[U-Boot] [PATCH V2 1/3] arm: discard relocation entry for secure section
The code such as PSCI in section named secure is bundled with u-boot image, and when bootm, the code will be copied to their runtime address same to compliation/linking address - CONFIG_ARMV7_SECURE_BASE.
When compile the PSCI code and link it into the u-boot image, there will be relocation entries in .rel.dyn section for PSCI. Actually, we do not needs these relocation entries.
If still keep the relocation entries in .rel.dyn section, r0 at line 103 and 106 in arch/arm/lib/relocate.S may be an invalid address which may not support read/write for one SoC. 102 /* relative fix: increase location by offset */ 103 add r0, r0, r4 104 ldr r1, [r0] 105 add r1, r1, r4 106 str r1, [r0]
So discard the relocation entries for code in secure section.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Cc: Tom Warren twarren@nvidia.com Cc: York Sun yorksun@freescale.com Cc: Hans De Goede hdegoede@redhat.com Cc: Ian Campbell ijc@hellion.org.uk Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Tom Rini trini@konsulko.com Cc: Jan Kiszka jan.kiszka@siemens.com Cc: Stefano Babic sbabic@denx.de ---
V1 thread: http://lists.denx.de/pipermail/u-boot/2015-October/229426.html Changes V2: Refine commit msg. Discard the relocation entry section for secure text.
arch/arm/cpu/u-boot.lds | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/cpu/u-boot.lds b/arch/arm/cpu/u-boot.lds index 03cd9f6..55a0683 100644 --- a/arch/arm/cpu/u-boot.lds +++ b/arch/arm/cpu/u-boot.lds @@ -51,6 +51,8 @@ SECTIONS *(.__secure_end) LONG(0x1d1071c); /* Must output something to reset LMA */ } + + /DISCARD/ : { *(.rel._secure*) } #endif
. = ALIGN(4);
1. add basic psci support for imx7 chip. 2. support cpu_on and cpu_off. 3. switch to non-secure mode when boot linux kernel. 4. set csu allow accessing all peripherial register in non-secure mode.
Signed-off-by: Frank Li Frank.Li@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com ---
arch/arm/cpu/armv7/mx7/Makefile | 4 ++ arch/arm/cpu/armv7/mx7/psci-mx7.c | 78 +++++++++++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/mx7/psci.S | 54 +++++++++++++++++++++++++++ arch/arm/cpu/armv7/mx7/soc.c | 9 +++++ 4 files changed, 145 insertions(+) create mode 100644 arch/arm/cpu/armv7/mx7/psci-mx7.c create mode 100644 arch/arm/cpu/armv7/mx7/psci.S
diff --git a/arch/arm/cpu/armv7/mx7/Makefile b/arch/arm/cpu/armv7/mx7/Makefile index e6ecef0..f25461c 100644 --- a/arch/arm/cpu/armv7/mx7/Makefile +++ b/arch/arm/cpu/armv7/mx7/Makefile @@ -6,3 +6,7 @@ #
obj-y := soc.o clock.o clock_slice.o + +ifdef CONFIG_ARMV7_PSCI +obj-y += psci.o psci-mx7.o +endif diff --git a/arch/arm/cpu/armv7/mx7/psci-mx7.c b/arch/arm/cpu/armv7/mx7/psci-mx7.c new file mode 100644 index 0000000..ec9ad87 --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/psci-mx7.c @@ -0,0 +1,78 @@ +#include <common.h> +#include <asm/psci.h> +#include <asm/arch/imx-regs.h> + +#define __secure __attribute__((section("._secure.text"))) + +#define GPC_CPU_PGC_SW_PDN_REQ 0xfc +#define GPC_CPU_PGC_SW_PUP_REQ 0xf0 +#define GPC_PGC_C1 0x840 + +#define BM_CPU_PGC_SW_PDN_PUP_REQ_CORE1_A7 0x2 + +/* below is for i.MX7D */ +#define SRC_GPR1_MX7D 0x074 +#define SRC_A7RCR0 0x004 +#define SRC_A7RCR1 0x008 + +#define BP_SRC_A7RCR0_A7_CORE_RESET0 0 +#define BP_SRC_A7RCR1_A7_CORE1_ENABLE 1 + +static inline void psci_writel(u32 value, u32 reg) +{ + *(volatile u32 *)reg = value; +} + +static inline int psci_readl(u32 reg) +{ + return *(volatile u32*)reg; +} + +static inline void imx_gpcv2_set_m_core_pgc(bool enable, u32 offset) +{ + psci_writel(enable, GPC_IPS_BASE_ADDR + offset); +} + +__secure void imx_gpcv2_set_core1_power(bool pdn) +{ + u32 reg = pdn ? GPC_CPU_PGC_SW_PUP_REQ : GPC_CPU_PGC_SW_PDN_REQ; + u32 val; + + imx_gpcv2_set_m_core_pgc(true, GPC_PGC_C1); + + val = psci_readl(GPC_IPS_BASE_ADDR + reg); + val |= BM_CPU_PGC_SW_PDN_PUP_REQ_CORE1_A7; + psci_writel(val, GPC_IPS_BASE_ADDR + reg); + + while ((psci_readl(GPC_IPS_BASE_ADDR + reg) & + BM_CPU_PGC_SW_PDN_PUP_REQ_CORE1_A7) != 0) + ; + + imx_gpcv2_set_m_core_pgc(false, GPC_PGC_C1); +} + +__secure void imx_enable_cpu_ca7(int cpu, bool enable) +{ + u32 mask, val; + + mask = 1 << (BP_SRC_A7RCR1_A7_CORE1_ENABLE + cpu - 1); + val = psci_readl(SRC_BASE_ADDR + SRC_A7RCR1); + val = enable ? val | mask : val & ~mask; + psci_writel(val, SRC_BASE_ADDR + SRC_A7RCR1); +} + +__secure int imx_cpu_on(int fn, int cpu, int pc) +{ + psci_writel(pc, SRC_BASE_ADDR + cpu * 8 + SRC_GPR1_MX7D); + imx_gpcv2_set_core1_power(true); + imx_enable_cpu_ca7(cpu, true); + return 0; +} + +__secure int imx_cpu_off(int cpu) +{ + imx_enable_cpu_ca7(cpu, false); + imx_gpcv2_set_core1_power(false); + psci_writel(0, SRC_BASE_ADDR + cpu * 8 + SRC_GPR1_MX7D + 4); + return 0; +} diff --git a/arch/arm/cpu/armv7/mx7/psci.S b/arch/arm/cpu/armv7/mx7/psci.S new file mode 100644 index 0000000..34c6ab3 --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/psci.S @@ -0,0 +1,54 @@ +#include <config.h> +#include <linux/linkage.h> + +#include <asm/armv7.h> +#include <asm/arch-armv7/generictimer.h> +#include <asm/psci.h> + + .pushsection ._secure.text, "ax" + + .arch_extension sec + + @ r1 = target CPU + @ r2 = target PC + +.globl psci_arch_init +psci_arch_init: + mov r6, lr + + bl psci_get_cpu_id + bl psci_get_cpu_stack_top + mov sp, r0 + + bx r6 + + @ r1 = target CPU + @ r2 = target PC + +.globl psci_cpu_on +psci_cpu_on: + push {lr} + + mov r0, r1 + bl psci_get_cpu_stack_top + str r2, [r0] + dsb + + ldr r2, =psci_cpu_entry + bl imx_cpu_on + + pop {pc} + +.globl psci_cpu_off +psci_cpu_off: + + bl psci_cpu_off_common + bl psci_get_cpu_id + bl imx_cpu_off + +1: wfi + b 1b + + .globl psci_text_end +psci_text_end: + .popsection diff --git a/arch/arm/cpu/armv7/mx7/soc.c b/arch/arm/cpu/armv7/mx7/soc.c index 2ed05ea..020731d 100644 --- a/arch/arm/cpu/armv7/mx7/soc.c +++ b/arch/arm/cpu/armv7/mx7/soc.c @@ -114,10 +114,19 @@ u32 __weak get_board_rev(void) } #endif
+/* enable all periherial can be access in nosec mode */ +static void init_csu(void) +{ + int i = 0; + for (i = 0; i < 64; i++) + writel(0x00FF00FF, 0x303e0000 + i * 4); +} + int arch_cpu_init(void) { init_aips();
+ init_csu(); /* Disable PDE bit of WMCR register */ imx_set_wdog_powerdown(false);
Do you really need psci_writel() psci_readl() functions? Why not simple call writel and readl instead?
int i = 0;
Lots of magic values here. Please add defines for improving code readability.
Thanks
-----Original Message----- From: Peng Fan [mailto:Peng.Fan@freescale.com] Sent: Tuesday, October 20, 2015 1:00 AM To: u-boot@lists.denx.de Cc: Fan Peng-B51431 Peng.Fan@freescale.com; Li Frank-B20596 Frank.Li@freescale.com; Stefano Babic sbabic@denx.de; Estevam Fabio- R49496 Fabio.Estevam@freescale.com Subject: [PATCH V2 2/3] mx7: psci: add basic psci support
- add basic psci support for imx7 chip.
- support cpu_on and cpu_off.
- switch to non-secure mode when boot linux kernel.
- set csu allow accessing all peripherial register in non-secure mode.
Obj-y += psci-mx7.o psci.o The otherwise psci_text_end will not be last one.
Best regards Frank Li
+static inline void psci_writel(u32 value, u32 reg) {
- *(volatile u32 *)reg = value;
- return *(volatile u32*)reg;
+static inline void imx_gpcv2_set_m_core_pgc(bool enable, u32 offset) {
- psci_writel(enable, GPC_IPS_BASE_ADDR + offset); }
+__secure void imx_gpcv2_set_core1_power(bool pdn) {
- u32 reg = pdn ? GPC_CPU_PGC_SW_PUP_REQ :
- u32 val;
- imx_gpcv2_set_m_core_pgc(true, GPC_PGC_C1);
- val = psci_readl(GPC_IPS_BASE_ADDR + reg);
- val |= BM_CPU_PGC_SW_PDN_PUP_REQ_CORE1_A7;
- psci_writel(val, GPC_IPS_BASE_ADDR + reg);
- while ((psci_readl(GPC_IPS_BASE_ADDR + reg) &
- imx_gpcv2_set_m_core_pgc(false, GPC_PGC_C1); }
+__secure void imx_enable_cpu_ca7(int cpu, bool enable) {
- u32 mask, val;
- mask = 1 << (BP_SRC_A7RCR1_A7_CORE1_ENABLE + cpu - 1);
- val = psci_readl(SRC_BASE_ADDR + SRC_A7RCR1);
- val = enable ? val | mask : val & ~mask;
- psci_writel(val, SRC_BASE_ADDR + SRC_A7RCR1); }
+__secure int imx_cpu_on(int fn, int cpu, int pc) {
- psci_writel(pc, SRC_BASE_ADDR + cpu * 8 + SRC_GPR1_MX7D);
- imx_gpcv2_set_core1_power(true);
- imx_enable_cpu_ca7(cpu, true);
- imx_enable_cpu_ca7(cpu, false);
- imx_gpcv2_set_core1_power(false);
- psci_writel(0, SRC_BASE_ADDR + cpu * 8 + SRC_GPR1_MX7D + 4);
+#include <asm/armv7.h> +#include <asm/arch-armv7/generictimer.h> #include <asm/psci.h>
- .pushsection ._secure.text, "ax"
- .arch_extension sec
- @ r1 = target CPU
- @ r2 = target PC
- mov r6, lr
- bl psci_get_cpu_id
- bl psci_get_cpu_stack_top
- mov sp, r0
- bx r6
- @ r1 = target CPU
- @ r2 = target PC
- push {lr}
- mov r0, r1
- str r2, [r0]
- dsb
- ldr r2, =psci_cpu_entry
- bl imx_cpu_on
- pop {pc}
- bl psci_cpu_off_common
- bl imx_cpu_off
+1: wfi
- b 1b
- .globl psci_text_end
+psci_text_end:
- .popsection
+/* enable all periherial can be access in nosec mode */ static void +init_csu(void) {
- int i = 0;
- for (i = 0; i < 64; i++)
writel(0x00FF00FF, 0x303e0000 + i * 4); }
- init_csu(); /* Disable PDE bit of WMCR register */ imx_set_wdog_powerdown(false);
-- 1.8.4
Hello Li,
I don't like this object module order sensitivity.
The object module order of secure code modules should not affect the resulting binary to the point of possibly preventing it from working -- after all, the object module order of 'vanilla' image code does not matter (1). We don't have this kind of problem when defining the image start and end, why would we have it with the secure code start and end?
IOW, psci_text_end could (and should) be defined in the linker script, not in an object module.
(1) except for start.S, which *must* be linked first, and even that is not done through object order but through linker script section order.
Amicalement,
-----Original Message----- From: Albert ARIBAUD [mailto:albert.u.boot@aribaud.net] Sent: Tuesday, October 20, 2015 9:25 AM To: Li Frank-B20596 Frank.Li@freescale.com Cc: Fan Peng-B51431 Peng.Fan@freescale.com; u-boot@lists.denx.de; Estevam Fabio-R49496 Fabio.Estevam@freescale.com Subject: Re: [U-Boot] [PATCH V2 2/3] mx7: psci: add basic psci support
Hello Li,
Secure code use psci_text_end to calculate stack top point.
I agree. The other platform put psci_text_end to object module.
Amicalement,
Albert.
Support PSCI and switch to non-secure mode when booting linux.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Frank Li Frank.Li@freescale.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com ---
Changes V2: default no enable CONFIG_ARMV7_VIRT
include/configs/mx7_common.h | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index ea2be49..fac76bd 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -92,4 +92,14 @@ #define CONFIG_CMD_FUSE #define CONFIG_MXC_OCOTP
+/* Default boot linux kernel in no secure mode. + * If want to boot kernel in secure mode, please define CONFIG_MX7_SEC + */ +#ifndef CONFIG_MX7_SEC +#define CONFIG_ARMV7_NONSEC 1 +#define CONFIG_ARMV7_PSCI 1 +#define CONFIG_ARMV7_PSCI_NR_CPUS 2 +#define CONFIG_ARMV7_SECURE_BASE 0x00900000 +#endif + #endif
Hello Peng,
Actually, I'll need you to do a slight change -- that's my fault, and karma even ensured that my own self of two years ago would be the one to come and kick me. See:
http://lists.denx.de/pipermail/u-boot/2013-December/168652.html
Which basically is about never discarding any section in the ELF file, and only copying a subset of the ELF sections into the binary file.
So rather than discarding the secure relocation records, let's move them to another section as you had proposed, and thus change the line
- /DISCARD/ : { *(.rel._secure*) }
Into a
.rel._secure { *(.rel._secure*) }
Placed right after the already present
.dynamic : { *(.dynamic*) }
With my apologies for the very late realization.
Amicalement,
Hi Albert,
On Tue, Oct 20, 2015 at 09:05:32AM +0200, Albert ARIBAUD wrote:
Hello Peng,
Ok. Then arch/arm/cpu/armv8/u-boot.lds should also have such fix, since lots sections are discarded in u-boot.lds for armv8.
Into a
It can not be placed after .dynamic, since the following is at front. 87 .rel.dyn : { 88 *(.rel*) 89 } So relocation entry from secure text will first placed into .rel.dyn section.
If not DISCARD, then I prefer to put ".rel.secure : { *(.rel._secure*) }" at line 55 which is wrapped by CONFIG_ARMV7_NONSEC in arch/arm/cpu/u-boot.lds.
See following patch:
From 4b950418835ff52cd7be8dd2b80fb8b0e055f9a2 Mon Sep 17 00:00:00 2001
From: Peng Fan Peng.Fan@freescale.com Date: Tue, 20 Oct 2015 15:18:22 +0800 Subject: [PATCH] arm: move relocation entry for secure section into a single section
So move them into a single section to avoid touching the relocation entry in arch/arm/lib/relocate.S.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Cc: Tom Warren twarren@nvidia.com Cc: York Sun yorksun@freescale.com Cc: Hans De Goede hdegoede@redhat.com Cc: Ian Campbell ijc@hellion.org.uk Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Tom Rini trini@konsulko.com Cc: Jan Kiszka jan.kiszka@siemens.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/u-boot.lds | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/cpu/u-boot.lds b/arch/arm/cpu/u-boot.lds index 03cd9f6..65986e8 100644 --- a/arch/arm/cpu/u-boot.lds +++ b/arch/arm/cpu/u-boot.lds @@ -51,6 +51,8 @@ SECTIONS *(.__secure_end) LONG(0x1d1071c); /* Must output something to reset LMA */ } + + .rel.secure : { *(.rel._secure*) } #endif
. = ALIGN(4);
Regards, Peng.
Amicalement,
Albert.
Hello Peng,
On Tue, 20 Oct 2015 15:20:43 +0800, Peng Fan b51431@freescale.com wrote:
Hi Albert,
Hello Peng,
You are correct, armv8 needs to be fixed, as well as zynq (and x86 but that's outside of my province). Anyway, that's a different problem which does not need to be addressed in this series.
Into a
I prefer all 'unused' sections to be kept together near the end of the LDS file -- I'll add an explicit comment in the LDS about it.
Besides, there no need to wrap such a section with a preprocessor conditional, as the linker will simply not emit an output section if there are no input sections at all for it; IOW, adding the '.rel._secure { *(.rel._secure*) }' line will be binary-invariant for platforms which do not have PSCI or other secure code.
Amicalement,
Hi Albert,
On Tue, Oct 20, 2015 at 09:32:51AM +0200, Albert ARIBAUD wrote:
Hello Peng,
Hi Albert,
Hello Peng,
Into a
But ".rel._secure { *(.rel._secure*) }" can not be placed after ".dynamic : { *(.dynamic*) }". Actually ".rel._secure { *(.rel._secure*) }" should be placed before ".rel_dyn_start" in u-boot.lds, otherwise the secure relocation entries will be placed into ".rel.dyn", but not ".rel._secure".
Regards, Peng.
Amicalement,
Albert.
Hello Peng,
On Tue, 20 Oct 2015 15:41:30 +0800, Peng Fan b51431@freescale.com wrote:
Hi Albert,
Hello Peng,
Hi Albert,
Hello Peng,
Into a
Hmm, you're correct, the linker will use the first pattern match, not the longest or best. :(
But then, the secure reloc input section cannot go in line 55, because that's still inside the binary part of the image, which means it will waste space in there.
So it's either use DISCARD at the very start of the SECTIONS (round line 17) or back to not generating relocatable code at all for PSCI.
Regards, Peng.
Amicalement,
Albert.
Amicalement,
Hello Albert,
On Tue, Oct 20, 2015 at 02:59:10PM +0200, Albert ARIBAUD wrote:
Hello Peng,
Hi Albert,
Hello Peng,
Hi Albert,
Hello Peng,
Into a
I do not know how to generate non-relocatable code only for the secure text. Since -mword-relocations and -pie are global flags, I do not know how to disable mword-relocations when compiling PSCI and other secure text.
Is this ok for you?
diff --git a/arch/arm/cpu/u-boot.lds b/arch/arm/cpu/u-boot.lds index 65986e8..fb2128a 100644 --- a/arch/arm/cpu/u-boot.lds +++ b/arch/arm/cpu/u-boot.lds @@ -14,6 +14,7 @@ OUTPUT_ARCH(arm) ENTRY(_start) SECTIONS { + /DISCARD/ : { *(.rel._secure*) } . = 0x00000000;
. = ALIGN(4);
Regards, Peng.
Regards, Peng.
Amicalement,
Albert.
Amicalement,
Albert.
Hello Peng,
On Wed, 21 Oct 2015 17:42:20 +0800, Peng Fan b51431@freescale.com wrote:
Hello Albert,
Actually, I haven't even found a compiler or gcc option to entirely remove relocations altogether.
Is this ok for you?
/DISCARD/ : { *(.rel._secure*) } . = 0x00000000; . = ALIGN(4);
Functionally, it works -- I've just checked it by comparing u-boot.map files of a mx7dsabresd build with and without the DISCARD. Not a single symbol from the text and data section gets changed.
The only missing thing left is a comment before the DISCARD line, explaining both why .rel._secure* input sections have to be discarded, and also explaining why this is done it right at the start of the output sections.
Thanks for your patience. :)
Regards, Peng.
Amicalement,
Hello Albert,
On Wed, Oct 21, 2015 at 01:42:27PM +0200, Albert ARIBAUD wrote:
Hello Peng,
Hello Albert,
Is this ok for you?
Ok. Will add the comments in V3.
Regards, Peng.
Regards, Peng.
Amicalement,
Albert.
participants (5)
Albert ARIBAUD
Fabio Estevam
Li Frank
Peng Fan
Peng Fan
