Re: [PATCH v6 0/3] Add StarFive JH7110 PCIe drvier support
Hi Minda
From: Minda Chen minda.chen@starfivetech.com Sent: Thursday, June 01, 2023 9:07 AM To: Leo Yu-Chi Liang(梁育齊) ycliang@andestech.com; Rick Jian-Zhi Chen(陳建志) rick@andestech.com; Simon Glass sjg@chromium.org; Stefan Roese sr@denx.de; Andrew Scull ascull@google.com; Pali Rohár pali@kernel.org; Mark Kettenis kettenis@openbsd.org Cc: u-boot@lists.denx.de; Mason Huo mason.huo@starfivetech.com; Leyfoon Tan leyfoon.tan@starfivetech.com; Kevin Xie kevin.xie@starfivetech.com Subject: Re: [PATCH v6 0/3] Add StarFive JH7110 PCIe drvier support
Hi Rick and Leo Could you review these series patches? Thanks. Since patch 1 was acked by Pali, Does it mean patch 1 is accepted?
OK, we will review these series patches ASAP and help to push.
Thanks, Rick
On 2023/5/9 16:26, Minda Chen wrote:
These PCIe series patches are based on the JH7110 RISC-V SoC and VisionFive V2 board.
The PCIe driver depends on gpio, pinctrl, clk and reset driver to do init. The PCIe dts configuation includes all these setting.
The PCIe drivers codes has been tested on the VisionFive V2 boards. The test devices includes M.2 NVMe SSD and Realtek 8169 Ethernet adapter.
previous patch version
v1: https://patchwork.ozlabs.org/project/uboot/cover/20230223105240.15180- 1-minda.chen@starfivetech.com/ v2: https://patchwork.ozlabs.org/project/uboot/cover/20230308054833.95730- 1-minda.chen@starfivetech.com/ v3: https://patchwork.ozlabs.org/project/uboot/cover/20230329100143.10724- 1-minda.chen@starfivetech.com/ v4: https://patchwork.ozlabs.org/project/uboot/cover/20230411010209.76561- 1-minda.chen@starfivetech.com/ v5: https://patchwork.ozlabs.org/project/uboot/cover/20230423105859.125764 -1-minda.chen@starfivetech.com/
changes v6 patch 2 1. Change one VisionFive2 config file. patch 3 1. remove the pcie interrupt-controller. interrupts setting revert to origin.
setting. v5 patch 1 1. split PLDA controller driver codes to pcie_plda_common.c 2. correct the codes of record secondary number. patch 3 1. change the pcie dtsi config. make them the same with kernel.
v4 patch 1 1. Remove the IDS_REVISION_ID macros. 2. Replace sec_busno to first_busno in starfive_pcie 3. Remove starfive_pcie_off_conf function. 4. Replace "imply" to "depends on" in PCIe Kconfig. 5 .Check sec_busno in starfive_pcie_addr_valid.
v3 patch 1 1. remove the read vendor ID delay 2. remove starfive_pcie_hide_rc_bar function. do not hide host bridge BAR write. 3. Using PCIE_ECAM_OFFSET and PCI_CLASS_BRIDGE_PCI_NORMAL macros. 4. Add comments for bus and address limitation reason in function starfive_pcie_addr_valid 5. Change the multiple line comments in Line 373 6. Using gpio_request_by_name to get PCIe reset gpio,and using dm_gpio_set_value set GPIO value. patch 2 1. support PCIeboth 12a and 13b vf2 board. patch 3 1. reset dts change to reset-gpio.
v2
- remove clock commit. The pcie clocks change has been includeded in [1].
- Using GENMASK marco1 in patch1.
- remove the syscon dts node in patch3. The syscon dts dts node has been included in [1].
Mason Huo (3): starfive: pci: Add StarFive JH7110 pcie driver configs: starfive-jh7110: Add support for PCIe host driver riscv: dts: starfive: Enable PCIe host controller
.../dts/jh7110-starfive-visionfive-2.dtsi | 11 + arch/riscv/dts/jh7110.dtsi | 74 ++++ configs/starfive_visionfive2_defconfig | 10 + drivers/pci/Kconfig | 13 + drivers/pci/Makefile | 2 + drivers/pci/pcie_plda_common.c | 116 +++++++ drivers/pci/pcie_plda_common.h | 118 +++++++ drivers/pci/pcie_starfive_jh7110.c | 317 ++++++++++++++++++ 8 files changed, 661 insertions(+) create mode 100644 drivers/pci/pcie_plda_common.c create mode 100644 drivers/pci/pcie_plda_common.h create mode 100644 drivers/pci/pcie_starfive_jh7110.c
base-commit: c9c2c95d4cd27fe0cd41fe13a863899d268f973c
Rick Chen
