[PATCH] i2c: i2c-gpio: Correctly handle new {sda,scl}-gpios bindings
gpio_request_list_by_name() returns the number of gpios requested. Notably it swallows the underlying -ENOENT when the "gpios" property does not exist.
Update the i2c-gpio driver to check for ret == 0 before trying the new sda-gpios/scl-gpios properties.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
drivers/i2c/i2c-gpio.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/i2c/i2c-gpio.c b/drivers/i2c/i2c-gpio.c index 4ed9e9e7cddd..c1fc290bd253 100644 --- a/drivers/i2c/i2c-gpio.c +++ b/drivers/i2c/i2c-gpio.c @@ -339,7 +339,7 @@ static int i2c_gpio_of_to_plat(struct udevice *dev) /* "gpios" is deprecated and replaced by "sda-gpios" + "scl-gpios". */ ret = gpio_request_list_by_name(dev, "gpios", bus->gpios, ARRAY_SIZE(bus->gpios), 0); - if (ret == -ENOENT) { + if (ret == 0) { ret = gpio_request_by_name(dev, "sda-gpios", 0, &bus->gpios[PIN_SDA], 0); if (ret < 0)
Chris Packham
