[U-Boot] [PATCH v2 2/9] ColdFire: Modules header files cleanup
Consolidate ATA, ePORT, QSPI, FlexCan, PWM, RNG, MDHA, SKHA, INTC, and FlexBus structures and definitions in immap_5xxx.h to more unify modules header files. Append DSPI support for m547x_8x. SSI cleanup. Remove USB Host structure from immap_539.h. Apply changes to use FlexBus structures in mcf52x2's cpu_init.c and platform configuration files.
Signed-off-by: TsiChung Liew Tsi-Chung.Liew@freescale.com --- cpu/mcf52x2/cpu_init.c | 271 ++++++++------------------- include/asm-m68k/coldfire/ata.h | 79 ++++++++ include/asm-m68k/coldfire/dspi.h | 15 +- include/asm-m68k/coldfire/eport.h | 139 ++++++++++++++ include/asm-m68k/coldfire/flexbus.h | 96 ++++++---- include/asm-m68k/coldfire/flexcan.h | 219 ++++++++++++++++++++++ include/asm-m68k/coldfire/intctrl.h | 246 +++++++++++++++++++++++++ include/asm-m68k/coldfire/mdha.h | 102 ++++++++++ include/asm-m68k/coldfire/pwm.h | 115 ++++++++++++ include/asm-m68k/coldfire/qspi.h | 111 +++++++++++ include/asm-m68k/coldfire/rng.h | 52 ++++++ include/asm-m68k/coldfire/skha.h | 121 ++++++++++++ include/asm-m68k/coldfire/ssi.h | 66 +++---- include/asm-m68k/immap_5227x.h | 109 +---------- include/asm-m68k/immap_5235.h | 166 ++---------------- include/asm-m68k/immap_5249.h | 4 + include/asm-m68k/immap_5253.h | 65 +------ include/asm-m68k/immap_5271.h | 39 +--- include/asm-m68k/immap_5272.h | 34 +---- include/asm-m68k/immap_5275.h | 120 +----------- include/asm-m68k/immap_5282.h | 91 +-------- include/asm-m68k/immap_5329.h | 284 +--------------------------- include/asm-m68k/immap_5445x.h | 160 +---------------- include/asm-m68k/immap_547x_8x.h | 40 +--- include/asm-m68k/m5227x.h | 233 +----------------------- include/asm-m68k/m5235.h | 303 ------------------------------ include/asm-m68k/m5249.h | 13 -- include/asm-m68k/m5271.h | 38 +---- include/asm-m68k/m5275.h | 46 ----- include/asm-m68k/m5282.h | 23 --- include/asm-m68k/m5329.h | 347 ----------------------------------- include/asm-m68k/m5445x.h | 337 ---------------------------------- include/asm-m68k/m547x_8x.h | 68 ------- include/configs/EB+MCF-EV123.h | 16 +- include/configs/M5235EVB.h | 10 +- include/configs/M5249EVB.h | 14 +- include/configs/M5253DEMO.h | 24 +-- include/configs/M5253EVBE.h | 20 +-- include/configs/M5275EVB.h | 14 +- include/configs/M5282EVB.h | 18 +-- include/configs/TASREG.h | 14 +- 41 files changed, 1498 insertions(+), 2784 deletions(-) create mode 100644 include/asm-m68k/coldfire/ata.h create mode 100644 include/asm-m68k/coldfire/eport.h create mode 100644 include/asm-m68k/coldfire/flexcan.h create mode 100644 include/asm-m68k/coldfire/intctrl.h create mode 100644 include/asm-m68k/coldfire/mdha.h create mode 100644 include/asm-m68k/coldfire/pwm.h create mode 100644 include/asm-m68k/coldfire/qspi.h create mode 100644 include/asm-m68k/coldfire/rng.h create mode 100644 include/asm-m68k/coldfire/skha.h
diff --git a/cpu/mcf52x2/cpu_init.c b/cpu/mcf52x2/cpu_init.c index 7bb358e..32ad6cd 100644 --- a/cpu/mcf52x2/cpu_init.c +++ b/cpu/mcf52x2/cpu_init.c @@ -36,6 +36,65 @@ #include <watchdog.h> #include <asm/immap.h>
+#ifndef CONFIG_M5272 +/* Only 5272 Flexbus chipselect is different from the rest */ +void init_fbcs(void) +{ + volatile fbcs_t *fbcs = (fbcs_t *) (MMAP_FBCS); + +#if (defined(CONFIG_SYS_CS0_BASE) && defined(CONFIG_SYS_CS0_MASK) \ + && defined(CONFIG_SYS_CS0_CTRL)) + fbcs->csar0 = CONFIG_SYS_CS0_BASE; + fbcs->cscr0 = CONFIG_SYS_CS0_CTRL; + fbcs->csmr0 = CONFIG_SYS_CS0_MASK; +#else +#warning "Chip Select 0 are not initialized/used" +#endif +#if (defined(CONFIG_SYS_CS1_BASE) && defined(CONFIG_SYS_CS1_MASK) \ + && defined(CONFIG_SYS_CS1_CTRL)) + fbcs->csar1 = CONFIG_SYS_CS1_BASE; + fbcs->cscr1 = CONFIG_SYS_CS1_CTRL; + fbcs->csmr1 = CONFIG_SYS_CS1_MASK; +#endif +#if (defined(CONFIG_SYS_CS2_BASE) && defined(CONFIG_SYS_CS2_MASK) \ + && defined(CONFIG_SYS_CS2_CTRL)) + fbcs->csar2 = CONFIG_SYS_CS2_BASE; + fbcs->cscr2 = CONFIG_SYS_CS2_CTRL; + fbcs->csmr2 = CONFIG_SYS_CS2_MASK; +#endif +#if (defined(CONFIG_SYS_CS3_BASE) && defined(CONFIG_SYS_CS3_MASK) \ + && defined(CONFIG_SYS_CS3_CTRL)) + fbcs->csar3 = CONFIG_SYS_CS3_BASE; + fbcs->cscr3 = CONFIG_SYS_CS3_CTRL; + fbcs->csmr3 = CONFIG_SYS_CS3_MASK; +#endif +#if (defined(CONFIG_SYS_CS4_BASE) && defined(CONFIG_SYS_CS4_MASK) \ + && defined(CONFIG_SYS_CS4_CTRL)) + fbcs->csar4 = CONFIG_SYS_CS4_BASE; + fbcs->cscr4 = CONFIG_SYS_CS4_CTRL; + fbcs->csmr4 = CONFIG_SYS_CS4_MASK; +#endif +#if (defined(CONFIG_SYS_CS5_BASE) && defined(CONFIG_SYS_CS5_MASK) \ + && defined(CONFIG_SYS_CS5_CTRL)) + fbcs->csar5 = CONFIG_SYS_CS5_BASE; + fbcs->cscr5 = CONFIG_SYS_CS5_CTRL; + fbcs->csmr5 = CONFIG_SYS_CS5_MASK; +#endif +#if (defined(CONFIG_SYS_CS6_BASE) && defined(CONFIG_SYS_CS6_MASK) \ + && defined(CONFIG_SYS_CS6_CTRL)) + fbcs->csar6 = CONFIG_SYS_CS6_BASE; + fbcs->cscr6 = CONFIG_SYS_CS6_CTRL; + fbcs->csmr6 = CONFIG_SYS_CS6_MASK; +#endif +#if (defined(CONFIG_SYS_CS7_BASE) && defined(CONFIG_SYS_CS7_MASK) \ + && defined(CONFIG_SYS_CS7_CTRL)) + fbcs->csar7 = CONFIG_SYS_CS7_BASE; + fbcs->cscr7 = CONFIG_SYS_CS7_CTRL; + fbcs->csmr7 = CONFIG_SYS_CS7_MASK; +#endif +} +#endif + #if defined(CONFIG_M5253) /* * Breath some life into the CPU... @@ -66,22 +125,14 @@ void cpu_init_f(void) mbar2_writeByte(MCFSIM_INTBASE, 0x40); /* Base interrupts at 64 */ mbar2_writeByte(MCFSIM_SPURVEC, 0x00);
- /*mbar2_writeLong(MCFSIM_IDECONFIG1, 0x00000020); */ /* Enable a 1 cycle pre-drive cycle on CS1 */ - - /* - * Setup chip selects... - */ - - mbar_writeShort(MCFSIM_CSAR1, CONFIG_SYS_CSAR1); - mbar_writeShort(MCFSIM_CSCR1, CONFIG_SYS_CSCR1); - mbar_writeLong(MCFSIM_CSMR1, CONFIG_SYS_CSMR1); + /*mbar2_writeLong(MCFSIM_IDECONFIG1, 0x00000020); *//* Enable a 1 cycle pre-drive cycle on CS1 */
- mbar_writeShort(MCFSIM_CSAR0, CONFIG_SYS_CSAR0); - mbar_writeShort(MCFSIM_CSCR0, CONFIG_SYS_CSCR0); - mbar_writeLong(MCFSIM_CSMR0, CONFIG_SYS_CSMR0); + /* FlexBus Chipselect */ + init_fbcs();
#ifdef CONFIG_FSL_I2C - CONFIG_SYS_I2C_PINMUX_REG = CONFIG_SYS_I2C_PINMUX_REG & CONFIG_SYS_I2C_PINMUX_CLR; + CONFIG_SYS_I2C_PINMUX_REG = + CONFIG_SYS_I2C_PINMUX_REG & CONFIG_SYS_I2C_PINMUX_CLR; CONFIG_SYS_I2C_PINMUX_REG |= CONFIG_SYS_I2C_PINMUX_SET; #ifdef CONFIG_SYS_I2C2_OFFSET CONFIG_SYS_I2C2_PINMUX_REG &= CONFIG_SYS_I2C2_PINMUX_CLR; @@ -121,6 +172,9 @@ void cpu_init_f(void) mbar_writeShort(MCF_WTM_WCR, 0); #endif
+ /* FlexBus Chipselect */ + init_fbcs(); + /* Set clockspeed to 100MHz */ mbar_writeShort(MCF_FMPLL_SYNCR, MCF_FMPLL_SYNCR_MFD(0) | MCF_FMPLL_SYNCR_RFD(0)); @@ -268,66 +322,20 @@ void uart_port_conf(void) */ void cpu_init_f(void) { - /* if we come from RAM we assume the CPU is + /* + * if we come from RAM we assume the CPU is * already initialized. */
#ifndef CONFIG_MONITOR_IS_IN_RAM - volatile wdog_t *wdog_reg = (wdog_t *)(MMAP_WDOG); - volatile gpio_t *gpio_reg = (gpio_t *)(MMAP_GPIO); - volatile csctrl_t *csctrl_reg = (csctrl_t *)(MMAP_FBCS); + volatile wdog_t *wdog_reg = (wdog_t *) (MMAP_WDOG); + volatile gpio_t *gpio_reg = (gpio_t *) (MMAP_GPIO);
/* Kill watchdog so we can initialize the PLL */ wdog_reg->wcr = 0;
- /* Memory Controller: */ - /* Flash */ - csctrl_reg->ar0 = CONFIG_SYS_AR0_PRELIM; - csctrl_reg->cr0 = CONFIG_SYS_CR0_PRELIM; - csctrl_reg->mr0 = CONFIG_SYS_MR0_PRELIM; - -#if (defined(CONFIG_SYS_AR1_PRELIM) && defined(CONFIG_SYS_CR1_PRELIM) && defined(CONFIG_SYS_MR1_PRELIM)) - csctrl_reg->ar1 = CONFIG_SYS_AR1_PRELIM; - csctrl_reg->cr1 = CONFIG_SYS_CR1_PRELIM; - csctrl_reg->mr1 = CONFIG_SYS_MR1_PRELIM; -#endif - -#if (defined(CONFIG_SYS_AR2_PRELIM) && defined(CONFIG_SYS_CR2_PRELIM) && defined(CONFIG_SYS_MR2_PRELIM)) - csctrl_reg->ar2 = CONFIG_SYS_AR2_PRELIM; - csctrl_reg->cr2 = CONFIG_SYS_CR2_PRELIM; - csctrl_reg->mr2 = CONFIG_SYS_MR2_PRELIM; -#endif - -#if (defined(CONFIG_SYS_AR3_PRELIM) && defined(CONFIG_SYS_CR3_PRELIM) && defined(CONFIG_SYS_MR3_PRELIM)) - csctrl_reg->ar3 = CONFIG_SYS_AR3_PRELIM; - csctrl_reg->cr3 = CONFIG_SYS_CR3_PRELIM; - csctrl_reg->mr3 = CONFIG_SYS_MR3_PRELIM; -#endif - -#if (defined(CONFIG_SYS_AR4_PRELIM) && defined(CONFIG_SYS_CR4_PRELIM) && defined(CONFIG_SYS_MR4_PRELIM)) - csctrl_reg->ar4 = CONFIG_SYS_AR4_PRELIM; - csctrl_reg->cr4 = CONFIG_SYS_CR4_PRELIM; - csctrl_reg->mr4 = CONFIG_SYS_MR4_PRELIM; -#endif - -#if (defined(CONFIG_SYS_AR5_PRELIM) && defined(CONFIG_SYS_CR5_PRELIM) && defined(CONFIG_SYS_MR5_PRELIM)) - csctrl_reg->ar5 = CONFIG_SYS_AR5_PRELIM; - csctrl_reg->cr5 = CONFIG_SYS_CR5_PRELIM; - csctrl_reg->mr5 = CONFIG_SYS_MR5_PRELIM; -#endif - -#if (defined(CONFIG_SYS_AR6_PRELIM) && defined(CONFIG_SYS_CR6_PRELIM) && defined(CONFIG_SYS_MR6_PRELIM)) - csctrl_reg->ar6 = CONFIG_SYS_AR6_PRELIM; - csctrl_reg->cr6 = CONFIG_SYS_CR6_PRELIM; - csctrl_reg->mr6 = CONFIG_SYS_MR6_PRELIM; -#endif - -#if (defined(CONFIG_SYS_AR7_PRELIM) && defined(CONFIG_SYS_CR7_PRELIM) && defined(CONFIG_SYS_MR7_PRELIM)) - csctrl_reg->ar7 = CONFIG_SYS_AR7_PRELIM; - csctrl_reg->cr7 = CONFIG_SYS_CR7_PRELIM; - csctrl_reg->mr7 = CONFIG_SYS_MR7_PRELIM; -#endif - + /* FlexBus Chipselect */ + init_fbcs(); #endif /* #ifndef CONFIG_MONITOR_IS_IN_RAM */
#ifdef CONFIG_FSL_I2C @@ -349,7 +357,7 @@ int cpu_init_r(void)
void uart_port_conf(void) { - volatile gpio_t *gpio = (gpio_t *)MMAP_GPIO; + volatile gpio_t *gpio = (gpio_t *) MMAP_GPIO;
/* Setup Ports: */ switch (CONFIG_SYS_UART_PORT) { @@ -384,7 +392,8 @@ void cpu_init_f(void) #ifndef CONFIG_MONITOR_IS_IN_RAM /* Set speed /PLL */ MCFCLOCK_SYNCR = - MCFCLOCK_SYNCR_MFD(CONFIG_SYS_MFD) | MCFCLOCK_SYNCR_RFD(CONFIG_SYS_RFD); + MCFCLOCK_SYNCR_MFD(CONFIG_SYS_MFD) | + MCFCLOCK_SYNCR_RFD(CONFIG_SYS_RFD); while (!(MCFCLOCK_SYNSR & MCFCLOCK_SYNSR_LOCK)) ;
MCFGPIO_PBCDPAR = 0xc0; @@ -425,119 +434,8 @@ void cpu_init_f(void) MCFGPIO_DDRUA = CONFIG_SYS_DDRUA; #endif
- /* This is probably a bad place to setup chip selects, but everyone - else is doing it! */ - -#if defined(CONFIG_SYS_CS0_BASE) & defined(CONFIG_SYS_CS0_SIZE) & \ - defined(CONFIG_SYS_CS0_WIDTH) & defined(CONFIG_SYS_CS0_WS) - - MCFCSM_CSAR0 = (CONFIG_SYS_CS0_BASE >> 16) & 0xFFFF; - -#if (CONFIG_SYS_CS0_WIDTH == 8) -#define CONFIG_SYS_CS0_PS MCFCSM_CSCR_PS_8 -#elif (CONFIG_SYS_CS0_WIDTH == 16) -#define CONFIG_SYS_CS0_PS MCFCSM_CSCR_PS_16 -#elif (CONFIG_SYS_CS0_WIDTH == 32) -#define CONFIG_SYS_CS0_PS MCFCSM_CSCR_PS_32 -#else -#error "CONFIG_SYS_CS0_WIDTH: Fault - wrong bus with for CS0" -#endif - MCFCSM_CSCR0 = MCFCSM_CSCR_WS(CONFIG_SYS_CS0_WS) - | CONFIG_SYS_CS0_PS | MCFCSM_CSCR_AA; - -#if (CONFIG_SYS_CS0_RO != 0) - MCFCSM_CSMR0 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS0_SIZE - 1) - | MCFCSM_CSMR_WP | MCFCSM_CSMR_V; -#else - MCFCSM_CSMR0 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS0_SIZE - 1) | MCFCSM_CSMR_V; -#endif -#else -#warning "Chip Select 0 are not initialized/used" -#endif - -#if defined(CONFIG_SYS_CS1_BASE) & defined(CONFIG_SYS_CS1_SIZE) & \ - defined(CONFIG_SYS_CS1_WIDTH) & defined(CONFIG_SYS_CS1_WS) - - MCFCSM_CSAR1 = (CONFIG_SYS_CS1_BASE >> 16) & 0xFFFF; - -#if (CONFIG_SYS_CS1_WIDTH == 8) -#define CONFIG_SYS_CS1_PS MCFCSM_CSCR_PS_8 -#elif (CONFIG_SYS_CS1_WIDTH == 16) -#define CONFIG_SYS_CS1_PS MCFCSM_CSCR_PS_16 -#elif (CONFIG_SYS_CS1_WIDTH == 32) -#define CONFIG_SYS_CS1_PS MCFCSM_CSCR_PS_32 -#else -#error "CONFIG_SYS_CS1_WIDTH: Fault - wrong bus with for CS1" -#endif - MCFCSM_CSCR1 = MCFCSM_CSCR_WS(CONFIG_SYS_CS1_WS) - | CONFIG_SYS_CS1_PS | MCFCSM_CSCR_AA; - -#if (CONFIG_SYS_CS1_RO != 0) - MCFCSM_CSMR1 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS1_SIZE - 1) - | MCFCSM_CSMR_WP | MCFCSM_CSMR_V; -#else - MCFCSM_CSMR1 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS1_SIZE - 1) - | MCFCSM_CSMR_V; -#endif -#else -#warning "Chip Select 1 are not initialized/used" -#endif - -#if defined(CONFIG_SYS_CS2_BASE) & defined(CONFIG_SYS_CS2_SIZE) & \ - defined(CONFIG_SYS_CS2_WIDTH) & defined(CONFIG_SYS_CS2_WS) - - MCFCSM_CSAR2 = (CONFIG_SYS_CS2_BASE >> 16) & 0xFFFF; - -#if (CONFIG_SYS_CS2_WIDTH == 8) -#define CONFIG_SYS_CS2_PS MCFCSM_CSCR_PS_8 -#elif (CONFIG_SYS_CS2_WIDTH == 16) -#define CONFIG_SYS_CS2_PS MCFCSM_CSCR_PS_16 -#elif (CONFIG_SYS_CS2_WIDTH == 32) -#define CONFIG_SYS_CS2_PS MCFCSM_CSCR_PS_32 -#else -#error "CONFIG_SYS_CS2_WIDTH: Fault - wrong bus with for CS2" -#endif - MCFCSM_CSCR2 = MCFCSM_CSCR_WS(CONFIG_SYS_CS2_WS) - | CONFIG_SYS_CS2_PS | MCFCSM_CSCR_AA; - -#if (CONFIG_SYS_CS2_RO != 0) - MCFCSM_CSMR2 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS2_SIZE - 1) - | MCFCSM_CSMR_WP | MCFCSM_CSMR_V; -#else - MCFCSM_CSMR2 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS2_SIZE - 1) - | MCFCSM_CSMR_V; -#endif -#else -#warning "Chip Select 2 are not initialized/used" -#endif - -#if defined(CONFIG_SYS_CS3_BASE) & defined(CONFIG_SYS_CS3_SIZE) & \ - defined(CONFIG_SYS_CS3_WIDTH) & defined(CONFIG_SYS_CS3_WS) - - MCFCSM_CSAR3 = (CONFIG_SYS_CS3_BASE >> 16) & 0xFFFF; - -#if (CONFIG_SYS_CS3_WIDTH == 8) -#define CONFIG_SYS_CS3_PS MCFCSM_CSCR_PS_8 -#elif (CONFIG_SYS_CS3_WIDTH == 16) -#define CONFIG_SYS_CS3_PS MCFCSM_CSCR_PS_16 -#elif (CONFIG_SYS_CS3_WIDTH == 32) -#define CONFIG_SYS_CS3_PS MCFCSM_CSCR_PS_32 -#else -#error "CONFIG_SYS_CS3_WIDTH: Fault - wrong bus with for CS1" -#endif - MCFCSM_CSCR3 = MCFCSM_CSCR_WS(CONFIG_SYS_CS3_WS) - | CONFIG_SYS_CS3_PS | MCFCSM_CSCR_AA; - -#if (CONFIG_SYS_CS3_RO != 0) - MCFCSM_CSMR3 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS3_SIZE - 1) - | MCFCSM_CSMR_WP | MCFCSM_CSMR_V; -#else - MCFCSM_CSMR3 = MCFCSM_CSMR_BAM(CONFIG_SYS_CS3_SIZE - 1) - | MCFCSM_CSMR_V; -#endif -#else -#warning "Chip Select 3 are not initialized/used" -#endif + /* FlexBus Chipselect */ + init_fbcs();
#endif /* CONFIG_MONITOR_IS_IN_RAM */
@@ -632,17 +530,8 @@ void cpu_init_f(void) mbar2_writeLong(MCFSIM_IDECONFIG1, 0x00000020); mbar2_writeLong(MCFSIM_IDECONFIG2, 0x00000000);
- /* - * Setup chip selects... - */ - - mbar_writeShort(MCFSIM_CSAR1, CONFIG_SYS_CSAR1); - mbar_writeShort(MCFSIM_CSCR1, CONFIG_SYS_CSCR1); - mbar_writeLong(MCFSIM_CSMR1, CONFIG_SYS_CSMR1); - - mbar_writeShort(MCFSIM_CSAR0, CONFIG_SYS_CSAR0); - mbar_writeShort(MCFSIM_CSCR0, CONFIG_SYS_CSCR0); - mbar_writeLong(MCFSIM_CSMR0, CONFIG_SYS_CSMR0); + /* FlexBus Chipselect */ + init_fbcs();
/* enable instruction cache now */ icache_enable(); diff --git a/include/asm-m68k/coldfire/ata.h b/include/asm-m68k/coldfire/ata.h new file mode 100644 index 0000000..3efd03a --- /dev/null +++ b/include/asm-m68k/coldfire/ata.h @@ -0,0 +1,79 @@ +/* + * ATA Internal Memory Map + * + * Copyright (C) 2004-2008 Freescale Semiconductor, Inc. + * TsiChung Liew (Tsi-Chung.Liew@freescale.com) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ATA_H__ +#define __ATA_H__ + +/* ATA */ +typedef struct atac { + /* PIO */ + u8 toff; /* 0x00 */ + u8 ton; /* 0x01 */ + u8 t1; /* 0x02 */ + u8 t2w; /* 0x03 */ + u8 t2r; /* 0x04 */ + u8 ta; /* 0x05 */ + u8 trd; /* 0x06 */ + u8 t4; /* 0x07 */ + u8 t9; /* 0x08 */ + + /* DMA */ + u8 tm; /* 0x09 */ + u8 tn; /* 0x0A */ + u8 td; /* 0x0B */ + u8 tk; /* 0x0C */ + u8 tack; /* 0x0D */ + u8 tenv; /* 0x0E */ + u8 trp; /* 0x0F */ + u8 tzah; /* 0x10 */ + u8 tmli; /* 0x11 */ + u8 tdvh; /* 0x12 */ + u8 tdzfs; /* 0x13 */ + u8 tdvs; /* 0x14 */ + u8 tcvh; /* 0x15 */ + u8 tss; /* 0x16 */ + u8 tcyc; /* 0x17 */ + + /* FIFO */ + u32 fifo32; /* 0x18 */ + u16 fifo16; /* 0x1C */ + u8 rsvd0[2]; + u8 ffill; /* 0x20 */ + u8 rsvd1[3]; + + /* ATA */ + u8 cr; /* 0x24 */ + u8 rsvd2[3]; + u8 isr; /* 0x28 */ + u8 rsvd3[3]; + u8 ier; /* 0x2C */ + u8 rsvd4[3]; + u8 icr; /* 0x30 */ + u8 rsvd5[3]; + u8 falarm; /* 0x34 */ + u8 rsvd6[106]; +} atac_t; + +#endif /* __ATA_H__ */ diff --git a/include/asm-m68k/coldfire/dspi.h b/include/asm-m68k/coldfire/dspi.h index 8327e1b..4b7d61e 100644 --- a/include/asm-m68k/coldfire/dspi.h +++ b/include/asm-m68k/coldfire/dspi.h @@ -46,15 +46,14 @@ typedef struct dspi { u32 dirsr; u32 dtfr; u32 drfr; - u32 dtfdr0; - u32 dtfdr1; - u32 dtfdr2; - u32 dtfdr3; +#ifdef CONFIG_MCF547x_8x + u32 dtfdr[4]; u8 resv1[0x30]; - u32 drfdr0; - u32 drfdr1; - u32 drfdr2; - u32 drfdr3; + u32 drfdr[4]; +#else + u32 dtfdr[16]; + u32 drfdr[16]; +#endif } dspi_t;
/* Bit definitions and macros for DMCR */ diff --git a/include/asm-m68k/coldfire/eport.h b/include/asm-m68k/coldfire/eport.h new file mode 100644 index 0000000..1d1bf63 --- /dev/null +++ b/include/asm-m68k/coldfire/eport.h @@ -0,0 +1,139 @@ +/* + * Edge Port Memory Map + * + * Copyright (C) 2004-2008 Freescale Semiconductor, Inc. + * TsiChung Liew (Tsi-Chung.Liew@freescale.com) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __EPORT_H__ +#define __EPORT_H__ + +/* Edge Port Module (EPORT) */ +typedef struct eport { +#ifdef CONFIG_MCF547x_8x + u16 par; /* 0x00 */ + u16 res0; /* 0x02 */ + u8 ddr; /* 0x04 */ + u8 ier; /* 0x05 */ + u16 res1; /* 0x06 */ + u8 dr; /* 0x08 */ + u8 pdr; /* 0x09 */ + u16 res2; /* 0x0A */ + u8 fr; /* 0x0C */ + u8 res3[3]; /* 0x0D */ +#else + u16 par; /* 0x00 Pin Assignment */ + u8 ddr; /* 0x02 Data Direction */ + u8 ier; /* 0x03 Interrupt Enable */ + u8 dr; /* 0x04 Data */ + u8 pdr; /* 0x05 Pin Data */ + u8 fr; /* 0x06 Flag */ + u8 res0; +#endif +} eport_t; + +/* EPPAR */ +#define EPORT_PAR_EPPA1(x) (((x)&0x0003)<<2) +#define EPORT_PAR_EPPA2(x) (((x)&0x0003)<<4) +#define EPORT_PAR_EPPA3(x) (((x)&0x0003)<<6) +#define EPORT_PAR_EPPA4(x) (((x)&0x0003)<<8) +#define EPORT_PAR_EPPA5(x) (((x)&0x0003)<<10) +#define EPORT_PAR_EPPA6(x) (((x)&0x0003)<<12) +#define EPORT_PAR_EPPA7(x) (((x)&0x0003)<<14) +#define EPORT_PAR_LEVEL (0) +#define EPORT_PAR_RISING (1) +#define EPORT_PAR_FALLING (2) +#define EPORT_PAR_BOTH (3) +#define EPORT_PAR_EPPA7_LEVEL (0x0000) +#define EPORT_PAR_EPPA7_RISING (0x4000) +#define EPORT_PAR_EPPA7_FALLING (0x8000) +#define EPORT_PAR_EPPA7_BOTH (0xC000) +#define EPORT_PAR_EPPA6_LEVEL (0x0000) +#define EPORT_PAR_EPPA6_RISING (0x1000) +#define EPORT_PAR_EPPA6_FALLING (0x2000) +#define EPORT_PAR_EPPA6_BOTH (0x3000) +#define EPORT_PAR_EPPA5_LEVEL (0x0000) +#define EPORT_PAR_EPPA5_RISING (0x0400) +#define EPORT_PAR_EPPA5_FALLING (0x0800) +#define EPORT_PAR_EPPA5_BOTH (0x0C00) +#define EPORT_PAR_EPPA4_LEVEL (0x0000) +#define EPORT_PAR_EPPA4_RISING (0x0100) +#define EPORT_PAR_EPPA4_FALLING (0x0200) +#define EPORT_PAR_EPPA4_BOTH (0x0300) +#define EPORT_PAR_EPPA3_LEVEL (0x0000) +#define EPORT_PAR_EPPA3_RISING (0x0040) +#define EPORT_PAR_EPPA3_FALLING (0x0080) +#define EPORT_PAR_EPPA3_BOTH (0x00C0) +#define EPORT_PAR_EPPA2_LEVEL (0x0000) +#define EPORT_PAR_EPPA2_RISING (0x0010) +#define EPORT_PAR_EPPA2_FALLING (0x0020) +#define EPORT_PAR_EPPA2_BOTH (0x0030) +#define EPORT_PAR_EPPA1_LEVEL (0x0000) +#define EPORT_PAR_EPPA1_RISING (0x0004) +#define EPORT_PAR_EPPA1_FALLING (0x0008) +#define EPORT_PAR_EPPA1_BOTH (0x000C) + +/* EPDDR */ +#define EPORT_DDR_EPDD1 (0x02) +#define EPORT_DDR_EPDD2 (0x04) +#define EPORT_DDR_EPDD3 (0x08) +#define EPORT_DDR_EPDD4 (0x10) +#define EPORT_DDR_EPDD5 (0x20) +#define EPORT_DDR_EPDD6 (0x40) +#define EPORT_DDR_EPDD7 (0x80) + +/* EPIER */ +#define EPORT_IER_EPIE1 (0x02) +#define EPORT_IER_EPIE2 (0x04) +#define EPORT_IER_EPIE3 (0x08) +#define EPORT_IER_EPIE4 (0x10) +#define EPORT_IER_EPIE5 (0x20) +#define EPORT_IER_EPIE6 (0x40) +#define EPORT_IER_EPIE7 (0x80) + +/* EPDR */ +#define EPORT_DR_EPD1 (0x02) +#define EPORT_DR_EPD2 (0x04) +#define EPORT_DR_EPD3 (0x08) +#define EPORT_DR_EPD4 (0x10) +#define EPORT_DR_EPD5 (0x20) +#define EPORT_DR_EPD6 (0x40) +#define EPORT_DR_EPD7 (0x80) + +/* EPPDR */ +#define EPORT_PDR_EPPD1 (0x02) +#define EPORT_PDR_EPPD2 (0x04) +#define EPORT_PDR_EPPD3 (0x08) +#define EPORT_PDR_EPPD4 (0x10) +#define EPORT_PDR_EPPD5 (0x20) +#define EPORT_PDR_EPPD6 (0x40) +#define EPORT_PDR_EPPD7 (0x80) + +/* EPFR */ +#define EPORT_FR_EPF1 (0x02) +#define EPORT_FR_EPF2 (0x04) +#define EPORT_FR_EPF3 (0x08) +#define EPORT_FR_EPF4 (0x10) +#define EPORT_FR_EPF5 (0x20) +#define EPORT_FR_EPF6 (0x40) +#define EPORT_FR_EPF7 (0x80) + +#endif /* __EPORT_H__ */ diff --git a/include/asm-m68k/coldfire/flexbus.h b/include/asm-m68k/coldfire/flexbus.h index 1d902c0..51cbbd8 100644 --- a/include/asm-m68k/coldfire/flexbus.h +++ b/include/asm-m68k/coldfire/flexbus.h @@ -31,33 +31,36 @@ *********************************************************************/
typedef struct fbcs { - u32 csar0; /* Chip-select Address Register */ - u32 csmr0; /* Chip-select Mask Register */ - u32 cscr0; /* Chip-select Control Register */ - u32 csar1; /* Chip-select Address Register */ - u32 csmr1; /* Chip-select Mask Register */ - u32 cscr1; /* Chip-select Control Register */ - u32 csar2; /* Chip-select Address Register */ - u32 csmr2; /* Chip-select Mask Register */ - u32 cscr2; /* Chip-select Control Register */ - u32 csar3; /* Chip-select Address Register */ - u32 csmr3; /* Chip-select Mask Register */ - u32 cscr3; /* Chip-select Control Register */ - u32 csar4; /* Chip-select Address Register */ - u32 csmr4; /* Chip-select Mask Register */ - u32 cscr4; /* Chip-select Control Register */ - u32 csar5; /* Chip-select Address Register */ - u32 csmr5; /* Chip-select Mask Register */ - u32 cscr5; /* Chip-select Control Register */ + u32 csar0; /* Chip-select Address */ + u32 csmr0; /* Chip-select Mask */ + u32 cscr0; /* Chip-select Control */ + u32 csar1; + u32 csmr1; + u32 cscr1; + u32 csar2; + u32 csmr2; + u32 cscr2; + u32 csar3; + u32 csmr3; + u32 cscr3; + u32 csar4; + u32 csmr4; + u32 cscr4; + u32 csar5; + u32 csmr5; + u32 cscr5; + u32 csar6; + u32 csmr6; + u32 cscr6; + u32 csar7; + u32 csmr7; + u32 cscr7; } fbcs_t;
-/* Bit definitions and macros for CSAR group */ -#define FBCS_CSAR_BA(x) ((x)&0xFFFF0000) +#define FBCS_CSAR_BA(x) ((x) & 0xFFFF0000)
-/* Bit definitions and macros for CSMR group */ -#define FBCS_CSMR_V (0x00000001) /* Valid bit */ -#define FBCS_CSMR_WP (0x00000100) /* Write protect */ -#define FBCS_CSMR_BAM(x) (((x)&0x0000FFFF)<<16) /* Base address mask */ +#define FBCS_CSMR_BAM(x) (((x) & 0xFFFF) << 16) +#define FBCS_CSMR_BAM_MASK (0x0000FFFF) #define FBCS_CSMR_BAM_4G (0xFFFF0000) #define FBCS_CSMR_BAM_2G (0x7FFF0000) #define FBCS_CSMR_BAM_1G (0x3FFF0000) @@ -78,21 +81,40 @@ typedef struct fbcs { #define FBCS_CSMR_BAM_128K (0x00010000) #define FBCS_CSMR_BAM_64K (0x00000000)
-/* Bit definitions and macros for CSCR group */ -#define FBCS_CSCR_BSTW (0x00000008) /* Burst-write enable */ -#define FBCS_CSCR_BSTR (0x00000010) /* Burst-read enable */ -#define FBCS_CSCR_BEM (0x00000020) /* Byte-enable mode */ -#define FBCS_CSCR_PS(x) (((x)&0x00000003)<<6) /* Port size */ -#define FBCS_CSCR_AA (0x00000100) /* Auto-acknowledge */ -#define FBCS_CSCR_WS(x) (((x)&0x0000003F)<<10) /* Wait states */ -#define FBCS_CSCR_WRAH(x) (((x)&0x00000003)<<16) /* Write address hold or deselect */ -#define FBCS_CSCR_RDAH(x) (((x)&0x00000003)<<18) /* Read address hold or deselect */ -#define FBCS_CSCR_ASET(x) (((x)&0x00000003)<<20) /* Address setup */ -#define FBCS_CSCR_SWSEN (0x00800000) /* Secondary wait state enable */ -#define FBCS_CSCR_SWS(x) (((x)&0x0000003F)<<26) /* Secondary wait states */ +#ifdef CONFIG_M5249 +#define FBCS_CSMR_WP (0x00000080) +#define FBCS_CSMR_AM (0x00000040) +#define FBCS_CSMR_CI (0x00000020) +#define FBCS_CSMR_SC (0x00000010) +#define FBCS_CSMR_SD (0x00000008) +#define FBCS_CSMR_UC (0x00000004) +#define FBCS_CSMR_UD (0x00000002) +#else +#define FBCS_CSMR_WP (0x00000100) +#endif +#define FBCS_CSMR_V (0x00000001) /* Valid bit */ + +#define FBCS_CSCR_SWS(x) (((x) & 0x3F) << 26) +#define FBCS_CSCR_SWS_MASK (0x03FFFFFF) +#define FBCS_CSCR_SWSEN (0x00800000) +#define FBCS_CSCR_ASET(x) (((x) & 0x03) << 20) +#define FBCS_CSCR_ASET_MASK (0xFFCFFFFF) +#define FBCS_CSCR_RDAH(x) (((x) & 0x03) << 18) +#define FBCS_CSCR_RDAH_MASK (0xFFF3FFFF) +#define FBCS_CSCR_WRAH(x) (((x) & 0x03) << 16) +#define FBCS_CSCR_WRAH_MASK (0xFFFCFFFF) +#define FBCS_CSCR_WS(x) (((x) & 0x3F) << 10) +#define FBCS_CSCR_WS_MASK (0xFFFF03FF) +#define FBCS_CSCR_SBM (0x00000200) +#define FBCS_CSCR_AA (0x00000100) +#define FBCS_CSCR_PS(x) (((x) & 0x03) << 6) +#define FBCS_CSCR_PS_MASK (0xFFFFFF3F) +#define FBCS_CSCR_BEM (0x00000020) +#define FBCS_CSCR_BSTR (0x00000010) +#define FBCS_CSCR_BSTW (0x00000008)
-#define FBCS_CSCR_PS_8 (0x00000040) #define FBCS_CSCR_PS_16 (0x00000080) +#define FBCS_CSCR_PS_8 (0x00000040) #define FBCS_CSCR_PS_32 (0x00000000)
#endif /* __FLEXBUS_H */ diff --git a/include/asm-m68k/coldfire/flexcan.h b/include/asm-m68k/coldfire/flexcan.h new file mode 100644 index 0000000..cafd44f --- /dev/null +++ b/include/asm-m68k/coldfire/flexcan.h @@ -0,0 +1,219 @@ +/* + * Flex CAN Memory Map + * + * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. + * TsiChung Liew (Tsi-Chung.Liew@freescale.com) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __FLEXCAN_H__ +#define __FLEXCAN_H__ + +/* FlexCan Message Buffer */ +typedef struct can_msgbuf_ctrl { +#ifdef CONFIG_M5282 + u8 tmstamp; /* 0x00 Timestamp */ + u8 ctrl; /* 0x01 Control */ + u16 idh; /* 0x02 ID High */ + u16 idl; /* 0x04 ID High */ + u8 data[8]; /* 0x06 8 Byte Data Field */ + u16 res; /* 0x0E */ +#else + u16 ctrl; /* 0x00 Control/Status */ + u16 tmstamp; /* 0x02 Timestamp */ + u32 id; /* 0x04 Identifier */ + u8 data[8]; /* 0x08 8 Byte Data Field */ +#endif +} can_msg_t; + +#ifdef CONFIG_M5282 +/* MSGBUF CTRL */ +#define CAN_MSGBUF_CTRL_CODE(x) (((x) & 0x0F) << 4) +#define CAN_MSGBUF_CTRL_CODE_MASK (0x0F) +#define CAN_MSGBUF_CTRL_LEN(x) ((x) & 0x0F) +#define CAN_MSGBUF_CTRL_LEN_MASK (0xF0) + +/* MSGBUF ID */ +#define CAN_MSGBUF_IDH_STD(x) (((x) & 0x07FF) << 5) +#define CAN_MSGBUF_IDH_STD_MASK (0xE003FFFF) +#define CAN_MSGBUF_IDH_SRR (0x0010) +#define CAN_MSGBUF_IDH_IDE (0x0080) +#define CAN_MSGBUF_IDH_EXTH(x) ((x) & 0x07) +#define CAN_MSGBUF_IDH_EXTH_MASK (0xFFF8) +#define CAN_MSGBUF_IDL_EXTL(x) (((x) & 0x7FFF) << 1) +#define CAN_MSGBUF_IDL_EXTL_MASK (0xFFFE) +#define CAN_MSGBUF_IDL_RTR (0x0001) +#else +/* MSGBUF CTRL */ +#define CAN_MSGBUF_CTRL_CODE(x) (((x) & 0x000F) << 8) +#define CAN_MSGBUF_CTRL_CODE_MASK (0xF0FF) +#define CAN_MSGBUF_CTRL_SRR (0x0040) +#define CAN_MSGBUF_CTRL_IDE (0x0020) +#define CAN_MSGBUF_CTRL_RTR (0x0010) +#define CAN_MSGBUF_CTRL_LEN(x) ((x) & 0x000F) +#define CAN_MSGBUF_CTRL_LEN_MASK (0xFFF0) + +/* MSGBUF ID */ +#define CAN_MSGBUF_ID_STD(x) (((x) & 0x000007FF) << 18) +#define CAN_MSGBUF_ID_STD_MASK (0xE003FFFF) +#define CAN_MSGBUF_ID_EXT(x) ((x) & 0x0003FFFF) +#define CAN_MSGBUF_ID_EXT_MASK (0xFFFC0000) +#endif + +/* FlexCan module */ +typedef struct can_ctrl { + u32 mcr; /* 0x00 Module Configuration */ + u32 ctrl; /* 0x04 Control */ + u32 timer; /* 0x08 Free Running Timer */ + u32 res1; /* 0x0C */ + u32 rxgmsk; /* 0x10 Rx Global Mask */ + u32 rx14msk; /* 0x14 RxBuffer 14 Mask */ + u32 rx15msk; /* 0x18 RxBuffer 15 Mask */ +#ifdef CONFIG_M5282 + u32 res2; /* 0x1C */ + u16 errstat; /* 0x20 Error and status */ + u16 imsk; /* 0x22 Interrupt Mask */ + u16 iflag; /* 0x24 Interrupt Flag */ + u16 errcnt; /* 0x26 Error Counter */ + u32 res3[3]; /* 0x28 - 0x33 */ +#else + u16 res2; /* 0x1C */ + u16 errcnt; /* 0x1E Error Counter */ + u16 res3; /* 0x20 */ + u16 errstat; /* 0x22 Error and status */ + u32 res4; /* 0x24 */ + u32 imsk; /* 0x28 Interrupt Mask */ + u32 res5; /* 0x2C */ + u16 iflag; /* 0x30 Interrupt Flag */ +#endif + u32 res6[19]; /* 0x34 - 0x7F */ + void *msgbuf; /* 0x80 Message Buffer 0-15 */ +} can_t; + +/* MCR */ +#define CAN_MCR_MDIS (0x80000000) +#define CAN_MCR_FRZ (0x40000000) +#define CAN_MCR_HALT (0x10000000) +#define CAN_MCR_NORDY (0x08000000) +#define CAN_MCF_WAKEMSK (0x04000000) /* 5282 */ +#define CAN_MCR_SOFTRST (0x02000000) +#define CAN_MCR_FRZACK (0x01000000) +#define CAN_MCR_SUPV (0x00800000) +#define CAN_MCR_SELFWAKE (0x00400000) /* 5282 */ +#define CAN_MCR_APS (0x00200000) /* 5282 */ +#define CAN_MCR_LPMACK (0x00100000) +#define CAN_MCF_BCC (0x00010000) +#define CAN_MCR_MAXMB(x) ((x) & 0x0F) +#define CAN_MCR_MAXMB_MASK (0xFFFFFFF0) + +/* CTRL */ +#define CAN_CTRL_PRESDIV(x) (((x) & 0xFF) << 24) +#define CAN_CTRL_PRESDIV_MASK (0x00FFFFFF) +#define CAN_CTRL_RJW(x) (((x) & 0x03) << 22) +#define CAN_CTRL_RJW_MASK (0xFF3FFFFF) +#define CAN_CTRL_PSEG1(x) (((x) & 0x07) << 19) +#define CAN_CTRL_PSEG1_MASK (0xFFC7FFFF) +#define CAN_CTRL_PSEG2(x) (((x) & 0x07) << 16) +#define CAN_CTRL_PSEG2_MASK (0xFFF8FFFF) +#define CAN_CTRL_BOFFMSK (0x00008000) +#define CAN_CTRL_ERRMSK (0x00004000) +#define CAN_CTRL_CLKSRC (0x00002000) +#define CAN_CTRL_LPB (0x00001000) +#define CAN_CTRL_RXMODE (0x00000400) /* 5282 */ +#define CAN_CTRL_TXMODE(x) (((x) & 0x03) << 8) /* 5282 */ +#define CAN_CTRL_TXMODE_MASK (0xFFFFFCFF) /* 5282 */ +#define CAN_CTRL_TXMODE_CAN0 (0x00000000) /* 5282 */ +#define CAN_CTRL_TXMODE_CAN1 (0x00000100) /* 5282 */ +#define CAN_CTRL_TXMODE_OPEN (0x00000200) /* 5282 */ +#define CAN_CTRL_SMP (0x00000080) +#define CAN_CTRL_BOFFREC (0x00000040) +#define CAN_CTRL_TSYNC (0x00000020) +#define CAN_CTRL_LBUF (0x00000010) +#define CAN_CTRL_LOM (0x00000008) +#define CAN_CTRL_PROPSEG(x) ((x) & 0x07) +#define CAN_CTRL_PROPSEG_MASK (0xFFFFFFF8) + +/* TIMER */ +/* Note: PRESDIV, RJW, PSG1, and PSG2 are part of timer in 5282 */ +#define CAN_TIMER(x) ((x) & 0xFFFF) +#define CAN_TIMER_MASK (0xFFFF0000) + +/* RXGMASK */ +#ifdef CONFIG_M5282 +#define CAN_RXGMSK_MI_STD(x) (((x) & 0x000007FF) << 21) +#define CAN_RXGMSK_MI_STD_MASK (0x001FFFFF) +#define CAN_RXGMSK_MI_EXT(x) (((x) & 0x0003FFFF) << 1) +#define CAN_RXGMSK_MI_EXT_MASK (0xFFF80001) +#else +#define CAN_RXGMSK_MI_STD(x) (((x) & 0x000007FF) << 18) +#define CAN_RXGMSK_MI_STD_MASK (0xE003FFFF) +#define CAN_RXGMSK_MI_EXT(x) ((x) & 0x0003FFFF) +#define CAN_RXGMSK_MI_EXT_MASK (0xFFFC0000) +#endif + +/* ERRCNT */ +#define CAN_ERRCNT_RXECTR(x) (((x) & 0xFF) << 8) +#define CAN_ERRCNT_RXECTR_MASK (0x00FF) +#define CAN_ERRCNT_TXECTR(x) ((x) & 0xFF) +#define CAN_ERRCNT_TXECTR_MASK (0xFF00) + +/* ERRSTAT */ +#define CAN_ERRSTAT_BITERR1 (0x8000) +#define CAN_ERRSTAT_BITERR0 (0x4000) +#define CAN_ERRSTAT_ACKERR (0x2000) +#define CAN_ERRSTAT_CRCERR (0x1000) +#define CAN_ERRSTAT_FRMERR (0x0800) +#define CAN_ERRSTAT_STFERR (0x0400) +#define CAN_ERRSTAT_TXWRN (0x0200) +#define CAN_ERRSTAT_RXWRN (0x0100) +#define CAN_ERRSTAT_IDLE (0x0080) +#define CAN_ERRSTAT_TXRX (0x0040) +#define CAN_ERRSTAT_FLT_MASK (0xFFCF) +#define CAN_ERRSTAT_FLT_BUSOFF (0x0020) +#define CAN_ERRSTAT_FLT_PASSIVE (0x0010) +#define CAN_ERRSTAT_FLT_ACTIVE (0x0000) +#ifdef CONFIG_M5282 +#define CAN_ERRSTAT_BOFFINT (0x0004) +#define CAN_ERRSTAT_ERRINT (0x0002) +#else +#define CAN_ERRSTAT_ERRINT (0x0004) +#define CAN_ERRSTAT_BOFFINT (0x0002) +#define CAN_ERRSTAT_WAKEINT (0x0001) +#endif + +/* IMASK */ +#ifdef CONFIG_M5253 +#define CAN_IMASK_BUFnM(x) (1 << (x & 0xFFFFFFFF)) +#define CAN_IMASK_BUFnM_MASKBIT(x) ~CAN_IMASK_BUFnM(x) +#else +#define CAN_IMASK_BUFnM(x) (1 << (x & 0xFFFF)) +#define CAN_IMASK_BUFnM_MASKBIT(x) ~CAN_IMASK_BUFnM(x) +#endif + +/* IFLAG */ +#ifdef CONFIG_M5253 +#define CAN_IFLAG_BUFnM(x) (1 << (x & 0xFFFFFFFF)) +#define CAN_IFLAG_BUFnM_MASKBIT(x) ~CAN_IFLAG_BUFnM(x) +#else +#define CAN_IFLAG_BUFnM(x) (1 << (x & 0xFFFF)) +#define CAN_IFLAG_BUFnM_MASKBIT(x) ~CAN_IFLAG_BUFnM(x) +#endif + +#endif /* __FLEXCAN_H__ */ diff --git a/include/asm-m68k/coldfire/intctrl.h b/include/asm-m68k/coldfire/intctrl.h new file mode 100644 index 0000000..ae82b29 --- /dev/null +++ b/include/asm-m68k/coldfire/intctrl.h @@ -0,0 +1,246 @@ +/* + * Interrupt Controller Memory Map + * + * Copyright (C) 2004-2008 Freescale Semiconductor, Inc. + * TsiChung Liew (Tsi-Chung.Liew@freescale.com) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __INTCTRL_H__ +#define __INTCTRL_H__ + +#if defined(CONFIG_M5235) || defined(CONFIG_M5271) || \ + defined(CONFIG_M5275) || defined(CONFIG_M5282) || \ + defined(CONFIG_M547x) || defined(CONFIG_M548x) +# define CONFIG_SYS_CF_INTC_REG1 +#endif + +typedef struct int0_ctrl { + /* Interrupt Controller 0 */ + u32 iprh0; /* 0x00 Pending High */ + u32 iprl0; /* 0x04 Pending Low */ + u32 imrh0; /* 0x08 Mask High */ + u32 imrl0; /* 0x0C Mask Low */ + u32 frch0; /* 0x10 Force High */ + u32 frcl0; /* 0x14 Force Low */ +#if defined(CONFIG_SYS_CF_INTC_REG1) + u8 irlr; /* 0x18 */ + u8 iacklpr; /* 0x19 */ + u16 res1[19]; /* 0x1a - 0x3c */ +#else + u16 res1; /* 0x18 - 0x19 */ + u16 icfg0; /* 0x1A Configuration */ + u8 simr0; /* 0x1C Set Interrupt Mask */ + u8 cimr0; /* 0x1D Clear Interrupt Mask */ + u8 clmask0; /* 0x1E Current Level Mask */ + u8 slmask; /* 0x1F Saved Level Mask */ + u32 res2[8]; /* 0x20 - 0x3F */ +#endif + u8 icr0[64]; /* 0x40 - 0x7F Control registers */ + u32 res3[24]; /* 0x80 - 0xDF */ + u8 swiack0; /* 0xE0 Software Interrupt ack */ + u8 res4[3]; /* 0xE1 - 0xE3 */ + u8 L1iack0; /* 0xE4 Level n interrupt ack */ + u8 res5[3]; /* 0xE5 - 0xE7 */ + u8 L2iack0; /* 0xE8 Level n interrupt ack */ + u8 res6[3]; /* 0xE9 - 0xEB */ + u8 L3iack0; /* 0xEC Level n interrupt ack */ + u8 res7[3]; /* 0xED - 0xEF */ + u8 L4iack0; /* 0xF0 Level n interrupt ack */ + u8 res8[3]; /* 0xF1 - 0xF3 */ + u8 L5iack0; /* 0xF4 Level n interrupt ack */ + u8 res9[3]; /* 0xF5 - 0xF7 */ + u8 L6iack0; /* 0xF8 Level n interrupt ack */ + u8 resa[3]; /* 0xF9 - 0xFB */ + u8 L7iack0; /* 0xFC Level n interrupt ack */ + u8 resb[3]; /* 0xFD - 0xFF */ +} int0_t; + +typedef struct int1_ctrl { + /* Interrupt Controller 1 */ + u32 iprh1; /* 0x00 Pending High */ + u32 iprl1; /* 0x04 Pending Low */ + u32 imrh1; /* 0x08 Mask High */ + u32 imrl1; /* 0x0C Mask Low */ + u32 frch1; /* 0x10 Force High */ + u32 frcl1; /* 0x14 Force Low */ +#if defined(CONFIG_SYS_CF_INTC_REG1) + u8 irlr; /* 0x18 */ + u8 iacklpr; /* 0x19 */ + u16 res1[19]; /* 0x1a - 0x3c */ +#else + u16 res1; /* 0x18 */ + u16 icfg1; /* 0x1A Configuration */ + u8 simr1; /* 0x1C Set Interrupt Mask */ + u8 cimr1; /* 0x1D Clear Interrupt Mask */ + u16 res2; /* 0x1E - 0x1F */ + u32 res3[8]; /* 0x20 - 0x3F */ +#endif + u8 icr1[64]; /* 0x40 - 0x7F */ + u32 res4[24]; /* 0x80 - 0xDF */ + u8 swiack1; /* 0xE0 Software Interrupt ack */ + u8 res5[3]; /* 0xE1 - 0xE3 */ + u8 L1iack1; /* 0xE4 Level n interrupt ack */ + u8 res6[3]; /* 0xE5 - 0xE7 */ + u8 L2iack1; /* 0xE8 Level n interrupt ack */ + u8 res7[3]; /* 0xE9 - 0xEB */ + u8 L3iack1; /* 0xEC Level n interrupt ack */ + u8 res8[3]; /* 0xED - 0xEF */ + u8 L4iack1; /* 0xF0 Level n interrupt ack */ + u8 res9[3]; /* 0xF1 - 0xF3 */ + u8 L5iack1; /* 0xF4 Level n interrupt ack */ + u8 resa[3]; /* 0xF5 - 0xF7 */ + u8 L6iack1; /* 0xF8 Level n interrupt ack */ + u8 resb[3]; /* 0xF9 - 0xFB */ + u8 L7iack1; /* 0xFC Level n interrupt ack */ + u8 resc[3]; /* 0xFD - 0xFF */ +} int1_t; + +typedef struct intgack_ctrl1 { + /* Global IACK Registers */ + u8 swiack; /* 0x00 Global Software Interrupt ack */ + u8 res0[0x3]; + u8 gl1iack; /* 0x04 */ + u8 resv1[0x3]; + u8 gl2iack; /* 0x08 */ + u8 res2[0x3]; + u8 gl3iack; /* 0x0C */ + u8 res3[0x3]; + u8 gl4iack; /* 0x10 */ + u8 res4[0x3]; + u8 gl5iack; /* 0x14 */ + u8 res5[0x3]; + u8 gl6iack; /* 0x18 */ + u8 res6[0x3]; + u8 gl7iack; /* 0x1C */ + u8 res7[0x3]; +} intgack_t; + +#define INTC_IPRH_INT63 (0x80000000) +#define INTC_IPRH_INT62 (0x40000000) +#define INTC_IPRH_INT61 (0x20000000) +#define INTC_IPRH_INT60 (0x10000000) +#define INTC_IPRH_INT59 (0x08000000) +#define INTC_IPRH_INT58 (0x04000000) +#define INTC_IPRH_INT57 (0x02000000) +#define INTC_IPRH_INT56 (0x01000000) +#define INTC_IPRH_INT55 (0x00800000) +#define INTC_IPRH_INT54 (0x00400000) +#define INTC_IPRH_INT53 (0x00200000) +#define INTC_IPRH_INT52 (0x00100000) +#define INTC_IPRH_INT51 (0x00080000) +#define INTC_IPRH_INT50 (0x00040000) +#define INTC_IPRH_INT49 (0x00020000) +#define INTC_IPRH_INT48 (0x00010000) +#define INTC_IPRH_INT47 (0x00008000) +#define INTC_IPRH_INT46 (0x00004000) +#define INTC_IPRH_INT45 (0x00002000) +#define INTC_IPRH_INT44 (0x00001000) +#define INTC_IPRH_INT43 (0x00000800) +#define INTC_IPRH_INT42 (0x00000400) +#define INTC_IPRH_INT41 (0x00000200) +#define INTC_IPRH_INT40 (0x00000100) +#define INTC_IPRH_INT39 (0x00000080) +#define INTC_IPRH_INT38 (0x00000040) +#define INTC_IPRH_INT37 (0x00000020) +#define INTC_IPRH_INT36 (0x00000010) +#define INTC_IPRH_INT35 (0x00000008) +#define INTC_IPRH_INT34 (0x00000004) +#define INTC_IPRH_INT33 (0x00000002) +#define INTC_IPRH_INT32 (0x00000001) + +#define INTC_IPRL_INT31 (0x80000000) +#define INTC_IPRL_INT30 (0x40000000) +#define INTC_IPRL_INT29 (0x20000000) +#define INTC_IPRL_INT28 (0x10000000) +#define INTC_IPRL_INT27 (0x08000000) +#define INTC_IPRL_INT26 (0x04000000) +#define INTC_IPRL_INT25 (0x02000000) +#define INTC_IPRL_INT24 (0x01000000) +#define INTC_IPRL_INT23 (0x00800000) +#define INTC_IPRL_INT22 (0x00400000) +#define INTC_IPRL_INT21 (0x00200000) +#define INTC_IPRL_INT20 (0x00100000) +#define INTC_IPRL_INT19 (0x00080000) +#define INTC_IPRL_INT18 (0x00040000) +#define INTC_IPRL_INT17 (0x00020000) +#define INTC_IPRL_INT16 (0x00010000) +#define INTC_IPRL_INT15 (0x00008000) +#define INTC_IPRL_INT14 (0x00004000) +#define INTC_IPRL_INT13 (0x00002000) +#define INTC_IPRL_INT12 (0x00001000) +#define INTC_IPRL_INT11 (0x00000800) +#define INTC_IPRL_INT10 (0x00000400) +#define INTC_IPRL_INT9 (0x00000200) +#define INTC_IPRL_INT8 (0x00000100) +#define INTC_IPRL_INT7 (0x00000080) +#define INTC_IPRL_INT6 (0x00000040) +#define INTC_IPRL_INT5 (0x00000020) +#define INTC_IPRL_INT4 (0x00000010) +#define INTC_IPRL_INT3 (0x00000008) +#define INTC_IPRL_INT2 (0x00000004) +#define INTC_IPRL_INT1 (0x00000002) +#define INTC_IPRL_INT0 (0x00000001) + +#define INTC_IMRLn_MASKALL (0x00000001) + +#define INTC_IRLR(x) (((x) & 0x7F) << 1) +#define INTC_IRLR_MASK (0x01) + +#define INTC_IACKLPR_LVL(x) (((x) & 0x07) << 4) +#define INTC_IACKLPR_LVL_MASK (0x8F) +#define INTC_IACKLPR_PRI(x) ((x) & 0x0F) +#define INTC_IACKLPR_PRI_MASK (0xF0) + +#if defined(CONFIG_SYS_CF_INTC_REG1) +#define INTC_ICR_IL(x) (((x) & 0x07) << 3) +#define INTC_ICR_IL_MASK (0xC7) +#define INTC_ICR_IP(x) ((x) & 0x07) +#define INTC_ICR_IP_MASK (0xF8) +#else +#define INTC_ICR_IL(x) ((x) & 0x07) +#define INTC_ICR_IL_MASK (0xF8) +#endif + +#define INTC_ICONFIG_ELVLPRI_MASK (0x01FF) +#define INTC_ICONFIG_ELVLPRI7 (0x8000) +#define INTC_ICONFIG_ELVLPRI6 (0x4000) +#define INTC_ICONFIG_ELVLPRI5 (0x2000) +#define INTC_ICONFIG_ELVLPRI4 (0x1000) +#define INTC_ICONFIG_ELVLPRI3 (0x0800) +#define INTC_ICONFIG_ELVLPRI2 (0x0400) +#define INTC_ICONFIG_ELVLPRI1 (0x0200) +#define INTC_ICONFIG_EMASK (0x0020) + +#define INTC_SIMR_ALL (0x40) +#define INTC_SIMR(x) ((x) & 0x3F) +#define INTC_SIMR_MASK (0x80) + +#define INTC_CIMR_ALL (0x40) +#define INTC_CIMR(x) ((x) & 0x3F) +#define INTC_CIMR_MASK (0x80) + +#define INTC_CLMASK(x) ((x) & 0x0F) +#define INTC_CLMASK_MASK (0xF0) + +#define INTC_SLMASK(x) ((x) & 0x0F) +#define INTC_SLMASK_MASK (0xF0) + +#endif /* __INTCTRL_H__ */ diff --git a/include/asm-m68k/coldfire/mdha.h b/include/asm-m68k/coldfire/mdha.h new file mode 100644 index 0000000..b698136 --- /dev/null +++ b/include/asm-m68k/coldfire/mdha.h @@ -0,0 +1,102 @@ +/* + * Message Digest Hardware Accelerator Memory Map + * + * Copyright (C) 2004-2008 Freescale Semiconductor, Inc. + * TsiChung Liew (Tsi-Chung.Liew@freescale.com) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __MDHA_H__ +#define __MDHA_H__ + +/* Message Digest Hardware Accelerator */ +typedef struct mdha_ctrl { + u32 mr; /* 0x00 MDHA Mode */ + u32 cr; /* 0x04 Control */ + u32 cmd; /* 0x08 Command */ + u32 sr; /* 0x0C Status */ + u32 isr; /* 0x10 Interrupt Status */ + u32 imr; /* 0x14 Interrupt Mask */ + u32 dsz; /* 0x1C Data Size */ + u32 inp; /* 0x20 Input FIFO */ + u32 res1[3]; /* 0x24 - 0x2F */ + u32 mda0; /* 0x30 Message Digest AO */ + u32 mdb0; /* 0x34 Message Digest BO */ + u32 mdc0; /* 0x38 Message Digest CO */ + u32 mdd0; /* 0x3C Message Digest DO */ + u32 mde0; /* 0x40 Message Digest EO */ + u32 mdsz; /* 0x44 Message Data Size */ + u32 res[10]; /* 0x48 - 0x6F */ + u32 mda1; /* 0x70 Message Digest A1 */ + u32 mdb1; /* 0x74 Message Digest B1 */ + u32 mdc1; /* 0x78 Message Digest C1 */ + u32 mdd1; /* 0x7C Message Digest D1 */ + u32 mde1; /* 0x80 Message Digest E1 */ +} mdha_t; + +#define MDHA_MR_SSL (0x00000400) +#define MDHA_MR_MACFUL (0x00000200) +#define MDHA_MR_SWAP (0x00000100) +#define MDHA_MR_OPAD (0x00000080) +#define MDHA_MR_IPAD (0x00000040) +#define MDHA_MR_INIT (0x00000020) +#define MDHA_MR_MAC(x) (((x) & 0x03) << 3) +#define MDHA_MR_MAC_MASK (0xFFFFFFE7) +#define MDHA_MR_MAC_EHMAC (0x00000010) +#define MDHA_MR_MAC_HMAC (0x00000008) +#define MDHA_MR_MAC_NONE (0x00000000) +#define MDHA_MR_PDATA (0x00000004) +#define MDHA_MR_ALG (0x00000001) + +#define MDHA_CR_DMAL(x) (((x) & 0x1F) << 16) /* 532x */ +#define MDHA_CR_DMAL_MASK (0xFFE0FFFF) /* 532x */ +#define MDHA_CR_END (0x00000004) /* 532x */ +#define MDHA_CR_DMA (0x00000002) /* 532x */ +#define MDHA_CR_IE (0x00000001) + +#define MDHA_CMD_GO (0x00000008) +#define MDHA_CMD_CI (0x00000004) +#define MDHA_CMD_RI (0x00000001) +#define MDHA_CMD_SWR (0x00000001) + +#define MDHA_SR_IFL(x) (((x) & 0xFF) << 16) +#define MDHA_SR_IFL_MASK (0xFF00FFFF) +#define MDHA_SR_APD(x) (((x) & 0x7) << 13) +#define MDHA_SR_APD_MASK (0xFFFF1FFF) +#define MDHA_SR_FS(x) (((x) & 0x7) << 8) +#define MDHA_SR_FS_MASK (0xFFFFF8FF) +#define MDHA_SR_GNW (0x00000080) +#define MDHA_SR_HSH (0x00000040) +#define MDHA_SR_BUSY (0x00000010) +#define MDHA_SR_RD (0x00000008) +#define MDHA_SR_ERR (0x00000004) +#define MDHA_SR_DONE (0x00000002) +#define MDHA_SR_INT (0x00000001) + +#define MDHA_ISR_DRL (0x00000400) /* 532x */ +#define MDHA_ISR_GTDS (0x00000200) +#define MDHA_ISR_ERE (0x00000100) +#define MDHA_ISR_RMDP (0x00000080) +#define MDHA_ISR_DSE (0x00000020) +#define MDHA_ISR_IME (0x00000010) +#define MDHA_ISR_NEIF (0x00000004) +#define MDHA_ISR_IFO (0x00000001) + +#endif /* __MDHA_H__ */ diff --git a/include/asm-m68k/coldfire/pwm.h b/include/asm-m68k/coldfire/pwm.h new file mode 100644 index 0000000..f737d98 --- /dev/null +++ b/include/asm-m68k/coldfire/pwm.h @@ -0,0 +1,115 @@ +/* + * Pulse Width Modulation Memory Map + * + * Copyright (C) 2004-2008 Freescale Semiconductor, Inc. + * TsiChung Liew (Tsi-Chung.Liew@freescale.com) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ATA_H__ +#define __ATA_H__ + +/* Pulse Width Modulation (PWM) */ +typedef struct pwm_ctrl { +#ifdef CONFIG_M5272 + u8 cr0; + u8 res1[3]; + u8 cr1; + u8 res2[3]; + u8 cr2; + u8 res3[7]; + u8 pwr0; + u8 res4[3]; + u8 pwr1; + u8 res5[3]; + u8 pwr2; + u8 res6[7]; +#else + u8 en; /* 0x00 PWM Enable */ + u8 pol; /* 0x01 Polarity */ + u8 clk; /* 0x02 Clock Select */ + u8 prclk; /* 0x03 Prescale Clock Select */ + u8 cae; /* 0x04 Center Align Enable */ + u8 ctl; /* 0x05 Control */ + u16 res1; /* 0x06 - 0x07 */ + u8 scla; /* 0x08 Scale A */ + u8 sclb; /* 0x09 Scale B */ + u16 res2; /* 0x0A - 0x0B */ +#ifdef CONFIG_M5275 + u8 cnt[4]; /* 0x0C Channel n Counter */ + u16 res3; /* 0x10 - 0x11 */ + u8 per[4]; /* 0x14 Channel n Period */ + u16 res4; /* 0x16 - 0x17 */ + u8 dty[4]; /* 0x18 Channel n Duty */ +#else + u8 cnt[8]; /* 0x0C Channel n Counter */ + u8 per[8]; /* 0x14 Channel n Period */ + u8 dty[8]; /* 0x1C Channel n Duty */ + u8 sdn; /* 0x24 Shutdown */ + u8 res3[3]; /* 0x25 - 0x27 */ +#endif /* CONFIG_M5275 */ +#endif /* CONFIG_M5272 */ +} pwm_t; + +#ifdef CONFIG_M5272 + +#define PWM_CR_EN (0x80) +#define PWM_CR_FRC1 (0x40) +#define PWM_CR_LVL (0x20) +#define PWM_CR_CLKSEL(x) ((x) & 0x0F) +#define PWM_CR_CLKSEL_MASK (0xF0) + +#else + +#define PWM_EN_PWMEn(x) (1 << ((x) & 0x07)) +#define PWM_EN_PWMEn_MASK (0xF0) + +#define PWM_POL_PPOLn(x) (1 << ((x) & 0x07)) +#define PWM_POL_PPOLn_MASK (0xF0) + +#define PWM_CLK_PCLKn(x) (1 << ((x) & 0x07)) +#define PWM_CLK_PCLKn_MASK (0xF0) + +#define PWM_PRCLK_PCKB(x) (((x) & 0x07) << 4) +#define PWM_PRCLK_PCKB_MASK (0x8F) +#define PWM_PRCLK_PCKA(x) ((x) & 0x07) +#define PWM_PRCLK_PCKA_MASK (0xF8) + +#define PWM_CLK_PCLKn(x) (1 << ((x) & 0x07)) +#define PWM_CLK_PCLKn_MASK (0xF0) + +#define PWM_CTL_CON67 (0x80) +#define PWM_CTL_CON45 (0x40) +#define PWM_CTL_CON23 (0x20) +#define PWM_CTL_CON01 (0x10) +#define PWM_CTL_PSWAR (0x08) +#define PWM_CTL_PFRZ (0x04) + +#define PWM_SDN_IF (0x80) +#define PWM_SDN_IE (0x40) +#define PWM_SDN_RESTART (0x20) +#define PWM_SDN_LVL (0x10) +#define PWM_SDN_PWM7IN (0x04) +#define PWM_SDN_PWM7IL (0x02) +#define PWM_SDN_SDNEN (0x01) + +#endif /* CONFIG_M5272 */ + +#endif /* __ATA_H__ */ diff --git a/include/asm-m68k/coldfire/qspi.h b/include/asm-m68k/coldfire/qspi.h new file mode 100644 index 0000000..8bcd2e4 --- /dev/null +++ b/include/asm-m68k/coldfire/qspi.h @@ -0,0 +1,111 @@ +/* + * Queue Serial Peripheral Interface Memory Map + * + * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. + * TsiChung Liew (Tsi-Chung.Liew@freescale.com) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __QSPI_H__ +#define __QSPI_H__ + +/* QSPI module registers */ +typedef struct qspi_ctrl { + u16 mr; /* 0x00 Mode */ + u16 res1; + u16 dlyr; /* 0x04 Delay */ + u16 res2; + u16 wr; /* 0x08 Wrap */ + u16 res3; + u16 ir; /* 0x0C Interrupt */ + u16 res4; + u16 ar; /* 0x10 Address */ + u16 res5; + u16 dr; /* 0x14 Data */ + u16 res6; +} qspi_t; + +/* MR */ +#define QSPI_QMR_MSTR (0x8000) +#define QSPI_QMR_DOHIE (0x4000) +#define QSPI_QMR_BITS(x) (((x)&0x000F)<<10) +#define QSPI_QMR_BITS_MASK (0xC3FF) +#define QSPI_QMR_BITS_8 (0x2000) +#define QSPI_QMR_BITS_9 (0x2400) +#define QSPI_QMR_BITS_10 (0x2800) +#define QSPI_QMR_BITS_11 (0x2C00) +#define QSPI_QMR_BITS_12 (0x3000) +#define QSPI_QMR_BITS_13 (0x3400) +#define QSPI_QMR_BITS_14 (0x3800) +#define QSPI_QMR_BITS_15 (0x3C00) +#define QSPI_QMR_BITS_16 (0x0000) +#define QSPI_QMR_CPOL (0x0200) +#define QSPI_QMR_CPHA (0x0100) +#define QSPI_QMR_BAUD(x) ((x)&0x00FF) +#define QSPI_QMR_BAUD_MASK (0xFF00) + +/* DLYR */ +#define QSPI_QDLYR_SPE (0x8000) +#define QSPI_QDLYR_QCD(x) (((x)&0x007F)<<8) +#define QSPI_QDLYR_QCD_MASK (0x80FF) +#define QSPI_QDLYR_DTL(x) ((x)&0x00FF) +#define QSPI_QDLYR_DTL_MASK (0xFF00) + +/* WR */ +#define QSPI_QWR_HALT (0x8000) +#define QSPI_QWR_WREN (0x4000) +#define QSPI_QWR_WRTO (0x2000) +#define QSPI_QWR_CSIV (0x1000) +#define QSPI_QWR_ENDQP(x) (((x)&0x000F)<<8) +#define QSPI_QWR_ENDQP_MASK (0xF0FF) +#define QSPI_QWR_CPTQP(x) (((x)&0x000F)<<4) +#define QSPI_QWR_CPTQP_MASK (0xFF0F) +#define QSPI_QWR_NEWQP(x) ((x)&0x000F) +#define QSPI_QWR_NEWQP_MASK (0xFFF0) + +/* IR */ +#define QSPI_QIR_WCEFB (0x8000) +#define QSPI_QIR_ABRTB (0x4000) +#define QSPI_QIR_ABRTL (0x1000) +#define QSPI_QIR_WCEFE (0x0800) +#define QSPI_QIR_ABRTE (0x0400) +#define QSPI_QIR_SPIFE (0x0100) +#define QSPI_QIR_WCEF (0x0008) +#define QSPI_QIR_ABRT (0x0004) +#define QSPI_QIR_SPIF (0x0001) + +/* AR */ +#define QSPI_QAR_ADDR(x) ((x)&0x003F) +#define QSPI_QAR_ADDR_MASK (0xFFC0) +#define QSPI_QAR_TRANS (0x0000) +#define QSPI_QAR_RECV (0x0010) +#define QSPI_QAR_CMD (0x0020) + +/* DR */ +#define QSPI_QDR_CONT (0x8000) +#define QSPI_QDR_BITSE (0x4000) +#define QSPI_QDR_DT (0x2000) +#define QSPI_QDR_DSCK (0x1000) +#define QSPI_QDR_QSPI_CS3 (0x0800) +#define QSPI_QDR_QSPI_CS2 (0x0400) +#define QSPI_QDR_QSPI_CS1 (0x0200) +#define QSPI_QDR_QSPI_CS0 (0x0100) + +#endif /* __QSPI_H__ */ diff --git a/include/asm-m68k/coldfire/rng.h b/include/asm-m68k/coldfire/rng.h new file mode 100644 index 0000000..1eefc56 --- /dev/null +++ b/include/asm-m68k/coldfire/rng.h @@ -0,0 +1,52 @@ +/* + * RNG Memory Map + * + * Copyright (C) 2004-2008 Freescale Semiconductor, Inc. + * TsiChung Liew (Tsi-Chung.Liew@freescale.com) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __RNG_H__ +#define __RNG_H__ + +/* Random Number Generator */ +typedef struct rng_ctrl { + u32 cr; /* 0x00 Control */ + u32 sr; /* 0x04 Status */ + u32 er; /* 0x08 Entropy */ + u32 out; /* 0x0C Output FIFO */ +} rng_t; + +#define RNG_CR_SLM (0x00000010) /* Sleep mode - 5445x */ +#define RNG_CR_CI (0x00000008) /* Clear interrupt */ +#define RNG_CR_IM (0x00000004) /* Interrupt mask */ +#define RNG_CR_HA (0x00000002) /* High assurance */ +#define RNG_CR_GO (0x00000001) /* Go bit */ + +#define RNG_SR_OFS(x) (((x) & 0x000000FF) << 16) +#define RNG_SR_OFS_MASK (0xFF00FFFF) +#define RNG_SR_OFL(x) (((x) & 0x000000FF) << 8) +#define RNG_SR_OFL_MASK (0xFFFF00FF) +#define RNG_SR_EI (0x00000008) +#define RNG_SR_FUF (0x00000004) +#define RNG_SR_LRS (0x00000002) +#define RNG_SR_SV (0x00000001) + +#endif /* __RNG_H__ */ diff --git a/include/asm-m68k/coldfire/skha.h b/include/asm-m68k/coldfire/skha.h new file mode 100644 index 0000000..bd6b5af --- /dev/null +++ b/include/asm-m68k/coldfire/skha.h @@ -0,0 +1,121 @@ +/* + * Symmetric Key Hardware Accelerator Memory Map + * + * Copyright (C) 2004-2008 Freescale Semiconductor, Inc. + * TsiChung Liew (Tsi-Chung.Liew@freescale.com) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __SKHA_H__ +#define __SKHA_H__ + +typedef struct skha_ctrl { + u32 mr; /* 0x00 Mode */ + u32 cr; /* 0x04 Control */ + u32 cmr; /* 0x08 Command */ + u32 sr; /* 0x0C Status */ + u32 esr; /* 0x10 Error Status */ + u32 emr; /* 0x14 Error Status Mask Register) */ + u32 ksr; /* 0x18 Key Size */ + u32 dsr; /* 0x1C Data Size */ + u32 in; /* 0x20 Input FIFO */ + u32 out; /* 0x24 Output FIFO */ + u32 res1[2]; /* 0x28 - 0x2F */ + u32 kdr1; /* 0x30 Key Data 1 */ + u32 kdr2; /* 0x34 Key Data 2 */ + u32 kdr3; /* 0x38 Key Data 3 */ + u32 kdr4; /* 0x3C Key Data 4 */ + u32 kdr5; /* 0x40 Key Data 5 */ + u32 kdr6; /* 0x44 Key Data 6 */ + u32 res2[10]; /* 0x48 - 0x6F */ + u32 c1; /* 0x70 Context 1 */ + u32 c2; /* 0x74 Context 2 */ + u32 c3; /* 0x78 Context 3 */ + u32 c4; /* 0x7C Context 4 */ + u32 c5; /* 0x80 Context 5 */ + u32 c6; /* 0x84 Context 6 */ + u32 c7; /* 0x88 Context 7 */ + u32 c8; /* 0x8C Context 8 */ + u32 c9; /* 0x90 Context 9 */ + u32 c10; /* 0x94 Context 10 */ + u32 c11; /* 0x98 Context 11 */ + u32 c12; /* 0x9C Context 12 - 5235, 5271, 5272 */ +} skha_t; + +#ifdef CONFIG_MCF532x +#define SKHA_MODE_CTRM(x) (((x) & 0x0F) << 9) +#define SKHA_MODE_CTRM_MASK (0xFFFFE1FF) +#define SKHA_MODE_DKP (0x00000100) +#else +#define SKHA_MODE_CTRM(x) (((x) & 0x0F) << 8) +#define SKHA_MODE_CTRM_MASK (0xFFFFF0FF) +#define SKHA_MODE_DKP (0x00000080) +#endif +#define SKHA_MODE_CM(x) (((x) & 0x03) << 3) +#define SKHA_MODE_CM_MASK (0xFFFFFFE7) +#define SKHA_MODE_DIR (0x00000004) +#define SKHA_MODE_ALG(x) ((x) & 0x03) +#define SKHA_MODE_ALG_MASK (0xFFFFFFFC) + +#define SHKA_CR_ODMAL(x) (((x) & 0x3F) << 24) +#define SHKA_CR_ODMAL_MASK (0xC0FFFFFF) +#define SHKA_CR_IDMAL(x) (((x) & 0x3F) << 16) +#define SHKA_CR_IDMAL_MASK (0xFFC0FFFF) +#define SHKA_CR_END (0x00000008) +#define SHKA_CR_ODMA (0x00000004) +#define SHKA_CR_IDMA (0x00000002) +#define SKHA_CR_IE (0x00000001) + +#define SKHA_CMR_GO (0x00000008) +#define SKHA_CMR_CI (0x00000004) +#define SKHA_CMR_RI (0x00000002) +#define SKHA_CMR_SWR (0x00000001) + +#define SKHA_SR_OFL(x) (((x) & 0xFF) << 24) +#define SKHA_SR_OFL_MASK (0x00FFFFFF) +#define SKHA_SR_IFL(x) (((x) & 0xFF) << 16) +#define SKHA_SR_IFL_MASK (0xFF00FFFF) +#define SKHA_SR_AESES(x) (((x) & 0x1F) << 11) +#define SKHA_SR_AESES_MASK (0xFFFF07FF) +#define SKHA_SR_DESES(x) (((x) & 0x7) << 8) +#define SKHA_SR_DESES_MASK (0xFFFFF8FF) +#define SKHA_SR_BUSY (0x00000010) +#define SKHA_SR_RD (0x00000008) +#define SKHA_SR_ERR (0x00000004) +#define SKHA_SR_DONE (0x00000002) +#define SKHA_SR_INT (0x00000001) + +#define SHKA_ESE_DRL (0x00000800) +#define SKHA_ESR_KRE (0x00000400) +#define SKHA_ESR_KPE (0x00000200) +#define SKHA_ESR_ERE (0x00000100) +#define SKHA_ESR_RMDP (0x00000080) +#define SKHA_ESR_KSE (0x00000040) +#define SKHA_ESR_DSE (0x00000020) +#define SKHA_ESR_IME (0x00000010) +#define SKHA_ESR_NEOF (0x00000008) +#define SKHA_ESR_NEIF (0x00000004) +#define SKHA_ESR_OFU (0x00000002) +#define SKHA_ESR_IFO (0x00000001) + +#define SKHA_KSR_SZ(x) ((x) & 0x3F) +#define SKHA_KSR_SZ_MASK (0xFFFFFFC0) + +#endif /* __SKHA_H__ */ diff --git a/include/asm-m68k/coldfire/ssi.h b/include/asm-m68k/coldfire/ssi.h index 105c475..b3dfbfa 100644 --- a/include/asm-m68k/coldfire/ssi.h +++ b/include/asm-m68k/coldfire/ssi.h @@ -26,10 +26,6 @@ #ifndef __SSI_H__ #define __SSI_H__
-/********************************************************************* -* Synchronous Serial Interface (SSI) -*********************************************************************/ - typedef struct ssi { u32 tx0; u32 tx1; @@ -52,14 +48,10 @@ typedef struct ssi { u32 rmask; } ssi_t;
-/********************************************************************* -* Synchronous Serial Interface (SSI) -*********************************************************************/ - -/* Bit definitions and macros for SSI_CR */ #define SSI_CR_CIS (0x00000200) #define SSI_CR_TCH (0x00000100) #define SSI_CR_MCE (0x00000080) +#define SSI_CR_I2S_MASK (0xFFFFFF9F) #define SSI_CR_I2S_SLAVE (0x00000040) #define SSI_CR_I2S_MASTER (0x00000020) #define SSI_CR_I2S_NORMAL (0x00000000) @@ -69,7 +61,6 @@ typedef struct ssi { #define SSI_CR_TE (0x00000002) #define SSI_CR_SSI_EN (0x00000001)
-/* Bit definitions and macros for SSI_ISR */ #define SSI_ISR_CMDAU (0x00040000) #define SSI_ISR_CMDDU (0x00020000) #define SSI_ISR_RXT (0x00010000) @@ -90,7 +81,6 @@ typedef struct ssi { #define SSI_ISR_TFE1 (0x00000002) #define SSI_ISR_TFE0 (0x00000001)
-/* Bit definitions and macros for SSI_IER */ #define SSI_IER_RDMAE (0x00400000) #define SSI_IER_RIE (0x00200000) #define SSI_IER_TDMAE (0x00100000) @@ -115,7 +105,6 @@ typedef struct ssi { #define SSI_IER_TFE1 (0x00000002) #define SSI_IER_TFE0 (0x00000001)
-/* Bit definitions and macros for SSI_TCR */ #define SSI_TCR_TXBIT0 (0x00000200) #define SSI_TCR_TFEN1 (0x00000100) #define SSI_TCR_TFEN0 (0x00000080) @@ -127,7 +116,6 @@ typedef struct ssi { #define SSI_TCR_TFSL (0x00000002) #define SSI_TCR_TEFS (0x00000001)
-/* Bit definitions and macros for SSI_RCR */ #define SSI_RCR_RXEXT (0x00000400) #define SSI_RCR_RXBIT0 (0x00000200) #define SSI_RCR_RFEN1 (0x00000100) @@ -138,38 +126,44 @@ typedef struct ssi { #define SSI_RCR_RFSL (0x00000002) #define SSI_RCR_REFS (0x00000001)
-/* Bit definitions and macros for SSI_CCR */ #define SSI_CCR_DIV2 (0x00040000) #define SSI_CCR_PSR (0x00020000) -#define SSI_CCR_WL(x) (((x)&0x0000000F)<<13) -#define SSI_CCR_DC(x) (((x)&0x0000001F)<<8) -#define SSI_CCR_PM(x) ((x)&0x000000FF) - -/* Bit definitions and macros for SSI_FCSR */ -#define SSI_FCSR_RFCNT1(x) (((x)&0x0000000F)<<28) -#define SSI_FCSR_TFCNT1(x) (((x)&0x0000000F)<<24) -#define SSI_FCSR_RFWM1(x) (((x)&0x0000000F)<<20) -#define SSI_FCSR_TFWM1(x) (((x)&0x0000000F)<<16) -#define SSI_FCSR_RFCNT0(x) (((x)&0x0000000F)<<12) -#define SSI_FCSR_TFCNT0(x) (((x)&0x0000000F)<<8) -#define SSI_FCSR_RFWM0(x) (((x)&0x0000000F)<<4) -#define SSI_FCSR_TFWM0(x) ((x)&0x0000000F) - -/* Bit definitions and macros for SSI_ACR */ -#define SSI_ACR_FRDIV(x) (((x)&0x0000003F)<<5) +#define SSI_CCR_WL(x) (((x) & 0x0F) << 13) +#define SSI_CCR_WL_MASK (0xFFFE1FFF) +#define SSI_CCR_DC(x) (((x)& 0x1F) << 8) +#define SSI_CCR_DC_MASK (0xFFFFE0FF) +#define SSI_CCR_PM(x) ((x) & 0xFF) +#define SSI_CCR_PM_MASK (0xFFFFFF00) + +#define SSI_FCSR_RFCNT1(x) (((x) & 0x0F) << 28) +#define SSI_FCSR_RFCNT1_MASK (0x0FFFFFFF) +#define SSI_FCSR_TFCNT1(x) (((x) & 0x0F) << 24) +#define SSI_FCSR_TFCNT1_MASK (0xF0FFFFFF) +#define SSI_FCSR_RFWM1(x) (((x) & 0x0F) << 20) +#define SSI_FCSR_RFWM1_MASK (0xFF0FFFFF) +#define SSI_FCSR_TFWM1(x) (((x) & 0x0F) << 16) +#define SSI_FCSR_TFWM1_MASK (0xFFF0FFFF) +#define SSI_FCSR_RFCNT0(x) (((x) & 0x0F) << 12) +#define SSI_FCSR_RFCNT0_MASK (0xFFFF0FFF) +#define SSI_FCSR_TFCNT0(x) (((x) & 0x0F) << 8) +#define SSI_FCSR_TFCNT0_MASK (0xFFFFF0FF) +#define SSI_FCSR_RFWM0(x) (((x) & 0x0F) << 4) +#define SSI_FCSR_RFWM0_MASK (0xFFFFFF0F) +#define SSI_FCSR_TFWM0(x) ((x) & 0x0F) +#define SSI_FCSR_TFWM0_MASK (0xFFFFFFF0) + +#define SSI_ACR_FRDIV(x) (((x) & 0x3F) << 5) +#define SSI_ACR_FRDIV_MASK (0xFFFFF81F) #define SSI_ACR_WR (0x00000010) #define SSI_ACR_RD (0x00000008) #define SSI_ACR_TIF (0x00000004) #define SSI_ACR_FV (0x00000002) #define SSI_ACR_AC97EN (0x00000001)
-/* Bit definitions and macros for SSI_ACADD */ -#define SSI_ACADD_SSI_ACADD(x) ((x)&0x0007FFFF) +#define SSI_ACADD_SSI_ACADD(x) ((x) & 0x0007FFFF)
-/* Bit definitions and macros for SSI_ACDAT */ -#define SSI_ACDAT_SSI_ACDAT(x) ((x)&0x0007FFFF) +#define SSI_ACDAT_SSI_ACDAT(x) ((x) & 0x0007FFFF)
-/* Bit definitions and macros for SSI_ATAG */ -#define SSI_ATAG_DDI_ATAG(x) ((x)&0x0000FFFF) +#define SSI_ATAG_DDI_ATAG(x) ((x) & 0x0000FFFF)
#endif /* __SSI_H__ */ diff --git a/include/asm-m68k/immap_5227x.h b/include/asm-m68k/immap_5227x.h index 83da3d5..6f65f50 100644 --- a/include/asm-m68k/immap_5227x.h +++ b/include/asm-m68k/immap_5227x.h @@ -69,109 +69,14 @@ #include <asm/coldfire/crossbar.h> #include <asm/coldfire/dspi.h> #include <asm/coldfire/edma.h> +#include <asm/coldfire/eport.h> #include <asm/coldfire/flexbus.h> +#include <asm/coldfire/flexcan.h> +#include <asm/coldfire/intctrl.h> #include <asm/coldfire/lcd.h> +#include <asm/coldfire/pwm.h> #include <asm/coldfire/ssi.h>
-/* Interrupt Controller (INTC) */ -typedef struct int0_ctrl { - u32 iprh0; /* 0x00 Pending Register High */ - u32 iprl0; /* 0x04 Pending Register Low */ - u32 imrh0; /* 0x08 Mask Register High */ - u32 imrl0; /* 0x0C Mask Register Low */ - u32 frch0; /* 0x10 Force Register High */ - u32 frcl0; /* 0x14 Force Register Low */ - u16 res1; /* 0x18 - 0x19 */ - u16 icfg0; /* 0x1A Configuration Register */ - u8 simr0; /* 0x1C Set Interrupt Mask */ - u8 cimr0; /* 0x1D Clear Interrupt Mask */ - u8 clmask0; /* 0x1E Current Level Mask */ - u8 slmask; /* 0x1F Saved Level Mask */ - u32 res2[8]; /* 0x20 - 0x3F */ - u8 icr0[64]; /* 0x40 - 0x7F Control registers */ - u32 res3[24]; /* 0x80 - 0xDF */ - u8 swiack0; /* 0xE0 Software Interrupt ack */ - u8 res4[3]; /* 0xE1 - 0xE3 */ - u8 Lniack0_1; /* 0xE4 Level n interrupt ack */ - u8 res5[3]; /* 0xE5 - 0xE7 */ - u8 Lniack0_2; /* 0xE8 Level n interrupt ack */ - u8 res6[3]; /* 0xE9 - 0xEB */ - u8 Lniack0_3; /* 0xEC Level n interrupt ack */ - u8 res7[3]; /* 0xED - 0xEF */ - u8 Lniack0_4; /* 0xF0 Level n interrupt ack */ - u8 res8[3]; /* 0xF1 - 0xF3 */ - u8 Lniack0_5; /* 0xF4 Level n interrupt ack */ - u8 res9[3]; /* 0xF5 - 0xF7 */ - u8 Lniack0_6; /* 0xF8 Level n interrupt ack */ - u8 resa[3]; /* 0xF9 - 0xFB */ - u8 Lniack0_7; /* 0xFC Level n interrupt ack */ - u8 resb[3]; /* 0xFD - 0xFF */ -} int0_t; - -typedef struct int1_ctrl { - /* Interrupt Controller 1 */ - u32 iprh1; /* 0x00 Pending Register High */ - u32 iprl1; /* 0x04 Pending Register Low */ - u32 imrh1; /* 0x08 Mask Register High */ - u32 imrl1; /* 0x0C Mask Register Low */ - u32 frch1; /* 0x10 Force Register High */ - u32 frcl1; /* 0x14 Force Register Low */ - u16 res1; /* 0x18 */ - u16 icfg1; /* 0x1A Configuration Register */ - u8 simr1; /* 0x1C Set Interrupt Mask */ - u8 cimr1; /* 0x1D Clear Interrupt Mask */ - u16 res2; /* 0x1E - 0x1F */ - u32 res3[8]; /* 0x20 - 0x3F */ - u8 icr1[64]; /* 0x40 - 0x7F */ - u32 res4[24]; /* 0x80 - 0xDF */ - u8 swiack1; /* 0xE0 Software Interrupt ack */ - u8 res5[3]; /* 0xE1 - 0xE3 */ - u8 Lniack1_1; /* 0xE4 Level n interrupt ack */ - u8 res6[3]; /* 0xE5 - 0xE7 */ - u8 Lniack1_2; /* 0xE8 Level n interrupt ack */ - u8 res7[3]; /* 0xE9 - 0xEB */ - u8 Lniack1_3; /* 0xEC Level n interrupt ack */ - u8 res8[3]; /* 0xED - 0xEF */ - u8 Lniack1_4; /* 0xF0 Level n interrupt ack */ - u8 res9[3]; /* 0xF1 - 0xF3 */ - u8 Lniack1_5; /* 0xF4 Level n interrupt ack */ - u8 resa[3]; /* 0xF5 - 0xF7 */ - u8 Lniack1_6; /* 0xF8 Level n interrupt ack */ - u8 resb[3]; /* 0xF9 - 0xFB */ - u8 Lniack1_7; /* 0xFC Level n interrupt ack */ - u8 resc[3]; /* 0xFD - 0xFF */ -} int1_t; - -/* Global Interrupt Acknowledge (IACK) */ -typedef struct iack { - u8 resv0[0xE0]; - u8 gswiack; - u8 resv1[0x3]; - u8 gl1iack; - u8 resv2[0x3]; - u8 gl2iack; - u8 resv3[0x3]; - u8 gl3iack; - u8 resv4[0x3]; - u8 gl4iack; - u8 resv5[0x3]; - u8 gl5iack; - u8 resv6[0x3]; - u8 gl6iack; - u8 resv7[0x3]; - u8 gl7iack; -} iack_t; - -/* Edge Port Module (EPORT) */ -typedef struct eport { - u16 eppar; - u8 epddr; - u8 epier; - u8 epdr; - u8 eppdr; - u8 epfr; -} eport_t; - /* Reset Controller Module (RCM) */ typedef struct rcm { u8 rcr; @@ -193,6 +98,12 @@ typedef struct ccm { u16 sbfcr; /* Serial Boot Control */ } ccm_t;
+typedef struct canex_ctrl { + can_msg_t msg[16]; /* 0x00 Message Buffer 0-15 */ + u32 res0[0x700]; /* 0x100 */ + can_msg_t rxim[16]; /* 0x800 Rx Individual Mask 0-15 */ +} canex_t; + /* General Purpose I/O Module (GPIO) */ typedef struct gpio { /* Port Output Data Registers */ diff --git a/include/asm-m68k/immap_5235.h b/include/asm-m68k/immap_5235.h index 3ef0321..f7f35fc 100644 --- a/include/asm-m68k/immap_5235.h +++ b/include/asm-m68k/immap_5235.h @@ -63,6 +63,15 @@ #define MMAP_ETPU (CONFIG_SYS_MBAR + 0x001D0000) #define MMAP_CAN2 (CONFIG_SYS_MBAR + 0x001F0000)
+#include <asm/coldfire/eport.h> +#include <asm/coldfire/flexbus.h> +#include <asm/coldfire/flexcan.h> +#include <asm/coldfire/intctrl.h> +#include <asm/coldfire/mdha.h> +#include <asm/coldfire/qspi.h> +#include <asm/coldfire/rng.h> +#include <asm/coldfire/skha.h> + /* System Control Module register */ typedef struct scm_ctrl { u32 ipsbar; /* 0x00 - MBAR */ @@ -104,141 +113,9 @@ typedef struct sdram_ctrl { u32 dmr1; /* 0x14 mask register block 1 */ } sdram_t;
-/* Flexbus module Chip select registers */ -typedef struct fbcs_ctrl { - u16 csar0; /* 0x00 Chip-Select Address Register 0 */ - u16 res0; - u32 csmr0; /* 0x04 Chip-Select Mask Register 0 */ - u16 res1; /* 0x08 */ - u16 cscr0; /* 0x0A Chip-Select Control Register 0 */ - - u16 csar1; /* 0x0C Chip-Select Address Register 1 */ - u16 res2; - u32 csmr1; /* 0x10 Chip-Select Mask Register 1 */ - u16 res3; /* 0x14 */ - u16 cscr1; /* 0x16 Chip-Select Control Register 1 */ - - u16 csar2; /* 0x18 Chip-Select Address Register 2 */ - u16 res4; - u32 csmr2; /* 0x1C Chip-Select Mask Register 2 */ - u16 res5; /* 0x20 */ - u16 cscr2; /* 0x22 Chip-Select Control Register 2 */ - - u16 csar3; /* 0x24 Chip-Select Address Register 3 */ - u16 res6; - u32 csmr3; /* 0x28 Chip-Select Mask Register 3 */ - u16 res7; /* 0x2C */ - u16 cscr3; /* 0x2E Chip-Select Control Register 3 */ - - u16 csar4; /* 0x30 Chip-Select Address Register 4 */ - u16 res8; - u32 csmr4; /* 0x34 Chip-Select Mask Register 4 */ - u16 res9; /* 0x38 */ - u16 cscr4; /* 0x3A Chip-Select Control Register 4 */ - - u16 csar5; /* 0x3C Chip-Select Address Register 5 */ - u16 res10; - u32 csmr5; /* 0x40 Chip-Select Mask Register 5 */ - u16 res11; /* 0x44 */ - u16 cscr5; /* 0x46 Chip-Select Control Register 5 */ - - u16 csar6; /* 0x48 Chip-Select Address Register 5 */ - u16 res12; - u32 csmr6; /* 0x4C Chip-Select Mask Register 5 */ - u16 res13; /* 0x50 */ - u16 cscr6; /* 0x52 Chip-Select Control Register 5 */ - - u16 csar7; /* 0x54 Chip-Select Address Register 5 */ - u16 res14; - u32 csmr7; /* 0x58 Chip-Select Mask Register 5 */ - u16 res15; /* 0x5C */ - u16 cscr7; /* 0x5E Chip-Select Control Register 5 */ -} fbcs_t; - -/* QSPI module registers */ -typedef struct qspi_ctrl { - u16 qmr; /* Mode register */ - u16 res1; - u16 qdlyr; /* Delay register */ - u16 res2; - u16 qwr; /* Wrap register */ - u16 res3; - u16 qir; /* Interrupt register */ - u16 res4; - u16 qar; /* Address register */ - u16 res5; - u16 qdr; /* Data register */ - u16 res6; -} qspi_t; - -/* Interrupt module registers */ -typedef struct int0_ctrl { - /* Interrupt Controller 0 */ - u32 iprh0; /* 0x00 Pending Register High */ - u32 iprl0; /* 0x04 Pending Register Low */ - u32 imrh0; /* 0x08 Mask Register High */ - u32 imrl0; /* 0x0C Mask Register Low */ - u32 frch0; /* 0x10 Force Register High */ - u32 frcl0; /* 0x14 Force Register Low */ - u8 irlr; /* 0x18 */ - u8 iacklpr; /* 0x19 */ - u16 res1[19]; /* 0x1a - 0x3c */ - u8 icr0[64]; /* 0x40 - 0x7F Control registers */ - u32 res3[24]; /* 0x80 - 0xDF */ - u8 swiack0; /* 0xE0 Software Interrupt Acknowledge */ - u8 res4[3]; /* 0xE1 - 0xE3 */ - u8 Lniack0_1; /* 0xE4 Level n interrupt acknowledge resister */ - u8 res5[3]; /* 0xE5 - 0xE7 */ - u8 Lniack0_2; /* 0xE8 Level n interrupt acknowledge resister */ - u8 res6[3]; /* 0xE9 - 0xEB */ - u8 Lniack0_3; /* 0xEC Level n interrupt acknowledge resister */ - u8 res7[3]; /* 0xED - 0xEF */ - u8 Lniack0_4; /* 0xF0 Level n interrupt acknowledge resister */ - u8 res8[3]; /* 0xF1 - 0xF3 */ - u8 Lniack0_5; /* 0xF4 Level n interrupt acknowledge resister */ - u8 res9[3]; /* 0xF5 - 0xF7 */ - u8 Lniack0_6; /* 0xF8 Level n interrupt acknowledge resister */ - u8 resa[3]; /* 0xF9 - 0xFB */ - u8 Lniack0_7; /* 0xFC Level n interrupt acknowledge resister */ - u8 resb[3]; /* 0xFD - 0xFF */ -} int0_t; - -typedef struct int1_ctrl { - /* Interrupt Controller 1 */ - u32 iprh1; /* 0x00 Pending Register High */ - u32 iprl1; /* 0x04 Pending Register Low */ - u32 imrh1; /* 0x08 Mask Register High */ - u32 imrl1; /* 0x0C Mask Register Low */ - u32 frch1; /* 0x10 Force Register High */ - u32 frcl1; /* 0x14 Force Register Low */ - u8 irlr; /* 0x18 */ - u8 iacklpr; /* 0x19 */ - u16 res1[19]; /* 0x1a - 0x3c */ - u8 icr1[64]; /* 0x40 - 0x7F */ - u32 res4[24]; /* 0x80 - 0xDF */ - u8 swiack1; /* 0xE0 Software Interrupt Acknowledge */ - u8 res5[3]; /* 0xE1 - 0xE3 */ - u8 Lniack1_1; /* 0xE4 Level n interrupt acknowledge resister */ - u8 res6[3]; /* 0xE5 - 0xE7 */ - u8 Lniack1_2; /* 0xE8 Level n interrupt acknowledge resister */ - u8 res7[3]; /* 0xE9 - 0xEB */ - u8 Lniack1_3; /* 0xEC Level n interrupt acknowledge resister */ - u8 res8[3]; /* 0xED - 0xEF */ - u8 Lniack1_4; /* 0xF0 Level n interrupt acknowledge resister */ - u8 res9[3]; /* 0xF1 - 0xF3 */ - u8 Lniack1_5; /* 0xF4 Level n interrupt acknowledge resister */ - u8 resa[3]; /* 0xF5 - 0xF7 */ - u8 Lniack1_6; /* 0xF8 Level n interrupt acknowledge resister */ - u8 resb[3]; /* 0xF9 - 0xFB */ - u8 Lniack1_7; /* 0xFC Level n interrupt acknowledge resister */ - u8 resc[3]; /* 0xFD - 0xFF */ -} int1_t; - -typedef struct intgack_ctrl1 { - /* Global IACK Registers */ - u8 swiack; /* 0xE0 Global Software Interrupt Acknowledge */ - u8 Lniack[7]; /* 0xE1 - 0xE7 Global Level 0 Interrupt Acknowledge */ -} intgack_t; +typedef struct canex_ctrl { + can_msg_t msg[16]; /* 0x00 Message Buffer 0-15 */ +} canex_t;
/* GPIO port registers */ typedef struct gpio_ctrl { @@ -356,23 +233,4 @@ typedef struct wdog_ctrl { u16 sr; /* 0x06 Service register */ } wdog_t;
-/* FlexCan module registers */ -typedef struct can_ctrl { - u32 mcr; /* 0x00 Module Configuration register */ - u32 ctrl; /* 0x04 Control register */ - u32 timer; /* 0x08 Free Running Timer */ - u32 res1; /* 0x0C */ - u32 rxgmask; /* 0x10 Rx Global Mask */ - u32 rx14mask; /* 0x14 RxBuffer 14 Mask */ - u32 rx15mask; /* 0x18 RxBuffer 15 Mask */ - u32 errcnt; /* 0x1C Error Counter Register */ - u32 errstat; /* 0x20 Error and status Register */ - u32 res2; /* 0x24 */ - u32 imask; /* 0x28 Interrupt Mask Register */ - u32 res3; /* 0x2C */ - u32 iflag; /* 0x30 Interrupt Flag Register */ - u32 res4[19]; /* 0x34 - 0x7F */ - u32 MB0_15[2048]; /* 0x80 Message Buffer 0-15 */ -} can_t; - #endif /* __IMMAP_5235__ */ diff --git a/include/asm-m68k/immap_5249.h b/include/asm-m68k/immap_5249.h index 6b57ba7..0242086 100644 --- a/include/asm-m68k/immap_5249.h +++ b/include/asm-m68k/immap_5249.h @@ -26,10 +26,14 @@ #define __IMMAP_5249__
#define MMAP_INTC (CONFIG_SYS_MBAR + 0x00000040) +#define MMAP_FBCS (CONFIG_SYS_MBAR + 0x00000080) #define MMAP_DTMR0 (CONFIG_SYS_MBAR + 0x00000140) #define MMAP_DTMR1 (CONFIG_SYS_MBAR + 0x00000180) #define MMAP_UART0 (CONFIG_SYS_MBAR + 0x000001C0) #define MMAP_UART1 (CONFIG_SYS_MBAR + 0x00000200) #define MMAP_QSPI (CONFIG_SYS_MBAR + 0x00000400)
+#include <asm/coldfire/flexbus.h> +#include <asm/coldfire/qspi.h> + #endif /* __IMMAP_5249__ */ diff --git a/include/asm-m68k/immap_5253.h b/include/asm-m68k/immap_5253.h index 4e3a481..b5a4cb5 100644 --- a/include/asm-m68k/immap_5253.h +++ b/include/asm-m68k/immap_5253.h @@ -23,10 +23,11 @@ * MA 02111-1307 USA */
-#ifndef __IMMAP_5249__ -#define __IMMAP_5249__ +#ifndef __IMMAP_5253__ +#define __IMMAP_5253__
#define MMAP_INTC (CONFIG_SYS_MBAR + 0x00000040) +#define MMAP_FBCS (CONFIG_SYS_MBAR + 0x00000080) #define MMAP_DTMR0 (CONFIG_SYS_MBAR + 0x00000140) #define MMAP_DTMR1 (CONFIG_SYS_MBAR + 0x00000180) #define MMAP_UART0 (CONFIG_SYS_MBAR + 0x000001C0) @@ -39,57 +40,13 @@ #define MMAP_I2C1 (CONFIG_SYS_MBAR2 + 0x00000440) #define MMAP_UART2 (CONFIG_SYS_MBAR2 + 0x00000C00)
-/********************************************************************* -* ATA Module (ATAC) -*********************************************************************/ +#include <asm/coldfire/ata.h> +#include <asm/coldfire/flexbus.h> +#include <asm/coldfire/flexcan.h> +#include <asm/coldfire/qspi.h>
-/* Register read/write struct */ -typedef struct atac { - /* PIO */ - u8 toff; /* 0x00 */ - u8 ton; /* 0x01 */ - u8 t1; /* 0x02 */ - u8 t2w; /* 0x03 */ - u8 t2r; /* 0x04 */ - u8 ta; /* 0x05 */ - u8 trd; /* 0x06 */ - u8 t4; /* 0x07 */ - u8 t9; /* 0x08 */ +typedef struct canex_ctrl { + can_msg_t msg[32]; /* 0x80 Message Buffer 0-31 */ +} canex_t;
- /* DMA */ - u8 tm; /* 0x09 */ - u8 tn; /* 0x0A */ - u8 td; /* 0x0B */ - u8 tk; /* 0x0C */ - u8 tack; /* 0x0D */ - u8 tenv; /* 0x0E */ - u8 trp; /* 0x0F */ - u8 tzah; /* 0x10 */ - u8 tmli; /* 0x11 */ - u8 tdvh; /* 0x12 */ - u8 tdzfs; /* 0x13 */ - u8 tdvs; /* 0x14 */ - u8 tcvh; /* 0x15 */ - u8 tss; /* 0x16 */ - u8 tcyc; /* 0x17 */ - - /* FIFO */ - u32 fifo32; /* 0x18 */ - u16 fifo16; /* 0x1C */ - u8 rsvd0[2]; - u8 ffill; /* 0x20 */ - u8 rsvd1[3]; - - /* ATA */ - u8 cr; /* 0x24 */ - u8 rsvd2[3]; - u8 isr; /* 0x28 */ - u8 rsvd3[3]; - u8 ier; /* 0x2C */ - u8 rsvd4[3]; - u8 icr; /* 0x30 */ - u8 rsvd5[3]; - u8 falarm; /* 0x34 */ -} atac_t; - -#endif /* __IMMAP_5249__ */ +#endif /* __IMMAP_5253__ */ diff --git a/include/asm-m68k/immap_5271.h b/include/asm-m68k/immap_5271.h index 462d5f2..8ddec5c 100644 --- a/include/asm-m68k/immap_5271.h +++ b/include/asm-m68k/immap_5271.h @@ -63,36 +63,13 @@ #define MMAP_ETPU (CONFIG_SYS_MBAR + 0x001D0000) #define MMAP_CAN2 (CONFIG_SYS_MBAR + 0x001F0000)
-/* Interrupt module registers */ -typedef struct int0_ctrl { - /* Interrupt Controller 0 */ - u32 iprh0; /* 0x00 Pending Register High */ - u32 iprl0; /* 0x04 Pending Register Low */ - u32 imrh0; /* 0x08 Mask Register High */ - u32 imrl0; /* 0x0C Mask Register Low */ - u32 frch0; /* 0x10 Force Register High */ - u32 frcl0; /* 0x14 Force Register Low */ - u8 irlr; /* 0x18 */ - u8 iacklpr; /* 0x19 */ - u16 res1[19]; /* 0x1a - 0x3c */ - u8 icr0[64]; /* 0x40 - 0x7F Control registers */ - u32 res3[24]; /* 0x80 - 0xDF */ - u8 swiack0; /* 0xE0 Software Interrupt Acknowledge */ - u8 res4[3]; /* 0xE1 - 0xE3 */ - u8 Lniack0_1; /* 0xE4 Level n interrupt acknowledge resister */ - u8 res5[3]; /* 0xE5 - 0xE7 */ - u8 Lniack0_2; /* 0xE8 Level n interrupt acknowledge resister */ - u8 res6[3]; /* 0xE9 - 0xEB */ - u8 Lniack0_3; /* 0xEC Level n interrupt acknowledge resister */ - u8 res7[3]; /* 0xED - 0xEF */ - u8 Lniack0_4; /* 0xF0 Level n interrupt acknowledge resister */ - u8 res8[3]; /* 0xF1 - 0xF3 */ - u8 Lniack0_5; /* 0xF4 Level n interrupt acknowledge resister */ - u8 res9[3]; /* 0xF5 - 0xF7 */ - u8 Lniack0_6; /* 0xF8 Level n interrupt acknowledge resister */ - u8 resa[3]; /* 0xF9 - 0xFB */ - u8 Lniack0_7; /* 0xFC Level n interrupt acknowledge resister */ - u8 resb[3]; /* 0xFD - 0xFF */ -} int0_t; +#include <asm/coldfire/eport.h> +#include <asm/coldfire/flexbus.h> +#include <asm/coldfire/intctrl.h> +#include <asm/coldfire/mdha.h> +#include <asm/coldfire/qspi.h> +#include <asm/coldfire/rng.h> +#include <asm/coldfire/skha.h> +
#endif /* __IMMAP_5271__ */ diff --git a/include/asm-m68k/immap_5272.h b/include/asm-m68k/immap_5272.h index b106289..8d4254b 100644 --- a/include/asm-m68k/immap_5272.h +++ b/include/asm-m68k/immap_5272.h @@ -44,6 +44,8 @@ #define MMAP_FEC (CONFIG_SYS_MBAR + 0x00000840) #define MMAP_USB (CONFIG_SYS_MBAR + 0x00001000)
+#include <asm/coldfire/pwm.h> + /* System configuration registers */ typedef struct sys_ctrl { uint sc_mbar; @@ -104,38 +106,6 @@ typedef struct gpio_ctrl { uchar res2[4]; } gpio_t;
-/* QSPI module registers */ -typedef struct qspi_ctrl { - ushort qspi_qmr; - uchar res1[2]; - ushort qspi_qdlyr; - uchar res2[2]; - ushort qspi_qwr; - uchar res3[2]; - ushort qspi_qir; - uchar res4[2]; - ushort qspi_qar; - uchar res5[2]; - ushort qspi_qdr; - uchar res6[10]; -} qspi_t; - -/* PWM module registers */ -typedef struct pwm_ctrl { - uchar pwm_pwcr0; - uchar res1[3]; - uchar pwm_pwcr1; - uchar res2[3]; - uchar pwm_pwcr2; - uchar res3[7]; - uchar pwm_pwwd0; - uchar res4[3]; - uchar pwm_pwwd1; - uchar res5[3]; - uchar pwm_pwwd2; - uchar res6[7]; -} pwm_t; - /* DMA module registers */ typedef struct dma_ctrl { ulong dma_dmr; diff --git a/include/asm-m68k/immap_5275.h b/include/asm-m68k/immap_5275.h index 495010b..46426a3 100644 --- a/include/asm-m68k/immap_5275.h +++ b/include/asm-m68k/immap_5275.h @@ -66,6 +66,15 @@ #define MMAP_USB (CONFIG_SYS_MBAR + 0x001C0000) #define MMAP_PWM0 (CONFIG_SYS_MBAR + 0x001D0000)
+#include <asm/coldfire/eport.h> +#include <asm/coldfire/flexbus.h> +#include <asm/coldfire/intctrl.h> +#include <asm/coldfire/mdha.h> +#include <asm/coldfire/pwm.h> +#include <asm/coldfire/qspi.h> +#include <asm/coldfire/rng.h> +#include <asm/coldfire/skha.h> + /* System configuration registers */ typedef struct sys_ctrl { @@ -109,51 +118,6 @@ typedef struct sdram_ctrl { u32 sdbmr1; } sdramctrl_t;
-/* Chip select module registers, offset: 0x080 -*/ -typedef struct cs_ctlr { - u16 ar0; - u16 res1; - u32 mr0; - u16 res2; - u16 cr0; - u16 ar1; - u16 res3; - u32 mr1; - u16 res4; - u16 cr1; - u16 ar2; - u16 res5; - u32 mr2; - u16 res6; - u16 cr2; - u16 ar3; - u16 res7; - u32 mr3; - u16 res8; - u16 cr3; - u16 ar4; - u16 res9; - u32 mr4; - u16 res10; - u16 cr4; - u16 ar5; - u16 res11; - u32 mr5; - u16 res12; - u16 cr5; - u16 ar6; - u16 res13; - u32 mr6; - u16 res14; - u16 cr6; - u16 ar7; - u16 res15; - u32 mr7; - u16 res16; - u16 cr7; -} csctrl_t; - /* DMA module registers, offset 0x100 */ typedef struct dma_ctrl { @@ -163,55 +127,6 @@ typedef struct dma_ctrl { u32 dcr; } dma_t;
-/* QSPI module registers, offset 0x340 - */ -typedef struct qspi_ctrl { - u16 qmr; - u8 res1[2]; - u16 qdlyr; - u8 res2[2]; - u16 qwr; - u8 res3[2]; - u16 qir; - u8 res4[2]; - u16 qar; - u8 res5[2]; - u16 qdr; - u8 res6[2]; -} qspi_t; - -/* Interrupt module registers, offset 0xc00 -*/ -typedef struct int_ctrl { - u32 iprh0; - u32 iprl0; - u32 imrh0; - u32 imrl0; - u32 frch0; - u32 frcl0; - u8 irlr; - u8 iacklpr; - u8 res1[0x26]; - u8 icr0[64]; /* No ICR0, done this way for readability */ - u8 res2[0x60]; - u8 swiack0; - u8 res3[3]; - u8 Lniack0_1; - u8 res4[3]; - u8 Lniack0_2; - u8 res5[3]; - u8 Lniack0_3; - u8 res6[3]; - u8 Lniack0_4; - u8 res7[3]; - u8 Lniack0_5; - u8 res8[3]; - u8 Lniack0_6; - u8 res9[3]; - u8 Lniack0_7; - u8 res10[3]; -} int0_t; - /* GPIO port registers */ typedef struct gpio_ctrl { @@ -325,23 +240,6 @@ typedef struct gpio_ctrl { } gpio_t;
-/* PWM module registers - */ -typedef struct pwm_ctrl { - u8 pwcr0; - u8 res1[3]; - u8 pwcr1; - u8 res2[3]; - u8 pwcr2; - u8 res3[7]; - u8 pwwd0; - u8 res4[3]; - u8 pwwd1; - u8 res5[3]; - u8 pwwd2; - u8 res6[7]; -} pwm_t; - /* Watchdog registers */ typedef struct wdog_ctrl { diff --git a/include/asm-m68k/immap_5282.h b/include/asm-m68k/immap_5282.h index e96463b..dd526a1 100644 --- a/include/asm-m68k/immap_5282.h +++ b/include/asm-m68k/immap_5282.h @@ -62,6 +62,12 @@ #define MMAP_CFMC (CONFIG_SYS_MBAR + 0x001D0000) #define MMAP_CFMMEM (CONFIG_SYS_MBAR + 0x04000000)
+#include <asm/coldfire/eport.h> +#include <asm/coldfire/flexbus.h> +#include <asm/coldfire/flexcan.h> +#include <asm/coldfire/intctrl.h> +#include <asm/coldfire/qspi.h> + /* System Control Module */ typedef struct scm_ctrl { u32 ipsbar; @@ -92,88 +98,9 @@ typedef struct scm_ctrl { u16 res8; } scm_t;
-/* Flexbus module Chip select registers */ -typedef struct fbcs_ctrl { - u16 csar0; /* 0x00 Chip-Select Address Register 0 */ - u16 res0; - u32 csmr0; /* 0x04 Chip-Select Mask Register 0 */ - u16 res1; /* 0x08 */ - u16 cscr0; /* 0x0A Chip-Select Control Register 0 */ - - u16 csar1; /* 0x0C Chip-Select Address Register 1 */ - u16 res2; - u32 csmr1; /* 0x10 Chip-Select Mask Register 1 */ - u16 res3; /* 0x14 */ - u16 cscr1; /* 0x16 Chip-Select Control Register 1 */ - - u16 csar2; /* 0x18 Chip-Select Address Register 2 */ - u16 res4; - u32 csmr2; /* 0x1C Chip-Select Mask Register 2 */ - u16 res5; /* 0x20 */ - u16 cscr2; /* 0x22 Chip-Select Control Register 2 */ - - u16 csar3; /* 0x24 Chip-Select Address Register 3 */ - u16 res6; - u32 csmr3; /* 0x28 Chip-Select Mask Register 3 */ - u16 res7; /* 0x2C */ - u16 cscr3; /* 0x2E Chip-Select Control Register 3 */ - - u16 csar4; /* 0x30 Chip-Select Address Register 4 */ - u16 res8; - u32 csmr4; /* 0x34 Chip-Select Mask Register 4 */ - u16 res9; /* 0x38 */ - u16 cscr4; /* 0x3A Chip-Select Control Register 4 */ - - u16 csar5; /* 0x3C Chip-Select Address Register 5 */ - u16 res10; - u32 csmr5; /* 0x40 Chip-Select Mask Register 5 */ - u16 res11; /* 0x44 */ - u16 cscr5; /* 0x46 Chip-Select Control Register 5 */ - - u16 csar6; /* 0x48 Chip-Select Address Register 5 */ - u16 res12; - u32 csmr6; /* 0x4C Chip-Select Mask Register 5 */ - u16 res13; /* 0x50 */ - u16 cscr6; /* 0x52 Chip-Select Control Register 5 */ - - u16 csar7; /* 0x54 Chip-Select Address Register 5 */ - u16 res14; - u32 csmr7; /* 0x58 Chip-Select Mask Register 5 */ - u16 res15; /* 0x5C */ - u16 cscr7; /* 0x5E Chip-Select Control Register 5 */ -} fbcs_t; - -/* Interrupt module registers */ -typedef struct int0_ctrl { - /* Interrupt Controller 0 */ - u32 iprh0; /* 0x00 Pending Register High */ - u32 iprl0; /* 0x04 Pending Register Low */ - u32 imrh0; /* 0x08 Mask Register High */ - u32 imrl0; /* 0x0C Mask Register Low */ - u32 frch0; /* 0x10 Force Register High */ - u32 frcl0; /* 0x14 Force Register Low */ - u8 irlr; /* 0x18 */ - u8 iacklpr; /* 0x19 */ - u16 res1[19]; /* 0x1a - 0x3c */ - u8 icr0[64]; /* 0x40 - 0x7F Control registers */ - u32 res3[24]; /* 0x80 - 0xDF */ - u8 swiack0; /* 0xE0 Software Interrupt Acknowledge */ - u8 res4[3]; /* 0xE1 - 0xE3 */ - u8 Lniack0_1; /* 0xE4 Level n interrupt acknowledge resister */ - u8 res5[3]; /* 0xE5 - 0xE7 */ - u8 Lniack0_2; /* 0xE8 Level n interrupt acknowledge resister */ - u8 res6[3]; /* 0xE9 - 0xEB */ - u8 Lniack0_3; /* 0xEC Level n interrupt acknowledge resister */ - u8 res7[3]; /* 0xED - 0xEF */ - u8 Lniack0_4; /* 0xF0 Level n interrupt acknowledge resister */ - u8 res8[3]; /* 0xF1 - 0xF3 */ - u8 Lniack0_5; /* 0xF4 Level n interrupt acknowledge resister */ - u8 res9[3]; /* 0xF5 - 0xF7 */ - u8 Lniack0_6; /* 0xF8 Level n interrupt acknowledge resister */ - u8 resa[3]; /* 0xF9 - 0xFB */ - u8 Lniack0_7; /* 0xFC Level n interrupt acknowledge resister */ - u8 resb[3]; /* 0xFD - 0xFF */ -} int0_t; +typedef struct canex_ctrl { + can_msg_t msg[16]; /* 0x00 Message Buffer 0-15 */ +} canex_t;
/* Clock Module registers */ typedef struct pll_ctrl { diff --git a/include/asm-m68k/immap_5329.h b/include/asm-m68k/immap_5329.h index 7678406..4f255c6 100644 --- a/include/asm-m68k/immap_5329.h +++ b/include/asm-m68k/immap_5329.h @@ -70,9 +70,16 @@
#include <asm/coldfire/crossbar.h> #include <asm/coldfire/edma.h> +#include <asm/coldfire/eport.h> +#include <asm/coldfire/qspi.h> #include <asm/coldfire/flexbus.h> +#include <asm/coldfire/flexcan.h> +#include <asm/coldfire/intctrl.h> #include <asm/coldfire/lcd.h> +#include <asm/coldfire/mdha.h> +#include <asm/coldfire/pwm.h> #include <asm/coldfire/ssi.h> +#include <asm/coldfire/skha.h>
/* System control module registers */ typedef struct scm1_ctrl { @@ -83,72 +90,6 @@ typedef struct scm1_ctrl { u32 bmt0; /*0x54 Bus Monitor Timeout 0 */ } scm1_t;
-/* Message Digest Hardware Accelerator */ -typedef struct mdha_ctrl { - u32 mdmr; /* 0x00 MDHA Mode Register */ - u32 mdcr; /* 0x04 Control register */ - u32 mdcmr; /* 0x08 Command Register */ - u32 mdsr; /* 0x0C Status Register */ - u32 mdisr; /* 0x10 Interrupt Status Register */ - u32 mdimr; /* 0x14 Interrupt Mask Register */ - u32 mddsr; /* 0x1C Data Size Register */ - u32 mdin; /* 0x20 Input FIFO */ - u32 res1[3]; /* 0x24 - 0x2F */ - u32 mdao; /* 0x30 Message Digest AO Register */ - u32 mdbo; /* 0x34 Message Digest BO Register */ - u32 mdco; /* 0x38 Message Digest CO Register */ - u32 mddo; /* 0x3C Message Digest DO Register */ - u32 mdeo; /* 0x40 Message Digest EO Register */ - u32 mdmds; /* 0x44 Message Data Size Register */ - u32 res[10]; /* 0x48 - 0x6F */ - u32 mda1; /* 0x70 Message Digest A1 Register */ - u32 mdb1; /* 0x74 Message Digest B1 Register */ - u32 mdc1; /* 0x78 Message Digest C1 Register */ - u32 mdd1; /* 0x7C Message Digest D1 Register */ - u32 mde1; /* 0x80 Message Digest E1 Register */ -} mdha_t; - -/* Symmetric Key Hardware Accelerator */ -typedef struct skha_ctrl { - u32 mr; /* 0x00 Mode Register */ - u32 cr; /* 0x04 Control Register */ - u32 cmr; /* 0x08 Command Register */ - u32 sr; /* 0x0C Status Register */ - u32 esr; /* 0x10 Error Status Register */ - u32 emr; /* 0x14 Error Status Mask Register) */ - u32 ksr; /* 0x18 Key Size Register */ - u32 dsr; /* 0x1C Data Size Register */ - u32 in; /* 0x20 Input FIFO */ - u32 out; /* 0x24 Output FIFO */ - u32 res1[2]; /* 0x28 - 0x2F */ - u32 kdr1; /* 0x30 Key Data Register 1 */ - u32 kdr2; /* 0x34 Key Data Register 2 */ - u32 kdr3; /* 0x38 Key Data Register 3 */ - u32 kdr4; /* 0x3C Key Data Register 4 */ - u32 kdr5; /* 0x40 Key Data Register 5 */ - u32 kdr6; /* 0x44 Key Data Register 6 */ - u32 res2[10]; /* 0x48 - 0x6F */ - u32 c1; /* 0x70 Context 1 */ - u32 c2; /* 0x74 Context 2 */ - u32 c3; /* 0x78 Context 3 */ - u32 c4; /* 0x7C Context 4 */ - u32 c5; /* 0x80 Context 5 */ - u32 c6; /* 0x84 Context 6 */ - u32 c7; /* 0x88 Context 7 */ - u32 c8; /* 0x8C Context 8 */ - u32 c9; /* 0x90 Context 9 */ - u32 c10; /* 0x94 Context 10 */ - u32 c11; /* 0x98 Context 11 */ -} skha_t; - -/* Random Number Generator */ -typedef struct rng_ctrl { - u32 rngcr; /* 0x00 RNG Control Register */ - u32 rngsr; /* 0x04 RNG Status Register */ - u32 rnger; /* 0x08 RNG Entropy Register */ - u32 rngout; /* 0x0C RNG Output FIFO */ -} rng_t; - /* System control module registers 2 */ typedef struct scm2_ctrl { u32 mpr1; /* 0x00 Master Privilege Register */ @@ -165,25 +106,6 @@ typedef struct scm2_ctrl { u32 bmt1; /* 0x54 Bus Monitor Timeout 1 */ } scm2_t;
-/* FlexCan module registers */ -typedef struct can_ctrl { - u32 mcr; /* 0x00 Module Configuration register */ - u32 ctrl; /* 0x04 Control register */ - u32 timer; /* 0x08 Free Running Timer */ - u32 res1; /* 0x0C */ - u32 rxgmask; /* 0x10 Rx Global Mask */ - u32 rx14mask; /* 0x14 RxBuffer 14 Mask */ - u32 rx15mask; /* 0x18 RxBuffer 15 Mask */ - u32 errcnt; /* 0x1C Error Counter Register */ - u32 errstat; /* 0x20 Error and status Register */ - u32 res2; /* 0x24 */ - u32 imask; /* 0x28 Interrupt Mask Register */ - u32 res3; /* 0x2C */ - u32 iflag; /* 0x30 Interrupt Flag Register */ - u32 res4[19]; /* 0x34 - 0x7F */ - u32 MB0_15[2048]; /* 0x80 Message Buffer 0-15 */ -} can_t; - /* System Control Module register 3 */ typedef struct scm3_ctrl { u8 res1[19]; /* 0x00 - 0x12 */ @@ -206,148 +128,9 @@ typedef struct scm3_ctrl { u32 cfdtr; /* 0x7C Core Fault Data Register */ } scm3_t;
-/* Interrupt module registers */ -typedef struct int0_ctrl { - /* Interrupt Controller 0 */ - u32 iprh0; /* 0x00 Pending Register High */ - u32 iprl0; /* 0x04 Pending Register Low */ - u32 imrh0; /* 0x08 Mask Register High */ - u32 imrl0; /* 0x0C Mask Register Low */ - u32 frch0; /* 0x10 Force Register High */ - u32 frcl0; /* 0x14 Force Register Low */ - u16 res1; /* 0x18 - 0x19 */ - u16 icfg0; /* 0x1A Configuration Register */ - u8 simr0; /* 0x1C Set Interrupt Mask */ - u8 cimr0; /* 0x1D Clear Interrupt Mask */ - u8 clmask0; /* 0x1E Current Level Mask */ - u8 slmask; /* 0x1F Saved Level Mask */ - u32 res2[8]; /* 0x20 - 0x3F */ - u8 icr0[64]; /* 0x40 - 0x7F Control registers */ - u32 res3[24]; /* 0x80 - 0xDF */ - u8 swiack0; /* 0xE0 Software Interrupt Acknowledge */ - u8 res4[3]; /* 0xE1 - 0xE3 */ - u8 Lniack0_1; /* 0xE4 Level n interrupt acknowledge resister */ - u8 res5[3]; /* 0xE5 - 0xE7 */ - u8 Lniack0_2; /* 0xE8 Level n interrupt acknowledge resister */ - u8 res6[3]; /* 0xE9 - 0xEB */ - u8 Lniack0_3; /* 0xEC Level n interrupt acknowledge resister */ - u8 res7[3]; /* 0xED - 0xEF */ - u8 Lniack0_4; /* 0xF0 Level n interrupt acknowledge resister */ - u8 res8[3]; /* 0xF1 - 0xF3 */ - u8 Lniack0_5; /* 0xF4 Level n interrupt acknowledge resister */ - u8 res9[3]; /* 0xF5 - 0xF7 */ - u8 Lniack0_6; /* 0xF8 Level n interrupt acknowledge resister */ - u8 resa[3]; /* 0xF9 - 0xFB */ - u8 Lniack0_7; /* 0xFC Level n interrupt acknowledge resister */ - u8 resb[3]; /* 0xFD - 0xFF */ -} int0_t; - -typedef struct int1_ctrl { - /* Interrupt Controller 1 */ - u32 iprh1; /* 0x00 Pending Register High */ - u32 iprl1; /* 0x04 Pending Register Low */ - u32 imrh1; /* 0x08 Mask Register High */ - u32 imrl1; /* 0x0C Mask Register Low */ - u32 frch1; /* 0x10 Force Register High */ - u32 frcl1; /* 0x14 Force Register Low */ - u16 res1; /* 0x18 */ - u16 icfg1; /* 0x1A Configuration Register */ - u8 simr1; /* 0x1C Set Interrupt Mask */ - u8 cimr1; /* 0x1D Clear Interrupt Mask */ - u16 res2; /* 0x1E - 0x1F */ - u32 res3[8]; /* 0x20 - 0x3F */ - u8 icr1[64]; /* 0x40 - 0x7F */ - u32 res4[24]; /* 0x80 - 0xDF */ - u8 swiack1; /* 0xE0 Software Interrupt Acknowledge */ - u8 res5[3]; /* 0xE1 - 0xE3 */ - u8 Lniack1_1; /* 0xE4 Level n interrupt acknowledge resister */ - u8 res6[3]; /* 0xE5 - 0xE7 */ - u8 Lniack1_2; /* 0xE8 Level n interrupt acknowledge resister */ - u8 res7[3]; /* 0xE9 - 0xEB */ - u8 Lniack1_3; /* 0xEC Level n interrupt acknowledge resister */ - u8 res8[3]; /* 0xED - 0xEF */ - u8 Lniack1_4; /* 0xF0 Level n interrupt acknowledge resister */ - u8 res9[3]; /* 0xF1 - 0xF3 */ - u8 Lniack1_5; /* 0xF4 Level n interrupt acknowledge resister */ - u8 resa[3]; /* 0xF5 - 0xF7 */ - u8 Lniack1_6; /* 0xF8 Level n interrupt acknowledge resister */ - u8 resb[3]; /* 0xF9 - 0xFB */ - u8 Lniack1_7; /* 0xFC Level n interrupt acknowledge resister */ - u8 resc[3]; /* 0xFD - 0xFF */ -} int1_t; - -typedef struct intgack_ctrl1 { - /* Global IACK Registers */ - u8 swiack; /* 0xE0 Global Software Interrupt Acknowledge */ - u8 Lniack[7]; /* 0xE1 - 0xE7 Global Level 0 Interrupt Acknowledge */ -} intgack_t; - -/* QSPI module registers */ -typedef struct qspi_ctrl { - u16 qmr; /* Mode register */ - u16 res1; - u16 qdlyr; /* Delay register */ - u16 res2; - u16 qwr; /* Wrap register */ - u16 res3; - u16 qir; /* Interrupt register */ - u16 res4; - u16 qar; /* Address register */ - u16 res5; - u16 qdr; /* Data register */ - u16 res6; -} qspi_t; - -/* PWM module registers */ -typedef struct pwm_ctrl { - u8 en; /* 0x00 PWM Enable Register */ - u8 pol; /* 0x01 Polarity Register */ - u8 clk; /* 0x02 Clock Select Register */ - u8 prclk; /* 0x03 Prescale Clock Select Register */ - u8 cae; /* 0x04 Center Align Enable Register */ - u8 ctl; /* 0x05 Control Register */ - u8 res1[2]; /* 0x06 - 0x07 */ - u8 scla; /* 0x08 Scale A register */ - u8 sclb; /* 0x09 Scale B register */ - u8 res2[2]; /* 0x0A - 0x0B */ - u8 cnt0; /* 0x0C Channel 0 Counter register */ - u8 cnt1; /* 0x0D Channel 1 Counter register */ - u8 cnt2; /* 0x0E Channel 2 Counter register */ - u8 cnt3; /* 0x0F Channel 3 Counter register */ - u8 cnt4; /* 0x10 Channel 4 Counter register */ - u8 cnt5; /* 0x11 Channel 5 Counter register */ - u8 cnt6; /* 0x12 Channel 6 Counter register */ - u8 cnt7; /* 0x13 Channel 7 Counter register */ - u8 per0; /* 0x14 Channel 0 Period register */ - u8 per1; /* 0x15 Channel 1 Period register */ - u8 per2; /* 0x16 Channel 2 Period register */ - u8 per3; /* 0x17 Channel 3 Period register */ - u8 per4; /* 0x18 Channel 4 Period register */ - u8 per5; /* 0x19 Channel 5 Period register */ - u8 per6; /* 0x1A Channel 6 Period register */ - u8 per7; /* 0x1B Channel 7 Period register */ - u8 dty0; /* 0x1C Channel 0 Duty register */ - u8 dty1; /* 0x1D Channel 1 Duty register */ - u8 dty2; /* 0x1E Channel 2 Duty register */ - u8 dty3; /* 0x1F Channel 3 Duty register */ - u8 dty4; /* 0x20 Channel 4 Duty register */ - u8 dty5; /* 0x21 Channel 5 Duty register */ - u8 dty6; /* 0x22 Channel 6 Duty register */ - u8 dty7; /* 0x23 Channel 7 Duty register */ - u8 sdn; /* 0x24 Shutdown register */ - u8 res3[3]; /* 0x25 - 0x27 */ -} pwm_t; - -/* Edge Port module registers */ -typedef struct eport_ctrl { - u16 par; /* 0x00 Pin Assignment Register */ - u8 ddar; /* 0x02 Data Direction Register */ - u8 ier; /* 0x03 Interrupt Enable Register */ - u8 dr; /* 0x04 Data Register */ - u8 pdr; /* 0x05 Pin Data Register */ - u8 fr; /* 0x06 Flag_Register */ - u8 res1; -} eport_t; +typedef struct canex_ctrl { + can_msg_t msg[16]; /* 0x00 Message Buffer 0-15 */ +} canex_t;
/* Watchdog registers */ typedef struct wdog_ctrl { @@ -593,53 +376,6 @@ typedef struct usb_otg { u32 eptctrl3; /* 0x1CC Endpoint control 3 */ } usbotg_t;
-/* USB Host module registers */ -typedef struct usb_host { - u32 id; /* 0x000 Identification Register */ - u32 hwgeneral; /* 0x004 General HW Parameters */ - u32 hwhost; /* 0x008 Host HW Parameters */ - u32 res1; /* 0x0C */ - u32 hwtxbuf; /* 0x010 TX Buffer HW Parameters */ - u32 hwrxbuf; /* 0x014 RX Buffer HW Parameters */ - u32 res2[58]; /* 0x18 - 0xFF */ - - /* Host Controller Capability Register */ - u8 caplength; /* 0x100 Capability Register Length */ - u8 res3; /* 0x101 */ - u16 hciver; /* 0x102 Host Interface Version Number */ - u32 hcsparams; /* 0x104 Host Structural Parameters */ - u32 hccparams; /* 0x108 Host Capability Parameters */ - u32 res4[13]; /* 0x10C - 0x13F */ - - /* Host Controller Operational Register */ - u32 cmd; /* 0x140 USB Command */ - u32 sts; /* 0x144 USB Status */ - u32 intr; /* 0x148 USB Interrupt Enable */ - u32 frindex; /* 0x14C USB Frame Index */ - u32 res5; /* 0x150 (ctrl segment register in EHCI spec) */ - u32 prdlst; /* 0x154 Periodic Frame List Base Address */ - u32 aynclst; /* 0x158 Current Asynchronous List Address */ - u32 ttctrl; /* 0x15C Host TT Asynchronous Buffer Control (non-ehci) */ - u32 burstsize; /* 0x160 Master Interface Data Burst Size (non-ehci) */ - u32 txfill; /* 0x164 Host Transmit FIFO Tuning Control (non-ehci) */ - u32 res6[6]; /* 0x168 - 0x17F */ - u32 cfgflag; /* 0x180 Configure Flag Register */ - u32 portsc1; /* 0x184 Port Status/Control */ - u32 res7[8]; /* 0x188 - 0x1A7 */ - - /* non-ehci registers */ - u32 mode; /* 0x1A8 USB mode register */ - u32 eptsetstat; /* 0x1AC Endpoint Setup status */ - u32 eptprime; /* 0x1B0 Endpoint initialization */ - u32 eptflush; /* 0x1B4 Endpoint de-initialize */ - u32 eptstat; /* 0x1B8 Endpoint status */ - u32 eptcomplete; /* 0x1BC Endpoint Complete */ - u32 eptctrl0; /* 0x1C0 Endpoint control 0 */ - u32 eptctrl1; /* 0x1C4 Endpoint control 1 */ - u32 eptctrl2; /* 0x1C8 Endpoint control 2 */ - u32 eptctrl3; /* 0x1CC Endpoint control 3 */ -} usbhost_t; - /* SDRAM controller registers */ typedef struct sdram_ctrl { u32 mode; /* 0x00 Mode/Extended Mode register */ diff --git a/include/asm-m68k/immap_5445x.h b/include/asm-m68k/immap_5445x.h index ef8930e..57cf3ec 100644 --- a/include/asm-m68k/immap_5445x.h +++ b/include/asm-m68k/immap_5445x.h @@ -69,161 +69,15 @@ #define MMAP_USBEHCI 0xFC0B0140 #define MMAP_USBOTG 0xFC0B01A0
+#include <asm/coldfire/ata.h> #include <asm/coldfire/crossbar.h> #include <asm/coldfire/dspi.h> #include <asm/coldfire/edma.h> +#include <asm/coldfire/eport.h> #include <asm/coldfire/flexbus.h> +#include <asm/coldfire/intctrl.h> #include <asm/coldfire/ssi.h>
-/* ATA */ -typedef struct atac { - /* PIO */ - u8 toff; /* 0x00 */ - u8 ton; /* 0x01 */ - u8 t1; /* 0x02 */ - u8 t2w; /* 0x03 */ - u8 t2r; /* 0x04 */ - u8 ta; /* 0x05 */ - u8 trd; /* 0x06 */ - u8 t4; /* 0x07 */ - u8 t9; /* 0x08 */ - - /* DMA */ - u8 tm; /* 0x09 */ - u8 tn; /* 0x0A */ - u8 td; /* 0x0B */ - u8 tk; /* 0x0C */ - u8 tack; /* 0x0D */ - u8 tenv; /* 0x0E */ - u8 trp; /* 0x0F */ - u8 tzah; /* 0x10 */ - u8 tmli; /* 0x11 */ - u8 tdvh; /* 0x12 */ - u8 tdzfs; /* 0x13 */ - u8 tdvs; /* 0x14 */ - u8 tcvh; /* 0x15 */ - u8 tss; /* 0x16 */ - u8 tcyc; /* 0x17 */ - - /* FIFO */ - u32 fifo32; /* 0x18 */ - u16 fifo16; /* 0x1C */ - u8 rsvd0[2]; - u8 ffill; /* 0x20 */ - u8 rsvd1[3]; - - /* ATA */ - u8 cr; /* 0x24 */ - u8 rsvd2[3]; - u8 isr; /* 0x28 */ - u8 rsvd3[3]; - u8 ier; /* 0x2C */ - u8 rsvd4[3]; - u8 icr; /* 0x30 */ - u8 rsvd5[3]; - u8 falarm; /* 0x34 */ - u8 rsvd6[106]; -} atac_t; - -/* Interrupt Controller (INTC) */ -typedef struct int0_ctrl { - u32 iprh0; /* 0x00 Pending Register High */ - u32 iprl0; /* 0x04 Pending Register Low */ - u32 imrh0; /* 0x08 Mask Register High */ - u32 imrl0; /* 0x0C Mask Register Low */ - u32 frch0; /* 0x10 Force Register High */ - u32 frcl0; /* 0x14 Force Register Low */ - u16 res1; /* 0x18 - 0x19 */ - u16 icfg0; /* 0x1A Configuration Register */ - u8 simr0; /* 0x1C Set Interrupt Mask */ - u8 cimr0; /* 0x1D Clear Interrupt Mask */ - u8 clmask0; /* 0x1E Current Level Mask */ - u8 slmask; /* 0x1F Saved Level Mask */ - u32 res2[8]; /* 0x20 - 0x3F */ - u8 icr0[64]; /* 0x40 - 0x7F Control registers */ - u32 res3[24]; /* 0x80 - 0xDF */ - u8 swiack0; /* 0xE0 Software Interrupt Acknowledge */ - u8 res4[3]; /* 0xE1 - 0xE3 */ - u8 Lniack0_1; /* 0xE4 Level n interrupt acknowledge resister */ - u8 res5[3]; /* 0xE5 - 0xE7 */ - u8 Lniack0_2; /* 0xE8 Level n interrupt acknowledge resister */ - u8 res6[3]; /* 0xE9 - 0xEB */ - u8 Lniack0_3; /* 0xEC Level n interrupt acknowledge resister */ - u8 res7[3]; /* 0xED - 0xEF */ - u8 Lniack0_4; /* 0xF0 Level n interrupt acknowledge resister */ - u8 res8[3]; /* 0xF1 - 0xF3 */ - u8 Lniack0_5; /* 0xF4 Level n interrupt acknowledge resister */ - u8 res9[3]; /* 0xF5 - 0xF7 */ - u8 Lniack0_6; /* 0xF8 Level n interrupt acknowledge resister */ - u8 resa[3]; /* 0xF9 - 0xFB */ - u8 Lniack0_7; /* 0xFC Level n interrupt acknowledge resister */ - u8 resb[3]; /* 0xFD - 0xFF */ -} int0_t; - -typedef struct int1_ctrl { - /* Interrupt Controller 1 */ - u32 iprh1; /* 0x00 Pending Register High */ - u32 iprl1; /* 0x04 Pending Register Low */ - u32 imrh1; /* 0x08 Mask Register High */ - u32 imrl1; /* 0x0C Mask Register Low */ - u32 frch1; /* 0x10 Force Register High */ - u32 frcl1; /* 0x14 Force Register Low */ - u16 res1; /* 0x18 */ - u16 icfg1; /* 0x1A Configuration Register */ - u8 simr1; /* 0x1C Set Interrupt Mask */ - u8 cimr1; /* 0x1D Clear Interrupt Mask */ - u16 res2; /* 0x1E - 0x1F */ - u32 res3[8]; /* 0x20 - 0x3F */ - u8 icr1[64]; /* 0x40 - 0x7F */ - u32 res4[24]; /* 0x80 - 0xDF */ - u8 swiack1; /* 0xE0 Software Interrupt Acknowledge */ - u8 res5[3]; /* 0xE1 - 0xE3 */ - u8 Lniack1_1; /* 0xE4 Level n interrupt acknowledge resister */ - u8 res6[3]; /* 0xE5 - 0xE7 */ - u8 Lniack1_2; /* 0xE8 Level n interrupt acknowledge resister */ - u8 res7[3]; /* 0xE9 - 0xEB */ - u8 Lniack1_3; /* 0xEC Level n interrupt acknowledge resister */ - u8 res8[3]; /* 0xED - 0xEF */ - u8 Lniack1_4; /* 0xF0 Level n interrupt acknowledge resister */ - u8 res9[3]; /* 0xF1 - 0xF3 */ - u8 Lniack1_5; /* 0xF4 Level n interrupt acknowledge resister */ - u8 resa[3]; /* 0xF5 - 0xF7 */ - u8 Lniack1_6; /* 0xF8 Level n interrupt acknowledge resister */ - u8 resb[3]; /* 0xF9 - 0xFB */ - u8 Lniack1_7; /* 0xFC Level n interrupt acknowledge resister */ - u8 resc[3]; /* 0xFD - 0xFF */ -} int1_t; - -/* Global Interrupt Acknowledge (IACK) */ -typedef struct iack { - u8 resv0[0xE0]; - u8 gswiack; - u8 resv1[0x3]; - u8 gl1iack; - u8 resv2[0x3]; - u8 gl2iack; - u8 resv3[0x3]; - u8 gl3iack; - u8 resv4[0x3]; - u8 gl4iack; - u8 resv5[0x3]; - u8 gl5iack; - u8 resv6[0x3]; - u8 gl6iack; - u8 resv7[0x3]; - u8 gl7iack; -} iack_t; - -/* Edge Port Module (EPORT) */ -typedef struct eport { - u16 eppar; - u8 epddr; - u8 epier; - u8 epdr; - u8 eppdr; - u8 epfr; -} eport_t; - /* Watchdog Timer Modules (WTM) */ typedef struct wtm { u16 wcr; @@ -387,14 +241,6 @@ typedef struct gpio { u8 dscr_ata; /* ATA Drive Strength Control Register */ } gpio_t;
-/* Random Number Generator (RNG) */ -typedef struct rng { - u32 rngcr; - u32 rngsr; - u32 rnger; - u32 rngout; -} rng_t; - /* SDRAM Controller (SDRAMC) */ typedef struct sdramc { u32 sdmr; /* SDRAM Mode/Extended Mode Register */ diff --git a/include/asm-m68k/immap_547x_8x.h b/include/asm-m68k/immap_547x_8x.h index c221936..50f8b05 100644 --- a/include/asm-m68k/immap_547x_8x.h +++ b/include/asm-m68k/immap_547x_8x.h @@ -57,7 +57,11 @@ #define MMAP_SRAMCFG (CONFIG_SYS_MBAR + 0x0001FF00) #define MMAP_SEC (CONFIG_SYS_MBAR + 0x00020000)
+#include <asm/coldfire/dspi.h> +#include <asm/coldfire/eport.h> #include <asm/coldfire/flexbus.h> +#include <asm/coldfire/flexcan.h> +#include <asm/coldfire/intctrl.h>
typedef struct siu { u32 mbar; /* 0x00 */ @@ -98,37 +102,6 @@ typedef struct xlb_arb { u32 pri; /* 0x268 */ } xlbarb_t;
-typedef struct int0_ctrl { - u32 iprh0; /* 0x00 */ - u32 iprl0; /* 0x04 */ - u32 imrh0; /* 0x08 */ - u32 imrl0; /* 0x0C */ - u32 frch0; /* 0x10 */ - u32 frcl0; /* 0x14 */ - u8 irlr; /* 0x18 */ - u8 iacklpr; /* 0x19 */ - u16 res1; /* 0x1A - 0x1B */ - u32 res2[9]; /* 0x1C - 0x3F */ - u8 icr0[64]; /* 0x40 - 0x7F */ - u32 res3[24]; /* 0x80 - 0xDF */ - u8 swiack0; /* 0xE0 */ - u8 res4[3]; /* 0xE1 - 0xE3 */ - u8 Lniack0_1; /* 0xE4 */ - u8 res5[3]; /* 0xE5 - 0xE7 */ - u8 Lniack0_2; /* 0xE8 */ - u8 res6[3]; /* 0xE9 - 0xEB */ - u8 Lniack0_3; /* 0xEC */ - u8 res7[3]; /* 0xED - 0xEF */ - u8 Lniack0_4; /* 0xF0 */ - u8 res8[3]; /* 0xF1 - 0xF3 */ - u8 Lniack0_5; /* 0xF4 */ - u8 res9[3]; /* 0xF5 - 0xF7 */ - u8 Lniack0_6; /* 0xF8 */ - u8 resa[3]; /* 0xF9 - 0xFB */ - u8 Lniack0_7; /* 0xFC */ - u8 resb[3]; /* 0xFD - 0xFF */ -} int0_t; - typedef struct gptmr { u8 ocpw; u8 octict; @@ -147,6 +120,11 @@ typedef struct gptmr { u8 intr; /* Interrupts */ } gptmr_t;
+typedef struct canex_ctrl { + can_msg_t msg[16]; /* 0x00 Message Buffer 0-15 */ +} canex_t; + + typedef struct slt { u32 tcnt; /* 0x00 */ u32 cr; /* 0x04 */ diff --git a/include/asm-m68k/m5227x.h b/include/asm-m68k/m5227x.h index afd31ba..61bc0ad 100644 --- a/include/asm-m68k/m5227x.h +++ b/include/asm-m68k/m5227x.h @@ -26,9 +26,7 @@ #ifndef __MCF5227X__ #define __MCF5227X__
-/********************************************************************* -* Interrupt Controller (INTC) -*********************************************************************/ +/* Interrupt Controller (INTC) */ #define INT0_LO_RSVD0 (0) #define INT0_LO_EPORT1 (1) #define INT0_LO_EPORT4 (4) @@ -98,235 +96,6 @@ #define INT1_HI_TOUCH_ADC (61) #define INT1_HI_PLL_LOCKS (62)
-/* Bit definitions and macros for IPRH */ -#define INTC_IPRH_INT32 (0x00000001) -#define INTC_IPRH_INT33 (0x00000002) -#define INTC_IPRH_INT34 (0x00000004) -#define INTC_IPRH_INT35 (0x00000008) -#define INTC_IPRH_INT36 (0x00000010) -#define INTC_IPRH_INT37 (0x00000020) -#define INTC_IPRH_INT38 (0x00000040) -#define INTC_IPRH_INT39 (0x00000080) -#define INTC_IPRH_INT40 (0x00000100) -#define INTC_IPRH_INT41 (0x00000200) -#define INTC_IPRH_INT42 (0x00000400) -#define INTC_IPRH_INT43 (0x00000800) -#define INTC_IPRH_INT44 (0x00001000) -#define INTC_IPRH_INT45 (0x00002000) -#define INTC_IPRH_INT46 (0x00004000) -#define INTC_IPRH_INT47 (0x00008000) -#define INTC_IPRH_INT48 (0x00010000) -#define INTC_IPRH_INT49 (0x00020000) -#define INTC_IPRH_INT50 (0x00040000) -#define INTC_IPRH_INT51 (0x00080000) -#define INTC_IPRH_INT52 (0x00100000) -#define INTC_IPRH_INT53 (0x00200000) -#define INTC_IPRH_INT54 (0x00400000) -#define INTC_IPRH_INT55 (0x00800000) -#define INTC_IPRH_INT56 (0x01000000) -#define INTC_IPRH_INT57 (0x02000000) -#define INTC_IPRH_INT58 (0x04000000) -#define INTC_IPRH_INT59 (0x08000000) -#define INTC_IPRH_INT60 (0x10000000) -#define INTC_IPRH_INT61 (0x20000000) -#define INTC_IPRH_INT62 (0x40000000) -#define INTC_IPRH_INT63 (0x80000000) - -/* Bit definitions and macros for IPRL */ -#define INTC_IPRL_INT0 (0x00000001) -#define INTC_IPRL_INT1 (0x00000002) -#define INTC_IPRL_INT2 (0x00000004) -#define INTC_IPRL_INT3 (0x00000008) -#define INTC_IPRL_INT4 (0x00000010) -#define INTC_IPRL_INT5 (0x00000020) -#define INTC_IPRL_INT6 (0x00000040) -#define INTC_IPRL_INT7 (0x00000080) -#define INTC_IPRL_INT8 (0x00000100) -#define INTC_IPRL_INT9 (0x00000200) -#define INTC_IPRL_INT10 (0x00000400) -#define INTC_IPRL_INT11 (0x00000800) -#define INTC_IPRL_INT12 (0x00001000) -#define INTC_IPRL_INT13 (0x00002000) -#define INTC_IPRL_INT14 (0x00004000) -#define INTC_IPRL_INT15 (0x00008000) -#define INTC_IPRL_INT16 (0x00010000) -#define INTC_IPRL_INT17 (0x00020000) -#define INTC_IPRL_INT18 (0x00040000) -#define INTC_IPRL_INT19 (0x00080000) -#define INTC_IPRL_INT20 (0x00100000) -#define INTC_IPRL_INT21 (0x00200000) -#define INTC_IPRL_INT22 (0x00400000) -#define INTC_IPRL_INT23 (0x00800000) -#define INTC_IPRL_INT24 (0x01000000) -#define INTC_IPRL_INT25 (0x02000000) -#define INTC_IPRL_INT26 (0x04000000) -#define INTC_IPRL_INT27 (0x08000000) -#define INTC_IPRL_INT28 (0x10000000) -#define INTC_IPRL_INT29 (0x20000000) -#define INTC_IPRL_INT30 (0x40000000) -#define INTC_IPRL_INT31 (0x80000000) - -/* Bit definitions and macros for IMRH */ -#define INTC_IMRH_INT_MASK32 (0x00000001) -#define INTC_IMRH_INT_MASK33 (0x00000002) -#define INTC_IMRH_INT_MASK34 (0x00000004) -#define INTC_IMRH_INT_MASK35 (0x00000008) -#define INTC_IMRH_INT_MASK36 (0x00000010) -#define INTC_IMRH_INT_MASK37 (0x00000020) -#define INTC_IMRH_INT_MASK38 (0x00000040) -#define INTC_IMRH_INT_MASK39 (0x00000080) -#define INTC_IMRH_INT_MASK40 (0x00000100) -#define INTC_IMRH_INT_MASK41 (0x00000200) -#define INTC_IMRH_INT_MASK42 (0x00000400) -#define INTC_IMRH_INT_MASK43 (0x00000800) -#define INTC_IMRH_INT_MASK44 (0x00001000) -#define INTC_IMRH_INT_MASK45 (0x00002000) -#define INTC_IMRH_INT_MASK46 (0x00004000) -#define INTC_IMRH_INT_MASK47 (0x00008000) -#define INTC_IMRH_INT_MASK48 (0x00010000) -#define INTC_IMRH_INT_MASK49 (0x00020000) -#define INTC_IMRH_INT_MASK50 (0x00040000) -#define INTC_IMRH_INT_MASK51 (0x00080000) -#define INTC_IMRH_INT_MASK52 (0x00100000) -#define INTC_IMRH_INT_MASK53 (0x00200000) -#define INTC_IMRH_INT_MASK54 (0x00400000) -#define INTC_IMRH_INT_MASK55 (0x00800000) -#define INTC_IMRH_INT_MASK56 (0x01000000) -#define INTC_IMRH_INT_MASK57 (0x02000000) -#define INTC_IMRH_INT_MASK58 (0x04000000) -#define INTC_IMRH_INT_MASK59 (0x08000000) -#define INTC_IMRH_INT_MASK60 (0x10000000) -#define INTC_IMRH_INT_MASK61 (0x20000000) -#define INTC_IMRH_INT_MASK62 (0x40000000) -#define INTC_IMRH_INT_MASK63 (0x80000000) - -/* Bit definitions and macros for IMRL */ -#define INTC_IMRL_INT_MASK0 (0x00000001) -#define INTC_IMRL_INT_MASK1 (0x00000002) -#define INTC_IMRL_INT_MASK2 (0x00000004) -#define INTC_IMRL_INT_MASK3 (0x00000008) -#define INTC_IMRL_INT_MASK4 (0x00000010) -#define INTC_IMRL_INT_MASK5 (0x00000020) -#define INTC_IMRL_INT_MASK6 (0x00000040) -#define INTC_IMRL_INT_MASK7 (0x00000080) -#define INTC_IMRL_INT_MASK8 (0x00000100) -#define INTC_IMRL_INT_MASK9 (0x00000200) -#define INTC_IMRL_INT_MASK10 (0x00000400) -#define INTC_IMRL_INT_MASK11 (0x00000800) -#define INTC_IMRL_INT_MASK12 (0x00001000) -#define INTC_IMRL_INT_MASK13 (0x00002000) -#define INTC_IMRL_INT_MASK14 (0x00004000) -#define INTC_IMRL_INT_MASK15 (0x00008000) -#define INTC_IMRL_INT_MASK16 (0x00010000) -#define INTC_IMRL_INT_MASK17 (0x00020000) -#define INTC_IMRL_INT_MASK18 (0x00040000) -#define INTC_IMRL_INT_MASK19 (0x00080000) -#define INTC_IMRL_INT_MASK20 (0x00100000) -#define INTC_IMRL_INT_MASK21 (0x00200000) -#define INTC_IMRL_INT_MASK22 (0x00400000) -#define INTC_IMRL_INT_MASK23 (0x00800000) -#define INTC_IMRL_INT_MASK24 (0x01000000) -#define INTC_IMRL_INT_MASK25 (0x02000000) -#define INTC_IMRL_INT_MASK26 (0x04000000) -#define INTC_IMRL_INT_MASK27 (0x08000000) -#define INTC_IMRL_INT_MASK28 (0x10000000) -#define INTC_IMRL_INT_MASK29 (0x20000000) -#define INTC_IMRL_INT_MASK30 (0x40000000) -#define INTC_IMRL_INT_MASK31 (0x80000000) - -/* Bit definitions and macros for INTFRCH */ -#define INTC_INTFRCH_INTFRC32 (0x00000001) -#define INTC_INTFRCH_INTFRC33 (0x00000002) -#define INTC_INTFRCH_INTFRC34 (0x00000004) -#define INTC_INTFRCH_INTFRC35 (0x00000008) -#define INTC_INTFRCH_INTFRC36 (0x00000010) -#define INTC_INTFRCH_INTFRC37 (0x00000020) -#define INTC_INTFRCH_INTFRC38 (0x00000040) -#define INTC_INTFRCH_INTFRC39 (0x00000080) -#define INTC_INTFRCH_INTFRC40 (0x00000100) -#define INTC_INTFRCH_INTFRC41 (0x00000200) -#define INTC_INTFRCH_INTFRC42 (0x00000400) -#define INTC_INTFRCH_INTFRC43 (0x00000800) -#define INTC_INTFRCH_INTFRC44 (0x00001000) -#define INTC_INTFRCH_INTFRC45 (0x00002000) -#define INTC_INTFRCH_INTFRC46 (0x00004000) -#define INTC_INTFRCH_INTFRC47 (0x00008000) -#define INTC_INTFRCH_INTFRC48 (0x00010000) -#define INTC_INTFRCH_INTFRC49 (0x00020000) -#define INTC_INTFRCH_INTFRC50 (0x00040000) -#define INTC_INTFRCH_INTFRC51 (0x00080000) -#define INTC_INTFRCH_INTFRC52 (0x00100000) -#define INTC_INTFRCH_INTFRC53 (0x00200000) -#define INTC_INTFRCH_INTFRC54 (0x00400000) -#define INTC_INTFRCH_INTFRC55 (0x00800000) -#define INTC_INTFRCH_INTFRC56 (0x01000000) -#define INTC_INTFRCH_INTFRC57 (0x02000000) -#define INTC_INTFRCH_INTFRC58 (0x04000000) -#define INTC_INTFRCH_INTFRC59 (0x08000000) -#define INTC_INTFRCH_INTFRC60 (0x10000000) -#define INTC_INTFRCH_INTFRC61 (0x20000000) -#define INTC_INTFRCH_INTFRC62 (0x40000000) -#define INTC_INTFRCH_INTFRC63 (0x80000000) - -/* Bit definitions and macros for INTFRCL */ -#define INTC_INTFRCL_INTFRC0 (0x00000001) -#define INTC_INTFRCL_INTFRC1 (0x00000002) -#define INTC_INTFRCL_INTFRC2 (0x00000004) -#define INTC_INTFRCL_INTFRC3 (0x00000008) -#define INTC_INTFRCL_INTFRC4 (0x00000010) -#define INTC_INTFRCL_INTFRC5 (0x00000020) -#define INTC_INTFRCL_INTFRC6 (0x00000040) -#define INTC_INTFRCL_INTFRC7 (0x00000080) -#define INTC_INTFRCL_INTFRC8 (0x00000100) -#define INTC_INTFRCL_INTFRC9 (0x00000200) -#define INTC_INTFRCL_INTFRC10 (0x00000400) -#define INTC_INTFRCL_INTFRC11 (0x00000800) -#define INTC_INTFRCL_INTFRC12 (0x00001000) -#define INTC_INTFRCL_INTFRC13 (0x00002000) -#define INTC_INTFRCL_INTFRC14 (0x00004000) -#define INTC_INTFRCL_INTFRC15 (0x00008000) -#define INTC_INTFRCL_INTFRC16 (0x00010000) -#define INTC_INTFRCL_INTFRC17 (0x00020000) -#define INTC_INTFRCL_INTFRC18 (0x00040000) -#define INTC_INTFRCL_INTFRC19 (0x00080000) -#define INTC_INTFRCL_INTFRC20 (0x00100000) -#define INTC_INTFRCL_INTFRC21 (0x00200000) -#define INTC_INTFRCL_INTFRC22 (0x00400000) -#define INTC_INTFRCL_INTFRC23 (0x00800000) -#define INTC_INTFRCL_INTFRC24 (0x01000000) -#define INTC_INTFRCL_INTFRC25 (0x02000000) -#define INTC_INTFRCL_INTFRC26 (0x04000000) -#define INTC_INTFRCL_INTFRC27 (0x08000000) -#define INTC_INTFRCL_INTFRC28 (0x10000000) -#define INTC_INTFRCL_INTFRC29 (0x20000000) -#define INTC_INTFRCL_INTFRC30 (0x40000000) -#define INTC_INTFRCL_INTFRC31 (0x80000000) - -/* Bit definitions and macros for ICONFIG */ -#define INTC_ICONFIG_EMASK (0x0020) -#define INTC_ICONFIG_ELVLPRI1 (0x0200) -#define INTC_ICONFIG_ELVLPRI2 (0x0400) -#define INTC_ICONFIG_ELVLPRI3 (0x0800) -#define INTC_ICONFIG_ELVLPRI4 (0x1000) -#define INTC_ICONFIG_ELVLPRI5 (0x2000) -#define INTC_ICONFIG_ELVLPRI6 (0x4000) -#define INTC_ICONFIG_ELVLPRI7 (0x8000) - -/* Bit definitions and macros for SIMR */ -#define INTC_SIMR_SIMR(x) (((x)&0x7F)) - -/* Bit definitions and macros for CIMR */ -#define INTC_CIMR_CIMR(x) (((x)&0x7F)) - -/* Bit definitions and macros for CLMASK */ -#define INTC_CLMASK_CLMASK(x) (((x)&0x0F)) - -/* Bit definitions and macros for SLMASK */ -#define INTC_SLMASK_SLMASK(x) (((x)&0x0F)) - -/* Bit definitions and macros for ICR group */ -#define INTC_ICR_IL(x) (((x)&0x07)) - /********************************************************************* * Reset Controller Module (RCM) *********************************************************************/ diff --git a/include/asm-m68k/m5235.h b/include/asm-m68k/m5235.h index b98b452..22987ac 100644 --- a/include/asm-m68k/m5235.h +++ b/include/asm-m68k/m5235.h @@ -163,94 +163,6 @@ #define SDRAMC_DMRn_V (0x00000001)
/********************************************************************* -* FlexBus Chip Selects (FBCS) -*********************************************************************/ -/* Bit definitions and macros for FBCS_CSMR */ -#define FBCS_CSMR_BAM(x) (((x)&0xFFFF)<<16) -#define FBCS_CSMR_BAM_4G (0xFFFF0000) -#define FBCS_CSMR_BAM_2G (0x7FFF0000) -#define FBCS_CSMR_BAM_1G (0x3FFF0000) -#define FBCS_CSMR_BAM_1024M (0x3FFF0000) -#define FBCS_CSMR_BAM_512M (0x1FFF0000) -#define FBCS_CSMR_BAM_256M (0x0FFF0000) -#define FBCS_CSMR_BAM_128M (0x07FF0000) -#define FBCS_CSMR_BAM_64M (0x03FF0000) -#define FBCS_CSMR_BAM_32M (0x01FF0000) -#define FBCS_CSMR_BAM_16M (0x00FF0000) -#define FBCS_CSMR_BAM_8M (0x007F0000) -#define FBCS_CSMR_BAM_4M (0x003F0000) -#define FBCS_CSMR_BAM_2M (0x001F0000) -#define FBCS_CSMR_BAM_1M (0x000F0000) -#define FBCS_CSMR_BAM_1024K (0x000F0000) -#define FBCS_CSMR_BAM_512K (0x00070000) -#define FBCS_CSMR_BAM_256K (0x00030000) -#define FBCS_CSMR_BAM_128K (0x00010000) -#define FBCS_CSMR_BAM_64K (0x00000000) -#define FBCS_CSMR_WP (0x00000100) -#define FBCS_CSMR_V (0x00000001) - -/* Bit definitions and macros for FBCS_CSCR */ -#define FBCS_CSCR_SRWS(x) (((x)&0x03)<<14) -#define FBCS_CSCR_IWS(x) (((x)&0x0F)<<10) -#define FBCS_CSCR_AA (0x0100) -#define FBCS_CSCR_PS_MASK (0x00C0) -#define FBCS_CSCR_PS_32 (0x0000) -#define FBCS_CSCR_PS_16 (0x0080) -#define FBCS_CSCR_PS_8 (0x0040) -#define FBCS_CSCR_BEM (0x0020) -#define FBCS_CSCR_BSTR (0x0010) -#define FBCS_CSCR_BSTW (0x0008) -#define FBCS_CSCR_SWWS(x) ((x)&0x07) - -/********************************************************************* -* Queued Serial Peripheral Interface (QSPI) -*********************************************************************/ -/* Bit definitions and macros for QSPI_QMR */ -#define QSPI_QMR_MSTR (0x8000) -#define QSPI_QMR_DOHIE (0x4000) -#define QSPI_QMR_BITS(x) (((x)&0x000F)<<10) -#define QSPI_QMR_CPOL (0x0200) -#define QSPI_QMR_CPHA (0x0100) -#define QSPI_QMR_BAUD(x) ((x)&0x00FF) - -/* Bit definitions and macros for QSPI_QDLYR */ -#define QSPI_QDLYR_SPE (0x8000) -#define QSPI_QDLYR_QCD(x) (((x)&0x007F)<<8) -#define QSPI_QDLYR_DTL(x) ((x)&0x00FF) - -/* Bit definitions and macros for QSPI_QWR */ -#define QSPI_QWR_HALT (0x8000) -#define QSPI_QWR_WREN (0x4000) -#define QSPI_QWR_WRTO (0x2000) -#define QSPI_QWR_CSIV (0x1000) -#define QSPI_QWR_ENDQP(x) (((x)&0x000F)<<8) -#define QSPI_QWR_NEWQP(x) ((x)&0x000F) - -/* Bit definitions and macros for QSPI_QIR */ -#define QSPI_QIR_WCEFB (0x8000) -#define QSPI_QIR_ABRTB (0x4000) -#define QSPI_QIR_ABRTL (0x1000) -#define QSPI_QIR_WCEFE (0x0800) -#define QSPI_QIR_ABRTE (0x0400) -#define QSPI_QIR_SPIFE (0x0100) -#define QSPI_QIR_WCEF (0x0008) -#define QSPI_QIR_ABRT (0x0004) -#define QSPI_QIR_SPIF (0x0001) - -/* Bit definitions and macros for QSPI_QAR */ -#define QSPI_QAR_ADDR(x) ((x)&0x003F) - -/* Bit definitions and macros for QSPI_QDR */ -#define QSPI_QDR_CONT (0x8000) -#define QSPI_QDR_BITSE (0x4000) -#define QSPI_QDR_DT (0x2000) -#define QSPI_QDR_DSCK (0x1000) -#define QSPI_QDR_QSPI_CS3 (0x0800) -#define QSPI_QDR_QSPI_CS2 (0x0400) -#define QSPI_QDR_QSPI_CS1 (0x0200) -#define QSPI_QDR_QSPI_CS0 (0x0100) - -/********************************************************************* * Interrupt Controller (INTC) *********************************************************************/ #define INT0_LO_RSVD0 (0) @@ -370,85 +282,6 @@ #define INT1_HI_ETPU_TC31F (58) #define INT1_HI_ETPU_TGIF (59)
-/* Bit definitions and macros for INTC_IPRH */ -#define INTC_IPRH_INT63 (0x80000000) -#define INTC_IPRH_INT62 (0x40000000) -#define INTC_IPRH_INT61 (0x20000000) -#define INTC_IPRH_INT60 (0x10000000) -#define INTC_IPRH_INT59 (0x08000000) -#define INTC_IPRH_INT58 (0x04000000) -#define INTC_IPRH_INT57 (0x02000000) -#define INTC_IPRH_INT56 (0x01000000) -#define INTC_IPRH_INT55 (0x00800000) -#define INTC_IPRH_INT54 (0x00400000) -#define INTC_IPRH_INT53 (0x00200000) -#define INTC_IPRH_INT52 (0x00100000) -#define INTC_IPRH_INT51 (0x00080000) -#define INTC_IPRH_INT50 (0x00040000) -#define INTC_IPRH_INT49 (0x00020000) -#define INTC_IPRH_INT48 (0x00010000) -#define INTC_IPRH_INT47 (0x00008000) -#define INTC_IPRH_INT46 (0x00004000) -#define INTC_IPRH_INT45 (0x00002000) -#define INTC_IPRH_INT44 (0x00001000) -#define INTC_IPRH_INT43 (0x00000800) -#define INTC_IPRH_INT42 (0x00000400) -#define INTC_IPRH_INT41 (0x00000200) -#define INTC_IPRH_INT40 (0x00000100) -#define INTC_IPRH_INT39 (0x00000080) -#define INTC_IPRH_INT38 (0x00000040) -#define INTC_IPRH_INT37 (0x00000020) -#define INTC_IPRH_INT36 (0x00000010) -#define INTC_IPRH_INT35 (0x00000008) -#define INTC_IPRH_INT34 (0x00000004) -#define INTC_IPRH_INT33 (0x00000002) -#define INTC_IPRH_INT32 (0x00000001) - -/* Bit definitions and macros for INTC_IPRL */ -#define INTC_IPRL_INT31 (0x80000000) -#define INTC_IPRL_INT30 (0x40000000) -#define INTC_IPRL_INT29 (0x20000000) -#define INTC_IPRL_INT28 (0x10000000) -#define INTC_IPRL_INT27 (0x08000000) -#define INTC_IPRL_INT26 (0x04000000) -#define INTC_IPRL_INT25 (0x02000000) -#define INTC_IPRL_INT24 (0x01000000) -#define INTC_IPRL_INT23 (0x00800000) -#define INTC_IPRL_INT22 (0x00400000) -#define INTC_IPRL_INT21 (0x00200000) -#define INTC_IPRL_INT20 (0x00100000) -#define INTC_IPRL_INT19 (0x00080000) -#define INTC_IPRL_INT18 (0x00040000) -#define INTC_IPRL_INT17 (0x00020000) -#define INTC_IPRL_INT16 (0x00010000) -#define INTC_IPRL_INT15 (0x00008000) -#define INTC_IPRL_INT14 (0x00004000) -#define INTC_IPRL_INT13 (0x00002000) -#define INTC_IPRL_INT12 (0x00001000) -#define INTC_IPRL_INT11 (0x00000800) -#define INTC_IPRL_INT10 (0x00000400) -#define INTC_IPRL_INT9 (0x00000200) -#define INTC_IPRL_INT8 (0x00000100) -#define INTC_IPRL_INT7 (0x00000080) -#define INTC_IPRL_INT6 (0x00000040) -#define INTC_IPRL_INT5 (0x00000020) -#define INTC_IPRL_INT4 (0x00000010) -#define INTC_IPRL_INT3 (0x00000008) -#define INTC_IPRL_INT2 (0x00000004) -#define INTC_IPRL_INT1 (0x00000002) -#define INTC_IPRL_INT0 (0x00000001) - -/* Bit definitions and macros for INTC_IRLR */ -#define INTC_IRLRn(x) (((x)&0x7F)<<1) - -/* Bit definitions and macros for INTC_IACKLPRn */ -#define INTC_IACKLPRn_LEVEL(x) (((x)&0x07)<<4) -#define INTC_IACKLPRn_PRI(x) ((x)&0x0F) - -/* Bit definitions and macros for INTC_ICRnx */ -#define INTC_ICRnx_IL(x) (((x)&0x07)<<3) -#define INTC_ICRnx_IP(x) ((x)&0x07) - /********************************************************************* * General Purpose I/O (GPIO) *********************************************************************/ @@ -758,49 +591,6 @@ #define PLL_SYNSR_CALPASS (0x00000001)
/********************************************************************* - * Edge Port -*********************************************************************/ -#define EPORT_EPPAR_EPPA7(x) (((x)&0x03)<<14) -#define EPORT_EPPAR_EPPA6(x) (((x)&0x03)<<12) -#define EPORT_EPPAR_EPPA5(x) (((x)&0x03)<<10) -#define EPORT_EPPAR_EPPA4(x) (((x)&0x03)<<8) -#define EPORT_EPPAR_EPPA3(x) (((x)&0x03)<<6) -#define EPORT_EPPAR_EPPA2(x) (((x)&0x03)<<4) -#define EPORT_EPPAR_EPPA1(x) (((x)&0x03)<<2) - -#define EPORT_EPDDR_EPDD7(x) EPORT_EPPAR_EPPA7(x) -#define EPORT_EPDDR_EPDD6(x) EPORT_EPPAR_EPPA6(x) -#define EPORT_EPDDR_EPDD5(x) EPORT_EPPAR_EPPA5(x) -#define EPORT_EPDDR_EPDD4(x) EPORT_EPPAR_EPPA4(x) -#define EPORT_EPDDR_EPDD3(x) EPORT_EPPAR_EPPA3(x) -#define EPORT_EPDDR_EPDD2(x) EPORT_EPPAR_EPPA2(x) -#define EPORT_EPDDR_EPDD1(x) EPORT_EPPAR_EPPA1(x) - -#define EPORT_EPIER_EPIE7 (0x80) -#define EPORT_EPIER_EPIE6 (0x40) -#define EPORT_EPIER_EPIE5 (0x20) -#define EPORT_EPIER_EPIE4 (0x10) -#define EPORT_EPIER_EPIE3 (0x08) -#define EPORT_EPIER_EPIE2 (0x04) -#define EPORT_EPIER_EPIE1 (0x02) - -#define EPORT_EPDR_EPDR7 EPORT_EPIER_EPIE7 -#define EPORT_EPDR_EPDR6 EPORT_EPIER_EPIE6 -#define EPORT_EPDR_EPDR5 EPORT_EPIER_EPIE5 -#define EPORT_EPDR_EPDR4 EPORT_EPIER_EPIE4 -#define EPORT_EPDR_EPDR3 EPORT_EPIER_EPIE3 -#define EPORT_EPDR_EPDR2 EPORT_EPIER_EPIE2 -#define EPORT_EPDR_EPDR1 EPORT_EPIER_EPIE1 - -#define EPORT_EPPDR_EPPDR7 EPORT_EPIER_EPIE7 -#define EPORT_EPPDR_EPPDR6 EPORT_EPIER_EPIE6 -#define EPORT_EPPDR_EPPDR5 EPORT_EPIER_EPIE5 -#define EPORT_EPPDR_EPPDR4 EPORT_EPIER_EPIE4 -#define EPORT_EPPDR_EPPDR3 EPORT_EPIER_EPIE3 -#define EPORT_EPPDR_EPPDR2 EPORT_EPIER_EPIE2 -#define EPORT_EPPDR_EPPDR1 EPORT_EPIER_EPIE1 - -/********************************************************************* * Watchdog Timer Modules (WTM) *********************************************************************/ /* Bit definitions and macros for WTM_WCR */ @@ -809,97 +599,4 @@ #define WTM_WCR_HALTED (0x0002) #define WTM_WCR_EN (0x0001)
-/********************************************************************* -* FlexCAN Module (CAN) -*********************************************************************/ -/* Bit definitions and macros for CAN_CANMCR */ -#define CANMCR_MDIS (0x80000000) -#define CANMCR_FRZ (0x40000000) -#define CANMCR_HALT (0x10000000) -#define CANMCR_NORDY (0x08000000) -#define CANMCR_SOFTRST (0x02000000) -#define CANMCR_FRZACK (0x01000000) -#define CANMCR_SUPV (0x00800000) -#define CANMCR_LPMACK (0x00100000) -#define CANMCR_MAXMB(x) (((x)&0x0F)) - -/* Bit definitions and macros for CAN_CANCTRL */ -#define CANCTRL_PRESDIV(x) (((x)&0xFF)<<24) -#define CANCTRL_RJW(x) (((x)&0x03)<<22) -#define CANCTRL_PSEG1(x) (((x)&0x07)<<19) -#define CANCTRL_PSEG2(x) (((x)&0x07)<<16) -#define CANCTRL_BOFFMSK (0x00008000) -#define CANCTRL_ERRMSK (0x00004000) -#define CANCTRL_CLKSRC (0x00002000) -#define CANCTRL_LPB (0x00001000) -#define CANCTRL_SMP (0x00000080) -#define CANCTRL_BOFFREC (0x00000040) -#define CANCTRL_TSYNC (0x00000020) -#define CANCTRL_LBUF (0x00000010) -#define CANCTRL_LOM (0x00000008) -#define CANCTRL_PROPSEG(x) (((x)&0x07)) - -/* Bit definitions and macros for CAN_TIMER */ -#define TIMER_TIMER(x) ((x)&0xFFFF) - -/* Bit definitions and macros for CAN_RXGMASK */ -#define RXGMASK_MI(x) ((x)&0x1FFFFFFF) - -/* Bit definitions and macros for CAN_ERRCNT */ -#define ERRCNT_TXECTR(x) (((x)&0xFF)) -#define ERRCNT_RXECTR(x) (((x)&0xFF)<<8) - -/* Bit definitions and macros for CAN_ERRSTAT */ -#define ERRSTAT_BITERR1 (0x00008000) -#define ERRSTAT_BITERR0 (0x00004000) -#define ERRSTAT_ACKERR (0x00002000) -#define ERRSTAT_CRCERR (0x00001000) -#define ERRSTAT_FRMERR (0x00000800) -#define ERRSTAT_STFERR (0x00000400) -#define ERRSTAT_TXWRN (0x00000200) -#define ERRSTAT_RXWRN (0x00000100) -#define ERRSTAT_IDLE (0x00000080) -#define ERRSTAT_TXRX (0x00000040) -#define ERRSTAT_FLT_BUSOFF (0x00000020) -#define ERRSTAT_FLT_PASSIVE (0x00000010) -#define ERRSTAT_FLT_ACTIVE (0x00000000) -#define ERRSTAT_BOFFINT (0x00000004) -#define ERRSTAT_ERRINT (0x00000002) - -/* Bit definitions and macros for CAN_IMASK */ -#define IMASK_BUF15M (0x00008000) -#define IMASK_BUF14M (0x00004000) -#define IMASK_BUF13M (0x00002000) -#define IMASK_BUF12M (0x00001000) -#define IMASK_BUF11M (0x00000800) -#define IMASK_BUF10M (0x00000400) -#define IMASK_BUF9M (0x00000200) -#define IMASK_BUF8M (0x00000100) -#define IMASK_BUF7M (0x00000080) -#define IMASK_BUF6M (0x00000040) -#define IMASK_BUF5M (0x00000020) -#define IMASK_BUF4M (0x00000010) -#define IMASK_BUF3M (0x00000008) -#define IMASK_BUF2M (0x00000004) -#define IMASK_BUF1M (0x00000002) -#define IMASK_BUF0M (0x00000001) - -/* Bit definitions and macros for CAN_IFLAG */ -#define IFLAG_BUF15I (0x00008000) -#define IFLAG_BUF14I (0x00004000) -#define IFLAG_BUF13I (0x00002000) -#define IFLAG_BUF12I (0x00001000) -#define IFLAG_BUF11I (0x00000800) -#define IFLAG_BUF10I (0x00000400) -#define IFLAG_BUF9I (0x00000200) -#define IFLAG_BUF8I (0x00000100) -#define IFLAG_BUF7I (0x00000080) -#define IFLAG_BUF6I (0x00000040) -#define IFLAG_BUF5I (0x00000020) -#define IFLAG_BUF4I (0x00000010) -#define IFLAG_BUF3I (0x00000008) -#define IFLAG_BUF2I (0x00000004) -#define IFLAG_BUF1I (0x00000002) -#define IFLAG_BUF0I (0x00000001) - #endif /* mcf5235_h */ diff --git a/include/asm-m68k/m5249.h b/include/asm-m68k/m5249.h index feb675c..fa0cb14 100644 --- a/include/asm-m68k/m5249.h +++ b/include/asm-m68k/m5249.h @@ -77,19 +77,6 @@ #define MCFSIM_IPR 0x40 /* Interrupt Pend reg (r/w) */ #define MCFSIM_IMR 0x44 /* Interrupt Mask reg (r/w) */
-#define MCFSIM_CSAR0 0x80 /* CS 0 Address 0 reg (r/w) */ -#define MCFSIM_CSMR0 0x84 /* CS 0 Mask 0 reg (r/w) */ -#define MCFSIM_CSCR0 0x8a /* CS 0 Control reg (r/w) */ -#define MCFSIM_CSAR1 0x8c /* CS 1 Address reg (r/w) */ -#define MCFSIM_CSMR1 0x90 /* CS 1 Mask reg (r/w) */ -#define MCFSIM_CSCR1 0x96 /* CS 1 Control reg (r/w) */ -#define MCFSIM_CSAR2 0x98 /* CS 2 Address reg (r/w) */ -#define MCFSIM_CSMR2 0x9c /* CS 2 Mask reg (r/w) */ -#define MCFSIM_CSCR2 0xa2 /* CS 2 Control reg (r/w) */ -#define MCFSIM_CSAR3 0xa4 /* CS 3 Address reg (r/w) */ -#define MCFSIM_CSMR3 0xa8 /* CS 3 Mask reg (r/w) */ -#define MCFSIM_CSCR3 0xae /* CS 3 Control reg (r/w) */ - #define MCFSIM_DCR 0x100 /* DRAM Control reg (r/w) */ #define MCFSIM_DACR0 0x108 /* DRAM 0 Addr and Ctrl (r/w) */ #define MCFSIM_DMR0 0x10c /* DRAM 0 Mask reg (r/w) */ diff --git a/include/asm-m68k/m5271.h b/include/asm-m68k/m5271.h index 000f0a5..7877616 100644 --- a/include/asm-m68k/m5271.h +++ b/include/asm-m68k/m5271.h @@ -116,9 +116,7 @@
#define MCFSIM_ICR1 0x000C41
-/********************************************************************* -* Interrupt Controller (INTC) -*********************************************************************/ +/* Interrupt Controller (INTC) */ #define INT0_LO_RSVD0 (0) #define INT0_LO_EPORT1 (1) #define INT0_LO_EPORT2 (2) @@ -182,38 +180,4 @@ #define INT0_HI_CAN1_BOFFINT (60) /* 60-63 Reserved */
-/* Bit definitions and macros for INTC_IPRL */ -#define INTC_IPRL_INT31 (0x80000000) -#define INTC_IPRL_INT30 (0x40000000) -#define INTC_IPRL_INT29 (0x20000000) -#define INTC_IPRL_INT28 (0x10000000) -#define INTC_IPRL_INT27 (0x08000000) -#define INTC_IPRL_INT26 (0x04000000) -#define INTC_IPRL_INT25 (0x02000000) -#define INTC_IPRL_INT24 (0x01000000) -#define INTC_IPRL_INT23 (0x00800000) -#define INTC_IPRL_INT22 (0x00400000) -#define INTC_IPRL_INT21 (0x00200000) -#define INTC_IPRL_INT20 (0x00100000) -#define INTC_IPRL_INT19 (0x00080000) -#define INTC_IPRL_INT18 (0x00040000) -#define INTC_IPRL_INT17 (0x00020000) -#define INTC_IPRL_INT16 (0x00010000) -#define INTC_IPRL_INT15 (0x00008000) -#define INTC_IPRL_INT14 (0x00004000) -#define INTC_IPRL_INT13 (0x00002000) -#define INTC_IPRL_INT12 (0x00001000) -#define INTC_IPRL_INT11 (0x00000800) -#define INTC_IPRL_INT10 (0x00000400) -#define INTC_IPRL_INT9 (0x00000200) -#define INTC_IPRL_INT8 (0x00000100) -#define INTC_IPRL_INT7 (0x00000080) -#define INTC_IPRL_INT6 (0x00000040) -#define INTC_IPRL_INT5 (0x00000020) -#define INTC_IPRL_INT4 (0x00000010) -#define INTC_IPRL_INT3 (0x00000008) -#define INTC_IPRL_INT2 (0x00000004) -#define INTC_IPRL_INT1 (0x00000002) -#define INTC_IPRL_INT0 (0x00000001) - #endif /* _MCF5271_H_ */ diff --git a/include/asm-m68k/m5275.h b/include/asm-m68k/m5275.h index 89c6c92..24dbae2 100644 --- a/include/asm-m68k/m5275.h +++ b/include/asm-m68k/m5275.h @@ -30,18 +30,6 @@ * Define the 5275 SIM register set addresses. These are similar, * but not quite identical to the 5282 registers and offsets. */ -#define MCFICM_INTC0 0x0c00 /* Base for Interrupt Ctrl 0 */ -#define MCFICM_INTC1 0x0d00 /* Base for Interrupt Ctrl 1 */ -#define MCFINTC_IPRH 0x00 /* Interrupt pending 32-63 */ -#define MCFINTC_IPRL 0x04 /* Interrupt pending 1-31 */ -#define MCFINTC_IMRH 0x08 /* Interrupt mask 32-63 */ -#define MCFINTC_IMRL 0x0c /* Interrupt mask 1-31 */ -#define MCFINTC_INTFRCH 0x10 /* Interrupt force 32-63 */ -#define MCFINTC_INTFRCL 0x14 /* Interrupt force 1-31 */ -#define MCFINTC_IRLR 0x18 /* */ -#define MCFINTC_IACKL 0x19 /* */ -#define MCFINTC_ICR0 0x40 /* Base ICR register */ - #define MCF_GPIO_PAR_UART 0x10007c #define UART0_ENABLE_MASK 0x000f #define UART1_ENABLE_MASK 0x00f0 @@ -198,40 +186,6 @@ #define INT1_HI_FEC1_BABR (35) /* 36-63 Reserved */
-/* Bit definitions and macros for INTC_IPRL */ -#define INTC_IPRL_INT31 (0x80000000) -#define INTC_IPRL_INT30 (0x40000000) -#define INTC_IPRL_INT29 (0x20000000) -#define INTC_IPRL_INT28 (0x10000000) -#define INTC_IPRL_INT27 (0x08000000) -#define INTC_IPRL_INT26 (0x04000000) -#define INTC_IPRL_INT25 (0x02000000) -#define INTC_IPRL_INT24 (0x01000000) -#define INTC_IPRL_INT23 (0x00800000) -#define INTC_IPRL_INT22 (0x00400000) -#define INTC_IPRL_INT21 (0x00200000) -#define INTC_IPRL_INT20 (0x00100000) -#define INTC_IPRL_INT19 (0x00080000) -#define INTC_IPRL_INT18 (0x00040000) -#define INTC_IPRL_INT17 (0x00020000) -#define INTC_IPRL_INT16 (0x00010000) -#define INTC_IPRL_INT15 (0x00008000) -#define INTC_IPRL_INT14 (0x00004000) -#define INTC_IPRL_INT13 (0x00002000) -#define INTC_IPRL_INT12 (0x00001000) -#define INTC_IPRL_INT11 (0x00000800) -#define INTC_IPRL_INT10 (0x00000400) -#define INTC_IPRL_INT9 (0x00000200) -#define INTC_IPRL_INT8 (0x00000100) -#define INTC_IPRL_INT7 (0x00000080) -#define INTC_IPRL_INT6 (0x00000040) -#define INTC_IPRL_INT5 (0x00000020) -#define INTC_IPRL_INT4 (0x00000010) -#define INTC_IPRL_INT3 (0x00000008) -#define INTC_IPRL_INT2 (0x00000004) -#define INTC_IPRL_INT1 (0x00000002) -#define INTC_IPRL_INT0 (0x00000001) - /* Bit definitions and macros for RCR */ #define RCM_RCR_FRCRSTOUT (0x40) #define RCM_RCR_SOFTRST (0x80) diff --git a/include/asm-m68k/m5282.h b/include/asm-m68k/m5282.h index 772c7e0..d59a8b2 100644 --- a/include/asm-m68k/m5282.h +++ b/include/asm-m68k/m5282.h @@ -440,29 +440,6 @@ #define MCFWTM_WCNTR (*(vu_short *)(CONFIG_SYS_MBAR+0x00140004)) #define MCFWTM_WSR (*(vu_short *)(CONFIG_SYS_MBAR+0x00140006))
-/* Chip SELECT Module CSM */ -#define MCFCSM_CSAR0 (*(vu_short *)(CONFIG_SYS_MBAR+0x00000080)) -#define MCFCSM_CSMR0 (*(vu_long *) (CONFIG_SYS_MBAR+0x00000084)) -#define MCFCSM_CSCR0 (*(vu_short *)(CONFIG_SYS_MBAR+0x0000008a)) -#define MCFCSM_CSAR1 (*(vu_short *)(CONFIG_SYS_MBAR+0x0000008C)) -#define MCFCSM_CSMR1 (*(vu_long *) (CONFIG_SYS_MBAR+0x00000090)) -#define MCFCSM_CSCR1 (*(vu_short *)(CONFIG_SYS_MBAR+0x00000096)) -#define MCFCSM_CSAR2 (*(vu_short *)(CONFIG_SYS_MBAR+0x00000098)) -#define MCFCSM_CSMR2 (*(vu_long *) (CONFIG_SYS_MBAR+0x0000009C)) -#define MCFCSM_CSCR2 (*(vu_short *)(CONFIG_SYS_MBAR+0x000000A2)) -#define MCFCSM_CSAR3 (*(vu_short *)(CONFIG_SYS_MBAR+0x000000A4)) -#define MCFCSM_CSMR3 (*(vu_long *) (CONFIG_SYS_MBAR+0x000000A8)) -#define MCFCSM_CSCR3 (*(vu_short *)(CONFIG_SYS_MBAR+0x000000AE)) - -#define MCFCSM_CSMR_BAM(x) ((x) & 0xFFFF0000) -#define MCFCSM_CSMR_WP (1<<8) -#define MCFCSM_CSMR_V (0x01) -#define MCFCSM_CSCR_WS(x) ((x & 0x0F)<<10) -#define MCFCSM_CSCR_AA (0x0100) -#define MCFCSM_CSCR_PS_32 (0x0000) -#define MCFCSM_CSCR_PS_8 (0x0040) -#define MCFCSM_CSCR_PS_16 (0x0080) - /********************************************************************* * General Purpose Timer (GPT) Module *********************************************************************/ diff --git a/include/asm-m68k/m5329.h b/include/asm-m68k/m5329.h index c1669dc..c7ebed1 100644 --- a/include/asm-m68k/m5329.h +++ b/include/asm-m68k/m5329.h @@ -187,65 +187,6 @@ #define CFATR_TYPE (0x01)
/********************************************************************* -* FlexBus Chip Selects (FBCS) -*********************************************************************/ -/* Bit definitions and macros for FBCS_CSAR */ -#define CSAR_BA(x) (((x)&0xFFFF)<<16) - -/* Bit definitions and macros for FBCS_CSMR */ -#define CSMR_BAM(x) (((x)&0xFFFF)<<16) -#define CSMR_BAM_4G (0xFFFF0000) -#define CSMR_BAM_2G (0x7FFF0000) -#define CSMR_BAM_1G (0x3FFF0000) -#define CSMR_BAM_1024M (0x3FFF0000) -#define CSMR_BAM_512M (0x1FFF0000) -#define CSMR_BAM_256M (0x0FFF0000) -#define CSMR_BAM_128M (0x07FF0000) -#define CSMR_BAM_64M (0x03FF0000) -#define CSMR_BAM_32M (0x01FF0000) -#define CSMR_BAM_16M (0x00FF0000) -#define CSMR_BAM_8M (0x007F0000) -#define CSMR_BAM_4M (0x003F0000) -#define CSMR_BAM_2M (0x001F0000) -#define CSMR_BAM_1M (0x000F0000) -#define CSMR_BAM_1024K (0x000F0000) -#define CSMR_BAM_512K (0x00070000) -#define CSMR_BAM_256K (0x00030000) -#define CSMR_BAM_128K (0x00010000) -#define CSMR_BAM_64K (0x00000000) -#define CSMR_WP (0x00000100) -#define CSMR_V (0x00000001) - -/* Bit definitions and macros for FBCS_CSCR */ -#define CSCR_SWS(x) (((x)&0x3F)<<26) -#define CSCR_ASET(x) (((x)&0x03)<<20) -#define CSCR_SWSEN (0x00800000) -#define CSCR_ASET_4CLK (0x00300000) -#define CSCR_ASET_3CLK (0x00200000) -#define CSCR_ASET_2CLK (0x00100000) -#define CSCR_ASET_1CLK (0x00000000) -#define CSCR_RDAH(x) (((x)&0x03)<<18) -#define CSCR_RDAH_4CYC (0x000C0000) -#define CSCR_RDAH_3CYC (0x00080000) -#define CSCR_RDAH_2CYC (0x00040000) -#define CSCR_RDAH_1CYC (0x00000000) -#define CSCR_WRAH(x) (((x)&0x03)<<16) -#define CSCR_WDAH_4CYC (0x00003000) -#define CSCR_WDAH_3CYC (0x00002000) -#define CSCR_WDAH_2CYC (0x00001000) -#define CSCR_WDAH_1CYC (0x00000000) -#define CSCR_WS(x) (((x)&0x3F)<<10) -#define CSCR_SBM (0x00000200) -#define CSCR_AA (0x00000100) -#define CSCR_PS_MASK (0x000000C0) -#define CSCR_PS_32 (0x00000000) -#define CSCR_PS_16 (0x00000080) -#define CSCR_PS_8 (0x00000040) -#define CSCR_BEM (0x00000020) -#define CSCR_BSTR (0x00000010) -#define CSCR_BSTW (0x00000008) - -/********************************************************************* * Reset Controller Module (RCM) *********************************************************************/
@@ -261,100 +202,6 @@ #define RCM_RSR_SOFT (0x20)
/********************************************************************* -* FlexCAN Module (CAN) -*********************************************************************/ -/* Bit definitions and macros for CAN_CANMCR */ -#define CANMCR_MDIS (0x80000000) -#define CANMCR_FRZ (0x40000000) -#define CANMCR_HALT (0x10000000) -#define CANMCR_NORDY (0x08000000) -#define CANMCR_SOFTRST (0x02000000) -#define CANMCR_FRZACK (0x01000000) -#define CANMCR_SUPV (0x00800000) -#define CANMCR_LPMACK (0x00100000) -#define CANMCR_MAXMB(x) (((x)&0x0F)) - -/* Bit definitions and macros for CAN_CANCTRL */ -#define CANCTRL_PRESDIV(x) (((x)&0xFF)<<24) -#define CANCTRL_RJW(x) (((x)&0x03)<<22) -#define CANCTRL_PSEG1(x) (((x)&0x07)<<19) -#define CANCTRL_PSEG2(x) (((x)&0x07)<<16) -#define CANCTRL_BOFFMSK (0x00008000) -#define CANCTRL_ERRMSK (0x00004000) -#define CANCTRL_CLKSRC (0x00002000) -#define CANCTRL_LPB (0x00001000) -#define CANCTRL_SMP (0x00000080) -#define CANCTRL_BOFFREC (0x00000040) -#define CANCTRL_TSYNC (0x00000020) -#define CANCTRL_LBUF (0x00000010) -#define CANCTRL_LOM (0x00000008) -#define CANCTRL_PROPSEG(x) (((x)&0x07)) - -/* Bit definitions and macros for CAN_TIMER */ -#define TIMER_TIMER(x) ((x)&0xFFFF) - -/* Bit definitions and macros for CAN_RXGMASK */ -#define RXGMASK_MI(x) ((x)&0x1FFFFFFF) - -/* Bit definitions and macros for CAN_ERRCNT */ -#define ERRCNT_TXECTR(x) (((x)&0xFF)) -#define ERRCNT_RXECTR(x) (((x)&0xFF)<<8) - -/* Bit definitions and macros for CAN_ERRSTAT */ -#define ERRSTAT_BITERR1 (0x00008000) -#define ERRSTAT_BITERR0 (0x00004000) -#define ERRSTAT_ACKERR (0x00002000) -#define ERRSTAT_CRCERR (0x00001000) -#define ERRSTAT_FRMERR (0x00000800) -#define ERRSTAT_STFERR (0x00000400) -#define ERRSTAT_TXWRN (0x00000200) -#define ERRSTAT_RXWRN (0x00000100) -#define ERRSTAT_IDLE (0x00000080) -#define ERRSTAT_TXRX (0x00000040) -#define ERRSTAT_FLT_BUSOFF (0x00000020) -#define ERRSTAT_FLT_PASSIVE (0x00000010) -#define ERRSTAT_FLT_ACTIVE (0x00000000) -#define ERRSTAT_BOFFINT (0x00000004) -#define ERRSTAT_ERRINT (0x00000002) -#define ERRSTAT_WAKINT (0x00000001) - -/* Bit definitions and macros for CAN_IMASK */ -#define IMASK_BUF15M (0x00008000) -#define IMASK_BUF14M (0x00004000) -#define IMASK_BUF13M (0x00002000) -#define IMASK_BUF12M (0x00001000) -#define IMASK_BUF11M (0x00000800) -#define IMASK_BUF10M (0x00000400) -#define IMASK_BUF9M (0x00000200) -#define IMASK_BUF8M (0x00000100) -#define IMASK_BUF7M (0x00000080) -#define IMASK_BUF6M (0x00000040) -#define IMASK_BUF5M (0x00000020) -#define IMASK_BUF4M (0x00000010) -#define IMASK_BUF3M (0x00000008) -#define IMASK_BUF2M (0x00000004) -#define IMASK_BUF1M (0x00000002) -#define IMASK_BUF0M (0x00000001) - -/* Bit definitions and macros for CAN_IFLAG */ -#define IFLAG_BUF15I (0x00008000) -#define IFLAG_BUF14I (0x00004000) -#define IFLAG_BUF13I (0x00002000) -#define IFLAG_BUF12I (0x00001000) -#define IFLAG_BUF11I (0x00000800) -#define IFLAG_BUF10I (0x00000400) -#define IFLAG_BUF9I (0x00000200) -#define IFLAG_BUF8I (0x00000100) -#define IFLAG_BUF7I (0x00000080) -#define IFLAG_BUF6I (0x00000040) -#define IFLAG_BUF5I (0x00000020) -#define IFLAG_BUF4I (0x00000010) -#define IFLAG_BUF3I (0x00000008) -#define IFLAG_BUF2I (0x00000004) -#define IFLAG_BUF1I (0x00000002) -#define IFLAG_BUF0I (0x00000001) - -/********************************************************************* * Interrupt Controller (INTC) *********************************************************************/ #define INTC0_EPORT INTC_IPRL_INT1 @@ -411,200 +258,6 @@ /* 49 - 61 Reserved */ #define INT0_HI_SCM (62)
-/* Bit definitions and macros for INTC_IPRH */ -#define INTC_IPRH_INT63 (0x80000000) -#define INTC_IPRH_INT62 (0x40000000) -#define INTC_IPRH_INT61 (0x20000000) -#define INTC_IPRH_INT60 (0x10000000) -#define INTC_IPRH_INT59 (0x08000000) -#define INTC_IPRH_INT58 (0x04000000) -#define INTC_IPRH_INT57 (0x02000000) -#define INTC_IPRH_INT56 (0x01000000) -#define INTC_IPRH_INT55 (0x00800000) -#define INTC_IPRH_INT54 (0x00400000) -#define INTC_IPRH_INT53 (0x00200000) -#define INTC_IPRH_INT52 (0x00100000) -#define INTC_IPRH_INT51 (0x00080000) -#define INTC_IPRH_INT50 (0x00040000) -#define INTC_IPRH_INT49 (0x00020000) -#define INTC_IPRH_INT48 (0x00010000) -#define INTC_IPRH_INT47 (0x00008000) -#define INTC_IPRH_INT46 (0x00004000) -#define INTC_IPRH_INT45 (0x00002000) -#define INTC_IPRH_INT44 (0x00001000) -#define INTC_IPRH_INT43 (0x00000800) -#define INTC_IPRH_INT42 (0x00000400) -#define INTC_IPRH_INT41 (0x00000200) -#define INTC_IPRH_INT40 (0x00000100) -#define INTC_IPRH_INT39 (0x00000080) -#define INTC_IPRH_INT38 (0x00000040) -#define INTC_IPRH_INT37 (0x00000020) -#define INTC_IPRH_INT36 (0x00000010) -#define INTC_IPRH_INT35 (0x00000008) -#define INTC_IPRH_INT34 (0x00000004) -#define INTC_IPRH_INT33 (0x00000002) -#define INTC_IPRH_INT32 (0x00000001) - -/* Bit definitions and macros for INTC_IPRL */ -#define INTC_IPRL_INT31 (0x80000000) -#define INTC_IPRL_INT30 (0x40000000) -#define INTC_IPRL_INT29 (0x20000000) -#define INTC_IPRL_INT28 (0x10000000) -#define INTC_IPRL_INT27 (0x08000000) -#define INTC_IPRL_INT26 (0x04000000) -#define INTC_IPRL_INT25 (0x02000000) -#define INTC_IPRL_INT24 (0x01000000) -#define INTC_IPRL_INT23 (0x00800000) -#define INTC_IPRL_INT22 (0x00400000) -#define INTC_IPRL_INT21 (0x00200000) -#define INTC_IPRL_INT20 (0x00100000) -#define INTC_IPRL_INT19 (0x00080000) -#define INTC_IPRL_INT18 (0x00040000) -#define INTC_IPRL_INT17 (0x00020000) -#define INTC_IPRL_INT16 (0x00010000) -#define INTC_IPRL_INT15 (0x00008000) -#define INTC_IPRL_INT14 (0x00004000) -#define INTC_IPRL_INT13 (0x00002000) -#define INTC_IPRL_INT12 (0x00001000) -#define INTC_IPRL_INT11 (0x00000800) -#define INTC_IPRL_INT10 (0x00000400) -#define INTC_IPRL_INT9 (0x00000200) -#define INTC_IPRL_INT8 (0x00000100) -#define INTC_IPRL_INT7 (0x00000080) -#define INTC_IPRL_INT6 (0x00000040) -#define INTC_IPRL_INT5 (0x00000020) -#define INTC_IPRL_INT4 (0x00000010) -#define INTC_IPRL_INT3 (0x00000008) -#define INTC_IPRL_INT2 (0x00000004) -#define INTC_IPRL_INT1 (0x00000002) -#define INTC_IPRL_INT0 (0x00000001) - -/* Bit definitions and macros for INTC_ICONFIG */ -#define INTC_ICFG_ELVLPRI7 (0x8000) -#define INTC_ICFG_ELVLPRI6 (0x4000) -#define INTC_ICFG_ELVLPRI5 (0x2000) -#define INTC_ICFG_ELVLPRI4 (0x1000) -#define INTC_ICFG_ELVLPRI3 (0x0800) -#define INTC_ICFG_ELVLPRI2 (0x0400) -#define INTC_ICFG_ELVLPRI1 (0x0200) -#define INTC_ICFG_EMASK (0x0020) - -/* Bit definitions and macros for INTC_SIMR */ -#define INTC_SIMR_SALL (0x40) -#define INTC_SIMR_SIMR(x) ((x)&0x3F) - -/* Bit definitions and macros for INTC_CIMR */ -#define INTC_CIMR_CALL (0x40) -#define INTC_CIMR_CIMR(x) ((x)&0x3F) - -/* Bit definitions and macros for INTC_CLMASK */ -#define INTC_CLMASK_CLMASK(x) ((x)&0x0F) - -/* Bit definitions and macros for INTC_SLMASK */ -#define INTC_SLMASK_SLMASK(x) ((x)&0x0F) - -/* Bit definitions and macros for INTC_ICR */ -#define INTC_ICR_IL(x) ((x)&0x07) - -/********************************************************************* -* Queued Serial Peripheral Interface (QSPI) -*********************************************************************/ -/* Bit definitions and macros for QSPI_QMR */ -#define QSPI_QMR_MSTR (0x8000) -#define QSPI_QMR_DOHIE (0x4000) -#define QSPI_QMR_BITS(x) (((x)&0x000F)<<10) -#define QSPI_QMR_CPOL (0x0200) -#define QSPI_QMR_CPHA (0x0100) -#define QSPI_QMR_BAUD(x) ((x)&0x00FF) - -/* Bit definitions and macros for QSPI_QDLYR */ -#define QSPI_QDLYR_SPE (0x8000) -#define QSPI_QDLYR_QCD(x) (((x)&0x007F)<<8) -#define QSPI_QDLYR_DTL(x) ((x)&0x00FF) - -/* Bit definitions and macros for QSPI_QWR */ -#define QSPI_QWR_NEWQP(x) ((x)&0x000F) -#define QSPI_QWR_ENDQP(x) (((x)&0x000F)<<8) -#define QSPI_QWR_CSIV (0x1000) -#define QSPI_QWR_WRTO (0x2000) -#define QSPI_QWR_WREN (0x4000) -#define QSPI_QWR_HALT (0x8000) - -/* Bit definitions and macros for QSPI_QIR */ -#define QSPI_QIR_WCEFB (0x8000) -#define QSPI_QIR_ABRTB (0x4000) -#define QSPI_QIR_ABRTL (0x1000) -#define QSPI_QIR_WCEFE (0x0800) -#define QSPI_QIR_ABRTE (0x0400) -#define QSPI_QIR_SPIFE (0x0100) -#define QSPI_QIR_WCEF (0x0008) -#define QSPI_QIR_ABRT (0x0004) -#define QSPI_QIR_SPIF (0x0001) - -/* Bit definitions and macros for QSPI_QAR */ -#define QSPI_QAR_ADDR(x) ((x)&0x003F) -#define QSPI_QAR_TRANS (0x0000) -#define QSPI_QAR_RECV (0x0010) -#define QSPI_QAR_CMD (0x0020) - -/* Bit definitions and macros for QSPI_QDR */ -#define QSPI_QDR_CONT (0x8000) -#define QSPI_QDR_BITSE (0x4000) -#define QSPI_QDR_DT (0x2000) -#define QSPI_QDR_DSCK (0x1000) -#define QSPI_QDR_QSPI_CS3 (0x0800) -#define QSPI_QDR_QSPI_CS2 (0x0400) -#define QSPI_QDR_QSPI_CS1 (0x0200) -#define QSPI_QDR_QSPI_CS0 (0x0100) - -/********************************************************************* -* Pulse Width Modulation (PWM) -*********************************************************************/ -/* Bit definitions and macros for PWM_E */ -#define PWM_EN_PWME7 (0x80) -#define PWM_EN_PWME5 (0x20) -#define PWM_EN_PWME3 (0x08) -#define PWM_EN_PWME1 (0x02) - -/* Bit definitions and macros for PWM_POL */ -#define PWM_POL_PPOL7 (0x80) -#define PWM_POL_PPOL5 (0x20) -#define PWM_POL_PPOL3 (0x08) -#define PWM_POL_PPOL1 (0x02) - -/* Bit definitions and macros for PWM_CLK */ -#define PWM_CLK_PCLK7 (0x80) -#define PWM_CLK_PCLK5 (0x20) -#define PWM_CLK_PCLK3 (0x08) -#define PWM_CLK_PCLK1 (0x02) - -/* Bit definitions and macros for PWM_PRCLK */ -#define PWM_PRCLK_PCKB(x) (((x)&0x07)<<4) -#define PWM_PRCLK_PCKA(x) ((x)&0x07) - -/* Bit definitions and macros for PWM_CAE */ -#define PWM_CAE_CAE7 (0x80) -#define PWM_CAE_CAE5 (0x20) -#define PWM_CAE_CAE3 (0x08) -#define PWM_CAE_CAE1 (0x02) - -/* Bit definitions and macros for PWM_CTL */ -#define PWM_CTL_CON67 (0x80) -#define PWM_CTL_CON45 (0x40) -#define PWM_CTL_CON23 (0x20) -#define PWM_CTL_CON01 (0x10) -#define PWM_CTL_PSWAR (0x08) -#define PWM_CTL_PFRZ (0x04) - -/* Bit definitions and macros for PWM_SDN */ -#define PWM_SDN_IF (0x80) -#define PWM_SDN_IE (0x40) -#define PWM_SDN_RESTART (0x20) -#define PWM_SDN_LVL (0x10) -#define PWM_SDN_PWM7IN (0x04) -#define PWM_SDN_PWM7IL (0x02) -#define PWM_SDN_SDNEN (0x01) - /********************************************************************* * Watchdog Timer Modules (WTM) *********************************************************************/ diff --git a/include/asm-m68k/m5445x.h b/include/asm-m68k/m5445x.h index 7fcf4ef..5966621 100644 --- a/include/asm-m68k/m5445x.h +++ b/include/asm-m68k/m5445x.h @@ -114,325 +114,6 @@ #define INT1_HI_PCI_ASR (56) #define INT1_HI_PLL_LOCKS (57)
-/* Bit definitions and macros for IPRH */ -#define INTC_IPRH_INT32 (0x00000001) -#define INTC_IPRH_INT33 (0x00000002) -#define INTC_IPRH_INT34 (0x00000004) -#define INTC_IPRH_INT35 (0x00000008) -#define INTC_IPRH_INT36 (0x00000010) -#define INTC_IPRH_INT37 (0x00000020) -#define INTC_IPRH_INT38 (0x00000040) -#define INTC_IPRH_INT39 (0x00000080) -#define INTC_IPRH_INT40 (0x00000100) -#define INTC_IPRH_INT41 (0x00000200) -#define INTC_IPRH_INT42 (0x00000400) -#define INTC_IPRH_INT43 (0x00000800) -#define INTC_IPRH_INT44 (0x00001000) -#define INTC_IPRH_INT45 (0x00002000) -#define INTC_IPRH_INT46 (0x00004000) -#define INTC_IPRH_INT47 (0x00008000) -#define INTC_IPRH_INT48 (0x00010000) -#define INTC_IPRH_INT49 (0x00020000) -#define INTC_IPRH_INT50 (0x00040000) -#define INTC_IPRH_INT51 (0x00080000) -#define INTC_IPRH_INT52 (0x00100000) -#define INTC_IPRH_INT53 (0x00200000) -#define INTC_IPRH_INT54 (0x00400000) -#define INTC_IPRH_INT55 (0x00800000) -#define INTC_IPRH_INT56 (0x01000000) -#define INTC_IPRH_INT57 (0x02000000) -#define INTC_IPRH_INT58 (0x04000000) -#define INTC_IPRH_INT59 (0x08000000) -#define INTC_IPRH_INT60 (0x10000000) -#define INTC_IPRH_INT61 (0x20000000) -#define INTC_IPRH_INT62 (0x40000000) -#define INTC_IPRH_INT63 (0x80000000) - -/* Bit definitions and macros for IPRL */ -#define INTC_IPRL_INT0 (0x00000001) -#define INTC_IPRL_INT1 (0x00000002) -#define INTC_IPRL_INT2 (0x00000004) -#define INTC_IPRL_INT3 (0x00000008) -#define INTC_IPRL_INT4 (0x00000010) -#define INTC_IPRL_INT5 (0x00000020) -#define INTC_IPRL_INT6 (0x00000040) -#define INTC_IPRL_INT7 (0x00000080) -#define INTC_IPRL_INT8 (0x00000100) -#define INTC_IPRL_INT9 (0x00000200) -#define INTC_IPRL_INT10 (0x00000400) -#define INTC_IPRL_INT11 (0x00000800) -#define INTC_IPRL_INT12 (0x00001000) -#define INTC_IPRL_INT13 (0x00002000) -#define INTC_IPRL_INT14 (0x00004000) -#define INTC_IPRL_INT15 (0x00008000) -#define INTC_IPRL_INT16 (0x00010000) -#define INTC_IPRL_INT17 (0x00020000) -#define INTC_IPRL_INT18 (0x00040000) -#define INTC_IPRL_INT19 (0x00080000) -#define INTC_IPRL_INT20 (0x00100000) -#define INTC_IPRL_INT21 (0x00200000) -#define INTC_IPRL_INT22 (0x00400000) -#define INTC_IPRL_INT23 (0x00800000) -#define INTC_IPRL_INT24 (0x01000000) -#define INTC_IPRL_INT25 (0x02000000) -#define INTC_IPRL_INT26 (0x04000000) -#define INTC_IPRL_INT27 (0x08000000) -#define INTC_IPRL_INT28 (0x10000000) -#define INTC_IPRL_INT29 (0x20000000) -#define INTC_IPRL_INT30 (0x40000000) -#define INTC_IPRL_INT31 (0x80000000) - -/* Bit definitions and macros for IMRH */ -#define INTC_IMRH_INT_MASK32 (0x00000001) -#define INTC_IMRH_INT_MASK33 (0x00000002) -#define INTC_IMRH_INT_MASK34 (0x00000004) -#define INTC_IMRH_INT_MASK35 (0x00000008) -#define INTC_IMRH_INT_MASK36 (0x00000010) -#define INTC_IMRH_INT_MASK37 (0x00000020) -#define INTC_IMRH_INT_MASK38 (0x00000040) -#define INTC_IMRH_INT_MASK39 (0x00000080) -#define INTC_IMRH_INT_MASK40 (0x00000100) -#define INTC_IMRH_INT_MASK41 (0x00000200) -#define INTC_IMRH_INT_MASK42 (0x00000400) -#define INTC_IMRH_INT_MASK43 (0x00000800) -#define INTC_IMRH_INT_MASK44 (0x00001000) -#define INTC_IMRH_INT_MASK45 (0x00002000) -#define INTC_IMRH_INT_MASK46 (0x00004000) -#define INTC_IMRH_INT_MASK47 (0x00008000) -#define INTC_IMRH_INT_MASK48 (0x00010000) -#define INTC_IMRH_INT_MASK49 (0x00020000) -#define INTC_IMRH_INT_MASK50 (0x00040000) -#define INTC_IMRH_INT_MASK51 (0x00080000) -#define INTC_IMRH_INT_MASK52 (0x00100000) -#define INTC_IMRH_INT_MASK53 (0x00200000) -#define INTC_IMRH_INT_MASK54 (0x00400000) -#define INTC_IMRH_INT_MASK55 (0x00800000) -#define INTC_IMRH_INT_MASK56 (0x01000000) -#define INTC_IMRH_INT_MASK57 (0x02000000) -#define INTC_IMRH_INT_MASK58 (0x04000000) -#define INTC_IMRH_INT_MASK59 (0x08000000) -#define INTC_IMRH_INT_MASK60 (0x10000000) -#define INTC_IMRH_INT_MASK61 (0x20000000) -#define INTC_IMRH_INT_MASK62 (0x40000000) -#define INTC_IMRH_INT_MASK63 (0x80000000) - -/* Bit definitions and macros for IMRL */ -#define INTC_IMRL_INT_MASK0 (0x00000001) -#define INTC_IMRL_INT_MASK1 (0x00000002) -#define INTC_IMRL_INT_MASK2 (0x00000004) -#define INTC_IMRL_INT_MASK3 (0x00000008) -#define INTC_IMRL_INT_MASK4 (0x00000010) -#define INTC_IMRL_INT_MASK5 (0x00000020) -#define INTC_IMRL_INT_MASK6 (0x00000040) -#define INTC_IMRL_INT_MASK7 (0x00000080) -#define INTC_IMRL_INT_MASK8 (0x00000100) -#define INTC_IMRL_INT_MASK9 (0x00000200) -#define INTC_IMRL_INT_MASK10 (0x00000400) -#define INTC_IMRL_INT_MASK11 (0x00000800) -#define INTC_IMRL_INT_MASK12 (0x00001000) -#define INTC_IMRL_INT_MASK13 (0x00002000) -#define INTC_IMRL_INT_MASK14 (0x00004000) -#define INTC_IMRL_INT_MASK15 (0x00008000) -#define INTC_IMRL_INT_MASK16 (0x00010000) -#define INTC_IMRL_INT_MASK17 (0x00020000) -#define INTC_IMRL_INT_MASK18 (0x00040000) -#define INTC_IMRL_INT_MASK19 (0x00080000) -#define INTC_IMRL_INT_MASK20 (0x00100000) -#define INTC_IMRL_INT_MASK21 (0x00200000) -#define INTC_IMRL_INT_MASK22 (0x00400000) -#define INTC_IMRL_INT_MASK23 (0x00800000) -#define INTC_IMRL_INT_MASK24 (0x01000000) -#define INTC_IMRL_INT_MASK25 (0x02000000) -#define INTC_IMRL_INT_MASK26 (0x04000000) -#define INTC_IMRL_INT_MASK27 (0x08000000) -#define INTC_IMRL_INT_MASK28 (0x10000000) -#define INTC_IMRL_INT_MASK29 (0x20000000) -#define INTC_IMRL_INT_MASK30 (0x40000000) -#define INTC_IMRL_INT_MASK31 (0x80000000) - -/* Bit definitions and macros for INTFRCH */ -#define INTC_INTFRCH_INTFRC32 (0x00000001) -#define INTC_INTFRCH_INTFRC33 (0x00000002) -#define INTC_INTFRCH_INTFRC34 (0x00000004) -#define INTC_INTFRCH_INTFRC35 (0x00000008) -#define INTC_INTFRCH_INTFRC36 (0x00000010) -#define INTC_INTFRCH_INTFRC37 (0x00000020) -#define INTC_INTFRCH_INTFRC38 (0x00000040) -#define INTC_INTFRCH_INTFRC39 (0x00000080) -#define INTC_INTFRCH_INTFRC40 (0x00000100) -#define INTC_INTFRCH_INTFRC41 (0x00000200) -#define INTC_INTFRCH_INTFRC42 (0x00000400) -#define INTC_INTFRCH_INTFRC43 (0x00000800) -#define INTC_INTFRCH_INTFRC44 (0x00001000) -#define INTC_INTFRCH_INTFRC45 (0x00002000) -#define INTC_INTFRCH_INTFRC46 (0x00004000) -#define INTC_INTFRCH_INTFRC47 (0x00008000) -#define INTC_INTFRCH_INTFRC48 (0x00010000) -#define INTC_INTFRCH_INTFRC49 (0x00020000) -#define INTC_INTFRCH_INTFRC50 (0x00040000) -#define INTC_INTFRCH_INTFRC51 (0x00080000) -#define INTC_INTFRCH_INTFRC52 (0x00100000) -#define INTC_INTFRCH_INTFRC53 (0x00200000) -#define INTC_INTFRCH_INTFRC54 (0x00400000) -#define INTC_INTFRCH_INTFRC55 (0x00800000) -#define INTC_INTFRCH_INTFRC56 (0x01000000) -#define INTC_INTFRCH_INTFRC57 (0x02000000) -#define INTC_INTFRCH_INTFRC58 (0x04000000) -#define INTC_INTFRCH_INTFRC59 (0x08000000) -#define INTC_INTFRCH_INTFRC60 (0x10000000) -#define INTC_INTFRCH_INTFRC61 (0x20000000) -#define INTC_INTFRCH_INTFRC62 (0x40000000) -#define INTC_INTFRCH_INTFRC63 (0x80000000) - -/* Bit definitions and macros for INTFRCL */ -#define INTC_INTFRCL_INTFRC0 (0x00000001) -#define INTC_INTFRCL_INTFRC1 (0x00000002) -#define INTC_INTFRCL_INTFRC2 (0x00000004) -#define INTC_INTFRCL_INTFRC3 (0x00000008) -#define INTC_INTFRCL_INTFRC4 (0x00000010) -#define INTC_INTFRCL_INTFRC5 (0x00000020) -#define INTC_INTFRCL_INTFRC6 (0x00000040) -#define INTC_INTFRCL_INTFRC7 (0x00000080) -#define INTC_INTFRCL_INTFRC8 (0x00000100) -#define INTC_INTFRCL_INTFRC9 (0x00000200) -#define INTC_INTFRCL_INTFRC10 (0x00000400) -#define INTC_INTFRCL_INTFRC11 (0x00000800) -#define INTC_INTFRCL_INTFRC12 (0x00001000) -#define INTC_INTFRCL_INTFRC13 (0x00002000) -#define INTC_INTFRCL_INTFRC14 (0x00004000) -#define INTC_INTFRCL_INTFRC15 (0x00008000) -#define INTC_INTFRCL_INTFRC16 (0x00010000) -#define INTC_INTFRCL_INTFRC17 (0x00020000) -#define INTC_INTFRCL_INTFRC18 (0x00040000) -#define INTC_INTFRCL_INTFRC19 (0x00080000) -#define INTC_INTFRCL_INTFRC20 (0x00100000) -#define INTC_INTFRCL_INTFRC21 (0x00200000) -#define INTC_INTFRCL_INTFRC22 (0x00400000) -#define INTC_INTFRCL_INTFRC23 (0x00800000) -#define INTC_INTFRCL_INTFRC24 (0x01000000) -#define INTC_INTFRCL_INTFRC25 (0x02000000) -#define INTC_INTFRCL_INTFRC26 (0x04000000) -#define INTC_INTFRCL_INTFRC27 (0x08000000) -#define INTC_INTFRCL_INTFRC28 (0x10000000) -#define INTC_INTFRCL_INTFRC29 (0x20000000) -#define INTC_INTFRCL_INTFRC30 (0x40000000) -#define INTC_INTFRCL_INTFRC31 (0x80000000) - -/* Bit definitions and macros for ICONFIG */ -#define INTC_ICONFIG_EMASK (0x0020) -#define INTC_ICONFIG_ELVLPRI1 (0x0200) -#define INTC_ICONFIG_ELVLPRI2 (0x0400) -#define INTC_ICONFIG_ELVLPRI3 (0x0800) -#define INTC_ICONFIG_ELVLPRI4 (0x1000) -#define INTC_ICONFIG_ELVLPRI5 (0x2000) -#define INTC_ICONFIG_ELVLPRI6 (0x4000) -#define INTC_ICONFIG_ELVLPRI7 (0x8000) - -/* Bit definitions and macros for SIMR */ -#define INTC_SIMR_SIMR(x) (((x)&0x7F)) - -/* Bit definitions and macros for CIMR */ -#define INTC_CIMR_CIMR(x) (((x)&0x7F)) - -/* Bit definitions and macros for CLMASK */ -#define INTC_CLMASK_CLMASK(x) (((x)&0x0F)) - -/* Bit definitions and macros for SLMASK */ -#define INTC_SLMASK_SLMASK(x) (((x)&0x0F)) - -/* Bit definitions and macros for ICR group */ -#define INTC_ICR_IL(x) (((x)&0x07)) - -/********************************************************************* -* Edge Port Module (EPORT) -*********************************************************************/ - -/* Bit definitions and macros for EPPAR */ -#define EPORT_EPPAR_EPPA1(x) (((x)&0x0003)<<2) -#define EPORT_EPPAR_EPPA2(x) (((x)&0x0003)<<4) -#define EPORT_EPPAR_EPPA3(x) (((x)&0x0003)<<6) -#define EPORT_EPPAR_EPPA4(x) (((x)&0x0003)<<8) -#define EPORT_EPPAR_EPPA5(x) (((x)&0x0003)<<10) -#define EPORT_EPPAR_EPPA6(x) (((x)&0x0003)<<12) -#define EPORT_EPPAR_EPPA7(x) (((x)&0x0003)<<14) -#define EPORT_EPPAR_LEVEL (0) -#define EPORT_EPPAR_RISING (1) -#define EPORT_EPPAR_FALLING (2) -#define EPORT_EPPAR_BOTH (3) -#define EPORT_EPPAR_EPPA7_LEVEL (0x0000) -#define EPORT_EPPAR_EPPA7_RISING (0x4000) -#define EPORT_EPPAR_EPPA7_FALLING (0x8000) -#define EPORT_EPPAR_EPPA7_BOTH (0xC000) -#define EPORT_EPPAR_EPPA6_LEVEL (0x0000) -#define EPORT_EPPAR_EPPA6_RISING (0x1000) -#define EPORT_EPPAR_EPPA6_FALLING (0x2000) -#define EPORT_EPPAR_EPPA6_BOTH (0x3000) -#define EPORT_EPPAR_EPPA5_LEVEL (0x0000) -#define EPORT_EPPAR_EPPA5_RISING (0x0400) -#define EPORT_EPPAR_EPPA5_FALLING (0x0800) -#define EPORT_EPPAR_EPPA5_BOTH (0x0C00) -#define EPORT_EPPAR_EPPA4_LEVEL (0x0000) -#define EPORT_EPPAR_EPPA4_RISING (0x0100) -#define EPORT_EPPAR_EPPA4_FALLING (0x0200) -#define EPORT_EPPAR_EPPA4_BOTH (0x0300) -#define EPORT_EPPAR_EPPA3_LEVEL (0x0000) -#define EPORT_EPPAR_EPPA3_RISING (0x0040) -#define EPORT_EPPAR_EPPA3_FALLING (0x0080) -#define EPORT_EPPAR_EPPA3_BOTH (0x00C0) -#define EPORT_EPPAR_EPPA2_LEVEL (0x0000) -#define EPORT_EPPAR_EPPA2_RISING (0x0010) -#define EPORT_EPPAR_EPPA2_FALLING (0x0020) -#define EPORT_EPPAR_EPPA2_BOTH (0x0030) -#define EPORT_EPPAR_EPPA1_LEVEL (0x0000) -#define EPORT_EPPAR_EPPA1_RISING (0x0004) -#define EPORT_EPPAR_EPPA1_FALLING (0x0008) -#define EPORT_EPPAR_EPPA1_BOTH (0x000C) - -/* Bit definitions and macros for EPDDR */ -#define EPORT_EPDDR_EPDD1 (0x02) -#define EPORT_EPDDR_EPDD2 (0x04) -#define EPORT_EPDDR_EPDD3 (0x08) -#define EPORT_EPDDR_EPDD4 (0x10) -#define EPORT_EPDDR_EPDD5 (0x20) -#define EPORT_EPDDR_EPDD6 (0x40) -#define EPORT_EPDDR_EPDD7 (0x80) - -/* Bit definitions and macros for EPIER */ -#define EPORT_EPIER_EPIE1 (0x02) -#define EPORT_EPIER_EPIE2 (0x04) -#define EPORT_EPIER_EPIE3 (0x08) -#define EPORT_EPIER_EPIE4 (0x10) -#define EPORT_EPIER_EPIE5 (0x20) -#define EPORT_EPIER_EPIE6 (0x40) -#define EPORT_EPIER_EPIE7 (0x80) - -/* Bit definitions and macros for EPDR */ -#define EPORT_EPDR_EPD1 (0x02) -#define EPORT_EPDR_EPD2 (0x04) -#define EPORT_EPDR_EPD3 (0x08) -#define EPORT_EPDR_EPD4 (0x10) -#define EPORT_EPDR_EPD5 (0x20) -#define EPORT_EPDR_EPD6 (0x40) -#define EPORT_EPDR_EPD7 (0x80) - -/* Bit definitions and macros for EPPDR */ -#define EPORT_EPPDR_EPPD1 (0x02) -#define EPORT_EPPDR_EPPD2 (0x04) -#define EPORT_EPPDR_EPPD3 (0x08) -#define EPORT_EPPDR_EPPD4 (0x10) -#define EPORT_EPPDR_EPPD5 (0x20) -#define EPORT_EPPDR_EPPD6 (0x40) -#define EPORT_EPPDR_EPPD7 (0x80) - -/* Bit definitions and macros for EPFR */ -#define EPORT_EPFR_EPF1 (0x02) -#define EPORT_EPFR_EPF2 (0x04) -#define EPORT_EPFR_EPF3 (0x08) -#define EPORT_EPFR_EPF4 (0x10) -#define EPORT_EPFR_EPF5 (0x20) -#define EPORT_EPFR_EPF6 (0x40) -#define EPORT_EPFR_EPF7 (0x80) - /********************************************************************* * Watchdog Timer Modules (WTM) *********************************************************************/ @@ -1040,24 +721,6 @@ #define GPIO_DSCR_ATA_ATA_LOAD_10PF (0x00)
/********************************************************************* -* Random Number Generator (RNG) -*********************************************************************/ - -/* Bit definitions and macros for RNGCR */ -#define RNG_RNGCR_GO (0x00000001) -#define RNG_RNGCR_HA (0x00000002) -#define RNG_RNGCR_IM (0x00000004) -#define RNG_RNGCR_CI (0x00000008) - -/* Bit definitions and macros for RNGSR */ -#define RNG_RNGSR_SV (0x00000001) -#define RNG_RNGSR_LRS (0x00000002) -#define RNG_RNGSR_FUF (0x00000004) -#define RNG_RNGSR_EI (0x00000008) -#define RNG_RNGSR_OFL(x) (((x)&0x000000FF)<<8) -#define RNG_RNGSR_OFS(x) (((x)&0x000000FF)<<16) - -/********************************************************************* * SDRAM Controller (SDRAMC) *********************************************************************/
diff --git a/include/asm-m68k/m547x_8x.h b/include/asm-m68k/m547x_8x.h index 2db8df2..23cee8e 100644 --- a/include/asm-m68k/m547x_8x.h +++ b/include/asm-m68k/m547x_8x.h @@ -305,74 +305,6 @@ #define INT0_HI_GPT1 (61) #define INT0_HI_GPT0 (62)
-/* Bit definitions and macros for IPRH */ -#define INTC_IPRH_INT32 (0x00000001) -#define INTC_IPRH_INT33 (0x00000002) -#define INTC_IPRH_INT34 (0x00000004) -#define INTC_IPRH_INT35 (0x00000008) -#define INTC_IPRH_INT36 (0x00000010) -#define INTC_IPRH_INT37 (0x00000020) -#define INTC_IPRH_INT38 (0x00000040) -#define INTC_IPRH_INT39 (0x00000080) -#define INTC_IPRH_INT40 (0x00000100) -#define INTC_IPRH_INT41 (0x00000200) -#define INTC_IPRH_INT42 (0x00000400) -#define INTC_IPRH_INT43 (0x00000800) -#define INTC_IPRH_INT44 (0x00001000) -#define INTC_IPRH_INT45 (0x00002000) -#define INTC_IPRH_INT46 (0x00004000) -#define INTC_IPRH_INT47 (0x00008000) -#define INTC_IPRH_INT48 (0x00010000) -#define INTC_IPRH_INT49 (0x00020000) -#define INTC_IPRH_INT50 (0x00040000) -#define INTC_IPRH_INT51 (0x00080000) -#define INTC_IPRH_INT52 (0x00100000) -#define INTC_IPRH_INT53 (0x00200000) -#define INTC_IPRH_INT54 (0x00400000) -#define INTC_IPRH_INT55 (0x00800000) -#define INTC_IPRH_INT56 (0x01000000) -#define INTC_IPRH_INT57 (0x02000000) -#define INTC_IPRH_INT58 (0x04000000) -#define INTC_IPRH_INT59 (0x08000000) -#define INTC_IPRH_INT60 (0x10000000) -#define INTC_IPRH_INT61 (0x20000000) -#define INTC_IPRH_INT62 (0x40000000) -#define INTC_IPRH_INT63 (0x80000000) - -/* Bit definitions and macros for IPRL */ -#define INTC_IPRL_INT0 (0x00000001) -#define INTC_IPRL_INT1 (0x00000002) -#define INTC_IPRL_INT2 (0x00000004) -#define INTC_IPRL_INT3 (0x00000008) -#define INTC_IPRL_INT4 (0x00000010) -#define INTC_IPRL_INT5 (0x00000020) -#define INTC_IPRL_INT6 (0x00000040) -#define INTC_IPRL_INT7 (0x00000080) -#define INTC_IPRL_INT8 (0x00000100) -#define INTC_IPRL_INT9 (0x00000200) -#define INTC_IPRL_INT10 (0x00000400) -#define INTC_IPRL_INT11 (0x00000800) -#define INTC_IPRL_INT12 (0x00001000) -#define INTC_IPRL_INT13 (0x00002000) -#define INTC_IPRL_INT14 (0x00004000) -#define INTC_IPRL_INT15 (0x00008000) -#define INTC_IPRL_INT16 (0x00010000) -#define INTC_IPRL_INT17 (0x00020000) -#define INTC_IPRL_INT18 (0x00040000) -#define INTC_IPRL_INT19 (0x00080000) -#define INTC_IPRL_INT20 (0x00100000) -#define INTC_IPRL_INT21 (0x00200000) -#define INTC_IPRL_INT22 (0x00400000) -#define INTC_IPRL_INT23 (0x00800000) -#define INTC_IPRL_INT24 (0x01000000) -#define INTC_IPRL_INT25 (0x02000000) -#define INTC_IPRL_INT26 (0x04000000) -#define INTC_IPRL_INT27 (0x08000000) -#define INTC_IPRL_INT28 (0x10000000) -#define INTC_IPRL_INT29 (0x20000000) -#define INTC_IPRL_INT30 (0x40000000) -#define INTC_IPRL_INT31 (0x80000000) - /********************************************************************* * General Purpose Timers (GPTMR) *********************************************************************/ diff --git a/include/configs/EB+MCF-EV123.h b/include/configs/EB+MCF-EV123.h index 876ec20..a13db7c 100644 --- a/include/configs/EB+MCF-EV123.h +++ b/include/configs/EB+MCF-EV123.h @@ -178,7 +178,7 @@ #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_SDRAM_BASE1 #define CONFIG_SYS_SDRAM_SIZE CONFIG_SYS_SDRAM_SIZE1
-#define CONFIG_SYS_FLASH_BASE 0xFFE00000 +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE #define CONFIG_SYS_INT_FLASH_BASE 0xF0000000 #define CONFIG_SYS_INT_FLASH_ENABLE 0x21
@@ -218,17 +218,13 @@ * Memory bank definitions */
-#define CONFIG_SYS_CS0_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_CS0_SIZE 2*1024*1024 -#define CONFIG_SYS_CS0_WIDTH 16 -#define CONFIG_SYS_CS0_RO 0 -#define CONFIG_SYS_CS0_WS 6 +#define CONFIG_SYS_CS0_BASE 0xFFE00000 +#define CONFIG_SYS_CS0_CTRL 0x00001980 +#define CONFIG_SYS_CS0_MASK 0x001F0001
#define CONFIG_SYS_CS3_BASE 0xE0000000 -#define CONFIG_SYS_CS3_SIZE 1*1024*1024 -#define CONFIG_SYS_CS3_WIDTH 16 -#define CONFIG_SYS_CS3_RO 0 -#define CONFIG_SYS_CS3_WS 6 +#define CONFIG_SYS_CS0_CTRL 0x00001980 +#define CONFIG_SYS_CS3_MASK 0x000F0001
/*----------------------------------------------------------------------- * Port configuration diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index e6c87ef..8c66f87 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -215,7 +215,7 @@ # define CONFIG_SYS_FLASH_PROTECTION /* "Real" (hardware) sectors protection */ #endif
-#define CONFIG_SYS_FLASH_BASE (CONFIG_SYS_CS0_BASE << 16) +#define CONFIG_SYS_FLASH_BASE (CONFIG_SYS_CS0_BASE)
/* Configuration for environment * Environment is embedded in u-boot in the second sector of the flash @@ -251,13 +251,13 @@ * CS7 - Available */ #ifdef NORFLASH_PS32BIT -# define CONFIG_SYS_CS0_BASE 0xFFC0 +# define CONFIG_SYS_CS0_BASE 0xFFC00000 # define CONFIG_SYS_CS0_MASK 0x003f0001 -# define CONFIG_SYS_CS0_CTRL 0x1D00 +# define CONFIG_SYS_CS0_CTRL 0x00001D00 #else -# define CONFIG_SYS_CS0_BASE 0xFFE0 +# define CONFIG_SYS_CS0_BASE 0xFFE00000 # define CONFIG_SYS_CS0_MASK 0x001f0001 -# define CONFIG_SYS_CS0_CTRL 0x1D80 +# define CONFIG_SYS_CS0_CTRL 0x00001D80 #endif
#endif /* _M5329EVB_H */ diff --git a/include/configs/M5249EVB.h b/include/configs/M5249EVB.h index 8699ef9..e3830e5 100644 --- a/include/configs/M5249EVB.h +++ b/include/configs/M5249EVB.h @@ -125,7 +125,7 @@ */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_SDRAM_SIZE 16 /* SDRAM size in MB */ -#define CONFIG_SYS_FLASH_BASE (CONFIG_SYS_CSAR0 << 16) +#define CONFIG_SYS_FLASH_BASE (CONFIG_SYS_CS0_BASE)
#if 0 /* test-only */ #define CONFIG_PRAM 512 /* test-only for SDRAM problem!!!!!!!!!!!!!!!!!!!! */ @@ -170,15 +170,15 @@ */
/* CS0 - AMD Flash, address 0xffc00000 */ -#define CONFIG_SYS_CSAR0 0xffe0 -#define CONFIG_SYS_CSCR0 0x1980 /* WS=0110, AA=1, PS=10 */ +#define CONFIG_SYS_CS0_BASE 0xffe00000 +#define CONFIG_SYS_CS0_CTRL 0x00001980 /* WS=0110, AA=1, PS=10 */ /** Note: There is a CSMR0/DRAM vector problem, need to disable C/I ***/ -#define CONFIG_SYS_CSMR0 0x003f0021 /* 4MB, AA=0, WP=0, C/I=1, V=1 */ +#define CONFIG_SYS_CS0_MASK 0x003f0021 /* 4MB, AA=0, WP=0, C/I=1, V=1 */
/* CS1 - FPGA, address 0xe0000000 */ -#define CONFIG_SYS_CSAR1 0xe000 -#define CONFIG_SYS_CSCR1 0x0d80 /* WS=0011, AA=1, PS=10 */ -#define CONFIG_SYS_CSMR1 0x00010001 /* 128kB, AA=0, WP=0, C/I=0, V=1*/ +#define CONFIG_SYS_CS1_BASE 0xe0000000 +#define CONFIG_SYS_CS1_CTRL 0x00000d80 /* WS=0011, AA=1, PS=10 */ +#define CONFIG_SYS_CS1_MASK 0x00010001 /* 128kB, AA=0, WP=0, C/I=0, V=1*/
/*----------------------------------------------------------------------- * Port configuration diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index 3a5c12f..378e45a 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -90,7 +90,7 @@
#define CONFIG_DRIVER_DM9000 #ifdef CONFIG_DRIVER_DM9000 -# define CONFIG_DM9000_BASE ((CONFIG_SYS_CSAR1 << 16) | 0x300) +# define CONFIG_DM9000_BASE (CONFIG_SYS_CS1_BASE | 0x300) # define DM9000_IO CONFIG_DM9000_BASE # define DM9000_DATA (CONFIG_DM9000_BASE + 4) # undef CONFIG_DM9000_DEBUG @@ -202,7 +202,7 @@ #define CONFIG_SYS_BOOTMAPSZ (CONFIG_SYS_SDRAM_BASE + (CONFIG_SYS_SDRAM_SIZE << 20))
/* FLASH organization */ -#define CONFIG_SYS_FLASH_BASE (CONFIG_SYS_CSAR0 << 16) +#define CONFIG_SYS_FLASH_BASE (CONFIG_SYS_CS0_BASE) #define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ #define CONFIG_SYS_MAX_FLASH_SECT 2048 /* max number of sectors on one chip */ #define CONFIG_SYS_FLASH_ERASE_TOUT 1000 @@ -233,21 +233,13 @@ /* Port configuration */ #define CONFIG_SYS_FECI2C 0xF0
-#define CONFIG_SYS_CSAR0 0xFF80 -#define CONFIG_SYS_CSMR0 0x007F0021 -#define CONFIG_SYS_CSCR0 0x1D80 +#define CONFIG_SYS_CS0_BASE 0xFF800000 +#define CONFIG_SYS_CS0_MASK 0x007F0021 +#define CONFIG_SYS_CS0_CTRL 0x00001D80
-#define CONFIG_SYS_CSAR1 0xE000 -#define CONFIG_SYS_CSMR1 0x00000001 -#define CONFIG_SYS_CSCR1 0x3DD8 - -#define CONFIG_SYS_CSAR2 0 -#define CONFIG_SYS_CSMR2 0 -#define CONFIG_SYS_CSCR2 0 - -#define CONFIG_SYS_CSAR3 0 -#define CONFIG_SYS_CSMR3 0 -#define CONFIG_SYS_CSCR3 0 +#define CONFIG_SYS_CS1_BASE 0xE0000000 +#define CONFIG_SYS_CS1_MASK 0x00000001 +#define CONFIG_SYS_CS1_CTRL 0x00003DD8
/*----------------------------------------------------------------------- * Port configuration diff --git a/include/configs/M5253EVBE.h b/include/configs/M5253EVBE.h index c2cd62b..86de97d 100644 --- a/include/configs/M5253EVBE.h +++ b/include/configs/M5253EVBE.h @@ -166,7 +166,7 @@ #define CONFIG_SYS_BOOTMAPSZ (CONFIG_SYS_SDRAM_BASE + (CONFIG_SYS_SDRAM_SIZE << 20))
/* FLASH organization */ -#define CONFIG_SYS_FLASH_BASE 0xffe00000 +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE #define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ #define CONFIG_SYS_MAX_FLASH_SECT 35 /* max number of sectors on one chip */ #define CONFIG_SYS_FLASH_ERASE_TOUT 1000 @@ -182,21 +182,9 @@ /* Port configuration */ #define CONFIG_SYS_FECI2C 0xF0
-#define CONFIG_SYS_CSAR0 0xFFE0 -#define CONFIG_SYS_CSMR0 0x001F0021 -#define CONFIG_SYS_CSCR0 0x1D80 - -#define CONFIG_SYS_CSAR1 0 -#define CONFIG_SYS_CSMR1 0 -#define CONFIG_SYS_CSCR1 0 - -#define CONFIG_SYS_CSAR2 0 -#define CONFIG_SYS_CSMR2 0 -#define CONFIG_SYS_CSCR2 0 - -#define CONFIG_SYS_CSAR3 0 -#define CONFIG_SYS_CSMR3 0 -#define CONFIG_SYS_CSCR3 0 +#define CONFIG_SYS_CS0_BASE 0xFFE00000 +#define CONFIG_SYS_CS0_MASK 0x001F0021 +#define CONFIG_SYS_CS0_CTRL 0x00001D80
/*----------------------------------------------------------------------- * Port configuration diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index 1f3539e..db48d76 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -173,7 +173,7 @@ */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_SDRAM_SIZE 16 /* SDRAM size in MB */ -#define CONFIG_SYS_FLASH_BASE 0xffe00000 +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE
#ifdef CONFIG_MONITOR_IS_IN_RAM #define CONFIG_SYS_MONITOR_BASE 0x20000 @@ -211,13 +211,13 @@ /*----------------------------------------------------------------------- * Memory bank definitions */ -#define CONFIG_SYS_AR0_PRELIM (CONFIG_SYS_FLASH_BASE >> 16) -#define CONFIG_SYS_CR0_PRELIM 0x1980 -#define CONFIG_SYS_MR0_PRELIM 0x001F0001 +#define CONFIG_SYS_CS0_BASE 0xffe00000 +#define CONFIG_SYS_CS0_CTRL 0x00001980 +#define CONFIG_SYS_CS0_MASK 0x001F0001
-#define CONFIG_SYS_AR1_PRELIM 0x3000 -#define CONFIG_SYS_CR1_PRELIM 0x1900 -#define CONFIG_SYS_MR1_PRELIM 0x00070001 +#define CONFIG_SYS_CS1_BASE 0x30000000 +#define CONFIG_SYS_CS1_CTRL 0x00001900 +#define CONFIG_SYS_CS1_MASK 0x00070001
/*----------------------------------------------------------------------- * Port configuration diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index a8a2655..15590cf 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -165,7 +165,7 @@ */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_SDRAM_SIZE 16 /* SDRAM size in MB */ -#define CONFIG_SYS_FLASH_BASE 0xffe00000 +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE #define CONFIG_SYS_INT_FLASH_BASE 0xf0000000 #define CONFIG_SYS_INT_FLASH_ENABLE 0x21
@@ -212,18 +212,10 @@ /*----------------------------------------------------------------------- * Memory bank definitions */ -#define CONFIG_SYS_CS0_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_CS0_SIZE 2*1024*1024 -#define CONFIG_SYS_CS0_WIDTH 16 -#define CONFIG_SYS_CS0_RO 0 -#define CONFIG_SYS_CS0_WS 6 -/* -#define CONFIG_SYS_CS3_BASE 0xE0000000 -#define CONFIG_SYS_CS3_SIZE 1*1024*1024 -#define CONFIG_SYS_CS3_WIDTH 16 -#define CONFIG_SYS_CS3_RO 0 -#define CONFIG_SYS_CS3_WS 6 -*/ +#define CONFIG_SYS_CS0_BASE 0xFFE00000 +#define CONFIG_SYS_CS0_CTRL 0x00001980 +#define CONFIG_SYS_CS0_MASK 0x001F0001 + /*----------------------------------------------------------------------- * Port configuration */ diff --git a/include/configs/TASREG.h b/include/configs/TASREG.h index 18ffbfd..25f3a26 100644 --- a/include/configs/TASREG.h +++ b/include/configs/TASREG.h @@ -206,7 +206,7 @@ */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_SDRAM_SIZE 16 /* SDRAM size in MB */ -#define CONFIG_SYS_FLASH_BASE 0xffc00000 +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE
#if 0 /* test-only */ #define CONFIG_PRAM 512 /* test-only for SDRAM problem!!!!!!!!!!!!!!!!!!!! */ @@ -257,15 +257,15 @@ */
/* CS0 - AMD Flash, address 0xffc00000 */ -#define CONFIG_SYS_CSAR0 0xffc0 -#define CONFIG_SYS_CSCR0 0x1980 /* WS=0110, AA=1, PS=10 */ +#define CONFIG_SYS_CS0_BASE 0xffc00000 +#define CONFIG_SYS_CS0_CTRL 0x00001980 /* WS=0110, AA=1, PS=10 */ /** Note: There is a CSMR0/DRAM vector problem, need to disable C/I ***/ -#define CONFIG_SYS_CSMR0 0x003f0021 /* 4MB, AA=0, WP=0, C/I=1, V=1 */ +#define CONFIG_SYS_CS0_MASK 0x003f0021 /* 4MB, AA=0, WP=0, C/I=1, V=1 */
Tsi-Chung Liew
