[U-Boot-Users] v1.3.4-rc1 released
Hello,
the first release candidate for v1.3.4 is out. Well, actually it's more some mile stone than a real release candidate as we still have a couple of issues that need to be fixed before we can consider a release:
PPC:
- MPC8272ADS: pci.c: In function 'ft_pci_setup': pci.c:460: error: 'bd_t' has no member named 'pci_clk' => will be fixed as suggested on ML
- MVBC_P: e1000.c: In function 'e1000_read_mac_addr': e1000.c:518: warning: integer constant is too large for 'long' type mvbc_p.c: In function 'mvbc_init_gpio': mvbc_p.c:112: warning: format '%08x' expects type 'unsigned int', but argument 2 has type 'long unsign ed int' mvbc_p.c:123: warning: dereferencing type-punned pointer will break strict-aliasing rules mvbc_p.c: In function 'mvbc_p_load_fpga': mvbc_p.c:247: warning: implicit declaration of function 'fpga_load'
- W7OLMG: post2.c: In function 'dtt_test': post2.c:81: error: 'DTT_READ_TEMP' undeclared (first use in this function) post2.c:81: error: (Each undeclared identifier is reported only once post2.c:81: error: for each function it appears in.) post2.c:82: error: 'DTT_TEMP_SET' undeclared (first use in this function) post2.c:83: error: 'DTT_TEMP_HYST' undeclared (first use in this function) make[1]: *** [/work/wd/tmp-ppc/board/w7o/post2.o] Error 1 make[1]: *** Waiting for unfinished jobs.... make: *** [/work/wd/tmp-ppc/board/w7o/libw7o.a] Error 2
- haleakala_nand: make[1]: *** No rule to make target `/work/wd/tmp-ppc/nand_spl/board/amcc/kilauea/.depend', needed by `all'. Stop.
[Out-of-tree building fails, in-tree it works.]
- kilauea_nand: make[1]: *** No rule to make target `/work/wd/tmp-ppc/nand_spl/board/amcc/kilauea/.depend', needed by `all'. Stop.
- sacsng: main.c: In function 'abortboot': main.c:119: warning: too many arguments for format
Here we need some clever idea to deal with configurable command prompts. I will look into this asap.
- sc3: main.c: In function 'abortboot': main.c:119: warning: too many arguments for format
- actux4: actux4.c:83: warning: left shift count >= width of type actux4.c:83: warning: left shift count >= width of type
- adsvix: cmd_ide.c: In function '__ide_outb': cmd_ide.c:825: warning: implicit declaration of function 'outb' cmd_ide.c: In function '__ide_inb': cmd_ide.c:834: warning: implicit declaration of function 'inb' pcmcia.c:39:2: warning: #warning "Board will only supply 5V, wait for next HW spin for selectable power" common/libcommon.a(cmd_ide.o): In function `__ide_outb': /home/wd/git/u-boot/work/common/cmd_ide.c:825: undefined reference to `outb' common/libcommon.a(cmd_ide.o): In function `__ide_inb': /home/wd/git/u-boot/work/common/cmd_ide.c:834: undefined reference to `inb'
- apollon: make: *** /work/wd/tmp-arm/onenand_ipl/board/apollon: No such file or directory. Stop.
- at91rm9200dk: In file included from /home/wd/git/u-boot/work/include/nand.h:32, from board.c:48: /home/wd/git/u-boot/work/include/linux/mtd/nand.h:82:1: warning: "NAND_CTL_SETCLE" redefined In file included from /work/wd/tmp-arm/include/config.h:2, from /home/wd/git/u-boot/work/include/common.h:35, from board.c:41: /home/wd/git/u-boot/work/include/configs/at91rm9200dk.h:153:1: warning: this is the location of the previous definition In file included from /home/wd/git/u-boot/work/include/nand.h:32, from board.c:48: /home/wd/git/u-boot/work/include/linux/mtd/nand.h:84:1: warning: "NAND_CTL_CLRCLE" redefined In file included from /work/wd/tmp-arm/include/config.h:2, from /home/wd/git/u-boot/work/include/common.h:35, from board.c:41: /home/wd/git/u-boot/work/include/configs/at91rm9200dk.h:152:1: warning: this is the location of the previous definition In file included from /home/wd/git/u-boot/work/include/nand.h:32, from board.c:48: /home/wd/git/u-boot/work/include/linux/mtd/nand.h:86:1: warning: "NAND_CTL_SETALE" redefined In file included from /work/wd/tmp-arm/include/config.h:2, from /home/wd/git/u-boot/work/include/common.h:35, from board.c:41: /home/wd/git/u-boot/work/include/configs/at91rm9200dk.h:151:1: warning: this is the location of the previous definition In file included from /home/wd/git/u-boot/work/include/nand.h:32, from board.c:48: /home/wd/git/u-boot/work/include/linux/mtd/nand.h:88:1: warning: "NAND_CTL_CLRALE" redefined In file included from /work/wd/tmp-arm/include/config.h:2, from /home/wd/git/u-boot/work/include/common.h:35, from board.c:41: /home/wd/git/u-boot/work/include/configs/at91rm9200dk.h:150:1: warning: this is the location of the previous definition
- csb637: In file included from /home/wd/git/u-boot/work/include/nand.h:32, from board.c:48: /home/wd/git/u-boot/work/include/linux/mtd/nand.h:82:1: warning: "NAND_CTL_SETCLE" redefined In file included from /work/wd/tmp-arm/include/config.h:2, from /home/wd/git/u-boot/work/include/common.h:35, from board.c:41: /home/wd/git/u-boot/work/include/configs/csb637.h:156:1: warning: this is the location of the previous definition In file included from /home/wd/git/u-boot/work/include/nand.h:32, from board.c:48: /home/wd/git/u-boot/work/include/linux/mtd/nand.h:84:1: warning: "NAND_CTL_CLRCLE" redefined In file included from /work/wd/tmp-arm/include/config.h:2, from /home/wd/git/u-boot/work/include/common.h:35, from board.c:41: /home/wd/git/u-boot/work/include/configs/csb637.h:155:1: warning: this is the location of the previous definition In file included from /home/wd/git/u-boot/work/include/nand.h:32, from board.c:48: /home/wd/git/u-boot/work/include/linux/mtd/nand.h:86:1: warning: "NAND_CTL_SETALE" redefined In file included from /work/wd/tmp-arm/include/config.h:2, from /home/wd/git/u-boot/work/include/common.h:35, from board.c:41: /home/wd/git/u-boot/work/include/configs/csb637.h:154:1: warning: this is the location of the previous definition In file included from /home/wd/git/u-boot/work/include/nand.h:32, from board.c:48: /home/wd/git/u-boot/work/include/linux/mtd/nand.h:88:1: warning: "NAND_CTL_CLRALE" redefined In file included from /work/wd/tmp-arm/include/config.h:2, from /home/wd/git/u-boot/work/include/common.h:35, from board.c:41: /home/wd/git/u-boot/work/include/configs/csb637.h:153:1: warning: this is the location of the previous definition
- ixp boards broken because of NPE Microcode issue
- m501sk, voiceblue: main.c: In function 'abortboot': main.c:215: warning: too many arguments for format
See above.
Please help testing and cleaning up the bugs.
Thanks.
Wolfgang Denk wrote:
Hello,
I'll look at this tonight. Maybe the code is being more clever than it should be or maybe I was simply stupider than I should have been.
Best regards, gvb
This board seems to be using the legacy NAND interface, but doesn't define CFG_NAND_LEGACY. It also doesn't define CONFIG_CMD_NAND; if one does so, then it gets build errors (with or without CFG_NAND_LEGACY).
- csb637:
Likewise.
-Scott
- csb637:
Likewise.
So is there an easy way to fix these boards?
- csb637:
Likewise.
Enable CFG_NAND_LEGACY and CONFIG_CMD_NAND, include whatever header that the NAND macros depend on, fix any other build breaks, and test the result. I don't have the hardware to do that last step, so I'll leave it up to the board maintainer.
-Scott
OK, thanks - I think I fixed it for at91rm9200dk, and disabled NAND support for csb637.
Jerry Van Baren
Scott Wood
