[PATCH V2 1/2] ARM: dts: stm32: Add alternate pinmux for SDMMC2 pins 4-7
Add another mux option for SDMMC2 pins 4..7, this is used on AV96 board.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrick Delaunay patrick.delaunay@st.com Cc: Patrice Chotard patrice.chotard@st.com --- V2: Use correct pin AFs --- arch/arm/dts/stm32mp157-pinctrl.dtsi | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/arch/arm/dts/stm32mp157-pinctrl.dtsi b/arch/arm/dts/stm32mp157-pinctrl.dtsi index 81a363d93d..1d0aac973c 100644 --- a/arch/arm/dts/stm32mp157-pinctrl.dtsi +++ b/arch/arm/dts/stm32mp157-pinctrl.dtsi @@ -907,6 +907,27 @@ }; };
+ sdmmc2_d47_pins_b: sdmmc2-d47-1 { + pins { + pinmux = <STM32_PINMUX('A', 8, AF9)>, /* SDMMC2_D4 */ + <STM32_PINMUX('A', 15, AF9)>, /* SDMMC2_D5 */ + <STM32_PINMUX('C', 6, AF10)>, /* SDMMC2_D6 */ + <STM32_PINMUX('C', 7, AF10)>; /* SDMMC2_D7 */ + slew-rate = <1>; + drive-push-pull; + bias-pull-up; + }; + }; + + sdmmc2_d47_sleep_pins_b: sdmmc2-d47-sleep-1 { + pins { + pinmux = <STM32_PINMUX('A', 8, ANALOG)>, /* SDMMC2_D4 */ + <STM32_PINMUX('A', 15, ANALOG)>, /* SDMMC2_D5 */ + <STM32_PINMUX('C', 6, ANALOG)>, /* SDMMC2_D6 */ + <STM32_PINMUX('C', 7, ANALOG)>; /* SDMMC2_D7 */ + }; + }; + spdifrx_pins_a: spdifrx-0 { pins { pinmux = <STM32_PINMUX('G', 12, AF8)>; /* SPDIF_IN1 */
The eMMC uses different pinmux for the top four data lines, use such a pinmux, otherwise it takes a very long time until the test for 8bit operation times out. And this is the correct pinmux per schematic too.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrick Delaunay patrick.delaunay@st.com Cc: Patrice Chotard patrice.chotard@st.com --- V2: No change --- arch/arm/dts/stm32mp157a-avenger96.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/stm32mp157a-avenger96.dts b/arch/arm/dts/stm32mp157a-avenger96.dts index 3065593bf2..e7505c7596 100644 --- a/arch/arm/dts/stm32mp157a-avenger96.dts +++ b/arch/arm/dts/stm32mp157a-avenger96.dts @@ -310,7 +310,7 @@
&sdmmc2 { pinctrl-names = "default"; - pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_a>; + pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_b>; non-removable; no-sd; no-sdio;
