[U-Boot] allow LED initialization without STATUS_LED_BOOT
For current U-Boot to initialize status LEDs via status_led_init(), it is required to have both CONFIG_STATUS_LED and STATUS_LED_BOOT defined. This may be a particular concern with GPIO LEDs, where __led_init() is required to correctly set up the GPIO (gpio_request and gpio_direction_output). Without STATUS_LED_BOOT the initialization isn't called, which could leave the user with a non-functional "led" command - due to the fact that the LED routines in gpio_led.c use gpio_set_value() just fine, but the GPIO never got set up properly in the first place.
I think having CONFIG_STATUS_LED is sufficient to justify a corresponding call to status_led_init(), even with no STATUS_LED_BOOT defined. To do so, common/board_r.c needs some way to call that routine either directly (which probably requires exposing it via status_led.h) or indirectly. For the latter, I've attached a patch that (ab)uses an invalid LED id in status_led_set() to enforce the init.
Regards, B. Nortmann
--- common/board_r.c | 10 +++++++--- drivers/misc/status_led.c | 7 ++++--- 2 files changed, 11 insertions(+), 6 deletions(-)
diff --git a/common/board_r.c b/common/board_r.c index 0335f6b..c67f459 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -547,11 +547,15 @@ static int initr_kgdb(void) } #endif
-#if defined(CONFIG_STATUS_LED) && defined(STATUS_LED_BOOT) +#ifdef CONFIG_STATUS_LED static int initr_status_led(void) { +#ifdef STATUS_LED_BOOT status_led_set(STATUS_LED_BOOT, STATUS_LED_BLINKING); - +#else + /* use invalid LED id to enforce status_led_init() */ + status_led_set(-1, 0); +#endif return 0; } #endif @@ -838,7 +842,7 @@ init_fnc_t init_sequence_r[] = { || defined(CONFIG_M68K) timer_init, /* initialize timer */ #endif -#if defined(CONFIG_STATUS_LED) && defined(STATUS_LED_BOOT) +#ifdef CONFIG_STATUS_LED initr_status_led, #endif /* PPC has a udelay(20) here dating from 2002. Why? */ diff --git a/drivers/misc/status_led.c b/drivers/misc/status_led.c index ed9adb2..4751c8d 100644 --- a/drivers/misc/status_led.c +++ b/drivers/misc/status_led.c @@ -94,12 +94,13 @@ void status_led_set (int led, int state) { led_dev_t *ld;
- if (led < 0 || led >= MAX_LED_DEV) - return; - + /* reordered, allows using invalid led ID to enforce init */ if (!status_led_init_done) status_led_init ();
+ if (led < 0 || led >= MAX_LED_DEV) + return; + ld = &led_dev[led];
ld->state = state;
Bernhard Nortmann
