[patch v1] arm add initial support for the Phytium Pe2201 Board board:phytium:add pe2201 folder,It initializes pcie, ddr and other aspects of phytium pe2201 board dts:add phytium_pe2201.dts,it is device tree of phytium pe2201 board, include pcie and uart node
Signed-off-by: TracyMg_Li TracyMg_Li@outlook.com --- arch/arm/Kconfig | 8 ++ arch/arm/dts/Makefile | 1 + arch/arm/dts/phytium-pe2201.dts | 43 +++++++ board/phytium/pe2201/Kconfig | 12 ++ board/phytium/pe2201/MAINTAINERS | 8 ++ board/phytium/pe2201/Makefile | 12 ++ board/phytium/pe2201/cpu.h | 64 +++++++++++ board/phytium/pe2201/ddr.c | 190 +++++++++++++++++++++++++++++++ board/phytium/pe2201/pcie.c | 60 ++++++++++ board/phytium/pe2201/pe2201.c | 92 +++++++++++++++ board/phytium/pe2201/pll.c | 75 ++++++++++++ board/phytium/pe2201/sec.c | 37 ++++++ configs/pe2201_defconfig | 40 +++++++ include/configs/pe2201.h | 32 ++++++ 14 files changed, 674 insertions(+) create mode 100644 arch/arm/dts/phytium-pe2201.dts create mode 100644 board/phytium/pe2201/Kconfig create mode 100644 board/phytium/pe2201/MAINTAINERS create mode 100644 board/phytium/pe2201/Makefile create mode 100644 board/phytium/pe2201/cpu.h create mode 100644 board/phytium/pe2201/ddr.c create mode 100644 board/phytium/pe2201/pcie.c create mode 100644 board/phytium/pe2201/pe2201.c create mode 100644 board/phytium/pe2201/pll.c create mode 100644 board/phytium/pe2201/sec.c create mode 100644 configs/pe2201_defconfig create mode 100644 include/configs/pe2201.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index d812685c98..8a8f8805a0 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -2060,6 +2060,13 @@ config TARGET_POMELO Support for pomelo platform. It has 8GB Sdram, uart and pcie.
+config TARGET_PE2201 + bool "Support Phytium PE2201 Platform" + select ARM64 + help + Support for pe2201 platform. + It has 2GB Sdram, uart and pcie. + config TARGET_PRESIDIO_ASIC bool "Support Cortina Presidio ASIC Platform" select ARM64 @@ -2336,6 +2343,7 @@ source "board/variscite/dart_6ul/Kconfig" source "board/vscom/baltos/Kconfig" source "board/phytium/durian/Kconfig" source "board/phytium/pomelo/Kconfig" +source "board/phytium/pe2201/Kconfig" source "board/xen/xenguest_arm64/Kconfig"
source "arch/arm/Kconfig.debug" diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 5fc888680b..ce2fc626b0 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1469,6 +1469,7 @@ dtb-$(CONFIG_TARGET_TOTAL_COMPUTE) += total_compute.dtb
dtb-$(CONFIG_TARGET_DURIAN) += phytium-durian.dtb dtb-$(CONFIG_TARGET_POMELO) += phytium-pomelo.dtb +dtb-$(CONFIG_TARGET_PE2201) += phytium-pe2201.dtb
dtb-$(CONFIG_TARGET_PRESIDIO_ASIC) += ca-presidio-engboard.dtb
diff --git a/arch/arm/dts/phytium-pe2201.dts b/arch/arm/dts/phytium-pe2201.dts new file mode 100644 index 0000000000..e661e80f06 --- /dev/null +++ b/arch/arm/dts/phytium-pe2201.dts @@ -0,0 +1,43 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * dts file for Phytium pe2201 board + * Copyright (C) 2023, Phytium Technology Co., Ltd. + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ +/dts-v1/; + +/ { + model = "Phytium pe2201 Board"; + compatible = "phytium,pe2201"; + #address-cells = <2>; + #size-cells = <2>; + + aliases { + serial0 = &uart0; + }; + + uart0: serial@2800c000 { + compatible = "arm,pl011", "arm,primecell"; + reg = <0x0 0x2800c000 0x0 0x1000>; + clock = <100000000>; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + pcie@40000000 { + compatible = "pci-host-ecam-generic"; + device_type = "pci"; + #address-cells = <3>; + #size-cells = <2>; + reg = <0x0 0x40000000 0x0 0x10000000>; + ranges = <0x01000000 0x00 0x00000000 0x0 0x50000000 0x0 0x00F00000>, + <0x02000000 0x00 0x58000000 0x0 0x58000000 0x0 0x28000000>, + <0x43000000 0x10 0x00000000 0x10 0x00000000 0x10 0x00000000>; + }; + }; +}; diff --git a/board/phytium/pe2201/Kconfig b/board/phytium/pe2201/Kconfig new file mode 100644 index 0000000000..f2f222b5d3 --- /dev/null +++ b/board/phytium/pe2201/Kconfig @@ -0,0 +1,12 @@ +if TARGET_PE2201 + +config SYS_BOARD + default "pe2201" + +config SYS_VENDOR + default "phytium" + +config SYS_CONFIG_NAME + default "pe2201" + +endif diff --git a/board/phytium/pe2201/MAINTAINERS b/board/phytium/pe2201/MAINTAINERS new file mode 100644 index 0000000000..f583d631d2 --- /dev/null +++ b/board/phytium/pe2201/MAINTAINERS @@ -0,0 +1,8 @@ +PE2201 BOARD +M: lixinde lixinde@phytium.com.cn +M: weichangzheng weichangzheng@phytium.com.cn +S: Maintained +F: board/phytium/pe2201/* +F: include/configs/pe2201.h +F: configs/pe2201_defconfig +F: arch/arm/dts/phytium-pe2201.dts diff --git a/board/phytium/pe2201/Makefile b/board/phytium/pe2201/Makefile new file mode 100644 index 0000000000..5350f0f818 --- /dev/null +++ b/board/phytium/pe2201/Makefile @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2023, Phytium Technology Co., Ltd. +# lixinde lixinde@phytium.com.cn +# weichangzheng weichangzheng@phytium.com.cn +# + +obj-y += pe2201.o +obj-y += pll.o +obj-y += pcie.o +obj-y += ddr.o +obj-y += sec.o diff --git a/board/phytium/pe2201/cpu.h b/board/phytium/pe2201/cpu.h new file mode 100644 index 0000000000..01adbb0a17 --- /dev/null +++ b/board/phytium/pe2201/cpu.h @@ -0,0 +1,64 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2023, Phytium Technology Co., Ltd. + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#ifndef _FT_PE2201_H +#define _FT_PE2201_H + +/* SMCCC ID */ +#define CPU_SVC_VERSION 0xC2000F00 +#define CPU_GET_RST_SOURCE 0xC2000F01 +#define CPU_INIT_PLL 0xC2000F02 +#define CPU_INIT_PCIE 0xC2000F03 +#define CPU_INIT_MEM 0xC2000F04 +#define CPU_INIT_SEC_SVC 0xC2000F05 + +/* CPU RESET */ +#define CPU_RESET_POWER_ON 0x1 +#define CPU_RESET_PLL 0x4 +#define CPU_RESET_WATCH_DOG 0x8 + +/* PLL */ +#define PARAMETER_PLL_MAGIC 0x54460020 + +/* PCIE */ +#define PARAMETER_PCIE_MAGIC 0x54460021 +#define CFG_INDEPENDENT_TREE 0x0 +#define PCI_PEU0 0x1 +#define PCI_PEU1 0x1 +#define PEU1_OFFSET 16 +#define PEU_C_OFFSET_MODE 16 +#define PEU_C_OFFSET_SPEED 0 +#define X1X1X1X1 0x2 +#define X1X1 0x0 +#define EP_MODE 0x0 +#define RC_MODE 0x1 +#define GEN3 3 + +/* DDR */ +#define PARAMETER_MCU_MAGIC 0x54460024 +#define PARAM_MCU_VERSION 0x3 +#define PARAM_MCU_SIZE 0x100 +#define PARAM_CH_ENABLE 0x1 + +#define RDIMM_TYPE 0x1 +#define UDIMM_TYPE 0x2 +#define LPDDR4_TYPE 0x10 +#define DIMM_X8 0x1 +#define DIMM_X16 0x2 +#define NO_MIRROR 0x0 +#define NO_ECC_TYPE 0 +#define DDR4_TYPE 0xC + +/* SEC */ +#define PARAMETER_COMMON_MAGIC 0x54460013 + +void ddr_init(void); +void sec_init(void); +void check_reset(void); +void pcie_init(void); + +#endif /* _FT_PE2201_H */ diff --git a/board/phytium/pe2201/ddr.c b/board/phytium/pe2201/ddr.c new file mode 100644 index 0000000000..549d211ccd --- /dev/null +++ b/board/phytium/pe2201/ddr.c @@ -0,0 +1,190 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023, Phytium Technology Co., Ltd. + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#include <stdio.h> +#include <linux/arm-smccc.h> +#include <init.h> +#include "cpu.h" + +struct ddr_spd { + /***************** read from spd ******************/ + u8 dimm_type; /* 1: RDIMM; 2: UDIMM; 3: SODIMM; 4: LRDIMM */ + u8 data_width; /* 0: x4; 1: x8; 2: x16; 3: x32 */ + u8 mirror_type; /* 0: standard; 1: mirror */ + u8 ecc_type; /* 0: no-ecc; 1: ecc */ + u8 dram_type; /* 0xB: DDR3; 0xC: DDR4 */ + u8 rank_num; + u8 row_num; + u8 col_num; + + u8 bg_num; /* DDR4/DDR5 */ + u8 bank_num; + u16 module_manufacturer_id; + u16 taamin; + u16 trcdmin; + + u16 trpmin; + u16 trasmin; + u16 trcmin; + u16 tfawmin; /* only DDR3/DDR4 */ + + u16 trrd_smin; /* only DDR4 */ + u16 trrd_lmin; /* only DDR4 */ + u16 tccd_lmin; /* only DDR4 */ + u16 twrmin; + + u16 twtr_smin; /* only DDR4 */ + u16 twtr_lmin; /* only DDR4 */ + u32 trfc1min; + + u32 trfc2min; + u32 trfc4_rfcsbmin; /* DDR4: tRFC4min; DDR5: tRFCsbmin */ + u8 resv[8]; + + /***************** RCD control words ******************/ + u8 f0rc03; /* bit[3:2]:CS bit[1:0]:CA */ + u8 f0rc04; /* bit[3:2]:ODT bit[1:0]:CKE */ + u8 f0rc05; /* bit[3:2]:CLK-A side bit[1:0]:CLK-B side */ + u8 rcd_num; /* Registers used on RDIMM */ + + u8 lrdimm_resv[4]; + u8 lrdimm_resv1[8]; + u8 lrdimm_resv2[8]; +} __attribute((aligned(4))); + +struct mcu_config { + u32 magic; + u32 version; + u32 size; + u8 rev1[4]; + + u8 ch_enable; + u8 resv1[7]; + + u64 misc_enable; + + u8 train_debug; + u8 train_recover; + u8 train_param_type; + u8 train_param_1; /* DDR4: cpu_odt */ + u8 train_param_2; /* DDR4: cpu_drv */ + u8 train_param_3; /* DDR4: mr_drv */ + u8 train_param_4; /* DDR4: rtt_nom */ + u8 train_param_5; /* DDR4: rtt_park */ + + u8 train_param_6; /* DDR4: rtt_wr */ + u8 resv2[7]; + + /***************** for LPDDR4 dq swap ******************/ + u32 data_byte_swap; + u32 slice0_dq_swizzle; + + u32 slice1_dq_swizzle; + u32 slice2_dq_swizzle; + + u32 slice3_dq_swizzle; + u32 slice4_dq_swizzle; + + u32 slice5_dq_swizzle; + u32 slice6_dq_swizzle; + + u32 slice7_dq_swizzle; + u8 resv3[4]; + u8 resv4[8]; + + struct ddr_spd ddr_spd_info; +} __attribute((aligned(4))); + +static void get_mcu_up_info_default(struct mcu_config *pm) +{ + pm->magic = PARAMETER_MCU_MAGIC; + pm->version = PARAM_MCU_VERSION; + pm->size = PARAM_MCU_SIZE; + pm->ch_enable = PARAM_CH_ENABLE; +} + +static u8 init_dimm_param(struct mcu_config *pm) +{ + debug("manual config dimm info...\n"); + pm->misc_enable = 0x2001; + pm->train_debug = 0x0; + pm->train_recover = 0x0; + pm->train_param_type = 0x0; + pm->train_param_1 = 0x0; + pm->train_param_2 = 0x0; + pm->train_param_3 = 0x0; + pm->train_param_4 = 0x0; + pm->train_param_5 = 0x0; + pm->train_param_6 = 0x0; + + pm->data_byte_swap = 0x76543210; + pm->slice0_dq_swizzle = 0x3145726; + + pm->slice1_dq_swizzle = 0x54176230; + pm->slice2_dq_swizzle = 0x57604132; + + pm->slice3_dq_swizzle = 0x20631547; + pm->slice4_dq_swizzle = 0x16057423; + + pm->slice5_dq_swizzle = 0x16057423; + pm->slice6_dq_swizzle = 0x16057423; + + pm->slice7_dq_swizzle = 0x16057423; + + pm->ddr_spd_info.dimm_type = RDIMM_TYPE; + pm->ddr_spd_info.data_width = DIMM_X16; + pm->ddr_spd_info.mirror_type = NO_MIRROR; + pm->ddr_spd_info.ecc_type = NO_ECC_TYPE; + pm->ddr_spd_info.dram_type = LPDDR4_TYPE; + pm->ddr_spd_info.rank_num = 0x1; + pm->ddr_spd_info.row_num = 0x10; + pm->ddr_spd_info.col_num = 0xa; + pm->ddr_spd_info.bg_num = 0x0; + pm->ddr_spd_info.bank_num = 0x8; + pm->ddr_spd_info.taamin = 0x0; + pm->ddr_spd_info.trcdmin = 0x0; + + pm->ddr_spd_info.trpmin = 0x0; + pm->ddr_spd_info.trasmin = 0x0; + pm->ddr_spd_info.trcmin = 0x0; + pm->ddr_spd_info.tfawmin = 0x0; + + pm->ddr_spd_info.trrd_smin = 0x0; + pm->ddr_spd_info.trrd_lmin = 0x0; + pm->ddr_spd_info.tccd_lmin = 0x0; + pm->ddr_spd_info.twrmin = 0x0; + + pm->ddr_spd_info.twtr_smin = 0x0; + pm->ddr_spd_info.twtr_lmin = 0x0; + + return 0; +} + +void get_default_mcu_info(u8 *data) +{ + get_mcu_up_info_default((struct mcu_config *)data); +} + +void fix_mcu_info(u8 *data) +{ + struct mcu_config *mcu_info = (struct mcu_config *)data; + + init_dimm_param(mcu_info); +} + +void ddr_init(void) +{ + u8 buffer[0x100]; + struct arm_smccc_res res; + + get_default_mcu_info(buffer); + fix_mcu_info(buffer); + + arm_smccc_smc(CPU_INIT_MEM, 0, (u64)buffer, 0, 0, 0, 0, 0, &res); + if (res.a0 != 0) + panic("DRAM init failed :0x%lx\n", res.a0); +} diff --git a/board/phytium/pe2201/pcie.c b/board/phytium/pe2201/pcie.c new file mode 100644 index 0000000000..34c38d2aee --- /dev/null +++ b/board/phytium/pe2201/pcie.c @@ -0,0 +1,60 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023, Phytium Technology Co., Ltd. + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#include <stdio.h> +#include <string.h> +#include <linux/arm-smccc.h> +#include <init.h> +#include "cpu.h" + +struct pcu_ctr { + u32 base_config[4]; + u32 equalization[4]; + u8 rev[72]; +} __attribute((aligned(4))); + +struct pcu_config { + u32 magic; + u32 version; + u32 size; + u8 rev1[4]; + u32 independent_tree; + u32 base_cfg; + u8 rev2[16]; + struct pcu_ctr ctr_cfg[2]; +} __attribute((aligned(4))); + +struct pcu_config const peu_base_info = { + .magic = PARAMETER_PCIE_MAGIC, + .version = 0x4, + .size = 0x100, + .independent_tree = CFG_INDEPENDENT_TREE, + .base_cfg = ((PCI_PEU1 | (X1X1X1X1 << 1)) << PEU1_OFFSET | (PCI_PEU0 | (X1X1 << 1))), + .ctr_cfg[0].base_config[0] = (EP_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[0].base_config[1] = (EP_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[0].base_config[2] = (EP_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[1].base_config[0] = (EP_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[1].base_config[1] = (EP_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[1].base_config[2] = (EP_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[0].equalization[0] = 0x7, + .ctr_cfg[0].equalization[1] = 0x7, + .ctr_cfg[0].equalization[2] = 0x7, + .ctr_cfg[1].equalization[0] = 0x7, + .ctr_cfg[1].equalization[1] = 0x7, + .ctr_cfg[1].equalization[2] = 0x7, +}; + +void pcie_init(void) +{ + u8 buffer[0x100]; + struct arm_smccc_res res; + + memcpy(buffer, &peu_base_info, sizeof(peu_base_info)); + arm_smccc_smc(CPU_INIT_PCIE, 0, (u64)buffer, 0, 0, 0, 0, 0, &res); + if (res.a0 != 0) + panic("PCIE init failed :0x%lx\n", res.a0); +} diff --git a/board/phytium/pe2201/pe2201.c b/board/phytium/pe2201/pe2201.c new file mode 100644 index 0000000000..0e837b0f50 --- /dev/null +++ b/board/phytium/pe2201/pe2201.c @@ -0,0 +1,92 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023, Phytium Technology Co., Ltd. + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#include <stdio.h> +#include <command.h> +#include <init.h> +#include <asm/armv8/mmu.h> +#include <asm/io.h> +#include <linux/arm-smccc.h> +#include <scsi.h> +#include <asm/u-boot.h> +#include "cpu.h" + +DECLARE_GLOBAL_DATA_PTR; + +int mach_cpu_init(void) +{ + check_reset(); + return 0; +} + +int board_early_init_f(void) +{ + pcie_init(); + return 0; +} + +int dram_init(void) +{ + debug("Phytium ddr init\n"); + ddr_init(); + + gd->mem_clk = 0; + gd->ram_size = PHYS_SDRAM_1_SIZE; + + sec_init(); + debug("PBF relocate done\n"); + + return 0; +} + +int dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} + +int board_init(void) +{ + return 0; +} + +void reset_cpu(void) +{ + struct arm_smccc_res res; + + debug("run in reset cpu\n"); + arm_smccc_smc(0x84000009, 0, 0, 0, 0, 0, 0, 0, &res); + if (res.a0 != 0) + panic("reset cpu error, %lx\n", res.a0); +} + +static struct mm_region pe2201_mem_map[] = { + { + .virt = 0x0UL, + .phys = 0x0UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE | PTE_BLOCK_PXN + }, + { + .virt = 0x80000000UL, + .phys = 0x80000000UL, + .size = 0x7b000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | PTE_BLOCK_NS | PTE_BLOCK_INNER_SHARE + }, + { + 0, + } +}; + +struct mm_region *mem_map = pe2201_mem_map; + +int last_stage_init(void) +{ + return 0; +} diff --git a/board/phytium/pe2201/pll.c b/board/phytium/pe2201/pll.c new file mode 100644 index 0000000000..f46435c74b --- /dev/null +++ b/board/phytium/pe2201/pll.c @@ -0,0 +1,75 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023, Phytium Technology Co., Ltd. + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#include <stdio.h> +#include <string.h> +#include <asm/io.h> +#include <linux/arm-smccc.h> +#include <init.h> +#include "cpu.h" + +struct pll_config { + u32 magic; + u32 version; + u32 size; + u8 rev1[4]; + u32 clust0_pll; + u32 clust1_pll; + u32 clust2_pll; + u32 noc_pll; + u32 dmu_pll; +} __attribute((aligned(4))); + +struct pll_config const pll_base_info = { + .magic = PARAMETER_PLL_MAGIC, + .version = 0x2, + .size = 0x100, + .clust0_pll = 2000, + .clust1_pll = 2000, + .clust2_pll = 2000, + .noc_pll = 1800, + .dmu_pll = 600, +}; + +u32 get_reset_source(void) +{ + struct arm_smccc_res res; + + arm_smccc_smc(CPU_GET_RST_SOURCE, 0, 0, 0, 0, 0, 0, 0, &res); + + return res.a0; +} + +void pll_init(void) +{ + u8 buffer[0x100]; + struct arm_smccc_res res; + + memcpy(buffer, &pll_base_info, sizeof(pll_base_info)); + arm_smccc_smc(CPU_INIT_PLL, 0, (u64)buffer, 0, 0, 0, 0, 0, &res); + if (res.a0 != 0) + panic("PLL init failed :0x%lx\n", res.a0); +} + +void check_reset(void) +{ + u32 rst; + + rst = get_reset_source(); + + switch (rst) { + case CPU_RESET_POWER_ON: + pll_init(); + break; + case CPU_RESET_PLL: + break; + case CPU_RESET_WATCH_DOG: + break; + default: + panic("other reset source\n"); + } +} diff --git a/board/phytium/pe2201/sec.c b/board/phytium/pe2201/sec.c new file mode 100644 index 0000000000..6a980d6ea6 --- /dev/null +++ b/board/phytium/pe2201/sec.c @@ -0,0 +1,37 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023, Phytium Technology Co., Ltd. + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#include <stdio.h> +#include <string.h> +#include <linux/arm-smccc.h> +#include <init.h> +#include "cpu.h" + +struct common_config { + u32 magic; + u32 version; + u32 size; + u8 rev1[4]; + u64 core_bit_map; +} __attribute((aligned(4))); + +struct common_config const common_base_info = { + .magic = PARAMETER_COMMON_MAGIC, + .version = 0x1, + .core_bit_map = 0x3333, +}; + +void sec_init(void) +{ + u8 buffer[0x100]; + struct arm_smccc_res res; + + memcpy(buffer, &common_base_info, sizeof(common_base_info)); + arm_smccc_smc(CPU_INIT_SEC_SVC, 0, (u64)buffer, 0, 0, 0, 0, 0, &res); + if (res.a0 != 0) + panic("SEC init failed :0x%lx\n", res.a0); +} diff --git a/configs/pe2201_defconfig b/configs/pe2201_defconfig new file mode 100644 index 0000000000..5a2f8f6f5e --- /dev/null +++ b/configs/pe2201_defconfig @@ -0,0 +1,40 @@ +CONFIG_ARM=y +CONFIG_ARM_SMCCC=y +CONFIG_TARGET_PE2201=y +CONFIG_TEXT_BASE=0x38180000 +CONFIG_SYS_MALLOC_LEN=0x101000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x30c1a000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_DEFAULT_DEVICE_TREE="phytium-pe2201" +CONFIG_BOARD_EARLY_INIT_F=y +# CONFIG_PSCI_RESET is not set +CONFIG_AHCI=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_LOAD_ADDR=0x90000000 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="earlycon=pl011,0x2800c000 root=/dev/sda2 rw" +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_LAST_STAGE_INIT=y +CONFIG_SYS_PROMPT="pe2201#" +# CONFIG_CMD_LZMADEC is not set +# CONFIG_CMD_UNZIP is not set +CONFIG_CMD_PCI=y +CONFIG_CMD_DM=y +CONFIG_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +# CONFIG_NET is not set +CONFIG_DM=y +CONFIG_SCSI_AHCI=y +CONFIG_AHCI_PCI=y +CONFIG_BLK=y +# CONFIG_MMC is not set +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCI_PHYTIUM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_PL01X_SERIAL=y diff --git a/include/configs/pe2201.h b/include/configs/pe2201.h new file mode 100644 index 0000000000..ff24dc5ac6 --- /dev/null +++ b/include/configs/pe2201.h @@ -0,0 +1,32 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2023, Phytium Technology Co., Ltd. + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#ifndef __PE2201_CONFIG_H +#define __PE2201_CONFIG_H + +/* SDRAM Bank #1 start address */ +#define PHYS_SDRAM_1 0x80000000 +#define PHYS_SDRAM_1_SIZE 0x74000000 +#define CFG_SYS_SDRAM_BASE PHYS_SDRAM_1 + +/* BOOT */ +#define BOOT_TARGET_DEVICES(func) \ + func(SCSI, scsi, 0) \ + +#include <config_distro_bootcmd.h> + +/* Initial environment variables */ +#define CFG_EXTRA_ENV_SETTINGS \ + "image=Image\0" \ + BOOTENV \ + "scriptaddr=0x90100000\0" \ + "kernel_addr_r=0x90200000\0" \ + "fdt_addr_r=0x95000000\0" \ + "boot_fit=no\0" \ + "fdtfile=phytium-pe2201.dtb\0" \ + +#endif
Please rework your commit message.
Please make sure this dts is being submitted upstream and passes validation there before submitting it upstream too.
[snip]
- bool "Support Phytium PE2201 Platform"
- select ARM64
- help
Was your patch spacing corrupted? If not, please fix this here.
[snip]
- Copyright (C) 2023, Phytium Technology Co., Ltd.
- lixinde lixinde@phytium.com.cn
- weichangzheng weichangzheng@phytium.com.cn
- func(SCSI, scsi, 0) \
- "image=Image\0" \
- BOOTENV \
- "scriptaddr=0x90100000\0" \
- "kernel_addr_r=0x90200000\0" \
- "fdt_addr_r=0x95000000\0" \
- "boot_fit=no\0" \
- "fdtfile=phytium-pe2201.dtb\0" \
Please switch to both bootstd and plain text environment, thanks.
