[U-Boot] please pull u-boot-samsung/master
Dear Albert,
The following changes since commit ca849aa4b86b282f837c58a0b129460ebfad2239:
ARM: activate DISPLAY_CPUINFO for VCMA9 + SMDK2410 board (2012-02-06 22:47:25 +0100)
are available in the git repository at: git://git.denx.de/u-boot-samsung master
Chander Kashyap (8): Exynos: PWM: Add TCMPB3 field in pwm structure Exynos: Fix ARM Clock frequency calculation Origen: Select SCLKMPLL as FIMD0 parent clock Exynos: Clock.c: Use CONFIG_SYS_CLK_FREQ macro ARM: EXYNOS: Add support for Exynos5 based SoCs EXYNOS: Add SMDK5250 board support EXYNOS: SMDK5250: Add MMC SPL support SMDK5250: Add ethernet support
HeungJun, Kim (3): ARMV7: Exynos4: Add watchdog.h for Exynos4 ARMV7: Exynos4: Add supoort power for Exynos4 ARMV7: Exynos4: Add support for TRATS board
Minkyu Kang (4): ORIGEN: remove duplicated MACH_TYPE define S5P: support generic watchdog timer TRATS: use the generic watchdog timer TRATS: set gpio of UART correctly
MAINTAINERS | 5 + Makefile | 1 + arch/arm/cpu/armv7/exynos/clock.c | 229 +++++++++- arch/arm/cpu/armv7/s5p-common/Makefile | 1 + arch/arm/cpu/armv7/s5p-common/wdt.c | 59 +++ arch/arm/include/asm/arch-exynos/clock.h | 326 +++++++++++++ arch/arm/include/asm/arch-exynos/cpu.h | 36 ++- arch/arm/include/asm/arch-exynos/dmc.h | 146 ++++++ arch/arm/include/asm/arch-exynos/gpio.h | 99 ++++- arch/arm/include/asm/arch-exynos/power.h | 230 ++++++++++ arch/arm/include/asm/arch-exynos/pwm.h | 2 +- arch/arm/include/asm/arch-exynos/tzpc.h | 52 +++ arch/arm/include/asm/arch-exynos/watchdog.h | 57 +++ arch/arm/include/asm/arch-s5pc1xx/cpu.h | 1 + arch/arm/include/asm/arch-s5pc1xx/watchdog.h | 58 +++ board/samsung/origen/lowlevel_init.S | 5 + board/samsung/origen/origen_setup.h | 12 + board/samsung/smdk5250/Makefile | 58 +++ board/samsung/smdk5250/clock_init.c | 202 ++++++++ board/samsung/smdk5250/dmc_init.c | 462 +++++++++++++++++++ board/samsung/smdk5250/lowlevel_init.S | 96 ++++ board/samsung/smdk5250/mmc_boot.c | 58 +++ board/samsung/smdk5250/setup.h | 451 ++++++++++++++++++ board/samsung/smdk5250/smdk5250.c | 240 ++++++++++ board/samsung/smdk5250/tzpc_init.c | 48 ++ board/samsung/trats/Makefile | 43 ++ board/samsung/trats/setup.h | 637 ++++++++++++++++++++++++++ board/samsung/trats/trats.c | 366 +++++++++++++++ boards.cfg | 2 + include/configs/origen.h | 2 - include/configs/s5pc210_universal.h | 1 + include/configs/smdk5250.h | 204 ++++++++ include/configs/trats.h | 217 +++++++++ tools/Makefile | 6 + tools/mkexynosspl.c | 122 +++++ 35 files changed, 4508 insertions(+), 26 deletions(-) create mode 100644 arch/arm/cpu/armv7/s5p-common/wdt.c create mode 100644 arch/arm/include/asm/arch-exynos/dmc.h create mode 100644 arch/arm/include/asm/arch-exynos/power.h create mode 100644 arch/arm/include/asm/arch-exynos/tzpc.h create mode 100644 arch/arm/include/asm/arch-exynos/watchdog.h create mode 100644 arch/arm/include/asm/arch-s5pc1xx/watchdog.h create mode 100644 board/samsung/smdk5250/Makefile create mode 100644 board/samsung/smdk5250/clock_init.c create mode 100644 board/samsung/smdk5250/dmc_init.c create mode 100644 board/samsung/smdk5250/lowlevel_init.S create mode 100644 board/samsung/smdk5250/mmc_boot.c create mode 100644 board/samsung/smdk5250/setup.h create mode 100644 board/samsung/smdk5250/smdk5250.c create mode 100644 board/samsung/smdk5250/tzpc_init.c create mode 100644 board/samsung/trats/Makefile create mode 100644 board/samsung/trats/setup.h create mode 100644 board/samsung/trats/trats.c create mode 100644 include/configs/smdk5250.h create mode 100644 include/configs/trats.h create mode 100644 tools/mkexynosspl.c
Hi Minkyu,
Le 10/02/2012 02:01, Minkyu Kang a écrit :
Dear Albert,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Minkyu Kang
