[U-Boot] Please pull u-boot-marvell/master
Hi Tom,
please pull the following Marvell related patches:
---------------------------------------------------------------- - Misc dts files sync'ed with Linux version (Chris) - Orion watchdog fix (Chris) - kwbimage changed to also support Marvell bin_hdr binary (Chris) - Add DM support to enable CONFIG_BLK for sata_mv (Stefan) - Enable BLK on multiple platforms (Stefan) - Misc minor fixes to AXP theadorable board (Stefan) - Correct logic for DM_SCSI + unconverted drivers check (stefan) - Add Kirkwood db-88f6281-bp board (Chris) - Misc changes to kirkwood to enable DM_USB here (Chris) - Change ahci_mvebu to enable usage on A38x (Baruch) - Update the kirkwood entry in git-mailrc (Baruch) - Misc minor improvements (turris, documentation) (Baruch) - Enhance sata_mv to support Kirkwood as well (Michael) - Add wdt command (Michael) - Add Marvell integrated CPUs (MSYS) support with DB-XC3-24G4XG board support (Chris) ----------------------------------------------------------------
Thanks, Stefan
The following changes since commit 7e9d5d4167921802d0e956f803392a2437f92bf5:
test.py: Disable fsck for FAT tests for now (2019-04-11 08:41:16 +0200)
git://www.denx.de/git/u-boot-marvell.git
for you to fetch changes up to ea755051738cfc46721351935a09036500e86053:
ARM: kirkwood: remove obsolete call to icache_enable (2019-04-11 13:42:13 +0200)
---------------------------------------------------------------- Baruch Siach (6): ARM: mvebu: define board_ahci_enable() for A38x ata: ahci_mvebu: add support for Armada 38x git-mailrc: update the kirkwood entry arm: mvebu: clearfog: document eMMC installation mvebu: drop dangling SPI flash comments and #ifdefs arm: mvebu: turris_omnia: select Kconfig SPI_FLASH_SPANSION
Chris Packham (20): arm: sync armada-xp dts files from Linux 5.0 watchdog: orion_wdt: support SPL usage watchdog: orion_wdt: take timeout value in ms arm: mvebu: x530: Enable watchdog in SPL and U-Boot tools: kwbimage: don't adjust for image_header for Armada MSYS ARM: kirkwood: add db-88f6281-bp board ARM: kirkwood: rename KW_CPU_WIN_BASE to MVEBU_CPU_WIN_BASE ARM: kirkwood: remove KW_DEFADR_PCI_IO_REMAP ARM: kirkwood: switch to using mvebu mbus ARM: kirkwood: remove kw_config_adr_windows ARM: kirkwood: enable CONFIG_DM_USB on db-88f6281-bp ARM: kirkwood: enable CONFIG_DM_USB for {dream, guru, sheeva}plug ARM: kirkwood: enable CONFIG_DM_USB for dns325 ARM: kirkwood: enable CONFIG_DM_USB for ds109 ARM: kirkwood: enable CONFIG_DM_USB for goflexhome ARM: kirkwood: enable CONFIG_DM_USB for lschlv2 and lsxhl ARM: kirkwood: enable CONFIG_DM_USB for nas220 arm: mvebu: Add Marvell's integrated CPUs arm: mvebu: NAND clock support for MSYS devices arm: mvebu: Add DB-XC3-24G4XG board
Leigh Brown (1): ARM: kirkwood: remove obsolete call to icache_enable
Michael Walle (5): sata: sata_mv: use correct format specifier in debug() sata: sata_mv: support kirkwood architecture sata: sata_mv: add orion-sata compatible string arm: kirkwood: lsxl: enable DM for SATA cmd: add wdt command
Stefan Roese (8): sata: sata_mv: Add DM support to enable CONFIG_BLK usage arm: mvebu: theadorable_debug_defconfig: Enable CONFIG_BLK arm: mvebu: db-mv784mp-gp_defconfig: Enable CONFIG_BLK arm: mvebu: theadorable: Add test for ctrl-c in PCIe PEX switch test Makefile: Correct logic for DM_SCSI + unconverted drivers check arm: mvebu: ds412: Enable CONFIG_BLK arm: mvebu: AXP: Enhance PCIe port capability configuration arm: mvebu: Fix Kconfig dependency warnings
Makefile | 19 +- arch/arm/dts/Makefile | 5 +- arch/arm/dts/armada-370-xp.dtsi | 133 ++++---- arch/arm/dts/armada-385-atl-x530-u-boot.dtsi | 4 + arch/arm/dts/armada-xp-98dx3236.dtsi | 343 ++++++++++++++++++++ arch/arm/dts/armada-xp-98dx3336.dtsi | 39 +++ arch/arm/dts/armada-xp-98dx4251.dtsi | 54 ++++ arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi | 24 ++ arch/arm/dts/armada-xp-db-xc3-24g4xg.dts | 110 +++++++ arch/arm/dts/armada-xp-gp.dts | 167 +++++----- arch/arm/dts/armada-xp-maxbcm.dts | 24 +- arch/arm/dts/armada-xp-mv78230.dtsi | 55 +--- arch/arm/dts/armada-xp-mv78260.dtsi | 58 +--- arch/arm/dts/armada-xp-mv78460.dtsi | 58 +--- arch/arm/dts/armada-xp-synology-ds414.dts | 199 ++++++------ arch/arm/dts/armada-xp-theadorable.dts | 69 ++-- arch/arm/dts/armada-xp.dtsi | 214 +++++++------ arch/arm/dts/kirkwood-db-88f6281-spi.dts | 48 +++ arch/arm/dts/kirkwood-db-88f6281.dts | 26 ++ arch/arm/dts/kirkwood-db.dtsi | 94 ++++++ arch/arm/mach-kirkwood/Kconfig | 4 + arch/arm/mach-kirkwood/cpu.c | 74 ++--- arch/arm/mach-kirkwood/include/mach/cpu.h | 13 +- arch/arm/mach-kirkwood/include/mach/soc.h | 2 +- arch/arm/mach-mvebu/Kconfig | 34 +- arch/arm/mach-mvebu/Makefile | 2 + arch/arm/mach-mvebu/cpu.c | 46 ++- arch/arm/mach-mvebu/include/mach/config.h | 2 +- arch/arm/mach-mvebu/include/mach/cpu.h | 3 + arch/arm/mach-mvebu/include/mach/soc.h | 31 ++ arch/arm/mach-mvebu/mbus.c | 9 + .../arm/mach-mvebu/serdes/axp/high_speed_env_lib.c | 8 +- board/CZ.NIC/turris_omnia/turris_omnia.c | 2 +- board/Marvell/db-88f6281-bp/Kconfig | 12 + board/Marvell/db-88f6281-bp/MAINTAINERS | 10 + board/Marvell/db-88f6281-bp/Makefile | 12 + board/Marvell/db-88f6281-bp/db-88f6281-bp.c | 103 ++++++ board/Marvell/db-88f6281-bp/kwbimage.cfg.in | 36 +++ board/Marvell/db-xc3-24g4xg/.gitignore | 1 + board/Marvell/db-xc3-24g4xg/MAINTAINERS | 7 + board/Marvell/db-xc3-24g4xg/Makefile | 14 + board/Marvell/db-xc3-24g4xg/README | 4 + board/Marvell/db-xc3-24g4xg/binary.0 | 11 + board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c | 68 ++++ board/Marvell/db-xc3-24g4xg/kwbimage.cfg.in | 12 + board/Synology/ds414/ds414.c | 4 +- board/alliedtelesis/x530/x530.c | 48 +++ board/maxbcm/maxbcm.c | 2 +- board/solidrun/clearfog/README | 23 ++ board/theadorable/theadorable.c | 38 ++- cmd/Kconfig | 6 + cmd/Makefile | 1 + cmd/wdt.c | 174 ++++++++++ configs/db-88f6281-bp-nand_defconfig | 54 ++++ configs/db-88f6281-bp-spi_defconfig | 56 ++++ configs/db-mv784mp-gp_defconfig | 1 + configs/db-xc3-24g4xg_defconfig | 55 ++++ configs/dns325_defconfig | 2 + configs/dreamplug_defconfig | 2 + configs/ds109_defconfig | 2 + configs/ds414_defconfig | 1 + configs/goflexhome_defconfig | 2 + configs/guruplug_defconfig | 2 + configs/lschlv2_defconfig | 6 +- configs/lsxhl_defconfig | 6 +- configs/nas220_defconfig | 2 + configs/sheevaplug_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/turris_omnia_defconfig | 1 + configs/x530_defconfig | 5 + doc/git-mailrc | 4 +- drivers/ata/Kconfig | 2 + drivers/ata/ahci_mvebu.c | 1 + drivers/ata/sata_mv.c | 354 ++++++++++++--------- drivers/ddr/marvell/axp/xor_regs.h | 4 + drivers/watchdog/Kconfig | 1 + drivers/watchdog/orion_wdt.c | 27 +- include/configs/clearfog.h | 2 - include/configs/db-88f6281-bp.h | 99 ++++++ include/configs/db-88f6720.h | 2 - include/configs/db-88f6820-amc.h | 2 - include/configs/db-88f6820-gp.h | 6 - include/configs/db-mv784mp-gp.h | 2 - include/configs/db-xc3-24g4xg.h | 41 +++ include/configs/ds414.h | 2 - include/configs/helios4.h | 2 - include/configs/lsxl.h | 23 +- include/configs/mvebu_armada-8k.h | 4 - include/configs/theadorable.h | 2 - include/configs/turris_mox.h | 4 - include/configs/turris_omnia.h | 3 - tools/kwbimage.c | 7 + 92 files changed, 2510 insertions(+), 842 deletions(-) create mode 100644 arch/arm/dts/armada-xp-98dx3236.dtsi create mode 100644 arch/arm/dts/armada-xp-98dx3336.dtsi create mode 100644 arch/arm/dts/armada-xp-98dx4251.dtsi create mode 100644 arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi create mode 100644 arch/arm/dts/armada-xp-db-xc3-24g4xg.dts create mode 100644 arch/arm/dts/kirkwood-db-88f6281-spi.dts create mode 100644 arch/arm/dts/kirkwood-db-88f6281.dts create mode 100644 arch/arm/dts/kirkwood-db.dtsi create mode 100644 board/Marvell/db-88f6281-bp/Kconfig create mode 100644 board/Marvell/db-88f6281-bp/MAINTAINERS create mode 100644 board/Marvell/db-88f6281-bp/Makefile create mode 100644 board/Marvell/db-88f6281-bp/db-88f6281-bp.c create mode 100644 board/Marvell/db-88f6281-bp/kwbimage.cfg.in create mode 100644 board/Marvell/db-xc3-24g4xg/.gitignore create mode 100644 board/Marvell/db-xc3-24g4xg/MAINTAINERS create mode 100644 board/Marvell/db-xc3-24g4xg/Makefile create mode 100644 board/Marvell/db-xc3-24g4xg/README create mode 100644 board/Marvell/db-xc3-24g4xg/binary.0 create mode 100644 board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c create mode 100644 board/Marvell/db-xc3-24g4xg/kwbimage.cfg.in create mode 100644 cmd/wdt.c create mode 100644 configs/db-88f6281-bp-nand_defconfig create mode 100644 configs/db-88f6281-bp-spi_defconfig create mode 100644 configs/db-xc3-24g4xg_defconfig create mode 100644 include/configs/db-88f6281-bp.h create mode 100644 include/configs/db-xc3-24g4xg.h
On Thu, Apr 11, 2019 at 02:34:01PM +0200, Stefan Roese wrote:
Hi Tom,
NAK. This is either racy, or there's other external output directory problems still: https://travis-ci.org/trini/u-boot/jobs/518755577#L1049
Hi Tom,
Hi Tom,
Ughh. Sorry, I thought that I worked this out with Chris and pushed the correct version. Will try again most likely tomorrow.
Sorry for the trouble.
Thanks, Stefan
On Thu, Apr 11, 2019 at 04:51:52PM +0200, Stefan Roese wrote:
Hi Tom,
Hi Tom,
No big deal, thanks!
Stefan Roese
