[PATCH] test/py: net: Add dhcp abort test
Abort the dhcp request in the middle by pressing ctrl + c on u-boot prompt and validate the abort status.
Signed-off-by: Love Kumar love.kumar@amd.com --- test/py/tests/test_net.py | 44 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 44 insertions(+)
diff --git a/test/py/tests/test_net.py b/test/py/tests/test_net.py index cd4b4dc53cbc..1e8eb0357eef 100644 --- a/test/py/tests/test_net.py +++ b/test/py/tests/test_net.py @@ -6,6 +6,7 @@
import pytest import u_boot_utils +import re
""" Note: This test relies on boardenv_* containing configuration values to define @@ -104,6 +105,49 @@ def test_net_dhcp(u_boot_console): global net_set_up net_set_up = True
+@pytest.mark.buildconfigspec("cmd_dhcp") +def test_net_dhcp_abort(u_boot_console): + """Test the dhcp command by pressing ctrl+c in the middle of dhcp request + + The boardenv_* file may be used to enable/disable this test; see the + comment at the beginning of this file. + """ + + test_dhcp = u_boot_console.config.env.get("env__net_dhcp_server", False) + if not test_dhcp: + pytest.skip("No DHCP server available") + + u_boot_console.run_command("setenv autoload no") + + # Phy reset before running dhcp command + output = u_boot_console.run_command("mii device") + eth_num = re.search(r"Current device: '(.+?)'", output).groups()[0] + u_boot_console.run_command(f"mii device {eth_num}") + output = u_boot_console.run_command("mii info") + eth_addr = hex(int(re.search(r"PHY (.+?):", output).groups()[0], 16)) + u_boot_console.run_command(f"mii modify {eth_addr} 0 0x8000 0x8000") + + u_boot_console.run_command("dhcp", wait_for_prompt=False) + try: + u_boot_console.wait_for("Waiting for PHY auto negotiation to complete") + except: + pytest.skip("Timeout waiting for PHY auto negotiation to complete") + + u_boot_console.wait_for("done") + + # Sending Ctrl-C + output = u_boot_console.run_command( + chr(3), wait_for_echo=False, send_nl=False + ) + + assert "TIMEOUT" not in output + assert "DHCP client bound to address " not in output + assert "Abort" in output + + # Provide a time to recover from Abort - if it is not performed + # There is message like: ethernet@ff0e0000: No link. + u_boot_console.run_command("sleep 1") + @pytest.mark.buildconfigspec('cmd_dhcp6') def test_net_dhcp6(u_boot_console): """Test the dhcp6 command.
- """Test the dhcp command by pressing ctrl+c in the middle of dhcp request
- The boardenv_* file may be used to enable/disable this test; see the
- comment at the beginning of this file.
- test_dhcp = u_boot_console.config.env.get("env__net_dhcp_server", False)
- if not test_dhcp:
- u_boot_console.run_command("setenv autoload no")
- # Phy reset before running dhcp command
- output = u_boot_console.run_command("mii device")
- eth_num = re.search(r"Current device: '(.+?)'", output).groups()[0]
- u_boot_console.run_command(f"mii device {eth_num}")
- output = u_boot_console.run_command("mii info")
- eth_addr = hex(int(re.search(r"PHY (.+?):", output).groups()[0], 16))
- u_boot_console.run_command(f"mii modify {eth_addr} 0 0x8000 0x8000")
- u_boot_console.run_command("dhcp", wait_for_prompt=False)
- try:
- except:
- u_boot_console.wait_for("done")
- # Sending Ctrl-C
- assert "TIMEOUT" not in output
- assert "DHCP client bound to address " not in output
- assert "Abort" in output
- # Provide a time to recover from Abort - if it is not performed
- # There is message like: ethernet@ff0e0000: No link.
- u_boot_console.run_command("sleep 1")
@pytest.mark.buildconfigspec('cmd_dhcp6') def test_net_dhcp6(u_boot_console): """Test the dhcp6 command. -- 2.25.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Similar issue is visible here too. There should be CMD_MII dependency.
- if not test_dhcp:
- try:
- except:
- # Sending Ctrl-C
- @pytest.mark.buildconfigspec('cmd_dhcp6') def test_net_dhcp6(u_boot_console): """Test the dhcp6 command.
qemu_arm64 test.py is showing this issue. ____________________________ test_net_dhcp_abort ______________________________ test/py/tests/test_net.py:138: in test_net_dhcp_abort eth_num = re.search(r"Current device: '(.+?)'", output).groups()[0] E AttributeError: 'NoneType' object has no attribute 'groups'
M
Love Kumar
Michal Simek
Ramon Fried
