[U-Boot-Users] PATCH: support JEDEC flash roms in CFI-flash framework
the following patch adds support for non-CFI flash ROMS, by hooking into the CFI flash code and using most of its code, as recently discussed here in the thread "Mixing CFI and non-CFI flashs".
Signed-off-by: Michael Schwingen michael@schwingen.org
diff --git a/drivers/Makefile b/drivers/Makefile index d19588f..4a2b11e 100755 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -29,7 +29,7 @@ LIB = $(obj)libdrivers.a
COBJS = 3c589.o 5701rls.o ali512x.o at45.o ata_piix.o \ ati_radeon_fb.o atmel_usart.o \ - bcm570x.o bcm570x_autoneg.o cfb_console.o cfi_flash.o \ + bcm570x.o bcm570x_autoneg.o cfb_console.o cfi_flash.o jedec_flash.o \ cs8900.o ct69000.o dataflash.o dc2114x.o dm9000x.o \ ds1722.o e1000.o eepro100.o enc28j60.o \ fsl_i2c.o fsl_pci_init.o \ diff --git a/drivers/cfi_flash.c b/drivers/cfi_flash.c index 5579a1e..a437193 100644 --- a/drivers/cfi_flash.c +++ b/drivers/cfi_flash.c @@ -98,10 +98,6 @@ #define AMD_STATUS_TOGGLE 0x40 #define AMD_STATUS_ERROR 0x20
-#define AMD_ADDR_ERASE_START ((info->portwidth == FLASH_CFI_8BIT) ? 0xAAA : 0x555) -#define AMD_ADDR_START ((info->portwidth == FLASH_CFI_8BIT) ? 0xAAA : 0x555) -#define AMD_ADDR_ACK ((info->portwidth == FLASH_CFI_8BIT) ? 0x555 : 0x2AA) - #define FLASH_OFFSET_MANUFACTURER_ID 0x00 #define FLASH_OFFSET_DEVICE_ID 0x01 #define FLASH_OFFSET_DEVICE_ID2 0x0E @@ -331,6 +327,62 @@ ulong flash_read_long (flash_info_t * info, flash_sect_t sect, uint offset) }
+#ifdef CFG_FLASH_CFI_LEGACY +/*----------------------------------------------------------------------- + * Call board code to request info about non-CFI flash. + * board_flash_get_legacy needs to fill in at least: + * info->portwidth, info->chipwidth and info->interface for Jedec probing. + */ +int flash_detect_legacy(ulong base, int banknum) +{ + flash_info_t *info = &flash_info[banknum]; + if (board_flash_get_legacy(base, banknum, info)) { + /* board code may have filled info completely. If not, we + use JEDEC ID probing. */ + if (!info->vendor) { + int modes[] = { CFI_CMDSET_AMD_STANDARD, CFI_CMDSET_INTEL_STANDARD }; + int i; + + for(i=0; i<sizeof(modes)/sizeof(modes[0]); i++) { + info->vendor = modes[i]; + info->start[0] = base; + if (info->portwidth == FLASH_CFI_8BIT && info->interface == FLASH_CFI_X8X16) { + info->unlock_addr1 = 0x2AAA; + info->unlock_addr2 = 0x5555; + } else { + info->unlock_addr1 = 0x5555; + info->unlock_addr2 = 0x2AAA; + } + flash_read_jedec_ids(info); + debug("JEDEC PROBE: ID %x %x %x\n", info->manufacturer_id, info->device_id, info->device_id2); + if (jedec_flash_match(info, base)) + break; + } + } + switch(info->vendor) { + case CFI_CMDSET_INTEL_STANDARD: + case CFI_CMDSET_INTEL_EXTENDED: + info->cmd_reset = FLASH_CMD_RESET; + break; + case CFI_CMDSET_AMD_STANDARD: + case CFI_CMDSET_AMD_EXTENDED: + case CFI_CMDSET_AMD_LEGACY: + info->cmd_reset = AMD_CMD_RESET; + break; + } + info->flash_id = FLASH_MAN_CFI; + return 1; + } + return 0; /* use CFI */ +} +#else +int inline flash_detect_legacy(ulong base, int banknum) +{ + return 0; /* use CFI */ +} +#endif + + /*----------------------------------------------------------------------- */ unsigned long flash_init (void) @@ -345,7 +397,10 @@ unsigned long flash_init (void) /* Init: no FLASHes known */ for (i = 0; i < CFG_MAX_FLASH_BANKS; ++i) { flash_info[i].flash_id = FLASH_UNKNOWN; - size += flash_info[i].size = flash_get_size (bank_base[i], i); + + if (!flash_detect_legacy (bank_base[i], i)) + flash_get_size (bank_base[i], i); + size += flash_info[i].size; if (flash_info[i].flash_id == FLASH_UNKNOWN) { #ifndef CFG_FLASH_QUIET_TEST printf ("## Unknown FLASH on Bank %d - Size = 0x%08lx = %ld MB\n", @@ -483,11 +538,18 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) case CFI_CMDSET_AMD_STANDARD: case CFI_CMDSET_AMD_EXTENDED: flash_unlock_seq (info, sect); - flash_write_cmd (info, sect, AMD_ADDR_ERASE_START, - AMD_CMD_ERASE_START); + flash_write_cmd (info, sect, info->unlock_addr1, AMD_CMD_ERASE_START); flash_unlock_seq (info, sect); flash_write_cmd (info, sect, 0, AMD_CMD_ERASE_SECTOR); break; +#ifdef CFG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: + flash_unlock_seq (info, 0); + flash_write_cmd (info, 0, info->unlock_addr1, AMD_CMD_ERASE_START); + flash_unlock_seq (info, 0); + flash_write_cmd (info, sect, 0, AMD_CMD_ERASE_SECTOR); + break; +#endif default: debug ("Unkown flash vendor %d\n", info->vendor); @@ -516,10 +578,15 @@ void flash_print_info (flash_info_t * info) return; }
- printf ("CFI conformant FLASH (%d x %d)", + printf ("%s FLASH (%d x %d)", + info->name, (info->portwidth << 3), (info->chipwidth << 3)); - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); + if (info->size < 1024*1024) + printf (" Size: %ld kB in %d Sectors\n", + info->size >> 10, info->sector_count); + else + printf (" Size: %ld MB in %d Sectors\n", + info->size >> 20, info->sector_count); printf (" "); switch (info->vendor) { case CFI_CMDSET_INTEL_STANDARD: @@ -534,6 +601,11 @@ void flash_print_info (flash_info_t * info) case CFI_CMDSET_AMD_EXTENDED: printf ("AMD Extended"); break; +#ifdef CFG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: + printf ("AMD Legacy"); + break; +#endif default: printf ("Unknown (%d)", info->vendor); break; @@ -777,6 +849,9 @@ static int flash_is_busy (flash_info_t * info, flash_sect_t sect) break; case CFI_CMDSET_AMD_STANDARD: case CFI_CMDSET_AMD_EXTENDED: +#ifdef CFG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: +#endif retval = flash_toggle (info, sect, 0, AMD_STATUS_TOGGLE); break; default: @@ -967,8 +1042,8 @@ static void flash_write_cmd (flash_info_t * info, flash_sect_t sect, uint offset
static void flash_unlock_seq (flash_info_t * info, flash_sect_t sect) { - flash_write_cmd (info, sect, AMD_ADDR_START, AMD_CMD_UNLOCK_START); - flash_write_cmd (info, sect, AMD_ADDR_ACK, AMD_CMD_UNLOCK_ACK); + flash_write_cmd (info, sect, info->unlock_addr1, AMD_CMD_UNLOCK_START); + flash_write_cmd (info, sect, info->unlock_addr2, AMD_CMD_UNLOCK_ACK); }
/*----------------------------------------------------------------------- @@ -1105,7 +1180,7 @@ static void flash_read_jedec_ids (flash_info_t * info) case CFI_CMDSET_AMD_EXTENDED: flash_write_cmd(info, 0, 0, AMD_CMD_RESET); flash_unlock_seq(info, 0); - flash_write_cmd(info, 0, AMD_ADDR_START, FLASH_CMD_READ_ID); + flash_write_cmd(info, 0, info->unlock_addr1, FLASH_CMD_READ_ID); udelay(1000); /* some flash are slow to respond */ info->manufacturer_id = flash_read_uchar (info, FLASH_OFFSET_MANUFACTURER_ID); @@ -1156,6 +1231,10 @@ static int flash_detect_cfi (flash_info_t * info) debug ("port %d bits chip %d bits\n", info->portwidth << CFI_FLASH_SHIFT_WIDTH, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); + /* this probably only works if info->interface == FLASH_CFI_X8X16 */ + info->unlock_addr1 = (info->portwidth == FLASH_CFI_8BIT) ? 0xAAA : 0x555; + info->unlock_addr2 = (info->portwidth == FLASH_CFI_8BIT) ? 0x555 : 0x2AA; + info->name = "CFI conformant"; return 1; } } @@ -1282,6 +1361,10 @@ ulong flash_get_size (ulong base, int banknum) debug ("erase_region_count = %d erase_region_size = %d\n", erase_region_count, erase_region_size); for (j = 0; j < erase_region_count; j++) { + if (sect_cnt >= CFG_MAX_FLASH_SECT) { + printf("ERROR: too many flash sectors\n"); + break; + } info->start[sect_cnt] = sector; sector += (erase_region_size * size_ratio);
@@ -1384,8 +1467,11 @@ static int flash_write_cfiword (flash_info_t * info, ulong dest, break; case CFI_CMDSET_AMD_EXTENDED: case CFI_CMDSET_AMD_STANDARD: +#ifdef CFG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: +#endif flash_unlock_seq (info, 0); - flash_write_cmd (info, 0, AMD_ADDR_START, AMD_CMD_WRITE); + flash_write_cmd (info, 0, info->unlock_addr1, AMD_CMD_WRITE); break; }
diff --git a/drivers/jedec_flash.c b/drivers/jedec_flash.c new file mode 100644 index 0000000..10ffb9e --- /dev/null +++ b/drivers/jedec_flash.c @@ -0,0 +1,315 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * based in great part on jedec_probe.c from linux kernel: + * (C) 2000 Red Hat. GPL'd. + * Occasionally maintained by Thayne Harbaugh tharbaugh at lnxi dot com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +/* The DEBUG define must be before common to enable debugging */ +/*#define DEBUG*/ + +#include <common.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <asm/byteorder.h> +#include <environment.h> + +#if defined CFG_FLASH_CFI_DRIVER && defined CFG_FLASH_CFI_LEGACY + +#define P_ID_AMD_STD CFI_CMDSET_AMD_LEGACY + +/* Manufacturers */ +#define MANUFACTURER_AMD 0x0001 +#define MANUFACTURER_SST 0x00BF + +/* AMD */ +#define AM29DL800BB 0x22C8 +#define AM29DL800BT 0x224A + +#define AM29F800BB 0x2258 +#define AM29F800BT 0x22D6 +#define AM29LV400BB 0x22BA +#define AM29LV400BT 0x22B9 +#define AM29LV800BB 0x225B +#define AM29LV800BT 0x22DA +#define AM29LV160DT 0x22C4 +#define AM29LV160DB 0x2249 +#define AM29F017D 0x003D +#define AM29F016D 0x00AD +#define AM29F080 0x00D5 +#define AM29F040 0x00A4 +#define AM29LV040B 0x004F +#define AM29F032B 0x0041 +#define AM29F002T 0x00B0 + +/* SST */ +#define SST39LF800 0x2781 +#define SST39LF160 0x2782 +#define SST39VF1601 0x234b +#define SST39LF512 0x00D4 +#define SST39LF010 0x00D5 +#define SST39LF020 0x00D6 +#define SST39LF040 0x00D7 +#define SST39SF010A 0x00B5 +#define SST39SF020A 0x00B6 + + +/* + * Unlock address sets for AMD command sets. + * Intel command sets use the MTD_UADDR_UNNECESSARY. + * Each identifier, except MTD_UADDR_UNNECESSARY, and + * MTD_UADDR_NO_SUPPORT must be defined below in unlock_addrs[]. + * MTD_UADDR_NOT_SUPPORTED must be 0 so that structure + * initialization need not require initializing all of the + * unlock addresses for all bit widths. + */ +enum uaddr { + MTD_UADDR_NOT_SUPPORTED = 0, /* data width not supported */ + MTD_UADDR_0x0555_0x02AA, + MTD_UADDR_0x0555_0x0AAA, + MTD_UADDR_0x5555_0x2AAA, + MTD_UADDR_0x0AAA_0x0555, + MTD_UADDR_DONT_CARE, /* Requires an arbitrary address */ + MTD_UADDR_UNNECESSARY, /* Does not require any address */ +}; + + +struct unlock_addr { + u32 addr1; + u32 addr2; +}; + + +/* + * I don't like the fact that the first entry in unlock_addrs[] + * exists, but is for MTD_UADDR_NOT_SUPPORTED - and, therefore, + * should not be used. The problem is that structures with + * initializers have extra fields initialized to 0. It is _very_ + * desireable to have the unlock address entries for unsupported + * data widths automatically initialized - that means that + * MTD_UADDR_NOT_SUPPORTED must be 0 and the first entry here + * must go unused. + */ +static const struct unlock_addr unlock_addrs[] = { + [MTD_UADDR_NOT_SUPPORTED] = { + .addr1 = 0xffff, + .addr2 = 0xffff + }, + + [MTD_UADDR_0x0555_0x02AA] = { + .addr1 = 0x0555, + .addr2 = 0x02aa + }, + + [MTD_UADDR_0x0555_0x0AAA] = { + .addr1 = 0x0555, + .addr2 = 0x0aaa + }, + + [MTD_UADDR_0x5555_0x2AAA] = { + .addr1 = 0x5555, + .addr2 = 0x2aaa + }, + + [MTD_UADDR_0x0AAA_0x0555] = { + .addr1 = 0x0AAA, + .addr2 = 0x0555 + }, + + [MTD_UADDR_DONT_CARE] = { + .addr1 = 0x0000, /* Doesn't matter which address */ + .addr2 = 0x0000 /* is used - must be last entry */ + }, + + [MTD_UADDR_UNNECESSARY] = { + .addr1 = 0x0000, + .addr2 = 0x0000 + } +}; + + +struct amd_flash_info { + const __u16 mfr_id; + const __u16 dev_id; + const char *name; + const int DevSize; + const int NumEraseRegions; + const int CmdSet; + const __u8 uaddr[4]; /* unlock addrs for 8, 16, 32, 64 */ + const ulong regions[6]; +}; + +#define ERASEINFO(size,blocks) (size<<8)|(blocks-1) + +#define SIZE_64KiB 16 +#define SIZE_128KiB 17 +#define SIZE_256KiB 18 +#define SIZE_512KiB 19 +#define SIZE_1MiB 20 +#define SIZE_2MiB 21 +#define SIZE_4MiB 22 +#define SIZE_8MiB 23 + +static const struct amd_flash_info jedec_table[] = { +#ifdef CFG_FLASH_LEGACY_256Kx8 + { + .mfr_id = MANUFACTURER_SST, + .dev_id = SST39LF020, + .name = "SST 39LF020", + .uaddr = { + [0] = MTD_UADDR_0x5555_0x2AAA /* x8 */ + }, + .DevSize = SIZE_256KiB, + .CmdSet = P_ID_AMD_STD, + .NumEraseRegions= 1, + .regions = { + ERASEINFO(0x01000,64), + } + }, +#endif +#ifdef CFG_FLASH_LEGACY_512Kx8 + { + .mfr_id = MANUFACTURER_AMD, + .dev_id = AM29LV040B, + .name = "AMD AM29LV040B", + .uaddr = { + [0] = MTD_UADDR_0x0555_0x02AA /* x8 */ + }, + .DevSize = SIZE_512KiB, + .CmdSet = P_ID_AMD_STD, + .NumEraseRegions= 1, + .regions = { + ERASEINFO(0x10000,8), + } + }, + { + .mfr_id = MANUFACTURER_SST, + .dev_id = SST39LF040, + .name = "SST 39LF040", + .uaddr = { + [0] = MTD_UADDR_0x5555_0x2AAA /* x8 */ + }, + .DevSize = SIZE_512KiB, + .CmdSet = P_ID_AMD_STD, + .NumEraseRegions= 1, + .regions = { + ERASEINFO(0x01000,128), + } + }, +#endif +}; + + +#define ARRAY_SIZE(x) (sizeof(x) / sizeof((x)[0])) + + +static inline void fill_info(flash_info_t *info, const struct amd_flash_info *jedec_entry, ulong base) +{ + int i,j; + int sect_cnt; + int size_ratio; + int total_size; + enum uaddr uaddr_idx; + + size_ratio = info->portwidth / info->chipwidth; + + debug("Found JEDEC Flash: %s\n", jedec_entry->name); + info->vendor = jedec_entry->CmdSet; + /* Todo: do we need device-specific timeouts? */ + info->erase_blk_tout = 30000; + info->buffer_write_tout = 1000; + info->write_tout = 100; + info->name = jedec_entry->name; + + /* copy unlock addresses from device table to CFI info struct. This + is just here because the addresses are in the table anyway - if + the flash is not detected due to wrong unlock addresses, + flash_detect_legacy would have to try all of them before we even + get here. */ + switch(info->chipwidth) { + case FLASH_CFI_8BIT: + uaddr_idx = jedec_entry->uaddr[0]; + break; + case FLASH_CFI_16BIT: + uaddr_idx = jedec_entry->uaddr[1]; + break; + case FLASH_CFI_32BIT: + uaddr_idx = jedec_entry->uaddr[2]; + break; + default: + uaddr_idx = MTD_UADDR_NOT_SUPPORTED; + break; + } + + debug("unlock address index %d\n", uaddr_idx); + info->unlock_addr1 = unlock_addrs[uaddr_idx].addr1; + info->unlock_addr2 = unlock_addrs[uaddr_idx].addr2; + debug("unlock addresses are 0x%x/0x%x\n", info->unlock_addr1, info->unlock_addr2); + + sect_cnt = 0; + total_size = 0; + for (i = 0; i < jedec_entry->NumEraseRegions; i++) { + ulong erase_region_size = jedec_entry->regions[i] >> 8; + ulong erase_region_count = (jedec_entry->regions[i] & 0xff) + 1; + + total_size += erase_region_size * erase_region_count; + debug ("erase_region_count = %d erase_region_size = %d\n", + erase_region_count, erase_region_size); + for (j = 0; j < erase_region_count; j++) { + if (sect_cnt >= CFG_MAX_FLASH_SECT) { + printf("ERROR: too many flash sectors\n"); + break; + } + info->start[sect_cnt] = base; + base += (erase_region_size * size_ratio); + sect_cnt++; + } + } + info->sector_count = sect_cnt; + info->size = total_size * size_ratio; +} + +/*----------------------------------------------------------------------- + * match jedec ids against table. If a match is found, fill flash_info entry + */ +int jedec_flash_match(flash_info_t *info, ulong base) +{ + int ret = 0; + int i; + ulong mask = 0xFFFF; + if (info->chipwidth == 1) + mask = 0xFF; + + for (i = 0; i < ARRAY_SIZE(jedec_table); i++) { + if ( (jedec_table[i].mfr_id & mask) == (info->manufacturer_id & mask) && + (jedec_table[i].dev_id & mask) == (info->device_id & mask)) { + fill_info(info, &jedec_table[i], base); + ret = 1; + break; + } + } + return ret; +} + +#endif /* defined CFG_FLASH_CFI_DRIVER && defined CFG_FLASH_CFI_LEGACY */ diff --git a/include/flash.h b/include/flash.h index b0bf733..bbd3b98 100644 --- a/include/flash.h +++ b/include/flash.h @@ -52,6 +52,9 @@ typedef struct { ushort ext_addr; /* extended query table address */ ushort cfi_version; /* cfi version */ ushort cfi_offset; /* offset for cfi query */ + ulong unlock_addr1; /* unlock address 1 for AMD flash roms */ + ulong unlock_addr2; /* unlock address 2 for AMD flash roms */ + const char *name; /* human-readable name */ #endif } flash_info_t;
@@ -101,6 +104,12 @@ extern void flash_read_user_serial(flash_info_t * info, void * buffer, int offse extern void flash_read_factory_serial(flash_info_t * info, void * buffer, int offset, int len); #endif /* CFG_FLASH_PROTECTION */
+#ifdef CFG_FLASH_CFI_LEGACY +extern ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info); +extern int jedec_flash_match(flash_info_t *info, ulong base); +#define CFI_CMDSET_AMD_LEGACY 0xFFF0 +#endif + /*----------------------------------------------------------------------- * return codes from flash_write(): */
Hi Michael,
Thanks. Looks very promising. If nobody objects, I would like to add this into the official repo after 1.3.0 is released. Please find some more comments below.
A reference to a mail thread is not good in a commit description. Please try to add all necessary infos directly in this text.
cs8900.o ct69000.o dataflash.o dc2114x.o dm9000x.o \ ds1722.o e1000.o eepro100.o enc28j60.o \ fsl_i2c.o fsl_pci_init.o \bcm570x.o bcm570x_autoneg.o cfb_console.o cfi_flash.o jedec_flash.o \
- Call board code to request info about non-CFI flash.
- board_flash_get_legacy needs to fill in at least:
- info->portwidth, info->chipwidth and info->interface for Jedec probing.
- flash_info_t *info = &flash_info[banknum];
- if (board_flash_get_legacy(base, banknum, info)) {
int i;
} else {
break;
break;
break;
return 1;
- return 0; /* use CFI */
+} +#endif
if (flash_info[i].flash_id == FLASH_UNKNOWN) {size += flash_info[i].size;
break;
- printf ("%s FLASH (%d x %d)",
(info->portwidth << 3), (info->chipwidth << 3));info->name,
- if (info->size < 1024*1024)
- else
printf (" "); switch (info->vendor) { case CFI_CMDSET_INTEL_STANDARD:info->size >> 20, info->sector_count);
break;
- case CFI_CMDSET_AMD_LEGACY:
- flash_write_cmd (info, sect, info->unlock_addr1, AMD_CMD_UNLOCK_START);
- flash_write_cmd (info, sect, info->unlock_addr2, AMD_CMD_UNLOCK_ACK);
udelay(1000); /* some flash are slow to respond */ info->manufacturer_id = flash_read_uchar (info, FLASH_OFFSET_MANUFACTURER_ID);flash_write_cmd(info, 0, info->unlock_addr1, FLASH_CMD_READ_ID);
break;
break; }flash_write_cmd (info, 0, info->unlock_addr1, AMD_CMD_WRITE);
- (C) Copyright 2007
- Michael Schwingen, michael@schwingen.org
- based in great part on jedec_probe.c from linux kernel:
- (C) 2000 Red Hat. GPL'd.
- Occasionally maintained by Thayne Harbaugh tharbaugh at lnxi dot com
- project.
- MA 02111-1307 USA
- Unlock address sets for AMD command sets.
- Intel command sets use the MTD_UADDR_UNNECESSARY.
- Each identifier, except MTD_UADDR_UNNECESSARY, and
- MTD_UADDR_NO_SUPPORT must be defined below in unlock_addrs[].
- MTD_UADDR_NOT_SUPPORTED must be 0 so that structure
- initialization need not require initializing all of the
- unlock addresses for all bit widths.
+enum uaddr {
- MTD_UADDR_NOT_SUPPORTED = 0, /* data width not supported */
- MTD_UADDR_0x0555_0x02AA,
- MTD_UADDR_0x0555_0x0AAA,
- MTD_UADDR_0x5555_0x2AAA,
- MTD_UADDR_0x0AAA_0x0555,
- MTD_UADDR_DONT_CARE, /* Requires an arbitrary address */
- MTD_UADDR_UNNECESSARY, /* Does not require any address */
- u32 addr1;
- u32 addr2;
- I don't like the fact that the first entry in unlock_addrs[]
- exists, but is for MTD_UADDR_NOT_SUPPORTED - and, therefore,
- should not be used. The problem is that structures with
- initializers have extra fields initialized to 0. It is _very_
- desireable to have the unlock address entries for unsupported
- data widths automatically initialized - that means that
- MTD_UADDR_NOT_SUPPORTED must be 0 and the first entry here
- must go unused.
- [MTD_UADDR_NOT_SUPPORTED] = {
.addr1 = 0xffff,
.addr2 = 0xffff
- [MTD_UADDR_0x0555_0x02AA] = {
.addr1 = 0x0555,
.addr2 = 0x02aa
- [MTD_UADDR_0x0555_0x0AAA] = {
.addr1 = 0x0555,
.addr2 = 0x0aaa
- [MTD_UADDR_0x5555_0x2AAA] = {
.addr1 = 0x5555,
.addr2 = 0x2aaa
- [MTD_UADDR_0x0AAA_0x0555] = {
.addr1 = 0x0AAA,
.addr2 = 0x0555
- [MTD_UADDR_DONT_CARE] = {
- [MTD_UADDR_UNNECESSARY] = {
.addr1 = 0x0000,
.addr2 = 0x0000
- const __u16 mfr_id;
- const __u16 dev_id;
- const char *name;
- const int DevSize;
- const int NumEraseRegions;
- const int CmdSet;
- const __u8 uaddr[4]; /* unlock addrs for 8, 16, 32, 64 */
- const ulong regions[6];
.uaddr = {
.regions = {
.uaddr = {
.regions = {
.uaddr = {
.regions = {
+#endif +};
- int i,j;
- int sect_cnt;
- int size_ratio;
- int total_size;
- enum uaddr uaddr_idx;
- size_ratio = info->portwidth / info->chipwidth;
- debug("Found JEDEC Flash: %s\n", jedec_entry->name);
- info->vendor = jedec_entry->CmdSet;
- /* Todo: do we need device-specific timeouts? */
- info->erase_blk_tout = 30000;
- info->buffer_write_tout = 1000;
- info->write_tout = 100;
- info->name = jedec_entry->name;
How does the Linux driver handle this timeout? Is it device specific there?
- /* copy unlock addresses from device table to CFI info struct. This
get here. */
- switch(info->chipwidth) {
- case FLASH_CFI_8BIT:
break;
- case FLASH_CFI_16BIT:
break;
- case FLASH_CFI_32BIT:
break;
- default:
break;
- debug("unlock address index %d\n", uaddr_idx);
- info->unlock_addr1 = unlock_addrs[uaddr_idx].addr1;
- info->unlock_addr2 = unlock_addrs[uaddr_idx].addr2;
- debug("unlock addresses are 0x%x/0x%x\n", info->unlock_addr1,
- sect_cnt = 0;
- total_size = 0;
- for (i = 0; i < jedec_entry->NumEraseRegions; i++) {
break;
sect_cnt++;
- info->sector_count = sect_cnt;
- info->size = total_size * size_ratio;
- match jedec ids against table. If a match is found, fill flash_info
- int ret = 0;
- int i;
- ulong mask = 0xFFFF;
- if (info->chipwidth == 1)
mask = 0xFF;
- for (i = 0; i < ARRAY_SIZE(jedec_table); i++) {
Please remove the space between the two "(":
if ((jedec_table[i].mfr_id & mask) == (info->manufacturer_id & mask) &&
ret = 1;
break;
- return ret;
- ulong unlock_addr1; /* unlock address 1 for AMD flash roms */
- ulong unlock_addr2; /* unlock address 2 for AMD flash roms */
- const char *name; /* human-readable name */
- return codes from flash_write():
This SF.net email is sponsored by: Splunk Inc. Still grepping through log files to find problems? Stop. Now Search log events and configuration files using AJAX and a browser. Download your FREE copy of Splunk now >> http://get.splunk.com/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Thanks for all your effort.
Best regards, Stefan
OK. I will await further comments and then re-submit with documentation.
No. I do not completely understand all the Linux MTD/Flash code, but a quick glance did not show any timer-based timeout handling - it seems the code relies on the timeout bit from the flash (I looked at 2.6.21.6).
The Jedec code has no device-specific timeout values in the tables, so I used hardcoded values which seem "big enough". To make this perfect, we would really need device-specific values, but from my expecience, relying on the flash status register to signal timeouts is sufficient.
cu Michael
Hello Michael,
Your patch fixes an issue with AMD_ADDR_* definitions for CFI flashes, along with its primary intent (JEDEC support in CFI framework). I think it would be better to submit the fix to AMD_ADDR_* as a separate patch. It's more logical this way, also, it might get committed sooner, as it likely fixes a problem with an existing board. I am willing to test such a patch on one of the troublesome boards.
I've got few comments related to the fix part of your patch - please see below.
Regards, Bartlomiej
int i;
} else {
break;
break;
break;
return 1;
+} +#endif
break;
- else
break;
Perhaps it would be better to follow what is being done in the Linux driver, adjusted to U-Boot context. I.e., something along the lines of (untested):
info->unlock_addr1 = 0x555; info->unlock_adde2 = 0x2aa;
/* Modify the unlock address if we are in compatibility mode */ if ( /* x16 in x8 mode */ ((info->chipwidth == FLASH_CFI_BY8) && (info->interface == 2)) || /* x32 in x16 mode */ ((info->chipwidth == FLASH_CFI_BY16) && (info->interface == 4))) { info->unlock_addr1 = 0xaaa; info->unlock_addr2 = 0x555; }
break;
- project.
- MA 02111-1307 USA
+enum uaddr {
- u32 addr1;
- u32 addr2;
- must go unused.
.addr1 = 0xffff,
.addr2 = 0xffff
.addr1 = 0x0555,
.addr2 = 0x02aa
.addr1 = 0x0555,
.addr2 = 0x0aaa
.addr1 = 0x5555,
.addr2 = 0x2aaa
.addr1 = 0x0AAA,
.addr2 = 0x0555
.addr1 = 0x0000,
.addr2 = 0x0000
- const char *name;
- const int CmdSet;
.uaddr = {
.regions = {
.uaddr = {
.regions = {
.uaddr = {
.regions = {
+#endif +};
- int i,j;
- int sect_cnt;
- int size_ratio;
- int total_size;
get here. */
break;
break;
break;
- default:
break;
- debug("unlock addresses are 0x%x/0x%x\n", info->unlock_addr1, info->unlock_addr2);
- sect_cnt = 0;
- total_size = 0;
break;
sect_cnt++;
- match jedec ids against table. If a match is found, fill flash_info entry
- int ret = 0;
- int i;
mask = 0xFF;
ret = 1;
break;
- return ret;
Linux driver uses addr_unlock1 and addr_unlock2 for this purpose, maybe it's a good idea to keep the variable names in sync with Linux?
Um - no. I removed that when changing to the unlock_addr* variables in the flash_info_t struct, for just that reason - I wanted the patch to be applied soon, and I have no way to test the change on a large number of boards.
Unless I made some error in the conversion, the CFI code should behave exactly the same with and without my patch. Only the Jedec code uses different unlock_addr values.
Actually, there are two points where I think the current code is wrong, and which I did not change, because those are probably best handled in separate patches: - unlock_addr values when running on 8-bit CFI flashs (interface == 0) - the AMD erase code, where the unlock sequence is written to the sector base address instead of the chip base address.
I am not sure what the policy is regarding changes that might break existing boards? Are those patches applied if enough people are sure they should be safe?
Agreed. I had this in an earlier version of my patch, where I needed to modify the AMD_ADDR_* macros, but removed it later in order to make minimal changes to the existing CFI behaviour. I think this should be added on top of my patch, unless everyone on this list agrees that it should go in immediately.
Not sure - the CFI code does not look very similar to the Linux code, so I see no big benefit in doing so, but as it is just a name, I can live with both variants.
cu Michael
Hi Michael,
Me too. But we should definitely wait till after the 1.3.0 release, which is hopefully going to happen in the next few days (Stefan waves to Grant ;)). Then this patch should go in very quickly, at least from my point of view, since it will enable me to drop a lot of board specific flash drivers.
I do have some here. And I will test it on some platforms.
Kind of. The subsystem maintainer (custodian) decides if and when a patch gets applied. This is of course after official review on the mailing list. As it seems I am the custodian for the CFI driver right now (Tolunay didn't have time anymore), so if nobody objects and the tests work fine, your patch will get pulled into the CFI custodian repo pretty soon. In the next merge window. We are trying to follow here the Linux model.
I vote for an incremental patch here too.
Please change it to the Linux version.
Done - here is the complete patch again, plus description:
the following patch adds support for non-CFI flash ROMs, by hooking into the CFI flash code and using most of its code. Also, error handling is added to the CFI code in case CFG_MAX_FLASH_SECT is set too low.
The basic idea is that the board-specific code provides a function "flash_detect_legacy" that is called for every flash bank, which can either provide completely hardcoded flash information, or provide enough information about the bus->flash mapping that the new Jedec probing code can detect the flash. If the function returns 0, the normal CFI code is called.
The new code is activated by setting CFG_FLASH_CFI_LEGACY.
Sample board code for a 256k*8 boot flash, combined with a 16-bit CFI flash looks like this:
ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) { if (banknum == 0) { /* non-CFI boot flash */ info->portwidth = 1; info->chipwidth = 1; info->interface = FLASH_CFI_X8; return 1; } else return 0; }
cu Michael
diff --git a/drivers/cfi_flash.c b/drivers/cfi_flash.c index 5579a1e..5bec74a 100644 --- a/drivers/cfi_flash.c +++ b/drivers/cfi_flash.c @@ -98,10 +98,6 @@ #define AMD_STATUS_TOGGLE 0x40 #define AMD_STATUS_ERROR 0x20
+#ifdef CFG_FLASH_CFI_LEGACY +/*----------------------------------------------------------------------- + * Call board code to request info about non-CFI flash. + * board_flash_get_legacy needs to fill in at least: + * info->portwidth, info->chipwidth and info->interface for Jedec probing. + */ +int flash_detect_legacy(ulong base, int banknum) +{ + flash_info_t *info = &flash_info[banknum]; + if (board_flash_get_legacy(base, banknum, info)) { + /* board code may have filled info completely. If not, we + use JEDEC ID probing. */ + if (!info->vendor) { + int modes[] = { CFI_CMDSET_AMD_STANDARD, CFI_CMDSET_INTEL_STANDARD }; + int i; + + for(i=0; i<sizeof(modes)/sizeof(modes[0]); i++) { + info->vendor = modes[i]; + info->start[0] = base; + if (info->portwidth == FLASH_CFI_8BIT && info->interface == FLASH_CFI_X8X16) { + info->addr_unlock1 = 0x2AAA; + info->addr_unlock2 = 0x5555; + } else { + info->addr_unlock1 = 0x5555; + info->addr_unlock2 = 0x2AAA; + } + flash_read_jedec_ids(info); + debug("JEDEC PROBE: ID %x %x %x\n", info->manufacturer_id, info->device_id, info->device_id2); + if (jedec_flash_match(info, base)) + break; + } + } + switch(info->vendor) { + case CFI_CMDSET_INTEL_STANDARD: + case CFI_CMDSET_INTEL_EXTENDED: + info->cmd_reset = FLASH_CMD_RESET; + break; + case CFI_CMDSET_AMD_STANDARD: + case CFI_CMDSET_AMD_EXTENDED: + case CFI_CMDSET_AMD_LEGACY: + info->cmd_reset = AMD_CMD_RESET; + break; + } + info->flash_id = FLASH_MAN_CFI; + return 1; + } + return 0; /* use CFI */ +} +#else +int inline flash_detect_legacy(ulong base, int banknum) +{ + return 0; /* use CFI */ +} +#endif + + /*----------------------------------------------------------------------- */ unsigned long flash_init (void) @@ -345,7 +397,10 @@ unsigned long flash_init (void) /* Init: no FLASHes known */ for (i = 0; i < CFG_MAX_FLASH_BANKS; ++i) { flash_info[i].flash_id = FLASH_UNKNOWN; - size += flash_info[i].size = flash_get_size (bank_base[i], i); + + if (!flash_detect_legacy (bank_base[i], i)) + flash_get_size (bank_base[i], i); + size += flash_info[i].size; if (flash_info[i].flash_id == FLASH_UNKNOWN) { #ifndef CFG_FLASH_QUIET_TEST printf ("## Unknown FLASH on Bank %d - Size = 0x%08lx = %ld MB\n", @@ -483,11 +538,18 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) case CFI_CMDSET_AMD_STANDARD: case CFI_CMDSET_AMD_EXTENDED: flash_unlock_seq (info, sect); - flash_write_cmd (info, sect, AMD_ADDR_ERASE_START, - AMD_CMD_ERASE_START); + flash_write_cmd (info, sect, info->addr_unlock1, AMD_CMD_ERASE_START); flash_unlock_seq (info, sect); flash_write_cmd (info, sect, 0, AMD_CMD_ERASE_SECTOR); break; +#ifdef CFG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: + flash_unlock_seq (info, 0); + flash_write_cmd (info, 0, info->addr_unlock1, AMD_CMD_ERASE_START); + flash_unlock_seq (info, 0); + flash_write_cmd (info, sect, 0, AMD_CMD_ERASE_SECTOR); + break; +#endif default: debug ("Unkown flash vendor %d\n", info->vendor); @@ -516,10 +578,15 @@ void flash_print_info (flash_info_t * info) return; }
static void flash_unlock_seq (flash_info_t * info, flash_sect_t sect) { - flash_write_cmd (info, sect, AMD_ADDR_START, AMD_CMD_UNLOCK_START); - flash_write_cmd (info, sect, AMD_ADDR_ACK, AMD_CMD_UNLOCK_ACK); + flash_write_cmd (info, sect, info->addr_unlock1, AMD_CMD_UNLOCK_START); + flash_write_cmd (info, sect, info->addr_unlock2, AMD_CMD_UNLOCK_ACK); }
/*----------------------------------------------------------------------- @@ -1105,7 +1180,7 @@ static void flash_read_jedec_ids (flash_info_t * info) case CFI_CMDSET_AMD_EXTENDED: flash_write_cmd(info, 0, 0, AMD_CMD_RESET); flash_unlock_seq(info, 0); - flash_write_cmd(info, 0, AMD_ADDR_START, FLASH_CMD_READ_ID); + flash_write_cmd(info, 0, info->addr_unlock1, FLASH_CMD_READ_ID); udelay(1000); /* some flash are slow to respond */ info->manufacturer_id = flash_read_uchar (info, FLASH_OFFSET_MANUFACTURER_ID); @@ -1156,6 +1231,10 @@ static int flash_detect_cfi (flash_info_t * info) debug ("port %d bits chip %d bits\n", info->portwidth << CFI_FLASH_SHIFT_WIDTH, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); + /* this probably only works if info->interface == FLASH_CFI_X8X16 */ + info->addr_unlock1 = (info->portwidth == FLASH_CFI_8BIT) ? 0xAAA : 0x555; + info->addr_unlock2 = (info->portwidth == FLASH_CFI_8BIT) ? 0x555 : 0x2AA; + info->name = "CFI conformant"; return 1; } } @@ -1282,6 +1361,10 @@ ulong flash_get_size (ulong base, int banknum) debug ("erase_region_count = %d erase_region_size = %d\n", erase_region_count, erase_region_size); for (j = 0; j < erase_region_count; j++) { + if (sect_cnt >= CFG_MAX_FLASH_SECT) { + printf("ERROR: too many flash sectors\n"); + break; + } info->start[sect_cnt] = sector; sector += (erase_region_size * size_ratio);
@@ -1384,8 +1467,11 @@ static int flash_write_cfiword (flash_info_t * info, ulong dest, break; case CFI_CMDSET_AMD_EXTENDED: case CFI_CMDSET_AMD_STANDARD: +#ifdef CFG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: +#endif flash_unlock_seq (info, 0); - flash_write_cmd (info, 0, AMD_ADDR_START, AMD_CMD_WRITE); + flash_write_cmd (info, 0, info->addr_unlock1, AMD_CMD_WRITE); break; }
diff --git a/drivers/jedec_flash.c b/drivers/jedec_flash.c new file mode 100644 index 0000000..2d808c4 --- /dev/null +++ b/drivers/jedec_flash.c @@ -0,0 +1,315 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * based in great part on jedec_probe.c from linux kernel: + * (C) 2000 Red Hat. GPL'd. + * Occasionally maintained by Thayne Harbaugh tharbaugh at lnxi dot com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +/* The DEBUG define must be before common to enable debugging */ +/*#define DEBUG*/ + +#include <common.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <asm/byteorder.h> +#include <environment.h> + +#if defined CFG_FLASH_CFI_DRIVER && defined CFG_FLASH_CFI_LEGACY + +#define P_ID_AMD_STD CFI_CMDSET_AMD_LEGACY + +/* Manufacturers */ +#define MANUFACTURER_AMD 0x0001 +#define MANUFACTURER_SST 0x00BF + +/* AMD */ +#define AM29DL800BB 0x22C8 +#define AM29DL800BT 0x224A + +#define AM29F800BB 0x2258 +#define AM29F800BT 0x22D6 +#define AM29LV400BB 0x22BA +#define AM29LV400BT 0x22B9 +#define AM29LV800BB 0x225B +#define AM29LV800BT 0x22DA +#define AM29LV160DT 0x22C4 +#define AM29LV160DB 0x2249 +#define AM29F017D 0x003D +#define AM29F016D 0x00AD +#define AM29F080 0x00D5 +#define AM29F040 0x00A4 +#define AM29LV040B 0x004F +#define AM29F032B 0x0041 +#define AM29F002T 0x00B0 + +/* SST */ +#define SST39LF800 0x2781 +#define SST39LF160 0x2782 +#define SST39VF1601 0x234b +#define SST39LF512 0x00D4 +#define SST39LF010 0x00D5 +#define SST39LF020 0x00D6 +#define SST39LF040 0x00D7 +#define SST39SF010A 0x00B5 +#define SST39SF020A 0x00B6 + + +/* + * Unlock address sets for AMD command sets. + * Intel command sets use the MTD_UADDR_UNNECESSARY. + * Each identifier, except MTD_UADDR_UNNECESSARY, and + * MTD_UADDR_NO_SUPPORT must be defined below in unlock_addrs[]. + * MTD_UADDR_NOT_SUPPORTED must be 0 so that structure + * initialization need not require initializing all of the + * unlock addresses for all bit widths. + */ +enum uaddr { + MTD_UADDR_NOT_SUPPORTED = 0, /* data width not supported */ + MTD_UADDR_0x0555_0x02AA, + MTD_UADDR_0x0555_0x0AAA, + MTD_UADDR_0x5555_0x2AAA, + MTD_UADDR_0x0AAA_0x0555, + MTD_UADDR_DONT_CARE, /* Requires an arbitrary address */ + MTD_UADDR_UNNECESSARY, /* Does not require any address */ +}; + + +struct unlock_addr { + u32 addr1; + u32 addr2; +}; + + +/* + * I don't like the fact that the first entry in unlock_addrs[] + * exists, but is for MTD_UADDR_NOT_SUPPORTED - and, therefore, + * should not be used. The problem is that structures with + * initializers have extra fields initialized to 0. It is _very_ + * desireable to have the unlock address entries for unsupported + * data widths automatically initialized - that means that + * MTD_UADDR_NOT_SUPPORTED must be 0 and the first entry here + * must go unused. + */ +static const struct unlock_addr unlock_addrs[] = { + [MTD_UADDR_NOT_SUPPORTED] = { + .addr1 = 0xffff, + .addr2 = 0xffff + }, + + [MTD_UADDR_0x0555_0x02AA] = { + .addr1 = 0x0555, + .addr2 = 0x02aa + }, + + [MTD_UADDR_0x0555_0x0AAA] = { + .addr1 = 0x0555, + .addr2 = 0x0aaa + }, + + [MTD_UADDR_0x5555_0x2AAA] = { + .addr1 = 0x5555, + .addr2 = 0x2aaa + }, + + [MTD_UADDR_0x0AAA_0x0555] = { + .addr1 = 0x0AAA, + .addr2 = 0x0555 + }, + + [MTD_UADDR_DONT_CARE] = { + .addr1 = 0x0000, /* Doesn't matter which address */ + .addr2 = 0x0000 /* is used - must be last entry */ + }, + + [MTD_UADDR_UNNECESSARY] = { + .addr1 = 0x0000, + .addr2 = 0x0000 + } +}; + + +struct amd_flash_info { + const __u16 mfr_id; + const __u16 dev_id; + const char *name; + const int DevSize; + const int NumEraseRegions; + const int CmdSet; + const __u8 uaddr[4]; /* unlock addrs for 8, 16, 32, 64 */ + const ulong regions[6]; +}; + +#define ERASEINFO(size,blocks) (size<<8)|(blocks-1) + +#define SIZE_64KiB 16 +#define SIZE_128KiB 17 +#define SIZE_256KiB 18 +#define SIZE_512KiB 19 +#define SIZE_1MiB 20 +#define SIZE_2MiB 21 +#define SIZE_4MiB 22 +#define SIZE_8MiB 23 + +static const struct amd_flash_info jedec_table[] = { +#ifdef CFG_FLASH_LEGACY_256Kx8 + { + .mfr_id = MANUFACTURER_SST, + .dev_id = SST39LF020, + .name = "SST 39LF020", + .uaddr = { + [0] = MTD_UADDR_0x5555_0x2AAA /* x8 */ + }, + .DevSize = SIZE_256KiB, + .CmdSet = P_ID_AMD_STD, + .NumEraseRegions= 1, + .regions = { + ERASEINFO(0x01000,64), + } + }, +#endif +#ifdef CFG_FLASH_LEGACY_512Kx8 + { + .mfr_id = MANUFACTURER_AMD, + .dev_id = AM29LV040B, + .name = "AMD AM29LV040B", + .uaddr = { + [0] = MTD_UADDR_0x0555_0x02AA /* x8 */ + }, + .DevSize = SIZE_512KiB, + .CmdSet = P_ID_AMD_STD, + .NumEraseRegions= 1, + .regions = { + ERASEINFO(0x10000,8), + } + }, + { + .mfr_id = MANUFACTURER_SST, + .dev_id = SST39LF040, + .name = "SST 39LF040", + .uaddr = { + [0] = MTD_UADDR_0x5555_0x2AAA /* x8 */ + }, + .DevSize = SIZE_512KiB, + .CmdSet = P_ID_AMD_STD, + .NumEraseRegions= 1, + .regions = { + ERASEINFO(0x01000,128), + } + }, +#endif +}; + + +#define ARRAY_SIZE(x) (sizeof(x) / sizeof((x)[0])) + + +static inline void fill_info(flash_info_t *info, const struct amd_flash_info *jedec_entry, ulong base) +{ + int i,j; + int sect_cnt; + int size_ratio; + int total_size; + enum uaddr uaddr_idx; + + size_ratio = info->portwidth / info->chipwidth; + + debug("Found JEDEC Flash: %s\n", jedec_entry->name); + info->vendor = jedec_entry->CmdSet; + /* Todo: do we need device-specific timeouts? */ + info->erase_blk_tout = 30000; + info->buffer_write_tout = 1000; + info->write_tout = 100; + info->name = jedec_entry->name; + + /* copy unlock addresses from device table to CFI info struct. This + is just here because the addresses are in the table anyway - if + the flash is not detected due to wrong unlock addresses, + flash_detect_legacy would have to try all of them before we even + get here. */ + switch(info->chipwidth) { + case FLASH_CFI_8BIT: + uaddr_idx = jedec_entry->uaddr[0]; + break; + case FLASH_CFI_16BIT: + uaddr_idx = jedec_entry->uaddr[1]; + break; + case FLASH_CFI_32BIT: + uaddr_idx = jedec_entry->uaddr[2]; + break; + default: + uaddr_idx = MTD_UADDR_NOT_SUPPORTED; + break; + } + + debug("unlock address index %d\n", uaddr_idx); + info->addr_unlock1 = unlock_addrs[uaddr_idx].addr1; + info->addr_unlock2 = unlock_addrs[uaddr_idx].addr2; + debug("unlock addresses are 0x%x/0x%x\n", info->addr_unlock1, info->addr_unlock2); + + sect_cnt = 0; + total_size = 0; + for (i = 0; i < jedec_entry->NumEraseRegions; i++) { + ulong erase_region_size = jedec_entry->regions[i] >> 8; + ulong erase_region_count = (jedec_entry->regions[i] & 0xff) + 1; + + total_size += erase_region_size * erase_region_count; + debug ("erase_region_count = %d erase_region_size = %d\n", + erase_region_count, erase_region_size); + for (j = 0; j < erase_region_count; j++) { + if (sect_cnt >= CFG_MAX_FLASH_SECT) { + printf("ERROR: too many flash sectors\n"); + break; + } + info->start[sect_cnt] = base; + base += (erase_region_size * size_ratio); + sect_cnt++; + } + } + info->sector_count = sect_cnt; + info->size = total_size * size_ratio; +} + +/*----------------------------------------------------------------------- + * match jedec ids against table. If a match is found, fill flash_info entry + */ +int jedec_flash_match(flash_info_t *info, ulong base) +{ + int ret = 0; + int i; + ulong mask = 0xFFFF; + if (info->chipwidth == 1) + mask = 0xFF; + + for (i = 0; i < ARRAY_SIZE(jedec_table); i++) { + if ((jedec_table[i].mfr_id & mask) == (info->manufacturer_id & mask) && + (jedec_table[i].dev_id & mask) == (info->device_id & mask)) { + fill_info(info, &jedec_table[i], base); + ret = 1; + break; + } + } + return ret; +} + +#endif /* defined CFG_FLASH_CFI_DRIVER && defined CFG_FLASH_CFI_LEGACY */
Sorry, I missed the diff for flash.h:
cu Michael
diff --git a/include/flash.h b/include/flash.h index b0bf733..cd075f9 100644 --- a/include/flash.h +++ b/include/flash.h @@ -52,6 +52,9 @@ typedef struct { ushort ext_addr; /* extended query table address */ ushort cfi_version; /* cfi version */ ushort cfi_offset; /* offset for cfi query */ + ulong addr_unlock1; /* unlock address 1 for AMD flash roms */ + ulong addr_unlock2; /* unlock address 2 for AMD flash roms */ + const char *name; /* human-readable name */ #endif } flash_info_t;
I think you also missed diff for drivers/Makefile, which was present in the original submission.
Regards, Bartlomiej
Oops - yes. It seems my working tree is in a strange state after updating from upstream - I am afraid I will have to re-do the patches in a fresh checked-out tree.
cu Michael
Well, drivers/Makefile is no more. I was just blindly comparing your patches sent to the list and forgot that U-Boot has undergone changes in the drivers' department. For example the CFI driver now lives in drivers/mtd/cfi_flash.c -- you'll have to re-spin your patch accordingly.
BTW: your patch is on a critical path for some changes I have in my queue -- do you think you would be able to sent your updated patch quite soon?
Thanks in advance.
Regards, Bartlomiej
Hi Michael,
Michael, could you please redo your patches very soon? I just updated the cfi-flash custodian repository. Best would be today. :)
Then I will pull them right away into the CFI repository. And if not, please let me know when you could find the time to do so.
Thanks.
Okay, I got it working - it seems I need to learn a bit more about git, so this is just a normal diff between a current tree vs. a patched one.
I renamed CFG_FLASH_CFI_LEGACY to CONFIG_FLASH_CFI_LEGACY so that it is picked up by autoconf.mk.
BTW: what is the best method to get other patches in? I have 4 general IXP42x patches which I sent to the list on 2007-11-10 and which got no comments, plus patches to add support for 4 boards that go on top of these (one of which needs the flash patch below).
cu Michael
diff --ignore-space -urN u-boot/drivers/mtd/Makefile u-boot-ms/drivers/mtd/Makefile --- u-boot/drivers/mtd/Makefile 2007-12-07 22:48:37.000000000 +0100 +++ u-boot-ms/drivers/mtd/Makefile 2007-12-07 21:17:02.000000000 +0100 @@ -29,6 +29,7 @@ COBJS-y += cfi_flash.o COBJS-y += dataflash.o COBJS-y += mw_eeprom.o +COBJS-$(CONFIG_FLASH_CFI_LEGACY) += jedec_flash.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --ignore-space -urN u-boot/drivers/mtd/cfi_flash.c u-boot-ms/drivers/mtd/cfi_flash.c --- u-boot/drivers/mtd/cfi_flash.c 2007-12-07 22:48:37.000000000 +0100 +++ u-boot-ms/drivers/mtd/cfi_flash.c 2007-12-07 22:37:10.000000000 +0100 @@ -98,10 +99,6 @@ #define AMD_STATUS_TOGGLE 0x40 #define AMD_STATUS_ERROR 0x20
-#define AMD_ADDR_ERASE_START ((info->portwidth == FLASH_CFI_8BIT) ? 0xAAA : 0x555) -#define AMD_ADDR_START ((info->portwidth == FLASH_CFI_8BIT) ? 0xAAA : 0x555) -#define AMD_ADDR_ACK ((info->portwidth == FLASH_CFI_8BIT) ? 0x555 : 0x2AA) - #define FLASH_OFFSET_MANUFACTURER_ID 0x00 #define FLASH_OFFSET_DEVICE_ID 0x01 #define FLASH_OFFSET_DEVICE_ID2 0x0E @@ -331,6 +328,62 @@ }
+#ifdef CONFIG_FLASH_CFI_LEGACY +/*----------------------------------------------------------------------- + * Call board code to request info about non-CFI flash. + * board_flash_get_legacy needs to fill in at least: + * info->portwidth, info->chipwidth and info->interface for Jedec probing. + */ +int flash_detect_legacy(ulong base, int banknum) +{ + flash_info_t *info = &flash_info[banknum]; + if (board_flash_get_legacy(base, banknum, info)) { + /* board code may have filled info completely. If not, we + use JEDEC ID probing. */ + if (!info->vendor) { + int modes[] = { CFI_CMDSET_AMD_STANDARD, CFI_CMDSET_INTEL_STANDARD }; + int i; + + for(i=0; i<sizeof(modes)/sizeof(modes[0]); i++) { + info->vendor = modes[i]; + info->start[0] = base; + if (info->portwidth == FLASH_CFI_8BIT && info->interface == FLASH_CFI_X8X16) { + info->addr_unlock1 = 0x2AAA; + info->addr_unlock2 = 0x5555; + } else { + info->addr_unlock1 = 0x5555; + info->addr_unlock2 = 0x2AAA; + } + flash_read_jedec_ids(info); + debug("JEDEC PROBE: ID %x %x %x\n", info->manufacturer_id, info->device_id, info->device_id2); + if (jedec_flash_match(info, base)) + break; + } + } + switch(info->vendor) { + case CFI_CMDSET_INTEL_STANDARD: + case CFI_CMDSET_INTEL_EXTENDED: + info->cmd_reset = FLASH_CMD_RESET; + break; + case CFI_CMDSET_AMD_STANDARD: + case CFI_CMDSET_AMD_EXTENDED: + case CFI_CMDSET_AMD_LEGACY: + info->cmd_reset = AMD_CMD_RESET; + break; + } + info->flash_id = FLASH_MAN_CFI; + return 1; + } + return 0; /* use CFI */ +} +#else +int inline flash_detect_legacy(ulong base, int banknum) +{ + return 0; /* use CFI */ +} +#endif + + /*----------------------------------------------------------------------- */ unsigned long flash_init (void) @@ -345,7 +398,10 @@ /* Init: no FLASHes known */ for (i = 0; i < CFG_MAX_FLASH_BANKS; ++i) { flash_info[i].flash_id = FLASH_UNKNOWN; - size += flash_info[i].size = flash_get_size (bank_base[i], i); + + if (!flash_detect_legacy (bank_base[i], i)) + flash_get_size (bank_base[i], i); + size += flash_info[i].size; if (flash_info[i].flash_id == FLASH_UNKNOWN) { #ifndef CFG_FLASH_QUIET_TEST printf ("## Unknown FLASH on Bank %d - Size = 0x%08lx = %ld MB\n", @@ -483,11 +539,18 @@ case CFI_CMDSET_AMD_STANDARD: case CFI_CMDSET_AMD_EXTENDED: flash_unlock_seq (info, sect); - flash_write_cmd (info, sect, AMD_ADDR_ERASE_START, - AMD_CMD_ERASE_START); + flash_write_cmd (info, sect, info->addr_unlock1, AMD_CMD_ERASE_START); flash_unlock_seq (info, sect); flash_write_cmd (info, sect, 0, AMD_CMD_ERASE_SECTOR); break; +#ifdef CONFIG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: + flash_unlock_seq (info, 0); + flash_write_cmd (info, 0, info->addr_unlock1, AMD_CMD_ERASE_START); + flash_unlock_seq (info, 0); + flash_write_cmd (info, sect, 0, AMD_CMD_ERASE_SECTOR); + break; +#endif default: debug ("Unkown flash vendor %d\n", info->vendor); @@ -516,8 +579,13 @@ return; }
- printf ("CFI conformant FLASH (%d x %d)", + printf ("%s FLASH (%d x %d)", + info->name, (info->portwidth << 3), (info->chipwidth << 3)); + if (info->size < 1024*1024) + printf (" Size: %ld kB in %d Sectors\n", + info->size >> 10, info->sector_count); + else printf (" Size: %ld MB in %d Sectors\n", info->size >> 20, info->sector_count); printf (" "); @@ -534,6 +602,11 @@ case CFI_CMDSET_AMD_EXTENDED: printf ("AMD Extended"); break; +#ifdef CONFIG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: + printf ("AMD Legacy"); + break; +#endif default: printf ("Unknown (%d)", info->vendor); break; @@ -777,6 +850,9 @@ break; case CFI_CMDSET_AMD_STANDARD: case CFI_CMDSET_AMD_EXTENDED: +#ifdef CONFIG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: +#endif retval = flash_toggle (info, sect, 0, AMD_STATUS_TOGGLE); break; default: @@ -967,8 +1043,8 @@
/*----------------------------------------------------------------------- @@ -1105,7 +1181,7 @@ case CFI_CMDSET_AMD_EXTENDED: flash_write_cmd(info, 0, 0, AMD_CMD_RESET); flash_unlock_seq(info, 0); - flash_write_cmd(info, 0, AMD_ADDR_START, FLASH_CMD_READ_ID); + flash_write_cmd(info, 0, info->addr_unlock1, FLASH_CMD_READ_ID); udelay(1000); /* some flash are slow to respond */ info->manufacturer_id = flash_read_uchar (info, FLASH_OFFSET_MANUFACTURER_ID); @@ -1156,6 +1232,10 @@ debug ("port %d bits chip %d bits\n", info->portwidth << CFI_FLASH_SHIFT_WIDTH, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); + /* this probably only works if info->interface == FLASH_CFI_X8X16 */ + info->addr_unlock1 = (info->portwidth == FLASH_CFI_8BIT) ? 0xAAA : 0x555; + info->addr_unlock2 = (info->portwidth == FLASH_CFI_8BIT) ? 0x555 : 0x2AA; + info->name = "CFI conformant"; return 1; } } @@ -1282,6 +1362,10 @@ debug ("erase_region_count = %d erase_region_size = %d\n", erase_region_count, erase_region_size); for (j = 0; j < erase_region_count; j++) { + if (sect_cnt >= CFG_MAX_FLASH_SECT) { + printf("ERROR: too many flash sectors\n"); + break; + } info->start[sect_cnt] = sector; sector += (erase_region_size * size_ratio);
@@ -1384,8 +1468,11 @@ break; case CFI_CMDSET_AMD_EXTENDED: case CFI_CMDSET_AMD_STANDARD: +#ifdef CONFIG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: +#endif flash_unlock_seq (info, 0); - flash_write_cmd (info, 0, AMD_ADDR_START, AMD_CMD_WRITE); + flash_write_cmd (info, 0, info->addr_unlock1, AMD_CMD_WRITE); break; }
diff --ignore-space -urN u-boot/drivers/mtd/jedec_flash.c u-boot-ms/drivers/mtd/jedec_flash.c --- u-boot/drivers/mtd/jedec_flash.c 1970-01-01 01:00:00.000000000 +0100 +++ u-boot-ms/drivers/mtd/jedec_flash.c 2007-12-07 22:40:04.000000000 +0100 @@ -0,0 +1,312 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * based in great part on jedec_probe.c from linux kernel: + * (C) 2000 Red Hat. GPL'd. + * Occasionally maintained by Thayne Harbaugh tharbaugh at lnxi dot com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +/* The DEBUG define must be before common to enable debugging */ +/*#define DEBUG*/ + +#include <common.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <asm/byteorder.h> +#include <environment.h> + +#define P_ID_AMD_STD CFI_CMDSET_AMD_LEGACY + +/* Manufacturers */ +#define MANUFACTURER_AMD 0x0001 +#define MANUFACTURER_SST 0x00BF + +/* AMD */ +#define AM29DL800BB 0x22C8 +#define AM29DL800BT 0x224A + +#define AM29F800BB 0x2258 +#define AM29F800BT 0x22D6 +#define AM29LV400BB 0x22BA +#define AM29LV400BT 0x22B9 +#define AM29LV800BB 0x225B +#define AM29LV800BT 0x22DA +#define AM29LV160DT 0x22C4 +#define AM29LV160DB 0x2249 +#define AM29F017D 0x003D +#define AM29F016D 0x00AD +#define AM29F080 0x00D5 +#define AM29F040 0x00A4 +#define AM29LV040B 0x004F +#define AM29F032B 0x0041 +#define AM29F002T 0x00B0 + +/* SST */ +#define SST39LF800 0x2781 +#define SST39LF160 0x2782 +#define SST39VF1601 0x234b +#define SST39LF512 0x00D4 +#define SST39LF010 0x00D5 +#define SST39LF020 0x00D6 +#define SST39LF040 0x00D7 +#define SST39SF010A 0x00B5 +#define SST39SF020A 0x00B6 + + +/* + * Unlock address sets for AMD command sets. + * Intel command sets use the MTD_UADDR_UNNECESSARY. + * Each identifier, except MTD_UADDR_UNNECESSARY, and + * MTD_UADDR_NO_SUPPORT must be defined below in unlock_addrs[]. + * MTD_UADDR_NOT_SUPPORTED must be 0 so that structure + * initialization need not require initializing all of the + * unlock addresses for all bit widths. + */ +enum uaddr { + MTD_UADDR_NOT_SUPPORTED = 0, /* data width not supported */ + MTD_UADDR_0x0555_0x02AA, + MTD_UADDR_0x0555_0x0AAA, + MTD_UADDR_0x5555_0x2AAA, + MTD_UADDR_0x0AAA_0x0555, + MTD_UADDR_DONT_CARE, /* Requires an arbitrary address */ + MTD_UADDR_UNNECESSARY, /* Does not require any address */ +}; + + +struct unlock_addr { + u32 addr1; + u32 addr2; +}; + + +/* + * I don't like the fact that the first entry in unlock_addrs[] + * exists, but is for MTD_UADDR_NOT_SUPPORTED - and, therefore, + * should not be used. The problem is that structures with + * initializers have extra fields initialized to 0. It is _very_ + * desireable to have the unlock address entries for unsupported + * data widths automatically initialized - that means that + * MTD_UADDR_NOT_SUPPORTED must be 0 and the first entry here + * must go unused. + */ +static const struct unlock_addr unlock_addrs[] = { + [MTD_UADDR_NOT_SUPPORTED] = { + .addr1 = 0xffff, + .addr2 = 0xffff + }, + + [MTD_UADDR_0x0555_0x02AA] = { + .addr1 = 0x0555, + .addr2 = 0x02aa + }, + + [MTD_UADDR_0x0555_0x0AAA] = { + .addr1 = 0x0555, + .addr2 = 0x0aaa + }, + + [MTD_UADDR_0x5555_0x2AAA] = { + .addr1 = 0x5555, + .addr2 = 0x2aaa + }, + + [MTD_UADDR_0x0AAA_0x0555] = { + .addr1 = 0x0AAA, + .addr2 = 0x0555 + }, + + [MTD_UADDR_DONT_CARE] = { + .addr1 = 0x0000, /* Doesn't matter which address */ + .addr2 = 0x0000 /* is used - must be last entry */ + }, + + [MTD_UADDR_UNNECESSARY] = { + .addr1 = 0x0000, + .addr2 = 0x0000 + } +}; + + +struct amd_flash_info { + const __u16 mfr_id; + const __u16 dev_id; + const char *name; + const int DevSize; + const int NumEraseRegions; + const int CmdSet; + const __u8 uaddr[4]; /* unlock addrs for 8, 16, 32, 64 */ + const ulong regions[6]; +}; + +#define ERASEINFO(size,blocks) (size<<8)|(blocks-1) + +#define SIZE_64KiB 16 +#define SIZE_128KiB 17 +#define SIZE_256KiB 18 +#define SIZE_512KiB 19 +#define SIZE_1MiB 20 +#define SIZE_2MiB 21 +#define SIZE_4MiB 22 +#define SIZE_8MiB 23 + +static const struct amd_flash_info jedec_table[] = { +#ifdef CFG_FLASH_LEGACY_256Kx8 + { + .mfr_id = MANUFACTURER_SST, + .dev_id = SST39LF020, + .name = "SST 39LF020", + .uaddr = { + [0] = MTD_UADDR_0x5555_0x2AAA /* x8 */ + }, + .DevSize = SIZE_256KiB, + .CmdSet = P_ID_AMD_STD, + .NumEraseRegions= 1, + .regions = { + ERASEINFO(0x01000,64), + } + }, +#endif +#ifdef CFG_FLASH_LEGACY_512Kx8 + { + .mfr_id = MANUFACTURER_AMD, + .dev_id = AM29LV040B, + .name = "AMD AM29LV040B", + .uaddr = { + [0] = MTD_UADDR_0x0555_0x02AA /* x8 */ + }, + .DevSize = SIZE_512KiB, + .CmdSet = P_ID_AMD_STD, + .NumEraseRegions= 1, + .regions = { + ERASEINFO(0x10000,8), + } + }, + { + .mfr_id = MANUFACTURER_SST, + .dev_id = SST39LF040, + .name = "SST 39LF040", + .uaddr = { + [0] = MTD_UADDR_0x5555_0x2AAA /* x8 */ + }, + .DevSize = SIZE_512KiB, + .CmdSet = P_ID_AMD_STD, + .NumEraseRegions= 1, + .regions = { + ERASEINFO(0x01000,128), + } + }, +#endif +}; + + +#define ARRAY_SIZE(x) (sizeof(x) / sizeof((x)[0])) + + +static inline void fill_info(flash_info_t *info, const struct amd_flash_info *jedec_entry, ulong base) +{ + int i,j; + int sect_cnt; + int size_ratio; + int total_size; + enum uaddr uaddr_idx; + + size_ratio = info->portwidth / info->chipwidth; + + debug("Found JEDEC Flash: %s\n", jedec_entry->name); + info->vendor = jedec_entry->CmdSet; + /* Todo: do we need device-specific timeouts? */ + info->erase_blk_tout = 30000; + info->buffer_write_tout = 1000; + info->write_tout = 100; + info->name = jedec_entry->name; + + /* copy unlock addresses from device table to CFI info struct. This + is just here because the addresses are in the table anyway - if + the flash is not detected due to wrong unlock addresses, + flash_detect_legacy would have to try all of them before we even + get here. */ + switch(info->chipwidth) { + case FLASH_CFI_8BIT: + uaddr_idx = jedec_entry->uaddr[0]; + break; + case FLASH_CFI_16BIT: + uaddr_idx = jedec_entry->uaddr[1]; + break; + case FLASH_CFI_32BIT: + uaddr_idx = jedec_entry->uaddr[2]; + break; + default: + uaddr_idx = MTD_UADDR_NOT_SUPPORTED; + break; + } + + debug("unlock address index %d\n", uaddr_idx); + info->addr_unlock1 = unlock_addrs[uaddr_idx].addr1; + info->addr_unlock2 = unlock_addrs[uaddr_idx].addr2; + debug("unlock addresses are 0x%x/0x%x\n", info->addr_unlock1, info->addr_unlock2); + + sect_cnt = 0; + total_size = 0; + for (i = 0; i < jedec_entry->NumEraseRegions; i++) { + ulong erase_region_size = jedec_entry->regions[i] >> 8; + ulong erase_region_count = (jedec_entry->regions[i] & 0xff) + 1; + + total_size += erase_region_size * erase_region_count; + debug ("erase_region_count = %d erase_region_size = %d\n", + erase_region_count, erase_region_size); + for (j = 0; j < erase_region_count; j++) { + if (sect_cnt >= CFG_MAX_FLASH_SECT) { + printf("ERROR: too many flash sectors\n"); + break; + } + info->start[sect_cnt] = base; + base += (erase_region_size * size_ratio); + sect_cnt++; + } + } + info->sector_count = sect_cnt; + info->size = total_size * size_ratio; +} + +/*----------------------------------------------------------------------- + * match jedec ids against table. If a match is found, fill flash_info entry + */ +int jedec_flash_match(flash_info_t *info, ulong base) +{ + int ret = 0; + int i; + ulong mask = 0xFFFF; + if (info->chipwidth == 1) + mask = 0xFF; + + for (i = 0; i < ARRAY_SIZE(jedec_table); i++) { + if ((jedec_table[i].mfr_id & mask) == (info->manufacturer_id & mask) && + (jedec_table[i].dev_id & mask) == (info->device_id & mask)) { + fill_info(info, &jedec_table[i], base); + ret = 1; + break; + } + } + return ret; +} + diff --ignore-space -urN u-boot/include/flash.h u-boot-ms/include/flash.h --- u-boot/include/flash.h 2007-12-07 22:48:39.000000000 +0100 +++ u-boot-ms/include/flash.h 2007-12-07 21:56:21.000000000 +0100 @@ -52,6 +52,9 @@ ushort ext_addr; /* extended query table address */ ushort cfi_version; /* cfi version */ ushort cfi_offset; /* offset for cfi query */ + ulong addr_unlock1; /* unlock address 1 for AMD flash roms */ + ulong addr_unlock2; /* unlock address 2 for AMD flash roms */ + const char *name; /* human-readable name */ #endif } flash_info_t;
@@ -101,6 +104,13 @@ extern void flash_read_factory_serial(flash_info_t * info, void * buffer, int offset, int len); #endif /* CFG_FLASH_PROTECTION */
+#ifdef CONFIG_FLASH_CFI_LEGACY +extern ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info); +extern int jedec_flash_match(flash_info_t *info, ulong base); +#define CFI_CMDSET_AMD_LEGACY 0xFFF0 +#endif + + /*----------------------------------------------------------------------- * return codes from flash_write(): */
Yes, git knowledge really helps upon U-Boot & Linux development.
OK, thanks.
Applied to u-boot-cfi-flash custodian repository. Thanks again for the quick responce.
If you get no response, then you should ask on the list (CC to custodian) from time to time about the status. Please note that the IXP custodian changed just a short while ago. I'm pretty sure that Jean-Christophe will handle this much better than I did (lack of time and hardware).
participants (5)
Bartlomiej Sieka
Michael Schwingen
Michael Schwingen
rincewind@discworld.dascon.de
Stefan Roese
