[U-Boot] unused-const-variable warnings in FSL DDR driver
Hi York,
When compiling latest u-boot with gcc 6.3 compiler, I get several 'unused-const-variable' warnings in options.c file of FSL DDR driver. Affected variables are for (DIMM_SLOTS_PER_CTLR==2) configuration (e.g. dual_0S[4]) and warnings could be fixed with the patch applied.
What do you think?
Best regards, Thomas
On 02/09/2017 02:32 AM, Thomas Schaefer wrote:
Hi York,
When compiling latest u-boot with gcc 6.3 compiler, I get several ‘unused-const-variable’ warnings in options.c file of FSL DDR driver. Affected variables are for (DIMM_SLOTS_PER_CTLR==2) configuration (e.g. dual_0S[4]) and warnings could be fixed with the patch applied.
What do you think?
Thomas,
Thanks for bringing it to my attention. I understand GCC 6 may have more warnings. The proposed patch is OK in logic but it increases the size of code unnecessarily. Can you come up with a different fix?
I can come back to check after I finish my work on hand.
York
Hi York,
What do you think?
Thomas,
York
Hi York,
not sure if I understand this correctly, but why is code size increased when these variables are not defined? I think code size is decreased instead as these variables are no longer defined if not needed.
I also don't see a way to achieve this in a different way as the variables are defined differently for DDR2, DDR3 and DDR4.
Hi York,
What do you think?
Thomas,
York
Hi York,
Wait a minute, did you generate the patch backward? Your patch shows removing "#if CONFIG_DIMM_SLOTS_PER_CTLR==2" which doesn't exist in current code. If the logic is reversed, then yes, you are reducing the size. Can GCC 6 optimize out the unused data? If yes, maybe we can use __maybe_unused to get rid of the warning?
York
Hi York,
What do you think?
Thomas,
York
Hi York,
York
Oops, you are right, sorry for the confusion. Here's the corrected version:
diff --git a/drivers/ddr/fsl/options.c b/drivers/ddr/fsl/options.c index d6a8fcb216..d90ed0b6cc 100644 --- a/drivers/ddr/fsl/options.c +++ b/drivers/ddr/fsl/options.c @@ -89,6 +89,7 @@ static const struct dynamic_odt single_S[4] = { {0, 0, 0, 0}, };
+#if (CONFIG_DIMM_SLOTS_PER_CTLR==2) static const struct dynamic_odt dual_DD[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, @@ -235,6 +236,7 @@ static const struct dynamic_odt dual_0S[4] = { {0, 0, 0, 0}
}; +#endif
static const struct dynamic_odt odt_unknown[4] = { { /* cs0 */ @@ -319,6 +321,7 @@ static const struct dynamic_odt single_S[4] = { {0, 0, 0, 0}, };
+#if (CONFIG_DIMM_SLOTS_PER_CTLR==2) static const struct dynamic_odt dual_DD[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, @@ -465,6 +468,7 @@ static const struct dynamic_odt dual_0S[4] = { {0, 0, 0, 0}
}; +#endif
static const struct dynamic_odt odt_unknown[4] = { { /* cs0 */ @@ -529,6 +533,7 @@ static const struct dynamic_odt single_S[4] = { {0, 0, 0, 0}, };
+#if (CONFIG_DIMM_SLOTS_PER_CTLR==2) static const struct dynamic_odt dual_DD[4] = { { /* cs0 */ FSL_DDR_ODT_OTHER_DIMM, @@ -676,6 +681,7 @@ static const struct dynamic_odt dual_0S[4] = { {0, 0, 0, 0}
}; +#endif
Hi York,
What do you think?
Thomas,
York
Hi York,
York
}; +#endif
}; +#endif
}; +#endif
This looks better. Can you check the size before and after this change? I wonder if GCC 6 can optimize out unused const. If it can, we may be able to get away by using __maybe_used and save a lot of #if.
By the way, please put space around "==" if you want to go this way.
York
Hi York,
What do you think?
Thomas,
York
Hi York,
York
}; +#endif
}; +#endif
}; +#endif
The above isn't quite enough for all cases. I'm testing a different and larger patch currently.
On 02/09/2017 02:32 AM, Thomas Schaefer wrote: > Hi York, > > > > When compiling latest u-boot with gcc 6.3 compiler, I get > several 'unused-const-variable' warnings in options.c file of FSL DDR driver. > Affected variables are for (DIMM_SLOTS_PER_CTLR==2) configuration (e.g. > dual_0S[4]) and warnings could be fixed with the patch applied. > > > > What do you think?
Thomas,
York
Hi York,
York
}; +#endif
}; +#endif
}; +#endif
-- Tom
I've built u-boot for T1042RDB with and without the above patch applied. Actually, binary images created are the same (with the exception of build timestamp of course), so GCC actually removes the unused variables.
When adding __maybe_unsued attribute to the variable definitions, warnings don't show up anymore:
diff --git a/drivers/ddr/fsl/options.c b/drivers/ddr/fsl/options.c index d6a8fcb216..64aaa77047 100644 --- a/drivers/ddr/fsl/options.c +++ b/drivers/ddr/fsl/options.c @@ -33,7 +33,7 @@ struct dynamic_odt { /* Quad rank is not verified yet due availability. * Replacing 20 OHM with 34 OHM since DDR4 doesn't have 20 OHM option */ -static const struct dynamic_odt single_Q[4] = { +__maybe_unused static const struct dynamic_odt single_Q[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_CS_AND_OTHER_DIMM, @@ -60,7 +60,7 @@ static const struct dynamic_odt single_Q[4] = { } };
-static const struct dynamic_odt single_D[4] = { +__maybe_unused static const struct dynamic_odt single_D[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_ALL, @@ -77,7 +77,7 @@ static const struct dynamic_odt single_D[4] = { {0, 0, 0, 0} };
-static const struct dynamic_odt single_S[4] = { +__maybe_unused static const struct dynamic_odt single_S[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_ALL, @@ -89,7 +89,7 @@ static const struct dynamic_odt single_S[4] = { {0, 0, 0, 0}, };
-static const struct dynamic_odt dual_DD[4] = { +__maybe_unused static const struct dynamic_odt dual_DD[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_SAME_DIMM, @@ -116,7 +116,7 @@ static const struct dynamic_odt dual_DD[4] = { } };
-static const struct dynamic_odt dual_DS[4] = { +__maybe_unused static const struct dynamic_odt dual_DS[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_SAME_DIMM, @@ -137,7 +137,7 @@ static const struct dynamic_odt dual_DS[4] = { }, {0, 0, 0, 0} }; -static const struct dynamic_odt dual_SD[4] = { +__maybe_unused static const struct dynamic_odt dual_SD[4] = { { /* cs0 */ FSL_DDR_ODT_OTHER_DIMM, FSL_DDR_ODT_ALL, @@ -159,7 +159,7 @@ static const struct dynamic_odt dual_SD[4] = { } };
-static const struct dynamic_odt dual_SS[4] = { +__maybe_unused static const struct dynamic_odt dual_SS[4] = { { /* cs0 */ FSL_DDR_ODT_OTHER_DIMM, FSL_DDR_ODT_ALL, @@ -176,7 +176,7 @@ static const struct dynamic_odt dual_SS[4] = { {0, 0, 0, 0} };
-static const struct dynamic_odt dual_D0[4] = { +__maybe_unused static const struct dynamic_odt dual_D0[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_SAME_DIMM, @@ -193,7 +193,7 @@ static const struct dynamic_odt dual_D0[4] = { {0, 0, 0, 0} };
-static const struct dynamic_odt dual_0D[4] = { +__maybe_unused static const struct dynamic_odt dual_0D[4] = { {0, 0, 0, 0}, {0, 0, 0, 0}, { /* cs2 */ @@ -210,7 +210,7 @@ static const struct dynamic_odt dual_0D[4] = { } };
-static const struct dynamic_odt dual_S0[4] = { +__maybe_unused static const struct dynamic_odt dual_S0[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_CS, @@ -223,7 +223,7 @@ static const struct dynamic_odt dual_S0[4] = {
-static const struct dynamic_odt dual_0S[4] = { +__maybe_unused static const struct dynamic_odt dual_0S[4] = { {0, 0, 0, 0}, {0, 0, 0, 0}, { /* cs2 */ @@ -236,7 +236,7 @@ static const struct dynamic_odt dual_0S[4] = {
-static const struct dynamic_odt odt_unknown[4] = { +__maybe_unused static const struct dynamic_odt odt_unknown[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_CS, @@ -263,7 +263,7 @@ static const struct dynamic_odt odt_unknown[4] = { } }; #elif defined(CONFIG_SYS_FSL_DDR3) -static const struct dynamic_odt single_Q[4] = { +__maybe_unused static const struct dynamic_odt single_Q[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_CS_AND_OTHER_DIMM, @@ -290,7 +290,7 @@ static const struct dynamic_odt single_Q[4] = { } };
-static const struct dynamic_odt single_D[4] = { +__maybe_unused static const struct dynamic_odt single_D[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_ALL, @@ -307,7 +307,7 @@ static const struct dynamic_odt single_D[4] = { {0, 0, 0, 0} };
-static const struct dynamic_odt single_S[4] = { +__maybe_unused static const struct dynamic_odt single_S[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_ALL, @@ -319,7 +319,7 @@ static const struct dynamic_odt single_S[4] = { {0, 0, 0, 0}, };
-static const struct dynamic_odt dual_DD[4] = { +__maybe_unused static const struct dynamic_odt dual_DD[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_SAME_DIMM, @@ -346,7 +346,7 @@ static const struct dynamic_odt dual_DD[4] = { } };
-static const struct dynamic_odt dual_DS[4] = { +__maybe_unused static const struct dynamic_odt dual_DS[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_SAME_DIMM, @@ -367,7 +367,7 @@ static const struct dynamic_odt dual_DS[4] = { }, {0, 0, 0, 0} }; -static const struct dynamic_odt dual_SD[4] = { +__maybe_unused static const struct dynamic_odt dual_SD[4] = { { /* cs0 */ FSL_DDR_ODT_OTHER_DIMM, FSL_DDR_ODT_ALL, @@ -389,7 +389,7 @@ static const struct dynamic_odt dual_SD[4] = { } };
-static const struct dynamic_odt dual_SS[4] = { +__maybe_unused static const struct dynamic_odt dual_SS[4] = { { /* cs0 */ FSL_DDR_ODT_OTHER_DIMM, FSL_DDR_ODT_ALL, @@ -406,7 +406,7 @@ static const struct dynamic_odt dual_SS[4] = { {0, 0, 0, 0} };
-static const struct dynamic_odt dual_D0[4] = { +__maybe_unused static const struct dynamic_odt dual_D0[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_SAME_DIMM, @@ -423,7 +423,7 @@ static const struct dynamic_odt dual_D0[4] = { {0, 0, 0, 0} };
-static const struct dynamic_odt dual_0D[4] = { +__maybe_unused static const struct dynamic_odt dual_0D[4] = { {0, 0, 0, 0}, {0, 0, 0, 0}, { /* cs2 */ @@ -440,7 +440,7 @@ static const struct dynamic_odt dual_0D[4] = { } };
-static const struct dynamic_odt dual_S0[4] = { +__maybe_unused static const struct dynamic_odt dual_S0[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_CS, @@ -453,7 +453,7 @@ static const struct dynamic_odt dual_S0[4] = {
-static const struct dynamic_odt dual_0S[4] = { +__maybe_unused static const struct dynamic_odt dual_0S[4] = { {0, 0, 0, 0}, {0, 0, 0, 0}, { /* cs2 */ @@ -466,7 +466,7 @@ static const struct dynamic_odt dual_0S[4] = {
-static const struct dynamic_odt odt_unknown[4] = { +__maybe_unused static const struct dynamic_odt odt_unknown[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_CS, @@ -493,14 +493,14 @@ static const struct dynamic_odt odt_unknown[4] = { } }; #else /* CONFIG_SYS_FSL_DDR3 */ -static const struct dynamic_odt single_Q[4] = { +__maybe_unused static const struct dynamic_odt single_Q[4] = { {0, 0, 0, 0}, {0, 0, 0, 0}, {0, 0, 0, 0}, {0, 0, 0, 0} };
-static const struct dynamic_odt single_D[4] = { +__maybe_unused static const struct dynamic_odt single_D[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_ALL, @@ -517,7 +517,7 @@ static const struct dynamic_odt single_D[4] = { {0, 0, 0, 0} };
-static const struct dynamic_odt single_S[4] = { +__maybe_unused static const struct dynamic_odt single_S[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_ALL, @@ -529,7 +529,7 @@ static const struct dynamic_odt single_S[4] = { {0, 0, 0, 0}, };
-static const struct dynamic_odt dual_DD[4] = { +__maybe_unused static const struct dynamic_odt dual_DD[4] = { { /* cs0 */ FSL_DDR_ODT_OTHER_DIMM, FSL_DDR_ODT_OTHER_DIMM, @@ -556,7 +556,7 @@ static const struct dynamic_odt dual_DD[4] = { } };
-static const struct dynamic_odt dual_DS[4] = { +__maybe_unused static const struct dynamic_odt dual_DS[4] = { { /* cs0 */ FSL_DDR_ODT_OTHER_DIMM, FSL_DDR_ODT_OTHER_DIMM, @@ -578,7 +578,7 @@ static const struct dynamic_odt dual_DS[4] = { {0, 0, 0, 0} };
-static const struct dynamic_odt dual_SD[4] = { +__maybe_unused static const struct dynamic_odt dual_SD[4] = { { /* cs0 */ FSL_DDR_ODT_OTHER_DIMM, FSL_DDR_ODT_OTHER_DIMM, @@ -600,7 +600,7 @@ static const struct dynamic_odt dual_SD[4] = { } };
-static const struct dynamic_odt dual_SS[4] = { +__maybe_unused static const struct dynamic_odt dual_SS[4] = { { /* cs0 */ FSL_DDR_ODT_OTHER_DIMM, FSL_DDR_ODT_OTHER_DIMM, @@ -617,7 +617,7 @@ static const struct dynamic_odt dual_SS[4] = { {0, 0, 0, 0} };
-static const struct dynamic_odt dual_D0[4] = { +__maybe_unused static const struct dynamic_odt dual_D0[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_ALL, @@ -634,7 +634,7 @@ static const struct dynamic_odt dual_D0[4] = { {0, 0, 0, 0} };
-static const struct dynamic_odt dual_0D[4] = { +__maybe_unused static const struct dynamic_odt dual_0D[4] = { {0, 0, 0, 0}, {0, 0, 0, 0}, { /* cs2 */ @@ -651,7 +651,7 @@ static const struct dynamic_odt dual_0D[4] = { } };
-static const struct dynamic_odt dual_S0[4] = { +__maybe_unused static const struct dynamic_odt dual_S0[4] = { { /* cs0 */ FSL_DDR_ODT_NEVER, FSL_DDR_ODT_CS, @@ -664,7 +664,7 @@ static const struct dynamic_odt dual_S0[4] = {
-static const struct dynamic_odt dual_0S[4] = { +__maybe_unused static const struct dynamic_odt dual_0S[4] = { {0, 0, 0, 0}, {0, 0, 0, 0}, { /* cs2 */ @@ -677,7 +677,7 @@ static const struct dynamic_odt dual_0S[4] = {
> On 02/09/2017 02:32 AM, Thomas Schaefer wrote: >> Hi York,
<snip>
Thomas,
Can you put your patch together with proper commit message and signature? I prefer your solution than this one http://patchwork.ozlabs.org/patch/726353/
York
From: york sun [mailto:york.sun@nxp.com] Sent: Samstag, 25. März 2017 16:35 To: Thomas Schaefer; Tom Rini Cc: u-boot@lists.denx.de Re: Re: AW: [U-Boot] unused-const-variable warnings in FSL DDR driver
Thomas,
York
Hi York,
please find the patch in the attachment.
commit 66dcf316bf2649e576f1b79aad3a5bb950d178d6 Author: Thomas Schaefer thomas.schaefer@kontron.com Date: Mon Mar 27 10:17:09 2017 +0200
drivers: ddr: fix unused-const-variable warnings
Depending on DDR configuration, gcc-6.x will show up unused-const- variable messages. Use __maybe_unused specifier for all dynamic_odt variable definitions to remove these warnings.
Memory footprint will not increase as gcc will optimize out unused constants.
Signed-off-by: Thomas Schaefer thomas.schaefer@kontron.com
Thomas,
York
Hi York,
drivers: ddr: fix unused-const-variable warnings Depending on DDR configuration, gcc-6.x will show up unused-const- variable messages. Use __maybe_unused specifier for all dynamic_odt variable definitions to remove these warnings. Memory footprint will not increase as gcc will optimize out unused constants. Signed-off-by: Thomas Schaefer <thomas.schaefer@kontron.com>
Thomas Schaefer
york sun
