[U-Boot] [PATCH] powerpc/mpc85xx: Use GOT when loading IVORs post-relocation
Commit 96d2bb952bb ("powerpc/mpc85xx: Don't relocate exception vectors") simplified IVOR initialization a bit too much, failing to use the post-relocation offset. This doesn't cause a problem with normal NOR boot, in which both the pre-relocation and post-relocation addresses are 64 KiB aligned. However, if TEXT_BASE is only 4 KiB aligned, such as for NAND/SD/etc. boot on some targets, as well as the QEMU target, the post-relocation address will not be the same in the lower 16 bits, as reserve_uboot() ensures that the relocation address is always 64 KiB aligned even if the pre-relocation address was not.
Use the GOT to get the proper post-relocation offsets.
Fixes: 96d2bb952bb ("powerpc/mpc85xx: Don't relocate exception vectors") Signed-off-by: Scott Wood scottwood@freescale.com Cc: Alexander Graf agraf@suse.de Cc: Shaohui Xie Shaohui.Xie@freescale.com --- arch/powerpc/cpu/mpc85xx/start.S | 35 ++++++++++++++++++++--------------- 1 file changed, 20 insertions(+), 15 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 28f04ee..e61d8e0 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -1664,41 +1664,46 @@ clear_bss: */ .globl trap_init trap_init: + mflr r11 + bl _GLOBAL_OFFSET_TABLE_-4 + mflr r12 + /* Update IVORs as per relocation */ mtspr IVPR,r3
- li r4,CriticalInput@l + lwz r4,CriticalInput@got(r12) mtspr IVOR0,r4 /* 0: Critical input */ - li r4,MachineCheck@l + lwz r4,MachineCheck@got(r12) mtspr IVOR1,r4 /* 1: Machine check */ - li r4,DataStorage@l + lwz r4,DataStorage@got(r12) mtspr IVOR2,r4 /* 2: Data storage */ - li r4,InstStorage@l + lwz r4,InstStorage@got(r12) mtspr IVOR3,r4 /* 3: Instruction storage */ - li r4,ExtInterrupt@l + lwz r4,ExtInterrupt@got(r12) mtspr IVOR4,r4 /* 4: External interrupt */ - li r4,Alignment@l + lwz r4,Alignment@got(r12) mtspr IVOR5,r4 /* 5: Alignment */ - li r4,ProgramCheck@l + lwz r4,ProgramCheck@got(r12) mtspr IVOR6,r4 /* 6: Program check */ - li r4,FPUnavailable@l + lwz r4,FPUnavailable@got(r12) mtspr IVOR7,r4 /* 7: floating point unavailable */ - li r4,SystemCall@l + lwz r4,SystemCall@got(r12) mtspr IVOR8,r4 /* 8: System call */ /* 9: Auxiliary processor unavailable(unsupported) */ - li r4,Decrementer@l + lwz r4,Decrementer@got(r12) mtspr IVOR10,r4 /* 10: Decrementer */ - li r4,IntervalTimer@l + lwz r4,IntervalTimer@got(r12) mtspr IVOR11,r4 /* 11: Interval timer */ - li r4,WatchdogTimer@l + lwz r4,WatchdogTimer@got(r12) mtspr IVOR12,r4 /* 12: Watchdog timer */ - li r4,DataTLBError@l + lwz r4,DataTLBError@got(r12) mtspr IVOR13,r4 /* 13: Data TLB error */ - li r4,InstructionTLBError@l + lwz r4,InstructionTLBError@got(r12) mtspr IVOR14,r4 /* 14: Instruction TLB error */ - li r4,DebugBreakpoint@l + lwz r4,DebugBreakpoint@got(r12) mtspr IVOR15,r4 /* 15: Debug */
+ mtlr r11 blr
.globl unlock_ram_in_cache
Tested on T4240QDS_NAND and T4240QDS_SDCARD, the hang issue fixed. Thanks!
Best Regards, Shaohui Xie
-----Original Message----- From: Wood Scott-B07421 Sent: Friday, April 24, 2015 9:02 AM To: u-boot@lists.denx.de; Sun York-R58495 Cc: Wood Scott-B07421; Alexander Graf; Xie Shaohui-B21989 Subject: [PATCH] powerpc/mpc85xx: Use GOT when loading IVORs post- relocation
Commit 96d2bb952bb ("powerpc/mpc85xx: Don't relocate exception vectors") simplified IVOR initialization a bit too much, failing to use the post- relocation offset. This doesn't cause a problem with normal NOR boot, in which both the pre-relocation and post-relocation addresses are 64 KiB aligned. However, if TEXT_BASE is only 4 KiB aligned, such as for NAND/SD/etc. boot on some targets, as well as the QEMU target, the post- relocation address will not be the same in the lower 16 bits, as reserve_uboot() ensures that the relocation address is always 64 KiB aligned even if the pre-relocation address was not.
- mflr r11
- bl _GLOBAL_OFFSET_TABLE_-4
- mflr r12
- /* Update IVORs as per relocation */ mtspr IVPR,r3
- lwz r4,CriticalInput@got(r12) mtspr IVOR0,r4 /* 0: Critical input */
- lwz r4,MachineCheck@got(r12) mtspr IVOR1,r4 /* 1: Machine check */
- lwz r4,DataStorage@got(r12) mtspr IVOR2,r4 /* 2: Data storage */
- lwz r4,InstStorage@got(r12) mtspr IVOR3,r4 /* 3: Instruction storage */
- lwz r4,ExtInterrupt@got(r12) mtspr IVOR4,r4 /* 4: External interrupt */
- li r4,Alignment@l
- lwz r4,Alignment@got(r12) mtspr IVOR5,r4 /* 5: Alignment */
- lwz r4,ProgramCheck@got(r12) mtspr IVOR6,r4 /* 6: Program check */
- lwz r4,FPUnavailable@got(r12) mtspr IVOR7,r4 /* 7: floating point unavailable */
- lwz r4,SystemCall@got(r12) mtspr IVOR8,r4 /* 8: System call */ /* 9: Auxiliary processor unavailable(unsupported) */
- lwz r4,Decrementer@got(r12) mtspr IVOR10,r4 /* 10: Decrementer */
- lwz r4,IntervalTimer@got(r12) mtspr IVOR11,r4 /* 11: Interval timer */
- lwz r4,WatchdogTimer@got(r12) mtspr IVOR12,r4 /* 12: Watchdog timer */
- lwz r4,DataTLBError@got(r12) mtspr IVOR13,r4 /* 13: Data TLB error */
- lwz r4,InstructionTLBError@got(r12) mtspr IVOR14,r4 /* 14: Instruction TLB error */
mtlr r11 blr
2.1.0
Shaohui,
Thanks for confirmation. Please reply with your Test-by or Acked-by signature. The signature will be capture when the patch is applied.
York
- mflr r11
- mflr r12
- li r4,Alignment@l
mtlr r11 blr
2.1.0
Tested-by: Shaohui Xie Shaohui.Xie@freescale.com
Applied to u-boot-mpc85xx master branch. Awaiting upstream.
York
Scott Wood
Shaohui Xie
York Sun
