[PATCH] lib: sparse: Fix error checking for write_sparse_chunk_raw
The return value of write_sparse_chunk_raw is unsigned, so the existing check has no effect. Use IS_ERR_VALUE to detect error instead, which is what write_sparse_chunk_raw does itself.
Fixes: 62649165cb0 ("lib: sparse: Make CHUNK_TYPE_RAW buffer aligned") Reported-by: Dan Carpenter dan.carpenter@linaro.org Link: https://lore.kernel.org/u-boot/1b323ec3-59b0-490b-a2f0-fd961dafcf49@moroto.m... Signed-off-by: Sean Anderson sean.anderson@seco.com ---
lib/image-sparse.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/image-sparse.c b/lib/image-sparse.c index f8289064692..09225692e9b 100644 --- a/lib/image-sparse.c +++ b/lib/image-sparse.c @@ -211,7 +211,7 @@ int write_sparse_image(struct sparse_storage *info,
blks = write_sparse_chunk_raw(info, blk, blkcnt, data, response); - if (blks < 0) + if (IS_ERR_VALUE(blks)) return -1;
blk += blks;
if (blks < 0)
if (IS_ERR_VALUE(blks)) return -1; blk += blks;
-- 2.35.1.1320.gc452695387.dirty
Reviewed-by: Michael Trimarchi michael@amarulasolutions.com
Michael
-- Michael Nazzareno Trimarchi Co-Founder & Chief Executive Officer M. +39 347 913 2170 michael@amarulasolutions.com __________________________________
Amarula Solutions BV Joop Geesinkweg 125, 1114 AB, Amsterdam, NL T. +31 (0)85 111 9172 info@amarulasolutions.com www.amarulasolutions.com
Hi Sean,
Thank you for the patch.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
if (blks < 0)
Thanks, Applied to https://source.denx.de/u-boot/custodians/u-boot-dfu (u-boot-dfu)
[1/1] lib: sparse: Fix error checking for write_sparse_chunk_raw https://source.denx.de/u-boot/custodians/u-boot-dfu/-/commit/09709a57d8b11fa...
-- Mattijs
Mattijs Korpershoek
Sean Anderson
