[U-Boot] [PATCH] Revert "sunxi: board: Print error after power initialization fails"
This reverts commit a8011eb84dfac5187cebf00ed8bc981bdb5c1fa1
This causes DRAM init failures on (at least) * allwinner h3 nanopi-duo2 * allwinner h2+ orangepi zero v1.1
Signed-off-by: Karl Palsson karlp@tweak.net.au ---
Ideally, this should get into 2019.01, so that this release is not broken on those targets.
board/sunxi/board.c | 18 ++++++++---------- 1 file changed, 8 insertions(+), 10 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 917f5b18f6..f022f365e9 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -637,6 +637,13 @@ void sunxi_board_init(void) power_failed |= axp_set_sw(IS_ENABLED(CONFIG_AXP_SW_ON)); #endif #endif + printf("DRAM:"); + gd->ram_size = sunxi_dram_init(); + printf(" %d MiB\n", (int)(gd->ram_size >> 20)); + if (!gd->ram_size) + hang(); + + sunxi_spl_store_dram_size(gd->ram_size);
/* * Only clock up the CPU to full speed if we are reasonably @@ -645,16 +652,7 @@ void sunxi_board_init(void) if (!power_failed) clock_set_pll1(CONFIG_SYS_CLK_FREQ); else - printf("Error setting up the power controller.\n" - "CPU frequency not set.\n"); - - printf("DRAM:"); - gd->ram_size = sunxi_dram_init(); - printf(" %d MiB\n", (int)(gd->ram_size >> 20)); - if (!gd->ram_size) - hang(); - - sunxi_spl_store_dram_size(gd->ram_size); + printf("Failed to set core voltage! Can't set CPU frequency\n"); } #endif
- allwinner h3 nanopi-duo2
- allwinner h2+ orangepi zero v1.1
Tested-By: Priit Laes plaes@plaes.org
Tested with A20 Olinuxino Lime2 (where original works too) and H2+ OrangePi Zero V1.1 (where the original patch caused breakage).
printf("DRAM:");
if (!gd->ram_size)
hang();
- Only clock up the CPU to full speed if we are reasonably
- printf("DRAM:");
hang();
} #endif
-- 2.14.5
karlp@tweak.net.au
Priit Laes
