[U-Boot] [PATCH] armv8: ls1088a: Move CONFIG_BOOTARGS and CONFIG_CMD_GREPENV to defconfig
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- configs/ls1088aqds_defconfig | 3 +++ configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 3 +++ configs/ls1088aqds_qspi_defconfig | 3 +++ configs/ls1088aqds_sdcard_ifc_defconfig | 3 +++ configs/ls1088aqds_sdcard_qspi_defconfig | 3 +++ configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 3 +++ configs/ls1088ardb_qspi_defconfig | 3 +++ configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 3 +++ configs/ls1088ardb_sdcard_qspi_defconfig | 3 +++ include/configs/ls1088a_common.h | 5 ----- 10 files changed, 27 insertions(+), 5 deletions(-)
diff --git a/configs/ls1088aqds_defconfig b/configs/ls1088aqds_defconfig index 5624595..323f89d 100644 --- a/configs/ls1088aqds_defconfig +++ b/configs/ls1088aqds_defconfig @@ -9,6 +9,9 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x3000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" +CONFIG_CMD_GREPENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y diff --git a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig index e464951..eba112a 100644 --- a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig @@ -3,6 +3,9 @@ CONFIG_TARGET_LS1088AQDS=y CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x3000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" +CONFIG_CMD_GREPENV=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig index 1e368d7..a93c60c 100644 --- a/configs/ls1088aqds_qspi_defconfig +++ b/configs/ls1088aqds_qspi_defconfig @@ -8,6 +8,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, QSPI_BOOT" # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x3000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" +CONFIG_CMD_GREPENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index 5f175f8..69adffd 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -14,6 +14,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" CONFIG_SD_BOOT=y # CONFIG_DISPLAY_BOARDINFO is not set # CONFIG_USE_BOOTCOMMAND is not set +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x3000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" +CONFIG_CMD_GREPENV=y CONFIG_SPL=y CONFIG_SPL_BUILD=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index b6de10c..3fc9354 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -13,6 +13,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SD_BOOT_QSPI" CONFIG_SD_BOOT=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x3000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" +CONFIG_CMD_GREPENV=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 diff --git a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig index 19c76b6..812a9a6 100644 --- a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig @@ -3,6 +3,9 @@ CONFIG_TARGET_LS1088ARDB=y CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x3000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" +CONFIG_CMD_GREPENV=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig index 8a08846..4ec755a 100644 --- a/configs/ls1088ardb_qspi_defconfig +++ b/configs/ls1088ardb_qspi_defconfig @@ -10,6 +10,9 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, QSPI_BOOT" # CONFIG_USE_BOOTCOMMAND is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x3000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" +CONFIG_CMD_GREPENV=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig index a4afbb5..d2ff299 100644 --- a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig @@ -16,6 +16,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SD_BOOT_QSPI" CONFIG_SD_BOOT=y # CONFIG_USE_BOOTCOMMAND is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x3000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" +CONFIG_CMD_GREPENV=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index 2f8c097..d6a5ad3 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -15,6 +15,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SD_BOOT_QSPI" CONFIG_SD_BOOT=y # CONFIG_USE_BOOTCOMMAND is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x3000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" +CONFIG_CMD_GREPENV=y CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 61c30c9..1178fec 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -166,7 +166,6 @@ unsigned long long get_qixis_addr(void); #define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (512UL * 1024 * 1024) #endif /* Command line configuration */ -#define CONFIG_CMD_GREPENV #define CONFIG_CMD_CACHE
/* Miscellaneous configurable options */ @@ -213,10 +212,6 @@ unsigned long long get_qixis_addr(void); "mcinitcmd=fsl_mc start mc 0x580a00000" \ " 0x580e00000 \0"
-#define CONFIG_BOOTARGS "console=ttyS0,115200 root=/dev/ram0 " \ - "earlycon=uart8250,mmio,0x21c0500 " \ - "ramdisk_size=0x3000000 default_hugepagesz=2m" \ - " hugepagesz=2m hugepages=256" #if defined(CONFIG_QSPI_BOOT) #define CONFIG_BOOTCOMMAND "sf probe 0:0;" \ "sf read 0x80200000 0xd00000 0x100000;"\
Ashish Kumar
