[U-Boot] [PATCH] video: arm: rpi: Bail out early if querying video information fails
When probing we query for the width and hight of the display. If the firmware does not report any connected display the system will crash. See https://github.com/raspberrypi/firmware/issues/1157 for details.
Signed-off-by: Fabian Vogt fvogt@suse.com [mb: update commit message] Signed-off-by: Matthias Brugger mbrugger@suse.com --- drivers/video/bcm2835.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/video/bcm2835.c b/drivers/video/bcm2835.c index bc41090aed..1d2eda084c 100644 --- a/drivers/video/bcm2835.c +++ b/drivers/video/bcm2835.c @@ -19,13 +19,15 @@ static int bcm2835_video_probe(struct udevice *dev)
debug("bcm2835: Query resolution...\n"); ret = bcm2835_get_video_size(&w, &h); - if (ret) + if (ret || w == 0 || h == 0) return -EIO;
debug("bcm2835: Setting up display for %d x %d\n", w, h); ret = bcm2835_set_video_params(&w, &h, 32, BCM2835_MBOX_PIXEL_ORDER_RGB, BCM2835_MBOX_ALPHA_MODE_IGNORED, &fb_base, &fb_size, &pitch); + if (ret) + return -EIO;
debug("bcm2835: Final resolution is %d x %d\n", w, h);
We could just propagate the value of ret instead of coalescing every error to EIO, but that's just a nit, so:
Reviewed-by: Andre Przywara andre.przywara@arm.com Tested-by: Andre Przywara andre.przywara@arm.com
I think this should be merged now, as on the RPi4 this is somewhat of a showstopper, because we don't have PCIe yet, so no USB, and no keyboard support. Which means serial console is the only way to control U-Boot.
Cheers, Andre.
- if (ret)
if (ret)
return -EIO;
On Thu, 11 Jul 2019 16:56:24 +0200 matthias.bgg@kernel.org matthias.bgg@kernel.org wrote: ...
Applied to u-boot-video/master, thanks!
-- Anatolij
Anatolij Gustschin
Andre Przywara
