[U-Boot] Possible bug in UBIFS function ubifs_finddir
All,
Hello again it has been a while since I was here. I am working on u-boot once again and think I may have found a bug in the UBIFS sub-system.
The function is ubifs_finddir and the issue is that there seems to be a free of a pointer in a structure that has already been freed. This is causing the free function to rightly crash.
The code is in the error path of the ubifs_finddir at the end of the function line 363:
if (file) free(file); if (dentry) free(dentry); if (dir) free(dir);
if (file->private_data) kfree(file->private_data); file->private_data = NULL; file->f_pos = 2;
The issue is that we are free'ing the file pointer at the top of this block and then trying to free the private_data element after the base pointer. I will fix and send a patch but before I do I just wanted to make sure I was not missing the obvious. Has this been discussed before and is there already a patch?
Regards, Rod Boyce
Free private_data member element before freeing file structure. This was causing malloc to crash. Also remove unnecessary variable assigments after file structure was free'd.
Signed-off-by: Rod Boyce uboot@teamboyce.co.uk ------------------------------- fs/ubifs/ubifs.c ------------------------------ diff --git a/fs/ubifs/ubifs.c b/fs/ubifs/ubifs.c index 5a5c739..61f70b2 100644 --- a/fs/ubifs/ubifs.c +++ b/fs/ubifs/ubifs.c @@ -360,6 +360,8 @@ return err; }
+ if (file->private_data) + kfree(file->private_data); if (file) free(file); if (dentry) @@ -367,10 +369,6 @@ if (dir) free(dir);
- if (file->private_data) - kfree(file->private_data); - file->private_data = NULL; - file->f_pos = 2; return 0; }
Hi Rod,
This patch does not apply:
Applying: For bug in UBIFS function ubifs_finddir Using index info to reconstruct a base tree... error: patch failed: fs/ubifs/ubifs.c:360 error: fs/ubifs/ubifs.c: patch does not apply Did you hand edit your patch?
How did you create this patch? I recommend to use "git format-patch". And send it via "git send-email".
Also, please change the patch subject and add "ubifs:":
- For bug in UBIFS function ubifs_finddir + ubifs: Fix bug in function ubifs_finddir
Please also take a look at this page for patch submission:
http://www.denx.de/wiki/view/U-Boot/Patches
Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Hi Stefan,
- ubifs: Fix bug in function ubifs_finddir
Thanks.
Sorry for my duplication, I just saw that you beat me with your answer ;)
Cheers Detlev
Hi Rod,
Actually the patch looks good - though I cannot apply the patch easily:
[dzu@pollux u-boot-testing (master)]$ git am -3 ~/transfer/p1 Applying: For bug in UBIFS function ubifs_finddir Using index info to reconstruct a base tree... error: patch failed: fs/ubifs/ubifs.c:360 error: fs/ubifs/ubifs.c: patch does not apply Did you hand edit your patch? It does not apply to blobs recorded in its index. Cannot fall back to three-way merge. Patch failed at 0001 For bug in UBIFS function ubifs_finddir When you have resolved this problem run "git am --resolved". If you would prefer to skip this patch, instead run "git am --skip". To restore the original branch and stop patching run "git am --abort".
Can you please resend the patch in a way that makes it possible to apply to current master? And if you do that, please change the subject line to something more expressive.
Thanks Detlev
Dear Rod Boyce,
Changes have been requested for your patch.
Do you think you will find time to submit a fixed version any time soon?
Thanks in advance.
Free private_data member element before freeing file structure. This was causing malloc to crash. Also remove unnecessary variable assigments as file structure gets free'd as well.
Signed-off-by: Rod Boyce uboot@teamboyce.co.uk Signed-off-by: Wolfgang Denk wd@denx.de Cc: Stefan Roese sr@denx.de --- As Rod appears to have disappeared I took the frredom to jump in and fix this. - wd
fs/ubifs/ubifs.c | 6 ++---- 1 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/fs/ubifs/ubifs.c b/fs/ubifs/ubifs.c index 5a5c739..61f70b2 100644 --- a/fs/ubifs/ubifs.c +++ b/fs/ubifs/ubifs.c @@ -360,6 +360,8 @@ out: return err; }
+ if (file->private_data) + kfree(file->private_data); if (file) free(file); if (dentry) @@ -367,10 +369,6 @@ out: if (dir) free(dir);
All,
Sorry about this I missed the e-mail asking me to reformat the patch. Thanks for sorting this out Wolfgang.
Regards, Rod Boyce
Applied to u-boot-ubi/master. Thanks.
Best regards, Stefan
Detlev Zundel
Rod Boyce
Stefan Roese
