Re: [U-Boot] Newbie SPL question for socfpga_sockit
On 3 March 2016 at 15:07, Marek Vasut marex@denx.de wrote:
On 3 March 2016 at 14:42, Marek Vasut marex@denx.de wrote:
On 03/03/2016 11:27 PM, George Broz wrote:
Hi Marek,
Hi!
Yes - would love to be using the SPL from 2016.01 for the Terasic board, but it does not seem to be working for me with the files from the repo or with handoff files I supply & run through qts-filter.sh. This is about two layers below where my normal expertise is, so any help getting 2016.01 (or later) SPL working (with the end goal of having working USB) would be much appreciated!
Are you using sockit ? Which revision (it's etched in the PCB from the bottom, it's not silkscreen but really part of the copper) ? I'll test it and get back to you. If I happen to forget about it, remind me ;-)
Best regards, --George Broz
On 3 March 2016 at 14:09, Marek Vasut marex@denx.de wrote:
On 03/03/2016 11:00 PM, George Broz wrote:
On 3 March 2016 at 06:51, Marek Vasut marex@denx.de wrote: > On 03/03/2016 03:48 PM, Dinh Nguyen wrote: >> >> >> On 03/02/2016 05:24 PM, Marek Vasut wrote: >>> >>> Well, that's our usual USB/QSPI cache issue that's tormenting your soul. >>> CCing Chin ;-) >>> >>> Does the issue by any chance magically disappear if you apply this patch: >>> >>> diff --git a/arch/arm/include/asm/system.h b/arch/arm/include/asm/system.h >>> index 026e7ef..06802c6 100644 >>> --- a/arch/arm/include/asm/system.h >>> +++ b/arch/arm/include/asm/system.h >>> @@ -274,7 +274,7 @@ static inline void set_dacr(unsigned int val) >>> >>> /* options available for data cache on each page */ >>> enum dcache_option { >>> - DCACHE_OFF = TTB_SECT_DOMAIN(0) | TTB_SECT_XN_MASK | TTB_SECT, >>> + DCACHE_OFF = TTB_SECT_S_MASK | TTB_SECT_DOMAIN(0) | >>> TTB_SECT_XN_MASK | TTB_SECT, >>> DCACHE_WRITETHROUGH = DCACHE_OFF | TTB_SECT_C_MASK, >>> DCACHE_WRITEBACK = DCACHE_WRITETHROUGH | TTB_SECT_B_MASK, >>> DCACHE_WRITEALLOC = DCACHE_WRITEBACK | TTB_SECT_TEX(1), >>>
The 2016.01 code I'm using already includes this patch. If I try reading a USB stick with dcache on or off I get the same result:
=> dcache off => usb reset resetting USB... USB0: Core Release: 2.93a dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! scanning bus 0 for devices... 1 USB Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) U-Boot Root Hub
This more likely means that either clock or reset bits are not configured correctly OR you're using the wrong controller. Since you're mixing old U-Boot SPL with new U-Boot, there can be some discrepancy and I have no idea how to help you with that :(
Best regards, Marek Vasut
-- Best regards, Marek Vasut
On 03/03/2016 11:57 PM, George Broz wrote:
Yes - using SocKit, revision D (etching is 10-31212180-D0).
Thanks - any help is much appreciated!
Try attached patch.
Thanks, Marek. The patch applied cleanly, but the end result is the same
(with DLEVEL=1 in sequencer.c) I get U-Boot SPL 2016.01 (Mar 03 2016 - 15:28:06) scc_mgr_initialize:281: Clearing SCC RFILE index 0 scc_mgr_initialize:281: Clearing SCC RFILE index 1 scc_mgr_initialize:281: Clearing SCC RFILE index 2 scc_mgr_initialize:281: Clearing SCC RFILE index 3 scc_mgr_initialize:281: Clearing SCC RFILE index 4 scc_mgr_initialize:281: Clearing SCC RFILE index 5 scc_mgr_initialize:281: Clearing SCC RFILE index 6 scc_mgr_initialize:281: Clearing SCC RFILE index 7 scc_mgr_initialize:281: Clearing SCC RFILE index 8 scc_mgr_initialize:281: Clearing SCC RFILE index 9 scc_mgr_initialize:281: Clearing SCC RFILE index 10 scc_mgr_initialize:281: Clearing SCC RFILE index 11 scc_mgr_initialize:281: Clearing SCC RFILE index 12 scc_mgr_initialize:281: Clearing SCC RFILE index 13 scc_mgr_initialize:281: Clearing SCC RFILE index 14 scc_mgr_initialize:281: Clearing SCC RFILE index 15
4x then hang.
George Broz
