +++ b/contrib/addons/tcp_md5/tcp_md5.h @@ -0,0 +1,84 @@ +/* + * Copyright (c) 2018 Simon Goldschmidt + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * Author: Simon Goldschmidt goldsimon@gmx.de + * + * To use the hooks in this file, make sure this file is included in LWIP_HOOK_FILENAME + * and define these hooks: + * + * #define LWIP_HOOK_TCP_INPACKET_PCB(pcb, hdr, optlen, opt1len, opt2, p) tcp_md5_check_inpacket(pcb, hdr, optlen, opt1len, opt2, p) + * #define LWIP_HOOK_TCP_OPT_LENGTH_SEGMENT(pcb, internal_len) tcp_md5_get_additional_option_length(pcb, internal_len) + * #define LWIP_HOOK_TCP_ADD_TX_OPTIONS(p, hdr, pcb, opts) tcp_md5_add_tx_options(p, hdr, pcb, opts) + * + * #define LWIP_HOOK_SOCKETS_SETSOCKOPT(s, sock, level, optname, optval, optlen, err) tcp_md5_setsockopt_hook(sock, level, optname, optval, optlen, err) + */ + +#ifndef LWIP_HDR_CONTRIB_ADDONS_TCP_MD5_H +#define LWIP_HDR_CONTRIB_ADDONS_TCP_MD5_H + +#include "lwip/opt.h" +#include "lwip/ip_addr.h" +#include "lwip/err.h" + +#include "lwip/priv/sockets_priv.h" +#include "lwip/priv/tcp_priv.h" + +#ifdef __cplusplus +extern "C" { +#endif + +/* setsockopt definitions and structs: */ + +/* This is the optname (for level = IPPROTO_TCP) */ +#ifndef TCP_MD5SIG +#define TCP_MD5SIG 14 +#endif + +#define TCP_MD5SIG_MAXKEYLEN 80 + +/* This is the optval type */ +struct tcp_md5sig { + struct sockaddr_storage tcpm_addr; + u16_t __tcpm_pad1; + u16_t tcpm_keylen; + u32_t __tcpm_pad2; + u8_t tcpm_key[TCP_MD5SIG_MAXKEYLEN]; +}; + +/* socket setsockopt hook: */ +int tcp_md5_setsockopt_hook(struct lwip_sock *sock, int level, int optname, const void *optval, u32_t optlen, int *err); + +/* Internal hook functions */ +void tcp_md5_init(void); +err_t tcp_md5_check_inpacket(struct tcp_pcb* pcb, struct tcp_hdr *hdr, u16_t optlen, u16_t opt1len, u8_t *opt2, struct pbuf *p); +u8_t tcp_md5_get_additional_option_length(const struct tcp_pcb *pcb, u8_t internal_option_length); +u32_t *tcp_md5_add_tx_options(struct pbuf *p, struct tcp_hdr *hdr, const struct tcp_pcb *pcb, u32_t *opts); + +#ifdef __cplusplus +} +#endif + +#endif /* LWIP_HDR_CONTRIB_ADDONS_TCP_MD5_H */ diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/CCodeGeneration.csproj b/contrib/apps/LwipMibCompiler/CCodeGeneration/CCodeGeneration.csproj new file mode 100644 index 00000000000..06d5075e4b3 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/CCodeGeneration.csproj @@ -0,0 +1,67 @@ +<?xml version="1.0" encoding="utf-8"?> +<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003"> + <PropertyGroup> + <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration> + <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform> + <ProductVersion>8.0.30703</ProductVersion> + <SchemaVersion>2.0</SchemaVersion> + <ProjectGuid>{7DA7C0AB-0982-4BF5-9324-F59A7A08D65B}</ProjectGuid> + <OutputType>Library</OutputType> + <AppDesignerFolder>Properties</AppDesignerFolder> + <RootNamespace>CCodeGeneration</RootNamespace> + <AssemblyName>CCodeGeneration</AssemblyName> + <TargetFrameworkVersion>v4.0</TargetFrameworkVersion> + <FileAlignment>512</FileAlignment> + <TargetFrameworkProfile /> + </PropertyGroup> + <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' "> + <DebugSymbols>true</DebugSymbols> + <DebugType>full</DebugType> + <Optimize>false</Optimize> + <OutputPath>bin\Debug</OutputPath> + <DefineConstants>DEBUG;TRACE</DefineConstants> + <ErrorReport>prompt</ErrorReport> + <WarningLevel>4</WarningLevel> + </PropertyGroup> + <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' "> + <DebugType>pdbonly</DebugType> + <Optimize>true</Optimize> + <OutputPath>bin\Release</OutputPath> + <DefineConstants>TRACE</DefineConstants> + <ErrorReport>prompt</ErrorReport> + <WarningLevel>4</WarningLevel> + </PropertyGroup> + <ItemGroup> + <Reference Include="System" /> + </ItemGroup> + <ItemGroup> + <Compile Include="CFile.cs" /> + <Compile Include="Code.cs" /> + <Compile Include="CodeContainerBase.cs" /> + <Compile Include="CodeElement.cs" /> + <Compile Include="Comment.cs" /> + <Compile Include="EmptyLine.cs" /> + <Compile Include="Function.cs" /> + <Compile Include="CGenerator.cs" /> + <Compile Include="IfThenElse.cs" /> + <Compile Include="PlainText.cs" /> + <Compile Include="Switch.cs" /> + <Compile Include="PP_If.cs" /> + <Compile Include="PP_Ifdef.cs" /> + <Compile Include="PP_Include.cs" /> + <Compile Include="FunctionDeclaration.cs" /> + <Compile Include="PP_Macro.cs" /> + <Compile Include="Properties\AssemblyInfo.cs" /> + <Compile Include="VariableDeclaration.cs" /> + <Compile Include="VariablePrototype.cs" /> + <Compile Include="VariableType.cs" /> + </ItemGroup> + <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" /> + <!-- To modify your build process, add your task inside one of the targets below and uncomment it. + Other similar extension points exist, see Microsoft.Common.targets. + <Target Name="BeforeBuild"> + </Target> + <Target Name="AfterBuild"> + </Target> + --> +</Project> \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/CFile.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/CFile.cs new file mode 100644 index 00000000000..6f12274250e --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/CFile.cs @@ -0,0 +1,54 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; + +namespace CCodeGeneration +{ + public class CFile: CodeContainerBase + { + public CFile() + { + base.IncreaseLevel = false; + } + + public void Save(CGenerator generator) + { + if (generator == null) + { + throw new ArgumentNullException("generator"); + } + + this.GenerateCode(0, generator); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/CGenerator.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/CGenerator.cs new file mode 100644 index 00000000000..4e8dfbc7aa2 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/CGenerator.cs @@ -0,0 +1,119 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.IO; + +namespace CCodeGeneration +{ + public class CGenerator + { + public TextWriter OutputStream { get; private set; } + public string File { get; private set; } + public uint IndentCount { get; private set; } + public string IndentChar { get; private set; } + public string NewLine { get; private set; } + + public CGenerator(System.IO.TextWriter outputStream, string file, uint indentCount, string indentChar, string newLine) + { + this.OutputStream = outputStream; + this.File = file; + this.IndentCount = indentCount; + this.IndentChar = indentChar; + this.NewLine = newLine; + } + + public string FileName + { + get + { + if (!String.IsNullOrWhiteSpace(this.File)) + { + return Path.GetFileName(this.File); + } + + return null; + } + } + + public void WriteSequence(string value, uint repetitions) + { + while (repetitions > 0) + { + this.OutputStream.Write(value); + repetitions--; + } + } + + public void IndentLine(int level) + { + while (level > 0) + { + WriteSequence(this.IndentChar, this.IndentCount); + level--; + } + } + + public void WriteNewLine() + { + this.OutputStream.Write(this.NewLine); + } + + public void WriteMultilineString(string value, int level = 0) + { + if (String.IsNullOrEmpty(value)) + { + return; + } + + // only \n and \r\n are recognized as linebreaks + string[] lines = value.Split(new char[] { '\n' }, StringSplitOptions.None); + + for (int l = 0; l < (lines.Length - 1); l++) + { + if (lines[l].EndsWith("\r")) + { + this.OutputStream.Write(lines[l].Substring(0, lines[l].Length-1)); + } + else + { + this.OutputStream.Write(lines[l]); + } + + this.WriteNewLine(); + this.IndentLine(level); + } + + this.OutputStream.Write(lines[lines.Length - 1]); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/Code.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/Code.cs new file mode 100644 index 00000000000..4834508ae51 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/Code.cs @@ -0,0 +1,56 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +namespace CCodeGeneration +{ + public class Code: CodeElement + { + public string Code_ { get; set; } + + public Code() + { + } + + public Code(string code) + { + this.Code_ = code; + } + + public override void GenerateCode(int level, CGenerator generator) + { + generator.IndentLine(level); + generator.WriteMultilineString(this.Code_, level); + generator.WriteNewLine(); + } + + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/CodeContainerBase.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/CodeContainerBase.cs new file mode 100644 index 00000000000..4327d92dcaf --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/CodeContainerBase.cs @@ -0,0 +1,139 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System.Collections.Generic; +using System; + +namespace CCodeGeneration +{ + public class CodeContainerBase: CodeElement + { + private readonly List<CodeElement> declarations = new List<CodeElement>(); + private readonly List<CodeElement> innerElements = new List<CodeElement>(); + private bool increaseLevel = true; + + public List<CodeElement> Declarations + { + get { return this.declarations; } + } + + public List<CodeElement> InnerElements + { + get { return this.innerElements; } + } + + protected bool IncreaseLevel + { + get { return this.increaseLevel; } + set { this.increaseLevel = value; } + } + + public void AddElements(IList<CodeElement> elements, params CodeElement[] spacerElements) + { + if (elements != null) + { + if ((spacerElements == null) || (spacerElements.Length == 0)) + { + this.innerElements.AddRange(elements); + } + else + { + bool spacerAdded = false; + + foreach (CodeElement element in elements) + { + this.innerElements.Add(element); + this.innerElements.AddRange(spacerElements); + spacerAdded = true; + } + + if (spacerAdded) + { + // remove last spacer again + this.innerElements.RemoveRange(this.innerElements.Count - spacerElements.Length, spacerElements.Length); + } + } + } + } + + public CodeElement AddElement(CodeElement element) + { + if (element != null) + { + this.innerElements.Add(element); + } + + return element; + } + + public Code AddCode(string code) + { + return this.AddElement(new Code(code)) as Code; + } + + public Code AddCodeFormat(string codeFormat, params object[] args) + { + return this.AddElement(new Code(String.Format(codeFormat, args))) as Code; + } + + public CodeElement AddDeclaration(CodeElement declaration) + { + if (declaration != null) + { + this.declarations.Add(declaration); + } + + return declaration; + } + + public override void GenerateCode(int level, CGenerator generator) + { + if (this.increaseLevel) + level++; + + if (this.declarations.Count > 0) + { + foreach (CodeElement element in this.declarations) + { + element.GenerateCode(level, generator); + } + + EmptyLine.SingleLine.GenerateCode(level, generator); + } + + foreach (CodeElement element in this.innerElements) + { + element.GenerateCode(level, generator); + } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/CodeElement.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/CodeElement.cs new file mode 100644 index 00000000000..51cf2d248e5 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/CodeElement.cs @@ -0,0 +1,41 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +namespace CCodeGeneration +{ + public class CodeElement + { + public virtual void GenerateCode(int level, CGenerator generator) + { + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/Comment.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/Comment.cs new file mode 100644 index 00000000000..51779beabbe --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/Comment.cs @@ -0,0 +1,75 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +namespace CCodeGeneration +{ + public class Comment: CodeElement + { + public const string CommentStart = "/*"; + public const string CommentEnd = "*/"; + + public string Comment_ { get; set; } + public bool SingleLine { get; set; } + + public Comment() + { + } + + public Comment(string comment, bool singleLine = false) + { + this.Comment_ = comment; + this.SingleLine = singleLine; + } + + public override void GenerateCode(int level, CGenerator generator) + { + generator.IndentLine(level); + generator.OutputStream.Write(CommentStart); + + if (!this.SingleLine) + { + generator.WriteNewLine(); + generator.IndentLine(level); + generator.WriteMultilineString(this.Comment_, level); + generator.WriteNewLine(); + generator.IndentLine(level); + } + else + { + generator.OutputStream.Write(" " + Comment_ + " "); + } + + generator.OutputStream.Write(CommentEnd); + generator.WriteNewLine(); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/EmptyLine.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/EmptyLine.cs new file mode 100644 index 00000000000..604c9477c37 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/EmptyLine.cs @@ -0,0 +1,64 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +namespace CCodeGeneration +{ + public class EmptyLine : CodeElement + { + public static readonly EmptyLine SingleLine = new EmptyLine(); + public static readonly EmptyLine TwoLines = new EmptyLine(2); + public static readonly EmptyLine ThreeLines = new EmptyLine(3); + + public uint Count { get; set; } + + public EmptyLine() + { + this.Count = 1; + } + + public EmptyLine(uint count) + { + this.Count = count; + } + + public override void GenerateCode(int level, CGenerator generator) + { + uint c = this.Count; + + while (c > 0) + { + generator.WriteNewLine(); + c--; + } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/Function.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/Function.cs new file mode 100644 index 00000000000..d81f6e56132 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/Function.cs @@ -0,0 +1,129 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Collections.Generic; + +namespace CCodeGeneration +{ + public class Function: CodeContainerBase + { + public string Name { get; set; } + public bool IsStatic { get; set; } + + private readonly List<VariableType> parameter = new List<VariableType>(); + private VariableType returnType = VariableType.Void; + + public Function() + { + } + + public Function(string name, bool isStatic = false) + { + this.Name = name; + this.IsStatic = isStatic; + } + + public List<VariableType> Parameter + { + get { return this.parameter; } + } + + public VariableType ReturnType + { + get { return this.returnType; } + set + { + if (value == null) + { + throw new ArgumentNullException("ReturnValue"); + } + this.returnType = value; + } + } + + public static Function FromDeclaration(FunctionDeclaration decl) + { + Function result = new Function(decl.Name, decl.IsStatic); + result.ReturnType = decl.ReturnType.Clone() as VariableType; + + foreach (VariableType param in decl.Parameter) + { + result.parameter.Add(param.Clone() as VariableType); + } + + return result; + } + + public override void GenerateCode(int level, CGenerator generator) + { + generator.IndentLine(level); + + if (this.IsStatic) + { + generator.OutputStream.Write("static "); + } + + this.returnType.GenerateCode(generator); + generator.OutputStream.Write(" " + this.Name + "("); + + if (this.Parameter.Count > 0) + { + for (int i = 0; i < this.parameter.Count; i++) + { + this.parameter[i].GenerateCode(generator); + + if (i < (this.parameter.Count - 1)) + { + generator.OutputStream.Write(", "); + } + } + } + else + { + generator.OutputStream.Write("void"); + } + + generator.OutputStream.Write(")"); + generator.WriteNewLine(); + generator.IndentLine(level); + generator.OutputStream.Write("{"); + generator.WriteNewLine(); + + base.GenerateCode(level, generator); + + generator.IndentLine(level); + generator.OutputStream.Write("}"); + generator.WriteNewLine(); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/FunctionDeclaration.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/FunctionDeclaration.cs new file mode 100644 index 00000000000..3bc42888ab1 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/FunctionDeclaration.cs @@ -0,0 +1,114 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Collections.Generic; + +namespace CCodeGeneration +{ + public class FunctionDeclaration: CodeElement + { + public string Name { get; set; } + public bool IsStatic { get; set; } + public bool IsExtern { get; set; } + + private readonly List<VariableType> parameter = new List<VariableType>(); + private VariableType returnType = VariableType.Void; + + public FunctionDeclaration() + { + } + + public FunctionDeclaration(string name, bool isStatic = false, bool isExtern = false) + { + this.Name = name; + this.IsStatic = isStatic; + this.IsExtern = isExtern; + } + + public List<VariableType> Parameter + { + get { return this.parameter; } + } + + public VariableType ReturnType + { + get { return this.returnType; } + set + { + if (value == null) + { + throw new ArgumentNullException("ReturnValue"); + } + this.returnType = value; + } + } + + public override void GenerateCode(int level, CGenerator generator) + { + generator.IndentLine(level); + + if (this.IsExtern) + { + generator.OutputStream.Write("extern "); + } + + if (this.IsStatic) + { + generator.OutputStream.Write("static "); + } + + this.returnType.GenerateCode(generator); + generator.OutputStream.Write(" " + this.Name + "("); + + if (this.Parameter.Count > 0) + { + for (int i = 0; i < this.parameter.Count; i++) + { + this.parameter[i].GenerateCode(generator); + + if (i < (this.parameter.Count - 1)) + { + generator.OutputStream.Write(", "); + } + } + } + else + { + generator.OutputStream.Write("void"); + } + + generator.OutputStream.Write(");"); + generator.WriteNewLine(); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/IfThenElse.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/IfThenElse.cs new file mode 100644 index 00000000000..c4710225c3b --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/IfThenElse.cs @@ -0,0 +1,137 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Collections.Generic; + +namespace CCodeGeneration +{ + public class ElseIf : CodeContainerBase + { + public string Condition { get; set; } + + public ElseIf() + { + } + + public ElseIf(string condition) + { + this.Condition = condition; + } + + public override void GenerateCode(int level, CGenerator generator) + { + if (!String.IsNullOrWhiteSpace(this.Condition)) + { + generator.IndentLine(level); + generator.OutputStream.Write(String.Format("else if ({0})", this.Condition)); + generator.WriteNewLine(); + generator.IndentLine(level); + generator.OutputStream.Write("{"); + generator.WriteNewLine(); + + base.GenerateCode(level, generator); + + generator.IndentLine(level); + generator.OutputStream.Write("}"); + generator.WriteNewLine(); + } + } + } + + public class IfThenElse: CodeContainerBase + { + public string Condition { get; set; } + + private List<ElseIf> elseIf = new List<ElseIf>(); + private CodeContainerBase else_ = new CodeContainerBase(); + + public IfThenElse() + { + } + + public IfThenElse(string condition) + { + this.Condition = condition; + } + + public List<ElseIf> ElseIf + { + get { return this.elseIf; } + } + + public CodeContainerBase Else + { + get { return this.else_; } + } + + public override void GenerateCode(int level, CGenerator generator) + { + if (!String.IsNullOrWhiteSpace(this.Condition)) + { + generator.IndentLine(level); + generator.OutputStream.Write(String.Format("if ({0})", this.Condition)); + generator.WriteNewLine(); + generator.IndentLine(level); + generator.OutputStream.Write("{"); + generator.WriteNewLine(); + + base.GenerateCode(level, generator); + + generator.IndentLine(level); + generator.OutputStream.Write("}"); + generator.WriteNewLine(); + + foreach (ElseIf elif in this.elseIf) + { + elif.GenerateCode(level, generator); + } + + if (this.else_.InnerElements.Count > 0) + { + generator.IndentLine(level); + generator.OutputStream.Write("else"); + generator.WriteNewLine(); + generator.IndentLine(level); + generator.OutputStream.Write("{"); + generator.WriteNewLine(); + + this.else_.GenerateCode(level, generator); + + generator.IndentLine(level); + generator.OutputStream.Write("}"); + generator.WriteNewLine(); + } + } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/PP_If.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/PP_If.cs new file mode 100644 index 00000000000..5568215543b --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/PP_If.cs @@ -0,0 +1,67 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; + +namespace CCodeGeneration +{ + public class PP_If: CodeContainerBase + { + public string Condition { get; set; } + + public PP_If() + { + base.IncreaseLevel = false; + } + + public PP_If(string condition) + : this() + { + this.Condition = condition; + } + + + public override void GenerateCode(int level, CGenerator generator) + { + if (!String.IsNullOrWhiteSpace(this.Condition)) + { + generator.OutputStream.Write("#if " + this.Condition); + generator.WriteNewLine(); + + base.GenerateCode(level, generator); + + generator.OutputStream.Write("#endif /* " + this.Condition + " */"); + generator.WriteNewLine(); + } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/PP_Ifdef.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/PP_Ifdef.cs new file mode 100644 index 00000000000..fd4f45af1c6 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/PP_Ifdef.cs @@ -0,0 +1,76 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; + +namespace CCodeGeneration +{ + public class PP_Ifdef: CodeContainerBase + { + public string Macro { get; set; } + public bool Inverted { get; set; } + + public PP_Ifdef() + { + base.IncreaseLevel = false; + } + + public PP_Ifdef(string macro, bool inverted = false) + : this() + { + this.Macro = macro; + this.Inverted = inverted; + } + + + public override void GenerateCode(int level, CGenerator generator) + { + if (!String.IsNullOrWhiteSpace(this.Macro)) + { + if (this.Inverted) + { + generator.OutputStream.Write("#ifndef " + this.Macro); + } + else + { + generator.OutputStream.Write("#ifdef " + this.Macro); + } + generator.WriteNewLine(); + + base.GenerateCode(level, generator); + + generator.OutputStream.Write("#endif /* " + this.Macro + " */"); + generator.WriteNewLine(); + } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/PP_Include.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/PP_Include.cs new file mode 100644 index 00000000000..0393d271375 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/PP_Include.cs @@ -0,0 +1,71 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; + +namespace CCodeGeneration +{ + public class PP_Include : CodeElement + { + public string File { get; set; } + public bool IsLocal { get; set; } + + public PP_Include() + { + this.IsLocal = true; + } + + public PP_Include(string file, bool isLocal = true) + { + this.File = file; + this.IsLocal = isLocal; + } + + public override void GenerateCode(int level, CGenerator generator) + { + if (!String.IsNullOrWhiteSpace(this.File)) + { + // includes are never indented + if (this.IsLocal) + { + generator.OutputStream.Write("#include "" + this.File + """); + } + else + { + generator.OutputStream.Write("#include <" + this.File + ">"); + } + + generator.WriteNewLine(); + } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/PP_Macro.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/PP_Macro.cs new file mode 100644 index 00000000000..6f302aa9c10 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/PP_Macro.cs @@ -0,0 +1,59 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +namespace CCodeGeneration +{ + public class PP_Macro: CodeElement + { + public string Name { get; set; } + public string Value { get; set; } + + public PP_Macro() + { + } + + public PP_Macro(string name, string value) + { + this.Name = name; + this.Value = value; + } + + + public override void GenerateCode(int level, CGenerator generator) + { + // macros are not indented at all + generator.OutputStream.Write("#define " + this.Name + " "); + generator.WriteMultilineString(this.Value); + generator.WriteNewLine(); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/PlainText.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/PlainText.cs new file mode 100644 index 00000000000..d5e076fefdc --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/PlainText.cs @@ -0,0 +1,49 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +namespace CCodeGeneration +{ + public class PlainText : CodeElement + { + public string Value { get; set; } + + public PlainText(string value) + { + this.Value = value; + } + + public override void GenerateCode(int level, CGenerator generator) + { + generator.WriteMultilineString(this.Value); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/Properties/AssemblyInfo.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/Properties/AssemblyInfo.cs new file mode 100644 index 00000000000..4c716ad3af5 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/Properties/AssemblyInfo.cs @@ -0,0 +1,36 @@ +using System.Reflection; +using System.Runtime.CompilerServices; +using System.Runtime.InteropServices; + +// Allgemeine Informationen über eine Assembly werden über die folgenden +// Attribute gesteuert. Ändern Sie diese Attributwerte, um die Informationen zu ändern, +// die mit einer Assembly verknüpft sind. +[assembly: AssemblyTitle("CCodeGeneration")] +[assembly: AssemblyDescription("")] +[assembly: AssemblyConfiguration("")] +[assembly: AssemblyCompany("")] +[assembly: AssemblyProduct("CCodeGeneration")] +[assembly: AssemblyCopyright("Copyright © 2015")] +[assembly: AssemblyTrademark("")] +[assembly: AssemblyCulture("")] + +// Durch Festlegen von ComVisible auf "false" werden die Typen in dieser Assembly unsichtbar +// für COM-Komponenten. Wenn Sie auf einen Typ in dieser Assembly von +// COM zugreifen müssen, legen Sie das ComVisible-Attribut für diesen Typ auf "true" fest. +[assembly: ComVisible(false)] + +// Die folgende GUID bestimmt die ID der Typbibliothek, wenn dieses Projekt für COM verfügbar gemacht wird +[assembly: Guid("8f07a0fa-86f4-48a0-97c7-f94fc5c3f103")] + +// Versionsinformationen für eine Assembly bestehen aus den folgenden vier Werten: +// +// Hauptversion +// Nebenversion +// Buildnummer +// Revision +// +// Sie können alle Werte angeben oder die standardmäßigen Build- und Revisionsnummern +// übernehmen, indem Sie "*" eingeben: +// [assembly: AssemblyVersion("1.0.*")] +[assembly: AssemblyVersion("1.0.0.0")] +[assembly: AssemblyFileVersion("1.0.0.0")] diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/Switch.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/Switch.cs new file mode 100644 index 00000000000..9166fb89d6e --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/Switch.cs @@ -0,0 +1,146 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Collections.Generic; + +namespace CCodeGeneration +{ + public class SwitchCase : CodeContainerBase + { + public string Value { get; set; } + + public SwitchCase() + { + } + + public SwitchCase(string value) + { + this.Value = value; + } + + public bool IsDefault + { + get { return (this.Value.ToLowerInvariant() == "default"); } + } + + public static SwitchCase GenerateDefault() + { + return new SwitchCase("default"); + } + + public override void GenerateCode(int level, CGenerator generator) + { + if (!String.IsNullOrWhiteSpace(this.Value)) + { + generator.IndentLine(level); + if (this.IsDefault) + { + generator.OutputStream.Write("default:"); + } + else + { + generator.OutputStream.Write(String.Format("case {0}:", this.Value)); + } + generator.WriteNewLine(); + generator.IndentLine(level + 1); + generator.OutputStream.Write("{"); + generator.WriteNewLine(); + + base.GenerateCode(level + 1, generator); + + generator.IndentLine(level + 1); + generator.OutputStream.Write("}"); + generator.WriteNewLine(); + + generator.IndentLine(level + 1); + generator.OutputStream.Write("break;"); + generator.WriteNewLine(); + } + } + } + + public class Switch: CodeElement + { + public string SwitchVar { get; set; } + + private List<SwitchCase> switches = new List<SwitchCase>(); + + public Switch() + { + } + + public Switch(string switchVar) + { + this.SwitchVar = switchVar; + } + + public List<SwitchCase> Switches + { + get { return this.switches; } + } + + public override void GenerateCode(int level, CGenerator generator) + { + if (!String.IsNullOrWhiteSpace(this.SwitchVar)) + { + generator.IndentLine(level); + generator.OutputStream.Write(String.Format("switch ({0})", this.SwitchVar)); + generator.WriteNewLine(); + generator.IndentLine(level); + generator.OutputStream.Write("{"); + generator.WriteNewLine(); + + SwitchCase defaultCase = null; // generate 'default' always as last case + foreach (SwitchCase switchCase in this.switches) + { + if (switchCase.IsDefault) + { + defaultCase = switchCase; + } + else + { + switchCase.GenerateCode(level + 1, generator); + } + } + if (defaultCase != null) + { + defaultCase.GenerateCode(level + 1, generator); + } + + generator.IndentLine(level); + generator.OutputStream.Write("}"); + generator.WriteNewLine(); + } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/VariableDeclaration.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/VariableDeclaration.cs new file mode 100644 index 00000000000..bf2c90266d1 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/VariableDeclaration.cs @@ -0,0 +1,82 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; + +namespace CCodeGeneration +{ + public class VariableDeclaration : CodeElement + { + public VariableType Type { get; set; } + public string InitialValue { get; set; } + public bool IsStatic { get; set; } + + public VariableDeclaration() + : base() + { + } + + public VariableDeclaration(VariableType type, string initialValue = null, bool isStatic = false) : + base() + { + this.Type = type; + this.InitialValue = initialValue; + this.IsStatic = isStatic; + } + + public override void GenerateCode(int level, CGenerator generator) + { + if (this.Type != null) + { + generator.IndentLine(level); + + if (this.IsStatic) + { + generator.OutputStream.Write("static "); + } + + // declare the variable + this.Type.GenerateCode(generator); + + if (!String.IsNullOrWhiteSpace(this.InitialValue)) + { + // add initialization value + generator.OutputStream.Write(" = "); + generator.WriteMultilineString(this.InitialValue, level); + } + + generator.OutputStream.Write(";"); + generator.WriteNewLine(); + } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/VariablePrototype.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/VariablePrototype.cs new file mode 100644 index 00000000000..38a41663922 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/VariablePrototype.cs @@ -0,0 +1,73 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +namespace CCodeGeneration +{ + public class VariablePrototype : CodeElement + { + public VariableType Type { get; set; } + + public VariablePrototype() + : base() + { + } + + public VariablePrototype(VariableType type) : + base() + { + Type = type; + } + + public static VariablePrototype FromVariableDeclaration(VariableDeclaration declaration) + { + return new VariablePrototype(declaration.Type); + } + + + public override void GenerateCode(int level, CGenerator generator) + { + if (this.Type != null) + { + generator.IndentLine(level); + + generator.OutputStream.Write("extern "); + + // declare the variable + this.Type.GenerateCode(generator); + + generator.OutputStream.Write(";"); + generator.WriteNewLine(); + } + } + + } +} diff --git a/contrib/apps/LwipMibCompiler/CCodeGeneration/VariableType.cs b/contrib/apps/LwipMibCompiler/CCodeGeneration/VariableType.cs new file mode 100644 index 00000000000..313abbeeef6 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/CCodeGeneration/VariableType.cs @@ -0,0 +1,130 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Text; + +namespace CCodeGeneration +{ + public enum ConstType + { + None, + Value, + Indirection, + Both + } + + public class VariableType : ICloneable + { + public const string VoidString = "void"; + public static readonly VariableType Void = new VariableType(null, "void"); + + public string Name { get; set; } + public string Type { get; set; } + public string Indirection { get; set; } + public ConstType Const { get; set; } + public string ArraySpecifier { get; set; } + + public VariableType() + { + } + + public VariableType(string name, string type, string indirection = null, ConstType const_ = ConstType.None, string arraySpecifier = null) + { + this.Name = name; + this.Type = type; + this.Indirection = indirection; + this.Const = const_; + this.ArraySpecifier = arraySpecifier; + } + + public void GenerateCode(CGenerator generator) + { + if (!String.IsNullOrWhiteSpace(this.Type)) + { + generator.OutputStream.Write(this.ToString().Trim()); + } + } + + public override string ToString() + { + if (!String.IsNullOrWhiteSpace(this.Type)) + { + StringBuilder vt = new StringBuilder(); + + if ((this.Const == ConstType.Value) || (this.Const == ConstType.Both)) + { + vt.Append("const "); + } + + vt.Append(this.Type); + vt.Append(" "); + + if (!String.IsNullOrWhiteSpace(this.Indirection)) + { + vt.Append(this.Indirection); + } + + if ((this.Const == ConstType.Indirection) || (this.Const == ConstType.Both)) + { + vt.Append("const "); + } + + if (!String.IsNullOrWhiteSpace(this.Name)) + { + vt.Append(this.Name); + } + + if (this.ArraySpecifier != null) + { + vt.Append("["); + vt.Append(this.ArraySpecifier); + vt.Append("]"); + } + + return vt.ToString().Trim(); + } + + return base.ToString(); + } + + #region ICloneable Member + + public object Clone() + { + // we only have value types as members -> simply use .net base function + return this.MemberwiseClone(); + } + + #endregion + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipMibCompiler.sln b/contrib/apps/LwipMibCompiler/LwipMibCompiler.sln new file mode 100644 index 00000000000..ee0414138a1 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipMibCompiler.sln @@ -0,0 +1,47 @@ + +Microsoft Visual Studio Solution File, Format Version 11.00 +# Visual Studio 2010 +Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "LwipMibCompiler", "LwipMibCompiler\LwipMibCompiler.csproj", "{C25D5640-D999-49BD-82E0-A1975296A91E}" +EndProject +Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "LwipSnmpCodeGeneration", "LwipSnmpCodeGeneration\LwipSnmpCodeGeneration.csproj", "{AABCAB90-1540-45D4-A159-14831A54E9A3}" +EndProject +Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "CCodeGeneration", "CCodeGeneration\CCodeGeneration.csproj", "{7DA7C0AB-0982-4BF5-9324-F59A7A08D65B}" +EndProject +Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "SharpSnmpLib.Mib", "SharpSnmpLib\SharpSnmpLib.Mib.csproj", "{CBE20411-5DB7-487D-825D-7694267BB6F5}" +EndProject +Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "MibViewer", "MibViewer\MibViewer.csproj", "{86CC0B65-7985-4017-A252-0A7A18DCAEF3}" +EndProject +Global + GlobalSection(SolutionConfigurationPlatforms) = preSolution + Debug|Any CPU = Debug|Any CPU + Release|Any CPU = Release|Any CPU + EndGlobalSection + GlobalSection(ProjectConfigurationPlatforms) = postSolution + {7DA7C0AB-0982-4BF5-9324-F59A7A08D65B}.Debug|Any CPU.ActiveCfg = Debug|Any CPU + {7DA7C0AB-0982-4BF5-9324-F59A7A08D65B}.Debug|Any CPU.Build.0 = Debug|Any CPU + {7DA7C0AB-0982-4BF5-9324-F59A7A08D65B}.Release|Any CPU.ActiveCfg = Release|Any CPU + {7DA7C0AB-0982-4BF5-9324-F59A7A08D65B}.Release|Any CPU.Build.0 = Release|Any CPU + {86CC0B65-7985-4017-A252-0A7A18DCAEF3}.Debug|Any CPU.ActiveCfg = Debug|Any CPU + {86CC0B65-7985-4017-A252-0A7A18DCAEF3}.Debug|Any CPU.Build.0 = Debug|Any CPU + {86CC0B65-7985-4017-A252-0A7A18DCAEF3}.Release|Any CPU.ActiveCfg = Release|Any CPU + {86CC0B65-7985-4017-A252-0A7A18DCAEF3}.Release|Any CPU.Build.0 = Release|Any CPU + {AABCAB90-1540-45D4-A159-14831A54E9A3}.Debug|Any CPU.ActiveCfg = Debug|Any CPU + {AABCAB90-1540-45D4-A159-14831A54E9A3}.Debug|Any CPU.Build.0 = Debug|Any CPU + {AABCAB90-1540-45D4-A159-14831A54E9A3}.Release|Any CPU.ActiveCfg = Release|Any CPU + {AABCAB90-1540-45D4-A159-14831A54E9A3}.Release|Any CPU.Build.0 = Release|Any CPU + {C25D5640-D999-49BD-82E0-A1975296A91E}.Debug|Any CPU.ActiveCfg = Debug|Any CPU + {C25D5640-D999-49BD-82E0-A1975296A91E}.Debug|Any CPU.Build.0 = Debug|Any CPU + {C25D5640-D999-49BD-82E0-A1975296A91E}.Release|Any CPU.ActiveCfg = Release|Any CPU + {C25D5640-D999-49BD-82E0-A1975296A91E}.Release|Any CPU.Build.0 = Release|Any CPU + {CBE20411-5DB7-487D-825D-7694267BB6F5}.Debug|Any CPU.ActiveCfg = Debug|Any CPU + {CBE20411-5DB7-487D-825D-7694267BB6F5}.Debug|Any CPU.Build.0 = Debug|Any CPU + {CBE20411-5DB7-487D-825D-7694267BB6F5}.Release|Any CPU.ActiveCfg = Release|Any CPU + {CBE20411-5DB7-487D-825D-7694267BB6F5}.Release|Any CPU.Build.0 = Release|Any CPU + EndGlobalSection + GlobalSection(MonoDevelopProperties) = preSolution + StartupItem = LwipMibCompiler\LwipMibCompiler.csproj + EndGlobalSection + GlobalSection(SolutionProperties) = preSolution + HideSolutionNode = FALSE + EndGlobalSection +EndGlobal diff --git a/contrib/apps/LwipMibCompiler/LwipMibCompiler/LwipMibCompiler.csproj b/contrib/apps/LwipMibCompiler/LwipMibCompiler/LwipMibCompiler.csproj new file mode 100644 index 00000000000..694263aa1ea --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipMibCompiler/LwipMibCompiler.csproj @@ -0,0 +1,73 @@ +<?xml version="1.0" encoding="utf-8"?> +<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003"> + <PropertyGroup> + <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration> + <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform> + <ProductVersion>8.0.30703</ProductVersion> + <SchemaVersion>2.0</SchemaVersion> + <ProjectGuid>{C25D5640-D999-49BD-82E0-A1975296A91E}</ProjectGuid> + <OutputType>Exe</OutputType> + <AppDesignerFolder>Properties</AppDesignerFolder> + <RootNamespace>LwipMibCompiler</RootNamespace> + <AssemblyName>LwipMibCompiler</AssemblyName> + <TargetFrameworkVersion>v4.0</TargetFrameworkVersion> + <FileAlignment>512</FileAlignment> + <TargetFrameworkProfile /> + </PropertyGroup> + <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Debug|AnyCPU'"> + <DebugSymbols>true</DebugSymbols> + <OutputPath>bin\Debug</OutputPath> + <DefineConstants>DEBUG;TRACE</DefineConstants> + <DebugType>full</DebugType> + <PlatformTarget>AnyCPU</PlatformTarget> + <ErrorReport>prompt</ErrorReport> + <CodeAnalysisIgnoreBuiltInRuleSets>false</CodeAnalysisIgnoreBuiltInRuleSets> + <CodeAnalysisIgnoreBuiltInRules>false</CodeAnalysisIgnoreBuiltInRules> + <WarningLevel>4</WarningLevel> + <Optimize>false</Optimize> + <UseVSHostingProcess>false</UseVSHostingProcess> + </PropertyGroup> + <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Release|AnyCPU'"> + <OutputPath>bin\Release</OutputPath> + <DefineConstants>TRACE</DefineConstants> + <Optimize>true</Optimize> + <DebugType>pdbonly</DebugType> + <PlatformTarget>AnyCPU</PlatformTarget> + <ErrorReport>prompt</ErrorReport> + <WarningLevel>4</WarningLevel> + <UseVSHostingProcess>false</UseVSHostingProcess> + </PropertyGroup> + <ItemGroup> + <Reference Include="System" /> + </ItemGroup> + <ItemGroup> + <Compile Include="Program.cs" /> + <Compile Include="Properties\AssemblyInfo.cs" /> + </ItemGroup> + <ItemGroup> + <None Include="app.config" /> + </ItemGroup> + <ItemGroup> + <ProjectReference Include="..\CCodeGeneration\CCodeGeneration.csproj"> + <Project>{7DA7C0AB-0982-4BF5-9324-F59A7A08D65B}</Project> + <Name>CCodeGeneration</Name> + </ProjectReference> + <ProjectReference Include="..\LwipSnmpCodeGeneration\LwipSnmpCodeGeneration.csproj"> + <Project>{AABCAB90-1540-45D4-A159-14831A54E9A3}</Project> + <Name>LwipSnmpCodeGeneration</Name> + </ProjectReference> + <ProjectReference Include="..\SharpSnmpLib\SharpSnmpLib.Mib.csproj"> + <Project>{CBE20411-5DB7-487D-825D-7694267BB6F5}</Project> + <Name>SharpSnmpLib.Mib</Name> + </ProjectReference> + </ItemGroup> + <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" /> + <PropertyGroup /> + <!-- To modify your build process, add your task inside one of the targets below and uncomment it. + Other similar extension points exist, see Microsoft.Common.targets. + <Target Name="BeforeBuild"> + </Target> + <Target Name="AfterBuild"> + </Target> + --> +</Project> \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/LwipMibCompiler/Program.cs b/contrib/apps/LwipMibCompiler/LwipMibCompiler/Program.cs new file mode 100644 index 00000000000..5dff8405cc2 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipMibCompiler/Program.cs @@ -0,0 +1,480 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Collections.Generic; +using System.IO; +using System.Reflection; +using System.Text.RegularExpressions; +using CCodeGeneration; +using Lextm.SharpSnmpLib.Mib; +using Lextm.SharpSnmpLib.Mib.Elements.Entities; +using Lextm.SharpSnmpLib.Mib.Elements.Types; +using LwipSnmpCodeGeneration; + +namespace LwipMibCompiler +{ + class Program + { + private static readonly Regex _alphaNumericRegex = new Regex("[^a-zA-Z0-9]"); + + static void Main(string[] args) + { + Console.WriteLine("lwIP MIB Compiler"); + Console.WriteLine(""); + + // check args + if ((args.Length < 2) || String.IsNullOrWhiteSpace(args[0]) || String.IsNullOrWhiteSpace(args[1])) + { + PrintUsage(); + return; + } + + string mibFile = args[0]; + if (!File.Exists(mibFile)) + { + Console.WriteLine(String.Format("Unable to find file '{0}'!", mibFile)); + } + + string destFile = args[1]; + string destHeaderFile; + + if (Directory.Exists(destFile)) + { + // only directory passed -> create dest filename from mib filename + string mibFileName = Path.GetFileNameWithoutExtension(mibFile).ToLowerInvariant(); + destFile = Path.Combine(destFile, mibFileName + ".c"); + } + + string destFileExt = Path.GetExtension(destFile); + if (!String.IsNullOrEmpty(destFileExt)) + { + destHeaderFile = destFile.Substring(0, destFile.Length - destFileExt.Length); + } + else + { + destHeaderFile = destFile; + } + destHeaderFile += ".h"; + + for (int i=2; i<args.Length; i++) + { + if (!String.IsNullOrWhiteSpace(args[i]) && Directory.Exists(args[i])) + { + MibTypesResolver.RegisterResolver(new FileSystemMibResolver(args[i], true)); + } + } + + + // read and resolve MIB + Console.WriteLine(" Reading MIB file..."); + + MibDocument md = new MibDocument(mibFile); + MibTypesResolver.ResolveTypes(md.Modules[0]); + MibTree mt = new MibTree(md.Modules[0] as MibModule); + + if (mt.Root.Count == 0) + { + Console.WriteLine("No root element found inside MIB!"); + return; + } + + MibCFile generatedFile = new MibCFile(); + MibHeaderFile generatedHeaderFile = new MibHeaderFile(); + + foreach (MibTreeNode mibTreeNode in mt.Root) + { + // create LWIP object tree from MIB structure + Console.WriteLine(" Creating lwIP object tree " + mibTreeNode.Entity.Name); + + SnmpMib snmpMib = new SnmpMib(); + snmpMib.Oid = mibTreeNode.Entity.Value; + snmpMib.BaseOid = MibTypesResolver.ResolveOid(mibTreeNode.Entity).GetOidValues(); + snmpMib.Name = mibTreeNode.Entity.Name; + + ProcessMibTreeNode(mibTreeNode, snmpMib); + + // let the tree transform itself depending on node structure + snmpMib.Analyze(); + + if (snmpMib.ChildNodes.Count != 0) + { + // generate code from LWIP object tree + Console.WriteLine(" Generating code " + snmpMib.Name); + snmpMib.Generate(generatedFile, generatedHeaderFile); + } + } + + string preservedCode = MibCFile.GetPreservedCode(destFile); + if (!string.IsNullOrEmpty(preservedCode)) + { + generatedFile.PreservedCode.Add(new PlainText(preservedCode)); + } + else + { + generatedFile.PreservedCode.AddRange(generatedFile.Implementation); + } + generatedFile.Implementation.Clear(); + + + using (StreamWriter fileWriter = new StreamWriter(destHeaderFile)) + { + CGenerator cGenerator = new CGenerator(fileWriter, destHeaderFile, 3, " ", Environment.NewLine); + generatedHeaderFile.Save(cGenerator); + } + using (StreamWriter fileWriter = new StreamWriter(destFile)) + { + CGenerator cGenerator = new CGenerator(fileWriter, destFile, 3, " ", Environment.NewLine); + generatedFile.Save(cGenerator); + } + + Console.WriteLine(" Done"); + } + + private static void PrintUsage() + { + string codeBase = Assembly.GetExecutingAssembly().CodeBase; + string appName = Path.GetFileName(codeBase); + + Console.WriteLine("Usage:"); + Console.WriteLine(String.Format(" {0} <source MIB file> <dest C file> [<search path 1 for referred MIB's> <search path 2 for referred MIB's> ...]", appName)); + Console.WriteLine(""); + Console.WriteLine(" <source MIB file>"); + Console.WriteLine(" Path and filename of MIB file to convert."); + Console.WriteLine(""); + Console.WriteLine(" <dest C file>"); + Console.WriteLine(" Destination path and file. If a path is passed only, filename is auto"); + Console.WriteLine(" generated from MIB file name."); + Console.WriteLine(""); + Console.WriteLine(" <search path X for referred MIB's>"); + Console.WriteLine(" It's important to provide all referred MIB's in order to correctly "); + Console.WriteLine(" resolve all used types."); + Console.WriteLine(""); + } + + + #region Generation of LWIP Object Tree + + private static void ProcessMibTreeNode(MibTreeNode mibTreeNode, SnmpTreeNode assignedSnmpNode) + { + foreach (MibTreeNode mtn in mibTreeNode.ChildNodes) + { + // in theory container nodes may also be scalars or tables at the same time (for now only process real containers) + if (mtn.NodeType == MibTreeNodeType.Container) + { + SnmpTreeNode snmpTreeNode = GenerateSnmpTreeNode(mtn, assignedSnmpNode); + assignedSnmpNode.ChildNodes.Add(snmpTreeNode); + + ProcessMibTreeNode(mtn, snmpTreeNode); + } + else if ((mtn.NodeType & MibTreeNodeType.Scalar) != 0) + { + SnmpScalarNode snmpScalarNode = GenerateSnmpScalarNode(mtn, assignedSnmpNode); + if (snmpScalarNode != null) + { + assignedSnmpNode.ChildNodes.Add(snmpScalarNode); + } + } + else if ((mtn.NodeType & MibTreeNodeType.Table) != 0) + { + SnmpTableNode snmpTableNode = GenerateSnmpTableNode(mtn, assignedSnmpNode); + if (snmpTableNode != null) + { + assignedSnmpNode.ChildNodes.Add(snmpTableNode); + } + } + } + } + + private static SnmpTreeNode GenerateSnmpTreeNode(MibTreeNode mibTreeNode, SnmpTreeNode parentNode) + { + SnmpTreeNode result = new SnmpTreeNode(parentNode); + result.Name = _alphaNumericRegex.Replace (mibTreeNode.Entity.Name, ""); + result.Oid = mibTreeNode.Entity.Value; + result.FullOid = MibTypesResolver.ResolveOid(mibTreeNode.Entity).GetOidString(); + + return result; + } + + private static SnmpScalarNode GenerateSnmpScalarNode(MibTreeNode mibTreeNode, SnmpTreeNode parentNode, bool ignoreAccessibleFlag = false) + { + ObjectType ote = mibTreeNode.Entity as ObjectType; + if (ote != null) + { + return GenerateSnmpScalarNode(ote, parentNode, ignoreAccessibleFlag); + } + + return null; + } + + private static SnmpScalarNode GenerateSnmpScalarNode(ObjectType ote, SnmpTreeNode parentNode, bool ignoreAccessibleFlag = false) + { + SnmpScalarNode result; + + ITypeAssignment mibType = ote.BaseType; + IntegerType it = (mibType as IntegerType); + if (it != null) + { + if (ote.ReferredType.Name == Symbol.TruthValue.ToString()) + { + result = new SnmpScalarNodeTruthValue(parentNode); + } + else if ((it.Type == IntegerType.Types.Integer) || (it.Type == IntegerType.Types.Integer32)) + { + result = new SnmpScalarNodeInt(parentNode); + } + else + { + Console.WriteLine(String.Format("Unsupported IntegerType '{0}'!", it.Type)); + return null; + } + if (it.IsEnumeration) + { + result.Restrictions.AddRange(CreateRestrictions(it.Enumeration)); + } + else + { + result.Restrictions.AddRange(CreateRestrictions(it.Ranges)); + } + } + else + { + UnsignedType ut = (mibType as UnsignedType); + if (ut != null) + { + if ((ut.Type == UnsignedType.Types.Unsigned32) || + (ut.Type == UnsignedType.Types.Gauge32)) + { + result = new SnmpScalarNodeUint(SnmpDataType.Gauge, parentNode); + } + else if (ut.Type == UnsignedType.Types.Counter32) + { + result = new SnmpScalarNodeUint(SnmpDataType.Counter, parentNode); + } + else if (ut.Type == UnsignedType.Types.TimeTicks) + { + result = new SnmpScalarNodeUint(SnmpDataType.TimeTicks, parentNode); + } + else if (ut.Type == UnsignedType.Types.Counter64) + { + result = new SnmpScalarNodeCounter64(parentNode); + if ((ut.Ranges != null) && (ut.Ranges.Count > 0)) + { + Console.WriteLine(String.Format("Generation of ranges is not supported for Counter64 type!")); + return null; + } + } + else + { + Console.WriteLine(String.Format("Unsupported UnsignedType '{0}'!", ut.Type)); + return null; + } + result.Restrictions.AddRange(CreateRestrictions(ut.Ranges)); + } + else if (mibType is IpAddressType) + { + result = new SnmpScalarNodeOctetString(SnmpDataType.IpAddress, parentNode); + result.Restrictions.AddRange(CreateRestrictions((mibType as OctetStringType).Size)); + } + else if (mibType is OpaqueType) + { + result = new SnmpScalarNodeOctetString(SnmpDataType.Opaque, parentNode); + result.Restrictions.AddRange(CreateRestrictions((mibType as OctetStringType).Size)); + } + else if (mibType is OctetStringType) + { + result = new SnmpScalarNodeOctetString(SnmpDataType.OctetString, parentNode); + result.Restrictions.AddRange(CreateRestrictions((mibType as OctetStringType).Size)); + } + else if (mibType is ObjectIdentifierType) + { + result = new SnmpScalarNodeObjectIdentifier(parentNode); + } + else if (mibType is BitsType) + { + result = new SnmpScalarNodeBits(parentNode, (uint)((mibType as BitsType).Map.GetHighestValue() + 1)); + result.Restrictions.AddRange(CreateRestrictions(mibType as BitsType)); + } + else + { + TypeAssignment ta = mibType as TypeAssignment; + if (ta != null) + { + Console.WriteLine(String.Format("Unsupported BaseType: Module='{0}', Name='{1}', Type='{2}'!", ta.Module.Name, ta.Name, ta.Type)); + } + else + { + Console.WriteLine(String.Format("Unsupported BaseType: Module='{0}', Name='{1}'!", mibType.Module, mibType.Name)); + } + + return null; + } + } + + result.Name = _alphaNumericRegex.Replace(ote.Name, ""); + result.Oid = ote.Value; + + if (ote.Access == MaxAccess.readWrite) + { + result.AccessMode = SnmpAccessMode.ReadWrite; + } + else if (ote.Access == MaxAccess.readOnly) + { + result.AccessMode = SnmpAccessMode.ReadOnly; + } + else if (ote.Access == MaxAccess.readCreate) + { + result.AccessMode = SnmpAccessMode.ReadOnly; + } + else if (ignoreAccessibleFlag && (ote.Access == MaxAccess.notAccessible)) + { + result.AccessMode = SnmpAccessMode.NotAccessible; + } + else + { + // not accessible or unsupported access type + return null; + } + + return result; + } + + private static IEnumerable<IRestriction> CreateRestrictions(ValueRanges ranges) + { + List<IRestriction> result = new List<IRestriction>(); + + if (ranges != null) + { + foreach (ValueRange range in ranges) + { + if (!range.End.HasValue) + { + result.Add(new IsEqualRestriction(range.Start)); + } + else + { + result.Add(new IsInRangeRestriction(range.Start, range.End.Value)); + } + } + } + + return result; + } + + private static IEnumerable<IRestriction> CreateRestrictions(ValueMap map) + { + if ((map != null) && (map.Count > 0)) + { + return CreateRestrictions(map.GetContinousRanges()); + } + + return new List<IRestriction>(); + } + + private static IEnumerable<IRestriction> CreateRestrictions(BitsType bt) + { + List<IRestriction> result = new List<IRestriction>(); + + if ((bt != null) && (bt.Map != null)) + { + result.Add(new BitMaskRestriction(bt.Map.GetBitMask())); + } + + return result; + } + + private static SnmpTableNode GenerateSnmpTableNode(MibTreeNode mibTreeNode, SnmpTreeNode parentNode) + { + SnmpTableNode result = new SnmpTableNode(parentNode); + result.Name = mibTreeNode.Entity.Name; + result.Oid = mibTreeNode.Entity.Value; + + // expect exactly one row entry + if ((mibTreeNode.ChildNodes.Count != 1) || ((mibTreeNode.ChildNodes[0].NodeType & MibTreeNodeType.TableRow) == 0) || (mibTreeNode.ChildNodes[0].Entity.Value != 1)) + { + Console.WriteLine("Found table with unsupported properties! Table needs exactly one (fixed) TableRow with OID=1 ! (" + mibTreeNode.Entity.Name + ")"); + return null; + } + + MibTreeNode rowNode = mibTreeNode.ChildNodes[0]; + + ObjectType rot = rowNode.Entity as ObjectType; + if (rot != null) + { + if (!String.IsNullOrWhiteSpace(rot.Augments)) + { + result.AugmentedTableRow = rot.Augments; + + // the indices from another table shall be used because this table is only an extension of it + rot = MibTypesResolver.ResolveDeclaration(rot.Module, rot.Augments) as ObjectType; + } + + if (rot.Indices != null) + { + foreach (string index in rot.Indices) + { + ObjectType indexEntity = MibTypesResolver.ResolveDeclaration(rot.Module, index) as ObjectType; + if (indexEntity == null) + { + Console.WriteLine(String.Format("Could not resolve index '{0}' for table '{1}'! Table omitted!", index, result.Name)); + return null; + } + + result.IndexNodes.Add(GenerateSnmpScalarNode(indexEntity, parentNode, ignoreAccessibleFlag: true)); + } + } + } + + if (result.IndexNodes.Count == 0) + { + // a table cannot be used without index + Console.WriteLine("Found table without any index column ! (" + mibTreeNode.Entity.Name + ")"); + return null; + } + + // add child nodes + foreach (MibTreeNode cellNode in rowNode.ChildNodes) + { + SnmpScalarNode ssn = GenerateSnmpScalarNode(cellNode, parentNode); + if (ssn != null) + { + result.CellNodes.Add(ssn); + } + } + + return result; + } + + #endregion + + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipMibCompiler/Properties/AssemblyInfo.cs b/contrib/apps/LwipMibCompiler/LwipMibCompiler/Properties/AssemblyInfo.cs new file mode 100644 index 00000000000..d30b8425b19 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipMibCompiler/Properties/AssemblyInfo.cs @@ -0,0 +1,36 @@ +using System.Reflection; +using System.Runtime.CompilerServices; +using System.Runtime.InteropServices; + +// Allgemeine Informationen über eine Assembly werden über die folgenden +// Attribute gesteuert. Ändern Sie diese Attributwerte, um die Informationen zu ändern, +// die mit einer Assembly verknüpft sind. +[assembly: AssemblyTitle("ConsoleApplication28")] +[assembly: AssemblyDescription("")] +[assembly: AssemblyConfiguration("")] +[assembly: AssemblyCompany("")] +[assembly: AssemblyProduct("ConsoleApplication28")] +[assembly: AssemblyCopyright("Copyright © 2015")] +[assembly: AssemblyTrademark("")] +[assembly: AssemblyCulture("")] + +// Durch Festlegen von ComVisible auf "false" werden die Typen in dieser Assembly unsichtbar +// für COM-Komponenten. Wenn Sie auf einen Typ in dieser Assembly von +// COM zugreifen müssen, legen Sie das ComVisible-Attribut für diesen Typ auf "true" fest. +[assembly: ComVisible(false)] + +// Die folgende GUID bestimmt die ID der Typbibliothek, wenn dieses Projekt für COM verfügbar gemacht wird +[assembly: Guid("0abf7541-6a96-43cd-9e24-462e074b2c96")] + +// Versionsinformationen für eine Assembly bestehen aus den folgenden vier Werten: +// +// Hauptversion +// Nebenversion +// Buildnummer +// Revision +// +// Sie können alle Werte angeben oder die standardmäßigen Build- und Revisionsnummern +// übernehmen, indem Sie "*" eingeben: +// [assembly: AssemblyVersion("1.0.*")] +[assembly: AssemblyVersion("1.0.0.0")] +[assembly: AssemblyFileVersion("1.0.0.0")] diff --git a/contrib/apps/LwipMibCompiler/LwipMibCompiler/app.config b/contrib/apps/LwipMibCompiler/LwipMibCompiler/app.config new file mode 100644 index 00000000000..e3656033377 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipMibCompiler/app.config @@ -0,0 +1,3 @@ +<?xml version="1.0"?> +<configuration> +<startup><supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0"/></startup></configuration> diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/IRestriction.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/IRestriction.cs new file mode 100644 index 00000000000..ee2f4536217 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/IRestriction.cs @@ -0,0 +1,120 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; + +namespace LwipSnmpCodeGeneration +{ + public interface IRestriction + { + string GetCheckCodeValid(string varNameToCheck); + string GetCheckCodeInvalid(string varNameToCheck); + } + + public class BitMaskRestriction : IRestriction + { + UInt32 mask; + + public BitMaskRestriction(UInt32 mask) + { + this.mask = mask; + } + + public string GetCheckCodeValid(string varNameToCheck) + { + return String.Format("(({0} & {1}) == {0})", varNameToCheck, this.mask); + } + + public string GetCheckCodeInvalid(string varNameToCheck) + { + return String.Format("(({0} & {1}) != {0})", varNameToCheck, this.mask); + } + } + + public class IsEqualRestriction : IRestriction + { + private Int64 value; + + public IsEqualRestriction(Int64 value) + { + this.value = value; + } + + public long Value + { + get { return value; } + } + + public string GetCheckCodeValid(string varNameToCheck) + { + return String.Format("({0} == {1})", varNameToCheck, this.value); + } + + public string GetCheckCodeInvalid(string varNameToCheck) + { + return String.Format("({0} != {1})", varNameToCheck, this.value); + } + } + + public class IsInRangeRestriction : IRestriction + { + private Int64 rangeStart; + private Int64 rangeEnd; + + public IsInRangeRestriction(Int64 rangeStart, Int64 rangeEnd) + { + this.rangeStart = rangeStart; + this.rangeEnd = rangeEnd; + } + + public long RangeStart + { + get { return this.rangeStart; } + } + + public long RangeEnd + { + get { return this.rangeEnd; } + } + + public string GetCheckCodeValid(string varNameToCheck) + { + return String.Format("(({0} >= {1}) && ({0} <= {2}))", varNameToCheck, this.rangeStart, this.rangeEnd); + } + + public string GetCheckCodeInvalid(string varNameToCheck) + { + return String.Format("(({0} < {1}) || ({0} > {2}))", varNameToCheck, this.rangeStart, this.rangeEnd); + } + } + +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/LwipSnmp.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/LwipSnmp.cs new file mode 100644 index 00000000000..edac59e04ce --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/LwipSnmp.cs @@ -0,0 +1,199 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; + +namespace LwipSnmpCodeGeneration +{ + public static class LwipOpts + { + public static bool GenerateEmptyFolders = false; + /// <summary> + /// If a tree node only has scalar nodes as child nodes, it is replaced by + /// a single scalar array node in order to save memory and have only one single get/test/set method for all scalars. + /// </summary> + public static bool GenerateScalarArrays = true; + /// <summary> + /// If a tree node has multiple scalars as subnodes as well as other treenodes it + /// defines a single get/test/set method for all scalar child node. + /// (without other treenodes as child it would have been converted to scalar array node). + /// </summary> + public static bool GenerateSingleAccessMethodsForTreeNodeScalars = GenerateScalarArrays; + } + + public static class LwipDefs + { + public const string Null = "NULL"; + public const string Vt_U8 = "u8_t"; + public const string Vt_U16 = "u16_t"; + public const string Vt_U32 = "u32_t"; + public const string Vt_S8 = "s8_t"; + public const string Vt_S16 = "s16_t"; + public const string Vt_S32 = "s32_t"; + public const string Vt_Snmp_err = "snmp_err_t"; + + public const string Incl_SnmpOpts = "lwip/apps/snmp_opts.h"; + public const string Opt_SnmpEnabled = "LWIP_SNMP"; + + public const string Vt_StMib = "struct snmp_mib"; + public const string Vt_StObjectId = "struct snmp_obj_id"; + public const string Vt_StNode = "struct snmp_node"; + public const string Vt_StNodeInstance = "struct snmp_node_instance"; + public const string Vt_StTreeNode = "struct snmp_tree_node"; + public const string Vt_StScalarNode = "struct snmp_scalar_node"; + public const string Vt_StScalarArrayNode = "struct snmp_scalar_array_node"; + public const string Vt_StScalarArrayNodeDef = "struct snmp_scalar_array_node_def"; + public const string Vt_StTableNode = "struct snmp_table_node"; + public const string Vt_StTableColumnDef = "struct snmp_table_col_def"; + public const string Vt_StNextOidState = "struct snmp_next_oid_state"; + + public const string Def_NodeAccessReadOnly = "SNMP_NODE_INSTANCE_READ_ONLY"; + public const string Def_NodeAccessReadWrite = "SNMP_NODE_INSTANCE_READ_WRITE"; + public const string Def_NodeAccessWriteOnly = "SNMP_NODE_INSTANCE_WRITE_ONLY"; + public const string Def_NodeAccessNotAccessible = "SNMP_NODE_INSTANCE_NOT_ACCESSIBLE"; + + public const string Def_ErrorCode_Ok = "SNMP_ERR_NOERROR"; + public const string Def_ErrorCode_WrongValue = "SNMP_ERR_WRONGVALUE"; + public const string Def_ErrorCode_NoSuchInstance = "SNMP_ERR_NOSUCHINSTANCE"; + + public const string FnctSuffix_GetValue = "_get_value"; + public const string FnctSuffix_SetTest = "_set_test"; + public const string FnctSuffix_SetValue = "_set_value"; + public const string FnctSuffix_GetInstance = "_get_instance"; + public const string FnctSuffix_GetNextInstance = "_get_next_instance"; + + public const string FnctName_SetTest_Ok = "snmp_set_test_ok"; + + public static string GetLwipDefForSnmpAccessMode(SnmpAccessMode am) + { + switch (am) + { + case SnmpAccessMode.ReadOnly: return Def_NodeAccessReadOnly; + case SnmpAccessMode.ReadWrite: return Def_NodeAccessReadWrite; + case SnmpAccessMode.NotAccessible: return Def_NodeAccessNotAccessible; + case SnmpAccessMode.WriteOnly: return Def_NodeAccessWriteOnly; + default: throw new NotSupportedException("Unknown SnmpAccessMode!"); + } + } + + public static string GetAsn1DefForSnmpDataType(SnmpDataType dt) + { + switch (dt) + { + // primitive + case SnmpDataType.Null: + return "SNMP_ASN1_TYPE_NULL"; + case SnmpDataType.Bits: + case SnmpDataType.OctetString: + return "SNMP_ASN1_TYPE_OCTET_STRING"; + case SnmpDataType.ObjectIdentifier: + return "SNMP_ASN1_TYPE_OBJECT_ID"; + case SnmpDataType.Integer: + return "SNMP_ASN1_TYPE_INTEGER"; + + // application + case SnmpDataType.IpAddress: + return "SNMP_ASN1_TYPE_IPADDR"; + case SnmpDataType.Counter: + return "SNMP_ASN1_TYPE_COUNTER"; + case SnmpDataType.Gauge: + return "SNMP_ASN1_TYPE_GAUGE"; + case SnmpDataType.TimeTicks: + return "SNMP_ASN1_TYPE_TIMETICKS"; + case SnmpDataType.Opaque: + return "SNMP_ASN1_TYPE_OPAQUE"; + case SnmpDataType.Counter64: + return "SNMP_ASN1_TYPE_COUNTER64"; + default: + throw new NotSupportedException("Unknown SnmpDataType!"); + } + } + + public static string GetLengthForSnmpDataType(SnmpDataType dt) + { + switch (dt) + { + case SnmpDataType.Null: + return "0"; + + case SnmpDataType.Integer: + case SnmpDataType.Counter: + case SnmpDataType.IpAddress: + case SnmpDataType.Gauge: + case SnmpDataType.TimeTicks: + return "4"; + + case SnmpDataType.Counter64: + return "8"; + + case SnmpDataType.OctetString: + case SnmpDataType.ObjectIdentifier: + case SnmpDataType.Bits: + case SnmpDataType.Opaque: + return null; + + default: + throw new NotSupportedException("Unknown SnmpDataType!"); + } + } + } + + public enum SnmpDataType + { + Null, + + Integer, // INTEGER, Integer32 + + Counter, // Counter, Counter32 + Gauge, // Gauge, Gauge32, Unsigned32 + TimeTicks, + + Counter64, + + OctetString, + Opaque, + Bits, + + ObjectIdentifier, + + IpAddress, + } + + public enum SnmpAccessMode + { + ReadOnly, + ReadWrite, + WriteOnly, + NotAccessible + } + +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/LwipSnmpCodeGeneration.csproj b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/LwipSnmpCodeGeneration.csproj new file mode 100644 index 00000000000..f4541c0c18d --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/LwipSnmpCodeGeneration.csproj @@ -0,0 +1,72 @@ +<?xml version="1.0" encoding="utf-8"?> +<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003"> + <PropertyGroup> + <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration> + <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform> + <ProductVersion>8.0.30703</ProductVersion> + <SchemaVersion>2.0</SchemaVersion> + <ProjectGuid>{AABCAB90-1540-45D4-A159-14831A54E9A3}</ProjectGuid> + <OutputType>Library</OutputType> + <AppDesignerFolder>Properties</AppDesignerFolder> + <RootNamespace>LwipSnmpCodeGeneration</RootNamespace> + <AssemblyName>LwipSnmpCodeGeneration</AssemblyName> + <TargetFrameworkVersion>v4.0</TargetFrameworkVersion> + <FileAlignment>512</FileAlignment> + <TargetFrameworkProfile /> + </PropertyGroup> + <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' "> + <DebugSymbols>true</DebugSymbols> + <DebugType>full</DebugType> + <Optimize>false</Optimize> + <OutputPath>bin\Debug</OutputPath> + <DefineConstants>DEBUG;TRACE</DefineConstants> + <ErrorReport>prompt</ErrorReport> + <WarningLevel>4</WarningLevel> + </PropertyGroup> + <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' "> + <DebugType>pdbonly</DebugType> + <Optimize>true</Optimize> + <OutputPath>bin\Release</OutputPath> + <DefineConstants>TRACE</DefineConstants> + <ErrorReport>prompt</ErrorReport> + <WarningLevel>4</WarningLevel> + </PropertyGroup> + <ItemGroup> + <Reference Include="System" /> + </ItemGroup> + <ItemGroup> + <Compile Include="IRestriction.cs" /> + <Compile Include="SnmpScalarNodeCounter64.cs" /> + <Compile Include="SnmpScalarNodeTruthValue.cs" /> + <Compile Include="SnmpScalarAggregationNode.cs" /> + <Compile Include="SnmpTableNode.cs" /> + <Compile Include="SnmpScalarArrayNode.cs" /> + <Compile Include="MibHeaderFile.cs" /> + <Compile Include="SnmpScalarNodeBits.cs" /> + <Compile Include="SnmpMib.cs" /> + <Compile Include="SnmpScalarNodeInt.cs" /> + <Compile Include="SnmpScalarNodeObjectIdentifier.cs" /> + <Compile Include="SnmpScalarNodeOctetString.cs" /> + <Compile Include="SnmpScalarNodeUint.cs" /> + <Compile Include="SnmpTreeNode.cs" /> + <Compile Include="LwipSnmp.cs" /> + <Compile Include="MibCFile.cs" /> + <Compile Include="Properties\AssemblyInfo.cs" /> + <Compile Include="SnmpNode.cs" /> + <Compile Include="SnmpScalarNode.cs" /> + </ItemGroup> + <ItemGroup> + <ProjectReference Include="..\CCodeGeneration\CCodeGeneration.csproj"> + <Project>{7DA7C0AB-0982-4BF5-9324-F59A7A08D65B}</Project> + <Name>CCodeGeneration</Name> + </ProjectReference> + </ItemGroup> + <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" /> + <!-- To modify your build process, add your task inside one of the targets below and uncomment it. + Other similar extension points exist, see Microsoft.Common.targets. + <Target Name="BeforeBuild"> + </Target> + <Target Name="AfterBuild"> + </Target> + --> +</Project> \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/MibCFile.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/MibCFile.cs new file mode 100644 index 00000000000..c48ec29d068 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/MibCFile.cs @@ -0,0 +1,196 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System.Collections.Generic; +using CCodeGeneration; +using System; +using System.IO; + +namespace LwipSnmpCodeGeneration +{ + public class MibCFile + { + #region Fields + + private const string PreservedSectionMarker = "LWIP MIB generator - preserved section begin"; + private const string PreservedSectionHeader = + "+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++\n" + + PreservedSectionMarker + "\n" + + "Code below is preserved on regeneration. Remove these comment lines to regenerate code.\n" + + "+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++"; + + private readonly List<CodeElement> includes = new List<CodeElement>(); + private readonly List<CodeElement> defines = new List<CodeElement>(); + private readonly List<CodeElement> declarations = new List<CodeElement>(); + private readonly List<CodeElement> implementation = new List<CodeElement>(); + private readonly List<CodeElement> preservedCode = new List<CodeElement>(); + + #endregion + + public MibCFile() + { + } + + #region Accessors + + public List<CodeElement> Includes + { + get { return this.includes; } + } + + public List<CodeElement> Defines + { + get { return this.defines; } + } + + public List<CodeElement> Declarations + { + get { return this.declarations; } + } + + public List<CodeElement> Implementation + { + get { return this.implementation; } + } + + public List<CodeElement> PreservedCode + { + get { return this.preservedCode; } + } + + #endregion + + #region Methods + + public void Save(CGenerator cGenerator) + { + CFile cFile = new CFile(); + + cFile.AddElement(new Comment("Generated by LwipMibCompiler")); + cFile.AddElement(EmptyLine.SingleLine); + + cFile.AddElement(new PP_Include(LwipDefs.Incl_SnmpOpts)); + CodeContainerBase e = cFile.AddElement(new PP_If(LwipDefs.Opt_SnmpEnabled)) as CodeContainerBase; + e.AddElement(EmptyLine.SingleLine); + + // include header file + string file = cGenerator.FileName; + if (!String.IsNullOrWhiteSpace(file)) + { + string ext = System.IO.Path.GetExtension(file); + + string headerFile = !String.IsNullOrEmpty(ext) ? file.Substring(0, file.Length - ext.Length) : file; + headerFile += ".h"; + + e.AddElement(new PP_Include(headerFile)); + } + + // include common snmp files + e.AddElement(new PP_Include("lwip/apps/snmp.h")); + e.AddElement(new PP_Include("lwip/apps/snmp_core.h")); + e.AddElement(new PP_Include("lwip/apps/snmp_scalar.h")); + e.AddElement(new PP_Include("lwip/apps/snmp_table.h")); + + if (this.includes.Count > 0) + { + e.AddElement(EmptyLine.SingleLine); + e.AddElements(this.includes); + } + + if (this.defines.Count > 0) + { + e.AddElement(EmptyLine.SingleLine); + e.AddElements(this.defines); + } + + if (this.declarations.Count > 0) + { + e.AddElement(EmptyLine.TwoLines); + e.AddElements(this.declarations); + } + + if (this.implementation.Count > 0) + { + e.AddElement(EmptyLine.TwoLines); + e.AddElements(this.implementation); + } + + if (this.preservedCode.Count > 0) + { + e.AddElement(EmptyLine.TwoLines); + e.AddElement(new Comment(PreservedSectionHeader)); + e.AddElement(EmptyLine.SingleLine); + e.AddElements(this.preservedCode); + } + + cFile.Save(cGenerator); + } + + public static string GetPreservedCode(string file) + { + if (File.Exists(file)) + { + using (StreamReader fileStream = new StreamReader(file)) + { + while (!fileStream.EndOfStream) + { + string line = fileStream.ReadLine(); + if (line == PreservedSectionMarker) + { + break; + } + } + + if (!fileStream.EndOfStream) + { + // skip the rest of the comment + spacer line + fileStream.ReadLine(); // "Code below is preserved... + fileStream.ReadLine(); // "+++++++++++++++++++++++... + fileStream.ReadLine(); // */ + fileStream.ReadLine(); // + + string preservedCode = fileStream.ReadToEnd(); + + int lastEndif = preservedCode.LastIndexOf("#endif", StringComparison.Ordinal); + preservedCode = preservedCode.Remove(lastEndif); + + return preservedCode; + } + } + } + + return null; + } + + #endregion + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/MibHeaderFile.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/MibHeaderFile.cs new file mode 100644 index 00000000000..95f2a06c5a1 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/MibHeaderFile.cs @@ -0,0 +1,129 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System.Collections.Generic; +using System.Text.RegularExpressions; +using CCodeGeneration; + +namespace LwipSnmpCodeGeneration +{ + public class MibHeaderFile + { + + #region Fields + + private readonly List<CodeElement> defines = new List<CodeElement>(); + private readonly List<CodeElement> includes = new List<CodeElement>(); + private readonly List<CodeElement> functionDeclarations = new List<CodeElement>(); + private readonly List<CodeElement> variableDeclarations = new List<CodeElement>(); + + #endregion + + public MibHeaderFile() + { + } + + #region Accessors + + public List<CodeElement> Defines + { + get { return this.defines; } + } + + public List<CodeElement> Includes + { + get { return this.includes; } + } + + public List<CodeElement> FunctionDeclarations + { + get { return this.functionDeclarations; } + } + + public List<CodeElement> VariableDeclarations + { + get { return this.variableDeclarations; } + } + + #endregion + + #region Methods + + public void Save(CGenerator cGenerator) + { + CFile cFile = new CFile(); + + cFile.AddElement(new Comment("Generated by LwipMibCompiler")); + cFile.AddElement(EmptyLine.SingleLine); + + string headerDefine = cGenerator.FileName; + headerDefine = new Regex("[^a-zA-Z0-9]").Replace(headerDefine, "_"); + headerDefine = headerDefine.ToUpperInvariant(); + + CodeContainerBase e = cFile.AddElement(new PP_Ifdef(headerDefine, inverted: true)) as CodeContainerBase; + e.AddElement(new PP_Macro(headerDefine, headerDefine)); + e.AddElement(EmptyLine.SingleLine); + + e.AddElement(new PP_Include(LwipDefs.Incl_SnmpOpts)); + e = e.AddElement(new PP_If(LwipDefs.Opt_SnmpEnabled)) as CodeContainerBase; + e.AddElement(EmptyLine.SingleLine); + + CodeContainerBase cplusplusopen = e.AddElement(new PP_Ifdef("__cplusplus")) as CodeContainerBase; + cplusplusopen.AddElement(new Code("extern "C" {")); + e.AddElement(EmptyLine.SingleLine); + + if (this.includes.Count > 0) + { + e.AddElements(this.includes); + e.AddElement(EmptyLine.SingleLine); + } + + if (this.defines.Count > 0) + { + e.AddElements(this.defines); + e.AddElement(EmptyLine.SingleLine); + } + + e.AddElements(this.functionDeclarations, EmptyLine.SingleLine); + e.AddElements(this.variableDeclarations, EmptyLine.SingleLine); + + e.AddElement(EmptyLine.SingleLine); + CodeContainerBase cplusplusclose = e.AddElement(new PP_Ifdef("__cplusplus")) as CodeContainerBase; + cplusplusclose.AddElement(new Code("}")); + + e.AddElement(EmptyLine.SingleLine); + cFile.Save(cGenerator); + } + + #endregion + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/Properties/AssemblyInfo.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/Properties/AssemblyInfo.cs new file mode 100644 index 00000000000..e68b43d5e5e --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/Properties/AssemblyInfo.cs @@ -0,0 +1,36 @@ +using System.Reflection; +using System.Runtime.CompilerServices; +using System.Runtime.InteropServices; + +// Allgemeine Informationen über eine Assembly werden über die folgenden +// Attribute gesteuert. Ändern Sie diese Attributwerte, um die Informationen zu ändern, +// die mit einer Assembly verknüpft sind. +[assembly: AssemblyTitle("LwipSnmpCodeGeneration")] +[assembly: AssemblyDescription("")] +[assembly: AssemblyConfiguration("")] +[assembly: AssemblyCompany("")] +[assembly: AssemblyProduct("LwipSnmpCodeGeneration")] +[assembly: AssemblyCopyright("Copyright © 2015")] +[assembly: AssemblyTrademark("")] +[assembly: AssemblyCulture("")] + +// Durch Festlegen von ComVisible auf "false" werden die Typen in dieser Assembly unsichtbar +// für COM-Komponenten. Wenn Sie auf einen Typ in dieser Assembly von +// COM zugreifen müssen, legen Sie das ComVisible-Attribut für diesen Typ auf "true" fest. +[assembly: ComVisible(false)] + +// Die folgende GUID bestimmt die ID der Typbibliothek, wenn dieses Projekt für COM verfügbar gemacht wird +[assembly: Guid("8cfbbb8b-dfbb-4dd5-80c9-e07845dd58c9")] + +// Versionsinformationen für eine Assembly bestehen aus den folgenden vier Werten: +// +// Hauptversion +// Nebenversion +// Buildnummer +// Revision +// +// Sie können alle Werte angeben oder die standardmäßigen Build- und Revisionsnummern +// übernehmen, indem Sie "*" eingeben: +// [assembly: AssemblyVersion("1.0.*")] +[assembly: AssemblyVersion("1.0.0.0")] +[assembly: AssemblyFileVersion("1.0.0.0")] diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpMib.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpMib.cs new file mode 100644 index 00000000000..477a18b62af --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpMib.cs @@ -0,0 +1,97 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Text; +using CCodeGeneration; + +namespace LwipSnmpCodeGeneration +{ + public class SnmpMib : SnmpTreeNode + { + public uint[] BaseOid { get; set; } + + public SnmpMib() + : base(null) + { + } + + public SnmpMib(uint[] baseOid) + : base(null) + { + this.BaseOid = baseOid; + } + + public override string FullNodeName + { + get { return this.Name.ToLowerInvariant() + "_root"; } + } + + public override void GenerateCode(MibCFile mibFile) + { + base.GenerateCode(mibFile); + + System.Diagnostics.Debug.Assert((this.BaseOid != null) && (this.BaseOid.Length > 0)); + + // create and add BaseOID declarations + StringBuilder boidInitialization = new StringBuilder("{"); + foreach (uint t in this.BaseOid) + { + boidInitialization.Append(t); + boidInitialization.Append(","); + } + boidInitialization.Length -= 1; + boidInitialization.Append("}"); + + VariableDeclaration boidDecl = new VariableDeclaration( + new VariableType(this.Name.ToLowerInvariant() + "_base_oid", LwipDefs.Vt_U32, null, ConstType.Value, String.Empty), + boidInitialization.ToString(), true); + + mibFile.Declarations.Add(boidDecl); + mibFile.Declarations.Add(GetExportDeclaration()); + } + + public override void GenerateHeaderCode(MibHeaderFile mibHeaderFile) + { + mibHeaderFile.Includes.Add(new PP_Include("lwip/apps/snmp_core.h")); + + mibHeaderFile.VariableDeclarations.Add(VariablePrototype.FromVariableDeclaration(GetExportDeclaration())); + } + + VariableDeclaration GetExportDeclaration() + { + return new VariableDeclaration( + new VariableType(this.Name.ToLowerInvariant(), LwipDefs.Vt_StMib, null, ConstType.Value), + String.Format("{{{0}_base_oid, LWIP_ARRAYSIZE({0}_base_oid), &{1}.node}}", this.Name.ToLowerInvariant(), this.FullNodeName)); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpNode.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpNode.cs new file mode 100644 index 00000000000..fceb4d5215b --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpNode.cs @@ -0,0 +1,119 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Text.RegularExpressions; +using CCodeGeneration; + +namespace LwipSnmpCodeGeneration +{ + public abstract class SnmpNode + { + public static readonly Regex NameValidationRegex = new Regex(@"^\w+$"); + + private string name; + private readonly SnmpTreeNode parentNode; + + protected SnmpNode(SnmpTreeNode parentNode) + { + this.parentNode = parentNode; + } + + public SnmpTreeNode ParentNode + { + get { return this.parentNode; } + } + + public virtual uint Oid { get; set; } + + public abstract string FullNodeName + { + get; + } + + public virtual string Name + { + get { return this.name; } + set + { + if (value != this.name) + { + // check for valid name + if (!NameValidationRegex.IsMatch(value)) + { + throw new ArgumentOutOfRangeException("Name"); + } + + this.name = value; + } + } + } + + public virtual void Generate(MibCFile generatedFile, MibHeaderFile generatedHeaderFile) + { + int declCount = generatedFile.Declarations.Count; + int implCount = generatedFile.Implementation.Count; + + this.GenerateHeaderCode(generatedHeaderFile); + this.GenerateCode(generatedFile); + + if (generatedFile.Declarations.Count != declCount) + { + generatedFile.Declarations.Add(EmptyLine.SingleLine); + } + if (generatedFile.Implementation.Count != implCount) + { + generatedFile.Implementation.Add(EmptyLine.SingleLine); + } + } + + public abstract void GenerateCode(MibCFile mibFile); + + public virtual void GenerateHeaderCode(MibHeaderFile mibHeaderFile) + { + } + + /// <summary> + /// Called after node structure creation is completed and before code is created. + /// Offers the possibility to perform operations depending on properties/subnodes. + /// If the node shall be transformed to another node(-type) than the own instance + /// may be replaced on parent node by the transformed instance. + /// Calling sequence is always from leafs up to root. So a tree node can assume + /// that the analyze method was already called on all child nodes. + /// E.g. a tree node only has scalar sub nodes -> it transforms itself to a scalar array node + /// </summary> + /// <returns>The transformed node or null if nothing shall be changed in parent structure.</returns> + public virtual void Analyze() + { + } + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarAggregationNode.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarAggregationNode.cs new file mode 100644 index 00000000000..f5c558c56a9 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarAggregationNode.cs @@ -0,0 +1,293 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System.Collections.Generic; +using System.Globalization; +using CCodeGeneration; + +namespace LwipSnmpCodeGeneration +{ + public abstract class SnmpScalarAggregationNode: SnmpNode + { + private bool getMethodRequired = false; + private bool testMethodRequired = false; + private bool setMethodRequired = false; + + protected SnmpScalarAggregationNode(SnmpTreeNode parentNode) + : base(parentNode) + { + } + + protected virtual string GetMethodName + { + get { return this.FullNodeName + LwipDefs.FnctSuffix_GetValue; } + } + + protected bool GetMethodRequired + { + get { return this.getMethodRequired; } + } + + protected virtual string TestMethodName + { + get { return this.FullNodeName + LwipDefs.FnctSuffix_SetTest; } + } + + protected bool TestMethodRequired + { + get { return this.testMethodRequired; } + } + + protected virtual string SetMethodName + { + get { return this.FullNodeName + LwipDefs.FnctSuffix_SetValue; } + } + + protected bool SetMethodRequired + { + get { return this.setMethodRequired; } + } + + protected abstract IEnumerable<SnmpScalarNode> AggregatedScalarNodes + { + get; + } + + public override void Analyze() + { + base.Analyze(); + + this.getMethodRequired = false; + this.testMethodRequired = false; + this.setMethodRequired = false; + + foreach (SnmpScalarNode scalarNode in this.AggregatedScalarNodes) + { + if ((scalarNode.AccessMode == SnmpAccessMode.ReadOnly) || (scalarNode.AccessMode == SnmpAccessMode.ReadWrite)) + { + this.getMethodRequired = true; + } + if ((scalarNode.AccessMode == SnmpAccessMode.WriteOnly) || (scalarNode.AccessMode == SnmpAccessMode.ReadWrite)) + { + this.testMethodRequired = true; + this.setMethodRequired = true; + } + + if (this.getMethodRequired && this.setMethodRequired) + { + break; + } + } + } + + protected void GenerateAggregatedCode(MibCFile mibFile, VariableType instanceType, string switchSelector, bool generateDeclarations = true, bool generateImplementations = true) + { + if (this.getMethodRequired) + { + FunctionDeclaration getMethodDecl = new FunctionDeclaration(this.GetMethodName, isStatic: true); + getMethodDecl.Parameter.Add(instanceType); + getMethodDecl.Parameter.Add(new VariableType("value", VariableType.VoidString, "*")); + getMethodDecl.ReturnType = new VariableType(null, LwipDefs.Vt_S16); + + if (generateDeclarations) + { + mibFile.Declarations.Add(getMethodDecl); + } + if (generateImplementations) + { + Function getMethod = Function.FromDeclaration(getMethodDecl); + GenerateGetMethodCode(getMethod, switchSelector); + mibFile.Implementation.Add(getMethod); + } + } + + if (this.testMethodRequired) + { + FunctionDeclaration testMethodDecl = new FunctionDeclaration(this.TestMethodName, isStatic: true); + testMethodDecl.Parameter.Add(instanceType); + testMethodDecl.Parameter.Add(new VariableType("len", LwipDefs.Vt_U16)); + testMethodDecl.Parameter.Add(new VariableType("value", VariableType.VoidString, "*")); + testMethodDecl.ReturnType = new VariableType(null, LwipDefs.Vt_Snmp_err); + + if (generateDeclarations) + { + mibFile.Declarations.Add(testMethodDecl); + } + if (generateImplementations) + { + Function testMethod = Function.FromDeclaration(testMethodDecl); + GenerateTestMethodCode(testMethod, switchSelector); + mibFile.Implementation.Add(testMethod); + } + } + + if (this.setMethodRequired) + { + FunctionDeclaration setMethodDecl = new FunctionDeclaration(this.SetMethodName, isStatic: true); + setMethodDecl.Parameter.Add(instanceType); + setMethodDecl.Parameter.Add(new VariableType("len", LwipDefs.Vt_U16)); + setMethodDecl.Parameter.Add(new VariableType("value", VariableType.VoidString, "*")); + setMethodDecl.ReturnType = new VariableType(null, LwipDefs.Vt_Snmp_err); + + if (generateDeclarations) + { + mibFile.Declarations.Add(setMethodDecl); + } + if (generateImplementations) + { + Function setMethod = Function.FromDeclaration(setMethodDecl); + GenerateSetMethodCode(setMethod, switchSelector); + mibFile.Implementation.Add(setMethod); + } + } + } + + protected virtual void GenerateGetMethodCode(Function getMethod, string switchSelector) + { + VariableDeclaration returnValue = new VariableDeclaration((VariableType)getMethod.ReturnType.Clone()); + returnValue.Type.Name = "value_len"; + getMethod.Declarations.Add(returnValue); + Switch sw = new Switch(switchSelector); + + bool valueVarUsed = false; + + foreach (SnmpScalarNode scalarNode in this.AggregatedScalarNodes) + { + if ((scalarNode.AccessMode == SnmpAccessMode.ReadOnly) || (scalarNode.AccessMode == SnmpAccessMode.ReadWrite)) + { + SwitchCase sc = new SwitchCase(scalarNode.Oid.ToString(CultureInfo.InvariantCulture)); + sc.Declarations.Add(new Comment(scalarNode.Name, singleLine: true)); + + scalarNode.GenerateGetMethodCode(sc, getMethod.Parameter[1].Name, ref valueVarUsed, returnValue.Type.Name); + + sw.Switches.Add(sc); + } + } + + SwitchCase scd = SwitchCase.GenerateDefault(); + scd.AddCodeFormat("LWIP_DEBUGF(SNMP_MIB_DEBUG,("{0}(): unknown id: %"S32_F"\n", {1}));", getMethod.Name, switchSelector); + scd.AddCodeFormat("{0} = 0;", returnValue.Type.Name); + sw.Switches.Add(scd); + + if (!valueVarUsed) + { + getMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", getMethod.Parameter[1].Name); + } + + getMethod.AddElement(sw); + + getMethod.AddCodeFormat("return {0};", returnValue.Type.Name); + } + + protected virtual void GenerateTestMethodCode(Function testMethod, string switchSelector) + { + VariableDeclaration returnValue = new VariableDeclaration((VariableType)testMethod.ReturnType.Clone(), LwipDefs.Def_ErrorCode_WrongValue); + returnValue.Type.Name = "err"; + testMethod.Declarations.Add(returnValue); + Switch sw = new Switch(switchSelector); + + bool valueVarUsed = false; + bool lenVarUsed = false; + + foreach (SnmpScalarNode scalarNode in this.AggregatedScalarNodes) + { + if ((scalarNode.AccessMode == SnmpAccessMode.WriteOnly) || (scalarNode.AccessMode == SnmpAccessMode.ReadWrite)) + { + SwitchCase sc = new SwitchCase(scalarNode.Oid.ToString(CultureInfo.InvariantCulture)); + sc.Declarations.Add(new Comment(scalarNode.Name, singleLine: true)); + + scalarNode.GenerateTestMethodCode(sc, testMethod.Parameter[2].Name, ref valueVarUsed, testMethod.Parameter[1].Name, ref lenVarUsed, returnValue.Type.Name); + + sw.Switches.Add(sc); + } + } + + SwitchCase scd = SwitchCase.GenerateDefault(); + scd.AddCodeFormat("LWIP_DEBUGF(SNMP_MIB_DEBUG,("{0}(): unknown id: %"S32_F"\n", {1}));", testMethod.Name, switchSelector); + sw.Switches.Add(scd); + + if (!valueVarUsed) + { + testMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", testMethod.Parameter[2].Name); + } + if (!lenVarUsed) + { + testMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", testMethod.Parameter[1].Name); + } + + testMethod.AddElement(sw); + + testMethod.AddCodeFormat("return {0};", returnValue.Type.Name); + } + + protected virtual void GenerateSetMethodCode(Function setMethod, string switchSelector) + { + VariableDeclaration returnValue = new VariableDeclaration((VariableType)setMethod.ReturnType.Clone(), LwipDefs.Def_ErrorCode_Ok); + returnValue.Type.Name = "err"; + setMethod.Declarations.Add(returnValue); + Switch sw = new Switch(switchSelector); + + bool valueVarUsed = false; + bool lenVarUsed = false; + + foreach (SnmpScalarNode scalarNode in this.AggregatedScalarNodes) + { + if ((scalarNode.AccessMode == SnmpAccessMode.WriteOnly) || (scalarNode.AccessMode == SnmpAccessMode.ReadWrite)) + { + SwitchCase sc = new SwitchCase(scalarNode.Oid.ToString(CultureInfo.InvariantCulture)); + sc.Declarations.Add(new Comment(scalarNode.Name, singleLine: true)); + + scalarNode.GenerateSetMethodCode(sc, setMethod.Parameter[2].Name, ref valueVarUsed, setMethod.Parameter[1].Name, ref lenVarUsed, returnValue.Type.Name); + + sw.Switches.Add(sc); + } + } + + SwitchCase scd = SwitchCase.GenerateDefault(); + scd.AddCodeFormat("LWIP_DEBUGF(SNMP_MIB_DEBUG,("{0}(): unknown id: %"S32_F"\n", {1}));", setMethod.Name, switchSelector); + sw.Switches.Add(scd); + + if (!valueVarUsed) + { + setMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", setMethod.Parameter[2].Name); + } + if (!lenVarUsed) + { + setMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", setMethod.Parameter[1].Name); + } + + setMethod.AddElement(sw); + + setMethod.AddCodeFormat("return {0};", returnValue.Type.Name); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarArrayNode.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarArrayNode.cs new file mode 100644 index 00000000000..086fbb9f6aa --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarArrayNode.cs @@ -0,0 +1,105 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Collections.Generic; +using System.Text; +using CCodeGeneration; + +namespace LwipSnmpCodeGeneration +{ + public class SnmpScalarArrayNode : SnmpScalarAggregationNode + { + private readonly List<SnmpScalarNode> scalarNodes; + + public SnmpScalarArrayNode(List<SnmpScalarNode> scalarNodes, SnmpTreeNode parentNode) + : base(parentNode) + { + this.scalarNodes = scalarNodes; + } + + public override string FullNodeName + { + get { return this.Name.ToLowerInvariant() + "_scalars"; } + } + + protected override IEnumerable<SnmpScalarNode> AggregatedScalarNodes + { + get { return this.scalarNodes; } + } + + public override void GenerateCode(MibCFile mibFile) + { + VariableType instanceType = new VariableType("node", LwipDefs.Vt_StScalarArrayNodeDef, "*", ConstType.Value); + GenerateAggregatedCode( + mibFile, + instanceType, + instanceType.Name + "->oid"); + + + // create and add node definitions + StringBuilder nodeDefs = new StringBuilder(); + foreach (SnmpScalarNode scalarNode in this.scalarNodes) + { + nodeDefs.AppendFormat(" {{{0}, {1}, {2}}}, /* {3} */ \n", + scalarNode.Oid, + LwipDefs.GetAsn1DefForSnmpDataType(scalarNode.DataType), + LwipDefs.GetLwipDefForSnmpAccessMode(scalarNode.AccessMode), + scalarNode.Name); + } + if (nodeDefs.Length > 0) + nodeDefs.Length--; + + VariableDeclaration nodeDefsDecl = new VariableDeclaration( + new VariableType(this.FullNodeName + "_nodes", LwipDefs.Vt_StScalarArrayNodeDef, null, ConstType.Value, String.Empty), + "{\n" + nodeDefs + "\n}" , + isStatic: true); + + mibFile.Declarations.Add(nodeDefsDecl); + + + // create and add node declaration + string nodeInitialization = String.Format("SNMP_SCALAR_CREATE_ARRAY_NODE({0}, {1}, {2}, {3}, {4})", + this.Oid, + nodeDefsDecl.Type.Name, + (this.GetMethodRequired) ? this.GetMethodName : LwipDefs.Null, + (this.TestMethodRequired) ? this.TestMethodName : LwipDefs.Null, + (this.SetMethodRequired) ? this.SetMethodName : LwipDefs.Null + ); + + mibFile.Declarations.Add(new VariableDeclaration( + new VariableType(this.FullNodeName, LwipDefs.Vt_StScalarArrayNode, null, ConstType.Value), + nodeInitialization, + isStatic: true)); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNode.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNode.cs new file mode 100644 index 00000000000..6be54c49f89 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNode.cs @@ -0,0 +1,395 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Collections.Generic; +using CCodeGeneration; + +namespace LwipSnmpCodeGeneration +{ + public class SnmpScalarNode: SnmpNode + { + protected const string LocalValueName = "v"; // name of (casted) local value variable + + private SnmpDataType dataType; + private SnmpAccessMode accessMode; + private readonly List<IRestriction> restrictions = new List<IRestriction>(); + + private bool useExternalMethods = false; + private string externalGetMethod; + private string externalTestMethod; + private string externalSetMethod; + + + public SnmpScalarNode(SnmpTreeNode parentNode) + : base(parentNode) + { + } + + public override string FullNodeName + { + get { return this.Name.ToLowerInvariant() + "_scalar"; } + } + + public SnmpDataType DataType + { + get { return this.dataType; } + set { this.dataType = value; } + } + + public List<IRestriction> Restrictions + { + get { return this.restrictions; } + } + + public SnmpAccessMode AccessMode + { + get { return this.accessMode; } + set { this.accessMode = value; } + } + + public virtual string FixedValueLength + { + get { return null; } + } + + /// <summary> + /// If scalar is used as a table index its value becomes part of the OID. This value returns how many OID parts are required to represent this value. + /// </summary> + public virtual int OidRepresentationLen + { + get { return -1; } + } + + public bool UseExternalMethods + { + get { return this.useExternalMethods; } + set { this.useExternalMethods = value; } + } + + public string ExternalGetMethod + { + get { return this.externalGetMethod; } + set { this.externalGetMethod = value; } + } + public string ExternalTestMethod + { + get { return this.externalTestMethod; } + set { this.externalTestMethod = value; } + } + public string ExternalSetMethod + { + get { return this.externalSetMethod; } + set { this.externalSetMethod = value; } + } + + public override void GenerateCode(MibCFile mibFile) + { + string getMethodName; + string testMethodName; + string setMethodName; + + if (this.useExternalMethods) + { + getMethodName = this.externalGetMethod; + testMethodName = this.externalTestMethod; + setMethodName = this.externalSetMethod; + } + else + { + getMethodName = LwipDefs.Null; + testMethodName = LwipDefs.Null; + setMethodName = LwipDefs.Null; + + if ((this.accessMode == SnmpAccessMode.ReadWrite) || (this.accessMode == SnmpAccessMode.ReadOnly)) + { + FunctionDeclaration getMethodDecl = new FunctionDeclaration(this.Name + LwipDefs.FnctSuffix_GetValue, isStatic: true); + getMethodDecl.Parameter.Add(new VariableType("instance", LwipDefs.Vt_StNodeInstance, "*")); + getMethodDecl.Parameter.Add(new VariableType("value", VariableType.VoidString, "*")); + getMethodDecl.ReturnType = new VariableType(null, LwipDefs.Vt_S16); + mibFile.Declarations.Add(getMethodDecl); + + Function getMethod = Function.FromDeclaration(getMethodDecl); + getMethodName = getMethod.Name; + + VariableDeclaration returnValue = new VariableDeclaration((VariableType)getMethod.ReturnType.Clone()); + returnValue.Type.Name = "value_len"; + getMethod.Declarations.Add(returnValue); + getMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", getMethod.Parameter[0].Name); + + bool valueVarUsed = false; + GenerateGetMethodCode(getMethod, getMethod.Parameter[1].Name, ref valueVarUsed, returnValue.Type.Name); + if (!valueVarUsed) + { + getMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", getMethod.Parameter[1].Name); + } + + getMethod.AddCodeFormat("return {0};", returnValue.Type.Name); + + mibFile.Implementation.Add(getMethod); + } + + if ((this.accessMode == SnmpAccessMode.ReadWrite) || (this.accessMode == SnmpAccessMode.WriteOnly)) + { + bool valueVarUsed; + bool lenVarUsed; + VariableDeclaration returnValue; + + if (this.restrictions.Count > 0) + { + FunctionDeclaration testMethodDecl = new FunctionDeclaration(this.Name + LwipDefs.FnctSuffix_SetTest, isStatic: true); + testMethodDecl.Parameter.Add(new VariableType("instance", LwipDefs.Vt_StNodeInstance, "*")); + testMethodDecl.Parameter.Add(new VariableType("len", LwipDefs.Vt_U16)); + testMethodDecl.Parameter.Add(new VariableType("value", VariableType.VoidString, "*")); + testMethodDecl.ReturnType = new VariableType(null, LwipDefs.Vt_Snmp_err); + mibFile.Declarations.Add(testMethodDecl); + + Function testMethod = Function.FromDeclaration(testMethodDecl); + testMethodName = testMethod.Name; + + returnValue = new VariableDeclaration((VariableType)testMethod.ReturnType.Clone(), LwipDefs.Def_ErrorCode_WrongValue); + returnValue.Type.Name = "err"; + testMethod.Declarations.Add(returnValue); + testMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", testMethod.Parameter[0].Name); + + valueVarUsed = false; + lenVarUsed = false; + + GenerateTestMethodCode(testMethod, testMethod.Parameter[2].Name, ref valueVarUsed, testMethod.Parameter[1].Name, ref lenVarUsed, returnValue.Type.Name); + + if (!valueVarUsed) + { + testMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", testMethod.Parameter[2].Name); + } + if (!lenVarUsed) + { + testMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", testMethod.Parameter[1].Name); + } + + testMethod.AddCodeFormat("return {0};", returnValue.Type.Name); + + mibFile.Implementation.Add(testMethod); + + } + else + { + testMethodName = LwipDefs.FnctName_SetTest_Ok; + } + + FunctionDeclaration setMethodDecl = null; + setMethodDecl = new FunctionDeclaration(this.Name + LwipDefs.FnctSuffix_SetValue, isStatic: true); + setMethodDecl.Parameter.Add(new VariableType("instance", LwipDefs.Vt_StNodeInstance, "*")); + setMethodDecl.Parameter.Add(new VariableType("len", LwipDefs.Vt_U16)); + setMethodDecl.Parameter.Add(new VariableType("value", VariableType.VoidString, "*")); + setMethodDecl.ReturnType = new VariableType(null, LwipDefs.Vt_Snmp_err); + mibFile.Declarations.Add(setMethodDecl); + + Function setMethod = Function.FromDeclaration(setMethodDecl); + setMethodName = setMethod.Name; + + returnValue = new VariableDeclaration((VariableType)setMethod.ReturnType.Clone(), LwipDefs.Def_ErrorCode_Ok); + returnValue.Type.Name = "err"; + setMethod.Declarations.Add(returnValue); + setMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", setMethod.Parameter[0].Name); + + valueVarUsed = false; + lenVarUsed = false; + + GenerateSetMethodCode(setMethod, setMethod.Parameter[2].Name, ref valueVarUsed, setMethod.Parameter[1].Name, ref lenVarUsed, returnValue.Type.Name); + + if (!valueVarUsed) + { + setMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", setMethod.Parameter[2].Name); + } + if (!lenVarUsed) + { + setMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", setMethod.Parameter[1].Name); + } + + setMethod.AddCodeFormat("return {0};", returnValue.Type.Name); + + mibFile.Implementation.Add(setMethod); + } + } + + // create and add node declaration + string nodeInitialization; + if (this.accessMode == SnmpAccessMode.ReadOnly) + { + nodeInitialization = String.Format("SNMP_SCALAR_CREATE_NODE_READONLY({0}, {1}, {2})", + this.Oid, + LwipDefs.GetAsn1DefForSnmpDataType(this.dataType), + getMethodName); + } + else + { + nodeInitialization = String.Format("SNMP_SCALAR_CREATE_NODE({0}, {1}, {2}, {3}, {4}, {5})", + this.Oid, + LwipDefs.GetLwipDefForSnmpAccessMode(this.accessMode), + LwipDefs.GetAsn1DefForSnmpDataType(this.dataType), + getMethodName, + testMethodName, + setMethodName); + } + + mibFile.Declarations.Add(new VariableDeclaration( + new VariableType(this.FullNodeName, LwipDefs.Vt_StScalarNode, null, ConstType.Value), + nodeInitialization, isStatic: true)); + } + + public virtual void GenerateGetMethodCode(CodeContainerBase container, string valueVarName, ref bool valueVarUsed, string retLenVarName) + { + bool localValueVarUsed; + if (GenerateValueDeclaration(container, LocalValueName, valueVarName)) + { + valueVarUsed = true; + localValueVarUsed = false; + } + else + { + localValueVarUsed = true; // do not generate UNUSED_ARG code + } + + if (this.FixedValueLength == null) + { + // check that value with variable length fits into buffer + container.AddElement(new Comment(String.Format("TODO: take care that value with variable length fits into buffer: ({0} <= SNMP_MAX_VALUE_SIZE)", retLenVarName), singleLine: true)); + } + + GenerateGetMethodCodeCore(container, LocalValueName, ref localValueVarUsed, retLenVarName); + if (!localValueVarUsed) + { + container.AddCode(String.Format("LWIP_UNUSED_ARG({0});", LocalValueName)); + } + } + + protected virtual void GenerateGetMethodCodeCore(CodeContainerBase container, string localValueVarName, ref bool localValueVarUsed, string retLenVarName) + { + container.AddElement(new Comment(String.Format("TODO: put requested value to '*{0}' here", localValueVarName), singleLine: true)); + container.AddCodeFormat("{0} = {1};", + retLenVarName, + (!String.IsNullOrWhiteSpace(this.FixedValueLength)) ? this.FixedValueLength : "0"); + } + + public virtual void GenerateTestMethodCode(CodeContainerBase container, string valueVarName, ref bool valueVarUsed, string lenVarName, ref bool lenVarUsed, string retErrVarName) + { + if (this.Restrictions.Count > 0) + { + bool localVarUsed; + if (GenerateValueDeclaration(container, LocalValueName, valueVarName)) + { + valueVarUsed = true; + localVarUsed = false; + } + else + { + localVarUsed = true; // do not generate UNUSED_ARG code + } + + if (!String.IsNullOrWhiteSpace(this.FixedValueLength)) + { + // check for fixed value + container.AddCodeFormat("LWIP_ASSERT("Invalid length for datatype", ({0} == {1}));", lenVarName, this.FixedValueLength); + lenVarUsed = true; + } + + GenerateTestMethodCodeCore(container, LocalValueName, ref localVarUsed, lenVarName, ref lenVarUsed, retErrVarName); + + if (!localVarUsed) + { + container.AddCode(String.Format("LWIP_UNUSED_ARG({0});", LocalValueName)); + } + } + else + { + container.AddCodeFormat("{0} = {1};", retErrVarName, LwipDefs.Def_ErrorCode_Ok); + } + } + + protected virtual void GenerateTestMethodCodeCore(CodeContainerBase container, string localValueVarName, ref bool localValueVarUsed, string lenVarName, ref bool lenVarUsed, string retErrVarName) + { + container.AddElement(new Comment(String.Format("TODO: test new value here:\nif (*{0} == ) {1} = {2};", localValueVarName, retErrVarName, LwipDefs.Def_ErrorCode_Ok))); + } + + public virtual void GenerateSetMethodCode(CodeContainerBase container, string valueVarName, ref bool valueVarUsed, string lenVarName, ref bool lenVarUsed, string retErrVarName) + { + bool localVarUsed; + if (GenerateValueDeclaration(container, LocalValueName, valueVarName)) + { + valueVarUsed = true; + localVarUsed = false; + } + else + { + localVarUsed = true; // do not generate UNUSED_ARG code + } + + GenerateSetMethodCodeCore(container, LocalValueName, ref localVarUsed, lenVarName, ref lenVarUsed, retErrVarName); + + if (!localVarUsed) + { + container.AddCode(String.Format("LWIP_UNUSED_ARG({0});", LocalValueName)); + } + } + + protected virtual void GenerateSetMethodCodeCore(CodeContainerBase container, string localValueVarName, ref bool localValueVarUsed, string lenVarName, ref bool lenVarUsed, string retErrVarName) + { + container.AddElement(new Comment(String.Format("TODO: store new value contained in '*{0}' here", localValueVarName), singleLine: true)); + } + + + protected virtual bool GenerateValueDeclaration(CodeContainerBase container, string variableName, string sourceName) + { + container.AddDeclaration(new VariableDeclaration( + new VariableType(variableName, LwipDefs.Vt_U8, "*"), + "(" + new VariableType(null, LwipDefs.Vt_U8, "*") + ")" + sourceName)); + + return true; + } + + public static SnmpScalarNode CreateFromDatatype(SnmpDataType dataType, SnmpTreeNode parentNode) + { + switch (dataType) + { + case SnmpDataType.Integer: + return new SnmpScalarNodeInt(parentNode); + + case SnmpDataType.Gauge: + case SnmpDataType.Counter: + case SnmpDataType.TimeTicks: + return new SnmpScalarNodeUint(dataType, parentNode); + } + + return new SnmpScalarNode(parentNode); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeBits.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeBits.cs new file mode 100644 index 00000000000..906a5a6cf12 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeBits.cs @@ -0,0 +1,121 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Text; +using CCodeGeneration; + +namespace LwipSnmpCodeGeneration +{ + public class SnmpScalarNodeBits : SnmpScalarNode + { + private readonly uint bitCount; + + public SnmpScalarNodeBits(SnmpTreeNode parentNode, uint bitCount) + : base(parentNode) + { + this.DataType = SnmpDataType.Bits; + this.bitCount = bitCount; + } + + public override void GenerateGetMethodCode(CodeContainerBase container, string valueVarName, ref bool valueVarUsed, string retLenVarName) + { + container.AddCode(String.Format( + "{0} = snmp_encode_bits(({1} *){2}, SNMP_MAX_VALUE_SIZE, 0 /* TODO: pass real value here */, {3});", + retLenVarName, + LwipDefs.Vt_U8, + valueVarName, + this.bitCount)); + + valueVarUsed = true; + } + + public override void GenerateTestMethodCode(CodeContainerBase container, string valueVarName, ref bool valueVarUsed, string lenVarName, ref bool lenVarUsed, string retErrVarName) + { + if (this.Restrictions.Count > 0) + { + const string bitVarName = "bits"; + + container.Declarations.Add(new VariableDeclaration(new VariableType(bitVarName, LwipDefs.Vt_U32))); + + IfThenElse ite = new IfThenElse(String.Format( + "snmp_decode_bits(({0} *){1}, {2}, &{3}) == ERR_OK", + LwipDefs.Vt_U8, + valueVarName, + lenVarName, + bitVarName)); + + valueVarUsed = true; + lenVarUsed = true; + + StringBuilder innerIfCond = new StringBuilder(); + foreach (IRestriction restriction in this.Restrictions) + { + innerIfCond.Append(restriction.GetCheckCodeValid(bitVarName)); + innerIfCond.Append(" || "); + } + + innerIfCond.Length -= 4; + + IfThenElse innerIte = new IfThenElse(innerIfCond.ToString()); + innerIte.AddCode(String.Format("{0} = {1};", retErrVarName, LwipDefs.Def_ErrorCode_Ok)); + ite.AddElement(innerIte); + container.AddElement(ite); + } + else + { + base.GenerateTestMethodCode(container, valueVarName, ref valueVarUsed, lenVarName, ref lenVarUsed, retErrVarName); + } + } + + public override void GenerateSetMethodCode(CodeContainerBase container, string valueVarName, ref bool valueVarUsed, string lenVarName, ref bool lenVarUsed, string retErrVarName) + { + const string bitVarName = "bits"; + + container.Declarations.Add(new VariableDeclaration(new VariableType(bitVarName, LwipDefs.Vt_U32))); + + IfThenElse ite = new IfThenElse(String.Format( + "snmp_decode_bits(({0} *){1}, {2}, &{3}) == ERR_OK", + LwipDefs.Vt_U8, + valueVarName, + lenVarName, + bitVarName)); + + valueVarUsed = true; + lenVarUsed = true; + + ite.AddElement(new Comment(String.Format("TODO: store new value contained in '{0}' here", bitVarName), singleLine: true)); + + container.AddElement(ite); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeCounter64.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeCounter64.cs new file mode 100644 index 00000000000..8f450c8a510 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeCounter64.cs @@ -0,0 +1,72 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Text; +using CCodeGeneration; + +namespace LwipSnmpCodeGeneration +{ + public class SnmpScalarNodeCounter64 : SnmpScalarNode + { + public SnmpScalarNodeCounter64(SnmpTreeNode parentNode) + : base(parentNode) + { + this.DataType = SnmpDataType.Counter64; + } + + protected override bool GenerateValueDeclaration(CodeContainerBase container, string variableName, string sourceName) + { + container.AddDeclaration(new VariableDeclaration( + new VariableType(variableName + "_high", LwipDefs.Vt_U32, "*"), + "(" + new VariableType(null, LwipDefs.Vt_U32, "*").ToString() + ")" + sourceName)); + container.AddDeclaration(new VariableDeclaration( + new VariableType(variableName + "_low", LwipDefs.Vt_U32, "*"), + variableName + "_high + 1")); + + container.AddCode(String.Format("LWIP_UNUSED_ARG({0}_high);", variableName)); + container.AddCode(String.Format("LWIP_UNUSED_ARG({0}_low);", variableName)); + + return false; + } + + public override string FixedValueLength + { + get { return String.Format("(2 * sizeof({0}))", LwipDefs.Vt_U32); } + } + + public override int OidRepresentationLen + { + get { return 1; } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeInt.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeInt.cs new file mode 100644 index 00000000000..a381234cea4 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeInt.cs @@ -0,0 +1,86 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Text; +using CCodeGeneration; + +namespace LwipSnmpCodeGeneration +{ + public class SnmpScalarNodeInt : SnmpScalarNode + { + public SnmpScalarNodeInt(SnmpTreeNode parentNode) + : base(parentNode) + { + this.DataType = SnmpDataType.Integer; + } + + protected override void GenerateTestMethodCodeCore(CodeContainerBase container, string localValueVarName, ref bool localValueVarUsed, string lenVarName, ref bool lenVarUsed, string retErrVarName) + { + System.Diagnostics.Trace.Assert(this.Restrictions.Count > 0); + + StringBuilder ifCond = new StringBuilder(); + foreach (IRestriction restriction in this.Restrictions) + { + ifCond.Append(restriction.GetCheckCodeValid("*" + localValueVarName)); + ifCond.Append(" || "); + + localValueVarUsed = true; + } + + ifCond.Length -= 4; + + IfThenElse ite = new IfThenElse(ifCond.ToString()); + ite.AddCode(String.Format("{0} = {1};", retErrVarName, LwipDefs.Def_ErrorCode_Ok)); + container.AddElement(ite); + } + + protected override bool GenerateValueDeclaration(CodeContainerBase container, string variableName, string sourceName) + { + container.AddDeclaration(new VariableDeclaration( + new VariableType(variableName, LwipDefs.Vt_S32, "*"), + "(" + new VariableType(null, LwipDefs.Vt_S32, "*") + ")" + sourceName)); + + return true; + } + + public override string FixedValueLength + { + get { return String.Format("sizeof({0})", LwipDefs.Vt_S32); } + } + + public override int OidRepresentationLen + { + get { return 1; } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeObjectIdentifier.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeObjectIdentifier.cs new file mode 100644 index 00000000000..5ce8d146e04 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeObjectIdentifier.cs @@ -0,0 +1,90 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using CCodeGeneration; + +namespace LwipSnmpCodeGeneration +{ + public class SnmpScalarNodeObjectIdentifier: SnmpScalarNode + { + public SnmpScalarNodeObjectIdentifier(SnmpTreeNode parentNode) + : base(parentNode) + { + this.DataType = SnmpDataType.ObjectIdentifier; + } + + protected override bool GenerateValueDeclaration(CodeContainerBase container, string variableName, string sourceName) + { + container.AddDeclaration(new VariableDeclaration( + new VariableType(variableName, LwipDefs.Vt_U32, "*"), + "(" + new VariableType(null, LwipDefs.Vt_U32, "*") + ")" + sourceName)); + + return true; + } + + protected override void GenerateGetMethodCodeCore(CodeContainerBase container, string localValueVarName, ref bool localValueVarUsed, string retLenVarName) + { + container.AddElement(new Comment(String.Format("TODO: put requested value to '*{0}' here. '{0}' has to be interpreted as {1}[]", localValueVarName, LwipDefs.Vt_U32), singleLine: true)); + container.AddElement(EmptyLine.SingleLine); + container.AddCode(String.Format("{0} = 0; // TODO: return real value length here (should be 'numOfElements * sizeof({1})')", retLenVarName, LwipDefs.Vt_U32)); + } + + protected override void GenerateTestMethodCodeCore(CodeContainerBase container, string localValueVarName, ref bool localValueVarUsed, string lenVarName, ref bool lenVarUsed, string retErrVarName) + { + VariableDeclaration objIdLenVar = new VariableDeclaration( + new VariableType(localValueVarName + "_len", LwipDefs.Vt_U8), + String.Format("{0} / sizeof({1})", lenVarName, LwipDefs.Vt_U32)); + lenVarUsed = true; + + container.Declarations.Add(objIdLenVar); + + base.GenerateTestMethodCodeCore(container, localValueVarName, ref localValueVarUsed, lenVarName, ref lenVarUsed, retErrVarName); + + container.AddCode(String.Format("LWIP_UNUSED_ARG({0});", objIdLenVar.Type.Name)); + } + + protected override void GenerateSetMethodCodeCore(CodeContainerBase container, string localValueVarName, ref bool localValueVarUsed, string lenVarName, ref bool lenVarUsed, string retErrVarName) + { + VariableDeclaration objIdLenVar = new VariableDeclaration( + new VariableType(localValueVarName + "_len", LwipDefs.Vt_U8), + String.Format("{0} / sizeof({1})", lenVarName, LwipDefs.Vt_U32)); + lenVarUsed = true; + + container.Declarations.Add(objIdLenVar); + + base.GenerateSetMethodCodeCore(container, localValueVarName, ref localValueVarUsed, lenVarName, ref lenVarUsed, retErrVarName); + + container.AddCode(String.Format("LWIP_UNUSED_ARG({0});", objIdLenVar.Type.Name)); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeOctetString.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeOctetString.cs new file mode 100644 index 00000000000..bf10f9a8d95 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeOctetString.cs @@ -0,0 +1,118 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Text; +using CCodeGeneration; + +namespace LwipSnmpCodeGeneration +{ + public class SnmpScalarNodeOctetString : SnmpScalarNode + { + public SnmpScalarNodeOctetString(SnmpDataType dataType, SnmpTreeNode parentNode) + : base(parentNode) + { + System.Diagnostics.Debug.Assert( + (dataType == SnmpDataType.OctetString) || + (dataType == SnmpDataType.Opaque) || + (dataType == SnmpDataType.IpAddress)); + + this.DataType = dataType; + } + + protected override void GenerateGetMethodCodeCore(CodeContainerBase container, string localValueVarName, ref bool localValueVarUsed, string retLenVarName) + { + if (this.Restrictions.Count > 0) + { + StringBuilder ifCond = new StringBuilder(); + foreach (IRestriction restriction in this.Restrictions) + { + ifCond.Append(restriction.GetCheckCodeValid(retLenVarName)); + ifCond.Append(" || "); + } + + ifCond.Length -= 4; + container.AddElement(new Comment("TODO: take care of len restrictions defined in MIB: " + ifCond, singleLine: true)); + } + base.GenerateGetMethodCodeCore(container, localValueVarName, ref localValueVarUsed, retLenVarName); + } + + protected override void GenerateTestMethodCodeCore(CodeContainerBase container, string localValueVarName, ref bool localValueVarUsed, string lenVarName, ref bool lenVarUsed, string retErrVarName) + { + System.Diagnostics.Trace.Assert(this.Restrictions.Count > 0); + + // checks refer to length of octet string + StringBuilder ifCond = new StringBuilder(); + foreach (IRestriction restriction in this.Restrictions) + { + ifCond.Append(restriction.GetCheckCodeValid(lenVarName)); + ifCond.Append(" || "); + + lenVarUsed = true; + } + + ifCond.Length -= 4; + + IfThenElse ite = new IfThenElse(ifCond.ToString()); + ite.AddCode(String.Format("{0} = {1};", retErrVarName, LwipDefs.Def_ErrorCode_Ok)); + container.AddElement(ite); + } + + public override int OidRepresentationLen + { + get + { + // check restrictions if we are set to one fixed length + if ((this.Restrictions != null) && (this.Restrictions.Count > 0)) + { + foreach (IRestriction restriction in this.Restrictions) + { + if (restriction is IsInRangeRestriction) + { + if ((restriction as IsInRangeRestriction).RangeStart == (restriction as IsInRangeRestriction).RangeEnd) + { + return (int)(restriction as IsInRangeRestriction).RangeStart; + } + } + else if (restriction is IsEqualRestriction) + { + return (int)(restriction as IsEqualRestriction).Value; + } + } + } + + return -1; // variable length + } + } + + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeTruthValue.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeTruthValue.cs new file mode 100644 index 00000000000..0f557526903 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeTruthValue.cs @@ -0,0 +1,66 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using CCodeGeneration; + +namespace LwipSnmpCodeGeneration +{ + public class SnmpScalarNodeTruthValue : SnmpScalarNodeInt + { + public SnmpScalarNodeTruthValue(SnmpTreeNode parentNode) + : base(parentNode) + { + } + + protected override void GenerateGetMethodCodeCore(CodeContainerBase container, string localValueVarName, ref bool localValueVarUsed, string retLenVarName) + { + container.AddCodeFormat("snmp_encode_truthvalue({0}, /* TODO: put requested bool value here */ 0);", localValueVarName); + localValueVarUsed = true; + + container.AddCode(String.Format("{0} = {1};", + retLenVarName, + (!String.IsNullOrWhiteSpace(this.FixedValueLength)) ? this.FixedValueLength : "0")); + } + + protected override void GenerateSetMethodCodeCore(CodeContainerBase container, string localValueVarName, ref bool localValueVarUsed, string lenVarName, ref bool lenVarUsed, string retErrVarName) + { + VariableType truthVar = new VariableType("bool_value", LwipDefs.Vt_U8); + container.Declarations.Add(new VariableDeclaration(truthVar)); + + container.AddCodeFormat("snmp_decode_truthvalue({0}, &{1});", localValueVarName, truthVar.Name); + localValueVarUsed = true; + + container.AddElement(new Comment(String.Format("TODO: store new value contained in '{0}' here", truthVar.Name), singleLine: true)); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeUint.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeUint.cs new file mode 100644 index 00000000000..edc161ac459 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpScalarNodeUint.cs @@ -0,0 +1,91 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Text; +using CCodeGeneration; + +namespace LwipSnmpCodeGeneration +{ + public class SnmpScalarNodeUint : SnmpScalarNode + { + public SnmpScalarNodeUint(SnmpDataType dataType, SnmpTreeNode parentNode) + : base(parentNode) + { + System.Diagnostics.Debug.Assert( + (dataType == SnmpDataType.Counter) || + (dataType == SnmpDataType.Gauge) || + (dataType == SnmpDataType.TimeTicks)); + + this.DataType = dataType; + } + + protected override void GenerateTestMethodCodeCore(CodeContainerBase container, string localValueVarName, ref bool localValueVarUsed, string lenVarName, ref bool lenVarUsed, string retErrVarName) + { + System.Diagnostics.Trace.Assert(this.Restrictions.Count > 0); + + StringBuilder ifCond = new StringBuilder(); + foreach (IRestriction restriction in this.Restrictions) + { + ifCond.Append(restriction.GetCheckCodeValid("*" + localValueVarName)); + ifCond.Append(" || "); + + localValueVarUsed = true; + } + + ifCond.Length -= 4; + + IfThenElse ite = new IfThenElse(ifCond.ToString()); + ite.AddCode(String.Format("{0} = {1};", retErrVarName, LwipDefs.Def_ErrorCode_Ok)); + container.AddElement(ite); + } + + protected override bool GenerateValueDeclaration(CodeContainerBase container, string variableName, string sourceName) + { + container.AddDeclaration(new VariableDeclaration( + new VariableType(variableName, LwipDefs.Vt_U32, "*"), + "(" + new VariableType(null, LwipDefs.Vt_U32, "*") + ")" + sourceName)); + + return true; + } + + public override string FixedValueLength + { + get { return String.Format("sizeof({0})", LwipDefs.Vt_U32); } + } + + public override int OidRepresentationLen + { + get { return 1; } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpTableNode.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpTableNode.cs new file mode 100644 index 00000000000..13a3bf27518 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpTableNode.cs @@ -0,0 +1,332 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Collections.Generic; +using System.Text; +using CCodeGeneration; + +namespace LwipSnmpCodeGeneration +{ + public class SnmpTableNode: SnmpScalarAggregationNode + { + private readonly List<SnmpScalarNode> cellNodes = new List<SnmpScalarNode>(); + private readonly List<SnmpScalarNode> indexNodes = new List<SnmpScalarNode>(); + private string augmentedTableRow = null; + + + public SnmpTableNode(SnmpTreeNode parentNode) + : base(parentNode) + { + } + + public List<SnmpScalarNode> CellNodes + { + get { return cellNodes; } + } + + public List<SnmpScalarNode> IndexNodes + { + get { return indexNodes; } + } + + public string AugmentedTableRow + { + get { return this.augmentedTableRow; } + set { this.augmentedTableRow = value; } + } + + public override string FullNodeName + { + get + { + string result = this.Name.ToLowerInvariant(); + if (!result.Contains("table")) + { + result += "_table"; + } + + return result; + } + } + + protected override IEnumerable<SnmpScalarNode> AggregatedScalarNodes + { + get { return this.cellNodes; } + } + + public override void GenerateCode(MibCFile mibFile) + { + FunctionDeclaration getInstanceMethodDecl = new FunctionDeclaration(this.FullNodeName + LwipDefs.FnctSuffix_GetInstance, isStatic: true); + getInstanceMethodDecl.Parameter.Add(new VariableType("column", LwipDefs.Vt_U32, "*", ConstType.Value)); + getInstanceMethodDecl.Parameter.Add(new VariableType("row_oid", LwipDefs.Vt_U32, "*", ConstType.Value)); + getInstanceMethodDecl.Parameter.Add(new VariableType("row_oid_len", LwipDefs.Vt_U8, "")); + getInstanceMethodDecl.Parameter.Add(new VariableType("cell_instance", LwipDefs.Vt_StNodeInstance, "*")); + getInstanceMethodDecl.ReturnType = new VariableType(null, LwipDefs.Vt_Snmp_err); + mibFile.Declarations.Add(getInstanceMethodDecl); + + Function getInstanceMethod = Function.FromDeclaration(getInstanceMethodDecl); + GenerateGetInstanceMethodCode(getInstanceMethod); + mibFile.Implementation.Add(getInstanceMethod); + + + FunctionDeclaration getNextInstanceMethodDecl = new FunctionDeclaration(this.FullNodeName + LwipDefs.FnctSuffix_GetNextInstance, isStatic: true); + getNextInstanceMethodDecl.Parameter.Add(new VariableType("column", LwipDefs.Vt_U32, "*", ConstType.Value)); + getNextInstanceMethodDecl.Parameter.Add(new VariableType("row_oid", LwipDefs.Vt_StObjectId, "*")); + getNextInstanceMethodDecl.Parameter.Add(new VariableType("cell_instance", LwipDefs.Vt_StNodeInstance, "*")); + getNextInstanceMethodDecl.ReturnType = new VariableType(null, LwipDefs.Vt_Snmp_err); + mibFile.Declarations.Add(getNextInstanceMethodDecl); + + Function getNextInstanceMethod = Function.FromDeclaration(getNextInstanceMethodDecl); + GenerateGetNextInstanceMethodCode(getNextInstanceMethod); + mibFile.Implementation.Add(getNextInstanceMethod); + + + VariableType instanceType = new VariableType("cell_instance", LwipDefs.Vt_StNodeInstance, "*"); + GenerateAggregatedCode( + mibFile, + instanceType, + String.Format("SNMP_TABLE_GET_COLUMN_FROM_OID({0}->instance_oid.id)", instanceType.Name)); + + + #region create and add column/table definitions + + StringBuilder colDefs = new StringBuilder(); + foreach (SnmpScalarNode colNode in this.cellNodes) + { + colDefs.AppendFormat(" {{{0}, {1}, {2}}}, /* {3} */ \n", + colNode.Oid, + LwipDefs.GetAsn1DefForSnmpDataType(colNode.DataType), + LwipDefs.GetLwipDefForSnmpAccessMode(colNode.AccessMode), + colNode.Name); + } + if (colDefs.Length > 0) + { + colDefs.Length--; + } + + VariableDeclaration colDefsDecl = new VariableDeclaration( + new VariableType(this.FullNodeName + "_columns", LwipDefs.Vt_StTableColumnDef, null, ConstType.Value, String.Empty), + "{\n" + colDefs + "\n}", + isStatic: true); + + mibFile.Declarations.Add(colDefsDecl); + + string nodeInitialization = String.Format("SNMP_TABLE_CREATE({0}, {1}, {2}, {3}, {4}, {5}, {6})", + this.Oid, + colDefsDecl.Type.Name, + getInstanceMethodDecl.Name, getNextInstanceMethodDecl.Name, + (this.GetMethodRequired) ? this.GetMethodName : LwipDefs.Null, + (this.TestMethodRequired) ? this.TestMethodName : LwipDefs.Null, + (this.SetMethodRequired) ? this.SetMethodName : LwipDefs.Null + ); + + mibFile.Declarations.Add(new VariableDeclaration( + new VariableType(this.FullNodeName, LwipDefs.Vt_StTableNode, null, ConstType.Value), + nodeInitialization, + isStatic: true)); + + #endregion + } + + protected virtual void GenerateGetInstanceMethodCode(Function getInstanceMethod) + { + VariableDeclaration returnValue = new VariableDeclaration((VariableType)getInstanceMethod.ReturnType.Clone(), LwipDefs.Def_ErrorCode_NoSuchInstance); + returnValue.Type.Name = "err"; + getInstanceMethod.Declarations.Add(returnValue); + + int instanceOidLength = 0; + StringBuilder indexColumns = new StringBuilder(); + foreach (SnmpScalarNode indexNode in this.indexNodes) + { + if (instanceOidLength >= 0) + { + if (indexNode.OidRepresentationLen >= 0) + { + instanceOidLength += indexNode.OidRepresentationLen; + } + else + { + // at least one index column has a variable length -> we cannot perform a static check + instanceOidLength = -1; + } + } + + indexColumns.AppendFormat( + " {0} ({1}, OID length = {2})\n", + indexNode.Name, + indexNode.DataType, + (indexNode.OidRepresentationLen >= 0) ? indexNode.OidRepresentationLen.ToString() : "variable"); + } + if (indexColumns.Length > 0) + { + indexColumns.Length--; + + getInstanceMethod.Declarations.Insert(0, new Comment(String.Format( + "The instance OID of this table consists of following (index) column(s):\n{0}", + indexColumns))); + } + + string augmentsHint = ""; + if (!String.IsNullOrWhiteSpace(this.augmentedTableRow)) + { + augmentsHint = String.Format( + "This table augments table '{0}'! Index columns therefore belong to table '{0}'!\n" + + "You may simply call the '*{1}' method of this table.\n\n", + (this.augmentedTableRow.ToLowerInvariant().EndsWith("entry")) ? this.augmentedTableRow.Substring(0, this.augmentedTableRow.Length-5) : this.augmentedTableRow, + LwipDefs.FnctSuffix_GetInstance); + } + + CodeContainerBase ccb = getInstanceMethod; + if (instanceOidLength > 0) + { + IfThenElse ite = new IfThenElse(String.Format("{0} == {1}", getInstanceMethod.Parameter[2].Name, instanceOidLength)); + getInstanceMethod.AddElement(ite); + ccb = ite; + } + + ccb.AddCodeFormat("LWIP_UNUSED_ARG({0});", getInstanceMethod.Parameter[0].Name); + ccb.AddCodeFormat("LWIP_UNUSED_ARG({0});", getInstanceMethod.Parameter[1].Name); + if (instanceOidLength <= 0) + { + ccb.AddCodeFormat("LWIP_UNUSED_ARG({0});", getInstanceMethod.Parameter[2].Name); + } + ccb.AddCodeFormat("LWIP_UNUSED_ARG({0});", getInstanceMethod.Parameter[3].Name); + + ccb.AddElement(new Comment(String.Format( + "TODO: check if '{0}'/'{1}' params contain a valid instance oid for a row\n" + + "If so, set '{2} = {3};'\n\n" + + "snmp_oid_* methods may be used for easier processing of oid\n\n" + + "{4}" + + "In order to avoid decoding OID a second time in subsequent get_value/set_test/set_value methods,\n" + + "you may store an arbitrary value (like a pointer to target value object) in '{5}->reference'/'{5}->reference_len'.\n" + + "But be aware that not always a subsequent method is called -> Do NOT allocate memory here and try to release it in subsequent methods!\n\n" + + "You also may replace function pointers in '{5}' param for get/test/set methods which contain the default values from table definition,\n" + + "in order to provide special methods, for the currently processed cell. Changed pointers are only valid for current request.", + getInstanceMethod.Parameter[1].Name, + getInstanceMethod.Parameter[2].Name, + returnValue.Type.Name, + LwipDefs.Def_ErrorCode_Ok, + augmentsHint, + getInstanceMethod.Parameter[3].Name + ))); + + getInstanceMethod.AddCodeFormat("return {0};", returnValue.Type.Name); + } + + protected virtual void GenerateGetNextInstanceMethodCode(Function getNextInstanceMethod) + { + getNextInstanceMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", getNextInstanceMethod.Parameter[0].Name); + getNextInstanceMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", getNextInstanceMethod.Parameter[1].Name); + getNextInstanceMethod.AddCodeFormat("LWIP_UNUSED_ARG({0});", getNextInstanceMethod.Parameter[2].Name); + + VariableDeclaration returnValue = new VariableDeclaration((VariableType)getNextInstanceMethod.ReturnType.Clone(), LwipDefs.Def_ErrorCode_NoSuchInstance); + returnValue.Type.Name = "err"; + getNextInstanceMethod.Declarations.Add(returnValue); + + StringBuilder indexColumns = new StringBuilder(); + foreach (SnmpScalarNode indexNode in this.indexNodes) + { + indexColumns.AppendFormat( + " {0} ({1}, OID length = {2})\n", + indexNode.Name, + indexNode.DataType, + (indexNode.OidRepresentationLen >= 0) ? indexNode.OidRepresentationLen.ToString() : "variable"); + } + if (indexColumns.Length > 0) + { + indexColumns.Length--; + + getNextInstanceMethod.Declarations.Insert(0, new Comment(String.Format( + "The instance OID of this table consists of following (index) column(s):\n{0}", + indexColumns))); + } + + string augmentsHint = ""; + if (!String.IsNullOrWhiteSpace(this.augmentedTableRow)) + { + augmentsHint = String.Format( + "This table augments table '{0}'! Index columns therefore belong to table '{0}'!\n" + + "You may simply call the '*{1}' method of this table.\n\n", + (this.augmentedTableRow.ToLowerInvariant().EndsWith("entry")) ? this.augmentedTableRow.Substring(0, this.augmentedTableRow.Length-5) : this.augmentedTableRow, + LwipDefs.FnctSuffix_GetNextInstance); + } + + getNextInstanceMethod.AddElement(new Comment(String.Format( + "TODO: analyze '{0}->id'/'{0}->len' and return the subsequent row instance\n" + + "Be aware that '{0}->id'/'{0}->len' must not point to a valid instance or have correct instance length.\n" + + "If '{0}->len' is 0, return the first instance. If '{0}->len' is longer than expected, cut superfluous OID parts.\n" + + "If a valid next instance is found, store it in '{0}->id'/'{0}->len' and set '{1} = {2};'\n\n" + + "snmp_oid_* methods may be used for easier processing of oid\n\n" + + "{3}" + + "In order to avoid decoding OID a second time in subsequent get_value/set_test/set_value methods,\n" + + "you may store an arbitrary value (like a pointer to target value object) in '{4}->reference'/'{4}->reference_len'.\n" + + "But be aware that not always a subsequent method is called -> Do NOT allocate memory here and try to release it in subsequent methods!\n\n" + + "You also may replace function pointers in '{4}' param for get/test/set methods which contain the default values from table definition,\n" + + "in order to provide special methods, for the currently processed cell. Changed pointers are only valid for current request.", + getNextInstanceMethod.Parameter[1].Name, + returnValue.Type.Name, + LwipDefs.Def_ErrorCode_Ok, + augmentsHint, + getNextInstanceMethod.Parameter[2].Name + ))); + + getNextInstanceMethod.AddElement(new Comment(String.Format( + "For easier processing and getting the next instance, you may use the 'snmp_next_oid_*' enumerator.\n" + + "Simply pass all known instance OID's to it and it returns the next valid one:\n\n" + + "{0} state;\n" + + "{1} result_buf;\n" + + "snmp_next_oid_init(&state, {2}->id, {2}->len, result_buf.id, SNMP_MAX_OBJ_ID_LEN);\n" + + "while ({{not all instances passed}}) {{\n" + + " {1} test_oid;\n" + + " {{fill test_oid to create instance oid for next instance}}\n" + + " snmp_next_oid_check(&state, test_oid.id, test_oid.len, {{target_data_ptr}});\n" + + "}}\n" + + "if(state.status == SNMP_NEXT_OID_STATUS_SUCCESS) {{\n" + + " snmp_oid_assign(row_oid, state.next_oid, state.next_oid_len);\n" + + " {3}->reference.ptr = state.reference; //==target_data_ptr, for usage in subsequent get/test/set\n" + + " {4} = {5};\n" + + "}}" + , + LwipDefs.Vt_StNextOidState, + LwipDefs.Vt_StObjectId, + getNextInstanceMethod.Parameter[1].Name, + getNextInstanceMethod.Parameter[2].Name, + returnValue.Type.Name, + LwipDefs.Def_ErrorCode_Ok + ))); + + getNextInstanceMethod.AddCodeFormat("return {0};", returnValue.Type.Name); + } + + } +} diff --git a/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpTreeNode.cs b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpTreeNode.cs new file mode 100644 index 00000000000..bf0c604ee4d --- /dev/null +++ b/contrib/apps/LwipMibCompiler/LwipSnmpCodeGeneration/SnmpTreeNode.cs @@ -0,0 +1,242 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Collections.Generic; +using System.Text; +using CCodeGeneration; + +namespace LwipSnmpCodeGeneration +{ + public class SnmpTreeNode: SnmpScalarAggregationNode + { + private readonly List<SnmpNode> childNodes = new List<SnmpNode>(); + private readonly List<SnmpScalarNode> childScalarNodes = new List<SnmpScalarNode>(); + private string fullOid = ""; + + public SnmpTreeNode(SnmpTreeNode parentNode) + : base(parentNode) + { + } + + public override string FullNodeName + { + get { return this.Name.ToLowerInvariant() + "_treenode"; } + } + + public string FullOid + { + get { return this.fullOid; } + set { this.fullOid = value; } + } + + public List<SnmpNode> ChildNodes + { + get { return this.childNodes; } + } + + protected override IEnumerable<SnmpScalarNode> AggregatedScalarNodes + { + get { return this.childScalarNodes; } + } + + private void GenerateAggregatedCode(MibCFile mibFile, bool generateDeclarations, bool generateImplementations) + { + VariableType instanceType = new VariableType("instance", LwipDefs.Vt_StNodeInstance, "*"); + base.GenerateAggregatedCode( + mibFile, + instanceType, + String.Format("{0}->node->oid", instanceType.Name), + generateDeclarations, + generateImplementations); + } + + private void GenerateAggregateMethodDeclarations(MibCFile mibFile) + { + if (LwipOpts.GenerateSingleAccessMethodsForTreeNodeScalars && (this.childScalarNodes.Count > 1)) + { + GenerateAggregatedCode(mibFile, true, false); + } + } + + public override void GenerateCode(MibCFile mibFile) + { + string nodeInitialization; + + if (LwipOpts.GenerateSingleAccessMethodsForTreeNodeScalars && (this.childScalarNodes.Count > 1)) + { + GenerateAggregatedCode(mibFile, false, true); + } + + // create and add node declaration + if (this.childNodes.Count > 0) + { + StringBuilder subnodeArrayInitialization = new StringBuilder(); + + for (int i=0; i<this.childNodes.Count; i++) + { + subnodeArrayInitialization.Append(" &"); + subnodeArrayInitialization.Append(this.childNodes[i].FullNodeName); + subnodeArrayInitialization.Append(".node"); + if (!(this.childNodes[i] is SnmpTreeNode)) + { + subnodeArrayInitialization.Append(".node"); + } + + if (i < (this.childNodes.Count - 1)) + { + subnodeArrayInitialization.Append(",\n"); + } + } + + VariableDeclaration subnodeArray = new VariableDeclaration( + new VariableType(this.Name.ToLowerInvariant() + "_subnodes", LwipDefs.Vt_StNode, "*", ConstType.Both, String.Empty), + "{\n" + subnodeArrayInitialization + "\n}", + isStatic: true); + + mibFile.Declarations.Add(subnodeArray); + + nodeInitialization = String.Format("SNMP_CREATE_TREE_NODE({0}, {1})", this.Oid, subnodeArray.Type.Name); + } + else + { + nodeInitialization = String.Format("SNMP_CREATE_EMPTY_TREE_NODE({0})", this.Oid); + } + + mibFile.Declarations.Add(new VariableDeclaration( + new VariableType(this.FullNodeName, LwipDefs.Vt_StTreeNode, null, ConstType.Value), + nodeInitialization, + isStatic: true)); + } + + public override void Analyze() + { + this.childScalarNodes.Clear(); + + // delegate analyze (don't use enumerator because the child node may change our child collection by e.g. removing or replacing itself) + for (int i=this.ChildNodes.Count-1; i>=0; i--) + { + this.ChildNodes[i].Analyze(); + } + + // collect scalar nodes + foreach (SnmpNode childNode in this.childNodes) + { + SnmpScalarNode scalarNode = childNode as SnmpScalarNode; + if (scalarNode != null) + { + this.childScalarNodes.Add(scalarNode); + } + } + + base.Analyze(); + + // check if we can merge this node to a scalar array node (all childs need to be scalars) + if (this.childNodes.Count > 0) + { + if (LwipOpts.GenerateScalarArrays && (this.childScalarNodes.Count == this.childNodes.Count) && (this.ParentNode != null)) + { + SnmpScalarArrayNode scalarArrayNode = new SnmpScalarArrayNode(this.childScalarNodes, this.ParentNode); + scalarArrayNode.Oid = this.Oid; + scalarArrayNode.Name = this.Name; + scalarArrayNode.Analyze(); + + for (int i=0; i<this.ParentNode.ChildNodes.Count; i++) + { + if (this.ParentNode.ChildNodes[i] == this) + { + this.ParentNode.ChildNodes.RemoveAt(i); + this.ParentNode.ChildNodes.Insert(i, scalarArrayNode); + break; + } + } + } + else if (LwipOpts.GenerateSingleAccessMethodsForTreeNodeScalars && (this.childScalarNodes.Count > 1)) + { + foreach (SnmpScalarNode scalarNode in this.childScalarNodes) + { + scalarNode.UseExternalMethods = true; + scalarNode.ExternalGetMethod = this.GetMethodName; + scalarNode.ExternalTestMethod = this.TestMethodName; + scalarNode.ExternalSetMethod = this.SetMethodName; + } + } + } + else // if (this.childNodes.Count == 0) + { + if (!LwipOpts.GenerateEmptyFolders && (this.ParentNode != null)) + { + // do not generate this empty folder because it only waste (static) memory + for (int i=0; i<this.ParentNode.ChildNodes.Count; i++) + { + if (this.ParentNode.ChildNodes[i] == this) + { + this.ParentNode.ChildNodes.RemoveAt(i); + break; + } + } + } + } + } + + public override void Generate(MibCFile generatedFile, MibHeaderFile generatedHeaderFile) + { + // generate code of child nodes + foreach (SnmpNode childNode in this.childNodes) + { + if (childNode is SnmpTreeNode) + { + childNode.Generate(generatedFile, generatedHeaderFile); + } + } + + Comment dividerComment = new Comment( + String.Format("--- {0} {1} -----------------------------------------------------", this.Name, this.fullOid), + singleLine: true); + + generatedFile.Declarations.Add(dividerComment); + generatedFile.Implementation.Add(dividerComment); + + this.GenerateAggregateMethodDeclarations(generatedFile); + + foreach (SnmpNode childNode in this.childNodes) + { + if (!(childNode is SnmpTreeNode)) + { + childNode.Generate(generatedFile, generatedHeaderFile); + } + } + + base.Generate(generatedFile, generatedHeaderFile); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/MibViewer/FormMain.Designer.cs b/contrib/apps/LwipMibCompiler/MibViewer/FormMain.Designer.cs new file mode 100644 index 00000000000..dcd19aa5067 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/MibViewer/FormMain.Designer.cs @@ -0,0 +1,166 @@ +namespace LwipMibViewer +{ + partial class FormMain + { + /// <summary> + /// Erforderliche Designervariable. + /// </summary> + private System.ComponentModel.IContainer components = null; + + /// <summary> + /// Verwendete Ressourcen bereinigen. + /// </summary> + /// <param name="disposing">True, wenn verwaltete Ressourcen gelöscht werden sollen; andernfalls False.</param> + protected override void Dispose(bool disposing) + { + if (disposing && (components != null)) + { + components.Dispose(); + } + base.Dispose(disposing); + } + + #region Vom Windows Form-Designer generierter Code + + /// <summary> + /// Erforderliche Methode für die Designerunterstützung. + /// Der Inhalt der Methode darf nicht mit dem Code-Editor geändert werden. + /// </summary> + private void InitializeComponent() + { + this.components = new System.ComponentModel.Container(); + System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(FormMain)); + this.treeMib = new System.Windows.Forms.TreeView(); + this.imagelistTreeNodeImages = new System.Windows.Forms.ImageList(this.components); + this.splitContainerMain = new System.Windows.Forms.SplitContainer(); + this.listviewNodeDetails = new System.Windows.Forms.ListView(); + this.columnHeader1 = ((System.Windows.Forms.ColumnHeader)(new System.Windows.Forms.ColumnHeader())); + this.columnHeader2 = ((System.Windows.Forms.ColumnHeader)(new System.Windows.Forms.ColumnHeader())); + this.toolStripMain = new System.Windows.Forms.ToolStrip(); + this.toolbuttonOpenMib = new System.Windows.Forms.ToolStripButton(); + this.dialogOpenMib = new System.Windows.Forms.OpenFileDialog(); + ((System.ComponentModel.ISupportInitialize)(this.splitContainerMain)).BeginInit(); + this.splitContainerMain.Panel1.SuspendLayout(); + this.splitContainerMain.Panel2.SuspendLayout(); + this.splitContainerMain.SuspendLayout(); + this.toolStripMain.SuspendLayout(); + this.SuspendLayout(); + // + // treeMib + // + this.treeMib.Dock = System.Windows.Forms.DockStyle.Fill; + this.treeMib.ImageIndex = 0; + this.treeMib.ImageList = this.imagelistTreeNodeImages; + this.treeMib.Location = new System.Drawing.Point(0, 0); + this.treeMib.Name = "treeMib"; + this.treeMib.SelectedImageIndex = 0; + this.treeMib.Size = new System.Drawing.Size(1028, 418); + this.treeMib.TabIndex = 0; + this.treeMib.AfterSelect += new System.Windows.Forms.TreeViewEventHandler(this.treeMib_AfterSelect); + // + // imagelistTreeNodeImages + // + this.imagelistTreeNodeImages.ImageStream = ((System.Windows.Forms.ImageListStreamer)(resources.GetObject("imagelistTreeNodeImages.ImageStream"))); + this.imagelistTreeNodeImages.TransparentColor = System.Drawing.Color.Transparent; + this.imagelistTreeNodeImages.Images.SetKeyName(0, "ntimgContainer"); + this.imagelistTreeNodeImages.Images.SetKeyName(1, "ntimgTable"); + this.imagelistTreeNodeImages.Images.SetKeyName(2, "ntimgRow"); + this.imagelistTreeNodeImages.Images.SetKeyName(3, "ntimgColumn"); + this.imagelistTreeNodeImages.Images.SetKeyName(4, "ntimgScalar"); + this.imagelistTreeNodeImages.Images.SetKeyName(5, "ntimgUnknown"); + // + // splitContainerMain + // + this.splitContainerMain.Dock = System.Windows.Forms.DockStyle.Fill; + this.splitContainerMain.Location = new System.Drawing.Point(0, 25); + this.splitContainerMain.Name = "splitContainerMain"; + this.splitContainerMain.Orientation = System.Windows.Forms.Orientation.Horizontal; + // + // splitContainerMain.Panel1 + // + this.splitContainerMain.Panel1.Controls.Add(this.treeMib); + // + // splitContainerMain.Panel2 + // + this.splitContainerMain.Panel2.Controls.Add(this.listviewNodeDetails); + this.splitContainerMain.Size = new System.Drawing.Size(1028, 625); + this.splitContainerMain.SplitterDistance = 418; + this.splitContainerMain.TabIndex = 1; + // + // listviewNodeDetails + // + this.listviewNodeDetails.Columns.AddRange(new System.Windows.Forms.ColumnHeader[] { + this.columnHeader1, + this.columnHeader2}); + this.listviewNodeDetails.Dock = System.Windows.Forms.DockStyle.Fill; + this.listviewNodeDetails.FullRowSelect = true; + this.listviewNodeDetails.HeaderStyle = System.Windows.Forms.ColumnHeaderStyle.None; + this.listviewNodeDetails.Location = new System.Drawing.Point(0, 0); + this.listviewNodeDetails.Name = "listviewNodeDetails"; + this.listviewNodeDetails.Size = new System.Drawing.Size(1028, 203); + this.listviewNodeDetails.TabIndex = 0; + this.listviewNodeDetails.UseCompatibleStateImageBehavior = false; + this.listviewNodeDetails.View = System.Windows.Forms.View.Details; + // + // columnHeader1 + // + this.columnHeader1.Text = ""; + this.columnHeader1.Width = 150; + // + // columnHeader2 + // + this.columnHeader2.Text = ""; + this.columnHeader2.Width = 777; + // + // toolStripMain + // + this.toolStripMain.Items.AddRange(new System.Windows.Forms.ToolStripItem[] { + this.toolbuttonOpenMib}); + this.toolStripMain.Location = new System.Drawing.Point(0, 0); + this.toolStripMain.Name = "toolStripMain"; + this.toolStripMain.Size = new System.Drawing.Size(1028, 25); + this.toolStripMain.TabIndex = 2; + // + // toolbuttonOpenMib + // + this.toolbuttonOpenMib.Image = ((System.Drawing.Image)(resources.GetObject("toolbuttonOpenMib.Image"))); + this.toolbuttonOpenMib.Name = "toolbuttonOpenMib"; + this.toolbuttonOpenMib.Size = new System.Drawing.Size(65, 22); + this.toolbuttonOpenMib.Text = "Open..."; + this.toolbuttonOpenMib.Click += new System.EventHandler(this.toolbuttonOpenMib_Click); + // + // FormMain + // + this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F); + this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font; + this.ClientSize = new System.Drawing.Size(1028, 650); + this.Controls.Add(this.splitContainerMain); + this.Controls.Add(this.toolStripMain); + this.Name = "FormMain"; + this.Text = "MIB Viewer"; + this.WindowState = System.Windows.Forms.FormWindowState.Maximized; + this.splitContainerMain.Panel1.ResumeLayout(false); + this.splitContainerMain.Panel2.ResumeLayout(false); + ((System.ComponentModel.ISupportInitialize)(this.splitContainerMain)).EndInit(); + this.splitContainerMain.ResumeLayout(false); + this.toolStripMain.ResumeLayout(false); + this.toolStripMain.PerformLayout(); + this.ResumeLayout(false); + this.PerformLayout(); + + } + + #endregion + + private System.Windows.Forms.TreeView treeMib; + private System.Windows.Forms.SplitContainer splitContainerMain; + private System.Windows.Forms.ListView listviewNodeDetails; + private System.Windows.Forms.ColumnHeader columnHeader1; + private System.Windows.Forms.ColumnHeader columnHeader2; + private System.Windows.Forms.ImageList imagelistTreeNodeImages; + private System.Windows.Forms.ToolStrip toolStripMain; + private System.Windows.Forms.ToolStripButton toolbuttonOpenMib; + private System.Windows.Forms.OpenFileDialog dialogOpenMib; + } +} + diff --git a/contrib/apps/LwipMibCompiler/MibViewer/FormMain.cs b/contrib/apps/LwipMibCompiler/MibViewer/FormMain.cs new file mode 100644 index 00000000000..7d2490dbda2 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/MibViewer/FormMain.cs @@ -0,0 +1,217 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System.Windows.Forms; +using Lextm.SharpSnmpLib.Mib; +using Lextm.SharpSnmpLib.Mib.Elements; +using Lextm.SharpSnmpLib.Mib.Elements.Types; +using Lextm.SharpSnmpLib.Mib.Elements.Entities; +using System.IO; + +namespace LwipMibViewer +{ + public partial class FormMain : Form + { + readonly ListViewGroup listviewgroupAbstract; + readonly ListViewGroup listviewgroupElement; + readonly ListViewGroup listviewgroupBaseType; + readonly ListViewGroup listviewgroupTypeChain; + + public FormMain() + { + this.Font = SystemInformation.MenuFont; + InitializeComponent(); + + this.listviewgroupAbstract = new ListViewGroup("Abstract", System.Windows.Forms.HorizontalAlignment.Left); + this.listviewgroupElement = new ListViewGroup("Element Properties", System.Windows.Forms.HorizontalAlignment.Left); + this.listviewgroupBaseType = new ListViewGroup("Element Base Type", System.Windows.Forms.HorizontalAlignment.Left); + this.listviewgroupTypeChain = new ListViewGroup("Element Type Chain", System.Windows.Forms.HorizontalAlignment.Left); + this.listviewNodeDetails.Groups.AddRange(new System.Windows.Forms.ListViewGroup[] { + listviewgroupAbstract, + listviewgroupElement, + listviewgroupBaseType, + listviewgroupTypeChain}); + + try + { + DirectoryInfo dirInfo = new DirectoryInfo(Path.GetDirectoryName(Application.ExecutablePath)); + if (dirInfo != null) + { + dirInfo = dirInfo.Parent; + if (dirInfo != null) + { + dirInfo = dirInfo.Parent; + if (dirInfo != null) + { + dirInfo = new DirectoryInfo(Path.Combine(dirInfo.FullName, "Mibs")); + if (dirInfo.Exists) + { + MibTypesResolver.RegisterResolver(new FileSystemMibResolver(dirInfo.FullName, true)); + } + } + } + } + } + catch + { } + } + + #region GUI Event Handler + + private void toolbuttonOpenMib_Click(object sender, System.EventArgs e) + { + if (this.dialogOpenMib.ShowDialog() == DialogResult.OK) + { + OpenMib(this.dialogOpenMib.FileName); + } + } + + private void treeMib_AfterSelect(object sender, TreeViewEventArgs e) + { + listviewNodeDetails.Items.Clear(); + + if (e.Node != null) + { + MibTreeNode mtn = e.Node.Tag as MibTreeNode; + if (mtn != null) + { + listviewNodeDetails.Items.Add(new ListViewItem(new string[] { "Abstract", mtn.NodeType.ToString() }, this.listviewgroupAbstract)); + + listviewNodeDetails.Items.Add(new ListViewItem(new string[] { "Module", (mtn.Entity.Module != null) ? mtn.Entity.Module.Name : "" }, this.listviewgroupElement)); + listviewNodeDetails.Items.Add(new ListViewItem(new string[] { "Type", mtn.Entity.GetType().Name }, this.listviewgroupElement)); + listviewNodeDetails.Items.Add(new ListViewItem(new string[] { "Name", mtn.Entity.Name }, this.listviewgroupElement)); + listviewNodeDetails.Items.Add(new ListViewItem(new string[] { "Description", mtn.Entity.Description }, this.listviewgroupElement)); + listviewNodeDetails.Items.Add(new ListViewItem(new string[] { "OID", mtn.Entity.Value.ToString() }, this.listviewgroupElement)); + listviewNodeDetails.Items.Add(new ListViewItem(new string[] { "Full OID", MibTypesResolver.ResolveOid(mtn.Entity).GetOidString() }, this.listviewgroupElement)); + if (mtn.Entity is ObjectType) + { + listviewNodeDetails.Items.Add(new ListViewItem(new string[] { "Access", (mtn.Entity as ObjectType).Access.ToString() }, this.listviewgroupElement)); + } + + ITypeReferrer tr = mtn.Entity as ITypeReferrer; + if (tr != null) + { + ShowTypeDetails(listviewNodeDetails, this.listviewgroupBaseType, tr.BaseType); + ShowTypeChain(listviewNodeDetails, tr.ReferredType); + } + } + } + } + + #endregion + + #region Methods + + private void OpenMib(string file) + { + try + { + MibDocument md = new MibDocument(file); + MibTypesResolver.ResolveTypes(md.Modules[0]); + + this.treeMib.Nodes.Clear(); + this.listviewNodeDetails.Items.Clear(); + + MibTree mt = new MibTree(md.Modules[0] as MibModule); + foreach (MibTreeNode mibTreeNode in mt.Root) + { + AddNode(mibTreeNode, this.treeMib.Nodes); + + foreach (TreeNode node in this.treeMib.Nodes) + { + node.Expand(); + } + } + } + catch + { + } + } + + private void AddNode(MibTreeNode mibNode, TreeNodeCollection parentNodes) + { + int imgIndex = 5; //unknown + if ((mibNode.NodeType & MibTreeNodeType.Table) != 0) + { + imgIndex = 1; + } + else if ((mibNode.NodeType & MibTreeNodeType.TableRow) != 0) + { + imgIndex = 2; + } + else if ((mibNode.NodeType & MibTreeNodeType.TableCell) != 0) + { + imgIndex = 3; + } + else if ((mibNode.NodeType & MibTreeNodeType.Scalar) != 0) + { + imgIndex = 4; + } + else if ((mibNode.NodeType & MibTreeNodeType.Container) != 0) + { + imgIndex = 0; + } + + TreeNode newNode = new TreeNode(mibNode.Entity.Name, imgIndex, imgIndex); + newNode.Tag = mibNode; + + parentNodes.Add(newNode); + + foreach (MibTreeNode child in mibNode.ChildNodes) + { + AddNode(child, newNode.Nodes); + } + } + + private void ShowTypeChain(ListView lv, ITypeAssignment type) + { + ShowTypeDetails(lv, this.listviewgroupTypeChain, type); + + ITypeReferrer tr = type as ITypeReferrer; + if ((tr != null) && (tr.ReferredType != null)) + { + lv.Items.Add(new ListViewItem(new string[] { " >>>", "" }, this.listviewgroupTypeChain)); + ShowTypeChain(listviewNodeDetails, tr.ReferredType); + } + } + + private void ShowTypeDetails(ListView lv, ListViewGroup lvg, ITypeAssignment type) + { + lv.Items.Add(new ListViewItem(new string[] { "Module", (type.Module != null) ? type.Module.Name : "" }, lvg)); + lv.Items.Add(new ListViewItem(new string[] { "Type", type.GetType().Name }, lvg)); + lv.Items.Add(new ListViewItem(new string[] { "Name", type.Name }, lvg)); + } + + #endregion + + } +} diff --git a/contrib/apps/LwipMibCompiler/MibViewer/FormMain.resx b/contrib/apps/LwipMibCompiler/MibViewer/FormMain.resx new file mode 100644 index 00000000000..973f546bd40 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/MibViewer/FormMain.resx @@ -0,0 +1,298 @@ +<?xml version="1.0" encoding="utf-8"?> +<root> + <!-- + Microsoft ResX Schema + + Version 2.0 + + The primary goals of this format is to allow a simple XML format + that is mostly human readable. The generation and parsing of the + various data types are done through the TypeConverter classes + associated with the data types. + + Example: + + ... ado.net/XML headers & schema ... + <resheader name="resmimetype">text/microsoft-resx</resheader> + <resheader name="version">2.0</resheader> + <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader> + <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader> + <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data> + <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data> + <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64"> + <value>[base64 mime encoded serialized .NET Framework object]</value> + </data> + <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64"> + <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value> + <comment>This is a comment</comment> + </data> + + There are any number of "resheader" rows that contain simple + name/value pairs. + + Each data row contains a name, and value. The row also contains a + type or mimetype. Type corresponds to a .NET class that support + text/value conversion through the TypeConverter architecture. + Classes that don't support this are serialized and stored with the + mimetype set. + + The mimetype is used for serialized objects, and tells the + ResXResourceReader how to depersist the object. This is currently not + extensible. For a given mimetype the value must be set accordingly: + + Note - application/x-microsoft.net.object.binary.base64 is the format + that the ResXResourceWriter will generate, however the reader can + read any of the formats listed below. + + mimetype: application/x-microsoft.net.object.binary.base64 + value : The object must be serialized with + : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter + : and then encoded with base64 encoding. + + mimetype: application/x-microsoft.net.object.soap.base64 + value : The object must be serialized with + : System.Runtime.Serialization.Formatters.Soap.SoapFormatter + : and then encoded with base64 encoding. + + mimetype: application/x-microsoft.net.object.bytearray.base64 + value : The object must be serialized into a byte array + : using a System.ComponentModel.TypeConverter + : and then encoded with base64 encoding. + --> + <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata"> + <xsd:import namespace="http://www.w3.org/XML/1998/namespace" /> + <xsd:element name="root" msdata:IsDataSet="true"> + xsd:complexType + <xsd:choice maxOccurs="unbounded"> + <xsd:element name="metadata"> + xsd:complexType + xsd:sequence + <xsd:element name="value" type="xsd:string" minOccurs="0" /> + </xsd:sequence> + <xsd:attribute name="name" use="required" type="xsd:string" /> + <xsd:attribute name="type" type="xsd:string" /> + <xsd:attribute name="mimetype" type="xsd:string" /> + <xsd:attribute ref="xml:space" /> + </xsd:complexType> + </xsd:element> + <xsd:element name="assembly"> + xsd:complexType + <xsd:attribute name="alias" type="xsd:string" /> + <xsd:attribute name="name" type="xsd:string" /> + </xsd:complexType> + </xsd:element> + <xsd:element name="data"> + xsd:complexType + xsd:sequence + <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" /> + <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" /> + </xsd:sequence> + <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" /> + <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" /> + <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" /> + <xsd:attribute ref="xml:space" /> + </xsd:complexType> + </xsd:element> + <xsd:element name="resheader"> + xsd:complexType + xsd:sequence + <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" /> + </xsd:sequence> + <xsd:attribute name="name" type="xsd:string" use="required" /> + </xsd:complexType> + </xsd:element> + </xsd:choice> + </xsd:complexType> + </xsd:element> + </xsd:schema> + <resheader name="resmimetype"> + <value>text/microsoft-resx</value> + </resheader> + <resheader name="version"> + <value>2.0</value> + </resheader> + <resheader name="reader"> + <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value> + </resheader> + <resheader name="writer"> + <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value> + </resheader> + <metadata name="imagelistTreeNodeImages.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"> + <value>17, 17</value> + </metadata> + <data name="imagelistTreeNodeImages.ImageStream" mimetype="application/x-microsoft.net.object.binary.base64"> + <value> + AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj00LjAuMC4w + LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0 + ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAABo + IQAAAk1TRnQBSQFMAgEBBgEAARABAAEQAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA + AwABIAMAAQEBAAEgBgABIBIAAwQBBQMWAR4DIgEyAzEBTwJGAUQBhwMvAUsDHgErAxsBJgMYASIDFQEd + AxIBGAMNARIDCgENAwcBCQMEAQUDAQECAwQBBQMWAR4DIgEyAzEBTgJGAUQBhwMvAUsDHgErAxsBJgMb + ASYDIQExAyEBMAMdASoDGwEmAxgBIQMLAQ8DAQECgAADAgEDAwwBEAMrAUMCRgFEAYIC/wHwAf8CRgFE + AYIDKgFAAw8BFAMNAREDCwEPAwkBDAMHAQoDBQEHAwQBBQMCAQMDAAEBAwIBAwMLAQ8DKwFDAkYBRAGC + Av8B8AH/AkYBRAGCAyoBQAMOARMDEgEZAT0COwFpAVwBRQFCAawBZwE+AToBxAFaAUUBQwGqATwBOwE6 + AWYDEAEWAwABAYQAAx4BKwJEAUIBewL/AfAB/wLpAdoD/wHxAf8CRAFCAXsDHgErJAADHgErAkQBQgF7 + Av8B8AH/AukB2gP/AfEB/wJEAUIBewMeASsBLgItAUcBdwFHATwByQG7AVQBPQHxA+4B/wG7AVMBPAHx + AXcBRgE8AckBLgItAUeEAAMdASoCRAFCAXcC/wHwAf8B6wHdAbEB/wH3AcEBNwH/Ae0B3wGzA/8B8gH/ + AkQBQgF3Ax0BKhwAAx0BKgJEAUIBdwL/AfAB/wLpAdoB/wLqAdwB/wLrAd4D/wHyAf8CRAFCAXcBZAFJ + AUIBrwG2AVkBQQHxAc0BVAEyAf8BvQF5AWIB/wHFAVABLgH/AbEBUQE1AfEBXAFIAUQBn4QAAkMBQQF2 + Av8B8AH/AukB2gH/AecBqwEhAf8B5wGrASEB/wHnAasBIQH/AeoB2wGwA/8B9AH/AkMBQQF2Ax0BKhgA + AkMBQQF2Av8B8AH/AukB2gH/AuoB3AH/AusB3gH/AuwB3wH/Au0B4QP/AfQB/wGAAUQBMQHaAc4BcAFN + AfwBugFMASoB/wPSAf8BvgGLAXgB/wG7AVIBMgH8AW8BSQE/AbqEAAMdASkCQwFBAXQC/wHxAf8B5wHX + AasB/wHXAZYBDAH/AdcBlgEMAf8B1wGWAQwB/wHoAdgBrgP/AfUB/wJDAUEBdAMdASkUAAMdASkCQwFB + AXQC/wHxAf8C6wHeAf8C7AHfAf8C7QHhAf8C7gHjAf8C7wHlAf8BzQF5AV4B/wHOAXcBWAH3AbwBVAEy + Af8BtAFMASoB/wPmAf8BtwFlAUsB8AFdAUkBRAGdiAADHQEpAkIBQQFyAv8B8gH/AeUB1AGpAf8BzQGJ + AQAB/wHNAYkBAAH/Ac0BiQEAAf8B6AHXAa8D/wH3Af8CQgFBAXIDHAEoFAADHQEpAkIBQQFyAv8B8gH/ + Au0B4QH/Au4B4wH/Au8B5QH/AvAB5wH/AeABuwGqAf8BzgFpAUgB/wHjAcsBwQH5BP8B3gHHAb0B9QF+ + AU8BQgHEAi0BLAFFjAADHAEoAkEBQAFxAv8B9AH/AecB1gGsAf8B0QGOAQQB/wHRAY4BBAH/AdEBjgEE + Af8B7AHbAbMD/wH4Af8CQQFAAXEDHAEoFAADHAEoAkEBQAFxAv8B9AH/Au8B5QH/AvAB5wH/AvEB6QH/ + AvMB6gH/AeQBvgGsAf8B1AGBAWIB/wGGAUoBNAHXAWYBTQFEAaoCLQEsAUWUAAMcAScCQQFAAW8C/wH1 + Af8B7AHcAbMB/wHfAaEBFwH/Ad8BoQEXAf8B3wGhARcB/wHxAeIBuwP/AfoB/wJBAUABbwMcAScUAAMc + AScCQQFAAW8C/wH1Af8C8QHpAf8C8wHqAf8C9AHsAf8C9QHuAf8C9gHwA/8B+gH/AkEBQAFvAxwBJ5gA + AxwBJwJAAT8BbQL/AfcB/wHyAeMBuwH/AfABuAEuAf8B8AG4AS4B/wHwAbgBLgH/AvgB9AP/AfsB/wJA + AT8BbQMcAScUAAMcAScCQAE/AW0C/wH3Af8C9AHsAf8C9QHuAf8C9gHwAf8C9wHyAf8C+AH0A/8B+wH/ + AkABPwFtAxwBJ5gAAxsBJgJAAT8BbAL/AfgB/wH3AeoBwwH/Af0ByQE/Af8B+QHsAccB/wL7AfcB/wL8 + AfkD/wH8Af8CQAE/AWwDGwEmFAADGwEmAkABPwFsAv8B+AH/AvYB8AH/AvcB8gH/AvgB9AH/AvsB9wH/ + AvwB+QP/AfwB/wJAAT8BbAMbASaYAAMbASYCPwE+AWsC/wH6Af8C+AH0Af8C+wH3Af8C3wHVAf8CyQG5 + Af8C4AHWA/8B/gH/Aj8BPgFrGAADGwEmAj8BPgFrAv8B+gH/AvgB9AH/AvsB9wH/At8B1QH/AskBuQH/ + AuAB1gP/Af4B/wI/AT4Ba5wAAxoBJQI/AT0BaQL/AfsB/wL8AfkB/wK8AawB/wQAArwBrAP/Af4B/wI/ + AT0BaRwAAxoBJQI/AT0BaQL/AfsB/wL8AfkB/wK8AawB/wQAArwBrAP/Af4B/wI/AT0BaaAAAxoBJQI+ + AT0BaAL/AfwB/wLLAcEB/wKgAZAB/wLLAcED/wH+Af8CPgE9AWggAAMaASUCPgE9AWgC/wH8Af8CywHB + Af8CoAGQAf8CywHBA/8B/gH/Aj4BPQFopAADGgElAj4BPQFnAv8B/gP/Af4D/wH+Bf8CPgE9AWckAAMa + ASUCPgE9AWcC/wH+A/8B/gP/Af4F/wI+AT0BZ6gAAxoBJAI+AT0BZgI+AT0BZgI+AT0BZgI+AT0BZgMx + AU0oAAMaASQCPgE9AWYCPgE9AWYCPgE9AWYCPgE9AWYDMQFNlAADIQEwAUABRgFIAXwBQwFOAVIBkgMF + AQccAAMHAQkDEAEWAxMBGgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMTARoDEwEa + AxABFgMHAQkDBwEJAxABFgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMTARoDEwEa + AxMBGgMQARYDBwEJAwcBCQMQARYDEwEaAxMBGgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMTARoDEwEa + AxMBGgMTARoDEAEWAwcBCQwAAjIBMwFQAUMBUQFXAZkBRQFkAXQBwAFYAYsBogHgATwBWAFqAcEDEwEa + AwUBBxgAAjwBOwFpAkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGH + AkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGHAjwBOwFpAjkBNAFpAkABNwGHAkABNwGH + AkABNwGHAkABNwGHAkABNwGHAkABNwGHAkABNwGHAkABNwGHAkABNwGHAkABNwGHAkABNwGHAkABNwGH + AkABNwGHAkABNwGHAjkBNAFpAjwBOwFpAkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGH + AkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGHAkYBRAGHAjwBOwFpAw0BEQMa + ASQBRAFNAVEBmAE8AYkBrAHyAWcBrwHTAfoBggHLAewB/wGFAc4B7gH/ARUBWwGCAe8BOgFXAWYBxAE6 + AVcBZgHEAT4BWgFqAb4BPgFaAWoBvgE+AVoBagG+AUQBTQFRAZgDGgEkAw0BEQJGAUMBgQL5AekB/wLz + AeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLz + AeIB/wLzAeIB/wL5AekB/wJGAUMBgQJDAToBgQL5AekB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLz + AeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wL5AekB/wJDAToBgQJG + AUMBgQL5AekB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLzAeIB/wLz + AeIB/wLzAeIB/wLzAeIB/wLzAeIB/wL5AekB/wJGAUMBgQMHAQkDDQESAUIBWwFmAbIBiAHQAe8B/wF9 + AcoB6QH/AX0BygHpAf8BhwHQAe8B/wEkAXsBqQH/AX0BvAHbAf8BfQG8AdsB/wGNAdEB8wH/AY0B0QHz + Af8BkAHUAfUB/wFCAVsBZgGyATACMQFNAwcBCQJEAUMBegL0AeQC/wHMAUIB/wH+AcsBQQH/AewB0gGG + Af8C2gHJAf8C2AHHAf8C1gHFAf8C1AHDAf8C0wHCAf8C0QHAAf8CzwG+Af8CzgG9Af8CzQG8Af8C9AHk + Af8CRAFDAXoCRgE+AXoC9AHkAv8BzAFDAf8B/gHLAUIB/wHsAdIBhgH/AtoByQH/AtgBxwH/AtYBxQH/ + AtQBwwH/AtMBwgH/AtEBwAH/As8BvgH/As4BvQH/As0BvAH/AvQB5AH/AkYBPgF6AkQBQwF6AvQB5AL/ + AcwBQgH/Af4BywFBAf8B7AHSAYYB/wLaAckB/wLYAccB/wHnAWEBPwH/AecBYQE/Af8B5wFhAT8B/wHn + AWEBPwH/As8BvgH/As4BvQH/As0BvAH/AvQB5AH/AkQBQwF6CAABQwFXAWABpAGKAdMB8AH/AYIBzQHr + Af8BggHNAesB/wGKAdMB8AH/ASQBfAGrAf8BegG5AdgB/wF6AbkB2AH/AYoBzgHwAf8BigHOAfAB/wGP + AdMB9AH/AfQBtgEsAf8BQwFXAWABpAQAAkQBQgF3AvUB5gL/AcwBQgL/Ae4BiAH/AewB0gGGAf8C9QHu + Af8C9QHuAf8C1gHFAf8C9QHuAf8C9QHuAf8C0QHAAf8C9QHuAf8C9QHuAf8CzQG8Af8C9QHmAf8CRAFC + AXcCRwE/AXcC9QHmAv8BzAFDAv8B7gGIAf8B7AHSAYYB/wL1Ae4B/wL1Ae4B/wLWAcUB/wL1Ae4B/wL1 + Ae4B/wLRAcAB/wL1Ae4B/wL1Ae4B/wLNAbwB/wL1AeYB/wJHAT8BdwJEAUIBdwL1AeYC/wHMAUIC/wHu + AYgB/wHsAdIBhgH/AvUB7gH/AvUB7gH/AdkBWAE2Af8B8gHJAbgB/wHyAckBuAH/AdkBWAE2Af8C9QHu + Af8C9QHuAf8CzQG8Af8C9QHmAf8CRAFCAXcIAAFDAVUBXgGeAY4B1gHyAf8BhwHQAe0B/wGHAdAB7QH/ + AY4B1gHyAf8BJgGCAa8B/wF7AboB2AH/AXsBugHYAf8BiwHPAfEB/wGLAc8B8QH/AZEB1QH1Af8B/gHJ + AT8B/wFDAVUBXgGeBAACQwFBAXUC9gHpAv8BzAFCAf8B/gHLAUEB/wHsAdIBhgH/AtoByQH/AtgBxwH/ + AtwBzAH/AtQBwwH/AtMBwgH/AtgByAH/As8BvgH/As4BvQH/As0BvAH/AvYB6QH/AkMBQQF1AkcBPwF1 + AvYB6QL/AcwBQwH/Af4BywFCAf8B7AHSAYYB/wLaAckB/wLYAccB/wLcAcwB/wLUAcMB/wLTAcIB/wLY + AcgB/wLPAb4B/wLOAb0B/wLNAbwB/wL2AekB/wJHAT8BdQJDAUEBdQL2AekC/wHMAUIB/wH+AcsBQQH/ + AewB0gGGAf8C2gHJAf8C2AHHAf8ByAFPAS0B/wHeAbYBngH/Ad4BtQGdAf8ByAFPAS0B/wLPAb4B/wLO + Ab0B/wLNAbwB/wL2AekB/wJDAUEBdQgAAUQBVQFdAZsBkgHaAfQB/wGLAdQB8AH/AYsB1AHwAf8BkgHa + AfQB/wEpAYUBswH/AX0BvAHaAf8BfQG8AdoB/wGNAdEB8wH/AY0B0QHzAf8BkwHXAfYB/wLrAd0B/wFE + AVUBXQGbBAACQgFBAXMC9wHrAv8BzAFCAv8B7gGIAf8B7AHSAYYB/wL3AfEB/wL3AfEB/wLWAcUB/wL3 + AfEB/wL3AfEB/wLRAcAB/wL3AfEB/wL3AfEB/wLNAbwB/wL3AesB/wJCAUEBcwJHAT8BcwL3AesC/wHM + AUMC/wHuAYgB/wHsAdIBhgH/AvcB8QH/AvcB8QH/AtYBxQH/AvcB8QH/AvcB8QH/AtEBwAH/AvcB8QH/ + AvcB8QH/As0BvAH/AvcB6wH/AkcBPwFzAkIBQQFzAvcB6wL/AcwBQgL/Ae4BiAH/AewB0gGGAf8C9wHx + Af8C9wHxAf8BuAFHASUB/wHzAcsBuQH/AfMBywG5Af8BuAFHASUB/wL3AfEB/wL3AfEB/wLNAbwB/wL3 + AesB/wJCAUEBcwgAAUQBUwFbApcB3gH2Af8BkAHYAfIB/wGQAdgB8gH/AZcB3gH2Af8BKwGJAbcB/wGA + Ab0B3AH/AYABvQHcAf8BjwHTAfUB/wGPAdMB9QH/AZUB2QH4Af8C9QHuAf8BRAFTAVsBlwQAAkIBQQFy + AvgB7gL/AcwBQgH/Af4BywFBAf8B7AHSAYYB/wLaAckB/wLYAccB/wLdAc4B/wLUAcMB/wLTAcIB/wLZ + AcoB/wLPAb4B/wLOAb0B/wLNAbwB/wL4Ae4B/wJCAUEBcgJIAUABcgL4Ae4B/wHsAYYBYwH/AeIBewFZ + Af8B1AFuAUwB/wHEAWABPgH/AbYBUgEwAf8BrQFHASUB/wGrAUMBIQH/AbEBRAEiAf8BvQFKASgB/wHM + AVIBMAH/AdsBWgE4Af8B6AFiAUAB/wL4Ae4B/wJIAUABcgJCAUEBcgL4Ae4C/wHMAUIB/wH+AcsBQQH/ + AewB0gGGAf8C2gHJAf8C2AHHAf8BrQFCASAB/wHeAbYBngH/Ad4BtQGdAf8BrQFCASAB/wLPAb4B/wLO + Ab0B/wLNAbwB/wL4Ae4B/wJCAUEBcggAAUQBUwFaAZQBmwHhAfcB/wGUAdsB9AH/AZQB2wH0Af8BmwHh + AfcB/wEuAY0BvAH/AYEBvgHdAf8BgQG+Ad0B/wGQAdQB9gH/AZAB1AH2Af8BlwHbAfkB/wL+Af0B/wFE + AVMBWgGUBAACQQFAAXAC+QHxAv8BzAFCAv8B7gGIAf8B7AHSAYYB/wL5AfUB/wL5AfUB/wLWAcUB/wL5 + AfUB/wL5AfUB/wLRAcAB/wL5AfUB/wL5AfUB/wLNAbwB/wL5AfEB/wJBAUABcAJHAUABcAL5AfEB/wHs + AYYBYwH/AfgBxQF5Af8B7QG1AXgB/wH1AcwBvAH/AfUBzAG8Af8B4AG3AZ8B/wH1AcwBvAH/AfUBzAG8 + Af8B3QG0AZwB/wH1AcwBvAH/AfUBzAG8Af8B6AFiAUAB/wL5AfEB/wJHAUABcAJBAUABcAL5AfEC/wHM + AUIC/wHuAYgB/wHsAdIBhgH/AvkB9QH/AvkB9QH/AasBRAEiAf8B9QHMAbwB/wH1AcwBvAH/AasBRAEi + Af8C+QH1Af8C+QH1Af8CzQG8Af8C+QHxAf8CQQFAAXAIAAFEAVEBVwGQAZ4B5QH5Af8BmAHfAfYB/wGY + Ad8B9gH/AZ4B5QH5Af8BMAGQAcAB/wGDAcAB3wH/AYMBwAHfAf8BkgHWAfgB/wGSAdYB+AH/AZkB3QH6 + Af8BRAFRAVcBkAMjATMEAAJBAUABbgL7AfQC/wHMAUIB/wH+AcsBQQH/AewB0gGGAf8C2gHJAf8C2AHH + Af8C3gHQAf8C1AHDAf8C0wHCAf8C2gHMAf8CzwG+Af8CzgG9Af8CzQG8Af8C+wH0Af8CQQFAAW4CRwFA + AW4C+wH0Af8B7AGGAWMB/wHiAXsBWQH/AdQBbgFMAf8BxAFgAT4B/wG2AVIBMAH/Aa0BRwElAf8BqwFD + ASEB/wGxAUQBIgH/Ab0BSgEoAf8BzAFSATAB/wHbAVoBOAH/AegBYgFAAf8C+wH0Af8CRwFAAW4CQQFA + AW4C+wH0Av8BzAFCAf8B/gHLAUEB/wHsAdIBhgH/AtoByQH/AtgBxwH/AbIBTAEqAf8B3gG2AZ4B/wHe + AbUBnQH/AbIBTAEqAf8CzwG+Af8CzgG9Af8CzQG8Af8C+wH0Af8CQQFAAW4IAAFDAU8BVQGNAaMB6AH7 + Af8BnQHjAfkB/wGdAeMB+QH/AaMB6AH7Af8BMwGUAcUB/wGFAcIB4QH/AYUBwgHhAf8BlAHYAfoB/wGU + AdgB+gH/AZsB3wH8Af8BQwFPAVUBjQgAAkABPwFtAvwB9wL/AcwBQgL/Ae4BiAH/AewB0gGGAf8C/AH6 + Af8C/AH6Af8C1gHFAf8C/AH6Af8C/AH6Af8C0QHAAf8C/AH6Af8C/AH6Af8CzQG8Af8C/AH3Af8CQAE/ + AW0CRwFAAW0C/AH3Av8BzAFDAv8B7gGIAf8B7AHSAYYB/wL8AfoB/wL8AfoB/wLWAcUB/wL8AfoB/wL8 + AfoB/wLRAcAB/wL8AfoB/wL8AfoB/wLNAbwB/wL8AfcB/wJHAUABbQJAAT8BbQL8AfcC/wHMAUIC/wHu + AYgB/wHsAdIBhgH/AvwB+gH/AvwB+gH/AcABWgE4Af8B9gHOAb8B/wH2Ac4BvwH/AcABWgE4Af8C/AH6 + Af8C/AH6Af8CzQG8Af8C/AH3Af8CQAE/AW0IAAFDAU8BVAGKAaYB6wH8Af8BoQHmAfsB/wGhAeYB+wH/ + AaYB6wH8Af8BOgGdAc8B/wGHAcQB4gH/AYcBxAHiAf8BlgHaAfwB/wGWAdoB/AH/AZ4B4gH9Af8BQwFP + AVQBiggAAj8BPgFrAv0B+QL/AcwBQgH/Af4BywFBAf8B9QHOAWIB/wHrAdIBhQH/AekB0AGDAf8B5wHO + AYEB/wHlAcwBgAH/AeQBywF8Af8B4gHJAXoB/wHgAccBeAH/Ad8BxgF3Af8B3gHFAXYB/wL9AfkB/wI/ + AT4BawJHAUABawL9AfkC/wHMAUMB/wH+AcsBQgH/AfUBzgFjAf8B6wHSAYUB/wHpAdABgwH/AecBzgGB + Af8B5QHMAYAB/wHkAcsBfQH/AeIByQF7Af8B4AHHAXkB/wHfAcYBeAH/Ad4BxQF3Af8C/QH5Af8CRwFA + AWsCPwE+AWsC/QH5Av8BzAFCAf8B/gHLAUEB/wH1Ac4BYgH/AesB0gGFAf8B6QHQAYMB/wHRAWoBSAH/ + AekBsQF0Af8B6AGwAXMB/wHRAWoBSAH/AeABxwF4Af8B3wHGAXcB/wHeAcUBdgH/Av0B+QH/Aj8BPgFr + CAABQgFNAVIBhwGpAe4B/QH/AaQB6QH8Af8BpAHpAfwB/wGqAe8B/QH/AUABoQHRAf8BkAHRAfEB/wGW + AdoB+wH/AZcB2wH9Af8BlwHbAf0B/wGfAeMB/gH/AUIBTQFSAYcIAAI/AT4BagL+AfwC/wHMAUIC/wHu + AYgB/wH9AcoBQAH/AfwB6wGFAf8B+wHqAYQB/wH4AcUBOwH/AfYB5QF9Af8B9AHjAXsB/wHzAcABNgH/ + AfEB4AF4Af8B7wHeAXYB/wHvAbwBMgH/Av4B/AH/Aj8BPgFqAkcBQAFqAv4B/AL/AcwBQwL/Ae4BiAH/ + Af0BygFBAf8B/AHrAYUB/wH7AeoBhAH/AfgBxQE8Af8B9gHlAX4B/wH0AeMBfAH/AfMBwAE3Af8B8QHg + AXkB/wHvAd4BdwH/Ae8BvAEzAf8C/gH8Af8CRwFAAWoCPwE+AWoC/gH8Av8BzAFCAv8B7gGIAf8B/QHK + AUAB/wH8AesBhQH/AfsB6gGEAf8B4QF5AVcB/wHzAcABcwH/AfIBvwFyAf8B4QF5AVcB/wHxAeABeAH/ + Ae8B3gF2Af8B7wG8ATIB/wL+AfwB/wI/AT4BaggAAUMBTAFSAYUBrQHxAv8BqwHvAf4B/wGVAeIB+AH/ + AWwByQHtAf8BRgGpAdkB/wGYAdwB/gH/AZgB3AH+Af8BmAHcAf4B/wGYAdwB/gH/AaEB5QL/AUMBTAFS + AYUIAAI+AT0BaAL/Af4C/wHMAUIB/wH+AcsBQQH/Af0BygFAAf8B/AHJAT8B/wH6AccBPQH/AfgBxQE7 + Af8B9gHDAToB/wH1AcIBOAH/AfMBwAE2Af8B8QG+ATQB/wHwAb0BMwH/Ae8BvAEyA/8B/gH/Aj4BPQFo + AkcBQAFoAv8B/gL/AcwBQwH/Af4BywFCAf8B/QHKAUEB/wH8AckBQAH/AfoBxwE+Af8B+AHFATwB/wH2 + AcMBOwH/AfUBwgE5Af8B8wHAATcB/wHxAb4BNQH/AfABvQE0Af8B7wG8ATMD/wH+Af8CRwFAAWgCPgE9 + AWgC/wH+Av8BzAFCAf8B/gHLAUEB/wH9AcoBQAH/AfwByQE/Af8B+gHHAT0B/wHsAYYBYgH/AewBhgFi + Af8B7AGGAWIB/wHsAYYBYgH/AfEBvgE0Af8B8AG9ATMB/wHvAbwBMgP/Af4B/wI+AT0BaAgAAUMBTAFQ + AYMBiAHcAfQB/wFeAcAB6QH/AV0BvwHqAf8BgAHTAfQB/wGcAeMB/QH/AaIB5gL/AaIB5gL/AaIB5gL/ + AaIB5gL/AaYB6gL/AUMBTAFQAYMIAAI+AT0BZzj/Aj4BPQFnAkcBQAFnOP8CRwFAAWcCPgE9AWc4/wI+ + AT0BZwgAATkBOwE9AWEBQgFLAU8BgQFCAUsBTwGBAUIBSwFPAYEBQgFLAU8BgQFCAUsBTwGBAUIBSwFP + AYEBQgFLAU8BgQFCAUsBTwGBAUIBSwFPAYEBQgFLAU8BgQE5ATsBPQFhCAADMQFNAj4BPQFmAj4BPQFm + Aj4BPQFmAj4BPQFmAj4BPQFmAj4BPQFmAj4BPQFmAj4BPQFmAj4BPQFmAj4BPQFmAj4BPQFmAj4BPQFm + Aj4BPQFmAj4BPQFmAzEBTQI3ATQBTQJHAUABZgJHAUABZgJHAUABZgJHAUABZgJHAUABZgJHAUABZgJH + AUABZgJHAUABZgJHAUABZgJHAUABZgJHAUABZgJHAUABZgJHAUABZgJHAUABZgI3ATQBTQMxAU0CPgE9 + AWYCPgE9AWYCPgE9AWYCPgE9AWYCPgE9AWYCPgE9AWYCPgE9AWYCPgE9AWYCPgE9AWYCPgE9AWYCPgE9 + AWYCPgE9AWYCPgE9AWYCPgE9AWYDMQFNAUIBTQE+BwABPgMAASgDAAFAAwABIAMAAQEBAAEBBgABARYA + A/8RAAGAAf8BgAEBBQABfwEAAQEFAAE/AQABAQUAAR8BAAEBBAABgAEPAYABAQQAAcABBwHAAQMEAAHg + AQMB4AEDBAAB8AEBAfABAQQAAfgBAAH4BQAB/AEAAfwFAAH+AQgB/gEIBAAB/wEAAf8FAAH/AYAB/wGA + BAAB/wHAAf8BwAQAAfgBfwYAAeABPxYAAcABAQYAAcABAQYAAcABAQYAAcABAQYAAcABAQYAAcABAQYA + AcABAwYAAcABAwYAAcABAwYAAcABAwYAAcABAwYAAcABAwYACw== +</value> + </data> + <metadata name="toolStripMain.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"> + <value>211, 17</value> + </metadata> + <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" /> + <data name="toolbuttonOpenMib.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64"> + <value> + iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8 + YQUAAAAJcEhZcwAADsIAAA7CARUoSoAAAAK6SURBVDhPjZNbSNNRHMfPU9DtwR71oZf5IgkF0YMEEYb2 + EGgG5YNgGQmGSUoYimbel5KKmlM0u3jJSpv3ad7WnGkzb2yO4bByF3WuuTnnnLv47Zw/9YclQQc+/L// + P+d8/r/f+Z8/Ib/HjJDcmhaS3P+Bzf2zjr8qiki+QyuE6dNNbIzFw6F8DJ++AVh97c9GK9jcA4LJAlKI + rQ7sW9/DpauGZSoFg6JwfJSU+TE0XIXOgqCaAwJ5ASn2bb6F19TM4bO+w4z4HgwWC9YcDugpK3Y7umQy + FOZEDMRkZQX7SWS5pMRrboVn9RUHy1/aEqDSajGn0WDZbIZ6bQ0t/f1gIzojI8lPMvaIPPWsN2FP/5yD + ZdmLWLwUi/FhZASSqSlOUtXczBMcGZnFVzGUTSr2jI1wfq/lYHms4Tqkc3MYnZ2F0mDAqs3GV8LaiUhN + TeYFA5mkenelHg5tNQfLw3UxaOrpQZdUiu7xca5/Mc0do6PQb28jPDk5hRf0PiQi5zcR7JoKDpYHaqIg + VyohW1jg+lcZjVwlCzod1p1OXEhMvM8LOtNJvWOpEjZVKQfL/ZVX0NrXh165HP2Tk5hQqzGuUmFQocCm + y4XzCQlpvKA9jTTa1WWwzBdzsNxdfhmfFxcxQRct0Q3UmEzY2t2FdWcHdrcb5+LiHvCC1hTSbFOWwDyT + x8GyuDQCbRIJ3tBPp6CfU0pbcdA3M4mDCs7ExqYzwWHKibo7pNs6T4+yIofDSqtof3IJBtqzTq+Hx+uF + y+OBky5kkh2aT0VFZTNBAEWQFEFqhyvO2pclSe6f03nYnC1EW9FFGOnGGSi+/X14KW6fD3tUtkdzYFiY + 0O801iWSaNFtUteWGST92nL1R/q1Q7ojAkHV0ZCQkuOhocV/c0wguHvgn2APyuPJ6dI4kpV/gzyjtycp + gf8g4Begs1B6Kbj3cQAAAABJRU5ErkJggg== +</value> + </data> + <metadata name="dialogOpenMib.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"> + <value>337, 17</value> + </metadata> +</root> \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/MibViewer/MibViewer.csproj b/contrib/apps/LwipMibCompiler/MibViewer/MibViewer.csproj new file mode 100644 index 00000000000..957c058c45d --- /dev/null +++ b/contrib/apps/LwipMibCompiler/MibViewer/MibViewer.csproj @@ -0,0 +1,94 @@ +<?xml version="1.0" encoding="utf-8"?> +<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003"> + <PropertyGroup> + <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration> + <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform> + <ProductVersion>8.0.30703</ProductVersion> + <SchemaVersion>2.0</SchemaVersion> + <ProjectGuid>{86CC0B65-7985-4017-A252-0A7A18DCAEF3}</ProjectGuid> + <OutputType>WinExe</OutputType> + <AppDesignerFolder>Properties</AppDesignerFolder> + <RootNamespace>LwipMibViewer</RootNamespace> + <AssemblyName>MibViewer</AssemblyName> + <TargetFrameworkVersion>v4.0</TargetFrameworkVersion> + <FileAlignment>512</FileAlignment> + <TargetFrameworkProfile /> + </PropertyGroup> + <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Debug|AnyCPU'"> + <DebugSymbols>true</DebugSymbols> + <OutputPath>bin\Debug</OutputPath> + <DefineConstants>DEBUG;TRACE</DefineConstants> + <DebugType>full</DebugType> + <ErrorReport>prompt</ErrorReport> + <CodeAnalysisIgnoreBuiltInRuleSets>true</CodeAnalysisIgnoreBuiltInRuleSets> + <CodeAnalysisIgnoreBuiltInRules>true</CodeAnalysisIgnoreBuiltInRules> + <WarningLevel>4</WarningLevel> + <Optimize>false</Optimize> + <UseVSHostingProcess>false</UseVSHostingProcess> + </PropertyGroup> + <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Release|AnyCPU'"> + <OutputPath>bin\Release</OutputPath> + <DefineConstants>TRACE</DefineConstants> + <Optimize>true</Optimize> + <DebugType>pdbonly</DebugType> + <PlatformTarget>AnyCPU</PlatformTarget> + <ErrorReport>prompt</ErrorReport> + <CodeAnalysisIgnoreBuiltInRuleSets>true</CodeAnalysisIgnoreBuiltInRuleSets> + <CodeAnalysisIgnoreBuiltInRules>true</CodeAnalysisIgnoreBuiltInRules> + <WarningLevel>4</WarningLevel> + <UseVSHostingProcess>false</UseVSHostingProcess> + </PropertyGroup> + <ItemGroup> + <Reference Include="System" /> + <Reference Include="System.Drawing" /> + <Reference Include="System.Windows.Forms" /> + </ItemGroup> + <ItemGroup> + <Compile Include="FormMain.cs"> + <SubType>Form</SubType> + </Compile> + <Compile Include="FormMain.Designer.cs"> + <DependentUpon>FormMain.cs</DependentUpon> + </Compile> + <Compile Include="Program.cs" /> + <Compile Include="Properties\AssemblyInfo.cs" /> + <EmbeddedResource Include="FormMain.resx"> + <DependentUpon>FormMain.cs</DependentUpon> + </EmbeddedResource> + <EmbeddedResource Include="Properties\Resources.resx"> + <Generator>ResXFileCodeGenerator</Generator> + <LastGenOutput>Resources.Designer.cs</LastGenOutput> + <SubType>Designer</SubType> + </EmbeddedResource> + <Compile Include="Properties\Resources.Designer.cs"> + <AutoGen>True</AutoGen> + <DependentUpon>Resources.resx</DependentUpon> + <DesignTime>True</DesignTime> + </Compile> + <None Include="app.config" /> + <None Include="Properties\Settings.settings"> + <Generator>SettingsSingleFileGenerator</Generator> + <LastGenOutput>Settings.Designer.cs</LastGenOutput> + </None> + <Compile Include="Properties\Settings.Designer.cs"> + <AutoGen>True</AutoGen> + <DependentUpon>Settings.settings</DependentUpon> + <DesignTimeSharedInput>True</DesignTimeSharedInput> + </Compile> + </ItemGroup> + <ItemGroup> + <ProjectReference Include="..\SharpSnmpLib\SharpSnmpLib.Mib.csproj"> + <Project>{CBE20411-5DB7-487D-825D-7694267BB6F5}</Project> + <Name>SharpSnmpLib.Mib</Name> + </ProjectReference> + </ItemGroup> + <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" /> + <PropertyGroup /> + <!-- To modify your build process, add your task inside one of the targets below and uncomment it. + Other similar extension points exist, see Microsoft.Common.targets. + <Target Name="BeforeBuild"> + </Target> + <Target Name="AfterBuild"> + </Target> + --> +</Project> \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/MibViewer/Program.cs b/contrib/apps/LwipMibCompiler/MibViewer/Program.cs new file mode 100644 index 00000000000..cd3ef314da2 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/MibViewer/Program.cs @@ -0,0 +1,51 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Martin Hentschel info@cl-soft.de + * + */ + +using System; +using System.Windows.Forms; + +namespace LwipMibViewer +{ + static class Program + { + /// <summary> + /// Der Haupteinstiegspunkt für die Anwendung. + /// </summary> + [STAThread] + static void Main() + { + Application.EnableVisualStyles(); + Application.SetCompatibleTextRenderingDefault(false); + Application.Run(new FormMain()); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/MibViewer/Properties/AssemblyInfo.cs b/contrib/apps/LwipMibCompiler/MibViewer/Properties/AssemblyInfo.cs new file mode 100644 index 00000000000..06e7286c0cc --- /dev/null +++ b/contrib/apps/LwipMibCompiler/MibViewer/Properties/AssemblyInfo.cs @@ -0,0 +1,36 @@ +using System.Reflection; +using System.Runtime.CompilerServices; +using System.Runtime.InteropServices; + +// Allgemeine Informationen über eine Assembly werden über die folgenden +// Attribute gesteuert. Ändern Sie diese Attributwerte, um die Informationen zu ändern, +// die mit einer Assembly verknüpft sind. +[assembly: AssemblyTitle("LwipMibViewer")] +[assembly: AssemblyDescription("")] +[assembly: AssemblyConfiguration("")] +[assembly: AssemblyCompany("")] +[assembly: AssemblyProduct("LwipMibViewer")] +[assembly: AssemblyCopyright("Copyright © 2015")] +[assembly: AssemblyTrademark("")] +[assembly: AssemblyCulture("")] + +// Durch Festlegen von ComVisible auf "false" werden die Typen in dieser Assembly unsichtbar +// für COM-Komponenten. Wenn Sie auf einen Typ in dieser Assembly von +// COM zugreifen müssen, legen Sie das ComVisible-Attribut für diesen Typ auf "true" fest. +[assembly: ComVisible(false)] + +// Die folgende GUID bestimmt die ID der Typbibliothek, wenn dieses Projekt für COM verfügbar gemacht wird +[assembly: Guid("7ffbd1c1-1c64-45bb-b243-2400446c649d")] + +// Versionsinformationen für eine Assembly bestehen aus den folgenden vier Werten: +// +// Hauptversion +// Nebenversion +// Buildnummer +// Revision +// +// Sie können alle Werte angeben oder die standardmäßigen Build- und Revisionsnummern +// übernehmen, indem Sie "*" eingeben: +// [assembly: AssemblyVersion("1.0.*")] +[assembly: AssemblyVersion("1.0.0.0")] +[assembly: AssemblyFileVersion("1.0.0.0")] diff --git a/contrib/apps/LwipMibCompiler/MibViewer/Properties/Resources.Designer.cs b/contrib/apps/LwipMibCompiler/MibViewer/Properties/Resources.Designer.cs new file mode 100644 index 00000000000..bf1571774d2 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/MibViewer/Properties/Resources.Designer.cs @@ -0,0 +1,63 @@ +//------------------------------------------------------------------------------ +// <auto-generated> +// Dieser Code wurde von einem Tool generiert. +// Laufzeitversion:4.0.30319.225 +// +// Änderungen an dieser Datei können falsches Verhalten verursachen und gehen verloren, wenn +// der Code erneut generiert wird. +// </auto-generated> +//------------------------------------------------------------------------------ + +namespace LwipMibViewer.Properties { + using System; + + + /// <summary> + /// Eine stark typisierte Ressourcenklasse zum Suchen von lokalisierten Zeichenfolgen usw. + /// </summary> + // Diese Klasse wurde von der StronglyTypedResourceBuilder automatisch generiert + // -Klasse über ein Tool wie ResGen oder Visual Studio automatisch generiert. + // Um einen Member hinzuzufügen oder zu entfernen, bearbeiten Sie die .ResX-Datei und führen dann ResGen + // mit der /str-Option erneut aus, oder Sie erstellen Ihr VS-Projekt neu. + [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "4.0.0.0")] + [global::System.Diagnostics.DebuggerNonUserCodeAttribute()] + [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()] + internal class Resources { + + private static global::System.Resources.ResourceManager resourceMan; + + private static global::System.Globalization.CultureInfo resourceCulture; + + [global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")] + internal Resources() { + } + + /// <summary> + /// Gibt die zwischengespeicherte ResourceManager-Instanz zurück, die von dieser Klasse verwendet wird. + /// </summary> + [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)] + internal static global::System.Resources.ResourceManager ResourceManager { + get { + if (object.ReferenceEquals(resourceMan, null)) { + global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("LwipMibViewer.Properties.Resources", typeof(Resources).Assembly); + resourceMan = temp; + } + return resourceMan; + } + } + + /// <summary> + /// Überschreibt die CurrentUICulture-Eigenschaft des aktuellen Threads für alle + /// Ressourcenzuordnungen, die diese stark typisierte Ressourcenklasse verwenden. + /// </summary> + [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)] + internal static global::System.Globalization.CultureInfo Culture { + get { + return resourceCulture; + } + set { + resourceCulture = value; + } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/MibViewer/Properties/Resources.resx b/contrib/apps/LwipMibCompiler/MibViewer/Properties/Resources.resx new file mode 100644 index 00000000000..af7dbebbace --- /dev/null +++ b/contrib/apps/LwipMibCompiler/MibViewer/Properties/Resources.resx @@ -0,0 +1,117 @@ +<?xml version="1.0" encoding="utf-8"?> +<root> + <!-- + Microsoft ResX Schema + + Version 2.0 + + The primary goals of this format is to allow a simple XML format + that is mostly human readable. The generation and parsing of the + various data types are done through the TypeConverter classes + associated with the data types. + + Example: + + ... ado.net/XML headers & schema ... + <resheader name="resmimetype">text/microsoft-resx</resheader> + <resheader name="version">2.0</resheader> + <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader> + <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader> + <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data> + <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data> + <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64"> + <value>[base64 mime encoded serialized .NET Framework object]</value> + </data> + <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64"> + <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value> + <comment>This is a comment</comment> + </data> + + There are any number of "resheader" rows that contain simple + name/value pairs. + + Each data row contains a name, and value. The row also contains a + type or mimetype. Type corresponds to a .NET class that support + text/value conversion through the TypeConverter architecture. + Classes that don't support this are serialized and stored with the + mimetype set. + + The mimetype is used for serialized objects, and tells the + ResXResourceReader how to depersist the object. This is currently not + extensible. For a given mimetype the value must be set accordingly: + + Note - application/x-microsoft.net.object.binary.base64 is the format + that the ResXResourceWriter will generate, however the reader can + read any of the formats listed below. + + mimetype: application/x-microsoft.net.object.binary.base64 + value : The object must be serialized with + : System.Serialization.Formatters.Binary.BinaryFormatter + : and then encoded with base64 encoding. + + mimetype: application/x-microsoft.net.object.soap.base64 + value : The object must be serialized with + : System.Runtime.Serialization.Formatters.Soap.SoapFormatter + : and then encoded with base64 encoding. + + mimetype: application/x-microsoft.net.object.bytearray.base64 + value : The object must be serialized into a byte array + : using a System.ComponentModel.TypeConverter + : and then encoded with base64 encoding. + --> + <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata"> + <xsd:element name="root" msdata:IsDataSet="true"> + xsd:complexType + <xsd:choice maxOccurs="unbounded"> + <xsd:element name="metadata"> + xsd:complexType + xsd:sequence + <xsd:element name="value" type="xsd:string" minOccurs="0" /> + </xsd:sequence> + <xsd:attribute name="name" type="xsd:string" /> + <xsd:attribute name="type" type="xsd:string" /> + <xsd:attribute name="mimetype" type="xsd:string" /> + </xsd:complexType> + </xsd:element> + <xsd:element name="assembly"> + xsd:complexType + <xsd:attribute name="alias" type="xsd:string" /> + <xsd:attribute name="name" type="xsd:string" /> + </xsd:complexType> + </xsd:element> + <xsd:element name="data"> + xsd:complexType + xsd:sequence + <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" /> + <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" /> + </xsd:sequence> + <xsd:attribute name="name" type="xsd:string" msdata:Ordinal="1" /> + <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" /> + <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" /> + </xsd:complexType> + </xsd:element> + <xsd:element name="resheader"> + xsd:complexType + xsd:sequence + <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" /> + </xsd:sequence> + <xsd:attribute name="name" type="xsd:string" use="required" /> + </xsd:complexType> + </xsd:element> + </xsd:choice> + </xsd:complexType> + </xsd:element> + </xsd:schema> + <resheader name="resmimetype"> + <value>text/microsoft-resx</value> + </resheader> + <resheader name="version"> + <value>2.0</value> + </resheader> + <resheader name="reader"> + <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value> + </resheader> + <resheader name="writer"> + <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value> + </resheader> +</root> \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/MibViewer/Properties/Settings.Designer.cs b/contrib/apps/LwipMibCompiler/MibViewer/Properties/Settings.Designer.cs new file mode 100644 index 00000000000..9831b20f0be --- /dev/null +++ b/contrib/apps/LwipMibCompiler/MibViewer/Properties/Settings.Designer.cs @@ -0,0 +1,26 @@ +//------------------------------------------------------------------------------ +// <auto-generated> +// Dieser Code wurde von einem Tool generiert. +// Laufzeitversion:4.0.30319.225 +// +// Änderungen an dieser Datei können falsches Verhalten verursachen und gehen verloren, wenn +// der Code erneut generiert wird. +// </auto-generated> +//------------------------------------------------------------------------------ + +namespace LwipMibViewer.Properties { + + + [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()] + [global::System.CodeDom.Compiler.GeneratedCodeAttribute("Microsoft.VisualStudio.Editors.SettingsDesigner.SettingsSingleFileGenerator", "10.0.0.0")] + internal sealed partial class Settings : global::System.Configuration.ApplicationSettingsBase { + + private static Settings defaultInstance = ((Settings)(global::System.Configuration.ApplicationSettingsBase.Synchronized(new Settings()))); + + public static Settings Default { + get { + return defaultInstance; + } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/MibViewer/Properties/Settings.settings b/contrib/apps/LwipMibCompiler/MibViewer/Properties/Settings.settings new file mode 100644 index 00000000000..39645652af6 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/MibViewer/Properties/Settings.settings @@ -0,0 +1,7 @@ +<?xml version='1.0' encoding='utf-8'?> +<SettingsFile xmlns="http://schemas.microsoft.com/VisualStudio/2004/01/settings" CurrentProfile="(Default)"> + <Profiles> + <Profile Name="(Default)" /> + </Profiles> + <Settings /> +</SettingsFile> diff --git a/contrib/apps/LwipMibCompiler/MibViewer/app.config b/contrib/apps/LwipMibCompiler/MibViewer/app.config new file mode 100644 index 00000000000..e3656033377 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/MibViewer/app.config @@ -0,0 +1,3 @@ +<?xml version="1.0"?> +<configuration> +<startup><supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0"/></startup></configuration> diff --git a/contrib/apps/LwipMibCompiler/Mibs/IANA-ADDRESS-FAMILY-NUMBERS-MIB b/contrib/apps/LwipMibCompiler/Mibs/IANA-ADDRESS-FAMILY-NUMBERS-MIB new file mode 100644 index 00000000000..101079558b5 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/IANA-ADDRESS-FAMILY-NUMBERS-MIB @@ -0,0 +1,131 @@ + + + IANA-ADDRESS-FAMILY-NUMBERS-MIB DEFINITIONS ::= BEGIN + + IMPORTS + MODULE-IDENTITY, + mib-2 FROM SNMPv2-SMI + TEXTUAL-CONVENTION FROM SNMPv2-TC; + + ianaAddressFamilyNumbers MODULE-IDENTITY + LAST-UPDATED "200203140000Z" -- March 14, 2002 + ORGANIZATION "IANA" + CONTACT-INFO + "Postal: Internet Assigned Numbers Authority + Internet Corporation for Assigned Names + and Numbers + 4676 Admiralty Way, Suite 330 + Marina del Rey, CA 90292-6601 + USA + + Tel: +1 310-823-9358 + E-Mail: iana&iana.org" + DESCRIPTION + "The MIB module defines the AddressFamilyNumbers + textual convention." + + -- revision history + + REVISION "200203140000Z" -- March 14, 2002 + DESCRIPTION "AddressFamilyNumbers assignment 22 to + fibreChannelWWPN. AddressFamilyNumbers + assignment 23 to fibreChannelWWNN. + AddressFamilyNumers assignment 24 to gwid." + + REVISION "200009080000Z" -- September 8, 2000 + DESCRIPTION "AddressFamilyNumbers assignment 19 to xtpOverIpv4. + AddressFamilyNumbers assignment 20 to xtpOverIpv6. + AddressFamilyNumbers assignment 21 to xtpNativeModeXTP." + + REVISION "200003010000Z" -- March 1, 2000 + DESCRIPTION "AddressFamilyNumbers assignment 17 to distinguishedName. + AddressFamilyNumbers assignment 18 to asNumber." + + REVISION "200002040000Z" -- February 4, 2000 + DESCRIPTION "AddressFamilyNumbers assignment 16 to dns." + + REVISION "9908260000Z" -- August 26, 1999 + DESCRIPTION "Initial version, published as RFC 2677." + + ::= { mib-2 72 } + + + AddressFamilyNumbers ::= TEXTUAL-CONVENTION + + STATUS current + DESCRIPTION + "The definition of this textual convention with the + addition of newly assigned values is published + periodically by the IANA, in either the Assigned + Numbers RFC, or some derivative of it specific to + Internet Network Management number assignments. + (The latest arrangements can be obtained by + contacting the IANA.) + + The enumerations are described as: + + other(0), -- none of the following + ipV4(1), -- IP Version 4 + ipV6(2), -- IP Version 6 + nsap(3), -- NSAP + hdlc(4), -- (8-bit multidrop) + bbn1822(5), + all802(6), -- (includes all 802 media + -- plus Ethernet 'canonical format') + e163(7), + e164(8), -- (SMDS, Frame Relay, ATM) + f69(9), -- (Telex) + x121(10), -- (X.25, Frame Relay) + ipx(11), -- IPX (Internet Protocol Exchange) + appleTalk(12), -- Apple Talk + decnetIV(13), -- DEC Net Phase IV + banyanVines(14), -- Banyan Vines + e164withNsap(15), + -- (E.164 with NSAP format subaddress) + dns(16), -- (Domain Name System) + distinguishedName(17), -- (Distinguished Name, per X.500) + asNumber(18), -- (16-bit quantity, per the AS number space) + xtpOverIpv4(19), -- XTP over IP version 4 + xtpOverIpv6(20), -- XTP over IP version 6 + xtpNativeModeXTP(21), -- XTP native mode XTP + fibreChannelWWPN(22), -- Fibre Channel World-Wide Port Name + fibreChannelWWNN(23), -- Fibre Channel World-Wide Node Name + gwid(24), -- Gateway Identifier + afi(25), -- AFI for L2VPN information + reserved(65535) + + + + Requests for new values should be made to IANA via + email (iana&iana.org)." + + SYNTAX INTEGER { + other(0), + ipV4(1), + ipV6(2), + nsap(3), + hdlc(4), + bbn1822(5), + all802(6), + e163(7), + e164(8), + f69(9), + x121(10), + ipx(11), + appleTalk(12), + decnetIV(13), + banyanVines(14), + e164withNsap(15), + dns(16), + distinguishedName(17), -- (Distinguished Name, per X.500) + asNumber(18), -- (16-bit quantity, per the AS number space) + xtpOverIpv4(19), + xtpOverIpv6(20), + xtpNativeModeXTP(21), + fibreChannelWWPN(22), + fibreChannelWWNN(23), + gwid(24), + afi(25), + reserved(65535) + } + END diff --git a/contrib/apps/LwipMibCompiler/Mibs/IANA-CHARSET-MIB b/contrib/apps/LwipMibCompiler/Mibs/IANA-CHARSET-MIB new file mode 100644 index 00000000000..499d54e4c2d --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/IANA-CHARSET-MIB @@ -0,0 +1,345 @@ +IANA-CHARSET-MIB DEFINITIONS ::= BEGIN +-- http://www.iana.org/assignments/ianacharset-mib + +IMPORTS + MODULE-IDENTITY, + mib-2 + FROM SNMPv2-SMI -- [RFC2578] + TEXTUAL-CONVENTION + FROM SNMPv2-TC; -- [RFC2579] + +ianaCharsetMIB MODULE-IDENTITY + LAST-UPDATED "200705140000Z" + ORGANIZATION "IANA" + CONTACT-INFO " Internet Assigned Numbers Authority + + Postal: ICANN + 4676 Admiralty Way, Suite 330 + Marina del Rey, CA 90292 + + Tel: +1 310 823 9358 + E-Mail: iana&iana.org" + + DESCRIPTION "This MIB module defines the IANACharset + TEXTUAL-CONVENTION. The IANACharset TC is used to + specify the encoding of string objects defined in + a MIB. + + Each version of this MIB will be released based on + the IANA Charset Registry file (see RFC 2978) at + http://www.iana.org/assignments/character-sets. + + Note: The IANACharset TC, originally defined in + RFC 1759, was inaccurately named CodedCharSet. + + Note: Best practice is to define new MIB string + objects with invariant UTF-8 (RFC 3629) syntax + using the SnmpAdminString TC (defined in RFC 3411) + in accordance with IETF Policy on Character Sets and + Languages (RFC 2277). + + Copyright (C) The Internet Society (2004). The + initial version of this MIB module was published + in RFC 3808; for full legal notices see the RFC + itself. Supplementary information may be + available on + http://www.ietf.org/copyrights/ianamib.html." + + -- revision history + + REVISION "200705140000Z" + DESCRIPTION "Registration of new charset 2107." + + REVISION "200612070000Z" + DESCRIPTION "Registration of new charsets numbered 118, 119, + and 2106." + + REVISION "200406080000Z" + DESCRIPTION "Original version transferred from Printer MIB, + generated from the IANA maintained assignments + http://www.iana.org/assignments/character-sets." + + ::= { mib-2 106 } + +IANACharset ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "Specifies an IANA registered 'charset' - coded character set + (CCS) plus optional character encoding scheme (CES) - terms + defined in 'IANA Charset Registration Procedures' (RFC 2978). + + Objects of this syntax are used to specify the encoding for + string objects defined in one or more MIBs. For example, the + prtLocalizationCharacterSet, prtInterpreterDefaultCharSetIn, and + prtInterpreterDefaultCharSetOut objects defined in Printer MIB. + + The current list of 'charset' names and enumerated values + is contained in the IANA Character Set Registry at: + + http://www.iana.org/assignments/character-sets + + Enum names are derived from the IANA Charset Registry 'Alias' + fields that begin with 'cs' (for character set). + Enum values are derived from the parallel 'MIBenum' fields." + SYNTAX INTEGER { + other(1), -- used if the designated + -- character set is not currently + -- registered by IANA + unknown(2), -- used as a default value + csASCII(3), + csISOLatin1(4), + csISOLatin2(5), + csISOLatin3(6), + csISOLatin4(7), + csISOLatinCyrillic(8), + csISOLatinArabic(9), + csISOLatinGreek(10), + csISOLatinHebrew(11), + csISOLatin5(12), + csISOLatin6(13), + csISOTextComm(14), + csHalfWidthKatakana(15), + csJISEncoding(16), + csShiftJIS(17), + csEUCPkdFmtJapanese(18), + csEUCFixWidJapanese(19), + csISO4UnitedKingdom(20), + csISO11SwedishForNames(21), + csISO15Italian(22), + csISO17Spanish(23), + csISO21German(24), + csISO60DanishNorwegian(25), + csISO69French(26), + csISO10646UTF1(27), + csISO646basic1983(28), + csINVARIANT(29), + csISO2IntlRefVersion(30), + csNATSSEFI(31), + csNATSSEFIADD(32), + csNATSDANO(33), + csNATSDANOADD(34), + csISO10Swedish(35), + csKSC56011987(36), + csISO2022KR(37), + csEUCKR(38), + csISO2022JP(39), + csISO2022JP2(40), + csISO13JISC6220jp(41), + csISO14JISC6220ro(42), + csISO16Portuguese(43), + csISO18Greek7Old(44), + csISO19LatinGreek(45), + csISO25French(46), + csISO27LatinGreek1(47), + csISO5427Cyrillic(48), + csISO42JISC62261978(49), + csISO47BSViewdata(50), + csISO49INIS(51), + csISO50INIS8(52), + csISO51INISCyrillic(53), + csISO54271981(54), + csISO5428Greek(55), + csISO57GB1988(56), + csISO58GB231280(57), + csISO61Norwegian2(58), + csISO70VideotexSupp1(59), + csISO84Portuguese2(60), + csISO85Spanish2(61), + csISO86Hungarian(62), + csISO87JISX0208(63), + csISO88Greek7(64), + csISO89ASMO449(65), + csISO90(66), + csISO91JISC62291984a(67), + csISO92JISC62991984b(68), + csISO93JIS62291984badd(69), + csISO94JIS62291984hand(70), + csISO95JIS62291984handadd(71), + csISO96JISC62291984kana(72), + csISO2033(73), + csISO99NAPLPS(74), + csISO102T617bit(75), + csISO103T618bit(76), + csISO111ECMACyrillic(77), + csa71(78), + csa72(79), + csISO123CSAZ24341985gr(80), + csISO88596E(81), + csISO88596I(82), + csISO128T101G2(83), + csISO88598E(84), + csISO88598I(85), + csISO139CSN369103(86), + csISO141JUSIB1002(87), + csISO143IECP271(88), + csISO146Serbian(89), + csISO147Macedonian(90), + csISO150(91), + csISO151Cuba(92), + csISO6937Add(93), + csISO153GOST1976874(94), + csISO8859Supp(95), + csISO10367Box(96), + csISO158Lap(97), + csISO159JISX02121990(98), + csISO646Danish(99), + csUSDK(100), + csDKUS(101), + csKSC5636(102), + csUnicode11UTF7(103), + csISO2022CN(104), + csISO2022CNEXT(105), + csUTF8(106), + csISO885913(109), + csISO885914(110), + csISO885915(111), + csISO885916(112), + csGBK(113), + csGB18030(114), + csOSDEBCDICDF0415(115), + csOSDEBCDICDF03IRV(116), + csOSDEBCDICDF041(117), + csISO115481(118), + csKZ1048(119), + csUnicode(1000), + csUCS4(1001), + csUnicodeASCII(1002), + csUnicodeLatin1(1003), + csUnicodeIBM1261(1005), + csUnicodeIBM1268(1006), + csUnicodeIBM1276(1007), + csUnicodeIBM1264(1008), + csUnicodeIBM1265(1009), + csUnicode11(1010), + csSCSU(1011), + csUTF7(1012), + csUTF16BE(1013), + csUTF16LE(1014), + csUTF16(1015), + csCESU8(1016), + csUTF32(1017), + csUTF32BE(1018), + csUTF32LE(1019), + csBOCU1(1020), + csWindows30Latin1(2000), + csWindows31Latin1(2001), + csWindows31Latin2(2002), + csWindows31Latin5(2003), + csHPRoman8(2004), + csAdobeStandardEncoding(2005), + csVenturaUS(2006), + csVenturaInternational(2007), + csDECMCS(2008), + csPC850Multilingual(2009), + csPCp852(2010), + csPC8CodePage437(2011), + csPC8DanishNorwegian(2012), + csPC862LatinHebrew(2013), + csPC8Turkish(2014), + csIBMSymbols(2015), + csIBMThai(2016), + csHPLegal(2017), + csHPPiFont(2018), + csHPMath8(2019), + csHPPSMath(2020), + csHPDesktop(2021), + csVenturaMath(2022), + csMicrosoftPublishing(2023), + csWindows31J(2024), + csGB2312(2025), + csBig5(2026), + csMacintosh(2027), + csIBM037(2028), + csIBM038(2029), + csIBM273(2030), + csIBM274(2031), + csIBM275(2032), + csIBM277(2033), + csIBM278(2034), + csIBM280(2035), + csIBM281(2036), + csIBM284(2037), + csIBM285(2038), + csIBM290(2039), + csIBM297(2040), + csIBM420(2041), + csIBM423(2042), + csIBM424(2043), + csIBM500(2044), + csIBM851(2045), + csIBM855(2046), + csIBM857(2047), + csIBM860(2048), + csIBM861(2049), + csIBM863(2050), + csIBM864(2051), + csIBM865(2052), + csIBM868(2053), + csIBM869(2054), + csIBM870(2055), + csIBM871(2056), + csIBM880(2057), + csIBM891(2058), + csIBM903(2059), + csIBBM904(2060), + csIBM905(2061), + csIBM918(2062), + csIBM1026(2063), + csIBMEBCDICATDE(2064), + csEBCDICATDEA(2065), + csEBCDICCAFR(2066), + csEBCDICDKNO(2067), + csEBCDICDKNOA(2068), + csEBCDICFISE(2069), + csEBCDICFISEA(2070), + csEBCDICFR(2071), + csEBCDICIT(2072), + csEBCDICPT(2073), + csEBCDICES(2074), + csEBCDICESA(2075), + csEBCDICESS(2076), + csEBCDICUK(2077), + csEBCDICUS(2078), + csUnknown8BiT(2079), + csMnemonic(2080), + csMnem(2081), + csVISCII(2082), + csVIQR(2083), + csKOI8R(2084), + csHZGB2312(2085), + csIBM866(2086), + csPC775Baltic(2087), + csKOI8U(2088), + csIBM00858(2089), + csIBM00924(2090), + csIBM01140(2091), + csIBM01141(2092), + csIBM01142(2093), + csIBM01143(2094), + csIBM01144(2095), + csIBM01145(2096), + csIBM01146(2097), + csIBM01147(2098), + csIBM01148(2099), + csIBM01149(2100), + csBig5HKSCS(2101), + csIBM1047(2102), + csPTCP154(2103), + csAmiga1251(2104), + csKOI7switched(2105), + csBRF(2106), + csTSCII(2107), + cswindows1250(2250), + cswindows1251(2251), + cswindows1252(2252), + cswindows1253(2253), + cswindows1254(2254), + cswindows1255(2255), + cswindows1256(2256), + cswindows1257(2257), + cswindows1258(2258), + csTIS620(2259), + reserved(3000) + } +END + diff --git a/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-ITU-ALARM-TC-MIB b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-ITU-ALARM-TC-MIB new file mode 100644 index 00000000000..8579485cf70 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-ITU-ALARM-TC-MIB @@ -0,0 +1,333 @@ +IANA-ITU-ALARM-TC-MIB DEFINITIONS ::= BEGIN + + IMPORTS + MODULE-IDENTITY, mib-2 FROM SNMPv2-SMI + TEXTUAL-CONVENTION FROM SNMPv2-TC; + + ianaItuAlarmNumbers MODULE-IDENTITY + LAST-UPDATED "200409090000Z" -- September 09, 2004 + ORGANIZATION "IANA" + CONTACT-INFO + "Postal: Internet Assigned Numbers Authority + Internet Corporation for Assigned Names + and Numbers + 4676 Admiralty Way, Suite 330 + Marina del Rey, CA 90292-6601 + USA + + Tel: +1 310-823-9358 + E-Mail: iana&iana.org" + DESCRIPTION + "The MIB module defines the ITU Alarm + textual convention for objects expected to require + regular extension. + + Copyright (C) The Internet Society (2004). The + initial version of this MIB module was published + in RFC 3877. For full legal notices see the RFC + itself. Supplementary information may be available on: + http://www.ietf.org/copyrights/ianamib.html" + REVISION "200409090000Z" + DESCRIPTION + "Initial version, published as RFC 3877." + ::= { mib-2 119 } + + + IANAItuProbableCause ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "ITU-T probable cause values. Duplicate values defined in + X.733 are appended with X733 to ensure syntactic uniqueness. + Probable cause value 0 is reserved for special purposes. + + The Internet Assigned Number Authority (IANA) is responsible + for the assignment of the enumerations in this TC. + IANAItuProbableCause value of 0 is reserved for special + purposes and MUST NOT be assigned. + + Values of IANAItuProbableCause in the range 1 to 1023 are + reserved for causes that correspond to ITU-T probable cause. + + All other requests for new causes will be handled on a + first-come, first served basis and will be assigned + enumeration values starting with 1025. + + Request should come in the form of well-formed + SMI [RFC2578] for enumeration names that are unique and + sufficiently descriptive. + + While some effort will be taken to ensure that new probable + causes do not conceptually duplicate existing probable + causes it is acknowledged that the existence of conceptual + duplicates in the starting probable cause list is an known + industry reality. + + To aid IANA in the administration of probable cause names + and values, the OPS Area Director will appoint one or more + experts to help review requests. + + See http://www.iana.org" + REFERENCE + "ITU Recommendation M.3100, 'Generic Network Information + Model', 1995 + ITU Recommendation X.733, 'Information Technology - Open + Systems Interconnection - System Management: Alarm + Reporting Function', 1992 + ITU Recommendation X.736, 'Information Technology - Open + Systems Interconnection - System Management: Security + Alarm Reporting Function', 1992" + + SYNTAX INTEGER + { + -- The following probable causes were defined in M.3100 + aIS (1), + callSetUpFailure (2), + degradedSignal (3), + farEndReceiverFailure (4), + framingError (5), + lossOfFrame (6), + lossOfPointer (7), + lossOfSignal (8), + payloadTypeMismatch (9), + transmissionError (10), + remoteAlarmInterface (11), + excessiveBER (12), + pathTraceMismatch (13), + unavailable (14), + signalLabelMismatch (15), + lossOfMultiFrame (16), + receiveFailure (17), + transmitFailure (18), + modulationFailure (19), + demodulationFailure (20), + broadcastChannelFailure (21), + connectionEstablishmentError (22), + invalidMessageReceived (23), + localNodeTransmissionError (24), + remoteNodeTransmissionError (25), + routingFailure (26), + --Values 27-50 are reserved for communications alarm related + --probable causes + -- The following are used with equipment alarm. + backplaneFailure (51), + dataSetProblem (52), + equipmentIdentifierDuplication (53), + externalIFDeviceProblem (54), + lineCardProblem (55), + multiplexerProblem (56), + nEIdentifierDuplication (57), + powerProblem (58), + processorProblem (59), + protectionPathFailure (60), + receiverFailure (61), + replaceableUnitMissing (62), + replaceableUnitTypeMismatch (63), + synchronizationSourceMismatch (64), + terminalProblem (65), + timingProblem (66), + transmitterFailure (67), + trunkCardProblem (68), + replaceableUnitProblem (69), + realTimeClockFailure (70), + --An equipment alarm to be issued if the system detects that the + --real time clock has failed + antennaFailure (71), + batteryChargingFailure (72), + diskFailure (73), + frequencyHoppingFailure (74), + iODeviceError (75), + lossOfSynchronisation (76), + lossOfRedundancy (77), + powerSupplyFailure (78), + signalQualityEvaluationFailure (79), + tranceiverFailure (80), + protectionMechanismFailure (81), + protectingResourceFailure (82), + -- Values 83-100 are reserved for equipment alarm related probable + -- causes + -- The following are used with environmental alarm. + airCompressorFailure (101), + airConditioningFailure (102), + airDryerFailure (103), + batteryDischarging (104), + batteryFailure (105), + commercialPowerFailure (106), + coolingFanFailure (107), + engineFailure (108), + fireDetectorFailure (109), + fuseFailure (110), + generatorFailure (111), + lowBatteryThreshold (112), + pumpFailure (113), + rectifierFailure (114), + rectifierHighVoltage (115), + rectifierLowFVoltage (116), + ventilationsSystemFailure (117), + enclosureDoorOpen (118), + explosiveGas (119), + fire (120), + flood (121), + highHumidity (122), + highTemperature (123), + highWind (124), + iceBuildUp (125), + intrusionDetection (126), + lowFuel (127), + lowHumidity (128), + lowCablePressure (129), + lowTemperatue (130), + lowWater (131), + smoke (132), + toxicGas (133), + coolingSystemFailure (134), + externalEquipmentFailure (135), + externalPointFailure (136), + -- Values 137-150 are reserved for environmental alarm related + -- probable causes + -- The following are used with Processing error alarm. + storageCapacityProblem (151), + memoryMismatch (152), + corruptData (153), + outOfCPUCycles (154), + sfwrEnvironmentProblem (155), + sfwrDownloadFailure (156), + lossOfRealTimel (157), + --A processing error alarm to be issued after the system has + --reinitialised. This will indicate + --to the management systems that the view they have of the managed + --system may no longer + --be valid. Usage example: The managed + --system issues this alarm after a reinitialization with severity + --warning to inform the + --management system about the event. No clearing notification will + --be sent. + applicationSubsystemFailure (158), + configurationOrCustomisationError (159), + databaseInconsistency (160), + fileError (161), + outOfMemory (162), + softwareError (163), + timeoutExpired (164), + underlayingResourceUnavailable (165), + versionMismatch (166), + --Values 168-200 are reserved for processing error alarm related + -- probable causes. + bandwidthReduced (201), + congestion (202), + excessiveErrorRate (203), + excessiveResponseTime (204), + excessiveRetransmissionRate (205), + reducedLoggingCapability (206), + systemResourcesOverload (207 ), + -- The following were defined X.733 + adapterError (500), + applicationSubsystemFailture (501), + bandwidthReducedX733 (502), + callEstablishmentError (503), + communicationsProtocolError (504), + communicationsSubsystemFailure (505), + configurationOrCustomizationError (506), + congestionX733 (507), + coruptData (508), + cpuCyclesLimitExceeded (509), + dataSetOrModemError (510), + degradedSignalX733 (511), + dteDceInterfaceError (512), + enclosureDoorOpenX733 (513), + equipmentMalfunction (514), + excessiveVibration (515), + fileErrorX733 (516), + fireDetected (517), + framingErrorX733 (518), + heatingVentCoolingSystemProblem (519), + humidityUnacceptable (520), + inputOutputDeviceError (521), + inputDeviceError (522), + lanError (523), + leakDetected (524), + localNodeTransmissionErrorX733 (525), + lossOfFrameX733 (526), + lossOfSignalX733 (527), + materialSupplyExhausted (528), + multiplexerProblemX733 (529), + outOfMemoryX733 (530), + ouputDeviceError (531), + performanceDegraded (532), + powerProblems (533), + pressureUnacceptable (534), + processorProblems (535), + pumpFailureX733 (536), + queueSizeExceeded (537), + receiveFailureX733 (538), + receiverFailureX733 (539), + remoteNodeTransmissionErrorX733 (540), + resourceAtOrNearingCapacity (541), + responseTimeExecessive (542), + retransmissionRateExcessive (543), + softwareErrorX733 (544), + softwareProgramAbnormallyTerminated (545), + softwareProgramError (546), + storageCapacityProblemX733 (547), + temperatureUnacceptable (548), + thresholdCrossed (549), + timingProblemX733 (550), + toxicLeakDetected (551), + transmitFailureX733 (552), + transmiterFailure (553), + underlyingResourceUnavailable (554), + versionMismatchX733 (555), + -- The following are defined in X.736 + authenticationFailure (600), + breachOfConfidentiality (601), + cableTamper (602), + delayedInformation (603), + denialOfService (604), + duplicateInformation (605), + informationMissing (606), + informationModificationDetected (607), + informationOutOfSequence (608), + keyExpired (609), + nonRepudiationFailure (610), + outOfHoursActivity (611), + outOfService (612), + proceduralError (613), + unauthorizedAccessAttempt (614), + unexpectedInformation (615), + + other (1024) + } + + IANAItuEventType ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "The ITU event Type values. + + The Internet Assigned Number Authority (IANA) is + responsible for the assignment of the enumerations + in this TC. + + Request should come in the form of well-formed + SMI [RFC2578] for enumeration names that are unique + and sufficiently descriptive. + + See http://www.iana.org " + REFERENCE + "ITU Recommendation X.736, 'Information Technology - Open + Systems Interconnection - System Management: Security + Alarm Reporting Function', 1992" + SYNTAX INTEGER + { + other (1), + communicationsAlarm (2), + qualityOfServiceAlarm (3), + processingErrorAlarm (4), + equipmentAlarm (5), + environmentalAlarm (6), + integrityViolation (7), + operationalViolation (8), + physicalViolation (9), + securityServiceOrMechanismViolation (10), + timeDomainViolation (11) + } + + END diff --git a/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-LANGUAGE-MIB b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-LANGUAGE-MIB new file mode 100644 index 00000000000..6210f723f6f --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-LANGUAGE-MIB @@ -0,0 +1,127 @@ + + IANA-LANGUAGE-MIB DEFINITIONS ::= BEGIN + + IMPORTS + MODULE-IDENTITY, OBJECT-IDENTITY, mib-2 + FROM SNMPv2-SMI; + + ianaLanguages MODULE-IDENTITY + LAST-UPDATED "200005100000Z" -- May 10, 2000 + ORGANIZATION "IANA" + CONTACT-INFO + "Internet Assigned Numbers Authority (IANA) + + Postal: ICANN + 4676 Admiralty Way, Suite 330 + Marina del Rey, CA 90292 + + Tel: +1 310 823 9358 x20 + E-Mail: iana&iana.org" + DESCRIPTION + "The MIB module registers object identifier values for + well-known programming and scripting languages. Every + language registration MUST describe the format used + when transferring scripts written in this language. + + Any additions or changes to the contents of this MIB + module require Designated Expert Review as defined in + the Guidelines for Writing IANA Considerations Section + document. The Designated Expert will be selected by + the IESG Area Director of the OPS Area. + + Note, this module does not have to register all possible + languages since languages are identified by object + identifier values. It is therefore possible to registered + languages in private OID trees. The references given below are not + normative with regard to the language version. Other + references might be better suited to describe some newer + versions of this language. The references are only + provided as `a pointer into the right direction'." + + -- Revision log, in reverse chronological order + + REVISION "200005100000Z" -- May 10, 2000 + DESCRIPTION "Import mib-2 instead of experimental, so that + this module compiles" + + REVISION "199909090900Z" -- September 9, 1999 + DESCRIPTION "Initial version as published at time of + publication of RFC 2591." + + ::= { mib-2 73 } + + + ianaLangJavaByteCode OBJECT-IDENTITY + STATUS current + DESCRIPTION + "Java byte code to be processed by a Java virtual machine. + A script written in Java byte code is transferred by using + the Java archive file format (JAR)." + REFERENCE + "The Java Virtual Machine Specification. + ISBN 0-201-63452-X" + ::= { ianaLanguages 1 } + + ianaLangTcl OBJECT-IDENTITY + STATUS current + DESCRIPTION + "The Tool Command Language (Tcl). A script written in the + Tcl language is transferred in Tcl source code format." + REFERENCE + "Tcl and the Tk Toolkit. + ISBN 0-201-63337-X" + ::= { ianaLanguages 2 } + + ianaLangPerl OBJECT-IDENTITY + STATUS current + DESCRIPTION + "The Perl language. A script written in the Perl language + is transferred in Perl source code format." + REFERENCE + "Programming Perl. + ISBN 1-56592-149-6" + ::= { ianaLanguages 3 } + + ianaLangScheme OBJECT-IDENTITY + STATUS current + DESCRIPTION + "The Scheme language. A script written in the Scheme + language is transferred in Scheme source code format." + REFERENCE + "The Revised^4 Report on the Algorithmic Language Scheme. + MIT Press" + ::= { ianaLanguages 4 } + + ianaLangSRSL OBJECT-IDENTITY + STATUS current + DESCRIPTION + "The SNMP Script Language defined by SNMP Research. A + script written in the SNMP Script Language is transferred + in the SNMP Script Language source code format." + ::= { ianaLanguages 5 } + + ianaLangPSL OBJECT-IDENTITY + STATUS current + DESCRIPTION + "The Patrol Script Language defined by BMC Software. A script + written in the Patrol Script Language is transferred in the + Patrol Script Language source code format." + REFERENCE + "PATROL Script Language Reference Manual, Version 3.0, + November 30, 1995. BMC Software, Inc. 2101 City West Blvd., + Houston, Texas 77042." + ::= { ianaLanguages 6 } + + ianaLangSMSL OBJECT-IDENTITY + STATUS current + DESCRIPTION + "The Systems Management Scripting Language. A script written + in the SMSL language is transferred in the SMSL source code + format." + REFERENCE + "ISO/ITU Command Sequencer. + ISO 10164-21 or ITU X.753" + ::= { ianaLanguages 7 } + + END + diff --git a/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-MALLOC-MIB b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-MALLOC-MIB new file mode 100644 index 00000000000..5869a363dcb --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-MALLOC-MIB @@ -0,0 +1,67 @@ + +IANA-MALLOC-MIB DEFINITIONS ::= BEGIN + +IMPORTS + MODULE-IDENTITY, mib-2 FROM SNMPv2-SMI + TEXTUAL-CONVENTION FROM SNMPv2-TC; + +ianaMallocMIB MODULE-IDENTITY + LAST-UPDATED "200301271200Z" -- January 27, 2003 + ORGANIZATION "IANA" + CONTACT-INFO + " Internet Assigned Numbers Authority + Internet Corporation for Assigned Names and Numbers + 4676 Admiralty Way, Suite 330 + Marina del Rey, CA 90292-6601 + + Phone: +1 310 823 9358 + EMail: iana&iana.org" + DESCRIPTION + "This MIB module defines the IANAscopeSource and + IANAmallocRangeSource textual conventions for use in MIBs + which need to identify ways of learning multicast scope and + range information. + + Any additions or changes to the contents of this MIB module + require either publication of an RFC, or Designated Expert + Review as defined in the Guidelines for Writing IANA + Considerations Section document. The Designated Expert will + be selected by the IESG Area Director(s) of the Transport + Area." + + -- revision log + + REVISION "200301271200Z" -- January 27, 2003 + DESCRIPTION + "Initial version." + ::= { mib-2 102 } + +IANAscopeSource ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "The source of multicast scope information." + SYNTAX INTEGER { + other(1), -- none of the following + manual(2), -- statically configured + local(3), -- automatically added by the system, + -- such as a Source-Specific Multicast + -- scope + mzap(4), -- MZAP + madcap(5) -- MADCAP + } + +IANAmallocRangeSource ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "The source of multicast address allocation range + information." + SYNTAX INTEGER { + other(1), -- none of the following + manual(2), -- statically configured + local(3) -- automatically added by the system, + -- such as a Source-Specific Multicast + -- range + } + +END + diff --git a/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-MAU-MIB b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-MAU-MIB new file mode 100644 index 00000000000..35c3f4a8527 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-MAU-MIB @@ -0,0 +1,770 @@ +IANA-MAU-MIB DEFINITIONS ::= BEGIN + + IMPORTS + MODULE-IDENTITY, OBJECT-IDENTITY, mib-2 + FROM SNMPv2-SMI + TEXTUAL-CONVENTION + FROM SNMPv2-TC + ; + + ianaMauMIB MODULE-IDENTITY + LAST-UPDATED "200704210000Z" -- April 21, 2007 + ORGANIZATION "IANA" + CONTACT-INFO " Internet Assigned Numbers Authority + + Postal: ICANN + 4676 Admiralty Way, Suite 330 + Marina del Rey, CA 90292 + + Tel: +1-310-823-9358 + EMail: iana&iana.org" + + DESCRIPTION + "This MIB module defines dot3MauType OBJECT-IDENTITIES and + IANAifMauListBits, IANAifMauMediaAvailable, + IANAifMauAutoNegCapBits, and IANAifJackType + + TEXTUAL-CONVENTIONs, specifying enumerated values of the + ifMauTypeListBits, ifMauMediaAvailable / rpMauMediaAvailable, + ifMauAutoNegCapabilityBits / ifMauAutoNegCapAdvertisedBits / + ifMauAutoNegCapReceivedBits and ifJackType / rpJackType objects + respectively, defined in the MAU-MIB. + + It is intended that each new MAU type, Media Availability + state, Auto Negotiation capability and/or Jack type defined by + the IEEE 802.3 working group and approved for publication in a + revision of IEEE Std 802.3 will be added to this MIB module, + provided that it is suitable for being managed by the base + objects in the MAU-MIB. An Expert Review, as defined in + RFC 2434 [RFC2434], is REQUIRED for such additions. + + The following reference is used throughout this MIB module: + + [IEEE802.3] refers to: + IEEE Std 802.3, 2005 Edition: 'IEEE Standard for + Information technology - Telecommunications and information + exchange between systems - Local and metropolitan area + networks - Specific requirements - + Part 3: Carrier sense multiple access with collision + detection (CSMA/CD) access method and physical layer + specifications'. + + This reference should be updated as appropriate when new + MAU types, Media Availability states, Auto Negotiation + capabilities, and/or Jack types are added to this MIB module. + + Copyright (C) The IETF Trust (2007). + The initial version of this MIB module was published in + RFC 4836; for full legal notices see the RFC itself. + Supplementary information may be available at: + http://www.ietf.org/copyrights/ianamib.html" + + REVISION "200704210000Z" -- April 21, 2007 + DESCRIPTION "Initial version of this MIB as published in + RFC 4836." + ::= { mib-2 154 } + + -- Textual Conventions + + IANAifMauTypeListBits ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "This data type is used as the syntax of the ifMauTypeListBits + object in the (updated) definition of MAU-MIB's ifMauTable. + + The most recent version of this textual convention is available + in the online version of this MIB module on the IANA web site. + + Requests for new values should be made to IANA via email + (iana&iana.org). + + Note that changes in this textual convention SHALL be + synchronized with relevant changes in the dot3MauType + OBJECT-IDENTITIES." + REFERENCE + "[IEEE802.3], Section 30.5.1.1.2" + SYNTAX BITS { + bOther(0), -- other or unknown + bAUI(1), -- AUI + b10base5(2), -- 10BASE-5 + bFoirl(3), -- FOIRL + + b10base2(4), -- 10BASE-2 + b10baseT(5), -- 10BASE-T duplex mode unknown + b10baseFP(6), -- 10BASE-FP + b10baseFB(7), -- 10BASE-FB + b10baseFL(8), -- 10BASE-FL duplex mode unknown + b10broad36(9), -- 10BROAD36 + b10baseTHD(10), -- 10BASE-T half duplex mode + b10baseTFD(11), -- 10BASE-T full duplex mode + b10baseFLHD(12), -- 10BASE-FL half duplex mode + b10baseFLFD(13), -- 10BASE-FL full duplex mode + b100baseT4(14), -- 100BASE-T4 + b100baseTXHD(15), -- 100BASE-TX half duplex mode + b100baseTXFD(16), -- 100BASE-TX full duplex mode + b100baseFXHD(17), -- 100BASE-FX half duplex mode + b100baseFXFD(18), -- 100BASE-FX full duplex mode + b100baseT2HD(19), -- 100BASE-T2 half duplex mode + b100baseT2FD(20), -- 100BASE-T2 full duplex mode + + b1000baseXHD(21), -- 1000BASE-X half duplex mode + b1000baseXFD(22), -- 1000BASE-X full duplex mode + b1000baseLXHD(23), -- 1000BASE-LX half duplex mode + b1000baseLXFD(24), -- 1000BASE-LX full duplex mode + b1000baseSXHD(25), -- 1000BASE-SX half duplex mode + b1000baseSXFD(26), -- 1000BASE-SX full duplex mode + b1000baseCXHD(27), -- 1000BASE-CX half duplex mode + b1000baseCXFD(28), -- 1000BASE-CX full duplex mode + b1000baseTHD(29), -- 1000BASE-T half duplex mode + b1000baseTFD(30), -- 1000BASE-T full duplex mode + + b10GbaseX(31), -- 10GBASE-X + b10GbaseLX4(32), -- 10GBASE-LX4 + + b10GbaseR(33), -- 10GBASE-R + b10GbaseER(34), -- 10GBASE-ER + b10GbaseLR(35), -- 10GBASE-LR + b10GbaseSR(36), -- 10GBASE-SR + b10GbaseW(37), -- 10GBASE-W + b10GbaseEW(38), -- 10GBASE-EW + b10GbaseLW(39), -- 10GBASE-LW + b10GbaseSW(40), -- 10GBASE-SW + -- new since RFC 3636 + b10GbaseCX4(41), -- 10GBASE-CX4 + b2BaseTL(42), -- 2BASE-TL + b10PassTS(43), -- 10PASS-TS + b100BaseBX10D(44), -- 100BASE-BX10D + b100BaseBX10U(45), -- 100BASE-BX10U + b100BaseLX10(46), -- 100BASE-LX10 + b1000BaseBX10D(47), -- 1000BASE-BX10D + b1000BaseBX10U(48), -- 1000BASE-BX10U + b1000BaseLX10(49), -- 1000BASE-LX10 + b1000BasePX10D(50), -- 1000BASE-PX10D + b1000BasePX10U(51), -- 1000BASE-PX10U + b1000BasePX20D(52), -- 1000BASE-PX20D + b1000BasePX20U(53) -- 1000BASE-PX20U + } + + IANAifMauMediaAvailable ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "This data type is used as the syntax of the + ifMauMediaAvailable and rpMauMediaAvailable objects in the + (updated) definition of MAU-MIB's ifMauTable and rpMauTable + respectively. + + Possible values are: + other(1) - undefined (not listed below) + unknown(2) - MAU's true state is unknown; e.g., + during initialization + available(3) - link, light, or loopback is normal + notAvailable(4) - link loss, low light, or no loopback + remoteFault(5) - a fault has been detected at the + remote end of the link. This value + applies to 10BASE-FB, 100BASE-T4 Far + End Fault Indication and non-specified + remote faults from a system running + auto-negotiation + invalidSignal(6) - invalid signal has been received from + the other end of the link, 10BASE-FB + only + remoteJabber(7) - remote fault, due to jabber + + remoteLinkLoss(8) - remote fault, due to link loss + remoteTest(9) - remote fault, due to test + offline(10) - offline, Clause 37 Auto-Negotiation + only + autoNegError(11) - Auto-Negotiation Error, Clause 37 + Auto-Negotiation only + pmdLinkFault(12) - PMA/PMD receive link fault. In case + of PAF (2BASE-TL / 10PASS-TS PHYs), + all PMEs in the aggregation group have + detected a link fault + wisFrameLoss(13) - WIS loss of frame, 10GBASE-W only + wisSignalLoss(14) - WIS loss of signal, 10GBASE-W only + pcsLinkFault(15) - PCS receive link fault + excessiveBER(16) - PCS Bit Error Ratio monitor + reporting excessive error ratio + dxsLinkFault(17) - DTE XGXS receive link fault, XAUI only + pxsLinkFault(18) - PHY XGXS receive link fault, XAUI only + availableReduced(19) - link normal, reduced bandwidth, + 2BASE-TL / 10PASS-TS only + ready(20) - at least one PME in the aggregation + group is detecting handshake tones, + 2BASE-TL / 10PASS-TS only + + If the MAU is a 10M b/s link or fiber type (FOIRL, 10BASE-T, + 10BASE-F), then this is equivalent to the link test fail + state/low light function. For an AUI, 10BASE2, 10BASE5, or + 10BROAD36 MAU, this indicates whether loopback is detected on + the DI circuit. The value of this attribute persists between + packets for MAU types AUI, 10BASE5, 10BASE2, 10BROAD36, and + 10BASEFP. + + At power-up or following a reset, the Media Available state + will be unknown(2) for AUI, 10BASE5, 10BASE2, 10BROAD36, and + 10BASE-FP MAUs. For these MAUs loopback will be tested on each + transmission during which no collision is detected. + If DI is receiving input when DO returns to IDL after a + transmission and there has been no collision during the + transmission, then loopback will be detected. The Media + Available state will only change during noncollided + transmissions for AUI, 10BASE2, 10BASE5, 10BROAD36, and + 10BASE-FP MAUs. + + For 100BASE-T2, 100BASE-T4, 100BASE-TX, 100BASE-FX, + 100BASE-LX10, and 100BASE-BX10 PHYs the enumerations match the + states within the link integrity state diagram. + Any MAU that implements management of [IEEE802.3] Clause + 28 Auto-Negotiation, will map remote fault indication to + remoteFault(5). + + Any MAU that implements management of Clause 37 + Auto-Negotiation, will map the received RF1 and RF2 bits as + follows: Offline maps to offline(10), Link_Failure maps to + remoteFault(5), and Auto-Negotiation Error maps to + autoNegError(11). + + The value remoteFault(5) applies to 10BASE-FB remote + fault indication, the 100BASE-X far-end fault indication, and + nonspecified remote faults from a system running Clause 28 + Auto-Negotiation. + + The value remoteJabber(7), remoteLink loss(8), or remoteTest(9) + SHOULD be used instead of remoteFault(5) where the reason for + remote fault is identified in the remote signaling protocol. + Where a Clause 22 MII or Clause 35 GMII is present, a logic + one in the remote fault bit maps to the value remoteFault(5), + a logic zero in the link status bit maps to the enumeration + notAvailable(4). The value notAvailable(4) takes precedence + over remoteFault(5). + + For 2BASE-TL and 10PASS-TS PHYs, the value unknown(2) maps to + the condition where the PHY (PCS with connected PMEs) is + initializing, the value ready(20) maps to the condition where + the interface is down and at least one PME in the aggregation + group is ready for handshake, the value available(3) maps to + the condition where all the PMEs in the aggregation group are + up, the value notAvailable(4) maps to the condition where all + the PMEs in the aggregation group are down and no handshake + tones are detected, the value availableReduced(19) maps to the + condition where the interface is up, a link fault is detected + at the receive direction by one or more PMEs in the + aggregation group, but at least one PME is up and the + enumeration pmdLinkFault(12) maps to the condition where a link + fault is detected at the receive direction by all of the PMEs + in the aggregation group. + + For 10 Gb/s the enumerations map to value of the link_fault + variable within the Link Fault Signaling state diagram + as follows: the value OK maps to the value available(3), + the value Local Fault maps to the value notAvailable(4), + and the value Remote Fault maps to the value remoteFault(5). + The value pmdLinkFault(12), wisFrameLoss(13), + wisSignalLoss(14), pcsLinkFault(15), excessiveBER(16), or + dxsLinkFault(17) SHOULD be used instead of the value + notAvailable(4), where the reason for the Local Fault state can + be identified through the use of the Clause 45 MDIO Interface. + Where multiple reasons for the Local Fault state can be + identified, only the highest precedence error SHOULD be + + reported. This precedence in descending order is as follows: + + pxsLinkFault + pmdLinkFault + wisFrameLoss + wisSignalLoss + pcsLinkFault + excessiveBER + dxsLinkFault. + + Where a Clause 45 MDIO interface is present a logic zero in + the PMA/PMD Receive link status bit ([IEEE802.3] + Section 45.2.1.2.2) maps to the value pmdLinkFault(12), + logic one in the LOF status bit (Section 45.2.2.10.4) maps + to the value wisFrameLoss(13), a logic one in the LOS + status bit (Section 45.2.2.10.5) maps to the value + wisSignalLoss, a logic zero in the PCS Receive + link status bit (Section 45.2.3.2.2) maps to the value + pcsLinkFault(15), a logic one in the 10GBASE-R PCS Latched + high BER status bit (Section 45.2.3.12.2) maps to the value + excessiveBER, a logic zero in the DTE XS receive link status + bit (Section 45.2.5.2.2) maps to the value dxsLinkFault(17) + and a logic zero in the PHY XS transmit link status bit + (Section 45.2.4.2.2) maps to the value pxsLinkFault(18). + + The most recent version of this textual convention is available + in the online version of this MIB module on the IANA web site. + + Requests for new values should be made to IANA via email + (iana&iana.org)." + REFERENCE + "[IEEE802.3], Section 30.5.1.1.4" + SYNTAX INTEGER { + other(1), + unknown(2), + available(3), + notAvailable(4), + remoteFault(5), + invalidSignal(6), + remoteJabber(7), + remoteLinkLoss(8), + remoteTest(9), + offline(10), + autoNegError(11), + pmdLinkFault(12), + wisFrameLoss(13), + wisSignalLoss(14), + pcsLinkFault(15), + + excessiveBER(16), + dxsLinkFault(17), + pxsLinkFault(18), + availableReduced(19), + ready(20) + } + + IANAifMauAutoNegCapBits ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "This data type is used as the syntax of the + ifMauAutoNegCapabilityBits, ifMauAutoNegCapAdvertisedBits, and + ifMauAutoNegCapReceivedBits objects in the (updated) definition + of MAU-MIB's ifMauAutoNegTable. + + The most recent version of this textual convention is available + in the online version of this MIB module on the IANA web site. + + Requests for new values should be made to IANA via email + (iana&iana.org)." + REFERENCE + "[IEEE802.3], Section 30.6.1.1.5" + SYNTAX BITS { + bOther(0), -- other or unknown + b10baseT(1), -- 10BASE-T half duplex mode + b10baseTFD(2), -- 10BASE-T full duplex mode + b100baseT4(3), -- 100BASE-T4 + b100baseTX(4), -- 100BASE-TX half duplex mode + b100baseTXFD(5), -- 100BASE-TX full duplex mode + b100baseT2(6), -- 100BASE-T2 half duplex mode + b100baseT2FD(7), -- 100BASE-T2 full duplex mode + bFdxPause(8), -- PAUSE for full-duplex links + bFdxAPause(9), -- Asymmetric PAUSE for full-duplex + -- links + bFdxSPause(10), -- Symmetric PAUSE for full-duplex + -- links + bFdxBPause(11), -- Asymmetric and Symmetric PAUSE for + -- full-duplex links + b1000baseX(12), -- 1000BASE-X, -LX, -SX, -CX half + -- duplex mode + b1000baseXFD(13), -- 1000BASE-X, -LX, -SX, -CX full + -- duplex mode + b1000baseT(14), -- 1000BASE-T half duplex mode + b1000baseTFD(15) -- 1000BASE-T full duplex mode + } + + IANAifJackType ::= TEXTUAL-CONVENTION + STATUS current + + DESCRIPTION + "Common enumeration values for repeater and interface MAU + jack types. This data type is used as the syntax of the + ifJackType and rpJackType objects in the (updated) definition + of MAU-MIB's ifJackTable and rpJackTable respectively. + + Possible values are: + other(1) - undefined or unknown + rj45(2) - RJ45 + rj45S(3) - RJ45 shielded + db9(4) - DB9 + bnc(5) - BNC + fAUI(6) - AUI female + mAUI(7) - AUI male + fiberSC(8) - SC fiber + fiberMIC(9) - MIC fiber + fiberST(10) - ST fiber + telco(11) - Telco + mtrj(12) - MT-RJ fiber + hssdc(13) - fiber channel style-2 + fiberLC(14) - LC fiber + cx4(15) - IB4X for 10GBASE-CX4 + + The most recent version of this textual convention is available + in the online version of this MIB module on the IANA web site. + + Requests for new values should be made to IANA via email + (iana&iana.org)." + SYNTAX INTEGER { + other(1), + rj45(2), + rj45S(3), + db9(4), + bnc(5), + fAUI(6), + mAUI(7), + fiberSC(8), + fiberMIC(9), + fiberST(10), + telco(11), + mtrj(12), + hssdc(13), + fiberLC(14), + -- new since RFC 3636 + cx4(15) + } + + -- OBJECT IDENTITIES for MAU types + + -- (see rpMauType and ifMauType of MAU-MIB for usage) + -- The following definitions has been moved from RFC 3636 and + -- no longer appear in its revision. + + dot3MauType OBJECT IDENTIFIER ::= { mib-2 snmpDot3MauMgt(26) 4 } + + dot3MauTypeAUI OBJECT-IDENTITY + STATUS current + DESCRIPTION "no internal MAU, view from AUI" + REFERENCE "[IEEE802.3], Section 7" + ::= { dot3MauType 1 } + + dot3MauType10Base5 OBJECT-IDENTITY + STATUS current + DESCRIPTION "thick coax MAU" + REFERENCE "[IEEE802.3], Section 7" + ::= { dot3MauType 2 } + + dot3MauTypeFoirl OBJECT-IDENTITY + STATUS current + DESCRIPTION "FOIRL MAU" + REFERENCE "[IEEE802.3], Section 9.9" + ::= { dot3MauType 3 } + + dot3MauType10Base2 OBJECT-IDENTITY + STATUS current + DESCRIPTION "thin coax MAU" + REFERENCE "[IEEE802.3], Section 10" + ::= { dot3MauType 4 } + + dot3MauType10BaseT OBJECT-IDENTITY + STATUS current + DESCRIPTION "UTP MAU. + Note that it is strongly recommended that + agents return either dot3MauType10BaseTHD or + dot3MauType10BaseTFD if the duplex mode is + known. However, management applications should + be prepared to receive this MAU type value from + older agent implementations." + REFERENCE "[IEEE802.3], Section 14" + ::= { dot3MauType 5 } + + dot3MauType10BaseFP OBJECT-IDENTITY + STATUS current + DESCRIPTION "passive fiber MAU" + REFERENCE "[IEEE802.3], Section 16" + ::= { dot3MauType 6 } + + dot3MauType10BaseFB OBJECT-IDENTITY + STATUS current + DESCRIPTION "sync fiber MAU" + REFERENCE "[IEEE802.3], Section 17" + ::= { dot3MauType 7 } + + dot3MauType10BaseFL OBJECT-IDENTITY + STATUS current + DESCRIPTION "async fiber MAU. + Note that it is strongly recommended that + agents return either dot3MauType10BaseFLHD or + dot3MauType10BaseFLFD if the duplex mode is + known. However, management applications should + be prepared to receive this MAU type value from + older agent implementations." + REFERENCE "[IEEE802.3], Section 18" + ::= { dot3MauType 8 } + + dot3MauType10Broad36 OBJECT-IDENTITY + STATUS current + DESCRIPTION "broadband DTE MAU. + Note that 10BROAD36 MAUs can be attached to + interfaces but not to repeaters." + REFERENCE "[IEEE802.3], Section 11" + ::= { dot3MauType 9 } + + ------ new since RFC 1515: + dot3MauType10BaseTHD OBJECT-IDENTITY + STATUS current + DESCRIPTION "UTP MAU, half duplex mode" + REFERENCE "[IEEE802.3], Section 14" + ::= { dot3MauType 10 } + + dot3MauType10BaseTFD OBJECT-IDENTITY + STATUS current + DESCRIPTION "UTP MAU, full duplex mode" + REFERENCE "[IEEE802.3], Section 14" + ::= { dot3MauType 11 } + + dot3MauType10BaseFLHD OBJECT-IDENTITY + STATUS current + DESCRIPTION "async fiber MAU, half duplex mode" + REFERENCE "[IEEE802.3], Section 18" + ::= { dot3MauType 12 } + + dot3MauType10BaseFLFD OBJECT-IDENTITY + STATUS current + DESCRIPTION "async fiber MAU, full duplex mode" + + REFERENCE "[IEEE802.3], Section 18" + ::= { dot3MauType 13 } + + dot3MauType100BaseT4 OBJECT-IDENTITY + STATUS current + DESCRIPTION "4 pair category 3 UTP" + REFERENCE "[IEEE802.3], Section 23" + ::= { dot3MauType 14 } + + dot3MauType100BaseTXHD OBJECT-IDENTITY + STATUS current + DESCRIPTION "2 pair category 5 UTP, half duplex mode" + REFERENCE "[IEEE802.3], Section 25" + ::= { dot3MauType 15 } + + dot3MauType100BaseTXFD OBJECT-IDENTITY + STATUS current + DESCRIPTION "2 pair category 5 UTP, full duplex mode" + REFERENCE "[IEEE802.3], Section 25" + ::= { dot3MauType 16 } + + dot3MauType100BaseFXHD OBJECT-IDENTITY + STATUS current + DESCRIPTION "X fiber over PMT, half duplex mode" + REFERENCE "[IEEE802.3], Section 26" + ::= { dot3MauType 17 } + + dot3MauType100BaseFXFD OBJECT-IDENTITY + STATUS current + DESCRIPTION "X fiber over PMT, full duplex mode" + REFERENCE "[IEEE802.3], Section 26" + ::= { dot3MauType 18 } + + dot3MauType100BaseT2HD OBJECT-IDENTITY + STATUS current + DESCRIPTION "2 pair category 3 UTP, half duplex mode" + REFERENCE "[IEEE802.3], Section 32" + ::= { dot3MauType 19 } + + dot3MauType100BaseT2FD OBJECT-IDENTITY + STATUS current + DESCRIPTION "2 pair category 3 UTP, full duplex mode" + REFERENCE "[IEEE802.3], Section 32" + ::= { dot3MauType 20 } + + ------ new since RFC 2239: + dot3MauType1000BaseXHD OBJECT-IDENTITY + STATUS current + + DESCRIPTION "PCS/PMA, unknown PMD, half duplex mode" + REFERENCE "[IEEE802.3], Section 36" + ::= { dot3MauType 21 } + + dot3MauType1000BaseXFD OBJECT-IDENTITY + STATUS current + DESCRIPTION "PCS/PMA, unknown PMD, full duplex mode" + REFERENCE "[IEEE802.3], Section 36" + ::= { dot3MauType 22 } + + dot3MauType1000BaseLXHD OBJECT-IDENTITY + STATUS current + DESCRIPTION "Fiber over long-wavelength laser, half duplex + mode" + REFERENCE "[IEEE802.3], Section 38" + ::= { dot3MauType 23 } + + dot3MauType1000BaseLXFD OBJECT-IDENTITY + STATUS current + DESCRIPTION "Fiber over long-wavelength laser, full duplex + mode" + REFERENCE "[IEEE802.3], Section 38" + ::= { dot3MauType 24 } + + dot3MauType1000BaseSXHD OBJECT-IDENTITY + STATUS current + DESCRIPTION "Fiber over short-wavelength laser, half + duplex mode" + REFERENCE "[IEEE802.3], Section 38" + ::= { dot3MauType 25 } + + dot3MauType1000BaseSXFD OBJECT-IDENTITY + STATUS current + DESCRIPTION "Fiber over short-wavelength laser, full + duplex mode" + REFERENCE "[IEEE802.3], Section 38" + ::= { dot3MauType 26 } + + dot3MauType1000BaseCXHD OBJECT-IDENTITY + STATUS current + DESCRIPTION "Copper over 150-Ohm balanced cable, half + duplex mode" + REFERENCE "[IEEE802.3], Section 39" + ::= { dot3MauType 27 } + + dot3MauType1000BaseCXFD OBJECT-IDENTITY + STATUS current + DESCRIPTION "Copper over 150-Ohm balanced cable, full + + duplex mode" + REFERENCE "[IEEE802.3], Section 39" + ::= { dot3MauType 28 } + + dot3MauType1000BaseTHD OBJECT-IDENTITY + STATUS current + DESCRIPTION "Four-pair Category 5 UTP, half duplex mode" + REFERENCE "[IEEE802.3], Section 40" + ::= { dot3MauType 29 } + + dot3MauType1000BaseTFD OBJECT-IDENTITY + STATUS current + DESCRIPTION "Four-pair Category 5 UTP, full duplex mode" + REFERENCE "[IEEE802.3], Section 40" + ::= { dot3MauType 30 } + + ------ new since RFC 2668: + dot3MauType10GigBaseX OBJECT-IDENTITY + STATUS current + DESCRIPTION "X PCS/PMA, unknown PMD." + REFERENCE "[IEEE802.3], Section 48" + ::= { dot3MauType 31 } + + dot3MauType10GigBaseLX4 OBJECT-IDENTITY + STATUS current + DESCRIPTION "X fiber over WWDM optics" + REFERENCE "[IEEE802.3], Section 53" + ::= { dot3MauType 32 } + + dot3MauType10GigBaseR OBJECT-IDENTITY + STATUS current + DESCRIPTION "R PCS/PMA, unknown PMD." + REFERENCE "[IEEE802.3], Section 49" + ::= { dot3MauType 33 } + + dot3MauType10GigBaseER OBJECT-IDENTITY + STATUS current + DESCRIPTION "R fiber over 1550 nm optics" + REFERENCE "[IEEE802.3], Section 52" + ::= { dot3MauType 34 } + + dot3MauType10GigBaseLR OBJECT-IDENTITY + STATUS current + DESCRIPTION "R fiber over 1310 nm optics" + REFERENCE "[IEEE802.3], Section 52" + ::= { dot3MauType 35 } + + dot3MauType10GigBaseSR OBJECT-IDENTITY + + STATUS current + DESCRIPTION "R fiber over 850 nm optics" + REFERENCE "[IEEE802.3], Section 52" + ::= { dot3MauType 36 } + + dot3MauType10GigBaseW OBJECT-IDENTITY + STATUS current + DESCRIPTION "W PCS/PMA, unknown PMD." + REFERENCE "[IEEE802.3], Section 49 and 50" + ::= { dot3MauType 37 } + + dot3MauType10GigBaseEW OBJECT-IDENTITY + STATUS current + DESCRIPTION "W fiber over 1550 nm optics" + REFERENCE "[IEEE802.3], Section 52" + ::= { dot3MauType 38 } + + dot3MauType10GigBaseLW OBJECT-IDENTITY + STATUS current + DESCRIPTION "W fiber over 1310 nm optics" + REFERENCE "[IEEE802.3], Section 52" + ::= { dot3MauType 39 } + + dot3MauType10GigBaseSW OBJECT-IDENTITY + STATUS current + DESCRIPTION "W fiber over 850 nm optics" + REFERENCE "[IEEE802.3], Section 52" + ::= { dot3MauType 40 } + + ------ new since RFC 3636: + dot3MauType10GigBaseCX4 OBJECT-IDENTITY + STATUS current + DESCRIPTION "X copper over 8 pair 100-Ohm balanced cable" + REFERENCE "[IEEE802.3], Section 54" + ::= { dot3MauType 41 } + + dot3MauType2BaseTL OBJECT-IDENTITY + STATUS current + DESCRIPTION "Voice grade UTP copper, up to 2700m, optional PAF" + REFERENCE "[IEEE802.3], Sections 61 and 63" + ::= { dot3MauType 42 } + + dot3MauType10PassTS OBJECT-IDENTITY + STATUS current + DESCRIPTION "Voice grade UTP copper, up to 750m, optional PAF" + REFERENCE "[IEEE802.3], Sections 61 and 62" + ::= { dot3MauType 43 } + + dot3MauType100BaseBX10D OBJECT-IDENTITY + STATUS current + DESCRIPTION "One single-mode fiber OLT, long wavelength, 10km" + REFERENCE "[IEEE802.3], Section 58" + ::= { dot3MauType 44 } + + dot3MauType100BaseBX10U OBJECT-IDENTITY + STATUS current + DESCRIPTION "One single-mode fiber ONU, long wavelength, 10km" + REFERENCE "[IEEE802.3], Section 58" + ::= { dot3MauType 45 } + + dot3MauType100BaseLX10 OBJECT-IDENTITY + STATUS current + DESCRIPTION "Two single-mode fibers, long wavelength, 10km" + REFERENCE "[IEEE802.3], Section 58" + ::= { dot3MauType 46 } + + dot3MauType1000BaseBX10D OBJECT-IDENTITY + STATUS current + DESCRIPTION "One single-mode fiber OLT, long wavelength, 10km" + REFERENCE "[IEEE802.3], Section 59" + ::= { dot3MauType 47 } + + dot3MauType1000BaseBX10U OBJECT-IDENTITY + STATUS current + DESCRIPTION "One single-mode fiber ONU, long wavelength, 10km" + REFERENCE "[IEEE802.3], Section 59" + ::= { dot3MauType 48 } + + dot3MauType1000BaseLX10 OBJECT-IDENTITY + STATUS current + DESCRIPTION "Two sigle-mode fiber, long wavelength, 10km" + REFERENCE "[IEEE802.3], Section 59" + ::= { dot3MauType 49 } + + dot3MauType1000BasePX10D OBJECT-IDENTITY + STATUS current + DESCRIPTION "One single-mode fiber EPON OLT, 10km" + REFERENCE "[IEEE802.3], Section 60" + ::= { dot3MauType 50 } + + dot3MauType1000BasePX10U OBJECT-IDENTITY + STATUS current + DESCRIPTION "One single-mode fiber EPON ONU, 10km" + REFERENCE "[IEEE802.3], Section 60" + ::= { dot3MauType 51 } + + dot3MauType1000BasePX20D OBJECT-IDENTITY + STATUS current + DESCRIPTION "One single-mode fiber EPON OLT, 20km" + REFERENCE "[IEEE802.3], Section 60" + ::= { dot3MauType 52 } + + dot3MauType1000BasePX20U OBJECT-IDENTITY + STATUS current + DESCRIPTION "One single-mode fiber EPON ONU, 20km" + REFERENCE "[IEEE802.3], Section 60" + ::= { dot3MauType 53 } + +END diff --git a/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-PRINTER-MIB b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-PRINTER-MIB new file mode 100644 index 00000000000..856ed5f89e9 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-PRINTER-MIB @@ -0,0 +1,1319 @@ +IANA-PRINTER-MIB DEFINITIONS ::= BEGIN + -- http://www.iana.org/assignments/ianaprinter-mib + +IMPORTS + MODULE-IDENTITY, + mib-2 + FROM SNMPv2-SMI -- [RFC2578] + TEXTUAL-CONVENTION + FROM SNMPv2-TC; -- [RFC2579] + +ianaPrinterMIB MODULE-IDENTITY + LAST-UPDATED "200509140000Z" -- September 14, 2005 + + ORGANIZATION "IANA" + CONTACT-INFO "Internet Assigned Numbers Authority + Postal: ICANN + 4676 Admiralty Way, Suite 330 + Marina del Rey, CA 90292 + + Tel: +1 310 823 9358 + E-Mail: iana&iana.org" + + DESCRIPTION "This MIB module defines a set of printing-related + TEXTUAL-CONVENTIONs for use in Printer MIB (RFC 3805), + Finisher MIB (RFC 3806), and other MIBs which need to + specify printing mechanism details. + + Any additions or changes to the contents of this MIB + module require either publication of an RFC, or + Designated Expert Review as defined in RFC 2434, + Guidelines for Writing an IANA Considerations Section + in RFCs. The Designated Expert will be selected by + the IESG Area Director(s) of the Applications Area. + + Copyright (C) The Internet Society (2004). The + initial version of this MIB module was published + in RFC 3805. For full legal notices see the RFC + itself or see: + http://www.ietf.org/copyrights/ianamib.html" + + REVISION "200509140000Z" -- September 14, 2005 + DESCRIPTION "Updates to include missing 'unknown' values + for PrtCoverStatusTC, PrtChannelTypeTC, + PrtAlertGroupTC and removal of comment for + for PrtAlertGroupTC." + + REVISION "200406020000Z" -- June 2, 2004 + DESCRIPTION "Original version, published in coordination + with Printer MIB (RFC 3805)." + ::= { mib-2 109 } + +-- +-- Generic TEXTUAL-CONVENTIONs +-- + +PrtCoverStatusTC ::= TEXTUAL-CONVENTION + -- This TC was extracted from prtCoverStatus in RFC 1759. + STATUS current + DESCRIPTION + "Values for encoding the state of a particular cover or + access panel on the printer case or enclosure." + SYNTAX INTEGER { + other(1), + unknown(2), + coverOpen(3), + coverClosed(4), + interlockOpen(5), + interlockClosed(6) + + } + +-- +-- General Group TEXTUAL-CONVENTIONs +-- + +PrtGeneralResetTC ::= TEXTUAL-CONVENTION + -- This TC was extracted from prtGeneralReset in RFC 1759. + STATUS current + DESCRIPTION + "Values for reading and writing the prtGeneralReset object. + + If a device does not have NVRAM, the device shall none the + less respond to a SET with the value resetToNVRAM(5) with a + sort of warm reset that resets the device to implementation- + defined state that is preferably under control of the system + administrator by some means outside the scope of the Printer + MIB specification." + + SYNTAX INTEGER { + notResetting(3), + powerCycleReset(4), -- Cold Start + resetToNVRAM(5), -- Warm Start + resetToFactoryDefaults(6) -- Reset contents of + -- NVRAM to factory + -- defaults + } +-- +-- Channel Group TEXTUAL-CONVENTIONs +-- + +PrtChannelTypeTC ::= TEXTUAL-CONVENTION + -- This TC was extracted from prtChannelType in RFC 1759. + STATUS current + DESCRIPTION + "This enumeration indicates the type of channel that is + receiving jobs." + SYNTAX INTEGER { + other(1), + unknown(2), + chSerialPort(3), + chParallelPort(4), + chIEEE1284Port(5), + chSCSIPort(6), + chAppleTalkPAP(7), + -- AppleTalk Printer + -- Access Protocol (PAP) + -- + -- prtChannelInformation entry: + + -- + -- Printer Name + -- Keyword: Name + -- Syntax: Name + -- Status: Optional + -- Multiplicity: Single + -- Description: The name of the printer + -- within the AppleTalk naming scope + chLPDServer(8), + -- prtChannelInformation entry: + -- + -- Printer queue name + -- Keyword: Queue + -- Syntax: Name + -- Status: Mandatory + -- Multiplicity: Single + -- Description: queue name as + -- defined in [RFC1179]. + chNetwareRPrinter(9), + -- Novell, Inc. + -- For each entry of this type, the + -- prtChannelInformation must have a pair of + -- keywords. For Netware 3.x channels this must + -- be a (PServer, Printer) pair. For Netware + -- 4.x channels and for IntranetWare channels + -- this must be a (NDSTree, NDSPrinter) pair. + -- + -- prtChannelInformation entries: + + -- Print Server Name + -- Keyword: PServer + -- Syntax: Name + -- Status: Mandatory + -- Multiplicity: Single + -- Description: The Pserver's SAP name + -- + -- Printer Number + -- Keyword: Printer + -- Syntax: Integer + -- Status: Mandatory + -- Multiplicity: Single + -- Description: The printer number + -- + -- NDSTree + -- Keyword: NDSTree + -- Syntax: Name + -- Multiplicity: Single + -- Description: The tree's SAP name + + -- + -- NDS Printer object + -- Keyword: NDSPrinter + -- Syntax: Text (Unicode) + -- Status: Mandatory + -- Multiplicity: Single + -- Description: The fully qualified + -- name of the Printer + -- + -- In the Netware 3.x environment, the + -- client checks the Bindery object + -- representing the named PServer. The + -- client then checks for queues which + -- are associated with the numbered + -- printer. In the 4.x and IntraNetware + -- environment, the client looks up the + -- queues which are associated with the + -- NDS Printer Object in the named Tree. + -- Depending on client access rights to + -- those queues, the client submits jobs + -- to the appropriate queue. + chNetwarePServer(10), + -- Novell,Inc. + -- For each entry of this type, the + -- prtChannelInformation must have a pair + -- of keywords. For Netware 3.x channels + -- this must be a (Server, PServer) pair. + -- For Netware 4.x and IntranetWare + -- channels, this must be a + -- (NDSTree, NDSPServer) pair. + -- + -- prtChannelInformation entries: + -- + -- Server Name + -- Keyword: Server + -- Syntax: Name + -- Status: Mandatory + -- Multiplicity: Single + -- Description: The SAP name of the + -- server for which the PServer is defined. + -- + -- PServer + -- Keyword: PServer + -- Syntax: Name + -- Status: Mandatory + -- Multiplicity: Single + -- Description: The bindery name of + -- the PServer + + -- + -- NDS Tree + -- Keyword: NDSTree + -- Syntax: Name + -- Status: Mandatory + -- Multiplicity: Single + -- Description: The NDS Tree name + -- + -- PServer + -- Keyword: NDSPServer + -- Syntax: Text (Unicode) + -- Status: Mandatory + -- Multiplicity: Single + -- Description: The fully qualified + -- name of the PServer object in the tree. + -- + -- In the 3.x environment, the client + -- checks the bindery object + -- representing the named PServer on the + -- named Server. In the 4.x and + -- IntranetWare environment, + -- the client checks the NDS object + -- representing the named PServer in the + -- named Tree. In either case, the + -- client then checks for all queues + -- associated with the Pserver object. + -- Depending on client access rights + -- to those queues, the client submits + -- jobs to the appropriate queue. + chPort9100(11), + -- DEPRECATED + -- (see chPortTCP - 37; chBidirPortTCP - 38) + chAppSocket(12), + -- A bi-directional, LPD-like, protocol using + -- 9101 for control and 9100 for data. + -- Adobe Systems, Inc. + chFTP(13), -- [RFC959] + chTFTP(14), -- [RFC1350] + chDLCLLCPort(15), + chIBM3270(16), -- IBM Coax + chIBM5250(17), -- IBM Twinax + chFax(18), + chIEEE1394(19), + chTransport1(20), + -- TCP port 35, for reserved TCP port list see + -- [RFC3232]. This RFC should also be + -- referenced for other channel + -- enumerations utilizing TCP port + + -- numbers 0 through 1024. + chCPAP(21), -- TCP port 170 + -- Digital Equipment Corp. + chDCERemoteProcCall(22), -- OSF + -- DEPRECATED + chONCRemoteProcCall(23), -- SUN Microsystems + -- DEPRECATED + chOLE(24), -- Microsoft + -- DEPRECATED + chNamedPipe(25), + chPCPrint(26), -- Banyan + chServerMessageBlock(27), + -- File/Print sharing protocol used by + -- various network operating systems + -- from IBM 3Com, Microsoft and others + -- + -- prtChannelInformation entry: + -- + -- Service Name + -- Keyword: Name + -- Syntax: Name + -- Status: Optional + -- Multiplicity: Single + -- Description: The service name of + -- the printer + chDPMF(28), -- IBM Infoprint + chDLLAPI(29), -- Microsoft + -- DEPRECATED + chVxDAPI(30), -- Microsoft + -- DEPRECATED + chSystemObjectManager(31), -- IBM + chDECLAT(32), + -- Digital Equipment Corp. + -- + -- prtChannelInformation entries: + -- + -- Port Name + -- Keyword: Port + -- Syntax: Name + -- Status: Conditionally + -- Mandatory + -- (see note below) + -- Multiplicity: Single + -- Description: LAT port name + -- + -- Service Name + -- Keyword: Service + -- Syntax: Name + + -- Status: Conditionally + -- Mandatory + -- Multiplicity: Single + -- Description: LAT service name + -- + -- The LAT channel may be + -- identified by either a port or + -- service, so either a + -- Port or Service entry must be + -- specified, but not both. + chNPAP(33), + chUSB(34), -- Not in RFC 1759 + -- Universal Serial Bus + chIRDA(35), -- Not in RFC 1759 + -- Infrared Data Assoc. Prot. + chPrintXChange(36), -- Not in RFC 1759 + -- PrintXChange Protocol + chPortTCP(37), -- Not in RFC 1759 + -- A unidirectional "raw" TCP + -- channel that uses an administratively + -- assigned TCP port address. + -- + -- prtChannelInformation entry: + -- + -- Port Number + -- Keyword: Port + -- Syntax: decimal number + -- Status: Mandatory + -- Multiplicity: Single + -- Description: TCP port number + chBidirPortTCP(38), -- Not in RFC 1759 + -- A bi-directional version of chPortTCP + -- + -- prtChannelInformation entries: + -- (See chPortTCP) + chUNPP(39), -- Not in RFC 1759 + -- Universal Network Printing + -- Protocol(UNPP). A bi-directional, + -- multiport network printing + -- application protocol available on + -- multiple transport protocols. + -- Underscore, Inc. + -- Contact: info&underscore.com + chAppleTalkADSP(40), -- Not in RFC 1759 + -- AppleTalk Data Stream Protocol. + -- ADSP is part of the AppleTalk + -- suite of protocols. + -- It is a symmetric, connection- + + -- oriented protocol that makes + -- possible the establishment + -- and maintenance of full-duplex + -- streams of data bytes between + -- two sockets in an AppleTalk + -- internet. + -- See [APPLEMAC]. + chPortSPX(41), -- Not in RFC 1759 + -- Sequenced Packet Exchange (SPX) + -- socket. + -- Novell, Inc. Similar to TCP, a + -- bi-directional data pipe using + -- Novell SPX as a transport. + -- + -- prtChannelInformation entries: + -- + -- Network Number + -- Keyword: Net + -- Syntax: HexString + -- Status: Mandatory + -- Multiplicity: Single + -- Description: The network number + -- + -- Node Number + -- Keyword: Node + -- Syntax: HexString + -- Status: Mandatory + -- Multiplicity: Single + -- Description: The node number + -- + -- Socket Number + -- Keyword: Socket + -- Syntax: HexString + -- Status: Mandatory + -- Multiplicity: Single + -- Description: The SPX socket number + -- + -- There must be exactly one "Net" and + -- one "Node" and one "Socket" entry. A + -- HexString is a binary value + -- represented as a string of + -- ASCII characters using hexadecimal + -- notation. + chPortHTTP(42), -- Not in RFC 1759 + -- Hypertext Transfer Protocol. See [RFC1945] + -- and [RFC2616]. + chNDPS(43), -- Not in RFC 1759 + -- Novell, Inc. + + -- + -- prtChannelInformation entry: + -- + -- Printer Agent Name + -- Keyword: PA + -- Syntax: Name + -- Status: Mandatory + -- Multiplicity: Single + -- Description: The NDPS Printer + -- Agent Name + chIPP(44), -- Not in RFC 1759 + -- Internet Printing Protocol (IPP), + -- (IPP/1.1 - see [RFC2910] and [RFC2911]) + -- also applies to all future versions of IPP. + -- + -- IPP Printer URI + -- Keyword: URI + -- Syntax: URI (Unicode UTF-8 per + -- [RFC2396]) + -- Status: Mandatory + -- Multiplicity: Single + -- Default: not applicable + -- Description: URI of this IPP Printer + -- within Internet naming scope. Unicode + -- UTF-8 [RFC3629] string with + -- hexadecimal escapes for any non-ASCII + -- characters (per [RFC2396]). + -- Conformance: An IPP Printer shall list all + -- IPP URI it supports (one per IPP Channel + -- entry). If a URI contains the 'http:' + -- scheme it must have an explicit port. + -- See: [RFC3629], [RFC2396], [RFC2910], + -- [RFC2911]. + -- + -- IPP Printer Client Authentication + -- Keyword: Auth + -- Syntax: Keyword + -- Status: Optional + -- Multiplicity: Single + -- Default: 'none' + -- Description: A client authentication + -- mechanism supported for this IPP Printer + -- URI: + -- 'none' + -- no client authentication mechanism + -- 'requesting-user-name' + -- authenticated user in 'requesting- + -- user-name' + + -- 'basic' + -- authenticated user via HTTP Basic + -- mechanism + -- 'digest' + -- authenticated user via HTTP Digest + -- mechanism + -- 'certificate' + -- authenticated user via certificate + -- mechanism + -- Conformance: An IPP Printer should list + -- all IPP client authentication mechanisms + -- it supports (one per IPP Channel entry). + -- See: [RFC2911] and [RFC2910]. + -- + -- IPP Printer Security + -- Keyword: Security + -- Syntax: Keyword + -- Status: Optional + -- Multiplicity: Single + -- Default: 'none' + -- Description: A security mechanism + -- supported for this IPP Printer URI: + -- 'none' + -- no security mechanism + -- 'ssl3' + -- SSL3 secure communications channel + -- protocol + -- 'tls' + -- TLS secure communications channel + -- protocol + -- Conformance: An IPP Printer should list + -- all IPP security mechanisms it supports + -- (one per IPP Channel entry). + -- See: [RFC2246], [RFC2911]. + -- + -- IPP Printer Protocol Version + -- Keyword: Version + -- Syntax: Keyword + -- Status: Optional + -- Multiplicity: Multiple + -- Default: '1.1' + -- Description: All of the IPP protocol + -- versions (major.minor) supported for + -- this IPP Printer URI: + -- '1.0' + -- IPP/1.0 conforming Printer + -- '1.1' + -- IPP/1.1 conforming Printer + + -- Conformance: An IPP Printer should list + -- all IPP versions it supports (all listed + -- in each IPP Channel entry). An IPP + -- Client should select the highest + -- numbered version the IPP Client supports + -- for use in all IPP Requests (for optimum + -- interworking). + -- See: [RFC2911]. + chSMTP(45) + -- Print Job submission via Simple Mail + -- Transfer Protocol (SMTP) - see [RFC2821] + -- + -- prtChannelInformation entry: + -- + -- Keyword: Mailto + -- Syntax: Name + -- Status: Mandatory + -- Multiplicity: Single + -- Default: not applicable + -- Description: The SMTP URL of the printer. +} + +-- +-- Interpreter Group TEXTUAL-CONVENTIONs +-- + +PrtInterpreterLangFamilyTC ::= TEXTUAL-CONVENTION + -- This TC was extracted from prtInterpreterLangFamily in RFC 1759. + STATUS current + DESCRIPTION + "This enumeration indicates the type of interpreter that is + receiving jobs." + SYNTAX INTEGER { + other(1), + unknown(2), -- Not in RFC 1759 + langPCL(3), -- PCL. Starting with PCL version 5, + -- HP-GL/2 is included as part of the + -- PCL language. + -- PCL and HP-GL/2 are registered + -- trademarks of Hewlett-Packard + -- Company. + langHPGL(4), -- Hewlett-Packard Graphics Language. + -- HP-GL is a registered trademark of + -- Hewlett-Packard Company. + langPJL(5), -- Peripheral Job Language. Appears in + -- the data stream between data intended + -- for a page description language. + -- Hewlett-Packard Co. + + langPS(6), -- PostScript (tm) Language + -- Postscript - a trademark of Adobe + -- Systems Incorporated which may be + -- registered in certain jurisdictions + langIPDS(7), -- Intelligent Printer Data Stream + -- Bi-directional print data stream for + -- documents consisting of data objects + -- (text, image, graphics, bar codes), + -- resources (fonts, overlays) and page, + -- form and finishing instructions. + -- Facilitates system level device + -- control, document tracking and error + -- recovery throughout the print + -- process. + -- IBM Corporation. + langPPDS(8), -- IBM Personal Printer Data Stream. + -- Originally called IBM ASCII, the name + -- was changed to PPDS when the Laser + -- Printer was introduced in 1989. + -- Lexmark International, Inc. + langEscapeP(9), -- Epson Corp. + langEpson(10), + langDDIF(11), -- Digital Document Interchange Format + -- Digital Equipment Corp., Maynard MA + langInterpress(12), + -- Xerox Corp. + langISO6429(13), -- ISO 6429. Control functions for + -- Coded Character Sets (has ASCII + -- control characters, plus additional + -- controls for + -- character imaging devices.) + langLineData(14), -- line-data: Lines of data as + -- separate ASCII or EBCDIC records + -- and containing no control functions + -- (no CR, LF, HT, FF, etc.) + -- For use with traditional line + -- printers. May use CR and/or LF to + -- delimit lines, instead of records. + -- See ISO 10175 Document Printing + -- Application (DPA) [ISO10175]. + langMODCA(15), -- Mixed Object Document Content + -- Architecture + -- Definitions that allow the + -- composition, interchange, and + -- presentation of final form + -- documents as a collection of data + -- objects (text, image, graphics, bar + -- codes), resources (fonts, overlays) + + -- and page, form and finishing + -- instructions. + -- IBM Corporation. + langREGIS(16), -- Remote Graphics Instruction Set, + -- Digital Equipment Corp., Maynard MA + langSCS(17), -- SNA Character String + -- Bi-directional print data stream for + -- SNA LU-1 mode of communication. + -- IBM + langSPDL(18), -- ISO 10180 Standard Page Description + -- Language + -- ISO Standard + langTEK4014(19), -- Tektronix Corp. + langPDS(20), + langIGP(21), -- Printronix Corp. + langCodeV(22), -- Magnum Code-V, Image and printer + -- control language used to control + -- impact/dot-matrix printers. + -- QMS, Inc., Mobile AL + langDSCDSE(23), -- DSC-DSE: Data Stream Compatible and + -- Emulation Bi-directional print data + -- stream for non-SNA (DSC) and SNA LU-3 + -- 3270 controller (DSE) communications + -- IBM + langWPS(24), -- Windows Printing System, Resource + -- based command/data stream used by + -- Microsoft At Work Peripherals. + -- Developed by the Microsoft + -- Corporation. + langLN03(25), -- Early DEC-PPL3, Digital Equipment + -- Corp. + langCCITT(26), + langQUIC(27), -- QUIC (Quality Information Code), Page + -- Description Language for laser + -- printers. Included graphics, printer + -- control capability and emulation of + -- other well-known printer. + -- QMS, Inc. + langCPAP(28), -- Common Printer Access Protocol + -- Digital Equipment Corp. + langDecPPL(29), -- Digital ANSI-Compliant Printing + -- Protocol + -- (DEC-PPL) + -- Digital Equipment Corp. + langSimpleText(30), + -- simple-text: character coded data, + -- including NUL, CR , LF, HT, and FF + -- control characters. See ISO 10175 + + -- Document Printing Application (DPA) + -- [ISO10175]. + langNPAP(31), -- Network Printer Alliance Protocol + -- (NPAP). This protocol has been + -- superseded by the IEEE 1284.1 TIPSI + -- Std (ref. LangTIPSI(49)). + langDOC(32), -- Document Option Commands, Appears in + -- the data stream between data + -- intended for a page description. + -- QMS, Inc. + langimPress(33), -- imPRESS, Page description language + -- originally developed for the + -- ImageServer product line. A binary + -- language providing representations + -- of text, simple graphics, and some + -- large forms (simple + -- bit-map and CCITT group 3/4 + -- encoded).The + -- language was intended to be sent over + -- an 8-bit channel and supported early + -- document preparation languages (e.g., + -- TeX and TROFF). + -- QMS, Inc. + langPinwriter(34), + -- 24 wire dot matrix printer for + -- USA, Europe, and Asia except + -- Japan. + -- More widely used in Germany, and + -- some Asian countries than in US. + -- NEC + langNPDL(35), -- Page printer for Japanese market. + -- NEC + langNEC201PL(36), -- Serial printer language used in + -- the Japanese market. + -- NEC + langAutomatic(37), + -- Automatic PDL sensing. Automatic + -- sensing of the interpreter + -- language family by the printer + -- examining the document content. + -- Which actual interpreter language + -- families are sensed depends on + -- the printer implementation. + langPages(38), -- Page printer Advanced Graphic + -- Escape Set + -- IBM Japan + langLIPS(39), -- LBP Image Processing System + langTIFF(40), -- Tagged Image File Format (Aldus) + + langDiagnostic(41), + -- A hex dump of the input to the + -- interpreter + langPSPrinter(42), + -- The PostScript Language used for + -- control (with any PDLs) + -- Adobe Systems Incorporated + langCaPSL(43), -- Canon Print Systems Language + langEXCL(44), -- Extended Command Language + -- Talaris Systems Inc. + langLCDS(45), -- Line Conditioned Data Stream + -- Xerox Corporation + langXES(46), -- Xerox Escape Sequences + -- Xerox Corporation + langPCLXL(47), -- Not in RFC 1759 + -- Printer Control Language. Extended + -- language features for printing, and + -- printer control. + -- Hewlett-Packard Co. + langART(48), -- Not in RFC 1759 + -- Advanced Rendering Tools (ART). + -- Page Description language + -- originally developed for the Laser + -- Press printers. + -- Technical reference manual: "ART IV + -- Reference Manual", No F33M. + -- Fuji Xerox Co., Ltd. + langTIPSI(49), -- Not in RFC 1759 + -- Transport Independent Printer + -- System Interface (ref. IEEE Std. + -- 1284.1) + langPrescribe(50), -- Not in RFC 1759 + -- Page description and printer + -- control language. It can be + -- described with ordinary ASCII + -- Technical reference manual: + -- "PRESCRIBE II Programming Manual" + langLinePrinter(51), -- Not in RFC 1759 + -- A simple-text character stream which + -- supports the control codes LF, VT, + -- FF, and plus Centronics or + -- Dataproducts Vertical Format Unit + -- (VFU) language is commonly used on + -- many older model line and matrix + -- printers. + langIDP(52), -- Not in RFC 1759 + -- Imaging Device Protocol + -- Apple Computer. + + langXJCL(53), -- Not in RFC 1759 + -- Xerox Job Control Language (JCL). + -- A Job Control language originally + -- developed for the LaserPress printers + -- and is capable of switching PDLs. + -- Technical reference manual: + -- "ART IV Reference Manual", No F33M. + -- Fuji Xerox Co., Ltd. + langPDF(54), -- Not in RFC 1759 + -- Adobe Portable Document Format + -- Adobe Systems, Inc. + langRPDL(55), -- Not in RFC 1759 + -- Ricoh Page Description Language for + -- printers. + -- Technical manual "RPDL command + -- reference" No.307029 + -- RICOH, Co. LTD + langIntermecIPL(56), -- Not in RFC 1759 + -- Intermec Printer Language for label + -- printers. + -- Technical Manual: "IPL Programmers + -- Reference Manual" + -- Intermec Corporation + langUBIFingerprint(57), -- Not in RFC 1759 + -- An intelligent basic-like programming + -- language for label printers. + -- Reference Manual: "UBI Fingerprint + -- 7.1", No. 1-960434-00 + -- United Barcode Industries + langUBIDirectProtocol(58), -- Not in RFC 1759 + -- An intelligent control language for + -- label printers. + -- Programmers guide: " UBI Direct + -- Protocol", No. 1-960419-00 + -- United Barcode Industries + langFujitsu(59), -- Not in RFC 1759 + -- Fujitsu Printer Language + -- Reference Manual: + -- "FM Printer Sequence" No. 80HP-0770 + -- FUJITSU LIMITED + langCGM(60), -- Not in RFC 1759 + -- Computer Graphics Metafile + -- MIME type 'image/cgm' + langJPEG(61), -- Not in RFC 1759 + -- Joint Photographic Experts Group + -- MIME type 'image/jpeg' + langCALS1(62), -- Not in RFC 1759 + -- US DOD CALS1 (see MIL-STD-1840) + + -- MIME type 'application/cals-1840' + langCALS2(63), -- Not in RFC 1759 + -- US DOD CALS2 (see MIL-STD-1840) + -- MIME type 'application/cals-1840' + langNIRS(64), -- Not in RFC 1759 + -- US DOD NIRS (see MIL-STD-1840) + -- MIME type 'application/cals-1840' + langC4(65) -- Not in RFC 1759 + -- US DOD C4 (see MIL-STD-1840) + -- MIME type 'application/cals-1840' +} + +-- +-- Input/Output Group TEXTUAL-CONVENTIONs +-- + +PrtInputTypeTC ::= TEXTUAL-CONVENTION + -- This TC was extracted from prtInputType in RFC 1759. + STATUS current + DESCRIPTION + "The type of technology (discriminated primarily according to + feeder mechanism type) employed by a specific component or + components." + SYNTAX INTEGER { + other(1), + unknown(2), + sheetFeedAutoRemovableTray(3), + sheetFeedAutoNonRemovableTray(4), + sheetFeedManual(5), + continuousRoll(6), + continuousFanFold(7) + } + +PrtOutputTypeTC ::= TEXTUAL-CONVENTION + -- This TC was extracted from prtOutputType in RFC 1759. + STATUS current + DESCRIPTION + "The Type of technology supported by this output subunit." + SYNTAX INTEGER { + other(1), + unknown(2), + removableBin(3), + unRemovableBin(4), + continuousRollDevice(5), + mailBox(6), + continuousFanFold(7) + } + +-- +-- Marker Group TEXTUAL-CONVENTIONs +-- + +PrtMarkerMarkTechTC ::= TEXTUAL-CONVENTION + -- This TC was extracted from prtMarkerMarkTech in RFC 1759. + STATUS current + DESCRIPTION + "The type of marking technology used for this marking + subunit." + SYNTAX INTEGER { + other(1), + unknown(2), + electrophotographicLED(3), + electrophotographicLaser(4), + electrophotographicOther(5), + impactMovingHeadDotMatrix9pin(6), + impactMovingHeadDotMatrix24pin(7), + impactMovingHeadDotMatrixOther(8), + impactMovingHeadFullyFormed(9), + impactBand(10), + impactOther(11), + inkjetAqueous(12), + inkjetSolid(13), + inkjetOther(14), + pen(15), + thermalTransfer(16), + thermalSensitive(17), + thermalDiffusion(18), + thermalOther(19), + electroerosion(20), + electrostatic(21), + photographicMicrofiche(22), + photographicImagesetter(23), + photographicOther(24), + ionDeposition(25), + eBeam(26), + typesetter(27) + } + +PrtMarkerSuppliesTypeTC ::= TEXTUAL-CONVENTION + -- This TC was extracted from prtMarkerSuppliesType in RFC 1759. + STATUS current + DESCRIPTION + "The type of this supply." + SYNTAX INTEGER { + other(1), + unknown(2), + + -- Values for Printer MIB + toner(3), + wasteToner(4), + ink(5), + inkCartridge(6), + inkRibbon(7), + wasteInk(8), + opc(9), -- photo conductor + developer(10), + fuserOil(11), + solidWax(12), + ribbonWax(13), + wasteWax(14), + fuser(15), -- Not in RFC 1759 + coronaWire(16), -- Not in RFC 1759 + fuserOilWick(17), -- Not in RFC 1759 + cleanerUnit(18), -- Not in RFC 1759 + fuserCleaningPad(19), -- Not in RFC 1759 + transferUnit(20), -- Not in RFC 1759 + tonerCartridge(21), -- Not in RFC 1759 + fuserOiler(22), -- Not in RFC 1759 + -- End of values for Printer MIB + -- Values for Finisher MIB + water(23), -- Not in RFC 1759 + wasteWater(24), -- Not in RFC 1759 + glueWaterAdditive(25),-- Not in RFC 1759 + wastePaper(26), -- Not in RFC 1759 + bindingSupply(27), -- Not in RFC 1759 + bandingSupply(28), -- Not in RFC 1759 + stitchingWire(29), -- Not in RFC 1759 + shrinkWrap(30), -- Not in RFC 1759 + paperWrap(31), -- Not in RFC 1759 + staples(32), -- Not in RFC 1759 + inserts(33), -- Not in RFC 1759 + covers(34) -- Not in RFC 1759 + -- End of values for Finisher MIB + } + +-- +-- Media Path TEXTUAL-CONVENTIONs +-- + +PrtMediaPathTypeTC ::= TEXTUAL-CONVENTION + -- This TC was extracted from prtMediaPathType in RFC 1759. + STATUS current + DESCRIPTION + "The type of the media path for this media path." + SYNTAX INTEGER { + + other(1), + unknown(2), + longEdgeBindingDuplex(3), + shortEdgeBindingDuplex(4), + simplex(5) + } + +-- +-- Console Group TEXTUAL-CONVENTIONs +-- + +PrtConsoleColorTC ::= TEXTUAL-CONVENTION + -- This TC was extracted from prtConsoleColor in RFC 1759. + STATUS current + DESCRIPTION + "The color of this light." + SYNTAX INTEGER { + other(1), + unknown(2), + white(3), + red(4), + green(5), + blue(6), + cyan(7), + magenta(8), + yellow(9), + orange(10) -- Not in RFC 1759 + } + +PrtConsoleDisableTC ::= TEXTUAL-CONVENTION + -- This TC was extracted from prtConsoleDisable in RFC 1759. + STATUS current + DESCRIPTION + "This value indicates whether or not input is accepted from + the operator console. A value of 'enabled' indicates that + input is accepted from the console, and a value of 'disabled' + indicates that input is not accepted from the console. " + SYNTAX INTEGER { + enabled(3), + disabled(4) + } + +-- +-- Alert Group TEXTUAL-CONVENTIONs +-- + +PrtAlertTrainingLevelTC ::= TEXTUAL-CONVENTION + -- This TC was extracted from prtAlertTrainingLevel in RFC 1759. + + STATUS current + DESCRIPTION + "The level of training required to handle this alert, if + human intervention is required. The noInterventionRequired + value should be used if the event does not require any human + intervention. The training level is an enumeration that is + determined and assigned by the printer manufacturer based on + the information or training required to handle this alert. + The printer will break alerts into these different training + levels. It is the responsibility of a management application + in the system to determine how a particular alert is handled + and how and to whom that alert is routed. The following are + the four training levels of alerts: + + Field Service - Alerts that typically require advanced + training and technical knowledge of the printer and its + subunits. An example of a technical person would be a + manufacturer's Field Service representative, or other + person formally trained by the manufacturer or similar + representative. + Trained - Alerts that require an intermediate or moderate + knowledge of the printer and its subunits. A typical + example of such an alert is replacing a toner cartridge. + Untrained - Alerts that can be fixed without prior + training either because the action to correct the alert + is obvious or the printer can help the untrained person + fix the problem. A typical example of such an alert is + reloading paper trays or emptying output bins on a low + end printer. + Management - Alerts that have to do with overall operation + of and configuration of the printer. Examples of such + management events are configuration change of subunits." + SYNTAX INTEGER { + other(1), + unknown(2), + untrained(3), + trained(4), + fieldService(5), + management(6), + noInterventionRequired(7) -- Not in RFC 1759 + } + +PrtAlertGroupTC ::= TEXTUAL-CONVENTION + -- Values in the range 1 to 29 must not be IANA-assigned without + -- re-publishing Printer MIB. + -- Values of 30 and greater are for use in MIBs that augment + -- the Printer MIB, such as the Finisher MIB. + -- This TC extracted from prtAlertGroup in RFC 1759. + + STATUS current + DESCRIPTION + "The type of subunit within the printer model that this alert + is related. Input, output, and markers are examples of + printer model groups, i.e., examples of types of subunits. + Wherever possible, the enumerations match the sub-identifier + that identifies the relevant table in the Printer MIB. + + NOTE: Alert type codes have been added for the Host Resources + MIB storage table and device table. These additional types + are for situations in which the printer's storage and device + objects must generate alerts (and possibly traps for critical + alerts)." + SYNTAX INTEGER { + other(1), + unknown(2), + -- Values for Host Resources MIB + hostResourcesMIBStorageTable(3), + hostResourcesMIBDeviceTable(4), + -- Values for Printer MIB + generalPrinter(5), + cover(6), + localization(7), + input(8), + output(9), + marker(10), + markerSupplies(11), + markerColorant(12), + mediaPath(13), + channel(14), + interpreter(15), + consoleDisplayBuffer(16), + consoleLights(17), + alert(18), -- Not in RFC 1759 + -- Values (5) to (29) reserved for Printer MIB + -- Values for Finisher MIB + finDevice(30), -- Not in RFC 1759 + finSupply(31), -- Not in RFC 1759 + finSupplyMediaInput(32), -- Not in RFC 1759 + finAttribute(33) -- Not in RFC 1759 + -- Values (30) to (39) reserved for Finisher MIB + } + +PrtAlertCodeTC ::= TEXTUAL-CONVENTION + -- This TC was extracted from prtAlertCode in RFC 1759. + STATUS current + DESCRIPTION + "The code that describes the type of alert for this entry in + + the table. Binary change event alerts describe states of the + subunit while unary change event alerts describe a single + event. The same alert code can be used for a binary change + event or a unary change event, depending on implementation. + Also, the same alert code can be used to indicate a critical + or non-critical (warning) alert, depending on implementation. + The value of prtAlertSeverityLevel specifies binary vs. unary + and critical vs. non-critical for each event for the + implementation. + + While there are some specific codes for many subunits, the + generic codes should be used for most subunit alerts. The + network management station can then query the subunit + specified by prtAlertGroup to determine further subunit + status and other subunit information. + + An agent shall not add two entries to the alert table for the + same event, one containing a generic event code and the other + containing a specific event code; the agent shall add only + one entry in the alert table for each event; either generic + (preferred) or specific, not both. + + Implementation of the unary change event + alertRemovalOfBinaryChangeEntry(1801) is optional. When + implemented, this alert code shall indicate to network + management stations that the trailing edge of a binary change + event has occurred and the corresponding alert entry has been + removed from the alert table. As with all events, the + alertRemovalOfBinaryChangeEntry(1801) alert shall be placed + at the end of the alert table. Such an alert table entry + shall specify the following information: + + prtAlertSeverityLevel warningUnaryChangeEvent(4) + prtAlertTrainingLevel noInterventionRequired(7) + prtAlertGroup alert(18) + prtAlertGroupIndex the index of the row in the + alert table of the binary + change event that this event + has removed. + prtAlertLocation unknown (-2) + prtAlertCode alertRemovalOfBinaryChangeEntry(1801) + prtAlertDescription <description or null string> + prtAlertTime the value of sysUpTime at + the time of the removal of the + binary change event from the + alert table. + + Optionally, the agent may generate a trap coincident with + + removing the binary change event and placing the unary change + event alertRemovalOfBinaryChangeEntry(1801) in the alert + table. For such a trap, the prtAlertIndex sent with the above + trap parameters shall be the index of the + alertRemovalOfBinaryChangeEvent row that was added to the + prtAlertTable; not the index of the row that was removed from + the prtAlertTable." + SYNTAX INTEGER { + other(1), + -- an event that is not represented + -- by one of the alert codes + -- specified below. + unknown(2), + -- The following generic codes are common to + -- multiple groups. The NMS may examine the + -- prtAlertGroup object to determine what group + -- to query for further information. + coverOpen(3), + coverClosed(4), + interlockOpen(5), + interlockClosed(6), + configurationChange(7), + jam(8), + subunitMissing(9), -- Not in RFC 1759 + -- The subunit tray, bin, etc. + -- has been removed. + subunitLifeAlmostOver(10), -- Not in RFC 1759 + subunitLifeOver(11), -- Not in RFC 1759 + subunitAlmostEmpty(12), -- Not in RFC 1759 + subunitEmpty(13), -- Not in RFC 1759 + subunitAlmostFull(14), -- Not in RFC 1759 + subunitFull(15), -- Not in RFC 1759 + subunitNearLimit(16), -- Not in RFC 1759 + subunitAtLimit(17), -- Not in RFC 1759 + subunitOpened(18), -- Not in RFC 1759 + subunitClosed(19), -- Not in RFC 1759 + subunitTurnedOn(20), -- Not in RFC 1759 + subunitTurnedOff(21), -- Not in RFC 1759 + subunitOffline(22), -- Not in RFC 1759 + subunitPowerSaver(23), -- Not in RFC 1759 + subunitWarmingUp(24), -- Not in RFC 1759 + subunitAdded(25), -- Not in RFC 1759 + subunitRemoved(26), -- Not in RFC 1759 + subunitResourceAdded(27), -- Not in RFC 1759 + subunitResourceRemoved(28), -- Not in RFC 1759 + subunitRecoverableFailure(29), + -- Not in RFC 1759 + subunitUnrecoverableFailure(30), + + -- Not in RFC 1759 + subunitRecoverableStorageError(31), + -- Not in RFC 1759 + subunitUnrecoverableStorageError(32), + -- Not in RFC 1759 + subunitMotorFailure(33), -- Not in RFC 1759 + subunitMemoryExhausted(34), -- Not in RFC 1759 + subunitUnderTemperature(35), -- Not in RFC 1759 + subunitOverTemperature(36), -- Not in RFC 1759 + subunitTimingFailure(37), -- Not in RFC 1759 + subunitThermistorFailure(38), -- Not in RFC 1759 + + -- General Printer group + doorOpen(501), -- DEPRECATED + -- Use coverOpened(3) + doorClosed(502), -- DEPRECATED + -- Use coverClosed(4) + powerUp(503), + powerDown(504), + printerNMSReset(505), -- Not in RFC 1759 + -- The printer has been reset by some + -- network management station(NMS) + -- writing into 'prtGeneralReset'. + printerManualReset(506), -- Not in RFC 1759 + -- The printer has been reset manually. + printerReadyToPrint(507), -- Not in RFC 1759 + -- The printer is ready to print. (i.e., + -- not warming up, not in power save + -- state, not adjusting print quality, + -- etc.). + + -- Input Group + inputMediaTrayMissing(801), + inputMediaSizeChange(802), + inputMediaWeightChange(803), + inputMediaTypeChange(804), + inputMediaColorChange(805), + inputMediaFormPartsChange(806), + inputMediaSupplyLow(807), + inputMediaSupplyEmpty(808), + inputMediaChangeRequest(809), -- Not in RFC 1759 + -- An interpreter has detected that a + -- different medium is need in this input + -- tray subunit. The prtAlertDescription may + -- be used to convey a human readable + -- description of the medium required to + -- satisfy the request. + inputManualInputRequest(810), -- Not in RFC 1759 + + -- An interpreter has detected that manual + -- input is required in this subunit. The + -- prtAlertDescription may be used to convey + -- a human readable description of the medium + -- required to satisfy the request. + inputTrayPositionFailure(811), -- Not in RFC 1759 + -- The input tray failed to position correctly. + inputTrayElevationFailure(812), + -- Not in RFC 1759 + inputCannotFeedSizeSelected(813), + -- Not in RFC 1759 + -- Output Group + outputMediaTrayMissing(901), + outputMediaTrayAlmostFull(902), + outputMediaTrayFull(903), + outputMailboxSelectFailure(904), + -- Not in RFC 1759 + -- Marker group + markerFuserUnderTemperature(1001), + markerFuserOverTemperature(1002), + markerFuserTimingFailure(1003), + -- Not in RFC 1759 + markerFuserThermistorFailure(1004), + -- Not in RFC 1759 + markerAdjustingPrintQuality(1005), + -- Not in RFC 1759 + -- Marker Supplies group + markerTonerEmpty(1101), + markerInkEmpty(1102), + markerPrintRibbonEmpty(1103), + markerTonerAlmostEmpty(1104), + markerInkAlmostEmpty(1105), + markerPrintRibbonAlmostEmpty(1106), + markerWasteTonerReceptacleAlmostFull(1107), + markerWasteInkReceptacleAlmostFull(1108), + markerWasteTonerReceptacleFull(1109), + markerWasteInkReceptacleFull(1110), + markerOpcLifeAlmostOver(1111), + markerOpcLifeOver(1112), + markerDeveloperAlmostEmpty(1113), + markerDeveloperEmpty(1114), + markerTonerCartridgeMissing(1115), + -- Not in RFC 1759 + -- Media Path Device Group + mediaPathMediaTrayMissing(1301), + mediaPathMediaTrayAlmostFull(1302), + mediaPathMediaTrayFull(1303), + mediaPathCannotDuplexMediaSelected(1304), + + -- Not in RFC 1759 + -- Interpreter Group + interpreterMemoryIncrease(1501), + interpreterMemoryDecrease(1502), + interpreterCartridgeAdded(1503), + interpreterCartridgeDeleted(1504), + interpreterResourceAdded(1505), + interpreterResourceDeleted(1506), + interpreterResourceUnavailable(1507), + interpreterComplexPageEncountered(1509), + -- Not in RFC 1759 + -- The interpreter has encountered a page + -- that is too complex for the resources that + -- are available. + -- Alert Group + alertRemovalOfBinaryChangeEntry(1801) + -- Not in RFC 1759 + -- A binary change event entry has been + -- removed from the alert table. This unary + -- change alert table entry is added to the + -- end of the alert table. + } +END + + diff --git a/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-RTPROTO-MIB b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-RTPROTO-MIB new file mode 100644 index 00000000000..952c84e250c --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANA-RTPROTO-MIB @@ -0,0 +1,92 @@ + +IANA-RTPROTO-MIB DEFINITIONS ::= BEGIN + +IMPORTS + MODULE-IDENTITY, mib-2 FROM SNMPv2-SMI + TEXTUAL-CONVENTION FROM SNMPv2-TC; + +ianaRtProtoMIB MODULE-IDENTITY + LAST-UPDATED "200009260000Z" -- September 26, 2000 + ORGANIZATION "IANA" + CONTACT-INFO + " Internet Assigned Numbers Authority + Internet Corporation for Assigned Names and Numbers + 4676 Admiralty Way, Suite 330 + Marina del Rey, CA 90292-6601 + + Phone: +1 310 823 9358 + EMail: iana&iana.org" + DESCRIPTION + "This MIB module defines the IANAipRouteProtocol and + IANAipMRouteProtocol textual conventions for use in MIBs + which need to identify unicast or multicast routing + mechanisms. + + Any additions or changes to the contents of this MIB module + require either publication of an RFC, or Designated Expert + Review as defined in RFC 2434, Guidelines for Writing an + IANA Considerations Section in RFCs. The Designated Expert + will be selected by the IESG Area Director(s) of the Routing + Area." + + REVISION "200009260000Z" -- September 26, 2000 + DESCRIPTION "Original version, published in coordination + with RFC 2932." + + ::= { mib-2 84 } + +IANAipRouteProtocol ::= TEXTUAL-CONVENTION + STATUS current + + DESCRIPTION + "A mechanism for learning routes. Inclusion of values for + routing protocols is not intended to imply that those + protocols need be supported." + SYNTAX INTEGER { + other (1), -- not specified + local (2), -- local interface + netmgmt (3), -- static route + icmp (4), -- result of ICMP Redirect + + -- the following are all dynamic + -- routing protocols + + egp (5), -- Exterior Gateway Protocol + ggp (6), -- Gateway-Gateway Protocol + hello (7), -- FuzzBall HelloSpeak + rip (8), -- Berkeley RIP or RIP-II + isIs (9), -- Dual IS-IS + esIs (10), -- ISO 9542 + ciscoIgrp (11), -- Cisco IGRP + bbnSpfIgp (12), -- BBN SPF IGP + ospf (13), -- Open Shortest Path First + bgp (14), -- Border Gateway Protocol + idpr (15), -- InterDomain Policy Routing + ciscoEigrp (16), -- Cisco EIGRP + dvmrp (17) -- DVMRP + } + +IANAipMRouteProtocol ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "The multicast routing protocol. Inclusion of values for + multicast routing protocols is not intended to imply that + those protocols need be supported." + SYNTAX INTEGER { + other(1), -- none of the following + local(2), -- e.g., manually configured + netmgmt(3), -- set via net.mgmt protocol + dvmrp(4), + mospf(5), + pimSparseDense(6), -- PIMv1, both DM and SM + cbt(7), + pimSparseMode(8), -- PIM-SM + pimDenseMode(9), -- PIM-DM + igmpOnly(10), + bgmp(11), + msdp(12) + } + +END + + diff --git a/contrib/apps/LwipMibCompiler/Mibs/IANA/IANATn3270eTC-MIB b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANATn3270eTC-MIB new file mode 100644 index 00000000000..e774ac009ea --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANATn3270eTC-MIB @@ -0,0 +1,306 @@ + + IANATn3270eTC-MIB DEFINITIONS ::= BEGIN + + IMPORTS + MODULE-IDENTITY, mib-2 + FROM SNMPv2-SMI + TEXTUAL-CONVENTION + FROM SNMPv2-TC; + + ianaTn3270eTcMib MODULE-IDENTITY + LAST-UPDATED "200005100000Z" -- May 10, 2000 + ORGANIZATION "IANA" + CONTACT-INFO + "Internet Assigned Numbers Authority + + Postal: ICANN + 4676 Admiralty Way, Suite 330 + Marina del Rey, CA 90292 + + Tel: +1 310 823 9358 x20 + E-Mail: iana&iana.org" + DESCRIPTION + "This module defines a set of textual conventions + for use by the TN3270E-MIB and the TN3270E-RT-MIB. + + Any additions or changes to the contents of this + MIB module must first be discussed on the tn3270e + working group list at: tn3270e&list.nih.gov + and approved by one of the following TN3270E + working group contacts: + + Ed Bailey (co-chair) - elbailey&us.ibm.com + Michael Boe (co-chair) - mboe&cisco.com + Ken White - kennethw&vnet.ibm.com + Robert Moore - remoore&us.ibm.com + + The above list of contacts can be altered with + the approval of the two co-chairs. + + The Textual Conventions defined within this MIB have + no security issues associated with them unless + explicitly stated in their corresponding + DESCRIPTION clause." + + -- revision log, in reverse chronological order + + REVISION "200005100000Z" -- May 10, 2000 + DESCRIPTION "Fix to import mib-2 instead of experimental." + + REVISION "199909011000Z" -- September 1, 1999 + DESCRIPTION + "Initial version transferred from the TN3270E + working group to IANA." + + ::= { mib-2 61 } + + + -- Textual Conventions + + IANATn3270eAddrType ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "The textual convention for defining the type of a + client address. The enumeration value unknown(0) is + also used to indicate that no actual address is present." + SYNTAX INTEGER { + unknown(0), + ipv4(1), + ipv6(2) + } + + IANATn3270eAddress ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "Denotes a client address. The type of client address is + determined by use of the IANATn3270eAddrType textual +convention. + The length in octets of a IANATn3270eAddress object is: + + IANATn3270eAddrType Address Length + +++++++++++++++++++ ++++++++++++++ + unknown(0) not specified or unknown; the + actual length of the + IANATn3270eAddress octet string + indicates if an address + is present + ipv4(1) 4 OCTETS + ipv6(2) 16 OCTETS + + This textual convention is similar to the TAddress + TC defined by RFC1903 except that it allows a + zero-length octet string and is not a full transport + layer address." + SYNTAX OCTET STRING (SIZE (0..255)) + + IANATn3270eClientType ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "The textual convention for defining the set of + enumerations used by tn3270eTcpConnClientIdFormat + in the TN3270E-MIB: + + ENUMERATION OCTETs DESCRIPTION + + none(1) 0 Not specified + other(2) 1..512 Implementation specific + ipv4(3) 6 4-octet IP Address plus + 2-octet TCP Port + ipv6(4) 18 16-octet IPv6 Address + plus 2-octet TCP Port + domainName(5) 1..512 The DNS name of a + client. + truncDomainName(6) 1..512 The (truncated) DNS name + of a client. + string(7) 1..512 Unknown Utf8String + certificate(8) 1..512 certificate + userId(9) 1..8 Client's userid + x509dn(10) 1..512 X.509 Distinguished Name + + Representation of a certificate(8) may be lead to + a security exposure and is NOT RECOMMENDED without + adequate security." + SYNTAX INTEGER { + none(1), + other(2), + ipv4(3), + ipv6(4), + domainName(5), + truncDomainName(6), + string(7), + certificate(8), + userId(9), + x509dn(10) + } + + IANATn3270Functions ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "This textual convention reflects the current set of + TN3270 and TN3270E functions that can be negotiated + between a server and its client: + + RFC856 + transmitBinary The sender of this command REQUESTS + permission to begin transmitting, or + confirms that it will now begin + transmitting characters which are to + be interpreted as 8 bits of binary + data by the receiver of the data. + RFC860 + timingMark The sender of this command REQUESTS + that the receiver of this command + return a WILL TIMING-MARK in the data + stream at the 'appropriate place'. + RFC885 + endOfRecord The sender of this command requests + permission to begin transmission of + the Telnet END-OF-RECORD (EOR) code + when transmitting data characters, or + the sender of this command confirms it + will now begin transmission of EORs + with transmitted data characters. + RFC1091 + terminalType Sender is willing to send terminal + type information in a subsequent + sub-negotiation. + + RFC1041 + tn3270Regime Sender is willing to send list of + supported 3270 Regimes in a + subsequent sub-negotiation. + RFC2355 + scsCtlCodes (Printer sessions only). Allows the + use of the SNA Character Stream (SCS) + and SCS control codes on the session. + SCS is used with LU type 1 SNA sessions. + dataStreamCtl (Printer sessions only). Allows the use + of the standard 3270 data stream. This + corresponds to LU type 3 SNA sessions. + responses Provides support for positive and + negative response handling. Allows the + server to reflect to the client any and + all definite, exception, and no response + requests sent by the host application. + bindImage Allows the server to send the SNA Bind + image and Unbind notification to the + client. + sysreq Allows the client and server to emulate + some (or all, depending on the server) of + the functions of the SYSREQ key in an SNA + environment." + SYNTAX BITS { + transmitBinary(0),-- rfc856 + timemark(1), -- rfc860 + endOfRecord(2), -- rfc885 + terminalType(3), -- rfc1091 + tn3270Regime(4), -- rfc1041 + scsCtlCodes(5), -- rfc2355 + dataStreamCtl(6), -- rfc2355 + responses(7), -- rfc2355 + bindImage(8), -- rfc2355 + sysreq(9) -- rfc2355 + } + + IANATn3270ResourceType ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "The type of resource defined by a resource pool. Refer + to tn3270eResPoolTable." + SYNTAX INTEGER { + other(1), + terminal(2), + printer(3), + terminalOrPrinter(4) + } + + IANATn3270DeviceType ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "This textual convention defines the list of device + types that can be set, as defined by RFC 2355." + SYNTAX INTEGER { + -- terminals + ibm3278d2(1), -- (24 row x 80 col display) + ibm3278d2E(2), -- (24 row x 80 col display) + ibm3278d3(3), -- (32 row x 80 col display) + ibm3278d3E(4), -- (32 row x 80 col display) + ibm3278d4(5), -- (43 row x 80 col display) + ibm3278d4E(6), -- (43 row x 80 col display) + ibm3278d5(7), -- (27 row x 132 col display) + ibm3278d5E(8), -- (27 row x 132 col display) + ibmDynamic(9), -- (no pre-defined display size) + + -- printers + ibm3287d1(10), + + unknown(100) + } + + IANATn3270eLogData ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "An octet string representing log data as pertaining to + either a TN3270 or TN3270E Session as reported from a + TN3270E Server. Log data is stored in an octet string + in time order (from earliest to latest). + + Each log element has the following form: + + +------+----+---------+------------+ + !length!type!TimeStamp! data ! + +------+----+---------+------------+ + + where + + length = one-octet length of the data portion of the + trace element, not including the length, + type, and TimeStamp fields + type = one-octet code point characterizing the data. + TimeStamp = A 4-octet field representing the number of + TimeTicks since the TN3270E server was last + activated. The server's last activation time + is available in the tn3270eSrvrConfLastActTime + object in the TN3270E MIB, which has the + syntax DateAndTime. + data = initial part of a PDU. + + length type + + 0-255 x'00' - unknown + 0 x'01' - inactivity timer expired + 0 x'02' - dynamic timer expired + 0 x'03' - actlu req + 0 x'04' - bind req + 0 x'05' - clear req + 0 x'06' - dactlu req + 0 x'07' - warm actpu req + 0 x'08' - sdt req + 0 x'09' - unbind req + 0 x'0A' - notify resp + 0 x'0B' - reply PSID neg rsp + 0 x'0C' - reply PSID pos rsp + 0 x'0D' - unbind rsp + 0 x'0E' - hierarchical reset + 0 x'0F' - client connect req + 0 x'10' - client disconnect req + 0 x'11' - timingmark received + 0 x'12' - flowControl timer expired + 0 x'13' - neg rsp to host + 0 x'14' - neg rsp from host + 0 x'15' - data contention + 0 x'16' - no buffer to send SNA data + 0 x'17' - receive response while inbound + 0 x'18' - client protocol error + 0 x'19' - badClientSequenceReceived + 1-255 x'1A' - utf8String + 2 x'1B' - hexCode, implementation dependent + + Log element entries have a minimum length of 6 octets. + The zero-length string indicates that no log data is + available." + SYNTAX OCTET STRING (SIZE (0 | 6..2048)) + + END + + diff --git a/contrib/apps/LwipMibCompiler/Mibs/IANA/IANAifType-MIB b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANAifType-MIB new file mode 100644 index 00000000000..39dddf9e266 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/IANA/IANAifType-MIB @@ -0,0 +1,572 @@ + IANAifType-MIB DEFINITIONS ::= BEGIN + + IMPORTS + MODULE-IDENTITY, mib-2 FROM SNMPv2-SMI + TEXTUAL-CONVENTION FROM SNMPv2-TC; + + ianaifType MODULE-IDENTITY + LAST-UPDATED "200709130000Z" -- September 13, 2007 + ORGANIZATION "IANA" + CONTACT-INFO " Internet Assigned Numbers Authority + + Postal: ICANN + 4676 Admiralty Way, Suite 330 + Marina del Rey, CA 90292 + + Tel: +1 310 823 9358 + E-Mail: iana&iana.org" + + DESCRIPTION "This MIB module defines the IANAifType Textual + Convention, and thus the enumerated values of + the ifType object defined in MIB-II's ifTable." + + REVISION "200709130000Z" -- September 13, 2007 + DESCRIPTION "Registration of new IANAifTypes 243 and 244." + + REVISION "200705290000Z" -- May 29, 2007 + DESCRIPTION "Changed the description for IANAifType 228." + + REVISION "200703080000Z" -- March 08, 2007 + DESCRIPTION "Registration of new IANAifType 242." + + REVISION "200701230000Z" -- January 23, 2007 + DESCRIPTION "Registration of new IANAifTypes 239, 240, and 241." + + REVISION "200610170000Z" -- October 17, 2006 + DESCRIPTION "Deprecated/Obsoleted IANAifType 230. Registration of + IANAifType 238." + + REVISION "200609250000Z" -- September 25, 2006 + DESCRIPTION "Changed the description for IANA ifType + 184 and added new IANA ifType 237." + + REVISION "200608170000Z" -- August 17, 2006 + DESCRIPTION "Changed the descriptions for IANAifTypes + 20 and 21." + + REVISION "200608110000Z" -- August 11, 2006 + DESCRIPTION "Changed the descriptions for IANAifTypes + 7, 11, 62, 69, and 117." + + REVISION "200607250000Z" -- July 25, 2006 + DESCRIPTION "Registration of new IANA ifType 236." + + REVISION "200606140000Z" -- June 14, 2006 + DESCRIPTION "Registration of new IANA ifType 235." + + REVISION "200603310000Z" -- March 31, 2006 + DESCRIPTION "Registration of new IANA ifType 234." + + REVISION "200603300000Z" -- March 30, 2006 + DESCRIPTION "Registration of new IANA ifType 233." + + REVISION "200512220000Z" -- December 22, 2005 + DESCRIPTION "Registration of new IANA ifTypes 231 and 232." + + REVISION "200510100000Z" -- October 10, 2005 + DESCRIPTION "Registration of new IANA ifType 230." + + REVISION "200509090000Z" -- September 09, 2005 + DESCRIPTION "Registration of new IANA ifType 229." + + REVISION "200505270000Z" -- May 27, 2005 + DESCRIPTION "Registration of new IANA ifType 228." + + REVISION "200503030000Z" -- March 3, 2005 + DESCRIPTION "Added the IANAtunnelType TC and deprecated + IANAifType sixToFour (215) per RFC4087." + + REVISION "200411220000Z" -- November 22, 2004 + DESCRIPTION "Registration of new IANA ifType 227 per RFC4631." + + REVISION "200406170000Z" -- June 17, 2004 + DESCRIPTION "Registration of new IANA ifType 226." + + REVISION "200405120000Z" -- May 12, 2004 + DESCRIPTION "Added description for IANAifType 6, and + changed the descriptions for IANAifTypes + 180, 181, and 182." + + REVISION "200405070000Z" -- May 7, 2004 + DESCRIPTION "Registration of new IANAifType 225." + + REVISION "200308250000Z" -- Aug 25, 2003 + DESCRIPTION "Deprecated IANAifTypes 7 and 11. Obsoleted + IANAifTypes 62, 69, and 117. ethernetCsmacd (6) + should be used instead of these values" + + REVISION "200308180000Z" -- Aug 18, 2003 + DESCRIPTION "Registration of new IANAifType + 224." + + REVISION "200308070000Z" -- Aug 7, 2003 + DESCRIPTION "Registration of new IANAifTypes + 222 and 223." + + REVISION "200303180000Z" -- Mar 18, 2003 + DESCRIPTION "Registration of new IANAifType + 221." + + REVISION "200301130000Z" -- Jan 13, 2003 + DESCRIPTION "Registration of new IANAifType + 220." + + REVISION "200210170000Z" -- Oct 17, 2002 + DESCRIPTION "Registration of new IANAifType + 219." + + REVISION "200207160000Z" -- Jul 16, 2002 + DESCRIPTION "Registration of new IANAifTypes + 217 and 218." + + REVISION "200207100000Z" -- Jul 10, 2002 + DESCRIPTION "Registration of new IANAifTypes + 215 and 216." + + REVISION "200206190000Z" -- Jun 19, 2002 + DESCRIPTION "Registration of new IANAifType + 214." + + REVISION "200201040000Z" -- Jan 4, 2002 + DESCRIPTION "Registration of new IANAifTypes + 211, 212 and 213." + + REVISION "200112200000Z" -- Dec 20, 2001 + DESCRIPTION "Registration of new IANAifTypes + 209 and 210." + + REVISION "200111150000Z" -- Nov 15, 2001 + DESCRIPTION "Registration of new IANAifTypes + 207 and 208." + + + REVISION "200111060000Z" -- Nov 6, 2001 + DESCRIPTION "Registration of new IANAifType + 206." + + + REVISION "200111020000Z" -- Nov 2, 2001 + DESCRIPTION "Registration of new IANAifType + 205." + + + REVISION "200110160000Z" -- Oct 16, 2001 + DESCRIPTION "Registration of new IANAifTypes + 199, 200, 201, 202, 203, and 204." + + + REVISION "200109190000Z" -- Sept 19, 2001 + DESCRIPTION "Registration of new IANAifType + 198." + + REVISION "200105110000Z" -- May 11, 2001 + DESCRIPTION "Registration of new IANAifType + 197." + + + REVISION "200101120000Z" -- Jan 12, 2001 + DESCRIPTION "Registration of new IANAifTypes + 195 and 196." + + REVISION "200012190000Z" -- Dec 19, 2000 + DESCRIPTION "Registration of new IANAifTypes + 193 and 194." + + REVISION "200012070000Z" -- Dec 07, 2000 + DESCRIPTION "Registration of new IANAifTypes + 191 and 192." + + REVISION "200012040000Z" -- Dec 04, 2000 + DESCRIPTION "Registration of new IANAifType + 190." + + REVISION "200010170000Z" -- Oct 17, 2000 + DESCRIPTION "Registration of new IANAifTypes + 188 and 189." + + REVISION "200010020000Z" -- Oct 02, 2000 + DESCRIPTION "Registration of new IANAifType 187." + + REVISION "200009010000Z" -- Sept 01, 2000 + DESCRIPTION "Registration of new IANAifTypes + 184, 185, and 186." + + REVISION "200008240000Z" -- Aug 24, 2000 + DESCRIPTION "Registration of new IANAifType 183." + + REVISION "200008230000Z" -- Aug 23, 2000 + DESCRIPTION "Registration of new IANAifTypes + 174-182." + + REVISION "200008220000Z" -- Aug 22, 2000 + DESCRIPTION "Registration of new IANAifTypes 170, + 171, 172 and 173." + + REVISION "200004250000Z" -- Apr 25, 2000 + DESCRIPTION "Registration of new IANAifTypes 168 and 169." + + REVISION "200003060000Z" -- Mar 6, 2000 + DESCRIPTION "Fixed a missing semi-colon in the IMPORT. + Also cleaned up the REVISION log a bit. + It is not complete, but from now on it will + be maintained and kept up to date with each + change to this MIB module." + + REVISION "199910081430Z" -- Oct 08, 1999 + DESCRIPTION "Include new name assignments up to cnr(85). + This is the first version available via the WWW + at: ftp://ftp.isi.edu/mib/ianaiftype.mib" + + REVISION "199401310000Z" -- Jan 31, 1994 + DESCRIPTION "Initial version of this MIB as published in + RFC 1573." + + ::= { mib-2 30 } + + + IANAifType ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "This data type is used as the syntax of the ifType + object in the (updated) definition of MIB-II's + ifTable. + + The definition of this textual convention with the + addition of newly assigned values is published + periodically by the IANA, in either the Assigned + Numbers RFC, or some derivative of it specific to + Internet Network Management number assignments. (The + latest arrangements can be obtained by contacting the + IANA.) + + Requests for new values should be made to IANA via + email (iana&iana.org). + + The relationship between the assignment of ifType + values and of OIDs to particular media-specific MIBs + is solely the purview of IANA and is subject to change + without notice. Quite often, a media-specific MIB's + OID-subtree assignment within MIB-II's 'transmission' + subtree will be the same as its ifType value. + However, in some circumstances this will not be the + case, and implementors must not pre-assume any + specific relationship between ifType values and + transmission subtree OIDs." + SYNTAX INTEGER { + other(1), -- none of the following + regular1822(2), + hdh1822(3), + ddnX25(4), + rfc877x25(5), + ethernetCsmacd(6), -- for all ethernet-like interfaces, + -- regardless of speed, as per RFC3635 + iso88023Csmacd(7), -- Deprecated via RFC3635 + -- ethernetCsmacd (6) should be used instead + iso88024TokenBus(8), + iso88025TokenRing(9), + iso88026Man(10), + starLan(11), -- Deprecated via RFC3635 + -- ethernetCsmacd (6) should be used instead + proteon10Mbit(12), + proteon80Mbit(13), + hyperchannel(14), + fddi(15), + lapb(16), + sdlc(17), + ds1(18), -- DS1-MIB + e1(19), -- Obsolete see DS1-MIB + basicISDN(20), -- no longer used + -- see also RFC2127 + primaryISDN(21), -- no longer used + -- see also RFC2127 + propPointToPointSerial(22), -- proprietary serial + ppp(23), + softwareLoopback(24), + eon(25), -- CLNP over IP + ethernet3Mbit(26), + nsip(27), -- XNS over IP + slip(28), -- generic SLIP + ultra(29), -- ULTRA technologies + ds3(30), -- DS3-MIB + sip(31), -- SMDS, coffee + frameRelay(32), -- DTE only. + rs232(33), + para(34), -- parallel-port + arcnet(35), -- arcnet + arcnetPlus(36), -- arcnet plus + atm(37), -- ATM cells + miox25(38), + sonet(39), -- SONET or SDH + x25ple(40), + iso88022llc(41), + localTalk(42), + smdsDxi(43), + frameRelayService(44), -- FRNETSERV-MIB + v35(45), + hssi(46), + hippi(47), + modem(48), -- Generic modem + aal5(49), -- AAL5 over ATM + sonetPath(50), + sonetVT(51), + smdsIcip(52), -- SMDS InterCarrier Interface + propVirtual(53), -- proprietary virtual/internal + propMultiplexor(54),-- proprietary multiplexing + ieee80212(55), -- 100BaseVG + fibreChannel(56), -- Fibre Channel + hippiInterface(57), -- HIPPI interfaces + frameRelayInterconnect(58), -- Obsolete use either + -- frameRelay(32) or + -- frameRelayService(44). + aflane8023(59), -- ATM Emulated LAN for 802.3 + aflane8025(60), -- ATM Emulated LAN for 802.5 + cctEmul(61), -- ATM Emulated circuit + fastEther(62), -- Obsoleted via RFC3635 + -- ethernetCsmacd (6) should be used instead + isdn(63), -- ISDN and X.25 + v11(64), -- CCITT V.11/X.21 + v36(65), -- CCITT V.36 + g703at64k(66), -- CCITT G703 at 64Kbps + g703at2mb(67), -- Obsolete see DS1-MIB + qllc(68), -- SNA QLLC + fastEtherFX(69), -- Obsoleted via RFC3635 + -- ethernetCsmacd (6) should be used instead + channel(70), -- channel + ieee80211(71), -- radio spread spectrum + ibm370parChan(72), -- IBM System 360/370 OEMI Channel + escon(73), -- IBM Enterprise Systems Connection + dlsw(74), -- Data Link Switching + isdns(75), -- ISDN S/T interface + isdnu(76), -- ISDN U interface + lapd(77), -- Link Access Protocol D + ipSwitch(78), -- IP Switching Objects + rsrb(79), -- Remote Source Route Bridging + atmLogical(80), -- ATM Logical Port + ds0(81), -- Digital Signal Level 0 + ds0Bundle(82), -- group of ds0s on the same ds1 + bsc(83), -- Bisynchronous Protocol + async(84), -- Asynchronous Protocol + cnr(85), -- Combat Net Radio + iso88025Dtr(86), -- ISO 802.5r DTR + eplrs(87), -- Ext Pos Loc Report Sys + arap(88), -- Appletalk Remote Access Protocol + propCnls(89), -- Proprietary Connectionless Protocol + hostPad(90), -- CCITT-ITU X.29 PAD Protocol + termPad(91), -- CCITT-ITU X.3 PAD Facility + frameRelayMPI(92), -- Multiproto Interconnect over FR + x213(93), -- CCITT-ITU X213 + adsl(94), -- Asymmetric Digital Subscriber Loop + radsl(95), -- Rate-Adapt. Digital Subscriber Loop + sdsl(96), -- Symmetric Digital Subscriber Loop + vdsl(97), -- Very H-Speed Digital Subscrib. Loop + iso88025CRFPInt(98), -- ISO 802.5 CRFP + myrinet(99), -- Myricom Myrinet + voiceEM(100), -- voice recEive and transMit + voiceFXO(101), -- voice Foreign Exchange Office + voiceFXS(102), -- voice Foreign Exchange Station + voiceEncap(103), -- voice encapsulation + voiceOverIp(104), -- voice over IP encapsulation + atmDxi(105), -- ATM DXI + atmFuni(106), -- ATM FUNI + atmIma (107), -- ATM IMA + pppMultilinkBundle(108), -- PPP Multilink Bundle + ipOverCdlc (109), -- IBM ipOverCdlc + ipOverClaw (110), -- IBM Common Link Access to Workstn + stackToStack (111), -- IBM stackToStack + virtualIpAddress (112), -- IBM VIPA + mpc (113), -- IBM multi-protocol channel support + ipOverAtm (114), -- IBM ipOverAtm + iso88025Fiber (115), -- ISO 802.5j Fiber Token Ring + tdlc (116), -- IBM twinaxial data link control + gigabitEthernet (117), -- Obsoleted via RFC3635 + -- ethernetCsmacd (6) should be used instead + hdlc (118), -- HDLC + lapf (119), -- LAP F + v37 (120), -- V.37 + x25mlp (121), -- Multi-Link Protocol + x25huntGroup (122), -- X25 Hunt Group + trasnpHdlc (123), -- Transp HDLC + interleave (124), -- Interleave channel + fast (125), -- Fast channel + ip (126), -- IP (for APPN HPR in IP networks) + docsCableMaclayer (127), -- CATV Mac Layer + docsCableDownstream (128), -- CATV Downstream interface + docsCableUpstream (129), -- CATV Upstream interface + a12MppSwitch (130), -- Avalon Parallel Processor + tunnel (131), -- Encapsulation interface + coffee (132), -- coffee pot + ces (133), -- Circuit Emulation Service + atmSubInterface (134), -- ATM Sub Interface + l2vlan (135), -- Layer 2 Virtual LAN using 802.1Q + l3ipvlan (136), -- Layer 3 Virtual LAN using IP + l3ipxvlan (137), -- Layer 3 Virtual LAN using IPX + digitalPowerline (138), -- IP over Power Lines + mediaMailOverIp (139), -- Multimedia Mail over IP + dtm (140), -- Dynamic syncronous Transfer Mode + dcn (141), -- Data Communications Network + ipForward (142), -- IP Forwarding Interface + msdsl (143), -- Multi-rate Symmetric DSL + ieee1394 (144), -- IEEE1394 High Performance Serial Bus + if-gsn (145), -- HIPPI-6400 + dvbRccMacLayer (146), -- DVB-RCC MAC Layer + dvbRccDownstream (147), -- DVB-RCC Downstream Channel + dvbRccUpstream (148), -- DVB-RCC Upstream Channel + atmVirtual (149), -- ATM Virtual Interface + mplsTunnel (150), -- MPLS Tunnel Virtual Interface + srp (151), -- Spatial Reuse Protocol + voiceOverAtm (152), -- Voice Over ATM + voiceOverFrameRelay (153), -- Voice Over Frame Relay + idsl (154), -- Digital Subscriber Loop over ISDN + compositeLink (155), -- Avici Composite Link Interface + ss7SigLink (156), -- SS7 Signaling Link + propWirelessP2P (157), -- Prop. P2P wireless interface + frForward (158), -- Frame Forward Interface + rfc1483 (159), -- Multiprotocol over ATM AAL5 + usb (160), -- USB Interface + ieee8023adLag (161), -- IEEE 802.3ad Link Aggregate + bgppolicyaccounting (162), -- BGP Policy Accounting + frf16MfrBundle (163), -- FRF .16 Multilink Frame Relay + h323Gatekeeper (164), -- H323 Gatekeeper + h323Proxy (165), -- H323 Voice and Video Proxy + mpls (166), -- MPLS + mfSigLink (167), -- Multi-frequency signaling link + hdsl2 (168), -- High Bit-Rate DSL - 2nd generation + shdsl (169), -- Multirate HDSL2 + ds1FDL (170), -- Facility Data Link 4Kbps on a DS1 + pos (171), -- Packet over SONET/SDH Interface + dvbAsiIn (172), -- DVB-ASI Input + dvbAsiOut (173), -- DVB-ASI Output + plc (174), -- Power Line Communtications + nfas (175), -- Non Facility Associated Signaling + tr008 (176), -- TR008 + gr303RDT (177), -- Remote Digital Terminal + gr303IDT (178), -- Integrated Digital Terminal + isup (179), -- ISUP + propDocsWirelessMaclayer (180), -- Cisco proprietary Maclayer + propDocsWirelessDownstream (181), -- Cisco proprietary Downstream + propDocsWirelessUpstream (182), -- Cisco proprietary Upstream + hiperlan2 (183), -- HIPERLAN Type 2 Radio Interface + propBWAp2Mp (184), -- PropBroadbandWirelessAccesspt2multipt + -- use of this iftype for IEEE 802.16 WMAN + -- interfaces as per IEEE Std 802.16f is + -- deprecated and ifType 237 should be used instead. + sonetOverheadChannel (185), -- SONET Overhead Channel + digitalWrapperOverheadChannel (186), -- Digital Wrapper + aal2 (187), -- ATM adaptation layer 2 + radioMAC (188), -- MAC layer over radio links + atmRadio (189), -- ATM over radio links + imt (190), -- Inter Machine Trunks + mvl (191), -- Multiple Virtual Lines DSL + reachDSL (192), -- Long Reach DSL + frDlciEndPt (193), -- Frame Relay DLCI End Point + atmVciEndPt (194), -- ATM VCI End Point + opticalChannel (195), -- Optical Channel + opticalTransport (196), -- Optical Transport + propAtm (197), -- Proprietary ATM + voiceOverCable (198), -- Voice Over Cable Interface + infiniband (199), -- Infiniband + teLink (200), -- TE Link + q2931 (201), -- Q.2931 + virtualTg (202), -- Virtual Trunk Group + sipTg (203), -- SIP Trunk Group + sipSig (204), -- SIP Signaling + docsCableUpstreamChannel (205), -- CATV Upstream Channel + econet (206), -- Acorn Econet + pon155 (207), -- FSAN 155Mb Symetrical PON interface + pon622 (208), -- FSAN622Mb Symetrical PON interface + bridge (209), -- Transparent bridge interface + linegroup (210), -- Interface common to multiple lines + voiceEMFGD (211), -- voice E&M Feature Group D + voiceFGDEANA (212), -- voice FGD Exchange Access North American + voiceDID (213), -- voice Direct Inward Dialing + mpegTransport (214), -- MPEG transport interface + sixToFour (215), -- 6to4 interface (DEPRECATED) + gtp (216), -- GTP (GPRS Tunneling Protocol) + pdnEtherLoop1 (217), -- Paradyne EtherLoop 1 + pdnEtherLoop2 (218), -- Paradyne EtherLoop 2 + opticalChannelGroup (219), -- Optical Channel Group + homepna (220), -- HomePNA ITU-T G.989 + gfp (221), -- Generic Framing Procedure (GFP) + ciscoISLvlan (222), -- Layer 2 Virtual LAN using Cisco ISL + actelisMetaLOOP (223), -- Acteleis proprietary MetaLOOP High Speed Link + fcipLink (224), -- FCIP Link + rpr (225), -- Resilient Packet Ring Interface Type + qam (226), -- RF Qam Interface + lmp (227), -- Link Management Protocol + cblVectaStar (228), -- Cambridge Broadband Networks Limited VectaStar + docsCableMCmtsDownstream (229), -- CATV Modular CMTS Downstream Interface + adsl2 (230), -- Asymmetric Digital Subscriber Loop Version 2 + -- (DEPRECATED/OBSOLETED - please use adsl2plus 238 instead) + macSecControlledIF (231), -- MACSecControlled + macSecUncontrolledIF (232), -- MACSecUncontrolled + aviciOpticalEther (233), -- Avici Optical Ethernet Aggregate + atmbond (234), -- atmbond + voiceFGDOS (235), -- voice FGD Operator Services + mocaVersion1 (236), -- MultiMedia over Coax Alliance (MoCA) Interface + -- as documented in information provided privately to IANA + ieee80216WMAN (237), -- IEEE 802.16 WMAN interface + adsl2plus (238), -- Asymmetric Digital Subscriber Loop Version 2, + -- Version 2 Plus and all variants + dvbRcsMacLayer (239), -- DVB-RCS MAC Layer + dvbTdm (240), -- DVB Satellite TDM + dvbRcsTdma (241), -- DVB-RCS TDMA + x86Laps (242), -- LAPS based on ITU-T X.86/Y.1323 + wwanPP (243), -- 3GPP WWAN + wwanPP2 (244) -- 3GPP2 WWAN + } + +IANAtunnelType ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "The encapsulation method used by a tunnel. The value + direct indicates that a packet is encapsulated + directly within a normal IP header, with no + intermediate header, and unicast to the remote tunnel + endpoint (e.g., an RFC 2003 IP-in-IP tunnel, or an RFC + 1933 IPv6-in-IPv4 tunnel). The value minimal indicates + that a Minimal Forwarding Header (RFC 2004) is + inserted between the outer header and the payload + packet. The value UDP indicates that the payload + packet is encapsulated within a normal UDP packet + (e.g., RFC 1234). + + The values sixToFour, sixOverFour, and isatap + indicates that an IPv6 packet is encapsulated directly + within an IPv4 header, with no intermediate header, + and unicast to the destination determined by the 6to4, + 6over4, or ISATAP protocol. + + The remaining protocol-specific values indicate that a + header of the protocol of that name is inserted + between the outer header and the payload header. + + The assignment policy for IANAtunnelType values is + identical to the policy for assigning IANAifType + values." + SYNTAX INTEGER { + other(1), -- none of the following + direct(2), -- no intermediate header + gre(3), -- GRE encapsulation + minimal(4), -- Minimal encapsulation + l2tp(5), -- L2TP encapsulation + pptp(6), -- PPTP encapsulation + l2f(7), -- L2F encapsulation + udp(8), -- UDP encapsulation + atmp(9), -- ATMP encapsulation + msdp(10), -- MSDP encapsulation + sixToFour(11), -- 6to4 encapsulation + sixOverFour(12), -- 6over4 encapsulation + isatap(13), -- ISATAP encapsulation + teredo(14) -- Teredo encapsulation + } + + END + + + + + + + + + diff --git a/contrib/apps/LwipMibCompiler/Mibs/IF-MIB b/contrib/apps/LwipMibCompiler/Mibs/IF-MIB new file mode 100644 index 00000000000..871389436b0 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/IF-MIB @@ -0,0 +1,1899 @@ +IF-MIB DEFINITIONS ::= BEGIN + +IMPORTS + MODULE-IDENTITY, OBJECT-TYPE, Counter32, Gauge32, Counter64, + Integer32, TimeTicks, mib-2, + NOTIFICATION-TYPE FROM SNMPv2-SMI + TEXTUAL-CONVENTION, DisplayString, + PhysAddress, TruthValue, RowStatus, + TimeStamp, AutonomousType, TestAndIncr FROM SNMPv2-TC + MODULE-COMPLIANCE, OBJECT-GROUP, + NOTIFICATION-GROUP FROM SNMPv2-CONF + snmpTraps FROM SNMPv2-MIB + IANAifType FROM IANAifType-MIB; + + +ifMIB MODULE-IDENTITY + LAST-UPDATED "200006140000Z" + ORGANIZATION "IETF Interfaces MIB Working Group" + CONTACT-INFO + " Keith McCloghrie + Cisco Systems, Inc. + 170 West Tasman Drive + San Jose, CA 95134-1706 + US + + 408-526-5260 + kzm@cisco.com" + DESCRIPTION + "The MIB module to describe generic objects for network + interface sub-layers. This MIB is an updated version of + MIB-II's ifTable, and incorporates the extensions defined in + RFC 1229." + + + REVISION "200006140000Z" + DESCRIPTION + "Clarifications agreed upon by the Interfaces MIB WG, and + published as RFC 2863." + REVISION "199602282155Z" + DESCRIPTION + "Revisions made by the Interfaces MIB WG, and published in + RFC 2233." + REVISION "199311082155Z" + DESCRIPTION + "Initial revision, published as part of RFC 1573." + ::= { mib-2 31 } + + +ifMIBObjects OBJECT IDENTIFIER ::= { ifMIB 1 } + +interfaces OBJECT IDENTIFIER ::= { mib-2 2 } + +-- +-- Textual Conventions +-- + + +-- OwnerString has the same semantics as used in RFC 1271 + +OwnerString ::= TEXTUAL-CONVENTION + DISPLAY-HINT "255a" + STATUS deprecated + DESCRIPTION + "This data type is used to model an administratively + assigned name of the owner of a resource. This information + is taken from the NVT ASCII character set. It is suggested + that this name contain one or more of the following: ASCII + form of the manager station's transport address, management + station name (e.g., domain name), network management + personnel's name, location, or phone number. In some cases + the agent itself will be the owner of an entry. In these + cases, this string shall be set to a string starting with + 'agent'." + SYNTAX OCTET STRING (SIZE(0..255)) + +-- InterfaceIndex contains the semantics of ifIndex and should be used +-- for any objects defined in other MIB modules that need these semantics. + +InterfaceIndex ::= TEXTUAL-CONVENTION + DISPLAY-HINT "d" + STATUS current + DESCRIPTION + + + "A unique value, greater than zero, for each interface or + interface sub-layer in the managed system. It is + recommended that values are assigned contiguously starting + from 1. The value for each interface sub-layer must remain + constant at least from one re-initialization of the entity's + network management system to the next re-initialization." + SYNTAX Integer32 (1..2147483647) + +InterfaceIndexOrZero ::= TEXTUAL-CONVENTION + DISPLAY-HINT "d" + STATUS current + DESCRIPTION + "This textual convention is an extension of the + InterfaceIndex convention. The latter defines a greater + than zero value used to identify an interface or interface + sub-layer in the managed system. This extension permits the + additional value of zero. the value zero is object-specific + and must therefore be defined as part of the description of + any object which uses this syntax. Examples of the usage of + zero might include situations where interface was unknown, + or when none or all interfaces need to be referenced." + SYNTAX Integer32 (0..2147483647) + +ifNumber OBJECT-TYPE + SYNTAX Integer32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of network interfaces (regardless of their + current state) present on this system." + ::= { interfaces 1 } + +ifTableLastChange OBJECT-TYPE + SYNTAX TimeTicks + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The value of sysUpTime at the time of the last creation or + deletion of an entry in the ifTable. If the number of + entries has been unchanged since the last re-initialization + of the local network management subsystem, then this object + contains a zero value." + ::= { ifMIBObjects 5 } + + +-- the Interfaces table + +-- The Interfaces table contains information on the entity's + + +-- interfaces. Each sub-layer below the internetwork-layer +-- of a network interface is considered to be an interface. + +ifTable OBJECT-TYPE + SYNTAX SEQUENCE OF IfEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "A list of interface entries. The number of entries is + given by the value of ifNumber." + ::= { interfaces 2 } + +ifEntry OBJECT-TYPE + SYNTAX IfEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "An entry containing management information applicable to a + particular interface." + INDEX { ifIndex } + ::= { ifTable 1 } + +IfEntry ::= + SEQUENCE { + ifIndex InterfaceIndex, + ifDescr DisplayString, + ifType IANAifType, + ifMtu Integer32, + ifSpeed Gauge32, + ifPhysAddress PhysAddress, + ifAdminStatus INTEGER, + ifOperStatus INTEGER, + ifLastChange TimeTicks, + ifInOctets Counter32, + ifInUcastPkts Counter32, + ifInNUcastPkts Counter32, -- deprecated + ifInDiscards Counter32, + ifInErrors Counter32, + ifInUnknownProtos Counter32, + ifOutOctets Counter32, + ifOutUcastPkts Counter32, + ifOutNUcastPkts Counter32, -- deprecated + ifOutDiscards Counter32, + ifOutErrors Counter32, + ifOutQLen Gauge32, -- deprecated + ifSpecific OBJECT IDENTIFIER -- deprecated + } + + + +ifIndex OBJECT-TYPE + SYNTAX InterfaceIndex + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "A unique value, greater than zero, for each interface. It + is recommended that values are assigned contiguously + starting from 1. The value for each interface sub-layer + must remain constant at least from one re-initialization of + the entity's network management system to the next re- + initialization." + ::= { ifEntry 1 } + +ifDescr OBJECT-TYPE + SYNTAX DisplayString (SIZE (0..255)) + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "A textual string containing information about the + interface. This string should include the name of the + manufacturer, the product name and the version of the + interface hardware/software." + ::= { ifEntry 2 } + +ifType OBJECT-TYPE + SYNTAX IANAifType + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The type of interface. Additional values for ifType are + assigned by the Internet Assigned Numbers Authority (IANA), + through updating the syntax of the IANAifType textual + convention." + ::= { ifEntry 3 } + +ifMtu OBJECT-TYPE + SYNTAX Integer32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The size of the largest packet which can be sent/received + on the interface, specified in octets. For interfaces that + are used for transmitting network datagrams, this is the + size of the largest network datagram that can be sent on the + interface." + ::= { ifEntry 4 } + +ifSpeed OBJECT-TYPE + + + SYNTAX Gauge32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "An estimate of the interface's current bandwidth in bits + per second. For interfaces which do not vary in bandwidth + or for those where no accurate estimation can be made, this + object should contain the nominal bandwidth. If the + bandwidth of the interface is greater than the maximum value + reportable by this object then this object should report its + maximum value (4,294,967,295) and ifHighSpeed must be used + to report the interace's speed. For a sub-layer which has + no concept of bandwidth, this object should be zero." + ::= { ifEntry 5 } + +ifPhysAddress OBJECT-TYPE + SYNTAX PhysAddress + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The interface's address at its protocol sub-layer. For + example, for an 802.x interface, this object normally + contains a MAC address. The interface's media-specific MIB + must define the bit and byte ordering and the format of the + value of this object. For interfaces which do not have such + an address (e.g., a serial line), this object should contain + an octet string of zero length." + ::= { ifEntry 6 } + +ifAdminStatus OBJECT-TYPE + SYNTAX INTEGER { + up(1), -- ready to pass packets + down(2), + testing(3) -- in some test mode + } + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "The desired state of the interface. The testing(3) state + indicates that no operational packets can be passed. When a + managed system initializes, all interfaces start with + ifAdminStatus in the down(2) state. As a result of either + explicit management action or per configuration information + retained by the managed system, ifAdminStatus is then + changed to either the up(1) or testing(3) states (or remains + in the down(2) state)." + ::= { ifEntry 7 } + + + +ifOperStatus OBJECT-TYPE + SYNTAX INTEGER { + up(1), -- ready to pass packets + down(2), + testing(3), -- in some test mode + unknown(4), -- status can not be determined + -- for some reason. + dormant(5), + notPresent(6), -- some component is missing + lowerLayerDown(7) -- down due to state of + -- lower-layer interface(s) + } + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The current operational state of the interface. The + testing(3) state indicates that no operational packets can + be passed. If ifAdminStatus is down(2) then ifOperStatus + should be down(2). If ifAdminStatus is changed to up(1) + then ifOperStatus should change to up(1) if the interface is + ready to transmit and receive network traffic; it should + change to dormant(5) if the interface is waiting for + external actions (such as a serial line waiting for an + incoming connection); it should remain in the down(2) state + if and only if there is a fault that prevents it from going + to the up(1) state; it should remain in the notPresent(6) + state if the interface has missing (typically, hardware) + components." + ::= { ifEntry 8 } + +ifLastChange OBJECT-TYPE + SYNTAX TimeTicks + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The value of sysUpTime at the time the interface entered + its current operational state. If the current state was + entered prior to the last re-initialization of the local + network management subsystem, then this object contains a + zero value." + ::= { ifEntry 9 } + +ifInOctets OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets received on the interface, + + + including framing characters. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifEntry 10 } + +ifInUcastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of packets, delivered by this sub-layer to a + higher (sub-)layer, which were not addressed to a multicast + or broadcast address at this sub-layer. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifEntry 11 } + +ifInNUcastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of packets, delivered by this sub-layer to a + higher (sub-)layer, which were addressed to a multicast or + broadcast address at this sub-layer. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime. + + This object is deprecated in favour of ifInMulticastPkts and + ifInBroadcastPkts." + ::= { ifEntry 12 } + +ifInDiscards OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of inbound packets which were chosen to be + discarded even though no errors had been detected to prevent + + + their being deliverable to a higher-layer protocol. One + possible reason for discarding such a packet could be to + free up buffer space. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifEntry 13 } + +ifInErrors OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "For packet-oriented interfaces, the number of inbound + packets that contained errors preventing them from being + deliverable to a higher-layer protocol. For character- + oriented or fixed-length interfaces, the number of inbound + transmission units that contained errors preventing them + from being deliverable to a higher-layer protocol. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifEntry 14 } + +ifInUnknownProtos OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "For packet-oriented interfaces, the number of packets + received via the interface which were discarded because of + an unknown or unsupported protocol. For character-oriented + or fixed-length interfaces that support protocol + multiplexing the number of transmission units received via + the interface which were discarded because of an unknown or + unsupported protocol. For any interface that does not + support protocol multiplexing, this counter will always be + 0. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifEntry 15 } + + +ifOutOctets OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets transmitted out of the + interface, including framing characters. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifEntry 16 } + +ifOutUcastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of packets that higher-level protocols + requested be transmitted, and which were not addressed to a + multicast or broadcast address at this sub-layer, including + those that were discarded or not sent. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifEntry 17 } + +ifOutNUcastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The total number of packets that higher-level protocols + requested be transmitted, and which were addressed to a + multicast or broadcast address at this sub-layer, including + those that were discarded or not sent. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime. + + This object is deprecated in favour of ifOutMulticastPkts + and ifOutBroadcastPkts." + ::= { ifEntry 18 } + + +ifOutDiscards OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of outbound packets which were chosen to be + discarded even though no errors had been detected to prevent + their being transmitted. One possible reason for discarding + such a packet could be to free up buffer space. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifEntry 19 } + +ifOutErrors OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "For packet-oriented interfaces, the number of outbound + packets that could not be transmitted because of errors. + For character-oriented or fixed-length interfaces, the + number of outbound transmission units that could not be + transmitted because of errors. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifEntry 20 } + +ifOutQLen OBJECT-TYPE + SYNTAX Gauge32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The length of the output packet queue (in packets)." + ::= { ifEntry 21 } + +ifSpecific OBJECT-TYPE + SYNTAX OBJECT IDENTIFIER + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "A reference to MIB definitions specific to the particular + media being used to realize the interface. It is + + + recommended that this value point to an instance of a MIB + object in the media-specific MIB, i.e., that this object + have the semantics associated with the InstancePointer + textual convention defined in RFC 2579. In fact, it is + recommended that the media-specific MIB specify what value + ifSpecific should/can take for values of ifType. If no MIB + definitions specific to the particular media are available, + the value should be set to the OBJECT IDENTIFIER { 0 0 }." + ::= { ifEntry 22 } + + + +-- +-- Extension to the interface table +-- +-- This table replaces the ifExtnsTable table. +-- + +ifXTable OBJECT-TYPE + SYNTAX SEQUENCE OF IfXEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "A list of interface entries. The number of entries is + given by the value of ifNumber. This table contains + additional objects for the interface table." + ::= { ifMIBObjects 1 } + +ifXEntry OBJECT-TYPE + SYNTAX IfXEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "An entry containing additional management information + applicable to a particular interface." + AUGMENTS { ifEntry } + ::= { ifXTable 1 } + +IfXEntry ::= + SEQUENCE { + ifName DisplayString, + ifInMulticastPkts Counter32, + ifInBroadcastPkts Counter32, + ifOutMulticastPkts Counter32, + ifOutBroadcastPkts Counter32, + ifHCInOctets Counter64, + ifHCInUcastPkts Counter64, + ifHCInMulticastPkts Counter64, + + + ifHCInBroadcastPkts Counter64, + ifHCOutOctets Counter64, + ifHCOutUcastPkts Counter64, + ifHCOutMulticastPkts Counter64, + ifHCOutBroadcastPkts Counter64, + ifLinkUpDownTrapEnable INTEGER, + ifHighSpeed Gauge32, + ifPromiscuousMode TruthValue, + ifConnectorPresent TruthValue, + ifAlias DisplayString, + ifCounterDiscontinuityTime TimeStamp + } + + +ifName OBJECT-TYPE + SYNTAX DisplayString + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The textual name of the interface. The value of this + object should be the name of the interface as assigned by + the local device and should be suitable for use in commands + entered at the device's `console'. This might be a text + name, such as `le0' or a simple port number, such as `1', + depending on the interface naming syntax of the device. If + several entries in the ifTable together represent a single + interface as named by the device, then each will have the + same value of ifName. Note that for an agent which responds + to SNMP queries concerning an interface on some other + (proxied) device, then the value of ifName for such an + interface is the proxied device's local name for it. + + If there is no local name, or this object is otherwise not + applicable, then this object contains a zero-length string." + ::= { ifXEntry 1 } + +ifInMulticastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of packets, delivered by this sub-layer to a + higher (sub-)layer, which were addressed to a multicast + address at this sub-layer. For a MAC layer protocol, this + includes both Group and Functional addresses. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + + + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifXEntry 2 } + +ifInBroadcastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of packets, delivered by this sub-layer to a + higher (sub-)layer, which were addressed to a broadcast + address at this sub-layer. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifXEntry 3 } + +ifOutMulticastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of packets that higher-level protocols + requested be transmitted, and which were addressed to a + multicast address at this sub-layer, including those that + were discarded or not sent. For a MAC layer protocol, this + includes both Group and Functional addresses. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifXEntry 4 } + +ifOutBroadcastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of packets that higher-level protocols + requested be transmitted, and which were addressed to a + broadcast address at this sub-layer, including those that + were discarded or not sent. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + + + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifXEntry 5 } + +-- +-- High Capacity Counter objects. These objects are all +-- 64 bit versions of the "basic" ifTable counters. These +-- objects all have the same basic semantics as their 32-bit +-- counterparts, however, their syntax has been extended +-- to 64 bits. +-- + +ifHCInOctets OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets received on the interface, + including framing characters. This object is a 64-bit + version of ifInOctets. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifXEntry 6 } + +ifHCInUcastPkts OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of packets, delivered by this sub-layer to a + higher (sub-)layer, which were not addressed to a multicast + or broadcast address at this sub-layer. This object is a + 64-bit version of ifInUcastPkts. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifXEntry 7 } + +ifHCInMulticastPkts OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + + + "The number of packets, delivered by this sub-layer to a + higher (sub-)layer, which were addressed to a multicast + address at this sub-layer. For a MAC layer protocol, this + includes both Group and Functional addresses. This object + is a 64-bit version of ifInMulticastPkts. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifXEntry 8 } + +ifHCInBroadcastPkts OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of packets, delivered by this sub-layer to a + higher (sub-)layer, which were addressed to a broadcast + address at this sub-layer. This object is a 64-bit version + of ifInBroadcastPkts. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifXEntry 9 } + +ifHCOutOctets OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets transmitted out of the + interface, including framing characters. This object is a + 64-bit version of ifOutOctets. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifXEntry 10 } + +ifHCOutUcastPkts OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + + + "The total number of packets that higher-level protocols + requested be transmitted, and which were not addressed to a + multicast or broadcast address at this sub-layer, including + those that were discarded or not sent. This object is a + 64-bit version of ifOutUcastPkts. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifXEntry 11 } + +ifHCOutMulticastPkts OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of packets that higher-level protocols + requested be transmitted, and which were addressed to a + multicast address at this sub-layer, including those that + were discarded or not sent. For a MAC layer protocol, this + includes both Group and Functional addresses. This object + is a 64-bit version of ifOutMulticastPkts. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifXEntry 12 } + +ifHCOutBroadcastPkts OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of packets that higher-level protocols + requested be transmitted, and which were addressed to a + broadcast address at this sub-layer, including those that + were discarded or not sent. This object is a 64-bit version + of ifOutBroadcastPkts. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ifCounterDiscontinuityTime." + ::= { ifXEntry 13 } + +ifLinkUpDownTrapEnable OBJECT-TYPE + + + SYNTAX INTEGER { enabled(1), disabled(2) } + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "Indicates whether linkUp/linkDown traps should be generated + for this interface. + + By default, this object should have the value enabled(1) for + interfaces which do not operate on 'top' of any other + interface (as defined in the ifStackTable), and disabled(2) + otherwise." + ::= { ifXEntry 14 } + +ifHighSpeed OBJECT-TYPE + SYNTAX Gauge32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "An estimate of the interface's current bandwidth in units + of 1,000,000 bits per second. If this object reports a + value of `n' then the speed of the interface is somewhere in + the range of `n-500,000' to `n+499,999'. For interfaces + which do not vary in bandwidth or for those where no + accurate estimation can be made, this object should contain + the nominal bandwidth. For a sub-layer which has no concept + of bandwidth, this object should be zero." + ::= { ifXEntry 15 } + +ifPromiscuousMode OBJECT-TYPE + SYNTAX TruthValue + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "This object has a value of false(2) if this interface only + accepts packets/frames that are addressed to this station. + This object has a value of true(1) when the station accepts + all packets/frames transmitted on the media. The value + true(1) is only legal on certain types of media. If legal, + setting this object to a value of true(1) may require the + interface to be reset before becoming effective. + + The value of ifPromiscuousMode does not affect the reception + of broadcast and multicast packets/frames by the interface." + ::= { ifXEntry 16 } + +ifConnectorPresent OBJECT-TYPE + SYNTAX TruthValue + MAX-ACCESS read-only + + + STATUS current + DESCRIPTION + "This object has the value 'true(1)' if the interface + sublayer has a physical connector and the value 'false(2)' + otherwise." + ::= { ifXEntry 17 } + +ifAlias OBJECT-TYPE + SYNTAX DisplayString (SIZE(0..64)) + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "This object is an 'alias' name for the interface as + specified by a network manager, and provides a non-volatile + 'handle' for the interface. + + On the first instantiation of an interface, the value of + ifAlias associated with that interface is the zero-length + string. As and when a value is written into an instance of + ifAlias through a network management set operation, then the + agent must retain the supplied value in the ifAlias instance + associated with the same interface for as long as that + interface remains instantiated, including across all re- + initializations/reboots of the network management system, + including those which result in a change of the interface's + ifIndex value. + + An example of the value which a network manager might store + in this object for a WAN interface is the (Telco's) circuit + number/identifier of the interface. + + Some agents may support write-access only for interfaces + having particular values of ifType. An agent which supports + write access to this object is required to keep the value in + non-volatile storage, but it may limit the length of new + values depending on how much storage is already occupied by + the current values for other interfaces." + ::= { ifXEntry 18 } + +ifCounterDiscontinuityTime OBJECT-TYPE + SYNTAX TimeStamp + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The value of sysUpTime on the most recent occasion at which + any one or more of this interface's counters suffered a + discontinuity. The relevant counters are the specific + instances associated with this interface of any Counter32 or + + + Counter64 object contained in the ifTable or ifXTable. If + no such discontinuities have occurred since the last re- + initialization of the local management subsystem, then this + object contains a zero value." + ::= { ifXEntry 19 } + +-- The Interface Stack Group +-- +-- Implementation of this group is optional, but strongly recommended +-- for all systems +-- + +ifStackTable OBJECT-TYPE + SYNTAX SEQUENCE OF IfStackEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The table containing information on the relationships + between the multiple sub-layers of network interfaces. In + particular, it contains information on which sub-layers run + 'on top of' which other sub-layers, where each sub-layer + corresponds to a conceptual row in the ifTable. For + example, when the sub-layer with ifIndex value x runs over + the sub-layer with ifIndex value y, then this table + contains: + + ifStackStatus.x.y=active + + For each ifIndex value, I, which identifies an active + interface, there are always at least two instantiated rows + in this table associated with I. For one of these rows, I + is the value of ifStackHigherLayer; for the other, I is the + value of ifStackLowerLayer. (If I is not involved in + multiplexing, then these are the only two rows associated + with I.) + + For example, two rows exist even for an interface which has + no others stacked on top or below it: + + ifStackStatus.0.x=active + ifStackStatus.x.0=active " + ::= { ifMIBObjects 2 } + + +ifStackEntry OBJECT-TYPE + SYNTAX IfStackEntry + MAX-ACCESS not-accessible + STATUS current + + + DESCRIPTION + "Information on a particular relationship between two sub- + layers, specifying that one sub-layer runs on 'top' of the + other sub-layer. Each sub-layer corresponds to a conceptual + row in the ifTable." + INDEX { ifStackHigherLayer, ifStackLowerLayer } + ::= { ifStackTable 1 } + + +IfStackEntry ::= + SEQUENCE { + ifStackHigherLayer InterfaceIndexOrZero, + ifStackLowerLayer InterfaceIndexOrZero, + ifStackStatus RowStatus + } + + +ifStackHigherLayer OBJECT-TYPE + SYNTAX InterfaceIndexOrZero + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The value of ifIndex corresponding to the higher sub-layer + of the relationship, i.e., the sub-layer which runs on 'top' + of the sub-layer identified by the corresponding instance of + ifStackLowerLayer. If there is no higher sub-layer (below + the internetwork layer), then this object has the value 0." + ::= { ifStackEntry 1 } + + +ifStackLowerLayer OBJECT-TYPE + SYNTAX InterfaceIndexOrZero + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The value of ifIndex corresponding to the lower sub-layer + of the relationship, i.e., the sub-layer which runs 'below' + the sub-layer identified by the corresponding instance of + ifStackHigherLayer. If there is no lower sub-layer, then + this object has the value 0." + ::= { ifStackEntry 2 } + + +ifStackStatus OBJECT-TYPE + SYNTAX RowStatus + MAX-ACCESS read-create + STATUS current + DESCRIPTION + + + "The status of the relationship between two sub-layers. + + Changing the value of this object from 'active' to + 'notInService' or 'destroy' will likely have consequences up + and down the interface stack. Thus, write access to this + object is likely to be inappropriate for some types of + interfaces, and many implementations will choose not to + support write-access for any type of interface." + ::= { ifStackEntry 3 } + +ifStackLastChange OBJECT-TYPE + SYNTAX TimeTicks + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The value of sysUpTime at the time of the last change of + the (whole) interface stack. A change of the interface + stack is defined to be any creation, deletion, or change in + value of any instance of ifStackStatus. If the interface + stack has been unchanged since the last re-initialization of + the local network management subsystem, then this object + contains a zero value." + ::= { ifMIBObjects 6 } + + +-- Generic Receive Address Table +-- +-- This group of objects is mandatory for all types of +-- interfaces which can receive packets/frames addressed to +-- more than one address. +-- +-- This table replaces the ifExtnsRcvAddr table. The main +-- difference is that this table makes use of the RowStatus +-- textual convention, while ifExtnsRcvAddr did not. + +ifRcvAddressTable OBJECT-TYPE + SYNTAX SEQUENCE OF IfRcvAddressEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "This table contains an entry for each address (broadcast, + multicast, or uni-cast) for which the system will receive + packets/frames on a particular interface, except as follows: + + - for an interface operating in promiscuous mode, entries + are only required for those addresses for which the system + would receive frames were it not operating in promiscuous + mode. + + + - for 802.5 functional addresses, only one entry is + required, for the address which has the functional address + bit ANDed with the bit mask of all functional addresses for + which the interface will accept frames. + + A system is normally able to use any unicast address which + corresponds to an entry in this table as a source address." + ::= { ifMIBObjects 4 } + +ifRcvAddressEntry OBJECT-TYPE + SYNTAX IfRcvAddressEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "A list of objects identifying an address for which the + system will accept packets/frames on the particular + interface identified by the index value ifIndex." + INDEX { ifIndex, ifRcvAddressAddress } + ::= { ifRcvAddressTable 1 } + +IfRcvAddressEntry ::= + SEQUENCE { + ifRcvAddressAddress PhysAddress, + ifRcvAddressStatus RowStatus, + ifRcvAddressType INTEGER + } + +ifRcvAddressAddress OBJECT-TYPE + SYNTAX PhysAddress + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "An address for which the system will accept packets/frames + on this entry's interface." + ::= { ifRcvAddressEntry 1 } + +ifRcvAddressStatus OBJECT-TYPE + SYNTAX RowStatus + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "This object is used to create and delete rows in the + ifRcvAddressTable." + + ::= { ifRcvAddressEntry 2 } + +ifRcvAddressType OBJECT-TYPE + SYNTAX INTEGER { + + + other(1), + volatile(2), + nonVolatile(3) + } + + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "This object has the value nonVolatile(3) for those entries + in the table which are valid and will not be deleted by the + next restart of the managed system. Entries having the + value volatile(2) are valid and exist, but have not been + saved, so that will not exist after the next restart of the + managed system. Entries having the value other(1) are valid + and exist but are not classified as to whether they will + continue to exist after the next restart." + + DEFVAL { volatile } + ::= { ifRcvAddressEntry 3 } + +-- definition of interface-related traps. + +linkDown NOTIFICATION-TYPE + OBJECTS { ifIndex, ifAdminStatus, ifOperStatus } + STATUS current + DESCRIPTION + "A linkDown trap signifies that the SNMP entity, acting in + an agent role, has detected that the ifOperStatus object for + one of its communication links is about to enter the down + state from some other state (but not from the notPresent + state). This other state is indicated by the included value + of ifOperStatus." + ::= { snmpTraps 3 } + +linkUp NOTIFICATION-TYPE + OBJECTS { ifIndex, ifAdminStatus, ifOperStatus } + STATUS current + DESCRIPTION + "A linkUp trap signifies that the SNMP entity, acting in an + agent role, has detected that the ifOperStatus object for + one of its communication links left the down state and + transitioned into some other state (but not into the + notPresent state). This other state is indicated by the + included value of ifOperStatus." + ::= { snmpTraps 4 } + +-- conformance information + + + +ifConformance OBJECT IDENTIFIER ::= { ifMIB 2 } + +ifGroups OBJECT IDENTIFIER ::= { ifConformance 1 } +ifCompliances OBJECT IDENTIFIER ::= { ifConformance 2 } + + +-- compliance statements + +ifCompliance3 MODULE-COMPLIANCE + STATUS current + DESCRIPTION + "The compliance statement for SNMP entities which have + network interfaces." + + MODULE -- this module + MANDATORY-GROUPS { ifGeneralInformationGroup, + linkUpDownNotificationsGroup } + +-- The groups: +-- ifFixedLengthGroup +-- ifHCFixedLengthGroup +-- ifPacketGroup +-- ifHCPacketGroup +-- ifVHCPacketGroup +-- are mutually exclusive; at most one of these groups is implemented +-- for a particular interface. When any of these groups is implemented +-- for a particular interface, then ifCounterDiscontinuityGroup must +-- also be implemented for that interface. + + + GROUP ifFixedLengthGroup + DESCRIPTION + "This group is mandatory for those network interfaces which + are character-oriented or transmit data in fixed-length + transmission units, and for which the value of the + corresponding instance of ifSpeed is less than or equal to + 20,000,000 bits/second." + + GROUP ifHCFixedLengthGroup + DESCRIPTION + "This group is mandatory for those network interfaces which + are character-oriented or transmit data in fixed-length + transmission units, and for which the value of the + corresponding instance of ifSpeed is greater than 20,000,000 + bits/second." + + GROUP ifPacketGroup + DESCRIPTION + + + "This group is mandatory for those network interfaces which + are packet-oriented, and for which the value of the + corresponding instance of ifSpeed is less than or equal to + 20,000,000 bits/second." + + GROUP ifHCPacketGroup + DESCRIPTION + "This group is mandatory only for those network interfaces + which are packet-oriented and for which the value of the + corresponding instance of ifSpeed is greater than 20,000,000 + bits/second but less than or equal to 650,000,000 + bits/second." + + GROUP ifVHCPacketGroup + DESCRIPTION + "This group is mandatory only for those network interfaces + which are packet-oriented and for which the value of the + corresponding instance of ifSpeed is greater than + 650,000,000 bits/second." + + + GROUP ifCounterDiscontinuityGroup + DESCRIPTION + "This group is mandatory for those network interfaces that + are required to maintain counters (i.e., those for which one + of the ifFixedLengthGroup, ifHCFixedLengthGroup, + ifPacketGroup, ifHCPacketGroup, or ifVHCPacketGroup is + mandatory)." + + + GROUP ifRcvAddressGroup + DESCRIPTION + "The applicability of this group MUST be defined by the + media-specific MIBs. Media-specific MIBs must define the + exact meaning, use, and semantics of the addresses in this + group." + + OBJECT ifLinkUpDownTrapEnable + MIN-ACCESS read-only + DESCRIPTION + "Write access is not required." + + OBJECT ifPromiscuousMode + MIN-ACCESS read-only + DESCRIPTION + "Write access is not required." + + OBJECT ifAdminStatus + + + SYNTAX INTEGER { up(1), down(2) } + MIN-ACCESS read-only + DESCRIPTION + "Write access is not required, nor is support for the value + testing(3)." + + OBJECT ifAlias + MIN-ACCESS read-only + DESCRIPTION + "Write access is not required." + + ::= { ifCompliances 3 } + +-- units of conformance + +ifGeneralInformationGroup OBJECT-GROUP + OBJECTS { ifIndex, ifDescr, ifType, ifSpeed, ifPhysAddress, + ifAdminStatus, ifOperStatus, ifLastChange, + ifLinkUpDownTrapEnable, ifConnectorPresent, + ifHighSpeed, ifName, ifNumber, ifAlias, + ifTableLastChange } + STATUS current + DESCRIPTION + "A collection of objects providing information applicable to + all network interfaces." + ::= { ifGroups 10 } + +-- the following five groups are mutually exclusive; at most +-- one of these groups is implemented for any interface + +ifFixedLengthGroup OBJECT-GROUP + OBJECTS { ifInOctets, ifOutOctets, ifInUnknownProtos, + ifInErrors, ifOutErrors } + STATUS current + DESCRIPTION + "A collection of objects providing information specific to + non-high speed (non-high speed interfaces transmit and + receive at speeds less than or equal to 20,000,000 + bits/second) character-oriented or fixed-length-transmission + network interfaces." + ::= { ifGroups 2 } + +ifHCFixedLengthGroup OBJECT-GROUP + OBJECTS { ifHCInOctets, ifHCOutOctets, + ifInOctets, ifOutOctets, ifInUnknownProtos, + ifInErrors, ifOutErrors } + STATUS current + DESCRIPTION + + + "A collection of objects providing information specific to + high speed (greater than 20,000,000 bits/second) character- + oriented or fixed-length-transmission network interfaces." + ::= { ifGroups 3 } + +ifPacketGroup OBJECT-GROUP + OBJECTS { ifInOctets, ifOutOctets, ifInUnknownProtos, + ifInErrors, ifOutErrors, + ifMtu, ifInUcastPkts, ifInMulticastPkts, + ifInBroadcastPkts, ifInDiscards, + ifOutUcastPkts, ifOutMulticastPkts, + ifOutBroadcastPkts, ifOutDiscards, + ifPromiscuousMode } + STATUS current + DESCRIPTION + "A collection of objects providing information specific to + non-high speed (non-high speed interfaces transmit and + receive at speeds less than or equal to 20,000,000 + bits/second) packet-oriented network interfaces." + ::= { ifGroups 4 } + +ifHCPacketGroup OBJECT-GROUP + OBJECTS { ifHCInOctets, ifHCOutOctets, + ifInOctets, ifOutOctets, ifInUnknownProtos, + ifInErrors, ifOutErrors, + ifMtu, ifInUcastPkts, ifInMulticastPkts, + ifInBroadcastPkts, ifInDiscards, + ifOutUcastPkts, ifOutMulticastPkts, + ifOutBroadcastPkts, ifOutDiscards, + ifPromiscuousMode } + STATUS current + DESCRIPTION + "A collection of objects providing information specific to + high speed (greater than 20,000,000 bits/second but less + than or equal to 650,000,000 bits/second) packet-oriented + network interfaces." + ::= { ifGroups 5 } + +ifVHCPacketGroup OBJECT-GROUP + OBJECTS { ifHCInUcastPkts, ifHCInMulticastPkts, + ifHCInBroadcastPkts, ifHCOutUcastPkts, + ifHCOutMulticastPkts, ifHCOutBroadcastPkts, + ifHCInOctets, ifHCOutOctets, + ifInOctets, ifOutOctets, ifInUnknownProtos, + ifInErrors, ifOutErrors, + ifMtu, ifInUcastPkts, ifInMulticastPkts, + ifInBroadcastPkts, ifInDiscards, + ifOutUcastPkts, ifOutMulticastPkts, + + + ifOutBroadcastPkts, ifOutDiscards, + ifPromiscuousMode } + STATUS current + DESCRIPTION + "A collection of objects providing information specific to + higher speed (greater than 650,000,000 bits/second) packet- + oriented network interfaces." + ::= { ifGroups 6 } + +ifRcvAddressGroup OBJECT-GROUP + OBJECTS { ifRcvAddressStatus, ifRcvAddressType } + STATUS current + DESCRIPTION + "A collection of objects providing information on the + multiple addresses which an interface receives." + ::= { ifGroups 7 } + +ifStackGroup2 OBJECT-GROUP + OBJECTS { ifStackStatus, ifStackLastChange } + STATUS current + DESCRIPTION + "A collection of objects providing information on the + layering of MIB-II interfaces." + ::= { ifGroups 11 } + +ifCounterDiscontinuityGroup OBJECT-GROUP + OBJECTS { ifCounterDiscontinuityTime } + STATUS current + DESCRIPTION + "A collection of objects providing information specific to + interface counter discontinuities." + ::= { ifGroups 13 } + +linkUpDownNotificationsGroup NOTIFICATION-GROUP + NOTIFICATIONS { linkUp, linkDown } + STATUS current + DESCRIPTION + "The notifications which indicate specific changes in the + value of ifOperStatus." + ::= { ifGroups 14 } + +-- Deprecated Definitions - Objects + + +-- +-- The Interface Test Table +-- +-- This group of objects is optional. However, a media-specific + + +-- MIB may make implementation of this group mandatory. +-- +-- This table replaces the ifExtnsTestTable +-- + +ifTestTable OBJECT-TYPE + SYNTAX SEQUENCE OF IfTestEntry + MAX-ACCESS not-accessible + STATUS deprecated + DESCRIPTION + "This table contains one entry per interface. It defines + objects which allow a network manager to instruct an agent + to test an interface for various faults. Tests for an + interface are defined in the media-specific MIB for that + interface. After invoking a test, the object ifTestResult + can be read to determine the outcome. If an agent can not + perform the test, ifTestResult is set to so indicate. The + object ifTestCode can be used to provide further test- + specific or interface-specific (or even enterprise-specific) + information concerning the outcome of the test. Only one + test can be in progress on each interface at any one time. + If one test is in progress when another test is invoked, the + second test is rejected. Some agents may reject a test when + a prior test is active on another interface. + + Before starting a test, a manager-station must first obtain + 'ownership' of the entry in the ifTestTable for the + interface to be tested. This is accomplished with the + ifTestId and ifTestStatus objects as follows: + + try_again: + get (ifTestId, ifTestStatus) + while (ifTestStatus != notInUse) + /* + * Loop while a test is running or some other + * manager is configuring a test. + */ + short delay + get (ifTestId, ifTestStatus) + } + + /* + * Is not being used right now -- let's compete + * to see who gets it. + */ + lock_value = ifTestId + + if ( set(ifTestId = lock_value, ifTestStatus = inUse, + + + ifTestOwner = 'my-IP-address') == FAILURE) + /* + * Another manager got the ifTestEntry -- go + * try again + */ + goto try_again; + + /* + * I have the lock + */ + set up any test parameters. + + /* + * This starts the test + */ + set(ifTestType = test_to_run); + + wait for test completion by polling ifTestResult + + when test completes, agent sets ifTestResult + agent also sets ifTestStatus = 'notInUse' + + retrieve any additional test results, and ifTestId + + if (ifTestId == lock_value+1) results are valid + + A manager station first retrieves the value of the + appropriate ifTestId and ifTestStatus objects, periodically + repeating the retrieval if necessary, until the value of + ifTestStatus is 'notInUse'. The manager station then tries + to set the same ifTestId object to the value it just + retrieved, the same ifTestStatus object to 'inUse', and the + corresponding ifTestOwner object to a value indicating + itself. If the set operation succeeds then the manager has + obtained ownership of the ifTestEntry, and the value of the + ifTestId object is incremented by the agent (per the + semantics of TestAndIncr). Failure of the set operation + indicates that some other manager has obtained ownership of + the ifTestEntry. + + Once ownership is obtained, any test parameters can be + setup, and then the test is initiated by setting ifTestType. + On completion of the test, the agent sets ifTestStatus to + 'notInUse'. Once this occurs, the manager can retrieve the + results. In the (rare) event that the invocation of tests + by two network managers were to overlap, then there would be + a possibility that the first test's results might be + overwritten by the second test's results prior to the first + + + results being read. This unlikely circumstance can be + detected by a network manager retrieving ifTestId at the + same time as retrieving the test results, and ensuring that + the results are for the desired request. + + If ifTestType is not set within an abnormally long period of + time after ownership is obtained, the agent should time-out + the manager, and reset the value of the ifTestStatus object + back to 'notInUse'. It is suggested that this time-out + period be 5 minutes. + + In general, a management station must not retransmit a + request to invoke a test for which it does not receive a + response; instead, it properly inspects an agent's MIB to + determine if the invocation was successful. Only if the + invocation was unsuccessful, is the invocation request + retransmitted. + + Some tests may require the interface to be taken off-line in + order to execute them, or may even require the agent to + reboot after completion of the test. In these + circumstances, communication with the management station + invoking the test may be lost until after completion of the + test. An agent is not required to support such tests. + However, if such tests are supported, then the agent should + make every effort to transmit a response to the request + which invoked the test prior to losing communication. When + the agent is restored to normal service, the results of the + test are properly made available in the appropriate objects. + Note that this requires that the ifIndex value assigned to + an interface must be unchanged even if the test causes a + reboot. An agent must reject any test for which it cannot, + perhaps due to resource constraints, make available at least + the minimum amount of information after that test + completes." + ::= { ifMIBObjects 3 } + +ifTestEntry OBJECT-TYPE + SYNTAX IfTestEntry + MAX-ACCESS not-accessible + STATUS deprecated + DESCRIPTION + "An entry containing objects for invoking tests on an + interface." + AUGMENTS { ifEntry } + ::= { ifTestTable 1 } + +IfTestEntry ::= + + + SEQUENCE { + ifTestId TestAndIncr, + ifTestStatus INTEGER, + ifTestType AutonomousType, + ifTestResult INTEGER, + ifTestCode OBJECT IDENTIFIER, + ifTestOwner OwnerString + } + +ifTestId OBJECT-TYPE + SYNTAX TestAndIncr + MAX-ACCESS read-write + STATUS deprecated + DESCRIPTION + "This object identifies the current invocation of the + interface's test." + ::= { ifTestEntry 1 } + +ifTestStatus OBJECT-TYPE + SYNTAX INTEGER { notInUse(1), inUse(2) } + MAX-ACCESS read-write + STATUS deprecated + DESCRIPTION + "This object indicates whether or not some manager currently + has the necessary 'ownership' required to invoke a test on + this interface. A write to this object is only successful + when it changes its value from 'notInUse(1)' to 'inUse(2)'. + After completion of a test, the agent resets the value back + to 'notInUse(1)'." + ::= { ifTestEntry 2 } + +ifTestType OBJECT-TYPE + SYNTAX AutonomousType + MAX-ACCESS read-write + STATUS deprecated + DESCRIPTION + "A control variable used to start and stop operator- + initiated interface tests. Most OBJECT IDENTIFIER values + assigned to tests are defined elsewhere, in association with + specific types of interface. However, this document assigns + a value for a full-duplex loopback test, and defines the + special meanings of the subject identifier: + + noTest OBJECT IDENTIFIER ::= { 0 0 } + + When the value noTest is written to this object, no action + is taken unless a test is in progress, in which case the + test is aborted. Writing any other value to this object is + + + only valid when no test is currently in progress, in which + case the indicated test is initiated. + + When read, this object always returns the most recent value + that ifTestType was set to. If it has not been set since + the last initialization of the network management subsystem + on the agent, a value of noTest is returned." + ::= { ifTestEntry 3 } + +ifTestResult OBJECT-TYPE + SYNTAX INTEGER { + none(1), -- no test yet requested + success(2), + inProgress(3), + notSupported(4), + unAbleToRun(5), -- due to state of system + aborted(6), + failed(7) + } + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "This object contains the result of the most recently + requested test, or the value none(1) if no tests have been + requested since the last reset. Note that this facility + provides no provision for saving the results of one test + when starting another, as could be required if used by + multiple managers concurrently." + ::= { ifTestEntry 4 } + +ifTestCode OBJECT-TYPE + SYNTAX OBJECT IDENTIFIER + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "This object contains a code which contains more specific + information on the test result, for example an error-code + after a failed test. Error codes and other values this + object may take are specific to the type of interface and/or + test. The value may have the semantics of either the + AutonomousType or InstancePointer textual conventions as + defined in RFC 2579. The identifier: + + testCodeUnknown OBJECT IDENTIFIER ::= { 0 0 } + + is defined for use if no additional result code is + available." + ::= { ifTestEntry 5 } + + +ifTestOwner OBJECT-TYPE + SYNTAX OwnerString + MAX-ACCESS read-write + STATUS deprecated + DESCRIPTION + "The entity which currently has the 'ownership' required to + invoke a test on this interface." + ::= { ifTestEntry 6 } + +-- Deprecated Definitions - Groups + + +ifGeneralGroup OBJECT-GROUP + OBJECTS { ifDescr, ifType, ifSpeed, ifPhysAddress, + ifAdminStatus, ifOperStatus, ifLastChange, + ifLinkUpDownTrapEnable, ifConnectorPresent, + ifHighSpeed, ifName } + STATUS deprecated + DESCRIPTION + "A collection of objects deprecated in favour of + ifGeneralInformationGroup." + ::= { ifGroups 1 } + + +ifTestGroup OBJECT-GROUP + OBJECTS { ifTestId, ifTestStatus, ifTestType, + ifTestResult, ifTestCode, ifTestOwner } + STATUS deprecated + DESCRIPTION + "A collection of objects providing the ability to invoke + tests on an interface." + ::= { ifGroups 8 } + + +ifStackGroup OBJECT-GROUP + OBJECTS { ifStackStatus } + STATUS deprecated + DESCRIPTION + "The previous collection of objects providing information on + the layering of MIB-II interfaces." + ::= { ifGroups 9 } + + +ifOldObjectsGroup OBJECT-GROUP + OBJECTS { ifInNUcastPkts, ifOutNUcastPkts, + ifOutQLen, ifSpecific } + STATUS deprecated + DESCRIPTION + + + "The collection of objects deprecated from the original MIB- + II interfaces group." + ::= { ifGroups 12 } + +-- Deprecated Definitions - Compliance + +ifCompliance MODULE-COMPLIANCE + STATUS deprecated + DESCRIPTION + "A compliance statement defined in a previous version of + this MIB module, for SNMP entities which have network + interfaces." + + MODULE -- this module + MANDATORY-GROUPS { ifGeneralGroup, ifStackGroup } + + GROUP ifFixedLengthGroup + DESCRIPTION + "This group is mandatory for all network interfaces which + are character-oriented or transmit data in fixed-length + transmission units." + + GROUP ifHCFixedLengthGroup + DESCRIPTION + "This group is mandatory only for those network interfaces + which are character-oriented or transmit data in fixed- + length transmission units, and for which the value of the + corresponding instance of ifSpeed is greater than 20,000,000 + bits/second." + + GROUP ifPacketGroup + DESCRIPTION + "This group is mandatory for all network interfaces which + are packet-oriented." + + GROUP ifHCPacketGroup + DESCRIPTION + "This group is mandatory only for those network interfaces + which are packet-oriented and for which the value of the + corresponding instance of ifSpeed is greater than + 650,000,000 bits/second." + + GROUP ifTestGroup + DESCRIPTION + "This group is optional. Media-specific MIBs which require + interface tests are strongly encouraged to use this group + for invoking tests and reporting results. A medium specific + MIB which has mandatory tests may make implementation of + + + this group mandatory." + + GROUP ifRcvAddressGroup + DESCRIPTION + "The applicability of this group MUST be defined by the + media-specific MIBs. Media-specific MIBs must define the + exact meaning, use, and semantics of the addresses in this + group." + + OBJECT ifLinkUpDownTrapEnable + MIN-ACCESS read-only + DESCRIPTION + "Write access is not required." + + OBJECT ifPromiscuousMode + MIN-ACCESS read-only + DESCRIPTION + "Write access is not required." + + OBJECT ifStackStatus + SYNTAX INTEGER { active(1) } -- subset of RowStatus + MIN-ACCESS read-only + DESCRIPTION + "Write access is not required, and only one of the six + enumerated values for the RowStatus textual convention need + be supported, specifically: active(1)." + + OBJECT ifAdminStatus + SYNTAX INTEGER { up(1), down(2) } + MIN-ACCESS read-only + DESCRIPTION + "Write access is not required, nor is support for the value + testing(3)." + ::= { ifCompliances 1 } + +ifCompliance2 MODULE-COMPLIANCE + STATUS deprecated + DESCRIPTION + "A compliance statement defined in a previous version of + this MIB module, for SNMP entities which have network + interfaces." + + MODULE -- this module + MANDATORY-GROUPS { ifGeneralInformationGroup, ifStackGroup2, + ifCounterDiscontinuityGroup } + + GROUP ifFixedLengthGroup + DESCRIPTION + + + "This group is mandatory for all network interfaces which + are character-oriented or transmit data in fixed-length + transmission units." + + GROUP ifHCFixedLengthGroup + DESCRIPTION + "This group is mandatory only for those network interfaces + which are character-oriented or transmit data in fixed- + length transmission units, and for which the value of the + corresponding instance of ifSpeed is greater than 20,000,000 + bits/second." + + GROUP ifPacketGroup + DESCRIPTION + "This group is mandatory for all network interfaces which + are packet-oriented." + + GROUP ifHCPacketGroup + DESCRIPTION + "This group is mandatory only for those network interfaces + which are packet-oriented and for which the value of the + corresponding instance of ifSpeed is greater than + 650,000,000 bits/second." + + GROUP ifRcvAddressGroup + DESCRIPTION + "The applicability of this group MUST be defined by the + media-specific MIBs. Media-specific MIBs must define the + exact meaning, use, and semantics of the addresses in this + group." + + OBJECT ifLinkUpDownTrapEnable + MIN-ACCESS read-only + DESCRIPTION + "Write access is not required." + + OBJECT ifPromiscuousMode + MIN-ACCESS read-only + DESCRIPTION + "Write access is not required." + + OBJECT ifStackStatus + SYNTAX INTEGER { active(1) } -- subset of RowStatus + MIN-ACCESS read-only + DESCRIPTION + "Write access is not required, and only one of the six + enumerated values for the RowStatus textual convention need + be supported, specifically: active(1)." + + + OBJECT ifAdminStatus + SYNTAX INTEGER { up(1), down(2) } + MIN-ACCESS read-only + DESCRIPTION + "Write access is not required, nor is support for the value + testing(3)." + + OBJECT ifAlias + MIN-ACCESS read-only + DESCRIPTION + "Write access is not required." + + ::= { ifCompliances 2 } + +END diff --git a/contrib/apps/LwipMibCompiler/Mibs/INET-ADDRESS-MIB b/contrib/apps/LwipMibCompiler/Mibs/INET-ADDRESS-MIB new file mode 100644 index 00000000000..a19b8d22698 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/INET-ADDRESS-MIB @@ -0,0 +1,421 @@ +INET-ADDRESS-MIB DEFINITIONS ::= BEGIN + +IMPORTS + MODULE-IDENTITY, mib-2, Unsigned32 FROM SNMPv2-SMI + TEXTUAL-CONVENTION FROM SNMPv2-TC; + +inetAddressMIB MODULE-IDENTITY + LAST-UPDATED "200502040000Z" + ORGANIZATION + "IETF Operations and Management Area" + CONTACT-INFO + "Juergen Schoenwaelder (Editor) + International University Bremen + P.O. Box 750 561 + 28725 Bremen, Germany + + Phone: +49 421 200-3587 + EMail: j.schoenwaelder@iu-bremen.de + + Send comments to ietfmibs@ops.ietf.org." + DESCRIPTION + "This MIB module defines textual conventions for + representing Internet addresses. An Internet + address can be an IPv4 address, an IPv6 address, + or a DNS domain name. This module also defines + textual conventions for Internet port numbers, + autonomous system numbers, and the length of an + Internet address prefix. + + Copyright (C) The Internet Society (2005). This version + of this MIB module is part of RFC 4001, see the RFC + itself for full legal notices." + REVISION "200502040000Z" + DESCRIPTION + "Third version, published as RFC 4001. This revision + introduces the InetZoneIndex, InetScopeType, and + InetVersion textual conventions." + REVISION "200205090000Z" + DESCRIPTION + "Second version, published as RFC 3291. This + revision contains several clarifications and + introduces several new textual conventions: + InetAddressPrefixLength, InetPortNumber, + InetAutonomousSystemNumber, InetAddressIPv4z, + and InetAddressIPv6z." + REVISION "200006080000Z" + + + + DESCRIPTION + "Initial version, published as RFC 2851." + ::= { mib-2 76 } + +InetAddressType ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "A value that represents a type of Internet address. + + unknown(0) An unknown address type. This value MUST + be used if the value of the corresponding + InetAddress object is a zero-length string. + It may also be used to indicate an IP address + that is not in one of the formats defined + below. + + ipv4(1) An IPv4 address as defined by the + InetAddressIPv4 textual convention. + + ipv6(2) An IPv6 address as defined by the + InetAddressIPv6 textual convention. + + ipv4z(3) A non-global IPv4 address including a zone + index as defined by the InetAddressIPv4z + textual convention. + + ipv6z(4) A non-global IPv6 address including a zone + index as defined by the InetAddressIPv6z + textual convention. + + dns(16) A DNS domain name as defined by the + InetAddressDNS textual convention. + + Each definition of a concrete InetAddressType value must be + accompanied by a definition of a textual convention for use + with that InetAddressType. + + To support future extensions, the InetAddressType textual + convention SHOULD NOT be sub-typed in object type definitions. + It MAY be sub-typed in compliance statements in order to + require only a subset of these address types for a compliant + implementation. + + Implementations must ensure that InetAddressType objects + and any dependent objects (e.g., InetAddress objects) are + consistent. An inconsistentValue error must be generated + if an attempt to change an InetAddressType object would, + for example, lead to an undefined InetAddress value. In + + + + particular, InetAddressType/InetAddress pairs must be + changed together if the address type changes (e.g., from + ipv6(2) to ipv4(1))." + SYNTAX INTEGER { + unknown(0), + ipv4(1), + ipv6(2), + ipv4z(3), + ipv6z(4), + dns(16) + } + +InetAddress ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "Denotes a generic Internet address. + + An InetAddress value is always interpreted within the context + of an InetAddressType value. Every usage of the InetAddress + textual convention is required to specify the InetAddressType + object that provides the context. It is suggested that the + InetAddressType object be logically registered before the + object(s) that use the InetAddress textual convention, if + they appear in the same logical row. + + The value of an InetAddress object must always be + consistent with the value of the associated InetAddressType + object. Attempts to set an InetAddress object to a value + inconsistent with the associated InetAddressType + must fail with an inconsistentValue error. + + When this textual convention is used as the syntax of an + index object, there may be issues with the limit of 128 + sub-identifiers specified in SMIv2, STD 58. In this case, + the object definition MUST include a 'SIZE' clause to + limit the number of potential instance sub-identifiers; + otherwise the applicable constraints MUST be stated in + the appropriate conceptual row DESCRIPTION clauses, or + in the surrounding documentation if there is no single + DESCRIPTION clause that is appropriate." + SYNTAX OCTET STRING (SIZE (0..255)) + +InetAddressIPv4 ::= TEXTUAL-CONVENTION + DISPLAY-HINT "1d.1d.1d.1d" + STATUS current + DESCRIPTION + "Represents an IPv4 network address: + + + + + Octets Contents Encoding + 1-4 IPv4 address network-byte order + + The corresponding InetAddressType value is ipv4(1). + + This textual convention SHOULD NOT be used directly in object + definitions, as it restricts addresses to a specific format. + However, if it is used, it MAY be used either on its own or in + conjunction with InetAddressType, as a pair." + SYNTAX OCTET STRING (SIZE (4)) + +InetAddressIPv6 ::= TEXTUAL-CONVENTION + DISPLAY-HINT "2x:2x:2x:2x:2x:2x:2x:2x" + STATUS current + DESCRIPTION + "Represents an IPv6 network address: + + Octets Contents Encoding + 1-16 IPv6 address network-byte order + + The corresponding InetAddressType value is ipv6(2). + + This textual convention SHOULD NOT be used directly in object + definitions, as it restricts addresses to a specific format. + However, if it is used, it MAY be used either on its own or in + conjunction with InetAddressType, as a pair." + SYNTAX OCTET STRING (SIZE (16)) + +InetAddressIPv4z ::= TEXTUAL-CONVENTION + DISPLAY-HINT "1d.1d.1d.1d%4d" + STATUS current + DESCRIPTION + "Represents a non-global IPv4 network address, together + with its zone index: + + Octets Contents Encoding + 1-4 IPv4 address network-byte order + 5-8 zone index network-byte order + + The corresponding InetAddressType value is ipv4z(3). + + The zone index (bytes 5-8) is used to disambiguate identical + address values on nodes that have interfaces attached to + different zones of the same scope. The zone index may contain + the special value 0, which refers to the default zone for each + scope. + + This textual convention SHOULD NOT be used directly in object + + + + definitions, as it restricts addresses to a specific format. + However, if it is used, it MAY be used either on its own or in + conjunction with InetAddressType, as a pair." + SYNTAX OCTET STRING (SIZE (8)) + +InetAddressIPv6z ::= TEXTUAL-CONVENTION + DISPLAY-HINT "2x:2x:2x:2x:2x:2x:2x:2x%4d" + STATUS current + DESCRIPTION + "Represents a non-global IPv6 network address, together + with its zone index: + + Octets Contents Encoding + 1-16 IPv6 address network-byte order + 17-20 zone index network-byte order + + The corresponding InetAddressType value is ipv6z(4). + + The zone index (bytes 17-20) is used to disambiguate + identical address values on nodes that have interfaces + attached to different zones of the same scope. The zone index + may contain the special value 0, which refers to the default + zone for each scope. + + This textual convention SHOULD NOT be used directly in object + definitions, as it restricts addresses to a specific format. + However, if it is used, it MAY be used either on its own or in + conjunction with InetAddressType, as a pair." + SYNTAX OCTET STRING (SIZE (20)) + +InetAddressDNS ::= TEXTUAL-CONVENTION + DISPLAY-HINT "255a" + STATUS current + DESCRIPTION + "Represents a DNS domain name. The name SHOULD be fully + qualified whenever possible. + + The corresponding InetAddressType is dns(16). + + The DESCRIPTION clause of InetAddress objects that may have + InetAddressDNS values MUST fully describe how (and when) + these names are to be resolved to IP addresses. + + The resolution of an InetAddressDNS value may require to + query multiple DNS records (e.g., A for IPv4 and AAAA for + IPv6). The order of the resolution process and which DNS + record takes precedence depends on the configuration of the + resolver. + + + + This textual convention SHOULD NOT be used directly in object + definitions, as it restricts addresses to a specific format. + However, if it is used, it MAY be used either on its own or in + conjunction with InetAddressType, as a pair." + SYNTAX OCTET STRING (SIZE (1..255)) + +InetAddressPrefixLength ::= TEXTUAL-CONVENTION + DISPLAY-HINT "d" + STATUS current + DESCRIPTION + "Denotes the length of a generic Internet network address + prefix. A value of n corresponds to an IP address mask + that has n contiguous 1-bits from the most significant + bit (MSB), with all other bits set to 0. + + An InetAddressPrefixLength value is always interpreted within + the context of an InetAddressType value. Every usage of the + InetAddressPrefixLength textual convention is required to + specify the InetAddressType object that provides the + context. It is suggested that the InetAddressType object be + logically registered before the object(s) that use the + InetAddressPrefixLength textual convention, if they appear + in the same logical row. + + InetAddressPrefixLength values larger than + the maximum length of an IP address for a specific + InetAddressType are treated as the maximum significant + value applicable for the InetAddressType. The maximum + significant value is 32 for the InetAddressType + 'ipv4(1)' and 'ipv4z(3)' and 128 for the InetAddressType + 'ipv6(2)' and 'ipv6z(4)'. The maximum significant value + for the InetAddressType 'dns(16)' is 0. + + The value zero is object-specific and must be defined as + part of the description of any object that uses this + syntax. Examples of the usage of zero might include + situations where the Internet network address prefix + is unknown or does not apply. + + The upper bound of the prefix length has been chosen to + be consistent with the maximum size of an InetAddress." + SYNTAX Unsigned32 (0..2040) + +InetPortNumber ::= TEXTUAL-CONVENTION + DISPLAY-HINT "d" + STATUS current + DESCRIPTION + "Represents a 16 bit port number of an Internet transport + + + + layer protocol. Port numbers are assigned by IANA. A + current list of all assignments is available from + http://www.iana.org/. + + The value zero is object-specific and must be defined as + part of the description of any object that uses this + syntax. Examples of the usage of zero might include + situations where a port number is unknown, or when the + value zero is used as a wildcard in a filter." + REFERENCE "STD 6 (RFC 768), STD 7 (RFC 793) and RFC 2960" + SYNTAX Unsigned32 (0..65535) + +InetAutonomousSystemNumber ::= TEXTUAL-CONVENTION + DISPLAY-HINT "d" + STATUS current + DESCRIPTION + "Represents an autonomous system number that identifies an + Autonomous System (AS). An AS is a set of routers under a + single technical administration, using an interior gateway + protocol and common metrics to route packets within the AS, + and using an exterior gateway protocol to route packets to + other ASes'. IANA maintains the AS number space and has + delegated large parts to the regional registries. + + Autonomous system numbers are currently limited to 16 bits + (0..65535). There is, however, work in progress to enlarge the + autonomous system number space to 32 bits. Therefore, this + textual convention uses an Unsigned32 value without a + range restriction in order to support a larger autonomous + system number space." + REFERENCE "RFC 1771, RFC 1930" + SYNTAX Unsigned32 + +InetScopeType ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "Represents a scope type. This textual convention can be used + in cases where a MIB has to represent different scope types + and there is no context information, such as an InetAddress + object, that implicitly defines the scope type. + + Note that not all possible values have been assigned yet, but + they may be assigned in future revisions of this specification. + Applications should therefore be able to deal with values + not yet assigned." + REFERENCE "RFC 3513" + SYNTAX INTEGER { + -- reserved(0), + + + + interfaceLocal(1), + linkLocal(2), + subnetLocal(3), + adminLocal(4), + siteLocal(5), -- site-local unicast addresses + -- have been deprecated by RFC 3879 + -- unassigned(6), + -- unassigned(7), + organizationLocal(8), + -- unassigned(9), + -- unassigned(10), + -- unassigned(11), + -- unassigned(12), + -- unassigned(13), + global(14) + -- reserved(15) + } + +InetZoneIndex ::= TEXTUAL-CONVENTION + DISPLAY-HINT "d" + STATUS current + DESCRIPTION + "A zone index identifies an instance of a zone of a + specific scope. + + The zone index MUST disambiguate identical address + values. For link-local addresses, the zone index will + typically be the interface index (ifIndex as defined in the + IF-MIB) of the interface on which the address is configured. + + The zone index may contain the special value 0, which refers + to the default zone. The default zone may be used in cases + where the valid zone index is not known (e.g., when a + management application has to write a link-local IPv6 + address without knowing the interface index value). The + default zone SHOULD NOT be used as an easy way out in + cases where the zone index for a non-global IPv6 address + is known." + REFERENCE "RFC4007" + SYNTAX Unsigned32 + +InetVersion ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "A value representing a version of the IP protocol. + + unknown(0) An unknown or unspecified version of the IP + protocol. + + + + ipv4(1) The IPv4 protocol as defined in RFC 791 (STD 5). + + ipv6(2) The IPv6 protocol as defined in RFC 2460. + + Note that this textual convention SHOULD NOT be used to + distinguish different address types associated with IP + protocols. The InetAddressType has been designed for this + purpose." + REFERENCE "RFC 791, RFC 2460" + SYNTAX INTEGER { + unknown(0), + ipv4(1), + ipv6(2) + } +END diff --git a/contrib/apps/LwipMibCompiler/Mibs/IP-MIB b/contrib/apps/LwipMibCompiler/Mibs/IP-MIB new file mode 100644 index 00000000000..0a93501bc47 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/IP-MIB @@ -0,0 +1,5254 @@ +IP-MIB DEFINITIONS ::= BEGIN + +IMPORTS + MODULE-IDENTITY, OBJECT-TYPE, + Integer32, Counter32, IpAddress, + mib-2, Unsigned32, Counter64, + zeroDotZero FROM SNMPv2-SMI + PhysAddress, TruthValue, + TimeStamp, RowPointer, + TEXTUAL-CONVENTION, TestAndIncr, + RowStatus, StorageType FROM SNMPv2-TC + MODULE-COMPLIANCE, OBJECT-GROUP FROM SNMPv2-CONF + InetAddress, InetAddressType, + InetAddressPrefixLength, + InetVersion, InetZoneIndex FROM INET-ADDRESS-MIB + InterfaceIndex FROM IF-MIB; + +ipMIB MODULE-IDENTITY + LAST-UPDATED "200602020000Z" + ORGANIZATION "IETF IPv6 MIB Revision Team" + CONTACT-INFO + "Editor: + + + + Shawn A. Routhier + Interworking Labs + 108 Whispering Pines Dr. Suite 235 + Scotts Valley, CA 95066 + USA + EMail: sar@iwl.com" + DESCRIPTION + "The MIB module for managing IP and ICMP implementations, but + excluding their management of IP routes. + + Copyright (C) The Internet Society (2006). This version of + this MIB module is part of RFC 4293; see the RFC itself for + full legal notices." + + REVISION "200602020000Z" + DESCRIPTION + "The IP version neutral revision with added IPv6 objects for + ND, default routers, and router advertisements. As well as + being the successor to RFC 2011, this MIB is also the + successor to RFCs 2465 and 2466. Published as RFC 4293." + + REVISION "199411010000Z" + DESCRIPTION + "A separate MIB module (IP-MIB) for IP and ICMP management + objects. Published as RFC 2011." + + REVISION "199103310000Z" + DESCRIPTION + "The initial revision of this MIB module was part of MIB-II, + which was published as RFC 1213." + ::= { mib-2 48} + +-- +-- The textual conventions we define and use in this MIB. +-- + +IpAddressOriginTC ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "The origin of the address. + + manual(2) indicates that the address was manually configured + to a specified address, e.g., by user configuration. + + dhcp(4) indicates an address that was assigned to this + system by a DHCP server. + + linklayer(5) indicates an address created by IPv6 stateless + + + + auto-configuration. + + random(6) indicates an address chosen by the system at + random, e.g., an IPv4 address within 169.254/16, or an RFC + 3041 privacy address." + SYNTAX INTEGER { + other(1), + manual(2), + dhcp(4), + linklayer(5), + random(6) + } + +IpAddressStatusTC ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "The status of an address. Most of the states correspond to + states from the IPv6 Stateless Address Autoconfiguration + protocol. + + The preferred(1) state indicates that this is a valid + address that can appear as the destination or source address + of a packet. + + The deprecated(2) state indicates that this is a valid but + deprecated address that should no longer be used as a source + address in new communications, but packets addressed to such + an address are processed as expected. + + The invalid(3) state indicates that this isn't a valid + address and it shouldn't appear as the destination or source + address of a packet. + + The inaccessible(4) state indicates that the address is not + accessible because the interface to which this address is + assigned is not operational. + + The unknown(5) state indicates that the status cannot be + determined for some reason. + + The tentative(6) state indicates that the uniqueness of the + address on the link is being verified. Addresses in this + state should not be used for general communication and + should only be used to determine the uniqueness of the + address. + + The duplicate(7) state indicates the address has been + determined to be non-unique on the link and so must not be + + + + used. + + The optimistic(8) state indicates the address is available + for use, subject to restrictions, while its uniqueness on + a link is being verified. + + In the absence of other information, an IPv4 address is + always preferred(1)." + REFERENCE "RFC 2462" + SYNTAX INTEGER { + preferred(1), + deprecated(2), + invalid(3), + inaccessible(4), + unknown(5), + tentative(6), + duplicate(7), + optimistic(8) + } + +IpAddressPrefixOriginTC ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "The origin of this prefix. + + manual(2) indicates a prefix that was manually configured. + + wellknown(3) indicates a well-known prefix, e.g., 169.254/16 + for IPv4 auto-configuration or fe80::/10 for IPv6 link-local + addresses. Well known prefixes may be assigned by IANA, + the address registries, or by specification in a standards + track RFC. + + dhcp(4) indicates a prefix that was assigned by a DHCP + server. + + routeradv(5) indicates a prefix learned from a router + advertisement. + + Note: while IpAddressOriginTC and IpAddressPrefixOriginTC + are similar, they are not identical. The first defines how + an address was created, while the second defines how a + prefix was found." + SYNTAX INTEGER { + other(1), + manual(2), + wellknown(3), + dhcp(4), + + + + routeradv(5) + } + +Ipv6AddressIfIdentifierTC ::= TEXTUAL-CONVENTION + DISPLAY-HINT "2x:" + STATUS current + DESCRIPTION + "This data type is used to model IPv6 address + interface identifiers. This is a binary string + of up to 8 octets in network byte-order." + SYNTAX OCTET STRING (SIZE (0..8)) + +-- +-- the IP general group +-- some objects that affect all of IPv4 +-- + +ip OBJECT IDENTIFIER ::= { mib-2 4 } + +ipForwarding OBJECT-TYPE + SYNTAX INTEGER { + forwarding(1), -- acting as a router + notForwarding(2) -- NOT acting as a router + } + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "The indication of whether this entity is acting as an IPv4 + router in respect to the forwarding of datagrams received + by, but not addressed to, this entity. IPv4 routers forward + datagrams. IPv4 hosts do not (except those source-routed + via the host). + + When this object is written, the entity should save the + change to non-volatile storage and restore the object from + non-volatile storage upon re-initialization of the system. + Note: a stronger requirement is not used because this object + was previously defined." + ::= { ip 1 } + +ipDefaultTTL OBJECT-TYPE + SYNTAX Integer32 (1..255) + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "The default value inserted into the Time-To-Live field of + the IPv4 header of datagrams originated at this entity, + whenever a TTL value is not supplied by the transport layer + + + + protocol. + + When this object is written, the entity should save the + change to non-volatile storage and restore the object from + non-volatile storage upon re-initialization of the system. + Note: a stronger requirement is not used because this object + was previously defined." + ::= { ip 2 } + +ipReasmTimeout OBJECT-TYPE + SYNTAX Integer32 + UNITS "seconds" + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The maximum number of seconds that received fragments are + held while they are awaiting reassembly at this entity." + ::= { ip 13 } + +-- +-- the IPv6 general group +-- Some objects that affect all of IPv6 +-- + +ipv6IpForwarding OBJECT-TYPE + SYNTAX INTEGER { + forwarding(1), -- acting as a router + notForwarding(2) -- NOT acting as a router + } + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "The indication of whether this entity is acting as an IPv6 + router on any interface in respect to the forwarding of + datagrams received by, but not addressed to, this entity. + IPv6 routers forward datagrams. IPv6 hosts do not (except + those source-routed via the host). + + When this object is written, the entity SHOULD save the + change to non-volatile storage and restore the object from + non-volatile storage upon re-initialization of the system." + ::= { ip 25 } + +ipv6IpDefaultHopLimit OBJECT-TYPE + SYNTAX Integer32 (0..255) + MAX-ACCESS read-write + STATUS current + DESCRIPTION + + + + "The default value inserted into the Hop Limit field of the + IPv6 header of datagrams originated at this entity whenever + a Hop Limit value is not supplied by the transport layer + protocol. + + When this object is written, the entity SHOULD save the + change to non-volatile storage and restore the object from + non-volatile storage upon re-initialization of the system." + REFERENCE "RFC 2461 Section 6.3.2" + ::= { ip 26 } + +-- +-- IPv4 Interface Table +-- + +ipv4InterfaceTableLastChange OBJECT-TYPE + SYNTAX TimeStamp + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The value of sysUpTime on the most recent occasion at which + a row in the ipv4InterfaceTable was added or deleted, or + when an ipv4InterfaceReasmMaxSize or an + ipv4InterfaceEnableStatus object was modified. + + If new objects are added to the ipv4InterfaceTable that + require the ipv4InterfaceTableLastChange to be updated when + they are modified, they must specify that requirement in + their description clause." + ::= { ip 27 } + +ipv4InterfaceTable OBJECT-TYPE + SYNTAX SEQUENCE OF Ipv4InterfaceEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The table containing per-interface IPv4-specific + information." + ::= { ip 28 } + +ipv4InterfaceEntry OBJECT-TYPE + SYNTAX Ipv4InterfaceEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "An entry containing IPv4-specific information for a specific + interface." + INDEX { ipv4InterfaceIfIndex } + + + + ::= { ipv4InterfaceTable 1 } + +Ipv4InterfaceEntry ::= SEQUENCE { + ipv4InterfaceIfIndex InterfaceIndex, + ipv4InterfaceReasmMaxSize Integer32, + ipv4InterfaceEnableStatus INTEGER, + ipv4InterfaceRetransmitTime Unsigned32 + } + +ipv4InterfaceIfIndex OBJECT-TYPE + SYNTAX InterfaceIndex + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The index value that uniquely identifies the interface to + which this entry is applicable. The interface identified by + a particular value of this index is the same interface as + identified by the same value of the IF-MIB's ifIndex." + ::= { ipv4InterfaceEntry 1 } + +ipv4InterfaceReasmMaxSize OBJECT-TYPE + SYNTAX Integer32 (0..65535) + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The size of the largest IPv4 datagram that this entity can + re-assemble from incoming IPv4 fragmented datagrams received + on this interface." + ::= { ipv4InterfaceEntry 2 } + +ipv4InterfaceEnableStatus OBJECT-TYPE + SYNTAX INTEGER { + up(1), + down(2) + } + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "The indication of whether IPv4 is enabled (up) or disabled + (down) on this interface. This object does not affect the + state of the interface itself, only its connection to an + IPv4 stack. The IF-MIB should be used to control the state + of the interface." + ::= { ipv4InterfaceEntry 3 } + +ipv4InterfaceRetransmitTime OBJECT-TYPE + SYNTAX Unsigned32 + UNITS "milliseconds" + + + + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The time between retransmissions of ARP requests to a + neighbor when resolving the address or when probing the + reachability of a neighbor." + REFERENCE "RFC 1122" + DEFVAL { 1000 } + ::= { ipv4InterfaceEntry 4 } + +-- +-- v6 interface table +-- + +ipv6InterfaceTableLastChange OBJECT-TYPE + SYNTAX TimeStamp + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The value of sysUpTime on the most recent occasion at which + a row in the ipv6InterfaceTable was added or deleted or when + an ipv6InterfaceReasmMaxSize, ipv6InterfaceIdentifier, + ipv6InterfaceEnableStatus, ipv6InterfaceReachableTime, + ipv6InterfaceRetransmitTime, or ipv6InterfaceForwarding + object was modified. + + If new objects are added to the ipv6InterfaceTable that + require the ipv6InterfaceTableLastChange to be updated when + they are modified, they must specify that requirement in + their description clause." + ::= { ip 29 } + +ipv6InterfaceTable OBJECT-TYPE + SYNTAX SEQUENCE OF Ipv6InterfaceEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The table containing per-interface IPv6-specific + information." + ::= { ip 30 } + +ipv6InterfaceEntry OBJECT-TYPE + SYNTAX Ipv6InterfaceEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "An entry containing IPv6-specific information for a given + interface." + + + + INDEX { ipv6InterfaceIfIndex } + ::= { ipv6InterfaceTable 1 } + +Ipv6InterfaceEntry ::= SEQUENCE { + ipv6InterfaceIfIndex InterfaceIndex, + ipv6InterfaceReasmMaxSize Unsigned32, + ipv6InterfaceIdentifier Ipv6AddressIfIdentifierTC, + ipv6InterfaceEnableStatus INTEGER, + ipv6InterfaceReachableTime Unsigned32, + ipv6InterfaceRetransmitTime Unsigned32, + ipv6InterfaceForwarding INTEGER + } + +ipv6InterfaceIfIndex OBJECT-TYPE + SYNTAX InterfaceIndex + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The index value that uniquely identifies the interface to + which this entry is applicable. The interface identified by + a particular value of this index is the same interface as + identified by the same value of the IF-MIB's ifIndex." + ::= { ipv6InterfaceEntry 1 } + +ipv6InterfaceReasmMaxSize OBJECT-TYPE + SYNTAX Unsigned32 (1500..65535) + UNITS "octets" + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The size of the largest IPv6 datagram that this entity can + re-assemble from incoming IPv6 fragmented datagrams received + on this interface." + ::= { ipv6InterfaceEntry 2 } + +ipv6InterfaceIdentifier OBJECT-TYPE + SYNTAX Ipv6AddressIfIdentifierTC + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The Interface Identifier for this interface. The Interface + Identifier is combined with an address prefix to form an + interface address. + + By default, the Interface Identifier is auto-configured + according to the rules of the link type to which this + interface is attached. + + + + + A zero length identifier may be used where appropriate. One + possible example is a loopback interface." + ::= { ipv6InterfaceEntry 3 } + +-- This object ID is reserved as it was used in earlier versions of +-- the MIB module. In theory, OIDs are not assigned until the +-- specification is released as an RFC; however, as some companies +-- may have shipped code based on earlier versions of the MIB, it +-- seems best to reserve this OID. This OID had been +-- ipv6InterfacePhysicalAddress. +-- ::= { ipv6InterfaceEntry 4} + +ipv6InterfaceEnableStatus OBJECT-TYPE + SYNTAX INTEGER { + up(1), + down(2) + } + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "The indication of whether IPv6 is enabled (up) or disabled + (down) on this interface. This object does not affect the + state of the interface itself, only its connection to an + IPv6 stack. The IF-MIB should be used to control the state + of the interface. + + When this object is written, the entity SHOULD save the + change to non-volatile storage and restore the object from + non-volatile storage upon re-initialization of the system." + ::= { ipv6InterfaceEntry 5 } + +ipv6InterfaceReachableTime OBJECT-TYPE + SYNTAX Unsigned32 + UNITS "milliseconds" + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The time a neighbor is considered reachable after receiving + a reachability confirmation." + REFERENCE "RFC 2461, Section 6.3.2" + ::= { ipv6InterfaceEntry 6 } + +ipv6InterfaceRetransmitTime OBJECT-TYPE + SYNTAX Unsigned32 + UNITS "milliseconds" + MAX-ACCESS read-only + STATUS current + DESCRIPTION + + + + "The time between retransmissions of Neighbor Solicitation + messages to a neighbor when resolving the address or when + probing the reachability of a neighbor." + REFERENCE "RFC 2461, Section 6.3.2" + ::= { ipv6InterfaceEntry 7 } + +ipv6InterfaceForwarding OBJECT-TYPE + SYNTAX INTEGER { + forwarding(1), -- acting as a router + notForwarding(2) -- NOT acting as a router + } + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "The indication of whether this entity is acting as an IPv6 + router on this interface with respect to the forwarding of + datagrams received by, but not addressed to, this entity. + IPv6 routers forward datagrams. IPv6 hosts do not (except + those source-routed via the host). + + This object is constrained by ipv6IpForwarding and is + ignored if ipv6IpForwarding is set to notForwarding. Those + systems that do not provide per-interface control of the + forwarding function should set this object to forwarding for + all interfaces and allow the ipv6IpForwarding object to + control the forwarding capability. + + When this object is written, the entity SHOULD save the + change to non-volatile storage and restore the object from + non-volatile storage upon re-initialization of the system." + ::= { ipv6InterfaceEntry 8 } + +-- +-- Per-Interface or System-Wide IP statistics. +-- +-- The following two tables, ipSystemStatsTable and ipIfStatsTable, +-- are intended to provide the same counters at different granularities. +-- The ipSystemStatsTable provides system wide counters aggregating +-- the traffic counters for all interfaces for a given address type. +-- The ipIfStatsTable provides the same counters but for specific +-- interfaces rather than as an aggregate. +-- +-- Note well: If a system provides both system-wide and interface- +-- specific values, the system-wide value may not be equal to the sum +-- of the interface-specific values across all interfaces due to e.g., +-- dynamic interface creation/deletion. +-- +-- Note well: Both of these tables contain some items that are + + + +-- represented by two objects, representing the value in either 32 +-- or 64 bits. For those objects, the 32-bit value MUST be the low +-- order 32 bits of the 64-bit value. Also note that the 32-bit +-- counters must be included when the 64-bit counters are included. + +ipTrafficStats OBJECT IDENTIFIER ::= { ip 31 } + +ipSystemStatsTable OBJECT-TYPE + SYNTAX SEQUENCE OF IpSystemStatsEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The table containing system wide, IP version specific + traffic statistics. This table and the ipIfStatsTable + contain similar objects whose difference is in their + granularity. Where this table contains system wide traffic + statistics, the ipIfStatsTable contains the same statistics + but counted on a per-interface basis." + ::= { ipTrafficStats 1 } + +ipSystemStatsEntry OBJECT-TYPE + SYNTAX IpSystemStatsEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "A statistics entry containing system-wide objects for a + particular IP version." + INDEX { ipSystemStatsIPVersion } + ::= { ipSystemStatsTable 1 } + +IpSystemStatsEntry ::= SEQUENCE { + ipSystemStatsIPVersion InetVersion, + ipSystemStatsInReceives Counter32, + ipSystemStatsHCInReceives Counter64, + ipSystemStatsInOctets Counter32, + ipSystemStatsHCInOctets Counter64, + ipSystemStatsInHdrErrors Counter32, + ipSystemStatsInNoRoutes Counter32, + ipSystemStatsInAddrErrors Counter32, + ipSystemStatsInUnknownProtos Counter32, + ipSystemStatsInTruncatedPkts Counter32, + ipSystemStatsInForwDatagrams Counter32, + ipSystemStatsHCInForwDatagrams Counter64, + ipSystemStatsReasmReqds Counter32, + ipSystemStatsReasmOKs Counter32, + ipSystemStatsReasmFails Counter32, + ipSystemStatsInDiscards Counter32, + ipSystemStatsInDelivers Counter32, + + + + ipSystemStatsHCInDelivers Counter64, + ipSystemStatsOutRequests Counter32, + ipSystemStatsHCOutRequests Counter64, + ipSystemStatsOutNoRoutes Counter32, + ipSystemStatsOutForwDatagrams Counter32, + ipSystemStatsHCOutForwDatagrams Counter64, + ipSystemStatsOutDiscards Counter32, + ipSystemStatsOutFragReqds Counter32, + ipSystemStatsOutFragOKs Counter32, + ipSystemStatsOutFragFails Counter32, + ipSystemStatsOutFragCreates Counter32, + ipSystemStatsOutTransmits Counter32, + ipSystemStatsHCOutTransmits Counter64, + ipSystemStatsOutOctets Counter32, + ipSystemStatsHCOutOctets Counter64, + ipSystemStatsInMcastPkts Counter32, + ipSystemStatsHCInMcastPkts Counter64, + ipSystemStatsInMcastOctets Counter32, + ipSystemStatsHCInMcastOctets Counter64, + ipSystemStatsOutMcastPkts Counter32, + ipSystemStatsHCOutMcastPkts Counter64, + ipSystemStatsOutMcastOctets Counter32, + ipSystemStatsHCOutMcastOctets Counter64, + ipSystemStatsInBcastPkts Counter32, + ipSystemStatsHCInBcastPkts Counter64, + ipSystemStatsOutBcastPkts Counter32, + ipSystemStatsHCOutBcastPkts Counter64, + ipSystemStatsDiscontinuityTime TimeStamp, + ipSystemStatsRefreshRate Unsigned32 + } + +ipSystemStatsIPVersion OBJECT-TYPE + SYNTAX InetVersion + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The IP version of this row." + ::= { ipSystemStatsEntry 1 } + +-- This object ID is reserved to allow the IDs for this table's objects +-- to align with the objects in the ipIfStatsTable. +-- ::= { ipSystemStatsEntry 2 } + +ipSystemStatsInReceives OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + + + + "The total number of input IP datagrams received, including + those received in error. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 3 } + +ipSystemStatsHCInReceives OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of input IP datagrams received, including + those received in error. This object counts the same + datagrams as ipSystemStatsInReceives, but allows for larger + values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 4 } + +ipSystemStatsInOctets OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets received in input IP datagrams, + including those received in error. Octets from datagrams + counted in ipSystemStatsInReceives MUST be counted here. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 5 } + +ipSystemStatsHCInOctets OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets received in input IP datagrams, + including those received in error. This object counts the + same octets as ipSystemStatsInOctets, but allows for larger + + + + values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 6 } + +ipSystemStatsInHdrErrors OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of input IP datagrams discarded due to errors in + their IP headers, including version number mismatch, other + format errors, hop count exceeded, errors discovered in + processing their IP options, etc. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 7 } + +ipSystemStatsInNoRoutes OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of input IP datagrams discarded because no route + could be found to transmit them to their destination. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 8 } + +ipSystemStatsInAddrErrors OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of input IP datagrams discarded because the IP + address in their IP header's destination field was not a + valid address to be received at this entity. This count + includes invalid addresses (e.g., ::0). For entities + that are not IP routers and therefore do not forward + + + + datagrams, this counter includes datagrams discarded + because the destination address was not a local address. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 9 } + +ipSystemStatsInUnknownProtos OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of locally-addressed IP datagrams received + successfully but discarded because of an unknown or + unsupported protocol. + + When tracking interface statistics, the counter of the + interface to which these datagrams were addressed is + incremented. This interface might not be the same as the + input interface for some of the datagrams. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 10 } + +ipSystemStatsInTruncatedPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of input IP datagrams discarded because the + datagram frame didn't carry enough data. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 11 } + +ipSystemStatsInForwDatagrams OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + + + + "The number of input datagrams for which this entity was not + their final IP destination and for which this entity + attempted to find a route to forward them to that final + destination. In entities that do not act as IP routers, + this counter will include only those datagrams that were + Source-Routed via this entity, and the Source-Route + processing was successful. + + When tracking interface statistics, the counter of the + incoming interface is incremented for each datagram. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 12 } + +ipSystemStatsHCInForwDatagrams OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of input datagrams for which this entity was not + their final IP destination and for which this entity + attempted to find a route to forward them to that final + destination. This object counts the same packets as + ipSystemStatsInForwDatagrams, but allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 13 } + +ipSystemStatsReasmReqds OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP fragments received that needed to be + reassembled at this interface. + + When tracking interface statistics, the counter of the + interface to which these fragments were addressed is + incremented. This interface might not be the same as the + input interface for some of the fragments. + + Discontinuities in the value of this counter can occur at + + + + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 14 } + +ipSystemStatsReasmOKs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP datagrams successfully reassembled. + + When tracking interface statistics, the counter of the + interface to which these datagrams were addressed is + incremented. This interface might not be the same as the + input interface for some of the datagrams. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 15 } + +ipSystemStatsReasmFails OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of failures detected by the IP re-assembly + algorithm (for whatever reason: timed out, errors, etc.). + Note that this is not necessarily a count of discarded IP + fragments since some algorithms (notably the algorithm in + RFC 815) can lose track of the number of fragments by + combining them as they are received. + + When tracking interface statistics, the counter of the + interface to which these fragments were addressed is + incremented. This interface might not be the same as the + input interface for some of the fragments. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 16 } + +ipSystemStatsInDiscards OBJECT-TYPE + SYNTAX Counter32 + + + + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of input IP datagrams for which no problems were + encountered to prevent their continued processing, but + were discarded (e.g., for lack of buffer space). Note that + this counter does not include any datagrams discarded while + awaiting re-assembly. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 17 } + +ipSystemStatsInDelivers OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of datagrams successfully delivered to IP + user-protocols (including ICMP). + + When tracking interface statistics, the counter of the + interface to which these datagrams were addressed is + incremented. This interface might not be the same as the + input interface for some of the datagrams. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 18 } + +ipSystemStatsHCInDelivers OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of datagrams successfully delivered to IP + user-protocols (including ICMP). This object counts the + same packets as ipSystemStatsInDelivers, but allows for + larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + + + + ::= { ipSystemStatsEntry 19 } + +ipSystemStatsOutRequests OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of IP datagrams that local IP user- + protocols (including ICMP) supplied to IP in requests for + transmission. Note that this counter does not include any + datagrams counted in ipSystemStatsOutForwDatagrams. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 20 } + +ipSystemStatsHCOutRequests OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of IP datagrams that local IP user- + protocols (including ICMP) supplied to IP in requests for + transmission. This object counts the same packets as + ipSystemStatsOutRequests, but allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 21 } + +ipSystemStatsOutNoRoutes OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of locally generated IP datagrams discarded + because no route could be found to transmit them to their + destination. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 22 } + + + +ipSystemStatsOutForwDatagrams OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of datagrams for which this entity was not their + final IP destination and for which it was successful in + finding a path to their final destination. In entities + that do not act as IP routers, this counter will include + only those datagrams that were Source-Routed via this + entity, and the Source-Route processing was successful. + + When tracking interface statistics, the counter of the + outgoing interface is incremented for a successfully + forwarded datagram. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 23 } + +ipSystemStatsHCOutForwDatagrams OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of datagrams for which this entity was not their + final IP destination and for which it was successful in + finding a path to their final destination. This object + counts the same packets as ipSystemStatsOutForwDatagrams, + but allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 24 } + +ipSystemStatsOutDiscards OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of output IP datagrams for which no problem was + encountered to prevent their transmission to their + destination, but were discarded (e.g., for lack of + buffer space). Note that this counter would include + + + + datagrams counted in ipSystemStatsOutForwDatagrams if any + such datagrams met this (discretionary) discard criterion. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 25 } + +ipSystemStatsOutFragReqds OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP datagrams that would require fragmentation + in order to be transmitted. + + When tracking interface statistics, the counter of the + outgoing interface is incremented for a successfully + fragmented datagram. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 26 } + +ipSystemStatsOutFragOKs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP datagrams that have been successfully + fragmented. + + When tracking interface statistics, the counter of the + outgoing interface is incremented for a successfully + fragmented datagram. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 27 } + +ipSystemStatsOutFragFails OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + + + + STATUS current + DESCRIPTION + "The number of IP datagrams that have been discarded because + they needed to be fragmented but could not be. This + includes IPv4 packets that have the DF bit set and IPv6 + packets that are being forwarded and exceed the outgoing + link MTU. + + When tracking interface statistics, the counter of the + outgoing interface is incremented for an unsuccessfully + fragmented datagram. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 28 } + +ipSystemStatsOutFragCreates OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of output datagram fragments that have been + generated as a result of IP fragmentation. + + When tracking interface statistics, the counter of the + outgoing interface is incremented for a successfully + fragmented datagram. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 29 } + +ipSystemStatsOutTransmits OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of IP datagrams that this entity supplied + to the lower layers for transmission. This includes + datagrams generated locally and those forwarded by this + entity. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + + + + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 30 } + +ipSystemStatsHCOutTransmits OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of IP datagrams that this entity supplied + to the lower layers for transmission. This object counts + the same datagrams as ipSystemStatsOutTransmits, but allows + for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 31 } + +ipSystemStatsOutOctets OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets in IP datagrams delivered to the + lower layers for transmission. Octets from datagrams + counted in ipSystemStatsOutTransmits MUST be counted here. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 32 } + +ipSystemStatsHCOutOctets OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets in IP datagrams delivered to the + lower layers for transmission. This objects counts the same + octets as ipSystemStatsOutOctets, but allows for larger + values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + + + + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 33 } + +ipSystemStatsInMcastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP multicast datagrams received. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 34 } + +ipSystemStatsHCInMcastPkts OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP multicast datagrams received. This object + counts the same datagrams as ipSystemStatsInMcastPkts but + allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 35 } + +ipSystemStatsInMcastOctets OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets received in IP multicast + datagrams. Octets from datagrams counted in + ipSystemStatsInMcastPkts MUST be counted here. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 36 } + +ipSystemStatsHCInMcastOctets OBJECT-TYPE + SYNTAX Counter64 + + + + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets received in IP multicast + datagrams. This object counts the same octets as + ipSystemStatsInMcastOctets, but allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 37 } + +ipSystemStatsOutMcastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP multicast datagrams transmitted. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 38 } + +ipSystemStatsHCOutMcastPkts OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP multicast datagrams transmitted. This + object counts the same datagrams as + ipSystemStatsOutMcastPkts, but allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 39 } + +ipSystemStatsOutMcastOctets OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets transmitted in IP multicast + datagrams. Octets from datagrams counted in + + + + ipSystemStatsOutMcastPkts MUST be counted here. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 40 } + +ipSystemStatsHCOutMcastOctets OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets transmitted in IP multicast + datagrams. This object counts the same octets as + ipSystemStatsOutMcastOctets, but allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 41 } + +ipSystemStatsInBcastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP broadcast datagrams received. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 42 } + +ipSystemStatsHCInBcastPkts OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP broadcast datagrams received. This object + counts the same datagrams as ipSystemStatsInBcastPkts but + allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + + + + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 43 } + +ipSystemStatsOutBcastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP broadcast datagrams transmitted. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 44 } + +ipSystemStatsHCOutBcastPkts OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP broadcast datagrams transmitted. This + object counts the same datagrams as + ipSystemStatsOutBcastPkts, but allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipSystemStatsDiscontinuityTime." + ::= { ipSystemStatsEntry 45 } + +ipSystemStatsDiscontinuityTime OBJECT-TYPE + SYNTAX TimeStamp + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The value of sysUpTime on the most recent occasion at which + any one or more of this entry's counters suffered a + discontinuity. + + If no such discontinuities have occurred since the last re- + initialization of the local management subsystem, then this + object contains a zero value." + ::= { ipSystemStatsEntry 46 } + +ipSystemStatsRefreshRate OBJECT-TYPE + SYNTAX Unsigned32 + UNITS "milli-seconds" + + + + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The minimum reasonable polling interval for this entry. + This object provides an indication of the minimum amount of + time required to update the counters in this entry." + ::= { ipSystemStatsEntry 47 } + +ipIfStatsTableLastChange OBJECT-TYPE + SYNTAX TimeStamp + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The value of sysUpTime on the most recent occasion at which + a row in the ipIfStatsTable was added or deleted. + + If new objects are added to the ipIfStatsTable that require + the ipIfStatsTableLastChange to be updated when they are + modified, they must specify that requirement in their + description clause." + ::= { ipTrafficStats 2 } + +ipIfStatsTable OBJECT-TYPE + SYNTAX SEQUENCE OF IpIfStatsEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The table containing per-interface traffic statistics. This + table and the ipSystemStatsTable contain similar objects + whose difference is in their granularity. Where this table + contains per-interface statistics, the ipSystemStatsTable + contains the same statistics, but counted on a system wide + basis." + ::= { ipTrafficStats 3 } + +ipIfStatsEntry OBJECT-TYPE + SYNTAX IpIfStatsEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "An interface statistics entry containing objects for a + particular interface and version of IP." + INDEX { ipIfStatsIPVersion, ipIfStatsIfIndex } + ::= { ipIfStatsTable 1 } + +IpIfStatsEntry ::= SEQUENCE { + ipIfStatsIPVersion InetVersion, + ipIfStatsIfIndex InterfaceIndex, + + + + ipIfStatsInReceives Counter32, + ipIfStatsHCInReceives Counter64, + ipIfStatsInOctets Counter32, + ipIfStatsHCInOctets Counter64, + ipIfStatsInHdrErrors Counter32, + ipIfStatsInNoRoutes Counter32, + ipIfStatsInAddrErrors Counter32, + ipIfStatsInUnknownProtos Counter32, + ipIfStatsInTruncatedPkts Counter32, + ipIfStatsInForwDatagrams Counter32, + ipIfStatsHCInForwDatagrams Counter64, + ipIfStatsReasmReqds Counter32, + ipIfStatsReasmOKs Counter32, + ipIfStatsReasmFails Counter32, + ipIfStatsInDiscards Counter32, + ipIfStatsInDelivers Counter32, + ipIfStatsHCInDelivers Counter64, + ipIfStatsOutRequests Counter32, + ipIfStatsHCOutRequests Counter64, + ipIfStatsOutForwDatagrams Counter32, + ipIfStatsHCOutForwDatagrams Counter64, + ipIfStatsOutDiscards Counter32, + ipIfStatsOutFragReqds Counter32, + ipIfStatsOutFragOKs Counter32, + ipIfStatsOutFragFails Counter32, + ipIfStatsOutFragCreates Counter32, + ipIfStatsOutTransmits Counter32, + ipIfStatsHCOutTransmits Counter64, + ipIfStatsOutOctets Counter32, + ipIfStatsHCOutOctets Counter64, + ipIfStatsInMcastPkts Counter32, + ipIfStatsHCInMcastPkts Counter64, + ipIfStatsInMcastOctets Counter32, + ipIfStatsHCInMcastOctets Counter64, + ipIfStatsOutMcastPkts Counter32, + ipIfStatsHCOutMcastPkts Counter64, + ipIfStatsOutMcastOctets Counter32, + ipIfStatsHCOutMcastOctets Counter64, + ipIfStatsInBcastPkts Counter32, + ipIfStatsHCInBcastPkts Counter64, + ipIfStatsOutBcastPkts Counter32, + ipIfStatsHCOutBcastPkts Counter64, + ipIfStatsDiscontinuityTime TimeStamp, + ipIfStatsRefreshRate Unsigned32 + } + +ipIfStatsIPVersion OBJECT-TYPE + SYNTAX InetVersion + + + + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The IP version of this row." + ::= { ipIfStatsEntry 1 } + +ipIfStatsIfIndex OBJECT-TYPE + SYNTAX InterfaceIndex + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The index value that uniquely identifies the interface to + which this entry is applicable. The interface identified by + a particular value of this index is the same interface as + identified by the same value of the IF-MIB's ifIndex." + ::= { ipIfStatsEntry 2 } + +ipIfStatsInReceives OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of input IP datagrams received, including + those received in error. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 3 } + +ipIfStatsHCInReceives OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of input IP datagrams received, including + those received in error. This object counts the same + datagrams as ipIfStatsInReceives, but allows for larger + values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 4 } + +ipIfStatsInOctets OBJECT-TYPE + + + + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets received in input IP datagrams, + including those received in error. Octets from datagrams + counted in ipIfStatsInReceives MUST be counted here. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 5 } + +ipIfStatsHCInOctets OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets received in input IP datagrams, + including those received in error. This object counts the + same octets as ipIfStatsInOctets, but allows for larger + values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 6 } + +ipIfStatsInHdrErrors OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of input IP datagrams discarded due to errors in + their IP headers, including version number mismatch, other + format errors, hop count exceeded, errors discovered in + processing their IP options, etc. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 7 } + +ipIfStatsInNoRoutes OBJECT-TYPE + SYNTAX Counter32 + + + + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of input IP datagrams discarded because no route + could be found to transmit them to their destination. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 8 } + +ipIfStatsInAddrErrors OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of input IP datagrams discarded because the IP + address in their IP header's destination field was not a + valid address to be received at this entity. This count + includes invalid addresses (e.g., ::0). For entities that + are not IP routers and therefore do not forward datagrams, + this counter includes datagrams discarded because the + destination address was not a local address. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 9 } + +ipIfStatsInUnknownProtos OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of locally-addressed IP datagrams received + successfully but discarded because of an unknown or + unsupported protocol. + + When tracking interface statistics, the counter of the + interface to which these datagrams were addressed is + incremented. This interface might not be the same as the + input interface for some of the datagrams. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + + + + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 10 } + +ipIfStatsInTruncatedPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of input IP datagrams discarded because the + datagram frame didn't carry enough data. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 11 } + +ipIfStatsInForwDatagrams OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of input datagrams for which this entity was not + their final IP destination and for which this entity + attempted to find a route to forward them to that final + destination. In entities that do not act as IP routers, + this counter will include only those datagrams that were + Source-Routed via this entity, and the Source-Route + processing was successful. + + When tracking interface statistics, the counter of the + incoming interface is incremented for each datagram. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 12 } + +ipIfStatsHCInForwDatagrams OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of input datagrams for which this entity was not + their final IP destination and for which this entity + attempted to find a route to forward them to that final + destination. This object counts the same packets as + + + + ipIfStatsInForwDatagrams, but allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 13 } + +ipIfStatsReasmReqds OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP fragments received that needed to be + reassembled at this interface. + + When tracking interface statistics, the counter of the + interface to which these fragments were addressed is + incremented. This interface might not be the same as the + input interface for some of the fragments. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 14 } + +ipIfStatsReasmOKs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP datagrams successfully reassembled. + + When tracking interface statistics, the counter of the + interface to which these datagrams were addressed is + incremented. This interface might not be the same as the + input interface for some of the datagrams. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 15 } + +ipIfStatsReasmFails OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + + + + STATUS current + DESCRIPTION + "The number of failures detected by the IP re-assembly + algorithm (for whatever reason: timed out, errors, etc.). + Note that this is not necessarily a count of discarded IP + fragments since some algorithms (notably the algorithm in + RFC 815) can lose track of the number of fragments by + combining them as they are received. + + When tracking interface statistics, the counter of the + interface to which these fragments were addressed is + incremented. This interface might not be the same as the + input interface for some of the fragments. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 16 } + +ipIfStatsInDiscards OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of input IP datagrams for which no problems were + encountered to prevent their continued processing, but + were discarded (e.g., for lack of buffer space). Note that + this counter does not include any datagrams discarded while + awaiting re-assembly. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 17 } + +ipIfStatsInDelivers OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of datagrams successfully delivered to IP + user-protocols (including ICMP). + + When tracking interface statistics, the counter of the + interface to which these datagrams were addressed is + incremented. This interface might not be the same as the + + + + input interface for some of the datagrams. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 18 } + +ipIfStatsHCInDelivers OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of datagrams successfully delivered to IP + user-protocols (including ICMP). This object counts the + same packets as ipIfStatsInDelivers, but allows for larger + values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 19 } + +ipIfStatsOutRequests OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of IP datagrams that local IP user- + protocols (including ICMP) supplied to IP in requests for + transmission. Note that this counter does not include any + datagrams counted in ipIfStatsOutForwDatagrams. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 20 } + +ipIfStatsHCOutRequests OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of IP datagrams that local IP user- + protocols (including ICMP) supplied to IP in requests for + transmission. This object counts the same packets as + + + + ipIfStatsOutRequests, but allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 21 } + +-- This object ID is reserved to allow the IDs for this table's objects +-- to align with the objects in the ipSystemStatsTable. +-- ::= {ipIfStatsEntry 22} + +ipIfStatsOutForwDatagrams OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of datagrams for which this entity was not their + final IP destination and for which it was successful in + finding a path to their final destination. In entities + that do not act as IP routers, this counter will include + only those datagrams that were Source-Routed via this + entity, and the Source-Route processing was successful. + + When tracking interface statistics, the counter of the + outgoing interface is incremented for a successfully + forwarded datagram. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 23 } + +ipIfStatsHCOutForwDatagrams OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of datagrams for which this entity was not their + final IP destination and for which it was successful in + finding a path to their final destination. This object + counts the same packets as ipIfStatsOutForwDatagrams, but + allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + + + + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 24 } + +ipIfStatsOutDiscards OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of output IP datagrams for which no problem was + encountered to prevent their transmission to their + destination, but were discarded (e.g., for lack of + buffer space). Note that this counter would include + datagrams counted in ipIfStatsOutForwDatagrams if any such + datagrams met this (discretionary) discard criterion. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 25 } + +ipIfStatsOutFragReqds OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP datagrams that would require fragmentation + in order to be transmitted. + + When tracking interface statistics, the counter of the + outgoing interface is incremented for a successfully + fragmented datagram. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 26 } + +ipIfStatsOutFragOKs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP datagrams that have been successfully + fragmented. + + When tracking interface statistics, the counter of the + + + + outgoing interface is incremented for a successfully + fragmented datagram. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 27 } + +ipIfStatsOutFragFails OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP datagrams that have been discarded because + they needed to be fragmented but could not be. This + includes IPv4 packets that have the DF bit set and IPv6 + packets that are being forwarded and exceed the outgoing + link MTU. + + When tracking interface statistics, the counter of the + outgoing interface is incremented for an unsuccessfully + fragmented datagram. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 28 } + +ipIfStatsOutFragCreates OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of output datagram fragments that have been + generated as a result of IP fragmentation. + + When tracking interface statistics, the counter of the + outgoing interface is incremented for a successfully + fragmented datagram. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 29 } + + + + +ipIfStatsOutTransmits OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of IP datagrams that this entity supplied + to the lower layers for transmission. This includes + datagrams generated locally and those forwarded by this + entity. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 30 } + +ipIfStatsHCOutTransmits OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of IP datagrams that this entity supplied + to the lower layers for transmission. This object counts + the same datagrams as ipIfStatsOutTransmits, but allows for + larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 31 } + +ipIfStatsOutOctets OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets in IP datagrams delivered to the + lower layers for transmission. Octets from datagrams + counted in ipIfStatsOutTransmits MUST be counted here. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 32 } + +ipIfStatsHCOutOctets OBJECT-TYPE + + + + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets in IP datagrams delivered to the + lower layers for transmission. This objects counts the same + octets as ipIfStatsOutOctets, but allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 33 } + +ipIfStatsInMcastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP multicast datagrams received. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 34 } + +ipIfStatsHCInMcastPkts OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP multicast datagrams received. This object + counts the same datagrams as ipIfStatsInMcastPkts, but + allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 35 } + +ipIfStatsInMcastOctets OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets received in IP multicast + + + + datagrams. Octets from datagrams counted in + ipIfStatsInMcastPkts MUST be counted here. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 36 } + +ipIfStatsHCInMcastOctets OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets received in IP multicast + datagrams. This object counts the same octets as + ipIfStatsInMcastOctets, but allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 37 } + +ipIfStatsOutMcastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP multicast datagrams transmitted. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 38 } + +ipIfStatsHCOutMcastPkts OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP multicast datagrams transmitted. This + object counts the same datagrams as ipIfStatsOutMcastPkts, + but allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + + + + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 39 } + +ipIfStatsOutMcastOctets OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets transmitted in IP multicast + datagrams. Octets from datagrams counted in + ipIfStatsOutMcastPkts MUST be counted here. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 40 } + +ipIfStatsHCOutMcastOctets OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of octets transmitted in IP multicast + datagrams. This object counts the same octets as + ipIfStatsOutMcastOctets, but allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 41 } + +ipIfStatsInBcastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP broadcast datagrams received. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 42 } + +ipIfStatsHCInBcastPkts OBJECT-TYPE + + + + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP broadcast datagrams received. This object + counts the same datagrams as ipIfStatsInBcastPkts, but + allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 43 } + +ipIfStatsOutBcastPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP broadcast datagrams transmitted. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 44 } + +ipIfStatsHCOutBcastPkts OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of IP broadcast datagrams transmitted. This + object counts the same datagrams as ipIfStatsOutBcastPkts, + but allows for larger values. + + Discontinuities in the value of this counter can occur at + re-initialization of the management system, and at other + times as indicated by the value of + ipIfStatsDiscontinuityTime." + ::= { ipIfStatsEntry 45 } + +ipIfStatsDiscontinuityTime OBJECT-TYPE + SYNTAX TimeStamp + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The value of sysUpTime on the most recent occasion at which + + + + any one or more of this entry's counters suffered a + discontinuity. + + If no such discontinuities have occurred since the last re- + initialization of the local management subsystem, then this + object contains a zero value." + ::= { ipIfStatsEntry 46 } + +ipIfStatsRefreshRate OBJECT-TYPE + SYNTAX Unsigned32 + UNITS "milli-seconds" + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The minimum reasonable polling interval for this entry. + This object provides an indication of the minimum amount of + time required to update the counters in this entry." + ::= { ipIfStatsEntry 47 } + +-- +-- Internet Address Prefix table +-- + +ipAddressPrefixTable OBJECT-TYPE + SYNTAX SEQUENCE OF IpAddressPrefixEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "This table allows the user to determine the source of an IP + address or set of IP addresses, and allows other tables to + share the information via pointer rather than by copying. + + For example, when the node configures both a unicast and + anycast address for a prefix, the ipAddressPrefix objects + for those addresses will point to a single row in this + table. + + This table primarily provides support for IPv6 prefixes, and + several of the objects are less meaningful for IPv4. The + table continues to allow IPv4 addresses to allow future + flexibility. In order to promote a common configuration, + this document includes suggestions for default values for + IPv4 prefixes. Each of these values may be overridden if an + object is meaningful to the node. + + All prefixes used by this entity should be included in this + table independent of how the entity learned the prefix. + (This table isn't limited to prefixes learned from router + + + + advertisements.)" + ::= { ip 32 } + +ipAddressPrefixEntry OBJECT-TYPE + SYNTAX IpAddressPrefixEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "An entry in the ipAddressPrefixTable." + INDEX { ipAddressPrefixIfIndex, ipAddressPrefixType, + ipAddressPrefixPrefix, ipAddressPrefixLength } + ::= { ipAddressPrefixTable 1 } + +IpAddressPrefixEntry ::= SEQUENCE { + ipAddressPrefixIfIndex InterfaceIndex, + ipAddressPrefixType InetAddressType, + ipAddressPrefixPrefix InetAddress, + ipAddressPrefixLength InetAddressPrefixLength, + ipAddressPrefixOrigin IpAddressPrefixOriginTC, + ipAddressPrefixOnLinkFlag TruthValue, + ipAddressPrefixAutonomousFlag TruthValue, + ipAddressPrefixAdvPreferredLifetime Unsigned32, + ipAddressPrefixAdvValidLifetime Unsigned32 + } + +ipAddressPrefixIfIndex OBJECT-TYPE + SYNTAX InterfaceIndex + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The index value that uniquely identifies the interface on + which this prefix is configured. The interface identified + by a particular value of this index is the same interface as + identified by the same value of the IF-MIB's ifIndex." + ::= { ipAddressPrefixEntry 1 } + +ipAddressPrefixType OBJECT-TYPE + SYNTAX InetAddressType + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The address type of ipAddressPrefix." + ::= { ipAddressPrefixEntry 2 } + +ipAddressPrefixPrefix OBJECT-TYPE + SYNTAX InetAddress + MAX-ACCESS not-accessible + STATUS current + + + + DESCRIPTION + "The address prefix. The address type of this object is + specified in ipAddressPrefixType. The length of this object + is the standard length for objects of that type (4 or 16 + bytes). Any bits after ipAddressPrefixLength must be zero. + + Implementors need to be aware that, if the size of + ipAddressPrefixPrefix exceeds 114 octets, then OIDS of + instances of columns in this row will have more than 128 + sub-identifiers and cannot be accessed using SNMPv1, + SNMPv2c, or SNMPv3." + ::= { ipAddressPrefixEntry 3 } + +ipAddressPrefixLength OBJECT-TYPE + SYNTAX InetAddressPrefixLength + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The prefix length associated with this prefix. + + The value 0 has no special meaning for this object. It + simply refers to address '::/0'." + ::= { ipAddressPrefixEntry 4 } + +ipAddressPrefixOrigin OBJECT-TYPE + SYNTAX IpAddressPrefixOriginTC + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The origin of this prefix." + ::= { ipAddressPrefixEntry 5 } + +ipAddressPrefixOnLinkFlag OBJECT-TYPE + SYNTAX TruthValue + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "This object has the value 'true(1)', if this prefix can be + used for on-link determination; otherwise, the value is + 'false(2)'. + + The default for IPv4 prefixes is 'true(1)'." + REFERENCE "For IPv6 RFC 2461, especially sections 2 and 4.6.2 and + RFC 2462" + ::= { ipAddressPrefixEntry 6 } + +ipAddressPrefixAutonomousFlag OBJECT-TYPE + SYNTAX TruthValue + + + + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "Autonomous address configuration flag. When true(1), + indicates that this prefix can be used for autonomous + address configuration (i.e., can be used to form a local + interface address). If false(2), it is not used to auto- + configure a local interface address. + + The default for IPv4 prefixes is 'false(2)'." + REFERENCE "For IPv6 RFC 2461, especially sections 2 and 4.6.2 and + RFC 2462" + ::= { ipAddressPrefixEntry 7 } + +ipAddressPrefixAdvPreferredLifetime OBJECT-TYPE + SYNTAX Unsigned32 + UNITS "seconds" + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The remaining length of time, in seconds, that this prefix + will continue to be preferred, i.e., time until deprecation. + + A value of 4,294,967,295 represents infinity. + + The address generated from a deprecated prefix should no + longer be used as a source address in new communications, + but packets received on such an interface are processed as + expected. + + The default for IPv4 prefixes is 4,294,967,295 (infinity)." + REFERENCE "For IPv6 RFC 2461, especially sections 2 and 4.6.2 and + RFC 2462" + ::= { ipAddressPrefixEntry 8 } + +ipAddressPrefixAdvValidLifetime OBJECT-TYPE + SYNTAX Unsigned32 + UNITS "seconds" + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The remaining length of time, in seconds, that this prefix + will continue to be valid, i.e., time until invalidation. A + value of 4,294,967,295 represents infinity. + + The address generated from an invalidated prefix should not + appear as the destination or source address of a packet. + + + + + The default for IPv4 prefixes is 4,294,967,295 (infinity)." + REFERENCE "For IPv6 RFC 2461, especially sections 2 and 4.6.2 and + RFC 2462" + ::= { ipAddressPrefixEntry 9 } + +-- +-- Internet Address Table +-- + +ipAddressSpinLock OBJECT-TYPE + SYNTAX TestAndIncr + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "An advisory lock used to allow cooperating SNMP managers to + coordinate their use of the set operation in creating or + modifying rows within this table. + + In order to use this lock to coordinate the use of set + operations, managers should first retrieve + ipAddressTableSpinLock. They should then determine the + appropriate row to create or modify. Finally, they should + issue the appropriate set command, including the retrieved + value of ipAddressSpinLock. If another manager has altered + the table in the meantime, then the value of + ipAddressSpinLock will have changed, and the creation will + fail as it will be specifying an incorrect value for + ipAddressSpinLock. It is suggested, but not required, that + the ipAddressSpinLock be the first var bind for each set of + objects representing a 'row' in a PDU." + ::= { ip 33 } + +ipAddressTable OBJECT-TYPE + SYNTAX SEQUENCE OF IpAddressEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "This table contains addressing information relevant to the + entity's interfaces. + + This table does not contain multicast address information. + Tables for such information should be contained in multicast + specific MIBs, such as RFC 3019. + + While this table is writable, the user will note that + several objects, such as ipAddressOrigin, are not. The + intention in allowing a user to write to this table is to + allow them to add or remove any entry that isn't + + + + permanent. The user should be allowed to modify objects + and entries when that would not cause inconsistencies + within the table. Allowing write access to objects, such + as ipAddressOrigin, could allow a user to insert an entry + and then label it incorrectly. + + Note well: When including IPv6 link-local addresses in this + table, the entry must use an InetAddressType of 'ipv6z' in + order to differentiate between the possible interfaces." + ::= { ip 34 } + +ipAddressEntry OBJECT-TYPE + SYNTAX IpAddressEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "An address mapping for a particular interface." + INDEX { ipAddressAddrType, ipAddressAddr } + ::= { ipAddressTable 1 } + +IpAddressEntry ::= SEQUENCE { + ipAddressAddrType InetAddressType, + ipAddressAddr InetAddress, + ipAddressIfIndex InterfaceIndex, + ipAddressType INTEGER, + ipAddressPrefix RowPointer, + ipAddressOrigin IpAddressOriginTC, + ipAddressStatus IpAddressStatusTC, + ipAddressCreated TimeStamp, + ipAddressLastChanged TimeStamp, + ipAddressRowStatus RowStatus, + ipAddressStorageType StorageType + } + +ipAddressAddrType OBJECT-TYPE + SYNTAX InetAddressType + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The address type of ipAddressAddr." + ::= { ipAddressEntry 1 } + +ipAddressAddr OBJECT-TYPE + SYNTAX InetAddress + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The IP address to which this entry's addressing information + + + + pertains. The address type of this object is specified in + ipAddressAddrType. + + Implementors need to be aware that if the size of + ipAddressAddr exceeds 116 octets, then OIDS of instances of + columns in this row will have more than 128 sub-identifiers + and cannot be accessed using SNMPv1, SNMPv2c, or SNMPv3." + ::= { ipAddressEntry 2 } + +ipAddressIfIndex OBJECT-TYPE + SYNTAX InterfaceIndex + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The index value that uniquely identifies the interface to + which this entry is applicable. The interface identified by + a particular value of this index is the same interface as + identified by the same value of the IF-MIB's ifIndex." + ::= { ipAddressEntry 3 } + +ipAddressType OBJECT-TYPE + SYNTAX INTEGER { + unicast(1), + anycast(2), + broadcast(3) + } + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The type of address. broadcast(3) is not a valid value for + IPv6 addresses (RFC 3513)." + DEFVAL { unicast } + ::= { ipAddressEntry 4 } + +ipAddressPrefix OBJECT-TYPE + SYNTAX RowPointer + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "A pointer to the row in the prefix table to which this + address belongs. May be { 0 0 } if there is no such row." + DEFVAL { zeroDotZero } + ::= { ipAddressEntry 5 } + +ipAddressOrigin OBJECT-TYPE + SYNTAX IpAddressOriginTC + MAX-ACCESS read-only + STATUS current + + + + DESCRIPTION + "The origin of the address." + ::= { ipAddressEntry 6 } + +ipAddressStatus OBJECT-TYPE + SYNTAX IpAddressStatusTC + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The status of the address, describing if the address can be + used for communication. + + In the absence of other information, an IPv4 address is + always preferred(1)." + DEFVAL { preferred } + ::= { ipAddressEntry 7 } + +ipAddressCreated OBJECT-TYPE + SYNTAX TimeStamp + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The value of sysUpTime at the time this entry was created. + If this entry was created prior to the last re- + initialization of the local network management subsystem, + then this object contains a zero value." + ::= { ipAddressEntry 8 } + +ipAddressLastChanged OBJECT-TYPE + SYNTAX TimeStamp + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The value of sysUpTime at the time this entry was last + updated. If this entry was updated prior to the last re- + initialization of the local network management subsystem, + then this object contains a zero value." + ::= { ipAddressEntry 9 } + +ipAddressRowStatus OBJECT-TYPE + SYNTAX RowStatus + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The status of this conceptual row. + + The RowStatus TC requires that this DESCRIPTION clause + states under which circumstances other objects in this row + + + + can be modified. The value of this object has no effect on + whether other objects in this conceptual row can be + modified. + + A conceptual row can not be made active until the + ipAddressIfIndex has been set to a valid index." + ::= { ipAddressEntry 10 } + +ipAddressStorageType OBJECT-TYPE + SYNTAX StorageType + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The storage type for this conceptual row. If this object + has a value of 'permanent', then no other objects are + required to be able to be modified." + DEFVAL { volatile } + ::= { ipAddressEntry 11 } + +-- +-- the Internet Address Translation table +-- + +ipNetToPhysicalTable OBJECT-TYPE + SYNTAX SEQUENCE OF IpNetToPhysicalEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The IP Address Translation table used for mapping from IP + addresses to physical addresses. + + The Address Translation tables contain the IP address to + 'physical' address equivalences. Some interfaces do not use + translation tables for determining address equivalences + (e.g., DDN-X.25 has an algorithmic method); if all + interfaces are of this type, then the Address Translation + table is empty, i.e., has zero entries. + + While many protocols may be used to populate this table, ARP + and Neighbor Discovery are the most likely + options." + REFERENCE "RFC 826 and RFC 2461" + ::= { ip 35 } + +ipNetToPhysicalEntry OBJECT-TYPE + SYNTAX IpNetToPhysicalEntry + MAX-ACCESS not-accessible + STATUS current + + + + DESCRIPTION + "Each entry contains one IP address to `physical' address + equivalence." + INDEX { ipNetToPhysicalIfIndex, + ipNetToPhysicalNetAddressType, + ipNetToPhysicalNetAddress } + ::= { ipNetToPhysicalTable 1 } + +IpNetToPhysicalEntry ::= SEQUENCE { + ipNetToPhysicalIfIndex InterfaceIndex, + ipNetToPhysicalNetAddressType InetAddressType, + ipNetToPhysicalNetAddress InetAddress, + ipNetToPhysicalPhysAddress PhysAddress, + ipNetToPhysicalLastUpdated TimeStamp, + ipNetToPhysicalType INTEGER, + ipNetToPhysicalState INTEGER, + ipNetToPhysicalRowStatus RowStatus + } + +ipNetToPhysicalIfIndex OBJECT-TYPE + SYNTAX InterfaceIndex + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The index value that uniquely identifies the interface to + which this entry is applicable. The interface identified by + a particular value of this index is the same interface as + identified by the same value of the IF-MIB's ifIndex." + ::= { ipNetToPhysicalEntry 1 } + +ipNetToPhysicalNetAddressType OBJECT-TYPE + SYNTAX InetAddressType + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The type of ipNetToPhysicalNetAddress." + ::= { ipNetToPhysicalEntry 2 } + +ipNetToPhysicalNetAddress OBJECT-TYPE + SYNTAX InetAddress + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The IP Address corresponding to the media-dependent + `physical' address. The address type of this object is + specified in ipNetToPhysicalAddressType. + + Implementors need to be aware that if the size of + + + + ipNetToPhysicalNetAddress exceeds 115 octets, then OIDS of + instances of columns in this row will have more than 128 + sub-identifiers and cannot be accessed using SNMPv1, + SNMPv2c, or SNMPv3." + ::= { ipNetToPhysicalEntry 3 } + +ipNetToPhysicalPhysAddress OBJECT-TYPE + SYNTAX PhysAddress (SIZE(0..65535)) + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The media-dependent `physical' address. + + As the entries in this table are typically not persistent + when this object is written the entity SHOULD NOT save the + change to non-volatile storage." + ::= { ipNetToPhysicalEntry 4 } + +ipNetToPhysicalLastUpdated OBJECT-TYPE + SYNTAX TimeStamp + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The value of sysUpTime at the time this entry was last + updated. If this entry was updated prior to the last re- + initialization of the local network management subsystem, + then this object contains a zero value." + ::= { ipNetToPhysicalEntry 5 } + +ipNetToPhysicalType OBJECT-TYPE + SYNTAX INTEGER { + other(1), -- none of the following + invalid(2), -- an invalidated mapping + dynamic(3), + static(4), + local(5) -- local interface + } + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The type of mapping. + + Setting this object to the value invalid(2) has the effect + of invalidating the corresponding entry in the + ipNetToPhysicalTable. That is, it effectively dis- + associates the interface identified with said entry from the + mapping identified with said entry. It is an + implementation-specific matter as to whether the agent + + + + removes an invalidated entry from the table. Accordingly, + management stations must be prepared to receive tabular + information from agents that corresponds to entries not + currently in use. Proper interpretation of such entries + requires examination of the relevant ipNetToPhysicalType + object. + + The 'dynamic(3)' type indicates that the IP address to + physical addresses mapping has been dynamically resolved + using e.g., IPv4 ARP or the IPv6 Neighbor Discovery + protocol. + + The 'static(4)' type indicates that the mapping has been + statically configured. Both of these refer to entries that + provide mappings for other entities addresses. + + The 'local(5)' type indicates that the mapping is provided + for an entity's own interface address. + + As the entries in this table are typically not persistent + when this object is written the entity SHOULD NOT save the + change to non-volatile storage." + DEFVAL { static } + ::= { ipNetToPhysicalEntry 6 } + +ipNetToPhysicalState OBJECT-TYPE + SYNTAX INTEGER { + reachable(1), -- confirmed reachability + + stale(2), -- unconfirmed reachability + + delay(3), -- waiting for reachability + -- confirmation before entering + -- the probe state + + probe(4), -- actively probing + + invalid(5), -- an invalidated mapping + + unknown(6), -- state can not be determined + -- for some reason. + + incomplete(7) -- address resolution is being + -- performed. + } + MAX-ACCESS read-only + STATUS current + DESCRIPTION + + + + "The Neighbor Unreachability Detection state for the + interface when the address mapping in this entry is used. + If Neighbor Unreachability Detection is not in use (e.g. for + IPv4), this object is always unknown(6)." + REFERENCE "RFC 2461" + ::= { ipNetToPhysicalEntry 7 } + +ipNetToPhysicalRowStatus OBJECT-TYPE + SYNTAX RowStatus + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The status of this conceptual row. + + The RowStatus TC requires that this DESCRIPTION clause + states under which circumstances other objects in this row + can be modified. The value of this object has no effect on + whether other objects in this conceptual row can be + modified. + + A conceptual row can not be made active until the + ipNetToPhysicalPhysAddress object has been set. + + Note that if the ipNetToPhysicalType is set to 'invalid', + the managed node may delete the entry independent of the + state of this object." + ::= { ipNetToPhysicalEntry 8 } + +-- +-- The IPv6 Scope Zone Index Table. +-- + +ipv6ScopeZoneIndexTable OBJECT-TYPE + SYNTAX SEQUENCE OF Ipv6ScopeZoneIndexEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The table used to describe IPv6 unicast and multicast scope + zones. + + For those objects that have names rather than numbers, the + names were chosen to coincide with the names used in the + IPv6 address architecture document. " + REFERENCE "Section 2.7 of RFC 4291" + ::= { ip 36 } + +ipv6ScopeZoneIndexEntry OBJECT-TYPE + SYNTAX Ipv6ScopeZoneIndexEntry + + + + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "Each entry contains the list of scope identifiers on a given + interface." + INDEX { ipv6ScopeZoneIndexIfIndex } + ::= { ipv6ScopeZoneIndexTable 1 } + +Ipv6ScopeZoneIndexEntry ::= SEQUENCE { + ipv6ScopeZoneIndexIfIndex InterfaceIndex, + ipv6ScopeZoneIndexLinkLocal InetZoneIndex, + ipv6ScopeZoneIndex3 InetZoneIndex, + ipv6ScopeZoneIndexAdminLocal InetZoneIndex, + ipv6ScopeZoneIndexSiteLocal InetZoneIndex, + ipv6ScopeZoneIndex6 InetZoneIndex, + ipv6ScopeZoneIndex7 InetZoneIndex, + ipv6ScopeZoneIndexOrganizationLocal InetZoneIndex, + ipv6ScopeZoneIndex9 InetZoneIndex, + ipv6ScopeZoneIndexA InetZoneIndex, + ipv6ScopeZoneIndexB InetZoneIndex, + ipv6ScopeZoneIndexC InetZoneIndex, + ipv6ScopeZoneIndexD InetZoneIndex + } + +ipv6ScopeZoneIndexIfIndex OBJECT-TYPE + SYNTAX InterfaceIndex + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The index value that uniquely identifies the interface to + which these scopes belong. The interface identified by a + particular value of this index is the same interface as + identified by the same value of the IF-MIB's ifIndex." + ::= { ipv6ScopeZoneIndexEntry 1 } + +ipv6ScopeZoneIndexLinkLocal OBJECT-TYPE + SYNTAX InetZoneIndex + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The zone index for the link-local scope on this interface." + ::= { ipv6ScopeZoneIndexEntry 2 } + +ipv6ScopeZoneIndex3 OBJECT-TYPE + SYNTAX InetZoneIndex + MAX-ACCESS read-only + STATUS current + DESCRIPTION + + + + "The zone index for scope 3 on this interface." + ::= { ipv6ScopeZoneIndexEntry 3 } + +ipv6ScopeZoneIndexAdminLocal OBJECT-TYPE + SYNTAX InetZoneIndex + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The zone index for the admin-local scope on this interface." + ::= { ipv6ScopeZoneIndexEntry 4 } + +ipv6ScopeZoneIndexSiteLocal OBJECT-TYPE + SYNTAX InetZoneIndex + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The zone index for the site-local scope on this interface." + ::= { ipv6ScopeZoneIndexEntry 5 } + +ipv6ScopeZoneIndex6 OBJECT-TYPE + SYNTAX InetZoneIndex + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The zone index for scope 6 on this interface." + ::= { ipv6ScopeZoneIndexEntry 6 } + +ipv6ScopeZoneIndex7 OBJECT-TYPE + SYNTAX InetZoneIndex + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The zone index for scope 7 on this interface." + ::= { ipv6ScopeZoneIndexEntry 7 } + +ipv6ScopeZoneIndexOrganizationLocal OBJECT-TYPE + SYNTAX InetZoneIndex + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The zone index for the organization-local scope on this + interface." + ::= { ipv6ScopeZoneIndexEntry 8 } + +ipv6ScopeZoneIndex9 OBJECT-TYPE + SYNTAX InetZoneIndex + MAX-ACCESS read-only + STATUS current + + + + DESCRIPTION + "The zone index for scope 9 on this interface." + ::= { ipv6ScopeZoneIndexEntry 9 } + +ipv6ScopeZoneIndexA OBJECT-TYPE + SYNTAX InetZoneIndex + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The zone index for scope A on this interface." + ::= { ipv6ScopeZoneIndexEntry 10 } + +ipv6ScopeZoneIndexB OBJECT-TYPE + SYNTAX InetZoneIndex + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The zone index for scope B on this interface." + ::= { ipv6ScopeZoneIndexEntry 11 } + +ipv6ScopeZoneIndexC OBJECT-TYPE + SYNTAX InetZoneIndex + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The zone index for scope C on this interface." + ::= { ipv6ScopeZoneIndexEntry 12 } + +ipv6ScopeZoneIndexD OBJECT-TYPE + SYNTAX InetZoneIndex + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The zone index for scope D on this interface." + ::= { ipv6ScopeZoneIndexEntry 13 } + +-- +-- The Default Router Table +-- This table simply lists the default routers; for more information +-- about routing tables, see the routing MIBs +-- + +ipDefaultRouterTable OBJECT-TYPE + SYNTAX SEQUENCE OF IpDefaultRouterEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The table used to describe the default routers known to this + + + + entity." + ::= { ip 37 } + +ipDefaultRouterEntry OBJECT-TYPE + SYNTAX IpDefaultRouterEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "Each entry contains information about a default router known + to this entity." + INDEX {ipDefaultRouterAddressType, ipDefaultRouterAddress, + ipDefaultRouterIfIndex} + ::= { ipDefaultRouterTable 1 } + +IpDefaultRouterEntry ::= SEQUENCE { + ipDefaultRouterAddressType InetAddressType, + ipDefaultRouterAddress InetAddress, + ipDefaultRouterIfIndex InterfaceIndex, + ipDefaultRouterLifetime Unsigned32, + ipDefaultRouterPreference INTEGER + } + +ipDefaultRouterAddressType OBJECT-TYPE + SYNTAX InetAddressType + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The address type for this row." + ::= { ipDefaultRouterEntry 1 } + +ipDefaultRouterAddress OBJECT-TYPE + SYNTAX InetAddress + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The IP address of the default router represented by this + row. The address type of this object is specified in + ipDefaultRouterAddressType. + + Implementers need to be aware that if the size of + ipDefaultRouterAddress exceeds 115 octets, then OIDS of + instances of columns in this row will have more than 128 + sub-identifiers and cannot be accessed using SNMPv1, + SNMPv2c, or SNMPv3." + ::= { ipDefaultRouterEntry 2 } + +ipDefaultRouterIfIndex OBJECT-TYPE + SYNTAX InterfaceIndex + + + + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The index value that uniquely identifies the interface by + which the router can be reached. The interface identified + by a particular value of this index is the same interface as + identified by the same value of the IF-MIB's ifIndex." + ::= { ipDefaultRouterEntry 3 } + +ipDefaultRouterLifetime OBJECT-TYPE + SYNTAX Unsigned32 (0..65535) + UNITS "seconds" + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The remaining length of time, in seconds, that this router + will continue to be useful as a default router. A value of + zero indicates that it is no longer useful as a default + router. It is left to the implementer of the MIB as to + whether a router with a lifetime of zero is removed from the + list. + + For IPv6, this value should be extracted from the router + advertisement messages." + REFERENCE "For IPv6 RFC 2462 sections 4.2 and 6.3.4" + ::= { ipDefaultRouterEntry 4 } + +ipDefaultRouterPreference OBJECT-TYPE + SYNTAX INTEGER { + reserved (-2), + low (-1), + medium (0), + high (1) + } + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "An indication of preference given to this router as a + default router as described in he Default Router + Preferences document. Treating the value as a + 2 bit signed integer allows for simple arithmetic + comparisons. + + For IPv4 routers or IPv6 routers that are not using the + updated router advertisement format, this object is set to + medium (0)." + REFERENCE "RFC 4291, section 2.1" + ::= { ipDefaultRouterEntry 5 } + + + +-- +-- Configuration information for constructing router advertisements +-- + +ipv6RouterAdvertSpinLock OBJECT-TYPE + SYNTAX TestAndIncr + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "An advisory lock used to allow cooperating SNMP managers to + coordinate their use of the set operation in creating or + modifying rows within this table. + + In order to use this lock to coordinate the use of set + operations, managers should first retrieve + ipv6RouterAdvertSpinLock. They should then determine the + appropriate row to create or modify. Finally, they should + issue the appropriate set command including the retrieved + value of ipv6RouterAdvertSpinLock. If another manager has + altered the table in the meantime, then the value of + ipv6RouterAdvertSpinLock will have changed and the creation + will fail as it will be specifying an incorrect value for + ipv6RouterAdvertSpinLock. It is suggested, but not + required, that the ipv6RouterAdvertSpinLock be the first var + bind for each set of objects representing a 'row' in a PDU." + ::= { ip 38 } + +ipv6RouterAdvertTable OBJECT-TYPE + SYNTAX SEQUENCE OF Ipv6RouterAdvertEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The table containing information used to construct router + advertisements." + ::= { ip 39 } + +ipv6RouterAdvertEntry OBJECT-TYPE + SYNTAX Ipv6RouterAdvertEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "An entry containing information used to construct router + advertisements. + + Information in this table is persistent, and when this + object is written, the entity SHOULD save the change to + non-volatile storage." + INDEX { ipv6RouterAdvertIfIndex } + + + + ::= { ipv6RouterAdvertTable 1 } + +Ipv6RouterAdvertEntry ::= SEQUENCE { + ipv6RouterAdvertIfIndex InterfaceIndex, + ipv6RouterAdvertSendAdverts TruthValue, + ipv6RouterAdvertMaxInterval Unsigned32, + ipv6RouterAdvertMinInterval Unsigned32, + ipv6RouterAdvertManagedFlag TruthValue, + ipv6RouterAdvertOtherConfigFlag TruthValue, + ipv6RouterAdvertLinkMTU Unsigned32, + ipv6RouterAdvertReachableTime Unsigned32, + ipv6RouterAdvertRetransmitTime Unsigned32, + ipv6RouterAdvertCurHopLimit Unsigned32, + ipv6RouterAdvertDefaultLifetime Unsigned32, + ipv6RouterAdvertRowStatus RowStatus + } + +ipv6RouterAdvertIfIndex OBJECT-TYPE + SYNTAX InterfaceIndex + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The index value that uniquely identifies the interface on + which router advertisements constructed with this + information will be transmitted. The interface identified + by a particular value of this index is the same interface as + identified by the same value of the IF-MIB's ifIndex." + ::= { ipv6RouterAdvertEntry 1 } + +ipv6RouterAdvertSendAdverts OBJECT-TYPE + SYNTAX TruthValue + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "A flag indicating whether the router sends periodic + router advertisements and responds to router solicitations + on this interface." + REFERENCE "RFC 2461 Section 6.2.1" + DEFVAL { false } + ::= { ipv6RouterAdvertEntry 2 } + +ipv6RouterAdvertMaxInterval OBJECT-TYPE + SYNTAX Unsigned32 (4..1800) + UNITS "seconds" + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The maximum time allowed between sending unsolicited router + + + + advertisements from this interface." + REFERENCE "RFC 2461 Section 6.2.1" + DEFVAL { 600 } + ::= { ipv6RouterAdvertEntry 3 } + +ipv6RouterAdvertMinInterval OBJECT-TYPE + SYNTAX Unsigned32 (3..1350) + UNITS "seconds" + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The minimum time allowed between sending unsolicited router + advertisements from this interface. + + The default is 0.33 * ipv6RouterAdvertMaxInterval, however, + in the case of a low value for ipv6RouterAdvertMaxInterval, + the minimum value for this object is restricted to 3." + REFERENCE "RFC 2461 Section 6.2.1" + ::= { ipv6RouterAdvertEntry 4 } + +ipv6RouterAdvertManagedFlag OBJECT-TYPE + SYNTAX TruthValue + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The true/false value to be placed into the 'managed address + configuration' flag field in router advertisements sent from + this interface." + REFERENCE "RFC 2461 Section 6.2.1" + DEFVAL { false } + ::= { ipv6RouterAdvertEntry 5 } + +ipv6RouterAdvertOtherConfigFlag OBJECT-TYPE + SYNTAX TruthValue + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The true/false value to be placed into the 'other stateful + configuration' flag field in router advertisements sent from + this interface." + REFERENCE "RFC 2461 Section 6.2.1" + DEFVAL { false } + ::= { ipv6RouterAdvertEntry 6 } + +ipv6RouterAdvertLinkMTU OBJECT-TYPE + SYNTAX Unsigned32 + MAX-ACCESS read-create + STATUS current + + + + DESCRIPTION + "The value to be placed in MTU options sent by the router on + this interface. + + A value of zero indicates that no MTU options are sent." + REFERENCE "RFC 2461 Section 6.2.1" + DEFVAL { 0 } + ::= { ipv6RouterAdvertEntry 7 } + +ipv6RouterAdvertReachableTime OBJECT-TYPE + SYNTAX Unsigned32 (0..3600000) + UNITS "milliseconds" + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The value to be placed in the reachable time field in router + advertisement messages sent from this interface. + + A value of zero in the router advertisement indicates that + the advertisement isn't specifying a value for reachable + time." + REFERENCE "RFC 2461 Section 6.2.1" + DEFVAL { 0 } + ::= { ipv6RouterAdvertEntry 8 } + +ipv6RouterAdvertRetransmitTime OBJECT-TYPE + SYNTAX Unsigned32 + UNITS "milliseconds" + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The value to be placed in the retransmit timer field in + router advertisements sent from this interface. + + A value of zero in the router advertisement indicates that + the advertisement isn't specifying a value for retrans + time." + REFERENCE "RFC 2461 Section 6.2.1" + DEFVAL { 0 } + ::= { ipv6RouterAdvertEntry 9 } + +ipv6RouterAdvertCurHopLimit OBJECT-TYPE + SYNTAX Unsigned32 (0..255) + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The default value to be placed in the current hop limit + field in router advertisements sent from this interface. + + + + The value should be set to the current diameter of the + Internet. + + A value of zero in the router advertisement indicates that + the advertisement isn't specifying a value for curHopLimit. + + The default should be set to the value specified in the IANA + web pages (www.iana.org) at the time of implementation." + REFERENCE "RFC 2461 Section 6.2.1" + ::= { ipv6RouterAdvertEntry 10 } + +ipv6RouterAdvertDefaultLifetime OBJECT-TYPE + SYNTAX Unsigned32 (0|4..9000) + UNITS "seconds" + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The value to be placed in the router lifetime field of + router advertisements sent from this interface. This value + MUST be either 0 or between ipv6RouterAdvertMaxInterval and + 9000 seconds. + + A value of zero indicates that the router is not to be used + as a default router. + + The default is 3 * ipv6RouterAdvertMaxInterval." + REFERENCE "RFC 2461 Section 6.2.1" + ::= { ipv6RouterAdvertEntry 11 } + +ipv6RouterAdvertRowStatus OBJECT-TYPE + SYNTAX RowStatus + MAX-ACCESS read-create + STATUS current + DESCRIPTION + "The status of this conceptual row. + + As all objects in this conceptual row have default values, a + row can be created and made active by setting this object + appropriately. + + The RowStatus TC requires that this DESCRIPTION clause + states under which circumstances other objects in this row + can be modified. The value of this object has no effect on + whether other objects in this conceptual row can be + modified." + ::= { ipv6RouterAdvertEntry 12 } + +-- + + + +-- ICMP section +-- + +icmp OBJECT IDENTIFIER ::= { mib-2 5 } + +-- +-- ICMP non-message-specific counters +-- + +-- These object IDs are reserved, as they were used in earlier +-- versions of the MIB module. In theory, OIDs are not assigned +-- until the specification is released as an RFC; however, as some +-- companies may have shipped code based on earlier versions of +-- the MIB, it seems best to reserve these OIDs. +-- ::= { icmp 27 } +-- ::= { icmp 28 } + +icmpStatsTable OBJECT-TYPE + SYNTAX SEQUENCE OF IcmpStatsEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The table of generic system-wide ICMP counters." + ::= { icmp 29 } + +icmpStatsEntry OBJECT-TYPE + SYNTAX IcmpStatsEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "A conceptual row in the icmpStatsTable." + INDEX { icmpStatsIPVersion } + ::= { icmpStatsTable 1 } + +IcmpStatsEntry ::= SEQUENCE { + icmpStatsIPVersion InetVersion, + icmpStatsInMsgs Counter32, + icmpStatsInErrors Counter32, + icmpStatsOutMsgs Counter32, + icmpStatsOutErrors Counter32 + } + +icmpStatsIPVersion OBJECT-TYPE + SYNTAX InetVersion + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The IP version of the statistics." + + + + ::= { icmpStatsEntry 1 } + +icmpStatsInMsgs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of ICMP messages that the entity received. + Note that this counter includes all those counted by + icmpStatsInErrors." + ::= { icmpStatsEntry 2 } + +icmpStatsInErrors OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of ICMP messages that the entity received but + determined as having ICMP-specific errors (bad ICMP + checksums, bad length, etc.)." + ::= { icmpStatsEntry 3 } + +icmpStatsOutMsgs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of ICMP messages that the entity attempted + to send. Note that this counter includes all those counted + by icmpStatsOutErrors." + ::= { icmpStatsEntry 4 } + +icmpStatsOutErrors OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of ICMP messages that this entity did not send + due to problems discovered within ICMP, such as a lack of + buffers. This value should not include errors discovered + outside the ICMP layer, such as the inability of IP to route + the resultant datagram. In some implementations, there may + be no types of error that contribute to this counter's + value." + ::= { icmpStatsEntry 5 } + +-- +-- per-version, per-message type ICMP counters + + + +-- + +icmpMsgStatsTable OBJECT-TYPE + SYNTAX SEQUENCE OF IcmpMsgStatsEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The table of system-wide per-version, per-message type ICMP + counters." + ::= { icmp 30 } + +icmpMsgStatsEntry OBJECT-TYPE + SYNTAX IcmpMsgStatsEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "A conceptual row in the icmpMsgStatsTable. + + The system should track each ICMP type value, even if that + ICMP type is not supported by the system. However, a + given row need not be instantiated unless a message of that + type has been processed, i.e., the row for + icmpMsgStatsType=X MAY be instantiated before but MUST be + instantiated after the first message with Type=X is + received or transmitted. After receiving or transmitting + any succeeding messages with Type=X, the relevant counter + must be incremented." + INDEX { icmpMsgStatsIPVersion, icmpMsgStatsType } + ::= { icmpMsgStatsTable 1 } + +IcmpMsgStatsEntry ::= SEQUENCE { + icmpMsgStatsIPVersion InetVersion, + icmpMsgStatsType Integer32, + icmpMsgStatsInPkts Counter32, + icmpMsgStatsOutPkts Counter32 + } + +icmpMsgStatsIPVersion OBJECT-TYPE + SYNTAX InetVersion + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The IP version of the statistics." + ::= { icmpMsgStatsEntry 1 } + +icmpMsgStatsType OBJECT-TYPE + SYNTAX Integer32 (0..255) + MAX-ACCESS not-accessible + + + + STATUS current + DESCRIPTION + "The ICMP type field of the message type being counted by + this row. + + Note that ICMP message types are scoped by the address type + in use." + REFERENCE "http://www.iana.org/assignments/icmp-parameters and + http://www.iana.org/assignments/icmpv6-parameters" + ::= { icmpMsgStatsEntry 2 } + +icmpMsgStatsInPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of input packets for this AF and type." + ::= { icmpMsgStatsEntry 3 } + +icmpMsgStatsOutPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of output packets for this AF and type." + ::= { icmpMsgStatsEntry 4 } +-- +-- conformance information +-- + +ipMIBConformance OBJECT IDENTIFIER ::= { ipMIB 2 } + +ipMIBCompliances OBJECT IDENTIFIER ::= { ipMIBConformance 1 } +ipMIBGroups OBJECT IDENTIFIER ::= { ipMIBConformance 2 } + +-- compliance statements +ipMIBCompliance2 MODULE-COMPLIANCE + STATUS current + DESCRIPTION + "The compliance statement for systems that implement IP - + either IPv4 or IPv6. + + There are a number of INDEX objects that cannot be + represented in the form of OBJECT clauses in SMIv2, but + for which we have the following compliance requirements, + expressed in OBJECT clause form in this description + clause: + + + + + -- OBJECT ipSystemStatsIPVersion + -- SYNTAX InetVersion {ipv4(1), ipv6(2)} + -- DESCRIPTION + -- This MIB requires support for only IPv4 and IPv6 + -- versions. + -- + -- OBJECT ipIfStatsIPVersion + -- SYNTAX InetVersion {ipv4(1), ipv6(2)} + -- DESCRIPTION + -- This MIB requires support for only IPv4 and IPv6 + -- versions. + -- + -- OBJECT icmpStatsIPVersion + -- SYNTAX InetVersion {ipv4(1), ipv6(2)} + -- DESCRIPTION + -- This MIB requires support for only IPv4 and IPv6 + -- versions. + -- + -- OBJECT icmpMsgStatsIPVersion + -- SYNTAX InetVersion {ipv4(1), ipv6(2)} + -- DESCRIPTION + -- This MIB requires support for only IPv4 and IPv6 + -- versions. + -- + -- OBJECT ipAddressPrefixType + -- SYNTAX InetAddressType {ipv4(1), ipv6(2)} + -- DESCRIPTION + -- This MIB requires support for only global IPv4 and + -- IPv6 address types. + -- + -- OBJECT ipAddressPrefixPrefix + -- SYNTAX InetAddress (Size(4 | 16)) + -- DESCRIPTION + -- This MIB requires support for only global IPv4 and + -- IPv6 addresses and so the size can be either 4 or + -- 16 bytes. + -- + -- OBJECT ipAddressAddrType + -- SYNTAX InetAddressType {ipv4(1), ipv6(2), + -- ipv4z(3), ipv6z(4)} + -- DESCRIPTION + -- This MIB requires support for only global and + -- non-global IPv4 and IPv6 address types. + -- + -- OBJECT ipAddressAddr + -- SYNTAX InetAddress (Size(4 | 8 | 16 | 20)) + -- DESCRIPTION + -- This MIB requires support for only global and + + + + -- non-global IPv4 and IPv6 addresses and so the size + -- can be 4, 8, 16, or 20 bytes. + -- + -- OBJECT ipNetToPhysicalNetAddressType + -- SYNTAX InetAddressType {ipv4(1), ipv6(2), + -- ipv4z(3), ipv6z(4)} + -- DESCRIPTION + -- This MIB requires support for only global and + -- non-global IPv4 and IPv6 address types. + -- + -- OBJECT ipNetToPhysicalNetAddress + -- SYNTAX InetAddress (Size(4 | 8 | 16 | 20)) + -- DESCRIPTION + -- This MIB requires support for only global and + -- non-global IPv4 and IPv6 addresses and so the size + -- can be 4, 8, 16, or 20 bytes. + -- + -- OBJECT ipDefaultRouterAddressType + -- SYNTAX InetAddressType {ipv4(1), ipv6(2), + -- ipv4z(3), ipv6z(4)} + -- DESCRIPTION + -- This MIB requires support for only global and + -- non-global IPv4 and IPv6 address types. + -- + -- OBJECT ipDefaultRouterAddress + -- SYNTAX InetAddress (Size(4 | 8 | 16 | 20)) + -- DESCRIPTION + -- This MIB requires support for only global and + -- non-global IPv4 and IPv6 addresses and so the size + -- can be 4, 8, 16, or 20 bytes." + + MODULE -- this module + + MANDATORY-GROUPS { ipSystemStatsGroup, ipAddressGroup, + ipNetToPhysicalGroup, ipDefaultRouterGroup, + icmpStatsGroup } + + GROUP ipSystemStatsHCOctetGroup + DESCRIPTION + "This group is mandatory for systems that have an aggregate + bandwidth of greater than 20MB. Including this group does + not allow an entity to neglect the 32 bit versions of these + objects." + + GROUP ipSystemStatsHCPacketGroup + DESCRIPTION + "This group is mandatory for systems that have an aggregate + bandwidth of greater than 650MB. Including this group + + + + does not allow an entity to neglect the 32 bit versions of + these objects." + + GROUP ipIfStatsGroup + DESCRIPTION + "This group is optional for all systems." + + GROUP ipIfStatsHCOctetGroup + DESCRIPTION + "This group is mandatory for systems that include the + ipIfStatsGroup and include links with bandwidths of greater + than 20MB. Including this group does not allow an entity to + neglect the 32 bit versions of these objects." + + GROUP ipIfStatsHCPacketGroup + DESCRIPTION + "This group is mandatory for systems that include the + ipIfStatsGroup and include links with bandwidths of greater + than 650MB. Including this group does not allow an entity + to neglect the 32 bit versions of these objects." + + GROUP ipv4GeneralGroup + DESCRIPTION + "This group is mandatory for all systems supporting IPv4." + + GROUP ipv4IfGroup + DESCRIPTION + "This group is mandatory for all systems supporting IPv4." + + GROUP ipv4SystemStatsGroup + DESCRIPTION + "This group is mandatory for all systems supporting IPv4." + + GROUP ipv4SystemStatsHCPacketGroup + DESCRIPTION + "This group is mandatory for all systems supporting IPv4 and + that have an aggregate bandwidth of greater than 650MB. + Including this group does not allow an entity to neglect the + 32 bit versions of these objects." + + GROUP ipv4IfStatsGroup + DESCRIPTION + "This group is mandatory for all systems supporting IPv4 and + including the ipIfStatsGroup." + + GROUP ipv4IfStatsHCPacketGroup + DESCRIPTION + "This group is mandatory for all systems supporting IPv4 and + + + + including the ipIfStatsHCPacketGroup. Including this group + does not allow an entity to neglect the 32 bit versions of + these objects." + + GROUP ipv6GeneralGroup2 + DESCRIPTION + "This group is mandatory for all systems supporting IPv6." + + GROUP ipv6IfGroup + DESCRIPTION + "This group is mandatory for all systems supporting IPv6." + + GROUP ipAddressPrefixGroup + DESCRIPTION + "This group is mandatory for all systems supporting IPv6." + + GROUP ipv6ScopeGroup + DESCRIPTION + "This group is mandatory for all systems supporting IPv6." + + GROUP ipv6RouterAdvertGroup + DESCRIPTION + "This group is mandatory for all IPv6 routers." + + GROUP ipLastChangeGroup + DESCRIPTION + "This group is optional for all agents." + + OBJECT ipv6IpForwarding + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write access to this + object." + + OBJECT ipv6IpDefaultHopLimit + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write access to this + object." + + OBJECT ipv4InterfaceEnableStatus + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write access to this + object." + + OBJECT ipv6InterfaceEnableStatus + MIN-ACCESS read-only + + + + DESCRIPTION + "An agent is not required to provide write access to this + object." + + OBJECT ipv6InterfaceForwarding + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write access to this + object." + + OBJECT ipAddressSpinLock + MIN-ACCESS not-accessible + DESCRIPTION + "An agent is not required to provide write access to this + object. However, if an agent provides write access to any + of the other objects in the ipAddressGroup, it SHOULD + provide write access to this object as well." + + OBJECT ipAddressIfIndex + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write or create access + to this object." + + OBJECT ipAddressType + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write or create access + to this object." + + OBJECT ipAddressStatus + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write or create access + to this object." + + OBJECT ipAddressRowStatus + SYNTAX RowStatus { active(1) } + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write or create access + to this object." + + OBJECT ipAddressStorageType + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write or create access + to this object. + + + + If an agent allows this object to be written or created, it + is not required to allow this object to be set to readOnly, + permanent, or nonVolatile." + + OBJECT ipNetToPhysicalPhysAddress + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write or create access + to this object." + + OBJECT ipNetToPhysicalType + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write or create access + to this object." + + OBJECT ipv6RouterAdvertSpinLock + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write access to this + object. However, if an agent provides write access to + any of the other objects in the ipv6RouterAdvertGroup, it + SHOULD provide write access to this object as well." + + OBJECT ipv6RouterAdvertSendAdverts + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write access to this + object." + + OBJECT ipv6RouterAdvertMaxInterval + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write access to this + object." + + OBJECT ipv6RouterAdvertMinInterval + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write access to this + object." + + OBJECT ipv6RouterAdvertManagedFlag + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write access to this + object." + + + + + OBJECT ipv6RouterAdvertOtherConfigFlag + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write access to this + object." + + OBJECT ipv6RouterAdvertLinkMTU + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write access to this + object." + + OBJECT ipv6RouterAdvertReachableTime + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write access to this + object." + + OBJECT ipv6RouterAdvertRetransmitTime + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write access to this + object." + + OBJECT ipv6RouterAdvertCurHopLimit + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write access to this + object." + + OBJECT ipv6RouterAdvertDefaultLifetime + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write access to this + object." + + OBJECT ipv6RouterAdvertRowStatus + MIN-ACCESS read-only + DESCRIPTION + "An agent is not required to provide write or create access + to this object." + + ::= { ipMIBCompliances 2 } + +-- units of conformance + +ipv4GeneralGroup OBJECT-GROUP + OBJECTS { ipForwarding, ipDefaultTTL, ipReasmTimeout } + + + + STATUS current + DESCRIPTION + "The group of IPv4-specific objects for basic management of + IPv4 entities." + ::= { ipMIBGroups 3 } + +ipv4IfGroup OBJECT-GROUP + OBJECTS { ipv4InterfaceReasmMaxSize, ipv4InterfaceEnableStatus, + ipv4InterfaceRetransmitTime } + STATUS current + DESCRIPTION + "The group of IPv4-specific objects for basic management of + IPv4 interfaces." + ::= { ipMIBGroups 4 } + +ipv6GeneralGroup2 OBJECT-GROUP + OBJECTS { ipv6IpForwarding, ipv6IpDefaultHopLimit } + STATUS current + DESCRIPTION + "The IPv6 group of objects providing for basic management of + IPv6 entities." + ::= { ipMIBGroups 5 } + +ipv6IfGroup OBJECT-GROUP + OBJECTS { ipv6InterfaceReasmMaxSize, ipv6InterfaceIdentifier, + ipv6InterfaceEnableStatus, ipv6InterfaceReachableTime, + ipv6InterfaceRetransmitTime, ipv6InterfaceForwarding } + STATUS current + DESCRIPTION + "The group of IPv6-specific objects for basic management of + IPv6 interfaces." + ::= { ipMIBGroups 6 } + +ipLastChangeGroup OBJECT-GROUP + OBJECTS { ipv4InterfaceTableLastChange, + ipv6InterfaceTableLastChange, + ipIfStatsTableLastChange } + STATUS current + DESCRIPTION + "The last change objects associated with this MIB. These + objects are optional for all agents. They SHOULD be + implemented on agents where it is possible to determine the + proper values. Where it is not possible to determine the + proper values, for example when the tables are split amongst + several sub-agents using AgentX, the agent MUST NOT + implement these objects to return an incorrect or static + value." + ::= { ipMIBGroups 7 } + + + +ipSystemStatsGroup OBJECT-GROUP + OBJECTS { ipSystemStatsInReceives, + ipSystemStatsInOctets, + ipSystemStatsInHdrErrors, + ipSystemStatsInNoRoutes, + ipSystemStatsInAddrErrors, + ipSystemStatsInUnknownProtos, + ipSystemStatsInTruncatedPkts, + ipSystemStatsInForwDatagrams, + ipSystemStatsReasmReqds, + ipSystemStatsReasmOKs, + ipSystemStatsReasmFails, + ipSystemStatsInDiscards, + ipSystemStatsInDelivers, + ipSystemStatsOutRequests, + ipSystemStatsOutNoRoutes, + ipSystemStatsOutForwDatagrams, + ipSystemStatsOutDiscards, + ipSystemStatsOutFragReqds, + ipSystemStatsOutFragOKs, + ipSystemStatsOutFragFails, + ipSystemStatsOutFragCreates, + ipSystemStatsOutTransmits, + ipSystemStatsOutOctets, + ipSystemStatsInMcastPkts, + ipSystemStatsInMcastOctets, + ipSystemStatsOutMcastPkts, + ipSystemStatsOutMcastOctets, + ipSystemStatsDiscontinuityTime, + ipSystemStatsRefreshRate } + STATUS current + DESCRIPTION + "IP system wide statistics." + ::= { ipMIBGroups 8 } + +ipv4SystemStatsGroup OBJECT-GROUP + OBJECTS { ipSystemStatsInBcastPkts, ipSystemStatsOutBcastPkts } + STATUS current + DESCRIPTION + "IPv4 only system wide statistics." + ::= { ipMIBGroups 9 } + +ipSystemStatsHCOctetGroup OBJECT-GROUP + OBJECTS { ipSystemStatsHCInOctets, + ipSystemStatsHCOutOctets, + ipSystemStatsHCInMcastOctets, + ipSystemStatsHCOutMcastOctets +} + + + + STATUS current + DESCRIPTION + "IP system wide statistics for systems that may overflow the + standard octet counters within 1 hour." + ::= { ipMIBGroups 10 } + +ipSystemStatsHCPacketGroup OBJECT-GROUP + OBJECTS { ipSystemStatsHCInReceives, + ipSystemStatsHCInForwDatagrams, + ipSystemStatsHCInDelivers, + ipSystemStatsHCOutRequests, + ipSystemStatsHCOutForwDatagrams, + ipSystemStatsHCOutTransmits, + ipSystemStatsHCInMcastPkts, + ipSystemStatsHCOutMcastPkts +} + STATUS current + DESCRIPTION + "IP system wide statistics for systems that may overflow the + standard packet counters within 1 hour." + ::= { ipMIBGroups 11 } + +ipv4SystemStatsHCPacketGroup OBJECT-GROUP + OBJECTS { ipSystemStatsHCInBcastPkts, + ipSystemStatsHCOutBcastPkts } + STATUS current + DESCRIPTION + "IPv4 only system wide statistics for systems that may + overflow the standard packet counters within 1 hour." + ::= { ipMIBGroups 12 } + +ipIfStatsGroup OBJECT-GROUP + OBJECTS { ipIfStatsInReceives, ipIfStatsInOctets, + ipIfStatsInHdrErrors, ipIfStatsInNoRoutes, + ipIfStatsInAddrErrors, ipIfStatsInUnknownProtos, + ipIfStatsInTruncatedPkts, ipIfStatsInForwDatagrams, + ipIfStatsReasmReqds, ipIfStatsReasmOKs, + ipIfStatsReasmFails, ipIfStatsInDiscards, + ipIfStatsInDelivers, ipIfStatsOutRequests, + ipIfStatsOutForwDatagrams, ipIfStatsOutDiscards, + ipIfStatsOutFragReqds, ipIfStatsOutFragOKs, + ipIfStatsOutFragFails, ipIfStatsOutFragCreates, + ipIfStatsOutTransmits, ipIfStatsOutOctets, + ipIfStatsInMcastPkts, ipIfStatsInMcastOctets, + ipIfStatsOutMcastPkts, ipIfStatsOutMcastOctets, + ipIfStatsDiscontinuityTime, ipIfStatsRefreshRate } + STATUS current + DESCRIPTION + + + + "IP per-interface statistics." + ::= { ipMIBGroups 13 } + +ipv4IfStatsGroup OBJECT-GROUP + OBJECTS { ipIfStatsInBcastPkts, ipIfStatsOutBcastPkts } + STATUS current + DESCRIPTION + "IPv4 only per-interface statistics." + ::= { ipMIBGroups 14 } + +ipIfStatsHCOctetGroup OBJECT-GROUP + OBJECTS { ipIfStatsHCInOctets, ipIfStatsHCOutOctets, + ipIfStatsHCInMcastOctets, ipIfStatsHCOutMcastOctets } + STATUS current + DESCRIPTION + "IP per-interfaces statistics for systems that include + interfaces that may overflow the standard octet + counters within 1 hour." + ::= { ipMIBGroups 15 } + +ipIfStatsHCPacketGroup OBJECT-GROUP + OBJECTS { ipIfStatsHCInReceives, ipIfStatsHCInForwDatagrams, + ipIfStatsHCInDelivers, ipIfStatsHCOutRequests, + ipIfStatsHCOutForwDatagrams, ipIfStatsHCOutTransmits, + ipIfStatsHCInMcastPkts, ipIfStatsHCOutMcastPkts } + STATUS current + DESCRIPTION + "IP per-interfaces statistics for systems that include + interfaces that may overflow the standard packet counters + within 1 hour." + ::= { ipMIBGroups 16 } + +ipv4IfStatsHCPacketGroup OBJECT-GROUP + OBJECTS { ipIfStatsHCInBcastPkts, ipIfStatsHCOutBcastPkts } + STATUS current + DESCRIPTION + "IPv4 only per-interface statistics for systems that include + interfaces that may overflow the standard packet counters + within 1 hour." + ::= { ipMIBGroups 17 } + +ipAddressPrefixGroup OBJECT-GROUP + OBJECTS { ipAddressPrefixOrigin, + ipAddressPrefixOnLinkFlag, + ipAddressPrefixAutonomousFlag, + ipAddressPrefixAdvPreferredLifetime, + ipAddressPrefixAdvValidLifetime } + STATUS current + + + + DESCRIPTION + "The group of objects for providing information about address + prefixes used by this node." + ::= { ipMIBGroups 18 } + +ipAddressGroup OBJECT-GROUP + OBJECTS { ipAddressSpinLock, ipAddressIfIndex, + ipAddressType, ipAddressPrefix, + ipAddressOrigin, ipAddressStatus, + ipAddressCreated, ipAddressLastChanged, + ipAddressRowStatus, ipAddressStorageType } + STATUS current + DESCRIPTION + "The group of objects for providing information about the + addresses relevant to this entity's interfaces." + ::= { ipMIBGroups 19 } + +ipNetToPhysicalGroup OBJECT-GROUP + OBJECTS { ipNetToPhysicalPhysAddress, ipNetToPhysicalLastUpdated, + ipNetToPhysicalType, ipNetToPhysicalState, + ipNetToPhysicalRowStatus } + STATUS current + DESCRIPTION + "The group of objects for providing information about the + mappings of network address to physical address known to + this node." + ::= { ipMIBGroups 20 } + +ipv6ScopeGroup OBJECT-GROUP + OBJECTS { ipv6ScopeZoneIndexLinkLocal, + ipv6ScopeZoneIndex3, + ipv6ScopeZoneIndexAdminLocal, + ipv6ScopeZoneIndexSiteLocal, + ipv6ScopeZoneIndex6, + ipv6ScopeZoneIndex7, + ipv6ScopeZoneIndexOrganizationLocal, + ipv6ScopeZoneIndex9, + ipv6ScopeZoneIndexA, + ipv6ScopeZoneIndexB, + ipv6ScopeZoneIndexC, + ipv6ScopeZoneIndexD } + STATUS current + DESCRIPTION + "The group of objects for managing IPv6 scope zones." + ::= { ipMIBGroups 21 } + +ipDefaultRouterGroup OBJECT-GROUP + OBJECTS { ipDefaultRouterLifetime, ipDefaultRouterPreference } + + + + STATUS current + DESCRIPTION + "The group of objects for providing information about default + routers known to this node." + ::= { ipMIBGroups 22 } + +ipv6RouterAdvertGroup OBJECT-GROUP + OBJECTS { ipv6RouterAdvertSpinLock, + ipv6RouterAdvertSendAdverts, + ipv6RouterAdvertMaxInterval, + ipv6RouterAdvertMinInterval, + ipv6RouterAdvertManagedFlag, + ipv6RouterAdvertOtherConfigFlag, + ipv6RouterAdvertLinkMTU, + ipv6RouterAdvertReachableTime, + ipv6RouterAdvertRetransmitTime, + ipv6RouterAdvertCurHopLimit, + ipv6RouterAdvertDefaultLifetime, + ipv6RouterAdvertRowStatus +} + STATUS current + DESCRIPTION + "The group of objects for controlling information advertised + by IPv6 routers." + ::= { ipMIBGroups 23 } + +icmpStatsGroup OBJECT-GROUP + OBJECTS {icmpStatsInMsgs, icmpStatsInErrors, + icmpStatsOutMsgs, icmpStatsOutErrors, + icmpMsgStatsInPkts, icmpMsgStatsOutPkts } + STATUS current + DESCRIPTION + "The group of objects providing ICMP statistics." + ::= { ipMIBGroups 24 } + +-- +-- Deprecated objects +-- + +ipInReceives OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The total number of input datagrams received from + interfaces, including those received in error. + + This object has been deprecated, as a new IP version-neutral + + + + table has been added. It is loosely replaced by + ipSystemStatsInRecieves." + ::= { ip 3 } + +ipInHdrErrors OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of input datagrams discarded due to errors in + their IPv4 headers, including bad checksums, version number + mismatch, other format errors, time-to-live exceeded, errors + discovered in processing their IPv4 options, etc. + + This object has been deprecated as a new IP version-neutral + table has been added. It is loosely replaced by + ipSystemStatsInHdrErrors." + ::= { ip 4 } + +ipInAddrErrors OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of input datagrams discarded because the IPv4 + address in their IPv4 header's destination field was not a + valid address to be received at this entity. This count + includes invalid addresses (e.g., 0.0.0.0) and addresses of + unsupported Classes (e.g., Class E). For entities which are + not IPv4 routers, and therefore do not forward datagrams, + this counter includes datagrams discarded because the + destination address was not a local address. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by + ipSystemStatsInAddrErrors." + ::= { ip 5 } + +ipForwDatagrams OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of input datagrams for which this entity was not + their final IPv4 destination, as a result of which an + attempt was made to find a route to forward them to that + final destination. In entities which do not act as IPv4 + routers, this counter will include only those packets which + + + + were Source-Routed via this entity, and the Source-Route + option processing was successful. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by + ipSystemStatsInForwDatagrams." + ::= { ip 6 } + +ipInUnknownProtos OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of locally-addressed datagrams received + successfully but discarded because of an unknown or + unsupported protocol. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by + ipSystemStatsInUnknownProtos." + ::= { ip 7 } + +ipInDiscards OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of input IPv4 datagrams for which no problems + were encountered to prevent their continued processing, but + which were discarded (e.g., for lack of buffer space). Note + that this counter does not include any datagrams discarded + while awaiting re-assembly. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by + ipSystemStatsInDiscards." + ::= { ip 8 } + +ipInDelivers OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The total number of input datagrams successfully delivered + to IPv4 user-protocols (including ICMP). + + This object has been deprecated as a new IP version neutral + table has been added. It is loosely replaced by + + + + ipSystemStatsIndelivers." + ::= { ip 9 } + +ipOutRequests OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The total number of IPv4 datagrams which local IPv4 user + protocols (including ICMP) supplied to IPv4 in requests for + transmission. Note that this counter does not include any + datagrams counted in ipForwDatagrams. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by + ipSystemStatsOutRequests." + ::= { ip 10 } + +ipOutDiscards OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of output IPv4 datagrams for which no problem was + encountered to prevent their transmission to their + destination, but which were discarded (e.g., for lack of + buffer space). Note that this counter would include + datagrams counted in ipForwDatagrams if any such packets met + this (discretionary) discard criterion. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by + ipSystemStatsOutDiscards." + ::= { ip 11 } + +ipOutNoRoutes OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of IPv4 datagrams discarded because no route + could be found to transmit them to their destination. Note + that this counter includes any packets counted in + ipForwDatagrams which meet this `no-route' criterion. Note + that this includes any datagrams which a host cannot route + because all of its default routers are down. + + This object has been deprecated, as a new IP version-neutral + + + + table has been added. It is loosely replaced by + ipSystemStatsOutNoRoutes." + ::= { ip 12 } + +ipReasmReqds OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of IPv4 fragments received which needed to be + reassembled at this entity. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by + ipSystemStatsReasmReqds." + ::= { ip 14 } + +ipReasmOKs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of IPv4 datagrams successfully re-assembled. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by + ipSystemStatsReasmOKs." + ::= { ip 15 } + +ipReasmFails OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of failures detected by the IPv4 re-assembly + algorithm (for whatever reason: timed out, errors, etc). + Note that this is not necessarily a count of discarded IPv4 + fragments since some algorithms (notably the algorithm in + RFC 815) can lose track of the number of fragments by + combining them as they are received. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by + ipSystemStatsReasmFails." + ::= { ip 16 } + +ipFragOKs OBJECT-TYPE + SYNTAX Counter32 + + + + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of IPv4 datagrams that have been successfully + fragmented at this entity. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by + ipSystemStatsOutFragOKs." + ::= { ip 17 } + +ipFragFails OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of IPv4 datagrams that have been discarded + because they needed to be fragmented at this entity but + could not be, e.g., because their Don't Fragment flag was + set. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by + ipSystemStatsOutFragFails." + ::= { ip 18 } + +ipFragCreates OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of IPv4 datagram fragments that have been + generated as a result of fragmentation at this entity. + + This object has been deprecated as a new IP version neutral + table has been added. It is loosely replaced by + ipSystemStatsOutFragCreates." + ::= { ip 19 } + +ipRoutingDiscards OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of routing entries which were chosen to be + discarded even though they are valid. One possible reason + for discarding such an entry could be to free-up buffer + space for other routing entries. + + + + This object was defined in pre-IPv6 versions of the IP MIB. + It was implicitly IPv4 only, but the original specifications + did not indicate this protocol restriction. In order to + clarify the specifications, this object has been deprecated + and a similar, but more thoroughly clarified, object has + been added to the IP-FORWARD-MIB." + ::= { ip 23 } + +-- the deprecated IPv4 address table + +ipAddrTable OBJECT-TYPE + SYNTAX SEQUENCE OF IpAddrEntry + MAX-ACCESS not-accessible + STATUS deprecated + DESCRIPTION + "The table of addressing information relevant to this + entity's IPv4 addresses. + + This table has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by the + ipAddressTable although several objects that weren't deemed + useful weren't carried forward while another + (ipAdEntReasmMaxSize) was moved to the ipv4InterfaceTable." + ::= { ip 20 } + +ipAddrEntry OBJECT-TYPE + SYNTAX IpAddrEntry + MAX-ACCESS not-accessible + STATUS deprecated + DESCRIPTION + "The addressing information for one of this entity's IPv4 + addresses." + INDEX { ipAdEntAddr } + ::= { ipAddrTable 1 } + +IpAddrEntry ::= SEQUENCE { + ipAdEntAddr IpAddress, + ipAdEntIfIndex INTEGER, + ipAdEntNetMask IpAddress, + ipAdEntBcastAddr INTEGER, + ipAdEntReasmMaxSize INTEGER + } + +ipAdEntAddr OBJECT-TYPE + SYNTAX IpAddress + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + + + + "The IPv4 address to which this entry's addressing + information pertains." + ::= { ipAddrEntry 1 } + +ipAdEntIfIndex OBJECT-TYPE + SYNTAX INTEGER (1..2147483647) + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The index value which uniquely identifies the interface to + which this entry is applicable. The interface identified by + a particular value of this index is the same interface as + identified by the same value of the IF-MIB's ifIndex." + ::= { ipAddrEntry 2 } + +ipAdEntNetMask OBJECT-TYPE + SYNTAX IpAddress + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The subnet mask associated with the IPv4 address of this + entry. The value of the mask is an IPv4 address with all + the network bits set to 1 and all the hosts bits set to 0." + ::= { ipAddrEntry 3 } + +ipAdEntBcastAddr OBJECT-TYPE + SYNTAX INTEGER (0..1) + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The value of the least-significant bit in the IPv4 broadcast + address used for sending datagrams on the (logical) + interface associated with the IPv4 address of this entry. + For example, when the Internet standard all-ones broadcast + address is used, the value will be 1. This value applies to + both the subnet and network broadcast addresses used by the + entity on this (logical) interface." + ::= { ipAddrEntry 4 } + +ipAdEntReasmMaxSize OBJECT-TYPE + SYNTAX INTEGER (0..65535) + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The size of the largest IPv4 datagram which this entity can + re-assemble from incoming IPv4 fragmented datagrams received + on this interface." + ::= { ipAddrEntry 5 } + + + +-- the deprecated IPv4 Address Translation table + +-- The Address Translation tables contain the IpAddress to +-- "physical" address equivalences. Some interfaces do not +-- use translation tables for determining address +-- equivalences (e.g., DDN-X.25 has an algorithmic method); +-- if all interfaces are of this type, then the Address +-- Translation table is empty, i.e., has zero entries. + +ipNetToMediaTable OBJECT-TYPE + SYNTAX SEQUENCE OF IpNetToMediaEntry + MAX-ACCESS not-accessible + STATUS deprecated + DESCRIPTION + "The IPv4 Address Translation table used for mapping from + IPv4 addresses to physical addresses. + + This table has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by the + ipNetToPhysicalTable." + ::= { ip 22 } + +ipNetToMediaEntry OBJECT-TYPE + SYNTAX IpNetToMediaEntry + MAX-ACCESS not-accessible + STATUS deprecated + DESCRIPTION + "Each entry contains one IpAddress to `physical' address + equivalence." + INDEX { ipNetToMediaIfIndex, + ipNetToMediaNetAddress } + ::= { ipNetToMediaTable 1 } + +IpNetToMediaEntry ::= SEQUENCE { + ipNetToMediaIfIndex INTEGER, + ipNetToMediaPhysAddress PhysAddress, + ipNetToMediaNetAddress IpAddress, + ipNetToMediaType INTEGER + } + +ipNetToMediaIfIndex OBJECT-TYPE + SYNTAX INTEGER (1..2147483647) + MAX-ACCESS read-create + STATUS deprecated + DESCRIPTION + "The interface on which this entry's equivalence is + effective. The interface identified by a particular value + of this index is the same interface as identified by the + + + + same value of the IF-MIB's ifIndex. + + This object predates the rule limiting index objects to a + max access value of 'not-accessible' and so continues to use + a value of 'read-create'." + ::= { ipNetToMediaEntry 1 } + +ipNetToMediaPhysAddress OBJECT-TYPE + SYNTAX PhysAddress (SIZE(0..65535)) + MAX-ACCESS read-create + STATUS deprecated + DESCRIPTION + "The media-dependent `physical' address. This object should + return 0 when this entry is in the 'incomplete' state. + + As the entries in this table are typically not persistent + when this object is written the entity should not save the + change to non-volatile storage. Note: a stronger + requirement is not used because this object was previously + defined." + ::= { ipNetToMediaEntry 2 } + +ipNetToMediaNetAddress OBJECT-TYPE + SYNTAX IpAddress + MAX-ACCESS read-create + STATUS deprecated + DESCRIPTION + "The IpAddress corresponding to the media-dependent + `physical' address. + + This object predates the rule limiting index objects to a + max access value of 'not-accessible' and so continues to use + a value of 'read-create'." + ::= { ipNetToMediaEntry 3 } + +ipNetToMediaType OBJECT-TYPE + SYNTAX INTEGER { + other(1), -- none of the following + invalid(2), -- an invalidated mapping + dynamic(3), + static(4) + } + MAX-ACCESS read-create + STATUS deprecated + DESCRIPTION + "The type of mapping. + + Setting this object to the value invalid(2) has the effect + + + + of invalidating the corresponding entry in the + ipNetToMediaTable. That is, it effectively dis-associates + the interface identified with said entry from the mapping + identified with said entry. It is an implementation- + specific matter as to whether the agent removes an + invalidated entry from the table. Accordingly, management + stations must be prepared to receive tabular information + from agents that corresponds to entries not currently in + use. Proper interpretation of such entries requires + examination of the relevant ipNetToMediaType object. + + As the entries in this table are typically not persistent + when this object is written the entity should not save the + change to non-volatile storage. Note: a stronger + requirement is not used because this object was previously + defined." + ::= { ipNetToMediaEntry 4 } + +-- the deprecated ICMP group + +icmpInMsgs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The total number of ICMP messages which the entity received. + Note that this counter includes all those counted by + icmpInErrors. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by + icmpStatsInMsgs." + ::= { icmp 1 } + +icmpInErrors OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP messages which the entity received but + determined as having ICMP-specific errors (bad ICMP + checksums, bad length, etc.). + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by + icmpStatsInErrors." + ::= { icmp 2 } + + + + +icmpInDestUnreachs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Destination Unreachable messages + received. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 3 } + +icmpInTimeExcds OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Time Exceeded messages received. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 4 } + +icmpInParmProbs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Parameter Problem messages received. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 5 } + +icmpInSrcQuenchs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Source Quench messages received. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 6 } + + + +icmpInRedirects OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Redirect messages received. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 7 } + +icmpInEchos OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Echo (request) messages received. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 8 } + +icmpInEchoReps OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Echo Reply messages received. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 9 } + +icmpInTimestamps OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Timestamp (request) messages received. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 10 } + + + + +icmpInTimestampReps OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Timestamp Reply messages received. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 11 } + +icmpInAddrMasks OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Address Mask Request messages received. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 12 } + +icmpInAddrMaskReps OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Address Mask Reply messages received. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 13 } + +icmpOutMsgs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The total number of ICMP messages which this entity + attempted to send. Note that this counter includes all + those counted by icmpOutErrors. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by + icmpStatsOutMsgs." + + + + ::= { icmp 14 } + +icmpOutErrors OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP messages which this entity did not send + due to problems discovered within ICMP, such as a lack of + buffers. This value should not include errors discovered + outside the ICMP layer, such as the inability of IP to route + the resultant datagram. In some implementations, there may + be no types of error which contribute to this counter's + value. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by + icmpStatsOutErrors." + ::= { icmp 15 } + +icmpOutDestUnreachs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Destination Unreachable messages sent. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 16 } + +icmpOutTimeExcds OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Time Exceeded messages sent. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 17 } + +icmpOutParmProbs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + + + + DESCRIPTION + "The number of ICMP Parameter Problem messages sent. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 18 } + +icmpOutSrcQuenchs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Source Quench messages sent. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 19 } + +icmpOutRedirects OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Redirect messages sent. For a host, this + object will always be zero, since hosts do not send + redirects. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 20 } + +icmpOutEchos OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Echo (request) messages sent. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 21 } + +icmpOutEchoReps OBJECT-TYPE + SYNTAX Counter32 + + + + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Echo Reply messages sent. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 22 } + +icmpOutTimestamps OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Timestamp (request) messages sent. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 23 } + +icmpOutTimestampReps OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Timestamp Reply messages sent. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 24 } + +icmpOutAddrMasks OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Address Mask Request messages sent. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 25 } + +icmpOutAddrMaskReps OBJECT-TYPE + SYNTAX Counter32 + + + + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The number of ICMP Address Mask Reply messages sent. + + This object has been deprecated, as a new IP version-neutral + table has been added. It is loosely replaced by a column in + the icmpMsgStatsTable." + ::= { icmp 26 } + +-- deprecated conformance information +-- deprecated compliance statements + +ipMIBCompliance MODULE-COMPLIANCE + STATUS deprecated + DESCRIPTION + "The compliance statement for systems that implement only + IPv4. For version-independence, this compliance statement + is deprecated in favor of ipMIBCompliance2." + MODULE -- this module + MANDATORY-GROUPS { ipGroup, + icmpGroup } + ::= { ipMIBCompliances 1 } + +-- deprecated units of conformance + +ipGroup OBJECT-GROUP + OBJECTS { ipForwarding, ipDefaultTTL, + ipInReceives, ipInHdrErrors, + ipInAddrErrors, ipForwDatagrams, + ipInUnknownProtos, ipInDiscards, + ipInDelivers, ipOutRequests, + ipOutDiscards, ipOutNoRoutes, + ipReasmTimeout, ipReasmReqds, + ipReasmOKs, ipReasmFails, + ipFragOKs, ipFragFails, + ipFragCreates, ipAdEntAddr, + ipAdEntIfIndex, ipAdEntNetMask, + ipAdEntBcastAddr, ipAdEntReasmMaxSize, + ipNetToMediaIfIndex, ipNetToMediaPhysAddress, + ipNetToMediaNetAddress, ipNetToMediaType, + ipRoutingDiscards +} + STATUS deprecated + DESCRIPTION + "The ip group of objects providing for basic management of IP + entities, exclusive of the management of IP routes. + + + + + As part of the version independence, this group has been + deprecated. " + ::= { ipMIBGroups 1 } + +icmpGroup OBJECT-GROUP + OBJECTS { icmpInMsgs, icmpInErrors, + icmpInDestUnreachs, icmpInTimeExcds, + icmpInParmProbs, icmpInSrcQuenchs, + icmpInRedirects, icmpInEchos, + icmpInEchoReps, icmpInTimestamps, + icmpInTimestampReps, icmpInAddrMasks, + icmpInAddrMaskReps, icmpOutMsgs, + icmpOutErrors, icmpOutDestUnreachs, + icmpOutTimeExcds, icmpOutParmProbs, + icmpOutSrcQuenchs, icmpOutRedirects, + icmpOutEchos, icmpOutEchoReps, + icmpOutTimestamps, icmpOutTimestampReps, + icmpOutAddrMasks, icmpOutAddrMaskReps } + STATUS deprecated + DESCRIPTION + "The icmp group of objects providing ICMP statistics. + + As part of the version independence, this group has been + deprecated. " + ::= { ipMIBGroups 2 } + +END diff --git a/contrib/apps/LwipMibCompiler/Mibs/RFC-1212 b/contrib/apps/LwipMibCompiler/Mibs/RFC-1212 new file mode 100644 index 00000000000..4b1bdcfd999 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/RFC-1212 @@ -0,0 +1,75 @@ +RFC-1212 DEFINITIONS ::= BEGIN + + IMPORTS + ObjectName + FROM RFC1155-SMI; +-- DisplayString +-- FROM RFC1158-MIB; + + OBJECT-TYPE MACRO ::= + BEGIN + TYPE NOTATION ::= + -- must conform to + -- RFC1155's ObjectSyntax + "SYNTAX" type(ObjectSyntax) + "ACCESS" Access + "STATUS" Status + DescrPart + ReferPart + IndexPart + DefValPart + VALUE NOTATION ::= value (VALUE ObjectName) + + Access ::= "read-only" + | "read-write" + | "write-only" + | "not-accessible" + Status ::= "mandatory" + | "optional" + | "obsolete" + | "deprecated" + + DescrPart ::= + "DESCRIPTION" value (description DisplayString) + | empty + + ReferPart ::= + "REFERENCE" value (reference DisplayString) + | empty + + IndexPart ::= + "INDEX" "{" IndexTypes "}" + | empty + IndexTypes ::= + IndexType | IndexTypes "," IndexType + IndexType ::= + -- if indexobject, use the SYNTAX + -- value of the correspondent + -- OBJECT-TYPE invocation + value (indexobject ObjectName) + -- otherwise use named SMI type + -- must conform to IndexSyntax below + | type (indextype) + + DefValPart ::= + "DEFVAL" "{" value (defvalue ObjectSyntax) "}" + | empty + + END + + IndexSyntax ::= + CHOICE { + number + INTEGER (0..MAX), + string + OCTET STRING, + object + OBJECT IDENTIFIER, + address + NetworkAddress, + ipAddress + IpAddress + } + +END + diff --git a/contrib/apps/LwipMibCompiler/Mibs/RFC-1215 b/contrib/apps/LwipMibCompiler/Mibs/RFC-1215 new file mode 100644 index 00000000000..3cdcfdf355b --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/RFC-1215 @@ -0,0 +1,34 @@ +RFC-1215 DEFINITIONS ::= BEGIN + + IMPORTS + ObjectName + FROM RFC1155-SMI; + + TRAP-TYPE MACRO ::= + BEGIN + TYPE NOTATION ::= "ENTERPRISE" value + (enterprise OBJECT IDENTIFIER) + VarPart + DescrPart + ReferPart + VALUE NOTATION ::= value (VALUE INTEGER) + + VarPart ::= + "VARIABLES" "{" VarTypes "}" + | empty + VarTypes ::= + VarType | VarTypes "," VarType + VarType ::= + value (vartype ObjectName) + + DescrPart ::= + "DESCRIPTION" value (description DisplayString) + | empty + + ReferPart ::= + "REFERENCE" value (reference DisplayString) + | empty + + END + +END diff --git a/contrib/apps/LwipMibCompiler/Mibs/RFC1065-SMI b/contrib/apps/LwipMibCompiler/Mibs/RFC1065-SMI new file mode 100644 index 00000000000..40e55d70082 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/RFC1065-SMI @@ -0,0 +1,132 @@ +RFC1065-SMI DEFINITIONS ::= BEGIN + +EXPORTS -- EVERYTHING + internet, directory, mgmt, + experimental, private, enterprises, + OBJECT-TYPE, ObjectName, ObjectSyntax, SimpleSyntax, + ApplicationSyntax, NetworkAddress, IpAddress, + Counter, Gauge, TimeTicks, Opaque; + + -- the path to the root + + internet OBJECT IDENTIFIER ::= { iso org(3) dod(6) 1 } + + directory OBJECT IDENTIFIER ::= { internet 1 } + + mgmt OBJECT IDENTIFIER ::= { internet 2 } + + experimental OBJECT IDENTIFIER ::= { internet 3 } + + private OBJECT IDENTIFIER ::= { internet 4 } + enterprises OBJECT IDENTIFIER ::= { private 1 } + + + -- definition of object types + + OBJECT-TYPE MACRO ::= + BEGIN + TYPE NOTATION ::= "SYNTAX" type (TYPE ObjectSyntax) + "ACCESS" Access + "STATUS" Status + VALUE NOTATION ::= value (VALUE ObjectName) + + Access ::= "read-only" + | "read-write" + | "write-only" + | "not-accessible" + Status ::= "mandatory" + | "optional" + | "obsolete" + END + + -- names of objects in the MIB + + ObjectName ::= + OBJECT IDENTIFIER + + + + -- syntax of objects in the MIB + + ObjectSyntax ::= + CHOICE { + simple + SimpleSyntax, + + -- note that simple SEQUENCEs are not directly + -- mentioned here to keep things simple (i.e., + -- prevent mis-use). However, application-wide + -- types which are IMPLICITly encoded simple + -- SEQUENCEs may appear in the following CHOICE + + application-wide + ApplicationSyntax + } + + SimpleSyntax ::= + CHOICE { + number + INTEGER, + + string + OCTET STRING, + + object + OBJECT IDENTIFIER, + + empty + NULL + } + + ApplicationSyntax ::= + CHOICE { + address + NetworkAddress, + + counter + Counter, + + gauge + Gauge, + + ticks + TimeTicks, + + arbitrary + Opaque + + + -- other application-wide types, as they are + -- defined, will be added here + } + + + -- application-wide types + + NetworkAddress ::= + CHOICE { + internet + IpAddress + } + + IpAddress ::= + [APPLICATION 0] -- in network-byte order + IMPLICIT OCTET STRING (SIZE (4)) + + Counter ::= + [APPLICATION 1] + IMPLICIT INTEGER (0..4294967295) + + Gauge ::= + [APPLICATION 2] + IMPLICIT INTEGER (0..4294967295) + + TimeTicks ::= + [APPLICATION 3] + IMPLICIT INTEGER + + Opaque ::= + [APPLICATION 4] -- arbitrary ASN.1 value, + IMPLICIT OCTET STRING -- "double-wrapped" + + END diff --git a/contrib/apps/LwipMibCompiler/Mibs/RFC1155-SMI b/contrib/apps/LwipMibCompiler/Mibs/RFC1155-SMI new file mode 100644 index 00000000000..a6c3bf62a31 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/RFC1155-SMI @@ -0,0 +1,129 @@ +RFC1155-SMI DEFINITIONS ::= BEGIN + +EXPORTS -- EVERYTHING + internet, directory, mgmt, + experimental, private, enterprises, + OBJECT-TYPE, ObjectName, ObjectSyntax, SimpleSyntax, + ApplicationSyntax, NetworkAddress, IpAddress, + Counter, Gauge, TimeTicks, Opaque; + + -- the path to the root + + internet OBJECT IDENTIFIER ::= { iso org(3) dod(6) 1 } + + directory OBJECT IDENTIFIER ::= { internet 1 } + + mgmt OBJECT IDENTIFIER ::= { internet 2 } + + experimental OBJECT IDENTIFIER ::= { internet 3 } + + private OBJECT IDENTIFIER ::= { internet 4 } + enterprises OBJECT IDENTIFIER ::= { private 1 } + + + -- definition of object types + + OBJECT-TYPE MACRO ::= + BEGIN + TYPE NOTATION ::= "SYNTAX" type (TYPE ObjectSyntax) + "ACCESS" Access + "STATUS" Status + VALUE NOTATION ::= value (VALUE ObjectName) + + Access ::= "read-only" + | "read-write" + | "write-only" + | "not-accessible" + Status ::= "mandatory" + | "optional" + | "obsolete" + END + + -- names of objects in the MIB + + ObjectName ::= + OBJECT IDENTIFIER + + -- syntax of objects in the MIB + + ObjectSyntax ::= + CHOICE { + simple + SimpleSyntax, + + -- note that simple SEQUENCEs are not directly + -- mentioned here to keep things simple (i.e., + -- prevent mis-use). However, application-wide + -- types which are IMPLICITly encoded simple + -- SEQUENCEs may appear in the following CHOICE + + application-wide + ApplicationSyntax + } + + SimpleSyntax ::= + CHOICE { + number + INTEGER, + + string + OCTET STRING, + + object + OBJECT IDENTIFIER, + + empty + NULL + } + + ApplicationSyntax ::= + CHOICE { + address + NetworkAddress, + + counter + Counter, + + gauge + Gauge, + + ticks + TimeTicks, + + arbitrary + Opaque + + -- other application-wide types, as they are + -- defined, will be added here + } + + + -- application-wide types + + NetworkAddress ::= + CHOICE { + internet + IpAddress + } + + IpAddress ::= + [APPLICATION 0] -- in network-byte order + IMPLICIT OCTET STRING (SIZE (4)) + + Counter ::= + [APPLICATION 1] + IMPLICIT INTEGER (0..4294967295) + + Gauge ::= + [APPLICATION 2] + IMPLICIT INTEGER (0..4294967295) + + TimeTicks ::= + [APPLICATION 3] + IMPLICIT INTEGER (0..4294967295) + + Opaque ::= + [APPLICATION 4] -- arbitrary ASN.1 value, + IMPLICIT OCTET STRING -- "double-wrapped" + + END diff --git a/contrib/apps/LwipMibCompiler/Mibs/RFC1158-MIB b/contrib/apps/LwipMibCompiler/Mibs/RFC1158-MIB new file mode 100644 index 00000000000..4acf34a0302 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/RFC1158-MIB @@ -0,0 +1,1493 @@ +RFC1158-MIB DEFINITIONS ::= BEGIN + +IMPORTS + mgmt, OBJECT-TYPE, NetworkAddress, IpAddress, + Counter, Gauge, TimeTicks + FROM RFC1155-SMI; + +DisplayString ::= + OCTET STRING + +mib-2 OBJECT IDENTIFIER ::= { mgmt 1 } -- MIB-II + -- (same prefix as MIB-I) + +system OBJECT IDENTIFIER ::= { mib-2 1 } +interfaces OBJECT IDENTIFIER ::= { mib-2 2 } +at OBJECT IDENTIFIER ::= { mib-2 3 } +ip OBJECT IDENTIFIER ::= { mib-2 4 } +icmp OBJECT IDENTIFIER ::= { mib-2 5 } +tcp OBJECT IDENTIFIER ::= { mib-2 6 } +udp OBJECT IDENTIFIER ::= { mib-2 7 } +egp OBJECT IDENTIFIER ::= { mib-2 8 } +-- cmot OBJECT IDENTIFIER ::= { mib-2 9 } +transmission OBJECT IDENTIFIER ::= { mib-2 10 } +snmp OBJECT IDENTIFIER ::= { mib-2 11 } + + +-- object types + +-- the System group + +sysDescr OBJECT-TYPE + SYNTAX DisplayString (SIZE (0..255)) + ACCESS read-only + STATUS mandatory + ::= { system 1 } + +sysObjectID OBJECT-TYPE + SYNTAX OBJECT IDENTIFIER + ACCESS read-only + STATUS mandatory + ::= { system 2 } + +sysUpTime OBJECT-TYPE + SYNTAX TimeTicks + ACCESS read-only + STATUS mandatory + ::= { system 3 } + +sysContact OBJECT-TYPE + SYNTAX DisplayString (SIZE (0..255)) + ACCESS read-write + STATUS mandatory + ::= { system 4 } + +sysName OBJECT-TYPE + SYNTAX DisplayString (SIZE (0..255)) + ACCESS read-write + STATUS mandatory + ::= { system 5 } + +sysLocation OBJECT-TYPE + SYNTAX DisplayString (SIZE (0..255)) + ACCESS read-only + STATUS mandatory + ::= { system 6 } + +sysServices OBJECT-TYPE + SYNTAX INTEGER (0..127) + ACCESS read-only + STATUS mandatory + ::= { system 7 } + + +-- the Interfaces group + +ifNumber OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + ::= { interfaces 1 } + +-- the Interfaces table + +ifTable OBJECT-TYPE + SYNTAX SEQUENCE OF IfEntry + ACCESS read-only + STATUS mandatory + ::= { interfaces 2 } + +ifEntry OBJECT-TYPE + SYNTAX IfEntry + ACCESS read-only + STATUS mandatory + ::= { ifTable 1 } + +IfEntry ::= SEQUENCE { + ifIndex + INTEGER, + ifDescr + DisplayString, + ifType + INTEGER, + ifMtu + INTEGER, + ifSpeed + Gauge, + ifPhysAddress + OCTET STRING, + ifAdminStatus + INTEGER, + ifOperStatus + INTEGER, + ifLastChange + TimeTicks, + ifInOctets + Counter, + ifInUcastPkts + Counter, + ifInNUcastPkts + Counter, + ifInDiscards + Counter, + ifInErrors + Counter, + ifInUnknownProtos + Counter, + ifOutOctets + Counter, + ifOutUcastPkts + Counter, + ifOutNUcastPkts + Counter, + ifOutDiscards + Counter, + ifOutErrors + Counter, + ifOutQLen + Gauge, + ifSpecific + OBJECT IDENTIFIER +} + +ifIndex OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + ::= { ifEntry 1 } + +ifDescr OBJECT-TYPE + SYNTAX DisplayString (SIZE (0..255)) + ACCESS read-only + STATUS mandatory + ::= { ifEntry 2 } + +ifType OBJECT-TYPE + SYNTAX INTEGER { + other(1), -- none of the + -- following + regular1822(2), + hdh1822(3), + ddn-x25(4), + rfc877-x25(5), + ethernet-csmacd(6), + iso88023-csmacd(7), + iso88024-tokenBus(8), + iso88025-tokenRing(9), + iso88026-man(10), + starLan(11), + proteon-10Mbit(12), + proteon-80Mbit(13), + hyperchannel(14), + fddi(15), + lapb(16), + sdlc(17), + t1-carrier(18), + cept(19), -- european + --equivalent of T-1 + basicISDN(20), + primaryISDN(21), + -- proprietary + -- serial + propPointToPointSerial(22), + terminalServer-asyncPort(23), + softwareLoopback(24), + eon(25), -- CLNP over IP + ethernet-3Mbit(26), + nsip(27), -- XNS over IP + slip(28) -- generic SLIP + } + ACCESS read-only + STATUS mandatory + ::= { ifEntry 3 } + +ifMtu OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + ::= { ifEntry 4 } + +ifSpeed OBJECT-TYPE + SYNTAX Gauge + ACCESS read-only + STATUS mandatory + ::= { ifEntry 5 } + +ifPhysAddress OBJECT-TYPE + SYNTAX OCTET STRING + ACCESS read-only + STATUS mandatory + ::= { ifEntry 6 } + +ifAdminStatus OBJECT-TYPE + SYNTAX INTEGER { + up(1), -- ready to pass packets + down(2), + testing(3) -- in some test mode + } + ACCESS read-write + STATUS mandatory + ::= { ifEntry 7 } + +ifOperStatus OBJECT-TYPE + SYNTAX INTEGER { + up(1), -- ready to pass packets + down(2), + testing(3) -- in some test mode + } + ACCESS read-only + STATUS mandatory + ::= { ifEntry 8 } + +ifLastChange OBJECT-TYPE + SYNTAX TimeTicks + ACCESS read-only + STATUS mandatory + ::= { ifEntry 9 } + +ifInOctets OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ifEntry 10 } + +ifInUcastPkts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ifEntry 11 } + +ifInNUcastPkts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ifEntry 12 } + +ifInDiscards OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ifEntry 13 } + +ifInErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ifEntry 14 } + +ifInUnknownProtos OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ifEntry 15 } + +ifOutOctets OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ifEntry 16 } + +ifOutUcastPkts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ifEntry 17 } + +ifOutNUcastPkts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ifEntry 18 } + +ifOutDiscards OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ifEntry 19 } + +ifOutErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ifEntry 20 } + +ifOutQLen OBJECT-TYPE + SYNTAX Gauge + ACCESS read-only + STATUS mandatory + ::= { ifEntry 21 } + +ifSpecific OBJECT-TYPE + SYNTAX OBJECT IDENTIFIER + ACCESS read-only + STATUS mandatory + ::= { ifEntry 22 } + +nullSpecific OBJECT IDENTIFIER ::= { 0 0 } + +-- the Address Translation group (deprecated) + +atTable OBJECT-TYPE + SYNTAX SEQUENCE OF AtEntry + ACCESS read-write + STATUS deprecated + ::= { at 1 } + +atEntry OBJECT-TYPE + SYNTAX AtEntry + ACCESS read-write + STATUS deprecated + ::= { atTable 1 } + +AtEntry ::= SEQUENCE { + atIfIndex + INTEGER, + atPhysAddress + OCTET STRING, + atNetAddress + NetworkAddress +} + +atIfIndex OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS deprecated + ::= { atEntry 1 } + +atPhysAddress OBJECT-TYPE + SYNTAX OCTET STRING + ACCESS read-write + STATUS deprecated + ::= { atEntry 2 } + +atNetAddress OBJECT-TYPE + SYNTAX NetworkAddress + ACCESS read-write + STATUS deprecated + ::= { atEntry 3 } + + +-- the IP group + +ipForwarding OBJECT-TYPE + SYNTAX INTEGER { + gateway(1), -- entity forwards + -- datagrams + host(2) -- entity does NOT + -- forward datagrams + } + ACCESS read-write + STATUS mandatory + ::= { ip 1 } + +ipDefaultTTL OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + ::= { ip 2 } + +ipInReceives OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 3 } + +ipInHdrErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 4 } + +ipInAddrErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 5 } + +ipForwDatagrams OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 6 } + +ipInUnknownProtos OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 7 } + +ipInDiscards OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 8 } + +ipInDelivers OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 9 } + +ipOutRequests OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 10 } + +ipOutDiscards OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 11 } + +ipOutNoRoutes OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 12 } + +ipReasmTimeout OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + ::= { ip 13 } + +ipReasmReqds OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 14 } + +ipReasmOKs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 15 } + +ipReasmFails OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 16 } + +ipFragOKs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 17 } + +ipFragFails OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 18 } + +ipFragCreates OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { ip 19 } + +-- the IP Interface table + +ipAddrTable OBJECT-TYPE + SYNTAX SEQUENCE OF IpAddrEntry + ACCESS read-only + STATUS mandatory + ::= { ip 20 } + +ipAddrEntry OBJECT-TYPE + SYNTAX IpAddrEntry + ACCESS read-only + STATUS mandatory + ::= { ipAddrTable 1 } + +IpAddrEntry ::= SEQUENCE { + ipAdEntAddr + IpAddress, + ipAdEntIfIndex + INTEGER, + ipAdEntNetMask + IpAddress, + ipAdEntBcastAddr + INTEGER, + ipAdEntReasmMaxSize + INTEGER (0..65535) +} + +ipAdEntAddr OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-only + STATUS mandatory + ::= { ipAddrEntry 1 } + +ipAdEntIfIndex OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + ::= { ipAddrEntry 2 } + +ipAdEntNetMask OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-only + STATUS mandatory + ::= { ipAddrEntry 3 } + +ipAdEntBcastAddr OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + ::= { ipAddrEntry 4 } + +ipAdEntReasmMaxSize OBJECT-TYPE + SYNTAX INTEGER (0..65535) + ACCESS read-only + STATUS mandatory + ::= { ipAddrEntry 5 } + +-- the IP Routing table + +ipRoutingTable OBJECT-TYPE + SYNTAX SEQUENCE OF IpRouteEntry + ACCESS read-write + STATUS mandatory + ::= { ip 21 } + +ipRouteEntry OBJECT-TYPE + SYNTAX IpRouteEntry + ACCESS read-write + STATUS mandatory + ::= { ipRoutingTable 1 } + +IpRouteEntry ::= SEQUENCE { + ipRouteDest + IpAddress, + ipRouteIfIndex + INTEGER, + ipRouteMetric1 + INTEGER, + ipRouteMetric2 + INTEGER, + ipRouteMetric3 + INTEGER, + ipRouteMetric4 + INTEGER, + ipRouteNextHop + IpAddress, + ipRouteType + INTEGER, + ipRouteProto + INTEGER, + ipRouteAge + INTEGER, + ipRouteMask + IpAddress +} + +ipRouteDest OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-write + STATUS mandatory + ::= { ipRouteEntry 1 } + +ipRouteIfIndex OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + ::= { ipRouteEntry 2 } + +ipRouteMetric1 OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + ::= { ipRouteEntry 3 } + +ipRouteMetric2 OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + ::= { ipRouteEntry 4 } + +ipRouteMetric3 OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + ::= { ipRouteEntry 5 } + +ipRouteMetric4 OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + ::= { ipRouteEntry 6 } + +ipRouteNextHop OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-write + STATUS mandatory + ::= { ipRouteEntry 7 } + +ipRouteType OBJECT-TYPE + SYNTAX INTEGER { + other(1), -- none of the following + + invalid(2), -- an invalidated route + + -- route to directly + direct(3), -- connected + -- (sub-)network + + -- route to a non-local + remote(4) -- host/network/ + -- sub-network + } + ACCESS read-write + STATUS mandatory + ::= { ipRouteEntry 8 } + +ipRouteProto OBJECT-TYPE + SYNTAX INTEGER { + other(1), -- none of the following + + -- non-protocol + -- information + + -- e.g., manually + local(2), -- configured entries + + -- set via a network + netmgmt(3), -- management protocol + + -- obtained via ICMP, + icmp(4), -- e.g., Redirect + + -- the following are + -- gateway routing + -- protocols + egp(5), + ggp(6), + hello(7), + rip(8), + is-is(9), + es-is(10), + ciscoIgrp(11), + bbnSpfIgp(12), + ospf(13), + bgp(14) + } + ACCESS read-only + STATUS mandatory + ::= { ipRouteEntry 9 } + +ipRouteAge OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + ::= { ipRouteEntry 10 } + +ipRouteMask OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-write + STATUS mandatory + ::= { ipRouteEntry 11 } + +-- the IP Address Translation tables + +ipNetToMediaTable OBJECT-TYPE + SYNTAX SEQUENCE OF IpNetToMediaEntry + ACCESS read-write + STATUS mandatory + ::= { ip 22 } + +ipNetToMediaEntry OBJECT-TYPE + SYNTAX IpNetToMediaEntry + ACCESS read-write + STATUS mandatory + ::= { ipNetToMediaTable 1 } + +IpNetToMediaEntry ::= SEQUENCE { + ipNetToMediaIfIndex + INTEGER, + ipNetToMediaPhysAddress + OCTET STRING, + ipNetToMediaNetAddress + IpAddress, + ipNetToMediaType + INTEGER +} + +ipNetToMediaIfIndex OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + ::= { ipNetToMediaEntry 1 } + +ipNetToMediaPhysAddress OBJECT-TYPE + SYNTAX OCTET STRING + ACCESS read-write + STATUS mandatory + ::= { ipNetToMediaEntry 2 } + +ipNetToMediaNetAddress OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-write + STATUS mandatory + ::= { ipNetToMediaEntry 3 } + +ipNetToMediaType OBJECT-TYPE + SYNTAX INTEGER { + other(1), -- none of the following + + invalid(2), -- an invalidated mapping + dynamic(3), -- connected (sub-)network + + static(4) + } + ACCESS read-write + STATUS mandatory + ::= { ipNetToMediaEntry 4 } + +-- the ICMP group + +icmpInMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 1 } + +icmpInErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 2 } + +icmpInDestUnreachs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 3 } + +icmpInTimeExcds OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 4 } + +icmpInParmProbs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 5 } + +icmpInSrcQuenchs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 6 } + +icmpInRedirects OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 7 } + +icmpInEchos OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 8 } + +icmpInEchoReps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 9 } + +icmpInTimestamps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 10 } + +icmpInTimestampReps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 11 } + +icmpInAddrMasks OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 12 } + +icmpInAddrMaskReps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 13 } + +icmpOutMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 14 } + +icmpOutErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 15 } + +icmpOutDestUnreachs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 16 } + +icmpOutTimeExcds OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 17 } + +icmpOutParmProbs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 18 } + +icmpOutSrcQuenchs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 19 } + +icmpOutRedirects OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 20 } + +icmpOutEchos OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 21 } + +icmpOutEchoReps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 22 } + +icmpOutTimestamps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 23 } + +icmpOutTimestampReps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 24 } + +icmpOutAddrMasks OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 25 } + +icmpOutAddrMaskReps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { icmp 26 } + + +-- the TCP group + +tcpRtoAlgorithm OBJECT-TYPE + SYNTAX INTEGER { + other(1), -- none of the following + constant(2), -- a constant rto + rsre(3), -- MIL-STD-1778, + -- Appendix B + vanj(4) -- Van Jacobson's + -- algorithm + } + ACCESS read-only + STATUS mandatory + ::= { tcp 1 } + +tcpRtoMin OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + ::= { tcp 2 } + +tcpRtoMax OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + ::= { tcp 3 } + +tcpMaxConn OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + ::= { tcp 4 } + +tcpActiveOpens OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { tcp 5 } + +tcpPassiveOpens OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { tcp 6 } + +tcpAttemptFails OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { tcp 7 } + +tcpEstabResets OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { tcp 8 } + +tcpCurrEstab OBJECT-TYPE + SYNTAX Gauge + ACCESS read-only + STATUS mandatory + ::= { tcp 9 } + +tcpInSegs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { tcp 10 } + +tcpOutSegs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { tcp 11 } + +tcpRetransSegs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { tcp 12 } + +-- the TCP connections table + +tcpConnTable OBJECT-TYPE + SYNTAX SEQUENCE OF TcpConnEntry + ACCESS read-only + STATUS mandatory + ::= { tcp 13 } + +tcpConnEntry OBJECT-TYPE + SYNTAX TcpConnEntry + ACCESS read-only + STATUS mandatory + ::= { tcpConnTable 1 } + +TcpConnEntry ::= SEQUENCE { + tcpConnState + INTEGER, + tcpConnLocalAddress + IpAddress, + tcpConnLocalPort + INTEGER (0..65535), + tcpConnRemAddress + IpAddress, + tcpConnRemPort + INTEGER (0..65535) +} + +tcpConnState OBJECT-TYPE + SYNTAX INTEGER { + closed(1), + listen(2), + synSent(3), + synReceived(4), + established(5), + finWait1(6), + finWait2(7), + closeWait(8), + lastAck(9), + closing(10), + timeWait(11) + } + ACCESS read-only + STATUS mandatory + ::= { tcpConnEntry 1 } + +tcpConnLocalAddress OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-only + STATUS mandatory + ::= { tcpConnEntry 2 } + +tcpConnLocalPort OBJECT-TYPE + SYNTAX INTEGER (0..65535) + ACCESS read-only + STATUS mandatory + ::= { tcpConnEntry 3 } + +tcpConnRemAddress OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-only + STATUS mandatory + ::= { tcpConnEntry 4 } + +tcpConnRemPort OBJECT-TYPE + SYNTAX INTEGER (0..65535) + ACCESS read-only + STATUS mandatory + ::= { tcpConnEntry 5 } + +-- additional TCP variables + +tcpInErrs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { tcp 14 } + +tcpOutRsts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { tcp 15 } + + +-- the UDP group + +udpInDatagrams OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { udp 1 } + +udpNoPorts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { udp 2 } + +udpInErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { udp 3 } + +udpOutDatagrams OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { udp 4 } + +-- the UDP listener table + +udpTable OBJECT-TYPE + SYNTAX SEQUENCE OF UdpEntry + ACCESS read-only + STATUS mandatory + ::= { udp 5 } + +udpEntry OBJECT-TYPE + SYNTAX UdpEntry + ACCESS read-only + STATUS mandatory + ::= { udpTable 1 } + +UdpEntry ::= SEQUENCE { + udpLocalAddress + IpAddress, + udpLocalPort + INTEGER (0..65535) +} + +udpLocalAddress OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-only + STATUS mandatory + ::= { udpEntry 1 } + +udpLocalPort OBJECT-TYPE + SYNTAX INTEGER (0..65535) + ACCESS read-only + STATUS mandatory + ::= { udpEntry 2 } + +-- the EGP group + +egpInMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { egp 1 } + +egpInErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { egp 2 } + +egpOutMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { egp 3 } + +egpOutErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { egp 4 } + +-- the EGP Neighbor table + +egpNeighTable OBJECT-TYPE + SYNTAX SEQUENCE OF EgpNeighEntry + ACCESS read-only + STATUS mandatory + ::= { egp 5 } + +egpNeighEntry OBJECT-TYPE + SYNTAX EgpNeighEntry + ACCESS read-only + STATUS mandatory + ::= { egpNeighTable 1 } + +EgpNeighEntry ::= SEQUENCE { + egpNeighState + INTEGER, + egpNeighAddr + IpAddress, + egpNeighAs + INTEGER, + egpNeighInMsgs + Counter, + egpNeighInErrs + Counter, + egpNeighOutMsgs + Counter, + egpNeighOutErrs + Counter, + egpNeighInErrMsgs + Counter, + egpNeighOutErrMsgs + Counter, + egpNeighStateUps + Counter, + egpNeighStateDowns + Counter, + egpNeighIntervalHello + INTEGER, + egpNeighIntervalPoll + INTEGER, + egpNeighMode + INTEGER, + egpNeighEventTrigger + INTEGER +} + +egpNeighState OBJECT-TYPE + SYNTAX INTEGER { + idle(1), + acquisition(2), + down(3), + up(4), + cease(5) + } + ACCESS read-only + STATUS mandatory + ::= { egpNeighEntry 1 } + +egpNeighAddr OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-only + STATUS mandatory + ::= { egpNeighEntry 2 } + +egpNeighAs OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + ::= { egpNeighEntry 3 } + +egpNeighInMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { egpNeighEntry 4 } + +egpNeighInErrs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { egpNeighEntry 5 } + +egpNeighOutMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { egpNeighEntry 6 } + +egpNeighOutErrs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { egpNeighEntry 7 } + +egpNeighInErrMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { egpNeighEntry 8 } + +egpNeighOutErrMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { egpNeighEntry 9 } + +egpNeighStateUps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { egpNeighEntry 10 } + +egpNeighStateDowns OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { egpNeighEntry 11 } + +egpNeighIntervalHello OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + ::= { egpNeighEntry 12 } + +egpNeighIntervalPoll OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + ::= { egpNeighEntry 13 } + +egpNeighMode OBJECT-TYPE + SYNTAX INTEGER { + active(1), + passive(2) + } + ACCESS read-only + STATUS mandatory + ::= { egpNeighEntry 14 } + +egpNeighEventTrigger OBJECT-TYPE + SYNTAX INTEGER { + start(1), + stop(2) + } + ACCESS read-write + STATUS mandatory + ::= { egpNeighEntry 15 } + +-- additional EGP variables + +egpAs OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + ::= { egp 6 } + + +-- the Transmission group (empty at present) + +-- the SNMP group + +snmpInPkts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 1 } + +snmpOutPkts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 2 } + +snmpInBadVersions OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 3 } + +snmpInBadCommunityNames OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 4 } + +snmpInBadCommunityUses OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 5 } + +snmpInASNParseErrs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 6 } + +snmpInBadTypes OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 7 } + +snmpInTooBigs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 8 } + +snmpInNoSuchNames OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 9 } + +snmpInBadValues OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 10 } + +snmpInReadOnlys OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 11 } + +snmpInGenErrs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 12 } + +snmpInTotalReqVars OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 13 } + +snmpInTotalSetVars OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 14 } + +snmpInGetRequests OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 15 } + +snmpInGetNexts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 16 } + +snmpInSetRequests OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 17 } + +snmpInGetResponses OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 18 } + +snmpInTraps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 19 } + +snmpOutTooBigs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 20 } + +snmpOutNoSuchNames OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 21 } + +snmpOutBadValues OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 22 } + +snmpOutReadOnlys OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 23 } + +snmpOutGenErrs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 24 } + +snmpOutGetRequests OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 25 } + +snmpOutGetNexts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 26 } + +snmpOutSetRequests OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 27 } + +snmpOutGetResponses OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 28 } + +snmpOutTraps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + ::= { snmp 29 } + +snmpEnableAuthTraps OBJECT-TYPE + SYNTAX INTEGER { + enabled(1), + disabled(2) + } + ACCESS read-write + STATUS mandatory + ::= { snmp 30 } + +END diff --git a/contrib/apps/LwipMibCompiler/Mibs/RFC1213-MIB b/contrib/apps/LwipMibCompiler/Mibs/RFC1213-MIB new file mode 100644 index 00000000000..2a849dede9b --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/RFC1213-MIB @@ -0,0 +1,2621 @@ +RFC1213-MIB DEFINITIONS ::= BEGIN + +IMPORTS + mgmt, NetworkAddress, IpAddress, Counter, Gauge, + TimeTicks + FROM RFC1155-SMI + OBJECT-TYPE + FROM RFC-1212; + +-- This MIB module uses the extended OBJECT-TYPE macro as +-- defined in [14]; + + +-- MIB-II (same prefix as MIB-I) + +mib-2 OBJECT IDENTIFIER ::= { mgmt 1 } + +-- textual conventions + +DisplayString ::= + OCTET STRING +-- This data type is used to model textual information taken +-- from the NVT ASCII character set. By convention, objects +-- with this syntax are declared as having + +-- +-- SIZE (0..255) + +PhysAddress ::= + OCTET STRING +-- This data type is used to model media addresses. For many +-- types of media, this will be in a binary representation. +-- For example, an ethernet address would be represented as +-- a string of 6 octets. + + +-- groups in MIB-II + +system OBJECT IDENTIFIER ::= { mib-2 1 } + +interfaces OBJECT IDENTIFIER ::= { mib-2 2 } + +at OBJECT IDENTIFIER ::= { mib-2 3 } + +ip OBJECT IDENTIFIER ::= { mib-2 4 } + +icmp OBJECT IDENTIFIER ::= { mib-2 5 } + +tcp OBJECT IDENTIFIER ::= { mib-2 6 } + +udp OBJECT IDENTIFIER ::= { mib-2 7 } + +egp OBJECT IDENTIFIER ::= { mib-2 8 } + +-- historical (some say hysterical) +-- cmot OBJECT IDENTIFIER ::= { mib-2 9 } + +transmission OBJECT IDENTIFIER ::= { mib-2 10 } + +snmp OBJECT IDENTIFIER ::= { mib-2 11 } + + +-- the System group + +-- Implementation of the System group is mandatory for all +-- systems. If an agent is not configured to have a value +-- for any of these variables, a string of length 0 is +-- returned. + +sysDescr OBJECT-TYPE + SYNTAX DisplayString (SIZE (0..255)) + ACCESS read-only + STATUS mandatory + DESCRIPTION + "A textual description of the entity. This value + should include the full name and version + identification of the system's hardware type, + software operating-system, and networking + software. It is mandatory that this only contain + printable ASCII characters." + ::= { system 1 } + +sysObjectID OBJECT-TYPE + SYNTAX OBJECT IDENTIFIER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The vendor's authoritative identification of the + network management subsystem contained in the + entity. This value is allocated within the SMI + enterprises subtree (1.3.6.1.4.1) and provides an + easy and unambiguous means for determining `what + kind of box' is being managed. For example, if + vendor `Flintstones, Inc.' was assigned the + subtree 1.3.6.1.4.1.4242, it could assign the + identifier 1.3.6.1.4.1.4242.1.1 to its `Fred + Router'." + ::= { system 2 } + +sysUpTime OBJECT-TYPE + SYNTAX TimeTicks + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The time (in hundredths of a second) since the + network management portion of the system was last + re-initialized." + ::= { system 3 } + +sysContact OBJECT-TYPE + SYNTAX DisplayString (SIZE (0..255)) + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The textual identification of the contact person + for this managed node, together with information + on how to contact this person." + ::= { system 4 } + +sysName OBJECT-TYPE + SYNTAX DisplayString (SIZE (0..255)) + ACCESS read-write + STATUS mandatory + DESCRIPTION + "An administratively-assigned name for this + managed node. By convention, this is the node's + fully-qualified domain name." + ::= { system 5 } + +sysLocation OBJECT-TYPE + SYNTAX DisplayString (SIZE (0..255)) + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The physical location of this node (e.g., + `telephone closet, 3rd floor')." + ::= { system 6 } + +sysServices OBJECT-TYPE + SYNTAX INTEGER (0..127) + ACCESS read-only + STATUS mandatory + DESCRIPTION + "A value which indicates the set of services that + this entity primarily offers. + + The value is a sum. This sum initially takes the + value zero, Then, for each layer, L, in the range + 1 through 7, that this node performs transactions + for, 2 raised to (L - 1) is added to the sum. For + example, a node which performs primarily routing + functions would have a value of 4 (2^(3-1)). In + contrast, a node which is a host offering + application services would have a value of 72 + (2^(4-1) + 2^(7-1)). Note that in the context of + the Internet suite of protocols, values should be + calculated accordingly: + + layer functionality + 1 physical (e.g., repeaters) + 2 datalink/subnetwork (e.g., bridges) + 3 internet (e.g., IP gateways) + 4 end-to-end (e.g., IP hosts) + 7 applications (e.g., mail relays) + + For systems including OSI protocols, layers 5 and + 6 may also be counted." + ::= { system 7 } + +-- the Interfaces group + +-- Implementation of the Interfaces group is mandatory for +-- all systems. + +ifNumber OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of network interfaces (regardless of + their current state) present on this system." + ::= { interfaces 1 } + + +-- the Interfaces table + +-- The Interfaces table contains information on the entity's +-- interfaces. Each interface is thought of as being +-- attached to a `subnetwork'. Note that this term should +-- not be confused with `subnet' which refers to an +-- addressing partitioning scheme used in the Internet suite +-- of protocols. + +ifTable OBJECT-TYPE + SYNTAX SEQUENCE OF IfEntry + ACCESS not-accessible + STATUS mandatory + DESCRIPTION + "A list of interface entries. The number of + entries is given by the value of ifNumber." + ::= { interfaces 2 } + +ifEntry OBJECT-TYPE + SYNTAX IfEntry + ACCESS not-accessible + STATUS mandatory + DESCRIPTION + "An interface entry containing objects at the + subnetwork layer and below for a particular + interface." + INDEX { ifIndex } + ::= { ifTable 1 } + +IfEntry ::= + SEQUENCE { + ifIndex + INTEGER, + ifDescr + DisplayString, + ifType + INTEGER, + ifMtu + INTEGER, + ifSpeed + Gauge, + ifPhysAddress + PhysAddress, + ifAdminStatus + INTEGER, + ifOperStatus + INTEGER, + ifLastChange + TimeTicks, + ifInOctets + Counter, + ifInUcastPkts + Counter, + ifInNUcastPkts + Counter, + ifInDiscards + Counter, + ifInErrors + Counter, + ifInUnknownProtos + Counter, + ifOutOctets + Counter, + ifOutUcastPkts + Counter, + ifOutNUcastPkts + Counter, + ifOutDiscards + Counter, + ifOutErrors + Counter, + ifOutQLen + Gauge, + ifSpecific + OBJECT IDENTIFIER + } + +ifIndex OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "A unique value for each interface. Its value + ranges between 1 and the value of ifNumber. The + value for each interface must remain constant at + least from one re-initialization of the entity's + network management system to the next re- + initialization." + ::= { ifEntry 1 } + +ifDescr OBJECT-TYPE + SYNTAX DisplayString (SIZE (0..255)) + ACCESS read-only + STATUS mandatory + DESCRIPTION + "A textual string containing information about the + interface. This string should include the name of + the manufacturer, the product name and the version + of the hardware interface." + ::= { ifEntry 2 } + +ifType OBJECT-TYPE + SYNTAX INTEGER { + other(1), -- none of the following + regular1822(2), + hdh1822(3), + ddn-x25(4), + rfc877-x25(5), + ethernet-csmacd(6), + iso88023-csmacd(7), + iso88024-tokenBus(8), + iso88025-tokenRing(9), + iso88026-man(10), + starLan(11), + proteon-10Mbit(12), + proteon-80Mbit(13), + hyperchannel(14), + fddi(15), + lapb(16), + sdlc(17), + ds1(18), -- T-1 + e1(19), -- european equiv. of T-1 + basicISDN(20), + primaryISDN(21), -- proprietary serial + propPointToPointSerial(22), + ppp(23), + softwareLoopback(24), + eon(25), -- CLNP over IP [11] + ethernet-3Mbit(26), + nsip(27), -- XNS over IP + slip(28), -- generic SLIP + ultra(29), -- ULTRA technologies + ds3(30), -- T-3 + sip(31), -- SMDS + frame-relay(32) + } + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The type of interface, distinguished according to + the physical/link protocol(s) immediately `below' + the network layer in the protocol stack." + ::= { ifEntry 3 } + +ifMtu OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The size of the largest datagram which can be + sent/received on the interface, specified in + octets. For interfaces that are used for + transmitting network datagrams, this is the size + of the largest network datagram that can be sent + on the interface." + ::= { ifEntry 4 } + +ifSpeed OBJECT-TYPE + SYNTAX Gauge + ACCESS read-only + STATUS mandatory + DESCRIPTION + "An estimate of the interface's current bandwidth + in bits per second. For interfaces which do not + vary in bandwidth or for those where no accurate + estimation can be made, this object should contain + the nominal bandwidth." + ::= { ifEntry 5 } + +ifPhysAddress OBJECT-TYPE + SYNTAX PhysAddress + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The interface's address at the protocol layer + immediately `below' the network layer in the + protocol stack. For interfaces which do not have + such an address (e.g., a serial line), this object + should contain an octet string of zero length." + ::= { ifEntry 6 } + +ifAdminStatus OBJECT-TYPE + SYNTAX INTEGER { + up(1), -- ready to pass packets + down(2), + testing(3) -- in some test mode + } + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The desired state of the interface. The + testing(3) state indicates that no operational + packets can be passed." + ::= { ifEntry 7 } + +ifOperStatus OBJECT-TYPE + SYNTAX INTEGER { + up(1), -- ready to pass packets + down(2), + testing(3) -- in some test mode + } + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The current operational state of the interface. + The testing(3) state indicates that no operational + packets can be passed." + ::= { ifEntry 8 } + +ifLastChange OBJECT-TYPE + SYNTAX TimeTicks + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The value of sysUpTime at the time the interface + entered its current operational state. If the + current state was entered prior to the last re- + initialization of the local network management + subsystem, then this object contains a zero + value." + ::= { ifEntry 9 } + +ifInOctets OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of octets received on the + interface, including framing characters." + ::= { ifEntry 10 } + +ifInUcastPkts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of subnetwork-unicast packets + delivered to a higher-layer protocol." + ::= { ifEntry 11 } + +ifInNUcastPkts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of non-unicast (i.e., subnetwork- + broadcast or subnetwork-multicast) packets + delivered to a higher-layer protocol." + ::= { ifEntry 12 } + +ifInDiscards OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of inbound packets which were chosen + to be discarded even though no errors had been + detected to prevent their being deliverable to a + higher-layer protocol. One possible reason for + discarding such a packet could be to free up + buffer space." + ::= { ifEntry 13 } + +ifInErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of inbound packets that contained + errors preventing them from being deliverable to a + higher-layer protocol." + ::= { ifEntry 14 } + +ifInUnknownProtos OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of packets received via the interface + which were discarded because of an unknown or + unsupported protocol." + ::= { ifEntry 15 } + +ifOutOctets OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of octets transmitted out of the + interface, including framing characters." + ::= { ifEntry 16 } + +ifOutUcastPkts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of packets that higher-level + protocols requested be transmitted to a + subnetwork-unicast address, including those that + were discarded or not sent." + ::= { ifEntry 17 } + +ifOutNUcastPkts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of packets that higher-level + protocols requested be transmitted to a non- + unicast (i.e., a subnetwork-broadcast or + subnetwork-multicast) address, including those + that were discarded or not sent." + ::= { ifEntry 18 } + +ifOutDiscards OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of outbound packets which were chosen + to be discarded even though no errors had been + detected to prevent their being transmitted. One + possible reason for discarding such a packet could + be to free up buffer space." + ::= { ifEntry 19 } + +ifOutErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of outbound packets that could not be + transmitted because of errors." + ::= { ifEntry 20 } + +ifOutQLen OBJECT-TYPE + SYNTAX Gauge + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The length of the output packet queue (in + packets)." + ::= { ifEntry 21 } + +ifSpecific OBJECT-TYPE + SYNTAX OBJECT IDENTIFIER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "A reference to MIB definitions specific to the + particular media being used to realize the + interface. For example, if the interface is + realized by an ethernet, then the value of this + object refers to a document defining objects + specific to ethernet. If this information is not + present, its value should be set to the OBJECT + IDENTIFIER { 0 0 }, which is a syntatically valid + object identifier, and any conformant + implementation of ASN.1 and BER must be able to + generate and recognize this value." + ::= { ifEntry 22 } + + +-- the Address Translation group + +-- Implementation of the Address Translation group is +-- mandatory for all systems. Note however that this group +-- is deprecated by MIB-II. That is, it is being included + +-- solely for compatibility with MIB-I nodes, and will most +-- likely be excluded from MIB-III nodes. From MIB-II and +-- onwards, each network protocol group contains its own +-- address translation tables. + +-- The Address Translation group contains one table which is +-- the union across all interfaces of the translation tables +-- for converting a NetworkAddress (e.g., an IP address) into +-- a subnetwork-specific address. For lack of a better term, +-- this document refers to such a subnetwork-specific address +-- as a `physical' address. + +-- Examples of such translation tables are: for broadcast +-- media where ARP is in use, the translation table is +-- equivalent to the ARP cache; or, on an X.25 network where +-- non-algorithmic translation to X.121 addresses is +-- required, the translation table contains the +-- NetworkAddress to X.121 address equivalences. + +atTable OBJECT-TYPE + SYNTAX SEQUENCE OF AtEntry + ACCESS not-accessible + STATUS deprecated + DESCRIPTION + "The Address Translation tables contain the + NetworkAddress to `physical' address equivalences. + Some interfaces do not use translation tables for + determining address equivalences (e.g., DDN-X.25 + has an algorithmic method); if all interfaces are + of this type, then the Address Translation table + is empty, i.e., has zero entries." + ::= { at 1 } + +atEntry OBJECT-TYPE + SYNTAX AtEntry + ACCESS not-accessible + STATUS deprecated + DESCRIPTION + "Each entry contains one NetworkAddress to + `physical' address equivalence." + INDEX { atIfIndex, + atNetAddress } + ::= { atTable 1 } + +AtEntry ::= + SEQUENCE { + atIfIndex + INTEGER, + atPhysAddress + PhysAddress, + atNetAddress + NetworkAddress + } + +atIfIndex OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS deprecated + DESCRIPTION + "The interface on which this entry's equivalence + is effective. The interface identified by a + particular value of this index is the same + interface as identified by the same value of + ifIndex." + ::= { atEntry 1 } + +atPhysAddress OBJECT-TYPE + SYNTAX PhysAddress + ACCESS read-write + STATUS deprecated + DESCRIPTION + "The media-dependent `physical' address. + + Setting this object to a null string (one of zero + length) has the effect of invaliding the + corresponding entry in the atTable object. That + is, it effectively dissasociates the interface + identified with said entry from the mapping + identified with said entry. It is an + implementation-specific matter as to whether the + agent removes an invalidated entry from the table. + Accordingly, management stations must be prepared + to receive tabular information from agents that + corresponds to entries not currently in use. + Proper interpretation of such entries requires + examination of the relevant atPhysAddress object." + ::= { atEntry 2 } + +atNetAddress OBJECT-TYPE + SYNTAX NetworkAddress + ACCESS read-write + STATUS deprecated + DESCRIPTION + "The NetworkAddress (e.g., the IP address) + corresponding to the media-dependent `physical' + address." + ::= { atEntry 3 } + + +-- the IP group + +-- Implementation of the IP group is mandatory for all +-- systems. + +ipForwarding OBJECT-TYPE + SYNTAX INTEGER { + forwarding(1), -- acting as a gateway + not-forwarding(2) -- NOT acting as a gateway + } + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The indication of whether this entity is acting + as an IP gateway in respect to the forwarding of + datagrams received by, but not addressed to, this + entity. IP gateways forward datagrams. IP hosts + do not (except those source-routed via the host). + + Note that for some managed nodes, this object may + take on only a subset of the values possible. + Accordingly, it is appropriate for an agent to + return a `badValue' response if a management + station attempts to change this object to an + inappropriate value." + ::= { ip 1 } + +ipDefaultTTL OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The default value inserted into the Time-To-Live + field of the IP header of datagrams originated at + this entity, whenever a TTL value is not supplied + by the transport layer protocol." + ::= { ip 2 } + +ipInReceives OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of input datagrams received from + interfaces, including those received in error." + ::= { ip 3 } + +ipInHdrErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of input datagrams discarded due to + errors in their IP headers, including bad + checksums, version number mismatch, other format + errors, time-to-live exceeded, errors discovered + in processing their IP options, etc." + ::= { ip 4 } + +ipInAddrErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of input datagrams discarded because + the IP address in their IP header's destination + field was not a valid address to be received at + this entity. This count includes invalid + addresses (e.g., 0.0.0.0) and addresses of + unsupported Classes (e.g., Class E). For entities + which are not IP Gateways and therefore do not + forward datagrams, this counter includes datagrams + discarded because the destination address was not + a local address." + ::= { ip 5 } + +ipForwDatagrams OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of input datagrams for which this + entity was not their final IP destination, as a + result of which an attempt was made to find a + route to forward them to that final destination. + In entities which do not act as IP Gateways, this + counter will include only those packets which were + Source-Routed via this entity, and the Source- + Route option processing was successful." + ::= { ip 6 } + +ipInUnknownProtos OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of locally-addressed datagrams + received successfully but discarded because of an + unknown or unsupported protocol." + ::= { ip 7 } + +ipInDiscards OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of input IP datagrams for which no + problems were encountered to prevent their + continued processing, but which were discarded + (e.g., for lack of buffer space). Note that this + counter does not include any datagrams discarded + while awaiting re-assembly." + ::= { ip 8 } + +ipInDelivers OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of input datagrams successfully + delivered to IP user-protocols (including ICMP)." + ::= { ip 9 } + +ipOutRequests OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of IP datagrams which local IP + user-protocols (including ICMP) supplied to IP in + requests for transmission. Note that this counter + does not include any datagrams counted in + ipForwDatagrams." + ::= { ip 10 } + +ipOutDiscards OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of output IP datagrams for which no + problem was encountered to prevent their + transmission to their destination, but which were + discarded (e.g., for lack of buffer space). Note + that this counter would include datagrams counted + in ipForwDatagrams if any such packets met this + (discretionary) discard criterion." + ::= { ip 11 } + +ipOutNoRoutes OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of IP datagrams discarded because no + route could be found to transmit them to their + destination. Note that this counter includes any + packets counted in ipForwDatagrams which meet this + `no-route' criterion. Note that this includes any + datagarms which a host cannot route because all of + its default gateways are down." + ::= { ip 12 } + +ipReasmTimeout OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The maximum number of seconds which received + fragments are held while they are awaiting + reassembly at this entity." + ::= { ip 13 } + +ipReasmReqds OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of IP fragments received which needed + to be reassembled at this entity." + ::= { ip 14 } + +ipReasmOKs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of IP datagrams successfully re- + assembled." + ::= { ip 15 } + +ipReasmFails OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of failures detected by the IP re- + assembly algorithm (for whatever reason: timed + out, errors, etc). Note that this is not + necessarily a count of discarded IP fragments + since some algorithms (notably the algorithm in + RFC 815) can lose track of the number of fragments + by combining them as they are received." + ::= { ip 16 } + +ipFragOKs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of IP datagrams that have been + successfully fragmented at this entity." + ::= { ip 17 } + +ipFragFails OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of IP datagrams that have been + discarded because they needed to be fragmented at + this entity but could not be, e.g., because their + Don't Fragment flag was set." + ::= { ip 18 } + +ipFragCreates OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of IP datagram fragments that have + been generated as a result of fragmentation at + this entity." + ::= { ip 19 } + +-- the IP address table + +-- The IP address table contains this entity's IP addressing +-- information. + +ipAddrTable OBJECT-TYPE + SYNTAX SEQUENCE OF IpAddrEntry + ACCESS not-accessible + STATUS mandatory + DESCRIPTION + "The table of addressing information relevant to + this entity's IP addresses." + ::= { ip 20 } + +ipAddrEntry OBJECT-TYPE + SYNTAX IpAddrEntry + ACCESS not-accessible + STATUS mandatory + DESCRIPTION + "The addressing information for one of this + entity's IP addresses." + INDEX { ipAdEntAddr } + ::= { ipAddrTable 1 } + +IpAddrEntry ::= + SEQUENCE { + ipAdEntAddr + IpAddress, + ipAdEntIfIndex + INTEGER, + ipAdEntNetMask + IpAddress, + ipAdEntBcastAddr + INTEGER, + ipAdEntReasmMaxSize + INTEGER (0..65535) + } + +ipAdEntAddr OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The IP address to which this entry's addressing + information pertains." + ::= { ipAddrEntry 1 } + +ipAdEntIfIndex OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The index value which uniquely identifies the + interface to which this entry is applicable. The + interface identified by a particular value of this + index is the same interface as identified by the + same value of ifIndex." + ::= { ipAddrEntry 2 } + +ipAdEntNetMask OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The subnet mask associated with the IP address of + this entry. The value of the mask is an IP + address with all the network bits set to 1 and all + the hosts bits set to 0." + ::= { ipAddrEntry 3 } + +ipAdEntBcastAddr OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The value of the least-significant bit in the IP + broadcast address used for sending datagrams on + the (logical) interface associated with the IP + address of this entry. For example, when the + Internet standard all-ones broadcast address is + used, the value will be 1. This value applies to + both the subnet and network broadcasts addresses + used by the entity on this (logical) interface." + ::= { ipAddrEntry 4 } + +ipAdEntReasmMaxSize OBJECT-TYPE + SYNTAX INTEGER (0..65535) + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The size of the largest IP datagram which this + entity can re-assemble from incoming IP fragmented + datagrams received on this interface." + ::= { ipAddrEntry 5 } + +-- the IP routing table + +-- The IP routing table contains an entry for each route +-- presently known to this entity. + +ipRouteTable OBJECT-TYPE + SYNTAX SEQUENCE OF IpRouteEntry + ACCESS not-accessible + STATUS mandatory + DESCRIPTION + "This entity's IP Routing table." + ::= { ip 21 } + +ipRouteEntry OBJECT-TYPE + SYNTAX IpRouteEntry + ACCESS not-accessible + STATUS mandatory + DESCRIPTION + "A route to a particular destination." + INDEX { ipRouteDest } + ::= { ipRouteTable 1 } + +IpRouteEntry ::= + SEQUENCE { + ipRouteDest + IpAddress, + ipRouteIfIndex + INTEGER, + ipRouteMetric1 + INTEGER, + ipRouteMetric2 + INTEGER, + ipRouteMetric3 + INTEGER, + ipRouteMetric4 + INTEGER, + ipRouteNextHop + IpAddress, + ipRouteType + INTEGER, + ipRouteProto + INTEGER, + ipRouteAge + INTEGER, + ipRouteMask + IpAddress, + ipRouteMetric5 + INTEGER, + ipRouteInfo + OBJECT IDENTIFIER + } + +ipRouteDest OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The destination IP address of this route. An + entry with a value of 0.0.0.0 is considered a + default route. Multiple routes to a single + destination can appear in the table, but access to + such multiple entries is dependent on the table- + access mechanisms defined by the network + management protocol in use." + ::= { ipRouteEntry 1 } + +ipRouteIfIndex OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The index value which uniquely identifies the + local interface through which the next hop of this + route should be reached. The interface identified + by a particular value of this index is the same + interface as identified by the same value of + ifIndex." + ::= { ipRouteEntry 2 } + +ipRouteMetric1 OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The primary routing metric for this route. The + semantics of this metric are determined by the + routing-protocol specified in the route's + ipRouteProto value. If this metric is not used, + its value should be set to -1." + ::= { ipRouteEntry 3 } + +ipRouteMetric2 OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + DESCRIPTION + "An alternate routing metric for this route. The + semantics of this metric are determined by the + routing-protocol specified in the route's + ipRouteProto value. If this metric is not used, + its value should be set to -1." + ::= { ipRouteEntry 4 } + +ipRouteMetric3 OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + DESCRIPTION + "An alternate routing metric for this route. The + semantics of this metric are determined by the + routing-protocol specified in the route's + ipRouteProto value. If this metric is not used, + its value should be set to -1." + ::= { ipRouteEntry 5 } + +ipRouteMetric4 OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + DESCRIPTION + "An alternate routing metric for this route. The + semantics of this metric are determined by the + routing-protocol specified in the route's + ipRouteProto value. If this metric is not used, + its value should be set to -1." + ::= { ipRouteEntry 6 } + +ipRouteNextHop OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The IP address of the next hop of this route. + (In the case of a route bound to an interface + which is realized via a broadcast media, the value + of this field is the agent's IP address on that + interface.)" + ::= { ipRouteEntry 7 } + +ipRouteType OBJECT-TYPE + SYNTAX INTEGER { + other(1), -- none of the following + + invalid(2), -- an invalidated route + + -- route to directly + direct(3), -- connected (sub-)network + + -- route to a non-local + indirect(4) -- host/network/sub-network + } + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The type of route. Note that the values + direct(3) and indirect(4) refer to the notion of + direct and indirect routing in the IP + architecture. + + Setting this object to the value invalid(2) has + the effect of invalidating the corresponding entry + in the ipRouteTable object. That is, it + effectively dissasociates the destination + identified with said entry from the route + identified with said entry. It is an + implementation-specific matter as to whether the + agent removes an invalidated entry from the table. + Accordingly, management stations must be prepared + to receive tabular information from agents that + corresponds to entries not currently in use. + Proper interpretation of such entries requires + examination of the relevant ipRouteType object." + ::= { ipRouteEntry 8 } + +ipRouteProto OBJECT-TYPE + SYNTAX INTEGER { + other(1), -- none of the following + + -- non-protocol information, + -- e.g., manually configured + local(2), -- entries + + -- set via a network + netmgmt(3), -- management protocol + + -- obtained via ICMP, + icmp(4), -- e.g., Redirect + + -- the remaining values are + -- all gateway routing + -- protocols + egp(5), + ggp(6), + hello(7), + rip(8), + is-is(9), + es-is(10), + ciscoIgrp(11), + bbnSpfIgp(12), + ospf(13), + bgp(14) + } + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The routing mechanism via which this route was + learned. Inclusion of values for gateway routing + protocols is not intended to imply that hosts + should support those protocols." + ::= { ipRouteEntry 9 } + +ipRouteAge OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The number of seconds since this route was last + updated or otherwise determined to be correct. + Note that no semantics of `too old' can be implied + except through knowledge of the routing protocol + by which the route was learned." + ::= { ipRouteEntry 10 } + +ipRouteMask OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-write + STATUS mandatory + DESCRIPTION + "Indicate the mask to be logical-ANDed with the + destination address before being compared to the + value in the ipRouteDest field. For those systems + that do not support arbitrary subnet masks, an + agent constructs the value of the ipRouteMask by + determining whether the value of the correspondent + ipRouteDest field belong to a class-A, B, or C + network, and then using one of: + + mask network + 255.0.0.0 class-A + 255.255.0.0 class-B + 255.255.255.0 class-C + If the value of the ipRouteDest is 0.0.0.0 (a + default route), then the mask value is also + 0.0.0.0. It should be noted that all IP routing + subsystems implicitly use this mechanism." + ::= { ipRouteEntry 11 } + +ipRouteMetric5 OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + DESCRIPTION + "An alternate routing metric for this route. The + semantics of this metric are determined by the + routing-protocol specified in the route's + ipRouteProto value. If this metric is not used, + its value should be set to -1." + ::= { ipRouteEntry 12 } + +ipRouteInfo OBJECT-TYPE + SYNTAX OBJECT IDENTIFIER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "A reference to MIB definitions specific to the + particular routing protocol which is responsible + for this route, as determined by the value + specified in the route's ipRouteProto value. If + this information is not present, its value should + be set to the OBJECT IDENTIFIER { 0 0 }, which is + a syntatically valid object identifier, and any + conformant implementation of ASN.1 and BER must be + able to generate and recognize this value." + ::= { ipRouteEntry 13 } + + +-- the IP Address Translation table + +-- The IP address translation table contain the IpAddress to +-- `physical' address equivalences. Some interfaces do not +-- use translation tables for determining address +-- equivalences (e.g., DDN-X.25 has an algorithmic method); +-- if all interfaces are of this type, then the Address +-- Translation table is empty, i.e., has zero entries. + +ipNetToMediaTable OBJECT-TYPE + SYNTAX SEQUENCE OF IpNetToMediaEntry + ACCESS not-accessible + STATUS mandatory + DESCRIPTION + "The IP Address Translation table used for mapping + from IP addresses to physical addresses." + ::= { ip 22 } + +ipNetToMediaEntry OBJECT-TYPE + SYNTAX IpNetToMediaEntry + ACCESS not-accessible + STATUS mandatory + DESCRIPTION + "Each entry contains one IpAddress to `physical' + address equivalence." + INDEX { ipNetToMediaIfIndex, + ipNetToMediaNetAddress } + ::= { ipNetToMediaTable 1 } + +IpNetToMediaEntry ::= + SEQUENCE { + ipNetToMediaIfIndex + INTEGER, + ipNetToMediaPhysAddress + PhysAddress, + ipNetToMediaNetAddress + IpAddress, + ipNetToMediaType + INTEGER + } + +ipNetToMediaIfIndex OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The interface on which this entry's equivalence + is effective. The interface identified by a + particular value of this index is the same + interface as identified by the same value of + ifIndex." + ::= { ipNetToMediaEntry 1 } + +ipNetToMediaPhysAddress OBJECT-TYPE + SYNTAX PhysAddress + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The media-dependent `physical' address." + ::= { ipNetToMediaEntry 2 } + +ipNetToMediaNetAddress OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The IpAddress corresponding to the media- + dependent `physical' address." + ::= { ipNetToMediaEntry 3 } + +ipNetToMediaType OBJECT-TYPE + SYNTAX INTEGER { + other(1), -- none of the following + invalid(2), -- an invalidated mapping + dynamic(3), + static(4) + } + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The type of mapping. + + Setting this object to the value invalid(2) has + the effect of invalidating the corresponding entry + in the ipNetToMediaTable. That is, it effectively + dissasociates the interface identified with said + entry from the mapping identified with said entry. + It is an implementation-specific matter as to + whether the agent removes an invalidated entry + from the table. Accordingly, management stations + must be prepared to receive tabular information + from agents that corresponds to entries not + currently in use. Proper interpretation of such + entries requires examination of the relevant + ipNetToMediaType object." + ::= { ipNetToMediaEntry 4 } + + +-- additional IP objects + +ipRoutingDiscards OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of routing entries which were chosen + to be discarded even though they are valid. One + possible reason for discarding such an entry could + be to free-up buffer space for other routing + entries." + ::= { ip 23 } + + +-- the ICMP group + +-- Implementation of the ICMP group is mandatory for all +-- systems. + +icmpInMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of ICMP messages which the + entity received. Note that this counter includes + all those counted by icmpInErrors." + ::= { icmp 1 } + +icmpInErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP messages which the entity + received but determined as having ICMP-specific + errors (bad ICMP checksums, bad length, etc.)." + ::= { icmp 2 } + +icmpInDestUnreachs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Destination Unreachable + messages received." + ::= { icmp 3 } + +icmpInTimeExcds OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Time Exceeded messages + received." + ::= { icmp 4 } + +icmpInParmProbs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Parameter Problem messages + received." + ::= { icmp 5 } + +icmpInSrcQuenchs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Source Quench messages + received." + ::= { icmp 6 } + +icmpInRedirects OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Redirect messages received." + ::= { icmp 7 } + +icmpInEchos OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Echo (request) messages + received." + ::= { icmp 8 } + +icmpInEchoReps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Echo Reply messages received." + ::= { icmp 9 } + +icmpInTimestamps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Timestamp (request) messages + received." + ::= { icmp 10 } + +icmpInTimestampReps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Timestamp Reply messages + received." + ::= { icmp 11 } + +icmpInAddrMasks OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Address Mask Request messages + received." + ::= { icmp 12 } + +icmpInAddrMaskReps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Address Mask Reply messages + received." + ::= { icmp 13 } + +icmpOutMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of ICMP messages which this + entity attempted to send. Note that this counter + includes all those counted by icmpOutErrors." + ::= { icmp 14 } + +icmpOutErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP messages which this entity did + not send due to problems discovered within ICMP + such as a lack of buffers. This value should not + include errors discovered outside the ICMP layer + such as the inability of IP to route the resultant + datagram. In some implementations there may be no + types of error which contribute to this counter's + value." + ::= { icmp 15 } + +icmpOutDestUnreachs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Destination Unreachable + messages sent." + ::= { icmp 16 } + +icmpOutTimeExcds OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Time Exceeded messages sent." + ::= { icmp 17 } + +icmpOutParmProbs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Parameter Problem messages + sent." + ::= { icmp 18 } + +icmpOutSrcQuenchs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Source Quench messages sent." + ::= { icmp 19 } + +icmpOutRedirects OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Redirect messages sent. For a + host, this object will always be zero, since hosts + do not send redirects." + ::= { icmp 20 } + +icmpOutEchos OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Echo (request) messages sent." + ::= { icmp 21 } + +icmpOutEchoReps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Echo Reply messages sent." + ::= { icmp 22 } + +icmpOutTimestamps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Timestamp (request) messages + sent." + ::= { icmp 23 } + +icmpOutTimestampReps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Timestamp Reply messages + sent." + ::= { icmp 24 } + +icmpOutAddrMasks OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Address Mask Request messages + sent." + ::= { icmp 25 } + +icmpOutAddrMaskReps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of ICMP Address Mask Reply messages + sent." + ::= { icmp 26 } + + +-- the TCP group + +-- Implementation of the TCP group is mandatory for all +-- systems that implement the TCP. + +-- Note that instances of object types that represent +-- information about a particular TCP connection are +-- transient; they persist only as long as the connection +-- in question. + +tcpRtoAlgorithm OBJECT-TYPE + SYNTAX INTEGER { + other(1), -- none of the following + + constant(2), -- a constant rto + rsre(3), -- MIL-STD-1778, Appendix B + vanj(4) -- Van Jacobson's algorithm [10] + } + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The algorithm used to determine the timeout value + used for retransmitting unacknowledged octets." + ::= { tcp 1 } + +tcpRtoMin OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The minimum value permitted by a TCP + implementation for the retransmission timeout, + measured in milliseconds. More refined semantics + for objects of this type depend upon the algorithm + used to determine the retransmission timeout. In + particular, when the timeout algorithm is rsre(3), + an object of this type has the semantics of the + LBOUND quantity described in RFC 793." + ::= { tcp 2 } + + +tcpRtoMax OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The maximum value permitted by a TCP + implementation for the retransmission timeout, + measured in milliseconds. More refined semantics + for objects of this type depend upon the algorithm + used to determine the retransmission timeout. In + particular, when the timeout algorithm is rsre(3), + an object of this type has the semantics of the + UBOUND quantity described in RFC 793." + ::= { tcp 3 } + +tcpMaxConn OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The limit on the total number of TCP connections + the entity can support. In entities where the + maximum number of connections is dynamic, this + object should contain the value -1." + ::= { tcp 4 } + +tcpActiveOpens OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of times TCP connections have made a + direct transition to the SYN-SENT state from the + CLOSED state." + ::= { tcp 5 } + +tcpPassiveOpens OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of times TCP connections have made a + direct transition to the SYN-RCVD state from the + LISTEN state." + ::= { tcp 6 } + +tcpAttemptFails OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of times TCP connections have made a + direct transition to the CLOSED state from either + the SYN-SENT state or the SYN-RCVD state, plus the + number of times TCP connections have made a direct + transition to the LISTEN state from the SYN-RCVD + state." + ::= { tcp 7 } + +tcpEstabResets OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of times TCP connections have made a + direct transition to the CLOSED state from either + the ESTABLISHED state or the CLOSE-WAIT state." + ::= { tcp 8 } + +tcpCurrEstab OBJECT-TYPE + SYNTAX Gauge + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of TCP connections for which the + current state is either ESTABLISHED or CLOSE- + WAIT." + ::= { tcp 9 } + +tcpInSegs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of segments received, including + those received in error. This count includes + segments received on currently established + connections." + ::= { tcp 10 } + +tcpOutSegs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of segments sent, including + those on current connections but excluding those + containing only retransmitted octets." + ::= { tcp 11 } + +tcpRetransSegs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of segments retransmitted - that + is, the number of TCP segments transmitted + containing one or more previously transmitted + octets." + ::= { tcp 12 } + + +-- the TCP Connection table + +-- The TCP connection table contains information about this +-- entity's existing TCP connections. + +tcpConnTable OBJECT-TYPE + SYNTAX SEQUENCE OF TcpConnEntry + ACCESS not-accessible + STATUS mandatory + DESCRIPTION + "A table containing TCP connection-specific + information." + ::= { tcp 13 } + +tcpConnEntry OBJECT-TYPE + SYNTAX TcpConnEntry + ACCESS not-accessible + STATUS mandatory + DESCRIPTION + "Information about a particular current TCP + connection. An object of this type is transient, + in that it ceases to exist when (or soon after) + the connection makes the transition to the CLOSED + state." + INDEX { tcpConnLocalAddress, + tcpConnLocalPort, + tcpConnRemAddress, + tcpConnRemPort } + ::= { tcpConnTable 1 } + +TcpConnEntry ::= + SEQUENCE { + tcpConnState + INTEGER, + tcpConnLocalAddress + IpAddress, + tcpConnLocalPort + INTEGER (0..65535), + tcpConnRemAddress + IpAddress, + tcpConnRemPort + INTEGER (0..65535) + } + +tcpConnState OBJECT-TYPE + SYNTAX INTEGER { + closed(1), + listen(2), + synSent(3), + synReceived(4), + established(5), + finWait1(6), + finWait2(7), + closeWait(8), + lastAck(9), + closing(10), + timeWait(11), + deleteTCB(12) + } + ACCESS read-write + STATUS mandatory + DESCRIPTION + "The state of this TCP connection. + + The only value which may be set by a management + station is deleteTCB(12). Accordingly, it is + appropriate for an agent to return a `badValue' + response if a management station attempts to set + this object to any other value. + + If a management station sets this object to the + value deleteTCB(12), then this has the effect of + deleting the TCB (as defined in RFC 793) of the + corresponding connection on the managed node, + resulting in immediate termination of the + connection. + + As an implementation-specific option, a RST + segment may be sent from the managed node to the + other TCP endpoint (note however that RST segments + are not sent reliably)." + ::= { tcpConnEntry 1 } + +tcpConnLocalAddress OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The local IP address for this TCP connection. In + the case of a connection in the listen state which + is willing to accept connections for any IP + interface associated with the node, the value + 0.0.0.0 is used." + ::= { tcpConnEntry 2 } + +tcpConnLocalPort OBJECT-TYPE + SYNTAX INTEGER (0..65535) + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The local port number for this TCP connection." + ::= { tcpConnEntry 3 } + +tcpConnRemAddress OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The remote IP address for this TCP connection." + ::= { tcpConnEntry 4 } + +tcpConnRemPort OBJECT-TYPE + SYNTAX INTEGER (0..65535) + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The remote port number for this TCP connection." + ::= { tcpConnEntry 5 } + + +-- additional TCP objects + +tcpInErrs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of segments received in error + (e.g., bad TCP checksums)." + ::= { tcp 14 } + +tcpOutRsts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of TCP segments sent containing the + RST flag." + ::= { tcp 15 } + + +-- the UDP group + +-- Implementation of the UDP group is mandatory for all +-- systems which implement the UDP. + +udpInDatagrams OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of UDP datagrams delivered to + UDP users." + ::= { udp 1 } + +udpNoPorts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of received UDP datagrams for + which there was no application at the destination + port." + ::= { udp 2 } + +udpInErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of received UDP datagrams that could + not be delivered for reasons other than the lack + of an application at the destination port." + ::= { udp 3 } + +udpOutDatagrams OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of UDP datagrams sent from this + entity." + ::= { udp 4 } + + +-- the UDP Listener table + +-- The UDP listener table contains information about this +-- entity's UDP end-points on which a local application is +-- currently accepting datagrams. + +udpTable OBJECT-TYPE + SYNTAX SEQUENCE OF UdpEntry + ACCESS not-accessible + STATUS mandatory + DESCRIPTION + "A table containing UDP listener information." + ::= { udp 5 } + +udpEntry OBJECT-TYPE + SYNTAX UdpEntry + ACCESS not-accessible + STATUS mandatory + DESCRIPTION + "Information about a particular current UDP + listener." + INDEX { udpLocalAddress, udpLocalPort } + ::= { udpTable 1 } + +UdpEntry ::= + SEQUENCE { + udpLocalAddress + IpAddress, + udpLocalPort + INTEGER (0..65535) + } + +udpLocalAddress OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The local IP address for this UDP listener. In + the case of a UDP listener which is willing to + accept datagrams for any IP interface associated + with the node, the value 0.0.0.0 is used." + ::= { udpEntry 1 } + +udpLocalPort OBJECT-TYPE + SYNTAX INTEGER (0..65535) + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The local port number for this UDP listener." + ::= { udpEntry 2 } + + +-- the EGP group + +-- Implementation of the EGP group is mandatory for all +-- systems which implement the EGP. + +egpInMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of EGP messages received without + error." + ::= { egp 1 } + +egpInErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of EGP messages received that proved + to be in error." + ::= { egp 2 } + +egpOutMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of locally generated EGP + messages." + ::= { egp 3 } + +egpOutErrors OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of locally generated EGP messages not + sent due to resource limitations within an EGP + entity." + ::= { egp 4 } + + +-- the EGP Neighbor table + +-- The EGP neighbor table contains information about this +-- entity's EGP neighbors. + +egpNeighTable OBJECT-TYPE + SYNTAX SEQUENCE OF EgpNeighEntry + ACCESS not-accessible + STATUS mandatory + DESCRIPTION + "The EGP neighbor table." + ::= { egp 5 } + +egpNeighEntry OBJECT-TYPE + SYNTAX EgpNeighEntry + ACCESS not-accessible + STATUS mandatory + DESCRIPTION + "Information about this entity's relationship with + a particular EGP neighbor." + INDEX { egpNeighAddr } + ::= { egpNeighTable 1 } + +EgpNeighEntry ::= + SEQUENCE { + egpNeighState + INTEGER, + egpNeighAddr + IpAddress, + egpNeighAs + INTEGER, + egpNeighInMsgs + Counter, + egpNeighInErrs + Counter, + egpNeighOutMsgs + Counter, + egpNeighOutErrs + Counter, + egpNeighInErrMsgs + Counter, + egpNeighOutErrMsgs + Counter, + egpNeighStateUps + Counter, + egpNeighStateDowns + Counter, + egpNeighIntervalHello + INTEGER, + egpNeighIntervalPoll + INTEGER, + egpNeighMode + INTEGER, + egpNeighEventTrigger + INTEGER + } + +egpNeighState OBJECT-TYPE + SYNTAX INTEGER { + idle(1), + acquisition(2), + down(3), + up(4), + cease(5) + } + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The EGP state of the local system with respect to + this entry's EGP neighbor. Each EGP state is + represented by a value that is one greater than + the numerical value associated with said state in + RFC 904." + ::= { egpNeighEntry 1 } + +egpNeighAddr OBJECT-TYPE + SYNTAX IpAddress + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The IP address of this entry's EGP neighbor." + ::= { egpNeighEntry 2 } + +egpNeighAs OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The autonomous system of this EGP peer. Zero + should be specified if the autonomous system + number of the neighbor is not yet known." + ::= { egpNeighEntry 3 } + +egpNeighInMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of EGP messages received without error + from this EGP peer." + ::= { egpNeighEntry 4 } + +egpNeighInErrs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of EGP messages received from this EGP + peer that proved to be in error (e.g., bad EGP + checksum)." + ::= { egpNeighEntry 5 } + +egpNeighOutMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of locally generated EGP messages to + this EGP peer." + ::= { egpNeighEntry 6 } + +egpNeighOutErrs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of locally generated EGP messages not + sent to this EGP peer due to resource limitations + within an EGP entity." + ::= { egpNeighEntry 7 } + +egpNeighInErrMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of EGP-defined error messages received + from this EGP peer." + ::= { egpNeighEntry 8 } + +egpNeighOutErrMsgs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of EGP-defined error messages sent to + this EGP peer." + ::= { egpNeighEntry 9 } + +egpNeighStateUps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of EGP state transitions to the UP + state with this EGP peer." + ::= { egpNeighEntry 10 } + +egpNeighStateDowns OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The number of EGP state transitions from the UP + state to any other state with this EGP peer." + ::= { egpNeighEntry 11 } + +egpNeighIntervalHello OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The interval between EGP Hello command + retransmissions (in hundredths of a second). This + represents the t1 timer as defined in RFC 904." + ::= { egpNeighEntry 12 } + +egpNeighIntervalPoll OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The interval between EGP poll command + retransmissions (in hundredths of a second). This + represents the t3 timer as defined in RFC 904." + ::= { egpNeighEntry 13 } + +egpNeighMode OBJECT-TYPE + SYNTAX INTEGER { active(1), passive(2) } + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The polling mode of this EGP entity, either + passive or active." + ::= { egpNeighEntry 14 } + +egpNeighEventTrigger OBJECT-TYPE + SYNTAX INTEGER { start(1), stop(2) } + ACCESS read-write + STATUS mandatory + DESCRIPTION + "A control variable used to trigger operator- + initiated Start and Stop events. When read, this + variable always returns the most recent value that + egpNeighEventTrigger was set to. If it has not + been set since the last initialization of the + network management subsystem on the node, it + returns a value of `stop'. + + When set, this variable causes a Start or Stop + event on the specified neighbor, as specified on + pages 8-10 of RFC 904. Briefly, a Start event + causes an Idle peer to begin neighbor acquisition + and a non-Idle peer to reinitiate neighbor + acquisition. A stop event causes a non-Idle peer + to return to the Idle state until a Start event + occurs, either via egpNeighEventTrigger or + otherwise." + ::= { egpNeighEntry 15 } + + +-- additional EGP objects + +egpAs OBJECT-TYPE + SYNTAX INTEGER + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The autonomous system number of this EGP entity." + ::= { egp 6 } + +-- the Transmission group + +-- Based on the transmission media underlying each interface +-- on a system, the corresponding portion of the Transmission +-- group is mandatory for that system. + +-- When Internet-standard definitions for managing +-- transmission media are defined, the transmission group is +-- used to provide a prefix for the names of those objects. + +-- Typically, such definitions reside in the experimental +-- portion of the MIB until they are "proven", then as a +-- part of the Internet standardization process, the +-- definitions are accordingly elevated and a new object +-- identifier, under the transmission group is defined. By +-- convention, the name assigned is: +-- +-- type OBJECT IDENTIFIER ::= { transmission number } +-- +-- where "type" is the symbolic value used for the media in +-- the ifType column of the ifTable object, and "number" is +-- the actual integer value corresponding to the symbol. + + +-- the SNMP group + +-- Implementation of the SNMP group is mandatory for all +-- systems which support an SNMP protocol entity. Some of +-- the objects defined below will be zero-valued in those +-- SNMP implementations that are optimized to support only +-- those functions specific to either a management agent or +-- a management station. In particular, it should be +-- observed that the objects below refer to an SNMP entity, +-- and there may be several SNMP entities residing on a +-- managed node (e.g., if the node is hosting acting as +-- a management station). + +snmpInPkts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of Messages delivered to the + SNMP entity from the transport service." + ::= { snmp 1 } + +snmpOutPkts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP Messages which were + passed from the SNMP protocol entity to the + transport service." + ::= { snmp 2 } + +snmpInBadVersions OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP Messages which were + delivered to the SNMP protocol entity and were for + an unsupported SNMP version." + ::= { snmp 3 } + +snmpInBadCommunityNames OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP Messages delivered to + the SNMP protocol entity which used a SNMP + community name not known to said entity." + ::= { snmp 4 } + +snmpInBadCommunityUses OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP Messages delivered to + the SNMP protocol entity which represented an SNMP + operation which was not allowed by the SNMP + community named in the Message." + ::= { snmp 5 } + +snmpInASNParseErrs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of ASN.1 or BER errors + encountered by the SNMP protocol entity when + decoding received SNMP Messages." + ::= { snmp 6 } + +-- { snmp 7 } is not used + +snmpInTooBigs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP PDUs which were + delivered to the SNMP protocol entity and for + which the value of the error-status field is + `tooBig'." + ::= { snmp 8 } + +snmpInNoSuchNames OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP PDUs which were + delivered to the SNMP protocol entity and for + which the value of the error-status field is + `noSuchName'." + ::= { snmp 9 } + +snmpInBadValues OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP PDUs which were + delivered to the SNMP protocol entity and for + which the value of the error-status field is + `badValue'." + ::= { snmp 10 } + +snmpInReadOnlys OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number valid SNMP PDUs which were + delivered to the SNMP protocol entity and for + which the value of the error-status field is + `readOnly'. It should be noted that it is a + protocol error to generate an SNMP PDU which + contains the value `readOnly' in the error-status + field, as such this object is provided as a means + of detecting incorrect implementations of the + SNMP." + ::= { snmp 11 } + +snmpInGenErrs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP PDUs which were + delivered to the SNMP protocol entity and for + which the value of the error-status field is + `genErr'." + ::= { snmp 12 } + +snmpInTotalReqVars OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of MIB objects which have been + retrieved successfully by the SNMP protocol entity + as the result of receiving valid SNMP Get-Request + and Get-Next PDUs." + ::= { snmp 13 } + +snmpInTotalSetVars OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of MIB objects which have been + altered successfully by the SNMP protocol entity + as the result of receiving valid SNMP Set-Request + PDUs." + ::= { snmp 14 } + +snmpInGetRequests OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP Get-Request PDUs which + have been accepted and processed by the SNMP + protocol entity." + ::= { snmp 15 } + +snmpInGetNexts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP Get-Next PDUs which have + been accepted and processed by the SNMP protocol + entity." + ::= { snmp 16 } + +snmpInSetRequests OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP Set-Request PDUs which + have been accepted and processed by the SNMP + protocol entity." + ::= { snmp 17 } + +snmpInGetResponses OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP Get-Response PDUs which + have been accepted and processed by the SNMP + protocol entity." + ::= { snmp 18 } + +snmpInTraps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP Trap PDUs which have + been accepted and processed by the SNMP protocol + entity." + ::= { snmp 19 } + +snmpOutTooBigs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP PDUs which were + generated by the SNMP protocol entity and for + which the value of the error-status field is + `tooBig.'" + ::= { snmp 20 } + +snmpOutNoSuchNames OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP PDUs which were + generated by the SNMP protocol entity and for + which the value of the error-status is + `noSuchName'." + ::= { snmp 21 } + +snmpOutBadValues OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP PDUs which were + generated by the SNMP protocol entity and for + which the value of the error-status field is + `badValue'." + ::= { snmp 22 } + +-- { snmp 23 } is not used + +snmpOutGenErrs OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP PDUs which were + generated by the SNMP protocol entity and for + which the value of the error-status field is + `genErr'." + ::= { snmp 24 } + +snmpOutGetRequests OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP Get-Request PDUs which + have been generated by the SNMP protocol entity." + ::= { snmp 25 } + +snmpOutGetNexts OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP Get-Next PDUs which have + been generated by the SNMP protocol entity." + ::= { snmp 26 } + +snmpOutSetRequests OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP Set-Request PDUs which + have been generated by the SNMP protocol entity." + ::= { snmp 27 } + +snmpOutGetResponses OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP Get-Response PDUs which + have been generated by the SNMP protocol entity." + ::= { snmp 28 } + +snmpOutTraps OBJECT-TYPE + SYNTAX Counter + ACCESS read-only + STATUS mandatory + DESCRIPTION + "The total number of SNMP Trap PDUs which have + been generated by the SNMP protocol entity." + ::= { snmp 29 } + +snmpEnableAuthenTraps OBJECT-TYPE + SYNTAX INTEGER { enabled(1), disabled(2) } + ACCESS read-write + STATUS mandatory + DESCRIPTION + "Indicates whether the SNMP agent process is + permitted to generate authentication-failure + traps. The value of this object overrides any + configuration information; as such, it provides a + means whereby all authentication-failure traps may + be disabled. + + Note that it is strongly recommended that this + object be stored in non-volatile memory so that it + remains constant between re-initializations of the + network management system." + ::= { snmp 30 } + +END diff --git a/contrib/apps/LwipMibCompiler/Mibs/SNMPv2-CONF b/contrib/apps/LwipMibCompiler/Mibs/SNMPv2-CONF new file mode 100644 index 00000000000..904dbbb29a0 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/SNMPv2-CONF @@ -0,0 +1,318 @@ +SNMPv2-CONF DEFINITIONS ::= BEGIN + +IMPORTS ObjectName, NotificationName, ObjectSyntax + FROM SNMPv2-SMI; + +-- definitions for conformance groups + +OBJECT-GROUP MACRO ::= +BEGIN + TYPE NOTATION ::= + ObjectsPart + "STATUS" Status + "DESCRIPTION" Text + ReferPart + + VALUE NOTATION ::= + value(VALUE OBJECT IDENTIFIER) + + ObjectsPart ::= + "OBJECTS" "{" Objects "}" + Objects ::= + Object + | Objects "," Object + Object ::= + value(ObjectName) + + Status ::= + "current" + | "deprecated" + | "obsolete" + + ReferPart ::= + "REFERENCE" Text + | empty + + -- a character string as defined in [2] + Text ::= value(IA5String) +END + +-- more definitions for conformance groups + +NOTIFICATION-GROUP MACRO ::= +BEGIN + TYPE NOTATION ::= + NotificationsPart + "STATUS" Status + "DESCRIPTION" Text + ReferPart + + VALUE NOTATION ::= + value(VALUE OBJECT IDENTIFIER) + + NotificationsPart ::= + "NOTIFICATIONS" "{" Notifications "}" + Notifications ::= + Notification + | Notifications "," Notification + Notification ::= + value(NotificationName) + + Status ::= + "current" + | "deprecated" + | "obsolete" + + ReferPart ::= + "REFERENCE" Text + | empty + + -- a character string as defined in [2] + Text ::= value(IA5String) +END + +-- definitions for compliance statements + +MODULE-COMPLIANCE MACRO ::= +BEGIN + TYPE NOTATION ::= + "STATUS" Status + "DESCRIPTION" Text + ReferPart + ModulePart + + VALUE NOTATION ::= + value(VALUE OBJECT IDENTIFIER) + + Status ::= + "current" + | "deprecated" + | "obsolete" + + ReferPart ::= + "REFERENCE" Text + | empty + + ModulePart ::= + Modules + Modules ::= + Module + | Modules Module + Module ::= + -- name of module -- + "MODULE" ModuleName + MandatoryPart + CompliancePart + + ModuleName ::= + -- identifier must start with uppercase letter + identifier ModuleIdentifier + -- must not be empty unless contained + -- in MIB Module + | empty + ModuleIdentifier ::= + value(OBJECT IDENTIFIER) + | empty + + MandatoryPart ::= + "MANDATORY-GROUPS" "{" Groups "}" + | empty + + Groups ::= + Group + | Groups "," Group + Group ::= + value(OBJECT IDENTIFIER) + + CompliancePart ::= + Compliances + | empty + + Compliances ::= + Compliance + | Compliances Compliance + Compliance ::= + ComplianceGroup + | Object + + ComplianceGroup ::= + "GROUP" value(OBJECT IDENTIFIER) + "DESCRIPTION" Text + + Object ::= + "OBJECT" value(ObjectName) + SyntaxPart + WriteSyntaxPart + AccessPart + "DESCRIPTION" Text + + -- must be a refinement for object's SYNTAX clause + SyntaxPart ::= "SYNTAX" Syntax + | empty + + -- must be a refinement for object's SYNTAX clause + WriteSyntaxPart ::= "WRITE-SYNTAX" Syntax + | empty + + Syntax ::= -- Must be one of the following: + -- a base type (or its refinement), + -- a textual convention (or its refinement), or + -- a BITS pseudo-type + type + | "BITS" "{" NamedBits "}" + + NamedBits ::= NamedBit + | NamedBits "," NamedBit + + NamedBit ::= identifier "(" number ")" -- number is nonnegative + + AccessPart ::= + "MIN-ACCESS" Access + | empty + Access ::= + "not-accessible" + | "accessible-for-notify" + | "read-only" + | "read-write" + | "read-create" + + -- a character string as defined in [2] + Text ::= value(IA5String) +END + +-- definitions for capabilities statements + +AGENT-CAPABILITIES MACRO ::= +BEGIN + TYPE NOTATION ::= + "PRODUCT-RELEASE" Text + "STATUS" Status + "DESCRIPTION" Text + ReferPart + ModulePart + + VALUE NOTATION ::= + value(VALUE OBJECT IDENTIFIER) + + Status ::= + "current" + | "obsolete" + + ReferPart ::= + "REFERENCE" Text + | empty + + ModulePart ::= + Modules + | empty + Modules ::= + Module + | Modules Module + Module ::= + -- name of module -- + "SUPPORTS" ModuleName + "INCLUDES" "{" Groups "}" + VariationPart + + ModuleName ::= + -- identifier must start with uppercase letter + identifier ModuleIdentifier + ModuleIdentifier ::= + value(OBJECT IDENTIFIER) + | empty + + Groups ::= + Group + | Groups "," Group + Group ::= + value(OBJECT IDENTIFIER) + + VariationPart ::= + Variations + | empty + Variations ::= + Variation + | Variations Variation + + Variation ::= + ObjectVariation + | NotificationVariation + + NotificationVariation ::= + "VARIATION" value(NotificationName) + AccessPart + "DESCRIPTION" Text + + ObjectVariation ::= + "VARIATION" value(ObjectName) + SyntaxPart + WriteSyntaxPart + AccessPart + CreationPart + DefValPart + "DESCRIPTION" Text + + -- must be a refinement for object's SYNTAX clause + SyntaxPart ::= "SYNTAX" Syntax + | empty + + WriteSyntaxPart ::= "WRITE-SYNTAX" Syntax + | empty + + Syntax ::= -- Must be one of the following: + -- a base type (or its refinement), + -- a textual convention (or its refinement), or + -- a BITS pseudo-type + type + | "BITS" "{" NamedBits "}" + + NamedBits ::= NamedBit + | NamedBits "," NamedBit + + NamedBit ::= identifier "(" number ")" -- number is nonnegative + + AccessPart ::= + "ACCESS" Access + | empty + + Access ::= + "not-implemented" + -- only "not-implemented" for notifications + | "accessible-for-notify" + | "read-only" + | "read-write" + | "read-create" + -- following is for backward-compatibility only + | "write-only" + + CreationPart ::= + "CREATION-REQUIRES" "{" Cells "}" + | empty + Cells ::= + Cell + | Cells "," Cell + Cell ::= + value(ObjectName) + + DefValPart ::= "DEFVAL" "{" Defvalue "}" + | empty + + Defvalue ::= -- must be valid for the object's syntax + -- in this macro's SYNTAX clause, if present, + -- or if not, in object's OBJECT-TYPE macro + value(ObjectSyntax) + | "{" BitsValue "}" + + BitsValue ::= BitNames + | empty + + BitNames ::= BitName + | BitNames "," BitName + + BitName ::= identifier + + -- a character string as defined in [2] + Text ::= value(IA5String) +END + +END diff --git a/contrib/apps/LwipMibCompiler/Mibs/SNMPv2-MIB b/contrib/apps/LwipMibCompiler/Mibs/SNMPv2-MIB new file mode 100644 index 00000000000..9494e42cbdc --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/SNMPv2-MIB @@ -0,0 +1,903 @@ +SNMPv2-MIB DEFINITIONS ::= BEGIN + +IMPORTS + MODULE-IDENTITY, OBJECT-TYPE, NOTIFICATION-TYPE, + TimeTicks, Counter32, snmpModules, mib-2 + FROM SNMPv2-SMI + DisplayString, TestAndIncr, TimeStamp + + + + FROM SNMPv2-TC + MODULE-COMPLIANCE, OBJECT-GROUP, NOTIFICATION-GROUP + FROM SNMPv2-CONF; + +snmpMIB MODULE-IDENTITY + LAST-UPDATED "200210160000Z" + ORGANIZATION "IETF SNMPv3 Working Group" + CONTACT-INFO + "WG-EMail: snmpv3@lists.tislabs.com + Subscribe: snmpv3-request@lists.tislabs.com + + Co-Chair: Russ Mundy + Network Associates Laboratories + postal: 15204 Omega Drive, Suite 300 + Rockville, MD 20850-4601 + USA + EMail: mundy@tislabs.com + phone: +1 301 947-7107 + + Co-Chair: David Harrington + Enterasys Networks + postal: 35 Industrial Way + P. O. Box 5005 + Rochester, NH 03866-5005 + USA + EMail: dbh@enterasys.com + phone: +1 603 337-2614 + + Editor: Randy Presuhn + BMC Software, Inc. + postal: 2141 North First Street + San Jose, CA 95131 + USA + EMail: randy_presuhn@bmc.com + phone: +1 408 546-1006" + DESCRIPTION + "The MIB module for SNMP entities. + + Copyright (C) The Internet Society (2002). This + version of this MIB module is part of RFC 3418; + see the RFC itself for full legal notices. + " + REVISION "200210160000Z" + DESCRIPTION + "This revision of this MIB module was published as + RFC 3418." + REVISION "199511090000Z" + DESCRIPTION + + + + "This revision of this MIB module was published as + RFC 1907." + REVISION "199304010000Z" + DESCRIPTION + "The initial revision of this MIB module was published + as RFC 1450." + ::= { snmpModules 1 } + +snmpMIBObjects OBJECT IDENTIFIER ::= { snmpMIB 1 } + +-- ::= { snmpMIBObjects 1 } this OID is obsolete +-- ::= { snmpMIBObjects 2 } this OID is obsolete +-- ::= { snmpMIBObjects 3 } this OID is obsolete + +-- the System group +-- +-- a collection of objects common to all managed systems. + +system OBJECT IDENTIFIER ::= { mib-2 1 } + +sysDescr OBJECT-TYPE + SYNTAX DisplayString (SIZE (0..255)) + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "A textual description of the entity. This value should + include the full name and version identification of + the system's hardware type, software operating-system, + and networking software." + ::= { system 1 } + +sysObjectID OBJECT-TYPE + SYNTAX OBJECT IDENTIFIER + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The vendor's authoritative identification of the + network management subsystem contained in the entity. + This value is allocated within the SMI enterprises + subtree (1.3.6.1.4.1) and provides an easy and + unambiguous means for determining `what kind of box' is + being managed. For example, if vendor `Flintstones, + Inc.' was assigned the subtree 1.3.6.1.4.1.424242, + it could assign the identifier 1.3.6.1.4.1.424242.1.1 + to its `Fred Router'." + ::= { system 2 } + +sysUpTime OBJECT-TYPE + + + + SYNTAX TimeTicks + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The time (in hundredths of a second) since the + network management portion of the system was last + re-initialized." + ::= { system 3 } + +sysContact OBJECT-TYPE + SYNTAX DisplayString (SIZE (0..255)) + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "The textual identification of the contact person for + this managed node, together with information on how + to contact this person. If no contact information is + known, the value is the zero-length string." + ::= { system 4 } + +sysName OBJECT-TYPE + SYNTAX DisplayString (SIZE (0..255)) + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "An administratively-assigned name for this managed + node. By convention, this is the node's fully-qualified + domain name. If the name is unknown, the value is + the zero-length string." + ::= { system 5 } + +sysLocation OBJECT-TYPE + SYNTAX DisplayString (SIZE (0..255)) + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "The physical location of this node (e.g., 'telephone + closet, 3rd floor'). If the location is unknown, the + value is the zero-length string." + ::= { system 6 } + +sysServices OBJECT-TYPE + SYNTAX INTEGER (0..127) + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "A value which indicates the set of services that this + entity may potentially offer. The value is a sum. + + + + This sum initially takes the value zero. Then, for + each layer, L, in the range 1 through 7, that this node + performs transactions for, 2 raised to (L - 1) is added + to the sum. For example, a node which performs only + routing functions would have a value of 4 (2^(3-1)). + In contrast, a node which is a host offering application + services would have a value of 72 (2^(4-1) + 2^(7-1)). + Note that in the context of the Internet suite of + protocols, values should be calculated accordingly: + + layer functionality + 1 physical (e.g., repeaters) + 2 datalink/subnetwork (e.g., bridges) + 3 internet (e.g., supports the IP) + 4 end-to-end (e.g., supports the TCP) + 7 applications (e.g., supports the SMTP) + + For systems including OSI protocols, layers 5 and 6 + may also be counted." + ::= { system 7 } + +-- object resource information +-- +-- a collection of objects which describe the SNMP entity's +-- (statically and dynamically configurable) support of +-- various MIB modules. + +sysORLastChange OBJECT-TYPE + SYNTAX TimeStamp + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The value of sysUpTime at the time of the most recent + change in state or value of any instance of sysORID." + ::= { system 8 } + +sysORTable OBJECT-TYPE + SYNTAX SEQUENCE OF SysOREntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The (conceptual) table listing the capabilities of + the local SNMP application acting as a command + responder with respect to various MIB modules. + SNMP entities having dynamically-configurable support + of MIB modules will have a dynamically-varying number + of conceptual rows." + ::= { system 9 } + + + +sysOREntry OBJECT-TYPE + SYNTAX SysOREntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "An entry (conceptual row) in the sysORTable." + INDEX { sysORIndex } + ::= { sysORTable 1 } + +SysOREntry ::= SEQUENCE { + sysORIndex INTEGER, + sysORID OBJECT IDENTIFIER, + sysORDescr DisplayString, + sysORUpTime TimeStamp +} + +sysORIndex OBJECT-TYPE + SYNTAX INTEGER (1..2147483647) + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The auxiliary variable used for identifying instances + of the columnar objects in the sysORTable." + ::= { sysOREntry 1 } + +sysORID OBJECT-TYPE + SYNTAX OBJECT IDENTIFIER + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "An authoritative identification of a capabilities + statement with respect to various MIB modules supported + by the local SNMP application acting as a command + responder." + ::= { sysOREntry 2 } + +sysORDescr OBJECT-TYPE + SYNTAX DisplayString + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "A textual description of the capabilities identified + by the corresponding instance of sysORID." + ::= { sysOREntry 3 } + +sysORUpTime OBJECT-TYPE + SYNTAX TimeStamp + MAX-ACCESS read-only + + + + STATUS current + DESCRIPTION + "The value of sysUpTime at the time this conceptual + row was last instantiated." + ::= { sysOREntry 4 } + + +-- the SNMP group +-- +-- a collection of objects providing basic instrumentation and +-- control of an SNMP entity. + +snmp OBJECT IDENTIFIER ::= { mib-2 11 } + +snmpInPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of messages delivered to the SNMP + entity from the transport service." + ::= { snmp 1 } + +snmpInBadVersions OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of SNMP messages which were delivered + to the SNMP entity and were for an unsupported SNMP + version." + ::= { snmp 3 } + +snmpInBadCommunityNames OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of community-based SNMP messages (for + example, SNMPv1) delivered to the SNMP entity which + used an SNMP community name not known to said entity. + Also, implementations which authenticate community-based + SNMP messages using check(s) in addition to matching + the community name (for example, by also checking + whether the message originated from a transport address + allowed to use a specified community name) MAY include + in this value the number of messages which failed the + additional check(s). It is strongly RECOMMENDED that + + + + the documentation for any security model which is used + to authenticate community-based SNMP messages specify + the precise conditions that contribute to this value." + ::= { snmp 4 } + +snmpInBadCommunityUses OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of community-based SNMP messages (for + example, SNMPv1) delivered to the SNMP entity which + represented an SNMP operation that was not allowed for + the SNMP community named in the message. The precise + conditions under which this counter is incremented + (if at all) depend on how the SNMP entity implements + its access control mechanism and how its applications + interact with that access control mechanism. It is + strongly RECOMMENDED that the documentation for any + access control mechanism which is used to control access + to and visibility of MIB instrumentation specify the + precise conditions that contribute to this value." + ::= { snmp 5 } + +snmpInASNParseErrs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of ASN.1 or BER errors encountered by + the SNMP entity when decoding received SNMP messages." + ::= { snmp 6 } + +snmpEnableAuthenTraps OBJECT-TYPE + SYNTAX INTEGER { enabled(1), disabled(2) } + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "Indicates whether the SNMP entity is permitted to + generate authenticationFailure traps. The value of this + object overrides any configuration information; as such, + it provides a means whereby all authenticationFailure + traps may be disabled. + + Note that it is strongly recommended that this object + be stored in non-volatile memory so that it remains + constant across re-initializations of the network + management system." + + + + ::= { snmp 30 } + +snmpSilentDrops OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of Confirmed Class PDUs (such as + GetRequest-PDUs, GetNextRequest-PDUs, + GetBulkRequest-PDUs, SetRequest-PDUs, and + InformRequest-PDUs) delivered to the SNMP entity which + were silently dropped because the size of a reply + containing an alternate Response Class PDU (such as a + Response-PDU) with an empty variable-bindings field + was greater than either a local constraint or the + maximum message size associated with the originator of + the request." + ::= { snmp 31 } + +snmpProxyDrops OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of Confirmed Class PDUs + (such as GetRequest-PDUs, GetNextRequest-PDUs, + GetBulkRequest-PDUs, SetRequest-PDUs, and + InformRequest-PDUs) delivered to the SNMP entity which + were silently dropped because the transmission of + the (possibly translated) message to a proxy target + failed in a manner (other than a time-out) such that + no Response Class PDU (such as a Response-PDU) could + be returned." + ::= { snmp 32 } + +-- information for notifications +-- +-- a collection of objects which allow the SNMP entity, when +-- supporting a notification originator application, +-- to be configured to generate SNMPv2-Trap-PDUs. + +snmpTrap OBJECT IDENTIFIER ::= { snmpMIBObjects 4 } + +snmpTrapOID OBJECT-TYPE + SYNTAX OBJECT IDENTIFIER + MAX-ACCESS accessible-for-notify + STATUS current + DESCRIPTION + + + + "The authoritative identification of the notification + currently being sent. This variable occurs as + the second varbind in every SNMPv2-Trap-PDU and + InformRequest-PDU." + ::= { snmpTrap 1 } + +-- ::= { snmpTrap 2 } this OID is obsolete + +snmpTrapEnterprise OBJECT-TYPE + SYNTAX OBJECT IDENTIFIER + MAX-ACCESS accessible-for-notify + STATUS current + DESCRIPTION + "The authoritative identification of the enterprise + associated with the trap currently being sent. When an + SNMP proxy agent is mapping an RFC1157 Trap-PDU + into a SNMPv2-Trap-PDU, this variable occurs as the + last varbind." + ::= { snmpTrap 3 } + +-- ::= { snmpTrap 4 } this OID is obsolete + + +-- well-known traps + +snmpTraps OBJECT IDENTIFIER ::= { snmpMIBObjects 5 } + +coldStart NOTIFICATION-TYPE + STATUS current + DESCRIPTION + "A coldStart trap signifies that the SNMP entity, + supporting a notification originator application, is + reinitializing itself and that its configuration may + have been altered." + ::= { snmpTraps 1 } + +warmStart NOTIFICATION-TYPE + STATUS current + DESCRIPTION + "A warmStart trap signifies that the SNMP entity, + supporting a notification originator application, + is reinitializing itself such that its configuration + is unaltered." + ::= { snmpTraps 2 } + +-- Note the linkDown NOTIFICATION-TYPE ::= { snmpTraps 3 } +-- and the linkUp NOTIFICATION-TYPE ::= { snmpTraps 4 } +-- are defined in RFC 2863 [RFC2863] + + + +authenticationFailure NOTIFICATION-TYPE + STATUS current + DESCRIPTION + "An authenticationFailure trap signifies that the SNMP + entity has received a protocol message that is not + properly authenticated. While all implementations + of SNMP entities MAY be capable of generating this + trap, the snmpEnableAuthenTraps object indicates + whether this trap will be generated." + ::= { snmpTraps 5 } + +-- Note the egpNeighborLoss notification is defined +-- as { snmpTraps 6 } in RFC 1213 + +-- the set group +-- +-- a collection of objects which allow several cooperating +-- command generator applications to coordinate their use of the +-- set operation. + +snmpSet OBJECT IDENTIFIER ::= { snmpMIBObjects 6 } + +snmpSetSerialNo OBJECT-TYPE + SYNTAX TestAndIncr + MAX-ACCESS read-write + STATUS current + DESCRIPTION + "An advisory lock used to allow several cooperating + command generator applications to coordinate their + use of the SNMP set operation. + + This object is used for coarse-grain coordination. + To achieve fine-grain coordination, one or more similar + objects might be defined within each MIB group, as + appropriate." + ::= { snmpSet 1 } + +-- conformance information + +snmpMIBConformance + OBJECT IDENTIFIER ::= { snmpMIB 2 } + +snmpMIBCompliances + OBJECT IDENTIFIER ::= { snmpMIBConformance 1 } +snmpMIBGroups OBJECT IDENTIFIER ::= { snmpMIBConformance 2 } + +-- compliance statements + + + + +-- ::= { snmpMIBCompliances 1 } this OID is obsolete +snmpBasicCompliance MODULE-COMPLIANCE + STATUS deprecated + DESCRIPTION + "The compliance statement for SNMPv2 entities which + implement the SNMPv2 MIB. + + This compliance statement is replaced by + snmpBasicComplianceRev2." + MODULE -- this module + MANDATORY-GROUPS { snmpGroup, snmpSetGroup, systemGroup, + snmpBasicNotificationsGroup } + + GROUP snmpCommunityGroup + DESCRIPTION + "This group is mandatory for SNMPv2 entities which + support community-based authentication." + + ::= { snmpMIBCompliances 2 } + +snmpBasicComplianceRev2 MODULE-COMPLIANCE + STATUS current + DESCRIPTION + "The compliance statement for SNMP entities which + implement this MIB module." + MODULE -- this module + MANDATORY-GROUPS { snmpGroup, snmpSetGroup, systemGroup, + snmpBasicNotificationsGroup } + + GROUP snmpCommunityGroup + DESCRIPTION + "This group is mandatory for SNMP entities which + support community-based authentication." + + GROUP snmpWarmStartNotificationGroup + DESCRIPTION + "This group is mandatory for an SNMP entity which + supports command responder applications, and is + able to reinitialize itself such that its + configuration is unaltered." + + ::= { snmpMIBCompliances 3 } + +-- units of conformance + +-- ::= { snmpMIBGroups 1 } this OID is obsolete +-- ::= { snmpMIBGroups 2 } this OID is obsolete +-- ::= { snmpMIBGroups 3 } this OID is obsolete + + + +-- ::= { snmpMIBGroups 4 } this OID is obsolete + +snmpGroup OBJECT-GROUP + OBJECTS { snmpInPkts, + snmpInBadVersions, + snmpInASNParseErrs, + snmpSilentDrops, + snmpProxyDrops, + snmpEnableAuthenTraps } + STATUS current + DESCRIPTION + "A collection of objects providing basic instrumentation + and control of an SNMP entity." + ::= { snmpMIBGroups 8 } + +snmpCommunityGroup OBJECT-GROUP + OBJECTS { snmpInBadCommunityNames, + snmpInBadCommunityUses } + STATUS current + DESCRIPTION + "A collection of objects providing basic instrumentation + of a SNMP entity which supports community-based + authentication." + ::= { snmpMIBGroups 9 } + +snmpSetGroup OBJECT-GROUP + OBJECTS { snmpSetSerialNo } + STATUS current + DESCRIPTION + "A collection of objects which allow several cooperating + command generator applications to coordinate their + use of the set operation." + ::= { snmpMIBGroups 5 } + +systemGroup OBJECT-GROUP + OBJECTS { sysDescr, sysObjectID, sysUpTime, + sysContact, sysName, sysLocation, + sysServices, + sysORLastChange, sysORID, + sysORUpTime, sysORDescr } + STATUS current + DESCRIPTION + "The system group defines objects which are common to all + managed systems." + ::= { snmpMIBGroups 6 } + +snmpBasicNotificationsGroup NOTIFICATION-GROUP + NOTIFICATIONS { coldStart, authenticationFailure } + + + + STATUS current + DESCRIPTION + "The basic notifications implemented by an SNMP entity + supporting command responder applications." + ::= { snmpMIBGroups 7 } + +snmpWarmStartNotificationGroup NOTIFICATION-GROUP + NOTIFICATIONS { warmStart } + STATUS current + DESCRIPTION + "An additional notification for an SNMP entity supporting + command responder applications, if it is able to reinitialize + itself such that its configuration is unaltered." + ::= { snmpMIBGroups 11 } + +snmpNotificationGroup OBJECT-GROUP + OBJECTS { snmpTrapOID, snmpTrapEnterprise } + STATUS current + DESCRIPTION + "These objects are required for entities + which support notification originator applications." + ::= { snmpMIBGroups 12 } + +-- definitions in RFC 1213 made obsolete by the inclusion of a +-- subset of the snmp group in this MIB + +snmpOutPkts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP Messages which were + passed from the SNMP protocol entity to the + transport service." + ::= { snmp 2 } + +-- { snmp 7 } is not used + +snmpInTooBigs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP PDUs which were + delivered to the SNMP protocol entity and for + which the value of the error-status field was + `tooBig'." + ::= { snmp 8 } + + + +snmpInNoSuchNames OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP PDUs which were + delivered to the SNMP protocol entity and for + which the value of the error-status field was + `noSuchName'." + ::= { snmp 9 } + +snmpInBadValues OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP PDUs which were + delivered to the SNMP protocol entity and for + which the value of the error-status field was + `badValue'." + ::= { snmp 10 } + +snmpInReadOnlys OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number valid SNMP PDUs which were delivered + to the SNMP protocol entity and for which the value + of the error-status field was `readOnly'. It should + be noted that it is a protocol error to generate an + SNMP PDU which contains the value `readOnly' in the + error-status field, as such this object is provided + as a means of detecting incorrect implementations of + the SNMP." + ::= { snmp 11 } + +snmpInGenErrs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP PDUs which were delivered + to the SNMP protocol entity and for which the value + of the error-status field was `genErr'." + ::= { snmp 12 } + +snmpInTotalReqVars OBJECT-TYPE + + + + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of MIB objects which have been + retrieved successfully by the SNMP protocol entity + as the result of receiving valid SNMP Get-Request + and Get-Next PDUs." + ::= { snmp 13 } + +snmpInTotalSetVars OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of MIB objects which have been + altered successfully by the SNMP protocol entity as + the result of receiving valid SNMP Set-Request PDUs." + ::= { snmp 14 } + +snmpInGetRequests OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP Get-Request PDUs which + have been accepted and processed by the SNMP + protocol entity." + ::= { snmp 15 } + +snmpInGetNexts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP Get-Next PDUs which have been + accepted and processed by the SNMP protocol entity." + ::= { snmp 16 } + +snmpInSetRequests OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP Set-Request PDUs which + have been accepted and processed by the SNMP protocol + entity." + ::= { snmp 17 } + + + +snmpInGetResponses OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP Get-Response PDUs which + have been accepted and processed by the SNMP protocol + entity." + ::= { snmp 18 } + +snmpInTraps OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP Trap PDUs which have been + accepted and processed by the SNMP protocol entity." + ::= { snmp 19 } + +snmpOutTooBigs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP PDUs which were generated + by the SNMP protocol entity and for which the value + of the error-status field was `tooBig.'" + ::= { snmp 20 } + +snmpOutNoSuchNames OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP PDUs which were generated + by the SNMP protocol entity and for which the value + of the error-status was `noSuchName'." + ::= { snmp 21 } + +snmpOutBadValues OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP PDUs which were generated + by the SNMP protocol entity and for which the value + of the error-status field was `badValue'." + ::= { snmp 22 } + + + +-- { snmp 23 } is not used + +snmpOutGenErrs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP PDUs which were generated + by the SNMP protocol entity and for which the value + of the error-status field was `genErr'." + ::= { snmp 24 } + +snmpOutGetRequests OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP Get-Request PDUs which + have been generated by the SNMP protocol entity." + ::= { snmp 25 } + +snmpOutGetNexts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP Get-Next PDUs which have + been generated by the SNMP protocol entity." + ::= { snmp 26 } + +snmpOutSetRequests OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP Set-Request PDUs which + have been generated by the SNMP protocol entity." + ::= { snmp 27 } + +snmpOutGetResponses OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP Get-Response PDUs which + have been generated by the SNMP protocol entity." + ::= { snmp 28 } + + + + +snmpOutTraps OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS obsolete + DESCRIPTION + "The total number of SNMP Trap PDUs which have + been generated by the SNMP protocol entity." + ::= { snmp 29 } + +snmpObsoleteGroup OBJECT-GROUP + OBJECTS { snmpOutPkts, snmpInTooBigs, snmpInNoSuchNames, + snmpInBadValues, snmpInReadOnlys, snmpInGenErrs, + snmpInTotalReqVars, snmpInTotalSetVars, + snmpInGetRequests, snmpInGetNexts, snmpInSetRequests, + snmpInGetResponses, snmpInTraps, snmpOutTooBigs, + snmpOutNoSuchNames, snmpOutBadValues, + snmpOutGenErrs, snmpOutGetRequests, snmpOutGetNexts, + snmpOutSetRequests, snmpOutGetResponses, snmpOutTraps + } + STATUS obsolete + DESCRIPTION + "A collection of objects from RFC 1213 made obsolete + by this MIB module." + ::= { snmpMIBGroups 10 } + +END diff --git a/contrib/apps/LwipMibCompiler/Mibs/SNMPv2-SMI b/contrib/apps/LwipMibCompiler/Mibs/SNMPv2-SMI new file mode 100644 index 00000000000..2132646cab0 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/SNMPv2-SMI @@ -0,0 +1,352 @@ +SNMPv2-SMI DEFINITIONS ::= BEGIN + + +-- the path to the root + +org OBJECT IDENTIFIER ::= { iso 3 } -- "iso" = 1 +dod OBJECT IDENTIFIER ::= { org 6 } +internet OBJECT IDENTIFIER ::= { dod 1 } + +directory OBJECT IDENTIFIER ::= { internet 1 } + +mgmt OBJECT IDENTIFIER ::= { internet 2 } +mib-2 OBJECT IDENTIFIER ::= { mgmt 1 } +transmission OBJECT IDENTIFIER ::= { mib-2 10 } + +experimental OBJECT IDENTIFIER ::= { internet 3 } + +private OBJECT IDENTIFIER ::= { internet 4 } +enterprises OBJECT IDENTIFIER ::= { private 1 } + +security OBJECT IDENTIFIER ::= { internet 5 } + +snmpV2 OBJECT IDENTIFIER ::= { internet 6 } + +-- transport domains +snmpDomains OBJECT IDENTIFIER ::= { snmpV2 1 } + +-- transport proxies +snmpProxys OBJECT IDENTIFIER ::= { snmpV2 2 } + +-- module identities +snmpModules OBJECT IDENTIFIER ::= { snmpV2 3 } + +-- Extended UTCTime, to allow dates with four-digit years +-- (Note that this definition of ExtUTCTime is not to be IMPORTed +-- by MIB modules.) +ExtUTCTime ::= OCTET STRING(SIZE(11 | 13)) + -- format is YYMMDDHHMMZ or YYYYMMDDHHMMZ + -- where: YY - last two digits of year (only years + -- between 1900-1999) + -- YYYY - last four digits of the year (any year) + -- MM - month (01 through 12) + -- DD - day of month (01 through 31) + -- HH - hours (00 through 23) + -- MM - minutes (00 through 59) + -- Z - denotes GMT (the ASCII character Z) + -- + -- For example, "9502192015Z" and "199502192015Z" represent + -- 8:15pm GMT on 19 February 1995. Years after 1999 must use + -- the four digit year format. Years 1900-1999 may use the + -- two or four digit format. + +-- definitions for information modules + +MODULE-IDENTITY MACRO ::= +BEGIN + TYPE NOTATION ::= + "LAST-UPDATED" value(Update ExtUTCTime) + "ORGANIZATION" Text + "CONTACT-INFO" Text + "DESCRIPTION" Text + RevisionPart + + VALUE NOTATION ::= + value(VALUE OBJECT IDENTIFIER) + + RevisionPart ::= + Revisions + | empty + Revisions ::= + Revision + | Revisions Revision + Revision ::= + "REVISION" value(Update ExtUTCTime) + "DESCRIPTION" Text + + -- a character string as defined in section 3.1.1 + Text ::= value(IA5String) +END + + +OBJECT-IDENTITY MACRO ::= +BEGIN + TYPE NOTATION ::= + "STATUS" Status + "DESCRIPTION" Text + ReferPart + + VALUE NOTATION ::= + value(VALUE OBJECT IDENTIFIER) + + Status ::= + "current" + | "deprecated" + | "obsolete" + + ReferPart ::= + "REFERENCE" Text + | empty + + -- a character string as defined in section 3.1.1 + Text ::= value(IA5String) +END + + +-- names of objects +-- (Note that these definitions of ObjectName and NotificationName +-- are not to be IMPORTed by MIB modules.) + +ObjectName ::= + OBJECT IDENTIFIER + +NotificationName ::= + OBJECT IDENTIFIER + +-- syntax of objects + +-- the "base types" defined here are: +-- 3 built-in ASN.1 types: INTEGER, OCTET STRING, OBJECT IDENTIFIER +-- 8 application-defined types: Integer32, IpAddress, Counter32, +-- Gauge32, Unsigned32, TimeTicks, Opaque, and Counter64 + +ObjectSyntax ::= + CHOICE { + simple + SimpleSyntax, + + -- note that SEQUENCEs for conceptual tables and + -- rows are not mentioned here... + + application-wide + ApplicationSyntax + } + +-- built-in ASN.1 types + +SimpleSyntax ::= + CHOICE { + -- INTEGERs with a more restrictive range + -- may also be used + integer-value -- includes Integer32 + INTEGER (-2147483648..2147483647), + + -- OCTET STRINGs with a more restrictive size + -- may also be used + string-value + OCTET STRING (SIZE (0..65535)), + + objectID-value + OBJECT IDENTIFIER + } + +-- indistinguishable from INTEGER, but never needs more than +-- 32-bits for a two's complement representation +Integer32 ::= + INTEGER (-2147483648..2147483647) + + +-- application-wide types + +ApplicationSyntax ::= + CHOICE { + ipAddress-value + IpAddress, + + counter-value + Counter32, + + timeticks-value + TimeTicks, + + arbitrary-value + Opaque, + + big-counter-value + Counter64, + + unsigned-integer-value -- includes Gauge32 + Unsigned32 + } + +-- in network-byte order +-- (this is a tagged type for historical reasons) +IpAddress ::= + [APPLICATION 0] + IMPLICIT OCTET STRING (SIZE (4)) + +-- this wraps +Counter32 ::= + [APPLICATION 1] + IMPLICIT INTEGER (0..4294967295) + +-- this doesn't wrap +Gauge32 ::= + [APPLICATION 2] + IMPLICIT INTEGER (0..4294967295) + +-- an unsigned 32-bit quantity +-- indistinguishable from Gauge32 +Unsigned32 ::= + [APPLICATION 2] + IMPLICIT INTEGER (0..4294967295) + +-- hundredths of seconds since an epoch +TimeTicks ::= + [APPLICATION 3] + IMPLICIT INTEGER (0..4294967295) + +-- for backward-compatibility only +Opaque ::= + [APPLICATION 4] + IMPLICIT OCTET STRING + +-- for counters that wrap in less than one hour with only 32 bits +Counter64 ::= + [APPLICATION 6] + IMPLICIT INTEGER (0..18446744073709551615) + + +-- definition for objects + +OBJECT-TYPE MACRO ::= +BEGIN + TYPE NOTATION ::= + "SYNTAX" Syntax + UnitsPart + "MAX-ACCESS" Access + "STATUS" Status + "DESCRIPTION" Text + ReferPart + IndexPart + DefValPart + + VALUE NOTATION ::= + value(VALUE ObjectName) + + Syntax ::= -- Must be one of the following: + -- a base type (or its refinement), + -- a textual convention (or its refinement), or + -- a BITS pseudo-type + type + | "BITS" "{" NamedBits "}" + + NamedBits ::= NamedBit + | NamedBits "," NamedBit + + NamedBit ::= identifier "(" number ")" -- number is nonnegative + + UnitsPart ::= + "UNITS" Text + | empty + + Access ::= + "not-accessible" + | "accessible-for-notify" + | "read-only" + | "read-write" + | "read-create" + + Status ::= + "current" + | "deprecated" + | "obsolete" + + ReferPart ::= + "REFERENCE" Text + | empty + + IndexPart ::= + "INDEX" "{" IndexTypes "}" + | "AUGMENTS" "{" Entry "}" + | empty + IndexTypes ::= + IndexType + | IndexTypes "," IndexType + IndexType ::= + "IMPLIED" Index + | Index + Index ::= + -- use the SYNTAX value of the + -- correspondent OBJECT-TYPE invocation + value(ObjectName) + Entry ::= + -- use the INDEX value of the + -- correspondent OBJECT-TYPE invocation + value(ObjectName) + + DefValPart ::= "DEFVAL" "{" Defvalue "}" + | empty + + Defvalue ::= -- must be valid for the type specified in + -- SYNTAX clause of same OBJECT-TYPE macro + value(ObjectSyntax) + | "{" BitsValue "}" + + BitsValue ::= BitNames + | empty + + BitNames ::= BitName + | BitNames "," BitName + + BitName ::= identifier + + -- a character string as defined in section 3.1.1 + Text ::= value(IA5String) +END + + +-- definitions for notifications + +NOTIFICATION-TYPE MACRO ::= +BEGIN + TYPE NOTATION ::= + ObjectsPart + "STATUS" Status + "DESCRIPTION" Text + ReferPart + + VALUE NOTATION ::= + value(VALUE NotificationName) + + ObjectsPart ::= + "OBJECTS" "{" Objects "}" + | empty + Objects ::= + Object + | Objects "," Object + Object ::= + value(ObjectName) + + Status ::= + "current" + | "deprecated" + | "obsolete" + + ReferPart ::= + "REFERENCE" Text + | empty + + -- a character string as defined in section 3.1.1 + Text ::= value(IA5String) +END + +-- definitions of administrative identifiers + +zeroDotZero OBJECT-IDENTITY + STATUS current + DESCRIPTION + "A value used for null identifiers." + ::= { 0 0 } + +END diff --git a/contrib/apps/LwipMibCompiler/Mibs/SNMPv2-TC b/contrib/apps/LwipMibCompiler/Mibs/SNMPv2-TC new file mode 100644 index 00000000000..a68f9690d19 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/SNMPv2-TC @@ -0,0 +1,786 @@ +SNMPv2-TC DEFINITIONS ::= BEGIN + +IMPORTS + TimeTicks FROM SNMPv2-SMI; + + +-- definition of textual conventions + +TEXTUAL-CONVENTION MACRO ::= +BEGIN + TYPE NOTATION ::= + DisplayPart + "STATUS" Status + "DESCRIPTION" Text + ReferPart + "SYNTAX" Syntax + + VALUE NOTATION ::= + value(VALUE Syntax) -- adapted ASN.1 + + DisplayPart ::= + "DISPLAY-HINT" Text + | empty + + Status ::= + "current" + | "deprecated" + | "obsolete" + + ReferPart ::= + "REFERENCE" Text + | empty + + -- a character string as defined in [2] + Text ::= value(IA5String) + + Syntax ::= -- Must be one of the following: + -- a base type (or its refinement), or + -- a BITS pseudo-type + type + | "BITS" "{" NamedBits "}" + + NamedBits ::= NamedBit + | NamedBits "," NamedBit + + NamedBit ::= identifier "(" number ")" -- number is nonnegative + +END + + + + +DisplayString ::= TEXTUAL-CONVENTION + DISPLAY-HINT "255a" + STATUS current + DESCRIPTION + "Represents textual information taken from the NVT ASCII + character set, as defined in pages 4, 10-11 of RFC 854. + + To summarize RFC 854, the NVT ASCII repertoire specifies: + + - the use of character codes 0-127 (decimal) + + - the graphics characters (32-126) are interpreted as + US ASCII + + - NUL, LF, CR, BEL, BS, HT, VT and FF have the special + meanings specified in RFC 854 + + - the other 25 codes have no standard interpretation + + - the sequence 'CR LF' means newline + + - the sequence 'CR NUL' means carriage-return + + - an 'LF' not preceded by a 'CR' means moving to the + same column on the next line. + + - the sequence 'CR x' for any x other than LF or NUL is + illegal. (Note that this also means that a string may + end with either 'CR LF' or 'CR NUL', but not with CR.) + + Any object defined using this syntax may not exceed 255 + characters in length." + SYNTAX OCTET STRING (SIZE (0..255)) + +PhysAddress ::= TEXTUAL-CONVENTION + DISPLAY-HINT "1x:" + STATUS current + DESCRIPTION + "Represents media- or physical-level addresses." + SYNTAX OCTET STRING + + +MacAddress ::= TEXTUAL-CONVENTION + DISPLAY-HINT "1x:" + STATUS current + DESCRIPTION + "Represents an 802 MAC address represented in the + `canonical' order defined by IEEE 802.1a, i.e., as if it + were transmitted least significant bit first, even though + 802.5 (in contrast to other 802.x protocols) requires MAC + addresses to be transmitted most significant bit first." + SYNTAX OCTET STRING (SIZE (6)) + +TruthValue ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "Represents a boolean value." + SYNTAX INTEGER { true(1), false(2) } + +TestAndIncr ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "Represents integer-valued information used for atomic + operations. When the management protocol is used to specify + that an object instance having this syntax is to be + modified, the new value supplied via the management protocol + must precisely match the value presently held by the + instance. If not, the management protocol set operation + fails with an error of `inconsistentValue'. Otherwise, if + the current value is the maximum value of 2^31-1 (2147483647 + decimal), then the value held by the instance is wrapped to + zero; otherwise, the value held by the instance is + incremented by one. (Note that regardless of whether the + management protocol set operation succeeds, the variable- + binding in the request and response PDUs are identical.) + + The value of the ACCESS clause for objects having this + syntax is either `read-write' or `read-create'. When an + instance of a columnar object having this syntax is created, + any value may be supplied via the management protocol. + + When the network management portion of the system is re- + initialized, the value of every object instance having this + syntax must either be incremented from its value prior to + the re-initialization, or (if the value prior to the re- + initialization is unknown) be set to a pseudo-randomly + generated value." + SYNTAX INTEGER (0..2147483647) + +AutonomousType ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "Represents an independently extensible type identification + value. It may, for example, indicate a particular sub-tree + with further MIB definitions, or define a particular type of + protocol or hardware." + SYNTAX OBJECT IDENTIFIER + + +InstancePointer ::= TEXTUAL-CONVENTION + STATUS obsolete + DESCRIPTION + "A pointer to either a specific instance of a MIB object or + a conceptual row of a MIB table in the managed device. In + the latter case, by convention, it is the name of the + particular instance of the first accessible columnar object + in the conceptual row. + + The two uses of this textual convention are replaced by + VariablePointer and RowPointer, respectively." + SYNTAX OBJECT IDENTIFIER + + +VariablePointer ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "A pointer to a specific object instance. For example, + sysContact.0 or ifInOctets.3." + SYNTAX OBJECT IDENTIFIER + + +RowPointer ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "Represents a pointer to a conceptual row. The value is the + name of the instance of the first accessible columnar object + in the conceptual row. + + For example, ifIndex.3 would point to the 3rd row in the + ifTable (note that if ifIndex were not-accessible, then + ifDescr.3 would be used instead)." + SYNTAX OBJECT IDENTIFIER + +RowStatus ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "The RowStatus textual convention is used to manage the + creation and deletion of conceptual rows, and is used as the + value of the SYNTAX clause for the status column of a + conceptual row (as described in Section 7.7.1 of [2].) + The status column has six defined values: + + - `active', which indicates that the conceptual row is + available for use by the managed device; + + - `notInService', which indicates that the conceptual + row exists in the agent, but is unavailable for use by + the managed device (see NOTE below); 'notInService' has + no implication regarding the internal consistency of + the row, availability of resources, or consistency with + the current state of the managed device; + + - `notReady', which indicates that the conceptual row + exists in the agent, but is missing information + necessary in order to be available for use by the + managed device (i.e., one or more required columns in + the conceptual row have not been instanciated); + + - `createAndGo', which is supplied by a management + station wishing to create a new instance of a + conceptual row and to have its status automatically set + to active, making it available for use by the managed + device; + + - `createAndWait', which is supplied by a management + station wishing to create a new instance of a + conceptual row (but not make it available for use by + the managed device); and, + + - `destroy', which is supplied by a management station + wishing to delete all of the instances associated with + an existing conceptual row. + + Whereas five of the six values (all except `notReady') may + be specified in a management protocol set operation, only + three values will be returned in response to a management + protocol retrieval operation: `notReady', `notInService' or + `active'. That is, when queried, an existing conceptual row + has only three states: it is either available for use by + the managed device (the status column has value `active'); + it is not available for use by the managed device, though + the agent has sufficient information to attempt to make it + so (the status column has value `notInService'); or, it is + not available for use by the managed device, and an attempt + to make it so would fail because the agent has insufficient + information (the state column has value `notReady'). + + NOTE WELL + + This textual convention may be used for a MIB table, + irrespective of whether the values of that table's + conceptual rows are able to be modified while it is + active, or whether its conceptual rows must be taken + out of service in order to be modified. That is, it is + the responsibility of the DESCRIPTION clause of the + status column to specify whether the status column must + not be `active' in order for the value of some other + column of the same conceptual row to be modified. If + such a specification is made, affected columns may be + changed by an SNMP set PDU if the RowStatus would not + be equal to `active' either immediately before or after + processing the PDU. In other words, if the PDU also + contained a varbind that would change the RowStatus + value, the column in question may be changed if the + RowStatus was not equal to `active' as the PDU was + received, or if the varbind sets the status to a value + other than 'active'. + + + Also note that whenever any elements of a row exist, the + RowStatus column must also exist. + + To summarize the effect of having a conceptual row with a + status column having a SYNTAX clause value of RowStatus, + consider the following state diagram: + + + STATE + +--------------+-----------+-------------+------------- + | A | B | C | D + | |status col.|status column| + |status column | is | is |status column + ACTION |does not exist| notReady | notInService| is active +--------------+--------------+-----------+-------------+------------- +set status |noError ->D|inconsist- |inconsistent-|inconsistent- +column to | or | entValue| Value| Value +createAndGo |inconsistent- | | | + | Value| | | +--------------+--------------+-----------+-------------+------------- +set status |noError see 1|inconsist- |inconsistent-|inconsistent- +column to | or | entValue| Value| Value +createAndWait |wrongValue | | | +--------------+--------------+-----------+-------------+------------- +set status |inconsistent- |inconsist- |noError |noError +column to | Value| entValue| | +active | | | | + | | or | | + | | | | + | |see 2 ->D|see 8 ->D| ->D +--------------+--------------+-----------+-------------+------------- +set status |inconsistent- |inconsist- |noError |noError ->C +column to | Value| entValue| | +notInService | | | | + | | or | | or + | | | | + | |see 3 ->C| ->C|see 6 +--------------+--------------+-----------+-------------+------------- +set status |noError |noError |noError |noError ->A +column to | | | | or +destroy | ->A| ->A| ->A|see 7 +--------------+--------------+-----------+-------------+------------- +set any other |see 4 |noError |noError |see 5 +column to some| | | | +value | | see 1| ->C| ->D +--------------+--------------+-----------+-------------+------------- + + (1) goto B or C, depending on information available to the + agent. + + (2) if other variable bindings included in the same PDU, + provide values for all columns which are missing but + required, and all columns have acceptable values, then + return noError and goto D. + + (3) if other variable bindings included in the same PDU, + provide legal values for all columns which are missing but + required, then return noError and goto C. + + (4) at the discretion of the agent, the return value may be + either: + + inconsistentName: because the agent does not choose to + create such an instance when the corresponding + RowStatus instance does not exist, or + + inconsistentValue: if the supplied value is + inconsistent with the state of some other MIB object's + value, or + + noError: because the agent chooses to create the + instance. + + If noError is returned, then the instance of the status + column must also be created, and the new state is B or C, + depending on the information available to the agent. If + inconsistentName or inconsistentValue is returned, the row + remains in state A. + + (5) depending on the MIB definition for the column/table, + either noError or inconsistentValue may be returned. + + (6) the return value can indicate one of the following + errors: + + wrongValue: because the agent does not support + notInService (e.g., an agent which does not support + createAndWait), or + + inconsistentValue: because the agent is unable to take + the row out of service at this time, perhaps because it + is in use and cannot be de-activated. + + (7) the return value can indicate the following error: + + inconsistentValue: because the agent is unable to + remove the row at this time, perhaps because it is in + use and cannot be de-activated. + + (8) the transition to D can fail, e.g., if the values of the + conceptual row are inconsistent, then the error code would + be inconsistentValue. + + NOTE: Other processing of (this and other varbinds of) the + set request may result in a response other than noError + being returned, e.g., wrongValue, noCreation, etc. + + + Conceptual Row Creation + + There are four potential interactions when creating a + conceptual row: selecting an instance-identifier which is + not in use; creating the conceptual row; initializing any + objects for which the agent does not supply a default; and, + making the conceptual row available for use by the managed + device. + + Interaction 1: Selecting an Instance-Identifier + + The algorithm used to select an instance-identifier varies + for each conceptual row. In some cases, the instance- + identifier is semantically significant, e.g., the + destination address of a route, and a management station + selects the instance-identifier according to the semantics. + + In other cases, the instance-identifier is used solely to + distinguish conceptual rows, and a management station + without specific knowledge of the conceptual row might + examine the instances present in order to determine an + unused instance-identifier. (This approach may be used, but + it is often highly sub-optimal; however, it is also a + questionable practice for a naive management station to + attempt conceptual row creation.) + + Alternately, the MIB module which defines the conceptual row + might provide one or more objects which provide assistance + in determining an unused instance-identifier. For example, + if the conceptual row is indexed by an integer-value, then + an object having an integer-valued SYNTAX clause might be + defined for such a purpose, allowing a management station to + issue a management protocol retrieval operation. In order + to avoid unnecessary collisions between competing management + stations, `adjacent' retrievals of this object should be + different. + + Finally, the management station could select a pseudo-random + number to use as the index. In the event that this index + was already in use and an inconsistentValue was returned in + response to the management protocol set operation, the + management station should simply select a new pseudo-random + number and retry the operation. + + A MIB designer should choose between the two latter + algorithms based on the size of the table (and therefore the + efficiency of each algorithm). For tables in which a large + number of entries are expected, it is recommended that a MIB + object be defined that returns an acceptable index for + creation. For tables with small numbers of entries, it is + recommended that the latter pseudo-random index mechanism be + used. + + Interaction 2: Creating the Conceptual Row + + Once an unused instance-identifier has been selected, the + management station determines if it wishes to create and + activate the conceptual row in one transaction or in a + negotiated set of interactions. + + Interaction 2a: Creating and Activating the Conceptual Row + + The management station must first determine the column + requirements, i.e., it must determine those columns for + which it must or must not provide values. Depending on the + complexity of the table and the management station's + knowledge of the agent's capabilities, this determination + can be made locally by the management station. Alternately, + the management station issues a management protocol get + operation to examine all columns in the conceptual row that + it wishes to create. In response, for each column, there + are three possible outcomes: + + - a value is returned, indicating that some other + management station has already created this conceptual + row. We return to interaction 1. + + - the exception `noSuchInstance' is returned, + indicating that the agent implements the object-type + associated with this column, and that this column in at + least one conceptual row would be accessible in the MIB + view used by the retrieval were it to exist. For those + columns to which the agent provides read-create access, + the `noSuchInstance' exception tells the management + station that it should supply a value for this column + when the conceptual row is to be created. + + - the exception `noSuchObject' is returned, indicating + that the agent does not implement the object-type + associated with this column or that there is no + conceptual row for which this column would be + accessible in the MIB view used by the retrieval. As + such, the management station can not issue any + management protocol set operations to create an + instance of this column. + + Once the column requirements have been determined, a + management protocol set operation is accordingly issued. + This operation also sets the new instance of the status + column to `createAndGo'. + + When the agent processes the set operation, it verifies that + it has sufficient information to make the conceptual row + available for use by the managed device. The information + available to the agent is provided by two sources: the + management protocol set operation which creates the + conceptual row, and, implementation-specific defaults + supplied by the agent (note that an agent must provide + implementation-specific defaults for at least those objects + which it implements as read-only). If there is sufficient + information available, then the conceptual row is created, a + `noError' response is returned, the status column is set to + `active', and no further interactions are necessary (i.e., + interactions 3 and 4 are skipped). If there is insufficient + information, then the conceptual row is not created, and the + set operation fails with an error of `inconsistentValue'. + On this error, the management station can issue a management + protocol retrieval operation to determine if this was + because it failed to specify a value for a required column, + or, because the selected instance of the status column + already existed. In the latter case, we return to + interaction 1. In the former case, the management station + can re-issue the set operation with the additional + information, or begin interaction 2 again using + `createAndWait' in order to negotiate creation of the + conceptual row. + + NOTE WELL + + Regardless of the method used to determine the column + requirements, it is possible that the management + station might deem a column necessary when, in fact, + the agent will not allow that particular columnar + instance to be created or written. In this case, the + management protocol set operation will fail with an + error such as `noCreation' or `notWritable'. In this + case, the management station decides whether it needs + to be able to set a value for that particular columnar + instance. If not, the management station re-issues the + management protocol set operation, but without setting + a value for that particular columnar instance; + otherwise, the management station aborts the row + creation algorithm. + + Interaction 2b: Negotiating the Creation of the Conceptual + Row + + The management station issues a management protocol set + operation which sets the desired instance of the status + column to `createAndWait'. If the agent is unwilling to + process a request of this sort, the set operation fails with + an error of `wrongValue'. (As a consequence, such an agent + must be prepared to accept a single management protocol set + operation, i.e., interaction 2a above, containing all of the + columns indicated by its column requirements.) Otherwise, + the conceptual row is created, a `noError' response is + returned, and the status column is immediately set to either + `notInService' or `notReady', depending on whether it has + sufficient information to (attempt to) make the conceptual + row available for use by the managed device. If there is + sufficient information available, then the status column is + set to `notInService'; otherwise, if there is insufficient + information, then the status column is set to `notReady'. + Regardless, we proceed to interaction 3. + + Interaction 3: Initializing non-defaulted Objects + + The management station must now determine the column + requirements. It issues a management protocol get operation + to examine all columns in the created conceptual row. In + the response, for each column, there are three possible + outcomes: + + - a value is returned, indicating that the agent + implements the object-type associated with this column + and had sufficient information to provide a value. For + those columns to which the agent provides read-create + access (and for which the agent allows their values to + be changed after their creation), a value return tells + the management station that it may issue additional + management protocol set operations, if it desires, in + order to change the value associated with this column. + + - the exception `noSuchInstance' is returned, + indicating that the agent implements the object-type + associated with this column, and that this column in at + least one conceptual row would be accessible in the MIB + view used by the retrieval were it to exist. However, + the agent does not have sufficient information to + provide a value, and until a value is provided, the + conceptual row may not be made available for use by the + managed device. For those columns to which the agent + provides read-create access, the `noSuchInstance' + exception tells the management station that it must + issue additional management protocol set operations, in + order to provide a value associated with this column. + + - the exception `noSuchObject' is returned, indicating + that the agent does not implement the object-type + associated with this column or that there is no + conceptual row for which this column would be + accessible in the MIB view used by the retrieval. As + such, the management station can not issue any + management protocol set operations to create an + instance of this column. + + If the value associated with the status column is + `notReady', then the management station must first deal with + all `noSuchInstance' columns, if any. Having done so, the + value of the status column becomes `notInService', and we + proceed to interaction 4. + + Interaction 4: Making the Conceptual Row Available + + Once the management station is satisfied with the values + associated with the columns of the conceptual row, it issues + a management protocol set operation to set the status column + to `active'. If the agent has sufficient information to + make the conceptual row available for use by the managed + device, the management protocol set operation succeeds (a + `noError' response is returned). Otherwise, the management + protocol set operation fails with an error of + `inconsistentValue'. + + NOTE WELL + + A conceptual row having a status column with value + `notInService' or `notReady' is unavailable to the + managed device. As such, it is possible for the + managed device to create its own instances during the + time between the management protocol set operation + which sets the status column to `createAndWait' and the + management protocol set operation which sets the status + column to `active'. In this case, when the management + protocol set operation is issued to set the status + column to `active', the values held in the agent + supersede those used by the managed device. + + If the management station is prevented from setting the + status column to `active' (e.g., due to management station + or network failure) the conceptual row will be left in the + `notInService' or `notReady' state, consuming resources + indefinitely. The agent must detect conceptual rows that + have been in either state for an abnormally long period of + time and remove them. It is the responsibility of the + DESCRIPTION clause of the status column to indicate what an + abnormally long period of time would be. This period of + time should be long enough to allow for human response time + (including `think time') between the creation of the + conceptual row and the setting of the status to `active'. + In the absence of such information in the DESCRIPTION + clause, it is suggested that this period be approximately 5 + minutes in length. This removal action applies not only to + newly-created rows, but also to previously active rows which + are set to, and left in, the notInService state for a + prolonged period exceeding that which is considered normal + for such a conceptual row. + + Conceptual Row Suspension + + When a conceptual row is `active', the management station + may issue a management protocol set operation which sets the + instance of the status column to `notInService'. If the + agent is unwilling to do so, the set operation fails with an + error of `wrongValue' or `inconsistentValue'. Otherwise, + the conceptual row is taken out of service, and a `noError' + response is returned. It is the responsibility of the + DESCRIPTION clause of the status column to indicate under + what circumstances the status column should be taken out of + service (e.g., in order for the value of some other column + of the same conceptual row to be modified). + + + Conceptual Row Deletion + + For deletion of conceptual rows, a management protocol set + operation is issued which sets the instance of the status + column to `destroy'. This request may be made regardless of + the current value of the status column (e.g., it is possible + to delete conceptual rows which are either `notReady', + `notInService' or `active'.) If the operation succeeds, + then all instances associated with the conceptual row are + immediately removed." + SYNTAX INTEGER { + -- the following two values are states: + -- these values may be read or written + active(1), + notInService(2), + + -- the following value is a state: + -- this value may be read, but not written + notReady(3), + + -- the following three values are + -- actions: these values may be written, + -- but are never read + createAndGo(4), + createAndWait(5), + destroy(6) + } + +TimeStamp ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "The value of the sysUpTime object at which a specific + occurrence happened. The specific occurrence must be + defined in the description of any object defined using this + type. + + If sysUpTime is reset to zero as a result of a re- + initialization of the network management (sub)system, then + the values of all TimeStamp objects are also reset. + However, after approximately 497 days without a re- + initialization, the sysUpTime object will reach 2^^32-1 and + then increment around to zero; in this case, existing values + of TimeStamp objects do not change. This can lead to + ambiguities in the value of TimeStamp objects." + SYNTAX TimeTicks + + +TimeInterval ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "A period of time, measured in units of 0.01 seconds." + SYNTAX INTEGER (0..2147483647) + +DateAndTime ::= TEXTUAL-CONVENTION + DISPLAY-HINT "2d-1d-1d,1d:1d:1d.1d,1a1d:1d" + STATUS current + DESCRIPTION + "A date-time specification. + + field octets contents range + ----- ------ -------- ----- + 1 1-2 year* 0..65536 + 2 3 month 1..12 + 3 4 day 1..31 + 4 5 hour 0..23 + 5 6 minutes 0..59 + 6 7 seconds 0..60 + (use 60 for leap-second) + 7 8 deci-seconds 0..9 + 8 9 direction from UTC '+' / '-' + 9 10 hours from UTC* 0..13 + 10 11 minutes from UTC 0..59 + + * Notes: + - the value of year is in network-byte order + - daylight saving time in New Zealand is +13 + + For example, Tuesday May 26, 1992 at 1:30:15 PM EDT would be + displayed as: + + 1992-5-26,13:30:15.0,-4:0 + + Note that if only local time is known, then timezone + information (fields 8-10) is not present." + SYNTAX OCTET STRING (SIZE (8 | 11)) + + +StorageType ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "Describes the memory realization of a conceptual row. A + row which is volatile(2) is lost upon reboot. A row which + is either nonVolatile(3), permanent(4) or readOnly(5), is + backed up by stable storage. A row which is permanent(4) + can be changed but not deleted. A row which is readOnly(5) + cannot be changed nor deleted. + + If the value of an object with this syntax is either + permanent(4) or readOnly(5), it cannot be written. + Conversely, if the value is either other(1), volatile(2) or + nonVolatile(3), it cannot be modified to be permanent(4) or + readOnly(5). (All illegal modifications result in a + 'wrongValue' error.) + + Every usage of this textual convention is required to + specify the columnar objects which a permanent(4) row must + at a minimum allow to be writable." + SYNTAX INTEGER { + other(1), -- eh? + volatile(2), -- e.g., in RAM + nonVolatile(3), -- e.g., in NVRAM + permanent(4), -- e.g., partially in ROM + readOnly(5) -- e.g., completely in ROM + } + +TDomain ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "Denotes a kind of transport service. + + Some possible values, such as snmpUDPDomain, are defined in + the SNMPv2-TM MIB module. Other possible values are defined + in other MIB modules." + REFERENCE "The SNMPv2-TM MIB module is defined in RFC 1906." + SYNTAX OBJECT IDENTIFIER + + +TAddress ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "Denotes a transport service address. + + A TAddress value is always interpreted within the context of a + TDomain value. Thus, each definition of a TDomain value must + be accompanied by a definition of a textual convention for use + with that TDomain. Some possible textual conventions, such as + SnmpUDPAddress for snmpUDPDomain, are defined in the SNMPv2-TM + MIB module. Other possible textual conventions are defined in + other MIB modules." + REFERENCE "The SNMPv2-TM MIB module is defined in RFC 1906." + SYNTAX OCTET STRING (SIZE (1..255)) + + +END diff --git a/contrib/apps/LwipMibCompiler/Mibs/SNMPv2-TM b/contrib/apps/LwipMibCompiler/Mibs/SNMPv2-TM new file mode 100644 index 00000000000..dadbc4a84e0 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/SNMPv2-TM @@ -0,0 +1,194 @@ +SNMPv2-TM DEFINITIONS ::= BEGIN + +IMPORTS + MODULE-IDENTITY, OBJECT-IDENTITY, + snmpModules, snmpDomains, snmpProxys + FROM SNMPv2-SMI + TEXTUAL-CONVENTION + FROM SNMPv2-TC; + +snmpv2tm MODULE-IDENTITY + LAST-UPDATED "200210160000Z" + ORGANIZATION "IETF SNMPv3 Working Group" + CONTACT-INFO + "WG-EMail: snmpv3@lists.tislabs.com + Subscribe: snmpv3-request@lists.tislabs.com + + Co-Chair: Russ Mundy + Network Associates Laboratories + postal: 15204 Omega Drive, Suite 300 + Rockville, MD 20850-4601 + USA + EMail: mundy@tislabs.com + phone: +1 301 947-7107 + + + + Co-Chair: David Harrington + Enterasys Networks + postal: 35 Industrial Way + P. O. Box 5005 + Rochester, NH 03866-5005 + USA + EMail: dbh@enterasys.com + phone: +1 603 337-2614 + + Editor: Randy Presuhn + BMC Software, Inc. + postal: 2141 North First Street + San Jose, CA 95131 + USA + EMail: randy_presuhn@bmc.com + phone: +1 408 546-1006" + DESCRIPTION + "The MIB module for SNMP transport mappings. + + Copyright (C) The Internet Society (2002). This + version of this MIB module is part of RFC 3417; + see the RFC itself for full legal notices. + " + REVISION "200210160000Z" + DESCRIPTION + "Clarifications, published as RFC 3417." + REVISION "199601010000Z" + DESCRIPTION + "Clarifications, published as RFC 1906." + REVISION "199304010000Z" + DESCRIPTION + "The initial version, published as RFC 1449." + ::= { snmpModules 19 } + +-- SNMP over UDP over IPv4 + +snmpUDPDomain OBJECT-IDENTITY + STATUS current + DESCRIPTION + "The SNMP over UDP over IPv4 transport domain. + The corresponding transport address is of type + SnmpUDPAddress." + ::= { snmpDomains 1 } + + + + + + + + +SnmpUDPAddress ::= TEXTUAL-CONVENTION + DISPLAY-HINT "1d.1d.1d.1d/2d" + STATUS current + DESCRIPTION + "Represents a UDP over IPv4 address: + + octets contents encoding + 1-4 IP-address network-byte order + 5-6 UDP-port network-byte order + " + SYNTAX OCTET STRING (SIZE (6)) + +-- SNMP over OSI + +snmpCLNSDomain OBJECT-IDENTITY + STATUS current + DESCRIPTION + "The SNMP over CLNS transport domain. + The corresponding transport address is of type + SnmpOSIAddress." + ::= { snmpDomains 2 } + +snmpCONSDomain OBJECT-IDENTITY + STATUS current + DESCRIPTION + "The SNMP over CONS transport domain. + The corresponding transport address is of type + SnmpOSIAddress." + ::= { snmpDomains 3 } + +SnmpOSIAddress ::= TEXTUAL-CONVENTION + DISPLAY-HINT "*1x:/1x:" + STATUS current + DESCRIPTION + "Represents an OSI transport-address: + + octets contents encoding + 1 length of NSAP 'n' as an unsigned-integer + (either 0 or from 3 to 20) + 2..(n+1) NSAP concrete binary representation + (n+2)..m TSEL string of (up to 64) octets + " + SYNTAX OCTET STRING (SIZE (1 | 4..85)) + + + + + + + + +-- SNMP over DDP + +snmpDDPDomain OBJECT-IDENTITY + STATUS current + DESCRIPTION + "The SNMP over DDP transport domain. The corresponding + transport address is of type SnmpNBPAddress." + ::= { snmpDomains 4 } + +SnmpNBPAddress ::= TEXTUAL-CONVENTION + STATUS current + DESCRIPTION + "Represents an NBP name: + + octets contents encoding + 1 length of object 'n' as an unsigned integer + 2..(n+1) object string of (up to 32) octets + n+2 length of type 'p' as an unsigned integer + (n+3)..(n+2+p) type string of (up to 32) octets + n+3+p length of zone 'q' as an unsigned integer + (n+4+p)..(n+3+p+q) zone string of (up to 32) octets + + For comparison purposes, strings are + case-insensitive. All strings may contain any octet + other than 255 (hex ff)." + SYNTAX OCTET STRING (SIZE (3..99)) + +-- SNMP over IPX + +snmpIPXDomain OBJECT-IDENTITY + STATUS current + DESCRIPTION + "The SNMP over IPX transport domain. The corresponding + transport address is of type SnmpIPXAddress." + ::= { snmpDomains 5 } + +SnmpIPXAddress ::= TEXTUAL-CONVENTION + DISPLAY-HINT "4x.1x:1x:1x:1x:1x:1x.2d" + STATUS current + DESCRIPTION + "Represents an IPX address: + + octets contents encoding + 1-4 network-number network-byte order + 5-10 physical-address network-byte order + 11-12 socket-number network-byte order + " + SYNTAX OCTET STRING (SIZE (12)) + + + +-- for proxy to SNMPv1 (RFC 1157) + +rfc1157Proxy OBJECT IDENTIFIER ::= { snmpProxys 1 } + +rfc1157Domain OBJECT-IDENTITY + STATUS deprecated + DESCRIPTION + "The transport domain for SNMPv1 over UDP over IPv4. + The corresponding transport address is of type + SnmpUDPAddress." + ::= { rfc1157Proxy 1 } + +-- ::= { rfc1157Proxy 2 } this OID is obsolete + +END diff --git a/contrib/apps/LwipMibCompiler/Mibs/TCP-MIB b/contrib/apps/LwipMibCompiler/Mibs/TCP-MIB new file mode 100644 index 00000000000..5b9e0bf3494 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/TCP-MIB @@ -0,0 +1,829 @@ +TCP-MIB DEFINITIONS ::= BEGIN + +IMPORTS + MODULE-IDENTITY, OBJECT-TYPE, Integer32, Unsigned32, + Gauge32, Counter32, Counter64, IpAddress, mib-2 + FROM SNMPv2-SMI + MODULE-COMPLIANCE, OBJECT-GROUP FROM SNMPv2-CONF + InetAddress, InetAddressType, + InetPortNumber FROM INET-ADDRESS-MIB; + +tcpMIB MODULE-IDENTITY + LAST-UPDATED "200502180000Z" -- 18 February 2005 + ORGANIZATION + "IETF IPv6 MIB Revision Team + http://www.ietf.org/html.charters/ipv6-charter.html" + CONTACT-INFO + "Rajiv Raghunarayan (editor) + + Cisco Systems Inc. + 170 West Tasman Drive + San Jose, CA 95134 + + Phone: +1 408 853 9612 + Email: raraghun@cisco.com + + Send comments to ipv6@ietf.org" + DESCRIPTION + "The MIB module for managing TCP implementations. + + Copyright (C) The Internet Society (2005). This version + of this MIB module is a part of RFC 4022; see the RFC + itself for full legal notices." + REVISION "200502180000Z" -- 18 February 2005 + DESCRIPTION + "IP version neutral revision, published as RFC 4022." + REVISION "9411010000Z" + DESCRIPTION + "Initial SMIv2 version, published as RFC 2012." + REVISION "9103310000Z" + DESCRIPTION + "The initial revision of this MIB module was part of + MIB-II." + ::= { mib-2 49 } + +-- the TCP base variables group + + + + +tcp OBJECT IDENTIFIER ::= { mib-2 6 } + +-- Scalars + +tcpRtoAlgorithm OBJECT-TYPE + SYNTAX INTEGER { + other(1), -- none of the following + constant(2), -- a constant rto + rsre(3), -- MIL-STD-1778, Appendix B + vanj(4), -- Van Jacobson's algorithm + rfc2988(5) -- RFC 2988 + } + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The algorithm used to determine the timeout value used for + retransmitting unacknowledged octets." + ::= { tcp 1 } + +tcpRtoMin OBJECT-TYPE + SYNTAX Integer32 (0..2147483647) + UNITS "milliseconds" + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The minimum value permitted by a TCP implementation for + the retransmission timeout, measured in milliseconds. + More refined semantics for objects of this type depend + on the algorithm used to determine the retransmission + timeout; in particular, the IETF standard algorithm + rfc2988(5) provides a minimum value." + ::= { tcp 2 } + +tcpRtoMax OBJECT-TYPE + SYNTAX Integer32 (0..2147483647) + UNITS "milliseconds" + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The maximum value permitted by a TCP implementation for + the retransmission timeout, measured in milliseconds. + More refined semantics for objects of this type depend + on the algorithm used to determine the retransmission + timeout; in particular, the IETF standard algorithm + rfc2988(5) provides an upper bound (as part of an + adaptive backoff algorithm)." + ::= { tcp 3 } + + + + +tcpMaxConn OBJECT-TYPE + SYNTAX Integer32 (-1 | 0..2147483647) + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The limit on the total number of TCP connections the entity + can support. In entities where the maximum number of + connections is dynamic, this object should contain the + value -1." + ::= { tcp 4 } + +tcpActiveOpens OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of times that TCP connections have made a direct + transition to the SYN-SENT state from the CLOSED state. + + Discontinuities in the value of this counter are + indicated via discontinuities in the value of sysUpTime." + ::= { tcp 5 } + +tcpPassiveOpens OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of times TCP connections have made a direct + transition to the SYN-RCVD state from the LISTEN state. + + Discontinuities in the value of this counter are + indicated via discontinuities in the value of sysUpTime." + ::= { tcp 6 } + +tcpAttemptFails OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of times that TCP connections have made a direct + transition to the CLOSED state from either the SYN-SENT + state or the SYN-RCVD state, plus the number of times that + TCP connections have made a direct transition to the + LISTEN state from the SYN-RCVD state. + + Discontinuities in the value of this counter are + indicated via discontinuities in the value of sysUpTime." + + + + ::= { tcp 7 } + +tcpEstabResets OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of times that TCP connections have made a direct + transition to the CLOSED state from either the ESTABLISHED + state or the CLOSE-WAIT state. + + Discontinuities in the value of this counter are + indicated via discontinuities in the value of sysUpTime." + ::= { tcp 8 } + +tcpCurrEstab OBJECT-TYPE + SYNTAX Gauge32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of TCP connections for which the current state + is either ESTABLISHED or CLOSE-WAIT." + ::= { tcp 9 } + +tcpInSegs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of segments received, including those + received in error. This count includes segments received + on currently established connections. + + Discontinuities in the value of this counter are + indicated via discontinuities in the value of sysUpTime." + ::= { tcp 10 } + +tcpOutSegs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of segments sent, including those on + current connections but excluding those containing only + retransmitted octets. + + Discontinuities in the value of this counter are + indicated via discontinuities in the value of sysUpTime." + + + + ::= { tcp 11 } + +tcpRetransSegs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of segments retransmitted; that is, the + number of TCP segments transmitted containing one or more + previously transmitted octets. + + Discontinuities in the value of this counter are + indicated via discontinuities in the value of sysUpTime." + ::= { tcp 12 } + +tcpInErrs OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of segments received in error (e.g., bad + TCP checksums). + + Discontinuities in the value of this counter are + indicated via discontinuities in the value of sysUpTime." + ::= { tcp 14 } + +tcpOutRsts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of TCP segments sent containing the RST flag. + + Discontinuities in the value of this counter are + indicated via discontinuities in the value of sysUpTime." + ::= { tcp 15 } + +-- { tcp 16 } was used to represent the ipv6TcpConnTable in RFC 2452, +-- which has since been obsoleted. It MUST not be used. + +tcpHCInSegs OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of segments received, including those + received in error. This count includes segments received + + + + on currently established connections. This object is + the 64-bit equivalent of tcpInSegs. + + Discontinuities in the value of this counter are + indicated via discontinuities in the value of sysUpTime." + ::= { tcp 17 } + +tcpHCOutSegs OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of segments sent, including those on + current connections but excluding those containing only + retransmitted octets. This object is the 64-bit + equivalent of tcpOutSegs. + + Discontinuities in the value of this counter are + indicated via discontinuities in the value of sysUpTime." + ::= { tcp 18 } + + +-- The TCP Connection table + +tcpConnectionTable OBJECT-TYPE + SYNTAX SEQUENCE OF TcpConnectionEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "A table containing information about existing TCP + connections. Note that unlike earlier TCP MIBs, there + is a separate table for connections in the LISTEN state." + ::= { tcp 19 } + +tcpConnectionEntry OBJECT-TYPE + SYNTAX TcpConnectionEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "A conceptual row of the tcpConnectionTable containing + information about a particular current TCP connection. + Each row of this table is transient in that it ceases to + exist when (or soon after) the connection makes the + transition to the CLOSED state." + INDEX { tcpConnectionLocalAddressType, + tcpConnectionLocalAddress, + tcpConnectionLocalPort, + tcpConnectionRemAddressType, + + + + tcpConnectionRemAddress, + tcpConnectionRemPort } + ::= { tcpConnectionTable 1 } + +TcpConnectionEntry ::= SEQUENCE { + tcpConnectionLocalAddressType InetAddressType, + tcpConnectionLocalAddress InetAddress, + tcpConnectionLocalPort InetPortNumber, + tcpConnectionRemAddressType InetAddressType, + tcpConnectionRemAddress InetAddress, + tcpConnectionRemPort InetPortNumber, + tcpConnectionState INTEGER, + tcpConnectionProcess Unsigned32 + } + +tcpConnectionLocalAddressType OBJECT-TYPE + SYNTAX InetAddressType + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The address type of tcpConnectionLocalAddress." + ::= { tcpConnectionEntry 1 } + +tcpConnectionLocalAddress OBJECT-TYPE + SYNTAX InetAddress + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The local IP address for this TCP connection. The type + of this address is determined by the value of + tcpConnectionLocalAddressType. + + As this object is used in the index for the + tcpConnectionTable, implementors should be + careful not to create entries that would result in OIDs + with more than 128 subidentifiers; otherwise the information + cannot be accessed by using SNMPv1, SNMPv2c, or SNMPv3." + ::= { tcpConnectionEntry 2 } + +tcpConnectionLocalPort OBJECT-TYPE + SYNTAX InetPortNumber + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The local port number for this TCP connection." + ::= { tcpConnectionEntry 3 } + +tcpConnectionRemAddressType OBJECT-TYPE + + + + SYNTAX InetAddressType + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The address type of tcpConnectionRemAddress." + ::= { tcpConnectionEntry 4 } + +tcpConnectionRemAddress OBJECT-TYPE + SYNTAX InetAddress + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The remote IP address for this TCP connection. The type + of this address is determined by the value of + tcpConnectionRemAddressType. + + As this object is used in the index for the + tcpConnectionTable, implementors should be + careful not to create entries that would result in OIDs + with more than 128 subidentifiers; otherwise the information + cannot be accessed by using SNMPv1, SNMPv2c, or SNMPv3." + ::= { tcpConnectionEntry 5 } + +tcpConnectionRemPort OBJECT-TYPE + SYNTAX InetPortNumber + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The remote port number for this TCP connection." + ::= { tcpConnectionEntry 6 } + +tcpConnectionState OBJECT-TYPE + SYNTAX INTEGER { + closed(1), + listen(2), + synSent(3), + synReceived(4), + established(5), + finWait1(6), + finWait2(7), + closeWait(8), + lastAck(9), + closing(10), + timeWait(11), + deleteTCB(12) + } + MAX-ACCESS read-write + STATUS current + + + + DESCRIPTION + "The state of this TCP connection. + + The value listen(2) is included only for parallelism to the + old tcpConnTable and should not be used. A connection in + LISTEN state should be present in the tcpListenerTable. + + The only value that may be set by a management station is + deleteTCB(12). Accordingly, it is appropriate for an agent + to return a `badValue' response if a management station + attempts to set this object to any other value. + + If a management station sets this object to the value + deleteTCB(12), then the TCB (as defined in [RFC793]) of + the corresponding connection on the managed node is + deleted, resulting in immediate termination of the + connection. + + As an implementation-specific option, a RST segment may be + sent from the managed node to the other TCP endpoint (note, + however, that RST segments are not sent reliably)." + ::= { tcpConnectionEntry 7 } + +tcpConnectionProcess OBJECT-TYPE + SYNTAX Unsigned32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The system's process ID for the process associated with + this connection, or zero if there is no such process. This + value is expected to be the same as HOST-RESOURCES-MIB:: + hrSWRunIndex or SYSAPPL-MIB::sysApplElmtRunIndex for some + row in the appropriate tables." + ::= { tcpConnectionEntry 8 } + +-- The TCP Listener table + +tcpListenerTable OBJECT-TYPE + SYNTAX SEQUENCE OF TcpListenerEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "A table containing information about TCP listeners. A + listening application can be represented in three + possible ways: + + 1. An application that is willing to accept both IPv4 and + IPv6 datagrams is represented by + + + + a tcpListenerLocalAddressType of unknown (0) and + a tcpListenerLocalAddress of ''h (a zero-length + octet-string). + + 2. An application that is willing to accept only IPv4 or + IPv6 datagrams is represented by a + tcpListenerLocalAddressType of the appropriate address + type and a tcpListenerLocalAddress of '0.0.0.0' or '::' + respectively. + + 3. An application that is listening for data destined + only to a specific IP address, but from any remote + system, is represented by a tcpListenerLocalAddressType + of an appropriate address type, with + tcpListenerLocalAddress as the specific local address. + + NOTE: The address type in this table represents the + address type used for the communication, irrespective + of the higher-layer abstraction. For example, an + application using IPv6 'sockets' to communicate via + IPv4 between ::ffff:10.0.0.1 and ::ffff:10.0.0.2 would + use InetAddressType ipv4(1))." + ::= { tcp 20 } + +tcpListenerEntry OBJECT-TYPE + SYNTAX TcpListenerEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "A conceptual row of the tcpListenerTable containing + information about a particular TCP listener." + INDEX { tcpListenerLocalAddressType, + tcpListenerLocalAddress, + tcpListenerLocalPort } + ::= { tcpListenerTable 1 } + +TcpListenerEntry ::= SEQUENCE { + tcpListenerLocalAddressType InetAddressType, + tcpListenerLocalAddress InetAddress, + tcpListenerLocalPort InetPortNumber, + tcpListenerProcess Unsigned32 + } + +tcpListenerLocalAddressType OBJECT-TYPE + SYNTAX InetAddressType + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + + + + "The address type of tcpListenerLocalAddress. The value + should be unknown (0) if connection initiations to all + local IP addresses are accepted." + ::= { tcpListenerEntry 1 } + +tcpListenerLocalAddress OBJECT-TYPE + SYNTAX InetAddress + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The local IP address for this TCP connection. + + The value of this object can be represented in three + possible ways, depending on the characteristics of the + listening application: + + 1. For an application willing to accept both IPv4 and + IPv6 datagrams, the value of this object must be + ''h (a zero-length octet-string), with the value + of the corresponding tcpListenerLocalAddressType + object being unknown (0). + + 2. For an application willing to accept only IPv4 or + IPv6 datagrams, the value of this object must be + '0.0.0.0' or '::' respectively, with + tcpListenerLocalAddressType representing the + appropriate address type. + + 3. For an application which is listening for data + destined only to a specific IP address, the value + of this object is the specific local address, with + tcpListenerLocalAddressType representing the + appropriate address type. + + As this object is used in the index for the + tcpListenerTable, implementors should be + careful not to create entries that would result in OIDs + with more than 128 subidentifiers; otherwise the information + cannot be accessed, using SNMPv1, SNMPv2c, or SNMPv3." + ::= { tcpListenerEntry 2 } + +tcpListenerLocalPort OBJECT-TYPE + SYNTAX InetPortNumber + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The local port number for this TCP connection." + ::= { tcpListenerEntry 3 } + + + +tcpListenerProcess OBJECT-TYPE + SYNTAX Unsigned32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The system's process ID for the process associated with + this listener, or zero if there is no such process. This + value is expected to be the same as HOST-RESOURCES-MIB:: + hrSWRunIndex or SYSAPPL-MIB::sysApplElmtRunIndex for some + row in the appropriate tables." + ::= { tcpListenerEntry 4 } + + +-- The deprecated TCP Connection table + +tcpConnTable OBJECT-TYPE + SYNTAX SEQUENCE OF TcpConnEntry + MAX-ACCESS not-accessible + STATUS deprecated + DESCRIPTION + "A table containing information about existing IPv4-specific + TCP connections or listeners. This table has been + deprecated in favor of the version neutral + tcpConnectionTable." + ::= { tcp 13 } + +tcpConnEntry OBJECT-TYPE + SYNTAX TcpConnEntry + MAX-ACCESS not-accessible + STATUS deprecated + DESCRIPTION + "A conceptual row of the tcpConnTable containing information + about a particular current IPv4 TCP connection. Each row + of this table is transient in that it ceases to exist when + (or soon after) the connection makes the transition to the + CLOSED state." + INDEX { tcpConnLocalAddress, + tcpConnLocalPort, + tcpConnRemAddress, + tcpConnRemPort } + ::= { tcpConnTable 1 } + +TcpConnEntry ::= SEQUENCE { + tcpConnState INTEGER, + tcpConnLocalAddress IpAddress, + tcpConnLocalPort Integer32, + tcpConnRemAddress IpAddress, + tcpConnRemPort Integer32 + + + + } + +tcpConnState OBJECT-TYPE + SYNTAX INTEGER { + closed(1), + listen(2), + synSent(3), + synReceived(4), + established(5), + finWait1(6), + finWait2(7), + closeWait(8), + lastAck(9), + closing(10), + timeWait(11), + deleteTCB(12) + } + MAX-ACCESS read-write + STATUS deprecated + DESCRIPTION + "The state of this TCP connection. + + The only value that may be set by a management station is + deleteTCB(12). Accordingly, it is appropriate for an agent + to return a `badValue' response if a management station + attempts to set this object to any other value. + + If a management station sets this object to the value + deleteTCB(12), then the TCB (as defined in [RFC793]) of + the corresponding connection on the managed node is + deleted, resulting in immediate termination of the + connection. + + As an implementation-specific option, a RST segment may be + sent from the managed node to the other TCP endpoint (note, + however, that RST segments are not sent reliably)." + ::= { tcpConnEntry 1 } + +tcpConnLocalAddress OBJECT-TYPE + SYNTAX IpAddress + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The local IP address for this TCP connection. In the case + of a connection in the listen state willing to + accept connections for any IP interface associated with the + node, the value 0.0.0.0 is used." + ::= { tcpConnEntry 2 } + + + +tcpConnLocalPort OBJECT-TYPE + SYNTAX Integer32 (0..65535) + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The local port number for this TCP connection." + ::= { tcpConnEntry 3 } + +tcpConnRemAddress OBJECT-TYPE + SYNTAX IpAddress + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The remote IP address for this TCP connection." + ::= { tcpConnEntry 4 } + +tcpConnRemPort OBJECT-TYPE + SYNTAX Integer32 (0..65535) + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The remote port number for this TCP connection." + ::= { tcpConnEntry 5 } + +-- conformance information + +tcpMIBConformance OBJECT IDENTIFIER ::= { tcpMIB 2 } + +tcpMIBCompliances OBJECT IDENTIFIER ::= { tcpMIBConformance 1 } +tcpMIBGroups OBJECT IDENTIFIER ::= { tcpMIBConformance 2 } + +-- compliance statements + +tcpMIBCompliance2 MODULE-COMPLIANCE + STATUS current + DESCRIPTION + "The compliance statement for systems that implement TCP. + + A number of INDEX objects cannot be + represented in the form of OBJECT clauses in SMIv2 but + have the following compliance requirements, + expressed in OBJECT clause form in this description + clause: + + -- OBJECT tcpConnectionLocalAddressType + -- SYNTAX InetAddressType { ipv4(1), ipv6(2) } + -- DESCRIPTION + -- This MIB requires support for only global IPv4 + + + + -- and IPv6 address types. + -- + -- OBJECT tcpConnectionRemAddressType + -- SYNTAX InetAddressType { ipv4(1), ipv6(2) } + -- DESCRIPTION + -- This MIB requires support for only global IPv4 + -- and IPv6 address types. + -- + -- OBJECT tcpListenerLocalAddressType + -- SYNTAX InetAddressType { unknown(0), ipv4(1), + -- ipv6(2) } + -- DESCRIPTION + -- This MIB requires support for only global IPv4 + -- and IPv6 address types. The type unknown also + -- needs to be supported to identify a special + -- case in the listener table: a listen using + -- both IPv4 and IPv6 addresses on the device. + -- + " + MODULE -- this module + MANDATORY-GROUPS { tcpBaseGroup, tcpConnectionGroup, + tcpListenerGroup } + GROUP tcpHCGroup + DESCRIPTION + "This group is mandatory for systems that are capable + of receiving or transmitting more than 1 million TCP + segments per second. 1 million segments per second will + cause a Counter32 to wrap in just over an hour." + OBJECT tcpConnectionState + SYNTAX INTEGER { closed(1), listen(2), synSent(3), + synReceived(4), established(5), + finWait1(6), finWait2(7), closeWait(8), + lastAck(9), closing(10), timeWait(11) } + MIN-ACCESS read-only + DESCRIPTION + "Write access is not required, nor is support for the value + deleteTCB (12)." + ::= { tcpMIBCompliances 2 } + +tcpMIBCompliance MODULE-COMPLIANCE + STATUS deprecated + DESCRIPTION + "The compliance statement for IPv4-only systems that + implement TCP. In order to be IP version independent, this + compliance statement is deprecated in favor of + tcpMIBCompliance2. However, agents are still encouraged + to implement these objects in order to interoperate with + the deployed base of managers." + + + + MODULE -- this module + MANDATORY-GROUPS { tcpGroup } + OBJECT tcpConnState + MIN-ACCESS read-only + DESCRIPTION + "Write access is not required." + ::= { tcpMIBCompliances 1 } + + +-- units of conformance + +tcpGroup OBJECT-GROUP + OBJECTS { tcpRtoAlgorithm, tcpRtoMin, tcpRtoMax, + tcpMaxConn, tcpActiveOpens, + tcpPassiveOpens, tcpAttemptFails, + tcpEstabResets, tcpCurrEstab, tcpInSegs, + tcpOutSegs, tcpRetransSegs, tcpConnState, + tcpConnLocalAddress, tcpConnLocalPort, + tcpConnRemAddress, tcpConnRemPort, + tcpInErrs, tcpOutRsts } + STATUS deprecated + DESCRIPTION + "The tcp group of objects providing for management of TCP + entities." + ::= { tcpMIBGroups 1 } + +tcpBaseGroup OBJECT-GROUP + OBJECTS { tcpRtoAlgorithm, tcpRtoMin, tcpRtoMax, + tcpMaxConn, tcpActiveOpens, + tcpPassiveOpens, tcpAttemptFails, + tcpEstabResets, tcpCurrEstab, tcpInSegs, + tcpOutSegs, tcpRetransSegs, + tcpInErrs, tcpOutRsts } + STATUS current + DESCRIPTION + "The group of counters common to TCP entities." + ::= { tcpMIBGroups 2 } + +tcpConnectionGroup OBJECT-GROUP + OBJECTS { tcpConnectionState, tcpConnectionProcess } + STATUS current + DESCRIPTION + "The group provides general information about TCP + connections." + ::= { tcpMIBGroups 3 } + +tcpListenerGroup OBJECT-GROUP + OBJECTS { tcpListenerProcess } + + + + STATUS current + DESCRIPTION + "This group has objects providing general information about + TCP listeners." + ::= { tcpMIBGroups 4 } + +tcpHCGroup OBJECT-GROUP + OBJECTS { tcpHCInSegs, tcpHCOutSegs } + STATUS current + DESCRIPTION + "The group of objects providing for counters of high speed + TCP implementations." + ::= { tcpMIBGroups 5 } + +END diff --git a/contrib/apps/LwipMibCompiler/Mibs/UDP-MIB b/contrib/apps/LwipMibCompiler/Mibs/UDP-MIB new file mode 100644 index 00000000000..b947b8126b2 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/Mibs/UDP-MIB @@ -0,0 +1,579 @@ +UDP-MIB DEFINITIONS ::= BEGIN + +IMPORTS + MODULE-IDENTITY, OBJECT-TYPE, Integer32, Counter32, Counter64, + Unsigned32, IpAddress, mib-2 FROM SNMPv2-SMI + MODULE-COMPLIANCE, OBJECT-GROUP FROM SNMPv2-CONF + InetAddress, InetAddressType, + InetPortNumber FROM INET-ADDRESS-MIB; + +udpMIB MODULE-IDENTITY + LAST-UPDATED "200505200000Z" -- May 20, 2005 + ORGANIZATION + "IETF IPv6 Working Group + http://www.ietf.org/html.charters/ipv6-charter.html" + CONTACT-INFO + "Bill Fenner (editor) + + AT&T Labs -- Research + 75 Willow Rd. + Menlo Park, CA 94025 + + Phone: +1 650 330-7893 + Email: fenner@research.att.com + + John Flick (editor) + + Hewlett-Packard Company + 8000 Foothills Blvd. M/S 5557 + Roseville, CA 95747 + + Phone: +1 916 785 4018 + Email: john.flick@hp.com + + Send comments to ipv6@ietf.org" + + + + DESCRIPTION + "The MIB module for managing UDP implementations. + Copyright (C) The Internet Society (2005). This + version of this MIB module is part of RFC 4113; + see the RFC itself for full legal notices." + REVISION "200505200000Z" -- May 20, 2005 + DESCRIPTION + "IP version neutral revision, incorporating the + following revisions: + + - Added udpHCInDatagrams and udpHCOutDatagrams in order + to provide high-capacity counters for fast networks. + - Added text to the descriptions of all counter objects + to indicate how discontinuities are detected. + - Deprecated the IPv4-specific udpTable and replaced it + with the version neutral udpEndpointTable. This + table includes support for connected UDP endpoints + and support for identification of the operating + system process associated with a UDP endpoint. + - Deprecated the udpGroup and replaced it with object + groups representing the current set of objects. + - Deprecated udpMIBCompliance and replaced it with + udpMIBCompliance2, which includes the compliance + information for the new object groups. + + This version published as RFC 4113." + REVISION "199411010000Z" -- November 1, 1994 + DESCRIPTION + "Initial SMIv2 version, published as RFC 2013." + REVISION "199103310000Z" -- March 31, 1991 + DESCRIPTION + "The initial revision of this MIB module was part of + MIB-II, published as RFC 1213." + ::= { mib-2 50 } + +-- the UDP group + +udp OBJECT IDENTIFIER ::= { mib-2 7 } + +udpInDatagrams OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of UDP datagrams delivered to UDP + users. + + + + + + Discontinuities in the value of this counter can occur + at re-initialization of the management system, and at + other times as indicated by discontinuities in the + value of sysUpTime." + ::= { udp 1 } + +udpNoPorts OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of received UDP datagrams for which + there was no application at the destination port. + + Discontinuities in the value of this counter can occur + at re-initialization of the management system, and at + other times as indicated by discontinuities in the + value of sysUpTime." + ::= { udp 2 } + +udpInErrors OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The number of received UDP datagrams that could not be + delivered for reasons other than the lack of an + application at the destination port. + + Discontinuities in the value of this counter can occur + at re-initialization of the management system, and at + other times as indicated by discontinuities in the + value of sysUpTime." + ::= { udp 3 } + +udpOutDatagrams OBJECT-TYPE + SYNTAX Counter32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of UDP datagrams sent from this + entity. + + Discontinuities in the value of this counter can occur + at re-initialization of the management system, and at + other times as indicated by discontinuities in the + value of sysUpTime." + ::= { udp 4 } + + + +udpHCInDatagrams OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of UDP datagrams delivered to UDP + users, for devices that can receive more than 1 + million UDP datagrams per second. + + Discontinuities in the value of this counter can occur + at re-initialization of the management system, and at + other times as indicated by discontinuities in the + value of sysUpTime." + ::= { udp 8 } + +udpHCOutDatagrams OBJECT-TYPE + SYNTAX Counter64 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The total number of UDP datagrams sent from this + entity, for devices that can transmit more than 1 + million UDP datagrams per second. + + Discontinuities in the value of this counter can occur + at re-initialization of the management system, and at + other times as indicated by discontinuities in the + value of sysUpTime." + ::= { udp 9 } + +-- +-- { udp 6 } was defined as the ipv6UdpTable in RFC2454's +-- IPV6-UDP-MIB. This RFC obsoletes RFC 2454, so { udp 6 } is +-- obsoleted. +-- + +-- The UDP "Endpoint" table. + +udpEndpointTable OBJECT-TYPE + SYNTAX SEQUENCE OF UdpEndpointEntry + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "A table containing information about this entity's UDP + endpoints on which a local application is currently + accepting or sending datagrams. + + + + + + The address type in this table represents the address + type used for the communication, irrespective of the + higher-layer abstraction. For example, an application + using IPv6 'sockets' to communicate via IPv4 between + ::ffff:10.0.0.1 and ::ffff:10.0.0.2 would use + InetAddressType ipv4(1). + + Unlike the udpTable in RFC 2013, this table also allows + the representation of an application that completely + specifies both local and remote addresses and ports. A + listening application is represented in three possible + ways: + + 1) An application that is willing to accept both IPv4 + and IPv6 datagrams is represented by a + udpEndpointLocalAddressType of unknown(0) and a + udpEndpointLocalAddress of ''h (a zero-length + octet-string). + + 2) An application that is willing to accept only IPv4 + or only IPv6 datagrams is represented by a + udpEndpointLocalAddressType of the appropriate + address type and a udpEndpointLocalAddress of + '0.0.0.0' or '::' respectively. + + 3) An application that is listening for datagrams only + for a specific IP address but from any remote + system is represented by a + udpEndpointLocalAddressType of the appropriate + address type, with udpEndpointLocalAddress + specifying the local address. + + In all cases where the remote is a wildcard, the + udpEndpointRemoteAddressType is unknown(0), the + udpEndpointRemoteAddress is ''h (a zero-length + octet-string), and the udpEndpointRemotePort is 0. + + If the operating system is demultiplexing UDP packets + by remote address and port, or if the application has + 'connected' the socket specifying a default remote + address and port, the udpEndpointRemote* values should + be used to reflect this." + ::= { udp 7 } + +udpEndpointEntry OBJECT-TYPE + SYNTAX UdpEndpointEntry + MAX-ACCESS not-accessible + STATUS current + + + + DESCRIPTION + "Information about a particular current UDP endpoint. + + Implementers need to be aware that if the total number + of elements (octets or sub-identifiers) in + udpEndpointLocalAddress and udpEndpointRemoteAddress + exceeds 111, then OIDs of column instances in this table + will have more than 128 sub-identifiers and cannot be + accessed using SNMPv1, SNMPv2c, or SNMPv3." + INDEX { udpEndpointLocalAddressType, + udpEndpointLocalAddress, + udpEndpointLocalPort, + udpEndpointRemoteAddressType, + udpEndpointRemoteAddress, + udpEndpointRemotePort, + udpEndpointInstance } + ::= { udpEndpointTable 1 } + +UdpEndpointEntry ::= SEQUENCE { + udpEndpointLocalAddressType InetAddressType, + udpEndpointLocalAddress InetAddress, + udpEndpointLocalPort InetPortNumber, + udpEndpointRemoteAddressType InetAddressType, + udpEndpointRemoteAddress InetAddress, + udpEndpointRemotePort InetPortNumber, + udpEndpointInstance Unsigned32, + udpEndpointProcess Unsigned32 + } + +udpEndpointLocalAddressType OBJECT-TYPE + SYNTAX InetAddressType + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The address type of udpEndpointLocalAddress. Only + IPv4, IPv4z, IPv6, and IPv6z addresses are expected, or + unknown(0) if datagrams for all local IP addresses are + accepted." + ::= { udpEndpointEntry 1 } + +udpEndpointLocalAddress OBJECT-TYPE + SYNTAX InetAddress + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The local IP address for this UDP endpoint. + + The value of this object can be represented in three + + + + possible ways, depending on the characteristics of the + listening application: + + 1. For an application that is willing to accept both + IPv4 and IPv6 datagrams, the value of this object + must be ''h (a zero-length octet-string), with + the value of the corresponding instance of the + udpEndpointLocalAddressType object being unknown(0). + + 2. For an application that is willing to accept only IPv4 + or only IPv6 datagrams, the value of this object + must be '0.0.0.0' or '::', respectively, while the + corresponding instance of the + udpEndpointLocalAddressType object represents the + appropriate address type. + + 3. For an application that is listening for data + destined only to a specific IP address, the value + of this object is the specific IP address for which + this node is receiving packets, with the + corresponding instance of the + udpEndpointLocalAddressType object representing the + appropriate address type. + + As this object is used in the index for the + udpEndpointTable, implementors of this table should be + careful not to create entries that would result in OIDs + with more than 128 subidentifiers; else the information + cannot be accessed using SNMPv1, SNMPv2c, or SNMPv3." + ::= { udpEndpointEntry 2 } + +udpEndpointLocalPort OBJECT-TYPE + SYNTAX InetPortNumber + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The local port number for this UDP endpoint." + ::= { udpEndpointEntry 3 } + +udpEndpointRemoteAddressType OBJECT-TYPE + SYNTAX InetAddressType + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The address type of udpEndpointRemoteAddress. Only + IPv4, IPv4z, IPv6, and IPv6z addresses are expected, or + unknown(0) if datagrams for all remote IP addresses are + accepted. Also, note that some combinations of + + + + udpEndpointLocalAdressType and + udpEndpointRemoteAddressType are not supported. In + particular, if the value of this object is not + unknown(0), it is expected to always refer to the + same IP version as udpEndpointLocalAddressType." + ::= { udpEndpointEntry 4 } + +udpEndpointRemoteAddress OBJECT-TYPE + SYNTAX InetAddress + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The remote IP address for this UDP endpoint. If + datagrams from any remote system are to be accepted, + this value is ''h (a zero-length octet-string). + Otherwise, it has the type described by + udpEndpointRemoteAddressType and is the address of the + remote system from which datagrams are to be accepted + (or to which all datagrams will be sent). + + As this object is used in the index for the + udpEndpointTable, implementors of this table should be + careful not to create entries that would result in OIDs + with more than 128 subidentifiers; else the information + cannot be accessed using SNMPv1, SNMPv2c, or SNMPv3." + ::= { udpEndpointEntry 5 } + +udpEndpointRemotePort OBJECT-TYPE + SYNTAX InetPortNumber + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The remote port number for this UDP endpoint. If + datagrams from any remote system are to be accepted, + this value is zero." + ::= { udpEndpointEntry 6 } + +udpEndpointInstance OBJECT-TYPE + SYNTAX Unsigned32 (1..'ffffffff'h) + MAX-ACCESS not-accessible + STATUS current + DESCRIPTION + "The instance of this tuple. This object is used to + distinguish among multiple processes 'connected' to + the same UDP endpoint. For example, on a system + implementing the BSD sockets interface, this would be + used to support the SO_REUSEADDR and SO_REUSEPORT + socket options." + + + + ::= { udpEndpointEntry 7 } + +udpEndpointProcess OBJECT-TYPE + SYNTAX Unsigned32 + MAX-ACCESS read-only + STATUS current + DESCRIPTION + "The system's process ID for the process associated with + this endpoint, or zero if there is no such process. + This value is expected to be the same as + HOST-RESOURCES-MIB::hrSWRunIndex or SYSAPPL-MIB:: + sysApplElmtRunIndex for some row in the appropriate + tables." + ::= { udpEndpointEntry 8 } + +-- The deprecated UDP Listener table + +-- The deprecated UDP listener table only contains information +-- about this entity's IPv4 UDP end-points on which a local +-- application is currently accepting datagrams. It does not +-- provide more detailed connection information, or information +-- about IPv6 endpoints. + +udpTable OBJECT-TYPE + SYNTAX SEQUENCE OF UdpEntry + MAX-ACCESS not-accessible + STATUS deprecated + DESCRIPTION + "A table containing IPv4-specific UDP listener + information. It contains information about all local + IPv4 UDP end-points on which an application is + currently accepting datagrams. This table has been + deprecated in favor of the version neutral + udpEndpointTable." + ::= { udp 5 } + +udpEntry OBJECT-TYPE + SYNTAX UdpEntry + MAX-ACCESS not-accessible + STATUS deprecated + DESCRIPTION + "Information about a particular current UDP listener." + INDEX { udpLocalAddress, udpLocalPort } + ::= { udpTable 1 } + +UdpEntry ::= SEQUENCE { + udpLocalAddress IpAddress, + udpLocalPort Integer32 + + + +} + +udpLocalAddress OBJECT-TYPE + SYNTAX IpAddress + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The local IP address for this UDP listener. In the + case of a UDP listener that is willing to accept + datagrams for any IP interface associated with the + node, the value 0.0.0.0 is used." + ::= { udpEntry 1 } + +udpLocalPort OBJECT-TYPE + SYNTAX Integer32 (0..65535) + MAX-ACCESS read-only + STATUS deprecated + DESCRIPTION + "The local port number for this UDP listener." + ::= { udpEntry 2 } + +-- conformance information + +udpMIBConformance OBJECT IDENTIFIER ::= { udpMIB 2 } +udpMIBCompliances OBJECT IDENTIFIER ::= { udpMIBConformance 1 } +udpMIBGroups OBJECT IDENTIFIER ::= { udpMIBConformance 2 } + +-- compliance statements + +udpMIBCompliance2 MODULE-COMPLIANCE + STATUS current + DESCRIPTION + "The compliance statement for systems that implement + UDP. + + There are a number of INDEX objects that cannot be + represented in the form of OBJECT clauses in SMIv2, but + for which we have the following compliance + requirements, expressed in OBJECT clause form in this + description clause: + + -- OBJECT udpEndpointLocalAddressType + -- SYNTAX InetAddressType { unknown(0), ipv4(1), + -- ipv6(2), ipv4z(3), + -- ipv6z(4) } + -- DESCRIPTION + -- Support for dns(5) is not required. + -- OBJECT udpEndpointLocalAddress + + + + -- SYNTAX InetAddress (SIZE(0|4|8|16|20)) + -- DESCRIPTION + -- Support is only required for zero-length + -- octet-strings, and for scoped and unscoped + -- IPv4 and IPv6 addresses. + -- OBJECT udpEndpointRemoteAddressType + -- SYNTAX InetAddressType { unknown(0), ipv4(1), + -- ipv6(2), ipv4z(3), + -- ipv6z(4) } + -- DESCRIPTION + -- Support for dns(5) is not required. + -- OBJECT udpEndpointRemoteAddress + -- SYNTAX InetAddress (SIZE(0|4|8|16|20)) + -- DESCRIPTION + -- Support is only required for zero-length + -- octet-strings, and for scoped and unscoped + -- IPv4 and IPv6 addresses. + " + MODULE -- this module + MANDATORY-GROUPS { udpBaseGroup, udpEndpointGroup } + GROUP udpHCGroup + DESCRIPTION + "This group is mandatory for systems that + are capable of receiving or transmitting more than + 1 million UDP datagrams per second. 1 million + datagrams per second will cause a Counter32 to + wrap in just over an hour." + ::= { udpMIBCompliances 2 } + +udpMIBCompliance MODULE-COMPLIANCE + STATUS deprecated + DESCRIPTION + "The compliance statement for IPv4-only systems that + implement UDP. For IP version independence, this + compliance statement is deprecated in favor of + udpMIBCompliance2. However, agents are still + encouraged to implement these objects in order to + interoperate with the deployed base of managers." + MODULE -- this module + MANDATORY-GROUPS { udpGroup } + ::= { udpMIBCompliances 1 } + +-- units of conformance + +udpGroup OBJECT-GROUP + OBJECTS { udpInDatagrams, udpNoPorts, + udpInErrors, udpOutDatagrams, + udpLocalAddress, udpLocalPort } + + + + STATUS deprecated + DESCRIPTION + "The deprecated group of objects providing for + management of UDP over IPv4." + ::= { udpMIBGroups 1 } + +udpBaseGroup OBJECT-GROUP + OBJECTS { udpInDatagrams, udpNoPorts, udpInErrors, + udpOutDatagrams } + STATUS current + DESCRIPTION + "The group of objects providing for counters of UDP + statistics." + ::= { udpMIBGroups 2 } + +udpHCGroup OBJECT-GROUP + OBJECTS { udpHCInDatagrams, udpHCOutDatagrams } + STATUS current + DESCRIPTION + "The group of objects providing for counters of high + speed UDP implementations." + ::= { udpMIBGroups 3 } + +udpEndpointGroup OBJECT-GROUP + OBJECTS { udpEndpointProcess } + STATUS current + DESCRIPTION + "The group of objects providing for the IP version + independent management of UDP 'endpoints'." + ::= { udpMIBGroups 4 } + +END diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/DisplayHint.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/DisplayHint.cs new file mode 100644 index 00000000000..831f1177a37 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/DisplayHint.cs @@ -0,0 +1,84 @@ +using System; +using System.Collections.Generic; +using System.Collections; + +namespace Lextm.SharpSnmpLib.Mib +{ + public class DisplayHint + { + private enum NumType { + dec, + hex, + oct, + bin, + str + } + + private string _str; + private NumType _type; + private int _decimalPoints = 0; + + public DisplayHint(string str) + { + _str = str; + if (str.StartsWith("d")) + { + _type = NumType.dec; + if (str.StartsWith("d-")) + { + _decimalPoints = Convert.ToInt32(str.Substring(2)); + } + } + else if (str.StartsWith("o")) + { + _type = NumType.oct; + } + else if (str.StartsWith("h")) + { + _type = NumType.hex; + } + else if (str.StartsWith("b")) + { + _type = NumType.bin; + } + else + { + _type = NumType.str; + foreach (char c in str) + { + + } + } + + } + + public override string ToString() + { + return _str; + } + + internal object Decode(int i) + { + switch (_type) + { + case NumType.dec: + if (_decimalPoints == 0) + { + return i; + } + else + { + return i / Math.Pow(10.0, _decimalPoints); + } + case NumType.hex: + return System.Convert.ToString(i, 16); + case NumType.oct: + return System.Convert.ToString(i, 8); + case NumType.bin: + return System.Convert.ToString(i, 2); + default: + return null; + } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/AgentCapabilities.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/AgentCapabilities.cs new file mode 100644 index 00000000000..2f79cce5980 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/AgentCapabilities.cs @@ -0,0 +1,29 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/31 + * Time: 13:18 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +namespace Lextm.SharpSnmpLib.Mib.Elements.Entities +{ + /// <summary> + /// The AGENT-CAPABILITIES construct is used to specify implementation characteristics of an SNMP agent sub-system with respect to object types and events. + /// </summary> + public sealed class AgentCapabilities : EntityBase + { + /// <summary> + /// Creates an <see cref="AgentCapabilities"/> instance. + /// </summary> + /// <param name="module"></param> + /// <param name="header"></param> + /// <param name="lexer"></param> + public AgentCapabilities(IModule module, SymbolList preAssignSymbols, ISymbolEnumerator symbols) + : base(module, preAssignSymbols, symbols) + { + } + + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/EntityBase.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/EntityBase.cs new file mode 100644 index 00000000000..6da9b18cc78 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/EntityBase.cs @@ -0,0 +1,46 @@ +using System; + +namespace Lextm.SharpSnmpLib.Mib.Elements.Entities +{ + public abstract class EntityBase: IEntity + { + private readonly IModule _module; + private string _parent; + private readonly uint _value; + private readonly string _name; + + public EntityBase(IModule module, SymbolList preAssignSymbols, ISymbolEnumerator symbols) + { + _module = module; + _name = preAssignSymbols[0].ToString(); + + Lexer.ParseOidValue(symbols, out _parent, out _value); + } + + public IModule Module + { + get { return _module; } + } + + public string Parent + { + get { return _parent; } + set { _parent = value; } + } + + public uint Value + { + get { return _value; } + } + + public string Name + { + get { return _name; } + } + + public virtual string Description + { + get { return string.Empty; } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/IEntity.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/IEntity.cs new file mode 100644 index 00000000000..7360a4727ca --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/IEntity.cs @@ -0,0 +1,62 @@ +// Entity interface. +// Copyright (C) 2008-2010 Malcolm Crowe, Lex Li, and other contributors. +// +// This library is free software; you can redistribute it and/or +// modify it under the terms of the GNU Lesser General Public +// License as published by the Free Software Foundation; either +// version 2.1 of the License, or (at your option) any later version. +// +// This library is distributed in the hope that it will be useful, +// but WITHOUT ANY WARRANTY; without even the implied warranty of +// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU +// Lesser General Public License for more details. +// +// You should have received a copy of the GNU Lesser General Public +// License along with this library; if not, write to the Free Software +// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/19 + * Time: 20:10 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +using System; + +namespace Lextm.SharpSnmpLib.Mib.Elements.Entities +{ + /// <summary> + /// Basic interface for all elements building up the MIB tree, thus having an OID as value. + /// </summary> + public interface IEntity : IDeclaration + { + /// <summary> + /// Parent name. + /// </summary> + string Parent + { + get; + set; + } + + /// <summary> + /// Value. + /// </summary> + uint Value + { + get; + } + + /// <summary> + /// Gets the description. + /// </summary> + /// <value>The description.</value> + string Description + { + get; + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ModuleCompliance.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ModuleCompliance.cs new file mode 100644 index 00000000000..008c354584a --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ModuleCompliance.cs @@ -0,0 +1,23 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/21 + * Time: 19:35 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +namespace Lextm.SharpSnmpLib.Mib.Elements.Entities +{ + /// <summary> + /// Description of ModuleComplianceNode. + /// </summary> + public sealed class ModuleCompliance : EntityBase + { + public ModuleCompliance(IModule module, SymbolList preAssignSymbols, ISymbolEnumerator symbols) + : base(module, preAssignSymbols, symbols) + { + } + + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ModuleIdentity.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ModuleIdentity.cs new file mode 100644 index 00000000000..6de28ce6991 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ModuleIdentity.cs @@ -0,0 +1,10 @@ +namespace Lextm.SharpSnmpLib.Mib.Elements.Entities +{ + public sealed class ModuleIdentity : EntityBase + { + public ModuleIdentity(IModule module, SymbolList preAssignSymbols, ISymbolEnumerator symbols) + : base(module, preAssignSymbols, symbols) + { + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/NotificationGroup.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/NotificationGroup.cs new file mode 100644 index 00000000000..27d3e4ce4fe --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/NotificationGroup.cs @@ -0,0 +1,22 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/21 + * Time: 19:34 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +namespace Lextm.SharpSnmpLib.Mib.Elements.Entities +{ + /// <summary> + /// Description of NotificationGroupNode. + /// </summary> + public sealed class NotificationGroup : EntityBase + { + public NotificationGroup(IModule module, SymbolList preAssignSymbols, ISymbolEnumerator symbols) + : base(module, preAssignSymbols, symbols) + { + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/NotificationType.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/NotificationType.cs new file mode 100644 index 00000000000..7386e21786e --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/NotificationType.cs @@ -0,0 +1,11 @@ + +namespace Lextm.SharpSnmpLib.Mib.Elements.Entities +{ + public sealed class NotificationType : EntityBase + { + public NotificationType(IModule module, SymbolList preAssignSymbols, ISymbolEnumerator symbols) + : base(module, preAssignSymbols, symbols) + { + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ObjectGroup.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ObjectGroup.cs new file mode 100644 index 00000000000..d846cdbb88c --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ObjectGroup.cs @@ -0,0 +1,22 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/21 + * Time: 19:27 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +namespace Lextm.SharpSnmpLib.Mib.Elements.Entities +{ + /// <summary> + /// Description of ObjectGroupNode. + /// </summary> + public sealed class ObjectGroup : EntityBase + { + public ObjectGroup(IModule module, SymbolList preAssignSymbols, ISymbolEnumerator symbols) + : base(module, preAssignSymbols, symbols) + { + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ObjectIdentity.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ObjectIdentity.cs new file mode 100644 index 00000000000..9c1e084807e --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ObjectIdentity.cs @@ -0,0 +1,21 @@ + +namespace Lextm.SharpSnmpLib.Mib.Elements.Entities +{ + /// <summary> + /// Object identifier node. + /// </summary> + public sealed class ObjectIdentity : EntityBase + { + + /// <summary> + /// Creates a <see cref="ObjectIdentity"/>. + /// </summary> + /// <param name="module">Module name</param> + /// <param name="header">Header</param> + /// <param name="lexer">Lexer</param> + public ObjectIdentity(IModule module, SymbolList preAssignSymbols, ISymbolEnumerator symbols) + : base(module, preAssignSymbols, symbols) + { + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ObjectType.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ObjectType.cs new file mode 100644 index 00000000000..3a8b567a4bb --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/ObjectType.cs @@ -0,0 +1,336 @@ +using System; +using System.Collections.Generic; +using Lextm.SharpSnmpLib.Mib.Elements.Types; + +namespace Lextm.SharpSnmpLib.Mib.Elements.Entities +{ + public sealed class ObjectType : EntityBase, ITypeReferrer + { + private ITypeAssignment _syntax; + private string _units; + private MaxAccess _access; + private Status _status; + private string _description; + private string _reference; + private IList<string> _indices; + private string _augments; + private string _defVal; + + public ObjectType(IModule module, SymbolList preAssignSymbols, ISymbolEnumerator symbols) + : base(module, preAssignSymbols, symbols) + { + ParseProperties(preAssignSymbols); + } + + private void ParseProperties(SymbolList header) + { + ISymbolEnumerator headerSymbols = header.GetSymbolEnumerator(); + Symbol temp = headerSymbols.NextNonEOLSymbol(); + + // Skip name + temp = headerSymbols.NextNonEOLSymbol(); + temp.Expect(Symbol.ObjectType); + + _syntax = ParseSyntax (Module, headerSymbols); + _units = ParseUnits (headerSymbols); + _access = ParseAccess (headerSymbols); + _status = ParseStatus (headerSymbols); + _description = ParseDescription (headerSymbols); + _reference = ParseReference (headerSymbols); + _indices = ParseIndices (headerSymbols); + _augments = ParseAugments (headerSymbols); + _defVal = ParseDefVal (headerSymbols); + } + + private static string ParseAugments(ISymbolEnumerator symbols) + { + Symbol current = symbols.NextNonEOLSymbol(); + + if (current == Symbol.Augments) + { + string augment = null; + + current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.OpenBracket); + + current = symbols.NextNonEOLSymbol(); + augment = current.ToString(); + + current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.CloseBracket); + + return augment; + } + else if (current != null) + { + symbols.PutBack(current); + } + + return null; + } + + private static string ParseDefVal(ISymbolEnumerator symbols) + { + Symbol current = symbols.NextNonEOLSymbol(); + + if (current == Symbol.DefVal) + { + current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.OpenBracket); + + string defVal = null; + current = symbols.NextNonEOLSymbol(); + + if (current == Symbol.OpenBracket) + { + int depth = 1; + // TODO: decode this. + while (depth > 0) + { + current = symbols.NextNonEOLSymbol(); + if (current == Symbol.OpenBracket) + { + depth++; + } + else if (current == Symbol.CloseBracket) + { + depth--; + } + } + } + else + { + defVal = current.ToString(); + current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.CloseBracket); + } + + return defVal; + } + else if (current != null) + { + symbols.PutBack(current); + } + + return null; + } + + private static IList<string> ParseIndices(ISymbolEnumerator symbols) + { + Symbol current = symbols.NextNonEOLSymbol(); + + if (current == Symbol.Index) + { + current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.OpenBracket); + + List<string> indices = new List<string>(); + + while (current != Symbol.CloseBracket) + { + current = symbols.NextNonEOLSymbol(); + + bool lastIndex = false; + if (current == Symbol.Implied) + { + current = symbols.NextNonEOLSymbol(); + lastIndex = true; // 'IMPLIED' may only be used for last index + } + + current.Assert((current != Symbol.Comma) && (current != Symbol.CloseBracket), "Expected index name but found symbol!"); + indices.Add(current.ToString()); + + current = symbols.NextNonEOLSymbol(); + if (lastIndex) + { + current.Expect(Symbol.CloseBracket); + } + else + { + current.Expect(Symbol.Comma, Symbol.CloseBracket); + } + } + + return indices; + } + else if (current != null) + { + symbols.PutBack(current); + } + + return null; + } + + private static string ParseReference(ISymbolEnumerator symbols) + { + Symbol current = symbols.NextNonEOLSymbol(); + + if (current == Symbol.Reference) + { + return symbols.NextNonEOLSymbol().ToString(); + } + else if (current != null) + { + symbols.PutBack(current); + } + + return null; + } + + private static string ParseDescription(ISymbolEnumerator symbols) + { + Symbol current = symbols.NextNonEOLSymbol(); + + if (current == Symbol.Description) + { + return symbols.NextNonEOLSymbol().ToString().Trim(new char[] { '"' }); + } + else if (current != null) + { + symbols.PutBack(current); + } + + return null; + } + + private static Status ParseStatus(ISymbolEnumerator symbols) + { + Status status = Status.obsolete; + + Symbol current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.Status); + + current = symbols.NextNonEOLSymbol(); + try + { + status = (Status)Enum.Parse(typeof(Status), current.ToString()); + } + catch (ArgumentException) + { + current.Assert(false, "Invalid/Unknown status"); + } + + return status; + } + + private static MaxAccess ParseAccess(ISymbolEnumerator symbols) + { + MaxAccess access = MaxAccess.notAccessible; + + Symbol current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.MaxAccess, Symbol.Access); + + current = symbols.NextNonEOLSymbol(); + switch (current.ToString()) + { + case "not-accessible": + access = MaxAccess.notAccessible; + break; + case "accessible-for-notify": + access = MaxAccess.accessibleForNotify; + break; + case "read-only": + access = MaxAccess.readOnly; + break; + case "read-write": + access = MaxAccess.readWrite; + break; + case "read-create": + access = MaxAccess.readCreate; + break; + case "write-only": + access = MaxAccess.readWrite; + break; + default: + current.Assert(false, "Invalid/Unknown access"); + break; + } + + return access; + } + + private static string ParseUnits(ISymbolEnumerator symbols) + { + Symbol current = symbols.NextNonEOLSymbol(); + + if (current == Symbol.Units) + { + return symbols.NextNonEOLSymbol().ToString(); + } + else if (current != null) + { + symbols.PutBack(current); + } + + return null; + } + + private static ITypeAssignment ParseSyntax(IModule module, ISymbolEnumerator symbols) + { + Symbol current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.Syntax); + + return Lexer.ParseBasicTypeDef(module, String.Empty, symbols, isMacroSyntax: true); + } + + private static bool IsProperty(Symbol sym) + { + string s = sym.ToString(); + return s == "SYNTAX" || s == "MAX-ACCESS" || s == "STATUS" || s == "DESCRIPTION"; + } + + public ITypeAssignment Syntax + { + get { return _syntax; } + internal set { _syntax = value; } + } + + public override string Description + { + get { return _description; } + } + + public MaxAccess Access + { + get { return _access; } + } + + public IList<string> Indices + { + get { return _indices; } + } + + public string Augments + { + get { return _augments; } + } + + #region ITypeReferrer Member + + public ITypeAssignment ReferredType + { + get { return _syntax; } + set { _syntax = value; } + } + + public ITypeAssignment BaseType + { + get + { + ITypeReferrer tr = this; + ITypeAssignment result = null; + + while ((tr != null) && (tr.ReferredType != null)) + { + result = tr.ReferredType; + tr = tr.ReferredType as ITypeReferrer; + } + + return result; + } + } + + #endregion + + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/OidValueAssignment.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/OidValueAssignment.cs new file mode 100644 index 00000000000..3c659407b8c --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Entities/OidValueAssignment.cs @@ -0,0 +1,30 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/17 + * Time: 20:49 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +using System; + +namespace Lextm.SharpSnmpLib.Mib.Elements.Entities +{ + /// <summary> + /// Object identifier node. + /// </summary> + public sealed class OidValueAssignment : EntityBase + { + /// <summary> + /// Creates a <see cref="OidValueAssignment"/>. + /// </summary> + /// <param name="module">Module</param> + /// <param name="name">Name</param> + /// <param name="lexer">Lexer</param> + public OidValueAssignment(IModule module, SymbolList preAssignSymbols, ISymbolEnumerator symbols) + : base(module, preAssignSymbols, symbols) + { + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Exports.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Exports.cs new file mode 100644 index 00000000000..c1e66e322d1 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Exports.cs @@ -0,0 +1,56 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/6/7 + * Time: 17:34 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +using System.Collections.Generic; + +namespace Lextm.SharpSnmpLib.Mib.Elements +{ + /// <summary> + /// Description of Exports. + /// </summary> + public sealed class Exports: IElement + { + private IModule _module; + private readonly IList<string> _types = new List<string>(); + + public Exports(IModule module, ISymbolEnumerator s) + { + _module = module; + + Symbol previous = null; + Symbol current; + do + { + current = s.NextSymbol(); + + if (current == Symbol.EOL) + { + continue; + } + else if (((current == Symbol.Comma) || (current == Symbol.Semicolon)) && (previous != null)) + { + previous.AssertIsValidIdentifier(); + _types.Add(previous.ToString()); + } + + previous = current; + } + while (current != Symbol.Semicolon); + } + + #region IElement Member + + public IModule Module + { + get { return _module; } + } + + #endregion + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/IDeclaration.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/IDeclaration.cs new file mode 100644 index 00000000000..0958ac6153b --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/IDeclaration.cs @@ -0,0 +1,18 @@ +using System; +using System.Collections.Generic; +using System.Linq; +using System.Text; + +namespace Lextm.SharpSnmpLib.Mib.Elements +{ + public interface IDeclaration: IElement + { + /// <summary> + /// Name. + /// </summary> + string Name + { + get; + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/IElement.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/IElement.cs new file mode 100644 index 00000000000..e2db7fd3a51 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/IElement.cs @@ -0,0 +1,35 @@ +// Construct interface. +// Copyright (C) 2008-2010 Malcolm Crowe, Lex Li, and other contributors. +// +// This library is free software; you can redistribute it and/or +// modify it under the terms of the GNU Lesser General Public +// License as published by the Free Software Foundation; either +// version 2.1 of the License, or (at your option) any later version. +// +// This library is distributed in the hope that it will be useful, +// but WITHOUT ANY WARRANTY; without even the implied warranty of +// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU +// Lesser General Public License for more details. +// +// You should have received a copy of the GNU Lesser General Public +// License along with this library; if not, write to the Free Software +// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + +namespace Lextm.SharpSnmpLib.Mib.Elements +{ + /// <summary> + /// Construct interface. + /// </summary> + [System.Diagnostics.CodeAnalysis.SuppressMessage("Microsoft.Design", "CA1040:AvoidEmptyInterfaces")] + public interface IElement + { + /// <summary> + /// Containing module. + /// </summary> + IModule Module + { + get; + } + + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/ITypeReferrer.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/ITypeReferrer.cs new file mode 100644 index 00000000000..f0f57056d4c --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/ITypeReferrer.cs @@ -0,0 +1,10 @@ +using Lextm.SharpSnmpLib.Mib.Elements.Types; + +namespace Lextm.SharpSnmpLib.Mib.Elements +{ + public interface ITypeReferrer + { + ITypeAssignment ReferredType { get; set; } + ITypeAssignment BaseType { get; } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Imports.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Imports.cs new file mode 100644 index 00000000000..3a4ec6ecb69 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Imports.cs @@ -0,0 +1,81 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/31 + * Time: 12:07 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +using System.Collections.Generic; + +namespace Lextm.SharpSnmpLib.Mib.Elements +{ + /// <summary> + /// The IMPORTS construct is used to specify items used in the current MIB module which are defined in another MIB module or ASN.1 module. + /// </summary> + public sealed class Imports : List<ImportsFrom>, IElement + { + private IModule _module; + + /// <summary> + /// Creates an <see cref="Imports"/> instance. + /// </summary> + /// <param name="lexer"></param> + public Imports(IModule module, ISymbolEnumerator symbols) + { + _module = module; + + Symbol current; + while ((current = symbols.NextSymbol()) != Symbol.Semicolon) + { + if (current == Symbol.EOL) + { + continue; + } + + ImportsFrom imports = new ImportsFrom(current, symbols); + + this.Add(imports); + } + } + + public IList<string> Dependents + { + get + { + List<string> result = new List<string>(); + + foreach (ImportsFrom import in this) + { + result.Add(import.Module); + } + + return result; + } + } + + public ImportsFrom GetImportFromType(string type) + { + foreach (ImportsFrom import in this) + { + if (import.Types.Contains(type)) + { + return import; + } + } + + return null; + } + + #region IElement Member + + public IModule Module + { + get { return _module; } + } + + #endregion + + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/ImportsFrom.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/ImportsFrom.cs new file mode 100644 index 00000000000..cd5154bd72c --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/ImportsFrom.cs @@ -0,0 +1,60 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/31 + * Time: 12:07 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +using System.Collections.Generic; + +namespace Lextm.SharpSnmpLib.Mib.Elements +{ + public sealed class ImportsFrom + { + private readonly string _module; + private readonly List<string> _types = new List<string>(); + + public ImportsFrom(Symbol last, ISymbolEnumerator symbols) + { + Symbol previous = last; + Symbol current; + while ((current = symbols.NextSymbol()) != Symbol.From) + { + if (current == Symbol.EOL) + { + continue; + } + + if (current == Symbol.Comma) + { + previous.AssertIsValidIdentifier(); + _types.Add(previous.ToString()); + } + + previous = current; + } + + previous.AssertIsValidIdentifier(); + _types.Add(previous.ToString()); + + _module = symbols.NextSymbol().ToString().ToUpperInvariant(); // module names are uppercase + } + + public string Module + { + get { return _module; } + } + + public IList<string> Types + { + get { return _types; } + } + + public override string ToString() + { + return string.Join(", ", _types.ToArray()) + " FROM " + _module; + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/TrapType.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/TrapType.cs new file mode 100644 index 00000000000..9c5ca4578cd --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/TrapType.cs @@ -0,0 +1,48 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/31 + * Time: 12:20 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +namespace Lextm.SharpSnmpLib.Mib.Elements +{ + public sealed class TrapType : IDeclaration + { + private readonly IModule _module; + private readonly string _name; + private readonly int _value; + + public TrapType(IModule module, SymbolList preAssignSymbols, ISymbolEnumerator symbols) + { + _module = module; + _name = preAssignSymbols[0].ToString(); + + Symbol valueSymbol = symbols.NextNonEOLSymbol(); + + bool succeeded = int.TryParse(valueSymbol.ToString(), out _value); + valueSymbol.Assert(succeeded, "not a decimal"); + } + + public int Value + { + get { return _value; } + } + + #region IDeclaration Member + + public IModule Module + { + get { return _module; } + } + + public string Name + { + get { return _name; } + } + + #endregion + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/BaseType.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/BaseType.cs new file mode 100644 index 00000000000..a4412812944 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/BaseType.cs @@ -0,0 +1,54 @@ + +namespace Lextm.SharpSnmpLib.Mib.Elements.Types +{ + public abstract class BaseType : ITypeAssignment + { + private IModule _module; + private string _name; + + protected BaseType(IModule module, string name) + { + _module = module; + _name = name; + } + + public virtual IModule Module + { + // differentiate between: + // FddiTimeNano ::= INTEGER (0..2147483647) + // which is an IntegerType which appears under Types in a MibModule and therefore has a name and module + // and + // SYNTAX INTEGER (0..2147483647) + // which is also an IntegerType but not defined as a separate type and therefore has NO name and NO module + get + { + if (!string.IsNullOrEmpty(_name)) + { + return _module; + } + else + { + return null; + } + } + protected set { _module = value; } + } + + public virtual string Name + { + get + { + if (!string.IsNullOrEmpty(_name)) + { + return _name; + } + else + { + return "{ Implicit Base Type }"; + } + } + protected set { _name = value; } + } + + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/BitsType.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/BitsType.cs new file mode 100644 index 00000000000..a64c8dbeb9b --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/BitsType.cs @@ -0,0 +1,26 @@ +using System; +using System.Collections.Generic; + +namespace Lextm.SharpSnmpLib.Mib.Elements.Types +{ + public class BitsType : BaseType + { + private ValueMap _map; + + public BitsType(IModule module, string name, ISymbolEnumerator symbols) + : base(module, name) + { + _map = Lexer.DecodeEnumerations(symbols); + } + + public ValueMap Map + { + get { return _map; } + } + + public string this[int value] + { + get { return _map[value]; } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/Choice.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/Choice.cs new file mode 100644 index 00000000000..c66d1f3f183 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/Choice.cs @@ -0,0 +1,35 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/31 + * Time: 11:39 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +namespace Lextm.SharpSnmpLib.Mib.Elements.Types +{ + /// <summary> + /// The CHOICE type represents a list of alternatives.. + /// </summary> + public sealed class Choice : BaseType + { + /// <summary> + /// Creates a <see cref="Choice"/> instance. + /// </summary> + /// <param name="module"></param> + /// <param name="name"></param> + /// <param name="lexer"></param> + public Choice(IModule module, string name, ISymbolEnumerator symbols) + : base(module, name) + { + while (symbols.NextNonEOLSymbol() != Symbol.OpenBracket) + { + } + + while (symbols.NextNonEOLSymbol() != Symbol.CloseBracket) + { + } + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/ITypeAssignment.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/ITypeAssignment.cs new file mode 100644 index 00000000000..e962f9df92f --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/ITypeAssignment.cs @@ -0,0 +1,6 @@ +namespace Lextm.SharpSnmpLib.Mib.Elements.Types +{ + public interface ITypeAssignment : IDeclaration + { + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/IntegerType.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/IntegerType.cs new file mode 100644 index 00000000000..4841ad51d53 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/IntegerType.cs @@ -0,0 +1,117 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/7/25 + * Time: 20:41 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +using System; +using System.Collections.Generic; + +namespace Lextm.SharpSnmpLib.Mib.Elements.Types +{ + /// <summary> + /// The INTEGER type represents a list of alternatives, or a range of numbers.. + /// Includes Integer32 as it's indistinguishable from INTEGER. + /// </summary> + /** + * As this type is used for Integer32 as well as INTEGER it incorrectly + * allows enumeration sub-typing of Integer32. This is ok as currently we + * do not care about detecting incorrect MIBs and this doesn't block the + * decoding of correct MIBs. + */ + public sealed class IntegerType : BaseType + { + public enum Types + { + Integer, + Integer32 + } + + private Types _type; + private bool _isEnumeration; + private ValueMap _map; + private ValueRanges _ranges; + + /// <summary> + /// Creates an <see cref="IntegerType"/> instance. + /// </summary> + /// <param name="module"></param> + /// <param name="name"></param> + /// <param name="enumerator"></param> + public IntegerType(IModule module, string name, Symbol type, ISymbolEnumerator symbols) + : base (module, name) + { + Types? t = GetExactType(type); + type.Assert(t.HasValue, "Unknown symbol for unsigned type!"); + _type = t.Value; + + _isEnumeration = false; + + Symbol current = symbols.NextNonEOLSymbol(); + if (current == Symbol.OpenBracket) + { + _isEnumeration = true; + symbols.PutBack(current); + _map = Lexer.DecodeEnumerations(symbols); + } + else if (current == Symbol.OpenParentheses) + { + symbols.PutBack(current); + _ranges = Lexer.DecodeRanges(symbols); + current.Assert(!_ranges.IsSizeDeclaration, "SIZE keyword is not allowed for ranges of integer types!"); + } + else + { + symbols.PutBack(current); + } + } + + public Types Type + { + get { return _type; } + } + + public ValueRanges Ranges + { + get { return _ranges; } + } + + public bool IsEnumeration + { + get + { + return _isEnumeration; + } + } + + public ValueMap Enumeration + { + get { return _isEnumeration ? _map : null; } + } + + internal static Types? GetExactType(Symbol symbol) + { + if (symbol == Symbol.Integer) + { + // represents the ASN.1 builtin INTEGER type: + // may be represent any arbitrary (signed/unsigned) integer (in theory may have any size) + return Types.Integer; + } + else if (symbol == Symbol.Integer32) + { + // Integer32 ::= INTEGER (-2147483648..2147483647) // from SNMPv2-SMI + return Types.Integer32; + } + + return null; + } + + internal static bool IsIntegerType(Symbol symbol) + { + return GetExactType(symbol).HasValue; + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/IpAddressType.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/IpAddressType.cs new file mode 100644 index 00000000000..84d78d66869 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/IpAddressType.cs @@ -0,0 +1,21 @@ + +namespace Lextm.SharpSnmpLib.Mib.Elements.Types +{ + public class IpAddressType : OctetStringType + { + public IpAddressType(IModule module, string name, ISymbolEnumerator symbols) + : base(module, name, symbols) + { + if (this.Size.Count != 0) + { + throw new MibException("Size definition not allowed for IpAddress type!"); + } + + // IpAddress type is defined as: + // IpAddress ::= + // [APPLICATION 0] + // IMPLICIT OCTET STRING (SIZE (4)) + this.Size.Add(new ValueRange(4, null)); + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/Macro.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/Macro.cs new file mode 100644 index 00000000000..9f911ac95c8 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/Macro.cs @@ -0,0 +1,34 @@ + +namespace Lextm.SharpSnmpLib.Mib.Elements.Types +{ + public sealed class Macro : ITypeAssignment + { + private IModule _module; + private string _name; + + [System.Diagnostics.CodeAnalysis.SuppressMessage("Microsoft.Performance", "CA1804:RemoveUnusedLocals", MessageId = "temp")] + public Macro(IModule module, SymbolList preAssignSymbols, ISymbolEnumerator symbols) + { + _module = module; + _name = preAssignSymbols[0].ToString(); + + while (symbols.NextNonEOLSymbol() != Symbol.Begin) + { + } + + while (symbols.NextNonEOLSymbol() != Symbol.End) + { + } + } + + public IModule Module + { + get { return _module; } + } + + public string Name + { + get { return _name; } + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/ObjectIdentifierType.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/ObjectIdentifierType.cs new file mode 100644 index 00000000000..cacd415aa3d --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/ObjectIdentifierType.cs @@ -0,0 +1,11 @@ + +namespace Lextm.SharpSnmpLib.Mib.Elements.Types +{ + public class ObjectIdentifierType : BaseType + { + public ObjectIdentifierType(IModule module, string name, ISymbolEnumerator symbols) + : base(module, name) + { + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/OctetStringType.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/OctetStringType.cs new file mode 100644 index 00000000000..f6453ce853f --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/OctetStringType.cs @@ -0,0 +1,31 @@ +using System.Collections.Generic; + +namespace Lextm.SharpSnmpLib.Mib.Elements.Types +{ + public class OctetStringType : BaseType + { + private ValueRanges _size; + + public OctetStringType(IModule module, string name, ISymbolEnumerator symbols) + : base(module, name) + { + Symbol current = symbols.NextNonEOLSymbol(); + if (current == Symbol.OpenParentheses) + { + symbols.PutBack(current); + _size = Lexer.DecodeRanges(symbols); + current.Assert(_size.IsSizeDeclaration, "SIZE keyword is required for ranges of octet string!"); + } + else + { + symbols.PutBack(current); + _size = new ValueRanges(isSizeDecl: true); + } + } + + public ValueRanges Size + { + get { return _size; } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/OpaqueType.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/OpaqueType.cs new file mode 100644 index 00000000000..5a7eda33204 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/OpaqueType.cs @@ -0,0 +1,11 @@ + +namespace Lextm.SharpSnmpLib.Mib.Elements.Types +{ + public class OpaqueType : OctetStringType + { + public OpaqueType(IModule module, string name, ISymbolEnumerator symbols) + : base(module, name, symbols) + { + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/Sequence.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/Sequence.cs new file mode 100644 index 00000000000..62912a515a9 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/Sequence.cs @@ -0,0 +1,46 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/21 + * Time: 19:43 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + + +namespace Lextm.SharpSnmpLib.Mib.Elements.Types +{ + /// <summary> + /// The SEQUENCE type represents a set of specified types. This is roughly analogous to a <code>struct</code> in C. + /// </summary> + public sealed class Sequence : BaseType + { + /// <summary> + /// Creates a <see cref="Sequence" /> instance. + /// </summary> + /// <param name="module">The module.</param> + /// <param name="name">The name.</param> + /// <param name="symbols">The enumerator.</param> + public Sequence(IModule module, string name, ISymbolEnumerator symbols) + : base(module, name) + { + // parse between ( ) + Symbol temp = symbols.NextNonEOLSymbol(); + int bracketSection = 0; + temp.Expect(Symbol.OpenBracket); + bracketSection++; + while (bracketSection > 0) + { + temp = symbols.NextNonEOLSymbol(); + if (temp == Symbol.OpenBracket) + { + bracketSection++; + } + else if (temp == Symbol.CloseBracket) + { + bracketSection--; + } + } + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/SequenceOf.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/SequenceOf.cs new file mode 100644 index 00000000000..4160ca40e47 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/SequenceOf.cs @@ -0,0 +1,23 @@ +using System.Collections.Generic; + +namespace Lextm.SharpSnmpLib.Mib.Elements.Types +{ + /// <summary> + /// The SEQUENCE OF type represents a list of data sets.. + /// </summary> + public sealed class SequenceOf : BaseType + { + private string _type; + + public SequenceOf(IModule module, string name, ISymbolEnumerator sym) + : base(module, name) + { + _type = sym.NextNonEOLSymbol().ToString(); + } + + public string Type + { + get { return _type; } + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/TextualConvention.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/TextualConvention.cs new file mode 100644 index 00000000000..ab4773150eb --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/TextualConvention.cs @@ -0,0 +1,238 @@ +using System; + +namespace Lextm.SharpSnmpLib.Mib.Elements.Types +{ + public sealed class TextualConvention : ITypeAssignment, ITypeReferrer + { + private IModule _module; + private string _name; + private DisplayHint _displayHint; + private Status _status; + private string _description; + private string _reference; + private ITypeAssignment _syntax; + + [System.Diagnostics.CodeAnalysis.SuppressMessage("Microsoft.Usage", "CA1801:ReviewUnusedParameters", MessageId = "module")] + public TextualConvention(IModule module, string name, ISymbolEnumerator symbols) + { + _module = module; + _name = name; + + _displayHint = ParseDisplayHint(symbols); + _status = ParseStatus(symbols); + _description = ParseDescription(symbols); + _reference = ParseReference(symbols); + _syntax = ParseSyntax(module, symbols); + } + + private static DisplayHint ParseDisplayHint(ISymbolEnumerator symbols) + { + Symbol current = symbols.NextNonEOLSymbol(); + + if (current == Symbol.DisplayHint) + { + return new DisplayHint(symbols.NextNonEOLSymbol().ToString().Trim(new char[] { '"' })); + } + + symbols.PutBack(current); + return null; + } + + private static Status ParseStatus(ISymbolEnumerator symbols) + { + Symbol current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.Status); + + try + { + return (Status)Enum.Parse(typeof(Status), symbols.NextNonEOLSymbol().ToString()); + } + catch (ArgumentException) + { + current.Assert(false, "Invalid/Unknown status"); + } + + return Status.current; + } + + private static string ParseDescription(ISymbolEnumerator symbols) + { + Symbol current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.Description); + + return symbols.NextNonEOLSymbol().ToString().Trim(new char[] { '"' }); + } + + private static string ParseReference(ISymbolEnumerator symbols) + { + Symbol current = symbols.NextNonEOLSymbol(); + + if (current == Symbol.Reference) + { + string reference = symbols.NextNonEOLSymbol().ToString(); + if ((reference.Length >= 2) && reference.StartsWith(""") && reference.EndsWith(""")) + { + return reference.Substring(1, reference.Length-2); + } + + return reference; + } + + symbols.PutBack(current); + return null; + } + + private static ITypeAssignment ParseSyntax(IModule module, ISymbolEnumerator symbols) + { + Symbol current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.Syntax); + + /* + * RFC2579 definition: + * Syntax ::= -- Must be one of the following: + * -- a base type (or its refinement), or + * -- a BITS pseudo-type + * type + * | "BITS" "{" NamedBits "}" + * + * From section 3.5: + * The data structure must be one of the alternatives defined + * in the ObjectSyntax CHOICE or the BITS construct. Note + * that this means that the SYNTAX clause of a Textual + * Convention can not refer to a previously defined Textual + * Convention. + * + * The SYNTAX clause of a TEXTUAL CONVENTION macro may be + * sub-typed in the same way as the SYNTAX clause of an + * OBJECT-TYPE macro. + * + * Therefore the possible values are (grouped by underlying type): + * INTEGER, Integer32 + * OCTET STRING, Opaque + * OBJECT IDENTIFIER + * IpAddress + * Counter64 + * Unsigned32, Counter32, Gauge32, TimeTicks + * BITS + * With appropriate sub-typing. + */ + + return Lexer.ParseBasicTypeDef(module, String.Empty, symbols, isMacroSyntax: true); + } + + public IModule Module + { + get { return _module; } + } + + public string Name + { + get { return _name; } + } + + public string DisplayHint + { + get { return _displayHint == null ? null : _displayHint.ToString(); } + } + + public Status Status + { + get { return _status; } + } + + public string Description + { + get { return _description; } + } + + public string Reference + { + get { return _reference; } + } + + public ITypeAssignment Syntax + { + get { return _syntax; } + } + + //internal object Decode(Variable v) + //{ + // if (_syntax is IntegerType) + // { + // Integer32 i = v.Data as Integer32; + // if (i == null || (_syntax as IntegerType).IsEnumeration) + // { + // return null; + // } + // else if (_displayHint != null) + // { + // return _displayHint.Decode(i.ToInt32()); + // } + // else + // { + // return i.ToInt32(); + // } + // } + // else if (_syntax is UnsignedType) + // { + // Integer32 i = v.Data as Integer32; + // if (i == null) + // { + // return null; + // } + // else if (_displayHint != null) + // { + // return _displayHint.Decode(i.ToInt32()); + // } + // else + // { + // return i.ToInt32(); + // } + // } + // else if (_syntax is OctetStringType) + // { + // OctetString o = v.Data as OctetString; + // if (o == null) + // { + // return null; + // } + // else + // { + // // TODO: Follow the format specifier for octet strings. + // return null; + // } + // } + // else + // { + // return null; + // } + //} + + #region ITypeReferrer Member + + public ITypeAssignment ReferredType + { + get { return _syntax; } + set { _syntax = value; } + } + + public ITypeAssignment BaseType + { + get + { + ITypeReferrer tr = this; + ITypeAssignment result = this; + + while ((tr != null) && (tr.ReferredType != null)) + { + result = tr.ReferredType; + tr = tr.ReferredType as ITypeReferrer; + } + + return result; + } + } + + #endregion + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/TypeAssignment.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/TypeAssignment.cs new file mode 100644 index 00000000000..b074ef62a26 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/TypeAssignment.cs @@ -0,0 +1,147 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/18 + * Time: 13:24 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ +using System; +using System.Collections.Generic; + +namespace Lextm.SharpSnmpLib.Mib.Elements.Types +{ + /* Please be aware of the following possible constructs: + * + * isnsRegEntityIndex OBJECT-TYPE + * SYNTAX IsnsEntityIndexIdOrZero + * ( 1 .. 4294967295 ) + * MAX-ACCESS not-accessible + * + * + */ + + /// <summary/> + /// </summary> + public sealed class TypeAssignment : ITypeAssignment + { + private IModule _module; + private string _name; + private string _type; + private ValueRanges _ranges; + private ValueMap _map; + + /// <summary> + /// Creates an <see cref="TypeAssignment" />. + /// </summary> + /// <param name="module">The module.</param> + /// <param name="name">The name.</param> + /// <param name="type">The type.</param> + /// <param name="symbols">The symbols.</param> + /// <param name="isMacroSyntax">if set to <c>true</c> indicates that the syntax clause of a macro is parsed (e.g. OBJECT-TYPE, TEXTUAL-CONVENTION).</param> + public TypeAssignment(IModule module, string name, Symbol type, ISymbolEnumerator symbols, bool isMacroSyntax) + { + _module = module; + _name = name; + + SymbolList typeSymbols = new SymbolList(); + typeSymbols.Add(type); + + Symbol current = symbols.NextSymbol(); + while (current != Symbol.EOL) + { + if (current == Symbol.OpenParentheses) + { + // parse range of unknown type + symbols.PutBack(current); + _ranges = Lexer.DecodeRanges(symbols); + break; + } + else if (current == Symbol.OpenBracket) + { + symbols.PutBack(current); + _map = Lexer.DecodeEnumerations(symbols); + break; + } + + typeSymbols.Add(current); + current = symbols.NextSymbol(); + } + + _type = typeSymbols.Join(" "); + + if ((_ranges == null) && (_map == null)) + { + current = symbols.NextNonEOLSymbol(); + if (current == Symbol.OpenParentheses) + { + // parse range of unknown type + symbols.PutBack(current); + _ranges = Lexer.DecodeRanges(symbols); + } + else if (current == Symbol.OpenBracket) + { + symbols.PutBack(current); + _map = Lexer.DecodeEnumerations(symbols); + } + else if (current != null) + { + symbols.PutBack(current); + } + } + + if (isMacroSyntax) + { + // inside a macro the syntax is limited to one line, except there are brackets used for ranges/enums + return; + } + + // outside macro Syntax clause we wait for two consecutive linebreaks with a following valid identifier as end condition + Symbol previous = current; + Symbol veryPrevious = null; + + while ((current = symbols.NextSymbol()) != null) + { + if ((veryPrevious == Symbol.EOL) && (previous == Symbol.EOL) && current.IsValidIdentifier()) + { + symbols.PutBack(current); + return; + } + + veryPrevious = previous; + previous = current; + } + + previous.Assert(false, "end of file reached"); + } + + public string Type + { + get { return _type; } + } + + public ValueRanges Ranges + { + get { return _ranges; } + } + + public IDictionary<long, string> Map + { + get { return _map; } + } + + #region ITypeAssignment Member + + public IModule Module + { + get { return _module; } + } + + public string Name + { + get { return _name; } + } + + #endregion + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/UnsignedType.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/UnsignedType.cs new file mode 100644 index 00000000000..4866fc90181 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Elements/Types/UnsignedType.cs @@ -0,0 +1,103 @@ +using System.Collections.Generic; + +namespace Lextm.SharpSnmpLib.Mib.Elements.Types +{ + /** + * As this type is used for Counter32 and TimeTicks as well as Unsigned32 + * and Gauge32 it incorrectly allows range restrictions of Counter32 and + * TimeTicks. This is ok as currently we do not care about detecting + * incorrect MIBs and this doesn't block the decoding of correct MIBs. + */ + public class UnsignedType : BaseType + { + public enum Types + { + Unsigned32, + Gauge32, + Counter32, + TimeTicks, + Counter64, + } + + private Types _type; + private ValueRanges _ranges; + + public UnsignedType(IModule module, string name, Symbol type, ISymbolEnumerator symbols) + : base(module, name) + { + Types? t = GetExactType(type); + type.Assert(t.HasValue, "Unknown symbol for unsigned type!"); + _type = t.Value; + + Symbol current = symbols.NextNonEOLSymbol(); + if (current == Symbol.OpenParentheses) + { + current.Assert((_type != Types.Counter64), "Ranges are not supported for Counter64 type!"); // our internal struct can only hold int64 values + + symbols.PutBack(current); + _ranges = Lexer.DecodeRanges(symbols); + current.Assert(!_ranges.IsSizeDeclaration, "SIZE keyword is not allowed for ranges of unsigned types!"); + } + else + { + symbols.PutBack(current); + } + } + + public Types Type + { + get { return _type; } + } + + public ValueRanges Ranges + { + get { return _ranges; } + } + + internal static Types? GetExactType(Symbol symbol) + { + if (symbol == Symbol.Unsigned32) + { + // [APPLICATION 2] IMPLICIT INTEGER (0..4294967295) // from SNMPv2-SMI + return Types.Unsigned32; + } + else if (symbol == Symbol.Gauge32) + { + // [APPLICATION 2] IMPLICIT INTEGER (0..4294967295) // from SNMPv2-SMI + return Types.Gauge32; + } + else if (symbol == Symbol.Counter32) + { + // [APPLICATION 1] IMPLICIT INTEGER (0..4294967295) // from SNMPv2-SMI + return Types.Counter32; + } + else if (symbol == Symbol.TimeTicks) + { + // [APPLICATION 3] IMPLICIT INTEGER (0..4294967295) // from SNMPv2-SMI + RFC1155-SMI + return Types.TimeTicks; + } + else if (symbol == Symbol.Gauge) + { + // [APPLICATION 2] IMPLICIT INTEGER (0..4294967295) // from RFC1155-SMI + return Types.Gauge32; + } + else if (symbol == Symbol.Counter) + { + // [APPLICATION 1] IMPLICIT INTEGER (0..4294967295) // from RFC1155-SMI + return Types.Counter32; + } + else if (symbol == Symbol.Counter64) + { + // [APPLICATION 6] IMPLICIT INTEGER (0..18446744073709551615) // from SNMPv2-SMI + return Types.Counter64; + } + + return null; + } + + internal static bool IsUnsignedType(Symbol symbol) + { + return GetExactType(symbol).HasValue; + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/IModule.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/IModule.cs new file mode 100644 index 00000000000..d41ab12978a --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/IModule.cs @@ -0,0 +1,81 @@ +// Module interface. +// Copyright (C) 2008-2010 Malcolm Crowe, Lex Li, and other contributors. +// +// This library is free software; you can redistribute it and/or +// modify it under the terms of the GNU Lesser General Public +// License as published by the Free Software Foundation; either +// version 2.1 of the License, or (at your option) any later version. +// +// This library is distributed in the hope that it will be useful, +// but WITHOUT ANY WARRANTY; without even the implied warranty of +// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU +// Lesser General Public License for more details. +// +// You should have received a copy of the GNU Lesser General Public +// License along with this library; if not, write to the Free Software +// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + +/* + * Created by SharpDevelop. + * User: lextm + * Date: 5/1/2009 + * Time: 10:40 AM + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ +using System.Collections.Generic; +using Lextm.SharpSnmpLib.Mib.Elements.Entities; +using Lextm.SharpSnmpLib.Mib.Elements.Types; +using Lextm.SharpSnmpLib.Mib.Elements; + +namespace Lextm.SharpSnmpLib.Mib +{ + /// <summary> + /// MIB Module interface. + /// </summary> + public interface IModule + { + /// <summary> + /// Module name. + /// </summary> + string Name + { + get; + } + + Exports Exports + { + get; + } + + Imports Imports + { + get; + } + + /// <summary> + /// Entities + Types + all other elements implementing IDeclaration + /// </summary> + IList<IDeclaration> Declarations + { + get; + } + + /// <summary> + /// Entities. + /// </summary> + IList<IEntity> Entities + { + get; + } + + /// <summary> + /// Known types. + /// </summary> + IList<ITypeAssignment> Types + { + get; + } + + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ISymbolEnumerator.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ISymbolEnumerator.cs new file mode 100644 index 00000000000..e9dd5920d51 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ISymbolEnumerator.cs @@ -0,0 +1,9 @@ +using System.Collections.Generic; + +namespace Lextm.SharpSnmpLib.Mib +{ + public interface ISymbolEnumerator: IEnumerator<Symbol> + { + bool PutBack(Symbol item); + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Lexer.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Lexer.cs new file mode 100644 index 00000000000..5bf2844a3db --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Lexer.cs @@ -0,0 +1,581 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/17 + * Time: 16:50 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +using System; +using System.Collections.Generic; +using System.IO; +using System.Text; +using Lextm.SharpSnmpLib.Mib.Elements.Types; + +namespace Lextm.SharpSnmpLib.Mib +{ + /// <summary> + /// Lexer class that parses MIB files into symbol list. + /// </summary> + public sealed class Lexer + { + private readonly SymbolList _symbols = new SymbolList(); + + public Lexer(string file) + : this(file, new StreamReader(file)) + { + } + + public Lexer(string file, TextReader stream) + { + this.Parse(file, stream); + } + + + public ISymbolEnumerator GetEnumerator() + { + return _symbols.GetSymbolEnumerator(); + } + + + #region Parsing of MIB File + + private class ParseParams + { + public string File; + public StringBuilder Temp = new StringBuilder(); + public bool StringSection = false; + public bool AssignSection = false; + public bool AssignAhead = false; + public bool DotSection = false; + + } + + /// <summary> + /// Parses MIB file to symbol list. + /// </summary> + /// <param name="file">File</param> + /// <param name="stream">File stream</param> + private void Parse(string file, TextReader stream) + { + if (stream == null) + { + throw new ArgumentNullException("stream"); + } + + ParseParams pp = new ParseParams(); + pp.File = file; + + string line; + int row = 0; + while ((line = stream.ReadLine()) != null) + { + if (!pp.StringSection && line.TrimStart().StartsWith("--", StringComparison.Ordinal)) + { + row++; + continue; // commented line + } + + ParseLine(pp, line, row); + row++; + } + } + + private void ParseLine(ParseParams pp, string line, int row) + { + line = line + "\n"; + int count = line.Length; + for (int i = 0; i < count; i++) + { + char current = line[i]; + bool moveNext = Parse(pp, current, row, i); + if (moveNext) + { + break; + } + } + } + + private bool Parse(ParseParams pp, char current, int row, int column) + { + switch (current) + { + case '\n': + case '{': + case '}': + case '(': + case ')': + case '[': + case ']': + case ';': + case ',': + case '|': + if (!pp.StringSection) + { + bool moveNext = ParseLastSymbol(pp, row, column); + if (moveNext) + { + _symbols.Add(CreateSpecialSymbol(pp.File, '\n', row, column)); + return true; + } + + _symbols.Add(CreateSpecialSymbol(pp.File, current, row, column)); + return false; + } + + break; + case '"': + pp.StringSection = !pp.StringSection; + break; + case '\r': + return false; + default: + if ((int)current == 0x1A) + { + // IMPORTANT: ignore invisible characters such as SUB. + return false; + } + + if (Char.IsWhiteSpace(current) && !pp.AssignSection && !pp.StringSection) + { + bool moveNext = ParseLastSymbol(pp, row, column); + if (moveNext) + { + _symbols.Add(CreateSpecialSymbol(pp.File, '\n', row, column)); + return true; + } + + return false; + } + + if (pp.AssignAhead) + { + pp.AssignAhead = false; + ParseLastSymbol(pp, row, column); + break; + } + + if (pp.DotSection && current != '.') + { + ParseLastSymbol(pp, row, column); + pp.DotSection = false; + } + + if (current == '.' && !pp.StringSection) + { + if (!pp.DotSection) + { + ParseLastSymbol(pp, row, column); + pp.DotSection = true; + } + } + + if (current == ':' && !pp.StringSection) + { + if (!pp.AssignSection) + { + ParseLastSymbol(pp, row, column); + } + + pp.AssignSection = true; + } + + if (current == '=' && !pp.StringSection) + { + pp.AssignSection = false; + pp.AssignAhead = true; + } + + break; + } + + pp.Temp.Append(current); + return false; + } + + private bool ParseLastSymbol(ParseParams pp, int row, int column) + { + if (pp.Temp.Length > 0) + { + Symbol s = new Symbol(pp.File, pp.Temp.ToString(), row, column); + + pp.Temp.Length = 0; + + if (s.ToString().StartsWith(Symbol.Comment.ToString())) + { + // ignore the rest symbols on this line because they are in comment. + return true; + } + + _symbols.Add(s); + } + + return false; + } + + private static Symbol CreateSpecialSymbol(string file, char value, int row, int column) + { + string str; + switch (value) + { + case '\n': + str = Environment.NewLine; + break; + case '{': + str = "{"; + break; + case '}': + str = "}"; + break; + case '(': + str = "("; + break; + case ')': + str = ")"; + break; + case '[': + str = "["; + break; + case ']': + str = "]"; + break; + case ';': + str = ";"; + break; + case ',': + str = ","; + break; + case '|': + str = "|"; + break; + default: + throw new ArgumentException("value is not a special character"); + } + + return new Symbol(file, str, row, column); + } + + #endregion + + #region Static Parse Helper + + public static ITypeAssignment ParseBasicTypeDef(IModule module, string name, ISymbolEnumerator symbols, bool isMacroSyntax = false) + { + Symbol current = symbols.NextNonEOLSymbol(); + + if (current == Symbol.Bits) + { + return new BitsType(module, name, symbols); + } + if (IntegerType.IsIntegerType(current)) + { + return new IntegerType(module, name, current, symbols); + } + if (UnsignedType.IsUnsignedType(current)) + { + return new UnsignedType(module, name, current, symbols); + } + if (current == Symbol.Opaque) + { + return new OpaqueType(module, name, symbols); + } + if (current == Symbol.IpAddress) + { + return new IpAddressType(module, name, symbols); + } + if (current == Symbol.TextualConvention) + { + return new TextualConvention(module, name, symbols); + } + if (current == Symbol.Octet) + { + Symbol next = symbols.NextNonEOLSymbol(); + + if (next == Symbol.String) + { + return new OctetStringType(module, name, symbols); + } + + symbols.PutBack(next); + } + if (current == Symbol.Object) + { + Symbol next = symbols.NextNonEOLSymbol(); + + if (next == Symbol.Identifier) + { + return new ObjectIdentifierType(module, name, symbols); + } + + symbols.PutBack(next); + } + if (current == Symbol.Sequence) + { + Symbol next = symbols.NextNonEOLSymbol(); + + if (next == Symbol.Of) + { + return new SequenceOf(module, name, symbols); + } + else + { + symbols.PutBack(next); + return new Sequence(module, name, symbols); + } + } + if (current == Symbol.Choice) + { + return new Choice(module, name, symbols); + } + + + return new TypeAssignment(module, name, current, symbols, isMacroSyntax); + } + + public static void ParseOidValue(ISymbolEnumerator symbols, out string parent, out uint value) + { + parent = null; + value = 0; + + Symbol current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.OpenBracket); + + Symbol previous = null; + StringBuilder longParent = new StringBuilder(); + + current = symbols.NextNonEOLSymbol(); + longParent.Append(current); + + while ((current = symbols.NextNonEOLSymbol()) != null) + { + bool succeeded; + + if (current == Symbol.OpenParentheses) + { + longParent.Append(current); + + current = symbols.NextNonEOLSymbol(); + succeeded = UInt32.TryParse(current.ToString(), out value); + current.Assert(succeeded, "not a decimal"); + longParent.Append(current); + current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.CloseParentheses); + longParent.Append(current); + continue; + } + + if (current == Symbol.CloseBracket) + { + parent = longParent.ToString(); + return; + } + + succeeded = UInt32.TryParse(current.ToString(), out value); + if (succeeded) + { + // numerical way + while ((current = symbols.NextNonEOLSymbol()) != Symbol.CloseBracket) + { + longParent.Append(".").Append(value); + succeeded = UInt32.TryParse(current.ToString(), out value); + current.Assert(succeeded, "not a decimal"); + } + + current.Expect(Symbol.CloseBracket); + parent = longParent.ToString(); + return; + } + + longParent.Append("."); + longParent.Append(current); + current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.OpenParentheses); + longParent.Append(current); + current = symbols.NextNonEOLSymbol(); + succeeded = UInt32.TryParse(current.ToString(), out value); + current.Assert(succeeded, "not a decimal"); + longParent.Append(current); + current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.CloseParentheses); + longParent.Append(current); + previous = current; + } + + throw MibException.Create("end of file reached", previous); + } + + + public static ValueRanges DecodeRanges(ISymbolEnumerator symbols) + { + ValueRanges result = new ValueRanges(); + + Symbol startSymbol = symbols.NextNonEOLSymbol(); + Symbol current = startSymbol; + current.Expect(Symbol.OpenParentheses); + + while (current != Symbol.CloseParentheses) + { + Symbol value1Symbol = symbols.NextNonEOLSymbol(); + + if ((value1Symbol == Symbol.Size) && !result.IsSizeDeclaration) + { + result.IsSizeDeclaration = true; + symbols.NextNonEOLSymbol().Expect(Symbol.OpenParentheses); + continue; + } + + // check for valid number + Int64? value1 = DecodeNumber(value1Symbol); + if (!value1.HasValue) + { + value1Symbol.Assert(false, "Invalid range declaration!"); + } + + // process next symbol + ValueRange range; + current = symbols.NextNonEOLSymbol(); + + if (current == Symbol.DoubleDot) + { + // its a continuous range + Symbol value2Symbol = symbols.NextNonEOLSymbol(); + Int64? value2 = DecodeNumber(value2Symbol); + value2Symbol.Assert(value2.HasValue && (value2.Value >= value1.Value), "Invalid range declaration!"); + + if (value2.Value == value1.Value) + { + range = new ValueRange(value1.Value, null); + } + else + { + range = new ValueRange(value1.Value, value2.Value); + } + + current = symbols.NextNonEOLSymbol(); + } + else + { + // its a single number + range = new ValueRange(value1.Value, null); + } + + // validate range + if (result.IsSizeDeclaration) + { + value1Symbol.Assert(range.Start >= 0, "Invalid range declaration! Size must be greater than 0"); + } + + result.Add(range); + + // check next symbol + current.Expect(Symbol.Pipe, Symbol.CloseParentheses); + } + + if (result.IsSizeDeclaration) + { + current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.CloseParentheses); + } + + // validate ranges in between + for (int i=0; i<result.Count; i++) + { + for (int k=i+1; k<result.Count; k++) + { + startSymbol.Assert(!result[i].IntersectsWith(result[k]), "Invalid range declaration! Overlapping of ranges!"); + } + } + + return result; + } + + public static Int64? DecodeNumber(Symbol number) + { + Int64 result; + string numString = (number != null) ? number.ToString() : null; + + if (!String.IsNullOrEmpty(numString)) + { + if (numString.StartsWith("'") && (numString.Length > 3)) + { + // search second apostrophe + int end = numString.IndexOf(''', 1); + if (end == (numString.Length - 2)) + { + try + { + switch (numString[numString.Length - 1]) + { + case 'b': + case 'B': + result = Convert.ToInt64(numString.Substring(1, numString.Length - 3), 2); + return result; + case 'h': + case 'H': + result = Convert.ToInt64(numString.Substring(1, numString.Length - 3), 16); + return result; + } + } + catch + { + } + } + } + else if (Int64.TryParse(numString, out result)) + { + return result; + } + } + + return null; + } + + public static ValueMap DecodeEnumerations(ISymbolEnumerator symbols) + { + Symbol current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.OpenBracket); + + ValueMap map = new ValueMap(); + do + { + current = symbols.NextNonEOLSymbol(); + string identifier = current.ToString(); + + current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.OpenParentheses); + + current = symbols.NextNonEOLSymbol(); + Int64 enumValue; + if (Int64.TryParse(current.ToString(), out enumValue)) + { + try + { + // Have to include the number as it seems repeated identifiers are allowed ?? + map.Add(enumValue, String.Format("{0}({1})", identifier, enumValue)); + } + catch (ArgumentException ex) + { + current.Assert(false, ex.Message); + } + } + else + { + // Need to get "DefinedValue". + } + + current = symbols.NextNonEOLSymbol(); + current.Expect(Symbol.CloseParentheses); + + current = symbols.NextNonEOLSymbol(); + } while (current == Symbol.Comma); + + current.Expect(Symbol.CloseBracket); + + return map; + } + + #endregion + + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MaxAccess.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MaxAccess.cs new file mode 100644 index 00000000000..f8029900b56 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MaxAccess.cs @@ -0,0 +1,17 @@ +using System; +using System.Collections.Generic; +using System.Linq; +using System.Text; + +namespace Lextm.SharpSnmpLib.Mib +{ + public enum MaxAccess + { + notAccessible, + accessibleForNotify, + readOnly, + readWrite, + readCreate + } + +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibDocument.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibDocument.cs new file mode 100644 index 00000000000..aac3b280ed3 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibDocument.cs @@ -0,0 +1,57 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/17 + * Time: 17:38 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +using System.Collections.Generic; + +namespace Lextm.SharpSnmpLib.Mib +{ + /// <summary> + /// MIB document. + /// </summary> + public sealed class MibDocument + { + private readonly List<IModule> _modules = new List<IModule>(); + + /// <summary> + /// Initializes a new instance of the <see cref="MibDocument" /> class. + /// </summary> + /// <param name="file">The file.</param> + public MibDocument(string file) + : this(new Lexer(file)) + { + } + + /// <summary> + /// Initializes a new instance of the <see cref="MibDocument"/> class. + /// </summary> + /// <param name="lexer">The lexer.</param> + public MibDocument(Lexer lexer) + { + ISymbolEnumerator symbols = lexer.GetEnumerator(); + + Symbol current; + while ((current = symbols.NextNonEOLSymbol()) != null) + { + symbols.PutBack(current); + _modules.Add(new MibModule(symbols)); + } + } + + /// <summary> + /// <see cref="MibModule"/> containing in this document. + /// </summary> + public IList<IModule> Modules + { + get + { + return _modules; + } + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibException.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibException.cs new file mode 100644 index 00000000000..efd89b3f756 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibException.cs @@ -0,0 +1,113 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/17 + * Time: 16:33 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +using System; +using System.Globalization; +#if (!SILVERLIGHT) +using System.Runtime.Serialization; +using System.Security.Permissions; +#endif + +namespace Lextm.SharpSnmpLib.Mib +{ + /// <summary> + /// Description of MibException. + /// </summary> + [Serializable] + [System.Diagnostics.CodeAnalysis.SuppressMessage("Microsoft.Naming", "CA1704:IdentifiersShouldBeSpelledCorrectly", MessageId = "Mib")] + public sealed class MibException : Exception + { + /// <summary> + /// Symbol. + /// </summary> + public Symbol Symbol { get; private set; } + + /// <summary> + /// Creates a <see cref="MibException"/>. + /// </summary> + public MibException() + { + } + + /// <summary> + /// Creates a <see cref="SnmpException"/> instance with a specific <see cref="string"/>. + /// </summary> + /// <param name="message">Message</param> + public MibException(string message) : base(message) + { + } + + /// <summary> + /// Creates a <see cref="MibException"/> instance with a specific <see cref="string"/> and an <see cref="Exception"/>. + /// </summary> + /// <param name="message">Message</param> + /// <param name="inner">Inner exception</param> + public MibException(string message, Exception inner) + : base(message, inner) + { + } +#if (!SILVERLIGHT) + /// <summary> + /// Creates a <see cref="MibException"/> instance. + /// </summary> + /// <param name="info">Info</param> + /// <param name="context">Context</param> + private MibException(SerializationInfo info, StreamingContext context) : base(info, context) + { + if (info == null) + { + throw new ArgumentNullException("info"); + } + + Symbol = (Symbol)info.GetValue("Symbol", typeof(Symbol)); + } + + /// <summary> + /// Gets object data. + /// </summary> + /// <param name="info">Info</param> + /// <param name="context">Context</param> + [SecurityPermission(SecurityAction.Demand, SerializationFormatter = true)] + public override void GetObjectData(SerializationInfo info, StreamingContext context) + { + base.GetObjectData(info, context); + info.AddValue("Symbol", Symbol); + } +#endif + + /// <summary> + /// Creates a <see cref="MibException"/> with a specific <see cref="Symbol"/>. + /// </summary> + /// <param name="message">Message</param> + /// <param name="symbol">Symbol</param> + /// <returns></returns> + public static MibException Create(string message, Symbol symbol) + { + if (symbol == null) + { + throw new ArgumentNullException("symbol"); + } + + if (String.IsNullOrEmpty(message)) + { + message = "Unknown MIB Exception"; + } + + message = String.Format( + "{0} (file: "{1}"; row: {2}; column: {3})", + message, + symbol.File, + symbol.Row + 1, + symbol.Column + 1); + + MibException ex = new MibException(message) { Symbol = symbol }; + return ex; + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibModule.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibModule.cs new file mode 100644 index 00000000000..cacfd045979 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibModule.cs @@ -0,0 +1,294 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/17 + * Time: 17:38 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +using System; +using System.Collections.Generic; +using Lextm.SharpSnmpLib.Mib.Elements; +using Lextm.SharpSnmpLib.Mib.Elements.Entities; +using Lextm.SharpSnmpLib.Mib.Elements.Types; + +namespace Lextm.SharpSnmpLib.Mib +{ + /// <summary> + /// MIB module class. + /// </summary> + [System.Diagnostics.CodeAnalysis.SuppressMessage("Microsoft.Naming", "CA1704:IdentifiersShouldBeSpelledCorrectly", MessageId = "Mib")] + public sealed class MibModule : IModule + { + private readonly string _name; + private readonly Imports _imports; + private readonly Exports _exports; + private readonly List<IElement> _tokens = new List<IElement>(); + + /// <summary> + /// Creates a <see cref="MibModule"/> with a specific <see cref="Lexer"/>. + /// </summary> + /// <param name="name">Module name</param> + /// <param name="symbols">Lexer</param> + [System.Diagnostics.CodeAnalysis.SuppressMessage("Microsoft.Naming", "CA1704:IdentifiersShouldBeSpelledCorrectly", MessageId = "lexer")] + public MibModule(ISymbolEnumerator symbols) + { + if (symbols == null) + { + throw new ArgumentNullException("lexer"); + } + + Symbol temp = symbols.NextNonEOLSymbol(); + temp.AssertIsValidIdentifier(); + _name = temp.ToString().ToUpperInvariant(); // all module names are uppercase + + temp = symbols.NextNonEOLSymbol(); + temp.Expect(Symbol.Definitions); + + temp = symbols.NextNonEOLSymbol(); + temp.Expect(Symbol.Assign); + + temp = symbols.NextSymbol(); + temp.Expect(Symbol.Begin); + + temp = symbols.NextNonEOLSymbol(); + if (temp == Symbol.Imports) + { + _imports = ParseDependents(symbols); + } + else if (temp == Symbol.Exports) + { + _exports = ParseExports(symbols); + } + else + { + symbols.PutBack(temp); + } + + ParseEntities(symbols); + } + + #region Accessors + + /// <summary> + /// Module name. + /// </summary> + public string Name + { + get { return _name; } + } + + public Exports Exports + { + get { return _exports; } + } + + public Imports Imports + { + get { return _imports; } + } + + public List<IElement> Tokens + { + get { return this._tokens; } + } + + /// <summary> + /// Entities + Types + all other elements implementing IDeclaration + /// </summary> + public IList<IDeclaration> Declarations + { + get + { + IList<IDeclaration> result = new List<IDeclaration>(); + foreach (IElement e in _tokens) + { + IDeclaration decl = e as IDeclaration; + if (decl != null) + { + result.Add(decl); + } + } + + return result; + } + } + + /// <summary> + /// OID nodes. + /// </summary> + public IList<IEntity> Entities + { + get + { + IList<IEntity> result = new List<IEntity>(); + foreach (IElement e in _tokens) + { + IEntity entity = e as IEntity; + if (entity != null) + { + result.Add(entity); + } + } + + return result; + } + } + + public IList<ITypeAssignment> Types + { + get + { + IList<ITypeAssignment> result = new List<ITypeAssignment>(); + foreach (IElement e in _tokens) + { + ITypeAssignment type = e as ITypeAssignment; + if (type != null) + { + result.Add(type); + } + } + + return result; + } + } + + #endregion + + #region Parsing of Symbols + + private Exports ParseExports(ISymbolEnumerator symbols) + { + return new Exports(this, symbols); + } + + private Imports ParseDependents(ISymbolEnumerator symbols) + { + return new Imports(this, symbols); + } + + private void ParseEntities(ISymbolEnumerator symbols) + { + Symbol temp = symbols.NextNonEOLSymbol(); + SymbolList buffer = new SymbolList(); + + while (temp != Symbol.End) + { + if (temp == Symbol.Assign) + { + ParseEntity(buffer, symbols); + buffer.Clear(); + // skip linebreaks behind an entity + temp = symbols.NextNonEOLSymbol(); + } + else + { + buffer.Add(temp); + temp = symbols.NextSymbol(); + } + } + } + + private void ParseEntity(SymbolList preAssignSymbols, ISymbolEnumerator symbols) + { + if ((preAssignSymbols == null) || (preAssignSymbols.Count == 0)) + { + Symbol s = symbols.NextSymbol(); + if (s != null) + { + s.Assert(false, "Invalid Entity declaration"); + } + else + { + throw new MibException("Invalid Entity declaration"); + } + } + + // check for a valid identifier + preAssignSymbols[0].AssertIsValidIdentifier(); + + if (preAssignSymbols.Count == 1) + { + // its a typedef + _tokens.Add(Lexer.ParseBasicTypeDef(this, preAssignSymbols[0].ToString(), symbols, isMacroSyntax: false)); + return; + } + + ISymbolEnumerator preAssignSymbolsEnumerator = preAssignSymbols.GetSymbolEnumerator(); + preAssignSymbolsEnumerator.NextNonEOLSymbol(); // returns identifier + Symbol type = preAssignSymbolsEnumerator.NextNonEOLSymbol(); + + // parse declarations + if (type == Symbol.Object) + { + Symbol next = preAssignSymbolsEnumerator.NextNonEOLSymbol(); + + if (next == Symbol.Identifier) + { + _tokens.Add(new OidValueAssignment(this, preAssignSymbols, symbols)); + return; + } + else if (next != null) + { + preAssignSymbolsEnumerator.PutBack(next); + } + } + if (type == Symbol.ModuleIdentity) + { + _tokens.Add(new ModuleIdentity(this, preAssignSymbols, symbols)); + return; + } + if (type == Symbol.ObjectType) + { + _tokens.Add(new ObjectType(this, preAssignSymbols, symbols)); + return; + } + if (type == Symbol.ObjectGroup) + { + _tokens.Add(new ObjectGroup(this, preAssignSymbols, symbols)); + return; + } + if (type == Symbol.NotificationGroup) + { + _tokens.Add(new NotificationGroup(this, preAssignSymbols, symbols)); + return; + } + if (type == Symbol.ModuleCompliance) + { + _tokens.Add(new ModuleCompliance(this, preAssignSymbols, symbols)); + return; + } + if (type == Symbol.NotificationType) + { + _tokens.Add(new NotificationType(this, preAssignSymbols, symbols)); + return; + } + if (type == Symbol.ObjectIdentity) + { + _tokens.Add(new ObjectIdentity(this, preAssignSymbols, symbols)); + return; + } + if (type == Symbol.Macro) + { + _tokens.Add(new Macro(this, preAssignSymbols, symbols)); + return; + } + if (type == Symbol.TrapType) + { + _tokens.Add(new TrapType(this, preAssignSymbols, symbols)); + return; + } + if (type == Symbol.AgentCapabilities) + { + _tokens.Add(new AgentCapabilities(this, preAssignSymbols, symbols)); + return; + } + + preAssignSymbols[1].Assert(false, "Unknown/Invalid declaration"); + } + + #endregion + + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibResolver.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibResolver.cs new file mode 100644 index 00000000000..96978e1ae3a --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibResolver.cs @@ -0,0 +1,97 @@ +using System; +using System.Collections.Generic; +using System.Linq; +using System.Text; +using System.IO; +using System.Reflection; + +namespace Lextm.SharpSnmpLib.Mib +{ + public interface IMibResolver + { + IModule Resolve(string moduleName); + } + + public class FileSystemMibResolver : IMibResolver + { + private string _path; + private bool _recursive; + + public FileSystemMibResolver(string path, bool recursive) + { + _path = path; + _recursive = recursive; + } + + #region IMibResolver Member + + public IModule Resolve(string moduleName) + { + if (Directory.Exists(_path)) + { + string[] matchedFiles = Directory.GetFiles( + _path, + "*", + (_recursive) ? SearchOption.AllDirectories : SearchOption.TopDirectoryOnly); + + if ((matchedFiles != null) && (matchedFiles.Length >= 1)) + { + foreach (string matchedFile in matchedFiles) + { + if (Path.GetFileNameWithoutExtension(matchedFile.ToLowerInvariant()) == moduleName.ToLowerInvariant()) + { + try + { + MibDocument md = new MibDocument (matchedFile); + if (md.Modules.Count > 0) + { + return md.Modules [0]; + } + } catch + { + } + } + } + } + } + + return null; + } + + #endregion + + } + + // earlier code for search of versioned MIBs: + // + //private const string Pattern = "-V[0-9]+$"; + //public static bool AllDependentsAvailable(MibModule module, IDictionary<string, MibModule> modules) + //{ + // foreach (string dependent in module.Dependents) + // { + // if (!DependentFound(dependent, modules)) + // { + // return false; + // } + // } + + // return true; + //} + + //private static bool DependentFound(string dependent, IDictionary<string, MibModule> modules) + //{ + // if (!Regex.IsMatch(dependent, Pattern)) + // { + // return modules.ContainsKey(dependent); + // } + + // if (modules.ContainsKey(dependent)) + // { + // return true; + // } + + // string dependentNonVersion = Regex.Replace(dependent, Pattern, string.Empty); + // return modules.ContainsKey(dependentNonVersion); + //} + +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibTree.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibTree.cs new file mode 100644 index 00000000000..a5174bc19e9 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibTree.cs @@ -0,0 +1,130 @@ +using System.Collections.Generic; +using Lextm.SharpSnmpLib.Mib.Elements.Entities; + +namespace Lextm.SharpSnmpLib.Mib +{ + /// <summary> + /// Builds up a tree from a single MIB + /// </summary> + public class MibTree + { + private readonly List<MibTreeNode> _root = new List<MibTreeNode>(); + + public MibTree(MibModule module) + { + IList<IEntity> entities = module.Entities; + + if (entities.Count > 0) + { + // try to find module identity as root + foreach (IEntity element in entities) + { + ModuleIdentity mi = element as ModuleIdentity; + + if (mi != null) + { + _root.Add(new MibTreeNode(null, mi)); + } + } + + // find OID assignments as root, if there are any that are not below ModuleIdentity + foreach (IEntity element in entities) + { + OidValueAssignment oa = element as OidValueAssignment; + + if (oa != null) + { + _root.Add(new MibTreeNode(null, oa)); + } + } + + FilterRealRoots (entities); + + foreach (MibTreeNode mibTreeNode in _root) + { + entities.Remove (mibTreeNode.Entity); + } + + if (_root.Count == 0) + { + //no module identity, assume first entity is root + _root.Add(new MibTreeNode(null, entities[0])); + } + + foreach (MibTreeNode mibTreeNode in _root) + { + if (entities.Contains (mibTreeNode.Entity)) + { + entities.Remove (mibTreeNode.Entity); + } + BuildTree(mibTreeNode, entities); + UpdateTreeNodeTypes(mibTreeNode); + } + } + } + + public IList<MibTreeNode> Root + { + get { return _root; } + } + + private bool EntityExists(IList<IEntity> entities, string name) + { + foreach(IEntity entity in entities) + { + if (entity.Name == name) + { + return true; + } + } + return false; + } + + private void FilterRealRoots(IList<IEntity> entities) + { + int i = 0; + while (i < _root.Count) + { + if (EntityExists(entities, _root[i].Entity.Parent)) + { + _root.RemoveAt(i); + } + else + { + i++; + } + } + } + + private void BuildTree(MibTreeNode node, IList<IEntity> entities) + { + int i = 0; + while (i < entities.Count) + { + if (entities[i].Parent == node.Entity.Name) + { + node.AddChild(entities[i]); + entities.RemoveAt(i); + } + else + { + i++; + } + } + + foreach (MibTreeNode childNode in node.ChildNodes) + { + BuildTree(childNode, entities); + } + } + + private void UpdateTreeNodeTypes(MibTreeNode node) + { + node.UpdateNodeType(); + foreach (MibTreeNode childNode in node.ChildNodes) + { + UpdateTreeNodeTypes(childNode); + } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibTreeNode.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibTreeNode.cs new file mode 100644 index 00000000000..386c8e5cde7 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibTreeNode.cs @@ -0,0 +1,112 @@ +using System; +using System.Collections.Generic; +using Lextm.SharpSnmpLib.Mib.Elements.Entities; +using Lextm.SharpSnmpLib.Mib.Elements.Types; + +namespace Lextm.SharpSnmpLib.Mib +{ + [Flags] + public enum MibTreeNodeType + { + Unknown = 0, + Container = (1 << 0), + Scalar = (1 << 1), + Table = (1 << 2), + TableRow = (1 << 3), + TableCell = (1 << 4), + NotificationRelated = (1 << 5), + ConformanceRelated = (1 << 6) + } + + + public class MibTreeNode + { + private MibTreeNode _parent = null; + private List<MibTreeNode> _childNodes = new List<MibTreeNode>(); + private IEntity _entity = null; + private MibTreeNodeType _nodeType = MibTreeNodeType.Unknown; + + public MibTreeNode(MibTreeNode parent, IEntity entity) + { + _parent = parent; + _entity = entity; + } + + public MibTreeNode Parent + { + get { return _parent; } + } + + public IEntity Entity + { + get { return _entity; } + } + + public MibTreeNodeType NodeType + { + get { return _nodeType; } + } + + public List<MibTreeNode> ChildNodes + { + get { return _childNodes; } + } + + public MibTreeNode AddChild(IEntity element) + { + MibTreeNode result = new MibTreeNode(this, element); + this.ChildNodes.Add(result); + + return result; + } + + public void UpdateNodeType() + { + _nodeType = MibTreeNodeType.Unknown; + + if (_entity != null) + { + if ((_entity is OidValueAssignment) || (_entity is ObjectIdentity)) + { + _nodeType |= MibTreeNodeType.Container; + return; + } + else if (_childNodes.Count > 0) + { + _nodeType |= MibTreeNodeType.Container; + } + + if (_entity is ObjectType) + { + ObjectType ot = _entity as ObjectType; + + if (ot.Syntax is SequenceOf) + { + _nodeType |= MibTreeNodeType.Table; + } + else if (ot.Syntax is Sequence) + { + _nodeType |= MibTreeNodeType.TableRow; + } + else if ((_parent != null) && ((_parent.NodeType & MibTreeNodeType.TableRow) != 0)) + { + _nodeType |= MibTreeNodeType.TableCell; + _nodeType |= MibTreeNodeType.Scalar; + } + else + { + _nodeType |= MibTreeNodeType.Scalar; + } + } + else if ((_entity is ModuleCompliance) || (_entity is ObjectGroup) || (_entity is NotificationGroup)) + { + _nodeType |= MibTreeNodeType.ConformanceRelated; + } + else if ((_entity is NotificationGroup) || (_entity is NotificationType)) + { + _nodeType |= MibTreeNodeType.NotificationRelated; + } + } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibTypesResolver.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibTypesResolver.cs new file mode 100644 index 00000000000..1e7529af14f --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/MibTypesResolver.cs @@ -0,0 +1,216 @@ +using System; +using System.Collections.Generic; +using System.Text.RegularExpressions; +using Lextm.SharpSnmpLib.Mib.Elements; +using Lextm.SharpSnmpLib.Mib.Elements.Entities; +using Lextm.SharpSnmpLib.Mib.Elements.Types; + +namespace Lextm.SharpSnmpLib.Mib +{ + public static class MibTypesResolver + { + private static readonly Regex _namedOidPathRegex = new Regex(@"^(?<Name>[^(]+)((?<Value>\d+))$"); + private static readonly List<IMibResolver> _resolver = new List<IMibResolver>(); + private static readonly List<IModule> _cachedModules = new List<IModule>(); + + public static void RegisterResolver(IMibResolver resolver) + { + if (resolver != null) + { + _resolver.Add(resolver); + } + } + + public static IModule ResolveModule(string moduleName) + { + // check if module is already cached + foreach (MibModule cachedModule in _cachedModules) + { + if (cachedModule.Name == moduleName) + { + return cachedModule; + } + } + + foreach (IMibResolver resolver in _resolver) + { + IModule resolvedModule = resolver.Resolve(moduleName); + if (resolvedModule != null) + { + ResolveTypes(resolvedModule); + _cachedModules.Add(resolvedModule); + return resolvedModule; + } + } + + return null; + } + + public static void ResolveTypes(IModule module) + { + foreach (IEntity entity in module.Entities) + { + ITypeReferrer typeReferringEntity = entity as ITypeReferrer; + + if (typeReferringEntity != null) + { + CheckTypeReferrer(module, typeReferringEntity); + } + } + + if (!_cachedModules.Contains(module)) + { + _cachedModules.Add(module); + } + } + + private static void CheckTypeReferrer(IModule module, ITypeReferrer typeReferringEntity) + { + TypeAssignment unknownType = typeReferringEntity.ReferredType as TypeAssignment; + if (unknownType != null) + { + typeReferringEntity.ReferredType = ResolveType(module, unknownType); + + if (typeReferringEntity.ReferredType is TypeAssignment) + { + Console.WriteLine(String.Format("Could not resolve type '{0}' declared in module '{1}'", (typeReferringEntity.ReferredType as TypeAssignment).Type, typeReferringEntity.ReferredType.Module.Name)); + } + } + + ITypeReferrer nextTypeReferringEntity = typeReferringEntity.ReferredType as ITypeReferrer; + if (nextTypeReferringEntity != null) + { + CheckTypeReferrer(module, nextTypeReferringEntity); + } + } + + public static ITypeAssignment ResolveType(IModule module, TypeAssignment type) + { + ITypeAssignment result = ResolveDeclaration(module, type.Type) as ITypeAssignment; + + return (result != null) ? result : type; + } + + public static IDeclaration ResolveDeclaration(IModule module, string name) + { + if ((module == null) || String.IsNullOrEmpty(name)) + { + return null; + } + + // check module internal types + foreach (IDeclaration decl in module.Declarations) + { + if (decl.Name == name) + { + return decl; + } + } + + // check if type is imported + if (module.Imports != null) + { + ImportsFrom imports = module.Imports.GetImportFromType(name); + if (imports != null) + { + IModule importedModule = ResolveModule(imports.Module); + if (importedModule != null) + { + return ResolveDeclaration(importedModule, name); + } + } + } + + return null; + } + + public static ObjectIdentifier ResolveOid(IEntity entity) + { + ObjectIdentifier result = new ObjectIdentifier(); + + if (entity != null) + { + ResolveOid(entity, result); + } + + return result; + } + + private static void ResolveOid(IEntity entity, ObjectIdentifier result) + { + result.Prepend(entity.Name, entity.Value); + + // check parent + if (!String.IsNullOrEmpty(entity.Parent)) + { + string[] pathParts = entity.Parent.Split('.'); + uint value; + + // all parts except the first should have their value directly or indirectly with them + if (pathParts.Length > 1) + { + for (int i=pathParts.Length-1; i>=1; i--) + { + if (uint.TryParse(pathParts[i], out value)) + { + result.Prepend("", value); + } + else + { + Match m = _namedOidPathRegex.Match(pathParts[i]); + if (m.Success) + { + result.Prepend(m.Groups["Name"].Value, uint.Parse(m.Groups["Value"].Value)); + } + else + { + throw new MibException("Invalid OID path detected for entity '" + entity.Name + "' in module '" + entity.Module + "'!"); + } + } + } + } + + // parse root part: either another entity or a standard root object + if (IsOidRoot(pathParts[0], out value)) + { + result.Prepend(pathParts[0], value); + } + else + { + // try to find entity inside this module + if (entity.Module != null) + { + entity = ResolveDeclaration(entity.Module, pathParts[0]) as IEntity; + + if (entity != null) + { + ResolveOid(entity, result); + } + else + { + result.Prepend("", uint.MaxValue); + } + } + else + { + result.Prepend("", uint.MaxValue); + } + } + } + } + + public static bool IsOidRoot(string name, out uint value) + { + value = uint.MaxValue; + + switch (name) + { + case "ccitt": value = 0; return true; + case "iso": value = 1; return true; + case "joint-iso-ccitt": value = 2; return true; + } + + return false; + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ObjectIdentifier.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ObjectIdentifier.cs new file mode 100644 index 00000000000..04248043926 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ObjectIdentifier.cs @@ -0,0 +1,54 @@ +using System.Collections.Generic; +using System.Text; + +namespace Lextm.SharpSnmpLib.Mib +{ + public class ObjectIdentifier: List<KeyValuePair<string, uint>> + { + public void Add(string name, uint oid) + { + this.Add(new KeyValuePair<string, uint>(name, oid)); + } + + public void Prepend(string name, uint oid) + { + this.Insert(0, new KeyValuePair<string, uint>(name, oid)); + } + + public void Insert(int index, string name, uint oid) + { + this.Insert(index, new KeyValuePair<string, uint>(name, oid)); + } + + public string GetOidString() + { + StringBuilder result = new StringBuilder(); + + foreach (KeyValuePair<string, uint> level in this) + { + result.Append(level.Value); + result.Append('.'); + } + + if (result.Length > 0) + { + result.Length--; + } + + return result.ToString(); + } + + public uint[] GetOidValues() + { + List<uint> result = new List<uint>(); + + foreach (KeyValuePair<string, uint> level in this) + { + result.Add(level.Value); + } + + return result.ToArray(); + } + + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Status.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Status.cs new file mode 100644 index 00000000000..4ddd3babeb5 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Status.cs @@ -0,0 +1,17 @@ +using System; +using System.Collections.Generic; +using System.Linq; +using System.Text; + +namespace Lextm.SharpSnmpLib.Mib +{ + public enum Status + { + current, + deprecated, + obsolete, + mandatory, + optional + } + +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Symbol.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Symbol.cs new file mode 100644 index 00000000000..b11386d8715 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/Symbol.cs @@ -0,0 +1,357 @@ +/* + * Created by SharpDevelop. + * User: lextm + * Date: 2008/5/17 + * Time: 17:14 + * + * To change this template use Tools | Options | Coding | Edit Standard Headers. + */ + +using System; +using System.Configuration; +using System.Globalization; +using System.Text; + +namespace Lextm.SharpSnmpLib.Mib +{ + /// <summary> + /// Description of Symbol. + /// </summary> + public sealed class Symbol : IEquatable<Symbol> + { + private readonly string _text; + private readonly int _row; + private readonly int _column; + private readonly string _file; + + private Symbol(string text) : this(null, text, -1, -1) + { + } + + /// <summary> + /// Creates a <see cref="Symbol"/>. + /// </summary> + /// <param name="file">File</param> + /// <param name="text">Text</param> + /// <param name="row">Row number</param> + /// <param name="column">column number</param> + public Symbol(string file, string text, int row, int column) + { + _file = file; + _text = text; + _row = row; + _column = column; + } + + /// <summary> + /// File. + /// </summary> + public string File + { + get + { + return _file; + } + } + + /// <summary> + /// Row number. + /// </summary> + public int Row + { + get + { + return _row; + } + } + + /// <summary> + /// Column number. + /// </summary> + public int Column + { + get + { + return _column; + } + } + + /// <summary> + /// Returns a <see cref="String"/> that represents this <see cref="Symbol"/>. + /// </summary> + /// <returns></returns> + public override string ToString() + { + return _text; + } + + /// <summary> + /// Determines whether the specified <see cref="Object"/> is equal to the current <see cref="Symbol"/>. + /// </summary> + /// <param name="obj">The <see cref="Object"/> to compare with the current <see cref="Symbol"/>. </param> + /// <returns><value>true</value> if the specified <see cref="Object"/> is equal to the current <see cref="Symbol"/>; otherwise, <value>false</value>. + /// </returns> + public override bool Equals(object obj) + { + if (obj == null) + { + return false; + } + + if (ReferenceEquals(this, obj)) + { + return true; + } + + return GetType() == obj.GetType() && Equals((Symbol)obj); + } + + /// <summary> + /// Serves as a hash function for a particular type. + /// </summary> + /// <returns>A hash code for the current <see cref="Symbol"/>.</returns> + public override int GetHashCode() + { + return _text.GetHashCode(); + } + + /// <summary> + /// The equality operator. + /// </summary> + /// <param name="left">Left <see cref="Symbol"/> object</param> + /// <param name="right">Right <see cref="Symbol"/> object</param> + /// <returns> + /// Returns <c>true</c> if the values of its operands are equal, <c>false</c> otherwise.</returns> + public static bool operator ==(Symbol left, Symbol right) + { + return Equals(left, right); + } + + /// <summary> + /// Determines whether the specified <see cref="Symbol"/> is equal to the current <see cref="Symbol"/>. + /// </summary> + /// <param name="left">Left <see cref="Symbol"/> object</param> + /// <param name="right">Right <see cref="Symbol"/> object</param> + /// <returns> + /// Returns <c>true</c> if the values of its operands are equal, <c>false</c> otherwise.</returns> + public static bool Equals(Symbol left, Symbol right) + { + object l = left; + object r = right; + if (l == r) + { + return true; + } + + if (l == null || r == null) + { + return false; + } + + return left._text.Equals(right._text); + } + + /// <summary> + /// The inequality operator. + /// </summary> + /// <param name="left">Left <see cref="Symbol"/> object</param> + /// <param name="right">Right <see cref="Symbol"/> object</param> + /// <returns> + /// Returns <c>true</c> if the values of its operands are not equal, <c>false</c> otherwise.</returns> + public static bool operator !=(Symbol left, Symbol right) + { + return !(left == right); + } + + #region IEquatable<Symbol> Members + /// <summary> + /// Indicates whether the current object is equal to another object of the same type. + /// </summary> + /// <param name="other">An object to compare with this object.</param> + /// <returns><value>true</value> if the current object is equal to the <paramref name="other"/> parameter; otherwise, <value>false</value>. + /// </returns> + public bool Equals(Symbol other) + { + return Equals(this, other); + } + + #endregion + + public static readonly Symbol Definitions = new Symbol("DEFINITIONS"); + public static readonly Symbol Begin = new Symbol("BEGIN"); + public static readonly Symbol Object = new Symbol("OBJECT"); + public static readonly Symbol Identifier = new Symbol("IDENTIFIER"); + public static readonly Symbol Assign = new Symbol("::="); + public static readonly Symbol OpenBracket = new Symbol("{"); + public static readonly Symbol CloseBracket = new Symbol("}"); + public static readonly Symbol Comment = new Symbol("--"); + public static readonly Symbol Imports = new Symbol("IMPORTS"); + public static readonly Symbol Semicolon = new Symbol(";"); + public static readonly Symbol From = new Symbol("FROM"); + public static readonly Symbol ModuleIdentity = new Symbol("MODULE-IDENTITY"); + public static readonly Symbol ObjectType = new Symbol("OBJECT-TYPE"); + public static readonly Symbol ObjectGroup = new Symbol("OBJECT-GROUP"); + public static readonly Symbol NotificationGroup = new Symbol("NOTIFICATION-GROUP"); + public static readonly Symbol ModuleCompliance = new Symbol("MODULE-COMPLIANCE"); + public static readonly Symbol Sequence = new Symbol("SEQUENCE"); + public static readonly Symbol NotificationType = new Symbol("NOTIFICATION-TYPE"); + public static readonly Symbol EOL = new Symbol(Environment.NewLine); + public static readonly Symbol ObjectIdentity = new Symbol("OBJECT-IDENTITY"); + public static readonly Symbol End = new Symbol("END"); + public static readonly Symbol Macro = new Symbol("MACRO"); + public static readonly Symbol Choice = new Symbol("CHOICE"); + public static readonly Symbol TrapType = new Symbol("TRAP-TYPE"); + public static readonly Symbol AgentCapabilities = new Symbol("AGENT-CAPABILITIES"); + public static readonly Symbol Comma = new Symbol(","); + public static readonly Symbol TextualConvention = new Symbol("TEXTUAL-CONVENTION"); + public static readonly Symbol Syntax = new Symbol("SYNTAX"); + public static readonly Symbol Bits = new Symbol("BITS"); + public static readonly Symbol Octet = new Symbol("OCTET"); + public static readonly Symbol String = new Symbol("STRING"); + public static readonly Symbol OpenParentheses = new Symbol("("); + public static readonly Symbol CloseParentheses = new Symbol(")"); + public static readonly Symbol Exports = new Symbol("EXPORTS"); + public static readonly Symbol DisplayHint = new Symbol("DISPLAY-HINT"); + public static readonly Symbol Status = new Symbol("STATUS"); + public static readonly Symbol Description = new Symbol("DESCRIPTION"); + public static readonly Symbol Reference = new Symbol("REFERENCE"); + public static readonly Symbol DoubleDot = new Symbol(".."); + public static readonly Symbol Pipe = new Symbol("|"); + public static readonly Symbol Size = new Symbol("SIZE"); + public static readonly Symbol Units = new Symbol("UNITS"); + public static readonly Symbol MaxAccess = new Symbol("MAX-ACCESS"); + public static readonly Symbol Access = new Symbol("ACCESS"); + public static readonly Symbol Index = new Symbol("INDEX"); + public static readonly Symbol Augments = new Symbol("AUGMENTS"); + public static readonly Symbol DefVal = new Symbol("DEFVAL"); + public static readonly Symbol Of = new Symbol("OF"); + public static readonly Symbol Integer = new Symbol("INTEGER"); + public static readonly Symbol Integer32 = new Symbol("Integer32"); + public static readonly Symbol IpAddress = new Symbol("IpAddress"); + public static readonly Symbol Counter32 = new Symbol("Counter32"); + public static readonly Symbol Counter = new Symbol("Counter"); + public static readonly Symbol TimeTicks = new Symbol("TimeTicks"); + public static readonly Symbol Opaque = new Symbol("Opaque"); + public static readonly Symbol Counter64 = new Symbol("Counter64"); + public static readonly Symbol Unsigned32 = new Symbol("Unsigned32"); + public static readonly Symbol Gauge32 = new Symbol("Gauge32"); + public static readonly Symbol Gauge = new Symbol("Gauge"); + public static readonly Symbol TruthValue = new Symbol("TruthValue"); + public static readonly Symbol Implied = new Symbol("IMPLIED"); + + internal void Expect(Symbol expected, params Symbol[] orExpected) + { + bool isExpected = (this == expected); + + if (!isExpected && (orExpected != null) && (orExpected.Length > 0)) + { + // check the alternatives + for (int i=0; i<orExpected.Length; i++) + { + if (this == orExpected[i]) + { + isExpected = true; + break; + } + } + } + + if (!isExpected) + { + if ((orExpected == null) || (orExpected.Length == 0)) + { + Assert(false, "Unexpected symbol found! Expected '" + expected.ToString() + "'"); + } + else + { + StringBuilder msg = new StringBuilder("Unexpected symbol found! Expected one of the following: '"); + msg.Append(expected); + + // check the alternatives + for (int i=0; i<orExpected.Length; i++) + { + msg.Append("', '"); + msg.Append(expected); + } + msg.Append("'"); + + Assert(false, msg.ToString()); + } + } + } + + internal void Assert(bool condition, string message) + { + if (!condition) + { + throw MibException.Create(message, this); + } + } + + internal void AssertIsValidIdentifier() + { + string message; + bool isValid = IsValidIdentifier(ToString(), out message); + Assert(isValid, message); + } + + internal bool IsValidIdentifier() + { + string message; + return IsValidIdentifier(ToString(), out message); + } + + private static bool IsValidIdentifier(string name, out string message) + { + if (UseStricterValidation && (name.Length < 1 || name.Length > 64)) + { + message = "an identifier must consist of 1 to 64 letters, digits, and hyphens"; + return false; + } + + if (!Char.IsLetter(name[0])) + { + message = "the initial character must be a letter"; + return false; + } + + if (name.EndsWith("-", StringComparison.Ordinal)) + { + message = "a hyphen cannot be the last character of an identifier"; + return false; + } + + if (name.Contains("--")) + { + message = "a hyphen cannot be immediately followed by another hyphen in an identifier"; + return false; + } + + if (UseStricterValidation && name.Contains("_")) + { + message = "underscores are not allowed in identifiers"; + return false; + } + + // TODO: SMIv2 forbids "-" except in module names and keywords + message = null; + return true; + } + + private static bool? _useStricterValidation; + + private static bool UseStricterValidation + { + get + { + if (_useStricterValidation == null) + { + object setting = ConfigurationManager.AppSettings["StricterValidationEnabled"]; + _useStricterValidation = setting != null && Convert.ToBoolean(setting.ToString(), CultureInfo.InvariantCulture); + } + + return _useStricterValidation.Value; + } + } + } +} \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/SymbolList.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/SymbolList.cs new file mode 100644 index 00000000000..5b2218e8bf5 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/SymbolList.cs @@ -0,0 +1,146 @@ +using System; +using System.Collections.Generic; +using System.Linq; +using System.Text; + +namespace Lextm.SharpSnmpLib.Mib +{ + public class SymbolList : List<Symbol> + { + public class SymbolEnumerator : ISymbolEnumerator + { + private SymbolList _list = null; + private int _index = -1; + + internal SymbolEnumerator(SymbolList list) + { + if (list == null) + { + throw new ArgumentNullException("lexer"); + } + + _list = list; + } + + #region ISymbolEnumerator Member + + public bool PutBack(Symbol item) + { + if ((_index < 0) || (_index >= _list.Count) || (item != _list[_index])) + { + throw new ArgumentException(@"wrong last symbol", "last"); + //return false; + } + + _index--; + return true; + } + + #endregion + + #region IEnumerator<Symbol> Member + + public Symbol Current + { + get + { + if ((_index >= 0) && (_index <= _list.Count)) + { + return _list[_index]; + } + + return null; + } + } + + #endregion + + #region IDisposable Member + + public void Dispose() + { + } + + #endregion + + #region IEnumerator Member + + object System.Collections.IEnumerator.Current + { + get { return this.Current; } + } + + public bool MoveNext() + { + _index++; + return (_index >= 0) && (_index < _list.Count); + } + + public void Reset() + { + _index = -1; + } + + #endregion + } + + /// <summary> + /// Initializes a new instance of the <see cref="SymbolList"/> class. + /// </summary> + public SymbolList() + { + } + + public ISymbolEnumerator GetSymbolEnumerator() + { + return new SymbolEnumerator(this); + } + + public string Join(string separator) + { + if (separator == null) + separator = ""; + + StringBuilder result = new StringBuilder(); + + foreach (Symbol s in this) + { + result.Append(s); + result.Append(separator); + } + + if (result.Length > 0) + { + result.Length -= separator.Length; + } + + return result.ToString(); + } + } + + public static class SymbolEnumeratorExtension + { + public static Symbol NextSymbol(this IEnumerator<Symbol> enumerator) + { + if (enumerator.MoveNext()) + { + return enumerator.Current; + } + + return null; + } + + public static Symbol NextNonEOLSymbol(this IEnumerator<Symbol> enumerator) + { + while (enumerator.MoveNext()) + { + if (enumerator.Current != Symbol.EOL) + { + return enumerator.Current; + } + } + + return null; + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ValueMap.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ValueMap.cs new file mode 100644 index 00000000000..48842356a20 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ValueMap.cs @@ -0,0 +1,103 @@ +using System; +using System.Collections.Generic; + +namespace Lextm.SharpSnmpLib.Mib +{ + public class ValueMap : Dictionary<Int64, string> + { + public ValueMap() + { + } + + /// <summary> + /// Returns the values of the map as continuous range. At best as one range. + /// </summary> + /// <returns></returns> + public ValueRanges GetContinousRanges() + { + ValueRanges result = new ValueRanges(); + + if (this.Count > 0) + { + List<Int64> values = new List<long>(this.Keys); + values.Sort(); + + Int64 last = values[0]; + Int64 offset = values[0]; + for (int i=1; i<values.Count; i++) + { + if (values[i] != last + 1) + { + if (last == offset) + { + result.Add(new ValueRange(offset, null)); + } + else + { + result.Add(new ValueRange(offset, last)); + } + + offset = values[i]; + } + + last = values[i]; + } + + if (last == offset) + { + result.Add(new ValueRange(offset, null)); + } + else + { + result.Add(new ValueRange(offset, last)); + } + } + + return result; + } + + /// <summary> + /// Gets the highest value contained in this value map. + /// </summary> + /// <returns></returns> + public Int64 GetHighestValue() + { + Int64 result = 0; + + foreach (Int64 value in this.Keys) + { + if (value > result) + { + result = value; + } + } + + return result; + } + + /// <summary> + /// Interprets the single values as bit positions and creates a mask of it. + /// </summary> + /// <returns></returns> + public UInt32 GetBitMask() + { + UInt32 result = 0; + + foreach (Int64 key in this.Keys) + { + if (key < 0) + { + throw new NotSupportedException("Negative numbers are not allowed for Bits!"); + } + if (key > 31) + { + throw new NotSupportedException("Bits with more than 32 bits are not supported!"); + } + + result |= (UInt32)(1 << (int)key); + } + + return result; + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ValueRange.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ValueRange.cs new file mode 100644 index 00000000000..3ff5bcb7d0d --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Mib/ValueRange.cs @@ -0,0 +1,76 @@ +using System; +using System.Collections.Generic; + +namespace Lextm.SharpSnmpLib.Mib +{ + public class ValueRanges: List<ValueRange> + { + public bool IsSizeDeclaration { get; internal set; } + + public ValueRanges(bool isSizeDecl = false) + { + IsSizeDeclaration = isSizeDecl; + } + + public bool Contains(Int64 value) + { + foreach (ValueRange range in this) + { + if (range.Contains(value)) + { + return true; + } + } + + return false; + } + } + + public class ValueRange + { + private readonly Int64 _start; + private readonly Int64? _end; + + public ValueRange(Int64 first, Int64? second) + { + _start = first; + _end = second; + } + + public Int64 Start + { + get { return _start; } + } + + public Int64? End + { + get { return _end; } + } + + public bool IntersectsWith(ValueRange other) + { + if (this._end == null) + { + return other.Contains(this._start); + } + else if (other._end == null) + { + return this.Contains(other._start); + } + + return (this._start <= other.End) && (this._end >= other._start); + } + + public bool Contains(Int64 value) + { + if (_end == null) + { + return value == _start; + } + else + { + return (_start <= value) && (value <= _end); + } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Properties/AssemblyInfo.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Properties/AssemblyInfo.cs new file mode 100644 index 00000000000..f96080d092f --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Properties/AssemblyInfo.cs @@ -0,0 +1,61 @@ +// <summary>#SNMP Library. An open source SNMP implementation for .NET.</summary> +// <copyright company="Lex Y. Li" file="AssemblyInfo.cs">Copyright (C) 2008 Lex Y. Li</copyright> +// +// This library is free software; you can redistribute it and/or +// modify it under the terms of the GNU Lesser General Public +// License as published by the Free Software Foundation; either +// version 2.1 of the License, or (at your option) any later version. +// +// This library is distributed in the hope that it will be useful, +// but WITHOUT ANY WARRANTY; without even the implied warranty of +// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU +// Lesser General Public License for more details. +// +// You should have received a copy of the GNU Lesser General Public +// License along with this library; if not, write to the Free Software +// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + +#region Using directives + +using System; +using System.Reflection; +using System.Resources; +using System.Runtime.CompilerServices; +using System.Runtime.InteropServices; + +#endregion + +// General Information about an assembly is controlled through the following +// set of attributes. Change these attribute values to modify the information +// associated with an assembly. +[assembly: AssemblyTitle("SharpSnmpLib")] +[assembly: AssemblyDescription("#SNMP Library for .NET")] +[assembly: AssemblyConfiguration("Lesser GPL 2.1+")] +[assembly: AssemblyCompany("LeXtudio")] +[assembly: AssemblyProduct("#SNMPLib")] +[assembly: AssemblyCopyright("(C) 2008-2010 Malcolm Crowe, Lex Li, Steve Santacroce, and other contributors.")] +[assembly: AssemblyTrademark("")] +[assembly: AssemblyCulture("")] + +// This sets the default COM visibility of types in the assembly to invisible. +// If you need to expose index type to COM, use [ComVisible(true)] on that type. +[assembly: ComVisible(false)] + +// The assembly version has following format : +// +// Major.Minor.Build.Revision +// +// You can specify all the values or you can use the default the Revision and +// Build Numbers by using the '*' as shown below: +[assembly: AssemblyVersion("7.0.011207.31")] +#if (!CF) +[assembly: AssemblyFileVersion("7.0.011207.31")] +#endif +[assembly: NeutralResourcesLanguage("en-US")] +[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Microsoft.Naming", "CA1704:IdentifiersShouldBeSpelledCorrectly", MessageId = "Lextm")] + +[assembly: InternalsVisibleTo("SharpSnmpLib.Tests, PublicKey=0024000004800000940000000602000000240000525341310004000001000100f7030532c52524" ++ "993841a0d09420340f3814e1b65473851bdcd18815510b035a2ae9ecee69c4cd2d9e4d6e6d5fbf" ++ "a564e86c4a4cddc9597619a31c060846ebb2e99511a0323ff82b1ebd95d6a4912502945f0e769f" ++ "190a69a439dbfb969ebad72a6f7e2e047907da4a7b9c08c6e98d5f1be8b8cafaf3eb978914059a" ++ "245d4bc1")] diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Properties/Resources.Designer.cs b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Properties/Resources.Designer.cs new file mode 100644 index 00000000000..38bc6bb94f5 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Properties/Resources.Designer.cs @@ -0,0 +1,63 @@ +//------------------------------------------------------------------------------ +// <auto-generated> +// Dieser Code wurde von einem Tool generiert. +// Laufzeitversion:4.0.30319.225 +// +// Änderungen an dieser Datei können falsches Verhalten verursachen und gehen verloren, wenn +// der Code erneut generiert wird. +// </auto-generated> +//------------------------------------------------------------------------------ + +namespace Lextm.SharpSnmpLib.Mib { + using System; + + + /// <summary> + /// Eine stark typisierte Ressourcenklasse zum Suchen von lokalisierten Zeichenfolgen usw. + /// </summary> + // Diese Klasse wurde von der StronglyTypedResourceBuilder automatisch generiert + // -Klasse über ein Tool wie ResGen oder Visual Studio automatisch generiert. + // Um einen Member hinzuzufügen oder zu entfernen, bearbeiten Sie die .ResX-Datei und führen dann ResGen + // mit der /str-Option erneut aus, oder Sie erstellen Ihr VS-Projekt neu. + [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "4.0.0.0")] + [global::System.Diagnostics.DebuggerNonUserCodeAttribute()] + [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()] + internal class Resources { + + private static global::System.Resources.ResourceManager resourceMan; + + private static global::System.Globalization.CultureInfo resourceCulture; + + [global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")] + internal Resources() { + } + + /// <summary> + /// Gibt die zwischengespeicherte ResourceManager-Instanz zurück, die von dieser Klasse verwendet wird. + /// </summary> + [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)] + internal static global::System.Resources.ResourceManager ResourceManager { + get { + if (object.ReferenceEquals(resourceMan, null)) { + global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("Lextm.SharpSnmpLib.Properties.Resources", typeof(Resources).Assembly); + resourceMan = temp; + } + return resourceMan; + } + } + + /// <summary> + /// Überschreibt die CurrentUICulture-Eigenschaft des aktuellen Threads für alle + /// Ressourcenzuordnungen, die diese stark typisierte Ressourcenklasse verwenden. + /// </summary> + [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)] + internal static global::System.Globalization.CultureInfo Culture { + get { + return resourceCulture; + } + set { + resourceCulture = value; + } + } + } +} diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/Properties/Resources.resx b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Properties/Resources.resx new file mode 100644 index 00000000000..7080a7d118e --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/Properties/Resources.resx @@ -0,0 +1,120 @@ +<?xml version="1.0" encoding="utf-8"?> +<root> + <!-- + Microsoft ResX Schema + + Version 2.0 + + The primary goals of this format is to allow a simple XML format + that is mostly human readable. The generation and parsing of the + various data types are done through the TypeConverter classes + associated with the data types. + + Example: + + ... ado.net/XML headers & schema ... + <resheader name="resmimetype">text/microsoft-resx</resheader> + <resheader name="version">2.0</resheader> + <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader> + <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader> + <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data> + <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data> + <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64"> + <value>[base64 mime encoded serialized .NET Framework object]</value> + </data> + <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64"> + <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value> + <comment>This is a comment</comment> + </data> + + There are any number of "resheader" rows that contain simple + name/value pairs. + + Each data row contains a name, and value. The row also contains a + type or mimetype. Type corresponds to a .NET class that support + text/value conversion through the TypeConverter architecture. + Classes that don't support this are serialized and stored with the + mimetype set. + + The mimetype is used for serialized objects, and tells the + ResXResourceReader how to depersist the object. This is currently not + extensible. For a given mimetype the value must be set accordingly: + + Note - application/x-microsoft.net.object.binary.base64 is the format + that the ResXResourceWriter will generate, however the reader can + read any of the formats listed below. + + mimetype: application/x-microsoft.net.object.binary.base64 + value : The object must be serialized with + : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter + : and then encoded with base64 encoding. + + mimetype: application/x-microsoft.net.object.soap.base64 + value : The object must be serialized with + : System.Runtime.Serialization.Formatters.Soap.SoapFormatter + : and then encoded with base64 encoding. + + mimetype: application/x-microsoft.net.object.bytearray.base64 + value : The object must be serialized into a byte array + : using a System.ComponentModel.TypeConverter + : and then encoded with base64 encoding. + --> + <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata"> + <xsd:import namespace="http://www.w3.org/XML/1998/namespace" /> + <xsd:element name="root" msdata:IsDataSet="true"> + xsd:complexType + <xsd:choice maxOccurs="unbounded"> + <xsd:element name="metadata"> + xsd:complexType + xsd:sequence + <xsd:element name="value" type="xsd:string" minOccurs="0" /> + </xsd:sequence> + <xsd:attribute name="name" use="required" type="xsd:string" /> + <xsd:attribute name="type" type="xsd:string" /> + <xsd:attribute name="mimetype" type="xsd:string" /> + <xsd:attribute ref="xml:space" /> + </xsd:complexType> + </xsd:element> + <xsd:element name="assembly"> + xsd:complexType + <xsd:attribute name="alias" type="xsd:string" /> + <xsd:attribute name="name" type="xsd:string" /> + </xsd:complexType> + </xsd:element> + <xsd:element name="data"> + xsd:complexType + xsd:sequence + <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" /> + <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" /> + </xsd:sequence> + <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" /> + <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" /> + <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" /> + <xsd:attribute ref="xml:space" /> + </xsd:complexType> + </xsd:element> + <xsd:element name="resheader"> + xsd:complexType + xsd:sequence + <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" /> + </xsd:sequence> + <xsd:attribute name="name" type="xsd:string" use="required" /> + </xsd:complexType> + </xsd:element> + </xsd:choice> + </xsd:complexType> + </xsd:element> + </xsd:schema> + <resheader name="resmimetype"> + <value>text/microsoft-resx</value> + </resheader> + <resheader name="version"> + <value>2.0</value> + </resheader> + <resheader name="reader"> + <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value> + </resheader> + <resheader name="writer"> + <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value> + </resheader> +</root> \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/SharpSnmpLib.Mib.csproj b/contrib/apps/LwipMibCompiler/SharpSnmpLib/SharpSnmpLib.Mib.csproj new file mode 100644 index 00000000000..2cf86578e22 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/SharpSnmpLib.Mib.csproj @@ -0,0 +1,140 @@ +<?xml version="1.0" encoding="utf-8"?> +<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003"> + <PropertyGroup> + <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration> + <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform> + <ProductVersion>8.0.30703</ProductVersion> + <SchemaVersion>2.0</SchemaVersion> + <ProjectGuid>{CBE20411-5DB7-487D-825D-7694267BB6F5}</ProjectGuid> + <OutputType>Library</OutputType> + <AppDesignerFolder>Properties</AppDesignerFolder> + <RootNamespace>Lextm.SharpSnmpLib</RootNamespace> + <AssemblyName>SharpSnmpLib.Mib</AssemblyName> + <DocumentationFile>..\bin\SharpSnmpLib.Mib.xml</DocumentationFile> + <FileAlignment>512</FileAlignment> + <TargetFrameworkProfile /> + <SignAssembly>True</SignAssembly> + <AssemblyOriginatorKeyFile>sharpsnmplib.snk</AssemblyOriginatorKeyFile> + <DelaySign>False</DelaySign> + <AssemblyOriginatorKeyMode>File</AssemblyOriginatorKeyMode> + <SccProjectName> + </SccProjectName> + <SccLocalPath> + </SccLocalPath> + <SccAuxPath> + </SccAuxPath> + <SccProvider> + </SccProvider> + <RunSourceAnalysis>False</RunSourceAnalysis> + <TargetFrameworkVersion>v4.0</TargetFrameworkVersion> + </PropertyGroup> + <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' "> + <DebugSymbols>true</DebugSymbols> + <DebugType>full</DebugType> + <Optimize>false</Optimize> + <OutputPath>bin\Debug</OutputPath> + <DefineConstants>DEBUG;TRACE</DefineConstants> + <ErrorReport>prompt</ErrorReport> + <WarningLevel>4</WarningLevel> + <DocumentationFile> + </DocumentationFile> + </PropertyGroup> + <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' "> + <DebugType>pdbonly</DebugType> + <Optimize>true</Optimize> + <OutputPath>bin\Release</OutputPath> + <DefineConstants>TRACE</DefineConstants> + <ErrorReport>prompt</ErrorReport> + <WarningLevel>4</WarningLevel> + <DocumentationFile> + </DocumentationFile> + </PropertyGroup> + <ItemGroup> + <Reference Include="System" /> + <Reference Include="System.Configuration" /> + </ItemGroup> + <ItemGroup> + <Compile Include="Mib\DisplayHint.cs" /> + <Compile Include="Mib\Elements\Entities\AgentCapabilities.cs" /> + <Compile Include="Mib\Elements\Entities\EntityBase.cs" /> + <Compile Include="Mib\Elements\Entities\IEntity.cs" /> + <Compile Include="Mib\Elements\Entities\ModuleCompliance.cs" /> + <Compile Include="Mib\Elements\Entities\ModuleIdentity.cs" /> + <Compile Include="Mib\Elements\Entities\NotificationGroup.cs" /> + <Compile Include="Mib\Elements\Entities\NotificationType.cs" /> + <Compile Include="Mib\Elements\Entities\ObjectGroup.cs" /> + <Compile Include="Mib\Elements\Entities\ObjectIdentity.cs" /> + <Compile Include="Mib\Elements\Entities\ObjectType.cs" /> + <Compile Include="Mib\Elements\Entities\OidValueAssignment.cs" /> + <Compile Include="Mib\Elements\Exports.cs" /> + <Compile Include="Mib\Elements\IElement.cs" /> + <Compile Include="Mib\Elements\Imports.cs" /> + <Compile Include="Mib\Elements\ImportsFrom.cs" /> + <Compile Include="Mib\Elements\IDeclaration.cs" /> + <Compile Include="Mib\Elements\TrapType.cs" /> + <Compile Include="Mib\Elements\Types\BaseType.cs" /> + <Compile Include="Mib\Elements\Types\BitsType.cs" /> + <Compile Include="Mib\Elements\Types\Choice.cs" /> + <Compile Include="Mib\Elements\Types\IntegerType.cs" /> + <Compile Include="Mib\Elements\Types\IpAddressType.cs" /> + <Compile Include="Mib\Elements\Types\ITypeAssignment.cs" /> + <Compile Include="Mib\Elements\ITypeReferrer.cs" /> + <Compile Include="Mib\Elements\Types\Macro.cs" /> + <Compile Include="Mib\Elements\Types\ObjectIdentifierType.cs" /> + <Compile Include="Mib\Elements\Types\OctetStringType.cs" /> + <Compile Include="Mib\Elements\Types\OpaqueType.cs" /> + <Compile Include="Mib\Elements\Types\Sequence.cs" /> + <Compile Include="Mib\Elements\Types\SequenceOf.cs" /> + <Compile Include="Mib\Elements\Types\TextualConvention.cs" /> + <Compile Include="Mib\Elements\Types\TypeAssignment.cs" /> + <Compile Include="Mib\Elements\Types\UnsignedType.cs" /> + <Compile Include="Mib\IModule.cs" /> + <Compile Include="Mib\ISymbolEnumerator.cs" /> + <Compile Include="Mib\MaxAccess.cs" /> + <Compile Include="Mib\MibResolver.cs" /> + <Compile Include="Mib\MibTree.cs" /> + <Compile Include="Mib\MibTreeNode.cs" /> + <Compile Include="Mib\MibTypesResolver.cs" /> + <Compile Include="Mib\ObjectIdentifier.cs" /> + <Compile Include="Mib\Status.cs" /> + <Compile Include="Mib\SymbolList.cs" /> + <Compile Include="Mib\Lexer.cs" /> + <Compile Include="Mib\MibDocument.cs" /> + <Compile Include="Mib\MibModule.cs" /> + <Compile Include="Mib\MibException.cs" /> + <Compile Include="Mib\Symbol.cs" /> + <Compile Include="Mib\ValueMap.cs" /> + <Compile Include="Mib\ValueRange.cs" /> + <Compile Include="Properties\AssemblyInfo.cs" /> + <Compile Include="Properties\Resources.Designer.cs"> + <AutoGen>True</AutoGen> + <DesignTime>True</DesignTime> + <DependentUpon>Resources.resx</DependentUpon> + </Compile> + </ItemGroup> + <ItemGroup> + <None Include="sharpsnmplib.snk" /> + </ItemGroup> + <ItemGroup> + <None Include="license.txt" /> + </ItemGroup> + <ItemGroup> + <EmbeddedResource Include="Properties\Resources.resx"> + <Generator>ResXFileCodeGenerator</Generator> + <LastGenOutput>Resources.Designer.cs</LastGenOutput> + <CustomToolNamespace>Lextm.SharpSnmpLib.Mib</CustomToolNamespace> + <SubType>Designer</SubType> + </EmbeddedResource> + </ItemGroup> + <ItemGroup> + <Folder Include="Resources\" /> + </ItemGroup> + <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" /> + <!-- To modify your build process, add your task inside one of the targets below and uncomment it. + Other similar extension points exist, see Microsoft.Common.targets. + <Target Name="BeforeBuild"> + </Target> + <Target Name="AfterBuild"> + </Target> + --> +</Project> \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/license.txt b/contrib/apps/LwipMibCompiler/SharpSnmpLib/license.txt new file mode 100644 index 00000000000..27946de2100 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/license.txt @@ -0,0 +1,458 @@ + GNU LESSER GENERAL PUBLIC LICENSE + Version 2.1, February 1999 + + Copyright (C) 1991, 1999 Free Software Foundation, Inc. + 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + Everyone is permitted to copy and distribute verbatim copies + of this license document, but changing it is not allowed. + +[This is the first released version of the Lesser GPL. It also counts + as the successor of the GNU Library Public License, version 2, hence + the version number 2.1.] + + Preamble + + The licenses for most software are designed to take away your +freedom to share and change it. By contrast, the GNU General Public +Licenses are intended to guarantee your freedom to share and change +free software--to make sure the software is free for all its users. + + This license, the Lesser General Public License, applies to some +specially designated software packages--typically libraries--of the +Free Software Foundation and other authors who decide to use it. You +can use it too, but we suggest you first think carefully about whether +this license or the ordinary General Public License is the better +strategy to use in any particular case, based on the explanations below. + + When we speak of free software, we are referring to freedom of use, +not price. Our General Public Licenses are designed to make sure that +you have the freedom to distribute copies of free software (and charge +for this service if you wish); that you receive source code or can get +it if you want it; that you can change the software and use pieces of +it in new free programs; and that you are informed that you can do +these things. + + To protect your rights, we need to make restrictions that forbid +distributors to deny you these rights or to ask you to surrender these +rights. These restrictions translate to certain responsibilities for +you if you distribute copies of the library or if you modify it. + + For example, if you distribute copies of the library, whether gratis +or for a fee, you must give the recipients all the rights that we gave +you. You must make sure that they, too, receive or can get the source +code. If you link other code with the library, you must provide +complete object files to the recipients, so that they can relink them +with the library after making changes to the library and recompiling +it. And you must show them these terms so they know their rights. + + We protect your rights with a two-step method: (1) we copyright the +library, and (2) we offer you this license, which gives you legal +permission to copy, distribute and/or modify the library. + + To protect each distributor, we want to make it very clear that +there is no warranty for the free library. Also, if the library is +modified by someone else and passed on, the recipients should know +that what they have is not the original version, so that the original +author's reputation will not be affected by problems that might be +introduced by others. + + Finally, software patents pose a constant threat to the existence of +any free program. We wish to make sure that a company cannot +effectively restrict the users of a free program by obtaining a +restrictive license from a patent holder. Therefore, we insist that +any patent license obtained for a version of the library must be +consistent with the full freedom of use specified in this license. + + Most GNU software, including some libraries, is covered by the +ordinary GNU General Public License. This license, the GNU Lesser +General Public License, applies to certain designated libraries, and +is quite different from the ordinary General Public License. We use +this license for certain libraries in order to permit linking those +libraries into non-free programs. + + When a program is linked with a library, whether statically or using +a shared library, the combination of the two is legally speaking a +combined work, a derivative of the original library. The ordinary +General Public License therefore permits such linking only if the +entire combination fits its criteria of freedom. The Lesser General +Public License permits more lax criteria for linking other code with +the library. + + We call this license the "Lesser" General Public License because it +does Less to protect the user's freedom than the ordinary General +Public License. It also provides other free software developers Less +of an advantage over competing non-free programs. These disadvantages +are the reason we use the ordinary General Public License for many +libraries. However, the Lesser license provides advantages in certain +special circumstances. + + For example, on rare occasions, there may be a special need to +encourage the widest possible use of a certain library, so that it becomes +a de-facto standard. To achieve this, non-free programs must be +allowed to use the library. A more frequent case is that a free +library does the same job as widely used non-free libraries. In this +case, there is little to gain by limiting the free library to free +software only, so we use the Lesser General Public License. + + In other cases, permission to use a particular library in non-free +programs enables a greater number of people to use a large body of +free software. For example, permission to use the GNU C Library in +non-free programs enables many more people to use the whole GNU +operating system, as well as its variant, the GNU/Linux operating +system. + + Although the Lesser General Public License is Less protective of the +users' freedom, it does ensure that the user of a program that is +linked with the Library has the freedom and the wherewithal to run +that program using a modified version of the Library. + + The precise terms and conditions for copying, distribution and +modification follow. Pay close attention to the difference between a +"work based on the library" and a "work that uses the library". The +former contains code derived from the library, whereas the latter must +be combined with the library in order to run. + + GNU LESSER GENERAL PUBLIC LICENSE + TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION + + 0. This License Agreement applies to any software library or other +program which contains a notice placed by the copyright holder or +other authorized party saying it may be distributed under the terms of +this Lesser General Public License (also called "this License"). +Each licensee is addressed as "you". + + A "library" means a collection of software functions and/or data +prepared so as to be conveniently linked with application programs +(which use some of those functions and data) to form executables. + + The "Library", below, refers to any such software library or work +which has been distributed under these terms. A "work based on the +Library" means either the Library or any derivative work under +copyright law: that is to say, a work containing the Library or a +portion of it, either verbatim or with modifications and/or translated +straightforwardly into another language. (Hereinafter, translation is +included without limitation in the term "modification".) + + "Source code" for a work means the preferred form of the work for +making modifications to it. For a library, complete source code means +all the source code for all modules it contains, plus any associated +interface definition files, plus the scripts used to control compilation +and installation of the library. + + Activities other than copying, distribution and modification are not +covered by this License; they are outside its scope. The act of +running a program using the Library is not restricted, and output from +such a program is covered only if its contents constitute a work based +on the Library (independent of the use of the Library in a tool for +writing it). Whether that is true depends on what the Library does +and what the program that uses the Library does. + + 1. You may copy and distribute verbatim copies of the Library's +complete source code as you receive it, in any medium, provided that +you conspicuously and appropriately publish on each copy an +appropriate copyright notice and disclaimer of warranty; keep intact +all the notices that refer to this License and to the absence of any +warranty; and distribute a copy of this License along with the +Library. + + You may charge a fee for the physical act of transferring a copy, +and you may at your option offer warranty protection in exchange for a +fee. + + 2. You may modify your copy or copies of the Library or any portion +of it, thus forming a work based on the Library, and copy and +distribute such modifications or work under the terms of Section 1 +above, provided that you also meet all of these conditions: + + a) The modified work must itself be a software library. + + b) You must cause the files modified to carry prominent notices + stating that you changed the files and the date of any change. + + c) You must cause the whole of the work to be licensed at no + charge to all third parties under the terms of this License. + + d) If a facility in the modified Library refers to a function or a + table of data to be supplied by an application program that uses + the facility, other than as an argument passed when the facility + is invoked, then you must make a good faith effort to ensure that, + in the event an application does not supply such function or + table, the facility still operates, and performs whatever part of + its purpose remains meaningful. + + (For example, a function in a library to compute square roots has + a purpose that is entirely well-defined independent of the + application. Therefore, Subsection 2d requires that any + application-supplied function or table used by this function must + be optional: if the application does not supply it, the square + root function must still compute square roots.) + +These requirements apply to the modified work as a whole. If +identifiable sections of that work are not derived from the Library, +and can be reasonably considered independent and separate works in +themselves, then this License, and its terms, do not apply to those +sections when you distribute them as separate works. But when you +distribute the same sections as part of a whole which is a work based +on the Library, the distribution of the whole must be on the terms of +this License, whose permissions for other licensees extend to the +entire whole, and thus to each and every part regardless of who wrote +it. + +Thus, it is not the intent of this section to claim rights or contest +your rights to work written entirely by you; rather, the intent is to +exercise the right to control the distribution of derivative or +collective works based on the Library. + +In addition, mere aggregation of another work not based on the Library +with the Library (or with a work based on the Library) on a volume of +a storage or distribution medium does not bring the other work under +the scope of this License. + + 3. You may opt to apply the terms of the ordinary GNU General Public +License instead of this License to a given copy of the Library. To do +this, you must alter all the notices that refer to this License, so +that they refer to the ordinary GNU General Public License, version 2, +instead of to this License. (If a newer version than version 2 of the +ordinary GNU General Public License has appeared, then you can specify +that version instead if you wish.) Do not make any other change in +these notices. + + Once this change is made in a given copy, it is irreversible for +that copy, so the ordinary GNU General Public License applies to all +subsequent copies and derivative works made from that copy. + + This option is useful when you wish to copy part of the code of +the Library into a program that is not a library. + + 4. You may copy and distribute the Library (or a portion or +derivative of it, under Section 2) in object code or executable form +under the terms of Sections 1 and 2 above provided that you accompany +it with the complete corresponding machine-readable source code, which +must be distributed under the terms of Sections 1 and 2 above on a +medium customarily used for software interchange. + + If distribution of object code is made by offering access to copy +from a designated place, then offering equivalent access to copy the +source code from the same place satisfies the requirement to +distribute the source code, even though third parties are not +compelled to copy the source along with the object code. + + 5. A program that contains no derivative of any portion of the +Library, but is designed to work with the Library by being compiled or +linked with it, is called a "work that uses the Library". Such a +work, in isolation, is not a derivative work of the Library, and +therefore falls outside the scope of this License. + + However, linking a "work that uses the Library" with the Library +creates an executable that is a derivative of the Library (because it +contains portions of the Library), rather than a "work that uses the +library". The executable is therefore covered by this License. +Section 6 states terms for distribution of such executables. + + When a "work that uses the Library" uses material from a header file +that is part of the Library, the object code for the work may be a +derivative work of the Library even though the source code is not. +Whether this is true is especially significant if the work can be +linked without the Library, or if the work is itself a library. The +threshold for this to be true is not precisely defined by law. + + If such an object file uses only numerical parameters, data +structure layouts and accessors, and small macros and small inline +functions (ten lines or less in length), then the use of the object +file is unrestricted, regardless of whether it is legally a derivative +work. (Executables containing this object code plus portions of the +Library will still fall under Section 6.) + + Otherwise, if the work is a derivative of the Library, you may +distribute the object code for the work under the terms of Section 6. +Any executables containing that work also fall under Section 6, +whether or not they are linked directly with the Library itself. + + 6. As an exception to the Sections above, you may also combine or +link a "work that uses the Library" with the Library to produce a +work containing portions of the Library, and distribute that work +under terms of your choice, provided that the terms permit +modification of the work for the customer's own use and reverse +engineering for debugging such modifications. + + You must give prominent notice with each copy of the work that the +Library is used in it and that the Library and its use are covered by +this License. You must supply a copy of this License. If the work +during execution displays copyright notices, you must include the +copyright notice for the Library among them, as well as a reference +directing the user to the copy of this License. Also, you must do one +of these things: + + a) Accompany the work with the complete corresponding + machine-readable source code for the Library including whatever + changes were used in the work (which must be distributed under + Sections 1 and 2 above); and, if the work is an executable linked + with the Library, with the complete machine-readable "work that + uses the Library", as object code and/or source code, so that the + user can modify the Library and then relink to produce a modified + executable containing the modified Library. (It is understood + that the user who changes the contents of definitions files in the + Library will not necessarily be able to recompile the application + to use the modified definitions.) + + b) Use a suitable shared library mechanism for linking with the + Library. A suitable mechanism is one that (1) uses at run time a + copy of the library already present on the user's computer system, + rather than copying library functions into the executable, and (2) + will operate properly with a modified version of the library, if + the user installs one, as long as the modified version is + interface-compatible with the version that the work was made with. + + c) Accompany the work with a written offer, valid for at + least three years, to give the same user the materials + specified in Subsection 6a, above, for a charge no more + than the cost of performing this distribution. + + d) If distribution of the work is made by offering access to copy + from a designated place, offer equivalent access to copy the above + specified materials from the same place. + + e) Verify that the user has already received a copy of these + materials or that you have already sent this user a copy. + + For an executable, the required form of the "work that uses the +Library" must include any data and utility programs needed for +reproducing the executable from it. However, as a special exception, +the materials to be distributed need not include anything that is +normally distributed (in either source or binary form) with the major +components (compiler, kernel, and so on) of the operating system on +which the executable runs, unless that component itself accompanies +the executable. + + It may happen that this requirement contradicts the license +restrictions of other proprietary libraries that do not normally +accompany the operating system. Such a contradiction means you cannot +use both them and the Library together in an executable that you +distribute. + + 7. You may place library facilities that are a work based on the +Library side-by-side in a single library together with other library +facilities not covered by this License, and distribute such a combined +library, provided that the separate distribution of the work based on +the Library and of the other library facilities is otherwise +permitted, and provided that you do these two things: + + a) Accompany the combined library with a copy of the same work + based on the Library, uncombined with any other library + facilities. This must be distributed under the terms of the + Sections above. + + b) Give prominent notice with the combined library of the fact + that part of it is a work based on the Library, and explaining + where to find the accompanying uncombined form of the same work. + + 8. You may not copy, modify, sublicense, link with, or distribute +the Library except as expressly provided under this License. Any +attempt otherwise to copy, modify, sublicense, link with, or +distribute the Library is void, and will automatically terminate your +rights under this License. However, parties who have received copies, +or rights, from you under this License will not have their licenses +terminated so long as such parties remain in full compliance. + + 9. You are not required to accept this License, since you have not +signed it. However, nothing else grants you permission to modify or +distribute the Library or its derivative works. These actions are +prohibited by law if you do not accept this License. Therefore, by +modifying or distributing the Library (or any work based on the +Library), you indicate your acceptance of this License to do so, and +all its terms and conditions for copying, distributing or modifying +the Library or works based on it. + + 10. Each time you redistribute the Library (or any work based on the +Library), the recipient automatically receives a license from the +original licensor to copy, distribute, link with or modify the Library +subject to these terms and conditions. You may not impose any further +restrictions on the recipients' exercise of the rights granted herein. +You are not responsible for enforcing compliance by third parties with +this License. + + 11. If, as a consequence of a court judgment or allegation of patent +infringement or for any other reason (not limited to patent issues), +conditions are imposed on you (whether by court order, agreement or +otherwise) that contradict the conditions of this License, they do not +excuse you from the conditions of this License. If you cannot +distribute so as to satisfy simultaneously your obligations under this +License and any other pertinent obligations, then as a consequence you +may not distribute the Library at all. For example, if a patent +license would not permit royalty-free redistribution of the Library by +all those who receive copies directly or indirectly through you, then +the only way you could satisfy both it and this License would be to +refrain entirely from distribution of the Library. + +If any portion of this section is held invalid or unenforceable under any +particular circumstance, the balance of the section is intended to apply, +and the section as a whole is intended to apply in other circumstances. + +It is not the purpose of this section to induce you to infringe any +patents or other property right claims or to contest validity of any +such claims; this section has the sole purpose of protecting the +integrity of the free software distribution system which is +implemented by public license practices. Many people have made +generous contributions to the wide range of software distributed +through that system in reliance on consistent application of that +system; it is up to the author/donor to decide if he or she is willing +to distribute software through any other system and a licensee cannot +impose that choice. + +This section is intended to make thoroughly clear what is believed to +be a consequence of the rest of this License. + + 12. If the distribution and/or use of the Library is restricted in +certain countries either by patents or by copyrighted interfaces, the +original copyright holder who places the Library under this License may add +an explicit geographical distribution limitation excluding those countries, +so that distribution is permitted only in or among countries not thus +excluded. In such case, this License incorporates the limitation as if +written in the body of this License. + + 13. The Free Software Foundation may publish revised and/or new +versions of the Lesser General Public License from time to time. +Such new versions will be similar in spirit to the present version, +but may differ in detail to address new problems or concerns. + +Each version is given a distinguishing version number. If the Library +specifies a version number of this License which applies to it and +"any later version", you have the option of following the terms and +conditions either of that version or of any later version published by +the Free Software Foundation. If the Library does not specify a +license version number, you may choose any version ever published by +the Free Software Foundation. + + 14. If you wish to incorporate parts of the Library into other free +programs whose distribution conditions are incompatible with these, +write to the author to ask for permission. For software which is +copyrighted by the Free Software Foundation, write to the Free +Software Foundation; we sometimes make exceptions for this. Our +decision will be guided by the two goals of preserving the free status +of all derivatives of our free software and of promoting the sharing +and reuse of software generally. + + NO WARRANTY + + 15. BECAUSE THE LIBRARY IS LICENSED FREE OF CHARGE, THERE IS NO +WARRANTY FOR THE LIBRARY, TO THE EXTENT PERMITTED BY APPLICABLE LAW. +EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR +OTHER PARTIES PROVIDE THE LIBRARY "AS IS" WITHOUT WARRANTY OF ANY +KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE +IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR +PURPOSE. THE ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE +LIBRARY IS WITH YOU. SHOULD THE LIBRARY PROVE DEFECTIVE, YOU ASSUME +THE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION. + + 16. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN +WRITING WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY +AND/OR REDISTRIBUTE THE LIBRARY AS PERMITTED ABOVE, BE LIABLE TO YOU +FOR DAMAGES, INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR +CONSEQUENTIAL DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE THE +LIBRARY (INCLUDING BUT NOT LIMITED TO LOSS OF DATA OR DATA BEING +RENDERED INACCURATE OR LOSSES SUSTAINED BY YOU OR THIRD PARTIES OR A +FAILURE OF THE LIBRARY TO OPERATE WITH ANY OTHER SOFTWARE), EVEN IF +SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH +DAMAGES. + + END OF TERMS AND CONDITIONS \ No newline at end of file diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/readme.txt b/contrib/apps/LwipMibCompiler/SharpSnmpLib/readme.txt new file mode 100644 index 00000000000..67b5a655712 --- /dev/null +++ b/contrib/apps/LwipMibCompiler/SharpSnmpLib/readme.txt @@ -0,0 +1 @@ +See docs in src/apps/snmp/snmp_core.c. diff --git a/contrib/apps/LwipMibCompiler/SharpSnmpLib/sharpsnmplib.snk b/contrib/apps/LwipMibCompiler/SharpSnmpLib/sharpsnmplib.snk new file mode 100644 index 0000000000000000000000000000000000000000..fe6f345af4820b6758f6909a2d489ac524eaf889 GIT binary patch literal 596 zcmV-a0;~N80ssI2Bme+XQ$aES1ONa50098^0|he0B_x?RL7>o-AT$p+6ydg1bA=n+ z(TEjM3j<mz>Fn-l#LX?9O>S*pzolg8Y)VYs$ys(8qZ|eZM(eWal@XvaKlm#iy_MFa zktG6@Uk-Mk8478nIotb|p1Rj6Z+<QWc?a4`dz=Wy>5X3-=(x)I^Xr$16a|_jT}#2q z4>os95Q>xdhUx6jI|K!RX~hw1f!(|e#!5;$P6^h;CwzlPPCzNSv5=EJ`&INw3Z=7z zpCl>Gkp_CX1_JoM)uqwp7RO;18$@HiTuXhh8G#I(lCQ>caMi|5DbsK=Ij`BFCHTSV z)k^SjW~pvk&&IH|pd-nVVYBt0_=U$ArZ<6G8WE6Fm+B494}Ss(+%Lc_4Ia8yP8XWx z#8OMKTbAeI*{B6YjJi>DVo}}N<pV3FEG$*fgg1q@s=jwi9-9Hw;VWy!GmbQF{KeLg zq)+u{n)`r6W#%!blM#0OH3`-desFkiQPp{IDlAg&4PFg78;8B|xz+`DsqJg9He(Ef zMNJED|6HkBfMa|*fF)2WbxL~qD#<&LD$2-PqX0fDZV{xB)5s5&Z<%QiC*{PDsE-*p zT~99>8VwM^Q}Dt#D!-QYa4P@<F-#}dk!<oS)c_tq-o*1IVXjV84qYAk0@6KYn3NR? zESDUA?g|n0J#pnT!}2uMq)*pP8~^)kxQYNMYb?kdM5T4vv;p;^foix4(bVnL$~}g_ ibkDVj;;f~NGM24=Oz7<dW~NJZT<D|d>XO=Y9CSTeQ4?wa
literal 0 HcmV?d00001
diff --git a/contrib/apps/LwipMibCompiler/example/compile_udp_mib.cmd b/contrib/apps/LwipMibCompiler/example/compile_udp_mib.cmd new file mode 100644 index 00000000000..1c84dbfed3c --- /dev/null +++ b/contrib/apps/LwipMibCompiler/example/compile_udp_mib.cmd @@ -0,0 +1 @@ +..\LwipMibCompiler\bin\Debug\LwipMibCompiler.exe ..\Mibs\UDP-MIB .\ ..\Mibs\ diff --git a/contrib/apps/LwipMibCompiler/example/compile_udp_mib.sh b/contrib/apps/LwipMibCompiler/example/compile_udp_mib.sh new file mode 100644 index 00000000000..93798c01b5a --- /dev/null +++ b/contrib/apps/LwipMibCompiler/example/compile_udp_mib.sh @@ -0,0 +1 @@ +../LwipMibCompiler/bin/Debug/LwipMibCompiler.exe ../Mibs/UDP-MIB ./ ../Mibs/ diff --git a/contrib/apps/chargen/README b/contrib/apps/chargen/README new file mode 100644 index 00000000000..7dc2ee522bd --- /dev/null +++ b/contrib/apps/chargen/README @@ -0,0 +1,52 @@ + + CHARGEN + +This file implements a nice example of handling multiple tcp sockets in a +server environment. Just call chargen_init() from your application after +you have initialized lwip and added your network interfaces. Change the +MAX_SERV option to increase or decrease the number of sessions supported. + +chargen will jam as much data as possible into the output socket, so it +will take up a lot of CPU time. Therefore it will be a good idea to run it +as the lowest possible priority (just ahead of any idle task). + +This is also a good example of how to support multiple sessions in an +embedded system where you might not have fork(). The multiple sessions are +all handled by the same thread and select() is used for demultiplexing. + +No makefile is provided, just add chargen to the makefile for your +application. It is OS and HW independent. + +Once the chargen server is running in your application, go to another system +and open a telnet session to your lwip platform at port 19. You should see an +ASCII pattern start to stream on you screen. + +As an example, lets say that your system running lwip is at IP address +192.168.10.244 and you have a linux system connected to it at IP address +192.168.10.59. Issue the following command at a terminal prompt on the linux system: + +telnet 192.168.10.244 19 + +You will see a pattern similar to the following on streaming by on your +screen: + +ABCDEFGHIJKLMNOPQRSTUVWXYZ[]^_`abcdefghijklmnopqrstuvwxyz{ +BCDEFGHIJKLMNOPQRSTUVWXYZ[]^_`abcdefghijklmnopqrstuvwxyz{| +CDEFGHIJKLMNOPQRSTUVWXYZ[]^_`abcdefghijklmnopqrstuvwxyz{|} +DEFGHIJKLMNOPQRSTUVWXYZ[]^_`abcdefghijklmnopqrstuvwxyz{|}~ +EFGHIJKLMNOPQRSTUVWXYZ[]^_`abcdefghijklmnopqrstuvwxyz{|}~! +FGHIJKLMNOPQRSTUVWXYZ[]^_`abcdefghijklmnopqrstuvwxyz{|}~!" +GHIJKLMNOPQRSTUVWXYZ[]^_`abcdefghijklmnopqrstuvwxyz{|}~!"# +HIJKLMNOPQRSTUVWXYZ[]^_`abcdefghijklmnopqrstuvwxyz{|}~!"#$ +IJKLMNOPQRSTUVWXYZ[]^_`abcdefghijklmnopqrstuvwxyz{|}~!"#$% +JKLMNOPQRSTUVWXYZ[]^_`abcdefghijklmnopqrstuvwxyz{|}~!"#$%& +KLMNOPQRSTUVWXYZ[]^_`abcdefghijklmnopqrstuvwxyz{|}~!"#$%&' +LMNOPQRSTUVWXYZ[]^_`abcdefghijklmnopqrstuvwxyz{|}~!"#$%&'( + +It even works from windows: At a dos prompt you can also issue the same +telnet command and you will get a similar (but much slower, at least on W98) +data stream. + +David Haas + + diff --git a/contrib/apps/chargen/chargen.c b/contrib/apps/chargen/chargen.c new file mode 100644 index 00000000000..94a70b90fc8 --- /dev/null +++ b/contrib/apps/chargen/chargen.c @@ -0,0 +1,274 @@ +/** @file + * + * chargen server for lwip + */ +/* + * Copyright (c) 2003 NBS Card Technology, Paramus, NJ. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: David Haas dhaas@alum.rpi.edu + * + * Purpose: chargen server for testing and demonstration purposes + * + * This file implements a nice example of handling multiple tcp sockets in a + * server environment. Just call chargen_init() from your application after + * you have initialized lwip and added your network interfaces. Change the + * MAX_SERV option to increase or decrease the number of sessions supported. + * + * chargen will jam as much data as possible into the output socket, so it + * will take up a lot of CPU time. Therefore it will be a good idea to run it + * as the lowest possible priority (just ahead of any idle task). + * + * This is also a good example of how to support multiple sessions in an + * embedded system where you might not have fork(). + */ + +#include "lwip/opt.h" +#include "lwip/sys.h" +#include "lwip/sockets.h" +#include "lwip/mem.h" + +#include <string.h> + +#include "chargen.h" + +#if LWIP_SOCKET && LWIP_SOCKET_SELECT + +#define MAX_SERV 5 /* Maximum number of chargen services. Don't need too many */ +#define CHARGEN_THREAD_NAME "chargen" +#define CHARGEN_PRIORITY 254 /* Really low priority */ +#define CHARGEN_THREAD_STACKSIZE 0 +#define SEND_SIZE TCP_SNDLOWAT /* If we only send this much, then when select + says we can send, we know we won't block */ + +struct charcb { + struct charcb *next; + int socket; + struct sockaddr_storage cliaddr; + socklen_t clilen; + char nextchar; +}; + +static struct charcb *charcb_list = NULL; + +/************************************************************** + * void close_chargen(struct charcb *p_charcb) + * + * Close the socket and remove this charcb from the list. + **************************************************************/ +static void +close_chargen(struct charcb *p_charcb) +{ + struct charcb *p_search_charcb; + + /* Either an error or tcp connection closed on other + * end. Close here */ + lwip_close(p_charcb->socket); + /* Free charcb */ + if (charcb_list == p_charcb) { + charcb_list = p_charcb->next; + } else { + for (p_search_charcb = charcb_list; p_search_charcb; p_search_charcb = p_search_charcb->next) { + if (p_search_charcb->next == p_charcb) { + p_search_charcb->next = p_charcb->next; + break; + } + } + } + mem_free(p_charcb); +} + +/************************************************************** + * void do_read(struct charcb *p_charcb) + * + * Socket definitely is ready for reading. Read a buffer from the socket and + * discard the data. If no data is read, then the socket is closed and the + * charcb is removed from the list and freed. + **************************************************************/ +static int +do_read(struct charcb *p_charcb) +{ + char buffer[80]; + int readcount; + + /* Read some data */ + readcount = lwip_read(p_charcb->socket, &buffer, 80); + if (readcount <= 0) { + close_chargen(p_charcb); + return -1; + } + return 0; +} + +/************************************************************** + * void chargen_thread(void *arg) + * + * chargen task. This server will wait for connections on well + * known TCP port number: 19. For every connection, the server will + * write as much data as possible to the tcp port. + **************************************************************/ +static void +chargen_thread(void *arg) +{ + int listenfd; +#if LWIP_IPV6 + struct sockaddr_in6 chargen_saddr; +#else /* LWIP_IPV6 */ + struct sockaddr_in chargen_saddr; +#endif /* LWIP_IPV6 */ + fd_set readset; + fd_set writeset; + int i, maxfdp1; + struct charcb *p_charcb; + LWIP_UNUSED_ARG(arg); + + memset(&chargen_saddr, 0, sizeof (chargen_saddr)); +#if LWIP_IPV6 + /* First acquire our socket for listening for connections */ + listenfd = lwip_socket(AF_INET6, SOCK_STREAM, 0); + chargen_saddr.sin6_family = AF_INET6; + chargen_saddr.sin6_addr = in6addr_any; + chargen_saddr.sin6_port = lwip_htons(19); /* Chargen server port */ +#else /* LWIP_IPV6 */ + /* First acquire our socket for listening for connections */ + listenfd = lwip_socket(AF_INET, SOCK_STREAM, 0); + chargen_saddr.sin_family = AF_INET; + chargen_saddr.sin_addr.s_addr = PP_HTONL(INADDR_ANY); + chargen_saddr.sin_port = lwip_htons(19); /* Chargen server port */ +#endif /* LWIP_IPV6 */ + + LWIP_ASSERT("chargen_thread(): Socket create failed.", listenfd >= 0); + + if (lwip_bind(listenfd, (struct sockaddr *) &chargen_saddr, sizeof (chargen_saddr)) == -1) { + LWIP_ASSERT("chargen_thread(): Socket bind failed.", 0); + } + + /* Put socket into listening mode */ + if (lwip_listen(listenfd, MAX_SERV) == -1) { + LWIP_ASSERT("chargen_thread(): Listen failed.", 0); + } + + + /* Wait forever for network input: This could be connections or data */ + for (;;) { + maxfdp1 = listenfd + 1; + + /* Determine what sockets need to be in readset */ + FD_ZERO(&readset); + FD_ZERO(&writeset); + FD_SET(listenfd, &readset); + for (p_charcb = charcb_list; p_charcb; p_charcb = p_charcb->next) { + if (maxfdp1 < p_charcb->socket + 1) { + maxfdp1 = p_charcb->socket + 1; + } + FD_SET(p_charcb->socket, &readset); + FD_SET(p_charcb->socket, &writeset); + } + + /* Wait for data or a new connection */ + i = lwip_select(maxfdp1, &readset, &writeset, NULL, NULL); + + if (i == 0) { + continue; + } + /* At least one descriptor is ready */ + if (FD_ISSET(listenfd, &readset)) { + /* We have a new connection request!!! */ + /* Lets create a new control block */ + p_charcb = (struct charcb *) mem_malloc(sizeof (struct charcb)); + if (p_charcb) { + p_charcb->socket = lwip_accept(listenfd, + (struct sockaddr *) &p_charcb->cliaddr, + &p_charcb->clilen); + if (p_charcb->socket < 0) { + mem_free(p_charcb); + } else { + /* Keep this tecb in our list */ + p_charcb->next = charcb_list; + charcb_list = p_charcb; + p_charcb->nextchar = 0x21; + } + } else { + /* No memory to accept connection. Just accept and then close */ + int sock; + struct sockaddr cliaddr; + socklen_t clilen; + + sock = lwip_accept(listenfd, &cliaddr, &clilen); + if (sock >= 0) { + lwip_close(sock); + } + } + } + /* Go through list of connected clients and process data */ + for (p_charcb = charcb_list; p_charcb; p_charcb = p_charcb->next) { + if (FD_ISSET(p_charcb->socket, &readset)) { + /* This socket is ready for reading. This could be because someone typed + * some characters or it could be because the socket is now closed. Try reading + * some data to see. */ + if (do_read(p_charcb) < 0) { + break; + } + } + if (FD_ISSET(p_charcb->socket, &writeset)) { + char line[80]; + char setchar = p_charcb->nextchar; + + for (i = 0; i < 59; i++) { + line[i] = setchar; + if (++setchar == 0x7f) { + setchar = 0x21; + } + } + line[i] = 0; + strcat(line, "\n\r"); + if (lwip_write(p_charcb->socket, line, strlen(line)) < 0) { + close_chargen(p_charcb); + break; + } + if (++p_charcb->nextchar == 0x7f) { + p_charcb->nextchar = 0x21; + } + } + } + } +} + + +/************************************************************** + * void chargen_init(void) + * + * This function initializes the chargen service. This function + * may only be called either before or after tasking has started. + **************************************************************/ +void +chargen_init(void) +{ + sys_thread_new(CHARGEN_THREAD_NAME, chargen_thread, NULL, CHARGEN_THREAD_STACKSIZE, CHARGEN_PRIORITY); +} + +#endif /* LWIP_SOCKET && LWIP_SOCKET_SELECT */ diff --git a/contrib/apps/chargen/chargen.h b/contrib/apps/chargen/chargen.h new file mode 100644 index 00000000000..eb83e4f40cf --- /dev/null +++ b/contrib/apps/chargen/chargen.h @@ -0,0 +1,12 @@ +#ifndef LWIP_CHARGEN_H +#define LWIP_CHARGEN_H + +#include "lwip/opt.h" + +#if LWIP_SOCKET + +void chargen_init(void); + +#endif /* LWIP_SOCKET */ + +#endif /* LWIP_CHARGEN_H */ diff --git a/contrib/apps/httpserver/README b/contrib/apps/httpserver/README new file mode 100644 index 00000000000..1f18bb81c9c --- /dev/null +++ b/contrib/apps/httpserver/README @@ -0,0 +1,12 @@ +HTTPSERVER + +This is a demonstration of how to make the most basic kind +of server using lWIP. + +* httpserver-raw.c - uses raw TCP calls (coming soon!) + +* httpserver-netconn.c - uses netconn and netbuf API + +This code updates the examples in Adam Dunkel's original +lwIP documentation to match changes in the code since that +PDF release. diff --git a/contrib/apps/httpserver/httpserver-netconn.c b/contrib/apps/httpserver/httpserver-netconn.c new file mode 100644 index 00000000000..051584e6352 --- /dev/null +++ b/contrib/apps/httpserver/httpserver-netconn.c @@ -0,0 +1,103 @@ + +#include "lwip/opt.h" +#include "lwip/arch.h" +#include "lwip/api.h" + +#include "httpserver-netconn.h" + +#if LWIP_NETCONN + +#ifndef HTTPD_DEBUG +#define HTTPD_DEBUG LWIP_DBG_OFF +#endif + +static const char http_html_hdr[] = "HTTP/1.1 200 OK\r\nContent-type: text/html\r\n\r\n"; +static const char http_index_html[] = "<html><head><title>Congrats!</title></head><body><h1>Welcome to our lwIP HTTP server!</h1><p>This is a small test page, served by httpserver-netconn.</body></html>"; + +/** Serve one HTTP connection accepted in the http thread */ +static void +http_server_netconn_serve(struct netconn *conn) +{ + struct netbuf *inbuf; + char *buf; + u16_t buflen; + err_t err; + + /* Read the data from the port, blocking if nothing yet there. + We assume the request (the part we care about) is in one netbuf */ + err = netconn_recv(conn, &inbuf); + + if (err == ERR_OK) { + netbuf_data(inbuf, (void**)&buf, &buflen); + + /* Is this an HTTP GET command? (only check the first 5 chars, since + there are other formats for GET, and we're keeping it very simple )*/ + if (buflen>=5 && + buf[0]=='G' && + buf[1]=='E' && + buf[2]=='T' && + buf[3]==' ' && + buf[4]=='/' ) { + + /* Send the HTML header + * subtract 1 from the size, since we don't send the \0 in the string + * NETCONN_NOCOPY: our data is const static, so no need to copy it + */ + netconn_write(conn, http_html_hdr, sizeof(http_html_hdr)-1, NETCONN_NOCOPY); + + /* Send our HTML page */ + netconn_write(conn, http_index_html, sizeof(http_index_html)-1, NETCONN_NOCOPY); + } + } + /* Close the connection (server closes in HTTP) */ + netconn_close(conn); + + /* Delete the buffer (netconn_recv gives us ownership, + so we have to make sure to deallocate the buffer) */ + netbuf_delete(inbuf); +} + +/** The main function, never returns! */ +static void +http_server_netconn_thread(void *arg) +{ + struct netconn *conn, *newconn; + err_t err; + LWIP_UNUSED_ARG(arg); + + /* Create a new TCP connection handle */ + /* Bind to port 80 (HTTP) with default IP address */ +#if LWIP_IPV6 + conn = netconn_new(NETCONN_TCP_IPV6); + netconn_bind(conn, IP6_ADDR_ANY, 80); +#else /* LWIP_IPV6 */ + conn = netconn_new(NETCONN_TCP); + netconn_bind(conn, IP_ADDR_ANY, 80); +#endif /* LWIP_IPV6 */ + LWIP_ERROR("http_server: invalid conn", (conn != NULL), return;); + + /* Put the connection into LISTEN state */ + netconn_listen(conn); + + do { + err = netconn_accept(conn, &newconn); + if (err == ERR_OK) { + http_server_netconn_serve(newconn); + netconn_delete(newconn); + } + } while(err == ERR_OK); + LWIP_DEBUGF(HTTPD_DEBUG, + ("http_server_netconn_thread: netconn_accept received error %d, shutting down\n", + err)); + netconn_close(conn); + netconn_delete(conn); +} + +/** Initialize the HTTP server (start its thread) */ +void +http_server_netconn_init(void) +{ + sys_thread_new("http_server_netconn", http_server_netconn_thread, NULL, DEFAULT_THREAD_STACKSIZE, DEFAULT_THREAD_PRIO); +} + +#endif /* LWIP_NETCONN*/ diff --git a/contrib/apps/httpserver/httpserver-netconn.h b/contrib/apps/httpserver/httpserver-netconn.h new file mode 100644 index 00000000000..d84b10362ff --- /dev/null +++ b/contrib/apps/httpserver/httpserver-netconn.h @@ -0,0 +1,6 @@ +#ifndef LWIP_HTTPSERVER_NETCONN_H +#define LWIP_HTTPSERVER_NETCONN_H + +void http_server_netconn_init(void); + +#endif /* LWIP_HTTPSERVER_NETCONN_H */ diff --git a/contrib/apps/netio/netio.c b/contrib/apps/netio/netio.c new file mode 100644 index 00000000000..7d12ac87843 --- /dev/null +++ b/contrib/apps/netio/netio.c @@ -0,0 +1,55 @@ +#include "netio.h" + +#include "lwip/opt.h" +#include "lwip/tcp.h" + +/* See http://www.nwlab.net/art/netio/netio.html to get the netio tool */ + +#if LWIP_TCP && LWIP_CALLBACK_API +static err_t +netio_recv(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err) +{ + LWIP_UNUSED_ARG(arg); + + if (err == ERR_OK && p != NULL) { + tcp_recved(pcb, p->tot_len); + pbuf_free(p); + } else { + pbuf_free(p); + } + + if (err == ERR_OK && p == NULL) { + tcp_arg(pcb, NULL); + tcp_sent(pcb, NULL); + tcp_recv(pcb, NULL); + tcp_close(pcb); + } + + return ERR_OK; +} + +static err_t +netio_accept(void *arg, struct tcp_pcb *pcb, err_t err) +{ + LWIP_UNUSED_ARG(arg); + LWIP_UNUSED_ARG(err); + + if (pcb != NULL) { + tcp_arg(pcb, NULL); + tcp_sent(pcb, NULL); + tcp_recv(pcb, netio_recv); + } + return ERR_OK; +} + +void +netio_init(void) +{ + struct tcp_pcb *pcb; + + pcb = tcp_new_ip_type(IPADDR_TYPE_ANY); + tcp_bind(pcb, IP_ANY_TYPE, 18767); + pcb = tcp_listen(pcb); + tcp_accept(pcb, netio_accept); +} +#endif /* LWIP_TCP && LWIP_CALLBACK_API */ diff --git a/contrib/apps/netio/netio.h b/contrib/apps/netio/netio.h new file mode 100644 index 00000000000..11d7730fe29 --- /dev/null +++ b/contrib/apps/netio/netio.h @@ -0,0 +1,6 @@ +#ifndef LWIP_NETIO_H +#define LWIP_NETIO_H + +void netio_init(void); + +#endif /* LWIP_NETIO_H */ diff --git a/contrib/apps/ping/ping.c b/contrib/apps/ping/ping.c new file mode 100644 index 00000000000..143fb83e85c --- /dev/null +++ b/contrib/apps/ping/ping.c @@ -0,0 +1,396 @@ +/** + * @file + * Ping sender module + * + */ + +/* + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + */ + +/** + * This is an example of a "ping" sender (with raw API and socket API). + * It can be used as a start point to maintain opened a network connection, or + * like a network "watchdog" for your device. + * + */ + +#include "lwip/opt.h" + +#if LWIP_RAW /* don't build if not configured for use in lwipopts.h */ + +#include "ping.h" + +#include "lwip/mem.h" +#include "lwip/raw.h" +#include "lwip/icmp.h" +#include "lwip/netif.h" +#include "lwip/sys.h" +#include "lwip/timeouts.h" +#include "lwip/inet_chksum.h" +#include "lwip/prot/ip4.h" + +#if PING_USE_SOCKETS +#include "lwip/sockets.h" +#include "lwip/inet.h" +#include <string.h> +#endif /* PING_USE_SOCKETS */ + + +/** + * PING_DEBUG: Enable debugging for PING. + */ +#ifndef PING_DEBUG +#define PING_DEBUG LWIP_DBG_ON +#endif + +/** ping receive timeout - in milliseconds */ +#ifndef PING_RCV_TIMEO +#define PING_RCV_TIMEO 1000 +#endif + +/** ping delay - in milliseconds */ +#ifndef PING_DELAY +#define PING_DELAY 1000 +#endif + +/** ping identifier - must fit on a u16_t */ +#ifndef PING_ID +#define PING_ID 0xAFAF +#endif + +/** ping additional data size to include in the packet */ +#ifndef PING_DATA_SIZE +#define PING_DATA_SIZE 32 +#endif + +/** ping result action - no default action */ +#ifndef PING_RESULT +#define PING_RESULT(ping_ok) +#endif + +/* ping variables */ +static const ip_addr_t* ping_target; +static u16_t ping_seq_num; +#ifdef LWIP_DEBUG +static u32_t ping_time; +#endif /* LWIP_DEBUG */ +#if !PING_USE_SOCKETS +static struct raw_pcb *ping_pcb; +#endif /* PING_USE_SOCKETS */ + +/** Prepare a echo ICMP request */ +static void +ping_prepare_echo( struct icmp_echo_hdr *iecho, u16_t len) +{ + size_t i; + size_t data_len = len - sizeof(struct icmp_echo_hdr); + + ICMPH_TYPE_SET(iecho, ICMP_ECHO); + ICMPH_CODE_SET(iecho, 0); + iecho->chksum = 0; + iecho->id = PING_ID; + iecho->seqno = lwip_htons(++ping_seq_num); + + /* fill the additional data buffer with some data */ + for(i = 0; i < data_len; i++) { + ((char*)iecho)[sizeof(struct icmp_echo_hdr) + i] = (char)i; + } + + iecho->chksum = inet_chksum(iecho, len); +} + +#if PING_USE_SOCKETS + +/* Ping using the socket ip */ +static err_t +ping_send(int s, const ip_addr_t *addr) +{ + int err; + struct icmp_echo_hdr *iecho; + struct sockaddr_storage to; + size_t ping_size = sizeof(struct icmp_echo_hdr) + PING_DATA_SIZE; + LWIP_ASSERT("ping_size is too big", ping_size <= 0xffff); + +#if LWIP_IPV6 + if(IP_IS_V6(addr) && !ip6_addr_isipv4mappedipv6(ip_2_ip6(addr))) { + /* todo: support ICMP6 echo */ + return ERR_VAL; + } +#endif /* LWIP_IPV6 */ + + iecho = (struct icmp_echo_hdr *)mem_malloc((mem_size_t)ping_size); + if (!iecho) { + return ERR_MEM; + } + + ping_prepare_echo(iecho, (u16_t)ping_size); + +#if LWIP_IPV4 + if(IP_IS_V4(addr)) { + struct sockaddr_in *to4 = (struct sockaddr_in*)&to; + to4->sin_len = sizeof(*to4); + to4->sin_family = AF_INET; + inet_addr_from_ip4addr(&to4->sin_addr, ip_2_ip4(addr)); + } +#endif /* LWIP_IPV4 */ + +#if LWIP_IPV6 + if(IP_IS_V6(addr)) { + struct sockaddr_in6 *to6 = (struct sockaddr_in6*)&to; + to6->sin6_len = sizeof(*to6); + to6->sin6_family = AF_INET6; + inet6_addr_from_ip6addr(&to6->sin6_addr, ip_2_ip6(addr)); + } +#endif /* LWIP_IPV6 */ + + err = lwip_sendto(s, iecho, ping_size, 0, (struct sockaddr*)&to, sizeof(to)); + + mem_free(iecho); + + return (err ? ERR_OK : ERR_VAL); +} + +static void +ping_recv(int s) +{ + char buf[64]; + int len; + struct sockaddr_storage from; + int fromlen = sizeof(from); + + while((len = lwip_recvfrom(s, buf, sizeof(buf), 0, (struct sockaddr*)&from, (socklen_t*)&fromlen)) > 0) { + if (len >= (int)(sizeof(struct ip_hdr)+sizeof(struct icmp_echo_hdr))) { + ip_addr_t fromaddr; + memset(&fromaddr, 0, sizeof(fromaddr)); + +#if LWIP_IPV4 + if(from.ss_family == AF_INET) { + struct sockaddr_in *from4 = (struct sockaddr_in*)&from; + inet_addr_to_ip4addr(ip_2_ip4(&fromaddr), &from4->sin_addr); + IP_SET_TYPE_VAL(fromaddr, IPADDR_TYPE_V4); + } +#endif /* LWIP_IPV4 */ + +#if LWIP_IPV6 + if(from.ss_family == AF_INET6) { + struct sockaddr_in6 *from6 = (struct sockaddr_in6*)&from; + inet6_addr_to_ip6addr(ip_2_ip6(&fromaddr), &from6->sin6_addr); + IP_SET_TYPE_VAL(fromaddr, IPADDR_TYPE_V6); + } +#endif /* LWIP_IPV6 */ + + LWIP_DEBUGF( PING_DEBUG, ("ping: recv ")); + ip_addr_debug_print_val(PING_DEBUG, fromaddr); + LWIP_DEBUGF( PING_DEBUG, (" %"U32_F" ms\n", (sys_now() - ping_time))); + + /* todo: support ICMP6 echo */ +#if LWIP_IPV4 + if (IP_IS_V4_VAL(fromaddr)) { + struct ip_hdr *iphdr; + struct icmp_echo_hdr *iecho; + + iphdr = (struct ip_hdr *)buf; + iecho = (struct icmp_echo_hdr *)(buf + (IPH_HL(iphdr) * 4)); + if ((iecho->id == PING_ID) && (iecho->seqno == lwip_htons(ping_seq_num))) { + /* do some ping result processing */ + PING_RESULT((ICMPH_TYPE(iecho) == ICMP_ER)); + return; + } else { + LWIP_DEBUGF( PING_DEBUG, ("ping: drop\n")); + } + } +#endif /* LWIP_IPV4 */ + } + fromlen = sizeof(from); + } + + if (len == 0) { + LWIP_DEBUGF( PING_DEBUG, ("ping: recv - %"U32_F" ms - timeout\n", (sys_now()-ping_time))); + } + + /* do some ping result processing */ + PING_RESULT(0); +} + +static void +ping_thread(void *arg) +{ + int s; + int ret; + +#if LWIP_SO_SNDRCVTIMEO_NONSTANDARD + int timeout = PING_RCV_TIMEO; +#else + struct timeval timeout; + timeout.tv_sec = PING_RCV_TIMEO/1000; + timeout.tv_usec = (PING_RCV_TIMEO%1000)*1000; +#endif + LWIP_UNUSED_ARG(arg); + +#if LWIP_IPV6 + if(IP_IS_V4(ping_target) || ip6_addr_isipv4mappedipv6(ip_2_ip6(ping_target))) { + s = lwip_socket(AF_INET6, SOCK_RAW, IP_PROTO_ICMP); + } else { + s = lwip_socket(AF_INET6, SOCK_RAW, IP6_NEXTH_ICMP6); + } +#else + s = lwip_socket(AF_INET, SOCK_RAW, IP_PROTO_ICMP); +#endif + if (s < 0) { + return; + } + + ret = lwip_setsockopt(s, SOL_SOCKET, SO_RCVTIMEO, &timeout, sizeof(timeout)); + LWIP_ASSERT("setting receive timeout failed", ret == 0); + LWIP_UNUSED_ARG(ret); + + while (1) { + if (ping_send(s, ping_target) == ERR_OK) { + LWIP_DEBUGF( PING_DEBUG, ("ping: send ")); + ip_addr_debug_print(PING_DEBUG, ping_target); + LWIP_DEBUGF( PING_DEBUG, ("\n")); + +#ifdef LWIP_DEBUG + ping_time = sys_now(); +#endif /* LWIP_DEBUG */ + ping_recv(s); + } else { + LWIP_DEBUGF( PING_DEBUG, ("ping: send ")); + ip_addr_debug_print(PING_DEBUG, ping_target); + LWIP_DEBUGF( PING_DEBUG, (" - error\n")); + } + sys_msleep(PING_DELAY); + } +} + +#else /* PING_USE_SOCKETS */ + +/* Ping using the raw ip */ +static u8_t +ping_recv(void *arg, struct raw_pcb *pcb, struct pbuf *p, const ip_addr_t *addr) +{ + struct icmp_echo_hdr *iecho; + LWIP_UNUSED_ARG(arg); + LWIP_UNUSED_ARG(pcb); + LWIP_UNUSED_ARG(addr); + LWIP_ASSERT("p != NULL", p != NULL); + + if ((p->tot_len >= (PBUF_IP_HLEN + sizeof(struct icmp_echo_hdr))) && + pbuf_remove_header(p, PBUF_IP_HLEN) == 0) { + iecho = (struct icmp_echo_hdr *)p->payload; + + if ((iecho->id == PING_ID) && (iecho->seqno == lwip_htons(ping_seq_num))) { + LWIP_DEBUGF( PING_DEBUG, ("ping: recv ")); + ip_addr_debug_print(PING_DEBUG, addr); + LWIP_DEBUGF( PING_DEBUG, (" %"U32_F" ms\n", (sys_now()-ping_time))); + + /* do some ping result processing */ + PING_RESULT(1); + pbuf_free(p); + return 1; /* eat the packet */ + } + /* not eaten, restore original packet */ + pbuf_add_header(p, PBUF_IP_HLEN); + } + + return 0; /* don't eat the packet */ +} + +static void +ping_send(struct raw_pcb *raw, const ip_addr_t *addr) +{ + struct pbuf *p; + struct icmp_echo_hdr *iecho; + size_t ping_size = sizeof(struct icmp_echo_hdr) + PING_DATA_SIZE; + + LWIP_DEBUGF( PING_DEBUG, ("ping: send ")); + ip_addr_debug_print(PING_DEBUG, addr); + LWIP_DEBUGF( PING_DEBUG, ("\n")); + LWIP_ASSERT("ping_size <= 0xffff", ping_size <= 0xffff); + + p = pbuf_alloc(PBUF_IP, (u16_t)ping_size, PBUF_RAM); + if (!p) { + return; + } + if ((p->len == p->tot_len) && (p->next == NULL)) { + iecho = (struct icmp_echo_hdr *)p->payload; + + ping_prepare_echo(iecho, (u16_t)ping_size); + + raw_sendto(raw, p, addr); +#ifdef LWIP_DEBUG + ping_time = sys_now(); +#endif /* LWIP_DEBUG */ + } + pbuf_free(p); +} + +static void +ping_timeout(void *arg) +{ + struct raw_pcb *pcb = (struct raw_pcb*)arg; + + LWIP_ASSERT("ping_timeout: no pcb given!", pcb != NULL); + + ping_send(pcb, ping_target); + + sys_timeout(PING_DELAY, ping_timeout, pcb); +} + +static void +ping_raw_init(void) +{ + ping_pcb = raw_new(IP_PROTO_ICMP); + LWIP_ASSERT("ping_pcb != NULL", ping_pcb != NULL); + + raw_recv(ping_pcb, ping_recv, NULL); + raw_bind(ping_pcb, IP_ADDR_ANY); + sys_timeout(PING_DELAY, ping_timeout, ping_pcb); +} + +void +ping_send_now(void) +{ + LWIP_ASSERT("ping_pcb != NULL", ping_pcb != NULL); + ping_send(ping_pcb, ping_target); +} + +#endif /* PING_USE_SOCKETS */ + +void +ping_init(const ip_addr_t* ping_addr) +{ + ping_target = ping_addr; + +#if PING_USE_SOCKETS + sys_thread_new("ping_thread", ping_thread, NULL, DEFAULT_THREAD_STACKSIZE, DEFAULT_THREAD_PRIO); +#else /* PING_USE_SOCKETS */ + ping_raw_init(); +#endif /* PING_USE_SOCKETS */ +} + +#endif /* LWIP_RAW */ diff --git a/contrib/apps/ping/ping.h b/contrib/apps/ping/ping.h new file mode 100644 index 00000000000..1f21c7b0997 --- /dev/null +++ b/contrib/apps/ping/ping.h @@ -0,0 +1,19 @@ +#ifndef LWIP_PING_H +#define LWIP_PING_H + +#include "lwip/ip_addr.h" + +/** + * PING_USE_SOCKETS: Set to 1 to use sockets, otherwise the raw api is used + */ +#ifndef PING_USE_SOCKETS +#define PING_USE_SOCKETS LWIP_SOCKET +#endif + +void ping_init(const ip_addr_t* ping_addr); + +#if !PING_USE_SOCKETS +void ping_send_now(void); +#endif /* !PING_USE_SOCKETS */ + +#endif /* LWIP_PING_H */ diff --git a/contrib/apps/rtp/rtp.c b/contrib/apps/rtp/rtp.c new file mode 100644 index 00000000000..4be69731c4e --- /dev/null +++ b/contrib/apps/rtp/rtp.c @@ -0,0 +1,308 @@ +/** + * @file + * RTP client/server module + * + */ + +/* + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + */ + +#include "lwip/opt.h" + +#if LWIP_SOCKET && LWIP_IGMP /* don't build if not configured for use in lwipopts.h */ + +#include "lwip/sys.h" +#include "lwip/sockets.h" + +#include "rtp.h" + +#include "rtpdata.h" + +#include <string.h> + +/** This is an example of a "RTP" client/server based on a MPEG4 bitstream (with socket API). + */ + +/** + * RTP_DEBUG: Enable debugging for RTP. + */ +#ifndef RTP_DEBUG +#define RTP_DEBUG LWIP_DBG_ON +#endif + +/** RTP stream port */ +#ifndef RTP_STREAM_PORT +#define RTP_STREAM_PORT 4000 +#endif + +/** RTP stream multicast address as IPv4 address in "u32_t" format */ +#ifndef RTP_STREAM_ADDRESS +#define RTP_STREAM_ADDRESS inet_addr("232.0.0.0") +#endif + +/** RTP send delay - in milliseconds */ +#ifndef RTP_SEND_DELAY +#define RTP_SEND_DELAY 40 +#endif + +/** RTP receive timeout - in milliseconds */ +#ifndef RTP_RECV_TIMEOUT +#define RTP_RECV_TIMEOUT 2000 +#endif + +/** RTP stats display period - in received packets */ +#ifndef RTP_RECV_STATS +#define RTP_RECV_STATS 50 +#endif + +/** RTP macro to let the application process the data */ +#ifndef RTP_RECV_PROCESSING +#define RTP_RECV_PROCESSING(p,s) +#endif + +/** RTP packet/payload size */ +#define RTP_PACKET_SIZE 1500 +#define RTP_PAYLOAD_SIZE 1024 + +/** RTP header constants */ +#define RTP_VERSION 0x80 +#define RTP_TIMESTAMP_INCREMENT 3600 +#define RTP_SSRC 0 +#define RTP_PAYLOADTYPE 96 +#define RTP_MARKER_MASK 0x80 + +/** RTP message header */ +#ifdef PACK_STRUCT_USE_INCLUDES +# include "arch/bpstruct.h" +#endif +PACK_STRUCT_BEGIN +struct rtp_hdr { + PACK_STRUCT_FLD_8(u8_t version); + PACK_STRUCT_FLD_8(u8_t payloadtype); + PACK_STRUCT_FIELD(u16_t seqNum); + PACK_STRUCT_FIELD(u32_t timestamp); + PACK_STRUCT_FIELD(u32_t ssrc); +} PACK_STRUCT_STRUCT; +PACK_STRUCT_END +#ifdef PACK_STRUCT_USE_INCLUDES +# include "arch/epstruct.h" +#endif + +/** RTP packets */ +static u8_t rtp_send_packet[RTP_PACKET_SIZE]; +static u8_t rtp_recv_packet[RTP_PACKET_SIZE]; + +/** + * RTP send packets + */ +static void +rtp_send_packets( int sock, struct sockaddr_in* to) +{ + struct rtp_hdr* rtphdr; + u8_t* rtp_payload; + size_t rtp_payload_size; + size_t rtp_data_index; + + /* prepare RTP packet */ + rtphdr = (struct rtp_hdr*)rtp_send_packet; + rtphdr->version = RTP_VERSION; + rtphdr->payloadtype = 0; + rtphdr->ssrc = PP_HTONL(RTP_SSRC); + rtphdr->timestamp = lwip_htonl(lwip_ntohl(rtphdr->timestamp) + RTP_TIMESTAMP_INCREMENT); + + /* send RTP stream packets */ + rtp_data_index = 0; + do { + rtp_payload = rtp_send_packet+sizeof(struct rtp_hdr); + rtp_payload_size = LWIP_MIN(RTP_PAYLOAD_SIZE, sizeof(rtp_data) - rtp_data_index); + + MEMCPY(rtp_payload, rtp_data + rtp_data_index, rtp_payload_size); + + /* set MARKER bit in RTP header on the last packet of an image */ + if ((rtp_data_index + rtp_payload_size) >= sizeof(rtp_data)) { + rtphdr->payloadtype = RTP_PAYLOADTYPE | RTP_MARKER_MASK; + } else { + rtphdr->payloadtype = RTP_PAYLOADTYPE; + } + + /* send RTP stream packet */ + if (lwip_sendto(sock, rtp_send_packet, sizeof(struct rtp_hdr) + rtp_payload_size, + 0, (struct sockaddr *)to, sizeof(struct sockaddr)) >= 0) { + rtphdr->seqNum = lwip_htons((u16_t)(lwip_ntohs(rtphdr->seqNum) + 1)); + rtp_data_index += rtp_payload_size; + } else { + LWIP_DEBUGF(RTP_DEBUG, ("rtp_sender: not sendto==%i\n", errno)); + } + }while (rtp_data_index < sizeof(rtp_data)); +} + +/** + * RTP send thread + */ +static void +rtp_send_thread(void *arg) +{ + int sock; + struct sockaddr_in local; + struct sockaddr_in to; + u32_t rtp_stream_address; + + LWIP_UNUSED_ARG(arg); + + /* initialize RTP stream address */ + rtp_stream_address = RTP_STREAM_ADDRESS; + + /* if we got a valid RTP stream address... */ + if (rtp_stream_address != 0) { + /* create new socket */ + sock = lwip_socket(AF_INET, SOCK_DGRAM, 0); + if (sock >= 0) { + /* prepare local address */ + memset(&local, 0, sizeof(local)); + local.sin_family = AF_INET; + local.sin_port = PP_HTONS(INADDR_ANY); + local.sin_addr.s_addr = PP_HTONL(INADDR_ANY); + + /* bind to local address */ + if (lwip_bind(sock, (struct sockaddr *)&local, sizeof(local)) == 0) { + /* prepare RTP stream address */ + memset(&to, 0, sizeof(to)); + to.sin_family = AF_INET; + to.sin_port = PP_HTONS(RTP_STREAM_PORT); + to.sin_addr.s_addr = rtp_stream_address; + + /* send RTP packets */ + memset(rtp_send_packet, 0, sizeof(rtp_send_packet)); + while (1) { + rtp_send_packets( sock, &to); + sys_msleep(RTP_SEND_DELAY); + } + } + + /* close the socket */ + lwip_close(sock); + } + } +} + +/** + * RTP recv thread + */ +static void +rtp_recv_thread(void *arg) +{ + int sock; + struct sockaddr_in local; + struct sockaddr_in from; + int fromlen; + struct ip_mreq ipmreq; + struct rtp_hdr* rtphdr; + u32_t rtp_stream_address; + int timeout; + int result; + int recvrtppackets = 0; + int lostrtppackets = 0; + u16_t lastrtpseq = 0; + + LWIP_UNUSED_ARG(arg); + + /* initialize RTP stream address */ + rtp_stream_address = RTP_STREAM_ADDRESS; + + /* if we got a valid RTP stream address... */ + if (rtp_stream_address != 0) { + /* create new socket */ + sock = lwip_socket(AF_INET, SOCK_DGRAM, 0); + if (sock >= 0) { + /* prepare local address */ + memset(&local, 0, sizeof(local)); + local.sin_family = AF_INET; + local.sin_port = PP_HTONS(RTP_STREAM_PORT); + local.sin_addr.s_addr = PP_HTONL(INADDR_ANY); + + /* bind to local address */ + if (lwip_bind(sock, (struct sockaddr *)&local, sizeof(local)) == 0) { + /* set recv timeout */ + timeout = RTP_RECV_TIMEOUT; + result = lwip_setsockopt(sock, SOL_SOCKET, SO_RCVTIMEO, (char *)&timeout, sizeof(timeout)); + if (result) { + LWIP_DEBUGF(RTP_DEBUG, ("rtp_recv_thread: setsockopt(SO_RCVTIMEO) failed: errno=%d\n", errno)); + } + + /* prepare multicast "ip_mreq" struct */ + ipmreq.imr_multiaddr.s_addr = rtp_stream_address; + ipmreq.imr_interface.s_addr = PP_HTONL(INADDR_ANY); + + /* join multicast group */ + if (lwip_setsockopt(sock, IPPROTO_IP, IP_ADD_MEMBERSHIP, &ipmreq, sizeof(ipmreq)) == 0) { + /* receive RTP packets */ + while(1) { + fromlen = sizeof(from); + result = lwip_recvfrom(sock, rtp_recv_packet, sizeof(rtp_recv_packet), 0, + (struct sockaddr *)&from, (socklen_t *)&fromlen); + if ((result > 0) && ((size_t)result >= sizeof(struct rtp_hdr))) { + size_t recved = (size_t)result; + rtphdr = (struct rtp_hdr *)rtp_recv_packet; + recvrtppackets++; + if ((lastrtpseq == 0) || ((lastrtpseq + 1) == lwip_ntohs(rtphdr->seqNum))) { + RTP_RECV_PROCESSING((rtp_recv_packet + sizeof(rtp_hdr)), (recved-sizeof(rtp_hdr))); + LWIP_UNUSED_ARG(recved); /* just in case... */ + } else { + lostrtppackets++; + } + lastrtpseq = lwip_ntohs(rtphdr->seqNum); + if ((recvrtppackets % RTP_RECV_STATS) == 0) { + LWIP_DEBUGF(RTP_DEBUG, ("rtp_recv_thread: recv %6i packet(s) / lost %4i packet(s) (%.4f%%)...\n", recvrtppackets, lostrtppackets, (lostrtppackets*100.0)/recvrtppackets)); + } + } else { + LWIP_DEBUGF(RTP_DEBUG, ("rtp_recv_thread: recv timeout...\n")); + } + } + + /* leave multicast group */ + /* TODO: this code is never reached + result = lwip_setsockopt(sock, IPPROTO_IP, IP_DROP_MEMBERSHIP, &ipmreq, sizeof(ipmreq)); + if (result) { + LWIP_DEBUGF(RTP_DEBUG, ("rtp_recv_thread: setsockopt(IP_DROP_MEMBERSHIP) failed: errno=%d\n", errno)); + }*/ + } + } + + /* close the socket */ + lwip_close(sock); + } + } +} + +void +rtp_init(void) +{ + sys_thread_new("rtp_send_thread", rtp_send_thread, NULL, DEFAULT_THREAD_STACKSIZE, DEFAULT_THREAD_PRIO); + sys_thread_new("rtp_recv_thread", rtp_recv_thread, NULL, DEFAULT_THREAD_STACKSIZE, DEFAULT_THREAD_PRIO); +} + +#endif /* LWIP_SOCKET && LWIP_IGMP */ diff --git a/contrib/apps/rtp/rtp.h b/contrib/apps/rtp/rtp.h new file mode 100644 index 00000000000..c53d89bdad6 --- /dev/null +++ b/contrib/apps/rtp/rtp.h @@ -0,0 +1,8 @@ +#ifndef LWIP_RTP_H +#define LWIP_RTP_H + +#if LWIP_SOCKET && LWIP_IGMP +void rtp_init(void); +#endif /* LWIP_SOCKET && LWIP_IGMP */ + +#endif /* LWIP_RTP_H */ diff --git a/contrib/apps/rtp/rtpdata.h b/contrib/apps/rtp/rtpdata.h new file mode 100644 index 00000000000..76ff344dd03 --- /dev/null +++ b/contrib/apps/rtp/rtpdata.h @@ -0,0 +1,2040 @@ +const unsigned char rtp_data[] = { + 0x00, 0x00, 0x01, 0xb0, 0xf5, 0x00, 0x00, 0x01, + 0xb5, 0x09, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, + 0x01, 0x20, 0x00, 0x86, 0x84, 0x00, 0x67, 0x0c, + 0x2c, 0x10, 0x90, 0x51, 0x8f, 0x00, 0x00, 0x01, + 0xb2, 0x44, 0x69, 0x76, 0x58, 0x35, 0x30, 0x33, + 0x62, 0x31, 0x33, 0x39, 0x33, 0x70, 0x00, 0x00, + 0x01, 0xb2, 0x58, 0x76, 0x69, 0x44, 0x30, 0x30, + 0x33, 0x39, 0x00, 0x00, 0x01, 0xb6, 0x18, 0x60, + 0xab, 0x94, 0x03, 0xc0, 0xca, 0xc0, 0x3e, 0xd0, + 0x78, 0x4f, 0xf9, 0x44, 0x91, 0xe9, 0xfa, 0xc9, + 0xfe, 0xa1, 0xa4, 0xc1, 0x66, 0x03, 0x2e, 0x39, + 0x0c, 0x7e, 0x0e, 0xaa, 0x02, 0x92, 0xf8, 0xd5, + 0xec, 0xe2, 0x35, 0xb9, 0x35, 0x0c, 0xb3, 0x82, + 0xa6, 0xad, 0xd0, 0xd1, 0xca, 0xb8, 0xe8, 0x10, + 0x55, 0x78, 0x03, 0xc0, 0x38, 0x15, 0xba, 0xce, + 0xe2, 0xea, 0x00, 0xc3, 0x60, 0xb1, 0x70, 0xf4, + 0x14, 0x6c, 0x35, 0x4d, 0xe8, 0x5a, 0x1e, 0x58, + 0xdf, 0x03, 0x01, 0xfd, 0x2a, 0x45, 0x54, 0xca, + 0x0f, 0x05, 0x00, 0xbd, 0xd0, 0xcc, 0xb4, 0x90, + 0x4c, 0x24, 0x6b, 0x20, 0x30, 0x95, 0xf1, 0x2f, + 0xb4, 0xa7, 0x83, 0xdc, 0xce, 0x03, 0x05, 0x02, + 0x1a, 0x5d, 0x1a, 0x2c, 0xbf, 0x51, 0x28, 0x8b, + 0xd7, 0x6b, 0xdd, 0xf9, 0x44, 0xbb, 0x0e, 0x91, + 0x64, 0xb9, 0xa6, 0x33, 0xd3, 0x6e, 0x34, 0xa4, + 0xac, 0xac, 0x53, 0x0d, 0x79, 0xbe, 0xae, 0x5b, + 0x47, 0x2e, 0xde, 0x62, 0xa1, 0x53, 0xcd, 0x7d, + 0xfe, 0x66, 0xa1, 0x2b, 0x9c, 0xe1, 0xca, 0xbc, + 0xea, 0x84, 0x1c, 0x68, 0xff, 0xbb, 0x28, 0xa1, + 0x26, 0x18, 0x99, 0xb1, 0x4f, 0x68, 0x80, 0x28, + 0x0e, 0x20, 0xc3, 0xbf, 0x0f, 0x80, 0xf8, 0x90, + 0x3b, 0x1f, 0x16, 0xe4, 0xb0, 0x6f, 0x44, 0x16, + 0x38, 0xb8, 0xc3, 0x81, 0x22, 0xfa, 0xe3, 0x09, + 0xf6, 0x61, 0x6d, 0xef, 0x67, 0x56, 0x3b, 0x57, + 0xb5, 0x23, 0x03, 0x1f, 0x6d, 0x0d, 0xb9, 0x08, + 0xc6, 0x43, 0xba, 0xd1, 0x40, 0x5a, 0xe8, 0xca, + 0x9e, 0x17, 0x1f, 0x6d, 0x5d, 0x16, 0x98, 0xab, + 0xe6, 0x99, 0xf6, 0x37, 0xc6, 0x1b, 0xdc, 0xb9, + 0xb3, 0xfe, 0x9a, 0x4b, 0x1e, 0xec, 0xf9, 0x5f, + 0xb8, 0xc7, 0xfc, 0xbe, 0x6c, 0xd5, 0xf3, 0x9b, + 0x17, 0x8b, 0x89, 0x82, 0xff, 0x30, 0x19, 0x20, + 0x30, 0xe6, 0x29, 0x96, 0x75, 0x75, 0xeb, 0x00, + 0x3f, 0xa1, 0x20, 0x5b, 0x06, 0x11, 0x98, 0x1f, + 0xb2, 0xad, 0x3a, 0x59, 0xe6, 0x7d, 0x38, 0xa4, + 0xb1, 0x4f, 0xfe, 0xdf, 0x3a, 0x4b, 0xdb, 0x69, + 0xc3, 0x93, 0xcc, 0xdf, 0x5e, 0xf7, 0x2a, 0x38, + 0x2a, 0x89, 0x84, 0x80, 0x6c, 0x12, 0x44, 0x95, + 0x78, 0xd8, 0x7e, 0x3f, 0x4e, 0xcf, 0x3f, 0x39, + 0xba, 0x9f, 0xfa, 0x8f, 0x2f, 0x62, 0xfa, 0xf0, + 0xb6, 0x20, 0xa7, 0x06, 0x02, 0x3f, 0x28, 0x96, + 0x80, 0xf0, 0x99, 0x8e, 0x82, 0x15, 0x11, 0x87, + 0x35, 0xa4, 0xfd, 0x53, 0xcb, 0xcd, 0x68, 0x38, + 0xe8, 0xdb, 0x8d, 0xc2, 0x71, 0xbc, 0x65, 0x3e, + 0xac, 0x5b, 0x0d, 0xae, 0xc0, 0x3c, 0x77, 0xfe, + 0xe8, 0xde, 0x3c, 0xbd, 0xdb, 0xb3, 0x39, 0x09, + 0x56, 0x0a, 0xa2, 0xfe, 0x40, 0xd7, 0x6f, 0x56, + 0x07, 0x02, 0xec, 0xd6, 0xed, 0x06, 0x5e, 0x2f, + 0xb6, 0xce, 0xf1, 0x4f, 0x16, 0x88, 0x04, 0x41, + 0x79, 0x0e, 0x98, 0xbe, 0x54, 0x75, 0x1a, 0xd6, + 0x50, 0xcf, 0x82, 0x6a, 0xf7, 0xaf, 0x7f, 0xfb, + 0x6d, 0x88, 0x97, 0x24, 0x40, 0x68, 0xa0, 0x57, + 0x79, 0x57, 0xe9, 0x6b, 0xaa, 0xe5, 0xe4, 0x2b, + 0xaa, 0x14, 0x64, 0x90, 0x6c, 0x50, 0x4a, 0xe3, + 0x97, 0x43, 0xf6, 0x81, 0x90, 0xa9, 0xa6, 0xba, + 0xb1, 0x21, 0x12, 0x5f, 0xe0, 0xdf, 0x88, 0x86, + 0x03, 0x30, 0x94, 0xb2, 0x6d, 0xd2, 0xdc, 0x45, + 0x14, 0x54, 0x1d, 0xe8, 0x38, 0x8d, 0xbe, 0x8a, + 0xaf, 0x20, 0xa2, 0x3e, 0xa2, 0x5c, 0xc6, 0xae, + 0xe6, 0xc4, 0x48, 0xec, 0xea, 0xc7, 0x4e, 0x17, + 0xb2, 0x91, 0x52, 0xb4, 0xe9, 0x8b, 0x15, 0xfb, + 0x99, 0x7c, 0xda, 0xb8, 0xad, 0x57, 0x31, 0x5b, + 0x5b, 0x67, 0xaa, 0x1e, 0x93, 0x76, 0xa5, 0x25, + 0xd9, 0x0d, 0x70, 0xd8, 0xb9, 0x11, 0x34, 0xfd, + 0xaf, 0x0e, 0x0d, 0x42, 0x57, 0x97, 0x26, 0x06, + 0xdf, 0x29, 0x7e, 0x79, 0x72, 0x22, 0x36, 0xa5, + 0x9f, 0x6a, 0x16, 0x24, 0x6f, 0x10, 0x56, 0xec, + 0x5b, 0x46, 0x50, 0x94, 0x88, 0xc4, 0xfa, 0x9e, + 0xd8, 0x5b, 0xb7, 0x50, 0x72, 0x62, 0x25, 0xaa, + 0x39, 0x84, 0x69, 0xaa, 0xfc, 0xbf, 0x9b, 0x45, + 0xf7, 0xc5, 0x41, 0x97, 0x41, 0xc7, 0xac, 0x7f, + 0x68, 0x92, 0xab, 0x64, 0xaa, 0x46, 0x32, 0x84, + 0x77, 0x1b, 0xfc, 0xbc, 0x5a, 0x42, 0x28, 0xfa, + 0x3e, 0x55, 0xf4, 0xe9, 0x44, 0xac, 0xc5, 0x4a, + 0x6c, 0x93, 0xde, 0x03, 0x6d, 0xdc, 0xb8, 0x5b, + 0xb7, 0x83, 0x7e, 0xc2, 0xaa, 0x33, 0x70, 0x34, + 0x41, 0x46, 0x25, 0xa5, 0x6f, 0xdb, 0x96, 0x0f, + 0xd3, 0xab, 0xd4, 0x17, 0x65, 0x96, 0x0c, 0x1e, + 0x39, 0x4c, 0x9d, 0x90, 0x3f, 0x5b, 0x8d, 0xaa, + 0xce, 0xac, 0xa6, 0x50, 0xf0, 0x66, 0xb2, 0x30, + 0xce, 0x42, 0x61, 0xaa, 0xb6, 0x7e, 0xca, 0xbf, + 0xfd, 0xbf, 0xef, 0x51, 0xed, 0xdf, 0x95, 0x0b, + 0xa7, 0x34, 0x24, 0x13, 0x62, 0x44, 0x81, 0xdf, + 0x3a, 0x8e, 0x95, 0x91, 0x67, 0xd7, 0x57, 0x54, + 0x92, 0x1d, 0x79, 0xa3, 0x2a, 0xf3, 0x0c, 0x7a, + 0x12, 0xa8, 0x33, 0xf9, 0x05, 0x02, 0x7b, 0xef, + 0x12, 0x18, 0xab, 0x8b, 0x40, 0x38, 0x7e, 0x0c, + 0x1f, 0x04, 0x30, 0x62, 0xa8, 0xd5, 0xd9, 0x78, + 0xdd, 0x1c, 0xb4, 0x57, 0xc1, 0x83, 0xc4, 0x41, + 0x08, 0x72, 0x5c, 0xc2, 0xb6, 0xd3, 0xd4, 0x85, + 0x4a, 0x7e, 0x58, 0xc3, 0x19, 0xfa, 0xdd, 0x51, + 0x03, 0x85, 0x1d, 0xe9, 0x10, 0x5e, 0x8c, 0x8f, + 0x41, 0x03, 0xe9, 0xbc, 0xa8, 0xba, 0xeb, 0x73, + 0x7d, 0x85, 0x69, 0xc7, 0x3b, 0xd9, 0x49, 0x0b, + 0x39, 0x03, 0x12, 0x11, 0x8b, 0x72, 0x97, 0x62, + 0x5f, 0xfe, 0x59, 0x4d, 0xc0, 0x3a, 0xdf, 0xcb, + 0x3e, 0x80, 0x39, 0xd5, 0x7a, 0xb1, 0x45, 0x86, + 0x06, 0xf6, 0xb6, 0xda, 0x98, 0xa1, 0x41, 0xae, + 0x12, 0xd3, 0xd1, 0x71, 0x5a, 0xa5, 0x40, 0xc0, + 0x8a, 0x3f, 0x4e, 0xac, 0x78, 0x93, 0x55, 0x31, + 0xfc, 0xcf, 0x67, 0x93, 0x52, 0xc4, 0x53, 0x0d, + 0xdf, 0x49, 0xd7, 0x83, 0x00, 0x18, 0x4b, 0xcd, + 0x65, 0xaf, 0xb5, 0xd5, 0x6c, 0xc4, 0x14, 0xb7, + 0xdb, 0x9d, 0x06, 0x17, 0xca, 0xe1, 0x60, 0x07, + 0x6d, 0x57, 0xd0, 0xfb, 0x1a, 0xf5, 0xb2, 0x56, + 0xca, 0xea, 0x21, 0x77, 0x41, 0xc0, 0x46, 0xc8, + 0x85, 0xe3, 0x15, 0x6a, 0xdb, 0x80, 0x47, 0x6d, + 0x05, 0x44, 0x06, 0x04, 0xf6, 0x92, 0x24, 0xdb, + 0x9b, 0x6f, 0xfa, 0x8d, 0x72, 0x2d, 0x75, 0x7e, + 0x33, 0x9c, 0xe7, 0x06, 0xbb, 0x3d, 0xa4, 0xb7, + 0xee, 0x31, 0x46, 0x4b, 0x91, 0xe2, 0xb0, 0x54, + 0x5c, 0x78, 0x9e, 0x45, 0x90, 0xe4, 0x76, 0xbe, + 0xe1, 0x4c, 0xae, 0x89, 0x20, 0x6e, 0x77, 0x76, + 0x94, 0x63, 0x93, 0xaa, 0x62, 0x0e, 0x28, 0x7b, + 0xec, 0xc9, 0xc5, 0x25, 0x64, 0x5a, 0xe9, 0xcc, + 0x91, 0x1a, 0x9c, 0xcf, 0x91, 0x47, 0x32, 0x12, + 0x9f, 0x8b, 0x36, 0x07, 0x33, 0x4c, 0x45, 0x06, + 0x19, 0xdb, 0x61, 0xc5, 0x68, 0xb7, 0xab, 0x2e, + 0x7b, 0x5c, 0xa6, 0x4c, 0x6e, 0x08, 0x5f, 0xc1, + 0xc4, 0x99, 0x64, 0xef, 0xd8, 0x05, 0x5c, 0x0f, + 0x76, 0xdd, 0xab, 0x4f, 0x8e, 0x29, 0x54, 0x59, + 0x1d, 0x30, 0x33, 0xfb, 0x3b, 0x43, 0x96, 0xf4, + 0x52, 0x47, 0x2c, 0x66, 0x81, 0xca, 0xa6, 0x73, + 0x51, 0xc1, 0xc0, 0x32, 0x98, 0xa3, 0x41, 0x1c, + 0x40, 0x5e, 0x22, 0x05, 0xa0, 0xdb, 0xb0, 0x88, + 0xdf, 0xee, 0x2f, 0x3a, 0xbb, 0xe2, 0xef, 0x79, + 0x09, 0xa6, 0x0c, 0x0f, 0x4c, 0xdc, 0x81, 0xcc, + 0x3d, 0x36, 0x52, 0x4e, 0xbd, 0x44, 0x0d, 0x0d, + 0x84, 0xf5, 0x74, 0x33, 0x14, 0x1a, 0x87, 0xcb, + 0xcc, 0x93, 0xa3, 0x69, 0x21, 0x20, 0x26, 0x23, + 0xd9, 0x95, 0x0c, 0x22, 0x2b, 0x2f, 0x0d, 0xf4, + 0x34, 0x74, 0x53, 0x16, 0x5d, 0x60, 0x96, 0x3e, + 0x53, 0xd3, 0xcc, 0xc5, 0x72, 0x49, 0xc2, 0x4d, + 0xea, 0x02, 0x21, 0x7f, 0xbd, 0x80, 0x1d, 0xf0, + 0x87, 0xe6, 0xdb, 0xcc, 0x92, 0xdd, 0xfe, 0x78, + 0x4a, 0xd2, 0xf9, 0x77, 0x24, 0xed, 0x5a, 0x31, + 0x6c, 0xec, 0x71, 0x5d, 0x85, 0xad, 0xb3, 0xb9, + 0x6f, 0x11, 0x2d, 0xfa, 0x42, 0x2b, 0xcb, 0x01, + 0x08, 0x18, 0x11, 0x56, 0xcb, 0x01, 0xe1, 0xe0, + 0x1f, 0x06, 0xe8, 0x3c, 0x6c, 0x01, 0xaa, 0x49, + 0x86, 0xbf, 0x63, 0x79, 0x03, 0xbe, 0xd8, 0x47, + 0x4f, 0x26, 0x0d, 0x11, 0xe3, 0x76, 0x27, 0x0e, + 0xf1, 0x79, 0x44, 0x46, 0xc3, 0x3b, 0x4f, 0x05, + 0x20, 0x40, 0xff, 0x59, 0x6f, 0xaa, 0x17, 0xf4, + 0x40, 0xa1, 0x15, 0x0a, 0x4c, 0x0f, 0x94, 0x81, + 0xb8, 0x0c, 0x8e, 0x8d, 0xc3, 0x80, 0xc1, 0xeb, + 0x02, 0x16, 0xf4, 0xbe, 0xca, 0xa4, 0x3a, 0xa8, + 0xec, 0x0c, 0x89, 0xc4, 0x59, 0xe4, 0x8b, 0x9a, + 0x40, 0x7e, 0xae, 0xea, 0xa0, 0xeb, 0x6a, 0x99, + 0x95, 0x73, 0x79, 0x62, 0x18, 0xb8, 0x38, 0x64, + 0x73, 0x97, 0xb7, 0x58, 0xd1, 0x2d, 0x8d, 0xbe, + 0xf3, 0x13, 0x2f, 0x7c, 0xc0, 0x1d, 0x61, 0x4e, + 0x4c, 0xe6, 0x95, 0xce, 0x97, 0xf9, 0xbc, 0xf4, + 0x5a, 0xce, 0xa1, 0x3b, 0x39, 0xef, 0xc5, 0x39, + 0x4b, 0x72, 0x1b, 0xa5, 0x41, 0x92, 0x27, 0xda, + 0x72, 0xc2, 0xbb, 0xd4, 0x8d, 0x34, 0x97, 0x9d, + 0xb7, 0xde, 0xe7, 0xb0, 0x64, 0x8a, 0x0a, 0x0c, + 0x0e, 0x60, 0x30, 0x62, 0xb8, 0xbb, 0x9f, 0x96, + 0x05, 0x31, 0x33, 0xfa, 0x3c, 0x1f, 0xf4, 0x3d, + 0x04, 0x3c, 0x5c, 0x1e, 0x1b, 0xfe, 0xf1, 0xfe, + 0xa1, 0xb1, 0x03, 0x54, 0x99, 0x50, 0x61, 0xc5, + 0xbc, 0x2d, 0x00, 0xfe, 0xaf, 0x01, 0xe1, 0x7f, + 0xeb, 0xd4, 0x77, 0x0d, 0xb4, 0x0a, 0x9c, 0x18, + 0x92, 0x3d, 0x5a, 0xbf, 0xc0, 0x98, 0x66, 0xcc, + 0x06, 0x09, 0x6a, 0x50, 0xe9, 0x18, 0x32, 0x00, + 0x78, 0xc8, 0x06, 0x68, 0xac, 0x8b, 0x3f, 0x38, + 0xbf, 0x4a, 0x33, 0x30, 0x1c, 0x4f, 0xae, 0x16, + 0x44, 0x98, 0x24, 0x08, 0xc9, 0x07, 0xed, 0x62, + 0xbb, 0x89, 0x15, 0xca, 0x0f, 0x09, 0x00, 0x7a, + 0x51, 0xc5, 0x93, 0x54, 0x45, 0xfb, 0x73, 0xdf, + 0xe9, 0x42, 0x07, 0x90, 0x10, 0xcb, 0xdb, 0x2b, + 0x47, 0x20, 0x2b, 0xaa, 0xf4, 0x5c, 0xa4, 0x28, + 0x38, 0x9d, 0x5a, 0x44, 0x22, 0x0d, 0x54, 0x81, + 0x1d, 0x07, 0x0a, 0x37, 0xee, 0x49, 0x8b, 0xfb, + 0x3a, 0x8d, 0x7e, 0x83, 0x84, 0xfd, 0xf7, 0x98, + 0xad, 0xac, 0xa7, 0x46, 0x07, 0x62, 0x72, 0x56, + 0x1c, 0x03, 0x05, 0x4d, 0x70, 0xd8, 0x60, 0x62, + 0x8a, 0x8d, 0xe8, 0x23, 0x03, 0x04, 0x6d, 0x60, + 0xdc, 0x2a, 0x27, 0x92, 0x08, 0x8f, 0x65, 0xed, + 0xbd, 0xca, 0xa5, 0x1d, 0x80, 0x8d, 0x11, 0x03, + 0x83, 0xc7, 0x05, 0x04, 0x85, 0xcd, 0x2f, 0x3a, + 0xd4, 0x83, 0x02, 0x91, 0x91, 0xc5, 0x76, 0xb5, + 0x79, 0xcb, 0xfb, 0x29, 0x22, 0x90, 0x1e, 0x09, + 0x9f, 0x2c, 0x07, 0x77, 0xa0, 0x38, 0xf8, 0x63, + 0xf5, 0x2a, 0xd4, 0xc5, 0x0f, 0xd7, 0x43, 0x38, + 0xb5, 0xe8, 0x38, 0x94, 0x29, 0x71, 0x68, 0xb4, + 0x99, 0x0a, 0x4d, 0xf6, 0x94, 0x9d, 0x8e, 0x96, + 0x58, 0x88, 0x63, 0x46, 0x02, 0x9d, 0x64, 0x83, + 0x70, 0x72, 0x32, 0x6f, 0x90, 0x1d, 0x0e, 0xd5, + 0xf5, 0xd9, 0x0d, 0xe8, 0x0f, 0xa3, 0x20, 0x5f, + 0x26, 0x59, 0xc3, 0x50, 0x33, 0x04, 0xc9, 0x0c, + 0xc8, 0xa2, 0xce, 0x12, 0x43, 0x44, 0xa3, 0x55, + 0xe5, 0x07, 0x05, 0x1a, 0x69, 0xa8, 0xc4, 0x39, + 0x92, 0xa2, 0x44, 0x0e, 0x08, 0xe0, 0xa2, 0x4a, + 0x28, 0xd7, 0x80, 0xe1, 0x37, 0x96, 0x0c, 0x49, + 0x28, 0x0f, 0x3c, 0xc8, 0xe2, 0xc1, 0x5d, 0x4f, + 0xd4, 0x48, 0xa2, 0x21, 0x59, 0xf1, 0x0d, 0x9f, + 0xaa, 0xc6, 0x77, 0xc8, 0xe5, 0xce, 0x0d, 0xca, + 0x02, 0x87, 0x4a, 0x49, 0x01, 0xc8, 0x48, 0xc8, + 0xf3, 0x1b, 0x2f, 0xdf, 0x6c, 0xcb, 0x88, 0x66, + 0xf1, 0x40, 0xbd, 0x6a, 0x34, 0xfc, 0xb0, 0x89, + 0xde, 0x11, 0xc5, 0xc6, 0xa2, 0x44, 0xc6, 0xdb, + 0x67, 0xff, 0xd1, 0x79, 0x01, 0xa4, 0x9e, 0xf0, + 0x1f, 0x10, 0x57, 0x2b, 0x24, 0xc5, 0x1c, 0x09, + 0x45, 0x7e, 0xcc, 0x55, 0xe5, 0x0d, 0x64, 0xe2, + 0x2c, 0xe4, 0xea, 0xe4, 0x81, 0x31, 0xfd, 0x61, + 0x38, 0x8f, 0xba, 0x1f, 0xb4, 0xd9, 0x6c, 0xa8, + 0xac, 0xe4, 0xe8, 0xca, 0x9e, 0xee, 0xa9, 0x51, + 0xd7, 0xe9, 0x9d, 0xcc, 0xb0, 0x7c, 0x24, 0xc5, + 0x13, 0xa0, 0x89, 0x78, 0x0b, 0x15, 0xd1, 0x09, + 0xe4, 0xbf, 0x34, 0x6f, 0xcf, 0x0b, 0x82, 0x51, + 0xb3, 0x70, 0x7d, 0x83, 0xe1, 0x24, 0x0d, 0x33, + 0xad, 0xda, 0x5d, 0xfe, 0xe7, 0x38, 0x54, 0x52, + 0x0e, 0x3d, 0xd5, 0xec, 0xef, 0x0b, 0x05, 0xe1, + 0x16, 0xa9, 0x45, 0xec, 0x5f, 0x81, 0xb9, 0xc8, + 0xff, 0x36, 0x0e, 0x0e, 0x01, 0x81, 0x31, 0xae, + 0x4b, 0x35, 0xd8, 0x18, 0x17, 0x8c, 0x33, 0x7a, + 0xa2, 0xee, 0x06, 0x5b, 0xd8, 0x0b, 0x07, 0xb0, + 0x52, 0xbe, 0xf6, 0xf4, 0x38, 0xec, 0x35, 0x6e, + 0x45, 0xc1, 0x5e, 0x51, 0xd3, 0x67, 0x93, 0x6d, + 0xaf, 0xd0, 0xe0, 0x2a, 0xea, 0x6a, 0x1e, 0x03, + 0x0c, 0x38, 0xa4, 0x38, 0xea, 0x34, 0x41, 0x99, + 0xcb, 0xe0, 0xcd, 0xda, 0xf2, 0xee, 0x86, 0x28, + 0x83, 0x38, 0x0b, 0x13, 0xd1, 0x73, 0x1e, 0x4f, + 0xb5, 0x18, 0x7d, 0xef, 0xed, 0x09, 0xdf, 0xf7, + 0x4a, 0x91, 0xdb, 0x41, 0x84, 0xf7, 0x07, 0x14, + 0x15, 0x3b, 0x01, 0xc5, 0x28, 0x41, 0x78, 0x9f, + 0xf6, 0x92, 0xce, 0x06, 0xe0, 0xb9, 0x9d, 0xa0, + 0xee, 0xf0, 0x25, 0xa9, 0xd4, 0xe0, 0x71, 0xb4, + 0x66, 0x0c, 0x11, 0x47, 0x01, 0x89, 0x34, 0x62, + 0x11, 0x60, 0x27, 0xa0, 0xfb, 0x1f, 0xfe, 0xd1, + 0x50, 0x6e, 0x0e, 0x23, 0xc3, 0xd8, 0x0e, 0xe8, + 0x53, 0xa7, 0x94, 0x03, 0x12, 0x41, 0x9a, 0x90, + 0x97, 0xce, 0x87, 0x0d, 0x42, 0x9d, 0x07, 0xce, + 0xff, 0xef, 0x4e, 0x07, 0x1a, 0x31, 0x08, 0x92, + 0x98, 0x0c, 0x49, 0x46, 0x74, 0x22, 0x2a, 0xf1, + 0x01, 0x51, 0x48, 0x26, 0xe9, 0xf5, 0xcd, 0xb0, + 0x0c, 0x2e, 0xa1, 0x3d, 0x29, 0x05, 0x4f, 0xa0, + 0x12, 0x06, 0x08, 0x9c, 0x94, 0x08, 0x60, 0xce, + 0xd0, 0x96, 0x81, 0x81, 0x18, 0x62, 0x03, 0xcc, + 0xba, 0x15, 0xd6, 0x91, 0x11, 0x14, 0x7e, 0xb2, + 0x7e, 0xd4, 0x56, 0x74, 0x37, 0xdc, 0x82, 0xfb, + 0x21, 0xa1, 0x93, 0x91, 0x60, 0x3d, 0xcb, 0x28, + 0x4b, 0x52, 0xe9, 0x26, 0x4a, 0x0c, 0x32, 0xca, + 0x31, 0xab, 0x10, 0x19, 0x6e, 0x76, 0x50, 0x1e, + 0x7c, 0x89, 0x2f, 0x42, 0x4a, 0x46, 0xf8, 0xb1, + 0x5e, 0xdc, 0xbe, 0x81, 0x4a, 0x0c, 0x4e, 0x6a, + 0x31, 0x70, 0xd4, 0x17, 0x62, 0x30, 0xf8, 0xbb, + 0xaa, 0xba, 0x06, 0x98, 0xf4, 0x05, 0x40, 0x7c, + 0x8e, 0x81, 0x22, 0xc7, 0x8b, 0xf2, 0x67, 0x49, + 0x64, 0x58, 0x1c, 0xb8, 0xa0, 0x6d, 0xb9, 0xea, + 0x5b, 0x11, 0x47, 0x18, 0xe7, 0xd0, 0xbc, 0xce, + 0xf3, 0x9d, 0x19, 0x10, 0x92, 0x95, 0x45, 0x47, + 0x78, 0x87, 0x81, 0x32, 0x6b, 0xc0, 0xe5, 0x7a, + 0x79, 0x25, 0x37, 0x0d, 0x05, 0x06, 0x73, 0x39, + 0x50, 0x9f, 0x8f, 0x5d, 0x09, 0x24, 0x34, 0x32, + 0x18, 0x04, 0x62, 0x9c, 0xe8, 0x1e, 0x06, 0x52, + 0x88, 0x1e, 0x26, 0x01, 0x30, 0x36, 0x81, 0x60, + 0x63, 0x41, 0x6a, 0x77, 0xa8, 0x42, 0xd4, 0xba, + 0x1f, 0x0e, 0x79, 0x06, 0x2d, 0x16, 0x83, 0x00, + 0xe3, 0xe6, 0xcb, 0xba, 0x82, 0x4a, 0x27, 0xd7, + 0x5e, 0xdc, 0x58, 0x44, 0x19, 0x28, 0x0c, 0xc7, + 0x2f, 0x57, 0xb2, 0x83, 0x83, 0x40, 0xcc, 0x1c, + 0xb8, 0x99, 0x41, 0xb9, 0xb0, 0xc8, 0x1f, 0x36, + 0x00, 0x75, 0x14, 0xa9, 0x25, 0x34, 0x87, 0x83, + 0x05, 0x13, 0x16, 0x7d, 0x91, 0x40, 0x3b, 0x9c, + 0xe8, 0x38, 0x57, 0x17, 0xd2, 0x03, 0xc0, 0xff, + 0x4e, 0x0c, 0x1f, 0x16, 0x96, 0xc0, 0xe3, 0x8d, + 0x62, 0x75, 0xb8, 0x04, 0xae, 0x03, 0x80, 0x88, + 0xa1, 0x56, 0x31, 0x57, 0x66, 0x2d, 0x8a, 0xef, + 0x11, 0x6f, 0xca, 0xe9, 0x47, 0x79, 0xd0, 0x9d, + 0x0c, 0xb0, 0x18, 0x47, 0x06, 0x03, 0x57, 0x2c, + 0xda, 0x8f, 0x4a, 0x80, 0xd9, 0xa0, 0x62, 0x80, + 0x60, 0x4d, 0x95, 0x18, 0x8c, 0x18, 0x45, 0xcb, + 0x17, 0xad, 0x34, 0xa3, 0xd2, 0xa1, 0xb5, 0xd3, + 0x32, 0xd9, 0xdb, 0xd1, 0x82, 0x98, 0x18, 0x83, + 0xa9, 0xcd, 0xb5, 0x20, 0x77, 0x03, 0x5c, 0x5f, + 0xa6, 0xdb, 0x48, 0x12, 0xd7, 0x46, 0xc8, 0xd1, + 0x78, 0x1c, 0x1d, 0x17, 0x04, 0x91, 0xe8, 0xbc, + 0x2a, 0xa0, 0x53, 0x83, 0x11, 0x29, 0xff, 0x18, + 0xfe, 0x8d, 0x98, 0x6e, 0xad, 0x11, 0x65, 0xa0, + 0xc8, 0x3c, 0x48, 0x48, 0x13, 0x55, 0x28, 0xf5, + 0x61, 0x9d, 0xe0, 0x38, 0x5e, 0x12, 0xc0, 0x70, + 0x44, 0xbf, 0x6f, 0x25, 0x9d, 0x2b, 0xcf, 0xb6, + 0x79, 0x3d, 0xcf, 0x45, 0x32, 0xa8, 0x19, 0x67, + 0x3a, 0x14, 0x43, 0x6d, 0x7d, 0xa1, 0x04, 0xb7, + 0x3e, 0xd3, 0x75, 0x45, 0x2a, 0x6a, 0x6d, 0xb2, + 0x12, 0x87, 0x90, 0xa0, 0x6b, 0xbf, 0x1a, 0x5b, + 0xb7, 0x14, 0xd0, 0x26, 0x88, 0x5e, 0xb8, 0x4d, + 0x70, 0x19, 0x65, 0x36, 0xdd, 0x9c, 0x40, 0x7a, + 0xbf, 0x21, 0xc8, 0x38, 0x38, 0x01, 0xca, 0x1e, + 0xc5, 0xee, 0xb3, 0x40, 0xc0, 0x9a, 0xd6, 0x24, + 0xa7, 0xb4, 0x6b, 0x06, 0x18, 0xfc, 0x1c, 0x11, + 0xaf, 0x6d, 0xcc, 0xbd, 0x5e, 0xc8, 0x8e, 0x07, + 0xbc, 0xe0, 0x52, 0x8f, 0x9a, 0xb1, 0x74, 0x40, + 0xe4, 0x63, 0x20, 0x99, 0x4f, 0xa8, 0xbc, 0x0e, + 0xf2, 0x86, 0x80, 0xea, 0x09, 0x8a, 0xec, 0xdd, + 0xe7, 0x39, 0x49, 0x6e, 0xc4, 0x5c, 0x5d, 0x0d, + 0x45, 0xd1, 0x7b, 0x8b, 0xd5, 0xaf, 0x43, 0x17, + 0xe9, 0x49, 0xac, 0x6d, 0x10, 0xa6, 0x4e, 0x5e, + 0xa8, 0xc8, 0x20, 0xca, 0x54, 0x8e, 0xa1, 0x15, + 0xb5, 0x0d, 0xa0, 0x66, 0x70, 0x93, 0x6f, 0x01, + 0xc4, 0x2b, 0xc1, 0x46, 0xbd, 0x74, 0x96, 0x05, + 0x75, 0x50, 0xc0, 0xc3, 0x8b, 0x22, 0x25, 0x07, + 0x1d, 0xf6, 0x70, 0x92, 0x2d, 0x17, 0x09, 0xcb, + 0xef, 0xbd, 0x88, 0xd6, 0x46, 0x7b, 0xbd, 0xa0, + 0xe7, 0xe9, 0xc7, 0x09, 0x01, 0xc0, 0xb1, 0x29, + 0x3a, 0xc1, 0xdd, 0x05, 0xd2, 0x6a, 0x60, 0x73, + 0x06, 0x54, 0x26, 0x84, 0x0b, 0x22, 0x42, 0x7e, + 0x0d, 0x62, 0xfe, 0xc5, 0xb8, 0x30, 0x3a, 0xa2, + 0x5f, 0x5b, 0xee, 0x6c, 0xc2, 0x50, 0x7a, 0x18, + 0x00, 0xdf, 0x86, 0x41, 0x97, 0x16, 0x3d, 0xd9, + 0xcb, 0x09, 0x46, 0x40, 0xb0, 0x04, 0xe5, 0xa0, + 0xbb, 0xa9, 0x8d, 0x84, 0xa6, 0xd4, 0xb7, 0x53, + 0xb2, 0xdf, 0x33, 0x16, 0x41, 0x38, 0x2f, 0x3c, + 0xa8, 0x21, 0xef, 0x3e, 0xd6, 0xcd, 0x8b, 0xf9, + 0x1f, 0x03, 0x7a, 0x29, 0x18, 0x84, 0x26, 0x7f, + 0xe1, 0xdf, 0x98, 0x1c, 0x36, 0x58, 0xdc, 0x51, + 0xde, 0x2d, 0x35, 0x1f, 0x69, 0xa7, 0x0a, 0x82, + 0x08, 0xe9, 0x59, 0x7f, 0x2b, 0x4a, 0x39, 0x25, + 0x96, 0x5f, 0xf1, 0x08, 0xa6, 0x5b, 0x4b, 0x67, + 0x51, 0x12, 0xf0, 0xf2, 0xae, 0x68, 0xbb, 0x72, + 0xef, 0x0a, 0xb6, 0x02, 0xbd, 0x14, 0x42, 0x37, + 0x1b, 0x80, 0xe2, 0x3a, 0xb7, 0xb4, 0x1c, 0x0a, + 0x9b, 0xa0, 0xea, 0x11, 0x21, 0x4b, 0x07, 0xc9, + 0x93, 0xb7, 0x7b, 0xd1, 0x13, 0x8d, 0x62, 0xfd, + 0x28, 0xbd, 0x44, 0x0e, 0x0f, 0x4e, 0x49, 0xb4, + 0x43, 0x11, 0xc0, 0x38, 0x38, 0x08, 0xd2, 0xd9, + 0x2e, 0x2c, 0x03, 0x9f, 0xa7, 0xd6, 0x37, 0x46, + 0x01, 0x1f, 0x58, 0x56, 0xc0, 0x9c, 0x07, 0x0c, + 0x9d, 0xba, 0x0a, 0x9a, 0x15, 0xd4, 0x63, 0x6a, + 0x13, 0x69, 0xe0, 0x6f, 0x4c, 0xd0, 0x53, 0xc0, + 0xf6, 0x6f, 0x3c, 0xb7, 0x7d, 0xcb, 0x3b, 0x40, + 0x8e, 0xfa, 0x04, 0x48, 0x16, 0x35, 0x8b, 0x7d, + 0xbc, 0x81, 0xaa, 0xb2, 0xe8, 0xbf, 0x7a, 0x0c, + 0x1c, 0xfe, 0x86, 0x26, 0x8e, 0x86, 0x25, 0x83, + 0x9d, 0x07, 0x11, 0xcf, 0xb8, 0x5b, 0x88, 0xe9, + 0x5e, 0x12, 0x21, 0x13, 0xed, 0xb1, 0xfa, 0x0c, + 0x87, 0xf0, 0xa3, 0x96, 0x05, 0x75, 0x33, 0x7a, + 0x3d, 0x1f, 0x09, 0x49, 0x58, 0x56, 0x9d, 0x95, + 0x5e, 0x52, 0x9b, 0x30, 0x3d, 0x64, 0x3d, 0xe4, + 0xde, 0xcb, 0x3c, 0x59, 0x56, 0x0d, 0xd4, 0x94, + 0x43, 0xf6, 0x24, 0xb7, 0x19, 0x1f, 0xa5, 0x6f, + 0xd7, 0xc5, 0x9f, 0x56, 0xde, 0xe7, 0x38, 0x8a, + 0xed, 0x3c, 0x15, 0xc1, 0x9b, 0x6b, 0x55, 0xab, + 0x11, 0xa4, 0xce, 0xef, 0xd2, 0x4c, 0x88, 0x00, + 0xad, 0x15, 0x18, 0xff, 0xb5, 0xad, 0xdf, 0x6f, + 0xa4, 0xdc, 0xbc, 0xab, 0x84, 0x65, 0x30, 0xab, + 0x09, 0x6b, 0xf4, 0xff, 0x43, 0x78, 0x30, 0x08, + 0xa7, 0xa0, 0xa9, 0xa2, 0xf0, 0x8b, 0x72, 0x82, + 0xa0, 0x5c, 0x12, 0xb0, 0x27, 0xe1, 0x84, 0x09, + 0x27, 0x6e, 0x2d, 0x62, 0xc6, 0xd1, 0x85, 0x1a, + 0x72, 0xb1, 0xbf, 0x83, 0xcc, 0x7f, 0xfa, 0x13, + 0x54, 0xe0, 0x71, 0xfa, 0x0e, 0x23, 0x7d, 0x06, + 0x25, 0x18, 0x4a, 0x11, 0x69, 0x43, 0x76, 0xe8, + 0xc8, 0x18, 0x23, 0x96, 0x15, 0x2c, 0x7f, 0x4e, + 0x8b, 0x01, 0x83, 0x6d, 0x18, 0x83, 0x04, 0x5b, + 0x80, 0xa8, 0xc1, 0x9d, 0x01, 0xfa, 0xe2, 0xa3, + 0x8d, 0x4f, 0xe9, 0x63, 0x0d, 0xfe, 0xe7, 0x7b, + 0xcc, 0x5e, 0x86, 0xf5, 0x1b, 0xae, 0x0e, 0x93, + 0xa0, 0x1f, 0x36, 0x33, 0xe8, 0x0e, 0x74, 0xcf, + 0xa0, 0x43, 0x11, 0x82, 0x6d, 0x5a, 0xa8, 0xa6, + 0x1a, 0xcb, 0xa1, 0xb4, 0x99, 0x6a, 0x08, 0x8f, + 0x68, 0x30, 0x2c, 0x5f, 0x51, 0xfd, 0x10, 0x1a, + 0xff, 0xd6, 0xec, 0xe7, 0x7a, 0xc7, 0xaf, 0x49, + 0x16, 0xbb, 0x51, 0x50, 0xad, 0xbf, 0x8b, 0x76, + 0x86, 0x20, 0x9b, 0x11, 0x81, 0xc5, 0x1b, 0x6f, + 0x06, 0xdf, 0xfc, 0x28, 0xda, 0xe9, 0x03, 0x6a, + 0xc1, 0x83, 0x96, 0xc1, 0x86, 0x3a, 0x12, 0xd2, + 0x8a, 0x8c, 0x83, 0x85, 0xd0, 0xa0, 0xf3, 0x2e, + 0x86, 0xee, 0xe1, 0xb7, 0xa1, 0x6d, 0x16, 0x2e, + 0xf4, 0x46, 0xc1, 0x45, 0x99, 0xd2, 0x6d, 0x72, + 0xd2, 0xe6, 0x52, 0x84, 0x07, 0x84, 0xf3, 0xc0, + 0xe0, 0x0e, 0xa2, 0x1f, 0x6c, 0xce, 0xf6, 0x83, + 0xc1, 0xc0, 0x3f, 0x47, 0xb9, 0x68, 0xc8, 0x11, + 0x04, 0x14, 0x40, 0xc3, 0x43, 0x13, 0xa0, 0xf3, + 0xff, 0xff, 0xbe, 0xfe, 0x58, 0xd4, 0x51, 0x7b, + 0x0a, 0x01, 0x62, 0x48, 0xe1, 0x9b, 0x6b, 0x65, + 0x8b, 0x54, 0x41, 0xc8, 0x9d, 0x57, 0x57, 0x64, + 0xf7, 0x51, 0x83, 0x0c, 0x47, 0x25, 0x01, 0xc8, + 0xad, 0x4a, 0x58, 0x4b, 0x05, 0xe0, 0xc0, 0x3d, + 0x10, 0x4e, 0xb5, 0x85, 0xb8, 0xbc, 0xb0, 0x1e, + 0x2a, 0x00, 0xb0, 0x58, 0xbd, 0x5e, 0xca, 0x4a, + 0x0c, 0x2e, 0x19, 0x82, 0xe5, 0x3e, 0x8b, 0xa0, + 0xe0, 0xc8, 0x8a, 0xae, 0xe7, 0xbe, 0x55, 0xbc, + 0x45, 0x4a, 0x60, 0x60, 0x09, 0xcb, 0x89, 0x4c, + 0x32, 0x08, 0x6d, 0x09, 0x0d, 0xb4, 0xd2, 0x54, + 0xf8, 0xa8, 0xab, 0xca, 0x6f, 0xc4, 0xbf, 0x00, + 0xe6, 0xb6, 0x8c, 0x4f, 0xc6, 0x16, 0xf7, 0x67, + 0x1a, 0x9b, 0x2a, 0x1c, 0xe0, 0x0e, 0x44, 0x80, + 0x80, 0x34, 0xb2, 0x9d, 0x59, 0x58, 0x17, 0xd1, + 0x87, 0x81, 0x60, 0x2c, 0xf8, 0x0a, 0xad, 0x69, + 0x49, 0x5d, 0x40, 0x43, 0x1b, 0x4e, 0x83, 0x7c, + 0x48, 0x88, 0x92, 0x09, 0x3f, 0x05, 0x78, 0xf6, + 0xc0, 0x60, 0xc9, 0xea, 0xd0, 0x66, 0xd3, 0x20, + 0x08, 0x5b, 0xa0, 0xaf, 0x1d, 0xb3, 0xa1, 0x35, + 0x2e, 0x1c, 0xc8, 0x33, 0x09, 0x1a, 0x34, 0x6d, + 0x83, 0x06, 0x61, 0x21, 0x5a, 0x99, 0x57, 0xd1, + 0xcc, 0xa2, 0x96, 0xed, 0x05, 0xc3, 0x61, 0x84, + 0x1e, 0x07, 0xfc, 0x3e, 0x55, 0x2d, 0x01, 0xe4, + 0x92, 0xc4, 0x56, 0xd6, 0xff, 0xc0, 0xa0, 0x6a, + 0x23, 0x89, 0x29, 0xc4, 0x76, 0x43, 0xf6, 0x7c, + 0xd6, 0x55, 0x0a, 0x0a, 0xb1, 0x00, 0x13, 0xaf, + 0xa2, 0xa0, 0xe4, 0x5c, 0x11, 0xb2, 0xa2, 0x51, + 0x80, 0x46, 0x98, 0xc3, 0x1e, 0x1b, 0x35, 0xc2, + 0x5c, 0xb5, 0xf4, 0xfb, 0xf2, 0x1c, 0x83, 0x83, + 0x80, 0x7c, 0xf8, 0x01, 0xfd, 0x9a, 0x85, 0x49, + 0x69, 0xc7, 0xd8, 0x1a, 0xc3, 0x0f, 0xa3, 0x27, + 0xb5, 0xa6, 0xc5, 0xdb, 0x3a, 0x15, 0x6e, 0x5e, + 0xdb, 0x93, 0x60, 0x8b, 0x28, 0x31, 0x48, 0xc0, + 0x35, 0x09, 0x3b, 0x5f, 0x28, 0x18, 0x54, 0x01, + 0x80, 0x66, 0x8c, 0x8e, 0x7e, 0xd6, 0xaa, 0x8d, + 0xa9, 0x9c, 0xa6, 0xe3, 0x10, 0xb6, 0x8c, 0x16, + 0xd0, 0x97, 0x4f, 0x78, 0x15, 0x21, 0x88, 0xb8, + 0x85, 0xb9, 0x01, 0xd1, 0x67, 0x69, 0xfd, 0xbe, + 0xe4, 0x52, 0xd6, 0xc4, 0x6a, 0x24, 0x07, 0x54, + 0x28, 0x08, 0xa6, 0x6f, 0x94, 0x03, 0x22, 0xf8, + 0x67, 0x46, 0x20, 0x9a, 0x4c, 0x93, 0x90, 0x1c, + 0x09, 0x90, 0x32, 0x46, 0x32, 0x0a, 0x2d, 0xe8, + 0x27, 0xc5, 0xdc, 0xf6, 0xc9, 0xde, 0x4e, 0x1a, + 0x45, 0x02, 0x5b, 0xab, 0xeb, 0x4a, 0x2f, 0x4d, + 0x95, 0x29, 0xe8, 0x0f, 0x04, 0xcc, 0xb8, 0xbc, + 0x6b, 0x32, 0x06, 0x08, 0x0d, 0xc0, 0x5f, 0xdb, + 0x24, 0x46, 0xb1, 0xbe, 0x85, 0x5a, 0xeb, 0x4a, + 0xa0, 0x40, 0x42, 0x48, 0x59, 0x37, 0xbd, 0x18, + 0x82, 0x72, 0x63, 0xfd, 0xa5, 0x12, 0x83, 0x90, + 0x85, 0x1e, 0xd5, 0x83, 0x35, 0xe0, 0xb9, 0x02, + 0xc7, 0xcd, 0x88, 0x23, 0x86, 0xe7, 0xc7, 0x12, + 0x4b, 0xcd, 0x1c, 0x59, 0x51, 0x29, 0x0c, 0x3b, + 0xc9, 0xd0, 0x4d, 0xf9, 0x6a, 0x33, 0xba, 0xef, + 0x2e, 0xe5, 0xd8, 0x69, 0x1a, 0x14, 0x44, 0x29, + 0xe6, 0xcb, 0xee, 0x7f, 0xd6, 0x9b, 0x25, 0x0c, + 0x51, 0x05, 0x48, 0xe4, 0xf9, 0x6a, 0xfd, 0xc9, + 0x9d, 0x8b, 0xd9, 0xd1, 0x3a, 0x14, 0x7d, 0xa9, + 0x38, 0x5a, 0x55, 0xd4, 0x57, 0x7f, 0xfb, 0x62, + 0x11, 0x80, 0x30, 0x61, 0x1d, 0x6a, 0x00, 0x92, + 0x2e, 0x9a, 0x7b, 0x82, 0x4a, 0x75, 0x77, 0x3b, + 0x61, 0xb6, 0xbe, 0x36, 0xa1, 0x87, 0x67, 0x46, + 0x0f, 0x30, 0xaf, 0x70, 0xbd, 0x8d, 0xc8, 0x31, + 0x53, 0x37, 0xc0, 0xc1, 0x8c, 0x15, 0x1d, 0x4d, + 0x38, 0xb5, 0x5c, 0x1c, 0x0b, 0xc1, 0x53, 0x17, + 0xe0, 0x75, 0xb6, 0x68, 0x19, 0x9d, 0x2b, 0xf4, + 0xe2, 0x09, 0x41, 0x30, 0xbe, 0xd0, 0xf7, 0xb2, + 0x2c, 0x69, 0xd1, 0x33, 0x83, 0xa6, 0x59, 0x66, + 0x17, 0xcb, 0x59, 0x6c, 0x18, 0x0c, 0x27, 0x1b, + 0xfe, 0xd4, 0x72, 0xac, 0x75, 0x25, 0x65, 0xca, + 0xfa, 0x0c, 0x05, 0xac, 0x29, 0x06, 0x04, 0xe1, + 0x78, 0xe8, 0x79, 0x4a, 0xf2, 0xa9, 0xe6, 0xfb, + 0xf1, 0x0e, 0x7e, 0xcd, 0x95, 0x6c, 0xed, 0x5a, + 0x9a, 0xa6, 0xc5, 0x01, 0x4d, 0x38, 0x36, 0x24, + 0x6b, 0xac, 0xe8, 0xf0, 0x77, 0xb9, 0xe9, 0x6f, + 0x55, 0x8f, 0x52, 0x48, 0xb2, 0xeb, 0xe6, 0x29, + 0xb7, 0xa6, 0xa5, 0x71, 0xbe, 0x57, 0x9e, 0xd0, + 0xda, 0xa1, 0xe5, 0x08, 0xaa, 0x65, 0xc1, 0x13, + 0xe8, 0x43, 0xef, 0x06, 0xac, 0xf8, 0x1f, 0x37, + 0xff, 0xb7, 0x53, 0x7e, 0x65, 0xd9, 0xf4, 0xdf, + 0x99, 0xc5, 0x25, 0x9b, 0x9b, 0x5c, 0x71, 0x90, + 0x6c, 0x49, 0xbe, 0x55, 0xff, 0x69, 0x70, 0xfa, + 0xff, 0xca, 0x7f, 0xe4, 0xe2, 0x4c, 0x42, 0x84, + 0x3a, 0x7d, 0xb0, 0x07, 0x07, 0x8c, 0x29, 0x80, + 0xc5, 0xa3, 0xc6, 0xee, 0xe1, 0x66, 0xe3, 0x1f, + 0xdf, 0xd5, 0x15, 0x08, 0x89, 0x16, 0x3c, 0x30, + 0x39, 0xcf, 0xaf, 0x35, 0x10, 0x2a, 0x38, 0x19, + 0xbe, 0x26, 0xb8, 0x13, 0x83, 0x00, 0x1c, 0xe4, + 0xda, 0xc5, 0x2b, 0xcf, 0xd2, 0xad, 0xc2, 0xa9, + 0x37, 0xb7, 0xb5, 0x01, 0x41, 0x0d, 0x40, 0x38, + 0x01, 0x9d, 0xe5, 0x12, 0x7f, 0xb4, 0x38, 0x54, + 0x5c, 0xdb, 0x7c, 0x02, 0x73, 0x7e, 0x2c, 0x17, + 0x2a, 0x1e, 0x09, 0x0a, 0xb3, 0x7c, 0x5d, 0x07, + 0xbb, 0xf5, 0xfb, 0xff, 0xa6, 0x9e, 0xef, 0x29, + 0xb5, 0x0b, 0x70, 0x6a, 0xa0, 0x6d, 0x01, 0x67, + 0xe9, 0x2d, 0x98, 0x72, 0xa6, 0x44, 0x47, 0x12, + 0xa2, 0x58, 0x25, 0x2b, 0xdc, 0x67, 0x71, 0xa5, + 0x57, 0x0b, 0x15, 0x65, 0xba, 0xa6, 0x07, 0xb3, + 0xb6, 0x22, 0x35, 0xde, 0x13, 0x09, 0xda, 0x08, + 0x0d, 0xb3, 0xad, 0x83, 0xc1, 0x40, 0x42, 0x3b, + 0xb7, 0x22, 0x90, 0xf5, 0xbe, 0x5d, 0xea, 0xcb, + 0x01, 0x88, 0xa5, 0x72, 0x60, 0xbe, 0x23, 0x64, + 0x6d, 0x57, 0xbb, 0x10, 0x7f, 0x94, 0x41, 0xac, + 0x73, 0x84, 0xb1, 0x75, 0xc1, 0x38, 0xeb, 0x25, + 0xbe, 0x6e, 0xf4, 0xb9, 0x8f, 0xa9, 0xd5, 0x84, + 0x14, 0xad, 0xfe, 0xc3, 0x48, 0x11, 0x52, 0x99, + 0x3a, 0x4e, 0x70, 0xe7, 0x65, 0x5a, 0x29, 0x85, + 0x2a, 0x02, 0x68, 0x99, 0xaf, 0xaa, 0xfa, 0xad, + 0x2c, 0xd1, 0x09, 0x46, 0xc4, 0x0d, 0xfd, 0xba, + 0x0c, 0x18, 0x98, 0x6d, 0x97, 0x5a, 0xd3, 0x0d, + 0xf9, 0x57, 0xbd, 0x75, 0x4e, 0x7f, 0x3b, 0xd5, + 0xf2, 0xa3, 0x9d, 0xde, 0xaf, 0x10, 0x13, 0x97, + 0xd5, 0x1c, 0xdb, 0xa3, 0xa2, 0xe9, 0x50, 0x7d, + 0x44, 0xdd, 0xe4, 0x0d, 0xea, 0x08, 0x27, 0x33, + 0x41, 0xba, 0xd5, 0xda, 0xc4, 0x2c, 0xec, 0xe7, + 0x66, 0x35, 0xc9, 0x3b, 0xd9, 0x27, 0x73, 0x83, + 0x17, 0x0d, 0x08, 0x3d, 0x35, 0x34, 0xa6, 0x9e, + 0xd7, 0xea, 0x84, 0xb2, 0xcf, 0x87, 0x95, 0x94, + 0xd5, 0x8b, 0x2e, 0x11, 0x89, 0x02, 0x06, 0x25, + 0x6a, 0x46, 0xd5, 0xe5, 0xa5, 0xb9, 0x54, 0x67, + 0x22, 0x9d, 0x2b, 0x92, 0xa0, 0x3c, 0x5e, 0xc5, + 0x78, 0x38, 0xac, 0xc2, 0xff, 0xe1, 0x57, 0xbc, + 0xb2, 0xd5, 0x48, 0xc7, 0x85, 0x10, 0x81, 0x54, + 0x89, 0x3d, 0xbb, 0xdc, 0xb8, 0xd8, 0xf5, 0x9c, + 0x8c, 0xa7, 0xe9, 0x46, 0x45, 0xd7, 0x40, 0x88, + 0x8c, 0xdc, 0x56, 0xdc, 0x46, 0xa3, 0x06, 0xfc, + 0xce, 0x91, 0x69, 0x8a, 0x55, 0x02, 0x8b, 0x72, + 0xe7, 0xdb, 0x1f, 0xa5, 0x2b, 0x06, 0x40, 0x55, + 0x31, 0x45, 0x9d, 0x40, 0xdd, 0x90, 0x54, 0x9a, + 0x70, 0x64, 0x89, 0x15, 0xc9, 0xbe, 0x4f, 0xb3, + 0x6d, 0xe5, 0x1c, 0xab, 0xc2, 0xc8, 0x30, 0x94, + 0xea, 0x5e, 0x54, 0xab, 0x14, 0x7b, 0xfe, 0xce, + 0x9b, 0xe6, 0xae, 0x50, 0xa6, 0xe9, 0x18, 0xb6, + 0xb1, 0x95, 0x44, 0x53, 0xcf, 0x7b, 0x96, 0x7b, + 0x98, 0x59, 0x43, 0x8e, 0x95, 0x0c, 0x21, 0x3b, + 0x95, 0xc2, 0xb5, 0xe1, 0x42, 0x80, 0xc0, 0xf6, + 0x99, 0xa4, 0xe0, 0x19, 0x83, 0xe1, 0x29, 0x28, + 0xf3, 0xd4, 0x72, 0xdb, 0x77, 0xd4, 0x3c, 0xaa, + 0x70, 0x3c, 0x45, 0xbd, 0x1b, 0x76, 0xf4, 0x80, + 0x30, 0x60, 0x34, 0x12, 0x6f, 0xe2, 0x84, 0x96, + 0xaf, 0x36, 0x29, 0xfb, 0x52, 0x73, 0xa8, 0xff, + 0x2d, 0xe9, 0xe3, 0x3f, 0xf4, 0xa8, 0xb2, 0xf7, + 0x4d, 0x15, 0x45, 0x83, 0x9b, 0x38, 0x33, 0x8b, + 0x8a, 0xf0, 0x80, 0xd4, 0x5e, 0x79, 0x7e, 0xf2, + 0xd1, 0xb8, 0xbe, 0x2f, 0xb2, 0x94, 0x9e, 0x24, + 0x73, 0xfe, 0x02, 0x63, 0x26, 0x79, 0xa4, 0xdd, + 0x4a, 0xda, 0x4a, 0xb5, 0xbb, 0x7c, 0x55, 0xdb, + 0xee, 0xca, 0x1b, 0x4b, 0xd9, 0xd8, 0x02, 0x0e, + 0xfd, 0xaa, 0xd7, 0xee, 0x6c, 0xb3, 0x86, 0xfb, + 0x28, 0x56, 0x0c, 0x1a, 0xab, 0xf8, 0x24, 0xb3, + 0xf5, 0x51, 0x46, 0xc6, 0x5b, 0xbd, 0x5a, 0xc9, + 0x26, 0xd9, 0xb5, 0x75, 0xb9, 0xc3, 0x7c, 0x3c, + 0x48, 0x43, 0x08, 0x5a, 0x3f, 0x6f, 0x4b, 0xfb, + 0x41, 0x86, 0xc5, 0xad, 0xf1, 0x78, 0xa7, 0x24, + 0xce, 0x45, 0xe8, 0xa4, 0x5e, 0x33, 0xcb, 0x3b, + 0x39, 0xd4, 0x67, 0x55, 0x72, 0x63, 0xc2, 0xd6, + 0x1b, 0x45, 0x29, 0xbb, 0xd8, 0x81, 0x00, 0xcc, + 0x63, 0xd3, 0xc5, 0x12, 0x73, 0xfe, 0xf6, 0xde, + 0x6e, 0x41, 0x89, 0x5f, 0xaf, 0x65, 0x5a, 0x9b, + 0x21, 0x59, 0x5c, 0xc1, 0x0b, 0xc5, 0x7a, 0xbe, + 0x28, 0xdf, 0x40, 0xf6, 0x2c, 0x8a, 0xc2, 0xa5, + 0x2b, 0x74, 0xf9, 0x3d, 0x63, 0x13, 0xd8, 0x98, + 0x71, 0x6f, 0x73, 0xb6, 0x88, 0x0d, 0xb3, 0x66, + 0x5a, 0x56, 0x22, 0x77, 0x9b, 0x88, 0x08, 0x64, + 0x2d, 0xff, 0x50, 0x42, 0x0d, 0x35, 0x47, 0x1b, + 0x93, 0x2d, 0x42, 0x88, 0x50, 0x2f, 0x06, 0xcf, + 0x29, 0x4a, 0x3e, 0xa5, 0x5d, 0xc4, 0xea, 0xbb, + 0x03, 0xde, 0xf0, 0x73, 0x2f, 0x51, 0xa8, 0x13, + 0x11, 0x64, 0x03, 0x14, 0xfb, 0xb3, 0xe1, 0xe2, + 0x65, 0x18, 0xcd, 0xd9, 0x51, 0x72, 0xf3, 0x72, + 0xd1, 0x12, 0xa3, 0x42, 0x8c, 0x4d, 0x00, 0x79, + 0x9f, 0x36, 0x24, 0x8e, 0x95, 0x2a, 0xcc, 0x06, + 0x02, 0xea, 0xad, 0x2b, 0xaa, 0x43, 0xcf, 0xe5, + 0xd3, 0x4b, 0x2c, 0x4a, 0x34, 0x76, 0xdb, 0x9b, + 0x97, 0x80, 0xe1, 0x56, 0xba, 0x6d, 0xe5, 0xf7, + 0x40, 0x70, 0x3a, 0x05, 0x91, 0xca, 0x8f, 0x9b, + 0xc1, 0x88, 0x2c, 0x0f, 0x0b, 0xb2, 0x50, 0x42, + 0x06, 0x2d, 0xbb, 0x98, 0x4b, 0xc6, 0x22, 0x90, + 0x78, 0xcf, 0xfd, 0xe6, 0x50, 0x60, 0x9d, 0x16, + 0xda, 0xd1, 0xd2, 0x6f, 0xb3, 0xf9, 0x21, 0xab, + 0x38, 0xc2, 0x30, 0xd4, 0xb7, 0xea, 0x1d, 0xfa, + 0xf6, 0xe7, 0x01, 0xc1, 0xde, 0xc0, 0xb3, 0x4f, + 0x03, 0x0f, 0xe7, 0x40, 0x39, 0x3a, 0x3a, 0xbb, + 0x08, 0x81, 0x5f, 0x10, 0x10, 0x94, 0x4c, 0x5d, + 0x3f, 0x9f, 0xd0, 0x34, 0x9d, 0x3e, 0xad, 0x31, + 0x8f, 0x66, 0xf6, 0xf4, 0x45, 0x2a, 0x9b, 0x78, + 0xe2, 0x02, 0x3f, 0xbc, 0x3f, 0x2e, 0xfb, 0x01, + 0xf8, 0x1a, 0x9b, 0xc0, 0xf6, 0xe5, 0xb5, 0x65, + 0xf8, 0xa2, 0xce, 0x3c, 0x23, 0xb4, 0x25, 0x17, + 0x2a, 0xb5, 0xa0, 0x60, 0xfd, 0x5f, 0x2f, 0xa5, + 0x0f, 0xd5, 0x28, 0x6b, 0xf6, 0xf4, 0x3a, 0xe4, + 0xf2, 0x28, 0x8c, 0xd8, 0xac, 0xe4, 0xdf, 0x51, + 0x0b, 0x14, 0x6a, 0x32, 0x5e, 0x0b, 0x9d, 0x5f, + 0xf8, 0x9d, 0x27, 0xfd, 0x36, 0xfb, 0xfa, 0x59, + 0xe0, 0x33, 0xce, 0xf1, 0x63, 0xb6, 0xd9, 0x6f, + 0x41, 0xe1, 0x20, 0x15, 0xba, 0x5e, 0x42, 0x57, + 0xed, 0x09, 0x1a, 0x59, 0xed, 0x1e, 0x8f, 0x4b, + 0xea, 0x56, 0x94, 0x6f, 0x33, 0xba, 0x2f, 0x14, + 0x74, 0x9e, 0x08, 0x51, 0x08, 0x8d, 0xbf, 0xf3, + 0x7d, 0x57, 0x2a, 0xf1, 0x01, 0xf2, 0x59, 0xd2, + 0xd9, 0xce, 0xe4, 0x97, 0xa4, 0xf8, 0x3f, 0x9c, + 0x00, 0x6b, 0xa3, 0x1a, 0xfe, 0x82, 0x26, 0xd6, + 0x26, 0x67, 0xb6, 0xf2, 0xab, 0xad, 0x7c, 0x3d, + 0x9c, 0x06, 0x34, 0xa3, 0x61, 0x55, 0x29, 0x42, + 0xe3, 0xac, 0xea, 0x52, 0x4a, 0xc6, 0x1c, 0x32, + 0x21, 0xa5, 0x69, 0xbf, 0x7f, 0x1a, 0xc6, 0x04, + 0xaa, 0x92, 0x0e, 0x54, 0x79, 0xac, 0xa5, 0xbb, + 0xe4, 0x32, 0xc5, 0x2a, 0x38, 0x69, 0x67, 0x91, + 0x57, 0xf1, 0xfa, 0xa0, 0xe9, 0xa5, 0x43, 0xea, + 0x9e, 0x6c, 0xe4, 0x1b, 0x72, 0xef, 0x1c, 0x5a, + 0xac, 0xcc, 0xf7, 0xae, 0x41, 0xcc, 0xa6, 0xcf, + 0xaa, 0xe5, 0xd5, 0x77, 0xc1, 0xdc, 0x6e, 0x7f, + 0xb9, 0xad, 0x62, 0xe5, 0x56, 0xf0, 0xd3, 0xca, + 0x35, 0x1a, 0x55, 0x3f, 0xa0, 0xc1, 0xef, 0x9b, + 0x6a, 0x59, 0xba, 0x59, 0x35, 0x6f, 0x72, 0xd3, + 0x48, 0x86, 0xa5, 0x41, 0x4e, 0x25, 0xa3, 0x06, + 0x0f, 0x55, 0xa6, 0x9b, 0xb3, 0x26, 0x03, 0x8e, + 0x2d, 0xe6, 0x75, 0x3b, 0x38, 0xd4, 0xe7, 0xfe, + 0xa3, 0xdd, 0xe5, 0xd9, 0x2a, 0x20, 0x71, 0x29, + 0x39, 0xec, 0xab, 0xdc, 0xda, 0xa5, 0x47, 0xae, + 0x59, 0x05, 0xb5, 0x71, 0x2b, 0x0a, 0x84, 0x25, + 0x51, 0x9f, 0xa9, 0x6d, 0x2f, 0x9b, 0x8a, 0x1b, + 0x4f, 0xc9, 0xfd, 0xe6, 0x4e, 0x74, 0x3b, 0x5c, + 0x8b, 0xf3, 0x6e, 0x4a, 0x18, 0xc0, 0x74, 0x3f, + 0x72, 0xee, 0x48, 0xa7, 0x75, 0xb6, 0x7f, 0x6a, + 0x2e, 0x49, 0x6a, 0xd3, 0xa1, 0x40, 0xd4, 0x47, + 0xd8, 0xce, 0x59, 0x2c, 0x43, 0xc5, 0xe5, 0x5d, + 0xfa, 0x66, 0x3f, 0xfa, 0x86, 0xf5, 0x7c, 0x3d, + 0x17, 0x32, 0xa2, 0x0f, 0xf1, 0xa5, 0x3d, 0xb4, + 0x11, 0xf8, 0x6c, 0x96, 0x22, 0x18, 0xb9, 0xe9, + 0x56, 0xee, 0x15, 0x28, 0x44, 0x84, 0x91, 0x11, + 0x09, 0xab, 0x75, 0xb6, 0x3d, 0xd9, 0x38, 0xb9, + 0x6a, 0x10, 0x1c, 0x35, 0x19, 0xb3, 0x89, 0xd9, + 0x95, 0x16, 0xfa, 0x92, 0x2f, 0x45, 0xdc, 0x3f, + 0x25, 0x2c, 0xd0, 0x74, 0xd0, 0xc8, 0xf6, 0x9a, + 0x31, 0x3f, 0xb8, 0x5a, 0x80, 0xd2, 0xc8, 0x39, + 0x10, 0x04, 0xb1, 0x12, 0xf9, 0x19, 0x5a, 0xe6, + 0xa0, 0xd1, 0x7d, 0x00, 0xdd, 0xed, 0x2b, 0x49, + 0xa0, 0x48, 0x07, 0x3c, 0x69, 0x00, 0x34, 0x43, + 0x5e, 0xc6, 0xf1, 0xa4, 0x12, 0x73, 0x06, 0xc8, + 0x0e, 0x97, 0x18, 0xdb, 0xd5, 0x82, 0xbd, 0x78, + 0xf2, 0x3f, 0x5e, 0xa1, 0x5f, 0x88, 0x88, 0x92, + 0xfe, 0x5f, 0x5b, 0xe9, 0xda, 0x04, 0xe5, 0x04, + 0xc2, 0x23, 0xf6, 0x95, 0x49, 0x92, 0x40, 0xfd, + 0x58, 0x31, 0xbd, 0xc8, 0x83, 0xd2, 0xd4, 0x76, + 0x21, 0x0a, 0x82, 0x40, 0xf0, 0x21, 0x26, 0x69, + 0x40, 0x19, 0x12, 0xcb, 0x95, 0x37, 0xd1, 0xc6, + 0x82, 0xbb, 0x56, 0xab, 0x8d, 0x86, 0xcf, 0xb2, + 0x83, 0xba, 0x43, 0x53, 0xa6, 0x95, 0x7e, 0x52, + 0xb6, 0x6e, 0xac, 0x8a, 0xa1, 0x29, 0x38, 0x58, + 0x77, 0xbe, 0xf2, 0x46, 0x77, 0x65, 0x2c, 0xc8, + 0xa6, 0xac, 0xba, 0x88, 0x8e, 0xc3, 0x74, 0x5c, + 0x41, 0x70, 0x20, 0x8f, 0xf6, 0x16, 0x87, 0xc3, + 0xa4, 0xc6, 0xe1, 0x78, 0x97, 0xef, 0x51, 0x87, + 0x17, 0xea, 0xc8, 0xe9, 0xc5, 0x04, 0x31, 0xe9, + 0x68, 0x84, 0xde, 0x26, 0x56, 0x3a, 0xf8, 0xfc, + 0xb3, 0x8a, 0x12, 0x33, 0xe6, 0x57, 0x43, 0x32, + 0x6f, 0xd1, 0x0d, 0x6a, 0x8d, 0x83, 0x7e, 0x70, + 0x1c, 0x7a, 0x26, 0xbe, 0x02, 0x94, 0x03, 0x98, + 0x6e, 0x6b, 0x0c, 0x0e, 0xdb, 0xdc, 0x44, 0x55, + 0x80, 0xc0, 0x3c, 0x26, 0x33, 0xf0, 0x41, 0xd6, + 0xdb, 0x97, 0xc3, 0xa5, 0x77, 0xd7, 0x26, 0xf7, + 0x6e, 0x79, 0x47, 0x67, 0x78, 0xbe, 0x55, 0xc5, + 0x41, 0x9d, 0x5a, 0xb0, 0x65, 0x6a, 0x0a, 0xd2, + 0x0f, 0xfd, 0xe0, 0xe7, 0xc3, 0xa5, 0x00, 0xf1, + 0x5f, 0xfb, 0xb4, 0xc0, 0x30, 0x4e, 0x3d, 0x6d, + 0x94, 0xb6, 0x83, 0x2f, 0xf6, 0xed, 0x06, 0x25, + 0xbb, 0xd0, 0x60, 0xaf, 0xea, 0x64, 0x2b, 0x86, + 0x9b, 0x68, 0x66, 0x79, 0x91, 0x8f, 0x7c, 0x10, + 0xd5, 0x8e, 0x73, 0xaa, 0x8b, 0x95, 0x67, 0x54, + 0x52, 0xd1, 0xeb, 0x5d, 0x9e, 0x42, 0x22, 0xf9, + 0x73, 0xd0, 0x3d, 0x11, 0xc1, 0x09, 0xa1, 0x15, + 0x33, 0x7f, 0x99, 0x54, 0x28, 0xdf, 0xb7, 0xcb, + 0x50, 0x8d, 0xff, 0x0f, 0xad, 0xd7, 0xf3, 0x37, + 0xed, 0x20, 0xf6, 0x82, 0x3a, 0x80, 0xc8, 0xfe, + 0x91, 0x1a, 0x0d, 0xa0, 0xa0, 0xc9, 0x20, 0x2a, + 0xa3, 0x76, 0x64, 0x9d, 0x04, 0x4f, 0x5e, 0x83, + 0x0c, 0x78, 0xf1, 0x82, 0x70, 0x66, 0x47, 0xd6, + 0x71, 0x50, 0x8d, 0x06, 0x31, 0x89, 0xd4, 0x05, + 0x4d, 0x4b, 0xde, 0x03, 0x0a, 0x59, 0x46, 0x04, + 0x81, 0x2d, 0x38, 0x30, 0xd8, 0x74, 0x3f, 0x64, + 0x18, 0xa1, 0x33, 0x3f, 0x83, 0x1c, 0xc7, 0x8f, + 0xd6, 0xf8, 0x49, 0x09, 0x7f, 0xfa, 0x19, 0x99, + 0xd7, 0x30, 0xd8, 0x41, 0x4a, 0xc2, 0x6e, 0x35, + 0x3d, 0xac, 0xfe, 0xd2, 0xa6, 0xa1, 0xbb, 0x33, + 0x3c, 0xe3, 0x7c, 0xc0, 0x60, 0x3f, 0x3c, 0xdc, + 0x5a, 0x02, 0xa5, 0x26, 0x37, 0x94, 0x11, 0xbb, + 0xf6, 0xb4, 0x91, 0x1c, 0xc8, 0xe1, 0x60, 0x28, + 0x04, 0x36, 0x15, 0x2b, 0x0f, 0x23, 0x05, 0xe5, + 0xcc, 0xe3, 0x6c, 0x36, 0x15, 0x98, 0xbf, 0x07, + 0x81, 0x81, 0xcd, 0xb0, 0x51, 0xe8, 0x3c, 0x6c, + 0x01, 0x63, 0xcf, 0xc1, 0x88, 0x7f, 0x75, 0xa1, + 0x70, 0xe3, 0xe6, 0x4c, 0xb1, 0x4d, 0xaa, 0x4b, + 0x1a, 0x6b, 0x39, 0x02, 0x9d, 0x31, 0xe8, 0x8c, + 0x08, 0x21, 0x09, 0x9c, 0xf7, 0x9b, 0x1e, 0xb4, + 0xab, 0x85, 0xb7, 0xf1, 0x9c, 0xe7, 0x50, 0xe4, + 0xee, 0xf2, 0x0c, 0x00, 0x58, 0xb9, 0xa4, 0xf1, + 0xbf, 0xcd, 0x62, 0x2a, 0xf8, 0xe6, 0x8e, 0x65, + 0x94, 0xb5, 0x4e, 0xcb, 0xcc, 0x2c, 0x34, 0x6c, + 0x44, 0x88, 0x09, 0xd4, 0x68, 0x1e, 0x02, 0x08, + 0x32, 0xfe, 0x75, 0x58, 0x43, 0x63, 0xc4, 0x9e, + 0x4d, 0xbf, 0x17, 0xeb, 0x6c, 0x0c, 0x78, 0x78, + 0xd2, 0x40, 0x60, 0x0e, 0x2e, 0x4d, 0xfb, 0xa0, + 0xc1, 0xf8, 0xee, 0x56, 0x8a, 0xee, 0xaa, 0x6f, + 0xc9, 0x29, 0x4e, 0x07, 0x8d, 0xac, 0x1b, 0x96, + 0x9c, 0x2b, 0x13, 0xe7, 0x78, 0xba, 0xe8, 0x79, + 0xb6, 0x40, 0x71, 0xdd, 0x34, 0x1b, 0x4c, 0x9e, + 0x5e, 0xa9, 0x53, 0xba, 0xba, 0xc1, 0xd4, 0x81, + 0xc0, 0x15, 0x51, 0x50, 0xed, 0xbc, 0xef, 0x24, + 0x3c, 0x2b, 0xba, 0x39, 0x2a, 0xef, 0x27, 0xa7, + 0x2f, 0x27, 0x7b, 0x62, 0x3a, 0x6d, 0x70, 0xdf, + 0x86, 0xcf, 0x16, 0xf0, 0x18, 0x63, 0xf8, 0xd6, + 0x37, 0xb6, 0x4b, 0x23, 0x6a, 0xdb, 0x6d, 0xbb, + 0x7f, 0x9c, 0x5b, 0x79, 0x24, 0xe5, 0xe9, 0xae, + 0x22, 0xa7, 0x6c, 0x3e, 0x4b, 0x36, 0x58, 0xa3, + 0xd8, 0xcb, 0x15, 0x49, 0x6e, 0xef, 0x3b, 0x11, + 0xac, 0xb4, 0xd5, 0x8d, 0xd0, 0xa5, 0x56, 0x0e, + 0x65, 0x07, 0x13, 0x54, 0xff, 0xb3, 0x7f, 0x3e, + 0xa2, 0xee, 0xf0, 0xac, 0xd0, 0xc9, 0x79, 0x87, + 0xd5, 0x52, 0xa5, 0x49, 0x65, 0x44, 0x55, 0xaa, + 0x2c, 0x96, 0x1b, 0xe9, 0x36, 0x1f, 0x5c, 0x54, + 0xdb, 0x7e, 0x6e, 0x8e, 0x7f, 0x99, 0xd9, 0x24, + 0x51, 0x67, 0xaf, 0x64, 0x2a, 0xbc, 0xbc, 0xff, + 0x16, 0xe4, 0x40, 0x42, 0x4f, 0x5a, 0x92, 0x29, + 0x69, 0x15, 0x6f, 0xbb, 0x16, 0xe1, 0xbb, 0xd5, + 0x39, 0x38, 0xa0, 0x97, 0xa2, 0x65, 0x15, 0xe9, + 0xa6, 0x59, 0xec, 0x92, 0xed, 0xd5, 0x1b, 0x79, + 0x2d, 0x51, 0x2f, 0x56, 0x37, 0xbd, 0x24, 0x36, + 0x52, 0x43, 0x76, 0x28, 0xeb, 0x6a, 0x24, 0x6f, + 0x79, 0xd0, 0xe4, 0xaa, 0xf3, 0x27, 0x6a, 0xc8, + 0x91, 0xa2, 0xa6, 0x8e, 0xab, 0x92, 0xb3, 0xed, + 0xd0, 0xef, 0x11, 0xb4, 0xa0, 0xab, 0x60, 0xcb, + 0x3a, 0x52, 0xbd, 0x1a, 0xae, 0xc8, 0xe7, 0x56, + 0x9c, 0x53, 0x85, 0x8a, 0x77, 0x57, 0xcd, 0xa2, + 0xe5, 0xe1, 0xb3, 0x67, 0xa0, 0x9f, 0x4c, 0xbc, + 0xda, 0x39, 0xc2, 0xb9, 0x27, 0x11, 0xc3, 0x7a, + 0xb7, 0x17, 0xec, 0x1a, 0xc7, 0xf7, 0x3c, 0xd4, + 0xdf, 0xe6, 0x95, 0xf3, 0x25, 0x37, 0xb5, 0x04, + 0x50, 0xb7, 0x45, 0xc2, 0x72, 0x49, 0xb9, 0xbe, + 0xb3, 0xeb, 0x6e, 0x64, 0x8a, 0x6d, 0x80, 0xc1, + 0x9d, 0xe0, 0xc5, 0xf4, 0xad, 0x86, 0xdb, 0x51, + 0x2d, 0xbf, 0x68, 0xa9, 0x78, 0x83, 0x22, 0x1b, + 0xab, 0x9b, 0x28, 0x26, 0x36, 0xac, 0x84, 0xe6, + 0x98, 0x56, 0xf8, 0x84, 0x05, 0xdb, 0x94, 0x71, + 0x9d, 0xba, 0xdc, 0x5f, 0xcb, 0x2f, 0xbc, 0xd8, + 0x8e, 0xed, 0x24, 0x51, 0xd5, 0xfa, 0x4e, 0x2f, + 0x08, 0x5a, 0xc8, 0x96, 0x5c, 0xad, 0x86, 0x36, + 0xcd, 0x80, 0x60, 0xb7, 0x67, 0x3f, 0xc5, 0x25, + 0x45, 0x9d, 0x11, 0x26, 0x20, 0xed, 0xe7, 0x7a, + 0x7c, 0x4e, 0x3d, 0x51, 0x07, 0x29, 0x33, 0xfd, + 0xad, 0xa3, 0xc5, 0x02, 0x09, 0x62, 0xd9, 0x3a, + 0x55, 0x66, 0xd9, 0x16, 0x5e, 0x45, 0xad, 0x5d, + 0xe6, 0xc7, 0x43, 0xcd, 0x1e, 0x36, 0xdf, 0xcb, + 0x51, 0x4c, 0xf6, 0x60, 0x7b, 0x3b, 0x14, 0xa3, + 0x8b, 0xf1, 0x4a, 0x0b, 0x3a, 0x54, 0x46, 0x38, + 0xa7, 0x14, 0x1a, 0xe1, 0x3a, 0xa6, 0xa4, 0x08, + 0x5f, 0xf3, 0x3d, 0x6b, 0xf6, 0x5c, 0xc2, 0xc5, + 0x16, 0xdb, 0x69, 0xb5, 0x30, 0xac, 0x0b, 0xaf, + 0x56, 0xe1, 0x24, 0x3c, 0x2f, 0x69, 0x33, 0x3b, + 0xbd, 0xd6, 0x14, 0x28, 0x5b, 0x24, 0x9d, 0x46, + 0xb5, 0x5e, 0xa0, 0xb2, 0x73, 0x51, 0x0d, 0x04, + 0x6c, 0x0f, 0x38, 0x97, 0xed, 0xcd, 0xaa, 0x55, + 0xa3, 0xb5, 0x7e, 0x96, 0x22, 0xc1, 0x16, 0x2d, + 0xd4, 0x7c, 0xe9, 0xd4, 0xd9, 0xf3, 0x63, 0x86, + 0xfc, 0xd2, 0x82, 0xdd, 0x44, 0x86, 0xf5, 0x05, + 0xe5, 0x5f, 0x82, 0xe2, 0x47, 0xb9, 0x69, 0xb5, + 0x03, 0x4d, 0x31, 0xc0, 0x43, 0xa3, 0xb0, 0xfa, + 0xcb, 0x6b, 0x09, 0x23, 0x3f, 0x6b, 0x72, 0x28, + 0x97, 0xf2, 0xaf, 0x9c, 0x9c, 0x1b, 0x48, 0xb4, + 0x8b, 0x1f, 0x3a, 0x0d, 0x15, 0x2b, 0x82, 0x18, + 0xf9, 0x96, 0x0a, 0xfc, 0x06, 0xf3, 0x3e, 0x89, + 0x4c, 0x8a, 0x64, 0xaa, 0x43, 0x84, 0x7d, 0x82, + 0xe3, 0xa2, 0xc5, 0x62, 0x32, 0x51, 0xda, 0xa1, + 0xc0, 0xe0, 0xac, 0x73, 0x91, 0x9b, 0xfe, 0x49, + 0x9a, 0xc7, 0x43, 0xd9, 0x32, 0xd0, 0x2f, 0x2a, + 0x25, 0xa8, 0x99, 0x22, 0xe5, 0x4d, 0x08, 0xcc, + 0xa4, 0xf4, 0x6a, 0x34, 0x1f, 0x8f, 0xd8, 0x5f, + 0x8a, 0x57, 0xad, 0xc8, 0x8d, 0x4f, 0x27, 0x50, + 0x05, 0x12, 0xb6, 0x83, 0x83, 0x35, 0x82, 0x2d, + 0x30, 0x89, 0x78, 0x68, 0x5c, 0x09, 0x95, 0xd1, + 0x90, 0x38, 0x17, 0xb6, 0x88, 0xa0, 0x1c, 0x30, + 0x0a, 0x6c, 0x94, 0x16, 0x20, 0xb0, 0x0a, 0x8f, + 0x0c, 0xc9, 0xaa, 0xe6, 0x84, 0x82, 0xff, 0x6a, + 0x25, 0xc1, 0x1c, 0x1c, 0xbc, 0x05, 0xc1, 0x61, + 0xeb, 0x63, 0xce, 0x2b, 0x1e, 0x2a, 0x4b, 0x04, + 0x7c, 0x61, 0x9f, 0x8e, 0x99, 0xfd, 0x49, 0xa0, + 0x78, 0x43, 0xff, 0xb2, 0xe1, 0x5f, 0x3d, 0xec, + 0x06, 0xe8, 0x94, 0xbf, 0x67, 0x43, 0xdb, 0xfc, + 0xf3, 0x7c, 0xed, 0xc3, 0xf8, 0xa5, 0x11, 0xa0, + 0x58, 0x04, 0x5e, 0xab, 0x54, 0x99, 0x29, 0x53, + 0x0a, 0x87, 0xf1, 0x20, 0x78, 0xac, 0x18, 0x3d, + 0x2e, 0x12, 0xc4, 0x86, 0xd1, 0x28, 0xfc, 0x03, + 0x71, 0x38, 0xf8, 0x15, 0xb1, 0xad, 0x47, 0x03, + 0xa6, 0xcc, 0x7d, 0x53, 0x16, 0x94, 0x1d, 0x17, + 0x22, 0xdf, 0xe3, 0xef, 0x89, 0x77, 0xa3, 0xd6, + 0x87, 0x98, 0x9b, 0xf7, 0x1a, 0x1f, 0xb3, 0xad, + 0xb0, 0x5c, 0x23, 0x24, 0x4e, 0xca, 0x46, 0x13, + 0xeb, 0x71, 0xaa, 0x23, 0x46, 0x5a, 0xf8, 0x93, + 0xf6, 0x37, 0xf7, 0x26, 0x82, 0xb5, 0x3b, 0x7d, + 0xf4, 0xf5, 0xc9, 0x98, 0x01, 0x65, 0xb5, 0x50, + 0xf5, 0x4d, 0xcf, 0x36, 0xad, 0xb1, 0xd4, 0xff, + 0x9b, 0x4c, 0xc7, 0xef, 0x80, 0xcb, 0x0a, 0xd3, + 0x2b, 0xf3, 0x6c, 0x7f, 0x22, 0xd7, 0x2e, 0x01, + 0x5f, 0x59, 0xb9, 0x2c, 0xbf, 0xf6, 0xc8, 0xf3, + 0xd1, 0x85, 0x40, 0x7d, 0x30, 0x06, 0x08, 0x0c, + 0xb5, 0x78, 0xc0, 0x2a, 0xc4, 0xb4, 0xad, 0x80, + 0x69, 0x7a, 0x95, 0x69, 0xc7, 0xa9, 0xd4, 0x33, + 0x57, 0xf1, 0x74, 0x12, 0xfc, 0xd3, 0x4d, 0x62, + 0x96, 0x94, 0xef, 0x44, 0x81, 0xbd, 0x1b, 0x78, + 0xc0, 0xb9, 0x20, 0xf8, 0x79, 0x07, 0x89, 0xc4, + 0x06, 0x87, 0xc9, 0x32, 0xf1, 0xa6, 0x1b, 0xd4, + 0x81, 0x01, 0x5c, 0x54, 0xad, 0x9f, 0xd0, 0x61, + 0x04, 0x77, 0xf9, 0x32, 0xcd, 0x69, 0xb4, 0xac, + 0x78, 0x72, 0x94, 0x40, 0x4d, 0xee, 0xa9, 0xb3, + 0xc9, 0x98, 0xda, 0xd9, 0x91, 0x8f, 0x2e, 0xa4, + 0x18, 0x07, 0xd9, 0xc8, 0x03, 0xc9, 0x45, 0x38, + 0x38, 0x89, 0xff, 0xb3, 0x57, 0x69, 0x46, 0x37, + 0x37, 0xcd, 0xb5, 0xf5, 0x4c, 0xf7, 0x92, 0xa7, + 0x48, 0xad, 0xa9, 0x57, 0x93, 0x7b, 0xef, 0xae, + 0x59, 0xf6, 0xb6, 0x15, 0xca, 0x22, 0x3e, 0x58, + 0x65, 0x26, 0x4a, 0x39, 0xf0, 0xf4, 0x4a, 0x4a, + 0xd4, 0xff, 0x8a, 0x94, 0x75, 0x9f, 0x29, 0xf5, + 0xdf, 0x36, 0xa3, 0x6e, 0x07, 0xbe, 0xec, 0x2d, + 0xcf, 0xc9, 0xb7, 0xb1, 0x6e, 0xf5, 0xc1, 0x88, + 0x43, 0xf1, 0x7f, 0x81, 0xc0, 0xa4, 0x04, 0x50, + 0x6e, 0x16, 0x7c, 0x3f, 0x05, 0x58, 0x30, 0xe4, + 0x7a, 0x0e, 0x05, 0x58, 0x30, 0x29, 0xc1, 0x8b, + 0x4b, 0x01, 0x4c, 0x0c, 0xa4, 0x18, 0x41, 0x10, + 0x41, 0x10, 0x18, 0x6c, 0xa4, 0x3f, 0x02, 0xe0, + 0xaa, 0x06, 0x0e, 0x41, 0xf0, 0x7f, 0xed, 0x0b, + 0x69, 0x44, 0xb4, 0xe5, 0xcd, 0x5c, 0x1f, 0xb4, + 0x3f, 0xd5, 0x7c, 0x6d, 0xa2, 0xf6, 0x8b, 0xc4, + 0x88, 0x24, 0x2b, 0x4f, 0xac, 0xec, 0xff, 0xc7, + 0x20, 0x64, 0x78, 0xa9, 0x20, 0x32, 0x96, 0x1b, + 0x8a, 0xfc, 0xac, 0xaf, 0xf5, 0xac, 0x6f, 0x14, + 0xe5, 0x6d, 0xa6, 0xcc, 0x45, 0x19, 0x2a, 0xe8, + 0xd0, 0x12, 0x9f, 0xc1, 0xe9, 0xa0, 0x03, 0xe0, + 0x52, 0x9a, 0x82, 0x27, 0xb7, 0x7e, 0x3e, 0xbd, + 0x60, 0xb5, 0xb5, 0x65, 0xcc, 0xf4, 0x42, 0xec, + 0xbb, 0x3f, 0xf4, 0x89, 0x55, 0xef, 0x41, 0x55, + 0x14, 0x03, 0x23, 0x65, 0xb5, 0xae, 0x33, 0xdd, + 0xe1, 0x87, 0x9b, 0xe6, 0xfa, 0x20, 0x27, 0x1f, + 0x27, 0x98, 0xa2, 0x6d, 0x2e, 0x2f, 0x48, 0x3f, + 0x51, 0xde, 0xdc, 0x8d, 0xd4, 0xcd, 0xb6, 0x58, + 0xa5, 0x46, 0xdc, 0x2d, 0xe1, 0x69, 0x67, 0xf8, + 0x36, 0xa7, 0x87, 0x23, 0xf9, 0x41, 0xe0, 0x60, + 0x43, 0x05, 0x14, 0x03, 0x05, 0x9d, 0x08, 0x00, + 0x8a, 0x08, 0xb5, 0x38, 0x2a, 0x80, 0xd6, 0xab, + 0x10, 0xe8, 0x3c, 0x17, 0xfd, 0x34, 0xb8, 0x15, + 0xa0, 0xaa, 0x8a, 0xc0, 0xd4, 0x6d, 0x42, 0xea, + 0x47, 0x0a, 0x03, 0xd0, 0xb1, 0x29, 0xed, 0x06, + 0xe9, 0x7b, 0x6a, 0x9b, 0x06, 0x62, 0x27, 0xf0, + 0x28, 0x84, 0x3c, 0x10, 0x01, 0x84, 0xa0, 0x62, + 0xd5, 0x0d, 0xeb, 0x2c, 0x37, 0x07, 0x9f, 0x57, + 0x73, 0xc0, 0xc2, 0x00, 0x7e, 0xc0, 0xec, 0x71, + 0x55, 0x4c, 0x67, 0xc3, 0xfa, 0xcd, 0x4c, 0x38, + 0xf3, 0x3f, 0x85, 0xd0, 0xc5, 0xba, 0x80, 0xf4, + 0x4d, 0x3f, 0x56, 0x9b, 0x64, 0x40, 0xc2, 0xf1, + 0xd6, 0xab, 0xed, 0xca, 0x93, 0x04, 0xb1, 0xf6, + 0x97, 0xf7, 0x03, 0xbf, 0x52, 0xec, 0x57, 0x53, + 0xcd, 0xf2, 0x8a, 0x5b, 0xea, 0xd2, 0x9c, 0x51, + 0xaa, 0x64, 0xe3, 0xd4, 0x08, 0x25, 0xe5, 0xc2, + 0x56, 0x84, 0x2c, 0x6f, 0xe5, 0xdd, 0x56, 0x24, + 0x97, 0x24, 0x6f, 0x13, 0xa7, 0x9e, 0xd6, 0x07, + 0xca, 0xc3, 0xf1, 0xc8, 0xef, 0x32, 0x2b, 0xf5, + 0x98, 0xab, 0x5a, 0xcc, 0x0f, 0xd9, 0x9f, 0x1f, + 0x78, 0xae, 0x7f, 0x2e, 0xf0, 0x2c, 0x61, 0x08, + 0x1e, 0x06, 0x04, 0x10, 0x53, 0x01, 0xe0, 0xfc, + 0x18, 0xb0, 0x6c, 0x5c, 0xa0, 0x3e, 0x1c, 0xd0, + 0x3b, 0x40, 0xf9, 0x65, 0x53, 0xd0, 0x61, 0x00, + 0x1e, 0x0b, 0xfc, 0xf9, 0x41, 0x56, 0x20, 0x88, + 0x0a, 0x41, 0x80, 0xc7, 0x40, 0xd0, 0xe0, 0x3c, + 0x07, 0xc1, 0x80, 0x54, 0x46, 0x0c, 0xad, 0x30, + 0xf0, 0x1e, 0x0a, 0x02, 0xf4, 0xe3, 0xf6, 0x87, + 0xdc, 0x07, 0x81, 0xff, 0x1c, 0x48, 0x61, 0x5a, + 0xb4, 0xbe, 0x63, 0x80, 0xaa, 0x50, 0x3f, 0xfb, + 0x2d, 0x7d, 0x96, 0x67, 0x01, 0x55, 0xd0, 0xf7, + 0xed, 0x6e, 0x87, 0xd6, 0x95, 0xeb, 0x9e, 0xda, + 0xb2, 0x0e, 0x1a, 0x0c, 0x6c, 0xa7, 0xaa, 0xe1, + 0x79, 0x84, 0xd9, 0x98, 0x23, 0x09, 0x6d, 0xf2, + 0x08, 0xbd, 0x68, 0x70, 0x3c, 0x1f, 0xb2, 0x1e, + 0x71, 0x48, 0x18, 0xef, 0x95, 0x32, 0xc8, 0x79, + 0xc5, 0x25, 0x43, 0x72, 0xa4, 0x6f, 0x7a, 0x3a, + 0xb9, 0x55, 0x27, 0xca, 0x5d, 0x55, 0x5b, 0x2c, + 0x2f, 0x2e, 0xdf, 0x5c, 0xff, 0x92, 0x25, 0x63, + 0x7f, 0x35, 0x4e, 0x76, 0x8d, 0xf2, 0x9b, 0x99, + 0xff, 0x7e, 0xf4, 0xb3, 0xe6, 0x03, 0x10, 0x32, + 0x70, 0x86, 0x0d, 0x85, 0x6a, 0x3a, 0x24, 0xb0, + 0x99, 0x6a, 0x06, 0xb8, 0x21, 0x02, 0x18, 0x32, + 0xe9, 0x18, 0xd0, 0x78, 0x48, 0x0a, 0xd2, 0x83, + 0x15, 0xb0, 0xba, 0x49, 0x67, 0x0b, 0x19, 0x06, + 0x41, 0xa1, 0x70, 0xe9, 0x57, 0x52, 0xe8, 0x85, + 0xf6, 0x1b, 0x55, 0x8a, 0xda, 0x10, 0x68, 0x33, + 0x09, 0x81, 0xe0, 0x7f, 0xb5, 0x04, 0x49, 0xff, + 0x08, 0x40, 0xaa, 0x6f, 0xa3, 0xcf, 0xb6, 0xac, + 0x21, 0x2a, 0x1d, 0xab, 0xf9, 0x6d, 0x2c, 0x6f, + 0xcd, 0xb4, 0x3e, 0xd4, 0x93, 0xfe, 0xf7, 0xd4, + 0xb2, 0x20, 0x99, 0xbb, 0xd3, 0x4a, 0x78, 0x88, + 0x1c, 0x41, 0xa6, 0x83, 0x65, 0xc0, 0x7b, 0xc3, + 0x81, 0xca, 0x41, 0x21, 0x50, 0x82, 0xde, 0x2a, + 0x68, 0xb7, 0xc9, 0xbc, 0x1f, 0xab, 0xfa, 0xde, + 0x55, 0xe2, 0xde, 0x0e, 0x59, 0xff, 0x2a, 0x86, + 0xb3, 0xbf, 0xd5, 0x15, 0x44, 0x59, 0xe6, 0x6d, + 0x06, 0x60, 0xab, 0x07, 0x20, 0xa0, 0x95, 0xb0, + 0x2d, 0x04, 0x11, 0x28, 0xb5, 0x92, 0xbd, 0x68, + 0x0c, 0x42, 0xde, 0xb6, 0x06, 0x73, 0x5a, 0x2a, + 0x5c, 0x73, 0x9b, 0xe0, 0xee, 0x58, 0xe0, 0xb8, + 0x07, 0x40, 0xf8, 0x42, 0x1d, 0xb2, 0x0c, 0x5c, + 0xc0, 0xf8, 0x7a, 0x98, 0xbd, 0xbf, 0x83, 0x2b, + 0x03, 0xc5, 0xf1, 0xa5, 0x5f, 0x9f, 0xdc, 0x63, + 0x2f, 0xfb, 0xac, 0xe6, 0x2e, 0x9b, 0x65, 0x4e, + 0xd0, 0x18, 0x4e, 0x58, 0xdd, 0xa5, 0xb2, 0x67, + 0x5a, 0x6c, 0x05, 0x1e, 0x06, 0x60, 0x1b, 0x00, + 0xf0, 0xec, 0x14, 0x1f, 0x4e, 0x9d, 0x24, 0x56, + 0xc8, 0x43, 0x64, 0x7e, 0x5a, 0xaf, 0x66, 0x6b, + 0x6a, 0xb1, 0x84, 0xec, 0xb1, 0xe0, 0x55, 0x6d, + 0xf5, 0x03, 0x56, 0x70, 0x73, 0x77, 0x3b, 0x7f, + 0xf5, 0x9b, 0x2d, 0x62, 0x40, 0x18, 0x6a, 0xf5, + 0x1f, 0xc5, 0xf7, 0xa3, 0x2e, 0x3f, 0x5c, 0x98, + 0x42, 0x08, 0x21, 0x09, 0x60, 0x78, 0x3f, 0xf8, + 0x47, 0x43, 0xf6, 0xa9, 0x27, 0x0a, 0x1e, 0x33, + 0x03, 0xea, 0xfc, 0x08, 0x61, 0x08, 0x7d, 0xa5, + 0xc9, 0xe6, 0xcd, 0xce, 0x7d, 0x81, 0xfb, 0x43, + 0xd1, 0xf8, 0x90, 0x3c, 0xaa, 0xaf, 0x53, 0x96, + 0x42, 0xfa, 0x98, 0xbc, 0x3c, 0x8c, 0x2f, 0xd2, + 0xc8, 0xa5, 0xaf, 0xa9, 0x93, 0xf9, 0x6b, 0x82, + 0x58, 0x28, 0xc0, 0xf8, 0xfd, 0x85, 0x4a, 0x95, + 0x0e, 0x59, 0xfe, 0xee, 0x16, 0xab, 0x6e, 0x30, + 0xc3, 0x4c, 0x4f, 0xb3, 0xfe, 0x37, 0xfe, 0x4d, + 0xcf, 0x66, 0x4d, 0x6f, 0x79, 0xfb, 0xc9, 0xc8, + 0xbf, 0x21, 0xc3, 0x03, 0xdf, 0x84, 0x0a, 0xc0, + 0xe5, 0x28, 0xf8, 0x0e, 0x8e, 0x83, 0xff, 0xcf, + 0x27, 0x2f, 0x54, 0xb8, 0xe5, 0x52, 0xae, 0xf9, + 0xb9, 0x37, 0x1b, 0x97, 0x62, 0x8f, 0x29, 0x96, + 0xe6, 0xac, 0x6e, 0x1c, 0xb6, 0xde, 0x21, 0xe4, + 0x34, 0xed, 0x71, 0x9b, 0x69, 0xfe, 0xac, 0x4a, + 0x4a, 0x07, 0x55, 0x2b, 0x08, 0x42, 0x1a, 0x46, + 0xe2, 0x51, 0x08, 0x7a, 0x21, 0x7c, 0x0e, 0x68, + 0x34, 0x11, 0x92, 0xd5, 0x6c, 0xf9, 0xa5, 0x4a, + 0x75, 0x52, 0x56, 0x04, 0x11, 0xfb, 0x55, 0x16, + 0xa8, 0xd5, 0x7e, 0xb8, 0x38, 0x93, 0x7f, 0xbb, + 0xa0, 0xb2, 0x28, 0xd0, 0x33, 0x62, 0x58, 0x94, + 0x9c, 0x78, 0x3f, 0x48, 0xa8, 0x4a, 0xa2, 0x1a, + 0x96, 0xb0, 0xb1, 0x52, 0x42, 0xf5, 0x49, 0xfd, + 0x36, 0x66, 0xea, 0xfe, 0x9e, 0x6f, 0xdb, 0x93, + 0x79, 0x6a, 0x25, 0xd7, 0xe3, 0xec, 0x03, 0x5b, + 0x1f, 0x0f, 0x47, 0x63, 0xe1, 0xf4, 0x1d, 0x0f, + 0x00, 0xe8, 0xf9, 0xaf, 0x26, 0x4e, 0xca, 0x7a, + 0x94, 0x7a, 0xc1, 0x77, 0xd5, 0x07, 0xdf, 0xd2, + 0xdf, 0x56, 0x9b, 0xfa, 0x5c, 0x61, 0x99, 0x65, + 0x6b, 0xc0, 0x65, 0x82, 0xbf, 0xa9, 0xa3, 0x89, + 0x02, 0xd4, 0xc2, 0x06, 0x0e, 0x80, 0x31, 0xa0, + 0x78, 0x2f, 0xf9, 0x44, 0x06, 0x18, 0x9b, 0x7e, + 0xac, 0x1e, 0x0b, 0xfd, 0x9f, 0x82, 0x85, 0x91, + 0x28, 0x18, 0x38, 0xf7, 0x04, 0x28, 0x23, 0xe8, + 0x30, 0x18, 0x10, 0x18, 0x51, 0xec, 0xe0, 0x2b, + 0x27, 0xc5, 0x7d, 0x51, 0xde, 0x75, 0x74, 0x27, + 0xb5, 0xc1, 0x66, 0xc0, 0x8e, 0x10, 0xcb, 0xd2, + 0x83, 0x32, 0x21, 0x26, 0x12, 0x07, 0xf1, 0x37, + 0xbe, 0xaf, 0x52, 0x44, 0xcd, 0x40, 0x6c, 0x12, + 0xfb, 0xcc, 0xef, 0x03, 0xfb, 0x90, 0x21, 0xa4, + 0xef, 0x74, 0x18, 0xd2, 0x9b, 0x3c, 0x22, 0x1f, + 0x14, 0x01, 0xe0, 0x51, 0x62, 0x66, 0x52, 0x40, + 0x3b, 0xa2, 0x4e, 0x09, 0x5e, 0x05, 0x3f, 0xc7, + 0xc0, 0xa7, 0xcb, 0x47, 0x20, 0xaa, 0x8c, 0x8e, + 0x14, 0xf0, 0xb7, 0xa3, 0x80, 0x23, 0xc2, 0xc0, + 0xe7, 0x87, 0xcd, 0x24, 0x6c, 0x49, 0x03, 0x82, + 0x18, 0x31, 0x5e, 0x17, 0xc6, 0x9a, 0xbc, 0x60, + 0x1e, 0x0b, 0xfd, 0xb1, 0x28, 0x10, 0xc2, 0x13, + 0x5f, 0xa3, 0x75, 0x05, 0x8d, 0x89, 0x25, 0xc5, + 0x5b, 0xf5, 0x0a, 0x78, 0x05, 0xbe, 0xf2, 0x1a, + 0xca, 0x86, 0x80, 0xc7, 0x9a, 0x55, 0xe9, 0x33, + 0xde, 0x2b, 0xfe, 0xff, 0x74, 0x45, 0xdb, 0x77, + 0x76, 0x95, 0xdf, 0xff, 0x6d, 0xaf, 0x35, 0x8f, + 0x79, 0x01, 0x64, 0x91, 0x10, 0xcc, 0x55, 0xae, + 0x68, 0x14, 0x00, 0xcd, 0x0f, 0x19, 0x56, 0x56, + 0x39, 0xc6, 0x2e, 0x79, 0xa6, 0xb5, 0x70, 0xe6, + 0x90, 0x6a, 0x0c, 0xb2, 0xa9, 0x3d, 0xde, 0x16, + 0xb6, 0xdf, 0xf5, 0x44, 0x59, 0x4d, 0xdb, 0xd7, + 0xc7, 0xd4, 0x06, 0xd0, 0x07, 0x03, 0x97, 0x3f, + 0xa1, 0xa4, 0x48, 0x81, 0xc7, 0x5a, 0x1b, 0x0f, + 0x6d, 0x33, 0xa6, 0x2d, 0xf0, 0xe8, 0xb9, 0x8e, + 0x0e, 0x13, 0x30, 0xd4, 0x35, 0xe6, 0xbd, 0x81, + 0x91, 0x84, 0x0b, 0x32, 0x2c, 0x2f, 0x09, 0x9d, + 0x9d, 0x3f, 0xe5, 0x34, 0x11, 0xce, 0x62, 0x19, + 0xd2, 0x9e, 0x3f, 0x4e, 0x78, 0x0e, 0x25, 0x19, + 0x11, 0xf5, 0x00, 0x3c, 0x94, 0x23, 0xdc, 0x07, + 0x23, 0x39, 0x91, 0xa3, 0xe1, 0xe5, 0x02, 0x43, + 0x4d, 0x3f, 0x51, 0x82, 0xc4, 0x1c, 0x2e, 0xeb, + 0xcf, 0xc1, 0xf3, 0x0d, 0x27, 0xb9, 0x93, 0x74, + 0x73, 0x37, 0x6d, 0xd0, 0x33, 0x9e, 0xea, 0x39, + 0x14, 0xa2, 0xea, 0x22, 0xce, 0x73, 0x88, 0x88, + 0x54, 0xa8, 0xc4, 0xc2, 0xd5, 0x0b, 0x2c, 0x37, + 0xe2, 0xdd, 0x88, 0x44, 0xc6, 0xc1, 0x5d, 0x5c, + 0xae, 0xec, 0xa8, 0xd4, 0x44, 0x1c, 0xaa, 0x3b, + 0xd5, 0x90, 0x20, 0x9d, 0x43, 0xc3, 0x83, 0x71, + 0xea, 0x82, 0xf6, 0xc4, 0x0b, 0x1a, 0xff, 0x40, + 0x87, 0xd8, 0x0f, 0x66, 0xf3, 0xf2, 0x72, 0x6a, + 0xd6, 0x11, 0xad, 0xef, 0xd9, 0xa0, 0xc1, 0xef, + 0xe1, 0x59, 0x56, 0x77, 0x95, 0x44, 0x88, 0x44, + 0x5e, 0xf2, 0x22, 0xea, 0xce, 0x15, 0x26, 0xf6, + 0x24, 0x9b, 0xb9, 0xb7, 0xa8, 0x54, 0xd6, 0x65, + 0xbc, 0xe2, 0xd1, 0x6f, 0x4e, 0x45, 0x90, 0x8c, + 0xce, 0xf6, 0x23, 0x8b, 0xc3, 0x43, 0x5a, 0x9a, + 0xde, 0xe2, 0x82, 0xd0, 0xfb, 0xed, 0xb2, 0x1e, + 0x41, 0xc2, 0x05, 0x08, 0x06, 0xd7, 0x54, 0xf1, + 0x1c, 0x95, 0x71, 0x41, 0x4a, 0xd3, 0x72, 0xc5, + 0xb9, 0x93, 0x6d, 0xd6, 0xb3, 0xa8, 0xaa, 0xc8, + 0xed, 0x8b, 0xc5, 0xd6, 0x97, 0x49, 0xd7, 0x9d, + 0x89, 0xe4, 0x91, 0x69, 0x2c, 0xda, 0xba, 0xd6, + 0x0d, 0x83, 0xde, 0xc5, 0xc6, 0x26, 0xfa, 0x81, + 0xe9, 0x56, 0xea, 0x9b, 0x27, 0x36, 0xa3, 0xe7, + 0x2a, 0xcb, 0x2c, 0x8b, 0xa3, 0x71, 0x99, 0xe5, + 0x9b, 0xc4, 0x10, 0x33, 0xa1, 0x5c, 0x4d, 0x45, + 0x62, 0x02, 0xab, 0x93, 0x9f, 0x51, 0x20, 0x77, + 0xe5, 0x37, 0x72, 0xa0, 0x95, 0x74, 0x5c, 0x5e, + 0xa9, 0x58, 0x6a, 0x33, 0xfa, 0xbf, 0x0f, 0xf9, + 0xa9, 0x8b, 0x75, 0xaf, 0x58, 0x5b, 0xcc, 0xfb, + 0x17, 0x43, 0xd2, 0xae, 0xf9, 0x47, 0xb6, 0x1b, + 0xde, 0xc5, 0xd1, 0xae, 0x8d, 0xeb, 0x37, 0xe5, + 0xf3, 0x3e, 0xc2, 0x9f, 0x69, 0x6e, 0xb7, 0xf0, + 0x21, 0x22, 0x2e, 0x76, 0x49, 0x57, 0x45, 0x56, + 0x40, 0x8d, 0xe2, 0x54, 0x8a, 0x8b, 0x4b, 0x6c, + 0x68, 0x70, 0xc2, 0x2f, 0x7b, 0x99, 0x16, 0xef, + 0x54, 0xc8, 0xa3, 0xa1, 0xea, 0x3e, 0xda, 0xb8, + 0x56, 0xa5, 0xbc, 0x20, 0xab, 0xa2, 0xaf, 0x27, + 0xa2, 0xeb, 0xa1, 0x9b, 0x32, 0x4d, 0xa6, 0xf8, + 0x1c, 0x68, 0x61, 0x45, 0x7a, 0xb3, 0x6b, 0x4d, + 0x0e, 0x3f, 0xfb, 0xb8, 0x8e, 0x7e, 0xf7, 0x85, + 0x8b, 0x55, 0x1c, 0xe6, 0x4e, 0x73, 0xbc, 0x8b, + 0x09, 0x88, 0xfe, 0x37, 0xa5, 0x9d, 0xb6, 0x5b, + 0x67, 0x38, 0x80, 0xd7, 0x7b, 0xc2, 0x53, 0xae, + 0x58, 0xb2, 0xd9, 0xb6, 0xae, 0x4b, 0x0d, 0xaf, + 0x4d, 0x94, 0x3b, 0x5c, 0xfe, 0x9a, 0xb8, 0x90, + 0x15, 0xbf, 0x56, 0xb6, 0xb7, 0x72, 0x2d, 0x7d, + 0x65, 0x96, 0x08, 0x90, 0xab, 0xba, 0xa4, 0xd1, + 0x11, 0x5a, 0x3c, 0xcd, 0x62, 0x59, 0x3e, 0xc4, + 0xe6, 0xf6, 0xac, 0xa4, 0xae, 0x59, 0xb3, 0xba, + 0xa7, 0x88, 0xfb, 0x28, 0xde, 0x72, 0x11, 0xd8, + 0xe3, 0xb2, 0x23, 0x95, 0x05, 0x5a, 0x8c, 0x16, + 0xea, 0xf0, 0xdc, 0x59, 0x01, 0x3c, 0xff, 0x54, + 0xe1, 0x65, 0xf5, 0xe5, 0x0f, 0x2d, 0x58, 0x63, + 0x7b, 0x9c, 0xe3, 0xd9, 0x7a, 0xb1, 0x2f, 0x7b, + 0x28, 0x4b, 0x13, 0x4d, 0x33, 0x03, 0x86, 0x2f, + 0xbc, 0x1e, 0xdc, 0x91, 0x1f, 0x7b, 0x79, 0x00, + 0xae, 0xad, 0xde, 0xf1, 0x18, 0x50, 0x4d, 0x80, + 0x33, 0x9d, 0xb9, 0xca, 0x50, 0x8f, 0x84, 0xab, + 0xf0, 0x99, 0x55, 0x73, 0x73, 0xdc, 0x6b, 0x2e, + 0x7f, 0x9c, 0x9f, 0x11, 0x20, 0x2b, 0xe2, 0x95, + 0xc9, 0xa1, 0xab, 0x24, 0x93, 0xb0, 0xd1, 0x51, + 0x52, 0x05, 0xd6, 0x0c, 0x5f, 0x78, 0x4b, 0x4f, + 0xd4, 0xc4, 0x6a, 0x92, 0xfa, 0x6b, 0x6a, 0x76, + 0xf4, 0x73, 0x62, 0x8e, 0x6a, 0xca, 0x16, 0x43, + 0x06, 0xd3, 0xa8, 0xc2, 0x9b, 0xb0, 0x72, 0xca, + 0xa9, 0xf8, 0xb4, 0x1f, 0xb0, 0xdf, 0xba, 0x49, + 0xb3, 0x96, 0x0d, 0xd1, 0x2e, 0x68, 0x4e, 0x83, + 0x10, 0x41, 0xad, 0xb7, 0x36, 0xde, 0xb7, 0xce, + 0xf0, 0xb7, 0x16, 0x5a, 0xe2, 0xd7, 0x96, 0x0a, + 0xcb, 0xe2, 0xac, 0xeb, 0x05, 0x57, 0x91, 0x99, + 0x78, 0x8f, 0x8b, 0xf7, 0x16, 0x5f, 0x90, 0x28, + 0x5b, 0x6b, 0xa2, 0xee, 0xf7, 0xa0, 0xf5, 0x30, + 0x01, 0x84, 0xbd, 0x05, 0xe0, 0x3a, 0x1b, 0x04, + 0xd5, 0x56, 0xd3, 0x61, 0x8c, 0xa0, 0xe0, 0x1e, + 0x72, 0xa9, 0xf9, 0x10, 0x1f, 0xd3, 0xa3, 0x68, + 0xca, 0x11, 0x1d, 0x2c, 0xa6, 0x9a, 0x88, 0xae, + 0x29, 0xe7, 0xaf, 0xfd, 0x3f, 0xc1, 0xce, 0x7b, + 0xfc, 0x53, 0xec, 0x6f, 0x90, 0x41, 0xcc, 0xb3, + 0x19, 0xe6, 0x0e, 0x66, 0xa8, 0x73, 0x52, 0xb1, + 0xa4, 0x20, 0xe4, 0x47, 0x0c, 0xb4, 0xad, 0x9b, + 0xf6, 0x73, 0xe9, 0xae, 0x7b, 0x2c, 0x2c, 0xf9, + 0x6c, 0x05, 0x6c, 0x0e, 0x54, 0x41, 0xb5, 0xe8, + 0xc5, 0x18, 0xa9, 0x4a, 0x81, 0xc2, 0x8a, 0x98, + 0xaa, 0xf2, 0xce, 0x7f, 0xde, 0xff, 0xaa, 0x36, + 0x99, 0xf7, 0x99, 0x6b, 0x79, 0x7a, 0x56, 0xc3, + 0x33, 0x5a, 0xde, 0x6c, 0x9b, 0x14, 0xe5, 0xe6, + 0xe6, 0x68, 0xdf, 0x23, 0xde, 0xef, 0x57, 0xed, + 0xb6, 0xdb, 0xd4, 0x3d, 0xb4, 0x96, 0xa1, 0xb4, + 0x8d, 0x05, 0x24, 0x80, 0xe2, 0x51, 0xaf, 0xe8, + 0x3f, 0x7c, 0x00, 0x72, 0x13, 0xc6, 0xc2, 0xd0, + 0x2b, 0x26, 0x8e, 0x74, 0x7c, 0x3c, 0xd6, 0x62, + 0x8b, 0x15, 0xfc, 0x74, 0x3c, 0xfa, 0x59, 0x73, + 0x85, 0x97, 0x13, 0xfd, 0x35, 0x57, 0x2b, 0x53, + 0x24, 0x6a, 0x96, 0xf5, 0xa5, 0x12, 0x7a, 0xe2, + 0x88, 0x79, 0x54, 0xe9, 0x07, 0x83, 0xf5, 0x10, + 0x7e, 0x93, 0xc9, 0x7d, 0x2a, 0x9e, 0x37, 0xaa, + 0xfd, 0x4b, 0x78, 0x37, 0x2d, 0x61, 0xb6, 0x1b, + 0x29, 0x0f, 0x54, 0x7d, 0x6b, 0xf9, 0xa5, 0x98, + 0x7a, 0xaf, 0x41, 0x63, 0xd0, 0xc0, 0xeb, 0x19, + 0x83, 0x81, 0x3a, 0xd9, 0x06, 0x24, 0xaf, 0xa3, + 0x44, 0xc4, 0x9b, 0xca, 0x37, 0xcc, 0x2c, 0x51, + 0x22, 0x8a, 0xd6, 0x56, 0x0b, 0x24, 0x92, 0x35, + 0x58, 0xb0, 0x70, 0x20, 0x4c, 0xc9, 0xe8, 0xc1, + 0x60, 0xe0, 0xb2, 0x4f, 0x28, 0x51, 0x0f, 0x29, + 0x31, 0xa9, 0xd8, 0xa9, 0xa4, 0xc9, 0xa6, 0xf3, + 0xb8, 0x3e, 0x1e, 0x24, 0x2e, 0x9b, 0x73, 0xaa, + 0x2b, 0x70, 0xb9, 0x86, 0x87, 0x3b, 0x93, 0x7f, + 0x30, 0xb5, 0x4a, 0x82, 0xdf, 0xa8, 0xe2, 0x9a, + 0x7c, 0xcf, 0x4f, 0x7e, 0x9b, 0x2b, 0x19, 0x05, + 0x5a, 0x8c, 0x24, 0x07, 0x12, 0x91, 0xe9, 0x8b, + 0x44, 0x84, 0x93, 0x47, 0x29, 0xd8, 0x1f, 0x09, + 0x54, 0x77, 0x36, 0x96, 0x27, 0x06, 0x50, 0x3e, + 0xf2, 0x59, 0xff, 0x87, 0x6c, 0xfd, 0x2e, 0x35, + 0x89, 0xef, 0xea, 0x9d, 0x2d, 0xbb, 0xf5, 0x2d, + 0xaf, 0x2d, 0xbd, 0x78, 0x95, 0x38, 0xe1, 0xb4, + 0xda, 0xc7, 0xd3, 0x34, 0x3f, 0x53, 0x24, 0xaa, + 0x93, 0xe3, 0x4c, 0xb1, 0xbf, 0xc1, 0xb5, 0xfb, + 0x5a, 0xa7, 0x0a, 0xbf, 0x26, 0xaf, 0x2f, 0x2a, + 0x24, 0x4e, 0x44, 0x4a, 0x49, 0x93, 0x1a, 0xf9, + 0x6b, 0x79, 0xac, 0xaf, 0xc5, 0x3c, 0xcb, 0xca, + 0x6e, 0x50, 0x60, 0xa5, 0x3d, 0xf3, 0x78, 0xb3, + 0x5c, 0x44, 0xa6, 0xfc, 0xd6, 0x8c, 0xba, 0x8c, + 0x1d, 0x48, 0x06, 0x10, 0x9a, 0x88, 0x10, 0x1e, + 0xd7, 0xb2, 0xe6, 0xf5, 0xa4, 0xe9, 0x15, 0x09, + 0x25, 0xed, 0x35, 0x93, 0x75, 0xb6, 0x5a, 0x92, + 0x22, 0x54, 0xd6, 0x78, 0x93, 0x39, 0xef, 0x01, + 0x49, 0x92, 0x39, 0x3d, 0x4d, 0xe6, 0x8b, 0xa7, + 0x8b, 0x92, 0x5b, 0xb3, 0x1a, 0x48, 0x93, 0xcd, + 0x5e, 0xed, 0xad, 0x7b, 0x22, 0x3d, 0xde, 0xcc, + 0xdb, 0xb7, 0x7b, 0x6f, 0x24, 0x99, 0x88, 0x0f, + 0x6f, 0xe1, 0x66, 0x45, 0x3d, 0x02, 0x74, 0xd2, + 0xc4, 0xa1, 0x57, 0x50, 0x8c, 0x95, 0x11, 0x40, + 0x2c, 0x45, 0x3c, 0x52, 0x85, 0xfa, 0x6a, 0xb4, + 0x21, 0x09, 0x0d, 0x72, 0xaa, 0x10, 0x84, 0x85, + 0x56, 0x7f, 0xcc, 0xe0, 0x80, 0x3a, 0x2e, 0x6a, + 0xc6, 0x58, 0xe8, 0xe1, 0x9c, 0xbe, 0x6b, 0x38, + 0xdb, 0x4a, 0x74, 0x70, 0xdc, 0x0f, 0x5a, 0x2d, + 0xd5, 0x16, 0x29, 0xd3, 0xe5, 0xfc, 0xc3, 0x49, + 0xb2, 0x34, 0xc3, 0x4d, 0x30, 0xd6, 0x5b, 0x71, + 0x86, 0x3d, 0x15, 0x7a, 0x5d, 0xbd, 0xfd, 0x9e, + 0xc9, 0x99, 0x3b, 0x7b, 0xbb, 0x79, 0xdb, 0xb6, + 0xed, 0x5e, 0x9f, 0x2a, 0x63, 0x5a, 0x2f, 0x25, + 0x42, 0x14, 0x42, 0x4a, 0x45, 0x13, 0x74, 0xa3, + 0x87, 0xc4, 0x7b, 0x99, 0xfc, 0xdf, 0x6f, 0xa3, + 0x7e, 0xfc, 0xb1, 0xbf, 0x7f, 0x33, 0xfe, 0xdf, + 0x55, 0xae, 0x7f, 0xdf, 0x53, 0x9b, 0x95, 0x0e, + 0x6f, 0x65, 0x21, 0xba, 0x88, 0x1d, 0xc0, 0x58, + 0x03, 0x9f, 0x81, 0xcb, 0xd4, 0x60, 0xe2, 0x17, + 0x18, 0xbe, 0xa6, 0xa2, 0x41, 0x28, 0x74, 0xd1, + 0x6b, 0x4d, 0x09, 0x43, 0xc5, 0x5e, 0x67, 0x2e, + 0x2b, 0xf2, 0xa1, 0xe2, 0x65, 0x58, 0xaf, 0x39, + 0xb1, 0x43, 0x38, 0xc3, 0x59, 0x8c, 0xe7, 0x3f, + 0xfc, 0xe7, 0xe6, 0xad, 0xfd, 0x82, 0x2b, 0xc5, + 0xad, 0x7b, 0xde, 0x6a, 0x34, 0xd7, 0xa3, 0x5e, + 0xcc, 0x99, 0xef, 0x35, 0x26, 0x67, 0xbd, 0x88, + 0xb3, 0x3d, 0xee, 0x66, 0x64, 0x85, 0x53, 0x24, + 0xe6, 0x49, 0xc8, 0x79, 0x0f, 0x55, 0xc6, 0x43, + 0x20, 0x1f, 0x0a, 0x02, 0xad, 0x88, 0x90, 0x84, + 0x56, 0x94, 0x85, 0x55, 0x1b, 0xe3, 0x0c, 0x7a, + 0xb7, 0xbe, 0x6b, 0x33, 0x59, 0xd2, 0xd6, 0x77, + 0xd9, 0x26, 0xb3, 0xfe, 0x70, 0xb5, 0xbb, 0xc9, + 0x5b, 0xff, 0x39, 0x85, 0xbb, 0xdd, 0x51, 0xc9, + 0xde, 0x3a, 0x38, 0xb0, 0xcc, 0x1d, 0xc0, 0x4e, + 0x4c, 0xe3, 0x5b, 0x62, 0x11, 0xae, 0xbe, 0xa8, + 0x86, 0x2f, 0xce, 0xdd, 0x19, 0x02, 0xc5, 0xee, + 0xc2, 0x9a, 0x0b, 0x96, 0x95, 0x63, 0x9a, 0xfa, + 0x83, 0x88, 0x74, 0x07, 0x1f, 0xd1, 0x02, 0x22, + 0x2a, 0x0c, 0x45, 0xcb, 0x42, 0x64, 0x42, 0x41, + 0xa7, 0x45, 0x21, 0x44, 0x83, 0x86, 0x03, 0x56, + 0x80, 0x31, 0x21, 0x7d, 0x59, 0x10, 0x64, 0x19, + 0x39, 0xd6, 0xe9, 0x1e, 0x9c, 0x5c, 0x44, 0xb1, + 0x28, 0x39, 0x71, 0x5a, 0x62, 0x78, 0x91, 0x60, + 0x7f, 0x2f, 0xff, 0xf0, 0x3d, 0x1c, 0x00, 0x60, + 0xe7, 0x67, 0x74, 0xcb, 0x8c, 0x21, 0x40, 0x2c, + 0x51, 0x0d, 0x75, 0x88, 0x40, 0x70, 0x38, 0x82, + 0x01, 0xc6, 0xba, 0x0e, 0x26, 0x68, 0x56, 0x44, + 0x0e, 0x34, 0xe6, 0x2b, 0x13, 0x69, 0x9a, 0x65, + 0x85, 0x28, 0x79, 0x10, 0xf0, 0x31, 0x91, 0x61, + 0x88, 0x54, 0xa2, 0xaf, 0x41, 0xcf, 0xef, 0x7b, + 0xcb, 0xcb, 0xd9, 0x54, 0xca, 0x22, 0x21, 0x40, + 0xe2, 0xfa, 0x8a, 0xf2, 0x03, 0x81, 0x72, 0x70, + 0x41, 0x9a, 0xd5, 0xdc, 0x8d, 0xf2, 0x76, 0x2e, + 0x55, 0xfb, 0xa8, 0x38, 0x6d, 0x70, 0x74, 0x7a, + 0x10, 0x54, 0xc5, 0xaa, 0x26, 0xa3, 0x44, 0x0b, + 0x00, 0x5f, 0x2c, 0xdc, 0xe0, 0x75, 0x11, 0xde, + 0x44, 0x7c, 0xec, 0x44, 0x75, 0x75, 0x43, 0x9a, + 0xc5, 0x0f, 0xed, 0xde, 0xed, 0x24, 0xd9, 0x10, + 0x62, 0xc8, 0xf8, 0x04, 0x56, 0xec, 0x46, 0x42, + 0x96, 0x15, 0xcb, 0x17, 0x5a, 0xc4, 0x38, 0xb1, + 0x22, 0xe8, 0xa1, 0x48, 0xc8, 0xe1, 0x92, 0xae, + 0x09, 0xd1, 0x34, 0xf3, 0x03, 0x9b, 0xd1, 0xb7, + 0x22, 0x05, 0x89, 0x29, 0x0e, 0xb9, 0x11, 0xf1, + 0x12, 0x14, 0x01, 0x8c, 0x0c, 0xa9, 0x3c, 0xcc, + 0x5e, 0x23, 0xec, 0x28, 0x0a, 0x67, 0x57, 0x36, + 0x0e, 0x28, 0x39, 0x22, 0x11, 0x71, 0xda, 0xbf, + 0x91, 0x7d, 0xd2, 0x85, 0xd7, 0x0c, 0xc6, 0x01, + 0x3d, 0x2b, 0xda, 0xcb, 0x52, 0x23, 0x88, 0x56, + 0xec, 0xe8, 0xc6, 0x20, 0x44, 0x4f, 0x8a, 0x14, + 0x12, 0x50, 0xc5, 0x12, 0xe4, 0x4c, 0xa4, 0xe7, + 0x46, 0x9a, 0x66, 0x72, 0x36, 0xde, 0x8e, 0x7e, + 0xc9, 0x50, 0x14, 0xf4, 0x5a, 0x12, 0x55, 0xa1, + 0x5d, 0x24, 0x22, 0x82, 0xc9, 0x51, 0xcb, 0xde, + 0x02, 0xc0, 0xa7, 0xa2, 0x92, 0x35, 0x44, 0x46, + 0x85, 0x11, 0x28, 0x30, 0x51, 0xa4, 0x43, 0x41, + 0x85, 0xe0, 0xe0, 0xae, 0xf5, 0x09, 0x06, 0x99, + 0x2f, 0x31, 0x99, 0x16, 0xc2, 0xc9, 0xc0, 0xd3, + 0xa3, 0x28, 0x43, 0xda, 0xbf, 0x9b, 0xe8, 0x1d, + 0xdb, 0xf5, 0xd0, 0x16, 0x60, 0x67, 0x49, 0x10, + 0xde, 0x9d, 0x9e, 0x14, 0x8c, 0x51, 0x82, 0xc0, + 0xd0, 0xa9, 0x55, 0x18, 0x5a, 0xd5, 0xb2, 0xd2, + 0xb9, 0xcd, 0x59, 0x65, 0xcd, 0xd4, 0x08, 0x14, + 0x41, 0x83, 0x9c, 0xdd, 0x5d, 0xfa, 0x6b, 0x29, + 0x05, 0xcb, 0x52, 0x32, 0x07, 0x06, 0x24, 0xe6, + 0xaf, 0xe9, 0x48, 0xa5, 0x45, 0x3a, 0x48, 0x0e, + 0x20, 0x5e, 0x70, 0x17, 0xba, 0x75, 0x69, 0x48, + 0x47, 0x1d, 0x36, 0x0e, 0x17, 0x11, 0x6e, 0xea, + 0x34, 0x63, 0x35, 0x86, 0x92, 0x5b, 0xa6, 0xa9, + 0x2c, 0xe8, 0x38, 0x16, 0x02, 0xa5, 0x59, 0xd1, + 0x75, 0x7b, 0xde, 0x70, 0x1f, 0xbe, 0x00, 0x3f, + 0xfa, 0xfa, 0xce, 0x9a, 0x90, 0x51, 0xe4, 0xea, + 0x0c, 0x22, 0x99, 0x57, 0x34, 0x4d, 0x57, 0xa3, + 0x8f, 0x86, 0xca, 0x0f, 0xdb, 0x6d, 0x37, 0x50, + 0x4a, 0xe5, 0x5b, 0x6a, 0xd8, 0xbf, 0x65, 0xec, + 0xd7, 0x2b, 0xb5, 0xff, 0x61, 0xc7, 0xe9, 0x7b, + 0xd3, 0x96, 0xcc, 0x9c, 0x5a, 0xb7, 0xed, 0x41, + 0x38, 0x73, 0x46, 0x53, 0x75, 0x6b, 0xfd, 0x30, + 0xd7, 0x84, 0xaf, 0xd3, 0x32, 0x07, 0x95, 0xfc, + 0x73, 0x5a, 0x1b, 0xf9, 0x42, 0x99, 0x03, 0x8e, + 0x10, 0xcc, 0xa0, 0xe1, 0xa0, 0xc4, 0x10, 0x8b, + 0xf7, 0xe3, 0xdc, 0xf0, 0x7d, 0x71, 0x4e, 0x7e, + 0x5d, 0xb4, 0x36, 0x14, 0x28, 0x83, 0x03, 0x00, + 0x58, 0x82, 0xc0, 0xfa, 0x7f, 0x39, 0x51, 0x9e, + 0x89, 0xbb, 0x20, 0xcd, 0x12, 0x01, 0x3d, 0xaf, + 0x50, 0x83, 0x85, 0xe8, 0x8a, 0x05, 0x29, 0xaf, + 0x4e, 0xe8, 0x84, 0x31, 0x08, 0x8c, 0x3f, 0xa7, + 0x22, 0xf5, 0x88, 0xea, 0x83, 0xba, 0x18, 0x0a, + 0xf4, 0x92, 0xa1, 0x44, 0x0e, 0x44, 0x12, 0x6a, + 0x0e, 0x90, 0x1c, 0x7a, 0xa0, 0x21, 0xa9, 0xb5, + 0xd1, 0x83, 0xba, 0x6d, 0x08, 0x4d, 0xdf, 0x97, + 0x35, 0x22, 0x30, 0x72, 0x03, 0xbf, 0x88, 0xc0, + 0x72, 0xe0, 0x38, 0x29, 0x9d, 0x34, 0xbd, 0x0a, + 0x34, 0xdf, 0x91, 0xf0, 0xa4, 0x53, 0x39, 0x09, + 0x2a, 0x30, 0x73, 0xdf, 0x91, 0xc4, 0x00, 0xe5, + 0xa7, 0x01, 0x39, 0xf9, 0x11, 0xa0, 0x8a, 0xbe, + 0x2f, 0xaa, 0x31, 0x90, 0xcc, 0x31, 0x27, 0xfd, + 0x34, 0xb1, 0xcf, 0x01, 0xfd, 0x7f, 0xff, 0xd2, + 0x74, 0xa0, 0x1d, 0x4a, 0x4e, 0x59, 0x0e, 0xe9, + 0xb4, 0x05, 0x00, 0xe3, 0x44, 0xf8, 0x31, 0x05, + 0xd3, 0x8b, 0x21, 0x7e, 0x5c, 0x1c, 0x03, 0xc1, + 0x3d, 0x51, 0x14, 0x0a, 0xea, 0x78, 0xa0, 0x31, + 0x09, 0x64, 0x1c, 0x12, 0xbe, 0x1b, 0x80, 0xe2, + 0x0c, 0x8b, 0x84, 0x85, 0x20, 0xb0, 0x09, 0x18, + 0x28, 0xd3, 0xe0, 0xe4, 0x20, 0xe0, 0x4d, 0xf6, + 0x9a, 0x07, 0x06, 0x4f, 0x60, 0xe4, 0x46, 0xdf, + 0xc6, 0x22, 0xe0, 0xc0, 0x28, 0xe2, 0x32, 0x0d, + 0x3f, 0xde, 0x00, 0xe0, 0x92, 0x01, 0x79, 0x54, + 0x6e, 0xec, 0xba, 0x02, 0x1a, 0x6c, 0xfc, 0x5f, + 0x8b, 0xc0, 0x77, 0x4f, 0x4a, 0x03, 0x61, 0x1b, + 0x50, 0x83, 0x84, 0x5f, 0xa3, 0x31, 0x45, 0xc5, + 0x81, 0xd4, 0xee, 0x9c, 0xda, 0x48, 0x31, 0xe2, + 0x32, 0x8a, 0xe2, 0xd2, 0x5b, 0xb7, 0x68, 0xcb, + 0x0d, 0x12, 0xa2, 0x42, 0x14, 0x65, 0xcd, 0x03, + 0x83, 0x20, 0x9d, 0x0e, 0x0b, 0x82, 0x96, 0xb4, + 0x64, 0xed, 0x34, 0xf9, 0xb5, 0x0d, 0x80, 0xfd, + 0xb0, 0x01, 0xd6, 0x62, 0x8d, 0x5d, 0x1d, 0x29, + 0xa1, 0x80, 0x66, 0x32, 0x7f, 0xe9, 0xb1, 0x33, + 0x17, 0x1a, 0x87, 0x59, 0x72, 0x0a, 0xba, 0x7a, + 0x88, 0x92, 0xf1, 0xf8, 0x31, 0x07, 0x40, 0x8f, + 0x12, 0xa0, 0x45, 0x3a, 0x88, 0x1c, 0x11, 0x30, + 0x72, 0xe4, 0x5a, 0x83, 0x61, 0x3c, 0x4e, 0xaa, + 0x00, 0xc9, 0x19, 0xf6, 0xb0, 0x38, 0x07, 0x04, + 0x93, 0x46, 0x62, 0x66, 0xb0, 0x2c, 0x08, 0xea, + 0x95, 0xc1, 0x3f, 0x48, 0x99, 0x3a, 0x8e, 0xf4, + 0xd2, 0xc0, 0xe0, 0xc4, 0x69, 0x34, 0x1e, 0x82, + 0x00, 0x30, 0x71, 0x4b, 0xdb, 0x0c, 0x45, 0x29, + 0xda, 0x4d, 0xa7, 0xf9, 0xde, 0x74, 0x5c, 0x0b, + 0xa4, 0xfc, 0xa6, 0xfc, 0x3d, 0x51, 0xc9, 0xf0, + 0xf3, 0x88, 0xcd, 0x4e, 0xd3, 0x60, 0xbb, 0xf3, + 0xaa, 0x17, 0xe4, 0xa2, 0xe0, 0x71, 0xf8, 0x8b, + 0x5c, 0x86, 0xa8, 0x3b, 0xa7, 0x64, 0x1a, 0x69, + 0x8e, 0x01, 0x14, 0x49, 0x41, 0x3c, 0x08, 0xd0, + 0x18, 0x07, 0xb9, 0x1c, 0x4e, 0x25, 0xd4, 0x71, + 0x80, 0x7d, 0x8f, 0xff, 0x52, 0xdd, 0x36, 0x14, + 0xd7, 0x4d, 0x38, 0xba, 0x36, 0x5a, 0x18, 0xa9, + 0xd2, 0x91, 0xda, 0x1f, 0xb5, 0x90, 0xa1, 0x71, + 0x7f, 0x48, 0x28, 0x19, 0x7a, 0x8c, 0xbc, 0x61, + 0xc8, 0x12, 0x7e, 0xae, 0x15, 0x60, 0xc8, 0x4d, + 0xe6, 0xea, 0x20, 0xc0, 0x13, 0x75, 0xe9, 0x52, + 0xaf, 0x74, 0x3d, 0xd6, 0x6d, 0xa2, 0xba, 0x69, + 0x32, 0xa4, 0x77, 0x65, 0x3d, 0x2b, 0x50, 0x75, + 0x05, 0xd5, 0xee, 0x1f, 0x55, 0xca, 0xd1, 0xbf, + 0x5e, 0x59, 0xbe, 0x06, 0x24, 0xc3, 0xe9, 0xff, + 0xeb, 0x20, 0x39, 0x41, 0xda, 0x80, 0x75, 0x07, + 0x0d, 0x56, 0x02, 0xe7, 0xaf, 0xa0, 0xcc, 0x8b, + 0x4e, 0x65, 0x91, 0x12, 0xc3, 0x49, 0x52, 0xe7, + 0x59, 0xa5, 0x01, 0x47, 0x2d, 0x06, 0x14, 0x4e, + 0x6a, 0x3a, 0x76, 0x2e, 0xbf, 0xfe, 0xd7, 0xc1, + 0x8d, 0xfa, 0xd4, 0x44, 0x27, 0x3e, 0x5a, 0x25, + 0xb0, 0xc5, 0x51, 0xd3, 0x54, 0xb2, 0xab, 0xf0, + 0x3c, 0x64, 0x01, 0xad, 0xb7, 0x8b, 0x85, 0x63, + 0x16, 0x67, 0x95, 0xc0, 0x64, 0x3e, 0xd9, 0x62, + 0x14, 0x41, 0x29, 0x6f, 0x5b, 0xc5, 0xba, 0x84, + 0xd0, 0xc4, 0x2b, 0x4d, 0x8a, 0x01, 0xd2, 0xe0, + 0x0f, 0x76, 0x9a, 0x02, 0x40, 0xed, 0xa1, 0x2e, + 0x37, 0x7d, 0x8c, 0xe4, 0xf5, 0x90, 0x15, 0xad, + 0x6b, 0x48, 0x10, 0x29, 0x40, 0xb1, 0x01, 0x1d, + 0xc3, 0x5c, 0x07, 0x1f, 0x24, 0xab, 0x4a, 0x90, + 0x14, 0x82, 0xc0, 0x27, 0x8d, 0x44, 0x18, 0x12, + 0x05, 0x1a, 0x24, 0x1c, 0x34, 0xbf, 0x42, 0xbd, + 0x3b, 0x15, 0x6d, 0x07, 0x12, 0x0b, 0x9e, 0xac, + 0x0c, 0x81, 0xcf, 0xf6, 0x03, 0xd0, 0x40, 0x06, + 0x30, 0x20, 0x61, 0x4e, 0x9d, 0x8c, 0xf8, 0x26, + 0x84, 0x43, 0x33, 0x74, 0x1c, 0x0b, 0xec, 0xb9, + 0x36, 0x41, 0x45, 0x5a, 0x28, 0xb9, 0xcd, 0x3f, + 0x9d, 0x2d, 0x80, 0xe9, 0x01, 0xc2, 0xfa, 0x34, + 0xde, 0x07, 0x1b, 0x73, 0xc1, 0xb8, 0xcf, 0xa5, + 0x23, 0x56, 0xd7, 0x41, 0xc8, 0xf8, 0x14, 0xe7, + 0x2a, 0xf0, 0x52, 0x0e, 0x0a, 0x3c, 0x43, 0x7a, + 0x8c, 0x4f, 0x89, 0x41, 0xd4, 0x13, 0x7d, 0xa0, + 0xe0, 0xc8, 0x89, 0xaa, 0x03, 0xd1, 0x3f, 0x3b, + 0xd2, 0x40, 0x71, 0xd6, 0x37, 0x01, 0xfc, 0x05, + 0xd3, 0x84, 0x39, 0x09, 0x03, 0x23, 0xa1, 0x1e, + 0x9e, 0x19, 0x83, 0x06, 0x41, 0x57, 0x07, 0x0c, + 0x09, 0x4f, 0x63, 0xfc, 0x66, 0xb8, 0x38, 0xf2, + 0xf0, 0x17, 0x71, 0x3c, 0x32, 0x0a, 0xba, 0x28, + 0x81, 0x72, 0x40, 0x5c, 0x35, 0xa9, 0x0b, 0x07, + 0x02, 0x6a, 0x12, 0x11, 0xe9, 0xea, 0x0e, 0x01, + 0xe0, 0xb8, 0xe8, 0x81, 0xc2, 0x8d, 0x46, 0x42, + 0x9c, 0x0f, 0x43, 0xff, 0xff, 0x02, 0x76, 0x22, + 0xa9, 0xcd, 0x07, 0x52, 0x3e, 0x0e, 0x04, 0xea, + 0xa0, 0xf3, 0xd0, 0x01, 0x83, 0x88, 0x9a, 0xe8, + 0xd1, 0x92, 0x03, 0x81, 0x3e, 0xf6, 0x54, 0x5d, + 0x58, 0x4d, 0x17, 0x66, 0xc3, 0x10, 0x5c, 0xf0, + 0xcc, 0x1c, 0x12, 0x3a, 0xe9, 0x05, 0x80, 0x54, + 0xc8, 0xc1, 0xd7, 0xa7, 0xaa, 0xf5, 0xd8, 0x6d, + 0x68, 0x8a, 0xba, 0x39, 0xc4, 0x08, 0xc8, 0x2c, + 0x07, 0x83, 0x84, 0xf5, 0x79, 0xa8, 0x45, 0xcb, + 0x82, 0xc3, 0x83, 0x17, 0xa6, 0x48, 0x48, 0x27, + 0xd3, 0xc2, 0xe1, 0x3f, 0x07, 0x04, 0xcc, 0x65, + 0xd0, 0xc8, 0x28, 0xc0, 0xe2, 0x40, 0x5c, 0x5b, + 0x38, 0x0b, 0xba, 0xbf, 0xa5, 0x72, 0x72, 0xca, + 0x8d, 0x1a, 0x21, 0x75, 0x8b, 0x13, 0xf2, 0x99, + 0x67, 0x10, 0x51, 0x81, 0x07, 0x15, 0x60, 0x75, + 0x58, 0x2a, 0xb6, 0x9e, 0xd3, 0xca, 0x54, 0xc5, + 0x8a, 0x41, 0xce, 0x65, 0x24, 0x4d, 0x15, 0x45, + 0xd0, 0xc0, 0x5c, 0x0b, 0xcc, 0xb1, 0xb1, 0x8f, + 0x20, 0x60, 0x13, 0x34, 0xee, 0x14, 0xbf, 0x5e, + 0x77, 0x4d, 0x03, 0xa0, 0x2c, 0x42, 0x6d, 0x2d, + 0xa7, 0x97, 0x2f, 0x98, 0xdb, 0x5c, 0x2d, 0xd5, + 0xd1, 0x77, 0xa8, 0x2e, 0x5e, 0x73, 0x81, 0x2d, + 0xef, 0xb1, 0xa5, 0x38, 0x38, 0xb9, 0x56, 0xec, + 0xd6, 0xb7, 0x64, 0x24, 0x41, 0x6a, 0x2a, 0x71, + 0x3d, 0x04, 0x5a, 0x28, 0xa9, 0x99, 0xd6, 0x49, + 0x01, 0xc4, 0x16, 0x20, 0xe8, 0xa0, 0xe5, 0x63, + 0xe8, 0x53, 0xe9, 0x2f, 0x14, 0x03, 0xb8, 0x35, + 0xa0, 0x44, 0x82, 0x2f, 0xdb, 0xd8, 0x1b, 0xeb, + 0xd0, 0x3c, 0x58, 0x3d, 0x19, 0x16, 0x1d, 0xd7, + 0xb5, 0x1b, 0x60, 0x54, 0xaf, 0xfd, 0xb4, 0x38, + 0xd7, 0x7a, 0xc2, 0xa0, 0x62, 0x49, 0x2a, 0xf5, + 0x61, 0x33, 0xfa, 0x25, 0xa7, 0xbc, 0x16, 0x27, + 0x7d, 0xd4, 0x3f, 0x76, 0xba, 0xbf, 0xcc, 0xb3, + 0x9d, 0xdc, 0xd9, 0xc3, 0xd5, 0x3e, 0xd2, 0x0b, + 0xfc, 0xb6, 0x58, 0xe8, 0x80, 0x52, 0x06, 0x07, + 0xb5, 0xfd, 0x15, 0xb1, 0x6e, 0x5e, 0xf4, 0xb3, + 0x76, 0x0a, 0xb5, 0xea, 0xfe, 0x4f, 0xd9, 0xe1, + 0xc2, 0x76, 0xbb, 0x02, 0xd9, 0x1e, 0x0f, 0x77, + 0xab, 0x4f, 0x79, 0xb5, 0x8c, 0xd2, 0xdc, 0x42, + 0x27, 0xef, 0xf5, 0x4e, 0x60, 0x31, 0xa9, 0x4d, + 0x54, 0x47, 0xf5, 0xdb, 0x4d, 0x25, 0xec, 0xee, + 0x7d, 0x56, 0x5b, 0x78, 0x2b, 0xd1, 0x25, 0xc4, + 0x75, 0x96, 0xf9, 0xc8, 0x08, 0xce, 0xfb, 0x9f, + 0xe2, 0xf3, 0x1f, 0x6d, 0xb5, 0xb6, 0x21, 0x95, + 0x01, 0xf4, 0xca, 0x8a, 0x87, 0xbb, 0x20, 0x49, + 0x53, 0x2e, 0x5c, 0xa9, 0xa8, 0x5e, 0xc3, 0x74, + 0xb4, 0xa9, 0x96, 0xb4, 0x3b, 0xf8, 0x73, 0x05, + 0x6b, 0x37, 0x79, 0x4a, 0x78, 0x2f, 0x82, 0x75, + 0xd3, 0x2b, 0x03, 0x6a, 0xda, 0x54, 0xc4, 0xfd, + 0xd6, 0xff, 0xef, 0x65, 0xe7, 0x17, 0xba, 0xb5, + 0x5c, 0xc9, 0xa8, 0x9a, 0x8f, 0x9a, 0x61, 0x8a, + 0xce, 0xa7, 0xdc, 0xc0, 0x2f, 0xf4, 0x21, 0x9a, + 0xc6, 0x85, 0x43, 0x2c, 0xe0, 0xca, 0x93, 0x69, + 0xae, 0x5d, 0x7b, 0xe3, 0x6b, 0x82, 0x71, 0x4a, + 0x8a, 0x91, 0xf1, 0x28, 0x3a, 0xbd, 0x05, 0xac, + 0x15, 0x22, 0xea, 0x04, 0x0e, 0xc8, 0xa2, 0xee, + 0xf4, 0x1c, 0x52, 0x0e, 0x40, 0x15, 0x4d, 0x8b, + 0x03, 0xa0, 0x0f, 0xe9, 0x1a, 0x0b, 0x43, 0x61, + 0x85, 0x39, 0xa6, 0x41, 0x78, 0x4b, 0x78, 0x88, + 0xf6, 0x9c, 0xf5, 0x70, 0x77, 0x02, 0x2c, 0x0f, + 0x4f, 0x00, 0x18, 0xd2, 0xc7, 0x08, 0x41, 0xc1, + 0x88, 0x4d, 0x40, 0xc7, 0x99, 0x19, 0x1e, 0x9e, + 0xf2, 0xd6, 0x02, 0xc7, 0x80, 0xe1, 0x93, 0xf7, + 0x91, 0x8c, 0x85, 0x73, 0x1a, 0x5c, 0xfc, 0x22, + 0x74, 0xa7, 0xb4, 0xd8, 0x39, 0x18, 0x4b, 0x97, + 0x01, 0xe8, 0xc1, 0x3f, 0xa2, 0x07, 0xf5, 0x80, + 0x0f, 0xf4, 0x13, 0x35, 0x02, 0xad, 0x7d, 0x20, + 0xc0, 0x1c, 0x14, 0xfa, 0x32, 0xef, 0x41, 0xc3, + 0x56, 0x19, 0x23, 0x21, 0x62, 0xe7, 0xf2, 0x02, + 0xeb, 0x4d, 0x83, 0x8a, 0x41, 0xc3, 0x07, 0x30, + 0x73, 0xf4, 0xea, 0x23, 0x40, 0xe0, 0x9d, 0xae, + 0x4a, 0x32, 0x05, 0xc4, 0xe9, 0x2f, 0x5d, 0xae, + 0xc1, 0xc5, 0x34, 0x51, 0x22, 0xad, 0xc0, 0x75, + 0xbc, 0x07, 0x1e, 0xb3, 0x47, 0xb7, 0x54, 0xf8, + 0x39, 0xcd, 0x08, 0x3a, 0x80, 0xea, 0x13, 0xb5, + 0xc1, 0xcb, 0x84, 0xac, 0x9b, 0x29, 0x0a, 0x34, + 0xfa, 0xe4, 0x83, 0x1a, 0x0e, 0x26, 0x90, 0x72, + 0xeb, 0x03, 0xa0, 0xd7, 0x23, 0xa1, 0x92, 0xc0, + 0xb1, 0x39, 0xd1, 0x03, 0x83, 0x32, 0x78, 0x09, + 0xf5, 0x7f, 0x17, 0x37, 0xd5, 0xa2, 0x31, 0xad, + 0xa2, 0xe8, 0x48, 0xa3, 0x3e, 0x6f, 0xec, 0x75, + 0xb6, 0xb3, 0xf2, 0xcb, 0x9a, 0x0e, 0xe0, 0x48, + 0x36, 0x08, 0x23, 0xe4, 0xa9, 0xd8, 0x5b, 0x6b, + 0x1b, 0x38, 0xdf, 0xbb, 0xc4, 0x7d, 0x86, 0x53, + 0x14, 0x44, 0x47, 0xf5, 0xf5, 0xca, 0x32, 0x17, + 0x86, 0x63, 0x43, 0x09, 0xeb, 0x06, 0x93, 0xfa, + 0xde, 0x08, 0xb1, 0x0c, 0x5a, 0xf4, 0x26, 0x1b, + 0xab, 0x12, 0xd5, 0x6e, 0xd2, 0xcc, 0x56, 0xc3, + 0x1f, 0xa6, 0xcd, 0x10, 0x18, 0x1e, 0x25, 0x65, + 0xb6, 0xf7, 0x7d, 0x1a, 0x56, 0x95, 0x8b, 0x22, + 0xdd, 0x18, 0x74, 0xe1, 0x53, 0xb0, 0x6f, 0xc1, + 0x5e, 0xb9, 0xe1, 0x1e, 0x17, 0x37, 0xe5, 0xbe, + 0x9f, 0x06, 0xf8, 0xb9, 0x49, 0x09, 0x94, 0xf7, + 0xfa, 0x88, 0x40, 0xde, 0x0d, 0xe5, 0xa4, 0xab, + 0x82, 0x4f, 0x48, 0x97, 0x8b, 0x45, 0x17, 0x31, + 0x4c, 0xd2, 0x81, 0x5a, 0x7b, 0x7d, 0x3a, 0xbb, + 0x02, 0x07, 0xfa, 0xf3, 0x1b, 0xcb, 0x56, 0xc5, + 0x0a, 0x62, 0x37, 0x6b, 0xab, 0xff, 0xde, 0x61, + 0x68, 0x1a, 0x6e, 0xf6, 0xc2, 0xb5, 0x91, 0x20, + 0x07, 0x05, 0x6a, 0x6e, 0x6e, 0xd8, 0xa3, 0x9c, + 0x80, 0x3c, 0x4e, 0x8c, 0xc6, 0x96, 0xef, 0x73, + 0x35, 0x08, 0x26, 0x2a, 0xdb, 0x0c, 0x2f, 0xdb, + 0x3d, 0xb3, 0x94, 0xf9, 0x72, 0xe4, 0x25, 0xca, + 0x41, 0xa6, 0x66, 0x83, 0x51, 0xfe, 0xf0, 0xb3, + 0xd7, 0x0a, 0x40, 0x77, 0x02, 0x7a, 0xa2, 0x18, + 0x43, 0x66, 0x22, 0xcb, 0x3a, 0x1c, 0x40, 0x70, + 0x26, 0xa7, 0x02, 0x09, 0x7d, 0x46, 0xd2, 0xab, + 0x41, 0x83, 0x41, 0x79, 0x1a, 0x30, 0x0f, 0xab, + 0x06, 0x0e, 0x18, 0xa0, 0xc0, 0x48, 0x23, 0xf2, + 0x06, 0xd0, 0x64, 0xfd, 0xfe, 0x5c, 0xd7, 0xed, + 0x2b, 0x53, 0xbb, 0x79, 0x0c, 0x49, 0x71, 0x70, + 0x37, 0x34, 0x7b, 0x77, 0xab, 0xa3, 0x80, 0xa6, + 0x89, 0xd7, 0x07, 0x8a, 0x80, 0x24, 0x2d, 0x4f, + 0x3c, 0xba, 0xe7, 0x4a, 0x35, 0x22, 0x4d, 0x4f, + 0x8b, 0xef, 0x10, 0x87, 0xda, 0xdc, 0xe2, 0x00, + 0x21, 0x5f, 0xdb, 0xb4, 0xdc, 0x19, 0xba, 0x11, + 0x26, 0x9d, 0x53, 0x50, 0x41, 0xad, 0x73, 0x50, + 0x85, 0x2f, 0x77, 0x50, 0x65, 0xa3, 0x20, 0x71, + 0x35, 0x71, 0x2e, 0xad, 0x8d, 0x6c, 0x17, 0x06, + 0x67, 0xaa, 0xdc, 0x5d, 0x6a, 0x6d, 0x49, 0xdd, + 0x7f, 0x32, 0xae, 0x8e, 0x04, 0x95, 0xb2, 0x71, + 0x7e, 0x2d, 0x0e, 0xc1, 0x70, 0x7f, 0x35, 0x7f, + 0x60, 0x73, 0x06, 0x11, 0xf0, 0xa8, 0x7d, 0xb2, + 0x87, 0xbf, 0x6d, 0x07, 0xa4, 0x0d, 0x0f, 0x99, + 0xc5, 0x3c, 0xe0, 0x66, 0x0e, 0x9d, 0x3f, 0xa6, + 0xae, 0xa7, 0x6b, 0x16, 0x47, 0x43, 0x87, 0x3e, + 0x17, 0xb6, 0x36, 0x68, 0x71, 0x00, 0x8b, 0x37, + 0x83, 0x08, 0x8c, 0x29, 0x2c, 0xd2, 0x46, 0x98, + 0x1b, 0x2a, 0xe1, 0x2c, 0x46, 0x31, 0xe0, 0x5b, + 0x1c, 0x86, 0xb0, 0x67, 0xd1, 0x7b, 0xe5, 0xe1, + 0xa0, 0xa3, 0x5d, 0x04, 0xc3, 0xe1, 0xeb, 0x50, + 0x15, 0xbf, 0xfc, 0x8b, 0x66, 0x4a, 0x85, 0x47, + 0x69, 0x16, 0x62, 0x2a, 0xff, 0xff, 0x7c, 0xa1, + 0x49, 0x5d, 0xde, 0x44, 0x60, 0xe2, 0x0b, 0xba, + 0x1a, 0xf2, 0x11, 0x56, 0x36, 0x85, 0x03, 0xe2, + 0x9f, 0xe4, 0x24, 0x14, 0xeb, 0xdd, 0xd6, 0x2b, + 0x5c, 0x9b, 0x9c, 0x85, 0x72, 0xae, 0x86, 0x74, + 0x89, 0x74, 0xfb, 0x6a, 0x0b, 0xee, 0xa3, 0x18, + 0xae, 0x47, 0x1c, 0xb0, 0xa6, 0x93, 0x44, 0xcb, + 0xd2, 0x51, 0x33, 0xf5, 0x4a, 0x90, 0x58, 0xba, + 0xa6, 0x50, 0x48, 0x60, 0xb1, 0x95, 0x4a, 0xc7, + 0x3c, 0xd6, 0x99, 0x9f, 0x51, 0xec, 0x61, 0x42, + 0xc8, 0x3b, 0xf6, 0xda, 0xc4, 0x4b, 0x53, 0x4b, + 0x1c, 0x44, 0x3f, 0x69, 0x2e, 0x79, 0xb6, 0xb6, + 0x55, 0xa7, 0x62, 0x9c, 0xd5, 0x14, 0xd5, 0xad, + 0x7f, 0x72, 0x89, 0xa0, 0x0c, 0xa2, 0xea, 0xc2, + 0x80, 0xd8, 0x3e, 0x11, 0xc4, 0x94, 0x9e, 0x1c, + 0x31, 0x18, 0x51, 0xde, 0xf0, 0x70, 0x7e, 0xee, + 0x16, 0x95, 0xa9, 0x2b, 0x0a, 0xa2, 0xeb, 0x25, + 0xa5, 0x55, 0x11, 0xb1, 0x49, 0xa6, 0xba, 0x4a, + 0x48, 0x1c, 0x00, 0xf0, 0xa0, 0x88, 0xf5, 0xbc, + 0xc9, 0x6f, 0x70, 0x3d, 0x93, 0xa7, 0x91, 0xd6, + 0x3d, 0x03, 0x8f, 0xfe, 0x8b, 0xd6, 0x05, 0xc1, + 0x76, 0x96, 0x6e, 0x83, 0xce, 0xff, 0xfb, 0xc3, + 0xda, 0xf0, 0xa1, 0x65, 0x97, 0xa2, 0x8b, 0xbf, + 0xa5, 0x10, 0x89, 0x02, 0xce, 0x23, 0x2d, 0xb2, + 0x55, 0x0e, 0x4f, 0x53, 0x78, 0xdf, 0xf7, 0x3d, + 0xab, 0x14, 0xbf, 0xc8, 0x0a, 0xe8, 0xfd, 0x79, + 0xb0, 0xa4, 0xa4, 0x1c, 0x41, 0x13, 0x64, 0x46, + 0x28, 0x4c, 0xb3, 0x24, 0x02, 0xba, 0x58, 0x50, + 0x14, 0xa7, 0x67, 0x35, 0x7e, 0xf2, 0xa2, 0x7b, + 0xb6, 0x0c, 0x33, 0xa8, 0x4e, 0xeb, 0xee, 0x74, + 0xb6, 0x03, 0xb8, 0x0b, 0x01, 0x71, 0x0d, 0x65, + 0x91, 0x7a, 0x0e, 0x05, 0x8f, 0x68, 0x48, 0x96, + 0x31, 0xb0, 0x39, 0xcc, 0xd4, 0x41, 0x4c, 0xec, + 0xfa, 0x22, 0xbc, 0xb5, 0x09, 0x07, 0x36, 0x77, + 0x8b, 0xe0, 0xaf, 0x5f, 0x58, 0xb1, 0xb9, 0x49, + 0x4d, 0x3b, 0xca, 0x87, 0xb6, 0x70, 0x92, 0x82, + 0xf1, 0xe5, 0xe8, 0xdb, 0x7b, 0x65, 0x2c, 0xd8, + 0xf1, 0x84, 0x08, 0x7f, 0x67, 0xf0, 0x40, 0x69, + 0x24, 0xd4, 0x6b, 0x53, 0x7c, 0x74, 0x9d, 0xe8, + 0x88, 0x2b, 0xab, 0xba, 0x49, 0xc4, 0x34, 0x55, + 0x81, 0x60, 0x0b, 0xb3, 0xc2, 0x30, 0x22, 0xa9, + 0xee, 0x82, 0x2b, 0x3a, 0x0b, 0x00, 0x5c, 0x6c, + 0x95, 0x04, 0xe5, 0xef, 0x46, 0x22, 0x74, 0x98, + 0x52, 0x2a, 0xd7, 0x6f, 0x68, 0x11, 0x85, 0x29, + 0xfd, 0xbd, 0x28, 0xc8, 0x4f, 0xb6, 0xde, 0x41, + 0x13, 0x17, 0x46, 0x46, 0xca, 0x3e, 0x69, 0xd5, + 0x3f, 0xde, 0x02, 0x69, 0x86, 0x47, 0xe3, 0xe6, + 0x03, 0xb6, 0x7d, 0x00, 0x9f, 0x68, 0xc1, 0x1b, + 0xd4, 0xd2, 0xf5, 0x7b, 0x2d, 0x6d, 0xb6, 0x74, + 0x09, 0xff, 0x46, 0x5c, 0x87, 0x15, 0x53, 0xd4, + 0x1a, 0x30, 0xe0, 0x60, 0x31, 0x0a, 0xf5, 0x03, + 0x38, 0x49, 0x0e, 0x6b, 0x9d, 0x12, 0x62, 0xaf, + 0xe1, 0x57, 0xd2, 0xb0, 0xb5, 0x86, 0x0f, 0x36, + 0x3b, 0x4c, 0xda, 0xcd, 0x46, 0x1b, 0xef, 0x0b, + 0x46, 0x07, 0xf6, 0x23, 0x41, 0x42, 0x69, 0xcb, + 0x91, 0x07, 0xaf, 0x78, 0xb9, 0x21, 0x20, 0x9c, + 0xb5, 0x00, 0x4c, 0x13, 0x35, 0xcf, 0x17, 0x08, + 0x62, 0x5e, 0xb6, 0x05, 0xb3, 0xd9, 0x28, 0x78, + 0x0c, 0x2f, 0x21, 0x32, 0x21, 0x30, 0xad, 0x4c, + 0xb6, 0xa5, 0x56, 0xda, 0xdc, 0x46, 0x4d, 0x3a, + 0xa6, 0x2d, 0xcb, 0x94, 0x16, 0x26, 0xc1, 0x75, + 0x0b, 0x8a, 0x6f, 0xf4, 0xaa, 0x0d, 0x9d, 0xae, + 0xb8, 0xf8, 0x78, 0x3c, 0x5d, 0x4f, 0xd5, 0x35, + 0x3a, 0x57, 0xd2, 0x97, 0xce, 0x79, 0x80, 0x24, + 0x0e, 0xed, 0x3e, 0x58, 0x39, 0x90, 0x16, 0x00, + 0x9d, 0x45, 0x74, 0x65, 0xc0, 0x1c, 0x48, 0x43, + 0xc4, 0x7d, 0xe6, 0xf4, 0x9b, 0x5e, 0x61, 0x6a, + 0xeb, 0x74, 0xd2, 0xc0, 0x9a, 0x9b, 0x3b, 0xb3, + 0x0d, 0x5b, 0xc0, 0x5d, 0x65, 0xba, 0x4a, 0x32, + 0x19, 0x02, 0xea, 0x7b, 0x21, 0xbb, 0x1f, 0x8c, + 0xce, 0x77, 0x0a, 0x25, 0x8b, 0x83, 0x81, 0x73, + 0x41, 0xf7, 0xa1, 0xb1, 0x9b, 0xfe, 0x4f, 0xc1, + 0x17, 0x51, 0x9b, 0xe1, 0x28, 0x2d, 0xa2, 0x4a, + 0x4b, 0x4d, 0xbc, 0xad, 0x33, 0x4a, 0x27, 0x10, + 0xd2, 0x50, 0x1c, 0xb1, 0x36, 0x50, 0x48, 0x65, + 0x35, 0xf8, 0x88, 0x28, 0x6b, 0x82, 0xc0, 0x1c, + 0x80, 0xa0, 0xfd, 0x5d, 0x17, 0x78, 0x13, 0xeb, + 0xcb, 0x5d, 0x85, 0x08, 0x51, 0x92, 0xf4, 0x1c, + 0xf4, 0xa4, 0xe2, 0x35, 0x9f, 0x08, 0xa9, 0xa4, + 0x08, 0x05, 0x32, 0x6d, 0x16, 0xf1, 0x7b, 0xc1, + 0x92, 0xc7, 0xd7, 0x8b, 0x2c, 0x27, 0xdf, 0x4e, + 0x9a, 0xe6, 0x54, 0x40, 0xe4, 0x21, 0x5a, 0xf9, + 0xc6, 0x24, 0xef, 0x65, 0x07, 0x2e, 0x2b, 0x4d, + 0x4f, 0x2a, 0x09, 0x6c, 0xe8, 0xc7, 0x88, 0x05, + 0xc7, 0x50, 0xb2, 0xde, 0xa2, 0xa1, 0x80, 0x64, + 0x0b, 0xb3, 0x36, 0xcd, 0x26, 0xde, 0x98, 0x8a, + 0xe4, 0x84, 0x17, 0x54, 0x2c, 0x54, 0x0e, 0x18, + 0x38, 0xa6, 0xb5, 0x0a, 0x46, 0x41, 0x2f, 0x1c, + 0x74, 0x80, 0xee, 0xf1, 0x7e, 0x74, 0x29, 0x8b, + 0xd4, 0xdd, 0xb5, 0x64, 0x74, 0x17, 0xcf, 0xcf, + 0xd8, 0x32, 0x34, 0xf9, 0xfc, 0x58, 0x64, 0xb5, + 0x44, 0x0e, 0x34, 0x41, 0x17, 0x15, 0xeb, 0xe0, + 0xa3, 0x49, 0x08, 0x3f, 0xe8, 0xc8, 0x8d, 0x5e, + 0xde, 0xa2, 0xb5, 0x00, 0x3a, 0x05, 0x78, 0xca, + 0x0a, 0xf5, 0xe5, 0x09, 0xb0, 0x5f, 0xea, 0x33, + 0x73, 0xce, 0x12, 0xde, 0x89, 0xa2, 0x49, 0x17, + 0x5a, 0x70, 0x07, 0xc1, 0x3b, 0xf5, 0x4c, 0x58, + 0xf6, 0xbe, 0x51, 0x49, 0x0f, 0xee, 0x8c, 0x11, + 0x03, 0x85, 0x5a, 0x29, 0x35, 0xd3, 0x44, 0x4c, + 0x63, 0x24, 0x0c, 0xc5, 0x2b, 0x2d, 0x9c, 0x46, + 0x50, 0x28, 0xd3, 0x88, 0xc4, 0x34, 0xbb, 0xb0, + 0x81, 0x41, 0x3d, 0xcf, 0x22, 0x58, 0x63, 0x43, + 0x13, 0xd3, 0x70, 0x64, 0x28, 0xc6, 0xcb, 0x90, + 0x6b, 0x9d, 0xd8, 0x38, 0x74, 0xfe, 0xf8, 0xa5, + 0x18, 0x0f, 0x08, 0xa3, 0x76, 0x8c, 0xa0, 0xbc, + 0x85, 0xc8, 0x2f, 0x0a, 0x16, 0x41, 0xc8, 0x3a, + 0x02, 0xe7, 0x5e, 0x03, 0xd2, 0x49, 0xde, 0x53, + 0x5c, 0x5c, 0x85, 0xf0, 0xa5, 0x69, 0x10, 0xf4, + 0x28, 0x65, 0x48, 0x38, 0x52, 0x11, 0x7b, 0x78, + 0x8b, 0x9d, 0x07, 0x04, 0x53, 0x3b, 0xd4, 0x75, + 0x41, 0xdd, 0x7c, 0xb1, 0xb4, 0x43, 0x21, 0x33, + 0xa0, 0xfd, 0xf0, 0x01, 0xee, 0x5e, 0x23, 0xd0, + 0x1e, 0x4c, 0xef, 0x05, 0xe2, 0xe1, 0x47, 0x8b, + 0x21, 0x84, 0x1a, 0x7b, 0xa8, 0x14, 0x03, 0x8e, + 0xb1, 0x5c, 0xf4, 0x92, 0x42, 0x55, 0x86, 0x92, + 0x69, 0x69, 0x42, 0x5b, 0x6a, 0xf1, 0x01, 0x20, + 0x4b, 0xa7, 0x0b, 0x03, 0x82, 0x36, 0x8b, 0xa8, + 0x0d, 0x10, 0xe1, 0x88, 0x38, 0x62, 0x2e, 0x13, + 0xe0, 0x7a, 0x48, 0x00, 0xc6, 0xb3, 0xbd, 0xe8, + 0x49, 0xaf, 0xb8, 0xed, 0x3b, 0x10, 0xa2, 0x15, + 0x4a, 0xd4, 0x30, 0x7e, 0x9c, 0xe9, 0xb0, 0x58, + 0x92, 0x04, 0x8d, 0x2a, 0xc8, 0xcf, 0xe9, 0xcc, + 0x8b, 0xa3, 0x0c, 0x89, 0xf5, 0x9c, 0xe5, 0xc5, + 0x08, 0xca, 0xd4, 0x95, 0x15, 0x21, 0xe2, 0xc8, + 0xc6, 0x93, 0xc2, 0x40, 0x70, 0x62, 0xf7, 0x20, + 0x39, 0x60, 0xaa, 0x5a, 0x48, 0x2e, 0x22, 0xd3, + 0x47, 0x26, 0x2c, 0xb8, 0xc8, 0x88, 0xaf, 0x11, + 0xf0, 0x32, 0x07, 0x02, 0x6c, 0xf1, 0x0f, 0x38, + 0x84, 0x1d, 0x5d, 0x96, 0x07, 0x70, 0x1c, 0x2b, + 0xb9, 0xc2, 0x50, 0x9b, 0x4e, 0x45, 0xe3, 0x25, + 0x8f, 0xee, 0x14, 0x72, 0x2c, 0x68, 0x29, 0x80, + 0x46, 0x58, 0xa1, 0x11, 0x20, 0x38, 0x9b, 0x70, + 0x90, 0x1c, 0x2e, 0x0c, 0x84, 0xcc, 0x7e, 0x27, + 0x2a, 0x16, 0x07, 0x0a, 0x1a, 0x88, 0x0f, 0x41, + 0xff, 0xf8, 0x61, 0x44, 0xd8, 0x60, 0x18, 0x85, + 0x53, 0x03, 0x20, 0x73, 0xa2, 0x07, 0x6b, 0xee, + 0x92, 0xc7, 0x4f, 0x0d, 0xf6, 0xf0, 0x17, 0x1a, + 0x59, 0xde, 0x9b, 0x28, 0x07, 0x04, 0xda, 0xca, + 0x2b, 0x6a, 0x37, 0x58, 0x6b, 0xaf, 0x83, 0x13, + 0x60, 0xe7, 0x6e, 0xc4, 0x48, 0x21, 0x0e, 0x58, + 0x92, 0x83, 0x82, 0x78, 0x8b, 0x23, 0x58, 0xd9, + 0x0d, 0x24, 0x7d, 0xb9, 0x2c, 0x07, 0x2c, 0x0e, + 0x42, 0x09, 0x98, 0xb0, 0xd8, 0x4d, 0x23, 0x10, + 0x70, 0xa7, 0x73, 0x86, 0xc6, 0x0b, 0x04, 0x9f, + 0xfb, 0x56, 0x29, 0x07, 0x23, 0x8f, 0x98, 0x0e, + 0x8f, 0x63, 0x0a, 0x50, 0x76, 0x29, 0x28, 0x26, + 0x3c, 0x5f, 0x02, 0xfb, 0x51, 0x9b, 0xb0, 0x61, + 0xc0, 0x70, 0xbc, 0x17, 0x29, 0xc0, 0xcc, 0x1d, + 0x08, 0x62, 0xca, 0x72, 0xf0, 0xa4, 0xfd, 0x5d, + 0x2c, 0x58, 0xd5, 0x5c, 0x1c, 0x2a, 0x4e, 0xf7, + 0x0a, 0x01, 0xfa, 0xff, 0xff, 0xd5, 0x09, 0xa8, + 0x8c, 0x1c, 0x30, 0x25, 0x09, 0xd3, 0xd9, 0x30, + 0xd3, 0xdb, 0x94, 0x13, 0x74, 0xc8, 0x71, 0x1a, + 0x21, 0x87, 0x43, 0x10, 0x89, 0x5a, 0x6b, 0x91, + 0xd5, 0x66, 0xa0, 0xb0, 0x1c, 0x30, 0x58, 0x64, + 0x15, 0xfe, 0x36, 0x04, 0x7b, 0x4d, 0x23, 0x07, + 0x3a, 0xf1, 0x0a, 0xc2, 0x7d, 0x3b, 0xa1, 0x91, + 0xa4, 0x62, 0x96, 0xb1, 0xae, 0x83, 0xf6, 0xc0, + 0x07, 0xae, 0x6c, 0x11, 0x45, 0xf4, 0x1c, 0x35, + 0x6a, 0x28, 0x39, 0x60, 0x71, 0x1b, 0xf4, 0x39, + 0x44, 0x41, 0xae, 0xf1, 0x07, 0x01, 0xd4, 0x89, + 0xf6, 0x94, 0x1f, 0x7d, 0xab, 0x1b, 0x20, 0xdb, + 0x22, 0x1e, 0xa2, 0x07, 0x09, 0x8b, 0xe3, 0xf4, + 0xda, 0x82, 0x8c, 0x25, 0x01, 0xc0, 0xe2, 0x36, + 0x59, 0xa0, 0xe2, 0x42, 0x82, 0x64, 0x78, 0xb0, + 0x66, 0x0e, 0x59, 0xdd, 0x63, 0x65, 0x0b, 0x02, + 0x6a, 0x8c, 0xc2, 0xad, 0x7a, 0x90, 0xa3, 0xa0, + 0xbd, 0xda, 0x53, 0xd9, 0xd5, 0x82, 0x4f, 0x2c, + 0x37, 0xd8, 0x50, 0x8c, 0xa0, 0x2a, 0x70, 0x5e, + 0x47, 0x4a, 0xa9, 0x28, 0xaf, 0x4f, 0x58, 0x88, + 0x31, 0x29, 0x19, 0x76, 0x8c, 0xc8, 0xbf, 0x0d, + 0xc1, 0x56, 0xe7, 0x0a, 0x05, 0xe5, 0x20, 0xe8, + 0xe6, 0xb0, 0x3b, 0xb7, 0xa0, 0xe1, 0x80, 0xaa, + 0xa0, 0x23, 0xd7, 0x74, 0xd5, 0x01, 0xfc, 0x19, + 0x85, 0x13, 0x01, 0xc1, 0x91, 0x1b, 0xec, 0x28, + 0x80, 0xb1, 0xe2, 0xc7, 0x6a, 0x74, 0x07, 0x2c, + 0x31, 0x15, 0xd8, 0xbd, 0xb7, 0x82, 0xe2, 0x1d, + 0x3c, 0xa2, 0x83, 0x97, 0x09, 0x3a, 0xc0, 0xb1, + 0x34, 0x50, 0x0b, 0x87, 0x6c, 0xc8, 0xa7, 0x6e, + 0x64, 0x37, 0xb7, 0x91, 0x1f, 0x09, 0x0a, 0x38, + 0x34, 0x8c, 0x97, 0x80, 0xe5, 0x8d, 0x94, 0x0a, + 0xd6, 0xe9, 0x24, 0x18, 0xae, 0x34, 0xd7, 0xd2, + 0x94, 0x20, 0x36, 0x34, 0x7c, 0x29, 0xe9, 0xb0, + 0x71, 0x3e, 0xe2, 0x08, 0x69, 0xde, 0x14, 0x8b, + 0xca, 0x01, 0x32, 0x67, 0x64, 0x43, 0x85, 0x07, + 0xf4, 0xdf, 0x04, 0xdb, 0x88, 0x38, 0xb0, 0xbc, + 0x32, 0x44, 0x14, 0x4f, 0x10, 0xa8, 0x34, 0x89, + 0x10, 0x38, 0x28, 0x7c, 0xe2, 0x0a, 0x0e, 0x17, + 0x04, 0xae, 0xfd, 0x78, 0x5d, 0x12, 0xdc, 0xde, + 0x73, 0x9c, 0x17, 0x85, 0x2f, 0x79, 0xc5, 0xbb, + 0x2c, 0x21, 0x6b, 0x92, 0x14, 0x92, 0x9f, 0x9e, + 0x0c, 0xd6, 0x20, 0x99, 0x28, 0xae, 0x27, 0x22, + 0x6d, 0xd9, 0xc4, 0x41, 0x99, 0xfd, 0x71, 0x42, + 0x25, 0x8a, 0x41, 0xd2, 0x1c, 0x60, 0xe3, 0xfa, + 0x14, 0x70, 0xa4, 0x8a, 0xaf, 0xa5, 0xd1, 0x90, + 0x26, 0x42, 0x2e, 0x53, 0x42, 0xe8, 0x0e, 0x0a, + 0x37, 0x27, 0x69, 0x29, 0x21, 0x41, 0x3c, 0xf6, + 0xf2, 0x21, 0xe5, 0x07, 0x48, 0x7a, 0x49, 0xd0, + 0x5c, 0xe9, 0xc9, 0x25, 0x0c, 0xa7, 0x02, 0xa9, + 0x9d, 0x17, 0x8c, 0x85, 0xdd, 0x05, 0xf6, 0x83, + 0x31, 0x8f, 0x41, 0xc2, 0xa8, 0x46, 0x0e, 0xa0, + 0xe0, 0x5f, 0x3c, 0x19, 0xd1, 0x4e, 0x9e, 0x40, + 0x89, 0x60, 0x5e, 0xcf, 0x60, 0x38, 0x07, 0xd4, + 0x20, 0xba, 0x7c, 0x28, 0xe8, 0x38, 0x62, 0xe9, + 0x25, 0xe1, 0xa1, 0x90, 0x38, 0x9a, 0xac, 0x45, + 0xaf, 0xa5, 0x8b, 0x21, 0xea, 0x23, 0x60, 0xe7, + 0x68, 0x8c, 0xa3, 0x81, 0x4c, 0xc3, 0x74, 0xd7, + 0x03, 0x22, 0x3e, 0xb8, 0xb8, 0x26, 0x64, 0x24, + 0xa4, 0xa7, 0xb4, 0xe6, 0x14, 0x12, 0x05, 0x52, + 0x0f, 0x45, 0x00, 0x19, 0xfc, 0x0e, 0x0a, 0x34, + 0x19, 0x03, 0x81, 0x7f, 0x8d, 0x34, 0xf7, 0x02, + 0x39, 0x8b, 0x8b, 0x90, 0x04, 0x52, 0x14, 0xb8, + 0xb8, 0x2c, 0x42, 0x58, 0x0b, 0x98, 0x9e, 0x51, + 0xc0, 0xc5, 0x68, 0x11, 0xe8, 0x03, 0x81, 0xc0, + 0xbf, 0x66, 0x81, 0xd5, 0xd2, 0xb9, 0x41, 0x27, + 0x02, 0x63, 0x11, 0xa3, 0x3f, 0x57, 0x9e, 0x73, + 0xbc, 0xb1, 0x09, 0x4f, 0x08, 0x37, 0x30, 0x94, + 0xe6, 0x93, 0x8b, 0xa3, 0x36, 0x6e, 0x00, 0xe1, + 0xae, 0xa8, 0x91, 0x83, 0x8d, 0x12, 0x85, 0x4a, + 0x8a, 0x1b, 0x27, 0xd3, 0xd3, 0x88, 0xc3, 0x07, + 0xcc, 0x80, 0xe0, 0x5c, 0xcc, 0xea, 0xc1, 0x90, + 0x2c, 0x5d, 0x3c, 0xa0, 0xe0, 0x9e, 0xad, 0x62, + 0x37, 0xc5, 0xe2, 0xa1, 0x40, 0x84, 0x2b, 0x82, + 0xb0, 0x5d, 0x3e, 0x73, 0xbd, 0x07, 0x0b, 0xc2, + 0x77, 0x16, 0x25, 0x17, 0x70, 0xd8, 0x38, 0x69, + 0x08, 0xb4, 0xcb, 0x0e, 0x05, 0x14, 0x38, 0x27, + 0x48, 0xaa, 0xa1, 0x85, 0x10, 0x07, 0xa3, 0x3d, + 0x54, 0x66, 0x18, 0x03, 0x8f, 0x1b, 0x3a, 0x4a, + 0x27, 0xd7, 0xbb, 0x01, 0xd0, 0xfe, 0xea, 0xf3, + 0xa6, 0xf8, 0x43, 0x86, 0x10, 0x1c, 0x76, 0x86, + 0x34, 0x62, 0x4a, 0x0b, 0xc4, 0xb9, 0xd3, 0x4e, + 0xd7, 0xf9, 0xa0, 0xb1, 0x24, 0x14, 0x50, 0xcf, + 0x86, 0x81, 0x3d, 0xe5, 0x42, 0xb7, 0x68, 0x2e, + 0xf4, 0x92, 0x14, 0x44, 0x63, 0x2e, 0x1d, 0x7e, + 0xaf, 0x42, 0x6d, 0x7f, 0x64, 0x29, 0x0a, 0xb5, + 0xec, 0x40, 0x0e, 0x04, 0xef, 0xbd, 0xe7, 0x56, + 0x40, 0x0b, 0x0a, 0x79, 0x8c, 0x7b, 0xc0, 0xa7, + 0x3d, 0xaf, 0x94, 0xde, 0x21, 0x45, 0xc0, 0xc0, + 0x17, 0x33, 0x31, 0x0a, 0xcb, 0x92, 0x03, 0x8f, + 0xb5, 0xd0, 0xf7, 0x9d, 0x3b, 0x56, 0x61, 0x21, + 0x25, 0x19, 0x82, 0xee, 0xf3, 0x92, 0xa3, 0x76, + 0xbd, 0xe7, 0xf6, 0x76, 0xf6, 0xe4, 0xc0, 0x29, + 0x81, 0xb5, 0xd0, 0x70, 0xad, 0xff, 0x3c, 0xba, + 0xd3, 0x6d, 0x96, 0xf5, 0x10, 0x2f, 0xe3, 0xb3, + 0x05, 0xc4, 0x53, 0xdb, 0x61, 0x20, 0x3a, 0x9f, + 0x9d, 0x35, 0xca, 0x4f, 0xa6, 0xe2, 0x90, 0x72, + 0xdd, 0x09, 0x21, 0x70, 0x7e, 0xe8, 0x00, 0xf2, + 0xe0, 0x3d, 0x60, 0x1d, 0x42, 0x5d, 0x20, 0x6d, + 0x82, 0xb6, 0xea, 0xe8, 0x04, 0xda, 0xfa, 0x48, + 0x8b, 0xb0, 0x96, 0xa0, 0x07, 0x2c, 0x4f, 0xed, + 0xbc, 0x5b, 0xa0, 0xe9, 0x05, 0x0f, 0x3a, 0x4a, + 0x82, 0x0a, 0xfe, 0x62, 0x13, 0xb1, 0x79, 0xde, + 0x8b, 0x88, 0x34, 0xe5, 0x1a, 0x01, 0x70, 0x57, + 0x2b, 0x82, 0xc3, 0x91, 0x72, 0x1a, 0xad, 0x62, + 0x0e, 0x83, 0x89, 0x57, 0x81, 0x27, 0x50, 0x2f, + 0x07, 0x3f, 0x07, 0x23, 0x3f, 0x17, 0xfc, 0xc4, + 0x1d, 0xda, 0x18, 0x11, 0x3b, 0x6f, 0x50, 0x62, + 0xc2, 0xf4, 0x40, 0x9d, 0xbc, 0x52, 0x88, 0x5c, + 0x2b, 0x77, 0x28, 0x6e, 0xb9, 0x20, 0x2e, 0xad, + 0x42, 0x68, 0x9f, 0x5e, 0x64, 0xbd, 0x36, 0x53, + 0x0a, 0x4a, 0x46, 0x8d, 0x64, 0x2b, 0x22, 0x3b, + 0xa6, 0xf5, 0x06, 0x76, 0x12, 0x89, 0xba, 0xc3, + 0x24, 0x23, 0x10, 0xc0, 0x87, 0x92, 0xf0, 0xe6, + 0xbe, 0x2b, 0x88, 0x6d, 0x34, 0x18, 0x1f, 0x95, + 0x89, 0x01, 0x7b, 0xed, 0x07, 0x20, 0x0c, 0x44, + 0xdb, 0x69, 0xae, 0x12, 0x20, 0x20, 0x8b, 0x40, + 0x9e, 0x2c, 0x4f, 0x10, 0x9b, 0x5c, 0x24, 0x79, + 0x78, 0x85, 0x12, 0x31, 0x98, 0x56, 0xf6, 0xde, + 0xa2, 0xb4, 0x66, 0x43, 0x54, 0xa9, 0x76, 0xbc, + 0xf0, 0x1c, 0x45, 0xba, 0x1a, 0x21, 0x28, 0x07, + 0x3f, 0x81, 0x1e, 0x83, 0x06, 0x5d, 0x0c, 0x89, + 0xa7, 0x94, 0x93, 0x80, 0xbd, 0xe9, 0xa0, 0xc3, + 0xa0, 0x3c, 0xee, 0x9c, 0xf2, 0x12, 0x03, 0x85, + 0x4f, 0x80, 0xea, 0x7a, 0xa2, 0xc8, 0x10, 0xae, + 0x8c, 0x82, 0x46, 0x28, 0xc1, 0xc2, 0xf0, 0x77, + 0x48, 0x69, 0xae, 0x48, 0x2b, 0xab, 0xe4, 0x0b, + 0x5e, 0xa3, 0x91, 0x61, 0x5e, 0x5c, 0xda, 0x34, + 0x44, 0xbd, 0xa4, 0x0d, 0x7e, 0x50, 0x73, 0xba, + 0xf4, 0x1f, 0xbf, 0xff, 0xff, 0x6a, 0x20, 0xa6, + 0x27, 0xf9, 0xc0, 0x7a, 0x0f, 0xff, 0xcf, 0xf5, + 0xd1, 0xae, 0x15, 0x65, 0x28, 0x90, 0x84, 0xd3, + 0x0a, 0x2f, 0x06, 0x00, 0xe2, 0x3f, 0x83, 0x4d, + 0x3f, 0x10, 0xac, 0x52, 0x0e, 0x3b, 0x81, 0xd1, + 0x7e, 0x06, 0x01, 0x14, 0x82, 0x3a, 0x04, 0x02, + 0xe4, 0x76, 0x1e, 0xe0, 0xe0, 0x5d, 0x52, 0x95, + 0xdd, 0xa7, 0xb8, 0x0b, 0x14, 0x00, 0xe0, 0xc8, + 0xeb, 0x58, 0xd8, 0xc4, 0x30, 0x21, 0xe0, 0xf4, + 0x30, 0x01, 0x84, 0xf4, 0x31, 0x18, 0x02, 0x7a, + 0x94, 0x2c, 0x15, 0xc4, 0xda, 0xc4, 0x78, 0x62, + 0x32, 0x8b, 0x42, 0x45, 0x81, 0xc5, 0x24, 0x71, + 0x01, 0x74, 0xe0, 0xc8, 0x90, 0x1c, 0x6c, 0x94, + 0x4d, 0x48, 0xb4, 0xf4, 0x37, 0x0d, 0x03, 0x89, + 0x0f, 0x38, 0x67, 0x60, 0x3f, 0xbc, 0x00, 0x6c, + 0x5e, 0x0e, 0x41, 0x4d, 0x85, 0x76, 0x02, 0xef, + 0x5e, 0x41, 0xcb, 0xd0, 0x70, 0x64, 0x85, 0x62, + 0x79, 0xd1, 0x80, 0xb8, 0x1c, 0x27, 0x70, 0x1f, + 0xdf, 0xff, 0xf7, 0x20, 0xa3, 0x25, 0x22, 0xd3, + 0x8b, 0x9e, 0x02, 0x1e, 0x5c, 0x1c, 0x11, 0xae, + 0xa3, 0x3a, 0xb7, 0xb2, 0x8b, 0xab, 0xe0, 0xb1, + 0x12, 0xf0, 0x1c, 0x2e, 0x0a, 0x12, 0xbc, 0x95, + 0x0f, 0x6a, 0x09, 0x2f, 0x45, 0xeb, 0x40, 0x1c, + 0x43, 0xcd, 0x59, 0x0b, 0xe2, 0x6a, 0x5f, 0x43, + 0x4a, 0x09, 0x54, 0xd3, 0x62, 0x9f, 0x65, 0x88, + 0x94, 0x8c, 0xaa, 0xc2, 0xfa, 0xfe, 0x55, 0x2c, + 0xe7, 0x82, 0xad, 0x6d, 0x41, 0xcc, 0x19, 0x22, + 0xe0, 0xa7, 0x31, 0x53, 0x91, 0x03, 0xf5, 0x17, + 0xfe, 0x2e, 0x29, 0x26, 0x4c, 0xb1, 0xb9, 0x2f, + 0x5b, 0x80, 0x8c, 0xb8, 0x61, 0x41, 0x77, 0x41, + 0xef, 0x11, 0xd4, 0x06, 0x86, 0x24, 0x5e, 0x44, + 0x2b, 0x8c, 0xd1, 0x14, 0x93, 0x32, 0xfc, 0x5b, + 0x51, 0x0a, 0xb4, 0xe5, 0x64, 0x3c, 0xb4, 0xd8, + 0x39, 0x18, 0x51, 0x48, 0x41, 0xcb, 0x70, 0x9f, + 0x70, 0x32, 0x40, 0x15, 0x4a, 0x88, 0x0e, 0x46, + 0x19, 0x84, 0x70, 0xd2, 0xe7, 0xf5, 0xe7, 0x81, + 0xaa, 0xe7, 0xdf, 0xe8, 0x69, 0x25, 0x36, 0x48, + 0x0e, 0x42, 0x14, 0x4d, 0xa6, 0xf2, 0x92, 0xac, + 0x49, 0xd2, 0x66, 0x85, 0x01, 0x28, 0xb8, 0x13, + 0x19, 0x6b, 0x78, 0x2e, 0x7e, 0xbf, 0xf8, 0x13, + 0xee, 0x50, 0x71, 0xcf, 0x20, 0x7f, 0x20, 0x30, + 0x2c, 0x34, 0x13, 0x5b, 0xb2, 0x31, 0x8a, 0xe2, + 0xf7, 0x34, 0x83, 0x31, 0xa6, 0xbe, 0x99, 0x56, + 0x1b, 0x6b, 0xb4, 0xa8, 0xf9, 0xca, 0x31, 0x1a, + 0x39, 0x50, 0x2c, 0x0e, 0x90, 0x1c, 0x73, 0xdc, + 0x9d, 0x5d, 0x6e, 0x22, 0xa6, 0x90, 0x9e, 0x5a, + 0xb2, 0x0e, 0x13, 0x45, 0xe7, 0xb3, 0xa0, 0xc4, + 0xcf, 0xbd, 0x43, 0x4d, 0x83, 0x06, 0x50, 0xe5, + 0x81, 0x6e, 0x00, 0xee, 0x00, 0xe8, 0xe9, 0xb8, + 0x52, 0x41, 0xec, 0x1b, 0x51, 0x75, 0x80, 0x99, + 0x57, 0xd1, 0x75, 0xd0, 0x94, 0x12, 0x0b, 0x89, + 0xfc, 0x17, 0x44, 0x25, 0x20, 0xb9, 0x53, 0x79, + 0x67, 0x3b, 0xf5, 0x22, 0x26, 0x69, 0x25, 0x42, + 0xe5, 0x71, 0x9c, 0xa1, 0xd0, 0x31, 0x5f, 0x6c, + 0x9b, 0x56, 0x35, 0x41, 0x71, 0x0b, 0x64, 0xe0, + 0x8a, 0x2b, 0xd3, 0xd7, 0x41, 0x63, 0x00, 0x79, + 0xdd, 0xd9, 0x2a, 0xe8, 0x51, 0x10, 0x40, 0x22, + 0x7d, 0x0b, 0x3b, 0xe2, 0x45, 0xe8, 0xbf, 0x54, + 0xf4, 0x60, 0xb0, 0xa5, 0x29, 0xe5, 0x11, 0x0d, + 0x29, 0xab, 0xde, 0xa2, 0x45, 0x20, 0x2f, 0xea, + 0xc8, 0xfa, 0x2e, 0x7e, 0x9c, 0x95, 0x12, 0x84, + 0xae, 0x23, 0x07, 0x09, 0x93, 0x24, 0x09, 0x38, + 0x3b, 0x86, 0x81, 0x35, 0x84, 0xda, 0xfb, 0x92, + 0x2f, 0x10, 0x83, 0x82, 0x2e, 0xba, 0x10, 0xc8, + 0xa4, 0x22, 0xdd, 0x07, 0x0d, 0x1f, 0x0d, 0xd9, + 0xd0, 0x4d, 0xd7, 0x21, 0xd7, 0x98, 0x03, 0x81, + 0x60, 0x7d, 0xd5, 0xe7, 0x21, 0x42, 0xe7, 0xe6, + 0xa0, 0xab, 0x83, 0x82, 0x7d, 0xc8, 0x32, 0xe5, + 0x07, 0x3e, 0x14, 0x9d, 0xd3, 0xf3, 0xa4, 0xa3, + 0x10, 0xca, 0x83, 0x8e, 0xa6, 0xb1, 0x4a, 0xc4, + 0xed, 0x74, 0x7d, 0x07, 0x02, 0xeb, 0xc3, 0x17, + 0x9c, 0xa8, 0xc2, 0x4a, 0x9f, 0x5c, 0x5c, 0x69, + 0x01, 0x36, 0x9d, 0xa4, 0xa0, 0xf3, 0xff, 0xff, + 0xa0, 0x39, 0x32, 0x52, 0x45, 0x91, 0x2f, 0xc0, + 0x9f, 0x06, 0x60, 0xe2, 0x5a, 0x77, 0x0a, 0x3f, + 0x89, 0x24, 0x28, 0x5c, 0x22, 0xac, 0xc5, 0xf8, + 0xb7, 0x6c, 0x40, 0x33, 0x7d, 0x58, 0x89, 0x72, + 0x69, 0xea, 0xc0, 0xe1, 0x91, 0x1f, 0x57, 0xd9, + 0x99, 0x27, 0x17, 0x47, 0x7a, 0x88, 0x26, 0xdb, + 0xa6, 0xe5, 0xe4, 0x01, 0xe2, 0xa9, 0x0c, 0x05, + 0x3b, 0x90, 0xda, 0x3e, 0x2c, 0x2b, 0x7e, 0x77, + 0xa4, 0x7a, 0x73, 0xc8, 0x1c, 0x59, 0x0a, 0x41, + 0x3f, 0x16, 0x61, 0x47, 0x01, 0xc4, 0xb3, 0x80, + 0xba, 0xd3, 0x4d, 0x86, 0x21, 0x80, 0x52, 0xfa, + 0x48, 0x8d, 0x10, 0xc4, 0x17, 0xd2, 0xf5, 0x14, + 0x0a, 0xe2, 0x7d, 0x46, 0x54, 0x4b, 0x0c, 0x0d, + 0x05, 0x58, 0xb0, 0x95, 0x4f, 0x50, 0x83, 0x91, + 0x05, 0x39, 0x10, 0x39, 0x10, 0x38, 0x8f, 0x1b, + 0xbc, 0x85, 0x01, 0x88, 0xd3, 0xb4, 0x13, 0xb5, + 0xe5, 0x74, 0x4b, 0x03, 0x91, 0x10, 0x31, 0x8c, + 0x0a, 0x25, 0x72, 0x5b, 0x06, 0x70, 0x9e, 0x51, + 0x53, 0x55, 0x19, 0x28, 0x38, 0xa0, 0x8f, 0x83, + 0x64, 0x21, 0x5e, 0xbb, 0x19, 0xcd, 0x18, 0x06, + 0x20, 0xe3, 0xf3, 0x16, 0xe8, 0x38, 0x22, 0xd0, + 0x12, 0x62, 0xac, 0x6c, 0x1d, 0x11, 0x9d, 0xbd, + 0x28, 0x84, 0xfa, 0xfa, 0x95, 0x77, 0xa0, 0x3a, + 0x86, 0x48, 0xa9, 0xa0, 0x8e, 0x2c, 0x50, 0x8f, + 0xbc, 0x01, 0xc0, 0xb0, 0x05, 0xcc, 0xd5, 0x90, + 0x41, 0x70, 0x4e, 0x9a, 0xeb, 0x22, 0x07, 0x14, + 0x82, 0xeb, 0xe0, 0x9f, 0x4e, 0x2c, 0x07, 0xea, + 0x80, 0x0d, 0x12, 0xc2, 0x81, 0x98, 0x38, 0x56, + 0x99, 0x60, 0x38, 0x27, 0xa5, 0x00, 0xf3, 0xff, + 0xff, 0x91, 0x99, 0x54, 0x8c, 0x4d, 0x9f, 0xab, + 0xdd, 0x51, 0x57, 0x5c, 0x90, 0x60, 0xb1, 0xef, + 0xca, 0x2b, 0xc0, 0xe2, 0x2a, 0x58, 0x94, 0xf1, + 0x4a, 0x22, 0xc8, 0x5d, 0xdf, 0x50, 0x49, 0x46, + 0x68, 0xc6, 0x51, 0xd1, 0x7b, 0x03, 0x00, 0x4d, + 0xa5, 0x14, 0x1d, 0x51, 0x05, 0x4f, 0x8b, 0x76, + 0x86, 0x6b, 0x03, 0x81, 0x3b, 0xd3, 0xb5, 0x1a, + 0xa7, 0xb6, 0xce, 0x20, 0x9c, 0x5e, 0x2c, 0x6c, + 0x86, 0x79, 0xc3, 0x64, 0x9d, 0x3f, 0xb8, 0x6c, + 0x1c, 0x42, 0xd6, 0x5a, 0x76, 0x0a, 0x2a, 0x32, + 0x3d, 0x77, 0x79, 0xc4, 0x16, 0x12, 0xd0, 0xa7, + 0x41, 0x80, 0xaf, 0x76, 0x20, 0xec, 0x07, 0x05, + 0x1f, 0x11, 0x85, 0x1c, 0xa8, 0x02, 0x8d, 0x7c, + 0x0e, 0x21, 0x75, 0x4f, 0x60, 0x3a, 0xa2, 0x27, + 0x9d, 0x06, 0x0c, 0x8d, 0x0a, 0xd9, 0x22, 0xf5, + 0x4d, 0x07, 0x50, 0x4c, 0xed, 0xe2, 0x30, 0xcc, + 0x07, 0xbb, 0x4f, 0x0c, 0xd1, 0x14, 0x83, 0x83, + 0x3e, 0x0d, 0x67, 0x94, 0x62, 0x0e, 0x17, 0xf5, + 0x00, 0xd1, 0xf0, 0x1c, 0xfd, 0x62, 0x04, 0x24, + 0x18, 0x51, 0x53, 0xfc, 0x28, 0x07, 0x0d, 0x77, + 0x03, 0x31, 0x5e, 0x51, 0xc8, 0x0e, 0x0a, 0xda, + 0xd5, 0x0f, 0x16, 0x58, 0x1d, 0xc0, 0x71, 0xc6, + 0x8b, 0x22, 0xc4, 0x66, 0xc2, 0x3d, 0x77, 0x6c, + 0xd2, 0x47, 0x65, 0x15, 0x0f, 0x41, 0xc3, 0x31, + 0x3f, 0xec, 0x36, 0x0b, 0xc7, 0x3b, 0x57, 0x44, + 0x52, 0x6e, 0x8a, 0xa7, 0x37, 0x95, 0x6a, 0x09, + 0x95, 0x37, 0xc4, 0x3c, 0x81, 0x98, 0x3a, 0x04, + 0x9f, 0x8b, 0x1a, 0x19, 0x83, 0x83, 0x11, 0x35, + 0x03, 0x90, 0x50, 0x72, 0x12, 0x39, 0xb0, 0xdf, + 0x41, 0xc4, 0x71, 0x4a, 0x12, 0x6d, 0x3e, 0x58, + 0xb8, 0xc9, 0x08, 0x2c, 0x20, 0x38, 0xf7, 0x58, + 0xd7, 0x41, 0xc1, 0x3d, 0x70, 0x33, 0x05, 0xd4, + 0xa8, 0x58, 0x1c, 0x18, 0xc8, 0x14, 0x77, 0xa2, + 0xa8, 0xbf, 0xcb, 0x51, 0x83, 0x8e, 0xc5, 0x29, + 0x5c, 0x17, 0x9e, 0xa0, 0x25, 0x44, 0x28, 0x9a, + 0x2f, 0xa8, 0x43, 0x0a, 0x7a, 0xd8, 0x8f, 0xb6, + 0x82, 0x66, 0x9f, 0x5e, 0x0c, 0x0d, 0x03, 0x97, + 0x42, 0x8c, 0xf4, 0xf0, 0xda, 0x21, 0x3e, 0x47, + 0xc3, 0x64, 0xcc, 0x66, 0x0e, 0x1a, 0x51, 0x5d, + 0x5d, 0x3b, 0x8a, 0x0a, 0x0a, 0x62, 0x3e, 0x72, + 0x3d, 0xdf, 0x83, 0x90, 0xa0, 0x05, 0xf7, 0xde, + 0x45, 0xb8, 0x33, 0xe2, 0xc0, 0xb0, 0x19, 0x91, + 0x3c, 0xef, 0x43, 0x75, 0xa2, 0x33, 0x6b, 0xf0, + 0x33, 0x7e, 0x56, 0x28, 0xd3, 0xab, 0xd4, 0x52, + 0x90, 0xfe, 0x21, 0x40, 0x52, 0xe8, 0x9e, 0xe7, + 0x22, 0x00, 0xd5, 0x4d, 0x06, 0x09, 0xe7, 0x90, + 0x16, 0x3c, 0xe1, 0x42, 0x10, 0xc0, 0x69, 0x10, + 0x71, 0xd1, 0x3d, 0x27, 0x79, 0x08, 0xda, 0x81, + 0x9a, 0x30, 0x72, 0x30, 0x4d, 0x72, 0x2e, 0x83, + 0x9c, 0x07, 0x06, 0x42, 0xbd, 0xcb, 0xd2, 0x2e, + 0x74, 0x51, 0xa7, 0xd4, 0x53, 0x70, 0x63, 0xc0, + 0x70, 0x49, 0xb9, 0x06, 0x66, 0xd0, 0x02, 0xc4, + 0x17, 0x9b, 0x84, 0x88, 0xc3, 0x30, 0x70, 0x55, + 0xb8, 0x0e, 0x5c, 0x1c, 0x32, 0x09, 0x90, 0xe5, + 0x5e, 0x6d, 0x01, 0xc4, 0x7d, 0x0a, 0xfd, 0x46, + 0x48, 0x48, 0xb3, 0xb7, 0x06, 0x4b, 0x8c, 0x10, + 0x03, 0x9f, 0xba, 0x2e, 0x46, 0x19, 0xbe, 0xf5, + 0x1a, 0xc7, 0xb4, 0xe0, 0x65, 0x02, 0x7c, 0x30, + 0x0c, 0x4d, 0x8a, 0x5f, 0x0d, 0x45, 0xca, 0x28, + 0x4b, 0x2b, 0x03, 0xa0, 0x30, 0x2c, 0x42, 0x5c, + 0xe6, 0x9e, 0x28, 0x82, 0xe0, 0x5c, 0xbe, 0xa3, + 0x96, 0x06, 0x61, 0x2c, 0x40, 0x1d, 0xd2, 0x17, + 0xc5, 0xc1, 0xc3, 0x5e, 0xce, 0x1a, 0xe0, 0xaf, + 0x4f, 0x0c, 0xba, 0x19, 0x06, 0x40, 0x3c, 0x6b, + 0xe7, 0x57, 0x58, 0xd4, 0x07, 0x1b, 0x14, 0x27, + 0xce, 0x92, 0xc2, 0x94, 0x60, 0xbe, 0x60, 0xe0, + 0x9f, 0x44, 0x85, 0xfa, 0xf8, 0xd8, 0x64, 0xa3, + 0x80, 0x39, 0x10, 0x55, 0xed, 0x18, 0x9b, 0x0b, + 0x32, 0x20, 0x58, 0x02, 0xe7, 0x1b, 0x21, 0xbd, + 0x9d, 0xe9, 0x50, 0x26, 0xe9, 0xba, 0x1f, 0xa2, + 0xee, 0x14, 0x2e, 0x03, 0xc8, 0xdd, 0x10, 0x4d, + 0x66, 0x8c, 0xe9, 0x48, 0x2e, 0x51, 0xe0, 0x26, + 0xa9, 0xc6, 0x43, 0x9c, 0x92, 0x20, 0x04, 0xd2, + 0xd7, 0x43, 0x27, 0x01, 0x7d, 0xa7, 0x65, 0x7c, + 0x0e, 0xb0, 0x11, 0xc2, 0x5b, 0xbf, 0x51, 0x57, + 0xc0, 0x46, 0xb1, 0x71, 0x97, 0x5d, 0x62, 0x06, + 0x68, 0xdf, 0xba, 0x6c, 0xad, 0x18, 0xc8, 0xe4, + 0x28, 0xcc, 0x1b, 0x7b, 0x85, 0x10, 0x31, 0x3f, + 0x41, 0xc8, 0x88, 0xb4, 0xde, 0x7f, 0x7e, 0x0c, + 0x05, 0x3e, 0xb9, 0xb5, 0x10, 0x6b, 0x2a, 0x1b, + 0xe7, 0x54, 0xe6, 0x12, 0x8d, 0xe8, 0x38, 0x62, + 0x7b, 0xd2, 0x45, 0xe8, 0x51, 0xf8, 0x8d, 0x71, + 0x78, 0x38, 0x62, 0x13, 0xb2, 0xfd, 0x09, 0x62, + 0x6c, 0x0d, 0x60, 0x32, 0x1f, 0xb7, 0xfa, 0x53, + 0xc8, 0x50, 0xb7, 0x06, 0x92, 0xa3, 0x32, 0xad, + 0x38, 0x0e, 0x28, 0x3d, 0x27, 0x9f, 0x20, 0x63, + 0xd7, 0xcb, 0xd4, 0x72, 0xf0, 0x90, 0x83, 0x5f, + 0x5d, 0x18, 0x92, 0xa3, 0x0d, 0xd7, 0x3d, 0xaa, + 0x91, 0x95, 0xe9, 0x48, 0xd1, 0xf4, 0x1f, 0xc2, + 0x00, 0x3f, 0x6c, 0x44, 0xba, 0x00, 0x70, 0x72, + 0x7e, 0x70, 0x57, 0x53, 0x64, 0x92, 0x0c, 0xcd, + 0x92, 0x02, 0xeb, 0xae, 0x50, 0x2a, 0xca, 0x0a, + 0x45, 0xc0, 0x3c, 0x1c, 0xee, 0x18, 0x03, 0x90, + 0x84, 0x54, 0x35, 0xe8, 0x49, 0xa7, 0x35, 0x12, + 0x00, 0x1c, 0x2e, 0x07, 0x3b, 0x49, 0x01, 0xdd, + 0x19, 0x83, 0x90, 0x89, 0xa7, 0x85, 0x05, 0x01, + 0x1b, 0x17, 0x14, 0x03, 0xb8, 0x0b, 0xe6, 0xc2, + 0x9e, 0x94, 0x9c, 0xd3, 0xa0, 0x70, 0x66, 0x43, + 0x3c, 0x07, 0x05, 0x49, 0x74, 0xd5, 0xe0, 0xc0, + 0x07, 0xae, 0xea, 0x5f, 0xa6, 0xc1, 0xc3, 0x05, + 0x85, 0xc2, 0xb8, 0xa4, 0x90, 0x2b, 0x89, 0xb8, + 0x0e, 0x42, 0x12, 0x34, 0x46, 0x81, 0xc4, 0xa2, + 0x96, 0xb8, 0x64, 0x6e, 0x02, 0xe7, 0xa3, 0x40, + 0x32, 0x07, 0x40, 0x5c, 0x3d, 0xed, 0x5f, 0xa1, + 0x55, 0x4b, 0xf9, 0x60, 0x70, 0xa2, 0x11, 0xf4, + 0x32, 0x73, 0xe5, 0x29, 0x0c, 0x01, 0xc5, 0x03, + 0x5b, 0x57, 0x20, 0x89, 0xd8, 0x39, 0x00, 0x39, + 0x71, 0x80, 0xd1, 0x8c, 0x49, 0x3a, 0x09, 0xf0, + 0xa2, 0x23, 0x07, 0x02, 0xfa, 0x54, 0x78, 0x94, + 0x31, 0x13, 0xac, 0x2a, 0x15, 0xd5, 0xe1, 0x17, + 0x51, 0x03, 0xa5, 0x3b, 0xa1, 0x2a, 0x37, 0xed, + 0xd2, 0xa2, 0x52, 0x42, 0x8a, 0xb1, 0xa2, 0x83, + 0xb2, 0xa4, 0xa2, 0x4a, 0x50, 0x8f, 0xa1, 0x80, + 0x55, 0x29, 0xd8, 0x9e, 0x50, 0x87, 0xa7, 0x31, + 0x50, 0x3b, 0x92, 0x0c, 0x0f, 0xf1, 0x99, 0x48, + 0x38, 0x07, 0x22, 0x24, 0x3f, 0xc1, 0xcb, 0x83, + 0x81, 0x60, 0x35, 0xc1, 0x75, 0x13, 0xf1, 0x74, + 0x43, 0x12, 0x51, 0x98, 0x47, 0x84, 0x52, 0x81, + 0x82, 0xc0, 0xe1, 0xac, 0x74, 0x16, 0x04, 0xa1, + 0x81, 0xe6, 0x04, 0x83, 0x20, 0x89, 0xd6, 0x42, + 0x7f, 0x4d, 0xd1, 0x81, 0x48, 0xa1, 0x46, 0x3f, + 0x8c, 0xc5, 0x33, 0x9b, 0xe4, 0x1b, 0x9d, 0x5c, + 0x63, 0x90, 0x1c, 0x83, 0xae, 0xc8, 0x51, 0x06, + 0x50, 0x32, 0xa0, 0xbf, 0x2d, 0xc0, 0x71, 0x20, + 0x38, 0x5c, 0x4a, 0xef, 0xa7, 0xb4, 0xd0, 0xb8, + 0x4b, 0x45, 0xc2, 0xf0, 0x4e, 0x65, 0x21, 0x3f, + 0x34, 0x8c, 0x1c, 0x4a, 0x0e, 0xeb, 0xe4, 0xa0, + 0x1d, 0x46, 0x01, 0x5c, 0xe8, 0x9f, 0x5f, 0x14, + 0xa2, 0x37, 0x49, 0x44, 0xcf, 0x9c, 0x18, 0x92, + 0xa3, 0x07, 0x09, 0xe6, 0x1b, 0x09, 0x2b, 0x83, + 0x10, 0x4c, 0xe2, 0x35, 0x9d, 0x13, 0x92, 0x80, + 0x70, 0x66, 0x35, 0x6b, 0x77, 0x84, 0x6c, 0x64, + 0xb9, 0xa5, 0x96, 0x13, 0xee, 0x0c, 0x41, 0xc8, + 0xfa, 0x13, 0xb5, 0x9d, 0x25, 0x0a, 0x75, 0xde, + 0x50, 0x70, 0x2f, 0xa7, 0x56, 0x37, 0x61, 0xb2, + 0x42, 0x40, 0xae, 0x68, 0xcc, 0xa5, 0x07, 0x42, + 0x4d, 0x0d, 0xad, 0xca, 0x0b, 0xd5, 0xa3, 0x21, + 0x36, 0x9e, 0x8a, 0x22, 0xfd, 0x05, 0x88, 0x38, + 0x82, 0x4a, 0x28, 0xc1, 0x6e, 0x92, 0xad, 0x43, + 0x17, 0x4a, 0x34, 0x60, 0xfe, 0x10, 0x01, 0xe3, + 0x75, 0x6e, 0x03, 0x82, 0x4b, 0xdc, 0xa2, 0xbd, + 0x77, 0x28, 0x3b, 0xab, 0x77, 0x85, 0x21, 0x3c, + 0xc1, 0x9b, 0x9c, 0xb6, 0x76, 0xdb, 0x67, 0x78, + 0xb6, 0x5e, 0x21, 0x92, 0xde, 0x11, 0x4a, 0x20, + 0x74, 0x08, 0xa4, 0xa1, 0xb8, 0xd3, 0x5e, 0x68, + 0xd6, 0x57, 0x85, 0x01, 0x89, 0x0c, 0x5e, 0xa0, + 0x07, 0x1a, 0x07, 0x09, 0xf7, 0x11, 0x02, 0xeb, + 0x07, 0x1e, 0xd3, 0x46, 0xad, 0x11, 0x94, 0x74, + 0x1d, 0xd7, 0x29, 0xc3, 0x62, 0xf7, 0x24, 0x1f, + 0x7c, 0x18, 0x38, 0xf8, 0x30, 0xc2, 0x86, 0x12, + 0x03, 0x9f, 0xea, 0x66, 0xc1, 0x83, 0x86, 0xc6, + 0x5e, 0xa0, 0x39, 0xce, 0x51, 0x44, 0xda, 0xf8, + 0x5f, 0x01, 0xc3, 0x4f, 0x61, 0xb5, 0xe8, 0x62, + 0x8c, 0xa0, 0x17, 0x57, 0x75, 0x0f, 0x36, 0xf1, + 0x65, 0xc8, 0x1c, 0x02, 0x53, 0xab, 0xd0, 0x58, + 0xba, 0xf6, 0x44, 0x00, 0x9d, 0xaf, 0x48, 0x22, + 0x38, 0x85, 0x09, 0x48, 0x45, 0xe5, 0x28, 0x1a, + 0xfb, 0x20, 0x6f, 0x38, 0x32, 0x14, 0x54, 0xb4, + 0x63, 0xd0, 0x70, 0xd6, 0x82, 0xef, 0x5d, 0xd1, + 0x9f, 0x56, 0x3d, 0xc6, 0x1c, 0xe2, 0x11, 0x5b, + 0x46, 0x6a, 0xfd, 0x6e, 0x04, 0xad, 0x62, 0x8c, + 0x07, 0x00, 0xe2, 0x32, 0xf8, 0x1c, 0xf0, 0x51, + 0x57, 0xc0, 0xe0, 0x1c, 0x2a, 0xf1, 0x07, 0x09, + 0xb0, 0xbe, 0x03, 0xb8, 0x09, 0xfd, 0x62, 0x8b, + 0x45, 0xe1, 0x5d, 0x07, 0x2c, 0xb0, 0x4f, 0x17, + 0xf4, 0x95, 0x00, 0x26, 0xc9, 0x4a, 0x18, 0x13, + 0xe2, 0xb4, 0x6b, 0xd0, 0xb1, 0xd4, 0x11, 0x69, + 0x69, 0xc2, 0xc8, 0x75, 0xf2, 0xc0, 0xe4, 0x64, + 0x1d, 0x71, 0x80, 0xb8, 0x4c, 0xc6, 0x36, 0x3b, + 0x64, 0x90, 0x38, 0xb3, 0x56, 0x18, 0x65, 0x08, + 0x8c, 0x46, 0xb9, 0xfa, 0xbf, 0x0c, 0xaa, 0xc1, + 0x26, 0x90, 0x1e, 0x8f, 0xff, 0xf2, 0x36, 0xba, + 0x34, 0x56, 0x54, 0x2b, 0x03, 0x90, 0x9e, 0x9a, + 0x31, 0x44, 0x18, 0x11, 0xfb, 0xc8, 0x13, 0x6b, + 0xe9, 0x61, 0x24, 0xc4, 0x68, 0x85, 0x33, 0x25, + 0x29, 0xa1, 0x15, 0x5d, 0xa4, 0xb2, 0xda, 0x15, + 0x7e, 0x62, 0x35, 0x96, 0x20, 0xf3, 0xa4, 0x51, + 0x79, 0xb0, 0xa5, 0x1f, 0x20, 0xc7, 0x80, 0x9b, + 0xed, 0x24, 0xe2, 0x11, 0xab, 0xe8, 0xcb, 0xa1, + 0x54, 0xcc, 0x44, 0x8b, 0x66, 0x76, 0x3a, 0x62, + 0x20, 0x4f, 0xd7, 0xe2, 0x29, 0xbe, 0x92, 0x93, + 0xb5, 0x90, 0x03, 0xba, 0x27, 0x7d, 0xb0, 0x39, + 0x2b, 0xea, 0x31, 0x9f, 0x02, 0x7f, 0x78, 0x50, + 0x80, 0x30, 0x3f, 0x68, 0x38, 0x90, 0x5e, 0x73, + 0x5f, 0x4e, 0xc5, 0x83, 0x80, 0x58, 0x53, 0x64, + 0x0e, 0xf5, 0x75, 0xea, 0xfd, 0x28, 0x01, 0xc2, + 0x7d, 0x25, 0x24, 0x18, 0x21, 0x26, 0x63, 0x2e, + 0x14, 0x03, 0x89, 0xb0, 0x4b, 0xd7, 0xcb, 0x40, + 0x1c, 0x0e, 0x27, 0xf1, 0x0a, 0x25, 0x08, 0xf8, + 0x0b, 0x00, 0x96, 0x57, 0x24, 0xb4, 0x1c, 0xbb, + 0xf2, 0xc8, 0x90, 0x13, 0xdb, 0xc5, 0xf8, 0x0b, + 0x8d, 0x77, 0x68, 0xc5, 0x12, 0x15, 0xd6, 0x58, + 0x1c, 0x41, 0x0a, 0x24, 0x17, 0x74, 0x99, 0x86, + 0x6e, 0x7b, 0x56, 0x5b, 0x8a, 0x1e, 0xb3, 0xa8, + 0xcf, 0x6b, 0xb5, 0x34, 0x66, 0x18, 0x0c, 0x90, + 0x0c, 0x0f, 0x6e, 0x12, 0x2e, 0x50, 0x30, 0x15, + 0xb8, 0xa5, 0x61, 0xbd, 0xe7, 0x21, 0x0b, 0x51, + 0x94, 0xd4, 0xe7, 0x03, 0x00, 0x75, 0x0a, 0xfb, + 0xce, 0x9c, 0xab, 0xb2, 0x94, 0x48, 0x17, 0x0c, + 0x02, 0x67, 0xc1, 0x91, 0x45, 0xa6, 0xc1, 0x3e, + 0x49, 0x62, 0x34, 0x41, 0x33, 0xb4, 0x67, 0xd1, + 0x5c, 0x9d, 0xe2, 0xe7, 0x62, 0xee, 0x55, 0x08, + 0x81, 0xdc, 0x42, 0x0e, 0x21, 0x85, 0xe4, 0xef, + 0x00, 0x78, 0x39, 0x18, 0x55, 0x2b, 0x92, 0xde, + 0xf4, 0xd1, 0x48, 0x2e, 0x7c, 0x90, 0x91, 0x6e, + 0x83, 0x84, 0xee, 0x4b, 0x16, 0x14, 0x55, 0xf5, + 0x45, 0x10, 0x03, 0x9c, 0xe7, 0x0d, 0xf4, 0x90, + 0x64, 0x0b, 0x17, 0xcd, 0x84, 0x96, 0x4a, 0xbc, + 0x09, 0x37, 0x4a, 0x3a, 0x0f, 0x3d, 0x00, 0x19, + 0x34, 0x74, 0x5f, 0x59, 0x41, 0x18, 0x17, 0x33, + 0x95, 0x75, 0xe7, 0x14, 0x80, 0xee, 0x84, 0xcc, + 0xae, 0x12, 0x80, 0xf2, 0x0d, 0xa4, 0x9d, 0xc9, + 0x00, 0x79, 0x03, 0x3b, 0x5f, 0x5b, 0xc4, 0x3d, + 0x82, 0xf0, 0x71, 0xf9, 0xb3, 0x88, 0xfb, 0xd0, + 0x72, 0x09, 0xd1, 0xa4, 0xe2, 0xc8, 0x33, 0x7a, + 0x8d, 0x00, 0x39, 0x08, 0x2e, 0xb5, 0xc0, 0xd4, + 0xd7, 0x68, 0x38, 0x17, 0x5a, 0x33, 0xfa, 0xf3, + 0x38, 0x83, 0x8b, 0x12, 0x21, 0x39, 0x2b, 0x94, + 0xf5, 0x18, 0x38, 0x33, 0x21, 0x9b, 0x41, 0xf1, + 0xe0, 0x07, 0xd2, 0x52, 0x59, 0x11, 0x92, 0x92, + 0x2f, 0x41, 0xc4, 0x3d, 0x5e, 0x1e, 0xd3, 0x95, + 0xc0, 0x71, 0x0c, 0x7a, 0xc5, 0x38, 0x8c, 0x6e, + 0xed, 0x31, 0xb0, 0xe2, 0x82, 0x35, 0x09, 0x27, + 0x3d, 0xaa, 0x72, 0xdc, 0x43, 0x04, 0x47, 0xc5, + 0xa9, 0xb0, 0x9b, 0x7f +}; diff --git a/contrib/apps/shell/shell.c b/contrib/apps/shell/shell.c new file mode 100644 index 00000000000..f4f668d7123 --- /dev/null +++ b/contrib/apps/shell/shell.c @@ -0,0 +1,1277 @@ +/* + * Copyright (c) 2001-2003 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Adam Dunkels adam@sics.se + * + */ + +#include "shell.h" + +#include "lwip/opt.h" + +#if LWIP_NETCONN && LWIP_TCP + +#include <string.h> +#include <stdio.h> + +#include "lwip/mem.h" +#include "lwip/debug.h" +#include "lwip/def.h" +#include "lwip/api.h" +#include "lwip/stats.h" + +#if LWIP_SOCKET +#include "lwip/errno.h" +#include "lwip/if_api.h" +#endif + +#ifdef WIN32 +#define NEWLINE "\r\n" +#else /* WIN32 */ +#define NEWLINE "\n" +#endif /* WIN32 */ + +/** Define this to 1 if you want to echo back all received characters + * (e.g. so they are displayed on a remote telnet) + */ +#ifndef SHELL_ECHO +#define SHELL_ECHO 0 +#endif + +#define BUFSIZE 1024 +static unsigned char buffer[BUFSIZE]; + +struct command { + struct netconn *conn; + s8_t (* exec)(struct command *); + u8_t nargs; + char *args[10]; +}; + +#include <stdio.h> +#include <stdlib.h> +#include <limits.h> + +#define ESUCCESS 0 +#define ESYNTAX -1 +#define ETOOFEW -2 +#define ETOOMANY -3 +#define ECLOSED -4 + +#define NCONNS 10 +static struct netconn *conns[NCONNS]; + +/* help_msg is split into 3 strings to prevent exceeding the C89 maximum length of 509 per string */ +static char help_msg1[] = "Available commands:"NEWLINE"\ +open [IP address] [TCP port]: opens a TCP connection to the specified address."NEWLINE"\ +lstn [TCP port]: sets up a server on the specified port."NEWLINE"\ +acpt [connection #]: waits for an incoming connection request."NEWLINE"\ +send [connection #] [message]: sends a message on a TCP connection."NEWLINE"\ +udpc [local UDP port] [IP address] [remote port]: opens a UDP "connection"."NEWLINE"\ +udpl [local UDP port] [IP address] [remote port]: opens a UDP-Lite "connection"."NEWLINE""; +static char help_msg2[] = "udpn [local UDP port] [IP address] [remote port]: opens a UDP "connection" without checksums."NEWLINE"\ +udpb [local port] [remote port]: opens a UDP broadcast "connection"."NEWLINE"\ +usnd [connection #] [message]: sends a message on a UDP connection."NEWLINE"\ +recv [connection #]: receives data on a TCP or UDP connection."NEWLINE"\ +clos [connection #]: closes a TCP or UDP connection."NEWLINE"\ +stat: prints out lwIP statistics."NEWLINE"\ +idxtoname [index]: outputs interface name from index."NEWLINE"\ +nametoidx [name]: outputs interface index from name."NEWLINE; +static char help_msg3[] = +"gethostnm [name]: outputs IP address of host."NEWLINE"\ +quit: quits"NEWLINE""; + +#if LWIP_STATS +static char padding_10spaces[] = " "; + +#define PROTOCOL_STATS (LINK_STATS && ETHARP_STATS && IPFRAG_STATS && IP_STATS && ICMP_STATS && UDP_STATS && TCP_STATS) + +#if PROTOCOL_STATS +static const char* shell_stat_proto_names[] = { +#if LINK_STATS + "LINK ", +#endif +#if ETHARP_STATS + "ETHARP ", +#endif +#if IPFRAG_STATS + "IP_FRAG ", +#endif +#if IP_STATS + "IP ", +#endif +#if ICMP_STATS + "ICMP ", +#endif +#if UDP_STATS + "UDP ", +#endif +#if TCP_STATS + "TCP ", +#endif + "last" +}; + +static struct stats_proto* shell_stat_proto_stats[] = { +#if LINK_STATS + &lwip_stats.link, +#endif +#if ETHARP_STATS + &lwip_stats.etharp, +#endif +#if IPFRAG_STATS + &lwip_stats.ip_frag, +#endif +#if IP_STATS + &lwip_stats.ip, +#endif +#if ICMP_STATS + &lwip_stats.icmp, +#endif +#if UDP_STATS + &lwip_stats.udp, +#endif +#if TCP_STATS + &lwip_stats.tcp, +#endif +}; +static const size_t num_protostats = sizeof(shell_stat_proto_stats)/sizeof(struct stats_proto*); + +static const char *stat_msgs_proto[] = { + " * transmitted ", + " * received ", + " forwarded ", + " * dropped ", + " * checksum errors ", + " * length errors ", + " * memory errors ", + " routing errors ", + " protocol errors ", + " option errors ", + " * misc errors ", + " cache hits " +}; +#endif /* PROTOCOL_STATS */ +#endif /* LWIP_STATS */ + +/*-----------------------------------------------------------------------------------*/ +static void +sendstr(const char *str, struct netconn *conn) +{ + netconn_write(conn, (const void *)str, strlen(str), NETCONN_NOCOPY); +} +/*-----------------------------------------------------------------------------------*/ +static s8_t +com_open(struct command *com) +{ + ip_addr_t ipaddr; + u16_t port; + int i; + err_t err; + long tmp; + + if (ipaddr_aton(com->args[0], &ipaddr) == -1) { + sendstr(strerror(errno), com->conn); + return ESYNTAX; + } + tmp = strtol(com->args[1], NULL, 10); + if((tmp < 0) || (tmp > 0xffff)) { + sendstr("Invalid port number."NEWLINE, com->conn); + return ESUCCESS; + } + port = (u16_t)tmp; + + /* Find the first unused connection in conns. */ + for(i = 0; i < NCONNS && conns[i] != NULL; i++); + + if (i == NCONNS) { + sendstr("No more connections available, sorry."NEWLINE, com->conn); + return ESUCCESS; + } + + sendstr("Opening connection to ", com->conn); + netconn_write(com->conn, com->args[0], strlen(com->args[0]), NETCONN_COPY); + sendstr(":", com->conn); + netconn_write(com->conn, com->args[1], strlen(com->args[1]), NETCONN_COPY); + sendstr(NEWLINE, com->conn); + + conns[i] = netconn_new(NETCONN_TCP); + if (conns[i] == NULL) { + sendstr("Could not create connection identifier (out of memory)."NEWLINE, com->conn); + return ESUCCESS; + } + err = netconn_connect(conns[i], &ipaddr, port); + if (err != ERR_OK) { + fprintf(stderr, "error %s"NEWLINE, lwip_strerr(err)); + sendstr("Could not connect to remote host: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + netconn_delete(conns[i]); + conns[i] = NULL; + return ESUCCESS; + } + + sendstr("Opened connection, connection identifier is ", com->conn); + snprintf((char *)buffer, sizeof(buffer), "%d"NEWLINE, i); + netconn_write(com->conn, buffer, strlen((const char *)buffer), NETCONN_COPY); + + return ESUCCESS; +} +/*-----------------------------------------------------------------------------------*/ +static s8_t +com_lstn(struct command *com) +{ + u16_t port; + int i; + err_t err; + long tmp; + + tmp = strtol(com->args[0], NULL, 10); + if((tmp < 0) || (tmp > 0xffff)) { + sendstr("Invalid port number."NEWLINE, com->conn); + return ESUCCESS; + } + port = (u16_t)tmp; + + /* Find the first unused connection in conns. */ + for(i = 0; i < NCONNS && conns[i] != NULL; i++); + + if (i == NCONNS) { + sendstr("No more connections available, sorry."NEWLINE, com->conn); + return ESUCCESS; + } + + sendstr("Opening a listening connection on port ", com->conn); + netconn_write(com->conn, com->args[0], strlen(com->args[0]), NETCONN_COPY); + sendstr(NEWLINE, com->conn); + + conns[i] = netconn_new(NETCONN_TCP); + if (conns[i] == NULL) { + sendstr("Could not create connection identifier (out of memory)."NEWLINE, com->conn); + return ESUCCESS; + } + + err = netconn_bind(conns[i], IP_ADDR_ANY, port); + if (err != ERR_OK) { + netconn_delete(conns[i]); + conns[i] = NULL; + sendstr("Could not bind: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + return ESUCCESS; + } + + err = netconn_listen(conns[i]); + if (err != ERR_OK) { + netconn_delete(conns[i]); + conns[i] = NULL; + sendstr("Could not listen: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + return ESUCCESS; + } + + sendstr("Opened connection, connection identifier is ", com->conn); + snprintf((char *)buffer, sizeof(buffer), "%d"NEWLINE, i); + netconn_write(com->conn, buffer, strlen((const char *)buffer), NETCONN_COPY); + + return ESUCCESS; +} +/*-----------------------------------------------------------------------------------*/ +/*-----------------------------------------------------------------------------------*/ +static s8_t +com_clos(struct command *com) +{ + int i; + err_t err; + + i = strtol(com->args[0], NULL, 10); + + if (i > NCONNS) { + sendstr("Connection identifier too high."NEWLINE, com->conn); + return ESUCCESS; + } + if (conns[i] == NULL) { + sendstr("Connection identifier not in use."NEWLINE, com->conn); + return ESUCCESS; + } + + err = netconn_close(conns[i]); + if (err != ERR_OK) { + sendstr("Could not close connection: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + return ESUCCESS; + } + + sendstr("Connection closed."NEWLINE, com->conn); + netconn_delete(conns[i]); + conns[i] = NULL; + return ESUCCESS; +} +/*-----------------------------------------------------------------------------------*/ +static s8_t +com_acpt(struct command *com) +{ + int i, j; + err_t err; + + /* Find the first unused connection in conns. */ + for(j = 0; j < NCONNS && conns[j] != NULL; j++); + + if (j == NCONNS) { + sendstr("No more connections available, sorry."NEWLINE, com->conn); + return ESUCCESS; + } + + i = strtol(com->args[0], NULL, 10); + + if (i > NCONNS) { + sendstr("Connection identifier too high."NEWLINE, com->conn); + return ESUCCESS; + } + if (conns[i] == NULL) { + sendstr("Connection identifier not in use."NEWLINE, com->conn); + return ESUCCESS; + } + + err = netconn_accept(conns[i], &conns[j]); + + if (err != ERR_OK) { + sendstr("Could not accept connection: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + return ESUCCESS; + } + + sendstr("Accepted connection, connection identifier for new connection is ", com->conn); + snprintf((char *)buffer, sizeof(buffer), "%d"NEWLINE, j); + netconn_write(com->conn, buffer, strlen((const char *)buffer), NETCONN_COPY); + + return ESUCCESS; +} +/*-----------------------------------------------------------------------------------*/ +#if LWIP_STATS +static void +com_stat_write_mem(struct netconn *conn, struct stats_mem *elem, int i) +{ + u16_t len; + char buf[100]; + size_t slen; + +#ifdef LWIP_DEBUG + LWIP_UNUSED_ARG(i); + slen = strlen(elem->name); + netconn_write(conn, elem->name, slen, NETCONN_COPY); +#else /* LWIP_DEBUG */ + len = (u16_t)sprintf(buf, "%d", i); + slen = strlen(buf); + netconn_write(conn, buf, slen, NETCONN_COPY); +#endif /* LWIP_DEBUG */ + if(slen < 10) { + netconn_write(conn, padding_10spaces, 10-slen, NETCONN_COPY); + } + + len = (u16_t)sprintf(buf, " * available %"MEM_SIZE_F NEWLINE, elem->avail); + netconn_write(conn, buf, len, NETCONN_COPY); + len = (u16_t)sprintf(buf, " * used %"MEM_SIZE_F NEWLINE, elem->used); + netconn_write(conn, buf, len, NETCONN_COPY); + len = (u16_t)sprintf(buf, " * high water mark %"MEM_SIZE_F NEWLINE, elem->max); + netconn_write(conn, buf, len, NETCONN_COPY); + len = (u16_t)sprintf(buf, " * errors %"STAT_COUNTER_F NEWLINE, elem->err); + netconn_write(conn, buf, len, NETCONN_COPY); + len = (u16_t)sprintf(buf, " * illegal %"STAT_COUNTER_F NEWLINE, elem->illegal); + netconn_write(conn, buf, len, NETCONN_COPY); +} +static void +com_stat_write_sys(struct netconn *conn, struct stats_syselem *elem, const char *name) +{ + u16_t len; + char buf[100]; + size_t slen = strlen(name); + + netconn_write(conn, name, slen, NETCONN_COPY); + if(slen < 10) { + netconn_write(conn, padding_10spaces, 10-slen, NETCONN_COPY); + } + + len = (u16_t)sprintf(buf, " * used %"STAT_COUNTER_F NEWLINE, elem->used); + netconn_write(conn, buf, len, NETCONN_COPY); + len = (u16_t)sprintf(buf, " * high water mark %"STAT_COUNTER_F NEWLINE, elem->max); + netconn_write(conn, buf, len, NETCONN_COPY); + len = (u16_t)sprintf(buf, " * errors %"STAT_COUNTER_F NEWLINE, elem->err); + netconn_write(conn, buf, len, NETCONN_COPY); +} +static s8_t +com_stat(struct command *com) +{ +#if PROTOCOL_STATS || MEMP_STATS + size_t i; +#endif /* PROTOCOL_STATS || MEMP_STATS */ +#if PROTOCOL_STATS + size_t k; + char buf[100]; + u16_t len; + + /* protocol stats, @todo: add IGMP */ + for(i = 0; i < num_protostats; i++) { + size_t s = sizeof(struct stats_proto)/sizeof(STAT_COUNTER); + STAT_COUNTER *c = &shell_stat_proto_stats[i]->xmit; + LWIP_ASSERT("stats not in sync", s == sizeof(stat_msgs_proto)/sizeof(char*)); + netconn_write(com->conn, shell_stat_proto_names[i], strlen(shell_stat_proto_names[i]), NETCONN_COPY); + for(k = 0; k < s; k++) { + len = (u16_t)sprintf(buf, "%s%"STAT_COUNTER_F NEWLINE, stat_msgs_proto[k], c[k]); + netconn_write(com->conn, buf, len, NETCONN_COPY); + } + } +#endif /* PROTOCOL_STATS */ +#if MEM_STATS + com_stat_write_mem(com->conn, &lwip_stats.mem, -1); +#endif /* MEM_STATS */ +#if MEMP_STATS + for(i = 0; i < MEMP_MAX; i++) { + com_stat_write_mem(com->conn, lwip_stats.memp[i], -1); + } +#endif /* MEMP_STATS */ +#if SYS_STATS + com_stat_write_sys(com->conn, &lwip_stats.sys.sem, "SEM "); + com_stat_write_sys(com->conn, &lwip_stats.sys.mutex, "MUTEX "); + com_stat_write_sys(com->conn, &lwip_stats.sys.mbox, "MBOX "); +#endif /* SYS_STATS */ + + return ESUCCESS; +} +#endif +/*-----------------------------------------------------------------------------------*/ +static s8_t +com_send(struct command *com) +{ + int i; + err_t err; + size_t len; + + i = strtol(com->args[0], NULL, 10); + + if (i > NCONNS) { + sendstr("Connection identifier too high."NEWLINE, com->conn); + return ESUCCESS; + } + + if (conns[i] == NULL) { + sendstr("Connection identifier not in use."NEWLINE, com->conn); + return ESUCCESS; + } + + len = strlen(com->args[1]); + com->args[1][len] = '\r'; + com->args[1][len + 1] = '\n'; + com->args[1][len + 2] = 0; + + err = netconn_write(conns[i], com->args[1], len + 3, NETCONN_COPY); + if (err != ERR_OK) { + sendstr("Could not send data: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + return ESUCCESS; + } + + sendstr("Data enqueued for sending."NEWLINE, com->conn); + return ESUCCESS; +} +/*-----------------------------------------------------------------------------------*/ +static s8_t +com_recv(struct command *com) +{ + int i; + err_t err; + struct netbuf *buf; + u16_t len; + + i = strtol(com->args[0], NULL, 10); + + if (i > NCONNS) { + sendstr("Connection identifier too high."NEWLINE, com->conn); + return ESUCCESS; + } + + if (conns[i] == NULL) { + sendstr("Connection identifier not in use."NEWLINE, com->conn); + return ESUCCESS; + } + + err = netconn_recv(conns[i], &buf); + if (err == ERR_OK) { + + netbuf_copy(buf, buffer, BUFSIZE); + len = netbuf_len(buf); + sendstr("Reading from connection:"NEWLINE, com->conn); + netconn_write(com->conn, buffer, len, NETCONN_COPY); + netbuf_delete(buf); + } else { + sendstr("EOF."NEWLINE, com->conn); + } + err = netconn_err(conns[i]); + if (err != ERR_OK) { + sendstr("Could not receive data: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + return ESUCCESS; + } + return ESUCCESS; +} +/*-----------------------------------------------------------------------------------*/ +static s8_t +com_udpc(struct command *com) +{ + ip_addr_t ipaddr; + u16_t lport, rport; + int i; + err_t err; + long tmp; + + tmp = strtol(com->args[0], NULL, 10); + if((tmp < 0) || (tmp > 0xffff)) { + sendstr("Invalid port number."NEWLINE, com->conn); + return ESUCCESS; + } + lport = (u16_t)tmp; + if (ipaddr_aton(com->args[1], &ipaddr) == -1) { + sendstr(strerror(errno), com->conn); + return ESYNTAX; + } + tmp = strtol(com->args[2], NULL, 10); + if((tmp < 0) || (tmp > 0xffff)) { + sendstr("Invalid port number."NEWLINE, com->conn); + return ESUCCESS; + } + rport = (u16_t)tmp; + + /* Find the first unused connection in conns. */ + for(i = 0; i < NCONNS && conns[i] != NULL; i++); + + if (i == NCONNS) { + sendstr("No more connections available, sorry."NEWLINE, com->conn); + return ESUCCESS; + } + + sendstr("Setting up UDP connection from port ", com->conn); + netconn_write(com->conn, com->args[0], strlen(com->args[0]), NETCONN_COPY); + sendstr(" to ", com->conn); + netconn_write(com->conn, com->args[1], strlen(com->args[1]), NETCONN_COPY); + sendstr(":", com->conn); + netconn_write(com->conn, com->args[2], strlen(com->args[2]), NETCONN_COPY); + sendstr(NEWLINE, com->conn); + + conns[i] = netconn_new(NETCONN_UDP); + if (conns[i] == NULL) { + sendstr("Could not create connection identifier (out of memory)."NEWLINE, com->conn); + return ESUCCESS; + } + + err = netconn_connect(conns[i], &ipaddr, rport); + if (err != ERR_OK) { + netconn_delete(conns[i]); + conns[i] = NULL; + sendstr("Could not connect to remote host: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + return ESUCCESS; + } + + err = netconn_bind(conns[i], IP_ADDR_ANY, lport); + if (err != ERR_OK) { + netconn_delete(conns[i]); + conns[i] = NULL; + sendstr("Could not bind: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + return ESUCCESS; + } + + sendstr("Connection set up, connection identifier is ", com->conn); + snprintf((char *)buffer, sizeof(buffer), "%d"NEWLINE, i); + netconn_write(com->conn, buffer, strlen((const char *)buffer), NETCONN_COPY); + + return ESUCCESS; +} +/*-----------------------------------------------------------------------------------*/ +static s8_t +com_udpl(struct command *com) +{ + ip_addr_t ipaddr; + u16_t lport, rport; + int i; + err_t err; + long tmp; + + tmp = strtol(com->args[0], NULL, 10); + if((tmp < 0) || (tmp > 0xffff)) { + sendstr("Invalid port number."NEWLINE, com->conn); + return ESUCCESS; + } + lport = (u16_t)tmp; + if (ipaddr_aton(com->args[1], &ipaddr) == -1) { + sendstr(strerror(errno), com->conn); + return ESYNTAX; + } + tmp = strtol(com->args[2], NULL, 10); + if((tmp < 0) || (tmp > 0xffff)) { + sendstr("Invalid port number."NEWLINE, com->conn); + return ESUCCESS; + } + rport = (u16_t)tmp; + + /* Find the first unused connection in conns. */ + for(i = 0; i < NCONNS && conns[i] != NULL; i++); + + if (i == NCONNS) { + sendstr("No more connections available, sorry."NEWLINE, com->conn); + return ESUCCESS; + } + + sendstr("Setting up UDP-Lite connection from port ", com->conn); + netconn_write(com->conn, com->args[0], strlen(com->args[0]), NETCONN_COPY); + sendstr(" to ", com->conn); + netconn_write(com->conn, com->args[1], strlen(com->args[1]), NETCONN_COPY); + sendstr(":", com->conn); + netconn_write(com->conn, com->args[2], strlen(com->args[2]), NETCONN_COPY); + sendstr(NEWLINE, com->conn); + + conns[i] = netconn_new(NETCONN_UDPLITE); + if (conns[i] == NULL) { + sendstr("Could not create connection identifier (out of memory)."NEWLINE, com->conn); + return ESUCCESS; + } + + err = netconn_connect(conns[i], &ipaddr, rport); + if (err != ERR_OK) { + netconn_delete(conns[i]); + conns[i] = NULL; + sendstr("Could not connect to remote host: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + return ESUCCESS; + } + + err = netconn_bind(conns[i], IP_ADDR_ANY, lport); + if (err != ERR_OK) { + netconn_delete(conns[i]); + conns[i] = NULL; + sendstr("Could not bind: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + return ESUCCESS; + } + + sendstr("Connection set up, connection identifier is ", com->conn); + snprintf((char *)buffer, sizeof(buffer), "%d"NEWLINE, i); + netconn_write(com->conn, buffer, strlen((const char *)buffer), NETCONN_COPY); + + return ESUCCESS; +} +/*-----------------------------------------------------------------------------------*/ +static s8_t +com_udpn(struct command *com) +{ + ip_addr_t ipaddr; + u16_t lport, rport; + int i; + err_t err; + long tmp; + + tmp = strtol(com->args[0], NULL, 10); + if((tmp < 0) || (tmp > 0xffff)) { + sendstr("Invalid port number."NEWLINE, com->conn); + return ESUCCESS; + } + lport = (u16_t)tmp; + if (ipaddr_aton(com->args[1], &ipaddr) == -1) { + sendstr(strerror(errno), com->conn); + return ESYNTAX; + } + tmp = strtol(com->args[2], NULL, 10); + if((tmp < 0) || (tmp > 0xffff)) { + sendstr("Invalid port number."NEWLINE, com->conn); + return ESUCCESS; + } + rport = (u16_t)tmp; + + /* Find the first unused connection in conns. */ + for(i = 0; i < NCONNS && conns[i] != NULL; i++); + + if (i == NCONNS) { + sendstr("No more connections available, sorry."NEWLINE, com->conn); + return ESUCCESS; + } + + sendstr("Setting up UDP connection without checksums from port ", com->conn); + netconn_write(com->conn, com->args[0], strlen(com->args[0]), NETCONN_COPY); + sendstr(" to ", com->conn); + netconn_write(com->conn, com->args[1], strlen(com->args[1]), NETCONN_COPY); + sendstr(":", com->conn); + netconn_write(com->conn, com->args[2], strlen(com->args[2]), NETCONN_COPY); + sendstr(NEWLINE, com->conn); + + conns[i] = netconn_new(NETCONN_UDPNOCHKSUM); + if (conns[i] == NULL) { + sendstr("Could not create connection identifier (out of memory)."NEWLINE, com->conn); + return ESUCCESS; + } + + err = netconn_connect(conns[i], &ipaddr, rport); + if (err != ERR_OK) { + netconn_delete(conns[i]); + conns[i] = NULL; + sendstr("Could not connect to remote host: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + return ESUCCESS; + } + + err = netconn_bind(conns[i], IP_ADDR_ANY, lport); + if (err != ERR_OK) { + netconn_delete(conns[i]); + conns[i] = NULL; + sendstr("Could not bind: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + return ESUCCESS; + } + + sendstr("Connection set up, connection identifier is ", com->conn); + snprintf((char *)buffer, sizeof(buffer), "%d"NEWLINE, i); + netconn_write(com->conn, buffer, strlen((const char *)buffer), NETCONN_COPY); + + return ESUCCESS; +} +/*-----------------------------------------------------------------------------------*/ +static s8_t +com_udpb(struct command *com) +{ + ip_addr_t ipaddr; +#if LWIP_IPV4 + u16_t lport; +#endif /* LWIP_IPV4 */ + u16_t rport; + int i; + err_t err; + long tmp; + + tmp = strtol(com->args[0], NULL, 10); + if((tmp < 0) || (tmp > 0xffff)) { + sendstr("Invalid port number."NEWLINE, com->conn); + return ESUCCESS; + } +#if LWIP_IPV4 + lport = (u16_t)tmp; +#endif /* LWIP_IPV4 */ + if (ipaddr_aton(com->args[1], &ipaddr) == -1) { + sendstr(strerror(errno), com->conn); + return ESYNTAX; + } + tmp = strtol(com->args[2], NULL, 10); + if((tmp < 0) || (tmp > 0xffff)) { + sendstr("Invalid port number."NEWLINE, com->conn); + return ESUCCESS; + } + rport = (u16_t)tmp; + + /* Find the first unused connection in conns. */ + for(i = 0; i < NCONNS && conns[i] != NULL; i++); + + if (i == NCONNS) { + sendstr("No more connections available, sorry."NEWLINE, com->conn); + return ESUCCESS; + } + + sendstr("Setting up UDP broadcast connection from port ", com->conn); + netconn_write(com->conn, com->args[0], strlen(com->args[0]), NETCONN_COPY); + sendstr(" to ", com->conn); + netconn_write(com->conn, com->args[1], strlen(com->args[1]), NETCONN_COPY); + sendstr(NEWLINE, com->conn); + + conns[i] = netconn_new(NETCONN_UDP); + if (conns[i] == NULL) { + sendstr("Could not create connection identifier (out of memory)."NEWLINE, com->conn); + return ESUCCESS; + } + + err = netconn_connect(conns[i], &ipaddr, rport); + if (err != ERR_OK) { + netconn_delete(conns[i]); + conns[i] = NULL; + sendstr("Could not connect to remote host: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + return ESUCCESS; + } + +#if LWIP_IPV4 + if (IP_IS_V6_VAL(ipaddr)) { + err = netconn_bind(conns[i], &ip_addr_broadcast, lport); + if (err != ERR_OK) { + netconn_delete(conns[i]); + conns[i] = NULL; + sendstr("Could not bind: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + return ESUCCESS; + } + } +#endif /* LWIP_IPV4 */ + + sendstr("Connection set up, connection identifier is ", com->conn); + snprintf((char *)buffer, sizeof(buffer), "%d"NEWLINE, i); + netconn_write(com->conn, buffer, strlen((const char *)buffer), NETCONN_COPY); + + return ESUCCESS; +} +/*-----------------------------------------------------------------------------------*/ +static s8_t +com_usnd(struct command *com) +{ + long i; + err_t err; + struct netbuf *buf; + char *mem; + u16_t len; + size_t tmp; + + i = strtol(com->args[0], NULL, 10); + + if (i > NCONNS) { + sendstr("Connection identifier too high."NEWLINE, com->conn); + return ESUCCESS; + } + + if (conns[i] == NULL) { + sendstr("Connection identifier not in use."NEWLINE, com->conn); + return ESUCCESS; + } + tmp = strlen(com->args[1]) + 1; + if (tmp > 0xffff) { + sendstr("Invalid length."NEWLINE, com->conn); + return ESUCCESS; + } + len = (u16_t)tmp; + + buf = netbuf_new(); + mem = (char *)netbuf_alloc(buf, len); + if (mem == NULL) { + sendstr("Could not allocate memory for sending."NEWLINE, com->conn); + return ESUCCESS; + } + strncpy(mem, com->args[1], len); + err = netconn_send(conns[i], buf); + netbuf_delete(buf); + if (err != ERR_OK) { + sendstr("Could not send data: ", com->conn); +#ifdef LWIP_DEBUG + sendstr(lwip_strerr(err), com->conn); +#else + sendstr("(debugging must be turned on for error message to appear)", com->conn); +#endif /* LWIP_DEBUG */ + sendstr(NEWLINE, com->conn); + return ESUCCESS; + } + + sendstr("Data sent."NEWLINE, com->conn); + return ESUCCESS; +} +/*-----------------------------------------------------------------------------------*/ +#if LWIP_SOCKET +/*-----------------------------------------------------------------------------------*/ +static s8_t +com_idxtoname(struct command *com) +{ + long i = strtol(com->args[0], NULL, 10); + + if (lwip_if_indextoname((unsigned int)i, (char *)buffer)) { + netconn_write(com->conn, buffer, strlen((const char *)buffer), NETCONN_COPY); + sendstr(NEWLINE, com->conn); + } else { + snprintf((char *)buffer, sizeof(buffer), "if_indextoname() failed: %d"NEWLINE, errno); + netconn_write(com->conn, buffer, strlen((const char *)buffer), NETCONN_COPY); + } + return ESUCCESS; +} +/*-----------------------------------------------------------------------------------*/ +static s8_t +com_nametoidx(struct command *com) +{ + unsigned int idx = lwip_if_nametoindex(com->args[0]); + + if (idx) { + snprintf((char *)buffer, sizeof(buffer), "%u"NEWLINE, idx); + netconn_write(com->conn, buffer, strlen((const char *)buffer), NETCONN_COPY); + } else { + sendstr("No interface found"NEWLINE, com->conn); + } + return ESUCCESS; +} +#endif /* LWIP_SOCKET */ +/*-----------------------------------------------------------------------------------*/ +#if LWIP_DNS +static s8_t +com_gethostbyname(struct command *com) +{ + ip_addr_t addr; + err_t err = netconn_gethostbyname(com->args[0], &addr); + + if (err == ERR_OK) { + if (ipaddr_ntoa_r(&addr, (char *)buffer, sizeof(buffer))) { + sendstr("Host found: ", com->conn); + sendstr((char *)buffer, com->conn); + sendstr(NEWLINE, com->conn); + } else { + sendstr("ipaddr_ntoa_r failed", com->conn); + } + } else { + sendstr("No host found"NEWLINE, com->conn); + } + return ESUCCESS; +} +#endif /* LWIP_DNS */ +/*-----------------------------------------------------------------------------------*/ +static s8_t +com_help(struct command *com) +{ + sendstr(help_msg1, com->conn); + sendstr(help_msg2, com->conn); + sendstr(help_msg3, com->conn); + return ESUCCESS; +} +/*-----------------------------------------------------------------------------------*/ +static s8_t +parse_command(struct command *com, u32_t len) +{ + u16_t i; + u16_t bufp; + + if (strncmp((const char *)buffer, "open", 4) == 0) { + com->exec = com_open; + com->nargs = 2; + } else if (strncmp((const char *)buffer, "lstn", 4) == 0) { + com->exec = com_lstn; + com->nargs = 1; + } else if (strncmp((const char *)buffer, "acpt", 4) == 0) { + com->exec = com_acpt; + com->nargs = 1; + } else if (strncmp((const char *)buffer, "clos", 4) == 0) { + com->exec = com_clos; + com->nargs = 1; +#if LWIP_STATS + } else if (strncmp((const char *)buffer, "stat", 4) == 0) { + com->exec = com_stat; + com->nargs = 0; +#endif + } else if (strncmp((const char *)buffer, "send", 4) == 0) { + com->exec = com_send; + com->nargs = 2; + } else if (strncmp((const char *)buffer, "recv", 4) == 0) { + com->exec = com_recv; + com->nargs = 1; + } else if (strncmp((const char *)buffer, "udpc", 4) == 0) { + com->exec = com_udpc; + com->nargs = 3; + } else if (strncmp((const char *)buffer, "udpb", 4) == 0) { + com->exec = com_udpb; + com->nargs = 2; + } else if (strncmp((const char *)buffer, "udpl", 4) == 0) { + com->exec = com_udpl; + com->nargs = 3; + } else if (strncmp((const char *)buffer, "udpn", 4) == 0) { + com->exec = com_udpn; + com->nargs = 3; + } else if (strncmp((const char *)buffer, "usnd", 4) == 0) { + com->exec = com_usnd; + com->nargs = 2; +#if LWIP_SOCKET + } else if (strncmp((const char *)buffer, "idxtoname", 9) == 0) { + com->exec = com_idxtoname; + com->nargs = 1; + } else if (strncmp((const char *)buffer, "nametoidx", 9) == 0) { + com->exec = com_nametoidx; + com->nargs = 1; +#endif /* LWIP_SOCKET */ +#if LWIP_DNS + } else if (strncmp((const char *)buffer, "gethostnm", 9) == 0) { + com->exec = com_gethostbyname; + com->nargs = 1; +#endif /* LWIP_DNS */ + } else if (strncmp((const char *)buffer, "help", 4) == 0) { + com->exec = com_help; + com->nargs = 0; + } else if (strncmp((const char *)buffer, "quit", 4) == 0) { + printf("quit"NEWLINE); + return ECLOSED; + } else { + return ESYNTAX; + } + + if (com->nargs == 0) { + return ESUCCESS; + } + bufp = 0; + for(; bufp < len && buffer[bufp] != ' '; bufp++); + for(i = 0; i < 10; i++) { + for(; bufp < len && buffer[bufp] == ' '; bufp++); + if (buffer[bufp] == '\r' || + buffer[bufp] == '\n') { + buffer[bufp] = 0; + if (i < com->nargs - 1) { + return ETOOFEW; + } + if (i > com->nargs - 1) { + return ETOOMANY; + } + break; + } + if (bufp > len) { + return ETOOFEW; + } + com->args[i] = (char *)&buffer[bufp]; + for(; bufp < len && buffer[bufp] != ' ' && buffer[bufp] != '\r' && + buffer[bufp] != '\n'; bufp++) { + if (buffer[bufp] == '\') { + buffer[bufp] = ' '; + } + } + if (bufp > len) { + return ESYNTAX; + } + buffer[bufp] = 0; + bufp++; + if (i == com->nargs - 1) { + break; + } + + } + + return ESUCCESS; +} +/*-----------------------------------------------------------------------------------*/ +static void +shell_error(s8_t err, struct netconn *conn) +{ + switch (err) { + case ESYNTAX: + sendstr("## Syntax error"NEWLINE, conn); + break; + case ETOOFEW: + sendstr("## Too few arguments to command given"NEWLINE, conn); + break; + case ETOOMANY: + sendstr("## Too many arguments to command given"NEWLINE, conn); + break; + case ECLOSED: + sendstr("## Connection closed"NEWLINE, conn); + break; + default: + /* unknown error, don't assert here */ + break; + } +} +/*-----------------------------------------------------------------------------------*/ +static void +prompt(struct netconn *conn) +{ + sendstr("> ", conn); +} +/*-----------------------------------------------------------------------------------*/ +static void +shell_main(struct netconn *conn) +{ + struct pbuf *p; + u16_t len = 0, cur_len; + struct command com; + s8_t err; + int i; + err_t ret; +#if SHELL_ECHO + void *echomem; +#endif /* SHELL_ECHO */ + + do { + ret = netconn_recv_tcp_pbuf(conn, &p); + if (ret == ERR_OK) { + pbuf_copy_partial(p, &buffer[len], (u16_t)(BUFSIZE - len), 0); + cur_len = p->tot_len; + len = (u16_t)(len + cur_len); + if ((len < cur_len) || (len > BUFSIZE)) { + len = BUFSIZE; + } +#if SHELL_ECHO + echomem = mem_malloc(cur_len); + if (echomem != NULL) { + pbuf_copy_partial(p, echomem, cur_len, 0); + netconn_write(conn, echomem, cur_len, NETCONN_COPY); + mem_free(echomem); + } +#endif /* SHELL_ECHO */ + pbuf_free(p); + if (((len > 0) && ((buffer[len-1] == '\r') || (buffer[len-1] == '\n'))) || + (len >= BUFSIZE)) { + if (buffer[0] != 0xff && + buffer[1] != 0xfe) { + err = parse_command(&com, len); + if (err == ESUCCESS) { + com.conn = conn; + err = com.exec(&com); + } + if (err == ECLOSED) { + printf("Closed"NEWLINE); + shell_error(err, conn); + goto close; + } + if (err != ESUCCESS) { + shell_error(err, conn); + } + } else { + sendstr(NEWLINE NEWLINE + "lwIP simple interactive shell."NEWLINE + "(c) Copyright 2001, Swedish Institute of Computer Science."NEWLINE + "Written by Adam Dunkels."NEWLINE + "For help, try the "help" command."NEWLINE, conn); + } + if (ret == ERR_OK) { + prompt(conn); + } + len = 0; + } + } + } while (ret == ERR_OK); + printf("err %s"NEWLINE, lwip_strerr(ret)); + +close: + netconn_close(conn); + + for(i = 0; i < NCONNS; i++) { + if (conns[i] != NULL) { + netconn_delete(conns[i]); + } + conns[i] = NULL; + } +} +/*-----------------------------------------------------------------------------------*/ +static void +shell_thread(void *arg) +{ + struct netconn *conn, *newconn; + err_t err; + LWIP_UNUSED_ARG(arg); + +#if LWIP_IPV6 + conn = netconn_new(NETCONN_TCP_IPV6); + LWIP_ERROR("shell: invalid conn", (conn != NULL), return;); + err = netconn_bind(conn, IP6_ADDR_ANY, 23); +#else /* LWIP_IPV6 */ + conn = netconn_new(NETCONN_TCP); + LWIP_ERROR("shell: invalid conn", (conn != NULL), return;); + err = netconn_bind(conn, IP_ADDR_ANY, 23); +#endif /* LWIP_IPV6 */ + LWIP_ERROR("shell: netconn_bind failed", (err == ERR_OK), netconn_delete(conn); return;); + err = netconn_listen(conn); + LWIP_ERROR("shell: netconn_listen failed", (err == ERR_OK), netconn_delete(conn); return;); + + while (1) { + err = netconn_accept(conn, &newconn); + if (err == ERR_OK) { + shell_main(newconn); + netconn_delete(newconn); + } + } +} +/*-----------------------------------------------------------------------------------*/ +void +shell_init(void) +{ + sys_thread_new("shell_thread", shell_thread, NULL, DEFAULT_THREAD_STACKSIZE, DEFAULT_THREAD_PRIO); +} + +#endif /* LWIP_NETCONN && LWIP_TCP */ diff --git a/contrib/apps/shell/shell.h b/contrib/apps/shell/shell.h new file mode 100644 index 00000000000..1ba9d1926e9 --- /dev/null +++ b/contrib/apps/shell/shell.h @@ -0,0 +1,37 @@ +/* + * Copyright (c) 2001-2003 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Adam Dunkels adam@sics.se + * + */ +#ifndef LWIP_SHELL_H +#define LWIP_SHELL_H + +void shell_init(void); + +#endif /* LWIP_SHELL_H */ diff --git a/contrib/apps/socket_examples/socket_examples.c b/contrib/apps/socket_examples/socket_examples.c new file mode 100644 index 00000000000..a60156f0e3a --- /dev/null +++ b/contrib/apps/socket_examples/socket_examples.c @@ -0,0 +1,680 @@ + +#include "socket_examples.h" + +#include "lwip/opt.h" + +#if LWIP_SOCKET && (LWIP_IPV4 || LWIP_IPV6) + +#include "lwip/sockets.h" +#include "lwip/sys.h" + +#include <string.h> +#include <stdio.h> + +#ifndef SOCK_TARGET_HOST4 +#define SOCK_TARGET_HOST4 "192.168.0.1" +#endif + +#ifndef SOCK_TARGET_HOST6 +#define SOCK_TARGET_HOST6 "FE80::12:34FF:FE56:78AB" +#endif + +#ifndef SOCK_TARGET_PORT +#define SOCK_TARGET_PORT 80 +#endif + +#ifndef SOCK_TARGET_MAXHTTPPAGESIZE +#define SOCK_TARGET_MAXHTTPPAGESIZE 1024 +#endif + +#ifndef SOCKET_EXAMPLES_RUN_PARALLEL +#define SOCKET_EXAMPLES_RUN_PARALLEL 0 +#endif + +static const u8_t cmpbuf[8] = {0xab, 0xab, 0xab, 0xab, 0xab, 0xab, 0xab, 0xab}; + +/* a helper struct to ensure memory before/after fd_set is not touched */ +typedef struct _xx +{ + u8_t buf1[8]; + fd_set readset; + u8_t buf2[8]; + fd_set writeset; + u8_t buf3[8]; + fd_set errset; + u8_t buf4[8]; +} fdsets; + +#define INIT_FDSETS(sets) do { \ + memset((sets)->buf1, 0xab, 8); \ + memset((sets)->buf2, 0xab, 8); \ + memset((sets)->buf3, 0xab, 8); \ + memset((sets)->buf4, 0xab, 8); \ +}while(0) + +#define CHECK_FDSETS(sets) do { \ + LWIP_ASSERT("buf1 fail", !memcmp((sets)->buf1, cmpbuf, 8)); \ + LWIP_ASSERT("buf2 fail", !memcmp((sets)->buf2, cmpbuf, 8)); \ + LWIP_ASSERT("buf3 fail", !memcmp((sets)->buf3, cmpbuf, 8)); \ + LWIP_ASSERT("buf4 fail", !memcmp((sets)->buf4, cmpbuf, 8)); \ +}while(0) + +static ip_addr_t dstaddr; + +/** This is an example function that tests + blocking- and nonblocking connect. */ +static void +sockex_nonblocking_connect(void *arg) +{ +#if LWIP_SOCKET_SELECT + int s; + int ret; + int opt; +#if LWIP_IPV6 + struct sockaddr_in6 addr; +#else /* LWIP_IPV6 */ + struct sockaddr_in addr; +#endif /* LWIP_IPV6 */ + fdsets sets; + struct timeval tv; + u32_t ticks_a, ticks_b; + int err; + const ip_addr_t *ipaddr = (const ip_addr_t*)arg; + struct pollfd fds; + INIT_FDSETS(&sets); + + /* set up address to connect to */ + memset(&addr, 0, sizeof(addr)); +#if LWIP_IPV6 + addr.sin6_len = sizeof(addr); + addr.sin6_family = AF_INET6; + addr.sin6_port = PP_HTONS(SOCK_TARGET_PORT); + inet6_addr_from_ip6addr(&addr.sin6_addr, ip_2_ip6(ipaddr)); +#else /* LWIP_IPV6 */ + addr.sin_len = sizeof(addr); + addr.sin_family = AF_INET; + addr.sin_port = PP_HTONS(SOCK_TARGET_PORT); + inet_addr_from_ip4addr(&addr.sin_addr, ip_2_ip4(ipaddr)); +#endif /* LWIP_IPV6 */ + + /* first try blocking: */ + + /* create the socket */ +#if LWIP_IPV6 + s = lwip_socket(AF_INET6, SOCK_STREAM, 0); +#else /* LWIP_IPV6 */ + s = lwip_socket(AF_INET, SOCK_STREAM, 0); +#endif /* LWIP_IPV6 */ + LWIP_ASSERT("s >= 0", s >= 0); + + /* connect */ + ret = lwip_connect(s, (struct sockaddr*)&addr, sizeof(addr)); + /* should succeed */ + LWIP_ASSERT("ret == 0", ret == 0); + + /* write something */ + ret = lwip_write(s, "test", 4); + LWIP_ASSERT("ret == 4", ret == 4); + + /* close */ + ret = lwip_close(s); + LWIP_ASSERT("ret == 0", ret == 0); + + /* now try nonblocking and close before being connected */ + + /* create the socket */ +#if LWIP_IPV6 + s = lwip_socket(AF_INET6, SOCK_STREAM, 0); +#else /* LWIP_IPV6 */ + s = lwip_socket(AF_INET, SOCK_STREAM, 0); +#endif /* LWIP_IPV6 */ + LWIP_ASSERT("s >= 0", s >= 0); + /* nonblocking */ + opt = lwip_fcntl(s, F_GETFL, 0); + LWIP_ASSERT("ret != -1", ret != -1); + opt |= O_NONBLOCK; + ret = lwip_fcntl(s, F_SETFL, opt); + LWIP_ASSERT("ret != -1", ret != -1); + /* connect */ + ret = lwip_connect(s, (struct sockaddr*)&addr, sizeof(addr)); + /* should have an error: "inprogress" */ + LWIP_ASSERT("ret == -1", ret == -1); + err = errno; + LWIP_ASSERT("errno == EINPROGRESS", err == EINPROGRESS); + /* close */ + ret = lwip_close(s); + LWIP_ASSERT("ret == 0", ret == 0); + /* try to close again, should fail with EBADF */ + ret = lwip_close(s); + LWIP_ASSERT("ret == -1", ret == -1); + err = errno; + LWIP_ASSERT("errno == EBADF", err == EBADF); + printf("closing socket in nonblocking connect succeeded\n"); + + /* now try nonblocking, connect should succeed: + this test only works if it is fast enough, i.e. no breakpoints, please! */ + + /* create the socket */ +#if LWIP_IPV6 + s = lwip_socket(AF_INET6, SOCK_STREAM, 0); +#else /* LWIP_IPV6 */ + s = lwip_socket(AF_INET, SOCK_STREAM, 0); +#endif /* LWIP_IPV6 */ + LWIP_ASSERT("s >= 0", s >= 0); + + /* nonblocking */ + opt = 1; + ret = lwip_ioctl(s, FIONBIO, &opt); + LWIP_ASSERT("ret == 0", ret == 0); + + /* connect */ + ret = lwip_connect(s, (struct sockaddr*)&addr, sizeof(addr)); + /* should have an error: "inprogress" */ + LWIP_ASSERT("ret == -1", ret == -1); + err = errno; + LWIP_ASSERT("errno == EINPROGRESS", err == EINPROGRESS); + + /* write should fail, too */ + ret = lwip_write(s, "test", 4); + LWIP_ASSERT("ret == -1", ret == -1); + err = errno; + LWIP_ASSERT("errno == EINPROGRESS", err == EINPROGRESS); + + CHECK_FDSETS(&sets); + FD_ZERO(&sets.readset); + CHECK_FDSETS(&sets); + FD_SET(s, &sets.readset); + CHECK_FDSETS(&sets); + FD_ZERO(&sets.writeset); + CHECK_FDSETS(&sets); + FD_SET(s, &sets.writeset); + CHECK_FDSETS(&sets); + FD_ZERO(&sets.errset); + CHECK_FDSETS(&sets); + FD_SET(s, &sets.errset); + CHECK_FDSETS(&sets); + tv.tv_sec = 0; + tv.tv_usec = 0; + /* select without waiting should fail */ + ret = lwip_select(s + 1, &sets.readset, &sets.writeset, &sets.errset, &tv); + CHECK_FDSETS(&sets); + LWIP_ASSERT("ret == 0", ret == 0); + LWIP_ASSERT("!FD_ISSET(s, &writeset)", !FD_ISSET(s, &sets.writeset)); + LWIP_ASSERT("!FD_ISSET(s, &readset)", !FD_ISSET(s, &sets.readset)); + LWIP_ASSERT("!FD_ISSET(s, &errset)", !FD_ISSET(s, &sets.errset)); + + fds.fd = s; + fds.events = POLLIN|POLLOUT; + fds.revents = 0; + ret = lwip_poll(&fds, 1, 0); + LWIP_ASSERT("ret == 0", ret == 0); + LWIP_ASSERT("fds.revents == 0", fds.revents == 0); + + FD_ZERO(&sets.readset); + FD_SET(s, &sets.readset); + FD_ZERO(&sets.writeset); + FD_SET(s, &sets.writeset); + FD_ZERO(&sets.errset); + FD_SET(s, &sets.errset); + ticks_a = sys_now(); + /* select with waiting should succeed */ + ret = lwip_select(s + 1, &sets.readset, &sets.writeset, &sets.errset, NULL); + ticks_b = sys_now(); + LWIP_ASSERT("ret == 1", ret == 1); + LWIP_ASSERT("FD_ISSET(s, &writeset)", FD_ISSET(s, &sets.writeset)); + LWIP_ASSERT("!FD_ISSET(s, &readset)", !FD_ISSET(s, &sets.readset)); + LWIP_ASSERT("!FD_ISSET(s, &errset)", !FD_ISSET(s, &sets.errset)); + + fds.fd = s; + fds.events = POLLIN|POLLOUT; + fds.revents = 0; + ret = lwip_poll(&fds, 1, 0); + LWIP_ASSERT("ret == 1", ret == 1); + LWIP_ASSERT("fds.revents & POLLOUT", fds.revents & POLLOUT); + + /* now write should succeed */ + ret = lwip_write(s, "test", 4); + LWIP_ASSERT("ret == 4", ret == 4); + + /* close */ + ret = lwip_close(s); + LWIP_ASSERT("ret == 0", ret == 0); + + printf("select() needed %d ticks to return writable\n", (int)(ticks_b - ticks_a)); + + + /* now try nonblocking to invalid address: + this test only works if it is fast enough, i.e. no breakpoints, please! */ + + /* create the socket */ +#if LWIP_IPV6 + s = lwip_socket(AF_INET6, SOCK_STREAM, 0); +#else /* LWIP_IPV6 */ + s = lwip_socket(AF_INET, SOCK_STREAM, 0); +#endif /* LWIP_IPV6 */ + LWIP_ASSERT("s >= 0", s >= 0); + + /* nonblocking */ + opt = 1; + ret = lwip_ioctl(s, FIONBIO, &opt); + LWIP_ASSERT("ret == 0", ret == 0); + +#if LWIP_IPV6 + addr.sin6_addr.un.u8_addr[0]++; /* this should result in an invalid address */ +#else /* LWIP_IPV6 */ + addr.sin_addr.s_addr++; /* this should result in an invalid address */ +#endif /* LWIP_IPV6 */ + + /* connect */ + ret = lwip_connect(s, (struct sockaddr*)&addr, sizeof(addr)); + /* should have an error: "inprogress" */ + LWIP_ASSERT("ret == -1", ret == -1); + err = errno; + LWIP_ASSERT("errno == EINPROGRESS", err == EINPROGRESS); + + /* write should fail, too */ + ret = lwip_write(s, "test", 4); + LWIP_ASSERT("ret == -1", ret == -1); + err = errno; + LWIP_ASSERT("errno == EINPROGRESS", err == EINPROGRESS); + LWIP_UNUSED_ARG(err); + + FD_ZERO(&sets.readset); + FD_SET(s, &sets.readset); + FD_ZERO(&sets.writeset); + FD_SET(s, &sets.writeset); + FD_ZERO(&sets.errset); + FD_SET(s, &sets.errset); + tv.tv_sec = 0; + tv.tv_usec = 0; + /* select without waiting should fail */ + ret = lwip_select(s + 1, &sets.readset, &sets.writeset, &sets.errset, &tv); + LWIP_ASSERT("ret == 0", ret == 0); + + FD_ZERO(&sets.readset); + FD_SET(s, &sets.readset); + FD_ZERO(&sets.writeset); + FD_SET(s, &sets.writeset); + FD_ZERO(&sets.errset); + FD_SET(s, &sets.errset); + ticks_a = sys_now(); + /* select with waiting should eventually succeed and return errset! */ + ret = lwip_select(s + 1, &sets.readset, &sets.writeset, &sets.errset, NULL); + ticks_b = sys_now(); + LWIP_ASSERT("ret > 0", ret > 0); + LWIP_ASSERT("FD_ISSET(s, &errset)", FD_ISSET(s, &sets.errset)); + /*LWIP_ASSERT("!FD_ISSET(s, &readset)", !FD_ISSET(s, &sets.readset)); + LWIP_ASSERT("!FD_ISSET(s, &writeset)", !FD_ISSET(s, &sets.writeset));*/ + + /* close */ + ret = lwip_close(s); + LWIP_ASSERT("ret == 0", ret == 0); + LWIP_UNUSED_ARG(ret); + + printf("select() needed %d ticks to return error\n", (int)(ticks_b - ticks_a)); + printf("sockex_nonblocking_connect finished successfully\n"); +#else + LWIP_UNUSED_ARG(arg); +#endif +} + +/** This is an example function that tests + the recv function (timeout etc.). */ +static void +sockex_testrecv(void *arg) +{ + int s; + int ret; + int err; +#if LWIP_SO_SNDRCVTIMEO_NONSTANDARD + int opt, opt2; +#else + struct timeval opt, opt2; +#endif + socklen_t opt2size; +#if LWIP_IPV6 + struct sockaddr_in6 addr; +#else /* LWIP_IPV6 */ + struct sockaddr_in addr; +#endif /* LWIP_IPV6 */ + size_t len; + char rxbuf[SOCK_TARGET_MAXHTTPPAGESIZE]; +#if LWIP_SOCKET_SELECT + fd_set readset; + fd_set errset; + struct timeval tv; +#endif + const ip_addr_t *ipaddr = (const ip_addr_t*)arg; + + /* set up address to connect to */ + memset(&addr, 0, sizeof(addr)); +#if LWIP_IPV6 + addr.sin6_len = sizeof(addr); + addr.sin6_family = AF_INET6; + addr.sin6_port = PP_HTONS(SOCK_TARGET_PORT); + inet6_addr_from_ip6addr(&addr.sin6_addr, ip_2_ip6(ipaddr)); +#else /* LWIP_IPV6 */ + addr.sin_len = sizeof(addr); + addr.sin_family = AF_INET; + addr.sin_port = PP_HTONS(SOCK_TARGET_PORT); + inet_addr_from_ip4addr(&addr.sin_addr, ip_2_ip4(ipaddr)); +#endif /* LWIP_IPV6 */ + + /* first try blocking: */ + + /* create the socket */ +#if LWIP_IPV6 + s = lwip_socket(AF_INET6, SOCK_STREAM, 0); +#else /* LWIP_IPV6 */ + s = lwip_socket(AF_INET, SOCK_STREAM, 0); +#endif /* LWIP_IPV6 */ + LWIP_ASSERT("s >= 0", s >= 0); + + /* connect */ + ret = lwip_connect(s, (struct sockaddr*)&addr, sizeof(addr)); + /* should succeed */ + LWIP_ASSERT("ret == 0", ret == 0); + + /* set recv timeout (100 ms) */ +#if LWIP_SO_SNDRCVTIMEO_NONSTANDARD + opt = 100; +#else + opt.tv_sec = 0; + opt.tv_usec = 100 * 1000; +#endif + ret = lwip_setsockopt(s, SOL_SOCKET, SO_RCVTIMEO, &opt, sizeof(opt)); + LWIP_ASSERT("ret == 0", ret == 0); +#if LWIP_SO_SNDRCVTIMEO_NONSTANDARD + opt2 = 0; +#else + opt2.tv_sec = 0; + opt2.tv_usec = 0; +#endif + opt2size = sizeof(opt2); + ret = lwip_getsockopt(s, SOL_SOCKET, SO_RCVTIMEO, &opt2, &opt2size); + LWIP_ASSERT("ret == 0", ret == 0); + LWIP_ASSERT("opt2size == sizeof(opt2)", opt2size == sizeof(opt2)); +#if LWIP_SO_SNDRCVTIMEO_NONSTANDARD + LWIP_ASSERT("opt == opt2", opt == opt2); +#else + LWIP_ASSERT("opt == opt2", opt.tv_sec == opt2.tv_sec); + LWIP_ASSERT("opt == opt2", opt.tv_usec == opt2.tv_usec); +#endif + + /* write the start of a GET request */ +#define SNDSTR1 "G" + len = strlen(SNDSTR1); + ret = lwip_write(s, SNDSTR1, len); + LWIP_ASSERT("ret == len", ret == (int)len); + + /* should time out if the other side is a good HTTP server */ + ret = lwip_read(s, rxbuf, 1); + LWIP_ASSERT("ret == -1", ret == -1); + err = errno; + LWIP_ASSERT("errno == EAGAIN", err == EAGAIN); + LWIP_UNUSED_ARG(err); + + /* write the rest of a GET request */ +#define SNDSTR2 "ET / HTTP_1.1\r\n\r\n" + len = strlen(SNDSTR2); + ret = lwip_write(s, SNDSTR2, len); + LWIP_ASSERT("ret == len", ret == (int)len); + + /* wait a while: should be enough for the server to send a response */ + sys_msleep(1000); + + /* should not time out but receive a response */ + ret = lwip_read(s, rxbuf, SOCK_TARGET_MAXHTTPPAGESIZE); + LWIP_ASSERT("ret > 0", ret > 0); + +#if LWIP_SOCKET_SELECT + /* now select should directly return because the socket is readable */ + FD_ZERO(&readset); + FD_ZERO(&errset); + FD_SET(s, &readset); + FD_SET(s, &errset); + tv.tv_sec = 10; + tv.tv_usec = 0; + ret = lwip_select(s + 1, &readset, NULL, &errset, &tv); + LWIP_ASSERT("ret == 1", ret == 1); + LWIP_ASSERT("!FD_ISSET(s, &errset)", !FD_ISSET(s, &errset)); + LWIP_ASSERT("FD_ISSET(s, &readset)", FD_ISSET(s, &readset)); +#endif + + /* should not time out but receive a response */ + ret = lwip_read(s, rxbuf, SOCK_TARGET_MAXHTTPPAGESIZE); + /* might receive a second packet for HTTP/1.1 servers */ + if (ret > 0) { + /* should return 0: closed */ + ret = lwip_read(s, rxbuf, SOCK_TARGET_MAXHTTPPAGESIZE); + LWIP_ASSERT("ret == 0", ret == 0); + } + + /* close */ + ret = lwip_close(s); + LWIP_ASSERT("ret == 0", ret == 0); + LWIP_UNUSED_ARG(ret); + + printf("sockex_testrecv finished successfully\n"); +} + +#if LWIP_SOCKET_SELECT +/** helper struct for the 2 functions below (multithreaded: thread-argument) */ +struct sockex_select_helper { + int socket; + int wait_read; + int expect_read; + int wait_write; + int expect_write; + int wait_err; + int expect_err; + int wait_ms; + sys_sem_t sem; +}; + +/** helper thread to wait for socket events using select */ +static void +sockex_select_waiter(void *arg) +{ + struct sockex_select_helper *helper = (struct sockex_select_helper *)arg; + int ret; + fd_set readset; + fd_set writeset; + fd_set errset; + struct timeval tv; + + LWIP_ASSERT("helper != NULL", helper != NULL); + + FD_ZERO(&readset); + FD_ZERO(&writeset); + FD_ZERO(&errset); + if (helper->wait_read) { + FD_SET(helper->socket, &readset); + } + if (helper->wait_write) { + FD_SET(helper->socket, &writeset); + } + if (helper->wait_err) { + FD_SET(helper->socket, &errset); + } + + tv.tv_sec = helper->wait_ms / 1000; + tv.tv_usec = (helper->wait_ms % 1000) * 1000; + + ret = lwip_select(helper->socket, &readset, &writeset, &errset, &tv); + if (helper->expect_read || helper->expect_write || helper->expect_err) { + LWIP_ASSERT("ret > 0", ret > 0); + } else { + LWIP_ASSERT("ret == 0", ret == 0); + } + LWIP_UNUSED_ARG(ret); + if (helper->expect_read) { + LWIP_ASSERT("FD_ISSET(helper->socket, &readset)", FD_ISSET(helper->socket, &readset)); + } else { + LWIP_ASSERT("!FD_ISSET(helper->socket, &readset)", !FD_ISSET(helper->socket, &readset)); + } + if (helper->expect_write) { + LWIP_ASSERT("FD_ISSET(helper->socket, &writeset)", FD_ISSET(helper->socket, &writeset)); + } else { + LWIP_ASSERT("!FD_ISSET(helper->socket, &writeset)", !FD_ISSET(helper->socket, &writeset)); + } + if (helper->expect_err) { + LWIP_ASSERT("FD_ISSET(helper->socket, &errset)", FD_ISSET(helper->socket, &errset)); + } else { + LWIP_ASSERT("!FD_ISSET(helper->socket, &errset)", !FD_ISSET(helper->socket, &errset)); + } + sys_sem_signal(&helper->sem); +} + +/** This is an example function that tests + more than one thread being active in select. */ +static void +sockex_testtwoselects(void *arg) +{ + int s1; + int s2; + int ret; +#if LWIP_IPV6 + struct sockaddr_in6 addr; +#else /* LWIP_IPV6 */ + struct sockaddr_in addr; +#endif /* LWIP_IPV6 */ + size_t len; + err_t lwiperr; + struct sockex_select_helper h1, h2, h3, h4; + const ip_addr_t *ipaddr = (const ip_addr_t*)arg; + + /* set up address to connect to */ + memset(&addr, 0, sizeof(addr)); +#if LWIP_IPV6 + addr.sin6_len = sizeof(addr); + addr.sin6_family = AF_INET6; + addr.sin6_port = PP_HTONS(SOCK_TARGET_PORT); + inet6_addr_from_ip6addr(&addr.sin6_addr, ip_2_ip6(ipaddr)); +#else /* LWIP_IPV6 */ + addr.sin_len = sizeof(addr); + addr.sin_family = AF_INET; + addr.sin_port = PP_HTONS(SOCK_TARGET_PORT); + inet_addr_from_ip4addr(&addr.sin_addr, ip_2_ip4(ipaddr)); +#endif /* LWIP_IPV6 */ + + /* create the sockets */ +#if LWIP_IPV6 + s1 = lwip_socket(AF_INET6, SOCK_STREAM, 0); + s2 = lwip_socket(AF_INET6, SOCK_STREAM, 0); +#else /* LWIP_IPV6 */ + s1 = lwip_socket(AF_INET, SOCK_STREAM, 0); + s2 = lwip_socket(AF_INET, SOCK_STREAM, 0); +#endif /* LWIP_IPV6 */ + LWIP_ASSERT("s1 >= 0", s1 >= 0); + LWIP_ASSERT("s2 >= 0", s2 >= 0); + + /* connect, should succeed */ + ret = lwip_connect(s1, (struct sockaddr*)&addr, sizeof(addr)); + LWIP_ASSERT("ret == 0", ret == 0); + ret = lwip_connect(s2, (struct sockaddr*)&addr, sizeof(addr)); + LWIP_ASSERT("ret == 0", ret == 0); + + /* write the start of a GET request */ +#define SNDSTR1 "G" + len = strlen(SNDSTR1); + ret = lwip_write(s1, SNDSTR1, len); + LWIP_ASSERT("ret == len", ret == (int)len); + ret = lwip_write(s2, SNDSTR1, len); + LWIP_ASSERT("ret == len", ret == (int)len); + LWIP_UNUSED_ARG(ret); + + h1.wait_read = 1; + h1.wait_write = 1; + h1.wait_err = 1; + h1.expect_read = 0; + h1.expect_write = 0; + h1.expect_err = 0; + lwiperr = sys_sem_new(&h1.sem, 0); + LWIP_ASSERT("lwiperr == ERR_OK", lwiperr == ERR_OK); + h1.socket = s1; + h1.wait_ms = 500; + + h2 = h1; + lwiperr = sys_sem_new(&h2.sem, 0); + LWIP_ASSERT("lwiperr == ERR_OK", lwiperr == ERR_OK); + h2.socket = s2; + h2.wait_ms = 1000; + + h3 = h1; + lwiperr = sys_sem_new(&h3.sem, 0); + LWIP_ASSERT("lwiperr == ERR_OK", lwiperr == ERR_OK); + h3.socket = s2; + h3.wait_ms = 1500; + + h4 = h1; + lwiperr = sys_sem_new(&h4.sem, 0); + LWIP_ASSERT("lwiperr == ERR_OK", lwiperr == ERR_OK); + LWIP_UNUSED_ARG(lwiperr); + h4.socket = s2; + h4.wait_ms = 2000; + + /* select: all sockets should time out if the other side is a good HTTP server */ + + sys_thread_new("sockex_select_waiter1", sockex_select_waiter, &h2, 0, 0); + sys_msleep(100); + sys_thread_new("sockex_select_waiter2", sockex_select_waiter, &h1, 0, 0); + sys_msleep(100); + sys_thread_new("sockex_select_waiter2", sockex_select_waiter, &h4, 0, 0); + sys_msleep(100); + sys_thread_new("sockex_select_waiter2", sockex_select_waiter, &h3, 0, 0); + + sys_sem_wait(&h1.sem); + sys_sem_wait(&h2.sem); + sys_sem_wait(&h3.sem); + sys_sem_wait(&h4.sem); + + /* close */ + ret = lwip_close(s1); + LWIP_ASSERT("ret == 0", ret == 0); + ret = lwip_close(s2); + LWIP_ASSERT("ret == 0", ret == 0); + + printf("sockex_testtwoselects finished successfully\n"); +} +#else +static void +sockex_testtwoselects(void *arg) +{ + LWIP_UNUSED_ARG(arg); +} +#endif + +#if !SOCKET_EXAMPLES_RUN_PARALLEL +static void +socket_example_test(void* arg) +{ + sys_msleep(1000); + sockex_nonblocking_connect(arg); + sockex_testrecv(arg); + sockex_testtwoselects(arg); + printf("all tests done, thread ending\n"); +} +#endif + +void socket_examples_init(void) +{ + int addr_ok; +#if LWIP_IPV6 + IP_SET_TYPE_VAL(dstaddr, IPADDR_TYPE_V6); + addr_ok = ip6addr_aton(SOCK_TARGET_HOST6, ip_2_ip6(&dstaddr)); +#else /* LWIP_IPV6 */ + IP_SET_TYPE_VAL(dstaddr, IPADDR_TYPE_V4); + addr_ok = ip4addr_aton(SOCK_TARGET_HOST4, ip_2_ip4(&dstaddr)); +#endif /* LWIP_IPV6 */ + LWIP_ASSERT("invalid address", addr_ok); +#if SOCKET_EXAMPLES_RUN_PARALLEL + sys_thread_new("sockex_nonblocking_connect", sockex_nonblocking_connect, &dstaddr, 0, 0); + sys_thread_new("sockex_testrecv", sockex_testrecv, &dstaddr, 0, 0); + sys_thread_new("sockex_testtwoselects", sockex_testtwoselects, &dstaddr, 0, 0); +#else + sys_thread_new("socket_example_test", socket_example_test, &dstaddr, 0, 0); +#endif +} + +#endif /* LWIP_SOCKET */ diff --git a/contrib/apps/socket_examples/socket_examples.h b/contrib/apps/socket_examples/socket_examples.h new file mode 100644 index 00000000000..354d03add0f --- /dev/null +++ b/contrib/apps/socket_examples/socket_examples.h @@ -0,0 +1,6 @@ +#ifndef LWIP_SOCKET_EXAMPLES_H +#define LWIP_SOCKET_EXAMPLES_H + +void socket_examples_init(void); + +#endif /* LWIP_SOCKET_EXAMPLES_H */ diff --git a/contrib/apps/tcpecho/tcpecho.c b/contrib/apps/tcpecho/tcpecho.c new file mode 100644 index 00000000000..8fe13596ab6 --- /dev/null +++ b/contrib/apps/tcpecho/tcpecho.c @@ -0,0 +1,101 @@ +/* + * Copyright (c) 2001-2003 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Adam Dunkels adam@sics.se + * + */ +#include "tcpecho.h" + +#include "lwip/opt.h" + +#if LWIP_NETCONN + +#include "lwip/sys.h" +#include "lwip/api.h" +/*-----------------------------------------------------------------------------------*/ +static void +tcpecho_thread(void *arg) +{ + struct netconn *conn, *newconn; + err_t err; + LWIP_UNUSED_ARG(arg); + + /* Create a new connection identifier. */ + /* Bind connection to well known port number 7. */ +#if LWIP_IPV6 + conn = netconn_new(NETCONN_TCP_IPV6); + netconn_bind(conn, IP6_ADDR_ANY, 7); +#else /* LWIP_IPV6 */ + conn = netconn_new(NETCONN_TCP); + netconn_bind(conn, IP_ADDR_ANY, 7); +#endif /* LWIP_IPV6 */ + LWIP_ERROR("tcpecho: invalid conn", (conn != NULL), return;); + + /* Tell connection to go into listening mode. */ + netconn_listen(conn); + + while (1) { + + /* Grab new connection. */ + err = netconn_accept(conn, &newconn); + /*printf("accepted new connection %p\n", newconn);*/ + /* Process the new connection. */ + if (err == ERR_OK) { + struct netbuf *buf; + void *data; + u16_t len; + + while ((err = netconn_recv(newconn, &buf)) == ERR_OK) { + /*printf("Recved\n");*/ + do { + netbuf_data(buf, &data, &len); + err = netconn_write(newconn, data, len, NETCONN_COPY); +#if 0 + if (err != ERR_OK) { + printf("tcpecho: netconn_write: error "%s"\n", lwip_strerr(err)); + } +#endif + } while (netbuf_next(buf) >= 0); + netbuf_delete(buf); + } + /*printf("Got EOF, looping\n");*/ + /* Close connection and discard connection identifier. */ + netconn_close(newconn); + netconn_delete(newconn); + } + } +} +/*-----------------------------------------------------------------------------------*/ +void +tcpecho_init(void) +{ + sys_thread_new("tcpecho_thread", tcpecho_thread, NULL, DEFAULT_THREAD_STACKSIZE, DEFAULT_THREAD_PRIO); +} +/*-----------------------------------------------------------------------------------*/ + +#endif /* LWIP_NETCONN */ diff --git a/contrib/apps/tcpecho/tcpecho.h b/contrib/apps/tcpecho/tcpecho.h new file mode 100644 index 00000000000..b27c50f2038 --- /dev/null +++ b/contrib/apps/tcpecho/tcpecho.h @@ -0,0 +1,38 @@ +/* + * Copyright (c) 2001-2003 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Adam Dunkels adam@sics.se + * + */ + +#ifndef LWIP_TCPECHO_H +#define LWIP_TCPECHO_H + +void tcpecho_init(void); + +#endif /* LWIP_TCPECHO_H */ diff --git a/contrib/apps/tcpecho_raw/tcpecho_raw.c b/contrib/apps/tcpecho_raw/tcpecho_raw.c new file mode 100644 index 00000000000..5a71d84b55e --- /dev/null +++ b/contrib/apps/tcpecho_raw/tcpecho_raw.c @@ -0,0 +1,301 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of and a contribution to the lwIP TCP/IP stack. + * + * Credits go to Adam Dunkels (and the current maintainers) of this software. + * + * Christiaan Simons rewrote this file to get a more stable echo example. + */ + +/** + * @file + * TCP echo server example using raw API. + * + * Echos all bytes sent by connecting client, + * and passively closes when client is done. + * + */ + +#include "lwip/opt.h" +#include "lwip/debug.h" +#include "lwip/stats.h" +#include "lwip/tcp.h" +#include "tcpecho_raw.h" + +#if LWIP_TCP && LWIP_CALLBACK_API + +static struct tcp_pcb *tcpecho_raw_pcb; + +enum tcpecho_raw_states +{ + ES_NONE = 0, + ES_ACCEPTED, + ES_RECEIVED, + ES_CLOSING +}; + +struct tcpecho_raw_state +{ + u8_t state; + u8_t retries; + struct tcp_pcb *pcb; + /* pbuf (chain) to recycle */ + struct pbuf *p; +}; + +static void +tcpecho_raw_free(struct tcpecho_raw_state *es) +{ + if (es != NULL) { + if (es->p) { + /* free the buffer chain if present */ + pbuf_free(es->p); + } + + mem_free(es); + } +} + +static void +tcpecho_raw_close(struct tcp_pcb *tpcb, struct tcpecho_raw_state *es) +{ + tcp_arg(tpcb, NULL); + tcp_sent(tpcb, NULL); + tcp_recv(tpcb, NULL); + tcp_err(tpcb, NULL); + tcp_poll(tpcb, NULL, 0); + + tcpecho_raw_free(es); + + tcp_close(tpcb); +} + +static void +tcpecho_raw_send(struct tcp_pcb *tpcb, struct tcpecho_raw_state *es) +{ + struct pbuf *ptr; + err_t wr_err = ERR_OK; + + while ((wr_err == ERR_OK) && + (es->p != NULL) && + (es->p->len <= tcp_sndbuf(tpcb))) { + ptr = es->p; + + /* enqueue data for transmission */ + wr_err = tcp_write(tpcb, ptr->payload, ptr->len, 1); + if (wr_err == ERR_OK) { + u16_t plen; + + plen = ptr->len; + /* continue with next pbuf in chain (if any) */ + es->p = ptr->next; + if(es->p != NULL) { + /* new reference! */ + pbuf_ref(es->p); + } + /* chop first pbuf from chain */ + pbuf_free(ptr); + /* we can read more data now */ + tcp_recved(tpcb, plen); + } else if(wr_err == ERR_MEM) { + /* we are low on memory, try later / harder, defer to poll */ + es->p = ptr; + } else { + /* other problem ?? */ + } + } +} + +static void +tcpecho_raw_error(void *arg, err_t err) +{ + struct tcpecho_raw_state *es; + + LWIP_UNUSED_ARG(err); + + es = (struct tcpecho_raw_state *)arg; + + tcpecho_raw_free(es); +} + +static err_t +tcpecho_raw_poll(void *arg, struct tcp_pcb *tpcb) +{ + err_t ret_err; + struct tcpecho_raw_state *es; + + es = (struct tcpecho_raw_state *)arg; + if (es != NULL) { + if (es->p != NULL) { + /* there is a remaining pbuf (chain) */ + tcpecho_raw_send(tpcb, es); + } else { + /* no remaining pbuf (chain) */ + if(es->state == ES_CLOSING) { + tcpecho_raw_close(tpcb, es); + } + } + ret_err = ERR_OK; + } else { + /* nothing to be done */ + tcp_abort(tpcb); + ret_err = ERR_ABRT; + } + return ret_err; +} + +static err_t +tcpecho_raw_sent(void *arg, struct tcp_pcb *tpcb, u16_t len) +{ + struct tcpecho_raw_state *es; + + LWIP_UNUSED_ARG(len); + + es = (struct tcpecho_raw_state *)arg; + es->retries = 0; + + if(es->p != NULL) { + /* still got pbufs to send */ + tcp_sent(tpcb, tcpecho_raw_sent); + tcpecho_raw_send(tpcb, es); + } else { + /* no more pbufs to send */ + if(es->state == ES_CLOSING) { + tcpecho_raw_close(tpcb, es); + } + } + return ERR_OK; +} + +static err_t +tcpecho_raw_recv(void *arg, struct tcp_pcb *tpcb, struct pbuf *p, err_t err) +{ + struct tcpecho_raw_state *es; + err_t ret_err; + + LWIP_ASSERT("arg != NULL",arg != NULL); + es = (struct tcpecho_raw_state *)arg; + if (p == NULL) { + /* remote host closed connection */ + es->state = ES_CLOSING; + if(es->p == NULL) { + /* we're done sending, close it */ + tcpecho_raw_close(tpcb, es); + } else { + /* we're not done yet */ + tcpecho_raw_send(tpcb, es); + } + ret_err = ERR_OK; + } else if(err != ERR_OK) { + /* cleanup, for unknown reason */ + LWIP_ASSERT("no pbuf expected here", p == NULL); + ret_err = err; + } + else if(es->state == ES_ACCEPTED) { + /* first data chunk in p->payload */ + es->state = ES_RECEIVED; + /* store reference to incoming pbuf (chain) */ + es->p = p; + tcpecho_raw_send(tpcb, es); + ret_err = ERR_OK; + } else if (es->state == ES_RECEIVED) { + /* read some more data */ + if(es->p == NULL) { + es->p = p; + tcpecho_raw_send(tpcb, es); + } else { + struct pbuf *ptr; + + /* chain pbufs to the end of what we recv'ed previously */ + ptr = es->p; + pbuf_cat(ptr,p); + } + ret_err = ERR_OK; + } else { + /* unknown es->state, trash data */ + tcp_recved(tpcb, p->tot_len); + pbuf_free(p); + ret_err = ERR_OK; + } + return ret_err; +} + +static err_t +tcpecho_raw_accept(void *arg, struct tcp_pcb *newpcb, err_t err) +{ + err_t ret_err; + struct tcpecho_raw_state *es; + + LWIP_UNUSED_ARG(arg); + if ((err != ERR_OK) || (newpcb == NULL)) { + return ERR_VAL; + } + + /* Unless this pcb should have NORMAL priority, set its priority now. + When running out of pcbs, low priority pcbs can be aborted to create + new pcbs of higher priority. */ + tcp_setprio(newpcb, TCP_PRIO_MIN); + + es = (struct tcpecho_raw_state *)mem_malloc(sizeof(struct tcpecho_raw_state)); + if (es != NULL) { + es->state = ES_ACCEPTED; + es->pcb = newpcb; + es->retries = 0; + es->p = NULL; + /* pass newly allocated es to our callbacks */ + tcp_arg(newpcb, es); + tcp_recv(newpcb, tcpecho_raw_recv); + tcp_err(newpcb, tcpecho_raw_error); + tcp_poll(newpcb, tcpecho_raw_poll, 0); + tcp_sent(newpcb, tcpecho_raw_sent); + ret_err = ERR_OK; + } else { + ret_err = ERR_MEM; + } + return ret_err; +} + +void +tcpecho_raw_init(void) +{ + tcpecho_raw_pcb = tcp_new_ip_type(IPADDR_TYPE_ANY); + if (tcpecho_raw_pcb != NULL) { + err_t err; + + err = tcp_bind(tcpecho_raw_pcb, IP_ANY_TYPE, 7); + if (err == ERR_OK) { + tcpecho_raw_pcb = tcp_listen(tcpecho_raw_pcb); + tcp_accept(tcpecho_raw_pcb, tcpecho_raw_accept); + } else { + /* abort? output diagnostic? */ + } + } else { + /* abort? output diagnostic? */ + } +} + +#endif /* LWIP_TCP && LWIP_CALLBACK_API */ diff --git a/contrib/apps/tcpecho_raw/tcpecho_raw.h b/contrib/apps/tcpecho_raw/tcpecho_raw.h new file mode 100644 index 00000000000..d1e3b33dd43 --- /dev/null +++ b/contrib/apps/tcpecho_raw/tcpecho_raw.h @@ -0,0 +1,35 @@ +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + */ +#ifndef LWIP_TCPECHO_RAW_H +#define LWIP_TCPECHO_RAW_H + +void tcpecho_raw_init(void); + +#endif /* LWIP_TCPECHO_RAW_H */ diff --git a/contrib/apps/udpecho/udpecho.c b/contrib/apps/udpecho/udpecho.c new file mode 100644 index 00000000000..b68301e38b7 --- /dev/null +++ b/contrib/apps/udpecho/udpecho.c @@ -0,0 +1,88 @@ +/* + * Copyright (c) 2001-2003 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Adam Dunkels adam@sics.se + * + */ + +#include "udpecho.h" + +#include "lwip/opt.h" + +#if LWIP_NETCONN + +#include "lwip/api.h" +#include "lwip/sys.h" + +/*-----------------------------------------------------------------------------------*/ +static void +udpecho_thread(void *arg) +{ + struct netconn *conn; + struct netbuf *buf; + char buffer[4096]; + err_t err; + LWIP_UNUSED_ARG(arg); + +#if LWIP_IPV6 + conn = netconn_new(NETCONN_UDP_IPV6); + LWIP_ERROR("udpecho: invalid conn", (conn != NULL), return;); + netconn_bind(conn, IP6_ADDR_ANY, 7); +#else /* LWIP_IPV6 */ + conn = netconn_new(NETCONN_UDP); + LWIP_ERROR("udpecho: invalid conn", (conn != NULL), return;); + netconn_bind(conn, IP_ADDR_ANY, 7); +#endif /* LWIP_IPV6 */ + + while (1) { + err = netconn_recv(conn, &buf); + if (err == ERR_OK) { + /* no need netconn_connect here, since the netbuf contains the address */ + if(netbuf_copy(buf, buffer, sizeof(buffer)) != buf->p->tot_len) { + LWIP_DEBUGF(LWIP_DBG_ON, ("netbuf_copy failed\n")); + } else { + buffer[buf->p->tot_len] = '\0'; + err = netconn_send(conn, buf); + if(err != ERR_OK) { + LWIP_DEBUGF(LWIP_DBG_ON, ("netconn_send failed: %d\n", (int)err)); + } else { + LWIP_DEBUGF(LWIP_DBG_ON, ("got %s\n", buffer)); + } + } + netbuf_delete(buf); + } + } +} +/*-----------------------------------------------------------------------------------*/ +void +udpecho_init(void) +{ + sys_thread_new("udpecho_thread", udpecho_thread, NULL, DEFAULT_THREAD_STACKSIZE, DEFAULT_THREAD_PRIO); +} + +#endif /* LWIP_NETCONN */ diff --git a/contrib/apps/udpecho/udpecho.h b/contrib/apps/udpecho/udpecho.h new file mode 100644 index 00000000000..c43891128cd --- /dev/null +++ b/contrib/apps/udpecho/udpecho.h @@ -0,0 +1,37 @@ +/* + * Copyright (c) 2001-2003 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Adam Dunkels adam@sics.se + * + */ +#ifndef LWIP_UDPECHO_H +#define LWIP_UDPECHO_H + +void udpecho_init(void); + +#endif /* LWIP_UDPECHO_H */ diff --git a/contrib/apps/udpecho_raw/udpecho_raw.c b/contrib/apps/udpecho_raw/udpecho_raw.c new file mode 100644 index 00000000000..43c9f0b119c --- /dev/null +++ b/contrib/apps/udpecho_raw/udpecho_raw.c @@ -0,0 +1,88 @@ +/* + * Copyright (c) 2016 Stephan Linz linz@li-pro.net, Li-Pro.Net + * All rights reserved. + * + * Based on examples provided by + * Iwan Budi Kusnanto ibk@labhijau.net (https://gist.github.com/iwanbk/1399729) + * Juri Haberland juri@sapienti-sat.org (https://lists.gnu.org/archive/html/lwip-users/2007-06/msg00078.html) + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of and a contribution to the lwIP TCP/IP stack. + * + * Credits go to Adam Dunkels (and the current maintainers) of this software. + * + * Stephan Linz rewrote this file to get a basic echo example. + */ + +/** + * @file + * UDP echo server example using raw API. + * + * Echos all bytes sent by connecting client, + * and passively closes when client is done. + * + */ + +#include "lwip/opt.h" +#include "lwip/debug.h" +#include "lwip/stats.h" +#include "lwip/udp.h" +#include "udpecho_raw.h" + +#if LWIP_UDP + +static struct udp_pcb *udpecho_raw_pcb; + +static void +udpecho_raw_recv(void *arg, struct udp_pcb *upcb, struct pbuf *p, + const ip_addr_t *addr, u16_t port) +{ + LWIP_UNUSED_ARG(arg); + if (p != NULL) { + /* send received packet back to sender */ + udp_sendto(upcb, p, addr, port); + /* free the pbuf */ + pbuf_free(p); + } +} + +void +udpecho_raw_init(void) +{ + udpecho_raw_pcb = udp_new_ip_type(IPADDR_TYPE_ANY); + if (udpecho_raw_pcb != NULL) { + err_t err; + + err = udp_bind(udpecho_raw_pcb, IP_ANY_TYPE, 7); + if (err == ERR_OK) { + udp_recv(udpecho_raw_pcb, udpecho_raw_recv, NULL); + } else { + /* abort? output diagnostic? */ + } + } else { + /* abort? output diagnostic? */ + } +} + +#endif /* LWIP_UDP */ diff --git a/contrib/apps/udpecho_raw/udpecho_raw.h b/contrib/apps/udpecho_raw/udpecho_raw.h new file mode 100644 index 00000000000..4a98b7402e2 --- /dev/null +++ b/contrib/apps/udpecho_raw/udpecho_raw.h @@ -0,0 +1,39 @@ +/* + * Copyright (c) 2016 Stephan Linz linz@li-pro.net, Li-Pro.Net + * All rights reserved. + * + * Based on examples provided by + * Iwan Budi Kusnanto ibk@labhijau.net (https://gist.github.com/iwanbk/1399729) + * Juri Haberland juri@sapienti-sat.org (https://lists.gnu.org/archive/html/lwip-users/2007-06/msg00078.html) + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + */ +#ifndef LWIP_UDPECHO_RAW_H +#define LWIP_UDPECHO_RAW_H + +void udpecho_raw_init(void); + +#endif /* LWIP_UDPECHO_RAW_H */ diff --git a/contrib/examples/ethernetif/ethernetif.c b/contrib/examples/ethernetif/ethernetif.c new file mode 100644 index 00000000000..79763e8b3cc --- /dev/null +++ b/contrib/examples/ethernetif/ethernetif.c @@ -0,0 +1,337 @@ +/** + * @file + * Ethernet Interface Skeleton + * + */ + +/* + * Copyright (c) 2001-2004 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Adam Dunkels adam@sics.se + * + */ + +/* + * This file is a skeleton for developing Ethernet network interface + * drivers for lwIP. Add code to the low_level functions and do a + * search-and-replace for the word "ethernetif" to replace it with + * something that better describes your network interface. + */ + +#include "lwip/opt.h" + +#if 0 /* don't build, this is only a skeleton, see previous comment */ + +#include "lwip/def.h" +#include "lwip/mem.h" +#include "lwip/pbuf.h" +#include "lwip/stats.h" +#include "lwip/snmp.h" +#include "lwip/ethip6.h" +#include "lwip/etharp.h" +#include "netif/ppp/pppoe.h" + +/* Define those to better describe your network interface. */ +#define IFNAME0 'e' +#define IFNAME1 'n' + +/** + * Helper struct to hold private data used to operate your ethernet interface. + * Keeping the ethernet address of the MAC in this struct is not necessary + * as it is already kept in the struct netif. + * But this is only an example, anyway... + */ +struct ethernetif { + struct eth_addr *ethaddr; + /* Add whatever per-interface state that is needed here. */ +}; + +/* Forward declarations. */ +static void ethernetif_input(struct netif *netif); + +/** + * In this function, the hardware should be initialized. + * Called from ethernetif_init(). + * + * @param netif the already initialized lwip network interface structure + * for this ethernetif + */ +static void +low_level_init(struct netif *netif) +{ + struct ethernetif *ethernetif = netif->state; + + /* set MAC hardware address length */ + netif->hwaddr_len = ETHARP_HWADDR_LEN; + + /* set MAC hardware address */ + netif->hwaddr[0] = ; + ... + netif->hwaddr[5] = ; + + /* maximum transfer unit */ + netif->mtu = 1500; + + /* device capabilities */ + /* don't set NETIF_FLAG_ETHARP if this device is not an ethernet one */ + netif->flags = NETIF_FLAG_BROADCAST | NETIF_FLAG_ETHARP | NETIF_FLAG_LINK_UP; + +#if LWIP_IPV6 && LWIP_IPV6_MLD + /* + * For hardware/netifs that implement MAC filtering. + * All-nodes link-local is handled by default, so we must let the hardware know + * to allow multicast packets in. + * Should set mld_mac_filter previously. */ + if (netif->mld_mac_filter != NULL) { + ip6_addr_t ip6_allnodes_ll; + ip6_addr_set_allnodes_linklocal(&ip6_allnodes_ll); + netif->mld_mac_filter(netif, &ip6_allnodes_ll, NETIF_ADD_MAC_FILTER); + } +#endif /* LWIP_IPV6 && LWIP_IPV6_MLD */ + + /* Do whatever else is needed to initialize interface. */ +} + +/** + * This function should do the actual transmission of the packet. The packet is + * contained in the pbuf that is passed to the function. This pbuf + * might be chained. + * + * @param netif the lwip network interface structure for this ethernetif + * @param p the MAC packet to send (e.g. IP packet including MAC addresses and type) + * @return ERR_OK if the packet could be sent + * an err_t value if the packet couldn't be sent + * + * @note Returning ERR_MEM here if a DMA queue of your MAC is full can lead to + * strange results. You might consider waiting for space in the DMA queue + * to become available since the stack doesn't retry to send a packet + * dropped because of memory failure (except for the TCP timers). + */ + +static err_t +low_level_output(struct netif *netif, struct pbuf *p) +{ + struct ethernetif *ethernetif = netif->state; + struct pbuf *q; + + initiate transfer(); + +#if ETH_PAD_SIZE + pbuf_remove_header(p, ETH_PAD_SIZE); /* drop the padding word */ +#endif + + for (q = p; q != NULL; q = q->next) { + /* Send the data from the pbuf to the interface, one pbuf at a + time. The size of the data in each pbuf is kept in the ->len + variable. */ + send data from(q->payload, q->len); + } + + signal that packet should be sent(); + + MIB2_STATS_NETIF_ADD(netif, ifoutoctets, p->tot_len); + if (((u8_t *)p->payload)[0] & 1) { + /* broadcast or multicast packet*/ + MIB2_STATS_NETIF_INC(netif, ifoutnucastpkts); + } else { + /* unicast packet */ + MIB2_STATS_NETIF_INC(netif, ifoutucastpkts); + } + /* increase ifoutdiscards or ifouterrors on error */ + +#if ETH_PAD_SIZE + pbuf_add_header(p, ETH_PAD_SIZE); /* reclaim the padding word */ +#endif + + LINK_STATS_INC(link.xmit); + + return ERR_OK; +} + +/** + * Should allocate a pbuf and transfer the bytes of the incoming + * packet from the interface into the pbuf. + * + * @param netif the lwip network interface structure for this ethernetif + * @return a pbuf filled with the received packet (including MAC header) + * NULL on memory error + */ +static struct pbuf * +low_level_input(struct netif *netif) +{ + struct ethernetif *ethernetif = netif->state; + struct pbuf *p, *q; + u16_t len; + + /* Obtain the size of the packet and put it into the "len" + variable. */ + len = ; + +#if ETH_PAD_SIZE + len += ETH_PAD_SIZE; /* allow room for Ethernet padding */ +#endif + + /* We allocate a pbuf chain of pbufs from the pool. */ + p = pbuf_alloc(PBUF_RAW, len, PBUF_POOL); + + if (p != NULL) { + +#if ETH_PAD_SIZE + pbuf_remove_header(p, ETH_PAD_SIZE); /* drop the padding word */ +#endif + + /* We iterate over the pbuf chain until we have read the entire + * packet into the pbuf. */ + for (q = p; q != NULL; q = q->next) { + /* Read enough bytes to fill this pbuf in the chain. The + * available data in the pbuf is given by the q->len + * variable. + * This does not necessarily have to be a memcpy, you can also preallocate + * pbufs for a DMA-enabled MAC and after receiving truncate it to the + * actually received size. In this case, ensure the tot_len member of the + * pbuf is the sum of the chained pbuf len members. + */ + read data into(q->payload, q->len); + } + acknowledge that packet has been read(); + + MIB2_STATS_NETIF_ADD(netif, ifinoctets, p->tot_len); + if (((u8_t *)p->payload)[0] & 1) { + /* broadcast or multicast packet*/ + MIB2_STATS_NETIF_INC(netif, ifinnucastpkts); + } else { + /* unicast packet*/ + MIB2_STATS_NETIF_INC(netif, ifinucastpkts); + } +#if ETH_PAD_SIZE + pbuf_add_header(p, ETH_PAD_SIZE); /* reclaim the padding word */ +#endif + + LINK_STATS_INC(link.recv); + } else { + drop packet(); + LINK_STATS_INC(link.memerr); + LINK_STATS_INC(link.drop); + MIB2_STATS_NETIF_INC(netif, ifindiscards); + } + + return p; +} + +/** + * This function should be called when a packet is ready to be read + * from the interface. It uses the function low_level_input() that + * should handle the actual reception of bytes from the network + * interface. Then the type of the received packet is determined and + * the appropriate input function is called. + * + * @param netif the lwip network interface structure for this ethernetif + */ +static void +ethernetif_input(struct netif *netif) +{ + struct ethernetif *ethernetif; + struct eth_hdr *ethhdr; + struct pbuf *p; + + ethernetif = netif->state; + + /* move received packet into a new pbuf */ + p = low_level_input(netif); + /* if no packet could be read, silently ignore this */ + if (p != NULL) { + /* pass all packets to ethernet_input, which decides what packets it supports */ + if (netif->input(p, netif) != ERR_OK) { + LWIP_DEBUGF(NETIF_DEBUG, ("ethernetif_input: IP input error\n")); + pbuf_free(p); + p = NULL; + } + } +} + +/** + * Should be called at the beginning of the program to set up the + * network interface. It calls the function low_level_init() to do the + * actual setup of the hardware. + * + * This function should be passed as a parameter to netif_add(). + * + * @param netif the lwip network interface structure for this ethernetif + * @return ERR_OK if the loopif is initialized + * ERR_MEM if private data couldn't be allocated + * any other err_t on error + */ +err_t +ethernetif_init(struct netif *netif) +{ + struct ethernetif *ethernetif; + + LWIP_ASSERT("netif != NULL", (netif != NULL)); + + ethernetif = mem_malloc(sizeof(struct ethernetif)); + if (ethernetif == NULL) { + LWIP_DEBUGF(NETIF_DEBUG, ("ethernetif_init: out of memory\n")); + return ERR_MEM; + } + +#if LWIP_NETIF_HOSTNAME + /* Initialize interface hostname */ + netif->hostname = "lwip"; +#endif /* LWIP_NETIF_HOSTNAME */ + + /* + * Initialize the snmp variables and counters inside the struct netif. + * The last argument should be replaced with your link speed, in units + * of bits per second. + */ + MIB2_INIT_NETIF(netif, snmp_ifType_ethernet_csmacd, LINK_SPEED_OF_YOUR_NETIF_IN_BPS); + + netif->state = ethernetif; + netif->name[0] = IFNAME0; + netif->name[1] = IFNAME1; + /* We directly use etharp_output() here to save a function call. + * You can instead declare your own function an call etharp_output() + * from it if you have to do some checks before sending (e.g. if link + * is available...) */ +#if LWIP_IPV4 + netif->output = etharp_output; +#endif /* LWIP_IPV4 */ +#if LWIP_IPV6 + netif->output_ip6 = ethip6_output; +#endif /* LWIP_IPV6 */ + netif->linkoutput = low_level_output; + + ethernetif->ethaddr = (struct eth_addr *) & (netif->hwaddr[0]); + + /* initialize the hardware */ + low_level_init(netif); + + return ERR_OK; +} + +#endif /* 0 */ diff --git a/contrib/examples/example_app/default_netif.h b/contrib/examples/example_app/default_netif.h new file mode 100644 index 00000000000..1a64f02e1db --- /dev/null +++ b/contrib/examples/example_app/default_netif.h @@ -0,0 +1,47 @@ +/* + * Copyright (c) 2001-2003 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Adam Dunkels adam@sics.se + * + */ + +#ifndef LWIP_DEFAULT_NETIF_H +#define LWIP_DEFAULT_NETIF_H + +#include "lwip/ip_addr.h" + +#if LWIP_IPV4 +void init_default_netif(const ip4_addr_t *ipaddr, const ip4_addr_t *netmask, const ip4_addr_t *gw); +#else +void init_default_netif(void); +#endif + +void default_netif_poll(void); +void default_netif_shutdown(void); + +#endif diff --git a/contrib/examples/example_app/lwipcfg.h.ci b/contrib/examples/example_app/lwipcfg.h.ci new file mode 100644 index 00000000000..dc8477c3e60 --- /dev/null +++ b/contrib/examples/example_app/lwipcfg.h.ci @@ -0,0 +1,73 @@ +/** + * Additional settings for the example app. + * Copy this to lwipcfg.h and make the config changes you need. + */ + +/* configuration for this port */ +#define PPP_USERNAME "Admin" +#define PPP_PASSWORD "pass" + +/** Define this to the index of the windows network adapter to use */ +#define PACKET_LIB_ADAPTER_NR 1 +/** Define this to the GUID of the windows network adapter to use + * or NOT define this if you want PACKET_LIB_ADAPTER_NR to be used */ +/*#define PACKET_LIB_ADAPTER_GUID "00000000-0000-0000-0000-000000000000"*/ +/*#define PACKET_LIB_GET_ADAPTER_NETADDRESS(addr) IP4_ADDR((addr), 192,168,1,0)*/ +/*#define PACKET_LIB_QUIET*/ + +/* #define USE_PCAPIF 1 */ +#define LWIP_PORT_INIT_IPADDR(addr) IP4_ADDR((addr), 192,168,1,200) +#define LWIP_PORT_INIT_GW(addr) IP4_ADDR((addr), 192,168,1,1) +#define LWIP_PORT_INIT_NETMASK(addr) IP4_ADDR((addr), 255,255,255,0) + +/* remember to change this MAC address to suit your needs! + the last octet will be increased by netif->num for each netif */ +#define LWIP_MAC_ADDR_BASE {0x00,0x01,0x02,0x03,0x04,0x05} + +/* #define USE_SLIPIF 0 */ +/* #define SIO_USE_COMPORT 0 */ +#ifdef USE_SLIPIF +#if USE_SLIPIF +#define LWIP_PORT_INIT_SLIP1_IPADDR(addr) IP4_ADDR((addr), 192, 168, 2, 2) +#define LWIP_PORT_INIT_SLIP1_GW(addr) IP4_ADDR((addr), 192, 168, 2, 1) +#define LWIP_PORT_INIT_SLIP1_NETMASK(addr) IP4_ADDR((addr), 255, 255, 255, 0) +#if USE_SLIPIF > 1 +#define LWIP_PORT_INIT_SLIP2_IPADDR(addr) IP4_ADDR((addr), 192, 168, 2, 1) +#define LWIP_PORT_INIT_SLIP2_GW(addr) IP4_ADDR((addr), 0, 0, 0, 0) +#define LWIP_PORT_INIT_SLIP2_NETMASK(addr) IP4_ADDR((addr), 255, 255, 255, 0)*/ +#endif /* USE_SLIPIF > 1 */ +#endif /* USE_SLIPIF */ +#endif /* USE_SLIPIF */ + +/* configuration for applications */ + +#define LWIP_CHARGEN_APP 1 +#define LWIP_DNS_APP 1 +#define LWIP_HTTPD_APP LWIP_TCP +/* Set this to 1 to use the netconn http server, + * otherwise the raw api server will be used. */ +/*#define LWIP_HTTPD_APP_NETCONN */ +#define LWIP_NETBIOS_APP LWIP_IPV4 && LWIP_UDP +#define LWIP_NETIO_APP 1 +#define LWIP_MDNS_APP LWIP_UDP +#define LWIP_MQTT_APP LWIP_TCP +#define LWIP_PING_APP 1 +#define LWIP_RTP_APP 1 +#define LWIP_SHELL_APP LWIP_TCP +#define LWIP_SNMP_APP LWIP_UDP +#define LWIP_SNTP_APP LWIP_UDP +#define LWIP_SOCKET_EXAMPLES_APP 1 +#define LWIP_TCPECHO_APP LWIP_TCP +/* Set this to 1 to use the netconn tcpecho server, + * otherwise the raw api server will be used. */ +/*#define LWIP_TCPECHO_APP_NETCONN */ +#define LWIP_TFTP_APP LWIP_UDP +#define LWIP_TFTP_CLIENT_APP LWIP_UDP +#define LWIP_UDPECHO_APP LWIP_UDP +#define LWIP_LWIPERF_APP LWIP_TCP + +#define USE_DHCP LWIP_DHCP +#define USE_AUTOIP LWIP_AUTOIP + +/* define this to your custom application-init function */ +/* #define LWIP_APP_INIT my_app_init() */ diff --git a/contrib/examples/example_app/lwipcfg.h.example b/contrib/examples/example_app/lwipcfg.h.example new file mode 100644 index 00000000000..b21e19b30b8 --- /dev/null +++ b/contrib/examples/example_app/lwipcfg.h.example @@ -0,0 +1,77 @@ +/** + * Additional settings for the example app. + * Copy this to lwipcfg.h and make the config changes you need. + */ + +/* configuration for this port */ +#define PPP_USERNAME "Admin" +#define PPP_PASSWORD "pass" + +/** Define this to the index of the windows network adapter to use */ +#define PACKET_LIB_ADAPTER_NR 1 +/** Define this to the GUID of the windows network adapter to use + * or NOT define this if you want PACKET_LIB_ADAPTER_NR to be used */ +/*#define PACKET_LIB_ADAPTER_GUID "00000000-0000-0000-0000-000000000000"*/ +/*#define PACKET_LIB_GET_ADAPTER_NETADDRESS(addr) IP4_ADDR((addr), 192,168,1,0)*/ +/*#define PACKET_LIB_QUIET*/ + +/* If these 2 are not defined, the corresponding config setting is used */ +/* #define USE_DHCP 0 */ +/* #define USE_AUTOIP 0 */ + +/* #define USE_PCAPIF 1 */ +#define LWIP_PORT_INIT_IPADDR(addr) IP4_ADDR((addr), 192,168,1,200) +#define LWIP_PORT_INIT_GW(addr) IP4_ADDR((addr), 192,168,1,1) +#define LWIP_PORT_INIT_NETMASK(addr) IP4_ADDR((addr), 255,255,255,0) + +/* remember to change this MAC address to suit your needs! + the last octet will be increased by netif->num for each netif */ +#define LWIP_MAC_ADDR_BASE {0x00,0x01,0x02,0x03,0x04,0x05} + +/* #define USE_SLIPIF 0 */ +/* #define SIO_USE_COMPORT 0 */ +#ifdef USE_SLIPIF +#if USE_SLIPIF +#define LWIP_PORT_INIT_SLIP1_IPADDR(addr) IP4_ADDR((addr), 192, 168, 2, 2) +#define LWIP_PORT_INIT_SLIP1_GW(addr) IP4_ADDR((addr), 192, 168, 2, 1) +#define LWIP_PORT_INIT_SLIP1_NETMASK(addr) IP4_ADDR((addr), 255, 255, 255, 0) +#if USE_SLIPIF > 1 +#define LWIP_PORT_INIT_SLIP2_IPADDR(addr) IP4_ADDR((addr), 192, 168, 2, 1) +#define LWIP_PORT_INIT_SLIP2_GW(addr) IP4_ADDR((addr), 0, 0, 0, 0) +#define LWIP_PORT_INIT_SLIP2_NETMASK(addr) IP4_ADDR((addr), 255, 255, 255, 0)*/ +#endif /* USE_SLIPIF > 1 */ +#endif /* USE_SLIPIF */ +#endif /* USE_SLIPIF */ + +/* configuration for applications */ + +#define LWIP_CHARGEN_APP 0 +#define LWIP_DNS_APP 0 +#define LWIP_HTTPD_APP 0 +/* Set this to 1 to use the netconn http server, + * otherwise the raw api server will be used. */ +/*#define LWIP_HTTPD_APP_NETCONN */ +#define LWIP_NETBIOS_APP 0 +#define LWIP_NETIO_APP 0 +#define LWIP_MDNS_APP 0 +#define LWIP_MQTT_APP 0 +#define LWIP_PING_APP 0 +#define LWIP_RTP_APP 0 +#define LWIP_SHELL_APP 0 +#define LWIP_SNMP_APP 0 +#define LWIP_SNTP_APP 0 +#define LWIP_SOCKET_EXAMPLES_APP 0 +#define LWIP_TCPECHO_APP 0 +/* Set this to 1 to use the netconn tcpecho server, + * otherwise the raw api server will be used. */ +/*#define LWIP_TCPECHO_APP_NETCONN */ +#define LWIP_TFTP_APP 0 +#define LWIP_TFTP_CLIENT_APP 0 +#define LWIP_UDPECHO_APP 0 +#define LWIP_LWIPERF_APP 0 + +/*#define USE_DHCP 1*/ +/*#define USE_AUTOIP 1*/ + +/* define this to your custom application-init function */ +/* #define LWIP_APP_INIT my_app_init() */ diff --git a/contrib/examples/example_app/lwipopts.h b/contrib/examples/example_app/lwipopts.h new file mode 100644 index 00000000000..ea2ca4bdae7 --- /dev/null +++ b/contrib/examples/example_app/lwipopts.h @@ -0,0 +1,326 @@ +/* + * Copyright (c) 2001-2003 Swedish Institute of Computer Science. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Adam Dunkels adam@sics.se + * + */ +#ifndef LWIP_LWIPOPTS_H +#define LWIP_LWIPOPTS_H + +#ifdef LWIP_OPTTEST_FILE +#include "lwipopts_test.h" +#else /* LWIP_OPTTEST_FILE */ + +#define LWIP_IPV4 1 +#define LWIP_IPV6 1 + +#define NO_SYS 0 +#define LWIP_SOCKET (NO_SYS==0) +#define LWIP_NETCONN (NO_SYS==0) +#define LWIP_NETIF_API (NO_SYS==0) + +#define LWIP_IGMP LWIP_IPV4 +#define LWIP_ICMP LWIP_IPV4 + +#define LWIP_SNMP LWIP_UDP +#define MIB2_STATS LWIP_SNMP +#ifdef LWIP_HAVE_MBEDTLS +#define LWIP_SNMP_V3 (LWIP_SNMP) +#endif + +#define LWIP_DNS LWIP_UDP +#define LWIP_MDNS_RESPONDER LWIP_UDP + +#define LWIP_NUM_NETIF_CLIENT_DATA (LWIP_MDNS_RESPONDER) + +#define LWIP_HAVE_LOOPIF 1 +#define LWIP_NETIF_LOOPBACK 1 +#define LWIP_LOOPBACK_MAX_PBUFS 10 + +#define TCP_LISTEN_BACKLOG 1 + +#define LWIP_COMPAT_SOCKETS 1 +#define LWIP_SO_RCVTIMEO 1 +#define LWIP_SO_RCVBUF 1 + +#define LWIP_TCPIP_CORE_LOCKING 1 + +#define LWIP_NETIF_LINK_CALLBACK 1 +#define LWIP_NETIF_STATUS_CALLBACK 1 +#define LWIP_NETIF_EXT_STATUS_CALLBACK 1 + +#ifdef LWIP_DEBUG + +#define LWIP_DBG_MIN_LEVEL 0 +#define PPP_DEBUG LWIP_DBG_OFF +#define MEM_DEBUG LWIP_DBG_OFF +#define MEMP_DEBUG LWIP_DBG_OFF +#define PBUF_DEBUG LWIP_DBG_OFF +#define API_LIB_DEBUG LWIP_DBG_OFF +#define API_MSG_DEBUG LWIP_DBG_OFF +#define TCPIP_DEBUG LWIP_DBG_OFF +#define NETIF_DEBUG LWIP_DBG_OFF +#define SOCKETS_DEBUG LWIP_DBG_OFF +#define DNS_DEBUG LWIP_DBG_OFF +#define AUTOIP_DEBUG LWIP_DBG_OFF +#define DHCP_DEBUG LWIP_DBG_OFF +#define IP_DEBUG LWIP_DBG_OFF +#define IP_REASS_DEBUG LWIP_DBG_OFF +#define ICMP_DEBUG LWIP_DBG_OFF +#define IGMP_DEBUG LWIP_DBG_OFF +#define UDP_DEBUG LWIP_DBG_OFF +#define TCP_DEBUG LWIP_DBG_OFF +#define TCP_INPUT_DEBUG LWIP_DBG_OFF +#define TCP_OUTPUT_DEBUG LWIP_DBG_OFF +#define TCP_RTO_DEBUG LWIP_DBG_OFF +#define TCP_CWND_DEBUG LWIP_DBG_OFF +#define TCP_WND_DEBUG LWIP_DBG_OFF +#define TCP_FR_DEBUG LWIP_DBG_OFF +#define TCP_QLEN_DEBUG LWIP_DBG_OFF +#define TCP_RST_DEBUG LWIP_DBG_OFF +#endif + +#define LWIP_DBG_TYPES_ON (LWIP_DBG_ON|LWIP_DBG_TRACE|LWIP_DBG_STATE|LWIP_DBG_FRESH|LWIP_DBG_HALT) + + +/* ---------- Memory options ---------- */ +/* MEM_ALIGNMENT: should be set to the alignment of the CPU for which + lwIP is compiled. 4 byte alignment -> define MEM_ALIGNMENT to 4, 2 + byte alignment -> define MEM_ALIGNMENT to 2. */ +/* MSVC port: intel processors don't need 4-byte alignment, + but are faster that way! */ +#define MEM_ALIGNMENT 4U + +/* MEM_SIZE: the size of the heap memory. If the application will send +a lot of data that needs to be copied, this should be set high. */ +#define MEM_SIZE 10240 + +/* MEMP_NUM_PBUF: the number of memp struct pbufs. If the application + sends a lot of data out of ROM (or other static memory), this + should be set high. */ +#define MEMP_NUM_PBUF 16 +/* MEMP_NUM_RAW_PCB: the number of UDP protocol control blocks. One + per active RAW "connection". */ +#define MEMP_NUM_RAW_PCB 3 +/* MEMP_NUM_UDP_PCB: the number of UDP protocol control blocks. One + per active UDP "connection". */ +#define MEMP_NUM_UDP_PCB 8 +/* MEMP_NUM_TCP_PCB: the number of simulatenously active TCP + connections. */ +#define MEMP_NUM_TCP_PCB 5 +/* MEMP_NUM_TCP_PCB_LISTEN: the number of listening TCP + connections. */ +#define MEMP_NUM_TCP_PCB_LISTEN 8 +/* MEMP_NUM_TCP_SEG: the number of simultaneously queued TCP + segments. */ +#define MEMP_NUM_TCP_SEG 16 +/* MEMP_NUM_SYS_TIMEOUT: the number of simulateously active + timeouts. */ +#define MEMP_NUM_SYS_TIMEOUT 17 + +/* The following four are used only with the sequential API and can be + set to 0 if the application only will use the raw API. */ +/* MEMP_NUM_NETBUF: the number of struct netbufs. */ +#define MEMP_NUM_NETBUF 2 +/* MEMP_NUM_NETCONN: the number of struct netconns. */ +#define MEMP_NUM_NETCONN 12 +/* MEMP_NUM_TCPIP_MSG_*: the number of struct tcpip_msg, which is used + for sequential API communication and incoming packets. Used in + src/api/tcpip.c. */ +#define MEMP_NUM_TCPIP_MSG_API 16 +#define MEMP_NUM_TCPIP_MSG_INPKT 16 + + +/* ---------- Pbuf options ---------- */ +/* PBUF_POOL_SIZE: the number of buffers in the pbuf pool. */ +#define PBUF_POOL_SIZE 120 + +/* PBUF_POOL_BUFSIZE: the size of each pbuf in the pbuf pool. */ +#define PBUF_POOL_BUFSIZE 256 + +/** SYS_LIGHTWEIGHT_PROT + * define SYS_LIGHTWEIGHT_PROT in lwipopts.h if you want inter-task protection + * for certain critical regions during buffer allocation, deallocation and memory + * allocation and deallocation. + */ +#define SYS_LIGHTWEIGHT_PROT (NO_SYS==0) + + +/* ---------- TCP options ---------- */ +#define LWIP_TCP 1 +#define TCP_TTL 255 + +#define LWIP_ALTCP (LWIP_TCP) +#ifdef LWIP_HAVE_MBEDTLS +#define LWIP_ALTCP_TLS (LWIP_TCP) +#define LWIP_ALTCP_TLS_MBEDTLS (LWIP_TCP) +#endif + + +/* Controls if TCP should queue segments that arrive out of + order. Define to 0 if your device is low on memory. */ +#define TCP_QUEUE_OOSEQ 1 + +/* TCP Maximum segment size. */ +#define TCP_MSS 1024 + +/* TCP sender buffer space (bytes). */ +#define TCP_SND_BUF 2048 + +/* TCP sender buffer space (pbufs). This must be at least = 2 * + TCP_SND_BUF/TCP_MSS for things to work. */ +#define TCP_SND_QUEUELEN (4 * TCP_SND_BUF/TCP_MSS) + +/* TCP writable space (bytes). This must be less than or equal + to TCP_SND_BUF. It is the amount of space which must be + available in the tcp snd_buf for select to return writable */ +#define TCP_SNDLOWAT (TCP_SND_BUF/2) + +/* TCP receive window. */ +#define TCP_WND (20 * 1024) + +/* Maximum number of retransmissions of data segments. */ +#define TCP_MAXRTX 12 + +/* Maximum number of retransmissions of SYN segments. */ +#define TCP_SYNMAXRTX 4 + + +/* ---------- ARP options ---------- */ +#define LWIP_ARP 1 +#define ARP_TABLE_SIZE 10 +#define ARP_QUEUEING 1 + + +/* ---------- IP options ---------- */ +/* Define IP_FORWARD to 1 if you wish to have the ability to forward + IP packets across network interfaces. If you are going to run lwIP + on a device with only one network interface, define this to 0. */ +#define IP_FORWARD 1 + +/* IP reassembly and segmentation.These are orthogonal even + * if they both deal with IP fragments */ +#define IP_REASSEMBLY 1 +#define IP_REASS_MAX_PBUFS (10 * ((1500 + PBUF_POOL_BUFSIZE - 1) / PBUF_POOL_BUFSIZE)) +#define MEMP_NUM_REASSDATA IP_REASS_MAX_PBUFS +#define IP_FRAG 1 +#define IPV6_FRAG_COPYHEADER 1 + +/* ---------- ICMP options ---------- */ +#define ICMP_TTL 255 + + +/* ---------- DHCP options ---------- */ +/* Define LWIP_DHCP to 1 if you want DHCP configuration of + interfaces. */ +#define LWIP_DHCP LWIP_UDP + +/* 1 if you want to do an ARP check on the offered address + (recommended). */ +#define DHCP_DOES_ARP_CHECK (LWIP_DHCP) + + +/* ---------- AUTOIP options ------- */ +#define LWIP_AUTOIP (LWIP_DHCP) +#define LWIP_DHCP_AUTOIP_COOP (LWIP_DHCP && LWIP_AUTOIP) + + +/* ---------- UDP options ---------- */ +#define LWIP_UDP 1 +#define LWIP_UDPLITE LWIP_UDP +#define UDP_TTL 255 + + +/* ---------- RAW options ---------- */ +#define LWIP_RAW 1 + + +/* ---------- Statistics options ---------- */ + +#define LWIP_STATS 1 +#define LWIP_STATS_DISPLAY 1 + +#if LWIP_STATS +#define LINK_STATS 1 +#define IP_STATS 1 +#define ICMP_STATS 1 +#define IGMP_STATS 1 +#define IPFRAG_STATS 1 +#define UDP_STATS 1 +#define TCP_STATS 1 +#define MEM_STATS 1 +#define MEMP_STATS 1 +#define PBUF_STATS 1 +#define SYS_STATS 1 +#endif /* LWIP_STATS */ + +/* ---------- NETBIOS options ---------- */ +#define LWIP_NETBIOS_RESPOND_NAME_QUERY 1 + +/* ---------- PPP options ---------- */ + +#define PPP_SUPPORT 1 /* Set > 0 for PPP */ + +#if PPP_SUPPORT + +#define NUM_PPP 1 /* Max PPP sessions. */ + + +/* Select modules to enable. Ideally these would be set in the makefile but + * we're limited by the command line length so you need to modify the settings + * in this file. + */ +#define PPPOE_SUPPORT 1 +#define PPPOS_SUPPORT 1 + +#define PAP_SUPPORT 1 /* Set > 0 for PAP. */ +#define CHAP_SUPPORT 1 /* Set > 0 for CHAP. */ +#define MSCHAP_SUPPORT 0 /* Set > 0 for MSCHAP */ +#define CBCP_SUPPORT 0 /* Set > 0 for CBCP (NOT FUNCTIONAL!) */ +#define CCP_SUPPORT 0 /* Set > 0 for CCP */ +#define VJ_SUPPORT 0 /* Set > 0 for VJ header compression. */ +#define MD5_SUPPORT 1 /* Set > 0 for MD5 (see also CHAP) */ + +#endif /* PPP_SUPPORT */ + +#endif /* LWIP_OPTTEST_FILE */ + +/* The following defines must be done even in OPTTEST mode: */ + +#if !defined(NO_SYS) || !NO_SYS /* default is 0 */ +void sys_check_core_locking(void); +#define LWIP_ASSERT_CORE_LOCKED() sys_check_core_locking() +#endif + +#ifndef LWIP_PLATFORM_ASSERT +/* Define LWIP_PLATFORM_ASSERT to something to catch missing stdio.h includes */ +void lwip_example_app_platform_assert(const char *msg, int line, const char *file); +#define LWIP_PLATFORM_ASSERT(x) lwip_example_app_platform_assert(x, __LINE__, __FILE__) +#endif + +#endif /* LWIP_LWIPOPTS_H */ diff --git a/contrib/examples/example_app/lwippools.h b/contrib/examples/example_app/lwippools.h new file mode 100644 index 00000000000..f58aa598117 --- /dev/null +++ b/contrib/examples/example_app/lwippools.h @@ -0,0 +1,20 @@ +/* OPTIONAL: Pools to replace heap allocation + * Optional: Pools can be used instead of the heap for mem_malloc. If + * so, these should be defined here, in increasing order according to + * the pool element size. + * + * LWIP_MALLOC_MEMPOOL(number_elements, element_size) + */ +#if MEM_USE_POOLS +LWIP_MALLOC_MEMPOOL_START +LWIP_MALLOC_MEMPOOL(100, 256) +LWIP_MALLOC_MEMPOOL(50, 512) +LWIP_MALLOC_MEMPOOL(20, 1024) +LWIP_MALLOC_MEMPOOL(20, 1536) +LWIP_MALLOC_MEMPOOL_END +#endif /* MEM_USE_POOLS */ + +/* Optional: Your custom pools can go here if you would like to use + * lwIP's memory pools for anything else. + */ +LWIP_MEMPOOL(SYS_MBOX, 22, 100, "SYS_MBOX") diff --git a/contrib/examples/example_app/ppp_settings.h b/contrib/examples/example_app/ppp_settings.h new file mode 100644 index 00000000000..7b3ee1aadc0 --- /dev/null +++ b/contrib/examples/example_app/ppp_settings.h @@ -0,0 +1,6 @@ +#ifdef _MSC_VER +#pragma warning (disable: 4242) /* PPP only: conversion from 'x' to 'y', possible loss of data */ +#pragma warning (disable: 4244) /* PPP only: conversion from 'x' to 'y', possible loss of data (again?) */ +#pragma warning (disable: 4310) /* PPP only: cast truncates constant value */ +#pragma warning (disable: 4706) /* PPP only: assignment within conditional expression */ +#endif /* MSC_VER */ diff --git a/contrib/examples/example_app/test.c b/contrib/examples/example_app/test.c new file mode 100644 index 00000000000..4f4b5d71212 --- /dev/null +++ b/contrib/examples/example_app/test.c @@ -0,0 +1,773 @@ +/* + * Copyright (c) 2001,2002 Florian Schulze. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * + * 1. Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in the + * documentation and/or other materials provided with the distribution. + * 3. Neither the name of the authors nor the names of the contributors + * may be used to endorse or promote products derived from this software + * without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHORS AND CONTRIBUTORS ``AS IS'' AND + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE + * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHORS OR CONTRIBUTORS BE LIABLE + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + * SUCH DAMAGE. + * + * test.c - This file is part of lwIP test + * + */ + +/* C runtime includes */ +#include <stdio.h> +#include <stdarg.h> +#include <stdlib.h> +#include <time.h> +#include <string.h> + +/* lwIP core includes */ +#include "lwip/opt.h" + +#include "lwip/sys.h" +#include "lwip/timeouts.h" +#include "lwip/debug.h" +#include "lwip/stats.h" +#include "lwip/init.h" +#include "lwip/tcpip.h" +#include "lwip/netif.h" +#include "lwip/api.h" + +#include "lwip/tcp.h" +#include "lwip/udp.h" +#include "lwip/dns.h" +#include "lwip/dhcp.h" +#include "lwip/autoip.h" + +/* lwIP netif includes */ +#include "lwip/etharp.h" +#include "netif/ethernet.h" + +/* applications includes */ +#include "lwip/apps/netbiosns.h" +#include "lwip/apps/httpd.h" +#include "apps/httpserver/httpserver-netconn.h" +#include "apps/netio/netio.h" +#include "apps/ping/ping.h" +#include "apps/rtp/rtp.h" +#include "apps/chargen/chargen.h" +#include "apps/shell/shell.h" +#include "apps/tcpecho/tcpecho.h" +#include "apps/udpecho/udpecho.h" +#include "apps/tcpecho_raw/tcpecho_raw.h" +#include "apps/socket_examples/socket_examples.h" + +#include "examples/lwiperf/lwiperf_example.h" +#include "examples/mdns/mdns_example.h" +#include "examples/snmp/snmp_example.h" +#include "examples/tftp/tftp_example.h" +#include "examples/sntp/sntp_example.h" +#include "examples/mqtt/mqtt_example.h" + +#include "examples/httpd/cgi_example/cgi_example.h" +#include "examples/httpd/fs_example/fs_example.h" +#include "examples/httpd/https_example/https_example.h" +#include "examples/httpd/ssi_example/ssi_example.h" + +#include "default_netif.h" + +#if NO_SYS +/* ... then we need information about the timer intervals: */ +#include "lwip/ip4_frag.h" +#include "lwip/igmp.h" +#endif /* NO_SYS */ + +#include "netif/ppp/ppp_opts.h" +#if PPP_SUPPORT +/* PPP includes */ +#include "lwip/sio.h" +#include "netif/ppp/pppapi.h" +#include "netif/ppp/pppos.h" +#include "netif/ppp/pppoe.h" +#if !NO_SYS && !LWIP_PPP_API +#error With NO_SYS==0, LWIP_PPP_API==1 is required. +#endif +#endif /* PPP_SUPPORT */ + +/* include the port-dependent configuration */ +#include "lwipcfg.h" + +#ifndef LWIP_EXAMPLE_APP_ABORT +#define LWIP_EXAMPLE_APP_ABORT() 0 +#endif + +/** Define this to 1 to enable a port-specific ethernet interface as default interface. */ +#ifndef USE_DEFAULT_ETH_NETIF +#define USE_DEFAULT_ETH_NETIF 1 +#endif + +/** Define this to 1 to enable a PPP interface. */ +#ifndef USE_PPP +#define USE_PPP 0 +#endif + +/** Define this to 1 or 2 to support 1 or 2 SLIP interfaces. */ +#ifndef USE_SLIPIF +#define USE_SLIPIF 0 +#endif + +/** Use an ethernet adapter? Default to enabled if port-specific ethernet netif or PPPoE are used. */ +#ifndef USE_ETHERNET +#define USE_ETHERNET (USE_DEFAULT_ETH_NETIF || PPPOE_SUPPORT) +#endif + +/** Use an ethernet adapter for TCP/IP? By default only if port-specific ethernet netif is used. */ +#ifndef USE_ETHERNET_TCPIP +#define USE_ETHERNET_TCPIP (USE_DEFAULT_ETH_NETIF) +#endif + +#if USE_SLIPIF +#include <netif/slipif.h> +#endif /* USE_SLIPIF */ + +#ifndef USE_DHCP +#define USE_DHCP LWIP_DHCP +#endif +#ifndef USE_AUTOIP +#define USE_AUTOIP LWIP_AUTOIP +#endif + +/* global variables for netifs */ +#if USE_ETHERNET +#if LWIP_DHCP +/* dhcp struct for the ethernet netif */ +static struct dhcp netif_dhcp; +#endif /* LWIP_DHCP */ +#if LWIP_AUTOIP +/* autoip struct for the ethernet netif */ +static struct autoip netif_autoip; +#endif /* LWIP_AUTOIP */ +#endif /* USE_ETHERNET */ +#if USE_PPP +/* THE PPP PCB */ +static ppp_pcb *ppp; +/* THE PPP interface */ +static struct netif ppp_netif; +/* THE PPP descriptor */ +static u8_t sio_idx = 0; +static sio_fd_t ppp_sio; +#endif /* USE_PPP */ +#if USE_SLIPIF +static struct netif slipif1; +#if USE_SLIPIF > 1 +static struct netif slipif2; +#endif /* USE_SLIPIF > 1 */ +#endif /* USE_SLIPIF */ + + +#if USE_PPP +static void +pppLinkStatusCallback(ppp_pcb *pcb, int errCode, void *ctx) +{ + struct netif *pppif = ppp_netif(pcb); + LWIP_UNUSED_ARG(ctx); + + switch(errCode) { + case PPPERR_NONE: { /* No error. */ + printf("pppLinkStatusCallback: PPPERR_NONE\n"); +#if LWIP_IPV4 + printf(" our_ipaddr = %s\n", ip4addr_ntoa(netif_ip4_addr(pppif))); + printf(" his_ipaddr = %s\n", ip4addr_ntoa(netif_ip4_gw(pppif))); + printf(" netmask = %s\n", ip4addr_ntoa(netif_ip4_netmask(pppif))); +#endif /* LWIP_IPV4 */ +#if LWIP_DNS + printf(" dns1 = %s\n", ipaddr_ntoa(dns_getserver(0))); + printf(" dns2 = %s\n", ipaddr_ntoa(dns_getserver(1))); +#endif /* LWIP_DNS */ +#if PPP_IPV6_SUPPORT + printf(" our6_ipaddr = %s\n", ip6addr_ntoa(netif_ip6_addr(pppif, 0))); +#endif /* PPP_IPV6_SUPPORT */ + break; + } + case PPPERR_PARAM: { /* Invalid parameter. */ + printf("pppLinkStatusCallback: PPPERR_PARAM\n"); + break; + } + case PPPERR_OPEN: { /* Unable to open PPP session. */ + printf("pppLinkStatusCallback: PPPERR_OPEN\n"); + break; + } + case PPPERR_DEVICE: { /* Invalid I/O device for PPP. */ + printf("pppLinkStatusCallback: PPPERR_DEVICE\n"); + break; + } + case PPPERR_ALLOC: { /* Unable to allocate resources. */ + printf("pppLinkStatusCallback: PPPERR_ALLOC\n"); + break; + } + case PPPERR_USER: { /* User interrupt. */ + printf("pppLinkStatusCallback: PPPERR_USER\n"); + break; + } + case PPPERR_CONNECT: { /* Connection lost. */ + printf("pppLinkStatusCallback: PPPERR_CONNECT\n"); + break; + } + case PPPERR_AUTHFAIL: { /* Failed authentication challenge. */ + printf("pppLinkStatusCallback: PPPERR_AUTHFAIL\n"); + break; + } + case PPPERR_PROTOCOL: { /* Failed to meet protocol. */ + printf("pppLinkStatusCallback: PPPERR_PROTOCOL\n"); + break; + } + case PPPERR_PEERDEAD: { /* Connection timeout */ + printf("pppLinkStatusCallback: PPPERR_PEERDEAD\n"); + break; + } + case PPPERR_IDLETIMEOUT: { /* Idle Timeout */ + printf("pppLinkStatusCallback: PPPERR_IDLETIMEOUT\n"); + break; + } + case PPPERR_CONNECTTIME: { /* Max connect time reached */ + printf("pppLinkStatusCallback: PPPERR_CONNECTTIME\n"); + break; + } + case PPPERR_LOOPBACK: { /* Loopback detected */ + printf("pppLinkStatusCallback: PPPERR_LOOPBACK\n"); + break; + } + default: { + printf("pppLinkStatusCallback: unknown errCode %d\n", errCode); + break; + } + } +} + +#if PPPOS_SUPPORT +static u32_t +ppp_output_cb(ppp_pcb *pcb, const void *data, u32_t len, void *ctx) +{ + LWIP_UNUSED_ARG(pcb); + LWIP_UNUSED_ARG(ctx); + return sio_write(ppp_sio, (const u8_t*)data, len); +} +#endif /* PPPOS_SUPPORT */ +#endif /* USE_PPP */ + +#if LWIP_NETIF_STATUS_CALLBACK +static void +status_callback(struct netif *state_netif) +{ + if (netif_is_up(state_netif)) { +#if LWIP_IPV4 + printf("status_callback==UP, local interface IP is %s\n", ip4addr_ntoa(netif_ip4_addr(state_netif))); +#else + printf("status_callback==UP\n"); +#endif + } else { + printf("status_callback==DOWN\n"); + } +} +#endif /* LWIP_NETIF_STATUS_CALLBACK */ + +#if LWIP_NETIF_LINK_CALLBACK +static void +link_callback(struct netif *state_netif) +{ + if (netif_is_link_up(state_netif)) { + printf("link_callback==UP\n"); + } else { + printf("link_callback==DOWN\n"); + } +} +#endif /* LWIP_NETIF_LINK_CALLBACK */ + +/* This function initializes all network interfaces */ +static void +test_netif_init(void) +{ +#if LWIP_IPV4 && USE_ETHERNET + ip4_addr_t ipaddr, netmask, gw; +#endif /* LWIP_IPV4 && USE_ETHERNET */ +#if USE_SLIPIF + u8_t num_slip1 = 0; +#if LWIP_IPV4 + ip4_addr_t ipaddr_slip1, netmask_slip1, gw_slip1; +#endif +#if USE_SLIPIF > 1 + u8_t num_slip2 = 1; +#if LWIP_IPV4 + ip4_addr_t ipaddr_slip2, netmask_slip2, gw_slip2; +#endif +#endif /* USE_SLIPIF > 1 */ +#endif /* USE_SLIPIF */ +#if USE_DHCP || USE_AUTOIP + err_t err; +#endif + +#if USE_PPP + const char *username = NULL, *password = NULL; +#ifdef PPP_USERNAME + username = PPP_USERNAME; +#endif +#ifdef PPP_PASSWORD + password = PPP_PASSWORD; +#endif + printf("ppp_connect: COM%d\n", (int)sio_idx); +#if PPPOS_SUPPORT + ppp_sio = sio_open(sio_idx); + if (ppp_sio == NULL) { + printf("sio_open error\n"); + } else { + ppp = pppos_create(&ppp_netif, ppp_output_cb, pppLinkStatusCallback, NULL); + if (ppp == NULL) { + printf("pppos_create error\n"); + } else { + ppp_set_auth(ppp, PPPAUTHTYPE_ANY, username, password); + ppp_connect(ppp, 0); + } + } +#endif /* PPPOS_SUPPORT */ +#endif /* USE_PPP */ + +#if USE_ETHERNET +#if LWIP_IPV4 + ip4_addr_set_zero(&gw); + ip4_addr_set_zero(&ipaddr); + ip4_addr_set_zero(&netmask); +#if USE_ETHERNET_TCPIP +#if USE_DHCP + printf("Starting lwIP, local interface IP is dhcp-enabled\n"); +#elif USE_AUTOIP + printf("Starting lwIP, local interface IP is autoip-enabled\n"); +#else /* USE_DHCP */ + LWIP_PORT_INIT_GW(&gw); + LWIP_PORT_INIT_IPADDR(&ipaddr); + LWIP_PORT_INIT_NETMASK(&netmask); + printf("Starting lwIP, local interface IP is %s\n", ip4addr_ntoa(&ipaddr)); +#endif /* USE_DHCP */ +#endif /* USE_ETHERNET_TCPIP */ +#else /* LWIP_IPV4 */ + printf("Starting lwIP, IPv4 disable\n"); +#endif /* LWIP_IPV4 */ + +#if LWIP_IPV4 + init_default_netif(&ipaddr, &netmask, &gw); +#else + init_default_netif(); +#endif +#if LWIP_IPV6 + netif_create_ip6_linklocal_address(netif_default, 1); + printf("ip6 linklocal address: %s\n", ip6addr_ntoa(netif_ip6_addr(netif_default, 0))); +#endif /* LWIP_IPV6 */ +#if LWIP_NETIF_STATUS_CALLBACK + netif_set_status_callback(netif_default, status_callback); +#endif /* LWIP_NETIF_STATUS_CALLBACK */ +#if LWIP_NETIF_LINK_CALLBACK + netif_set_link_callback(netif_default, link_callback); +#endif /* LWIP_NETIF_LINK_CALLBACK */ + +#if USE_ETHERNET_TCPIP +#if LWIP_AUTOIP + autoip_set_struct(netif_default, &netif_autoip); +#endif /* LWIP_AUTOIP */ +#if LWIP_DHCP + dhcp_set_struct(netif_default, &netif_dhcp); +#endif /* LWIP_DHCP */ + netif_set_up(netif_default); +#if USE_DHCP + err = dhcp_start(netif_default); + LWIP_ASSERT("dhcp_start failed", err == ERR_OK); +#elif USE_AUTOIP + err = autoip_start(netif_default); + LWIP_ASSERT("autoip_start failed", err == ERR_OK); +#endif /* USE_DHCP */ +#else /* USE_ETHERNET_TCPIP */ + /* Use ethernet for PPPoE only */ + netif.flags &= ~(NETIF_FLAG_ETHARP | NETIF_FLAG_IGMP); /* no ARP */ + netif.flags |= NETIF_FLAG_ETHERNET; /* but pure ethernet */ +#endif /* USE_ETHERNET_TCPIP */ + +#if USE_PPP && PPPOE_SUPPORT + /* start PPPoE after ethernet netif is added! */ + ppp = pppoe_create(&ppp_netif, netif_default, NULL, NULL, pppLinkStatusCallback, NULL); + if (ppp == NULL) { + printf("pppoe_create error\n"); + } else { + ppp_set_auth(ppp, PPPAUTHTYPE_ANY, username, password); + ppp_connect(ppp, 0); + } +#endif /* USE_PPP && PPPOE_SUPPORT */ + +#endif /* USE_ETHERNET */ +#if USE_SLIPIF +#if LWIP_IPV4 +#define SLIP1_ADDRS &ipaddr_slip1, &netmask_slip1, &gw_slip1, + LWIP_PORT_INIT_SLIP1_IPADDR(&ipaddr_slip1); + LWIP_PORT_INIT_SLIP1_GW(&gw_slip1); + LWIP_PORT_INIT_SLIP1_NETMASK(&netmask_slip1); + printf("Starting lwIP slipif, local interface IP is %s\n", ip4addr_ntoa(&ipaddr_slip1)); +#else +#define SLIP1_ADDRS + printf("Starting lwIP slipif\n"); +#endif +#if defined(SIO_USE_COMPORT) && SIO_USE_COMPORT + num_slip1++; /* COM ports cannot be 0-based */ +#endif + netif_add(&slipif1, SLIP1_ADDRS &num_slip1, slipif_init, ip_input); +#if !USE_ETHERNET + netif_set_default(&slipif1); +#endif /* !USE_ETHERNET */ +#if LWIP_IPV6 + netif_create_ip6_linklocal_address(&slipif1, 1); + printf("SLIP ip6 linklocal address: %s\n", ip6addr_ntoa(netif_ip6_addr(&slipif1, 0))); +#endif /* LWIP_IPV6 */ +#if LWIP_NETIF_STATUS_CALLBACK + netif_set_status_callback(&slipif1, status_callback); +#endif /* LWIP_NETIF_STATUS_CALLBACK */ +#if LWIP_NETIF_LINK_CALLBACK + netif_set_link_callback(&slipif1, link_callback); +#endif /* LWIP_NETIF_LINK_CALLBACK */ + netif_set_up(&slipif1); + +#if USE_SLIPIF > 1 +#if LWIP_IPV4 +#define SLIP2_ADDRS &ipaddr_slip2, &netmask_slip2, &gw_slip2, + LWIP_PORT_INIT_SLIP2_IPADDR(&ipaddr_slip2); + LWIP_PORT_INIT_SLIP2_GW(&gw_slip2); + LWIP_PORT_INIT_SLIP2_NETMASK(&netmask_slip2); + printf("Starting lwIP SLIP if #2, local interface IP is %s\n", ip4addr_ntoa(&ipaddr_slip2)); +#else +#define SLIP2_ADDRS + printf("Starting lwIP SLIP if #2\n"); +#endif +#if defined(SIO_USE_COMPORT) && SIO_USE_COMPORT + num_slip2++; /* COM ports cannot be 0-based */ +#endif + netif_add(&slipif2, SLIP2_ADDRS &num_slip2, slipif_init, ip_input); +#if LWIP_IPV6 + netif_create_ip6_linklocal_address(&slipif1, 1); + printf("SLIP2 ip6 linklocal address: "); + ip6_addr_debug_print(0xFFFFFFFF & ~LWIP_DBG_HALT, netif_ip6_addr(&slipif2, 0)); + printf("\n"); +#endif /* LWIP_IPV6 */ +#if LWIP_NETIF_STATUS_CALLBACK + netif_set_status_callback(&slipif2, status_callback); +#endif /* LWIP_NETIF_STATUS_CALLBACK */ +#if LWIP_NETIF_LINK_CALLBACK + netif_set_link_callback(&slipif2, link_callback); +#endif /* LWIP_NETIF_LINK_CALLBACK */ + netif_set_up(&slipif2); +#endif /* USE_SLIPIF > 1*/ +#endif /* USE_SLIPIF */ +} + +#if LWIP_DNS_APP && LWIP_DNS +static void +dns_found(const char *name, const ip_addr_t *addr, void *arg) +{ + LWIP_UNUSED_ARG(arg); + printf("%s: %s\n", name, addr ? ipaddr_ntoa(addr) : "<not found>"); +} + +static void +dns_dorequest(void *arg) +{ + const char* dnsname = "3com.com"; + ip_addr_t dnsresp; + LWIP_UNUSED_ARG(arg); + + if (dns_gethostbyname(dnsname, &dnsresp, dns_found, NULL) == ERR_OK) { + dns_found(dnsname, &dnsresp, NULL); + } +} +#endif /* LWIP_DNS_APP && LWIP_DNS */ + +/* This function initializes applications */ +static void +apps_init(void) +{ +#if LWIP_DNS_APP && LWIP_DNS + /* wait until the netif is up (for dhcp, autoip or ppp) */ + sys_timeout(5000, dns_dorequest, NULL); +#endif /* LWIP_DNS_APP && LWIP_DNS */ + +#if LWIP_CHARGEN_APP && LWIP_SOCKET + chargen_init(); +#endif /* LWIP_CHARGEN_APP && LWIP_SOCKET */ + +#if LWIP_PING_APP && LWIP_RAW && LWIP_ICMP + ping_init(&netif_default->gw); +#endif /* LWIP_PING_APP && LWIP_RAW && LWIP_ICMP */ + +#if LWIP_NETBIOS_APP && LWIP_UDP + netbiosns_init(); +#ifndef NETBIOS_LWIP_NAME +#if LWIP_NETIF_HOSTNAME + netbiosns_set_name(netif_default->hostname); +#else + netbiosns_set_name("NETBIOSLWIPDEV"); +#endif +#endif +#endif /* LWIP_NETBIOS_APP && LWIP_UDP */ + +#if LWIP_HTTPD_APP && LWIP_TCP +#ifdef LWIP_HTTPD_APP_NETCONN + http_server_netconn_init(); +#else /* LWIP_HTTPD_APP_NETCONN */ +#if defined(LWIP_HTTPD_EXAMPLE_CUSTOMFILES) && LWIP_HTTPD_EXAMPLE_CUSTOMFILES && defined(LWIP_HTTPD_EXAMPLE_CUSTOMFILES_ROOTDIR) + fs_ex_init(LWIP_HTTPD_EXAMPLE_CUSTOMFILES_ROOTDIR); +#endif + httpd_init(); +#if defined(LWIP_HTTPD_EXAMPLE_SSI_SIMPLE) && LWIP_HTTPD_EXAMPLE_SSI_SIMPLE + ssi_ex_init(); +#endif +#if defined(LWIP_HTTPD_EXAMPLE_CGI_SIMPLE) && LWIP_HTTPD_EXAMPLE_CGI_SIMPLE + cgi_ex_init(); +#endif +#if defined(LWIP_HTTPD_EXAMPLE_HTTPS) && LWIP_HTTPD_EXAMPLE_HTTPS + https_ex_init(); +#endif +#endif /* LWIP_HTTPD_APP_NETCONN */ +#endif /* LWIP_HTTPD_APP && LWIP_TCP */ + +#if LWIP_NETIO_APP && LWIP_TCP + netio_init(); +#endif /* LWIP_NETIO_APP && LWIP_TCP */ + +#if LWIP_RTP_APP && LWIP_SOCKET && LWIP_IGMP + rtp_init(); +#endif /* LWIP_RTP_APP && LWIP_SOCKET && LWIP_IGMP */ + +#if LWIP_SHELL_APP && LWIP_NETCONN + shell_init(); +#endif /* LWIP_SHELL_APP && LWIP_NETCONN */ +#if LWIP_TCPECHO_APP +#if LWIP_NETCONN && defined(LWIP_TCPECHO_APP_NETCONN) + tcpecho_init(); +#else /* LWIP_NETCONN && defined(LWIP_TCPECHO_APP_NETCONN) */ + tcpecho_raw_init(); +#endif +#endif /* LWIP_TCPECHO_APP && LWIP_NETCONN */ +#if LWIP_UDPECHO_APP && LWIP_NETCONN + udpecho_init(); +#endif /* LWIP_UDPECHO_APP && LWIP_NETCONN */ +#if LWIP_SOCKET_EXAMPLES_APP && LWIP_SOCKET + socket_examples_init(); +#endif /* LWIP_SOCKET_EXAMPLES_APP && LWIP_SOCKET */ +#if LWIP_MDNS_APP + mdns_example_init(); +#endif +#if LWIP_SNMP_APP + snmp_example_init(); +#endif +#if LWIP_SNTP_APP + sntp_example_init(); +#endif +#if LWIP_TFTP_APP + tftp_example_init_server(); +#endif +#if LWIP_TFTP_CLIENT_APP + tftp_example_init_client(); +#endif +#if LWIP_LWIPERF_APP + lwiperf_example_init(); +#endif +#if LWIP_MQTT_APP + mqtt_example_init(); +#endif + +#ifdef LWIP_APP_INIT + LWIP_APP_INIT(); +#endif +} + +/* This function initializes this lwIP test. When NO_SYS=1, this is done in + * the main_loop context (there is no other one), when NO_SYS=0, this is done + * in the tcpip_thread context */ +static void +test_init(void * arg) +{ /* remove compiler warning */ +#if NO_SYS + LWIP_UNUSED_ARG(arg); +#else /* NO_SYS */ + sys_sem_t *init_sem; + LWIP_ASSERT("arg != NULL", arg != NULL); + init_sem = (sys_sem_t*)arg; +#endif /* NO_SYS */ + + /* init randomizer again (seed per thread) */ + srand((unsigned int)time(NULL)); + + /* init network interfaces */ + test_netif_init(); + + /* init apps */ + apps_init(); + +#if !NO_SYS + sys_sem_signal(init_sem); +#endif /* !NO_SYS */ +} + +/* This is somewhat different to other ports: we have a main loop here: + * a dedicated task that waits for packets to arrive. This would normally be + * done from interrupt context with embedded hardware, but we don't get an + * interrupt in windows for that :-) */ +static void +main_loop(void) +{ +#if !NO_SYS + err_t err; + sys_sem_t init_sem; +#endif /* NO_SYS */ +#if USE_PPP +#if !USE_ETHERNET + int count; + u8_t rxbuf[1024]; +#endif + volatile int callClosePpp = 0; +#endif /* USE_PPP */ + + /* initialize lwIP stack, network interfaces and applications */ +#if NO_SYS + lwip_init(); + test_init(NULL); +#else /* NO_SYS */ + err = sys_sem_new(&init_sem, 0); + LWIP_ASSERT("failed to create init_sem", err == ERR_OK); + LWIP_UNUSED_ARG(err); + tcpip_init(test_init, &init_sem); + /* we have to wait for initialization to finish before + * calling update_adapter()! */ + sys_sem_wait(&init_sem); + sys_sem_free(&init_sem); +#endif /* NO_SYS */ + +#if (LWIP_SOCKET || LWIP_NETCONN) && LWIP_NETCONN_SEM_PER_THREAD + netconn_thread_init(); +#endif + + /* MAIN LOOP for driver update (and timers if NO_SYS) */ + while (!LWIP_EXAMPLE_APP_ABORT()) { +#if NO_SYS + /* handle timers (already done in tcpip.c when NO_SYS=0) */ + sys_check_timeouts(); +#endif /* NO_SYS */ + +#if USE_ETHERNET + default_netif_poll(); +#else /* USE_ETHERNET */ + /* try to read characters from serial line and pass them to PPPoS */ + count = sio_read(ppp_sio, (u8_t*)rxbuf, 1024); + if(count > 0) { + pppos_input(ppp, rxbuf, count); + } else { + /* nothing received, give other tasks a chance to run */ + sys_msleep(1); + } + +#endif /* USE_ETHERNET */ +#if USE_SLIPIF + slipif_poll(&slipif1); +#if USE_SLIPIF > 1 + slipif_poll(&slipif2); +#endif /* USE_SLIPIF > 1 */ +#endif /* USE_SLIPIF */ +#if ENABLE_LOOPBACK && !LWIP_NETIF_LOOPBACK_MULTITHREADING + /* check for loopback packets on all netifs */ + netif_poll_all(); +#endif /* ENABLE_LOOPBACK && !LWIP_NETIF_LOOPBACK_MULTITHREADING */ +#if USE_PPP + { + int do_hup = 0; + if(do_hup) { + ppp_close(ppp, 1); + do_hup = 0; + } + } + if(callClosePpp && ppp) { + /* make sure to disconnect PPP before stopping the program... */ + callClosePpp = 0; +#if NO_SYS + ppp_close(ppp, 0); +#else + pppapi_close(ppp, 0); +#endif + ppp = NULL; + } +#endif /* USE_PPP */ + } + +#if USE_PPP + if(ppp) { + u32_t started; + printf("Closing PPP connection...\n"); + /* make sure to disconnect PPP before stopping the program... */ +#if NO_SYS + ppp_close(ppp, 0); +#else + pppapi_close(ppp, 0); +#endif + ppp = NULL; + /* Wait for some time to let PPP finish... */ + started = sys_now(); + do + { +#if USE_ETHERNET + default_netif_poll(); +#endif + /* @todo: need a better check here: only wait until PPP is down */ + } while(sys_now() - started < 5000); + } +#endif /* USE_PPP */ +#if (LWIP_SOCKET || LWIP_NETCONN) && LWIP_NETCONN_SEM_PER_THREAD + netconn_thread_cleanup(); +#endif +#if USE_ETHERNET + default_netif_shutdown(); +#endif /* USE_ETHERNET */ +} + +#if USE_PPP && PPPOS_SUPPORT +int main(int argc, char **argv) +#else /* USE_PPP && PPPOS_SUPPORT */ +int main(void) +#endif /* USE_PPP && PPPOS_SUPPORT */ +{ +#if USE_PPP && PPPOS_SUPPORT + if(argc > 1) { + sio_idx = (u8_t)atoi(argv[1]); + } + printf("Using serial port %d for PPP\n", sio_idx); +#endif /* USE_PPP && PPPOS_SUPPORT */ + /* no stdio-buffering, please! */ + setvbuf(stdout, NULL,_IONBF, 0); + + main_loop(); + + return 0; +} + +/* This function is only required to prevent arch.h including stdio.h + * (which it does if LWIP_PLATFORM_ASSERT is undefined) + */ +void lwip_example_app_platform_assert(const char *msg, int line, const char *file) +{ + printf("Assertion "%s" failed at line %d in %s\n", msg, line, file); + fflush(NULL); + abort(); +} diff --git a/contrib/examples/example_app/test_configs/opt_default.h b/contrib/examples/example_app/test_configs/opt_default.h new file mode 100644 index 00000000000..67b69d209ae --- /dev/null +++ b/contrib/examples/example_app/test_configs/opt_default.h @@ -0,0 +1,295 @@ +/* test an lwipopts.h file with default contents */ +#define NO_SYS 0 +#define NO_SYS_NO_TIMERS 0 +#define LWIP_TIMERS 1 +#define LWIP_TIMERS_CUSTOM 0 +#define LWIP_MPU_COMPATIBLE 0 +#define LWIP_TCPIP_CORE_LOCKING 1 +#define LWIP_TCPIP_CORE_LOCKING_INPUT 0 +#define SYS_LIGHTWEIGHT_PROT 1 +#define MEM_LIBC_MALLOC 0 +#define MEMP_MEM_MALLOC 0 +#define MEMP_MEM_INIT 0 +#define MEM_ALIGNMENT 1 +#define MEM_SIZE 1600 +#define MEMP_OVERFLOW_CHECK 0 +#define MEMP_SANITY_CHECK 0 +#define MEM_OVERFLOW_CHECK 0 +#define MEM_SANITY_CHECK 0 +#define MEM_USE_POOLS 0 +#define MEM_USE_POOLS_TRY_BIGGER_POOL 0 +#define MEMP_USE_CUSTOM_POOLS 0 +#define LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT 0 +/*#define MEMP_NUM_PBUF 16 +#define MEMP_NUM_RAW_PCB 4 +#define MEMP_NUM_UDP_PCB 4 +#define MEMP_NUM_TCP_PCB 5 +#define MEMP_NUM_TCP_PCB_LISTEN 8 +#define MEMP_NUM_TCP_SEG 16 +#define MEMP_NUM_ALTCP_PCB MEMP_NUM_TCP_PCB +#define MEMP_NUM_REASSDATA 5 +#define MEMP_NUM_FRAG_PBUF 15 +#define MEMP_NUM_ARP_QUEUE 30 +#define MEMP_NUM_IGMP_GROUP 8 +#define MEMP_NUM_SYS_TIMEOUT (LWIP_NUM_SYS_TIMEOUT_INTERNAL + 2) +#define MEMP_NUM_NETBUF 2 +#define MEMP_NUM_NETCONN 4 +#define MEMP_NUM_SELECT_CB 4 +#define MEMP_NUM_TCPIP_MSG_API 8 +#define MEMP_NUM_TCPIP_MSG_INPKT 8 +#define MEMP_NUM_NETDB 1 +#define MEMP_NUM_LOCALHOSTLIST 1 +#define PBUF_POOL_SIZE 16 +#define MEMP_NUM_API_MSG MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_DNS_API_MSG MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_SOCKET_SETGETSOCKOPT_DATA MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_NETIFAPI_MSG MEMP_NUM_TCPIP_MSG_API*/ +#define LWIP_ARP 1 +#define ARP_TABLE_SIZE 10 +#define ARP_MAXAGE 300 +#define ARP_QUEUEING 0 +#define ARP_QUEUE_LEN 3 +#define ETHARP_SUPPORT_VLAN 0 +#define LWIP_ETHERNET LWIP_ARP +#define ETH_PAD_SIZE 0 +#define ETHARP_SUPPORT_STATIC_ENTRIES 0 +#define ETHARP_TABLE_MATCH_NETIF !LWIP_SINGLE_NETIF +#define LWIP_IPV4 1 +#define IP_FORWARD 0 +#define IP_REASSEMBLY 1 +#define IP_FRAG 1 +#define IP_OPTIONS_ALLOWED 1 +#define IP_REASS_MAXAGE 15 +#define IP_REASS_MAX_PBUFS 10 +#define IP_DEFAULT_TTL 255 +#define IP_SOF_BROADCAST 0 +#define IP_SOF_BROADCAST_RECV 0 +#define IP_FORWARD_ALLOW_TX_ON_RX_NETIF 0 +#define LWIP_ICMP 1 +#define ICMP_TTL (IP_DEFAULT_TTL) +#define LWIP_BROADCAST_PING 0 +#define LWIP_MULTICAST_PING 0 +#define LWIP_RAW 0 +#define RAW_TTL (IP_DEFAULT_TTL) +#define LWIP_DHCP 1 +#define LWIP_DHCP_CHECK_LINK_UP 0 +#define LWIP_DHCP_BOOTP_FILE 0 +#define LWIP_DHCP_GET_NTP_SRV 0 +#define LWIP_DHCP_MAX_NTP_SERVERS 1 +#define LWIP_DHCP_MAX_DNS_SERVERS DNS_MAX_SERVERS +#define LWIP_AUTOIP 0 +#define LWIP_DHCP_AUTOIP_COOP 0 +#define LWIP_DHCP_AUTOIP_COOP_TRIES 9 +#define LWIP_MIB2_CALLBACKS 0 +#define LWIP_MULTICAST_TX_OPTIONS ((LWIP_IGMP || LWIP_IPV6_MLD) && (LWIP_UDP || LWIP_RAW)) +#define LWIP_IGMP 0 +#define LWIP_DNS 0 +#define DNS_TABLE_SIZE 4 +#define DNS_MAX_NAME_LENGTH 256 +#define DNS_MAX_SERVERS 2 +#define DNS_MAX_RETRIES 4 +#define DNS_DOES_NAME_CHECK 1 +#define LWIP_DNS_SECURE (LWIP_DNS_SECURE_RAND_XID | LWIP_DNS_SECURE_NO_MULTIPLE_OUTSTANDING | LWIP_DNS_SECURE_RAND_SRC_PORT) +#define DNS_LOCAL_HOSTLIST 0 +#define DNS_LOCAL_HOSTLIST_IS_DYNAMIC 0 +#define LWIP_DNS_SUPPORT_MDNS_QUERIES 0 +#define LWIP_UDP 1 +#define LWIP_UDPLITE 0 +#define UDP_TTL (IP_DEFAULT_TTL) +#define LWIP_NETBUF_RECVINFO 0 +#define LWIP_TCP 1 +#define TCP_TTL (IP_DEFAULT_TTL) +#define TCP_WND (4 * TCP_MSS) +#define TCP_MAXRTX 12 +#define TCP_SYNMAXRTX 6 +#define TCP_QUEUE_OOSEQ (LWIP_TCP) +#define LWIP_TCP_SACK_OUT 0 +#define LWIP_TCP_MAX_SACK_NUM 4 +#define TCP_MSS 536 +#define TCP_CALCULATE_EFF_SEND_MSS 1 +#define TCP_SND_BUF (2 * TCP_MSS) +#define TCP_SND_QUEUELEN ((4 * (TCP_SND_BUF) + (TCP_MSS - 1))/(TCP_MSS)) +#define TCP_SNDLOWAT LWIP_MIN(LWIP_MAX(((TCP_SND_BUF)/2), (2 * TCP_MSS) + 1), (TCP_SND_BUF) - 1) +#define TCP_SNDQUEUELOWAT LWIP_MAX(((TCP_SND_QUEUELEN)/2), 5) +#define TCP_OOSEQ_MAX_BYTES 0 +#define TCP_OOSEQ_BYTES_LIMIT(pcb) TCP_OOSEQ_MAX_BYTES +#define TCP_OOSEQ_MAX_PBUFS 0 +#define TCP_OOSEQ_PBUFS_LIMIT(pcb) TCP_OOSEQ_MAX_PBUFS +#define TCP_LISTEN_BACKLOG 0 +#define TCP_DEFAULT_LISTEN_BACKLOG 0xff +#define TCP_OVERSIZE TCP_MSS +#define LWIP_TCP_TIMESTAMPS 0 +#define TCP_WND_UPDATE_THRESHOLD LWIP_MIN((TCP_WND / 4), (TCP_MSS * 4)) +#define LWIP_EVENT_API 0 +#define LWIP_CALLBACK_API 1 +#define LWIP_WND_SCALE 0 +#define TCP_RCV_SCALE 0 +#define LWIP_TCP_PCB_NUM_EXT_ARGS 0 +#define LWIP_ALTCP 0 +#define LWIP_ALTCP_TLS 0 +#define PBUF_LINK_HLEN (14 + ETH_PAD_SIZE) +#define PBUF_LINK_ENCAPSULATION_HLEN 0 +#define PBUF_POOL_BUFSIZE LWIP_MEM_ALIGN_SIZE(TCP_MSS+40+PBUF_LINK_ENCAPSULATION_HLEN+PBUF_LINK_HLEN) +#define LWIP_PBUF_REF_T u8_t +#define LWIP_SINGLE_NETIF 0 +#define LWIP_NETIF_HOSTNAME 0 +#define LWIP_NETIF_API 0 +#define LWIP_NETIF_STATUS_CALLBACK 0 +#define LWIP_NETIF_EXT_STATUS_CALLBACK 0 +#define LWIP_NETIF_LINK_CALLBACK 0 +#define LWIP_NETIF_REMOVE_CALLBACK 0 +#define LWIP_NETIF_HWADDRHINT 0 +#define LWIP_NETIF_TX_SINGLE_PBUF 0 +#define LWIP_NUM_NETIF_CLIENT_DATA 0 +#define LWIP_HAVE_LOOPIF (LWIP_NETIF_LOOPBACK && !LWIP_SINGLE_NETIF) +#define LWIP_LOOPIF_MULTICAST 0 +#define LWIP_NETIF_LOOPBACK 0 +#define LWIP_LOOPBACK_MAX_PBUFS 0 +#define LWIP_NETIF_LOOPBACK_MULTITHREADING (!NO_SYS) +/*#define TCPIP_THREAD_NAME "tcpip_thread" +#define TCPIP_THREAD_STACKSIZE 0 +#define TCPIP_THREAD_PRIO 1 +#define TCPIP_MBOX_SIZE 0 +#define LWIP_TCPIP_THREAD_ALIVE() +#define SLIPIF_THREAD_NAME "slipif_loop" +#define SLIPIF_THREAD_STACKSIZE 0 +#define SLIPIF_THREAD_PRIO 1 +#define DEFAULT_THREAD_NAME "lwIP" +#define DEFAULT_THREAD_STACKSIZE 0 +#define DEFAULT_THREAD_PRIO 1 +#define DEFAULT_RAW_RECVMBOX_SIZE 0 +#define DEFAULT_UDP_RECVMBOX_SIZE 0 +#define DEFAULT_TCP_RECVMBOX_SIZE 0 +#define DEFAULT_ACCEPTMBOX_SIZE 0*/ +#define LWIP_NETCONN 1 +#define LWIP_TCPIP_TIMEOUT 0 +#define LWIP_NETCONN_SEM_PER_THREAD 0 +#define LWIP_NETCONN_FULLDUPLEX 0 +#define LWIP_SOCKET 1 +#define LWIP_COMPAT_SOCKETS 1 /* 0..2 */ +#define LWIP_POSIX_SOCKETS_IO_NAMES 1 +#define LWIP_SOCKET_OFFSET 0 +#define LWIP_TCP_KEEPALIVE 0 +#define LWIP_SO_SNDTIMEO 0 +#define LWIP_SO_RCVTIMEO 0 +#define LWIP_SO_SNDRCVTIMEO_NONSTANDARD 0 +#define LWIP_SO_RCVBUF 0 +#define LWIP_SO_LINGER 0 +#define RECV_BUFSIZE_DEFAULT INT_MAX +#define LWIP_TCP_CLOSE_TIMEOUT_MS_DEFAULT 20000 +#define SO_REUSE 0 +#define SO_REUSE_RXTOALL 0 +#define LWIP_FIONREAD_LINUXMODE 0 +#define LWIP_SOCKET_SELECT 1 +#define LWIP_SOCKET_POLL 1 +#define LWIP_STATS 1 +#define LWIP_STATS_DISPLAY 0 +#define LINK_STATS 1 +#define ETHARP_STATS (LWIP_ARP) +#define IP_STATS 1 +#define IPFRAG_STATS (IP_REASSEMBLY || IP_FRAG) +#define ICMP_STATS 1 +#define IGMP_STATS (LWIP_IGMP) +#define UDP_STATS (LWIP_UDP) +#define TCP_STATS (LWIP_TCP) +#define MEM_STATS ((MEM_LIBC_MALLOC == 0) && (MEM_USE_POOLS == 0)) +#define MEMP_STATS (MEMP_MEM_MALLOC == 0) +#define SYS_STATS (NO_SYS == 0) +#define IP6_STATS (LWIP_IPV6) +#define ICMP6_STATS (LWIP_IPV6 && LWIP_ICMP6) +#define IP6_FRAG_STATS (LWIP_IPV6 && (LWIP_IPV6_FRAG || LWIP_IPV6_REASS)) +#define MLD6_STATS (LWIP_IPV6 && LWIP_IPV6_MLD) +#define ND6_STATS (LWIP_IPV6) +#define MIB2_STATS 0 +#define LWIP_CHECKSUM_CTRL_PER_NETIF 0 +#define CHECKSUM_GEN_IP 1 +#define CHECKSUM_GEN_UDP 1 +#define CHECKSUM_GEN_TCP 1 +#define CHECKSUM_GEN_ICMP 1 +#define CHECKSUM_GEN_ICMP6 1 +#define CHECKSUM_CHECK_IP 1 +#define CHECKSUM_CHECK_UDP 1 +#define CHECKSUM_CHECK_TCP 1 +#define CHECKSUM_CHECK_ICMP 1 +#define CHECKSUM_CHECK_ICMP6 1 +#define LWIP_CHECKSUM_ON_COPY 0 +#define LWIP_IPV6 0 +#define IPV6_REASS_MAXAGE 60 +#define LWIP_IPV6_SCOPES (LWIP_IPV6 && !LWIP_SINGLE_NETIF) +#define LWIP_IPV6_SCOPES_DEBUG 0 +#define LWIP_IPV6_NUM_ADDRESSES 3 +#define LWIP_IPV6_FORWARD 0 +#define LWIP_IPV6_FRAG 1 +#define LWIP_IPV6_REASS (LWIP_IPV6) +#define LWIP_IPV6_SEND_ROUTER_SOLICIT 1 +#define LWIP_IPV6_AUTOCONFIG (LWIP_IPV6) +#define LWIP_IPV6_ADDRESS_LIFETIMES (LWIP_IPV6_AUTOCONFIG) +#define LWIP_IPV6_DUP_DETECT_ATTEMPTS 1 +#define LWIP_ICMP6 (LWIP_IPV6) +#define LWIP_ICMP6_DATASIZE 8 +#define LWIP_ICMP6_HL 255 +#define LWIP_IPV6_MLD (LWIP_IPV6) +#define MEMP_NUM_MLD6_GROUP 4 +#define LWIP_ND6_QUEUEING (LWIP_IPV6) +#define MEMP_NUM_ND6_QUEUE 20 +#define LWIP_ND6_NUM_NEIGHBORS 10 +#define LWIP_ND6_NUM_DESTINATIONS 10 +#define LWIP_ND6_NUM_PREFIXES 5 +#define LWIP_ND6_NUM_ROUTERS 3 +#define LWIP_ND6_MAX_MULTICAST_SOLICIT 3 +#define LWIP_ND6_MAX_UNICAST_SOLICIT 3 +#define LWIP_ND6_MAX_ANYCAST_DELAY_TIME 1000 +#define LWIP_ND6_MAX_NEIGHBOR_ADVERTISEMENT 3 +#define LWIP_ND6_REACHABLE_TIME 30000 +#define LWIP_ND6_RETRANS_TIMER 1000 +#define LWIP_ND6_DELAY_FIRST_PROBE_TIME 5000 +#define LWIP_ND6_ALLOW_RA_UPDATES 1 +#define LWIP_ND6_TCP_REACHABILITY_HINTS 1 +#define LWIP_ND6_RDNSS_MAX_DNS_SERVERS 0 +#define LWIP_IPV6_DHCP6 0 +#define LWIP_IPV6_DHCP6_STATEFUL 0 +#define LWIP_IPV6_DHCP6_STATELESS LWIP_IPV6_DHCP6 +#define LWIP_DHCP6_GET_NTP_SRV 0 +#define LWIP_DHCP6_MAX_NTP_SERVERS 1 +#define LWIP_DHCP6_MAX_DNS_SERVERS DNS_MAX_SERVERS + +/* TODO: check hooks */ + +#define LWIP_DBG_MIN_LEVEL LWIP_DBG_LEVEL_ALL +#define LWIP_DBG_TYPES_ON LWIP_DBG_ON +#define ETHARP_DEBUG LWIP_DBG_OFF +#define NETIF_DEBUG LWIP_DBG_OFF +#define PBUF_DEBUG LWIP_DBG_OFF +#define API_LIB_DEBUG LWIP_DBG_OFF +#define API_MSG_DEBUG LWIP_DBG_OFF +#define SOCKETS_DEBUG LWIP_DBG_OFF +#define ICMP_DEBUG LWIP_DBG_OFF +#define IGMP_DEBUG LWIP_DBG_OFF +#define INET_DEBUG LWIP_DBG_OFF +#define IP_DEBUG LWIP_DBG_OFF +#define IP_REASS_DEBUG LWIP_DBG_OFF +#define RAW_DEBUG LWIP_DBG_OFF +#define MEM_DEBUG LWIP_DBG_OFF +#define MEMP_DEBUG LWIP_DBG_OFF +#define SYS_DEBUG LWIP_DBG_OFF +#define TIMERS_DEBUG LWIP_DBG_OFF +#define TCP_DEBUG LWIP_DBG_OFF +#define TCP_INPUT_DEBUG LWIP_DBG_OFF +#define TCP_FR_DEBUG LWIP_DBG_OFF +#define TCP_RTO_DEBUG LWIP_DBG_OFF +#define TCP_CWND_DEBUG LWIP_DBG_OFF +#define TCP_WND_DEBUG LWIP_DBG_OFF +#define TCP_OUTPUT_DEBUG LWIP_DBG_OFF +#define TCP_RST_DEBUG LWIP_DBG_OFF +#define TCP_QLEN_DEBUG LWIP_DBG_OFF +#define UDP_DEBUG LWIP_DBG_OFF +#define TCPIP_DEBUG LWIP_DBG_OFF +#define SLIP_DEBUG LWIP_DBG_OFF +#define DHCP_DEBUG LWIP_DBG_OFF +#define AUTOIP_DEBUG LWIP_DBG_OFF +#define DNS_DEBUG LWIP_DBG_OFF +#define IP6_DEBUG LWIP_DBG_OFF +#define DHCP6_DEBUG LWIP_DBG_OFF +#define LWIP_TESTMODE 0 + +#define LWIP_PERF 0 diff --git a/contrib/examples/example_app/test_configs/opt_dualstack.h b/contrib/examples/example_app/test_configs/opt_dualstack.h new file mode 100644 index 00000000000..4caf490d2c9 --- /dev/null +++ b/contrib/examples/example_app/test_configs/opt_dualstack.h @@ -0,0 +1,295 @@ +/* test an lwipopts.h file with default contents */ +#define NO_SYS 0 +#define NO_SYS_NO_TIMERS 0 +#define LWIP_TIMERS 1 +#define LWIP_TIMERS_CUSTOM 0 +#define LWIP_MPU_COMPATIBLE 0 +#define LWIP_TCPIP_CORE_LOCKING 1 +#define LWIP_TCPIP_CORE_LOCKING_INPUT 0 +#define SYS_LIGHTWEIGHT_PROT 1 +#define MEM_LIBC_MALLOC 0 +#define MEMP_MEM_MALLOC 0 +#define MEMP_MEM_INIT 0 +#define MEM_ALIGNMENT 1 +#define MEM_SIZE 1600 +#define MEMP_OVERFLOW_CHECK 0 +#define MEMP_SANITY_CHECK 0 +#define MEM_OVERFLOW_CHECK 0 +#define MEM_SANITY_CHECK 0 +#define MEM_USE_POOLS 0 +#define MEM_USE_POOLS_TRY_BIGGER_POOL 0 +#define MEMP_USE_CUSTOM_POOLS 0 +#define LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT 0 +/*#define MEMP_NUM_PBUF 16 +#define MEMP_NUM_RAW_PCB 4 +#define MEMP_NUM_UDP_PCB 4 +#define MEMP_NUM_TCP_PCB 5 +#define MEMP_NUM_TCP_PCB_LISTEN 8 +#define MEMP_NUM_TCP_SEG 16 +#define MEMP_NUM_ALTCP_PCB MEMP_NUM_TCP_PCB +#define MEMP_NUM_REASSDATA 5 +#define MEMP_NUM_FRAG_PBUF 15 +#define MEMP_NUM_ARP_QUEUE 30 +#define MEMP_NUM_IGMP_GROUP 8 +#define MEMP_NUM_SYS_TIMEOUT (LWIP_NUM_SYS_TIMEOUT_INTERNAL + 2) +#define MEMP_NUM_NETBUF 2 +#define MEMP_NUM_NETCONN 4 +#define MEMP_NUM_SELECT_CB 4 +#define MEMP_NUM_TCPIP_MSG_API 8 +#define MEMP_NUM_TCPIP_MSG_INPKT 8 +#define MEMP_NUM_NETDB 1 +#define MEMP_NUM_LOCALHOSTLIST 1 +#define PBUF_POOL_SIZE 16 +#define MEMP_NUM_API_MSG MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_DNS_API_MSG MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_SOCKET_SETGETSOCKOPT_DATA MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_NETIFAPI_MSG MEMP_NUM_TCPIP_MSG_API*/ +#define LWIP_ARP 1 +#define ARP_TABLE_SIZE 10 +#define ARP_MAXAGE 300 +#define ARP_QUEUEING 0 +#define ARP_QUEUE_LEN 3 +#define ETHARP_SUPPORT_VLAN 0 +#define LWIP_ETHERNET LWIP_ARP +#define ETH_PAD_SIZE 0 +#define ETHARP_SUPPORT_STATIC_ENTRIES 0 +#define ETHARP_TABLE_MATCH_NETIF !LWIP_SINGLE_NETIF +#define LWIP_IPV4 1 +#define IP_FORWARD 0 +#define IP_REASSEMBLY 1 +#define IP_FRAG 1 +#define IP_OPTIONS_ALLOWED 1 +#define IP_REASS_MAXAGE 15 +#define IP_REASS_MAX_PBUFS 10 +#define IP_DEFAULT_TTL 255 +#define IP_SOF_BROADCAST 0 +#define IP_SOF_BROADCAST_RECV 0 +#define IP_FORWARD_ALLOW_TX_ON_RX_NETIF 0 +#define LWIP_ICMP 1 +#define ICMP_TTL (IP_DEFAULT_TTL) +#define LWIP_BROADCAST_PING 0 +#define LWIP_MULTICAST_PING 0 +#define LWIP_RAW 0 +#define RAW_TTL (IP_DEFAULT_TTL) +#define LWIP_DHCP LWIP_UDP +#define LWIP_DHCP_CHECK_LINK_UP 0 +#define LWIP_DHCP_BOOTP_FILE 0 +#define LWIP_DHCP_GET_NTP_SRV 0 +#define LWIP_DHCP_MAX_NTP_SERVERS 1 +#define LWIP_DHCP_MAX_DNS_SERVERS DNS_MAX_SERVERS +#define LWIP_AUTOIP 0 +#define LWIP_DHCP_AUTOIP_COOP 0 +#define LWIP_DHCP_AUTOIP_COOP_TRIES 9 +#define LWIP_MIB2_CALLBACKS 0 +#define LWIP_MULTICAST_TX_OPTIONS ((LWIP_IGMP || LWIP_IPV6_MLD) && (LWIP_UDP || LWIP_RAW)) +#define LWIP_IGMP 0 +#define LWIP_DNS 0 +#define DNS_TABLE_SIZE 4 +#define DNS_MAX_NAME_LENGTH 256 +#define DNS_MAX_SERVERS 2 +#define DNS_MAX_RETRIES 4 +#define DNS_DOES_NAME_CHECK 1 +#define LWIP_DNS_SECURE (LWIP_DNS_SECURE_RAND_XID | LWIP_DNS_SECURE_NO_MULTIPLE_OUTSTANDING | LWIP_DNS_SECURE_RAND_SRC_PORT) +#define DNS_LOCAL_HOSTLIST 0 +#define DNS_LOCAL_HOSTLIST_IS_DYNAMIC 0 +#define LWIP_DNS_SUPPORT_MDNS_QUERIES 0 +#define LWIP_UDP 1 +#define LWIP_UDPLITE 0 +#define UDP_TTL (IP_DEFAULT_TTL) +#define LWIP_NETBUF_RECVINFO 0 +#define LWIP_TCP 1 +#define TCP_TTL (IP_DEFAULT_TTL) +#define TCP_WND (4 * TCP_MSS) +#define TCP_MAXRTX 12 +#define TCP_SYNMAXRTX 6 +#define TCP_QUEUE_OOSEQ (LWIP_TCP) +#define LWIP_TCP_SACK_OUT 0 +#define LWIP_TCP_MAX_SACK_NUM 4 +#define TCP_MSS 536 +#define TCP_CALCULATE_EFF_SEND_MSS 1 +#define TCP_SND_BUF (2 * TCP_MSS) +#define TCP_SND_QUEUELEN ((4 * (TCP_SND_BUF) + (TCP_MSS - 1))/(TCP_MSS)) +#define TCP_SNDLOWAT LWIP_MIN(LWIP_MAX(((TCP_SND_BUF)/2), (2 * TCP_MSS) + 1), (TCP_SND_BUF) - 1) +#define TCP_SNDQUEUELOWAT LWIP_MAX(((TCP_SND_QUEUELEN)/2), 5) +#define TCP_OOSEQ_MAX_BYTES 0 +#define TCP_OOSEQ_BYTES_LIMIT(pcb) TCP_OOSEQ_MAX_BYTES +#define TCP_OOSEQ_MAX_PBUFS 0 +#define TCP_OOSEQ_PBUFS_LIMIT(pcb) TCP_OOSEQ_MAX_PBUFS +#define TCP_LISTEN_BACKLOG 0 +#define TCP_DEFAULT_LISTEN_BACKLOG 0xff +#define TCP_OVERSIZE TCP_MSS +#define LWIP_TCP_TIMESTAMPS 0 +#define TCP_WND_UPDATE_THRESHOLD LWIP_MIN((TCP_WND / 4), (TCP_MSS * 4)) +#define LWIP_EVENT_API 0 +#define LWIP_CALLBACK_API 1 +#define LWIP_WND_SCALE 0 +#define TCP_RCV_SCALE 0 +#define LWIP_TCP_PCB_NUM_EXT_ARGS 0 +#define LWIP_ALTCP 0 +#define LWIP_ALTCP_TLS 0 +#define PBUF_LINK_HLEN (14 + ETH_PAD_SIZE) +#define PBUF_LINK_ENCAPSULATION_HLEN 0 +#define PBUF_POOL_BUFSIZE LWIP_MEM_ALIGN_SIZE(TCP_MSS+40+PBUF_LINK_ENCAPSULATION_HLEN+PBUF_LINK_HLEN) +#define LWIP_PBUF_REF_T u8_t +#define LWIP_SINGLE_NETIF 0 +#define LWIP_NETIF_HOSTNAME 0 +#define LWIP_NETIF_API 0 +#define LWIP_NETIF_STATUS_CALLBACK 0 +#define LWIP_NETIF_EXT_STATUS_CALLBACK 0 +#define LWIP_NETIF_LINK_CALLBACK 0 +#define LWIP_NETIF_REMOVE_CALLBACK 0 +#define LWIP_NETIF_HWADDRHINT 0 +#define LWIP_NETIF_TX_SINGLE_PBUF 0 +#define LWIP_NUM_NETIF_CLIENT_DATA 0 +#define LWIP_HAVE_LOOPIF (LWIP_NETIF_LOOPBACK && !LWIP_SINGLE_NETIF) +#define LWIP_LOOPIF_MULTICAST 0 +#define LWIP_NETIF_LOOPBACK 0 +#define LWIP_LOOPBACK_MAX_PBUFS 0 +#define LWIP_NETIF_LOOPBACK_MULTITHREADING (!NO_SYS) +/*#define TCPIP_THREAD_NAME "tcpip_thread" +#define TCPIP_THREAD_STACKSIZE 0 +#define TCPIP_THREAD_PRIO 1 +#define TCPIP_MBOX_SIZE 0 +#define LWIP_TCPIP_THREAD_ALIVE() +#define SLIPIF_THREAD_NAME "slipif_loop" +#define SLIPIF_THREAD_STACKSIZE 0 +#define SLIPIF_THREAD_PRIO 1 +#define DEFAULT_THREAD_NAME "lwIP" +#define DEFAULT_THREAD_STACKSIZE 0 +#define DEFAULT_THREAD_PRIO 1 +#define DEFAULT_RAW_RECVMBOX_SIZE 0 +#define DEFAULT_UDP_RECVMBOX_SIZE 0 +#define DEFAULT_TCP_RECVMBOX_SIZE 0 +#define DEFAULT_ACCEPTMBOX_SIZE 0*/ +#define LWIP_NETCONN 1 +#define LWIP_TCPIP_TIMEOUT 0 +#define LWIP_NETCONN_SEM_PER_THREAD 0 +#define LWIP_NETCONN_FULLDUPLEX 0 +#define LWIP_SOCKET 1 +#define LWIP_COMPAT_SOCKETS 1 /* 0..2 */ +#define LWIP_POSIX_SOCKETS_IO_NAMES 1 +#define LWIP_SOCKET_OFFSET 0 +#define LWIP_TCP_KEEPALIVE 0 +#define LWIP_SO_SNDTIMEO 0 +#define LWIP_SO_RCVTIMEO 0 +#define LWIP_SO_SNDRCVTIMEO_NONSTANDARD 0 +#define LWIP_SO_RCVBUF 0 +#define LWIP_SO_LINGER 0 +#define RECV_BUFSIZE_DEFAULT INT_MAX +#define LWIP_TCP_CLOSE_TIMEOUT_MS_DEFAULT 20000 +#define SO_REUSE 0 +#define SO_REUSE_RXTOALL 0 +#define LWIP_FIONREAD_LINUXMODE 0 +#define LWIP_SOCKET_SELECT 1 +#define LWIP_SOCKET_POLL 1 +#define LWIP_STATS 1 +#define LWIP_STATS_DISPLAY 0 +#define LINK_STATS 1 +#define ETHARP_STATS (LWIP_ARP) +#define IP_STATS 1 +#define IPFRAG_STATS (IP_REASSEMBLY || IP_FRAG) +#define ICMP_STATS 1 +#define IGMP_STATS (LWIP_IGMP) +#define UDP_STATS (LWIP_UDP) +#define TCP_STATS (LWIP_TCP) +#define MEM_STATS ((MEM_LIBC_MALLOC == 0) && (MEM_USE_POOLS == 0)) +#define MEMP_STATS (MEMP_MEM_MALLOC == 0) +#define SYS_STATS (NO_SYS == 0) +#define IP6_STATS (LWIP_IPV6) +#define ICMP6_STATS (LWIP_IPV6 && LWIP_ICMP6) +#define IP6_FRAG_STATS (LWIP_IPV6 && (LWIP_IPV6_FRAG || LWIP_IPV6_REASS)) +#define MLD6_STATS (LWIP_IPV6 && LWIP_IPV6_MLD) +#define ND6_STATS (LWIP_IPV6) +#define MIB2_STATS 0 +#define LWIP_CHECKSUM_CTRL_PER_NETIF 0 +#define CHECKSUM_GEN_IP 1 +#define CHECKSUM_GEN_UDP 1 +#define CHECKSUM_GEN_TCP 1 +#define CHECKSUM_GEN_ICMP 1 +#define CHECKSUM_GEN_ICMP6 1 +#define CHECKSUM_CHECK_IP 1 +#define CHECKSUM_CHECK_UDP 1 +#define CHECKSUM_CHECK_TCP 1 +#define CHECKSUM_CHECK_ICMP 1 +#define CHECKSUM_CHECK_ICMP6 1 +#define LWIP_CHECKSUM_ON_COPY 0 +#define LWIP_IPV6 1 +#define IPV6_REASS_MAXAGE 60 +#define LWIP_IPV6_SCOPES (LWIP_IPV6 && !LWIP_SINGLE_NETIF) +#define LWIP_IPV6_SCOPES_DEBUG 0 +#define LWIP_IPV6_NUM_ADDRESSES 3 +#define LWIP_IPV6_FORWARD 0 +#define LWIP_IPV6_FRAG 1 +#define LWIP_IPV6_REASS (LWIP_IPV6) +#define LWIP_IPV6_SEND_ROUTER_SOLICIT 1 +#define LWIP_IPV6_AUTOCONFIG (LWIP_IPV6) +#define LWIP_IPV6_ADDRESS_LIFETIMES (LWIP_IPV6_AUTOCONFIG) +#define LWIP_IPV6_DUP_DETECT_ATTEMPTS 1 +#define LWIP_ICMP6 (LWIP_IPV6) +#define LWIP_ICMP6_DATASIZE 8 +#define LWIP_ICMP6_HL 255 +#define LWIP_IPV6_MLD (LWIP_IPV6) +#define MEMP_NUM_MLD6_GROUP 4 +#define LWIP_ND6_QUEUEING (LWIP_IPV6) +#define MEMP_NUM_ND6_QUEUE 20 +#define LWIP_ND6_NUM_NEIGHBORS 10 +#define LWIP_ND6_NUM_DESTINATIONS 10 +#define LWIP_ND6_NUM_PREFIXES 5 +#define LWIP_ND6_NUM_ROUTERS 3 +#define LWIP_ND6_MAX_MULTICAST_SOLICIT 3 +#define LWIP_ND6_MAX_UNICAST_SOLICIT 3 +#define LWIP_ND6_MAX_ANYCAST_DELAY_TIME 1000 +#define LWIP_ND6_MAX_NEIGHBOR_ADVERTISEMENT 3 +#define LWIP_ND6_REACHABLE_TIME 30000 +#define LWIP_ND6_RETRANS_TIMER 1000 +#define LWIP_ND6_DELAY_FIRST_PROBE_TIME 5000 +#define LWIP_ND6_ALLOW_RA_UPDATES 1 +#define LWIP_ND6_TCP_REACHABILITY_HINTS 1 +#define LWIP_ND6_RDNSS_MAX_DNS_SERVERS 0 +#define LWIP_IPV6_DHCP6 0 +#define LWIP_IPV6_DHCP6_STATEFUL 0 +#define LWIP_IPV6_DHCP6_STATELESS LWIP_IPV6_DHCP6 +#define LWIP_DHCP6_GET_NTP_SRV 0 +#define LWIP_DHCP6_MAX_NTP_SERVERS 1 +#define LWIP_DHCP6_MAX_DNS_SERVERS DNS_MAX_SERVERS + +/* TODO: check hooks */ + +#define LWIP_DBG_MIN_LEVEL LWIP_DBG_LEVEL_ALL +#define LWIP_DBG_TYPES_ON LWIP_DBG_ON +#define ETHARP_DEBUG LWIP_DBG_OFF +#define NETIF_DEBUG LWIP_DBG_OFF +#define PBUF_DEBUG LWIP_DBG_OFF +#define API_LIB_DEBUG LWIP_DBG_OFF +#define API_MSG_DEBUG LWIP_DBG_OFF +#define SOCKETS_DEBUG LWIP_DBG_OFF +#define ICMP_DEBUG LWIP_DBG_OFF +#define IGMP_DEBUG LWIP_DBG_OFF +#define INET_DEBUG LWIP_DBG_OFF +#define IP_DEBUG LWIP_DBG_OFF +#define IP_REASS_DEBUG LWIP_DBG_OFF +#define RAW_DEBUG LWIP_DBG_OFF +#define MEM_DEBUG LWIP_DBG_OFF +#define MEMP_DEBUG LWIP_DBG_OFF +#define SYS_DEBUG LWIP_DBG_OFF +#define TIMERS_DEBUG LWIP_DBG_OFF +#define TCP_DEBUG LWIP_DBG_OFF +#define TCP_INPUT_DEBUG LWIP_DBG_OFF +#define TCP_FR_DEBUG LWIP_DBG_OFF +#define TCP_RTO_DEBUG LWIP_DBG_OFF +#define TCP_CWND_DEBUG LWIP_DBG_OFF +#define TCP_WND_DEBUG LWIP_DBG_OFF +#define TCP_OUTPUT_DEBUG LWIP_DBG_OFF +#define TCP_RST_DEBUG LWIP_DBG_OFF +#define TCP_QLEN_DEBUG LWIP_DBG_OFF +#define UDP_DEBUG LWIP_DBG_OFF +#define TCPIP_DEBUG LWIP_DBG_OFF +#define SLIP_DEBUG LWIP_DBG_OFF +#define DHCP_DEBUG LWIP_DBG_OFF +#define AUTOIP_DEBUG LWIP_DBG_OFF +#define DNS_DEBUG LWIP_DBG_OFF +#define IP6_DEBUG LWIP_DBG_OFF +#define DHCP6_DEBUG LWIP_DBG_OFF +#define LWIP_TESTMODE 0 + +#define LWIP_PERF 0 diff --git a/contrib/examples/example_app/test_configs/opt_ipv4only.h b/contrib/examples/example_app/test_configs/opt_ipv4only.h new file mode 100644 index 00000000000..82ba46712c0 --- /dev/null +++ b/contrib/examples/example_app/test_configs/opt_ipv4only.h @@ -0,0 +1,295 @@ +/* test an lwipopts.h file with default contents */ +#define NO_SYS 0 +#define NO_SYS_NO_TIMERS 0 +#define LWIP_TIMERS 1 +#define LWIP_TIMERS_CUSTOM 0 +#define LWIP_MPU_COMPATIBLE 0 +#define LWIP_TCPIP_CORE_LOCKING 1 +#define LWIP_TCPIP_CORE_LOCKING_INPUT 0 +#define SYS_LIGHTWEIGHT_PROT 1 +#define MEM_LIBC_MALLOC 0 +#define MEMP_MEM_MALLOC 0 +#define MEMP_MEM_INIT 0 +#define MEM_ALIGNMENT 1 +#define MEM_SIZE 1600 +#define MEMP_OVERFLOW_CHECK 0 +#define MEMP_SANITY_CHECK 0 +#define MEM_OVERFLOW_CHECK 0 +#define MEM_SANITY_CHECK 0 +#define MEM_USE_POOLS 0 +#define MEM_USE_POOLS_TRY_BIGGER_POOL 0 +#define MEMP_USE_CUSTOM_POOLS 0 +#define LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT 0 +/*#define MEMP_NUM_PBUF 16 +#define MEMP_NUM_RAW_PCB 4 +#define MEMP_NUM_UDP_PCB 4 +#define MEMP_NUM_TCP_PCB 5 +#define MEMP_NUM_TCP_PCB_LISTEN 8 +#define MEMP_NUM_TCP_SEG 16 +#define MEMP_NUM_ALTCP_PCB MEMP_NUM_TCP_PCB +#define MEMP_NUM_REASSDATA 5 +#define MEMP_NUM_FRAG_PBUF 15 +#define MEMP_NUM_ARP_QUEUE 30 +#define MEMP_NUM_IGMP_GROUP 8 +#define MEMP_NUM_SYS_TIMEOUT (LWIP_NUM_SYS_TIMEOUT_INTERNAL + 2) +#define MEMP_NUM_NETBUF 2 +#define MEMP_NUM_NETCONN 4 +#define MEMP_NUM_SELECT_CB 4 +#define MEMP_NUM_TCPIP_MSG_API 8 +#define MEMP_NUM_TCPIP_MSG_INPKT 8 +#define MEMP_NUM_NETDB 1 +#define MEMP_NUM_LOCALHOSTLIST 1 +#define PBUF_POOL_SIZE 16 +#define MEMP_NUM_API_MSG MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_DNS_API_MSG MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_SOCKET_SETGETSOCKOPT_DATA MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_NETIFAPI_MSG MEMP_NUM_TCPIP_MSG_API*/ +#define LWIP_ARP 1 +#define ARP_TABLE_SIZE 10 +#define ARP_MAXAGE 300 +#define ARP_QUEUEING 0 +#define ARP_QUEUE_LEN 3 +#define ETHARP_SUPPORT_VLAN 0 +#define LWIP_ETHERNET LWIP_ARP +#define ETH_PAD_SIZE 0 +#define ETHARP_SUPPORT_STATIC_ENTRIES 0 +#define ETHARP_TABLE_MATCH_NETIF !LWIP_SINGLE_NETIF +#define LWIP_IPV4 1 +#define IP_FORWARD 0 +#define IP_REASSEMBLY 1 +#define IP_FRAG 1 +#define IP_OPTIONS_ALLOWED 1 +#define IP_REASS_MAXAGE 15 +#define IP_REASS_MAX_PBUFS 10 +#define IP_DEFAULT_TTL 255 +#define IP_SOF_BROADCAST 0 +#define IP_SOF_BROADCAST_RECV 0 +#define IP_FORWARD_ALLOW_TX_ON_RX_NETIF 0 +#define LWIP_ICMP 1 +#define ICMP_TTL (IP_DEFAULT_TTL) +#define LWIP_BROADCAST_PING 0 +#define LWIP_MULTICAST_PING 0 +#define LWIP_RAW 0 +#define RAW_TTL (IP_DEFAULT_TTL) +#define LWIP_DHCP LWIP_UDP +#define LWIP_DHCP_CHECK_LINK_UP 0 +#define LWIP_DHCP_BOOTP_FILE 0 +#define LWIP_DHCP_GET_NTP_SRV 0 +#define LWIP_DHCP_MAX_NTP_SERVERS 1 +#define LWIP_DHCP_MAX_DNS_SERVERS DNS_MAX_SERVERS +#define LWIP_AUTOIP 0 +#define LWIP_DHCP_AUTOIP_COOP 0 +#define LWIP_DHCP_AUTOIP_COOP_TRIES 9 +#define LWIP_MIB2_CALLBACKS 0 +#define LWIP_MULTICAST_TX_OPTIONS ((LWIP_IGMP || LWIP_IPV6_MLD) && (LWIP_UDP || LWIP_RAW)) +#define LWIP_IGMP 0 +#define LWIP_DNS 0 +#define DNS_TABLE_SIZE 4 +#define DNS_MAX_NAME_LENGTH 256 +#define DNS_MAX_SERVERS 2 +#define DNS_MAX_RETRIES 4 +#define DNS_DOES_NAME_CHECK 1 +#define LWIP_DNS_SECURE (LWIP_DNS_SECURE_RAND_XID | LWIP_DNS_SECURE_NO_MULTIPLE_OUTSTANDING | LWIP_DNS_SECURE_RAND_SRC_PORT) +#define DNS_LOCAL_HOSTLIST 0 +#define DNS_LOCAL_HOSTLIST_IS_DYNAMIC 0 +#define LWIP_DNS_SUPPORT_MDNS_QUERIES 0 +#define LWIP_UDP 1 +#define LWIP_UDPLITE 0 +#define UDP_TTL (IP_DEFAULT_TTL) +#define LWIP_NETBUF_RECVINFO 0 +#define LWIP_TCP 1 +#define TCP_TTL (IP_DEFAULT_TTL) +#define TCP_WND (4 * TCP_MSS) +#define TCP_MAXRTX 12 +#define TCP_SYNMAXRTX 6 +#define TCP_QUEUE_OOSEQ (LWIP_TCP) +#define LWIP_TCP_SACK_OUT 0 +#define LWIP_TCP_MAX_SACK_NUM 4 +#define TCP_MSS 536 +#define TCP_CALCULATE_EFF_SEND_MSS 1 +#define TCP_SND_BUF (2 * TCP_MSS) +#define TCP_SND_QUEUELEN ((4 * (TCP_SND_BUF) + (TCP_MSS - 1))/(TCP_MSS)) +#define TCP_SNDLOWAT LWIP_MIN(LWIP_MAX(((TCP_SND_BUF)/2), (2 * TCP_MSS) + 1), (TCP_SND_BUF) - 1) +#define TCP_SNDQUEUELOWAT LWIP_MAX(((TCP_SND_QUEUELEN)/2), 5) +#define TCP_OOSEQ_MAX_BYTES 0 +#define TCP_OOSEQ_BYTES_LIMIT(pcb) TCP_OOSEQ_MAX_BYTES +#define TCP_OOSEQ_MAX_PBUFS 0 +#define TCP_OOSEQ_PBUFS_LIMIT(pcb) TCP_OOSEQ_MAX_PBUFS +#define TCP_LISTEN_BACKLOG 0 +#define TCP_DEFAULT_LISTEN_BACKLOG 0xff +#define TCP_OVERSIZE TCP_MSS +#define LWIP_TCP_TIMESTAMPS 0 +#define TCP_WND_UPDATE_THRESHOLD LWIP_MIN((TCP_WND / 4), (TCP_MSS * 4)) +#define LWIP_EVENT_API 0 +#define LWIP_CALLBACK_API 1 +#define LWIP_WND_SCALE 0 +#define TCP_RCV_SCALE 0 +#define LWIP_TCP_PCB_NUM_EXT_ARGS 0 +#define LWIP_ALTCP 0 +#define LWIP_ALTCP_TLS 0 +#define PBUF_LINK_HLEN (14 + ETH_PAD_SIZE) +#define PBUF_LINK_ENCAPSULATION_HLEN 0 +#define PBUF_POOL_BUFSIZE LWIP_MEM_ALIGN_SIZE(TCP_MSS+40+PBUF_LINK_ENCAPSULATION_HLEN+PBUF_LINK_HLEN) +#define LWIP_PBUF_REF_T u8_t +#define LWIP_SINGLE_NETIF 0 +#define LWIP_NETIF_HOSTNAME 0 +#define LWIP_NETIF_API 0 +#define LWIP_NETIF_STATUS_CALLBACK 0 +#define LWIP_NETIF_EXT_STATUS_CALLBACK 0 +#define LWIP_NETIF_LINK_CALLBACK 0 +#define LWIP_NETIF_REMOVE_CALLBACK 0 +#define LWIP_NETIF_HWADDRHINT 0 +#define LWIP_NETIF_TX_SINGLE_PBUF 0 +#define LWIP_NUM_NETIF_CLIENT_DATA 0 +#define LWIP_HAVE_LOOPIF (LWIP_NETIF_LOOPBACK && !LWIP_SINGLE_NETIF) +#define LWIP_LOOPIF_MULTICAST 0 +#define LWIP_NETIF_LOOPBACK 0 +#define LWIP_LOOPBACK_MAX_PBUFS 0 +#define LWIP_NETIF_LOOPBACK_MULTITHREADING (!NO_SYS) +/*#define TCPIP_THREAD_NAME "tcpip_thread" +#define TCPIP_THREAD_STACKSIZE 0 +#define TCPIP_THREAD_PRIO 1 +#define TCPIP_MBOX_SIZE 0 +#define LWIP_TCPIP_THREAD_ALIVE() +#define SLIPIF_THREAD_NAME "slipif_loop" +#define SLIPIF_THREAD_STACKSIZE 0 +#define SLIPIF_THREAD_PRIO 1 +#define DEFAULT_THREAD_NAME "lwIP" +#define DEFAULT_THREAD_STACKSIZE 0 +#define DEFAULT_THREAD_PRIO 1 +#define DEFAULT_RAW_RECVMBOX_SIZE 0 +#define DEFAULT_UDP_RECVMBOX_SIZE 0 +#define DEFAULT_TCP_RECVMBOX_SIZE 0 +#define DEFAULT_ACCEPTMBOX_SIZE 0*/ +#define LWIP_NETCONN 1 +#define LWIP_TCPIP_TIMEOUT 0 +#define LWIP_NETCONN_SEM_PER_THREAD 0 +#define LWIP_NETCONN_FULLDUPLEX 0 +#define LWIP_SOCKET 1 +#define LWIP_COMPAT_SOCKETS 1 /* 0..2 */ +#define LWIP_POSIX_SOCKETS_IO_NAMES 1 +#define LWIP_SOCKET_OFFSET 0 +#define LWIP_TCP_KEEPALIVE 0 +#define LWIP_SO_SNDTIMEO 0 +#define LWIP_SO_RCVTIMEO 0 +#define LWIP_SO_SNDRCVTIMEO_NONSTANDARD 0 +#define LWIP_SO_RCVBUF 0 +#define LWIP_SO_LINGER 0 +#define RECV_BUFSIZE_DEFAULT INT_MAX +#define LWIP_TCP_CLOSE_TIMEOUT_MS_DEFAULT 20000 +#define SO_REUSE 0 +#define SO_REUSE_RXTOALL 0 +#define LWIP_FIONREAD_LINUXMODE 0 +#define LWIP_SOCKET_SELECT 1 +#define LWIP_SOCKET_POLL 1 +#define LWIP_STATS 1 +#define LWIP_STATS_DISPLAY 0 +#define LINK_STATS 1 +#define ETHARP_STATS (LWIP_ARP) +#define IP_STATS 1 +#define IPFRAG_STATS (IP_REASSEMBLY || IP_FRAG) +#define ICMP_STATS 1 +#define IGMP_STATS (LWIP_IGMP) +#define UDP_STATS (LWIP_UDP) +#define TCP_STATS (LWIP_TCP) +#define MEM_STATS ((MEM_LIBC_MALLOC == 0) && (MEM_USE_POOLS == 0)) +#define MEMP_STATS (MEMP_MEM_MALLOC == 0) +#define SYS_STATS (NO_SYS == 0) +#define IP6_STATS (LWIP_IPV6) +#define ICMP6_STATS (LWIP_IPV6 && LWIP_ICMP6) +#define IP6_FRAG_STATS (LWIP_IPV6 && (LWIP_IPV6_FRAG || LWIP_IPV6_REASS)) +#define MLD6_STATS (LWIP_IPV6 && LWIP_IPV6_MLD) +#define ND6_STATS (LWIP_IPV6) +#define MIB2_STATS 0 +#define LWIP_CHECKSUM_CTRL_PER_NETIF 0 +#define CHECKSUM_GEN_IP 1 +#define CHECKSUM_GEN_UDP 1 +#define CHECKSUM_GEN_TCP 1 +#define CHECKSUM_GEN_ICMP 1 +#define CHECKSUM_GEN_ICMP6 1 +#define CHECKSUM_CHECK_IP 1 +#define CHECKSUM_CHECK_UDP 1 +#define CHECKSUM_CHECK_TCP 1 +#define CHECKSUM_CHECK_ICMP 1 +#define CHECKSUM_CHECK_ICMP6 1 +#define LWIP_CHECKSUM_ON_COPY 0 +#define LWIP_IPV6 0 +#define IPV6_REASS_MAXAGE 60 +#define LWIP_IPV6_SCOPES (LWIP_IPV6 && !LWIP_SINGLE_NETIF) +#define LWIP_IPV6_SCOPES_DEBUG 0 +#define LWIP_IPV6_NUM_ADDRESSES 3 +#define LWIP_IPV6_FORWARD 0 +#define LWIP_IPV6_FRAG 1 +#define LWIP_IPV6_REASS (LWIP_IPV6) +#define LWIP_IPV6_SEND_ROUTER_SOLICIT 1 +#define LWIP_IPV6_AUTOCONFIG (LWIP_IPV6) +#define LWIP_IPV6_ADDRESS_LIFETIMES (LWIP_IPV6_AUTOCONFIG) +#define LWIP_IPV6_DUP_DETECT_ATTEMPTS 1 +#define LWIP_ICMP6 (LWIP_IPV6) +#define LWIP_ICMP6_DATASIZE 8 +#define LWIP_ICMP6_HL 255 +#define LWIP_IPV6_MLD (LWIP_IPV6) +#define MEMP_NUM_MLD6_GROUP 4 +#define LWIP_ND6_QUEUEING (LWIP_IPV6) +#define MEMP_NUM_ND6_QUEUE 20 +#define LWIP_ND6_NUM_NEIGHBORS 10 +#define LWIP_ND6_NUM_DESTINATIONS 10 +#define LWIP_ND6_NUM_PREFIXES 5 +#define LWIP_ND6_NUM_ROUTERS 3 +#define LWIP_ND6_MAX_MULTICAST_SOLICIT 3 +#define LWIP_ND6_MAX_UNICAST_SOLICIT 3 +#define LWIP_ND6_MAX_ANYCAST_DELAY_TIME 1000 +#define LWIP_ND6_MAX_NEIGHBOR_ADVERTISEMENT 3 +#define LWIP_ND6_REACHABLE_TIME 30000 +#define LWIP_ND6_RETRANS_TIMER 1000 +#define LWIP_ND6_DELAY_FIRST_PROBE_TIME 5000 +#define LWIP_ND6_ALLOW_RA_UPDATES 1 +#define LWIP_ND6_TCP_REACHABILITY_HINTS 1 +#define LWIP_ND6_RDNSS_MAX_DNS_SERVERS 0 +#define LWIP_IPV6_DHCP6 0 +#define LWIP_IPV6_DHCP6_STATEFUL 0 +#define LWIP_IPV6_DHCP6_STATELESS LWIP_IPV6_DHCP6 +#define LWIP_DHCP6_GET_NTP_SRV 0 +#define LWIP_DHCP6_MAX_NTP_SERVERS 1 +#define LWIP_DHCP6_MAX_DNS_SERVERS DNS_MAX_SERVERS + +/* TODO: check hooks */ + +#define LWIP_DBG_MIN_LEVEL LWIP_DBG_LEVEL_ALL +#define LWIP_DBG_TYPES_ON LWIP_DBG_ON +#define ETHARP_DEBUG LWIP_DBG_OFF +#define NETIF_DEBUG LWIP_DBG_OFF +#define PBUF_DEBUG LWIP_DBG_OFF +#define API_LIB_DEBUG LWIP_DBG_OFF +#define API_MSG_DEBUG LWIP_DBG_OFF +#define SOCKETS_DEBUG LWIP_DBG_OFF +#define ICMP_DEBUG LWIP_DBG_OFF +#define IGMP_DEBUG LWIP_DBG_OFF +#define INET_DEBUG LWIP_DBG_OFF +#define IP_DEBUG LWIP_DBG_OFF +#define IP_REASS_DEBUG LWIP_DBG_OFF +#define RAW_DEBUG LWIP_DBG_OFF +#define MEM_DEBUG LWIP_DBG_OFF +#define MEMP_DEBUG LWIP_DBG_OFF +#define SYS_DEBUG LWIP_DBG_OFF +#define TIMERS_DEBUG LWIP_DBG_OFF +#define TCP_DEBUG LWIP_DBG_OFF +#define TCP_INPUT_DEBUG LWIP_DBG_OFF +#define TCP_FR_DEBUG LWIP_DBG_OFF +#define TCP_RTO_DEBUG LWIP_DBG_OFF +#define TCP_CWND_DEBUG LWIP_DBG_OFF +#define TCP_WND_DEBUG LWIP_DBG_OFF +#define TCP_OUTPUT_DEBUG LWIP_DBG_OFF +#define TCP_RST_DEBUG LWIP_DBG_OFF +#define TCP_QLEN_DEBUG LWIP_DBG_OFF +#define UDP_DEBUG LWIP_DBG_OFF +#define TCPIP_DEBUG LWIP_DBG_OFF +#define SLIP_DEBUG LWIP_DBG_OFF +#define DHCP_DEBUG LWIP_DBG_OFF +#define AUTOIP_DEBUG LWIP_DBG_OFF +#define DNS_DEBUG LWIP_DBG_OFF +#define IP6_DEBUG LWIP_DBG_OFF +#define DHCP6_DEBUG LWIP_DBG_OFF +#define LWIP_TESTMODE 0 + +#define LWIP_PERF 0 diff --git a/contrib/examples/example_app/test_configs/opt_ipv6only.h b/contrib/examples/example_app/test_configs/opt_ipv6only.h new file mode 100644 index 00000000000..b3cb1e044b4 --- /dev/null +++ b/contrib/examples/example_app/test_configs/opt_ipv6only.h @@ -0,0 +1,295 @@ +/* test an lwipopts.h file with default contents */ +#define NO_SYS 0 +#define NO_SYS_NO_TIMERS 0 +#define LWIP_TIMERS 1 +#define LWIP_TIMERS_CUSTOM 0 +#define LWIP_MPU_COMPATIBLE 0 +#define LWIP_TCPIP_CORE_LOCKING 1 +#define LWIP_TCPIP_CORE_LOCKING_INPUT 0 +#define SYS_LIGHTWEIGHT_PROT 1 +#define MEM_LIBC_MALLOC 0 +#define MEMP_MEM_MALLOC 0 +#define MEMP_MEM_INIT 0 +#define MEM_ALIGNMENT 1 +#define MEM_SIZE 1600 +#define MEMP_OVERFLOW_CHECK 0 +#define MEMP_SANITY_CHECK 0 +#define MEM_OVERFLOW_CHECK 0 +#define MEM_SANITY_CHECK 0 +#define MEM_USE_POOLS 0 +#define MEM_USE_POOLS_TRY_BIGGER_POOL 0 +#define MEMP_USE_CUSTOM_POOLS 0 +#define LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT 0 +/*#define MEMP_NUM_PBUF 16 +#define MEMP_NUM_RAW_PCB 4 +#define MEMP_NUM_UDP_PCB 4 +#define MEMP_NUM_TCP_PCB 5 +#define MEMP_NUM_TCP_PCB_LISTEN 8 +#define MEMP_NUM_TCP_SEG 16 +#define MEMP_NUM_ALTCP_PCB MEMP_NUM_TCP_PCB +#define MEMP_NUM_REASSDATA 5 +#define MEMP_NUM_FRAG_PBUF 15 +#define MEMP_NUM_ARP_QUEUE 30 +#define MEMP_NUM_IGMP_GROUP 8 +#define MEMP_NUM_SYS_TIMEOUT (LWIP_NUM_SYS_TIMEOUT_INTERNAL + 2) +#define MEMP_NUM_NETBUF 2 +#define MEMP_NUM_NETCONN 4 +#define MEMP_NUM_SELECT_CB 4 +#define MEMP_NUM_TCPIP_MSG_API 8 +#define MEMP_NUM_TCPIP_MSG_INPKT 8 +#define MEMP_NUM_NETDB 1 +#define MEMP_NUM_LOCALHOSTLIST 1 +#define PBUF_POOL_SIZE 16 +#define MEMP_NUM_API_MSG MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_DNS_API_MSG MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_SOCKET_SETGETSOCKOPT_DATA MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_NETIFAPI_MSG MEMP_NUM_TCPIP_MSG_API*/ +#define LWIP_ARP 1 +#define ARP_TABLE_SIZE 10 +#define ARP_MAXAGE 300 +#define ARP_QUEUEING 0 +#define ARP_QUEUE_LEN 3 +#define ETHARP_SUPPORT_VLAN 0 +#define LWIP_ETHERNET LWIP_ARP +#define ETH_PAD_SIZE 0 +#define ETHARP_SUPPORT_STATIC_ENTRIES 0 +#define ETHARP_TABLE_MATCH_NETIF !LWIP_SINGLE_NETIF +#define LWIP_IPV4 0 +#define IP_FORWARD 0 +#define IP_REASSEMBLY 1 +#define IP_FRAG 1 +#define IP_OPTIONS_ALLOWED 1 +#define IP_REASS_MAXAGE 15 +#define IP_REASS_MAX_PBUFS 10 +#define IP_DEFAULT_TTL 255 +#define IP_SOF_BROADCAST 0 +#define IP_SOF_BROADCAST_RECV 0 +#define IP_FORWARD_ALLOW_TX_ON_RX_NETIF 0 +#define LWIP_ICMP 1 +#define ICMP_TTL (IP_DEFAULT_TTL) +#define LWIP_BROADCAST_PING 0 +#define LWIP_MULTICAST_PING 0 +#define LWIP_RAW 0 +#define RAW_TTL (IP_DEFAULT_TTL) +#define LWIP_DHCP 0 +#define LWIP_DHCP_CHECK_LINK_UP 0 +#define LWIP_DHCP_BOOTP_FILE 0 +#define LWIP_DHCP_GET_NTP_SRV 0 +#define LWIP_DHCP_MAX_NTP_SERVERS 1 +#define LWIP_DHCP_MAX_DNS_SERVERS DNS_MAX_SERVERS +#define LWIP_AUTOIP 0 +#define LWIP_DHCP_AUTOIP_COOP 0 +#define LWIP_DHCP_AUTOIP_COOP_TRIES 9 +#define LWIP_MIB2_CALLBACKS 0 +#define LWIP_MULTICAST_TX_OPTIONS ((LWIP_IGMP || LWIP_IPV6_MLD) && (LWIP_UDP || LWIP_RAW)) +#define LWIP_IGMP 0 +#define LWIP_DNS 0 +#define DNS_TABLE_SIZE 4 +#define DNS_MAX_NAME_LENGTH 256 +#define DNS_MAX_SERVERS 2 +#define DNS_MAX_RETRIES 4 +#define DNS_DOES_NAME_CHECK 1 +#define LWIP_DNS_SECURE (LWIP_DNS_SECURE_RAND_XID | LWIP_DNS_SECURE_NO_MULTIPLE_OUTSTANDING | LWIP_DNS_SECURE_RAND_SRC_PORT) +#define DNS_LOCAL_HOSTLIST 0 +#define DNS_LOCAL_HOSTLIST_IS_DYNAMIC 0 +#define LWIP_DNS_SUPPORT_MDNS_QUERIES 0 +#define LWIP_UDP 1 +#define LWIP_UDPLITE 0 +#define UDP_TTL (IP_DEFAULT_TTL) +#define LWIP_NETBUF_RECVINFO 0 +#define LWIP_TCP 1 +#define TCP_TTL (IP_DEFAULT_TTL) +#define TCP_WND (4 * TCP_MSS) +#define TCP_MAXRTX 12 +#define TCP_SYNMAXRTX 6 +#define TCP_QUEUE_OOSEQ (LWIP_TCP) +#define LWIP_TCP_SACK_OUT 0 +#define LWIP_TCP_MAX_SACK_NUM 4 +#define TCP_MSS 536 +#define TCP_CALCULATE_EFF_SEND_MSS 1 +#define TCP_SND_BUF (2 * TCP_MSS) +#define TCP_SND_QUEUELEN ((4 * (TCP_SND_BUF) + (TCP_MSS - 1))/(TCP_MSS)) +#define TCP_SNDLOWAT LWIP_MIN(LWIP_MAX(((TCP_SND_BUF)/2), (2 * TCP_MSS) + 1), (TCP_SND_BUF) - 1) +#define TCP_SNDQUEUELOWAT LWIP_MAX(((TCP_SND_QUEUELEN)/2), 5) +#define TCP_OOSEQ_MAX_BYTES 0 +#define TCP_OOSEQ_BYTES_LIMIT(pcb) TCP_OOSEQ_MAX_BYTES +#define TCP_OOSEQ_MAX_PBUFS 0 +#define TCP_OOSEQ_PBUFS_LIMIT(pcb) TCP_OOSEQ_MAX_PBUFS +#define TCP_LISTEN_BACKLOG 0 +#define TCP_DEFAULT_LISTEN_BACKLOG 0xff +#define TCP_OVERSIZE TCP_MSS +#define LWIP_TCP_TIMESTAMPS 0 +#define TCP_WND_UPDATE_THRESHOLD LWIP_MIN((TCP_WND / 4), (TCP_MSS * 4)) +#define LWIP_EVENT_API 0 +#define LWIP_CALLBACK_API 1 +#define LWIP_WND_SCALE 0 +#define TCP_RCV_SCALE 0 +#define LWIP_TCP_PCB_NUM_EXT_ARGS 0 +#define LWIP_ALTCP 0 +#define LWIP_ALTCP_TLS 0 +#define PBUF_LINK_HLEN (14 + ETH_PAD_SIZE) +#define PBUF_LINK_ENCAPSULATION_HLEN 0 +#define PBUF_POOL_BUFSIZE LWIP_MEM_ALIGN_SIZE(TCP_MSS+40+PBUF_LINK_ENCAPSULATION_HLEN+PBUF_LINK_HLEN) +#define LWIP_PBUF_REF_T u8_t +#define LWIP_SINGLE_NETIF 0 +#define LWIP_NETIF_HOSTNAME 0 +#define LWIP_NETIF_API 0 +#define LWIP_NETIF_STATUS_CALLBACK 0 +#define LWIP_NETIF_EXT_STATUS_CALLBACK 0 +#define LWIP_NETIF_LINK_CALLBACK 0 +#define LWIP_NETIF_REMOVE_CALLBACK 0 +#define LWIP_NETIF_HWADDRHINT 0 +#define LWIP_NETIF_TX_SINGLE_PBUF 0 +#define LWIP_NUM_NETIF_CLIENT_DATA 0 +#define LWIP_HAVE_LOOPIF (LWIP_NETIF_LOOPBACK && !LWIP_SINGLE_NETIF) +#define LWIP_LOOPIF_MULTICAST 0 +#define LWIP_NETIF_LOOPBACK 0 +#define LWIP_LOOPBACK_MAX_PBUFS 0 +#define LWIP_NETIF_LOOPBACK_MULTITHREADING (!NO_SYS) +/*#define TCPIP_THREAD_NAME "tcpip_thread" +#define TCPIP_THREAD_STACKSIZE 0 +#define TCPIP_THREAD_PRIO 1 +#define TCPIP_MBOX_SIZE 0 +#define LWIP_TCPIP_THREAD_ALIVE() +#define SLIPIF_THREAD_NAME "slipif_loop" +#define SLIPIF_THREAD_STACKSIZE 0 +#define SLIPIF_THREAD_PRIO 1 +#define DEFAULT_THREAD_NAME "lwIP" +#define DEFAULT_THREAD_STACKSIZE 0 +#define DEFAULT_THREAD_PRIO 1 +#define DEFAULT_RAW_RECVMBOX_SIZE 0 +#define DEFAULT_UDP_RECVMBOX_SIZE 0 +#define DEFAULT_TCP_RECVMBOX_SIZE 0 +#define DEFAULT_ACCEPTMBOX_SIZE 0*/ +#define LWIP_NETCONN 1 +#define LWIP_TCPIP_TIMEOUT 0 +#define LWIP_NETCONN_SEM_PER_THREAD 0 +#define LWIP_NETCONN_FULLDUPLEX 0 +#define LWIP_SOCKET 1 +#define LWIP_COMPAT_SOCKETS 1 /* 0..2 */ +#define LWIP_POSIX_SOCKETS_IO_NAMES 1 +#define LWIP_SOCKET_OFFSET 0 +#define LWIP_TCP_KEEPALIVE 0 +#define LWIP_SO_SNDTIMEO 0 +#define LWIP_SO_RCVTIMEO 0 +#define LWIP_SO_SNDRCVTIMEO_NONSTANDARD 0 +#define LWIP_SO_RCVBUF 0 +#define LWIP_SO_LINGER 0 +#define RECV_BUFSIZE_DEFAULT INT_MAX +#define LWIP_TCP_CLOSE_TIMEOUT_MS_DEFAULT 20000 +#define SO_REUSE 0 +#define SO_REUSE_RXTOALL 0 +#define LWIP_FIONREAD_LINUXMODE 0 +#define LWIP_SOCKET_SELECT 1 +#define LWIP_SOCKET_POLL 1 +#define LWIP_STATS 1 +#define LWIP_STATS_DISPLAY 0 +#define LINK_STATS 1 +#define ETHARP_STATS (LWIP_ARP) +#define IP_STATS 1 +#define IPFRAG_STATS (IP_REASSEMBLY || IP_FRAG) +#define ICMP_STATS 1 +#define IGMP_STATS (LWIP_IGMP) +#define UDP_STATS (LWIP_UDP) +#define TCP_STATS (LWIP_TCP) +#define MEM_STATS ((MEM_LIBC_MALLOC == 0) && (MEM_USE_POOLS == 0)) +#define MEMP_STATS (MEMP_MEM_MALLOC == 0) +#define SYS_STATS (NO_SYS == 0) +#define IP6_STATS (LWIP_IPV6) +#define ICMP6_STATS (LWIP_IPV6 && LWIP_ICMP6) +#define IP6_FRAG_STATS (LWIP_IPV6 && (LWIP_IPV6_FRAG || LWIP_IPV6_REASS)) +#define MLD6_STATS (LWIP_IPV6 && LWIP_IPV6_MLD) +#define ND6_STATS (LWIP_IPV6) +#define MIB2_STATS 0 +#define LWIP_CHECKSUM_CTRL_PER_NETIF 0 +#define CHECKSUM_GEN_IP 1 +#define CHECKSUM_GEN_UDP 1 +#define CHECKSUM_GEN_TCP 1 +#define CHECKSUM_GEN_ICMP 1 +#define CHECKSUM_GEN_ICMP6 1 +#define CHECKSUM_CHECK_IP 1 +#define CHECKSUM_CHECK_UDP 1 +#define CHECKSUM_CHECK_TCP 1 +#define CHECKSUM_CHECK_ICMP 1 +#define CHECKSUM_CHECK_ICMP6 1 +#define LWIP_CHECKSUM_ON_COPY 0 +#define LWIP_IPV6 1 +#define IPV6_REASS_MAXAGE 60 +#define LWIP_IPV6_SCOPES (LWIP_IPV6 && !LWIP_SINGLE_NETIF) +#define LWIP_IPV6_SCOPES_DEBUG 0 +#define LWIP_IPV6_NUM_ADDRESSES 3 +#define LWIP_IPV6_FORWARD 0 +#define LWIP_IPV6_FRAG 1 +#define LWIP_IPV6_REASS (LWIP_IPV6) +#define LWIP_IPV6_SEND_ROUTER_SOLICIT 1 +#define LWIP_IPV6_AUTOCONFIG (LWIP_IPV6) +#define LWIP_IPV6_ADDRESS_LIFETIMES (LWIP_IPV6_AUTOCONFIG) +#define LWIP_IPV6_DUP_DETECT_ATTEMPTS 1 +#define LWIP_ICMP6 (LWIP_IPV6) +#define LWIP_ICMP6_DATASIZE 8 +#define LWIP_ICMP6_HL 255 +#define LWIP_IPV6_MLD (LWIP_IPV6) +#define MEMP_NUM_MLD6_GROUP 4 +#define LWIP_ND6_QUEUEING (LWIP_IPV6) +#define MEMP_NUM_ND6_QUEUE 20 +#define LWIP_ND6_NUM_NEIGHBORS 10 +#define LWIP_ND6_NUM_DESTINATIONS 10 +#define LWIP_ND6_NUM_PREFIXES 5 +#define LWIP_ND6_NUM_ROUTERS 3 +#define LWIP_ND6_MAX_MULTICAST_SOLICIT 3 +#define LWIP_ND6_MAX_UNICAST_SOLICIT 3 +#define LWIP_ND6_MAX_ANYCAST_DELAY_TIME 1000 +#define LWIP_ND6_MAX_NEIGHBOR_ADVERTISEMENT 3 +#define LWIP_ND6_REACHABLE_TIME 30000 +#define LWIP_ND6_RETRANS_TIMER 1000 +#define LWIP_ND6_DELAY_FIRST_PROBE_TIME 5000 +#define LWIP_ND6_ALLOW_RA_UPDATES 1 +#define LWIP_ND6_TCP_REACHABILITY_HINTS 1 +#define LWIP_ND6_RDNSS_MAX_DNS_SERVERS 0 +#define LWIP_IPV6_DHCP6 0 +#define LWIP_IPV6_DHCP6_STATEFUL 0 +#define LWIP_IPV6_DHCP6_STATELESS LWIP_IPV6_DHCP6 +#define LWIP_DHCP6_GET_NTP_SRV 0 +#define LWIP_DHCP6_MAX_NTP_SERVERS 1 +#define LWIP_DHCP6_MAX_DNS_SERVERS DNS_MAX_SERVERS + +/* TODO: check hooks */ + +#define LWIP_DBG_MIN_LEVEL LWIP_DBG_LEVEL_ALL +#define LWIP_DBG_TYPES_ON LWIP_DBG_ON +#define ETHARP_DEBUG LWIP_DBG_OFF +#define NETIF_DEBUG LWIP_DBG_OFF +#define PBUF_DEBUG LWIP_DBG_OFF +#define API_LIB_DEBUG LWIP_DBG_OFF +#define API_MSG_DEBUG LWIP_DBG_OFF +#define SOCKETS_DEBUG LWIP_DBG_OFF +#define ICMP_DEBUG LWIP_DBG_OFF +#define IGMP_DEBUG LWIP_DBG_OFF +#define INET_DEBUG LWIP_DBG_OFF +#define IP_DEBUG LWIP_DBG_OFF +#define IP_REASS_DEBUG LWIP_DBG_OFF +#define RAW_DEBUG LWIP_DBG_OFF +#define MEM_DEBUG LWIP_DBG_OFF +#define MEMP_DEBUG LWIP_DBG_OFF +#define SYS_DEBUG LWIP_DBG_OFF +#define TIMERS_DEBUG LWIP_DBG_OFF +#define TCP_DEBUG LWIP_DBG_OFF +#define TCP_INPUT_DEBUG LWIP_DBG_OFF +#define TCP_FR_DEBUG LWIP_DBG_OFF +#define TCP_RTO_DEBUG LWIP_DBG_OFF +#define TCP_CWND_DEBUG LWIP_DBG_OFF +#define TCP_WND_DEBUG LWIP_DBG_OFF +#define TCP_OUTPUT_DEBUG LWIP_DBG_OFF +#define TCP_RST_DEBUG LWIP_DBG_OFF +#define TCP_QLEN_DEBUG LWIP_DBG_OFF +#define UDP_DEBUG LWIP_DBG_OFF +#define TCPIP_DEBUG LWIP_DBG_OFF +#define SLIP_DEBUG LWIP_DBG_OFF +#define DHCP_DEBUG LWIP_DBG_OFF +#define AUTOIP_DEBUG LWIP_DBG_OFF +#define DNS_DEBUG LWIP_DBG_OFF +#define IP6_DEBUG LWIP_DBG_OFF +#define DHCP6_DEBUG LWIP_DBG_OFF +#define LWIP_TESTMODE 0 + +#define LWIP_PERF 0 diff --git a/contrib/examples/example_app/test_configs/opt_no_tcp_dualstack.h b/contrib/examples/example_app/test_configs/opt_no_tcp_dualstack.h new file mode 100644 index 00000000000..9d70acea4b0 --- /dev/null +++ b/contrib/examples/example_app/test_configs/opt_no_tcp_dualstack.h @@ -0,0 +1,4 @@ +#include "test_configs/opt_dualstack.h" + +#undef LWIP_TCP +#define LWIP_TCP 0 diff --git a/contrib/examples/example_app/test_configs/opt_no_tcp_ipv4only.h b/contrib/examples/example_app/test_configs/opt_no_tcp_ipv4only.h new file mode 100644 index 00000000000..bd228318423 --- /dev/null +++ b/contrib/examples/example_app/test_configs/opt_no_tcp_ipv4only.h @@ -0,0 +1,4 @@ +#include "test_configs/opt_ipv4only.h" + +#undef LWIP_TCP +#define LWIP_TCP 0 diff --git a/contrib/examples/example_app/test_configs/opt_no_tcp_ipv6only.h b/contrib/examples/example_app/test_configs/opt_no_tcp_ipv6only.h new file mode 100644 index 00000000000..9f956e3cbcf --- /dev/null +++ b/contrib/examples/example_app/test_configs/opt_no_tcp_ipv6only.h @@ -0,0 +1,4 @@ +#include "test_configs/opt_ipv6only.h" + +#undef LWIP_TCP +#define LWIP_TCP 0 diff --git a/contrib/examples/example_app/test_configs/opt_no_udp_dualstack.h b/contrib/examples/example_app/test_configs/opt_no_udp_dualstack.h new file mode 100644 index 00000000000..c9b9e9af993 --- /dev/null +++ b/contrib/examples/example_app/test_configs/opt_no_udp_dualstack.h @@ -0,0 +1,4 @@ +#include "test_configs/opt_dualstack.h" + +#undef LWIP_UDP +#define LWIP_UDP 0 diff --git a/contrib/examples/example_app/test_configs/opt_no_udp_ipv4only.h b/contrib/examples/example_app/test_configs/opt_no_udp_ipv4only.h new file mode 100644 index 00000000000..7aa3ace9dda --- /dev/null +++ b/contrib/examples/example_app/test_configs/opt_no_udp_ipv4only.h @@ -0,0 +1,4 @@ +#include "test_configs/opt_ipv4only.h" + +#undef LWIP_UDP +#define LWIP_UDP 0 diff --git a/contrib/examples/example_app/test_configs/opt_no_udp_ipv6only.h b/contrib/examples/example_app/test_configs/opt_no_udp_ipv6only.h new file mode 100644 index 00000000000..0572798b1a0 --- /dev/null +++ b/contrib/examples/example_app/test_configs/opt_no_udp_ipv6only.h @@ -0,0 +1,4 @@ +#include "test_configs/opt_ipv6only.h" + +#undef LWIP_UDP +#define LWIP_UDP 0 diff --git a/contrib/examples/example_app/test_configs/opt_none.h b/contrib/examples/example_app/test_configs/opt_none.h new file mode 100644 index 00000000000..3c3932183b2 --- /dev/null +++ b/contrib/examples/example_app/test_configs/opt_none.h @@ -0,0 +1,2 @@ +/* test and empty lwipopts.h file */ + diff --git a/contrib/examples/example_app/test_configs/opt_nosys_dual.h b/contrib/examples/example_app/test_configs/opt_nosys_dual.h new file mode 100644 index 00000000000..17ee97ff461 --- /dev/null +++ b/contrib/examples/example_app/test_configs/opt_nosys_dual.h @@ -0,0 +1,295 @@ +/* test an lwipopts.h file with default contents */ +#define NO_SYS 0 +#define NO_SYS_NO_TIMERS 0 +#define LWIP_TIMERS 1 +#define LWIP_TIMERS_CUSTOM 0 +#define LWIP_MPU_COMPATIBLE 0 +#define LWIP_TCPIP_CORE_LOCKING 1 +#define LWIP_TCPIP_CORE_LOCKING_INPUT 0 +#define SYS_LIGHTWEIGHT_PROT 1 +#define MEM_LIBC_MALLOC 0 +#define MEMP_MEM_MALLOC 0 +#define MEMP_MEM_INIT 0 +#define MEM_ALIGNMENT 1 +#define MEM_SIZE 1600 +#define MEMP_OVERFLOW_CHECK 0 +#define MEMP_SANITY_CHECK 0 +#define MEM_OVERFLOW_CHECK 0 +#define MEM_SANITY_CHECK 0 +#define MEM_USE_POOLS 0 +#define MEM_USE_POOLS_TRY_BIGGER_POOL 0 +#define MEMP_USE_CUSTOM_POOLS 0 +#define LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT 0 +/*#define MEMP_NUM_PBUF 16 +#define MEMP_NUM_RAW_PCB 4 +#define MEMP_NUM_UDP_PCB 4 +#define MEMP_NUM_TCP_PCB 5 +#define MEMP_NUM_TCP_PCB_LISTEN 8 +#define MEMP_NUM_TCP_SEG 16 +#define MEMP_NUM_ALTCP_PCB MEMP_NUM_TCP_PCB +#define MEMP_NUM_REASSDATA 5 +#define MEMP_NUM_FRAG_PBUF 15 +#define MEMP_NUM_ARP_QUEUE 30 +#define MEMP_NUM_IGMP_GROUP 8 +#define MEMP_NUM_SYS_TIMEOUT (LWIP_NUM_SYS_TIMEOUT_INTERNAL + 2) +#define MEMP_NUM_NETBUF 2 +#define MEMP_NUM_NETCONN 4 +#define MEMP_NUM_SELECT_CB 4 +#define MEMP_NUM_TCPIP_MSG_API 8 +#define MEMP_NUM_TCPIP_MSG_INPKT 8 +#define MEMP_NUM_NETDB 1 +#define MEMP_NUM_LOCALHOSTLIST 1 +#define PBUF_POOL_SIZE 16 +#define MEMP_NUM_API_MSG MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_DNS_API_MSG MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_SOCKET_SETGETSOCKOPT_DATA MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_NETIFAPI_MSG MEMP_NUM_TCPIP_MSG_API*/ +#define LWIP_ARP 1 +#define ARP_TABLE_SIZE 10 +#define ARP_MAXAGE 300 +#define ARP_QUEUEING 0 +#define ARP_QUEUE_LEN 3 +#define ETHARP_SUPPORT_VLAN 0 +#define LWIP_ETHERNET LWIP_ARP +#define ETH_PAD_SIZE 0 +#define ETHARP_SUPPORT_STATIC_ENTRIES 0 +#define ETHARP_TABLE_MATCH_NETIF !LWIP_SINGLE_NETIF +#define LWIP_IPV4 1 +#define IP_FORWARD 0 +#define IP_REASSEMBLY 1 +#define IP_FRAG 1 +#define IP_OPTIONS_ALLOWED 1 +#define IP_REASS_MAXAGE 15 +#define IP_REASS_MAX_PBUFS 10 +#define IP_DEFAULT_TTL 255 +#define IP_SOF_BROADCAST 0 +#define IP_SOF_BROADCAST_RECV 0 +#define IP_FORWARD_ALLOW_TX_ON_RX_NETIF 0 +#define LWIP_ICMP 1 +#define ICMP_TTL (IP_DEFAULT_TTL) +#define LWIP_BROADCAST_PING 0 +#define LWIP_MULTICAST_PING 0 +#define LWIP_RAW 0 +#define RAW_TTL (IP_DEFAULT_TTL) +#define LWIP_DHCP 1 +#define LWIP_DHCP_CHECK_LINK_UP 0 +#define LWIP_DHCP_BOOTP_FILE 0 +#define LWIP_DHCP_GET_NTP_SRV 0 +#define LWIP_DHCP_MAX_NTP_SERVERS 1 +#define LWIP_DHCP_MAX_DNS_SERVERS DNS_MAX_SERVERS +#define LWIP_AUTOIP 0 +#define LWIP_DHCP_AUTOIP_COOP 0 +#define LWIP_DHCP_AUTOIP_COOP_TRIES 9 +#define LWIP_MIB2_CALLBACKS 0 +#define LWIP_MULTICAST_TX_OPTIONS ((LWIP_IGMP || LWIP_IPV6_MLD) && (LWIP_UDP || LWIP_RAW)) +#define LWIP_IGMP 0 +#define LWIP_DNS 0 +#define DNS_TABLE_SIZE 4 +#define DNS_MAX_NAME_LENGTH 256 +#define DNS_MAX_SERVERS 2 +#define DNS_MAX_RETRIES 4 +#define DNS_DOES_NAME_CHECK 1 +#define LWIP_DNS_SECURE (LWIP_DNS_SECURE_RAND_XID | LWIP_DNS_SECURE_NO_MULTIPLE_OUTSTANDING | LWIP_DNS_SECURE_RAND_SRC_PORT) +#define DNS_LOCAL_HOSTLIST 0 +#define DNS_LOCAL_HOSTLIST_IS_DYNAMIC 0 +#define LWIP_DNS_SUPPORT_MDNS_QUERIES 0 +#define LWIP_UDP 1 +#define LWIP_UDPLITE 0 +#define UDP_TTL (IP_DEFAULT_TTL) +#define LWIP_NETBUF_RECVINFO 0 +#define LWIP_TCP 1 +#define TCP_TTL (IP_DEFAULT_TTL) +#define TCP_WND (4 * TCP_MSS) +#define TCP_MAXRTX 12 +#define TCP_SYNMAXRTX 6 +#define TCP_QUEUE_OOSEQ (LWIP_TCP) +#define LWIP_TCP_SACK_OUT 0 +#define LWIP_TCP_MAX_SACK_NUM 4 +#define TCP_MSS 536 +#define TCP_CALCULATE_EFF_SEND_MSS 1 +#define TCP_SND_BUF (2 * TCP_MSS) +#define TCP_SND_QUEUELEN ((4 * (TCP_SND_BUF) + (TCP_MSS - 1))/(TCP_MSS)) +#define TCP_SNDLOWAT LWIP_MIN(LWIP_MAX(((TCP_SND_BUF)/2), (2 * TCP_MSS) + 1), (TCP_SND_BUF) - 1) +#define TCP_SNDQUEUELOWAT LWIP_MAX(((TCP_SND_QUEUELEN)/2), 5) +#define TCP_OOSEQ_MAX_BYTES 0 +#define TCP_OOSEQ_BYTES_LIMIT(pcb) TCP_OOSEQ_MAX_BYTES +#define TCP_OOSEQ_MAX_PBUFS 0 +#define TCP_OOSEQ_PBUFS_LIMIT(pcb) TCP_OOSEQ_MAX_PBUFS +#define TCP_LISTEN_BACKLOG 0 +#define TCP_DEFAULT_LISTEN_BACKLOG 0xff +#define TCP_OVERSIZE TCP_MSS +#define LWIP_TCP_TIMESTAMPS 0 +#define TCP_WND_UPDATE_THRESHOLD LWIP_MIN((TCP_WND / 4), (TCP_MSS * 4)) +#define LWIP_EVENT_API 0 +#define LWIP_CALLBACK_API 1 +#define LWIP_WND_SCALE 0 +#define TCP_RCV_SCALE 0 +#define LWIP_TCP_PCB_NUM_EXT_ARGS 0 +#define LWIP_ALTCP 0 +#define LWIP_ALTCP_TLS 0 +#define PBUF_LINK_HLEN (14 + ETH_PAD_SIZE) +#define PBUF_LINK_ENCAPSULATION_HLEN 0 +#define PBUF_POOL_BUFSIZE LWIP_MEM_ALIGN_SIZE(TCP_MSS+40+PBUF_LINK_ENCAPSULATION_HLEN+PBUF_LINK_HLEN) +#define LWIP_PBUF_REF_T u8_t +#define LWIP_SINGLE_NETIF 0 +#define LWIP_NETIF_HOSTNAME 0 +#define LWIP_NETIF_API 0 +#define LWIP_NETIF_STATUS_CALLBACK 0 +#define LWIP_NETIF_EXT_STATUS_CALLBACK 0 +#define LWIP_NETIF_LINK_CALLBACK 0 +#define LWIP_NETIF_REMOVE_CALLBACK 0 +#define LWIP_NETIF_HWADDRHINT 0 +#define LWIP_NETIF_TX_SINGLE_PBUF 0 +#define LWIP_NUM_NETIF_CLIENT_DATA 0 +#define LWIP_HAVE_LOOPIF (LWIP_NETIF_LOOPBACK && !LWIP_SINGLE_NETIF) +#define LWIP_LOOPIF_MULTICAST 0 +#define LWIP_NETIF_LOOPBACK 0 +#define LWIP_LOOPBACK_MAX_PBUFS 0 +#define LWIP_NETIF_LOOPBACK_MULTITHREADING (!NO_SYS) +/*#define TCPIP_THREAD_NAME "tcpip_thread" +#define TCPIP_THREAD_STACKSIZE 0 +#define TCPIP_THREAD_PRIO 1 +#define TCPIP_MBOX_SIZE 0 +#define LWIP_TCPIP_THREAD_ALIVE() +#define SLIPIF_THREAD_NAME "slipif_loop" +#define SLIPIF_THREAD_STACKSIZE 0 +#define SLIPIF_THREAD_PRIO 1 +#define DEFAULT_THREAD_NAME "lwIP" +#define DEFAULT_THREAD_STACKSIZE 0 +#define DEFAULT_THREAD_PRIO 1 +#define DEFAULT_RAW_RECVMBOX_SIZE 0 +#define DEFAULT_UDP_RECVMBOX_SIZE 0 +#define DEFAULT_TCP_RECVMBOX_SIZE 0 +#define DEFAULT_ACCEPTMBOX_SIZE 0*/ +#define LWIP_NETCONN 0 +#define LWIP_TCPIP_TIMEOUT 0 +#define LWIP_NETCONN_SEM_PER_THREAD 0 +#define LWIP_NETCONN_FULLDUPLEX 0 +#define LWIP_SOCKET 0 +#define LWIP_COMPAT_SOCKETS 1 /* 0..2 */ +#define LWIP_POSIX_SOCKETS_IO_NAMES 1 +#define LWIP_SOCKET_OFFSET 0 +#define LWIP_TCP_KEEPALIVE 0 +#define LWIP_SO_SNDTIMEO 0 +#define LWIP_SO_RCVTIMEO 0 +#define LWIP_SO_SNDRCVTIMEO_NONSTANDARD 0 +#define LWIP_SO_RCVBUF 0 +#define LWIP_SO_LINGER 0 +#define RECV_BUFSIZE_DEFAULT INT_MAX +#define LWIP_TCP_CLOSE_TIMEOUT_MS_DEFAULT 20000 +#define SO_REUSE 0 +#define SO_REUSE_RXTOALL 0 +#define LWIP_FIONREAD_LINUXMODE 0 +#define LWIP_SOCKET_SELECT 1 +#define LWIP_SOCKET_POLL 1 +#define LWIP_STATS 1 +#define LWIP_STATS_DISPLAY 0 +#define LINK_STATS 1 +#define ETHARP_STATS (LWIP_ARP) +#define IP_STATS 1 +#define IPFRAG_STATS (IP_REASSEMBLY || IP_FRAG) +#define ICMP_STATS 1 +#define IGMP_STATS (LWIP_IGMP) +#define UDP_STATS (LWIP_UDP) +#define TCP_STATS (LWIP_TCP) +#define MEM_STATS ((MEM_LIBC_MALLOC == 0) && (MEM_USE_POOLS == 0)) +#define MEMP_STATS (MEMP_MEM_MALLOC == 0) +#define SYS_STATS (NO_SYS == 0) +#define IP6_STATS (LWIP_IPV6) +#define ICMP6_STATS (LWIP_IPV6 && LWIP_ICMP6) +#define IP6_FRAG_STATS (LWIP_IPV6 && (LWIP_IPV6_FRAG || LWIP_IPV6_REASS)) +#define MLD6_STATS (LWIP_IPV6 && LWIP_IPV6_MLD) +#define ND6_STATS (LWIP_IPV6) +#define MIB2_STATS 0 +#define LWIP_CHECKSUM_CTRL_PER_NETIF 0 +#define CHECKSUM_GEN_IP 1 +#define CHECKSUM_GEN_UDP 1 +#define CHECKSUM_GEN_TCP 1 +#define CHECKSUM_GEN_ICMP 1 +#define CHECKSUM_GEN_ICMP6 1 +#define CHECKSUM_CHECK_IP 1 +#define CHECKSUM_CHECK_UDP 1 +#define CHECKSUM_CHECK_TCP 1 +#define CHECKSUM_CHECK_ICMP 1 +#define CHECKSUM_CHECK_ICMP6 1 +#define LWIP_CHECKSUM_ON_COPY 0 +#define LWIP_IPV6 1 +#define IPV6_REASS_MAXAGE 60 +#define LWIP_IPV6_SCOPES (LWIP_IPV6 && !LWIP_SINGLE_NETIF) +#define LWIP_IPV6_SCOPES_DEBUG 0 +#define LWIP_IPV6_NUM_ADDRESSES 3 +#define LWIP_IPV6_FORWARD 0 +#define LWIP_IPV6_FRAG 1 +#define LWIP_IPV6_REASS (LWIP_IPV6) +#define LWIP_IPV6_SEND_ROUTER_SOLICIT 1 +#define LWIP_IPV6_AUTOCONFIG (LWIP_IPV6) +#define LWIP_IPV6_ADDRESS_LIFETIMES (LWIP_IPV6_AUTOCONFIG) +#define LWIP_IPV6_DUP_DETECT_ATTEMPTS 1 +#define LWIP_ICMP6 (LWIP_IPV6) +#define LWIP_ICMP6_DATASIZE 8 +#define LWIP_ICMP6_HL 255 +#define LWIP_IPV6_MLD (LWIP_IPV6) +#define MEMP_NUM_MLD6_GROUP 4 +#define LWIP_ND6_QUEUEING (LWIP_IPV6) +#define MEMP_NUM_ND6_QUEUE 20 +#define LWIP_ND6_NUM_NEIGHBORS 10 +#define LWIP_ND6_NUM_DESTINATIONS 10 +#define LWIP_ND6_NUM_PREFIXES 5 +#define LWIP_ND6_NUM_ROUTERS 3 +#define LWIP_ND6_MAX_MULTICAST_SOLICIT 3 +#define LWIP_ND6_MAX_UNICAST_SOLICIT 3 +#define LWIP_ND6_MAX_ANYCAST_DELAY_TIME 1000 +#define LWIP_ND6_MAX_NEIGHBOR_ADVERTISEMENT 3 +#define LWIP_ND6_REACHABLE_TIME 30000 +#define LWIP_ND6_RETRANS_TIMER 1000 +#define LWIP_ND6_DELAY_FIRST_PROBE_TIME 5000 +#define LWIP_ND6_ALLOW_RA_UPDATES 1 +#define LWIP_ND6_TCP_REACHABILITY_HINTS 1 +#define LWIP_ND6_RDNSS_MAX_DNS_SERVERS 0 +#define LWIP_IPV6_DHCP6 0 +#define LWIP_IPV6_DHCP6_STATEFUL 0 +#define LWIP_IPV6_DHCP6_STATELESS LWIP_IPV6_DHCP6 +#define LWIP_DHCP6_GET_NTP_SRV 0 +#define LWIP_DHCP6_MAX_NTP_SERVERS 1 +#define LWIP_DHCP6_MAX_DNS_SERVERS DNS_MAX_SERVERS + +/* TODO: check hooks */ + +#define LWIP_DBG_MIN_LEVEL LWIP_DBG_LEVEL_ALL +#define LWIP_DBG_TYPES_ON LWIP_DBG_ON +#define ETHARP_DEBUG LWIP_DBG_OFF +#define NETIF_DEBUG LWIP_DBG_OFF +#define PBUF_DEBUG LWIP_DBG_OFF +#define API_LIB_DEBUG LWIP_DBG_OFF +#define API_MSG_DEBUG LWIP_DBG_OFF +#define SOCKETS_DEBUG LWIP_DBG_OFF +#define ICMP_DEBUG LWIP_DBG_OFF +#define IGMP_DEBUG LWIP_DBG_OFF +#define INET_DEBUG LWIP_DBG_OFF +#define IP_DEBUG LWIP_DBG_OFF +#define IP_REASS_DEBUG LWIP_DBG_OFF +#define RAW_DEBUG LWIP_DBG_OFF +#define MEM_DEBUG LWIP_DBG_OFF +#define MEMP_DEBUG LWIP_DBG_OFF +#define SYS_DEBUG LWIP_DBG_OFF +#define TIMERS_DEBUG LWIP_DBG_OFF +#define TCP_DEBUG LWIP_DBG_OFF +#define TCP_INPUT_DEBUG LWIP_DBG_OFF +#define TCP_FR_DEBUG LWIP_DBG_OFF +#define TCP_RTO_DEBUG LWIP_DBG_OFF +#define TCP_CWND_DEBUG LWIP_DBG_OFF +#define TCP_WND_DEBUG LWIP_DBG_OFF +#define TCP_OUTPUT_DEBUG LWIP_DBG_OFF +#define TCP_RST_DEBUG LWIP_DBG_OFF +#define TCP_QLEN_DEBUG LWIP_DBG_OFF +#define UDP_DEBUG LWIP_DBG_OFF +#define TCPIP_DEBUG LWIP_DBG_OFF +#define SLIP_DEBUG LWIP_DBG_OFF +#define DHCP_DEBUG LWIP_DBG_OFF +#define AUTOIP_DEBUG LWIP_DBG_OFF +#define DNS_DEBUG LWIP_DBG_OFF +#define IP6_DEBUG LWIP_DBG_OFF +#define DHCP6_DEBUG LWIP_DBG_OFF +#define LWIP_TESTMODE 0 + +#define LWIP_PERF 0 diff --git a/contrib/examples/example_app/test_configs/opt_nosys_ipv4.h b/contrib/examples/example_app/test_configs/opt_nosys_ipv4.h new file mode 100644 index 00000000000..024d79be11d --- /dev/null +++ b/contrib/examples/example_app/test_configs/opt_nosys_ipv4.h @@ -0,0 +1,295 @@ +/* test an lwipopts.h file with default contents */ +#define NO_SYS 0 +#define NO_SYS_NO_TIMERS 0 +#define LWIP_TIMERS 1 +#define LWIP_TIMERS_CUSTOM 0 +#define LWIP_MPU_COMPATIBLE 0 +#define LWIP_TCPIP_CORE_LOCKING 1 +#define LWIP_TCPIP_CORE_LOCKING_INPUT 0 +#define SYS_LIGHTWEIGHT_PROT 1 +#define MEM_LIBC_MALLOC 0 +#define MEMP_MEM_MALLOC 0 +#define MEMP_MEM_INIT 0 +#define MEM_ALIGNMENT 1 +#define MEM_SIZE 1600 +#define MEMP_OVERFLOW_CHECK 0 +#define MEMP_SANITY_CHECK 0 +#define MEM_OVERFLOW_CHECK 0 +#define MEM_SANITY_CHECK 0 +#define MEM_USE_POOLS 0 +#define MEM_USE_POOLS_TRY_BIGGER_POOL 0 +#define MEMP_USE_CUSTOM_POOLS 0 +#define LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT 0 +/*#define MEMP_NUM_PBUF 16 +#define MEMP_NUM_RAW_PCB 4 +#define MEMP_NUM_UDP_PCB 4 +#define MEMP_NUM_TCP_PCB 5 +#define MEMP_NUM_TCP_PCB_LISTEN 8 +#define MEMP_NUM_TCP_SEG 16 +#define MEMP_NUM_ALTCP_PCB MEMP_NUM_TCP_PCB +#define MEMP_NUM_REASSDATA 5 +#define MEMP_NUM_FRAG_PBUF 15 +#define MEMP_NUM_ARP_QUEUE 30 +#define MEMP_NUM_IGMP_GROUP 8 +#define MEMP_NUM_SYS_TIMEOUT (LWIP_NUM_SYS_TIMEOUT_INTERNAL + 2) +#define MEMP_NUM_NETBUF 2 +#define MEMP_NUM_NETCONN 4 +#define MEMP_NUM_SELECT_CB 4 +#define MEMP_NUM_TCPIP_MSG_API 8 +#define MEMP_NUM_TCPIP_MSG_INPKT 8 +#define MEMP_NUM_NETDB 1 +#define MEMP_NUM_LOCALHOSTLIST 1 +#define PBUF_POOL_SIZE 16 +#define MEMP_NUM_API_MSG MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_DNS_API_MSG MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_SOCKET_SETGETSOCKOPT_DATA MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_NETIFAPI_MSG MEMP_NUM_TCPIP_MSG_API*/ +#define LWIP_ARP 1 +#define ARP_TABLE_SIZE 10 +#define ARP_MAXAGE 300 +#define ARP_QUEUEING 0 +#define ARP_QUEUE_LEN 3 +#define ETHARP_SUPPORT_VLAN 0 +#define LWIP_ETHERNET LWIP_ARP +#define ETH_PAD_SIZE 0 +#define ETHARP_SUPPORT_STATIC_ENTRIES 0 +#define ETHARP_TABLE_MATCH_NETIF !LWIP_SINGLE_NETIF +#define LWIP_IPV4 1 +#define IP_FORWARD 0 +#define IP_REASSEMBLY 1 +#define IP_FRAG 1 +#define IP_OPTIONS_ALLOWED 1 +#define IP_REASS_MAXAGE 15 +#define IP_REASS_MAX_PBUFS 10 +#define IP_DEFAULT_TTL 255 +#define IP_SOF_BROADCAST 0 +#define IP_SOF_BROADCAST_RECV 0 +#define IP_FORWARD_ALLOW_TX_ON_RX_NETIF 0 +#define LWIP_ICMP 1 +#define ICMP_TTL (IP_DEFAULT_TTL) +#define LWIP_BROADCAST_PING 0 +#define LWIP_MULTICAST_PING 0 +#define LWIP_RAW 0 +#define RAW_TTL (IP_DEFAULT_TTL) +#define LWIP_DHCP 1 +#define LWIP_DHCP_CHECK_LINK_UP 0 +#define LWIP_DHCP_BOOTP_FILE 0 +#define LWIP_DHCP_GET_NTP_SRV 0 +#define LWIP_DHCP_MAX_NTP_SERVERS 1 +#define LWIP_DHCP_MAX_DNS_SERVERS DNS_MAX_SERVERS +#define LWIP_AUTOIP 0 +#define LWIP_DHCP_AUTOIP_COOP 0 +#define LWIP_DHCP_AUTOIP_COOP_TRIES 9 +#define LWIP_MIB2_CALLBACKS 0 +#define LWIP_MULTICAST_TX_OPTIONS ((LWIP_IGMP || LWIP_IPV6_MLD) && (LWIP_UDP || LWIP_RAW)) +#define LWIP_IGMP 0 +#define LWIP_DNS 0 +#define DNS_TABLE_SIZE 4 +#define DNS_MAX_NAME_LENGTH 256 +#define DNS_MAX_SERVERS 2 +#define DNS_MAX_RETRIES 4 +#define DNS_DOES_NAME_CHECK 1 +#define LWIP_DNS_SECURE (LWIP_DNS_SECURE_RAND_XID | LWIP_DNS_SECURE_NO_MULTIPLE_OUTSTANDING | LWIP_DNS_SECURE_RAND_SRC_PORT) +#define DNS_LOCAL_HOSTLIST 0 +#define DNS_LOCAL_HOSTLIST_IS_DYNAMIC 0 +#define LWIP_DNS_SUPPORT_MDNS_QUERIES 0 +#define LWIP_UDP 1 +#define LWIP_UDPLITE 0 +#define UDP_TTL (IP_DEFAULT_TTL) +#define LWIP_NETBUF_RECVINFO 0 +#define LWIP_TCP 1 +#define TCP_TTL (IP_DEFAULT_TTL) +#define TCP_WND (4 * TCP_MSS) +#define TCP_MAXRTX 12 +#define TCP_SYNMAXRTX 6 +#define TCP_QUEUE_OOSEQ (LWIP_TCP) +#define LWIP_TCP_SACK_OUT 0 +#define LWIP_TCP_MAX_SACK_NUM 4 +#define TCP_MSS 536 +#define TCP_CALCULATE_EFF_SEND_MSS 1 +#define TCP_SND_BUF (2 * TCP_MSS) +#define TCP_SND_QUEUELEN ((4 * (TCP_SND_BUF) + (TCP_MSS - 1))/(TCP_MSS)) +#define TCP_SNDLOWAT LWIP_MIN(LWIP_MAX(((TCP_SND_BUF)/2), (2 * TCP_MSS) + 1), (TCP_SND_BUF) - 1) +#define TCP_SNDQUEUELOWAT LWIP_MAX(((TCP_SND_QUEUELEN)/2), 5) +#define TCP_OOSEQ_MAX_BYTES 0 +#define TCP_OOSEQ_BYTES_LIMIT(pcb) TCP_OOSEQ_MAX_BYTES +#define TCP_OOSEQ_MAX_PBUFS 0 +#define TCP_OOSEQ_PBUFS_LIMIT(pcb) TCP_OOSEQ_MAX_PBUFS +#define TCP_LISTEN_BACKLOG 0 +#define TCP_DEFAULT_LISTEN_BACKLOG 0xff +#define TCP_OVERSIZE TCP_MSS +#define LWIP_TCP_TIMESTAMPS 0 +#define TCP_WND_UPDATE_THRESHOLD LWIP_MIN((TCP_WND / 4), (TCP_MSS * 4)) +#define LWIP_EVENT_API 0 +#define LWIP_CALLBACK_API 1 +#define LWIP_WND_SCALE 0 +#define TCP_RCV_SCALE 0 +#define LWIP_TCP_PCB_NUM_EXT_ARGS 0 +#define LWIP_ALTCP 0 +#define LWIP_ALTCP_TLS 0 +#define PBUF_LINK_HLEN (14 + ETH_PAD_SIZE) +#define PBUF_LINK_ENCAPSULATION_HLEN 0 +#define PBUF_POOL_BUFSIZE LWIP_MEM_ALIGN_SIZE(TCP_MSS+40+PBUF_LINK_ENCAPSULATION_HLEN+PBUF_LINK_HLEN) +#define LWIP_PBUF_REF_T u8_t +#define LWIP_SINGLE_NETIF 0 +#define LWIP_NETIF_HOSTNAME 0 +#define LWIP_NETIF_API 0 +#define LWIP_NETIF_STATUS_CALLBACK 0 +#define LWIP_NETIF_EXT_STATUS_CALLBACK 0 +#define LWIP_NETIF_LINK_CALLBACK 0 +#define LWIP_NETIF_REMOVE_CALLBACK 0 +#define LWIP_NETIF_HWADDRHINT 0 +#define LWIP_NETIF_TX_SINGLE_PBUF 0 +#define LWIP_NUM_NETIF_CLIENT_DATA 0 +#define LWIP_HAVE_LOOPIF (LWIP_NETIF_LOOPBACK && !LWIP_SINGLE_NETIF) +#define LWIP_LOOPIF_MULTICAST 0 +#define LWIP_NETIF_LOOPBACK 0 +#define LWIP_LOOPBACK_MAX_PBUFS 0 +#define LWIP_NETIF_LOOPBACK_MULTITHREADING (!NO_SYS) +/*#define TCPIP_THREAD_NAME "tcpip_thread" +#define TCPIP_THREAD_STACKSIZE 0 +#define TCPIP_THREAD_PRIO 1 +#define TCPIP_MBOX_SIZE 0 +#define LWIP_TCPIP_THREAD_ALIVE() +#define SLIPIF_THREAD_NAME "slipif_loop" +#define SLIPIF_THREAD_STACKSIZE 0 +#define SLIPIF_THREAD_PRIO 1 +#define DEFAULT_THREAD_NAME "lwIP" +#define DEFAULT_THREAD_STACKSIZE 0 +#define DEFAULT_THREAD_PRIO 1 +#define DEFAULT_RAW_RECVMBOX_SIZE 0 +#define DEFAULT_UDP_RECVMBOX_SIZE 0 +#define DEFAULT_TCP_RECVMBOX_SIZE 0 +#define DEFAULT_ACCEPTMBOX_SIZE 0*/ +#define LWIP_NETCONN 0 +#define LWIP_TCPIP_TIMEOUT 0 +#define LWIP_NETCONN_SEM_PER_THREAD 0 +#define LWIP_NETCONN_FULLDUPLEX 0 +#define LWIP_SOCKET 0 +#define LWIP_COMPAT_SOCKETS 1 /* 0..2 */ +#define LWIP_POSIX_SOCKETS_IO_NAMES 1 +#define LWIP_SOCKET_OFFSET 0 +#define LWIP_TCP_KEEPALIVE 0 +#define LWIP_SO_SNDTIMEO 0 +#define LWIP_SO_RCVTIMEO 0 +#define LWIP_SO_SNDRCVTIMEO_NONSTANDARD 0 +#define LWIP_SO_RCVBUF 0 +#define LWIP_SO_LINGER 0 +#define RECV_BUFSIZE_DEFAULT INT_MAX +#define LWIP_TCP_CLOSE_TIMEOUT_MS_DEFAULT 20000 +#define SO_REUSE 0 +#define SO_REUSE_RXTOALL 0 +#define LWIP_FIONREAD_LINUXMODE 0 +#define LWIP_SOCKET_SELECT 1 +#define LWIP_SOCKET_POLL 1 +#define LWIP_STATS 1 +#define LWIP_STATS_DISPLAY 0 +#define LINK_STATS 1 +#define ETHARP_STATS (LWIP_ARP) +#define IP_STATS 1 +#define IPFRAG_STATS (IP_REASSEMBLY || IP_FRAG) +#define ICMP_STATS 1 +#define IGMP_STATS (LWIP_IGMP) +#define UDP_STATS (LWIP_UDP) +#define TCP_STATS (LWIP_TCP) +#define MEM_STATS ((MEM_LIBC_MALLOC == 0) && (MEM_USE_POOLS == 0)) +#define MEMP_STATS (MEMP_MEM_MALLOC == 0) +#define SYS_STATS (NO_SYS == 0) +#define IP6_STATS (LWIP_IPV6) +#define ICMP6_STATS (LWIP_IPV6 && LWIP_ICMP6) +#define IP6_FRAG_STATS (LWIP_IPV6 && (LWIP_IPV6_FRAG || LWIP_IPV6_REASS)) +#define MLD6_STATS (LWIP_IPV6 && LWIP_IPV6_MLD) +#define ND6_STATS (LWIP_IPV6) +#define MIB2_STATS 0 +#define LWIP_CHECKSUM_CTRL_PER_NETIF 0 +#define CHECKSUM_GEN_IP 1 +#define CHECKSUM_GEN_UDP 1 +#define CHECKSUM_GEN_TCP 1 +#define CHECKSUM_GEN_ICMP 1 +#define CHECKSUM_GEN_ICMP6 1 +#define CHECKSUM_CHECK_IP 1 +#define CHECKSUM_CHECK_UDP 1 +#define CHECKSUM_CHECK_TCP 1 +#define CHECKSUM_CHECK_ICMP 1 +#define CHECKSUM_CHECK_ICMP6 1 +#define LWIP_CHECKSUM_ON_COPY 0 +#define LWIP_IPV6 0 +#define IPV6_REASS_MAXAGE 60 +#define LWIP_IPV6_SCOPES (LWIP_IPV6 && !LWIP_SINGLE_NETIF) +#define LWIP_IPV6_SCOPES_DEBUG 0 +#define LWIP_IPV6_NUM_ADDRESSES 3 +#define LWIP_IPV6_FORWARD 0 +#define LWIP_IPV6_FRAG 1 +#define LWIP_IPV6_REASS (LWIP_IPV6) +#define LWIP_IPV6_SEND_ROUTER_SOLICIT 1 +#define LWIP_IPV6_AUTOCONFIG (LWIP_IPV6) +#define LWIP_IPV6_ADDRESS_LIFETIMES (LWIP_IPV6_AUTOCONFIG) +#define LWIP_IPV6_DUP_DETECT_ATTEMPTS 1 +#define LWIP_ICMP6 (LWIP_IPV6) +#define LWIP_ICMP6_DATASIZE 8 +#define LWIP_ICMP6_HL 255 +#define LWIP_IPV6_MLD (LWIP_IPV6) +#define MEMP_NUM_MLD6_GROUP 4 +#define LWIP_ND6_QUEUEING (LWIP_IPV6) +#define MEMP_NUM_ND6_QUEUE 20 +#define LWIP_ND6_NUM_NEIGHBORS 10 +#define LWIP_ND6_NUM_DESTINATIONS 10 +#define LWIP_ND6_NUM_PREFIXES 5 +#define LWIP_ND6_NUM_ROUTERS 3 +#define LWIP_ND6_MAX_MULTICAST_SOLICIT 3 +#define LWIP_ND6_MAX_UNICAST_SOLICIT 3 +#define LWIP_ND6_MAX_ANYCAST_DELAY_TIME 1000 +#define LWIP_ND6_MAX_NEIGHBOR_ADVERTISEMENT 3 +#define LWIP_ND6_REACHABLE_TIME 30000 +#define LWIP_ND6_RETRANS_TIMER 1000 +#define LWIP_ND6_DELAY_FIRST_PROBE_TIME 5000 +#define LWIP_ND6_ALLOW_RA_UPDATES 1 +#define LWIP_ND6_TCP_REACHABILITY_HINTS 1 +#define LWIP_ND6_RDNSS_MAX_DNS_SERVERS 0 +#define LWIP_IPV6_DHCP6 0 +#define LWIP_IPV6_DHCP6_STATEFUL 0 +#define LWIP_IPV6_DHCP6_STATELESS LWIP_IPV6_DHCP6 +#define LWIP_DHCP6_GET_NTP_SRV 0 +#define LWIP_DHCP6_MAX_NTP_SERVERS 1 +#define LWIP_DHCP6_MAX_DNS_SERVERS DNS_MAX_SERVERS + +/* TODO: check hooks */ + +#define LWIP_DBG_MIN_LEVEL LWIP_DBG_LEVEL_ALL +#define LWIP_DBG_TYPES_ON LWIP_DBG_ON +#define ETHARP_DEBUG LWIP_DBG_OFF +#define NETIF_DEBUG LWIP_DBG_OFF +#define PBUF_DEBUG LWIP_DBG_OFF +#define API_LIB_DEBUG LWIP_DBG_OFF +#define API_MSG_DEBUG LWIP_DBG_OFF +#define SOCKETS_DEBUG LWIP_DBG_OFF +#define ICMP_DEBUG LWIP_DBG_OFF +#define IGMP_DEBUG LWIP_DBG_OFF +#define INET_DEBUG LWIP_DBG_OFF +#define IP_DEBUG LWIP_DBG_OFF +#define IP_REASS_DEBUG LWIP_DBG_OFF +#define RAW_DEBUG LWIP_DBG_OFF +#define MEM_DEBUG LWIP_DBG_OFF +#define MEMP_DEBUG LWIP_DBG_OFF +#define SYS_DEBUG LWIP_DBG_OFF +#define TIMERS_DEBUG LWIP_DBG_OFF +#define TCP_DEBUG LWIP_DBG_OFF +#define TCP_INPUT_DEBUG LWIP_DBG_OFF +#define TCP_FR_DEBUG LWIP_DBG_OFF +#define TCP_RTO_DEBUG LWIP_DBG_OFF +#define TCP_CWND_DEBUG LWIP_DBG_OFF +#define TCP_WND_DEBUG LWIP_DBG_OFF +#define TCP_OUTPUT_DEBUG LWIP_DBG_OFF +#define TCP_RST_DEBUG LWIP_DBG_OFF +#define TCP_QLEN_DEBUG LWIP_DBG_OFF +#define UDP_DEBUG LWIP_DBG_OFF +#define TCPIP_DEBUG LWIP_DBG_OFF +#define SLIP_DEBUG LWIP_DBG_OFF +#define DHCP_DEBUG LWIP_DBG_OFF +#define AUTOIP_DEBUG LWIP_DBG_OFF +#define DNS_DEBUG LWIP_DBG_OFF +#define IP6_DEBUG LWIP_DBG_OFF +#define DHCP6_DEBUG LWIP_DBG_OFF +#define LWIP_TESTMODE 0 + +#define LWIP_PERF 0 diff --git a/contrib/examples/example_app/test_configs/opt_nosys_ipv6.h b/contrib/examples/example_app/test_configs/opt_nosys_ipv6.h new file mode 100644 index 00000000000..d0273521a52 --- /dev/null +++ b/contrib/examples/example_app/test_configs/opt_nosys_ipv6.h @@ -0,0 +1,295 @@ +/* test an lwipopts.h file with default contents */ +#define NO_SYS 0 +#define NO_SYS_NO_TIMERS 0 +#define LWIP_TIMERS 1 +#define LWIP_TIMERS_CUSTOM 0 +#define LWIP_MPU_COMPATIBLE 0 +#define LWIP_TCPIP_CORE_LOCKING 1 +#define LWIP_TCPIP_CORE_LOCKING_INPUT 0 +#define SYS_LIGHTWEIGHT_PROT 1 +#define MEM_LIBC_MALLOC 0 +#define MEMP_MEM_MALLOC 0 +#define MEMP_MEM_INIT 0 +#define MEM_ALIGNMENT 1 +#define MEM_SIZE 1600 +#define MEMP_OVERFLOW_CHECK 0 +#define MEMP_SANITY_CHECK 0 +#define MEM_OVERFLOW_CHECK 0 +#define MEM_SANITY_CHECK 0 +#define MEM_USE_POOLS 0 +#define MEM_USE_POOLS_TRY_BIGGER_POOL 0 +#define MEMP_USE_CUSTOM_POOLS 0 +#define LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT 0 +/*#define MEMP_NUM_PBUF 16 +#define MEMP_NUM_RAW_PCB 4 +#define MEMP_NUM_UDP_PCB 4 +#define MEMP_NUM_TCP_PCB 5 +#define MEMP_NUM_TCP_PCB_LISTEN 8 +#define MEMP_NUM_TCP_SEG 16 +#define MEMP_NUM_ALTCP_PCB MEMP_NUM_TCP_PCB +#define MEMP_NUM_REASSDATA 5 +#define MEMP_NUM_FRAG_PBUF 15 +#define MEMP_NUM_ARP_QUEUE 30 +#define MEMP_NUM_IGMP_GROUP 8 +#define MEMP_NUM_SYS_TIMEOUT (LWIP_NUM_SYS_TIMEOUT_INTERNAL + 2) +#define MEMP_NUM_NETBUF 2 +#define MEMP_NUM_NETCONN 4 +#define MEMP_NUM_SELECT_CB 4 +#define MEMP_NUM_TCPIP_MSG_API 8 +#define MEMP_NUM_TCPIP_MSG_INPKT 8 +#define MEMP_NUM_NETDB 1 +#define MEMP_NUM_LOCALHOSTLIST 1 +#define PBUF_POOL_SIZE 16 +#define MEMP_NUM_API_MSG MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_DNS_API_MSG MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_SOCKET_SETGETSOCKOPT_DATA MEMP_NUM_TCPIP_MSG_API +#define MEMP_NUM_NETIFAPI_MSG MEMP_NUM_TCPIP_MSG_API*/ +#define LWIP_ARP 1 +#define ARP_TABLE_SIZE 10 +#define ARP_MAXAGE 300 +#define ARP_QUEUEING 0 +#define ARP_QUEUE_LEN 3 +#define ETHARP_SUPPORT_VLAN 0 +#define LWIP_ETHERNET LWIP_ARP +#define ETH_PAD_SIZE 0 +#define ETHARP_SUPPORT_STATIC_ENTRIES 0 +#define ETHARP_TABLE_MATCH_NETIF !LWIP_SINGLE_NETIF +#define LWIP_IPV4 0 +#define IP_FORWARD 0 +#define IP_REASSEMBLY 1 +#define IP_FRAG 1 +#define IP_OPTIONS_ALLOWED 1 +#define IP_REASS_MAXAGE 15 +#define IP_REASS_MAX_PBUFS 10 +#define IP_DEFAULT_TTL 255 +#define IP_SOF_BROADCAST 0 +#define IP_SOF_BROADCAST_RECV 0 +#define IP_FORWARD_ALLOW_TX_ON_RX_NETIF 0 +#define LWIP_ICMP 1 +#define ICMP_TTL (IP_DEFAULT_TTL) +#define LWIP_BROADCAST_PING 0 +#define LWIP_MULTICAST_PING 0 +#define LWIP_RAW 0 +#define RAW_TTL (IP_DEFAULT_TTL) +#define LWIP_DHCP 0 +#define LWIP_DHCP_CHECK_LINK_UP 0 +#define LWIP_DHCP_BOOTP_FILE 0 +#define LWIP_DHCP_GET_NTP_SRV 0 +#define LWIP_DHCP_MAX_NTP_SERVERS 1 +#define LWIP_DHCP_MAX_DNS_SERVERS DNS_MAX_SERVERS +#define LWIP_AUTOIP 0 +#define LWIP_DHCP_AUTOIP_COOP 0 +#define LWIP_DHCP_AUTOIP_COOP_TRIES 9 +#define LWIP_MIB2_CALLBACKS 0 +#define LWIP_MULTICAST_TX_OPTIONS ((LWIP_IGMP || LWIP_IPV6_MLD) && (LWIP_UDP || LWIP_RAW)) +#define LWIP_IGMP 0 +#define LWIP_DNS 0 +#define DNS_TABLE_SIZE 4 +#define DNS_MAX_NAME_LENGTH 256 +#define DNS_MAX_SERVERS 2 +#define DNS_MAX_RETRIES 4 +#define DNS_DOES_NAME_CHECK 1 +#define LWIP_DNS_SECURE (LWIP_DNS_SECURE_RAND_XID | LWIP_DNS_SECURE_NO_MULTIPLE_OUTSTANDING | LWIP_DNS_SECURE_RAND_SRC_PORT) +#define DNS_LOCAL_HOSTLIST 0 +#define DNS_LOCAL_HOSTLIST_IS_DYNAMIC 0 +#define LWIP_DNS_SUPPORT_MDNS_QUERIES 0 +#define LWIP_UDP 1 +#define LWIP_UDPLITE 0 +#define UDP_TTL (IP_DEFAULT_TTL) +#define LWIP_NETBUF_RECVINFO 0 +#define LWIP_TCP 1 +#define TCP_TTL (IP_DEFAULT_TTL) +#define TCP_WND (4 * TCP_MSS) +#define TCP_MAXRTX 12 +#define TCP_SYNMAXRTX 6 +#define TCP_QUEUE_OOSEQ (LWIP_TCP) +#define LWIP_TCP_SACK_OUT 0 +#define LWIP_TCP_MAX_SACK_NUM 4 +#define TCP_MSS 536 +#define TCP_CALCULATE_EFF_SEND_MSS 1 +#define TCP_SND_BUF (2 * TCP_MSS) +#define TCP_SND_QUEUELEN ((4 * (TCP_SND_BUF) + (TCP_MSS - 1))/(TCP_MSS)) +#define TCP_SNDLOWAT LWIP_MIN(LWIP_MAX(((TCP_SND_BUF)/2), (2 * TCP_MSS) + 1), (TCP_SND_BUF) - 1) +#define TCP_SNDQUEUELOWAT LWIP_MAX(((TCP_SND_QUEUELEN)/2), 5) +#define TCP_OOSEQ_MAX_BYTES 0 +#define TCP_OOSEQ_BYTES_LIMIT(pcb) TCP_OOSEQ_MAX_BYTES +#define TCP_OOSEQ_MAX_PBUFS 0 +#define TCP_OOSEQ_PBUFS_LIMIT(pcb) TCP_OOSEQ_MAX_PBUFS +#define TCP_LISTEN_BACKLOG 0 +#define TCP_DEFAULT_LISTEN_BACKLOG 0xff +#define TCP_OVERSIZE TCP_MSS +#define LWIP_TCP_TIMESTAMPS 0 +#define TCP_WND_UPDATE_THRESHOLD LWIP_MIN((TCP_WND / 4), (TCP_MSS * 4)) +#define LWIP_EVENT_API 0 +#define LWIP_CALLBACK_API 1 +#define LWIP_WND_SCALE 0 +#define TCP_RCV_SCALE 0 +#define LWIP_TCP_PCB_NUM_EXT_ARGS 0 +#define LWIP_ALTCP 0 +#define LWIP_ALTCP_TLS 0 +#define PBUF_LINK_HLEN (14 + ETH_PAD_SIZE) +#define PBUF_LINK_ENCAPSULATION_HLEN 0 +#define PBUF_POOL_BUFSIZE LWIP_MEM_ALIGN_SIZE(TCP_MSS+40+PBUF_LINK_ENCAPSULATION_HLEN+PBUF_LINK_HLEN) +#define LWIP_PBUF_REF_T u8_t +#define LWIP_SINGLE_NETIF 0 +#define LWIP_NETIF_HOSTNAME 0 +#define LWIP_NETIF_API 0 +#define LWIP_NETIF_STATUS_CALLBACK 0 +#define LWIP_NETIF_EXT_STATUS_CALLBACK 0 +#define LWIP_NETIF_LINK_CALLBACK 0 +#define LWIP_NETIF_REMOVE_CALLBACK 0 +#define LWIP_NETIF_HWADDRHINT 0 +#define LWIP_NETIF_TX_SINGLE_PBUF 0 +#define LWIP_NUM_NETIF_CLIENT_DATA 0 +#define LWIP_HAVE_LOOPIF (LWIP_NETIF_LOOPBACK && !LWIP_SINGLE_NETIF) +#define LWIP_LOOPIF_MULTICAST 0 +#define LWIP_NETIF_LOOPBACK 0 +#define LWIP_LOOPBACK_MAX_PBUFS 0 +#define LWIP_NETIF_LOOPBACK_MULTITHREADING (!NO_SYS) +/*#define TCPIP_THREAD_NAME "tcpip_thread" +#define TCPIP_THREAD_STACKSIZE 0 +#define TCPIP_THREAD_PRIO 1 +#define TCPIP_MBOX_SIZE 0 +#define LWIP_TCPIP_THREAD_ALIVE() +#define SLIPIF_THREAD_NAME "slipif_loop" +#define SLIPIF_THREAD_STACKSIZE 0 +#define SLIPIF_THREAD_PRIO 1 +#define DEFAULT_THREAD_NAME "lwIP" +#define DEFAULT_THREAD_STACKSIZE 0 +#define DEFAULT_THREAD_PRIO 1 +#define DEFAULT_RAW_RECVMBOX_SIZE 0 +#define DEFAULT_UDP_RECVMBOX_SIZE 0 +#define DEFAULT_TCP_RECVMBOX_SIZE 0 +#define DEFAULT_ACCEPTMBOX_SIZE 0*/ +#define LWIP_NETCONN 0 +#define LWIP_TCPIP_TIMEOUT 0 +#define LWIP_NETCONN_SEM_PER_THREAD 0 +#define LWIP_NETCONN_FULLDUPLEX 0 +#define LWIP_SOCKET 0 +#define LWIP_COMPAT_SOCKETS 1 /* 0..2 */ +#define LWIP_POSIX_SOCKETS_IO_NAMES 1 +#define LWIP_SOCKET_OFFSET 0 +#define LWIP_TCP_KEEPALIVE 0 +#define LWIP_SO_SNDTIMEO 0 +#define LWIP_SO_RCVTIMEO 0 +#define LWIP_SO_SNDRCVTIMEO_NONSTANDARD 0 +#define LWIP_SO_RCVBUF 0 +#define LWIP_SO_LINGER 0 +#define RECV_BUFSIZE_DEFAULT INT_MAX +#define LWIP_TCP_CLOSE_TIMEOUT_MS_DEFAULT 20000 +#define SO_REUSE 0 +#define SO_REUSE_RXTOALL 0 +#define LWIP_FIONREAD_LINUXMODE 0 +#define LWIP_SOCKET_SELECT 1 +#define LWIP_SOCKET_POLL 1 +#define LWIP_STATS 1 +#define LWIP_STATS_DISPLAY 0 +#define LINK_STATS 1 +#define ETHARP_STATS (LWIP_ARP) +#define IP_STATS 1 +#define IPFRAG_STATS (IP_REASSEMBLY || IP_FRAG) +#define ICMP_STATS 1 +#define IGMP_STATS (LWIP_IGMP) +#define UDP_STATS (LWIP_UDP) +#define TCP_STATS (LWIP_TCP) +#define MEM_STATS ((MEM_LIBC_MALLOC == 0) && (MEM_USE_POOLS == 0)) +#define MEMP_STATS (MEMP_MEM_MALLOC == 0) +#define SYS_STATS (NO_SYS == 0) +#define IP6_STATS (LWIP_IPV6) +#define ICMP6_STATS (LWIP_IPV6 && LWIP_ICMP6) +#define IP6_FRAG_STATS (LWIP_IPV6 && (LWIP_IPV6_FRAG || LWIP_IPV6_REASS)) +#define MLD6_STATS (LWIP_IPV6 && LWIP_IPV6_MLD) +#define ND6_STATS (LWIP_IPV6) +#define MIB2_STATS 0 +#define LWIP_CHECKSUM_CTRL_PER_NETIF 0 +#define CHECKSUM_GEN_IP 1 +#define CHECKSUM_GEN_UDP 1 +#define CHECKSUM_GEN_TCP 1 +#define CHECKSUM_GEN_ICMP 1 +#define CHECKSUM_GEN_ICMP6 1 +#define CHECKSUM_CHECK_IP 1 +#define CHECKSUM_CHECK_UDP 1 +#define CHECKSUM_CHECK_TCP 1 +#define CHECKSUM_CHECK_ICMP 1 +#define CHECKSUM_CHECK_ICMP6 1 +#define LWIP_CHECKSUM_ON_COPY 0 +#define LWIP_IPV6 1 +#define IPV6_REASS_MAXAGE 60 +#define LWIP_IPV6_SCOPES (LWIP_IPV6 && !LWIP_SINGLE_NETIF) +#define LWIP_IPV6_SCOPES_DEBUG 0 +#define LWIP_IPV6_NUM_ADDRESSES 3 +#define LWIP_IPV6_FORWARD 0 +#define LWIP_IPV6_FRAG 1 +#define LWIP_IPV6_REASS (LWIP_IPV6) +#define LWIP_IPV6_SEND_ROUTER_SOLICIT 1 +#define LWIP_IPV6_AUTOCONFIG (LWIP_IPV6) +#define LWIP_IPV6_ADDRESS_LIFETIMES (LWIP_IPV6_AUTOCONFIG) +#define LWIP_IPV6_DUP_DETECT_ATTEMPTS 1 +#define LWIP_ICMP6 (LWIP_IPV6) +#define LWIP_ICMP6_DATASIZE 8 +#define LWIP_ICMP6_HL 255 +#define LWIP_IPV6_MLD (LWIP_IPV6) +#define MEMP_NUM_MLD6_GROUP 4 +#define LWIP_ND6_QUEUEING (LWIP_IPV6) +#define MEMP_NUM_ND6_QUEUE 20 +#define LWIP_ND6_NUM_NEIGHBORS 10 +#define LWIP_ND6_NUM_DESTINATIONS 10 +#define LWIP_ND6_NUM_PREFIXES 5 +#define LWIP_ND6_NUM_ROUTERS 3 +#define LWIP_ND6_MAX_MULTICAST_SOLICIT 3 +#define LWIP_ND6_MAX_UNICAST_SOLICIT 3 +#define LWIP_ND6_MAX_ANYCAST_DELAY_TIME 1000 +#define LWIP_ND6_MAX_NEIGHBOR_ADVERTISEMENT 3 +#define LWIP_ND6_REACHABLE_TIME 30000 +#define LWIP_ND6_RETRANS_TIMER 1000 +#define LWIP_ND6_DELAY_FIRST_PROBE_TIME 5000 +#define LWIP_ND6_ALLOW_RA_UPDATES 1 +#define LWIP_ND6_TCP_REACHABILITY_HINTS 1 +#define LWIP_ND6_RDNSS_MAX_DNS_SERVERS 0 +#define LWIP_IPV6_DHCP6 0 +#define LWIP_IPV6_DHCP6_STATEFUL 0 +#define LWIP_IPV6_DHCP6_STATELESS LWIP_IPV6_DHCP6 +#define LWIP_DHCP6_GET_NTP_SRV 0 +#define LWIP_DHCP6_MAX_NTP_SERVERS 1 +#define LWIP_DHCP6_MAX_DNS_SERVERS DNS_MAX_SERVERS + +/* TODO: check hooks */ + +#define LWIP_DBG_MIN_LEVEL LWIP_DBG_LEVEL_ALL +#define LWIP_DBG_TYPES_ON LWIP_DBG_ON +#define ETHARP_DEBUG LWIP_DBG_OFF +#define NETIF_DEBUG LWIP_DBG_OFF +#define PBUF_DEBUG LWIP_DBG_OFF +#define API_LIB_DEBUG LWIP_DBG_OFF +#define API_MSG_DEBUG LWIP_DBG_OFF +#define SOCKETS_DEBUG LWIP_DBG_OFF +#define ICMP_DEBUG LWIP_DBG_OFF +#define IGMP_DEBUG LWIP_DBG_OFF +#define INET_DEBUG LWIP_DBG_OFF +#define IP_DEBUG LWIP_DBG_OFF +#define IP_REASS_DEBUG LWIP_DBG_OFF +#define RAW_DEBUG LWIP_DBG_OFF +#define MEM_DEBUG LWIP_DBG_OFF +#define MEMP_DEBUG LWIP_DBG_OFF +#define SYS_DEBUG LWIP_DBG_OFF +#define TIMERS_DEBUG LWIP_DBG_OFF +#define TCP_DEBUG LWIP_DBG_OFF +#define TCP_INPUT_DEBUG LWIP_DBG_OFF +#define TCP_FR_DEBUG LWIP_DBG_OFF +#define TCP_RTO_DEBUG LWIP_DBG_OFF +#define TCP_CWND_DEBUG LWIP_DBG_OFF +#define TCP_WND_DEBUG LWIP_DBG_OFF +#define TCP_OUTPUT_DEBUG LWIP_DBG_OFF +#define TCP_RST_DEBUG LWIP_DBG_OFF +#define TCP_QLEN_DEBUG LWIP_DBG_OFF +#define UDP_DEBUG LWIP_DBG_OFF +#define TCPIP_DEBUG LWIP_DBG_OFF +#define SLIP_DEBUG LWIP_DBG_OFF +#define DHCP_DEBUG LWIP_DBG_OFF +#define AUTOIP_DEBUG LWIP_DBG_OFF +#define DNS_DEBUG LWIP_DBG_OFF +#define IP6_DEBUG LWIP_DBG_OFF +#define DHCP6_DEBUG LWIP_DBG_OFF +#define LWIP_TESTMODE 0 + +#define LWIP_PERF 0 diff --git a/contrib/examples/httpd/cgi_example/cgi_example.c b/contrib/examples/httpd/cgi_example/cgi_example.c new file mode 100644 index 00000000000..c9c74763bb6 --- /dev/null +++ b/contrib/examples/httpd/cgi_example/cgi_example.c @@ -0,0 +1,107 @@ +/** + * @file + * HTTPD simple CGI example + * + * This file demonstrates how to add support for basic CGI. + */ + + /* + * Copyright (c) 2017 Simon Goldschmidt + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Simon Goldschmidt goldsimon@gmx.de + * + */ + +#include "lwip/opt.h" +#include "cgi_example.h" + +#include "lwip/apps/httpd.h" + +#include "lwip/def.h" +#include "lwip/mem.h" + +#include <stdio.h> +#include <string.h> + +/** define LWIP_HTTPD_EXAMPLE_CGI_SIMPLE to 1 to enable this cgi example */ +#ifndef LWIP_HTTPD_EXAMPLE_CGI_SIMPLE +#define LWIP_HTTPD_EXAMPLE_CGI_SIMPLE 0 +#endif + +#if LWIP_HTTPD_EXAMPLE_CGI_SIMPLE + +#if !LWIP_HTTPD_CGI +#error LWIP_HTTPD_EXAMPLE_CGI_SIMPLE needs LWIP_HTTPD_CGI +#endif + +static const char *cgi_handler_basic(int iIndex, int iNumParams, char *pcParam[], char *pcValue[]); + +static const tCGI cgi_handlers[] = { + { + "/basic_cgi", + cgi_handler_basic + }, + { + "/basic_cgi_2", + cgi_handler_basic + } +}; + +void +cgi_ex_init(void) +{ + http_set_cgi_handlers(cgi_handlers, LWIP_ARRAYSIZE(cgi_handlers)); +} + +/** This basic CGI function can parse param/value pairs and return an url that + * is sent as a response by httpd. + * + * This example function just checks that the input url has two key value + * parameter pairs: "foo=bar" and "test=123" + * If not, it returns 404 + */ +static const char * +cgi_handler_basic(int iIndex, int iNumParams, char *pcParam[], char *pcValue[]) +{ + LWIP_ASSERT("check index", iIndex < LWIP_ARRAYSIZE(cgi_handlers)); + + if (iNumParams == 2) { + if (!strcmp(pcParam[0], "foo")) { + if (!strcmp(pcValue[0], "bar")) { + if (!strcmp(pcParam[1], "test")) { + if (!strcmp(pcValue[1], "123")) { + return "/index.html"; + } + } + } + } + } + return "/404.html"; +} + +#endif /* LWIP_HTTPD_EXAMPLE_CGI_SIMPLE */ diff --git a/contrib/examples/httpd/cgi_example/cgi_example.h b/contrib/examples/httpd/cgi_example/cgi_example.h new file mode 100644 index 00000000000..b655661b364 --- /dev/null +++ b/contrib/examples/httpd/cgi_example/cgi_example.h @@ -0,0 +1,38 @@ +/* + * Copyright (c) 2017 Simon Goldschmidt + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Simon Goldschmidt goldsimon@gmx.de + * + */ + +#ifndef LWIP_HDR_HTTP_EXAMPLES_CGI_EXAMPLE +#define LWIP_HDR_HTTP_EXAMPLES_CGI_EXAMPLE + +void cgi_ex_init(void); + +#endif /* LWIP_HDR_HTTP_EXAMPLES_CGI_EXAMPLE */ diff --git a/contrib/examples/httpd/examples_fs/404.html b/contrib/examples/httpd/examples_fs/404.html new file mode 100644 index 00000000000..40b343a91e2 --- /dev/null +++ b/contrib/examples/httpd/examples_fs/404.html @@ -0,0 +1,21 @@ +<html> +<head><title>lwIP - A Lightweight TCP/IP Stack</title></head> +<body bgcolor="white" text="black"> + + <table width="100%"> + <tr valign="top"><td width="80"> + <a href="http://www.sics.se/"><img src="/img/sics.gif" + border="0" alt="SICS logo" title="SICS logo"></a> + </td><td width="500"> + <h1>lwIP - A Lightweight TCP/IP Stack</h1> + <h2>404 - Page not found</h2> + <p> + Sorry, the page you are requesting was not found on this + server. + </p> + </td><td> + + </td></tr> + </table> +</body> +</html> diff --git a/contrib/examples/httpd/examples_fs/img/sics.gif b/contrib/examples/httpd/examples_fs/img/sics.gif new file mode 100644 index 0000000000000000000000000000000000000000..0a4fc7bb07050eec9226ca93bc9ad237f35502c8 GIT binary patch literal 724 zcmZ?wbhEHbbYoCrSjxa~Q`<5tD{KG${gWq8=I7_%uwlcpWy=~G8p_Jb<mBY$&Yi2L zr|0SE84?oG)zy`dkZ^3-%)MJT9a_EcrlZ5v^w0wvR$YzryB6SjW^(O`g%i$omtCq( zz1Wg_a%P*Al@$X6!;T$0{?iiZ0PSD^`GtY)pTmR#4;`ug6HAIt=2*?Yu%g6kZPfZ3 zYsywSu<UDolwcE}z}uJ4V5lL(%f9t+LaB<~k3a2#Y%guy*tx5!YMj~RS}M5N^8y*W zS~%(|8`?W3R!!z&nOQN-pLt#-<COW%a~3aQEnmFAZ$>4zT=SA;^3z!7uBu>UZ()&> z+r1;Oh0mFly?klC)5cAV$sD}98F{LBUHERS_hGGKac5`W-mvIltqUt73*&`X?UVf< z%<?>Uqmm^}K~z9MaFS-jwgVGIUF9Z77P_s7Vc}y?@_XT+GT)AcZF$6%$qQsA+Q0bF z!Mss%ktc&>+n*qp2aIzy6-8A8zNf3ovHkU%wPnH@(O;*7g5`QX{a~M@%VFg!<T=&z zwg}4+kyg!B&lx$EcruCvJ_w$8Rg+CBh3U)j#(As?N-0YX)~%j5J^04XzX9(jGdY!* zyqKe)c#<)r;#sJsLYTjgLttUkfdWOP)_vYGF08MXFz#2{`ay;*(4zl=(i@32mP%Ky zO?F{4YC7>JaWkVUk6yFE1wL^V{({yi?^s!by^W;pXIz%mY}~L;uBR^JK|)kW|Avap zVzxyL+2N;b1q1f77<gM<SsgDw+g7+ly~9TJf%v|vN>^T<4c)gUoN8c;6;F^+^0^VN o#HPS7gPr3^SVM!%(d|c@c+6frXclnOc-SHmma$O4k%7S)08~d;ZvX%Q
literal 0 HcmV?d00001
diff --git a/contrib/examples/httpd/examples_fs/index.html b/contrib/examples/httpd/examples_fs/index.html new file mode 100644 index 00000000000..ab575ef0891 --- /dev/null +++ b/contrib/examples/httpd/examples_fs/index.html @@ -0,0 +1,47 @@ +<html> +<head><title>lwIP - A Lightweight TCP/IP Stack</title></head> +<body bgcolor="white" text="black"> + + <table width="100%"> + <tr valign="top"><td width="80"> + <a href="http://www.sics.se/"><img src="/img/sics.gif" + border="0" alt="SICS logo" title="SICS logo"></a> + </td><td width="500"> + <h1>lwIP - A Lightweight TCP/IP Stack</h1> + <p> + The web page you are watching was served by a simple web + server running on top of the lightweight TCP/IP stack <a + href="http://www.sics.se/~adam/lwip/%22%3ElwIP</a>. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + The focus of the lwIP TCP/IP implementation is to reduce + the RAM usage while still having a full scale TCP. This + makes lwIP suitable for use in embedded systems with tens + of kilobytes of free RAM and room for around 40 kilobytes + of code ROM. + </p> + <p> + More information about lwIP can be found at the lwIP + homepage at <a + href="http://savannah.nongnu.org/projects/lwip/%22%3Ehttp://savannah.nongnu.org/pr...</a> + or at the lwIP wiki at <a + href="http://lwip.wikia.com/%22%3Ehttp://lwip.wikia.com/</a>. + </p> + </td><td> + + </td></tr> + </table> +</body> +</html> + diff --git a/contrib/examples/httpd/examples_fs/login.html b/contrib/examples/httpd/examples_fs/login.html new file mode 100644 index 00000000000..71c535b4a3f --- /dev/null +++ b/contrib/examples/httpd/examples_fs/login.html @@ -0,0 +1,28 @@ +<html> +<head><title>lwIP - A Lightweight TCP/IP Stack</title></head> +<body bgcolor="white" text="black"> + +<table width="100%"> + <tr valign="top"> + <td width="80"> + <a href="http://www.sics.se/"><img src="/img/sics.gif" border="0" alt="SICS logo" title="SICS logo"/></a> + </td> + <td width="500"> + <h1>Login</h1> + <form name="login" action="login.cgi" method="post"> + <div> + <label><b>Username</b></label> + <input type="text" placeholder="Enter Username" name="user" required> + <label><b>Password</b></label> + <input type="password" placeholder="Enter Password" name="pass" required> + <button type="submit">Login</button> + </div> + </form> + </td> + <td> + + </td> + </tr> +</table> +</body> +</html> diff --git a/contrib/examples/httpd/examples_fs/loginfail.html b/contrib/examples/httpd/examples_fs/loginfail.html new file mode 100644 index 00000000000..6d5c742b2c2 --- /dev/null +++ b/contrib/examples/httpd/examples_fs/loginfail.html @@ -0,0 +1,25 @@ +<html> +<head><title>lwIP - A Lightweight TCP/IP Stack</title></head> +<body bgcolor="white" text="black"> + + <table width="100%"> + <tr valign="top"> + <td width="80"> + <a href="http://www.sics.se/"><img src="/img/sics.gif" border="0" alt="SICS logo" title="SICS logo"/></a> + </td> + <td width="500"> + <h1>lwIP - A Lightweight TCP/IP Stack</h1> + <p> + Login failed. + </p> + <p> + Click <a href="login.html">here</a> to retry login. + </p> + </td> + <td> + + </td> + </tr> + </table> +</body> +</html> diff --git a/contrib/examples/httpd/examples_fs/session.html b/contrib/examples/httpd/examples_fs/session.html new file mode 100644 index 00000000000..72d3bff9981 --- /dev/null +++ b/contrib/examples/httpd/examples_fs/session.html @@ -0,0 +1,25 @@ +<html> +<head><title>lwIP - A Lightweight TCP/IP Stack</title></head> +<body bgcolor="white" text="black"> + + <table width="100%"> + <tr valign="top"> + <td width="80"> + <a href="http://www.sics.se/"><img src="/img/sics.gif" border="0" alt="SICS logo" title="SICS logo"/></a> + </td> + <td width="500"> + <h1>lwIP - A Lightweight TCP/IP Stack</h1> + <p> + Login succeeded, session active. + </p> + <p> + Click <a href="login.html">here</a> to retry login. + </p> + </td> + <td> + + </td> + </tr> + </table> +</body> +</html> diff --git a/contrib/examples/httpd/examples_fs/ssi.shtml b/contrib/examples/httpd/examples_fs/ssi.shtml new file mode 100644 index 00000000000..153d0167f5a --- /dev/null +++ b/contrib/examples/httpd/examples_fs/ssi.shtml @@ -0,0 +1,315 @@ +<html> +<head><title>lwIP - A Lightweight TCP/IP Stack</title></head> +<body bgcolor="white" text="black"> + + <table width="100%"> + <tr valign="top"><td width="80"> + <a href="http://www.sics.se/"><img src="/img/sics.gif" + border="0" alt="SICS logo" title="SICS logo"></a> + </td><td width="500"> + <h1>lwIP - A Lightweight TCP/IP Stack</h1> + <h1><!--#HellWorl--></h1> + <p> + The web page you are watching was served by a simple web + server running on top of the lightweight TCP/IP stack <a + href="http://www.sics.se/~adam/lwip/%22%3ElwIP</a>. + </p> + <p> + This page is here to test SSI, so here is a counter as + an example of content changing for every request: + "<!--#counter-->" + </p> + <p> + And here is an example of a tag result buffer return in + multiple parts: "<!--#MultPart-->" + </p> + <p> + To test LWIP_HTTPD_CGI_SSI, here are the CGI parameters: + <!--#CgiParam--> + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + lwIP is an open source implementation of the TCP/IP + protocol suite that was originally written by <a + href="http://www.sics.se/~adam/lwip/%22%3EAdam Dunkels + of the Swedish Institute of Computer Science</a> but now is + being actively developed by a team of developers + distributed world-wide. Since it's release, lwIP has + spurred a lot of interest and has been ported to several + platforms and operating systems. lwIP can be used either + with or without an underlying OS. + </p> + <p> + The focus of the lwIP TCP/IP implementation is to reduce + the RAM usage while still having a full scale TCP. This + makes lwIP suitable for use in embedded systems with tens + of kilobytes of free RAM and room for around 40 kilobytes + of code ROM. + </p> + <p> + More information about lwIP can be found at the lwIP + homepage at <a + href="http://savannah.nongnu.org/projects/lwip/%22%3Ehttp://savannah.nongnu.org/pr...</a> + or at the lwIP wiki at <a + href="http://lwip.wikia.com/%22%3Ehttp://lwip.wikia.com/</a>. + </p> + </td><td> + + </td></tr> + </table> +</body> +</html> + diff --git a/contrib/examples/httpd/examples_fsdata.c b/contrib/examples/httpd/examples_fsdata.c new file mode 100644 index 00000000000..7eed926a85e --- /dev/null +++ b/contrib/examples/httpd/examples_fsdata.c @@ -0,0 +1,1543 @@ +#include "lwip/apps/fs.h" +#include "lwip/def.h" + + +#define file_NULL (struct fsdata_file *) NULL + + +#ifndef FS_FILE_FLAGS_HEADER_INCLUDED +#define FS_FILE_FLAGS_HEADER_INCLUDED 1 +#endif +#ifndef FS_FILE_FLAGS_HEADER_PERSISTENT +#define FS_FILE_FLAGS_HEADER_PERSISTENT 0 +#endif +/* FSDATA_FILE_ALIGNMENT: 0=off, 1=by variable, 2=by include */ +#ifndef FSDATA_FILE_ALIGNMENT +#define FSDATA_FILE_ALIGNMENT 0 +#endif +#ifndef FSDATA_ALIGN_PRE +#define FSDATA_ALIGN_PRE +#endif +#ifndef FSDATA_ALIGN_POST +#define FSDATA_ALIGN_POST +#endif +#if FSDATA_FILE_ALIGNMENT==2 +#include "fsdata_alignment.h" +#endif +#if FSDATA_FILE_ALIGNMENT==1 +static const unsigned int dummy_align__img_sics_gif = 0; +#endif +static const unsigned char FSDATA_ALIGN_PRE data__img_sics_gif[] FSDATA_ALIGN_POST = { +/* /img/sics.gif (14 chars) */ +0x2f,0x69,0x6d,0x67,0x2f,0x73,0x69,0x63,0x73,0x2e,0x67,0x69,0x66,0x00,0x00,0x00, + +/* HTTP header */ +/* "HTTP/1.1 200 OK +" (17 bytes) */ +0x48,0x54,0x54,0x50,0x2f,0x31,0x2e,0x31,0x20,0x32,0x30,0x30,0x20,0x4f,0x4b,0x0d, +0x0a, +/* "Server: lwIP/2.0.3d (http://savannah.nongnu.org/projects/lwip) +" (64 bytes) */ +0x53,0x65,0x72,0x76,0x65,0x72,0x3a,0x20,0x6c,0x77,0x49,0x50,0x2f,0x32,0x2e,0x30, +0x2e,0x33,0x64,0x20,0x28,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x73,0x61,0x76,0x61, +0x6e,0x6e,0x61,0x68,0x2e,0x6e,0x6f,0x6e,0x67,0x6e,0x75,0x2e,0x6f,0x72,0x67,0x2f, +0x70,0x72,0x6f,0x6a,0x65,0x63,0x74,0x73,0x2f,0x6c,0x77,0x69,0x70,0x29,0x0d,0x0a, + +/* "Content-Length: 724 +" (18+ bytes) */ +0x43,0x6f,0x6e,0x74,0x65,0x6e,0x74,0x2d,0x4c,0x65,0x6e,0x67,0x74,0x68,0x3a,0x20, +0x37,0x32,0x34,0x0d,0x0a, +/* "Connection: keep-alive +" (24 bytes) */ +0x43,0x6f,0x6e,0x6e,0x65,0x63,0x74,0x69,0x6f,0x6e,0x3a,0x20,0x6b,0x65,0x65,0x70, +0x2d,0x61,0x6c,0x69,0x76,0x65,0x0d,0x0a, +/* "Content-Type: image/gif + +" (27 bytes) */ +0x43,0x6f,0x6e,0x74,0x65,0x6e,0x74,0x2d,0x54,0x79,0x70,0x65,0x3a,0x20,0x69,0x6d, +0x61,0x67,0x65,0x2f,0x67,0x69,0x66,0x0d,0x0a,0x0d,0x0a, +/* raw file data (724 bytes) */ +0x47,0x49,0x46,0x38,0x39,0x61,0x46,0x00,0x22,0x00,0xa5,0x00,0x00,0xd9,0x2b,0x39, +0x6a,0x6a,0x6a,0xbf,0xbf,0xbf,0x93,0x93,0x93,0x0f,0x0f,0x0f,0xb0,0xb0,0xb0,0xa6, +0xa6,0xa6,0x80,0x80,0x80,0x76,0x76,0x76,0x1e,0x1e,0x1e,0x9d,0x9d,0x9d,0x2e,0x2e, +0x2e,0x49,0x49,0x49,0x54,0x54,0x54,0x8a,0x8a,0x8a,0x60,0x60,0x60,0xc6,0xa6,0x99, +0xbd,0xb5,0xb2,0xc2,0xab,0xa1,0xd9,0x41,0x40,0xd5,0x67,0x55,0xc0,0xb0,0xaa,0xd5, +0x5e,0x4e,0xd6,0x50,0x45,0xcc,0x93,0x7d,0xc8,0xa1,0x90,0xce,0x8b,0x76,0xd2,0x7b, +0x65,0xd1,0x84,0x6d,0xc9,0x99,0x86,0x3a,0x3a,0x3a,0x00,0x00,0x00,0xb8,0xb8,0xb8, +0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, +0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, +0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, +0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, +0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, +0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x2c,0x00,0x00, +0x00,0x00,0x46,0x00,0x22,0x00,0x00,0x06,0xfe,0x40,0x90,0x70,0x48,0x2c,0x1a,0x8f, +0xc8,0xa4,0x72,0xc9,0x6c,0x3a,0x9f,0xd0,0xa8,0x74,0x4a,0xad,0x5a,0xaf,0xd8,0xac, +0x76,0xa9,0x40,0x04,0xbe,0x83,0xe2,0x60,0x3c,0x50,0x20,0x0d,0x8e,0x6f,0x00,0x31, +0x28,0x1c,0x0d,0x07,0xb5,0xc3,0x60,0x75,0x24,0x3e,0xf8,0xfc,0x87,0x11,0x06,0xe9, +0x3d,0x46,0x07,0x0b,0x7a,0x7a,0x7c,0x43,0x06,0x1e,0x84,0x78,0x0b,0x07,0x6e,0x51, +0x01,0x8a,0x84,0x08,0x7e,0x79,0x80,0x87,0x89,0x91,0x7a,0x93,0x0a,0x04,0x99,0x78, +0x96,0x4f,0x03,0x9e,0x79,0x01,0x94,0x9f,0x43,0x9c,0xa3,0xa4,0x05,0x77,0xa3,0xa0, +0x4e,0x98,0x79,0x0b,0x1e,0x83,0xa4,0xa6,0x1f,0x96,0x05,0x9d,0xaa,0x78,0x01,0x07, +0x84,0x04,0x1e,0x1e,0xbb,0xb8,0x51,0x84,0x0e,0x43,0x05,0x07,0x77,0xa5,0x7f,0x42, +0xb1,0xb2,0x01,0x63,0x08,0x0d,0xbb,0x01,0x0c,0x7a,0x0d,0x44,0x0e,0xd8,0xaf,0x4c, +0x05,0x7a,0x04,0x47,0x07,0x07,0xb7,0x80,0xa2,0xe1,0x7d,0x44,0x05,0x01,0x04,0x01, +0xd0,0xea,0x87,0x93,0x4f,0xe0,0x9a,0x49,0xce,0xd8,0x79,0x04,0x66,0x20,0x15,0x10, +0x10,0x11,0x92,0x29,0x80,0xb6,0xc0,0x91,0x15,0x45,0x1e,0x90,0x19,0x71,0x46,0xa8, +0x5c,0x04,0x0e,0x00,0x22,0x4e,0xe8,0x40,0x24,0x9f,0x3e,0x04,0x06,0xa7,0x58,0xd4, +0x93,0xa0,0x1c,0x91,0x3f,0xe8,0xf0,0x88,0x03,0xb1,0x21,0xa2,0x49,0x00,0x19,0x86, +0xfc,0x52,0x44,0xe0,0x01,0x9d,0x29,0x21,0x15,0x25,0x50,0xf7,0x67,0x25,0x1e,0x06, +0xfd,0x4e,0x9a,0xb4,0x90,0xac,0x15,0xfa,0xcb,0x52,0x53,0x1e,0x8c,0xf2,0xf8,0x07, +0x92,0x2d,0x08,0x3a,0x4d,0x12,0x49,0x95,0x49,0xdb,0x14,0x04,0xc4,0x14,0x85,0x29, +0xaa,0xe7,0x01,0x08,0xa4,0x49,0x01,0x14,0x51,0xe0,0x53,0x91,0xd5,0x29,0x06,0x1a, +0x64,0x02,0xf4,0xc7,0x81,0x9e,0x05,0x20,0x22,0x64,0xa5,0x30,0xae,0xab,0x9e,0x97, +0x53,0xd8,0xb9,0xfd,0x50,0xef,0x93,0x02,0x42,0x74,0x34,0xe8,0x9c,0x20,0x21,0xc9, +0x01,0x68,0x78,0xe6,0x55,0x29,0x20,0x56,0x4f,0x4c,0x40,0x51,0x71,0x82,0xc0,0x70, +0x21,0x22,0x85,0xbe,0x4b,0x1c,0x44,0x05,0xea,0xa4,0x01,0xbf,0x22,0xb5,0xf0,0x1c, +0x06,0x51,0x38,0x8f,0xe0,0x22,0xec,0x18,0xac,0x39,0x22,0xd4,0xd6,0x93,0x44,0x01, +0x32,0x82,0xc8,0xfc,0x61,0xb3,0x01,0x45,0x0c,0x2e,0x83,0x30,0xd0,0x0e,0x17,0x24, +0x0f,0x70,0x85,0x94,0xee,0x05,0x05,0x53,0x4b,0x32,0x1b,0x3f,0x98,0xd3,0x1d,0x29, +0x81,0xb0,0xae,0x1e,0x8c,0x7e,0x68,0xe0,0x60,0x5a,0x54,0x8f,0xb0,0x78,0x69,0x73, +0x06,0xa2,0x00,0x6b,0x57,0xca,0x3d,0x11,0x50,0xbd,0x04,0x30,0x4b,0x3a,0xd4,0xab, +0x5f,0x1f,0x9b,0x3d,0x13,0x74,0x27,0x88,0x3c,0x25,0xe0,0x17,0xbe,0x7a,0x79,0x45, +0x0d,0x0c,0xb0,0x8b,0xda,0x90,0xca,0x80,0x06,0x5d,0x17,0x60,0x1c,0x22,0x4c,0xd8, +0x57,0x22,0x06,0x20,0x00,0x98,0x07,0x08,0xe4,0x56,0x80,0x80,0x1c,0xc5,0xb7,0xc5, +0x82,0x0c,0x36,0xe8,0xe0,0x83,0x10,0x46,0x28,0xe1,0x84,0x14,0x56,0x68,0xa1,0x10, +0x41,0x00,0x00,0x3b,}; + +#if FSDATA_FILE_ALIGNMENT==1 +static const unsigned int dummy_align__404_html = 1; +#endif +static const unsigned char FSDATA_ALIGN_PRE data__404_html[] FSDATA_ALIGN_POST = { +/* /404.html (10 chars) */ +0x2f,0x34,0x30,0x34,0x2e,0x68,0x74,0x6d,0x6c,0x00,0x00,0x00, + +/* HTTP header */ +/* "HTTP/1.1 404 File not found +" (29 bytes) */ +0x48,0x54,0x54,0x50,0x2f,0x31,0x2e,0x31,0x20,0x34,0x30,0x34,0x20,0x46,0x69,0x6c, +0x65,0x20,0x6e,0x6f,0x74,0x20,0x66,0x6f,0x75,0x6e,0x64,0x0d,0x0a, +/* "Server: lwIP/2.0.3d (http://savannah.nongnu.org/projects/lwip) +" (64 bytes) */ +0x53,0x65,0x72,0x76,0x65,0x72,0x3a,0x20,0x6c,0x77,0x49,0x50,0x2f,0x32,0x2e,0x30, +0x2e,0x33,0x64,0x20,0x28,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x73,0x61,0x76,0x61, +0x6e,0x6e,0x61,0x68,0x2e,0x6e,0x6f,0x6e,0x67,0x6e,0x75,0x2e,0x6f,0x72,0x67,0x2f, +0x70,0x72,0x6f,0x6a,0x65,0x63,0x74,0x73,0x2f,0x6c,0x77,0x69,0x70,0x29,0x0d,0x0a, + +/* "Content-Length: 565 +" (18+ bytes) */ +0x43,0x6f,0x6e,0x74,0x65,0x6e,0x74,0x2d,0x4c,0x65,0x6e,0x67,0x74,0x68,0x3a,0x20, +0x35,0x36,0x35,0x0d,0x0a, +/* "Connection: keep-alive +" (24 bytes) */ +0x43,0x6f,0x6e,0x6e,0x65,0x63,0x74,0x69,0x6f,0x6e,0x3a,0x20,0x6b,0x65,0x65,0x70, +0x2d,0x61,0x6c,0x69,0x76,0x65,0x0d,0x0a, +/* "Content-Type: text/html + +" (27 bytes) */ +0x43,0x6f,0x6e,0x74,0x65,0x6e,0x74,0x2d,0x54,0x79,0x70,0x65,0x3a,0x20,0x74,0x65, +0x78,0x74,0x2f,0x68,0x74,0x6d,0x6c,0x0d,0x0a,0x0d,0x0a, +/* raw file data (565 bytes) */ +0x3c,0x68,0x74,0x6d,0x6c,0x3e,0x0d,0x0a,0x3c,0x68,0x65,0x61,0x64,0x3e,0x3c,0x74, +0x69,0x74,0x6c,0x65,0x3e,0x6c,0x77,0x49,0x50,0x20,0x2d,0x20,0x41,0x20,0x4c,0x69, +0x67,0x68,0x74,0x77,0x65,0x69,0x67,0x68,0x74,0x20,0x54,0x43,0x50,0x2f,0x49,0x50, +0x20,0x53,0x74,0x61,0x63,0x6b,0x3c,0x2f,0x74,0x69,0x74,0x6c,0x65,0x3e,0x3c,0x2f, +0x68,0x65,0x61,0x64,0x3e,0x0d,0x0a,0x3c,0x62,0x6f,0x64,0x79,0x20,0x62,0x67,0x63, +0x6f,0x6c,0x6f,0x72,0x3d,0x22,0x77,0x68,0x69,0x74,0x65,0x22,0x20,0x74,0x65,0x78, +0x74,0x3d,0x22,0x62,0x6c,0x61,0x63,0x6b,0x22,0x3e,0x0d,0x0a,0x0d,0x0a,0x20,0x20, +0x20,0x20,0x3c,0x74,0x61,0x62,0x6c,0x65,0x20,0x77,0x69,0x64,0x74,0x68,0x3d,0x22, +0x31,0x30,0x30,0x25,0x22,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x20,0x20,0x3c,0x74, +0x72,0x20,0x76,0x61,0x6c,0x69,0x67,0x6e,0x3d,0x22,0x74,0x6f,0x70,0x22,0x3e,0x3c, +0x74,0x64,0x20,0x77,0x69,0x64,0x74,0x68,0x3d,0x22,0x38,0x30,0x22,0x3e,0x09,0x20, +0x20,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x61,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68, +0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73, +0x65,0x2f,0x22,0x3e,0x3c,0x69,0x6d,0x67,0x20,0x73,0x72,0x63,0x3d,0x22,0x2f,0x69, +0x6d,0x67,0x2f,0x73,0x69,0x63,0x73,0x2e,0x67,0x69,0x66,0x22,0x0d,0x0a,0x09,0x20, +0x20,0x62,0x6f,0x72,0x64,0x65,0x72,0x3d,0x22,0x30,0x22,0x20,0x61,0x6c,0x74,0x3d, +0x22,0x53,0x49,0x43,0x53,0x20,0x6c,0x6f,0x67,0x6f,0x22,0x20,0x74,0x69,0x74,0x6c, +0x65,0x3d,0x22,0x53,0x49,0x43,0x53,0x20,0x6c,0x6f,0x67,0x6f,0x22,0x3e,0x3c,0x2f, +0x61,0x3e,0x0d,0x0a,0x09,0x3c,0x2f,0x74,0x64,0x3e,0x3c,0x74,0x64,0x20,0x77,0x69, +0x64,0x74,0x68,0x3d,0x22,0x35,0x30,0x30,0x22,0x3e,0x09,0x20,0x20,0x0d,0x0a,0x09, +0x20,0x20,0x3c,0x68,0x31,0x3e,0x6c,0x77,0x49,0x50,0x20,0x2d,0x20,0x41,0x20,0x4c, +0x69,0x67,0x68,0x74,0x77,0x65,0x69,0x67,0x68,0x74,0x20,0x54,0x43,0x50,0x2f,0x49, +0x50,0x20,0x53,0x74,0x61,0x63,0x6b,0x3c,0x2f,0x68,0x31,0x3e,0x0d,0x0a,0x09,0x20, +0x20,0x3c,0x68,0x32,0x3e,0x34,0x30,0x34,0x20,0x2d,0x20,0x50,0x61,0x67,0x65,0x20, +0x6e,0x6f,0x74,0x20,0x66,0x6f,0x75,0x6e,0x64,0x3c,0x2f,0x68,0x32,0x3e,0x0d,0x0a, +0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x53,0x6f,0x72, +0x72,0x79,0x2c,0x20,0x74,0x68,0x65,0x20,0x70,0x61,0x67,0x65,0x20,0x79,0x6f,0x75, +0x20,0x61,0x72,0x65,0x20,0x72,0x65,0x71,0x75,0x65,0x73,0x74,0x69,0x6e,0x67,0x20, +0x77,0x61,0x73,0x20,0x6e,0x6f,0x74,0x20,0x66,0x6f,0x75,0x6e,0x64,0x20,0x6f,0x6e, +0x20,0x74,0x68,0x69,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x65,0x72,0x76, +0x65,0x72,0x2e,0x20,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09, +0x3c,0x2f,0x74,0x64,0x3e,0x3c,0x74,0x64,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x26,0x6e, +0x62,0x73,0x70,0x3b,0x0d,0x0a,0x09,0x3c,0x2f,0x74,0x64,0x3e,0x3c,0x2f,0x74,0x72, +0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x20,0x20,0x3c,0x2f,0x74,0x61,0x62,0x6c,0x65, +0x3e,0x0d,0x0a,0x3c,0x2f,0x62,0x6f,0x64,0x79,0x3e,0x0d,0x0a,0x3c,0x2f,0x68,0x74, +0x6d,0x6c,0x3e,0x0d,0x0a,}; + +#if FSDATA_FILE_ALIGNMENT==1 +static const unsigned int dummy_align__index_html = 2; +#endif +static const unsigned char FSDATA_ALIGN_PRE data__index_html[] FSDATA_ALIGN_POST = { +/* /index.html (12 chars) */ +0x2f,0x69,0x6e,0x64,0x65,0x78,0x2e,0x68,0x74,0x6d,0x6c,0x00, + +/* HTTP header */ +/* "HTTP/1.1 200 OK +" (17 bytes) */ +0x48,0x54,0x54,0x50,0x2f,0x31,0x2e,0x31,0x20,0x32,0x30,0x30,0x20,0x4f,0x4b,0x0d, +0x0a, +/* "Server: lwIP/2.0.3d (http://savannah.nongnu.org/projects/lwip) +" (64 bytes) */ +0x53,0x65,0x72,0x76,0x65,0x72,0x3a,0x20,0x6c,0x77,0x49,0x50,0x2f,0x32,0x2e,0x30, +0x2e,0x33,0x64,0x20,0x28,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x73,0x61,0x76,0x61, +0x6e,0x6e,0x61,0x68,0x2e,0x6e,0x6f,0x6e,0x67,0x6e,0x75,0x2e,0x6f,0x72,0x67,0x2f, +0x70,0x72,0x6f,0x6a,0x65,0x63,0x74,0x73,0x2f,0x6c,0x77,0x69,0x70,0x29,0x0d,0x0a, + +/* "Content-Length: 1751 +" (18+ bytes) */ +0x43,0x6f,0x6e,0x74,0x65,0x6e,0x74,0x2d,0x4c,0x65,0x6e,0x67,0x74,0x68,0x3a,0x20, +0x31,0x37,0x35,0x31,0x0d,0x0a, +/* "Connection: keep-alive +" (24 bytes) */ +0x43,0x6f,0x6e,0x6e,0x65,0x63,0x74,0x69,0x6f,0x6e,0x3a,0x20,0x6b,0x65,0x65,0x70, +0x2d,0x61,0x6c,0x69,0x76,0x65,0x0d,0x0a, +/* "Content-Type: text/html + +" (27 bytes) */ +0x43,0x6f,0x6e,0x74,0x65,0x6e,0x74,0x2d,0x54,0x79,0x70,0x65,0x3a,0x20,0x74,0x65, +0x78,0x74,0x2f,0x68,0x74,0x6d,0x6c,0x0d,0x0a,0x0d,0x0a, +/* raw file data (1751 bytes) */ +0x3c,0x68,0x74,0x6d,0x6c,0x3e,0x0d,0x0a,0x3c,0x68,0x65,0x61,0x64,0x3e,0x3c,0x74, +0x69,0x74,0x6c,0x65,0x3e,0x6c,0x77,0x49,0x50,0x20,0x2d,0x20,0x41,0x20,0x4c,0x69, +0x67,0x68,0x74,0x77,0x65,0x69,0x67,0x68,0x74,0x20,0x54,0x43,0x50,0x2f,0x49,0x50, +0x20,0x53,0x74,0x61,0x63,0x6b,0x3c,0x2f,0x74,0x69,0x74,0x6c,0x65,0x3e,0x3c,0x2f, +0x68,0x65,0x61,0x64,0x3e,0x0d,0x0a,0x3c,0x62,0x6f,0x64,0x79,0x20,0x62,0x67,0x63, +0x6f,0x6c,0x6f,0x72,0x3d,0x22,0x77,0x68,0x69,0x74,0x65,0x22,0x20,0x74,0x65,0x78, +0x74,0x3d,0x22,0x62,0x6c,0x61,0x63,0x6b,0x22,0x3e,0x0d,0x0a,0x0d,0x0a,0x20,0x20, +0x20,0x20,0x3c,0x74,0x61,0x62,0x6c,0x65,0x20,0x77,0x69,0x64,0x74,0x68,0x3d,0x22, +0x31,0x30,0x30,0x25,0x22,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x20,0x20,0x3c,0x74, +0x72,0x20,0x76,0x61,0x6c,0x69,0x67,0x6e,0x3d,0x22,0x74,0x6f,0x70,0x22,0x3e,0x3c, +0x74,0x64,0x20,0x77,0x69,0x64,0x74,0x68,0x3d,0x22,0x38,0x30,0x22,0x3e,0x09,0x20, +0x20,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x61,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68, +0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73, +0x65,0x2f,0x22,0x3e,0x3c,0x69,0x6d,0x67,0x20,0x73,0x72,0x63,0x3d,0x22,0x2f,0x69, +0x6d,0x67,0x2f,0x73,0x69,0x63,0x73,0x2e,0x67,0x69,0x66,0x22,0x0d,0x0a,0x09,0x20, +0x20,0x62,0x6f,0x72,0x64,0x65,0x72,0x3d,0x22,0x30,0x22,0x20,0x61,0x6c,0x74,0x3d, +0x22,0x53,0x49,0x43,0x53,0x20,0x6c,0x6f,0x67,0x6f,0x22,0x20,0x74,0x69,0x74,0x6c, +0x65,0x3d,0x22,0x53,0x49,0x43,0x53,0x20,0x6c,0x6f,0x67,0x6f,0x22,0x3e,0x3c,0x2f, +0x61,0x3e,0x0d,0x0a,0x09,0x3c,0x2f,0x74,0x64,0x3e,0x3c,0x74,0x64,0x20,0x77,0x69, +0x64,0x74,0x68,0x3d,0x22,0x35,0x30,0x30,0x22,0x3e,0x09,0x20,0x20,0x0d,0x0a,0x09, +0x20,0x20,0x3c,0x68,0x31,0x3e,0x6c,0x77,0x49,0x50,0x20,0x2d,0x20,0x41,0x20,0x4c, +0x69,0x67,0x68,0x74,0x77,0x65,0x69,0x67,0x68,0x74,0x20,0x54,0x43,0x50,0x2f,0x49, +0x50,0x20,0x53,0x74,0x61,0x63,0x6b,0x3c,0x2f,0x68,0x31,0x3e,0x0d,0x0a,0x09,0x20, +0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x54,0x68,0x65,0x20,0x77, +0x65,0x62,0x20,0x70,0x61,0x67,0x65,0x20,0x79,0x6f,0x75,0x20,0x61,0x72,0x65,0x20, +0x77,0x61,0x74,0x63,0x68,0x69,0x6e,0x67,0x20,0x77,0x61,0x73,0x20,0x73,0x65,0x72, +0x76,0x65,0x64,0x20,0x62,0x79,0x20,0x61,0x20,0x73,0x69,0x6d,0x70,0x6c,0x65,0x20, +0x77,0x65,0x62,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x65,0x72,0x76,0x65,0x72, +0x20,0x72,0x75,0x6e,0x6e,0x69,0x6e,0x67,0x20,0x6f,0x6e,0x20,0x74,0x6f,0x70,0x20, +0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x6c,0x69,0x67,0x68,0x74,0x77,0x65,0x69,0x67, +0x68,0x74,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x20,0x73,0x74,0x61,0x63,0x6b,0x20, +0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68, +0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73, +0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x6c, +0x77,0x49,0x50,0x3c,0x2f,0x61,0x3e,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70, +0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20, +0x6c,0x77,0x49,0x50,0x20,0x69,0x73,0x20,0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20, +0x73,0x6f,0x75,0x72,0x63,0x65,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74, +0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x54,0x43,0x50, +0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x72,0x6f,0x74,0x6f,0x63, +0x6f,0x6c,0x20,0x73,0x75,0x69,0x74,0x65,0x20,0x74,0x68,0x61,0x74,0x20,0x77,0x61, +0x73,0x20,0x6f,0x72,0x69,0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77,0x72,0x69, +0x74,0x74,0x65,0x6e,0x20,0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77, +0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f, +0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x41,0x64,0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b, +0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x74,0x68,0x65, +0x20,0x53,0x77,0x65,0x64,0x69,0x73,0x68,0x20,0x49,0x6e,0x73,0x74,0x69,0x74,0x75, +0x74,0x65,0x20,0x6f,0x66,0x20,0x43,0x6f,0x6d,0x70,0x75,0x74,0x65,0x72,0x20,0x53, +0x63,0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75,0x74,0x20,0x6e, +0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x62,0x65,0x69,0x6e, +0x67,0x20,0x61,0x63,0x74,0x69,0x76,0x65,0x6c,0x79,0x20,0x64,0x65,0x76,0x65,0x6c, +0x6f,0x70,0x65,0x64,0x20,0x62,0x79,0x20,0x61,0x20,0x74,0x65,0x61,0x6d,0x20,0x6f, +0x66,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x64,0x69,0x73,0x74,0x72,0x69,0x62,0x75,0x74,0x65,0x64,0x20,0x77, +0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69,0x64,0x65,0x2e,0x20,0x53,0x69,0x6e,0x63,0x65, +0x20,0x69,0x74,0x27,0x73,0x20,0x72,0x65,0x6c,0x65,0x61,0x73,0x65,0x2c,0x20,0x6c, +0x77,0x49,0x50,0x20,0x68,0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x70, +0x75,0x72,0x72,0x65,0x64,0x20,0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20,0x69, +0x6e,0x74,0x65,0x72,0x65,0x73,0x74,0x20,0x61,0x6e,0x64,0x20,0x68,0x61,0x73,0x20, +0x62,0x65,0x65,0x6e,0x20,0x70,0x6f,0x72,0x74,0x65,0x64,0x20,0x74,0x6f,0x20,0x73, +0x65,0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x6c,0x61, +0x74,0x66,0x6f,0x72,0x6d,0x73,0x20,0x61,0x6e,0x64,0x20,0x6f,0x70,0x65,0x72,0x61, +0x74,0x69,0x6e,0x67,0x20,0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77, +0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65,0x20,0x75,0x73,0x65,0x64,0x20,0x65, +0x69,0x74,0x68,0x65,0x72,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x77,0x69,0x74,0x68, +0x20,0x6f,0x72,0x20,0x77,0x69,0x74,0x68,0x6f,0x75,0x74,0x20,0x61,0x6e,0x20,0x75, +0x6e,0x64,0x65,0x72,0x6c,0x79,0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09, +0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a, +0x09,0x20,0x20,0x20,0x20,0x54,0x68,0x65,0x20,0x66,0x6f,0x63,0x75,0x73,0x20,0x6f, +0x66,0x20,0x74,0x68,0x65,0x20,0x6c,0x77,0x49,0x50,0x20,0x54,0x43,0x50,0x2f,0x49, +0x50,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e, +0x20,0x69,0x73,0x20,0x74,0x6f,0x20,0x72,0x65,0x64,0x75,0x63,0x65,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x74,0x68,0x65,0x20,0x52,0x41,0x4d,0x20,0x75,0x73,0x61,0x67, +0x65,0x20,0x77,0x68,0x69,0x6c,0x65,0x20,0x73,0x74,0x69,0x6c,0x6c,0x20,0x68,0x61, +0x76,0x69,0x6e,0x67,0x20,0x61,0x20,0x66,0x75,0x6c,0x6c,0x20,0x73,0x63,0x61,0x6c, +0x65,0x20,0x54,0x43,0x50,0x2e,0x20,0x54,0x68,0x69,0x73,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x6d,0x61,0x6b,0x65,0x73,0x20,0x6c,0x77,0x49,0x50,0x20,0x73,0x75,0x69, +0x74,0x61,0x62,0x6c,0x65,0x20,0x66,0x6f,0x72,0x20,0x75,0x73,0x65,0x20,0x69,0x6e, +0x20,0x65,0x6d,0x62,0x65,0x64,0x64,0x65,0x64,0x20,0x73,0x79,0x73,0x74,0x65,0x6d, +0x73,0x20,0x77,0x69,0x74,0x68,0x20,0x74,0x65,0x6e,0x73,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x6f,0x66,0x20,0x6b,0x69,0x6c,0x6f,0x62,0x79,0x74,0x65,0x73,0x20,0x6f, +0x66,0x20,0x66,0x72,0x65,0x65,0x20,0x52,0x41,0x4d,0x20,0x61,0x6e,0x64,0x20,0x72, +0x6f,0x6f,0x6d,0x20,0x66,0x6f,0x72,0x20,0x61,0x72,0x6f,0x75,0x6e,0x64,0x20,0x34, +0x30,0x20,0x6b,0x69,0x6c,0x6f,0x62,0x79,0x74,0x65,0x73,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x6f,0x66,0x20,0x63,0x6f,0x64,0x65,0x20,0x52,0x4f,0x4d,0x2e,0x0d,0x0a, +0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d, +0x0a,0x09,0x20,0x20,0x20,0x20,0x4d,0x6f,0x72,0x65,0x20,0x69,0x6e,0x66,0x6f,0x72, +0x6d,0x61,0x74,0x69,0x6f,0x6e,0x20,0x61,0x62,0x6f,0x75,0x74,0x20,0x6c,0x77,0x49, +0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65,0x20,0x66,0x6f,0x75,0x6e,0x64,0x20,0x61, +0x74,0x20,0x74,0x68,0x65,0x20,0x6c,0x77,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x68,0x6f,0x6d,0x65,0x70,0x61,0x67,0x65,0x20,0x61,0x74,0x20,0x3c,0x61,0x0d, +0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70, +0x3a,0x2f,0x2f,0x73,0x61,0x76,0x61,0x6e,0x6e,0x61,0x68,0x2e,0x6e,0x6f,0x6e,0x67, +0x6e,0x75,0x2e,0x6f,0x72,0x67,0x2f,0x70,0x72,0x6f,0x6a,0x65,0x63,0x74,0x73,0x2f, +0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x73,0x61, +0x76,0x61,0x6e,0x6e,0x61,0x68,0x2e,0x6e,0x6f,0x6e,0x67,0x6e,0x75,0x2e,0x6f,0x72, +0x67,0x2f,0x70,0x72,0x6f,0x6a,0x65,0x63,0x74,0x73,0x2f,0x6c,0x77,0x69,0x70,0x2f, +0x3c,0x2f,0x61,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x72,0x20,0x61,0x74, +0x20,0x74,0x68,0x65,0x20,0x6c,0x77,0x49,0x50,0x20,0x77,0x69,0x6b,0x69,0x20,0x61, +0x74,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d, +0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x6c,0x77,0x69,0x70,0x2e,0x77,0x69,0x6b, +0x69,0x61,0x2e,0x63,0x6f,0x6d,0x2f,0x22,0x3e,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f, +0x6c,0x77,0x69,0x70,0x2e,0x77,0x69,0x6b,0x69,0x61,0x2e,0x63,0x6f,0x6d,0x2f,0x3c, +0x2f,0x61,0x3e,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09, +0x3c,0x2f,0x74,0x64,0x3e,0x3c,0x74,0x64,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x26,0x6e, +0x62,0x73,0x70,0x3b,0x0d,0x0a,0x09,0x3c,0x2f,0x74,0x64,0x3e,0x3c,0x2f,0x74,0x72, +0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x20,0x20,0x3c,0x2f,0x74,0x61,0x62,0x6c,0x65, +0x3e,0x0d,0x0a,0x3c,0x2f,0x62,0x6f,0x64,0x79,0x3e,0x0d,0x0a,0x3c,0x2f,0x68,0x74, +0x6d,0x6c,0x3e,0x0d,0x0a,0x0d,0x0a,}; + +#if FSDATA_FILE_ALIGNMENT==1 +static const unsigned int dummy_align__login_html = 3; +#endif +static const unsigned char FSDATA_ALIGN_PRE data__login_html[] FSDATA_ALIGN_POST = { +/* /login.html (12 chars) */ +0x2f,0x6c,0x6f,0x67,0x69,0x6e,0x2e,0x68,0x74,0x6d,0x6c,0x00, + +/* HTTP header */ +/* "HTTP/1.1 200 OK +" (17 bytes) */ +0x48,0x54,0x54,0x50,0x2f,0x31,0x2e,0x31,0x20,0x32,0x30,0x30,0x20,0x4f,0x4b,0x0d, +0x0a, +/* "Server: lwIP/2.0.3d (http://savannah.nongnu.org/projects/lwip) +" (64 bytes) */ +0x53,0x65,0x72,0x76,0x65,0x72,0x3a,0x20,0x6c,0x77,0x49,0x50,0x2f,0x32,0x2e,0x30, +0x2e,0x33,0x64,0x20,0x28,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x73,0x61,0x76,0x61, +0x6e,0x6e,0x61,0x68,0x2e,0x6e,0x6f,0x6e,0x67,0x6e,0x75,0x2e,0x6f,0x72,0x67,0x2f, +0x70,0x72,0x6f,0x6a,0x65,0x63,0x74,0x73,0x2f,0x6c,0x77,0x69,0x70,0x29,0x0d,0x0a, + +/* "Content-Length: 768 +" (18+ bytes) */ +0x43,0x6f,0x6e,0x74,0x65,0x6e,0x74,0x2d,0x4c,0x65,0x6e,0x67,0x74,0x68,0x3a,0x20, +0x37,0x36,0x38,0x0d,0x0a, +/* "Connection: keep-alive +" (24 bytes) */ +0x43,0x6f,0x6e,0x6e,0x65,0x63,0x74,0x69,0x6f,0x6e,0x3a,0x20,0x6b,0x65,0x65,0x70, +0x2d,0x61,0x6c,0x69,0x76,0x65,0x0d,0x0a, +/* "Content-Type: text/html + +" (27 bytes) */ +0x43,0x6f,0x6e,0x74,0x65,0x6e,0x74,0x2d,0x54,0x79,0x70,0x65,0x3a,0x20,0x74,0x65, +0x78,0x74,0x2f,0x68,0x74,0x6d,0x6c,0x0d,0x0a,0x0d,0x0a, +/* raw file data (768 bytes) */ +0x3c,0x68,0x74,0x6d,0x6c,0x3e,0x0d,0x0a,0x3c,0x68,0x65,0x61,0x64,0x3e,0x3c,0x74, +0x69,0x74,0x6c,0x65,0x3e,0x6c,0x77,0x49,0x50,0x20,0x2d,0x20,0x41,0x20,0x4c,0x69, +0x67,0x68,0x74,0x77,0x65,0x69,0x67,0x68,0x74,0x20,0x54,0x43,0x50,0x2f,0x49,0x50, +0x20,0x53,0x74,0x61,0x63,0x6b,0x3c,0x2f,0x74,0x69,0x74,0x6c,0x65,0x3e,0x3c,0x2f, +0x68,0x65,0x61,0x64,0x3e,0x0d,0x0a,0x3c,0x62,0x6f,0x64,0x79,0x20,0x62,0x67,0x63, +0x6f,0x6c,0x6f,0x72,0x3d,0x22,0x77,0x68,0x69,0x74,0x65,0x22,0x20,0x74,0x65,0x78, +0x74,0x3d,0x22,0x62,0x6c,0x61,0x63,0x6b,0x22,0x3e,0x0d,0x0a,0x0d,0x0a,0x3c,0x74, +0x61,0x62,0x6c,0x65,0x20,0x77,0x69,0x64,0x74,0x68,0x3d,0x22,0x31,0x30,0x30,0x25, +0x22,0x3e,0x0d,0x0a,0x20,0x3c,0x74,0x72,0x20,0x76,0x61,0x6c,0x69,0x67,0x6e,0x3d, +0x22,0x74,0x6f,0x70,0x22,0x3e,0x0d,0x0a,0x20,0x20,0x3c,0x74,0x64,0x20,0x77,0x69, +0x64,0x74,0x68,0x3d,0x22,0x38,0x30,0x22,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x3c,0x61, +0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77, +0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x22,0x3e,0x3c,0x69,0x6d,0x67, +0x20,0x73,0x72,0x63,0x3d,0x22,0x2f,0x69,0x6d,0x67,0x2f,0x73,0x69,0x63,0x73,0x2e, +0x67,0x69,0x66,0x22,0x20,0x62,0x6f,0x72,0x64,0x65,0x72,0x3d,0x22,0x30,0x22,0x20, +0x61,0x6c,0x74,0x3d,0x22,0x53,0x49,0x43,0x53,0x20,0x6c,0x6f,0x67,0x6f,0x22,0x20, +0x74,0x69,0x74,0x6c,0x65,0x3d,0x22,0x53,0x49,0x43,0x53,0x20,0x6c,0x6f,0x67,0x6f, +0x22,0x2f,0x3e,0x3c,0x2f,0x61,0x3e,0x0d,0x0a,0x20,0x20,0x3c,0x2f,0x74,0x64,0x3e, +0x0d,0x0a,0x20,0x20,0x3c,0x74,0x64,0x20,0x77,0x69,0x64,0x74,0x68,0x3d,0x22,0x35, +0x30,0x30,0x22,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x3c,0x68,0x31,0x3e,0x4c,0x6f,0x67, +0x69,0x6e,0x3c,0x2f,0x68,0x31,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x3c,0x66,0x6f,0x72, +0x6d,0x20,0x6e,0x61,0x6d,0x65,0x3d,0x22,0x6c,0x6f,0x67,0x69,0x6e,0x22,0x20,0x61, +0x63,0x74,0x69,0x6f,0x6e,0x3d,0x22,0x6c,0x6f,0x67,0x69,0x6e,0x2e,0x63,0x67,0x69, +0x22,0x20,0x6d,0x65,0x74,0x68,0x6f,0x64,0x3d,0x22,0x70,0x6f,0x73,0x74,0x22,0x3e, +0x0d,0x0a,0x20,0x20,0x20,0x20,0x3c,0x64,0x69,0x76,0x3e,0x0d,0x0a,0x20,0x20,0x20, +0x20,0x20,0x3c,0x6c,0x61,0x62,0x65,0x6c,0x3e,0x3c,0x62,0x3e,0x55,0x73,0x65,0x72, +0x6e,0x61,0x6d,0x65,0x3c,0x2f,0x62,0x3e,0x3c,0x2f,0x6c,0x61,0x62,0x65,0x6c,0x3e, +0x0d,0x0a,0x20,0x20,0x20,0x20,0x20,0x3c,0x69,0x6e,0x70,0x75,0x74,0x20,0x74,0x79, +0x70,0x65,0x3d,0x22,0x74,0x65,0x78,0x74,0x22,0x20,0x70,0x6c,0x61,0x63,0x65,0x68, +0x6f,0x6c,0x64,0x65,0x72,0x3d,0x22,0x45,0x6e,0x74,0x65,0x72,0x20,0x55,0x73,0x65, +0x72,0x6e,0x61,0x6d,0x65,0x22,0x20,0x6e,0x61,0x6d,0x65,0x3d,0x22,0x75,0x73,0x65, +0x72,0x22,0x20,0x72,0x65,0x71,0x75,0x69,0x72,0x65,0x64,0x3e,0x0d,0x0a,0x20,0x20, +0x20,0x20,0x20,0x3c,0x6c,0x61,0x62,0x65,0x6c,0x3e,0x3c,0x62,0x3e,0x50,0x61,0x73, +0x73,0x77,0x6f,0x72,0x64,0x3c,0x2f,0x62,0x3e,0x3c,0x2f,0x6c,0x61,0x62,0x65,0x6c, +0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x20,0x3c,0x69,0x6e,0x70,0x75,0x74,0x20,0x74, +0x79,0x70,0x65,0x3d,0x22,0x70,0x61,0x73,0x73,0x77,0x6f,0x72,0x64,0x22,0x20,0x70, +0x6c,0x61,0x63,0x65,0x68,0x6f,0x6c,0x64,0x65,0x72,0x3d,0x22,0x45,0x6e,0x74,0x65, +0x72,0x20,0x50,0x61,0x73,0x73,0x77,0x6f,0x72,0x64,0x22,0x20,0x6e,0x61,0x6d,0x65, +0x3d,0x22,0x70,0x61,0x73,0x73,0x22,0x20,0x72,0x65,0x71,0x75,0x69,0x72,0x65,0x64, +0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x20,0x3c,0x62,0x75,0x74,0x74,0x6f,0x6e,0x20, +0x74,0x79,0x70,0x65,0x3d,0x22,0x73,0x75,0x62,0x6d,0x69,0x74,0x22,0x3e,0x4c,0x6f, +0x67,0x69,0x6e,0x3c,0x2f,0x62,0x75,0x74,0x74,0x6f,0x6e,0x3e,0x0d,0x0a,0x20,0x20, +0x20,0x20,0x3c,0x2f,0x64,0x69,0x76,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x3c,0x2f,0x66, +0x6f,0x72,0x6d,0x3e,0x20,0x0d,0x0a,0x20,0x20,0x3c,0x2f,0x74,0x64,0x3e,0x0d,0x0a, +0x20,0x20,0x3c,0x74,0x64,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x26,0x6e,0x62,0x73,0x70, +0x3b,0x0d,0x0a,0x20,0x20,0x3c,0x2f,0x74,0x64,0x3e,0x0d,0x0a,0x20,0x3c,0x2f,0x74, +0x72,0x3e,0x0d,0x0a,0x3c,0x2f,0x74,0x61,0x62,0x6c,0x65,0x3e,0x0d,0x0a,0x3c,0x2f, +0x62,0x6f,0x64,0x79,0x3e,0x0d,0x0a,0x3c,0x2f,0x68,0x74,0x6d,0x6c,0x3e,0x0d,0x0a, +}; + +#if FSDATA_FILE_ALIGNMENT==1 +static const unsigned int dummy_align__loginfail_html = 4; +#endif +static const unsigned char FSDATA_ALIGN_PRE data__loginfail_html[] FSDATA_ALIGN_POST = { +/* /loginfail.html (16 chars) */ +0x2f,0x6c,0x6f,0x67,0x69,0x6e,0x66,0x61,0x69,0x6c,0x2e,0x68,0x74,0x6d,0x6c,0x00, + + +/* HTTP header */ +/* "HTTP/1.1 200 OK +" (17 bytes) */ +0x48,0x54,0x54,0x50,0x2f,0x31,0x2e,0x31,0x20,0x32,0x30,0x30,0x20,0x4f,0x4b,0x0d, +0x0a, +/* "Server: lwIP/2.0.3d (http://savannah.nongnu.org/projects/lwip) +" (64 bytes) */ +0x53,0x65,0x72,0x76,0x65,0x72,0x3a,0x20,0x6c,0x77,0x49,0x50,0x2f,0x32,0x2e,0x30, +0x2e,0x33,0x64,0x20,0x28,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x73,0x61,0x76,0x61, +0x6e,0x6e,0x61,0x68,0x2e,0x6e,0x6f,0x6e,0x67,0x6e,0x75,0x2e,0x6f,0x72,0x67,0x2f, +0x70,0x72,0x6f,0x6a,0x65,0x63,0x74,0x73,0x2f,0x6c,0x77,0x69,0x70,0x29,0x0d,0x0a, + +/* "Content-Length: 559 +" (18+ bytes) */ +0x43,0x6f,0x6e,0x74,0x65,0x6e,0x74,0x2d,0x4c,0x65,0x6e,0x67,0x74,0x68,0x3a,0x20, +0x35,0x35,0x39,0x0d,0x0a, +/* "Connection: keep-alive +" (24 bytes) */ +0x43,0x6f,0x6e,0x6e,0x65,0x63,0x74,0x69,0x6f,0x6e,0x3a,0x20,0x6b,0x65,0x65,0x70, +0x2d,0x61,0x6c,0x69,0x76,0x65,0x0d,0x0a, +/* "Content-Type: text/html + +" (27 bytes) */ +0x43,0x6f,0x6e,0x74,0x65,0x6e,0x74,0x2d,0x54,0x79,0x70,0x65,0x3a,0x20,0x74,0x65, +0x78,0x74,0x2f,0x68,0x74,0x6d,0x6c,0x0d,0x0a,0x0d,0x0a, +/* raw file data (559 bytes) */ +0x3c,0x68,0x74,0x6d,0x6c,0x3e,0x0d,0x0a,0x3c,0x68,0x65,0x61,0x64,0x3e,0x3c,0x74, +0x69,0x74,0x6c,0x65,0x3e,0x6c,0x77,0x49,0x50,0x20,0x2d,0x20,0x41,0x20,0x4c,0x69, +0x67,0x68,0x74,0x77,0x65,0x69,0x67,0x68,0x74,0x20,0x54,0x43,0x50,0x2f,0x49,0x50, +0x20,0x53,0x74,0x61,0x63,0x6b,0x3c,0x2f,0x74,0x69,0x74,0x6c,0x65,0x3e,0x3c,0x2f, +0x68,0x65,0x61,0x64,0x3e,0x0d,0x0a,0x3c,0x62,0x6f,0x64,0x79,0x20,0x62,0x67,0x63, +0x6f,0x6c,0x6f,0x72,0x3d,0x22,0x77,0x68,0x69,0x74,0x65,0x22,0x20,0x74,0x65,0x78, +0x74,0x3d,0x22,0x62,0x6c,0x61,0x63,0x6b,0x22,0x3e,0x0d,0x0a,0x0d,0x0a,0x20,0x3c, +0x74,0x61,0x62,0x6c,0x65,0x20,0x77,0x69,0x64,0x74,0x68,0x3d,0x22,0x31,0x30,0x30, +0x25,0x22,0x3e,0x0d,0x0a,0x20,0x20,0x3c,0x74,0x72,0x20,0x76,0x61,0x6c,0x69,0x67, +0x6e,0x3d,0x22,0x74,0x6f,0x70,0x22,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x3c,0x74,0x64, +0x20,0x77,0x69,0x64,0x74,0x68,0x3d,0x22,0x38,0x30,0x22,0x3e,0x0d,0x0a,0x20,0x20, +0x20,0x20,0x3c,0x61,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a, +0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x22,0x3e, +0x3c,0x69,0x6d,0x67,0x20,0x73,0x72,0x63,0x3d,0x22,0x2f,0x69,0x6d,0x67,0x2f,0x73, +0x69,0x63,0x73,0x2e,0x67,0x69,0x66,0x22,0x20,0x62,0x6f,0x72,0x64,0x65,0x72,0x3d, +0x22,0x30,0x22,0x20,0x61,0x6c,0x74,0x3d,0x22,0x53,0x49,0x43,0x53,0x20,0x6c,0x6f, +0x67,0x6f,0x22,0x20,0x74,0x69,0x74,0x6c,0x65,0x3d,0x22,0x53,0x49,0x43,0x53,0x20, +0x6c,0x6f,0x67,0x6f,0x22,0x2f,0x3e,0x3c,0x2f,0x61,0x3e,0x0d,0x0a,0x20,0x20,0x20, +0x3c,0x2f,0x74,0x64,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x3c,0x74,0x64,0x20,0x77,0x69, +0x64,0x74,0x68,0x3d,0x22,0x35,0x30,0x30,0x22,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20, +0x3c,0x68,0x31,0x3e,0x6c,0x77,0x49,0x50,0x20,0x2d,0x20,0x41,0x20,0x4c,0x69,0x67, +0x68,0x74,0x77,0x65,0x69,0x67,0x68,0x74,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x20, +0x53,0x74,0x61,0x63,0x6b,0x3c,0x2f,0x68,0x31,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20, +0x3c,0x70,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x20,0x4c,0x6f,0x67,0x69,0x6e,0x20, +0x66,0x61,0x69,0x6c,0x65,0x64,0x2e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x3c,0x2f,0x70, +0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20, +0x20,0x43,0x6c,0x69,0x63,0x6b,0x20,0x3c,0x61,0x20,0x68,0x72,0x65,0x66,0x3d,0x22, +0x6c,0x6f,0x67,0x69,0x6e,0x2e,0x68,0x74,0x6d,0x6c,0x22,0x3e,0x68,0x65,0x72,0x65, +0x3c,0x2f,0x61,0x3e,0x20,0x74,0x6f,0x20,0x72,0x65,0x74,0x72,0x79,0x20,0x6c,0x6f, +0x67,0x69,0x6e,0x2e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a, +0x20,0x20,0x20,0x3c,0x2f,0x74,0x64,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x3c,0x74,0x64, +0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x26,0x6e,0x62,0x73,0x70,0x3b,0x0d,0x0a,0x20, +0x20,0x20,0x3c,0x2f,0x74,0x64,0x3e,0x0d,0x0a,0x20,0x20,0x3c,0x2f,0x74,0x72,0x3e, +0x0d,0x0a,0x20,0x3c,0x2f,0x74,0x61,0x62,0x6c,0x65,0x3e,0x0d,0x0a,0x3c,0x2f,0x62, +0x6f,0x64,0x79,0x3e,0x0d,0x0a,0x3c,0x2f,0x68,0x74,0x6d,0x6c,0x3e,0x0d,0x0a,}; + +#if FSDATA_FILE_ALIGNMENT==1 +static const unsigned int dummy_align__session_html = 5; +#endif +static const unsigned char FSDATA_ALIGN_PRE data__session_html[] FSDATA_ALIGN_POST = { +/* /session.html (14 chars) */ +0x2f,0x73,0x65,0x73,0x73,0x69,0x6f,0x6e,0x2e,0x68,0x74,0x6d,0x6c,0x00,0x00,0x00, + +/* HTTP header */ +/* "HTTP/1.1 200 OK +" (17 bytes) */ +0x48,0x54,0x54,0x50,0x2f,0x31,0x2e,0x31,0x20,0x32,0x30,0x30,0x20,0x4f,0x4b,0x0d, +0x0a, +/* "Server: lwIP/2.0.3d (http://savannah.nongnu.org/projects/lwip) +" (64 bytes) */ +0x53,0x65,0x72,0x76,0x65,0x72,0x3a,0x20,0x6c,0x77,0x49,0x50,0x2f,0x32,0x2e,0x30, +0x2e,0x33,0x64,0x20,0x28,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x73,0x61,0x76,0x61, +0x6e,0x6e,0x61,0x68,0x2e,0x6e,0x6f,0x6e,0x67,0x6e,0x75,0x2e,0x6f,0x72,0x67,0x2f, +0x70,0x72,0x6f,0x6a,0x65,0x63,0x74,0x73,0x2f,0x6c,0x77,0x69,0x70,0x29,0x0d,0x0a, + +/* "Content-Length: 578 +" (18+ bytes) */ +0x43,0x6f,0x6e,0x74,0x65,0x6e,0x74,0x2d,0x4c,0x65,0x6e,0x67,0x74,0x68,0x3a,0x20, +0x35,0x37,0x38,0x0d,0x0a, +/* "Connection: keep-alive +" (24 bytes) */ +0x43,0x6f,0x6e,0x6e,0x65,0x63,0x74,0x69,0x6f,0x6e,0x3a,0x20,0x6b,0x65,0x65,0x70, +0x2d,0x61,0x6c,0x69,0x76,0x65,0x0d,0x0a, +/* "Content-Type: text/html + +" (27 bytes) */ +0x43,0x6f,0x6e,0x74,0x65,0x6e,0x74,0x2d,0x54,0x79,0x70,0x65,0x3a,0x20,0x74,0x65, +0x78,0x74,0x2f,0x68,0x74,0x6d,0x6c,0x0d,0x0a,0x0d,0x0a, +/* raw file data (578 bytes) */ +0x3c,0x68,0x74,0x6d,0x6c,0x3e,0x0d,0x0a,0x3c,0x68,0x65,0x61,0x64,0x3e,0x3c,0x74, +0x69,0x74,0x6c,0x65,0x3e,0x6c,0x77,0x49,0x50,0x20,0x2d,0x20,0x41,0x20,0x4c,0x69, +0x67,0x68,0x74,0x77,0x65,0x69,0x67,0x68,0x74,0x20,0x54,0x43,0x50,0x2f,0x49,0x50, +0x20,0x53,0x74,0x61,0x63,0x6b,0x3c,0x2f,0x74,0x69,0x74,0x6c,0x65,0x3e,0x3c,0x2f, +0x68,0x65,0x61,0x64,0x3e,0x0d,0x0a,0x3c,0x62,0x6f,0x64,0x79,0x20,0x62,0x67,0x63, +0x6f,0x6c,0x6f,0x72,0x3d,0x22,0x77,0x68,0x69,0x74,0x65,0x22,0x20,0x74,0x65,0x78, +0x74,0x3d,0x22,0x62,0x6c,0x61,0x63,0x6b,0x22,0x3e,0x0d,0x0a,0x0d,0x0a,0x20,0x3c, +0x74,0x61,0x62,0x6c,0x65,0x20,0x77,0x69,0x64,0x74,0x68,0x3d,0x22,0x31,0x30,0x30, +0x25,0x22,0x3e,0x0d,0x0a,0x20,0x20,0x3c,0x74,0x72,0x20,0x76,0x61,0x6c,0x69,0x67, +0x6e,0x3d,0x22,0x74,0x6f,0x70,0x22,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x3c,0x74,0x64, +0x20,0x77,0x69,0x64,0x74,0x68,0x3d,0x22,0x38,0x30,0x22,0x3e,0x0d,0x0a,0x20,0x20, +0x20,0x20,0x3c,0x61,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a, +0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x22,0x3e, +0x3c,0x69,0x6d,0x67,0x20,0x73,0x72,0x63,0x3d,0x22,0x2f,0x69,0x6d,0x67,0x2f,0x73, +0x69,0x63,0x73,0x2e,0x67,0x69,0x66,0x22,0x20,0x62,0x6f,0x72,0x64,0x65,0x72,0x3d, +0x22,0x30,0x22,0x20,0x61,0x6c,0x74,0x3d,0x22,0x53,0x49,0x43,0x53,0x20,0x6c,0x6f, +0x67,0x6f,0x22,0x20,0x74,0x69,0x74,0x6c,0x65,0x3d,0x22,0x53,0x49,0x43,0x53,0x20, +0x6c,0x6f,0x67,0x6f,0x22,0x2f,0x3e,0x3c,0x2f,0x61,0x3e,0x0d,0x0a,0x20,0x20,0x20, +0x3c,0x2f,0x74,0x64,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x3c,0x74,0x64,0x20,0x77,0x69, +0x64,0x74,0x68,0x3d,0x22,0x35,0x30,0x30,0x22,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20, +0x3c,0x68,0x31,0x3e,0x6c,0x77,0x49,0x50,0x20,0x2d,0x20,0x41,0x20,0x4c,0x69,0x67, +0x68,0x74,0x77,0x65,0x69,0x67,0x68,0x74,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x20, +0x53,0x74,0x61,0x63,0x6b,0x3c,0x2f,0x68,0x31,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20, +0x3c,0x70,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x20,0x4c,0x6f,0x67,0x69,0x6e,0x20, +0x73,0x75,0x63,0x63,0x65,0x65,0x64,0x65,0x64,0x2c,0x20,0x73,0x65,0x73,0x73,0x69, +0x6f,0x6e,0x20,0x61,0x63,0x74,0x69,0x76,0x65,0x2e,0x0d,0x0a,0x20,0x20,0x20,0x20, +0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x20, +0x20,0x20,0x20,0x20,0x43,0x6c,0x69,0x63,0x6b,0x20,0x3c,0x61,0x20,0x68,0x72,0x65, +0x66,0x3d,0x22,0x6c,0x6f,0x67,0x69,0x6e,0x2e,0x68,0x74,0x6d,0x6c,0x22,0x3e,0x68, +0x65,0x72,0x65,0x3c,0x2f,0x61,0x3e,0x20,0x74,0x6f,0x20,0x72,0x65,0x74,0x72,0x79, +0x20,0x6c,0x6f,0x67,0x69,0x6e,0x2e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x3c,0x2f,0x70, +0x3e,0x0d,0x0a,0x20,0x20,0x20,0x3c,0x2f,0x74,0x64,0x3e,0x0d,0x0a,0x20,0x20,0x20, +0x3c,0x74,0x64,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x26,0x6e,0x62,0x73,0x70,0x3b, +0x0d,0x0a,0x20,0x20,0x20,0x3c,0x2f,0x74,0x64,0x3e,0x0d,0x0a,0x20,0x20,0x3c,0x2f, +0x74,0x72,0x3e,0x0d,0x0a,0x20,0x3c,0x2f,0x74,0x61,0x62,0x6c,0x65,0x3e,0x0d,0x0a, +0x3c,0x2f,0x62,0x6f,0x64,0x79,0x3e,0x0d,0x0a,0x3c,0x2f,0x68,0x74,0x6d,0x6c,0x3e, +0x0d,0x0a,}; + +#if FSDATA_FILE_ALIGNMENT==1 +static const unsigned int dummy_align__ssi_shtml = 6; +#endif +static const unsigned char FSDATA_ALIGN_PRE data__ssi_shtml[] FSDATA_ALIGN_POST = { +/* /ssi.shtml (11 chars) */ +0x2f,0x73,0x73,0x69,0x2e,0x73,0x68,0x74,0x6d,0x6c,0x00,0x00, + +/* HTTP header */ +/* "HTTP/1.1 200 OK +" (17 bytes) */ +0x48,0x54,0x54,0x50,0x2f,0x31,0x2e,0x31,0x20,0x32,0x30,0x30,0x20,0x4f,0x4b,0x0d, +0x0a, +/* "Server: lwIP/2.0.3d (http://savannah.nongnu.org/projects/lwip) +" (64 bytes) */ +0x53,0x65,0x72,0x76,0x65,0x72,0x3a,0x20,0x6c,0x77,0x49,0x50,0x2f,0x32,0x2e,0x30, +0x2e,0x33,0x64,0x20,0x28,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x73,0x61,0x76,0x61, +0x6e,0x6e,0x61,0x68,0x2e,0x6e,0x6f,0x6e,0x67,0x6e,0x75,0x2e,0x6f,0x72,0x67,0x2f, +0x70,0x72,0x6f,0x6a,0x65,0x63,0x74,0x73,0x2f,0x6c,0x77,0x69,0x70,0x29,0x0d,0x0a, + +/* "Connection: Close +" (19 bytes) */ +0x43,0x6f,0x6e,0x6e,0x65,0x63,0x74,0x69,0x6f,0x6e,0x3a,0x20,0x43,0x6c,0x6f,0x73, +0x65,0x0d,0x0a, +/* "Content-Type: text/html +Expires: Fri, 10 Apr 2008 14:00:00 GMT +Pragma: no-cache + +" (85 bytes) */ +0x43,0x6f,0x6e,0x74,0x65,0x6e,0x74,0x2d,0x54,0x79,0x70,0x65,0x3a,0x20,0x74,0x65, +0x78,0x74,0x2f,0x68,0x74,0x6d,0x6c,0x0d,0x0a,0x45,0x78,0x70,0x69,0x72,0x65,0x73, +0x3a,0x20,0x46,0x72,0x69,0x2c,0x20,0x31,0x30,0x20,0x41,0x70,0x72,0x20,0x32,0x30, +0x30,0x38,0x20,0x31,0x34,0x3a,0x30,0x30,0x3a,0x30,0x30,0x20,0x47,0x4d,0x54,0x0d, +0x0a,0x50,0x72,0x61,0x67,0x6d,0x61,0x3a,0x20,0x6e,0x6f,0x2d,0x63,0x61,0x63,0x68, +0x65,0x0d,0x0a,0x0d,0x0a, +/* raw file data (14429 bytes) */ +0x3c,0x68,0x74,0x6d,0x6c,0x3e,0x0d,0x0a,0x3c,0x68,0x65,0x61,0x64,0x3e,0x3c,0x74, +0x69,0x74,0x6c,0x65,0x3e,0x6c,0x77,0x49,0x50,0x20,0x2d,0x20,0x41,0x20,0x4c,0x69, +0x67,0x68,0x74,0x77,0x65,0x69,0x67,0x68,0x74,0x20,0x54,0x43,0x50,0x2f,0x49,0x50, +0x20,0x53,0x74,0x61,0x63,0x6b,0x3c,0x2f,0x74,0x69,0x74,0x6c,0x65,0x3e,0x3c,0x2f, +0x68,0x65,0x61,0x64,0x3e,0x0d,0x0a,0x3c,0x62,0x6f,0x64,0x79,0x20,0x62,0x67,0x63, +0x6f,0x6c,0x6f,0x72,0x3d,0x22,0x77,0x68,0x69,0x74,0x65,0x22,0x20,0x74,0x65,0x78, +0x74,0x3d,0x22,0x62,0x6c,0x61,0x63,0x6b,0x22,0x3e,0x0d,0x0a,0x0d,0x0a,0x20,0x20, +0x20,0x20,0x3c,0x74,0x61,0x62,0x6c,0x65,0x20,0x77,0x69,0x64,0x74,0x68,0x3d,0x22, +0x31,0x30,0x30,0x25,0x22,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x20,0x20,0x3c,0x74, +0x72,0x20,0x76,0x61,0x6c,0x69,0x67,0x6e,0x3d,0x22,0x74,0x6f,0x70,0x22,0x3e,0x3c, +0x74,0x64,0x20,0x77,0x69,0x64,0x74,0x68,0x3d,0x22,0x38,0x30,0x22,0x3e,0x09,0x20, +0x20,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x61,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68, +0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73, +0x65,0x2f,0x22,0x3e,0x3c,0x69,0x6d,0x67,0x20,0x73,0x72,0x63,0x3d,0x22,0x2f,0x69, +0x6d,0x67,0x2f,0x73,0x69,0x63,0x73,0x2e,0x67,0x69,0x66,0x22,0x0d,0x0a,0x09,0x20, +0x20,0x62,0x6f,0x72,0x64,0x65,0x72,0x3d,0x22,0x30,0x22,0x20,0x61,0x6c,0x74,0x3d, +0x22,0x53,0x49,0x43,0x53,0x20,0x6c,0x6f,0x67,0x6f,0x22,0x20,0x74,0x69,0x74,0x6c, +0x65,0x3d,0x22,0x53,0x49,0x43,0x53,0x20,0x6c,0x6f,0x67,0x6f,0x22,0x3e,0x3c,0x2f, +0x61,0x3e,0x0d,0x0a,0x09,0x3c,0x2f,0x74,0x64,0x3e,0x3c,0x74,0x64,0x20,0x77,0x69, +0x64,0x74,0x68,0x3d,0x22,0x35,0x30,0x30,0x22,0x3e,0x09,0x20,0x20,0x0d,0x0a,0x09, +0x20,0x20,0x3c,0x68,0x31,0x3e,0x6c,0x77,0x49,0x50,0x20,0x2d,0x20,0x41,0x20,0x4c, +0x69,0x67,0x68,0x74,0x77,0x65,0x69,0x67,0x68,0x74,0x20,0x54,0x43,0x50,0x2f,0x49, +0x50,0x20,0x53,0x74,0x61,0x63,0x6b,0x3c,0x2f,0x68,0x31,0x3e,0x0d,0x0a,0x09,0x20, +0x20,0x3c,0x68,0x31,0x3e,0x3c,0x21,0x2d,0x2d,0x23,0x48,0x65,0x6c,0x6c,0x57,0x6f, +0x72,0x6c,0x2d,0x2d,0x3e,0x3c,0x2f,0x68,0x31,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c, +0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x54,0x68,0x65,0x20,0x77,0x65,0x62, +0x20,0x70,0x61,0x67,0x65,0x20,0x79,0x6f,0x75,0x20,0x61,0x72,0x65,0x20,0x77,0x61, +0x74,0x63,0x68,0x69,0x6e,0x67,0x20,0x77,0x61,0x73,0x20,0x73,0x65,0x72,0x76,0x65, +0x64,0x20,0x62,0x79,0x20,0x61,0x20,0x73,0x69,0x6d,0x70,0x6c,0x65,0x20,0x77,0x65, +0x62,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x65,0x72,0x76,0x65,0x72,0x20,0x72, +0x75,0x6e,0x6e,0x69,0x6e,0x67,0x20,0x6f,0x6e,0x20,0x74,0x6f,0x70,0x20,0x6f,0x66, +0x20,0x74,0x68,0x65,0x20,0x6c,0x69,0x67,0x68,0x74,0x77,0x65,0x69,0x67,0x68,0x74, +0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x20,0x73,0x74,0x61,0x63,0x6b,0x20,0x3c,0x61, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74, +0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f, +0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x6c,0x77,0x49, +0x50,0x3c,0x2f,0x61,0x3e,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d, +0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x54,0x68, +0x69,0x73,0x20,0x70,0x61,0x67,0x65,0x20,0x69,0x73,0x20,0x68,0x65,0x72,0x65,0x20, +0x74,0x6f,0x20,0x74,0x65,0x73,0x74,0x20,0x53,0x53,0x49,0x2c,0x20,0x73,0x6f,0x20, +0x68,0x65,0x72,0x65,0x20,0x69,0x73,0x20,0x61,0x20,0x63,0x6f,0x75,0x6e,0x74,0x65, +0x72,0x20,0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x61,0x6e,0x20,0x65,0x78, +0x61,0x6d,0x70,0x6c,0x65,0x20,0x6f,0x66,0x20,0x63,0x6f,0x6e,0x74,0x65,0x6e,0x74, +0x20,0x63,0x68,0x61,0x6e,0x67,0x69,0x6e,0x67,0x20,0x66,0x6f,0x72,0x20,0x65,0x76, +0x65,0x72,0x79,0x20,0x72,0x65,0x71,0x75,0x65,0x73,0x74,0x3a,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x22,0x3c,0x21,0x2d,0x2d,0x23,0x63,0x6f,0x75,0x6e,0x74,0x65,0x72, +0x2d,0x2d,0x3e,0x22,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09, +0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x41,0x6e,0x64,0x20, +0x68,0x65,0x72,0x65,0x20,0x69,0x73,0x20,0x61,0x6e,0x20,0x65,0x78,0x61,0x6d,0x70, +0x6c,0x65,0x20,0x6f,0x66,0x20,0x61,0x20,0x74,0x61,0x67,0x20,0x72,0x65,0x73,0x75, +0x6c,0x74,0x20,0x62,0x75,0x66,0x66,0x65,0x72,0x20,0x72,0x65,0x74,0x75,0x72,0x6e, +0x20,0x69,0x6e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6d,0x75,0x6c,0x74,0x69,0x70, +0x6c,0x65,0x20,0x70,0x61,0x72,0x74,0x73,0x3a,0x20,0x22,0x3c,0x21,0x2d,0x2d,0x23, +0x4d,0x75,0x6c,0x74,0x50,0x61,0x72,0x74,0x2d,0x2d,0x3e,0x22,0x0d,0x0a,0x09,0x20, +0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x54,0x6f,0x20,0x74,0x65,0x73,0x74,0x20,0x4c,0x57,0x49,0x50, +0x5f,0x48,0x54,0x54,0x50,0x44,0x5f,0x43,0x47,0x49,0x5f,0x53,0x53,0x49,0x2c,0x20, +0x68,0x65,0x72,0x65,0x20,0x61,0x72,0x65,0x20,0x74,0x68,0x65,0x20,0x43,0x47,0x49, +0x20,0x70,0x61,0x72,0x61,0x6d,0x65,0x74,0x65,0x72,0x73,0x3a,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x3c,0x21,0x2d,0x2d,0x23,0x43,0x67,0x69,0x50,0x61,0x72,0x61,0x6d, +0x2d,0x2d,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20, +0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6c,0x77,0x49,0x50,0x20, +0x69,0x73,0x20,0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f,0x75,0x72,0x63, +0x65,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e, +0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x0d,0x0a, +0x09,0x20,0x20,0x20,0x20,0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20,0x73,0x75, +0x69,0x74,0x65,0x20,0x74,0x68,0x61,0x74,0x20,0x77,0x61,0x73,0x20,0x6f,0x72,0x69, +0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77,0x72,0x69,0x74,0x74,0x65,0x6e,0x20, +0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66, +0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63, +0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f, +0x22,0x3e,0x41,0x64,0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73,0x0d,0x0a, +0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x53,0x77,0x65,0x64, +0x69,0x73,0x68,0x20,0x49,0x6e,0x73,0x74,0x69,0x74,0x75,0x74,0x65,0x20,0x6f,0x66, +0x20,0x43,0x6f,0x6d,0x70,0x75,0x74,0x65,0x72,0x20,0x53,0x63,0x69,0x65,0x6e,0x63, +0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75,0x74,0x20,0x6e,0x6f,0x77,0x20,0x69,0x73, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x62,0x65,0x69,0x6e,0x67,0x20,0x61,0x63,0x74, +0x69,0x76,0x65,0x6c,0x79,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x64,0x20, +0x62,0x79,0x20,0x61,0x20,0x74,0x65,0x61,0x6d,0x20,0x6f,0x66,0x20,0x64,0x65,0x76, +0x65,0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x64,0x69, +0x73,0x74,0x72,0x69,0x62,0x75,0x74,0x65,0x64,0x20,0x77,0x6f,0x72,0x6c,0x64,0x2d, +0x77,0x69,0x64,0x65,0x2e,0x20,0x53,0x69,0x6e,0x63,0x65,0x20,0x69,0x74,0x27,0x73, +0x20,0x72,0x65,0x6c,0x65,0x61,0x73,0x65,0x2c,0x20,0x6c,0x77,0x49,0x50,0x20,0x68, +0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x70,0x75,0x72,0x72,0x65,0x64, +0x20,0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20,0x69,0x6e,0x74,0x65,0x72,0x65, +0x73,0x74,0x20,0x61,0x6e,0x64,0x20,0x68,0x61,0x73,0x20,0x62,0x65,0x65,0x6e,0x20, +0x70,0x6f,0x72,0x74,0x65,0x64,0x20,0x74,0x6f,0x20,0x73,0x65,0x76,0x65,0x72,0x61, +0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x6c,0x61,0x74,0x66,0x6f,0x72,0x6d, +0x73,0x20,0x61,0x6e,0x64,0x20,0x6f,0x70,0x65,0x72,0x61,0x74,0x69,0x6e,0x67,0x20, +0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49,0x50,0x20,0x63,0x61, +0x6e,0x20,0x62,0x65,0x20,0x75,0x73,0x65,0x64,0x20,0x65,0x69,0x74,0x68,0x65,0x72, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x77,0x69,0x74,0x68,0x20,0x6f,0x72,0x20,0x77, +0x69,0x74,0x68,0x6f,0x75,0x74,0x20,0x61,0x6e,0x20,0x75,0x6e,0x64,0x65,0x72,0x6c, +0x79,0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70, +0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70, +0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6c,0x77,0x49,0x50,0x20,0x69,0x73,0x20, +0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f,0x75,0x72,0x63,0x65,0x20,0x69, +0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66, +0x20,0x74,0x68,0x65,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20,0x73,0x75,0x69,0x74,0x65, +0x20,0x74,0x68,0x61,0x74,0x20,0x77,0x61,0x73,0x20,0x6f,0x72,0x69,0x67,0x69,0x6e, +0x61,0x6c,0x6c,0x79,0x20,0x77,0x72,0x69,0x74,0x74,0x65,0x6e,0x20,0x62,0x79,0x20, +0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68, +0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73, +0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x41, +0x64,0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x53,0x77,0x65,0x64,0x69,0x73,0x68, +0x20,0x49,0x6e,0x73,0x74,0x69,0x74,0x75,0x74,0x65,0x20,0x6f,0x66,0x20,0x43,0x6f, +0x6d,0x70,0x75,0x74,0x65,0x72,0x20,0x53,0x63,0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f, +0x61,0x3e,0x20,0x62,0x75,0x74,0x20,0x6e,0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x62,0x65,0x69,0x6e,0x67,0x20,0x61,0x63,0x74,0x69,0x76,0x65, +0x6c,0x79,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x64,0x20,0x62,0x79,0x20, +0x61,0x20,0x74,0x65,0x61,0x6d,0x20,0x6f,0x66,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f, +0x70,0x65,0x72,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x64,0x69,0x73,0x74,0x72, +0x69,0x62,0x75,0x74,0x65,0x64,0x20,0x77,0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69,0x64, +0x65,0x2e,0x20,0x53,0x69,0x6e,0x63,0x65,0x20,0x69,0x74,0x27,0x73,0x20,0x72,0x65, +0x6c,0x65,0x61,0x73,0x65,0x2c,0x20,0x6c,0x77,0x49,0x50,0x20,0x68,0x61,0x73,0x0d, +0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x70,0x75,0x72,0x72,0x65,0x64,0x20,0x61,0x20, +0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20,0x69,0x6e,0x74,0x65,0x72,0x65,0x73,0x74,0x20, +0x61,0x6e,0x64,0x20,0x68,0x61,0x73,0x20,0x62,0x65,0x65,0x6e,0x20,0x70,0x6f,0x72, +0x74,0x65,0x64,0x20,0x74,0x6f,0x20,0x73,0x65,0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a, +0x09,0x20,0x20,0x20,0x20,0x70,0x6c,0x61,0x74,0x66,0x6f,0x72,0x6d,0x73,0x20,0x61, +0x6e,0x64,0x20,0x6f,0x70,0x65,0x72,0x61,0x74,0x69,0x6e,0x67,0x20,0x73,0x79,0x73, +0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62, +0x65,0x20,0x75,0x73,0x65,0x64,0x20,0x65,0x69,0x74,0x68,0x65,0x72,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x77,0x69,0x74,0x68,0x20,0x6f,0x72,0x20,0x77,0x69,0x74,0x68, +0x6f,0x75,0x74,0x20,0x61,0x6e,0x20,0x75,0x6e,0x64,0x65,0x72,0x6c,0x79,0x69,0x6e, +0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a, +0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6c,0x77,0x49, +0x50,0x20,0x69,0x73,0x20,0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f,0x75, +0x72,0x63,0x65,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69, +0x6f,0x6e,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x54,0x43,0x50,0x2f,0x49,0x50, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20, +0x73,0x75,0x69,0x74,0x65,0x20,0x74,0x68,0x61,0x74,0x20,0x77,0x61,0x73,0x20,0x6f, +0x72,0x69,0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77,0x72,0x69,0x74,0x74,0x65, +0x6e,0x20,0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72, +0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73, +0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69, +0x70,0x2f,0x22,0x3e,0x41,0x64,0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x53,0x77, +0x65,0x64,0x69,0x73,0x68,0x20,0x49,0x6e,0x73,0x74,0x69,0x74,0x75,0x74,0x65,0x20, +0x6f,0x66,0x20,0x43,0x6f,0x6d,0x70,0x75,0x74,0x65,0x72,0x20,0x53,0x63,0x69,0x65, +0x6e,0x63,0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75,0x74,0x20,0x6e,0x6f,0x77,0x20, +0x69,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x62,0x65,0x69,0x6e,0x67,0x20,0x61, +0x63,0x74,0x69,0x76,0x65,0x6c,0x79,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65, +0x64,0x20,0x62,0x79,0x20,0x61,0x20,0x74,0x65,0x61,0x6d,0x20,0x6f,0x66,0x20,0x64, +0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20, +0x64,0x69,0x73,0x74,0x72,0x69,0x62,0x75,0x74,0x65,0x64,0x20,0x77,0x6f,0x72,0x6c, +0x64,0x2d,0x77,0x69,0x64,0x65,0x2e,0x20,0x53,0x69,0x6e,0x63,0x65,0x20,0x69,0x74, +0x27,0x73,0x20,0x72,0x65,0x6c,0x65,0x61,0x73,0x65,0x2c,0x20,0x6c,0x77,0x49,0x50, +0x20,0x68,0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x70,0x75,0x72,0x72, +0x65,0x64,0x20,0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20,0x69,0x6e,0x74,0x65, +0x72,0x65,0x73,0x74,0x20,0x61,0x6e,0x64,0x20,0x68,0x61,0x73,0x20,0x62,0x65,0x65, +0x6e,0x20,0x70,0x6f,0x72,0x74,0x65,0x64,0x20,0x74,0x6f,0x20,0x73,0x65,0x76,0x65, +0x72,0x61,0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x6c,0x61,0x74,0x66,0x6f, +0x72,0x6d,0x73,0x20,0x61,0x6e,0x64,0x20,0x6f,0x70,0x65,0x72,0x61,0x74,0x69,0x6e, +0x67,0x20,0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49,0x50,0x20, +0x63,0x61,0x6e,0x20,0x62,0x65,0x20,0x75,0x73,0x65,0x64,0x20,0x65,0x69,0x74,0x68, +0x65,0x72,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x77,0x69,0x74,0x68,0x20,0x6f,0x72, +0x20,0x77,0x69,0x74,0x68,0x6f,0x75,0x74,0x20,0x61,0x6e,0x20,0x75,0x6e,0x64,0x65, +0x72,0x6c,0x79,0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c, +0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x6c,0x77,0x49,0x50,0x20,0x69,0x73,0x20,0x61,0x6e,0x20,0x6f,0x70,0x65, +0x6e,0x20,0x73,0x6f,0x75,0x72,0x63,0x65,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65, +0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x54, +0x43,0x50,0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x72,0x6f,0x74, +0x6f,0x63,0x6f,0x6c,0x20,0x73,0x75,0x69,0x74,0x65,0x20,0x74,0x68,0x61,0x74,0x20, +0x77,0x61,0x73,0x20,0x6f,0x72,0x69,0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77, +0x72,0x69,0x74,0x74,0x65,0x6e,0x20,0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f, +0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64,0x61, +0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x41,0x64,0x61,0x6d,0x20,0x44,0x75, +0x6e,0x6b,0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x74, +0x68,0x65,0x20,0x53,0x77,0x65,0x64,0x69,0x73,0x68,0x20,0x49,0x6e,0x73,0x74,0x69, +0x74,0x75,0x74,0x65,0x20,0x6f,0x66,0x20,0x43,0x6f,0x6d,0x70,0x75,0x74,0x65,0x72, +0x20,0x53,0x63,0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75,0x74, +0x20,0x6e,0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x62,0x65, +0x69,0x6e,0x67,0x20,0x61,0x63,0x74,0x69,0x76,0x65,0x6c,0x79,0x20,0x64,0x65,0x76, +0x65,0x6c,0x6f,0x70,0x65,0x64,0x20,0x62,0x79,0x20,0x61,0x20,0x74,0x65,0x61,0x6d, +0x20,0x6f,0x66,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a, +0x09,0x20,0x20,0x20,0x20,0x64,0x69,0x73,0x74,0x72,0x69,0x62,0x75,0x74,0x65,0x64, +0x20,0x77,0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69,0x64,0x65,0x2e,0x20,0x53,0x69,0x6e, +0x63,0x65,0x20,0x69,0x74,0x27,0x73,0x20,0x72,0x65,0x6c,0x65,0x61,0x73,0x65,0x2c, +0x20,0x6c,0x77,0x49,0x50,0x20,0x68,0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20, +0x73,0x70,0x75,0x72,0x72,0x65,0x64,0x20,0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66, +0x20,0x69,0x6e,0x74,0x65,0x72,0x65,0x73,0x74,0x20,0x61,0x6e,0x64,0x20,0x68,0x61, +0x73,0x20,0x62,0x65,0x65,0x6e,0x20,0x70,0x6f,0x72,0x74,0x65,0x64,0x20,0x74,0x6f, +0x20,0x73,0x65,0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70, +0x6c,0x61,0x74,0x66,0x6f,0x72,0x6d,0x73,0x20,0x61,0x6e,0x64,0x20,0x6f,0x70,0x65, +0x72,0x61,0x74,0x69,0x6e,0x67,0x20,0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x2e,0x20, +0x6c,0x77,0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65,0x20,0x75,0x73,0x65,0x64, +0x20,0x65,0x69,0x74,0x68,0x65,0x72,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x77,0x69, +0x74,0x68,0x20,0x6f,0x72,0x20,0x77,0x69,0x74,0x68,0x6f,0x75,0x74,0x20,0x61,0x6e, +0x20,0x75,0x6e,0x64,0x65,0x72,0x6c,0x79,0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d, +0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6c,0x77,0x49,0x50,0x20,0x69,0x73,0x20,0x61, +0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f,0x75,0x72,0x63,0x65,0x20,0x69,0x6d, +0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66,0x20, +0x74,0x68,0x65,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20,0x73,0x75,0x69,0x74,0x65,0x20, +0x74,0x68,0x61,0x74,0x20,0x77,0x61,0x73,0x20,0x6f,0x72,0x69,0x67,0x69,0x6e,0x61, +0x6c,0x6c,0x79,0x20,0x77,0x72,0x69,0x74,0x74,0x65,0x6e,0x20,0x62,0x79,0x20,0x3c, +0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74, +0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65, +0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x41,0x64, +0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x53,0x77,0x65,0x64,0x69,0x73,0x68,0x20, +0x49,0x6e,0x73,0x74,0x69,0x74,0x75,0x74,0x65,0x20,0x6f,0x66,0x20,0x43,0x6f,0x6d, +0x70,0x75,0x74,0x65,0x72,0x20,0x53,0x63,0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f,0x61, +0x3e,0x20,0x62,0x75,0x74,0x20,0x6e,0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x62,0x65,0x69,0x6e,0x67,0x20,0x61,0x63,0x74,0x69,0x76,0x65,0x6c, +0x79,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x64,0x20,0x62,0x79,0x20,0x61, +0x20,0x74,0x65,0x61,0x6d,0x20,0x6f,0x66,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70, +0x65,0x72,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x64,0x69,0x73,0x74,0x72,0x69, +0x62,0x75,0x74,0x65,0x64,0x20,0x77,0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69,0x64,0x65, +0x2e,0x20,0x53,0x69,0x6e,0x63,0x65,0x20,0x69,0x74,0x27,0x73,0x20,0x72,0x65,0x6c, +0x65,0x61,0x73,0x65,0x2c,0x20,0x6c,0x77,0x49,0x50,0x20,0x68,0x61,0x73,0x0d,0x0a, +0x09,0x20,0x20,0x20,0x20,0x73,0x70,0x75,0x72,0x72,0x65,0x64,0x20,0x61,0x20,0x6c, +0x6f,0x74,0x20,0x6f,0x66,0x20,0x69,0x6e,0x74,0x65,0x72,0x65,0x73,0x74,0x20,0x61, +0x6e,0x64,0x20,0x68,0x61,0x73,0x20,0x62,0x65,0x65,0x6e,0x20,0x70,0x6f,0x72,0x74, +0x65,0x64,0x20,0x74,0x6f,0x20,0x73,0x65,0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x70,0x6c,0x61,0x74,0x66,0x6f,0x72,0x6d,0x73,0x20,0x61,0x6e, +0x64,0x20,0x6f,0x70,0x65,0x72,0x61,0x74,0x69,0x6e,0x67,0x20,0x73,0x79,0x73,0x74, +0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65, +0x20,0x75,0x73,0x65,0x64,0x20,0x65,0x69,0x74,0x68,0x65,0x72,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x77,0x69,0x74,0x68,0x20,0x6f,0x72,0x20,0x77,0x69,0x74,0x68,0x6f, +0x75,0x74,0x20,0x61,0x6e,0x20,0x75,0x6e,0x64,0x65,0x72,0x6c,0x79,0x69,0x6e,0x67, +0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09, +0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6c,0x77,0x49,0x50, +0x20,0x69,0x73,0x20,0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f,0x75,0x72, +0x63,0x65,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69,0x6f, +0x6e,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x0d, +0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20,0x73, +0x75,0x69,0x74,0x65,0x20,0x74,0x68,0x61,0x74,0x20,0x77,0x61,0x73,0x20,0x6f,0x72, +0x69,0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77,0x72,0x69,0x74,0x74,0x65,0x6e, +0x20,0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65, +0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69, +0x63,0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70, +0x2f,0x22,0x3e,0x41,0x64,0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73,0x0d, +0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x53,0x77,0x65, +0x64,0x69,0x73,0x68,0x20,0x49,0x6e,0x73,0x74,0x69,0x74,0x75,0x74,0x65,0x20,0x6f, +0x66,0x20,0x43,0x6f,0x6d,0x70,0x75,0x74,0x65,0x72,0x20,0x53,0x63,0x69,0x65,0x6e, +0x63,0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75,0x74,0x20,0x6e,0x6f,0x77,0x20,0x69, +0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x62,0x65,0x69,0x6e,0x67,0x20,0x61,0x63, +0x74,0x69,0x76,0x65,0x6c,0x79,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x64, +0x20,0x62,0x79,0x20,0x61,0x20,0x74,0x65,0x61,0x6d,0x20,0x6f,0x66,0x20,0x64,0x65, +0x76,0x65,0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x64, +0x69,0x73,0x74,0x72,0x69,0x62,0x75,0x74,0x65,0x64,0x20,0x77,0x6f,0x72,0x6c,0x64, +0x2d,0x77,0x69,0x64,0x65,0x2e,0x20,0x53,0x69,0x6e,0x63,0x65,0x20,0x69,0x74,0x27, +0x73,0x20,0x72,0x65,0x6c,0x65,0x61,0x73,0x65,0x2c,0x20,0x6c,0x77,0x49,0x50,0x20, +0x68,0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x70,0x75,0x72,0x72,0x65, +0x64,0x20,0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20,0x69,0x6e,0x74,0x65,0x72, +0x65,0x73,0x74,0x20,0x61,0x6e,0x64,0x20,0x68,0x61,0x73,0x20,0x62,0x65,0x65,0x6e, +0x20,0x70,0x6f,0x72,0x74,0x65,0x64,0x20,0x74,0x6f,0x20,0x73,0x65,0x76,0x65,0x72, +0x61,0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x6c,0x61,0x74,0x66,0x6f,0x72, +0x6d,0x73,0x20,0x61,0x6e,0x64,0x20,0x6f,0x70,0x65,0x72,0x61,0x74,0x69,0x6e,0x67, +0x20,0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49,0x50,0x20,0x63, +0x61,0x6e,0x20,0x62,0x65,0x20,0x75,0x73,0x65,0x64,0x20,0x65,0x69,0x74,0x68,0x65, +0x72,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x77,0x69,0x74,0x68,0x20,0x6f,0x72,0x20, +0x77,0x69,0x74,0x68,0x6f,0x75,0x74,0x20,0x61,0x6e,0x20,0x75,0x6e,0x64,0x65,0x72, +0x6c,0x79,0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f, +0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x6c,0x77,0x49,0x50,0x20,0x69,0x73,0x20,0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e, +0x20,0x73,0x6f,0x75,0x72,0x63,0x65,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e, +0x74,0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x54,0x43, +0x50,0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x72,0x6f,0x74,0x6f, +0x63,0x6f,0x6c,0x20,0x73,0x75,0x69,0x74,0x65,0x20,0x74,0x68,0x61,0x74,0x20,0x77, +0x61,0x73,0x20,0x6f,0x72,0x69,0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77,0x72, +0x69,0x74,0x74,0x65,0x6e,0x20,0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77, +0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d, +0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x41,0x64,0x61,0x6d,0x20,0x44,0x75,0x6e, +0x6b,0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x74,0x68, +0x65,0x20,0x53,0x77,0x65,0x64,0x69,0x73,0x68,0x20,0x49,0x6e,0x73,0x74,0x69,0x74, +0x75,0x74,0x65,0x20,0x6f,0x66,0x20,0x43,0x6f,0x6d,0x70,0x75,0x74,0x65,0x72,0x20, +0x53,0x63,0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75,0x74,0x20, +0x6e,0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x62,0x65,0x69, +0x6e,0x67,0x20,0x61,0x63,0x74,0x69,0x76,0x65,0x6c,0x79,0x20,0x64,0x65,0x76,0x65, +0x6c,0x6f,0x70,0x65,0x64,0x20,0x62,0x79,0x20,0x61,0x20,0x74,0x65,0x61,0x6d,0x20, +0x6f,0x66,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x64,0x69,0x73,0x74,0x72,0x69,0x62,0x75,0x74,0x65,0x64,0x20, +0x77,0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69,0x64,0x65,0x2e,0x20,0x53,0x69,0x6e,0x63, +0x65,0x20,0x69,0x74,0x27,0x73,0x20,0x72,0x65,0x6c,0x65,0x61,0x73,0x65,0x2c,0x20, +0x6c,0x77,0x49,0x50,0x20,0x68,0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73, +0x70,0x75,0x72,0x72,0x65,0x64,0x20,0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20, +0x69,0x6e,0x74,0x65,0x72,0x65,0x73,0x74,0x20,0x61,0x6e,0x64,0x20,0x68,0x61,0x73, +0x20,0x62,0x65,0x65,0x6e,0x20,0x70,0x6f,0x72,0x74,0x65,0x64,0x20,0x74,0x6f,0x20, +0x73,0x65,0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x6c, +0x61,0x74,0x66,0x6f,0x72,0x6d,0x73,0x20,0x61,0x6e,0x64,0x20,0x6f,0x70,0x65,0x72, +0x61,0x74,0x69,0x6e,0x67,0x20,0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c, +0x77,0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65,0x20,0x75,0x73,0x65,0x64,0x20, +0x65,0x69,0x74,0x68,0x65,0x72,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x77,0x69,0x74, +0x68,0x20,0x6f,0x72,0x20,0x77,0x69,0x74,0x68,0x6f,0x75,0x74,0x20,0x61,0x6e,0x20, +0x75,0x6e,0x64,0x65,0x72,0x6c,0x79,0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a, +0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d, +0x0a,0x09,0x20,0x20,0x20,0x20,0x6c,0x77,0x49,0x50,0x20,0x69,0x73,0x20,0x61,0x6e, +0x20,0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f,0x75,0x72,0x63,0x65,0x20,0x69,0x6d,0x70, +0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66,0x20,0x74, +0x68,0x65,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20, +0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20,0x73,0x75,0x69,0x74,0x65,0x20,0x74, +0x68,0x61,0x74,0x20,0x77,0x61,0x73,0x20,0x6f,0x72,0x69,0x67,0x69,0x6e,0x61,0x6c, +0x6c,0x79,0x20,0x77,0x72,0x69,0x74,0x74,0x65,0x6e,0x20,0x62,0x79,0x20,0x3c,0x61, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74, +0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f, +0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x41,0x64,0x61, +0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20, +0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x53,0x77,0x65,0x64,0x69,0x73,0x68,0x20,0x49, +0x6e,0x73,0x74,0x69,0x74,0x75,0x74,0x65,0x20,0x6f,0x66,0x20,0x43,0x6f,0x6d,0x70, +0x75,0x74,0x65,0x72,0x20,0x53,0x63,0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f,0x61,0x3e, +0x20,0x62,0x75,0x74,0x20,0x6e,0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x62,0x65,0x69,0x6e,0x67,0x20,0x61,0x63,0x74,0x69,0x76,0x65,0x6c,0x79, +0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x64,0x20,0x62,0x79,0x20,0x61,0x20, +0x74,0x65,0x61,0x6d,0x20,0x6f,0x66,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65, +0x72,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x64,0x69,0x73,0x74,0x72,0x69,0x62, +0x75,0x74,0x65,0x64,0x20,0x77,0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69,0x64,0x65,0x2e, +0x20,0x53,0x69,0x6e,0x63,0x65,0x20,0x69,0x74,0x27,0x73,0x20,0x72,0x65,0x6c,0x65, +0x61,0x73,0x65,0x2c,0x20,0x6c,0x77,0x49,0x50,0x20,0x68,0x61,0x73,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x73,0x70,0x75,0x72,0x72,0x65,0x64,0x20,0x61,0x20,0x6c,0x6f, +0x74,0x20,0x6f,0x66,0x20,0x69,0x6e,0x74,0x65,0x72,0x65,0x73,0x74,0x20,0x61,0x6e, +0x64,0x20,0x68,0x61,0x73,0x20,0x62,0x65,0x65,0x6e,0x20,0x70,0x6f,0x72,0x74,0x65, +0x64,0x20,0x74,0x6f,0x20,0x73,0x65,0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x70,0x6c,0x61,0x74,0x66,0x6f,0x72,0x6d,0x73,0x20,0x61,0x6e,0x64, +0x20,0x6f,0x70,0x65,0x72,0x61,0x74,0x69,0x6e,0x67,0x20,0x73,0x79,0x73,0x74,0x65, +0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65,0x20, +0x75,0x73,0x65,0x64,0x20,0x65,0x69,0x74,0x68,0x65,0x72,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x77,0x69,0x74,0x68,0x20,0x6f,0x72,0x20,0x77,0x69,0x74,0x68,0x6f,0x75, +0x74,0x20,0x61,0x6e,0x20,0x75,0x6e,0x64,0x65,0x72,0x6c,0x79,0x69,0x6e,0x67,0x20, +0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20, +0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6c,0x77,0x49,0x50,0x20, +0x69,0x73,0x20,0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f,0x75,0x72,0x63, +0x65,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e, +0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x0d,0x0a, +0x09,0x20,0x20,0x20,0x20,0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20,0x73,0x75, +0x69,0x74,0x65,0x20,0x74,0x68,0x61,0x74,0x20,0x77,0x61,0x73,0x20,0x6f,0x72,0x69, +0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77,0x72,0x69,0x74,0x74,0x65,0x6e,0x20, +0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66, +0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63, +0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f, +0x22,0x3e,0x41,0x64,0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73,0x0d,0x0a, +0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x53,0x77,0x65,0x64, +0x69,0x73,0x68,0x20,0x49,0x6e,0x73,0x74,0x69,0x74,0x75,0x74,0x65,0x20,0x6f,0x66, +0x20,0x43,0x6f,0x6d,0x70,0x75,0x74,0x65,0x72,0x20,0x53,0x63,0x69,0x65,0x6e,0x63, +0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75,0x74,0x20,0x6e,0x6f,0x77,0x20,0x69,0x73, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x62,0x65,0x69,0x6e,0x67,0x20,0x61,0x63,0x74, +0x69,0x76,0x65,0x6c,0x79,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x64,0x20, +0x62,0x79,0x20,0x61,0x20,0x74,0x65,0x61,0x6d,0x20,0x6f,0x66,0x20,0x64,0x65,0x76, +0x65,0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x64,0x69, +0x73,0x74,0x72,0x69,0x62,0x75,0x74,0x65,0x64,0x20,0x77,0x6f,0x72,0x6c,0x64,0x2d, +0x77,0x69,0x64,0x65,0x2e,0x20,0x53,0x69,0x6e,0x63,0x65,0x20,0x69,0x74,0x27,0x73, +0x20,0x72,0x65,0x6c,0x65,0x61,0x73,0x65,0x2c,0x20,0x6c,0x77,0x49,0x50,0x20,0x68, +0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x70,0x75,0x72,0x72,0x65,0x64, +0x20,0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20,0x69,0x6e,0x74,0x65,0x72,0x65, +0x73,0x74,0x20,0x61,0x6e,0x64,0x20,0x68,0x61,0x73,0x20,0x62,0x65,0x65,0x6e,0x20, +0x70,0x6f,0x72,0x74,0x65,0x64,0x20,0x74,0x6f,0x20,0x73,0x65,0x76,0x65,0x72,0x61, +0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x6c,0x61,0x74,0x66,0x6f,0x72,0x6d, +0x73,0x20,0x61,0x6e,0x64,0x20,0x6f,0x70,0x65,0x72,0x61,0x74,0x69,0x6e,0x67,0x20, +0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49,0x50,0x20,0x63,0x61, +0x6e,0x20,0x62,0x65,0x20,0x75,0x73,0x65,0x64,0x20,0x65,0x69,0x74,0x68,0x65,0x72, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x77,0x69,0x74,0x68,0x20,0x6f,0x72,0x20,0x77, +0x69,0x74,0x68,0x6f,0x75,0x74,0x20,0x61,0x6e,0x20,0x75,0x6e,0x64,0x65,0x72,0x6c, +0x79,0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70, +0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20, +0x6c,0x77,0x49,0x50,0x20,0x69,0x73,0x20,0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20, +0x73,0x6f,0x75,0x72,0x63,0x65,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74, +0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x54,0x43,0x50, +0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x72,0x6f,0x74,0x6f,0x63, +0x6f,0x6c,0x20,0x73,0x75,0x69,0x74,0x65,0x20,0x74,0x68,0x61,0x74,0x20,0x77,0x61, +0x73,0x20,0x6f,0x72,0x69,0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77,0x72,0x69, +0x74,0x74,0x65,0x6e,0x20,0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77, +0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f, +0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x41,0x64,0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b, +0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x74,0x68,0x65, +0x20,0x53,0x77,0x65,0x64,0x69,0x73,0x68,0x20,0x49,0x6e,0x73,0x74,0x69,0x74,0x75, +0x74,0x65,0x20,0x6f,0x66,0x20,0x43,0x6f,0x6d,0x70,0x75,0x74,0x65,0x72,0x20,0x53, +0x63,0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75,0x74,0x20,0x6e, +0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x62,0x65,0x69,0x6e, +0x67,0x20,0x61,0x63,0x74,0x69,0x76,0x65,0x6c,0x79,0x20,0x64,0x65,0x76,0x65,0x6c, +0x6f,0x70,0x65,0x64,0x20,0x62,0x79,0x20,0x61,0x20,0x74,0x65,0x61,0x6d,0x20,0x6f, +0x66,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x64,0x69,0x73,0x74,0x72,0x69,0x62,0x75,0x74,0x65,0x64,0x20,0x77, +0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69,0x64,0x65,0x2e,0x20,0x53,0x69,0x6e,0x63,0x65, +0x20,0x69,0x74,0x27,0x73,0x20,0x72,0x65,0x6c,0x65,0x61,0x73,0x65,0x2c,0x20,0x6c, +0x77,0x49,0x50,0x20,0x68,0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x70, +0x75,0x72,0x72,0x65,0x64,0x20,0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20,0x69, +0x6e,0x74,0x65,0x72,0x65,0x73,0x74,0x20,0x61,0x6e,0x64,0x20,0x68,0x61,0x73,0x20, +0x62,0x65,0x65,0x6e,0x20,0x70,0x6f,0x72,0x74,0x65,0x64,0x20,0x74,0x6f,0x20,0x73, +0x65,0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x6c,0x61, +0x74,0x66,0x6f,0x72,0x6d,0x73,0x20,0x61,0x6e,0x64,0x20,0x6f,0x70,0x65,0x72,0x61, +0x74,0x69,0x6e,0x67,0x20,0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77, +0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65,0x20,0x75,0x73,0x65,0x64,0x20,0x65, +0x69,0x74,0x68,0x65,0x72,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x77,0x69,0x74,0x68, +0x20,0x6f,0x72,0x20,0x77,0x69,0x74,0x68,0x6f,0x75,0x74,0x20,0x61,0x6e,0x20,0x75, +0x6e,0x64,0x65,0x72,0x6c,0x79,0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09, +0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a, +0x09,0x20,0x20,0x20,0x20,0x6c,0x77,0x49,0x50,0x20,0x69,0x73,0x20,0x61,0x6e,0x20, +0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f,0x75,0x72,0x63,0x65,0x20,0x69,0x6d,0x70,0x6c, +0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66,0x20,0x74,0x68, +0x65,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70, +0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20,0x73,0x75,0x69,0x74,0x65,0x20,0x74,0x68, +0x61,0x74,0x20,0x77,0x61,0x73,0x20,0x6f,0x72,0x69,0x67,0x69,0x6e,0x61,0x6c,0x6c, +0x79,0x20,0x77,0x72,0x69,0x74,0x74,0x65,0x6e,0x20,0x62,0x79,0x20,0x3c,0x61,0x0d, +0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70, +0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x7e, +0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x41,0x64,0x61,0x6d, +0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f, +0x66,0x20,0x74,0x68,0x65,0x20,0x53,0x77,0x65,0x64,0x69,0x73,0x68,0x20,0x49,0x6e, +0x73,0x74,0x69,0x74,0x75,0x74,0x65,0x20,0x6f,0x66,0x20,0x43,0x6f,0x6d,0x70,0x75, +0x74,0x65,0x72,0x20,0x53,0x63,0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f,0x61,0x3e,0x20, +0x62,0x75,0x74,0x20,0x6e,0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x62,0x65,0x69,0x6e,0x67,0x20,0x61,0x63,0x74,0x69,0x76,0x65,0x6c,0x79,0x20, +0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x64,0x20,0x62,0x79,0x20,0x61,0x20,0x74, +0x65,0x61,0x6d,0x20,0x6f,0x66,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x72, +0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x64,0x69,0x73,0x74,0x72,0x69,0x62,0x75, +0x74,0x65,0x64,0x20,0x77,0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69,0x64,0x65,0x2e,0x20, +0x53,0x69,0x6e,0x63,0x65,0x20,0x69,0x74,0x27,0x73,0x20,0x72,0x65,0x6c,0x65,0x61, +0x73,0x65,0x2c,0x20,0x6c,0x77,0x49,0x50,0x20,0x68,0x61,0x73,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x73,0x70,0x75,0x72,0x72,0x65,0x64,0x20,0x61,0x20,0x6c,0x6f,0x74, +0x20,0x6f,0x66,0x20,0x69,0x6e,0x74,0x65,0x72,0x65,0x73,0x74,0x20,0x61,0x6e,0x64, +0x20,0x68,0x61,0x73,0x20,0x62,0x65,0x65,0x6e,0x20,0x70,0x6f,0x72,0x74,0x65,0x64, +0x20,0x74,0x6f,0x20,0x73,0x65,0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x70,0x6c,0x61,0x74,0x66,0x6f,0x72,0x6d,0x73,0x20,0x61,0x6e,0x64,0x20, +0x6f,0x70,0x65,0x72,0x61,0x74,0x69,0x6e,0x67,0x20,0x73,0x79,0x73,0x74,0x65,0x6d, +0x73,0x2e,0x20,0x6c,0x77,0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65,0x20,0x75, +0x73,0x65,0x64,0x20,0x65,0x69,0x74,0x68,0x65,0x72,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x77,0x69,0x74,0x68,0x20,0x6f,0x72,0x20,0x77,0x69,0x74,0x68,0x6f,0x75,0x74, +0x20,0x61,0x6e,0x20,0x75,0x6e,0x64,0x65,0x72,0x6c,0x79,0x69,0x6e,0x67,0x20,0x4f, +0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20, +0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6c,0x77,0x49,0x50,0x20,0x69, +0x73,0x20,0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f,0x75,0x72,0x63,0x65, +0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e,0x20, +0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20,0x73,0x75,0x69, +0x74,0x65,0x20,0x74,0x68,0x61,0x74,0x20,0x77,0x61,0x73,0x20,0x6f,0x72,0x69,0x67, +0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77,0x72,0x69,0x74,0x74,0x65,0x6e,0x20,0x62, +0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d, +0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73, +0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22, +0x3e,0x41,0x64,0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x53,0x77,0x65,0x64,0x69, +0x73,0x68,0x20,0x49,0x6e,0x73,0x74,0x69,0x74,0x75,0x74,0x65,0x20,0x6f,0x66,0x20, +0x43,0x6f,0x6d,0x70,0x75,0x74,0x65,0x72,0x20,0x53,0x63,0x69,0x65,0x6e,0x63,0x65, +0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75,0x74,0x20,0x6e,0x6f,0x77,0x20,0x69,0x73,0x0d, +0x0a,0x09,0x20,0x20,0x20,0x20,0x62,0x65,0x69,0x6e,0x67,0x20,0x61,0x63,0x74,0x69, +0x76,0x65,0x6c,0x79,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x64,0x20,0x62, +0x79,0x20,0x61,0x20,0x74,0x65,0x61,0x6d,0x20,0x6f,0x66,0x20,0x64,0x65,0x76,0x65, +0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x64,0x69,0x73, +0x74,0x72,0x69,0x62,0x75,0x74,0x65,0x64,0x20,0x77,0x6f,0x72,0x6c,0x64,0x2d,0x77, +0x69,0x64,0x65,0x2e,0x20,0x53,0x69,0x6e,0x63,0x65,0x20,0x69,0x74,0x27,0x73,0x20, +0x72,0x65,0x6c,0x65,0x61,0x73,0x65,0x2c,0x20,0x6c,0x77,0x49,0x50,0x20,0x68,0x61, +0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x70,0x75,0x72,0x72,0x65,0x64,0x20, +0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20,0x69,0x6e,0x74,0x65,0x72,0x65,0x73, +0x74,0x20,0x61,0x6e,0x64,0x20,0x68,0x61,0x73,0x20,0x62,0x65,0x65,0x6e,0x20,0x70, +0x6f,0x72,0x74,0x65,0x64,0x20,0x74,0x6f,0x20,0x73,0x65,0x76,0x65,0x72,0x61,0x6c, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x6c,0x61,0x74,0x66,0x6f,0x72,0x6d,0x73, +0x20,0x61,0x6e,0x64,0x20,0x6f,0x70,0x65,0x72,0x61,0x74,0x69,0x6e,0x67,0x20,0x73, +0x79,0x73,0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49,0x50,0x20,0x63,0x61,0x6e, +0x20,0x62,0x65,0x20,0x75,0x73,0x65,0x64,0x20,0x65,0x69,0x74,0x68,0x65,0x72,0x0d, +0x0a,0x09,0x20,0x20,0x20,0x20,0x77,0x69,0x74,0x68,0x20,0x6f,0x72,0x20,0x77,0x69, +0x74,0x68,0x6f,0x75,0x74,0x20,0x61,0x6e,0x20,0x75,0x6e,0x64,0x65,0x72,0x6c,0x79, +0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e, +0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6c, +0x77,0x49,0x50,0x20,0x69,0x73,0x20,0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20,0x73, +0x6f,0x75,0x72,0x63,0x65,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61, +0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x54,0x43,0x50,0x2f, +0x49,0x50,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f, +0x6c,0x20,0x73,0x75,0x69,0x74,0x65,0x20,0x74,0x68,0x61,0x74,0x20,0x77,0x61,0x73, +0x20,0x6f,0x72,0x69,0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77,0x72,0x69,0x74, +0x74,0x65,0x6e,0x20,0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20, +0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77, +0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c, +0x77,0x69,0x70,0x2f,0x22,0x3e,0x41,0x64,0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65, +0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20, +0x53,0x77,0x65,0x64,0x69,0x73,0x68,0x20,0x49,0x6e,0x73,0x74,0x69,0x74,0x75,0x74, +0x65,0x20,0x6f,0x66,0x20,0x43,0x6f,0x6d,0x70,0x75,0x74,0x65,0x72,0x20,0x53,0x63, +0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75,0x74,0x20,0x6e,0x6f, +0x77,0x20,0x69,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x62,0x65,0x69,0x6e,0x67, +0x20,0x61,0x63,0x74,0x69,0x76,0x65,0x6c,0x79,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f, +0x70,0x65,0x64,0x20,0x62,0x79,0x20,0x61,0x20,0x74,0x65,0x61,0x6d,0x20,0x6f,0x66, +0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x64,0x69,0x73,0x74,0x72,0x69,0x62,0x75,0x74,0x65,0x64,0x20,0x77,0x6f, +0x72,0x6c,0x64,0x2d,0x77,0x69,0x64,0x65,0x2e,0x20,0x53,0x69,0x6e,0x63,0x65,0x20, +0x69,0x74,0x27,0x73,0x20,0x72,0x65,0x6c,0x65,0x61,0x73,0x65,0x2c,0x20,0x6c,0x77, +0x49,0x50,0x20,0x68,0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x70,0x75, +0x72,0x72,0x65,0x64,0x20,0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20,0x69,0x6e, +0x74,0x65,0x72,0x65,0x73,0x74,0x20,0x61,0x6e,0x64,0x20,0x68,0x61,0x73,0x20,0x62, +0x65,0x65,0x6e,0x20,0x70,0x6f,0x72,0x74,0x65,0x64,0x20,0x74,0x6f,0x20,0x73,0x65, +0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x6c,0x61,0x74, +0x66,0x6f,0x72,0x6d,0x73,0x20,0x61,0x6e,0x64,0x20,0x6f,0x70,0x65,0x72,0x61,0x74, +0x69,0x6e,0x67,0x20,0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49, +0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65,0x20,0x75,0x73,0x65,0x64,0x20,0x65,0x69, +0x74,0x68,0x65,0x72,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x77,0x69,0x74,0x68,0x20, +0x6f,0x72,0x20,0x77,0x69,0x74,0x68,0x6f,0x75,0x74,0x20,0x61,0x6e,0x20,0x75,0x6e, +0x64,0x65,0x72,0x6c,0x79,0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20, +0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x6c,0x77,0x49,0x50,0x20,0x69,0x73,0x20,0x61,0x6e,0x20,0x6f, +0x70,0x65,0x6e,0x20,0x73,0x6f,0x75,0x72,0x63,0x65,0x20,0x69,0x6d,0x70,0x6c,0x65, +0x6d,0x65,0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66,0x20,0x74,0x68,0x65, +0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x72, +0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20,0x73,0x75,0x69,0x74,0x65,0x20,0x74,0x68,0x61, +0x74,0x20,0x77,0x61,0x73,0x20,0x6f,0x72,0x69,0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79, +0x20,0x77,0x72,0x69,0x74,0x74,0x65,0x6e,0x20,0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a, +0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a, +0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61, +0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x41,0x64,0x61,0x6d,0x20, +0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66, +0x20,0x74,0x68,0x65,0x20,0x53,0x77,0x65,0x64,0x69,0x73,0x68,0x20,0x49,0x6e,0x73, +0x74,0x69,0x74,0x75,0x74,0x65,0x20,0x6f,0x66,0x20,0x43,0x6f,0x6d,0x70,0x75,0x74, +0x65,0x72,0x20,0x53,0x63,0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62, +0x75,0x74,0x20,0x6e,0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20, +0x62,0x65,0x69,0x6e,0x67,0x20,0x61,0x63,0x74,0x69,0x76,0x65,0x6c,0x79,0x20,0x64, +0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x64,0x20,0x62,0x79,0x20,0x61,0x20,0x74,0x65, +0x61,0x6d,0x20,0x6f,0x66,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x72,0x73, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x64,0x69,0x73,0x74,0x72,0x69,0x62,0x75,0x74, +0x65,0x64,0x20,0x77,0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69,0x64,0x65,0x2e,0x20,0x53, +0x69,0x6e,0x63,0x65,0x20,0x69,0x74,0x27,0x73,0x20,0x72,0x65,0x6c,0x65,0x61,0x73, +0x65,0x2c,0x20,0x6c,0x77,0x49,0x50,0x20,0x68,0x61,0x73,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x73,0x70,0x75,0x72,0x72,0x65,0x64,0x20,0x61,0x20,0x6c,0x6f,0x74,0x20, +0x6f,0x66,0x20,0x69,0x6e,0x74,0x65,0x72,0x65,0x73,0x74,0x20,0x61,0x6e,0x64,0x20, +0x68,0x61,0x73,0x20,0x62,0x65,0x65,0x6e,0x20,0x70,0x6f,0x72,0x74,0x65,0x64,0x20, +0x74,0x6f,0x20,0x73,0x65,0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x70,0x6c,0x61,0x74,0x66,0x6f,0x72,0x6d,0x73,0x20,0x61,0x6e,0x64,0x20,0x6f, +0x70,0x65,0x72,0x61,0x74,0x69,0x6e,0x67,0x20,0x73,0x79,0x73,0x74,0x65,0x6d,0x73, +0x2e,0x20,0x6c,0x77,0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65,0x20,0x75,0x73, +0x65,0x64,0x20,0x65,0x69,0x74,0x68,0x65,0x72,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20, +0x77,0x69,0x74,0x68,0x20,0x6f,0x72,0x20,0x77,0x69,0x74,0x68,0x6f,0x75,0x74,0x20, +0x61,0x6e,0x20,0x75,0x6e,0x64,0x65,0x72,0x6c,0x79,0x69,0x6e,0x67,0x20,0x4f,0x53, +0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c, +0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6c,0x77,0x49,0x50,0x20,0x69,0x73, +0x20,0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f,0x75,0x72,0x63,0x65,0x20, +0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f, +0x66,0x20,0x74,0x68,0x65,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20,0x73,0x75,0x69,0x74, +0x65,0x20,0x74,0x68,0x61,0x74,0x20,0x77,0x61,0x73,0x20,0x6f,0x72,0x69,0x67,0x69, +0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77,0x72,0x69,0x74,0x74,0x65,0x6e,0x20,0x62,0x79, +0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22, +0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e, +0x73,0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e, +0x41,0x64,0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x53,0x77,0x65,0x64,0x69,0x73, +0x68,0x20,0x49,0x6e,0x73,0x74,0x69,0x74,0x75,0x74,0x65,0x20,0x6f,0x66,0x20,0x43, +0x6f,0x6d,0x70,0x75,0x74,0x65,0x72,0x20,0x53,0x63,0x69,0x65,0x6e,0x63,0x65,0x3c, +0x2f,0x61,0x3e,0x20,0x62,0x75,0x74,0x20,0x6e,0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a, +0x09,0x20,0x20,0x20,0x20,0x62,0x65,0x69,0x6e,0x67,0x20,0x61,0x63,0x74,0x69,0x76, +0x65,0x6c,0x79,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x64,0x20,0x62,0x79, +0x20,0x61,0x20,0x74,0x65,0x61,0x6d,0x20,0x6f,0x66,0x20,0x64,0x65,0x76,0x65,0x6c, +0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x64,0x69,0x73,0x74, +0x72,0x69,0x62,0x75,0x74,0x65,0x64,0x20,0x77,0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69, +0x64,0x65,0x2e,0x20,0x53,0x69,0x6e,0x63,0x65,0x20,0x69,0x74,0x27,0x73,0x20,0x72, +0x65,0x6c,0x65,0x61,0x73,0x65,0x2c,0x20,0x6c,0x77,0x49,0x50,0x20,0x68,0x61,0x73, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x70,0x75,0x72,0x72,0x65,0x64,0x20,0x61, +0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20,0x69,0x6e,0x74,0x65,0x72,0x65,0x73,0x74, +0x20,0x61,0x6e,0x64,0x20,0x68,0x61,0x73,0x20,0x62,0x65,0x65,0x6e,0x20,0x70,0x6f, +0x72,0x74,0x65,0x64,0x20,0x74,0x6f,0x20,0x73,0x65,0x76,0x65,0x72,0x61,0x6c,0x0d, +0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x6c,0x61,0x74,0x66,0x6f,0x72,0x6d,0x73,0x20, +0x61,0x6e,0x64,0x20,0x6f,0x70,0x65,0x72,0x61,0x74,0x69,0x6e,0x67,0x20,0x73,0x79, +0x73,0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49,0x50,0x20,0x63,0x61,0x6e,0x20, +0x62,0x65,0x20,0x75,0x73,0x65,0x64,0x20,0x65,0x69,0x74,0x68,0x65,0x72,0x0d,0x0a, +0x09,0x20,0x20,0x20,0x20,0x77,0x69,0x74,0x68,0x20,0x6f,0x72,0x20,0x77,0x69,0x74, +0x68,0x6f,0x75,0x74,0x20,0x61,0x6e,0x20,0x75,0x6e,0x64,0x65,0x72,0x6c,0x79,0x69, +0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d, +0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6c,0x77, +0x49,0x50,0x20,0x69,0x73,0x20,0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f, +0x75,0x72,0x63,0x65,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74, +0x69,0x6f,0x6e,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x54,0x43,0x50,0x2f,0x49, +0x50,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c, +0x20,0x73,0x75,0x69,0x74,0x65,0x20,0x74,0x68,0x61,0x74,0x20,0x77,0x61,0x73,0x20, +0x6f,0x72,0x69,0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77,0x72,0x69,0x74,0x74, +0x65,0x6e,0x20,0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68, +0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e, +0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77, +0x69,0x70,0x2f,0x22,0x3e,0x41,0x64,0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c, +0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x53, +0x77,0x65,0x64,0x69,0x73,0x68,0x20,0x49,0x6e,0x73,0x74,0x69,0x74,0x75,0x74,0x65, +0x20,0x6f,0x66,0x20,0x43,0x6f,0x6d,0x70,0x75,0x74,0x65,0x72,0x20,0x53,0x63,0x69, +0x65,0x6e,0x63,0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75,0x74,0x20,0x6e,0x6f,0x77, +0x20,0x69,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x62,0x65,0x69,0x6e,0x67,0x20, +0x61,0x63,0x74,0x69,0x76,0x65,0x6c,0x79,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70, +0x65,0x64,0x20,0x62,0x79,0x20,0x61,0x20,0x74,0x65,0x61,0x6d,0x20,0x6f,0x66,0x20, +0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x64,0x69,0x73,0x74,0x72,0x69,0x62,0x75,0x74,0x65,0x64,0x20,0x77,0x6f,0x72, +0x6c,0x64,0x2d,0x77,0x69,0x64,0x65,0x2e,0x20,0x53,0x69,0x6e,0x63,0x65,0x20,0x69, +0x74,0x27,0x73,0x20,0x72,0x65,0x6c,0x65,0x61,0x73,0x65,0x2c,0x20,0x6c,0x77,0x49, +0x50,0x20,0x68,0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x70,0x75,0x72, +0x72,0x65,0x64,0x20,0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20,0x69,0x6e,0x74, +0x65,0x72,0x65,0x73,0x74,0x20,0x61,0x6e,0x64,0x20,0x68,0x61,0x73,0x20,0x62,0x65, +0x65,0x6e,0x20,0x70,0x6f,0x72,0x74,0x65,0x64,0x20,0x74,0x6f,0x20,0x73,0x65,0x76, +0x65,0x72,0x61,0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x6c,0x61,0x74,0x66, +0x6f,0x72,0x6d,0x73,0x20,0x61,0x6e,0x64,0x20,0x6f,0x70,0x65,0x72,0x61,0x74,0x69, +0x6e,0x67,0x20,0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49,0x50, +0x20,0x63,0x61,0x6e,0x20,0x62,0x65,0x20,0x75,0x73,0x65,0x64,0x20,0x65,0x69,0x74, +0x68,0x65,0x72,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x77,0x69,0x74,0x68,0x20,0x6f, +0x72,0x20,0x77,0x69,0x74,0x68,0x6f,0x75,0x74,0x20,0x61,0x6e,0x20,0x75,0x6e,0x64, +0x65,0x72,0x6c,0x79,0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20, +0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x6c,0x77,0x49,0x50,0x20,0x69,0x73,0x20,0x61,0x6e,0x20,0x6f,0x70, +0x65,0x6e,0x20,0x73,0x6f,0x75,0x72,0x63,0x65,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d, +0x65,0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20, +0x54,0x43,0x50,0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x72,0x6f, +0x74,0x6f,0x63,0x6f,0x6c,0x20,0x73,0x75,0x69,0x74,0x65,0x20,0x74,0x68,0x61,0x74, +0x20,0x77,0x61,0x73,0x20,0x6f,0x72,0x69,0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20, +0x77,0x72,0x69,0x74,0x74,0x65,0x6e,0x20,0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f, +0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64, +0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x41,0x64,0x61,0x6d,0x20,0x44, +0x75,0x6e,0x6b,0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20, +0x74,0x68,0x65,0x20,0x53,0x77,0x65,0x64,0x69,0x73,0x68,0x20,0x49,0x6e,0x73,0x74, +0x69,0x74,0x75,0x74,0x65,0x20,0x6f,0x66,0x20,0x43,0x6f,0x6d,0x70,0x75,0x74,0x65, +0x72,0x20,0x53,0x63,0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75, +0x74,0x20,0x6e,0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x62, +0x65,0x69,0x6e,0x67,0x20,0x61,0x63,0x74,0x69,0x76,0x65,0x6c,0x79,0x20,0x64,0x65, +0x76,0x65,0x6c,0x6f,0x70,0x65,0x64,0x20,0x62,0x79,0x20,0x61,0x20,0x74,0x65,0x61, +0x6d,0x20,0x6f,0x66,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d, +0x0a,0x09,0x20,0x20,0x20,0x20,0x64,0x69,0x73,0x74,0x72,0x69,0x62,0x75,0x74,0x65, +0x64,0x20,0x77,0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69,0x64,0x65,0x2e,0x20,0x53,0x69, +0x6e,0x63,0x65,0x20,0x69,0x74,0x27,0x73,0x20,0x72,0x65,0x6c,0x65,0x61,0x73,0x65, +0x2c,0x20,0x6c,0x77,0x49,0x50,0x20,0x68,0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x73,0x70,0x75,0x72,0x72,0x65,0x64,0x20,0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f, +0x66,0x20,0x69,0x6e,0x74,0x65,0x72,0x65,0x73,0x74,0x20,0x61,0x6e,0x64,0x20,0x68, +0x61,0x73,0x20,0x62,0x65,0x65,0x6e,0x20,0x70,0x6f,0x72,0x74,0x65,0x64,0x20,0x74, +0x6f,0x20,0x73,0x65,0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20, +0x70,0x6c,0x61,0x74,0x66,0x6f,0x72,0x6d,0x73,0x20,0x61,0x6e,0x64,0x20,0x6f,0x70, +0x65,0x72,0x61,0x74,0x69,0x6e,0x67,0x20,0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x2e, +0x20,0x6c,0x77,0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65,0x20,0x75,0x73,0x65, +0x64,0x20,0x65,0x69,0x74,0x68,0x65,0x72,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x77, +0x69,0x74,0x68,0x20,0x6f,0x72,0x20,0x77,0x69,0x74,0x68,0x6f,0x75,0x74,0x20,0x61, +0x6e,0x20,0x75,0x6e,0x64,0x65,0x72,0x6c,0x79,0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e, +0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70, +0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6c,0x77,0x49,0x50,0x20,0x69,0x73,0x20, +0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f,0x75,0x72,0x63,0x65,0x20,0x69, +0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66, +0x20,0x74,0x68,0x65,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20,0x73,0x75,0x69,0x74,0x65, +0x20,0x74,0x68,0x61,0x74,0x20,0x77,0x61,0x73,0x20,0x6f,0x72,0x69,0x67,0x69,0x6e, +0x61,0x6c,0x6c,0x79,0x20,0x77,0x72,0x69,0x74,0x74,0x65,0x6e,0x20,0x62,0x79,0x20, +0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68, +0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73, +0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x41, +0x64,0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x53,0x77,0x65,0x64,0x69,0x73,0x68, +0x20,0x49,0x6e,0x73,0x74,0x69,0x74,0x75,0x74,0x65,0x20,0x6f,0x66,0x20,0x43,0x6f, +0x6d,0x70,0x75,0x74,0x65,0x72,0x20,0x53,0x63,0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f, +0x61,0x3e,0x20,0x62,0x75,0x74,0x20,0x6e,0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x62,0x65,0x69,0x6e,0x67,0x20,0x61,0x63,0x74,0x69,0x76,0x65, +0x6c,0x79,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x64,0x20,0x62,0x79,0x20, +0x61,0x20,0x74,0x65,0x61,0x6d,0x20,0x6f,0x66,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f, +0x70,0x65,0x72,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x64,0x69,0x73,0x74,0x72, +0x69,0x62,0x75,0x74,0x65,0x64,0x20,0x77,0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69,0x64, +0x65,0x2e,0x20,0x53,0x69,0x6e,0x63,0x65,0x20,0x69,0x74,0x27,0x73,0x20,0x72,0x65, +0x6c,0x65,0x61,0x73,0x65,0x2c,0x20,0x6c,0x77,0x49,0x50,0x20,0x68,0x61,0x73,0x0d, +0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x70,0x75,0x72,0x72,0x65,0x64,0x20,0x61,0x20, +0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20,0x69,0x6e,0x74,0x65,0x72,0x65,0x73,0x74,0x20, +0x61,0x6e,0x64,0x20,0x68,0x61,0x73,0x20,0x62,0x65,0x65,0x6e,0x20,0x70,0x6f,0x72, +0x74,0x65,0x64,0x20,0x74,0x6f,0x20,0x73,0x65,0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a, +0x09,0x20,0x20,0x20,0x20,0x70,0x6c,0x61,0x74,0x66,0x6f,0x72,0x6d,0x73,0x20,0x61, +0x6e,0x64,0x20,0x6f,0x70,0x65,0x72,0x61,0x74,0x69,0x6e,0x67,0x20,0x73,0x79,0x73, +0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62, +0x65,0x20,0x75,0x73,0x65,0x64,0x20,0x65,0x69,0x74,0x68,0x65,0x72,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x77,0x69,0x74,0x68,0x20,0x6f,0x72,0x20,0x77,0x69,0x74,0x68, +0x6f,0x75,0x74,0x20,0x61,0x6e,0x20,0x75,0x6e,0x64,0x65,0x72,0x6c,0x79,0x69,0x6e, +0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a, +0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6c,0x77,0x49, +0x50,0x20,0x69,0x73,0x20,0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f,0x75, +0x72,0x63,0x65,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69, +0x6f,0x6e,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x54,0x43,0x50,0x2f,0x49,0x50, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20, +0x73,0x75,0x69,0x74,0x65,0x20,0x74,0x68,0x61,0x74,0x20,0x77,0x61,0x73,0x20,0x6f, +0x72,0x69,0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77,0x72,0x69,0x74,0x74,0x65, +0x6e,0x20,0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72, +0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73, +0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69, +0x70,0x2f,0x22,0x3e,0x41,0x64,0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x53,0x77, +0x65,0x64,0x69,0x73,0x68,0x20,0x49,0x6e,0x73,0x74,0x69,0x74,0x75,0x74,0x65,0x20, +0x6f,0x66,0x20,0x43,0x6f,0x6d,0x70,0x75,0x74,0x65,0x72,0x20,0x53,0x63,0x69,0x65, +0x6e,0x63,0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75,0x74,0x20,0x6e,0x6f,0x77,0x20, +0x69,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x62,0x65,0x69,0x6e,0x67,0x20,0x61, +0x63,0x74,0x69,0x76,0x65,0x6c,0x79,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65, +0x64,0x20,0x62,0x79,0x20,0x61,0x20,0x74,0x65,0x61,0x6d,0x20,0x6f,0x66,0x20,0x64, +0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20, +0x64,0x69,0x73,0x74,0x72,0x69,0x62,0x75,0x74,0x65,0x64,0x20,0x77,0x6f,0x72,0x6c, +0x64,0x2d,0x77,0x69,0x64,0x65,0x2e,0x20,0x53,0x69,0x6e,0x63,0x65,0x20,0x69,0x74, +0x27,0x73,0x20,0x72,0x65,0x6c,0x65,0x61,0x73,0x65,0x2c,0x20,0x6c,0x77,0x49,0x50, +0x20,0x68,0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x70,0x75,0x72,0x72, +0x65,0x64,0x20,0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20,0x69,0x6e,0x74,0x65, +0x72,0x65,0x73,0x74,0x20,0x61,0x6e,0x64,0x20,0x68,0x61,0x73,0x20,0x62,0x65,0x65, +0x6e,0x20,0x70,0x6f,0x72,0x74,0x65,0x64,0x20,0x74,0x6f,0x20,0x73,0x65,0x76,0x65, +0x72,0x61,0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x6c,0x61,0x74,0x66,0x6f, +0x72,0x6d,0x73,0x20,0x61,0x6e,0x64,0x20,0x6f,0x70,0x65,0x72,0x61,0x74,0x69,0x6e, +0x67,0x20,0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49,0x50,0x20, +0x63,0x61,0x6e,0x20,0x62,0x65,0x20,0x75,0x73,0x65,0x64,0x20,0x65,0x69,0x74,0x68, +0x65,0x72,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x77,0x69,0x74,0x68,0x20,0x6f,0x72, +0x20,0x77,0x69,0x74,0x68,0x6f,0x75,0x74,0x20,0x61,0x6e,0x20,0x75,0x6e,0x64,0x65, +0x72,0x6c,0x79,0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c, +0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x6c,0x77,0x49,0x50,0x20,0x69,0x73,0x20,0x61,0x6e,0x20,0x6f,0x70,0x65, +0x6e,0x20,0x73,0x6f,0x75,0x72,0x63,0x65,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65, +0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x54, +0x43,0x50,0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x72,0x6f,0x74, +0x6f,0x63,0x6f,0x6c,0x20,0x73,0x75,0x69,0x74,0x65,0x20,0x74,0x68,0x61,0x74,0x20, +0x77,0x61,0x73,0x20,0x6f,0x72,0x69,0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77, +0x72,0x69,0x74,0x74,0x65,0x6e,0x20,0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f, +0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64,0x61, +0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x41,0x64,0x61,0x6d,0x20,0x44,0x75, +0x6e,0x6b,0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x74, +0x68,0x65,0x20,0x53,0x77,0x65,0x64,0x69,0x73,0x68,0x20,0x49,0x6e,0x73,0x74,0x69, +0x74,0x75,0x74,0x65,0x20,0x6f,0x66,0x20,0x43,0x6f,0x6d,0x70,0x75,0x74,0x65,0x72, +0x20,0x53,0x63,0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75,0x74, +0x20,0x6e,0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x62,0x65, +0x69,0x6e,0x67,0x20,0x61,0x63,0x74,0x69,0x76,0x65,0x6c,0x79,0x20,0x64,0x65,0x76, +0x65,0x6c,0x6f,0x70,0x65,0x64,0x20,0x62,0x79,0x20,0x61,0x20,0x74,0x65,0x61,0x6d, +0x20,0x6f,0x66,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a, +0x09,0x20,0x20,0x20,0x20,0x64,0x69,0x73,0x74,0x72,0x69,0x62,0x75,0x74,0x65,0x64, +0x20,0x77,0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69,0x64,0x65,0x2e,0x20,0x53,0x69,0x6e, +0x63,0x65,0x20,0x69,0x74,0x27,0x73,0x20,0x72,0x65,0x6c,0x65,0x61,0x73,0x65,0x2c, +0x20,0x6c,0x77,0x49,0x50,0x20,0x68,0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20, +0x73,0x70,0x75,0x72,0x72,0x65,0x64,0x20,0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66, +0x20,0x69,0x6e,0x74,0x65,0x72,0x65,0x73,0x74,0x20,0x61,0x6e,0x64,0x20,0x68,0x61, +0x73,0x20,0x62,0x65,0x65,0x6e,0x20,0x70,0x6f,0x72,0x74,0x65,0x64,0x20,0x74,0x6f, +0x20,0x73,0x65,0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70, +0x6c,0x61,0x74,0x66,0x6f,0x72,0x6d,0x73,0x20,0x61,0x6e,0x64,0x20,0x6f,0x70,0x65, +0x72,0x61,0x74,0x69,0x6e,0x67,0x20,0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x2e,0x20, +0x6c,0x77,0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65,0x20,0x75,0x73,0x65,0x64, +0x20,0x65,0x69,0x74,0x68,0x65,0x72,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x77,0x69, +0x74,0x68,0x20,0x6f,0x72,0x20,0x77,0x69,0x74,0x68,0x6f,0x75,0x74,0x20,0x61,0x6e, +0x20,0x75,0x6e,0x64,0x65,0x72,0x6c,0x79,0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d, +0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6c,0x77,0x49,0x50,0x20,0x69,0x73,0x20,0x61, +0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f,0x75,0x72,0x63,0x65,0x20,0x69,0x6d, +0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66,0x20, +0x74,0x68,0x65,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20,0x73,0x75,0x69,0x74,0x65,0x20, +0x74,0x68,0x61,0x74,0x20,0x77,0x61,0x73,0x20,0x6f,0x72,0x69,0x67,0x69,0x6e,0x61, +0x6c,0x6c,0x79,0x20,0x77,0x72,0x69,0x74,0x74,0x65,0x6e,0x20,0x62,0x79,0x20,0x3c, +0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74, +0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65, +0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x41,0x64, +0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x53,0x77,0x65,0x64,0x69,0x73,0x68,0x20, +0x49,0x6e,0x73,0x74,0x69,0x74,0x75,0x74,0x65,0x20,0x6f,0x66,0x20,0x43,0x6f,0x6d, +0x70,0x75,0x74,0x65,0x72,0x20,0x53,0x63,0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f,0x61, +0x3e,0x20,0x62,0x75,0x74,0x20,0x6e,0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x62,0x65,0x69,0x6e,0x67,0x20,0x61,0x63,0x74,0x69,0x76,0x65,0x6c, +0x79,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x64,0x20,0x62,0x79,0x20,0x61, +0x20,0x74,0x65,0x61,0x6d,0x20,0x6f,0x66,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70, +0x65,0x72,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x64,0x69,0x73,0x74,0x72,0x69, +0x62,0x75,0x74,0x65,0x64,0x20,0x77,0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69,0x64,0x65, +0x2e,0x20,0x53,0x69,0x6e,0x63,0x65,0x20,0x69,0x74,0x27,0x73,0x20,0x72,0x65,0x6c, +0x65,0x61,0x73,0x65,0x2c,0x20,0x6c,0x77,0x49,0x50,0x20,0x68,0x61,0x73,0x0d,0x0a, +0x09,0x20,0x20,0x20,0x20,0x73,0x70,0x75,0x72,0x72,0x65,0x64,0x20,0x61,0x20,0x6c, +0x6f,0x74,0x20,0x6f,0x66,0x20,0x69,0x6e,0x74,0x65,0x72,0x65,0x73,0x74,0x20,0x61, +0x6e,0x64,0x20,0x68,0x61,0x73,0x20,0x62,0x65,0x65,0x6e,0x20,0x70,0x6f,0x72,0x74, +0x65,0x64,0x20,0x74,0x6f,0x20,0x73,0x65,0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x70,0x6c,0x61,0x74,0x66,0x6f,0x72,0x6d,0x73,0x20,0x61,0x6e, +0x64,0x20,0x6f,0x70,0x65,0x72,0x61,0x74,0x69,0x6e,0x67,0x20,0x73,0x79,0x73,0x74, +0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65, +0x20,0x75,0x73,0x65,0x64,0x20,0x65,0x69,0x74,0x68,0x65,0x72,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x77,0x69,0x74,0x68,0x20,0x6f,0x72,0x20,0x77,0x69,0x74,0x68,0x6f, +0x75,0x74,0x20,0x61,0x6e,0x20,0x75,0x6e,0x64,0x65,0x72,0x6c,0x79,0x69,0x6e,0x67, +0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09, +0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6c,0x77,0x49,0x50, +0x20,0x69,0x73,0x20,0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f,0x75,0x72, +0x63,0x65,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69,0x6f, +0x6e,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x0d, +0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20,0x73, +0x75,0x69,0x74,0x65,0x20,0x74,0x68,0x61,0x74,0x20,0x77,0x61,0x73,0x20,0x6f,0x72, +0x69,0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77,0x72,0x69,0x74,0x74,0x65,0x6e, +0x20,0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65, +0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69, +0x63,0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70, +0x2f,0x22,0x3e,0x41,0x64,0x61,0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73,0x0d, +0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x53,0x77,0x65, +0x64,0x69,0x73,0x68,0x20,0x49,0x6e,0x73,0x74,0x69,0x74,0x75,0x74,0x65,0x20,0x6f, +0x66,0x20,0x43,0x6f,0x6d,0x70,0x75,0x74,0x65,0x72,0x20,0x53,0x63,0x69,0x65,0x6e, +0x63,0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75,0x74,0x20,0x6e,0x6f,0x77,0x20,0x69, +0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x62,0x65,0x69,0x6e,0x67,0x20,0x61,0x63, +0x74,0x69,0x76,0x65,0x6c,0x79,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x64, +0x20,0x62,0x79,0x20,0x61,0x20,0x74,0x65,0x61,0x6d,0x20,0x6f,0x66,0x20,0x64,0x65, +0x76,0x65,0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x64, +0x69,0x73,0x74,0x72,0x69,0x62,0x75,0x74,0x65,0x64,0x20,0x77,0x6f,0x72,0x6c,0x64, +0x2d,0x77,0x69,0x64,0x65,0x2e,0x20,0x53,0x69,0x6e,0x63,0x65,0x20,0x69,0x74,0x27, +0x73,0x20,0x72,0x65,0x6c,0x65,0x61,0x73,0x65,0x2c,0x20,0x6c,0x77,0x49,0x50,0x20, +0x68,0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73,0x70,0x75,0x72,0x72,0x65, +0x64,0x20,0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20,0x69,0x6e,0x74,0x65,0x72, +0x65,0x73,0x74,0x20,0x61,0x6e,0x64,0x20,0x68,0x61,0x73,0x20,0x62,0x65,0x65,0x6e, +0x20,0x70,0x6f,0x72,0x74,0x65,0x64,0x20,0x74,0x6f,0x20,0x73,0x65,0x76,0x65,0x72, +0x61,0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x6c,0x61,0x74,0x66,0x6f,0x72, +0x6d,0x73,0x20,0x61,0x6e,0x64,0x20,0x6f,0x70,0x65,0x72,0x61,0x74,0x69,0x6e,0x67, +0x20,0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49,0x50,0x20,0x63, +0x61,0x6e,0x20,0x62,0x65,0x20,0x75,0x73,0x65,0x64,0x20,0x65,0x69,0x74,0x68,0x65, +0x72,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x77,0x69,0x74,0x68,0x20,0x6f,0x72,0x20, +0x77,0x69,0x74,0x68,0x6f,0x75,0x74,0x20,0x61,0x6e,0x20,0x75,0x6e,0x64,0x65,0x72, +0x6c,0x79,0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f, +0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x6c,0x77,0x49,0x50,0x20,0x69,0x73,0x20,0x61,0x6e,0x20,0x6f,0x70,0x65,0x6e, +0x20,0x73,0x6f,0x75,0x72,0x63,0x65,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e, +0x74,0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x54,0x43, +0x50,0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x72,0x6f,0x74,0x6f, +0x63,0x6f,0x6c,0x20,0x73,0x75,0x69,0x74,0x65,0x20,0x74,0x68,0x61,0x74,0x20,0x77, +0x61,0x73,0x20,0x6f,0x72,0x69,0x67,0x69,0x6e,0x61,0x6c,0x6c,0x79,0x20,0x77,0x72, +0x69,0x74,0x74,0x65,0x6e,0x20,0x62,0x79,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x77, +0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f,0x7e,0x61,0x64,0x61,0x6d, +0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x41,0x64,0x61,0x6d,0x20,0x44,0x75,0x6e, +0x6b,0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x74,0x68, +0x65,0x20,0x53,0x77,0x65,0x64,0x69,0x73,0x68,0x20,0x49,0x6e,0x73,0x74,0x69,0x74, +0x75,0x74,0x65,0x20,0x6f,0x66,0x20,0x43,0x6f,0x6d,0x70,0x75,0x74,0x65,0x72,0x20, +0x53,0x63,0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f,0x61,0x3e,0x20,0x62,0x75,0x74,0x20, +0x6e,0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x62,0x65,0x69, +0x6e,0x67,0x20,0x61,0x63,0x74,0x69,0x76,0x65,0x6c,0x79,0x20,0x64,0x65,0x76,0x65, +0x6c,0x6f,0x70,0x65,0x64,0x20,0x62,0x79,0x20,0x61,0x20,0x74,0x65,0x61,0x6d,0x20, +0x6f,0x66,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x72,0x73,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x64,0x69,0x73,0x74,0x72,0x69,0x62,0x75,0x74,0x65,0x64,0x20, +0x77,0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69,0x64,0x65,0x2e,0x20,0x53,0x69,0x6e,0x63, +0x65,0x20,0x69,0x74,0x27,0x73,0x20,0x72,0x65,0x6c,0x65,0x61,0x73,0x65,0x2c,0x20, +0x6c,0x77,0x49,0x50,0x20,0x68,0x61,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x73, +0x70,0x75,0x72,0x72,0x65,0x64,0x20,0x61,0x20,0x6c,0x6f,0x74,0x20,0x6f,0x66,0x20, +0x69,0x6e,0x74,0x65,0x72,0x65,0x73,0x74,0x20,0x61,0x6e,0x64,0x20,0x68,0x61,0x73, +0x20,0x62,0x65,0x65,0x6e,0x20,0x70,0x6f,0x72,0x74,0x65,0x64,0x20,0x74,0x6f,0x20, +0x73,0x65,0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x70,0x6c, +0x61,0x74,0x66,0x6f,0x72,0x6d,0x73,0x20,0x61,0x6e,0x64,0x20,0x6f,0x70,0x65,0x72, +0x61,0x74,0x69,0x6e,0x67,0x20,0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x2e,0x20,0x6c, +0x77,0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65,0x20,0x75,0x73,0x65,0x64,0x20, +0x65,0x69,0x74,0x68,0x65,0x72,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x77,0x69,0x74, +0x68,0x20,0x6f,0x72,0x20,0x77,0x69,0x74,0x68,0x6f,0x75,0x74,0x20,0x61,0x6e,0x20, +0x75,0x6e,0x64,0x65,0x72,0x6c,0x79,0x69,0x6e,0x67,0x20,0x4f,0x53,0x2e,0x0d,0x0a, +0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x70,0x3e,0x0d, +0x0a,0x09,0x20,0x20,0x20,0x20,0x6c,0x77,0x49,0x50,0x20,0x69,0x73,0x20,0x61,0x6e, +0x20,0x6f,0x70,0x65,0x6e,0x20,0x73,0x6f,0x75,0x72,0x63,0x65,0x20,0x69,0x6d,0x70, +0x6c,0x65,0x6d,0x65,0x6e,0x74,0x61,0x74,0x69,0x6f,0x6e,0x20,0x6f,0x66,0x20,0x74, +0x68,0x65,0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20, +0x70,0x72,0x6f,0x74,0x6f,0x63,0x6f,0x6c,0x20,0x73,0x75,0x69,0x74,0x65,0x20,0x74, +0x68,0x61,0x74,0x20,0x77,0x61,0x73,0x20,0x6f,0x72,0x69,0x67,0x69,0x6e,0x61,0x6c, +0x6c,0x79,0x20,0x77,0x72,0x69,0x74,0x74,0x65,0x6e,0x20,0x62,0x79,0x20,0x3c,0x61, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74, +0x70,0x3a,0x2f,0x2f,0x77,0x77,0x77,0x2e,0x73,0x69,0x63,0x73,0x2e,0x73,0x65,0x2f, +0x7e,0x61,0x64,0x61,0x6d,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x41,0x64,0x61, +0x6d,0x20,0x44,0x75,0x6e,0x6b,0x65,0x6c,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20, +0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x53,0x77,0x65,0x64,0x69,0x73,0x68,0x20,0x49, +0x6e,0x73,0x74,0x69,0x74,0x75,0x74,0x65,0x20,0x6f,0x66,0x20,0x43,0x6f,0x6d,0x70, +0x75,0x74,0x65,0x72,0x20,0x53,0x63,0x69,0x65,0x6e,0x63,0x65,0x3c,0x2f,0x61,0x3e, +0x20,0x62,0x75,0x74,0x20,0x6e,0x6f,0x77,0x20,0x69,0x73,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x62,0x65,0x69,0x6e,0x67,0x20,0x61,0x63,0x74,0x69,0x76,0x65,0x6c,0x79, +0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65,0x64,0x20,0x62,0x79,0x20,0x61,0x20, +0x74,0x65,0x61,0x6d,0x20,0x6f,0x66,0x20,0x64,0x65,0x76,0x65,0x6c,0x6f,0x70,0x65, +0x72,0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x64,0x69,0x73,0x74,0x72,0x69,0x62, +0x75,0x74,0x65,0x64,0x20,0x77,0x6f,0x72,0x6c,0x64,0x2d,0x77,0x69,0x64,0x65,0x2e, +0x20,0x53,0x69,0x6e,0x63,0x65,0x20,0x69,0x74,0x27,0x73,0x20,0x72,0x65,0x6c,0x65, +0x61,0x73,0x65,0x2c,0x20,0x6c,0x77,0x49,0x50,0x20,0x68,0x61,0x73,0x0d,0x0a,0x09, +0x20,0x20,0x20,0x20,0x73,0x70,0x75,0x72,0x72,0x65,0x64,0x20,0x61,0x20,0x6c,0x6f, +0x74,0x20,0x6f,0x66,0x20,0x69,0x6e,0x74,0x65,0x72,0x65,0x73,0x74,0x20,0x61,0x6e, +0x64,0x20,0x68,0x61,0x73,0x20,0x62,0x65,0x65,0x6e,0x20,0x70,0x6f,0x72,0x74,0x65, +0x64,0x20,0x74,0x6f,0x20,0x73,0x65,0x76,0x65,0x72,0x61,0x6c,0x0d,0x0a,0x09,0x20, +0x20,0x20,0x20,0x70,0x6c,0x61,0x74,0x66,0x6f,0x72,0x6d,0x73,0x20,0x61,0x6e,0x64, +0x20,0x6f,0x70,0x65,0x72,0x61,0x74,0x69,0x6e,0x67,0x20,0x73,0x79,0x73,0x74,0x65, +0x6d,0x73,0x2e,0x20,0x6c,0x77,0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65,0x20, +0x75,0x73,0x65,0x64,0x20,0x65,0x69,0x74,0x68,0x65,0x72,0x0d,0x0a,0x09,0x20,0x20, +0x20,0x20,0x77,0x69,0x74,0x68,0x20,0x6f,0x72,0x20,0x77,0x69,0x74,0x68,0x6f,0x75, +0x74,0x20,0x61,0x6e,0x20,0x75,0x6e,0x64,0x65,0x72,0x6c,0x79,0x69,0x6e,0x67,0x20, +0x4f,0x53,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x20, +0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x54,0x68,0x65,0x20,0x66, +0x6f,0x63,0x75,0x73,0x20,0x6f,0x66,0x20,0x74,0x68,0x65,0x20,0x6c,0x77,0x49,0x50, +0x20,0x54,0x43,0x50,0x2f,0x49,0x50,0x20,0x69,0x6d,0x70,0x6c,0x65,0x6d,0x65,0x6e, +0x74,0x61,0x74,0x69,0x6f,0x6e,0x20,0x69,0x73,0x20,0x74,0x6f,0x20,0x72,0x65,0x64, +0x75,0x63,0x65,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x74,0x68,0x65,0x20,0x52,0x41, +0x4d,0x20,0x75,0x73,0x61,0x67,0x65,0x20,0x77,0x68,0x69,0x6c,0x65,0x20,0x73,0x74, +0x69,0x6c,0x6c,0x20,0x68,0x61,0x76,0x69,0x6e,0x67,0x20,0x61,0x20,0x66,0x75,0x6c, +0x6c,0x20,0x73,0x63,0x61,0x6c,0x65,0x20,0x54,0x43,0x50,0x2e,0x20,0x54,0x68,0x69, +0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6d,0x61,0x6b,0x65,0x73,0x20,0x6c,0x77, +0x49,0x50,0x20,0x73,0x75,0x69,0x74,0x61,0x62,0x6c,0x65,0x20,0x66,0x6f,0x72,0x20, +0x75,0x73,0x65,0x20,0x69,0x6e,0x20,0x65,0x6d,0x62,0x65,0x64,0x64,0x65,0x64,0x20, +0x73,0x79,0x73,0x74,0x65,0x6d,0x73,0x20,0x77,0x69,0x74,0x68,0x20,0x74,0x65,0x6e, +0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x6b,0x69,0x6c,0x6f,0x62, +0x79,0x74,0x65,0x73,0x20,0x6f,0x66,0x20,0x66,0x72,0x65,0x65,0x20,0x52,0x41,0x4d, +0x20,0x61,0x6e,0x64,0x20,0x72,0x6f,0x6f,0x6d,0x20,0x66,0x6f,0x72,0x20,0x61,0x72, +0x6f,0x75,0x6e,0x64,0x20,0x34,0x30,0x20,0x6b,0x69,0x6c,0x6f,0x62,0x79,0x74,0x65, +0x73,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x6f,0x66,0x20,0x63,0x6f,0x64,0x65,0x20, +0x52,0x4f,0x4d,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c,0x2f,0x70,0x3e,0x0d,0x0a,0x09, +0x20,0x20,0x3c,0x70,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x4d,0x6f,0x72,0x65, +0x20,0x69,0x6e,0x66,0x6f,0x72,0x6d,0x61,0x74,0x69,0x6f,0x6e,0x20,0x61,0x62,0x6f, +0x75,0x74,0x20,0x6c,0x77,0x49,0x50,0x20,0x63,0x61,0x6e,0x20,0x62,0x65,0x20,0x66, +0x6f,0x75,0x6e,0x64,0x20,0x61,0x74,0x20,0x74,0x68,0x65,0x20,0x6c,0x77,0x49,0x50, +0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x6f,0x6d,0x65,0x70,0x61,0x67,0x65,0x20, +0x61,0x74,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20,0x20,0x68,0x72,0x65,0x66, +0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x73,0x61,0x76,0x61,0x6e,0x6e,0x61, +0x68,0x2e,0x6e,0x6f,0x6e,0x67,0x6e,0x75,0x2e,0x6f,0x72,0x67,0x2f,0x70,0x72,0x6f, +0x6a,0x65,0x63,0x74,0x73,0x2f,0x6c,0x77,0x69,0x70,0x2f,0x22,0x3e,0x68,0x74,0x74, +0x70,0x3a,0x2f,0x2f,0x73,0x61,0x76,0x61,0x6e,0x6e,0x61,0x68,0x2e,0x6e,0x6f,0x6e, +0x67,0x6e,0x75,0x2e,0x6f,0x72,0x67,0x2f,0x70,0x72,0x6f,0x6a,0x65,0x63,0x74,0x73, +0x2f,0x6c,0x77,0x69,0x70,0x2f,0x3c,0x2f,0x61,0x3e,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x6f,0x72,0x20,0x61,0x74,0x20,0x74,0x68,0x65,0x20,0x6c,0x77,0x49,0x50,0x20, +0x77,0x69,0x6b,0x69,0x20,0x61,0x74,0x20,0x3c,0x61,0x0d,0x0a,0x09,0x20,0x20,0x20, +0x20,0x68,0x72,0x65,0x66,0x3d,0x22,0x68,0x74,0x74,0x70,0x3a,0x2f,0x2f,0x6c,0x77, +0x69,0x70,0x2e,0x77,0x69,0x6b,0x69,0x61,0x2e,0x63,0x6f,0x6d,0x2f,0x22,0x3e,0x68, +0x74,0x74,0x70,0x3a,0x2f,0x2f,0x6c,0x77,0x69,0x70,0x2e,0x77,0x69,0x6b,0x69,0x61, +0x2e,0x63,0x6f,0x6d,0x2f,0x3c,0x2f,0x61,0x3e,0x2e,0x0d,0x0a,0x09,0x20,0x20,0x3c, +0x2f,0x70,0x3e,0x0d,0x0a,0x09,0x3c,0x2f,0x74,0x64,0x3e,0x3c,0x74,0x64,0x3e,0x0d, +0x0a,0x09,0x20,0x20,0x26,0x6e,0x62,0x73,0x70,0x3b,0x0d,0x0a,0x09,0x3c,0x2f,0x74, +0x64,0x3e,0x3c,0x2f,0x74,0x72,0x3e,0x0d,0x0a,0x20,0x20,0x20,0x20,0x20,0x20,0x3c, +0x2f,0x74,0x61,0x62,0x6c,0x65,0x3e,0x0d,0x0a,0x3c,0x2f,0x62,0x6f,0x64,0x79,0x3e, +0x0d,0x0a,0x3c,0x2f,0x68,0x74,0x6d,0x6c,0x3e,0x0d,0x0a,0x0d,0x0a,}; + + + +const struct fsdata_file file__img_sics_gif[] = { { +file_NULL, +data__img_sics_gif, +data__img_sics_gif + 16, +sizeof(data__img_sics_gif) - 16, +FS_FILE_FLAGS_HEADER_INCLUDED | FS_FILE_FLAGS_HEADER_PERSISTENT | FS_FILE_FLAGS_HEADER_HTTPVER_1_1, +}}; + +const struct fsdata_file file__404_html[] = { { +file__img_sics_gif, +data__404_html, +data__404_html + 12, +sizeof(data__404_html) - 12, +FS_FILE_FLAGS_HEADER_INCLUDED | FS_FILE_FLAGS_HEADER_PERSISTENT | FS_FILE_FLAGS_HEADER_HTTPVER_1_1, +}}; + +const struct fsdata_file file__index_html[] = { { +file__404_html, +data__index_html, +data__index_html + 12, +sizeof(data__index_html) - 12, +FS_FILE_FLAGS_HEADER_INCLUDED | FS_FILE_FLAGS_HEADER_PERSISTENT | FS_FILE_FLAGS_HEADER_HTTPVER_1_1, +}}; + +const struct fsdata_file file__login_html[] = { { +file__index_html, +data__login_html, +data__login_html + 12, +sizeof(data__login_html) - 12, +FS_FILE_FLAGS_HEADER_INCLUDED | FS_FILE_FLAGS_HEADER_PERSISTENT | FS_FILE_FLAGS_HEADER_HTTPVER_1_1, +}}; + +const struct fsdata_file file__loginfail_html[] = { { +file__login_html, +data__loginfail_html, +data__loginfail_html + 16, +sizeof(data__loginfail_html) - 16, +FS_FILE_FLAGS_HEADER_INCLUDED | FS_FILE_FLAGS_HEADER_PERSISTENT | FS_FILE_FLAGS_HEADER_HTTPVER_1_1, +}}; + +const struct fsdata_file file__session_html[] = { { +file__loginfail_html, +data__session_html, +data__session_html + 16, +sizeof(data__session_html) - 16, +FS_FILE_FLAGS_HEADER_INCLUDED | FS_FILE_FLAGS_HEADER_PERSISTENT | FS_FILE_FLAGS_HEADER_HTTPVER_1_1, +}}; + +const struct fsdata_file file__ssi_shtml[] = { { +file__session_html, +data__ssi_shtml, +data__ssi_shtml + 12, +sizeof(data__ssi_shtml) - 12, +FS_FILE_FLAGS_HEADER_INCLUDED | FS_FILE_FLAGS_SSI, +}}; + +#define FS_ROOT file__ssi_shtml +#define FS_NUMFILES 7 + diff --git a/contrib/examples/httpd/fs_example/fs_example.c b/contrib/examples/httpd/fs_example/fs_example.c new file mode 100644 index 00000000000..e3552b12ea8 --- /dev/null +++ b/contrib/examples/httpd/fs_example/fs_example.c @@ -0,0 +1,324 @@ +/** + * @file + * HTTPD custom file system example + * + * This file demonstrates how to add support for an external file system to httpd. + * It provides access to the specified root directory and uses stdio.h file functions + * to read files. + * + * ATTENTION: This implementation is *not* secure: no checks are added to ensure + * files are only read below the specified root directory! + */ + + /* + * Copyright (c) 2017 Simon Goldschmidt + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Simon Goldschmidt goldsimon@gmx.de + * + */ + +#include "lwip/opt.h" +#include "fs_example.h" + +#include "lwip/apps/fs.h" +#include "lwip/def.h" +#include "lwip/mem.h" + +#include <stdio.h> +#include <string.h> + +/** define LWIP_HTTPD_EXAMPLE_CUSTOMFILES to 1 to enable this file system */ +#ifndef LWIP_HTTPD_EXAMPLE_CUSTOMFILES +#define LWIP_HTTPD_EXAMPLE_CUSTOMFILES 0 +#endif + +/** define LWIP_HTTPD_EXAMPLE_CUSTOMFILES_DELAYED to 1 to delay open and read + * as if e.g. reading from external SPI flash */ +#ifndef LWIP_HTTPD_EXAMPLE_CUSTOMFILES_DELAYED +#define LWIP_HTTPD_EXAMPLE_CUSTOMFILES_DELAYED 1 +#endif + +/** define LWIP_HTTPD_EXAMPLE_CUSTOMFILES_LIMIT_READ to the number of bytes + * to read to emulate limited transfer buffers and don't read whole files in + * one chunk. + * WARNING: lowering this slows down the connection! + */ +#ifndef LWIP_HTTPD_EXAMPLE_CUSTOMFILES_LIMIT_READ +#define LWIP_HTTPD_EXAMPLE_CUSTOMFILES_LIMIT_READ 0 +#endif + +#if LWIP_HTTPD_EXAMPLE_CUSTOMFILES + +#if !LWIP_HTTPD_CUSTOM_FILES +#error This needs LWIP_HTTPD_CUSTOM_FILES +#endif +#if !LWIP_HTTPD_DYNAMIC_HEADERS +#error This needs LWIP_HTTPD_DYNAMIC_HEADERS +#endif +#if !LWIP_HTTPD_DYNAMIC_FILE_READ +#error This wants to demonstrate read-after-open, so LWIP_HTTPD_DYNAMIC_FILE_READ is required! +#endif +#if !LWIP_HTTPD_FS_ASYNC_READ +#error This needs LWIP_HTTPD_FS_ASYNC_READ +#endif +#if !LWIP_HTTPD_FILE_EXTENSION +#error This needs LWIP_HTTPD_FILE_EXTENSION +#endif + +#if LWIP_HTTPD_EXAMPLE_CUSTOMFILES_DELAYED +#include "lwip/tcpip.h" +#endif + +struct fs_custom_data { + FILE *f; +#if LWIP_HTTPD_EXAMPLE_CUSTOMFILES_DELAYED + int delay_read; + fs_wait_cb callback_fn; + void *callback_arg; +#endif +}; + +const char* fs_ex_root_dir; + +void +fs_ex_init(const char *httpd_root_dir) +{ + fs_ex_root_dir = strdup(httpd_root_dir); +} + +#if LWIP_HTTPD_CUSTOM_FILES +int +fs_open_custom(struct fs_file *file, const char *name) +{ + char full_filename[256]; + FILE *f; + + snprintf(full_filename, 255, "%s%s", fs_ex_root_dir, name); + full_filename[255] = 0; + + f = fopen(full_filename, "rb"); + if (f != NULL) { + if (!fseek(f, 0, SEEK_END)) { + int len = (int)ftell(f); + if(!fseek(f, 0, SEEK_SET)) { + struct fs_custom_data *data = (struct fs_custom_data *)mem_malloc(sizeof(struct fs_custom_data)); + LWIP_ASSERT("out of memory?", data != NULL); + memset(file, 0, sizeof(struct fs_file)); +#if LWIP_HTTPD_EXAMPLE_CUSTOMFILES_DELAYED + file->len = 0; /* read size delayed */ + data->delay_read = 3; + LWIP_UNUSED_ARG(len); +#else + file->len = len; +#endif + file->flags = FS_FILE_FLAGS_HEADER_PERSISTENT; + data->f = f; + file->pextension = data; + return 1; + } + } + fclose(f); + } + return 0; +} + +void +fs_close_custom(struct fs_file *file) +{ + if (file && file->pextension) { + struct fs_custom_data *data = (struct fs_custom_data *)file->pextension; + if (data->f != NULL) { + fclose(data->f); + data->f = NULL; + } + mem_free(data); + } +} + +#if LWIP_HTTPD_FS_ASYNC_READ +u8_t +fs_canread_custom(struct fs_file *file) +{ + /* This function is only necessary for asynchronous I/O: + If reading would block, return 0 and implement fs_wait_read_custom() to call the + supplied callback if reading works. */ +#if LWIP_HTTPD_EXAMPLE_CUSTOMFILES_DELAYED + struct fs_custom_data *data; + LWIP_ASSERT("file != NULL", file != NULL); + data = (struct fs_custom_data *)file->pextension; + if (data == NULL) { + /* file transfer has been completed already */ + LWIP_ASSERT("transfer complete", file->index == file->len); + return 1; + } + LWIP_ASSERT("data != NULL", data != NULL); + /* This just simulates a simple delay. This delay would normally come e.g. from SPI transfer */ + if (data->delay_read == 3) { + /* delayed file size mode */ + data->delay_read = 1; + LWIP_ASSERT("", file->len == 0); + if (!fseek(data->f, 0, SEEK_END)) { + int len = (int)ftell(data->f); + if(!fseek(data->f, 0, SEEK_SET)) { + file->len = len; /* read size delayed */ + data->delay_read = 1; + return 0; + } + } + /* if we come here, something is wrong with the file */ + LWIP_ASSERT("file error", 0); + } + if (data->delay_read == 1) { + /* tell read function to delay further */ + } +#endif + LWIP_UNUSED_ARG(file); + return 1; +} + +#if LWIP_HTTPD_EXAMPLE_CUSTOMFILES_DELAYED +static void +fs_example_read_cb(void *arg) +{ + struct fs_custom_data *data = (struct fs_custom_data *)arg; + fs_wait_cb callback_fn = data->callback_fn; + void *callback_arg = data->callback_arg; + data->callback_fn = NULL; + data->callback_arg = NULL; + + LWIP_ASSERT("no callback_fn", callback_fn != NULL); + + callback_fn(callback_arg); +} +#endif + +u8_t +fs_wait_read_custom(struct fs_file *file, fs_wait_cb callback_fn, void *callback_arg) +{ +#if LWIP_HTTPD_EXAMPLE_CUSTOMFILES_DELAYED + err_t err; + struct fs_custom_data *data = (struct fs_custom_data *)file->pextension; + LWIP_ASSERT("data not set", data != NULL); + data->callback_fn = callback_fn; + data->callback_arg = callback_arg; + err = tcpip_try_callback(fs_example_read_cb, data); + LWIP_ASSERT("out of queue elements?", err == ERR_OK); + LWIP_UNUSED_ARG(err); +#else + LWIP_ASSERT("not implemented in this example configuration", 0); +#endif + LWIP_UNUSED_ARG(file); + LWIP_UNUSED_ARG(callback_fn); + LWIP_UNUSED_ARG(callback_arg); + /* Return + - 0 if ready to read (at least one byte) + - 1 if reading should be delayed (call 'tcpip_callback(callback_fn, callback_arg)' when ready) */ + return 1; +} + +int +fs_read_async_custom(struct fs_file *file, char *buffer, int count, fs_wait_cb callback_fn, void *callback_arg) +{ + struct fs_custom_data *data = (struct fs_custom_data *)file->pextension; + FILE *f; + int len; + int read_count = count; + LWIP_ASSERT("data not set", data != NULL); + +#if LWIP_HTTPD_EXAMPLE_CUSTOMFILES_DELAYED + /* This just simulates a delay. This delay would normally come e.g. from SPI transfer */ + LWIP_ASSERT("invalid state", data->delay_read >= 0 && data->delay_read <= 2); + if (data->delay_read == 2) { + /* no delay next time */ + data->delay_read = 0; + return FS_READ_DELAYED; + } else if (data->delay_read == 1) { + err_t err; + /* execute requested delay */ + data->delay_read = 2; + LWIP_ASSERT("duplicate callback request", data->callback_fn == NULL); + data->callback_fn = callback_fn; + data->callback_arg = callback_arg; + err = tcpip_try_callback(fs_example_read_cb, data); + LWIP_ASSERT("out of queue elements?", err == ERR_OK); + LWIP_UNUSED_ARG(err); + return FS_READ_DELAYED; + } + /* execute this read but delay the next one */ + data->delay_read = 1; +#endif + +#if LWIP_HTTPD_EXAMPLE_CUSTOMFILES_LIMIT_READ + read_count = LWIP_MIN(read_count, LWIP_HTTPD_EXAMPLE_CUSTOMFILES_LIMIT_READ); +#endif + + f = data->f; + len = (int)fread(buffer, 1, read_count, f); + + LWIP_UNUSED_ARG(callback_fn); + LWIP_UNUSED_ARG(callback_arg); + + file->index += len; + + /* Return + - FS_READ_EOF if all bytes have been read + - FS_READ_DELAYED if reading is delayed (call 'tcpip_callback(callback_fn, callback_arg)' when done) */ + if (len == 0) { + /* all bytes read already */ + return FS_READ_EOF; + } + return len; +} + +#else /* LWIP_HTTPD_FS_ASYNC_READ */ +int +fs_read_custom(struct fs_file *file, char *buffer, int count) +{ + struct fs_custom_data *data = (struct fs_custom_data *)file->pextension; + FILE *f; + int len; + int read_count = count; + LWIP_ASSERT("data not set", data != NULL); + +#if LWIP_HTTPD_EXAMPLE_CUSTOMFILES_LIMIT_READ + read_count = LWIP_MIN(read_count, LWIP_HTTPD_EXAMPLE_CUSTOMFILES_LIMIT_READ); +#endif + + f = data->f; + len = (int)fread(buffer, 1, read_count, f); + + file->index += len; + + /* Return FS_READ_EOF if all bytes have been read */ + return len; +} + +#endif /* LWIP_HTTPD_FS_ASYNC_READ */ +#endif /* LWIP_HTTPD_CUSTOM_FILES */ + +#endif /* LWIP_HTTPD_EXAMPLE_CUSTOMFILES */ diff --git a/contrib/examples/httpd/fs_example/fs_example.h b/contrib/examples/httpd/fs_example/fs_example.h new file mode 100644 index 00000000000..b399e4d5cc7 --- /dev/null +++ b/contrib/examples/httpd/fs_example/fs_example.h @@ -0,0 +1,38 @@ +/* + * Copyright (c) 2017 Simon Goldschmidt + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Simon Goldschmidt goldsimon@gmx.de + * + */ + +#ifndef LWIP_HDR_HTTP_EXAMPLES_FS_EXAMPLE +#define LWIP_HDR_HTTP_EXAMPLES_FS_EXAMPLE + +void fs_ex_init(const char *httpd_root_dir); + +#endif /* LWIP_HDR_HTTP_EXAMPLES_FS_EXAMPLE */ diff --git a/contrib/examples/httpd/genfiles_example/genfiles_example.c b/contrib/examples/httpd/genfiles_example/genfiles_example.c new file mode 100644 index 00000000000..b96df2a7da1 --- /dev/null +++ b/contrib/examples/httpd/genfiles_example/genfiles_example.c @@ -0,0 +1,186 @@ +/** + * @file + * HTTPD custom file system example for runtime generated files + * + * This file demonstrates how to add support for generated files to httpd. + */ + + /* + * Copyright (c) 2017 Simon Goldschmidt + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Simon Goldschmidt goldsimon@gmx.de + * + */ + +#include "lwip/opt.h" +#include "genfiles_example.h" + +#include "lwip/apps/fs.h" +#include "lwip/def.h" +#include "lwip/mem.h" + +#include <stdio.h> +#include <string.h> + +/** define LWIP_HTTPD_EXAMPLE_GENERATEDFILES to 1 to enable this file system */ +#ifndef LWIP_HTTPD_EXAMPLE_GENERATEDFILES +#define LWIP_HTTPD_EXAMPLE_GENERATEDFILES 0 +#endif + +#if LWIP_HTTPD_EXAMPLE_GENERATEDFILES + +#if !LWIP_HTTPD_CUSTOM_FILES +#error This needs LWIP_HTTPD_CUSTOM_FILES +#endif +#if !LWIP_HTTPD_FILE_EXTENSION +#error This needs LWIP_HTTPD_FILE_EXTENSION +#endif +#if !LWIP_HTTPD_DYNAMIC_HEADERS +#error This needs LWIP_HTTPD_DYNAMIC_HEADERS +#endif + +/* This is the page we send. It's not generated, as you see. + * Generating custom things instead of memcpy is left to your imagination :-) + */ +const char generated_html[] = +"<html>\n" +"<head><title>lwIP - A Lightweight TCP/IP Stack</title></head>\n" +" <body bgcolor="white" text="black">\n" +" <table width="100%">\n" +" <tr valign="top">\n" +" <td width="80">\n" +" <a href="http://www.sics.se/%5C%22%3E<img src="/img/sics.gif"\n" +" border="0" alt="SICS logo" title="SICS logo"></a>\n" +" </td>\n" +" <td width="500">\n" +" <h1>lwIP - A Lightweight TCP/IP Stack</h1>\n" +" <h2>Generated page</h2>\n" +" <p>This page might be generated in-memory at runtime</p>\n" +" </td>\n" +" <td>\n" +" \n" +" </td>\n" +" </tr>\n" +" </table>\n" +" </body>\n" +"</html>"; + + +void +genfiles_ex_init(void) +{ + /* nothing to do here yet */ +} + +int +fs_open_custom(struct fs_file *file, const char *name) +{ + /* this example only provides one file */ + if (!strcmp(name, "/generated.html")) { + /* initialize fs_file correctly */ + memset(file, 0, sizeof(struct fs_file)); + file->pextension = mem_malloc(sizeof(generated_html)); + if (file->pextension != NULL) { + /* instead of doing memcpy, you would generate e.g. a JSON here */ + memcpy(file->pextension, generated_html, sizeof(generated_html)); + file->data = (const char *)file->pextension; + file->len = sizeof(generated_html) - 1; /* don't send the trailing 0 */ + file->index = file->len; + /* allow persisteng connections */ + file->flags = FS_FILE_FLAGS_HEADER_PERSISTENT; + return 1; + } + } + return 0; +} + +void +fs_close_custom(struct fs_file *file) +{ + if (file && file->pextension) { + mem_free(file->pextension); + file->pextension = NULL; + } +} + +#if LWIP_HTTPD_FS_ASYNC_READ +u8_t +fs_canread_custom(struct fs_file *file) +{ + LWIP_UNUSED_ARG(file); + /* This example does not use delayed/async reading */ + return 1; +} + +u8_t +fs_wait_read_custom(struct fs_file *file, fs_wait_cb callback_fn, void *callback_arg) +{ + LWIP_ASSERT("not implemented in this example configuration", 0); + LWIP_UNUSED_ARG(file); + LWIP_UNUSED_ARG(callback_fn); + LWIP_UNUSED_ARG(callback_arg); + /* Return + - 1 if ready to read (at least one byte) + - 0 if reading should be delayed (call 'tcpip_callback(callback_fn, callback_arg)' when ready) */ + return 1; +} + +int +fs_read_async_custom(struct fs_file *file, char *buffer, int count, fs_wait_cb callback_fn, void *callback_arg) +{ + LWIP_ASSERT("not implemented in this example configuration", 0); + LWIP_UNUSED_ARG(file); + LWIP_UNUSED_ARG(buffer); + LWIP_UNUSED_ARG(count); + LWIP_UNUSED_ARG(callback_fn); + LWIP_UNUSED_ARG(callback_arg); + /* Return + - FS_READ_EOF if all bytes have been read + - FS_READ_DELAYED if reading is delayed (call 'tcpip_callback(callback_fn, callback_arg)' when done) */ + /* all bytes read already */ + return FS_READ_EOF; +} + +#else /* LWIP_HTTPD_FS_ASYNC_READ */ +int +fs_read_custom(struct fs_file *file, char *buffer, int count) +{ + LWIP_ASSERT("not implemented in this example configuration", 0); + LWIP_UNUSED_ARG(file); + LWIP_UNUSED_ARG(buffer); + LWIP_UNUSED_ARG(count); + /* Return + - FS_READ_EOF if all bytes have been read + - FS_READ_DELAYED if reading is delayed (call 'tcpip_callback(callback_fn, callback_arg)' when done) */ + /* all bytes read already */ + return FS_READ_EOF; +} + +#endif /* LWIP_HTTPD_FS_ASYNC_READ */ + +#endif /* LWIP_HTTPD_EXAMPLE_GENERATEDFILES */ diff --git a/contrib/examples/httpd/genfiles_example/genfiles_example.h b/contrib/examples/httpd/genfiles_example/genfiles_example.h new file mode 100644 index 00000000000..dd9731e0737 --- /dev/null +++ b/contrib/examples/httpd/genfiles_example/genfiles_example.h @@ -0,0 +1,38 @@ +/* + * Copyright (c) 2017 Simon Goldschmidt + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Simon Goldschmidt goldsimon@gmx.de + * + */ + +#ifndef LWIP_HDR_HTTP_EXAMPLES_GENFILES_EXAMPLE +#define LWIP_HDR_HTTP_EXAMPLES_GENFILES_EXAMPLE + +void genfiles_ex_init(void); + +#endif /* LWIP_HDR_HTTP_EXAMPLES_GENFILES_EXAMPLE */ diff --git a/contrib/examples/httpd/https_example/https_example.c b/contrib/examples/httpd/https_example/https_example.c new file mode 100644 index 00000000000..7619896961d --- /dev/null +++ b/contrib/examples/httpd/https_example/https_example.c @@ -0,0 +1,144 @@ +/** + * @file + * HTTPD https example + * + * This file demonstrates how to initialize httpd for https. + * To do this, it needs 2 files: + * - server certificate + * - server private key + * + * In addition to that, watch out for resource shortage. You'll need plenty of + * heap (start with MEM_SIZE >= 200 KByte or monitor its err counters) and be + * sure to at least set the following settings high enough (monitor + * lwip_stats for an idea of what's needed): + * - MEMP_NUM_TCP_PCB/MEMP_NUM_ALTCP_PCB + * - MEMP_NUM_TCPIP_MSG_INPKT + * - MEMP_NUM_TCP_SEG + */ + + /* + * Copyright (c) 2017-2019 Simon Goldschmidt + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Simon Goldschmidt goldsimon@gmx.de + * + */ + +#include "lwip/opt.h" +#include "https_example.h" + +#include "lwip/altcp_tls.h" +#include "lwip/apps/httpd.h" + +#include <stdio.h> +#include <stdlib.h> +#include <string.h> + +/** define LWIP_HTTPD_EXAMPLE_HTTPS to 1 to enable this file system */ +#ifndef LWIP_HTTPD_EXAMPLE_HTTPS +#define LWIP_HTTPD_EXAMPLE_HTTPS 0 +#endif + +#if LWIP_HTTPD_EXAMPLE_HTTPS && LWIP_ALTCP_TLS + +#ifndef LWIP_HTTPD_EXAMPLE_HTTPS_KEY_FILE +#error "define LWIP_HTTPD_EXAMPLE_HTTPS_KEY_FILE to the created server private key" +#endif + +/* If the key file is password-protected, define LWIP_HTTPD_EXAMPLE_HTTPS_KEY_FILE_PASS */ +#ifdef LWIP_HTTPD_EXAMPLE_HTTPS_KEY_FILE_PASS +#ifndef LWIP_HTTPD_EXAMPLE_HTTPS_KEY_FILE_PASS_LEN +#define LWIP_HTTPD_EXAMPLE_HTTPS_KEY_FILE_PASS_LEN strlen(LWIP_HTTPD_EXAMPLE_HTTPS_KEY_FILE_PASS) +#endif +#else +#define LWIP_HTTPD_EXAMPLE_HTTPS_KEY_FILE_PASS NULL +#define LWIP_HTTPD_EXAMPLE_HTTPS_KEY_FILE_PASS_LEN 0 +#endif + +#ifndef LWIP_HTTPD_EXAMPLE_HTTPS_CERT_FILE +#error "define LWIP_HTTPD_EXAMPLE_HTTPS_CERT_FILE to the created server certificate" +#endif + +static u8_t *read_file(const char *filename, size_t *file_size) +{ + u8_t *buf; + long fsize; + FILE *f = fopen(filename, "rb"); + if (!f) { + return NULL; + } + fseek(f, 0, SEEK_END); + fsize = ftell(f); + fseek(f, 0, SEEK_SET); + + buf = (u8_t *)malloc(fsize + 1); + if (!buf) { + fclose(f); + return NULL; + } + fread(buf, 1, fsize, f); + fclose(f); + + buf[fsize] = 0; + if (file_size) { + /* Note: the '+ 1' is required for mbedTLS to correctly parse the buffer */ + *file_size = (size_t)(fsize + 1); + } + return buf; +} + +/** This function loads a server certificate and private key as x509 from disk. + * For information how to create such files, see mbedTLS tutorial ("How to + * generate a self-signed certificate") or OpenSSL documentation ("How to + * generate a self-signed certificate and private key using OpenSSL"), e.g. + * 'openssl req -x509 -sha256 -nodes -days 365 -newkey rsa:2048 -keyout privateKey.key -out certificate.crt' + * Copy the resulting files and define the path to them + */ +void +https_ex_init(void) +{ + struct altcp_tls_config *conf; + u8_t *privkey, *cert; + size_t privkey_size, cert_size; + + privkey = read_file(LWIP_HTTPD_EXAMPLE_HTTPS_KEY_FILE, &privkey_size); + LWIP_ASSERT("Failed to open https server private key", privkey != NULL); + cert = read_file(LWIP_HTTPD_EXAMPLE_HTTPS_CERT_FILE, &cert_size); + LWIP_ASSERT("Failed to open https server certificate", cert != NULL); + + conf = altcp_tls_create_config_server_privkey_cert(privkey, privkey_size, + LWIP_HTTPD_EXAMPLE_HTTPS_KEY_FILE_PASS, LWIP_HTTPD_EXAMPLE_HTTPS_KEY_FILE_PASS_LEN, cert, cert_size); + LWIP_ASSERT("Failed to create https server config", conf != NULL); + + httpd_inits(conf); + + /* secure erase should be done in production environment */ + free(privkey); + free(cert); +} + +#endif /* LWIP_HTTPD_EXAMPLE_HTTPS */ diff --git a/contrib/examples/httpd/https_example/https_example.h b/contrib/examples/httpd/https_example/https_example.h new file mode 100644 index 00000000000..c1525e6a836 --- /dev/null +++ b/contrib/examples/httpd/https_example/https_example.h @@ -0,0 +1,38 @@ +/* + * Copyright (c) 2017 Simon Goldschmidt + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Simon Goldschmidt goldsimon@gmx.de + * + */ + +#ifndef LWIP_HDR_HTTP_EXAMPLES_HTTPS_EXAMPLE +#define LWIP_HDR_HTTP_EXAMPLES_HTTPS_EXAMPLE + +void https_ex_init(void); + +#endif /* LWIP_HDR_HTTP_EXAMPLES_HTTPS_EXAMPLE */ diff --git a/contrib/examples/httpd/post_example/post_example.c b/contrib/examples/httpd/post_example/post_example.c new file mode 100644 index 00000000000..f4e4369c9e4 --- /dev/null +++ b/contrib/examples/httpd/post_example/post_example.c @@ -0,0 +1,167 @@ +/** + * @file + * HTTPD example for simple POST + */ + + /* + * Copyright (c) 2017 Simon Goldschmidt + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Simon Goldschmidt goldsimon@gmx.de + * + */ + +#include "lwip/opt.h" + +#include "lwip/apps/httpd.h" +#include "lwip/def.h" +#include "lwip/mem.h" + +#include <stdio.h> +#include <string.h> + +/** define LWIP_HTTPD_EXAMPLE_GENERATEDFILES to 1 to enable this file system */ +#ifndef LWIP_HTTPD_EXAMPLE_SIMPLEPOST +#define LWIP_HTTPD_EXAMPLE_SIMPLEPOST 0 +#endif + +#if LWIP_HTTPD_EXAMPLE_SIMPLEPOST + +#if !LWIP_HTTPD_SUPPORT_POST +#error This needs LWIP_HTTPD_SUPPORT_POST +#endif + +#define USER_PASS_BUFSIZE 16 + +static void *current_connection; +static void *valid_connection; +static char last_user[USER_PASS_BUFSIZE]; + +err_t +httpd_post_begin(void *connection, const char *uri, const char *http_request, + u16_t http_request_len, int content_len, char *response_uri, + u16_t response_uri_len, u8_t *post_auto_wnd) +{ + LWIP_UNUSED_ARG(connection); + LWIP_UNUSED_ARG(http_request); + LWIP_UNUSED_ARG(http_request_len); + LWIP_UNUSED_ARG(content_len); + LWIP_UNUSED_ARG(post_auto_wnd); + if (!memcmp(uri, "/login.cgi", 11)) { + if (current_connection != connection) { + current_connection = connection; + valid_connection = NULL; + /* default page is "login failed" */ + snprintf(response_uri, response_uri_len, "/loginfail.html"); + /* e.g. for large uploads to slow flash over a fast connection, you should + manually update the rx window. That way, a sender can only send a full + tcp window at a time. If this is required, set 'post_aut_wnd' to 0. + We do not need to throttle upload speed here, so: */ + *post_auto_wnd = 1; + return ERR_OK; + } + } + return ERR_VAL; +} + +err_t +httpd_post_receive_data(void *connection, struct pbuf *p) +{ + err_t ret; + + LWIP_ASSERT("NULL pbuf", p != NULL); + + if (current_connection == connection) { + u16_t token_user = pbuf_memfind(p, "user=", 5, 0); + u16_t token_pass = pbuf_memfind(p, "pass=", 5, 0); + if ((token_user != 0xFFFF) && (token_pass != 0xFFFF)) { + u16_t value_user = token_user + 5; + u16_t value_pass = token_pass + 5; + u16_t len_user = 0; + u16_t len_pass = 0; + u16_t tmp; + /* find user len */ + tmp = pbuf_memfind(p, "&", 1, value_user); + if (tmp != 0xFFFF) { + len_user = tmp - value_user; + } else { + len_user = p->tot_len - value_user; + } + /* find pass len */ + tmp = pbuf_memfind(p, "&", 1, value_pass); + if (tmp != 0xFFFF) { + len_pass = tmp - value_pass; + } else { + len_pass = p->tot_len - value_pass; + } + if ((len_user > 0) && (len_user < USER_PASS_BUFSIZE) && + (len_pass > 0) && (len_pass < USER_PASS_BUFSIZE)) { + /* provide contiguous storage if p is a chained pbuf */ + char buf_user[USER_PASS_BUFSIZE]; + char buf_pass[USER_PASS_BUFSIZE]; + char *user = (char *)pbuf_get_contiguous(p, buf_user, sizeof(buf_user), len_user, value_user); + char *pass = (char *)pbuf_get_contiguous(p, buf_pass, sizeof(buf_pass), len_pass, value_pass); + if (user && pass) { + user[len_user] = 0; + pass[len_pass] = 0; + if (!strcmp(user, "lwip") && !strcmp(pass, "post")) { + /* user and password are correct, create a "session" */ + valid_connection = connection; + memcpy(last_user, user, sizeof(last_user)); + } + } + } + } + /* not returning ERR_OK aborts the connection, so return ERR_OK unless the + connection is unknown */ + ret = ERR_OK; + } else { + ret = ERR_VAL; + } + + /* this function must ALWAYS free the pbuf it is passed or it will leak memory */ + pbuf_free(p); + + return ret; +} + +void +httpd_post_finished(void *connection, char *response_uri, u16_t response_uri_len) +{ + /* default page is "login failed" */ + snprintf(response_uri, response_uri_len, "/loginfail.html"); + if (current_connection == connection) { + if (valid_connection == connection) { + /* login succeeded */ + snprintf(response_uri, response_uri_len, "/session.html"); + } + current_connection = NULL; + valid_connection = NULL; + } +} + +#endif /* LWIP_HTTPD_EXAMPLE_SIMPLEPOST*/ diff --git a/contrib/examples/httpd/ssi_example/ssi_example.c b/contrib/examples/httpd/ssi_example/ssi_example.c new file mode 100644 index 00000000000..2024e2ead01 --- /dev/null +++ b/contrib/examples/httpd/ssi_example/ssi_example.c @@ -0,0 +1,264 @@ +/** + * @file + * HTTPD simple SSI example + * + * This file demonstrates how to add support for SSI. + * It does this in a very simple way by providing the three tags 'HelloWorld' + * 'counter', and 'MultiPart'. + * + * This file also demonstrates how to integrate CGI with SSI. + */ + + /* + * Copyright (c) 2017 Simon Goldschmidt + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Simon Goldschmidt goldsimon@gmx.de + * + */ + +#include "lwip/opt.h" +#include "ssi_example.h" + +#include "lwip/apps/httpd.h" + +#include "lwip/def.h" +#include "lwip/mem.h" + +#include <stdio.h> +#include <string.h> + +/** define LWIP_HTTPD_EXAMPLE_SSI_SIMPLE to 1 to enable this ssi example*/ +#ifndef LWIP_HTTPD_EXAMPLE_SSI_SIMPLE +#define LWIP_HTTPD_EXAMPLE_SSI_SIMPLE 0 +#endif + +/** define LWIP_HTTPD_EXAMPLE_SSI_SIMPLE_CGI_INTEGRATION to 1 to show how to + * integrate CGI into SSI (LWIP_HTTPD_CGI_SSI) */ +#ifndef LWIP_HTTPD_EXAMPLE_SSI_SIMPLE_CGI_INTEGRATION +#define LWIP_HTTPD_EXAMPLE_SSI_SIMPLE_CGI_INTEGRATION 0 +#endif + +#if LWIP_HTTPD_EXAMPLE_SSI_SIMPLE + +#if LWIP_HTTPD_EXAMPLE_SSI_SIMPLE_CGI_INTEGRATION +#if !LWIP_HTTPD_FILE_STATE +#error LWIP_HTTPD_EXAMPLE_SSI_SIMPLE_CGI_INTEGRATION needs LWIP_HTTPD_FILE_STATE +#endif +#if !LWIP_HTTPD_CGI_SSI +#error LWIP_HTTPD_EXAMPLE_SSI_SIMPLE_CGI_INTEGRATION needs LWIP_HTTPD_CGI_SSI +#endif + +#define MAX_CGI_LEN 16 +#endif + +const char * ssi_example_tags[] = { + "HellWorl", + "counter", + "MultPart" +#if LWIP_HTTPD_EXAMPLE_SSI_SIMPLE_CGI_INTEGRATION + ,"CgiParam" +#endif +}; + +u16_t ssi_example_ssi_handler( +#if LWIP_HTTPD_SSI_RAW + const char* ssi_tag_name, +#else /* LWIP_HTTPD_SSI_RAW */ + int iIndex, +#endif /* LWIP_HTTPD_SSI_RAW */ + char *pcInsert, int iInsertLen +#if LWIP_HTTPD_SSI_MULTIPART + , u16_t current_tag_part, u16_t *next_tag_part +#endif /* LWIP_HTTPD_SSI_MULTIPART */ +#if defined(LWIP_HTTPD_FILE_STATE) && LWIP_HTTPD_FILE_STATE + , void *connection_state +#endif /* LWIP_HTTPD_FILE_STATE */ + ) +{ + size_t printed; +#if LWIP_HTTPD_SSI_RAW + /* a real application could use if(!strcmp) blocks here, but we want to keep + the differences between configurations small, so translate string to index here */ + int iIndex; + for (iIndex = 0; iIndex < LWIP_ARRAYSIZE(ssi_example_tags); iIndex++) { + if(!strcmp(ssi_tag_name, ssi_example_tags[iIndex])) { + break; + } + } +#endif +#if defined(LWIP_HTTPD_FILE_STATE) && LWIP_HTTPD_FILE_STATE + LWIP_UNUSED_ARG(connection_state); +#endif + + switch (iIndex) { + case 0: /* "HelloWorld" */ + printed = snprintf(pcInsert, iInsertLen, "Hello World!"); + break; + case 1: /* "counter" */ + { + static int counter; + counter++; + printed = snprintf(pcInsert, iInsertLen, "%d", counter); + } + break; + case 2: /* "MultPart" */ +#if LWIP_HTTPD_SSI_MULTIPART + switch (current_tag_part) { + case 0: + printed = snprintf(pcInsert, iInsertLen, "part0"); + *next_tag_part = 1; + break; + case 1: + printed = snprintf(pcInsert, iInsertLen, "part1"); + *next_tag_part = 2; + break; + case 2: + printed = snprintf(pcInsert, iInsertLen, "part2"); + break; + default: + printed = snprintf(pcInsert, iInsertLen, "unhandled part: %d", (int)current_tag_part); + break; + } +#else + printed = snprintf(pcInsert, iInsertLen, "LWIP_HTTPD_SSI_MULTIPART disabled"); +#endif + break; +#if LWIP_HTTPD_EXAMPLE_SSI_SIMPLE_CGI_INTEGRATION + case 3: + if (connection_state) { + char *params = (char *)connection_state; + if (*params) { + printed = snprintf(pcInsert, iInsertLen, "%s", (char *)params); + } else { + printed = snprintf(pcInsert, iInsertLen, "none"); + } + } else { + printed = snprintf(pcInsert, iInsertLen, "NULL"); + } + break; +#endif + default: /* unknown tag */ + printed = 0; + break; + } + LWIP_ASSERT("sane length", printed <= 0xFFFF); + return (u16_t)printed; +} + +void +ssi_ex_init(void) +{ + int i; + for (i = 0; i < LWIP_ARRAYSIZE(ssi_example_tags); i++) { + LWIP_ASSERT("tag too long for LWIP_HTTPD_MAX_TAG_NAME_LEN", + strlen(ssi_example_tags[i]) <= LWIP_HTTPD_MAX_TAG_NAME_LEN); + } + + http_set_ssi_handler(ssi_example_ssi_handler, +#if LWIP_HTTPD_SSI_RAW + NULL, 0 +#else + ssi_example_tags, LWIP_ARRAYSIZE(ssi_example_tags) +#endif + ); +} + +#if LWIP_HTTPD_EXAMPLE_SSI_SIMPLE_CGI_INTEGRATION +void * +fs_state_init(struct fs_file *file, const char *name) +{ + char *ret; + LWIP_UNUSED_ARG(file); + LWIP_UNUSED_ARG(name); + ret = (char *)mem_malloc(MAX_CGI_LEN); + if (ret) { + *ret = 0; + } + return ret; +} + +void +fs_state_free(struct fs_file *file, void *state) +{ + LWIP_UNUSED_ARG(file); + if (state != NULL) { + mem_free(state); + } +} + +void +httpd_cgi_handler(struct fs_file *file, const char* uri, int iNumParams, + char **pcParam, char **pcValue +#if defined(LWIP_HTTPD_FILE_STATE) && LWIP_HTTPD_FILE_STATE + , void *connection_state +#endif /* LWIP_HTTPD_FILE_STATE */ + ) +{ + LWIP_UNUSED_ARG(file); + LWIP_UNUSED_ARG(uri); + if (connection_state != NULL) { + char *start = (char *)connection_state; + char *end = start + MAX_CGI_LEN; + int i; + memset(start, 0, MAX_CGI_LEN); + /* print a string of the arguments: */ + for (i = 0; i < iNumParams; i++) { + size_t len; + len = end - start; + if (len) { + size_t inlen = strlen(pcParam[i]); + size_t copylen = LWIP_MIN(inlen, len); + memcpy(start, pcParam[i], copylen); + start += copylen; + len -= copylen; + } + if (len) { + *start = '='; + start++; + len--; + } + if (len) { + size_t inlen = strlen(pcValue[i]); + size_t copylen = LWIP_MIN(inlen, len); + memcpy(start, pcValue[i], copylen); + start += copylen; + len -= copylen; + } + if (len) { + *start = ';'; + len--; + } + /* ensure NULL termination */ + end--; + *end = 0; + } + } +} +#endif /* LWIP_HTTPD_EXAMPLE_SSI_SIMPLE_CGI_INTEGRATION */ + +#endif /* LWIP_HTTPD_EXAMPLE_SSI_SIMPLE */ diff --git a/contrib/examples/httpd/ssi_example/ssi_example.h b/contrib/examples/httpd/ssi_example/ssi_example.h new file mode 100644 index 00000000000..b7ec298ad75 --- /dev/null +++ b/contrib/examples/httpd/ssi_example/ssi_example.h @@ -0,0 +1,38 @@ +/* + * Copyright (c) 2017 Simon Goldschmidt + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Simon Goldschmidt goldsimon@gmx.de + * + */ + +#ifndef LWIP_HDR_HTTP_EXAMPLES_SSI_EXAMPLE +#define LWIP_HDR_HTTP_EXAMPLES_SSI_EXAMPLE + +void ssi_ex_init(void); + +#endif /* LWIP_HDR_HTTP_EXAMPLES_SSI_EXAMPLE */ diff --git a/contrib/examples/lwiperf/lwiperf_example.c b/contrib/examples/lwiperf/lwiperf_example.c new file mode 100644 index 00000000000..a33bc6f23ae --- /dev/null +++ b/contrib/examples/lwiperf/lwiperf_example.c @@ -0,0 +1,50 @@ +/* + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Dirk Ziegelmeier dziegel@gmx.de + * + */ + +#include "lwip/apps/lwiperf.h" +#include "lwiperf_example.h" + +static void +lwiperf_report(void *arg, enum lwiperf_report_type report_type, + const ip_addr_t* local_addr, u16_t local_port, const ip_addr_t* remote_addr, u16_t remote_port, + u32_t bytes_transferred, u32_t ms_duration, u32_t bandwidth_kbitpsec) +{ + LWIP_UNUSED_ARG(arg); + LWIP_UNUSED_ARG(local_addr); + LWIP_UNUSED_ARG(local_port); + + LWIP_PLATFORM_DIAG(("IPERF report: type=%d, remote: %s:%d, total bytes: %"U32_F", duration in ms: %"U32_F", kbits/s: %"U32_F"\n", + (int)report_type, ipaddr_ntoa(remote_addr), (int)remote_port, bytes_transferred, ms_duration, bandwidth_kbitpsec)); +} + +void +lwiperf_example_init(void) +{ + lwiperf_start_tcp_server_default(lwiperf_report, NULL); +} diff --git a/contrib/examples/lwiperf/lwiperf_example.h b/contrib/examples/lwiperf/lwiperf_example.h new file mode 100644 index 00000000000..d7b35c88e10 --- /dev/null +++ b/contrib/examples/lwiperf/lwiperf_example.h @@ -0,0 +1,43 @@ +/* + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Dirk Ziegelmeier dziegel@gmx.de + * + */ + +#ifndef LWIPERF_EXAMPLE_H +#define LWIPERF_EXAMPLE_H + +#ifdef __cplusplus +extern "C" { +#endif + +void lwiperf_example_init(void); + +#ifdef __cplusplus +} +#endif + +#endif /* LWIPERF_EXAMPLE_H */ diff --git a/contrib/examples/mdns/mdns_example.c b/contrib/examples/mdns/mdns_example.c new file mode 100644 index 00000000000..49625ef1197 --- /dev/null +++ b/contrib/examples/mdns/mdns_example.c @@ -0,0 +1,63 @@ +/* + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Dirk Ziegelmeier dziegel@gmx.de + * + */ + +#include "lwip/apps/mdns.h" +#include "mdns_example.h" + +#if LWIP_MDNS_RESPONDER +static void +srv_txt(struct mdns_service *service, void *txt_userdata) +{ + err_t res; + LWIP_UNUSED_ARG(txt_userdata); + + res = mdns_resp_add_service_txtitem(service, "path=/", 6); + LWIP_ERROR("mdns add service txt failed\n", (res == ERR_OK), return); +} +#endif + +#if LWIP_MDNS_RESPONDER +static void +mdns_example_report(struct netif* netif, u8_t result, s8_t service) +{ + LWIP_PLATFORM_DIAG(("mdns status[netif %d][service %d]: %d\n", netif->num, service, result)); +} +#endif + +void +mdns_example_init(void) +{ +#if LWIP_MDNS_RESPONDER + mdns_resp_register_name_result_cb(mdns_example_report); + mdns_resp_init(); + mdns_resp_add_netif(netif_default, "lwip"); + mdns_resp_add_service(netif_default, "myweb", "_http", DNSSD_PROTO_TCP, 80, srv_txt, NULL); + mdns_resp_announce(netif_default); +#endif +} diff --git a/contrib/examples/mdns/mdns_example.h b/contrib/examples/mdns/mdns_example.h new file mode 100644 index 00000000000..ab51ade53ba --- /dev/null +++ b/contrib/examples/mdns/mdns_example.h @@ -0,0 +1,43 @@ +/* + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Dirk Ziegelmeier dziegel@gmx.de + * + */ + +#ifndef MDNS_EXAMPLE_H +#define MDNS_EXAMPLE_H + +#ifdef __cplusplus +extern "C" { +#endif + +void mdns_example_init(void); + +#ifdef __cplusplus +} +#endif + +#endif /* MDNS_EXAMPLE_H */ diff --git a/contrib/examples/mqtt/mqtt_example.c b/contrib/examples/mqtt/mqtt_example.c new file mode 100644 index 00000000000..bb277d6fd80 --- /dev/null +++ b/contrib/examples/mqtt/mqtt_example.c @@ -0,0 +1,128 @@ +/* + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Dirk Ziegelmeier dziegel@gmx.de + * + */ + +#include "lwip/apps/mqtt.h" +#include "mqtt_example.h" + +#if LWIP_TCP + +/** Define this to a compile-time IP address initialization + * to connect anything else than IPv4 loopback + */ +#ifndef LWIP_MQTT_EXAMPLE_IPADDR_INIT +#if LWIP_IPV4 +#define LWIP_MQTT_EXAMPLE_IPADDR_INIT = IPADDR4_INIT(PP_HTONL(IPADDR_LOOPBACK)) +#else +#define LWIP_MQTT_EXAMPLE_IPADDR_INIT +#endif +#endif + +static ip_addr_t mqtt_ip LWIP_MQTT_EXAMPLE_IPADDR_INIT; +static mqtt_client_t* mqtt_client; + +static const struct mqtt_connect_client_info_t mqtt_client_info = +{ + "test", + NULL, /* user */ + NULL, /* pass */ + 100, /* keep alive */ + NULL, /* will_topic */ + NULL, /* will_msg */ + 0, /* will_qos */ + 0 /* will_retain */ +#if LWIP_ALTCP && LWIP_ALTCP_TLS + , NULL +#endif +}; + +static void +mqtt_incoming_data_cb(void *arg, const u8_t *data, u16_t len, u8_t flags) +{ + const struct mqtt_connect_client_info_t* client_info = (const struct mqtt_connect_client_info_t*)arg; + LWIP_UNUSED_ARG(data); + + LWIP_PLATFORM_DIAG(("MQTT client "%s" data cb: len %d, flags %d\n", client_info->client_id, + (int)len, (int)flags)); +} + +static void +mqtt_incoming_publish_cb(void *arg, const char *topic, u32_t tot_len) +{ + const struct mqtt_connect_client_info_t* client_info = (const struct mqtt_connect_client_info_t*)arg; + + LWIP_PLATFORM_DIAG(("MQTT client "%s" publish cb: topic %s, len %d\n", client_info->client_id, + topic, (int)tot_len)); +} + +static void +mqtt_request_cb(void *arg, err_t err) +{ + const struct mqtt_connect_client_info_t* client_info = (const struct mqtt_connect_client_info_t*)arg; + + LWIP_PLATFORM_DIAG(("MQTT client "%s" request cb: err %d\n", client_info->client_id, (int)err)); +} + +static void +mqtt_connection_cb(mqtt_client_t *client, void *arg, mqtt_connection_status_t status) +{ + const struct mqtt_connect_client_info_t* client_info = (const struct mqtt_connect_client_info_t*)arg; + LWIP_UNUSED_ARG(client); + + LWIP_PLATFORM_DIAG(("MQTT client "%s" connection cb: status %d\n", client_info->client_id, (int)status)); + + if (status == MQTT_CONNECT_ACCEPTED) { + mqtt_sub_unsub(client, + "topic_qos1", 1, + mqtt_request_cb, LWIP_CONST_CAST(void*, client_info), + 1); + mqtt_sub_unsub(client, + "topic_qos0", 0, + mqtt_request_cb, LWIP_CONST_CAST(void*, client_info), + 1); + } +} +#endif /* LWIP_TCP */ + +void +mqtt_example_init(void) +{ +#if LWIP_TCP + mqtt_client = mqtt_client_new(); + + mqtt_set_inpub_callback(mqtt_client, + mqtt_incoming_publish_cb, + mqtt_incoming_data_cb, + LWIP_CONST_CAST(void*, &mqtt_client_info)); + + mqtt_client_connect(mqtt_client, + &mqtt_ip, MQTT_PORT, + mqtt_connection_cb, LWIP_CONST_CAST(void*, &mqtt_client_info), + &mqtt_client_info); +#endif /* LWIP_TCP */ +} diff --git a/contrib/examples/mqtt/mqtt_example.h b/contrib/examples/mqtt/mqtt_example.h new file mode 100644 index 00000000000..797678b2cf2 --- /dev/null +++ b/contrib/examples/mqtt/mqtt_example.h @@ -0,0 +1,43 @@ +/* + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Dirk Ziegelmeier dziegel@gmx.de + * + */ + +#ifndef MQTT_EXAMPLE_H +#define MQTT_EXAMPLE_H + +#ifdef __cplusplus +extern "C" { +#endif + +void mqtt_example_init(void); + +#ifdef __cplusplus +} +#endif + +#endif /* MQTT_EXAMPLE_H */ diff --git a/contrib/examples/ppp/pppos_example.c b/contrib/examples/ppp/pppos_example.c new file mode 100644 index 00000000000..0d18ce5240d --- /dev/null +++ b/contrib/examples/ppp/pppos_example.c @@ -0,0 +1,221 @@ +/* + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Dirk Ziegelmeier dziegel@gmx.de + * + */ + +#include "lwip/dns.h" + +#ifndef PPPOS_SUPPORT +#define PPPOS_SUPPORT 0 +#endif /* PPPOS_SUPPORT */ + +#if PPPOS_SUPPORT +#include "netif/ppp/pppos.h" +#include "lwip/sio.h" +#define PPP_PTY_TEST 1 +#endif /* PPPOS_SUPPORT */ + +#include "pppos_example.h" + +#include <stdio.h> + +#if PPPOS_SUPPORT +static sio_fd_t ppp_sio; +static ppp_pcb *ppp; +static struct netif pppos_netif; + +static void +pppos_rx_thread(void *arg) +{ + u32_t len; + u8_t buffer[128]; + LWIP_UNUSED_ARG(arg); + + /* Please read the "PPPoS input path" chapter in the PPP documentation. */ + while (1) { + len = sio_read(ppp_sio, buffer, sizeof(buffer)); + if (len > 0) { + /* Pass received raw characters from PPPoS to be decoded through lwIP + * TCPIP thread using the TCPIP API. This is thread safe in all cases + * but you should avoid passing data byte after byte. */ + pppos_input_tcpip(ppp, buffer, len); + } + } +} + +static void +ppp_link_status_cb(ppp_pcb *pcb, int err_code, void *ctx) +{ + struct netif *pppif = ppp_netif(pcb); + LWIP_UNUSED_ARG(ctx); + + switch(err_code) { + case PPPERR_NONE: /* No error. */ + { +#if LWIP_DNS + const ip_addr_t *ns; +#endif /* LWIP_DNS */ + fprintf(stderr, "ppp_link_status_cb: PPPERR_NONE\n\r"); +#if LWIP_IPV4 + fprintf(stderr, " our_ip4addr = %s\n\r", ip4addr_ntoa(netif_ip4_addr(pppif))); + fprintf(stderr, " his_ipaddr = %s\n\r", ip4addr_ntoa(netif_ip4_gw(pppif))); + fprintf(stderr, " netmask = %s\n\r", ip4addr_ntoa(netif_ip4_netmask(pppif))); +#endif /* LWIP_IPV4 */ +#if LWIP_IPV6 + fprintf(stderr, " our_ip6addr = %s\n\r", ip6addr_ntoa(netif_ip6_addr(pppif, 0))); +#endif /* LWIP_IPV6 */ + +#if LWIP_DNS + ns = dns_getserver(0); + fprintf(stderr, " dns1 = %s\n\r", ipaddr_ntoa(ns)); + ns = dns_getserver(1); + fprintf(stderr, " dns2 = %s\n\r", ipaddr_ntoa(ns)); +#endif /* LWIP_DNS */ +#if PPP_IPV6_SUPPORT + fprintf(stderr, " our6_ipaddr = %s\n\r", ip6addr_ntoa(netif_ip6_addr(pppif, 0))); +#endif /* PPP_IPV6_SUPPORT */ + } + break; + + case PPPERR_PARAM: /* Invalid parameter. */ + printf("ppp_link_status_cb: PPPERR_PARAM\n"); + break; + + case PPPERR_OPEN: /* Unable to open PPP session. */ + printf("ppp_link_status_cb: PPPERR_OPEN\n"); + break; + + case PPPERR_DEVICE: /* Invalid I/O device for PPP. */ + printf("ppp_link_status_cb: PPPERR_DEVICE\n"); + break; + + case PPPERR_ALLOC: /* Unable to allocate resources. */ + printf("ppp_link_status_cb: PPPERR_ALLOC\n"); + break; + + case PPPERR_USER: /* User interrupt. */ + printf("ppp_link_status_cb: PPPERR_USER\n"); + break; + + case PPPERR_CONNECT: /* Connection lost. */ + printf("ppp_link_status_cb: PPPERR_CONNECT\n"); + break; + + case PPPERR_AUTHFAIL: /* Failed authentication challenge. */ + printf("ppp_link_status_cb: PPPERR_AUTHFAIL\n"); + break; + + case PPPERR_PROTOCOL: /* Failed to meet protocol. */ + printf("ppp_link_status_cb: PPPERR_PROTOCOL\n"); + break; + + case PPPERR_PEERDEAD: /* Connection timeout. */ + printf("ppp_link_status_cb: PPPERR_PEERDEAD\n"); + break; + + case PPPERR_IDLETIMEOUT: /* Idle Timeout. */ + printf("ppp_link_status_cb: PPPERR_IDLETIMEOUT\n"); + break; + + case PPPERR_CONNECTTIME: /* PPPERR_CONNECTTIME. */ + printf("ppp_link_status_cb: PPPERR_CONNECTTIME\n"); + break; + + case PPPERR_LOOPBACK: /* Connection timeout. */ + printf("ppp_link_status_cb: PPPERR_LOOPBACK\n"); + break; + + default: + printf("ppp_link_status_cb: unknown errCode %d\n", err_code); + break; + } +} + +static u32_t +ppp_output_cb(ppp_pcb *pcb, const void *data, u32_t len, void *ctx) +{ + LWIP_UNUSED_ARG(pcb); + LWIP_UNUSED_ARG(ctx); + return sio_write(ppp_sio, (const u8_t*)data, len); +} + +#if LWIP_NETIF_STATUS_CALLBACK +static void +netif_status_callback(struct netif *nif) +{ + printf("PPPNETIF: %c%c%d is %s\n", nif->name[0], nif->name[1], nif->num, + netif_is_up(nif) ? "UP" : "DOWN"); +#if LWIP_IPV4 + printf("IPV4: Host at %s ", ip4addr_ntoa(netif_ip4_addr(nif))); + printf("mask %s ", ip4addr_ntoa(netif_ip4_netmask(nif))); + printf("gateway %s\n", ip4addr_ntoa(netif_ip4_gw(nif))); +#endif /* LWIP_IPV4 */ +#if LWIP_IPV6 + printf("IPV6: Host at %s\n", ip6addr_ntoa(netif_ip6_addr(nif, 0))); +#endif /* LWIP_IPV6 */ +#if LWIP_NETIF_HOSTNAME + printf("FQDN: %s\n", netif_get_hostname(nif)); +#endif /* LWIP_NETIF_HOSTNAME */ +} +#endif /* LWIP_NETIF_STATUS_CALLBACK */ +#endif + +void +pppos_example_init(void) +{ +#if PPPOS_SUPPORT +#if PPP_PTY_TEST + ppp_sio = sio_open(2); +#else + ppp_sio = sio_open(0); +#endif + if(!ppp_sio) + { + perror("PPPOS example: Error opening device"); + return; + } + + ppp = pppos_create(&pppos_netif, ppp_output_cb, ppp_link_status_cb, NULL); + if (!ppp) + { + printf("PPPOS example: Could not create PPP control interface"); + return; + } + +#ifdef LWIP_PPP_CHAP_TEST + ppp_set_auth(ppp, PPPAUTHTYPE_CHAP, "lwip", "mysecret"); +#endif + + ppp_connect(ppp, 0); + +#if LWIP_NETIF_STATUS_CALLBACK + netif_set_status_callback(&pppos_netif, netif_status_callback); +#endif /* LWIP_NETIF_STATUS_CALLBACK */ + + sys_thread_new("pppos_rx_thread", pppos_rx_thread, NULL, DEFAULT_THREAD_STACKSIZE, DEFAULT_THREAD_PRIO); +#endif /* PPPOS_SUPPORT */ +} diff --git a/contrib/examples/ppp/pppos_example.h b/contrib/examples/ppp/pppos_example.h new file mode 100644 index 00000000000..726961c80d8 --- /dev/null +++ b/contrib/examples/ppp/pppos_example.h @@ -0,0 +1,43 @@ +/* + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Dirk Ziegelmeier dziegel@gmx.de + * + */ + +#ifndef PPPOS_EXAMPLE_H +#define PPPOS_EXAMPLE_H + +#ifdef __cplusplus +extern "C" { +#endif + +void pppos_example_init(void); + +#ifdef __cplusplus +} +#endif + +#endif /* PPPOS_EXAMPLE_H */ diff --git a/contrib/examples/snmp/snmp_example.c b/contrib/examples/snmp/snmp_example.c new file mode 100644 index 00000000000..59524747980 --- /dev/null +++ b/contrib/examples/snmp/snmp_example.c @@ -0,0 +1,80 @@ +/* + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Dirk Ziegelmeier dziegel@gmx.de + * + */ + +#include "lwip/netif.h" +#include "lwip/apps/snmp.h" +#include "lwip/apps/snmp_mib2.h" +#include "lwip/apps/snmpv3.h" +#include "lwip/apps/snmp_snmpv2_framework.h" +#include "lwip/apps/snmp_snmpv2_usm.h" +#include "examples/snmp/snmp_v3/snmpv3_dummy.h" +#include "examples/snmp/snmp_private_mib/private_mib.h" +#include "snmp_example.h" + +#if LWIP_SNMP +static const struct snmp_mib *mibs[] = { + &mib2, + &mib_private +#if LWIP_SNMP_V3 + , &snmpframeworkmib + , &snmpusmmib +#endif +}; +#endif /* LWIP_SNMP */ + +void +snmp_example_init(void) +{ +#if LWIP_SNMP + s32_t req_nr; + lwip_privmib_init(); +#if SNMP_LWIP_MIB2 +#if SNMP_USE_NETCONN + snmp_threadsync_init(&snmp_mib2_lwip_locks, snmp_mib2_lwip_synchronizer); +#endif /* SNMP_USE_NETCONN */ + snmp_mib2_set_syscontact_readonly((const u8_t*)"root", NULL); + snmp_mib2_set_syslocation_readonly((const u8_t*)"lwIP development PC", NULL); + snmp_mib2_set_sysdescr((const u8_t*)"lwIP example", NULL); +#endif /* SNMP_LWIP_MIB2 */ + +#if LWIP_SNMP_V3 + snmpv3_dummy_init(); +#endif + + snmp_set_mibs(mibs, LWIP_ARRAYSIZE(mibs)); + snmp_init(); + + snmp_trap_dst_ip_set(0, &netif_default->gw); + snmp_trap_dst_enable(0, 1); + + snmp_send_inform_generic(SNMP_GENTRAP_COLDSTART, NULL, &req_nr); + snmp_send_trap_generic(SNMP_GENTRAP_COLDSTART); + +#endif /* LWIP_SNMP */ +} diff --git a/contrib/examples/snmp/snmp_example.h b/contrib/examples/snmp/snmp_example.h new file mode 100644 index 00000000000..fafcd68f2b1 --- /dev/null +++ b/contrib/examples/snmp/snmp_example.h @@ -0,0 +1,43 @@ +/* + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Dirk Ziegelmeier dziegel@gmx.de + * + */ + +#ifndef SNMP_EXAMPLE_H +#define SNMP_EXAMPLE_H + +#ifdef __cplusplus +extern "C" { +#endif + +void snmp_example_init(void); + +#ifdef __cplusplus +} +#endif + +#endif /* SNMP_EXAMPLE_H */ diff --git a/contrib/examples/snmp/snmp_private_mib/lwip_prvmib.c b/contrib/examples/snmp/snmp_private_mib/lwip_prvmib.c new file mode 100644 index 00000000000..51a49fe158a --- /dev/null +++ b/contrib/examples/snmp/snmp_private_mib/lwip_prvmib.c @@ -0,0 +1,401 @@ +/** + * @file + * lwip Private MIB + * + * @todo create MIB file for this example + * @note the lwip enterprise tree root (26381) is owned by the lwIP project. + * It is NOT allowed to allocate new objects under this ID (26381) without our, + * the lwip developers, permission! + * + * Please apply for your own ID with IANA: http://www.iana.org/numbers.html + * + * lwip OBJECT IDENTIFIER ::= { enterprises 26381 } + * example OBJECT IDENTIFIER ::= { lwip 1 } + */ + +/* + * Copyright (c) 2006 Axon Digital Design B.V., The Netherlands. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * Author: Christiaan Simons christiaan.simons@axon.tv + */ + +#include "private_mib.h" + +#if LWIP_SNMP + +/** Directory where the sensor files are */ +#define SENSORS_DIR "w:\sensors" +/** Set to 1 to read sensor values from files (in directory defined by SENSORS_DIR) */ +#define SENSORS_USE_FILES 0 +/** Set to 1 to search sensor files at startup (in directory defined by SENSORS_DIR) */ +#define SENSORS_SEARCH_FILES 0 + +#if SENSORS_SEARCH_FILES +#include <sys/stat.h> +#include <sys/types.h> +#include <unistd.h> +#include <fcntl.h> +#include <dirent.h> +#endif /* SENSORS_SEARCH_FILES */ + +#include <string.h> +#include <stdio.h> + +#include "lwip/apps/snmp_table.h" +#include "lwip/apps/snmp_scalar.h" + +#if !SENSORS_USE_FILES || !SENSORS_SEARCH_FILES +/** When not using & searching files, defines the number of sensors */ +#define SENSOR_COUNT 4 +#endif /* !SENSORS_USE_FILES || !SENSORS_SEARCH_FILES */ + +/* + This example presents a table for a few (at most 10) sensors. + Sensor detection takes place at initialization (once only). + Sensors may and can not be added or removed after agent + has started. Note this is only a limitation of this crude example, + the agent does support dynamic object insertions and removals. + + You'll need to manually create a directory called "sensors" and + a few single line text files with an integer temperature value. + The files must be called [0..9].txt. + + ./sensors/0.txt [content: 20] + ./sensors/3.txt [content: 75] + + The sensor values may be changed in runtime by editing the + text files in the "sensors" directory. +*/ + +#define SENSOR_MAX 10 +#define SENSOR_NAME_LEN 20 + +struct sensor_inf +{ + u8_t num; + + char file[SENSOR_NAME_LEN + 1]; + +#if !SENSORS_USE_FILES + /** When not using files, contains the value of the sensor */ + s32_t value; +#endif /* !SENSORS_USE_FILES */ +}; + +static struct sensor_inf sensors[SENSOR_MAX]; + +static s16_t sensor_count_get_value(struct snmp_node_instance* instance, void* value); +static snmp_err_t sensor_table_get_cell_instance(const u32_t* column, const u32_t* row_oid, u8_t row_oid_len, struct snmp_node_instance* cell_instance); +static snmp_err_t sensor_table_get_next_cell_instance(const u32_t* column, struct snmp_obj_id* row_oid, struct snmp_node_instance* cell_instance); +static s16_t sensor_table_get_value(struct snmp_node_instance* instance, void* value); +static snmp_err_t sensor_table_set_value(struct snmp_node_instance* instance, u16_t len, void *value); + +/* sensorentry .1.3.6.1.4.1.26381.1.1.1 (.level0.level1) + where level 0 is the table column (temperature/file name) + and level 1 the table row (sensor index) */ +static const struct snmp_table_col_def sensor_table_columns[] = { + { 1, SNMP_ASN1_TYPE_INTEGER, SNMP_NODE_INSTANCE_READ_WRITE }, + { 2, SNMP_ASN1_TYPE_OCTET_STRING, SNMP_NODE_INSTANCE_READ_ONLY } +}; + +/* sensortable .1.3.6.1.4.1.26381.1.1 */ +static const struct snmp_table_node sensor_table = SNMP_TABLE_CREATE( + 1, sensor_table_columns, + sensor_table_get_cell_instance, sensor_table_get_next_cell_instance, + sensor_table_get_value, snmp_set_test_ok, sensor_table_set_value); + +/* sensorcount .1.3.6.1.4.1.26381.1.2 */ +static const struct snmp_scalar_node sensor_count = SNMP_SCALAR_CREATE_NODE_READONLY( + 2, SNMP_ASN1_TYPE_INTEGER, sensor_count_get_value); + +/* example .1.3.6.1.4.1.26381.1 */ +static const struct snmp_node* const example_nodes[] = { + &sensor_table.node.node, + &sensor_count.node.node +}; +static const struct snmp_tree_node example_node = SNMP_CREATE_TREE_NODE(1, example_nodes); + +static const u32_t prvmib_base_oid[] = { 1,3,6,1,4,1,26381,1 }; +const struct snmp_mib mib_private = SNMP_MIB_CREATE(prvmib_base_oid, &example_node.node); + +#if 0 +/* for reference: we could also have expressed it like this: */ + +/* lwip .1.3.6.1.4.1.26381 */ +static const struct snmp_node* const lwip_nodes[] = { + &example_node.node +}; +static const struct snmp_tree_node lwip_node = SNMP_CREATE_TREE_NODE(26381, lwip_nodes); + +/* enterprises .1.3.6.1.4.1 */ +static const struct snmp_node* const enterprises_nodes[] = { + &lwip_node.node +}; +static const struct snmp_tree_node enterprises_node = SNMP_CREATE_TREE_NODE(1, enterprises_nodes); + +/* private .1.3.6.1.4 */ +static const struct snmp_node* const private_nodes[] = { + &enterprises_node.node +}; +static const struct snmp_tree_node private_root = SNMP_CREATE_TREE_NODE(4, private_nodes); + +static const u32_t prvmib_base_oid[] = { 1,3,6,1,4 }; +const struct snmp_mib mib_private = SNMP_MIB_CREATE(prvmib_base_oid, &private_root.node); +#endif + +/** + * Initialises this private MIB before use. + * @see main.c + */ +void +lwip_privmib_init(void) +{ +#if SENSORS_USE_FILES && SENSORS_SEARCH_FILES + char *buf, *ebuf, *cp; + size_t bufsize; + int nbytes; + struct stat sb; + struct dirent *dp; + int fd; +#else /* SENSORS_USE_FILES && SENSORS_SEARCH_FILES */ + u8_t i; +#endif /* SENSORS_USE_FILES && SENSORS_SEARCH_FILES */ + + memset(sensors, 0, sizeof(sensors)); + + printf("SNMP private MIB start, detecting sensors.\n"); + +#if SENSORS_USE_FILES && SENSORS_SEARCH_FILES + /* look for sensors in sensors directory */ + fd = open(SENSORS_DIR, O_RDONLY); + if (fd > -1) + { + fstat(fd, &sb); + bufsize = sb.st_size; + if (bufsize < (size_t)sb.st_blksize) + { + bufsize = sb.st_blksize; + } + buf = (char*)malloc(bufsize); + if (buf != NULL) + { + do + { + long base; + + nbytes = getdirentries(fd, buf, bufsize, &base); + if (nbytes > 0) + { + ebuf = buf + nbytes; + cp = buf; + while (cp < ebuf) + { + dp = (struct dirent *)cp; + if (lwip_isdigit(dp->d_name[0])) + { + unsigned char idx = dp->d_name[0] - '0'; + + sensors[idx].num = idx+1; + strncpy(&sensors[idx].file[0], dp->d_name, SENSOR_NAME_LEN); + printf("%s\n", sensors[idx].file); + } + cp += dp->d_reclen; + } + } + } + while (nbytes > 0); + + free(buf); + } + close(fd); + } +#else /* SENSORS_USE_FILES && SENSORS_SEARCH_FILES */ + for (i = 0; i < SENSOR_COUNT; i++) { + sensors[i].num = (u8_t)(i + 1); + snprintf(sensors[i].file, sizeof(sensors[i].file), "%d.txt", i); + +#if !SENSORS_USE_FILES + /* initialize sensor value to != zero */ + sensors[i].value = 11 * (i+1); +#endif /* !SENSORS_USE_FILES */ + } +#endif /* SENSORS_USE_FILE && SENSORS_SEARCH_FILES */ +} + +/* sensorcount .1.3.6.1.4.1.26381.1.2 */ +static s16_t +sensor_count_get_value(struct snmp_node_instance* instance, void* value) +{ + size_t count = 0; + u32_t *uint_ptr = (u32_t*)value; + + LWIP_UNUSED_ARG(instance); + + for(count=0; count<LWIP_ARRAYSIZE(sensors); count++) { + if(sensors[count].num == 0) { + *uint_ptr = (u32_t)count; + return sizeof(*uint_ptr); + } + } + + return 0; +} + +/* sensortable .1.3.6.1.4.1.26381.1.1 */ +/* list of allowed value ranges for incoming OID */ +static const struct snmp_oid_range sensor_table_oid_ranges[] = { + { 1, SENSOR_MAX+1 } +}; + +static snmp_err_t +sensor_table_get_cell_instance(const u32_t* column, const u32_t* row_oid, u8_t row_oid_len, struct snmp_node_instance* cell_instance) +{ + u32_t sensor_num; + size_t i; + + LWIP_UNUSED_ARG(column); + + /* check if incoming OID length and if values are in plausible range */ + if(!snmp_oid_in_range(row_oid, row_oid_len, sensor_table_oid_ranges, LWIP_ARRAYSIZE(sensor_table_oid_ranges))) { + return SNMP_ERR_NOSUCHINSTANCE; + } + + /* get sensor index from incoming OID */ + sensor_num = row_oid[0]; + + /* find sensor with index */ + for(i=0; i<LWIP_ARRAYSIZE(sensors); i++) { + if(sensors[i].num != 0) { + if(sensors[i].num == sensor_num) { + /* store sensor index for subsequent operations (get/test/set) */ + cell_instance->reference.u32 = (u32_t)i; + return SNMP_ERR_NOERROR; + } + } + } + + /* not found */ + return SNMP_ERR_NOSUCHINSTANCE; +} + +static snmp_err_t +sensor_table_get_next_cell_instance(const u32_t* column, struct snmp_obj_id* row_oid, struct snmp_node_instance* cell_instance) +{ + size_t i; + struct snmp_next_oid_state state; + u32_t result_temp[LWIP_ARRAYSIZE(sensor_table_oid_ranges)]; + + LWIP_UNUSED_ARG(column); + + /* init struct to search next oid */ + snmp_next_oid_init(&state, row_oid->id, row_oid->len, result_temp, LWIP_ARRAYSIZE(sensor_table_oid_ranges)); + + /* iterate over all possible OIDs to find the next one */ + for(i=0; i<LWIP_ARRAYSIZE(sensors); i++) { + if(sensors[i].num != 0) { + u32_t test_oid[LWIP_ARRAYSIZE(sensor_table_oid_ranges)]; + + test_oid[0] = sensors[i].num; + + /* check generated OID: is it a candidate for the next one? */ + snmp_next_oid_check(&state, test_oid, LWIP_ARRAYSIZE(sensor_table_oid_ranges), (void*)i); + } + } + + /* did we find a next one? */ + if(state.status == SNMP_NEXT_OID_STATUS_SUCCESS) { + snmp_oid_assign(row_oid, state.next_oid, state.next_oid_len); + /* store sensor index for subsequent operations (get/test/set) */ + cell_instance->reference.u32 = LWIP_CONST_CAST(u32_t, state.reference); + return SNMP_ERR_NOERROR; + } + + /* not found */ + return SNMP_ERR_NOSUCHINSTANCE; +} + +static s16_t +sensor_table_get_value(struct snmp_node_instance* instance, void* value) +{ + u32_t i = instance->reference.u32; + s32_t *temperature = (s32_t *)value; + + switch (SNMP_TABLE_GET_COLUMN_FROM_OID(instance->instance_oid.id)) + { + case 1: /* sensor value */ +#if SENSORS_USE_FILES + FILE* sensf; + char senspath[sizeof(SENSORS_DIR)+1+SENSOR_NAME_LEN+1] = SENSORS_DIR"/"; + + strncpy(&senspath[sizeof(SENSORS_DIR)], + sensors[i].file, + SENSOR_NAME_LEN); + sensf = fopen(senspath,"r"); + if (sensf != NULL) + { + fscanf(sensf,"%"S32_F,temperature); + fclose(sensf); + } +#else /* SENSORS_USE_FILES */ + *temperature = sensors[i].value; +#endif /* SENSORS_USE_FILES */ + return sizeof(s32_t); + case 2: /* file name */ + MEMCPY(value, sensors[i].file, strlen(sensors[i].file)); + return (s16_t)strlen(sensors[i].file); + default: + return 0; + } +} + +static snmp_err_t +sensor_table_set_value(struct snmp_node_instance* instance, u16_t len, void *value) +{ + u32_t i = instance->reference.u32; + s32_t *temperature = (s32_t *)value; +#if SENSORS_USE_FILES + FILE* sensf; + char senspath[sizeof(SENSORS_DIR)+1+SENSOR_NAME_LEN+1] = SENSORS_DIR"/"; + + strncpy(&senspath[sizeof(SENSORS_DIR)], + sensors[i].file, + SENSOR_NAME_LEN); + sensf = fopen(senspath, "w"); + if (sensf != NULL) + { + fprintf(sensf, "%"S32_F, *temperature); + fclose(sensf); + } +#else /* SENSORS_USE_FILES */ + sensors[i].value = *temperature; +#endif /* SENSORS_USE_FILES */ + + LWIP_UNUSED_ARG(len); + + return SNMP_ERR_NOERROR; +} + +#endif /* LWIP_SNMP */ diff --git a/contrib/examples/snmp/snmp_private_mib/private_mib.h b/contrib/examples/snmp/snmp_private_mib/private_mib.h new file mode 100644 index 00000000000..69be8a4fc58 --- /dev/null +++ b/contrib/examples/snmp/snmp_private_mib/private_mib.h @@ -0,0 +1,26 @@ +/** + * @file + * Exports Private lwIP MIB + */ + +#ifndef LWIP_HDR_PRIVATE_MIB_H +#define LWIP_HDR_PRIVATE_MIB_H + +#include "lwip/apps/snmp_opts.h" + +#include "lwip/apps/snmp_core.h" + +#ifdef __cplusplus +extern "C" { +#endif + +/* export MIB */ +extern const struct snmp_mib mib_private; + +void lwip_privmib_init(void); + +#ifdef __cplusplus +} +#endif + +#endif diff --git a/contrib/examples/snmp/snmp_v3/snmpv3_dummy.c b/contrib/examples/snmp/snmp_v3/snmpv3_dummy.c new file mode 100644 index 00000000000..a7c53ed73ac --- /dev/null +++ b/contrib/examples/snmp/snmp_v3/snmpv3_dummy.c @@ -0,0 +1,395 @@ +/** + * @file + * Dummy SNMPv3 functions. + */ + +/* + * Copyright (c) 2016 Elias Oenal. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * Author: Elias Oenal lwip@eliasoenal.com + * Dirk Ziegelmeier dirk@ziegelmeier.net + */ + +#include "lwip/apps/snmpv3.h" +#include "snmpv3_dummy.h" +#include <string.h> +#include "lwip/err.h" +#include "lwip/def.h" +#include "lwip/timeouts.h" + +#if LWIP_SNMP && LWIP_SNMP_V3 + +struct user_table_entry { + char username[32]; + snmpv3_auth_algo_t auth_algo; + u8_t auth_key[20]; + snmpv3_priv_algo_t priv_algo; + u8_t priv_key[20]; +}; + +static struct user_table_entry user_table[] = { + { "lwip", SNMP_V3_AUTH_ALGO_INVAL, "" , SNMP_V3_PRIV_ALGO_INVAL, "" }, + { "piwl", SNMP_V3_AUTH_ALGO_INVAL, "" , SNMP_V3_PRIV_ALGO_INVAL, "" }, + { "test", SNMP_V3_AUTH_ALGO_INVAL, "" , SNMP_V3_PRIV_ALGO_INVAL, "" } +}; + +static char snmpv3_engineid[32]; +static u8_t snmpv3_engineid_len; + +static u32_t enginetime = 0; + +/* In this implementation engineboots is volatile. In a real world application this value should be stored in non-volatile memory.*/ +static u32_t engineboots = 0; + +/** + * @brief Get the user table entry for the given username. + * + * @param[in] username pointer to the username + * + * @return pointer to the user table entry or NULL if not found. + */ +static struct user_table_entry* +get_user(const char *username) +{ + size_t i; + + for (i = 0; i < LWIP_ARRAYSIZE(user_table); i++) { + if (strnlen(username, 32) != strnlen(user_table[i].username, 32)) { + continue; + } + + if (memcmp(username, user_table[i].username, strnlen(username, 32)) == 0) { + return &user_table[i]; + } + } + + return NULL; +} + +u8_t +snmpv3_get_amount_of_users(void) +{ + return LWIP_ARRAYSIZE(user_table); +} + +/** + * @brief Get the username of a user number (index) + * @param username is a pointer to a string. + * @param index is the user index. + * @return ERR_OK if user is found, ERR_VAL is user is not found. + */ +err_t +snmpv3_get_username(char *username, u8_t index) +{ + if (index < LWIP_ARRAYSIZE(user_table)) { + MEMCPY(username, user_table[index].username, sizeof(user_table[0].username)); + return ERR_OK; + } + + return ERR_VAL; +} + +/** + * Timer callback function that increments enginetime and reschedules itself. + * + * @param arg unused argument + */ +static void +snmpv3_enginetime_timer(void *arg) +{ + LWIP_UNUSED_ARG(arg); + + enginetime++; + + /* This handles the engine time reset */ + snmpv3_get_engine_time_internal(); + + /* restart timer */ + sys_timeout(1000, snmpv3_enginetime_timer, NULL); +} + +err_t +snmpv3_set_user_auth_algo(const char *username, snmpv3_auth_algo_t algo) +{ + struct user_table_entry *p = get_user(username); + + if (p) { + switch (algo) { + case SNMP_V3_AUTH_ALGO_INVAL: + if (p->priv_algo != SNMP_V3_PRIV_ALGO_INVAL) { + /* Privacy MUST be disabled before configuring authentication */ + break; + } else { + p->auth_algo = algo; + return ERR_OK; + } +#if LWIP_SNMP_V3_CRYPTO + case SNMP_V3_AUTH_ALGO_MD5: + case SNMP_V3_AUTH_ALGO_SHA: +#endif + p->auth_algo = algo; + return ERR_OK; + default: + break; + } + } + + return ERR_VAL; +} + +err_t +snmpv3_set_user_priv_algo(const char *username, snmpv3_priv_algo_t algo) +{ + struct user_table_entry *p = get_user(username); + + if (p) { + switch (algo) { +#if LWIP_SNMP_V3_CRYPTO + case SNMP_V3_PRIV_ALGO_AES: + case SNMP_V3_PRIV_ALGO_DES: + if (p->auth_algo == SNMP_V3_AUTH_ALGO_INVAL) { + /* Authentication MUST be enabled before configuring privacy */ + break; + } else { + p->priv_algo = algo; + return ERR_OK; + } +#endif + case SNMP_V3_PRIV_ALGO_INVAL: + p->priv_algo = algo; + return ERR_OK; + default: + break; + } + } + + return ERR_VAL; +} + +err_t +snmpv3_set_user_auth_key(const char *username, const char *password) +{ + struct user_table_entry *p = get_user(username); + const char *engineid; + u8_t engineid_len; + + if (p) { + /* password should be at least 8 characters long */ + if (strlen(password) >= 8) { + memset(p->auth_key, 0, sizeof(p->auth_key)); + snmpv3_get_engine_id(&engineid, &engineid_len); + switch (p->auth_algo) { + case SNMP_V3_AUTH_ALGO_INVAL: + return ERR_OK; +#if LWIP_SNMP_V3_CRYPTO + case SNMP_V3_AUTH_ALGO_MD5: + snmpv3_password_to_key_md5((const u8_t*)password, strlen(password), (const u8_t*)engineid, engineid_len, p->auth_key); + return ERR_OK; + case SNMP_V3_AUTH_ALGO_SHA: + snmpv3_password_to_key_sha((const u8_t*)password, strlen(password), (const u8_t*)engineid, engineid_len, p->auth_key); + return ERR_OK; +#endif + default: + return ERR_VAL; + } + } + } + + return ERR_VAL; +} + +err_t +snmpv3_set_user_priv_key(const char *username, const char *password) +{ + struct user_table_entry *p = get_user(username); + const char *engineid; + u8_t engineid_len; + + if (p) { + /* password should be at least 8 characters long */ + if (strlen(password) >= 8) { + memset(p->priv_key, 0, sizeof(p->priv_key)); + snmpv3_get_engine_id(&engineid, &engineid_len); + switch (p->auth_algo) { + case SNMP_V3_AUTH_ALGO_INVAL: + return ERR_OK; +#if LWIP_SNMP_V3_CRYPTO + case SNMP_V3_AUTH_ALGO_MD5: + snmpv3_password_to_key_md5((const u8_t*)password, strlen(password), (const u8_t*)engineid, engineid_len, p->priv_key); + return ERR_OK; + case SNMP_V3_AUTH_ALGO_SHA: + snmpv3_password_to_key_sha((const u8_t*)password, strlen(password), (const u8_t*)engineid, engineid_len, p->priv_key); + return ERR_OK; +#endif + default: + return ERR_VAL; + } + } + } + + return ERR_VAL; +} + +/** + * @brief Get the storage type of the given username. + * + * @param[in] username pointer to the username + * @param[out] type the storage type + * + * @return ERR_OK if the user was found, ERR_VAL if not. + */ +err_t +snmpv3_get_user_storagetype(const char *username, snmpv3_user_storagetype_t *type) +{ + if (get_user(username) != NULL) { + /* Found user in user table + * In this dummy implementation, storage is permanent because no user can be deleted. + * All changes to users are lost after a reboot.*/ + *type = SNMP_V3_USER_STORAGETYPE_PERMANENT; + return ERR_OK; + } + + return ERR_VAL; +} + +/** + * @param username is a pointer to a string. + * @param auth_algo is a pointer to u8_t. The implementation has to set this if user was found. + * @param auth_key is a pointer to a pointer to a string. Implementation has to set this if user was found. + * @param priv_algo is a pointer to u8_t. The implementation has to set this if user was found. + * @param priv_key is a pointer to a pointer to a string. Implementation has to set this if user was found. + */ +err_t +snmpv3_get_user(const char* username, snmpv3_auth_algo_t *auth_algo, u8_t *auth_key, snmpv3_priv_algo_t *priv_algo, u8_t *priv_key) +{ + const struct user_table_entry *p; + + /* The msgUserName specifies the user (principal) on whose behalf the + message is being exchanged. Note that a zero-length userName will + not match any user, but it can be used for snmpEngineID discovery. */ + if(strlen(username) == 0) { + return ERR_OK; + } + + p = get_user(username); + + if (!p) { + return ERR_VAL; + } + + if (auth_algo != NULL) { + *auth_algo = p->auth_algo; + } + if(auth_key != NULL) { + MEMCPY(auth_key, p->auth_key, sizeof(p->auth_key)); + } + if (priv_algo != NULL) { + *priv_algo = p->priv_algo; + } + if(priv_key != NULL) { + MEMCPY(priv_key, p->priv_key, sizeof(p->priv_key)); + } + return ERR_OK; +} + +/** + * Get engine ID from persistence + */ +void +snmpv3_get_engine_id(const char **id, u8_t *len) +{ + *id = snmpv3_engineid; + *len = snmpv3_engineid_len; +} + +/** + * Store engine ID in persistence + */ +err_t +snmpv3_set_engine_id(const char *id, u8_t len) +{ + MEMCPY(snmpv3_engineid, id, len); + snmpv3_engineid_len = len; + return ERR_OK; +} + +/** + * Get engine boots from persistence. Must be increased on each boot. + */ +u32_t +snmpv3_get_engine_boots(void) +{ + return engineboots; +} + +/** + * Store engine boots in persistence + */ +void +snmpv3_set_engine_boots(u32_t boots) +{ + engineboots = boots; +} + +/** + * RFC3414 2.2.2. + * Once the timer reaches 2147483647 it gets reset to zero and the + * engine boot ups get incremented. + */ +u32_t +snmpv3_get_engine_time(void) +{ + return enginetime; +} + +/** + * Reset current engine time to 0 + */ +void +snmpv3_reset_engine_time(void) +{ + enginetime = 0; +} + +/** + * Initialize dummy SNMPv3 implementation + */ +void +snmpv3_dummy_init(void) +{ + snmpv3_set_engine_id("FOO", 3); + + snmpv3_set_user_auth_algo("lwip", SNMP_V3_AUTH_ALGO_SHA); + snmpv3_set_user_auth_key("lwip", "maplesyrup"); + + snmpv3_set_user_priv_algo("lwip", SNMP_V3_PRIV_ALGO_DES); + snmpv3_set_user_priv_key("lwip", "maplesyrup"); + + /* Start the engine time timer */ + snmpv3_enginetime_timer(NULL); +} + +#endif /* LWIP_SNMP && LWIP_SNMP_V3 */ diff --git a/contrib/examples/snmp/snmp_v3/snmpv3_dummy.h b/contrib/examples/snmp/snmp_v3/snmpv3_dummy.h new file mode 100644 index 00000000000..ba25b6d7d58 --- /dev/null +++ b/contrib/examples/snmp/snmp_v3/snmpv3_dummy.h @@ -0,0 +1,53 @@ +/** + * @file + * Dummy SNMPv3 functions. + */ + +/* + * Copyright (c) 2017 Dirk Ziegelmeier. + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * Author: Dirk Ziegelmeier dziegel@gmx.de + */ + +#ifndef LWIP_HDR_APPS_SNMP_V3_DUMMY_H +#define LWIP_HDR_APPS_SNMP_V3_DUMMY_H + +#include "lwip/apps/snmp_opts.h" +#include "lwip/err.h" +#include "lwip/apps/snmpv3.h" + +#if LWIP_SNMP && LWIP_SNMP_V3 + +err_t snmpv3_set_user_auth_algo(const char *username, snmpv3_auth_algo_t algo); +err_t snmpv3_set_user_priv_algo(const char *username, snmpv3_priv_algo_t algo); +err_t snmpv3_set_user_auth_key(const char *username, const char *password); +err_t snmpv3_set_user_priv_key(const char *username, const char *password); + +void snmpv3_dummy_init(void); + +#endif /* LWIP_SNMP && LWIP_SNMP_V3 */ + +#endif /* LWIP_HDR_APPS_SNMP_V3_DUMMY_H */ diff --git a/contrib/examples/sntp/sntp_example.c b/contrib/examples/sntp/sntp_example.c new file mode 100644 index 00000000000..e9f6ac86c93 --- /dev/null +++ b/contrib/examples/sntp/sntp_example.c @@ -0,0 +1,66 @@ +/* + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Dirk Ziegelmeier dziegel@gmx.de + * + */ + +#include <time.h> + +#include "lwip/opt.h" +#include "lwip/apps/sntp.h" +#include "sntp_example.h" +#include "lwip/netif.h" + +void +sntp_set_system_time(u32_t sec) +{ + char buf[32]; + struct tm current_time_val; + time_t current_time = (time_t)sec; + +#if defined(_WIN32) || defined(WIN32) + localtime_s(¤t_time_val, ¤t_time); +#else + localtime_r(¤t_time, ¤t_time_val); +#endif + + strftime(buf, sizeof(buf), "%d.%m.%Y %H:%M:%S", ¤t_time_val); + LWIP_PLATFORM_DIAG(("SNTP time: %s\n", buf)); +} + +void +sntp_example_init(void) +{ + sntp_setoperatingmode(SNTP_OPMODE_POLL); +#if LWIP_DHCP + sntp_servermode_dhcp(1); /* get SNTP server via DHCP */ +#else /* LWIP_DHCP */ +#if LWIP_IPV4 + sntp_setserver(0, netif_ip_gw4(netif_default)); +#endif /* LWIP_IPV4 */ +#endif /* LWIP_DHCP */ + sntp_init(); +} diff --git a/contrib/examples/sntp/sntp_example.h b/contrib/examples/sntp/sntp_example.h new file mode 100644 index 00000000000..94fc10db217 --- /dev/null +++ b/contrib/examples/sntp/sntp_example.h @@ -0,0 +1,45 @@ +/* + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Dirk Ziegelmeier dziegel@gmx.de + * + */ + +#ifndef SNTP_EXAMPLE_H +#define SNTP_EXAMPLE_H + +#ifdef __cplusplus +extern "C" { +#endif + +void sntp_example_init(void); + +void sntp_set_system_time(u32_t sec); + +#ifdef __cplusplus +} +#endif + +#endif /* SNTP_EXAMPLE_H */ diff --git a/contrib/examples/tftp/tftp_example.c b/contrib/examples/tftp/tftp_example.c new file mode 100644 index 00000000000..3e140146ab7 --- /dev/null +++ b/contrib/examples/tftp/tftp_example.c @@ -0,0 +1,155 @@ +/* + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Dirk Ziegelmeier dziegel@gmx.de + * + */ + +#include <stdio.h> + +#include "lwip/apps/tftp_client.h" +#include "lwip/apps/tftp_server.h" +#include "tftp_example.h" + +#include <string.h> + +#if LWIP_UDP + +/* Define a base directory for TFTP access + * ATTENTION: This code does NOT check for sandboxing, + * i.e. '..' in paths is not checked! */ +#ifndef LWIP_TFTP_EXAMPLE_BASE_DIR +#define LWIP_TFTP_EXAMPLE_BASE_DIR "" +#endif + +/* Define this to a file to get via tftp client */ +#ifndef LWIP_TFTP_EXAMPLE_CLIENT_FILENAME +#define LWIP_TFTP_EXAMPLE_CLIENT_FILENAME "test.bin" +#endif + +/* Define this to a server IP string */ +#ifndef LWIP_TFTP_EXAMPLE_CLIENT_REMOTEIP +#define LWIP_TFTP_EXAMPLE_CLIENT_REMOTEIP "192.168.0.1" +#endif + +static char full_filename[256]; + +static void * +tftp_open_file(const char* fname, u8_t is_write) +{ + snprintf(full_filename, sizeof(full_filename), "%s%s", LWIP_TFTP_EXAMPLE_BASE_DIR, fname); + full_filename[sizeof(full_filename)-1] = 0; + + if (is_write) { + return (void*)fopen(full_filename, "wb"); + } else { + return (void*)fopen(full_filename, "rb"); + } +} + +static void* +tftp_open(const char* fname, const char* mode, u8_t is_write) +{ + LWIP_UNUSED_ARG(mode); + return tftp_open_file(fname, is_write); +} + +static void +tftp_close(void* handle) +{ + fclose((FILE*)handle); +} + +static int +tftp_read(void* handle, void* buf, int bytes) +{ + int ret = fread(buf, 1, bytes, (FILE*)handle); + if (ret <= 0) { + return -1; + } + return ret; +} + +static int +tftp_write(void* handle, struct pbuf* p) +{ + while (p != NULL) { + if (fwrite(p->payload, 1, p->len, (FILE*)handle) != (size_t)p->len) { + return -1; + } + p = p->next; + } + + return 0; +} + +/* For TFTP client only */ +static void +tftp_error(void* handle, int err, const char* msg, int size) +{ + char message[100]; + + LWIP_UNUSED_ARG(handle); + + memset(message, 0, sizeof(message)); + MEMCPY(message, msg, LWIP_MIN(sizeof(message)-1, (size_t)size)); + + printf("TFTP error: %d (%s)", err, message); +} + +static const struct tftp_context tftp = { + tftp_open, + tftp_close, + tftp_read, + tftp_write, + tftp_error +}; + +void +tftp_example_init_server(void) +{ + tftp_init_server(&tftp); +} + +void +tftp_example_init_client(void) +{ + void *f; + err_t err; + ip_addr_t srv; + int ret = ipaddr_aton(LWIP_TFTP_EXAMPLE_CLIENT_REMOTEIP, &srv); + LWIP_ASSERT("ipaddr_aton failed", ret == 1); + + err = tftp_init_client(&tftp); + LWIP_ASSERT("tftp_init_client failed", err == ERR_OK); + + f = tftp_open_file(LWIP_TFTP_EXAMPLE_CLIENT_FILENAME, 1); + LWIP_ASSERT("failed to create file", f != NULL); + + err = tftp_get(f, &srv, TFTP_PORT, LWIP_TFTP_EXAMPLE_CLIENT_FILENAME, TFTP_MODE_OCTET); + LWIP_ASSERT("tftp_get failed", err == ERR_OK); +} + +#endif /* LWIP_UDP */ diff --git a/contrib/examples/tftp/tftp_example.h b/contrib/examples/tftp/tftp_example.h new file mode 100644 index 00000000000..73407004726 --- /dev/null +++ b/contrib/examples/tftp/tftp_example.h @@ -0,0 +1,29 @@ +/* + * To change this license header, choose License Headers in Project Properties. + * To change this template file, choose Tools | Templates + * and open the template in the editor. + */ + +/* + * File: tftp_example.h + * Author: dziegel + * + * Created on February 17, 2018, 3:43 PM + */ + +#ifndef TFTP_EXAMPLE_H +#define TFTP_EXAMPLE_H + +#ifdef __cplusplus +extern "C" { +#endif + +void tftp_example_init_server(void); +void tftp_example_init_client(void); + +#ifdef __cplusplus +} +#endif + +#endif /* TFTP_EXAMPLE_H */ + diff --git a/contrib/ports/CMakeCommon.cmake b/contrib/ports/CMakeCommon.cmake new file mode 100644 index 00000000000..a56b59cb8a4 --- /dev/null +++ b/contrib/ports/CMakeCommon.cmake @@ -0,0 +1,128 @@ +if(NOT ${CMAKE_VERSION} VERSION_LESS "3.10.0") + include_guard(GLOBAL) +endif() + +if(NOT CMAKE_BUILD_TYPE) + message(STATUS "CMAKE_BUILD_TYPE not set - defaulting to Debug build.") + set(CMAKE_BUILD_TYPE Debug CACHE STRING "Choose the type of build, options are: ${CMAKE_CONFIGURATION_TYPES}." FORCE) +endif() +message (STATUS "Build type: ${CMAKE_BUILD_TYPE}") + +set(LWIP_CONTRIB_DIR ${LWIP_DIR}/contrib) + +# ARM mbedtls support https://tls.mbed.org/ +if(NOT DEFINED LWIP_MBEDTLSDIR) + set(LWIP_MBEDTLSDIR ${LWIP_DIR}/../mbedtls) + message(STATUS "LWIP_MBEDTLSDIR not set - using default location ${LWIP_MBEDTLSDIR}") +endif() +if(EXISTS ${LWIP_MBEDTLSDIR}/CMakeLists.txt) + set(LWIP_HAVE_MBEDTLS ON BOOL) + + # Prevent building MBEDTLS programs and tests + set(ENABLE_PROGRAMS OFF CACHE BOOL "") + set(ENABLE_TESTING OFF CACHE BOOL "") + + # mbedtls uses cmake. Sweet! + add_subdirectory(${LWIP_MBEDTLSDIR} mbedtls) + + set (LWIP_MBEDTLS_DEFINITIONS + LWIP_HAVE_MBEDTLS=1 + ) + set (LWIP_MBEDTLS_INCLUDE_DIRS + ${LWIP_MBEDTLSDIR}/include + ) + set (LWIP_MBEDTLS_LINK_LIBRARIES + mbedtls + mbedcrypto + mbedx509 + ) +endif() + +set(LWIP_COMPILER_FLAGS_GNU_CLANG + $<$CONFIG:Debug:-Og> + $<$CONFIG:Debug:-g> + $<$CONFIG:Release:-O3> + -Wall + -pedantic + -Werror + -Wparentheses + -Wsequence-point + -Wswitch-default + -Wextra + -Wundef + -Wshadow + -Wpointer-arith + -Wcast-qual + -Wwrite-strings + $<$<COMPILE_LANGUAGE:C>:-Wold-style-definition> + -Wcast-align + $<$<COMPILE_LANGUAGE:C>:-Wmissing-prototypes> + $<$<COMPILE_LANGUAGE:C>:-Wnested-externs> + -Wunreachable-code + -Wuninitialized + -Wmissing-prototypes + -Waggregate-return + -Wlogical-not-parentheses +) + +if (NOT LWIP_HAVE_MBEDTLS) + list(APPEND LWIP_COMPILER_FLAGS_GNU_CLANG + -Wredundant-decls + $<$<COMPILE_LANGUAGE:C>:-Wc++-compat> + ) +endif() + +if(CMAKE_C_COMPILER_ID STREQUAL "GNU") + list(APPEND LWIP_COMPILER_FLAGS_GNU_CLANG + -Wlogical-op + -Wtrampolines + ) + + if (NOT LWIP_HAVE_MBEDTLS) + list(APPEND LWIP_COMPILER_FLAGS_GNU_CLANG + $<$<COMPILE_LANGUAGE:C>:-Wc90-c99-compat> + ) + endif() + + if(NOT CMAKE_C_COMPILER_VERSION VERSION_LESS 4.9) + if(LWIP_USE_SANITIZERS) + list(APPEND LWIP_COMPILER_FLAGS_GNU_CLANG + -fsanitize=address + -fsanitize=undefined + -fno-sanitize=alignment + -fstack-protector + -fstack-check + ) + set(LWIP_SANITIZER_LIBS asan ubsan) + endif() + endif() + + set(LWIP_COMPILER_FLAGS ${LWIP_COMPILER_FLAGS_GNU_CLANG}) +endif() + +if(CMAKE_C_COMPILER_ID STREQUAL "Clang") + list(APPEND LWIP_COMPILER_FLAGS_GNU_CLANG + -Wdocumentation + -Wno-documentation-deprecated-sync + ) + + if(LWIP_USE_SANITIZERS) + list(APPEND LWIP_COMPILER_FLAGS_GNU_CLANG + -fsanitize=address + -fsanitize=undefined + -fno-sanitize=alignment + ) + set(LWIP_SANITIZER_LIBS asan ubsan) + endif() + + set(LWIP_COMPILER_FLAGS ${LWIP_COMPILER_FLAGS_GNU_CLANG}) +endif() + +if(CMAKE_C_COMPILER_ID STREQUAL "MSVC") + set(LWIP_COMPILER_FLAGS + $<$CONFIG:Debug:/Od> + $<$CONFIG:Release:/Ox> + /W4 + /WX + ) +endif() diff --git a/contrib/ports/Common.allports.mk b/contrib/ports/Common.allports.mk new file mode 100644 index 00000000000..049ba6afb1e --- /dev/null +++ b/contrib/ports/Common.allports.mk @@ -0,0 +1,91 @@ +# +# Copyright (c) 2001, 2002 Swedish Institute of Computer Science. +# All rights reserved. +# +# Redistribution and use in source and binary forms, with or without modification, +# are permitted provided that the following conditions are met: +# +# 1. Redistributions of source code must retain the above copyright notice, +# this list of conditions and the following disclaimer. +# 2. Redistributions in binary form must reproduce the above copyright notice, +# this list of conditions and the following disclaimer in the documentation +# and/or other materials provided with the distribution. +# 3. The name of the author may not be used to endorse or promote products +# derived from this software without specific prior written permission. +# +# THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED +# WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF +# MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT +# SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, +# EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT +# OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING +# IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY +# OF SUCH DAMAGE. +# +# This file is part of the lwIP TCP/IP stack. +# +# Author: Adam Dunkels adam@sics.se +# + +#CC=gcc +#CC=clang +CCDEP?=$(CC) + +CFLAGS+=-g -DLWIP_DEBUG -Wall -pedantic -Werror \ + -Wparentheses -Wsequence-point -Wswitch-default \ + -Wextra -Wundef -Wshadow -Wpointer-arith -Wcast-qual \ + -Wc++-compat -Wwrite-strings -Wold-style-definition -Wcast-align \ + -Wmissing-prototypes -Wnested-externs \ + -Wunreachable-code -Wuninitialized -Wmissing-prototypes \ + -Wredundant-decls -Waggregate-return -Wlogical-not-parentheses +# -Wconversion -Wsign-compare -Wmissing-include-dirs + +ifeq (,$(findstring clang,$(CC))) +CFLAGS+= -Wlogical-op -Wc90-c99-compat -Wtrampolines +# if GCC is newer than 4.8/4.9 you may use: +#CFLAGS:=$(CFLAGS) -fsanitize=address -fstack-protector -fstack-check -fsanitize=undefined -fno-sanitize=alignment +else +# we cannot sanitize alignment on x86-64 targets because clang wants 64 bit alignment +CFLAGS+= -fsanitize=address -fsanitize=undefined -fno-sanitize=alignment -Wdocumentation -Wno-documentation-deprecated-sync +endif + +CONTRIBDIR?=../../.. +ARFLAGS?=rs + +#Set this to where you have the lwip core module checked out from git +#default assumes it's a dir above the contrib module +LWIPDIR?=$(CONTRIBDIR)/.. + +CFLAGS+=-I. \ + -I$(CONTRIBDIR) \ + -I$(LWIPDIR)/include \ + -I$(LWIPARCH)/include + +# Add include path and link to mbedTLS lib if available +MBEDTLSDIR?=$(LWIPDIR)/../mbedtls +ifneq (,$(wildcard $(MBEDTLSDIR)/include/mbedtls/*.h)) +LDFLAGS+=-L$(MBEDTLSDIR)/library -lmbedtls -lmbedcrypto -lmbedx509 +CFLAGS+=-I$(MBEDTLSDIR)/include -Wno-redundant-decls -DLWIP_HAVE_MBEDTLS=1 -Wno-c90-c99-compat +endif + +include $(CONTRIBDIR)/Filelists.mk +include $(LWIPDIR)/Filelists.mk + +# LWIPFILES: All the above. +LWIPFILES=$(LWIPNOAPPSFILES) $(ARCHFILES) +LWIPOBJS=$(notdir $(LWIPFILES:.c=.o)) + +LWIPLIBCOMMON=liblwipcommon.a +$(LWIPLIBCOMMON): $(LWIPOBJS) + $(AR) $(ARFLAGS) $(LWIPLIBCOMMON) $? + +APPFILES=$(CONTRIBAPPFILES) $(LWIPAPPFILES) +APPLIB=liblwipapps.a +APPOBJS=$(notdir $(APPFILES:.c=.o)) +$(APPLIB): $(APPOBJS) + $(AR) $(ARFLAGS) $(APPLIB) $? + +%.o: + $(CC) $(CFLAGS) -c $< diff --git a/contrib/ports/freertos/include/arch/sys_arch.h b/contrib/ports/freertos/include/arch/sys_arch.h new file mode 100644 index 00000000000..0cfc889decb --- /dev/null +++ b/contrib/ports/freertos/include/arch/sys_arch.h @@ -0,0 +1,95 @@ +/* + * Copyright (c) 2017 Simon Goldschmidt + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Simon Goldschmdit goldsimon@gmx.de + * + */ +#ifndef LWIP_ARCH_SYS_ARCH_H +#define LWIP_ARCH_SYS_ARCH_H + +#include "lwip/opt.h" +#include "lwip/arch.h" + +/** This is returned by _fromisr() sys functions to tell the outermost function + * that a higher priority task was woken and the scheduler needs to be invoked. + */ +#define ERR_NEED_SCHED 123 + +/* This port includes FreeRTOS headers in sys_arch.c only. + * FreeRTOS uses pointers as object types. We use wrapper structs instead of + * void pointers directly to get a tiny bit of type safety. + */ + +void sys_arch_msleep(u32_t delay_ms); +#define sys_msleep(ms) sys_arch_msleep(ms) + +#if SYS_LIGHTWEIGHT_PROT +typedef u32_t sys_prot_t; +#endif /* SYS_LIGHTWEIGHT_PROT */ + +#if !LWIP_COMPAT_MUTEX +struct _sys_mut { + void *mut; +}; +typedef struct _sys_mut sys_mutex_t; +#define sys_mutex_valid_val(mutex) ((mutex).mut != NULL) +#define sys_mutex_valid(mutex) (((mutex) != NULL) && sys_mutex_valid_val(*(mutex))) +#define sys_mutex_set_invalid(mutex) ((mutex)->mut = NULL) +#endif /* !LWIP_COMPAT_MUTEX */ + +struct _sys_sem { + void *sem; +}; +typedef struct _sys_sem sys_sem_t; +#define sys_sem_valid_val(sema) ((sema).sem != NULL) +#define sys_sem_valid(sema) (((sema) != NULL) && sys_sem_valid_val(*(sema))) +#define sys_sem_set_invalid(sema) ((sema)->sem = NULL) + +struct _sys_mbox { + void *mbx; +}; +typedef struct _sys_mbox sys_mbox_t; +#define sys_mbox_valid_val(mbox) ((mbox).mbx != NULL) +#define sys_mbox_valid(mbox) (((mbox) != NULL) && sys_mbox_valid_val(*(mbox))) +#define sys_mbox_set_invalid(mbox) ((mbox)->mbx = NULL) + +struct _sys_thread { + void *thread_handle; +}; +typedef struct _sys_thread sys_thread_t; + +#if LWIP_NETCONN_SEM_PER_THREAD +sys_sem_t* sys_arch_netconn_sem_get(void); +void sys_arch_netconn_sem_alloc(void); +void sys_arch_netconn_sem_free(void); +#define LWIP_NETCONN_THREAD_SEM_GET() sys_arch_netconn_sem_get() +#define LWIP_NETCONN_THREAD_SEM_ALLOC() sys_arch_netconn_sem_alloc() +#define LWIP_NETCONN_THREAD_SEM_FREE() sys_arch_netconn_sem_free() +#endif /* LWIP_NETCONN_SEM_PER_THREAD */ + +#endif /* LWIP_ARCH_SYS_ARCH_H */ diff --git a/contrib/ports/freertos/sys_arch.c b/contrib/ports/freertos/sys_arch.c new file mode 100644 index 00000000000..856835384ab --- /dev/null +++ b/contrib/ports/freertos/sys_arch.c @@ -0,0 +1,607 @@ +/* + * Copyright (c) 2017 Simon Goldschmidt + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without modification, + * are permitted provided that the following conditions are met: + * + * 1. Redistributions of source code must retain the above copyright notice, + * this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright notice, + * this list of conditions and the following disclaimer in the documentation + * and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT + * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, + * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT + * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING + * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * This file is part of the lwIP TCP/IP stack. + * + * Author: Simon Goldschmidt goldsimon@gmx.de + * + */ + +/* lwIP includes. */ +#include "lwip/debug.h" +#include "lwip/def.h" +#include "lwip/sys.h" +#include "lwip/mem.h" +#include "lwip/stats.h" +#include "lwip/tcpip.h" +#include "FreeRTOS.h" +#include "semphr.h" +#include "task.h" + +/** Set this to 1 if you want the stack size passed to sys_thread_new() to be + * interpreted as number of stack words (FreeRTOS-like). + * Default is that they are interpreted as byte count (lwIP-like). + */ +#ifndef LWIP_FREERTOS_THREAD_STACKSIZE_IS_STACKWORDS +#define LWIP_FREERTOS_THREAD_STACKSIZE_IS_STACKWORDS 0 +#endif + +/** Set this to 1 to use a mutex for SYS_ARCH_PROTECT() critical regions. + * Default is 0 and locks interrupts/scheduler for SYS_ARCH_PROTECT(). + */ +#ifndef LWIP_FREERTOS_SYS_ARCH_PROTECT_USES_MUTEX +#define LWIP_FREERTOS_SYS_ARCH_PROTECT_USES_MUTEX 0 +#endif + +/** Set this to 1 to include a sanity check that SYS_ARCH_PROTECT() and + * SYS_ARCH_UNPROTECT() are called matching. + */ +#ifndef LWIP_FREERTOS_SYS_ARCH_PROTECT_SANITY_CHECK +#define LWIP_FREERTOS_SYS_ARCH_PROTECT_SANITY_CHECK 0 +#endif + +/** Set this to 1 to let sys_mbox_free check that queues are empty when freed */ +#ifndef LWIP_FREERTOS_CHECK_QUEUE_EMPTY_ON_FREE +#define LWIP_FREERTOS_CHECK_QUEUE_EMPTY_ON_FREE 0 +#endif + +/** Set this to 1 to enable core locking check functions in this port. + * For this to work, you'll have to define LWIP_ASSERT_CORE_LOCKED() + * and LWIP_MARK_TCPIP_THREAD() correctly in your lwipopts.h! */ +#ifndef LWIP_FREERTOS_CHECK_CORE_LOCKING +#define LWIP_FREERTOS_CHECK_CORE_LOCKING 0 +#endif + +/** Set this to 0 to implement sys_now() yourself, e.g. using a hw timer. + * Default is 1, where FreeRTOS ticks are used to calculate back to ms. + */ +#ifndef LWIP_FREERTOS_SYS_NOW_FROM_FREERTOS +#define LWIP_FREERTOS_SYS_NOW_FROM_FREERTOS 1 +#endif + +#if !configSUPPORT_DYNAMIC_ALLOCATION +# error "lwIP FreeRTOS port requires configSUPPORT_DYNAMIC_ALLOCATION" +#endif +#if !INCLUDE_vTaskDelay +# error "lwIP FreeRTOS port requires INCLUDE_vTaskDelay" +#endif +#if !INCLUDE_vTaskSuspend +# error "lwIP FreeRTOS port requires INCLUDE_vTaskSuspend" +#endif +#if LWIP_FREERTOS_SYS_ARCH_PROTECT_USES_MUTEX || !LWIP_COMPAT_MUTEX +#if !configUSE_MUTEXES +# error "lwIP FreeRTOS port requires configUSE_MUTEXES" +#endif +#endif + +#if SYS_LIGHTWEIGHT_PROT && LWIP_FREERTOS_SYS_ARCH_PROTECT_USES_MUTEX +static SemaphoreHandle_t sys_arch_protect_mutex; +#endif +#if SYS_LIGHTWEIGHT_PROT && LWIP_FREERTOS_SYS_ARCH_PROTECT_SANITY_CHECK +static sys_prot_t sys_arch_protect_nesting; +#endif + +/* Initialize this module (see description in sys.h) */ +void +sys_init(void) +{ +#if SYS_LIGHTWEIGHT_PROT && LWIP_FREERTOS_SYS_ARCH_PROTECT_USES_MUTEX + /* initialize sys_arch_protect global mutex */ + sys_arch_protect_mutex = xSemaphoreCreateRecursiveMutex(); + LWIP_ASSERT("failed to create sys_arch_protect mutex", + sys_arch_protect_mutex != NULL); +#endif /* SYS_LIGHTWEIGHT_PROT && LWIP_FREERTOS_SYS_ARCH_PROTECT_USES_MUTEX */ +} + +#if configUSE_16_BIT_TICKS == 1 +#error This port requires 32 bit ticks or timer overflow will fail +#endif + +#if LWIP_FREERTOS_SYS_NOW_FROM_FREERTOS +u32_t +sys_now(void) +{ + return xTaskGetTickCount() * portTICK_PERIOD_MS; +} +#endif + +u32_t +sys_jiffies(void) +{ + return xTaskGetTickCount(); +} + +#if SYS_LIGHTWEIGHT_PROT + +sys_prot_t +sys_arch_protect(void) +{ +#if LWIP_FREERTOS_SYS_ARCH_PROTECT_USES_MUTEX + BaseType_t ret; + LWIP_ASSERT("sys_arch_protect_mutex != NULL", sys_arch_protect_mutex != NULL); + + ret = xSemaphoreTakeRecursive(sys_arch_protect_mutex, portMAX_DELAY); + LWIP_ASSERT("sys_arch_protect failed to take the mutex", ret == pdTRUE); +#else /* LWIP_FREERTOS_SYS_ARCH_PROTECT_USES_MUTEX */ + taskENTER_CRITICAL(); +#endif /* LWIP_FREERTOS_SYS_ARCH_PROTECT_USES_MUTEX */ +#if LWIP_FREERTOS_SYS_ARCH_PROTECT_SANITY_CHECK + { + /* every nested call to sys_arch_protect() returns an increased number */ + sys_prot_t ret = sys_arch_protect_nesting; + sys_arch_protect_nesting++; + LWIP_ASSERT("sys_arch_protect overflow", sys_arch_protect_nesting > ret); + return ret; + } +#else + return 1; +#endif +} + +void +sys_arch_unprotect(sys_prot_t pval) +{ +#if LWIP_FREERTOS_SYS_ARCH_PROTECT_USES_MUTEX + BaseType_t ret; +#endif +#if LWIP_FREERTOS_SYS_ARCH_PROTECT_SANITY_CHECK + LWIP_ASSERT("unexpected sys_arch_protect_nesting", sys_arch_protect_nesting > 0); + sys_arch_protect_nesting--; + LWIP_ASSERT("unexpected sys_arch_protect_nesting", sys_arch_protect_nesting == pval); +#endif + +#if LWIP_FREERTOS_SYS_ARCH_PROTECT_USES_MUTEX + LWIP_ASSERT("sys_arch_protect_mutex != NULL", sys_arch_protect_mutex != NULL); + + ret = xSemaphoreGiveRecursive(sys_arch_protect_mutex); + LWIP_ASSERT("sys_arch_unprotect failed to give the mutex", ret == pdTRUE); +#else /* LWIP_FREERTOS_SYS_ARCH_PROTECT_USES_MUTEX */ + taskEXIT_CRITICAL(); +#endif /* LWIP_FREERTOS_SYS_ARCH_PROTECT_USES_MUTEX */ + LWIP_UNUSED_ARG(pval); +} + +#endif /* SYS_LIGHTWEIGHT_PROT */ + +void +sys_arch_msleep(u32_t delay_ms) +{ + TickType_t delay_ticks = delay_ms / portTICK_RATE_MS; + vTaskDelay(delay_ticks); +} + +#if !LWIP_COMPAT_MUTEX + +/* Create a new mutex*/ +err_t +sys_mutex_new(sys_mutex_t *mutex) +{ + LWIP_ASSERT("mutex != NULL", mutex != NULL); + + mutex->mut = xSemaphoreCreateRecursiveMutex(); + if(mutex->mut == NULL) { + SYS_STATS_INC(mutex.err); + return ERR_MEM; + } + SYS_STATS_INC_USED(mutex); + return ERR_OK; +} + +void +sys_mutex_lock(sys_mutex_t *mutex) +{ + BaseType_t ret; + LWIP_ASSERT("mutex != NULL", mutex != NULL); + LWIP_ASSERT("mutex->mut != NULL", mutex->mut != NULL); + + ret = xSemaphoreTakeRecursive(mutex->mut, portMAX_DELAY); + LWIP_ASSERT("failed to take the mutex", ret == pdTRUE); +} + +void +sys_mutex_unlock(sys_mutex_t *mutex) +{ + BaseType_t ret; + LWIP_ASSERT("mutex != NULL", mutex != NULL); + LWIP_ASSERT("mutex->mut != NULL", mutex->mut != NULL); + + ret = xSemaphoreGiveRecursive(mutex->mut); + LWIP_ASSERT("failed to give the mutex", ret == pdTRUE); +} + +void +sys_mutex_free(sys_mutex_t *mutex) +{ + LWIP_ASSERT("mutex != NULL", mutex != NULL); + LWIP_ASSERT("mutex->mut != NULL", mutex->mut != NULL); + + SYS_STATS_DEC(mutex.used); + vSemaphoreDelete(mutex->mut); + mutex->mut = NULL; +} + +#endif /* !LWIP_COMPAT_MUTEX */ + +err_t +sys_sem_new(sys_sem_t *sem, u8_t initial_count) +{ + LWIP_ASSERT("sem != NULL", sem != NULL); + LWIP_ASSERT("initial_count invalid (not 0 or 1)", + (initial_count == 0) || (initial_count == 1)); + + sem->sem = xSemaphoreCreateBinary(); + if(sem->sem == NULL) { + SYS_STATS_INC(sem.err); + return ERR_MEM; + } + SYS_STATS_INC_USED(sem); + + if(initial_count == 1) { + BaseType_t ret = xSemaphoreGive(sem->sem); + LWIP_ASSERT("sys_sem_new: initial give failed", ret == pdTRUE); + } + return ERR_OK; +} + +void +sys_sem_signal(sys_sem_t *sem) +{ + BaseType_t ret; + LWIP_ASSERT("sem != NULL", sem != NULL); + LWIP_ASSERT("sem->sem != NULL", sem->sem != NULL); + + ret = xSemaphoreGive(sem->sem); + /* queue full is OK, this is a signal only... */ + LWIP_ASSERT("sys_sem_signal: sane return value", + (ret == pdTRUE) || (ret == errQUEUE_FULL)); +} + +u32_t +sys_arch_sem_wait(sys_sem_t *sem, u32_t timeout_ms) +{ + BaseType_t ret; + LWIP_ASSERT("sem != NULL", sem != NULL); + LWIP_ASSERT("sem->sem != NULL", sem->sem != NULL); + + if(!timeout_ms) { + /* wait infinite */ + ret = xSemaphoreTake(sem->sem, portMAX_DELAY); + LWIP_ASSERT("taking semaphore failed", ret == pdTRUE); + } else { + TickType_t timeout_ticks = timeout_ms / portTICK_RATE_MS; + ret = xSemaphoreTake(sem->sem, timeout_ticks); + if (ret == errQUEUE_EMPTY) { + /* timed out */ + return SYS_ARCH_TIMEOUT; + } + LWIP_ASSERT("taking semaphore failed", ret == pdTRUE); + } + + /* Old versions of lwIP required us to return the time waited. + This is not the case any more. Just returning != SYS_ARCH_TIMEOUT + here is enough. */ + return 1; +} + +void +sys_sem_free(sys_sem_t *sem) +{ + LWIP_ASSERT("sem != NULL", sem != NULL); + LWIP_ASSERT("sem->sem != NULL", sem->sem != NULL); + + SYS_STATS_DEC(sem.used); + vSemaphoreDelete(sem->sem); + sem->sem = NULL; +} + +err_t +sys_mbox_new(sys_mbox_t *mbox, int size) +{ + LWIP_ASSERT("mbox != NULL", mbox != NULL); + LWIP_ASSERT("size > 0", size > 0); + + mbox->mbx = xQueueCreate((UBaseType_t)size, sizeof(void *)); + if(mbox->mbx == NULL) { + SYS_STATS_INC(mbox.err); + return ERR_MEM; + } + SYS_STATS_INC_USED(mbox); + return ERR_OK; +} + +void +sys_mbox_post(sys_mbox_t *mbox, void *msg) +{ + BaseType_t ret; + LWIP_ASSERT("mbox != NULL", mbox != NULL); + LWIP_ASSERT("mbox->mbx != NULL", mbox->mbx != NULL); + + ret = xQueueSendToBack(mbox->mbx, &msg, portMAX_DELAY); + LWIP_ASSERT("mbox post failed", ret == pdTRUE); +} + +err_t +sys_mbox_trypost(sys_mbox_t *mbox, void *msg) +{ + BaseType_t ret; + LWIP_ASSERT("mbox != NULL", mbox != NULL); + LWIP_ASSERT("mbox->mbx != NULL", mbox->mbx != NULL); + + ret = xQueueSendToBack(mbox->mbx, &msg, 0); + if (ret == pdTRUE) { + return ERR_OK; + } else { + LWIP_ASSERT("mbox trypost failed", ret == errQUEUE_FULL); + SYS_STATS_INC(mbox.err); + return ERR_MEM; + } +} + +err_t +sys_mbox_trypost_fromisr(sys_mbox_t *mbox, void *msg) +{ + BaseType_t ret; + BaseType_t xHigherPriorityTaskWoken = pdFALSE; + LWIP_ASSERT("mbox != NULL", mbox != NULL); + LWIP_ASSERT("mbox->mbx != NULL", mbox->mbx != NULL); + + ret = xQueueSendToBackFromISR(mbox->mbx, &msg, &xHigherPriorityTaskWoken); + if (ret == pdTRUE) { + if (xHigherPriorityTaskWoken == pdTRUE) { + return ERR_NEED_SCHED; + } + return ERR_OK; + } else { + LWIP_ASSERT("mbox trypost failed", ret == errQUEUE_FULL); + SYS_STATS_INC(mbox.err); + return ERR_MEM; + } +} + +u32_t +sys_arch_mbox_fetch(sys_mbox_t *mbox, void **msg, u32_t timeout_ms) +{ + BaseType_t ret; + void *msg_dummy; + LWIP_ASSERT("mbox != NULL", mbox != NULL); + LWIP_ASSERT("mbox->mbx != NULL", mbox->mbx != NULL); + + if (!msg) { + msg = &msg_dummy; + } + + if (!timeout_ms) { + /* wait infinite */ + ret = xQueueReceive(mbox->mbx, &(*msg), portMAX_DELAY); + LWIP_ASSERT("mbox fetch failed", ret == pdTRUE); + } else { + TickType_t timeout_ticks = timeout_ms / portTICK_RATE_MS; + ret = xQueueReceive(mbox->mbx, &(*msg), timeout_ticks); + if (ret == errQUEUE_EMPTY) { + /* timed out */ + *msg = NULL; + return SYS_ARCH_TIMEOUT; + } + LWIP_ASSERT("mbox fetch failed", ret == pdTRUE); + } + + /* Old versions of lwIP required us to return the time waited. + This is not the case any more. Just returning != SYS_ARCH_TIMEOUT + here is enough. */ + return 1; +} + +u32_t +sys_arch_mbox_tryfetch(sys_mbox_t *mbox, void **msg) +{ + BaseType_t ret; + void *msg_dummy; + LWIP_ASSERT("mbox != NULL", mbox != NULL); + LWIP_ASSERT("mbox->mbx != NULL", mbox->mbx != NULL); + + if (!msg) { + msg = &msg_dummy; + } + + ret = xQueueReceive(mbox->mbx, &(*msg), 0); + if (ret == errQUEUE_EMPTY) { + *msg = NULL; + return SYS_MBOX_EMPTY; + } + LWIP_ASSERT("mbox fetch failed", ret == pdTRUE); + + return 0; +} + +void +sys_mbox_free(sys_mbox_t *mbox) +{ + LWIP_ASSERT("mbox != NULL", mbox != NULL); + LWIP_ASSERT("mbox->mbx != NULL", mbox->mbx != NULL); + +#if LWIP_FREERTOS_CHECK_QUEUE_EMPTY_ON_FREE + { + UBaseType_t msgs_waiting = uxQueueMessagesWaiting(mbox->mbx); + LWIP_ASSERT("mbox quence not empty", msgs_waiting == 0); + + if (msgs_waiting != 0) { + SYS_STATS_INC(mbox.err); + } + } +#endif + + vQueueDelete(mbox->mbx); + + SYS_STATS_DEC(mbox.used); +} + +sys_thread_t +sys_thread_new(const char *name, lwip_thread_fn thread, void *arg, int stacksize, int prio) +{ + TaskHandle_t rtos_task; + BaseType_t ret; + sys_thread_t lwip_thread; + size_t rtos_stacksize; + + LWIP_ASSERT("invalid stacksize", stacksize > 0); +#if LWIP_FREERTOS_THREAD_STACKSIZE_IS_STACKWORDS + rtos_stacksize = (size_t)stacksize; +#else + rtos_stacksize = (size_t)stacksize / sizeof(StackType_t); +#endif + + /* lwIP's lwip_thread_fn matches FreeRTOS' TaskFunction_t, so we can pass the + thread function without adaption here. */ + ret = xTaskCreate(thread, name, (configSTACK_DEPTH_TYPE)rtos_stacksize, arg, prio, &rtos_task); + LWIP_ASSERT("task creation failed", ret == pdTRUE); + + lwip_thread.thread_handle = rtos_task; + return lwip_thread; +} + +#if LWIP_NETCONN_SEM_PER_THREAD +#if configNUM_THREAD_LOCAL_STORAGE_POINTERS > 0 + +sys_sem_t * +sys_arch_netconn_sem_get(void) +{ + void* ret; + TaskHandle_t task = xTaskGetCurrentTaskHandle(); + LWIP_ASSERT("task != NULL", task != NULL); + + ret = pvTaskGetThreadLocalStoragePointer(task, 0); + return ret; +} + +void +sys_arch_netconn_sem_alloc(void) +{ + void *ret; + TaskHandle_t task = xTaskGetCurrentTaskHandle(); + LWIP_ASSERT("task != NULL", task != NULL); + + ret = pvTaskGetThreadLocalStoragePointer(task, 0); + if(ret == NULL) { + sys_sem_t *sem; + err_t err; + /* need to allocate the memory for this semaphore */ + sem = mem_malloc(sizeof(sys_sem_t)); + LWIP_ASSERT("sem != NULL", sem != NULL); + err = sys_sem_new(sem, 0); + LWIP_ASSERT("err == ERR_OK", err == ERR_OK); + LWIP_ASSERT("sem invalid", sys_sem_valid(sem)); + vTaskSetThreadLocalStoragePointer(task, 0, sem); + } +} + +void sys_arch_netconn_sem_free(void) +{ + void* ret; + TaskHandle_t task = xTaskGetCurrentTaskHandle(); + LWIP_ASSERT("task != NULL", task != NULL); + + ret = pvTaskGetThreadLocalStoragePointer(task, 0); + if(ret != NULL) { + sys_sem_t *sem = ret; + sys_sem_free(sem); + mem_free(sem); + vTaskSetThreadLocalStoragePointer(task, 0, NULL); + } +} + +#else /* configNUM_THREAD_LOCAL_STORAGE_POINTERS > 0 */ +#error LWIP_NETCONN_SEM_PER_THREAD needs configNUM_THREAD_LOCAL_STORAGE_POINTERS +#endif /* configNUM_THREAD_LOCAL_STORAGE_POINTERS > 0 */ + +#endif /* LWIP_NETCONN_SEM_PER_THREAD */ + +#if LWIP_FREERTOS_CHECK_CORE_LOCKING +#if LWIP_TCPIP_CORE_LOCKING + +/** Flag the core lock held. A counter for recursive locks. */ +static u8_t lwip_core_lock_count; +static TaskHandle_t lwip_core_lock_holder_thread; + +void +sys_lock_tcpip_core(void) +{ + sys_mutex_lock(&lock_tcpip_core); + if (lwip_core_lock_count == 0) { + lwip_core_lock_holder_thread = xTaskGetCurrentTaskHandle(); + } + lwip_core_lock_count++; +} + +void +sys_unlock_tcpip_core(void) +{ + lwip_core_lock_count--; + if (lwip_core_lock_count == 0) { + lwip_core_lock_holder_thread = 0; + } + sys_mutex_unlock(&lock_tcpip_core); +} + +#endif /* LWIP_TCPIP_CORE_LOCKING */ + +#if !NO_SYS +static TaskHandle_t lwip_tcpip_thread; +#endif + +void +sys_mark_tcpip_thread(void) +{ +#if !NO_SYS + lwip_tcpip_thread = xTaskGetCurrentTaskHandle(); +#endif +} + +void +sys_check_core_locking(void) +{ + /* Embedded systems should check we are NOT in an interrupt context here */ + /* E.g. core Cortex-M3/M4 ports: + configASSERT( ( portNVIC_INT_CTRL_REG & portVECTACTIVE_MASK ) == 0 ); + + Instead, we use more generic FreeRTOS functions here, which should fail from ISR: */ + taskENTER_CRITICAL(); + taskEXIT_CRITICAL(); + +#if !NO_SYS + if (lwip_tcpip_thread != 0) { + TaskHandle_t current_thread = xTaskGetCurrentTaskHandle(); + +#if LWIP_TCPIP_CORE_LOCKING + LWIP_ASSERT("Function called without core lock", + current_thread == lwip_core_lock_holder_thread && lwip_core_lock_count > 0); +#else /* LWIP_TCPIP_CORE_LOCKING */ + LWIP_ASSERT("Function called from wrong thread", current_thread == lwip_tcpip_thread); +#endif /* LWIP_TCPIP_CORE_LOCKING */ + } +#endif /* !NO_SYS */ +} + +#endif /* LWIP_FREERTOS_CHECK_CORE_LOCKING*/ diff --git a/contrib/ports/unix/Common.mk b/contrib/ports/unix/Common.mk new file mode 100644 index 00000000000..f80a9807b38 --- /dev/null +++ b/contrib/ports/unix/Common.mk @@ -0,0 +1,51 @@ +# +# Copyright (c) 2001, 2002 Swedish Institute of Computer Science. +# All rights reserved. +# +# Redistribution and use in source and binary forms, with or without modification, +# are permitted provided that the following conditions are met: +# +# 1. Redistributions of source code must retain the above copyright notice, +# this list of conditions and the following disclaimer. +# 2. Redistributions in binary form must reproduce the above copyright notice, +# this list of conditions and the following disclaimer in the documentation +# and/or other materials provided with the distribution. +# 3. The name of the author may not be used to endorse or promote products +# derived from this software without specific prior written permission. +# +# THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED +# WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF +# MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT +# SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, +# EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT +# OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING +# IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY +# OF SUCH DAMAGE. +# +# This file is part of the lwIP TCP/IP stack. +# +# Author: Adam Dunkels adam@sics.se +# + +# Architecture specific files. +LWIPARCH?=$(CONTRIBDIR)/ports/unix/port +SYSARCH?=$(LWIPARCH)/sys_arch.c +ARCHFILES=$(LWIPARCH)/perf.c \ + $(SYSARCH) \ + $(LWIPARCH)/netif/tapif.c \ + $(LWIPARCH)/netif/list.c \ + $(LWIPARCH)/netif/sio.c \ + $(LWIPARCH)/netif/fifo.c + +UNIX_COMMON_MK_DIR := $(dir $(abspath $(lastword $(MAKEFILE_LIST)))) +include $(UNIX_COMMON_MK_DIR)../Common.allports.mk + +LDFLAGS+=-lutil + +UNAME_S:= $(shell uname -s) +ifneq ($(UNAME_S),Darwin) +# Darwin doesn't have pthreads or POSIX real-time extensions libs +LDFLAGS+=-pthread -lrt +endif diff --git a/contrib/ports/unix/Filelists.cmake b/contrib/ports/unix/Filelists.cmake new file mode 100644 index 00000000000..84bfdedf00f --- /dev/null +++ b/contrib/ports/unix/Filelists.cmake @@ -0,0 +1,44 @@ +# This file is indended to be included in end-user CMakeLists.txt +# include(/path/to/Filelists.cmake) +# It assumes the variable LWIP_CONTRIB_DIR is defined pointing to the +# root path of lwIP/contrib sources. +# +# This file is NOT designed (on purpose) to be used as cmake +# subdir via add_subdirectory() +# The intention is to provide greater flexibility to users to +# create their own targets using the *_SRCS variables. + +if(NOT ${CMAKE_VERSION} VERSION_LESS "3.10.0") + include_guard(GLOBAL) +endif() + +set(lwipcontribportunix_SRCS + ${LWIP_CONTRIB_DIR}/ports/unix/port/sys_arch.c + ${LWIP_CONTRIB_DIR}/ports/unix/port/perf.c +) + +set(lwipcontribportunixnetifs_SRCS + ${LWIP_CONTRIB_DIR}/ports/unix/port/netif/tapif.c + ${LWIP_CONTRIB_DIR}/ports/unix/port/netif/list.c + ${LWIP_CONTRIB_DIR}/ports/unix/port/netif/sio.c + ${LWIP_CONTRIB_DIR}/ports/unix/port/netif/fifo.c +) + +add_library(lwipcontribportunix EXCLUDE_FROM_ALL ${lwipcontribportunix_SRCS} ${lwipcontribportunixnetifs_SRCS}) +target_include_directories(lwipcontribportunix PRIVATE ${LWIP_INCLUDE_DIRS} ${LWIP_MBEDTLS_INCLUDE_DIRS}) +target_compile_options(lwipcontribportunix PRIVATE ${LWIP_COMPILER_FLAGS}) +target_compile_definitions(lwipcontribportunix PRIVATE ${LWIP_DEFINITIONS} ${LWIP_MBEDTLS_DEFINITIONS}) +target_link_libraries(lwipcontribportunix PUBLIC ${LWIP_MBEDTLS_LINK_LIBRARIES}) + +if (CMAKE_SYSTEM_NAME STREQUAL "Linux") + find_library(LIBUTIL util) + find_library(LIBPTHREAD pthread) + find_library(LIBRT rt) + target_link_libraries(lwipcontribportunix PUBLIC ${LIBUTIL} ${LIBPTHREAD} ${LIBRT}) +endif() + +if (CMAKE_SYSTEM_NAME STREQUAL "Darwin") + # Darwin doesn't have pthreads or POSIX real-time extensions libs + find_library(LIBUTIL util) + target_link_libraries(lwipcontribportunix PUBLIC ${LIBUTIL}) +endif() diff --git a/contrib/ports/unix/README b/contrib/ports/unix/README new file mode 100644 index 00000000000..3b8f9957773 --- /dev/null +++ b/contrib/ports/unix/README @@ -0,0 +1,25 @@ +This port contains infrastructure and examples for running lwIP on Unix-like +operating systems (Linux, OpenBSD, cygwin). Much of this is targeted towards +testing lwIP applications. + +* port/sys_arch.c, port/perf.c, port/include/arch/: Generic platform porting, + for both states of NO_SYS. (Mapping debugging to printf, providing + sys_now & co from the system time etc.) + +* check: Runs the unit tests shipped with main lwIP on the Unix port. + +* port/netif, port/include/netif: Various network interface implementations and + their helpers, some explicitly for Unix infrastructure, some generic (but most + useful on an easy to debug system): + + * fifo: Helper for sio + + * list: Helper for unixif + + * pcapif: Network interface that replays packages from a PCAP dump file, and + discards packages sent out from it + + * sio: Mapping Unix character devices to lwIP's sio mechanisms + + * tapif: Network interface that is mapped to a tap interface (Unix user + space layer 2 network device). Uses lwIP threads. diff --git a/contrib/ports/unix/check/CMakeLists.txt b/contrib/ports/unix/check/CMakeLists.txt new file mode 100644 index 00000000000..9cf8d05a7fe --- /dev/null +++ b/contrib/ports/unix/check/CMakeLists.txt @@ -0,0 +1,61 @@ +cmake_minimum_required(VERSION 3.8) + +set (CMAKE_CONFIGURATION_TYPES "Debug;Release") + +project(lwipunittests C) + +if (NOT CMAKE_SYSTEM_NAME STREQUAL "Linux" AND NOT CMAKE_SYSTEM_NAME STREQUAL "Darwin" AND NOT CMAKE_SYSTEM_NAME STREQUAL "GNU") + message(FATAL_ERROR "Unit test are currently only working on Linux, Darwin or Hurd") +endif() + +set(LWIP_DIR ${CMAKE_CURRENT_SOURCE_DIR}/../../../..) +if (NOT CMAKE_SYSTEM_NAME STREQUAL "GNU") + set(LWIP_USE_SANITIZERS true) +endif() +include(${LWIP_DIR}/contrib/ports/CMakeCommon.cmake) + +if(CMAKE_C_COMPILER_ID STREQUAL "Clang") + # check.h causes 'error: token pasting of ',' and __VA_ARGS__ is a GNU extension' with clang 9.0.0 + list(LWIP_COMPILER_FLAGS APPEND -Wno-gnu-zero-variadic-macro-arguments) +endif() + +set (LWIP_DEFINITIONS -DLWIP_DEBUG -DLWIP_NOASSERT_ON_ERROR) +set (LWIP_INCLUDE_DIRS + "${LWIP_DIR}/test/unit" + "${LWIP_DIR}/src/include" + "${LWIP_CONTRIB_DIR}/" + "${LWIP_CONTRIB_DIR}/ports/unix/port/include" + "${CMAKE_CURRENT_SOURCE_DIR}/" +) + +include(${LWIP_CONTRIB_DIR}/ports/unix/Filelists.cmake) +include(${LWIP_DIR}/src/Filelists.cmake) +include(${LWIP_DIR}/test/unit/Filelists.cmake) + +add_executable(lwip_unittests ${LWIP_TESTFILES}) +target_include_directories(lwip_unittests PRIVATE ${LWIP_INCLUDE_DIRS}) +target_compile_options(lwip_unittests PRIVATE ${LWIP_COMPILER_FLAGS}) +target_compile_definitions(lwip_unittests PRIVATE ${LWIP_DEFINITIONS} ${LWIP_MBEDTLS_DEFINITIONS}) + +find_library(LIBCHECK check) +find_library(LIBM m) +target_link_libraries(lwip_unittests ${LWIP_SANITIZER_LIBS} lwipallapps lwipcore ${LIBCHECK} ${LIBM}) + +if (NOT CMAKE_SYSTEM_NAME STREQUAL "Darwin") + # check installed via brew on Darwin doesn't have a separate subunit library (must be statically linked) + find_library(LIBSUBUNIT subunit) + target_link_libraries(lwip_unittests ${LIBSUBUNIT}) +endif() + +if (CMAKE_SYSTEM_NAME STREQUAL "Linux" OR CMAKE_SYSTEM_NAME STREQUAL "GNU") + find_library(LIBUTIL util) + find_library(LIBPTHREAD pthread) + find_library(LIBRT rt) + target_link_libraries(lwip_unittests ${LIBUTIL} ${LIBPTHREAD} ${LIBRT}) +endif() + +if (CMAKE_SYSTEM_NAME STREQUAL "Darwin") + # Darwin doesn't have pthreads or POSIX real-time extensions libs + find_library(LIBUTIL util) + target_link_libraries(lwip_unittests ${LIBUTIL}) +endif() diff --git a/contrib/ports/unix/check/Makefile b/contrib/ports/unix/check/Makefile new file mode 100644 index 00000000000..81e22e5244a --- /dev/null +++ b/contrib/ports/unix/check/Makefile @@ -0,0 +1,94 @@ +# +# Copyright (c) 2001, 2002 Swedish Institute of Computer Science. +# All rights reserved. +# +# Redistribution and use in source and binary forms, with or without modification, +# are permitted provided that the following conditions are met: +# +# 1. Redistributions of source code must retain the above copyright notice, +# this list of conditions and the following disclaimer. +# 2. Redistributions in binary form must reproduce the above copyright notice, +# this list of conditions and the following disclaimer in the documentation +# and/or other materials provided with the distribution. +# 3. The name of the author may not be used to endorse or promote products +# derived from this software without specific prior written permission. +# +# THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED +# WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF +# MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT +# SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, +# EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT +# OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING +# IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY +# OF SUCH DAMAGE. +# +# This file is part of the lwIP TCP/IP stack. +# +# Author: Adam Dunkels adam@sics.se +# + +all compile: lwip_unittests +.PHONY: all clean check + +LWIPDIR=../../../../src + +# The include path to sys_arch.h and lwipopts.h must be first, so this must be before Common.mk +CFLAGS=-DLWIP_NOASSERT_ON_ERROR -I/usr/include/check -I$(LWIPDIR)/../test/unit + +# Ignore 'too many arguments for format' warnings which happen with GCCs +# from check 0.15.2 on fail_if/fail_unless macros with text. +# See https://github.com/libcheck/check/pull/298/commits/82540c5428d3818b64d +CFLAGS+=-Wno-error=format-extra-args + +ifeq (clang,$(findstring clang,$(CC))) +# check.h causes 'error: token pasting of ',' and __VA_ARGS__ is a GNU extension' with clang 9.0.0 +CFLAGS+=-Wno-gnu-zero-variadic-macro-arguments +endif + +# Prevent compiling sys_arch.c of unix port because unit test provide their own port +SYSARCH?= +include ../Common.mk + +LDFLAGS:=-lcheck -lm $(LDFLAGS) + +ifneq ($(UNAME_S),Darwin) +# check installed via brew on Darwin doesn't have a separate subunit library (must be statically linked) +LDFLAGS+=-lsubunit +endif + +TESTDIR=$(LWIPDIR)/../test/unit +include $(TESTDIR)/Filelists.mk +TESTOBJS=$(notdir $(TESTFILES:.c=.o)) + +DEPFILES=.depend_test .depend_lwip .depend_app + +clean: + @rm -f *.o $(LWIPLIBCOMMON) $(APPLIB) lwip_unittests *.s $(DEPFILES) *.core core lwip_unittests.xml + +depend dep: $(DEPFILES) + @true + +ifneq ($(MAKECMDGOALS),clean) +include $(DEPFILES) +endif + +.depend_test: $(TESTFILES) + $(CCDEP) $(CFLAGS) -MM $^ > .depend_test || rm -f .depend_test +.depend_lwip: $(LWIPFILES) + $(CCDEP) $(CFLAGS) -MM $^ > .depend_lwip || rm -f .depend_lwip +.depend_app: $(APPFILES) + $(CCDEP) $(CFLAGS) -MM $^ > .depend_app || rm -f .depend_app + +ifneq ($(UNAME_S),Darwin) +# clang on Darwin doesn't support --start-group +lwip_unittests: $(DEPFILES) $(TESTOBJS) $(LWIPLIBCOMMON) $(APPLIB) + $(CC) $(CFLAGS) -o lwip_unittests $(TESTOBJS) -Wl,--start-group $(LWIPLIBCOMMON) $(APPLIB) $(LDFLAGS) -Wl,--end-group +else +lwip_unittests: $(DEPF
