[PATCH] tools/env/fw_env.h: remove env.h
As reported by Nicolas Carrier on the Buildroot mailing list [1], there is a new build issue while building a program which interacts with the u-boot environment. This program uses the headers of the ubootenv library provided by uboot-tools.
This is a recent change from uboot [2] adding "#include <env.h>" to fw_env.h. Adding env.h require a board configuration to build since it also include compiler.h (and others uboot internal includes).
env.h include seems not needed since env_set() is not used in fw_env tool.
Nicolas removed env.h from fw_env tool and fixed it's build issue.
This problem is present since uboot v2019.10.
[1] http://lists.busybox.net/pipermail/buildroot/2020-April/280307.html [2] https://gitlab.denx.de/u-boot/u-boot/-/commit/9fb625ce05539fe6876a59ce1dcadb...
Reported-by: Nicolas Carrier nicolas.carrier@orolia.com Signed-off-by: Romain Naour romain.naour@gmail.com --- tools/env/fw_env.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/tools/env/fw_env.h b/tools/env/fw_env.h index b60fbfc8f8..78c803c944 100644 --- a/tools/env/fw_env.h +++ b/tools/env/fw_env.h @@ -4,7 +4,6 @@ * Wolfgang Denk, DENX Software Engineering, wd@denx.de. */
-#include <env.h> #include <stdint.h>
Romain Naour
